[GRASS-SVN] r72778 - in grass/trunk: . include
svn_grass at osgeo.org
Wed Jun 6 12:15:27 PDT 2018
Author: mmetz
Date: 2018-06-06 12:15:27 -0700 (Wed, 06 Jun 2018)
New Revision: 72778
grass/trunk/configure
grass/trunk/configure.in
grass/trunk/include/config.h.in
configure: use new PROJ API only with proj-5.1.x or higher, otherwise fall back to old PROJ.4 API
Modified: grass/trunk/configure
--- grass/trunk/configure 2018-06-06 17:51:47 UTC (rev 72777)
+++ grass/trunk/configure 2018-06-06 19:15:27 UTC (rev 72778)
@@ -5761,6 +5761,126 @@
if test $PROJ4API = 0 ; then
+echo $ac_n "checking External PROJ major version""... $ac_c" 1>&6
+echo "configure:5767: checking External PROJ major version" >&5
+ac_save_cppflags="$CPPFLAGS"
+CPPFLAGS="$PROJINC $CPPFLAGS"
+if test "$cross_compiling" = yes; then
+ proj_ver_major=0
+ echo "$ac_t""unknown (cross-compiling)" 1>&6
+else
+ cat > conftest.$ac_ext <<EOF
+#line 5775 "configure"
+#include "confdefs.h"
+#include <stdio.h>
+#include <proj.h>
+int main(void) {
+ FILE *fp = fopen("conftestdata","w");
+ fprintf(fp, "%d", PROJ_VERSION_MAJOR);
+ return 0;
+EOF
+if { (eval echo configure:5787: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+then
+ proj_ver_major=`cat conftestdata`
+ echo "$ac_t""$proj_ver_major" 1>&6
+else
+ echo "configure: failed program was:" >&5
+ cat conftest.$ac_ext >&5
+ rm -fr conftest*
+ { echo "configure: error: *** Could not determine External PROJ major version." 1>&2; exit 1; }
+fi
+rm -fr conftest*
+fi
+CPPFLAGS=$ac_save_cppflags
+echo $ac_n "checking External PROJ minor version""... $ac_c" 1>&6
+echo "configure:5804: checking External PROJ minor version" >&5
+ proj_ver_minor=0
+else
+#line 5812 "configure"
+#include <stdio.h>
+#include <proj.h>
+int main(void) {
+ fprintf(fp, "%d", PROJ_VERSION_MINOR);
+ return 0;
+EOF
+if { (eval echo configure:5824: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+then
+ proj_ver_minor=`cat conftestdata`
+ echo "$ac_t""$proj_ver_minor" 1>&6
+else
+ rm -fr conftest*
+ { echo "configure: error: *** Could not determine External PROJ minor version." 1>&2; exit 1; }
+fi
+rm -fr conftest*
+fi
+echo $ac_n "checking External PROJ patch version""... $ac_c" 1>&6
+echo "configure:5841: checking External PROJ patch version" >&5
+ proj_ver_patch=0
+else
+#line 5849 "configure"
+#include <stdio.h>
+#include <proj.h>
+int main(void) {
+ fprintf(fp, "%d", PROJ_VERSION_PATCH);
+ return 0;
+EOF
+if { (eval echo configure:5861: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+then
+ proj_ver_patch=`cat conftestdata`
+ echo "$ac_t""$proj_ver_patch" 1>&6
+else
+ rm -fr conftest*
+ { echo "configure: error: *** Could not determine External PROJ patch version." 1>&2; exit 1; }
+fi
+rm -fr conftest*
+fi
+ echo "$ac_t""found PROJ version "${proj_ver_major}.${proj_ver_minor}.${proj_ver_patch}"" 1>&6
+ # minimum required PROJ 5+ version to use the new PROJ API: 5.1.0
+ if test ${proj_ver_major} = 5 && test `expr "proj_ver_minor" \< 1` = 1 ; then
+ echo "configure: warning: At least PROJ version "5.1.0" is required for the new API " 1>&2
+ PROJ4API=1
+ fi
+fi
+if test $PROJ4API = 0 ; then
echo "$ac_t""using new PROJ version 5+ API" 1>&6
# With PROJ library directory
@@ -5767,7 +5887,7 @@
echo $ac_n "checking for location of External PROJ library""... $ac_c" 1>&6
-echo "configure:5771: checking for location of External PROJ library" >&5
+echo "configure:5891: checking for location of External PROJ library" >&5
case "$with_proj_libs" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-proj-libs." 1>&2; exit 1; }
@@ -5791,13 +5911,13 @@
echo $ac_n "checking for proj_pj_info in -lproj""... $ac_c" 1>&6
-echo "configure:5795: checking for proj_pj_info in -lproj" >&5
+echo "configure:5915: checking for proj_pj_info in -lproj" >&5
ac_lib_var=`echo proj'_'proj_pj_info | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-lproj $LIBS"
-#line 5801 "configure"
+#line 5921 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -5808,7 +5928,7 @@
proj_pj_info()
; return 0; }
EOF
-if { (eval echo configure:5812: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5932: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -5839,7 +5959,11 @@
else
echo "$ac_t""using old PROJ version 4 API" 1>&6
+ cat >> confdefs.h <<\EOF
+#define USE_PROJ4API 1
+EOF
@@ -5847,15 +5971,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:5851: checking for $ac_hdr" >&5
+echo "configure:5975: checking for $ac_hdr" >&5
-#line 5854 "configure"
+#line 5978 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:5859: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5983: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -5891,7 +6015,7 @@
else
echo $ac_n "checking External PROJ.4 version""... $ac_c" 1>&6
-echo "configure:5895: checking External PROJ.4 version" >&5
+echo "configure:6019: checking External PROJ.4 version" >&5
@@ -5899,7 +6023,7 @@
else
-#line 5903 "configure"
+#line 6027 "configure"
#include <stdio.h>
@@ -5911,7 +6035,7 @@
EOF
-if { (eval echo configure:5915: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:6039: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
proj_ver=`cat conftestdata`
echo "$ac_t""$proj_ver" 1>&6
@@ -5936,7 +6060,7 @@
echo $ac_n "checking for location of External PROJ.4 library""... $ac_c" 1>&6
-echo "configure:5940: checking for location of External PROJ.4 library" >&5
+echo "configure:6064: checking for location of External PROJ.4 library" >&5
@@ -5960,13 +6084,13 @@
echo $ac_n "checking for pj_get_def in -lproj""... $ac_c" 1>&6
-echo "configure:5964: checking for pj_get_def in -lproj" >&5
+echo "configure:6088: checking for pj_get_def in -lproj" >&5
ac_lib_var=`echo proj'_'pj_get_def | sed 'y%./+-%__p_%'`
LIBS="-lproj $LIBS"
-#line 5970 "configure"
+#line 6094 "configure"
@@ -5977,7 +6101,7 @@
pj_get_def()
; return 0; }
EOF
-if { (eval echo configure:5981: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6105: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6012,7 +6136,7 @@
echo $ac_n "checking for location of External PROJ data files""... $ac_c" 1>&6
-echo "configure:6016: checking for location of External PROJ data files" >&5
+echo "configure:6140: checking for location of External PROJ data files" >&5
case "$with_proj_share" in
{ echo "configure: error: *** You must supply a directory to --with-proj-share." 1>&2; exit 1; }
@@ -6036,7 +6160,7 @@
# LOC_CHECK_SHARE does not work when cross compiling
if test "$cross_compiling" = "yes" ; then
echo $ac_n "checking for epsg""... $ac_c" 1>&6
-echo "configure:6040: checking for epsg" >&5
+echo "configure:6164: checking for epsg" >&5
else
@@ -6043,7 +6167,7 @@
ac_safe=`echo "$PROJSHARE/epsg" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $PROJSHARE/epsg""... $ac_c" 1>&6
-echo "configure:6047: checking for $PROJSHARE/epsg" >&5
+echo "configure:6171: checking for $PROJSHARE/epsg" >&5
{ echo "configure: error: Cannot check for file existence when cross compiling" 1>&2; exit 1; }
