[GRASS-SVN] r72338 - grass/trunk/locale/po
svn_grass at osgeo.org
Sat Mar 10 10:27:01 PST 2018
Author: neteler
Date: 2018-03-10 10:27:01 -0800 (Sat, 10 Mar 2018)
New Revision: 72338
Added:
grass/trunk/locale/po/grasslibs_hu.po
grass/trunk/locale/po/grassmods_hu.po
grass/trunk/locale/po/grasswxpy_hu.po
i18N: added Hungarian from Transifex (https://www.transifex.com/grass-gis/grass72/dashboard/)
Added: grass/trunk/locale/po/grasslibs_hu.po
--- grass/trunk/locale/po/grasslibs_hu.po (rev 0)
+++ grass/trunk/locale/po/grasslibs_hu.po 2018-03-10 18:27:01 UTC (rev 72338)
@@ -0,0 +1,9545 @@
+# Translation of grasslibs_hu.po
+# Copyright (C) 2017 GRASS Development Team
+# This file is distributed under the same license as the GRASS GIS package.
+# transifex generated, 2017
+msgid ""
+msgstr ""
+"Project-Id-Version: grasslibs_hu\n"
+"Report-Msgid-Bugs-To: \n"
+"POT-Creation-Date: 2018-03-10 19:26+0100\n"
+"PO-Revision-Date: 2018-03-10 17:22+0100\n"
+"Last-Translator: Zoltan Siki <siki at agt.bme.hu>, 2018\n"
+"Language-Team: Hungarian (https://www.transifex.com/grass-gis/teams/45198/hu/)\n"
+"Language: hu\n"
+"MIME-Version: 1.0\n"
+"Content-Type: text/plain; charset=UTF-8\n"
+"Content-Transfer-Encoding: 8bit\n"
+"Plural-Forms: nplurals=2; plural=(n != 1);\n"
+#: ../lib/htmldriver/graph_set.c:97
+#, c-format
+msgid "html: collecting to file '%s'"
+msgstr ""
+#: ../lib/htmldriver/graph_set.c:98
+#, c-format
+msgid "html: image size %dx%d"
+msgstr ""
+#: ../lib/htmldriver/graph_set.c:111 ../lib/htmldriver/graph_set.c:115
+#: ../lib/htmldriver/graph_set.c:119
+#, c-format
+msgid "html: type '%s'"
+msgstr ""
+#: ../lib/driver/parse_ftcap.c:84
+#, c-format
+msgid "%s: Unable to read font definition file; use the default"
+msgstr ""
+#: ../lib/driver/parse_ftcap.c:90
+#, c-format
+msgid "%s: No font definition file"
+msgstr ""
+#: ../lib/manage/do_list.c:30
+#, c-format
+msgid "%s: invalid index %d"
+msgstr ""
+#: ../lib/manage/read_list.c:73
+#, c-format
+msgid "Unable to open data base element list '%s'"
+msgstr ""
+#: ../lib/manage/read_list.c:134
+#, c-format
+msgid "Format error: file ('%s') line (%d) - %s"
+msgstr ""
+#: ../lib/manage/do_remove.c:42
+#, c-format
+msgid "Removing %s <%s>"
+msgstr ""
+#: ../lib/manage/do_remove.c:57 ../lib/manage/do_rename.c:54
+#: ../lib/ogsf/gp3.c:56 ../lib/ogsf/gp3.c:191 ../lib/ogsf/gv3.c:60
+#: ../lib/ogsf/gv3.c:333 ../lib/vector/Vlib/open.c:235
+#: ../lib/vector/Vlib/map.c:263 ../lib/vector/Vlib/legal_vname.c:141
+#: ../lib/vector/Vlib/legal_vname.c:144
+#, c-format
+msgid "Vector map <%s> not found"
+msgstr ""
+#: ../lib/manage/do_remove.c:65
+msgid "Unable to delete vector map"
+msgstr ""
+#: ../lib/manage/do_remove.c:73 ../lib/manage/do_rename.c:71
+#: ../lib/raster/open.c:176 ../lib/raster/open.c:843 ../lib/raster/open.c:880
+#: ../lib/raster/open.c:932 ../lib/ogsf/gs3.c:125 ../lib/ogsf/gs3.c:189
+#: ../lib/ogsf/gs3.c:264 ../lib/ogsf/gs3.c:336 ../lib/ogsf/gs3.c:442
+#: ../lib/ogsf/gs3.c:529 ../lib/ogsf/gs3.c:588 ../lib/ogsf/gs3.c:645
+#: ../lib/ogsf/gs3.c:716 ../lib/ogsf/gs3.c:786 ../lib/ogsf/gsd_legend.c:239
+#: ../lib/rst/interp_float/resout2d.c:205
+#: ../lib/rst/interp_float/resout2d.c:253
+#: ../lib/rst/interp_float/resout2d.c:296
+#: ../lib/rst/interp_float/resout2d.c:327
+#: ../lib/rst/interp_float/resout2d.c:377
+#: ../lib/rst/interp_float/resout2d.c:395
+#: ../lib/rst/interp_float/resout2d.c:410
+#: ../lib/rst/interp_float/resout2d.c:426
+#: ../lib/rst/interp_float/output2d.c:247
+#: ../lib/rst/interp_float/output2d.c:328
+#: ../lib/rst/interp_float/output2d.c:397
+#: ../lib/rst/interp_float/output2d.c:447
+#: ../lib/rst/interp_float/output2d.c:461
+#: ../lib/rst/interp_float/output2d.c:475
+#: ../lib/rst/interp_float/output2d.c:491 ../lib/gis/legal_name.c:94
+#: ../lib/gis/legal_name.c:97
+#, c-format
+msgid "Raster map <%s> not found"
+msgstr ""
+#: ../lib/manage/do_remove.c:78 ../lib/manage/do_rename.c:76
+#: ../lib/ogsf/gvl_file.c:427 ../lib/ogsf/gvl3.c:40
+#: ../lib/gpde/n_arrays_io.c:273
+#, c-format
+msgid "3D raster map <%s> not found"
+msgstr ""
+#: ../lib/manage/do_remove.c:85
+#, c-format
+msgid "Unable to remove %s element"
+msgstr ""
+#: ../lib/manage/do_remove.c:89 ../lib/manage/do_remove.c:109
+#: ../lib/manage/do_copy.c:61 ../lib/manage/do_rename.c:87
+#: ../lib/manage/do_rename.c:107
+#, c-format
+msgid "%s is missing"
+msgstr ""
+#: ../lib/manage/do_remove.c:92 ../lib/manage/do_remove.c:112
+#, c-format
+msgid "%s removed"
+msgstr ""
+#: ../lib/manage/do_remove.c:105
+#, c-format
+msgid "Unable to remove %s"
+msgstr ""
+#: ../lib/manage/do_remove.c:121
+#, c-format
+msgid "<%s> nothing removed"
+msgstr ""
+#: ../lib/manage/do_copy.c:43
+#, c-format
+msgid "Copy %s <%s> to current mapset as <%s>"
+msgstr ""
+#: ../lib/manage/do_copy.c:50 ../lib/manage/do_copy.c:67
+#, c-format
+msgid "Unable to copy <%s> to current mapset as <%s>"
+msgstr ""
+#: ../lib/manage/do_copy.c:72
+#, c-format
+msgid "%s copied"
+msgstr ""
+#: ../lib/manage/do_rename.c:42
+#, c-format
+msgid "Rename %s <%s> to <%s>"
+msgstr ""
+#: ../lib/manage/do_rename.c:62
+#, c-format
+msgid "Unable to rename vector map <%s> to <%s>"
+msgstr ""
+#: ../lib/manage/do_rename.c:83 ../lib/manage/do_rename.c:103
+#, c-format
+msgid "Unable to rename %s"
+msgstr ""
+#: ../lib/manage/do_rename.c:90 ../lib/manage/do_rename.c:110
+#, c-format
+msgid "%s renamed"
+msgstr ""
+#: ../lib/manage/do_rename.c:119
+#, c-format
+msgid "<%s> nothing renamed"
+msgstr ""
+#: ../lib/manage/option.c:47
+#, c-format
+msgid "%s to be %s"
+msgstr ""
+#: ../lib/manage/option.c:51
+msgid "Raster"
+msgstr "Raszter"
+#: ../lib/manage/option.c:53
+msgid "Vector"
+msgstr "Vektor"
+#: ../lib/manage/option.c:55
+msgid "Region"
+msgstr "Régió"
+#: ../lib/manage/option.c:57
+msgid "Group"
+msgstr "Csoport"
+#: ../lib/temporal/lib/default_name.c:69
+msgid "Programmer error - only SQLite driver is currently supported"
+msgstr ""
+#: ../lib/temporal/lib/connect.c:110
+#, c-format
+msgid "Mapset <%s> does not exist."
+msgstr ""
+#: ../lib/rowio/setup.c:61 ../lib/rowio/setup.c:67 ../lib/segment/open.c:98
+#: ../lib/rst/interp_float/segmen2d_parallel.c:78
+#: ../lib/rst/interp_float/segmen2d_parallel.c:85
+#: ../lib/rst/interp_float/segmen2d_parallel.c:92
+#: ../lib/rst/interp_float/segmen2d_parallel.c:101
+#: ../lib/rst/interp_float/segmen2d_parallel.c:263
+#: ../lib/rst/interp_float/interp2d.c:139
+#: ../lib/rst/interp_float/interp2d.c:145
+#: ../lib/rst/interp_float/segmen2d.c:197
+#: ../lib/rst/interp_float/segmen2d.c:203
+#: ../lib/rst/interp_float/segmen2d.c:209
+#: ../lib/rst/interp_float/segmen2d.c:219
+#: ../lib/vector/diglib/struct_alloc.c:494 ../lib/vector/Vlib/line.c:50
+#: ../lib/vector/Vlib/line.c:154 ../lib/vector/Vlib/map.c:48
+#: ../lib/vector/neta/bridge.c:58 ../lib/vector/neta/spanningtree.c:101
+#: ../lib/vector/neta/path.c:262 ../lib/vector/neta/components.c:71
+#: ../lib/vector/neta/components.c:176 ../lib/vector/neta/centrality.c:63
+#: ../lib/vector/neta/centrality.c:145 ../lib/vector/neta/flow.c:66
+#: ../lib/vector/neta/flow.c:190 ../lib/vector/neta/timetables.c:69
+#: ../lib/vector/neta/timetables.c:168 ../lib/vector/neta/timetables.c:178
+#: ../lib/vector/neta/timetables.c:191 ../lib/vector/neta/timetables.c:278
+#: ../lib/vector/neta/timetables.c:413 ../lib/vector/neta/timetables.c:425
+#: ../lib/vector/neta/articulation_point.c:60
+msgid "Out of memory"
+msgstr ""
+#: ../lib/arraystats/class.c:19
+#, c-format
+msgid "Unknown algorithm '%s'"
+msgstr ""
+#: ../lib/arraystats/class.c:42
+msgid "Discont algorithm currently not available because of bugs"
+msgstr ""
+#: ../lib/arraystats/class.c:49
+msgid "Classification algorithm failed"
+msgstr ""
+#: ../lib/arraystats/class.c:227
+msgid "Equiprobable classbreaks currently limited to 10 classes"
+msgstr ""
+#: ../lib/arraystats/class.c:242
+#, c-format
+msgid "There are classbreaks outside the range min-max. Number of classes reduced to %i, but using probabilities for %i classes."
+msgstr ""
+#: ../lib/raster/range.c:103
+#, c-format
+msgid "Unable to read fp range file for <%s>"
+msgstr ""
+#: ../lib/raster/range.c:170
+#, c-format
+msgid "Unable to read quant rules for raster map <%s>"
+msgstr ""
+#: ../lib/raster/range.c:207 ../lib/raster/range.c:227
+#, c-format
+msgid "Unable to read range file for <%s>"
+msgstr ""
+#: ../lib/raster/range.c:286
+#, c-format
+msgid "Unable to read stats file for <%s>"
+msgstr ""
+#: ../lib/raster/range.c:368 ../lib/raster/range.c:374
+#: ../lib/raster/range.c:406 ../lib/raster/range.c:420
+#, c-format
+msgid "Unable to write range file for <%s>"
+msgstr ""
+#: ../lib/raster/range.c:450 ../lib/raster/range.c:464
+#: ../lib/raster/range.c:482 ../lib/raster/range.c:487
+#, c-format
+msgid "Unable to write stats file for <%s>"
+msgstr ""
+#: ../lib/raster/raster_metadata.c:109
+#, c-format
+msgid "Unable to read <%s> for raster map <%s@%s>"
+msgstr ""
+#: ../lib/raster/raster_metadata.c:119 ../lib/raster/raster_metadata.c:148
+#, c-format
+msgid "Error closing <%s> metadata file for raster map <%s@%s>"
+msgstr ""
+#: ../lib/raster/raster_metadata.c:142
+#, c-format
+msgid "Unable to create <%s> metadata file for raster map <%s@%s>"
+msgstr ""
+#: ../lib/raster/cats.c:109
+#, c-format
+msgid "Category support for <%s@%s> missing"
+msgstr ""
+#: ../lib/raster/cats.c:112
+#, c-format
+msgid "Category support for <%s@%s> invalid"
+msgstr ""
+#: ../lib/raster/cats.c:145
+#, c-format
+msgid "Category support for vector map <%s@%s> missing"
+msgstr ""
+#: ../lib/raster/cats.c:149
+#, c-format
+msgid "Category support for vector map <%s@%s> invalid"
+msgstr ""
+#: ../lib/raster/cats.c:971
+#, c-format
+msgid "Unable to open %s file for map <%s>"
+msgstr ""
+#: ../lib/raster/put_row.c:121
+#, c-format
+msgid "Error writing uncompressed FP data for row %d of <%s>: %s"
+msgstr ""
+#: ../lib/raster/put_row.c:131
+#, c-format
+msgid "Error writing compressed FP data for row %d of <%s>: %s"
+msgstr ""
+#: ../lib/raster/put_row.c:391 ../lib/raster/put_row.c:397
+#, c-format
+msgid "Error writing compressed data for row %d of <%s>"
+msgstr ""
+#: ../lib/raster/put_row.c:407
+#, c-format
+msgid "Error writing uncompressed data for row %d of <%s>"
+msgstr ""
+#: ../lib/raster/put_row.c:467
+#, c-format
+msgid "Error writing data via GDAL for row %d of <%s>"
+msgstr ""
+#: ../lib/raster/put_row.c:491
+msgid "GDAL output doesn't support writing null rows separately"
+msgstr ""
+#: ../lib/raster/put_row.c:494
+#, c-format
+msgid "No null file for <%s>"
+msgstr ""
+#: ../lib/raster/put_row.c:521 ../lib/raster/put_row.c:526
+#, c-format
+msgid "Error writing compressed null data for row %d of <%s>"
+msgstr ""
+#: ../lib/raster/put_row.c:560 ../lib/raster/put_row.c:563
+#, c-format
+msgid "Error writing null row %d of <%s>"
+msgstr ""
+#: ../lib/raster/put_row.c:688
+#, c-format
+msgid "put_raster_row: raster map <%s> not open for write - request ignored"
+msgstr ""
+#: ../lib/raster/put_row.c:695
+msgid "put_raster_row: unopened file descriptor - request ignored"
+msgstr ""
+#: ../lib/raster/open.c:191
+#, c-format
+msgid "Unable to open raster map <%s@%s> since it is a reclass of raster map <%s@%s> which does not exist"
+msgstr ""
+#: ../lib/raster/open.c:196
+#, c-format
+msgid "Error reading reclass file for raster map <%s>"
+msgstr ""
+#: ../lib/raster/open.c:207
+#, c-format
+msgid "Error reading map type for raster map <%s>"
+msgstr ""
+#: ../lib/raster/open.c:215
+#, c-format
+msgid "Raster map <%s@%s>: format field in header file invalid"
+msgstr ""
+#: ../lib/raster/open.c:234
+#, c-format
+msgid "Compression with %s is not supported"
+msgstr ""
+#: ../lib/raster/open.c:238
+#, c-format
+msgid "Raster map <%s> is in different projection than current region. Found <%s>, should be <%s>."
+msgstr ""
+#: ../lib/raster/open.c:245
+#, c-format
+msgid "Raster map <%s> is in different zone (%d) than current region (%d)"
+msgstr ""
+#: ../lib/raster/open.c:250
+#, c-format
+msgid "Raster map <%s>: bytes per cell (%d) too large"
+msgstr ""
+#: ../lib/raster/open.c:275
+#, c-format
+msgid "Raster map <%s@%s> is a GDAL link but GRASS is compiled without GDAL support"
+msgstr ""
+#: ../lib/raster/open.c:283
+#, c-format
+msgid "Unable to open %s file for raster map <%s@%s>"
+msgstr ""
+#: ../lib/raster/open.c:320
+#, c-format
+msgid "Error reading format for <%s@%s>"
+msgstr ""
+#: ../lib/raster/open.c:525
+msgid "Unable to create GDAL link"
+msgstr ""
+#: ../lib/raster/open.c:597 ../lib/raster/gdal.c:477
+#, c-format
+msgid "Invalid map type <%d>"
+msgstr ""
+#: ../lib/raster/open.c:602 ../lib/raster/open.c:757
+#, c-format
+msgid "Raster map <%s> is not in the current mapset (%s)"
+msgstr ""
+#: ../lib/raster/open.c:609
+#, c-format
+msgid "<%s> is an illegal file name"
+msgstr ""
+#: ../lib/raster/open.c:624 ../lib/raster/open.c:704 ../lib/raster/open.c:780
+#, c-format
+msgid "No temp files available: %s"
+msgstr ""
+#: ../lib/raster/open.c:753
+#, c-format
+msgid "Raster map <%s> does not exist in the current mapset (%s)"
+msgstr ""
+#: ../lib/raster/open.c:819
+msgid "Rast_set_fp_type(): can only be called with FCELL_TYPE or DCELL_TYPE"
+msgstr ""
+#: ../lib/raster/open.c:877
+#, c-format
+msgid "Raster map <%s> not found in mapset <%s>"
+msgstr ""
+#: ../lib/raster/open.c:938
+#, c-format
+msgid "Unable to find '%s'"
+msgstr ""
+#: ../lib/raster/open.c:949
+#, c-format
+msgid "Invalid type: field '%s' in file '%s'"
+msgstr ""
+#: ../lib/raster/open.c:954
+#, c-format
+msgid "Missing type: field in file '%s'"
+msgstr ""
+#: ../lib/raster/open.c:959
+#, c-format
+msgid "Raster map <%s> is not xdr: byte_order: %s"
+msgstr ""
+#: ../lib/raster/open.c:1028
+msgid "Rast_set_quant_rules() can be called only for raster maps opened for reading"
+msgstr ""
+#: ../lib/raster/window.c:31
+msgid "Internal error: Rast_get_window() called with split window. Use Rast_get_input_window() or Rast_get_output_window() instead."
+msgstr ""
+#: ../lib/raster/window.c:90
+msgid "Internal error: Rast_window_rows() called with split window. Use Rast_input_window_rows() or Rast_output_window_rows() instead."
+msgstr ""
+#: ../lib/raster/window.c:125
+msgid "Internal error: Rast_window_cols() called with split window. Use Rast_input_window_cols() or Rast_output_window_cols() instead."
+msgstr ""
+#: ../lib/raster/color_read.c:103
+msgid "missing"
+msgstr ""
+#: ../lib/raster/color_read.c:106
+msgid "invalid"
+msgstr ""
+#: ../lib/raster/color_read.c:112
+#, c-format
+msgid "Color support for <%s@%s> %s"
+msgstr ""
+#: ../lib/raster/color_write.c:81 ../lib/vector/Vlib/color_write.c:71
+#, c-format
+msgid "Qualified name <%s> doesn't match mapset <%s>"
+msgstr ""
+#: ../lib/raster/color_write.c:96 ../lib/vector/Vlib/color_write.c:91
+#, c-format
+msgid "Unable to create <%s> file for map <%s>"
+msgstr ""
+#: ../lib/raster/get_row.c:35 ../lib/raster/get_row.c:901
+#, c-format
+msgid "Reading raster map <%s@%s> request for row %d is outside region"
+msgstr ""
+#: ../lib/raster/get_row.c:95
+#, c-format
+msgid "Error seeking fp raster data file for row %d of <%s>: %s"
+msgstr ""
+#: ../lib/raster/get_row.c:103
+#, c-format
+msgid "Error uncompressing fp raster data for row %d of <%s>: error code %d"
+msgstr ""
+#: ../lib/raster/get_row.c:138
+#, c-format
+msgid "Error seeking raster data file for row %d of <%s>: %s"
+msgstr ""
+#: ../lib/raster/get_row.c:145
+#, c-format
+msgid "Error reading raster data for row %d of <%s>: %s"
+msgstr ""
+#: ../lib/raster/get_row.c:169
+#, c-format
+msgid "Error uncompressing raster data for row %d of <%s>"
+msgstr ""
+#: ../lib/raster/get_row.c:188 ../lib/raster/get_row.c:192
+#, c-format
+msgid "Error reading raster data for row %d of <%s>"
+msgstr ""
+#: ../lib/raster/get_row.c:228
+#, c-format
+msgid "Error reading raster data via GDAL for row %d of <%s>"
+msgstr ""
+#: ../lib/raster/get_row.c:830
+#, c-format
+msgid "Error seeking compressed null data for row %d of <%s>"
+msgstr ""
+#: ../lib/raster/get_row.c:835 ../lib/raster/get_row.c:845
+#, c-format
+msgid "Error reading compressed null data for row %d of <%s>"
+msgstr ""
+#: ../lib/raster/get_row.c:851
+#, c-format
+msgid "Error uncompressing null data for row %d of <%s>"
+msgstr ""
+#: ../lib/raster/get_row.c:885
+#, c-format
+msgid "Error seeking null row %d for <%s>"
+msgstr ""
+#: ../lib/raster/get_row.c:888
+#, c-format
+msgid "Error reading null row %d for <%s>"
+msgstr ""
+#: ../lib/raster/quant_io.c:43
+#, c-format
+msgid "Floating data range for raster map <%s> is empty"
+msgstr ""
+#: ../lib/raster/quant_io.c:52
+#, c-format
+msgid "Integer data range for raster map <%s> is empty"
+msgstr ""
+#: ../lib/raster/quant_io.c:105
+#, c-format
+msgid "Attempt to open quantization table for CELL raster map <%s>"
+msgstr ""
+#: ../lib/raster/quant_io.c:135
+#, c-format
+msgid "Quantization file for raster map <%s> is missing"
+msgstr ""
+#: ../lib/raster/quant_io.c:145
+#, c-format
+msgid "Quantization file for raster map <%s> is empty"
+msgstr ""
+#: ../lib/raster/reclass.c:168
+#, c-format
+msgid "Too many reclass categories for <%s@%s>"
+msgstr ""
+#: ../lib/raster/reclass.c:171
+#, c-format
+msgid "Illegal reclass format in header file for <%s@%s>"
+msgstr ""
+#: ../lib/raster/reclass.c:273
+msgid "Illegal reclass request"
+msgstr ""
+#: ../lib/raster/reclass.c:278
+msgid "Illegal reclass type"
+msgstr ""
+#: ../lib/raster/reclass.c:284
+#, c-format
+msgid "Unable to create header file for <%s@%s>"
+msgstr ""
+#: ../lib/raster/reclass.c:332
+#, c-format
+msgid "Unable to create dependency file in <%s@%s>"
+msgstr ""
+#: ../lib/raster/alloc_cell.c:151
+#, c-format
+msgid "Rast__null_bitstream_size: cols (%d) is negative"
+msgstr ""
+#: ../lib/raster/put_cellhd.c:34
+#, c-format
+msgid "Unable to create header file for <%s>"
+msgstr ""
+#: ../lib/raster/interp.c:211
+#, c-format
+msgid "Unknown interpolation method: %s"
+msgstr ""
+#: ../lib/raster/mask_info.c:43
+#, c-format
+msgid "<%s> in mapset <%s>"
+msgstr ""
+#: ../lib/raster/mask_info.c:46
+msgid "none"
+msgstr ""
+#: ../lib/raster/mask_info.c:49
+msgid "not known"
+msgstr ""
+#: ../lib/raster/quant_rw.c:88
+#, c-format
+msgid "Unable to read fp range for raster map <%s>"
+msgstr ""
+#: ../lib/raster/quant_rw.c:92
+#, c-format
+msgid "Raster map <%s> is empty"
+msgstr ""
+#: ../lib/raster/quant_rw.c:157
+#, c-format
+msgid "Unable to write quant rules: raster map <%s> is integer"
+msgstr ""
+#: ../lib/raster/quant_rw.c:166
+#, c-format
+msgid "Unable to write quant rules for raster map <%s>"
+msgstr ""
+#: ../lib/raster/format.c:162
+#, c-format
+msgid "Fail of initial read of compressed file [%s in %s]"
+msgstr ""
+#: ../lib/raster/format.c:176
+#, c-format
+msgid "Fail of initial read of compressed null file [%s in %s]"
+msgstr ""
+#: ../lib/raster/histogram.c:55
+#, c-format
+msgid "Histogram for [%s in %s] missing (run r.support)"
+msgstr ""
+#: ../lib/raster/histogram.c:62
+#, c-format
+msgid "Can't read histogram for [%s in %s]"
+msgstr ""
+#: ../lib/raster/histogram.c:66 ../lib/raster/histogram.c:73
+#, c-format
+msgid "Invalid histogram file for [%s in %s]"
+msgstr ""
+#: ../lib/raster/histogram.c:331
+#, c-format
+msgid "Unable to create histogram file for <%s>"
+msgstr ""
+#: ../lib/raster/color_rules.c:120
+msgid "syntax error in the color rule"
+msgstr ""
+#: ../lib/raster/color_rules.c:122
+msgid "syntax error in the color format"
+msgstr ""
+#: ../lib/raster/color_rules.c:130
+msgid "percentage not in range 0-100"
+msgstr ""
+#: ../lib/raster/color_rules.c:132
+msgid "invalid value"
+msgstr ""
+#: ../lib/raster/color_rules.c:134
+msgid "unknown error"
+msgstr ""
+#: ../lib/raster/color_rules.c:180
+#, c-format
+msgid "bad rule (%s): [%s]"
+msgstr ""
+#: ../lib/raster/color_rules.c:232
+msgid "Unknown error reading color rule"
+msgstr ""
+#: ../lib/raster/color_rules.c:330
+#, c-format
+msgid "Unable to load color rules <%s>"
+msgstr ""
+#: ../lib/raster/color_rand.c:33
+#, c-format
+msgid "Rast_make_random_colors: min (%d) > max (%d)"
+msgstr ""
+#: ../lib/raster/close.c:77 ../lib/raster/close.c:110
+#, c-format
+msgid "Invalid descriptor: %d"
+msgstr ""
+#: ../lib/raster/close.c:392 ../lib/raster/close.c:520
+#, c-format
+msgid "Unable to rename null file '%s' to '%s': %s"
+msgstr ""
+#: ../lib/raster/close.c:462
+#, c-format
+msgid "Unable to rename cell file '%s' to '%s': %s"
+msgstr ""
+#: ../lib/raster/close.c:542
+msgid "unable to write f_format file for CELL maps"
+msgstr ""
+#: ../lib/raster/history.c:115 ../lib/raster/history.c:123
+#, c-format
+msgid "Unable to get history information for <%s@%s>"
+msgstr ""
+#: ../lib/raster/history.c:162
+#, c-format
+msgid "Unable to write history information for <%s>"
+msgstr ""
+#: ../lib/raster/history.c:235
+#, c-format
+msgid "generated by %s"
+msgstr ""
+#: ../lib/raster/gdal.c:89
+#, c-format
+msgid "Unable to locate symbol <%s>"
+msgstr ""
+#: ../lib/raster/gdal.c:145
+msgid "Unable to load GDAL library"
+msgstr ""
+#: ../lib/raster/gdal.c:375
+msgid "Unable to open GDAL file"
+msgstr ""
+#: ../lib/raster/gdal.c:483
+#, c-format
+msgid "Unable to get <%s> driver"
+msgstr ""
+#: ../lib/raster/gdal.c:492
+#, c-format
+msgid "Unable to create <%s> dataset using <%s> driver"
+msgstr ""
+#: ../lib/raster/gdal.c:500
+#, c-format
+msgid "Driver <%s> does not support direct writing. Using MEM driver for intermediate dataset."
+msgstr ""
+#: ../lib/raster/gdal.c:506
+msgid "Unable to get in-memory raster driver"
+msgstr ""
+#: ../lib/raster/gdal.c:513
+#, c-format
+msgid "Unable to create <%s> dataset using memory driver"
+msgstr ""
+#: ../lib/raster/gdal.c:517
+#, c-format
+msgid "Driver <%s> does not support creating rasters"
+msgstr ""
+#: ../lib/raster/gdal.c:533
+msgid "Unable to set geo transform"
+msgstr ""
+#: ../lib/raster/gdal.c:537
+msgid "Unable to set projection"
+msgstr ""
+#: ../lib/raster/gdal.c:541
+#, c-format
+msgid "Unable to create cell_misc/%s/gdal file"
+msgstr ""
+#: ../lib/raster/gdal.c:557
+#, c-format
+msgid "Error writing cell_misc/%s/gdal file"
+msgstr ""
+#: ../lib/raster/gdal.c:605
+#, c-format
+msgid "Unable to create output file <%s> using driver <%s>"
+msgstr ""
+#: ../lib/raster/get_cellhd.c:66
+#, c-format
+msgid "Unable to read header file for raster map <%s@%s>. It is a reclass of raster map <%s@%s> %s"
+msgstr ""
+#: ../lib/raster/get_cellhd.c:70
+msgid "which is missing."
+msgstr ""
+#: ../lib/raster/get_cellhd.c:71
+msgid "whose header file can't be opened."
+msgstr ""
+#: ../lib/raster/get_cellhd.c:76
+#, c-format
+msgid "Unable to open header file for raster map <%s@%s>"
+msgstr ""
+#: ../lib/raster/sample.c:70
+msgid "Unknown interpolation type"
+msgstr ""
+#: ../lib/raster/sample.c:327
+msgid "\"no data\" label found; setting to zero"
+msgstr ""
+#: ../lib/raster/put_title.c:28
+#, c-format
+msgid "category information for [%s] in [%s] missing or invalid"
+msgstr ""
+#: ../lib/raster/put_title.c:37
+msgid "G_put_title - can't create a temp file"
+msgstr ""
+#: ../lib/raster/put_title.c:53
+#, c-format
+msgid "category information for [%s] in [%s] invalid"
+msgstr ""
+#: ../lib/raster/put_title.c:60
+msgid "G_put_title - can't reopen temp file"
+msgstr ""
+#: ../lib/raster/put_title.c:67
+#, c-format
+msgid "can't write category information for [%s] in [%s]"
+msgstr ""
+#: ../lib/raster/init.c:61
+msgid "Raster library not initialized. Programmer forgot to call Rast_init()."
+msgstr ""
+#: ../lib/raster/init.c:109
+#, c-format
+msgid "Unknown compression method <%s>, using default %s"
+msgstr ""
+#: ../lib/raster/init.c:113
+#, c-format
+msgid "No compression is not supported for GRASS raster maps, using default %s"
+msgstr ""
+#: ../lib/raster/init.c:120
+#, c-format
+msgid "This GRASS version does not support %s compression, using default %s"
+msgstr ""
+#: ../lib/raster/null_val.c:64
+msgid "EmbedGivenNulls: wrong data type"
+msgstr ""
+#: ../lib/raster/null_val.c:114
+msgid "Rast_set_null_value: wrong data type!"
+msgstr ""
+#: ../lib/raster/auto_mask.c:69
+msgid "Unable to open automatic MASK file"
+msgstr ""
+#: ../lib/raster/set_window.c:48
+msgid "Rast_set_window() called while window split"
+msgstr ""
+#: ../lib/raster/set_window.c:131
+msgid "Rast_set_read_window(): projection/zone differs from that of currently open raster maps"
+msgstr ""
+#: ../lib/raster/set_window.c:158
+#, c-format
+msgid "Input window changed while maps are open for read. Map name <%s>"
+msgstr ""
+#: ../lib/raster/set_window.c:174
+#, c-format
+msgid "Output window changed while maps are open for write. Map name <%s>"
+msgstr ""
+#: ../lib/ogsf/gsd_img_tif.c:66 ../lib/ogsf/gk2.c:216
+#: ../lib/ogsf/gsd_img_ppm.c:52 ../lib/ogsf/gsd_img_ppm.c:95
+#, c-format
+msgid "Unable to open file <%s> for writing"
+msgstr ""
+#: ../lib/ogsf/gk.c:320
+msgid "Need at least 3 keyframes for spline"
+msgstr ""
+#: ../lib/ogsf/gk.c:622
+msgid "Need at least 2 keyframes for interpolation"
+msgstr ""
+#: ../lib/ogsf/gs2.c:1211
+#, c-format
+msgid "no category info"
+msgstr ""
+#: ../lib/ogsf/gs2.c:1230
+#, c-format
+msgid "no data"
+msgstr ""
+#: ../lib/ogsf/gs2.c:1655
+#, c-format
+msgid "Raster map <%s> is outside of current region. Load failed."
+msgstr ""
+#: ../lib/ogsf/gs2.c:1733 ../lib/ogsf/gs2.c:1739 ../lib/ogsf/gs2.c:1747
+#: ../lib/ogsf/gs2.c:1756 ../lib/ogsf/gs2.c:1764 ../lib/ogsf/gs2.c:1774
+#: ../lib/ogsf/gs2.c:1822
+msgid "GS_load_att_map(): Out of memory. Unable to load map"
+msgstr ""
+#: ../lib/ogsf/gs2.c:1850
+msgid "Loading failed"
+msgstr ""
+#: ../lib/ogsf/gs2.c:1854
+msgid "Error finding range"
+msgstr ""
+#: ../lib/ogsf/gk2.c:272 ../lib/ogsf/gk2.c:285
+msgid "Check no. of frames requested and keyframes marked"
+msgstr ""
+#: ../lib/ogsf/gs3.c:132 ../lib/ogsf/gs3.c:196 ../lib/ogsf/gs3.c:348
+#: ../lib/ogsf/gs3.c:454 ../lib/ogsf/gs3.c:540
+#, c-format
+msgid "Loading raster map <%s>..."
+msgstr ""
+#: ../lib/ogsf/gs3.c:596
+#, c-format
+msgid "Color table range doesn't match data (mincol=%d, maxcol=%d"
+msgstr ""
+#: ../lib/ogsf/gs3.c:658 ../lib/ogsf/gs3.c:730
+#, c-format
+msgid "Translating colors from raster map <%s>..."
+msgstr ""
+#: ../lib/ogsf/gs3.c:967
+msgid "View not saved by this program,there may be some inconsistancies"
+msgstr ""
+#: ../lib/ogsf/gsdrape.c:207
+msgid "Unable to process vector map - out of memory"
+msgstr ""
+#: ../lib/ogsf/gp3.c:62 ../lib/ogsf/gp3.c:196 ../lib/ogsf/gv3.c:66
+#: ../lib/ogsf/gv3.c:338 ../lib/python/temporal/c_libraries_interface.py:747
+#: ../lib/vector/Vlib/open.c:301 ../lib/vector/Vlib/open.c:437
+#: ../lib/vector/Vlib/map.c:192 ../lib/vector/Vlib/map.c:202
+#: ../lib/vector/Vlib/map.c:274
+#, c-format, python-format
+msgid "Unable to open vector map <%s>"
+msgstr ""
+#: ../lib/ogsf/gp3.c:92 ../lib/vector/Vlib/copy.c:169
+#: ../lib/vector/Vlib/copy.c:246
+#, c-format
+msgid "Unable to read vector map <%s>"
+msgstr ""
+#: ../lib/ogsf/gp3.c:148
+#, c-format
+msgid "No points from vector map <%s> fall within current region"
+msgstr ""
+#: ../lib/ogsf/gp3.c:153
+#, c-format
+msgid "Vector map <%s> loaded (%d points)"
+msgstr ""
+#: ../lib/ogsf/gp3.c:202 ../lib/ogsf/gv3.c:344
+#: ../lib/rst/interp_float/vinput2d.c:100 ../lib/vector/Vlib/cats.c:589
+#: ../lib/vector/Vlib/copy.c:620 ../lib/vector/Vlib/copy.c:730
+#: ../lib/vector/Vlib/map.c:300 ../lib/vector/Vlib/map.c:436
+#: ../lib/vector/Vlib/ascii.c:398 ../lib/vector/Vlib/array.c:276
+#: ../lib/vector/Vlib/net_build.c:159 ../lib/vector/Vlib/net_build.c:206
+#: ../lib/vector/Vlib/net_build.c:490 ../lib/vector/Vlib/net_build.c:791
+#: ../lib/vector/Vlib/net_build.c:971
+#, c-format
+msgid "Database connection not defined for layer %d"
+msgstr ""
+#: ../lib/ogsf/gp3.c:208 ../lib/ogsf/gv3.c:350
+#: ../lib/rst/interp_float/vinput2d.c:109 ../lib/db/dbmi_client/db.c:46
+#: ../lib/db/dbmi_client/copy_tab.c:112 ../lib/db/dbmi_client/copy_tab.c:133
+#: ../lib/vector/Vlib/cats.c:597 ../lib/vector/Vlib/close_nat.c:160
+#: ../lib/vector/Vlib/write_ogr.c:198 ../lib/vector/Vlib/write_pg.c:2915
+#: ../lib/vector/Vlib/map.c:341 ../lib/vector/Vlib/ascii.c:410
+#: ../lib/vector/Vlib/array.c:282 ../lib/vector/Vlib/net_build.c:165
+#: ../lib/vector/Vlib/net_build.c:211 ../lib/vector/Vlib/net_build.c:496
+#: ../lib/vector/Vlib/net_build.c:797 ../lib/vector/Vlib/net_build.c:976
+#: ../lib/vector/neta/utils.c:119 ../lib/vector/neta/timetables.c:133
+#, c-format
+msgid "Unable to open database <%s> by driver <%s>"
+msgstr ""
+#: ../lib/ogsf/gp3.c:211
+#, c-format
+msgid "Loading thematic points layer <%s>..."
+msgstr ""
+#: ../lib/ogsf/gp3.c:235 ../lib/ogsf/gv3.c:377
+#, c-format
+msgid "No color rule defined for category %d"
+msgstr ""
+#: ../lib/ogsf/gp3.c:249 ../lib/ogsf/gv3.c:392
+#, c-format
+msgid "Invalid color definition (%s)"
+msgstr ""
+#: ../lib/ogsf/gp3.c:288
+#, c-format
+msgid "%d points without category. Unable to determine color rules for features without category."
+msgstr ""
+#: ../lib/ogsf/gsd_surf.c:1742
+msgid "Cut-plane points mis-match between surfaces. Check resolution(s)."
+msgstr ""
+#: ../lib/ogsf/gsd_legend.c:246
+#, c-format
+msgid "Unable to read color file of raster map <%s>"
+msgstr ""
+#: ../lib/ogsf/gsd_legend.c:252
+#, c-format
+msgid "Unable to read category file of raster map <%s>"
+msgstr ""
+#: ../lib/ogsf/gsd_legend.c:269
+#, c-format
+msgid "Unable to read fp range of raster map <%s>"
+msgstr ""
+#: ../lib/ogsf/gsd_legend.c:281
+#, c-format
+msgid "Unable to read range of raster map <%s>"
+msgstr ""
+#: ../lib/ogsf/gsd_legend.c:295
+msgid "Range request error for legend"
+msgstr ""
+#: ../lib/ogsf/gsd_legend.c:385
+msgid "Unable to show discrete FP range (use list)"
+msgstr ""
+#: ../lib/ogsf/gsd_legend.c:501
+msgid "Too many categories to show as discrete!"
+msgstr ""
+#: ../lib/ogsf/gsd_legend.c:503
+msgid "Try using smaller font!"
+msgstr ""
+#: ../lib/ogsf/gsd_label.c:58
+msgid "Max. number of labels reached!"
+msgstr ""
+#: ../lib/ogsf/gs_bm.c:124
+msgid "Bitmap mismatch"
+msgstr ""
+#: ../lib/ogsf/gv3.c:269
+#, c-format
+msgid "No features from vector map <%s> fall within current region"
+msgstr ""
+#: ../lib/ogsf/gv3.c:274
+#, c-format
+msgid "Vector map <%s> loaded (%d features)"
+msgstr ""
+#: ../lib/ogsf/gv3.c:353
+#, c-format
+msgid "Loading thematic vector layer <%s>..."
+msgstr ""
+#: ../lib/ogsf/gv3.c:414
+#, c-format
+msgid "%d features without category. Unable to determine color rules for features without category."
+msgstr ""
+#: ../lib/ogsf/gvl_file.c:103
+msgid "Maximum number of datafiles exceeded"
+msgstr ""
+#: ../lib/ogsf/gvl_file.c:436 ../lib/gpde/n_arrays_io.c:281
+#: ../lib/python/temporal/c_libraries_interface.py:676
+msgid "Unable to open 3D raster map <%s>"
+msgstr ""
+#: ../lib/ogsf/gvl_file.c:442
+#, c-format
+msgid "Unable to read range of 3D raster map <%s>"
+msgstr ""
+#: ../lib/ogsf/gvl_file.c:470
+#: ../lib/python/temporal/c_libraries_interface.py:706
+#: ../lib/raster3d/close.c:120 ../lib/raster3d/close.c:130
+#: ../lib/raster3d/close.c:159
+msgid "Unable to close 3D raster map <%s>"
+msgstr ""
+#: ../lib/ogsf/gsds.c:109
+msgid "Maximum number of datasets exceeded"
+msgstr ""
+#: ../lib/ogsf/gsd_prim.c:146
+#, c-format
+msgid "Color Material: %d"
+msgstr ""
+#: ../lib/ogsf/gsd_prim.c:630
+#, c-format
+msgid "gsd_rot(): %c is an invalid axis specification. Rotation ignored. Please advise GRASS developers of this error"
+msgstr ""
+#: ../lib/ogsf/trans.c:180
+msgid "Out of matrix stack space"
+msgstr ""
+#: ../lib/ogsf/trans.c:200
+msgid "Tried to pop an empty stack"
+msgstr ""
+#: ../lib/ogsf/gvl2.c:267
+#, c-format
+msgid "Loading 3d raster map <%s>..."
+msgstr ""
+#: ../lib/ogsf/gp2.c:705
+msgid "Unknown icon marker, using \"sphere\""
+msgstr ""
+#: ../lib/gpde/test/test_main.c:88
+msgid "Performs unit and integration tests for gpde library"
+msgstr ""
+#: ../lib/gpde/n_parse_options.c:106
+msgid "The calculation time in seconds"
+msgstr ""
+#: ../lib/gpde/n_arrays_io.c:93
+#, c-format
+msgid "Reading raster map <%s> into memory"
+msgstr ""
+#: ../lib/gpde/n_arrays_io.c:183
+msgid "N_array_2d * array is empty"
+msgstr ""
+#: ../lib/gpde/n_arrays_io.c:202
+#, c-format
+msgid "Write 2d array to raster map <%s>"
+msgstr ""
+#: ../lib/gpde/n_arrays_io.c:309
+#, c-format
+msgid "Read g3d map <%s> into the memory"
+msgstr ""
+#: ../lib/gpde/n_arrays_io.c:364 ../lib/gpde/n_arrays_io.c:464
+msgid "Error closing g3d file"
+msgstr ""
+#: ../lib/gpde/n_arrays_io.c:420
+#, c-format
+msgid "Error opening g3d map <%s>"
+msgstr ""
+#: ../lib/gpde/n_arrays_io.c:422
+#, c-format
+msgid "Write 3d array to g3d map <%s>"
+msgstr ""
+#: ../lib/gpde/n_gwflow.c:436 ../lib/gpde/n_gwflow.c:715
+#, c-format
+msgid "The total sum of the water budget: %g\n"
+msgstr ""
+#: ../lib/gpde/n_gwflow.c:438 ../lib/gpde/n_gwflow.c:717
+#, c-format
+msgid "The total sum of the water budget is significantly larger then 0: %g\n"
+msgstr ""
+#: ../lib/display/icon.c:80
+#, c-format
+msgid "Unsupported icon %d"
+msgstr ""
+#: ../lib/display/r_raster.c:98
+#, c-format
+msgid "Both %s and %s are defined. %s will be ignored."
+msgstr ""
+#: ../lib/display/r_raster.c:131
+#, c-format
+msgid "Neither %s (managed by d.mon command) nor %s (used for direct rendering) defined"
+msgstr ""
+#: ../lib/display/r_raster.c:150
+#, c-format
+msgid "Unknown display driver <%s>"
+msgstr ""
+#: ../lib/display/r_raster.c:151
+#, c-format
+msgid "Using display driver <%s>..."
+msgstr ""
+#: ../lib/display/tran_colr.c:107 ../lib/display/tran_colr.c:109
+#, c-format
+msgid "[%s]: No such color"
+msgstr "[%s]: Nincs ilyen szín"
+#: ../lib/nviz/position.c:56
+msgid "Unable to set focus"
+msgstr ""
+#: ../lib/nviz/nviz.c:128
+#, c-format
+msgid "Invalid color (%s), using \"white\" as default"
+msgstr ""
+#: ../lib/nviz/render.c:106
+msgid "Bad server connection"
+msgstr ""
+#: ../lib/nviz/render.c:112
+msgid "Unable to get visual info"
+msgstr ""
+#: ../lib/nviz/render.c:119
+msgid "Unable to create rendering context"
+msgstr ""
+#: ../lib/nviz/map_obj.c:59
+msgid "Maximum surfaces loaded!"
+msgstr ""
+#: ../lib/nviz/map_obj.c:88
+msgid "Maximum vector line maps loaded!"
+msgstr ""
+#: ../lib/nviz/map_obj.c:97 ../lib/nviz/map_obj.c:128
+#, c-format
+msgid "Error loading vector map <%s>"
+msgstr ""
+#: ../lib/nviz/map_obj.c:116
+msgid "Maximum vector point maps loaded!"
+msgstr ""
+#: ../lib/nviz/map_obj.c:143
+msgid "Maximum volumes loaded!"
+msgstr ""
+#: ../lib/nviz/map_obj.c:152
+#, c-format
+msgid "Error loading 3d raster map <%s>"
+msgstr ""
+#: ../lib/nviz/map_obj.c:160
+msgid "Nviz_new_map_obj(): unsupported data type"
+msgstr ""
+#: ../lib/nviz/lights.c:171
+msgid "Unable to define new light"
+msgstr ""
+#: ../lib/cairodriver/text.c:46
+#, c-format
+msgid "Unable to convert from <%s> to UTF-8"
+msgstr ""
+#: ../lib/cairodriver/text.c:56
+msgid "Some characters could not be converted to UTF-8"
+msgstr ""
+#: ../lib/cairodriver/read_xid.c:14
+#, c-format
+msgid "Unable to open input file <%s>"
+msgstr ""
+#: ../lib/cairodriver/read_xid.c:17
+#, c-format
+msgid "Unable to read input file <%s>"
+msgstr ""
+#: ../lib/cairodriver/read_xid.c:20
+#, c-format
+msgid "Unable to parse input file <%s>"
+msgstr ""
+#: ../lib/cairodriver/read_ppm.c:28 ../lib/cairodriver/read_bmp.c:88
+#, c-format
+msgid "Cairo: unable to open input file <%s>"
+msgstr ""
+#: ../lib/cairodriver/read_ppm.c:32 ../lib/cairodriver/read_bmp.c:92
+#, c-format
+msgid "Cairo: invalid input file <%s>"
+msgstr ""
+#: ../lib/cairodriver/read_ppm.c:38
+#, c-format
+msgid "Cairo: input file has incorrect dimensions: expected: %dx%d got: %dx%d"
+msgstr ""
+#: ../lib/cairodriver/read_ppm.c:46
+#, c-format
+msgid "Cairo: unable to open input mask file <%s>"
+msgstr ""
+#: ../lib/cairodriver/read_ppm.c:50
+#, c-format
+msgid "Cairo: invalid input mask file <%s>"
+msgstr ""
+#: ../lib/cairodriver/read_ppm.c:56
+#, c-format
+msgid "Cairo: input mask file has incorrect dimensions: expected: %dx%d got: %dx%d"
+msgstr ""
+#: ../lib/cairodriver/read_bmp.c:96
+#, c-format
+msgid "Cairo: Invalid BMP header for <%s>"
+msgstr ""
+#: ../lib/cairodriver/write_bmp.c:72 ../lib/cairodriver/write_ppm.c:27
+#, c-format
+msgid "Cairo: unable to open output file <%s>"
+msgstr ""
+#: ../lib/cairodriver/write_ppm.c:34
+#, c-format
+msgid "Cairo: unable to open mask file <%s>"
+msgstr ""
+#: ../lib/cairodriver/draw_bitmap.c:47
+msgid "Cairo_Bitmap: Failed to create source"
+msgstr ""
+#: ../lib/cairodriver/raster.c:109
+msgid "Failed to create cairo surface"
+msgstr ""
+#: ../lib/cairodriver/write_xid.c:14 ../lib/pngdriver/read_png.c:71
+#, c-format
+msgid "Unable to open output file <%s>"
+msgstr ""
+#: ../lib/cairodriver/write_xid.c:19
+#, c-format
+msgid "Unable to write output file <%s>"
+msgstr ""
+#: ../lib/cairodriver/graph.c:67
+msgid "Unable to open display"
+msgstr ""
+#: ../lib/cairodriver/graph.c:85
+msgid "Unable to obtain visual"
+msgstr ""
+#: ../lib/cairodriver/graph.c:160
+#, c-format
+msgid "Unknown file extension: %s"
+msgstr ""
+#: ../lib/cairodriver/graph.c:190
+#, c-format
+msgid "cairo: collecting to file '%s'"
+msgstr ""
+#: ../lib/cairodriver/graph.c:192
+#, c-format
+msgid "cairo: image size %dx%d"
+msgstr ""
+#: ../lib/cairodriver/graph.c:371
+msgid "Unknown Cairo surface type"
+msgstr ""
+#: ../lib/cairodriver/graph.c:376
+msgid "Failed to initialize Cairo surface"
+msgstr ""
+#: ../lib/psdriver/graph_set.c:199
+#, c-format
+msgid "ps: truecolor status %s"
+msgstr ""
+#: ../lib/psdriver/graph_set.c:200 ../lib/pngdriver/graph_set.c:102
+msgid "enabled"
+msgstr ""
+msgid "disabled"
+msgstr ""
+#: ../lib/psdriver/graph_set.c:214
+#, c-format
+msgid "ps: collecting to file '%s'"
+msgstr ""
+#: ../lib/psdriver/graph_set.c:215
+#, c-format
+msgid "ps: image size %dx%d"
+msgstr ""
+#: ../lib/python/temporal/open_stds.py:63
+#: ../lib/python/temporal/open_stds.py:119
+#, python-format
+msgid "Unknown type: %s"
+msgstr ""
+#: ../lib/python/temporal/open_stds.py:69
+#, python-format
+msgid "Space time %(sp)s dataset <%(name)s> not found"
+msgstr ""
+#: ../lib/python/temporal/open_stds.py:108
+msgid "Space time datasets can only be created in the current mapset"
+msgstr ""
+#: ../lib/python/temporal/open_stds.py:125
+#, python-format
+msgid "Space time %(sp)s dataset <%(name)s> is already in the database. Use the overwrite flag."
+msgstr ""
+#: ../lib/python/temporal/open_stds.py:160
+#, python-format
+msgid "Overwriting space time %(sp)s dataset <%(name)s> and unregistering all maps"
+msgstr ""
+#: ../lib/python/temporal/open_stds.py:168
+#, python-format
+msgid "Creating a new space time %s dataset"
+msgstr ""
+#: ../lib/python/temporal/open_stds.py:211
+#: ../lib/python/temporal/mapcalc.py:239 ../lib/python/temporal/extract.py:131
+#, python-format
+msgid "Map <%s> is already in temporal database, use overwrite flag to overwrite"
+msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:167
+#: ../lib/python/temporal/abstract_space_time_dataset.py:301
+#, python-format
+msgid "Unknown temporal type \"%s\""
+msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:294
+#: ../lib/python/temporal/abstract_space_time_dataset.py:1062
+#, python-format
+msgid "Wrong granularity: \"%s\""
+msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:322
+#, python-format
+msgid "Unsupported temporal unit: %s"
+msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:372
+#, python-format
+msgid "Created register table <%s> for space time %s dataset <%s>"
+msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:690
+#: ../lib/python/temporal/abstract_space_time_dataset.py:932
+msgid "The space time datasets must be of the same temporal type"
+msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:695
+#: ../lib/python/temporal/abstract_space_time_dataset.py:937
+msgid "The temporal map type of the sample dataset must be interval"
+msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:1499
+#, python-format
+msgid "Unable to get map ids from register table <%s>"
+msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:1609
+#, python-format
+msgid "Unable to shift dataset <%(ds)s> of type %(type)s in the temporal database. The mapset of the dataset does not match the current mapset"
+msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:1616
+#: ../lib/python/temporal/datetime_math.py:451
+#, python-format
+msgid "Wrong granularity format: %s"
+msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:1778
+#, python-format
+msgid "Unable to snap dataset <%(ds)s> of type %(type)s in the temporal database. The mapset of the dataset does not match the current mapset"
+msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:1880
+#, python-format
+msgid "Unable to rename dataset <%(ds)s> of type %(type)s in the temporal database. The mapset of the dataset does not match the current mapset"
+msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:1889
+msgid "Renaming of space time datasets is not supported for PostgreSQL."
+msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:1954
+#, python-format
+msgid "Delete space time %s dataset <%s> from temporal database"
+msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:1960
+#: ../lib/python/temporal/abstract_map_dataset.py:841
+#, python-format
+msgid "Unable to delete dataset <%(ds)s> of type %(type)s from the temporal database. The mapset of the dataset does not match the current mapset"
+msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:1973
+#, python-format
+msgid "Drop map register table: %s"
+msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2028
+msgid "Error in register table request"
+msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2057
+#, python-format
+msgid "Unable to register map in dataset <%(ds)s> of type %(type)s. The mapset of the dataset does not match the current mapset"
+msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2066
+msgid "Only a map that was inserted in the temporal database can be registered in a space time dataset"
+msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2089
+#, python-format
+msgid "Map <%(id)s> with layer %(l)s has invalid time"
+msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2093
+#, python-format
+msgid "Map <%s> has invalid time"
+msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2111
+#, python-format
+msgid "Temporal type of space time dataset <%(id)s> and map <%(map)s> with layer %(l)s are different"
+msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2117
+#, python-format
+msgid "Temporal type of space time dataset <%(id)s> and map <%(map)s> are different"
+msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2132
+#, python-format
+msgid "Set temporal unit for space time %s dataset <%s> to %s"
+msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2142
+#, python-format
+msgid "Relative time units of space time dataset <%(id)s> and map <%(map)s> with layer %(l)s are different"
+msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2148
+#, python-format
+msgid "Relative time units of space time dataset <%(id)s> and map <%(map)s> are different"
+msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2154
+msgid "Only maps from the same mapset can be registered"
+msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2159
+#, python-format
+msgid "Map <%(map)s> with layer %(l)s is already registered."
+msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2163
+#, python-format
+msgid "Map <%s> is already registered."
+msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2211
+#, python-format
+msgid "Unable to unregister map from dataset <%(ds)s> of type %(type)s in the temporal database. The mapset of the dataset does not match the current mapset"
+msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2224
+#, python-format
+msgid "Map <%(map)s> with layer %(l)s is not registered in space time dataset <%(base)s>"
+msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2230
+#, python-format
+msgid "Map <%(map)s> is not registered in space time dataset <%(base)s>"
+msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2285
+#: ../lib/python/temporal/abstract_dataset.py:426
+#: ../lib/python/temporal/abstract_dataset.py:469
+#: ../lib/python/temporal/abstract_map_dataset.py:424
+#: ../lib/python/temporal/abstract_map_dataset.py:520
+#, python-format
+msgid "Unable to update dataset <%(ds)s> of type %(type)s in the temporal database. The mapset of the dataset does not match the current mapset"
+msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2291
+#, python-format
+msgid "Update metadata, spatial and temporal extent from all registered maps of <%s>"
+msgstr ""
+#: ../lib/python/temporal/abstract_dataset.py:386
+#, python-format
+msgid "Unable to insert dataset <%(ds)s> of type %(type)s in the temporal database. The mapset of the dataset does not match the current mapset"
+msgstr ""
+#: ../lib/python/temporal/abstract_map_dataset.py:350
+#, python-format
+msgid "Start time must be of type datetime for %(type)s map <%(id)s> with layer: %(l)s"
+msgstr ""
+#: ../lib/python/temporal/abstract_map_dataset.py:357
+#, python-format
+msgid "Start time must be of type datetime for %(type)s map <%(id)s>"
+msgstr ""
+#: ../lib/python/temporal/abstract_map_dataset.py:365
+#, python-format
+msgid "End time must be of type datetime for %(type)s map <%(id)s> with layer: %(l)s"
+msgstr ""
+#: ../lib/python/temporal/abstract_map_dataset.py:372
+#, python-format
+msgid "End time must be of type datetime for %(type)s map <%(id)s>"
+msgstr ""
+#: ../lib/python/temporal/abstract_map_dataset.py:381
+#, python-format
+msgid "End time must be greater than start time for %(type)s map <%(id)s> with layer: %(l)s"
+msgstr ""
+#: ../lib/python/temporal/abstract_map_dataset.py:389
+#: ../lib/python/temporal/abstract_map_dataset.py:482
+#, python-format
+msgid "End time must be greater than start time for %(type)s map <%(id)s>"
+msgstr ""
+#: ../lib/python/temporal/abstract_map_dataset.py:460
+#, python-format
+msgid "Unsupported relative time unit type for %(type)s map <%(id)s> with layer %(l)s: %(u)s"
+msgstr ""
+#: ../lib/python/temporal/abstract_map_dataset.py:467
+#, python-format
+msgid "Unsupported relative time unit type for %(type)s map <%(id)s>: %(u)s"
+msgstr ""
+#: ../lib/python/temporal/abstract_map_dataset.py:476
+#, python-format
+msgid "End time must be greater than start time for %(typ)s map <%(id)s> with layer %(l)s"
+msgstr ""
+#: ../lib/python/temporal/abstract_map_dataset.py:800
+#, python-format
+msgid "Map <%(id)s> with layer %(layer)s has incorrect time interval, start time is greater than end time"
+msgstr ""
+#: ../lib/python/temporal/abstract_map_dataset.py:806
+#, python-format
+msgid "Map <%s> has incorrect time interval, start time is greater than end time"
+msgstr ""
+#: ../lib/python/temporal/abstract_map_dataset.py:812
+#, python-format
+msgid "Map <%s> has incorrect start time"
+msgstr ""
+#: ../lib/python/temporal/abstract_map_dataset.py:859
+#, python-format
+msgid "Delete %s dataset <%s> from temporal database"
+msgstr ""
+#: ../lib/python/temporal/abstract_map_dataset.py:909
+#, python-format
+msgid "Unable to unregister dataset <%(ds)s> of type %(type)s from the temporal database. The mapset of the dataset does not match the current mapset"
+msgstr ""
+#: ../lib/python/temporal/register.py:82 ../lib/python/temporal/register.py:85
+#, python-format
+msgid "%s= and %s= are mutually exclusive"
+msgstr ""
+#: ../lib/python/temporal/register.py:89
+#, python-format
+msgid "%s= and the %s flag are mutually exclusive"
+msgstr ""
+#: ../lib/python/temporal/register.py:93
+msgid "The increment option requires the start option"
+msgstr ""
+#: ../lib/python/temporal/register.py:96
+msgid "The interval flag requires the start option"
+msgstr ""
+#: ../lib/python/temporal/register.py:99
+#, python-format
+msgid "Please specify %s= and %s="
+msgstr ""
+#: ../lib/python/temporal/register.py:103
+#, python-format
+msgid "Please specify %s= or %s="
+msgstr ""
+#: ../lib/python/temporal/register.py:114
+#, python-format
+msgid "Space time %(sp)s dataset <%(name)s> with relative time found, but no relative unit set for %(sp)s maps"
+msgstr ""
+#: ../lib/python/temporal/register.py:175
+msgid "The increment option will be ignored because of time stamps in input file"
+msgstr ""
+#: ../lib/python/temporal/register.py:179
+msgid "The interval flag will be ignored because of time stamps in input file"
+msgstr ""
+#: ../lib/python/temporal/register.py:187
+msgid "Gathering map information..."
+msgstr ""
+#: ../lib/python/temporal/register.py:197
+#, python-format
+msgid "Unable to update %(t)s map <%(id)s>. The map does not exist."
+msgstr ""
+#: ../lib/python/temporal/register.py:215
+#, python-format
+msgid "Unable to register %(t)s map <%(id)s> with layer %(l)s. The map has timestamp and the start time is not set."
+msgstr ""
+#: ../lib/python/temporal/register.py:221
+#, python-format
+msgid "Unable to register %(t)s map <%(id)s>. The map has no timestamp and the start time is not set."
+msgstr ""
+#: ../lib/python/temporal/register.py:229
+#, python-format
+msgid "%(u)s= can only be set for relative time"
+msgstr ""
+#: ../lib/python/temporal/register.py:232
+#, python-format
+msgid "%(u)s= must be set in case of relative time stamps"
+msgstr ""
+#: ../lib/python/temporal/register.py:245
+#, python-format
+msgid "Map is already registered in temporal database. Unable to update %(t)s map <%(id)s> with layer %(l)s. Overwrite flag is not set."
+msgstr ""
+#: ../lib/python/temporal/register.py:252
+#, python-format
+msgid "Map is already registered in temporal database. Unable to update %(t)s map <%(id)s>. Overwrite flag is not set."
+msgstr ""
+#: ../lib/python/temporal/register.py:276
+#, python-format
+msgid "Unable to update %(t)s map <%(id)s> with layer %(l)s. The temporal types are different."
+msgstr ""
+#: ../lib/python/temporal/register.py:282
+#, python-format
+msgid "Unable to update %(t)s map <%(id)s>. The temporal types are different."
+msgstr ""
+#: ../lib/python/temporal/register.py:330
+msgid "Registering maps in the temporal database..."
+msgstr ""
+#: ../lib/python/temporal/register.py:337
+msgid "Registering maps in the space time dataset..."
+msgstr ""
+#: ../lib/python/temporal/register.py:346
+msgid "Updating space time dataset..."
+msgstr ""
+#: ../lib/python/temporal/register.py:399
+#: ../lib/python/temporal/register.py:406
+#, python-format
+msgid "Unable to convert string \"%s\"into a datetime object"
+msgstr ""
+#: ../lib/python/temporal/register.py:414
+#: ../lib/python/temporal/register.py:419
+msgid "Error occurred in increment computation"
+msgstr ""
+#: ../lib/python/temporal/register.py:422
+#, python-format
+msgid "Set absolute valid time for map <%(id)s> with layer %(layer)s to %(start)s - %(end)s"
+msgstr ""
+#: ../lib/python/temporal/register.py:427
+#, python-format
+msgid "Set absolute valid time for map <%s> to %s - %s"
+msgstr ""
+#: ../lib/python/temporal/register.py:444
+#, python-format
+msgid "Set relative valid time for map <%s> with layer %s to %i - %s with unit %s"
+msgstr ""
+#: ../lib/python/temporal/register.py:449
+#, python-format
+msgid "Set relative valid time for map <%s> to %i - %s with unit %s"
+msgstr ""
+#: ../lib/python/temporal/factory.py:51
+#, python-format
+msgid "Unknown dataset type: %s"
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:85
+#, python-format
+msgid "Unable to import/link raster map <%s> from file %s."
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:96
+#, python-format
+msgid "Unable to set the color rules for raster map <%s>."
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:120
+#, python-format
+msgid "Unable to unpack raster map <%s> from file %s."
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:144
+#, python-format
+msgid "Unable to import vector map <%s> from file %s."
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:168
+#, python-format
+msgid "Unable to unpack vector map <%s> from file %s."
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:207
+#, python-format
+msgid "Space time raster dataset archive <%s> not found"
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:210
+#, python-format
+msgid "Extraction directory <%s> not found"
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:216
+#, python-format
+msgid "Checking validity of input file (size: %0.1f MB). Make take a while..."
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:223
+#, python-format
+msgid "Unable to find init file <%s>"
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:225
+#, python-format
+msgid "Unable to find list file <%s>"
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:227
+#, python-format
+msgid "Unable to find projection file <%s>"
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:229
+msgid "Extracting data..."
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:269
+msgid "Projection information does not match. Proceeding..."
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:273
+#, python-brace-format
+msgid ""
+"Difference between PROJ_INFO file of imported map and of current location:\n"
+"{diff}"
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:276
+msgid "Projection information does not match. Aborting."
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:293
+#, python-format
+msgid "Unable to create location %(l)s. Reason: %(e)s"
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:301
+#, python-format
+msgid "Unable to switch to location %s"
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:306
+#, python-format
+msgid "Unable to create default temporal database in new location %s"
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:380
+#, python-format
+msgid "Key words %(t)s, %(s)s or %(n)s not found in init file."
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:386
+msgid "Number of maps mismatch in init and list file."
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:397
+msgid "The archive file is of wrong space time dataset type"
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:405
+#, python-format
+msgid "Unable to find GeoTIFF raster file <%s> in archive."
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:411
+#, python-format
+msgid "Unable to find AAIGrid raster file <%s> in archive."
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:417
+#, python-format
+msgid "Unable to find GML vector file <%s> in archive."
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:426
+#, python-format
+msgid "Unable to find GRASS package file <%s> in archive."
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:429
+msgid "Unsupported input format"
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:435
+#, python-format
+msgid "Space time %(t)s dataset <%(sp)s> is already in the database. Use the overwrite flag."
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:456
+#, python-format
+msgid "Overwrite space time %(sp)s dataset <%(id)s> and unregister all maps."
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:468
+#, python-format
+msgid "Key word %s not found in init file."
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:473
+#, python-format
+msgid "Create space time %s dataset."
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:502
+msgid "Switching to original location failed"
+msgstr ""
+#: ../lib/python/temporal/datetime_math.py:256
+#: ../lib/python/temporal/datetime_math.py:273
+#, python-format
+msgid "Wrong increment format: %s"
+msgstr ""
+#: ../lib/python/temporal/datetime_math.py:771
+msgid "Time string seems to specify relative time"
+msgstr ""
+#: ../lib/python/temporal/datetime_math.py:783
+msgid "Dates Before Christ (BC) are not supported"
+msgstr ""
+#: ../lib/python/temporal/datetime_math.py:787
+msgid "Time zones are not supported"
+msgstr ""
+#: ../lib/python/temporal/datetime_math.py:807
+#, python-format
+msgid "Unable to parse time string: %s"
+msgstr ""
+#: ../lib/python/temporal/stds_export.py:107
+#, python-format
+msgid "Unable to export raster map <%s>"
+msgstr ""
+#: ../lib/python/temporal/stds_export.py:118
+#, python-format
+msgid "Unable to export color rules for raster map <%s> r.out.gdal"
+msgstr ""
+#: ../lib/python/temporal/stds_export.py:142
+#, python-format
+msgid "Unable to export raster map <%s> with r.pack"
+msgstr ""
+#: ../lib/python/temporal/stds_export.py:170
+#, python-format
+msgid "Unable to export vector map <%s> as GML with v.out.ogr"
+msgstr ""
+#: ../lib/python/temporal/stds_export.py:203
+#, python-format
+msgid "Unable to export vector map <%s> with v.pack"
+msgstr ""
+#: ../lib/python/temporal/stds_export.py:229
+#, python-format
+msgid "Unable to export raster map <%s> with r3.pack"
+msgstr ""
+#: ../lib/python/temporal/c_libraries_interface.py:596
+#: ../lib/python/temporal/c_libraries_interface.py:613
+msgid "Unable to read range file"
+msgstr ""
+#: ../lib/python/temporal/c_libraries_interface.py:691
+#, python-format
+msgid "Unable to load range of 3D raster map <%s>"
+msgstr ""
+#: ../lib/python/temporal/mapcalc.py:109
+msgid "Starting spatio-temporal sampling..."
+msgstr ""
+#: ../lib/python/temporal/mapcalc.py:111
+msgid "Starting temporal sampling..."
+msgstr ""
+#: ../lib/python/temporal/mapcalc.py:128
+msgid "No samples found for map calculation"
+msgstr ""
+#: ../lib/python/temporal/mapcalc.py:155
+msgid "Found more than a single map in a sample granule. Only the first map is used for computation. Use t.rast.aggregate.ds to create synchronous raster datasets."
+msgstr ""
+#: ../lib/python/temporal/mapcalc.py:173
+msgid "No maps registered in input dataset"
+msgstr ""
+#: ../lib/python/temporal/mapcalc.py:189
+msgid "Starting mapcalc computation..."
+msgstr ""
+#: ../lib/python/temporal/mapcalc.py:259
+#, python-format
+msgid "Apply mapcalc expression: \"%s\""
+msgstr ""
+#: ../lib/python/temporal/mapcalc.py:278
+msgid "Error while mapcalc computation"
+msgstr ""
+#: ../lib/python/temporal/mapcalc.py:284
+msgid "Starting map registration in temporal database..."
+msgstr ""
+#: ../lib/python/temporal/mapcalc.py:323
+msgid "Removing {}/{} ({}%) maps because empty..."
+msgstr ""
+#: ../lib/python/temporal/mapcalc.py:441 ../lib/python/temporal/mapcalc.py:447
+#: ../lib/python/temporal/mapcalc.py:453 ../lib/python/temporal/mapcalc.py:459
+#: ../lib/python/temporal/mapcalc.py:465 ../lib/python/temporal/mapcalc.py:471
+#: ../lib/python/temporal/mapcalc.py:477 ../lib/python/temporal/mapcalc.py:483
+#: ../lib/python/temporal/mapcalc.py:489 ../lib/python/temporal/mapcalc.py:524
+#: ../lib/python/temporal/mapcalc.py:533 ../lib/python/temporal/mapcalc.py:542
+#: ../lib/python/temporal/mapcalc.py:551 ../lib/python/temporal/mapcalc.py:560
+#: ../lib/python/temporal/mapcalc.py:569 ../lib/python/temporal/mapcalc.py:578
+#: ../lib/python/temporal/mapcalc.py:587 ../lib/python/temporal/mapcalc.py:596
+#, python-format
+msgid "The temporal operators <%s> support only absolute time."
+msgstr ""
+#: ../lib/python/temporal/aggregation.py:127
+#, python-format
+msgid "Aggregating %s raster maps"
+msgstr ""
+#: ../lib/python/temporal/aggregation.py:141
+#, python-format
+msgid "Raster map <%(name)s> is already in temporal database, use overwrite flag to overwrite"
+msgstr ""
+#: ../lib/python/temporal/aggregation.py:146
+#, python-format
+msgid "Computing aggregation of maps between %(st)s - %(end)s"
+msgstr ""
+#: ../lib/python/temporal/aggregation.py:171
+msgid "Error occurred in r.series computation"
+msgstr ""
+#: ../lib/python/temporal/aggregation.py:280
+#, python-format
+msgid "Aggregating %(len)i raster maps from %(start)s to %(end)s"
+msgstr ""
+#: ../lib/python/temporal/aggregation.py:301
+#, python-format
+msgid "Unable to perform aggregation. Output raster map <%(name)s> exists and overwrite flag was not set"
+msgstr ""
+#: ../lib/python/temporal/aggregation.py:319
+#, python-format
+msgid "The limit of open files (%i) was reached (%i). The module r.series will be run with flag z, to avoid open files limit exceeding."
+msgstr ""
+#: ../lib/python/temporal/temporal_raster_base_algebra.py:690
+#, python-format
+msgid "Error computing map <%s>"
+msgstr ""
+#: ../lib/python/temporal/temporal_raster_base_algebra.py:777
+#: ../lib/python/temporal/temporal_algebra.py:2395
+#, python-format
+msgid "%s map <%s> not found in GRASS spatial database"
+msgstr ""
+#: ../lib/python/temporal/sampling.py:95 ../lib/python/temporal/sampling.py:100
+#, python-format
+msgid "Dataset <%s> not found in temporal database"
+msgstr ""
+#: ../lib/python/temporal/extract.py:60
+msgid "You need to specify the base name of new created maps"
+msgstr ""
+#: ../lib/python/temporal/extract.py:138
+#, python-format
+msgid "Applying r.mapcalc expression: \"%s\""
+msgstr ""
+#: ../lib/python/temporal/extract.py:143
+#, python-format
+msgid "Applying r3.mapcalc expression: \"%s\""
+msgstr ""
+#: ../lib/python/temporal/extract.py:148
+#, python-format
+msgid "Applying v.extract where statement: \"%s\""
+msgstr ""
+#: ../lib/python/temporal/extract.py:176
+msgid "Error in computation process"
+msgstr ""
+#: ../lib/python/temporal/temporal_granularity.py:1054
+#: ../lib/python/temporal/temporal_granularity.py:1096
+msgid "Output granularity seems not to be valid. Please use one of the following values : {gr}"
+msgstr ""
+#: ../lib/python/temporal/temporal_granularity.py:1058
+#: ../lib/python/temporal/temporal_granularity.py:1099
+#: ../lib/python/temporal/temporal_granularity.py:1172
+msgid "Invalid absolute granularity"
+msgstr ""
+#: ../lib/python/temporal/temporal_granularity.py:1169
+msgid "Probably you need to invert 'from_gran' and 'to_gran'"
+msgstr ""
+#: ../lib/python/temporal/list_stds.py:208
+msgid "Empty map list"
+msgstr ""
+#: ../lib/python/temporal/list_stds.py:219
+msgid "Empty entry in map list, this should not happen"
+msgstr ""
+#: ../lib/python/temporal/temporal_algebra.py:815
+msgid "Spatio-temporal topological operators are not supported in granularity algebra mode"
+msgstr ""
+#: ../lib/python/temporal/temporal_algebra.py:853
+msgid "All input space time datasets must have a valid temporal topology."
+msgstr ""
+#: ../lib/python/temporal/temporal_algebra.py:862
+msgid "All input space time datasets must have the same temporal type."
+msgstr ""
+#: ../lib/python/temporal/temporal_algebra.py:1113
+#, python-format
+msgid "Removing un-needed or empty %s maps"
+msgstr ""
+#: ../lib/python/temporal/temporal_algebra.py:1168
+#, python-format
+msgid "Space time %s dataset <%s> not found"
+msgstr ""
+#: ../lib/python/temporal/temporal_algebra.py:1196
+#: ../lib/python/temporal/temporal_algebra.py:1200
+#, python-format
+msgid "Wrong temporal type of space time dataset <%s> <%s> time is required"
+msgstr ""
+#: ../lib/python/temporal/temporal_algebra.py:1220
+msgid "Wrong type of input "
+msgstr ""
+#: ../lib/python/temporal/temporal_algebra.py:2186
+#, python-format
+msgid "The resulting space time dataset type <%(a)s> is different from the requested type <%(b)s>"
+msgstr ""
+#: ../lib/python/temporal/temporal_algebra.py:2192
+msgid "Maps that should be registered in the resulting space time dataset have different types."
+msgstr ""
+#: ../lib/python/temporal/temporal_algebra.py:2401
+msgid "Wrong map type. TMAP only supports single maps that are registered in the temporal GRASS database"
+msgstr ""
+#: ../lib/python/temporal/temporal_algebra.py:2429
+msgid "Merging empty map lists"
+msgstr ""
+#: ../lib/python/temporal/temporal_algebra.py:2432
+msgid "First Map list is empty, can't merge it. Return only last map list"
+msgstr ""
+#: ../lib/python/temporal/temporal_algebra.py:2435
+msgid "Second Map list is empty, can't merge it. Return only first map list"
+msgstr ""
+#: ../lib/python/temporal/temporal_algebra.py:2443
+msgid "Space time datasets to merge must have the same temporal type"
+msgstr ""
+#: ../lib/python/temporal/spatial_extent.py:123
+msgid "Projections are different. Unable to compute overlapping_2d for spatial extents"
+msgstr ""
+#: ../lib/python/temporal/spatial_extent.py:529
+msgid "Projections are different. Unable to compute is_in_2d for spatial extents"
+msgstr ""
+#: ../lib/python/temporal/spatial_extent.py:661
+msgid "Projections are different. Unable to compute equivalent_2d for spatial extents"
+msgstr ""
+#: ../lib/python/temporal/spatial_extent.py:766
+msgid "Projections are different. Unable to compute cover_2d for spatial extents"
+msgstr ""
+#: ../lib/python/temporal/spatial_extent.py:838
+msgid "Projections are different. Unable to compute cover for spatial extents"
+msgstr ""
+#: ../lib/python/temporal/spatial_extent.py:1690
+msgid "Volume computation is not supported for LL projections"
+msgstr ""
+#: ../lib/python/temporal/spatial_extent.py:1708
+msgid "Area computation is not supported for LL projections"
+msgstr ""
+#: ../lib/python/temporal/gui_support.py:58 ../lib/python/script/core.py:1298
+#, python-format
+msgid "Invalid element '%s'"
+msgstr ""
+#: ../lib/python/temporal/univar_statistics.py:62
+#: ../lib/python/temporal/univar_statistics.py:178
+#, python-format
+msgid "Space time %(sp)s dataset <%(i)s> is empty"
+msgstr ""
+#: ../lib/python/temporal/univar_statistics.py:101
+#, python-format
+msgid "Unable to get statistics for raster map <%s>"
+msgstr ""
+#: ../lib/python/temporal/univar_statistics.py:104
+#, python-format
+msgid "Unable to get statistics for 3d raster map <%s>"
+msgstr ""
+#: ../lib/python/temporal/univar_statistics.py:168
+#, python-format
+msgid "Space time %(sp)s dataset <%(i)s> not found"
+msgstr ""
+#: ../lib/python/temporal/univar_statistics.py:222
+#, python-format
+msgid "Unable to get statistics for vector map <%s>"
+msgstr ""
+#: ../lib/python/temporal/base.py:380
+msgid "Object not found in the temporal database"
+msgstr ""
+#: ../lib/python/temporal/base.py:462 ../lib/python/temporal/base.py:513
+msgid "Missing identifier"
+msgstr ""
+#: ../lib/python/temporal/base.py:621
+msgid "Wrong identifier, the mapset is missing"
+msgstr ""
+#: ../lib/python/temporal/space_time_datasets.py:251
+#, python-format
+msgid "Unable to read timestamp file for raster map <%s>"
+msgstr ""
+#: ../lib/python/temporal/space_time_datasets.py:275
+#, python-format
+msgid "Unable to create timestamp file for raster map <%s>"
+msgstr ""
+#: ../lib/python/temporal/space_time_datasets.py:280
+#, python-format
+msgid "Invalid datetime in timestamp for raster map <%s>"
+msgstr ""
+#: ../lib/python/temporal/space_time_datasets.py:285
+#: ../lib/python/temporal/space_time_datasets.py:633
+msgid "Internal error"
+msgstr ""
+#: ../lib/python/temporal/space_time_datasets.py:302
+#: ../lib/python/temporal/space_time_datasets.py:647
+#, python-format
+msgid "Unable to remove timestamp for raster map <%s>"
+msgstr ""
+#: ../lib/python/temporal/space_time_datasets.py:599
+#, python-format
+msgid "Unable to read timestamp file for 3D raster map <%s>"
+msgstr ""
+#: ../lib/python/temporal/space_time_datasets.py:623
+#, python-format
+msgid "Unable to create timestamp file for 3D raster map <%s>"
+msgstr ""
+#: ../lib/python/temporal/space_time_datasets.py:628
+#, python-format
+msgid "Invalid datetime in timestamp for 3D raster map <%s>"
+msgstr ""
+#: ../lib/python/temporal/space_time_datasets.py:907
+#, python-format
+msgid "Unable to read timestamp file for vector map <%s>"
+msgstr ""
+#: ../lib/python/temporal/space_time_datasets.py:930
+#, python-format
+msgid "Unable to create timestamp file for vector map <%s>"
+msgstr ""
+#: ../lib/python/temporal/space_time_datasets.py:935
+#, python-format
+msgid "Invalid datetime in timestamp for vector map <%s>"
+msgstr ""
+#: ../lib/python/temporal/space_time_datasets.py:951
+#, python-format
+msgid "Unable to remove timestamp for vector map <%s>"
+msgstr ""
+#: ../lib/python/temporal/temporal_vector_algebra.py:386
+#, python-format
+msgid "Error vector maps with basename %s exist. Use --o flag to overwrite existing file"
+msgstr ""
+#: ../lib/python/temporal/temporal_vector_algebra.py:419
+#, python-format
+msgid ""
+"Error starting %s : \n"
+"%s"
+msgstr ""
+#: ../lib/python/temporal/temporal_vector_algebra.py:492
+#, python-format
+msgid ""
+"Error vector map %s exist in temporal database. Use overwrite flag. : \n"
+"%s"
+msgstr ""
+#: ../lib/python/temporal/core.py:603
+msgid "Unable to initialize the temporal DBMI interface. Please use t.connect to specify the driver and the database string"
+msgstr ""
+#: ../lib/python/temporal/core.py:672
+#, python-format
+msgid ""
+"Unable to receive temporal database metadata.\n"
+"Current temporal database info:%(info)s"
+msgstr ""
+#: ../lib/python/temporal/core.py:677
+#, python-format
+msgid ""
+"Unsupported temporal database: version mismatch.\n"
+" %(backup)s Supported temporal API version is: %(api)i.\n"
+"Please update your GRASS GIS installation.\n"
+msgstr ""
+#: ../lib/python/temporal/core.py:685
+#, python-format
+msgid ""
+" %(backup)sSupported temporal database version is: %(tdb)i\n"
+msgstr ""
+#: ../lib/python/temporal/core.py:773
+#, python-format
+msgid "Creating temporal database: %s"
+msgstr ""
+#: ../lib/python/temporal/core.py:782
+#, python-format
+msgid ""
+"Unable to create SQLite temporal database\n"
+"Exception: %s\n"
+"Please use t.connect to set a read- and writable temporal database path"
+msgstr ""
+#: ../lib/python/temporal/core.py:947
+msgid "Unable to mogrify sql statement. "
+msgstr ""
+#: ../lib/python/temporal/core.py:969
+msgid "Unable to check table. "
+msgstr ""
+#: ../lib/python/temporal/core.py:985
+msgid "Unable to execute sql statement. "
+msgstr ""
+#: ../lib/python/temporal/core.py:995
+msgid "Unable to fetch one. "
+msgstr ""
+#: ../lib/python/temporal/core.py:1005
+msgid "Unable to fetch all. "
+msgstr ""
+#: ../lib/python/temporal/core.py:1022
+msgid "Unable to execute transaction. "
+msgstr ""
+#: ../lib/python/temporal/core.py:1126
+#, python-format
+msgid ""
+"Unable to connect to %(db)s database: %(string)s\n"
+"Exception: \"%(ex)s\"\n"
+"Please use t.connect to set a read- and writable temporal database backend"
+msgstr ""
+#: ../lib/python/temporal/core.py:1286
+#, python-format
+msgid ""
+"Unable to execute :\n"
+" %(sql)s"
+msgstr ""
+#: ../lib/python/temporal/core.py:1330
+#, python-format
+msgid ""
+"Unable to execute transaction:\n"
+" %(sql)s"
+msgstr ""
+#: ../lib/python/gunittest/gmodules.py:103
+msgid "input='-' must be used when stdin is specified"
+msgstr ""
+#: ../lib/python/gunittest/gmodules.py:105
+msgid "stdin must be string or buffer, not PIPE"
+msgstr ""
+#: ../lib/python/gunittest/gmodules.py:108
+msgid "stdin must be used when input='-'"
+msgstr ""
+#: ../lib/python/gunittest/gmodules.py:110
+msgid "You cannot merge stdout and stderr and not capture them"
+msgstr ""
+#: ../lib/python/gunittest/gmodules.py:112
+msgid "stdout argument not allowed, it could be overridden"
+msgstr ""
+#: ../lib/python/gunittest/gmodules.py:114
+msgid "stderr argument not allowed, it could be overridden"
+msgstr ""
+#: ../lib/python/exceptions/__init__.py:68
+#, python-format
+msgid "Module run %s %s ended with error"
+msgstr ""
+#: ../lib/python/exceptions/__init__.py:69
+#, python-format
+msgid ""
+"\n"
+"Process ended with non-zero return code %s"
+msgstr ""
+#: ../lib/python/exceptions/__init__.py:71
+#, python-format
+msgid ""
+". See the following errors:\n"
+"%s"
+msgstr ""
+#: ../lib/python/exceptions/__init__.py:75
+msgid ". See errors in the (error) output."
+msgstr ""
+#: ../lib/python/script/array.py:157 ../lib/python/script/array.py:207
+#: ../lib/python/script/array.py:254 ../lib/python/script/array.py:305
+#: ../lib/python/script/array.py:356 ../lib/python/script/array.py:398
+#, python-format
+msgid "Invalid kind <%s>"
+msgstr ""
+#: ../lib/python/script/array.py:160 ../lib/python/script/array.py:210
+#: ../lib/python/script/array.py:308 ../lib/python/script/array.py:359
+#, python-format
+msgid "Invalid size <%d>"
+msgstr ""
+#: ../lib/python/script/array.py:197
+msgid "grass.script.array.read is deprecated and does not work on MS Windows, pass raster name in the constructor"
+msgstr ""
+#: ../lib/python/script/array.py:247 ../lib/python/script/array.py:392
+#, python-format
+msgid "Invalid FP size <%d>"
+msgstr ""
+#: ../lib/python/script/array.py:251 ../lib/python/script/array.py:395
+#, python-format
+msgid "Invalid integer size <%d>"
+msgstr ""
+#: ../lib/python/script/array.py:346
+msgid "grass.script.array3d.read is deprecated and does not work on MS Windows, pass 3D raster name in the constructor"
+msgstr ""
+#: ../lib/python/script/db.py:45 ../lib/db/dbmi_client/column.c:136
+#: ../lib/vector/Vlib/write_pg.c:666 ../lib/vector/Vlib/ascii.c:428
+msgid "Unable to describe table <%s>"
+msgstr ""
+#: ../lib/python/script/db.py:153
+#, python-format
+msgid "Programmer error: '%(sql)s', '%(filename)s', or '%(table)s' must be provided"
+msgstr ""
+#: ../lib/python/script/db.py:163
+msgid "Fetching data failed"
+msgstr ""
+#: ../lib/python/script/vector.py:88
+#, python-format
+msgid "Database connection not defined for layer %s"
+msgstr ""
+#: ../lib/python/script/vector.py:230
+#, python-format
+msgid "Missing layer %(layer)d in vector map <%(map)s>"
+msgstr ""
+#: ../lib/python/script/vector.py:245
+msgid "vector_db_select() failed"
+msgstr ""
+#: ../lib/python/script/vector.py:353
+msgid "Number of given vector maps ({m}) differs from number of layers ({l})"
+msgstr ""
+#: ../lib/python/script/vector.py:415
+msgid ""
+"v.what output is not valid JSON format:\n"
+" {ret}"
+msgstr ""
+#: ../lib/python/script/raster.py:51
+#, python-format
+msgid "Unable to write history for <%(map)s>. Raster map <%(map)s> not found in current mapset."
+msgstr ""
+#: ../lib/python/script/raster.py:110
+#, python-format
+msgid "An error occurred while running r.mapcalc with expression: %s"
+msgstr ""
+#: ../lib/python/script/raster.py:189
+msgid "No data"
+msgstr ""
+#: ../lib/python/script/raster.py:197
+msgid "value"
+msgstr ""
+msgid "label"
+msgstr ""
+msgid "color"
+msgstr ""
+#: ../lib/python/script/raster3d.py:92
+#, python-format
+msgid "An error occurred while running r3.mapcalc with expression: %s"
+msgstr ""
+#: ../lib/python/script/core.py:67
+msgid "Cannot find the executable {0}"
+msgstr ""
+#: ../lib/python/script/core.py:307
+#, python-format
+msgid "To run the module <%s> add underscore at the end of the option <%s> to avoid conflict with Python keywords. Underscore at the beginning is depreciated in GRASS GIS 7.0 and will be removed in version 7.1."
+msgstr ""
+#: ../lib/python/script/core.py:987
+msgid "Mixing value types. Will try to compare after integer conversion"
+msgstr ""
+#: ../lib/python/script/core.py:1188
+#, python-format
+msgid "Element type should be \"cell\" and not \"%s\""
+msgstr ""
+#: ../lib/python/script/core.py:1217 ../lib/python/script/core.py:1282
+#, python-format
+msgid "Element type should be \"raster\" and not \"%s\""
+msgstr ""
+#: ../lib/python/script/core.py:1437
+msgid "Unable to list mapsets"
+msgstr ""
+#: ../lib/python/script/core.py:1476
+#, python-format
+msgid "Location <%s> already exists. Operation canceled."
+msgstr ""
+#: ../lib/python/script/core.py:1479
+#, python-format
+msgid "Location <%s> already exists and will be overwritten"
+msgstr ""
+#: ../lib/python/script/core.py:1603
+msgid "Debug level {0}"
+msgstr ""
+#: ../lib/python/script/core.py:1606
+msgid "WARNING: Ignoring unsupported debug level (must be >=0 and <=5). {0}\n"
+msgstr ""
+#: ../lib/python/script/core.py:1622
+#, python-format
+msgid "Illegal filename <%s>. Cannot be 'NULL' or start with '.'."
+msgstr ""
+#: ../lib/python/script/core.py:1631
+#, python-format
+msgid "Illegal filename <%(s)s>. <%(il)s> not allowed.\n"
+msgstr ""
+#: ../lib/python/script/task.py:58
+msgid "unknown"
+msgstr ""
+#: ../lib/python/script/task.py:169
+#, python-format
+msgid "Parameter element '%(element)s' not found: '%(value)s'"
+msgstr ""
+#: ../lib/python/script/task.py:184
+#, python-format
+msgid "Flag not found: %s"
+msgstr ""
+#: ../lib/python/script/task.py:203
+#, python-format
+msgid "Parameter '%(name)s' (%(desc)s) is missing."
+msgstr ""
+#: ../lib/python/script/task.py:236
+msgid "<required>"
+msgstr ""
+#: ../lib/python/script/task.py:496 ../lib/python/script/task.py:500
+#, python-format
+msgid ""
+"Unable to fetch interface description for command '%(cmd)s'.\n"
+"\n"
+"Details: %(det)s"
+msgstr ""
+#: ../lib/python/script/task.py:523
+msgid "Cannot parse interface description of<{name}> module: {error}"
+msgstr ""
+#: ../lib/python/pygrass/modules/grid/grid.py:553
+msgid "Execution of subprocesses was not successful"
+msgstr ""
+#: ../lib/python/pygrass/raster/category.py:69
+msgid "Raster type: {0} not supported"
+msgstr ""
+#: ../lib/python/pygrass/raster/category.py:156
+msgid "Error executing: Rast_get_ith_cat"
+msgstr ""
+#: ../lib/python/pygrass/raster/category.py:184
+msgid "Null value detected"
+msgstr ""
+#: ../lib/python/pygrass/raster/category.py:186
+msgid "Error executing: Rast_set_cat"
+msgstr ""
+#: ../lib/python/pygrass/raster/abstract.py:274
+msgid "Mode type: {0} not supported ('r', 'w')"
+msgstr ""
+#: ../lib/python/pygrass/raster/abstract.py:285
+msgid "Overwrite type: {0} not supported (True/False)"
+msgstr ""
+#: ../lib/python/pygrass/raster/abstract.py:298
+#: ../lib/python/pygrass/vector/abstract.py:97
+msgid "Map name {0} not valid"
+msgstr ""
+#: ../lib/python/pygrass/raster/__init__.py:209
+msgid "The map does not exist, I can't open in 'r' mode"
+msgstr ""
+#: ../lib/python/pygrass/raster/__init__.py:214
+msgid "Raster map <{0}> already exists and will be not overwritten"
+msgstr ""
+#: ../lib/python/pygrass/raster/__init__.py:218
+msgid "Raster type not defined"
+msgstr ""
+#: ../lib/python/pygrass/raster/__init__.py:321
+msgid "Mode type: {0} not supported ('r', 'w','rw')"
+msgstr ""
+#: ../lib/python/pygrass/raster/__init__.py:341
+#, python-format
+msgid "Index out of range: %r."
+msgstr ""
+#: ../lib/python/pygrass/raster/__init__.py:530
+msgid "Raster map <{0}> already exists. Use overwrite."
+msgstr ""
+#: ../lib/python/pygrass/raster/__init__.py:561
+msgid "Raster map <{0}> does not exist"
+msgstr ""
+#: ../lib/python/pygrass/errors.py:18
+msgid "The map is close!"
+msgstr ""
+#: ../lib/python/pygrass/errors.py:29
+msgid "The self.c_mapinfo pointer must be correctly initiated"
+msgstr ""
+#: ../lib/python/pygrass/utils.py:277
+msgid "Vector doesn't contain points"
+msgstr ""
+#: ../lib/python/pygrass/vector/table.py:1033
+#, python-format
+msgid "Deleting table <%s> which is attached to following map(s):"
+msgstr ""
+#: ../lib/python/pygrass/vector/table.py:1037
+msgid "You must use the force flag to actually remove it. Exiting."
+msgstr ""
+#: ../lib/python/pygrass/vector/__init__.py:806
+#, python-format
+msgid "Unable to read line of feature %i"
+msgstr ""
+#: ../lib/python/pygrass/vector/__init__.py:895
+#, python-format
+msgid "Unable to read area with id %i"
+msgstr ""
+#: ../lib/raster3d/test/test_main.c:96
+msgid "raster3d"
+msgstr ""
+#: ../lib/raster3d/test/test_main.c:97
+msgid "unit test"
+msgstr ""
+#: ../lib/raster3d/range.c:73
+#, c-format
+msgid "Unable to open range file for [%s in %s]"
+msgstr ""
+#: ../lib/raster3d/range.c:88
+#, c-format
+msgid "Error reading range file for [%s in %s]"
+msgstr ""
+#: ../lib/raster3d/range.c:150
+#, c-format
+msgid "Unable to open range file for <%s>"
+msgstr ""
+#: ../lib/raster3d/open.c:20
+msgid "Rast3d_open_cell_old_no_header: error in Rast3d_mask_open_old"
+msgstr ""
+#: ../lib/raster3d/open.c:26
+msgid "Rast3d_open_cell_old_no_header: error in Rast3d_malloc"
+msgstr ""
+#: ../lib/raster3d/open.c:37
+msgid "Rast3d_open_cell_old_no_header: error in G_open_old"
+msgstr ""
+#: ../lib/raster3d/open.c:93
+msgid "Rast3d_open_cell_old: error in Rast3d_open_cell_old_no_header"
+msgstr ""
+#: ../lib/raster3d/open.c:98
+msgid "Rast3d_open_cell_old: can't rewind file"
+msgstr ""
+#: ../lib/raster3d/open.c:111
+msgid "Rast3d_open_cell_old: error in Rast3d_read_header"
+msgstr ""
+#: ../lib/raster3d/open.c:119
+msgid "Rast3d_open_cell_old: projection does not match window projection"
+msgstr ""
+#: ../lib/raster3d/open.c:123
+msgid "Rast3d_open_cell_old: zone does not match window zone"
+msgstr ""
+#: ../lib/raster3d/open.c:135 ../lib/raster3d/open.c:152
+msgid "Rast3d_open_cell_old: can't read header"
+msgstr ""
+#: ../lib/raster3d/open.c:141
+msgid "Rast3d_open_cell_old: index does not fit into long"
+msgstr ""
+#: ../lib/raster3d/open.c:145
+msgid "Rast3d_open_cell_old: error in Rast3d_malloc"
+msgstr ""
+#: ../lib/raster3d/open.c:172
+msgid "Rast3d_open_cell_old: error in Rast3d_fill_header"
+msgstr ""
+#: ../lib/raster3d/open.c:219
+msgid "Rast3d_open_cell_new: error in Rast3d_mask_open_old"
+msgstr ""
+#: ../lib/raster3d/open.c:228
+msgid "Rast3d_open_cell_new: error in Rast3d_malloc"
+msgstr ""
+#: ../lib/raster3d/open.c:233
+#, c-format
+msgid "map <%s> is not in the current mapset"
+msgstr ""
+#: ../lib/raster3d/open.c:243
+msgid "Rast3d_open_cell_new: could not open file"
+msgstr ""
+#: ../lib/raster3d/open.c:287 ../lib/raster3d/open.c:292
+msgid "Rast3d_open_cell_new: can't write header"
+msgstr ""
+#: ../lib/raster3d/open.c:314
+msgid "Rast3d_open_cell_new: error in Rast3d_fill_header"
+msgstr ""
+#: ../lib/raster3d/param.c:84
+msgid "Rast3d_get_standard3d_params: precision value invalid"
+msgstr ""
+#: ../lib/raster3d/param.c:105
+msgid "Rast3d_get_standard3d_params: tile dimension value invalid"
+msgstr ""
+#: ../lib/raster3d/param.c:129
+msgid "Window replacing the default"
+msgstr ""
+#: ../lib/raster3d/maskfn.c:77
+#, c-format
+msgid "Adding rule: %lf - %lf"
+msgstr ""
+#: ../lib/raster3d/maskfn.c:95
+#, c-format
+msgid "%s: illegal value spec"
+msgstr ""
+#: ../lib/raster3d/header.c:217 ../lib/raster3d/close.c:99
+#: ../lib/raster3d/close.c:105 ../lib/raster3d/close.c:191
+#, c-format
+msgid "Unable to write header for 3D raster map <%s>"
+msgstr ""
+#: ../lib/raster3d/close.c:47
+#, c-format
+msgid "Unable to write history for 3D raster map <%s>"
+msgstr ""
+#: ../lib/raster3d/close.c:62
+#, c-format
+msgid "Unable to move temp raster map <%s> to 3D raster map <%s>"
+msgstr ""
+#: ../lib/raster3d/close.c:79
+msgid "Unable to flush all tiles"
+msgstr ""
+#: ../lib/raster3d/close.c:84
+msgid "Unable to flush index"
+msgstr ""
+#: ../lib/raster3d/close.c:94
+msgid "Unable to position file"
+msgstr ""
+#: ../lib/raster3d/close.c:110 ../lib/raster3d/close.c:153
+#, c-format
+msgid "Unable to create 3D raster map <%s>"
+msgstr ""
+#: ../lib/raster3d/close.c:169
+msgid "Error in cache"
+msgstr ""
+#: ../lib/raster3d/history.c:43
+#, c-format
+msgid "can't get history information for [%s] in mapset [%s]"
+msgstr ""
+#: ../lib/raster3d/color.c:354
+#, c-format
+msgid "mapset <%s> is not the current mapset"
+msgstr ""
+#: ../lib/cluster/c_exec.c:44
+#, c-format
+msgid "Not enough data points (%d) in cluster"
+msgstr ""
+#: ../lib/cluster/c_begin.c:57
+#, c-format
+msgid "produced by i.cluster"
+msgstr ""
+#: ../lib/pngdriver/graph_set.c:101
+#, c-format
+msgid "png: truecolor status %s"
+msgstr ""
+#: ../lib/pngdriver/graph_set.c:149
+#, c-format
+msgid "png: collecting to file '%s'"
+msgstr ""
+#: ../lib/pngdriver/graph_set.c:150
+#, c-format
+msgid "png: image size %dx%d"
+msgstr ""
+#: ../lib/pngdriver/read_png.c:42
+msgid "Unable to read PNG"
+msgstr ""
+#: ../lib/pngdriver/read_png.c:60
+msgid "Unable allocate PNG structure"
+msgstr ""
+#: ../lib/pngdriver/read_png.c:64 ../lib/pngdriver/write_png.c:71
+#: ../lib/pngdriver/write_png.c:75
+msgid "Unable to allocate PNG structure"
+msgstr ""
+#: ../lib/pngdriver/read_png.c:67
+msgid "Unable to read PNG file"
+msgstr ""
+#: ../lib/pngdriver/read_png.c:81
+msgid "Input PNG file is not 8-bit"
+msgstr ""
+#: ../lib/pngdriver/read_png.c:85
+#, c-format
+msgid "Input PNG file has incorrect dimensions: expected: %dx%d got: %lux%lu"
+msgstr ""
+#: ../lib/pngdriver/read_png.c:90
+msgid "Input PNG file is not RGBA"
+msgstr ""
+#: ../lib/pngdriver/read_png.c:94
+msgid "Input PNG file is not indexed color"
+msgstr ""
+#: ../lib/pngdriver/read_png.c:104
+msgid "Input PNG file has invalid palette"
+msgstr ""
+#: ../lib/pngdriver/write_png.c:39
+msgid "Unable to write PNG"
+msgstr ""
+#: ../lib/pngdriver/write_png.c:78
+msgid "Unable to write PNG file"
+msgstr ""
+#: ../lib/pngdriver/write_png.c:82
+#, c-format
+msgid "Unable to open output PNG file <%s>"
+msgstr ""
+#: ../lib/symbol/read.c:211
+#, c-format
+msgid "Cannot read symbol line coordinates: %s"
+msgstr ""
+#: ../lib/symbol/read.c:260
+#, c-format
+msgid "Incorrect symbol name: '%s' (should be: group/name or group/name at mapset)"
+msgstr ""
+#: ../lib/symbol/read.c:284
+#, c-format
+msgid "Cannot find/open symbol: '%s'"
+msgstr ""
+#: ../lib/symbol/read.c:393 ../lib/symbol/read.c:411 ../lib/symbol/read.c:421
+#: ../lib/symbol/read.c:439
+#, c-format
+msgid "Incorrect symbol color: '%s', using default."
+msgstr ""
+#: ../lib/imagery/iclass_signatures.c:120
+#, c-format
+msgid "Unable to open output signature file '%s'"
+msgstr ""
+#: ../lib/imagery/iclass_perimeter.c:109
+#, c-format
+msgid "Get area %d failed"
+msgstr ""
+#: ../lib/imagery/iclass_perimeter.c:116
+msgid "Perimeter computation failed"
+msgstr ""
+#: ../lib/imagery/iclass_perimeter.c:208
+msgid "Absurd polygon."
+msgstr ""
+#: ../lib/imagery/iclass_perimeter.c:253
+msgid "Outlined area is too large."
+msgstr ""
+#: ../lib/imagery/iclass.c:83
+#, c-format
+msgid "No areas in category %d"
+msgstr ""
+#: ../lib/imagery/iclass.c:127
+#, c-format
+msgid "Raster map <%s@%s> in subgroup <%s> does not exist"
+msgstr ""
+#: ../lib/imagery/iclass.c:131
+#, c-format
+msgid "Raster map <%s@%s> in group <%s> does not exist"
+msgstr ""
+#: ../lib/imagery/iclass.c:143
+#, c-format
+msgid "Subgroup <%s> does not have enough files (it has %d files)"
+msgstr ""
+#: ../lib/imagery/iclass.c:147
+#, c-format
+msgid "Group <%s> does not have enough files (it has %d files)"
+msgstr ""
+#: ../lib/imagery/fopen.c:23
+#, c-format
+msgid "Unable to create file [%s] of group [%s in %s]"
+msgstr ""
+#: ../lib/imagery/fopen.c:36 ../lib/imagery/fopen.c:57
+#, c-format
+msgid "Unable to open file [%s] of group [%s in %s]"
+msgstr ""
+#: ../lib/imagery/fopen.c:49
+#, c-format
+msgid "Unable to find file [%s] of group [%s in %s]"
+msgstr ""
+#: ../lib/imagery/fopen.c:79
+#, c-format
+msgid "Unable to create file [%s] for subgroup [%s] of group [%s in %s]"
+msgstr ""
+#: ../lib/imagery/fopen.c:101 ../lib/imagery/fopen.c:127
+#, c-format
+msgid "Unable to open file [%s] for subgroup [%s] of group [%s in %s]"
+msgstr ""
+#: ../lib/imagery/fopen.c:116
+#, c-format
+msgid "Unable to find file [%s] for subgroup [%s] of group [%s in %s]"
+msgstr ""
+#: ../lib/imagery/iscatt_core.c:81
+#, c-format
+msgid "Unable to write header into category raster condition file <%s>."
+msgstr ""
+#: ../lib/imagery/iscatt_core.c:98
+#, c-format
+msgid "Unable to write into category raster condition file <%s>."
+msgstr ""
+#: ../lib/imagery/iscatt_core.c:255
+#, c-format
+msgid "Unable to open category raster condtions file <%s>."
+msgstr ""
+#: ../lib/imagery/iscatt_core.c:263
+#, c-format
+msgid "Unable to find patch raster <%s>."
+msgstr ""
+#: ../lib/imagery/iscatt_core.c:280
+#, c-format
+msgid "Resolutions of patch <%s> and patched file <%s> are not same."
+msgstr ""
+#: ../lib/imagery/iscatt_core.c:307 ../lib/imagery/iscatt_core.c:349
+#, c-format
+msgid "Corrupted category raster conditions file <%s> (fseek failed)"
+msgstr ""
+#: ../lib/imagery/iscatt_core.c:338
+#, c-format
+msgid "Unable to write into category raster conditions file <%s>"
+msgstr ""
+#: ../lib/imagery/iscatt_core.c:526
+msgid "Unable to read from category raster condtition file."
+msgstr ""
+#: ../lib/imagery/iscatt_core.c:533
+msgid "Invalid size of category raster conditions file."
+msgstr ""
+#: ../lib/imagery/iscatt_core.c:579
+msgid "Data inconsistent. Value computed for scatter plot is out of initialized range."
+msgstr ""
+#: ../lib/imagery/iscatt_core.c:745
+#, c-format
+msgid "Unbale to read find raster <%s>"
+msgstr ""
+#: ../lib/imagery/iscatt_core.c:755
+#, c-format
+msgid "Unbale to open raster <%s>"
+msgstr ""
+#: ../lib/imagery/iscatt_core.c:761
+#, c-format
+msgid "Raster <%s> type is not <%s>"
+msgstr ""
+#: ../lib/imagery/iscatt_core.c:775
+#, c-format
+msgid "Unable to read range of raster <%s>"
+msgstr ""
+#: ../lib/imagery/iscatt_core.c:803
+#, c-format
+msgid "Unable to open category raster condtition file <%s>"
+msgstr ""
+#: ../lib/imagery/iscatt_core.c:817
+msgid "Corrupted category raster conditions file (fseek failed)"
+msgstr ""
+#: ../lib/imagery/iscatt_core.c:972 ../lib/imagery/iclass_statistics.c:227
+#, c-format
+msgid "prepare_signature: scan line %d has odd number of points."
+msgstr ""
+#: ../lib/imagery/iscatt_core.c:981 ../lib/imagery/iclass_statistics.c:237
+msgid "signature: perimeter points out of order."
+msgstr ""
+#: ../lib/imagery/iclass_statistics.c:218
+msgid "prepare_signature: outline has odd number of points."
+msgstr ""
+#: ../lib/imagery/iclass_statistics.c:248
+#, c-format
+msgid "Data error preparing signatures: value (%d) > num of cats (%d)"
+msgstr ""
+#: ../lib/imagery/iclass_statistics.c:561
+#: ../lib/imagery/iclass_statistics.c:584
+#: ../lib/imagery/iclass_statistics.c:607
+#: ../lib/imagery/iclass_statistics.c:630
+#: ../lib/imagery/iclass_statistics.c:653
+#: ../lib/imagery/iclass_statistics.c:680
+#: ../lib/imagery/iclass_statistics.c:712
+#: ../lib/imagery/iclass_statistics.c:735
+#: ../lib/imagery/iclass_statistics.c:758
+msgid "Band index out of range"
+msgstr "Sáv index tartományon kívül"
+#: ../lib/imagery/iclass_statistics.c:684
+msgid "Cell category value out of range"
+msgstr "Cella kategória érték tartományon kívül"
+#: ../lib/imagery/list_subgp.c:72
+#, c-format
+msgid "subgroup <%s> of group <%s> is empty\n"
+msgstr "<%s> alcsoport a <%s> csoportból üres\n"
+#: ../lib/imagery/list_subgp.c:85
+#, c-format
+msgid "subgroup <%s> of group <%s> references the following raster maps\n"
+msgstr ""
+#: ../lib/imagery/points.c:124
+#, c-format
+msgid "Unable to open control point file for group [%s in %s]"
+msgstr ""
+#: ../lib/imagery/points.c:132
+#, c-format
+msgid "Bad format in control point file for group [%s in %s]"
+msgstr ""
+#: ../lib/imagery/points.c:159
+#, c-format
+msgid "Unable to create control point file for group [%s in %s]"
+msgstr ""
+#: ../lib/imagery/georef_tps.c:219
+msgid "Calculating forward transformation coefficients"
+msgstr ""
+#: ../lib/imagery/georef_tps.c:236
+msgid "Calculating backward transformation coefficients"
+msgstr ""
+#: ../lib/imagery/georef_tps.c:279 ../lib/imagery/georef_tps.c:282
+#: ../lib/imagery/georef_tps.c:285 ../lib/imagery/georef_tps.c:290
+#: ../lib/imagery/georef_tps.c:293
+#, c-format
+msgid "%s: out of memory"
+msgstr ""
+#: ../lib/imagery/list_gp.c:34
+#, c-format
+msgid "group <%s> is empty\n"
+msgstr "<%s> csoport üres\n"
+#: ../lib/imagery/list_gp.c:44
+#, c-format
+msgid "group <%s> references the following raster maps\n"
+msgstr "<%s> csoport a következő raszter térképekre hivatkozik\n"
+#: ../lib/imagery/sigsetfile.c:41
+#, c-format
+msgid "Unable to create signature file <%s> for subgroup <%s> of group <%s> - <%s> is not current mapset"
+msgstr ""
+#: ../lib/imagery/sigsetfile.c:57
+#, c-format
+msgid "Unable to create signature file <%s> for subgroup <%s> of group <%s>"
+msgstr ""
+#: ../lib/imagery/target.c:38
+#, c-format
+msgid "Unable to read target file for group [%s]"
+msgstr ""
+#: ../lib/init/grass.py:123
+msgid "WARNING"
+msgstr ""
+#: ../lib/init/grass.py:187 ../lib/gis/parser.c:621
+msgid "ERROR"
+msgstr ""
+#: ../lib/init/grass.py:188
+msgid "Exiting..."
+msgstr ""
+#: ../lib/init/grass.py:332
+msgid "Usage"
+msgstr ""
+#: ../lib/init/grass.py:333 ../lib/gis/parser_html.c:141
+#: ../lib/gis/parser_rest.c:146
+msgid "Flags"
+msgstr ""
+#: ../lib/init/grass.py:334
+msgid "print this help message"
+msgstr ""
+#: ../lib/init/grass.py:335
+msgid "show version information and exit"
+msgstr ""
+#: ../lib/init/grass.py:336
+msgid "create given database, location or mapset if it doesn't exist"
+msgstr ""
+#: ../lib/init/grass.py:337
+msgid "exit after creation of location or mapset. Only with -c flag"
+msgstr ""
+#: ../lib/init/grass.py:338
+msgid "force removal of .gislock if exists (use with care!). Only with -text flag"
+msgstr ""
+#: ../lib/init/grass.py:339
+msgid "use text based interface (skip welcome screen)"
+msgstr ""
+#: ../lib/init/grass.py:340 ../lib/init/grass.py:342 ../lib/init/grass.py:344
+msgid "and set as default"
+msgstr ""
+#: ../lib/init/grass.py:341
+msgid "use text based interface (show welcome screen)"
+msgstr ""
+#: ../lib/init/grass.py:343
+msgid "use $DEFAULT_GUI graphical user interface"
+msgstr ""
+#: ../lib/init/grass.py:345
+msgid "print GRASS configuration parameters"
+msgstr ""
+#: ../lib/init/grass.py:346
+msgid "options: arch,build,compiler,path,revision,version"
+msgstr ""
+#: ../lib/init/grass.py:347 ../lib/gis/parser_html.c:189
+#: ../lib/gis/parser_rest.c:179
+msgid "Parameters"
+msgstr ""
+#: ../lib/init/grass.py:348
+msgid "initial GRASS GIS database directory"
+msgstr ""
+#: ../lib/init/grass.py:349
+msgid "directory containing Locations"
+msgstr ""
+#: ../lib/init/grass.py:350
+msgid "initial GRASS Location"
+msgstr ""
+#: ../lib/init/grass.py:351
+msgid "directory containing Mapsets with one common coordinate system (projection)"
+msgstr ""
+#: ../lib/init/grass.py:352
+msgid "initial GRASS Mapset"
+msgstr ""
+#: ../lib/init/grass.py:353
+msgid "fully qualified initial Mapset directory"
+msgstr ""
+#: ../lib/init/grass.py:354
+msgid "Environment variables relevant for startup"
+msgstr ""
+#: ../lib/init/grass.py:355
+msgid "select GUI (text, gui, gtext)"
+msgstr ""
+#: ../lib/init/grass.py:356
+msgid "set html web browser for help pages"
+msgstr ""
+#: ../lib/init/grass.py:357
+msgid "set additional path(s) to local GRASS modules or user scripts"
+msgstr ""
+#: ../lib/init/grass.py:358
+msgid "set additional GISBASE for locally installed GRASS Addons"
+msgstr ""
+#: ../lib/init/grass.py:359
+msgid "shell script to be processed as batch job"
+msgstr ""
+#: ../lib/init/grass.py:360
+msgid "set Python interpreter name to override 'python'"
+msgstr ""
+#: ../lib/init/grass.py:361
+msgid "execute GRASS module or script"
+msgstr ""
+#: ../lib/init/grass.py:362
+msgid "provided executable will be executed in GRASS session"
+msgstr ""
+#: ../lib/init/grass.py:363
+msgid "GRASS module, script or any other executable"
+msgstr ""
+#: ../lib/init/grass.py:364
+msgid "parameters of the executable"
+msgstr ""
+#: ../lib/init/grass.py:365
+msgid "standard flags"
+msgstr ""
+#: ../lib/init/grass.py:390
+msgid "The APPDATA variable is not set, ask your operating system support"
+msgstr ""
+#: ../lib/init/grass.py:393
+msgid "The APPDATA variable points to directory which does not exist, ask your operating system support"
+msgstr ""
+#: ../lib/init/grass.py:440
+#, python-format
+msgid "Unable to create temporary directory <grass7-%(user)s-%(lock)s>! Exiting."
+msgstr ""
+#: ../lib/init/grass.py:493
+msgid "Invalid line in RC file ({file}): '{line}' ({error})\n"
+msgstr ""
+#: ../lib/init/grass.py:547
+#, python-format
+msgid "GUI <%s> not supported in this version"
+msgstr ""
+#: ../lib/init/grass.py:704
+msgid "Searched for a web browser, but none found"
+msgstr ""
+#: ../lib/init/grass.py:743
+msgid ""
+"The python command does not work as expected!\n"
+"Please check your GRASS_PYTHON environment variable.\n"
+"Use the -help option for details.\n"
+msgstr ""
+#: ../lib/init/grass.py:747
+msgid "GRASS GUI not found. Please check your installation."
+msgstr ""
+#: ../lib/init/grass.py:749
+msgid ""
+"{}\n"
+"Switching to text based interface mode.\n"
+"\n"
+"Hit RETURN to continue.\n"
+msgstr ""
+#: ../lib/init/grass.py:758
+msgid ""
+"It appears that the X Windows system is not active.\n"
+"A graphical based user interface is not supported.\n"
+"(DISPLAY variable is not set.)\n"
+"\n"
+msgstr ""
+#: ../lib/init/grass.py:851 ../lib/gis/make_mapset.c:66
+#, c-format, python-format
+msgid "Location <%s> doesn't exist"
+msgstr ""
+#: ../lib/init/grass.py:853
+#, python-format
+msgid "<%s> is not a valid GRASS Location because PERMANENT Mapset is missing"
+msgstr ""
+#: ../lib/init/grass.py:856
+#, python-format
+msgid "<%s> is not a valid GRASS Location because PERMANENT is not a directory"
+msgstr ""
+#: ../lib/init/grass.py:861
+#, python-format
+msgid "<%s> is not a valid GRASS Location because PERMANENT Mapset does not have a DEFAULT_WIND file (default computational region)"
+msgstr ""
+#: ../lib/init/grass.py:866
+msgid "Mapset <{mapset}> doesn't exist in GRASS Location <{loc}>. A new mapset can be created by '-c' switch."
+msgstr ""
+#: ../lib/init/grass.py:870
+#, python-format
+msgid "<%s> is not a GRASS Mapset because it is not a directory"
+msgstr ""
+#: ../lib/init/grass.py:873
+#, python-format
+msgid "<%s> is not a valid GRASS Mapset because it does not have a WIND file"
+msgstr ""
+#: ../lib/init/grass.py:877
+#, python-format
+msgid "<%s> is not a valid GRASS Mapset because its WIND file is not readable"
+msgstr ""
+#: ../lib/init/grass.py:880
+msgid "Mapset <{mapset}> or Location <{location}> is invalid for an unknown reason"
+msgstr ""
+#: ../lib/init/grass.py:943
+#, python-format
+msgid "Failed to create new location. The location <%s> already exists."
+msgstr ""
+#: ../lib/init/grass.py:950
+msgid "Missing WIND file"
+msgstr ""
+#: ../lib/init/grass.py:968
+msgid ""
+"GISDBASE, LOCATION_NAME and MAPSET variables not set properly.\n"
+"Interactive startup needed."
+msgstr ""
+#: ../lib/init/grass.py:992
+#, python-format
+msgid "Invalid user interface specified - <%s>. Use the --help option to see valid interface names."
+msgstr ""
+#: ../lib/init/grass.py:1011
+msgid ""
+"Error in GUI startup. See messages above (if any) and if necessary, please report this error to the GRASS developers.\n"
+"On systems with package manager, make sure you have the right GUI package, probably named grass-gui, installed.\n"
+"To run GRASS GIS in text mode use the -text flag.\n"
+"Use '--help' for further options\n"
+" {cmd_name} --help\n"
+"See also: https://grass.osgeo.org/{cmd_name}/manuals/helptext.html"
+msgstr ""
+#: ../lib/init/grass.py:1023
+msgid ""
+"Exit was requested in GUI.\n"
+"GRASS GIS will not start. Bye."
+msgstr ""
+#: ../lib/init/grass.py:1026
+msgid ""
+"Invalid return code from GUI startup script.\n"
+"Please advise GRASS developers of this error."
+msgstr ""
+#: ../lib/init/grass.py:1073
+msgid ""
+"Error reading data path information from g.gisenv.\n"
+"GISDBASE={gisbase}\n"
+"LOCATION_NAME={location}\n"
+"MAPSET={mapset}\n"
+"\n"
+"Check the <{file}> file."
+msgstr ""
+#: ../lib/init/grass.py:1279
+#, python-format
+msgid "Path '%s' doesn't exist"
+msgstr ""
+#: ../lib/init/grass.py:1281
+#, python-format
+msgid "Path '%s' not accessible."
+msgstr ""
+#. GTC %s is mapset's folder path
+#: ../lib/init/grass.py:1286
+#, python-format
+msgid "You are not the owner of '%s'."
+msgstr ""
+#: ../lib/init/grass.py:1294
+#, python-format
+msgid ""
+"%(user)s is currently running GRASS in selected mapset (file %(file)s found). Concurrent use not allowed.\n"
+"You can force launching GRASS using -f flag (note that you need permission for this operation). Have another look in the processor manager just to be sure..."
+msgstr ""
+#: ../lib/init/grass.py:1301
+#, python-format
+msgid "%(user)s is currently running GRASS in selected mapset (file %(file)s found). Forcing to launch GRASS..."
+msgstr ""
+#: ../lib/init/grass.py:1305
+#, python-format
+msgid ""
+"Unable to properly access '%s'.\n"
+"Please notify system personnel."
+msgstr ""
+#: ../lib/init/grass.py:1326
+msgid "Building user fontcap..."
+msgstr ""
+#: ../lib/init/grass.py:1385
+msgid "The SHELL variable is not set"
+msgstr ""
+#: ../lib/init/grass.py:1401
+msgid "Unsupported shell <{sh}>: {env_file}"
+msgstr ""
+#: ../lib/init/grass.py:1417
+#, python-format
+msgid ""
+"Job file <%s> has been defined in the 'GRASS_BATCH_JOB' variable but not found. Exiting.\n"
+"\n"
+"Use 'unset GRASS_BATCH_JOB' to disable batch job processing."
+msgstr ""
+#: ../lib/init/grass.py:1424
+#, python-format
+msgid "Change file permission to 'executable' for <%s>"
+msgstr ""
+#: ../lib/init/grass.py:1439
+#, python-format
+msgid "Executing <%s> ..."
+msgstr ""
+#: ../lib/init/grass.py:1446
+msgid ""
+"Execution of <{cmd}> failed:\n"
+"{error}"
+msgstr ""
+#: ../lib/init/grass.py:1449
+#, python-format
+msgid "Execution of <%s> finished."
+msgstr ""
+#: ../lib/init/grass.py:1480
+msgid "Unable to close GUI. {0}"
+msgstr ""
+#: ../lib/init/grass.py:1507
+#, python-format
+msgid "Welcome to GRASS GIS %s"
+msgstr ""
+#: ../lib/init/grass.py:1529
+msgid "GRASS GIS homepage:"
+msgstr ""
+#. GTC Running through: SHELL NAME
+#: ../lib/init/grass.py:1531
+msgid "This version running through:"
+msgstr ""
+#: ../lib/init/grass.py:1533
+msgid "Help is available with the command:"
+msgstr ""
+#: ../lib/init/grass.py:1534
+msgid "See the licence terms with:"
+msgstr ""
+#: ../lib/init/grass.py:1535
+msgid "See citation options with:"
+msgstr ""
+#: ../lib/init/grass.py:1538
+msgid "If required, restart the GUI with:"
+msgstr ""
+#: ../lib/init/grass.py:1540
+msgid "Start the GUI with:"
+msgstr ""
+#: ../lib/init/grass.py:1542
+msgid "When ready to quit enter:"
+msgstr ""
+#: ../lib/init/grass.py:1630
+msgid "2D and 3D raster MASKs present"
+msgstr ""
+#: ../lib/init/grass.py:1631
+msgid "Raster MASK present"
+msgstr ""
+#: ../lib/init/grass.py:1632
+msgid "3D raster MASK present"
+msgstr ""
+#: ../lib/init/grass.py:1675
+msgid "Done."
+msgstr ""
+#: ../lib/init/grass.py:1677
+msgid "Goodbye from GRASS GIS"
+msgstr ""
+#: ../lib/init/grass.py:1682
+msgid "Cleaning up temporary files..."
+msgstr ""
+#: ../lib/init/grass.py:1702
+msgid "Please install the GRASS GIS development package"
+msgstr ""
+#: ../lib/init/grass.py:1736
+#, python-format
+msgid "Parameter <%s> not supported"
+msgstr ""
+#: ../lib/init/grass.py:1880
+msgid "Flag -e requires also flag -c"
+msgstr ""
+#: ../lib/init/grass.py:1927
+msgid ""
+"Unable to start GRASS GIS. You have the choice to:\n"
+" - Launch the graphical user interface with the '-gui' switch\n"
+" {cmd_name} -gui\n"
+" - Launch with path to the location/mapset as an argument\n"
+" {cmd_name} /path/to/location/mapset`\n"
+" - Create a location with '-c' and launch in its PERMANENT mapset\n"
+" {cmd_name} -c EPSG:number /path/to/location\n"
+" {cmd_name} -c geofile /path/to/location\n"
+" - Create manually the GISRC file ({gisrcrc})\n"
+" - Use '--help' for further options\n"
+msgstr ""
+#: ../lib/init/grass.py:1950
+msgid "Creating new GRASS GIS location/mapset..."
+msgstr ""
+#: ../lib/init/grass.py:1952
+msgid "Starting GRASS GIS..."
+msgstr ""
+#: ../lib/init/grass.py:1973
+msgid "<{0}> requested, but not available. Run GRASS in text mode (-text) or install missing package (usually 'grass-gui')."
+msgstr ""
+#: ../lib/init/grass.py:2027
+#, python-format
+msgid "Launching <%s> GUI in the background, please wait..."
