[GRASS-SVN] r72831 - grass/trunk/raster/r.external
svn_grass at osgeo.org
Thu Jun 14 13:27:04 PDT 2018
Author: mmetz
Date: 2018-06-14 13:27:04 -0700 (Thu, 14 Jun 2018)
New Revision: 72831
grass/trunk/raster/r.external/link.c
grass/trunk/raster/r.external/proto.h
r.external: get real stats, not approximations for each band
Modified: grass/trunk/raster/r.external/link.c
--- grass/trunk/raster/r.external/link.c 2018-06-14 17:55:34 UTC (rev 72830)
+++ grass/trunk/raster/r.external/link.c 2018-06-14 20:27:04 UTC (rev 72831)
@@ -8,8 +8,6 @@
void query_band(GDALRasterBandH hBand, const char *output,
struct Cell_head *cellhd, struct band_info *info)
- int bGotMin, bGotMax;
info->gdal_type = GDALGetRasterDataType(hBand);
info->null_val = GDALGetRasterNoDataValue(hBand, &info->has_null);
@@ -49,11 +47,6 @@
break;
- info->range[0] = GDALGetRasterMinimum(hBand, &bGotMin);
- info->range[1] = GDALGetRasterMaximum(hBand, &bGotMax);
- if(!(bGotMin && bGotMax))
- GDALComputeRasterMinMax(hBand, 0, info->range);
Rast_init_colors(&info->colors);
if (GDALGetRasterColorTable(hBand) != NULL) {
@@ -82,13 +75,6 @@
output);
Rast_make_grey_scale_colors(&info->colors, 0, 255);
- else {
- /* set data range to grey scale: */
- G_verbose_message(_("Setting grey color table for <%s> (data range)"),
- output);
- Rast_make_grey_scale_colors(&info->colors,
- (int) info->range[0], (int) info->range[1]);
@@ -198,6 +184,7 @@
struct History history;
struct Categories cats;
char buf[1024];
+ int outfd;
Rast_put_cellhd(output, cellhd);
@@ -205,19 +192,7 @@
make_link(input, output, band, info, flip);
- if (info->data_type == CELL_TYPE) {
- struct Range range;
- range.min = (CELL)info->range[0];
- range.max = (CELL)info->range[1];
- range.first_time = 0;
- Rast_write_range(output, &range);
- else {
- struct FPRange fprange;
- fprange.min = info->range[0];
- fprange.max = info->range[1];
- fprange.first_time = 0;
- Rast_write_fp_range(output, &fprange);
+ if (info->data_type != CELL_TYPE) {
write_fp_format(output, info);
write_fp_quant(output);
@@ -236,5 +211,39 @@
if (title)
Rast_put_cell_title(output, title);
- G_done_msg(_("Link to raster map <%s> created."), output);
+ /* get stats for this raster band */
+ G_remove_misc("cell_misc", "stats", output);
+ outfd = Rast_open_old(output, G_mapset());
+ if (info->data_type == CELL_TYPE) {
+ int r;
+ struct Range range;
+ CELL *rbuf = Rast_allocate_buf(CELL_TYPE);
+ G_remove_misc("cell_misc", "range", output);
+ Rast_init_range(&range);
+ for (r = 0; r < cellhd->rows; r++) {
+ Rast_get_row(outfd, rbuf, r, CELL_TYPE);
+ Rast_row_update_range(rbuf, cellhd->cols, &range);
+ Rast_write_range(output, &range);
+ G_free(rbuf);
+ else {
+ int r;
+ struct FPRange fprange;
+ void *rbuf = Rast_allocate_buf(info->data_type);
+ G_remove_misc("cell_misc", "f_range", output);
+ Rast_init_fp_range(&fprange);
+ Rast_get_row(outfd, rbuf, r, info->data_type);
+ Rast_row_update_fp_range(rbuf, cellhd->cols, &fprange, info->data_type);
+ Rast_write_fp_range(output, &fprange);
+ G_free(rbuf);
+ Rast_unopen(outfd);
+ G_message(_("Link to raster map <%s> created."), output);
Modified: grass/trunk/raster/r.external/proto.h
--- grass/trunk/raster/r.external/proto.h 2018-06-14 17:55:34 UTC (rev 72830)
+++ grass/trunk/raster/r.external/proto.h 2018-06-14 20:27:04 UTC (rev 72831)
@@ -11,7 +11,6 @@
GDALDataType gdal_type;
int has_null;
double null_val;
- double range[2];
struct Colors colors;