@@ -6075,7 +6199,7 @@
# Extract the first word of "nad2bin", so it can be a program name with args.
set dummy nad2bin; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:6079: checking for $ac_word" >&5
+echo "configure:6203: checking for $ac_word" >&5
case "$NAD2BIN" in
@@ -6115,7 +6239,7 @@
echo $ac_n "checking whether to use regex""... $ac_c" 1>&6
-echo "configure:6119: checking whether to use regex" >&5
+echo "configure:6243: checking whether to use regex" >&5
echo "$ac_t"""$with_regex"" 1>&6
case "$with_regex" in
"no") USE_REGEX= ;;
@@ -6135,7 +6259,7 @@
echo $ac_n "checking for location of regex includes""... $ac_c" 1>&6
-echo "configure:6139: checking for location of regex includes" >&5
+echo "configure:6263: checking for location of regex includes" >&5
case "$with_regex_includes" in
{ echo "configure: error: *** You must supply a directory to --with-regex-includes." 1>&2; exit 1; }
@@ -6161,15 +6285,15 @@
do
-echo "configure:6165: checking for $ac_hdr" >&5
+echo "configure:6289: checking for $ac_hdr" >&5
-#line 6168 "configure"
+#line 6292 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:6173: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6297: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6203,7 +6327,7 @@
echo $ac_n "checking for location of regex library""... $ac_c" 1>&6
-echo "configure:6207: checking for location of regex library" >&5
+echo "configure:6331: checking for location of regex library" >&5
case "$with_regex_libs" in
{ echo "configure: error: *** You must supply a directory to --with-regex-libs." 1>&2; exit 1; }
@@ -6228,10 +6352,10 @@
LIBS=" $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for regcomp""... $ac_c" 1>&6
-echo "configure:6232: checking for regcomp" >&5
+echo "configure:6356: checking for regcomp" >&5
-#line 6235 "configure"
+#line 6359 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char regcomp(); below. */
@@ -6254,7 +6378,7 @@
; return 0; }
EOF
-if { (eval echo configure:6258: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6382: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_regcomp=yes"
else
@@ -6281,13 +6405,13 @@
echo $ac_n "checking for regcomp in -lregex""... $ac_c" 1>&6
-echo "configure:6285: checking for regcomp in -lregex" >&5
+echo "configure:6409: checking for regcomp in -lregex" >&5
ac_lib_var=`echo regex'_'regcomp | sed 'y%./+-%__p_%'`
LIBS="-lregex $LIBS"
-#line 6291 "configure"
+#line 6415 "configure"
@@ -6298,7 +6422,7 @@
regcomp()
; return 0; }
EOF
-if { (eval echo configure:6302: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6426: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6348,7 +6472,7 @@
echo $ac_n "checking whether to use Readline""... $ac_c" 1>&6
-echo "configure:6352: checking whether to use Readline" >&5
+echo "configure:6476: checking whether to use Readline" >&5
echo "$ac_t"""$with_readline"" 1>&6
case "$with_readline" in
"no") USE_READLINE= ;;
@@ -6369,7 +6493,7 @@
echo $ac_n "checking for location of Readline includes""... $ac_c" 1>&6
-echo "configure:6373: checking for location of Readline includes" >&5
+echo "configure:6497: checking for location of Readline includes" >&5
case "$with_readline_includes" in
{ echo "configure: error: *** You must supply a directory to --with-readline-includes." 1>&2; exit 1; }
@@ -6395,15 +6519,15 @@
do
-echo "configure:6399: checking for $ac_hdr" >&5
+echo "configure:6523: checking for $ac_hdr" >&5
-#line 6402 "configure"
+#line 6526 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:6407: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6531: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6439,15 +6563,15 @@
do
-echo "configure:6443: checking for $ac_hdr" >&5
+echo "configure:6567: checking for $ac_hdr" >&5
-#line 6446 "configure"
+#line 6570 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:6451: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6575: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6481,7 +6605,7 @@
echo $ac_n "checking for location of Readline library""... $ac_c" 1>&6
-echo "configure:6485: checking for location of Readline library" >&5
+echo "configure:6609: checking for location of Readline library" >&5
case "$with_readline_libs" in
{ echo "configure: error: *** You must supply a directory to --with-readline-libs." 1>&2; exit 1; }
@@ -6506,13 +6630,13 @@
echo $ac_n "checking for readline in -lreadline""... $ac_c" 1>&6
-echo "configure:6510: checking for readline in -lreadline" >&5
+echo "configure:6634: checking for readline in -lreadline" >&5
ac_lib_var=`echo readline'_'readline | sed 'y%./+-%__p_%'`
LIBS="-lreadline $LIBS"
-#line 6516 "configure"
+#line 6640 "configure"
@@ -6523,7 +6647,7 @@
readline()
; return 0; }
EOF
-if { (eval echo configure:6527: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6651: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6558,13 +6682,13 @@
echo $ac_n "checking for add_history in -lhistory""... $ac_c" 1>&6
-echo "configure:6562: checking for add_history in -lhistory" >&5
+echo "configure:6686: checking for add_history in -lhistory" >&5
ac_lib_var=`echo history'_'add_history | sed 'y%./+-%__p_%'`
LIBS="-lhistory $LIBS"
-#line 6568 "configure"
+#line 6692 "configure"
@@ -6575,7 +6699,7 @@
add_history()
; return 0; }
EOF
-if { (eval echo configure:6579: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6703: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6617,7 +6741,7 @@
# GDAL option
echo $ac_n "checking whether to use GDAL""... $ac_c" 1>&6
-echo "configure:6621: checking whether to use GDAL" >&5
+echo "configure:6745: checking whether to use GDAL" >&5
GDAL_LIBS=
GDAL_CFLAGS=
@@ -6635,7 +6759,7 @@
# Extract the first word of "gdal-config", so it can be a program name with args.
set dummy gdal-config; ac_word=$2
-echo "configure:6639: checking for $ac_word" >&5
+echo "configure:6763: checking for $ac_word" >&5
case "$GDAL_CONFIG" in
@@ -6690,7 +6814,7 @@
LIBS="$LIBS $GDAL_LIBS"
CFLAGS="$CFLAGS $GDAL_CFLAGS"
-#line 6694 "configure"
+#line 6818 "configure"
#include <gdal.h>
int main() {
@@ -6697,7 +6821,7 @@
GDALOpen("foo", GA_ReadOnly);
; return 0; }
EOF
-if { (eval echo configure:6701: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6825: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
else
@@ -6706,7 +6830,7 @@
LIBS="$LIBS $GDAL_DEP_LIBS"
-#line 6710 "configure"
+#line 6834 "configure"
#include <gdal.h>
int main() {
@@ -6713,7 +6837,7 @@
; return 0; }
EOF
-if { (eval echo configure:6717: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6841: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
GDAL_LIBS="$GDAL_LIBS $GDAL_DEP_LIBS"
else
@@ -6745,7 +6869,7 @@
# libLAS option
echo $ac_n "checking whether to use libLAS""... $ac_c" 1>&6
-echo "configure:6749: checking whether to use libLAS" >&5
+echo "configure:6873: checking whether to use libLAS" >&5
LIBLAS_LIBS=
LIBLAS_CFLAGS=
@@ -6762,7 +6886,7 @@
# Extract the first word of "liblas-config", so it can be a program name with args.
set dummy liblas-config; ac_word=$2
-echo "configure:6766: checking for $ac_word" >&5
+echo "configure:6890: checking for $ac_word" >&5
case "$LIBLAS_CONFIG" in
@@ -6815,15 +6939,15 @@
do
-echo "configure:6819: checking for $ac_hdr" >&5
+echo "configure:6943: checking for $ac_hdr" >&5
-#line 6822 "configure"
+#line 6946 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:6827: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6951: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6849,7 +6973,7 @@
done
-#line 6853 "configure"
+#line 6977 "configure"
#include <liblas/capi/liblas.h>
int main() {
@@ -6856,7 +6980,7 @@
LASReader_Create("foo");
; return 0; }
EOF
-if { (eval echo configure:6860: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6984: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
else
@@ -6864,7 +6988,7 @@
rm -rf conftest*
-#line 6868 "configure"
+#line 6992 "configure"
int main() {
@@ -6871,7 +6995,7 @@
; return 0; }
EOF
-if { (eval echo configure:6875: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6999: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
LAS_LIBS="$LAS_LIBS"
else
@@ -6904,7 +7028,7 @@
# PDAL option
echo $ac_n "checking whether to use PDAL""... $ac_c" 1>&6
-echo "configure:6908: checking whether to use PDAL" >&5
+echo "configure:7032: checking whether to use PDAL" >&5
# new and currently used way to switch language to C++
# AC_LANG_PUSH(C++)
@@ -6932,7 +7056,7 @@
# Extract the first word of "pdal-config", so it can be a program name with args.
set dummy pdal-config; ac_word=$2
-echo "configure:6936: checking for $ac_word" >&5
+echo "configure:7060: checking for $ac_word" >&5
case "$PDAL_CONFIG" in
@@ -6982,7 +7106,7 @@
CFLAGS="$CFLAGS $PDAL_CFLAGS"
CPPFLAGS="$CPPFLAGS $PDAL_CPPFLAGS $PDAL_INC"
-#line 6986 "configure"
+#line 7110 "configure"
#include <pdal/PointTable.hpp>
int main() {
@@ -6989,7 +7113,7 @@
pdal::PointTable table;
; return 0; }
EOF
-if { (eval echo configure:6993: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7117: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
else
@@ -6997,7 +7121,7 @@
rm -rf conftest*
-#line 7001 "configure"
+#line 7125 "configure"
int main() {
@@ -7004,7 +7128,7 @@
; return 0; }
EOF
-if { (eval echo configure:7008: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7132: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
PDAL_LIBS="$PDAL_LIBS"
else
@@ -7054,7 +7178,7 @@
# NetCDF option
echo $ac_n "checking whether to use NetCDF""... $ac_c" 1>&6
-echo "configure:7058: checking whether to use NetCDF" >&5
+echo "configure:7182: checking whether to use NetCDF" >&5
NETCDF_LIBS=
NETCDF_CFLAGS=
@@ -7071,7 +7195,7 @@
# Extract the first word of "nc-config", so it can be a program name with args.
set dummy nc-config; ac_word=$2
-echo "configure:7075: checking for $ac_word" >&5
+echo "configure:7199: checking for $ac_word" >&5
case "$NETCDF_CONFIG" in
@@ -7118,7 +7242,7 @@
LIBS="$LIBS $NETCDF_LIBS"
CFLAGS="$CFLAGS $NETCDF_CFLAGS"
-#line 7122 "configure"
+#line 7246 "configure"
#include <netcdf.h>
int main() {
@@ -7125,7 +7249,7 @@
nc_create("foo", NC_CLOBBER, NULL);
; return 0; }
EOF
-if { (eval echo configure:7129: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7253: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
else
@@ -7133,7 +7257,7 @@
rm -rf conftest*
-#line 7137 "configure"
+#line 7261 "configure"
#include <netcdf.h>
int main() {
@@ -7140,7 +7264,7 @@
; return 0; }
EOF
-if { (eval echo configure:7144: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7268: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
NETCDF_LIBS="$NETCDF_LIBS"