+msgstr ""
+#: ../lib/init/grass.py:2049
+#, python-format
+msgid "Failed to start shell '%s'"
+msgstr ""
+#: ../lib/init/lock.c:38
+#, c-format
+msgid "Usage: %s file pid"
+msgstr ""
+#: ../lib/init/lock.c:42
+msgid "Concurrent mapset locking is not supported on Windows"
+msgstr ""
+#: ../lib/init/lock.c:60
+#, c-format
+msgid "Unable to write lockfile %s (%s)"
+msgstr ""
+#: ../lib/segment/open.c:53
+msgid "Segment file name is NULL"
+msgstr ""
+#: ../lib/segment/open.c:58
+msgid "Segment file exists already"
+msgstr ""
+#: ../lib/segment/open.c:66
+msgid "Unable to create segment file"
+msgstr ""
+#: ../lib/segment/open.c:74
+msgid "Could not write segment file"
+msgstr ""
+#: ../lib/segment/open.c:78
+msgid "Illegal segment configuration parameter(s)"
+msgstr ""
+#: ../lib/segment/open.c:87
+msgid "Unable to re-open segment file"
+msgstr ""
+#: ../lib/segment/open.c:94
+msgid "Could not read segment file"
+msgstr ""
+#: ../lib/segment/format.c:144
+msgid "Segment format: file size too large"
+msgstr ""
+#: ../lib/segment/format.c:145
+msgid "Please recompile with Large File Support (LFS)"
+msgstr ""
+#: ../lib/rst/interp_float/segmen2d_parallel.c:109
+msgid "Starting parallel work"
+msgstr ""
+#: ../lib/rst/interp_float/segmen2d_parallel.c:188
+#: ../lib/rst/interp_float/segmen2d.c:133
+msgid "Taking too long to find points for interpolation - please change the region to area where your points are. Continuing calculations..."
+msgstr ""
+#: ../lib/rst/interp_float/input2d.c:58
+#, c-format
+msgid "Mask raster map <%s> not found"
+msgstr ""
+#: ../lib/rst/interp_float/input2d.c:81
+msgid "Bitmap mask created"
+msgstr ""
+#: ../lib/rst/interp_float/interp2d.c:232
+#, c-format
+msgid "Overshoot - increase in tension suggested. Overshoot occurs at (%d,%d) cell. Z-value %f, zmin %f, zmax %f."
+msgstr ""
+#: ../lib/rst/interp_float/resout2d.c:77
+msgid "Temporarily changing the region to desired resolution..."
+msgstr ""
+#: ../lib/rst/interp_float/resout2d.c:103
+#, c-format
+msgid "First change your rows number(%d) to %d"
+msgstr ""
+#: ../lib/rst/interp_float/resout2d.c:110
+#, c-format
+msgid "First change your columns number(%d) to %d"
+msgstr ""
+#: ../lib/rst/interp_float/resout2d.c:264
+msgid "No color table for input raster map -- will not create color table"
+msgstr ""
+#: ../lib/rst/interp_float/resout2d.c:458
+msgid "Changing the region back to initial..."
+msgstr ""
+#: ../lib/rst/interp_float/vinput2d.c:94
+#, c-format
+msgid "Vector map <%s> is not 3D"
+msgstr ""
+#: ../lib/rst/interp_float/vinput2d.c:97
+msgid "Loading data from attribute table ..."
+msgstr ""
+#: ../lib/rst/interp_float/vinput2d.c:115
+#: ../lib/rst/interp_float/vinput2d.c:129 ../lib/db/dbmi_client/copy_tab.c:291
+#, c-format
+msgid "Column <%s> not found"
+msgstr ""
+#: ../lib/rst/interp_float/vinput2d.c:118
+#: ../lib/rst/interp_float/vinput2d.c:131
+#, c-format
+msgid "Data type of column <%s> must be numeric"
+msgstr ""
+#: ../lib/rst/interp_float/vinput2d.c:142
+msgid "Reading features from vector map ..."
+msgstr ""
+#: ../lib/rst/interp_float/vinput2d.c:174
+#, c-format
+msgid "Database record for cat %d not found"
+msgstr ""
+#: ../lib/rst/interp_float/vinput2d.c:192
+msgid "Negative value of smoothing detected: sm must be >= 0"
+msgstr ""
+#: ../lib/rst/interp_float/vinput2d.c:256
+msgid "Strip exists with insufficient data"
+msgstr ""
+#: ../lib/rst/interp_float/vinput2d.c:270
+#, c-format
+msgid "There are points outside specified 2D/3D region - %d points ignored"
+msgstr ""
+#: ../lib/rst/interp_float/vinput2d.c:273
+#, c-format
+msgid "Ignoring %d points (too dense)"
+msgstr ""
+#: ../lib/rst/interp_float/vinput2d.c:277
+#, c-format
+msgid "%d points given for interpolation (after thinning) is less than given NPMIN=%d"
+msgstr ""
+#: ../lib/rst/interp_float/vinput2d.c:282
+msgid "Zero points in the given region"
+msgstr ""
+#: ../lib/rst/interp_float/vinput2d.c:287
+#, c-format
+msgid "Segmentation parameters set to invalid values: npmin= %d, segmax= %d for smooth connection of segments, npmin > segmax (see manual)"
+msgstr ""
+#: ../lib/rst/interp_float/vinput2d.c:293
+#, c-format
+msgid "There are less than %d points for interpolation. No segmentation is necessary, to run the program faster set segmax=%d (see manual)"
+msgstr ""
+#: ../lib/rst/interp_float/vinput2d.c:297
+#, c-format
+msgid "Number of points from vector map %d"
+msgstr ""
+#: ../lib/rst/interp_float/vinput2d.c:298
+#, c-format
+msgid "Number of points outside of 2D/3D region %d"
+msgstr ""
+#: ../lib/rst/interp_float/vinput2d.c:300
+#, c-format
+msgid "Number of points being used %d"
+msgstr ""
+#: ../lib/rst/interp_float/vinput2d.c:333
+msgid "Some points outside of region (ignored)"
+msgstr ""
+#: ../lib/rst/interp_float/vinput2d.c:339
+msgid "Unable to allocate memory"
+msgstr ""
+#: ../lib/rst/interp_float/vinput2d.c:347
+#, c-format
+msgid "Unable to insert %f,%f,%f a = %d"
+msgstr ""
+#: ../lib/rst/interp_float/output2d.c:117
+#, c-format
+msgid "First change your rows number to nsizr! %d %d"
+msgstr ""
+#: ../lib/rst/interp_float/output2d.c:124
+#, c-format
+msgid "First change your cols number to nsizc %d %d"
+msgstr ""
+#: ../lib/rst/interp_float/write2d.c:53 ../lib/rst/interp_float/write2d.c:64
+#: ../lib/rst/interp_float/write2d.c:79 ../lib/rst/interp_float/write2d.c:88
+#: ../lib/rst/interp_float/write2d.c:96 ../lib/rst/interp_float/write2d.c:104
+msgid "Cannot write files"
+msgstr ""
+#: ../lib/gmath/test/test_blas3.c:38
+msgid ""
+"\n"
+"++ Running blas level 3 unit tests ++"
+msgstr ""
+#: ../lib/gmath/test/test_blas3.c:44
+msgid ""
+"\n"
+"-- blas level 3 unit tests failure --"
+msgstr ""
+#: ../lib/gmath/test/test_blas3.c:46
+msgid ""
+"\n"
+"-- blas level 3 unit tests finished successfully --"
+msgstr ""
+#: ../lib/gmath/test/test_ccmath_wrapper.c:37
+msgid ""
+"\n"
+"++ Running ccmath wrapper unit tests ++"
+msgstr ""
+#: ../lib/gmath/test/test_ccmath_wrapper.c:42
+msgid ""
+"\n"
+"-- ccmath wrapper unit tests failure --"
+msgstr ""
+#: ../lib/gmath/test/test_ccmath_wrapper.c:44
+msgid ""
+"\n"
+"-- ccmath wrapper unit tests finished successfully --"
+msgstr ""
+#: ../lib/gmath/test/bench_solver_direct.c:34
+msgid ""
+"\n"
+"++ Running direct solver benchmark ++"
+msgstr ""
+#: ../lib/gmath/test/test_blas1.c:40
+msgid ""
+"\n"
+"++ Running blas level 1 unit tests ++"
+msgstr ""
+#: ../lib/gmath/test/test_blas1.c:47
+msgid ""
+"\n"
+"-- blas level 1 unit tests failure --"
+msgstr ""
+#: ../lib/gmath/test/test_blas1.c:49
+msgid ""
+"\n"
+"-- blas level 1 unit tests finished successfully --"
+msgstr ""
+#: ../lib/gmath/test/bench_blas2.c:35
+msgid ""
+"\n"
+"++ Running blas level 2 benchmark ++"
+msgstr ""
+#: ../lib/gmath/test/test_solvers.c:37
+msgid ""
+"\n"
+"++ Running solver unit tests ++"
+msgstr ""
+#: ../lib/gmath/test/test_solvers.c:42
+msgid ""
+"\n"
+"-- Solver unit tests failure --"
+msgstr ""
+#: ../lib/gmath/test/test_solvers.c:44
+msgid ""
+"\n"
+"-- Solver unit tests finished successfully --"
+msgstr ""
+#: ../lib/gmath/test/test_main.c:47 ../lib/db/dbmi_base/test/test_main.c:47
+#: ../lib/vector/rtree/test_suite/test_main.c:44
+msgid "Choose the unit tests to run"
+msgstr ""
+#: ../lib/gmath/test/test_main.c:54 ../lib/db/dbmi_base/test/test_main.c:54
+msgid "Choose the integration tests to run"
+msgstr ""
+#: ../lib/gmath/test/test_main.c:61
+msgid "The size of the matrices and vectors for benchmarking"
+msgstr ""
+#: ../lib/gmath/test/test_main.c:68
+msgid "Choose solver benchmark"
+msgstr ""
+#: ../lib/gmath/test/test_main.c:75
+msgid "Choose blas benchmark"
+msgstr ""
+#: ../lib/gmath/test/test_main.c:79 ../lib/db/dbmi_base/test/test_main.c:58
+msgid "Run all unit tests"
+msgstr ""
+#: ../lib/gmath/test/test_main.c:83 ../lib/db/dbmi_base/test/test_main.c:62
+msgid "Run all integration tests"
+msgstr ""
+#: ../lib/gmath/test/test_main.c:87 ../lib/db/dbmi_base/test/test_main.c:66
+msgid "Run all unit and integration tests"
+msgstr ""
+#: ../lib/gmath/test/test_main.c:106
+msgid "Performs benchmarks, unit and integration tests for the gmath library"
+msgstr ""
+#: ../lib/gmath/test/test_matrix_conversion.c:37
+msgid ""
+"\n"
+"++ Running matrix conversion unit tests ++"
+msgstr ""
+#: ../lib/gmath/test/test_matrix_conversion.c:42
+msgid ""
+"\n"
+"-- Matrix conversion unit tests failure --"
+msgstr ""
+#: ../lib/gmath/test/test_matrix_conversion.c:44
+msgid ""
+"\n"
+"-- Matrix conversion unit tests finished successfully --"
+msgstr ""
+#: ../lib/gmath/test/bench_solver_krylov.c:34
+msgid ""
+"\n"
+"++ Running krylov solver benchmark ++"
+msgstr ""
+#: ../lib/gmath/test/test_blas2.c:38
+msgid ""
+"\n"
+"++ Running blas level 2 unit tests ++"
+msgstr ""
+#: ../lib/gmath/test/test_blas2.c:44
+msgid ""
+"\n"
+"-- blas level 2 unit tests failure --"
+msgstr ""
+#: ../lib/gmath/test/test_blas2.c:46
+msgid ""
+"\n"
+"-- blas level 2 unit tests finished successfully --"
+msgstr ""
+#: ../lib/gmath/test/bench_blas3.c:34
+msgid ""
+"\n"
+"++ Running blas level 3 benchmark ++"
+msgstr ""
+#: ../lib/gmath/solvers_classic_iter.c:84
+#, c-format
+msgid "sparse Jacobi -- iteration %5i error %g\n"
+msgstr ""
+#: ../lib/gmath/solvers_classic_iter.c:156
+#, c-format
+msgid "sparse SOR -- iteration %5i error %g\n"
+msgstr ""
+#: ../lib/gmath/solvers_classic_iter.c:218
+#, c-format
+msgid "Jacobi -- iteration %5i error %g\n"
+msgstr ""
+#: ../lib/gmath/solvers_classic_iter.c:275
+#, c-format
+msgid "SOR -- iteration %5i error %g\n"
+msgstr ""
+#: ../lib/gmath/la.c:61 ../lib/gmath/la.c:117
+msgid "Matrix dimensions out of range"
+msgstr ""
+#: ../lib/gmath/la.c:150
+msgid "Matrix is not initialised fully."
+msgstr ""
+#: ../lib/gmath/la.c:155
+msgid "Unable to allocate space for matrix copy"
+msgstr ""
+#: ../lib/gmath/la.c:220
+msgid "Input matrix is uninitialized"
+msgstr ""
+#: ../lib/gmath/la.c:285
+msgid "First scalar multiplier must be non-zero"
+msgstr ""
+#: ../lib/gmath/la.c:291 ../lib/gmath/la.c:299 ../lib/gmath/la.c:364
+msgid "One or both input matrices uninitialised"
+msgstr ""
+#: ../lib/gmath/la.c:304 ../lib/gmath/la.c:369
+msgid "Matrix order does not match"
+msgstr ""
+#: ../lib/gmath/la.c:310
+msgid "Unable to allocate space for matrix sum"
+msgstr ""
+#: ../lib/gmath/la.c:374
+msgid "Unable to allocate space for matrix product"
+msgstr ""
+#: ../lib/gmath/la.c:486
+msgid "Input: one or both data matrices uninitialised"
+msgstr ""
+#: ../lib/gmath/la.c:491
+msgid "Principal matrix is not properly dimensioned"
+msgstr ""
+#: ../lib/gmath/la.c:496
+msgid "Input: you must have at least one array to solve"
+msgstr ""
+#: ../lib/gmath/la.c:502
+msgid "Could not allocate space for solution matrix"
+msgstr ""
+#: ../lib/gmath/la.c:508 ../lib/gmath/la.c:516
+msgid "Could not allocate space for working matrix"
+msgstr ""
+#: ../lib/gmath/la.c:569
+msgid "Matrix (or submatrix is singular). Solution undetermined"
+msgstr ""
+#: ../lib/gmath/la.c:573
+msgid "Problem in LA routine."
+msgstr ""
+#: ../lib/gmath/la.c:580
+msgid "Procedure not yet available for selected matrix type"
+msgstr ""
+#: ../lib/gmath/la.c:614
+msgid "Matrix is not square. Cannot determine inverse"
+msgstr ""
+#: ../lib/gmath/la.c:619
+msgid "Unable to allocate space for matrix"
+msgstr ""
+#: ../lib/gmath/la.c:636
+msgid "Matrix is singular"
+msgstr ""
+#: ../lib/gmath/la.c:641
+msgid "Problem in LA procedure."
+msgstr ""
+#: ../lib/gmath/la.c:729
+msgid "Element array has not been allocated"
+msgstr ""
+#: ../lib/gmath/la.c:734
+msgid "Specified element is outside array bounds"
+msgstr ""
+#: ../lib/gmath/la.c:788
+msgid "Specified matrix column index is outside range"
+msgstr ""
+#: ../lib/gmath/la.c:793 ../lib/gmath/la.c:834 ../lib/gmath/la.c:1198
+#: ../lib/gmath/la.c:1250 ../lib/gmath/la.c:1325
+msgid "Matrix is not initialised"
+msgstr ""
+#: ../lib/gmath/la.c:798 ../lib/gmath/la.c:839
+msgid "Could not allocate space for vector structure"
+msgstr ""
+#: ../lib/gmath/la.c:829
+msgid "Specified matrix row index is outside range"
+msgstr ""
+#: ../lib/gmath/la.c:869
+msgid "Specified row index is outside range"
+msgstr ""
+#: ../lib/gmath/la.c:874
+msgid "Specified column index is outside range"
+msgstr ""
+#: ../lib/gmath/la.c:894
+msgid "Unknown vector type."
+msgstr ""
+#: ../lib/gmath/la.c:949
+msgid "Input matrix and vector have differing dimensions1"
+msgstr ""
+#: ../lib/gmath/la.c:955 ../lib/gmath/la.c:1071 ../lib/gmath/la.c:1361
+msgid "Output vector is uninitialized"
+msgstr ""
+#: ../lib/gmath/la.c:1076 ../lib/gmath/la.c:1366
+msgid "Vectors are not of the same type"
+msgstr ""
+#: ../lib/gmath/la.c:1081
+msgid "Output vector is of incorrect type"
+msgstr ""
+#: ../lib/gmath/la.c:1086 ../lib/gmath/la.c:1376
+msgid "Matrices not allowed"
+msgstr ""
+#: ../lib/gmath/la.c:1092 ../lib/gmath/la.c:1383
+msgid "Vectors have differing dimensions"
+msgstr ""
+#: ../lib/gmath/la.c:1098 ../lib/gmath/la.c:1390
+msgid "Output vector has incorrect dimension"
+msgstr ""
+#: ../lib/gmath/la.c:1143
+msgid "Vector dimensions out of range"
+msgstr ""
+#: ../lib/gmath/la.c:1148
+msgid "Row/column out of range"
+msgstr ""
+#: ../lib/gmath/la.c:1371
+msgid "Output vector is not the same type as others"
+msgstr ""
+#: ../lib/gmath/la.c:1437
+msgid "Vector structure is not initialised"
+msgstr ""
+#: ../lib/gmath/la.c:1558 ../lib/gmath/la.c:1566 ../lib/gmath/la.c:1571
+msgid "Input format error"
+msgstr ""
+#: ../lib/gmath/solvers_krylov.c:254 ../lib/gmath/solvers_krylov.c:482
+#: ../lib/gmath/solvers_krylov.c:646 ../lib/gmath/solvers_direct.c:134
+msgid "Unable to solve the linear equation system"
+msgstr ""
+#: ../lib/gmath/solvers_krylov.c:262
+#, c-format
+msgid "Sparse PCG -- iteration %i error %g\n"
+msgstr ""
+#: ../lib/gmath/solvers_krylov.c:264
+#, c-format
+msgid "PCG -- iteration %i error %g\n"
+msgstr ""
+#: ../lib/gmath/solvers_krylov.c:490
+#, c-format
+msgid "Sparse CG -- iteration %i error %g\n"
+msgstr ""
+#: ../lib/gmath/solvers_krylov.c:492
+#, c-format
+msgid "CG -- iteration %i error %g\n"
+msgstr ""
+#: ../lib/gmath/solvers_krylov.c:695
+#, c-format
+msgid "Sparse BiCGStab -- iteration %i error %g\n"
+msgstr ""
+#: ../lib/gmath/solvers_krylov.c:698
+#, c-format
+msgid "BiCGStab -- iteration %i error %g\n"
+msgstr ""
+#: ../lib/gmath/solvers_direct_cholesky_band.c:33
+#, c-format
+msgid "Decomposition failed at row %i and col %i"
+msgstr ""
+#: ../lib/gmath/solvers_direct.c:45
+msgid "Starting direct gauss elimination solver"
+msgstr ""
+#: ../lib/gmath/solvers_direct.c:73
+msgid "Starting direct lu decomposition solver"
+msgstr ""
+#: ../lib/gmath/solvers_direct.c:131
+msgid "Starting cholesky decomposition solver"
+msgstr ""
+#: ../lib/gmath/del2g.c:50
+msgid " taking FFT of image..."
+msgstr ""
+#: ../lib/gmath/del2g.c:56
+msgid " computing del**2 g..."
+msgstr ""
+#: ../lib/gmath/del2g.c:59
+msgid " taking FFT of del**2 g..."
+msgstr ""
+#: ../lib/gmath/del2g.c:63
+msgid " multiplying transforms..."
+msgstr ""
+#: ../lib/gmath/del2g.c:66
+msgid " taking inverse FFT..."
+msgstr ""
+#: ../lib/gis/lrand48.c:84
+#, c-format
+msgid "gettimeofday failed: %s"
+msgstr ""
+#: ../lib/gis/lrand48.c:114
+msgid "Pseudo-random number generator not seeded"
+msgstr ""
+#: ../lib/gis/cmprlz4.c:89 ../lib/gis/cmprlz4.c:156 ../lib/gis/cmprbzip.c:104
+#: ../lib/gis/cmprbzip.c:183 ../lib/gis/cmprzstd.c:102
+#: ../lib/gis/cmprzstd.c:176 ../lib/gis/cmprzlib.c:100
+#: ../lib/gis/cmprzlib.c:179 ../lib/gis/compress.c:335
+msgid "No source buffer"
+msgstr ""
+#: ../lib/gis/cmprlz4.c:92 ../lib/gis/cmprlz4.c:159 ../lib/gis/cmprbzip.c:107
+#: ../lib/gis/cmprbzip.c:186 ../lib/gis/cmprzstd.c:105
+#: ../lib/gis/cmprzstd.c:179 ../lib/gis/cmprzlib.c:103
+#: ../lib/gis/cmprzlib.c:182
+msgid "No destination buffer"
+msgstr ""
+#: ../lib/gis/cmprlz4.c:99 ../lib/gis/cmprlz4.c:166 ../lib/gis/cmprbzip.c:114
+#: ../lib/gis/cmprbzip.c:193 ../lib/gis/cmprzstd.c:112
+#: ../lib/gis/cmprzstd.c:186 ../lib/gis/cmprzlib.c:110
+#: ../lib/gis/cmprzlib.c:189 ../lib/gis/compress.c:337
+#, c-format
+msgid "Invalid source buffer size %d"
+msgstr ""
+#: ../lib/gis/cmprlz4.c:101 ../lib/gis/cmprlz4.c:168 ../lib/gis/cmprbzip.c:116
+#: ../lib/gis/cmprbzip.c:195 ../lib/gis/cmprzstd.c:114
+#: ../lib/gis/cmprzstd.c:188 ../lib/gis/cmprzlib.c:112
+#: ../lib/gis/cmprzlib.c:191 ../lib/gis/compress.c:257
+#, c-format
+msgid "Invalid destination buffer size %d"
+msgstr ""
+#: ../lib/gis/cmprlz4.c:121
+msgid "LZ4 compression error"
+msgstr ""
+#: ../lib/gis/cmprlz4.c:177
+msgid "LZ4 decompression error"
+msgstr ""
+#: ../lib/gis/cmprlz4.c:186 ../lib/gis/cmprbzip.c:219 ../lib/gis/cmprzstd.c:206
+#: ../lib/gis/cmprzlib.c:215
+#, c-format
+msgid "Got uncompressed size %d, expected %d"
+msgstr ""
+#: ../lib/gis/cmprbzip.c:97 ../lib/gis/cmprbzip.c:176
+msgid "GRASS needs to be compiled with BZIP2 for BZIP2 compression"
+msgstr ""
+#: ../lib/gis/cmprbzip.c:141
+#, c-format
+msgid "BZIP2 version %s compression error %d"
+msgstr ""
+#: ../lib/gis/cmprbzip.c:208
+#, c-format
+msgid "BZIP2 version %s decompression error %d"
+msgstr ""
+#: ../lib/gis/distance.c:154
+#, c-format
+msgid "%s: shouldn't happen: code=%d P=(%f,%f) S=(%f,%f)(%f,%f)"
+msgstr ""
+#: ../lib/gis/parser_html.c:57 ../lib/gis/parser_rest.c:60
+msgid "NAME"
+msgstr ""
+#: ../lib/gis/parser_html.c:70 ../lib/gis/parser_rest.c:73
+msgid "KEYWORDS"
+msgstr ""
+#: ../lib/gis/parser_html.c:75 ../lib/gis/parser_rest.c:78
+msgid "SYNOPSIS"
+msgstr ""
+#: ../lib/gis/parser_html.c:167 ../lib/gis/parser_rest.c:164
+#: ../lib/gis/parser_help.c:215 ../lib/gis/parser_interface.c:329
+msgid "Allow output files to overwrite existing files"
+msgstr ""
+#: ../lib/gis/parser_html.c:171 ../lib/gis/parser_help.c:217
+#: ../lib/gis/parser_interface.c:337
+msgid "Print usage summary"
+msgstr ""
+#: ../lib/gis/parser_html.c:174 ../lib/gis/parser_rest.c:168
+#: ../lib/gis/parser_help.c:218 ../lib/gis/parser_interface.c:344
+msgid "Verbose module output"
+msgstr ""
+#: ../lib/gis/parser_html.c:177 ../lib/gis/parser_rest.c:171
+#: ../lib/gis/parser_help.c:219 ../lib/gis/parser_interface.c:351
+msgid "Quiet module output"
+msgstr ""
+#: ../lib/gis/parser_html.c:180 ../lib/gis/parser_help.c:221
+msgid "Force launching GUI dialog"
+msgstr ""
+#: ../lib/gis/parser_html.c:233 ../lib/gis/parser_rest.c:223
+msgid "Options"
+msgstr ""
+#: ../lib/gis/parser_html.c:239 ../lib/gis/parser_rest.c:230
+msgid "Default"
+msgstr ""
+#: ../lib/gis/open.c:68
+#, c-format
+msgid "G__open(read): mapset <%s> doesn't match xmapset <%s>"
+msgstr ""
+#: ../lib/gis/open.c:89
+#, c-format
+msgid "G__open(read): Unable to open '%s': %s"
+msgstr ""
+#: ../lib/gis/open.c:98
+#, c-format
+msgid "G__open(write): xmapset <%s> != G_mapset() <%s>"
+msgstr ""
+#: ../lib/gis/open.c:122
+#, c-format
+msgid "G__open(write): Unable to open '%s': %s"
+msgstr ""
+#: ../lib/gis/get_ellipse.c:263 ../lib/proj/ellipse.c:243
+#, c-format
+msgid "Unable to open ellipsoid table file <%s>"
+msgstr ""
+#: ../lib/gis/get_ellipse.c:344 ../lib/gis/get_ellipse.c:367
+#, c-format
+msgid "Invalid a: field '%s' in file %s in <%s>"
+msgstr ""
+#: ../lib/gis/get_ellipse.c:356
+#, c-format
+msgid "Invalid ellipsoid '%s' in file %s in <%s>"
+msgstr ""
+#: ../lib/gis/get_ellipse.c:370
+#, c-format
+msgid "Invalid es: field '%s' in file %s in <%s>"
+msgstr ""
+#: ../lib/gis/get_ellipse.c:383
+#, c-format
+msgid "No ellipsoid info given in file %s in <%s>"
+msgstr ""
+#: ../lib/gis/parser.c:355
+#, c-format
+msgid "BUG in option name, '%s' is not valid"
+msgstr ""
+#: ../lib/gis/parser.c:407
+#, c-format
+msgid "BUG in descriptions, option '%s' in <%s> does not exist"
+msgstr ""
+#: ../lib/gis/parser.c:525
+msgid "Use either --quiet or --verbose flag, not both. Assuming --verbose."
+msgstr ""
+#: ../lib/gis/parser.c:539
+msgid "Use either --quiet or --verbose flag, not both. Assuming --quiet."
+msgstr ""
+#: ../lib/gis/parser.c:554
+msgid "Use either --qq or --verbose flag, not both. Assuming --qq."
+msgstr ""
+#: ../lib/gis/parser.c:585
+#, c-format
+msgid "Sorry <%s> is not a valid option"
+msgstr ""
+#: ../lib/gis/parser.c:598
+msgid "Your installation doesn't include GUI, exiting."
+msgstr ""
+#: ../lib/gis/parser.c:943
+msgid "Unable to determine program name"
+msgstr ""
+#: ../lib/gis/parser.c:965 ../lib/gis/parser.c:984
+#, c-format
+msgid "%s: Sorry, <%c> is not a valid flag"
+msgstr ""
+#: ../lib/gis/parser.c:1114
+#, c-format
+msgid "%s: Sorry, <%s=> is ambiguous"
+msgstr ""
+#: ../lib/gis/parser.c:1117
+#, c-format
+msgid "Option <%s=> matches"
+msgstr ""
+#: ../lib/gis/parser.c:1135
+#, c-format
+msgid "Please update the usage of <%s>: option <%s> has been renamed to <%s>"
+msgstr ""
+#: ../lib/gis/parser.c:1148
+#, c-format
+msgid "%s: Sorry, <%s> is not a valid parameter"
+msgstr ""
+#: ../lib/gis/parser.c:1154 ../lib/gis/parser.c:1400
+#, c-format
+msgid "<%s> is an abbreviation for <%s>"
+msgstr ""
+#: ../lib/gis/parser.c:1159
+#, c-format
+msgid "Option <%s> does not accept multiple answers"
+msgstr ""
+#: ../lib/gis/parser.c:1231
+#, c-format
+msgid ""
+"Illegal range syntax for parameter <%s>\n"
+"\tPresented as: %s"
+msgstr ""
+#: ../lib/gis/parser.c:1237
+#, c-format
+msgid ""
+"Value <%s> out of range for parameter <%s>\n"
+"\tLegal range: %s"
+msgstr ""
+#: ../lib/gis/parser.c:1243
+#, c-format
+msgid "Missing value for parameter <%s>"
+msgstr ""
+#: ../lib/gis/parser.c:1249
+#, c-format
+msgid ""
+"Value <%s> ambiguous for parameter <%s>\n"
+"\tValid options: %s"
+msgstr ""
+#: ../lib/gis/parser.c:1422
+#, c-format
+msgid ""
+"Required parameter <%s> not set:\n"
+"\t(%s)"
+msgstr ""
+#: ../lib/gis/parser.c:1514
+#, c-format
+msgid ""
+"Option <%s> must be provided in multiples of %d\n"
+"\tYou provided %d item(s): %s"
+msgstr ""
+#: ../lib/gis/parser.c:1588 ../lib/gis/error.c:363
+#, c-format
+msgid "ERROR: "
+msgstr ""
+#: ../lib/gis/parser.c:1590 ../lib/gis/parser.c:1597
+#, c-format
+msgid "option <%s>: <%s> exists. To overwrite, use the --overwrite flag"
+msgstr ""
+#: ../lib/gis/parser.c:1707
+#, c-format
+msgid "%s= is not a separator option"
+msgstr ""
+#: ../lib/gis/parser.c:1710
+#, c-format
+msgid "No separator given for %s="
+msgstr ""
+#: ../lib/gis/parser.c:1772 ../lib/gis/parser.c:1789
+#, c-format
+msgid "%s= is not a file option"
+msgstr ""
+#: ../lib/gis/parser.c:1774
+#, c-format
+msgid "Opening multiple files not supported for %s="
+msgstr ""
+#: ../lib/gis/parser.c:1780
+#, c-format
+msgid "Unable to open %s file <%s>"
+msgstr ""
+#: ../lib/gis/parser.c:1786
+#, c-format
+msgid "Unable to create %s file <%s>"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:147
+msgid "SQL SELECT statement"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:149
+msgid "Example: select * from towns where population > 10000"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:156
+msgid "WHERE conditions of SQL statement without 'where' keyword"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:157
+msgid "Example: income < 1000 and population >= 10000"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:165
+msgid "Name of attribute table"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:174
+msgid "Name of database driver"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:183
+msgid "Name of database"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:192
+msgid "Database schema"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:193
+msgid "Do not use this option if schemas are not supported by driver/database server"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:202
+msgid "Name of attribute column"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:211
+msgid "Name of attribute column(s)"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:220
+msgid "Name of key column"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:221
+msgid "Must refer to an integer column"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:233
+msgid "Name of input imagery group"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:241
+msgid "Name of input imagery subgroup"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:251
+msgid "Name of input raster map"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:260
+msgid "Name of input raster map(s)"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:268
+msgid "Name for output raster map"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:277
+msgid "Name for output raster map(s)"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:285
+msgid "Name of raster map"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:294
+msgid "Name of raster map(s)"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:302
+msgid "Name of base raster map"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:310
+msgid "Name of cover raster map"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:318
+msgid "Name of input elevation raster map"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:327
+msgid "Name of input elevation raster map(s)"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:334
+msgid "Type of raster map to be created"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:335
+msgid "Storage type for resultant raster map"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:339
+msgid "Integer"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:340
+msgid "Single precision floating point"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:341
+msgid "Double precision floating point"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:347
+msgid "Sampling interpolation method"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:351
+msgid "Nearest-neighbor interpolation"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:352
+msgid "Bilinear interpolation"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:353
+msgid "Bicubic interpolation"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:362
+msgid "Name of input basename raster map(s)"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:371
+msgid "Name for output basename raster map(s)"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:381
+msgid "Name of input 3D raster map"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:390
+msgid "Name of input 3D raster map(s)"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:398
+msgid "Name for output 3D raster map"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:406
+msgid "Name of 3D raster map"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:415
+msgid "Name of 3D raster map(s)"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:424
+msgid "Data type used in the output raster3d map"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:433
+msgid "Number of digits used as mantissa in the internal map storage, 0 -23 for float, 0 - 52 for double, max or default"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:443
+msgid "The compression method used in the output raster3d map"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:453
+msgid "The dimensions of the tiles used in the output raster3d map (XxYxZ or default: 16x16x8)"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:463
+msgid "Name of input vector map"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:464
+#: ../lib/gis/parser_standard_options.c:491
+msgid "Or data source for direct OGR access"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:473
+msgid "Name of input vector map(s)"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:474
+msgid "Or data source(s) for direct OGR access"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:482
+msgid "Name for output vector map"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:490
+msgid "Name of vector map"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:500
+msgid "Name of vector map(s)"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:509
+#: ../lib/gis/parser_standard_options.c:518
+msgid "Input feature type"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:525
+msgid "Layer number or name"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:527
+msgid "Vector features can have category values in different layers. This number determines which layer to use. When used with direct OGR access this is the layer name."
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:537
+msgid "Layer number or name ('-1' for all layers)"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:539
+msgid "A single vector map can be connected to multiple database tables. This number determines which table to use. When used with direct OGR access this is the layer name."
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:548
+msgid "Category value"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:556
+msgid "Category values"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:557
+#: ../lib/gis/parser_standard_options.c:572
+msgid "Example: 1,3,7-9,13"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:564
+msgid "Feature id"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:571
+msgid "Feature ids"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:582
+#: ../lib/gis/parser_standard_options.c:590
+msgid "Name of input file"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:598
+msgid "Name for output file"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:607
+msgid "Field separator"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:608
+msgid "Special characters: pipe, comma, space, tab, newline"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:619
+#: ../lib/gis/parser_standard_options.c:630
+msgid "Color"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:621
+msgid "Either a standard color name or R:G:B triplet"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:632
+msgid "Either a standard color name, R:G:B triplet, or \"none\""
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:643
+msgid "Name of input directory"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:653
+msgid "Units"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:662
+msgid "Data type(s)"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:672
+msgid "Name of mapset (default: current search path)"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:673
+msgid "'.' for current mapset"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:681
+msgid "Location name"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:682
+msgid "Location name (not location path)"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:692
+msgid "GRASS GIS database directory"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:693
+msgid "Default: path to the current GRASS GIS database"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:705
+msgid "Coordinates"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:714
+msgid "Name of color table"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:725
+msgid "String representing NULL value"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:734
+msgid "Name of saved region"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:744
+msgid "Name of the input space time dataset"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:753
+msgid "Name of the input space time datasets"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:761
+msgid "Name of the output space time dataset"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:769
+msgid "Name of the input space time raster dataset"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:778
+msgid "Name of the input space time raster datasets"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:786
+msgid "Name of the output space time raster dataset"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:794
+msgid "Name of the input space time vector dataset"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:803
+msgid "Name of the input space time vector datasets"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:811
+msgid "Name of the output space time vector dataset"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:819
+msgid "Name of the input space time raster3d dataset"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:828
+msgid "Name of the input space time raster3d datasets"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:836
+msgid "Name of the output space time raster3d dataset"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:845
+msgid "Type of the input space time dataset"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:853
+msgid "Name of the input map"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:862
+msgid "Name of the input maps"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:871
+msgid "Type of the input map"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:880
+msgid "The temporal type of the space time dataset"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:887
+msgid "WHERE conditions of SQL statement without 'where' keyword used in the temporal GIS framework"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:888
+msgid "Example: start_time > '2001-01-01 12:30:00'"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:898
+msgid "The method to be used for sampling the input dataset"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:932
+msgid "Do not create attribute table"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:936
+msgid "Do not build topology"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:937
+msgid "Advantageous when handling a large number of points"
+msgstr ""
+#: ../lib/gis/gisinit.c:53 ../lib/gis/gisinit.c:87
+#, c-format
+msgid "Module built against version %s but trying to use version %s. You need to rebuild GRASS GIS or untangle multiple installations."
+msgstr ""
+#: ../lib/gis/gisinit.c:65
+#, c-format
+msgid "MAPSET %s - permission denied"
+msgstr ""
+#: ../lib/gis/gisinit.c:68
+#, c-format
+msgid "MAPSET %s not found at %s"
+msgstr ""
+#: ../lib/gis/gisinit.c:102
+msgid "System not initialized. Programmer forgot to call G_gisinit()."
+msgstr ""
+#: ../lib/gis/view.c:176
+#, c-format
+msgid "Unable to open %s for writing"
+msgstr ""
+#: ../lib/gis/view.c:262 ../lib/gis/view.c:479
+#, c-format
+msgid "Unable to open %s for reading"
+msgstr ""
+#: ../lib/gis/view.c:465
+#, c-format
+msgid "GRASS window when view was saved:\n"
+msgstr ""
+#: ../lib/gis/view.c:545
+#, c-format
+msgid " Window saved in \"%s\" is completely outside of current GRASS window."
+msgstr ""
+#: ../lib/gis/view.c:549
+#, c-format
+msgid " Only %d%% of window saved in \"%s\" overlaps with current GRASS window."
+msgstr ""
+#: ../lib/gis/open_misc.c:49
+#, c-format
+msgid "G__open_misc(read): mapset <%s> doesn't match xmapset <%s>"
+msgstr ""
+#: ../lib/gis/open_misc.c:74
+#, c-format
+msgid "G__open_misc(write): xmapset <%s> != G_mapset() <%s>"
+msgstr ""
+#: ../lib/gis/myname.c:46
+msgid "This location has no description."
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:57
+#, c-format
+msgid "Illegal n-s resolution value <%lf>"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:61 ../lib/gis/adj_cellhd.c:163
+msgid "Illegal row value"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:65 ../lib/gis/adj_cellhd.c:169
+msgid "Illegal e-w resolution value"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:69 ../lib/gis/adj_cellhd.c:175
+msgid "Illegal col value"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:75 ../lib/gis/adj_cellhd.c:191
+msgid "North must be north of South"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:77 ../lib/gis/adj_cellhd.c:193
+msgid "North must be larger than South"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:83 ../lib/gis/adj_cellhd.c:199
+msgid "East must be larger than West"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:102 ../lib/gis/adj_cellhd.c:242
+msgid "Invalid coordinates"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:109 ../lib/gis/adj_cellhd.c:249
+msgid "NS resolution has been changed"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:114 ../lib/gis/adj_cellhd.c:254
+msgid "EW resolution has been changed"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:117 ../lib/gis/adj_cellhd.c:257
+msgid "NS and EW resolutions are different"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:157
+msgid "Illegal n-s resolution value"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:159
+msgid "Illegal n-s3 resolution value"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:165
+msgid "Illegal row3 value"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:171
+msgid "Illegal e-w3 resolution value"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:177
+msgid "Illegal col3 value"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:181
+msgid "Illegal t-b3 resolution value"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:185
+msgid "Illegal depths value"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:202
+msgid "Top must be larger than Bottom"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:276
+#, c-format
+msgid "East (%.15g) is not larger than West (%.15g)"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:311
+#, c-format
+msgid "Illegal latitude for North: %g"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:313
+#, c-format
+msgid "Illegal latitude for South: %g"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:319
+#, c-format
+msgid "Illegal longitude for West: %g"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:323
+#, c-format
+msgid "Illegal longitude for East: %g"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:351
+#, c-format
+msgid "NS extent does not match NS resolution: %g cells difference"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:360
+#, c-format
+msgid "%g cells missing to reach 90 degree north"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:363 ../lib/gis/adj_cellhd.c:377
+#: ../lib/gis/adj_cellhd.c:391
+#, c-format
+msgid "Subtle input data rounding error of north boundary (%g)"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:373
+#, c-format
+msgid "90 degree north is exceeded by %g cells"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:402
+msgid "Illegal latitude for North"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:410
+#, c-format
+msgid "%g cells missing to reach 90 degree south"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:413 ../lib/gis/adj_cellhd.c:427
+#: ../lib/gis/adj_cellhd.c:441
+#, c-format
+msgid "Subtle input data rounding error of south boundary (%g)"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:423
+#, c-format
+msgid "90 degree south is exceeded by %g cells"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:452
+msgid "Illegal latitude for South"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:481
+#, c-format
+msgid "EW extent does not match EW resolution: %g cells difference"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:487
+#, c-format
+msgid "360 degree EW extent is exceeded by %g cells"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:493
+#, c-format
+msgid "%g cells missing to cover 360 degree EW extent"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:528
+msgid "Invalid NS resolution"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:533
+msgid "Invalid EW resolution"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:538
+msgid "Invalid North"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:543
+msgid "Invalid South"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:548
+msgid "Invalid West"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:553
+msgid "Invalid East"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:606
+#, c-format
+msgid "NS resolution rounded from %s to %s"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:639 ../lib/gis/adj_cellhd.c:694
+#, c-format
+msgid "North rounded from %s to %s"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:651
+#, c-format
+msgid "South adjusted from %s to %s"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:666 ../lib/gis/adj_cellhd.c:709
+#, c-format
+msgid "South rounded from %s to %s"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:678
+#, c-format
+msgid "North adjusted from %s to %s"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:732
+#, c-format
+msgid "EW resolution rounded from %s to %s"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:765 ../lib/gis/adj_cellhd.c:820
+#, c-format
+msgid "West rounded from %s to %s"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:777
+#, c-format
+msgid "East adjusted from %s to %s"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:792 ../lib/gis/adj_cellhd.c:835
+#, c-format
+msgid "East rounded from %s to %s"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:804
+#, c-format
+msgid "West adjusted from %s to %s"
+msgstr ""
+#: ../lib/gis/units.c:208
+msgid "square units"
+msgstr ""
+msgid "square unit"
+msgstr ""
+#: ../lib/gis/units.c:210
+msgid "units"
+msgstr ""
+msgid "unit"
+msgstr ""
+#: ../lib/gis/units.c:215
+msgid "square meters"
+msgstr ""
+msgid "square meter"
+msgstr ""
+#: ../lib/gis/units.c:217
+msgid "meters"
+msgstr ""
+msgid "meter"
+msgstr ""
+#: ../lib/gis/units.c:222
+msgid "square kilometers"
+msgstr ""
+msgid "square kilometer"
+msgstr ""
+#: ../lib/gis/units.c:224
+msgid "kilometers"
+msgstr ""
+msgid "kilometer"
+msgstr ""
+#: ../lib/gis/units.c:229
+msgid "acres"
+msgstr ""
+msgid "acre"
+msgstr ""
+#: ../lib/gis/units.c:237
+msgid "hectares"
+msgstr ""
+msgid "hectare"
+msgstr ""
+#: ../lib/gis/units.c:245
+msgid "square miles"
+msgstr ""
+msgid "square mile"
+msgstr ""
+#: ../lib/gis/units.c:247
+msgid "miles"
+msgstr ""
+msgid "mile"
+msgstr ""
+#: ../lib/gis/units.c:252
+msgid "square feet"
+msgstr ""
+msgid "square foot"
+msgstr ""
+#: ../lib/gis/units.c:254
+msgid "feet"
+msgstr ""
+msgid "foot"
+msgstr ""
+#: ../lib/gis/units.c:259
+msgid "square US feet"
+msgstr ""
+msgid "square US foot"
+msgstr ""
+#: ../lib/gis/units.c:261
+msgid "US feet"
+msgstr ""
+msgid "US foot"
+msgstr ""
+#: ../lib/gis/units.c:266
+msgid "square degrees"
+msgstr ""
+msgid "square degree"
+msgstr ""
+#: ../lib/gis/units.c:268
+msgid "degrees"
+msgstr ""
+msgid "degree"
+msgstr ""
+#: ../lib/gis/units.c:272
+msgid "years"
+msgstr ""
+msgid "year"
+msgstr ""
+#: ../lib/gis/units.c:276
+msgid "months"
+msgstr ""
+msgid "month"
+msgstr ""
+#: ../lib/gis/units.c:280
+msgid "days"
+msgstr ""
+msgid "day"
+msgstr ""
+#: ../lib/gis/units.c:284
+msgid "hours"
+msgstr ""
+msgid "hour"
+msgstr ""
+#: ../lib/gis/units.c:288
+msgid "minutes"
+msgstr ""
+msgid "minute"
+msgstr ""
+#: ../lib/gis/units.c:292
+msgid "seconds"
+msgstr ""
+msgid "second"
+msgstr ""
+#: ../lib/gis/key_value3.c:33
+#, c-format
+msgid "Unable to open output file <%s>: %s"
+msgstr ""
+#: ../lib/gis/key_value3.c:36
+#, c-format
+msgid "Error writing file <%s>: %s"
+msgstr ""
+#: ../lib/gis/key_value3.c:39
+#, c-format
+msgid "Error closing output file <%s>: %s"
+msgstr ""
+#: ../lib/gis/key_value3.c:60
+#, c-format
+msgid "Unable to open input file <%s>: %s"
+msgstr ""
+#: ../lib/gis/key_value3.c:64
+#, c-format
+msgid "Error reading file <%s>: %s"
+msgstr ""
+#: ../lib/gis/key_value3.c:67
+#, c-format
+msgid "Error closing input file <%s>: %s"
+msgstr ""
+#: ../lib/gis/proj2.c:63
+msgid "Latitude-Longitude"
+msgstr ""
+#: ../lib/gis/proj2.c:65
+msgid "Other Projection"
+msgstr ""
+#: ../lib/gis/alloc.c:44 ../lib/gis/alloc.c:86 ../lib/gis/alloc.c:132
+#, c-format
+msgid "Current region rows: %d, cols: %d"
+msgstr ""
+#: ../lib/gis/alloc.c:47
+#, c-format
+msgid "G_malloc: unable to allocate %lu bytes of memory at %s:%d"
+msgstr ""
+#: ../lib/gis/alloc.c:89
+#, c-format
+msgid "G_calloc: unable to allocate %lu * %lu bytes of memory at %s:%d"
+msgstr ""
+#: ../lib/gis/alloc.c:135
+#, c-format
+msgid "G_realloc: unable to allocate %lu bytes of memory at %s:%d"
+msgstr ""
+#: ../lib/gis/env.c:311
+msgid "GISRC - variable not set"
+msgstr ""
+#: ../lib/gis/env.c:343 ../lib/gis/env.c:369
+#, c-format
+msgid "Variable '%s' not set"
+msgstr ""
+#: ../lib/gis/list.c:83
+#, c-format
+msgid "no %s files available in current mapset\n"
+msgstr ""
+#: ../lib/gis/list.c:86
+#, c-format
+msgid "no %s files available in mapset <%s>\n"
+msgstr ""
+#: ../lib/gis/list.c:132
+#, c-format
+msgid "%s files available in mapset <%s>:\n"
+msgstr ""
+#: ../lib/gis/list.c:204
+msgid "G_list: Unknown element type"
+msgstr ""
+#: ../lib/gis/error.c:362
+msgid "WARNING: "
+msgstr ""
+#: ../lib/gis/parser_help.c:84
+msgid "Description:"
+msgstr ""
+#: ../lib/gis/parser_help.c:103
+msgid "Keywords:"
+msgstr ""
+#: ../lib/gis/parser_help.c:111
+msgid "Usage:"
+msgstr ""
+#: ../lib/gis/parser_help.c:141
+msgid "ERROR: Option key not defined"
+msgstr ""
+#: ../lib/gis/parser_help.c:191
+msgid "Flags:"
+msgstr ""
+#: ../lib/gis/parser_help.c:220
+msgid "Super quiet module output"
+msgstr ""
+#: ../lib/gis/parser_help.c:230
+msgid "Parameters:"
+msgstr ""
+#: ../lib/gis/parser_help.c:253
+#, c-format
+msgid " %*s default: %s\n"
+msgstr ""
+#: ../lib/gis/parser_help.c:279
+#, c-format
+msgid " %*s options: "
+msgstr ""
+#: ../lib/gis/spawn.c:386
+#, c-format
+msgid "CreateProcess() failed: error = %d"
+msgstr ""
+#: ../lib/gis/spawn.c:421
+#, c-format
+msgid "G_spawn: unable to redirect descriptor %d"
+msgstr ""
+#: ../lib/gis/spawn.c:429 ../lib/gis/spawn.c:619
+#, c-format
+msgid "G_spawn: unable to open file %s"
+msgstr ""
+#: ../lib/gis/spawn.c:503
+msgid "G_spawn: unable to execute command"
+msgstr ""
+#: ../lib/gis/spawn.c:528 ../lib/gis/spawn.c:536
+#, c-format
+msgid "G_spawn: unable to restore signal %d"
+msgstr ""
+#: ../lib/gis/spawn.c:567
+#, c-format
+msgid "G_spawn: unable to reset signal %d"
+msgstr ""
+#: ../lib/gis/spawn.c:576
+#, c-format
+msgid "G_spawn: unable to ignore signal %d"
+msgstr ""
+#: ../lib/gis/spawn.c:587
+#, c-format
+msgid "G_spawn: unable to block signal %d"
+msgstr ""
+#: ../lib/gis/spawn.c:595
+#, c-format
+msgid "G_spawn: unable to unblock signal %d"
+msgstr ""
+#: ../lib/gis/spawn.c:624 ../lib/gis/spawn.c:633
+#, c-format
+msgid "G_spawn: unable to duplicate descriptor %d to %d"
+msgstr ""
+#: ../lib/gis/spawn.c:666
+#, c-format
+msgid "Unable to create a new process: %s"
+msgstr ""
+#: ../lib/gis/spawn.c:681
+#, c-format
+msgid "Unable to change directory to %s"
+msgstr ""
+#: ../lib/gis/spawn.c:689
+msgid "Unable to execute command"
+msgstr ""
+#: ../lib/gis/datum.c:160
+#, c-format
+msgid "unable to open datum table file: %s"
+msgstr ""
+#: ../lib/gis/datum.c:182
+#, c-format
+msgid "error in datum table file, line %d"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:141 ../lib/gis/rd_cellhd.c:180
+#: ../lib/gis/rd_cellhd.c:357
+#, c-format
+msgid "Syntax error in cell header, line %d: %s"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:150
+msgid "Duplicate projection field"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:153
+#, c-format
+msgid "Invalid projection field: %s"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:160
+msgid "Duplicate zone field"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:163
+#, c-format
+msgid "Invalid zone field: %s"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:170 ../lib/gis/rd_cellhd.c:172
+#: ../lib/gis/rd_cellhd.c:363 ../lib/gis/rd_cellhd.c:365
+#: ../lib/gis/rd_cellhd.c:367 ../lib/gis/rd_cellhd.c:369
+#: ../lib/gis/rd_cellhd.c:371 ../lib/gis/rd_cellhd.c:373
+#: ../lib/gis/rd_cellhd.c:384 ../lib/gis/rd_cellhd.c:386
+#: ../lib/gis/rd_cellhd.c:388 ../lib/gis/rd_cellhd.c:390
+#, c-format
+msgid "Field <%s> missing"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:195
+msgid "Duplicate north field"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:197
+#, c-format
+msgid "Invalid north field: %s"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:203
+msgid "Duplicate south field"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:205
+#, c-format
+msgid "Invalid south field: %s"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:211
+msgid "Duplicate east field"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:213
+#, c-format
+msgid "Invalid east field: %s"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:219
+msgid "Duplicate west field"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:221
+#, c-format
+msgid "Invalid west field: %s"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:227
+msgid "Duplicate top field"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:229
+#, c-format
+msgid "Invalid top field: %s"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:235
+msgid "Duplicate bottom field"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:237
+#, c-format
+msgid "Invalid bottom field: %s"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:243
+msgid "Duplicate e-w resolution field"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:245 ../lib/gis/rd_cellhd.c:247
+#, c-format
+msgid "Invalid e-w resolution field: %s"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:253
+msgid "Duplicate 3D e-w resolution field"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:255 ../lib/gis/rd_cellhd.c:257
+#, c-format
+msgid "Invalid 3D e-w resolution field: %s"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:263
+msgid "Duplicate n-s resolution field"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:265 ../lib/gis/rd_cellhd.c:267
+#, c-format
+msgid "Invalid n-s resolution field: %s"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:273
+msgid "Duplicate 3D n-s resolution field"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:275 ../lib/gis/rd_cellhd.c:277
+#, c-format
+msgid "Invalid 3D n-s resolution field: %s"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:283
+msgid "Duplicate t-b resolution field"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:285 ../lib/gis/rd_cellhd.c:287
+#, c-format
+msgid "Invalid t-b resolution field: %s"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:293
+msgid "Duplicate rows field"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:295 ../lib/gis/rd_cellhd.c:297
+#, c-format
+msgid "Invalid rows field: %s"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:303
+msgid "Duplicate 3D rows field"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:305 ../lib/gis/rd_cellhd.c:307
+#, c-format
+msgid "Invalid 3D rows field: %s"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:313
+msgid "Duplicate cols field"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:315 ../lib/gis/rd_cellhd.c:317
+#, c-format
+msgid "Invalid cols field: %s"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:323
+msgid "Duplicate 3D cols field"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:325 ../lib/gis/rd_cellhd.c:327
+#, c-format
+msgid "Invalid 3D cols field: %s"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:333
+msgid "Duplicate depths field"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:335 ../lib/gis/rd_cellhd.c:337
+#, c-format
+msgid "Invalid depths field: %s"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:343
+msgid "Duplicate format field"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:345
+#, c-format
+msgid "Invalid format field: %s"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:351
+msgid "Duplicate compressed field"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:353
+#, c-format
+msgid "Invalid compressed field: %s"
+msgstr ""
+#: ../lib/gis/seek.c:52 ../lib/gis/seek.c:58
+msgid "Unable to seek"
+msgstr ""
+#: ../lib/gis/seek.c:56
+msgid "Seek offset out of range"
+msgstr ""
+#: ../lib/gis/cmprzstd.c:80 ../lib/gis/cmprzstd.c:95 ../lib/gis/cmprzstd.c:169
+msgid "GRASS needs to be compiled with ZSTD for ZSTD compression"
+msgstr ""
+#: ../lib/gis/cmprzstd.c:134 ../lib/gis/cmprzstd.c:196
+#, c-format
+msgid "ZSTD compression error %d: %s"
+msgstr ""
+#: ../lib/gis/paths.c:201
+#, c-format
+msgid "Unable to open file <%s> for reading"
+msgstr ""
+#: ../lib/gis/paths.c:217
+#, c-format
+msgid "Unable to fetch security info for <%s>"
+msgstr ""
+#: ../lib/gis/parser_wps.c:490
+msgid "Multiple outputs are not supported by WPS 1.0.0"
+msgstr ""
+#: ../lib/gis/color_rules.c:88
+msgid "no description"
+msgstr ""
+#: ../lib/gis/mapset_msc.c:90
+#, c-format
+msgid "Unable to make mapset element %s (%s): %s"
+msgstr ""
+#: ../lib/gis/mapset_msc.c:94
+#, c-format
+msgid "Unable to access mapset element %s (%s): %s"
+msgstr ""
+#: ../lib/gis/cmprzlib.c:142
+#, c-format
+msgid "ZLIB compression error %d: %s"
+msgstr ""
+#: ../lib/gis/cmprzlib.c:204
+#, c-format
+msgid "ZLIB decompression error %d: %s"
+msgstr ""
+#: ../lib/gis/ls.c:103
+#, c-format
+msgid "Unable to open directory %s"
+msgstr ""
+#: ../lib/gis/location.c:61
+#, c-format
+msgid "LOCATION <%s> not available"
+msgstr ""
+#: ../lib/gis/token.c:169
+msgid "parse error"
+msgstr ""
+#: ../lib/gis/done_msg.c:38
+#, c-format
+msgid "%s complete. %s"
+msgstr ""
+#: ../lib/gis/parser_dependencies.c:122
+msgid "Internal error: option or flag not found"
+msgstr ""
+#: ../lib/gis/parser_dependencies.c:179
+#, c-format
+msgid "<%s> or <%s>"
+msgstr ""
+#, c-format
+msgid "<%s> and <%s>"
+msgstr ""
+#: ../lib/gis/parser_dependencies.c:212
+#, c-format
+msgid "Options %s are mutually exclusive"
+msgstr ""
+#: ../lib/gis/parser_dependencies.c:236
+#, c-format
+msgid "At least one of the following options is required: %s"
+msgstr ""
+#: ../lib/gis/parser_dependencies.c:270
+#, c-format
+msgid "Option <%s> requires at least one of %s"
+msgstr ""
+#: ../lib/gis/parser_dependencies.c:273
+#, c-format
+msgid "Option <%s> requires <%s>"
+msgstr ""
+#: ../lib/gis/parser_dependencies.c:305
+#, c-format
+msgid "Option %s requires all of %s"
+msgstr ""
+#: ../lib/gis/parser_dependencies.c:332
+#, c-format
+msgid "Option %s is mutually exclusive with all of %s"
+msgstr ""
+#: ../lib/gis/parser_dependencies.c:358
+#, c-format
+msgid "Either all or none of %s must be given"
+msgstr ""
+#: ../lib/gis/parser_dependencies.c:391 ../lib/gis/parser_dependencies.c:428
+#, c-format
+msgid "Internal error: invalid rule type: %d"
+msgstr ""
+#: ../lib/gis/get_projinfo.c:37 ../lib/gis/get_projinfo.c:66
+#, c-format
+msgid "<%s> file not found for location <%s>"
+msgstr ""
+#: ../lib/gis/home.c:39
+msgid "Unable to determine user's home directory"
+msgstr ""
+#: ../lib/gis/home.c:120
+#, c-format
+msgid "Failed to create directory [%s]"
+msgstr ""
+#: ../lib/gis/debug.c:80
+#, c-format
+msgid "Cannot open debug file '%s'"
+msgstr ""
+#: ../lib/gis/worker.c:84
+msgid "Task already has a worker"
+msgstr ""
+#: ../lib/gis/compress.c:143 ../lib/gis/compress.c:208
+#: ../lib/gis/compress.c:225 ../lib/gis/compress.c:240
+msgid "Request for unsupported compressor"
+msgstr ""
+#: ../lib/gis/compress.c:255
+msgid "No destination buffer allocated"
+msgstr ""
+#: ../lib/gis/compress.c:262
+#, c-format
+msgid "Invalid read size %d"
+msgstr ""
+#: ../lib/gis/compress.c:283
+#, c-format
+msgid "Unable to read %d bytes: end of file"
+msgstr ""
+#: ../lib/gis/compress.c:285
+#, c-format
+msgid "Unable to read %d bytes: %s"
+msgstr ""
+#: ../lib/gis/compress.c:360 ../lib/gis/compress.c:383
+#: ../lib/gis/compress.c:424
+msgid "Unable to write compression flag"
+msgstr ""
+#: ../lib/gis/compress.c:371 ../lib/gis/compress.c:394
+#: ../lib/gis/compress.c:437
+#, c-format
+msgid "Unable to write %d bytes: nothing written"
+msgstr ""
+#: ../lib/gis/compress.c:373 ../lib/gis/compress.c:396
+#: ../lib/gis/compress.c:439
+#, c-format
+msgid "Unable to write %d bytes: %s"
+msgstr ""
+#: ../lib/gis/timestamp.c:292
+#, c-format
+msgid "Unable to create timestamp file for %s map <%s@%s>"
+msgstr ""
+#: ../lib/gis/timestamp.c:301
+#, c-format
+msgid "Invalid timestamp specified for %s map <%s@%s>"
+msgstr ""
+#: ../lib/gis/timestamp.c:331
+#, c-format
+msgid "Unable to open timestamp file for %s map <%s@%s>"
+msgstr ""
+#: ../lib/gis/timestamp.c:340
+#, c-format
+msgid "Invalid timestamp file for %s map <%s@%s>"
+msgstr ""
+#: ../lib/gis/timestamp.c:479
+#, c-format
+msgid "Unable to open timestamp file for vector map <%s@%s>"
+msgstr ""
+#: ../lib/gis/timestamp.c:488
+#, c-format
+msgid "Invalid timestamp file for vector map <%s@%s>"
+msgstr ""
+#: ../lib/gis/timestamp.c:524
+#, c-format
+msgid "Unable to create timestamp file for vector map <%s@%s>"
+msgstr ""
+#: ../lib/gis/timestamp.c:533
+#, c-format
+msgid "Invalid timestamp specified for vector map <%s@%s>"
+msgstr ""
+#: ../lib/gis/legal_name.c:39
+#, c-format
+msgid "Illegal filename <%s>. Cannot start with '.' or be 'NULL'."
+msgstr ""
+#: ../lib/gis/legal_name.c:46
+#, c-format
+msgid "Illegal filename <%s>. Character <%c> not allowed.\n"
+msgstr ""
+#: ../lib/gis/legal_name.c:77 ../lib/gis/legal_name.c:81
+#, c-format
+msgid "Output raster map name <%s> is not valid map name"
+msgstr ""
+#: ../lib/gis/legal_name.c:118 ../lib/gis/legal_name.c:122
+#, c-format
+msgid "Output raster map <%s> is used as input"
+msgstr ""
+#: ../lib/gis/proj3.c:121 ../lib/vector/Vlib/header.c:552
+msgid "Unknown projection"
+msgstr ""
+#: ../lib/gis/get_window.c:118
+#, c-format
+msgid "Unable to open element file <%s> for <%s@%s>"
+msgstr ""
+#: ../lib/gis/get_window.c:123
+#, c-format
+msgid "Region file %s/%s/%s is empty"
+msgstr ""
+#: ../lib/gis/find_file.c:114
+#, c-format
+msgid "Data element '%s/%s' was found in more mapsets (also found in <%s>)"
+msgstr ""
+#: ../lib/gis/find_file.c:127
+#, c-format
+msgid "Using <%s@%s>..."
+msgstr ""
+#: ../lib/gis/mkstemp.c:132
+msgid "Attempt to create read-only temporary file"
+msgstr ""
+#: ../lib/gis/mkstemp.c:138
+#, c-format
+msgid "Unrecognised access mode: %o"
+msgstr ""
+#: ../lib/gis/mapset.c:38
+msgid "MAPSET is not set"
+msgstr ""
+#: ../lib/gis/mapset.c:80
+#, c-format
+msgid "MAPSET <%s> not available"
+msgstr ""
+#: ../lib/db/dbmi_client/table.c:46 ../lib/db/dbmi_client/delete_tab.c:40
+#, c-format
+msgid "Unable open database <%s> by driver <%s>"
+msgstr ""
+#: ../lib/db/dbmi_client/table.c:110 ../lib/db/dbmi_client/copy_tab.c:242
+#: ../lib/db/dbmi_client/copy_tab.c:319 ../lib/vector/Vlib/write_ogr.c:211
+#, c-format
+msgid "Unable to open select cursor: '%s'"
+msgstr ""
+#: ../lib/db/dbmi_client/delete_tab.c:53
+#, c-format
+msgid "Unable to drop table: '%s'"
+msgstr ""
+#: ../lib/db/dbmi_client/db.c:41 ../lib/db/dbmi_client/copy_tab.c:107
+#: ../lib/db/dbmi_client/copy_tab.c:127 ../lib/vector/Vlib/write_ogr.c:193
+#: ../lib/vector/Vlib/write_pg.c:2910 ../lib/vector/Vlib/ascii.c:404
+#, c-format
+msgid "Unable to start driver <%s>"
+msgstr ""
+#: ../lib/db/dbmi_client/copy_tab.c:91
+#, c-format
+msgid "Array of values to select from column <%s> is empty"
+msgstr ""
+#: ../lib/db/dbmi_client/copy_tab.c:151
+#, c-format
+msgid "Unable to get list tables in database <%s>"
+msgstr ""
+#: ../lib/db/dbmi_client/copy_tab.c:189
+#, c-format
+msgid "Table <%s> already exists in database and will be overwritten"
+msgstr ""
+#: ../lib/db/dbmi_client/copy_tab.c:194
+#, c-format
+msgid "Table <%s> already exists in database <%s>"
+msgstr ""
+#: ../lib/db/dbmi_client/copy_tab.c:274
+#, c-format
+msgid "Column <%s> is not integer"
+msgstr ""
+#: ../lib/db/dbmi_client/copy_tab.c:294
+#, c-format
+msgid "Unable to create table <%s>"
+msgstr ""
+#: ../lib/db/dbmi_client/copy_tab.c:338 ../lib/vector/Vlib/write_ogr.c:587
+#: ../lib/vector/Vlib/write_pg.c:2017
+#, c-format
+msgid "Unable to fetch data from table <%s>"
+msgstr ""
+#: ../lib/db/dbmi_client/copy_tab.c:394
+#, c-format
+msgid "Unknown column type (column <%s>)"
+msgstr ""
+#: ../lib/db/dbmi_client/select.c:119 ../lib/db/dbmi_client/select.c:221
+#: ../lib/db/dbmi_client/select.c:288
+msgid "Missing column name"
+msgstr ""
+#: ../lib/db/dbmi_client/select.c:216 ../lib/db/dbmi_client/select.c:283
+msgid "Missing key column name"
+msgstr ""
+#: ../lib/db/dbmi_client/select.c:317 ../lib/vector/Vlib/cats.c:603
+#, c-format
+msgid "Unable select records from table <%s>"
+msgstr ""
+#: ../lib/db/dbmi_client/select.c:333
+msgid "Key column type is not integer"
+msgstr ""
+#: ../lib/db/dbmi_driver/d_error.c:35
+#, c-format
+msgid "DBMI-%s driver error:"
+msgstr ""
+#: ../lib/db/dbmi_base/test/test_columns.c:37
+msgid ""
+"\n"
+"++ Running column unit tests ++"
+msgstr ""
+#: ../lib/db/dbmi_base/test/test_columns.c:42
+msgid ""
+"\n"
+"-- column unit tests failure --"
+msgstr ""
+#: ../lib/db/dbmi_base/test/test_columns.c:44
+msgid ""
+"\n"
+"-- column unit tests finished successfully --"
+msgstr ""
+#: ../lib/db/dbmi_base/test/test_columns.c:57
+msgid ""
+"\n"
+"++ Run test copy column ++"
+msgstr ""
+#: ../lib/db/dbmi_base/test/test_columns.c:150
+msgid ""
+"\n"
+"++ Test copy column finished ++"
+msgstr ""
+#: ../lib/db/dbmi_base/test/test_main.c:83
+msgid "Performs unit and integration tests for the dbmi base library"
+msgstr ""
+#: ../lib/db/dbmi_base/test/test_table.c:38
+msgid ""
+"\n"
+"++ Running table unit tests ++"
+msgstr ""
+#: ../lib/db/dbmi_base/test/test_table.c:43
+msgid ""
+"\n"
+"-- Table unit tests failure --"
+msgstr ""
+#: ../lib/db/dbmi_base/test/test_table.c:45
+msgid ""
+"\n"
+"-- Table unit tests finished successfully --"
+msgstr ""
+#: ../lib/db/dbmi_base/default_name.c:136
+msgid "Programmer error"
+msgstr ""
+#: ../lib/db/dbmi_base/legal_dbname.c:38
+#, c-format
+msgid "Illegal table map name <%s>. May not contain '.' or 'NULL'."
+msgstr ""
+#: ../lib/db/dbmi_base/legal_dbname.c:45
+#, c-format
+msgid "Illegal table map name <%s>. Must start with a letter."
+msgstr ""
+#: ../lib/db/dbmi_base/legal_dbname.c:54
+#, c-format
+msgid "Illegal table map name <%s>. Character <%c> not allowed."
+msgstr ""
+#: ../lib/db/dbmi_base/valuefmt.c:52
+msgid "db_convert_Cstring_to_value(): unrecognized sqltype"
+msgstr ""
+#: ../lib/db/dbmi_base/valuefmt.c:91
+msgid "db_convert_value_into_string(): unrecongized sqltype-type"
+msgstr ""
+#: ../lib/db/dbmi_base/xdrvalue.c:82
+msgid "send data: invalid C-type"
+msgstr ""
+#: ../lib/db/dbmi_base/login.c:115
+#, c-format
+msgid "Unable to read file '%s'"
+msgstr ""
+#: ../lib/db/dbmi_base/login.c:126
+#, c-format
+msgid "Login file (%s) corrupted (line: %s)"
+msgstr ""
+#: ../lib/db/dbmi_base/login.c:164
+#, c-format
+msgid "Unable to write file '%s'"
+msgstr ""
+#: ../lib/db/dbmi_base/login.c:229
+#, c-format
+msgid "DB connection <%s/%s> already exists and will be overwritten"
+msgstr ""
+#: ../lib/db/dbmi_base/login.c:232
+#, c-format
+msgid "DB connection <%s/%s> already exists. Re-run '%s' with '--%s' flag to overwrite existing settings."
+msgstr ""
+#: ../lib/db/dbmi_base/error.c:72
+msgid "<NULL error message>"
+msgstr ""
+#: ../lib/db/dbmi_base/error.c:91
+msgid "dbmi: Protocol error"
+msgstr ""
+#: ../lib/db/dbmi_base/error.c:136
+msgid "dbmi: Out of Memory"
+msgstr ""
+#: ../lib/db/dbmi_base/error.c:149
+#, c-format
+msgid "dbmi: %s() not implemented"
+msgstr ""
+#: ../lib/db/dbmi_base/error.c:163
+#, c-format
+msgid "dbmi: Invalid procedure %d"
+msgstr ""
+#: ../lib/db/dbmi_base/xdrtable.c:109
+msgid "fetch: table has wrong number of columns"
+msgstr ""
+#: ../lib/db/dbmi_base/index.c:180
+msgid "db_set_index_column_name(): invalid column number"
+msgstr ""
+#: ../lib/db/dbmi_base/index.c:197
+msgid "db_get_index_column_name(): invalid column number"
+msgstr ""
+#: ../lib/vector/diglib/spindex_rw.c:98 ../lib/vector/diglib/spindex_rw.c:106
+msgid "Topology file must be written before spatial index file"
+msgstr ""
+#: ../lib/vector/diglib/spindex_rw.c:302
+#, c-format
+msgid "This version of GRASS (%d.%d) is too old to read this spatial index format. Try to rebuild topology or upgrade GRASS to at least version %d."
+msgstr ""
+#: ../lib/vector/diglib/spindex_rw.c:308
+#, c-format
+msgid "Your GRASS version does not fully support spatial index format %d.%d of the vector. Consider to rebuild topology or upgrade GRASS."
+msgstr ""
+#: ../lib/vector/diglib/spindex_rw.c:317
+#, c-format
+msgid "Spatial index format version %d.%d is not supported by this release. Please rebuild topology."
+msgstr ""
+#: ../lib/vector/diglib/plus_line.c:262 ../lib/vector/diglib/plus_line.c:302
+#, c-format
+msgid "Attempt to delete not registered line %d from node %d"
+msgstr ""
+#: ../lib/vector/diglib/cindex_rw.c:156
+#, c-format
+msgid "This version of GRASS (%d.%d) is too old to read this category index format. Try to rebuild topology or upgrade GRASS to at least version %d."
+msgstr ""
+#: ../lib/vector/diglib/frmt.c:45 ../lib/vector/diglib/frmt.c:70
+#, c-format
+msgid "Vector format not recognized: %s"
+msgstr ""
+#: ../lib/vector/diglib/frmt.c:79 ../lib/vector/diglib/frmt.c:88
+#, c-format
+msgid "Vector format '%s' not supported"
+msgstr ""
+#: ../lib/vector/diglib/frmt.c:97
+#, c-format
+msgid "Format definition is not correct: %s"
+msgstr ""
+#: ../lib/vector/diglib/port_init.c:158
+#, c-format
+msgid "Unable to find '%x' in %s"
+msgstr ""
+#: ../lib/vector/diglib/spindex.c:450
+#, c-format
+msgid "Unable to delete node %d from spatial index"
+msgstr ""
+#: ../lib/vector/diglib/spindex.c:493
+#, c-format
+msgid "Unable to delete line %d from spatial index"
+msgstr ""
+#: ../lib/vector/diglib/spindex.c:529
+msgid "Attempt to delete sidx for dead area"
+msgstr ""
+#: ../lib/vector/diglib/spindex.c:546
+#, c-format
+msgid "Unable to delete area %d from spatial index"
+msgstr ""
+#: ../lib/vector/diglib/spindex.c:595
+#, c-format
+msgid "Unable to delete isle %d from spatial index"
+msgstr ""
+#: ../lib/vector/diglib/plus.c:222
+msgid "Unable read topology for nodes"
+msgstr ""
+#: ../lib/vector/diglib/plus.c:227
+#, c-format
+msgid "Unable to read topology for node %d"
+msgstr ""
+#: ../lib/vector/diglib/plus.c:232
+msgid "Unable read topology for lines"
+msgstr ""
+#: ../lib/vector/diglib/plus.c:237
+#, c-format
+msgid "Unable to read topology for line %d"
+msgstr ""
+#: ../lib/vector/diglib/plus.c:242
+msgid "Unable to read topo for areas"
+msgstr ""
+#: ../lib/vector/diglib/plus.c:247
+#, c-format
+msgid "Unable read topology for area %d"
+msgstr ""
+#: ../lib/vector/diglib/plus.c:252
+msgid "Unable to read topology for isles"
+msgstr ""
+#: ../lib/vector/diglib/plus.c:257
+#, c-format
+msgid "Unable to read topology for isle %d"
+msgstr ""
+#: ../lib/vector/diglib/plus.c:279 ../lib/vector/diglib/plus.c:305
+msgid "Unable to write head to plus file"
+msgstr ""
+#: ../lib/vector/diglib/plus.c:284
+msgid "Unable to write nodes to plus file"
+msgstr ""
+#: ../lib/vector/diglib/plus.c:289
+msgid "Unable to write lines to plus file"
+msgstr ""
+#: ../lib/vector/diglib/plus.c:294
+msgid "Unable to write areas to plus file"
+msgstr ""
+#: ../lib/vector/diglib/plus.c:299
+msgid "Unable to write isles to plus file"
+msgstr ""
+#: ../lib/vector/diglib/plus_node.c:213
+#, c-format
+msgid "Attempt to read line angle for the line which is not connected to the node: node %d, line %d"
+msgstr ""
+#: ../lib/vector/diglib/file.c:159
+msgid "Writing to file loaded to memory not supported"
+msgstr ""
+#: ../lib/vector/diglib/file.c:197
+msgid "Unable to load file to memory, file not open"
+msgstr ""
+#: ../lib/vector/diglib/file.c:212
+msgid "Vector memory mode not supported, using 'AUTO'"
+msgstr ""
+#: ../lib/vector/diglib/portable.c:208 ../lib/vector/diglib/portable.c:241
+#: ../lib/vector/diglib/portable.c:683 ../lib/vector/diglib/plus_struct.c:563
+msgid "Vector exceeds supported file size limit"
+msgstr ""
+#: ../lib/vector/diglib/test.c:58
+msgid "Unable to open test.tmp file"
+msgstr ""
+#: ../lib/vector/diglib/test.c:75
+#, c-format
+msgid "Error in read/write portable double, byte_order = %d Written: %.16e3E Read: %.16e3E"
+msgstr ""
+#: ../lib/vector/diglib/test.c:89
+#, c-format
+msgid "Error in read/write portable float, byte_order = %d Written: %.8e3E Read: %.8e3E"
+msgstr ""
+#: ../lib/vector/diglib/test.c:104
+#, c-format
+msgid "Error in read/write portable off_t, byte_order = %d Written: %lu Read: %lu"
+msgstr ""
+#: ../lib/vector/diglib/test.c:119
+#, c-format
+msgid "Error in read/write portable long, byte_order = %d Written: %lu Read: %lu"
+msgstr ""
+#: ../lib/vector/diglib/test.c:134
+#, c-format
+msgid "Error in read/write portable int, byte_order = %d Written: %d Read: %d"
+msgstr ""
+#: ../lib/vector/diglib/test.c:150
+#, c-format
+msgid "Error in read/write portable short, byte_order = %d Written: %d Read: %d"
+msgstr ""
+#: ../lib/vector/diglib/test.c:165
+#, c-format
+msgid "Error in read/write portable char, byte_order = %d Written: %d Read: %d"
+msgstr ""
+#: ../lib/vector/diglib/plus_area.c:218 ../lib/vector/diglib/plus_area.c:718
+#, c-format
+msgid "Line %d already has area/isle %d to left"
+msgstr ""
+#: ../lib/vector/diglib/plus_area.c:228 ../lib/vector/diglib/plus_area.c:726
+#, c-format
+msgid "Line %d already has area/isle %d to right"
+msgstr ""
+#: ../lib/vector/diglib/plus_area.c:282
+msgid "Isle already registered in area"
+msgstr ""
+#: ../lib/vector/diglib/plus_area.c:316
+msgid "Attempt to delete isle from dead area"
+msgstr ""
+#: ../lib/vector/diglib/plus_area.c:324
+#, c-format
+msgid "Attempt to delete not registered isle %d from area %d"
+msgstr ""
+#: ../lib/vector/diglib/plus_area.c:371
+msgid "Attempt to delete dead area"
+msgstr ""
+#: ../lib/vector/diglib/plus_area.c:410
+#, c-format
+msgid "Dead centroid %d registered for area (bug in the vector library)"
+msgstr ""
+#: ../lib/vector/diglib/plus_area.c:433
+#, c-format
+msgid "Attempt to delete area %d info from dead isle %d"
+msgstr ""
+#: ../lib/vector/diglib/plus_area.c:784
+#, c-format
+msgid "Attempt to delete isle %d info from dead area %d"
+msgstr ""
+#: ../lib/vector/diglib/plus_struct.c:523
+#, c-format
+msgid "This version of GRASS (%d.%d) is too old to read this topology format. Try to rebuild topology or upgrade GRASS to at least version %d."
+msgstr ""
+#: ../lib/vector/diglib/plus_struct.c:529
+#, c-format
+msgid "Your GRASS version does not fully support topology format %d.%d of the vector. Consider to rebuild topology or upgrade GRASS."
+msgstr ""
+#: ../lib/vector/diglib/plus_struct.c:539
+#, c-format
+msgid "Old topology format version %d.%d is not supported by this release. Try to rebuild topology using v.build or v.build.all module."
+msgstr ""
+#: ../lib/vector/rtree/test_suite/test_basics.c:40
+msgid ""
+"\n"
+"++ Running basic unit tests ++"
+msgstr ""
+#: ../lib/vector/rtree/test_suite/test_basics.c:48
+msgid ""
+"\n"
+"-- Basic rtree unit tests failure --"
+msgstr ""
+#: ../lib/vector/rtree/test_suite/test_basics.c:50
+msgid ""
+"\n"
+"-- Basic rtree unit tests finished successfully --"
+msgstr ""
+#: ../lib/vector/rtree/test_suite/test_main.c:61
+msgid "Unit tests for the vector rtree library"
+msgstr ""
+#: ../lib/vector/vedit/cats.c:63
+#, c-format
+msgid "Unable to set category %d for (feature id %d)"
+msgstr ""
+#: ../lib/vector/vedit/delete.c:40
+#, c-format
+msgid "Attempt to delete dead feature (%d)"
+msgstr ""
+#: ../lib/vector/vedit/delete.c:72
+#, c-format
+msgid "No area found for centroid %d"
+msgstr ""
+#: ../lib/vector/vedit/delete.c:76
+#, c-format
+msgid "Duplicate centroid %d, unable to delete area"
+msgstr ""
+#: ../lib/vector/vedit/delete.c:105
+#, c-format
+msgid "Area %d without centroid"
+msgstr ""
+#: ../lib/vector/vedit/delete.c:121
+#, c-format
+msgid "Area %d has no boundaries"
+msgstr ""
+#: ../lib/vector/vedit/select.c:231
+msgid "Unknown query tool"
+msgstr ""
+#: ../lib/vector/Vlib/cindex.c:32
+msgid "Category index is not up to date"
+msgstr ""
+#: ../lib/vector/Vlib/cindex.c:38
+msgid "Layer index out of range"
+msgstr ""
+#: ../lib/vector/Vlib/cindex.c:268
+msgid "Category index out of range"
+msgstr ""
+#: ../lib/vector/Vlib/cindex.c:488
+#, c-format
+msgid "Unable to create category index file for vector map <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/cindex.c:497
+msgid "Error writing out category index file"
+msgstr ""
+#: ../lib/vector/Vlib/cindex.c:539 ../lib/vector/Vlib/open.c:393
+#, c-format
+msgid "Unable to open category index file for vector map <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/read_ogr.c:56 ../lib/vector/Vlib/read_ogr.c:157
+#: ../lib/vector/Vlib/read_ogr.c:242 ../lib/vector/Vlib/build_ogr.c:101
+#: ../lib/vector/Vlib/build_ogr.c:176 ../lib/vector/Vlib/write_ogr.c:69
+#: ../lib/vector/Vlib/write_ogr.c:105 ../lib/vector/Vlib/write_ogr.c:146
+#: ../lib/vector/Vlib/field.c:675 ../lib/vector/Vlib/write_sfa.c:298
+#: ../lib/vector/Vlib/rewind_ogr.c:47 ../lib/vector/Vlib/rewind_ogr.c:71
+#: ../lib/vector/Vlib/open_ogr.c:121 ../lib/vector/Vlib/open_ogr.c:154
+#: ../lib/vector/Vlib/open_ogr.c:231 ../lib/vector/Vlib/build_sfa.c:714
+#: ../lib/vector/Vlib/simple_features.c:310
+#: ../lib/vector/Vlib/header_finfo.c:41 ../lib/vector/Vlib/header_finfo.c:80
+#: ../lib/vector/Vlib/header_finfo.c:113 ../lib/vector/Vlib/header_finfo.c:153
+#: ../lib/vector/Vlib/header_finfo.c:254 ../lib/vector/Vlib/close.c:284
+#: ../lib/vector/Vlib/close_ogr.c:77 ../lib/vector/Vlib/close_ogr.c:111
+#: ../lib/proj/convert.c:64
+msgid "GRASS is not compiled with OGR support"
+msgstr ""
+#: ../lib/vector/Vlib/read_ogr.c:215 ../lib/vector/Vlib/read_ogr.c:224
+#, c-format
+msgid "Unable to get feature geometry, fid %ld"
+msgstr ""
+#: ../lib/vector/Vlib/read_ogr.c:344 ../lib/vector/Vlib/read_ogr.c:578
+#: ../lib/vector/Vlib/build_sfa.c:603
+#, c-format
+msgid "OGR feature type %d not supported"
+msgstr ""
+#: ../lib/vector/Vlib/read_ogr.c:382 ../lib/vector/Vlib/read_pg.c:482
+msgid "Feature without geometry. Skipped."
+msgstr ""
+#: ../lib/vector/Vlib/read_ogr.c:390
+msgid "OGR feature without ID"
+msgstr ""
+#: ../lib/vector/Vlib/read_ogr.c:514
+#, c-format
+msgid "OGR feature type '%s' not supported"
+msgstr ""
+#: ../lib/vector/Vlib/rewind.c:29 ../lib/vector/Vlib/open.c:59
+#: ../lib/vector/Vlib/write.c:56 ../lib/vector/Vlib/write.c:62
+#: ../lib/vector/Vlib/close.c:38 ../lib/vector/Vlib/read.c:32
+#: ../lib/vector/Vlib/build.c:37
+msgid "Requested format is not compiled in this version"
+msgstr ""
+#: ../lib/vector/Vlib/line.c:184 ../lib/vector/Vlib/line.c:217
+#: ../lib/vector/Vlib/line.c:250
+msgid "Index out of range in"
+msgstr ""
+#: ../lib/vector/Vlib/line.c:550
+msgid "Segment outside line, no segment created"
+msgstr ""
+#: ../lib/vector/Vlib/cats.c:45
+msgid "Vect_new_cats_struct(): Out of memory"
+msgstr ""
+#: ../lib/vector/Vlib/cats.c:127
+#, c-format
+msgid "Too many categories (%d), unable to set cat %d (layer %d)"
+msgstr ""
+#: ../lib/vector/Vlib/cats.c:419
+#, c-format
+msgid "Unable to convert category string '%s' (from '%s') to category range"
+msgstr ""
+#: ../lib/vector/Vlib/cats.c:572 ../lib/vector/Vlib/cats.c:668
+msgid "Layer number must be > 0 for category constraints"
+msgstr ""
+#: ../lib/vector/Vlib/cats.c:585
+#, c-format
+msgid "'%s' and '%s' parameters were supplied, cats will be ignored"
+msgstr ""
+#: ../lib/vector/Vlib/cats.c:593
+#, c-format
+msgid "Loading categories from table <%s>..."
+msgstr ""
+#: ../lib/vector/Vlib/cats.c:605
+#, c-format
+msgid "One category loaded"
+msgid_plural "%d categories loaded"
+msgstr[0] ""
+msgstr[1] ""
+#: ../lib/vector/Vlib/cats.c:627
+#, c-format
+msgid "No categories selected with '%s' option"
+msgstr ""
+#: ../lib/vector/Vlib/cats.c:637
+#, c-format
+msgid "%d errors in '%s' option"
+msgstr ""
+#: ../lib/vector/Vlib/copy.c:81
+#, c-format
+msgid "Unable to copy features. Input vector map <%s> is not open"
+msgstr ""
+#: ../lib/vector/Vlib/copy.c:102
+#, c-format
+msgid "Unable to create PostGIS layer <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/copy.c:134
+#, c-format
+msgid "Vector map <%s> not open on topological level. Areas will be skipped!"
+msgstr ""
+#: ../lib/vector/Vlib/copy.c:230 ../lib/vector/Vlib/copy.c:235
+msgid "Copying features..."
+msgstr ""
+#: ../lib/vector/Vlib/copy.c:232
+#, c-format
+msgid "Copying features (%s)..."
+msgstr ""
+#: ../lib/vector/Vlib/copy.c:358
+msgid "Writing new feature failed"
+msgstr ""
+#: ../lib/vector/Vlib/copy.c:364
+#, c-format
+msgid "%d features without category or from different layer skipped"
+msgstr ""
+#: ../lib/vector/Vlib/copy.c:396
+msgid "Exporting nodes..."
+msgstr ""
+#: ../lib/vector/Vlib/copy.c:424
+#, c-format
+msgid "Writing node %d failed"
+msgstr ""
+#: ../lib/vector/Vlib/copy.c:428 ../lib/vector/Vlib/close_pg.c:99
+#: ../lib/vector/Vlib/close_pg.c:146 ../lib/vector/Vlib/rewind_pg.c:56
+#: ../lib/vector/Vlib/rewind_pg.c:81 ../lib/vector/Vlib/read_pg.c:91
+#: ../lib/vector/Vlib/read_pg.c:214 ../lib/vector/Vlib/read_pg.c:298
+#: ../lib/vector/Vlib/read_pg.c:416 ../lib/vector/Vlib/write_pg.c:123
+#: ../lib/vector/Vlib/write_pg.c:157 ../lib/vector/Vlib/write_pg.c:196
+#: ../lib/vector/Vlib/write_pg.c:294 ../lib/vector/Vlib/write_pg.c:354
+#: ../lib/vector/Vlib/write_pg.c:476 ../lib/vector/Vlib/write_sfa.c:306
+#: ../lib/vector/Vlib/build_sfa.c:721 ../lib/vector/Vlib/simple_features.c:336
+#: ../lib/vector/Vlib/build_pg.c:117 ../lib/vector/Vlib/header_finfo.c:47
+#: ../lib/vector/Vlib/header_finfo.c:86 ../lib/vector/Vlib/header_finfo.c:123
+#: ../lib/vector/Vlib/header_finfo.c:171 ../lib/vector/Vlib/open_pg.c:143
+#: ../lib/vector/Vlib/open_pg.c:200 ../lib/vector/Vlib/open_pg.c:299
+#: ../lib/vector/Vlib/open_pg.c:349 ../lib/vector/Vlib/close.c:275
+#: ../lib/vector/Vlib/area.c:94 ../lib/vector/Vlib/area.c:499
+msgid "GRASS is not compiled with PostgreSQL support"
+msgstr ""
+#: ../lib/vector/Vlib/copy.c:502
+msgid "Exporting areas..."
+msgstr ""
+#: ../lib/vector/Vlib/copy.c:560 ../lib/vector/Vlib/copy.c:568
+#, c-format
+msgid "Writing area %d failed"
+msgstr ""
+#: ../lib/vector/Vlib/copy.c:576
+#, c-format
+msgid "%d areas without category or from different layer skipped"
+msgstr ""
+#: ../lib/vector/Vlib/copy.c:630
+#, c-format
+msgid "Unable to copy table <%s> for layer %d from <%s> to <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/copy.c:749
+#, c-format
+msgid "Unable to add database link for vector map <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/copy.c:764 ../lib/vector/Vlib/close_nat.c:102
+#: ../lib/vector/Vlib/map.c:317
+#, c-format
+msgid "Unable to copy table <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/copy.c:773
+#, c-format
+msgid "Unable to open database <%s> with driver <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/copy.c:780
+msgid "Unable to create index"
+msgstr ""
+#: ../lib/vector/Vlib/copy.c:786
+#, c-format
+msgid "Unable to grant privileges on table <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/remove_duplicates.c:199
+#, c-format
+msgid "Removed duplicates: %d"
+msgstr ""
+#: ../lib/vector/Vlib/level.c:34
+msgid "Map structure was never initialized"
+msgstr ""
+#: ../lib/vector/Vlib/level.c:36
+msgid "Map structure has been closed"
+msgstr ""
+#: ../lib/vector/Vlib/open.c:138
+#, c-format
+msgid "Programmer requested unknown access level %d"
+msgstr ""
+#: ../lib/vector/Vlib/open.c:232
+#, c-format
+msgid "Vector map <%s> not found in current mapset"
+msgstr ""
+#: ../lib/vector/Vlib/open.c:252
+msgid "Temporary vector maps can be accessed only in the current mapset"
+msgstr ""
+#: ../lib/vector/Vlib/open.c:277
+msgid "Vector map which is not in the current mapset cannot be opened for update"
+msgstr ""
+#: ../lib/vector/Vlib/open.c:311
+#, c-format
+msgid "Unable to read header file of vector map <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/open.c:352
+#, c-format
+msgid "Unable to open topology file for vector map <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/open.c:367 ../lib/vector/Vlib/open.c:871
+#: ../lib/vector/Vlib/build.c:866
+#, c-format
+msgid "Unable to open spatial index file for vector map <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/open.c:419
+#, c-format
+msgid "Unable to open vector map <%s> on level %d. Try to rebuild vector topology with v.build."
+msgstr ""
+#: ../lib/vector/Vlib/open.c:445
+#, c-format
+msgid "Building topology for OGR layer <%s> from datasource '%s'..."
+msgstr ""
+#: ../lib/vector/Vlib/open.c:453
+#, c-format
+msgid "Unable to open vector map <%s> on level %d"
+msgstr ""
+#: ../lib/vector/Vlib/open.c:507
+#, c-format
+msgid "Unable to open history file for vector map <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/open.c:777
+#, c-format
+msgid "Unable to create vector map: <%s> is not in the current mapset (%s)"
+msgstr ""
+#: ../lib/vector/Vlib/open.c:786
+#, c-format
+msgid "Unable to create vector map: <%s> is not SQL compliant"
+msgstr ""
+#: ../lib/vector/Vlib/open.c:813 ../lib/vector/Vlib/open.c:826
+#: ../lib/vector/Vlib/map.c:159
+#, c-format
+msgid "Unable to delete vector map <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/open.c:821 ../lib/vector/Vlib/map.c:155
+#: ../lib/vector/Vlib/map.c:249
+#, c-format
+msgid "Vector map <%s> already exists and will be overwritten"
+msgstr ""
+#: ../lib/vector/Vlib/open.c:846
+#, c-format
+msgid "Unable to open history file of vector map <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/open.c:887
+#, c-format
+msgid "Using OGR/%s format"
+msgstr ""
+#: ../lib/vector/Vlib/open.c:891
+msgid "Using PostGIS Topology format"
+msgstr ""
+#: ../lib/vector/Vlib/open.c:893
+msgid "Using PostGIS format"
+msgstr ""
+#: ../lib/vector/Vlib/open.c:896
+msgid "Using native format"
+msgstr ""
+#: ../lib/vector/Vlib/open.c:985
+#, c-format
+msgid "Unable to stat file <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/open.c:1049
+#, c-format
+msgid "unknown %d (update Vect_maptype_info)"
+msgstr ""
+#: ../lib/vector/Vlib/open.c:1138
+msgid "Size of 'coor' file differs from value saved in topology file"
+msgstr ""
+#: ../lib/vector/Vlib/open.c:1149 ../lib/vector/Vlib/open.c:1248
+#, c-format
+msgid "Please rebuild topology for vector map <%s@%s>"
+msgstr ""
+#: ../lib/vector/Vlib/open.c:1237
+msgid "Size of 'coor' file differs from value saved in sidx file"
+msgstr ""
+#: ../lib/vector/Vlib/open.c:1317
+msgid "Unable to open OGR file"
+msgstr ""
+#: ../lib/vector/Vlib/open.c:1343
+msgid "OGR output also detected, using OGR"
+msgstr ""
+#: ../lib/vector/Vlib/open.c:1355 ../lib/vector/Vlib/write_pg.c:612
+#: ../lib/vector/Vlib/write_pg.c:880 ../lib/vector/Vlib/build_pg.c:411
+msgid "Unable to open PG file"
+msgstr ""
+#: ../lib/vector/Vlib/write.c:30 ../lib/vector/Vlib/write.c:36
+#: ../lib/vector/Vlib/write.c:42 ../lib/vector/Vlib/write.c:49
+#: ../lib/vector/Vlib/read.c:25
+msgid "for this format/level not supported"
+msgstr ""
+#: ../lib/vector/Vlib/write.c:194
+#, c-format
+msgid "Unable to write feature in vector map <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/write.c:234
+#, c-format
+msgid "Unable to rewrite feature/offset %lu in vector map <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/write.c:266
+#, c-format
+msgid "Unable to delete feature/offset %lu from vector map <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/write.c:299
+msgid "Unable to restore feature/offset %"
+msgstr ""
+#: ../lib/vector/Vlib/write.c:308
+#, c-format
+msgid "Vector map <%s> is not opened"
+msgstr ""
+#: ../lib/vector/Vlib/write.c:313
+#, c-format
+msgid "Vector map <%s> is not opened in write mode"
+msgstr ""
+#: ../lib/vector/Vlib/dgraph.c:432
+msgid "Trying to add more edges to the planar_graph than the initial allocation size allows"
+msgstr ""
+#: ../lib/vector/Vlib/remove_areas.c:107 ../lib/vector/Vlib/remove_areas.c:268
+msgid "Area is composed of dead boundary"
+msgstr ""
+#: ../lib/vector/Vlib/remove_areas.c:194 ../lib/vector/Vlib/remove_areas.c:602
+#, c-format
+msgid "%d areas of total size %g removed"
+msgstr ""
+#: ../lib/vector/Vlib/remove_areas.c:395
+msgid "Could not delete line from coor"
+msgstr ""
+#: ../lib/vector/Vlib/remove_areas.c:458
+msgid "dissolve_neighbour > 0, failed to build new area"
+msgstr ""
+#: ../lib/vector/Vlib/remove_areas.c:463 ../lib/vector/Vlib/remove_areas.c:501
+msgid "Dissolve with neighbour area: corrupt topology"
+msgstr ""
+#: ../lib/vector/Vlib/remove_areas.c:497
+msgid "Failed to build new area"
+msgstr ""
+#: ../lib/vector/Vlib/remove_areas.c:544 ../lib/vector/Vlib/remove_areas.c:571
+msgid "Failed to build new isle"
+msgstr ""
+#: ../lib/vector/Vlib/remove_areas.c:549 ../lib/vector/Vlib/remove_areas.c:576
+msgid "Dissolve with outer isle: corrupt topology"
+msgstr ""
+#: ../lib/vector/Vlib/remove_areas.c:581
+msgid "Area merging failed"
+msgstr ""
+#: ../lib/vector/Vlib/close_pg.c:66 ../lib/vector/Vlib/read_pg.c:1420
+#, c-format
+msgid "Unable to close cursor %s"
+msgstr ""
+#: ../lib/vector/Vlib/close_pg.c:139 ../lib/vector/Vlib/close_ogr.c:104
+#, c-format
+msgid "Unable to save feature index file for vector map <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/read_nat.c:144 ../lib/vector/Vlib/read_pg.c:331
+#: ../lib/vector/Vlib/write_pg.c:236 ../lib/vector/Vlib/write_pg.c:381
+#: ../lib/vector/Vlib/write_pg.c:396 ../lib/vector/Vlib/write_sfa.c:158
+#: ../lib/vector/Vlib/write_sfa.c:207 ../lib/vector/Vlib/read_sfa.c:50
+#: ../lib/vector/Vlib/write_nat.c:182 ../lib/vector/Vlib/write_nat.c:295
+#: ../lib/vector/Vlib/write_nat.c:651 ../lib/vector/Vlib/box.c:249
+#: ../lib/vector/Vlib/read.c:173
+#, c-format
+msgid "Attempt to access feature with invalid id (%d)"
+msgstr ""
+#: ../lib/vector/Vlib/read_nat.c:150 ../lib/vector/Vlib/read_pg.c:337
+#: ../lib/vector/Vlib/write_pg.c:242 ../lib/vector/Vlib/write_pg.c:402
+#: ../lib/vector/Vlib/write_pg.c:2592 ../lib/vector/Vlib/write_pg.c:2689
+#: ../lib/vector/Vlib/read_sfa.c:56 ../lib/vector/Vlib/write_nat.c:301
+#: ../lib/vector/Vlib/write_nat.c:657
+#, c-format
+msgid "Attempt to access dead feature %d"
+msgstr ""
+#: ../lib/vector/Vlib/read_pg.c:192 ../lib/vector/Vlib/read_sfa.c:117
+#, c-format
+msgid "Unexpected feature type (%d) - should be (%d)"
+msgstr ""
+#: ../lib/vector/Vlib/read_pg.c:272 ../lib/vector/Vlib/read_pg.c:471
+#, c-format
+msgid "Feature %ld without geometry skipped"
+msgstr ""
+#: ../lib/vector/Vlib/read_pg.c:365
+#, c-format
+msgid "Requesting invalid feature from cache (%d). Number of features in cache: %d"
+msgstr ""
+#: ../lib/vector/Vlib/read_pg.c:368
+#, c-format
+msgid "Feature %d: unexpected type (%d) - should be %d"
+msgstr ""
+#: ../lib/vector/Vlib/read_pg.c:378 ../lib/vector/Vlib/build_sfa.c:354
+#: ../lib/vector/Vlib/build_sfa.c:364
+#, c-format
+msgid "Feature %d without geometry skipped"
+msgstr ""
+#: ../lib/vector/Vlib/read_pg.c:575
+msgid "No geometry or topo geometry column defined"
+msgstr ""
+#: ../lib/vector/Vlib/read_pg.c:585
+msgid "Random access not supported. Primary key not defined."
+msgstr ""
+#: ../lib/vector/Vlib/read_pg.c:652
+msgid "Inconsistency in topology: detected centroid (should be point)"
+msgstr ""
+#: ../lib/vector/Vlib/read_pg.c:662
+msgid "Inconsistency in topology: detected boundary (should be line)"
+msgstr ""
+#: ../lib/vector/Vlib/read_pg.c:787
+#, c-format
+msgid "Invalid WKB content: %d bytes"
+msgstr ""
+#: ../lib/vector/Vlib/read_pg.c:803
+msgid "Reading EWKB with 4-dimensional coordinates (XYZM) is not supported"
+msgstr ""
+#: ../lib/vector/Vlib/read_pg.c:884 ../lib/vector/Vlib/read_pg.c:1192
+#: ../lib/vector/Vlib/read_pg.c:1362 ../lib/vector/Vlib/read_pg.c:1455
+#: ../lib/vector/Vlib/write_pg.c:737 ../lib/vector/Vlib/write_pg.c:1176
+#: ../lib/vector/Vlib/write_pg.c:1285 ../lib/vector/Vlib/write_pg.c:1798
+#: ../lib/vector/Vlib/write_pg.c:1975 ../lib/vector/Vlib/write_pg.c:2333
+#, c-format
+msgid "Unsupported feature type %d"
+msgstr ""
+#: ../lib/vector/Vlib/read_pg.c:996 ../lib/vector/Vlib/read_pg.c:1066
+#: ../lib/vector/Vlib/read_pg.c:1137
+msgid "Length of input WKB is too small"
+msgstr ""
+#: ../lib/vector/Vlib/read_pg.c:1077
+#, c-format
+msgid "Invalid cache index %d (max: %d)"
+msgstr ""
+#: ../lib/vector/Vlib/read_pg.c:1215
+#, c-format
+msgid "Corrupted data. %s."
+msgstr ""
+#: ../lib/vector/Vlib/read_pg.c:1217
+msgid "Corrupted data"
+msgstr ""
+#: ../lib/vector/Vlib/read_pg.c:1252
+#, c-format
+msgid "Unable to parse '%s'"
+msgstr ""
+#: ../lib/vector/Vlib/read_pg.c:1530
+#, c-format
+msgid ""
+"Execution failed: %s (...)\n"
+"Reason: %s"
+msgstr ""
+#: ../lib/vector/Vlib/read_pg.c:1561
+#, c-format
+msgid ""
+"Execution failed: %s\n"
+"Reason: %s"
+msgstr ""
+#: ../lib/vector/Vlib/read_pg.c:1693
+#, c-format
+msgid ""
+"Unable to read features. Reason:\n"
+"%s"
+msgstr ""
+#: ../lib/vector/Vlib/build_ogr.c:72
+msgid "Empty OGR layer, nothing to build"
+msgstr ""
+#: ../lib/vector/Vlib/build_ogr.c:87 ../lib/vector/Vlib/build_pg.c:93
+#, c-format
+msgid "Feature table <%s> has no primary key defined"
+msgstr ""
+#: ../lib/vector/Vlib/build_ogr.c:89
+msgid "Random read is not supported by OGR for this layer. Unable to build topology."
+msgstr ""
+#: ../lib/vector/Vlib/build_ogr.c:95 ../lib/vector/Vlib/build_pg.c:101
+#, c-format
+msgid "Using external data format '%s' (feature type '%s')"
+msgstr ""
+#: ../lib/vector/Vlib/build_ogr.c:139
+#, c-format
+msgid "Unable to open fidx file for write <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/close_nat.c:74
+#, c-format
+msgid "Unable to create '%s': %s"
+msgstr ""
+#: ../lib/vector/Vlib/close_nat.c:81
+#, c-format
+msgid "Unable to copy '%s': %s"
+msgstr ""
+#: ../lib/vector/Vlib/close_nat.c:167
+#, c-format
+msgid "Unable to drop table <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/write_ogr.c:96 ../lib/vector/Vlib/write_pg.c:187
+#: ../lib/vector/Vlib/write_pg.c:255 ../lib/vector/Vlib/write_sfa.c:164
+msgid "Unable to rewrite feature (incompatible feature types)"
+msgstr ""
+#: ../lib/vector/Vlib/write_ogr.c:129 ../lib/vector/Vlib/open_ogr.c:65
+msgid "OGR layer not defined"
+msgstr ""
+#: ../lib/vector/Vlib/write_ogr.c:134 ../lib/vector/Vlib/write_pg.c:326
+#, c-format
+msgid "Invalid offset (%ld)"
+msgstr ""
+#: ../lib/vector/Vlib/write_ogr.c:140 ../lib/vector/Vlib/write_pg.c:347
+msgid "Unable to delete feature"
+msgstr ""
+#: ../lib/vector/Vlib/write_ogr.c:240
+#, c-format
+msgid "Creating field <%s> failed"
+msgstr ""
+#: ../lib/vector/Vlib/write_ogr.c:306 ../lib/vector/Vlib/write_pg.c:1105
+#, c-format
+msgid "Unsupported geometry type (%d)"
+msgstr ""
+#: ../lib/vector/Vlib/write_ogr.c:328
+#, c-format
+msgid "Unable to create OGR layer <%s> in '%s'"
+msgstr ""
+#: ../lib/vector/Vlib/write_ogr.c:340 ../lib/vector/Vlib/write_pg.c:1118
+#, c-format
+msgid "More layers defined, using driver <%s> and database <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/write_ogr.c:346 ../lib/vector/Vlib/write_pg.c:1123
+msgid "Database connection not defined. Unable to write attributes."
+msgstr ""
+#: ../lib/vector/Vlib/write_ogr.c:410 ../lib/vector/Vlib/write_pg.c:1238
+#: ../lib/vector/Vlib/write_pg.c:1403
+#, c-format
+msgid "No category defined for layer %d"
+msgstr ""
+#: ../lib/vector/Vlib/write_ogr.c:412 ../lib/vector/Vlib/write_pg.c:1240
+#: ../lib/vector/Vlib/write_pg.c:1405
+#, c-format
+msgid "Feature has more categories, using category %d (from layer %d)"
+msgstr ""
+#: ../lib/vector/Vlib/write_ogr.c:426
+msgid "Feature is not a point. Skipping."
+msgstr ""
+#: ../lib/vector/Vlib/write_ogr.c:434
+msgid "Feature is not a line. Skipping."
+msgstr ""
+#: ../lib/vector/Vlib/write_ogr.c:441
+msgid "Feature is not a polygon. Skipping."
+msgstr ""
+#: ../lib/vector/Vlib/write_ogr.c:448
+msgid "Feature is not a face. Skipping."
+msgstr ""
+#: ../lib/vector/Vlib/write_ogr.c:454
+#, c-format
+msgid "Unsupported feature type (%d)"
+msgstr ""
+#: ../lib/vector/Vlib/write_ogr.c:473
+msgid "Boundary is not closed. Feature skipped."
+msgstr ""
+#: ../lib/vector/Vlib/write_ogr.c:502
+msgid "Unable to writes feature attributes"
+msgstr ""
+#: ../lib/vector/Vlib/write_ogr.c:567
+#, c-format
+msgid "Feature without category of layer %d"
+msgstr ""
+#: ../lib/vector/Vlib/write_ogr.c:581 ../lib/vector/Vlib/write_pg.c:2013
+#, c-format
+msgid "Unable to select attributes for category %d"
+msgstr ""
+#: ../lib/vector/Vlib/write_ogr.c:593 ../lib/vector/Vlib/write_pg.c:2022
+#, c-format
+msgid "No database record for category %d, no attributes will be written"
+msgstr ""
+#: ../lib/vector/Vlib/write_ogr.c:626
+#, c-format
+msgid "Unable to create field <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/write_ogr.c:655 ../lib/vector/Vlib/write_pg.c:2082
+#, c-format
+msgid "Unsupported column type %d"
+msgstr ""
+#: ../lib/vector/Vlib/field.c:91
+msgid "Layer number must be 1 or greater"
+msgstr ""
+#: ../lib/vector/Vlib/field.c:96
+msgid "Unable to add attribute link, vector map is not opened in WRITE mode"
+msgstr ""
+#: ../lib/vector/Vlib/field.c:103
+msgid "Unable to add attribute link"
+msgstr ""
+#: ../lib/vector/Vlib/field.c:109
+msgid "Unable to write attribute links"
+msgstr ""
+#: ../lib/vector/Vlib/field.c:154
+msgid "Unable to write database links"
+msgstr ""
+#: ../lib/vector/Vlib/field.c:178
+msgid "Database connection not defined. Skipping."
+msgstr ""
+#: ../lib/vector/Vlib/field.c:185
+msgid "More DB links defined for input vector map. Using only first DB link for output."
+msgstr ""
+#: ../lib/vector/Vlib/field.c:261
+#, c-format
+msgid "Layer number %d or name <%s> already exists"
+msgstr ""
+#: ../lib/vector/Vlib/field.c:345
+#, c-format
+msgid ""
+"Default driver / database set to:\n"
+"driver: %s\n"
+"database: %s"
+msgstr ""
+#: ../lib/vector/Vlib/field.c:352
+msgid "Default driver is not set"
+msgstr ""
+#: ../lib/vector/Vlib/field.c:355
+msgid "Default database is not set"
+msgstr ""
+#: ../lib/vector/Vlib/field.c:428
+#, c-format
+msgid "Requested dblink %d, maximum link number %d"
+msgstr ""
+#: ../lib/vector/Vlib/field.c:614 ../lib/vector/Vlib/field.c:622
+#, c-format
+msgid "Error in rule on row %d in <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/field.c:690 ../lib/vector/Vlib/open_ogr.c:77
+#, c-format
+msgid "Unable to open OGR data source '%s'"
+msgstr ""
+#: ../lib/vector/Vlib/field.c:707
+#, c-format
+msgid "Unable to open OGR layer <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/field.c:734
+msgid "Unable to open OGR DBMI driver"
+msgstr ""
+#: ../lib/vector/Vlib/field.c:773
+msgid "All FID tests failed. Neither 'FID' nor 'ogc_fid' nor 'ogr_fid' nor 'gid' available in OGR DB table"
+msgstr ""
+#: ../lib/vector/Vlib/field.c:840
+#, c-format
+msgid "Feature table <%s> has no primary key defined. Unable to define DB links."
+msgstr ""
+#: ../lib/vector/Vlib/field.c:860
+msgid "GRASS not compiled with PostgreSQL support"
+msgstr ""
+#: ../lib/vector/Vlib/field.c:892
+msgid "Unknown vector map format"
+msgstr ""
+#: ../lib/vector/Vlib/field.c:925
+#, c-format
+msgid "Unable to create database definition file for vector map <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/field.c:1020
+msgid "Bug: attempt to update map which is not in current mapset"
+msgstr ""
+#: ../lib/vector/Vlib/snap.c:223 ../lib/vector/Vlib/snap.c:582
+msgid "Snap vertices Pass 1: select points"
+msgstr ""
+#: ../lib/vector/Vlib/snap.c:270 ../lib/vector/Vlib/snap.c:636
+msgid "Snap vertices Pass 2: assign anchor vertices"
+msgstr ""
+#: ../lib/vector/Vlib/snap.c:339 ../lib/vector/Vlib/snap.c:705
+msgid "Snap vertices Pass 3: snap to assigned points"
+msgstr ""
+#: ../lib/vector/Vlib/snap.c:525 ../lib/vector/Vlib/snap.c:888
+#, c-format
+msgid "Snapped vertices: %d"
+msgstr ""
+#: ../lib/vector/Vlib/snap.c:526 ../lib/vector/Vlib/snap.c:889
+#, c-format
+msgid "New vertices: %d"
+msgstr ""
+#: ../lib/vector/Vlib/snap.c:916
+msgid "Reading features..."
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:285
+#, c-format
+msgid "Unable to rewrite feature %d"
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:321 ../lib/vector/Vlib/write_pg.c:811
+#: ../lib/vector/Vlib/write_pg.c:1213 ../lib/vector/Vlib/write_pg.c:1371
+#: ../lib/vector/Vlib/simple_features.c:324
+msgid "No connection defined"
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:452
+#, c-format
+msgid "Unable to delete feature (%s) %d"
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:554 ../lib/vector/Vlib/write_pg.c:1301
+#: ../lib/vector/Vlib/write_sfa.c:349
+msgid "Boundary is not closed. Skipping."
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:773
+#, c-format
+msgid "Building spatial index on <%s>..."
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:841
+#, c-format
+msgid "Schema <%s> doesn't exist, created"
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:920
+#, c-format
+msgid "Creating topology schema <%s>..."
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:934
+#, c-format
+msgid "Adding new topology column <%s>..."
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:1072 ../lib/vector/Vlib/open_pg.c:85
+#: ../lib/vector/Vlib/open_pg.c:232
+msgid "Connection string not defined"
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:1077 ../lib/vector/Vlib/write_pg.c:1217
+#: ../lib/vector/Vlib/write_pg.c:1375 ../lib/vector/Vlib/open_pg.c:90
+#: ../lib/vector/Vlib/open_pg.c:237
+msgid "PostGIS feature table not defined"
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:1130
+msgid "Unable to create new PostGIS feature table"
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:1144
+msgid "Unable to create new PostGIS topology schema"
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:1251
+#, c-format
+msgid "Point skipped (output feature type: %s)"
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:1258
+#, c-format
+msgid "Line skipped (output feature type: %s)"
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:1265
+#, c-format
+msgid "Centroid skipped (output feature type: %s)"
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:1272
+#, c-format
+msgid "Boundary skipped (output feature type: %s)"
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:1279
+#, c-format
+msgid "Face skipped (output feature type: %s)"
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:1365
+#, c-format
+msgid "Invalid feature type (%d) for nodes"
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:1379
+msgid "PostGIS topology schema not defined"
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:1880
+msgid "Trying to insert 3D data into feature table which store 2D data only"
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:1885
+msgid "Trying to insert 2D data into feature table which store 3D data only"
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:1910
+msgid "Unable to insert topological element into PostGIS Topology schema"
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:2048
+#, c-format
+msgid "FID column must be integer, column <%s> ignored!"
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:2089
+msgid "Invalid value for FID column: NULL"
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:2181
+#, c-format
+msgid "Invalid feature %d (max: %d)"
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:2195
+#, c-format
+msgid "Invalid feature type (%d) for node"
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:2199
+#, c-format
+msgid "Invalid node %d (%d)"
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:2277
+#, c-format
+msgid "Unable to determine next left/right edge for edge %d"
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:2282
+msgid "Unable to insert new edge. Topology not available."
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:2381 ../lib/vector/Vlib/write_pg.c:2388
+msgid "Invalid topology"
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:2587 ../lib/vector/Vlib/write_pg.c:2684
+#, c-format
+msgid "Attempt to access non-existing feature %d"
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:2618
+msgid "Unable to determine next left/right edge"
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:2704
+msgid "Unable to create new face"
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:2842 ../lib/vector/Vlib/write_pg.c:2854
+#, c-format
+msgid "Unable to delete node %d"
+msgstr ""
+#: ../lib/vector/Vlib/write_sfa.c:117
+msgid "Unable to calculate centroid for area"
+msgstr ""
+#: ../lib/vector/Vlib/write_sfa.c:131 ../lib/vector/Vlib/write_sfa.c:173
+#: ../lib/vector/Vlib/write_sfa.c:273 ../lib/vector/Vlib/read_sfa.c:124
+msgid "GRASS is not compiled with OGR/PostgreSQL support"
+msgstr ""
+#: ../lib/vector/Vlib/write_sfa.c:219
+msgid "Attempt to delete dead feature"
+msgstr ""
+#: ../lib/vector/Vlib/write_sfa.c:311
+#, c-format
+msgid "Unsupported vector map format (%d)"
+msgstr ""
+#: ../lib/vector/Vlib/level_two.c:23
+#, c-format
+msgid "Vector map <%s> is not open at topological level"
+msgstr ""
+#: ../lib/vector/Vlib/level_two.c:284
+#, c-format
+msgid "Invalid node id: %d"
+msgstr ""
+#: ../lib/vector/Vlib/level_two.c:316
+#, c-format
+msgid "Nodes not available for line %d"
+msgstr ""
+#: ../lib/vector/Vlib/level_two.c:357
+#, c-format
+msgid "Areas not available for line %d"
+msgstr ""
+#: ../lib/vector/Vlib/level_two.c:362
+#, c-format
+msgid "Line %d is not a boundary"
+msgstr ""
+#: ../lib/vector/Vlib/level_two.c:445
+#, c-format
+msgid "Topology info not available for feature %d"
+msgstr ""
+#: ../lib/vector/Vlib/buffer2.c:361
+msgid "Line is not looped"
+msgstr ""
+#: ../lib/vector/Vlib/buffer2.c:443
+#, c-format
+msgid "Unexpected result of line_intersection() res = %d"
+msgstr ""
+#: ../lib/vector/Vlib/buffer2.c:589
+msgid "Next edge was visited (right) but it is not the first one !!! breaking loop"
+msgstr ""
+#: ../lib/vector/Vlib/buffer2.c:600
+msgid "Next edge was visited (left) but it is not the first one !!! breaking loop"
+msgstr ""
+#: ../lib/vector/Vlib/buffer2.c:648
+msgid "side != 0 feature not implemented"
+msgstr ""
+#: ../lib/vector/Vlib/buffer2.c:890 ../lib/vector/Vlib/buffer2.c:937
+msgid "zero area size"
+msgstr ""
+#: ../lib/vector/Vlib/buffer2.c:896 ../lib/vector/Vlib/buffer2.c:943
+msgid "Line was not closed"
+msgstr ""
+#: ../lib/vector/Vlib/buffer2.c:909 ../lib/vector/Vlib/buffer2.c:960
+msgid "Vect_get_point_in_poly() failed"
+msgstr ""
+#: ../lib/vector/Vlib/map.c:139 ../lib/vector/Vlib/map.c:245
+msgid "Vector map name is not SQL compliant"
+msgstr ""
+#: ../lib/vector/Vlib/map.c:143
+#, c-format
+msgid "Unable to find vector map <%s> in <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/map.c:179 ../lib/vector/Vlib/map.c:267
+#, c-format
+msgid "Unable to copy vector map <%s> to <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/map.c:331 ../lib/vector/Vlib/map.c:462
+#, c-format
+msgid "Unable to delete table <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/map.c:346
+#, c-format
+msgid "Unable to create index for table <%s>, key <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/map.c:402
+#, c-format
+msgid "Ignoring invalid mapset: %s"
+msgstr ""
+#: ../lib/vector/Vlib/map.c:407
+#, c-format
+msgid "Invalid vector map name <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/map.c:417
+#, c-format
+msgid "Unable to open header file for vector map <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/map.c:449
+#, c-format
+msgid "Unable to find table <%s> linked to vector map <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/map.c:472
+#, c-format
+msgid "Table <%s> linked to vector map <%s> does not exist"
+msgstr ""
+#: ../lib/vector/Vlib/map.c:485
+#, c-format
+msgid "Unable to open directory '%s'"
+msgstr ""
+#: ../lib/vector/Vlib/map.c:499
+#, c-format
+msgid "Unable to delete file '%s'"
+msgstr ""
+#: ../lib/vector/Vlib/map.c:519
+#, c-format
+msgid "Unable to rename directory '%s' to '%s'"
+msgstr ""
+#: ../lib/vector/Vlib/map.c:528
+#, c-format
+msgid "Unable to remove directory '%s': %s"
+msgstr ""
+#: ../lib/vector/Vlib/open_ogr.c:60
+msgid "OGR datasource not defined"
+msgstr ""
+#: ../lib/vector/Vlib/open_ogr.c:97
+#, c-format
+msgid "OGR layer <%s> not found"
+msgstr ""
+#: ../lib/vector/Vlib/open_ogr.c:145 ../lib/vector/Vlib/open_pg.c:193
+#, c-format
+msgid "Unable to open feature index file for vector map <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/open_ogr.c:191
+#, c-format
+msgid "Unable to get OGR driver <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/open_ogr.c:199
+#, c-format
+msgid "Unable to create OGR data source '%s'"
+msgstr ""
+#: ../lib/vector/Vlib/open_ogr.c:211
+#, c-format
+msgid "OGR layer <%s> already exists and will be overwritten"
+msgstr ""
+#: ../lib/vector/Vlib/open_ogr.c:215
+#, c-format
+msgid "Unable to delete OGR layer <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/open_ogr.c:221
+#, c-format
+msgid "OGR layer <%s> already exists in datasource '%s'"
+msgstr ""
+#: ../lib/vector/Vlib/open_ogr.c:279
+#, c-format
+msgid "Feature index format version %d.%d is not supported by this release. Try to rebuild topology or upgrade GRASS."
+msgstr ""
+#: ../lib/vector/Vlib/open_ogr.c:284
+#, c-format
+msgid "Your GRASS version does not fully support feature index format %d.%d of the vector. Consider to rebuild topology or upgrade GRASS."
+msgstr ""
+#: ../lib/vector/Vlib/intersect2.c:1231 ../lib/vector/Vlib/intersect2.c:1237
+#: ../lib/vector/Vlib/intersect2.c:1239 ../lib/vector/Vlib/intersect2.c:1291
+#: ../lib/vector/Vlib/intersect2.c:1300 ../lib/vector/Vlib/intersect2.c:1321
+#: ../lib/vector/Vlib/intersect2.c:1338 ../lib/vector/Vlib/intersect.c:1194
+#: ../lib/vector/Vlib/intersect.c:1200 ../lib/vector/Vlib/intersect.c:1202
+#: ../lib/vector/Vlib/intersect.c:1257 ../lib/vector/Vlib/intersect.c:1266
+#: ../lib/vector/Vlib/intersect.c:1287 ../lib/vector/Vlib/intersect.c:1304
+msgid "Error while adding point to array. Out of memory"
+msgstr ""
+#: ../lib/vector/Vlib/bridges.c:213
+#, c-format
+msgid "Removed lines: %d"
+msgstr ""
+#: ../lib/vector/Vlib/bridges.c:214
+#, c-format
+msgid "Removed bridges: %d"
+msgstr ""
+#: ../lib/vector/Vlib/ascii.c:84
+#, c-format
+msgid "Error reading ASCII file: (bad type) [%s]"
+msgstr ""
+#: ../lib/vector/Vlib/ascii.c:123
+#, c-format
+msgid "Error reading ASCII file: (unknown type) [%s]"
+msgstr ""
+#: ../lib/vector/Vlib/ascii.c:143
+msgid "End of ASCII file reached before end of coordinates"
+msgstr ""
+#: ../lib/vector/Vlib/ascii.c:155
+#, c-format
+msgid "Error reading ASCII file: (bad point) [%s]"
+msgstr ""
+#: ../lib/vector/Vlib/ascii.c:160
+#, c-format
+msgid "Unparsable longitude value: [%s]"
+msgstr ""
+#: ../lib/vector/Vlib/ascii.c:165
+#, c-format
+msgid "Unparsable latitude value: [%s]"
+msgstr ""
+#: ../lib/vector/Vlib/ascii.c:201
+msgid "End of ASCII file reached before end of categories"
+msgstr ""
+#: ../lib/vector/Vlib/ascii.c:212
+#, c-format
+msgid "Error reading categories: [%s]"
+msgstr ""
+#: ../lib/vector/Vlib/ascii.c:225
+msgid "Unable to copy points"
+msgstr ""
+#: ../lib/vector/Vlib/ascii.c:238
+#, c-format
+msgid "Vector map <%s> is 2D. %d 3D features (faces or kernels) skipped."
+msgstr ""
+#: ../lib/vector/Vlib/ascii.c:270
+#, c-format
+msgid ""
+"Unexpected data in vector header:\n"
+"[%s]"
+msgstr ""
+#: ../lib/vector/Vlib/ascii.c:306
+#, c-format
+msgid "Unknown keyword <%s> in vector head"
+msgstr ""
+#: ../lib/vector/Vlib/ascii.c:465
+#, c-format
+msgid "Column <%s> does not exist"
+msgstr ""
+#: ../lib/vector/Vlib/ascii.c:467
+msgid "Available columns:"
+msgstr ""
+#: ../lib/vector/Vlib/ascii.c:472
+msgid "Export cancelled"
+msgstr ""
+#: ../lib/vector/Vlib/ascii.c:505
+#, c-format
+msgid "Unknown type of column <%s>, export cancelled"
+msgstr ""
+#: ../lib/vector/Vlib/ascii.c:539
+#, c-format
+msgid "Unable to select record from table <%s> (key %s, column %s)"
+msgstr ""
+#: ../lib/vector/Vlib/ascii.c:661
+#, c-format
+msgid "Unknown feature type %d"
+msgstr ""
+#: ../lib/vector/Vlib/ascii.c:701
+#, c-format
+msgid "Feature has more categories. Only one category (%d) is exported."
+msgstr ""
+#: ../lib/vector/Vlib/ascii.c:718
+#, c-format
+msgid "Cannot select attributes for cat = %d"
+msgstr ""
+#: ../lib/vector/Vlib/ascii.c:724
+msgid "Unable to fetch data from table"
+msgstr ""
+#: ../lib/vector/Vlib/ascii.c:756 ../lib/vector/Vlib/net_build.c:216
+#: ../lib/vector/Vlib/net_build.c:501 ../lib/vector/Vlib/net_build.c:519
+#: ../lib/vector/Vlib/net_build.c:802 ../lib/vector/Vlib/net_build.c:820
+#: ../lib/vector/Vlib/net_build.c:981
+#, c-format
+msgid "Column <%s> not found in table <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/ascii.c:758
+#, c-format
+msgid "Column <%s>: unsupported data type"
+msgstr ""
+#: ../lib/vector/Vlib/ascii.c:840
+msgid "Unknown format"
+msgstr ""
+#: ../lib/vector/Vlib/ascii.c:850
+msgid "Topology not available, unable to process areas"
+msgstr ""
+#: ../lib/vector/Vlib/ascii.c:863
+#, c-format
+msgid "Unable to get boundary of area id %d"
+msgstr ""
+#: ../lib/vector/Vlib/ascii.c:875
+#, c-format
+msgid "Unable to get boundary of isle id %d (area id %d)"
+msgstr ""
+#: ../lib/vector/Vlib/ascii.c:889
+#, c-format
+msgid "%d features without category skipped. To export also features without category use '%s=-1'."
