[GRASS-SVN] r72890 - grass-addons/grass7/raster/r.accumulate
svn_grass at osgeo.org
Sat Jun 23 10:30:47 PDT 2018
Author: hcho
Date: 2018-06-23 10:30:47 -0700 (Sat, 23 Jun 2018)
New Revision: 72890
grass-addons/grass7/raster/r.accumulate/accumulate.c
grass-addons/grass7/raster/r.accumulate/global.h
grass-addons/grass7/raster/r.accumulate/main.c
grass-addons/grass7/raster/r.accumulate/raster.c
r.accumulate: Run grass_indent.sh
Modified: grass-addons/grass7/raster/r.accumulate/accumulate.c
--- grass-addons/grass7/raster/r.accumulate/accumulate.c 2018-06-23 17:26:36 UTC (rev 72889)
+++ grass-addons/grass7/raster/r.accumulate/accumulate.c 2018-06-23 17:30:47 UTC (rev 72890)
@@ -13,12 +13,12 @@
double
accumulate(CELL ** dir_buf, RASTER_MAP weight_buf, RASTER_MAP acc_buf,
- char **done, char neg, int row, int col)
+ char **done, char neg, int row, int col)
static int dir_checks[3][3][2] = {
- {{SE, NW}, {S, N}, {SW, NE}},
- {{E, W}, {0, 0}, {W, E}},
- {{NE, SW}, {N, S}, {NW, SE}}
+ {{SE, NW}, {S, N}, {SW, NE}},
+ {{E, W}, {0, 0}, {W, E}},
+ {{NE, SW}, {N, S}, {NW, SE}}
int rows = weight_buf.rows, cols = weight_buf.cols;
int i, j;
@@ -26,34 +26,34 @@
double acc;
if (done[row][col])
- return fabs(get(acc_buf, row, col));
+ return fabs(get(acc_buf, row, col));
if (weight_buf.map.v)
- acc = get(weight_buf, row, col);
+ acc = get(weight_buf, row, col);
else
- acc = 1.0;
+ acc = 1.0;
for (i = -1; i <= 1; i++) {
- if (row + i < 0 || row + i >= rows) {
- incomplete = 1;
- continue;
- for (j = -1; j <= 1; j++) {
- if (i == 0 && j == 0)
- continue;
- if (col + j < 0 || col + j >= cols) {
- incomplete = 1;
- continue;
- if (dir_buf[row + i][col + j] == dir_checks[i + 1][j + 1][0] &&
- dir_buf[row][col] != dir_checks[i + 1][j + 1][1]) {
- acc +=
- accumulate(dir_buf, weight_buf, acc_buf, done, neg,
- row + i, col + j);
- if (done[row + i][col + j] == 2)
- incomplete = 1;
+ if (row + i < 0 || row + i >= rows) {
+ incomplete = 1;
+ continue;
+ for (j = -1; j <= 1; j++) {
+ if (i == 0 && j == 0)
+ continue;
+ if (col + j < 0 || col + j >= cols) {
+ incomplete = 1;
+ continue;
+ if (dir_buf[row + i][col + j] == dir_checks[i + 1][j + 1][0] &&
+ dir_buf[row][col] != dir_checks[i + 1][j + 1][1]) {
+ acc +=
+ accumulate(dir_buf, weight_buf, acc_buf, done, neg,
+ row + i, col + j);
+ if (done[row + i][col + j] == 2)
+ incomplete = 1;
set(acc_buf, row, col, neg && incomplete ? -acc : acc);
Modified: grass-addons/grass7/raster/r.accumulate/global.h
--- grass-addons/grass7/raster/r.accumulate/global.h 2018-06-23 17:26:36 UTC (rev 72889)
+++ grass-addons/grass7/raster/r.accumulate/global.h 2018-06-23 17:30:47 UTC (rev 72890)
@@ -6,10 +6,10 @@
int rows, cols;
union
- void **v;
- CELL **c;
- FCELL **f;
- DCELL **d;
+ void **v;
+ CELL **c;
+ FCELL **f;
+ DCELL **d;
} map;
} RASTER_MAP;
Modified: grass-addons/grass7/raster/r.accumulate/main.c
--- grass-addons/grass7/raster/r.accumulate/main.c 2018-06-23 17:26:36 UTC (rev 72889)
+++ grass-addons/grass7/raster/r.accumulate/main.c 2018-06-23 17:30:47 UTC (rev 72890)
@@ -32,11 +32,11 @@
struct GModule *module;
struct
- struct Option *dir, *format, *weight, *acc;
+ struct Option *dir, *format, *weight, *acc;
} opt;
struct
- struct Flag *neg;
+ struct Flag *neg;
} flag;
char *desc;
char *dir_name, *weight_name, *acc_name;
@@ -57,7 +57,7 @@
G_add_keyword(_("raster"));
G_add_keyword(_("hydrology"));
module->description =
- _("Calculates weighted flow accumulation using a flow direction map.");
+ _("Calculates weighted flow accumulation using a flow direction map.");
