[GRASS-SVN] r72816 - grass-addons/grass7/imagery/i.sentinel.mask
svn_grass at osgeo.org
Wed Jun 13 08:06:30 PDT 2018
Author: Robifag
Date: 2018-06-13 08:06:30 -0700 (Wed, 13 Jun 2018)
New Revision: 72816
Added:
grass-addons/grass7/imagery/i.sentinel.mask/Makefile
grass-addons/grass7/imagery/i.sentinel.mask/i.sentinel.mask.html
grass-addons/grass7/imagery/i.sentinel.mask/i.sentinel.mask.py
grass-addons/grass7/imagery/i.sentinel.mask/i_sentinel_mask_CD.png
grass-addons/grass7/imagery/i.sentinel.mask/i_sentinel_mask_CS.png
grass-addons/grass7/imagery/i.sentinel.mask/i_sentinel_mask_GWF.png
grass-addons/grass7/imagery/i.sentinel.mask/i_sentinel_mask_SD.png
Add the first version of i.sentinel.mask module
Added: grass-addons/grass7/imagery/i.sentinel.mask/Makefile
--- grass-addons/grass7/imagery/i.sentinel.mask/Makefile (rev 0)
+++ grass-addons/grass7/imagery/i.sentinel.mask/Makefile 2018-06-13 15:06:30 UTC (rev 72816)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = i.sentinel.mask
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Added: grass-addons/grass7/imagery/i.sentinel.mask/i.sentinel.mask.html
--- grass-addons/grass7/imagery/i.sentinel.mask/i.sentinel.mask.html (rev 0)
+++ grass-addons/grass7/imagery/i.sentinel.mask/i.sentinel.mask.html 2018-06-13 15:06:30 UTC (rev 72816)
@@ -0,0 +1,94 @@
+<h2>DESCRIPTION</h2>
+<em>i.sentinel.mask</em> allows to automatically identify clouds and their shadows in Sentinel 2 images.
+<p>
+The implemented procedure consists essentially of values thresholds, comparisons and calculations between bands and they lead to two different
+rough maps of clouds and shadows which require further improvements and elaborations (e.g. transformation from raster to vector, cleaning geometries,
+ removing small areas, checking topology, etc.) carried out in the different steps of the procedure.
+<table cellspacing="2" cellpadding="2" width="100%" border="0">
+ <tbody>
+ <tr>
+ <td align="center" valign="bottom"><a href="i_sentinel_mask_GWF.png"><img src="i_sentinel_mask_GWF.png" width="100%"></a><br><i>Fig: Module General WorkFlow</i></td>
+ <td align="center" valign="bottom"><a href="i_sentinel_mask_CD.png"><img src="i_sentinel_mask_CD.png" width="100%"></a><br><i>Fig: Cloud detection procedure</i></td>
+ <td align="center" valign="bottom"><a href="i_sentinel_mask_SD.png"><img src="i_sentinel_mask_SD.png" width="100%"></a><br><i>Fig: Shadow detection procedure</i></td>
+ </tr>
+ </tbody>
+</table>
+<p>
+The algorithm has been developed starting from rules found in literature (Parmes et. al 2017) and conveniently refined.<br>
+Regarding the detection of shadows, some misclassification can occur. Often shadows and water have in fact similar reflectance
+values which can lead to erroneous classification of water bodies as shadows. Therefore, in order to increase the accuracy of
+the final shadow mask, a control check is implemented. Clouds and shadows are spatially intersected in order to remove misclassified areas.
+This means that all those shadow geometries which do not intersect a cloud geometry are removed.
+<div align="center" style="margin: 10px">
+<a href="i_sentinel_mask_CS.png">
+<img src="i_sentinel_mask_CS.png" width="30%">
+</a><br>
+<i>Fig: Module General WorkFlow</i>
+</div>
+<!--center>
+<br>
+</center-->
+<p>
+All necessary input bands (blue, green, red, nir, nir8a, swir11, swir12) must be imported in GRASS and specified one by one or using a text file.