+msgstr ""
+#: ../lib/vector/Vlib/constraint.c:150
+msgid "Layer constraint ignored for non-native vector formats"
+msgstr ""
+#: ../lib/vector/Vlib/geos.c:52
+msgid "vector map is not opened"
+msgstr ""
+#: ../lib/vector/Vlib/geos.c:55
+#, c-format
+msgid "Vect_read_line_geos(): feature id %d is not reasonable (max features in vector map <%s>: %d)"
+msgstr ""
+#: ../lib/vector/Vlib/geos.c:60
+msgid "only native format supported"
+msgstr ""
+#: ../lib/vector/Vlib/geos.c:65 ../lib/vector/Vlib/geos.c:258
+msgid "Attempt to read dead line"
+msgstr ""
+#: ../lib/vector/Vlib/geos.c:90
+#, c-format
+msgid "Vect_read_area_geos(): unable to read area id %d"
+msgstr ""
+#: ../lib/vector/Vlib/geos.c:104
+#, c-format
+msgid "Vect_read_area_geos(): unable to read isle id %d of area id %d"
+msgstr ""
+#: ../lib/vector/Vlib/geos.c:205
+#, c-format
+msgid "Unable to read line offset %ld"
+msgstr ""
+#: ../lib/vector/Vlib/geos.c:412
+#, c-format
+msgid "Attempt to read points of nonexistent area id %d"
+msgstr ""
+#: ../lib/vector/Vlib/geos.c:472
+#, c-format
+msgid "Unable to read feature id %d"
+msgstr ""
+#: ../lib/vector/Vlib/header.c:86
+#, c-format
+msgid "Unable to create header file for vector map <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/header.c:129
+#, c-format
+msgid "Unable to open header file of vector <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/header.c:137
+#, c-format
+msgid "Corrupted row in head: %s"
+msgstr ""
+#: ../lib/vector/Vlib/header.c:175
+#, c-format
+msgid "Unknown keyword '%s' in vector head"
+msgstr ""
+#: ../lib/vector/Vlib/build_sfa.c:279 ../lib/vector/Vlib/build_sfa.c:546
+#, c-format
+msgid "Unable to calculate centroid for area %d"
+msgstr ""
+#: ../lib/vector/Vlib/build_sfa.c:305
+#, c-format
+msgid "Feature type %d not supported"
+msgstr ""
+#: ../lib/vector/Vlib/build_sfa.c:339 ../lib/vector/Vlib/build_sfa.c:632
+#: ../lib/vector/Vlib/build_nat.c:75
+msgid "Registering primitives..."
+msgstr ""
+#: ../lib/vector/Vlib/build_sfa.c:385 ../lib/vector/Vlib/build_sfa.c:664
+#: ../lib/vector/Vlib/build_nat.c:118
+#, c-format
+msgid "One primitive registered"
+msgid_plural "%d primitives registered"
+msgstr[0] ""
+msgstr[1] ""
+#: ../lib/vector/Vlib/build_sfa.c:386 ../lib/vector/Vlib/build_sfa.c:665
+#: ../lib/vector/Vlib/build_nat.c:119
+#, c-format
+msgid "One vertex registered"
+msgid_plural "%d vertices registered"
+msgstr[0] ""
+msgstr[1] ""
+#: ../lib/vector/Vlib/build_sfa.c:668
+#, c-format
+msgid "One feature without geometry skipped"
+msgid_plural "%d features without geometry skipped"
+msgstr[0] ""
+msgstr[1] ""
+#: ../lib/vector/Vlib/build_sfa.c:725
+#, c-format
+msgid "%s: Native format unsupported"
+msgstr ""
+#: ../lib/vector/Vlib/build_sfa.c:751
+msgid "Feature index is built only for non-native formats. Nothing to dump."
+msgstr ""
+#: ../lib/vector/Vlib/simple_features.c:225
+#, c-format
+msgid "Unknown Simple Features type (%d)"
+msgstr ""
+#: ../lib/vector/Vlib/simple_features.c:332
+msgid "Unable to get number of simple features"
+msgstr ""
+#: ../lib/vector/Vlib/simple_features.c:341
+#, c-format
+msgid "Unable to report simple features for vector map <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/build_pg.c:88
+msgid "No DB connection"
+msgstr ""
+#: ../lib/vector/Vlib/build_pg.c:95
+msgid "Random read is not supported for this layer. Unable to build topology."
+msgstr ""
+#: ../lib/vector/Vlib/build_pg.c:105
+msgid "Building pseudo-topology over simple features..."
+msgstr ""
+#: ../lib/vector/Vlib/build_pg.c:107
+#, c-format
+msgid "Building topology from PostGIS topology schema <%s>..."
+msgstr ""
+#: ../lib/vector/Vlib/build_pg.c:212 ../lib/vector/Vlib/open_pg.c:1485
+#, c-format
+msgid "Inconsistency in topology: number of nodes %d (should be %d)"
+msgstr ""
+#: ../lib/vector/Vlib/build_pg.c:237
+msgid "Cleaning-up topology schema..."
+msgstr ""
+#: ../lib/vector/Vlib/build_pg.c:282
+msgid "Updating faces..."
+msgstr ""
+#: ../lib/vector/Vlib/build_pg.c:314
+msgid "Updating edges..."
+msgstr ""
+#: ../lib/vector/Vlib/build_pg.c:323
+msgid "Inconsistency in topology detected. Dead line found."
+msgstr ""
+#: ../lib/vector/Vlib/build_pg.c:377
+msgid "Updating TopoGeometry data..."
+msgstr ""
+#: ../lib/vector/Vlib/build_pg.c:462
+#, c-format
+msgid "Unsupported topo geometry type %d"
+msgstr ""
+#: ../lib/vector/Vlib/build_pg.c:491
+#, c-format
+msgid "Unable to create <%s.%s>"
+msgstr ""
+#: ../lib/vector/Vlib/build_pg.c:642
+msgid "Unable to write nodes, offset array mismatch"
+msgstr ""
+#: ../lib/vector/Vlib/build_pg.c:671
+msgid "Unable to write nodes"
+msgstr ""
+#: ../lib/vector/Vlib/build_pg.c:716
+#, c-format
+msgid "Inconsistency in topology: number of boundaries %d (should be %d)"
+msgstr ""
+#: ../lib/vector/Vlib/build_pg.c:739
+msgid "Unable to write lines"
+msgstr ""
+#: ../lib/vector/Vlib/build_pg.c:790
+#, c-format
+msgid "Topology for centroid %d not available. Area %d skipped"
+msgstr ""
+#: ../lib/vector/Vlib/build_pg.c:1000
+msgid "Create simple features topology from topogeometry data..."
+msgstr ""
+#: ../lib/vector/Vlib/build_pg.c:1018
+#, c-format
+msgid "Unable to build simple features from topogeometry data. Unsupported type %d."
+msgstr ""
+#: ../lib/vector/Vlib/clean_nodes.c:248
+#, c-format
+msgid "Modifications: %d"
+msgstr ""
+#: ../lib/vector/Vlib/open_pg.c:109 ../lib/vector/Vlib/open_pg.c:267
+msgid "No feature tables found in database."
+msgstr ""
+#: ../lib/vector/Vlib/open_pg.c:133
+#, c-format
+msgid "Feature table <%s> not found in 'geometry_columns'"
+msgstr ""
+#: ../lib/vector/Vlib/open_pg.c:181
+msgid "Topology schema not found."
+msgstr ""
+#: ../lib/vector/Vlib/open_pg.c:273
+#, c-format
+msgid "PostGIS layer <%s.%s> already exists and will be overwritten"
+msgstr ""
+#: ../lib/vector/Vlib/open_pg.c:276
+#, c-format
+msgid "Unable to delete PostGIS layer <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/open_pg.c:282
+#, c-format
+msgid "PostGIS layer <%s.%s> already exists in database '%s'"
+msgstr ""
+#: ../lib/vector/Vlib/open_pg.c:390
+msgid "No key column detected."
+msgstr ""
+#: ../lib/vector/Vlib/open_pg.c:462 ../lib/vector/Vlib/open_pg.c:474
+#, c-format
+msgid "Execution failed: %s"
+msgstr ""
+#: ../lib/vector/Vlib/open_pg.c:476
+#, c-format
+msgid "PostGIS topology schema <%s> dropped"
+msgstr ""
+#: ../lib/vector/Vlib/open_pg.c:559
+msgid "Connection to PostgreSQL database failed. Try to set up username/password by db.login."
+msgstr ""
+#: ../lib/vector/Vlib/open_pg.c:566
+msgid "Unable to get database name"
+msgstr ""
+#: ../lib/vector/Vlib/open_pg.c:571
+#, c-format
+msgid "<%s> is not PostGIS database. DB table 'spatial_ref_sys' not found."
+msgstr ""
+#: ../lib/vector/Vlib/open_pg.c:580
+#, c-format
+msgid "PostGIS Topology extension not found in the database <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/open_pg.c:667
+msgid "Empty bounding box"
+msgstr ""
+#: ../lib/vector/Vlib/open_pg.c:768
+#, c-format
+msgid "Inconsistency in topology: unable to read node %d"
+msgstr ""
+#: ../lib/vector/Vlib/open_pg.c:834
+#, c-format
+msgid "Inconsistency in topology: node %d - unexpected feature type %d"
+msgstr ""
+#: ../lib/vector/Vlib/open_pg.c:1003
+#, c-format
+msgid "Area %d without boundary detected"
+msgstr ""
+#: ../lib/vector/Vlib/open_pg.c:1061
+#, c-format
+msgid "Isle %d without boundary detected"
+msgstr ""
+#: ../lib/vector/Vlib/open_pg.c:1128
+msgid "Unable to get map bounding box from topology"
+msgstr ""
+#: ../lib/vector/Vlib/open_pg.c:1135
+#, c-format
+msgid ""
+"Unable to parse map bounding box:\n"
+"%s"
+msgstr ""
+#: ../lib/vector/Vlib/open_pg.c:1159
+#, c-format
+msgid "Different number of nodes detected (%d, %d)"
+msgstr ""
+#: ../lib/vector/Vlib/open_pg.c:1187 ../lib/vector/Vlib/open_pg.c:1209
+#, c-format
+msgid "Different number of areas detected (%d, %d)"
+msgstr ""
+#: ../lib/vector/Vlib/open_pg.c:1380
+msgid "To be implemented: isles not attached in Topo-Geo-only mode"
+msgstr ""
+#: ../lib/vector/Vlib/open_pg.c:1569
+#, c-format
+msgid "Inconsistency in topology: number of points %d (should be %d)"
+msgstr ""
+#: ../lib/vector/Vlib/open_pg.c:1614
+#, c-format
+msgid "Inconsistency in topology: number of lines %d (should be %d)"
+msgstr ""
+#: ../lib/vector/Vlib/open_pg.c:1668
+#, c-format
+msgid "Inconsistency in topology: number of centroids %d (should be %d)"
+msgstr ""
+#: ../lib/vector/Vlib/net_analyze.c:201 ../lib/vector/Vlib/graph.c:226
+#, c-format
+msgid "dglShortestPath error: %s"
+msgstr ""
+#: ../lib/vector/Vlib/net_analyze.c:291 ../lib/vector/Vlib/net_analyze.c:332
+#, c-format
+msgid "Unable to find point with defined unique category for node <%d>."
+msgstr ""
+#: ../lib/vector/Vlib/net_analyze.c:295 ../lib/vector/Vlib/net_analyze.c:336
+#, c-format
+msgid ""
+"There exists more than one point on node <%d> with unique category in field <%d>.\n"
+"The unique category layer may not be valid."
+msgstr ""
+#: ../lib/vector/Vlib/net_analyze.c:452
+msgid "Wrong line direction in Vect_net_get_line_cost()"
+msgstr ""
+#: ../lib/vector/Vlib/close.c:91
+#, c-format
+msgid "Unable to create vector map <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/close.c:108
+msgid "Copying features failed"
+msgstr ""
+#: ../lib/vector/Vlib/close.c:141
+#, c-format
+msgid "Unable to open %s file"
+msgstr ""
+#: ../lib/vector/Vlib/close.c:226
+#, c-format
+msgid "Unable to close vector <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/close.c:257
+#, c-format
+msgid "Invalid request for writing frmt file - map format is %d"
+msgstr ""
+#: ../lib/vector/Vlib/close.c:289
+#, c-format
+msgid "Link to vector map <%s> created"
+msgstr ""
+#: ../lib/vector/Vlib/read_sfa.c:90
+#, c-format
+msgid "Unable to construct centroid for area %d. Skipped."
+msgstr ""
+#: ../lib/vector/Vlib/read_sfa.c:95
+#, c-format
+msgid "Centroid %d: invalid area %d"
+msgstr ""
+#: ../lib/vector/Vlib/array.c:96
+#, c-format
+msgid "%d errors in category string"
+msgstr ""
+#: ../lib/vector/Vlib/array.c:142 ../lib/vector/Vlib/array.c:267
+msgid "Mixed area and other type requested for vector array"
+msgstr ""
+#: ../lib/vector/Vlib/array.c:152 ../lib/vector/Vlib/array.c:175
+#: ../lib/vector/Vlib/array.c:304 ../lib/vector/Vlib/array.c:336
+msgid "Not enough space in vector array"
+msgstr ""
+#: ../lib/vector/Vlib/array.c:292
+#, c-format
+msgid "Unable to select record from table <%s> (key %s, where %s)"
+msgstr ""
+#: ../lib/vector/Vlib/write_nat.c:398
+msgid "Attempt to access feature with invalid id (%"
+msgstr ""
+#: ../lib/vector/Vlib/write_nat.c:404
+#, c-format
+msgid "Attempt to access alive feature %d"
+msgstr ""
+#: ../lib/vector/Vlib/write_nat.c:566 ../lib/vector/Vlib/write_nat.c:602
+#, c-format
+msgid "%s: Area %d does not exist"
+msgstr ""
+#: ../lib/vector/Vlib/write_nat.c:756
+#, c-format
+msgid "Attempt to access dead area %d"
+msgstr ""
+#: ../lib/vector/Vlib/area.c:50
+msgid "Attempt to read points of nonexistent area"
+msgstr ""
+#: ../lib/vector/Vlib/area.c:81
+msgid "Attempt to read points of nonexistent isle"
+msgstr ""
+#: ../lib/vector/Vlib/area.c:121 ../lib/vector/Vlib/area.c:153
+#: ../lib/vector/Vlib/area.c:219 ../lib/vector/Vlib/area.c:248
+#, c-format
+msgid "Attempt to read topo for dead area (%d)"
+msgstr ""
+#: ../lib/vector/Vlib/area.c:189 ../lib/vector/Vlib/area.c:275
+#, c-format
+msgid "Attempt to read topo for dead isle (%d)"
+msgstr ""
+#: ../lib/vector/Vlib/break_lines.c:572
+#, c-format
+msgid "Intersections: %d"
+msgstr ""
+#: ../lib/vector/Vlib/box.c:264
+#, c-format
+msgid "Unable to determine bbox for feature %d"
+msgstr ""
+#: ../lib/vector/Vlib/box.c:313 ../lib/vector/Vlib/box.c:359
+#, c-format
+msgid "Attempt to access area with invalid id (%d)"
+msgstr ""
+#: ../lib/vector/Vlib/box.c:325
+#, c-format
+msgid "Unable to determine bbox for area %d"
+msgstr ""
+#: ../lib/vector/Vlib/box.c:371
+#, c-format
+msgid "Unable to determine bbox for isle %d"
+msgstr ""
+#: ../lib/vector/Vlib/box.c:429
+#, c-format
+msgid "Topology not available for vector map <%s>. Registering primitives..."
+msgstr ""
+#: ../lib/vector/Vlib/box.c:436 ../lib/vector/Vlib/build_nat.c:85
+msgid "Unable to read vector map"
+msgstr ""
+#: ../lib/vector/Vlib/net_build.c:101 ../lib/vector/Vlib/net_build.c:727
+msgid "Building graph..."
+msgstr ""
+#: ../lib/vector/Vlib/net_build.c:143 ../lib/vector/Vlib/net_build.c:775
+msgid "Unable to build network graph"
+msgstr ""
+#: ../lib/vector/Vlib/net_build.c:149 ../lib/vector/Vlib/net_build.c:781
+msgid "Forward costs column not specified"
+msgstr ""
+#: ../lib/vector/Vlib/net_build.c:156
+msgid "Turntable field < 1"
+msgstr ""
+#: ../lib/vector/Vlib/net_build.c:172
+#, c-format
+msgid "Turntable column <%s> not found in table <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/net_build.c:182 ../lib/vector/Vlib/net_build.c:223
+#: ../lib/vector/Vlib/net_build.c:508 ../lib/vector/Vlib/net_build.c:526
+#: ../lib/vector/Vlib/net_build.c:809 ../lib/vector/Vlib/net_build.c:827
+#: ../lib/vector/Vlib/net_build.c:988
+#, c-format
+msgid "Data type of column <%s> not supported (must be numeric)"
+msgstr ""
+#: ../lib/vector/Vlib/net_build.c:202 ../lib/vector/Vlib/net_build.c:967
+msgid "Setting node costs..."
+msgstr ""
+#: ../lib/vector/Vlib/net_build.c:277 ../lib/vector/Vlib/net_build.c:1032
+#, c-format
+msgid "Database record for node %d (cat = %d) not found (cost set to 0)"
+msgstr ""
+#: ../lib/vector/Vlib/net_build.c:332 ../lib/vector/Vlib/net_build.c:352
+msgid "Cannot add network arc for virtual node connection."
+msgstr ""
+#: ../lib/vector/Vlib/net_build.c:364
+#, c-format
+msgid ""
+"There exists more than one point of node <%d> with unique category field <%d>.\n"
+"The unique categories layer is not valid therefore you will probably get incorrect results."
+msgstr ""
+#: ../lib/vector/Vlib/net_build.c:393
+#, c-format
+msgid ""
+"Unable to find point representing intersection <%d> in unique categories field <%d>.\n"
+"Cost for the intersection was set to 0.\n"
+msgstr ""
+#: ../lib/vector/Vlib/net_build.c:407
+#, c-format
+msgid ""
+"Unable to find node for point representing intersection <%d> in unique categories field <%d>.\n"
+msgstr ""
+#: ../lib/vector/Vlib/net_build.c:432
+#, c-format
+msgid "Database record for turn with cat = %d in not found. (The turn was skipped."
+msgstr ""
+#: ../lib/vector/Vlib/net_build.c:465
+msgid "Cannot add network arc representing turn."
+msgstr ""
+#: ../lib/vector/Vlib/net_build.c:487 ../lib/vector/Vlib/net_build.c:788
+msgid "Arc field < 1"
+msgstr ""
+#: ../lib/vector/Vlib/net_build.c:539 ../lib/vector/Vlib/net_build.c:840
+msgid "Registering arcs..."
+msgstr ""
+#: ../lib/vector/Vlib/net_build.c:558
+#, c-format
+msgid ""
+"Line with id <%d> has more unique categories defined in field <%d>.\n"
+msgstr ""
+#: ../lib/vector/Vlib/net_build.c:579
+#, c-format
+msgid "Database record for line %d (cat = %d, forward/both direction(s)) not found (cost was set to 0)"
+msgstr ""
+#: ../lib/vector/Vlib/net_build.c:596
+#, c-format
+msgid "Database record for line %d (cat = %d, backword direction) not found(cost was set to 0)"
+msgstr ""
+#: ../lib/vector/Vlib/net_build.c:658 ../lib/vector/Vlib/net_build.c:1064
+msgid "Flattening the graph..."
+msgstr ""
+#: ../lib/vector/Vlib/net_build.c:661 ../lib/vector/Vlib/net_build.c:1067
+#: ../lib/vector/Vlib/graph.c:105 ../lib/vector/neta/flow.c:331
+msgid "GngFlatten error"
+msgstr ""
+#: ../lib/vector/Vlib/net_build.c:667 ../lib/vector/Vlib/net_build.c:1073
+msgid "Graph was built"
+msgstr ""
+#: ../lib/vector/Vlib/net_build.c:869
+#, c-format
+msgid "Database record for line %d (cat = %d, forward/both direction(s)) not found (forward/both direction(s) of line skipped)"
+msgstr ""
+#: ../lib/vector/Vlib/net_build.c:888
+#, c-format
+msgid "Database record for line %d (cat = %d, backword direction) not found(direction of line skipped)"
+msgstr ""
+#: ../lib/vector/Vlib/net_build.c:937
+msgid "Cannot add network arc"
+msgstr ""
+#: ../lib/vector/Vlib/legal_vname.c:43
+#, c-format
+msgid "Illegal vector map name <%s>. May not contain '.' or 'NULL'."
+msgstr ""
+#: ../lib/vector/Vlib/legal_vname.c:50
+#, c-format
+msgid "Illegal vector map name <%s>. Must start with a letter."
+msgstr ""
+#: ../lib/vector/Vlib/legal_vname.c:58
+#, c-format
+msgid "Illegal vector map name <%s>. Character '%c' not allowed."
+msgstr ""
+#: ../lib/vector/Vlib/legal_vname.c:65
+#, c-format
+msgid "Illegal vector map name <%s>. SQL keyword cannot be used as vector map name."
+msgstr ""
+#: ../lib/vector/Vlib/legal_vname.c:100 ../lib/vector/Vlib/legal_vname.c:104
+#, c-format
+msgid "Output vector map name <%s> is not in the current mapset (%s)"
+msgstr ""
+#: ../lib/vector/Vlib/legal_vname.c:117 ../lib/vector/Vlib/legal_vname.c:121
+#, c-format
+msgid "Output vector map name <%s> is not SQL compliant"
+msgstr ""
+#: ../lib/vector/Vlib/legal_vname.c:159 ../lib/vector/Vlib/legal_vname.c:163
+#, c-format
+msgid "Output vector map <%s> is used as input"
+msgstr ""
+#: ../lib/vector/Vlib/merge_lines.c:240
+#, c-format
+msgid "%d boundaries merged"
+msgstr ""
+#: ../lib/vector/Vlib/merge_lines.c:241
+#, c-format
+msgid "%d new boundaries"
+msgstr ""
+#: ../lib/vector/Vlib/open_nat.c:56
+#, c-format
+msgid "Unable to open coor file for vector map <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/open_nat.c:152
+#, c-format
+msgid "Coor file of vector map <%s@%s> is larger than it should be (%ld bytes excess)"
+msgstr ""
+#: ../lib/vector/Vlib/open_nat.c:156
+#, c-format
+msgid "Coor file of vector <%s@%s> is shorter than it should be (%ld bytes missing)."
+msgstr ""
+#: ../lib/vector/Vlib/read.c:93 ../lib/vector/Vlib/read.c:129
+#: ../lib/vector/Vlib/read.c:168
+msgid "Vector map is not open for reading"
+msgstr ""
+#: ../lib/vector/Vlib/read.c:136 ../lib/vector/Vlib/read.c:180
+#, c-format
+msgid "Unable to read feature %d from vector map <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/read.c:200
+msgid "Line index is out of range"
+msgstr ""
+#: ../lib/vector/Vlib/read.c:224
+msgid "Node index is out of range"
+msgstr ""
+#: ../lib/vector/Vlib/read.c:248
+msgid "Area index is out of range"
+msgstr ""
+#: ../lib/vector/Vlib/read.c:272
+msgid "Isle index is out of range"
+msgstr ""
+#: ../lib/vector/Vlib/dangles.c:148
+msgid "Changed"
+msgstr ""
+#: ../lib/vector/Vlib/dangles.c:151
+msgid "Removed"
+msgstr ""
+#: ../lib/vector/Vlib/dangles.c:154
+msgid "Selected"
+msgstr ""
+#: ../lib/vector/Vlib/dangles.c:262
+#, c-format
+msgid "%s lines: %d"
+msgstr ""
+#: ../lib/vector/Vlib/dangles.c:263
+#, c-format
+msgid "%s dangles: %d"
+msgstr ""
+#: ../lib/vector/Vlib/overlay.c:72
+msgid "unknown operator"
+msgstr ""
+#: ../lib/vector/Vlib/overlay.c:124
+msgid "Overlay: line/boundary types not supported by AND operator"
+msgstr ""
+#: ../lib/vector/Vlib/overlay.c:127
+msgid "Overlay: area x area types not supported by AND operator"
+msgstr ""
+#: ../lib/vector/Vlib/intersect.c:127
+msgid "3D not supported by Vect_segment_intersection()"
+msgstr ""
+#: ../lib/vector/Vlib/intersect.c:353
+msgid "Vect_segment_intersection() ERROR (collinear vertical segments)"
+msgstr ""
+#: ../lib/vector/Vlib/intersect.c:447
+msgid "Vect_segment_intersection() ERROR (collinear non vertical segments)"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:116
+msgid "Area of size = 0.0 (less than 4 vertices) ignored"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:132
+msgid "Unable to add area (map closed, topo saved)"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:140
+msgid "Unable to add isle (map closed, topo saved)"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:150
+msgid "Area of size = 0.0 ignored"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:201
+msgid "Request to find area outside nonexistent isle"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:352
+msgid "Larger bbox but smaller area!!!"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:607
+msgid "Checking for topological errors..."
+msgstr ""
+#: ../lib/vector/Vlib/build.c:642
+#, c-format
+msgid "Number of lines of length zero: %d"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:644
+#, c-format
+msgid "Number of boundaries of length zero: %d"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:653
+#, c-format
+msgid "Number of boundary intersections: %d"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:677
+msgid "Skipping further checks because of incorrect boundaries"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:727
+#, c-format
+msgid "Number of redundant holes: %d"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:872
+#, c-format
+msgid "Building topology for vector map <%s>..."
+msgstr ""
+#: ../lib/vector/Vlib/build.c:890
+msgid "Topology was built"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:901
+#, c-format
+msgid "Number of nodes: %d"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:902
+#, c-format
+msgid "Number of primitives: %d"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:903
+#, c-format
+msgid "Number of points: %d"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:904
+#, c-format
+msgid "Number of lines: %d"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:905
+#, c-format
+msgid "Number of boundaries: %d"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:906
+#, c-format
+msgid "Number of centroids: %d"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:909
+#, c-format
+msgid "Number of faces: %d"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:912
+#, c-format
+msgid "Number of kernels: %d"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:958
+#, c-format
+msgid "Number of areas: %d"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:959
+#, c-format
+msgid "Number of isles: %d"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:964
+#, c-format
+msgid "Number of areas without centroid: %d"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:969
+#, c-format
+msgid "Number of centroids exceeds number of areas: %d > %d"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:973
+#, c-format
+msgid "Number of incorrect boundaries: %d"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:977
+#, c-format
+msgid "Number of centroids outside area: %d"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:981
+#, c-format
+msgid "Number of duplicate centroids: %d"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:985
+msgid "Number of areas: -"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:986
+msgid "Number of isles: -"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:1014
+#, c-format
+msgid "Unable to create topo file for vector map <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:1022
+msgid "Error writing out topo file"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:1211
+msgid "Unable to build spatial index from topology, vector map is not opened at topology level 2"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:1234
+#, c-format
+msgid "%s is no longer supported"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:1257
+msgid "Spatial index not available, can not be saved"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:1269
+#, c-format
+msgid "Unable to create spatial index file for vector map <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:1278
+msgid "Error writing out spatial index file"
+msgstr ""
+#: ../lib/vector/Vlib/break_polygons.c:102
+msgid "Break polygons: Bug in binary tree!"
+msgstr ""
+#: ../lib/vector/Vlib/break_polygons.c:156
+#: ../lib/vector/Vlib/break_polygons.c:435
+msgid "Breaking polygons (pass 1: select break points)..."
+msgstr ""
+#: ../lib/vector/Vlib/break_polygons.c:286
+#: ../lib/vector/Vlib/break_polygons.c:552
+msgid "Breaking polygons (pass 2: break at selected points)..."
+msgstr ""
+#: ../lib/vector/Vlib/break_polygons.c:398
+#: ../lib/vector/Vlib/break_polygons.c:650
+#, c-format
+msgid "Breaks: %d"
+msgstr ""
+#: ../lib/vector/Vlib/break_polygons.c:592
+msgid "Point not in search tree!"
+msgstr ""
+#: ../lib/vector/Vlib/graph.c:138
+msgid "Unable to add network arc"
+msgstr ""
+#: ../lib/vector/Vlib/poly.c:268
+msgid "Unable to find point in polygon"
+msgstr ""
+#: ../lib/vector/Vlib/poly.c:810
+msgid "conditions failed"
+msgstr ""
+#: ../lib/vector/Vlib/build_nat.c:130
+msgid "Building areas..."
+msgstr ""
+#: ../lib/vector/Vlib/build_nat.c:154
+#, c-format
+msgid "One area built"
+msgid_plural "%d areas built"
+msgstr[0] ""
+msgstr[1] ""
+#: ../lib/vector/Vlib/build_nat.c:155
+#, c-format
+msgid "One isle built"
+msgid_plural "%d isles built"
+msgstr[0] ""
+msgstr[1] ""
+#: ../lib/vector/Vlib/build_nat.c:164
+msgid "Attaching islands..."
+msgstr ""
+#: ../lib/vector/Vlib/build_nat.c:181
+msgid "Attaching centroids..."
+msgstr ""
+#: ../lib/vector/Vlib/select.c:116
+#, c-format
+msgid "Unable to delete item %d from spatial index"
+msgstr ""
+#: ../lib/vector/neta/spanningtree.c:106
+msgid "Computing minimum spanning tree..."
+msgstr ""
+#: ../lib/vector/neta/utils.c:200
+#, c-format
+msgid "Point %d is not connected!"
+msgstr ""
+#: ../lib/vector/neta/utils.c:235
+#, c-format
+msgid "'%s' must be > 0"
+msgstr ""
+#: ../lib/vector/neta/utils.c:244
+msgid "'where' and 'cats' parameters were supplied, cat will be ignored"
+msgstr ""
+#: ../lib/vector/neta/utils.c:247
+msgid "Unable to load data from database"
+msgstr ""
+#: ../lib/vector/neta/utils.c:254
+msgid "Problem loading category values"
+msgstr ""
+#: ../lib/vector/neta/timetables.c:46 ../lib/vector/neta/timetables.c:203
+#: ../lib/vector/neta/timetables.c:244 ../lib/vector/neta/timetables.c:286
+#, c-format
+msgid "Unable to open select cursor: %s"
+msgstr ""
+#: ../lib/proj/get_proj.c:148
+#, c-format
+msgid "Invalid zone %s specified"
+msgstr ""
+#: ../lib/proj/get_proj.c:228
+msgid "Unable to initialise PROJ.4 with the following parameter list:"
+msgstr ""
+#: ../lib/proj/get_proj.c:236
+#, c-format
+msgid "The error message: %s"
+msgstr "A hibaüzenet: %s"
+#: ../lib/proj/get_proj.c:294
+msgid "Option input overflowed option table"
+msgstr ""
+#: ../lib/proj/get_proj.c:325
+#, c-format
+msgid "Unable to initialize pj cause: %s"
+msgstr ""
+#: ../lib/proj/get_proj.c:401
+msgid "Input Projection Parameters"
+msgstr ""
+#: ../lib/proj/get_proj.c:404
+msgid "Input Unit Factor"
+msgstr ""
+#: ../lib/proj/get_proj.c:414
+msgid "Output Projection Parameters"
+msgstr ""
+#: ../lib/proj/get_proj.c:417
+msgid "Output Unit Factor"
+msgstr ""
+#: ../lib/proj/ellipse.c:97
+#, c-format
+msgid "Invalid ellipsoid <%s> in file"
+msgstr ""
+#: ../lib/proj/ellipse.c:124
+msgid "No secondary ellipsoid descriptor (rf, es or b) in file"
+msgstr ""
+#: ../lib/proj/ellipse.c:128
+msgid "Invalid ellipsoid descriptors (a, rf, es or b) in file"
+msgstr ""
+#: ../lib/proj/ellipse.c:141
+msgid "No ellipsoid info given in file"
+msgstr ""
+#: ../lib/proj/datum.c:195
+msgid "Failed to detect nadgrids path, GRASS_PROJSHARE not defined"
+msgstr ""
+#: ../lib/proj/datum.c:278 ../lib/proj/datum.c:358
+#, c-format
+msgid "Unable to open datum table file <%s>"
+msgstr ""
+#: ../lib/proj/datum.c:291 ../lib/proj/datum.c:372
+#, c-format
+msgid "Error in datum table file <%s>, line %d"
+msgstr ""
+#: ../lib/proj/convert.c:159
+msgid "Unable parse GRASS PROJ_INFO file"
+msgstr ""
+#: ../lib/proj/convert.c:164
+msgid "Unable get PROJ.4-style parameter string"
+msgstr ""
+#: ../lib/proj/convert.c:178
+#, c-format
+msgid "OGR can't parse PROJ.4-style parameter string: %s (OGR Error code was %d)"
+msgstr ""
+#: ../lib/proj/convert.c:191
+#, c-format
+msgid "OGR can't get WKT-style parameter string (OGR Error code was %d)"
+msgstr ""
+#: ../lib/proj/convert.c:427
+#, c-format
+msgid "Updating spatial reference with embedded proj4 definition failed. Proj4 definition: <%s>"
+msgstr ""
+#: ../lib/proj/convert.c:434
+msgid "Updating spatial reference with embedded proj4 definition"
+msgstr ""
+#: ../lib/proj/convert.c:564
+msgid "No projection name! Projection parameters likely to be meaningless."
+msgstr ""
+#: ../lib/proj/convert.c:626
+#, c-format
+msgid "Datum <%s> not recognised by GRASS and no parameters found"
+msgstr ""
+#: ../lib/proj/convert.c:642
+#, c-format
+msgid "Datum <%s> apparently recognised by GRASS but no parameters found. You may want to look into this."
+msgstr ""
+#: ../lib/proj/convert.c:646
+#, c-format
+msgid "Invalid transformation number %d; valid range is 1 to %d. Leaving datum transform parameters unspecified."
+msgstr ""
+#: ../lib/proj/do_proj.c:106 ../lib/proj/do_proj.c:180
+#, c-format
+msgid "pj_transform() failed: %s"
+msgstr ""
+#: ../lib/lidar/zones.c:476 ../lib/lidar/zones.c:513
+#, c-format
+msgid "<%s> created in database."
+msgstr ""
+#: ../lib/lidar/zones.c:480 ../lib/lidar/zones.c:517
+#, c-format
+msgid "<%s> has not been created in database."
+msgstr ""
+#: ../lib/lidar/raster.c:74 ../lib/lidar/raster.c:89 ../lib/lidar/raster.c:102
+#: ../lib/lidar/raster.c:119 ../lib/lidar/raster.c:134
+#: ../lib/lidar/raster.c:147 ../lib/lidar/raster.c:162
+#: ../lib/lidar/raster.c:175
+#, c-format
+msgid "Unable to access table <%s>"
+msgstr ""
Added: grass/trunk/locale/po/grassmods_hu.po
--- grass/trunk/locale/po/grassmods_hu.po (rev 0)
+++ grass/trunk/locale/po/grassmods_hu.po 2018-03-10 18:27:01 UTC (rev 72338)
@@ -0,0 +1,43507 @@
+# Translation of grassmods_hu.po
+# Copyright (C) 2017 GRASS Development Team
+# This file is distributed under the same license as the GRASS GIS package.
+# transifex generated, 2017
+msgid ""
+msgstr ""
+"Project-Id-Version: grasslibs_hu\n"
+"Report-Msgid-Bugs-To: \n"
+"POT-Creation-Date: 2018-03-10 19:26+0100\n"
+"PO-Revision-Date: 2018-03-10 17:22+0100\n"
+"Last-Translator: Zoltan Siki <siki at agt.bme.hu>, 2018\n"
+"Language-Team: Hungarian (https://www.transifex.com/grass-gis/teams/45198/hu/)\n"
+"Language: hu\n"
+"MIME-Version: 1.0\n"
+"Content-Type: text/plain; charset=UTF-8\n"
+"Content-Transfer-Encoding: 8bit\n"
+"Plural-Forms: nplurals=2; plural=(n != 1);\n"
+#: ../temporal/t.connect/main.c:34
+#: ../locale/scriptstrings/t.rast.extract_to_translate.c:2
+#: ../locale/scriptstrings/t.support_to_translate.c:2
+#: ../locale/scriptstrings/t.select_to_translate.c:2
+#: ../locale/scriptstrings/t.vect.univar_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.series_to_translate.c:2
+#: ../locale/scriptstrings/t.info_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.contour_to_translate.c:2
+#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:2
+#: ../locale/scriptstrings/t.vect.export_to_translate.c:2
+#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:2
+#: ../locale/scriptstrings/t.vect.algebra_to_translate.c:2
+#: ../locale/scriptstrings/t.list_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:2
+#: ../locale/scriptstrings/v.what.strds_to_translate.c:3
+#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.list_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:2
+#: ../locale/scriptstrings/t.vect.extract_to_translate.c:2
+#: ../locale/scriptstrings/t.vect.list_to_translate.c:2
+#: ../locale/scriptstrings/t.vect.db.select_to_translate.c:2
+#: ../locale/scriptstrings/t.snap_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:2
+#: ../locale/scriptstrings/t.rename_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:2
+#: ../locale/scriptstrings/t.create_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.what_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.to.rast3_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.import_to_translate.c:2
+#: ../locale/scriptstrings/t.sample_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.algebra_to_translate.c:2
+#: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:2
+#: ../locale/scriptstrings/t.vect.import_to_translate.c:2
+#: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.univar_to_translate.c:2
+#: ../locale/scriptstrings/t.topology_to_translate.c:2
+#: ../locale/scriptstrings/t.register_to_translate.c:2
+#: ../locale/scriptstrings/t.merge_to_translate.c:2
+#: ../locale/scriptstrings/t.unregister_to_translate.c:2
+#: ../locale/scriptstrings/t.remove_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:2
+#: ../locale/scriptstrings/t.shift_to_translate.c:2
+#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.export_to_translate.c:2
+#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:2
+#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:2
+msgid "temporal"
+msgstr ""
+#: ../temporal/t.connect/main.c:35 ../display/d.colorlist/main.c:36
+#: ../display/d.fontlist/main.c:46 ../display/d.font/main.c:46
+#: ../general/g.region/main.c:66 ../general/g.mapsets/main.c:64
+#: ../general/g.mapset/main.c:50 ../general/g.gisenv/main.c:44
+msgid "settings"
+msgstr ""
+#: ../temporal/t.connect/main.c:36
+#: ../locale/scriptstrings/t.support_to_translate.c:3
+#: ../locale/scriptstrings/t.select_to_translate.c:3
+#: ../locale/scriptstrings/t.info_to_translate.c:3
+#: ../raster/r.timestamp/main.c:36 ../raster/r.describe/main.c:55
+#: ../raster/r.info/main.c:73 ../raster/r.support/main.c:55
+#: ../raster/r.region/main.c:52 ../raster3d/r3.support/main.c:50
+#: ../raster3d/r3.timestamp/main.c:44 ../raster3d/r3.info/main.c:76
+#: ../vector/v.support/main.c:40 ../vector/v.timestamp/main.c:36
+#: ../vector/v.info/main.c:38
+msgid "metadata"
+msgstr ""
+#: ../temporal/t.connect/main.c:38
+msgid "Prints/sets general temporal GIS database connection for current mapset."
+msgstr ""
+#: ../temporal/t.connect/main.c:42 ../db/db.connect/main.c:51
+msgid "Print current connection parameters and exit"
+msgstr ""
+#: ../temporal/t.connect/main.c:43
+#: ../locale/scriptstrings/g.extension_to_translate.c:16
+#: ../locale/scriptstrings/g.extension_to_translate.c:18
+#: ../locale/scriptstrings/g.extension_to_translate.c:20
+#: ../locale/scriptstrings/g.extension_to_translate.c:22
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:18
+#: ../locale/scriptstrings/v.unpack_to_translate.c:13
+#: ../locale/scriptstrings/r.unpack_to_translate.c:12
+#: ../raster/r.colors/edit_colors.c:128 ../raster/r.out.gdal/main.c:145
+#: ../raster/r.external.out/main.c:272 ../raster/r.external.out/main.c:283
+#: ../raster/r.what/main.c:122 ../raster/r.what/main.c:130
+#: ../raster/r.what/main.c:144 ../raster/r.what/main.c:149
+#: ../raster/r.what/main.c:154 ../raster/r.what/main.c:159
+#: ../raster/r.what/main.c:169 ../raster/r.proj/main.c:204
+#: ../raster/r.proj/main.c:214 ../raster/r.proj/main.c:220
+#: ../raster/r.in.gdal/main.c:209 ../raster/r.in.gdal/main.c:242
+#: ../raster/r.sunmask/main.c:232 ../raster/r.sunmask/main.c:238
+#: ../raster/r.external/main.c:96 ../raster/r.external/main.c:135
+#: ../display/d.mon/main.c:115 ../display/d.mon/main.c:120
+#: ../display/d.mon/main.c:125 ../general/g.list/main.c:105
+#: ../general/g.list/main.c:116 ../general/g.list/main.c:138
+#: ../general/g.list/main.c:143 ../general/g.list/main.c:148
+#: ../general/g.list/main.c:153 ../general/g.region/main.c:90
+#: ../general/g.region/main.c:96 ../general/g.region/main.c:101
+#: ../general/g.region/main.c:107 ../general/g.region/main.c:113
+#: ../general/g.region/main.c:119 ../general/g.region/main.c:125
+#: ../general/g.region/main.c:133 ../general/g.region/main.c:138
+#: ../general/g.region/main.c:144 ../general/g.region/main.c:149
+#: ../general/g.region/main.c:154 ../general/g.mapsets/main.c:87
+#: ../general/g.mapsets/main.c:92 ../general/g.mapsets/main.c:98
+#: ../general/g.proj/main.c:80 ../general/g.proj/main.c:86
+#: ../general/g.proj/main.c:92 ../general/g.proj/main.c:98
+#: ../general/g.proj/main.c:104 ../general/g.proj/main.c:115
+#: ../general/g.proj/main.c:120 ../general/g.mapset/main.c:76
+#: ../general/g.mapset/main.c:82 ../imagery/i.group/main.c:79
+#: ../imagery/i.group/main.c:84 ../imagery/i.group/main.c:89
+#: ../db/db.connect/main.c:53 ../db/db.connect/main.c:58
+#: ../db/db.login/main.c:91 ../vector/v.external.out/args.c:63
+#: ../vector/v.external.out/args.c:75 ../vector/v.external.out/args.c:81
+#: ../vector/v.db.connect/main.c:84 ../vector/v.db.connect/main.c:89
+#: ../vector/v.db.connect/main.c:96 ../vector/v.db.connect/main.c:103
+#: ../vector/v.in.ogr/main.c:321 ../vector/v.in.ogr/main.c:327
+#: ../vector/v.colors/main.c:133 ../vector/v.what/main.c:91
+#: ../vector/v.what/main.c:96 ../vector/v.what/main.c:101
+#: ../vector/v.what/main.c:106 ../vector/v.what/main.c:111
+#: ../vector/v.info/parse.c:25 ../vector/v.info/parse.c:31
+#: ../vector/v.info/parse.c:36 ../vector/v.info/parse.c:41
+#: ../vector/v.info/parse.c:46 ../vector/v.external/args.c:57
+#: ../vector/v.external/args.c:63 ../vector/v.external/args.c:71
+#: ../vector/v.to.db/parse.c:118 ../vector/v.to.db/parse.c:123
+#: ../vector/v.to.db/parse.c:129 ../vector/v.to.db/parse.c:135
+msgid "Print"
+msgstr "Nyomtatás"
+#: ../temporal/t.connect/main.c:48 ../db/db.connect/main.c:63
+msgid "Check connection parameters, set if uninitialized, and exit"
+msgstr ""
+#: ../temporal/t.connect/main.c:49 ../temporal/t.connect/main.c:55
+#: ../temporal/t.connect/main.c:60 ../temporal/t.connect/main.c:65
+#: ../temporal/t.connect/main.c:69 ../general/g.gisenv/main.c:66
+#: ../general/g.gisenv/main.c:74 ../general/g.gisenv/main.c:84
+#: ../db/db.connect/main.c:64 ../db/db.connect/main.c:70
+#: ../db/db.connect/main.c:75 ../db/db.connect/main.c:79
+#: ../db/db.connect/main.c:83 ../db/db.connect/main.c:93
+msgid "Set"
+msgstr ""
+#: ../temporal/t.connect/main.c:53 ../db/db.connect/main.c:68
+msgid "Set from default settings and exit"
+msgstr ""
+#: ../temporal/t.connect/main.c:54
+msgid "Overwrite current settings if initialized"
+msgstr ""
+#: ../temporal/t.connect/main.c:59
+msgid "Print current connection parameter in shell style and exit"
+msgstr ""
+#: ../temporal/t.connect/main.c:83 ../temporal/t.connect/main.c:95
+msgid "Temporal GIS database connection not defined. Run t.connect."
+msgstr ""
+#: ../temporal/t.connect/main.c:111
+#, c-format
+msgid ""
+"Default TGIS driver / database set to:\n"
+"driver: %s\n"
+"database: %s"
+msgstr ""
+#: ../temporal/t.connect/main.c:118
+msgid "Default TGIS driver is not set"
+msgstr ""
+#: ../temporal/t.connect/main.c:121
+msgid "Default TGIS database is not set"
+msgstr ""
+#: ../temporal/t.connect/main.c:133 ../db/db.connect/main.c:161
+#: ../db/db.connect/main.c:188
+#, c-format
+msgid ""
+"driver: %s\n"
+"database: %s"
+msgstr ""
+#: ../locale/scriptstrings/g.search.modules_to_translate.c:1
+msgid "Search in GRASS modules using keywords"
+msgstr ""
+#: ../locale/scriptstrings/g.search.modules_to_translate.c:2
+#: ../locale/scriptstrings/g.extension_to_translate.c:3
+#: ../locale/scriptstrings/g.extension.all_to_translate.c:3
+#: ../locale/scriptstrings/g.manual_to_translate.c:2
+#: ../general/g.findfile/main.c:38 ../general/g.version/main.c:65
+#: ../general/g.ppmtopng/main.c:117 ../general/g.list/main.c:65
+#: ../general/g.cairocomp/main.c:196 ../general/g.region/main.c:65
+#: ../general/g.gui/main.c:39 ../general/g.findetc/main.c:28
+#: ../general/g.rename/main.c:45 ../general/g.mapsets/main.c:63
+#: ../general/g.pnmcomp/main.c:282 ../general/g.copy/main.c:41
+#: ../general/g.proj/main.c:64 ../general/g.mapset/main.c:49
+#: ../general/g.dirseps/main.c:34 ../general/g.gisenv/main.c:43
+#: ../general/g.message/main.c:33 ../general/g.setproj/main.c:78
+#: ../general/g.access/main.c:37 ../general/g.filename/main.c:39
+#: ../general/g.remove/main.c:69 ../general/g.tempfile/main.c:38
+#: ../general/g.mkfontcap/main.c:71
+msgid "general"
+msgstr ""
+#: ../locale/scriptstrings/g.search.modules_to_translate.c:3
+msgid "modules"
+msgstr ""
+#: ../locale/scriptstrings/g.search.modules_to_translate.c:4
+#: ../general/g.list/main.c:68
+msgid "search"
+msgstr ""
+#: ../locale/scriptstrings/g.search.modules_to_translate.c:5
+msgid "Keyword to be searched"
+msgstr ""
+#: ../locale/scriptstrings/g.search.modules_to_translate.c:6
+msgid "Display only modules where all keywords are available (AND), default: OR"
+msgstr ""
+#: ../locale/scriptstrings/g.search.modules_to_translate.c:7
+#: ../locale/scriptstrings/g.search.modules_to_translate.c:9
+#: ../locale/scriptstrings/g.search.modules_to_translate.c:11
+#: ../locale/scriptstrings/g.search.modules_to_translate.c:14
+#: ../locale/scriptstrings/g.search.modules_to_translate.c:16
+#: ../locale/scriptstrings/g.search.modules_to_translate.c:18
+#: ../locale/scriptstrings/g.search.modules_to_translate.c:20
+#: ../locale/scriptstrings/v.import_to_translate.c:10
+#: ../locale/scriptstrings/v.import_to_translate.c:13
+#: ../locale/scriptstrings/v.import_to_translate.c:16
+#: ../locale/scriptstrings/v.import_to_translate.c:19
+#: ../locale/scriptstrings/i.spectral_to_translate.c:10
+#: ../locale/scriptstrings/i.spectral_to_translate.c:12
+#: ../locale/scriptstrings/db.in.ogr_to_translate.c:8
+#: ../locale/scriptstrings/db.in.ogr_to_translate.c:10
+#: ../locale/scriptstrings/db.in.ogr_to_translate.c:13
+#: ../locale/scriptstrings/r.import_to_translate.c:12
+#: ../locale/scriptstrings/r.import_to_translate.c:15
+#: ../locale/scriptstrings/r.import_to_translate.c:18
+#: ../locale/scriptstrings/r.import_to_translate.c:21
+#: ../locale/scriptstrings/r.import_to_translate.c:23
+#: ../locale/scriptstrings/m.proj_to_translate.c:11
+#: ../locale/scriptstrings/m.proj_to_translate.c:23
+#: ../locale/scriptstrings/m.proj_to_translate.c:25
+#: ../locale/scriptstrings/m.proj_to_translate.c:27 ../raster/r.sun/main.c:403
+#: ../raster/r.sun/main.c:412 ../raster/r.sun/main.c:421
+#: ../raster/r.sun/main.c:430 ../raster/r.sun/main.c:439
+#: ../raster/r.sun/main.c:448 ../raster/r.resamp.rst/main.c:174
+#: ../raster/r.resamp.rst/main.c:180 ../raster/r.resamp.rst/main.c:186
+#: ../raster/r.resamp.rst/main.c:192 ../raster/r.resamp.rst/main.c:198
+#: ../raster/r.resamp.rst/main.c:204 ../raster/r.resamp.rst/main.c:264
+#: ../raster/r.spread/main.c:277 ../raster/r.spread/main.c:289
+#: ../raster/r.spread/main.c:301 ../raster/r.grow.distance/main.c:162
+#: ../raster/r.grow.distance/main.c:168 ../raster/r.in.lidar/main.c:126
+#: ../raster/r.in.lidar/main.c:253 ../raster/r.in.lidar/main.c:286
+#: ../raster/r.in.lidar/main.c:295 ../raster/r.in.xyz/main.c:297
+#: ../raster/r.lake/main.c:167 ../raster/r.lake/main.c:195
+#: ../raster/r.sim/r.sim.sediment/main.c:179
+#: ../raster/r.sim/r.sim.sediment/main.c:186
+#: ../raster/r.sim/r.sim.sediment/main.c:193
+#: ../raster/r.sim/r.sim.sediment/main.c:199
+#: ../raster/r.sim/r.sim.sediment/main.c:206
+#: ../raster/r.sim/r.sim.sediment/main.c:213
+#: ../raster/r.sim/r.sim.sediment/main.c:220
+#: ../raster/r.sim/r.sim.water/main.c:197
+#: ../raster/r.sim/r.sim.water/main.c:203
+#: ../raster/r.sim/r.sim.water/main.c:209
+#: ../raster/r.sim/r.sim.water/main.c:216
+#: ../raster/r.sim/r.sim.water/main.c:223
+#: ../raster/r.sim/r.sim.water/main.c:298 ../raster3d/r3.flow/main.c:211
+#: ../raster3d/r3.flow/main.c:218 ../raster3d/r3.in.lidar/main.c:190
+#: ../raster3d/r3.in.lidar/main.c:196 ../raster3d/r3.in.lidar/main.c:202
+#: ../vector/v.out.ascii/args.c:35 ../vector/v.out.ascii/args.c:81
+#: ../vector/v.profile/main.c:218 ../vector/v.profile/main.c:223
+#: ../vector/v.profile/main.c:229 ../vector/v.in.ogr/main.c:229
+#: ../vector/v.in.ogr/main.c:284 ../vector/v.in.ogr/main.c:334
+#: ../vector/v.in.ogr/main.c:340 ../vector/v.in.ogr/main.c:382
+msgid "Output"
+msgstr "Output"
+#: ../locale/scriptstrings/g.search.modules_to_translate.c:8
+msgid "Invert selection (logical NOT)"
+msgstr ""
+#: ../locale/scriptstrings/g.search.modules_to_translate.c:10
+msgid "Search in manual pages too (can be slow)"
+msgstr ""
+#: ../locale/scriptstrings/g.search.modules_to_translate.c:12
+msgid "Search only for the exact keyword in module keyword list"
+msgstr ""
+#: ../locale/scriptstrings/g.search.modules_to_translate.c:13
+msgid "Instead of full text search, search only in actual keywords"
+msgstr ""
+#: ../locale/scriptstrings/g.search.modules_to_translate.c:15
+msgid "Use colorized (more readable) output to terminal"
+msgstr ""
+#: ../locale/scriptstrings/g.search.modules_to_translate.c:17
+msgid "Shell script format"
+msgstr ""
+#: ../locale/scriptstrings/g.search.modules_to_translate.c:19
+msgid "JSON format"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.extract_to_translate.c:1
+msgid "Extracts a subset of a space time raster datasets."
+msgstr ""
+#: ../locale/scriptstrings/t.rast.extract_to_translate.c:3
+#: ../locale/scriptstrings/t.vect.extract_to_translate.c:3
+#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:3
+#: ../vector/v.decimate/main.c:127 ../vector/v.outlier/main.c:71
+#: ../vector/v.extract/main.c:78
+msgid "extract"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.extract_to_translate.c:4
+#: ../locale/scriptstrings/wxpyimgview_to_translate.c:4
+#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:2
+#: ../locale/scriptstrings/r.pack_to_translate.c:2
+#: ../locale/scriptstrings/v.rast.stats_to_translate.c:4
+#: ../locale/scriptstrings/t.rast.series_to_translate.c:5
+#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:4
+#: ../locale/scriptstrings/r.rgb_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.contour_to_translate.c:4
+#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:4
+#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:4
+#: ../locale/scriptstrings/r.out.xyz_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.list_to_translate.c:4
+#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:4
+#: ../locale/scriptstrings/r.shade_to_translate.c:2
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:2
+#: ../locale/scriptstrings/r.tileset_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:4
+#: ../locale/scriptstrings/r.reclass.area_to_translate.c:2
+#: ../locale/scriptstrings/r.blend_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:4
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:4
+#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:4
+#: ../locale/scriptstrings/r.mask_to_translate.c:2
+#: ../locale/scriptstrings/r.unpack_to_translate.c:2
+#: ../locale/scriptstrings/i.spectral_to_translate.c:4
+#: ../locale/scriptstrings/t.rast.what_to_translate.c:4
+#: ../locale/scriptstrings/t.rast.to.rast3_to_translate.c:4
+#: ../locale/scriptstrings/t.rast.import_to_translate.c:4
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.algebra_to_translate.c:4
+#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:4
+#: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:3
+#: ../locale/scriptstrings/r.drain_to_translate.c:2
+#: ../locale/scriptstrings/d.to.rast_to_translate.c:4
+#: ../locale/scriptstrings/t.rast.univar_to_translate.c:4
+#: ../locale/scriptstrings/r.in.aster_to_translate.c:2
+#: ../locale/scriptstrings/d.correlate_to_translate.c:4
+#: ../locale/scriptstrings/r.grow_to_translate.c:2
+#: ../locale/scriptstrings/d.rast.edit_to_translate.c:4
+#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:4
+#: ../locale/scriptstrings/r.plane_to_translate.c:2
+#: ../locale/scriptstrings/r.in.srtm_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.export_to_translate.c:4
+#: ../doc/raster/r.example/main.c:83 ../raster/r.surf.area/main.c:76
+#: ../raster/r.path/main.c:137 ../raster/r.profile/main.c:53
+#: ../raster/r.sun/main.c:251 ../raster/r.regression.multi/main.c:129
+#: ../raster/r.volume/main.c:76 ../raster/r.solute.transport/main.c:229
+#: ../raster/r.walk/main.c:196 ../raster/r.timestamp/main.c:35
+#: ../raster/r.colors/edit_colors.c:63 ../raster/r.mfilter/main.c:56
+#: ../raster/r.cost/main.c:157 ../raster/r.resamp.interp/main.c:76
+#: ../raster/r.reclass/main.c:50 ../raster/r.topmodel/main.c:51
+#: ../raster/r.texture/main.c:102 ../raster/r.stats/main.c:106
+#: ../raster/r.stats.quantile/main.c:516 ../raster/r.in.poly/main.c:34
+#: ../raster/r.out.pov/main.c:121 ../raster/r.li/r.li.padcv/padcv.c:53
+#: ../raster/r.li/r.li.shape/main.c:49 ../raster/r.li/r.li.mps/mps.c:52
+#: ../raster/r.li/r.li.renyi/renyi.c:47 ../raster/r.li/r.li.cwed/cwed.c:54
+#: ../raster/r.li/r.li.mpa/mpa.c:44 ../raster/r.li/r.li.simpson/simpson.c:46
+#: ../raster/r.li/r.li.padrange/padrange.c:53
+#: ../raster/r.li/r.li.edgedensity/edgedensity.c:48
+#: ../raster/r.li/r.li.patchnum/main.c:50 ../raster/r.li/r.li.padsd/padsd.c:53
+#: ../raster/r.li/r.li.dominance/dominance.c:46
+#: ../raster/r.li/r.li.pielou/pielou.c:46
+#: ../raster/r.li/r.li.shannon/shannon.c:46
+#: ../raster/r.li/r.li.patchdensity/main.c:51
+#: ../raster/r.li/r.li.richness/richness.c:43 ../raster/r.out.ppm3/main.c:57
+#: ../raster/r.out.bin/main.c:279 ../raster/r.to.rast3/main.c:197
+#: ../raster/r.resamp.rst/main.c:148 ../raster/r.univar/r.univar_main.c:104
+#: ../raster/r.recode/main.c:48 ../raster/r.random/main.c:51
+#: ../raster/r.spreadpath/main.c:88 ../raster/r.uslek/main.c:53
+#: ../raster/r.report/main.c:67 ../raster/r.horizon/main.c:180
+#: ../raster/r.quant/main.c:47 ../raster/r.series.accumulate/main.c:80
+#: ../raster/r.rescale.eq/main.c:52 ../raster/r.distance/main.c:39
+#: ../raster/r.mode/main.c:55 ../raster/r.spread/main.c:105
+#: ../raster/r.support.stats/main.c:38 ../raster/r.to.rast3elev/main.c:361
+#: ../raster/r.usler/main.c:52 ../raster/r.thin/main.c:57
+#: ../raster/r.out.vtk/main.c:59 ../raster/r.colors.out/raster_main.c:45
+#: ../raster/r.gwflow/main.c:208 ../raster/r.describe/main.c:54
+#: ../raster/r.what.color/main.c:88 ../raster/r.neighbors/main.c:167
+#: ../raster/r.buffer/main.c:66 ../raster/r.contour/main.c:87
+#: ../raster/r.slope.aspect/main.c:167 ../raster/r.in.ascii/main.c:69
+#: ../raster/r.stream.extract/main.c:76 ../raster/r.grow.distance/main.c:150
+#: ../raster/r.random.surface/main.c:57 ../raster/r.surf.random/main.c:36
+#: ../raster/r.in.gridatb/main.c:45 ../raster/r.fill.dir/main.c:88
+#: ../raster/r.clump/main.c:58 ../raster/r.circle/main.c:51
+#: ../raster/r.in.png/main.c:519 ../raster/r.cross/main.c:68
+#: ../raster/r.series/main.c:137 ../raster/r.in.lidar/main.c:108
+#: ../raster/r.mapcalc/main.c:70 ../raster/r.statistics/main.c:55
+#: ../raster/r.sunhours/main.c:72 ../raster/r.stats.zonal/main.c:101
+#: ../raster/r.out.gridatb/main.c:67 ../raster/r.regression.line/main.c:46
+#: ../raster/r.resamp.stats/main.c:261 ../raster/r.compress/main.c:68
+#: ../raster/r.out.gdal/main.c:139 ../raster/r.basins.fill/main.c:54
+#: ../raster/r.in.xyz/main.c:158 ../raster/r.surf.fractal/main.c:38
+#: ../raster/r.kappa/main.c:68 ../raster/r.coin/main.c:66
+#: ../raster/r.water.outlet/main.c:57 ../raster/r.to.vect/main.c:76
+#: ../raster/r.out.vrml/main.c:47 ../raster/r.quantile/main.c:265
+#: ../raster/r.param.scale/interface.c:54 ../raster/r.surf.idw/main.c:104
+#: ../raster/r.in.bin/main.c:257 ../raster/r.drain/main.c:109
+#: ../raster/r.random.cells/main.c:47 ../raster/r.surf.contour/main.c:60
+#: ../raster/r.fill.stats/main.c:775 ../raster/r.tile/main.c:43
+#: ../raster/r.patch/main.c:58 ../raster/r.info/main.c:72
+#: ../raster/r.geomorphon/main.c:104 ../raster/r.topidx/main.c:39
+#: ../raster/r.category/main.c:52 ../raster/r.series.interp/main.c:64
+#: ../raster/r.external.out/main.c:235 ../raster/r.resamp.bspline/main.c:79
+#: ../raster/r.in.mat/main.c:91 ../raster/r.ros/main.c:212
+#: ../raster/r.null/main.c:60 ../raster/r.what/main.c:100
+#: ../raster/r.transect/main.c:103 ../raster/r.flow/main.c:421
+#: ../raster/r.proj/main.c:144 ../raster/r.surf.gauss/main.c:38
+#: ../raster/r.out.png/main.c:112 ../raster/r.resample/main.c:54
+#: ../raster/r.relief/main.c:107 ../raster/r.carve/main.c:74
+#: ../raster/r.in.gdal/main.c:93 ../raster/r.sunmask/main.c:116
+#: ../raster/r.out.ascii/main.c:59 ../raster/r.out.mpeg/main.c:102
+#: ../raster/r.covar/main.c:51 ../raster/r.out.ppm/main.c:54
+#: ../raster/r.support/main.c:54 ../raster/r.lake/main.c:150
+#: ../raster/r.out.mat/main.c:62 ../raster/r.his/main.c:67
+#: ../raster/r.external/main.c:57 ../raster/r.resamp.filter/main.c:394
+#: ../raster/r.latlong/main.c:56 ../raster/r.composite/main.c:72
+#: ../raster/r.region/main.c:51 ../raster/r.watershed/front/main.c:73
+#: ../raster/r.rescale/main.c:48 ../raster/r.sim/r.sim.sediment/main.c:114
+#: ../raster/r.sim/r.sim.water/main.c:113 ../display/d.colortable/main.c:61
+#: ../display/d.rgb/main.c:55 ../display/d.rast.num/main.c:79
+#: ../display/d.rast/main.c:55 ../display/d.profile/main.c:193
+#: ../display/d.rast.arrow/main.c:99 ../raster3d/r3.cross.rast/main.c:230
+#: ../raster3d/r3.to.rast/main.c:261 ../misc/m.nviz.image/main.c:53
+#: ../misc/m.nviz.script/main.c:71 ../vector/v.what.rast3/main.c:66
+#: ../vector/v.to.rast/main.c:46 ../vector/v.what.rast/main.c:73
+#: ../vector/v.sample/main.c:77 ../vector/v.neighbors/main.c:53
+#: ../visualization/ximgview/main.c:292
+msgid "raster"
+msgstr "raszter"
+#: ../locale/scriptstrings/t.rast.extract_to_translate.c:5
+#: ../locale/scriptstrings/t.support_to_translate.c:4
+#: ../locale/scriptstrings/t.select_to_translate.c:4
+#: ../locale/scriptstrings/t.vect.univar_to_translate.c:5
+#: ../locale/scriptstrings/t.rast.series_to_translate.c:6
+#: ../locale/scriptstrings/t.info_to_translate.c:5
+#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:5
+#: ../locale/scriptstrings/t.rast.contour_to_translate.c:6
+#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:7
+#: ../locale/scriptstrings/t.vect.export_to_translate.c:5
+#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:6
+#: ../locale/scriptstrings/t.vect.algebra_to_translate.c:5
+#: ../locale/scriptstrings/t.list_to_translate.c:5
+#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:6
+#: ../locale/scriptstrings/v.what.strds_to_translate.c:8
+#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:5
+#: ../locale/scriptstrings/t.rast.list_to_translate.c:6
+#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:5
+#: ../locale/scriptstrings/t.vect.extract_to_translate.c:5
+#: ../locale/scriptstrings/t.vect.list_to_translate.c:6
+#: ../locale/scriptstrings/t.vect.db.select_to_translate.c:7
+#: ../locale/scriptstrings/t.snap_to_translate.c:5
+#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:5
+#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:5
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:5
+#: ../locale/scriptstrings/t.rename_to_translate.c:5
+#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:6
+#: ../locale/scriptstrings/t.create_to_translate.c:5
+#: ../locale/scriptstrings/t.rast.what_to_translate.c:5
+#: ../locale/scriptstrings/t.rast.to.rast3_to_translate.c:7
+#: ../locale/scriptstrings/t.rast.import_to_translate.c:5
+#: ../locale/scriptstrings/t.sample_to_translate.c:4
+#: ../locale/scriptstrings/t.rast.algebra_to_translate.c:5
+#: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:5
+#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:5
+#: ../locale/scriptstrings/t.vect.import_to_translate.c:5
+#: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:5
+#: ../locale/scriptstrings/t.rast.univar_to_translate.c:5
+#: ../locale/scriptstrings/t.topology_to_translate.c:4
+#: ../locale/scriptstrings/t.register_to_translate.c:5
+#: ../locale/scriptstrings/t.merge_to_translate.c:5
+#: ../locale/scriptstrings/t.unregister_to_translate.c:5
+#: ../locale/scriptstrings/t.remove_to_translate.c:5
+#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:5
+#: ../locale/scriptstrings/t.shift_to_translate.c:5
+#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:6
+#: ../locale/scriptstrings/t.rast.export_to_translate.c:5
+#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:6
+#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:6
+#: ../raster/r.timestamp/main.c:38 ../raster3d/r3.timestamp/main.c:46
+#: ../vector/v.timestamp/main.c:38
+msgid "time"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.extract_to_translate.c:6
+msgid "r.mapcalc expression assigned to all extracted raster maps"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.extract_to_translate.c:7
+#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:8
+#: ../locale/scriptstrings/t.rast.contour_to_translate.c:7
+#: ../locale/scriptstrings/t.vect.algebra_to_translate.c:7
+#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:8
+#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:6
+#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:13
+#: ../locale/scriptstrings/t.vect.extract_to_translate.c:6
+#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:6
+#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:14
+#: ../locale/scriptstrings/t.rast.import_to_translate.c:7
+#: ../locale/scriptstrings/t.rast.algebra_to_translate.c:7
+#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:8
+#: ../locale/scriptstrings/t.vect.import_to_translate.c:7
+#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:8
+#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:8
+msgid "Basename of the new generated output maps"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.extract_to_translate.c:8
+#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:9
+#: ../locale/scriptstrings/t.rast.contour_to_translate.c:8
+#: ../locale/scriptstrings/t.vect.algebra_to_translate.c:8
+#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:9
+#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:7
+#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:14
+#: ../locale/scriptstrings/t.vect.extract_to_translate.c:7
+#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:15
+#: ../locale/scriptstrings/t.rast.import_to_translate.c:8
+#: ../locale/scriptstrings/t.rast.algebra_to_translate.c:8
+#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:9
+#: ../locale/scriptstrings/t.vect.import_to_translate.c:8
+#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:8
+#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:9
+#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:9
+msgid "A numerical suffix separated by an underscore will be attached to create a unique identifier"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.extract_to_translate.c:9
+#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:10
+#: ../locale/scriptstrings/t.rast.contour_to_translate.c:9
+#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:10
+#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:8
+#: ../locale/scriptstrings/t.vect.extract_to_translate.c:8
+#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:8
+#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:10
+#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:9
+msgid "Suffix to add at basename: set 'gran' for granularity, 'time' for the full time format, 'num' for numerical suffix with a specific number of digits (default %05)"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.extract_to_translate.c:10
+#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:13
+#: ../locale/scriptstrings/t.rast.algebra_to_translate.c:9
+#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:9
+msgid "Number of r.mapcalc processes to run in parallel"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.extract_to_translate.c:11
+#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:14
+#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:14
+#: ../locale/scriptstrings/t.rast.algebra_to_translate.c:11
+#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:12
+#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:10
+#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:11
+#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:12
+#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:11
+msgid "Register Null maps"
+msgstr ""
+#: ../locale/scriptstrings/wxpyimgview_to_translate.c:1
+msgid "Views BMP images from the PNG driver."
+msgstr ""
+#: ../locale/scriptstrings/wxpyimgview_to_translate.c:2
+#: ../locale/scriptstrings/d.shade_to_translate.c:2
+#: ../locale/scriptstrings/d.polar_to_translate.c:2
+#: ../locale/scriptstrings/d.what.vect_to_translate.c:2
+#: ../locale/scriptstrings/d.what.rast_to_translate.c:2
+#: ../locale/scriptstrings/d.redraw_to_translate.c:2
+#: ../locale/scriptstrings/d.frame_to_translate.c:2
+#: ../locale/scriptstrings/d.to.rast_to_translate.c:2
+#: ../locale/scriptstrings/d.correlate_to_translate.c:2
+#: ../locale/scriptstrings/d.rast.edit_to_translate.c:2
+#: ../locale/scriptstrings/d.out.file_to_translate.c:2
+#: ../locale/scriptstrings/d.rast.leg_to_translate.c:2
+#: ../display/d.colortable/main.c:60 ../display/d.mon/main.c:50
+#: ../display/d.vect.thematic/main.c:85 ../display/d.geodesic/main.c:46
+#: ../display/d.his/main.c:62 ../display/d.barscale/main.c:63
+#: ../display/d.rgb/main.c:53 ../display/d.grid/main.c:53
+#: ../display/d.legend.vect/main.c:50 ../display/d.colorlist/main.c:35
+#: ../display/d.extract/main.c:49 ../display/d.rhumbline/main.c:44
+#: ../display/d.graph/main.c:58 ../display/d.legend/main.c:78
+#: ../display/d.rast.num/main.c:77 ../display/d.fontlist/main.c:45
+#: ../display/d.labels/main.c:43 ../display/d.linegraph/main.c:231
+#: ../display/d.vect.chart/main.c:63 ../display/d.text/main.c:139
+#: ../display/d.info/main.c:34 ../display/d.path/main.c:48
+#: ../display/d.rast/main.c:53 ../display/d.northarrow/main.c:46
+#: ../display/d.erase/main.c:29 ../display/d.where/main.c:43
+#: ../display/d.font/main.c:45 ../display/d.histogram/main.c:83
+#: ../display/d.vect/main.c:73 ../display/d.profile/main.c:191
+#: ../display/d.title/main.c:49 ../display/d.rast.arrow/main.c:97
+#: ../raster3d/r3.mkdspf/main.c:80 ../general/g.ppmtopng/main.c:118
+#: ../general/g.cairocomp/main.c:197 ../general/g.pnmcomp/main.c:283
+#: ../visualization/ximgview/main.c:290
+msgid "display"
+msgstr ""
+#: ../locale/scriptstrings/wxpyimgview_to_translate.c:3
+#: ../locale/scriptstrings/d.redraw_to_translate.c:3
+#: ../locale/scriptstrings/d.frame_to_translate.c:3 ../display/d.mon/main.c:51
+#: ../display/d.his/main.c:63 ../display/d.rgb/main.c:54
+#: ../display/d.info/main.c:35 ../display/d.rast/main.c:54
+#: ../display/d.erase/main.c:30 ../display/d.vect/main.c:74
+#: ../misc/m.nviz.image/main.c:52 ../misc/m.nviz.script/main.c:70
+#: ../visualization/ximgview/main.c:291
+msgid "graphics"
+msgstr ""
+#: ../locale/scriptstrings/wxpyimgview_to_translate.c:5
+msgid "Name of input image file"
+msgstr ""
+#: ../locale/scriptstrings/wxpyimgview_to_translate.c:6
+#: ../visualization/ximgview/main.c:308
+msgid "Percentage of CPU time to use"
+msgstr ""
+#: ../locale/scriptstrings/v.db.addtable_to_translate.c:1
+msgid "Creates and connects a new attribute table to a given layer of an existing vector map."
+msgstr ""
+#: ../locale/scriptstrings/v.db.addtable_to_translate.c:2
+#: ../locale/scriptstrings/v.to.lines_to_translate.c:2
+#: ../locale/scriptstrings/v.clip_to_translate.c:2
+#: ../locale/scriptstrings/v.rast.stats_to_translate.c:2
+#: ../locale/scriptstrings/t.vect.univar_to_translate.c:4
+#: ../locale/scriptstrings/v.what.vect_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.contour_to_translate.c:5
+#: ../locale/scriptstrings/t.vect.export_to_translate.c:4
+#: ../locale/scriptstrings/t.vect.algebra_to_translate.c:4
+#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:5
+#: ../locale/scriptstrings/v.what.strds_to_translate.c:2
+#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:2
+#: ../locale/scriptstrings/d.what.vect_to_translate.c:3
+#: ../locale/scriptstrings/t.vect.extract_to_translate.c:4
+#: ../locale/scriptstrings/t.vect.list_to_translate.c:4
+#: ../locale/scriptstrings/t.vect.db.select_to_translate.c:4
+#: ../locale/scriptstrings/v.build.all_to_translate.c:2
+#: ../locale/scriptstrings/v.import_to_translate.c:2
+#: ../locale/scriptstrings/v.in.lines_to_translate.c:2
+#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:2
+#: ../locale/scriptstrings/v.report_to_translate.c:2
+#: ../locale/scriptstrings/v.unpack_to_translate.c:2
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:2
+#: ../locale/scriptstrings/v.db.update_to_translate.c:2
+#: ../locale/scriptstrings/v.db.join_to_translate.c:2
+#: ../locale/scriptstrings/d.what.rast_to_translate.c:3
+#: ../locale/scriptstrings/v.centroids_to_translate.c:2
+#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:2
+#: ../locale/scriptstrings/v.db.droprow_to_translate.c:2
+#: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:4
+#: ../locale/scriptstrings/v.dissolve_to_translate.c:2
+#: ../locale/scriptstrings/t.vect.import_to_translate.c:4
+#: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:4
+#: ../locale/scriptstrings/v.in.e00_to_translate.c:2
+#: ../locale/scriptstrings/v.in.wfs_to_translate.c:2
+#: ../locale/scriptstrings/v.in.geonames_to_translate.c:2
+#: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:2
+#: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:2
+#: ../locale/scriptstrings/v.pack_to_translate.c:2
+#: ../locale/scriptstrings/v.db.droptable_to_translate.c:2
+#: ../doc/vector/v.example/main.c:50 ../raster/r.random/main.c:53
+#: ../raster/r.contour/main.c:90 ../display/d.legend.vect/main.c:52
+#: ../display/d.extract/main.c:50 ../display/d.vect/main.c:75
+#: ../misc/m.nviz.image/main.c:54 ../misc/m.nviz.script/main.c:73
+#: ../vector/v.out.vtk/main.c:47 ../vector/v.mkgrid/main.c:70
+#: ../vector/v.external.out/main.c:43 ../vector/v.what.rast3/main.c:64
+#: ../vector/v.to.rast/main.c:44 ../vector/v.lidar.edgedetection/main.c:75
+#: ../vector/v.out.ogr/main.c:83 ../vector/v.kcv/main.c:55
+#: ../vector/v.surf.idw/main.c:87 ../vector/v.class/main.c:45
+#: ../vector/v.clean/test/topocheck.c:42 ../vector/v.clean/main.c:51
+#: ../vector/v.label.sa/main.c:38 ../vector/v.net.distance/main.c:66
+#: ../vector/v.random/main.c:97 ../vector/v.support/main.c:39
+#: ../vector/v.out.dxf/main.c:56 ../vector/v.out.lidar/main.c:471
+#: ../vector/v.proj/main.c:68 ../vector/v.db.connect/main.c:52
+#: ../vector/v.to.rast3/main.c:48 ../vector/v.out.ascii/main.c:47
+#: ../vector/v.cluster/main.c:90 ../vector/v.in.lidar/main.c:136
+#: ../vector/v.build.polylines/main.c:110
+#: ../vector/v.lidar.correction/main.c:71 ../vector/v.reclass/main.c:67
+#: ../vector/v.segment/main.c:60 ../vector/v.surf.rst/main.c:147
+#: ../vector/v.surf.bspline/main.c:91 ../vector/v.db.select/main.c:54
+#: ../vector/v.net.allpairs/main.c:61 ../vector/v.in.dwg/main.c:82
+#: ../vector/v.drape/main.c:56 ../vector/v.buffer/main.c:221
+#: ../vector/v.lidar.growing/main.c:75 ../vector/v.select/main.c:48
+#: ../vector/v.profile/main.c:153 ../vector/v.extrude/main.c:67
+#: ../vector/v.in.region/main.c:41 ../vector/v.hull/main.c:52
+#: ../vector/v.out.svg/main.c:77 ../vector/v.net.connectivity/main.c:52
+#: ../vector/v.in.ogr/main.c:195 ../vector/v.patch/main.c:69
+#: ../vector/v.net.path/main.c:42 ../vector/v.overlay/main.c:63
+#: ../vector/v.perturb/main.c:62 ../vector/v.net.iso/main.c:76
+#: ../vector/v.to.3d/main.c:36 ../vector/v.timestamp/main.c:35
+#: ../vector/v.type/main.c:38 ../vector/v.what.rast/main.c:71
+#: ../vector/v.net.spanningtree/main.c:46 ../vector/v.net.steiner/main.c:346
+#: ../vector/v.net.flow/main.c:58 ../vector/v.delaunay/main.c:85
+#: ../vector/v.normal/main.c:72 ../vector/v.sample/main.c:75
+#: ../vector/v.rectify/main.c:70 ../vector/v.qcount/main.c:60
+#: ../vector/v.univar/main.c:92 ../vector/v.distance/main.c:121
+#: ../vector/v.net.timetable/main.c:260 ../vector/v.in.db/main.c:52
+#: ../vector/v.in.ascii/main.c:70 ../vector/v.net.visibility/main.c:45
+#: ../vector/v.out.pov/main.c:46 ../vector/v.to.points/main.c:53
+#: ../vector/v.colors/main.c:55 ../vector/v.build/main.c:36
+#: ../vector/v.voronoi/main.c:123 ../vector/v.net.bridge/main.c:47
+#: ../vector/v.neighbors/main.c:50 ../vector/v.split/main.c:54
+#: ../vector/v.vol.rst/main.c:235 ../vector/v.net.components/main.c:72
+#: ../vector/v.decimate/main.c:123 ../vector/v.what/main.c:62
+#: ../vector/v.outlier/main.c:69 ../vector/v.net.salesman/main.c:127
+#: ../vector/v.colors.out/main.c:49 ../vector/v.kernel/main.c:108
+#: ../vector/v.category/main.c:75 ../vector/v.label/main.c:59
+#: ../vector/v.edit/main.c:54 ../vector/v.net.centrality/main.c:96
+#: ../vector/v.info/print.c:436 ../vector/v.info/main.c:37
+#: ../vector/v.parallel/main.c:49 ../vector/v.out.postgis/main.c:44
+#: ../vector/v.in.dxf/main.c:64 ../vector/v.vect.stats/main.c:130
+#: ../vector/v.extract/main.c:77 ../vector/v.lrs/v.lrs.label/main.c:102
+#: ../vector/v.lrs/v.lrs.where/main.c:57
+#: ../vector/v.lrs/v.lrs.segment/main.c:71
+#: ../vector/v.lrs/v.lrs.create/main.c:121 ../vector/v.net/main.c:47
+#: ../vector/v.net.alloc/main.c:64 ../vector/v.transform/main.c:70
+#: ../vector/v.generalize/main.c:76 ../vector/v.external/main.c:52
+#: ../vector/v.to.db/main.c:36 ../visualization/ximgview/main.c:293
+msgid "vector"
+msgstr ""
+#: ../locale/scriptstrings/v.db.addtable_to_translate.c:3
+#: ../locale/scriptstrings/db.droptable_to_translate.c:3
+#: ../locale/scriptstrings/v.what.vect_to_translate.c:7
+#: ../locale/scriptstrings/v.what.strds_to_translate.c:7
+#: ../locale/scriptstrings/db.test_to_translate.c:3
+#: ../locale/scriptstrings/t.vect.db.select_to_translate.c:3
+#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:3
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:4
+#: ../locale/scriptstrings/v.db.update_to_translate.c:3
+#: ../locale/scriptstrings/db.out.ogr_to_translate.c:4
+#: ../locale/scriptstrings/db.in.ogr_to_translate.c:4
+#: ../locale/scriptstrings/v.db.join_to_translate.c:3
+#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:3
+#: ../locale/scriptstrings/v.db.droprow_to_translate.c:3
+#: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:3
+#: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:3
+#: ../locale/scriptstrings/v.db.droptable_to_translate.c:3
+#: ../locale/scriptstrings/db.univar_to_translate.c:4
+#: ../locale/scriptstrings/db.dropcolumn_to_translate.c:3
+#: ../db/db.databases/main.c:96 ../db/db.columns/main.c:100
+#: ../db/db.copy/main.c:36 ../db/db.connect/main.c:44
+#: ../db/db.describe/main.c:130 ../db/db.execute/main.c:126
+#: ../db/db.select/main.c:266 ../db/db.tables/main.c:98
+#: ../db/db.dropdb/main.c:72 ../db/db.createdb/main.c:72
+#: ../vector/v.what.rast3/main.c:69 ../vector/v.class/main.c:47
+#: ../vector/v.db.connect/main.c:53 ../vector/v.db.select/main.c:55
+#: ../vector/v.what.rast/main.c:76 ../vector/v.univar/main.c:95
+#: ../vector/v.distance/main.c:124 ../vector/v.vect.stats/main.c:131
+#: ../vector/v.to.db/main.c:37
+msgid "attribute table"
+msgstr ""
+#: ../locale/scriptstrings/v.db.addtable_to_translate.c:4
+#: ../locale/scriptstrings/db.droptable_to_translate.c:2
+#: ../locale/scriptstrings/v.what.vect_to_translate.c:4
+#: ../locale/scriptstrings/db.test_to_translate.c:2
+#: ../locale/scriptstrings/t.vect.db.select_to_translate.c:5
+#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:4
+#: ../locale/scriptstrings/v.db.update_to_translate.c:4
+#: ../locale/scriptstrings/db.out.ogr_to_translate.c:2
+#: ../locale/scriptstrings/db.in.ogr_to_translate.c:2
+#: ../locale/scriptstrings/v.db.join_to_translate.c:4
+#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:4
+#: ../locale/scriptstrings/v.db.droprow_to_translate.c:4
+#: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:4
+#: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:4
+#: ../locale/scriptstrings/v.db.droptable_to_translate.c:4
+#: ../locale/scriptstrings/db.univar_to_translate.c:2
+#: ../locale/scriptstrings/db.dropcolumn_to_translate.c:2
+#: ../db/db.databases/main.c:95 ../db/db.drivers/main.c:71
+#: ../db/db.columns/main.c:99 ../db/db.copy/main.c:35
+#: ../db/db.connect/main.c:43 ../db/db.describe/main.c:129
+#: ../db/db.execute/main.c:125 ../db/db.select/main.c:265
+#: ../db/db.login/main.c:40 ../db/db.tables/main.c:97 ../db/db.dropdb/main.c:71
+#: ../db/db.createdb/main.c:71 ../vector/v.db.connect/main.c:54
+#: ../vector/v.db.select/main.c:56 ../vector/v.distance/main.c:123
+#: ../vector/v.in.db/main.c:54 ../vector/v.vect.stats/main.c:132
+#: ../vector/v.to.db/main.c:38
+msgid "database"
+msgstr ""
+#: ../locale/scriptstrings/v.db.addtable_to_translate.c:5
+msgid "Name of new attribute table (default: vector map name)"
+msgstr ""
+#: ../locale/scriptstrings/v.db.addtable_to_translate.c:6
+#: ../locale/scriptstrings/v.db.addtable_to_translate.c:8
+#: ../locale/scriptstrings/v.db.addtable_to_translate.c:9
+#: ../locale/scriptstrings/v.db.addtable_to_translate.c:12
+msgid "Definition"
+msgstr ""
+#: ../locale/scriptstrings/v.db.addtable_to_translate.c:7
+msgid "Layer number where to add new attribute table"
+msgstr ""
+#: ../locale/scriptstrings/v.db.addtable_to_translate.c:10
+#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:6
+msgid "Name and type of the new column(s) ('name type [,name type, ...]')"
+msgstr ""
+#: ../locale/scriptstrings/v.db.addtable_to_translate.c:11
+#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:7
+msgid "Types depend on database backend, but all support VARCHAR(), INT, DOUBLE PRECISION and DATE. Example: 'label varchar(250), value integer'"
+msgstr ""
+#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:1
+msgid "Sets color rules based on stddev from a raster map's mean value."
+msgstr ""
+#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:3
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:3
+#: ../raster/r.colors/edit_colors.c:67 ../raster/r.colors.out/raster_main.c:46
+#: ../raster/r.colors.out/raster3d_main.c:47 ../raster/r.what.color/main.c:90
+#: ../display/d.colortable/main.c:62 ../vector/v.colors/main.c:56
+#: ../vector/v.colors.out/main.c:50
+msgid "color table"
+msgstr ""
+#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:4
+msgid "Color using standard deviation bands"
+msgstr ""
+#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:5
+msgid "Force center at zero"
+msgstr ""
+#: ../locale/scriptstrings/v.to.lines_to_translate.c:1
+msgid "Converts vector polygons or points to lines."
+msgstr ""
+#: ../locale/scriptstrings/v.to.lines_to_translate.c:3
+#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:3
+#: ../locale/scriptstrings/v.report_to_translate.c:3 ../raster/r.thin/main.c:58
+#: ../raster/r.circle/main.c:53 ../raster/r.to.vect/main.c:78
+#: ../raster/r.patch/main.c:59 ../vector/v.mkgrid/main.c:71
+#: ../vector/v.clean/main.c:53 ../vector/v.build.polylines/main.c:112
+#: ../vector/v.segment/main.c:61 ../vector/v.drape/main.c:57
+#: ../vector/v.buffer/main.c:225 ../vector/v.select/main.c:49
+#: ../vector/v.extrude/main.c:68 ../vector/v.in.region/main.c:42
+#: ../vector/v.hull/main.c:53 ../vector/v.in.ogr/main.c:199
+#: ../vector/v.patch/main.c:70 ../vector/v.overlay/main.c:64
+#: ../vector/v.perturb/main.c:63 ../vector/v.to.3d/main.c:37
+#: ../vector/v.type/main.c:39 ../vector/v.delaunay/main.c:86
+#: ../vector/v.univar/main.c:96 ../vector/v.to.points/main.c:54
+#: ../vector/v.build/main.c:38 ../vector/v.voronoi/main.c:124
+#: ../vector/v.split/main.c:55 ../vector/v.edit/main.c:55
+#: ../vector/v.parallel/main.c:50 ../vector/v.transform/main.c:72
+#: ../vector/v.generalize/main.c:83
+msgid "geometry"
+msgstr ""
+#: ../locale/scriptstrings/v.to.lines_to_translate.c:4
+#: ../locale/scriptstrings/v.clip_to_translate.c:4
+#: ../locale/scriptstrings/v.centroids_to_translate.c:4
+#: ../locale/scriptstrings/v.dissolve_to_translate.c:4
+#: ../misc/m.measure/main.c:49 ../vector/v.buffer/main.c:223
+#: ../vector/v.type/main.c:41 ../vector/v.category/main.c:695
+msgid "area"
+msgstr ""
+#: ../locale/scriptstrings/v.to.lines_to_translate.c:5
+#: ../locale/scriptstrings/v.in.lines_to_translate.c:4
+#: ../locale/scriptstrings/v.dissolve_to_translate.c:5
+#: ../vector/v.build.polylines/main.c:113 ../vector/v.buffer/main.c:226
+#: ../vector/v.type/main.c:42 ../vector/v.to.points/main.c:56
+#: ../vector/v.category/main.c:683 ../vector/v.edit/main.c:57
+#: ../vector/v.parallel/main.c:52
+msgid "line"
+msgstr ""
+#: ../locale/scriptstrings/v.to.lines_to_translate.c:6
+#: ../locale/scriptstrings/v.in.lines_to_translate.c:5
+#: ../vector/v.segment/main.c:63 ../vector/v.type/main.c:43
+#: ../vector/v.to.points/main.c:59 ../vector/v.category/main.c:679
+#: ../vector/v.edit/main.c:59
+msgid "point"
+msgstr ""
+#: ../locale/scriptstrings/v.to.lines_to_translate.c:7
+msgid "Method used for point interpolation"
+msgstr ""
+#: ../locale/scriptstrings/v.to.lines_to_translate.c:8
+#: ../locale/scriptstrings/r.reclass.area_to_translate.c:6
+#: ../locale/scriptstrings/r.reclass.area_to_translate.c:8
+#: ../locale/scriptstrings/r.reclass.area_to_translate.c:10
+msgid "Area"
+msgstr ""
+#: ../locale/scriptstrings/t.support_to_translate.c:1
+msgid "Modifies the metadata of a space time dataset."
+msgstr ""
+#: ../locale/scriptstrings/t.support_to_translate.c:5
+#: ../locale/scriptstrings/t.create_to_translate.c:7
+msgid "Semantic type of the space time dataset"
+msgstr ""
+#: ../locale/scriptstrings/t.support_to_translate.c:6
+#: ../locale/scriptstrings/t.select_to_translate.c:5
+#: ../locale/scriptstrings/t.info_to_translate.c:7
+#: ../locale/scriptstrings/t.snap_to_translate.c:7
+#: ../locale/scriptstrings/t.rename_to_translate.c:6
+#: ../locale/scriptstrings/t.topology_to_translate.c:5
+#: ../locale/scriptstrings/t.shift_to_translate.c:7
+msgid "input"
+msgstr ""
+#: ../locale/scriptstrings/t.support_to_translate.c:7
+#: ../locale/scriptstrings/t.select_to_translate.c:6
+#: ../locale/scriptstrings/t.info_to_translate.c:8
+#: ../locale/scriptstrings/t.snap_to_translate.c:8
+#: ../locale/scriptstrings/t.rename_to_translate.c:7
+#: ../locale/scriptstrings/t.sample_to_translate.c:6
+#: ../locale/scriptstrings/t.sample_to_translate.c:7
+#: ../locale/scriptstrings/t.topology_to_translate.c:6
+#: ../locale/scriptstrings/t.merge_to_translate.c:7
+#: ../locale/scriptstrings/t.shift_to_translate.c:8
+msgid "Required"
+msgstr ""
+#: ../locale/scriptstrings/t.support_to_translate.c:8
+msgid "Title of the space time dataset"
+msgstr ""
+#: ../locale/scriptstrings/t.support_to_translate.c:9
+msgid "Description of the space time dataset"
+msgstr ""
+#: ../locale/scriptstrings/t.support_to_translate.c:10
+msgid "Aggregation type of the space time raster or 3D raster dataset"
+msgstr ""
+#: ../locale/scriptstrings/t.support_to_translate.c:11
+msgid "Update the metadata information and spatial extent of registered maps from the GRASS spatial database"
+msgstr ""
+#: ../locale/scriptstrings/t.support_to_translate.c:12
+msgid "Check for removed maps and delete them from the temporal database and all effected space time datasets"
+msgstr ""
+#: ../locale/scriptstrings/t.support_to_translate.c:13
+msgid "Update metadata information, temporal and spatial extent from registered maps based on database entries."
+msgstr ""
+#: ../locale/scriptstrings/r.pack_to_translate.c:1
+msgid "Exports a raster map as GRASS GIS specific archive file"
+msgstr ""
+#: ../locale/scriptstrings/r.pack_to_translate.c:3
+#: ../locale/scriptstrings/t.vect.export_to_translate.c:3
+#: ../locale/scriptstrings/r.out.xyz_to_translate.c:3
+#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:3
+#: ../locale/scriptstrings/db.out.ogr_to_translate.c:3
+#: ../locale/scriptstrings/d.to.rast_to_translate.c:3
+#: ../locale/scriptstrings/d.out.file_to_translate.c:3
+#: ../locale/scriptstrings/v.pack_to_translate.c:3
+#: ../locale/scriptstrings/t.rast.export_to_translate.c:3
+#: ../raster/r.out.pov/main.c:122 ../raster/r.out.ppm3/main.c:58
+#: ../raster/r.out.bin/main.c:280 ../raster/r.out.vtk/main.c:60
+#: ../raster/r.colors.out/raster_main.c:47
+#: ../raster/r.colors.out/raster3d_main.c:48 ../raster/r.out.gridatb/main.c:68
+#: ../raster/r.out.gdal/main.c:140 ../raster/r.out.vrml/main.c:48
+#: ../raster/r.external.out/main.c:236 ../raster/r.out.png/main.c:113
+#: ../raster/r.out.ascii/main.c:60 ../raster/r.out.mpeg/main.c:103
+#: ../raster/r.out.ppm/main.c:55 ../raster/r.out.mat/main.c:63
+#: ../raster3d/r3.out.netcdf/main.c:587 ../raster3d/r3.out.vtk/main.c:377
+#: ../raster3d/r3.out.bin/main.c:206 ../raster3d/r3.out.v5d/main.c:285
+#: ../raster3d/r3.out.ascii/main.c:303 ../vector/v.out.vtk/main.c:48
+#: ../vector/v.external.out/main.c:44 ../vector/v.out.ogr/main.c:84
+#: ../vector/v.out.dxf/main.c:57 ../vector/v.out.lidar/main.c:472
+#: ../vector/v.out.ascii/main.c:48 ../vector/v.out.svg/main.c:78
+#: ../vector/v.out.pov/main.c:47 ../vector/v.colors.out/main.c:51
+#: ../vector/v.out.postgis/main.c:45
+msgid "export"
+msgstr "export"
+#: ../locale/scriptstrings/r.pack_to_translate.c:4
+#: ../locale/scriptstrings/v.unpack_to_translate.c:4
+#: ../locale/scriptstrings/r.unpack_to_translate.c:4
+#: ../locale/scriptstrings/v.pack_to_translate.c:4
+msgid "copying"
+msgstr ""
+#: ../locale/scriptstrings/r.pack_to_translate.c:5
+msgid "Name of raster map to pack up"
+msgstr ""
+#: ../locale/scriptstrings/r.pack_to_translate.c:6
+#: ../locale/scriptstrings/v.pack_to_translate.c:6
+msgid "Name for output file (default is <input>.pack)"
+msgstr ""
+#: ../locale/scriptstrings/r.pack_to_translate.c:7
+#: ../locale/scriptstrings/v.pack_to_translate.c:7
+msgid "Switch the compression off"
+msgstr ""
+#: ../locale/scriptstrings/v.clip_to_translate.c:1
+msgid "Extracts features of input map which overlay features of clip map."
+msgstr ""
+#: ../locale/scriptstrings/v.clip_to_translate.c:3
+#: ../vector/v.overlay/main.c:66
+msgid "clip"
+msgstr ""
+#: ../locale/scriptstrings/v.clip_to_translate.c:5
+msgid "Name of vector map to be clipped"
+msgstr ""
+#: ../locale/scriptstrings/v.clip_to_translate.c:6
+msgid "Name of clip vector map"
+msgstr ""
+#: ../locale/scriptstrings/v.clip_to_translate.c:7
+msgid "Do not dissolve clip map"
+msgstr ""
+#: ../locale/scriptstrings/v.clip_to_translate.c:8
+msgid "Clip by region"
+msgstr ""
+#: ../locale/scriptstrings/v.clip_to_translate.c:9
+#: ../raster/r.in.gdal/main.c:204 ../raster/r.in.gdal/main.c:237
+#: ../vector/v.db.select/main.c:101
+msgid "Region"
+msgstr ""
+#: ../locale/scriptstrings/v.rast.stats_to_translate.c:1
+msgid "Calculates univariate statistics from a raster map based on a vector map and uploads statistics to new attribute columns."
+msgstr ""
+#: ../locale/scriptstrings/v.rast.stats_to_translate.c:3
+#: ../locale/scriptstrings/t.vect.univar_to_translate.c:3
+#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:3
+#: ../locale/scriptstrings/r.reclass.area_to_translate.c:3
+#: ../locale/scriptstrings/v.report_to_translate.c:4
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:3
+#: ../locale/scriptstrings/t.rast.univar_to_translate.c:3
+#: ../locale/scriptstrings/i.oif_to_translate.c:4
+#: ../locale/scriptstrings/d.correlate_to_translate.c:3
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:6
+#: ../locale/scriptstrings/db.univar_to_translate.c:3
+#: ../raster/r.surf.area/main.c:78 ../raster/r.regression.multi/main.c:130
+#: ../raster/r.mfilter/main.c:58 ../raster/r.texture/main.c:104
+#: ../raster/r.stats/main.c:107 ../raster/r.stats.quantile/main.c:517
+#: ../raster/r.univar/r3.univar_main.c:99
+#: ../raster/r.univar/r.univar_main.c:105 ../raster/r.report/main.c:68
+#: ../raster/r.quant/main.c:48 ../raster/r.mode/main.c:56
+#: ../raster/r.support.stats/main.c:39 ../raster/r.neighbors/main.c:169
+#: ../raster/r.clump/main.c:59 ../raster/r.cross/main.c:69
+#: ../raster/r.in.lidar/main.c:111 ../raster/r.statistics/main.c:56
+#: ../raster/r.stats.zonal/main.c:102 ../raster/r.regression.line/main.c:47
+#: ../raster/r.in.xyz/main.c:160 ../raster/r.kappa/main.c:69
+#: ../raster/r.coin/main.c:67 ../raster/r.quantile/main.c:267
+#: ../raster/r.covar/main.c:52 ../display/d.histogram/main.c:85
+#: ../raster3d/r3.neighbors/main.c:211 ../raster3d/r3.stats/main.c:49
+#: ../raster3d/r3.in.lidar/main.c:165 ../imagery/i.cca/main.c:85
+#: ../vector/v.kcv/main.c:56 ../vector/v.class/main.c:48
+#: ../vector/v.random/main.c:99 ../vector/v.perturb/main.c:64
+#: ../vector/v.normal/main.c:73 ../vector/v.qcount/main.c:61
+#: ../vector/v.univar/main.c:93 ../vector/v.neighbors/main.c:52
+#: ../vector/v.outlier/main.c:70
+msgid "statistics"
+msgstr "statisztika"
+#: ../locale/scriptstrings/v.rast.stats_to_translate.c:5
+#: ../raster/r.univar/r3.univar_main.c:100
+#: ../raster/r.univar/r.univar_main.c:106 ../vector/v.univar/main.c:94
+#: ../vector/v.vect.stats/main.c:133
+msgid "univariate statistics"
+msgstr ""
+#: ../locale/scriptstrings/v.rast.stats_to_translate.c:6
+#: ../raster/r.univar/r.univar_main.c:107 ../raster/r.statistics/main.c:57
+#: ../raster/r.stats.zonal/main.c:103 ../vector/v.vect.stats/main.c:134
+msgid "zonal statistics"
+msgstr ""
+#: ../locale/scriptstrings/v.rast.stats_to_translate.c:7
+#: ../locale/scriptstrings/v.what.vect_to_translate.c:3
+#: ../locale/scriptstrings/v.what.strds_to_translate.c:4
+#: ../locale/scriptstrings/t.rast.what_to_translate.c:3
+#: ../locale/scriptstrings/t.sample_to_translate.c:3
+#: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:3
+#: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:3
+#: ../raster/r.random/main.c:52 ../raster/r.random.cells/main.c:48
+#: ../display/d.where/main.c:44 ../vector/v.what.rast3/main.c:65
+#: ../vector/v.random/main.c:98 ../vector/v.drape/main.c:58
+#: ../vector/v.extrude/main.c:69 ../vector/v.what.rast/main.c:72
+#: ../vector/v.sample/main.c:76
+msgid "sampling"
+msgstr ""
+#: ../locale/scriptstrings/v.rast.stats_to_translate.c:8
+#: ../locale/scriptstrings/v.what.vect_to_translate.c:6
+#: ../locale/scriptstrings/v.what.strds_to_translate.c:6
+#: ../locale/scriptstrings/i.spectral_to_translate.c:3
+#: ../raster/r.what.color/main.c:89 ../raster/r.what/main.c:101
+#: ../display/d.where/main.c:46 ../vector/v.what.rast3/main.c:68
+#: ../vector/v.what.rast/main.c:75 ../vector/v.what/main.c:63
+msgid "querying"
+msgstr ""
+#: ../locale/scriptstrings/v.rast.stats_to_translate.c:9
+msgid "Continue if upload column(s) already exist"
+msgstr ""
+#: ../locale/scriptstrings/v.rast.stats_to_translate.c:10
+#: ../vector/v.to.rast/main.c:121
+msgid "Create densified lines (default: thin lines)"
+msgstr ""
+#: ../locale/scriptstrings/v.rast.stats_to_translate.c:11
+#: ../vector/v.to.rast/main.c:122
+msgid "All cells touched by the line will be set, not only those on the render path"
+msgstr ""
+#: ../locale/scriptstrings/v.rast.stats_to_translate.c:12
+msgid "Name of input raster map to calculate statistics from"
+msgstr ""
+#: ../locale/scriptstrings/v.rast.stats_to_translate.c:13
+msgid "Column prefix for new attribute columns"
+msgstr ""
+#: ../locale/scriptstrings/v.rast.stats_to_translate.c:14
+msgid "The methods to use"
+msgstr ""
+#: ../locale/scriptstrings/v.rast.stats_to_translate.c:15
+msgid "Percentile to calculate"
+msgstr ""
+#: ../locale/scriptstrings/i.pansharpen_to_translate.c:1
+msgid "Image fusion algorithms to sharpen multispectral with high-res panchromatic channels"
+msgstr ""
+#: ../locale/scriptstrings/i.pansharpen_to_translate.c:2
+#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:2
+#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:2
+#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:2
+#: ../locale/scriptstrings/i.spectral_to_translate.c:2
+#: ../locale/scriptstrings/i.oif_to_translate.c:2
+#: ../locale/scriptstrings/r.in.aster_to_translate.c:4
+#: ../locale/scriptstrings/i.tasscap_to_translate.c:2
+#: ../imagery/i.eb.hsebal01/main.c:104 ../imagery/i.rgb.his/main.c:46
+#: ../imagery/i.segment/main.c:36 ../imagery/i.eb.soilheatflux/main.c:49
+#: ../imagery/i.gensig/main.c:39 ../imagery/i.evapo.mh/main.c:69
+#: ../imagery/i.eb.eta/main.c:42 ../imagery/i.his.rgb/main.c:46
+#: ../imagery/i.rectify/main.c:83 ../imagery/i.maxlik/main.c:61
+#: ../imagery/i.fft/main.c:78 ../imagery/i.smap/main.c:38
+#: ../imagery/i.eb.evapfr/main.c:47 ../imagery/i.target/main.c:45
+#: ../imagery/i.evapo.pt/main.c:66 ../imagery/i.gensigset/main.c:40
+#: ../imagery/i.topo.corr/main.c:47 ../imagery/i.albedo/main.c:95
+#: ../imagery/i.vi/main.c:89 ../imagery/i.cca/main.c:84
+#: ../imagery/i.evapo.time/main.c:77 ../imagery/i.eb.netrad/main.c:56
+#: ../imagery/i.cluster/main.c:75 ../imagery/i.aster.toar/main.c:97
+#: ../imagery/i.landsat.acca/main.c:105 ../imagery/i.modis.qc/main.c:168
+#: ../imagery/i.zc/main.c:53 ../imagery/i.pca/main.c:72
+#: ../imagery/i.ifft/main.c:77 ../imagery/i.landsat.toar/main.c:70
+#: ../imagery/i.emissivity/main.c:44 ../imagery/i.group/main.c:52
+#: ../imagery/i.biomass/main.c:50 ../imagery/i.evapo.pm/main.c:58
+#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:56
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:87
+#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:64
+#: ../imagery/i.ortho.photo/i.ortho.target/main.c:47
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:388
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:47
+#: ../imagery/i.ortho.photo/i.ortho.photo/menu.c:46
+msgid "imagery"
+msgstr ""
+#: ../locale/scriptstrings/i.pansharpen_to_translate.c:3
+msgid "fusion"
+msgstr ""
+#: ../locale/scriptstrings/i.pansharpen_to_translate.c:4
+msgid "sharpen"
+msgstr ""
+#: ../locale/scriptstrings/i.pansharpen_to_translate.c:5
+msgid "Brovey"
+msgstr ""
+#: ../locale/scriptstrings/i.pansharpen_to_translate.c:6
+msgid "IHS"
+msgstr ""
+#: ../locale/scriptstrings/i.pansharpen_to_translate.c:7
+msgid "HIS"
+msgstr ""
+#: ../locale/scriptstrings/i.pansharpen_to_translate.c:8
+#: ../imagery/i.pca/main.c:74
+msgid "PCA"
+msgstr ""
+#: ../locale/scriptstrings/i.pansharpen_to_translate.c:9
+msgid "Name of raster map to be used for <red>"
+msgstr ""
+#: ../locale/scriptstrings/i.pansharpen_to_translate.c:10
+msgid "Name of raster map to be used for <green>"
+msgstr ""
+#: ../locale/scriptstrings/i.pansharpen_to_translate.c:11
+msgid "Name of raster map to be used for <blue>"
+msgstr ""
+#: ../locale/scriptstrings/i.pansharpen_to_translate.c:12
+msgid "Name of raster map to be used for high resolution panchromatic channel"
+msgstr ""
+#: ../locale/scriptstrings/i.pansharpen_to_translate.c:13
+msgid "Method for pan sharpening"
+msgstr ""
+#: ../locale/scriptstrings/i.pansharpen_to_translate.c:14
+msgid "Serial processing rather than parallel processing"
+msgstr ""
+#: ../locale/scriptstrings/i.pansharpen_to_translate.c:15
+msgid "Rebalance blue channel for LANDSAT"
+msgstr ""
+#: ../locale/scriptstrings/d.shade_to_translate.c:1
+#: ../locale/scriptstrings/r.shade_to_translate.c:1
+msgid "Drapes a color raster over an shaded relief or aspect map."
+msgstr ""
+#: ../locale/scriptstrings/d.shade_to_translate.c:3
+#: ../locale/scriptstrings/r.shade_to_translate.c:3
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:3
+#: ../locale/scriptstrings/r.in.aster_to_translate.c:6
+#: ../locale/scriptstrings/r.plane_to_translate.c:3
+#: ../raster/r.param.scale/interface.c:57 ../raster/r.relief/main.c:108
+msgid "elevation"
+msgstr ""
+#: ../locale/scriptstrings/d.shade_to_translate.c:4
+#: ../locale/scriptstrings/r.shade_to_translate.c:4
+#: ../raster/r.relief/main.c:109
+msgid "relief"
+msgstr ""
+#: ../locale/scriptstrings/d.shade_to_translate.c:5
+#: ../locale/scriptstrings/r.shade_to_translate.c:5
+#: ../raster/r.relief/main.c:111
+msgid "hillshade"
+msgstr ""
+#: ../locale/scriptstrings/d.shade_to_translate.c:6
+#: ../locale/scriptstrings/r.shade_to_translate.c:6
+#: ../misc/m.nviz.image/main.c:51 ../misc/m.nviz.script/main.c:74
+#: ../visualization/ximgview/main.c:294
+msgid "visualization"
+msgstr ""
+#: ../locale/scriptstrings/d.shade_to_translate.c:7
+#: ../locale/scriptstrings/r.shade_to_translate.c:7
+msgid "Name of shaded relief or aspect raster map"
+msgstr ""
+#: ../locale/scriptstrings/d.shade_to_translate.c:8
+#: ../locale/scriptstrings/r.shade_to_translate.c:8
+msgid "Name of raster to drape over relief raster map"
+msgstr ""
+#: ../locale/scriptstrings/d.shade_to_translate.c:9
+#: ../locale/scriptstrings/r.shade_to_translate.c:9
+msgid "Typically, this raster is elevation or other colorful raster"
+msgstr ""
+#: ../locale/scriptstrings/d.shade_to_translate.c:10
+#: ../locale/scriptstrings/r.shade_to_translate.c:11
+msgid "Percent to brighten"
+msgstr ""
+#: ../locale/scriptstrings/t.select_to_translate.c:1
+msgid "Select maps from space time datasets by topological relationships to other space time datasets using temporal algebra."
+msgstr ""
+#: ../locale/scriptstrings/t.select_to_translate.c:7
+msgid "The temporal mapcalc expression"
+msgstr ""
+#: ../locale/scriptstrings/t.select_to_translate.c:8
+msgid "Check the spatial topology of temporally related maps and select only spatially related maps"
+msgstr ""
+#: ../locale/scriptstrings/t.select_to_translate.c:9
+#: ../locale/scriptstrings/t.rast.algebra_to_translate.c:13
+msgid "Perform a dry run, compute all dependencies and module calls but don't run them"
+msgstr ""
+#: ../locale/scriptstrings/t.vect.univar_to_translate.c:1
+msgid "Calculates univariate statistics of attributes for each registered vector map of a space time vector dataset"
+msgstr ""
+#: ../locale/scriptstrings/t.vect.univar_to_translate.c:6
+#: ../locale/scriptstrings/t.vect.univar_to_translate.c:7
+#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:10
+#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:11
+#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:7
+#: ../locale/scriptstrings/t.list_to_translate.c:7
+#: ../locale/scriptstrings/t.list_to_translate.c:8
+#: ../locale/scriptstrings/t.list_to_translate.c:14
+#: ../locale/scriptstrings/t.list_to_translate.c:15
+#: ../locale/scriptstrings/t.rast.list_to_translate.c:10
+#: ../locale/scriptstrings/t.rast.list_to_translate.c:11
+#: ../locale/scriptstrings/t.vect.list_to_translate.c:10
+#: ../locale/scriptstrings/t.vect.list_to_translate.c:11
+#: ../locale/scriptstrings/v.report_to_translate.c:5
+#: ../locale/scriptstrings/t.rast.univar_to_translate.c:6
+#: ../raster/r.in.lidar/main.c:193 ../raster/r.in.lidar/main.c:209
+#: ../raster/r.in.lidar/main.c:262 ../raster/r.in.lidar/main.c:272
+#: ../raster/r.in.lidar/main.c:341 ../raster/r.category/main.c:62
+#: ../raster/r.category/main.c:71 ../display/d.vect.thematic/main.c:98
+#: ../display/d.vect.thematic/main.c:148 ../display/d.vect.chart/main.c:74
+#: ../display/d.vect.chart/main.c:77 ../display/d.rast/main.c:70
+#: ../display/d.rast/main.c:87 ../display/d.vect/main.c:84
+#: ../display/d.vect/main.c:109 ../display/d.vect/main.c:112
+#: ../display/d.vect/main.c:115 ../display/d.vect/main.c:317
+#: ../raster3d/r3.in.lidar/main.c:232 ../raster3d/r3.in.lidar/main.c:242
+#: ../raster3d/r3.in.lidar/main.c:272 ../raster3d/r3.in.lidar/main.c:288
+#: ../vector/v.to.rast/main.c:57 ../vector/v.to.rast/main.c:60
+#: ../vector/v.to.rast/main.c:63 ../vector/v.out.ogr/args.c:12
+#: ../vector/v.out.ogr/args.c:22 ../vector/v.out.ogr/args.c:102
+#: ../vector/v.clean/main.c:61 ../vector/v.clean/main.c:64
+#: ../vector/v.random/main.c:119 ../vector/v.random/main.c:122
+#: ../vector/v.random/main.c:125 ../vector/v.random/main.c:128
+#: ../vector/v.out.lidar/main.c:487 ../vector/v.out.lidar/main.c:491
+#: ../vector/v.out.lidar/main.c:588 ../vector/v.out.ascii/args.c:24
+#: ../vector/v.out.ascii/args.c:28 ../vector/v.out.ascii/args.c:43
+#: ../vector/v.out.ascii/args.c:46 ../vector/v.in.lidar/main.c:187
+#: ../vector/v.in.lidar/main.c:197 ../vector/v.in.lidar/main.c:206
+#: ../vector/v.in.lidar/main.c:216 ../vector/v.in.lidar/main.c:223
+#: ../vector/v.in.lidar/main.c:228 ../vector/v.in.lidar/main.c:283
+#: ../vector/v.in.lidar/main.c:289 ../vector/v.in.lidar/main.c:297
+#: ../vector/v.reclass/main.c:77 ../vector/v.reclass/main.c:82
+#: ../vector/v.surf.rst/main.c:178 ../vector/v.surf.rst/main.c:190
+#: ../vector/v.db.select/main.c:64 ../vector/v.db.select/main.c:67
+#: ../vector/v.db.select/main.c:70 ../vector/v.db.select/main.c:76
+#: ../vector/v.db.select/main.c:116 ../vector/v.net.allpairs/main.c:75
+#: ../vector/v.net.allpairs/main.c:81 ../vector/v.net.allpairs/main.c:84
+#: ../vector/v.net.allpairs/main.c:87 ../vector/v.drape/main.c:67
+#: ../vector/v.drape/main.c:70 ../vector/v.drape/main.c:73
+#: ../vector/v.drape/main.c:78 ../vector/v.buffer/main.c:235
+#: ../vector/v.buffer/main.c:238 ../vector/v.buffer/main.c:241
+#: ../vector/v.buffer/main.c:246 ../vector/v.select/args.c:18
+#: ../vector/v.select/args.c:24 ../vector/v.select/args.c:33
+#: ../vector/v.select/args.c:39 ../vector/v.select/args.c:106
+#: ../vector/v.profile/main.c:165 ../vector/v.profile/main.c:168
+#: ../vector/v.profile/main.c:173 ../vector/v.extrude/main.c:84
+#: ../vector/v.extrude/main.c:87 ../vector/v.extrude/main.c:90
+#: ../vector/v.extrude/main.c:95 ../vector/v.in.ogr/main.c:238
+#: ../vector/v.in.ogr/main.c:243 ../vector/v.in.ogr/main.c:252
+#: ../vector/v.in.ogr/main.c:268 ../vector/v.in.ogr/main.c:316
+#: ../vector/v.in.ogr/main.c:361 ../vector/v.to.3d/args.c:19
+#: ../vector/v.to.3d/args.c:25 ../vector/v.in.db/main.c:94
+#: ../vector/v.to.points/main.c:67 ../vector/v.to.points/main.c:71
+#: ../vector/v.decimate/main.c:149 ../vector/v.decimate/main.c:152
+#: ../vector/v.category/main.c:85 ../vector/v.category/main.c:89
+#: ../vector/v.category/main.c:93 ../vector/v.edit/args.c:24
+#: ../vector/v.edit/args.c:29 ../vector/v.edit/args.c:118
+#: ../vector/v.edit/args.c:122 ../vector/v.edit/args.c:131
+#: ../vector/v.edit/args.c:140 ../vector/v.edit/args.c:149
+#: ../vector/v.edit/args.c:152 ../vector/v.edit/args.c:170
+#: ../vector/v.edit/args.c:205 ../vector/v.net.centrality/main.c:121
+#: ../vector/v.net.centrality/main.c:123 ../vector/v.out.postgis/args.c:15
+#: ../vector/v.out.postgis/args.c:19 ../vector/v.vect.stats/main.c:157
+#: ../vector/v.vect.stats/main.c:162 ../vector/v.vect.stats/main.c:167
+#: ../vector/v.vect.stats/main.c:172 ../vector/v.vect.stats/main.c:177
+#: ../vector/v.vect.stats/main.c:182 ../vector/v.extract/main.c:98
+#: ../vector/v.extract/main.c:103 ../vector/v.extract/main.c:109
+#: ../vector/v.extract/main.c:112 ../vector/v.extract/main.c:115
+#: ../vector/v.extract/main.c:125 ../vector/v.extract/main.c:135
+#: ../vector/v.generalize/main.c:94 ../vector/v.generalize/main.c:233
+#: ../vector/v.generalize/main.c:236 ../vector/v.to.db/parse.c:45
+msgid "Selection"
+msgstr ""
+#: ../locale/scriptstrings/t.vect.univar_to_translate.c:8
+#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:13
+#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:8
+#: ../locale/scriptstrings/t.list_to_translate.c:16
+#: ../locale/scriptstrings/t.rast.list_to_translate.c:14
+#: ../locale/scriptstrings/t.vect.list_to_translate.c:13
+#: ../locale/scriptstrings/t.vect.db.select_to_translate.c:8
+#: ../locale/scriptstrings/t.rast.univar_to_translate.c:7
+msgid "Field separator character between the output columns"
+msgstr ""
+#: ../locale/scriptstrings/t.vect.univar_to_translate.c:9
+#: ../locale/scriptstrings/t.vect.univar_to_translate.c:12
+#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:14
+#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:16
+#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:9
+#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:12
+#: ../locale/scriptstrings/t.list_to_translate.c:11
+#: ../locale/scriptstrings/t.list_to_translate.c:17
+#: ../locale/scriptstrings/t.list_to_translate.c:19
+#: ../locale/scriptstrings/t.rast.list_to_translate.c:8
+#: ../locale/scriptstrings/t.rast.list_to_translate.c:15
+#: ../locale/scriptstrings/t.rast.list_to_translate.c:17
+#: ../locale/scriptstrings/t.vect.list_to_translate.c:8
+#: ../locale/scriptstrings/t.vect.list_to_translate.c:14
+#: ../locale/scriptstrings/t.vect.list_to_translate.c:16
+#: ../locale/scriptstrings/t.rast.univar_to_translate.c:8
+#: ../locale/scriptstrings/t.rast.univar_to_translate.c:12
+#: ../raster/r.stats/main.c:123 ../raster/r.stats/main.c:127
+#: ../raster/r.stats/main.c:151 ../raster/r.stats.quantile/main.c:559
+#: ../raster/r.univar/r.univar_main.c:56 ../raster/r.univar/r.univar_main.c:62
+#: ../raster/r.univar/r.univar_main.c:72 ../raster/r.report/parse.c:69
+#: ../raster/r.report/parse.c:77 ../raster/r.report/parse.c:85
+#: ../raster/r.report/parse.c:109 ../raster/r.report/parse.c:114
+#: ../raster/r.report/parse.c:119 ../raster/r.report/parse.c:124
+#: ../raster/r.kappa/main.c:104 ../raster/r.kappa/main.c:109
+msgid "Formatting"
+msgstr ""
+#: ../locale/scriptstrings/t.vect.univar_to_translate.c:10
+#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:10
+#: ../locale/scriptstrings/t.rast.univar_to_translate.c:9
+#: ../raster/r.univar/r3.univar_main.c:63 ../raster/r.univar/r.univar_main.c:66
+#: ../vector/v.univar/main.c:130
+msgid "Calculate extended statistics"
+msgstr ""
+#: ../locale/scriptstrings/t.vect.univar_to_translate.c:11
+#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:15
+#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:11
+#: ../locale/scriptstrings/t.rast.list_to_translate.c:16
+#: ../locale/scriptstrings/t.vect.list_to_translate.c:15
+#: ../locale/scriptstrings/t.rast.univar_to_translate.c:11
+msgid "Suppress printing of column names"
+msgstr ""
+#: ../locale/scriptstrings/db.droptable_to_translate.c:1
+msgid "Drops an attribute table."
+msgstr ""
+#: ../locale/scriptstrings/db.droptable_to_translate.c:4
+#: ../locale/scriptstrings/db.dropcolumn_to_translate.c:4
+#: ../general/g.remove/main.c:135
+msgid "Force removal (required for actual deletion of files)"
+msgstr ""
+#: ../locale/scriptstrings/db.droptable_to_translate.c:5
+msgid "Name of database driver"
+msgstr ""
+#: ../locale/scriptstrings/db.droptable_to_translate.c:6
+msgid "If not given then default driver is used"
+msgstr ""
+#: ../locale/scriptstrings/db.droptable_to_translate.c:7
+#: ../locale/scriptstrings/db.droptable_to_translate.c:10
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:16
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:26
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:28
+#: ../db/db.databases/main.c:80 ../db/db.databases/main.c:91
+#: ../db/db.execute/main.c:144 ../db/db.execute/main.c:149
+#: ../db/db.execute/main.c:154 ../db/db.select/main.c:219
+#: ../db/db.select/main.c:224
+msgid "Connection"
+msgstr ""
+#: ../locale/scriptstrings/db.droptable_to_translate.c:8
+msgid "Name of database"
+msgstr ""
+#: ../locale/scriptstrings/db.droptable_to_translate.c:9
+msgid "If not given then default database is used"
+msgstr ""
+#: ../locale/scriptstrings/db.droptable_to_translate.c:11
+msgid "Name of table to drop"
+msgstr ""
+#: ../locale/scriptstrings/g.extension_to_translate.c:1
+msgid "Maintains GRASS Addons extensions in local GRASS installation."
+msgstr ""
+#: ../locale/scriptstrings/g.extension_to_translate.c:2
+msgid "Downloads and installs extensions from GRASS Addons repository or other source into the local GRASS installation or removes installed extensions."
+msgstr ""
+#: ../locale/scriptstrings/g.extension_to_translate.c:4
+#: ../locale/scriptstrings/g.extension.all_to_translate.c:4
+msgid "installation"
+msgstr ""
+#: ../locale/scriptstrings/g.extension_to_translate.c:5
+#: ../locale/scriptstrings/g.extension.all_to_translate.c:5
+msgid "extensions"
+msgstr ""
+#: ../locale/scriptstrings/g.extension_to_translate.c:6
+msgid "addons"
+msgstr ""
+#: ../locale/scriptstrings/g.extension_to_translate.c:7
+msgid "download"
+msgstr ""
+#: ../locale/scriptstrings/g.extension_to_translate.c:8
+msgid "Name of extension to install or remove"
+msgstr ""
+#: ../locale/scriptstrings/g.extension_to_translate.c:9
+msgid "Name of toolbox (set of extensions) when -t flag is given"
+msgstr ""
+#: ../locale/scriptstrings/g.extension_to_translate.c:10
+#: ../locale/scriptstrings/g.extension.all_to_translate.c:6
+#: ../general/g.mapsets/main.c:81 ../vector/v.net/args.c:36
+msgid "Operation to be performed"
+msgstr ""
+#: ../locale/scriptstrings/g.extension_to_translate.c:11
+msgid "URL or directory to get the extension from (supported only on Linux and Mac)"
+msgstr ""
+#: ../locale/scriptstrings/g.extension_to_translate.c:12
+msgid "The official repository is used by default. User can specify a ZIP file, directory or a repository on common hosting services. If not identified, Subversion repository is assumed. See manual for all options."
+msgstr ""
+#: ../locale/scriptstrings/g.extension_to_translate.c:13
+msgid "Prefix where to install extension (ignored when flag -s is given)"
+msgstr ""
+#: ../locale/scriptstrings/g.extension_to_translate.c:14
+msgid "Set the proxy with: \"http=<value>,ftp=<value>\""
+msgstr ""
+#: ../locale/scriptstrings/g.extension_to_translate.c:15
+msgid "List available extensions in the official GRASS GIS Addons repository"
+msgstr ""
+#: ../locale/scriptstrings/g.extension_to_translate.c:17
+msgid "List available extensions in the official GRASS GIS Addons repository including module description"
+msgstr ""
+#: ../locale/scriptstrings/g.extension_to_translate.c:19
+msgid "List available extensions in the official GRASS GIS Addons repository (shell script style)"
+msgstr ""
+#: ../locale/scriptstrings/g.extension_to_translate.c:21
+msgid "List locally installed extensions"
+msgstr ""
+#: ../locale/scriptstrings/g.extension_to_translate.c:23
+msgid "Install system-wide (may need system administrator rights)"
+msgstr ""
+#: ../locale/scriptstrings/g.extension_to_translate.c:24
+#: ../locale/scriptstrings/g.extension_to_translate.c:26
+#: ../locale/scriptstrings/g.extension_to_translate.c:28
+msgid "Install"
+msgstr ""
+#: ../locale/scriptstrings/g.extension_to_translate.c:25
+msgid "Download source code and exit"
+msgstr ""
+#: ../locale/scriptstrings/g.extension_to_translate.c:27
+msgid "Do not install new extension, just compile it"
+msgstr ""
+#: ../locale/scriptstrings/g.extension_to_translate.c:29
+msgid "Force removal when uninstalling extension (operation=remove)"
+msgstr ""
+#: ../locale/scriptstrings/g.extension_to_translate.c:30
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:15
+#: ../locale/scriptstrings/r.mask_to_translate.c:20
+#: ../raster/r.colors/edit_colors.c:116 ../raster/r.null/main.c:108
+#: ../vector/v.colors/main.c:122
+msgid "Remove"
+msgstr ""
+#: ../locale/scriptstrings/g.extension_to_translate.c:31
+msgid "Operate on toolboxes instead of single modules (experimental)"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.series_to_translate.c:1
+msgid "Performs different aggregation algorithms from r.series on all or a subset of raster maps in a space time raster dataset."
