[GRASS-SVN] r72898 - grass-addons/grass7/raster/r.accumulate
Mon Jun 25 02:19:07 PDT 2018
Author: hcho
Date: 2018-06-25 02:19:07 -0700 (Mon, 25 Jun 2018)
New Revision: 72898
   grass-addons/grass7/raster/r.accumulate/Makefile
   grass-addons/grass7/raster/r.accumulate/accumulate.c
   grass-addons/grass7/raster/r.accumulate/global.h
   grass-addons/grass7/raster/r.accumulate/main.c
   grass-addons/grass7/raster/r.accumulate/r.accumulate.html
   grass-addons/grass7/raster/r.accumulate/raster.c
r.accumulate: Implement stream delineation (stream option); Rename input/output options to direction/accumulation (multiple output options)
Modified: grass-addons/grass7/raster/r.accumulate/Makefile
--- grass-addons/grass7/raster/r.accumulate/Makefile	2018-06-24 17:17:46 UTC (rev 72897)
+++ grass-addons/grass7/raster/r.accumulate/Makefile	2018-06-25 09:19:07 UTC (rev 72898)
@@ -2,8 +2,8 @@
 PGM = r.accumulate
-LIBES = $(RASTERLIB) $(GISLIB)
-DEPENDENCIES = $(RASTERDEP) $(GISDEP)
+LIBES = $(GISLIB) $(RASTERLIB) $(VECTORLIB)
+DEPENDENCIES = $(GISDEP) $(RASTERDEP) $(VECTORDEP)
 include $(MODULE_TOPDIR)/include/Make/Module.make
Modified: grass-addons/grass7/raster/r.accumulate/accumulate.c
--- grass-addons/grass7/raster/r.accumulate/accumulate.c	2018-06-24 17:17:46 UTC (rev 72897)
+++ grass-addons/grass7/raster/r.accumulate/accumulate.c	2018-06-25 09:19:07 UTC (rev 72898)
@@ -1,44 +1,30 @@
-#include <grass/raster.h>
 #include "global.h"
-#define NW 135
-#define N 90
-#define NE 45
-#define E 360
-#define SE 315
-#define S 270
-#define SW 225
-#define W 180
-double accumulate(CELL ** dir_buf, RASTER_MAP weight_buf, RASTER_MAP acc_buf,
-                  char **done, char neg, int row, int col)
+double accumulate(struct cell_map *dir_buf, struct raster_map *weight_buf,
+                  struct raster_map *accum_buf, char **done, char neg,
+                  int row, int col)
-    static int dir_checks[3][3][2] = {
-        {{SE, NW}, {S, N}, {SW, NE}},
-        {{E, W}, {0, 0}, {W, E}},
-        {{NE, SW}, {N, S}, {NW, SE}}
-    int rows = acc_buf.rows, cols = acc_buf.cols;
+    int rows = dir_buf->rows, cols = dir_buf->cols;
     int i, j;
     char incomplete = 0;
-    double acc;
+    double accum;
     /* if the current cell has been calculated, just return its accumulation so
      * that downstream cells can simply propagate and add it to themselves */
     if (done[row][col]) {
-        acc = get(acc_buf, row, col);
+        accum = get(accum_buf, row, col);
         /* for negative accumulation, always return its absolute value;
          * otherwise return it as is */
-        return neg && acc < 0 ? -acc : acc;
+        return neg && accum < 0 ? -accum : accum;
     /* if a weight map is specified (no negative accumulation is implied), use
      * the weight value at the current cell; otherwise use 1 */
-    if (weight_buf.map.v)
-        acc = get(weight_buf, row, col);
+    if (weight_buf->map.v)
+        accum = get(weight_buf, row, col);
     else
-        acc = 1.0;
+        accum = 1.0;
     /* loop through all neighbor cells and see if any of them drains into the
      * current cell (are there upstream cells?) */
@@ -65,13 +51,13 @@
             /* if a neighbor cell drains into the current cell and the current
              * cell doesn't flow back into the same neighbor cell (no flow
              * loop), trace and recursively accumulate upstream cells */
-            if (dir_buf[row + i][col + j] == dir_checks[i + 1][j + 1][0] &&
-                dir_buf[row][col] != dir_checks[i + 1][j + 1][1]) {
+            if (dir_buf->c[row + i][col + j] == dir_checks[i + 1][j + 1][0] &&