+The text file has to be written following the syntax below: <em>variable=your_map</em>
+<div class="code"><pre>
+blue=<em>your_blue_map</em>
+green=<em>your_green_map</em>
+red=<em>your_red_map</em>
+nir=<em>your_nir_map</em>
+nir8a=<em>your_nir8a_map</em>
+swir11=<em>your_swir11_map</em>
+swir12=<em>your_swir12_map</em>
+</pre></div>
+Tha variables names (blue, green, red, nir, nir8a, swir11, swir12) have to be written precisely like in the example above (e.g. not Blue, nor BLUE but blue),
+no spaces or special characters are permitted.
+<p>
+The final outputs are two different vector maps, one for clouds and one for shadows.
+<p>
+The metadata file (MTD_TL.xml) is required only if both masks (cloud and shadow)
+are computed. The module retrieves from this file the sun azimuth and zenith necessary for the shadow mask cleaning phase
+<em>(see the schema above)</em>
+<p>
+If flag <b>-s</b> is given all selected bands are rescaled using the specified scale factor [<b>scale_fac</b>=<em>integer</em>]. By default the scale factor is set to 10000,
+the QUANTIFICATION_VALUE from the metadata of Sentinel 2 images.
+<p>
+The module takes the current region settings into accout. To ignore the current region and set it from the whole image, the flag <b>-r</b> has to be given.
+<p>
+The module allows to compute only the cloud mask or both cloud and shadow masks. If flag <b>-c</b> is given, only the cloud procedure will be performed. The computation
+of cloud mask is mandatory for shadow mask creation. In fact cloud map is used during the cleaning phase of the shadow mask in order to remove misclassifications.
+<h2>EXAMPLE</h2>
+<div class="code">
+i.sentinel.mask -r -s input_file=/home/input_bands.txt cloud_mask=cloud_sen2 shadow_mask=shadow_sen2 mtd_file=/home/MTD_TL.xml scale_fac=1000
+</div>
+<p>
+-r to set the computational region to the maximum image extente and -s to rescale the input bands with the specified scale factor (in this case 1000)
+<h2>REFERENCE</h2>
+<ul>
+<li>Parmes et. al 2017</li>
+</ul>
+<h2>SEE ALSO</h2>
+<em>
+<a href="i.sentinel.download.html">i.sentinel.download</a>,
+<a href="i.sentinel.import.html">i.sentinel.import</a>,
+<a href="r.import.html">r.import</a>,
+<a href="r.extenal.html">r.external</a>
+</em>
+<h2>AUTHOR</h2>
+Roberta Fagandini, GSoC 2018 student<br>
+<a href="https://wiki.osgeo.org/wiki/User:Mlennert">Moritz Lennert</a><br>
+<a href="https://wiki.osgeo.org/wiki/User:Robertomarzocchi">Roberto Marzocchi</a>
Added: grass-addons/grass7/imagery/i.sentinel.mask/i.sentinel.mask.py
--- grass-addons/grass7/imagery/i.sentinel.mask/i.sentinel.mask.py (rev 0)
+++ grass-addons/grass7/imagery/i.sentinel.mask/i.sentinel.mask.py 2018-06-13 15:06:30 UTC (rev 72816)
@@ -0,0 +1,549 @@
+#!/usr/bin/env python
+# coding=utf-8
+# MODULE: i.sentinel.mask
+# AUTHOR(S): Roberta Fagandini, Moritz Lennert, Roberto Marzocchi
+# PURPOSE: Creates clouds and shadows masks for Sentinel-2 images
+# COPYRIGHT: (C) 2018 by the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+#%Module
+#% description: Creates clouds and shadows masks for Sentinel-2 images
+#% keywords: imagery
+#% keywords: sentinel
+#% keywords: cloud detection
+#% keywords: shadow
+#% keywords: reflectance
+#%End
+#%option
+#% key: input_file
+#% type: string
+#% gisprompt: old,file,file
+#% description: name of the .txt file with listed input bands
+#% required : no
+#% multiple: no
+#% guisection: Required
+#%end
+#%option
+#% key: blue
+#% type: string