+msgstr ""
+#: ../locale/scriptstrings/t.rast.series_to_translate.c:3
+#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:3
+#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:3
+#: ../locale/scriptstrings/r.reclass.area_to_translate.c:4
+#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:3
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:8
+#: ../raster/r.neighbors/main.c:170 ../raster/r.series/main.c:138
+#: ../raster/r.in.lidar/main.c:113 ../raster/r.in.xyz/main.c:162
+#: ../raster/r.patch/main.c:63 ../raster3d/r3.neighbors/main.c:212
+#: ../raster3d/r3.in.lidar/main.c:167 ../vector/v.neighbors/main.c:54
+msgid "aggregation"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.series_to_translate.c:4
+#: ../raster/r.series.accumulate/main.c:81 ../raster/r.series/main.c:139
+#: ../raster/r.patch/main.c:64 ../raster/r.series.interp/main.c:65
+msgid "series"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.series_to_translate.c:7
+#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:11
+#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:10
+#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:7
+#: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:8
+msgid "Aggregate operation to be performed on the raster maps"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.series_to_translate.c:8
+#: ../raster/r.neighbors/main.c:239 ../raster/r.series/main.c:168
+#: ../raster/r.resamp.stats/main.c:282 ../raster3d/r3.neighbors/main.c:127
+msgid "Quantile to calculate for method=quantile"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.series_to_translate.c:9
+#: ../locale/scriptstrings/t.rast.what_to_translate.c:8
+msgid "Sort the maps by category"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.series_to_translate.c:10
+msgid "Do not assign the space time raster dataset start and end time to the output map"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.series_to_translate.c:11
+#: ../raster/r.series.accumulate/main.c:159 ../raster/r.series/main.c:187
+#: ../raster/r.resamp.stats/main.c:288 ../raster/r.resamp.filter/main.c:436
+msgid "Propagate NULLs"
+msgstr ""
+#: ../locale/scriptstrings/t.info_to_translate.c:1
+msgid "Lists information about space time datasets and maps."
+msgstr ""
+#: ../locale/scriptstrings/t.info_to_translate.c:4 ../raster/r.info/main.c:74
+#: ../raster3d/r3.info/main.c:78 ../general/g.region/main.c:68
+#: ../vector/v.info/main.c:40
+msgid "extent"
+msgstr ""
+#: ../locale/scriptstrings/t.info_to_translate.c:6
+msgid "Name of an existing space time dataset or map"
+msgstr ""
+#: ../locale/scriptstrings/t.info_to_translate.c:9
+#: ../locale/scriptstrings/i.oif_to_translate.c:6
+#: ../raster/r.regression.multi/main.c:162
+#: ../raster/r.regression.line/main.c:69 ../general/g.region/main.c:148
+#: ../imagery/i.group/main.c:88
+msgid "Print in shell script style"
+msgstr ""
+#: ../locale/scriptstrings/t.info_to_translate.c:10
+msgid "Print history information in human readable shell style for space time datasets"
+msgstr ""
+#: ../locale/scriptstrings/t.info_to_translate.c:11
+msgid "Print information about the temporal DBMI interface and exit"
+msgstr ""
+#: ../locale/scriptstrings/d.polar_to_translate.c:1
+msgid "Draws polar diagram of angle map such as aspect or flow directions"
+msgstr ""
+#: ../locale/scriptstrings/d.polar_to_translate.c:3
+#: ../locale/scriptstrings/d.correlate_to_translate.c:5
+msgid "diagram"
+msgstr ""
+#: ../locale/scriptstrings/d.polar_to_translate.c:4
+msgid "Name of raster angle map"
+msgstr ""
+#: ../locale/scriptstrings/d.polar_to_translate.c:5
+msgid "Pixel value to be interpreted as undefined (different from NULL)"
+msgstr ""
+#: ../locale/scriptstrings/d.polar_to_translate.c:6
+msgid "Name for optional EPS output file"
+msgstr ""
+#: ../locale/scriptstrings/d.polar_to_translate.c:7
+msgid "Plot using Xgraph"
+msgstr ""
+msgid "Aggregates data of an existing space time raster dataset using the time intervals of a second space time dataset."
+msgstr ""
+#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:6
+msgid "Time intervals from this space time dataset (raster, vector or raster3d) are used for aggregation computation"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:7
+msgid "Type of the space time dataset from which aggregation will be copied"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:12
+#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:11
+msgid "Offset that is used to create the output map ids, output map id is generated as: basename_ (count + offset)"
+msgstr ""
+#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:1
+msgid "Performs auto-balancing of colors for RGB images."
+msgstr ""
+#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:3
+#: ../locale/scriptstrings/r.rgb_to_translate.c:3
+msgid "RGB"
+msgstr ""
+#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:4
+#: ../imagery/i.albedo/main.c:98 ../imagery/i.aster.toar/main.c:102
+#: ../imagery/i.landsat.acca/main.c:108 ../imagery/i.modis.qc/main.c:173
+#: ../imagery/i.landsat.toar/main.c:76
+msgid "satellite"
+msgstr ""
+#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:5
+#: ../display/d.colorlist/main.c:37
+msgid "colors"
+msgstr ""
+#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:6
+msgid "Name of red channel"
+msgstr ""
+#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:7
+msgid "Name of green channel"
+msgstr ""
+#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:8
+msgid "Name of blue channel"
+msgstr ""
+#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:9
+msgid "Cropping intensity (upper brightness level)"
+msgstr ""
+#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:10
+msgid "Extend colors to full range of data on each channel"
+msgstr ""
+#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:11
+#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:13
+#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:15
+#: ../display/d.barscale/main.c:153 ../display/d.barscale/main.c:159
+#: ../display/d.rast.num/main.c:89 ../display/d.rast.num/main.c:95
+#: ../display/d.rast.num/main.c:113 ../display/d.northarrow/main.c:104
+#: ../display/d.northarrow/main.c:109 ../display/d.northarrow/main.c:115
+#: ../display/d.vect/main.c:121 ../display/d.vect/main.c:127
+#: ../display/d.vect/main.c:131 ../display/d.vect/main.c:138
+#: ../display/d.vect/main.c:309 ../display/d.rast.arrow/main.c:119
+#: ../display/d.rast.arrow/main.c:125 ../display/d.rast.arrow/main.c:131
+#: ../display/d.rast.arrow/main.c:137 ../vector/v.label.sa/main.c:103
+#: ../vector/v.label.sa/main.c:113 ../vector/v.label.sa/main.c:120
+#: ../vector/v.label.sa/main.c:130 ../vector/v.label.sa/main.c:140
+#: ../vector/v.label.sa/main.c:150 ../vector/v.label.sa/main.c:157
+#: ../vector/v.label/main.c:152 ../vector/v.label/main.c:176
+#: ../vector/v.label/main.c:189 ../vector/v.label/main.c:195
+#: ../vector/v.label/main.c:205
+msgid "Colors"
+msgstr ""
+#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:12
+msgid "Preserve relative colors, adjust brightness only"
+msgstr ""
+#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:14
+msgid "Reset to standard color range"
+msgstr ""
+#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:16
+#: ../locale/scriptstrings/i.oif_to_translate.c:7
+msgid "Process bands serially (default: run in parallel)"
+msgstr ""
+#: ../locale/scriptstrings/r.rgb_to_translate.c:1
+msgid "Splits a raster map into red, green and blue maps."
+msgstr ""
+#: ../locale/scriptstrings/r.rgb_to_translate.c:4
+msgid "separate"
+msgstr ""
+#: ../locale/scriptstrings/r.rgb_to_translate.c:5
+msgid "split"
+msgstr ""
+#: ../locale/scriptstrings/r.rgb_to_translate.c:6
+msgid "Red channel raster map name"
+msgstr ""
+#: ../locale/scriptstrings/r.rgb_to_translate.c:7
+msgid "Green channel raster map name"
+msgstr ""
+#: ../locale/scriptstrings/r.rgb_to_translate.c:8
+msgid "Blue channel raster map name"
+msgstr ""
+#: ../locale/scriptstrings/v.what.vect_to_translate.c:1
+msgid "Uploads vector values at positions of vector points to the table."
+msgstr ""
+#: ../locale/scriptstrings/v.what.vect_to_translate.c:5
+#: ../locale/scriptstrings/v.what.strds_to_translate.c:5
+#: ../raster/r.what/main.c:102 ../display/d.where/main.c:45
+#: ../vector/v.what.rast3/main.c:67 ../vector/v.what.rast/main.c:74
+#: ../vector/v.what/main.c:64
+msgid "position"
+msgstr ""
+#: ../locale/scriptstrings/v.what.vect_to_translate.c:8
+#: ../vector/v.what.rast3/main.c:76 ../vector/v.what.rast/main.c:83
+msgid "Name of vector points map for which to edit attributes"
+msgstr ""
+#: ../locale/scriptstrings/v.what.vect_to_translate.c:9
+#: ../locale/scriptstrings/v.db.join_to_translate.c:6
+msgid "layer,column"
+msgstr ""
+#: ../locale/scriptstrings/v.what.vect_to_translate.c:10
+#: ../locale/scriptstrings/v.db.join_to_translate.c:8
+msgid "column"
+msgstr ""
+#: ../locale/scriptstrings/v.what.vect_to_translate.c:11
+#: ../vector/v.what.rast3/main.c:87 ../vector/v.what.rast/main.c:98
+msgid "Name of attribute column to be updated with the query result"
+msgstr ""
+#: ../locale/scriptstrings/v.what.vect_to_translate.c:12
+msgid "Name of vector map to be queried"
+msgstr ""
+#: ../locale/scriptstrings/v.what.vect_to_translate.c:13
+msgid "query_layer,query_column"
+msgstr ""
+#: ../locale/scriptstrings/v.what.vect_to_translate.c:14
+msgid "query_column"
+msgstr ""
+#: ../locale/scriptstrings/v.what.vect_to_translate.c:15
+msgid "Name of attribute column to be queried"
+msgstr ""
+#: ../locale/scriptstrings/v.what.vect_to_translate.c:16
+msgid "Maximum query distance in map units"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.contour_to_translate.c:1
+msgid "Produces a space time vector dataset of specified contours from a space time raster dataset."
+msgstr ""
+#: ../locale/scriptstrings/t.rast.contour_to_translate.c:3
+msgid "contour"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.contour_to_translate.c:10
+#: ../raster/r.contour/main.c:101
+msgid "Increment between contour levels"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.contour_to_translate.c:11
+#: ../raster/r.contour/main.c:109
+msgid "List of contour levels"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.contour_to_translate.c:12
+#: ../raster/r.contour/main.c:116
+msgid "Minimum contour level"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.contour_to_translate.c:13
+#: ../raster/r.contour/main.c:123
+msgid "Maximum contour level"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.contour_to_translate.c:14
+#: ../raster/r.contour/main.c:132
+msgid "Minimum number of points for a contour line (0 -> no limit)"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.contour_to_translate.c:15
+msgid "Number of r.contour processes to run in parallel, more than 1 process works only in conjunction with flag -t"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.contour_to_translate.c:16
+#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:13
+msgid "Register empty vector maps"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.contour_to_translate.c:17
+#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:14
+msgid "Do not create attribute tables"
+msgstr ""
+msgid "Lists registered maps of a space time raster3d dataset."
+msgstr ""
+#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:3
+#: ../locale/scriptstrings/t.list_to_translate.c:3
+#: ../locale/scriptstrings/t.rast.list_to_translate.c:3
+#: ../locale/scriptstrings/t.vect.list_to_translate.c:3
+#: ../locale/scriptstrings/t.rename_to_translate.c:3
+#: ../locale/scriptstrings/t.create_to_translate.c:3
+#: ../locale/scriptstrings/t.register_to_translate.c:3
+#: ../locale/scriptstrings/t.unregister_to_translate.c:3
+#: ../locale/scriptstrings/t.remove_to_translate.c:3
+#: ../raster/r.compress/main.c:69 ../general/g.findfile/main.c:39
+#: ../general/g.list/main.c:66 ../general/g.findetc/main.c:29
+#: ../general/g.rename/main.c:46 ../general/g.copy/main.c:42
+#: ../general/g.dirseps/main.c:35 ../general/g.access/main.c:38
+#: ../general/g.filename/main.c:40 ../general/g.remove/main.c:70
+#: ../imagery/i.target/main.c:46 ../imagery/i.group/main.c:53
+msgid "map management"
+msgstr ""
+#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:4
+#: ../locale/scriptstrings/t.list_to_translate.c:4
+#: ../locale/scriptstrings/t.rast.list_to_translate.c:5
+#: ../locale/scriptstrings/t.vect.list_to_translate.c:5
+#: ../general/g.list/main.c:67
+msgid "list"
+msgstr ""
+#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:5
+#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:4
+#: ../locale/scriptstrings/t.rast.to.rast3_to_translate.c:5
+#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:4
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:2
+#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:4
+#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:4
+#: ../raster/r.colors/edit_colors.c:59 ../raster/r.univar/r3.univar_main.c:98
+#: ../raster/r.to.rast3elev/main.c:363
+#: ../raster/r.colors.out/raster3d_main.c:46 ../raster3d/r3.support/main.c:49
+#: ../raster3d/r3.gwflow/main.c:159 ../raster3d/r3.out.netcdf/main.c:586
+#: ../raster3d/r3.retile/main.c:96 ../raster3d/r3.neighbors/main.c:208
+#: ../raster3d/r3.out.vtk/main.c:376 ../raster3d/r3.mkdspf/main.c:79
+#: ../raster3d/r3.mask/main.c:133 ../raster3d/r3.in.v5d/main.c:178
+#: ../raster3d/r3.out.bin/main.c:205 ../raster3d/r3.flow/main.c:179
+#: ../raster3d/r3.flow/test_main.c:43 ../raster3d/r3.cross.rast/main.c:228
+#: ../raster3d/r3.out.v5d/main.c:284 ../raster3d/r3.timestamp/main.c:43
+#: ../raster3d/r3.in.bin/main.c:252 ../raster3d/r3.info/main.c:75
+#: ../raster3d/r3.to.rast/main.c:259 ../raster3d/r3.stats/main.c:48
+#: ../raster3d/r3.gradient/main.c:43 ../raster3d/r3.out.ascii/main.c:302
+#: ../raster3d/r3.in.lidar/main.c:162 ../raster3d/r3.null/main.c:180
+#: ../raster3d/r3.in.ascii/main.c:354 ../misc/m.nviz.image/main.c:55
+#: ../misc/m.nviz.script/main.c:72
+msgid "raster3d"
+msgstr ""
+#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:6
+#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:5
+#: ../locale/scriptstrings/t.rast.to.rast3_to_translate.c:6
+#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:5
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:4
+#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:5
+#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:5
+#: ../raster/r.to.rast3/main.c:199 ../raster/r.to.rast3elev/main.c:364
+#: ../raster3d/r3.support/main.c:51 ../raster3d/r3.gwflow/main.c:161
+#: ../raster3d/r3.out.netcdf/main.c:589 ../raster3d/r3.retile/main.c:98
+#: ../raster3d/r3.neighbors/main.c:210 ../raster3d/r3.out.vtk/main.c:378
+#: ../raster3d/r3.mkdspf/main.c:81 ../raster3d/r3.mask/main.c:135
+#: ../raster3d/r3.in.v5d/main.c:180 ../raster3d/r3.out.bin/main.c:207
+#: ../raster3d/r3.flow/main.c:181 ../raster3d/r3.cross.rast/main.c:231
+#: ../raster3d/r3.out.v5d/main.c:286 ../raster3d/r3.timestamp/main.c:47
+#: ../raster3d/r3.in.bin/main.c:254 ../raster3d/r3.info/main.c:77
+#: ../raster3d/r3.to.rast/main.c:262 ../raster3d/r3.stats/main.c:50
+#: ../raster3d/r3.gradient/main.c:45 ../raster3d/r3.out.ascii/main.c:304
+#: ../raster3d/r3.null/main.c:182 ../raster3d/r3.in.ascii/main.c:356
+#: ../vector/v.to.rast3/main.c:50 ../vector/v.vol.rst/main.c:236
+msgid "voxel"
+msgstr ""
+#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:8
+msgid "Order the space time dataset by category"
+msgstr ""
+#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:9
+#: ../locale/scriptstrings/t.list_to_translate.c:13
+#: ../locale/scriptstrings/t.rast.list_to_translate.c:9
+#: ../locale/scriptstrings/t.vect.list_to_translate.c:9
+msgid "Columns to be printed to stdout"
+msgstr ""
+#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:12
+#: ../locale/scriptstrings/t.rast.list_to_translate.c:12
+#: ../locale/scriptstrings/t.vect.list_to_translate.c:12
+msgid "Method used for data listing"
+msgstr ""
+#: ../locale/scriptstrings/t.vect.export_to_translate.c:1
+msgid "Exports a space time vector dataset as GRASS GIS specific archive file."
+msgstr ""
+#: ../locale/scriptstrings/t.vect.export_to_translate.c:6
+msgid "Name of a space time vector dataset archive"
+msgstr ""
+#: ../locale/scriptstrings/t.vect.export_to_translate.c:7
+#: ../locale/scriptstrings/t.rast.export_to_translate.c:7
+msgid "Path to the work directory, default is /tmp"
+msgstr ""
+#: ../locale/scriptstrings/t.vect.export_to_translate.c:8
+#: ../locale/scriptstrings/t.rast.export_to_translate.c:8
+msgid "Compression method of the tar archive"
+msgstr ""
+#: ../locale/scriptstrings/t.vect.export_to_translate.c:9
+msgid "The export format of a single vector map"
+msgstr ""
+#: ../locale/scriptstrings/t.vect.export_to_translate.c:10
+msgid "Supported are GML via v.out.ogr and the GRASS package format of v.pack"
+msgstr ""
+msgid "Calculates univariate statistics from the non-null cells for each registered 3D raster map of a space time 3D raster dataset."
+msgstr ""
+#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:1
+msgid "Imports SPOT VGT NDVI data into a raster map."
+msgstr ""
+#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:3
+#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:3
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:3
+#: ../locale/scriptstrings/v.import_to_translate.c:3
+#: ../locale/scriptstrings/v.in.lines_to_translate.c:3
+#: ../locale/scriptstrings/v.unpack_to_translate.c:3
+#: ../locale/scriptstrings/r.unpack_to_translate.c:3
+#: ../locale/scriptstrings/db.in.ogr_to_translate.c:3
+#: ../locale/scriptstrings/t.rast.import_to_translate.c:3
+#: ../locale/scriptstrings/t.vect.import_to_translate.c:3
+#: ../locale/scriptstrings/r.import_to_translate.c:3
+#: ../locale/scriptstrings/v.in.e00_to_translate.c:3
+#: ../locale/scriptstrings/v.in.wfs_to_translate.c:3
+#: ../locale/scriptstrings/v.in.geonames_to_translate.c:3
+#: ../locale/scriptstrings/r.in.aster_to_translate.c:3
+#: ../locale/scriptstrings/r.in.srtm_to_translate.c:3
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:3
+#: ../raster/r.in.poly/main.c:35 ../raster/r.in.ascii/main.c:70
+#: ../raster/r.in.gridatb/main.c:46 ../raster/r.in.png/main.c:520
+#: ../raster/r.in.lidar/main.c:109 ../raster/r.in.xyz/main.c:159
+#: ../raster/r.in.bin/main.c:258 ../raster/r.in.mat/main.c:92
+#: ../raster/r.proj/main.c:147 ../raster/r.in.gdal/main.c:94
+#: ../raster/r.external/main.c:58 ../raster3d/r3.in.v5d/main.c:179
+#: ../raster3d/r3.in.bin/main.c:253 ../raster3d/r3.in.lidar/main.c:163
+#: ../raster3d/r3.in.ascii/main.c:355 ../vector/v.proj/main.c:71
+#: ../vector/v.in.lidar/main.c:137 ../vector/v.in.dwg/main.c:83
+#: ../vector/v.in.ogr/main.c:196 ../vector/v.in.db/main.c:53
+#: ../vector/v.in.ascii/main.c:71 ../vector/v.in.dxf/main.c:65
+#: ../vector/v.external/main.c:53
+msgid "import"
+msgstr ""
+#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:4
+msgid "NDVI"
+msgstr ""
+#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:5
+msgid "SPOT"
+msgstr ""
+#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:6
+msgid "Also import quality map (SM status map layer) and filter NDVI map"
+msgstr ""
+#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:7
+msgid "Name of input SPOT VGT NDVI HDF file"
+msgstr ""
+#: ../locale/scriptstrings/t.vect.algebra_to_translate.c:1
+msgid "Apply temporal and spatial operations on space time vector datasets using temporal vector algebra."
+msgstr ""
+#: ../locale/scriptstrings/t.vect.algebra_to_translate.c:3
+#: ../locale/scriptstrings/t.rast.algebra_to_translate.c:3
+#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:3
+#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:3
+#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:3
+#: ../raster/r.mfilter/main.c:57 ../raster/r.texture/main.c:103
+#: ../raster/r.mode/main.c:57 ../raster/r.neighbors/main.c:168
+#: ../raster/r.mapcalc/main.c:71 ../raster/r.quantile/main.c:266
+#: ../raster3d/r3.neighbors/main.c:209 ../vector/v.neighbors/main.c:51
+msgid "algebra"
+msgstr ""
+#: ../locale/scriptstrings/t.vect.algebra_to_translate.c:6
+#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:6
+msgid "Spatio-temporal mapcalc expression"
+msgstr ""
+#: ../locale/scriptstrings/t.vect.algebra_to_translate.c:9
+#: ../locale/scriptstrings/t.rast.algebra_to_translate.c:10
+#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:11
+#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:12
+#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:11
+msgid "Check the spatial topology of temporally related maps and process only spatially related maps"
+msgstr ""
+msgid "Lists space time datasets and maps registered in the temporal database."
+msgstr ""
+#: ../locale/scriptstrings/t.list_to_translate.c:6
+msgid "Type of the space time dataset or map, default is strds"
+msgstr ""
+#: ../locale/scriptstrings/t.list_to_translate.c:9
+#: ../locale/scriptstrings/t.list_to_translate.c:12
+msgid "Columns number_of_maps and granularity only available for space time datasets"
+msgstr ""
+#: ../locale/scriptstrings/t.list_to_translate.c:10
+#: ../locale/scriptstrings/t.rast.list_to_translate.c:7
+#: ../locale/scriptstrings/t.vect.list_to_translate.c:7
+msgid "Sort the space time dataset by category"
+msgstr ""
+#: ../locale/scriptstrings/t.list_to_translate.c:18
+#: ../locale/scriptstrings/t.sample_to_translate.c:11
+msgid "Print the column names as first row"
+msgstr ""
+msgid "Converts a space time raster dataset into a space time vector dataset"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:3
+#: ../locale/scriptstrings/r.out.xyz_to_translate.c:5
+#: ../locale/scriptstrings/t.rast.to.rast3_to_translate.c:3
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:7
+#: ../raster/r.to.rast3/main.c:198 ../raster/r.to.rast3elev/main.c:362
+#: ../raster/r.in.ascii/main.c:71 ../raster/r.in.lidar/main.c:112
+#: ../raster/r.in.xyz/main.c:161 ../raster/r.to.vect/main.c:77
+#: ../raster3d/r3.to.rast/main.c:260 ../raster3d/r3.out.ascii/main.c:305
+#: ../raster3d/r3.in.lidar/main.c:166 ../raster3d/r3.in.ascii/main.c:357
+#: ../vector/v.to.rast/main.c:45 ../vector/v.to.rast3/main.c:49
+msgid "conversion"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:7
+#: ../raster/r.to.vect/main.c:87 ../vector/v.mkgrid/main.c:136
+msgid "Output feature type"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:11
+#: ../raster/r.to.vect/main.c:94
+msgid "Name of attribute column to store value"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:12
+msgid "Number of r.to.vect processes to run in parallel, more than 1 process works only in conjunction with flag -t"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:15
+#: ../raster/r.to.vect/main.c:100
+msgid "Smooth corners of area features"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:16
+#: ../raster/r.to.vect/main.c:110
+msgid "Write raster values as z coordinate"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:17
+#: ../raster/r.to.vect/main.c:111
+msgid "Table is not created. Currently supported only for points."
+msgstr ""
+#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:18
+#: ../raster/r.to.vect/main.c:117 ../vector/v.proj/main.c:130
+msgid "Do not build vector topology"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:19
+#: ../raster/r.to.vect/main.c:95
+msgid "Name must be SQL compliant"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:20
+#: ../raster/r.to.vect/main.c:105
+msgid "Use raster values as categories instead of unique sequence (CELL only)"
+msgstr ""
+#: ../locale/scriptstrings/v.what.strds_to_translate.c:1
+msgid "Uploads space time raster dataset values at positions of vector points to the table."
+msgstr ""
+#: ../locale/scriptstrings/v.what.strds_to_translate.c:9
+msgid "Update attribute table of input vector map"
+msgstr ""
+#: ../locale/scriptstrings/v.what.strds_to_translate.c:10
+msgid "Instead of creating a new vector map update the attribute table with value(s)"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:1
+msgid "Replaces gaps in a space time raster dataset with interpolated raster maps."
+msgstr ""
+#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:3
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:4
+#: ../raster/r.resamp.interp/main.c:78 ../raster/r.surf.idw/main.c:106
+#: ../raster/r.surf.contour/main.c:62 ../raster/r.fill.stats/main.c:777
+#: ../raster/r.series.interp/main.c:66 ../raster/r.resamp.bspline/main.c:82
+#: ../vector/v.surf.idw/main.c:89 ../vector/v.surf.rst/main.c:149
+#: ../vector/v.surf.bspline/main.c:93 ../vector/v.vol.rst/main.c:238
+msgid "interpolation"
+msgstr "interpoláció"
+#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:9
+msgid "Number of interpolation processes to run in parallel"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:10
+msgid "Assign the space time raster dataset start and end time to the output map"
+msgstr ""
+#: ../locale/scriptstrings/r.out.xyz_to_translate.c:1
+msgid "Exports a raster map to a text file as x,y,z values based on cell centers."
+msgstr ""
+#: ../locale/scriptstrings/r.out.xyz_to_translate.c:4
+msgid "ASCII"
+msgstr ""
+#: ../locale/scriptstrings/r.out.xyz_to_translate.c:6
+#: ../locale/scriptstrings/i.oif_to_translate.c:5 ../raster/r.stats/main.c:119
+#: ../raster/r.stats.quantile/main.c:555 ../raster/r.univar/r3.univar_main.c:42
+#: ../raster/r.univar/r.univar_main.c:41 ../raster/r.quantile/main.c:299
+#: ../raster/r.what/main.c:127 ../db/db.select/main.c:241
+#: ../vector/v.db.select/main.c:95
+msgid "Name for output file (if omitted or \"-\" output to stdout)"
+msgstr ""
+#: ../locale/scriptstrings/r.out.xyz_to_translate.c:7
+msgid "Include no data values"
+msgstr ""
+#: ../locale/scriptstrings/db.test_to_translate.c:1
+msgid "Test database driver, database must exist and set by db.connect."
+msgstr ""
+#: ../locale/scriptstrings/db.test_to_translate.c:4
+msgid "Test name"
+msgstr ""
+msgid "Lists registered maps of a space time raster dataset."
+msgstr ""
+#: ../locale/scriptstrings/t.rast.list_to_translate.c:13
+msgid "The granule to be used for listing. The granule must be specified as string eg.: absolute time \"1 months\" or relative time \"1\""
+msgstr ""
+#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:1
+msgid "Computes cyclic accumulations of a space time raster dataset."
+msgstr ""
+#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:3
+#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:3
+#: ../raster/r.series.accumulate/main.c:82
+#: ../raster/r.watershed/front/main.c:76
+msgid "accumulation"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:6
+msgid "Input space time raster dataset that defines the lower threshold, values lower than this threshold are excluded from accumulation"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:7
+msgid "Input space time raster dataset that defines the upper threshold, values higher than this threshold are excluded from accumulation"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:8
+#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:10
+msgid "The temporal starting point to begin the accumulation, eg '2001-01-01'"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:9
+#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:11
+msgid "The temporal date to stop the accumulation, eg '2009-01-01'"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:10
+#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:12
+msgid "The temporal cycle to restart the accumulation, eg '12 months'"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:11
+msgid "The temporal offset to the beginning of the next cycle, eg '6 months'"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:12
+msgid "The granularity for accumulation '1 day'"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:15
+msgid "Suffix to add to the basename. Set 'gran' for granularity, 'time' for the full time format, 'num' for numerical suffix with a specific number of digits (default %05)"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:16
+msgid "Use these limits in case lower and/or upper input space time raster datasets are not defined or contain NULL values"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:17
+msgid "Scale factor for input space time raster dataset"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:18
+msgid "Shift factor for input space time raster dataset"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:19
+msgid "This method will be applied to compute the accumulative values from the input maps in a single granule"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:20
+msgid "Growing Degree Days or Winkler indices; Mean: sum(input maps)/(number of input maps); Biologically Effective Degree Days; Huglin Heliothermal index"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:21
+#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:19
+msgid "Register empty maps in the output space time raster dataset, otherwise they will be deleted"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:22
+#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:20
+msgid "Reverse time direction in cyclic accumulation"
+msgstr ""
+#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:1
+msgid "Imports Mapgen or Matlab-ASCII vector maps into GRASS."
+msgstr ""
+#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:4
+msgid "Input map is in Matlab format"
+msgstr ""
+#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:5
+msgid "Create a 3D vector points map from 3 column Matlab data"
+msgstr ""
+#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:6
+msgid "Name of input file in Mapgen/Matlab format"
+msgstr ""
+#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:7
+msgid "Name for output vector map (omit for display to stdout)"
+msgstr ""
+#: ../locale/scriptstrings/d.what.vect_to_translate.c:1
+msgid "Allows the user to interactively query vector map layers at user-selected locations."
+msgstr ""
+#: ../locale/scriptstrings/r.shade_to_translate.c:10
+msgid "Name of shaded raster map"
+msgstr ""
+#: ../locale/scriptstrings/r.shade_to_translate.c:12 ../raster/r.his/main.c:121
+msgid "Color to use instead of NULL values"
+msgstr ""
+#: ../locale/scriptstrings/r.shade_to_translate.c:13
+msgid "Either a standard color name, R:G:B triplet, or \"none\""
+msgstr ""
+#: ../locale/scriptstrings/r.shade_to_translate.c:14 ../raster/r.his/main.c:126
+msgid "Use colors from color tables for NULL values"
+msgstr ""
+#: ../locale/scriptstrings/t.vect.extract_to_translate.c:1
+msgid "Extracts a subset of a space time vector dataset."
+msgstr ""
+#: ../locale/scriptstrings/t.vect.extract_to_translate.c:9
+msgid "The number of v.extract processes to run in parallel. Use only if database backend is used which supports concurrent writing"
+msgstr ""
+#: ../locale/scriptstrings/t.vect.extract_to_translate.c:10
+msgid "Register empty maps"
+msgstr ""
+msgid "Downloads and imports data from WMS/WMTS/NASA OnEarth server."
+msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:4
+#: ../locale/scriptstrings/v.in.wfs_to_translate.c:4
+msgid "OGC web services"
+msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:5
+msgid "Typically starts with \"http://\""
+msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:6
+#: ../locale/scriptstrings/r.drain_to_translate.c:9
+#: ../locale/scriptstrings/r.import_to_translate.c:11
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:14
+#: ../imagery/i.ifft/main.c:93 ../vector/v.kernel/main.c:133
+msgid "Name for output raster map"
+msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:7
+msgid "Layer(s) to request from the map server"
+msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:8
+msgid "Layer style(s) to request from the map server"
+msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:9
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:34
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:40
+msgid "Map style"
+msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:10
+msgid "Image format requested from the server"
+msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:11
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:13
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:18
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:20
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:22
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:24
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:31
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:38
+msgid "Request"
+msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:12
+msgid "EPSG code of requested source projection"
+msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:14
+msgid "Driver used to communication with server"
+msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:15
+msgid "WMS_GDAL;Download data using GDAL WMS driver;WMS_GRASS;Download data using native GRASS-WMS driver;WMTS_GRASS;Download data using native GRASS-WMTS driver;OnEarth_GRASS;Download data using native GRASS-OnEarth driver;"
+msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:17
+msgid "WMS standard version"
+msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:19
+msgid "Maximum columns to request at a time"
+msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:21
+msgid "Maximum rows to request at a time"
+msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:23
+msgid "Additional query parameters to pass to the server"
+msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:25
+msgid "Username for server connection"
+msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:27
+msgid "Password for server connection"
+msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:29
+msgid "Interpolation method to use in reprojection"
+msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:30
+msgid "Request data for this named region instead of the current region bounds"
+msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:32
+#: ../display/d.mon/main.c:102 ../display/d.grid/main.c:113
+#: ../display/d.legend.vect/main.c:101 ../display/d.legend/main.c:246
+#: ../display/d.path/main.c:115 ../display/d.erase/main.c:37
+#: ../display/d.histogram/main.c:108 ../general/g.pnmcomp/main.c:325
+#: ../misc/m.nviz.image/args.c:70 ../vector/v.label.sa/main.c:124
+#: ../vector/v.label/main.c:187 ../vector/v.lrs/v.lrs.label/main.c:218
+msgid "Background color"
+msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:33
+msgid "Format: 0xRRGGBB"
+msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:35
+msgid "Capabilities file to parse (input). It is relevant for WMTS_GRASS and OnEarth_GRASS drivers"
+msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:36
+msgid "File where the server capabilities will be saved ('c' flag)"
+msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:37
+msgid "Get the server capabilities then exit"
+msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:39
+msgid "Do not request transparent data"
+msgstr ""
+msgid "Lists registered maps of a space time vector dataset."
+msgstr ""
+#: ../locale/scriptstrings/t.vect.db.select_to_translate.c:1
+msgid "Prints attributes of vector maps registered in a space time vector dataset."
+msgstr ""
+#: ../locale/scriptstrings/t.vect.db.select_to_translate.c:6
+#: ../vector/v.decimate/main.c:128 ../vector/v.outlier/main.c:72
+#: ../vector/v.extract/main.c:79
+msgid "select"
+msgstr ""
+#: ../locale/scriptstrings/g.extension.all_to_translate.c:1
+msgid "Rebuilds or removes all locally installed GRASS Addons extensions."
+msgstr ""
+#: ../locale/scriptstrings/g.extension.all_to_translate.c:2
+msgid "By default only extensions built against different GIS Library are rebuilt."
+msgstr ""
+#: ../locale/scriptstrings/g.extension.all_to_translate.c:7
+msgid "Force operation (required for removal)"
+msgstr ""
+#: ../locale/scriptstrings/r.tileset_to_translate.c:1
+msgid "Produces tilings of the source projection for use in the destination region and projection."
+msgstr ""
+#: ../locale/scriptstrings/r.tileset_to_translate.c:3
+#: ../raster/r.tile/main.c:44 ../raster3d/r3.retile/main.c:97
+msgid "tiling"
+msgstr ""
+#: ../locale/scriptstrings/r.tileset_to_translate.c:4
+msgid "Produces shell script output"
+msgstr ""
+#: ../locale/scriptstrings/r.tileset_to_translate.c:5
+msgid "Produces web map server query string output"
+msgstr ""
+#: ../locale/scriptstrings/r.tileset_to_translate.c:6
+msgid "Name of region to use instead of current region for bounds and resolution"
+msgstr ""
+#: ../locale/scriptstrings/r.tileset_to_translate.c:7
+msgid "Source projection"
+msgstr ""
+#: ../locale/scriptstrings/r.tileset_to_translate.c:8
+#: ../locale/scriptstrings/r.tileset_to_translate.c:10
+msgid "Conversion factor from units to meters in source projection"
+msgstr ""
+#: ../locale/scriptstrings/r.tileset_to_translate.c:9
+msgid "Destination projection, defaults to this location's projection"
+msgstr ""
+#: ../locale/scriptstrings/r.tileset_to_translate.c:11
+msgid "Maximum number of columns for a tile in the source projection"
+msgstr ""
+#: ../locale/scriptstrings/r.tileset_to_translate.c:12
+msgid "Maximum number of rows for a tile in the source projection"
+msgstr ""
+#: ../locale/scriptstrings/r.tileset_to_translate.c:13
+msgid "Number of cells tiles should overlap in each direction"
+msgstr ""
+#: ../locale/scriptstrings/r.tileset_to_translate.c:14
+msgid "Output field separator"
+msgstr ""
+#: ../locale/scriptstrings/v.build.all_to_translate.c:1
+msgid "Rebuilds topology on all vector maps in the current mapset."
+msgstr ""
+#: ../locale/scriptstrings/v.build.all_to_translate.c:3
+#: ../locale/scriptstrings/t.topology_to_translate.c:3
+#: ../vector/v.clean/main.c:52 ../vector/v.build.polylines/main.c:111
+#: ../vector/v.in.ogr/main.c:198 ../vector/v.build/main.c:37
+#: ../vector/v.info/main.c:39 ../vector/v.out.postgis/main.c:48
+#: ../vector/v.generalize/main.c:82
+msgid "topology"
+msgstr ""
+#: ../locale/scriptstrings/t.snap_to_translate.c:1
+msgid "Snaps temporally the maps of a space time dataset."
+msgstr ""
+#: ../locale/scriptstrings/t.snap_to_translate.c:3
+#: ../locale/scriptstrings/t.merge_to_translate.c:3
+#: ../locale/scriptstrings/t.shift_to_translate.c:3
+msgid "time management"
+msgstr ""
+#: ../locale/scriptstrings/t.snap_to_translate.c:4 ../vector/v.clean/main.c:54
+#: ../vector/v.in.ogr/main.c:200
+msgid "snapping"
+msgstr ""
+#: ../locale/scriptstrings/t.snap_to_translate.c:6
+#: ../locale/scriptstrings/t.shift_to_translate.c:6
+msgid "Name of an existing space time dataset"
+msgstr ""
+#: ../locale/scriptstrings/v.import_to_translate.c:1
+msgid "Imports vector data into a GRASS vector map using OGR library and reprojects on the fly."
+msgstr ""
+#: ../locale/scriptstrings/v.import_to_translate.c:4
+#: ../locale/scriptstrings/r.import_to_translate.c:4
+#: ../locale/scriptstrings/m.proj_to_translate.c:3 ../raster/r.proj/main.c:145
+#: ../raster/r.latlong/main.c:59 ../general/g.proj/main.c:65
+#: ../general/g.setproj/main.c:79 ../vector/v.proj/main.c:69
+msgid "projection"
+msgstr ""
+#: ../locale/scriptstrings/v.import_to_translate.c:5
+#: ../vector/v.in.ogr/main.c:208
+msgid "Name of OGR datasource to be imported"
+msgstr ""
+#: ../locale/scriptstrings/v.import_to_translate.c:6
+#: ../locale/scriptstrings/v.import_to_translate.c:8
+#: ../locale/scriptstrings/i.spectral_to_translate.c:6
+#: ../locale/scriptstrings/i.spectral_to_translate.c:7
+#: ../locale/scriptstrings/i.spectral_to_translate.c:8
+#: ../locale/scriptstrings/r.import_to_translate.c:6
+#: ../locale/scriptstrings/r.import_to_translate.c:8
+#: ../locale/scriptstrings/t.register_to_translate.c:6
+#: ../locale/scriptstrings/t.register_to_translate.c:7
+#: ../locale/scriptstrings/t.register_to_translate.c:9
+#: ../locale/scriptstrings/t.register_to_translate.c:12
+#: ../locale/scriptstrings/t.register_to_translate.c:26
+#: ../locale/scriptstrings/t.remove_to_translate.c:6
+#: ../locale/scriptstrings/t.remove_to_translate.c:9
+#: ../locale/scriptstrings/t.remove_to_translate.c:11
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:18
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:20
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:22
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:24
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:27
+#: ../raster/r.sun/main.c:272 ../raster/r.sun/main.c:281
+#: ../raster/r.sun/main.c:290 ../raster/r.sun/main.c:299
+#: ../raster/r.sun/main.c:307 ../raster/r.sun/main.c:316
+#: ../raster/r.sun/main.c:325 ../raster/r.sun/main.c:334
+#: ../raster/r.sun/main.c:343 ../raster/r.sun/main.c:352
+#: ../raster/r.sun/main.c:361 ../raster/r.sun/main.c:370
+#: ../raster/r.sun/main.c:379 ../raster/r.sun/main.c:386
+#: ../raster/r.sun/main.c:394 ../raster/r.horizon/main.c:195
+#: ../raster/r.horizon/main.c:204 ../raster/r.horizon/main.c:212
+#: ../raster/r.spread/main.c:125 ../raster/r.spread/main.c:139
+#: ../raster/r.spread/main.c:151 ../raster/r.spread/main.c:164
+#: ../raster/r.spread/main.c:177 ../raster/r.spread/main.c:189
+#: ../raster/r.spread/main.c:201 ../raster/r.in.lidar/main.c:122
+#: ../raster/r.in.lidar/main.c:133 ../raster/r.in.xyz/main.c:213
+#: ../raster/r.in.xyz/main.c:222 ../raster/r.in.xyz/main.c:230
+#: ../raster/r.in.xyz/main.c:241 ../raster/r.in.xyz/main.c:251
+#: ../raster/r.external/main.c:66 ../raster/r.external/main.c:74
+#: ../raster/r.external/main.c:83 ../raster/r.sim/r.sim.sediment/main.c:158
+#: ../raster/r.sim/r.sim.sediment/main.c:166
+#: ../raster/r.sim/r.sim.sediment/main.c:173
+#: ../raster/r.sim/r.sim.water/main.c:138
+#: ../raster/r.sim/r.sim.water/main.c:147
+#: ../raster/r.sim/r.sim.water/main.c:154
+#: ../raster/r.sim/r.sim.water/main.c:163
+#: ../raster/r.sim/r.sim.water/main.c:169
+#: ../raster/r.sim/r.sim.water/main.c:177
+#: ../raster/r.sim/r.sim.water/main.c:184
+#: ../raster/r.sim/r.sim.water/main.c:191 ../display/d.legend/main.c:88
+#: ../display/d.legend/main.c:93 ../display/d.text/main.c:149
+#: ../display/d.text/main.c:154 ../raster3d/r3.flow/main.c:188
+#: ../raster3d/r3.flow/main.c:195 ../raster3d/r3.flow/main.c:205
+#: ../raster3d/r3.in.lidar/main.c:177 ../raster3d/r3.in.lidar/main.c:184
+#: ../vector/v.in.ogr/main.c:224 ../vector/v.edit/args.c:96
+#: ../vector/v.edit/args.c:215
+msgid "Input"
+msgstr ""
+#: ../locale/scriptstrings/v.import_to_translate.c:7
+#: ../vector/v.in.ogr/main.c:220
+msgid "OGR layer name. If not given, all available layers are imported"
+msgstr ""
+#: ../locale/scriptstrings/v.import_to_translate.c:9
+#: ../vector/v.proj/main.c:106
+msgid "Name for output vector map (default: input)"
+msgstr ""
+#: ../locale/scriptstrings/v.import_to_translate.c:11
+msgid "Output vector map extent"
+msgstr ""
+#: ../locale/scriptstrings/v.import_to_translate.c:12
+msgid "input;extent of input map;region;extent of current region"
+msgstr ""
+#: ../locale/scriptstrings/v.import_to_translate.c:14
+#: ../locale/scriptstrings/db.in.ogr_to_translate.c:11
+#: ../vector/v.in.ogr/main.c:297
+msgid "Encoding value for attribute data"
+msgstr ""
+#: ../locale/scriptstrings/v.import_to_translate.c:15
+#: ../vector/v.in.ogr/main.c:299
+msgid "Overrides encoding interpretation, useful when importing ESRI Shapefile"
+msgstr ""
+#: ../locale/scriptstrings/v.import_to_translate.c:17
+#: ../vector/v.in.ogr/main.c:275
+msgid "Snapping threshold for boundaries (map units)"
+msgstr ""
+#: ../locale/scriptstrings/v.import_to_translate.c:18
+msgid "A suitable threshold is estimated during import"
+msgstr ""
+#: ../locale/scriptstrings/v.import_to_translate.c:20
+#: ../locale/scriptstrings/v.import_to_translate.c:22
+msgid "Input SRS"
+msgstr ""
+#: ../locale/scriptstrings/v.import_to_translate.c:21
+#: ../general/g.proj/main.c:159
+msgid "EPSG projection code"
+msgstr ""
+#: ../locale/scriptstrings/v.import_to_translate.c:23
+#: ../general/g.proj/main.c:181
+msgid "Index number of datum transform parameters"
+msgstr ""
+#: ../locale/scriptstrings/v.import_to_translate.c:24
+msgid "-1 to list available datum transform parameters"
+msgstr ""
+#: ../locale/scriptstrings/v.import_to_translate.c:25
+#: ../vector/v.in.ogr/main.c:320
+msgid "List supported OGR formats and exit"
+msgstr ""
+#: ../locale/scriptstrings/v.import_to_translate.c:26
+#: ../vector/v.in.ogr/main.c:326
+msgid "List available OGR layers in data source and exit"
+msgstr ""
+#: ../locale/scriptstrings/v.import_to_translate.c:27
+#: ../locale/scriptstrings/v.unpack_to_translate.c:9
+#: ../locale/scriptstrings/r.unpack_to_translate.c:8
+#: ../locale/scriptstrings/t.rast.import_to_translate.c:18
+#: ../locale/scriptstrings/t.vect.import_to_translate.c:14
+#: ../locale/scriptstrings/r.import_to_translate.c:31
+#: ../raster/r.in.lidar/main.c:300 ../raster/r.in.gdal/main.c:186
+#: ../raster/r.external/main.c:102 ../raster3d/r3.in.lidar/main.c:293
+#: ../vector/v.in.lidar/main.c:321 ../vector/v.in.ogr/main.c:348
+#: ../vector/v.external/args.c:45
+msgid "Override projection check (use current location's projection)"
+msgstr ""
+#: ../locale/scriptstrings/v.import_to_translate.c:28
+#: ../locale/scriptstrings/r.import_to_translate.c:32
+#: ../vector/v.in.ogr/main.c:350 ../vector/v.external/args.c:47
+msgid "Assume that the dataset has the same projection as the current location"
+msgstr ""
+msgid "Aggregates temporally the maps of a space time raster dataset by a user defined granularity."
+msgstr ""
+#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:7
+msgid "Either a numerical suffix or the start time (s-flag) separated by an underscore will be attached to create a unique identifier"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:9
+msgid "Aggregation granularity, format absolute time \"x years, x months, x weeks, x days, x hours, x minutes, x seconds\" or an integer value for relative time"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:12
+msgid "Number of r.series processes to run in parallel"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:13
+msgid "The maximum number of open files allowed for each r.series process"
+msgstr ""
+#: ../locale/scriptstrings/r.reclass.area_to_translate.c:1
+msgid "Reclasses a raster map greater or less than user specified area size (in hectares)."
+msgstr ""
+#: ../locale/scriptstrings/r.reclass.area_to_translate.c:5
+msgid "Value option that sets the area size limit (in hectares)"
+msgstr ""
+#: ../locale/scriptstrings/r.reclass.area_to_translate.c:7
+msgid "Lesser or greater than specified value"
+msgstr ""
+#: ../locale/scriptstrings/r.reclass.area_to_translate.c:9
+msgid "Method used for reclassification"
+msgstr ""
+#: ../locale/scriptstrings/r.reclass.area_to_translate.c:11
+msgid "Input map is clumped"
+msgstr ""
+#: ../locale/scriptstrings/r.reclass.area_to_translate.c:12
+msgid "Clumps including diagonal neighbors"
+msgstr ""
+#: ../locale/scriptstrings/r.blend_to_translate.c:1
+msgid "Blends color components of two raster maps by a given ratio."
+msgstr ""
+#: ../locale/scriptstrings/r.blend_to_translate.c:3
+#: ../raster/r.composite/main.c:73
+msgid "composite"
+msgstr ""
+#: ../locale/scriptstrings/r.blend_to_translate.c:4
+msgid "Name of first raster map for blending"
+msgstr ""
+#: ../locale/scriptstrings/r.blend_to_translate.c:5
+msgid "Name of second raster map for blending"
+msgstr ""
+#: ../locale/scriptstrings/r.blend_to_translate.c:6
+msgid "Basename for red, green and blue output raster maps"
+msgstr ""
+#: ../locale/scriptstrings/r.blend_to_translate.c:7
+msgid "Percentage weight of first map for color blending"
+msgstr ""
+#: ../locale/scriptstrings/r.blend_to_translate.c:8
+msgid "Combine resulting R,G,B layers into single output map"
+msgstr ""
+msgid "Detects accumulation patterns in temporally accumulated space time raster datasets created by t.rast.accumulate."
+msgstr ""
+#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:6
+msgid "Input space time raster dataset that specifies the minimum values to detect the accumulation pattern"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:7
+msgid "Input space time raster dataset that specifies the maximum values to detect the accumulation pattern"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:8
+msgid "The output space time raster dataset that stores the occurrence of the the accumulation pattern using the provided data range"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:9
+msgid "The output space time raster dataset that stores the indication of the start, intermediate and end of the specified data range"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:13
+msgid "The temporal offset to the begin of the next cycle, eg '6 months'"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:16
+msgid "Suffix to add at basename: set 'gran' for granularity, 'time' for the full time format, 'count' for numerical suffix with a specific number of digits (default %05)"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:17
+msgid "The minimum and maximum value of the occurrence of accumulated values, these values will be used if the min/max space time raster datasets are not specified"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:18
+msgid "The user defined values that indicate start, intermediate and end status in the indicator output space time raster dataset"
+msgstr ""
+msgid "Creates/modifies the color table associated with each raster map of the space time raster dataset."
+msgstr ""
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:6
+msgid "Name of color table (see r.color help)"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:7
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:9
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:11
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:13
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:20
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:22
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:24
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:26
+#: ../raster/r.colors/edit_colors.c:90 ../raster/r.colors/edit_colors.c:97
+#: ../raster/r.colors/edit_colors.c:104 ../raster/r.colors/edit_colors.c:111
+#: ../raster/r.colors/edit_colors.c:122 ../raster/r.colors/edit_colors.c:133
+#: ../raster/r.colors/edit_colors.c:138 ../raster/r.colors/edit_colors.c:143
+#: ../raster/r.colors/edit_colors.c:148 ../raster/r.category/main.c:81
+#: ../raster/r.category/main.c:88 ../display/d.linegraph/main.c:270
+#: ../vector/v.colors/main.c:81 ../vector/v.colors/main.c:92
+#: ../vector/v.colors/main.c:99 ../vector/v.colors/main.c:106
+#: ../vector/v.colors/main.c:112 ../vector/v.colors/main.c:138
+#: ../vector/v.colors/main.c:143 ../vector/v.colors/main.c:148
+msgid "Define"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:8
+#: ../raster/r.colors/edit_colors.c:96 ../vector/v.colors/main.c:98
+msgid "Raster map from which to copy color table"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:10
+#: ../raster/r.colors/edit_colors.c:103 ../vector/v.colors/main.c:105
+msgid "3D raster map from which to copy color table"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:12
+#: ../raster/r.colors/edit_colors.c:109 ../vector/v.colors/main.c:111
+msgid "Path to rules file"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:14
+#: ../raster/r.colors/edit_colors.c:115 ../vector/v.colors/main.c:121
+msgid "Remove existing color table"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:16
+#: ../raster/r.colors/edit_colors.c:121 ../vector/v.colors/main.c:127
+msgid "Only write new color table if it does not already exist"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:17
+#: ../raster/r.colors/edit_colors.c:126 ../vector/v.colors/main.c:131
+msgid "List available rules then exit"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:19
+#: ../raster/r.colors/edit_colors.c:132 ../vector/v.colors/main.c:137
+msgid "Invert colors"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:21
+#: ../raster/r.colors/edit_colors.c:137 ../vector/v.colors/main.c:142
+msgid "Logarithmic scaling"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:23
+#: ../raster/r.colors/edit_colors.c:142 ../vector/v.colors/main.c:147
+msgid "Logarithmic-absolute scaling"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:25
+#: ../raster/r.colors/edit_colors.c:147
+msgid "Histogram equalization"
+msgstr ""
+#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:1
+msgid "Mosaics several images and extends colormap."
+msgstr ""
+#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:4
+#: ../raster/r.patch/main.c:60
+msgid "mosaicking"
+msgstr ""
+#: ../locale/scriptstrings/t.rename_to_translate.c:1
+msgid "Renames a space time dataset"
+msgstr ""
+#: ../locale/scriptstrings/t.rename_to_translate.c:4
+#: ../general/g.rename/main.c:47
+msgid "rename"
+msgstr ""
+#: ../locale/scriptstrings/v.in.lines_to_translate.c:1
+msgid "Imports ASCII x,y[,z] coordinates as a series of lines."
+msgstr ""
+#: ../locale/scriptstrings/v.in.lines_to_translate.c:6
+msgid "Create a 3D line from 3 column data"
+msgstr ""
+#: ../locale/scriptstrings/v.in.lines_to_translate.c:7
+msgid "Name of input file (or \"-\" to read from stdin)"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:1
+msgid "Exports space time raster dataset as VTK time series."
+msgstr ""
+#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:5
+msgid "VTK"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:7
+msgid "Path to the export directory"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:8
+#: ../raster/r.out.vtk/parameters.c:45
+msgid "Value to represent no data cell"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:9
+#: ../raster/r.out.vtk/parameters.c:59
+msgid "Create VTK point data instead of VTK cell data (if no elevation map is given)"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:10
+#: ../vector/v.out.vtk/main.c:84
+msgid "Correct the coordinates to fit the VTK-OpenGL precision"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:11
+msgid "Export files using the space time dataset granularity for equidistant time between maps, where statement will be ignored"
+msgstr ""
+#: ../locale/scriptstrings/r.mask_to_translate.c:1
+msgid "Creates a MASK for limiting raster operation."
+msgstr ""
+#: ../locale/scriptstrings/r.mask_to_translate.c:3
+#: ../raster3d/r3.mask/main.c:134
+msgid "mask"
+msgstr ""
+#: ../locale/scriptstrings/r.mask_to_translate.c:4
+msgid "Name of raster map to use as mask"
+msgstr ""
+#: ../locale/scriptstrings/r.mask_to_translate.c:5
+#: ../locale/scriptstrings/r.mask_to_translate.c:8
+msgid "Raster"
+msgstr ""
+#: ../locale/scriptstrings/r.mask_to_translate.c:6
+msgid "Raster values to use for mask"
+msgstr ""
+#: ../locale/scriptstrings/r.mask_to_translate.c:7
+msgid "Format: 1 2 3 thru 7 *"
+msgstr ""
+#: ../locale/scriptstrings/r.mask_to_translate.c:9
+msgid "Name of vector map to use as mask"
+msgstr ""
+#: ../locale/scriptstrings/r.mask_to_translate.c:10
+#: ../locale/scriptstrings/r.mask_to_translate.c:12
+#: ../locale/scriptstrings/r.mask_to_translate.c:14
+#: ../locale/scriptstrings/r.mask_to_translate.c:16
+msgid "Vector"
+msgstr ""
+#: ../locale/scriptstrings/r.mask_to_translate.c:11
+msgid "Layer number or name (vector)"
+msgstr ""
+#: ../locale/scriptstrings/r.mask_to_translate.c:13
+msgid "Category values (vector)"
+msgstr ""
+#: ../locale/scriptstrings/r.mask_to_translate.c:15
+msgid "WHERE conditions of SQL statement without 'where' keyword (vector)"
+msgstr ""
+#: ../locale/scriptstrings/r.mask_to_translate.c:17
+msgid "Create inverse mask"
+msgstr ""
+#: ../locale/scriptstrings/r.mask_to_translate.c:18
+#: ../general/g.proj/main.c:201 ../general/g.mapset/main.c:70
+msgid "Create"
+msgstr ""
+#: ../locale/scriptstrings/r.mask_to_translate.c:19
+msgid "Remove existing mask (overrides other options)"
+msgstr ""
+#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:1
+msgid "Reconnects attribute tables for all vector maps from the current mapset to a new database."
+msgstr ""
+#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:5
+msgid "Copy attribute tables to the target database if not exist"
+msgstr ""
+#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:6
+msgid "Delete attribute tables from the source database"
+msgstr ""
+#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:7
+msgid "Name of source database"
+msgstr ""
+#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:8
+msgid "Name of source database schema"
+msgstr ""
+#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:9
+msgid "Name for target driver"
+msgstr ""
+#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:10
+msgid "Name for target database"
+msgstr ""
+#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:11
+msgid "Name for target database schema"
+msgstr ""
+#: ../locale/scriptstrings/v.report_to_translate.c:1
+msgid "Reports geometry statistics for vector maps."
+msgstr ""
+#: ../locale/scriptstrings/v.report_to_translate.c:6
+msgid "Value to calculate"
+msgstr ""
+#: ../locale/scriptstrings/v.report_to_translate.c:7
+msgid "Sort the result"
+msgstr ""
+#: ../locale/scriptstrings/v.report_to_translate.c:8
+msgid "asc;Sort in ascending order;desc;Sort in descending order"
+msgstr ""
+#: ../locale/scriptstrings/v.unpack_to_translate.c:1
+msgid "Imports a vector map as GRASS GIS specific archive file (packed with v.pack)"
+msgstr ""
+#: ../locale/scriptstrings/v.unpack_to_translate.c:5
+#: ../locale/scriptstrings/r.unpack_to_translate.c:5
+msgid "Name of input pack file"
+msgstr ""
+#: ../locale/scriptstrings/v.unpack_to_translate.c:6
+msgid "Name for output vector map"
+msgstr ""
+#: ../locale/scriptstrings/v.unpack_to_translate.c:7
+msgid "Default: taken from input file internals"
+msgstr ""
+#: ../locale/scriptstrings/v.unpack_to_translate.c:8
+#: ../locale/scriptstrings/v.unpack_to_translate.c:11
+#: ../locale/scriptstrings/r.unpack_to_translate.c:7
+#: ../locale/scriptstrings/r.unpack_to_translate.c:10 ../ps/ps.map/main.c:100
+#: ../ps/ps.map/main.c:113 ../ps/ps.map/main.c:135
+#: ../raster/r.univar/r.univar_main.c:42 ../raster/r.kappa/main.c:90
+#: ../raster/r.kappa/main.c:98
+msgid "Output settings"
+msgstr ""
+#: ../locale/scriptstrings/v.unpack_to_translate.c:10
+#: ../locale/scriptstrings/r.unpack_to_translate.c:9
+#: ../locale/scriptstrings/t.rast.import_to_translate.c:19
+#: ../locale/scriptstrings/t.vect.import_to_translate.c:15
+#: ../raster/r.in.lidar/main.c:302 ../raster/r.in.gdal/main.c:188
+#: ../raster/r.external/main.c:104 ../raster3d/r3.in.lidar/main.c:295
+#: ../vector/v.in.lidar/main.c:323
+msgid "Assume that the dataset has same projection as the current location"
+msgstr ""
+#: ../locale/scriptstrings/v.unpack_to_translate.c:12
+#: ../locale/scriptstrings/r.unpack_to_translate.c:11
+msgid "Print projection information of input pack file and exit"
+msgstr ""
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:1
+msgid "Calculates univariate statistics on selected table column for a GRASS vector map."
+msgstr ""
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:5
+#: ../locale/scriptstrings/db.univar_to_translate.c:5
+msgid "Name of attribute column on which to calculate statistics (must be numeric)"
+msgstr ""
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:6
+#: ../locale/scriptstrings/db.univar_to_translate.c:6
+#: ../raster/r.univar/r3.univar_main.c:52 ../raster/r.univar/r.univar_main.c:52
+#: ../vector/v.univar/main.c:122
+msgid "Percentile to calculate (requires extended statistics flag)"
+msgstr ""
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:7
+#: ../locale/scriptstrings/db.univar_to_translate.c:7
+msgid "Extended statistics (quartiles and 90th percentile)"
+msgstr ""
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:8
+#: ../locale/scriptstrings/db.univar_to_translate.c:8
+#: ../raster/r.info/main.c:91
+msgid "Print stats in shell script style"
+msgstr ""
+#: ../locale/scriptstrings/v.db.update_to_translate.c:1
+msgid "Updates a column in the attribute table connected to a vector map."
+msgstr ""
+#: ../locale/scriptstrings/v.db.update_to_translate.c:5
+msgid "Name of attribute column to update"
+msgstr ""
+#: ../locale/scriptstrings/v.db.update_to_translate.c:6
+msgid "Literal value to update the column with"
+msgstr ""
+#: ../locale/scriptstrings/v.db.update_to_translate.c:7
+msgid "Name of other attribute column to query, can be combination of columns (e.g. co1+col2)"
+msgstr ""
+#: ../locale/scriptstrings/v.db.update_to_translate.c:8
+msgid "Name of SQLite extension file for extra functions (SQLite backend only)"
+msgstr ""
+#: ../locale/scriptstrings/t.create_to_translate.c:1
+msgid "Creates a space time dataset."
+msgstr ""
+#: ../locale/scriptstrings/t.create_to_translate.c:4
+msgid "create"
+msgstr ""
+#: ../locale/scriptstrings/t.create_to_translate.c:6
+msgid "Type of the output space time dataset"
+msgstr ""
+#: ../locale/scriptstrings/t.create_to_translate.c:8
+#: ../locale/scriptstrings/t.rast.import_to_translate.c:10
+#: ../locale/scriptstrings/t.vect.import_to_translate.c:10
+msgid "Title of the new space time dataset"
+msgstr ""
+#: ../locale/scriptstrings/t.create_to_translate.c:9
+#: ../locale/scriptstrings/t.rast.import_to_translate.c:11
+#: ../locale/scriptstrings/t.vect.import_to_translate.c:11
+msgid "Description of the new space time dataset"
+msgstr ""
+#: ../locale/scriptstrings/db.out.ogr_to_translate.c:1
+msgid "Exports attribute tables into various formats."
+msgstr ""
+#: ../locale/scriptstrings/db.out.ogr_to_translate.c:5
+msgid "GRASS table name"
+msgstr ""
+#: ../locale/scriptstrings/db.out.ogr_to_translate.c:6
+msgid "Output table file name or DB connection string"
+msgstr ""
+#: ../locale/scriptstrings/db.out.ogr_to_translate.c:7
+msgid "Table format"
+msgstr ""
+#: ../locale/scriptstrings/db.out.ogr_to_translate.c:8
+msgid "Name for output table (default: input name)"
+msgstr ""
+msgid "Imports a raster map as GRASS GIS specific archive file (packed with r.pack)"
+msgstr ""
+#: ../locale/scriptstrings/r.unpack_to_translate.c:6
+msgid "Name for output raster map (default: taken from input file internals)"
+msgstr ""
+#: ../locale/scriptstrings/i.spectral_to_translate.c:1
+msgid "Displays spectral response at user specified locations in group or images."
+msgstr ""
+#: ../locale/scriptstrings/i.spectral_to_translate.c:5
+#: ../locale/scriptstrings/i.oif_to_translate.c:3
+msgid "multispectral"
+msgstr ""
+#: ../locale/scriptstrings/i.spectral_to_translate.c:9
+msgid "Name for output image (or text file for -t)"
+msgstr ""
+#: ../locale/scriptstrings/i.spectral_to_translate.c:11
+msgid "Graphics format for output file"
+msgstr ""
+#: ../locale/scriptstrings/i.spectral_to_translate.c:13
+msgid "Show sampling coordinates instead of numbering in the legend"
+msgstr ""
+#: ../locale/scriptstrings/i.spectral_to_translate.c:14
+msgid "Use gnuplot for display"
+msgstr ""
+#: ../locale/scriptstrings/i.spectral_to_translate.c:15
+msgid "output to text file"
+msgstr ""
+msgid "Imports attribute tables in various formats."
+msgstr ""
+#: ../locale/scriptstrings/db.in.ogr_to_translate.c:5
+msgid "Table file to be imported or DB connection string"
+msgstr ""
+#: ../locale/scriptstrings/db.in.ogr_to_translate.c:6
+msgid "Name of table from given DB to be imported"
+msgstr ""
+#: ../locale/scriptstrings/db.in.ogr_to_translate.c:7
+msgid "Name for output table"
+msgstr ""
+#: ../locale/scriptstrings/db.in.ogr_to_translate.c:9
+msgid "Name for auto-generated unique key column"
+msgstr ""
+#: ../locale/scriptstrings/db.in.ogr_to_translate.c:12
+msgid "Overrides encoding interpretation, useful when importing DBF tables"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.what_to_translate.c:1
+msgid "Sample a space time raster dataset at specific vector point coordinates and write the output to stdout using different layouts"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.what_to_translate.c:6
+msgid "Comma separated list of coordinates"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.what_to_translate.c:7
+msgid "Name for the output file or \"-\" in case stdout should be used"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.what_to_translate.c:9
+msgid "The layout of the output. One point per row (row), one point per column (col), all timsteps in one row (timerow)"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.what_to_translate.c:10
+msgid "Number of r.what processes to run in parallel"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.what_to_translate.c:11
+#: ../raster/r.what/main.c:143
+msgid "Output header row"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.what_to_translate.c:12
+msgid "Use stdin as input and ignore coordinates and point option"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.what_to_translate.c:13
+#: ../raster/r.what/main.c:168
+msgid "Show the category for vector points map"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.to.rast3_to_translate.c:1
+msgid "Converts a space time raster dataset into a 3D raster map."
+msgstr ""
+#: ../locale/scriptstrings/v.db.join_to_translate.c:1
+msgid "Joins a database table to a vector map table."
+msgstr ""
+#: ../locale/scriptstrings/v.db.join_to_translate.c:5
+msgid "Vector map to which to join other table"
+msgstr ""
+#: ../locale/scriptstrings/v.db.join_to_translate.c:7
+msgid "Layer where to join"
+msgstr ""
+#: ../locale/scriptstrings/v.db.join_to_translate.c:9
+msgid "Identifier column (e.g.: cat) in the vector table to be used for join"
+msgstr ""
+#: ../locale/scriptstrings/v.db.join_to_translate.c:10
+msgid "Other table name"
+msgstr ""
+#: ../locale/scriptstrings/v.db.join_to_translate.c:11
+msgid "ocolumn,scolumns"
+msgstr ""
+#: ../locale/scriptstrings/v.db.join_to_translate.c:12
+msgid "Identifier column (e.g.: id) in the other table used for join"
+msgstr ""
+#: ../locale/scriptstrings/v.db.join_to_translate.c:13
+msgid "Subset of columns from the other table"
+msgstr ""
+msgid "Imports space time raster dataset."
+msgstr ""
+#: ../locale/scriptstrings/t.rast.import_to_translate.c:6
+#: ../locale/scriptstrings/t.vect.import_to_translate.c:6
+#: ../raster/r.in.gdal/main.c:95 ../general/g.proj/main.c:66
+#: ../vector/v.in.ogr/main.c:201
+msgid "create location"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.import_to_translate.c:9
+#: ../locale/scriptstrings/t.vect.import_to_translate.c:9
+msgid "Path to the extraction directory"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.import_to_translate.c:12
+#: ../locale/scriptstrings/t.vect.import_to_translate.c:12
+msgid "Create a new location and import the data into it. Do not run this module in parallel or interrupt it when a new location should be created"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.import_to_translate.c:13
+#: ../locale/scriptstrings/r.import_to_translate.c:10
+#: ../raster/r.stream.extract/main.c:141 ../raster/r.resamp.bspline/main.c:151
+#: ../raster/r.proj/main.c:192 ../raster/r.in.gdal/main.c:124
+#: ../vector/v.to.rast/main.c:117 ../vector/v.surf.bspline/main.c:195
+msgid "Cache size for raster rows"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.import_to_translate.c:14
+#: ../locale/scriptstrings/r.import_to_translate.c:9
+#: ../raster/r.stream.extract/main.c:140 ../raster/r.resamp.bspline/main.c:150
+#: ../raster/r.proj/main.c:191 ../raster/r.in.gdal/main.c:123
+#: ../vector/v.to.rast/main.c:116 ../vector/v.surf.bspline/main.c:194
+msgid "Maximum memory to be used (in MB)"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.import_to_translate.c:15
+msgid "Set the current region from the last map that was imported"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.import_to_translate.c:16
+msgid "Link the raster files using r.external"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.import_to_translate.c:17
+#: ../locale/scriptstrings/t.vect.import_to_translate.c:13
+msgid "Extend location extents based on new dataset"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.import_to_translate.c:20
+msgid "Create the location specified by the \"location\" parameter and exit. Do not import the space time raster datasets."
+msgstr ""
+#: ../locale/scriptstrings/d.what.rast_to_translate.c:1
+msgid "Allows the user to interactively query raster map layers at user-selected locations."
+msgstr ""
+#: ../locale/scriptstrings/v.centroids_to_translate.c:1
+msgid "Adds missing centroids to closed boundaries."
+msgstr ""
+#: ../locale/scriptstrings/v.centroids_to_translate.c:3
+#: ../vector/v.category/main.c:691
+msgid "centroid"
+msgstr ""
+#: ../locale/scriptstrings/v.centroids_to_translate.c:5
+msgid "Action to be taken"
+msgstr ""
+#: ../locale/scriptstrings/v.centroids_to_translate.c:6
+msgid "Category number starting value"
+msgstr ""
+#: ../locale/scriptstrings/v.centroids_to_translate.c:7
+#: ../vector/v.category/main.c:134
+msgid "Category increment"
+msgstr ""
+#: ../locale/scriptstrings/g.manual_to_translate.c:1
+msgid "Displays the manual pages of GRASS modules."
+msgstr ""
+#: ../locale/scriptstrings/g.manual_to_translate.c:3
+msgid "manual"
+msgstr ""
+#: ../locale/scriptstrings/g.manual_to_translate.c:4
+msgid "help"
+msgstr ""
+#: ../locale/scriptstrings/g.manual_to_translate.c:5
+msgid "Display index"
+msgstr ""
+#: ../locale/scriptstrings/g.manual_to_translate.c:6
+msgid "Display topics"
+msgstr ""
+#: ../locale/scriptstrings/g.manual_to_translate.c:7
+msgid "Display as MAN text page instead of HTML page in browser"
+msgstr ""
+#: ../locale/scriptstrings/g.manual_to_translate.c:8
+msgid "Display online manuals instead of locally installed"
+msgstr ""
+#: ../locale/scriptstrings/g.manual_to_translate.c:9
+msgid "Use online manuals available at http://grass.osgeo.org website. This flag has no effect when displaying MAN text pages."
+msgstr ""
+#: ../locale/scriptstrings/g.manual_to_translate.c:10
+msgid "Manual entry to be displayed"
+msgstr ""
+#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:1
+msgid "Adds one or more columns to the attribute table connected to a given vector map."
+msgstr ""
+#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:5
+msgid "Layer number where to add column(s)"
+msgstr ""
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:1
+msgid "Fills no-data areas in raster maps using spline interpolation."
+msgstr ""
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:5
+#: ../raster/r.proj/main.c:182 ../imagery/i.rectify/main.c:132
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:126
+msgid "Interpolation method to use"
+msgstr ""
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:6
+msgid "Spline tension parameter"
+msgstr ""
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:7
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:9
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:11
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:13
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:15
+msgid "RST options"
+msgstr ""
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:8
+msgid "Spline smoothing parameter"
+msgstr ""
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:10
+msgid "Width of hole edge used for interpolation (in cells)"
+msgstr ""
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:12
+#: ../vector/v.surf.rst/main.c:307 ../vector/v.vol.rst/main.c:319
+msgid "Minimum number of points for approximation in a segment (>segmax)"
+msgstr ""
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:14
+#: ../vector/v.surf.rst/main.c:298 ../vector/v.vol.rst/main.c:310
+msgid "Maximum number of points in a segment"
+msgstr ""
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:16
+#: ../raster/r.resamp.bspline/main.c:131 ../vector/v.surf.bspline/main.c:177
+msgid "Tykhonov regularization parameter (affects smoothing)"
+msgstr ""
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:17
+msgid "Used in bilinear and bicubic spline interpolation"
+msgstr ""
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:18
+msgid "Spline options"
+msgstr ""
+#: ../locale/scriptstrings/v.db.droprow_to_translate.c:1
+msgid "Removes a vector feature from a vector map through attribute selection."
+msgstr ""
+msgid "Samples the input space time dataset(s) with a sample space time dataset and print the result to stdout."
+msgstr ""
+#: ../locale/scriptstrings/t.sample_to_translate.c:5
+msgid "Name of the sample space time dataset"
+msgstr ""
+#: ../locale/scriptstrings/t.sample_to_translate.c:8
+msgid "Type of the sample space time dataset"
+msgstr ""
+#: ../locale/scriptstrings/t.sample_to_translate.c:9
+msgid "Field separator between output columns, default is tabular \" | \""
+msgstr ""
+#: ../locale/scriptstrings/t.sample_to_translate.c:10
+msgid "Do not use \",\" as this char is reserved to list several map ids in a sample granule"
+msgstr ""
+#: ../locale/scriptstrings/t.sample_to_translate.c:12
+msgid "Check for spatial topological overlap"
+msgstr ""
+#: ../locale/scriptstrings/d.redraw_to_translate.c:1
+msgid "Redraws the content of currently selected monitor."
+msgstr ""
+#: ../locale/scriptstrings/d.redraw_to_translate.c:4
+#: ../locale/scriptstrings/d.frame_to_translate.c:4 ../display/d.mon/main.c:52
+#: ../display/d.info/main.c:36 ../display/d.erase/main.c:31
+msgid "monitors"
+msgstr ""
+#: ../locale/scriptstrings/d.frame_to_translate.c:1
+msgid "Manages display frames on the user's graphics monitor."
+msgstr ""
+#: ../locale/scriptstrings/d.frame_to_translate.c:5
+msgid "frame"
+msgstr ""
+#: ../locale/scriptstrings/d.frame_to_translate.c:6
+msgid "Create a new frame if doesn't exist and select"
+msgstr ""
+#: ../locale/scriptstrings/d.frame_to_translate.c:7
+msgid "Remove all frames, erase the screen and exit"
+msgstr ""
+#: ../locale/scriptstrings/d.frame_to_translate.c:8
+msgid "Print name of current frame and exit"
+msgstr ""
+#: ../locale/scriptstrings/d.frame_to_translate.c:9
+msgid "Print names of all frames including 'at' position and exit"
+msgstr ""
+#: ../locale/scriptstrings/d.frame_to_translate.c:10
+msgid "Frame to be selected or created (if -c flag is given)"
+msgstr ""
+#: ../locale/scriptstrings/d.frame_to_translate.c:11
+msgid "Screen coordinates in percent where to place the frame (0,0 is lower-left)"
+msgstr ""
+#: ../locale/scriptstrings/d.frame_to_translate.c:12
+msgid "Implies only when -c or --overwrite flag is given"
+msgstr ""
+msgid "Apply temporal and spatial operations on space time raster datasets using temporal raster algebra."
+msgstr ""
+#: ../locale/scriptstrings/t.rast.algebra_to_translate.c:6
+msgid "r.mapcalc expression for temporal and spatial analysis of space time raster datasets"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.algebra_to_translate.c:12
+#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:13
+msgid "Use granularity sampling instead of the temporal topology approach"
+msgstr ""
+#: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:1
+msgid "Observes specific locations in a space time raster dataset over a period of time using vector points."
+msgstr ""
+#: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:6
+msgid "Name of the new created vector map that stores the sampled values in different layers"
+msgstr ""
+#: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:7
+msgid "Names of the vector columns to be created and to store sampled raster values, one name for each STRDS"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:1
+msgid "Performs a neighborhood analysis for each map in a space time raster dataset."
+msgstr ""
+#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:6
+#: ../raster/r.neighbors/main.c:212
+msgid "Neighborhood size"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:11
+msgid "Number of r.neighbor processes to run in parallel"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:13
+msgid "Ignore the current region settings and use the raster map regions"
+msgstr ""
+#: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:1
+#: ../raster/r.buffer/main.c:69
+msgid "Creates a raster map showing buffer zones surrounding cells that contain non-NULL category values."
+msgstr ""
+#: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:2
+msgid "This is the low-memory alternative to the classic r.buffer module."
+msgstr ""
+#: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:4
+#: ../raster/r.buffer/main.c:67 ../raster/r.circle/main.c:52
+#: ../vector/v.buffer/main.c:222 ../vector/v.parallel/main.c:51
+msgid "buffer"
+msgstr ""
+#: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:5
+#: ../raster/r.buffer/main.c:94
+msgid "Ignore zero (0) data cells instead of NULL cells"
+msgstr ""
+#: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:6
+#: ../raster/r.buffer/main.c:81
+msgid "Distance zone(s)"
+msgstr ""
+#: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:7
+#: ../raster/r.buffer/main.c:88
+msgid "Units of distance"
+msgstr ""
+#: ../locale/scriptstrings/v.dissolve_to_translate.c:1
+msgid "Dissolves boundaries between adjacent areas sharing a common category number or attribute."
+msgstr ""
+#: ../locale/scriptstrings/v.dissolve_to_translate.c:3
+#: ../vector/v.extract/main.c:80
+msgid "dissolve"
+msgstr ""
+#: ../locale/scriptstrings/v.dissolve_to_translate.c:6
+msgid "Layer number or name."
+msgstr ""
+#: ../locale/scriptstrings/v.dissolve_to_translate.c:7
+msgid "Name of attribute column used to dissolve common boundaries"
+msgstr ""
+msgid "Imports a space time vector dataset from a GRASS GIS specific archive file."
+msgstr ""
+#: ../locale/scriptstrings/t.vect.import_to_translate.c:16
+msgid "Create the location specified by the \"location\" parameter and exit. Do not import the space time vector datasets."
+msgstr ""
+#: ../locale/scriptstrings/r.drain_to_translate.c:1
+#: ../raster/r.drain/main.c:113
+msgid "Traces a flow through an elevation model or cost surface on a raster map."
+msgstr ""
+#: ../locale/scriptstrings/r.drain_to_translate.c:3 ../raster/r.path/main.c:138
+#: ../raster/r.solute.transport/main.c:230 ../raster/r.topmodel/main.c:52
+#: ../raster/r.uslek/main.c:54 ../raster/r.usler/main.c:53
+#: ../raster/r.gwflow/main.c:210 ../raster/r.stream.extract/main.c:77
+#: ../raster/r.fill.dir/main.c:89 ../raster/r.basins.fill/main.c:55
+#: ../raster/r.water.outlet/main.c:58 ../raster/r.drain/main.c:110
+#: ../raster/r.topidx/main.c:40 ../raster/r.flow/main.c:422
+#: ../raster/r.carve/main.c:75 ../raster/r.lake/main.c:151
+#: ../raster/r.watershed/front/main.c:74
+#: ../raster/r.sim/r.sim.sediment/main.c:115
+#: ../raster/r.sim/r.sim.water/main.c:114 ../raster3d/r3.gwflow/main.c:162
+#: ../raster3d/r3.flow/main.c:180
+msgid "hydrology"
+msgstr "hidrológia"
+#: ../locale/scriptstrings/r.drain_to_translate.c:4 ../raster/r.path/main.c:139
+#: ../raster/r.walk/main.c:197 ../raster/r.cost/main.c:158
+#: ../raster/r.drain/main.c:111
+msgid "cost surface"
+msgstr ""
+#: ../locale/scriptstrings/r.drain_to_translate.c:5
+#: ../raster/r.drain/main.c:116
+msgid "Name of input elevation or cost surface raster map"
+msgstr ""
+#: ../locale/scriptstrings/r.drain_to_translate.c:6
+#: ../raster/r.drain/main.c:121
+msgid "Name of input movement direction map associated with the cost surface"
+msgstr ""
+#: ../locale/scriptstrings/r.drain_to_translate.c:7
+#: ../raster/r.drain/main.c:123
+msgid "Direction in degrees CCW from east"
+msgstr ""
+#: ../locale/scriptstrings/r.drain_to_translate.c:8
+#: ../locale/scriptstrings/r.drain_to_translate.c:23
+#: ../raster/r.drain/main.c:125 ../raster/r.drain/main.c:168
+msgid "Cost surface"
+msgstr ""
+#: ../locale/scriptstrings/r.drain_to_translate.c:10
+#: ../raster/r.drain/main.c:133
+msgid "Name for output drain vector map"
+msgstr ""
+#: ../locale/scriptstrings/r.drain_to_translate.c:11
+#: ../raster/r.drain/main.c:134
+msgid "Recommended for cost surface made using knight's move"
+msgstr ""
+#: ../locale/scriptstrings/r.drain_to_translate.c:12
+#: ../raster/r.path/main.c:182 ../raster/r.walk/main.c:245
+#: ../raster/r.cost/main.c:209 ../raster/r.drain/main.c:139
+msgid "Coordinates of starting point(s) (E,N)"
+msgstr ""
+#: ../locale/scriptstrings/r.drain_to_translate.c:13
+#: ../locale/scriptstrings/r.drain_to_translate.c:15
+#: ../raster/r.path/main.c:183 ../raster/r.path/main.c:189
+#: ../raster/r.walk/main.c:227 ../raster/r.walk/main.c:239
+#: ../raster/r.walk/main.c:246 ../raster/r.walk/main.c:327
+#: ../raster/r.cost/main.c:191 ../raster/r.cost/main.c:203
+#: ../raster/r.cost/main.c:210 ../raster/r.cost/main.c:260
+#: ../raster/r.drain/main.c:140 ../raster/r.drain/main.c:147
+msgid "Start"
+msgstr ""
+#: ../locale/scriptstrings/r.drain_to_translate.c:14
+#: ../raster/r.path/main.c:188 ../raster/r.drain/main.c:145
+msgid "Name of starting vector points map(s)"
+msgstr ""
+#: ../locale/scriptstrings/r.drain_to_translate.c:16
+#: ../raster/r.path/main.c:193 ../raster/r.drain/main.c:151
+msgid "Copy input cell values on output"
+msgstr ""
+#: ../locale/scriptstrings/r.drain_to_translate.c:17
+#: ../locale/scriptstrings/r.drain_to_translate.c:19
+#: ../locale/scriptstrings/r.drain_to_translate.c:21
+#: ../raster/r.path/main.c:194 ../raster/r.path/main.c:199
+#: ../raster/r.path/main.c:204 ../raster/r.drain/main.c:152
+#: ../raster/r.drain/main.c:157 ../raster/r.drain/main.c:162
+msgid "Path settings"
+msgstr ""
+#: ../locale/scriptstrings/r.drain_to_translate.c:18
+#: ../raster/r.path/main.c:198 ../raster/r.drain/main.c:156
+msgid "Accumulate input values along the path"
+msgstr ""
+#: ../locale/scriptstrings/r.drain_to_translate.c:20
+#: ../raster/r.path/main.c:203 ../raster/r.drain/main.c:161
+msgid "Count cell numbers along the path"
+msgstr ""
+#: ../locale/scriptstrings/r.drain_to_translate.c:22
+#: ../raster/r.drain/main.c:167
+msgid "The input raster map is a cost surface (direction surface must also be specified)"
+msgstr ""
+msgid "Imports raster data into a GRASS raster map using GDAL library and reprojects on the fly."
+msgstr ""
+#: ../locale/scriptstrings/r.import_to_translate.c:5
+msgid "Name of GDAL dataset to be imported"
+msgstr ""
+#: ../locale/scriptstrings/r.import_to_translate.c:7
+msgid "Input band(s) to select (default is all bands)"
+msgstr ""
+#: ../locale/scriptstrings/r.import_to_translate.c:13
+msgid "Resampling method to use for reprojection"
+msgstr ""
+#: ../locale/scriptstrings/r.import_to_translate.c:14
+msgid "nearest;nearest neighbor;bilinear;bilinear interpolation;bicubic;bicubic interpolation;lanczos;lanczos filter;bilinear_f;bilinear interpolation with fallback;bicubic_f;bicubic interpolation with fallback;lanczos_f;lanczos filter with fallback"
+msgstr ""
+#: ../locale/scriptstrings/r.import_to_translate.c:16
+msgid "Output raster map extent"
+msgstr ""
+#: ../locale/scriptstrings/r.import_to_translate.c:17
+msgid "region;extent of current region;input;extent of input map"
+msgstr ""
+#: ../locale/scriptstrings/r.import_to_translate.c:19
+msgid "Resolution of output raster map (default: estimated)"
+msgstr ""
+#: ../locale/scriptstrings/r.import_to_translate.c:20
+msgid "estimated;estimated resolution;value;user-specified resolution;region;current region resolution"
+msgstr ""
+#: ../locale/scriptstrings/r.import_to_translate.c:22
+msgid "Resolution of output raster map (use with option resolution=value)"
+msgstr ""
+#: ../locale/scriptstrings/r.import_to_translate.c:24
+#: ../raster/r.in.poly/main.c:50 ../raster/r.in.ascii/main.c:92
+#: ../raster/r.in.bin/main.c:298 ../raster/r.in.gdal/main.c:141
+#: ../raster/r.support/main.c:66 ../raster/r.external/main.c:90
+msgid "Title for resultant raster map"
+msgstr ""
+#: ../locale/scriptstrings/r.import_to_translate.c:25
+#: ../raster/r.in.gdal/main.c:142 ../raster/r.in.gdal/main.c:151
+#: ../raster/r.in.gdal/main.c:160 ../raster/r.in.gdal/main.c:166
+#: ../raster/r.external/main.c:91 ../imagery/i.landsat.toar/main.c:94
+#: ../imagery/i.landsat.toar/main.c:116 ../imagery/i.landsat.toar/main.c:125
+#: ../imagery/i.landsat.toar/main.c:134 ../imagery/i.landsat.toar/main.c:142
+#: ../imagery/i.landsat.toar/main.c:151
+msgid "Metadata"
+msgstr ""
+#: ../locale/scriptstrings/r.import_to_translate.c:26
+msgid "Estimate resolution only"
+msgstr ""
+#: ../locale/scriptstrings/r.import_to_translate.c:27
+#: ../locale/scriptstrings/r.import_to_translate.c:29
+#: ../raster/r.horizon/main.c:278 ../raster/r.horizon/main.c:297
+msgid "Optional"
+msgstr ""
+#: ../locale/scriptstrings/r.import_to_translate.c:28
+#: ../raster/r.proj/main.c:208
+msgid "Do not perform region cropping optimization"
+msgstr ""
+#: ../locale/scriptstrings/r.import_to_translate.c:30
+#: ../raster/r.in.gdal/main.c:215
+msgid "Force Lat/Lon maps to fit into geographic coordinates (90N,S; 180E,W)"
+msgstr ""
+#: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:1
+msgid "Stores raster map values at spatial and temporal positions of vector points as vector attributes."
+msgstr ""
+#: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:6
+msgid "Name of the vector column to be created and to store sampled raster values"
+msgstr ""
+#: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:7
+msgid "The use of a column name forces t.vect.what.rast to sample only values from the first map found in an interval. Otherwise the raster map names are used as column names"
+msgstr ""
+#: ../locale/scriptstrings/v.in.e00_to_translate.c:1
+msgid "Imports E00 file into a vector map."
+msgstr ""
+#: ../locale/scriptstrings/v.in.e00_to_translate.c:4
+msgid "E00"
+msgstr ""
+#: ../locale/scriptstrings/v.in.e00_to_translate.c:5
+msgid "Name of input E00 file"
+msgstr ""
+#: ../locale/scriptstrings/d.to.rast_to_translate.c:1
+msgid "Saves the contents of the active display monitor to a raster map."
+msgstr ""
+#: ../locale/scriptstrings/t.rast.univar_to_translate.c:1
+msgid "Calculates univariate statistics from the non-null cells for each registered raster map of a space time raster dataset."
+msgstr ""
+#: ../locale/scriptstrings/t.rast.univar_to_translate.c:10
+msgid "Ignore the current region settings and use the raster map regions for univar statistical calculation"
+msgstr ""
+#: ../locale/scriptstrings/t.topology_to_translate.c:1
+msgid "Lists temporal topology of a space time dataset."
+msgstr ""
+#: ../locale/scriptstrings/t.topology_to_translate.c:7
+msgid "Print temporal topological relationships and exit"
+msgstr ""
+#: ../locale/scriptstrings/t.topology_to_translate.c:8
+msgid "Print spatio-temporal topological relationships and exit"
+msgstr ""
+#: ../locale/scriptstrings/v.in.wfs_to_translate.c:1
+msgid "Imports GetFeature from a WFS server."
+msgstr ""
+#: ../locale/scriptstrings/v.in.wfs_to_translate.c:5
+msgid "Base URL starting with 'http' and ending in '?'"
+msgstr ""
+#: ../locale/scriptstrings/v.in.wfs_to_translate.c:6
+msgid "Comma separated names of data layers to download"
+msgstr ""
+#: ../locale/scriptstrings/v.in.wfs_to_translate.c:7
+msgid "Specify alternate spatial reference system (example: EPSG:4326)"
+msgstr ""
+#: ../locale/scriptstrings/v.in.wfs_to_translate.c:8
+msgid "The given code must be supported by the server, consult the capabilities file"
+msgstr ""
+#: ../locale/scriptstrings/v.in.wfs_to_translate.c:9
+msgid "Maximum number of features to download"
+msgstr ""
+#: ../locale/scriptstrings/v.in.wfs_to_translate.c:10
+msgid "(default: unlimited)"
+msgstr ""
+#: ../locale/scriptstrings/v.in.wfs_to_translate.c:11
+msgid "Skip earlier feature IDs and start downloading at this one"
+msgstr ""
+#: ../locale/scriptstrings/v.in.wfs_to_translate.c:12
+msgid "(default: start with the first feature)"
+msgstr ""
+#: ../locale/scriptstrings/v.in.wfs_to_translate.c:13
+msgid "Download server capabilities to 'wms_capabilities.xml' in the current directory and exit"
+msgstr ""
+#: ../locale/scriptstrings/v.in.wfs_to_translate.c:14
+msgid "Restrict fetch to features which touch the current region"
+msgstr ""
+#: ../locale/scriptstrings/i.oif_to_translate.c:1
+msgid "Calculates Optimum-Index-Factor table for spectral bands"
+msgstr ""
+#: ../locale/scriptstrings/v.in.geonames_to_translate.c:1
+msgid "Imports geonames.org country files into a vector points map."
+msgstr ""
+#: ../locale/scriptstrings/v.in.geonames_to_translate.c:4
+msgid "gazetteer"
+msgstr ""
+#: ../locale/scriptstrings/v.in.geonames_to_translate.c:5
+msgid "Name of uncompressed geonames file (with .txt extension)"
+msgstr ""
+msgid "Assigns timestamps and registers raster, vector and raster3d maps in a space time dataset."
+msgstr ""
+#: ../locale/scriptstrings/t.register_to_translate.c:4
+msgid "register"
+msgstr ""
+#: ../locale/scriptstrings/t.register_to_translate.c:8
+#: ../locale/scriptstrings/t.unregister_to_translate.c:7
+msgid "input,maps"
+msgstr ""
+#: ../locale/scriptstrings/t.register_to_translate.c:10
+#: ../locale/scriptstrings/t.unregister_to_translate.c:6
+msgid "Input file with map names, one per line"
+msgstr ""
+#: ../locale/scriptstrings/t.register_to_translate.c:11
+msgid "Additionally the start time and the end time can be specified per line"
+msgstr ""
+#: ../locale/scriptstrings/t.register_to_translate.c:13
+msgid "Valid start date and time of the first map"
+msgstr ""
+#: ../locale/scriptstrings/t.register_to_translate.c:14
+#: ../locale/scriptstrings/t.register_to_translate.c:17
+msgid "Format for absolute time: \"yyyy-mm-dd HH:MM:SS +HHMM\", relative time is of type integer."
+msgstr ""
+#: ../locale/scriptstrings/t.register_to_translate.c:15
+#: ../locale/scriptstrings/t.register_to_translate.c:18
+#: ../locale/scriptstrings/t.register_to_translate.c:21
+#: ../locale/scriptstrings/t.register_to_translate.c:24
+#: ../locale/scriptstrings/t.register_to_translate.c:28
+msgid "Time & Date"
+msgstr ""
+#: ../locale/scriptstrings/t.register_to_translate.c:16
+msgid "Valid end date and time of all map"
+msgstr ""
+#: ../locale/scriptstrings/t.register_to_translate.c:19
+msgid "Time stamp unit"
+msgstr ""
+#: ../locale/scriptstrings/t.register_to_translate.c:20
+msgid "Unit must be set in case of relative timestamps"
+msgstr ""
+#: ../locale/scriptstrings/t.register_to_translate.c:22
+msgid "Time increment, works only in conjunction with start option"
+msgstr ""
+#: ../locale/scriptstrings/t.register_to_translate.c:23
+msgid "Time increment between maps for creation of valid time intervals (format for absolute time: NNN seconds, minutes, hours, days, weeks, months, years; format for relative time is of type integer: 5)"
+msgstr ""
+#: ../locale/scriptstrings/t.register_to_translate.c:25
+msgid "Field separator character of the input file"
+msgstr ""
+#: ../locale/scriptstrings/t.register_to_translate.c:27
+msgid "Create an interval (start and end time) in case an increment and the start time are provided"
+msgstr ""
+#: ../locale/scriptstrings/r.in.aster_to_translate.c:1
+msgid "Georeference, rectify, and import Terra-ASTER imagery and relative DEMs using gdalwarp."
+msgstr ""
+#: ../locale/scriptstrings/r.in.aster_to_translate.c:5
+#: ../imagery/i.albedo/main.c:100 ../imagery/i.aster.toar/main.c:103
+msgid "ASTER"
+msgstr ""
+#: ../locale/scriptstrings/r.in.aster_to_translate.c:7
+msgid "Name of input ASTER image"
+msgstr ""
+#: ../locale/scriptstrings/r.in.aster_to_translate.c:8
+msgid "ASTER imagery processing type (Level 1A, Level 1B, or relative DEM)"
+msgstr ""
+#: ../locale/scriptstrings/r.in.aster_to_translate.c:9
+msgid "List L1A or L1B band to translate (1,2,3n,...), or enter 'all' to translate all bands"
+msgstr ""
+#: ../locale/scriptstrings/r.in.aster_to_translate.c:10
+msgid "Base name for output raster map (band number will be appended to base name)"
+msgstr ""
+#: ../locale/scriptstrings/t.merge_to_translate.c:1
+msgid "Merges several space time datasets into a single space time dataset."
+msgstr ""
+#: ../locale/scriptstrings/t.merge_to_translate.c:4 ../raster/r.patch/main.c:61
+msgid "merge"
+msgstr ""
+#: ../locale/scriptstrings/t.merge_to_translate.c:6
+#: ../locale/scriptstrings/t.remove_to_translate.c:8
+msgid "inputs"
+msgstr ""
+#: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:1
+msgid "Renames a column in the attribute table connected to a given vector map."
+msgstr ""
+#: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:5
+msgid "Old and new name of the column (old,new)"
+msgstr ""
+#: ../locale/scriptstrings/d.correlate_to_translate.c:1
+msgid "Prints a graph of the correlation between raster maps (in pairs)."
+msgstr ""
+#: ../locale/scriptstrings/d.correlate_to_translate.c:6
+msgid "correlation"
+msgstr ""
+#: ../locale/scriptstrings/r.grow_to_translate.c:1
+msgid "Generates a raster map layer with contiguous areas grown by one cell."
+msgstr ""
+#: ../locale/scriptstrings/r.grow_to_translate.c:3
+#: ../raster/r.distance/main.c:40 ../raster/r.grow.distance/main.c:151
+#: ../display/d.geodesic/main.c:47 ../display/d.rhumbline/main.c:45
+#: ../misc/m.cogo/main.c:226 ../misc/m.measure/main.c:48
+#: ../vector/v.distance/main.c:122
+msgid "distance"
+msgstr "távolság"
+#: ../locale/scriptstrings/r.grow_to_translate.c:4
+#: ../raster/r.grow.distance/main.c:152
+msgid "proximity"
+msgstr "közelség"
+#: ../locale/scriptstrings/r.grow_to_translate.c:5
+msgid "Radius is in map units rather than cells"
+msgstr ""
+#: ../locale/scriptstrings/r.grow_to_translate.c:6
+msgid "Radius of buffer in raster cells"
+msgstr ""
+#: ../locale/scriptstrings/r.grow_to_translate.c:7
+#: ../raster/r.grow.distance/main.c:174
+msgid "Metric"
+msgstr ""
+#: ../locale/scriptstrings/r.grow_to_translate.c:8
+msgid "Value to write for input cells which are non-NULL (-1 => NULL)"
+msgstr ""
+#: ../locale/scriptstrings/r.grow_to_translate.c:9
+msgid "Value to write for \"grown\" cells"
+msgstr ""
+#: ../locale/scriptstrings/t.unregister_to_translate.c:1
+msgid "Unregisters raster, vector and raster3d maps from the temporal database or a specific space time dataset."
+msgstr ""
+#: ../locale/scriptstrings/t.unregister_to_translate.c:4
+msgid "unregister"
+msgstr ""
+#: ../locale/scriptstrings/t.unregister_to_translate.c:8
+msgid "Name(s) of existing raster, vector or raster3d map(s) to unregister"
+msgstr ""
+msgid "Removes space time datasets from temporal database."
+msgstr ""
+#: ../locale/scriptstrings/t.remove_to_translate.c:4
+#: ../general/g.remove/main.c:71
+msgid "remove"
+msgstr ""
+#: ../locale/scriptstrings/t.remove_to_translate.c:7
+msgid "Type of the space time dataset, default is strds"
+msgstr ""
+#: ../locale/scriptstrings/t.remove_to_translate.c:10
+msgid "Input file with dataset names, one per line"
+msgstr ""
+#: ../locale/scriptstrings/t.remove_to_translate.c:12
+msgid "Remove all registered maps from the temporal and also from the spatial database"
+msgstr ""
+#: ../locale/scriptstrings/t.remove_to_translate.c:13
+msgid "Force recursive removing"
+msgstr ""
+#: ../locale/scriptstrings/d.rast.edit_to_translate.c:1
+msgid "Edits cell values in a raster map."
+msgstr ""
+#: ../locale/scriptstrings/d.rast.edit_to_translate.c:3
+#: ../vector/v.type/main.c:40 ../vector/v.edit/main.c:56
+msgid "editing"
+msgstr ""
+#: ../locale/scriptstrings/d.rast.edit_to_translate.c:5
+#: ../raster/r.flow/main.c:434
+msgid "Name of input aspect raster map"
+msgstr ""
+#: ../locale/scriptstrings/d.rast.edit_to_translate.c:6
+msgid "Width of display canvas"
+msgstr ""
+#: ../locale/scriptstrings/d.rast.edit_to_translate.c:7
+msgid "Height of display canvas"
+msgstr ""
+#: ../locale/scriptstrings/d.rast.edit_to_translate.c:8
+msgid "Minimum size of each cell"
+msgstr ""
+#: ../locale/scriptstrings/d.rast.edit_to_translate.c:9
+msgid "Maximum number of rows to load"
+msgstr ""
+#: ../locale/scriptstrings/d.rast.edit_to_translate.c:10
+msgid "Maximum number of columns to load"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:1
+msgid "Performs spatio-temporal mapcalc expressions on temporally sampled maps of space time raster datasets."
+msgstr ""
+#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:7
+msgid "Basename for output raster maps"
+msgstr ""
+#: ../locale/scriptstrings/m.proj_to_translate.c:1
+msgid "Converts coordinates from one projection to another (cs2cs frontend)."
+msgstr ""
+#: ../locale/scriptstrings/m.proj_to_translate.c:2 ../misc/m.cogo/main.c:225
+#: ../misc/m.transform/main.c:316 ../misc/m.nviz.image/main.c:50
+#: ../misc/m.nviz.script/main.c:69 ../misc/m.measure/main.c:46
+msgid "miscellaneous"
+msgstr ""
+#: ../locale/scriptstrings/m.proj_to_translate.c:4
+#: ../locale/scriptstrings/i.tasscap_to_translate.c:3
+#: ../raster/r.proj/main.c:146 ../imagery/i.fft/main.c:79
+#: ../imagery/i.pca/main.c:73 ../imagery/i.ifft/main.c:78
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:390
+#: ../misc/m.transform/main.c:317 ../vector/v.proj/main.c:70
+#: ../vector/v.transform/main.c:71
+msgid "transformation"
+msgstr ""
+#: ../locale/scriptstrings/m.proj_to_translate.c:5
+msgid "Input coordinates to reproject"
+msgstr ""
+#: ../locale/scriptstrings/m.proj_to_translate.c:6
+#: ../locale/scriptstrings/m.proj_to_translate.c:9
+#: ../locale/scriptstrings/m.proj_to_translate.c:13
+msgid "Input coordinates"
+msgstr ""
+#: ../locale/scriptstrings/m.proj_to_translate.c:7
+msgid "Name of input coordinate file"
+msgstr ""
+#: ../locale/scriptstrings/m.proj_to_translate.c:8
+#: ../raster/r.reclass/main.c:66 ../raster/r.recode/main.c:61
+#: ../raster/r.in.ascii/main.c:79 ../raster3d/r3.in.ascii/main.c:87
+#: ../general/g.proj/main.c:141 ../general/g.proj/main.c:150
+#: ../db/db.execute/main.c:139 ../db/db.select/main.c:208
+#: ../vector/v.segment/main.c:80 ../vector/v.what/main.c:78
+#: ../vector/v.edit/args.c:95
+msgid "'-' for standard input"
+msgstr ""
+#: ../locale/scriptstrings/m.proj_to_translate.c:10
+msgid "Name for output coordinate file (omit to send to stdout)"
+msgstr ""
+#: ../locale/scriptstrings/m.proj_to_translate.c:12
+msgid "Field separator (format: input[,output])"
+msgstr ""
+#: ../locale/scriptstrings/m.proj_to_translate.c:14
+msgid "Input projection parameters (PROJ.4 style)"
+msgstr ""
+#: ../locale/scriptstrings/m.proj_to_translate.c:15
+#: ../locale/scriptstrings/m.proj_to_translate.c:17
+#: ../locale/scriptstrings/m.proj_to_translate.c:19
+#: ../locale/scriptstrings/m.proj_to_translate.c:21
+msgid "Projections"
+msgstr ""
+#: ../locale/scriptstrings/m.proj_to_translate.c:16
+msgid "Output projection parameters (PROJ.4 style)"
+msgstr ""
+#: ../locale/scriptstrings/m.proj_to_translate.c:18
+msgid "Use LL WGS84 as input and current location as output projection"
+msgstr ""
+#: ../locale/scriptstrings/m.proj_to_translate.c:20
+msgid "Use current location as input and LL WGS84 as output projection"
+msgstr ""
+#: ../locale/scriptstrings/m.proj_to_translate.c:22
+msgid "Output long/lat in decimal degrees, or other projections with many decimal places"
+msgstr ""
+#: ../locale/scriptstrings/m.proj_to_translate.c:24
+msgid "Include input coordinates in output file"
+msgstr ""
+#: ../locale/scriptstrings/m.proj_to_translate.c:26
+msgid "Include column names in output file"
+msgstr ""
+#: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:1
+msgid "Drops a column from the attribute table connected to a given vector map."
+msgstr ""
+#: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:5
+msgid "Name of attribute column(s) to drop"
+msgstr ""
+#: ../locale/scriptstrings/d.out.file_to_translate.c:1
+msgid "Saves the contents of the active display monitor to a graphics file."
+msgstr ""
+#: ../locale/scriptstrings/d.out.file_to_translate.c:4
+#: ../raster/r.topmodel/main.c:72 ../general/g.list/main.c:114
+msgid "Name for output file"
+msgstr ""
+#: ../locale/scriptstrings/d.out.file_to_translate.c:5
+#: ../misc/m.nviz.image/args.c:105
+msgid "Graphics file format"
+msgstr ""
+#: ../locale/scriptstrings/d.out.file_to_translate.c:6
+msgid "Width and height of output image"
+msgstr ""
+#: ../locale/scriptstrings/d.out.file_to_translate.c:7
+msgid "Images"
+msgstr ""
+#: ../locale/scriptstrings/r.plane_to_translate.c:1
+msgid "Creates raster plane map given dip (inclination), aspect (azimuth) and one point."
+msgstr ""
+#: ../locale/scriptstrings/r.plane_to_translate.c:4
+msgid "Dip of plane in degrees"
+msgstr ""
+#: ../locale/scriptstrings/r.plane_to_translate.c:5
+msgid "Azimuth of the plane in degrees"
+msgstr ""
+#: ../locale/scriptstrings/r.plane_to_translate.c:6
+msgid "Easting coordinate of a point on the plane"
+msgstr ""
+#: ../locale/scriptstrings/r.plane_to_translate.c:7
+msgid "Northing coordinate of a point on the plane"
+msgstr ""
+#: ../locale/scriptstrings/r.plane_to_translate.c:8
+msgid "Elevation coordinate of a point on the plane"
+msgstr ""
+#: ../locale/scriptstrings/t.shift_to_translate.c:1
+msgid "Shifts temporally the maps of a space time dataset."
+msgstr ""
+#: ../locale/scriptstrings/t.shift_to_translate.c:4
+msgid "shift"
+msgstr ""
+#: ../locale/scriptstrings/t.shift_to_translate.c:9
+msgid "Shift granularity"
+msgstr ""
+#: ../locale/scriptstrings/t.shift_to_translate.c:10
+msgid "Format absolute time: \"x years, x months, x weeks, x days, x hours, x minutes, x seconds\", relative time is of type integer"
+msgstr ""
+#: ../locale/scriptstrings/r.in.srtm_to_translate.c:1
+msgid "Imports SRTM HGT files into raster map."
+msgstr ""
+#: ../locale/scriptstrings/r.in.srtm_to_translate.c:4
+msgid "Name of SRTM input tile (file without .hgt.zip extension)"
+msgstr ""
+#: ../locale/scriptstrings/r.in.srtm_to_translate.c:5
+msgid "Name for output raster map (default: input tile)"
+msgstr ""
+#: ../locale/scriptstrings/r.in.srtm_to_translate.c:6
+msgid "Input is a 1-arcsec tile (default: 3-arcsec)"
+msgstr ""
+#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:1
+msgid "Performs r3.mapcalc expressions on maps of sampled space time 3D raster datasets."
+msgstr ""
+#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:7
+msgid "r3.mapcalc expression applied to each time step of the sampled data"
+msgstr ""
+#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:10
+#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:10
+#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:10
+msgid "Number of r3.mapcalc processes to run in parallel"
+msgstr ""
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:1
+msgid "Create a 3D raster map from an assemblage of many coordinates using univariate statistics"
+msgstr ""
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:5
+#: ../raster/r.in.lidar/main.c:110 ../raster/r.in.xyz/main.c:165
+#: ../raster3d/r3.in.lidar/main.c:164 ../vector/v.lidar.edgedetection/main.c:76
+#: ../vector/v.out.lidar/main.c:473 ../vector/v.in.lidar/main.c:138
+#: ../vector/v.lidar.correction/main.c:72 ../vector/v.surf.bspline/main.c:94
+#: ../vector/v.lidar.growing/main.c:76 ../vector/v.decimate/main.c:124
+#: ../vector/v.outlier/main.c:74
+msgid "LIDAR"
+msgstr ""
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:9
+#: ../raster/r.in.lidar/main.c:114 ../raster/r.in.xyz/main.c:163
+#: ../raster3d/r3.in.lidar/main.c:168
+msgid "binning"
+msgstr ""
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:10
+#: ../raster/r.in.lidar/main.c:306 ../raster/r.in.xyz/main.c:328
+#: ../raster3d/r3.in.lidar/main.c:303
+msgid "Scan data file for extent then exit"
+msgstr ""
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:11
+#: ../raster/r.in.lidar/main.c:311 ../raster/r.in.xyz/main.c:335
+#: ../raster3d/r3.in.lidar/main.c:307
+msgid "In scan mode, print using shell script style"
+msgstr ""
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:12
+#: ../raster/r.in.xyz/main.c:341
+msgid "Ignore broken lines"
+msgstr ""
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:13
+msgid "ASCII file containing input data"
+msgstr ""
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:15
+#: ../raster/r.in.lidar/main.c:139 ../raster/r.in.xyz/main.c:179
+msgid "Statistic to use for raster values"
+msgstr ""
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:16
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:32
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:34
+#: ../raster/r.in.lidar/main.c:143 ../raster/r.in.lidar/main.c:235
+#: ../raster/r.in.lidar/main.c:245 ../raster/r.in.xyz/main.c:183
+#: ../raster/r.in.xyz/main.c:315 ../raster/r.in.xyz/main.c:324
+msgid "Statistic"
+msgstr ""
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:17
+msgid "Storage type for resultant raster map"
+msgstr ""
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:19
+#: ../raster/r.in.xyz/main.c:221
+msgid "Column number of x coordinates in input file (first column is 1)"
+msgstr ""
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:21
+#: ../raster/r.in.xyz/main.c:229
+msgid "Column number of y coordinates in input file"
+msgstr ""
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:23
+msgid "Column number of z coordinates in input file"
+msgstr ""
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:25
+#: ../raster/r.in.xyz/main.c:237
+msgid "Column number of data values in input file"
+msgstr ""
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:26
+msgid "If not given or set to 0, the data points' z-values are used"
+msgstr ""
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:28
+msgid "Filter range for value column data (min,max)"
+msgstr ""
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:29
+msgid "Scaling factor to apply to value column data"
+msgstr ""
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:30
+#: ../raster/r.in.lidar/main.c:225 ../raster/r.in.xyz/main.c:305
+msgid "Percent of map to keep in memory"
+msgstr ""
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:31
+#: ../raster/r.in.lidar/main.c:234
+msgid "pth percentile of the values"
+msgstr ""
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:33
+#: ../raster/r.in.lidar/main.c:244 ../raster/r.in.xyz/main.c:323
+msgid "Discard <trim> percent of the smallest and <trim> percent of the largest observations"
+msgstr ""
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:35
+msgid "Number of parallel processes to launch"
+msgstr ""
+#: ../locale/scriptstrings/v.pack_to_translate.c:1
+msgid "Exports a vector map as GRASS GIS specific archive file"
+msgstr ""
+#: ../locale/scriptstrings/v.pack_to_translate.c:5
+msgid "Name of vector map to pack up"
+msgstr ""
+#: ../locale/scriptstrings/i.tasscap_to_translate.c:1
+msgid "Performs Tasseled Cap (Kauth Thomas) transformation."
+msgstr ""
+#: ../locale/scriptstrings/i.tasscap_to_translate.c:4
+#: ../imagery/i.albedo/main.c:99 ../imagery/i.landsat.acca/main.c:109
+#: ../imagery/i.landsat.toar/main.c:77
+msgid "Landsat"
+msgstr ""
+#: ../locale/scriptstrings/i.tasscap_to_translate.c:5
+#: ../imagery/i.albedo/main.c:102 ../imagery/i.modis.qc/main.c:174
+msgid "MODIS"
+msgstr ""
+#: ../locale/scriptstrings/i.tasscap_to_translate.c:6
+msgid "Tasseled Cap transformation"
+msgstr ""
+#: ../locale/scriptstrings/i.tasscap_to_translate.c:7
+msgid "For Landsat4-7: bands 1, 2, 3, 4, 5, 7; for Landsat8: bands 2, 3, 4, 5, 6, 7; for MODIS: bands 1, 2, 3, 4, 5, 6, 7"
+msgstr ""
+#: ../locale/scriptstrings/i.tasscap_to_translate.c:8
+#: ../imagery/i.pca/main.c:85
+msgid "Name for output basename raster map(s)"
+msgstr ""
+#: ../locale/scriptstrings/i.tasscap_to_translate.c:9
+msgid "Satellite sensor"
+msgstr ""
+#: ../locale/scriptstrings/i.tasscap_to_translate.c:10
+msgid "landsat4_tm;Use transformation rules for Landsat 4 TM;landsat5_tm;Use transformation rules for Landsat 5 TM;landsat7_etm;Use transformation rules for Landsat 7 ETM;landsat8_oli;Use transformation rules for Landsat 8 OLI;modis;Use transformation rules for MODIS"
+msgstr ""
+#: ../locale/scriptstrings/d.rast.leg_to_translate.c:1
+msgid "Displays a raster map and its legend on a graphics window"
+msgstr ""
+#: ../locale/scriptstrings/d.rast.leg_to_translate.c:3
+#: ../display/d.vect.thematic/main.c:86 ../display/d.barscale/main.c:64
+#: ../display/d.grid/main.c:54 ../display/d.legend.vect/main.c:51
+#: ../display/d.graph/main.c:59 ../display/d.legend/main.c:79
+#: ../display/d.linegraph/main.c:232 ../display/d.vect.chart/main.c:64
+#: ../display/d.text/main.c:140 ../display/d.northarrow/main.c:47
+#: ../display/d.title/main.c:50
+msgid "cartography"
+msgstr ""
+#: ../locale/scriptstrings/d.rast.leg_to_translate.c:4
+#: ../display/d.vect.thematic/main.c:88 ../display/d.legend.vect/main.c:53
+#: ../display/d.legend/main.c:80
+msgid "legend"
+msgstr ""
+#: ../locale/scriptstrings/d.rast.leg_to_translate.c:5
+#: ../display/d.legend/main.c:277
+msgid "Flip legend"
+msgstr ""
+#: ../locale/scriptstrings/d.rast.leg_to_translate.c:6
+msgid "Omit entries with missing label"
+msgstr ""
+#: ../locale/scriptstrings/d.rast.leg_to_translate.c:7
+msgid "Name of raster map to display"
+msgstr ""
+#: ../locale/scriptstrings/d.rast.leg_to_translate.c:8
+#: ../display/d.legend/main.c:272
+msgid "Draw smooth gradient"
+msgstr ""
+#: ../locale/scriptstrings/d.rast.leg_to_translate.c:9
+msgid "Number of lines to appear in the legend"
+msgstr ""
+#: ../locale/scriptstrings/d.rast.leg_to_translate.c:10
+msgid "Name of input raster map to generate legend from"
+msgstr ""
+#: ../locale/scriptstrings/v.db.droptable_to_translate.c:1
+msgid "Removes existing attribute table of a vector map."
+msgstr ""
+#: ../locale/scriptstrings/v.db.droptable_to_translate.c:5
+msgid "Force removal (required for actual deletion of table)"
+msgstr ""
+#: ../locale/scriptstrings/v.db.droptable_to_translate.c:6
+msgid "Table name (default: vector map name)"
+msgstr ""
+#: ../locale/scriptstrings/db.univar_to_translate.c:1
+msgid "Calculates univariate statistics on selected table column."
+msgstr ""
+#: ../locale/scriptstrings/t.rast.export_to_translate.c:1
+msgid "Exports space time raster dataset."
+msgstr ""
+#: ../locale/scriptstrings/t.rast.export_to_translate.c:6
+msgid "Name of a space time raster dataset archive"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.export_to_translate.c:9
+msgid "The export format of a single raster map"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.export_to_translate.c:10
+msgid "Supported are GTiff, AAIGrid via r.out.gdal and the GRASS package format of r.pack"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.export_to_translate.c:11
+#: ../raster/r.out.gdal/main.c:201
+msgid "Data type"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.export_to_translate.c:12
+msgid "Supported only for GTiff"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.export_to_translate.c:13
+#: ../raster/r.out.gdal/main.c:211
+msgid "Creation option(s) to pass to the output format driver"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.export_to_translate.c:14
+#: ../raster/r.out.gdal/main.c:213
+msgid "In the form of \"NAME=VALUE\", separate multiple entries with a comma"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.export_to_translate.c:15
+#: ../raster/r.out.gdal/main.c:221
+msgid "Metadata key(s) and value(s) to include"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.export_to_translate.c:16
+#: ../raster/r.out.gdal/main.c:223
+msgid "In the form of \"META-TAG=VALUE\", separate multiple entries with a comma. Not supported by all output format drivers."
+msgstr ""
+#: ../locale/scriptstrings/t.rast.export_to_translate.c:17
+#: ../raster/r.out.gdal/main.c:233
+msgid "Assign a specified nodata value to output bands"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.export_to_translate.c:18
+#: ../raster/r.out.gdal/main.c:235
+msgid "If given, the nodata value is always written to metadata even if there are no NULL cells in the input band (enhances output compatibility)."
+msgstr ""
+msgid "Apply temporal and spatial operations on space time 3D raster datasets using temporal 3D raster algebra."
+msgstr ""
+#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:7
+msgid "Algebraic expression for temporal and spatial analysis of space time 3D raster datasets"
+msgstr ""
+#: ../locale/scriptstrings/db.dropcolumn_to_translate.c:1
+msgid "Drops a column from selected attribute table."
+msgstr ""
+msgid "Extracts a subset of a space time 3D raster dataset."
+msgstr ""
+#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:7
+msgid "The r3.mapcalc expression assigned to all extracted 3D raster maps"
+msgstr ""
+#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:8
+msgid "Basename of the new generated 3D raster maps"
+msgstr ""
+#: ../ps/ps.map/r_colortable.c:65 ../ps/ps.map/r_vlegend.c:49
+#: ../ps/ps.map/r_info.c:48
+msgid "illegal where request"
+msgstr ""
+#: ../ps/ps.map/r_colortable.c:73 ../ps/ps.map/r_colortable.c:89
+#: ../ps/ps.map/ps_outline.c:100
+msgid "illegal width request"
+msgstr ""
+#: ../ps/ps.map/r_colortable.c:81
+msgid "illegal height request"
+msgstr ""
+#: ../ps/ps.map/r_colortable.c:106
+msgid "illegal range request"
+msgstr ""
+#: ../ps/ps.map/r_colortable.c:122
+msgid "illegal columns request"
+msgstr ""
+#: ../ps/ps.map/r_colortable.c:141
+msgid "Unsupported color request (colortable)"
+msgstr ""
+#: ../ps/ps.map/r_colortable.c:143
+msgid "illegal color request (colortable)"
+msgstr ""
+#: ../ps/ps.map/r_colortable.c:170
+msgid "illegal colortable sub-request"
+msgstr ""
+#: ../ps/ps.map/r_colortable.c:181
+msgid "No raster selected for colortable!"
+msgstr ""
+#: ../ps/ps.map/getgrid.c:61 ../ps/ps.map/getgrid.c:85
+#: ../ps/ps.map/getgrid.c:171 ../ps/ps.map/getgrid.c:195
+#: ../ps/ps.map/r_header.c:65 ../ps/ps.map/ps_outline.c:87
+#: ../ps/ps.map/r_info.c:67
+msgid "Unsupported color request"
+msgstr ""
+#: ../ps/ps.map/getgrid.c:63 ../ps/ps.map/getgrid.c:87
+#: ../ps/ps.map/getgrid.c:173 ../ps/ps.map/getgrid.c:197
+#: ../ps/ps.map/r_instructions.c:149 ../ps/ps.map/r_instructions.c:464
+#: ../ps/ps.map/r_header.c:67 ../ps/ps.map/ps_outline.c:89
+#: ../ps/ps.map/r_info.c:69
+msgid "illegal color request"
+msgstr ""
+#: ../ps/ps.map/getgrid.c:95 ../ps/ps.map/getgrid.c:206
+msgid "illegal numbers request"
+msgstr ""
+#: ../ps/ps.map/getgrid.c:126 ../ps/ps.map/getgrid.c:234
+msgid "illegal grid width request"
+msgstr ""
+#: ../ps/ps.map/getgrid.c:132
+msgid "illegal request (grid)"
+msgstr ""
+#: ../ps/ps.map/getgrid.c:240
+msgid "illegal request (geogrid)"
+msgstr ""
+#: ../ps/ps.map/makeprocs.c:29
+#, c-format
+msgid "Unable to open prolog <%s>"
+msgstr ""
+#: ../ps/ps.map/r_instructions.c:62
+msgid "Data exist after final 'end' instruction!"
+msgstr ""
+#: ../ps/ps.map/r_instructions.c:80
+msgid "no file specified"
+msgstr ""
+#: ../ps/ps.map/r_instructions.c:84
+msgid "unable to open"
+msgstr ""
+#: ../ps/ps.map/r_instructions.c:115
+msgid "illegal maploc request"
+msgstr ""
+#: ../ps/ps.map/r_instructions.c:129 ../ps/ps.map/main.c:220
+msgid "illegal copies request"
+msgstr ""
+#: ../ps/ps.map/r_instructions.c:144 ../ps/ps.map/r_instructions.c:340
+msgid "no raster map selected yet"
+msgstr ""
+#: ../ps/ps.map/r_instructions.c:160
+msgid "illegal value list"
+msgstr ""
+#: ../ps/ps.map/r_instructions.c:196
+msgid "scalebar is not appropriate for this projection"
+msgstr ""
+#: ../ps/ps.map/r_instructions.c:204
+msgid "Bad scalebar length"
+msgstr ""
+#: ../ps/ps.map/r_instructions.c:220
+msgid "illegal text request"
+msgstr ""
+#: ../ps/ps.map/r_instructions.c:234
+msgid "illegal point request"
+msgstr ""
+#: ../ps/ps.map/r_instructions.c:248
+msgid "illegal eps request"
+msgstr ""
+#: ../ps/ps.map/r_instructions.c:265
+msgid "illegal line request"
+msgstr ""
+#: ../ps/ps.map/r_instructions.c:282
+msgid "illegal rectangle request"
+msgstr ""
+#: ../ps/ps.map/r_instructions.c:293
+msgid "illegal comments request"
+msgstr ""
+#: ../ps/ps.map/r_instructions.c:309
+msgid "illegal scale request"
+msgstr ""
+#: ../ps/ps.map/r_instructions.c:369
+msgid "group not found"
+msgstr ""
+#: ../ps/ps.map/r_instructions.c:411
+msgid "illegal grid spacing"
+msgstr ""
+#: ../ps/ps.map/r_instructions.c:422
+msgid "geogrid is not available for this projection"
+msgstr ""
+#: ../ps/ps.map/r_instructions.c:432
+msgid "illegal geo-grid spacing"
+msgstr ""
+#: ../ps/ps.map/r_instructions.c:469
+msgid "illegal request"
+msgstr ""
+#: ../ps/ps.map/main.c:93
+msgid "postscript"
+msgstr ""
+#: ../ps/ps.map/main.c:94
+msgid "printing"
+msgstr ""
+#: ../ps/ps.map/main.c:95
+msgid "Produces hardcopy PostScript map output."
+msgstr ""
+#: ../ps/ps.map/main.c:99
+msgid "Rotate plot 90 degrees"
+msgstr ""
+#: ../ps/ps.map/main.c:105
+msgid "List paper formats (name width height left right top bottom(margin))"
+msgstr ""
+#: ../ps/ps.map/main.c:107 ../ps/ps.map/main.c:120
+msgid "Utility"
+msgstr ""
+#: ../ps/ps.map/main.c:112
+msgid "Create EPS (Encapsulated PostScript) instead of PostScript file"
+msgstr ""
+#: ../ps/ps.map/main.c:118
+msgid "Describe map-box's position on the page and exit (inches from top-left of paper)"
+msgstr ""
+#: ../ps/ps.map/main.c:123
+msgid "File containing mapping instructions"
+msgstr ""
+#: ../ps/ps.map/main.c:124
+msgid "Use '-' to enter instructions from keyboard)"
+msgstr ""
+#: ../ps/ps.map/main.c:127
+msgid "Name for PostScript output file"
+msgstr ""
+#: ../ps/ps.map/main.c:133
+msgid "Number of copies to print"
+msgstr ""
+#: ../ps/ps.map/main.c:205
+#, c-format
+msgid "Unable to open file '%s': %s"
+msgstr ""
+#: ../ps/ps.map/main.c:213 ../ps/ps.map/main.c:232
+#: ../vector/v.univar/main.c:147 ../vector/v.to.db/parse.c:143
+#: ../vector/v.to.db/parse.c:146
+#, c-format
+msgid ""
+"Required parameter <%s> not set:\n"
+"\t(%s)"
+msgstr ""
+#: ../ps/ps.map/main.c:273
+#, c-format
+msgid "PostScript file '%s' successfully written."
+msgstr ""
+#: ../ps/ps.map/do_scalebar.c:192
+msgid "meters"
+msgstr ""
+#: ../ps/ps.map/do_scalebar.c:194
+msgid "kilometers"
+msgstr ""
+#: ../ps/ps.map/do_scalebar.c:196
+msgid "feet"
+msgstr ""
+#: ../ps/ps.map/do_scalebar.c:198
+msgid "miles"
+msgstr ""
+#: ../ps/ps.map/do_scalebar.c:200
+msgid "nautical miles"
+msgstr ""
+#: ../ps/ps.map/map_setup.c:82
+#, c-format
+msgid "Scale set to %s"
+msgstr ""
+#: ../ps/ps.map/do_masking.c:23
+msgid "Can't open temporary PostScript mask file."