else
@@ -7171,7 +7295,7 @@
# GEOS option
echo $ac_n "checking whether to use GEOS""... $ac_c" 1>&6
-echo "configure:7175: checking whether to use GEOS" >&5
+echo "configure:7299: checking whether to use GEOS" >&5
GEOS_LIBS=
GEOS_CFLAGS=
@@ -7189,7 +7313,7 @@
# Extract the first word of "geos-config", so it can be a program name with args.
set dummy geos-config; ac_word=$2
-echo "configure:7193: checking for $ac_word" >&5
+echo "configure:7317: checking for $ac_word" >&5
case "$GEOS_CONFIG" in
@@ -7237,15 +7361,15 @@
do
-echo "configure:7241: checking for $ac_hdr" >&5
+echo "configure:7365: checking for $ac_hdr" >&5
-#line 7244 "configure"
+#line 7368 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7249: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7373: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7284,13 +7408,13 @@
echo $ac_n "checking for initGEOS in -lgeos_c""... $ac_c" 1>&6
-echo "configure:7288: checking for initGEOS in -lgeos_c" >&5
+echo "configure:7412: checking for initGEOS in -lgeos_c" >&5
ac_lib_var=`echo geos_c'_'initGEOS | sed 'y%./+-%__p_%'`
LIBS="-lgeos_c $LIBS"
-#line 7294 "configure"
+#line 7418 "configure"
@@ -7301,7 +7425,7 @@
initGEOS()
; return 0; }
EOF
-if { (eval echo configure:7305: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7429: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7345,7 +7469,7 @@
echo $ac_n "checking whether to use TIFF""... $ac_c" 1>&6
-echo "configure:7349: checking whether to use TIFF" >&5
+echo "configure:7473: checking whether to use TIFF" >&5
echo "$ac_t"""$with_tiff"" 1>&6
case "$with_tiff" in
"no") USE_TIFF= ;;
@@ -7365,7 +7489,7 @@
echo $ac_n "checking for location of TIFF includes""... $ac_c" 1>&6
-echo "configure:7369: checking for location of TIFF includes" >&5
+echo "configure:7493: checking for location of TIFF includes" >&5
case "$with_tiff_includes" in
{ echo "configure: error: *** You must supply a directory to --with-tiff-includes." 1>&2; exit 1; }
@@ -7391,15 +7515,15 @@
do
-echo "configure:7395: checking for $ac_hdr" >&5
+echo "configure:7519: checking for $ac_hdr" >&5
-#line 7398 "configure"
+#line 7522 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7403: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7527: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7433,7 +7557,7 @@
echo $ac_n "checking for location of TIFF library""... $ac_c" 1>&6
-echo "configure:7437: checking for location of TIFF library" >&5
+echo "configure:7561: checking for location of TIFF library" >&5
case "$with_tiff_libs" in
{ echo "configure: error: *** You must supply a directory to --with-tiff-libs." 1>&2; exit 1; }
@@ -7464,13 +7588,13 @@
echo $ac_n "checking for TIFFOpen in -ltiff""... $ac_c" 1>&6
-echo "configure:7468: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7592: checking for TIFFOpen in -ltiff" >&5
ac_lib_var=`echo tiff'_'TIFFOpen | sed 'y%./+-%__p_%'`
LIBS="-ltiff $LIBS"
-#line 7474 "configure"
+#line 7598 "configure"
@@ -7481,7 +7605,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7485: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7609: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7500,13 +7624,13 @@
echo "$ac_t""no" 1>&6
-echo "configure:7504: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7628: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $MATHLIB $LIBS"
-#line 7510 "configure"
+#line 7634 "configure"
@@ -7517,7 +7641,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7521: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7645: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7536,13 +7660,13 @@
-echo "configure:7540: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7664: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $ZLIB $LIBS"
-#line 7546 "configure"
+#line 7670 "configure"
@@ -7553,7 +7677,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7557: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7681: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7572,13 +7696,13 @@
-echo "configure:7576: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7700: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $ZLIB $MATHLIB $LIBS"
-#line 7582 "configure"
+#line 7706 "configure"
@@ -7589,7 +7713,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7593: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7717: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7608,13 +7732,13 @@
-echo "configure:7612: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7736: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff -ljpeg $LIBS"
-#line 7618 "configure"
+#line 7742 "configure"
@@ -7625,7 +7749,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7629: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7753: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7644,13 +7768,13 @@
-echo "configure:7648: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7772: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff -ljpeg $MATHLIB $LIBS"
-#line 7654 "configure"
+#line 7778 "configure"
@@ -7661,7 +7785,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7665: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7789: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7680,13 +7804,13 @@
-echo "configure:7684: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7808: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff -ljpeg $ZLIB $LIBS"
-#line 7690 "configure"
+#line 7814 "configure"
@@ -7697,7 +7821,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7701: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7825: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7716,13 +7840,13 @@
-echo "configure:7720: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7844: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff -ljpeg $ZLIB $MATHLIB $LIBS"
-#line 7726 "configure"
+#line 7850 "configure"
@@ -7733,7 +7857,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7737: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7861: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7831,7 +7955,7 @@
echo $ac_n "checking whether to use PNG""... $ac_c" 1>&6
-echo "configure:7835: checking whether to use PNG" >&5
+echo "configure:7959: checking whether to use PNG" >&5
echo "$ac_t"""$with_png"" 1>&6
case "$with_png" in
"no") USE_PNG= ;;
@@ -7850,7 +7974,7 @@
echo $ac_n "checking for location of PNG includes""... $ac_c" 1>&6
-echo "configure:7854: checking for location of PNG includes" >&5
+echo "configure:7978: checking for location of PNG includes" >&5
case "$with_png_includes" in
{ echo "configure: error: *** You must supply a directory to --with-png-includes." 1>&2; exit 1; }
@@ -7876,15 +8000,15 @@
do
-echo "configure:7880: checking for $ac_hdr" >&5
+echo "configure:8004: checking for $ac_hdr" >&5
-#line 7883 "configure"
+#line 8007 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7888: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8012: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7918,7 +8042,7 @@
echo $ac_n "checking for location of PNG library""... $ac_c" 1>&6
-echo "configure:7922: checking for location of PNG library" >&5
+echo "configure:8046: checking for location of PNG library" >&5
case "$with_png_libs" in
{ echo "configure: error: *** You must supply a directory to --with-png-libs." 1>&2; exit 1; }
@@ -7943,13 +8067,13 @@
echo $ac_n "checking for png_read_image in -lpng""... $ac_c" 1>&6
-echo "configure:7947: checking for png_read_image in -lpng" >&5
+echo "configure:8071: checking for png_read_image in -lpng" >&5
ac_lib_var=`echo png'_'png_read_image | sed 'y%./+-%__p_%'`
LIBS="-lpng $ZLIB $MATHLIB $LIBS"
-#line 7953 "configure"
+#line 8077 "configure"
@@ -7960,7 +8084,7 @@
png_read_image()
; return 0; }
EOF
-if { (eval echo configure:7964: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8088: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8002,7 +8126,7 @@
echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:8006: checking whether to use PostgreSQL" >&5
+echo "configure:8130: checking whether to use PostgreSQL" >&5
echo "$ac_t"""$with_postgres"" 1>&6
case "$with_postgres" in
"no") USE_POSTGRES= ;;
@@ -8029,7 +8153,7 @@
echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:8033: checking for location of PostgreSQL includes" >&5
+echo "configure:8157: checking for location of PostgreSQL includes" >&5
case "$with_postgres_includes" in
{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -8055,15 +8179,15 @@
do
-echo "configure:8059: checking for $ac_hdr" >&5
+echo "configure:8183: checking for $ac_hdr" >&5
-#line 8062 "configure"
+#line 8186 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8067: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8191: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8101,7 +8225,7 @@
echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:8105: checking for location of PostgreSQL library" >&5
+echo "configure:8229: checking for location of PostgreSQL library" >&5
case "$with_postgres_libs" in
{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -8130,13 +8254,13 @@
echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:8134: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:8258: checking for PQsetdbLogin in -lpq" >&5
ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 8140 "configure"
+#line 8264 "configure"
@@ -8147,7 +8271,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:8151: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8275: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8166,13 +8290,13 @@
-echo "configure:8170: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:8294: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 8176 "configure"
+#line 8300 "configure"
@@ -8183,7 +8307,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:8187: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8311: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8202,13 +8326,13 @@
-echo "configure:8206: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:8330: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lcrypt $LIBS"
-#line 8212 "configure"
+#line 8336 "configure"
@@ -8219,7 +8343,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:8223: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8347: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8238,13 +8362,13 @@
-echo "configure:8242: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:8366: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
-#line 8248 "configure"
+#line 8372 "configure"
@@ -8255,7 +8379,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:8259: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8383: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8312,13 +8436,13 @@
ac_save_ldflags="$LDFLAGS"
LDFLAGS="$LDFLAGS $PQLIBPATH"
echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:8316: checking for PQcmdTuples in -lpq" >&5
+echo "configure:8440: checking for PQcmdTuples in -lpq" >&5
ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 8322 "configure"
+#line 8446 "configure"
@@ -8329,7 +8453,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:8333: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8457: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8351,13 +8475,13 @@
-echo "configure:8355: checking for PQcmdTuples in -lpq" >&5
+echo "configure:8479: checking for PQcmdTuples in -lpq" >&5
-#line 8361 "configure"
+#line 8485 "configure"
@@ -8368,7 +8492,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:8372: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8496: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8411,7 +8535,7 @@
echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:8415: checking whether to use MySQL" >&5
+echo "configure:8539: checking whether to use MySQL" >&5
echo "$ac_t"""$with_mysql"" 1>&6
case "$with_mysql" in
"no") USE_MYSQL= ;;
@@ -8431,7 +8555,7 @@
echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:8435: checking for location of MySQL includes" >&5
+echo "configure:8559: checking for location of MySQL includes" >&5
case "$with_mysql_includes" in
{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -8457,15 +8581,15 @@
do
-echo "configure:8461: checking for $ac_hdr" >&5
+echo "configure:8585: checking for $ac_hdr" >&5
-#line 8464 "configure"
+#line 8588 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8469: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8593: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8502,7 +8626,7 @@
echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:8506: checking for location of MySQL library" >&5
+echo "configure:8630: checking for location of MySQL library" >&5
case "$with_mysql_libs" in
{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -8533,13 +8657,13 @@
echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:8537: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8661: checking for mysql_query in -lmysqlclient" >&5
ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
LIBS="-lmysqlclient $LIBS"
-#line 8543 "configure"
+#line 8667 "configure"
@@ -8550,7 +8674,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:8554: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8678: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8569,13 +8693,13 @@
-echo "configure:8573: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8697: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 8579 "configure"
+#line 8703 "configure"
@@ -8586,7 +8710,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:8590: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8714: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8605,13 +8729,13 @@
-echo "configure:8609: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8733: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 8615 "configure"
+#line 8739 "configure"
@@ -8622,7 +8746,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:8626: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8750: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8641,13 +8765,13 @@
-echo "configure:8645: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8769: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 8651 "configure"
+#line 8775 "configure"
@@ -8658,7 +8782,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:8662: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8786: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8677,13 +8801,13 @@
-echo "configure:8681: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8805: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 8687 "configure"
+#line 8811 "configure"
@@ -8694,7 +8818,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:8698: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8822: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8713,13 +8837,13 @@
-echo "configure:8717: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8841: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 8723 "configure"
+#line 8847 "configure"
@@ -8730,7 +8854,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:8734: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8858: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8749,13 +8873,13 @@
-echo "configure:8753: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8877: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 8759 "configure"
+#line 8883 "configure"
@@ -8766,7 +8890,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:8770: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8894: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8785,13 +8909,13 @@
-echo "configure:8789: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8913: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 8795 "configure"
+#line 8919 "configure"
@@ -8802,7 +8926,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:8806: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8930: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8892,7 +9016,7 @@