+                dir_buf->c[row][col] != dir_checks[i + 1][j + 1][1]) {
                 /* for negative accumulation, accumulate() always returns a
-                 * positive value, so acc is always positive (cell count);
-                 * otherwise, acc is weighted accumulation */
-                acc +=
-                    accumulate(dir_buf, weight_buf, acc_buf, done, neg,
+                 * positive value, so accum is always positive (cell count);
+                 * otherwise, accum is weighted accumulation */
+                accum +=
+                    accumulate(dir_buf, weight_buf, accum_buf, done, neg,
                                row + i, col + j);
                 /* if the neighbor cell is incomplete, the current cell also
@@ -85,12 +71,12 @@
     /* if negative accumulation is desired and the current cell is incomplete,
      * use a negative cell count without weighting; otherwise use accumulation
      * as is (cell count or weighted accumulation, which can be negative) */
-    set(acc_buf, row, col, neg && incomplete ? -acc : acc);
+    set(accum_buf, row, col, neg && incomplete ? -accum : accum);
     /* the current cell is done; 1 for no likely underestimates and 2 for
      * likely underestimates */
     done[row][col] = 1 + incomplete;
-    /* for negative accumulation, acc is already positive */
-    return acc;
+    /* for negative accumulation, accum is already positive */
+    return accum;
Modified: grass-addons/grass7/raster/r.accumulate/global.h
--- grass-addons/grass7/raster/r.accumulate/global.h	2018-06-24 17:17:46 UTC (rev 72897)
+++ grass-addons/grass7/raster/r.accumulate/global.h	2018-06-25 09:19:07 UTC (rev 72898)
@@ -1,7 +1,26 @@
+#ifndef _GLOBAL_H_
+#define _GLOBAL_H_
+#include <grass/vector.h>
-typedef struct
+#define NE 1
+#define N 2
+#define NW 3
+#define W 4
+#define SW 5
+#define S 6
+#define SE 7
+#define E 8
+struct cell_map
+    int rows, cols;
+    CELL **c;
+struct raster_map
     RASTER_MAP_TYPE type;
     int rows, cols;
     union
@@ -11,11 +30,46 @@
         FCELL **f;
         DCELL **d;
     } map;
-} RASTER_MAP;
+struct point_list
+    int nalloc, n;
+    double *x, *y;
+#ifdef _MAIN_C_
+#define GLOBAL
+#else
+#define GLOBAL extern
+#endif
+GLOBAL int dir_checks[3][3][2]
+#ifdef _MAIN_C_
+    {{SE, NW}, {S, N}, {SW, NE}},
+    {{E, W}, {0, 0}, {W, E}},
+    {{NE, SW}, {N, S}, {NW, SE}}
+#endif
 /* raster.c */
-void set(RASTER_MAP, int, int, double);
-double get(RASTER_MAP, int, int);
+void set(struct raster_map *, int, int, double);
+double get(struct raster_map *, int, int);
+/* point_list.c */
+void init_point_list(struct point_list *);
+void reset_point_list(struct point_list *);
+void free_point_list(struct point_list *);
+void add_point(struct point_list *, double, double);
 /* accumulate.c */
-double accumulate(CELL **, RASTER_MAP, RASTER_MAP, char **, char, int, int);
+double accumulate(struct cell_map *, struct raster_map *, struct raster_map *,
+                  char **, char, int, int);
+/* delineate_streams.c */
+void delineate_streams(struct Map_info *, double, struct cell_map *,
+                       struct raster_map *);
+#endif
Modified: grass-addons/grass7/raster/r.accumulate/main.c
--- grass-addons/grass7/raster/r.accumulate/main.c	2018-06-24 17:17:46 UTC (rev 72897)
+++ grass-addons/grass7/raster/r.accumulate/main.c	2018-06-25 09:19:07 UTC (rev 72898)
@@ -5,8 +5,8 @@
  * AUTHOR(S):    Huidae Cho <grass4u gmail.com>
- * PURPOSE:      Calculates weighted flow accumulation using a flow direction
- *               map.
+ * PURPOSE:      Calculates weighted flow accumulation and delineates stream
+ *               networks using a flow direction map.
