[GRASS-SVN] r72936 - grass-addons/grass7/raster/r.accumulate
Fri Jun 29 16:12:23 PDT 2018
Author: hcho
Date: 2018-06-29 16:12:23 -0700 (Fri, 29 Jun 2018)
New Revision: 72936
   grass-addons/grass7/raster/r.accumulate/r.accumulate.html
r.accumulate: Fix a typo in the manual
Modified: grass-addons/grass7/raster/r.accumulate/r.accumulate.html
--- grass-addons/grass7/raster/r.accumulate/r.accumulate.html	2018-06-29 15:55:51 UTC (rev 72935)
+++ grass-addons/grass7/raster/r.accumulate/r.accumulate.html	2018-06-29 23:12:23 UTC (rev 72936)
@@ -188,7 +188,7 @@
     id_column=lfp_id outlet_id_column=outlet_id
 # calculate longest flow paths at given coordinates and all points in the outlets map and assign IDs
-r.accumulate direction=drain_directions lfp=lfp_multi_wi_id coordinates=642455,222614,642306,222734 outlet=outlets \
+r.accumulate direction=drain_directions lfp=lfp_multi_w_id coordinates=642455,222614,642306,222734 outlet=outlets \
     id=1,2 id_column=lfp_id outlet_id_column=outlet_id
 </pre></div>