# Extract the first word of "mysql_config", so it can be a program name with args.
set dummy mysql_config; ac_word=$2
-echo "configure:8896: checking for $ac_word" >&5
+echo "configure:9020: checking for $ac_word" >&5
case "$MYSQLD_CONFIG" in
@@ -8941,10 +9065,10 @@
LIBS="$MYSQLDLIB $LIBS"
echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:8945: checking for mysql_server_init" >&5
+echo "configure:9069: checking for mysql_server_init" >&5
-#line 8948 "configure"
+#line 9072 "configure"
which can conflict with char mysql_server_init(); below. */
@@ -8970,7 +9094,7 @@
; return 0; }
EOF
-if { (eval echo configure:8974: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9098: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_mysql_server_init=yes"
else
@@ -9022,7 +9146,7 @@
echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:9026: checking whether to use SQLite" >&5
+echo "configure:9150: checking whether to use SQLite" >&5
echo "$ac_t"""$with_sqlite"" 1>&6
case "$with_sqlite" in
"no") USE_SQLITE= ;;
@@ -9042,7 +9166,7 @@
echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:9046: checking for location of SQLite includes" >&5
+echo "configure:9170: checking for location of SQLite includes" >&5
case "$with_sqlite_includes" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -9068,15 +9192,15 @@
do
-echo "configure:9072: checking for $ac_hdr" >&5
+echo "configure:9196: checking for $ac_hdr" >&5
-#line 9075 "configure"
+#line 9199 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9080: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9204: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9119,7 +9243,7 @@
echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:9123: checking for location of SQLite library" >&5
+echo "configure:9247: checking for location of SQLite library" >&5
case "$with_sqlite_libs" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -9148,13 +9272,13 @@
echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:9152: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:9276: checking for sqlite3_open in -lsqlite3" >&5
ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
LIBS="-lsqlite3 $LIBS"
-#line 9158 "configure"
+#line 9282 "configure"
@@ -9165,7 +9289,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:9169: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9293: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9184,13 +9308,13 @@
-echo "configure:9188: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:9312: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $DLLIB $LIBS"
-#line 9194 "configure"
+#line 9318 "configure"
@@ -9201,7 +9325,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:9205: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9329: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9220,13 +9344,13 @@
-echo "configure:9224: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:9348: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 9230 "configure"
+#line 9354 "configure"
@@ -9237,7 +9361,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:9241: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9365: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9256,13 +9380,13 @@
-echo "configure:9260: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:9384: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $MATHLIB $DLLIB $LIBS"
-#line 9266 "configure"
+#line 9390 "configure"
@@ -9273,7 +9397,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:9277: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9401: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9348,7 +9472,7 @@
OPENGL_WINDOWS=
echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:9352: checking whether to use OpenGL" >&5
+echo "configure:9476: checking whether to use OpenGL" >&5
echo "$ac_t"""$with_opengl"" 1>&6
case "$with_opengl" in
n|no)
@@ -9382,7 +9506,7 @@
echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:9386: checking for location of OpenGL includes" >&5
+echo "configure:9510: checking for location of OpenGL includes" >&5
case "$with_opengl_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -9408,15 +9532,15 @@
do
-echo "configure:9412: checking for $ac_hdr" >&5
+echo "configure:9536: checking for $ac_hdr" >&5
-#line 9415 "configure"
+#line 9539 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9420: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9544: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9450,7 +9574,7 @@
echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:9454: checking for location of OpenGL library" >&5
+echo "configure:9578: checking for location of OpenGL library" >&5
case "$with_opengl_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -9479,13 +9603,13 @@
echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:9483: checking for glBegin in -lGL" >&5
+echo "configure:9607: checking for glBegin in -lGL" >&5
ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 9489 "configure"
+#line 9613 "configure"
@@ -9496,7 +9620,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:9500: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9624: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9515,13 +9639,13 @@
-echo "configure:9519: checking for glBegin in -lGL" >&5
+echo "configure:9643: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 9525 "configure"
+#line 9649 "configure"
@@ -9532,7 +9656,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:9536: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9660: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9551,13 +9675,13 @@
-echo "configure:9555: checking for glBegin in -lGL" >&5
+echo "configure:9679: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 9561 "configure"
+#line 9685 "configure"
@@ -9568,7 +9692,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:9572: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9696: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9587,13 +9711,13 @@
-echo "configure:9591: checking for glBegin in -lGL" >&5
+echo "configure:9715: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 9597 "configure"
+#line 9721 "configure"
@@ -9604,7 +9728,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:9608: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9732: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9666,13 +9790,13 @@
echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:9670: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:9794: checking for gluBeginCurve in -lGLU" >&5
ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 9676 "configure"
+#line 9800 "configure"
@@ -9683,7 +9807,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:9687: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9811: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9702,13 +9826,13 @@
-echo "configure:9706: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:9830: checking for gluBeginCurve in -lGLU" >&5
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 9712 "configure"
+#line 9836 "configure"
@@ -9719,7 +9843,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:9723: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9847: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9766,10 +9890,10 @@
LIBS=" $OPENGLLIB $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:9770: checking for glXCreatePbuffer" >&5
+echo "configure:9894: checking for glXCreatePbuffer" >&5
-#line 9773 "configure"
+#line 9897 "configure"
which can conflict with char glXCreatePbuffer(); below. */
@@ -9792,7 +9916,7 @@
; return 0; }
EOF
-if { (eval echo configure:9796: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9920: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreatePbuffer=yes"
else
@@ -9829,10 +9953,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:9833: checking for glXCreateGLXPixmap" >&5
+echo "configure:9957: checking for glXCreateGLXPixmap" >&5
-#line 9836 "configure"
+#line 9960 "configure"
which can conflict with char glXCreateGLXPixmap(); below. */
@@ -9855,7 +9979,7 @@
; return 0; }
EOF
-if { (eval echo configure:9859: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9983: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreateGLXPixmap=yes"
else
@@ -9898,7 +10022,7 @@
echo $ac_n "checking for location of OpenGL framework""... $ac_c" 1>&6
-echo "configure:9902: checking for location of OpenGL framework" >&5
+echo "configure:10026: checking for location of OpenGL framework" >&5
case "$with_opengl_framework" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-framework." 1>&2; exit 1; }
@@ -9922,15 +10046,15 @@
do
-echo "configure:9926: checking for $ac_hdr" >&5
+echo "configure:10050: checking for $ac_hdr" >&5
-#line 9929 "configure"
+#line 10053 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9934: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10058: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9966,10 +10090,10 @@
LIBS="-framework OpenGL -framework AGL -framework ApplicationServices $LIBS"
LDFLAGS="$OPENGLPATH $LDFLAGS"
echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:9970: checking for glBegin" >&5
+echo "configure:10094: checking for glBegin" >&5
-#line 9973 "configure"
+#line 10097 "configure"
which can conflict with char glBegin(); below. */
@@ -9992,7 +10116,7 @@
; return 0; }
EOF
-if { (eval echo configure:9996: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10120: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glBegin=yes"
else
@@ -10029,10 +10153,10 @@
echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:10033: checking for gluBeginCurve" >&5
+echo "configure:10157: checking for gluBeginCurve" >&5
-#line 10036 "configure"
+#line 10160 "configure"
which can conflict with char gluBeginCurve(); below. */
@@ -10055,7 +10179,7 @@
; return 0; }
EOF
-if { (eval echo configure:10059: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10183: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gluBeginCurve=yes"
else
@@ -10103,7 +10227,7 @@
-echo "configure:10107: checking for location of OpenGL includes" >&5
+echo "configure:10231: checking for location of OpenGL includes" >&5
@@ -10129,15 +10253,15 @@
do
-echo "configure:10133: checking for $ac_hdr" >&5
+echo "configure:10257: checking for $ac_hdr" >&5
-#line 10136 "configure"
+#line 10260 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10141: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10265: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10171,7 +10295,7 @@
-echo "configure:10175: checking for location of OpenGL library" >&5
+echo "configure:10299: checking for location of OpenGL library" >&5
@@ -10196,11 +10320,11 @@
ac_save_libs="$LIBS"
echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:10200: checking for OpenGL library" >&5
+echo "configure:10324: checking for OpenGL library" >&5
LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
LIBS="-lopengl32 "
-#line 10204 "configure"
+#line 10328 "configure"
#include <GL/gl.h>
int main() {
@@ -10207,7 +10331,7 @@
glEnd();
; return 0; }
EOF
-if { (eval echo configure:10211: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10335: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
echo "$ac_t""found" 1>&6
@@ -10231,11 +10355,11 @@
echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:10235: checking for GLU library" >&5
+echo "configure:10359: checking for GLU library" >&5
LIBS="-lglu32 $OPENGLLIB "
-#line 10239 "configure"
+#line 10363 "configure"
#include <GL/glu.h>
int main() {
@@ -10242,7 +10366,7 @@
gluNewQuadric();
; return 0; }
EOF
-if { (eval echo configure:10246: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10370: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -10291,7 +10415,7 @@
echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:10295: checking whether to use ODBC" >&5
