[GRASS-SVN] r72867 - grass-addons/grass7/raster/r.spread.sod
Thu Jun 21 13:09:01 PDT 2018
Author: wenzeslaus
Date: 2018-06-21 13:09:01 -0700 (Thu, 21 Jun 2018)
New Revision: 72867
Added:
   grass-addons/grass7/raster/r.spread.sod/raster.h
Removed:
   grass-addons/grass7/raster/r.spread.sod/Img.cpp
   grass-addons/grass7/raster/r.spread.sod/Img.h
   grass-addons/grass7/raster/r.spread.sod/CHANGELOG.md
   grass-addons/grass7/raster/r.spread.sod/Spore.cpp
   grass-addons/grass7/raster/r.spread.sod/Spore.h
   grass-addons/grass7/raster/r.spread.sod/date.h
   grass-addons/grass7/raster/r.spread.sod/main.cpp
r.spread.sod: add critical temperature
Now using branch lanternfly from upstream
(https://github.com/ncsu-landscape-dynamics/SOD-modeling-cpp).
This also significantly improves the raster (image) handling class
which is now a more general template class.
Modified: grass-addons/grass7/raster/r.spread.sod/CHANGELOG.md
--- grass-addons/grass7/raster/r.spread.sod/CHANGELOG.md	2018-06-21 19:49:23 UTC (rev 72866)
+++ grass-addons/grass7/raster/r.spread.sod/CHANGELOG.md	2018-06-21 20:09:01 UTC (rev 72867)
@@ -4,10 +4,50 @@
 The format is based on [Keep a Changelog](http://keepachangelog.com/).
-## 2018-03-26 - mortality update
+## 2018-06-21 - Critical Temperature
 ### Added
+- Time-series of temperature raster maps specified as a text file.
+- Temperature rasters are used at a specified month to check against
+  a provided critical temperature and if the condition is met,
+  infected trees become susceptible again.
+### Changed
+- Img was replaced by a generalized Raster template class which can
+  handle both integers and floating point numbers. (Vaclav Petras)
+## 2018-06-13 - Spotted Lanternfly
+### Added
+- The date class now supports also month increments. (Vaclav Petras)
+- A new step option allows user to choose between weekly and monthly
+  increments in simulation. (Vaclav Petras)
+- A custom season can now be selected by the user. (Vaclav Petras)
+- A new test executable for the date class added and available in an
+  alternative Makefile. (Vaclav Petras)
+### Changed
+- The season option is no longer yes or no but a range of months.
+  (Vaclav Petras)
+### Fixed
+- Avoid segmentation fault by using the weather coefficients only when
+  available. (Vaclav Petras)
+- Make the NetCDF time-series input option always present regardless
+  compilation settings which avoids use of uninitialized variable later
+  (and thus undefined behavior). Modules now produces error with
+  explanation when option is used but it was compiled without NetCDF
+  support. (Vaclav Petras)
+## 2018-06-04 - Mortality Addition
+### Added
 - Mortality (Vaclav Petras)
  - Enabled by a flag, mandatory mortality rate, optional start time
  - Optional output series of accumulated dead tree counts per cell
@@ -15,7 +55,7 @@
   and a provided value (Vaclav Petras)
 - Multiply for image class is commutative (Vaclav Petras)
-## 2018-03-26 - March 2018 update
+## 2018-03-26 - March 2018 Update
 ### Changed
@@ -25,7 +65,7 @@
  - Explicitly include necessary standard C++ headers
  - Add formalities: basic documentation and a proper GRASS module name
-## 2017-09-05 - September 2017 update
+## 2017-09-05 - September 2017 Update
 ### Added
@@ -52,7 +92,7 @@
 - Interface now checks if only one way of providing weather coefficients
   was used. (Vaclav Petras)
-## 2017-01-28 - January 2017 status
+## 2017-01-28 - January 2017 Status
 ### Added
Deleted: grass-addons/grass7/raster/r.spread.sod/Img.cpp
--- grass-addons/grass7/raster/r.spread.sod/Img.cpp	2018-06-21 19:49:23 UTC (rev 72866)
+++ grass-addons/grass7/raster/r.spread.sod/Img.cpp	2018-06-21 20:09:01 UTC (rev 72867)
@@ -1,413 +0,0 @@
- * SOD model - raster manipulation
- * Copyright (C) 2015-2017 by the authors.
- * Authors: Zexi Chen (zchen22 ncsu edu)
- *          Vaclav Petras (wenzeslaus gmail com)
- * The code contained herein is licensed under the GNU General Public
- * License. You may obtain a copy of the GNU General Public License
- * Version 2 or later at the following locations:
- * http://www.opensource.org/licenses/gpl-license.html
- * http://www.gnu.org/copyleft/gpl.html
-// define to support NetCDF format directly
-// (requires linking to netcdf_c++)
-// #define SOD_GDAL_SUPPORT
-#include "Img.h"
-extern "C" {
-#include <grass/gis.h>
-#include <grass/glocale.h>
-#include <grass/raster.h>
-#ifdef SOD_GDAL_SUPPORT
-#include <gdal/gdal.h>
-#include <gdal/gdal_priv.h>
-#endif
-#include <algorithm>
-#include <stdexcept>
-using std::string;
-using std::cerr;
-using std::endl;
-/* Iterate over two ranges and apply a binary function which modifies
- * the first parameter.