+msgstr ""
+#: ../ps/ps.map/read_cfg.c:64
+#, c-format
+msgid "Paper '%s' not found, using defaults"
+msgstr ""
+#: ../ps/ps.map/do_geogrid.c:86 ../ps/ps.map/do_geogrid.c:91
+#: ../ps/ps.map/do_geogrid.c:115 ../ps/ps.map/do_geogrid.c:120
+#: ../ps/ps.map/do_geogrid.c:189 ../ps/ps.map/do_geogrid.c:230
+#: ../ps/ps.map/do_geogrid.c:306 ../ps/ps.map/do_geogrid.c:322
+#: ../ps/ps.map/do_geogrid.c:339 ../ps/ps.map/do_geogrid.c:356
+#: ../ps/ps.map/do_geogrid.c:412 ../ps/ps.map/do_geogrid.c:418
+#: ../ps/ps.map/do_geogrid.c:422 ../ps/ps.map/do_geogrid.c:430
+#: ../ps/ps.map/do_geogrid.c:434 ../raster/r.horizon/main.c:846
+#: ../raster/r.horizon/main.c:864 ../raster/r.latlong/main.c:133
+#: ../display/d.grid/plot.c:287 ../display/d.grid/plot.c:293
+#: ../display/d.grid/plot.c:334 ../display/d.grid/plot.c:340
+#: ../display/d.grid/plot.c:427 ../display/d.grid/plot.c:433
+#: ../display/d.grid/plot.c:485 ../display/d.grid/plot.c:491
+#: ../display/d.grid/plot.c:635 ../display/d.grid/plot.c:651
+#: ../display/d.grid/plot.c:668 ../display/d.grid/plot.c:685
+msgid "Error in pj_do_proj"
+msgstr ""
+#: ../ps/ps.map/do_geogrid.c:272 ../raster/r.sun/main.c:788
+#: ../raster/r.horizon/main.c:538 ../display/d.grid/plot.c:554
+#: ../display/d.where/main.c:113 ../general/g.region/printwindow.c:257
+#: ../general/g.region/printwindow.c:481 ../general/g.region/printwindow.c:550
+msgid "Can't get projection key values of current location"
+msgstr ""
+#: ../ps/ps.map/do_geogrid.c:278 ../raster/r.sun/main.c:798
+#: ../raster/r.horizon/main.c:548 ../raster/r.latlong/main.c:114
+#: ../display/d.grid/plot.c:561 ../display/d.grid/plot.c:588
+#: ../display/d.where/main.c:120 ../display/d.where/main.c:146
+msgid "Unable to set up lat/long projection parameters"
+msgstr ""
+#: ../ps/ps.map/ps_clrtbl.c:35 ../ps/ps.map/ps_fclrtbl.c:46
+#, c-format
+msgid "Creating color table for <%s in %s>..."
+msgstr ""
+#: ../ps/ps.map/ps_clrtbl.c:39 ../display/d.histogram/main.c:174
+#, c-format
+msgid "Category file for <%s> not available"
+msgstr ""
+#: ../ps/ps.map/ps_clrtbl.c:44 ../ps/ps.map/ps_fclrtbl.c:69
+msgid "Unable to read colors for colorbar"
+msgstr ""
+#: ../ps/ps.map/ps_clrtbl.c:54
+msgid "Your cats/ file is invalid. A cats/ file with categories and labels is required for 'colortable' when using categorical legends; see the r.category help page. Colortable creation has been skipped."
+msgstr ""
+#: ../ps/ps.map/ps_clrtbl.c:69 ../ps/ps.map/ps_fclrtbl.c:97
+#: ../ps/ps.map/ps_fclrtbl.c:102
+msgid "Colorbar y location beyond page margins. Adjusting."
+msgstr ""
+#: ../ps/ps.map/ps_clrtbl.c:75 ../ps/ps.map/ps_fclrtbl.c:108
+#: ../ps/ps.map/ps_fclrtbl.c:113
+msgid "Colorbar x location beyond page margins. Adjusting."
+msgstr ""
+#: ../ps/ps.map/r_header.c:77
+msgid "illegal header sub-request"
+msgstr ""
+#: ../ps/ps.map/ps_raster.c:42
+msgid "Can't create temporary PostScript mask file."
+msgstr ""
+#: ../ps/ps.map/ps_raster.c:102 ../raster/r.series.accumulate/main.c:248
+#: ../raster/r.series.accumulate/main.c:273
+#: ../raster/r.series.accumulate/main.c:284
+#: ../raster/r.series.accumulate/main.c:292
+#: ../raster/r.series.accumulate/main.c:300
+#: ../raster/r.grow.distance/main.c:276 ../raster/r.surf.idw/main.c:713
+#: ../raster/r.out.mpeg/main.c:286
+#, c-format
+msgid "Reading raster map <%s>..."
+msgstr ""
+#: ../ps/ps.map/ps_raster.c:105
+#, c-format
+msgid "Reading raster maps in group <%s>..."
+msgstr ""
+#: ../ps/ps.map/scale.c:136
+msgid "PSmap: do_scale(): shouldn't happen"
+msgstr ""
+#: ../ps/ps.map/ps_outline.c:43
+#, c-format
+msgid "Outlining areas in raster map <%s in %s> ..."
+msgstr ""
+#: ../ps/ps.map/ps_outline.c:107
+msgid "illegal outline sub-request"
+msgstr ""
+#: ../ps/ps.map/ps_vpoints.c:71 ../ps/ps.map/ps_vlines.c:56
+#: ../ps/ps.map/ps_vareas.c:161
+msgid "Cannot load data from table"
+msgstr ""
+#: ../ps/ps.map/ps_vpoints.c:87 ../ps/ps.map/do_plt.c:169
+msgid "Cannot read symbol, using default icon"
+msgstr ""
+#: ../ps/ps.map/ps_vpoints.c:160 ../ps/ps.map/ps_vpoints.c:171
+#: ../ps/ps.map/ps_vpoints.c:195 ../ps/ps.map/ps_vpoints.c:236
+#: ../ps/ps.map/ps_vpoints.c:246 ../ps/ps.map/ps_vlines.c:119
+#: ../ps/ps.map/ps_vareas.c:102
+#, c-format
+msgid "No record for category [%d]"
+msgstr ""
+#: ../ps/ps.map/ps_vpoints.c:177
+#, c-format
+msgid "Attribute is of invalid size [%.3f] for category [%d]"
+msgstr ""
+#: ../ps/ps.map/ps_vpoints.c:201 ../ps/ps.map/ps_vlines.c:125
+#: ../ps/ps.map/ps_vareas.c:108
+#, c-format
+msgid "Invalid RGB color definition in column <%s> for category [%d]"
+msgstr ""
+#: ../ps/ps.map/ps_vlines.c:84 ../ps/ps.map/ps_vareas.c:67
+#: ../ps/ps.map/ps_vareas.c:78
+msgid "Read error in vector map"
+msgstr ""
+#: ../ps/ps.map/r_plt.c:173
+msgid "Can't open eps file"
+msgstr ""
+#: ../ps/ps.map/do_plt.c:38
+msgid "Reading point/line file ..."
+msgstr ""
+#: ../ps/ps.map/do_vectors.c:33
+#, c-format
+msgid "Reading vector map <%s in %s> ..."
+msgstr ""
+#: ../ps/ps.map/do_vectors.c:136
+#, c-format
+msgid "Reading vector points file <%s in %s> ..."
+msgstr ""
+#: ../ps/ps.map/eps.c:18
+#, c-format
+msgid "Can't open eps file <%s>"
+msgstr ""
+#: ../ps/ps.map/eps.c:37
+#, c-format
+msgid "Bounding box in eps file <%s> was not found"
+msgstr ""
+#: ../ps/ps.map/ps_fclrtbl.c:51
+msgid "Range information not available (run r.support)"
+msgstr ""
+#: ../ps/ps.map/ps_fclrtbl.c:64
+msgid "A floating point colortable must contain a range of values"
+msgstr ""
+#: ../ps/ps.map/do_psfiles.c:20
+#, c-format
+msgid "Reading PostScript include file <%s> ..."
+msgstr ""
+#: ../ps/ps.map/r_vlegend.c:86 ../ps/ps.map/r_info.c:93
+msgid "illegal border color request"
+msgstr ""
+#: ../ps/ps.map/r_vlegend.c:97
+msgid "illegal vlegend sub-request"
+msgstr ""
+#: ../ps/ps.map/r_group.c:29
+msgid "Can't get group information"
+msgstr ""
+#: ../ps/ps.map/catval.c:48 ../ps/ps.map/catval.c:110 ../ps/ps.map/catval.c:176
+#: ../vector/v.class/main.c:111 ../vector/v.label.sa/labels.c:75
+#: ../vector/v.vol.rst/user1.c:95 ../vector/v.label/main.c:274
+msgid "Unable to get layer info for vector map"
+msgstr ""
+#: ../ps/ps.map/catval.c:53 ../ps/ps.map/catval.c:115 ../ps/ps.map/catval.c:181
+#: ../doc/vector/v.example/main.c:137 ../raster/r.volume/main.c:243
+#: ../raster/r.random/random.c:73 ../raster/r.contour/main.c:172
+#: ../raster/r.to.vect/main.c:188 ../display/d.vect.thematic/plot1.c:111
+#: ../display/d.vect.chart/plot.c:44 ../display/d.vect/shape.c:44
+#: ../display/d.vect/attr.c:43 ../raster3d/r3.flow/main.c:46
+#: ../misc/m.nviz.image/vector.c:293 ../vector/v.out.vtk/writeVTK.c:649
+#: ../vector/v.mkgrid/main.c:278 ../vector/v.what.rast3/main.c:126
+#: ../vector/v.to.rast/support.c:109 ../vector/v.to.rast/support.c:284
+#: ../vector/v.to.rast/support.c:523 ../vector/v.to.rast/vect2rast.c:60
+#: ../vector/v.out.ogr/main.c:690 ../vector/v.kcv/main.c:126
+#: ../vector/v.surf.idw/read_sites.c:55 ../vector/v.class/main.c:117
+#: ../vector/v.label.sa/labels.c:78 ../vector/v.net.distance/main.c:279
+#: ../vector/v.random/main.c:240 ../vector/v.db.connect/main.c:223
+#: ../vector/v.db.connect/main.c:331 ../vector/v.to.rast3/main.c:84
+#: ../vector/v.reclass/main.c:133 ../vector/v.surf.rst/main.c:620
+#: ../vector/v.surf.bspline/main.c:384 ../vector/v.surf.bspline/crosscorr.c:123
+#: ../vector/v.db.select/main.c:177 ../vector/v.net.allpairs/main.c:166
+#: ../vector/v.in.dwg/main.c:213 ../vector/v.buffer/main.c:431
+#: ../vector/v.select/copy_tabs.c:82 ../vector/v.profile/main.c:426
+#: ../vector/v.profile/main.c:580 ../vector/v.extrude/main.c:229
+#: ../vector/v.out.svg/main.c:159 ../vector/v.in.ogr/main.c:1132
+#: ../vector/v.in.ogr/main.c:1178 ../vector/v.patch/main.c:156
+#: ../vector/v.patch/main.c:188 ../vector/v.patch/main.c:309
+#: ../vector/v.patch/main.c:391 ../vector/v.net.path/path.c:96
+#: ../vector/v.overlay/main.c:246 ../vector/v.overlay/main.c:413
+#: ../vector/v.net.iso/main.c:376 ../vector/v.to.3d/trans2.c:55
+#: ../vector/v.to.3d/trans3.c:57 ../vector/v.what.rast/main.c:144
+#: ../vector/v.net.flow/main.c:169 ../vector/v.normal/main.c:122
+#: ../vector/v.sample/main.c:179 ../vector/v.distance/main.c:520
+#: ../vector/v.distance/main.c:555 ../vector/v.distance/main.c:601
+#: ../vector/v.distance/main.c:1340 ../vector/v.distance/main.c:1359
+#: ../vector/v.net.timetable/main.c:93 ../vector/v.in.db/main.c:164
+#: ../vector/v.in.db/main.c:302 ../vector/v.in.ascii/main.c:348
+#: ../vector/v.to.points/main.c:177 ../vector/v.colors/scan_attr.c:29
+#: ../vector/v.colors/read_rgb.c:28 ../vector/v.colors/write_rgb.c:25
+#: ../vector/v.vol.rst/user1.c:99 ../vector/v.vol.rst/main.c:600
+#: ../vector/v.net.components/main.c:180
+#: ../vector/v.colors.out/make_colors.c:36 ../vector/v.label/main.c:278
+#: ../vector/v.edit/select.c:516 ../vector/v.net.centrality/main.c:246
+#: ../vector/v.info/print.c:147 ../vector/v.out.postgis/table.c:34
+#: ../vector/v.in.dxf/write_vect.c:211 ../vector/v.extract/main.c:263
+#: ../vector/v.lrs/v.lrs.create/main.c:296
+#: ../vector/v.lrs/v.lrs.create/main.c:305 ../vector/v.net.alloc/main.c:316
+#: ../vector/v.transform/trans_digit.c:41 ../vector/v.to.db/update.c:46
+#: ../vector/v.to.db/query.c:89
+#, c-format
+msgid "Unable to open database <%s> by driver <%s>"
+msgstr ""
+#: ../ps/ps.map/catval.c:63
+msgid "Column type not supported (must be string)"
+msgstr ""
+#: ../ps/ps.map/catval.c:66 ../ps/ps.map/catval.c:131 ../ps/ps.map/catval.c:198
+#: ../vector/v.surf.idw/read_sites.c:68 ../vector/v.class/main.c:132
+#: ../vector/v.out.lidar/main.c:132 ../vector/v.out.lidar/main.c:167
+#: ../vector/v.to.rast3/main.c:95 ../vector/v.surf.bspline/main.c:398
+#: ../vector/v.normal/main.c:134 ../vector/v.sample/main.c:152
+#: ../vector/v.univar/main.c:366 ../vector/v.vol.rst/user1.c:112
+msgid "Unable to select data from table"
+msgstr ""
+#: ../ps/ps.map/catval.c:128
+msgid "Size column type must be numeric"
+msgstr ""
+#: ../ps/ps.map/catval.c:195
+msgid "Rotation column type must be numeric"
+msgstr ""
+#: ../ps/ps.map/r_info.c:81
+msgid "illegal bgcolor request"
+msgstr ""
+#: ../ps/ps.map/r_info.c:103
+msgid "illegal mapinfo sub-request"
+msgstr ""
+#: ../ps/ps.map/do_labels.c:44
+#, c-format
+msgid "Can't open label file <%s> in mapset <%s>"
+msgstr ""
+#: ../ps/ps.map/do_labels.c:48
+#, c-format
+msgid "Reading labels file <%s in %s> ..."
+msgstr ""
+#: ../ps/ps.map/do_labels.c:66
+#, c-format
+msgid "Can't open temporary label file <%s>"
+msgstr ""
+#: ../ps/ps.map/do_labels.c:69
+msgid "Reading text file ..."
+msgstr ""
+#: ../ps/ps.map/do_labels.c:162
+msgid "Text labels: 'fontsize' given so ignoring 'size'"
+msgstr ""
+#: ../doc/raster/r.example/main.c:84 ../doc/vector/v.example/main.c:51
+msgid "keyword2"
+msgstr ""
+#: ../doc/raster/r.example/main.c:85 ../doc/vector/v.example/main.c:52
+msgid "keyword3"
+msgstr ""
+#: ../doc/raster/r.example/main.c:86
+msgid "My first raster module"
+msgstr ""
+#: ../doc/raster/r.example/main.c:105 ../raster/r.walk/main.c:463
+#: ../raster/r.walk/main.c:468 ../raster/r.walk/main.c:808
+#: ../raster/r.colors/edit_colors.c:393 ../raster/r.cost/main.c:377
+#: ../raster/r.cost/main.c:668 ../raster/r.reclass/main.c:79
+#: ../raster/r.univar/r.univar_main.c:234 ../raster/r.report/parse.c:273
+#: ../raster/r.distance/parse.c:72 ../raster/r.distance/parse.c:81
+#: ../raster/r.spread/main.c:439 ../raster/r.spread/main.c:442
+#: ../raster/r.spread/main.c:445 ../raster/r.spread/main.c:449
+#: ../raster/r.spread/main.c:452 ../raster/r.spread/main.c:455
+#: ../raster/r.buffer/main.c:112 ../raster/r.stream.extract/main.c:173
+#: ../raster/r.stream.extract/main.c:177 ../raster/r.stream.extract/main.c:182
+#: ../raster/r.cross/main.c:105 ../raster/r.mapcalc/map.c:519
+#: ../raster/r.mapcalc/map.c:813 ../raster/r.mapcalc/map3.c:710
+#: ../raster/r.compress/main.c:124 ../raster/r.compress/main.c:304
+#: ../raster/r.kappa/main.c:150 ../raster/r.kappa/stats.c:33
+#: ../raster/r.kappa/stats.c:38 ../raster/r.coin/main.c:121
+#: ../raster/r.coin/main.c:123 ../raster/r.fill.stats/main.c:1028
+#: ../raster/r.tile/main.c:86 ../raster/r.info/main.c:110
+#: ../raster/r.geomorphon/memory.c:14 ../raster/r.category/main.c:119
+#: ../raster/r.category/main.c:140 ../raster/r.ros/main.c:368
+#: ../raster/r.ros/main.c:379 ../raster/r.ros/main.c:384
+#: ../raster/r.ros/main.c:389 ../raster/r.ros/main.c:394
+#: ../raster/r.ros/main.c:408 ../raster/r.ros/main.c:412
+#: ../raster/r.ros/main.c:427 ../raster/r.ros/main.c:431
+#: ../raster/r.ros/main.c:442 ../raster/r.null/main.c:128
+#: ../raster/r.flow/io.c:65 ../raster/r.flow/io.c:242
+#: ../raster/r.carve/main.c:165 ../raster/r.sim/simlib/output.c:363
+#: ../raster/r.sim/simlib/output.c:372 ../raster/r.sim/simlib/output.c:403
+#: ../raster/r.sim/simlib/output.c:412 ../raster/r.sim/simlib/output.c:458
+#: ../raster/r.sim/simlib/output.c:475 ../raster/r.sim/simlib/output.c:497
+#: ../raster/r.sim/simlib/output.c:541 ../raster/r.sim/simlib/output.c:583
+#: ../raster/r.sim/simlib/output.c:755 ../general/g.region/main.c:442
+#: ../general/g.region/main.c:779 ../general/g.region/main.c:787
+#: ../imagery/i.segment/parse_args.c:199 ../imagery/i.gensig/parse.c:38
+#: ../imagery/i.gensigset/parse.c:44 ../imagery/i.pca/main.c:139
+#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:197
+#: ../misc/m.nviz.image/surface.c:50 ../misc/m.nviz.image/surface.c:107
+#: ../vector/v.colors/main.c:312 ../vector/v.vol.rst/main.c:615
+#: ../scripts/v.rast.stats/v.rast.stats.py:128 ../scripts/r.rgb/r.rgb.py:60
+#: ../scripts/r.mask/r.mask.py:131 ../scripts/r.grow/r.grow.py:123
+#: ../scripts/d.polar/d.polar.py:62 ../scripts/r.pack/r.pack.py:74
+#: ../scripts/r.buffer.lowmem/r.buffer.lowmem.py:87
+#: ../scripts/d.correlate/d.correlate.py:50
+#: ../scripts/d.rast.leg/d.rast.leg.py:99
+#: ../scripts/d.rast.leg/d.rast.leg.py:103
+#: ../scripts/r.reclass.area/r.reclass.area.py:103
+#: ../scripts/r.reclass.area/r.reclass.area.py:213
+#: ../scripts/r.fillnulls/r.fillnulls.py:149
+#, c-format, python-format
+msgid "Raster map <%s> not found"
+msgstr ""
+#: ../doc/vector/v.example/main.c:53
+msgid "My first vector module"
+msgstr ""
+#: ../doc/vector/v.example/main.c:75 ../raster/r.walk/main.c:438
+#: ../raster/r.cost/main.c:352 ../raster/r.carve/main.c:158
+#: ../display/d.extract/main.c:98 ../general/g.region/main.c:492
+#: ../misc/m.nviz.image/vector.c:84 ../vector/v.lidar.edgedetection/main.c:180
+#: ../vector/v.clean/test/topocheck.c:63
+#: ../vector/v.lidar.correction/main.c:157 ../vector/v.surf.bspline/main.c:263
+#: ../vector/v.surf.bspline/main.c:332 ../vector/v.lidar.growing/main.c:126
+#: ../vector/v.profile/main.c:359 ../vector/v.profile/main.c:363
+#: ../vector/v.colors/main.c:238 ../vector/v.outlier/main.c:176
+#: ../vector/v.edit/main.c:155 ../vector/v.vect.stats/main.c:263
+#: ../vector/v.vect.stats/main.c:271 ../vector/v.lrs/v.lrs.label/main.c:268
+#: ../vector/v.lrs/v.lrs.where/main.c:127
+#: ../vector/v.lrs/v.lrs.where/main.c:136
+#: ../vector/v.lrs/v.lrs.segment/main.c:140
+#: ../vector/v.lrs/v.lrs.create/main.c:251
+#: ../vector/v.lrs/v.lrs.create/main.c:260 ../scripts/r.mask/r.mask.py:150
+#: ../scripts/v.pack/v.pack.py:65 ../scripts/v.dissolve/v.dissolve.py:68
+#: ../scripts/v.db.univar/v.db.univar.py:75 ../scripts/v.report/v.report.py:74
+msgid "Vector map <%s> not found"
+msgstr ""
+#: ../doc/vector/v.example/main.c:81 ../vector/v.cluster/main.c:146
+#: ../vector/v.profile/main.c:366
+msgid "Unable to set predetermined vector open level"
+msgstr ""
+#: ../doc/vector/v.example/main.c:87 ../raster/r.path/main.c:291
+#: ../raster/r.walk/main.c:702 ../raster/r.walk/main.c:765
+#: ../raster/r.cost/main.c:562 ../raster/r.cost/main.c:625
+#: ../raster/r.random/support.c:67 ../raster/r.drain/main.c:272
+#: ../raster/r.what/main.c:250 ../raster/r.carve/main.c:162
+#: ../raster/r.region/main.c:176 ../raster/r.sim/simlib/observation_points.c:41
+#: ../display/d.extract/main.c:103 ../display/d.vect.chart/main.c:246
+#: ../display/d.path/main.c:185 ../raster3d/r3.flow/main.c:411
+#: ../general/manage/lister/vector.c:32 ../general/g.region/main.c:502
+#: ../misc/m.nviz.image/vector.c:280 ../vector/v.what.rast3/main.c:114
+#: ../vector/v.to.rast/support.c:100 ../vector/v.to.rast/support.c:272
+#: ../vector/v.to.rast/support.c:510 ../vector/v.to.rast/vect2rast.c:39
+#: ../vector/v.lidar.edgedetection/main.c:186 ../vector/v.out.ogr/main.c:136
+#: ../vector/v.surf.idw/read_sites.c:29 ../vector/v.class/main.c:102
+#: ../vector/v.clean/test/topocheck.c:67 ../vector/v.clean/test/topocheck.c:87
+#: ../vector/v.clean/main.c:283 ../vector/v.label.sa/labels.c:58
+#: ../vector/v.net.distance/main.c:192 ../vector/v.random/main.c:201
+#: ../vector/v.support/main.c:134 ../vector/v.out.dxf/main.c:80
+#: ../vector/v.out.lidar/main.c:609 ../vector/v.proj/main.c:237
+#: ../vector/v.db.connect/main.c:154 ../vector/v.to.rast3/main.c:73
+#: ../vector/v.out.ascii/main.c:87 ../vector/v.out.ascii/main.c:94
+#: ../vector/v.cluster/main.c:149 ../vector/v.build.polylines/main.c:151
+#: ../vector/v.lidar.correction/main.c:161 ../vector/v.reclass/main.c:113
+#: ../vector/v.segment/main.c:108 ../vector/v.surf.rst/main.c:561
+#: ../vector/v.surf.rst/main.c:665 ../vector/v.db.select/main.c:164
+#: ../vector/v.net.allpairs/main.c:130 ../vector/v.drape/main.c:143
+#: ../vector/v.buffer/main.c:337 ../vector/v.lidar.growing/main.c:138
+#: ../vector/v.lidar.growing/main.c:142 ../vector/v.select/main.c:108
+#: ../vector/v.profile/main.c:370 ../vector/v.profile/main.c:394
+#: ../vector/v.extrude/main.c:190 ../vector/v.hull/main.c:87
+#: ../vector/v.out.svg/main.c:139 ../vector/v.net.connectivity/main.c:130
+#: ../vector/v.patch/main.c:129 ../vector/v.patch/main.c:147
+#: ../vector/v.patch/main.c:177 ../vector/v.patch/main.c:274
+#: ../vector/v.patch/main.c:355 ../vector/v.net.path/main.c:158
+#: ../vector/v.overlay/main.c:188 ../vector/v.perturb/main.c:148
+#: ../vector/v.perturb/main.c:173 ../vector/v.net.iso/main.c:243
+#: ../vector/v.to.3d/main.c:72 ../vector/v.type/main.c:131
+#: ../vector/v.what.rast/main.c:131 ../vector/v.net.spanningtree/main.c:101
+#: ../vector/v.net.steiner/main.c:432 ../vector/v.net.flow/main.c:143
+#: ../vector/v.delaunay/main.c:120 ../vector/v.normal/main.c:110
+#: ../vector/v.sample/main.c:124 ../vector/v.rectify/main.c:150
+#: ../vector/v.qcount/main.c:101 ../vector/v.univar/main.c:158
+#: ../vector/v.distance/main.c:364 ../vector/v.distance/main.c:386
+#: ../vector/v.net.timetable/main.c:353 ../vector/v.net.visibility/main.c:73
+#: ../vector/v.net.visibility/main.c:82 ../vector/v.out.pov/main.c:97
+#: ../vector/v.to.points/main.c:130 ../vector/v.colors/main.c:262
+#: ../vector/v.build/main.c:118 ../vector/v.build/main.c:128
+#: ../vector/v.voronoi/main.c:196 ../vector/v.net.bridge/main.c:118
+#: ../vector/v.neighbors/main.c:88 ../vector/v.split/main.c:172
+#: ../vector/v.vol.rst/main.c:560 ../vector/v.net.components/main.c:148
+#: ../vector/v.decimate/main.c:272 ../vector/v.net.salesman/main.c:250
+#: ../vector/v.colors.out/scan_cats.c:20
+#: ../vector/v.colors.out/make_colors.c:23 ../vector/v.kernel/main.c:318
+#: ../vector/v.kernel/main.c:331 ../vector/v.label/main.c:268
+#: ../vector/v.edit/main.c:170 ../vector/v.edit/main.c:243
+#: ../vector/v.net.centrality/main.c:209 ../vector/v.info/main.c:61
+#: ../vector/v.parallel/main.c:148 ../vector/v.out.postgis/main.c:100
+#: ../vector/v.vect.stats/main.c:267 ../vector/v.vect.stats/main.c:278
+#: ../vector/v.extract/main.c:191 ../vector/v.lrs/v.lrs.label/main.c:272
+#: ../vector/v.lrs/v.lrs.where/main.c:131
+#: ../vector/v.lrs/v.lrs.where/main.c:140
+#: ../vector/v.lrs/v.lrs.segment/main.c:144
+#: ../vector/v.lrs/v.lrs.create/main.c:254
+#: ../vector/v.lrs/v.lrs.create/main.c:263 ../vector/v.net/main.c:68
+#: ../vector/v.net/main.c:92 ../vector/v.net.alloc/main.c:185
+#: ../vector/v.transform/main.c:197 ../vector/v.generalize/main.c:327
+#: ../vector/v.external/main.c:228 ../vector/v.to.db/main.c:59
+#, c-format
+msgid "Unable to open vector map <%s>"
+msgstr ""
+#: ../doc/vector/v.example/main.c:100 ../raster/r.path/main.c:226
+#: ../raster/r.volume/main.c:155 ../raster/r.random/random.c:63
+#: ../raster/r.contour/main.c:156 ../raster/r.stream.extract/close.c:38
+#: ../raster/r.to.vect/main.c:157 ../raster/r.drain/main.c:201
+#: ../raster/r.resamp.bspline/main.c:495 ../raster/r.flow/io.c:178
+#: ../raster/r.carve/vect.c:32 ../raster/r.sim/simlib/output.c:38
+#: ../raster/r.sim/simlib/output.c:44 ../display/d.extract/main.c:106
+#: ../raster3d/r3.flow/main.c:396 ../vector/v.mkgrid/main.c:264
+#: ../vector/v.lidar.edgedetection/main.c:251 ../vector/v.clean/main.c:288
+#: ../vector/v.clean/main.c:295 ../vector/v.net.distance/main.c:198
+#: ../vector/v.random/main.c:229 ../vector/v.proj/main.c:380
+#: ../vector/v.cluster/main.c:209 ../vector/v.in.lidar/main.c:555
+#: ../vector/v.build.polylines/main.c:156
+#: ../vector/v.lidar.correction/main.c:215
+#: ../vector/v.lidar.correction/main.c:221 ../vector/v.reclass/main.c:117
+#: ../vector/v.segment/main.c:114 ../vector/v.surf.rst/main.c:600
+#: ../vector/v.surf.rst/main.c:603 ../vector/v.surf.rst/main.c:769
+#: ../vector/v.surf.bspline/main.c:353 ../vector/v.net.allpairs/main.c:136
+#: ../vector/v.in.dwg/main.c:200 ../vector/v.drape/main.c:158
+#: ../vector/v.buffer/main.c:405 ../vector/v.select/main.c:125
+#: ../vector/v.profile/main.c:537 ../vector/v.extrude/main.c:196
+#: ../vector/v.in.region/main.c:75 ../vector/v.hull/main.c:121
+#: ../vector/v.net.connectivity/main.c:136 ../vector/v.in.ogr/main.c:844
+#: ../vector/v.patch/main.c:283 ../vector/v.patch/main.c:288
+#: ../vector/v.net.path/main.c:167 ../vector/v.overlay/main.c:220
+#: ../vector/v.perturb/main.c:154 ../vector/v.net.iso/main.c:356
+#: ../vector/v.to.3d/main.c:87 ../vector/v.net.spanningtree/main.c:107
+#: ../vector/v.net.steiner/main.c:607 ../vector/v.net.flow/main.c:149
+#: ../vector/v.net.flow/main.c:155 ../vector/v.delaunay/main.c:126
+#: ../vector/v.sample/main.c:162 ../vector/v.rectify/main.c:216
+#: ../vector/v.qcount/main.c:127 ../vector/v.distance/main.c:410
+#: ../vector/v.net.timetable/main.c:359 ../vector/v.in.db/main.c:151
+#: ../vector/v.in.ascii/main.c:251 ../vector/v.net.visibility/main.c:77
+#: ../vector/v.to.points/main.c:138 ../vector/v.build/main.c:154
+#: ../vector/v.voronoi/main.c:215 ../vector/v.net.bridge/main.c:124
+#: ../vector/v.split/main.c:177 ../vector/v.vol.rst/main.c:580
+#: ../vector/v.vol.rst/main.c:583 ../vector/v.net.components/main.c:154
+#: ../vector/v.decimate/main.c:391 ../vector/v.outlier/main.c:229
+#: ../vector/v.outlier/main.c:234 ../vector/v.outlier/main.c:240
+#: ../vector/v.net.salesman/main.c:551 ../vector/v.kernel/main.c:337
+#: ../vector/v.edit/main.c:107 ../vector/v.edit/main.c:122
+#: ../vector/v.net.centrality/main.c:215 ../vector/v.parallel/main.c:153
+#: ../vector/v.in.dxf/main.c:146 ../vector/v.extract/main.c:346
+#: ../vector/v.lrs/v.lrs.label/main.c:276
+#: ../vector/v.lrs/v.lrs.segment/main.c:148
+#: ../vector/v.lrs/v.lrs.create/main.c:267
+#: ../vector/v.lrs/v.lrs.create/main.c:273 ../vector/v.net.alloc/main.c:298
+#: ../vector/v.transform/main.c:265 ../vector/v.generalize/main.c:338
+#: ../vector/v.external/main.c:180 ../scripts/v.what.strds/v.what.strds.py:217
+msgid "Unable to create vector map <%s>"
+msgstr ""
+#: ../doc/vector/v.example/main.c:109 ../display/d.vect.thematic/plot1.c:105
+#: ../display/d.vect.chart/plot.c:38 ../display/d.vect/shape.c:38
+#: ../vector/v.what.rast3/main.c:120 ../vector/v.to.rast/support.c:104
+#: ../vector/v.to.rast/support.c:276 ../vector/v.to.rast/support.c:515
+#: ../vector/v.surf.bspline/crosscorr.c:114 ../vector/v.buffer/main.c:426
+#: ../vector/v.extrude/main.c:224 ../vector/v.overlay/main.c:398
+#: ../vector/v.what.rast/main.c:138 ../vector/v.univar/main.c:229
+#: ../vector/v.distance/main.c:549 ../vector/v.colors/scan_attr.c:24
+#: ../vector/v.colors/read_rgb.c:23 ../vector/v.colors/write_rgb.c:20
+#: ../vector/v.edit/select.c:502 ../vector/v.vect.stats/main.c:330
+#: ../vector/v.vect.stats/main.c:404 ../vector/v.generalize/misc.c:170
+#, c-format
+msgid "Database connection not defined for layer %d"
+msgstr ""
+#: ../doc/vector/v.example/main.c:129 ../raster/r.stream.extract/close.c:178
+#: ../display/d.vect.thematic/main.c:294 ../display/d.vect/opt.c:147
+#: ../db/db.databases/main.c:48 ../db/db.columns/main.c:51
+#: ../db/db.describe/main.c:56 ../db/db.execute/main.c:70
+#: ../db/db.select/main.c:75 ../db/db.tables/main.c:45
+#: ../db/db.dropdb/main.c:42 ../db/db.createdb/main.c:42
+#: ../vector/v.out.vtk/writeVTK.c:644 ../vector/v.db.connect/main.c:217
+#: ../vector/v.db.connect/main.c:283 ../vector/v.profile/main.c:420
+#: ../vector/v.profile/main.c:575 ../vector/v.out.svg/main.c:152
+#: ../vector/v.edit/select.c:509
+#, c-format
+msgid "Unable to start driver <%s>"
+msgstr ""
+#: ../doc/vector/v.example/main.c:142 ../db/db.columns/main.c:62
+#: ../db/db.describe/main.c:67 ../vector/v.out.vtk/writeVTK.c:655
+#: ../vector/v.out.ogr/main.c:695 ../vector/v.random/main.c:273
+#: ../vector/v.db.connect/main.c:228 ../vector/v.reclass/main.c:193
+#: ../vector/v.profile/main.c:433 ../vector/v.profile/main.c:586
+#: ../vector/v.out.svg/main.c:165 ../vector/v.patch/main.c:164
+#: ../vector/v.patch/main.c:204 ../vector/v.in.ascii/main.c:435
+#: ../vector/v.info/print.c:152 ../vector/v.out.postgis/table.c:41
+#: ../scripts/db.univar/db.univar.py:112
+msgid "Unable to describe table <%s>"
+msgstr ""
+#: ../doc/vector/v.example/main.c:175
+#, c-format
+msgid "Unable to get attribute data for cat %d"
+msgstr ""
+#: ../doc/vector/v.example/main.c:184
+#, c-format
+msgid "Error while retrieving database record for cat %d"
+msgstr ""
+#: ../doc/vector/v.example/main.c:217
+#, c-format
+msgid "Unable to copy attribute table to vector map <%s>"
+msgstr ""
+#: ../raster/r.surf.area/main.c:77 ../raster/r.contour/main.c:88
+#: ../raster/r.random.surface/main.c:58 ../raster/r.surf.random/main.c:37
+#: ../raster/r.surf.fractal/main.c:39 ../raster/r.surf.idw/main.c:105
+#: ../raster/r.surf.contour/main.c:61 ../raster/r.fill.stats/main.c:776
+#: ../raster/r.resamp.bspline/main.c:80 ../raster/r.surf.gauss/main.c:39
+#: ../vector/v.surf.idw/main.c:88 ../vector/v.surf.rst/main.c:148
+#: ../vector/v.surf.bspline/main.c:92 ../vector/v.vol.rst/main.c:237
+msgid "surface"
+msgstr ""
+#: ../raster/r.surf.area/main.c:79
+msgid "area estimation"
+msgstr ""
+#: ../raster/r.surf.area/main.c:80
+msgid "Prints estimation of surface area for raster map."
+msgstr ""
+#: ../raster/r.surf.area/main.c:89
+msgid "Vertical scale"
+msgstr ""
+#: ../raster/r.surf.area/main.c:93
+msgid "Output units"
+msgstr ""
+#: ../raster/r.surf.area/main.c:94
+msgid "Default: square map units"
+msgstr ""
+#: ../raster/r.surf.area/main.c:102
+#, c-format
+msgid "Output in '%s'"
+msgstr ""
+#: ../raster/r.surf.area/main.c:106
+msgid "Output in 'square map units'"
+msgstr ""
+#: ../raster/r.surf.area/main.c:153
+msgid "Null value area ignored in calculation:"
+msgstr ""
+#: ../raster/r.surf.area/main.c:155
+msgid "Plan area used in calculation:"
+msgstr ""
+#: ../raster/r.surf.area/main.c:158
+msgid "Surface area calculation(low, high, avg):"
+msgstr ""
+#: ../raster/r.surf.area/main.c:163
+msgid "Current region plan area:"
+msgstr ""
+#: ../raster/r.surf.area/main.c:165
+msgid "Estimated region Surface Area:"
+msgstr ""
+#: ../raster/r.path/main.c:141
+msgid "Traces paths from starting points following input directions."
+msgstr ""
+#: ../raster/r.path/main.c:144
+msgid "Name of input direction"
+msgstr ""
+#: ../raster/r.path/main.c:146
+msgid "Direction in degrees CCW from east, or bitmask encoded"
+msgstr ""
+#: ../raster/r.path/main.c:151
+msgid "Format of the input direction map"
+msgstr ""
+#: ../raster/r.path/main.c:157
+msgid "auto-detect direction format"
+msgstr ""
+#: ../raster/r.path/main.c:158
+msgid "degrees CCW from East"
+msgstr ""
+#: ../raster/r.path/main.c:159
+msgid "degrees CCW from East divided by 45 (e.g. r.watershed directions)"
+msgstr ""
+#: ../raster/r.path/main.c:160
+msgid "bitmask encoded directions (e.g. r.cost -b)"
+msgstr ""
+#: ../raster/r.path/main.c:166
+msgid "Name of input raster values to be used for output"
+msgstr ""
+#: ../raster/r.path/main.c:172
+msgid "Name for output raster path map"
+msgstr ""
+#: ../raster/r.path/main.c:177
+msgid "Name for output vector path map"
+msgstr ""
+#: ../raster/r.path/main.c:211
+msgid "No output requested"
+msgstr ""
+#: ../raster/r.path/main.c:234 ../raster/r.drain/main.c:213
+msgid "Specify just one of the -c, -a and -n flags"
+msgstr ""
+#: ../raster/r.path/main.c:262 ../raster/r.drain/main.c:244
+#, c-format
+msgid "Starting point %d is outside the current region"
+msgstr ""
+#: ../raster/r.path/main.c:293 ../raster/r.walk/main.c:704
+#: ../raster/r.cost/main.c:564 ../raster/r.drain/main.c:274
+#, c-format
+msgid "Reading vector map <%s> with start points..."
+msgstr ""
+#: ../raster/r.path/main.c:307 ../raster/r.walk/main.c:717
+#: ../raster/r.walk/main.c:777 ../raster/r.cost/main.c:577
+#: ../raster/r.cost/main.c:637 ../raster/r.to.vect/main.c:289
+#: ../raster/r.drain/main.c:287 ../display/d.vect.thematic/display.c:75
+#: ../display/d.vect/vert.c:27 ../display/d.vect/lines.c:143
+#: ../display/d.vect/label.c:44 ../display/d.vect/zcoor.c:38
+#: ../display/d.vect/dir.c:30 ../display/d.vect/topo.c:52
+#: ../display/d.vect/attr.c:51 ../vector/v.label.sa/labels.c:141
+#: ../vector/v.out.lidar/main.c:732 ../vector/v.perturb/main.c:182
+#: ../vector/v.to.3d/trans2.c:84 ../vector/v.to.3d/trans3.c:85
+#: ../vector/v.what.rast/main.c:213 ../vector/v.colors/scan_z.c:36
+#: ../vector/v.colors/scan_cats.c:24 ../vector/v.vol.rst/user1.c:140
+#: ../vector/v.decimate/main.c:406 ../vector/v.colors.out/scan_cats.c:32
+#: ../vector/v.label/main.c:293 ../vector/v.info/level1.c:38
+msgid "Unable to read vector map"
+msgstr ""
+#: ../raster/r.path/main.c:341 ../raster/r.drain/main.c:319
+#, c-format
+msgid "Starting vector map <%s> contains no points in the current region"
+msgstr ""
+#: ../raster/r.path/main.c:349
+msgid "No start point(s) specified"
+msgstr ""
+#: ../raster/r.path/main.c:370 ../raster/r.path/main.c:432
+#: ../raster/r.path/main.c:449
+msgid "Unable to write to tempfile"
+msgstr ""
+#: ../raster/r.path/main.c:378 ../raster/r.info/main.c:134
+msgid "Unable to read range file"
+msgstr ""
+#: ../raster/r.path/main.c:381
+#, c-format
+msgid "Invalid directions map <%s>"
+msgstr ""
+#: ../raster/r.path/main.c:386
+msgid "Directional degrees can not be > 360"
+msgstr ""
+#: ../raster/r.path/main.c:391
+msgid "Directional degrees divided by 45 can not be > 8"
+msgstr ""
+#: ../raster/r.path/main.c:396
+#, c-format
+msgid "Bitmask encoded directions can not be > %d"
+msgstr ""
+#: ../raster/r.path/main.c:402
+msgid "Input direction format assumed to be degrees CCW from East divided by 45"
+msgstr ""
+#: ../raster/r.path/main.c:406
+msgid "Input direction format assumed to be bitmask encoded without Knight's move"
+msgstr ""
+#: ../raster/r.path/main.c:410
+msgid "Input direction format assumed to be degrees CCW from East"
+msgstr ""
+#: ../raster/r.path/main.c:414
+msgid "Input direction format assumed to be bitmask encoded with Knight's move"
+msgstr ""
+#: ../raster/r.path/main.c:417
+#, c-format
+msgid "Unable to detect format of input direction map <%s>"
+msgstr ""
+#: ../raster/r.path/main.c:420
+#, c-format
+msgid "Invalid directions format '%s'"
+msgstr ""
+#: ../raster/r.path/main.c:478 ../vector/v.buffer/main.c:414
+#: ../vector/v.in.ogr/main.c:855 ../vector/v.overlay/main.c:227
+msgid "Unable to create temporary vector map"
+msgstr ""
+#: ../raster/r.path/main.c:484 ../raster/r.path/main.c:500
+#, c-format
+msgid "No path at row %d, col %d"
+msgstr ""
+#: ../raster/r.path/main.c:489 ../vector/v.overlay/line_area.c:256
+#: ../vector/v.overlay/area_area.c:109
+msgid "Breaking lines..."
+msgstr ""
+#: ../raster/r.path/main.c:542 ../raster/r.path/main.c:572
+#: ../raster/r.in.lidar/main.c:760 ../raster/r.drain/main.c:471
+msgid "Writing output raster map..."
+msgstr ""
+#: ../raster/r.path/main.c:625
+msgid "Unable to increase point list"
+msgstr ""
+#: ../raster/r.path/main.c:725 ../raster/r.path/main.c:756
+#: ../raster/r.path/main.c:877 ../raster/r.path/main.c:985
+#: ../raster/r.path/main.c:1011 ../raster/r.path/main.c:1108
+#: ../raster/r.clump/clump.c:99 ../raster/r.clump/clump.c:151
+#: ../raster/r.clump/minsize.c:152 ../raster/r.clump/minsize.c:253
+#: ../raster/r.clump/minsize.c:287 ../raster/r.clump/minsize.c:293
+#: ../raster/r.clump/minsize.c:424 ../raster/r.clump/minsize.c:447
+#: ../raster/r.clump/minsize.c:518 ../imagery/i.segment/cluster.c:431
+msgid "Unable to read from temp file"
+msgstr ""
+#: ../raster/r.path/main.c:811
+#, c-format
+msgid "No path from row %d, col %d"
+msgstr ""
+#: ../raster/r.path/main.c:825
+#, c-format
+msgid "Invalid direction %d"
+msgstr ""
+#: ../raster/r.path/main.c:914
+msgid "Path is leaving the current region"
+msgstr ""
+#: ../raster/r.profile/main.c:54 ../raster/r.transect/main.c:104
+#: ../display/d.profile/main.c:192 ../raster3d/r3.cross.rast/main.c:229
+#: ../vector/v.profile/main.c:154
+msgid "profile"
+msgstr ""
+#: ../raster/r.profile/main.c:55 ../raster/r.transect/main.c:105
+#: ../vector/v.profile/main.c:155
+msgid "transect"
+msgstr ""
+#: ../raster/r.profile/main.c:57
+msgid "Outputs the raster map layer values lying on user-defined line(s)."
+msgstr ""
+#: ../raster/r.profile/main.c:65 ../raster/r.horizon/main.c:304
+msgid "Name of file for output (use output=- for stdout)"
+msgstr ""
+#: ../raster/r.profile/main.c:70 ../display/d.profile/main.c:203
+msgid "Profile coordinate pairs"
+msgstr ""
+#: ../raster/r.profile/main.c:76
+msgid "Name of input file containing coordinate pairs"
+msgstr ""
+#: ../raster/r.profile/main.c:78
+msgid "Use instead of the 'coordinates' option. \"-\" reads from stdin."
+msgstr ""
+#: ../raster/r.profile/main.c:86
+msgid "Resolution along profile (default = current region resolution)"
+msgstr ""
+#: ../raster/r.profile/main.c:94 ../raster/r.transect/main.c:127
+msgid "Output easting and northing in first two columns of four column output"
+msgstr ""
+#: ../raster/r.profile/main.c:99
+msgid "Output RRR:GGG:BBB color values for each profile point"
+msgstr ""
+#: ../raster/r.profile/main.c:104
+msgid "If units are not specified, current location units are used. Meters are used by default in geographic (latlon) locations."
+msgstr ""
+#: ../raster/r.profile/main.c:118
+msgid "Either use profile option or coordinate_file option, but not both"
+msgstr ""
+#: ../raster/r.profile/main.c:145
+#, c-format
+msgid "Illegal resolution %g [%s]"
+msgstr ""
+#: ../raster/r.profile/main.c:152
+#, c-format
+msgid "Using resolution: %g [%s]"
+msgstr ""
+#: ../raster/r.profile/main.c:176 ../raster/r.out.ppm3/main.c:133
+#: ../raster/r.recode/main.c:90 ../raster/r.horizon/main.c:385
+#: ../raster/r.in.lidar/main.c:651 ../raster/r.category/main.c:173
+#: ../raster/r.out.ascii/main.c:157 ../display/d.mon/stop.c:66
+#: ../general/g.pnmcomp/main.c:242 ../general/g.pnmcomp/main.c:259
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:348
+#: ../misc/m.transform/main.c:276 ../misc/m.nviz.script/main.c:202
+#: ../vector/v.out.vtk/main.c:173 ../vector/v.out.ascii/main.c:125
+#: ../vector/v.profile/main.c:330 ../vector/v.edit/main.c:81
+#: ../vector/v.net/main.c:100
+#, c-format
+msgid "Unable to open file <%s>"
+msgstr ""
+#: ../raster/r.profile/main.c:183
+msgid "Output columns:"
+msgstr ""
+#: ../raster/r.profile/main.c:186
+#, c-format
+msgid "Easting, Northing, Along track dist. [%s], Elevation"
+msgstr ""
+#: ../raster/r.profile/main.c:188
+#, c-format
+msgid "Along track dist. [%s], Elevation"
+msgstr ""
+#: ../raster/r.profile/main.c:190
+msgid " RGB color"
+msgstr ""
+#: ../raster/r.profile/main.c:201
+#, c-format
+msgid "Could not open <%s>"
+msgstr ""
+#: ../raster/r.profile/main.c:208
+#, c-format
+msgid "Invalid coordinates %s %s"
+msgstr ""
+#: ../raster/r.profile/main.c:279
+#, c-format
+msgid "Approx. transect length: %f [%s]"
+msgstr ""
+#: ../raster/r.profile/main.c:282
+msgid "Endpoint coordinates are outside of current region settings"
+msgstr ""
+#: ../raster/r.profile/input.c:30 ../raster/r.profile/input.c:47
+#: ../raster/r.profile/input.c:60
+msgid "One coordinate pair per line, please"
+msgstr ""
+#: ../raster/r.sun/main.c:252 ../raster/r.horizon/main.c:181
+#: ../raster/r.sunhours/main.c:73 ../raster/r.sunmask/main.c:117
+msgid "solar"
+msgstr ""
+#: ../raster/r.sun/main.c:253 ../raster/r.sunhours/main.c:74
+msgid "sun energy"
+msgstr ""
+#: ../raster/r.sun/main.c:254 ../raster/r.sunmask/main.c:119
+msgid "shadow"
+msgstr ""
+#: ../raster/r.sun/main.c:255
+msgid "Solar irradiance and irradiation model."
+msgstr ""
+#: ../raster/r.sun/main.c:257
+msgid "Computes direct (beam), diffuse and reflected solar irradiation raster maps for given day, latitude, surface and atmospheric conditions. Solar parameters (e.g. sunrise, sunset times, declination, extraterrestrial irradiance, daylight length) are saved in the map history file. Alternatively, a local time can be specified to compute solar incidence angle and/or irradiance raster maps. The shadowing effect of the topography is optionally incorporated."
+msgstr ""
+#: ../raster/r.sun/main.c:271
+msgid "Name of the input elevation raster map [meters]"
+msgstr ""
+#: ../raster/r.sun/main.c:280
+msgid "Name of the input aspect map (terrain aspect or azimuth of the solar panel) [decimal degrees]"
+msgstr ""
+#: ../raster/r.sun/main.c:289
+msgid "A single value of the orientation (aspect), 270 is south"
+msgstr ""
+#: ../raster/r.sun/main.c:298
+msgid "Name of the input slope raster map (terrain slope or solar panel inclination) [decimal degrees]"
+msgstr ""
+#: ../raster/r.sun/main.c:306
+msgid "A single value of inclination (slope)"
+msgstr ""
+#: ../raster/r.sun/main.c:315
+msgid "Name of the Linke atmospheric turbidity coefficient input raster map [-]"
+msgstr ""
+#: ../raster/r.sun/main.c:324
+msgid "A single value of the Linke atmospheric turbidity coefficient [-]"
+msgstr ""
+#: ../raster/r.sun/main.c:333
+msgid "Name of the ground albedo coefficient input raster map [-]"
+msgstr ""
+#: ../raster/r.sun/main.c:342
+msgid "A single value of the ground albedo coefficient [-]"
+msgstr ""
+#: ../raster/r.sun/main.c:351
+msgid "Name of input raster map containing latitudes [decimal degrees]"
+msgstr ""
+#: ../raster/r.sun/main.c:360
+msgid "Name of input raster map containing longitudes [decimal degrees]"
+msgstr ""
+#: ../raster/r.sun/main.c:369
+msgid "Name of real-sky beam radiation coefficient (thick cloud) input raster map [0-1]"
+msgstr ""
+#: ../raster/r.sun/main.c:378
+msgid "Name of real-sky diffuse radiation coefficient (haze) input raster map [0-1]"
+msgstr ""
+#: ../raster/r.sun/main.c:385
+msgid "The horizon information input map basename"
+msgstr ""
+#: ../raster/r.sun/main.c:393 ../raster/r.horizon/main.c:211
+msgid "Angle step size for multidirectional horizon [degrees]"
+msgstr ""
+#: ../raster/r.sun/main.c:402
+msgid "Output incidence angle raster map (mode 1 only)"
+msgstr ""
+#: ../raster/r.sun/main.c:411
+msgid "Output beam irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2.day-1] (mode 2)"
+msgstr ""
+#: ../raster/r.sun/main.c:420
+msgid "Output diffuse irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2.day-1] (mode 2)"
+msgstr ""
+#: ../raster/r.sun/main.c:429
+msgid "Output ground reflected irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2.day-1] (mode 2)"
+msgstr ""
+#: ../raster/r.sun/main.c:438
+msgid "Output global (total) irradiance/irradiation [W.m-2] (mode 1) or irradiance/irradiation raster map [Wh.m-2.day-1] (mode 2)"
+msgstr ""
+#: ../raster/r.sun/main.c:447
+msgid "Output insolation time raster map [h] (mode 2 only)"
+msgstr ""
+#: ../raster/r.sun/main.c:454
+msgid "No. of day of the year (1-365)"
+msgstr ""
+#: ../raster/r.sun/main.c:456 ../raster/r.sun/main.c:465
+#: ../raster/r.sun/main.c:482 ../raster/r.sun/main.c:529
+#: ../raster/r.sunhours/main.c:103 ../raster/r.sunhours/main.c:112
+#: ../raster/r.sunhours/main.c:120 ../raster/r.sunhours/main.c:129
+#: ../raster/r.sunhours/main.c:138 ../raster/r.sunhours/main.c:147
+#: ../raster/r.sunmask/main.c:153 ../raster/r.sunmask/main.c:161
+#: ../raster/r.sunmask/main.c:169 ../raster/r.sunmask/main.c:177
+#: ../raster/r.sunmask/main.c:185 ../raster/r.sunmask/main.c:194
+#: ../raster/r.sunmask/main.c:203 ../imagery/i.landsat.toar/main.c:206
+msgid "Time"
+msgstr ""
+#: ../raster/r.sun/main.c:464
+msgid "Time step when computing all-day radiation sums [decimal hours]"
+msgstr ""
+#: ../raster/r.sun/main.c:472
+msgid "Declination value (overriding the internally computed value) [radians]"
+msgstr ""
+#: ../raster/r.sun/main.c:480
+msgid "Local (solar) time (to be set for mode 1 only) [decimal hours]"
+msgstr ""
+#: ../raster/r.sun/main.c:491
+msgid "Number of threads which will be used for parallel computing"
+msgstr ""
+#: ../raster/r.sun/main.c:513 ../raster/r.horizon/main.c:296
+msgid "Sampling distance step coefficient (0.5-1.5)"
+msgstr ""
+#: ../raster/r.sun/main.c:521
+msgid "Read the input files in this number of chunks"
+msgstr ""
+#: ../raster/r.sun/main.c:528
+msgid "Civil time zone value, if none, the time will be local solar time"
+msgstr ""
+#: ../raster/r.sun/main.c:534
+msgid "Do not incorporate the shadowing effect of terrain"
+msgstr ""
+#: ../raster/r.sun/main.c:539
+msgid "Use the low-memory version of the program"
+msgstr ""
+#: ../raster/r.sun/main.c:578
+#, c-format
+msgid "<%d> is not valid number of threads. Number of threads will be set to <%d>"
+msgstr ""
+#: ../raster/r.sun/main.c:587
+#, c-format
+msgid "Number of threads <%d>"
+msgstr ""
+#: ../raster/r.sun/main.c:594
+msgid "You must give the longitude raster if you use civil time"
+msgstr ""
+#: ../raster/r.sun/main.c:597
+msgid "Error reading civil time zone value"
+msgstr ""
+#: ../raster/r.sun/main.c:600
+msgid "Invalid civil time zone value"
+msgstr ""
+#: ../raster/r.sun/main.c:625
+msgid "insol_time and incidout are incompatible options"
+msgstr ""
+#: ../raster/r.sun/main.c:630
+msgid "Error reading time step size"
+msgstr ""
+#: ../raster/r.sun/main.c:632
+msgid "Invalid time step size"
+msgstr ""
+#: ../raster/r.sun/main.c:636
+msgid "Error reading horizon step size"
+msgstr ""
+#: ../raster/r.sun/main.c:641
+msgid "The horizon step size must be greater than 0."
+msgstr ""
+#: ../raster/r.sun/main.c:644
+msgid "If you use the horizon option you must also set the 'horizonstep' parameter."
+msgstr ""
+#: ../raster/r.sun/main.c:650
+msgid "Time and insol_time are incompatible options"
+msgstr ""
+#: ../raster/r.sun/main.c:652
+msgid "Mode 1: instantaneous solar incidence angle & irradiance using a set local time"
+msgstr ""
+#: ../raster/r.sun/main.c:657
+msgid "incidout requires time parameter to be set"
+msgstr ""
+#: ../raster/r.sun/main.c:659
+msgid "Mode 2: integrated daily irradiation for a given day of the year"
+msgstr ""
+#: ../raster/r.sun/main.c:682
+#, c-format
+msgid "Using Linke constant: %lf"
+msgstr ""
+#: ../raster/r.sun/main.c:684
+#, c-format
+msgid "Using Linke map <%s>"
+msgstr ""
+#: ../raster/r.sun/main.c:689
+#, c-format
+msgid "Using albedo constant: %lf"
+msgstr ""
+#: ../raster/r.sun/main.c:691
+#, c-format
+msgid "Using albedo map <%s>"
+msgstr ""
+#: ../raster/r.sun/main.c:696
+#, c-format
+msgid "Using slope constant: %lf"
+msgstr ""
+#: ../raster/r.sun/main.c:699
+#, c-format
+msgid "Using slope map <%s>"
+msgstr ""
+#: ../raster/r.sun/main.c:704
+#, c-format
+msgid "Using aspect constant: %lf"
+msgstr ""
+#: ../raster/r.sun/main.c:707
+#, c-format
+msgid "Using aspect map <%s>"
+msgstr ""
+#: ../raster/r.sun/main.c:722
+msgid "If you use -s and no horizon rasters, numpartitions must be =1"
+msgstr ""
+#: ../raster/r.sun/main.c:735
+msgid "If you want to save memory and to use shadows, you must use pre-calculated horizons."
+msgstr ""
+#: ../raster/r.sun/main.c:780 ../raster/r.horizon/main.c:531
+#: ../display/d.where/main.c:107 ../general/g.region/printwindow.c:251
+#: ../general/g.region/printwindow.c:475 ../general/g.region/printwindow.c:542
+msgid "Can't get projection info of current location"
+msgstr ""
+#: ../raster/r.sun/main.c:784 ../raster/r.horizon/main.c:534
+#: ../display/d.where/main.c:110 ../general/g.region/printwindow.c:254
+#: ../general/g.region/printwindow.c:478 ../general/g.region/printwindow.c:547
+msgid "Can't get projection units of current location"
+msgstr ""
+#: ../raster/r.sun/main.c:802
+msgid "latin and longin raster maps have no effect when in a Lat/Lon location"
+msgstr ""
+#: ../raster/r.sun/main.c:807
+msgid "Both latin and longin raster maps must be given, or neither"
+msgstr ""
+#: ../raster/r.sun/main.c:854 ../raster/r.sun/main.c:865
+#: ../raster/r.sun/main.c:878 ../raster/r.sun/main.c:890
+#: ../raster/r.sun/main.c:901 ../raster/r.sun/main.c:912
+#: ../raster/r.sun/main.c:923 ../raster/r.sun/main.c:935
+#: ../raster/r.sun/main.c:946 ../raster/r.li/r.li.daemon/list.c:49
+#: ../raster/r.to.rast3/main.c:244 ../raster/r.stream.extract/cseg.c:51
+#: ../raster/r.stream.extract/dseg.c:51 ../raster/r.stream.extract/bseg.c:50
+#: ../raster/r.stream.extract/seg.c:56 ../raster3d/r3.to.rast/main.c:360
+#: ../imagery/i.smap/multialloc.c:115 ../db/drivers/sqlite/listdb.c:134
+#: ../db/drivers/postgres/listtab.c:92 ../db/drivers/postgres/listdb.c:88
+#: ../vector/v.mkgrid/write_grid.c:28 ../vector/v.kcv/main.c:208
+#: ../vector/v.net.distance/main.c:228 ../vector/v.surf.rst/main.c:843
+#: ../vector/v.net.allpairs/main.c:201 ../vector/v.profile/processors.c:31
+#: ../vector/v.net.connectivity/main.c:186
+#: ../vector/v.net.connectivity/main.c:202 ../vector/v.net.flow/main.c:232
+#: ../vector/v.net.timetable/main.c:389 ../vector/v.net.timetable/main.c:399
+#: ../vector/v.vol.rst/user1.c:423 ../vector/v.net.components/main.c:170
+#: ../vector/v.net.centrality/main.c:293 ../vector/v.net.centrality/main.c:298
+#: ../vector/v.net.centrality/main.c:304 ../vector/v.net.centrality/main.c:310
+#: ../vector/v.net.centrality/main.c:316
+#: ../vector/v.generalize/simplification.c:33
+#: ../vector/v.generalize/simplification.c:40
+#: ../vector/v.generalize/simplification.c:306
+#: ../vector/v.generalize/simplification.c:314
+#: ../vector/v.generalize/simplification.c:338
+#: ../vector/v.generalize/matrix.c:144 ../vector/v.generalize/network.c:96
+#: ../vector/v.generalize/network.c:131 ../vector/v.generalize/smoothing.c:144
+#: ../vector/v.generalize/smoothing.c:231
+#: ../vector/v.generalize/smoothing.c:374
+#: ../vector/v.generalize/smoothing.c:528
+#: ../vector/v.generalize/smoothing.c:574
+#: ../vector/v.generalize/smoothing.c:578
+#: ../vector/v.generalize/smoothing.c:582
+#: ../vector/v.generalize/smoothing.c:586
+#: ../vector/v.generalize/smoothing.c:590
+#: ../vector/v.generalize/smoothing.c:594
+#: ../vector/v.generalize/smoothing.c:598
+msgid "Out of memory"
+msgstr ""
+#: ../raster/r.regression.multi/main.c:61
+msgid "Matrix is unsolvable"
+msgstr ""
+#: ../raster/r.regression.multi/main.c:131
+#: ../raster/r.regression.line/main.c:48
+msgid "regression"
+msgstr ""
+#: ../raster/r.regression.multi/main.c:133
+msgid "Calculates multiple linear regression from raster maps."
+msgstr ""
+#: ../raster/r.regression.multi/main.c:138
+#: ../raster/r.regression.line/main.c:55
+msgid "Map for x coefficient"
+msgstr ""
+#: ../raster/r.regression.multi/main.c:142
+#: ../raster/r.regression.line/main.c:59
+msgid "Map for y coefficient"
+msgstr ""
+#: ../raster/r.regression.multi/main.c:147
+msgid "Map to store residuals"
+msgstr ""
+#: ../raster/r.regression.multi/main.c:152
+msgid "Map to store estimates"
+msgstr ""
+#: ../raster/r.regression.multi/main.c:158
+#: ../raster/r.regression.line/main.c:65
+msgid "ASCII file for storing regression coefficients (output to screen if file not specified)."
+msgstr ""
+#: ../raster/r.regression.multi/main.c:170 ../raster/r.stats/main.c:227
+#: ../raster/r.stats.quantile/main.c:319
+#: ../raster/r.univar/r3.univar_main.c:128
+#: ../raster/r.univar/r.univar_main.c:129 ../raster/r.regression.line/main.c:77
+#: ../raster/r.quantile/main.c:313 ../raster/r.what/main.c:177
+#: ../db/db.select/main.c:142 ../vector/v.db.select/main.c:126
+#, c-format
+msgid "Unable to open file <%s> for writing"
+msgstr ""
+#: ../raster/r.regression.multi/main.c:250
+msgid "First pass..."
+msgstr ""
+#: ../raster/r.regression.multi/main.c:323
+msgid "Not enough valid cells available"
+msgstr ""
+#: ../raster/r.regression.multi/main.c:337
+msgid "Multiple regression failed"
+msgstr ""
+#: ../raster/r.regression.multi/main.c:342
+msgid "Second pass..."
+msgstr ""
+#: ../raster/r.volume/main.c:77 ../raster3d/r3.stats/main.c:51
+msgid "volume"
+msgstr ""
+#: ../raster/r.volume/main.c:78 ../raster/r.clump/main.c:61
+msgid "clumps"
+msgstr ""
+#: ../raster/r.volume/main.c:80
+msgid "Calculates the volume of data \"clumps\"."
+msgstr ""
+#: ../raster/r.volume/main.c:81
+msgid "Optionally produces a GRASS vector points map containing the calculated centroids of these clumps."
+msgstr ""
+#: ../raster/r.volume/main.c:86
+msgid "Name of input raster map representing data that will be summed within clumps"
+msgstr ""
+#: ../raster/r.volume/main.c:92
+msgid "Name of input clump raster map"
+msgstr ""
+#: ../raster/r.volume/main.c:93
+msgid "Preferably the output of r.clump. If no clump map is given than MASK is used."
+msgstr ""
+#: ../raster/r.volume/main.c:99
+msgid "Name for output vector points map to contain clump centroids"
+msgstr ""
+#: ../raster/r.volume/main.c:104 ../raster/r.report/parse.c:63
+msgid "Name for output file to hold the report"
+msgstr ""
+#: ../raster/r.volume/main.c:106 ../raster/r.report/parse.c:65
+msgid "If no output file given report is printed to standard output"
+msgstr ""
+#: ../raster/r.volume/main.c:110
+msgid "Generate unformatted report (items separated by colon)"
+msgstr ""
+#: ../raster/r.volume/main.c:143
+msgid "No MASK found. If no clump map is given than the MASK is required. You need to define a clump raster map or create a MASK by r.mask command."
+msgstr ""
+#: ../raster/r.volume/main.c:145
+msgid "No clump map given, using MASK"
+msgstr ""
+#: ../raster/r.volume/main.c:198
+#, c-format
+msgid "Invalid category value %d (max=%d): row=%d col=%d"
+msgstr ""
+#: ../raster/r.volume/main.c:231
+#, c-format
+msgid "Creating vector point map <%s>..."
+msgstr ""
+#: ../raster/r.volume/main.c:233
+#, c-format
+msgid "From '%s' on raster map <%s> using clumps from <%s>"
+msgstr ""
+#: ../raster/r.volume/main.c:260 ../raster/r.to.vect/main.c:229
+#: ../raster3d/r3.flow/main.c:64 ../vector/v.mkgrid/main.c:342
+#: ../vector/v.mkgrid/main.c:400 ../vector/v.random/main.c:254
+#: ../vector/v.in.ascii/main.c:415 ../vector/v.in.dxf/write_vect.c:233
+#: ../vector/v.lrs/v.lrs.create/main.c:338
+#, c-format
+msgid "Unable to create table: %s"
+msgstr ""
+#: ../raster/r.volume/main.c:266
+#, c-format
+msgid ""
+"\n"
+"Volume report on data from <%s> using clumps on <%s> raster map"
+msgstr ""
+#: ../raster/r.volume/main.c:270
+#, c-format
+msgid "Category Average Data # Cells Centroid Total\n"
+msgstr ""
+#: ../raster/r.volume/main.c:272
+#, c-format
+msgid "Number in clump Total in clump Easting Northing Volume"
+msgstr ""
+#: ../raster/r.volume/main.c:296 ../raster/r.to.vect/util.c:157
+#: ../raster/r.to.vect/areas_io.c:359 ../vector/v.random/main.c:471
+#: ../vector/v.random/main.c:591 ../vector/v.in.lidar/attributes.c:240
+#: ../vector/v.vol.rst/vector.c:80
+#, c-format
+msgid "Cannot insert new row: %s"
+msgstr ""
+#: ../raster/r.volume/main.c:319
+msgid "Total Volume"
+msgstr ""
+#: ../raster/r.solute.transport/main.c:59
+msgid "The initial concentration in [kg/m^3]"
+msgstr ""
+#: ../raster/r.solute.transport/main.c:63
+msgid "The piezometric head in [m]"
+msgstr ""
+#: ../raster/r.solute.transport/main.c:68
+msgid "The x-part of the hydraulic conductivity tensor in [m/s]"
+msgstr ""
+#: ../raster/r.solute.transport/main.c:73
+msgid "The y-part of the hydraulic conductivity tensor in [m/s]"
+msgstr ""
+#: ../raster/r.solute.transport/main.c:79
+msgid "The status for each cell, = 0 - inactive cell, 1 - active cell, 2 - dirichlet- and 3 - transfer boundary condition"
+msgstr ""
+#: ../raster/r.solute.transport/main.c:85
+msgid "The x-part of the diffusion tensor in [m^2/s]"
+msgstr ""
+#: ../raster/r.solute.transport/main.c:90
+msgid "The y-part of the diffusion tensor in [m^2/s]"
+msgstr ""
+#: ../raster/r.solute.transport/main.c:94
+#: ../raster/r.solute.transport/main.c:102
+#: ../raster/r.solute.transport/main.c:138
+#: ../raster/r.solute.transport/main.c:145
+msgid "Water flow"
+msgstr ""
+#: ../raster/r.solute.transport/main.c:96
+msgid "Groundwater sources and sinks in [m^3/s]"
+msgstr ""
+#: ../raster/r.solute.transport/main.c:103
+msgid "Concentration sources and sinks bounded to a water source or sink in [kg/s]"
+msgstr ""
+#: ../raster/r.solute.transport/main.c:112
+msgid "Concentration of inner sources and inner sinks in [kg/s] (i.e. a chemical reaction)"
+msgstr ""
+#: ../raster/r.solute.transport/main.c:117
+msgid "Retardation factor [-]"
+msgstr ""
+#: ../raster/r.solute.transport/main.c:121
+msgid "Effective porosity [-]"
+msgstr ""
+#: ../raster/r.solute.transport/main.c:125
+msgid "Top surface of the aquifer in [m]"
+msgstr ""
+#: ../raster/r.solute.transport/main.c:129
+msgid "Bottom surface of the aquifer in [m]"
+msgstr ""
+#: ../raster/r.solute.transport/main.c:132
+msgid "The resulting concentration of the numerical solute transport calculation will be written to this map. [kg/m^3]"
+msgstr ""
+#: ../raster/r.solute.transport/main.c:140
+msgid "Calculate and store the groundwater filter velocity vector part in x direction [m/s]\n"
+msgstr ""
+#: ../raster/r.solute.transport/main.c:147
+msgid "Calculate and store the groundwater filter velocity vector part in y direction [m/s]\n"
+msgstr ""
+#: ../raster/r.solute.transport/main.c:161
+msgid "The longditudinal dispersivity length. [m]"
+msgstr ""
+#: ../raster/r.solute.transport/main.c:169
+msgid "The transversal dispersivity length. [m]"
+msgstr ""
+#: ../raster/r.solute.transport/main.c:177
+msgid "Use this number of time loops if the CFL flag is off. The timestep will become dt/loops."
+msgstr ""
+#: ../raster/r.solute.transport/main.c:187
+msgid "Set the flow stabilizing scheme (full or exponential upwinding)."
+msgstr ""
+#: ../raster/r.solute.transport/main.c:192 ../raster3d/r3.gwflow/main.c:131
+msgid "Use a full filled quadratic linear equation system, default is a sparse linear equation system."
+msgstr ""
+#: ../raster/r.solute.transport/main.c:199
+msgid "Use the Courant-Friedrichs-Lewy criteria for time step calculation"
+msgstr ""
+#: ../raster/r.solute.transport/main.c:231
+msgid "solute transport"
+msgstr ""
+#: ../raster/r.solute.transport/main.c:233
+msgid "Numerical calculation program for transient, confined and unconfined solute transport in two dimensions"
+msgstr ""
+#: ../raster/r.solute.transport/main.c:244 ../raster/r.gwflow/main.c:222
+#: ../raster/r.topidx/main.c:57 ../raster/r.carve/main.c:213
+#, c-format
+msgid "Lat/Long location is not supported by %s. Please reproject map first."
+msgstr ""
+#: ../raster/r.solute.transport/main.c:258
+msgid "The direct LU solver do not work with sparse matrices"
+msgstr ""
+#: ../raster/r.solute.transport/main.c:260
+msgid "The direct Gauss solver do not work with sparse matrices"
+msgstr ""
+#: ../raster/r.solute.transport/main.c:370
+#, c-format
+msgid "The Courant-Friedrichs-Lewy criteria is %g it should be within [0:1]"
+msgstr ""
+#: ../raster/r.solute.transport/main.c:371
+#, c-format
+msgid "The largest stable time step is %g"
+msgstr ""
+#: ../raster/r.solute.transport/main.c:380
+#, c-format
+msgid "Number of inner loops is %g"
+msgstr ""
+#: ../raster/r.solute.transport/main.c:381
+#, c-format
+msgid "Time step for each loop %g"
+msgstr ""
+#: ../raster/r.solute.transport/main.c:385
+#, c-format
+msgid "The time step is to large: %gs. The largest time step should be of size %gs."
+msgstr ""
+#: ../raster/r.solute.transport/main.c:397
+#, c-format
+msgid "Time step %i with time sum %g"
+msgstr ""
+#: ../raster/r.solute.transport/main.c:543
+msgid "Could not create and solve the linear equation system"
+msgstr ""
+#: ../raster/r.walk/main.c:198 ../raster/r.cost/main.c:159
+#: ../raster/r.spreadpath/main.c:90
+msgid "cumulative costs"
+msgstr ""
+#: ../raster/r.walk/main.c:199 ../raster/r.cost/main.c:160
+#: ../vector/v.net.iso/main.c:78 ../vector/v.net.alloc/main.c:66
+msgid "cost allocation"
+msgstr ""
+#: ../raster/r.walk/main.c:201
+msgid "Creates a raster map showing the anisotropic cumulative cost of moving between different geographic locations on an input raster map whose cell category values represent cost."
+msgstr ""
+#: ../raster/r.walk/main.c:211
+msgid "Name of input raster map containing friction costs"
+msgstr ""
+#: ../raster/r.walk/main.c:214
+msgid "Name for output raster map to contain walking costs"
+msgstr ""
+#: ../raster/r.walk/main.c:220 ../raster/r.cost/main.c:184
+msgid "Name for output raster map to contain movement directions"
+msgstr ""
+#: ../raster/r.walk/main.c:221 ../raster/r.walk/main.c:336
+#: ../raster/r.cost/main.c:178 ../raster/r.cost/main.c:185
+#: ../raster/r.cost/main.c:269
+msgid "Optional outputs"
+msgstr ""
+#: ../raster/r.walk/main.c:226 ../raster/r.cost/main.c:190
+msgid "Name of starting vector points map"
+msgstr ""
+#: ../raster/r.walk/main.c:232 ../raster/r.cost/main.c:196
+msgid "Name of stopping vector points map"
+msgstr ""
+#: ../raster/r.walk/main.c:233 ../raster/r.walk/main.c:253
+#: ../raster/r.cost/main.c:197 ../raster/r.cost/main.c:217
+msgid "Stop"
+msgstr ""
+#: ../raster/r.walk/main.c:238 ../raster/r.cost/main.c:202
+msgid "Name of starting raster points map"
+msgstr ""
+#: ../raster/r.walk/main.c:252 ../raster/r.cost/main.c:216
+msgid "Coordinates of stopping point(s) (E,N)"
+msgstr ""
+#: ../raster/r.walk/main.c:262 ../raster/r.cost/main.c:226
+msgid "Maximum cumulative cost"
+msgstr ""
+#: ../raster/r.walk/main.c:271 ../raster/r.cost/main.c:235
+msgid "Cost assigned to null cells. By default, null cells are excluded"
+msgstr ""
+#: ../raster/r.walk/main.c:272 ../raster/r.walk/main.c:322
+#: ../raster/r.cost/main.c:236 ../raster/r.cost/main.c:255
+msgid "NULL cells"
+msgstr ""
+#: ../raster/r.walk/main.c:281 ../raster/r.cost/main.c:245
+msgid "Maximum memory to be used in MB"
+msgstr ""
+#: ../raster/r.walk/main.c:291
+msgid "Coefficients for walking energy formula parameters a,b,c,d"
+msgstr ""
+#: ../raster/r.walk/main.c:292 ../raster/r.walk/main.c:302
+#: ../raster/r.walk/main.c:312 ../raster/r.resamp.rst/main.c:210
+#: ../raster/r.resamp.rst/main.c:216 ../raster/r.resamp.rst/main.c:224
+#: ../raster/r.resamp.rst/main.c:232 ../raster/r.resamp.rst/main.c:240
+#: ../raster/r.slope.aspect/main.c:197 ../raster/r.slope.aspect/main.c:205
+#: ../raster/r.slope.aspect/main.c:263 ../raster/r.slope.aspect/main.c:272
+#: ../raster/r.slope.aspect/main.c:278 ../raster/r.slope.aspect/main.c:286
+#: ../raster/r.in.bin/main.c:275 ../raster/r.in.bin/main.c:280
+#: ../raster/r.in.bin/main.c:306 ../raster/r.in.bin/main.c:314
+#: ../raster/r.in.bin/main.c:323 ../raster/r.in.bin/main.c:384
+#: ../raster/r.in.bin/main.c:398 ../raster/r.resamp.bspline/main.c:107
+#: ../raster/r.resamp.bspline/main.c:115 ../raster/r.resamp.bspline/main.c:121
+#: ../raster/r.resamp.bspline/main.c:133 ../raster/r.resamp.bspline/main.c:138
+#: ../raster/r.out.mpeg/main.c:132 ../display/d.mon/main.c:82
+#: ../display/d.mon/main.c:90 ../display/d.mon/main.c:98
+#: ../display/d.mon/main.c:104 ../display/d.mon/main.c:110
+#: ../display/d.mon/main.c:145 ../display/d.mon/main.c:151
+#: ../display/d.mon/main.c:157 ../general/g.access/main.c:50
+#: ../general/g.access/main.c:58 ../imagery/i.segment/parse_args.c:71
+#: ../imagery/i.segment/parse_args.c:80 ../imagery/i.segment/parse_args.c:91
+#: ../imagery/i.segment/parse_args.c:102 ../imagery/i.segment/parse_args.c:112
+#: ../imagery/i.segment/parse_args.c:130 ../imagery/i.segment/parse_args.c:138
+#: ../imagery/i.segment/parse_args.c:147 ../imagery/i.segment/parse_args.c:154
+#: ../imagery/i.segment/parse_args.c:160 ../imagery/i.segment/parse_args.c:166
+#: ../imagery/i.segment/parse_args.c:172 ../imagery/i.segment/parse_args.c:179
+#: ../imagery/i.cluster/main.c:103 ../imagery/i.cluster/main.c:120
+#: ../imagery/i.cluster/main.c:128 ../imagery/i.cluster/main.c:137
+#: ../imagery/i.cluster/main.c:145 ../imagery/i.cluster/main.c:153
+#: ../imagery/i.landsat.toar/main.c:159 ../imagery/i.landsat.toar/main.c:168
+#: ../imagery/i.landsat.toar/main.c:178 ../imagery/i.landsat.toar/main.c:187
+#: ../imagery/i.landsat.toar/main.c:208 ../db/db.login/main.c:60
+#: ../db/db.login/main.c:68 ../db/db.login/main.c:77 ../db/db.login/main.c:86
+#: ../vector/v.external.out/args.c:20 ../vector/v.external.out/args.c:35
+#: ../vector/v.external.out/args.c:47 ../vector/v.external.out/args.c:53
+#: ../vector/v.lidar.edgedetection/main.c:99
+#: ../vector/v.lidar.edgedetection/main.c:108
+#: ../vector/v.lidar.edgedetection/main.c:117
+#: ../vector/v.lidar.edgedetection/main.c:126
+#: ../vector/v.lidar.edgedetection/main.c:135
+#: ../vector/v.lidar.edgedetection/main.c:143
+#: ../vector/v.lidar.edgedetection/main.c:152 ../vector/v.surf.idw/main.c:115
+#: ../vector/v.surf.idw/main.c:124 ../vector/v.surf.idw/main.c:132
+#: ../vector/v.db.connect/main.c:66 ../vector/v.db.connect/main.c:72
+#: ../vector/v.lidar.correction/main.c:102
+#: ../vector/v.lidar.correction/main.c:111 ../vector/v.surf.bspline/main.c:113
+#: ../vector/v.surf.bspline/main.c:120 ../vector/v.surf.bspline/main.c:150
+#: ../vector/v.surf.bspline/main.c:159 ../vector/v.surf.bspline/main.c:167
+#: ../vector/v.surf.bspline/main.c:179 ../vector/v.vol.rst/main.c:268
+#: ../vector/v.vol.rst/main.c:276 ../vector/v.vol.rst/main.c:283
+#: ../vector/v.vol.rst/main.c:311 ../vector/v.vol.rst/main.c:320
+#: ../vector/v.vol.rst/main.c:329 ../vector/v.vol.rst/main.c:337
+#: ../vector/v.vol.rst/main.c:346 ../vector/v.vol.rst/main.c:354
+#: ../vector/v.outlier/main.c:104 ../vector/v.outlier/main.c:113
+#: ../vector/v.outlier/main.c:121 ../vector/v.colors.out/main.c:68
+#: ../vector/v.colors.out/main.c:73
+msgid "Settings"
+msgstr ""
+#: ../raster/r.walk/main.c:301
+msgid "Lambda coefficients for combining walking energy and friction cost"
+msgstr ""
+#: ../raster/r.walk/main.c:311
+msgid "Slope factor determines travel energy cost per height step"
+msgstr ""
+#: ../raster/r.walk/main.c:317 ../raster/r.cost/main.c:250
+msgid "Use the 'Knight's move'; slower, but more accurate"
+msgstr ""
+#: ../raster/r.walk/main.c:321 ../raster/r.cost/main.c:254
+msgid "Keep null values in output raster map"
+msgstr ""
+#: ../raster/r.walk/main.c:326 ../raster/r.cost/main.c:259
+msgid "Start with values in raster map"
+msgstr ""
+#: ../raster/r.walk/main.c:331 ../raster/r.cost/main.c:264
+msgid "Print info about disk space and memory requirements and exit"
+msgstr ""
+#: ../raster/r.walk/main.c:335 ../raster/r.cost/main.c:268
+msgid "Create bitmask encoded directions"
+msgstr ""
+#: ../raster/r.walk/main.c:382 ../raster/r.cost/main.c:321
+msgid "Must specify exactly one of start_points, start_rast or coordinate"
+msgstr ""
+#: ../raster/r.walk/main.c:388 ../raster/r.walk/main.c:852
+#: ../raster/r.cost/main.c:327 ../raster/r.cost/main.c:715
+msgid "No start points"
+msgstr ""
+#: ../raster/r.walk/main.c:393 ../raster/r.cost/main.c:332
+msgid "No stop points"
+msgstr ""
+#: ../raster/r.walk/main.c:397 ../raster/r.cost/main.c:336
+#, c-format
+msgid "Inappropriate maximum cost: %d"
+msgstr ""
+#: ../raster/r.walk/main.c:400 ../raster/r.cost/main.c:339
+#, c-format
+msgid "Inappropriate amount of memory: %d"
+msgstr ""
+#: ../raster/r.walk/main.c:405
+#, c-format
+msgid "Missing required value: got %d instead of 4"
+msgstr ""
+#: ../raster/r.walk/main.c:408
+#, c-format
+msgid "Walking costs are a=%g b=%g c=%g d=%g"
+msgstr ""
+#: ../raster/r.walk/main.c:413 ../raster/r.walk/main.c:421
+#, c-format
+msgid "Missing required value: %d"
+msgstr ""
+#: ../raster/r.walk/main.c:416
+#, c-format
+msgid "Lambda is %g"
+msgstr ""
+#: ../raster/r.walk/main.c:424
+#, c-format
+msgid "Slope_factor is %g"
+msgstr ""
+#: ../raster/r.walk/main.c:443 ../raster/r.cost/main.c:357
+msgid "Assigning negative cost to null cell. Null cells excluded."
+msgstr ""
+#: ../raster/r.walk/main.c:553 ../raster/r.walk/main.c:566
+#: ../raster/r.cost/main.c:439 ../raster/r.cost/main.c:451
+#, c-format
+msgid "Will need at least %.2f MB of disk space"
+msgstr ""
+#: ../raster/r.walk/main.c:555 ../raster/r.walk/main.c:567
+#: ../raster/r.cost/main.c:441 ../raster/r.cost/main.c:452
+#, c-format
+msgid "Will need at least %.2f MB of memory"
+msgstr ""
+#: ../raster/r.walk/main.c:557 ../raster/r.walk/main.c:568
+#: ../raster/r.cost/main.c:443 ../raster/r.cost/main.c:453
+#, c-format
+msgid "%d of %d segments are kept in memory"
+msgstr ""
+#: ../raster/r.walk/main.c:573 ../raster/r.cost/main.c:458
+msgid "Creating some temporary files..."
+msgstr ""
+#: ../raster/r.walk/main.c:577 ../raster/r.walk/main.c:582
+#: ../raster/r.cost/main.c:462 ../raster/r.cost/main.c:467
+#: ../raster/r.resamp.bspline/main.c:316 ../raster/r.resamp.bspline/main.c:401
+#: ../raster/r.resamp.bspline/main.c:473 ../vector/v.surf.bspline/main.c:475
+#: ../vector/v.surf.bspline/main.c:503
+msgid "Can not create temporary file"
+msgstr ""
+#: ../raster/r.walk/main.c:586
+#, c-format
+msgid "Reading raster maps <%s> and <%s>, initializing output..."
+msgstr ""
+#: ../raster/r.walk/main.c:673 ../raster/r.cost/main.c:533
+msgid "Initializing directional output..."
+msgstr ""
+#: ../raster/r.walk/main.c:742 ../raster/r.cost/main.c:602
+#, c-format
+msgid "No start points found in vector map <%s>"
+msgstr ""
+#: ../raster/r.walk/main.c:744 ../raster/r.cost/main.c:604
+#, c-format
+msgid "%d point found"
+msgid_plural "%d points found"
+msgstr[0] ""
+msgstr[1] ""
+#: ../raster/r.walk/main.c:757 ../raster/r.cost/main.c:617
+#, c-format
+msgid "Reading vector map <%s> with stop points..."
+msgstr ""
+#: ../raster/r.walk/main.c:795 ../raster/r.cost/main.c:655
+#, c-format
+msgid "No stop points found in vector <%s>"
+msgstr ""
+#: ../raster/r.walk/main.c:815 ../raster/r.cost/main.c:676
+#: ../raster/r.texture/h_measure.c:738 ../raster/r.stream.extract/load.c:44
+#: ../raster/r.stream.extract/load.c:53 ../imagery/i.smap/interp.c:68
+msgid "Unable to allocate memory"
+msgstr ""
+#: ../raster/r.walk/main.c:817 ../raster/r.cost/main.c:678
+#, c-format
+msgid "Reading raster map <%s> with start points..."
+msgstr ""
+#: ../raster/r.walk/main.c:863 ../raster/r.cost/main.c:726
+msgid "Specified starting location outside database window"
+msgstr ""
+#: ../raster/r.walk/main.c:888 ../raster/r.cost/main.c:753
+#, c-format
+msgid "Number of duplicate stop points: %d"
+msgstr ""
+#: ../raster/r.walk/main.c:902 ../raster/r.cost/main.c:767
+msgid "Finding cost path..."
+msgstr ""
+#: ../raster/r.walk/main.c:1461 ../raster/r.cost/main.c:1110
+msgid "Error, ct == pres_cell"
+msgstr ""
+#: ../raster/r.walk/main.c:1473
+#, c-format
+msgid "Writing output raster map <%s>... "
+msgstr ""
+#: ../raster/r.walk/main.c:1537 ../raster/r.cost/main.c:1230
+#, c-format
+msgid "Writing output movement direction raster map <%s>..."
+msgstr ""
+#: ../raster/r.walk/main.c:1582 ../raster/r.cost/main.c:1297
+#, c-format
+msgid "Peak cost value: %g"
+msgstr ""
+#: ../raster/r.walk/main.c:1600 ../raster/r.walk/main.c:1636
+#: ../raster/r.cost/main.c:1315 ../raster/r.cost/main.c:1351
+#, c-format
+msgid "Illegal x coordinate <%s>"
+msgstr ""
+#: ../raster/r.walk/main.c:1602 ../raster/r.walk/main.c:1638
+#: ../raster/r.cost/main.c:1317 ../raster/r.cost/main.c:1353
+#, c-format
+msgid "Illegal y coordinate <%s>"
+msgstr ""
+#: ../raster/r.walk/main.c:1606 ../raster/r.walk/main.c:1642
+#: ../raster/r.cost/main.c:1321 ../raster/r.cost/main.c:1357
+#, c-format
+msgid "Warning, ignoring point outside window: %g, %g"
+msgstr ""
+#: ../raster/r.timestamp/main.c:37 ../raster3d/r3.timestamp/main.c:45
+#: ../vector/v.timestamp/main.c:37
+msgid "timestamp"
+msgstr ""
+#: ../raster/r.timestamp/main.c:39
+msgid "Modifies a timestamp for a raster map."
+msgstr ""
+#: ../raster/r.timestamp/main.c:40
+msgid "Print/add/remove a timestamp for a raster map."
+msgstr ""
+#: ../raster/r.timestamp/main.c:49 ../vector/v.timestamp/main.c:50
+msgid "Datetime, datetime1/datetime2, or 'none' to remove"
+msgstr ""
+#: ../raster/r.timestamp/main.c:50 ../vector/v.timestamp/main.c:51
+msgid "Format: '15 jan 1994' (absolute) or '2 years' (relative)"
+msgstr ""
+#: ../raster/r.timestamp/main.c:65
+#, c-format
+msgid "Raster map <%s> not found %s"
+msgstr ""
+#: ../raster/r.colors/rules.c:40
+#, c-format
+msgid "Enter rules, \"end\" when done, \"help\" if you need it.\n"
+msgstr ""
+#: ../raster/r.colors/rules.c:49
+#, c-format
+msgid "fp: Data range is %s to %s\n"
+msgstr ""
+#: ../raster/r.colors/rules.c:53
+#, c-format
+msgid "Data range is %ld to %ld\n"
+msgstr ""
+#: ../raster/r.colors/rules.c:64
+#, c-format
+msgid ""
+"Your color rules do not cover the whole range of data!\n"
+" (rules %f to %f but data %f to %f)"
+msgstr ""
+#: ../raster/r.colors/rules.c:104 ../raster/r.reclass/parse.c:41
+#, c-format
+msgid "Enter a rule in one of these formats:\n"
+msgstr ""
+#: ../raster/r.colors/rules.c:105
+#, c-format
+msgid " val color\n"
+msgstr ""
+#: ../raster/r.colors/rules.c:106
+#, c-format
+msgid " n%% color\n"
+msgstr ""
+#: ../raster/r.colors/rules.c:107
+#, c-format
+msgid " nv color\n"
+msgstr ""
+#: ../raster/r.colors/rules.c:108
+#, c-format
+msgid " default color\n"
+msgstr ""
+#: ../raster/r.colors/rules.c:109
+#, c-format
+msgid "color can be one of:\n"
+msgstr ""
+#: ../raster/r.colors/rules.c:111
+#, c-format
+msgid "or an R:G:B triplet, e.g.: 0:127:255\n"
+msgstr ""
+#: ../raster/r.colors/rules.c:132
+#, c-format
+msgid "bad rule (%s); rule not added"
+msgstr ""
+#: ../raster/r.colors/rules.c:134
+#, c-format
+msgid "bad rule (%s): [%s]"
+msgstr ""
+#: ../raster/r.colors/edit_colors.c:61
+msgid "Creates/modifies the color table associated with a 3D raster map."
+msgstr ""
+#: ../raster/r.colors/edit_colors.c:65
+msgid "Creates/modifies the color table associated with a raster map."
+msgstr ""
+#: ../raster/r.colors/edit_colors.c:75 ../raster/r.colors/edit_colors.c:87
+msgid "Map"
+msgstr ""
+#: ../raster/r.colors/edit_colors.c:81
+msgid "Input file with one map name per line"
+msgstr ""
+#: ../raster/r.colors/edit_colors.c:83
+msgid "Input map names can be defined in an input file in case a large amount of maps must be specified. This option is mutual exclusive to the map option."
+msgstr ""
+#: ../raster/r.colors/edit_colors.c:110
+msgid "\"-\" to read rules from stdin"
+msgstr ""
+#: ../raster/r.colors/edit_colors.c:186 ../raster/r.series.interp/main.c:180
+#, c-format
+msgid "Unable to open %s file <%s>"
+msgstr ""
+#: ../raster/r.colors/edit_colors.c:229 ../raster/r.colors/edit_colors.c:262
+#, c-format
+msgid "%s map <%s> not found"
+msgstr ""
+#: ../raster/r.colors/edit_colors.c:235
+#, c-format
+msgid "No %s map name found in input file <%s>"
+msgstr ""
+#: ../raster/r.colors/edit_colors.c:278
+#, c-format
+msgid "Unable to remove color table of %s map <%s>"
+msgstr ""
+#: ../raster/r.colors/edit_colors.c:280
+#, c-format
+msgid "Color table of %s map <%s> not found"
+msgstr ""
+#: ../raster/r.colors/edit_colors.c:302
+#, c-format
+msgid "Color table exists for %s map <%s>. Exiting."
+msgstr ""
+#: ../raster/r.colors/edit_colors.c:358
+#, c-format
+msgid "Color table 'random' is not supported for floating point %s map"
+msgstr ""
+#: ../raster/r.colors/edit_colors.c:362
+#, c-format
+msgid "Color table 'grey.eq' is not supported for floating point %s map"
+msgstr ""
+#: ../raster/r.colors/edit_colors.c:368
+#, c-format
+msgid "Color table 'grey.log' is not supported for floating point %s map"
+msgstr ""
+#: ../raster/r.colors/edit_colors.c:376 ../imagery/i.vi/main.c:545
+#, c-format
+msgid "Unknown color request '%s'"
+msgstr ""
+#: ../raster/r.colors/edit_colors.c:386 ../vector/v.colors/make_colors.c:51
+#, c-format
+msgid "Unable to load rules file <%s>"
+msgstr ""
+#: ../raster/r.colors/edit_colors.c:396 ../raster/r.colors.out/raster_main.c:69
+#: ../raster/r.grow.distance/main.c:382 ../raster/r.fill.dir/main.c:155
+#: ../vector/v.colors/main.c:315
+#, c-format
+msgid "Unable to read color table for raster map <%s>"
+msgstr ""
+#: ../raster/r.colors/edit_colors.c:400 ../raster/r.univar/r3.univar_main.c:144
+#: ../raster/r.univar/r3.univar_main.c:182 ../raster3d/r3.support/main.c:135
+#: ../raster3d/r3.out.netcdf/main.c:600 ../raster3d/r3.retile/main.c:113
+#: ../raster3d/r3.neighbors/main.c:229 ../raster3d/r3.out.vtk/main.c:142
+#: ../raster3d/r3.mask/main.c:58 ../raster3d/r3.out.bin/main.c:299
+#: ../raster3d/r3.flow/main.c:87 ../raster3d/r3.cross.rast/main.c:245
+#: ../raster3d/r3.out.v5d/main.c:307 ../raster3d/r3.timestamp/main.c:73
+#: ../raster3d/r3.to.rast/main.c:275 ../raster3d/r3.stats/main.c:97
+#: ../raster3d/r3.out.ascii/main.c:326 ../raster3d/r3.null/main.c:103
+#: ../general/g.region/main.c:468 ../vector/v.colors/main.c:319
+#, c-format
+msgid "3D raster map <%s> not found"
+msgstr ""
+#: ../raster/r.colors/edit_colors.c:403 ../vector/v.colors/main.c:322
+#, c-format
+msgid "Unable to read color table for 3D raster map <%s>"
+msgstr ""
+#: ../raster/r.colors/edit_colors.c:447
+#, c-format
+msgid "Color table for %s map <%s> set to '%s'"
+msgstr ""
+#: ../raster/r.colors/stats.c:39
+#, c-format
+msgid "(%i/%i) Reading raster map <%s>..."
+msgstr ""
+#: ../raster/r.colors/stats.c:73
+msgid "Unable to use logarithmic scaling if range includes zero"
+msgstr ""
+#: ../raster/r.colors/stats.c:118
+msgid "Error opening 3d raster map"
+msgstr ""
+#: ../raster/r.colors/stats.c:125
+#, c-format
+msgid "(%i/%i) Reading map <%s>..."
+msgstr ""
+#: ../raster/r.mfilter/main.c:59 ../raster/r.neighbors/main.c:173
+#: ../raster/r.resamp.filter/main.c:397 ../raster3d/r3.neighbors/main.c:215
+#: ../vector/v.outlier/main.c:73
+msgid "filter"
+msgstr ""
+#: ../raster/r.mfilter/main.c:60
+msgid "Performs raster map matrix filter."
+msgstr ""
+#: ../raster/r.mfilter/main.c:71
+msgid "Path to filter file"
+msgstr ""
+#: ../raster/r.mfilter/main.c:79
+msgid "Number of times to repeat the filter"
+msgstr ""
+#: ../raster/r.mfilter/main.c:80 ../raster/r.mfilter/main.c:99
+#: ../imagery/i.pca/main.c:109 ../imagery/i.pca/main.c:120
+msgid "Filter"
+msgstr ""
+#: ../raster/r.mfilter/main.c:86
+msgid "Output raster map title"
+msgstr ""
+#: ../raster/r.mfilter/main.c:98
+msgid "Apply filter only to null data values"
+msgstr ""
+#: ../raster/r.mfilter/main.c:125
+msgid "Raster map too small for the size of the filter"
+msgstr ""
+#: ../raster/r.mfilter/getfilt.c:27
+#, c-format
+msgid "Cannot open filter file '%s'"
+msgstr ""
+#: ../raster/r.mfilter/getfilt.c:47
+msgid "Illegal filter matrix size specified"
+msgstr ""
+#: ../raster/r.mfilter/getfilt.c:50
+msgid "Even filter matrix size specified"
+msgstr ""
+#: ../raster/r.mfilter/getfilt.c:72
+msgid "Illegal filter matrix"
+msgstr ""
+#: ../raster/r.mfilter/getfilt.c:80 ../raster/r.mfilter/getfilt.c:107
+#: ../raster/r.mfilter/getfilt.c:124
+msgid "Filter file format error"
+msgstr ""
+#: ../raster/r.mfilter/getfilt.c:83
+msgid "Duplicate filter divisor specified"
+msgstr ""
+#: ../raster/r.mfilter/getfilt.c:101
+msgid "Illegal divisor matrix"
+msgstr ""
+#: ../raster/r.mfilter/getfilt.c:110
+msgid "Duplicate filter type specified"
+msgstr ""
+#: ../raster/r.mfilter/getfilt.c:117
+msgid "Illegal filter type specified"
+msgstr ""
+#: ../raster/r.mfilter/getfilt.c:127
+msgid "Duplicate filter start specified"
+msgstr ""
+#: ../raster/r.mfilter/getfilt.c:135
+#, c-format
+msgid "Filter start %s ignored, using UL"
+msgstr ""
+#: ../raster/r.mfilter/getfilt.c:157
+msgid "Illegal filter file format"
+msgstr ""
+#: ../raster/r.mfilter/perform.c:40 ../raster/r.mfilter/perform.c:51
+msgid "Unable to create temporary file"
+msgstr ""
+#: ../raster/r.mfilter/perform.c:81
+#, c-format
+msgid "Writing raster map <%s>"
+msgstr ""
+#: ../raster/r.mfilter/getrow.c:23
+msgid "Error reading temporary file"
+msgstr ""
+#: ../raster/r.cost/main.c:162
+msgid "Creates a raster map showing the cumulative cost of moving between different geographic locations on an input raster map whose cell category values represent cost."
+msgstr ""
+#: ../raster/r.cost/main.c:169
+msgid "Name of input raster map containing grid cell cost information"
+msgstr ""
+#: ../raster/r.cost/main.c:177
+msgid "Name for output raster map with nearest start point"
+msgstr ""
+#: ../raster/r.cost/main.c:471
+#, c-format
+msgid "Reading raster map <%s>, initializing output..."
+msgstr ""
+#: ../raster/r.cost/main.c:516
+#, c-format
+msgid "Negative cell value found at row %d, col %d. Setting negative value to null_cost value"
+msgstr ""
+#: ../raster/r.cost/main.c:1133 ../raster/r.buffer/write_map.c:45
+#: ../raster/r.flow/io.c:207
+#, c-format
+msgid "Writing output raster map <%s>..."
+msgstr ""
+#: ../raster/r.cost/main.c:1135
+#, c-format
+msgid "Writing raster map with nearest start point <%s>..."
+msgstr ""
+#: ../raster/r.resamp.interp/main.c:77 ../raster/r.resamp.rst/main.c:149
+#: ../raster/r.resamp.stats/main.c:262 ../raster/r.resamp.bspline/main.c:81
+#: ../raster/r.resample/main.c:55 ../raster/r.resamp.filter/main.c:395
+msgid "resample"
+msgstr ""
+#: ../raster/r.resamp.interp/main.c:80
+msgid "Resamples raster map to a finer grid using interpolation."
+msgstr ""
+#: ../raster/r.resamp.interp/main.c:88
+msgid "Method"
+msgstr "Módszer"
+#: ../raster/r.resamp.interp/main.c:102 ../imagery/i.topo.corr/main.c:158
+#, c-format
+msgid "Invalid method: %s"
+msgstr ""
+#: ../raster/r.resamp.interp/main.c:370 ../raster/r.mode/main.c:143
+#: ../raster/r.resamp.stats/main.c:395 ../raster/r.tile/main.c:200
+#: ../raster/r.resamp.filter/main.c:593
+#, c-format
+msgid "Unable to read color table for %s"
+msgstr ""
+#: ../raster/r.reclass/main.c:51 ../raster/r.recode/main.c:50
+#: ../vector/v.reclass/main.c:68
+msgid "reclassification"
+msgstr ""
+#: ../raster/r.reclass/main.c:52
+msgid "Reclassify raster map based on category values."
+msgstr ""
+#: ../raster/r.reclass/main.c:54
+msgid "Creates a new raster map whose category values are based upon a reclassification of the categories in an existing raster map."
+msgstr ""
+#: ../raster/r.reclass/main.c:59
+msgid "Name of raster map to be reclassified"
+msgstr ""
+#: ../raster/r.reclass/main.c:65
+msgid "File containing reclass rules"
+msgstr ""
+#: ../raster/r.reclass/main.c:72 ../raster/r.recode/main.c:67
+#: ../raster/r.neighbors/main.c:221 ../raster/r.clump/main.c:75
+msgid "Title for output raster map"
+msgstr ""
+#: ../raster/r.reclass/main.c:83
+msgid "Input map can NOT be the same as output map"
+msgstr ""
+#: ../raster/r.reclass/main.c:89
+#, c-format
+msgid "Cannot open rules file <%s>"
+msgstr ""
+#: ../raster/r.reclass/main.c:103
+#, c-format
+msgid "Enter rule(s), \"end\" when done, \"help\" if you need it\n"
+msgstr ""
+#: ../raster/r.reclass/main.c:105
+#, c-format
+msgid "FCELL: Data range is %.7g to %.7g\n"
+msgstr ""
+#: ../raster/r.reclass/main.c:108
+#, c-format
+msgid "DCELL: Data range is %.15g to %.15g\n"
+msgstr ""
+#: ../raster/r.reclass/main.c:111
+#, c-format
+msgid "CELL: Data range is %ld to %ld\n"
+msgstr ""
+#: ../raster/r.reclass/main.c:119
+#, c-format
+msgid "Illegal reclass rule -"
+msgstr ""
+#: ../raster/r.reclass/main.c:120
+#, c-format
+msgid " ignored\n"
+msgstr ""
+#: ../raster/r.reclass/main.c:123
+msgid " - invalid reclass rule"
+msgstr ""
+#: ../raster/r.reclass/main.c:139
+#, c-format
+msgid "No rules specified. Raster map <%s> not created"
+msgstr ""
+#: ../raster/r.reclass/main.c:142 ../raster/r.recode/main.c:99
+#: ../raster/r.quant/main.c:183
+msgid "No rules specified"
+msgstr ""
+#: ../raster/r.reclass/reclass.c:51 ../raster/r.reclass/reclass.c:111
+msgid "Too many categories"
+msgstr ""
+#: ../raster/r.reclass/reclass.c:216
+#, c-format
+msgid "Cannot read header file of <%s@%s>"
+msgstr ""
+#: ../raster/r.reclass/reclass.c:234
+#, c-format
+msgid "Cannot overwrite existing raster map <%s>"
+msgstr ""
+#: ../raster/r.reclass/reclass.c:239
+#, c-format
+msgid "Cannot create reclass file of <%s>"
+msgstr ""
+#: ../raster/r.reclass/reclass.c:247
+#, c-format
+msgid "Cannot create raster map <%s>"
+msgstr ""
+#: ../raster/r.reclass/parse.c:42
+msgid "poor quality"
+msgstr ""
+#: ../raster/r.reclass/parse.c:44
+msgid "medium quality"
+msgstr ""
+#: ../raster/r.reclass/parse.c:59
+msgid "Can't have null on the left-hand side of the rule"
+msgstr ""
+#: ../raster/r.reclass/parse.c:88 ../raster/r.reclass/parse.c:100
+msgid "Can't have null on the right-hand side of the rule"
+msgstr ""
+#: ../raster/r.reclass/parse.c:196
+#, c-format
+msgid "%f rounded up to %d\n"
+msgstr ""
+#: ../raster/r.topmodel/infiltration.c:148
+#: ../raster/r.topmodel/infiltration.c:217
+#, c-format
+msgid "Maximum number of iterations exceeded at time step %d"
+msgstr ""
+#: ../raster/r.topmodel/file_io.c:28 ../raster/r.topmodel/file_io.c:136
+#: ../raster/r.topmodel/file_io.c:161 ../raster/r.series.accumulate/main.c:221
+#: ../raster/r.series/main.c:223 ../raster/r.mapcalc/main.c:49
+#: ../raster/r.in.xyz/main.c:582 ../raster/r.in.mat/main.c:125
+#: ../raster/r.support/main.c:176 ../display/d.legend.vect/main.c:259
+#: ../display/d.legend.vect/main.c:273 ../display/d.legend.vect/draw.c:72
+#: ../display/d.linegraph/main.c:415 ../display/d.linegraph/main.c:432
+#: ../display/d.linegraph/main.c:730 ../display/d.text/main.c:380
+#: ../display/d.where/main.c:163 ../raster3d/r3.support/main.c:167
+#: ../general/g.cairocomp/main.c:46 ../vector/v.segment/main.c:98
+#: ../vector/v.net.path/path.c:49 ../vector/v.lrs/v.lrs.segment/main.c:133
+#, c-format
+msgid "Unable to open input file <%s>"
+msgstr ""
+#: ../raster/r.topmodel/file_io.c:56
+#, c-format
+msgid "%s cannot be 0"
+msgstr ""
+#: ../raster/r.topmodel/file_io.c:209 ../raster/r.topmodel/topmodel.c:77
+#: ../vector/v.out.pov/main.c:104
+#, c-format
+msgid "Unable to create output file <%s>"
+msgstr ""
+#: ../raster/r.topmodel/main.c:53 ../raster/r.spread/main.c:109
+#: ../raster/r.ros/main.c:217 ../raster/r.sim/r.sim.sediment/main.c:120
+#: ../raster/r.sim/r.sim.water/main.c:118
+msgid "model"
+msgstr ""
+#: ../raster/r.topmodel/main.c:55
+msgid "Simulates TOPMODEL which is a physically based hydrologic model."
+msgstr ""
+#: ../raster/r.topmodel/main.c:60
+msgid "Name of input TOPMODEL parameters file"
+msgstr ""
+#: ../raster/r.topmodel/main.c:65
+msgid "Name of input topographic index statistics file"
+msgstr ""
+#: ../raster/r.topmodel/main.c:69
+msgid "Name of input rainfall and potential evapotranspiration data file"
+msgstr ""
+#: ../raster/r.topmodel/main.c:76
+msgid "Time step"
+msgstr ""
+#: ../raster/r.topmodel/main.c:77
+msgid "Generate output for this time step"
+msgstr ""
+#: ../raster/r.topmodel/main.c:83
+msgid "Topographic index class"
+msgstr ""
+#: ../raster/r.topmodel/main.c:85
+msgid "Generate output for this topographic index class"
+msgstr ""
+#: ../raster/r.topmodel/main.c:92
+msgid "Name of input topographic index raster map"
+msgstr ""
+#: ../raster/r.topmodel/main.c:94
+msgid "Must be clipped to the catchment boundary. Used for generating outtopidxstats"
+msgstr ""
+#: ../raster/r.topmodel/main.c:96 ../raster/r.topmodel/main.c:106
+#: ../raster/r.topmodel/main.c:115
+msgid "Preprocess"
+msgstr ""
+#: ../raster/r.topmodel/main.c:100
+msgid "Number of topographic index classes"
+msgstr ""
+#: ../raster/r.topmodel/main.c:102
+msgid "Used for generating outtopidxstats"
+msgstr ""
+#: ../raster/r.topmodel/main.c:111
+msgid "Name for output topographic index statistics file"
+msgstr ""
+#: ../raster/r.topmodel/main.c:113
+msgid "Requires topidx and ntopidxclasses"
+msgstr ""
+#: ../raster/r.topmodel/main.c:120
+msgid "Preprocess only and stop after generating outtopidxstats"
+msgstr ""
+#: ../raster/r.topmodel/main.c:150
+#, c-format
+msgid "%s must be greater than 1"
+msgstr ""
+#: ../raster/r.topmodel/main.c:154 ../raster/r.topmodel/main.c:157
+#, c-format
+msgid "Ignoring %s because %s is not specified"
+msgstr ""
+#: ../raster/r.topmodel/topmodel.c:32
+#, c-format
+msgid "Unable to run %s"
+msgstr ""
+#: ../raster/r.topmodel/topmodel.c:74
+#, c-format
+msgid "Invalid %s output"
+msgstr ""
+#: ../raster/r.texture/main.c:68
+#, c-format
+msgid "Unknown measure <%s>"
+msgstr ""
+#: ../raster/r.texture/main.c:105
+msgid "texture"
+msgstr ""
+#: ../raster/r.texture/main.c:107
+msgid "Generate images with textural features from a raster map."
+msgstr ""
+#: ../raster/r.texture/main.c:121
+msgid "The size of moving window (odd and >= 3)"
+msgstr ""
+#: ../raster/r.texture/main.c:131
+msgid "The distance between two samples (>= 1)"
+msgstr ""
+#: ../raster/r.texture/main.c:132
+msgid "The distance must be smaller than the size of the moving window"
+msgstr ""
+#: ../raster/r.texture/main.c:148
+msgid "Textural measurement method"
+msgstr ""
+#: ../raster/r.texture/main.c:152
+msgid "Separate output for each angle (0, 45, 90, 135)"
+msgstr ""
+#: ../raster/r.texture/main.c:153
+msgid "Angles are counterclockwise from east: 0 is East to West, 45 is North-East to South-West"
+msgstr ""
+#: ../raster/r.texture/main.c:158
+msgid "Calculate all textural measurements"
+msgstr ""
+#: ../raster/r.texture/main.c:162
+msgid "Allow NULL cells in a moving window"
+msgstr ""
+#: ../raster/r.texture/main.c:163
+msgid "This will also avoid cropping along edges of the current region"
+msgstr ""
+#: ../raster/r.texture/main.c:172
+msgid "Size of the moving window must be > 0"
+msgstr ""
+#: ../raster/r.texture/main.c:174
+msgid "Size of the moving window must be odd"
+msgstr ""
+#: ../raster/r.texture/main.c:177
+msgid "The distance between two samples must be > 0"
+msgstr ""
+#: ../raster/r.texture/main.c:179
+msgid "The distance between two samples must be smaller than the size of the moving window"
+msgstr ""
+#: ../raster/r.texture/main.c:200
+msgid "Nothing to compute. Use at least one textural measure."
+msgstr ""
+#: ../raster/r.texture/main.c:292 ../raster/r.carve/raster.c:13
+#: ../imagery/i.zc/main.c:157
+msgid "Reading raster map..."
+msgstr ""
+#: ../raster/r.texture/main.c:342
+#, c-format
+msgid "Calculating %d texture measure"
+msgid_plural "Calculating %d texture measures"
+msgstr[0] ""
+msgstr[1] ""
+#: ../raster/r.texture/main.c:345 ../imagery/i.vi/main.c:225
+#, c-format
+msgid "Calculating %s..."
+msgstr ""
+#: ../raster/r.texture/h_measure.c:156
+#, c-format
+msgid "Too many categories (found: %i, max: %i). Try to rescale or reclassify the map"
+msgstr ""
+#: ../raster/r.stats/main.c:109
+msgid "Generates area statistics for raster map."
+msgstr ""
+#: ../raster/r.stats/main.c:114 ../raster/r.report/parse.c:38
+msgid "Name of raster map(s) to report on"
+msgstr ""
+#: ../raster/r.stats/main.c:136 ../raster/r.report/parse.c:94
+msgid "Number of floating-point subranges to collect stats from"
+msgstr ""
+#: ../raster/r.stats/main.c:137 ../raster/r.stats/main.c:192
+#: ../raster/r.stats/main.c:197 ../raster/r.stats/main.c:212
+#: ../raster/r.stats/main.c:217 ../raster/r.report/parse.c:95
+#: ../raster/r.report/parse.c:139 ../raster/r.report/parse.c:145
+msgid "Floating point"
+msgstr ""
+#: ../raster/r.stats/main.c:144 ../raster/r.report/parse.c:102
+msgid "Sort output statistics by cell counts"
+msgstr ""
+#: ../raster/r.stats/main.c:145 ../raster/r.report/parse.c:103
+msgid "Default: sorted by categories or intervals"
+msgstr ""
+#: ../raster/r.stats/main.c:149 ../raster/r.report/parse.c:107
+msgid "Sort by cell counts in ascending order"
+msgstr ""
+#: ../raster/r.stats/main.c:150 ../raster/r.report/parse.c:108
+msgid "Sort by cell counts in descending order"
+msgstr ""
+#: ../raster/r.stats/main.c:157
+msgid "Print area totals in square meters"
+msgstr ""
+#: ../raster/r.stats/main.c:158 ../raster/r.stats/main.c:163
+#: ../raster/r.stats/main.c:169 ../raster/r.report/parse.c:58
+msgid "Statistics"
+msgstr ""
+#: ../raster/r.stats/main.c:162
+msgid "Print cell counts (sortable)"
+msgstr ""
+#: ../raster/r.stats/main.c:168
+msgid "Print approximate (total percent may not be 100%) percents"
+msgstr ""
+#: ../raster/r.stats/main.c:173
+msgid "Print category labels"
+msgstr ""
+#: ../raster/r.stats/main.c:177
+msgid "One cell (range) per line"
+msgstr ""
+#: ../raster/r.stats/main.c:181
+msgid "Print grid coordinates (east and north)"
+msgstr ""
+#: ../raster/r.stats/main.c:182 ../raster/r.stats/main.c:187
+msgid "Coordinates"
+msgstr ""
+#: ../raster/r.stats/main.c:186
+msgid "Print x and y (column and row)"
+msgstr ""
+#: ../raster/r.stats/main.c:191
+msgid "Print averaged values instead of intervals (floating-point maps only)"
+msgstr ""
+#: ../raster/r.stats/main.c:196
+msgid "Print raw indexes of floating-point ranges (floating-point maps only)"
+msgstr ""
+#: ../raster/r.stats/main.c:201 ../raster/r.report/parse.c:128
+msgid "Do not report no data value"
+msgstr ""
+#: ../raster/r.stats/main.c:202 ../raster/r.stats/main.c:207
+#: ../raster/r.report/parse.c:129 ../raster/r.report/parse.c:134
+msgid "No data"
+msgstr ""
+#: ../raster/r.stats/main.c:206 ../raster/r.report/parse.c:133
+msgid "Do not report cells where all maps have no data"
+msgstr ""
+#: ../raster/r.stats/main.c:211 ../raster/r.report/parse.c:138
+msgid "Report for cats floating-point ranges (floating-point maps only)"
+msgstr ""
+#: ../raster/r.stats/main.c:216 ../raster/r.report/parse.c:144
+msgid "Read floating-point map as integer (use map's quant rules)"
+msgstr ""
+#: ../raster/r.stats/main.c:233
+#, c-format
+msgid "'%s' must be greater than zero; using %s=255"
+msgstr ""
+#: ../raster/r.stats/main.c:285 ../raster/r.series.accumulate/main.c:265
+#: ../raster/r.series/main.c:287
+msgid "Raster map not found"
+msgstr ""
+#: ../raster/r.stats/main.c:303
+#, c-format
+msgid "Raster map <%s> is reading as integer map! Flag '-%c' and/or '%s' option will be ignored."
+msgstr ""
+#: ../raster/r.stats/main.c:319
+#, c-format
+msgid "Cats for raster map <%s> are either missing or have no explicit labels. Using %s=%d."
+msgstr ""
+#: ../raster/r.stats/main.c:325
+#, c-format
+msgid "Flag '-%c' was given, using cats fp ranges of raster map <%s>, ignoring '%s' option"
+msgstr ""
+#: ../raster/r.stats/main.c:331 ../raster/r.contour/main.c:149
+#, c-format
+msgid "Unable to read fp range of raster map <%s>"
+msgstr ""
+#: ../raster/r.stats/main.c:358 ../raster/r.recode/read_rules.c:35
+#, c-format
+msgid "Unable to read range for map <%s>"
+msgstr ""
+#: ../raster/r.stats/raw_stats.c:118
+msgid "Invalid map type"
+msgstr ""
+#: ../raster/r.stats.quantile/main.c:86
+msgid "Computing histograms"
+msgstr ""
+#: ../raster/r.stats.quantile/main.c:123
+msgid "No cells found where both base and cover are not NULL"
+msgstr ""
+#: ../raster/r.stats.quantile/main.c:174 ../raster/r.quantile/main.c:103
+msgid "Computing bins"
+msgstr ""
+#: ../raster/r.stats.quantile/main.c:231 ../raster/r.quantile/main.c:144
+msgid "Binning data"
+msgstr ""
+#: ../raster/r.stats.quantile/main.c:287 ../raster/r.quantile/main.c:189
+msgid "Sorting bins"
+msgstr ""
+#: ../raster/r.stats.quantile/main.c:315
+msgid "Printing quantiles"
+msgstr ""
+#: ../raster/r.stats.quantile/main.c:360 ../raster/r.quantile/main.c:204
+msgid "Computing quantiles"
+msgstr ""
+#: ../raster/r.stats.quantile/main.c:412
+msgid "Generating reclass maps"
+msgstr ""
+#: ../raster/r.stats.quantile/main.c:427 ../raster/r.stats.zonal/main.c:482
+#: ../raster/r.proj/readcell.c:59 ../raster/r.proj/readcell.c:129
+#: ../imagery/i.rectify/readcell.c:55
+#: ../imagery/i.ortho.photo/i.ortho.rectify/readcell.c:66
+msgid "Unable to open temporary file"
+msgstr ""
+#: ../raster/r.stats.quantile/main.c:454
+msgid "Writing output maps"
+msgstr ""
+#: ../raster/r.stats.quantile/main.c:518 ../raster/r.quantile/main.c:268
+msgid "percentile"
+msgstr ""
+#: ../raster/r.stats.quantile/main.c:519 ../raster/r.quantile/main.c:269
+msgid "quantile"
+msgstr ""
+#: ../raster/r.stats.quantile/main.c:520
+msgid "Compute category quantiles using two passes."
+msgstr ""
+#: ../raster/r.stats.quantile/main.c:530 ../raster/r.quantile/main.c:278
+msgid "Number of quantiles"
+msgstr ""
+#: ../raster/r.stats.quantile/main.c:536 ../raster/r.quantile/main.c:286
+msgid "List of percentiles"
+msgstr ""
+#: ../raster/r.stats.quantile/main.c:543 ../raster/r.quantile/main.c:292
+msgid "Number of bins to use"
+msgstr ""
+#: ../raster/r.stats.quantile/main.c:547
+msgid "Resultant raster map(s)"
+msgstr ""
+#: ../raster/r.stats.quantile/main.c:564 ../raster/r.stats.zonal/main.c:149
+msgid "Create reclass map with statistics as category labels"
+msgstr ""
+#: ../raster/r.stats.quantile/main.c:569
+msgid "Do not create output maps; just print statistics"
+msgstr ""
+#: ../raster/r.stats.quantile/main.c:574
+msgid "Print statistics in table format"
+msgstr ""
+#: ../raster/r.stats.quantile/main.c:586
+#, c-format
+msgid "Either -%c or %s= must be given"
+msgstr ""
+#: ../raster/r.stats.quantile/main.c:590 ../raster/r.out.bin/main.c:369
+#: ../raster/r.neighbors/main.c:262 ../raster/r.in.bin/main.c:426
+#: ../raster/r.in.bin/main.c:432
+#, c-format
+msgid "-%c and %s= are mutually exclusive"
+msgstr ""
+#: ../raster/r.stats.quantile/main.c:615
+#, c-format
+msgid "Number of quantiles (%d) does not match number of output maps (%d)"
+msgstr ""
+#: ../raster/r.stats.quantile/main.c:624 ../raster/r.stats.zonal/main.c:181
+msgid "The base map must be an integer (CELL) map"
+msgstr ""
+#: ../raster/r.stats.quantile/main.c:627 ../raster/r.stats.zonal/main.c:184
+#, c-format
+msgid "Unable to read range of base map <%s>"
+msgstr ""
+#: ../raster/r.stats.quantile/main.c:632
+#, c-format
+msgid "Base map <%s> has many categories (%d), computation might be slow and might need a lot of memory"
+msgstr ""
+#: ../raster/r.in.poly/main.c:37
+msgid "Creates raster maps from ASCII polygon/line/point data files."
+msgstr ""
+#: ../raster/r.in.poly/main.c:41
+msgid "Name of input file; or \"-\" to read from stdin"
+msgstr ""
+#: ../raster/r.in.poly/main.c:60
+msgid "Integer representing NULL value data cell"
+msgstr ""
+#: ../raster/r.in.poly/main.c:66
+msgid "Number of rows to hold in memory"
+msgstr ""
+#: ../raster/r.in.poly/main.c:74
+msgid "Minimum number of rows to hold in memory is 1"
+msgstr ""
+#: ../raster/r.in.poly/main.c:83
+msgid "Type doesn't exist"
+msgstr ""
+#: ../raster/r.in.poly/get_item.c:97
+#, c-format
+msgid "Illegal coordinate <%s, %s>, skipping."
+msgstr ""
+#: ../raster/r.in.poly/get_item.c:102
+#, c-format
+msgid "Illegal north coordinate <%s>, skipping."
+msgstr ""
+#: ../raster/r.in.poly/get_item.c:107
+#, c-format
+msgid "Illegal east coordinate <%s>, skipping."
+msgstr ""
+#: ../raster/r.in.poly/poly2rast.c:56 ../raster/r.in.xyz/main.c:645
+#, c-format
+msgid "Pass #%d (of %d) ..."
+msgstr ""
+#: ../raster/r.in.poly/poly2rast.c:81 ../raster/r.carve/raster.c:33
+#: ../vector/v.to.rast/vect2rast.c:179
+msgid "Writing raster map..."
+msgstr ""
+#: ../raster/r.out.pov/main.c:124
+msgid "Converts a raster map layer into a height-field file for POV-Ray."
