[GRASS-SVN] r72919 - grass-addons/grass7/raster/r.accumulate
svn_grass at osgeo.org
Thu Jun 28 15:31:30 PDT 2018
Author: hcho
Date: 2018-06-28 15:31:30 -0700 (Thu, 28 Jun 2018)
New Revision: 72919
grass-addons/grass7/raster/r.accumulate/delineate_streams.c
grass-addons/grass7/raster/r.accumulate/global.h
grass-addons/grass7/raster/r.accumulate/main.c
grass-addons/grass7/raster/r.accumulate/r.accumulate.html
r.accumulate: Do not delineate streams across confluences by default; Add -c to do that
Modified: grass-addons/grass7/raster/r.accumulate/delineate_streams.c
--- grass-addons/grass7/raster/r.accumulate/delineate_streams.c 2018-06-28 19:10:43 UTC (rev 72918)
+++ grass-addons/grass7/raster/r.accumulate/delineate_streams.c 2018-06-28 22:31:30 UTC (rev 72919)
@@ -2,11 +2,12 @@
#include <grass/vector.h>
#include "global.h"
-static void trace_down(struct cell_map *, struct Cell_head *, int, int,
+static void trace_down(struct cell_map *, struct raster_map *accum_buf,
+ double, char, struct Cell_head *, int, int,
struct point_list *);
-void delineate_streams(struct Map_info *Map, double thresh,
- struct cell_map *dir_buf, struct raster_map *accum_buf)
+void delineate_streams(struct Map_info *Map, struct cell_map *dir_buf,
+ struct raster_map *accum_buf, double thresh, char conf)
struct Cell_head window;
int rows = accum_buf->rows, cols = accum_buf->cols;
@@ -27,7 +28,7 @@
for (row = 0; row < rows; row++) {
for (col = 0; col < cols; col++) {
int i, j;
- char has_thresh_inflow = 0;
+ int nup = 0;
/* if the current cell is less than the threshold, skip */
if (get(accum_buf, row, col) < thresh)
@@ -34,7 +35,7 @@
continue;
/* the current cell is greater than the threshold; check if it is
- * headwater (no upstream cells greater than the threshold) */
+ * a headwater (no upstream cells greater than the threshold) */
for (i = -1; i <= 1; i++) {
/* skip edge cells */
if (row + i < 0 || row + i >= rows)
@@ -47,18 +48,20 @@
/* if a neighbor cell flows into the current cell and has a
* flow higher than the threshold, the current cell is not
- * headwater */
+ * a headwater */
if (dir_buf->c[row + i][col + j] ==
dir_checks[i + 1][j + 1][0] &&
get(accum_buf, row + i, col + j) >= thresh)
- has_thresh_inflow = 1;
+ nup++;
- /* if headwater is found, trace down flow directions */
- if (!has_thresh_inflow) {
+ /* if a headwater is found or a confluence is found and requested,
+ * trace down flow directions */
+ if (!nup || (!conf && nup > 1)) {
reset_point_list(&pl);
- trace_down(dir_buf, &window, row, col, &pl);
+ trace_down(dir_buf, accum_buf, thresh, conf, &window, row,
+ col, &pl);
/* if tracing is successful, write out the stream */
if (pl.n > 0) {
@@ -79,7 +82,8 @@
Vect_destroy_cats_struct(Cats);
-static void trace_down(struct cell_map *dir_buf, struct Cell_head *window,
+static void trace_down(struct cell_map *dir_buf, struct raster_map *accum_buf,
+ double thresh, char conf, struct Cell_head *window,
int row, int col, struct point_list *pl)
static int next_cells[8][2] = {
@@ -86,6 +90,7 @@
{-1, 1}, {-1, 0}, {-1, -1}, {0, -1}, {1, -1}, {1, 0}, {1, 1}, {0, 1}
int rows = dir_buf->rows, cols = dir_buf->cols;
+ int i, j;
int dir;
/* if the current cell is outside the computational region, stop tracing */
@@ -96,10 +101,38 @@
add_point(pl, Rast_col_to_easting(col + 0.5, window),
Rast_row_to_northing(row + 0.5, window));
+ /* conf = 1 for continuous streams across a confluence;
+ * conf = 0 for split streams at a confluence */
+ if (!conf) {
+ int nup = 0;
+ for (i = -1; i <= 1; i++) {
+ /* skip edge cells */
+ if (row + i < 0 || row + i >= rows)
+ continue;
+ for (j = -1; j <= 1; j++) {
+ /* skip the current and edge cells */
+ if ((i == 0 && j == 0) || col + j < 0 || col + j >= cols)
+ continue;
+ /* if multiple neighbor cells flow into the current cell and
+ * have a flow higher than the threshold, the current cell is a
+ * confluence; stop tracing in this case only if this cell is