+#% gisprompt: old,cell,raster
+#% description: input bands
+#% required : no
+#% multiple: no
+#%end
+#%option
+#% key: green
+#% type: string
+#% required : no
+#% multiple: no
+#%end
+#%option
+#% key: red
+#% type: string
+#% required : no
+#% multiple: no
+#%end
+#%option
+#% key: nir
+#% type: string
+#% required : no
+#% multiple: no
+#%end
+#%option
+#% key: nir8a
+#% type: string
+#% required : no
+#% multiple: no
+#%end
+#%option
+#% key: swir11
+#% type: string
+#% required : no
+#% multiple: no
+#%end
+#%option
+#% key: swir12
+#% type: string
+#% required : no
+#% multiple: no
+#%end
+#%option
+#% key: cloud_mask
+#% type: string
+#% gisprompt: new,vector,vector
+#% description: name of output vector cloud mask
+#% required : yes
+#% guisection: Output
+#%end
+#%option
+#% key: shadow_mask
+#% type: string
+#% description: name of output vector shadow mask
+#% required : no
+#%end
+#%option
+#% key: mtd_file
+#% type: string
+#% description: name of the image metadata file (MTD_TL.xml)
+#% required : no
+#% multiple: no
+#% guisection: Metadata
+#%end
+#%option
+#% key: scale_fac
+#% type: integer
+#% description: rescale factor
+#% required : no
+#% answer: 10000
+#% guisection: Rescale
+#%end
+#%flag
+#% key: r
+#% description: Set computational region to maximum image extent
+#%end
+#%flag
+#% key: t
+#% description: Do not delete temporary files
+#%end
+#%flag
+#% key: s
+#% description: Rescale input bands
+#%end
+#%flag
+#% key: c
+#% description: Compute only the cloud mask
+#%end
+import grass.script as gscript
+import math
+import os
+import sys
+import shutil
+import re
+import glob
+import numpy
+import time
+import atexit
+import xml.etree.ElementTree as et
+def main ():
+ #import bands atmospherically corrected using arcsi (scale factor 1000 instead of 10000)
+ # INPUT
+ #temporary map names
+ global tmp, t, mapset
+ tmp = {}
+ mapset = gscript.gisenv()['MAPSET']
+ mapset2 = '@{}'.format(mapset)
+ processid = os.getpid()
+ processid = str(processid)
+ tmp["cloud_def"] = "cloud_def"+ processid
+ tmp["shadow_temp"] = "shadow_temp"+ processid
+ tmp["cloud_v"] = "cloud_v_" + processid
+ tmp["shadow_temp_v"] = "shadow_temp_v_" + processid
+ tmp["shadow_temp_mask"] = "shadow_temp_mask_" + processid
+ tmp["centroid"] = "centroid_" + processid
+ tmp["dissolve"] = "dissolve_" + processid
+ tmp["delcat"] = "delcat_" + processid
+ tmp["addcat"] = "addcat_" + processid
+ tmp["cl_shift"] = "cl_shift_" + processid
+ tmp["overlay"] = "overlay_" + processid
+ #check temporary map names are not existing maps
+ for key, value in tmp.items():
+ if gscript.find_file(value,
+ element = 'vector',
+ mapset = mapset)['file']:
+ gscript.fatal(("Temporary vector map <{}> already exists.").format(value))
+ element = 'cell',
+ gscript.fatal(("Temporary raster map <{}> already exists.").format(value))
+ #input file
+ mtd_file = options['mtd_file']
+ bands = {}
+ if options['input_file']=='':
+ bands['blue'] = options['blue']
+ bands['green'] = options['green']
+ bands['red'] = options['red']
+ bands['nir'] = options['nir']
+ bands['nir8a'] = options['nir8a']
+ bands['swir11'] = options['swir11']
+ bands['swir12'] = options['swir12']
+ else:
+ input_file = options['input_file']
+ for line in file(input_file):
+ a = line.split('=')
+ if len(a) != 2 or a[0] not in ['blue', 'green', 'red', 'nir', 'nir8a', 'swir11', 'swir12' ]:
+ gscript.fatal("Syntax error in the txt file. See the manual for further information about the right syntax.")