-template<class InputIt1, class InputIt2, class BinaryOperation>
-BinaryOperation for_each_zip(InputIt1 first1, InputIt1 last1, InputIt2 first2, BinaryOperation f) {
-    for (; first1 != last1; ++first1, ++first2) {
-        f(*first1, *first2);
-    return f;
-Img::Img()
-    width = 0;
-    height = 0;
-    w_e_res = 0;
-    n_s_res = 0;
-    data = NULL;
-Img::Img(const Img& other)
-    width = other.width;
-    height = other.height;
-    w_e_res = other.w_e_res;
-    n_s_res = other.n_s_res;
-    data = new int[width * height];
-    std::copy(other.data, other.data + (width * height), data);
-Img::Img(const Img& other, int value)
-    data = new int[width * height]{value};
-Img::Img(Img&& other)
-    data = other.data;
-    other.data = nullptr;
-Img::Img(int width, int height, int w_e_res, int n_s_res)
-    this->width = width;
-    this->height = height;
-    this->w_e_res = w_e_res;
-    this->n_s_res = n_s_res;
-    this->data = new int[width * height];
-Img::Img(int width, int height, int w_e_res, int n_s_res, int value)
-    this->data = new int[width * height]{value};
-Img::Img(const char *fileName)
-    GDALDataset *dataset;
-    GDALRasterBand *dataBand;
-    GDALAllRegister();
-    dataset = (GDALDataset *) GDALOpen(fileName, GA_ReadOnly);
-    double adfGeoTransform[6];
-    if (!dataset) {
-        cerr << "Can not open the image!" << endl;
-    else {
-        width = dataset->GetRasterXSize();
-        height = dataset->GetRasterYSize();
-        if (dataset->GetGeoTransform(adfGeoTransform) == CE_None) {
-            w_e_res = abs(adfGeoTransform[1]);
-            n_s_res = abs(adfGeoTransform[5]);
-        //cout << width << "x" << height <<endl;
-        //cout << w_e_res << "X" << n_s_res << endl;
-        dataBand = dataset->GetRasterBand(1);
-        CPLErr error = dataBand->RasterIO(GF_Read, 0, 0, width, height,
-                                          data, width, height,
-                                          GDT_Int32, 0, 0);
-        if (error == CE_Failure)
-            throw std::runtime_error(string("Reading raster failed"
-                                            " in GDAL RasterIO: ")
-                                     + CPLGetLastErrorMsg());
-        GDALClose((GDALDatasetH) dataset);
-#else
-    throw std::runtime_error("GDAL support not available");
-#endif
-// TODO: add move constuctor
-Img Img::fromGrassRaster(const char *name)
-    int fd = Rast_open_old(name, "");
-    Img img;
-    img.width = Rast_window_cols();
-    img.height = Rast_window_rows();
-    Cell_head region;
-    Rast_get_window(&region);
-    img.w_e_res = region.ew_res;
-    img.n_s_res = region.ns_res;
-    img.data = new int[img.height * img.width];
-    for (int row = 0; row < img.height; row++) {
-        Rast_get_c_row(fd, img.data + (row * img.width), row);
-    Rast_close(fd);
-    return img;
-   const int ** Img::getData(){
-   return this->data;
-Img& Img::operator=(const Img& other)
-    if (this != &other)
-        if (data)
-            delete[] data;
-    return *this;
-Img& Img::operator=(Img&& other)
-        if (data)
-            delete[] data;
-    return *this;
-Img Img::operator+(const Img& image) const
-    if (this->width != image.getWidth() || this->height != image.getHeight()) {
-        cerr << "The height or width of one image do not match with that of the other one!" << endl;
-        return Img();
-    else {
-        auto re_width = this->width;
-        auto re_height = this->height;
-        auto out = Img(re_width, re_height, this->w_e_res, this->n_s_res);
-        for (int i = 0; i < re_height; i++) {
-            for (int j = 0; j < re_width; j++) {
-                out.data[i * width + j] = this->data[i * width + j] + image.data[i * width + j];
-        return out;
-Img Img::operator-(const Img& image) const
-        return Img();
-    else {
-                out.data[i * width + j] = this->data[i * width + j] - image.data[i * width + j];
-        return out;
-Img Img::operator*(const Img& image) const
-    if (width != image.getWidth() || height != image.getHeight()) {
-        throw std::runtime_error("The height or width of one image do"
-                                 " not match with that of the other one.");
-    auto out = Img(width, height, w_e_res, n_s_res);
-    std::transform(data, data + (width * height), image.data, out.data,
-                   [](const int& a, const int& b) { return a * b; });
-    return out;
-Img Img::operator/(const Img& image) const
-                   [](const int& a, const int& b) { return a / b; });