+echo "configure:10419: checking whether to use ODBC" >&5
echo "$ac_t"""$with_odbc"" 1>&6
case "$with_odbc" in
"no") USE_ODBC= ;;
@@ -10310,7 +10434,7 @@
echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:10314: checking for location of ODBC includes" >&5
+echo "configure:10438: checking for location of ODBC includes" >&5
case "$with_odbc_includes" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -10336,15 +10460,15 @@
do
-echo "configure:10340: checking for $ac_hdr" >&5
+echo "configure:10464: checking for $ac_hdr" >&5
-#line 10343 "configure"
+#line 10467 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10348: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10472: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10378,7 +10502,7 @@
echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:10382: checking for location of ODBC library" >&5
+echo "configure:10506: checking for location of ODBC library" >&5
case "$with_odbc_libs" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -10403,13 +10527,13 @@
echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:10407: checking for SQLConnect in -lodbc" >&5
+echo "configure:10531: checking for SQLConnect in -lodbc" >&5
ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-lodbc $ICONVLIB $LIBS"
-#line 10413 "configure"
+#line 10537 "configure"
@@ -10420,7 +10544,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:10424: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10548: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10445,13 +10569,13 @@
echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:10449: checking for SQLConnect in -liodbc" >&5
+echo "configure:10573: checking for SQLConnect in -liodbc" >&5
ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-liodbc $LIBS"
-#line 10455 "configure"
+#line 10579 "configure"
@@ -10462,7 +10586,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:10466: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10590: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10487,11 +10611,11 @@
echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:10491: checking for ODBC library" >&5
+echo "configure:10615: checking for ODBC library" >&5
LDFLAGS="$ODBCLIB $LDFLAGS"
LIBS="-lodbc32 "
-#line 10495 "configure"
+#line 10619 "configure"
#include <windows.h>
#include <sql.h>
@@ -10499,7 +10623,7 @@
SQLAllocEnv((SQLHENV *)0);
; return 0; }
EOF
-if { (eval echo configure:10503: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10627: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -10548,7 +10672,7 @@
echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:10552: checking whether to use FFTW" >&5
+echo "configure:10676: checking whether to use FFTW" >&5
echo "$ac_t"""$with_fftw"" 1>&6
case "$with_fftw" in
"no") USE_FFTW= ;;
@@ -10567,7 +10691,7 @@
echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:10571: checking for location of FFTW includes" >&5
+echo "configure:10695: checking for location of FFTW includes" >&5
case "$with_fftw_includes" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -10593,15 +10717,15 @@
do
-echo "configure:10597: checking for $ac_hdr" >&5
+echo "configure:10721: checking for $ac_hdr" >&5
-#line 10600 "configure"
+#line 10724 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10605: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10729: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10629,15 +10753,15 @@
do
-echo "configure:10633: checking for $ac_hdr" >&5
+echo "configure:10757: checking for $ac_hdr" >&5
-#line 10636 "configure"
+#line 10760 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10641: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10765: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10665,15 +10789,15 @@
do
-echo "configure:10669: checking for $ac_hdr" >&5
+echo "configure:10793: checking for $ac_hdr" >&5
-#line 10672 "configure"
+#line 10796 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10677: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10801: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10719,7 +10843,7 @@
echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:10723: checking for location of FFTW library" >&5
+echo "configure:10847: checking for location of FFTW library" >&5
case "$with_fftw_libs" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -10744,13 +10868,13 @@
echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:10748: checking for fftw_execute in -lfftw3" >&5
+echo "configure:10872: checking for fftw_execute in -lfftw3" >&5
ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 10754 "configure"
+#line 10878 "configure"
@@ -10761,7 +10885,7 @@
fftw_execute()
; return 0; }
EOF
-if { (eval echo configure:10765: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10889: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10786,13 +10910,13 @@
echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:10790: checking for fftwnd_one in -lfftw" >&5
+echo "configure:10914: checking for fftwnd_one in -lfftw" >&5
ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-lfftw $MATHLIB $LIBS"
cat > conftest.$ac_ext <<EOF
-#line 10796 "configure"
+#line 10920 "configure"
#include "confdefs.h"
@@ -10803,7 +10927,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:10807: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10931: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10828,13 +10952,13 @@
echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:10832: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:10956: checking for fftwnd_one in -ldfftw" >&5
ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-ldfftw $MATHLIB $LIBS"
-#line 10838 "configure"
+#line 10962 "configure"
@@ -10845,7 +10969,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:10849: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10973: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10902,7 +11026,7 @@
echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:10906: checking whether to use BLAS" >&5
+echo "configure:11030: checking whether to use BLAS" >&5
echo "$ac_t"""$with_blas"" 1>&6
case "$with_blas" in
"no") USE_BLAS= ;;
@@ -10923,7 +11047,7 @@
echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:10927: checking for location of BLAS includes" >&5
+echo "configure:11051: checking for location of BLAS includes" >&5
case "$with_blas_includes" in
{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -10943,7 +11067,7 @@
echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:10947: checking for location of BLAS library" >&5
+echo "configure:11071: checking for location of BLAS library" >&5
case "$with_blas_libs" in
{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -10969,15 +11093,15 @@
do
-echo "configure:10973: checking for $ac_hdr" >&5
+echo "configure:11097: checking for $ac_hdr" >&5
-#line 10976 "configure"
+#line 11100 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10981: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11105: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11012,13 +11136,13 @@
echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:11016: checking for dnrm2_ in -lblas" >&5
+echo "configure:11140: checking for dnrm2_ in -lblas" >&5
ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
LIBS="-lblas $MATHLIB $LIBS"
-#line 11022 "configure"
+#line 11146 "configure"
@@ -11029,7 +11153,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:11033: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11157: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11048,13 +11172,13 @@
-echo "configure:11052: checking for dnrm2_ in -lblas" >&5
+echo "configure:11176: checking for dnrm2_ in -lblas" >&5
ac_save_LIBS="$LIBS"
LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 11058 "configure"
+#line 11182 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -11065,7 +11189,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:11069: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11193: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -11109,13 +11233,13 @@
save_LDFLAGS="$LDFLAGS"
LDFLAGS="$BLASLIB $LDFLAGS"
echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:11113: checking for ATL_xerbla in -latlas" >&5
+echo "configure:11237: checking for ATL_xerbla in -latlas" >&5
ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
LIBS="-latlas $LIBS"
-#line 11119 "configure"
+#line 11243 "configure"
@@ -11126,7 +11250,7 @@
ATL_xerbla()
; return 0; }
EOF
-if { (eval echo configure:11130: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11254: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11141,13 +11265,13 @@
if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
echo "$ac_t""yes" 1>&6
echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:11145: checking for sgemm_ in -lf77blas" >&5
+echo "configure:11269: checking for sgemm_ in -lf77blas" >&5
ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lf77blas -latlas $LIBS"
-#line 11151 "configure"
+#line 11275 "configure"
@@ -11158,7 +11282,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:11162: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11286: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11173,13 +11297,13 @@
echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:11177: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:11301: checking for cblas_dgemm in -lcblas" >&5
ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 11183 "configure"
+#line 11307 "configure"
@@ -11190,7 +11314,7 @@
cblas_dgemm()
; return 0; }
EOF
-if { (eval echo configure:11194: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11318: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11236,9 +11360,9 @@
save_LIBS="$LIBS"
LIBS="$vlib_flags $LIBS"
echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:11240: checking for sgemm in $vlib_flags" >&5
+echo "configure:11364: checking for sgemm in $vlib_flags" >&5
-#line 11242 "configure"
+#line 11366 "configure"
int main() {
@@ -11245,7 +11369,7 @@
sgemm
; return 0; }
EOF
-if { (eval echo configure:11249: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11373: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
blas_ok=yes; BLASLIB="$vlib_flags"
else
@@ -11263,13 +11387,13 @@
# BLAS in PhiPACK libraries? (requires generic BLAS, too)
if test $blas_ok = no; then
echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:11267: checking for sgemm_ in -lblas" >&5
+echo "configure:11391: checking for sgemm_ in -lblas" >&5
ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lblas $LIBS"
-#line 11273 "configure"
+#line 11397 "configure"
@@ -11280,7 +11404,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:11284: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11408: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11295,13 +11419,13 @@
echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:11299: checking for dgemm_ in -ldgemm" >&5
+echo "configure:11423: checking for dgemm_ in -ldgemm" >&5
ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
LIBS="-ldgemm -lblas $LIBS"
-#line 11305 "configure"
+#line 11429 "configure"
@@ -11312,7 +11436,7 @@
dgemm_()
; return 0; }
EOF
-if { (eval echo configure:11316: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11440: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11327,13 +11451,13 @@
echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:11331: checking for sgemm_ in -lsgemm" >&5
+echo "configure:11455: checking for sgemm_ in -lsgemm" >&5
ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsgemm -lblas $LIBS"
-#line 11337 "configure"
+#line 11461 "configure"
@@ -11344,7 +11468,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:11348: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11472: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11378,13 +11502,13 @@
if test "x$GCC" != xyes; then # only works with Sun CC
echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:11382: checking for acosp in -lsunmath" >&5
+echo "configure:11506: checking for acosp in -lsunmath" >&5
ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
LIBS="-lsunmath $LIBS"
-#line 11388 "configure"
+#line 11512 "configure"
@@ -11395,7 +11519,7 @@
acosp()
; return 0; }
EOF
-if { (eval echo configure:11399: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11523: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11410,13 +11534,13 @@
echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:11414: checking for sgemm_ in -lsunperf" >&5
+echo "configure:11538: checking for sgemm_ in -lsunperf" >&5
ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsunperf -lsunmath $LIBS"
-#line 11420 "configure"
+#line 11544 "configure"
@@ -11427,7 +11551,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:11431: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11555: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11457,13 +11581,13 @@
# Generic BLAS library
-echo "configure:11461: checking for sgemm_ in -lblas" >&5
+echo "configure:11585: checking for sgemm_ in -lblas" >&5
LIBS="-lblas $LIBS"
-#line 11467 "configure"
+#line 11591 "configure"
@@ -11474,7 +11598,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:11478: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11602: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11513,7 +11637,7 @@
echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:11517: checking whether to use LAPACK" >&5
+echo "configure:11641: checking whether to use LAPACK" >&5
echo "$ac_t"""$with_lapack"" 1>&6
case "$with_lapack" in
"no") USE_LAPACK= ;;
@@ -11538,7 +11662,7 @@
echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:11542: checking for location of LAPACK includes" >&5
+echo "configure:11666: checking for location of LAPACK includes" >&5
case "$with_lapack_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -11558,7 +11682,7 @@
echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:11562: checking for location of LAPACK library" >&5
+echo "configure:11686: checking for location of LAPACK library" >&5
case "$with_lapack_libs" in
{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -11584,15 +11708,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:11588: checking for $ac_hdr" >&5
+echo "configure:11712: checking for $ac_hdr" >&5
-#line 11591 "configure"
+#line 11715 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:11596: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11720: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -11624,10 +11748,10 @@
save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:11628: checking for dsegv_" >&5
+echo "configure:11752: checking for dsegv_" >&5
-#line 11631 "configure"
+#line 11755 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char dsegv_(); below. */
@@ -11650,7 +11774,7 @@
; return 0; }
EOF
-if { (eval echo configure:11654: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11778: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_dsegv_=yes"
else
@@ -11677,13 +11801,13 @@
save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:11681: checking for desgv_ in -llapack" >&5
+echo "configure:11805: checking for desgv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $FLIBS $LIBS"
-#line 11687 "configure"
+#line 11811 "configure"
@@ -11694,7 +11818,7 @@
desgv_()
; return 0; }
EOF
-if { (eval echo configure:11698: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11822: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11726,13 +11850,13 @@
echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:11730: checking for dgesv_ in -llapack" >&5
+echo "configure:11854: checking for dgesv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $BLASLIB $MATHLIB $LIBS"
-#line 11736 "configure"
+#line 11860 "configure"
@@ -11743,7 +11867,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:11747: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11871: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11762,13 +11886,13 @@
-echo "configure:11766: checking for dgesv_ in -llapack" >&5
+echo "configure:11890: checking for dgesv_ in -llapack" >&5
LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 11772 "configure"
+#line 11896 "configure"
@@ -11779,7 +11903,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:11783: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11907: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11835,7 +11959,7 @@
echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:11839: checking whether to use Cairo" >&5
+echo "configure:11963: checking whether to use Cairo" >&5
echo "$ac_t"""$with_cairo"" 1>&6
case "$with_cairo" in
"no") USE_CAIRO= ;;
@@ -11867,7 +11991,7 @@
echo $ac_n "checking for location of cairo includes""... $ac_c" 1>&6
-echo "configure:11871: checking for location of cairo includes" >&5
+echo "configure:11995: checking for location of cairo includes" >&5
case "$with_cairo_includes" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-includes." 1>&2; exit 1; }
@@ -11893,15 +12017,15 @@
do
-echo "configure:11897: checking for $ac_hdr" >&5
+echo "configure:12021: checking for $ac_hdr" >&5
-#line 11900 "configure"
+#line 12024 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11905: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12029: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11937,7 +12061,7 @@
echo $ac_n "checking for location of cairo library""... $ac_c" 1>&6
-echo "configure:11941: checking for location of cairo library" >&5
+echo "configure:12065: checking for location of cairo library" >&5
case "$with_cairo_libs" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-libs." 1>&2; exit 1; }
@@ -11957,7 +12081,7 @@
echo $ac_n "checking for cairo linking flags""... $ac_c" 1>&6
-echo "configure:11961: checking for cairo linking flags" >&5
+echo "configure:12085: checking for cairo linking flags" >&5
case "$with_cairo_ldflags" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-ldflags." 1>&2; exit 1; }
@@ -11973,10 +12097,10 @@
LIBS=" $CAIROLIB $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:11977: checking for cairo_create" >&5
+echo "configure:12101: checking for cairo_create" >&5
-#line 11980 "configure"
+#line 12104 "configure"
which can conflict with char cairo_create(); below. */
@@ -11999,7 +12123,7 @@
; return 0; }
EOF
-if { (eval echo configure:12003: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12127: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_create=yes"
else
@@ -12033,10 +12157,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_xlib_surface_create_with_xrender_format""... $ac_c" 1>&6
-echo "configure:12037: checking for cairo_xlib_surface_create_with_xrender_format" >&5
+echo "configure:12161: checking for cairo_xlib_surface_create_with_xrender_format" >&5
-#line 12040 "configure"
+#line 12164 "configure"
which can conflict with char cairo_xlib_surface_create_with_xrender_format(); below. */
@@ -12059,7 +12183,7 @@
; return 0; }
EOF
-if { (eval echo configure:12063: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12187: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_xlib_surface_create_with_xrender_format=yes"
else
@@ -12092,10 +12216,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_xlib_surface_get_xrender_format""... $ac_c" 1>&6
-echo "configure:12096: checking for cairo_xlib_surface_get_xrender_format" >&5
+echo "configure:12220: checking for cairo_xlib_surface_get_xrender_format" >&5
-#line 12099 "configure"
+#line 12223 "configure"
which can conflict with char cairo_xlib_surface_get_xrender_format(); below. */
@@ -12118,7 +12242,7 @@
; return 0; }
EOF
-if { (eval echo configure:12122: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12246: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_xlib_surface_get_xrender_format=yes"
else
@@ -12160,7 +12284,7 @@
echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:12164: checking whether to use FreeType" >&5
+echo "configure:12288: checking whether to use FreeType" >&5
echo "$ac_t"""$with_freetype"" 1>&6
case "$with_freetype" in
"no") USE_FREETYPE= ;;
@@ -12179,7 +12303,7 @@
echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:12183: checking for location of FreeType includes" >&5
+echo "configure:12307: checking for location of FreeType includes" >&5
case "$with_freetype_includes" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -12205,15 +12329,15 @@
do
-echo "configure:12209: checking for $ac_hdr" >&5
+echo "configure:12333: checking for $ac_hdr" >&5
-#line 12212 "configure"
+#line 12336 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12217: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12341: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12247,7 +12371,7 @@
echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:12251: checking for location of FreeType library" >&5
+echo "configure:12375: checking for location of FreeType library" >&5
case "$with_freetype_libs" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -12272,13 +12396,13 @@
echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:12276: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:12400: checking for FT_Init_FreeType in -lfreetype" >&5
ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
LIBS="-lfreetype $LIBS"
-#line 12282 "configure"
+#line 12406 "configure"
@@ -12289,7 +12413,7 @@
FT_Init_FreeType()
; return 0; }
EOF
-if { (eval echo configure:12293: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12417: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12330,7 +12454,7 @@
echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:12334: checking whether to use NLS" >&5
+echo "configure:12458: checking whether to use NLS" >&5
echo "$ac_t"""$with_nls"" 1>&6
case "$with_nls" in
"no") USE_NLS= ;;
@@ -12350,10 +12474,10 @@
echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:12354: checking for gettext" >&5
+echo "configure:12478: checking for gettext" >&5
-#line 12357 "configure"
+#line 12481 "configure"
which can conflict with char gettext(); below. */
@@ -12376,7 +12500,7 @@
; return 0; }
EOF
-if { (eval echo configure:12380: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12504: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gettext=yes"
else
@@ -12394,13 +12518,13 @@
echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:12398: checking for gettext in -lintl" >&5
+echo "configure:12522: checking for gettext in -lintl" >&5
ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
LIBS="-lintl $LIBS"
-#line 12404 "configure"
+#line 12528 "configure"
@@ -12411,7 +12535,7 @@
gettext()
; return 0; }
EOF
-if { (eval echo configure:12415: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12539: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12446,7 +12570,7 @@
echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:12450: checking whether to use C++" >&5
+echo "configure:12574: checking whether to use C++" >&5
echo "$ac_t"""$with_cxx"" 1>&6
case "$with_cxx" in
"no") USE_CXX= ;;
@@ -12462,7 +12586,7 @@
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:12466: checking for $ac_word" >&5
+echo "configure:12590: checking for $ac_word" >&5
if test -n "$CXX"; then
ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -12491,7 +12615,7 @@
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:12495: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:12619: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
ac_ext=C
# CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -12502,12 +12626,12 @@
cat > conftest.$ac_ext << EOF
-#line 12506 "configure"
+#line 12630 "configure"
int main(){return(0);}
EOF
-if { (eval echo configure:12511: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12635: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