+ a[1] = a[1].strip()
+ bands[a[0]] = a[1]
+ d = 'double'
+ f_bands = {}
+ scale_fac = options['scale_fac']
+ cloud_clean_T = 50000
+ shadow_clean_T = 10000
+ raster_max = {}
+ cloud_mask = options['cloud_mask']
+ shadow_mask = options['shadow_mask']
+ if bands['blue'] == '' or bands['green'] == '' or bands['red'] == '' or bands['nir'] == '' or bands['nir8a'] == '' or bands['swir11'] == '' or bands['swir12'] == '':
+ gscript.fatal(("All input bands (blue, green, red, nir, nir8a, swir11, swir12) are required"))
+ for key, value in bands.items():
+ if not gscript.find_file(value,
+ element = 'cell',
+ gscript.fatal(("Raster map <{}> not found.").format(value))
+ if not flags["c"]:
+ if options['mtd_file']== '':
+ gscript.fatal("Metadata file is required for shadow mask computation. Please specified it")
+ if options['shadow_mask']=='':
+ gscript.fatal("Output name is required for shadow mask. Please specified it")
+ if flags["r"]:
+ gscript.use_temp_region()
+ gscript.run_command('g.region',
+ rast=bands.values(),
+ flags='a')
+ gscript.message(_("--- The computational region has been temporarily set to image max extent ---"))
+ else:
+ gscript.warning(_("All subsequent operations will be limited to the current computational region"))
+ if flags["s"]:
+ gscript.message(_('--- Start rescaling bands ---'))
+ for key, b in bands.items():
+ gscript.message(_(b))
+ b = gscript.find_file(b, element = 'cell')['name']
+ gscript.mapcalc('{r} = 1.0 * ({b})/{scale_fac}'.format(
+ r=("{}_{}".format(b, d)),
+ b=b,
+ scale_fac=scale_fac))
+ f_bands[key] = "{}_{}".format(b, d)
+ gscript.message(_(f_bands.values()))
+ gscript.message(_('--- All bands have been rescaled ---'))
+ else:
+ gscript.warning(_('Any rescale factor has been applied'))
+ if gscript.raster_info(b)['datatype'] != "DCELL":
+ gscript.fatal("Raster maps must be double")
+ else:
+ f_bands = bands
+ gscript.message(_('--- Start computing maximum values of bands ---'))
+ for key, fb in f_bands.items():
+ gscript.message(_(fb))
+ stats = gscript.parse_command('r.univar', flags='g', map=fb)
+ raster_max[key] = (float(stats['max']))
+ gscript.message(_('--- Computed maximum value: {} ---'.format(raster_max.values())))
+ gscript.message(_('--- Statistics have been computed! ---'))
+ #### start of Clouds detection (some rules from litterature)###
+ gscript.message(_('--- Start clouds detection procedure ---'))
+ gscript.message(_('--- Computing cloud mask... ---'))
+ first_rule = '(({} > (0.08*{})) && ({} > (0.08*{})) && ({} > (0.08*{})))'.format(
+ f_bands['blue'],
+ raster_max['blue'],
+ f_bands['green'],
+ raster_max['green'],
+ f_bands['red'],
+ raster_max['red'])
+ second_rule = '(({} < ((0.08*{})*1.5)) && ({} > {}*1.3))'.format(
+ f_bands['red'],
+ raster_max['red'],
+ f_bands['red'],
+ f_bands['swir12'])
+ third_rule = '(({} < (0.1*{})) && ({} < (0.1*{})))'.format(
+ f_bands['swir11'],
+ raster_max['swir11'],
+ f_bands['swir12'],