-    return out;
-Img Img::operator*(double value) const
-    std::transform(data, data + (width * height), out.data,
-                   [&value](const int& a) { return a * value; });
-    return out;
-Img Img::operator/(double value) const
-                   [&value](const int& a) { return a / value; });
-    return out;
-Img& Img::operator+=(int value)
-    std::for_each(data, data + (width * height),
-                  [&value](int& a) { a += value; });
-    return *this;
-Img& Img::operator-=(int value)
-                  [&value](int& a) { a -= value; });
-    return *this;
-Img& Img::operator*=(double value)
-                  [&value](int& a) { a *= value; });
-    return *this;
-Img& Img::operator/=(double value)
-                  [&value](int& a) { a /= value; });
-    return *this;
-Img& Img::operator+=(const Img& image)
-    for_each_zip(data, data + (width * height), image.data,
-                 [](int& a, int& b) { a += b; });
-    return *this;
-Img& Img::operator-=(const Img& image)
-                 [](int& a, int& b) { a -= b; });
-    return *this;
-Img& Img::operator*=(const Img& image)
-                 [](int& a, int& b) { a *= b; });
-    return *this;
-Img& Img::operator/=(const Img& image)
-                 [](int& a, int& b) { a /= b; });
-    return *this;
-Img operator*(double factor, const Img& image)
-    return image * factor;
-Img::~Img()
-    if (data) {
-        delete[] data;
-void Img::toGrassRaster(const char *name)
-    int fd = Rast_open_new(name, CELL_TYPE);
-    for (int i = 0; i < height; i++)
-        Rast_put_c_row(fd, data + (i * width));
-    Rast_close(fd);
-// ref_name file is used to retrieve transformation and projection
-// information from the known (input) file
-void Img::toGdal(const char *name, const char *ref_name)
-    const char *format = "GTiff";
-    // obtain information for output Geotiff images
-    GDALDataset *inputDataset = (GDALDataset *) GDALOpen(ref_name,
-                                                         GA_ReadOnly);
-    double inputAdfGeoTransform[6];
-    inputDataset->GetGeoTransform(inputAdfGeoTransform);
-    // setup driver
-    GDALDriver *gdalDriver = GetGDALDriverManager()->GetDriverByName(format);
-    // set output Dataset and create output geotiff
-    char **papszOptions = NULL;
-    GDALDataset *outDataset = gdalDriver->Create(name, width, height, 1,
-                                                 GDT_Byte, papszOptions);
-    outDataset->SetGeoTransform(inputAdfGeoTransform);
-    outDataset->SetProjection(inputDataset->GetProjectionRef());
-    GDALRasterBand *outBand = outDataset->GetRasterBand(1);
-    CPLErr error = outBand->RasterIO(GF_Write, 0, 0, width, height,
-                                     GDT_Int32, 0, 0);
-        throw std::runtime_error(string("Writing raster failed"
-    GDALClose((GDALDatasetH) outDataset);
-    GDALClose((GDALDatasetH) inputDataset);
-    CSLDestroy(papszOptions);
-#else
-#endif
Deleted: grass-addons/grass7/raster/r.spread.sod/Img.h
--- grass-addons/grass7/raster/r.spread.sod/Img.h	2018-06-21 19:49:23 UTC (rev 72866)
+++ grass-addons/grass7/raster/r.spread.sod/Img.h	2018-06-21 20:09:01 UTC (rev 72867)
@@ -1,127 +0,0 @@
-#ifndef IMG_H
-#define IMG_H
-#include <iostream>
-#include <string>
-#include <cmath>
-#include <stdlib.h>
-enum Direction
-    N = 0, NE = 45, E = 90, SE = 135, S = 180, SW = 225, W = 270, NW = 315, NONE  // NO means that there is no wind
-class Img
-private:
-    int width;
-    int height;
-    // the west-east resolution of the pixel
-    int w_e_res;
-    // the north-south resolution of the pixel
-    int n_s_res;
-    int *data;
-public:
-    Img();
-    Img(Img&& other);
-    Img(const Img& other);
-    // Use dimensions of an existing object, but supply a new value
-    Img(const Img& other, int value);
-    //Img(int width,int height);
-    Img(const char *fileName);
-    Img(int width, int height, int w_e_res, int n_s_res);
-    Img(int width, int height, int w_e_res, int n_s_res, int value);
-    Img& operator=(Img&& other);
-    Img& operator=(const Img& other);
-    int getWidth() const
-        return width;
-    int getHeight() const
-        return height;
-    int getWEResolution() const
-        return w_e_res;
-    int getNSResolution() const
-        return n_s_res;
-    void fill(int value)
-        std::fill(data, data + (width * height), value);
-    void zero()
-        std::fill(data, data + (width * height), 0);
-    template<class UnaryOperation>