ac_cv_prog_cxx_works=yes
# If we can't run a trivial program, we are probably using a cross compiler.
if (./conftest; exit) 2>/dev/null; then
@@ -12533,12 +12657,12 @@
{ echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
fi
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:12537: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:12661: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
cross_compiling=$ac_cv_prog_cxx_cross
echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:12542: checking whether we are using GNU C++" >&5
+echo "configure:12666: checking whether we are using GNU C++" >&5
cat > conftest.C <<EOF
#ifdef __GNUC__
@@ -12545,7 +12669,7 @@
yes;
#endif
EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:12549: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:12673: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
ac_cv_prog_gxx=yes
else
ac_cv_prog_gxx=no
@@ -12563,7 +12687,7 @@
ac_save_CXXFLAGS="$CXXFLAGS"
CXXFLAGS=
echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:12567: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:12691: checking whether ${CXX-g++} accepts -g" >&5
echo 'void f(){}' > conftest.cc
if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -12601,7 +12725,7 @@
'void exit (int);'
do
-#line 12605 "configure"
+#line 12729 "configure"
#include <stdlib.h>
$ac_declaration
@@ -12609,7 +12733,7 @@
exit (42);
; return 0; }
EOF
-if { (eval echo configure:12613: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:12737: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
echo "configure: failed program was:" >&5
@@ -12619,7 +12743,7 @@
fi
rm -f conftest*
-#line 12623 "configure"
+#line 12747 "configure"
$ac_declaration
int main() {
@@ -12626,7 +12750,7 @@
exit (42);
; return 0; }
EOF
-if { (eval echo configure:12630: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:12754: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
break
else
@@ -12655,7 +12779,7 @@
echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:12659: checking whether to use openDWG" >&5
+echo "configure:12783: checking whether to use openDWG" >&5
echo "$ac_t"""$with_opendwg"" 1>&6
case "$with_opendwg" in
"no") USE_OPENDWG= ;;
@@ -12675,7 +12799,7 @@
echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:12679: checking for location of openDGW includes" >&5
+echo "configure:12803: checking for location of openDGW includes" >&5
case "$with_opendwg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -12701,15 +12825,15 @@
do
-echo "configure:12705: checking for $ac_hdr" >&5
+echo "configure:12829: checking for $ac_hdr" >&5
-#line 12708 "configure"
+#line 12832 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12713: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12837: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12743,7 +12867,7 @@
echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:12747: checking for location of openDWG library" >&5
+echo "configure:12871: checking for location of openDWG library" >&5
case "$with_opendwg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -12784,7 +12908,7 @@
echo $ac_n "checking whether to use POSIX threads""... $ac_c" 1>&6
-echo "configure:12788: checking whether to use POSIX threads" >&5
+echo "configure:12912: checking whether to use POSIX threads" >&5
echo "$ac_t"""$with_pthread"" 1>&6
case "$with_pthread" in
"no") USE_PTHREAD= ;;
@@ -12804,7 +12928,7 @@
echo $ac_n "checking for location of POSIX threads includes""... $ac_c" 1>&6
-echo "configure:12808: checking for location of POSIX threads includes" >&5
+echo "configure:12932: checking for location of POSIX threads includes" >&5
case "$with_pthread_includes" in
{ echo "configure: error: *** You must supply a directory to --with-pthread-includes." 1>&2; exit 1; }
@@ -12830,15 +12954,15 @@
do
-echo "configure:12834: checking for $ac_hdr" >&5
+echo "configure:12958: checking for $ac_hdr" >&5
-#line 12837 "configure"
+#line 12961 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12842: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12966: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12872,7 +12996,7 @@
echo $ac_n "checking for location of POSIX threads library""... $ac_c" 1>&6
-echo "configure:12876: checking for location of POSIX threads library" >&5
+echo "configure:13000: checking for location of POSIX threads library" >&5
case "$with_pthread_libs" in
{ echo "configure: error: *** You must supply a directory to --with-pthread-libs." 1>&2; exit 1; }
@@ -12897,10 +13021,10 @@
LIBS=" $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for pthread_create""... $ac_c" 1>&6
-echo "configure:12901: checking for pthread_create" >&5
+echo "configure:13025: checking for pthread_create" >&5
-#line 12904 "configure"
+#line 13028 "configure"
which can conflict with char pthread_create(); below. */
@@ -12923,7 +13047,7 @@
; return 0; }
EOF
-if { (eval echo configure:12927: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13051: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_pthread_create=yes"
else
@@ -12950,13 +13074,13 @@
echo $ac_n "checking for pthread_create in -lpthread""... $ac_c" 1>&6
-echo "configure:12954: checking for pthread_create in -lpthread" >&5
+echo "configure:13078: checking for pthread_create in -lpthread" >&5
ac_lib_var=`echo pthread'_'pthread_create | sed 'y%./+-%__p_%'`
LIBS="-lpthread $LIBS"
-#line 12960 "configure"
+#line 13084 "configure"
@@ -12967,7 +13091,7 @@
pthread_create()
; return 0; }
EOF
-if { (eval echo configure:12971: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13095: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13017,7 +13141,7 @@
echo $ac_n "checking whether to use OpenMP""... $ac_c" 1>&6
-echo "configure:13021: checking whether to use OpenMP" >&5
+echo "configure:13145: checking whether to use OpenMP" >&5
echo "$ac_t"""$with_openmp"" 1>&6
case "$with_openmp" in
"no") USE_OPENMP= ;;
@@ -13038,7 +13162,7 @@
echo $ac_n "checking for location of OpenMP includes""... $ac_c" 1>&6
-echo "configure:13042: checking for location of OpenMP includes" >&5
+echo "configure:13166: checking for location of OpenMP includes" >&5
case "$with_openmp_includes" in
{ echo "configure: error: *** You must supply a directory to --with-openmp-includes." 1>&2; exit 1; }
@@ -13064,15 +13188,15 @@
do
-echo "configure:13068: checking for $ac_hdr" >&5
+echo "configure:13192: checking for $ac_hdr" >&5
-#line 13071 "configure"
+#line 13195 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13076: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13200: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13110,7 +13234,7 @@
echo $ac_n "checking for location of OpenMP library""... $ac_c" 1>&6
-echo "configure:13114: checking for location of OpenMP library" >&5
+echo "configure:13238: checking for location of OpenMP library" >&5
case "$with_openmp_libs" in
{ echo "configure: error: *** You must supply a directory to --with-openmp-libs." 1>&2; exit 1; }
@@ -13135,10 +13259,10 @@
LIBS=" $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for GOMP_parallel_start""... $ac_c" 1>&6
-echo "configure:13139: checking for GOMP_parallel_start" >&5
+echo "configure:13263: checking for GOMP_parallel_start" >&5
-#line 13142 "configure"
+#line 13266 "configure"
which can conflict with char GOMP_parallel_start(); below. */
@@ -13161,7 +13285,7 @@
; return 0; }
EOF
-if { (eval echo configure:13165: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13289: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_GOMP_parallel_start=yes"
else
@@ -13188,13 +13312,13 @@
echo $ac_n "checking for GOMP_parallel_start in -lgomp""... $ac_c" 1>&6
-echo "configure:13192: checking for GOMP_parallel_start in -lgomp" >&5
+echo "configure:13316: checking for GOMP_parallel_start in -lgomp" >&5
ac_lib_var=`echo gomp'_'GOMP_parallel_start | sed 'y%./+-%__p_%'`
LIBS="-lgomp $LIBS"
-#line 13198 "configure"
+#line 13322 "configure"
@@ -13205,7 +13329,7 @@
; return 0; }
EOF
-if { (eval echo configure:13209: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13333: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13278,7 +13402,7 @@
echo $ac_n "checking whether to use OpenCL""... $ac_c" 1>&6
-echo "configure:13282: checking whether to use OpenCL" >&5
+echo "configure:13406: checking whether to use OpenCL" >&5
echo "$ac_t"""$with_opencl"" 1>&6
case "$with_opencl" in
"no") USE_OPENCL= ;;
@@ -13298,7 +13422,7 @@
echo $ac_n "checking for location of OpenCL includes""... $ac_c" 1>&6
-echo "configure:13302: checking for location of OpenCL includes" >&5
+echo "configure:13426: checking for location of OpenCL includes" >&5
case "$with_opencl_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opencl-includes." 1>&2; exit 1; }
@@ -13325,15 +13449,15 @@
do
-echo "configure:13329: checking for $ac_hdr" >&5
+echo "configure:13453: checking for $ac_hdr" >&5
-#line 13332 "configure"
+#line 13456 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13337: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13461: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13373,10 +13497,10 @@
LIBS="-framework OpenCL $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for clGetPlatformInfo""... $ac_c" 1>&6
-echo "configure:13377: checking for clGetPlatformInfo" >&5
+echo "configure:13501: checking for clGetPlatformInfo" >&5
-#line 13380 "configure"
+#line 13504 "configure"
which can conflict with char clGetPlatformInfo(); below. */
@@ -13399,7 +13523,7 @@
; return 0; }
EOF
-if { (eval echo configure:13403: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13527: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_clGetPlatformInfo=yes"
else
@@ -13438,15 +13562,15 @@
do
-echo "configure:13442: checking for $ac_hdr" >&5
+echo "configure:13566: checking for $ac_hdr" >&5
-#line 13445 "configure"
+#line 13569 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13450: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13574: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13479,7 +13603,7 @@
# With OpenCL library directory
echo $ac_n "checking for location of OpenCL library""... $ac_c" 1>&6
-echo "configure:13483: checking for location of OpenCL library" >&5
+echo "configure:13607: checking for location of OpenCL library" >&5
case "$with_opencl_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opencl-libs." 1>&2; exit 1; }
@@ -13503,13 +13627,13 @@
echo $ac_n "checking for clGetPlatformInfo in -lOpenCL""... $ac_c" 1>&6
-echo "configure:13507: checking for clGetPlatformInfo in -lOpenCL" >&5
+echo "configure:13631: checking for clGetPlatformInfo in -lOpenCL" >&5
ac_lib_var=`echo OpenCL'_'clGetPlatformInfo | sed 'y%./+-%__p_%'`
LIBS="-lOpenCL $LIBS"
-#line 13513 "configure"
+#line 13637 "configure"
@@ -13520,7 +13644,7 @@
clGetPlatformInfo()
; return 0; }
EOF
-if { (eval echo configure:13524: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13648: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13580,7 +13704,7 @@
fi
echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:13584: checking for special C compiler options needed for large files" >&5
+echo "configure:13708: checking for special C compiler options needed for large files" >&5
ac_cv_sys_largefile_CC=no
largefile_cc_opt=""