+msgstr ""
+#: ../raster/r.out.pov/main.c:131
+msgid "Name of output povray file (TGA height field file)"
+msgstr ""
+#: ../raster/r.out.pov/main.c:138
+msgid "Height-field type (0=actual heights 1=normalized)"
+msgstr ""
+#: ../raster/r.out.pov/main.c:144
+msgid "Elevation bias"
+msgstr ""
+#: ../raster/r.out.pov/main.c:150 ../raster/r.param.scale/interface.c:118
+msgid "Vertical scaling factor"
+msgstr ""
+#: ../raster/r.out.pov/main.c:170
+#, c-format
+msgid "Invalid output filename <%s>"
+msgstr ""
+#: ../raster/r.out.pov/main.c:173 ../raster/r.colors.out/raster_main.c:79
+#: ../raster/r.colors.out/raster3d_main.c:80 ../raster/r.out.vrml/main.c:131
+#: ../raster/r.out.png/main.c:205 ../raster/r.support/main.c:162
+#: ../raster/r.out.mat/main.c:91 ../raster3d/r3.support/main.c:153
+#: ../general/g.cairocomp/main.c:66 ../vector/v.colors.out/main.c:103
+#, c-format
+msgid "Unable to open output file <%s>"
+msgstr ""
+#: ../raster/r.out.pov/main.c:180
+#, c-format
+msgid "Raster map is too big! Exceeds %d columns or %d rows"
+msgstr ""
+#: ../raster/r.out.pov/main.c:201
+msgid "Negative elevation values in input"
+msgstr ""
+#: ../raster/r.li/r.li.padcv/padcv.c:52
+msgid "Calculates coefficient of variation of patch area on a raster map"
+msgstr ""
+#: ../raster/r.li/r.li.padcv/padcv.c:54 ../raster/r.li/r.li.shape/main.c:50
+#: ../raster/r.li/r.li.mps/mps.c:53 ../raster/r.li/r.li.renyi/renyi.c:48
+#: ../raster/r.li/r.li.cwed/cwed.c:55 ../raster/r.li/r.li.mpa/mpa.c:45
+#: ../raster/r.li/r.li.simpson/simpson.c:47
+#: ../raster/r.li/r.li.padrange/padrange.c:54
+#: ../raster/r.li/r.li.edgedensity/edgedensity.c:49
+#: ../raster/r.li/r.li.patchnum/main.c:51 ../raster/r.li/r.li.padsd/padsd.c:54
+#: ../raster/r.li/r.li.dominance/dominance.c:47
+#: ../raster/r.li/r.li.pielou/pielou.c:47
+#: ../raster/r.li/r.li.shannon/shannon.c:47
+#: ../raster/r.li/r.li.patchdensity/main.c:52
+#: ../raster/r.li/r.li.richness/richness.c:44
+msgid "landscape structure analysis"
+msgstr ""
+#: ../raster/r.li/r.li.padcv/padcv.c:55 ../raster/r.li/r.li.shape/main.c:51
+#: ../raster/r.li/r.li.mps/mps.c:54 ../raster/r.li/r.li.cwed/cwed.c:56
+#: ../raster/r.li/r.li.mpa/mpa.c:46 ../raster/r.li/r.li.padrange/padrange.c:55
+#: ../raster/r.li/r.li.edgedensity/edgedensity.c:50
+#: ../raster/r.li/r.li.patchnum/main.c:52 ../raster/r.li/r.li.padsd/padsd.c:55
+#: ../raster/r.li/r.li.patchdensity/main.c:53
+msgid "patch index"
+msgstr ""
+#: ../raster/r.li/r.li.padcv/padcv.c:62 ../raster/r.li/r.li.shape/main.c:59
+#: ../raster/r.li/r.li.mps/mps.c:62 ../raster/r.li/r.li.renyi/renyi.c:57
+#: ../raster/r.li/r.li.cwed/cwed.c:64 ../raster/r.li/r.li.mpa/mpa.c:53
+#: ../raster/r.li/r.li.simpson/simpson.c:56
+#: ../raster/r.li/r.li.padrange/padrange.c:62
+#: ../raster/r.li/r.li.edgedensity/edgedensity.c:58
+#: ../raster/r.li/r.li.patchnum/main.c:59 ../raster/r.li/r.li.padsd/padsd.c:62
+#: ../raster/r.li/r.li.dominance/dominance.c:56
+#: ../raster/r.li/r.li.pielou/pielou.c:56
+#: ../raster/r.li/r.li.shannon/shannon.c:56
+#: ../raster/r.li/r.li.patchdensity/main.c:61
+#: ../raster/r.li/r.li.richness/richness.c:53
+msgid "Configuration file"
+msgstr ""
+#: ../raster/r.li/r.li.shape/main.c:48
+msgid "Calculates shape index on a raster map"
+msgstr ""
+#: ../raster/r.li/r.li.mps/mps.c:51
+msgid "Calculates mean patch size index on a raster map, using a 4 neighbour algorithm"
+msgstr ""
+#: ../raster/r.li/r.li.renyi/renyi.c:46
+msgid "Calculates Renyi's diversity index on a raster map"
+msgstr ""
+#: ../raster/r.li/r.li.renyi/renyi.c:49
+#: ../raster/r.li/r.li.simpson/simpson.c:48
+#: ../raster/r.li/r.li.dominance/dominance.c:48
+#: ../raster/r.li/r.li.pielou/pielou.c:48
+#: ../raster/r.li/r.li.shannon/shannon.c:48
+#: ../raster/r.li/r.li.richness/richness.c:45
+msgid "diversity index"
+msgstr ""
+#: ../raster/r.li/r.li.renyi/renyi.c:63
+msgid "Alpha value is the order of the generalized entropy"
+msgstr ""
+#: ../raster/r.li/r.li.cwed/cwed.c:53
+msgid "Calculates contrast weighted edge density index on a raster map"
+msgstr ""
+#: ../raster/r.li/r.li.cwed/cwed.c:70
+msgid "Name of file that contains the weight to calculate the index"
+msgstr ""
+#: ../raster/r.li/r.li.cwed/cwed.c:306 ../raster/r.li/r.li.cwed/cwed.c:453
+#: ../raster/r.li/r.li.cwed/cwed.c:599
+msgid "Row cache is too small"
+msgstr ""
+#: ../raster/r.li/r.li.mpa/mpa.c:43
+msgid "Calculates mean pixel attribute index on a raster map"
+msgstr ""
+#: ../raster/r.li/r.li.daemon/daemon.c:97
+msgid "Cannot create random access file"
+msgstr ""
+#: ../raster/r.li/r.li.daemon/daemon.c:105
+#: ../raster/r.li/r.li.daemon/daemon.c:111
+#: ../raster/r.li/r.li.daemon/daemon.c:117
+#, c-format
+msgid "Cannot create %s directory"
+msgstr ""
+#: ../raster/r.li/r.li.daemon/daemon.c:174 ../raster/r.surf.random/main.c:66
+#: ../raster/r.circle/main.c:153 ../raster/r.surf.fractal/main.c:85
+#: ../raster/r.composite/main.c:262
+#, c-format
+msgid "Raster map <%s> created."
+msgstr ""
+#: ../raster/r.li/r.li.daemon/daemon.c:201
+#, c-format
+msgid "Cannot find configuration file <%s>"
+msgstr ""
+#: ../raster/r.li/r.li.daemon/daemon.c:208
+#: ../raster/r.li/r.li.daemon/daemon.c:212
+msgid "Cannot read setup file"
+msgstr ""
+#: ../raster/r.li/r.li.daemon/daemon.c:216
+msgid "Unable to parse configuration file (sampling frame)"
+msgstr ""
+#: ../raster/r.li/r.li.daemon/daemon.c:475
+msgid "Irregular MASKEDOVERLAY areas definition"
+msgstr ""
+#: ../raster/r.li/r.li.daemon/daemon.c:479
+#, c-format
+msgid "The configuration file can only be used with the <%s> raster map"
+msgstr ""
+#: ../raster/r.li/r.li.daemon/daemon.c:485
+msgid "Unable to parse configuration file (sample area)"
+msgstr ""
+#: ../raster/r.li/r.li.daemon/daemon.c:520
+msgid "Too many units to place"
+msgstr ""
+#: ../raster/r.li/r.li.daemon/daemon.c:589
+msgid "Too many stratified random sample for raster map"
+msgstr ""
+#: ../raster/r.li/r.li.daemon/daemon.c:623
+msgid "Illegal areas disposition"
+msgstr ""
+#: ../raster/r.li/r.li.daemon/daemon.c:695
+msgid "Cannot make lseek"
+msgstr ""
+#: ../raster/r.li/r.li.daemon/worker.c:135
+#, c-format
+msgid "unable to open <%s> mask ... continuing without!"
+msgstr ""
+#: ../raster/r.li/r.li.simpson/simpson.c:45
+msgid "Calculates Simpson's diversity index on a raster map"
+msgstr ""
+#: ../raster/r.li/r.li.padrange/padrange.c:52
+msgid "Calculates range of patch area size on a raster map"
+msgstr ""
+#: ../raster/r.li/r.li.edgedensity/edgedensity.c:47
+msgid "Calculates edge density index on a raster map, using a 4 neighbour algorithm"
+msgstr ""
+#: ../raster/r.li/r.li.edgedensity/edgedensity.c:68
+msgid "The value of the patch type"
+msgstr ""
+#: ../raster/r.li/r.li.edgedensity/edgedensity.c:69
+msgid "It can be integer, double or float; it will be changed in function of map type"
+msgstr ""
+#: ../raster/r.li/r.li.edgedensity/edgedensity.c:74
+msgid "Exclude border edges"
+msgstr ""
+#: ../raster/r.li/r.li.patchnum/main.c:49
+msgid "Calculates patch number index on a raster map, using a 4 neighbour algorithm."
+msgstr ""
+#: ../raster/r.li/r.li.padsd/padsd.c:52
+msgid "Calculates standard deviation of patch area a raster map"
+msgstr ""
+#: ../raster/r.li/r.li.dominance/dominance.c:45
+msgid "Calculates dominance's diversity index on a raster map"
+msgstr ""
+#: ../raster/r.li/r.li.pielou/pielou.c:45
+msgid "Calculates Pielou's diversity index on a raster map"
+msgstr ""
+#: ../raster/r.li/r.li.shannon/shannon.c:45
+msgid "Calculates Shannon's diversity index on a raster map"
+msgstr ""
+#: ../raster/r.li/r.li.patchdensity/main.c:50
+msgid "Calculates patch density index on a raster map, using a 4 neighbour algorithm"
+msgstr ""
+#: ../raster/r.li/r.li.richness/richness.c:42
+msgid "Calculates richness index on a raster map"
+msgstr ""
+#: ../raster/r.out.ppm3/main.c:59
+msgid "Converts 3 GRASS raster layers (R,G,B) to a PPM image file."
+msgstr ""
+#: ../raster/r.out.ppm3/main.c:64 ../raster/r.composite/main.c:90
+#: ../display/d.rgb/main.c:69
+#, c-format
+msgid "Name of raster map to be used for <%s>"
+msgstr ""
+#: ../raster/r.out.ppm3/main.c:84
+msgid "Name for new PPM file. (use '-' for stdout)"
+msgstr ""
+#: ../raster/r.out.ppm3/main.c:88
+msgid "Add comments to describe the region"
+msgstr ""
+#: ../raster/r.out.ppm3/main.c:95 ../raster/r.out.ppm/main.c:101
+#, c-format
+msgid "row = %d"
+msgid_plural "rows = %d"
+msgstr[0] ""
+msgstr[1] ""
+#. GTC Raster columns
+#: ../raster/r.out.ppm3/main.c:97 ../raster/r.out.ppm/main.c:102
+#, c-format
+msgid "column = %d"
+msgid_plural "columns = %d"
+msgstr[0] ""
+msgstr[1] ""
+#: ../raster/r.out.ppm3/main.c:115 ../raster/r.his/main.c:167
+#: ../raster/r.his/main.c:183 ../raster/r.his/main.c:201
+#: ../display/d.colortable/main.c:135 ../display/d.his/main.c:139
+#: ../display/d.his/main.c:156 ../display/d.his/main.c:174
+#: ../display/d.rgb/main.c:99 ../display/d.legend/main.c:409
+#: ../display/d.legend/main.c:417 ../display/d.rast.num/main.c:253
+#: ../display/d.rast/display.c:23 ../display/d.histogram/main.c:171
+#, c-format
+msgid "Color file for <%s> not available"
+msgstr ""
+#: ../raster/r.out.ppm3/main.c:160
+msgid "Converting... "
+msgstr ""
+#: ../raster/r.out.bin/main.c:53 ../raster/r.out.bin/main.c:62
+#: ../raster/r.out.bin/main.c:470 ../raster/r.mapcalc/map3.c:129
+#: ../raster/r.mapcalc/map3.c:143 ../raster/r.mapcalc/map3.c:157
+#: ../raster3d/r3.out.bin/main.c:113
+msgid "Error writing data"
+msgstr ""
+#: ../raster/r.out.bin/main.c:139
+#, c-format
+msgid "Header File = %s"
+msgstr ""
+#: ../raster/r.out.bin/main.c:144 ../raster/r.out.bin/main.c:228
+#: ../raster/r.out.bin/main.c:414 ../display/d.mon/start.c:181
+#: ../display/d.mon/start.c:224 ../raster3d/r3.out.bin/main.c:321
+#, c-format
+msgid "Unable to create file <%s>"
+msgstr ""
+#: ../raster/r.out.bin/main.c:223
+#, c-format
+msgid "World File = %s"
+msgstr ""
+#: ../raster/r.out.bin/main.c:281
+msgid "Exports a GRASS raster to a binary array."
+msgstr ""
+#: ../raster/r.out.bin/main.c:290 ../raster/r.random/main.c:62
+#: ../imagery/i.zc/main.c:66
+msgid "Name of input raster map"
+msgstr ""
+#: ../raster/r.out.bin/main.c:297
+msgid "Name for output binary map (use output=- for stdout)"
+msgstr ""
+#: ../raster/r.out.bin/main.c:304 ../raster3d/r3.out.bin/main.c:221
+msgid "Value to write out for null"
+msgstr ""
+#: ../raster/r.out.bin/main.c:311 ../raster/r.in.bin/main.c:305
+msgid "Number of bytes per cell"
+msgstr ""
+#: ../raster/r.out.bin/main.c:318 ../raster/r.in.bin/main.c:330
+#: ../raster3d/r3.out.bin/main.c:235
+msgid "Output byte order"
+msgstr ""
+#: ../raster/r.out.bin/main.c:323
+msgid "Generate integer output"
+msgstr ""
+#: ../raster/r.out.bin/main.c:327
+msgid "Generate floating-point output"
+msgstr ""
+#: ../raster/r.out.bin/main.c:331
+msgid "Export array with GMT compatible header"
+msgstr ""
+#: ../raster/r.out.bin/main.c:335
+msgid "Generate BIL world and header files"
+msgstr ""
+#: ../raster/r.out.bin/main.c:339
+msgid "Byte swap output"
+msgstr ""
+#: ../raster/r.out.bin/main.c:347 ../raster3d/r3.out.bin/main.c:256
+msgid "Invalid value for null (integers only)"
+msgstr ""
+#: ../raster/r.out.bin/main.c:379 ../raster/r.in.bin/main.c:462
+#: ../vector/v.colors/main.c:225
+#, c-format
+msgid "-%c and -%c are mutually exclusive"
+msgstr ""
+#: ../raster/r.out.bin/main.c:399
+#, c-format
+msgid "Floating-point output requires %s=4 or %s=8"
+msgstr ""
+#: ../raster/r.out.bin/main.c:404
+#, c-format
+msgid "Integer output doesn't support %s=8 in this build"
+msgstr ""
+#: ../raster/r.out.bin/main.c:419
+msgid "GMT grid doesn't support 64-bit integers"
+msgstr ""
+#: ../raster/r.out.bin/main.c:425
+msgid "Creating BIL support files..."
+msgstr ""
+#: ../raster/r.out.bin/main.c:442
+#, c-format
+msgid "Exporting raster as floating values (%s=%d)"
+msgstr ""
+#: ../raster/r.out.bin/main.c:445
+msgid "Writing GMT float format ID=1"
+msgstr ""
+#: ../raster/r.out.bin/main.c:448
+#, c-format
+msgid "Exporting raster as integer values (%s=%d)"
+msgstr ""
+#: ../raster/r.out.bin/main.c:451
+msgid "Writing GMT integer format ID=2"
+msgstr ""
+#: ../raster/r.out.bin/main.c:454 ../raster3d/r3.out.bin/main.c:323
+msgid "Using the current region settings..."
+msgstr ""
+#: ../raster/r.out.bin/main.c:455 ../raster3d/r3.out.bin/main.c:324
+#, c-format
+msgid "north=%f"
+msgstr ""
+#: ../raster/r.out.bin/main.c:456 ../raster3d/r3.out.bin/main.c:325
+#, c-format
+msgid "south=%f"
+msgstr ""
+#: ../raster/r.out.bin/main.c:457 ../raster3d/r3.out.bin/main.c:326
+#, c-format
+msgid "east=%f"
+msgstr ""
+#: ../raster/r.out.bin/main.c:458 ../raster3d/r3.out.bin/main.c:327
+#, c-format
+msgid "west=%f"
+msgstr ""
+#: ../raster/r.out.bin/main.c:459
+#, c-format
+msgid "r=%d"
+msgstr ""
+#: ../raster/r.out.bin/main.c:460
+#, c-format
+msgid "c=%d"
+msgstr ""
+#: ../raster/r.to.rast3/main.c:59 ../raster/r.to.rast3elev/main.c:136
+msgid "Could not close the map"
+msgstr ""
+#: ../raster/r.to.rast3/main.c:79
+msgid "2D raster maps which represent the slices"
+msgstr ""
+#: ../raster/r.to.rast3/main.c:84 ../raster/r.to.rast3elev/main.c:175
+msgid "The maximum tile size in kilo bytes. Default is 32KB."
+msgstr ""
+#: ../raster/r.to.rast3/main.c:93
+msgid "Use 3D raster mask (if exists) with output map"
+msgstr ""
+#: ../raster/r.to.rast3/main.c:201
+msgid "Converts 2D raster map slices to one 3D raster volume map."
+msgstr ""
+#: ../raster/r.to.rast3/main.c:213
+msgid "No output map"
+msgstr ""
+#: ../raster/r.to.rast3/main.c:230
+msgid "The 2D and 3D region settings are different. Using the 3D region settings to adjust the 2D region."
+msgstr ""
+#: ../raster/r.to.rast3/main.c:262
+#, c-format
+msgid "Open raster map %s - one time for each depth (%d/%d)"
+msgstr ""
+#: ../raster/r.to.rast3/main.c:275
+msgid "Input maps have to be from the same type. CELL, FCELL or DCELL!"
+msgstr ""
+#: ../raster/r.to.rast3/main.c:279 ../raster/r.to.rast3elev/main.c:457
+msgid "Creating 3D raster map"
+msgstr ""
+#: ../raster/r.to.rast3/main.c:291 ../raster/r.to.rast3elev/main.c:443
+msgid "Error opening 3D raster map"
+msgstr ""
+#: ../raster/r.to.rast3/main.c:326 ../raster/r.to.rast3elev/main.c:501
+msgid "Error closing 3d raster map"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:151
+msgid "Reinterpolates and optionally computes topographic analysis from input raster map to a new raster map (possibly with different resolution) using regularized spline with tension and smoothing."
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:162
+msgid "Desired east-west resolution"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:168
+msgid "Desired north-south resolution"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:173
+msgid "Name for output elevation raster map"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:179
+msgid "Name for output slope map (or fx)"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:185
+msgid "Name for output aspect map (or fy)"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:191
+msgid "Name for output profile curvature map (or fxx)"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:197
+msgid "Name for output tangential curvature map (or fyy)"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:203
+msgid "Name for output mean curvature map (or fxy)"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:209
+msgid "Name of input raster map containing smoothing"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:215
+msgid "Name of input raster map to be used as mask"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:223
+msgid "Rows/columns overlap for segmentation"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:231
+msgid "Multiplier for z-values"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:239
+msgid "Spline tension value"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:246 ../vector/v.surf.rst/main.c:340
+msgid "Anisotropy angle (in degrees counterclockwise from East)"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:247 ../raster/r.resamp.rst/main.c:254
+msgid "Anisotropy"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:253 ../vector/v.surf.rst/main.c:347
+msgid "Anisotropy scaling factor"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:258
+msgid "Use dnorm independent tension"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:263 ../vector/v.surf.rst/main.c:171
+msgid "Output partial derivatives instead of topographic parameters"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:297
+msgid "Unable to read ew_res value"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:300
+msgid "Unable to read ns_res value"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:303
+msgid "Invalid value for tension"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:306
+msgid "Invalid value for zmult"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:309
+msgid "Invalid value for overlap"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:313
+msgid "Invalid value for theta"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:317
+msgid "Invalid value for scalex"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:319
+msgid "When using anisotropy both theta and scalex must be specified"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:357
+#, c-format
+msgid "Map <%s> is the wrong resolution"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:365
+msgid "Smoothing values can not be negative or NULL"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:371
+msgid "Input map resolution differs from current region resolution!"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:387
+msgid "Processing all selected output files will require"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:391
+#, c-format
+msgid "%.2f GB of disk space for temp files."
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:394
+#, c-format
+msgid "%.2f MB of disk space for temp files."
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:397
+#, c-format
+msgid "%.2f KB of disk space for temp files."
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:400
+#, c-format
+msgid "%d byte of disk space for temp files."
+msgid_plural "%d bytes of disk space for temp files."
+msgstr[0] ""
+msgstr[1] ""
+#: ../raster/r.resamp.rst/main.c:436
+msgid "Maximum value of a raster map is NULL."
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:464
+msgid "Temporarily changing the region to desired resolution ..."
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:469
+msgid "Changing back to the original region ..."
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:478 ../raster/r.resample/main.c:112
+msgid "Percent complete: "
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:490
+#, c-format
+msgid "dnorm in mainc after grid before out1= %f"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:494
+msgid "split_and_interpolate() failed"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:509
+#, c-format
+msgid "dnorm in mainc after grid before out2= %f"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:515
+msgid "Unable to write raster maps -- try increasing cell size"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:542 ../raster/r.in.ascii/main.c:120
+#: ../raster/r.in.ascii/main.c:150 ../display/d.title/main.c:117
+#: ../raster3d/r3.in.ascii/main.c:169 ../general/g.setproj/get_stp.c:162
+#: ../general/g.setproj/get_stp.c:165 ../general/g.setproj/get_stp.c:282
+#: ../general/g.setproj/get_stp.c:286 ../vector/v.surf.rst/main.c:864
+#: ../vector/v.in.ascii/main.c:275
+#, c-format
+msgid "Unable to open temporary file <%s>"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:547 ../raster/r.thin/io.c:131
+#: ../raster/r.thin/io.c:138 ../raster/r.thin/io.c:147
+#: ../vector/v.surf.rst/main.c:869
+#, c-format
+msgid "Error writing temporary file <%s>"
+msgstr ""
+#: ../raster/r.univar/r3.univar_main.c:37
+msgid "3D Raster map used for zoning, must be of type CELL"
+msgstr ""
+#: ../raster/r.univar/r3.univar_main.c:59 ../raster/r.univar/r.univar_main.c:61
+#: ../vector/v.univar/main.c:126 ../vector/v.what/main.c:100
+msgid "Print the stats in shell script style"
+msgstr ""
+#: ../raster/r.univar/r3.univar_main.c:67 ../raster/r.univar/r.univar_main.c:71
+msgid "Table output format instead of standard output format"
+msgstr ""
+#: ../raster/r.univar/r3.univar_main.c:103
+msgid "Calculates univariate statistics from the non-null cells of a 3D raster map."
+msgstr ""
+#: ../raster/r.univar/r3.univar_main.c:105
+#: ../raster/r.univar/r.univar_main.c:112
+msgid "Statistics include number of cells counted, minimum and maximum cell values, range, arithmetic mean, population variance, standard deviation, coefficient of variation, and sum."
+msgstr ""
+#: ../raster/r.univar/r3.univar_main.c:151
+#: ../raster/r.univar/r3.univar_main.c:189 ../raster3d/r3.out.netcdf/main.c:617
+#: ../raster3d/r3.retile/main.c:127 ../raster3d/r3.neighbors/main.c:266
+#: ../raster3d/r3.neighbors/main.c:275 ../raster3d/r3.out.vtk/main.c:207
+#: ../raster3d/r3.out.vtk/main.c:292 ../raster3d/r3.out.vtk/main.c:513
+#: ../raster3d/r3.mkdspf/main.c:168 ../raster3d/r3.mask/main.c:64
+#: ../raster3d/r3.out.bin/main.c:314 ../raster3d/r3.flow/main.c:118
+#: ../raster3d/r3.flow/main.c:132 ../raster3d/r3.flow/main.c:373
+#: ../raster3d/r3.flow/main.c:385 ../raster3d/r3.flow/test_main.c:82
+#: ../raster3d/r3.cross.rast/main.c:279 ../raster3d/r3.out.v5d/main.c:312
+#: ../raster3d/r3.info/main.c:110 ../raster3d/r3.to.rast/main.c:298
+#: ../raster3d/r3.to.rast/main.c:322 ../raster3d/r3.stats/main.c:104
+#: ../raster3d/r3.gradient/main.c:113 ../raster3d/r3.gradient/main.c:122
+#: ../raster3d/r3.out.ascii/main.c:339 ../raster3d/r3.null/main.c:110
+#, c-format
+msgid "Unable to open 3D raster map <%s>"
+msgstr ""
+#: ../raster/r.univar/r.univar_main.c:36
+msgid "Raster map used for zoning, must be of type CELL"
+msgstr ""
+#: ../raster/r.univar/r.univar_main.c:53 ../raster/r.univar/r.univar_main.c:67
+msgid "Extended"
+msgstr ""
+#: ../raster/r.univar/r.univar_main.c:76
+msgid "Use the native resolution and extent of the raster map, instead of the current region"
+msgstr ""
+#: ../raster/r.univar/r.univar_main.c:110
+msgid "Calculates univariate statistics from the non-null cells of a raster map."
+msgstr ""
+#: ../raster/r.univar/r.univar_main.c:123
+msgid "zones option and region flag -r are mutually exclusive"
+msgstr ""
+#: ../raster/r.univar/r.univar_main.c:201 ../raster/r.out.png/main.c:272
+#, c-format
+msgid "Raster <%s> type mismatch"
+msgstr ""
+#: ../raster/r.recode/read_rules.c:20
+#, c-format
+msgid "Unable to read f_range for map %s"
+msgstr ""
+#: ../raster/r.recode/read_rules.c:24 ../display/d.colortable/main.c:146
+msgid "Data range is empty"
+msgstr ""
+#: ../raster/r.recode/read_rules.c:30
+#, c-format
+msgid "Data range of %s is %s to %s (entire map)"
+msgstr ""
+#: ../raster/r.recode/read_rules.c:39
+#, c-format
+msgid "Integer data range of %s is empty"
+msgstr ""
+#: ../raster/r.recode/read_rules.c:41
+#, c-format
+msgid "Integer data range of %s is %d to %d"
+msgstr ""
+#: ../raster/r.recode/read_rules.c:61
+msgid "Enter the rule or 'help' for the format description"
+msgstr ""
+#: ../raster/r.recode/read_rules.c:85
+msgid "Enter a rule in one of these formats:"
+msgstr ""
+#: ../raster/r.recode/read_rules.c:87
+msgid "old_low:old_high:new_low:new_high"
+msgstr ""
+#: ../raster/r.recode/read_rules.c:88
+msgid "old_low:old_high:new_val (i.e. new_high == new_low)"
+msgstr ""
+#: ../raster/r.recode/read_rules.c:89
+msgid "*:old_val:new_val (interval [inf, old_val])"
+msgstr ""
+#: ../raster/r.recode/read_rules.c:90
+msgid "old_val:*:new_val (interval [old_val, inf])"
+msgstr ""
+#: ../raster/r.recode/read_rules.c:92
+msgid "When finished type \"end\"."
+msgstr ""
+#: ../raster/r.recode/read_rules.c:126 ../raster/r.quant/read_rules.c:158
+#, c-format
+msgid "%s is not a valid rule"
+msgstr ""
+#: ../raster/r.recode/main.c:49
+msgid "recode categories"
+msgstr ""
+#: ../raster/r.recode/main.c:51
+msgid "Recodes categorical raster maps."
+msgstr ""
+#: ../raster/r.recode/main.c:54
+msgid "Name of raster map to be recoded"
+msgstr ""
+#: ../raster/r.recode/main.c:60
+msgid "File containing recode rules"
+msgstr ""
+#: ../raster/r.recode/main.c:71
+msgid "Align the current region to the input raster map"
+msgstr ""
+#: ../raster/r.recode/main.c:75
+msgid "Force output to 'double' raster map type (DCELL)"
+msgstr ""
+#: ../raster/r.recode/main.c:96
+#, c-format
+msgid "No rules specified. Raster map <%s> not created."
+msgstr ""
+#: ../raster/r.random/count.c:68
+msgid "Collecting Stats..."
+msgstr ""
+#: ../raster/r.random/count.c:123
+msgid "Programmer error in get_stats/switch"
+msgstr ""
+#: ../raster/r.random/main.c:54 ../raster/r.random.surface/main.c:59
+#: ../raster/r.surf.random/main.c:38 ../raster/r.random.cells/main.c:49
+#: ../raster/r.surf.gauss/main.c:40 ../vector/v.random/main.c:100
+#: ../vector/v.perturb/main.c:65 ../vector/v.extract/main.c:81
+msgid "random"
+msgstr ""
+#: ../raster/r.random/main.c:55 ../display/d.vect/main.c:76
+#: ../general/g.region/main.c:70 ../vector/v.random/main.c:103
+#: ../vector/v.cluster/main.c:94 ../vector/v.in.lidar/main.c:139
+#: ../vector/v.patch/main.c:71 ../vector/v.perturb/main.c:67
+#: ../vector/v.rectify/main.c:72 ../vector/v.in.ascii/main.c:73
+#: ../vector/v.decimate/main.c:130 ../vector/v.edit/main.c:61
+#: ../vector/v.info/main.c:43 ../vector/v.in.dxf/main.c:67
+#: ../vector/v.external/main.c:57
+msgid "level1"
+msgstr ""
+#: ../raster/r.random/main.c:58
+msgid "Creates a raster map layer and vector point map containing randomly located points."
+msgstr ""
+#: ../raster/r.random/main.c:67
+msgid "Name of cover raster map"
+msgstr ""
+#: ../raster/r.random/main.c:74
+msgid "The number of points to allocate"
+msgstr ""
+#: ../raster/r.random/main.c:86
+msgid "Generate points also for NULL category"
+msgstr ""
+#: ../raster/r.random/main.c:91
+msgid "Report information about input raster and exit"
+msgstr ""
+#: ../raster/r.random/main.c:95
+msgid "Generate vector points as 3D points"
+msgstr ""
+#: ../raster/r.random/main.c:98 ../vector/v.in.ascii/main.c:195
+msgid "Do not build topology in points mode"
+msgstr ""
+#: ../raster/r.random/main.c:99 ../display/d.linegraph/main.c:353
+#: ../display/d.linegraph/main.c:362 ../display/d.linegraph/main.c:371
+#: ../display/d.linegraph/main.c:386 ../vector/v.out.ascii/args.c:40
+#: ../vector/v.out.ascii/args.c:66 ../vector/v.out.ascii/args.c:76
+#: ../vector/v.out.ascii/args.c:86 ../vector/v.out.ascii/args.c:92
+#: ../vector/v.in.ascii/main.c:119 ../vector/v.in.ascii/main.c:126
+#: ../vector/v.in.ascii/main.c:138 ../vector/v.in.ascii/main.c:148
+#: ../vector/v.in.ascii/main.c:158 ../vector/v.in.ascii/main.c:168
+#: ../vector/v.in.ascii/main.c:192 ../vector/v.in.ascii/main.c:196
+#: ../vector/v.in.ascii/main.c:202 ../vector/v.in.ascii/main.c:207
+msgid "Points"
+msgstr ""
+#: ../raster/r.random/main.c:143
+#, c-format
+msgid "Note: one (or both) of %s and %s must be specified"
+msgstr ""
+#: ../raster/r.random/main.c:151
+#, c-format
+msgid "<%s=%s> invalid percentage"
+msgstr ""
+#: ../raster/r.random/main.c:162
+#, c-format
+msgid "<%s=%s> invalid number of points"
+msgstr ""
+#: ../raster/r.random/main.c:176
+#, c-format
+msgid "There aren't [%llu] cells in the current region"
+msgstr ""
+#: ../raster/r.random/main.c:179
+#, c-format
+msgid "There aren't [%llu] non-NULL cells in the current region"
+msgstr ""
+#: ../raster/r.random/main.c:183
+#, c-format
+msgid "There aren't [%lu] cells in the current region"
+msgstr ""
+#: ../raster/r.random/main.c:186
+#, c-format
+msgid "There aren't [%lu] non-NULL cells in the current region"
+msgstr ""
+#: ../raster/r.random/main.c:192
+msgid "There are no valid locations in the current region"
+msgstr ""
+#: ../raster/r.random/random.c:43 ../raster/r.random/random.c:47
+#: ../raster/r.mapcalc/map3.c:518 ../imagery/i.landsat.acca/main.c:57
+#: ../imagery/i.landsat.acca/tools.c:126
+#: ../imagery/i.landsat.acca/algorithm.c:380
+#: ../imagery/i.landsat.toar/main.c:406 ../imagery/i.landsat.toar/main.c:544
+#, c-format
+msgid "Unable to open raster map <%s>"
+msgstr ""
+#: ../raster/r.random/random.c:100
+msgid "Cannot create new table"
+msgstr ""
+#: ../raster/r.random/random.c:110
+#, c-format
+msgid "Writing raster map <%s> and vector map <%s> ..."
+msgstr ""
+#: ../raster/r.random/random.c:113
+#, c-format
+msgid "Writing raster map <%s> ..."
+msgstr ""
+#: ../raster/r.random/random.c:115
+#, c-format
+msgid "Writing vector map <%s> ..."
+msgstr ""
+#: ../raster/r.random/random.c:190 ../vector/v.net.distance/main.c:363
+#: ../vector/v.net.allpairs/main.c:271 ../vector/v.net.path/path.c:350
+#: ../vector/v.net.iso/main.c:724 ../vector/v.net.iso/main.c:754
+#: ../vector/v.net.flow/main.c:262 ../vector/v.net.timetable/main.c:134
+#: ../vector/v.net.timetable/main.c:156 ../vector/v.net.components/main.c:39
+#: ../vector/v.net.centrality/main.c:69 ../vector/v.net.alloc/main.c:432
+#: ../vector/v.net.alloc/main.c:464 ../vector/v.net.alloc/main.c:495
+#: ../vector/v.net.alloc/main.c:533 ../vector/v.net.alloc/main.c:561
+#: ../vector/v.net.alloc/main.c:612 ../vector/v.net.alloc/main.c:648
+#: ../vector/v.net.alloc/main.c:679
+#, c-format
+msgid "Cannot insert new record: %s"
+msgstr ""
+#: ../raster/r.random/random.c:244
+#, c-format
+msgid "Only [%llu] random points created"
+msgstr ""
+#: ../raster/r.random/random.c:247
+#, c-format
+msgid "Only [%lu] random points created"
+msgstr ""
+#: ../raster/r.random/random.c:258 ../raster/r.to.vect/main.c:233
+#: ../db/drivers/postgres/index.c:59 ../vector/v.mkgrid/main.c:346
+#: ../vector/v.mkgrid/main.c:404 ../vector/v.random/main.c:260
+#: ../vector/v.select/copy_tabs.c:87 ../vector/v.patch/main.c:328
+#: ../vector/v.overlay/main.c:592 ../vector/v.extract/copy_tab.c:124
+msgid "Unable to create index"
+msgstr ""
+#: ../raster/r.random/random.c:262 ../raster/r.contour/main.c:193
+#: ../raster/r.stream.extract/close.c:202 ../raster/r.to.vect/main.c:238
+#: ../raster3d/r3.flow/main.c:72 ../vector/v.mkgrid/main.c:350
+#: ../vector/v.mkgrid/main.c:408 ../vector/v.random/main.c:266
+#: ../vector/v.in.lidar/attributes.c:144 ../vector/v.reclass/main.c:327
+#: ../vector/v.in.dwg/main.c:249 ../vector/v.select/copy_tabs.c:90
+#: ../vector/v.in.ogr/main.c:1146 ../vector/v.patch/main.c:333
+#: ../vector/v.overlay/main.c:597 ../vector/v.sample/main.c:197
+#: ../vector/v.distance/main.c:1424 ../vector/v.in.ascii/main.c:423
+#: ../vector/v.to.points/main.c:202 ../vector/v.in.dxf/write_vect.c:238
+#: ../vector/v.extract/copy_tab.c:129
+#, c-format
+msgid "Unable to grant privileges on table <%s>"
+msgstr ""
+#: ../raster/r.spreadpath/main.c:89 ../raster/r.spread/main.c:106
+#: ../raster/r.ros/main.c:213
+msgid "fire"
+msgstr ""
+#: ../raster/r.spreadpath/main.c:92
+msgid "Recursively traces the least cost path backwards to cells from which the cumulative cost was determined."
+msgstr ""
+#: ../raster/r.spreadpath/main.c:98
+msgid "Name of raster map containing back-path easting information"
+msgstr ""
+#: ../raster/r.spreadpath/main.c:103
+msgid "Name of raster map containing back-path northing information"
+msgstr ""
+#: ../raster/r.spreadpath/main.c:108
+msgid "The map E and N grid coordinates of starting points"
+msgstr ""
+#: ../raster/r.spreadpath/main.c:161
+#, c-format
+msgid "eading the input map -%s- and -%s- and creating some temporary files..."
+msgstr ""
+#: ../raster/r.spreadpath/main.c:281
+msgid "Finding the least cost paths ..."
+msgstr ""
+#: ../raster/r.spreadpath/main.c:296
+#, c-format
+msgid "Writing the output map -%s-..."
+msgstr ""
+#: ../raster/r.uslek/main.c:55 ../raster/r.usler/main.c:55
+#: ../raster/r.sim/r.sim.sediment/main.c:116
+#: ../raster/r.sim/r.sim.water/main.c:115
+msgid "soil"
+msgstr ""
+#: ../raster/r.uslek/main.c:56 ../raster/r.usler/main.c:56
+#: ../raster/r.sim/r.sim.sediment/main.c:118
+msgid "erosion"
+msgstr ""
+#: ../raster/r.uslek/main.c:57
+msgid "Computes USLE Soil Erodibility Factor (K)."
+msgstr ""
+#: ../raster/r.uslek/main.c:62
+msgid "Name of soil sand fraction raster map [0.0-1.0]"
+msgstr ""
+#: ../raster/r.uslek/main.c:66
+msgid "Name of soil clay fraction raster map [0.0-1.0]"
+msgstr ""
+#: ../raster/r.uslek/main.c:70
+msgid "Name of soil silt fraction raster map [0.0-1.0]"
+msgstr ""
+#: ../raster/r.uslek/main.c:74
+msgid "Name of soil organic matter raster map [0.0-1.0]"
+msgstr ""
+#: ../raster/r.uslek/main.c:77
+msgid "Name for output USLE K factor raster map [t.ha.hr/ha.MJ.mm]"
+msgstr ""
+#: ../raster/r.report/main.c:69
+msgid "Reports statistics for raster maps."
+msgstr ""
+#: ../raster/r.report/label.c:13
+msgid "Page width is too small"
+msgstr ""
+#: ../raster/r.report/stats.c:93
+#, c-format
+msgid "Unable to open result file <%s>"
+msgstr ""
+#: ../raster/r.report/stats.c:128 ../raster/r.kappa/stats.c:14
+msgid "Problem reading r.stats output"
+msgstr ""
+#: ../raster/r.report/parse.c:45
+msgid "Units to report"
+msgstr ""
+#: ../raster/r.report/parse.c:49
+msgid "area in square miles"
+msgstr ""
+#: ../raster/r.report/parse.c:50
+msgid "area in square meters"
+msgstr ""
+#: ../raster/r.report/parse.c:51
+msgid "area in square kilometers"
+msgstr ""
+#: ../raster/r.report/parse.c:52
+msgid "area in acres"
+msgstr ""
+#: ../raster/r.report/parse.c:53
+msgid "area in hectares"
+msgstr ""
+#: ../raster/r.report/parse.c:54
+msgid "number of cells"
+msgstr ""
+#: ../raster/r.report/parse.c:55
+msgid "percent cover"
+msgstr ""
+#: ../raster/r.report/parse.c:75
+msgid "Page length"
+msgstr ""
+#: ../raster/r.report/parse.c:83
+msgid "Page width"
+msgstr ""
+#: ../raster/r.report/parse.c:113
+msgid "Suppress page headers"
+msgstr ""
+#: ../raster/r.report/parse.c:118
+msgid "Use formfeeds between pages"
+msgstr ""
+#: ../raster/r.report/parse.c:123
+msgid "Scientific format"
+msgstr ""
+#: ../raster/r.report/parse.c:187
+msgid "nsteps has to be > 0; using nsteps=255"
+msgstr ""
+#: ../raster/r.report/parse.c:193
+msgid "Illegal page length"
+msgstr ""
+#: ../raster/r.report/parse.c:198
+msgid "Illegal page width"
+msgstr ""
+#: ../raster/r.report/parse.c:253
+#, c-format
+msgid "Only %d unit%s allowed"
+msgstr ""
+#: ../raster/r.report/parse.c:286
+#, c-format
+msgid "Unable to read fp range for raster map <%s>"
+msgstr ""
+#: ../raster/r.report/parse.c:294 ../raster/r.mapcalc/map.c:235
+#: ../raster/r.mapcalc/map3.c:191 ../raster/r.category/main.c:148
+#: ../raster/r.category/main.c:230
+#, c-format
+msgid "Unable to read category file of raster map <%s@%s>"
+msgstr ""
+#: ../raster/r.horizon/main.c:182 ../raster/r.sunhours/main.c:75
+#: ../raster/r.sunmask/main.c:118
+msgid "sun position"
+msgstr ""
+#: ../raster/r.horizon/main.c:184
+msgid "Computes horizon angle height from a digital elevation model."
+msgstr ""
+#: ../raster/r.horizon/main.c:186
+msgid "The module has two different modes of operation: 1. Computes the entire horizon around a single point whose coordinates are given with the 'coord' option. The horizon height (in radians). 2. Computes one or more raster maps of the horizon height in a single direction. The input for this is the angle (in degrees), which is measured counterclockwise with east=0, north=90 etc. The output is the horizon height in radians."
+msgstr ""
+#: ../raster/r.horizon/main.c:203
+msgid "Direction in which you want to know the horizon height"
+msgstr ""
+#: ../raster/r.horizon/main.c:220
+msgid "Start angle for multidirectional horizon [degrees]"
+msgstr ""
+#: ../raster/r.horizon/main.c:221 ../raster/r.horizon/main.c:230
+#: ../raster/r.horizon/main.c:238 ../raster/r.horizon/main.c:246
+#: ../raster/r.horizon/main.c:254 ../raster/r.horizon/main.c:262
+#: ../raster/r.horizon/main.c:270 ../raster/r.horizon/main.c:283
+msgid "Raster mode"
+msgstr ""
+#: ../raster/r.horizon/main.c:229
+msgid "End angle for multidirectional horizon [degrees]"
+msgstr ""
+#: ../raster/r.horizon/main.c:237
+msgid "For horizon rasters, read from the DEM an extra buffer around the present region"
+msgstr ""
+#: ../raster/r.horizon/main.c:245
+msgid "For horizon rasters, read from the DEM an extra buffer eastward the present region"
+msgstr ""
+#: ../raster/r.horizon/main.c:253
+msgid "For horizon rasters, read from the DEM an extra buffer westward the present region"
+msgstr ""
+#: ../raster/r.horizon/main.c:261
+msgid "For horizon rasters, read from the DEM an extra buffer northward the present region"
+msgstr ""
+#: ../raster/r.horizon/main.c:269
+msgid "For horizon rasters, read from the DEM an extra buffer southward the present region"
+msgstr ""
+#: ../raster/r.horizon/main.c:277
+msgid "The maximum distance to consider when finding the horizon height"
+msgstr ""
+#: ../raster/r.horizon/main.c:288
+msgid "Coordinate for which you want to calculate the horizon"
+msgstr ""
+#: ../raster/r.horizon/main.c:289 ../raster/r.horizon/main.c:305
+msgid "Point mode"
+msgstr ""
+#: ../raster/r.horizon/main.c:310
+msgid "Write output in degrees (default is radians)"
+msgstr ""
+#: ../raster/r.horizon/main.c:315
+msgid "Write output in compass orientation (default is CCW, East=0)"
+msgstr ""
+#: ../raster/r.horizon/main.c:355
+msgid "Note: In latitude-longitude coordinate system specify buffers in degree unit"
+msgstr ""
+#: ../raster/r.horizon/main.c:368
+msgid "Can't read the coordinates from the \"coordinate\" option."
+msgstr ""
+#: ../raster/r.horizon/main.c:395
+msgid "You didn't specify a direction value or step size. Aborting."
+msgstr ""
+#: ../raster/r.horizon/main.c:400
+msgid "You didn't specify a horizon raster name. Aborting."
+msgstr ""
+#: ../raster/r.horizon/main.c:415
+msgid "Negative values of start angle are not allowed. Aborting."
+msgstr ""
+#: ../raster/r.horizon/main.c:419
+msgid "End angle is not between 0 and 360. Aborting."
+msgstr ""
+#: ../raster/r.horizon/main.c:423
+msgid "You specify a start grater than the end angle. Aborting."
+msgstr ""
+#: ../raster/r.horizon/main.c:431
+msgid "You didn't specify an angle step size. Aborting."
+msgstr ""
+#: ../raster/r.horizon/main.c:442
+msgid "Could not read bufferzone size. Aborting."
+msgstr ""
+#: ../raster/r.horizon/main.c:447 ../raster/r.horizon/main.c:453
+#: ../raster/r.horizon/main.c:460 ../raster/r.horizon/main.c:467
+#, c-format
+msgid "Could not read %s bufferzone size. Aborting."
+msgstr ""
+#: ../raster/r.horizon/main.c:448
+msgid "east"
+msgstr ""
+#: ../raster/r.horizon/main.c:454
+msgid "west"
+msgstr ""
+#: ../raster/r.horizon/main.c:461
+msgid "south"
+msgstr ""
+#: ../raster/r.horizon/main.c:468
+msgid "north"
+msgstr ""
+#: ../raster/r.horizon/main.c:473
+msgid "Could not read maximum distance. Aborting."
+msgstr ""
+#: ../raster/r.horizon/main.c:484
+msgid "The distance value must be 0.5-1.5. Aborting."
+msgstr ""
+#: ../raster/r.horizon/main.c:654 ../raster/r.in.ascii/main.c:187
+#, c-format
+msgid "OOPS: rows changed from %d to %d"
+msgstr ""
+#: ../raster/r.horizon/main.c:658 ../raster/r.in.ascii/main.c:190
+#, c-format
+msgid "OOPS: cols changed from %d to %d"
+msgstr ""
+#: ../raster/r.horizon/main.c:1174
+#, c-format
+msgid "Calculating map %01d of %01d (angle %.2f, raster map <%s>)"
+msgstr ""
+#: ../raster/r.quant/read_rules.c:50
+msgid "Old data range is empty"
+msgstr ""
+#: ../raster/r.quant/read_rules.c:56
+#, c-format
+msgid "Old data range is %s to %s"
+msgstr ""
+#: ../raster/r.quant/read_rules.c:59
+msgid "Old integer data range is empty"
+msgstr ""
+#: ../raster/r.quant/read_rules.c:61
+#, c-format
+msgid "Old integer data range is %d to %d"
+msgstr ""
+#: ../raster/r.quant/read_rules.c:83
+#, c-format
+msgid "unable to open input file <%s>"
+msgstr ""
+#: ../raster/r.quant/read_rules.c:89
+#, c-format
+msgid ""
+"\n"
+"Enter the rule or 'help' for the format description or 'end' to exit:\n"
+msgstr ""
+#: ../raster/r.quant/read_rules.c:112
+msgid "quant rules do not cover the whole range map"
+msgstr ""
+#: ../raster/r.quant/main.c:49
+msgid "quantization"
+msgstr ""
+#: ../raster/r.quant/main.c:51
+msgid "Produces the quantization file for a floating-point map."
+msgstr ""
+#: ../raster/r.quant/main.c:59
+msgid "Raster map(s) to be quantized"
+msgstr ""
+#: ../raster/r.quant/main.c:64
+msgid "Path to rules file (\"-\" to read from stdin)"
+msgstr ""
+#: ../raster/r.quant/main.c:70
+msgid "Base map to take quant rules from"
+msgstr ""
+#: ../raster/r.quant/main.c:75
+msgid "Floating point range: dmin,dmax"
+msgstr ""
+#: ../raster/r.quant/main.c:81
+msgid "Integer range: min,max"
+msgstr ""
+#: ../raster/r.quant/main.c:86
+msgid "Truncate floating point data"
+msgstr ""
+#: ../raster/r.quant/main.c:90
+msgid "Round floating point data"
+msgstr ""
+#: ../raster/r.quant/main.c:111
+#, c-format
+msgid "-%c, -%c, %s=, %s= and %s= are mutually exclusive"
+msgstr ""
+#: ../raster/r.quant/main.c:120
+#, c-format
+msgid "%s= and %s= must be used together"
+msgstr ""
+#: ../raster/r.quant/main.c:131
+#, c-format
+msgid "%s is integer map, it can't be quantized"
+msgstr ""
+#: ../raster/r.quant/main.c:139
+msgid "Truncating..."
+msgstr ""
+#: ../raster/r.quant/main.c:144
+msgid "Rounding..."
+msgstr ""
+#: ../raster/r.quant/main.c:152
+#, c-format
+msgid "%s is integer map, it can't be used as basemap"
+msgstr ""
+#: ../raster/r.quant/main.c:156
+#, c-format
+msgid "unable to read quant rules for basemap <%s>"
+msgstr ""
+#: ../raster/r.quant/main.c:163 ../raster/r.quant/main.c:166
+#, c-format
+msgid "invalid value for %s= <%s>"
+msgstr ""
+#: ../raster/r.quant/main.c:168
+#, c-format
+msgid "Setting quant rules for input map(s) to (%f,%f) -> (%d,%d)"
+msgstr ""
+#: ../raster/r.quant/main.c:181
+msgid "No rules specified. Quant table(s) not changed."
+msgstr ""
+#: ../raster/r.quant/main.c:189
+#, c-format
+msgid "New quant table created for %s"
+msgstr ""
+#: ../raster/r.series.accumulate/main.c:84
+msgid "Makes each output cell value a accumulationfunction of the values assigned to the corresponding cells in the input raster map layers."
+msgstr ""
+#: ../raster/r.series.accumulate/main.c:90
+msgid "Existing map to be added to output"
+msgstr ""
+#: ../raster/r.series.accumulate/main.c:98
+msgid "Input file with raster map names, one per line"
+msgstr ""
+#: ../raster/r.series.accumulate/main.c:109
+msgid "Scale factor for input"
+msgstr ""
+#: ../raster/r.series.accumulate/main.c:116
+msgid "Shift factor for input"
+msgstr ""
+#: ../raster/r.series.accumulate/main.c:121
+msgid "The raster map specifying the lower accumulation limit, also called baseline"
+msgstr ""
+#: ../raster/r.series.accumulate/main.c:126
+msgid "The raster map specifying the upper accumulation limit, also called cutoff. Only applied to BEDD computation."
+msgstr ""
+#: ../raster/r.series.accumulate/main.c:132 ../raster/r.series/main.c:183
+msgid "Ignore values outside this range"
+msgstr ""
+#: ../raster/r.series.accumulate/main.c:139
+msgid "Use these limits in case lower and/or upper input maps are not defined"
+msgstr ""
+#: ../raster/r.series.accumulate/main.c:151
+msgid "Growing Degree Days or Winkler indices"
+msgstr ""
+#: ../raster/r.series.accumulate/main.c:152
+msgid "Mean: sum(input maps)/(number of input maps)"
+msgstr ""
+#: ../raster/r.series.accumulate/main.c:153
+msgid "Biologically Effective Degree Days"
+msgstr ""
+#: ../raster/r.series.accumulate/main.c:154
+msgid "Huglin Heliothermal index"
+msgstr ""
+#: ../raster/r.series.accumulate/main.c:163 ../raster/r.series/main.c:191
+msgid "Do not keep files open"
+msgstr ""
+#: ../raster/r.series.accumulate/main.c:167
+msgid "Create a FCELL map (floating point single precision) as output"
+msgstr ""
+#: ../raster/r.series.accumulate/main.c:206 ../raster/r.neighbors/main.c:266
+#: ../raster/r.series/main.c:204 ../raster/r.mapcalc/main.c:131
+#: ../raster/r.series.interp/main.c:118 ../raster/r.series.interp/main.c:122
+#: ../raster/r.series.interp/main.c:134 ../raster/r.series.interp/main.c:138
+#: ../raster/r.external/main.c:170 ../vector/v.colors/main.c:206
+#, c-format
+msgid "%s= and %s= are mutually exclusive"
+msgstr ""
+#: ../raster/r.series.accumulate/main.c:210 ../raster/r.series/main.c:208
+#: ../raster/r.series.interp/main.c:126 ../raster/r.series.interp/main.c:142
+#, c-format
+msgid "Please specify %s= or %s="
+msgstr ""
+#: ../raster/r.series.accumulate/main.c:255 ../raster/r.series/main.c:275
+msgid "No raster map name found in input file"
+msgstr ""
+#: ../raster/r.series.accumulate/main.c:318 ../raster/r.slope.aspect/main.c:567
+#: ../raster/r.series/main.c:386 ../raster/r.patch/main.c:140
+#: ../raster/r.series.interp/main.c:339 ../raster/r.relief/main.c:316
+msgid "Percent complete..."
+msgstr ""
+#: ../raster/r.series.accumulate/main.c:354
+#, c-format
+msgid "'%s'=%f must be > '%s'=%f"
+msgstr ""
+#: ../raster/r.rescale.eq/main.c:53 ../raster/r.rescale/main.c:49
+msgid "rescale"
+msgstr ""
+#: ../raster/r.rescale.eq/main.c:55
+msgid "Rescales histogram equalized the range of category values in a raster map layer."
+msgstr ""
+#: ../raster/r.rescale.eq/main.c:61 ../raster/r.rescale/main.c:56
+msgid "The name of the raster map to be rescaled"
+msgstr ""
+#: ../raster/r.rescale.eq/main.c:69 ../raster/r.rescale/main.c:64
+msgid "The input data range to be rescaled (default: full range of input map)"
+msgstr ""
+#: ../raster/r.rescale.eq/main.c:72 ../raster/r.rescale/main.c:67
+msgid "The resulting raster map name"
+msgstr ""
+#: ../raster/r.rescale.eq/main.c:79 ../raster/r.rescale/main.c:74
+msgid "The output data range"
+msgstr ""
+#: ../raster/r.rescale.eq/main.c:86 ../raster/r.rescale/main.c:81
+msgid "Title for new raster map"
+msgstr ""
+#: ../raster/r.rescale.eq/main.c:115
+#, c-format
+msgid "Rescale %s[%d,%d] to %s[%d,%d]"
+msgstr ""
+#: ../raster/r.rescale.eq/get_stats.c:19 ../raster/r.rescale/get_range.c:24
+#, c-format
+msgid "Reading %s ..."
+msgstr ""
+#: ../raster/r.distance/distance.c:102
+#, c-format
+msgid "Reading maps <%s,%s> while finding 0 distance ..."
+msgstr ""
+#: ../raster/r.distance/main.c:42
+msgid "Locates the closest points between objects in two raster maps."
+msgstr ""
+#: ../raster/r.distance/edges.c:47
+#, c-format
+msgid "Reading map %s ..."
+msgstr ""
+#: ../raster/r.distance/report.c:61
+#: ../scripts/i.colors.enhance/i.colors.enhance.py:153
+#: ../scripts/i.colors.enhance/i.colors.enhance.py:176
+#: ../scripts/i.colors.enhance/i.colors.enhance.py:186
+#: ../scripts/i.colors.enhance/i.colors.enhance.py:210
+msgid "Processing..."
+msgstr ""
+#: ../raster/r.distance/parse.c:35
+msgid "Name of two input raster maps for computing inter-class distances"
+msgstr ""
+#: ../raster/r.distance/parse.c:45
+msgid "Sort output by distance"
+msgstr ""
+#: ../raster/r.distance/parse.c:46
+msgid "Default: sorted by categories"
+msgstr ""
+#: ../raster/r.distance/parse.c:50
+msgid "Sort by distance in ascending order"
+msgstr ""
+#: ../raster/r.distance/parse.c:51
+msgid "Sort by distance in descending order"
+msgstr ""
+#: ../raster/r.distance/parse.c:55
+msgid "Include category labels in the output"
+msgstr ""
+#: ../raster/r.distance/parse.c:60
+msgid "Report zero distance if rasters are overlapping"
+msgstr ""
+#: ../raster/r.distance/parse.c:64
+msgid "Report null objects as *"
+msgstr ""
+#: ../raster/r.distance/parse.c:74 ../raster/r.distance/parse.c:83
+#, c-format
+msgid "Raster map <%s> is not CELL"
+msgstr ""
+#: ../raster/r.mode/read_stats.c:14
+msgid "reading r.stats output"
+msgstr ""
+#: ../raster/r.mode/main.c:59
+msgid "Finds the mode of values in a cover map within areas assigned the same category value in a user-specified base map."
+msgstr ""
+#: ../raster/r.mode/main.c:65
+msgid "Base map to be reclassified"
+msgstr ""
+#: ../raster/r.mode/main.c:72
+msgid "Coverage map"
+msgstr ""
+#: ../raster/r.mode/main.c:79
+msgid "Output map"
+msgstr ""
+#: ../raster/r.mode/main.c:92
+#, c-format
+msgid "%s: Unable to read category labels"
+msgstr ""
+#: ../raster/r.spread/main.c:107 ../raster/r.ros/main.c:214
+msgid "spread"
+msgstr ""
+#: ../raster/r.spread/main.c:108 ../raster/r.ros/main.c:216
+#: ../raster/r.lake/main.c:152
+msgid "hazard"
+msgstr ""
+#: ../raster/r.spread/main.c:111
+msgid "Simulates elliptically anisotropic spread."
+msgstr ""
+#: ../raster/r.spread/main.c:113
+msgid "Generates a raster map of the cumulative time of spread, given raster maps containing the rates of spread (ROS), the ROS directions and the spread origins. It optionally produces raster maps to contain backlink UTM coordinates for tracing spread paths. Usable for fire spread simulations."
+msgstr ""
+#: ../raster/r.spread/main.c:127
+msgid "Raster map containing base ROS (cm/min)"
+msgstr ""
+#: ../raster/r.spread/main.c:129
+msgid "Name of an existing raster map layer in the user's current mapset search path containing the ROS values in the directions perpendicular to maximum ROSes' (cm/minute). These ROSes are also the ones without the effect of directional factors."
+msgstr ""
+#: ../raster/r.spread/main.c:141
+msgid "Raster map containing maximal ROS (cm/min)"
+msgstr ""
+#: ../raster/r.spread/main.c:143
+msgid "Name of an existing raster map layer in the user's current mapset search path containing the maximum ROS values (cm/minute)."
+msgstr ""
+#: ../raster/r.spread/main.c:153
+msgid "Raster map containing directions of maximal ROS (degree)"
+msgstr ""
+#: ../raster/r.spread/main.c:155
+msgid "Name of an existing raster map layer in the user's current mapset search path containing directions of the maximum ROSes, clockwise from north (degree)."
+msgstr ""
+#: ../raster/r.spread/main.c:166
+msgid "Raster map containing starting sources"
+msgstr ""
+#: ../raster/r.spread/main.c:168
+msgid "Name of an existing raster map layer in the user's current mapset search path containing starting locations of the spread phenomenon. Any positive integers in this map are recognized as starting sources (seeds)."
+msgstr ""
+#: ../raster/r.spread/main.c:179
+msgid "Raster map containing maximal spotting distance (m, required with -s)"
+msgstr ""
+#: ../raster/r.spread/main.c:181
+msgid "Name of an existing raster map layer in the user's current mapset search path containing the maximum potential spotting distances (meters)."
+msgstr ""
+#: ../raster/r.spread/main.c:191
+msgid "Raster map containing midflame wind speed (ft/min, required with -s)"
+msgstr ""
+#: ../raster/r.spread/main.c:193 ../raster/r.ros/main.c:279
+msgid "Name of an existing raster map layer in the user's current mapset search path containing wind velocities at half of the average flame height (feet/minute)."
+msgstr ""
+#: ../raster/r.spread/main.c:203
+msgid "Raster map containing fine fuel moisture of the cell receiving a spotting firebrand (%, required with -s)"
+msgstr ""
+#: ../raster/r.spread/main.c:205 ../raster/r.ros/main.c:240
+msgid "Name of an existing raster map layer in the user's current mapset search path containing the 1-hour (<.25\") fuel moisture (percentage content multiplied by 100)."
+msgstr ""
+#: ../raster/r.spread/main.c:215
+msgid "Basic sampling window size needed to meet certain accuracy (3)"
+msgstr ""
+#: ../raster/r.spread/main.c:217
+msgid "An odd integer ranging 3 - 15 indicating the basic sampling window size within which all cells will be considered to see whether they will be reached by the current spread cell. The default number is 3 which means a 3x3 window."
+msgstr ""
+#: ../raster/r.spread/main.c:227
+msgid "Sampling density for additional computing (range: 0.0 - 1.0 (0.5))"
+msgstr ""
+#: ../raster/r.spread/main.c:229
+msgid "A decimal number ranging 0.0 - 1.0 indicating additional sampling cells will be considered to see whether they will be reached by the current spread cell. The closer to 1.0 the decimal number is, the longer the program will run and the higher the simulation accuracy will be. The default number is 0.5."
+msgstr ""
+#: ../raster/r.spread/main.c:241
+msgid "Initial time for current simulation (0) (min)"
+msgstr ""
+#: ../raster/r.spread/main.c:243
+msgid "A non-negative number specifying the initial time for the current spread simulation (minutes). This is useful when multiple phase simulation is conducted. The default time is 0."
+msgstr ""
+#: ../raster/r.spread/main.c:252
+msgid "Simulating time duration LAG (fill the region) (min)"
+msgstr ""
+#: ../raster/r.spread/main.c:254
+msgid "A non-negative integer specifying the simulating duration time lag (minutes). The default is infinite, but the program will terminate when the current geographic region/mask has been filled. It also controls the computational time, the shorter the time lag, the faster the program will run."
+msgstr ""
+#: ../raster/r.spread/main.c:266
+msgid "Name of raster map as a display backdrop"
+msgstr ""
+#: ../raster/r.spread/main.c:268
+msgid "Name of an existing raster map layer in the user's current mapset search path to be used as the background on which the \"live\" movement will be shown."
+msgstr ""
+#: ../raster/r.spread/main.c:279
+msgid "Raster map to contain output spread time (min)"
+msgstr ""
+#: ../raster/r.spread/main.c:281
+msgid "Name of the new raster map layer to contain the results of the cumulative spread time needed for a phenomenon to reach each cell from the starting sources (minutes)."
+msgstr ""
+#: ../raster/r.spread/main.c:291
+msgid "Name of raster map to contain X back coordinates"
+msgstr ""
+#: ../raster/r.spread/main.c:293
+msgid "Name of the new raster map layer to contain the results of backlink information in UTM easting coordinates for each cell."
+msgstr ""
+#: ../raster/r.spread/main.c:303
+msgid "Name of raster map to contain Y back coordinates"
+msgstr ""
+#: ../raster/r.spread/main.c:305
+msgid "Name of the new raster map layer to contain the results of backlink information in UTM northing coordinates for each cell."
+msgstr ""
+#: ../raster/r.spread/main.c:312
+msgid "DISPLAY 'live' spread process on screen"
+msgstr ""
+#: ../raster/r.spread/main.c:314
+msgid "Display the 'live' simulation on screen. A graphics window must be opened and selected before using this option."
+msgstr ""
+#: ../raster/r.spread/main.c:320
+msgid "Consider spotting effect (for wildfires)"
+msgstr ""
+#: ../raster/r.spread/main.c:324
+msgid "Use start raster map values in output spread time raster map"
+msgstr ""
+#: ../raster/r.spread/main.c:326
+msgid "Designed to be used with output of previous run of r.spread when computing spread iteratively. The values in start raster map are considered as time. Allowed values in raster map are from zero to the value of init_time option. If not enabled, init_time is used in the area of start raster map"
+msgstr ""
+#: ../raster/r.spread/main.c:502
+msgid "Reading inputs..."
+msgstr ""
+#: ../raster/r.spread/main.c:543
+#, c-format
+msgid "Maximum of start raster map is grater than init_time (%d > %d)"
+msgstr ""
+#: ../raster/r.spread/main.c:547
+#, c-format
+msgid "Minimum of start raster map is less than zero (%d < 0)"
+msgstr ""
+#: ../raster/r.spread/main.c:555
+#, c-format
+msgid "Reading %s..."
+msgstr ""
+#: ../raster/r.support.stats/main.c:37
+msgid "Update raster map statistics"
+msgstr ""
+#: ../raster/r.support.stats/main.c:49
+#, c-format
+msgid "Statistics for <%s> updated"
+msgstr ""
+#: ../raster/r.support.stats/check.c:43
+#, c-format
+msgid "Updating statistics for [%s]..."
+msgstr ""
+#: ../raster/r.support.stats/check.c:56
+msgid "Updating histogram range..."
+msgstr ""
+#: ../raster/r.support.stats/check.c:88
+#, c-format
+msgid "Updating the number of categories for [%s]..."
+msgstr ""
+#: ../raster/r.to.rast3elev/main.c:99
+msgid "The number of input and elevation maps is not equal"
+msgstr ""
+#: ../raster/r.to.rast3elev/main.c:165
+msgid "The value to fill the upper cells, default is null"
+msgstr ""
+#: ../raster/r.to.rast3elev/main.c:172
+msgid "The value to fill the lower cells, default is null"
+msgstr ""
+#: ../raster/r.to.rast3elev/main.c:185
+msgid "Use the input map values to fill the upper cells"
+msgstr ""
+#: ../raster/r.to.rast3elev/main.c:190
+msgid "Use the input map values to fill the lower cells"
+msgstr ""
+#: ../raster/r.to.rast3elev/main.c:194 ../raster3d/r3.out.netcdf/main.c:116
+#: ../raster3d/r3.cross.rast/main.c:109 ../raster3d/r3.to.rast/main.c:128
+#: ../raster3d/r3.out.ascii/main.c:118
+msgid "Use 3D raster mask (if exists) with input map"
+msgstr ""
+#: ../raster/r.to.rast3elev/main.c:287 ../raster/r.to.rast3elev/main.c:320
+msgid "Error writing 3D raster double data"
+msgstr ""
+#: ../raster/r.to.rast3elev/main.c:366
+msgid "Creates a 3D volume map based on 2D elevation and value raster maps."
+msgstr ""
+#: ../raster/r.to.rast3elev/main.c:400
+msgid "The upper value is not valid"
+msgstr ""
+#: ../raster/r.to.rast3elev/main.c:410
+msgid "The lower value is not valid"
+msgstr ""
+#: ../raster/r.to.rast3elev/main.c:427
+msgid "The 2D and 3D region settings are different. I will use the 3D region settings to adjust the 2D region."
+msgstr ""
+#: ../raster/r.usler/main.c:54
+msgid "rainfall"
+msgstr ""
+#: ../raster/r.usler/main.c:57
+msgid "Computes USLE R factor, Rainfall erosivity index."
+msgstr ""
+#: ../raster/r.usler/main.c:60
+msgid "Name of annual precipitation raster map [mm/year]"
+msgstr ""
+#: ../raster/r.usler/main.c:63
+msgid "Name for output USLE R raster map [MJ.mm/ha.hr.year]"
+msgstr ""
+#: ../raster/r.usler/main.c:70
+msgid "Name of USLE R equation"
+msgstr ""
+#: ../raster/r.usler/main.c:75
+msgid "Roosle (1975)"
+msgstr ""
+#: ../raster/r.usler/main.c:76
+msgid "Morgan (1974)"
+msgstr ""
+#: ../raster/r.usler/main.c:77
+msgid "Foster (1981)"
+msgstr ""
+#: ../raster/r.usler/main.c:78
+msgid "El-Swaify (1985)"
+msgstr ""
+#: ../raster/r.thin/main.c:60
+msgid "Thins non-null cells that denote linear features in a raster map layer."
+msgstr ""
+#: ../raster/r.thin/main.c:72
+msgid "Maximal number of iterations"
+msgstr ""
+#: ../raster/r.thin/io.c:98
+msgid "Input raster must be of type CELL."
+msgstr ""
+#. GTC Count of raster rows
+#. GTC Count of window rows
+#: ../raster/r.thin/io.c:105 ../raster/r.thin/io.c:172
+#: ../raster/r.thin/io.c:181 ../display/d.rast.num/main.c:199
+#: ../vector/v.surf.idw/main.c:259 ../vector/v.kernel/main.c:302
+#, c-format
+msgid "%d row"
+msgid_plural "%d rows"
+msgstr[0] ""
+msgstr[1] ""
+#. GTC Count of raster columns
+#. GTC Count of window columns
+#: ../raster/r.thin/io.c:107 ../raster/r.thin/io.c:174
+#: ../raster/r.thin/io.c:183 ../vector/v.surf.idw/main.c:261
+#: ../vector/v.kernel/main.c:303
+#, c-format
+msgid "%d column"
+msgid_plural "%d columns"
+msgstr[0] ""
+msgstr[1] ""
+#. GTC First argument is the raster map name, second and third - a string representing number of rows and cols
+#: ../raster/r.thin/io.c:109
+#, c-format
+msgid "Raster map <%s> - %s X %s"
+msgstr ""
+#: ../raster/r.thin/io.c:122
+#, c-format
+msgid "Unable to create temporary file <%s> -- errno = %d"
+msgstr ""
+#. GTC %s will be replaced with number of rows and columns
+#: ../raster/r.thin/io.c:176
+#, c-format
+msgid "Output map %s X %s"
+msgstr ""
+#: ../raster/r.thin/io.c:185
+#, c-format
+msgid "Window %s X %s"
+msgstr ""
+#: ../raster/r.thin/thin_lines.c:67
+msgid "Unable to find bounding box for lines"
+msgstr ""
+#: ../raster/r.thin/thin_lines.c:69
+#, c-format
+msgid "Bounding box: l = %d, r = %d, t = %d, b = %d"
+msgstr ""
+#: ../raster/r.thin/thin_lines.c:116
+#, c-format
+msgid "Pass number %d"
+msgstr ""
+#: ../raster/r.thin/thin_lines.c:167
+#, c-format
+msgid "Deleted %d pixel"
+msgid_plural "Deleted %d pixels"
+msgstr[0] ""
+msgstr[1] ""
+#: ../raster/r.thin/thin_lines.c:171
+msgid "Thinning completed successfully."
+msgstr ""
+#: ../raster/r.thin/thin_lines.c:173
+msgid "Thinning not completed, consider to increase 'iterations' parameter."
+msgstr ""
+#: ../raster/r.out.vtk/main.c:62
+msgid "Converts raster maps into the VTK-ASCII format."
+msgstr ""
+#: ../raster/r.out.vtk/main.c:73
+msgid "No input maps specified. You need to specify at least one input map or three vector maps or three rgb maps."
+msgstr ""
+#: ../raster/r.out.vtk/main.c:131 ../raster/r.out.vtk/main.c:191
+#: ../raster/r.out.vtk/main.c:212 ../raster/r.out.vtk/main.c:251
+#, c-format
+msgid "Open Raster file %s"
+msgstr ""
+#: ../raster/r.out.vtk/main.c:222
+msgid "Writing VTK ImageData\n"
+msgstr ""
+#: ../raster/r.out.vtk/main.c:232
+msgid "Wrong RGB maps. Maps should have the same type! RGB output not added!"
+msgstr ""
+#: ../raster/r.out.vtk/main.c:261
+msgid "Writing VTK Vector Data\n"
+msgstr ""
+#: ../raster/r.out.vtk/main.c:271
+msgid "Wrong vector maps. Maps should have the same type! Vector output not added!"
+msgstr ""
+#: ../raster/r.out.vtk/main.c:283
+msgid "Error closing VTK-ASCII file"
+msgstr ""
+#: ../raster/r.out.vtk/writeascii.c:75
+msgid "write_vtk_normal_header: Writing VTK-Header"
+msgstr ""
+#: ../raster/r.out.vtk/writeascii.c:108
+msgid "write_vtk_structured_elevation_header: Writing VTK-Header"
+msgstr ""
+#: ../raster/r.out.vtk/writeascii.c:124
+msgid "write_vtk_polygonal_elevation_header: Writing VTK-Header"
+msgstr ""
+#: ../raster/r.out.vtk/writeascii.c:139
+msgid "write_vtk_celldata_header: Writing VTK-DataHeader"
+msgstr ""
+#: ../raster/r.out.vtk/writeascii.c:148
+msgid "writeVTKPointHeader: Writing VTK-DataHeader"
+msgstr ""
+#: ../raster/r.out.vtk/writeascii.c:169
+msgid "write_vtk_structured_coordinates: Writing Coordinates"
+msgstr ""
+#: ../raster/r.out.vtk/writeascii.c:225
+msgid "write_vtk_polygonal_coordinates: Writing VTK Polygonal data"
+msgstr ""
+#: ../raster/r.out.vtk/writeascii.c:334
+msgid "write_vtk_data: Writing VTK-Data"
+msgstr ""
+#: ../raster/r.out.vtk/writeascii.c:384
+msgid "write_vtk_rgb_image_data: Writing VTK-ImageData"
+msgstr ""
+#: ../raster/r.out.vtk/writeascii.c:412
+msgid "Wrong map values! Values should in between 0 and 255!\n"
+msgstr ""
+#: ../raster/r.out.vtk/writeascii.c:442
+msgid "write_vtk_vector_data: Writing VTK-vector data"
+msgstr ""
+#: ../raster/r.out.vtk/parameters.c:32
+msgid "Raster map(s) to be converted to VTK-ASCII data format"
+msgstr ""
+#: ../raster/r.out.vtk/parameters.c:36 ../raster3d/r3.out.vtk/parameters.c:34
+msgid "Name for VTK-ASCII output file"
+msgstr ""
+#: ../raster/r.out.vtk/parameters.c:53
+msgid "Constant elevation (if no elevation map is specified)"
+msgstr ""
+#: ../raster/r.out.vtk/parameters.c:69
+msgid "Three (r,g,b) raster maps to create RGB values [redmap,greenmap,bluemap]"
+msgstr ""
+#: ../raster/r.out.vtk/parameters.c:79
+msgid "Three (x,y,z) raster maps to create vector values [xmap,ymap,zmap]"
+msgstr ""
+#: ../raster/r.out.vtk/parameters.c:85 ../raster3d/r3.out.vtk/parameters.c:94
+#: ../vector/v.out.vtk/main.c:76
+msgid "Scale factor for elevation"
+msgstr ""
+#: ../raster/r.out.vtk/parameters.c:98 ../raster/r.out.ascii/main.c:79
+#: ../display/d.rast.num/main.c:104 ../raster3d/r3.out.vtk/parameters.c:107
+#: ../vector/v.out.vtk/main.c:70 ../vector/v.out.ascii/args.c:75
+msgid "Number of significant digits (floating point only)"
+msgstr ""
+#: ../raster/r.out.vtk/parameters.c:104
+msgid "Use structured grid for elevation (not recommended)"
+msgstr ""
+#: ../raster/r.out.vtk/parameters.c:110
+msgid "Use polydata-trianglestrips for elevation grid creation"
+msgstr ""
+#: ../raster/r.out.vtk/parameters.c:116
+msgid "Use polydata-vertices for elevation grid creation (to use with vtkDelauny2D)"
+msgstr ""
+#: ../raster/r.out.vtk/parameters.c:122
+msgid "Scale factor affects the origin (if no elevation map is given)"
+msgstr ""
+#: ../raster/r.out.vtk/parameters.c:128 ../raster3d/r3.out.vtk/parameters.c:123
+msgid "Correct the coordinates to match the VTK-OpenGL precision"
+msgstr ""
+#: ../raster/r.colors.out/raster_main.c:49
+msgid "Exports the color table associated with a raster map."
+msgstr ""
+#: ../raster/r.colors.out/raster_main.c:55
+#: ../raster/r.colors.out/raster3d_main.c:56 ../vector/v.colors.out/main.c:61
+msgid "Path to output rules file"
+msgstr ""
+#: ../raster/r.colors.out/raster_main.c:56
+#: ../raster/r.colors.out/raster3d_main.c:57 ../raster/r.kappa/main.c:89
+#: ../vector/v.colors.out/main.c:62
+msgid "If not given write to standard output"
+msgstr ""
+#: ../raster/r.colors.out/raster_main.c:61
+#: ../raster/r.colors.out/raster3d_main.c:62 ../vector/v.colors.out/main.c:72
+msgid "Output values as percentages"
+msgstr ""
+#: ../raster/r.colors.out/raster3d_main.c:50
+msgid "Exports the color table associated with a 3D raster map."
+msgstr ""
+#: ../raster/r.colors.out/raster3d_main.c:70
+#, c-format
+msgid "Unable to read color table for raster3d map <%s>"
+msgstr ""
+#: ../raster/r.gwflow/main.c:57
+msgid "Name of input raster map with initial piezometric head in [m]"
+msgstr ""
+#: ../raster/r.gwflow/main.c:62
+msgid "Name of input raster map providing boundary condition status: 0-inactive, 1-active, 2-dirichlet"
+msgstr ""
+#: ../raster/r.gwflow/main.c:67
+msgid "Name of input raster map with x-part of the hydraulic conductivity tensor in [m/s]"
+msgstr ""
+#: ../raster/r.gwflow/main.c:72
+msgid "Name of input raster map with y-part of the hydraulic conductivity tensor in [m/s]"
+msgstr ""
+#: ../raster/r.gwflow/main.c:77
+msgid "Name of input raster map with water sources and sinks in [m^3/s]"
+msgstr ""
+#: ../raster/r.gwflow/main.c:81
+msgid "Name of input raster map with storativity for confined or effective porosity for unconfined groundwater flow booth in [-] "
+msgstr ""
+#: ../raster/r.gwflow/main.c:86
+msgid "Recharge"
+msgstr ""
+#: ../raster/r.gwflow/main.c:88
+msgid "Recharge input raster map e.g: 6*10^-9 per cell in [m^3/s*m^2]"
+msgstr ""
+#: ../raster/r.gwflow/main.c:92
+msgid "Name of input raster map describing the top surface of the aquifer in [m]"
+msgstr ""
+#: ../raster/r.gwflow/main.c:96
+msgid "Name of input raster map describing the bottom surface of the aquifer in [m]"
+msgstr ""
+#: ../raster/r.gwflow/main.c:100
+msgid "Output raster map storing the numerical result [m]"
+msgstr ""
+#: ../raster/r.gwflow/main.c:106
+msgid "Output raster map to store the groundwater filter velocity vector part in x direction [m/s]"
+msgstr ""
+#: ../raster/r.gwflow/main.c:112
+msgid "Output raster map to store the groundwater filter velocity vector part in y direction [m/s]"
+msgstr ""
+#: ../raster/r.gwflow/main.c:118
+msgid "Output raster map to store the groundwater budget for each cell [m^3/s]"
+msgstr ""
+#: ../raster/r.gwflow/main.c:126
+msgid "The type of groundwater flow"
+msgstr ""
+#: ../raster/r.gwflow/main.c:132
+msgid "Name of input raster map providing the height of the river bed in [m]"
+msgstr ""
+#: ../raster/r.gwflow/main.c:140
+msgid "Name of input raster map providing the water level (head) of the river with leakage connection in [m]"
+msgstr ""
+#: ../raster/r.gwflow/main.c:147
+msgid "Name of input raster map providing the leakage coefficient of the river bed in [1/s]."
+msgstr ""
+#: ../raster/r.gwflow/main.c:155
+msgid "Name of input raster map providing the height of the drainage bed in [m]"
+msgstr ""
+#: ../raster/r.gwflow/main.c:162
+msgid "Name of input raster map providing the leakage coefficient of the drainage bed in [1/s]"
+msgstr ""
+#: ../raster/r.gwflow/main.c:167
+msgid "The maximum number of iterations in the linearization approach"
+msgstr ""
+#: ../raster/r.gwflow/main.c:176
+msgid "Allocate a full quadratic linear equation system, default is a sparse linear equation system."
+msgstr ""
+#: ../raster/r.gwflow/main.c:209 ../raster3d/r3.gwflow/main.c:160
+msgid "groundwater flow"
+msgstr ""
+#: ../raster/r.gwflow/main.c:212
+msgid "Numerical calculation program for transient, confined and unconfined groundwater flow in two dimensions."
+msgstr ""
+#: ../raster/r.gwflow/main.c:237
+msgid "Please provide river_head, river_leak and river_bed maps"
+msgstr ""
+#: ../raster/r.gwflow/main.c:249
+msgid "Please provide drain_head and drain_leak maps"
+msgstr ""
+#: ../raster/r.gwflow/main.c:263
+msgid "The cholesky solver dos not work with sparse matrices. You may choose a full filled quadratic matrix, flag -f."
+msgstr ""
+#: ../raster/r.gwflow/main.c:293
+#, c-format
+msgid "Calculation time: %g"
+msgstr ""
+#: ../raster/r.gwflow/main.c:380
+#, c-format
+msgid "Calculation of unconfined groundwater flow loop %i"
+msgstr ""
+#: ../raster/r.gwflow/main.c:403
+#, c-format
+msgid "Maximum difference between this and last increment: %g"
+msgstr ""
+#: ../raster/r.gwflow/main.c:546 ../raster3d/r3.gwflow/main.c:279
+msgid "Unable to create and solve the linear equation system"
+msgstr ""
+#: ../raster/r.describe/main.c:57
+msgid "Prints terse list of category values found in a raster map layer."
+msgstr ""
+#: ../raster/r.describe/main.c:71
+msgid "Number of quantization steps"
+msgstr ""
+#: ../raster/r.describe/main.c:77
+msgid "Print the output one value per line"
+msgstr ""
+#: ../raster/r.describe/main.c:81
+msgid "Only print the range of the data"
+msgstr ""
+#: ../raster/r.describe/main.c:85
+msgid "Suppress reporting of any NULLs"
+msgstr ""
+#: ../raster/r.describe/main.c:89
+msgid "Use the current region"
+msgstr ""
+#: ../raster/r.describe/main.c:93
+msgid "Read floating-point map as integer"
+msgstr ""
+#: ../raster/r.describe/main.c:105
+#, c-format
+msgid "%s = %s -- must be greater than zero"
+msgstr ""
+#: ../raster/r.describe/describe.c:94
+#, c-format
+msgid "Reading <%s> ..."
+msgstr ""
+#: ../raster/r.what.color/main.c:91
+msgid "Queries colors for a raster map layer."
+msgstr ""
+#: ../raster/r.what.color/main.c:99
+msgid "Name of existing raster map to query colors"
+msgstr ""
+#: ../raster/r.what.color/main.c:106
+msgid "Values to query colors for"
+msgstr ""
+#: ../raster/r.what.color/main.c:113
+msgid "Output format (printf-style)"
+msgstr ""
+#: ../raster/r.what.color/main.c:117
+msgid "Read values from stdin"
+msgstr ""
+#: ../raster/r.what.color/main.c:123
+msgid "Either \"-i\" or \"value=\" must be given"
+msgstr ""
+#: ../raster/r.neighbors/main.c:102 ../raster/r.series/main.c:104
+#: ../raster/r.resamp.stats/main.c:301 ../raster3d/r3.neighbors/main.c:94
+#, c-format
+msgid "Unknown method <%s>"
+msgstr ""
+#: ../raster/r.neighbors/main.c:121
+#, c-format
+msgid "Invalid out_type enumeration: %d"
+msgstr ""
+#: ../raster/r.neighbors/main.c:171 ../raster3d/r3.neighbors/main.c:213
+msgid "neighbor"
+msgstr ""
+#: ../raster/r.neighbors/main.c:172 ../raster3d/r3.neighbors/main.c:214
+msgid "focal statistics"
+msgstr ""
+#: ../raster/r.neighbors/main.c:175
+msgid "Makes each cell category value a function of the category values assigned to the cells around it, and stores new cell values in an output raster map layer."
+msgstr ""
+#: ../raster/r.neighbors/main.c:185
+msgid "Name of an input raster map to select the cells which should be processed"
+msgstr ""
+#: ../raster/r.neighbors/main.c:204 ../vector/v.neighbors/main.c:72
+msgid "Neighborhood operation"
+msgstr ""
+#: ../raster/r.neighbors/main.c:206 ../raster/r.neighbors/main.c:214
+#: ../raster/r.neighbors/main.c:249
+msgid "Neighborhood"
+msgstr ""
+#: ../raster/r.neighbors/main.c:226
+msgid "Text file containing weights"
+msgstr ""
+#: ../raster/r.neighbors/main.c:232
+msgid "Sigma (in cells) for Gaussian filter"
+msgstr ""
+#: ../raster/r.neighbors/main.c:244
+msgid "Do not align output with the input"
+msgstr ""
+#: ../raster/r.neighbors/main.c:248
+msgid "Use circular neighborhood"
+msgstr ""
+#: ../raster/r.neighbors/main.c:256
+msgid "Neighborhood size must be positive"
+msgstr ""
+#: ../raster/r.neighbors/main.c:258
+msgid "Neighborhood size must be odd"
+msgstr ""
+#: ../raster/r.neighbors/main.c:293
+#, c-format
+msgid "%s= and %s= must have the same number of values"
+msgstr ""
+#: ../raster/r.neighbors/main.c:329
+#, c-format
+msgid "Method %s not compatible with weighing window, using weight mask instead"
+msgstr ""
+#: ../raster/r.neighbors/main.c:337
+#, c-format
+msgid "Method %s not compatible with Gaussian filter, using unweighed version instead"
+msgstr ""
+#: ../raster/r.neighbors/main.c:386
+#, c-format
+msgid "Opening selection map <%s>"
+msgstr ""
+#: ../raster/r.neighbors/readweights.c:18
+#, c-format
+msgid "Unable to open weights file %s"
+msgstr ""
+#: ../raster/r.neighbors/readweights.c:23
+#, c-format
+msgid "Error reading weights file %s"
+msgstr ""
+#: ../raster/r.buffer/parse_dist.c:54
+#, c-format
+msgid "%s: %s - illegal distance specification"
+msgstr ""
+#: ../raster/r.buffer/main.c:131
+msgid "Parse distances error"
+msgstr ""
+#: ../raster/r.buffer/main.c:150
+#, c-format
+msgid "Pass %d (of %d)"
+msgstr ""
+#: ../raster/r.buffer/execute.c:34
+msgid "Finding buffer zones..."
+msgstr ""
+#: ../raster/r.buffer/read_map.c:52 ../raster/r.flow/io.c:89
+#: ../raster/r.flow/io.c:107
+#, c-format
+msgid "Reading input raster map <%s>..."
+msgstr ""
+#: ../raster/r.contour/main.c:89
+msgid "contours"
+msgstr ""
+#: ../raster/r.contour/main.c:91
+msgid "Produces a vector map of specified contours from a raster map."
+msgstr ""
+#: ../raster/r.contour/main.c:102 ../raster/r.contour/main.c:110
+#: ../raster/r.contour/main.c:117 ../raster/r.contour/main.c:124
+msgid "Contour levels"
+msgstr ""
+#: ../raster/r.contour/main.c:140
+#, c-format
+msgid "Neither <%s> nor <%s> option must be specified"
+msgstr ""
+#: ../raster/r.contour/main.c:183 ../raster/r.stream.extract/close.c:194
+#: ../vector/v.net.distance/main.c:291 ../vector/v.in.lidar/attributes.c:135
+#: ../vector/v.net.allpairs/main.c:179 ../vector/v.in.dwg/main.c:240
+#: ../vector/v.in.ogr/main.c:1139 ../vector/v.net.path/path.c:109
+#: ../vector/v.overlay/main.c:587 ../vector/v.net.iso/main.c:390
+#: ../vector/v.net.flow/main.c:181 ../vector/v.distance/main.c:1419
+#: ../vector/v.net.timetable/main.c:103 ../vector/v.to.points/main.c:192
+#: ../vector/v.net.components/main.c:190 ../vector/v.net.centrality/main.c:266
+#: ../vector/v.net.alloc/main.c:329
+#, c-format
+msgid "Unable to create table: '%s'"
+msgstr ""
+#: ../raster/r.contour/main.c:188 ../raster3d/r3.flow/main.c:67
+#: ../vector/v.in.lidar/attributes.c:139 ../vector/v.reclass/main.c:322
+#: ../vector/v.in.dwg/main.c:244 ../vector/v.in.ogr/main.c:1361
+#: ../vector/v.in.ascii/main.c:523 ../vector/v.to.points/main.c:197
+#: ../vector/v.in.dxf/write_vect.c:241
+#, c-format
+msgid "Unable to create index for table <%s>, key <%s>"
+msgstr ""
+#: ../raster/r.contour/main.c:203 ../vector/v.select/copy_tabs.c:17
+#: ../vector/v.voronoi/main.c:384 ../vector/v.extract/copy_tab.c:57
+#: ../vector/v.generalize/misc.c:134
+msgid "Writing attributes..."
+msgstr ""
+#: ../raster/r.contour/main.c:216 ../raster3d/r3.flow/flowline.c:60
+#: ../vector/v.overlay/line_area.c:443 ../vector/v.overlay/area_area.c:345
+#: ../vector/v.to.points/write.c:57
+#, c-format
+msgid "Unable to insert new record: '%s'"
+msgstr ""
+#: ../raster/r.contour/main.c:237 ../raster/r.in.lidar/main.c:613
+#: ../vector/v.generalize/displacement.c:78
+msgid "Reading data..."
+msgstr ""
+#: ../raster/r.contour/main.c:263
+#, c-format
+msgid "Range of data: min=%f, max=%f"
+msgstr ""
+#: ../raster/r.contour/main.c:265
+msgid "Range of data: empty"
+msgstr ""
+#: ../raster/r.contour/main.c:293 ../raster/r.contour/main.c:296
+msgid "This step value is not allowed"
+msgstr ""
+#: ../raster/r.contour/main.c:321
+#, c-format
+msgid "Range of levels: min = %f, max = %f"
+msgstr ""
+#: ../raster/r.contour/main.c:350
+msgid "Displacing data..."
+msgstr ""
+#: ../raster/r.contour/cont.c:82
+#, c-format
+msgid "Writing vector contour (one level)..."
+msgid_plural "Writing vector contours (total levels %d)..."
+msgstr[0] ""
+msgstr[1] ""
+#: ../raster/r.contour/cont.c:213
+#, c-format
+msgid "%d crossing found"
+msgid_plural "%d crossings found"
+msgstr[0] ""
+msgstr[1] ""
+#: ../raster/r.contour/cont.c:266
+msgid "Illegal edge number"
+msgstr ""
+#: ../raster/r.contour/cont.c:374
+msgid "Edge number out of range"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:168 ../raster/r.param.scale/interface.c:56
+#: ../raster/r.relief/main.c:110 ../imagery/i.topo.corr/main.c:48
+msgid "terrain"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:169
+msgid "aspect"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:170
+msgid "slope"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:171
+msgid "curvature"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:172
+msgid "Generates raster maps of slope, aspect, curvatures and partial derivatives from an elevation raster map."
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:174
+msgid "Aspect is calculated counterclockwise from east."
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:181 ../vector/v.surf.rst/main.c:201
+msgid "Name for output slope raster map"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:182 ../raster/r.slope.aspect/main.c:188
+#: ../raster/r.slope.aspect/main.c:212 ../raster/r.slope.aspect/main.c:219
+#: ../raster/r.slope.aspect/main.c:226 ../raster/r.slope.aspect/main.c:233
+#: ../raster/r.slope.aspect/main.c:240 ../raster/r.slope.aspect/main.c:247
+#: ../raster/r.slope.aspect/main.c:254 ../raster/r.watershed/front/main.c:139
+#: ../raster/r.watershed/front/main.c:146
+#: ../raster/r.watershed/front/main.c:153
+#: ../raster/r.watershed/front/main.c:160
+#: ../raster/r.watershed/front/main.c:166
+#: ../raster/r.watershed/front/main.c:172
+#: ../raster/r.watershed/front/main.c:180
+#: ../raster/r.watershed/front/main.c:188
+#: ../raster/r.watershed/front/main.c:195 ../vector/v.surf.rst/main.c:172
+#: ../vector/v.surf.rst/main.c:196 ../vector/v.surf.rst/main.c:202
+#: ../vector/v.surf.rst/main.c:208 ../vector/v.surf.rst/main.c:214
+#: ../vector/v.surf.rst/main.c:220 ../vector/v.surf.rst/main.c:226
+#: ../vector/v.surf.rst/main.c:232 ../vector/v.surf.rst/main.c:239
+#: ../vector/v.surf.rst/main.c:246 ../vector/v.surf.rst/main.c:253
+#: ../vector/v.surf.bspline/main.c:130 ../vector/v.surf.bspline/main.c:135
+#: ../vector/v.vol.rst/main.c:291 ../vector/v.vol.rst/main.c:297
+#: ../vector/v.vol.rst/main.c:360 ../vector/v.vol.rst/main.c:366
+#: ../vector/v.vol.rst/main.c:372 ../vector/v.vol.rst/main.c:379
+#: ../vector/v.vol.rst/main.c:385 ../vector/v.vol.rst/main.c:391
+#: ../vector/v.vol.rst/main.c:397 ../vector/v.vol.rst/main.c:403
+msgid "Outputs"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:187 ../vector/v.surf.rst/main.c:207
+msgid "Name for output aspect raster map"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:196
+msgid "Format for reporting the slope"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:203
+msgid "Type of output aspect and slope maps"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:211 ../vector/v.surf.rst/main.c:213
+msgid "Name for output profile curvature raster map"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:218 ../vector/v.surf.rst/main.c:219
+msgid "Name for output tangential curvature raster map"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:225
+msgid "Name for output first order partial derivative dx (E-W slope) raster map"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:232
+msgid "Name for output first order partial derivative dy (N-S slope) raster map"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:239
+msgid "Name for output second order partial derivative dxx raster map"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:246
+msgid "Name for output second order partial derivative dyy raster map"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:253
+msgid "Name for output second order partial derivative dxy raster map"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:259
+msgid "Multiplicative factor to convert elevation units to horizontal units"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:268
+msgid "Minimum slope value (in percent) for which aspect is computed"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:277
+msgid "Do not align the current region to the raster elevation map"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:283
+msgid "Create aspect as degrees clockwise from North (azimuth), with flat = -9999"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:285
+msgid "Default: degrees counter-clockwise from East, with flat = 0"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:338 ../raster/r.relief/main.c:220
+#, c-format
+msgid "%s=%s - must be a positive number"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:344 ../raster/r.relief/main.c:201
+#: ../raster/r.relief/main.c:207
+#, c-format
+msgid "%s=%s - must be a non-negative number"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:359
+#, c-format
+msgid "You must specify at least one of the parameters: <%s>, <%s>, <%s>, <%s>, <%s>, <%s>, <%s>, <%s> or <%s>"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:381
+#, c-format
+msgid "Wrong raster type: %s"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:410
+msgid "r.slope.aspect does not convert horizontal units to meters in this version, see manual page."
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:993
+#, c-format
+msgid "Elevation products for mapset <%s> in <%s>"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:1012
+#, c-format
+msgid "Min computed aspect %.4f, max computed aspect %.4f"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:1113
+#, c-format
+msgid "Aspect raster map <%s> complete"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:1170
+#, c-format
+msgid "Min computed slope %.4f, max computed slope %.4f"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:1223
+#, c-format
+msgid "Slope raster map <%s> complete"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:1295
+#, c-format
+msgid "Profile curve raster map <%s> complete"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:1322
+#, c-format
+msgid "Tangential curve raster map <%s> complete"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:1347
+#, c-format
+msgid "E-W slope raster map <%s> complete"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:1372
+#, c-format
+msgid "N-S slope raster map <%s> complete"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:1397
+#, c-format
+msgid "Dxx raster map <%s> complete"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:1422
+#, c-format
+msgid "Dyy raster map <%s> complete"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:1447
+#, c-format
+msgid "Dxy raster map <%s> complete"
+msgstr ""
+#: ../raster/r.in.ascii/main.c:74
+msgid "Converts a GRASS ASCII raster file to binary raster map."
+msgstr ""
+#: ../raster/r.in.ascii/main.c:78 ../raster3d/r3.in.ascii/main.c:86
+#: ../vector/v.in.ascii/main.c:80
+msgid "Name of input file to be imported"
+msgstr ""
+#: ../raster/r.in.ascii/main.c:85
+msgid "Default: CELL for integer values, DCELL for floating-point values"
+msgstr ""
+#: ../raster/r.in.ascii/main.c:97 ../raster/r.in.ascii/main.c:102
+msgid "Default: read from header"
+msgstr ""
+#: ../raster/r.in.ascii/main.c:99
+msgid "Multiplier for ASCII data"
+msgstr ""
+#: ../raster/r.in.ascii/main.c:103
+msgid "String representing NULL value data cell"
+msgstr ""
+#: ../raster/r.in.ascii/main.c:104
+msgid "NULL data"
+msgstr ""
+#: ../raster/r.in.ascii/main.c:109
+msgid "SURFER (Golden Software) ASCII file will be imported"
+msgstr ""
+#: ../raster/r.in.ascii/main.c:128
+#, c-format
+msgid "Wrong entry for multiplier: %s"
+msgstr ""
+#: ../raster/r.in.ascii/main.c:153 ../raster3d/r3.in.ascii/main.c:172
+msgid "Unable to read input from stdin"
+msgstr ""
+#: ../raster/r.in.ascii/main.c:160
+#, c-format
+msgid "Unable to read input from <%s>"
+msgstr ""
+#: ../raster/r.in.ascii/main.c:180
+msgid "Can't get cell header"
+msgstr ""
+#: ../raster/r.in.ascii/main.c:202
+#, c-format
+msgid "Data conversion failed at row %d, col %d"
+msgstr ""
+#: ../raster/r.in.ascii/main.c:275 ../raster3d/r3.in.ascii/main.c:130
+msgid "Unable to write to file"
+msgstr ""
+#: ../raster/r.in.ascii/gethead.c:35
+msgid "input file is not a Surfer ascii grid file"
+msgstr ""
+#: ../raster/r.in.ascii/gethead.c:41
+msgid "error reading the column and row dimension from the Surfer grid file"
+msgstr ""
+#: ../raster/r.in.ascii/gethead.c:47
+msgid "error reading the X range from the Surfer grid file"
+msgstr ""
+#: ../raster/r.in.ascii/gethead.c:53
+msgid "error reading the Y range from the Surfer grid file"
+msgstr ""
+#: ../raster/r.in.ascii/gethead.c:59
+msgid "error reading the Z range from the Surfer grid file"
+msgstr ""
+#: ../raster/r.in.ascii/gethead.c:105
+msgid "error getting file position"
+msgstr ""
+#: ../raster/r.in.ascii/gethead.c:164
+msgid "illegal type field: using type int"
+msgstr ""
+#: ../raster/r.in.ascii/gethead.c:169
+msgid "ignoring type filed in header, type is set on command line"
+msgstr ""
+#: ../raster/r.in.ascii/gethead.c:176
+msgid "illegal multiplier field: using 1.0"
+msgstr ""
+#: ../raster/r.in.ascii/gethead.c:181
+msgid "ignoring multiplier filed in header, multiplier is set on command line"
+msgstr ""
+#: ../raster/r.in.ascii/gethead.c:189
+msgid "ignoring null filed in header, null string is set on command line"
+msgstr ""
+#: ../raster/r.in.ascii/gethead.c:218
+msgid "error in ascii data format"
+msgstr ""
+#: ../raster/r.in.ascii/gethead.c:248
+#, c-format
+msgid "Duplicate \"%s\" field in header"
+msgstr ""
+#: ../raster/r.in.ascii/gethead.c:253
+#, c-format
+msgid "Illegal \"%s\" value in header: %s"
+msgstr ""
+#: ../raster/r.in.ascii/gethead.c:261
+#, c-format
+msgid "\"%s\" field missing from header"
+msgstr ""
+#: ../raster/r.stream.extract/main.c:78 ../raster/r.watershed/front/main.c:78
+msgid "stream network"
+msgstr ""
+#: ../raster/r.stream.extract/main.c:79
+msgid "Performs stream network extraction."
+msgstr ""
+#: ../raster/r.stream.extract/main.c:85
+msgid "Name of input accumulation raster map"
+msgstr ""
+#: ../raster/r.stream.extract/main.c:88
+msgid "Stream extraction will use provided accumulation instead of calculating it anew"
+msgstr ""
+#: ../raster/r.stream.extract/main.c:89 ../raster/r.stream.extract/main.c:97
+#: ../raster/r.flow/main.c:435 ../raster/r.flow/main.c:441
+msgid "Input maps"
+msgstr ""
+#: ../raster/r.stream.extract/main.c:93
+msgid "Name of input raster map with real depressions"
+msgstr ""
+#: ../raster/r.stream.extract/main.c:96
+msgid "Streams will not be routed out of real depressions"
+msgstr ""
+#: ../raster/r.stream.extract/main.c:101
+msgid "Minimum flow accumulation for streams"
+msgstr ""
+#: ../raster/r.stream.extract/main.c:102
+msgid "Must be > 0"
+msgstr ""
+#: ../raster/r.stream.extract/main.c:108
+msgid "Use SFD above this threshold"
+msgstr ""
+#: ../raster/r.stream.extract/main.c:110
+msgid "If accumulation is larger than d8cut, SFD is used instead of MFD. Applies only if no accumulation map is given."
+msgstr ""
+#: ../raster/r.stream.extract/main.c:121
+msgid "Montgomery exponent for slope, disabled with 0"
+msgstr ""
+#: ../raster/r.stream.extract/main.c:123
+msgid "Montgomery: accumulation is multiplied with pow(slope,mexp) and then compared with threshold"
+msgstr ""
+#: ../raster/r.stream.extract/main.c:131
+msgid "Delete stream segments shorter than stream_length cells"
+msgstr ""
+#: ../raster/r.stream.extract/main.c:133
+msgid "Applies only to first-order stream segments (springs/stream heads)"
+msgstr ""
+#: ../raster/r.stream.extract/main.c:146
+msgid "Name for output raster map with unique stream ids"
+msgstr ""
+#: ../raster/r.stream.extract/main.c:148 ../raster/r.stream.extract/main.c:155
+#: ../raster/r.stream.extract/main.c:162 ../raster/r.flow/main.c:459
+#: ../raster/r.flow/main.c:465 ../raster/r.flow/main.c:471
+msgid "Output maps"
+msgstr ""
+#: ../raster/r.stream.extract/main.c:153
+msgid "Name for output vector map with unique stream ids"
+msgstr ""
+#: ../raster/r.stream.extract/main.c:160
+msgid "Name for output raster map with flow direction"
+msgstr ""
+#: ../raster/r.stream.extract/main.c:191
+#, c-format
+msgid "Threshold must be > 0 but is %f"
+msgstr ""
+#: ../raster/r.stream.extract/main.c:200
+#, c-format
+msgid "d8cut must be positive or zero but is %f"
+msgstr ""
+#: ../raster/r.stream.extract/main.c:208
+#, c-format
+msgid "Montgomery exponent must be positive or zero but is %f"
+msgstr ""
+#: ../raster/r.stream.extract/main.c:211
+#, c-format
+msgid "Montgomery exponent is %f, recommended range is 0.0 - 3.0"
+msgstr ""
+#: ../raster/r.stream.extract/main.c:221
+#, c-format
+msgid "Minimum stream length must be positive or zero but is %d"
+msgstr ""
+#: ../raster/r.stream.extract/main.c:230
+#, c-format
+msgid "Memory must be positive but is %d"
+msgstr ""
+#: ../raster/r.stream.extract/main.c:240
+msgid "At least one output raster maps must be specified"
+msgstr ""
+#: ../raster/r.stream.extract/main.c:314
+#, c-format
+msgid "%.2f%% of data are kept in memory"
+msgstr ""
+#: ../raster/r.stream.extract/main.c:318
+#: ../raster/r.watershed/seg/init_vars.c:252
+#, c-format
+msgid "Will need up to %.2f MB of disk space"
+msgstr ""
+#: ../raster/r.stream.extract/main.c:320
+#: ../raster/r.watershed/seg/init_vars.c:254
+#, c-format
+msgid "Will need up to %.2f GB (%.0f MB) of disk space"
+msgstr ""
+#: ../raster/r.stream.extract/main.c:324
+msgid "Creating temporary files..."
+msgstr ""
+#: ../raster/r.stream.extract/main.c:344
+msgid "Unable to load input raster map(s)"
+msgstr ""
+#: ../raster/r.stream.extract/main.c:346
+msgid "No non-NULL cells in input raster map(s)"
+msgstr ""
+#: ../raster/r.stream.extract/main.c:397
+msgid "Unable to initialize search"
+msgstr ""
+#: ../raster/r.stream.extract/main.c:401
+msgid "Unable to sort elevation raster map values"
+msgstr ""
+#: ../raster/r.stream.extract/main.c:407
+msgid "Unable to calculate flow accumulation"
+msgstr ""
+#: ../raster/r.stream.extract/main.c:412
+msgid "Unable to extract streams"
+msgstr ""
+#: ../raster/r.stream.extract/main.c:419
+msgid "Unable to thin streams"
+msgstr ""
+#: ../raster/r.stream.extract/main.c:424
+msgid "Unable to delete short stream segments"
+msgstr ""
+#: ../raster/r.stream.extract/main.c:430
+msgid "Unable to write output raster maps"
+msgstr ""
+#: ../raster/r.stream.extract/do_astar.c:40
+msgid "A* Search..."
+msgstr ""
+#: ../raster/r.stream.extract/do_astar.c:62
+#, c-format
+msgid "%lld surplus points"
+msgstr ""
+#: ../raster/r.stream.extract/do_astar.c:67
+#, c-format
+msgid "Too many points in heap %lld, should be %lld"
+msgstr ""
+#: ../raster/r.stream.extract/cseg.c:19 ../raster/r.stream.extract/bseg.c:19
+#: ../raster/r.stream.extract/seg.c:20
+msgid "Unable to create segment file"
+msgstr ""
+#: ../raster/r.stream.extract/cseg.c:29 ../raster/r.stream.extract/cseg.c:79
+#: ../raster/r.stream.extract/cseg.c:88 ../raster/r.stream.extract/dseg.c:29
+#: ../raster/r.stream.extract/dseg.c:79 ../raster/r.stream.extract/dseg.c:88
+#: ../raster/r.stream.extract/bseg.c:28 ../raster/r.stream.extract/bseg.c:78
+#: ../raster/r.stream.extract/bseg.c:87 ../raster/r.stream.extract/seg.c:34
+#: ../raster/r.stream.extract/seg.c:76
+msgid "Unable to write segment file"
+msgstr ""
+#: ../raster/r.stream.extract/cseg.c:33 ../raster/r.stream.extract/bseg.c:32
+#: ../raster/r.stream.extract/seg.c:38
+msgid "Illegal configuration parameter(s)"
+msgstr ""
+#: ../raster/r.stream.extract/cseg.c:40 ../raster/r.stream.extract/dseg.c:40
+#: ../raster/r.stream.extract/bseg.c:39
+msgid "Unable to re-open segment file"
+msgstr ""
+#: ../raster/r.stream.extract/cseg.c:47 ../raster/r.stream.extract/dseg.c:47
+#: ../raster/r.stream.extract/dseg.c:97 ../raster/r.stream.extract/bseg.c:46
+#: ../raster/r.stream.extract/bseg.c:96 ../raster/r.stream.extract/seg.c:52
+#: ../raster/r.stream.extract/seg.c:94 ../raster/r.stream.extract/seg.c:103
+msgid "Unable to read segment file"
+msgstr ""
+#: ../raster/r.stream.extract/cseg.c:97
+msgid "Unabel to read segment file"
+msgstr ""
+#: ../raster/r.stream.extract/cseg.c:120
+#, c-format
+msgid "Unable to segment put row %d for raster map <%s>"
+msgstr ""
+#: ../raster/r.stream.extract/init_search.c:24
+msgid "Initializing A* search..."
+msgstr ""
+#: ../raster/r.stream.extract/dseg.c:19
+msgid "dseg_open(): unable to create segment file"
+msgstr ""
+#: ../raster/r.stream.extract/dseg.c:33
+msgid "Iillegal configuration parameter(s)"
+msgstr ""
+#: ../raster/r.stream.extract/dseg.c:120
+#, c-format
+msgid "Inable to segment put row %d for raster <%s>"
+msgstr ""
+#: ../raster/r.stream.extract/streams.c:72
+#: ../raster/r.stream.extract/streams.c:668
+#, c-format
+msgid "Stream_no %d and n_stream_nodes %lld out of sync"
+msgstr ""
+#: ../raster/r.stream.extract/streams.c:128
+#, c-format
+msgid "BUG: stream node %d has only 1 tributary: %d"
+msgstr ""
+#: ../raster/r.stream.extract/streams.c:160
+msgid "Calculating flow accumulation..."
+msgstr ""
+#: ../raster/r.stream.extract/streams.c:336
+#: ../raster/r.watershed/seg/do_cum.c:487
+#: ../raster/r.watershed/ram/do_cum.c:443
+#, c-format
+msgid "MFD: cumulative proportion of flow distribution not 1.0 but %f"
+msgstr ""
+#: ../raster/r.stream.extract/streams.c:392
+msgid "Extracting streams..."
+msgstr ""
+#: ../raster/r.stream.extract/streams.c:469
+msgid "Bug in stream extraction"
+msgstr ""
+#: ../raster/r.stream.extract/streams.c:631
+msgid "Can't use Montgomery's method, no stream direction found"
+msgstr ""
+#: ../raster/r.stream.extract/streams.c:700
+#, c-format
+msgid "MFD: A * path already processed when setting drainage direction: %lld of %lld cells"
+msgstr ""
+#: ../raster/r.stream.extract/close.c:35
+#, c-format
+msgid "Writing vector map <%s>..."
+msgstr ""
+#: ../raster/r.stream.extract/close.c:123
+#, c-format
+msgid "Stream id %d not set, top is %d, parent is %d"
+msgstr ""
+#: ../raster/r.stream.extract/close.c:144
+msgid "Stream id not set while tracing"
+msgstr ""
+#: ../raster/r.stream.extract/close.c:163
+msgid "Writing attribute data..."
+msgstr ""
+#: ../raster/r.stream.extract/close.c:198
+#, c-format
+msgid "Unable to create index on table <%s>"
+msgstr ""
+#: ../raster/r.stream.extract/close.c:219
+#, c-format
+msgid "Unable to insert new row: '%s'"
+msgstr ""
+#: ../raster/r.stream.extract/close.c:255 ../raster/r.grow.distance/main.c:325
+#: ../raster/r.fill.dir/main.c:259
+msgid "Writing output raster maps..."
+msgstr ""
+#: ../raster/r.stream.extract/close.c:320
+#, c-format
+msgid "Unable to write vector map <%s>"
+msgstr ""
+#: ../raster/r.stream.extract/del_streams.c:130
+#, c-format
+msgid "Deleting stream segments shorter than %d cell..."
+msgid_plural "Deleting stream segments shorter than %d cells..."
+msgstr[0] ""
+msgstr[1] ""
+#: ../raster/r.stream.extract/del_streams.c:193
+#, c-format
+msgid "%d stream segment deleted"
+msgid_plural "%d stream segments deleted"
+msgstr[0] ""
+msgstr[1] ""
+#: ../raster/r.stream.extract/seg.c:45
+#, c-format
+msgid "Unable to re-open file '%s'"
+msgstr ""
+#: ../raster/r.stream.extract/seg.c:85
+msgid "seg_put_row(): could not write segment file"
+msgstr ""
+#: ../raster/r.stream.extract/thin.c:83
+msgid "Thinning stream segments..."
+msgstr ""
+#: ../raster/r.stream.extract/thin.c:169
+#, c-format
+msgid "%d of %lld stream segments were thinned"
+msgstr ""
+#: ../raster/r.stream.extract/load.c:33
+msgid "Loading elevation raster map..."
+msgstr ""
+#: ../raster/r.stream.extract/load.c:35
+msgid "Loading input raster maps..."
+msgstr ""
+#: ../raster/r.stream.extract/load.c:95
+msgid "Elevation raster map is NULL but accumulation map is not NULL"
+msgstr ""
+#: ../raster/r.grow.distance/main.c:154
+msgid "Generates a raster map containing distances to nearest raster features."
+msgstr ""
+#: ../raster/r.grow.distance/main.c:161
+msgid "Name for distance output raster map"
+msgstr ""
+#: ../raster/r.grow.distance/main.c:167
+msgid "Name for value output raster map"
+msgstr ""
+#: ../raster/r.grow.distance/main.c:180
+msgid "Output distances in meters instead of map units"
+msgstr ""
+#: ../raster/r.grow.distance/main.c:184
+msgid "Calculate distance to nearest NULL cell"
+msgstr ""
+#: ../raster/r.grow.distance/main.c:195
+msgid "Distance output is required for distance to NULL cells"
+msgstr ""
+#: ../raster/r.grow.distance/main.c:197
+msgid "Value output is meaningless for distance to NULL cells"
+msgstr ""
+#: ../raster/r.grow.distance/main.c:203
+msgid "At least one of distance= and value= must be given"
+msgstr ""
+#: ../raster/r.grow.distance/main.c:218
+msgid "metric=geodesic is only valid for lat/lon"
+msgstr ""
+#: ../raster/r.grow.distance/main.c:224
+#, c-format
+msgid "Unknown metric: '%s'"
+msgstr ""
+#: ../raster/r.grow.distance/main.c:229
+#, c-format
+msgid "Output distance in meters for lat/lon is only possible with '%s=%s'"
+msgstr ""
+#: ../raster/r.grow.distance/main.c:249
+#, c-format
+msgid "Unable to create temporary file <%s>"
+msgstr ""
+#: ../raster/r.random.surface/main.c:61
+msgid "Generates random surface(s) with spatial dependence."
+msgstr ""
+#: ../raster/r.random.surface/main.c:68
+msgid "Name for output raster map(s)"
+msgstr ""
+#: ../raster/r.random.surface/main.c:77 ../raster/r.random.cells/main.c:62
+msgid "Maximum distance of spatial correlation (value >= 0.0)"
+msgstr ""
+#: ../raster/r.random.surface/main.c:85
+msgid "Distance decay exponent (value > 0.0)"
+msgstr ""
+#: ../raster/r.random.surface/main.c:94
+msgid "Distance filter remains flat before beginning exponent"
+msgstr ""
+#: ../raster/r.random.surface/main.c:102
+msgid "Random seed (SEED_MIN >= value >= SEED_MAX), default [random]"
+msgstr ""
+#: ../raster/r.random.surface/main.c:108
+msgid "Maximum cell value of distribution"
+msgstr ""
+#: ../raster/r.random.surface/main.c:113
+msgid "Uniformly distributed cell values"
+msgstr ""
+#: ../raster/r.random.surface/main.c:128 ../raster/r.random.cells/init.c:96
+#, c-format
+msgid "Generating raster map <%s>..."
+msgstr ""
+#: ../raster/r.random.surface/save.c:98 ../raster/r.drain/main.c:523
+#: ../raster/r.random.cells/indep.c:139 ../raster/r.composite/main.c:191
+#: ../imagery/i.ifft/main.c:207
+#, c-format
+msgid "Writing raster map <%s>..."
+msgstr ""
+#: ../raster/r.random.surface/init.c:73
+#, c-format
+msgid "High (%d) must be greater than 1"
+msgstr ""
+#: ../raster/r.random.surface/init.c:82
+#, c-format
+msgid "Rastar map <%s> repeated, maps must be unique"
+msgstr ""
+#: ../raster/r.random.surface/init.c:92
+msgid "Output raster map required"
+msgstr ""
+#: ../raster/r.random.surface/init.c:108
+#, c-format
+msgid "Seed (%d) larger than maximum (%d)"
+msgstr ""
+#: ../raster/r.random.surface/init.c:111 ../raster/r.random.surface/init.c:120
+#, c-format
+msgid " seed is set to %d"
+msgstr ""
+#: ../raster/r.random.surface/init.c:116
+#, c-format
+msgid "Seed (%d) smaller than minimum (%d)"
+msgstr ""
+#: ../raster/r.random.surface/init.c:159
+#, c-format
+msgid "Distance value (%d): %lf must be >= 0.0"
+msgstr ""
+#: ../raster/r.random.surface/init.c:187
+#, c-format
+msgid "Exponent value (%lf) must be > 0.0"
+msgstr ""
+#: ../raster/r.random.surface/init.c:211
+#, c-format
+msgid "Flat value (%lf) must be less than distance value (%lf)"
+msgstr ""
+#: ../raster/r.random.surface/init.c:232
+msgid "Must have a distance value for each filter"
+msgstr ""
+#: ../raster/r.random.surface/init.c:264
+msgid "Must have a exponent value for each filter"
+msgstr ""
+#: ../raster/r.random.surface/init.c:281
+msgid "Must have a weight value for each filter"
+msgstr ""
+#: ../raster/r.surf.random/main.c:40
+msgid "Produces a raster surface map of uniform random deviates with defined range."
+msgstr ""
+#: ../raster/r.surf.random/main.c:46
+msgid "Minimum random value"
+msgstr ""
+#: ../raster/r.surf.random/main.c:52
+msgid "Maximum random value"
+msgstr ""
+#: ../raster/r.surf.random/main.c:58
+msgid "Create an integer raster map"
+msgstr ""
+#: ../raster/r.in.gridatb/file_io.c:35
+msgid "Setting window header failed"
+msgstr ""
+#: ../raster/r.in.gridatb/file_io.c:38
+msgid "Rows changed"
+msgstr ""
+#: ../raster/r.in.gridatb/file_io.c:41
+msgid "Cols changed"
+msgstr ""
+#: ../raster/r.in.gridatb/main.c:48
+msgid "Imports GRIDATB.FOR map file (TOPMODEL) into a GRASS raster map."
+msgstr ""
+#: ../raster/r.in.gridatb/main.c:51
+msgid "GRIDATB i/o map file"
+msgstr ""
+#: ../raster/r.in.gridatb/main.c:68
+#, c-format
+msgid "File not found: %s"
+msgstr ""
+#: ../raster/r.fill.dir/main.c:90
+msgid "sink"
+msgstr ""
+#: ../raster/r.fill.dir/main.c:91
+msgid "fill sinks"
+msgstr ""
+#: ../raster/r.fill.dir/main.c:92
+msgid "depressions"
+msgstr ""
+#: ../raster/r.fill.dir/main.c:94
+msgid "Filters and generates a depressionless elevation map and a flow direction map from a given elevation raster map."
+msgstr ""
+#: ../raster/r.fill.dir/main.c:101
+msgid "Name for output depressionless elevation raster map"
+msgstr ""
+#: ../raster/r.fill.dir/main.c:105
+msgid "Name for output flow direction map for depressionless elevation raster map"
+msgstr ""
+#: ../raster/r.fill.dir/main.c:110
+msgid "Name for output raster map of problem areas"
+msgstr ""
+#: ../raster/r.fill.dir/main.c:117
+msgid "Aspect direction format"
+msgstr ""
+#: ../raster/r.fill.dir/main.c:123
+msgid "Find unresolved areas only"
+msgstr ""
+#: ../raster/r.fill.dir/main.c:129
+#, c-format
+msgid "The '%c' flag requires '%s'to be specified"
+msgstr ""
+#: ../raster/r.fill.dir/main.c:150
+msgid "Direction map is D8 resolution, i.e. 45 degrees"
+msgstr ""
+#: ../raster/r.fill.dir/main.c:192
+msgid "Reading input elevation raster map..."
+msgstr ""
+#: ../raster/r.fill.dir/main.c:202
+msgid "Filling sinks..."
+msgstr ""
+#: ../raster/r.fill.dir/main.c:206
+msgid "Determining flow directions for ambiguous cases..."
+msgstr ""
+#: ../raster/r.fill.dir/main.c:219
+msgid "Repeat to get the final directions..."
+msgstr ""
+#: ../raster/r.fill.dir/wtrshed.c:95
+#, c-format
+msgid "Watershed pass %d"
+msgstr ""
+#: ../raster/r.fill.dir/resolve.c:136
+#, c-format
+msgid "Downward pass %d"
+msgstr ""
+#: ../raster/r.fill.dir/resolve.c:173
+#, c-format
+msgid "Upward pass %d"
+msgstr ""
+#: ../raster/r.fill.dir/dopolys.c:84
+#, c-format
+msgid "Found %d unresolved area"
+msgid_plural "Found %d unresolved areas"
+msgstr[0] ""
+msgstr[1] ""
+#: ../raster/r.clump/main.c:60
+msgid "reclass"
+msgstr ""
+#: ../raster/r.clump/main.c:63
+msgid "Recategorizes data in a raster map by grouping cells that form physically discrete areas into unique categories."
+msgstr ""
+#: ../raster/r.clump/main.c:82
+msgid "Threshold to identify similar cells"
+msgstr ""
+#: ../raster/r.clump/main.c:83
+msgid "Valid range: 0 = identical to < 1 = maximal difference"
+msgstr ""
+#: ../raster/r.clump/main.c:90
+msgid "Minimum clump size in cells"
+msgstr ""
+#: ../raster/r.clump/main.c:91
+msgid "Clumps smaller than minsize will be merged to form larger clumps"
+msgstr ""
+#: ../raster/r.clump/main.c:95
+msgid "Clump also diagonal cells"
+msgstr ""
+#: ../raster/r.clump/main.c:96
+msgid "Clumps are also traced along diagonal neighboring cells"
+msgstr ""
+#: ../raster/r.clump/main.c:100
+msgid "Print only the number of clumps in shell script style"
+msgstr ""
+#: ../raster/r.clump/main.c:122
+#, c-format
+msgid "Valid range for option <%s> is 0 <= value < 1"
+msgstr ""
+#: ../raster/r.clump/main.c:180
+#, c-format
+msgid "%d clump."
+msgid_plural "%d clumps."
+msgstr[0] ""
+msgstr[1] ""
+#: ../raster/r.clump/clump.c:53 ../imagery/i.segment/cluster.c:386
+#: ../vector/v.cluster/main.c:406 ../vector/v.cluster/main.c:615
+#: ../vector/v.cluster/main.c:972
+msgid "Generating renumbering scheme..."
+msgstr ""
+#: ../raster/r.clump/clump.c:83
+msgid "Pass 2 of 2..."
+msgstr ""
+#: ../raster/r.clump/clump.c:115 ../raster/r.clump/clump.c:347
+#: ../raster/r.clump/clump.c:361 ../raster/r.clump/clump.c:648
+#: ../raster/r.clump/clump.c:662 ../raster/r.clump/minsize.c:163
+#: ../raster/r.clump/minsize.c:390 ../imagery/i.segment/cluster.c:363
+#: ../imagery/i.segment/cluster.c:377
+msgid "Unable to write to temp file"
+msgstr ""
+#: ../raster/r.clump/clump.c:124
+#, c-format
+msgid "%d initial clumps"
+msgstr ""
+#: ../raster/r.clump/clump.c:213 ../raster/r.clump/clump.c:477
+#: ../raster/r.clump/minsize.c:373 ../imagery/i.segment/cluster.c:121
+msgid "Unable to open temp file"
+msgstr ""
+#: ../raster/r.clump/clump.c:235 ../raster/r.clump/clump.c:492
+msgid "Pass 1 of 2..."
+msgstr ""
+#: ../raster/r.clump/clump.c:427
+#, c-format
+msgid "%d-band clumping with threshold %g"
+msgstr ""
+#: ../raster/r.clump/clump.c:451 ../imagery/i.segment/write_output.c:112
+#: ../imagery/i.segment/open_files.c:57 ../imagery/i.segment/open_files.c:224
+#: ../imagery/i.segment/open_files.c:232
+#, c-format
+msgid "No min/max found in raster map <%s>"
+msgstr ""
+#: ../raster/r.clump/rclist.c:17 ../imagery/i.segment/rclist.c:17
+msgid "rclist out of memory"
+msgstr ""
+#: ../raster/r.clump/minsize.c:357
+msgid "Minimum size must be larger than 1"
+msgstr ""
+#: ../raster/r.clump/minsize.c:368
+msgid "Loading input ..."
+msgstr ""
+#: ../raster/r.clump/minsize.c:418
+#, c-format
+msgid "Merging clumps smaller than %d cells..."
+msgstr ""
+#: ../raster/r.clump/minsize.c:509
+#, c-format
+msgid "Renumbering remaining %d clumps..."
+msgstr ""
+#: ../raster/r.circle/main.c:54 ../vector/v.buffer/main.c:224
+msgid "circle"
+msgstr ""
+#: ../raster/r.circle/main.c:56
+msgid "Creates a raster map containing concentric rings around a given point."
+msgstr ""
+#: ../raster/r.circle/main.c:63
+msgid "The coordinate of the center (east,north)"
+msgstr ""
+#: ../raster/r.circle/main.c:69
+msgid "Minimum radius for ring/circle map (in meters)"
+msgstr ""
+#: ../raster/r.circle/main.c:75
+msgid "Maximum radius for ring/circle map (in meters)"
+msgstr ""
+#: ../raster/r.circle/main.c:81
+msgid "Data value multiplier"
+msgstr ""
+#: ../raster/r.circle/main.c:85
+msgid "Generate binary raster map"
+msgstr ""
+#: ../raster/r.circle/main.c:108
+msgid "Please specify a radius in which min < max"
+msgstr ""
+#: ../raster/r.circle/main.c:116
+msgid "Please specify min and/or max radius when using the binary flag"
+msgstr ""
+#: ../raster/r.in.png/main.c:297
+#, c-format
+msgid "Unable to open PNG file '%s'"
+msgstr ""
+#: ../raster/r.in.png/main.c:300
+msgid "Input file empty or too short"
+msgstr ""
+#: ../raster/r.in.png/main.c:303
+msgid "Input file not a PNG file"
+msgstr ""
+#: ../raster/r.in.png/main.c:307 ../raster/r.in.png/main.c:311
+#: ../general/g.ppmtopng/main.c:70 ../general/g.ppmtopng/main.c:74
+msgid "Unable to allocate PNG structure"
+msgstr ""
+#: ../raster/r.in.png/main.c:314
+msgid "PNG error"
+msgstr ""
+#: ../raster/r.in.png/main.c:485 ../raster/r.cross/main.c:161
+#: ../raster/r.basins.fill/main.c:146 ../raster/r.resample/main.c:125
+#, c-format
+msgid "Creating support files for <%s>..."
+msgstr ""
+#: ../raster/r.in.png/main.c:522
+msgid "Imports non-georeferenced PNG format image."