-    void for_each(UnaryOperation op)
-        std::for_each(data, data + (width * height), op);
-    const int& operator()(unsigned row, unsigned col) const
-        return data[row * width + col];
-    int& operator()(unsigned row, unsigned col)
-    Img operator+(const Img& image) const;
-    Img operator-(const Img& image) const;
-    Img operator*(const Img& image) const;
-    Img operator/(const Img& image) const;
-    Img operator*(double value) const;
-    Img operator/(double value) const;
-    Img& operator+=(int value);
-    Img& operator-=(int value);
-    Img& operator*=(double value);
-    Img& operator/=(double value);
-    Img& operator+=(const Img& image);
-    Img& operator-=(const Img& image);
-    Img& operator*=(const Img& image);
-    Img& operator/=(const Img& image);
-    friend Img operator*(double factor, const Img& image);
-    ~Img();
-    void toGrassRaster(const char *name);
-    void toGdal(const char *name, const char *ref_name);
-    static Img fromGrassRaster(const char *name);
-#endif
Modified: grass-addons/grass7/raster/r.spread.sod/Spore.cpp
--- grass-addons/grass7/raster/r.spread.sod/Spore.cpp	2018-06-21 19:49:23 UTC (rev 72866)
+++ grass-addons/grass7/raster/r.spread.sod/Spore.cpp	2018-06-21 20:09:01 UTC (rev 72867)
@@ -95,6 +95,19 @@
     generator.seed(random_seed);
+void Sporulation::SporeRemove(Img& I, Img& S, const DImg temperature,
+                              double critical_temperature)
+    for (int i = 0; i < height; i++) {
+        for (int j = 0; j < width; j++) {
+            if (temperature(i, j) < critical_temperature) {
+                S(i, j) += I(i, j);  // move back to suseptable pool
+                I(i, j) = 0;  // remove all infection
 void Sporulation::SporeGen(const Img& I, const double *weather,
                            double weather_value, double rate)
Modified: grass-addons/grass7/raster/r.spread.sod/Spore.h
--- grass-addons/grass7/raster/r.spread.sod/Spore.h	2018-06-21 19:49:23 UTC (rev 72866)
+++ grass-addons/grass7/raster/r.spread.sod/Spore.h	2018-06-21 20:09:01 UTC (rev 72867)
@@ -19,7 +19,7 @@
 #ifndef SPORE_H
 #define SPORE_H
-#include "Img.h"
+#include "raster.h"
 #include <random>
@@ -29,6 +29,12 @@
     CAUCHY, CAUCHY_MIX          // NO means that there is no wind
+// NONE means that there is no wind
+enum Direction
+    N = 0, NE = 45, E = 90, SE = 135, S = 180, SW = 225, W = 270, NW = 315, NONE
 class Sporulation
 private:
@@ -42,6 +48,8 @@
     std::default_random_engine generator;
 public:
     Sporulation(unsigned random_seed, const Img &size);
+    void SporeRemove(Img& I, Img &S, const DImg temperature,
+                     double critical_temperature);
     void SporeGen(const Img& I, const double *weather,
                   double weather_value, double rate);
     void SporeSpreadDisp_singleSpecies(Img& S, Img& I, Img& I2,
Modified: grass-addons/grass7/raster/r.spread.sod/date.h
--- grass-addons/grass7/raster/r.spread.sod/date.h	2018-06-21 19:49:23 UTC (rev 72866)
+++ grass-addons/grass7/raster/r.spread.sod/date.h	2018-06-21 20:09:01 UTC (rev 72867)
@@ -35,10 +35,12 @@
     Date(const Date &d): year(d.year), month(d.month), day(d.day){}
     Date(int y, int m, int d): year(y), month(m), day(d){}
     Date(): year(2000), month(1), day(1){}
-    void increasedByWeek();
-    Date getYearEnd();
-    Date getNextYearEnd();
-    bool isYearEnd();
+    inline void increasedByWeek();
+    inline void increasedByMonth();
+    inline Date getYearEnd();
+    inline Date getNextYearEnd();
+    inline bool isYearEnd();
+    inline bool isLastMonthOfYear();
     int getMonth() const {return month;}
     int getYear() const { return year;}
     int getDay() const {return day;}
@@ -45,12 +47,12 @@
     void setMonth(int m){month = m;}
     void setYear(int y){year = y;}
     void setDay(int d){day = d;}
-    int weeksFromDate(Date start);
-    friend std::ostream& operator<<(std::ostream& os, const Date &d);
-    friend bool operator> (const Date &d1, const Date &d2);
-    friend bool operator>= (const Date &d1, const Date &d2);
-    friend bool operator< (const Date &d1, const Date &d2);
-    friend bool operator<= (const Date &d1, const Date &d2);
+    inline int weeksFromDate(Date start);
+    inline friend std::ostream& operator<<(std::ostream& os, const Date &d);
+    inline friend bool operator> (const Date &d1, const Date &d2);
+    inline friend bool operator>= (const Date &d1, const Date &d2);
+    inline friend bool operator< (const Date &d1, const Date &d2);
