[GRASS-SVN] r72820 - grass-addons/grass7/raster/r.lfp
svn_grass at osgeo.org
Wed Jun 13 22:32:16 PDT 2018
Author: hcho
Date: 2018-06-13 22:32:16 -0700 (Wed, 13 Jun 2018)
New Revision: 72820
grass-addons/grass7/raster/r.lfp/r.lfp.py
r.lfp: Check for integer IDs
Modified: grass-addons/grass7/raster/r.lfp/r.lfp.py
--- grass-addons/grass7/raster/r.lfp/r.lfp.py 2018-06-14 05:12:14 UTC (rev 72819)
+++ grass-addons/grass7/raster/r.lfp/r.lfp.py 2018-06-14 05:32:16 UTC (rev 72820)
@@ -89,6 +89,11 @@
if id:
ids = id.split(",")
+ for i in range(0, len(ids)):
+ try:
+ ids[i] = int(ids[i])
+ except:
+ grass.fatal(_("Invalid ID '%s'") % ids[i])
else:
ids = []
@@ -120,7 +125,10 @@
cols = line.split("|")
coords.extend([cols[x_ind], cols[y_ind]])
if outletid_ind >= 0:
- ids.extend([cols[outletid_ind]])
+ try:
+ ids.extend([int(cols[outletid_ind])])
+ except:
p.wait()
if p.returncode != 0:
grass.fatal(_("Cannot read outlet points"))
@@ -148,8 +156,13 @@
grass.fatal(_("Cannot add a table to the output vector map"))
for i in range(0, len(coords) / 2):
+ cat = i + 1
coor = "%s,%s" % (coords[2*i], coords[2*i+1])
- grass.message(_("Processing the outlet at %s..." % coor))
+ if assign_id:
+ id = ids[i]
+ grass.message(_("Processing outlet %d at %s...") % (id, coor))
+ else:
+ grass.message(_("Processing outlet at %s...") % coor)
# create the outlet vector map
out = prefix + "out"
@@ -255,10 +268,10 @@
grass.run_command("v.category", overwrite=True,
input=lfp, output=lfp2, option="del", cat=-1)
- input=lfp2, output=lfp, option="add", cat=i+1,
+ input=lfp2, output=lfp, option="add", cat=cat,
step=0)
except CalledModuleError:
- grass.fatal(_("Cannot add categories"))
+ grass.fatal(_("Cannot add category %d") % cat)
# copy the final longest flow path to the output map
try:
@@ -272,9 +285,9 @@
grass.run_command("v.to.db", map=output, option="cat",
columns="cat")
grass.run_command("v.db.update", map=output, column=idcol,
- value=ids[i], where="cat=%d" % (i+1))
+ value=id, where="cat=%d" % cat)
- grass.fatal(_("Cannot assign ID"))
+ grass.fatal(_("Cannot assign ID %d") % id)
# remove intermediate outputs
grass.run_command("g.remove", flags="f", type="raster,vector",