+ * not starting a new stream at this confluence */
+ if (dir_buf->c[row + i][col + j] ==
+ dir_checks[i + 1][j + 1][0] &&
+ get(accum_buf, row + i, col + j) >= thresh && pl->n > 1 &&
+ ++nup > 1)
+ return;
/* if the current cell doesn't flow out of the computational region
* (negative direction from r.watershed flows out), keep tracing */
dir = dir_buf->c[row][col] - 1;
if (dir >= 0 && dir < 8)
- trace_down(dir_buf, window, row + next_cells[dir][0],
- col + next_cells[dir][1], pl);
+ trace_down(dir_buf, accum_buf, thresh, conf, window,
+ row + next_cells[dir][0], col + next_cells[dir][1], pl);
Modified: grass-addons/grass7/raster/r.accumulate/global.h
--- grass-addons/grass7/raster/r.accumulate/global.h 2018-06-28 19:10:43 UTC (rev 72918)
+++ grass-addons/grass7/raster/r.accumulate/global.h 2018-06-28 22:31:30 UTC (rev 72919)
@@ -87,8 +87,8 @@
char **, char);
/* delineate_streams.c */
-void delineate_streams(struct Map_info *, double, struct cell_map *,
- struct raster_map *);
+void delineate_streams(struct Map_info *, struct cell_map *,
+ struct raster_map *, double, char);
/* calculate_lfp.c */
void calculate_lfp(struct Map_info *, struct cell_map *, struct raster_map *,
Modified: grass-addons/grass7/raster/r.accumulate/main.c
--- grass-addons/grass7/raster/r.accumulate/main.c 2018-06-28 19:10:43 UTC (rev 72918)
+++ grass-addons/grass7/raster/r.accumulate/main.c 2018-06-28 22:31:30 UTC (rev 72919)
@@ -53,14 +53,16 @@
struct
struct Flag *neg;
+ struct Flag *conf;
} flag;
char *desc;
- char *dir_name, *weight_name, *accum_name, *stream_name, *outlet_name, *lfp_name;
+ char *dir_name, *weight_name, *accum_name, *stream_name, *outlet_name,
+ *lfp_name;
int dir_fd;
double dir_format, thresh;
struct Range dir_range;
CELL dir_min, dir_max;
- char neg;
+ char neg, conf;
char **done;
struct cell_map dir_buf;
struct raster_map weight_buf, accum_buf;
@@ -158,6 +160,10 @@
flag.neg->label =
_("Use negative flow accumulation for likely underestimates");
+ flag.conf = G_define_flag();
+ flag.conf->key = 'c';
+ flag.conf->label = _("Delineate streams across confluences");
/* weighting doesn't support negative accumulation because weights
* themselves can be negative; the longest flow path requires positive
* non-weighted accumulation */
@@ -168,6 +174,7 @@
G_option_requires(opt.idcol, opt.id, opt.outlet_idcol, NULL);
G_option_requires_all(opt.id, opt.idcol, opt.coords, NULL);
G_option_requires_all(opt.outlet_idcol, opt.idcol, opt.outlet, NULL);
+ G_option_requires(flag.conf, opt.stream, NULL);
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
@@ -329,6 +336,7 @@
thresh = opt.thresh->answer ? atof(opt.thresh->answer) : 0.0;
neg = flag.neg->answer;
+ conf = flag.conf->answer;
rows = Rast_window_rows();
cols = Rast_window_cols();
@@ -417,7 +425,7 @@
Vect_set_map_name(&Map, "Stream network");
Vect_hist_command(&Map);
- delineate_streams(&Map, thresh, &dir_buf, &accum_buf);
+ delineate_streams(&Map, &dir_buf, &accum_buf, thresh, conf);
if (!Vect_build(&Map))
G_warning(_("Unable to build topology for vector map <%s>"),
Modified: grass-addons/grass7/raster/r.accumulate/r.accumulate.html
--- grass-addons/grass7/raster/r.accumulate/r.accumulate.html 2018-06-28 19:10:43 UTC (rev 72918)
+++ grass-addons/grass7/raster/r.accumulate/r.accumulate.html 2018-06-28 22:31:30 UTC (rev 72919)
@@ -38,8 +38,12 @@
With <b>stream</b> and <b>threshold</b> options, the module will delineate
stream networks with the minimum flow accumulation for stream generation. A
-<b>weight</b> input map may be used with <b>threshold</b>.
+<b>weight</b> input map may be used with <b>threshold</b>. Delineated stream
+lines are split at confluences.
+<p>With <b>-c</b> flag, stream lines are delineated across confluences and may
+overlap with other stream lines that share the same downstream outlet.
<h3>Longest flow path calculation</h3>
With <b>longest_flow_path</b> option, the module will create a longest flow