+    inline friend bool operator<= (const Date &d1, const Date &d2);
@@ -69,6 +71,12 @@
     return false;
+bool Date::isLastMonthOfYear(){
+    if (month == 12)
+        return true;
+    return false;
 Date Date::getNextYearEnd(){
     if (month == 1)
         return Date(year, 12, 31);
@@ -151,6 +159,25 @@
+void Date::increasedByMonth()
+    month += 1;
+    if (month > 12) {
+        year++;
+        month = 1;
+    if (year % 4 == 0 && (year % 100 != 0 || year % 400 == 0)) {
+        if (day > day_in_month[1][month]) {
+            day = day_in_month[1][month];
+    else {
+        if (day > day_in_month[0][month]) {
+            day = day_in_month[0][month];
 int Date::weeksFromDate(Date start) {
     int week = 0;
Modified: grass-addons/grass7/raster/r.spread.sod/main.cpp
--- grass-addons/grass7/raster/r.spread.sod/main.cpp	2018-06-21 19:49:23 UTC (rev 72866)
+++ grass-addons/grass7/raster/r.spread.sod/main.cpp	2018-06-21 20:09:01 UTC (rev 72867)
@@ -21,7 +21,7 @@
 // #define SOD_NETCDF_SUPPORT
 #include "date.h"
-#include "Img.h"
 #include "Spore.h"
 extern "C" {
@@ -135,15 +135,11 @@
                                     " value '" + text +"' provided");
-bool seasonality_from_string(const string& text)
+typedef std::pair<int, int> Season;
+inline Season seasonality_from_option(const Option* opt)
-    if (text == "yes")
-        return true;
-    else if (text == "no")
-        return false;
-    else
-        throw std::invalid_argument("seasonality_from_string: Invalid"
-                                    " value '" + text +"' provided");
+    return {std::atoi(opt->answers[0]), std::atoi(opt->answers[1])};
 void read_names(std::vector<string>& names, const char* filename)
@@ -242,7 +238,10 @@
     struct Option *species, *lvtree, *infected, *outside_spores;
     struct Option *nc_weather, *moisture_file, *temperature_file, *weather_value, *weather_file;
+    struct Option *lethal_temperature_value, *lethal_temperature_months;
+    struct Option *actual_temperature_file;
     struct Option *start_time, *end_time, *seasonality;
+    struct Option *step;
     struct Option *spore_rate, *wind;
     struct Option *radial_type, *scale_1, *scale_2, *kappa, *gamma;
     struct Option *infected_to_dead_rate, *first_year_to_die;
@@ -343,13 +342,11 @@
     opt.wind->required = YES;
     opt.wind->guisection = _("Weather");
-#ifdef SOD_NETCDF_SUPPORT
     opt.nc_weather = G_define_standard_option(G_OPT_F_BIN_INPUT);
     opt.nc_weather->key = "ncdf_weather";
     opt.nc_weather->description = _("Weather data");
     opt.nc_weather->required = NO;
     opt.nc_weather->guisection = _("Weather");
-#endif
     opt.moisture_file = G_define_standard_option(G_OPT_F_INPUT);
     opt.moisture_file->key = "moisture_file";
@@ -387,6 +384,40 @@
     opt.weather_value->required = NO;
     opt.weather_value->guisection = _("Weather");
+    opt.lethal_temperature_value = G_define_option();
+    opt.lethal_temperature_value->type = TYPE_DOUBLE;
+    opt.lethal_temperature_value->key = "lethal_temperature";
+    opt.lethal_temperature_value->label =
+        _("Temperature when the pest or patogen dies");
+    opt.lethal_temperature_value->description =
+        _("The temerature unit must be the same as for the"
+          "temerature raster map (typically degrees of Celsius)");
+    opt.lethal_temperature_value->required = NO;
+    opt.lethal_temperature_value->multiple = NO;
+    opt.lethal_temperature_value->guisection = _("Weather");
+    opt.lethal_temperature_months = G_define_option();
+    opt.lethal_temperature_months->type = TYPE_INTEGER;
+    opt.lethal_temperature_months->key = "lethal_month";
+    opt.lethal_temperature_months->label =
+        _("Month when the pest or patogen dies due to low temperature");
+    opt.lethal_temperature_months->description =
+    // TODO: implement this as multiple
+    opt.lethal_temperature_months->required = NO;
+    opt.lethal_temperature_months->guisection = _("Weather");
+    // TODO: rename coefs in interface and improve their descs
+    opt.actual_temperature_file = G_define_standard_option(G_OPT_F_INPUT);
+    opt.actual_temperature_file->key = "actual_temperature_file";
+    opt.actual_temperature_file->label =
+        _("Input file with one temperature raster map name per line");
+    opt.actual_temperature_file->description =
+        _("The temperature should be in actual temperature units (typically degrees of Celsius)");
+    opt.actual_temperature_file->required = NO;
+    opt.actual_temperature_file->guisection = _("Weather");