@@ -13588,7 +13712,7 @@
# IRIX 6.2 and later do not support large files by default,
# so use the C compiler's -n32 option if that helps.
-#line 13592 "configure"
+#line 13716 "configure"
#include <sys/types.h>
/* Check that off_t can represent 2**63 - 1 correctly.
@@ -13604,7 +13728,7 @@
; return 0; }
EOF
-if { (eval echo configure:13608: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13732: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
@@ -13613,7 +13737,7 @@
ac_save_CC="${CC-cc}"
CC="$CC -n32"
-#line 13617 "configure"
+#line 13741 "configure"
@@ -13629,7 +13753,7 @@
; return 0; }
EOF
-if { (eval echo configure:13633: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13757: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_CC=' -n32'
else
@@ -13656,11 +13780,11 @@
fi
echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:13660: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:13784: checking for _FILE_OFFSET_BITS value needed for large files" >&5
ac_cv_sys_file_offset_bits=no
-#line 13664 "configure"
+#line 13788 "configure"
@@ -13676,7 +13800,7 @@
; return 0; }
EOF
-if { (eval echo configure:13680: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13804: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
@@ -13683,7 +13807,7 @@
cat conftest.$ac_ext >&5
rm -rf conftest*
-#line 13687 "configure"
+#line 13811 "configure"
#define _FILE_OFFSET_BITS 64
@@ -13701,7 +13825,7 @@
; return 0; }
EOF
-if { (eval echo configure:13705: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13829: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_file_offset_bits=64
else
@@ -13727,11 +13851,11 @@
fi
echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:13731: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:13855: checking for _LARGE_FILES value needed for large files" >&5
ac_cv_sys_large_files=no
-#line 13735 "configure"
+#line 13859 "configure"
@@ -13747,7 +13871,7 @@
; return 0; }
EOF
-if { (eval echo configure:13751: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13875: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
@@ -13754,7 +13878,7 @@
rm -rf conftest*
-#line 13758 "configure"
+#line 13882 "configure"
#define _LARGE_FILES 1
@@ -13772,7 +13896,7 @@
; return 0; }
EOF
-if { (eval echo configure:13776: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13900: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_large_files=1
else
@@ -13798,11 +13922,11 @@
fi
echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:13802: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:13926: checking for _LARGEFILE_SOURCE value needed for large files" >&5
ac_cv_sys_largefile_source=no
-#line 13806 "configure"
+#line 13930 "configure"
#include <stdio.h>
int main() {
@@ -13809,7 +13933,7 @@
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:13813: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13937: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
@@ -13816,7 +13940,7 @@
rm -rf conftest*
-#line 13820 "configure"
+#line 13944 "configure"
#define _LARGEFILE_SOURCE 1
#include <stdio.h>
@@ -13825,7 +13949,7 @@
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:13829: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13953: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_source=1
else
@@ -13857,11 +13981,11 @@
ac_save_cflags=${CFLAGS}
CFLAGS="$LFS_CFLAGS ${ac_save_cflags}"
-echo "configure:13861: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:13985: checking for _LARGEFILE_SOURCE value needed for large files" >&5
-#line 13865 "configure"
+#line 13989 "configure"
#include <stdio.h>
int main() {
@@ -13868,7 +13992,7 @@
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:13872: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13996: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
@@ -13875,7 +13999,7 @@
rm -rf conftest*
-#line 13879 "configure"
+#line 14003 "configure"
#include <stdio.h>
@@ -13884,7 +14008,7 @@
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:13888: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14012: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
else
@@ -13914,11 +14038,11 @@
# If you want fseeko and ftello with glibc, upgrade to a fixed glibc.
echo $ac_n "checking for fseeko""... $ac_c" 1>&6
-echo "configure:13918: checking for fseeko" >&5
+echo "configure:14042: checking for fseeko" >&5
ac_cv_func_fseeko=no
-#line 13922 "configure"
+#line 14046 "configure"
#include <stdio.h>
int main() {
@@ -13925,7 +14049,7 @@
return fseeko && fseeko (stdin, 0, 0);
; return 0; }
EOF
-if { (eval echo configure:13929: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14053: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_func_fseeko=yes
else
@@ -13942,10 +14066,10 @@
fi
echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:13946: checking if system supports Large Files at all" >&5
+echo "configure:14070: checking if system supports Large Files at all" >&5
-#line 13949 "configure"
+#line 14073 "configure"
#include <stdio.h>
@@ -13977,7 +14101,7 @@
#endif
; return 0; }
EOF
-if { (eval echo configure:13981: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14105: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_largefiles=yes
else
Modified: grass/trunk/configure.in
--- grass/trunk/configure.in 2018-06-06 17:51:47 UTC (rev 72777)
+++ grass/trunk/configure.in 2018-06-06 19:15:27 UTC (rev 72778)
@@ -688,6 +688,18 @@
LOC_CHECK_INCLUDES(proj.h,External PROJ,$PROJINC,PROJ4API=1)
if test $PROJ4API = 0 ; then
+ LOC_CHECK_VERSION_INT(proj.h,PROJ_VERSION_MAJOR,External PROJ major,proj_ver_major,$PROJINC,0)
+ LOC_CHECK_VERSION_INT(proj.h,PROJ_VERSION_MINOR,External PROJ minor,proj_ver_minor,$PROJINC,0)
+ LOC_CHECK_VERSION_INT(proj.h,PROJ_VERSION_PATCH,External PROJ patch,proj_ver_patch,$PROJINC,0)
+ AC_MSG_RESULT([found PROJ version "${proj_ver_major}.${proj_ver_minor}.${proj_ver_patch}"])
+ # minimum required PROJ 5+ version to use the new PROJ API: 5.1.0
+ if test ${proj_ver_major} = 5 && test `expr "proj_ver_minor" \< 1` = 1 ; then
+ AC_MSG_WARN([At least PROJ version "5.1.0" is required for the new API ])
+ PROJ4API=1
+ fi
+fi
+if test $PROJ4API = 0 ; then
AC_MSG_RESULT([using new PROJ version 5+ API])
# With PROJ library directory
@@ -696,6 +708,7 @@
LOC_CHECK_LIBS(proj,proj_pj_info,External PROJ,$PROJLIB,PROJLIB,,,)
else
AC_MSG_RESULT([using old PROJ version 4 API])
+ AC_DEFINE(USE_PROJ4API)
LOC_CHECK_INCLUDES(proj_api.h,External PROJ,$PROJINC)
# PROJ version check for v4.x
Modified: grass/trunk/include/config.h.in
--- grass/trunk/include/config.h.in 2018-06-06 17:51:47 UTC (rev 72777)
+++ grass/trunk/include/config.h.in 2018-06-06 19:15:27 UTC (rev 72778)
@@ -146,8 +146,11 @@
/* define if SQLite is to be used */
#undef HAVE_SQLITE
-/* define if proj.h exists */
+#undef USE_PROJ4API
+#ifndef USE_PROJ4API
+/* define if proj.h exists and if the PROJ4 API should not be used */
#undef HAVE_PROJ_H
+#endif
/* define if GDAL is to be used */
#undef HAVE_GDAL
