[GRASS-SVN] r72865 - grass/trunk/scripts/v.rast.stats
Thu Jun 21 09:50:09 PDT 2018
Author: mlennert
Date: 2018-06-21 09:50:09 -0700 (Thu, 21 Jun 2018)
New Revision: 72865
   grass/trunk/scripts/v.rast.stats/v.rast.stats.py
v.rast.stats: check for existence of attribute table before launching v.to.rast
Modified: grass/trunk/scripts/v.rast.stats/v.rast.stats.py
--- grass/trunk/scripts/v.rast.stats/v.rast.stats.py	2018-06-21 16:01:17 UTC (rev 72864)
+++ grass/trunk/scripts/v.rast.stats/v.rast.stats.py	2018-06-21 16:50:09 UTC (rev 72865)
@@ -119,6 +119,15 @@
     if vect_mapset != mapset or not grass.find_file(vector, 'vector', mapset)['file']:
         grass.fatal(_("Vector map <%s> not found in current mapset") % vector)
+    # check if DBF driver used, in this case cut to 10 chars col names:
+    try:
+        fi = grass.vector_db(map=vector)[int(layer)]
+    except KeyError:
+        grass.fatal(
+            _('There is no table connected to this map. Run v.db.connect or v.db.addtable first.'))
+    # we need this for non-DBF driver:
+    dbfdriver = fi['driver'] == 'dbf'
     vector = vs[0]
     rastertmp = "%s_%s" % (vector, tmpname)
@@ -159,15 +168,6 @@
     if number < 1:
         grass.fatal(_("No categories found in raster map"))
-    # check if DBF driver used, in this case cut to 10 chars col names:
-    try:
-        fi = grass.vector_db(map=vector)[int(layer)]
-    except KeyError:
-        grass.fatal(
-            _('There is no table connected to this map. Run v.db.connect or v.db.addtable first.'))
-    # we need this for non-DBF driver:
-    dbfdriver = fi['driver'] == 'dbf'
     # Find out which table is linked to the vector map on the given layer
     if not fi['table']:
         grass.fatal(