     opt.start_time = G_define_option();
     opt.start_time->type = TYPE_INTEGER;
     opt.start_time->key = "start_time";
@@ -406,12 +437,27 @@
     opt.seasonality = G_define_option();
     opt.seasonality->type = TYPE_STRING;
     opt.seasonality->key = "seasonality";
-    opt.seasonality->label = _("Seasonal spread");
-    opt.seasonality->description = _("Spread limited to certain months (season)");
-    opt.seasonality->options = "yes,no";
-    opt.seasonality->answer = "yes";
+    opt.seasonality->label = _("Seasonal spread (from,to)");
+    opt.seasonality->description =
+            _("Spread limited to certain months (season), for example"
+              " 5,9 for spread starting at the beginning of May and"
+              " ending at the end of September");
+    opt.seasonality->key_desc = "from,to";
+    //opt.seasonality->options = "1-12";
+    opt.seasonality->answer = "1,12";
+    opt.seasonality->multiple = NO;
     opt.seasonality->guisection = _("Time");
+    opt.step = G_define_option();
+    opt.step->type = TYPE_STRING;
+    opt.step->key = "step";
+    opt.step->label = _("Step of simulation");
+    opt.step->description = _("How often the simulation computes new step");
+    opt.step->options = "week,month";
+    opt.step->descriptions = _("week;Compute next simulation step each week;month;Compute next simulation step each month");
+    opt.step->required = YES;
+    opt.step->guisection = _("Time");
     opt.spore_rate = G_define_option();
     opt.spore_rate->type = TYPE_DOUBLE;
     opt.spore_rate->key = "spore_rate";
@@ -558,6 +604,13 @@
     if (G_parser(argc, argv))
         exit(EXIT_FAILURE);
+#ifndef SOD_NETCDF_SUPPORT
+    if (opt.nc_weather->answer) {
+        G_fatal_error(_("Direct NetCDF support is not available in this"
+                        " installation, import the data instead"));
+#endif
     unsigned num_runs = 1;
     if (opt.runs->answer)
         num_runs = std::stoul(opt.runs->answer);
@@ -572,7 +625,7 @@
     file_exists_or_fatal_error(opt.weather_file);
     // Seasonality: Do you want the spread to be limited to certain months?
-    bool ss = seasonality_from_string(opt.seasonality->answer);
+    Season season = seasonality_from_option(opt.seasonality);
     Direction pwdir = direction_enum_from_string(opt.wind->answer);
@@ -604,11 +657,14 @@
         cerr << "Start date must precede the end date!!!" << endl;
         exit(EXIT_FAILURE);
     Date dd_start(start_time, 01, 01);
     Date dd_end(end_time, 12, 31);
     // difference in years (in dates) but including both years
     auto num_years = dd_end.getYear() - dd_start.getYear() + 1;
+    string step = opt.step->answer;
     // mortality
     bool mortality = false;
     unsigned first_year_to_die = 1;  // starts at 1 (same as the opt)
@@ -716,6 +772,24 @@
 #endif
+    double use_lethal_temperature = false;
+    double lethal_temperature_value;
+    int lethal_temperature_month = 0;  // invalid value for month
+    std::vector<string> actual_temperature_names;
+    std::vector<DImg> actual_temperatures;
+    if (opt.lethal_temperature_value->answer)
+        lethal_temperature_value = std::stod(opt.lethal_temperature_value->answer);
+    if (opt.lethal_temperature_months->answer)
+        lethal_temperature_month = std::stod(opt.lethal_temperature_months->answer);
+    if (opt.actual_temperature_file->answer) {
+        file_exists_or_fatal_error(opt.actual_temperature_file);
+        read_names(actual_temperature_names, opt.actual_temperature_file->answer);
+        for (string name : actual_temperature_names) {
+            actual_temperatures.push_back(DImg::fromGrassRaster(name.c_str()));
+        use_lethal_temperature = true;
     const unsigned max_weeks_in_year = 53;
     double *mcf = nullptr;
     double *ccf = nullptr;
@@ -754,11 +828,30 @@
     Date dd_current(dd_start);
     // main simulation loop (weekly steps)
-    for (int current_week = 0; ; current_week++, dd_current.increasedByWeek()) {
+    for (int current_week = 0; ; current_week++, step == "month" ? dd_current.increasedByMonth() : dd_current.increasedByWeek()) {
         if (dd_current < dd_end)
-            if (!ss || !(dd_current.getMonth() > 9))
+            if (season.first >= dd_current.getMonth() && dd_current.getMonth() <= season.second)
                 unresolved_weeks.push_back(current_week);
+        // removal is out of sync with the actual runs but it does
+        // not matter as long as removal happends out of season
+        if (use_lethal_temperature
