[GRASS-SVN] r72869 - grass/branches/releasebranch_7_4/vector/v.to.db
Thu Jun 21 13:57:47 PDT 2018
Author: mmetz
Date: 2018-06-21 13:57:47 -0700 (Thu, 21 Jun 2018)
New Revision: 72869
   grass/branches/releasebranch_7_4/vector/v.to.db/areas.c
   grass/branches/releasebranch_7_4/vector/v.to.db/report.c
   grass/branches/releasebranch_7_4/vector/v.to.db/units.c
   grass/branches/releasebranch_7_4/vector/v.to.db/update.c
v.to.db: fix compactness and fractal dimension (fixes #3102, backport trunk r72866,8)
Modified: grass/branches/releasebranch_7_4/vector/v.to.db/areas.c
--- grass/branches/releasebranch_7_4/vector/v.to.db/areas.c	2018-06-21 20:55:25 UTC (rev 72868)
+++ grass/branches/releasebranch_7_4/vector/v.to.db/areas.c	2018-06-21 20:57:47 UTC (rev 72869)
@@ -59,11 +59,9 @@
 			Values[idx].d1 += perimeter;
 			break;
 		    case O_COMPACT:
-			Values[idx].d1 =
-			    perimeter / (2.0 * sqrt(M_PI * area));
-			break;
 		    case O_FD:
-			Values[idx].d1 = 2.0 * log(perimeter) / log(area);
+			Values[idx].d1 += area;
+			Values[idx].d2 += perimeter;
 			break;
 		    case O_BBOX:
 			if (Values[idx].d1 < Bbox.N)
@@ -90,11 +88,9 @@
 		    break;
 		case O_COMPACT:
-		    Values[idx].d1 =
-		    break;
 		case O_FD:
 		    break;
 	        case O_BBOX:
Modified: grass/branches/releasebranch_7_4/vector/v.to.db/report.c
--- grass/branches/releasebranch_7_4/vector/v.to.db/report.c	2018-06-21 20:55:25 UTC (rev 72868)
+++ grass/branches/releasebranch_7_4/vector/v.to.db/report.c	2018-06-21 20:57:47 UTC (rev 72869)
@@ -1,3 +1,4 @@
+#include <math.h>
 #include <grass/dbmi.h>
 #include <grass/glocale.h>
 #include "global.h"
@@ -57,17 +58,29 @@
 	break;
     case O_COMPACT:
+	/* perimeter / (2.0 * sqrt(M_PI * area)) */
 	if (G_verbose() > G_verbose_min())
 	    fprintf(stdout, "cat%scompact\n", options.fs);
-	for (i = 0; i < vstat.rcat; i++)
+	for (i = 0; i < vstat.rcat; i++) {
+	    Values[i].d1 = Values[i].d2 / (2.0 * sqrt(M_PI * Values[i].d1));
 	    fprintf(stdout, "%d%s%.15g\n", Values[i].cat, options.fs, Values[i].d1);
 	break;
     case O_FD:
+	/* 2.0 * log(perimeter) / log(area)
+	 * avoid division by zero:
+	 * 2.0 * log(1 + perimeter) / log(1 + area)
+	 * more in line with compactness:
+	 * 2.0 * log(perimeter / (2.0 * sqrt(M_PI)) / log(area) */
 	    fprintf(stdout, "cat%sfd\n", options.fs);
+	    if (Values[i].d1 == 1) /* log(1) == 0 */
+		Values[i].d1 += 0.000001;
+	    Values[i].d1 = 2.0 * log(Values[i].d2 / (2.0 * sqrt(M_PI))) / log(Values[i].d1);
 	break;
     case O_PERIMETER:
Modified: grass/branches/releasebranch_7_4/vector/v.to.db/units.c
--- grass/branches/releasebranch_7_4/vector/v.to.db/units.c	2018-06-21 20:55:25 UTC (rev 72868)
+++ grass/branches/releasebranch_7_4/vector/v.to.db/units.c	2018-06-21 20:57:47 UTC (rev 72869)
@@ -23,6 +23,13 @@
 	    Values[i].d1 *= sq_f;
 	break;
+    case O_COMPACT:
+    case O_FD:
+	    Values[i].d1 *= sq_f;
+	    Values[i].d2 *= f;
+	break;
     case O_AZIMUTH:
 	    if (rad == 0) {
Modified: grass/branches/releasebranch_7_4/vector/v.to.db/update.c
--- grass/branches/releasebranch_7_4/vector/v.to.db/update.c	2018-06-21 20:55:25 UTC (rev 72868)
+++ grass/branches/releasebranch_7_4/vector/v.to.db/update.c	2018-06-21 20:57:47 UTC (rev 72869)
@@ -1,5 +1,6 @@
 #include <stdio.h>
 #include <stdlib.h>
+#include <math.h>
 #include "global.h"
@@ -11,7 +12,7 @@
     int i, *catexst, *cex, upd, fcat;
     char buf1[2000], buf2[2000], left[20], right[20];
     struct field_info *qFi, *Fi;
-    dbString stmt;
+    dbString stmt, strval;
     dbDriver *driver;
     vstat.dupl = 0;
@@ -21,6 +22,7 @@
     vstat.error = 0;
     db_init_string(&stmt);
+    db_init_string(&strval);
     /* layer to find table to read from */
     qFi = Vect_get_field(Map, options.qfield);
@@ -100,8 +102,6 @@
 	case O_LENGTH:
 	case O_AREA:
-	case O_COMPACT:
-	case O_FD:
 	case O_PERIMETER:
 	case O_SLOPE:
 	case O_SINUOUS:
@@ -118,6 +118,26 @@
 	       	Values[i].d4, Fi->key, Values[i].cat);
 	    break;
+	case O_COMPACT:
+	    sprintf(buf2, "%s %f where %s = %d", buf1, Values[i].d1, Fi->key,
+		    Values[i].cat);
+	    break;
+	case O_FD:
+		    Values[i].cat);
+	    break;
 	case O_COOR:
 	case O_START:
 	case O_END:
@@ -196,8 +216,10 @@
 		    break;
 		case (DB_C_TYPE_STRING):
+		    db_set_string(&strval, Values[i].str1);
+		    db_double_quote_string(&strval);
 		    sprintf(buf2, "%s '%s' where %s = %d", buf1,
-			    Values[i].str1, Fi->key, Values[i].cat);
+			    db_get_string(&strval), Fi->key, Values[i].cat);
 		    break;
 		case (DB_C_TYPE_DATETIME):
@@ -248,6 +270,8 @@
 		    vstat.update++;
 		else {
+		    G_warning(_("Cannot update table: %s"),
+				db_get_string(&stmt));
 		    vstat.error++;
