[GRASS-SVN] r72801 - grass-addons/grass7/raster/r.lfp
svn_grass at osgeo.org
Mon Jun 11 20:28:26 PDT 2018
Author: hcho
Date: 2018-06-11 20:28:26 -0700 (Mon, 11 Jun 2018)
New Revision: 72801
grass-addons/grass7/raster/r.lfp/r.lfp.py
Split the longest flow path at outlet
Modified: grass-addons/grass7/raster/r.lfp/r.lfp.py
--- grass-addons/grass7/raster/r.lfp/r.lfp.py 2018-06-12 01:19:03 UTC (rev 72800)
+++ grass-addons/grass7/raster/r.lfp/r.lfp.py 2018-06-12 03:28:26 UTC (rev 72801)
@@ -84,25 +84,8 @@
except CalledModuleError:
grass.fatal(_("Cannot calculate the downstream flow length"))
- # calculate the upstream flow length
- flus = prefix + "flus"
- try:
- grass.run_command("r.stream.distance", overwrite=True, flags="o",
- stream_rast=outlet, direction=input,
- method="upstream", distance=flus)
- except CalledModuleError:
- grass.fatal(_("Cannot calculate the upstream flow length"))
- # calculate the sum of downstream and upstream flow lengths
- fldsus = prefix + "fldsus"
- try:
- grass.run_command("r.mapcalc", overwrite=True,
- expression="%s=%s+%s" % (fldsus, flds, flus))
- grass.fatal(_("Cannot calculate the sum of downstream and upstream flow lengths"))
# find the longest flow length
- p = grass.pipe_command("r.info", flags="r", map=fldsus)
+ p = grass.pipe_command("r.info", flags="r", map=flds)
max = ""
for line in p.stdout:
line = line.rstrip("\n")
@@ -113,23 +96,14 @@
if p.returncode != 0 or max == "":
grass.fatal(_("Cannot find the longest flow length"))
- min = float(max) - 0.0005
+ threshold = float(max) - 0.0005
- # extract the longest flow path
- lfp = prefix + "lfp"
- try:
- expression="%s=if(%s>=%f, 1, null())" %
- (lfp, fldsus, min))
- grass.fatal(_("Cannot create the longest flow path raster map"))
# find the headwater cells
heads = prefix + "heads"
try:
- expression="%s=if(!isnull(%s)&&%s>=%f,1,null())" %
- (heads, lfp, flds, min))
+ expression="%s=if(%s>=%f,1,null())" %
+ (heads, flds, threshold))
grass.fatal(_("Cannot find the headwater cells"))
@@ -141,12 +115,46 @@
grass.fatal(_("Cannot create the headwater vector map"))
# calculate the longest flow path in vector format
+ path = prefix + "path"
try:
- grass.run_command("r.path", input=input, vector_path=output,
+ grass.run_command("r.path", input=input, vector_path=path,
start_points=heads)
grass.fatal(_("Cannot create the longest flow path vector map"))
+ # snap the outlet
+ try:
+ grass.run_command("r.to.vect", overwrite=True,
+ input=outlet, output=outlet, type="point")
+ except CalledModuleError:
+ grass.fatal(_("Cannot snap the outlet"))
+ # find the coordinates of the snapped outlet
+ p = grass.pipe_command("v.to.db", flags="p", map=outlet, option="coor")
+ coords = ""
+ for line in p.stdout:
+ line = line.rstrip("\n")
+ if line == "cat|x|y|z":
+ continue
+ cols = line.split("|")
+ coords = "%s,%s" % (cols[1], cols[2])
+ p.wait()
+ if p.returncode != 0 or coords == "":
+ grass.fatal(_("Cannot find the coordinates of the snapped outlet"))
+ # split the longest flow path at the outlet
+ try:
+ grass.run_command("v.edit", map=path, tool="break", coords=coords)
+ grass.fatal(_("Cannot split the longest flow path at the outlet"))
+ # select the final longest flow path
+ try:
+ grass.run_command("v.select", overwrite=True,
+ ainput=path, binput=heads, output=output)
+ grass.fatal(_("Cannot select the final longest flow path"))
# remove intermediate outputs
grass.run_command("g.remove", flags="f", type="raster,vector",
pattern="%s*" % prefix)