+                && dd_current.getMonth() == lethal_temperature_month
+                && (dd_current.getYear() <= dd_end.getYear())) {
+            // to avoid problem with Jan 1 of the following year
+            // we explicitely check if we are in a valid year range
+            unsigned simulation_year = dd_current.getYear() - dd_start.getYear();
+            if (simulation_year >= actual_temperatures.size())
+                G_fatal_error(_("Not enough temperatures"));
+            #pragma omp parallel for num_threads(threads)
+            for (unsigned run = 0; run < num_runs; run++) {
+                sporulations[run].SporeRemove(inf_species_rasts[run],
+                                              sus_species_rasts[run],
+                                              actual_temperatures[simulation_year],
+                                              lethal_temperature_value);
         // if all the oaks are infected, then exit
         if (all_infected(S_species_rast)) {
             cerr << "In the " << dd_current << " all suspectible oaks are infected!" << endl;
@@ -766,7 +859,7 @@
         // check whether the spore occurs in the month
-        if (dd_current.isYearEnd() || dd_current >= dd_end) {
+        if ((step == "month" ? dd_current.isLastMonthOfYear() : dd_current.isYearEnd()) || dd_current >= dd_end) {
             if (!unresolved_weeks.empty()) {
                 unsigned week_in_chunk = 0;
@@ -797,7 +890,10 @@
                     // actual runs of the simulation per week
                     for (auto week : unresolved_weeks) {
-                        double *week_weather = weather + week_in_chunk * width * height;
+                        double *week_weather = 0;
+                        if (weather) {
+                            week_weather = weather + week_in_chunk * width * height;
                         if (!weather_coeff && !weather_values.empty()) {
                             weather_value = weather_values[week];
Added: grass-addons/grass7/raster/r.spread.sod/raster.h
--- grass-addons/grass7/raster/r.spread.sod/raster.h	                        (rev 0)
+++ grass-addons/grass7/raster/r.spread.sod/raster.h	2018-06-21 20:09:01 UTC (rev 72867)
@@ -0,0 +1,433 @@
+#ifndef RASTER_H
+#define RASTER_H
+ * SOD model - raster manipulation
+ * Copyright (C) 2015-2018 by the authors.
+ * Authors: Vaclav Petras <wenzeslaus gmail com>
+ *          Completely rewritten by Vaclav Petras based on
+ *          version by Zexi Chen <zchen22 ncsu edu>.
+ * The code contained herein is licensed under the GNU General Public
+ * License. You may obtain a copy of the GNU General Public License
+ * Version 2 or later at the following locations:
+ * http://www.opensource.org/licenses/gpl-license.html
+ * http://www.gnu.org/copyleft/gpl.html
+#include <iostream>
+#include <string>
+#include <cmath>
+#include <algorithm>
+#include <stdlib.h>
+extern "C" {
+#include <grass/gis.h>
+#include <grass/glocale.h>
+#include <grass/raster.h>
+#include <stdexcept>
+using std::string;
+using std::cerr;
+using std::endl;
+/* Iterate over two ranges and apply a binary function which modifies
+ * the first parameter.
+template<class InputIt1, class InputIt2, class BinaryOperation>
+BinaryOperation for_each_zip(InputIt1 first1, InputIt1 last1, InputIt2 first2, BinaryOperation f) {
+    for (; first1 != last1; ++first1, ++first2) {
+        f(*first1, *first2);
+    return f;
+template<typename Number>
+class Raster
+private:
+    unsigned width;
+    unsigned height;
+    // the west-east resolution of the pixel
+    double w_e_res;
+    // the north-south resolution of the pixel
+    double n_s_res;
+    Number *data;
+public:
+    Raster()
+        width = 0;
+        height = 0;
+        w_e_res = 0;
+        n_s_res = 0;
+        data = NULL;
+    Raster(const Raster& other)
+        width = other.width;
+        height = other.height;
+        w_e_res = other.w_e_res;
+        n_s_res = other.n_s_res;
+        data = new Number[width * height];
+        std::copy(other.data, other.data + (width * height), data);
+    Raster(const Raster& other, Number value)
+        data = new Number[width * height]{value};
+    Raster(Raster&& other)
+        data = other.data;
+        other.data = nullptr;
+    Raster(int width, int height, int w_e_res, int n_s_res)
+        this->width = width;
+        this->height = height;
+        this->w_e_res = w_e_res;
+        this->n_s_res = n_s_res;
+        this->data = new Number[width * height];
+    // TODO: res are doubles
+    // TODO: size is unsigned?