+ raster_max['swir12'])
+ fourth_rule = '(if({} == max({}, 2 * {}, 2 * {}, 2 * {})))'.format(
+ f_bands['nir8a'],
+ f_bands['nir8a'],
+ f_bands['blue'],
+ f_bands['green'],
+ f_bands['red'])
+ fifth_rule = '({} > 0.2)'.format(f_bands['blue'])
+ cloud_rules = '({} == 1) && ({} == 0) && ({} == 0) && ({} == 0) && ({} == 1)'.format(
+ first_rule,
+ second_rule,
+ third_rule,
+ fourth_rule,
+ fifth_rule)
+ expr_c = '{} = if({}, 0, null( ))'.format(
+ tmp["cloud_def"],
+ cloud_rules)
+ gscript.mapcalc(expr_c, overwrite=True)
+ gscript.message(_('--- Converting raster cloud mask into vector map ---'))
+ gscript.run_command('r.to.vect',
+ input=tmp["cloud_def"],
+ output=tmp["cloud_v"],
+ type='area',
+ flags='s')
+ gscript.message(_('--- Cleaning geometries ---'))
+ gscript.run_command('v.clean',
+ input=tmp["cloud_v"],
+ output=cloud_mask,
+ tool='rmarea',
+ threshold=cloud_clean_T)
+ gscript.message(_('--- Finish cloud detection procedure ---'))
+ ### end of Clouds detection ####
+ ### start of shadows detection ###
+ gscript.message(_('--- Start shadows detection procedure ---'))
+ gscript.message(_('--- Computing shadow mask... ---'))
+ sixth_rule = '((({} > {}) && ({} < {}) && ({} < 0.1) && ({} < 0.1)) \
+ || (({} < {}) && ({} < {}) && ({} < 0.1) && ({} < 0.1) && ({} < 0.1)))'.format(
+ f_bands['blue'],
+ f_bands['blue'],
+ f_bands['nir'],
+ f_bands['blue'],
+ f_bands['blue'],
+ f_bands['blue'],
+ f_bands['nir'],
+ f_bands['blue'],
+ f_bands['nir'])
+ seventh_rule = '({} - {})'.format(
+ f_bands['green'],
+ f_bands['blue'])
+ shadow_rules = '(({} == 1) && ({} < 0.007))'.format(
+ sixth_rule,
+ seventh_rule)
+ expr_s = '{} = if({}, 0, null( ))'.format(
+ tmp["shadow_temp"],
+ shadow_rules)
+ gscript.mapcalc( expr_s, overwrite=True)
+ gscript.message(_('--- Converting raster shadow mask into vector map ---'))
+ input=tmp["shadow_temp"],
+ output=tmp["shadow_temp_v"],
+ type='area',
+ flags='s',
+ overwrite=True)
+ input=tmp["shadow_temp_v"],
+ output=tmp["shadow_temp_mask"],
+ tool='rmarea',
+ threshold=shadow_clean_T)
+ gscript.message(_('--- Finish Shadows detection procedure ---'))
+ ### end of shadows detection ###
+ # START shadows cleaning Procedure (remove shadows misclassification)
+ ### start shadow mask preparation ###
+ gscript.message(_('--- Start removing misclassification from the shadow mask ---'))
+ gscript.message(_('--- Data preparation... ---'))
+ gscript.run_command('v.centroids',
+ input=tmp["shadow_temp_mask"],
+ output=tmp["centroid"],
+ quiet=True)
+ gscript.run_command('v.db.droptable',
+ map=tmp["centroid"],
+ flags='f')
+ gscript.run_command('v.db.addtable',
+ columns='value')
+ gscript.run_command('v.db.update',
+ layer=1,
+ column='value',
+ value=1)
+ gscript.run_command('v.dissolve',
+ input=tmp["centroid"],
+ column='value',
+ output=tmp["dissolve"],
+ quiet=True)
+ gscript.run_command('v.category',
+ input=tmp["dissolve"],
+ type='point,line,boundary,centroid,area,face,kernel',