opt.dir = G_define_standard_option(G_OPT_R_INPUT);
opt.dir->description = _("Name of input direction map");
@@ -70,9 +70,9 @@
opt.format->options = "auto,degree,45degree";
opt.format->answer = "auto";
G_asprintf(&desc, "auto;%s;degree;%s;45degree;%s",
- _("auto-detect direction format"),
- _("degrees CCW from East"),
- _("degrees CCW from East divided by 45 (e.g. r.watershed directions)"));
+ _("auto-detect direction format"),
+ _("degrees CCW from East"),
+ _("degrees CCW from East divided by 45 (e.g. r.watershed directions)"));
opt.format->descriptions = desc;
opt.weight = G_define_standard_option(G_OPT_R_INPUT);
@@ -83,17 +83,17 @@
opt.acc = G_define_standard_option(G_OPT_R_OUTPUT);
opt.acc->type = TYPE_STRING;
opt.acc->description =
- _("Name for output weighted flow accumulation map");
+ _("Name for output weighted flow accumulation map");
flag.neg = G_define_flag();
flag.neg->key = 'n';
flag.neg->label =
- _("Use negative flow accumulation for likely underestimates");
+ _("Use negative flow accumulation for likely underestimates");
G_option_exclusive(opt.weight, flag.neg, NULL);
if (G_parser(argc, argv))
- exit(EXIT_FAILURE);
+ exit(EXIT_FAILURE);
dir_name = opt.dir->answer;
weight_name = opt.weight->answer;
@@ -101,51 +101,51 @@
dir_fd = Rast_open_old(dir_name, "");
if (Rast_get_map_type(dir_fd) != CELL_TYPE)
- G_fatal_error(_("Invalid directions map <%s>"), dir_name);
+ G_fatal_error(_("Invalid directions map <%s>"), dir_name);
/* adapted from r.path */
if (Rast_read_range(dir_name, "", &dir_range) < 0)
- G_fatal_error(_("Unable to read range file"));
+ G_fatal_error(_("Unable to read range file"));
Rast_get_range_min_max(&dir_range, &dir_min, &dir_max);
if (dir_max <= 0)
dir_format = DIR_UNKNOWN;
if (strcmp(opt.format->answer, "degree") == 0) {
- if (dir_max > 360)
- G_fatal_error(_("Directional degrees can not be > 360"));
- dir_format = DIR_DEG;
+ if (dir_max > 360)
+ G_fatal_error(_("Directional degrees can not be > 360"));
+ dir_format = DIR_DEG;
else if (strcmp(opt.format->answer, "45degree") == 0) {
- if (dir_max > 8)
- G_fatal_error(_("Directional degrees divided by 45 can not be > 8"));
- dir_format = DIR_DEG45;
+ if (dir_max > 8)
+ G_fatal_error(_("Directional degrees divided by 45 can not be > 8"));
+ dir_format = DIR_DEG45;
else if (strcmp(opt.format->answer, "auto") == 0) {
- if (dir_max <= 8) {
- G_important_message(_("Input direction format assumed to be degrees CCW from East divided by 45"));
- else if (dir_max <= 360) {
- G_important_message(_("Input direction format assumed to be degrees CCW from East"));
- else
- G_fatal_error(_("Unable to detect format of input direction map <%s>"),
- dir_name);
+ if (dir_max <= 8) {
+ G_important_message(_("Input direction format assumed to be degrees CCW from East divided by 45"));
+ else if (dir_max <= 360) {
+ G_important_message(_("Input direction format assumed to be degrees CCW from East"));
+ else
+ G_fatal_error(_("Unable to detect format of input direction map <%s>"),
+ dir_name);
if (dir_format == DIR_UNKNOWN)
- G_fatal_error(_("Invalid directions format '%s'"),
- opt.format->answer);
+ G_fatal_error(_("Invalid directions format '%s'"),
+ opt.format->answer);
/* end of r.path */
if (weight_name) {
- weight_fd = Rast_open_old(weight_name, "");
- weight_buf.type = Rast_get_map_type(weight_fd);
+ weight_fd = Rast_open_old(weight_name, "");
+ weight_buf.type = Rast_get_map_type(weight_fd);
else {
- weight_fd = -1;
- weight_buf.type = CELL_TYPE;
+ weight_fd = -1;
+ weight_buf.type = CELL_TYPE;