  * COPYRIGHT:    (C) 2018 by the GRASS Development Team
@@ -16,10 +16,13 @@
+#define _MAIN_C_
 #include <stdlib.h>
 #include <string.h>
 #include <grass/gis.h>
 #include <grass/glocale.h>
 #include "global.h"
@@ -32,7 +35,12 @@
     struct GModule *module;
     struct
-        struct Option *dir, *format, *weight, *acc;
+        struct Option *dir;
+        struct Option *format;
+        struct Option *weight;
+        struct Option *accum;
+        struct Option *thresh;
+        struct Option *stream;
     } opt;
     struct
@@ -39,17 +47,18 @@
         struct Flag *neg;
     } flag;
     char *desc;
-    char *dir_name, *weight_name, *acc_name;
-    int dir_fd, weight_fd, acc_fd;
-    double dir_format;
+    char *dir_name, *weight_name, *accum_name, *stream_name;
+    int dir_fd, weight_fd, accum_fd;
+    double dir_format, thresh;
     struct Range dir_range;
     CELL dir_min, dir_max;
     char neg;
     char **done;
-    CELL **dir_buf;
-    RASTER_MAP weight_buf, acc_buf;
+    struct cell_map dir_buf;
+    struct raster_map weight_buf, accum_buf;
     int rows, cols, row, col;
     struct History hist;
+    struct Map_info Map;
     G_gisinit(argv[0]);
@@ -57,9 +66,10 @@
     G_add_keyword(_("raster"));
     G_add_keyword(_("hydrology"));
     module->description =
-        _("Calculates weighted flow accumulation using a flow direction map.");
+        _("Calculates weighted flow accumulation and delineates stream networks using a flow direction map.");
     opt.dir = G_define_standard_option(G_OPT_R_INPUT);
+    opt.dir->key = "direction";
     opt.dir->description = _("Name of input direction map");
     opt.format = G_define_option();
@@ -80,11 +90,23 @@
     opt.weight->required = NO;
     opt.weight->description = _("Name of input flow weight map");
-    opt.acc = G_define_standard_option(G_OPT_R_OUTPUT);
-    opt.acc->type = TYPE_STRING;
-    opt.acc->description =
+    opt.accum = G_define_standard_option(G_OPT_R_OUTPUT);
+    opt.accum->key = "accumulation";
+    opt.accum->required = NO;
+    opt.accum->type = TYPE_STRING;
+    opt.accum->description =
         _("Name for output weighted flow accumulation map");
+    opt.thresh = G_define_option();
+    opt.thresh->key = "threshold";
+    opt.thresh->type = TYPE_DOUBLE;
+    opt.thresh->label = _("Minimum flow accumulation for streams");
+    opt.stream = G_define_standard_option(G_OPT_V_OUTPUT);
+    opt.stream->key = "stream";
+    opt.stream->required = NO;
+    opt.stream->description = _("Name for output stream vector map");
     flag.neg = G_define_flag();
     flag.neg->key = 'n';
     flag.neg->label =
@@ -93,6 +115,8 @@
     /* weighting doesn't support negative accumulation because weights
      * themselves can be negative */
     G_option_exclusive(opt.weight, flag.neg, NULL);
+    G_option_required(opt.accum, opt.stream, NULL);
+    G_option_collective(opt.thresh, opt.stream, NULL);
     if (G_parser(argc, argv))
         exit(EXIT_FAILURE);
@@ -99,7 +123,8 @@
     dir_name = opt.dir->answer;
     weight_name = opt.weight->answer;
-    acc_name = opt.acc->answer;
+    accum_name = opt.accum->answer;
+    stream_name = opt.stream->answer;
     dir_fd = Rast_open_old(dir_name, "");
     if (Rast_get_map_type(dir_fd) != CELL_TYPE)
@@ -141,6 +166,7 @@
                       opt.format->answer);
     /* end of r.path */
+    thresh = opt.thresh->answer ? atof(opt.thresh->answer) : 0.0;
     neg = flag.neg->answer;
     rows = Rast_window_rows();
@@ -148,21 +174,24 @@
     /* initialize the done array and read the direction map */
     done = G_malloc(rows * sizeof(char *));
-    dir_buf = G_malloc(rows * sizeof(CELL *));
+    dir_buf.rows = rows;
+    dir_buf.cols = cols;
+    dir_buf.c = G_malloc(rows * sizeof(CELL *));
     for (row = 0; row < rows; row++) {
         done[row] = G_calloc(cols, 1);
-        dir_buf[row] = Rast_allocate_c_buf();
-        Rast_get_c_row(dir_fd, dir_buf[row], row);
-        if (dir_format == DIR_DEG45) {
+        dir_buf.c[row] = Rast_allocate_c_buf();
+        Rast_get_c_row(dir_fd, dir_buf.c[row], row);
+        if (dir_format == DIR_DEG) {
             for (col = 0; col < cols; col++)
-                dir_buf[row][col] *= 45;
+                dir_buf.c[row][col] /= 45.0;
+    Rast_close(dir_fd);
     /* optionally, read a weight map */
     if (weight_name) {