+msgstr ""
+#: ../raster/r.in.png/main.c:532
+msgid "Title for created raster map"
+msgstr ""
+#: ../raster/r.in.png/main.c:538
+msgid "Display gamma"
+msgstr ""
+#: ../raster/r.in.png/main.c:544
+msgid "Alpha threshold"
+msgstr ""
+#: ../raster/r.in.png/main.c:548
+msgid "Create floating-point map (0.0 - 1.0)"
+msgstr ""
+#: ../raster/r.in.png/main.c:552
+msgid "Output image file header only and exit"
+msgstr ""
+#: ../raster/r.cross/main.c:71
+msgid "Creates a cross product of the category values from multiple raster map layers."
+msgstr ""
+#: ../raster/r.cross/main.c:80
+#, c-format
+msgid "Names of 2-%d input raster maps"
+msgstr ""
+#: ../raster/r.cross/main.c:89
+msgid "Non-NULL data only"
+msgstr ""
+#: ../raster/r.cross/main.c:102
+#, c-format
+msgid "More than %d files not allowed"
+msgstr ""
+#: ../raster/r.cross/main.c:111
+msgid "Must specify 2 or more input maps"
+msgstr ""
+#: ../raster/r.cross/main.c:129
+#, c-format
+msgid "%s: STEP 2 ..."
+msgstr ""
+#: ../raster/r.cross/main.c:171
+#, c-format
+msgid "%d categories"
+msgstr ""
+#: ../raster/r.cross/cross.c:65
+#, c-format
+msgid "%s: STEP 1 ... "
+msgstr ""
+#: ../raster/r.cross/renumber.c:33
+#, c-format
+msgid "%s: STEP 3 ... "
+msgstr ""
+#: ../raster/r.series/main.c:141
+msgid "Makes each output cell value a function of the values assigned to the corresponding cells in the input raster map layers."
+msgstr ""
+#: ../raster/r.series/main.c:150
+msgid "Input file with one raster map name and optional one weight per line, field separator between name and weight is |"
+msgstr ""
+#: ../raster/r.series/main.c:161 ../raster3d/r3.neighbors/main.c:119
+msgid "Aggregate operation"
+msgstr ""
+#: ../raster/r.series/main.c:176
+msgid "Weighting factor for each input map, default value is 1.0 for each input map"
+msgstr ""
+#: ../raster/r.series/main.c:250 ../raster/r.series/main.c:312
+msgid "Weights must be positive"
+msgstr ""
+#: ../raster/r.series/main.c:268 ../raster/r.series/main.c:318
+#, c-format
+msgid "Reading raster map <%s> using weight %f..."
+msgstr ""
+#: ../raster/r.series/main.c:298
+msgid "input= and weights= must have the same number of values"
+msgstr ""
+#: ../raster/r.series/main.c:333
+msgid "output= and method= must have the same number of values"
+msgstr ""
+#: ../raster/r.series/main.c:351
+#, c-format
+msgid "Method %s not compatible with weights, using unweighed version instead"
+msgstr ""
+#: ../raster/r.in.lidar/point_binning.c:205 ../raster/r.in.xyz/main.c:483
+msgid "Unable to calculate percentile without the pth option specified!"
+msgstr ""
+#: ../raster/r.in.lidar/point_binning.c:217 ../raster/r.in.xyz/main.c:495
+msgid "Unable to calculate trimmed mean without the trim option specified!"
+msgstr ""
+#: ../raster/r.in.lidar/info.c:108 ../raster/r.in.xyz/main.c:1203
+#: ../raster3d/r3.in.lidar/info.c:109
+msgid "Scanning data ..."
+msgstr ""
+#: ../raster/r.in.lidar/info.c:148 ../raster/r.in.xyz/main.c:1309
+#: ../raster3d/r3.in.lidar/info.c:149
+#, c-format
+msgid "Range: min max\n"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:116
+msgid "Creates a raster map from LAS LiDAR points using univariate statistics."
+msgstr ""
+#: ../raster/r.in.lidar/main.c:120 ../raster3d/r3.in.lidar/main.c:174
+#: ../vector/v.in.lidar/main.c:144
+msgid "LAS input file"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:121 ../raster/r.in.lidar/main.c:131
+#: ../raster3d/r3.in.lidar/main.c:182 ../vector/v.in.lidar/main.c:145
+msgid "LiDAR input files in LAS format (*.las or *.laz)"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:130 ../raster3d/r3.in.lidar/main.c:181
+msgid "File containing names of LAS input files"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:158 ../raster/r.in.xyz/main.c:198
+msgid "Number of points in cell"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:159 ../raster/r.in.xyz/main.c:199
+msgid "Minimum value of point values in cell"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:160 ../raster/r.in.xyz/main.c:200
+msgid "Maximum value of point values in cell"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:161 ../raster/r.in.xyz/main.c:201
+msgid "Range of point values in cell"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:162 ../raster/r.in.xyz/main.c:202
+msgid "Sum of point values in cell"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:163 ../raster/r.in.xyz/main.c:203
+msgid "Mean (average) value of point values in cell"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:164 ../raster/r.in.xyz/main.c:204
+msgid "Standard deviation of point values in cell"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:165 ../raster/r.in.xyz/main.c:205
+msgid "Variance of point values in cell"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:166 ../raster/r.in.xyz/main.c:206
+msgid "Coefficient of variance of point values in cell"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:167 ../raster/r.in.xyz/main.c:207
+msgid "Median value of point values in cell"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:168
+msgid "pth (nth) percentile of point values in cell"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:169 ../raster/r.in.xyz/main.c:209
+msgid "Skewness of point values in cell"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:170 ../raster/r.in.xyz/main.c:210
+msgid "Trimmed mean of point values in cell"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:180
+msgid "Subtract raster values from the Z coordinates"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:182
+msgid "The scale for Z is applied beforehand, the range filter for Z afterwards"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:184 ../raster/r.in.lidar/main.c:201
+#: ../raster/r.in.lidar/main.c:217 ../raster/r.in.lidar/main.c:333
+#: ../raster3d/r3.in.lidar/main.c:251 ../raster3d/r3.in.lidar/main.c:264
+#: ../raster3d/r3.in.lidar/main.c:280
+msgid "Transform"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:191
+msgid "Filter range for Z data (min,max)"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:192
+msgid "Applied after base_raster transformation step"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:200 ../raster3d/r3.in.lidar/main.c:263
+msgid "Scale to apply to Z data"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:208 ../raster3d/r3.in.lidar/main.c:271
+msgid "Filter range for intensity values (min,max)"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:216 ../raster3d/r3.in.lidar/main.c:279
+msgid "Scale to apply to intensity values"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:242
+msgid "Discard given percentage of the smallest and largest values"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:252
+msgid "Output raster resolution"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:259 ../raster3d/r3.in.lidar/main.c:229
+#: ../vector/v.in.lidar/main.c:203
+msgid "Only import points of selected return type"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:260 ../raster3d/r3.in.lidar/main.c:230
+#: ../vector/v.in.lidar/main.c:204
+msgid "If not specified, all points are imported"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:269 ../raster3d/r3.in.lidar/main.c:239
+#: ../vector/v.in.lidar/main.c:213
+msgid "Only import points of selected class(es)"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:270 ../raster3d/r3.in.lidar/main.c:240
+#: ../vector/v.in.lidar/main.c:214
+msgid "Input is comma separated integers. If not specified, all points are imported."
+msgstr ""
+#: ../raster/r.in.lidar/main.c:277 ../raster3d/r3.in.lidar/main.c:299
+#: ../vector/v.in.lidar/main.c:278
+msgid "Print LAS file info and exit"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:282
+msgid "Use the extent of the input for the raster extent"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:284
+msgid "Set internally computational region extents based on the point cloud"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:291
+msgid "Set computation region to match the new raster map"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:293
+msgid "Set computation region to match the 2D extent and resolution of the newly created new raster map"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:316
+msgid "Use intensity values rather than Z values"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:318
+msgid "Uses intensity values everywhere as if they would be Z coordinates"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:324
+msgid "Use Z values for filtering, but intensity values for statistics"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:329
+msgid "Use base raster resolution instead of computational region"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:331
+msgid "For getting values from base raster, use its actual resolution instead of computational region resolution"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:337 ../raster3d/r3.in.lidar/main.c:284
+#: ../vector/v.in.lidar/main.c:293
+msgid "Use only valid points"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:339 ../raster3d/r3.in.lidar/main.c:286
+#: ../vector/v.in.lidar/main.c:295
+msgid "Points invalid according to APSRS LAS specification will be filtered out"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:359
+#, c-format
+msgid "Flag %c makes sense only with %s option or -%c flag"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:367
+msgid "Trim option can be used only with trimmean method"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:374 ../raster3d/r3.in.lidar/main.c:340
+#, c-format
+msgid "File <%s> does not exist"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:391
+msgid "zrange will not be taken into account during scan"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:404 ../raster3d/r3.in.lidar/main.c:374
+#: ../vector/v.in.lidar/main.c:349
+#, c-format
+msgid "Input file <%s> does not exist"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:408 ../raster3d/r3.in.lidar/main.c:378
+#, c-format
+msgid "Unable to open file <%s> as a LiDAR point cloud"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:412 ../raster3d/r3.in.lidar/main.c:382
+#: ../vector/v.in.lidar/main.c:358
+#, c-format
+msgid "Unable to read LAS header of <%s>"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:428 ../raster3d/r3.in.lidar/main.c:398
+msgid "First file's projection checked, checking projection of the other files..."
+msgstr ""
+#: ../raster/r.in.lidar/main.c:466
+#, c-format
+msgid "Unknown filter option <%s>"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:484 ../raster/r.in.xyz/main.c:383
+msgid "Invalid zrange"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:498
+#, c-format
+msgid "Invalid %s"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:530 ../general/g.region/main.c:843
+#, c-format
+msgid "Invalid input <%s=%s>"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:533
+#, c-format
+msgid "Option '%s' must be > 0.0"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:601
+#, c-format
+msgid "Unable to process the hole map at once. Please set the '%s' option to some value lower than 100."
+msgstr ""
+#: ../raster/r.in.lidar/main.c:621
+#, c-format
+msgid "Pass #%d (of %d)..."
+msgstr ""
+#: ../raster/r.in.lidar/main.c:783
+#, c-format
+msgid "%lu points found in input file(s)"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:803
+#, c-format
+msgid "%lu input points were invalid and filtered out"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:806
+#, c-format
+msgid "%lu input points were invalid, use -%c flag to filter them out"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:809
+#, c-format
+msgid "Raster map <%s> created. %lu points from %d files found in region."
+msgstr ""
+#: ../raster/r.in.lidar/main.c:814
+#, c-format
+msgid "Raster map <%s> created. %lu points found in region."
+msgstr ""
+#: ../raster/r.in.lidar/rast_segment.c:40
+#: ../raster3d/r3.in.lidar/rast_segment.c:53
+msgid "Cannot create temporary file with segments of a raster map"
+msgstr ""
+#: ../raster/r.in.lidar/projection.c:34 ../raster/r.in.gdal/proj.c:153
+#: ../raster/r.external/proj.c:153 ../raster3d/r3.in.lidar/projection.c:36
+#: ../vector/v.in.lidar/projection.c:32 ../vector/v.in.pdal/projection.c:31
+#: ../vector/v.in.ogr/proj.c:361 ../vector/v.external/proj.c:246
+msgid ""
+"Projection of dataset does not appear to match current location.\n"
+"\n"
+msgstr ""
+#: ../raster/r.in.lidar/projection.c:40 ../raster3d/r3.in.lidar/projection.c:42
+#: ../vector/v.in.lidar/projection.c:38 ../vector/v.in.pdal/projection.c:37
+msgid "GRASS LOCATION PROJ_INFO is:\n"
+msgstr ""
+#: ../raster/r.in.lidar/projection.c:49 ../raster/r.in.lidar/projection.c:55
+#: ../raster3d/r3.in.lidar/projection.c:51
+#: ../raster3d/r3.in.lidar/projection.c:57 ../vector/v.in.lidar/projection.c:47
+#: ../vector/v.in.lidar/projection.c:53 ../vector/v.in.pdal/projection.c:46
+#: ../vector/v.in.pdal/projection.c:52
+msgid "Import dataset PROJ_INFO is:\n"
+msgstr ""
+#: ../raster/r.in.lidar/projection.c:91 ../raster/r.in.gdal/proj.c:259
+#: ../raster/r.external/proj.c:259 ../raster3d/r3.in.lidar/projection.c:93
+#: ../vector/v.in.lidar/projection.c:89 ../vector/v.in.pdal/projection.c:88
+#: ../vector/v.in.ogr/proj.c:467 ../vector/v.external/proj.c:352
+#, c-format
+msgid ""
+"\n"
+"In case of no significant differences in the projection definitions, use the -o flag to ignore them and use current location definition.\n"
+msgstr ""
+#: ../raster/r.in.lidar/projection.c:95 ../raster3d/r3.in.lidar/projection.c:97
+#: ../vector/v.in.lidar/projection.c:93 ../vector/v.in.pdal/projection.c:92
+msgid "Consider generating a new location with 'location' parameter from input data set.\n"
+msgstr ""
+#: ../raster/r.in.lidar/projection.c:113
+#: ../raster3d/r3.in.lidar/projection.c:115
+#: ../vector/v.in.lidar/projection.c:111 ../vector/v.in.pdal/projection.c:110
+#: ../vector/v.in.pdal/projection.c:156 ../vector/v.in.pdal/projection.c:189
+msgid "Unable to convert input map projection information to GRASS format for checking"
+msgstr ""
+#: ../raster/r.in.lidar/projection.c:128 ../raster/r.in.gdal/proj.c:144
+#: ../raster/r.external/proj.c:144 ../raster3d/r3.in.lidar/projection.c:130
+#: ../vector/v.in.lidar/projection.c:126 ../vector/v.in.ogr/proj.c:352
+#: ../vector/v.external/proj.c:237
+msgid "Over-riding projection check"
+msgstr ""
+#: ../raster/r.in.lidar/projection.c:139 ../raster/r.in.gdal/proj.c:282
+#: ../raster/r.external/proj.c:282 ../raster3d/r3.in.lidar/projection.c:141
+#: ../vector/v.in.lidar/projection.c:137 ../vector/v.in.pdal/projection.c:137
+#: ../vector/v.in.ogr/proj.c:490 ../vector/v.external/proj.c:375
+msgid "Projection of input dataset and current location appear to match"
+msgstr ""
+#: ../raster/r.in.lidar/string_list.c:34
+#: ../raster3d/r3.in.lidar/string_list.c:47
+#, c-format
+msgid "Cannot open file %s for reading"
+msgstr ""
+#: ../raster/r.mapcalc/main.c:72
+msgid "Raster map calculator."
+msgstr ""
+#: ../raster/r.mapcalc/main.c:79
+msgid "Expression to evaluate"
+msgstr ""
+#: ../raster/r.mapcalc/main.c:80 ../raster/r.mapcalc/main.c:99
+msgid "Expression"
+msgstr ""
+#: ../raster/r.mapcalc/main.c:88
+msgid ""
+"The computational region that should be used.\n"
+" - current uses the current region of the mapset.\n"
+" - intersect computes the intersection region between\n"
+" all input maps and uses the smallest resolution\n"
+" - union computes the union extent of all map regions\n"
+" and uses the smallest resolution"
+msgstr ""
+#: ../raster/r.mapcalc/main.c:98
+msgid "File containing expression(s) to evaluate"
+msgstr ""
+#: ../raster/r.mapcalc/main.c:105
+msgid "Seed for rand() function"
+msgstr ""
+#: ../raster/r.mapcalc/main.c:109
+msgid "Generate random seed (result is non-deterministic)"
+msgstr ""
+#: ../raster/r.mapcalc/main.c:113
+msgid "List input and output maps"
+msgstr ""
+#: ../raster/r.mapcalc/main.c:135
+#, c-format
+msgid "%s= and -%c are mutually exclusive"
+msgstr ""
+#: ../raster/r.mapcalc/main.c:146
+msgid "parse error"
+msgstr ""
+#: ../raster/r.mapcalc/main.c:185
+msgid "Floating point error(s) occurred in the calculation"
+msgstr ""
+#: ../raster/r.mapcalc/map.c:226 ../raster/r.mapcalc/map3.c:182
+#, c-format
+msgid "Unable to read color file for raster map <%s@%s>"
+msgstr ""
+#: ../raster/r.mapcalc/map.c:239 ../raster/r.mapcalc/map3.c:195
+#, c-format
+msgid "Unable to create btree for raster map <%s@%s>"
+msgstr ""
+#: ../raster/r.mapcalc/map.c:288 ../raster/r.mapcalc/map.c:495
+#: ../raster/r.mapcalc/map.c:536 ../raster/r.mapcalc/map.c:634
+#: ../raster/r.mapcalc/expression.c:357 ../raster/r.mapcalc/map3.c:240
+#: ../raster/r.mapcalc/map3.c:424 ../raster/r.mapcalc/map3.c:469
+#: ../raster/r.mapcalc/map3.c:566
+#, c-format
+msgid "Invalid map modifier: '%c'"
+msgstr ""
+#: ../raster/r.mapcalc/map.c:426 ../raster/r.mapcalc/map3.c:354
+#: ../raster/r.mapcalc/evaluate.c:143 ../raster/r.mapcalc/evaluate.c:283
+#, c-format
+msgid "Unknown type: %d"
+msgstr ""
+#: ../raster/r.mapcalc/expression.c:206
+#, c-format
+msgid "Undefined variable '%s'"
+msgstr ""
+#: ../raster/r.mapcalc/expression.c:221
+#, c-format
+msgid "Invalid map <%s>"
+msgstr ""
+#: ../raster/r.mapcalc/expression.c:262
+#, c-format
+msgid "Undefined function '%s'"
+msgstr ""
+#: ../raster/r.mapcalc/expression.c:267
+#, c-format
+msgid "Too few arguments (%d) to function %s()"
+msgstr ""
+#: ../raster/r.mapcalc/expression.c:271
+#, c-format
+msgid "Too many arguments (%d) to function %s()"
+msgstr ""
+#: ../raster/r.mapcalc/expression.c:275
+#, c-format
+msgid "Incorrect argument types to function %s()"
+msgstr ""
+#: ../raster/r.mapcalc/expression.c:278
+#, c-format
+msgid "Internal error for function %s()"
+msgstr ""
+#: ../raster/r.mapcalc/expression.c:453
+#, c-format
+msgid "Illegal number of arguments (%d) for operator '%s'"
+msgstr ""
+#: ../raster/r.mapcalc/expression.c:493
+#, c-format
+msgid "Format_expression_prec: unknown type: %d"
+msgstr ""
+#: ../raster/r.mapcalc/function.c:35
+#, c-format
+msgid "Known functions:"
+msgstr ""
+#: ../raster/r.mapcalc/map3.c:373
+#, c-format
+msgid "Unable to close raster map <%s@%s>"
+msgstr ""
+#: ../raster/r.mapcalc/map3.c:607 ../raster/r.sunhours/main.c:324
+#: ../raster/r.sunhours/main.c:335 ../raster/r.sunhours/main.c:346
+#: ../imagery/i.landsat.acca/tools.c:136
+#: ../imagery/i.landsat.acca/algorithm.c:234
+#: ../imagery/i.landsat.acca/algorithm.c:388
+#: ../imagery/i.landsat.toar/main.c:566
+#, c-format
+msgid "Unable to create raster map <%s>"
+msgstr ""
+#: ../raster/r.mapcalc/map3.c:632
+msgid "Unable to close output raster map"
+msgstr ""
+#: ../raster/r.mapcalc/evaluate.c:189
+#, c-format
+msgid "Invalid type: %d"
+msgstr ""
+#: ../raster/r.mapcalc/evaluate.c:228
+#, c-format
+msgid "Too few arguments for function '%s'"
+msgstr ""
+#: ../raster/r.mapcalc/evaluate.c:232
+#, c-format
+msgid "Too many arguments for function '%s'"
+msgstr ""
+#: ../raster/r.mapcalc/evaluate.c:236
+#, c-format
+msgid "Invalid argument type for function '%s'"
+msgstr ""
+#: ../raster/r.mapcalc/evaluate.c:240
+#, c-format
+msgid "Invalid return type for function '%s'"
+msgstr ""
+#: ../raster/r.mapcalc/evaluate.c:244
+#, c-format
+msgid "Unknown type for function '%s'"
+msgstr ""
+#: ../raster/r.mapcalc/evaluate.c:247
+#, c-format
+msgid "Number of arguments for function '%s'"
+msgstr ""
+#: ../raster/r.mapcalc/evaluate.c:251
+#, c-format
+msgid "Unknown error for function '%s'"
+msgstr ""
+#: ../raster/r.mapcalc/evaluate.c:329
+#, c-format
+msgid "output map <%s> exists. To overwrite, use the --overwrite flag"
+msgstr ""
+#: ../raster/r.statistics/read_stats.c:20
+msgid "Reading r.stats output"
+msgstr ""
+#: ../raster/r.statistics/main.c:59
+msgid "Calculates category or object oriented statistics."
+msgstr ""
+#: ../raster/r.statistics/main.c:69 ../raster/r.stats.zonal/main.c:115
+msgid "Method of object-based statistic"
+msgstr ""
+#: ../raster/r.statistics/main.c:92 ../raster/r.stats.zonal/main.c:138
+msgid "Resultant raster map"
+msgstr ""
+#: ../raster/r.statistics/main.c:98 ../raster/r.stats.zonal/main.c:144
+msgid "Cover values extracted from the category labels of the cover map"
+msgstr ""
+#: ../raster/r.statistics/main.c:104 ../raster/r.statistics/main.c:107
+#: ../raster/r.surf.idw/main.c:164
+msgid "This module currently only works for integer (CELL) maps"
+msgstr ""
+#: ../raster/r.statistics/main.c:110 ../raster/r.support/main.c:245
+#: ../display/d.title/main.c:110 ../raster3d/r3.support/main.c:248
+#, c-format
+msgid "Unable to read category file of raster map <%s>"
+msgstr ""
+#: ../raster/r.statistics/main.c:118 ../raster/r.stats.zonal/main.c:165
+#: ../raster/r.proj/main.c:237 ../imagery/i.rectify/main.c:156
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:151
+#: ../vector/v.vect.stats/main.c:302
+#, c-format
+msgid "<%s=%s> unknown %s"
+msgstr ""
+#: ../raster/r.statistics/o_var.c:95 ../raster/r.statistics/o_sdev.c:94
+msgid "o_var: No data in array"
+msgstr ""
+#: ../raster/r.statistics/o_kurt.c:91
+msgid "o_kurto: No data in array"
+msgstr ""
+#: ../raster/r.statistics/o_adev.c:93
+msgid "o_adev: No data in array"
+msgstr ""
+#: ../raster/r.statistics/o_skew.c:91
+msgid "o_skew: No data in array"
+msgstr ""
+#: ../raster/r.sunhours/main.c:76
+msgid "Calculates solar elevation, solar azimuth, and sun hours."
+msgstr ""
+#: ../raster/r.sunhours/main.c:77
+msgid "Solar elevation: the angle between the direction of the geometric center of the sun's apparent disk and the (idealized) horizon. Solar azimuth: the angle from due north in clockwise direction."
+msgstr ""
+#: ../raster/r.sunhours/main.c:83
+msgid "Output raster map with solar elevation angle"
+msgstr ""
+#: ../raster/r.sunhours/main.c:88
+msgid "Output raster map with solar azimuth angle"
+msgstr ""
+#: ../raster/r.sunhours/main.c:93
+msgid "Output raster map with sunshine hours"
+msgstr ""
+#: ../raster/r.sunhours/main.c:94
+msgid "Sunshine hours require SOLPOS use and Greenwich standard time"
+msgstr ""
+#: ../raster/r.sunhours/main.c:101
+msgid "Year"
+msgstr ""
+#: ../raster/r.sunhours/main.c:109
+msgid "Month"
+msgstr ""
+#: ../raster/r.sunhours/main.c:110
+msgid "If not given, day is interpreted as day of the year"
+msgstr ""
+#: ../raster/r.sunhours/main.c:118
+msgid "Day"
+msgstr ""
+#: ../raster/r.sunhours/main.c:126
+msgid "Hour"
+msgstr ""
+#: ../raster/r.sunhours/main.c:135
+msgid "Minutes"
+msgstr ""
+#: ../raster/r.sunhours/main.c:144
+msgid "Seconds"
+msgstr ""
+#: ../raster/r.sunhours/main.c:151
+msgid "Time is local sidereal time, not Greenwich standard time"
+msgstr ""
+#: ../raster/r.sunhours/main.c:155
+msgid "Do not use SOLPOS algorithm of NREL"
+msgstr ""
+#: ../raster/r.sunhours/main.c:167
+msgid "No output requested, exiting."
+msgstr ""
+#: ../raster/r.sunhours/main.c:193
+msgid "NREL SOLPOS algorithm uses Greenwich standard time."
+msgstr ""
+#: ../raster/r.sunhours/main.c:194 ../raster/r.sunhours/main.c:202
+msgid "Time will be interpreted as Greenwich standard time."
+msgstr ""
+#: ../raster/r.sunhours/main.c:200
+msgid "Time will be interpreted as local sidereal time."
+msgstr ""
+#: ../raster/r.sunhours/main.c:205
+msgid "Sunshine hours require NREL SOLPOS."
+msgstr ""
+#: ../raster/r.sunhours/main.c:210
+msgid "Current projection is x,y (undefined)."
+msgstr ""
+#: ../raster/r.sunhours/main.c:216
+msgid "Cannot get projection info of current location"
+msgstr ""
+#: ../raster/r.sunhours/main.c:219
+msgid "Cannot get projection units of current location"
+msgstr ""
+#: ../raster/r.sunhours/main.c:222
+msgid "Cannot get projection key values of current location"
+msgstr ""
+#: ../raster/r.sunhours/main.c:232 ../general/g.region/printwindow.c:267
+#: ../general/g.region/printwindow.c:488 ../general/g.region/printwindow.c:569
+msgid "Unable to update lat/long projection parameters"
+msgstr ""
+#: ../raster/r.sunhours/main.c:296 ../raster/r.sunhours/main.c:391
+#: ../raster/r.sunmask/g_solposition.c:127
+#: ../general/g.region/printwindow.c:285 ../general/g.region/printwindow.c:293
+#: ../general/g.region/printwindow.c:301 ../general/g.region/printwindow.c:309
+#: ../general/g.region/printwindow.c:319 ../general/g.region/printwindow.c:503
+#: ../general/g.region/printwindow.c:596 ../general/g.region/printwindow.c:608
+#: ../general/g.region/printwindow.c:625 ../general/g.region/printwindow.c:643
+#: ../general/g.region/printwindow.c:658
+msgid "Error in pj_do_proj (projection of input coordinate pair)"
+msgstr ""
+#: ../raster/r.sunhours/main.c:356
+msgid "Calculating solar elevation and azimuth..."
+msgstr ""
+#: ../raster/r.sunhours/main.c:359
+msgid "Calculating solar elevation..."
+msgstr ""
+#: ../raster/r.sunhours/main.c:362
+msgid "Calculating solar azimuth..."
+msgstr ""
+#: ../raster/r.sunhours/solpos00.c:994 ../raster/r.sunmask/solpos00.c:950
+#, c-format
+msgid "S_decode ==> Please fix the year: %d [1950-2050]"
+msgstr ""
+#: ../raster/r.sunhours/solpos00.c:997 ../raster/r.sunmask/solpos00.c:953
+#, c-format
+msgid "S_decode ==> Please fix the month: %d"
+msgstr ""
+#: ../raster/r.sunhours/solpos00.c:999 ../raster/r.sunmask/solpos00.c:955
+#, c-format
+msgid "S_decode ==> Please fix the day-of-month: %d"
+msgstr ""
+#: ../raster/r.sunhours/solpos00.c:1002 ../raster/r.sunmask/solpos00.c:958
+#, c-format
+msgid "S_decode ==> Please fix the day-of-year: %d"
+msgstr ""
+#: ../raster/r.sunhours/solpos00.c:1005 ../raster/r.sunmask/solpos00.c:961
+#, c-format
+msgid "S_decode ==> Please fix the hour: %d"
+msgstr ""
+#: ../raster/r.sunhours/solpos00.c:1007 ../raster/r.sunmask/solpos00.c:963
+#, c-format
+msgid "S_decode ==> Please fix the minute: %d"
+msgstr ""
+#: ../raster/r.sunhours/solpos00.c:1009 ../raster/r.sunmask/solpos00.c:965
+#, c-format
+msgid "S_decode ==> Please fix the second: %d"
+msgstr ""
+#: ../raster/r.sunhours/solpos00.c:1011 ../raster/r.sunmask/solpos00.c:967
+#, c-format
+msgid "S_decode ==> Please fix the time zone: %f"
+msgstr ""
+#: ../raster/r.sunhours/solpos00.c:1014 ../raster/r.sunmask/solpos00.c:970
+#, c-format
+msgid "S_decode ==> Please fix the interval: %d"
+msgstr ""
+#: ../raster/r.sunhours/solpos00.c:1017 ../raster/r.sunmask/solpos00.c:973
+#, c-format
+msgid "S_decode ==> Please fix the latitude: %f"
+msgstr ""
+#: ../raster/r.sunhours/solpos00.c:1020 ../raster/r.sunmask/solpos00.c:976
+#, c-format
+msgid "S_decode ==> Please fix the longitude: %f"
+msgstr ""
+#: ../raster/r.sunhours/solpos00.c:1023 ../raster/r.sunmask/solpos00.c:979
+#, c-format
+msgid "S_decode ==> Please fix the temperature: %f"
+msgstr ""
+#: ../raster/r.sunhours/solpos00.c:1026 ../raster/r.sunmask/solpos00.c:982
+#, c-format
+msgid "S_decode ==> Please fix the pressure: %f"
+msgstr ""
+#: ../raster/r.sunhours/solpos00.c:1028 ../raster/r.sunmask/solpos00.c:984
+#, c-format
+msgid "S_decode ==> Please fix the tilt: %f"
+msgstr ""
+#: ../raster/r.sunhours/solpos00.c:1030 ../raster/r.sunmask/solpos00.c:986
+#, c-format
+msgid "S_decode ==> Please fix the aspect: %f"
+msgstr ""
+#: ../raster/r.sunhours/solpos00.c:1032 ../raster/r.sunmask/solpos00.c:988
+#, c-format
+msgid "S_decode ==> Please fix the shadowband width: %f"
+msgstr ""
+#: ../raster/r.sunhours/solpos00.c:1035 ../raster/r.sunmask/solpos00.c:991
+#, c-format
+msgid "S_decode ==> Please fix the shadowband radius: %f"
+msgstr ""
+#: ../raster/r.sunhours/solpos00.c:1038 ../raster/r.sunmask/solpos00.c:994
+#, c-format
+msgid "S_decode ==> Please fix the shadowband sky factor: %f"
+msgstr ""
+#: ../raster/r.stats.zonal/main.c:105
+msgid "Calculates category or object oriented statistics (accumulator-based statistics)."
+msgstr ""
+#: ../raster/r.stats.zonal/main.c:178
+#, c-format
+msgid "Unable to read category file of cover map <%s>"
+msgstr ""
+#: ../raster/r.stats.zonal/main.c:248
+msgid "First pass"
+msgstr ""
+#: ../raster/r.stats.zonal/main.c:327
+msgid "Second pass"
+msgstr ""
+#: ../raster/r.stats.zonal/main.c:474
+msgid "Generating reclass map"
+msgstr ""
+#: ../raster/r.stats.zonal/main.c:496
+msgid "Writing output map"
+msgstr ""
+#: ../raster/r.out.gridatb/main.c:70
+msgid "Exports GRASS raster map to GRIDATB.FOR map file (TOPMODEL)."
+msgstr ""
+#: ../raster/r.regression.line/main.c:50
+msgid "Calculates linear regression from two raster maps: y = a + b*x."
+msgstr ""
+#: ../raster/r.resamp.stats/main.c:264
+msgid "Resamples raster map layers to a coarser grid using aggregation."
+msgstr ""
+#: ../raster/r.resamp.stats/main.c:274
+msgid "Aggregation method"
+msgstr ""
+#: ../raster/r.resamp.stats/main.c:292
+msgid "Weight according to area (slower)"
+msgstr ""
+#: ../raster/r.compress/main.c:70
+msgid "compression"
+msgstr ""
+#: ../raster/r.compress/main.c:71
+msgid "Compresses and decompresses raster maps."
+msgstr ""
+#: ../raster/r.compress/main.c:74
+msgid "Name of existing raster map(s)"
+msgstr ""
+#: ../raster/r.compress/main.c:78
+msgid "Uncompress the map"
+msgstr ""
+#: ../raster/r.compress/main.c:82
+msgid "Print compression information and data type of input map(s)"
+msgstr ""
+#: ../raster/r.compress/main.c:86
+msgid "Print compression information in shell script style"
+msgstr ""
+#: ../raster/r.compress/main.c:128 ../raster/r.compress/main.c:308
+#, c-format
+msgid "Raster map <%s> is not in the current mapset"
+msgstr ""
+#: ../raster/r.compress/main.c:134
+#, c-format
+msgid "<%s> is a reclass file of map <%s> in mapset <%s> - can't uncompress"
+msgstr ""
+#: ../raster/r.compress/main.c:136
+#, c-format
+msgid "<%s> is a reclass file of map <%s> in mapset <%s> - can't compress"
+msgstr ""
+#: ../raster/r.compress/main.c:141
+#, c-format
+msgid "<%s> is a GDAL-linked map - can't (un)compress"
+msgstr ""
+#: ../raster/r.compress/main.c:215
+msgid "DONE: uncompressed file is %lu %s (%.2f%) smaller"
+msgstr ""
+#: ../raster/r.compress/main.c:216
+msgid "DONE: compressed file is %lu %s (%.2f%) smaller"
+msgstr ""
+#: ../raster/r.compress/main.c:220
+msgid "DONE: uncompressed file is %lu %s (%.2f%) larger"
+msgstr ""
+#: ../raster/r.compress/main.c:221
+msgid "DONE: compressed file is %lu %s (%.2f%) larger"
+msgstr ""
+#: ../raster/r.compress/main.c:224
+msgid "same size"
+msgstr ""
+#: ../raster/r.compress/main.c:240
+#, c-format
+msgid "<%s> already uncompressed"
+msgstr ""
+#: ../raster/r.compress/main.c:243
+#, c-format
+msgid "Uncompressing <%s>"
+msgstr ""
+#: ../raster/r.compress/main.c:251
+#, c-format
+msgid "Re-compressing <%s>"
+msgstr ""
+#: ../raster/r.compress/main.c:254
+#, c-format
+msgid "Compressing <%s>"
+msgstr ""
+#: ../raster/r.compress/main.c:312
+#, c-format
+msgid "<%s> is a GDAL-linked map"
+msgstr ""
+#: ../raster/r.compress/main.c:316
+#, c-format
+msgid "<%s> is a reclass file of map <%s> in mapset <%s>"
+msgstr ""
+#: ../raster/r.compress/main.c:336
+#, c-format
+msgid "<%s> is uncompressed (method %i: %s). Data type: %s"
+msgstr ""
+#: ../raster/r.compress/main.c:343
+#, c-format
+msgid "<%s> is compressed (method %i: %s). Data type: %s"
+msgstr ""
+#: ../raster/r.compress/main.c:351
+#, c-format
+msgid "<%s> has a compressed NULL file"
+msgstr ""
+#: ../raster/r.compress/main.c:353
+#, c-format
+msgid "<%s> has an uncompressed NULL file"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:52
+#, c-format
+msgid "Supported formats:\n"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:138
+msgid "Exports GRASS raster maps into GDAL supported formats."
+msgstr ""
+#: ../raster/r.out.gdal/main.c:144
+msgid "List supported output formats"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:150
+msgid "Do not write GDAL standard colortable"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:151
+msgid "Only applicable to Byte or UInt16 data types"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:152 ../raster/r.out.gdal/main.c:158
+#: ../raster/r.out.gdal/main.c:205 ../raster/r.out.gdal/main.c:216
+#: ../raster/r.out.gdal/main.c:227 ../raster/r.out.gdal/main.c:240
+#: ../raster/r.out.gdal/main.c:251 ../vector/v.out.ogr/args.c:48
+#: ../vector/v.out.ogr/args.c:59 ../vector/v.out.ogr/args.c:69
+#: ../vector/v.out.ogr/args.c:79 ../vector/v.out.ogr/args.c:95
+#: ../vector/v.out.ogr/args.c:108 ../vector/v.out.ogr/args.c:115
+#: ../vector/v.out.ogr/args.c:121 ../vector/v.out.ogr/args.c:128
+#: ../vector/v.out.postgis/args.c:38 ../vector/v.out.postgis/args.c:48
+#: ../vector/v.out.postgis/args.c:61 ../vector/v.out.postgis/args.c:67
+#: ../vector/v.out.postgis/args.c:73 ../vector/v.out.postgis/args.c:79
+msgid "Creation"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:156
+msgid "Do not write non-standard metadata"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:157
+msgid "Enhances compatibility with other GIS software"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:162
+msgid "Write raster attribute table"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:163
+msgid "Some export formats may not be supported"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:167
+msgid "Force raster export despite any warnings of data loss"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:168
+msgid "Overrides nodata safety check"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:171
+msgid "Name of raster map (or group) to export"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:174
+msgid "Name for output raster file"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:180
+msgid "Raster data format to write (case sensitive, see also -l flag)"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:248
+msgid "Number of overviews to create for the output dataset"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:278
+#, c-format
+msgid "Raster map or group <%s> not found"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:282
+#, c-format
+msgid "No raster maps in group <%s>"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:297
+#, c-format
+msgid "Unable to get <%s> driver"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:303
+#, c-format
+msgid "Driver <%s> does not support direct writing. Using MEM driver for intermediate dataset."
+msgstr ""
+#: ../raster/r.out.gdal/main.c:308
+msgid "Unable to get in-memory raster driver"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:312
+#, c-format
+msgid "Driver <%s> does not support creating rasters"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:387
+#, c-format
+msgid "Could not read data range of raster <%s>"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:444
+#, c-format
+msgid "Exporting to GDAL data type: %s"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:459
+msgid "Raster export would result in complete data loss, aborting."
+msgstr ""
+#: ../raster/r.out.gdal/main.c:470
+#, c-format
+msgid "Precision loss: Raster map <%s> of type %s to be exported as %s. This can be avoided by using %s."
+msgstr ""
+#: ../raster/r.out.gdal/main.c:481
+#, c-format
+msgid "Precision loss: The range of <%s> can not be accurately preserved with GDAL datatype Float32. This can be avoided by exporting to Int32 or Float64."
+msgstr ""
+#: ../raster/r.out.gdal/main.c:489
+#, c-format
+msgid "Precision loss: Float32 can not preserve the DCELL precision of raster <%s>. This can be avoided by using Float64"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:498
+msgid "Forcing raster export"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:500
+#, c-format
+msgid "Raster export aborted. To override data loss check, use the -%c flag"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:515 ../raster/r.out.gdal/main.c:544
+#: ../raster/r.out.gdal/main.c:548
+msgid "Raster export aborted."
+msgstr ""
+#: ../raster/r.out.gdal/main.c:525
+msgid "Checking GDAL data type and nodata value..."
+msgstr ""
+#: ../raster/r.out.gdal/main.c:528
+#, c-format
+msgid "Checking options for raster map <%s> (band %d)..."
+msgstr ""
+#: ../raster/r.out.gdal/main.c:542
+msgid "Forcing raster export."
+msgstr ""
+#: ../raster/r.out.gdal/main.c:573
+msgid "Unable to create dataset using memory raster driver"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:582
+#, c-format
+msgid "Unable to create <%s> dataset using <%s> driver"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:597
+msgid "Unable to set geo transform"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:605
+msgid "Unable to set projection"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:633
+#, c-format
+msgid "Exporting raster data to %s format..."
+msgstr ""
+#: ../raster/r.out.gdal/main.c:636
+#, c-format
+msgid "Exporting raster map <%s> (band %d)..."
+msgstr ""
+#: ../raster/r.out.gdal/main.c:649
+#, c-format
+msgid "Unable to export raster map <%s>"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:662
+msgid "Number of overviews must be between 0 and 5"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:669
+msgid "Building overviews ..."
+msgstr ""
+#: ../raster/r.out.gdal/main.c:679
+msgid "Unable to build overviews"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:690
+#, c-format
+msgid "Unable to create raster map <%s> using driver <%s>"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:713 ../raster/r.out.gdal/main.c:725
+#: ../raster/r.out.gdal/main.c:738 ../raster/r.out.gdal/main.c:751
+#: ../raster/r.out.gdal/main.c:763 ../raster/r.out.gdal/main.c:777
+#: ../raster/r.out.gdal/export_band.c:477
+#: ../raster/r.out.gdal/export_band.c:489
+#: ../raster/r.out.gdal/export_band.c:502
+#: ../raster/r.out.gdal/export_band.c:515
+#: ../raster/r.out.gdal/export_band.c:527
+#: ../raster/r.out.gdal/export_band.c:540
+#: ../raster/r.out.gdal/export_band.c:554
+msgid "Selected GDAL datatype does not cover data range."
+msgstr ""
+#: ../raster/r.out.gdal/main.c:714 ../raster/r.out.gdal/main.c:726
+#: ../raster/r.out.gdal/main.c:739 ../raster/r.out.gdal/main.c:752
+#: ../raster/r.out.gdal/export_band.c:478
+#: ../raster/r.out.gdal/export_band.c:490
+#: ../raster/r.out.gdal/export_band.c:503
+#: ../raster/r.out.gdal/export_band.c:516
+#, c-format
+msgid "GDAL datatype: %s, range: %d - %d"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:717 ../raster/r.out.gdal/main.c:729
+#: ../raster/r.out.gdal/main.c:742 ../raster/r.out.gdal/main.c:755
+#: ../raster/r.out.gdal/main.c:767 ../raster/r.out.gdal/main.c:781
+#, c-format
+msgid "Range to be exported: %g - %g"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:764 ../raster/r.out.gdal/export_band.c:528
+#, c-format
+msgid "GDAL datatype: %s, range: %u - %u"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:778 ../raster/r.out.gdal/export_band.c:541
+#: ../raster/r.out.gdal/export_band.c:555
+#, c-format
+msgid "GDAL datatype: %s, range: %g - %g"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:805 ../raster/r.out.gdal/main.c:818
+#: ../raster/r.out.gdal/main.c:832 ../raster/r.out.gdal/main.c:845
+#: ../raster/r.out.gdal/main.c:860
+#, c-format
+msgid "Mismatch between metadata nodata value and actual nodata value in exported raster: specified nodata value %g gets converted to %d by selected GDAL datatype."
+msgstr ""
+#: ../raster/r.out.gdal/main.c:808 ../raster/r.out.gdal/main.c:835
+#: ../raster/r.out.gdal/main.c:863
+#, c-format
+msgid "GDAL datatype: %s, valid range: %d - %d"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:821 ../raster/r.out.gdal/main.c:848
+#, c-format
+msgid "GDAL datatype: %s, valid range: %u - %u"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:874
+#, c-format
+msgid "Mismatch between metadata nodata value and actual nodata value in exported raster: specified nodata value %g gets converted to %g by selected GDAL datatype."
+msgstr ""
+#: ../raster/r.out.gdal/main.c:877
+#, c-format
+msgid "GDAL datatype: %s, valid range: %g - %g"
+msgstr ""
+#: ../raster/r.out.gdal/export_band.c:53 ../raster/r.out.gdal/export_band.c:359
+msgid "Unable to allocate buffer for reading raster map"
+msgstr ""
+#: ../raster/r.out.gdal/export_band.c:168
+#, c-format
+msgid "Using GDAL data type <%s>"
+msgstr ""
+#: ../raster/r.out.gdal/export_band.c:173
+#, c-format
+msgid "Input raster map contains cells with NULL-value (no-data). The value %d will be used to represent no-data values in the input map. You can specify a nodata value with the %s option."
+msgstr ""
+#: ../raster/r.out.gdal/export_band.c:178
+#, c-format
+msgid "Input raster map contains cells with NULL-value (no-data). The value %g will be used to represent no-data values in the input map. You can specify a nodata value with the %s option."
+msgstr ""
+#: ../raster/r.out.gdal/export_band.c:188
+#, c-format
+msgid "The default nodata value is present in rasterband <%s> and would lead to data loss. Please specify a custom nodata value with the %s parameter."
+msgstr ""
+#: ../raster/r.out.gdal/export_band.c:195
+#, c-format
+msgid "The user given nodata value %g is present in rasterband <%s> and would lead to data loss. Please specify a different nodata value with the %s parameter."
+msgstr ""
+#: ../raster/r.out.gdal/export_band.c:240
+msgid "Unable to get raster band"
+msgstr ""
+#: ../raster/r.out.gdal/export_band.c:396
+#: ../raster/r.out.gdal/export_band.c:425
+#: ../raster/r.out.gdal/export_band.c:454
+msgid "Unable to write GDAL raster file"
+msgstr ""
+#: ../raster/r.out.gdal/export_band.c:481
+#: ../raster/r.out.gdal/export_band.c:493
+#: ../raster/r.out.gdal/export_band.c:506
+#: ../raster/r.out.gdal/export_band.c:519
+#: ../raster/r.out.gdal/export_band.c:531
+#: ../raster/r.out.gdal/export_band.c:544
+#: ../raster/r.out.gdal/export_band.c:558
+#, c-format
+msgid "Raster map <%s> range: %g - %g"
+msgstr ""
+#: ../raster/r.out.gdal/attr.c:140 ../raster/r.out.gdal/attr.c:178
+msgid "Failed to set raster attribute table"
+msgstr ""
+#: ../raster/r.basins.fill/main.c:56 ../raster/r.water.outlet/main.c:59
+#: ../raster/r.watershed/front/main.c:75
+msgid "watershed"
+msgstr ""
+#: ../raster/r.basins.fill/main.c:58
+msgid "Generates watershed subbasins raster map."
+msgstr ""
+#: ../raster/r.basins.fill/main.c:62
+msgid "Name of input coded stream network raster map"
+msgstr ""
+#: ../raster/r.basins.fill/main.c:66
+msgid "Name of input thinned ridge network raster map"
+msgstr ""
+#: ../raster/r.basins.fill/main.c:74
+msgid "Number of passes through the dataset"
+msgstr ""
+#: ../raster/r.basins.fill/main.c:122
+msgid "Forward sweep complete"
+msgstr ""
+#: ../raster/r.basins.fill/main.c:139
+msgid "Reverse sweep complete"
+msgstr ""
+#: ../raster/r.basins.fill/read_map.c:39
+#, c-format
+msgid "Reading <%s> ... "
+msgstr ""
+#: ../raster/r.in.xyz/main.c:167
+msgid "Creates a raster map from an assemblage of many coordinates using univariate statistics."
+msgstr ""
+#: ../raster/r.in.xyz/main.c:171
+msgid "ASCII file containing input data (or \"-\" to read from stdin)"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:208
+msgid "Pth (nth) percentile of point values in cell"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:239
+msgid "If a separate value column is given, this option refers to the z-coordinate column to be filtered by the zrange option"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:250
+msgid "Number of header lines to skip at top of input file"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:258 ../vector/v.in.lidar/main.c:196
+#: ../vector/v.decimate/main.c:148
+msgid "Filter range for z data (min,max)"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:259 ../raster/r.in.xyz/main.c:267
+#: ../raster/r.in.xyz/main.c:276 ../raster/r.in.xyz/main.c:284
+#: ../raster/r.in.xyz/main.c:292
+msgid "Advanced Input"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:266
+msgid "Scale to apply to z data"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:274
+msgid "Alternate column number of data values in input file"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:275
+msgid "If not given (or set to 0) the z-column data is used"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:283
+msgid "Filter range for alternate value column data (min,max)"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:291
+msgid "Scale to apply to alternate value column data"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:314
+msgid "Pth percentile of the values"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:329 ../raster/r.in.xyz/main.c:336
+msgid "Scan"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:366
+msgid "Please specify a reasonable column number."
+msgstr ""
+#: ../raster/r.in.xyz/main.c:378 ../vector/v.in.ascii/main.c:220
+msgid "Please specify reasonable number of lines to skip"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:397
+msgid "Invalid vrange"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:536
+#, c-format
+msgid "Unable to process the hole map at once. Please set the %s option to some value lower than 100."
+msgstr ""
+#: ../raster/r.in.xyz/main.c:589
+msgid "If input is not from a file it is only possible to perform a single pass."
+msgstr ""
+#: ../raster/r.in.xyz/main.c:601
+msgid "Range filters will not be taken into account during scan"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:638
+msgid "Reading input data..."
+msgstr ""
+#: ../raster/r.in.xyz/main.c:721 ../raster/r.in.xyz/main.c:729
+#: ../raster/r.in.xyz/main.c:1218 ../raster/r.in.xyz/main.c:1226
+#, c-format
+msgid ""
+"Not enough data columns. Incorrect delimiter or column number? Found the following character(s) in row %lu:\n"
+"[%s]"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:725 ../raster/r.in.xyz/main.c:1222
+msgid "Line ignored as requested"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:744 ../raster/r.in.xyz/main.c:1256
+#, c-format
+msgid "Bad y-coordinate line %lu column %d. <%s>"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:751 ../raster/r.in.xyz/main.c:1241
+#, c-format
+msgid "Bad x-coordinate line %lu column %d. <%s>"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:769 ../raster/r.in.xyz/main.c:1271
+#, c-format
+msgid "Bad z-coordinate line %lu column %d. <%s>"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:782 ../raster/r.in.xyz/main.c:1289
+#, c-format
+msgid "Bad data value line %lu column %d. <%s>"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:835
+#, c-format
+msgid "%lu points found in input file"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:838
+msgid "Writing to output raster map..."
+msgstr ""
+#: ../raster/r.in.xyz/main.c:1177
+#, c-format
+msgid "%lu points found in region."
+msgstr ""
+#: ../raster/r.surf.fractal/spec_syn.c:60
+msgid "Preliminary surface calculations..."
+msgstr ""
+#: ../raster/r.surf.fractal/spec_syn.c:119
+#, c-format
+msgid "Calculating surface %d (of %d)..."
+msgstr ""
+#: ../raster/r.surf.fractal/main.c:40
+msgid "fractal"
+msgstr ""
+#: ../raster/r.surf.fractal/main.c:42
+msgid "Creates a fractal surface of a given fractal dimension."
+msgstr ""
+#: ../raster/r.surf.fractal/main.c:48
+msgid "Fractal dimension of surface (2 < D < 3)"
+msgstr ""
+#: ../raster/r.surf.fractal/main.c:55
+msgid "Number of intermediate images to produce"
+msgstr ""
+#: ../raster/r.surf.fractal/main.c:79
+#, c-format
+msgid "Fractal dimension of %.2lf must be between 2 and 3."
+msgstr ""
+#: ../raster/r.surf.fractal/process.c:54
+msgid "Unable to allocate data buffer. Check current region with g.region."
+msgstr ""
+#: ../raster/r.kappa/prt_hdr.c:18
+#, c-format
+msgid "Cannot open file <%s> to write header"
+msgstr ""
+#: ../raster/r.kappa/main.c:70 ../imagery/i.segment/main.c:38
+#: ../imagery/i.gensig/main.c:40 ../imagery/i.maxlik/main.c:62
+#: ../imagery/i.smap/main.c:39 ../imagery/i.gensigset/main.c:41
+#: ../imagery/i.cluster/main.c:76 ../vector/v.class/main.c:46
+msgid "classification"
+msgstr ""
+#: ../raster/r.kappa/main.c:72
+msgid "Calculates error matrix and kappa parameter for accuracy assessment of classification result."
+msgstr ""
+#: ../raster/r.kappa/main.c:78
+msgid "Name of raster map containing classification result"
+msgstr ""
+#: ../raster/r.kappa/main.c:83
+msgid "Name of raster map containing reference classes"
+msgstr ""
+#: ../raster/r.kappa/main.c:88
+msgid "Name for output file containing error matrix and kappa"
+msgstr ""
+#: ../raster/r.kappa/main.c:96
+msgid "Title for error matrix and kappa"
+msgstr ""
+#: ../raster/r.kappa/main.c:102
+msgid "Wide report"
+msgstr ""
+#: ../raster/r.kappa/main.c:103
+msgid "132 columns (default: 80)"
+msgstr ""
+#: ../raster/r.kappa/main.c:108
+msgid "No header in the report"
+msgstr ""
+#: ../raster/r.kappa/prt_label.c:17
+#, c-format
+msgid "Can't open file <%s> to write label"
+msgstr ""
+#: ../raster/r.kappa/calc_kappa.c:32
+#, c-format
+msgid "Cannot open file <%s> to write kappa and relevant parameters"
+msgstr ""
+#: ../raster/r.kappa/prt_mat.c:39
+#, c-format
+msgid "Cannot open file <%s> to write cats and counts (error matrix)"
+msgstr ""
+#: ../raster/r.coin/print_coin.c:44
+#, c-format
+msgid "Preparing report ..."
+msgstr ""
+#: ../raster/r.coin/main.c:69
+msgid "Tabulates the mutual occurrence (coincidence) of categories for two raster map layers."
+msgstr ""
+#: ../raster/r.coin/main.c:74
+msgid "Name of first input raster map"
+msgstr ""
+#: ../raster/r.coin/main.c:78
+msgid "Name of second input raster map"
+msgstr ""
+#: ../raster/r.coin/main.c:84
+msgid "Unit of measure"
+msgstr ""
+#: ../raster/r.coin/main.c:86
+msgid "c(ells), p(ercent), x(percent of category [column]), y(percent of category [row]), a(cres), h(ectares), k(square kilometers), m(square miles)"
+msgstr ""
+#: ../raster/r.coin/main.c:93
+msgid "Wide report, 132 columns (default: 80)"
+msgstr ""
+#: ../raster/r.coin/make_coin.c:48
+#, c-format
+msgid "Tabulating Coincidence between '%s' and '%s'"
+msgstr ""
+#: ../raster/r.coin/make_coin.c:61
+msgid "Unable to create any tempfiles"
+msgstr ""
+#: ../raster/r.coin/make_coin.c:65
+msgid "Unable to run r.stats"
+msgstr ""
+#: ../raster/r.coin/make_coin.c:72
+msgid "Unexpected output from r.stats"
+msgstr ""
+#: ../raster/r.coin/make_coin.c:84
+msgid "Unable to open tempfile"
+msgstr ""
+#: ../raster/r.water.outlet/main.c:56
+msgid "Creates watershed basins from a drainage direction map."
+msgstr ""
+#: ../raster/r.water.outlet/main.c:62
+msgid "Name of input drainage direction map"
+msgstr ""
+#: ../raster/r.water.outlet/main.c:65
+msgid "Name for output watershed basin map"
+msgstr ""
+#: ../raster/r.water.outlet/main.c:68
+msgid "Coordinates of outlet point"
+msgstr ""
+#: ../raster/r.water.outlet/main.c:81
+#, c-format
+msgid "Illegal east coordinate '%s'"
+msgstr ""
+#: ../raster/r.water.outlet/main.c:83
+#, c-format
+msgid "Illegal north coordinate '%s'"
+msgstr ""
+#: ../raster/r.water.outlet/main.c:88
+#, c-format
+msgid "Ignoring point outside computation region: %.4f,%.4f"
+msgstr ""
+#: ../raster/r.to.vect/main.c:79
+msgid "vectorization"
+msgstr ""
+#: ../raster/r.to.vect/main.c:80
+msgid "Converts a raster map into a vector map."
+msgstr ""
+#: ../raster/r.to.vect/main.c:106 ../raster/r.to.vect/main.c:113
+#: ../vector/v.to.rast/main.c:88 ../vector/v.to.rast/main.c:94
+#: ../vector/v.to.rast/main.c:100 ../vector/v.buffer/main.c:306
+#: ../vector/v.in.ogr/main.c:290 ../vector/v.in.ogr/main.c:300
+#: ../vector/v.in.ogr/main.c:310 ../vector/v.in.ogr/main.c:343
+#: ../vector/v.in.ogr/main.c:375 ../vector/v.overlay/main.c:135
+#: ../vector/v.overlay/main.c:145 ../vector/v.extract/main.c:93
+#: ../vector/v.extract/main.c:145 ../vector/v.generalize/main.c:245
+msgid "Attributes"
+msgstr ""
+#: ../raster/r.to.vect/main.c:118
+msgid "Recommended for massive point conversion"
+msgstr ""
+#: ../raster/r.to.vect/main.c:131
+msgid "z flag is supported only for points"
+msgstr ""
+#: ../raster/r.to.vect/main.c:142
+msgid "Raster is not CELL, '-v' flag ignored, raster values will be written to the table."
+msgstr ""
+#: ../raster/r.to.vect/main.c:144
+msgid "Raster is not CELL, '-v' flag ignored, raster values will be z coordinate."
+msgstr ""
+#: ../raster/r.to.vect/main.c:146
+msgid "Raster is not CELL, '-v' flag ignored, raster values will be lost."
+msgstr ""
+#: ../raster/r.to.vect/main.c:151
+msgid "Categories will be unique sequence, raster values will be lost."
+msgstr ""
+#: ../raster/r.to.vect/main.c:312
+msgid "Updating attributes..."
+msgstr ""
+#: ../raster/r.to.vect/main.c:335
+#, c-format
+msgid "Unable to insert into table: %s"
+msgstr ""
+#: ../raster/r.to.vect/lines.c:71
+msgid "Extracting lines..."
+msgstr ""
+#: ../raster/r.to.vect/lines.c:504
+#, c-format
+msgid "Crowded cell at (%f, %f): row %d, col %d, count %d"
+msgstr ""
+#: ../raster/r.to.vect/lines.c:508
+msgid ""
+"Raster map is not thinned properly.\n"
+"Please run r.thin."
+msgstr ""
+#: ../raster/r.to.vect/lines.c:582
+msgid "join_lines: p front pointer not NULL!"
+msgstr ""
+#: ../raster/r.to.vect/lines.c:588
+msgid "join_lines: q front pointer not NULL!"
+msgstr ""
+#: ../raster/r.to.vect/lines.c:606
+msgid "extend line: p is NULL"
+msgstr ""
+#: ../raster/r.to.vect/lines.c:632
+msgid "extend_lines: p front pointer not NULL!"
+msgstr ""
+#: ../raster/r.to.vect/lines.c:639
+msgid "extend_lines: q back pointer not NULL!"
+msgstr ""
+#: ../raster/r.to.vect/points.c:36
+msgid "Extracting points..."
+msgstr ""
+#: ../raster/r.to.vect/areas_io.c:154
+#, c-format
+msgid ""
+"write_bnd: line terminated unexpectedly\n"
+"previous (%d) point %p (%d,%d,%d) %p %p"
+msgstr ""
+#: ../raster/r.to.vect/areas_io.c:287
+msgid "Writing areas..."
+msgstr ""
+#: ../raster/r.to.vect/lines_io.c:76
+msgid "write_line: found half a loop!"
+msgstr ""
+#: ../raster/r.to.vect/lines_io.c:177
+#, c-format
+msgid ""
+"write_line: line terminated unexpectedly\n"
+" previous (%d) point %p (%d,%d,%d) %p %p"
+msgstr ""
+#: ../raster/r.to.vect/areas.c:122
+msgid "Extracting areas..."
+msgstr ""
+#: ../raster/r.out.vrml/main.c:49
+msgid "VRML"
+msgstr "VRML"
+#: ../raster/r.out.vrml/main.c:51
+msgid "Exports a raster map to the Virtual Reality Modeling Language (VRML)."
+msgstr ""
+#: ../raster/r.out.vrml/main.c:58
+msgid "Name of input color map"
+msgstr ""
+#: ../raster/r.out.vrml/main.c:65 ../misc/m.nviz.image/args.c:575
+msgid "Vertical exaggeration"
+msgstr ""
+#: ../raster/r.out.vrml/main.c:69
+msgid "Name for output VRML file"
+msgstr "Output VRML fájl neve"
+#: ../raster/r.out.vrml/main.c:88
+#, c-format
+msgid "Range info for [%s] not available (run r.support)"
+msgstr ""
+#: ../raster/r.out.vrml/main.c:97
+#, c-format
+msgid "Range info for <%s> not available (run r.support)"
+msgstr ""
+#: ../raster/r.out.vrml/main.c:129
+#, c-format
+msgid "Opening %s for writing... "
+msgstr ""
+#: ../raster/r.out.vrml/put_grid.c:38
+msgid "Writing vertices..."
+msgstr ""
+#: ../raster/r.out.vrml/put_grid.c:83
+msgid "Writing color file..."
+msgstr ""
+#: ../raster/r.quantile/main.c:69
+msgid "Computing histogram"
+msgstr ""
+#: ../raster/r.quantile/main.c:270
+msgid "Compute quantiles using two passes."
+msgstr ""
+#: ../raster/r.quantile/main.c:303
+msgid "Generate recode rules based on quantile-defined intervals"
+msgstr ""
+#: ../raster/r.quantile/main.c:337
+msgid "Too many quantiles"
+msgstr ""
+#: ../raster/r.param.scale/main.c:42
+msgid "Lat/Long locations are not supported by this module"
+msgstr ""
+#: ../raster/r.param.scale/process.c:75
+msgid "E-W and N-S grid resolutions are different. Taking average."
+msgstr ""
+#: ../raster/r.param.scale/interface.c:55
+msgid "geomorphology"
+msgstr ""
+#: ../raster/r.param.scale/interface.c:58
+msgid "landform"
+msgstr ""
+#: ../raster/r.param.scale/interface.c:59
+msgid "Extracts terrain parameters from a DEM."
+msgstr ""
+#: ../raster/r.param.scale/interface.c:60
+msgid "Uses a multi-scale approach by taking fitting quadratic parameters to any size window (via least squares)."
+msgstr ""
+#: ../raster/r.param.scale/interface.c:78
+msgid "Name for output raster map containing morphometric parameter"
+msgstr ""
+#: ../raster/r.param.scale/interface.c:82
+msgid "Slope tolerance that defines a 'flat' surface (degrees)"
+msgstr ""
+#: ../raster/r.param.scale/interface.c:89
+msgid "Curvature tolerance that defines 'planar' surface"
+msgstr ""
+#: ../raster/r.param.scale/interface.c:96
+msgid "Size of processing window (odd number only)"
+msgstr ""
+#: ../raster/r.param.scale/interface.c:104
+msgid "Morphometric parameter in 'size' window to calculate"
+msgstr ""
+#: ../raster/r.param.scale/interface.c:112
+msgid "Exponent for distance weighting (0.0-4.0)"
+msgstr ""
+#: ../raster/r.param.scale/interface.c:124
+msgid "Constrain model through central window cell"
+msgstr ""
+#: ../raster/r.param.scale/interface.c:167
+msgid "Morphometric parameter not recognised. Assuming 'Elevation'"
+msgstr ""
+#: ../raster/r.param.scale/interface.c:175
+msgid "Inappropriate window size (too big or even)"
+msgstr ""
+#: ../raster/r.surf.idw/main.c:107 ../raster/r.fill.stats/main.c:778
+#: ../vector/v.surf.idw/main.c:90
+msgid "IDW"
+msgstr "IDW"
+#: ../raster/r.surf.idw/main.c:109
+msgid "Provides surface interpolation from raster point data by Inverse Distance Squared Weighting."
+msgstr ""
+#: ../raster/r.surf.idw/main.c:119 ../vector/v.surf.idw/main.c:113
+msgid "Number of interpolation points"
+msgstr ""
+#: ../raster/r.surf.idw/main.c:124
+msgid "Output is the interpolation error"
+msgstr ""
+#: ../raster/r.surf.idw/main.c:130
+#, c-format
+msgid "Illegal value for '%s' (%s)"
+msgstr ""
+#: ../raster/r.surf.idw/main.c:260
+#, c-format
+msgid "Interpolating raster map <%s> (%d row)..."
+msgid_plural "Interpolating raster map <%s> (%d rows)..."
+msgstr[0] ""
+msgstr[1] ""
+#: ../raster/r.in.bin/main.c:61 ../raster/r.in.bin/main.c:70
+#: ../raster/r.in.bin/main.c:614
+msgid "Error reading data"
+msgstr ""
+#: ../raster/r.in.bin/main.c:260
+msgid "Import a binary raster file into a GRASS raster map layer."
+msgstr ""
+#: ../raster/r.in.bin/main.c:265
+msgid "Import as floating-point data (default: integer)"
+msgstr ""
+#: ../raster/r.in.bin/main.c:270
+msgid "Import as double-precision floating-point data (default: integer)"
+msgstr ""
+#: ../raster/r.in.bin/main.c:274 ../raster3d/r3.in.bin/main.c:369
+msgid "Signed data (two's complement)"
+msgstr ""
+#: ../raster/r.in.bin/main.c:279
+msgid "Byte swap the data during import"
+msgstr ""
+#: ../raster/r.in.bin/main.c:284
+msgid "Get region info from GMT style header"
+msgstr ""
+#: ../raster/r.in.bin/main.c:285 ../raster/r.in.bin/main.c:339
+#: ../raster/r.in.bin/main.c:347 ../raster/r.in.bin/main.c:355
+#: ../raster/r.in.bin/main.c:363 ../raster/r.in.bin/main.c:370
+#: ../raster/r.in.bin/main.c:377 ../raster/r.region/main.c:110
+#: ../raster/r.region/main.c:119 ../raster/r.region/main.c:128
+#: ../raster/r.region/main.c:137 ../raster3d/r3.in.bin/main.c:284
+#: ../raster3d/r3.in.bin/main.c:292 ../raster3d/r3.in.bin/main.c:300
+#: ../raster3d/r3.in.bin/main.c:308 ../raster3d/r3.in.bin/main.c:316
+#: ../raster3d/r3.in.bin/main.c:323 ../raster3d/r3.in.bin/main.c:330
+#: ../raster3d/r3.in.bin/main.c:337 ../raster3d/r3.in.bin/main.c:344
+#: ../general/g.region/main.c:161 ../general/g.region/main.c:205
+#: ../general/g.region/main.c:214 ../general/g.region/main.c:223
+#: ../general/g.region/main.c:232 ../general/g.region/main.c:241
+#: ../general/g.region/main.c:250 ../general/g.region/main.c:326
+#: ../general/g.region/main.c:337 ../general/g.region/main.c:349
+msgid "Bounds"
+msgstr ""
+#: ../raster/r.in.bin/main.c:288
+msgid "Name of binary raster file to be imported"
+msgstr ""
+#: ../raster/r.in.bin/main.c:291
+msgid "Output name or prefix if several bands are imported"
+msgstr ""
+#: ../raster/r.in.bin/main.c:313
+msgid "Header size in bytes"
+msgstr ""
+#: ../raster/r.in.bin/main.c:321
+msgid "Number of bands in input file"
+msgstr ""
+#: ../raster/r.in.bin/main.c:322
+msgid "Bands must be in band-sequential order"
+msgstr ""
+#: ../raster/r.in.bin/main.c:338 ../raster3d/r3.in.bin/main.c:283
+msgid "Northern limit of geographic region (outer edge)"
+msgstr ""
+#: ../raster/r.in.bin/main.c:346 ../raster3d/r3.in.bin/main.c:291
+msgid "Southern limit of geographic region (outer edge)"
+msgstr ""
+#: ../raster/r.in.bin/main.c:354 ../raster3d/r3.in.bin/main.c:299
+msgid "Eastern limit of geographic region (outer edge)"
+msgstr ""
+#: ../raster/r.in.bin/main.c:362 ../raster3d/r3.in.bin/main.c:307
+msgid "Western limit of geographic region (outer edge)"
+msgstr ""
+#: ../raster/r.in.bin/main.c:369 ../raster3d/r3.in.bin/main.c:329
+msgid "Number of rows"
+msgstr ""
+#: ../raster/r.in.bin/main.c:376 ../raster3d/r3.in.bin/main.c:336
+msgid "Number of columns"
+msgstr ""
+#: ../raster/r.in.bin/main.c:383 ../raster3d/r3.in.bin/main.c:350
+msgid "Set Value to NULL"
+msgstr ""
+#: ../raster/r.in.bin/main.c:392
+msgid "Flip input horizontal and/or vertical"
+msgstr ""
+#: ../raster/r.in.bin/main.c:395
+msgid "Flip input horizontal (East - West)"
+msgstr ""
+#: ../raster/r.in.bin/main.c:396
+msgid "Flip input vertical (North - South)"
+msgstr ""
+#: ../raster/r.in.bin/main.c:410
+#, c-format
+msgid "Option %s must be > 0"
+msgstr ""
+#: ../raster/r.in.bin/main.c:413
+#, c-format
+msgid "Option %s must be >= 0"
+msgstr ""
+#: ../raster/r.in.bin/main.c:435 ../raster/r.in.bin/main.c:438
+#, c-format
+msgid "Option %s= is ignored if -%c is set"
+msgstr ""
+#: ../raster/r.in.bin/main.c:467
+#, c-format
+msgid "-%c incompatible with %s=%d; must be 4 or 8"
+msgstr ""
+#: ../raster/r.in.bin/main.c:476
+#, c-format
+msgid "-%c incompatible with %s=%d; must be 8"
+msgstr ""
+#: ../raster/r.in.bin/main.c:484
+#, c-format
+msgid "%s= required for integer data"
+msgstr ""
+#: ../raster/r.in.bin/main.c:488
+#, c-format
+msgid "Integer input doesn't support %s=8 in this build"
+msgstr ""
+#: ../raster/r.in.bin/main.c:493
+#, c-format
+msgid "%s= must be 1, 2, 4 or 8"
+msgstr ""
+#: ../raster/r.in.bin/main.c:506
+#, c-format
+msgid "Either -%c or %s= and %s= must be given"
+msgstr ""
+#: ../raster/r.in.bin/main.c:512
+#, c-format
+msgid "Either all or none of %s=, %s=, %s= and %s= must be given"
+msgstr ""
+#: ../raster/r.in.bin/main.c:521 ../display/d.grid/main.c:266
+#: ../raster3d/r3.in.bin/main.c:424
+#, c-format
+msgid "Illegal north coordinate <%s>"
+msgstr ""
+#: ../raster/r.in.bin/main.c:523 ../raster3d/r3.in.bin/main.c:426
+#, c-format
+msgid "Illegal south coordinate <%s>"
+msgstr ""
+#: ../raster/r.in.bin/main.c:525 ../display/d.grid/main.c:259
+#: ../raster3d/r3.in.bin/main.c:428
+#, c-format
+msgid "Illegal east coordinate <%s>"
+msgstr ""
+#: ../raster/r.in.bin/main.c:527 ../raster3d/r3.in.bin/main.c:430
+#, c-format
+msgid "Illegal west coordinate <%s>"
+msgstr ""
+#: ../raster/r.in.bin/main.c:533 ../raster3d/r3.in.bin/main.c:438
+#, c-format
+msgid "Unable to open <%s>"
+msgstr ""
+#: ../raster/r.in.bin/main.c:554
+#, c-format
+msgid "East-West (ewres: %f) and North-South (nwres: %f) resolution differ significantly. Did you assign %s= and %s= correctly?"
+msgstr ""
+#: ../raster/r.in.bin/main.c:575
+msgid "File Size %"
+msgstr ""
+#: ../raster/r.in.bin/main.c:577 ../raster3d/r3.in.bin/main.c:448
+msgid "Bytes do not match file size"
+msgstr ""
+#: ../raster/r.in.bin/main.c:595
+#, c-format
+msgid "Importing band %d..."
+msgstr ""
+#: ../raster/r.drain/main.c:179
+msgid "Directional drain selected... checking for direction raster map"
+msgstr ""
+#: ../raster/r.drain/main.c:182
+msgid "Surface/Hydrology drain selected"
+msgstr ""
+#: ../raster/r.drain/main.c:187
+#, c-format
+msgid "Direction raster map <%s> not specified, if direction flag is on, a direction raster must be given"
+msgstr ""
+#: ../raster/r.drain/main.c:194
+#, c-format
+msgid "Direction raster map <%s> should not be specified for Surface/Hydrology drains"
+msgstr ""
+#: ../raster/r.drain/main.c:327
+msgid "No start/stop point(s) specified"
+msgstr ""
+#: ../raster/r.drain/main.c:402
+msgid "Calculating flow directions..."
+msgstr ""
+#: ../raster/r.drain/main.c:693
+#, c-format
+msgid "direction read: %lf, neighbour found: %i"
+msgstr ""
+#: ../raster/r.random.cells/main.c:50
+msgid "autocorrelation"
+msgstr ""
+#: ../raster/r.random.cells/main.c:52
+msgid "Generates random cell values with spatial dependence."
+msgstr ""
+#: ../raster/r.random.cells/main.c:70
+msgid "Maximum number of cells to be created"
+msgstr ""
+#: ../raster/r.random.cells/main.c:77
+msgid "Random seed (SEED_MIN >= value >= SEED_MAX) (default [random])"
+msgstr ""
+#: ../raster/r.random.cells/random.c:50
+#, c-format
+msgid "RAN1: j == %d shouldn't happen"
+msgstr ""
+#: ../raster/r.random.cells/init.c:77
+msgid "Distance must be >= 0.0"
+msgstr ""
+#: ../raster/r.surf.contour/main.c:64
+msgid "Generates surface raster map from rasterized contours."
+msgstr ""
+#: ../raster/r.surf.contour/main.c:67
+msgid "Name of input raster map containing contours"
+msgstr ""
+#: ../raster/r.fill.stats/main.c:155
+msgid "Spatial weights neighborhood (cells):"
+msgstr ""
+#: ../raster/r.fill.stats/main.c:779 ../raster/r.null/main.c:61
+#: ../raster3d/r3.null/main.c:181
+msgid "null data"
+msgstr ""
+#: ../raster/r.fill.stats/main.c:781
+msgid "Rapidly fills 'no data' cells (NULLs) of a raster map with interpolated values (IDW)."
+msgstr ""
+#: ../raster/r.fill.stats/main.c:789
+msgid "Raster map with data gaps to fill"
+msgstr ""
+#: ../raster/r.fill.stats/main.c:794
+msgid "Name of result output map"
+msgstr ""
+#: ../raster/r.fill.stats/main.c:799
+msgid "Name of uncertainty output map"
+msgstr ""
+#: ../raster/r.fill.stats/main.c:808
+msgid "Distance threshold (default: in cells) for interpolation"
+msgstr ""
+#: ../raster/r.fill.stats/main.c:817
+msgid "Statistic for interpolated cell values"
+msgstr ""
+#: ../raster/r.fill.stats/main.c:828
+msgid "Minimum input data value to include in interpolation"
+msgstr ""
+#: ../raster/r.fill.stats/main.c:837
+msgid "Maximum input data value to include in interpolation"
+msgstr ""
+#: ../raster/r.fill.stats/main.c:846
+msgid "Power coefficient for IDW interpolation"
+msgstr ""
+#: ../raster/r.fill.stats/main.c:856
+msgid "Minimum number of data cells within search radius"
+msgstr ""
+#: ../raster/r.fill.stats/main.c:861
+msgid "Interpret distance as map units, not number of cells"
+msgstr ""
+#: ../raster/r.fill.stats/main.c:865
+msgid "Keep (preserve) original cell values"
+msgstr ""
+#: ../raster/r.fill.stats/main.c:867
+msgid "By default original values are smoothed"
+msgstr ""
+#: ../raster/r.fill.stats/main.c:871
+msgid "Just print the spatial weights matrix"
+msgstr ""
+#: ../raster/r.fill.stats/main.c:875
+msgid "Just print estimated memory usage"
+msgstr ""
+#: ../raster/r.fill.stats/main.c:880
+msgid "Single precision floating point output"
+msgstr ""
+#: ../raster/r.fill.stats/main.c:893
+msgid "You are working with lat/lon data."
+msgstr ""
+#: ../raster/r.fill.stats/main.c:894
+msgid "This module uses a straight-line distance metric."
+msgstr ""
+#: ../raster/r.fill.stats/main.c:895
+msgid "Expect inaccuracies."
+msgstr ""
+#: ../raster/r.fill.stats/main.c:910
+msgid "Result map name cannot be identical with uncertainty map name."
+msgstr ""
+#: ../raster/r.fill.stats/main.c:919
+msgid "Maximum distance must be larger than zero."
+msgstr ""
+#: ../raster/r.fill.stats/main.c:923
+#, c-format
+msgid "Maximum distance must be at least '%.6f' (W-E resolution)."
+msgstr ""
+#: ../raster/r.fill.stats/main.c:928
+#, c-format
+msgid "Maximum distance must be at least '%.6f' (S-N resolution)."
+msgstr ""
+#: ../raster/r.fill.stats/main.c:933
+#, c-format
+msgid "Maximum distance must be at least '%.6f' (W-E and S-N resolution)."
+msgstr ""
+#: ../raster/r.fill.stats/main.c:938
+#, c-format
+msgid "Maximum distance too large. Adjusted to '%.6f' (diagonal of current region)."
+msgstr ""
+#: ../raster/r.fill.stats/main.c:948
+msgid "Maximum distance must be at least one cell."
+msgstr ""
+#: ../raster/r.fill.stats/main.c:954
+#, c-format
+msgid "Maximum distance too large. Adjusted to '%lu' cells (diagonal of current region)."
+msgstr ""
+#: ../raster/r.fill.stats/main.c:961
+msgid "Minimum number of cells must be at least '1'."
+msgstr ""
+#: ../raster/r.fill.stats/main.c:964
+msgid "Specified minimum number of cells unreachable with current settings."
+msgstr ""
+#: ../raster/r.fill.stats/main.c:969
+msgid "Value for 'minimum' must be smaller than value for 'maximum'."
+msgstr ""
+#: ../raster/r.fill.stats/main.c:973
+msgid "The 'power' option has no effect in any mode other than 'wmean'."
+msgstr ""
+#: ../raster/r.fill.stats/main.c:984
+msgid ""
+"The specified maximum distance cannot be resolved to whole cells\n"
+" at the current resolution settings."
+msgstr ""
+#: ../raster/r.fill.stats/main.c:995
+#, c-format
+msgid "W-E size of neighborhood is %lu cells."
+msgstr ""
+#: ../raster/r.fill.stats/main.c:996
+#, c-format
+msgid "S-N size of neighborhood is %lu cells."
+msgstr ""
+#: ../raster/r.fill.stats/main.c:999
+msgid "Neighborhood cannot be smaller than 3 cells in X or Y direction."
+msgstr ""
+#: ../raster/r.fill.stats/main.c:1052
+#, c-format
+msgid "Input data range is %f to %f.\n"
+msgstr ""
+#: ../raster/r.fill.stats/main.c:1068
+#, c-format
+msgid "Input data type is integer but interpolation mode is '%s'."
+msgstr ""
+#: ../raster/r.fill.stats/main.c:1072
+msgid "Output type changed to floating point (single)."
+msgstr ""
+#: ../raster/r.fill.stats/main.c:1076
+msgid "Output type changed to floating point (double)."
+msgstr ""
+#: ../raster/r.fill.stats/main.c:1081
+#, c-format
+msgid "Ignoring '%c' flag. Output data type will be integer."
+msgstr ""
+#: ../raster/r.fill.stats/main.c:1111
+#, c-format
+msgid "Input data type is '%s' (%i bytes) and output data type is '%s' (%i bytes)."
+msgstr ""
+#: ../raster/r.fill.stats/main.c:1252
+msgid "Interpolating:"
+msgstr ""
+#: ../raster/r.fill.stats/main.c:1386
+#, c-format
+msgid "Processing time was %ih%im%is."
+msgstr ""
+#: ../raster/r.tile/main.c:46
+msgid "Splits a raster map into tiles."
+msgstr ""
+#: ../raster/r.tile/main.c:55
+msgid "Output base name"
+msgstr ""
+#: ../raster/r.tile/main.c:62
+msgid "Width of tiles (columns)"
+msgstr ""
+#: ../raster/r.tile/main.c:69
+msgid "Height of tiles (rows)"
+msgstr ""
+#: ../raster/r.tile/main.c:76
+msgid "Overlap of tiles"
+msgstr ""
+#: ../raster/r.tile/main.c:129
+#, c-format
+msgid "Generating %d x %d = %d tiles..."
+msgstr ""
+#: ../raster/r.tile/main.c:184
+#, c-format
+msgid "Unable to read cats for %s"
+msgstr ""
+#: ../raster/r.patch/main.c:62
+msgid "patching"
+msgstr ""
+#: ../raster/r.patch/main.c:66
+msgid "Creates a composite raster map layer by using known category values from one (or more) map layer(s) to fill in areas of \"no data\" in another map layer."
+msgstr ""
+#: ../raster/r.patch/main.c:73
+msgid "Name of raster maps to be patched together"
+msgstr ""
+#: ../raster/r.patch/main.c:76
+msgid "Name for resultant raster map"
+msgstr ""
+#: ../raster/r.patch/main.c:83
+msgid "Use zero (0) for transparency instead of NULL"
+msgstr ""
+#: ../raster/r.patch/main.c:88
+msgid "Do not create color and category files"
+msgstr ""
+#: ../raster/r.patch/main.c:103
+msgid "The minimum number of input raster maps is two"
+msgstr ""
+#: ../raster/r.patch/main.c:180
+#, c-format
+msgid "Creating support files for raster map <%s>..."
+msgstr ""
+#: ../raster/r.info/main.c:75 ../vector/v.info/main.c:41
+msgid "history"
+msgstr ""
+#: ../raster/r.info/main.c:77
+msgid "Outputs basic information about a raster map."
+msgstr ""
+#: ../raster/r.info/main.c:83
+msgid "Print raster array information in shell script style"
+msgstr ""
+#: ../raster/r.info/main.c:87
+msgid "Print range in shell script style"
+msgstr ""
+#: ../raster/r.info/main.c:95
+msgid "Print extended metadata information in shell script style"
+msgstr ""
+#: ../raster/r.info/main.c:99 ../raster3d/r3.info/main.c:94
+msgid "Print raster history instead of info"
+msgstr ""
+#: ../raster/r.info/main.c:105
+#, c-format
+msgid "Flags -%c and -%c/%c/%c are mutually exclusive"
+msgstr ""
+#: ../raster/r.info/main.c:312 ../raster/r.info/main.c:531
+#: ../raster3d/r3.info/main.c:138 ../raster3d/r3.info/main.c:145
+#: ../raster3d/r3.info/main.c:151 ../raster3d/r3.info/main.c:156
+#: ../raster3d/r3.info/main.c:162 ../raster3d/r3.info/main.c:167
+#: ../raster3d/r3.info/main.c:172 ../raster3d/r3.info/main.c:183
+#: ../raster3d/r3.info/main.c:189 ../raster3d/r3.info/main.c:204
+#: ../raster3d/r3.info/main.c:211 ../raster3d/r3.info/main.c:218
+#: ../raster3d/r3.info/main.c:223 ../raster3d/r3.info/main.c:228
+#: ../raster3d/r3.info/main.c:235 ../raster3d/r3.info/main.c:245
+#: ../raster3d/r3.info/main.c:251 ../raster3d/r3.info/main.c:257
+#: ../raster3d/r3.info/main.c:273 ../raster3d/r3.info/main.c:280
+#: ../raster3d/r3.info/main.c:287 ../raster3d/r3.info/main.c:296
+#: ../raster3d/r3.info/main.c:306 ../raster3d/r3.info/main.c:316
+#: ../raster3d/r3.info/main.c:326 ../raster3d/r3.info/main.c:346
+#: ../raster3d/r3.info/main.c:356 ../raster3d/r3.info/main.c:361
+#: ../raster3d/r3.info/main.c:369 ../raster3d/r3.info/main.c:382
+msgid "Cannot allocate memory for string"
+msgstr ""
+#: ../raster/r.geomorphon/memory.c:21
+#, c-format
+msgid "Region resolution shoudn't be lesser than map %s resolution. Run g.region raster=%s to set proper resolution"
+msgstr ""
+#: ../raster/r.geomorphon/main.c:103
+msgid "Calculates geomorphons (terrain forms) and associated geometry using machine vision approach."
+msgstr ""
+#: ../raster/r.geomorphon/main.c:105
+msgid "geomorphons"
+msgstr ""
+#: ../raster/r.geomorphon/main.c:106
+msgid "terrain patterns"
+msgstr ""
+#: ../raster/r.geomorphon/main.c:107
+msgid "machine vision geomorphometry"
+msgstr ""
+#: ../raster/r.geomorphon/main.c:127
+msgid "Outer search radius"
+msgstr ""
+#: ../raster/r.geomorphon/main.c:134
+msgid "Inner search radius"
+msgstr ""
+#: ../raster/r.geomorphon/main.c:141
+msgid "Flatenss threshold (degrees)"
+msgstr ""
+#: ../raster/r.geomorphon/main.c:149
+msgid "Flatenss distance, zero for none"
+msgstr ""
+#: ../raster/r.geomorphon/main.c:155
+msgid "Prefix for maps resulting from multiresolution approach"
+msgstr ""
+#: ../raster/r.geomorphon/main.c:156 ../raster/r.geomorphon/main.c:164
+#: ../raster/r.geomorphon/main.c:172
+msgid "Multires"
+msgstr ""
+#: ../raster/r.geomorphon/main.c:163
+msgid "Distance step for every iteration (zero to omit)"
+msgstr ""
+#: ../raster/r.geomorphon/main.c:171
+msgid "Distance where serch will start in multiple mode (zero to omit)"
+msgstr ""
+#: ../raster/r.geomorphon/main.c:177
+msgid "Use meters to define search units (default is cells)"
+msgstr ""
+#: ../raster/r.geomorphon/main.c:181
+msgid "Use extended form correction"
+msgstr ""
+#: ../raster/r.geomorphon/main.c:196 ../raster/r.watershed/shed/com_line.c:231
+#: ../raster/r.watershed/shed/com_line.c:266 ../general/g.rename/main.c:85
+#: ../general/g.copy/main.c:80 ../imagery/i.landsat.acca/main.c:188
+#: ../imagery/i.landsat.toar/main.c:563
+#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:114
+#, c-format
+msgid "<%s> is an illegal file name"
+msgstr ""
+#: ../raster/r.geomorphon/main.c:201
+#, c-format
+msgid "At least one output is required, e.g. %s"
+msgstr ""
+#: ../raster/r.geomorphon/main.c:227
+msgid "Search radius size must cover at least 1 cell"
+msgstr ""
+#: ../raster/r.geomorphon/main.c:239
+msgid "Skip radius size must be at least 1 cell lower than radius"
+msgstr ""
+#: ../raster/r.geomorphon/main.c:245
+msgid "Flatenss threshold must be grater than 0"
+msgstr ""
+#: ../raster/r.geomorphon/main.c:254
+msgid "Flatenss distance should be between skip and search radius. Otherwise ignored"
+msgstr ""
+#: ../raster/r.geomorphon/main.c:272
+msgid "For multiresolution mode step must be greater than or equal to resolution of one cell"
+msgstr ""
+#: ../raster/r.geomorphon/main.c:276
+#, c-format
+msgid "<%s> is an incorrect prefix"
+msgstr ""
+#: ../raster/r.geomorphon/main.c:368
+msgid "Unknown output data type"
+msgstr ""
+#: ../raster/r.topidx/file_io.c:35
+#, c-format
+msgid "The current region resolution [%s x %s] is finer than the input map's resolution [%s x %s]. The current region resolution must be identical to, or coarser than, the input map's resolution."
+msgstr ""
+#: ../raster/r.topidx/file_io.c:42
+msgid "Reading elevation map..."
+msgstr ""
+#: ../raster/r.topidx/file_io.c:87
+msgid "Writing topographic index map..."
+msgstr ""
+#: ../raster/r.topidx/main.c:41
+msgid "wetness"
+msgstr ""
+#: ../raster/r.topidx/main.c:42 ../raster/r.watershed/front/main.c:80
+msgid "topographic index"
+msgstr ""
+#: ../raster/r.topidx/main.c:44
+msgid "Creates a topographic index (wetness index) raster map from an elevation raster map."
+msgstr ""
+#: ../raster/r.topidx/main.c:50
+msgid "Name for output topographic index raster map"
+msgstr ""
+#: ../raster/r.topidx/topidx.c:41 ../raster/r.flow/main.c:314
+#: ../imagery/i.landsat.toar/main.c:534
+msgid "Calculating..."
+msgstr ""
+#: ../raster/r.topidx/topidx.c:272
+#, c-format
+msgid "Number of sinks or boundaries: %d"
+msgstr ""
+#: ../raster/r.category/cats.c:47
+#, c-format
+msgid "Reading <%s> in <%s>"
+msgstr ""
+#: ../raster/r.category/main.c:53 ../vector/v.category/main.c:76
+msgid "category"
+msgstr ""
+#: ../raster/r.category/main.c:55
+msgid "Manages category values and labels associated with user-specified raster map layers."
+msgstr ""
+#: ../raster/r.category/main.c:69
+msgid "Comma separated value list"
+msgstr ""
+#: ../raster/r.category/main.c:70
+msgid "Example: 1.4,3.8,13"
+msgstr ""
+#: ../raster/r.category/main.c:80 ../raster/r.support/main.c:115
+#: ../raster3d/r3.support/main.c:111
+msgid "Raster map from which to copy category table"
+msgstr ""
+#: ../raster/r.category/main.c:87
+msgid "File containing category label rules (or \"-\" to read from stdin)"
+msgstr ""
+#: ../raster/r.category/main.c:95
+msgid "Default label or format string for dynamic labeling"
+msgstr ""
+#: ../raster/r.category/main.c:97
+msgid "Used when no explicit label exists for the category"
+msgstr ""
+#: ../raster/r.category/main.c:105
+msgid "Dynamic label coefficients"
+msgstr ""
+#: ../raster/r.category/main.c:107
+msgid "Two pairs of category multiplier and offsets, for $1 and $2"
+msgstr ""
+#: ../raster/r.category/main.c:130 ../raster/r.support/main.c:147
+#, c-format
+msgid "Raster map <%s> not found in current mapset"
+msgstr ""
+#: ../raster/r.category/main.c:152
+#, c-format
+msgid "Category table for <%s> set from <%s>"
+msgstr ""
+#: ../raster/r.category/main.c:211
+#, c-format
+msgid ""
+"Incorrect format of input rules. Check separators. Invalid line is:\n"
+"%s"
+msgstr ""
+#: ../raster/r.category/main.c:267
+#, c-format
+msgid "Unable to read category file of raster map <%s> in <%s>"
+msgstr ""
+#: ../raster/r.category/main.c:283
+msgid "The map is floating point! Ignoring cats list, using vals list"
+msgstr ""
+#: ../raster/r.category/main.c:300
+msgid "vals argument is required for floating point map!"
+msgstr ""
+#: ../raster/r.series.interp/main.c:69
+msgid "Interpolates raster maps located (temporal or spatial) in between input raster maps at specific sampling positions."
+msgstr ""
+#: ../raster/r.series.interp/main.c:79
+msgid "Data point position for each input map"
+msgstr ""
+#: ../raster/r.series.interp/main.c:84
+msgid "Input file with one input raster map name and data point position per line, field separator between name and sample point is |"
+msgstr ""
+#: ../raster/r.series.interp/main.c:97
+msgid "Sampling point position for each output map"
+msgstr ""
+#: ../raster/r.series.interp/main.c:101
+msgid "Input file with one output raster map name and sample point position per line, field separator between name and sample point is |"
+msgstr ""
+#: ../raster/r.series.interp/main.c:111
+msgid "Interpolation method, currently only linear interpolation is supported"
+msgstr ""
+#: ../raster/r.series.interp/main.c:130 ../raster/r.series.interp/main.c:146
+#, c-format
+msgid "Please specify %s= and %s="
+msgstr ""
+#: ../raster/r.series.interp/main.c:213
+#, c-format
+msgid "Missing point position for %s map <%s> in file <%s> near line %i"
+msgstr ""
+#: ../raster/r.series.interp/main.c:228 ../raster/r.series.interp/main.c:262
+#, c-format
+msgid "Preparing %s map <%s> at position %g"
+msgstr ""
+#: ../raster/r.series.interp/main.c:232
+#, c-format
+msgid "No raster map name found in %s file <%s>"
+msgstr ""
+#: ../raster/r.series.interp/main.c:243
+#, c-format
+msgid "No %s raster map not found"
+msgstr ""
+#: ../raster/r.series.interp/main.c:250
+#, c-format
+msgid "The number of %s maps and %s point positions must be equal"
+msgstr ""
+#: ../raster/r.series.interp/main.c:279
+#, c-format
+msgid "Start interpolation run with %i input maps and %i output maps"
+msgstr ""
+#: ../raster/r.series.interp/main.c:299
+#, c-format
+msgid "map <%s> at position %g was not interpolated. Check the interpolation interval."
+msgstr ""
+#: ../raster/r.series.interp/main.c:319
+msgid "At least 2 input maps are required for linear interpolation"
+msgstr ""
+#: ../raster/r.series.interp/main.c:337
+#, c-format
+msgid "Interpolate map <%s> at position %g in interval (%g;%g)"
+msgstr ""
+#: ../raster/r.external.out/main.c:38
+#, c-format
+msgid "Supported Formats:\n"
+msgstr ""
+#: ../raster/r.external.out/main.c:132
+msgid "Unable to open GDAL file"
+msgstr ""
+#: ../raster/r.external.out/main.c:156 ../vector/v.external.out/format.c:49
+#, c-format
+msgid "Format <%s> not supported"
+msgstr ""
+#: ../raster/r.external.out/main.c:162
+#, c-format
+msgid "Format <%s> does not support direct write"
+msgstr ""
+#: ../raster/r.external.out/main.c:166 ../vector/v.external.out/format.c:52
+#, c-format
+msgid "Format <%s> does not support writing"
+msgstr ""
+#: ../raster/r.external.out/main.c:214
+msgid "Unable to create GDAL file"
+msgstr ""
+#: ../raster/r.external.out/main.c:217
+msgid "Error writing GDAL file"
+msgstr ""
+#: ../raster/r.external.out/main.c:237 ../vector/v.external.out/main.c:45
+msgid "output"
+msgstr ""
+#: ../raster/r.external.out/main.c:238 ../raster/r.external/main.c:59
+#: ../vector/v.external.out/main.c:46 ../vector/v.external/main.c:54
+msgid "external"
+msgstr ""
+#: ../raster/r.external.out/main.c:240
+msgid "Redirects raster output to file utilizing GDAL library rather than storing in GRASS raster format."
+msgstr ""
+#: ../raster/r.external.out/main.c:244
+msgid "Name of output directory"
+msgstr ""
+#: ../raster/r.external.out/main.c:251
+msgid "Extension for output files"
+msgstr ""
+#: ../raster/r.external.out/main.c:257
+msgid "Format of output files"
+msgstr ""
+#: ../raster/r.external.out/main.c:264 ../vector/v.external.out/args.c:39
+#: ../vector/v.out.postgis/args.c:52
+msgid "Creation options"
+msgstr ""
+#: ../raster/r.external.out/main.c:271 ../raster/r.in.gdal/main.c:208
+#: ../raster/r.external/main.c:95 ../vector/v.external.out/args.c:62
+#: ../vector/v.external/args.c:56
+msgid "List supported formats and exit"
+msgstr ""
+#: ../raster/r.external.out/main.c:277
+msgid "Cease using GDAL and revert to native output"
+msgstr ""
+#: ../raster/r.external.out/main.c:282 ../vector/v.external.out/args.c:74
+msgid "Print current status"
+msgstr ""
+#: ../raster/r.resamp.bspline/main.c:84
+msgid "Performs bilinear or bicubic spline interpolation with Tykhonov regularization."
+msgstr ""
+#: ../raster/r.resamp.bspline/main.c:92
+msgid "Name for output vector map with interpolation grid"
+msgstr ""
+#: ../raster/r.resamp.bspline/main.c:97
+msgid "Name of raster map to use for masking"
+msgstr ""
+#: ../raster/r.resamp.bspline/main.c:98 ../vector/v.surf.bspline/main.c:140
+msgid "Only cells that are not NULL and not zero are interpolated"
+msgstr ""
+#: ../raster/r.resamp.bspline/main.c:106
+msgid "Length of each spline step in the east-west direction. Default: 1.5 * ewres."
+msgstr ""
+#: ../raster/r.resamp.bspline/main.c:114
+msgid "Length of each spline step in the north-south direction. Default: 1.5 * nsres."
+msgstr ""
+#: ../raster/r.resamp.bspline/main.c:118 ../vector/v.surf.bspline/main.c:163
+msgid "Spline interpolation algorithm"
+msgstr ""
+#: ../raster/r.resamp.bspline/main.c:124
+#: ../vector/v.lidar.correction/main.c:407 ../vector/v.surf.bspline/main.c:170
+#: ../vector/v.outlier/main.c:418
+msgid "Bilinear interpolation"
+msgstr ""
+#: ../raster/r.resamp.bspline/main.c:125 ../vector/v.surf.bspline/main.c:171
+msgid "Bicubic interpolation"
+msgstr ""
+#: ../raster/r.resamp.bspline/main.c:137
+msgid "Only interpolate null cells in input raster map"
+msgstr ""
+#: ../raster/r.resamp.bspline/main.c:143 ../vector/v.surf.bspline/main.c:101
+msgid "Find the best Tykhonov regularizing parameter using a \"leave-one-out\" cross validation method"
+msgstr ""
+#: ../raster/r.resamp.bspline/main.c:183
+msgid "ew_step must be positive"
+msgstr ""
+#: ../raster/r.resamp.bspline/main.c:191
+msgid "ns_step must be positive"
+msgstr ""
+#: ../raster/r.resamp.bspline/main.c:218
+#, c-format
+msgid "spline step in ew direction %g"
+msgstr ""
+#: ../raster/r.resamp.bspline/main.c:219
+#, c-format
+msgid "spline step in ns direction %g"
+msgstr ""
+#: ../raster/r.resamp.bspline/main.c:220
+#, c-format
+msgid "adjusted EW splines %d"
+msgstr ""
+#: ../raster/r.resamp.bspline/main.c:221
+#, c-format
+msgid "adjusted NS splines %d"
+msgstr ""
+#: ../raster/r.resamp.bspline/main.c:300 ../vector/v.surf.bspline/main.c:461
+msgid "Memory in MB must be >= 3"
+msgstr ""
+#: ../raster/r.resamp.bspline/main.c:321 ../raster/r.resamp.bspline/main.c:406
+#: ../raster/r.resamp.bspline/main.c:478 ../vector/v.surf.bspline/main.c:480
+#: ../vector/v.surf.bspline/main.c:508
+msgid "Can not initialize temporary file"
+msgstr ""
+#: ../raster/r.resamp.bspline/main.c:327
+#, c-format
+msgid "Loading input raster <%s>"
+msgstr ""
+#: ../raster/r.resamp.bspline/main.c:341 ../raster/r.resamp.bspline/main.c:452
+#: ../raster/r.resamp.bspline/main.c:488
+msgid "Can not write to temp file"
+msgstr ""
+#: ../raster/r.resamp.bspline/main.c:346
+msgid "Only NULL cells in input raster"
+msgstr ""
+#: ../raster/r.resamp.bspline/main.c:370 ../vector/v.surf.bspline/main.c:313
+msgid "Cross validation didn't finish correctly"
+msgstr ""
+#: ../raster/r.resamp.bspline/main.c:374 ../vector/v.surf.bspline/main.c:319
+#, c-format
+msgid "Cross validation finished for ew_step = %f and ns_step = %f"
+msgstr ""
+#: ../raster/r.resamp.bspline/main.c:394
+msgid "Mark cells for interpolation"
+msgstr ""
+#: ../raster/r.resamp.bspline/main.c:466
+msgid "No NULL cells found in input raster."
+msgstr ""
+#: ../raster/r.resamp.bspline/main.c:481 ../vector/v.surf.bspline/main.c:483
+msgid "Initializing output..."
+msgstr ""
+#: ../raster/r.resamp.bspline/main.c:556
+#, c-format
+msgid "subregion %d of %d"
+msgstr ""
+#: ../raster/r.resamp.bspline/main.c:730
+msgid "No data within this subregion. Consider increasing the spline step."
+msgstr ""
+#: ../raster/r.resamp.bspline/main.c:746 ../vector/v.surf.bspline/main.c:899
+#: ../vector/v.net.components/main.c:213 ../vector/v.out.postgis/main.c:174
+msgid "Writing output..."
+msgstr ""
+#: ../raster/r.resamp.bspline/crosscorr.c:160
+#, c-format
+msgid "%d are too many cells, recommended are < 100 cells. The cross validation would take too much time."
+msgstr ""
+#: ../raster/r.resamp.bspline/crosscorr.c:169
+#, c-format
+msgid "%d point read in region"
+msgid_plural "%d points read in region"
+msgstr[0] ""
+msgstr[1] ""
+#: ../raster/r.resamp.bspline/crosscorr.c:174
+msgid "Maybe it takes too long. Consider reducing the region extents."
+msgstr ""
+#: ../raster/r.resamp.bspline/crosscorr.c:197
+#: ../vector/v.surf.bspline/crosscorr.c:151
+#, c-format
+msgid "Too many splines (%d x %d). Consider changing spline steps \"ew_step=\" \"ns_step=\"."
+msgstr ""
+#: ../raster/r.resamp.bspline/crosscorr.c:215
+#: ../vector/v.surf.bspline/crosscorr.c:169
+#, c-format
+msgid "Beginning cross validation with lambda_i=%.4f ... (%d of %d)"
+msgstr ""
+#: ../raster/r.resamp.bspline/crosscorr.c:306
+#: ../vector/v.surf.bspline/crosscorr.c:295
+#, c-format
+msgid "Mean = %.5lf"
+msgstr ""
+#: ../raster/r.resamp.bspline/crosscorr.c:307
+#: ../vector/v.surf.bspline/crosscorr.c:296
+#, c-format
+msgid "Root Mean Square (RMS) = %.5lf"
+msgstr ""
+#: ../raster/r.resamp.bspline/crosscorr.c:324
+#: ../vector/v.surf.bspline/crosscorr.c:313
+msgid "Different number of splines and lambda_i values have been taken for the cross correlation"
+msgstr ""
+#: ../raster/r.resamp.bspline/crosscorr.c:326
+#: ../vector/v.surf.bspline/crosscorr.c:315
+#, c-format
+msgid "The minimum value for the test (rms=%lf) was obtained with: lambda_i = %.3f"
+msgstr ""
+#: ../raster/r.resamp.bspline/crosscorr.c:334
+#: ../vector/v.surf.bspline/crosscorr.c:323
+msgid "Table of results:"
+msgstr ""
+#: ../raster/r.resamp.bspline/crosscorr.c:335
+#: ../vector/v.surf.bspline/crosscorr.c:324
+#, c-format
+msgid " lambda | mean | rms |\n"
+msgstr ""
+#: ../raster/r.resamp.bspline/crosscorr.c:345
+#: ../vector/v.surf.bspline/crosscorr.c:334
+msgid "No point lies into the current region"
+msgstr ""
+#: ../raster/r.in.mat/main.c:94
+msgid "Imports a binary MAT-File(v4) to a GRASS raster."
+msgstr ""
+#: ../raster/r.in.mat/main.c:101
+msgid "Name of input MAT-File(v4)"
+msgstr ""
+#: ../raster/r.in.mat/main.c:105
+msgid "Name for output raster map (override)"
+msgstr ""
+#: ../raster/r.in.mat/main.c:149
+msgid "Reading MAT-File..."
+msgstr ""
+#: ../raster/r.in.mat/main.c:175
+msgid "Array contains no data"
+msgstr ""
+#: ../raster/r.in.mat/main.c:180
+msgid "Array contains imaginary data"
+msgstr ""
+#: ../raster/r.in.mat/main.c:186
+msgid "Invalid array name"
+msgstr ""
+#: ../raster/r.in.mat/main.c:206
+msgid "Invalid 'map_name' array"
+msgstr ""
+#: ../raster/r.in.mat/main.c:216
+msgid "Error reading 'map_name' array"
+msgstr ""
+#: ../raster/r.in.mat/main.c:227
+msgid "Invalid 'map_northern_edge' array"
+msgstr ""
+#: ../raster/r.in.mat/main.c:236
+msgid "Invalid 'map_southern_edge' array"
+msgstr ""
+#: ../raster/r.in.mat/main.c:245
+msgid "Invalid 'map_eastern_edge' array"
+msgstr ""
+#: ../raster/r.in.mat/main.c:254
+msgid "Invalid 'map_western_edge' array"
+msgstr ""
+#: ../raster/r.in.mat/main.c:262
+msgid "Invalid 'map_title' array"
+msgstr ""
+#: ../raster/r.in.mat/main.c:272
+msgid "Error reading 'map_title' array"
+msgstr ""
+#: ../raster/r.in.mat/main.c:285
+msgid "Invalid 'map_data' array"
+msgstr ""
+#: ../raster/r.in.mat/main.c:311 ../raster/r.in.mat/main.c:443
+#: ../raster/r.in.mat/main.c:522
+msgid "Please contact the GRASS development team"
+msgstr ""
+#: ../raster/r.in.mat/main.c:316
+#, c-format
+msgid "Skipping unknown array '%s'"
+msgstr ""
+#: ../raster/r.in.mat/main.c:344
+#, c-format
+msgid "No 'map_data' array found in <%s>"
+msgstr ""
+#: ../raster/r.in.mat/main.c:351
+#, c-format
+msgid "Setting map name to <%s> which overrides <%s>"
+msgstr ""
+#: ../raster/r.in.mat/main.c:358
+#, c-format
+msgid "Setting map name to <%s>"
+msgstr ""
+#: ../raster/r.in.mat/main.c:362
+msgid "No 'map_name' array found; using <MatFile>"
+msgstr ""
+#: ../raster/r.in.mat/main.c:373
+msgid "Missing bound"
+msgstr ""
+#: ../raster/r.in.mat/main.c:377
+msgid "Using default bounds"
+msgstr ""
+#: ../raster/r.in.mat/main.c:391
+#, c-format
+msgid "Map <%s> bounds set to:"
+msgstr ""
+#: ../raster/r.in.mat/main.c:392 ../raster/r.out.mat/main.c:174
+#, c-format
+msgid "northern edge=%f"
+msgstr ""
+#: ../raster/r.in.mat/main.c:393 ../raster/r.out.mat/main.c:175
+#, c-format
+msgid "southern edge=%f"
+msgstr ""
+#: ../raster/r.in.mat/main.c:394 ../raster/r.out.mat/main.c:176
+#, c-format
+msgid "eastern edge=%f"
+msgstr ""
+#: ../raster/r.in.mat/main.c:395 ../raster/r.out.mat/main.c:177
+#, c-format
+msgid "western edge=%f"
+msgstr ""
+#: ../raster/r.in.mat/main.c:396 ../raster/r.out.mat/main.c:178
+#, c-format
+msgid "nsres=%f"
+msgstr ""
+#: ../raster/r.in.mat/main.c:397 ../raster/r.out.mat/main.c:179
+#, c-format
+msgid "ewres=%f"
+msgstr ""
+#: ../raster/r.in.mat/main.c:398 ../raster/r.out.mat/main.c:180
+#: ../raster3d/r3.out.bin/main.c:330
+#, c-format
+msgid "rows=%d"
+msgstr ""
+#: ../raster/r.in.mat/main.c:399 ../raster/r.out.mat/main.c:181
+#: ../raster3d/r3.out.bin/main.c:331
+#, c-format
+msgid "cols=%d"
+msgstr ""
+#: ../raster/r.in.mat/main.c:408
+msgid "Writing new raster map..."
+msgstr ""
+#: ../raster/r.ros/main.c:215
+msgid "rate of spread"
+msgstr ""
+#: ../raster/r.ros/main.c:218
+msgid "Generates rate of spread raster maps."
+msgstr ""
+#: ../raster/r.ros/main.c:220
+msgid "Generates three, or four raster map layers showing the base (perpendicular) rate of spread (ROS), the maximum (forward) ROS, the direction of the maximum ROS, and optionally the maximum potential spotting distance for fire spread simulation."
+msgstr ""
+#: ../raster/r.ros/main.c:227
+msgid "Raster map containing fuel models"
+msgstr ""
+#: ../raster/r.ros/main.c:229
+msgid "Name of an existing raster map layer in the user's current mapset search path containing the standard fuel models defined by the USDA Forest Service. Valid values are 1-13; other numbers are recognized as barriers by r.ros."
+msgstr ""
+#: ../raster/r.ros/main.c:238
+msgid "Raster map containing the 1-hour fuel moisture (%)"
+msgstr ""
+#: ../raster/r.ros/main.c:248
+msgid "Raster map containing the 10-hour fuel moisture (%)"
+msgstr ""
+#: ../raster/r.ros/main.c:250
+msgid "Name of an existing raster map layer in the user's current mapset search path containing the 10-hour (.25-1\") fuel moisture (percentage content multiplied by 100)."
+msgstr ""
+#: ../raster/r.ros/main.c:258
+msgid "Raster map containing the 100-hour fuel moisture (%)"
+msgstr ""
+#: ../raster/r.ros/main.c:260
+msgid "Name of an existing raster map layer in the user's current mapset search path containing the 100-hour (1-3\") fuel moisture (percentage content multiplied by 100)."
+msgstr ""
+#: ../raster/r.ros/main.c:267
+msgid "Raster map containing live fuel moisture (%)"
+msgstr ""
+#: ../raster/r.ros/main.c:269
+msgid "Name of an existing raster map layer in the user's current mapset search path containing live (herbaceous) fuel moisture (percentage content multiplied by 100)."
+msgstr ""
+#: ../raster/r.ros/main.c:277
+msgid "Raster map containing midflame wind velocities (ft/min)"
+msgstr ""
+#: ../raster/r.ros/main.c:287
+msgid "Name of raster map containing wind directions (degree)"
+msgstr ""
+#: ../raster/r.ros/main.c:289
+msgid "Name of an existing raster map layer in the user's current mapset search path containing wind direction, clockwise from north (degree)."
+msgstr ""
+#: ../raster/r.ros/main.c:297
+msgid "Name of raster map containing slope (degree)"
+msgstr ""
+#: ../raster/r.ros/main.c:299
+msgid "Name of an existing raster map layer in the user's current mapset search path containing topographic slope (degree)."
+msgstr ""
+#: ../raster/r.ros/main.c:307
+msgid "Raster map containing aspect (degree, CCW from E)"
+msgstr ""
+#: ../raster/r.ros/main.c:309
+msgid "Name of an existing raster map layer in the user's current mapset search path containing topographic aspect, counterclockwise from east (GRASS convention) in degrees."
+msgstr ""
+#: ../raster/r.ros/main.c:317
+msgid "Raster map containing elevation (m, required for spotting)"
+msgstr ""
+#: ../raster/r.ros/main.c:319
+msgid "Name of an existing raster map layer in the user's current mapset search path containing elevation (meters). Option is required from spotting distance computation (when spotting_distance option is provided)"
+msgstr ""
+#: ../raster/r.ros/main.c:328
+msgid "Output raster map containing base ROS (cm/min)"
+msgstr ""
+#: ../raster/r.ros/main.c:330
+msgid "Base (perpendicular) rate of spread (ROS)"
+msgstr ""
+#: ../raster/r.ros/main.c:336
+msgid "Output raster map containing maximal ROS (cm/min)"
+msgstr ""
+#: ../raster/r.ros/main.c:338
+msgid "The maximum (forward) rate of spread (ROS)"
+msgstr ""
+#: ../raster/r.ros/main.c:344
+msgid "Output raster map containing directions of maximal ROS (degree)"
+msgstr ""
+#: ../raster/r.ros/main.c:346
+msgid "The direction of the maximal (forward) rate of spread (ROS)"
+msgstr ""
+#: ../raster/r.ros/main.c:352
+msgid "Output raster map containing maximal spotting distance (m)"
+msgstr ""
+#: ../raster/r.ros/main.c:354
+msgid "The maximal potential spotting distance (requires elevation raster map to be provided)."
+msgstr ""
+#: ../raster/r.ros/main.c:373
+msgid "No dead fuel moisture is given. At least one of the 1-h, 10-h, 100-h moisture layers is required."
+msgstr ""
+#: ../raster/r.ros/main.c:397
+#, c-format
+msgid "A wind direction layer should be given if the wind velocity layer <%s> has been given"
+msgstr ""
+#: ../raster/r.ros/main.c:402
+#, c-format
+msgid "A wind velocity layer should be given if the wind direction layer <%s> has been given"
+msgstr ""
+#: ../raster/r.ros/main.c:416
+#, c-format
+msgid "An aspect layer should be given if the slope layer <%s> has been given"
+msgstr ""
+#: ../raster/r.ros/main.c:421
+#, c-format
+msgid "A slope layer should be given if the aspect layer <%s> has been given"
+msgstr ""
+#: ../raster/r.ros/main.c:437
+msgid "An elevation layer should be given if considering spotting"
+msgstr ""
+#: ../raster/r.ros/main.c:873
+#, c-format
+msgid "Raster maps <%s>, <%s> and <%s> created."
+msgstr ""
+#: ../raster/r.null/main.c:62
+msgid "Manages NULL-values of given raster map."
+msgstr ""
+#: ../raster/r.null/main.c:65
+msgid "Name of raster map for which to edit null values"
+msgstr ""
+#: ../raster/r.null/main.c:73 ../raster3d/r3.null/main.c:63
+msgid "List of cell values to be set to NULL"
+msgstr ""
+#: ../raster/r.null/main.c:74 ../raster/r.null/main.c:82
+#: ../general/g.proj/main.c:193
+msgid "Modify"
+msgstr ""
+#: ../raster/r.null/main.c:81 ../raster3d/r3.null/main.c:70
+msgid "The value to replace the null value by"
+msgstr ""
+#: ../raster/r.null/main.c:86
+msgid "Only do the work if the map is floating-point"
+msgstr ""
+#: ../raster/r.null/main.c:87 ../raster/r.null/main.c:92
+#: ../raster/r.null/main.c:98
+msgid "Check"
+msgstr ""
+#: ../raster/r.null/main.c:91
+msgid "Only do the work if the map is integer"
+msgstr ""
+#: ../raster/r.null/main.c:97
+msgid "Only do the work if the map doesn't have a NULL-value bitmap file"
+msgstr ""
+#: ../raster/r.null/main.c:103
+msgid "Create NULL-value bitmap file validating all data cells"
+msgstr ""
+#: ../raster/r.null/main.c:107
+msgid "Remove NULL-value bitmap file"
+msgstr ""
+#: ../raster/r.null/main.c:113
+msgid "Re-create NULL-value bitmap file (to compress or uncompress)"
+msgstr ""
+#: ../raster/r.null/main.c:132
+#, c-format
+msgid "Raster map <%s> is a reclass of map <%s@%s>. Consider to generate a copy with r.mapcalc. Exiting."
+msgstr ""
+#: ../raster/r.null/main.c:138
+#, c-format
+msgid "Raster map <%s> is not in your mapset <%s>"
+msgstr ""
+#: ../raster/r.null/main.c:145
+#, c-format
+msgid "%s is illegal entry for null"
+msgstr ""
+#: ../raster/r.null/main.c:152
+#, c-format
+msgid "Raster map <%s> already has a null bitmap file"
+msgstr ""
+#: ../raster/r.null/main.c:156
+#, c-format
+msgid "<%s> is integer raster map (CELL)"
+msgstr ""
+#: ../raster/r.null/main.c:160
+#, c-format
+msgid "<%s> is integer raster map (CELL). Using null=%d."
+msgstr ""
+#: ../raster/r.null/main.c:166
+#, c-format
+msgid "<%s> is floating pointing raster map"
+msgstr ""
+#: ../raster/r.null/main.c:183 ../raster/r.null/main.c:226
+#, c-format
+msgid "Writing new null file for raster map <%s>..."
+msgstr ""
+#: ../raster/r.null/main.c:193 ../raster/r.null/main.c:238
+#: ../raster/r.null/main.c:252
+#, c-format
+msgid "Raster map <%s> modified."
+msgstr ""
+#: ../raster/r.null/main.c:208
+msgid "The NULL file is already compressed, nothing to do."
+msgstr ""
+#: ../raster/r.null/main.c:214
+msgid "The NULL file is already uncompressed, nothing to do."
+msgstr ""
+#: ../raster/r.null/main.c:245
+#, c-format
+msgid "Removing null file for raster map <%s>..."
+msgstr ""
+#: ../raster/r.null/main.c:316
+#, c-format
+msgid "%s: %s: illegal value spec"
+msgstr ""
+#: ../raster/r.null/main.c:318
+#, c-format
+msgid "%s: illegal value spec"
+msgstr ""
+#: ../raster/r.null/main.c:379
+#, c-format
+msgid "Writing new data for raster map <%s>..."
+msgstr ""
+#: ../raster/r.what/main.c:104
+msgid "Queries raster maps on their category values and category labels."
+msgstr ""
+#: ../raster/r.what/main.c:108
+msgid "Name of existing raster map(s) to query"
+msgstr ""
+#: ../raster/r.what/main.c:111 ../vector/v.what/main.c:77
+msgid "Coordinates for query"
+msgstr ""
+#: ../raster/r.what/main.c:112 ../raster/r.what/main.c:118
+#: ../db/db.select/main.c:203 ../db/db.select/main.c:209
+#: ../db/db.select/main.c:213 ../db/db.select/main.c:251
+#: ../db/db.select/main.c:261 ../vector/v.to.db/parse.c:106
+#: ../vector/v.to.db/parse.c:114
+msgid "Query"
+msgstr ""
+#: ../raster/r.what/main.c:116
+msgid "Name of vector points map for query"
+msgstr ""
+#: ../raster/r.what/main.c:137
+msgid "Size of point cache"
+msgstr ""
+#: ../raster/r.what/main.c:139 ../raster/r.what/main.c:164
+#: ../display/d.legend/main.c:118 ../display/d.legend/main.c:128
+#: ../display/d.legend/main.c:136 ../display/d.legend/main.c:168
+#: ../display/d.legend/main.c:253 ../display/d.legend/main.c:258
+#: ../display/d.legend/main.c:268 ../display/d.legend/main.c:278
+#: ../display/d.legend/main.c:293
+msgid "Advanced"
+msgstr ""
+#: ../raster/r.what/main.c:148
+msgid "Show the category labels of the grid cell(s)"
+msgstr ""
+#: ../raster/r.what/main.c:153
+msgid "Output color values as RRR:GGG:BBB"
+msgstr ""
+#: ../raster/r.what/main.c:158
+msgid "Output integer category values, not cell values"
+msgstr ""
+#: ../raster/r.what/main.c:163
+msgid "Turn on cache reporting"
+msgstr ""
+#: ../raster/r.what/main.c:199
+msgid "Flag 'v' required option 'points'"
+msgstr ""
+#: ../raster/r.what/main.c:214
+#, c-format
+msgid "Can only do up to %d raster maps (more than %d given)"
+msgstr ""
+#: ../raster/r.what/main.c:231
+#, c-format
+msgid "Unable to read category file for <%s>"
+msgstr ""
+#: ../raster/r.what/main.c:314
+#, c-format
+msgid "Unable to read vector map <%s>"
+msgstr ""
+#: ../raster/r.what/main.c:318
+#, c-format
+msgid "Line %d is not point or centroid, skipped"
+msgstr ""
+#: ../raster/r.what/main.c:404
+#, c-format
+msgid "%s %s is outside your current region"
+msgstr ""
+#: ../raster/r.transect/main.c:84
+#, c-format
+msgid "End coordinate: %.15g, %.15g"
+msgstr ""
+#: ../raster/r.transect/main.c:107
+msgid "Outputs raster map layer values lying along user defined transect line(s)."
+msgstr ""
+#: ../raster/r.transect/main.c:111
+msgid "Raster map to be queried"
+msgstr ""
+#: ../raster/r.transect/main.c:117
+msgid "Transect definition"
+msgstr ""
+#: ../raster/r.flow/main.c:423
+msgid "Constructs flowlines."
+msgstr ""
+#: ../raster/r.flow/main.c:425
+msgid "Computes flowlines, flowpath lengths, and flowaccumulation (contributing areas) from a elevation raster map."
+msgstr ""
+#: ../raster/r.flow/main.c:440
+msgid "Name of input barrier raster map"
+msgstr ""
+#: ../raster/r.flow/main.c:447
+msgid "Number of cells between flowlines"
+msgstr ""
+#: ../raster/r.flow/main.c:453
+msgid "Maximum number of segments per flowline"
+msgstr ""
+#: ../raster/r.flow/main.c:458
+msgid "Name for output flow line vector map"
+msgstr ""
+#: ../raster/r.flow/main.c:464
+msgid "Name for output flow path length raster map"
+msgstr ""
+#: ../raster/r.flow/main.c:470
+msgid "Name for output flow accumulation raster map"
+msgstr ""
+#: ../raster/r.flow/main.c:476
+msgid "Compute upslope flowlines instead of default downhill flowlines"
+msgstr ""
+#: ../raster/r.flow/main.c:480
+msgid "3D lengths instead of 2D"
+msgstr ""
+#: ../raster/r.flow/main.c:484
+msgid "Use less memory, at a performance penalty"
+msgstr ""
+#: ../raster/r.flow/main.c:539
+msgid "You must select one or more output maps (flout, lgout, dsout)"
+msgstr ""
+#: ../raster/r.flow/main.c:555
+msgid "lat/long projection not supported by r.flow. Please use 'r.watershed' for calculating flow accumulation."
+msgstr ""
+#: ../raster/r.flow/precomp.c:48
+msgid "Precomputing e/w distances..."
+msgstr ""
+#: ../raster/r.flow/precomp.c:50
+msgid "Precomputing quantization tolerances..."
+msgstr ""
+#: ../raster/r.flow/precomp.c:53
+msgid "Precomputing inverted elevations..."
+msgstr ""
+#: ../raster/r.flow/precomp.c:57
+msgid "Precomputing interpolated border elevations..."
+msgstr ""
+#: ../raster/r.flow/precomp.c:63
+msgid "Precomputing re-oriented aspects..."
+msgstr ""
+#: ../raster/r.flow/precomp.c:67
+msgid "Precomputing aspects..."
+msgstr ""
+#: ../raster/r.flow/precomp.c:111
+#, c-format
+msgid ""
+"Resolution too unbalanced:\n"
+"atan2(%f deg, %f deg) =%f < %f tolerance\n"
+"please resample input map"
+msgstr ""
+#: ../raster/r.flow/precomp.c:116
+#, c-format
+msgid "Resolution too unbalanced (%f x %f); please resample input map"
+msgstr ""
+#: ../raster/r.flow/io.c:87
+msgid "Elevation raster map resolution differs from current region resolution"
+msgstr ""
+#: ../raster/r.flow/io.c:104
+msgid "Resolution of aspect file differs from current region resolution"
+msgstr ""
+#: ../raster/r.flow/io.c:121
+msgid "Reading input files: barrier"
+msgstr ""
+#: ../raster/r.flow/io.c:149
+#, c-format
+msgid "Cannot create segment file %s"
+msgstr ""
+#: ../raster/r.flow/io.c:154
+#, c-format
+msgid "Cannot format segment file %s"
+msgstr ""
+#: ../raster/r.flow/io.c:160
+#, c-format
+msgid "Cannot open segment file %s"
+msgstr ""
+#: ../raster/r.flow/mem.c:40
+#, c-format
+msgid "Unable to write segment file for %s"
+msgstr ""
+#: ../raster/r.proj/readcell.c:67
+msgid "Allocating memory and reading input raster map..."
+msgstr ""
+#: ../raster/r.proj/readcell.c:92 ../imagery/i.rectify/readcell.c:89
+#: ../imagery/i.ortho.photo/i.ortho.rectify/readcell.c:102
+msgid "Error writing segment file"
+msgstr ""
+#: ../raster/r.proj/readcell.c:125 ../imagery/i.rectify/readcell.c:116
+#: ../imagery/i.ortho.photo/i.ortho.rectify/readcell.c:132
+msgid "Internal error: cache miss on fully-cached map"
+msgstr ""
+#: ../raster/r.proj/readcell.c:138 ../imagery/i.rectify/readcell.c:125
+#: ../imagery/i.ortho.photo/i.ortho.rectify/readcell.c:141
+msgid "Error seeking on segment file"
+msgstr ""
+#: ../raster/r.proj/readcell.c:141 ../imagery/i.rectify/readcell.c:128
+#: ../imagery/i.ortho.photo/i.ortho.rectify/readcell.c:144
+msgid "Error reading segment file"
+msgstr ""
+#: ../raster/r.proj/main.c:149
+msgid "Re-projects a raster map from given location to the current location."
