[GRASS-SVN] r72886 - grass/trunk/raster/r.random
Sat Jun 23 01:55:37 PDT 2018
Author: mmetz
Date: 2018-06-23 01:55:37 -0700 (Sat, 23 Jun 2018)
New Revision: 72886
Removed:
   grass/trunk/raster/r.random/creat_rand.c
   grass/trunk/raster/r.random/local_proto.h
   grass/trunk/raster/r.random/main.c
   grass/trunk/raster/r.random/random.c
r.random: add seed option to set the seed of the RNG (fixes #3594)
Deleted: grass/trunk/raster/r.random/creat_rand.c
--- grass/trunk/raster/r.random/creat_rand.c	2018-06-22 21:39:11 UTC (rev 72885)
+++ grass/trunk/raster/r.random/creat_rand.c	2018-06-23 08:55:37 UTC (rev 72886)
@@ -1,14 +0,0 @@
-#include <grass/gis.h>
-long make_rand(void)
-    return G_lrand48();
-void init_rand(void)
-    /* FIXME - allow seed to be specified for repeatability */
-    G_srand48_auto();
Modified: grass/trunk/raster/r.random/local_proto.h
--- grass/trunk/raster/r.random/local_proto.h	2018-06-22 21:39:11 UTC (rev 72885)
+++ grass/trunk/raster/r.random/local_proto.h	2018-06-23 08:55:37 UTC (rev 72886)
@@ -44,12 +44,6 @@
 /* count.c */
 void get_stats(struct rr_state *);
-/* creat_rand.c */
-long make_rand(void);
-void init_rand(void);
 /* random.c */
 int execute_random(struct rr_state *);
Modified: grass/trunk/raster/r.random/main.c
--- grass/trunk/raster/r.random/main.c	2018-06-22 21:39:11 UTC (rev 72885)
+++ grass/trunk/raster/r.random/main.c	2018-06-23 08:55:37 UTC (rev 72886)
@@ -34,11 +34,12 @@
     gcell_count targets;
     gcell_count count;
     struct rr_state myState;
+    long seed_value;
     struct GModule *module;
     struct
-	struct Option *input, *cover, *raster, *sites, *npoints;
+	struct Option *input, *cover, *raster, *sites, *npoints, *seed;
     } parm;
     struct
@@ -81,6 +82,12 @@
     parm.sites->required = NO;
     parm.sites->key = "vector";
+    parm.seed = G_define_option();
+    parm.seed->key = "seed";
+    parm.seed->type = TYPE_INTEGER;
+    parm.seed->required = NO;
+    parm.seed->description = _("Seed for rand() function");
     flag.zero = G_define_flag();
     flag.zero->key = 'z';
     flag.zero->description = _("Generate points also for NULL category");
@@ -194,6 +201,16 @@
 	myState.nRand = targets;
+    if (parm.seed->answer) {
+        seed_value = atol(parm.seed->answer);
+        G_srand48(seed_value);
+        G_debug(3, "Read random seed from seed=: %ld", seed_value);
+    else {
+        seed_value = G_srand48_auto();
+        G_debug(3, "Generated random seed (-s): %ld", seed_value);
     execute_random(&myState);
     if (myState.outraster)
Modified: grass/trunk/raster/r.random/random.c
--- grass/trunk/raster/r.random/random.c	2018-06-22 21:39:11 UTC (rev 72885)
+++ grass/trunk/raster/r.random/random.c	2018-06-23 08:55:37 UTC (rev 72886)
@@ -116,7 +116,6 @@
     G_percent(0, theState->nRand, 2);
-    init_rand();
     nc = (theState->use_nulls) ? theState->nCells :
 	theState->nCells - theState->nNulls;
     nt = theState->nRand;	/* Number of points to generate */
@@ -141,7 +140,7 @@
 		    do_check = 0;
-	    if (do_check && make_rand() % nc < nt) {
+	    if (do_check && G_lrand48() % nc < nt) {
 		nt--;
 		if (is_null_value(theState->buf, col))
 		    cpvalue(&theState->nulls, 0, &theState->buf, col);