acc_buf.type = weight_buf.type;
@@ -159,64 +159,64 @@
done = G_malloc(rows * sizeof(char *));
dir_buf = G_malloc(rows * sizeof(CELL *));
for (row = 0; row < rows; row++) {
- done[row] = G_calloc(cols, 1);
- dir_buf[row] = Rast_allocate_c_buf();
- Rast_get_c_row(dir_fd, dir_buf[row], row);
- if (dir_format == DIR_DEG45) {
- for (col = 0; col < cols; col++)
- dir_buf[row][col] *= 45;
+ done[row] = G_calloc(cols, 1);
+ dir_buf[row] = Rast_allocate_c_buf();
+ Rast_get_c_row(dir_fd, dir_buf[row], row);
+ if (dir_format == DIR_DEG45) {
+ for (col = 0; col < cols; col++)
+ dir_buf[row][col] *= 45;
if (weight_fd >= 0) {
- weight_buf.map.v = (void **)G_malloc(rows * sizeof(void *));
- for (row = 0; row < rows; row++) {
- weight_buf.map.v[row] =
- (void *)Rast_allocate_buf(weight_buf.type);
- Rast_get_row(weight_fd, weight_buf.map.v[row], row,
- weight_buf.type);
+ weight_buf.map.v = (void **)G_malloc(rows * sizeof(void *));
+ for (row = 0; row < rows; row++) {
+ weight_buf.map.v[row] =
+ (void *)Rast_allocate_buf(weight_buf.type);
+ Rast_get_row(weight_fd, weight_buf.map.v[row], row,
+ weight_buf.type);
else
- weight_buf.map.v = NULL;
+ weight_buf.map.v = NULL;
weight_buf.rows = rows;
weight_buf.cols = cols;
acc_buf.map.v = (void **)G_malloc(rows * sizeof(void *));
- acc_buf.map.v[row] = (void *)Rast_allocate_buf(acc_buf.type);
+ acc_buf.map.v[row] = (void *)Rast_allocate_buf(acc_buf.type);
acc_buf.rows = rows;
acc_buf.cols = cols;
- accumulate(dir_buf, weight_buf, acc_buf, done, neg, row, col);
+ accumulate(dir_buf, weight_buf, acc_buf, done, neg, row, col);
- Rast_put_row(acc_fd, acc_buf.map.v[row], acc_buf.type);
+ Rast_put_row(acc_fd, acc_buf.map.v[row], acc_buf.type);
G_free(done);
- G_free(dir_buf[row]);
- if (weight_fd >= 0)
- G_free(weight_buf.map.v[row]);
- G_free(acc_buf.map.v[row]);
+ G_free(dir_buf[row]);
+ if (weight_fd >= 0)
+ G_free(weight_buf.map.v[row]);
+ G_free(acc_buf.map.v[row]);
G_free(dir_buf);
if (weight_fd >= 0)
- G_free(weight_buf.map.v);
+ G_free(weight_buf.map.v);
G_free(acc_buf.map.v);
Rast_close(dir_fd);
if (weight_fd >= 0)
- Rast_close(weight_fd);
+ Rast_close(weight_fd);
Rast_close(acc_fd);
Rast_put_cell_title(acc_name,
- weight_name ? "Weighted flow accumulation" :
- (neg ? "Flow accumulation with likely underestimates"
- : "Flow accumulation"));
+ weight_name ? "Weighted flow accumulation" :
+ (neg ? "Flow accumulation with likely underestimates"
+ : "Flow accumulation"));
Rast_short_history(acc_name, "raster", &hist);
Rast_command_history(&hist);
Rast_write_history(acc_name, &hist);
Modified: grass-addons/grass7/raster/r.accumulate/raster.c
--- grass-addons/grass7/raster/r.accumulate/raster.c 2018-06-23 17:26:36 UTC (rev 72889)
+++ grass-addons/grass7/raster/r.accumulate/raster.c 2018-06-23 17:30:47 UTC (rev 72890)
@@ -5,14 +5,14 @@
switch (buf.type) {
case CELL_TYPE:
- buf.map.c[row][col] = (CELL) value;
- break;
+ buf.map.c[row][col] = (CELL) value;
+ break;
case FCELL_TYPE:
- buf.map.f[row][col] = (FCELL) value;
- break;
+ buf.map.f[row][col] = (FCELL) value;
+ break;
case DCELL_TYPE:
- buf.map.d[row][col] = (DCELL) value;
- break;
+ buf.map.d[row][col] = (DCELL) value;
+ break;
return;
@@ -24,14 +24,14 @@
switch (buf.type) {
case CELL_TYPE:
- value = (double)buf.map.c[row][col];
- break;
+ value = (double)buf.map.c[row][col];
+ break;
case FCELL_TYPE:
- value = (double)buf.map.f[row][col];
- break;
+ value = (double)buf.map.f[row][col];
+ break;
case DCELL_TYPE:
- value = buf.map.d[row][col];
- break;
+ value = buf.map.d[row][col];
+ break;
return value;