+    Raster(int width, int height, int w_e_res, int n_s_res, int value)
+        this->data = new Number[width * height]{value};
+    int getWidth() const
+        return width;
+    int getHeight() const
+        return height;
+    int getWEResolution() const
+        return w_e_res;
+    int getNSResolution() const
+        return n_s_res;
+    void fill(Number value)
+        std::fill(data, data + (width * height), value);
+    void zero()
+        std::fill(data, data + (width * height), 0);
+    template<class UnaryOperation>
+    void for_each(UnaryOperation op)
+        std::for_each(data, data + (width * height), op);
+    const Number& operator()(unsigned row, unsigned col) const
+        return data[row * width + col];
+    Number& operator()(unsigned row, unsigned col)
+    Raster& operator=(const Raster& other)
+        if (this != &other)
+            if (data)
+                delete[] data;
+        return *this;
+    Raster& operator=(Raster&& other)
+            if (data)
+                delete[] data;
+        return *this;
+    Raster operator+(const Raster& image) const
+        if (this->width != image.getWidth() || this->height != image.getHeight()) {
+            cerr << "The height or width of one image do not match with that of the other one!" << endl;
+            return Raster();
+        else {
+            auto re_width = this->width;
+            auto re_height = this->height;
+            auto out = Raster(re_width, re_height, this->w_e_res, this->n_s_res);
+            for (int i = 0; i < re_height; i++) {
+                for (int j = 0; j < re_width; j++) {
+                    out.data[i * width + j] = this->data[i * width + j] + image.data[i * width + j];
+            return out;
+    Raster operator-(const Raster& image) const
+            return Raster();
+        else {
+                    out.data[i * width + j] = this->data[i * width + j] - image.data[i * width + j];
+            return out;
+    Raster operator*(const Raster& image) const
+        if (width != image.getWidth() || height != image.getHeight()) {
+            throw std::runtime_error("The height or width of one image do"
+                                     " not match with that of the other one.");
+        auto out = Raster(width, height, w_e_res, n_s_res);
+        std::transform(data, data + (width * height), image.data, out.data,
+                       [](const Number& a, const Number& b) { return a * b; });
+        return out;
+    Raster operator/(const Raster& image) const
+                       [](const Number& a, const Number& b) { return a / b; });
+        return out;
+    Raster operator*(double value) const
+        std::transform(data, data + (width * height), out.data,
+                       [&value](const Number& a) { return a * value; });
+        return out;
+    Raster operator/(double value) const
+                       [&value](const Number& a) { return a / value; });
+        return out;
+    Raster& operator+=(Number value)
+                      [&value](Number& a) { a += value; });
+        return *this;
+    Raster& operator-=(Number value)
+                      [&value](Number& a) { a -= value; });
+        return *this;
+    Raster& operator*=(double value)
+                      [&value](Number& a) { a *= value; });
+        return *this;
+    Raster& operator/=(double value)
+                      [&value](Number& a) { a /= value; });
+        return *this;
+    Raster& operator+=(const Raster& image)
+        for_each_zip(data, data + (width * height), image.data,
+                     [](Number& a, Number& b) { a += b; });
+        return *this;
+    Raster& operator-=(const Raster& image)
+                     [](Number& a, Number& b) { a -= b; });
+        return *this;
+    Raster& operator*=(const Raster& image)
+                     [](Number& a, Number& b) { a *= b; });
+        return *this;
+    Raster& operator/=(const Raster& image)
+                     [](Number& a, Number& b) { a /= b; });
+        return *this;
+    friend inline Raster operator*(double factor, const Raster& image)
+        return image * factor;
+    friend inline Raster pow(Raster image, double value) {
+        image.for_each([value](Number& a){a = std::pow(a, value);});
+        return image;
+    friend inline Raster sqrt(Raster image) {
+        image.for_each([](Number& a){a = std::sqrt(a);});
+        return image;
+    ~Raster()
+        if (data) {
+            delete[] data;
+    static inline Raster fromGrassRaster(const char *name)
+        int fd = Rast_open_old(name, "");
+        Raster img;
+        img.width = Rast_window_cols();
+        img.height = Rast_window_rows();
+        Cell_head region;
+        Rast_get_window(&region);
+        img.w_e_res = region.ew_res;
+        img.n_s_res = region.ns_res;
+        img.data = new Number[img.height * img.width];
+        for (int row = 0; row < img.height; row++) {
+            Rast_get_d_row(fd, img.data + (row * img.width), row);
+        Rast_close(fd);
+        return img;
+    void inline toGrassRaster(const char *name)
+        int fd = Rast_open_new(name, DCELL_TYPE);
+            Rast_put_d_row(fd, data + (i * width));
+        Rast_close(fd);
+template <>
+inline Raster<int> Raster<int>::fromGrassRaster(const char *name)
+    Raster img;
+    Cell_head region;
+    img.data = new int[img.height * img.width];
+        Rast_get_c_row(fd, img.data + (row * img.width), row);
+    Rast_close(fd);
+    return img;
+template <>
+inline void Raster<int>::toGrassRaster(const char *name)
+    int fd = Rast_open_new(name, CELL_TYPE);
+        Rast_put_c_row(fd, data + (i * width));
+    Rast_close(fd);
+// convenient definitions, names for backwards compatibility
+typedef Raster<int> Img;
+typedef Raster<double> DImg;
+#endif
