[GRASS-SVN] r72780 - grass/trunk
svn_grass at osgeo.org
Wed Jun 6 13:15:00 PDT 2018
Author: mmetz
Date: 2018-06-06 13:15:00 -0700 (Wed, 06 Jun 2018)
New Revision: 72780
grass/trunk/configure
grass/trunk/configure.in
configure: fix version check
Modified: grass/trunk/configure
--- grass/trunk/configure 2018-06-06 19:17:06 UTC (rev 72779)
+++ grass/trunk/configure 2018-06-06 20:15:00 UTC (rev 72780)
@@ -5874,7 +5874,7 @@
echo "$ac_t""found PROJ version "${proj_ver_major}.${proj_ver_minor}.${proj_ver_patch}"" 1>&6
# minimum required PROJ 5+ version to use the new PROJ API: 5.1.0
- if test ${proj_ver_major} = 5 && test `expr "proj_ver_minor" \< 1` = 1 ; then
+ if test ${proj_ver_major} = 5 && test `expr ${proj_ver_minor} \< 1` = 1 ; then
echo "configure: warning: At least PROJ version "5.1.0" is required for the new API " 1>&2
PROJ4API=1
fi
@@ -6051,7 +6051,7 @@
CPPFLAGS=$ac_save_cppflags
- if test `expr "$proj_ver" \< 446` = 1 ; then
+ if test `expr ${proj_ver} \< 446` = 1 ; then
{ echo "configure: error: *** PROJ.4.4.6 or later is required." 1>&2; exit 1; }
fi
fi
Modified: grass/trunk/configure.in
--- grass/trunk/configure.in 2018-06-06 19:17:06 UTC (rev 72779)
+++ grass/trunk/configure.in 2018-06-06 20:15:00 UTC (rev 72780)
@@ -693,7 +693,7 @@
LOC_CHECK_VERSION_INT(proj.h,PROJ_VERSION_PATCH,External PROJ patch,proj_ver_patch,$PROJINC,0)
AC_MSG_RESULT([found PROJ version "${proj_ver_major}.${proj_ver_minor}.${proj_ver_patch}"])
AC_MSG_WARN([At least PROJ version "5.1.0" is required for the new API ])
PROJ4API=1
fi
@@ -718,7 +718,7 @@
else
LOC_CHECK_VERSION_INT(proj_api.h,PJ_VERSION,External PROJ.4,proj_ver,$PROJINC,0)
AC_MSG_ERROR([*** PROJ.4.4.6 or later is required.])
fi
fi
