[GRASS-SVN] r72308 - grass/trunk/gui/wxpython/gmodeler
svn_grass at osgeo.org
Fri Mar 2 14:27:18 PST 2018
Author: martinl
Date: 2018-03-02 14:27:18 -0800 (Fri, 02 Mar 2018)
New Revision: 72308
grass/trunk/gui/wxpython/gmodeler/frame.py
grass/trunk/gui/wxpython/gmodeler/giface.py
grass/trunk/gui/wxpython/gmodeler/model.py
wxGUI/gmodeler: implement display data functionality (work in progress)
Modified: grass/trunk/gui/wxpython/gmodeler/frame.py
--- grass/trunk/gui/wxpython/gmodeler/frame.py 2018-03-02 22:22:33 UTC (rev 72307)
+++ grass/trunk/gui/wxpython/gmodeler/frame.py 2018-03-02 22:27:18 UTC (rev 72308)
@@ -11,7 +11,7 @@
- frame::ItemPanel
- frame::PythonPanel
-(C) 2010-2014 by the GRASS Development Team
+(C) 2010-2018 by the GRASS Development Team
This program is free software under the GNU General Public License
(>=v2). Read the file COPYING that comes with GRASS for details.
@@ -1467,7 +1467,7 @@
if not hasattr(self, "popupID"):
self.popupID = dict()
for key in ('remove', 'enable', 'addPoint',
- 'delPoint', 'intermediate', 'props', 'id',
+ 'delPoint', 'intermediate', 'display', 'props', 'id',
'label', 'comment'):
self.popupID[key] = wx.NewId()
@@ -1529,20 +1529,38 @@
if len(shape.GetLineControlPoints()) == 2:
popupMenu.Enable(self.popupID['delPoint'], False)
- if isinstance(shape, ModelData) and '@' not in shape.GetValue():
+ if isinstance(shape, ModelData):
popupMenu.AppendSeparator()
- popupMenu.Append(
- self.popupID['intermediate'],
- text=_('Intermediate'),
- kind=wx.ITEM_CHECK)
- if self.GetShape().IsIntermediate():
- popupMenu.Check(self.popupID['intermediate'], True)
+ if '@' not in shape.GetValue() and \
+ len(self.GetShape().GetRelations('from')) > 0:
+ popupMenu.Append(
+ self.popupID['intermediate'],
+ text=_('Intermediate'),
+ kind=wx.ITEM_CHECK)
+ if self.GetShape().IsIntermediate():
+ popupMenu.Check(self.popupID['intermediate'], True)
- self.frame.Bind(
- wx.EVT_MENU,
- self.OnIntermediate,
- id=self.popupID['intermediate'])
+ self.frame.Bind(
+ wx.EVT_MENU,
+ self.OnIntermediate,
+ id=self.popupID['intermediate'])
+ if self.frame._giface.GetMapDisplay():
+ popupMenu.Append(
+ self.popupID['display'],
+ text=_('Display'),
+ if self.GetShape().HasDisplay():
+ popupMenu.Check(self.popupID['display'], True)
+ self.frame.Bind(
+ wx.EVT_MENU,
+ self.OnHasDisplay,
+ id=self.popupID['display'])
+ popupMenu.Enable(self.popupID['display'], False)
if isinstance(shape, ModelData) or \
isinstance(shape, ModelAction) or \
isinstance(shape, ModelLoop):
@@ -1647,6 +1665,28 @@
shape.SetIntermediate(event.IsChecked())
self.frame.canvas.Refresh()
+ def OnHasDisplay(self, event):
+ """Mark data to be displayed"""
+ self.frame.ModelChanged()
+ shape = self.GetShape()
+ shape.SetHasDisplay(event.IsChecked())
+ self.frame.canvas.Refresh()
+ try:
+ if event.IsChecked():
+ # add map layer to display
+ self.frame._giface.GetLayerList().AddLayer(
+ ltype=shape.GetPrompt(), name=shape.GetValue(), checked=True,
+ cmd=shape.GetDisplayCmd())
+ else:
+ # remove map layer(s) from display
+ layers = self.frame._giface.GetLayerList().GetLayersByName(shape.GetValue())
+ for layer in layers:
+ self.frame._giface.GetLayerList().DeleteLayer(layer)
+ except GException as e:
+ GError(parent=self,
+ message='{}'.format(e))
def OnRemove(self, event):
"""Remove shape
Modified: grass/trunk/gui/wxpython/gmodeler/giface.py
--- grass/trunk/gui/wxpython/gmodeler/giface.py 2018-03-02 22:22:33 UTC (rev 72307)
+++ grass/trunk/gui/wxpython/gmodeler/giface.py 2018-03-02 22:27:18 UTC (rev 72308)
@@ -6,7 +6,7 @@
Classes:
- giface::GraphicalModelerGrassInterface
-(C) 2013-2014 by the GRASS Development Team
+(C) 2013-2018 by the GRASS Development Team
Modified: grass/trunk/gui/wxpython/gmodeler/model.py
--- grass/trunk/gui/wxpython/gmodeler/model.py 2018-03-02 22:22:33 UTC (rev 72307)
+++ grass/trunk/gui/wxpython/gmodeler/model.py 2018-03-02 22:27:18 UTC (rev 72308)
@@ -18,7 +18,7 @@
- model::WritePythonFile
- model::ModelParamDialog
-(C) 2010-2016 by the GRASS Development Team
@@ -1346,6 +1346,7 @@
self.value = value
self.prompt = prompt
self.intermediate = False
+ self.display = False
self.propWin = None
if not width:
width = UserSettings.Get(
@@ -1374,6 +1375,14 @@
"""Set intermediate flag"""
self.intermediate = im
+ def HasDisplay(self):
+ """Checks if data item is marked to be displayed"""
+ return self.display
+ def SetHasDisplay(self, tbd):
+ """Set to-be-displayed flag"""
+ self.display = tbd
def OnDraw(self, dc):
self._setPen()
@@ -1506,7 +1515,21 @@
self._setPen()
self.SetLabel()
+ def GetDisplayCmd(self):
+ """Get display command as list"""
+ cmd = []
+ if self.prompt == 'raster':
+ cmd.append('d.rast')
+ elif self.prompt == 'vector':
+ cmd.append('d.vect')
+ else:
+ raise GException("Unsupported display prompt: {}".format(
+ self.prompt))
+ cmd.append('map=' + self.value)
+ return cmd
class ModelRelation(ogl.LineShape):
"""Data - action relation"""