         weight_fd = Rast_open_old(weight_name, "");
-        acc_buf.type = weight_buf.type = Rast_get_map_type(weight_fd);
+        accum_buf.type = weight_buf.type = Rast_get_map_type(weight_fd);
         weight_buf.rows = rows;
         weight_buf.cols = cols;
         weight_buf.map.v = (void **)G_malloc(rows * sizeof(void *));
@@ -172,61 +201,80 @@
             Rast_get_row(weight_fd, weight_buf.map.v[row], row,
                          weight_buf.type);
+        Rast_close(weight_fd);
     else {
         weight_fd = -1;
         weight_buf.map.v = NULL;
-        acc_buf.type = CELL_TYPE;
+        accum_buf.type = CELL_TYPE;
-    /* create output buffer */
-    acc_buf.rows = rows;
-    acc_buf.cols = cols;
-    acc_buf.map.v = (void **)G_malloc(rows * sizeof(void *));
+    /* create accumulation buffer */
+    accum_buf.rows = rows;
+    accum_buf.cols = cols;
+    accum_buf.map.v = (void **)G_malloc(rows * sizeof(void *));
-        acc_buf.map.v[row] = (void *)Rast_allocate_buf(acc_buf.type);
+        accum_buf.map.v[row] = (void *)Rast_allocate_buf(accum_buf.type);
-    /* create a new output map */
-    acc_fd = Rast_open_new(acc_name, acc_buf.type);
+    /* create a new accumulation map if requested */
+    accum_fd = accum_name ? Rast_open_new(accum_name, accum_buf.type) : -1;
     /* accumulate flows */
-            accumulate(dir_buf, weight_buf, acc_buf, done, neg, row, col);
+            accumulate(&dir_buf, &weight_buf, &accum_buf, done, neg, row,
+                       col);
-    /* write out output buffer to the output map */
-    for (row = 0; row < rows; row++)
-        Rast_put_row(acc_fd, acc_buf.map.v[row], acc_buf.type);
+    /* write out buffer to the accumulatoin map */
+    if (accum_fd >= 0) {
+        for (row = 0; row < rows; row++)
+            Rast_put_row(accum_fd, accum_buf.map.v[row], accum_buf.type);
+        Rast_close(accum_fd);
-    /* close all maps */
-    Rast_close(dir_fd);
-    Rast_close(acc_fd);
-    if (weight_fd >= 0)
-        Rast_close(weight_fd);
+        /* write history */
+        Rast_put_cell_title(accum_name,
+                            weight_name ? "Weighted flow accumulation" :
+                            (neg ?
+                             "Flow accumulation with likely underestimates" :
+                             "Flow accumulation"));
+        Rast_short_history(accum_name, "raster", &hist);
+        Rast_command_history(&hist);
+        Rast_write_history(accum_name, &hist);
     /* free buffer memory */
         G_free(done[row]);
-        G_free(dir_buf[row]);
-        G_free(acc_buf.map.v[row]);
         if (weight_fd >= 0)
             G_free(weight_buf.map.v[row]);
     G_free(done);
-    G_free(dir_buf);
-    G_free(acc_buf.map.v);
     if (weight_fd >= 0)
         G_free(weight_buf.map.v);
-    /* write history */
-    Rast_put_cell_title(acc_name,
-                        weight_name ? "Weighted flow accumulation" :
-                        (neg ? "Flow accumulation with likely underestimates"
-                         : "Flow accumulation"));
-    Rast_short_history(acc_name, "raster", &hist);
-    Rast_command_history(&hist);
-    Rast_write_history(acc_name, &hist);
+    /* delineate stream networks */
+    if (stream_name) {
+        if (Vect_open_new(&Map, stream_name, 0) < 0)
+            G_fatal_error(_("Unable to create vector map <%s>"), stream_name);
+        Vect_set_map_name(&Map, "Stream network");
+        Vect_hist_command(&Map);
+        delineate_streams(&Map, thresh, &dir_buf, &accum_buf);
+        if (!Vect_build(&Map))
+            G_warning(_("Unable to build topology for vector map <%s>"),
+                      stream_name);
+        Vect_close(&Map);
+    /* free buffer memory */
+    for (row = 0; row < rows; row++) {
+        G_free(dir_buf.c[row]);
+        G_free(accum_buf.map.v[row]);
+    G_free(dir_buf.c);
+    G_free(accum_buf.map.v);
     exit(EXIT_SUCCESS);
Modified: grass-addons/grass7/raster/r.accumulate/r.accumulate.html
--- grass-addons/grass7/raster/r.accumulate/r.accumulate.html	2018-06-24 17:17:46 UTC (rev 72897)
+++ grass-addons/grass7/raster/r.accumulate/r.accumulate.html	2018-06-25 09:19:07 UTC (rev 72898)
@@ -1,7 +1,7 @@
 <h2>DESCRIPTION</h2>
-<em>r.accumulate</em> calculates weighted flow accumulatin using a flow
-direction map.