+ output=tmp["delcat"],
+ option='del',
+ cat=-1,
+ quiet=True)
+ input=tmp["delcat"],
+ type='centroid,area',
+ output=tmp["addcat"],
+ option='add',
+ quiet=True)
+ map=tmp["addcat"],
+ flags='f')
+ columns='value')
+ ### end shadow mask preparation ###
+ ### start cloud mask preparation ###
+ map=cloud_mask,
+ flags='f')
+ map=cloud_mask,
+ columns='value')
+ ### end cloud mask preparation ###
+ ### shift cloud mask using dE e dN ###
+ ### start reading mean sun zenith and azimuth from xml file to compute dE and dN automatically ###
+ gscript.message(_('--- Reading mean sun zenith and azimuth from MTD_TL.xml file to compute clouds shift ---'))
+ xml_tree = et.parse(mtd_file)
+ root = xml_tree.getroot()
+ ZA = []
+ for elem in root[1]:
+ for subelem in elem[1]:
+ ZA.append (subelem.text)
+ z = float(ZA[0])
+ a = float(ZA[1])
+ gscript.message(_('--- the mean sun Zenith is: {:.3f} deg ---'.format(z)))
+ gscript.message(_('--- the mean sun Azimuth is: {:.3f} deg ---'.format(a)))
+ ### stop reading mean sun zenith and azimuth from xml file to compute dE and dN automatically ###
+ ### start computing the east and north shift for clouds and the overlapping area between clouds and shadows at steps of 100m ###
+ gscript.message(_('--- Start computing the east and north clouds shift at steps of 100m of clouds height---'))
+ H = 1000
+ dH = 100
+ HH = []
+ dE = []
+ dN = []
+ AA = []
+ while H <= 4000:
+ z_deg_to_rad = math.radians(z)
+ tan_Z = math.tan(z_deg_to_rad)
+ a_deg_to_rad = math.radians(a)
+ cos_A = math.cos(a_deg_to_rad)
+ sin_A = math.sin(a_deg_to_rad)
+ E_shift = (-H * tan_Z * sin_A)
+ N_shift = (-H * tan_Z * cos_A)
+ dE.append (E_shift)
+ dN.append (N_shift)
+ HH.append(H)
+ H = H + dH
+ gscript.run_command('v.transform',
+ input=cloud_mask,
+ output=tmp["cl_shift"],
+ xshift=E_shift,
+ yshift=N_shift,
+ overwrite=True,
+ quiet=True)
+ gscript.run_command('v.overlay',
+ ainput=tmp["addcat"],
+ binput=tmp["cl_shift"],
+ operator='and',
+ output=tmp["overlay"],
+ overwrite=True,
+ quiet=True)
+ gscript.run_command('v.db.addcolumn',
+ map=tmp["overlay"],
+ columns='area double')
+ area = gscript.read_command('v.to.db',
+ option='area',
+ columns='area',
+ flags='c')
+ area2 = gscript.parse_key_val(area, sep='|')
+ AA.append(float(area2['total area']))
+ # find the maximum overlapping area between clouds and shadows#
+ index_maxAA = numpy.argmax(AA)
+ # clouds are shifted using the clouds height corresponding to the maximum overlapping area then are intersect with shadows#
+ input=cloud_mask,
+ xshift=dE[index_maxAA],
+ yshift=dN[index_maxAA],
+ overwrite=True,
+ quiet=True)
+ gscript.run_command('v.select',
+ atype='point,line,boundary,centroid,area',
+ btype='point,line,boundary,centroid,area',
+ output=shadow_mask,
+ operator='intersects',
+ quiet=True)
+ gscript.message(_('--- the estimated clouds height is: {} m ---'.format(HH[index_maxAA])))
