[GRASS-SVN] r72329 - grass/trunk/raster/r.in.lidar
svn_grass at osgeo.org
Tue Mar 6 09:00:28 PST 2018
Author: marisn
Date: 2018-03-06 09:00:28 -0800 (Tue, 06 Mar 2018)
New Revision: 72329
grass/trunk/raster/r.in.lidar/main.c
grass/trunk/raster/r.in.lidar/r.in.lidar.html
r.in.lidar: Trim option affects only trimmean method.
Fail if user atempts to use it with other metods.
Modified: grass/trunk/raster/r.in.lidar/main.c
--- grass/trunk/raster/r.in.lidar/main.c 2018-03-06 16:24:11 UTC (rev 72328)
+++ grass/trunk/raster/r.in.lidar/main.c 2018-03-06 17:00:28 UTC (rev 72329)
@@ -362,6 +362,11 @@
set_region_flag->answer = '\0';
+ /* Trim option is used only for trimmean method */
+ if (trim_opt->answer != NULL && strcmp(method_opt->answer, "trimmean") != 0) {
+ G_fatal_error(_("Trim option can be used only with trimmean method"));
struct StringList infiles;
if (file_list_opt->answer) {
Modified: grass/trunk/raster/r.in.lidar/r.in.lidar.html
--- grass/trunk/raster/r.in.lidar/r.in.lidar.html 2018-03-06 16:24:11 UTC (rev 72328)
+++ grass/trunk/raster/r.in.lidar/r.in.lidar.html 2018-03-06 17:00:28 UTC (rev 72329)
@@ -360,6 +360,11 @@
The default map <b>type</b>=<tt>FCELL</tt> is intended as compromise between
preserving data precision and limiting system resource consumption.
+<h3>Trim option</h3>
+<p>
+Trim option value is used only when calculating trimmed mean values.
+Attempt to use it with other statistical methods will result in an error.
<h2>EXAMPLES</h2>
Simple example of binning of point from a LAS file into a newly created
