[GRASS-SVN] r72863 - grass/trunk/scripts/r.drain
Thu Jun 21 07:39:25 PDT 2018
Author: hcho
Date: 2018-06-21 07:39:25 -0700 (Thu, 21 Jun 2018)
New Revision: 72863
   grass/trunk/scripts/r.drain/r.drain.py
r.drain: Add a rule to avoid an exception from r.path
Modified: grass/trunk/scripts/r.drain/r.drain.py
--- grass/trunk/scripts/r.drain/r.drain.py	2018-06-20 14:52:45 UTC (rev 72862)
+++ grass/trunk/scripts/r.drain/r.drain.py	2018-06-21 14:39:25 UTC (rev 72863)
@@ -104,6 +104,9 @@
 #% description: The input raster map is a cost surface (direction surface must also be specified)
 #% guisection: Cost surface
 #%end
+#%rules
+#% required: start_coordinates, start_points
+#%end
 import os
 import sys