+ gscript.message(_('--- the estimated east shift is: {:.2f} m ---'.format(dE[index_maxAA])))
+ gscript.message(_('--- the estimated north shift is: {:.2f} m ---'.format(dN[index_maxAA])))
+ else:
+ gscript.warning(_('No shadow mask will be computed'))
+def cleanup():
+ if flags["r"]:
+ gscript.del_temp_region()
+ gscript.message(_('--- The computational region has been reset to the previous one---'))
+ if flags["t"]:
+ gscript.message(_('--- No temporary files have been deleted ---'))
+ else:
+ if gscript.find_file(value, element = 'vector', mapset = mapset)['file']:
+ gscript.run_command("g.remove",
+ flags="f",
+ type='vector',
+ name=",".join([tmp[m] for m in tmp.keys()]),
+ quiet=True)
+ if gscript.find_file(value, element = 'cell', mapset = mapset)['file']:
+ flags="f",
+ type='raster',
+ quiet=True)
+if __name__ == "__main__":
+ options, flags = gscript.parser()
+ atexit.register(cleanup)
+ main()
Added: grass-addons/grass7/imagery/i.sentinel.mask/i_sentinel_mask_CD.png
(Binary files differ)
Index: grass-addons/grass7/imagery/i.sentinel.mask/i_sentinel_mask_CD.png
--- grass-addons/grass7/imagery/i.sentinel.mask/i_sentinel_mask_CD.png 2018-06-13 15:05:18 UTC (rev 72815)
+++ grass-addons/grass7/imagery/i.sentinel.mask/i_sentinel_mask_CD.png 2018-06-13 15:06:30 UTC (rev 72816)
Property changes on: grass-addons/grass7/imagery/i.sentinel.mask/i_sentinel_mask_CD.png
___________________________________________________________________
Added: svn:mime-type
## -0,0 +1 ##
+application/octet-stream
\ No newline at end of property
Added: grass-addons/grass7/imagery/i.sentinel.mask/i_sentinel_mask_CS.png
Index: grass-addons/grass7/imagery/i.sentinel.mask/i_sentinel_mask_CS.png
--- grass-addons/grass7/imagery/i.sentinel.mask/i_sentinel_mask_CS.png 2018-06-13 15:05:18 UTC (rev 72815)
+++ grass-addons/grass7/imagery/i.sentinel.mask/i_sentinel_mask_CS.png 2018-06-13 15:06:30 UTC (rev 72816)
Property changes on: grass-addons/grass7/imagery/i.sentinel.mask/i_sentinel_mask_CS.png
## -0,0 +1 ##
Added: grass-addons/grass7/imagery/i.sentinel.mask/i_sentinel_mask_GWF.png
Index: grass-addons/grass7/imagery/i.sentinel.mask/i_sentinel_mask_GWF.png
--- grass-addons/grass7/imagery/i.sentinel.mask/i_sentinel_mask_GWF.png 2018-06-13 15:05:18 UTC (rev 72815)
+++ grass-addons/grass7/imagery/i.sentinel.mask/i_sentinel_mask_GWF.png 2018-06-13 15:06:30 UTC (rev 72816)
Property changes on: grass-addons/grass7/imagery/i.sentinel.mask/i_sentinel_mask_GWF.png
## -0,0 +1 ##
Added: grass-addons/grass7/imagery/i.sentinel.mask/i_sentinel_mask_SD.png
Index: grass-addons/grass7/imagery/i.sentinel.mask/i_sentinel_mask_SD.png
--- grass-addons/grass7/imagery/i.sentinel.mask/i_sentinel_mask_SD.png 2018-06-13 15:05:18 UTC (rev 72815)
+++ grass-addons/grass7/imagery/i.sentinel.mask/i_sentinel_mask_SD.png 2018-06-13 15:06:30 UTC (rev 72816)
Property changes on: grass-addons/grass7/imagery/i.sentinel.mask/i_sentinel_mask_SD.png
## -0,0 +1 ##
