[GRASS-SVN] r72900 - grass-addons/grass7/raster/r.accumulate
Mon Jun 25 02:29:45 PDT 2018
Author: hcho
Date: 2018-06-25 02:29:45 -0700 (Mon, 25 Jun 2018)
New Revision: 72900
Added:
   grass-addons/grass7/raster/r.accumulate/delineate_streams.c
   grass-addons/grass7/raster/r.accumulate/point_list.c
r.accumulate: Add missing files
Added: grass-addons/grass7/raster/r.accumulate/delineate_streams.c
--- grass-addons/grass7/raster/r.accumulate/delineate_streams.c	                        (rev 0)
+++ grass-addons/grass7/raster/r.accumulate/delineate_streams.c	2018-06-25 09:29:45 UTC (rev 72900)
@@ -0,0 +1,110 @@
+#include <grass/gis.h>
+#include <grass/vector.h>
+#include "global.h"
+static void trace_down(struct cell_map *, int, int, double, double, double,
+                       double, struct point_list *);
+void delineate_streams(struct Map_info *Map, double thresh,
+                       struct cell_map *dir_buf, struct raster_map *accum_buf)
+    struct Cell_head window;
+    double w_off, n_off, ew_res, ns_res;
+    int rows = accum_buf->rows, cols = accum_buf->cols;
+    int row, col;
+    int i, j;
+    char has_thresh_inflow;
+    struct point_list pl;
+    struct line_pnts *Points;
+    struct line_cats *Cats;
+    int stream_id = 0;
+    G_get_set_window(&window);
+    ew_res = window.ew_res;
+    ns_res = window.ns_res;
+    w_off = window.west + 0.5 * ew_res;
+    n_off = window.north - 0.5 * ns_res;
+    init_point_list(&pl);
+    Points = Vect_new_line_struct();
+    Cats = Vect_new_cats_struct();
+    /* loop through all cells to find headwater cells */
+    for (row = 0; row < rows; row++) {
+        for (col = 0; col < cols; col++) {
+            /* if the current cell is less than the threshold, skip */
+            if (get(accum_buf, row, col) < thresh)
+                continue;
+            /* the current cell is greater than the threshold; check if it is
+             * headwater (no upstream cells greater than the threshold) */
+            has_thresh_inflow = 0;
+            for (i = -1; i <= 1; i++) {
+                /* skip edge cells */
+                if (row + i < 0 || row + i >= rows)
+                    continue;
+                for (j = -1; j <= 1; j++) {
+                    /* skip the current and edge cells */
+                    if ((i == 0 && j == 0) || col + j < 0 || col + j >= cols)
+                        continue;
+                    /* if a neighbor cell flows into the current cell and has a
+                     * flow higher than the threshold, the current cell is not
+                     * headwater */
+                    if (dir_buf->c[row + i][col + j] ==
+                        dir_checks[i + 1][j + 1][0] &&
+                        get(accum_buf, row + i, col + j) >= thresh)
+                        has_thresh_inflow = 1;
+            /* if headwater is found, trace down flow directions */
+            if (!has_thresh_inflow) {
+                reset_point_list(&pl);
+                trace_down(dir_buf, row, col, w_off, n_off, ew_res, ns_res,
+                           &pl);
+                /* if tracing is successful, write out the stream */
+                if (pl.n > 0) {
+                    Vect_reset_line(Points);
+                    Vect_reset_cats(Cats);
+                    Vect_copy_xyz_to_pnts(Points, pl.x, pl.y, NULL, pl.n);
+                    Vect_cat_set(Cats, 1, ++stream_id);
+                    Vect_write_line(Map, GV_LINE, Points, Cats);
+    free_point_list(&pl);
+    Vect_destroy_line_struct(Points);
+    Vect_destroy_cats_struct(Cats);
+static void trace_down(struct cell_map *dir_buf, int row, int col,
+                       double w_off, double n_off, double ew_res,
+                       double ns_res, struct point_list *pl)
+    static int next_cells[8][2] = {
+        {-1, 1}, {-1, 0}, {-1, -1}, {0, -1}, {1, -1}, {1, 0}, {1, 1}, {0, 1}
+    int rows = dir_buf->rows, cols = dir_buf->cols;
+    int dir;
+    /* if the current cell is outside the computational region, stop tracing */
+    if (row < 0 || row >= rows || col < 0 || col >= cols)
+        return;
+    /* add the current cell */
+    add_point(pl, w_off + col * ew_res, n_off - row * ns_res);
+    /* if the current cell doesn't flow out of the computational region
+     * (negative direction from r.watershed flows out), keep tracing */
+    dir = dir_buf->c[row][col] - 1;
+    if (dir >= 0 && dir < 8)
+        trace_down(dir_buf, row + next_cells[dir][0],
+                   col + next_cells[dir][1], w_off, n_off, ew_res, ns_res,
+                   pl);
Added: grass-addons/grass7/raster/r.accumulate/point_list.c
--- grass-addons/grass7/raster/r.accumulate/point_list.c	                        (rev 0)
+++ grass-addons/grass7/raster/r.accumulate/point_list.c	2018-06-25 09:29:45 UTC (rev 72900)
@@ -0,0 +1,39 @@
+#include <grass/glocale.h>
+#define POINTS_INCREMENT 1024
+void init_point_list(struct point_list *pl)
+    pl->nalloc = pl->n = 0;
+    pl->x = pl->y = NULL;
+void reset_point_list(struct point_list *pl)
+    pl->n = 0;
+void free_point_list(struct point_list *pl)
+    if (pl->x)
+        G_free(pl->x);
+    if (pl->y)
+        G_free(pl->y);
+    init_point_list(pl);
+void add_point(struct point_list *pl, double x, double y)
+    if (pl->n == pl->nalloc) {
+        pl->nalloc += POINTS_INCREMENT;
+        pl->x = (double *)G_realloc(pl->x, pl->nalloc * sizeof(double));
+        pl->y = (double *)G_realloc(pl->y, pl->nalloc * sizeof(double));
+        if (!pl->x || !pl->y)
+            G_fatal_error(_("Unable to increase point list"));
+    pl->x[pl->n] = x;
+    pl->y[pl->n] = y;
+    pl->n++;