+<em>r.accumulate</em> calculates weighted flow accumulatin and delineates
+stream networks using a flow direction map.
 <h2>NOTES</h2>
@@ -36,17 +36,19 @@
 These examples use the North Carolina sample dataset.
-<p>Create the SFD flow accumulation and drainage maps using
-<em>r.watershed</em>:
+<h3>Flow accumulation</h3>
+<p>Calculate flow accumulation using <em>r.watershed</em> and
+<em>r.accumulate</em>:
 <div class="code"><pre>
 # set computational region
 g.region raster=elevation -p
 # calculate positive flow accumulation and drainage directions using r.watershed
-r.watershed elevation=elevation accumulation=flow_accum drainage=drain_directions -sa
+r.watershed elevation=elevation accumulation=flow_accum drainage=drain_directions -s -a
 # calculate flow accumulation using r.accumulate
-r.accumulate input=drain_directions output=flow_accum_new
+r.accumulate direction=drain_directions accumulation=flow_accum_new
 # copy color table
 r.colors map=flow_accum_new raster=flow_accum
@@ -73,6 +75,36 @@
 (<i>flow_accum_new</i> from <em>r.accumulate</em>). The same cells are properly
 accumulated from the headwater cells.
+<h3>Stream network delineation</h3>
+<p>Calculate flow accumulation and delineate stream networks at once:
+<div class="code"><pre>
+# use r.accumulate to create flow_accum_new and streams_new at once
+r.accumulate direction=drain_directions accumulation=flow_accum_new threshold=50000 stream=streams_new
+# or delineate stream networks only without creating an accumulation map
+r.accumulate direction=drain_directions threshold=50000 stream=streams_new_only
+# use r.stream.extract, elevation, and flow_accum_new to delineate stream networks
+r.stream.extract elevation=elevation accumulation=flow_accum_new threshold=50000 stream_vector=streams direction=drain_directions_2
+</pre></div>
+<img src="r_accumulate_nc_stream_example.png">
+<p>In this example, <em>r.accumulate</em> and <em>r.stream.extract</em>
+produced slightly different stream networks where the flow turns 90 degrees or
+there are multiple downstream cells with the same elevation. The following
+figure shows an example where the <i>streams</i> (red from
+<em>r.stream.extract</em>) and <i>streams_new</i> (blue from
+<em>r.accumulate</em>) vector maps present different stream paths. The numbers
+show cell elevations (<i>elevation</i> map), and the yellow
+(<i>drain_directions</i> map) and green (<i>drain_directions_2</i> map) arrows
+represent flow directions generated by <em>r.watershed</em> with <b>-s</b> flag
+and <em>r.stream.extract</em>, respectively. Note that the two flow direction
+maps are different.
+<p><img src="r_accumulate_nc_stream_comparison.png">
 <h2>SEE ALSO</h2>
 <em>
Modified: grass-addons/grass7/raster/r.accumulate/raster.c
--- grass-addons/grass7/raster/r.accumulate/raster.c	2018-06-24 17:17:46 UTC (rev 72897)
+++ grass-addons/grass7/raster/r.accumulate/raster.c	2018-06-25 09:19:07 UTC (rev 72898)
@@ -1,17 +1,17 @@
 #include "global.h"
-void set(RASTER_MAP buf, int row, int col, double value)
+void set(struct raster_map *buf, int row, int col, double value)
-    switch (buf.type) {
+    switch (buf->type) {
     case CELL_TYPE:
-        buf.map.c[row][col] = (CELL) value;
+        buf->map.c[row][col] = (CELL) value;
         break;
     case FCELL_TYPE:
-        buf.map.f[row][col] = (FCELL) value;
+        buf->map.f[row][col] = (FCELL) value;
         break;
     case DCELL_TYPE:
-        buf.map.d[row][col] = (DCELL) value;
+        buf->map.d[row][col] = (DCELL) value;
         break;
@@ -18,19 +18,19 @@
     return;
-double get(RASTER_MAP buf, int row, int col)
+double get(struct raster_map *buf, int row, int col)
     double value = 0;
     case CELL_TYPE:
-        value = (double)buf.map.c[row][col];
+        value = (double)buf->map.c[row][col];
         break;
     case FCELL_TYPE:
-        value = (double)buf.map.f[row][col];
+        value = (double)buf->map.f[row][col];
         break;
     case DCELL_TYPE:
-        value = buf.map.d[row][col];
+        value = buf->map.d[row][col];
         break;