+msgstr ""
+#: ../raster/r.proj/main.c:153
+msgid "Location containing input raster map"
+msgstr ""
+#: ../raster/r.proj/main.c:154 ../raster/r.proj/main.c:159
+#: ../raster/r.proj/main.c:164 ../vector/v.proj/main.c:79
+#: ../vector/v.proj/main.c:84 ../vector/v.proj/main.c:90
+#: ../vector/v.net.flow/main.c:108 ../vector/v.net.flow/main.c:114
+msgid "Source"
+msgstr ""
+#: ../raster/r.proj/main.c:157
+msgid "Mapset containing input raster map"
+msgstr ""
+#: ../raster/r.proj/main.c:158 ../vector/v.proj/main.c:83
+msgid "Default: name of current mapset"
+msgstr ""
+#: ../raster/r.proj/main.c:162
+msgid "Name of input raster map to re-project"
+msgstr ""
+#: ../raster/r.proj/main.c:167 ../vector/v.proj/main.c:93
+msgid "Path to GRASS database of input location"
+msgstr ""
+#: ../raster/r.proj/main.c:171
+msgid "Name for output raster map (default: same as 'input')"
+msgstr ""
+#: ../raster/r.proj/main.c:172 ../raster/r.proj/main.c:183
+#: ../raster/r.proj/main.c:199 ../vector/v.proj/main.c:102
+#: ../vector/v.proj/main.c:107 ../vector/v.proj/main.c:119
+#: ../vector/v.proj/main.c:126
+msgid "Target"
+msgstr ""
+#: ../raster/r.proj/main.c:198
+msgid "Resolution of output raster map"
+msgstr ""
+#: ../raster/r.proj/main.c:203
+msgid "List raster maps in input mapset and exit"
+msgstr ""
+#: ../raster/r.proj/main.c:213
+msgid "Print input map's bounds in the current projection and exit"
+msgstr ""
+#: ../raster/r.proj/main.c:219
+msgid "Print input map's bounds in the current projection and exit (shell style)"
+msgstr ""
+#: ../raster/r.proj/main.c:245 ../display/d.mon/start.c:52
+#: ../imagery/i.gensig/parse.c:50 ../imagery/i.gensigset/parse.c:57
+#: ../imagery/i.cluster/main.c:179 ../vector/v.proj/main.c:150
+#: ../vector/v.external/main.c:137
+#, c-format
+msgid "option <%s>: <%s> exists. To overwrite, use the --overwrite flag"
+msgstr ""
+#: ../raster/r.proj/main.c:252 ../vector/v.proj/main.c:165
+msgid "Input and output locations can not be the same"
+msgstr ""
+#: ../raster/r.proj/main.c:254
+msgid "Input and output locations are the same"
+msgstr ""
+#: ../raster/r.proj/main.c:264
+msgid "Unable to get projection info of output raster map"
+msgstr ""
+#: ../raster/r.proj/main.c:267
+msgid "Unable to get projection units of output raster map"
+msgstr ""
+#: ../raster/r.proj/main.c:270
+msgid "Unable to get projection key values of output raster map"
+msgstr ""
+#: ../raster/r.proj/main.c:279
+#, c-format
+msgid "Mapset <%s> in input location <%s> - %s"
+msgstr ""
+#: ../raster/r.proj/main.c:281 ../raster/r.in.gdal/main.c:934
+#: ../imagery/i.rectify/target.c:32
+#: ../imagery/i.ortho.photo/i.ortho.rectify/target.c:32
+#: ../vector/v.rectify/target.c:41
+msgid "permission denied"
+msgstr ""
+#: ../raster/r.proj/main.c:282 ../raster/r.in.gdal/main.c:935
+msgid "not found"
+msgstr ""
+#: ../raster/r.proj/main.c:288 ../vector/v.proj/main.c:189
+#, c-format
+msgid "Checking location <%s> mapset <%s>"
+msgstr ""
+#: ../raster/r.proj/main.c:300 ../vector/v.proj/main.c:206
+#: ../vector/v.select/main.c:89 ../vector/v.in.ogr/main.c:445
+#: ../vector/v.what.rast/main.c:121 ../vector/v.edit/main.c:89
+#: ../vector/v.net/args.c:152 ../vector/v.net/args.c:159
+#: ../vector/v.net/args.c:165 ../vector/v.net/args.c:169
+#: ../vector/v.net/args.c:179 ../vector/v.external/main.c:110
+#: ../scripts/d.frame/d.frame.py:288
+#, c-format, python-format
+msgid "Required parameter <%s> not set"
+msgstr ""
+#: ../raster/r.proj/main.c:303
+#, c-format
+msgid "Raster map <%s> in location <%s> in mapset <%s> not found"
+msgstr ""
+#: ../raster/r.proj/main.c:311
+msgid "Unable to get projection info of input map"
+msgstr ""
+#: ../raster/r.proj/main.c:314
+msgid "Unable to get projection units of input map"
+msgstr ""
+#: ../raster/r.proj/main.c:317
+msgid "Unable to get projection key values of input map"
+msgstr ""
+#: ../raster/r.proj/main.c:332
+msgid "Unable to work with unprojected data (xy location)"
+msgstr ""
+#: ../raster/r.proj/main.c:351
+#, c-format
+msgid "Input map <%s@%s> in location <%s>:"
+msgstr ""
+#: ../raster/r.proj/main.c:443
+msgid "Input:"
+msgstr ""
+#: ../raster/r.proj/main.c:444 ../raster/r.proj/main.c:455
+#, c-format
+msgid "Cols: %d (%d)"
+msgstr ""
+#: ../raster/r.proj/main.c:445 ../raster/r.proj/main.c:456
+#, c-format
+msgid "Rows: %d (%d)"
+msgstr ""
+#: ../raster/r.proj/main.c:446 ../raster/r.proj/main.c:457
+#, c-format
+msgid "North: %f (%f)"
+msgstr ""
+#: ../raster/r.proj/main.c:447 ../raster/r.proj/main.c:458
+#, c-format
+msgid "South: %f (%f)"
+msgstr ""
+#: ../raster/r.proj/main.c:448 ../raster/r.proj/main.c:459
+#, c-format
+msgid "West: %f (%f)"
+msgstr ""
+#: ../raster/r.proj/main.c:449 ../raster/r.proj/main.c:460
+#, c-format
+msgid "East: %f (%f)"
+msgstr ""
+#: ../raster/r.proj/main.c:450 ../raster/r.proj/main.c:461
+#, c-format
+msgid "EW-res: %f"
+msgstr ""
+#: ../raster/r.proj/main.c:451 ../raster/r.proj/main.c:462
+#, c-format
+msgid "NS-res: %f"
+msgstr ""
+#: ../raster/r.proj/main.c:454
+msgid "Output:"
+msgstr ""
+#: ../raster/r.proj/main.c:491
+msgid "Projecting..."
+msgstr ""
+#: ../raster/r.proj/bordwalk.c:216
+msgid "Input raster map is outside current region"
+msgstr ""
+#: ../raster/r.proj/bordwalk.c:242
+msgid "Unable to reproject map center"
+msgstr ""
+#: ../raster/r.surf.gauss/main.c:42
+msgid "Generates a raster map using gaussian random number generator."
+msgstr ""
+#: ../raster/r.surf.gauss/main.c:44
+msgid "Mean and standard deviation of gaussian deviates can be expressed by the user."
+msgstr ""
+#: ../raster/r.surf.gauss/main.c:51
+msgid "Distribution mean"
+msgstr ""
+#: ../raster/r.surf.gauss/main.c:57
+msgid "Standard deviation"
+msgstr ""
+#: ../raster/r.out.png/main.c:116
+msgid "Export a GRASS raster map as a non-georeferenced PNG image."
+msgstr ""
+#: ../raster/r.out.png/main.c:122
+msgid "Name for new PNG file (use '-' for stdout)"
+msgstr ""
+#: ../raster/r.out.png/main.c:130
+msgid "Compression level of PNG file"
+msgstr ""
+#: ../raster/r.out.png/main.c:131
+msgid "(0 = none, 1 = fastest, 9 = best)"
+msgstr ""
+#: ../raster/r.out.png/main.c:138
+msgid "Make NULL cells transparent"
+msgstr ""
+#: ../raster/r.out.png/main.c:142
+msgid "Output world file"
+msgstr ""
+#: ../raster/r.out.png/main.c:175 ../display/d.legend.vect/draw.c:193
+#: ../display/d.legend.vect/draw.c:204 ../display/d.graph/main.c:104
+#: ../display/d.graph/do_graph.c:105 ../display/d.graph/do_graph.c:355
+#: ../display/d.graph/do_graph.c:370 ../display/d.labels/color.c:68
+#: ../display/d.rast/display.c:27
+#, c-format
+msgid "[%s]: No such color"
+msgstr ""
+#: ../raster/r.out.png/main.c:257
+#, c-format
+msgid "Converting <%s>..."
+msgstr ""
+#: ../raster/r.out.png/main.c:422
+msgid "Writing world file"
+msgstr ""
+#: ../raster/r.out.png/main.c:425
+msgid "Got null file name"
+msgstr ""
+#: ../raster/r.out.png/main.c:427
+msgid "Got null region struct"
+msgstr ""
+#: ../raster/r.out.png/main.c:429
+msgid "Unable to open world file for writing"
+msgstr ""
+#: ../raster/r.resample/main.c:57
+msgid "GRASS raster map layer data resampling capability."
+msgstr ""
+#: ../raster/r.resample/main.c:66
+msgid "Name of an input layer"
+msgstr ""
+#: ../raster/r.resample/main.c:73
+msgid "Name of an output layer"
+msgstr ""
+#: ../raster/r.resample/main.c:138
+msgid "Creating new cats file..."
+msgstr ""
+#: ../raster/r.relief/main.c:112
+msgid "Creates shaded relief map from an elevation map (DEM)."
+msgstr ""
+#: ../raster/r.relief/main.c:117
+msgid "Name for output shaded relief map"
+msgstr ""
+#: ../raster/r.relief/main.c:125
+msgid "Altitude of the sun in degrees above the horizon"
+msgstr ""
+#: ../raster/r.relief/main.c:126 ../raster/r.relief/main.c:136
+msgid "Sun position"
+msgstr ""
+#: ../raster/r.relief/main.c:135
+msgid "Azimuth of the sun in degrees to the east of north"
+msgstr ""
+#: ../raster/r.relief/main.c:143
+msgid "Factor for exaggerating relief"
+msgstr ""
+#: ../raster/r.relief/main.c:151
+msgid "Scale factor for converting meters to elevation units"
+msgstr ""
+#: ../raster/r.relief/main.c:158
+msgid "Elevation units (overrides scale factor)"
+msgstr ""
+#: ../raster/r.relief/main.c:163
+msgid "international feet"
+msgstr ""
+#: ../raster/r.relief/main.c:164
+msgid "survey feet"
+msgstr ""
+#: ../raster/r.relief/main.c:194 ../raster/r.in.gdal/main.c:396
+#: ../raster/r.in.gdal/main.c:678 ../imagery/i.landsat.toar/main.c:548
+#, c-format
+msgid "Raster map <%s> already exists and will be overwritten"
+msgstr ""
+#: ../raster/r.relief/main.c:197 ../raster/r.in.gdal/main.c:399
+#: ../raster/r.in.gdal/main.c:681
+#, c-format
+msgid "Raster map <%s> already exists"
+msgstr ""
+#: ../raster/r.relief/main.c:215
+#, c-format
+msgid "%s=%s - must not be zero"
+msgstr ""
+#: ../raster/r.relief/main.c:474
+#, c-format
+msgid "Shaded relief raster map <%s> complete"
+msgstr ""
+#: ../raster/r.carve/main.c:76
+msgid "Generates stream channels."
+msgstr ""
+#: ../raster/r.carve/main.c:77
+msgid "Takes vector stream data, transforms it to raster and subtracts depth from the output DEM."
+msgstr ""
+#: ../raster/r.carve/main.c:82
+msgid "Name of input raster elevation map"
+msgstr ""
+#: ../raster/r.carve/main.c:87
+msgid "Name of input vector map containing stream(s)"
+msgstr ""
+#: ../raster/r.carve/main.c:95
+msgid "Name for output vector map for adjusted stream points"
+msgstr ""
+#: ../raster/r.carve/main.c:100
+msgid "Stream width (in meters)"
+msgstr ""
+#: ../raster/r.carve/main.c:101
+msgid "Default is raster cell width"
+msgstr ""
+#: ../raster/r.carve/main.c:106
+msgid "Additional stream depth (in meters)"
+msgstr ""
+#: ../raster/r.carve/main.c:110
+msgid "No flat areas allowed in flow direction"
+msgstr ""
+#: ../raster/r.carve/main.c:134
+#, c-format
+msgid "Invalid width value '%s' - using default."
+msgstr ""
+#: ../raster/r.carve/main.c:148
+#, c-format
+msgid "Invalid depth value '%s' - using default."
+msgstr ""
+#: ../raster/r.carve/enforce_ds.c:83
+msgid "Processing lines... "
+msgstr ""
+#: ../raster/r.carve/enforce_ds.c:175
+msgid "Vect runs out of region and re-enters - this case is not yet implemented."
+msgstr ""
+#: ../raster/r.carve/lobf.c:74
+msgid "trying to divide by zero...no unique solution for system...skipping..."
+msgstr ""
+#: ../raster/r.in.gdal/main.c:97
+msgid "Imports raster data into a GRASS raster map using GDAL library."
+msgstr ""
+#: ../raster/r.in.gdal/main.c:103
+msgid "Name of raster file to be imported"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:112
+msgid "Band(s) to select (default is all bands)"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:113 ../raster/r.in.gdal/main.c:226
+msgid "Bands"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:130
+msgid "Name of GCPs target location"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:132
+msgid "Name of location to create or to read projection from for GCPs transformation"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:134 ../raster/r.in.gdal/main.c:189
+#: ../raster/r.in.gdal/main.c:196 ../vector/v.info/print.c:505
+#: ../vector/v.info/print.c:510
+msgid "Projection"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:149
+msgid "Offset to be added to band numbers"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:150
+msgid "If 0, no offset is added and the first band is 1"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:158
+msgid "Zero-padding of band number by filling with leading zeros up to given number"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:159
+msgid "If 0, length will be adjusted to 'offset' number without leading zeros"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:165
+msgid "Name of the output file that contains the imported map names"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:172 ../vector/v.in.lidar/main.c:272
+#: ../vector/v.in.ogr/main.c:282
+msgid "Name for new location to create"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:179
+msgid "File prefix for raster attribute tables"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:180
+msgid "The band number and \".csv\" will be appended to the file prefix"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:194 ../raster/r.external/main.c:109
+#: ../vector/v.in.ogr/main.c:355 ../vector/v.external/args.c:52
+msgid "Perform projection check only and exit"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:201 ../raster/r.external/main.c:114
+#: ../vector/v.in.lidar/main.c:302 ../vector/v.in.ogr/main.c:367
+msgid "Extend region extents based on new dataset"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:203 ../raster/r.external/main.c:115
+#: ../vector/v.in.ogr/main.c:369
+msgid "Also updates the default region if in the PERMANENT mapset"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:219 ../raster/r.external/main.c:119
+#: ../raster/r.region/main.c:70
+msgid "Auto-adjustment for lat/lon"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:220 ../raster/r.external/main.c:120
+#: ../raster/r.region/main.c:71
+msgid "Attempt to fix small precision errors in resolution and extents"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:225
+msgid "Keep band numbers instead of using band color names"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:231
+msgid "Create the location specified by the \"location\" parameter and exit. Do not import the raster file."
+msgstr ""
+#: ../raster/r.in.gdal/main.c:236 ../vector/v.in.lidar/main.c:284
+#: ../vector/v.in.ogr/main.c:362
+msgid "Limit import to the current region"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:241
+msgid "Print number of bands and exit"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:273 ../raster/r.external/list.c:23
+#: ../vector/v.external.out/list.c:102 ../vector/v.out.ogr/list.c:116
+#: ../vector/v.in.ogr/main.c:404 ../vector/v.external/list.c:94
+msgid "Supported formats:"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:316
+msgid "You have to specify a target location different from output location"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:320
+msgid "You need to specify valid location name."
+msgstr ""
+#: ../raster/r.in.gdal/main.c:324
+msgid "The '-l' flag only works in Lat/Lon locations"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:327
+msgid "The number of digits for band numbering must be equal or greater than 0"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:340
+msgid "Disabling '-r' flag for new location"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:346
+#, c-format
+msgid "Using memory cache size: %s MiB"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:355
+#, c-format
+msgid "Unable to open datasource <%s>"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:366
+#, c-format
+msgid "Input seems to be NOAA/AVHRR data which needs to be georeferenced with thin plate spline transformation (%s or %s)."
+msgstr ""
+#: ../raster/r.in.gdal/main.c:379
+msgid "Input contains subdatasets which may need to be imported separately"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:419
+msgid "Input raster map is flipped or rotated - cannot import. You may use 'gdalwarp' to transform the map to North-up."
+msgstr ""
+#: ../raster/r.in.gdal/main.c:438
+#, c-format
+msgid "Unable to fetch the affine transformation coefficients. Flag -%c cannot be used in this case."
+msgstr ""
+#: ../raster/r.in.gdal/main.c:466
+msgid "Map bounds have been constrained to geographic coordinates. You will almost certainly want to check map bounds and resolution with r.info and reset them with r.region before going any further."
+msgstr ""
+#: ../raster/r.in.gdal/main.c:511 ../raster/r.in.gdal/main.c:538
+msgid "Input raster does not overlap current computational region. Nothing to import."
+msgstr ""
+#: ../raster/r.in.gdal/main.c:575
+#, c-format
+msgid "Importing %d raster bands..."
+msgstr ""
+#: ../raster/r.in.gdal/main.c:594 ../raster/r.external/main.c:230
+#, c-format
+msgid "Selected band (%d) does not exist"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:619
+msgid "Unable to open the map names output text file"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:650
+#, c-format
+msgid "Unable to get raster band number %d"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:727
+#, c-format
+msgid "Copying %d GCPS in points file for <%s>"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:735
+msgid "GCPs have the following OpenGIS WKT Coordinate System:"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:758
+msgid "Re-projecting GCPs table:"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:759
+#, c-format
+msgid "* Input projection for GCP table: %s"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:761
+#, c-format
+msgid "* Output projection for GCP table: %s"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:782
+#, c-format
+msgid "Error in pj_do_proj (can't re-projection GCP %i)"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:804 ../raster/r.in.gdal/proj.c:85
+#: ../raster/r.external/proj.c:85 ../vector/v.in.lidar/main.c:507
+#: ../vector/v.in.ogr/proj.c:292 ../vector/v.external/proj.c:177
+msgid "Unable to convert input map projection to GRASS format; cannot create new location."
+msgstr ""
+#: ../raster/r.in.gdal/main.c:828 ../raster/r.in.gdal/proj.c:91
+#: ../raster/r.external/proj.c:91 ../vector/v.in.lidar/main.c:513
+#: ../vector/v.in.ogr/proj.c:298 ../vector/v.external/proj.c:183
+#, c-format
+msgid "Unable to create new location <%s>"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:834 ../raster/r.in.gdal/proj.c:94
+#: ../raster/r.external/proj.c:94 ../general/g.proj/create.c:16
+#: ../vector/v.in.lidar/main.c:516 ../vector/v.in.ogr/proj.c:301
+#: ../vector/v.external/proj.c:186
+#, c-format
+msgid "Location <%s> created"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:837
+#, c-format
+msgid "The target for the output group <%s> has been set to location <%s>, mapset <PERMANENT>."
+msgstr ""
+#: ../raster/r.in.gdal/main.c:877 ../raster/r.external/window.c:93
+#: ../vector/v.in.ogr/main.c:1901
+msgid "Default region for this location updated"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:880 ../raster/r.external/window.c:96
+#: ../vector/v.in.ogr/main.c:1904
+msgid "Region for the current mapset updated"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:908
+msgid "Unable to translate projection key values of input GCPs"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:924
+msgid "Unable to get projection info of target location"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:926
+msgid "Unable to get projection units of target location"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:928
+msgid "Unable to get projection key values of target location"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:932 ../imagery/i.rectify/target.c:31
+#: ../imagery/i.ortho.photo/i.ortho.rectify/target.c:31
+#: ../vector/v.rectify/target.c:40
+#, c-format
+msgid "Mapset <%s> in target location <%s> - "
+msgstr ""
+#: ../raster/r.in.gdal/main.c:970
+#, c-format
+msgid "Importing raster map <%s>..."
+msgstr ""
+#: ../raster/r.in.gdal/main.c:1085 ../raster/r.in.gdal/main.c:1140
+#: ../raster/r.in.gdal/main.c:1214
+msgid "Invalid row"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:1482 ../raster/r.in.gdal/main.c:1539
+msgid "Inconsistent color rules in RAT"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:1596
+#, c-format
+msgid "Setting grey color table for <%s> (8bit, full range)"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:1610
+#, c-format
+msgid "Setting grey color table for <%s> (16bit, image range)"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:1712
+#, c-format
+msgid "Unable to open file <%s>: %s."
+msgstr ""
+#: ../raster/r.in.gdal/proj.c:46 ../raster/r.external/proj.c:46
+#, c-format
+msgid ""
+"Input contains an invalid SRS. WKT definition:\n"
+"%s"
+msgstr ""
+#: ../raster/r.in.gdal/proj.c:73 ../raster/r.external/proj.c:73
+msgid "No projection information available"
+msgstr ""
+#: ../raster/r.in.gdal/proj.c:116 ../raster/r.external/proj.c:116
+#: ../vector/v.in.ogr/proj.c:323 ../vector/v.external/proj.c:208
+msgid "Unable to convert input map projection information to GRASS format."
+msgstr ""
+#: ../raster/r.in.gdal/proj.c:160 ../raster/r.external/proj.c:160
+#: ../vector/v.in.ogr/proj.c:368 ../vector/v.external/proj.c:253
+msgid "Location PROJ_INFO is:\n"
+msgstr ""
+#: ../raster/r.in.gdal/proj.c:170 ../raster/r.in.gdal/proj.c:177
+#: ../raster/r.external/proj.c:170 ../raster/r.external/proj.c:177
+#: ../vector/v.in.ogr/proj.c:378 ../vector/v.in.ogr/proj.c:385
+#: ../vector/v.external/proj.c:263 ../vector/v.external/proj.c:270
+msgid "Dataset PROJ_INFO is:\n"
+msgstr ""
+#: ../raster/r.in.gdal/proj.c:263 ../raster/r.external/proj.c:263
+#: ../vector/v.in.ogr/proj.c:471 ../vector/v.external/proj.c:356
+msgid "Consider generating a new location from the input dataset using the 'location' parameter.\n"
+msgstr ""
+#: ../raster/r.sunmask/main.c:120
+msgid "Calculates cast shadow areas from sun position and elevation raster map."
+msgstr ""
+#: ../raster/r.sunmask/main.c:121
+msgid "Either exact sun position (A) is specified, or date/time to calculate the sun position (B) by r.sunmask itself."
+msgstr ""
+#: ../raster/r.sunmask/main.c:135
+msgid "Altitude of the sun in degrees above the horizon (A)"
+msgstr ""
+#: ../raster/r.sunmask/main.c:136 ../raster/r.sunmask/main.c:145
+#: ../raster/r.sunmask/main.c:213 ../raster/r.sunmask/main.c:223
+#: ../display/d.text/main.c:199 ../display/d.text/main.c:208
+#: ../display/d.text/main.c:217 ../display/d.text/main.c:254
+#: ../display/d.text/main.c:259
+msgid "Position"
+msgstr ""
+#: ../raster/r.sunmask/main.c:144
+msgid "Azimuth of the sun in degrees from north (A)"
+msgstr ""
+#: ../raster/r.sunmask/main.c:151
+msgid "Year (B)"
+msgstr ""
+#: ../raster/r.sunmask/main.c:159
+msgid "Month (B)"
+msgstr ""
+#: ../raster/r.sunmask/main.c:167
+msgid "Day (B)"
+msgstr ""
+#: ../raster/r.sunmask/main.c:175
+msgid "Hour (B)"
+msgstr ""
+#: ../raster/r.sunmask/main.c:183
+msgid "Minutes (B)"
+msgstr ""
+#: ../raster/r.sunmask/main.c:191
+msgid "Seconds (B)"
+msgstr ""
+#: ../raster/r.sunmask/main.c:201
+msgid "Timezone"
+msgstr ""
+#: ../raster/r.sunmask/main.c:202
+msgid "East positive, offset from GMT, also use to adjust daylight savings"
+msgstr ""
+#: ../raster/r.sunmask/main.c:211
+msgid "Easting coordinate (point of interest)"
+msgstr ""
+#: ../raster/r.sunmask/main.c:212 ../raster/r.sunmask/main.c:222
+msgid "Default: map center"
+msgstr ""
+#: ../raster/r.sunmask/main.c:221
+msgid "Northing coordinate (point of interest)"
+msgstr ""
+#: ../raster/r.sunmask/main.c:227
+msgid "Do not ignore zero elevation"
+msgstr ""
+#: ../raster/r.sunmask/main.c:231
+msgid "Calculate sun position only and exit"
+msgstr ""
+#: ../raster/r.sunmask/main.c:237
+msgid "Print the sun position output in shell script style"
+msgstr ""
+#: ../raster/r.sunmask/main.c:251
+#, c-format
+msgid "Using map center coordinates: %f %f"
+msgstr ""
+#: ../raster/r.sunmask/main.c:258
+msgid "Empty east coordinate specified"
+msgstr ""
+#: ../raster/r.sunmask/main.c:260
+msgid "Empty north coordinate specified"
+msgstr ""
+#: ../raster/r.sunmask/main.c:279
+msgid "Either define sun position or location/date/time parameters"
+msgstr ""
+#: ../raster/r.sunmask/main.c:282
+msgid "Neither sun position nor east/north, date/time/timezone definition are complete"
+msgstr ""
+#: ../raster/r.sunmask/main.c:286
+#, c-format
+msgid "Calculating sun position... (using solpos (V. %s) from NREL)"
+msgstr ""
+#: ../raster/r.sunmask/main.c:291
+msgid "Using user defined sun azimuth, altitude settings (ignoring eventual other values)"
+msgstr ""
+#: ../raster/r.sunmask/main.c:399
+msgid "Please correct settings"
+msgstr ""
+#: ../raster/r.sunmask/main.c:413
+#, c-format
+msgid "Time (%02i:%02i:%02i) is before sunrise (%02d:%02d:%02d)"
+msgstr ""
+#: ../raster/r.sunmask/main.c:417
+#, c-format
+msgid "Time (%02i:%02i:%02i) is before sunrise"
+msgstr ""
+#: ../raster/r.sunmask/main.c:420 ../raster/r.sunmask/main.c:430
+msgid "Nothing to calculate. Please verify settings."
+msgstr ""
+#: ../raster/r.sunmask/main.c:424
+#, c-format
+msgid "Time (%02i:%02i:%02i) is after sunset (%02d:%02d:%02d)"
+msgstr ""
+#: ../raster/r.sunmask/main.c:428
+#, c-format
+msgid "Time (%02i:%02i:%02i) is after sunset"
+msgstr ""
+#: ../raster/r.sunmask/main.c:439
+msgid "You already know the sun position"
+msgstr ""
+#: ../raster/r.sunmask/main.c:444 ../vector/v.colors/main.c:199
+#, c-format
+msgid "Option <%s> required"
+msgstr ""
+#: ../raster/r.sunmask/main.c:456
+#, c-format
+msgid "Unable to open range file for raster map <%s>"
+msgstr ""
+#: ../raster/r.sunmask/main.c:472
+msgid "Calculating shadows from DEM..."
+msgstr ""
+#: ../raster/r.sunmask/g_solposition.c:66
+msgid "Unable to calculate sun position in un-projected locations. Specify sunposition directly."
+msgstr ""
+#: ../raster/r.sunmask/g_solposition.c:88
+#, c-format
+msgid "Specified point %f, %f outside of current region, is that intended? Anyway, it will be used."
+msgstr ""
+#: ../raster/r.sunmask/g_solposition.c:98 ../raster/r.latlong/main.c:101
+msgid "Unable to get projection info of current location"
+msgstr ""
+#: ../raster/r.sunmask/g_solposition.c:101 ../raster/r.latlong/main.c:103
+msgid "Unable to get projection units of current location"
+msgstr ""
+#: ../raster/r.sunmask/g_solposition.c:104 ../raster/r.latlong/main.c:105
+msgid "Unable to get projection key values of current location"
+msgstr ""
+#: ../raster/r.out.ascii/main.c:63
+msgid "Converts a raster map layer into a GRASS ASCII text file."
+msgstr ""
+#: ../raster/r.out.ascii/main.c:72
+msgid "Name for output ASCII grid map (use out=- for stdout)"
+msgstr ""
+#: ../raster/r.out.ascii/main.c:86
+msgid "Number of values printed before wrapping a line (only SURFER or MODFLOW format)"
+msgstr ""
+#: ../raster/r.out.ascii/main.c:91
+msgid "String to represent null cell (GRASS grid only)"
+msgstr ""
+#: ../raster/r.out.ascii/main.c:95 ../raster3d/r3.out.ascii/main.c:102
+msgid "Suppress printing of header information"
+msgstr ""
+#: ../raster/r.out.ascii/main.c:99
+msgid "Write SURFER (Golden Software) ASCII grid"
+msgstr ""
+#: ../raster/r.out.ascii/main.c:103
+msgid "Write MODFLOW (USGS) ASCII array"
+msgstr ""
+#: ../raster/r.out.ascii/main.c:107
+msgid "Force output of integer values"
+msgstr ""
+#: ../raster/r.out.ascii/main.c:114
+msgid "Failed to interpret dp as an integer"
+msgstr ""
+#: ../raster/r.out.ascii/main.c:116 ../raster3d/r3.out.vtk/main.c:394
+msgid "dp has to be from 0 to 20"
+msgstr ""
+#: ../raster/r.out.ascii/main.c:122
+msgid "Failed to interpret width as an integer"
+msgstr ""
+#: ../raster/r.out.ascii/main.c:128
+msgid "Both -s and -h doesn't make sense"
+msgstr ""
+#: ../raster/r.out.ascii/main.c:131
+msgid "Use -M or -s, not both"
+msgstr ""
+#: ../raster/r.out.ascii/main.c:166
+#, c-format
+msgid "Unable to read fp range for <%s>"
+msgstr ""
+#: ../raster/r.out.ascii/main.c:182
+#, c-format
+msgid "Read failed at row %d"
+msgstr ""
+#: ../raster/r.out.mpeg/main.c:104
+msgid "animation"
+msgstr ""
+#: ../raster/r.out.mpeg/main.c:107
+msgid "Converts raster map series to MPEG movie."
+msgstr ""
+#: ../raster/r.out.mpeg/main.c:115
+#, c-format
+msgid "Name of input raster map(s) for view no.%d"
+msgstr ""
+#: ../raster/r.out.mpeg/main.c:117
+msgid "Views"
+msgstr ""
+#: ../raster/r.out.mpeg/main.c:131
+msgid "Quality factor (1 = highest quality, lowest compression)"
+msgstr ""
+#: ../raster/r.out.mpeg/main.c:136
+msgid "Convert on the fly, uses less disk space"
+msgstr ""
+#: ../raster/r.out.mpeg/main.c:137
+msgid "Requires r.out.ppm with stdout option"
+msgstr ""
+#: ../raster/r.out.mpeg/main.c:160
+msgid "Either mpeg_encode or ppmtompeg must be installed"
+msgstr ""
+#: ../raster/r.out.mpeg/main.c:291
+#, c-format
+msgid "Unable to read color table for <%s>"
+msgstr ""
+#: ../raster/r.out.mpeg/main.c:341 ../raster/r.out.mpeg/main.c:374
+msgid "mpeg_encode ERROR"
+msgstr ""
+#: ../raster/r.out.mpeg/main.c:417
+msgid "Error reading wildcard"
+msgstr ""
+#: ../raster/r.out.mpeg/write.c:81 ../raster/r.out.mpeg/write.c:178
+msgid "Size mismatch error!"
+msgstr ""
+#: ../raster/r.out.mpeg/write.c:139 ../raster/r.out.mpeg/write.c:181
+msgid "Unable to open output file"
+msgstr ""
+#: ../raster/r.out.mpeg/write.c:215
+msgid "Unable to create temporary files."
+msgstr ""
+#: ../raster/r.covar/main.c:54
+msgid "Outputs a covariance/correlation matrix for user-specified raster map layer(s)."
+msgstr ""
+#: ../raster/r.covar/main.c:61
+msgid "Print correlation matrix"
+msgstr ""
+#: ../raster/r.covar/main.c:86
+#, c-format
+msgid "%s: complete ... "
+msgstr ""
+#: ../raster/r.covar/main.c:110 ../imagery/i.pca/main.c:197
+msgid "No non-null values"
+msgstr ""
+#: ../raster/r.out.ppm/main.c:56
+msgid "Converts a GRASS raster map to a PPM image file."
+msgstr ""
+#: ../raster/r.out.ppm/main.c:64
+msgid "Name for new PPM file (use '-' for stdout)"
+msgstr ""
+#: ../raster/r.out.ppm/main.c:68
+msgid "Output greyscale instead of color"
+msgstr ""
+#: ../raster/r.out.ppm/main.c:72
+msgid "Suppress printing of PPM header"
+msgstr ""
+#: ../raster/r.out.ppm/main.c:124
+#, c-format
+msgid "Unable to open file <%s> for write"
+msgstr ""
+#: ../raster/r.out.ppm/main.c:154
+msgid "Converting..."
+msgstr ""
+#: ../raster/r.out.ppm/main.c:234
+#, c-format
+msgid "File <%s> created"
+msgstr ""
+#: ../raster/r.support/main.c:56
+msgid "Allows creation and/or modification of raster map layer support files."
+msgstr ""
+#: ../raster/r.support/main.c:74 ../raster3d/r3.support/main.c:70
+msgid "Text to append to the next line of the map's metadata file"
+msgstr ""
+#: ../raster/r.support/main.c:80
+msgid "Text to use for map data units"
+msgstr ""
+#: ../raster/r.support/main.c:86
+msgid "Text to use for map vertical datum"
+msgstr ""
+#: ../raster/r.support/main.c:93 ../raster3d/r3.support/main.c:89
+msgid "Text to use for data source, line 1"
+msgstr ""
+#: ../raster/r.support/main.c:100 ../raster3d/r3.support/main.c:96
+msgid "Text to use for data source, line 2"
+msgstr ""
+#: ../raster/r.support/main.c:108 ../raster3d/r3.support/main.c:104
+msgid "Text to use for data description or keyword(s)"
+msgstr ""
+#: ../raster/r.support/main.c:120 ../raster3d/r3.support/main.c:116
+msgid "Text file from which to load history"
+msgstr ""
+#: ../raster/r.support/main.c:125 ../raster3d/r3.support/main.c:121
+msgid "Text file in which to save history"
+msgstr ""
+#: ../raster/r.support/main.c:129
+msgid "Update statistics (histogram, range)"
+msgstr ""
+#: ../raster/r.support/main.c:133
+msgid "Create/reset the null file"
+msgstr ""
+#: ../raster/r.support/main.c:137
+msgid "Delete the null file"
+msgstr ""
+#: ../raster/r.support/main.c:249 ../raster3d/r3.support/main.c:252
+#, c-format
+msgid "cats table for [%s] set to %s"
+msgstr ""
+#: ../raster/r.support/main.c:273 ../raster/r.support/main.c:301
+#, c-format
+msgid "[%s] is a reclass of another map. Exiting."
+msgstr ""
+#: ../raster/r.support/main.c:285
+#, c-format
+msgid "Writing new null file for [%s]... "
+msgstr ""
+#: ../raster/r.support/main.c:305
+#, c-format
+msgid "Removing null file for [%s]...\n"
+msgstr ""
+#: ../raster/r.support/main.c:312 ../scripts/d.polar/d.polar.py:407
+#: ../scripts/i.in.spotvgt/i.in.spotvgt.py:280
+#: ../scripts/r.plane/r.plane.py:122 ../scripts/r.fillnulls/r.fillnulls.py:493
+#: ../scripts/v.in.e00/v.in.e00.py:165 ../scripts/r.in.aster/r.in.aster.py:144
+msgid "Done."
+msgstr ""
+#: ../raster/r.support/check.c:26
+#, c-format
+msgid ""
+"\n"
+" Updating statistics for [%s]"
+msgstr ""
+#: ../raster/r.support/check.c:69
+#, c-format
+msgid ""
+" Updating the number of categories for [%s]\n"
+"\n"
+msgstr ""
+#: ../raster/r.lake/main.c:153
+msgid "flood"
+msgstr ""
+#: ../raster/r.lake/main.c:154
+msgid "Fills lake at given point to given level."
+msgstr ""
+#: ../raster/r.lake/main.c:160
+msgid "Water level"
+msgstr ""
+#: ../raster/r.lake/main.c:170
+msgid "Seed point coordinates"
+msgstr ""
+#: ../raster/r.lake/main.c:171
+msgid "Either this coordinates pair or a seed map have to be specified"
+msgstr ""
+#: ../raster/r.lake/main.c:175 ../raster/r.lake/main.c:184
+msgid "Seed"
+msgstr ""
+#: ../raster/r.lake/main.c:180
+msgid "Input raster map with given starting point(s) (at least 1 cell > 0)"
+msgstr ""
+#: ../raster/r.lake/main.c:182
+msgid "Either this parameter or a coordinates pair have to be specified"
+msgstr ""
+#: ../raster/r.lake/main.c:189
+msgid "Use negative depth values for lake raster map"
+msgstr ""
+#: ../raster/r.lake/main.c:194
+msgid "Overwrite seed map with result (lake) map"
+msgstr ""
+#: ../raster/r.lake/main.c:201
+msgid "Both seed map and coordinates cannot be specified"
+msgstr ""
+#: ../raster/r.lake/main.c:204
+msgid "Seed map or seed coordinates must be set!"
+msgstr ""
+#: ../raster/r.lake/main.c:207
+msgid "Seed coordinates and output map lake= must be set!"
+msgstr ""
+#: ../raster/r.lake/main.c:210
+msgid "Both lake and overwrite cannot be specified"
+msgstr ""
+#: ../raster/r.lake/main.c:213
+msgid "Output lake map or overwrite flag must be set!"
+msgstr ""
+#: ../raster/r.lake/main.c:240
+msgid "Seed point outside the current region"
+msgstr ""
+#: ../raster/r.lake/main.c:254
+msgid "G_malloc: out of memory"
+msgstr ""
+#: ../raster/r.lake/main.c:276
+msgid "Given water level at seed point is below earth surface. Increase water level or move seed point."
+msgstr ""
+#: ../raster/r.lake/main.c:355
+#, c-format
+msgid "Lake depth from %f to %f (specified water level is taken as zero)"
+msgstr ""
+#: ../raster/r.lake/main.c:356
+#, c-format
+msgid "Lake area %f square meters"
+msgstr ""
+#: ../raster/r.lake/main.c:357
+#, c-format
+msgid "Lake volume %f cubic meters"
+msgstr ""
+#: ../raster/r.lake/main.c:358
+msgid "Volume is correct only if lake depth (terrain raster map) is in meters"
+msgstr ""
+#: ../raster/r.out.mat/main.c:64
+msgid "Exports a GRASS raster to a binary MAT-File."
+msgstr ""
+#: ../raster/r.out.mat/main.c:73
+msgid "Name for output binary MAT file"
+msgstr ""
+#: ../raster/r.out.mat/main.c:113
+#, c-format
+msgid "Exporting <%s>"
+msgstr ""
+#: ../raster/r.out.mat/main.c:173
+msgid "Using the Current Region settings:"
+msgstr ""
+#: ../raster/r.out.mat/main.c:248
+msgid "Exporting raster as integer values"
+msgstr ""
+#: ../raster/r.out.mat/main.c:253
+msgid "Exporting raster as floating point values"
+msgstr ""
+#: ../raster/r.out.mat/main.c:258
+msgid "Exporting raster as double FP values"
+msgstr ""
+#: ../raster/r.out.mat/main.c:301
+msgid "Reading in map ... "
+msgstr ""
+#: ../raster/r.out.mat/main.c:314
+msgid "Writing out map..."
+msgstr ""
+#: ../raster/r.out.mat/main.c:374
+#, c-format
+msgid "%ld bytes written to '%s'"
+msgstr ""
+#: ../raster/r.his/main.c:68 ../display/d.his/main.c:64
+#: ../imagery/i.rgb.his/main.c:47 ../imagery/i.his.rgb/main.c:47
+msgid "color transformation"
+msgstr ""
+#: ../raster/r.his/main.c:73
+msgid "Generates red, green and blue (RGB) raster map layers combining hue, intensity and saturation (HIS) values from user-specified input raster map layers."
+msgstr ""
+#: ../raster/r.his/main.c:82 ../display/d.his/main.c:78
+msgid "Name of layer to be used for hue"
+msgstr ""
+#: ../raster/r.his/main.c:89 ../display/d.his/main.c:85
+msgid "Name of layer to be used for intensity"
+msgstr ""
+#: ../raster/r.his/main.c:96 ../display/d.his/main.c:92
+msgid "Name of layer to be used for saturation"
+msgstr ""
+#: ../raster/r.his/main.c:103
+msgid "Name of output layer to be used for red"
+msgstr ""
+#: ../raster/r.his/main.c:110
+msgid "Name of output layer to be used for green"
+msgstr ""
+#: ../raster/r.his/main.c:117
+msgid "Name of output layer to be used for blue"
+msgstr ""
+#: ../raster/r.his/main.c:145
+#, c-format
+msgid "No such color <%s>"
+msgstr ""
+#: ../raster/r.external/window.c:23
+msgid "Input raster map is rotated - cannot import. You may use 'gdalwarp' to transform the map to North-up."
+msgstr ""
+#: ../raster/r.external/window.c:26
+msgid "Applying horizontal flip"
+msgstr ""
+#: ../raster/r.external/window.c:30
+msgid "Applying vertical flip"
+msgstr ""
+#: ../raster/r.external/main.c:61
+msgid "Links GDAL supported raster data as a pseudo GRASS raster map."
+msgstr ""
+#: ../raster/r.external/main.c:64
+msgid "Name of raster file to be linked"
+msgstr ""
+#: ../raster/r.external/main.c:70
+msgid "Name of non-file GDAL data source"
+msgstr ""
+#: ../raster/r.external/main.c:82
+msgid "Band to select (default is all bands)"
+msgstr ""
+#: ../raster/r.external/main.c:124
+msgid "Flip horizontally"
+msgstr ""
+#: ../raster/r.external/main.c:128
+msgid "Flip vertically"
+msgstr ""
+#: ../raster/r.external/main.c:133
+msgid "List available bands including band type in dataset and exit"
+msgstr ""
+#: ../raster/r.external/main.c:134
+msgid "Format: band number,type,projection check"
+msgstr ""
+#: ../raster/r.external/main.c:166
+#, c-format
+msgid "%s= or %s= must be given"
+msgstr ""
+#: ../raster/r.external/main.c:177 ../display/d.mon/start.c:86
+msgid "Unable to get current working directory"
+msgstr ""
+#: ../raster/r.external/main.c:214
+msgid "Proceeding with import..."
+msgstr ""
+#: ../raster/r.external/main.c:218
+#, c-format
+msgid "Imagery group <%s> already exists and will be overwritten."
+msgstr ""
+#: ../raster/r.external/main.c:225
+#, c-format
+msgid "Reading band %d of %d..."
+msgstr ""
+#: ../raster/r.external/main.c:262
+#, c-format
+msgid "Imagery group <%s> created"
+msgstr ""
+#: ../raster/r.external/link.c:48
+msgid "Complex types not supported"
+msgstr ""
+#: ../raster/r.external/link.c:63
+#, c-format
+msgid "Copying color table for %s"
+msgstr ""
+#: ../raster/r.external/link.c:81
+#, c-format
+msgid "Setting grey color table for <%s> (full 8bit range)"
+msgstr ""
+#: ../raster/r.external/link.c:87
+#, c-format
+msgid "Setting grey color table for <%s> (data range)"
+msgstr ""
+#: ../raster/r.external/link.c:101
+#, c-format
+msgid "Unable to create cell/%s file"
+msgstr ""
+#: ../raster/r.external/link.c:110
+#, c-format
+msgid "Unable to create fcell/%s file"
+msgstr ""
+#: ../raster/r.external/link.c:146
+#, c-format
+msgid "Unable to create cell_misc/%s/gdal file"
+msgstr ""
+#: ../raster/r.external/link.c:149
+#, c-format
+msgid "Error writing cell_misc/%s/gdal file"
+msgstr ""
+#: ../raster/r.external/link.c:174
+#, c-format
+msgid "Unable to create cell_misc/%s/f_format file"
+msgstr ""
+#: ../raster/r.external/link.c:177
+#, c-format
+msgid "Error writing cell_misc/%s/f_format file"
+msgstr ""
+#: ../raster/r.external/link.c:224
+#, c-format
+msgid "Creating support files for %s"
+msgstr ""
+#: ../raster/r.external/link.c:236
+#, c-format
+msgid "Link to raster map <%s> created."
+msgstr ""
+#: ../raster/r.resamp.filter/main.c:142
+#, c-format
+msgid "Filter <%s> not found"
+msgstr ""
+#: ../raster/r.resamp.filter/main.c:396
+msgid "kernel filter"
+msgstr ""
+#: ../raster/r.resamp.filter/main.c:399
+msgid "Resamples raster map layers using an analytic kernel."
+msgstr ""
+#: ../raster/r.resamp.filter/main.c:410
+msgid "Filter kernel(s)"
+msgstr ""
+#: ../raster/r.resamp.filter/main.c:418
+msgid "Filter radius"
+msgstr ""
+#: ../raster/r.resamp.filter/main.c:425
+msgid "Filter radius (horizontal)"
+msgstr ""
+#: ../raster/r.resamp.filter/main.c:432
+msgid "Filter radius (vertical)"
+msgstr ""
+#: ../raster/r.resamp.filter/main.c:443 ../vector/v.external.out/args.c:90
+#, c-format
+msgid "%s= and %s=/%s= are mutually exclusive"
+msgstr ""
+#: ../raster/r.resamp.filter/main.c:448
+#, c-format
+msgid "Either %s= or %s=/%s= required"
+msgstr ""
+#: ../raster/r.resamp.filter/main.c:451
+#, c-format
+msgid "Both %s= and %s= required"
+msgstr ""
+#: ../raster/r.resamp.filter/main.c:474
+msgid "Differing number of values for filter= and [xy_]radius="
+msgstr ""
+#: ../raster/r.resamp.filter/main.c:477
+#, c-format
+msgid "Too many filters (max: %d)"
+msgstr ""
+#: ../raster/r.resamp.filter/main.c:495
+msgid "At least one filter must be finite"
+msgstr ""
+#: ../raster/r.latlong/main.c:57
+msgid "latitude"
+msgstr ""
+#: ../raster/r.latlong/main.c:58
+msgid "longitude"
+msgstr ""
+#: ../raster/r.latlong/main.c:60
+msgid "Creates a latitude/longitude raster map."
+msgstr ""
+#: ../raster/r.latlong/main.c:66
+msgid "Name for output latitude or longitude raster map"
+msgstr ""
+#: ../raster/r.latlong/main.c:70
+msgid "Longitude output"
+msgstr ""
+#: ../raster/r.composite/main.c:76
+msgid "Combines red, green and blue raster maps into a single composite raster map."
+msgstr ""
+#: ../raster/r.composite/main.c:102
+msgid "Number of levels to be used for each component"
+msgstr ""
+#: ../raster/r.composite/main.c:103 ../raster/r.composite/main.c:121
+msgid "Levels"
+msgstr ""
+#: ../raster/r.composite/main.c:118
+#, c-format
+msgid "Number of levels to be used for <%s>"
+msgstr ""
+#: ../raster/r.composite/main.c:128
+msgid "Dither"
+msgstr ""
+#: ../raster/r.composite/main.c:132
+msgid "Use closest color"
+msgstr ""
+#: ../raster/r.composite/main.c:164
+#, c-format
+msgid "Unable to read color file of raster map <%s>"
+msgstr ""
+#: ../raster/r.composite/main.c:286
+msgid "Creating color table for output raster map..."
+msgstr ""
+#: ../raster/r.region/main.c:54
+msgid "Sets the boundary definitions for a raster map."
+msgstr ""
+#: ../raster/r.region/main.c:60
+msgid "Set from current region"
+msgstr ""
+#: ../raster/r.region/main.c:61 ../raster/r.region/main.c:66
+#: ../raster/r.region/main.c:72 ../raster/r.region/main.c:87
+#: ../raster/r.region/main.c:94 ../raster/r.region/main.c:101
+#: ../raster/r.region/main.c:144 ../general/g.region/main.c:79
+#: ../general/g.region/main.c:85 ../general/g.region/main.c:172
+#: ../general/g.region/main.c:179 ../general/g.region/main.c:188
+#: ../general/g.region/main.c:196
+msgid "Existing"
+msgstr ""
+#: ../raster/r.region/main.c:65 ../general/g.region/main.c:78
+msgid "Set from default region"
+msgstr ""
+#: ../raster/r.region/main.c:77
+msgid "Name of raster map to change"
+msgstr ""
+#: ../raster/r.region/main.c:85
+msgid "Set region from named region"
+msgstr ""
+#: ../raster/r.region/main.c:93
+msgid "Set region to match this raster map"
+msgstr ""
+#: ../raster/r.region/main.c:100
+msgid "Set region to match this vector map"
+msgstr ""
+#: ../raster/r.region/main.c:109 ../general/g.region/main.c:204
+msgid "Value for the northern edge"
+msgstr ""
+#: ../raster/r.region/main.c:118 ../general/g.region/main.c:213
+msgid "Value for the southern edge"
+msgstr ""
+#: ../raster/r.region/main.c:127 ../general/g.region/main.c:222
+msgid "Value for the eastern edge"
+msgstr ""
+#: ../raster/r.region/main.c:136 ../general/g.region/main.c:231
+msgid "Value for the western edge"
+msgstr ""
+#: ../raster/r.region/main.c:143
+msgid "Raster map to align to"
+msgstr ""
+#: ../raster/r.watershed/shed/valid.c:24
+msgid "accum file missing in valid_basins()"
+msgstr ""
+#: ../raster/r.watershed/shed/intro.c:8
+#, c-format
+msgid "%s provides a text-based user-interface to the %s program."
+msgstr ""
+#: ../raster/r.watershed/shed/intro.c:10
+#, c-format
+msgid "%s also allows the user to prepare a report of map layers for each"
+msgstr ""
+#: ../raster/r.watershed/shed/intro.c:12
+#, c-format
+msgid "watershed basin determined in %s.\n"
+msgstr ""
+#: ../raster/r.watershed/shed/intro.c:14
+#, c-format
+msgid "%s will help the user determine which options to use for the"
+msgstr ""
+#: ../raster/r.watershed/shed/intro.c:16
+#, c-format
+msgid "%s program. %s will then ask for map layers that will be"
+msgstr ""
+#: ../raster/r.watershed/shed/intro.c:18
+#, c-format
+msgid "divided by basin. %s will then run %s and create the report."
+msgstr ""
+#: ../raster/r.watershed/shed/main.c:41
+msgid "Slow version of water analysis program starting now"
+msgstr ""
+#: ../raster/r.watershed/shed/main.c:46 ../raster/r.watershed/shed/main.c:55
+#, c-format
+msgid "<<%s>> command line failed"
+msgstr ""
+#: ../raster/r.watershed/shed/main.c:72
+msgid "unable to open output file"
+msgstr ""
+#: ../raster/r.watershed/shed/basin_maps.c:12
+msgid ""
+"\n"
+"\n"
+"Please indicate which map layers you wish to use in the lumped"
+msgstr ""
+#: ../raster/r.watershed/shed/basin_maps.c:13
+msgid "parameter hydrologic/soil erosion model. Continue inputing cell map"
+msgstr ""
+#: ../raster/r.watershed/shed/basin_maps.c:14
+msgid "layers, one at a time, until all desired map layers are in."
+msgstr ""
+#: ../raster/r.watershed/shed/basin_maps.c:15
+#, c-format
+msgid "You can have %s include a list of categories in each."
+msgstr ""
+#: ../raster/r.watershed/shed/basin_maps.c:17
+#, c-format
+msgid ""
+"\n"
+"Hit <return> at the map prompt to continue with %s"
+msgstr ""
+#: ../raster/r.watershed/shed/basin_maps.c:36
+#, c-format
+msgid ""
+"\n"
+"The output from %s will be divided into watershed"
+msgstr ""
+#: ../raster/r.watershed/shed/basin_maps.c:38
+msgid "basins. There are two possible methods of tabulating the information:"
+msgstr ""
+#: ../raster/r.watershed/shed/basin_maps.c:39
+msgid "1) by only including data pertaining to the basin itself, or 2) using"
+msgstr ""
+#: ../raster/r.watershed/shed/basin_maps.c:40
+msgid "data from the basin, and all basins upstream of it."
+msgstr ""
+#: ../raster/r.watershed/shed/basin_maps.c:43
+msgid ""
+"\n"
+"Would you like the data organized:"
+msgstr ""
+#: ../raster/r.watershed/shed/basin_maps.c:44
+msgid ""
+"1) Basin only\n"
+"2) Upstream only\n"
+"3) Both\n"
+"OR 0) to cancel program"
+msgstr ""
+#: ../raster/r.watershed/shed/basin_maps.c:45
+#, c-format
+msgid ""
+"\n"
+"Your choice: "
+msgstr ""
+#: ../raster/r.watershed/shed/basin_maps.c:69
+#: ../raster/r.watershed/shed/basin_maps.c:73
+#, c-format
+msgid ""
+"\n"
+"OK, %s should start running now using the following form:\n"
+"%s"
+msgstr ""
+#: ../raster/r.watershed/shed/file_in.c:15
+msgid "unable to open ARMSED file"
+msgstr ""
+#: ../raster/r.watershed/shed/read.c:23
+msgid "unable to open basin/half basin map"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:23
+msgid ""
+"\n"
+"This set of questions will organize the command line for the"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:24
+#, c-format
+msgid "%s program to run properly for your application."
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:26
+#, c-format
+msgid "The first question is whether you want %s to run"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:28
+#, c-format
+msgid "in its fast mode or its slow mode. If you run %s"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:30
+msgid "in the fast mode, the computer will finish about 10 times faster"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:31
+msgid "than in the slow mode, but will not allow other programs to run"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:32
+msgid "at the same time. The fast mode also places all of the data into"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:33
+msgid "RAM, which limits the size of window that can be run. The slow"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:34
+msgid "mode uses disk space in the same hard disk partition as where GRASS is"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:35
+msgid "stored. Thus, if the program does not work in the slow mode, you will"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:36
+msgid "need to remove unnecessary files from that partition. The slow mode"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:37
+#, c-format
+msgid "will allow other processes to run concurrently with %s.\n"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:69
+#: ../raster/r.watershed/shed/com_line.c:182
+msgid ""
+"\n"
+"If you hit <return> by itself for the next question, this"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:70
+#: ../raster/r.watershed/shed/com_line.c:183
+msgid "program will terminate."
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:81
+#, c-format
+msgid ""
+"\n"
+"One of the options for %s is a `depression map'. A"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:83
+msgid "depression map indicates all the locations in the current map window where"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:84
+msgid "water accumulates and does not leave by the edge of the map. Lakes without"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:85
+msgid "outlet streams and sinkholes are examples of `depressions'. If you wish to"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:86
+msgid "have a depression map, prepare a map where non-zero values indicate the"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:87
+msgid "locations where depressions occur.\n"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:88
+msgid "Hit <return> by itself for the next question if there is no depression map."
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:99
+#, c-format
+msgid ""
+"\n"
+"The %s program will divide the elevation map into a number of"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:101
+msgid "watershed basins. The number of watershed basins is indirectly determined"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:102
+msgid "by the `basin threshold' value. The basin threshold is the area necessary for"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:103
+#, c-format
+msgid "%s to define a unique watershed basin. This area only applies to"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:105
+msgid "`exterior drainage basins'. An exterior drainage basin does not have any"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:106
+msgid "drainage basins flowing into it. Interior drainage basin size is determined"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:107
+msgid "by the surface flow going into stream segments between stream interceptions."
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:108
+#, c-format
+msgid "Thus interior drainage basins can be of any size. The %s program"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:110
+msgid "also allows the user to relate basin size to potential overland flow"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:111
+msgid "(i.e., areas with low infiltration capacities will need smaller areas to"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:112
+msgid "develop stream channels than neighboring areas with high infiltration rates)."
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:113
+msgid "The user can create a map layer with potential overland flow values, and"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:114
+#, c-format
+msgid "%s will accumulate those values instead of area.\n"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:116
+msgid "What unit of measure will you use for the basin threshold:"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:119
+msgid " 1) acres, 2) meters sq., 3) miles sq., 4) hectares,"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:120
+msgid " 5) kilometers sq., 6) map cells, 7) overland flow units"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:121
+#, c-format
+msgid "Choose 1-7 or 0 to exit this program: "
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:131
+msgid ""
+"\n"
+"How large an area (or how many overland flow units) must a drainage basin"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:132
+#, c-format
+msgid "be for it to be an exterior drainage basin: "
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:201
+#, c-format
+msgid ""
+"\n"
+"%s must create a map layer of watershed basins"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:203
+#: ../raster/r.watershed/shed/com_line.c:224
+#, c-format
+msgid "before %s can run properly."
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:222
+#, c-format
+msgid ""
+"\n"
+"%s must create a file of watershed basin relationships"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:228
+#: ../raster/r.watershed/shed/com_line.c:263
+#, c-format
+msgid ""
+"\n"
+"Please name this file:"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:257
+#, c-format
+msgid ""
+"\n"
+"%s will generate a lot of output. Indicate a file"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:259
+#, c-format
+msgid "name for %s to send the output to."
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:277
+#, c-format
+msgid ""
+"\n"
+"The accumulation map from %s must be present for"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:279
+#, c-format
+msgid "%s to work properly."
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:290
+#, c-format
+msgid ""
+"\n"
+"%s can produce several maps not necessary for"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:292
+#, c-format
+msgid "%s to function (stream channels, overland flow aspect, and"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:294
+#, c-format
+msgid "a display version of the accumulation map). %s also has the"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:296
+msgid "ability to generate several variables in the Revised Universal Soil Loss"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:297
+msgid "Equation (Rusle): Slope Length (LS), and Slope Steepness (S).\n"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:348
+msgid ""
+"\n"
+"The Slope Length factor (LS) and Slope Steepness (S) are influenced by"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:349
+#, c-format
+msgid "disturbed land. %s reflects this with an optional map layer or value"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:351
+msgid "where the value indicates the percent of disturbed (barren) land in that cell."
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:352
+msgid "Type <return> if you do not have a disturbed land map layer."
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:364
+msgid ""
+"\n"
+"Type the value indicating the percent of disturbed land. This value will"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:365
+msgid "be used for every cell in the current region."
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:368
+#, c-format
+msgid ""
+"\n"
+"Input value here [0-100]: "
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:379
+msgid ""
+"\n"
+"Overland surface flow only occurs for a set distance before swales form."
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:380
+#, c-format
+msgid "Because of digital terrain model limitations, %s cannot pick up"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:382
+#, c-format
+msgid "these swales. %s allows for an input (warning: kludge factor)"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:384
+msgid "that prevents the surface flow distance from getting too long. Normally,"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:385
+msgid "maximum slope length is around 600 feet (about 183 meters)."
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:400
+msgid ""
+"\n"
+"Roads, ditches, changes in ground cover, and other factors will stop"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:401
+msgid "slope length. You may input a raster map indicating the locations of these"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:402
+msgid "blocking factors.\n"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:403
+msgid "Hit <return> by itself for the next question if there is no blocking map."
+msgstr ""
+#: ../raster/r.watershed/seg/sg_factor.c:14
+msgid "SECTION 5: RUSLE LS and/or S factor determination."
+msgstr ""
+#: ../raster/r.watershed/seg/close_maps2.c:38
+#: ../raster/r.watershed/ram/close_maps2.c:34
+msgid "No basins were created. Verify threshold and region settings."
+msgstr ""
+#: ../raster/r.watershed/seg/close_maps2.c:86
+msgid "Closing stream segments map"
+msgstr ""
+#: ../raster/r.watershed/seg/close_maps2.c:109
+msgid "Closing basins map"
+msgstr ""
+#: ../raster/r.watershed/seg/close_maps2.c:116
+msgid "Closing half basins map"
+msgstr ""
+#: ../raster/r.watershed/seg/main.c:92 ../raster/r.watershed/seg/main.c:107
+#: ../raster/r.watershed/ram/main.c:82 ../raster/r.watershed/ram/main.c:98
+#, c-format
+msgid "SECTION %d: Closing Maps."
+msgstr ""
+#: ../raster/r.watershed/seg/main.c:105 ../raster/r.watershed/ram/main.c:96
+#, c-format
+msgid "SECTION %d: Watershed determination."
+msgstr ""
+#: ../raster/r.watershed/seg/do_astar.c:30
+#: ../raster/r.watershed/ram/do_astar.c:27
+msgid "SECTION 2: A* Search."
+msgstr ""
+#: ../raster/r.watershed/seg/do_astar.c:48
+msgid "No seeds for A* Search"
+msgstr ""
+#: ../raster/r.watershed/seg/do_astar.c:146
+msgid "bug in A* Search: doer %"
+msgstr ""
+#: ../raster/r.watershed/seg/close_maps.c:20
+msgid "Closing accumulation map"
+msgstr ""
+#: ../raster/r.watershed/seg/close_maps.c:136
+msgid "Closing TCI and SPI maps"
+msgstr ""
+#: ../raster/r.watershed/seg/close_maps.c:138
+msgid "Closing TCI map"
+msgstr ""
+#: ../raster/r.watershed/seg/close_maps.c:140
+msgid "Closing SPI map"
+msgstr ""
+#: ../raster/r.watershed/seg/close_maps.c:300
+msgid "Closing flow direction map"
+msgstr ""
+#: ../raster/r.watershed/seg/close_maps.c:327
+msgid "Closing LS map"
+msgstr ""
+#: ../raster/r.watershed/seg/close_maps.c:332
+msgid "Closing SL map"
+msgstr ""
+#: ../raster/r.watershed/seg/init_vars.c:139
+#, c-format
+msgid "SECTION 1 beginning: Initiating Variables. %d section total."
+msgid_plural "SECTION 1 beginning: Initiating Variables. %d sections total."
+msgstr[0] ""
+msgstr[1] ""
+#: ../raster/r.watershed/seg/init_vars.c:175
+msgid "Maximum memory to be used was smaller than 3 MB, set to 3 MB."
+msgstr ""
+#: ../raster/r.watershed/seg/init_vars.c:470
+msgid "SECTION 1b: Determining Offmap Flow."
+msgstr ""
+#: ../raster/r.watershed/seg/do_cum.c:119
+#: ../raster/r.watershed/ram/do_cum.c:114
+msgid "SECTION 3: Accumulating Surface Flow with SFD."
+msgstr ""
+#: ../raster/r.watershed/seg/do_cum.c:293
+#: ../raster/r.watershed/ram/do_cum.c:276
+msgid "SECTION 3a: Accumulating Surface Flow with MFD."
+msgstr ""
+#: ../raster/r.watershed/seg/do_cum.c:529
+msgid "MFD: A * path already processed when distributing flow: %d of %"
+msgstr ""
+#: ../raster/r.watershed/seg/do_cum.c:533
+#: ../raster/r.watershed/ram/do_cum.c:486
+msgid "SECTION 3b: Adjusting drainage directions."
+msgstr ""
+#: ../raster/r.watershed/seg/usage.c:9 ../raster/r.watershed/ram/usage.c:9
+#, c-format
+msgid ""
+"USAGE for basin delineation:\n"
+"%s -4 elevation=elevation_map threshold=swale_threshold [flow=overland_flow_map] [drainage=drain_direction_map] [depression=depression_map] [accumulation=accumulation_map] [basin=watershed_basin_map] [stream=stream_segment_map]\n"
+"\n"
+"USAGE for slope length determination:\n"
+"%s [-4] elevation=elevation_map threshold=swale_threshold [drainage=drain_direction_map] [depression=depression_map] [accumulation=accumulation_map] [max_slope_length=max_slope_length] [blocking=overland_blocking_map] [slope_steepness=slope_steepness_map] length_slope=length_slope_map [disturbed_land=rill_erosion_map] [slope_deposition=slope_deposition value or map]USAGE for ARMSED FILE creation:\n"
+"%s [-4] elevation=elevation_map threshold=swale_threshold [flow=overland_flow_map] [drainage=drain_direction_map] [depression=depression_map] [accumulation=accumulation_map] [basin=watershed_basin_map] [stream=stream_segment_map] [half_basin=half_basin_map] ar=ARMSED_file_name\n"
+"\n"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:77
+msgid "drainage"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:79
+msgid "stream power index"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:81
+msgid "Calculates hydrological parameters and RUSLE factors."
+msgstr ""
+#: ../raster/r.watershed/front/main.c:84 ../raster/r.watershed/front/main.c:91
+#: ../raster/r.watershed/front/main.c:97 ../raster/r.watershed/front/main.c:104
+#: ../raster/r.watershed/front/main.c:113
+#: ../raster/r.watershed/front/main.c:121
+#: ../raster/r.watershed/front/main.c:130
+msgid "Inputs"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:88
+msgid "Name of input depressions raster map"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:89
+msgid "All non-NULL and non-zero cells are considered as real depressions"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:95
+msgid "Name of input raster representing amount of overland flow per cell"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:101
+msgid "Name of input raster map percent of disturbed land"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:102
+#: ../raster/r.watershed/front/main.c:127
+msgid "For USLE"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:109
+msgid "Name of input raster map blocking overland surface flow"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:111
+msgid "For USLE. All non-NULL and non-zero cells are considered as blocking terrain."
+msgstr ""
+#: ../raster/r.watershed/front/main.c:118
+msgid "Minimum size of exterior watershed basin"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:126
+msgid "Maximum length of surface flow in map units"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:135
+msgid "Name for output accumulation raster map"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:137
+msgid "Number of cells that drain through each cell"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:144
+msgid "Name for output topographic index ln(a / tan(b)) map"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:151
+msgid "Stream power index a * tan(b)"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:157
+msgid "Name for output drainage direction raster map"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:158
+msgid "Directions numbered from 1 to 8"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:164
+msgid "Name for output basins raster map"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:170
+msgid "Name for output stream segments raster map"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:176
+msgid "Name for output half basins raster map"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:178
+msgid "Each half-basin is given a unique value"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:184
+msgid "Name for output slope length raster map"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:186
+msgid "Slope length and steepness (LS) factor for USLE"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:192
+msgid "Name for output slope steepness raster map"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:193
+msgid "Slope steepness (S) factor for USLE"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:202
+msgid "Convergence factor for MFD (1-10)"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:204
+msgid "1 = most diverging flow, 10 = most converging flow. Recommended: 5"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:211
+msgid "Maximum memory to be used with -m flag (in MB)"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:215
+msgid "SFD (D8) flow (default is MFD)"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:217
+msgid "SFD: single flow direction, MFD: multiple flow direction"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:222
+msgid "Allow only horizontal and vertical flow of water"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:227
+msgid "Enable disk swap memory option: Operation is slow"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:229
+msgid "Only needed if memory requirements exceed available RAM; see manual on how to calculate memory requirements"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:234
+msgid "Use positive flow accumulation even for likely underestimates"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:236
+msgid "See manual for a detailed description of flow accumulation output"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:241
+msgid "Beautify flat areas"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:243
+msgid "Flow direction in flat areas is modified to look prettier"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:259
+msgid "Sorry, you must choose an output map."
+msgstr ""
+#: ../raster/r.watershed/front/main.c:265
+msgid "The basin threshold must be a positive number."
+msgstr ""
+#: ../raster/r.watershed/front/main.c:281
+msgid ""
+"Sorry, if any of the following options are set:\n"
+" basin, stream, half_basin, length_slope, or slope_steepness\n"
+" you MUST provide a value for the basin threshold parameter."
+msgstr ""
+#: ../raster/r.watershed/front/main.c:308
+msgid "Beautify flat areas is not yet supported for disk swap mode"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:338
+#, c-format
+msgid "Subprocess failed with exit code %d"
+msgstr ""
+#: ../raster/r.watershed/ram/sg_factor.c:14
+msgid "SECTION 4: RUSLE LS and/or S factor determination."
+msgstr ""
+#: ../raster/r.watershed/ram/do_astar.c:256
+msgid "heapsize too large"
+msgstr ""
+#: ../raster/r.watershed/ram/do_flatarea.c:56
+msgid "Beautify flat areas: priority queue error"
+msgstr ""
+#: ../raster/r.watershed/ram/do_flatarea.c:229
+msgid "flat cell escaped for uphill correction"
+msgstr ""
+#: ../raster/r.watershed/ram/do_flatarea.c:235
+#, c-format
+msgid "queue error: last uphill order %d > current uphill order %d"
+msgstr ""
+#: ../raster/r.watershed/ram/do_flatarea.c:240
+msgid "uphill order not set"
+msgstr ""
+#: ../raster/r.watershed/ram/do_flatarea.c:266
+msgid "flat cell escaped in uphill correction"
+msgstr ""
+#: ../raster/r.watershed/ram/do_flatarea.c:302
+msgid "downhill order: no more points in down queue"
+msgstr ""
+#: ../raster/r.watershed/ram/do_flatarea.c:310
+msgid "flat cell escaped for downhill correction"
+msgstr ""
+#: ../raster/r.watershed/ram/do_flatarea.c:316
+#, c-format
+msgid "queue error: last downhill order %d > current downhill order %d"
+msgstr ""
+#: ../raster/r.watershed/ram/do_flatarea.c:321
+msgid "downhill order: downhill order not set"
+msgstr ""
+#: ../raster/r.watershed/ram/do_flatarea.c:344
+msgid "flat cell escaped in downhill correction"
+msgstr ""
+#: ../raster/r.watershed/ram/do_flatarea.c:382
+msgid "flat cell escaped for adjustment"
+msgstr ""
+#: ../raster/r.watershed/ram/do_flatarea.c:389
+msgid "adjustment: uphill order not set"
+msgstr ""
+#: ../raster/r.watershed/ram/do_flatarea.c:391
+msgid "adjustment: downhill order not set"
+msgstr ""
+#: ../raster/r.watershed/ram/do_flatarea.c:417
+msgid "flat cell escaped in adjustment"
+msgstr ""
+#: ../raster/r.watershed/ram/init_vars.c:121
+#, c-format
+msgid "SECTION 1a (of %1d): Initiating Memory."
+msgstr ""
+#: ../raster/r.watershed/ram/init_vars.c:311
+#, c-format
+msgid "SECTION 1b (of %1d): Determining Offmap Flow."
+msgstr ""
+#: ../raster/r.watershed/ram/do_cum.c:480
+#, c-format
+msgid "MFD: A * path already processed when distributing flow: %d of %d cell"
+msgid_plural "MFD: A * path already processed when distributing flow: %d of %d cells"
+msgstr[0] ""
+msgstr[1] ""
+#: ../raster/r.rescale/main.c:51
+msgid "Rescales the range of category values in a raster map layer."
+msgstr ""
+#: ../raster/r.rescale/main.c:110
+#, c-format
+msgid "Rescale %s[%ld,%ld] to %s[%ld,%ld]"
+msgstr ""
+#: ../raster/r.sim/simlib/hydro.c:202
+#, c-format
+msgid "nwalk (%d) > maxw (%d)!"
+msgstr ""
+#: ../raster/r.sim/simlib/hydro.c:411
+msgid "Unable to write raster maps"
+msgstr ""
+#: ../raster/r.sim/simlib/hydro.c:478 ../raster/r.sim/r.sim.sediment/main.c:435
+msgid "Cannot write raster maps"
+msgstr ""
+#: ../raster/r.sim/simlib/observation_points.c:64
+#, c-format
+msgid "Unable to read points from map %s"
+msgstr ""
+#: ../raster/r.sim/simlib/observation_points.c:85
+#, c-format
+msgid "Unable to open observation logfile %s for writing"
+msgstr ""
+#: ../raster/r.sim/simlib/output.c:321 ../raster/r.sim/simlib/output.c:329
+#, c-format
+msgid "FP raster map <%s> not found"
+msgstr ""
+#: ../raster/r.sim/simlib/input.c:307
+#, c-format
+msgid "Raster map <%s> not found, and manin_val undefined, choose one to be allowed to process"
+msgstr ""
+#: ../raster/r.sim/simlib/input.c:420
+msgid "Zero value in Mannings n"
+msgstr ""
+#: ../raster/r.sim/simlib/input.c:471
+msgid "Infiltration exceeds the rainfall rate everywhere! No overland flow."
+msgstr ""
+#: ../raster/r.sim/simlib/input.c:495
+#, c-format
+msgid ""
+"Min elevation \t= %.2f m\n"
+"Max elevation \t= %.2f m\n"
+msgstr ""
+#: ../raster/r.sim/simlib/input.c:497
+#, c-format
+msgid "Mean Source Rate (rainf. excess or sediment) \t= %f m/s or kg/m2s \n"
+msgstr ""
+#: ../raster/r.sim/simlib/input.c:499
+#, c-format
+msgid "Mean flow velocity \t= %f m/s\n"
+msgstr ""
+#: ../raster/r.sim/simlib/input.c:500
+#, c-format
+msgid "Mean Mannings \t= %f\n"
+msgstr ""
+#: ../raster/r.sim/simlib/input.c:504
+#, c-format
+msgid "Number of iterations \t= %d cell\n"
+msgid_plural "Number of iterations \t= %d cells\n"
+msgstr[0] ""
+msgstr[1] ""
+#: ../raster/r.sim/simlib/input.c:506
+#, c-format
+msgid "Time step \t= %.2f s\n"
+msgstr ""
+#: ../raster/r.sim/simlib/input.c:508
+#, c-format
+msgid ""
+"Sigmax \t= %f\n"
+"Max velocity \t= %f m/s\n"
+msgstr ""
+#: ../raster/r.sim/simlib/input.c:510
+#, c-format
+msgid "Time step used \t= %.2f s\n"
+msgstr ""
+#: ../raster/r.sim/simlib/input.c:562
+msgid "Unable to write et file"
+msgstr ""
+#: ../raster/r.sim/r.sim.sediment/main.c:117
+msgid "sediment flow"
+msgstr ""
+#: ../raster/r.sim/r.sim.sediment/main.c:119
+msgid "deposition"
+msgstr ""
+#: ../raster/r.sim/r.sim.sediment/main.c:122
+msgid "Sediment transport and erosion/deposition simulation using path sampling method (SIMWE)."
+msgstr ""
+#: ../raster/r.sim/r.sim.sediment/main.c:129
+msgid "Name of water depth raster map [m]"
+msgstr ""
+#: ../raster/r.sim/r.sim.sediment/main.c:133
+#: ../raster/r.sim/r.sim.water/main.c:127
+msgid "Name of x-derivatives raster map [m/m]"
+msgstr ""
+#: ../raster/r.sim/r.sim.sediment/main.c:137
+#: ../raster/r.sim/r.sim.water/main.c:131
+msgid "Name of y-derivatives raster map [m/m]"
+msgstr ""
+#: ../raster/r.sim/r.sim.sediment/main.c:142
+msgid "Name of detachment capacity coefficient raster map [s/m]"
+msgstr ""
+#: ../raster/r.sim/r.sim.sediment/main.c:147
+msgid "Name of transport capacity coefficient raster map [s]"
+msgstr ""
+#: ../raster/r.sim/r.sim.sediment/main.c:152
+msgid "Name of critical shear stress raster map [Pa]"
+msgstr ""
+#: ../raster/r.sim/r.sim.sediment/main.c:157
+#: ../raster/r.sim/r.sim.water/main.c:168
+msgid "Name of Manning's n raster map"
+msgstr ""
+#: ../raster/r.sim/r.sim.sediment/main.c:165
+#: ../raster/r.sim/r.sim.water/main.c:176
+msgid "Manning's n unique value"
+msgstr ""
+#: ../raster/r.sim/r.sim.sediment/main.c:172
+#: ../raster/r.sim/r.sim.water/main.c:190
+msgid "Name of sampling locations vector points map"
+msgstr ""
+#: ../raster/r.sim/r.sim.sediment/main.c:178
+msgid "Name for output transport capacity raster map [kg/ms]"
+msgstr ""
+#: ../raster/r.sim/r.sim.sediment/main.c:185
+msgid "Name for output transport limited erosion-deposition raster map [kg/m2s]"
+msgstr ""
+#: ../raster/r.sim/r.sim.sediment/main.c:192
+msgid "Name for output sediment concentration raster map [particle/m3]"
+msgstr ""
+#: ../raster/r.sim/r.sim.sediment/main.c:198
+msgid "Name for output sediment flux raster map [kg/ms]"
+msgstr ""
+#: ../raster/r.sim/r.sim.sediment/main.c:205
+msgid "Name for output erosion-deposition raster map [kg/m2s]"
+msgstr ""
+#: ../raster/r.sim/r.sim.sediment/main.c:212
+#: ../raster/r.sim/r.sim.water/main.c:222
+msgid "Name for sampling points output text file. For each observation vector point the time series of sediment transport is stored."
+msgstr ""
+#: ../raster/r.sim/r.sim.sediment/main.c:219
+#: ../raster/r.sim/r.sim.water/main.c:215
+msgid "Base name of the output walkers vector points map"
+msgstr ""
+#: ../raster/r.sim/r.sim.sediment/main.c:226
+msgid "Number of walkers"
+msgstr ""
+#: ../raster/r.sim/r.sim.sediment/main.c:227
+#: ../raster/r.sim/r.sim.sediment/main.c:235
+#: ../raster/r.sim/r.sim.sediment/main.c:244
+#: ../raster/r.sim/r.sim.sediment/main.c:262
+#: ../raster/r.sim/r.sim.sediment/main.c:289
+#: ../raster/r.sim/r.sim.water/main.c:231
+#: ../raster/r.sim/r.sim.water/main.c:239
+#: ../raster/r.sim/r.sim.water/main.c:248
+#: ../raster/r.sim/r.sim.water/main.c:266
+#: ../raster/r.sim/r.sim.water/main.c:276
+#: ../raster/r.sim/r.sim.water/main.c:284
+#: ../raster/r.sim/r.sim.water/main.c:293
+#: ../raster/r.sim/r.sim.water/main.c:324 ../imagery/i.eb.hsebal01/main.c:141
+#: ../imagery/i.eb.hsebal01/main.c:150 ../imagery/i.eb.hsebal01/main.c:157
+#: ../imagery/i.eb.hsebal01/main.c:164 ../imagery/i.eb.hsebal01/main.c:171
+#: ../imagery/i.eb.hsebal01/main.c:178 ../vector/v.surf.rst/main.c:161
+#: ../vector/v.surf.rst/main.c:166 ../vector/v.surf.rst/main.c:187
+#: ../vector/v.surf.rst/main.c:262 ../vector/v.surf.rst/main.c:268
+#: ../vector/v.surf.rst/main.c:276 ../vector/v.surf.rst/main.c:283
+#: ../vector/v.surf.rst/main.c:291 ../vector/v.surf.rst/main.c:299
+#: ../vector/v.surf.rst/main.c:308 ../vector/v.surf.rst/main.c:316
+#: ../vector/v.surf.rst/main.c:324 ../vector/v.surf.rst/main.c:333
+#: ../vector/v.surf.rst/main.c:341 ../vector/v.surf.rst/main.c:348
+msgid "Parameters"
+msgstr ""
+#: ../raster/r.sim/r.sim.sediment/main.c:234
+#: ../raster/r.sim/r.sim.water/main.c:238
+msgid "Time used for iterations [minutes]"
+msgstr ""
+#: ../raster/r.sim/r.sim.sediment/main.c:243
+#: ../raster/r.sim/r.sim.water/main.c:247
+msgid "Time interval for creating output maps [minutes]"
+msgstr ""
+#: ../raster/r.sim/r.sim.sediment/main.c:261
+#: ../raster/r.sim/r.sim.water/main.c:265
+msgid "Water diffusion constant"
+msgstr ""
+#: ../raster/r.sim/r.sim.sediment/main.c:269
+#: ../raster/r.sim/r.sim.water/main.c:304
+msgid "Seed for random number generator"
+msgstr ""
+#: ../raster/r.sim/r.sim.sediment/main.c:271
+#: ../raster/r.sim/r.sim.water/main.c:306
+msgid "The same seed can be used to obtain same results or random seed can be generated by other means."
+msgstr ""
+#: ../raster/r.sim/r.sim.sediment/main.c:277
+#: ../raster/r.sim/r.sim.water/main.c:312
+msgid "Generate random seed"
+msgstr ""
+#: ../raster/r.sim/r.sim.sediment/main.c:279
+#: ../raster/r.sim/r.sim.water/main.c:314
+msgid "Automatically generates random seed for random number generator (use when you don't want to provide the seed option)"
+msgstr ""
+#: ../raster/r.sim/r.sim.sediment/main.c:288
+#: ../raster/r.sim/r.sim.water/main.c:323
+msgid "Number of threads which will be used for parallel compute"
+msgstr ""
+#: ../raster/r.sim/r.sim.sediment/main.c:296
+#: ../raster/r.sim/r.sim.water/main.c:331
+#, c-format
+msgid "Generated random seed (-s): %ld"
+msgstr ""
+#: ../raster/r.sim/r.sim.sediment/main.c:301
+#: ../raster/r.sim/r.sim.water/main.c:336
+#, c-format
+msgid "Read random seed from %s option: %ld"
+msgstr ""
+#: ../raster/r.sim/r.sim.sediment/main.c:374
+#: ../raster/r.sim/r.sim.water/main.c:402 ../vector/v.surf.rst/main.c:404
+#, c-format
+msgid "<%d> is not valid number of threads. Number of threads will be set on <%d>"
+msgstr ""
+#: ../raster/r.sim/r.sim.sediment/main.c:383
+#: ../raster/r.sim/r.sim.water/main.c:411
+#, c-format
+msgid "Number of threads: %d"
+msgstr ""
+#: ../raster/r.sim/r.sim.sediment/main.c:397
+#: ../raster/r.sim/r.sim.water/main.c:505
+msgid "More than 100 files are going to be created !!!!!"
+msgstr ""
+#: ../raster/r.sim/r.sim.sediment/main.c:403
+#: ../raster/r.sim/r.sim.water/main.c:511
+#, c-format
+msgid "default nwalk=%d, rwalk=%f"
+msgstr ""
+#: ../raster/r.sim/r.sim.sediment/main.c:412
+#: ../raster/r.sim/r.sim.water/main.c:521
+#, c-format
+msgid "Using metric conversion factor %f, step=%f"
+msgstr ""
+#: ../raster/r.sim/r.sim.sediment/main.c:419
+msgid "You are not outputting any raster or site files"
+msgstr ""
+#: ../raster/r.sim/r.sim.sediment/main.c:422
+#: ../raster/r.sim/r.sim.water/main.c:530 ../vector/v.surf.rst/main.c:656
+#: ../vector/v.surf.rst/main.c:711 ../vector/v.vol.rst/main.c:914
+msgid "Input failed"
+msgstr ""
+#: ../raster/r.sim/r.sim.water/main.c:116 ../vector/v.net.flow/main.c:60
+msgid "flow"
+msgstr ""
+#: ../raster/r.sim/r.sim.water/main.c:117
+msgid "overland flow"
+msgstr ""
+#: ../raster/r.sim/r.sim.water/main.c:120
+msgid "Overland flow hydrologic simulation using path sampling method (SIMWE)."
+msgstr ""
+#: ../raster/r.sim/r.sim.water/main.c:137
+msgid "Name of rainfall excess rate (rain-infilt) raster map [mm/hr]"
+msgstr ""
+#: ../raster/r.sim/r.sim.water/main.c:146
+msgid "Rainfall excess rate unique value [mm/hr]"
+msgstr ""
+#: ../raster/r.sim/r.sim.water/main.c:153
+msgid "Name of runoff infiltration rate raster map [mm/hr]"
+msgstr ""
+#: ../raster/r.sim/r.sim.water/main.c:162
+msgid "Runoff infiltration rate unique value [mm/hr]"
+msgstr ""
+#: ../raster/r.sim/r.sim.water/main.c:183
+msgid "Name of flow controls raster map (permeability ratio 0-1)"
+msgstr ""
+#: ../raster/r.sim/r.sim.water/main.c:196
+msgid "Name for output water depth raster map [m]"
+msgstr ""
+#: ../raster/r.sim/r.sim.water/main.c:202
+msgid "Name for output water discharge raster map [m3/s]"
+msgstr ""
+#: ../raster/r.sim/r.sim.water/main.c:208
+msgid "Name for output simulation error raster map [m]"
+msgstr ""
+#: ../raster/r.sim/r.sim.water/main.c:230
+msgid "Number of walkers, default is twice the number of cells"
+msgstr ""
+#: ../raster/r.sim/r.sim.water/main.c:274
+msgid "Threshold water depth [m]"
+msgstr ""
+#: ../raster/r.sim/r.sim.water/main.c:275
+msgid "Diffusion increases after this water depth is reached"
+msgstr ""
+#: ../raster/r.sim/r.sim.water/main.c:283
+msgid "Diffusion increase constant"
+msgstr ""
+#: ../raster/r.sim/r.sim.water/main.c:292
+msgid "Weighting factor for water flow velocity vector"
+msgstr ""
+#: ../raster/r.sim/r.sim.water/main.c:297
+msgid "Time-series output"
+msgstr ""
+#: ../raster/r.sim/r.sim.water/main.c:527
+msgid "You are not outputting any raster maps"
+msgstr ""
+#: ../display/d.colortable/main.c:64
+msgid "Displays the color table associated with a raster map layer."
+msgstr ""
+#: ../display/d.colortable/main.c:68
+msgid "Name of raster map whose color table is to be displayed"
+msgstr ""
+#: ../display/d.colortable/main.c:73
+msgid "Color of lines separating the colors of the color table"
+msgstr ""
+#: ../display/d.colortable/main.c:79
+msgid "Number of lines to appear in the color table"
+msgstr ""
+#: ../display/d.colortable/main.c:85
+msgid "Number of columns to appear in the color table"
+msgstr ""
+#: ../display/d.colortable/main.c:90
+msgid "Do not draw a collar showing the NULL color in FP maps"
+msgstr ""
+#: ../display/d.colortable/main.c:112
+#, c-format
+msgid "<%s> is floating-point; ignoring [lines] and drawing continuous color ramp"
+msgstr ""
+#: ../display/d.colortable/main.c:126
+#, c-format
+msgid "<%s> is floating-point; ignoring [cols] and drawing continuous color ramp"
+msgstr ""
+#: ../display/d.colortable/main.c:137
+#, c-format
+msgid "Range file for <%s> not available"
+msgstr ""
+#: ../display/d.mon/main.c:53
+msgid "Controls graphics display monitors from the command line."
+msgstr ""
+#: ../display/d.mon/main.c:58
+msgid "Name of monitor to start"
+msgstr ""
+#: ../display/d.mon/main.c:60 ../display/d.mon/main.c:67
+#: ../display/d.mon/main.c:74 ../display/d.mon/main.c:135
+#: ../display/d.mon/main.c:140
+msgid "Manage"
+msgstr ""
+#: ../display/d.mon/main.c:65
+msgid "Name of monitor to stop"
+msgstr ""
+#: ../display/d.mon/main.c:72
+msgid "Name of monitor to select"
+msgstr ""
+#: ../display/d.mon/main.c:78
+msgid "Width for display monitor if not set by GRASS_RENDER_WIDTH"
+msgstr ""
+#: ../display/d.mon/main.c:79
+msgid "Default value: 720"
+msgstr ""
+#: ../display/d.mon/main.c:86
+msgid "Height for display monitor if not set by GRASS_RENDER_HEIGHT"
+msgstr ""
+#: ../display/d.mon/main.c:87
+msgid "Default value: 480"
+msgstr ""
+#: ../display/d.mon/main.c:94
+msgid "Dimensions of display monitor versus current size"
+msgstr ""
+#: ../display/d.mon/main.c:95
+msgid "Example: resolution=2 enlarge display monitor twice to 1280x960"
+msgstr ""
+#: ../display/d.mon/main.c:108
+msgid "Name for output file (when starting new monitor)"
+msgstr ""
+#: ../display/d.mon/main.c:109
+msgid "Ignored for 'wx' monitors"
+msgstr ""
+#: ../display/d.mon/main.c:114
+msgid "List running monitors and exit"
+msgstr ""
+#: ../display/d.mon/main.c:119
+msgid "Print name of currently selected monitor and exit"
+msgstr ""
+#: ../display/d.mon/main.c:124
+msgid "Print commands for currently selected monitor and exit"
+msgstr ""
+#: ../display/d.mon/main.c:130
+msgid "Print path to support files of currently selected monitor and exit"
+msgstr ""
+#: ../display/d.mon/main.c:134
+msgid "Do not automatically select when starting"
+msgstr ""
+#: ../display/d.mon/main.c:139
+msgid "Release and stop currently selected monitor and exit"
+msgstr ""
+#: ../display/d.mon/main.c:144
+msgid "Disable true colors"
+msgstr ""
+#: ../display/d.mon/main.c:149
+msgid "Open output file in update mode"
+msgstr ""
+#: ../display/d.mon/main.c:150
+msgid "Requires --overwrite flag"
+msgstr ""
+#: ../display/d.mon/main.c:155
+msgid "Launch light-weight wx monitor without toolbars and statusbar"
+msgstr ""
+#: ../display/d.mon/main.c:156
+msgid "Requires 'start=wx0-7'"
+msgstr ""
+#: ../display/d.mon/main.c:163
+#, c-format
+msgid "Flag -%c has effect only for wx monitors (%s=wx0-7)"
+msgstr ""
+#: ../display/d.mon/main.c:169 ../general/g.mapsets/main.c:136
+#: ../general/g.mapsets/main.c:138 ../general/g.mapsets/main.c:148
+#, c-format
+msgid "Flag -%c ignored"
+msgstr ""
+#: ../display/d.mon/main.c:173
+msgid "Currently selected monitor:"
+msgstr ""
+#: ../display/d.mon/main.c:177
+#, c-format
+msgid "List of commands for monitor <%s>:"
+msgstr ""
+#: ../display/d.mon/main.c:185
+#, c-format
+msgid "Monitor <%s> released"
+msgstr ""
+#: ../display/d.mon/main.c:190
+msgid "No monitor selected"
+msgstr ""
+#: ../display/d.mon/main.c:209
+#, c-format
+msgid "Either <%s>, <%s> or <%s> must be given"
+msgstr ""
+#: ../display/d.mon/main.c:214 ../general/g.mapsets/main.c:140
+#: ../general/g.mapsets/main.c:150 ../general/g.mapsets/main.c:158
+#, c-format
+msgid "Option <%s> ignored"
+msgstr ""
+#: ../display/d.mon/stop.c:18 ../display/d.mon/select.c:30
+#, c-format
+msgid "Monitor <%s> is not running"
+msgstr ""
+#: ../display/d.mon/stop.c:41
+#, c-format
+msgid "Unable to delete file <%s>"
+msgstr ""
+#: ../display/d.mon/stop.c:46
+#, c-format
+msgid "Unable to delete directory <%s>"
+msgstr ""
+#: ../display/d.mon/stop.c:75
+#, c-format
+msgid "Unable to read file <%s>"
+msgstr ""
+#: ../display/d.mon/start.c:46 ../display/d.mon/start.c:74
+#, c-format
+msgid "File <%s> already exists and will be overwritten"
+msgstr ""
+#: ../display/d.mon/start.c:67
+#, c-format
+msgid "Unable to start monitor, don't have write permission for <%s>"
+msgstr ""
+#: ../display/d.mon/start.c:76
+#, c-format
+msgid "Unable to delete <%s>"
+msgstr ""
+#: ../display/d.mon/start.c:93
+#, c-format
+msgid "Output file: %s"
+msgstr ""
+#: ../display/d.mon/start.c:148
+#, c-format
+msgid "Monitor <%s> already running"
+msgstr ""
+#: ../display/d.mon/start.c:151
+#, c-format
+msgid "Starting monitor <%s>..."
+msgstr ""
+#: ../display/d.mon/start.c:169
+msgid "Unable to copy render command file"
+msgstr ""
+#: ../display/d.mon/list.c:80
+msgid "List of running monitors:"
+msgstr ""
+#: ../display/d.mon/list.c:82
+msgid "No monitors running"
+msgstr ""
+#: ../display/d.mon/list.c:116 ../scripts/d.what.rast/d.what.rast.py:40
+#: ../scripts/d.what.vect/d.what.vect.py:40 ../scripts/d.redraw/d.redraw.py:41
+#, c-format, python-format
+msgid "Unable to open file '%s'"
+msgstr ""
+#: ../display/d.mon/list.c:145
+#, c-format
+msgid "No support files found for monitor <%s>"
+msgstr ""
+#: ../display/d.mon/select.c:14
+#, c-format
+msgid "Monitor <%s> is already selected"
+msgstr ""
+#: ../display/d.vect.thematic/plot1.c:120
+msgid "Color definition column not specified"
+msgstr ""
+#: ../display/d.vect.thematic/plot1.c:130
+#, c-format
+msgid "Color definition column (%s) not a string. Column must be of form RRR:GGG:BBB where RGB values range 0-255."
+msgstr ""
+#: ../display/d.vect.thematic/plot1.c:135
+#: ../display/d.vect.thematic/plot1.c:163 ../display/d.vect.thematic/main.c:316
+#, c-format
+msgid "Cannot select data (%s) from table"
+msgstr ""
+#: ../display/d.vect.thematic/plot1.c:148
+msgid "Line width column not specified."
+msgstr ""
+#: ../display/d.vect.thematic/plot1.c:159
+#, c-format
+msgid "Line width column (%s) not a number."
+msgstr ""
+#: ../display/d.vect.thematic/plot1.c:204
+#, c-format
+msgid ""
+"\n"
+"ERROR: vector map - can't read\n"
+msgstr ""
+#: ../display/d.vect.thematic/plot1.c:279
+#, c-format
+msgid "Error in color definition column (%s), element %d with cat %d: colorstring [%s]"
+msgstr ""
+#: ../display/d.vect.thematic/plot1.c:286
+#, c-format
+msgid "Error in color definition column (%s), element %d with cat %d"
+msgstr ""
+#: ../display/d.vect.thematic/plot1.c:354
+#, c-format
+msgid "Error in line width column (%s), element %d with cat %d: line width [%d]"
+msgstr ""
+#: ../display/d.vect.thematic/main.c:87
+msgid "choropleth map"
+msgstr ""
+#: ../display/d.vect.thematic/main.c:90
+msgid "Displays a thematic vector map in the active graphics frame."
+msgstr ""
+#: ../display/d.vect.thematic/main.c:97
+msgid "Layer number. If -1, all layers are displayed."
+msgstr ""
+#: ../display/d.vect.thematic/main.c:103
+msgid "Name of attribute column to be classified"
+msgstr ""
+#: ../display/d.vect.thematic/main.c:110
+msgid "Class breaks, without minimum and maximum"
+msgstr ""
+#: ../display/d.vect.thematic/main.c:111 ../display/d.vect.thematic/main.c:129
+#: ../display/d.vect.thematic/main.c:137
+msgid "Classes"
+msgstr ""
+#: ../display/d.vect.thematic/main.c:119 ../vector/v.class/main.c:68
+msgid "Algorithm to use for classification"
+msgstr ""
+#: ../display/d.vect.thematic/main.c:123 ../vector/v.class/main.c:76
+msgid "simple intervals"
+msgstr ""
+#: ../display/d.vect.thematic/main.c:124 ../vector/v.class/main.c:77
+msgid "standard deviations"
+msgstr ""
+#: ../display/d.vect.thematic/main.c:125 ../vector/v.class/main.c:78
+msgid "quantiles"
+msgstr ""
+#: ../display/d.vect.thematic/main.c:126 ../vector/v.class/main.c:79
+msgid "equiprobable (normal distribution)"
+msgstr ""
+#: ../display/d.vect.thematic/main.c:136 ../vector/v.class/main.c:88
+msgid "Number of classes to define"
+msgstr ""
+#: ../display/d.vect.thematic/main.c:144
+msgid "Colors (one per class)"
+msgstr ""
+#: ../display/d.vect.thematic/main.c:154 ../display/d.vect.thematic/main.c:160
+msgid "Boundaries"
+msgstr ""
+#: ../display/d.vect.thematic/main.c:155
+msgid "Boundary width"
+msgstr ""
+#: ../display/d.vect.thematic/main.c:159
+msgid "Boundary color"
+msgstr ""
+#: ../display/d.vect.thematic/main.c:168 ../display/d.vect.thematic/main.c:178
+#: ../display/d.vect/main.c:167 ../display/d.vect/main.c:177
+#: ../display/d.vect/main.c:184 ../display/d.vect/main.c:190
+#: ../display/d.vect/main.c:326
+msgid "Symbols"
+msgstr ""
+#: ../display/d.vect.thematic/main.c:172 ../display/d.vect/main.c:171
+msgid "Point and centroid symbol"
+msgstr ""
+#: ../display/d.vect.thematic/main.c:179 ../display/d.legend.vect/main.c:88
+#: ../display/d.vect/main.c:178
+msgid "Symbol size"
+msgstr ""
+#: ../display/d.vect.thematic/main.c:186 ../display/d.vect.thematic/main.c:197
+#: ../display/d.vect.thematic/main.c:206 ../display/d.vect.thematic/main.c:218
+#: ../display/d.vect.thematic/main.c:224 ../display/d.vect.thematic/main.c:229
+#: ../display/d.vect.thematic/main.c:239 ../display/d.vect.thematic/main.c:244
+#: ../display/d.vect/main.c:201 ../display/d.vect/main.c:211
+#: ../display/d.vect/main.c:219 ../display/d.vect/main.c:331
+msgid "Legend"
+msgstr ""
+#: ../display/d.vect.thematic/main.c:190
+msgid "Legend symbol for lines"
+msgstr ""
+#: ../display/d.vect.thematic/main.c:201
+msgid "Legend symbol for areas"
+msgstr ""
+#: ../display/d.vect.thematic/main.c:207
+msgid "Thematic map title"
+msgstr ""
+#: ../display/d.vect.thematic/main.c:214 ../display/d.vect.thematic/main.c:236
+msgid "DEPRECATED"
+msgstr ""
+#: ../display/d.vect.thematic/main.c:215
+msgid "Output legend file"
+msgstr ""
+#: ../display/d.vect.thematic/main.c:223 ../display/d.vect.chart/main.c:142
+msgid "Create legend information and send to stdout"
+msgstr ""
+#: ../display/d.vect.thematic/main.c:228
+msgid "Do not draw map, only output the legend information"
+msgstr ""
+#: ../display/d.vect.thematic/main.c:237
+msgid "When printing legend info, include extended statistical info from classification algorithm"
+msgstr ""
+#: ../display/d.vect.thematic/main.c:243 ../display/d.vect/main.c:330
+msgid "Do not show this layer in vector legend"
+msgstr ""
+#: ../display/d.vect.thematic/main.c:255
+msgid "Flag -e is deprecated, set verbose mode with --v to get the extended statistical info."
+msgstr ""
+#: ../display/d.vect.thematic/main.c:258
+msgid "Option legendfile is deprecated, either use flag -l to print legend to standard output, or set GRASS_LEGEND_FILE environment variable (see d.legend.vect for details)."
+msgstr ""
+#: ../display/d.vect.thematic/main.c:277
+#, c-format
+msgid "%s: You must build topology on vector map. Run v.build."
+msgstr ""
+#: ../display/d.vect.thematic/main.c:288
+msgid "'layer' must be > 0"
+msgstr ""
+#: ../display/d.vect.thematic/main.c:290 ../display/d.vect/opt.c:143
+#: ../vector/v.db.connect/main.c:180
+msgid "Database connection not defined"
+msgstr ""
+#: ../display/d.vect.thematic/main.c:299 ../display/d.vect/opt.c:152
+#: ../db/db.columns/main.c:56 ../db/db.describe/main.c:61
+#: ../db/db.execute/main.c:76 ../db/db.select/main.c:81
+#: ../db/db.tables/main.c:50
+#, c-format
+msgid "Unable to open database <%s>"
+msgstr ""
+#: ../display/d.vect.thematic/main.c:312
+#, c-format
+msgid "Data (%s) not numeric. Column must be numeric."
+msgstr ""
+#: ../display/d.vect.thematic/main.c:379
+#, c-format
+msgid "Unknown color: [%s]"
+msgstr ""
+#: ../display/d.vect.thematic/main.c:390
+msgid "You gave both manual breaks and a classification algorithm or a number of classes. The manual breaks have precedence and will thus be used."
+msgstr ""
+#: ../display/d.vect.thematic/main.c:427
+msgid "You must either give classbreaks or a classification algorithm"
+msgstr ""
+#: ../display/d.vect.thematic/main.c:440
+#, c-format
+msgid ""
+"Not enough colors or error in color specifications.\n"
+"Need %i entries for 'colors' parameter"
+msgstr ""
+#: ../display/d.vect.thematic/main.c:445
+#, c-format
+msgid "Error interpreting color %s"
+msgstr ""
+#: ../display/d.vect.thematic/main.c:462
+msgid "Plotting ..."
+msgstr ""
+#: ../display/d.vect.thematic/main.c:474
+msgid "The bounding box of the map is outside the current region, nothing drawn."
+msgstr ""
+#: ../display/d.vect.thematic/main.c:523
+#, c-format
+msgid ""
+"\n"
+"Total number of records: %.0f\n"
+msgstr ""
+#: ../display/d.vect.thematic/main.c:525
+#, c-format
+msgid "Classification of %s into %i classes\n"
+msgstr ""
+#: ../display/d.vect.thematic/main.c:527 ../vector/v.class/main.c:203
+#, c-format
+msgid "Using algorithm: *** %s ***\n"
+msgstr ""
+#: ../display/d.vect.thematic/main.c:529 ../vector/v.class/main.c:204
+#, c-format
+msgid "Mean: %f\tStandard deviation = %f\n"
+msgstr ""
+#: ../display/d.vect.thematic/main.c:533
+#, c-format
+msgid "Last chi2 = %f\n"
+msgstr ""
+#: ../display/d.vect.thematic/main.c:535 ../vector/v.class/main.c:211
+#, c-format
+msgid "Stdev multiplied by %.4f to define step\n"
+msgstr ""
+#: ../display/d.vect.thematic/display.c:51 ../display/d.vect/lines.c:107
+#: ../display/d.vect/lines.c:335
+#, c-format
+msgid "Unable to read symbol <%s>, unable to display points"
+msgstr ""
+#: ../display/d.vect.thematic/display.c:118 ../display/d.vect/lines.c:175
+#, c-format
+msgid "%d point plotted"
+msgid_plural "%d points plotted"
+msgstr[0] ""
+msgstr[1] ""
+#: ../display/d.vect.thematic/display.c:121 ../display/d.vect/lines.c:177
+#, c-format
+msgid "%d line plotted"
+msgid_plural "%d lines plotted"
+msgstr[0] ""
+msgstr[1] ""
+#: ../display/d.vect.thematic/display.c:125 ../display/d.vect/lines.c:179
+#, c-format
+msgid "%d centroid plotted"
+msgid_plural "%d centroids plotted"
+msgstr[0] ""
+msgstr[1] ""
+#: ../display/d.vect.thematic/display.c:129 ../display/d.vect/lines.c:181
+#, c-format
+msgid "%d boundary plotted"
+msgid_plural "%d boundaries plotted"
+msgstr[0] ""
+msgstr[1] ""
+#: ../display/d.vect.thematic/display.c:132 ../display/d.vect/lines.c:183
+#, c-format
+msgid "%d face plotted"
+msgid_plural "%d faces plotted"
+msgstr[0] ""
+msgstr[1] ""
+#: ../display/d.geodesic/main.c:48
+msgid "great circle"
+msgstr ""
+#: ../display/d.geodesic/main.c:49 ../display/d.path/main.c:50
+#: ../vector/v.net.distance/main.c:68 ../vector/v.net.allpairs/main.c:63
+#: ../vector/v.net.path/main.c:44 ../vector/v.net.timetable/main.c:262
+#: ../vector/v.net.visibility/main.c:47
+msgid "shortest path"
+msgstr ""
+#: ../display/d.geodesic/main.c:51
+msgid "Displays a geodesic line, tracing the shortest distance between two geographic points along a great circle, in a longitude/latitude data set."
+msgstr ""
+#: ../display/d.geodesic/main.c:58 ../display/d.rhumbline/main.c:53
+#: ../display/d.path/main.c:65
+msgid "Starting and ending coordinates"
+msgstr ""
+#: ../display/d.geodesic/main.c:62 ../display/d.rhumbline/main.c:57
+#: ../display/d.northarrow/main.c:103
+msgid "Line color"
+msgstr ""
+#: ../display/d.geodesic/main.c:66 ../display/d.grid/main.c:107
+#: ../display/d.rhumbline/main.c:62 ../display/d.legend/main.c:203
+#: ../display/d.rast.num/main.c:88 ../display/d.northarrow/main.c:113
+#: ../vector/v.label.sa/main.c:98 ../vector/v.label/main.c:151
+#: ../vector/v.lrs/v.lrs.label/main.c:193
+msgid "Text color"
+msgstr ""
+#: ../display/d.geodesic/main.c:78 ../display/d.rhumbline/main.c:75
+#, c-format
+msgid "Location is not %s"
+msgstr ""
+#: ../display/d.geodesic/main.c:87 ../display/d.rhumbline/main.c:86
+#: ../display/d.path/main.c:140
+msgid "No coordinates given"
+msgstr ""
+#: ../display/d.geodesic/main.c:90 ../display/d.geodesic/main.c:93
+#: ../display/d.geodesic/main.c:96 ../display/d.geodesic/main.c:99
+#: ../display/d.rhumbline/main.c:89 ../display/d.rhumbline/main.c:92
+#: ../display/d.rhumbline/main.c:95 ../display/d.rhumbline/main.c:98
+#, c-format
+msgid "%s - illegal longitude"
+msgstr ""
+#: ../display/d.his/main.c:69
+msgid "Displays the result obtained by combining hue, intensity, and saturation (HIS) values from user-specified input raster map layers."
+msgstr ""
+#: ../display/d.his/main.c:97
+msgid "Percent to brighten intensity channel"
+msgstr ""
+#: ../display/d.his/main.c:103
+msgid "Respect NULL values while drawing"
+msgstr ""
+#: ../display/d.barscale/main.c:65
+msgid "Displays a barscale on the graphics monitor."
+msgstr ""
+#: ../display/d.barscale/main.c:69
+msgid "Use feet/miles instead of meters"
+msgstr ""
+#: ../display/d.barscale/main.c:73
+msgid "Draw the scale bar without text"
+msgstr ""
+#: ../display/d.barscale/main.c:74 ../display/d.barscale/main.c:141
+#: ../display/d.barscale/main.c:166 ../display/d.barscale/main.c:183
+#: ../display/d.text/main.c:164 ../display/d.text/main.c:173
+#: ../display/d.text/main.c:182 ../display/d.text/main.c:190
+#: ../display/d.text/main.c:264 ../display/d.text/main.c:269
+#: ../display/d.northarrow/main.c:100 ../display/d.northarrow/main.c:130
+#: ../display/d.northarrow/main.c:135 ../display/d.northarrow/main.c:140
+msgid "Text"
+msgstr ""
+#: ../display/d.barscale/main.c:78
+msgid "Display north-arrow symbol."
+msgstr ""
+#: ../display/d.barscale/main.c:79 ../display/d.barscale/main.c:88
+#: ../display/d.barscale/main.c:149 ../display/d.northarrow/main.c:73
+msgid "Style"
+msgstr ""
+#: ../display/d.barscale/main.c:83
+msgid "Type of barscale to draw"
+msgstr ""
+#: ../display/d.barscale/main.c:102
+msgid "Classic style"
+msgstr ""
+#: ../display/d.barscale/main.c:103
+msgid "Line style"
+msgstr ""
+#: ../display/d.barscale/main.c:104
+msgid "Solid style"
+msgstr ""
+#: ../display/d.barscale/main.c:105
+msgid "Hollow style"
+msgstr ""
+#: ../display/d.barscale/main.c:106
+msgid "Full checker style"
+msgstr ""
+#: ../display/d.barscale/main.c:107
+msgid "Part checker style"
+msgstr ""
+#: ../display/d.barscale/main.c:108
+msgid "Mixed checker style"
+msgstr ""
+#: ../display/d.barscale/main.c:109
+msgid "Tail checker style"
+msgstr ""
+#: ../display/d.barscale/main.c:110
+msgid "Up ticks style"
+msgstr ""
+#: ../display/d.barscale/main.c:111
+msgid "Down ticks style"
+msgstr ""
+#: ../display/d.barscale/main.c:112
+msgid "Both ticks style"
+msgstr ""
+msgid "Arrow ends style"
+msgstr ""
+#: ../display/d.barscale/main.c:121 ../display/d.northarrow/main.c:83
+msgid "Screen coordinates of the rectangle's top-left corner"
+msgstr ""
+#: ../display/d.barscale/main.c:122 ../display/d.northarrow/main.c:84
+msgid "(0,0) is lower-left of the display frame"
+msgstr ""
+#: ../display/d.barscale/main.c:130
+msgid "Length of barscale in map units"
+msgstr ""
+#: ../display/d.barscale/main.c:134
+msgid "Barscale units to display"
+msgstr ""
+#: ../display/d.barscale/main.c:139
+msgid "Custom label of unit"
+msgstr ""
+#: ../display/d.barscale/main.c:148
+msgid "Number of segments"
+msgstr ""
+#: ../display/d.barscale/main.c:152
+msgid "Bar scale and text color"
+msgstr ""
+#: ../display/d.barscale/main.c:158
+msgid "Background color (drawn behind the bar)"
+msgstr ""
+#: ../display/d.barscale/main.c:163
+msgid "Text position"
+msgstr ""
+#: ../display/d.barscale/main.c:174
+msgid "Scale factor to change bar width"
+msgstr ""
+#: ../display/d.barscale/main.c:182 ../display/d.legend.vect/main.c:123
+#: ../display/d.legend/main.c:218 ../display/d.northarrow/main.c:129
+msgid "Font size"
+msgstr ""
+#: ../display/d.barscale/main.c:193
+#, c-format
+msgid "%s does not work with a latitude-longitude location"
+msgstr ""
+#: ../display/d.barscale/main.c:237 ../display/d.barscale/main.c:254
+#: ../display/d.barscale/draw_scale.c:220
+msgid "Programmer error"
+msgstr ""
+#: ../display/d.barscale/draw_scale.c:611
+#: ../display/d.northarrow/draw_n_arrow.c:200
+#, c-format
+msgid "Could not read symbol \"%s\""
+msgstr ""
+#: ../display/d.rgb/main.c:58
+msgid "Displays three user-specified raster maps as red, green, and blue overlays in the active graphics frame."
+msgstr ""
+#: ../display/d.rgb/main.c:63 ../display/d.rast/main.c:81
+msgid "Make null cells opaque"
+msgstr ""
+#: ../display/d.rgb/main.c:64 ../display/d.rast/main.c:77
+#: ../display/d.rast/main.c:82
+msgid "Null cells"
+msgstr ""
+#: ../display/d.grid/main.c:55
+msgid "graticule"
+msgstr ""
+#: ../display/d.grid/main.c:56 ../vector/v.mkgrid/main.c:72
+msgid "grid"
+msgstr ""
+#: ../display/d.grid/main.c:58
+msgid "Overlays a user-specified grid in the active display frame on the graphics monitor."
+msgstr ""
+#: ../display/d.grid/main.c:66
+msgid "Size of grid to be drawn (in map units)"
+msgstr ""
+#: ../display/d.grid/main.c:68
+msgid "0 for north-south resolution of the current region. In map units or DDD:MM:SS format. Example: \"1000\" or \"0:10\""
+msgstr ""
+#: ../display/d.grid/main.c:76
+msgid "Lines of the grid pass through this coordinate"
+msgstr ""
+#: ../display/d.grid/main.c:85
+msgid "Draw only east-west lines, north-south lines, or both "
+msgstr ""
+#: ../display/d.grid/main.c:86 ../display/d.grid/main.c:159
+#: ../display/d.grid/main.c:164 ../display/d.grid/main.c:169
+msgid "Disable"
+msgstr ""
+#: ../display/d.grid/main.c:92
+msgid "Grid line width"
+msgstr ""
+#: ../display/d.grid/main.c:96 ../display/d.rast.num/main.c:94
+msgid "Grid color"
+msgstr ""
+#: ../display/d.grid/main.c:97 ../display/d.grid/main.c:102
+#: ../display/d.grid/main.c:108 ../display/d.grid/main.c:114
+msgid "Color"
+msgstr ""
+#: ../display/d.grid/main.c:101 ../display/d.legend.vect/main.c:95
+#: ../display/d.legend/main.c:240 ../vector/v.label.sa/main.c:144
+#: ../vector/v.label/main.c:193 ../vector/v.lrs/v.lrs.label/main.c:223
+msgid "Border color"
+msgstr ""
+#: ../display/d.grid/main.c:122
+msgid "Font size for gridline coordinate labels"
+msgstr ""
+#: ../display/d.grid/main.c:127
+msgid "Align the origin to the east-north corner of the current region"
+msgstr ""
+#: ../display/d.grid/main.c:132
+msgid "Draw geographic grid (referenced to current ellipsoid)"
+msgstr ""
+#: ../display/d.grid/main.c:133 ../display/d.grid/main.c:139
+#: ../display/d.grid/main.c:144 ../display/d.grid/main.c:149
+#: ../display/d.grid/main.c:154 ../misc/m.nviz.image/args.c:233
+#: ../misc/m.nviz.image/args.c:244 ../misc/m.nviz.image/args.c:255
+#: ../misc/m.nviz.image/args.c:267 ../misc/m.nviz.image/args.c:279
+#: ../misc/m.nviz.image/args.c:288 ../misc/m.nviz.image/args.c:298
+#: ../misc/m.nviz.image/args.c:608 ../misc/m.nviz.image/args.c:620
+msgid "Draw"
+msgstr ""
+#: ../display/d.grid/main.c:138
+msgid "Draw geographic grid (referenced to WGS84 ellipsoid)"
+msgstr ""
+#: ../display/d.grid/main.c:143
+msgid "Draw '+' marks instead of grid lines"
+msgstr ""
+#: ../display/d.grid/main.c:148
+msgid "Draw '.' marks instead of grid lines"
+msgstr ""
+#: ../display/d.grid/main.c:153
+msgid "Draw fiducial marks instead of grid lines"
+msgstr ""
+#: ../display/d.grid/main.c:158
+msgid "Disable grid drawing"
+msgstr ""
+#: ../display/d.grid/main.c:163
+msgid "Disable border drawing"
+msgstr ""
+#: ../display/d.grid/main.c:168
+msgid "Disable text drawing"
+msgstr ""
+#: ../display/d.grid/main.c:178
+msgid "Both grid and border drawing are disabled"
+msgstr ""
+#: ../display/d.grid/main.c:182
+msgid "Geo-grid option not available for LL projection, use without -g/-w"
+msgstr ""
+#: ../display/d.grid/main.c:184
+msgid "Geo-grid option not available for XY projection, use without -g/-w"
+msgstr ""
+#: ../display/d.grid/main.c:203
+msgid "Choose a single mark style"
+msgstr ""
+#: ../display/d.grid/main.c:234
+#, c-format
+msgid "Invalid geo-grid size <%s>"
+msgstr ""
+#: ../display/d.grid/main.c:239
+#, c-format
+msgid "Invalid grid size <%s>"
+msgstr ""
+#: ../display/d.grid/fiducial.c:61
+msgid "Reading symbol"
+msgstr ""
+#: ../display/d.grid/plot.c:373
+msgid "Geo-grid option only available for LL projection, use without -g/-w"
+msgstr ""
+#: ../display/d.grid/plot.c:575
+msgid ""
+"WGS84 grid output not possible as this location does not contain\n"
+"datum transformation parameters. Try running g.setproj."
+msgstr ""
+#: ../display/d.grid/plot.c:743
+msgid "Error in pj_do_proj1"
+msgstr ""
+#: ../display/d.grid/plot.c:749
+msgid "Error in pj_do_proj2"
+msgstr ""
+#: ../display/d.grid/plot.c:753
+msgid "Error in pj_do_proj3"
+msgstr ""
+#: ../display/d.grid/plot.c:761
+msgid "Error in pj_do_proj5"
+msgstr ""
+#: ../display/d.grid/plot.c:765
+msgid "Error in pj_do_proj6"
+msgstr ""
+#: ../display/d.legend.vect/main.c:55
+msgid "Displays a vector legend in the active graphics frame."
+msgstr ""
+#: ../display/d.legend.vect/main.c:66
+msgid "Screen position of legend to be drawn (percentage, [0,0] is lower left)"
+msgstr ""
+#: ../display/d.legend.vect/main.c:74
+msgid "Number of legend columns"
+msgstr ""
+#: ../display/d.legend.vect/main.c:75 ../display/d.legend.vect/main.c:90
+msgid "Layout"
+msgstr ""
+#: ../display/d.legend.vect/main.c:81 ../display/d.legend/main.c:99
+msgid "Legend title"
+msgstr ""
+#: ../display/d.legend.vect/main.c:82 ../display/d.legend.vect/main.c:141
+#: ../display/d.legend/main.c:100 ../display/d.legend/main.c:109
+msgid "Title"
+msgstr ""
+#: ../display/d.legend.vect/main.c:96 ../display/d.legend.vect/main.c:102
+#: ../display/d.legend.vect/main.c:109 ../display/d.legend.vect/main.c:168
+#: ../display/d.legend/main.c:241 ../display/d.legend/main.c:247
+#: ../display/d.legend/main.c:288
+msgid "Background"
+msgstr ""
+#: ../display/d.legend.vect/main.c:108
+msgid "Background border width"
+msgstr ""
+#: ../display/d.legend.vect/main.c:115 ../display/d.legend/main.c:210
+#: ../display/d.rast.num/main.c:119 ../display/d.text/main.c:223
+#: ../display/d.vect/main.c:266 ../vector/v.label/main.c:122
+msgid "Font name"
+msgstr ""
+#: ../display/d.legend.vect/main.c:116 ../display/d.legend.vect/main.c:125
+#: ../display/d.legend.vect/main.c:132 ../display/d.legend.vect/main.c:148
+#: ../display/d.legend.vect/main.c:157 ../display/d.legend.vect/main.c:163
+#: ../display/d.legend/main.c:204 ../display/d.legend/main.c:211
+#: ../display/d.legend/main.c:220 ../display/d.legend/main.c:227
+#: ../display/d.legend/main.c:235 ../display/d.rast.num/main.c:120
+#: ../display/d.rast.num/main.c:127 ../display/d.rast.num/main.c:135
+#: ../display/d.text/main.c:224 ../display/d.text/main.c:234
+#: ../display/d.text/main.c:241 ../display/d.text/main.c:249
+#: ../display/d.text/main.c:274
+msgid "Font settings"
+msgstr ""
+#: ../display/d.legend.vect/main.c:124
+msgid "Default: 12"
+msgstr ""
+#: ../display/d.legend.vect/main.c:131
+msgid "Title font name"
+msgstr ""
+#: ../display/d.legend.vect/main.c:139 ../display/d.legend/main.c:107
+msgid "Title font size"
+msgstr ""
+#: ../display/d.legend.vect/main.c:140
+msgid "Default: 18"
+msgstr ""
+#: ../display/d.legend.vect/main.c:147
+msgid "Subtitle font name"
+msgstr ""
+#: ../display/d.legend.vect/main.c:155
+msgid "Subtitle font size"
+msgstr ""
+#: ../display/d.legend.vect/main.c:156
+msgid "Default: 14"
+msgstr ""
+#: ../display/d.legend.vect/main.c:162
+msgid "Font color"
+msgstr ""
+#: ../display/d.legend.vect/main.c:167
+msgid "Display legend background"
+msgstr ""
+#: ../display/d.legend.vect/main.c:171 ../display/d.legend.vect/main.c:178
+#: ../display/d.legend.vect/main.c:185
+msgid "In/Out"
+msgstr ""
+#: ../display/d.legend.vect/main.c:172
+msgid "Field separator for input file"
+msgstr ""
+#: ../display/d.legend.vect/main.c:175
+msgid "Input legend file"
+msgstr ""
+#: ../display/d.legend.vect/main.c:176
+msgid "Path to legend file "
+msgstr ""
+#: ../display/d.legend.vect/main.c:181
+msgid "Output csv file"
+msgstr ""
+#: ../display/d.legend.vect/main.c:182
+msgid "Path to output file or '-' for standard output"
+msgstr ""
+#: ../display/d.legend.vect/draw.c:178
+msgid "Cannot read symbol"
+msgstr ""
+#: ../display/d.legend.vect/draw.c:238
+msgid "Invalid value for color type in legend file. Use one of 'lf' or 'ps'."
+msgstr ""
+#: ../display/d.colorlist/main.c:39
+msgid "Outputs a list of all available display colors."
+msgstr ""
+#: ../display/d.extract/main.c:52
+msgid "Selects and extracts vectors with mouse into new vector map."
+msgstr ""
+#: ../display/d.extract/main.c:65 ../display/d.path/main.c:99
+msgid "Original line color"
+msgstr ""
+#: ../display/d.extract/main.c:71 ../display/d.path/main.c:107
+msgid "Highlight color"
+msgstr ""
+#: ../display/d.extract/main.c:79 ../vector/v.label/main.c:233
+msgid "No graphics device selected"
+msgstr ""
+#: ../display/d.extract/main.c:122
+msgid "Copying tables..."
+msgstr ""
+#: ../display/d.extract/main.c:130
+msgid "Cannot get db link info -> cannot copy table."
+msgstr ""
+#: ../display/d.extract/extract.c:43
+msgid "Select vector(s) with mouse"
+msgstr ""
+#: ../display/d.extract/extract.c:44
+msgid " - L: draw box with left mouse button to select"
+msgstr ""
+#: ../display/d.extract/extract.c:45
+msgid " - M: draw box with middle mouse button to remove from display"
+msgstr ""
+#: ../display/d.extract/extract.c:46
+msgid " - R: quit and save selected vectors to new map\n"
+msgstr ""
+#: ../display/d.extract/extract.c:48
+msgid "L: add M: remove R: quit and save\n"
+msgstr ""
+#: ../display/d.rhumbline/main.c:46
+msgid "rhumbline"
+msgstr ""
+#: ../display/d.rhumbline/main.c:48
+msgid "Displays the rhumbline joining two longitude/latitude coordinates."
+msgstr ""
+#: ../display/d.graph/main.c:61
+msgid "Program for generating and displaying simple graphics on the display monitor."
+msgstr ""
+#: ../display/d.graph/main.c:66
+msgid "Name of file containing graphics commands, if not given reads from standard input"
+msgstr ""
+#: ../display/d.graph/main.c:73
+msgid "Color to draw with, either a standard GRASS color or R:G:B triplet"
+msgstr ""
+#: ../display/d.graph/main.c:80
+msgid "Coordinates are given in map units"
+msgstr ""
+#: ../display/d.graph/main.c:91
+#, c-format
+msgid "Graph file <%s> not found"
+msgstr ""
+#: ../display/d.graph/do_graph.c:65 ../display/d.graph/do_graph.c:81
+#, c-format
+msgid "Problem parsing coordinates [%s]"
+msgstr ""
+#: ../display/d.graph/do_graph.c:98
+msgid "Unable to read color"
+msgstr ""
+#: ../display/d.graph/do_graph.c:129 ../display/d.graph/do_graph.c:195
+#: ../display/d.graph/do_graph.c:216 ../display/d.graph/do_graph.c:267
+#: ../display/d.graph/do_graph.c:334 ../display/d.graph/graphics.c:60
+#, c-format
+msgid "Problem parsing command [%s]"
+msgstr ""
+#: ../display/d.graph/do_graph.c:377
+msgid "Cannot read symbol, cannot display points"
+msgstr ""
+#: ../display/d.legend/main.c:82
+msgid "Displays a legend for a 2D or 3D raster map in the active frame of the graphics monitor."
+msgstr ""
+#: ../display/d.legend/main.c:108
+msgid "Default: Same as fontsize"
+msgstr ""
+#: ../display/d.legend/main.c:117
+msgid "Number of text lines (useful for truncating long legends)"
+msgstr ""
+#: ../display/d.legend/main.c:127
+msgid "Thinning factor (thin=10 gives cats 0,10,20...)"
+msgstr ""
+#: ../display/d.legend/main.c:135
+msgid "Units to display after labels (e.g. meters)"
+msgstr ""
+#: ../display/d.legend/main.c:144
+msgid "Number of text labels for smooth gradient legend"
+msgstr ""
+#: ../display/d.legend/main.c:145 ../display/d.legend/main.c:154
+#: ../display/d.legend/main.c:161 ../display/d.legend/main.c:263
+#: ../display/d.legend/main.c:273 ../display/d.legend/main.c:283
+msgid "Gradient"
+msgstr ""
+#: ../display/d.legend/main.c:151
+msgid "Specific values to draw ticks"
+msgstr ""
+#: ../display/d.legend/main.c:160
+msgid "Display label every step"
+msgstr ""
+#: ../display/d.legend/main.c:167
+msgid "Number of digits after decimal point"
+msgstr ""
+#: ../display/d.legend/main.c:179
+msgid "Size and placement as percentage of screen coordinates (0,0 is lower left)"
+msgstr ""
+#: ../display/d.legend/main.c:189
+msgid "List of discrete category numbers/values for legend"
+msgstr ""
+#: ../display/d.legend/main.c:191 ../display/d.legend/main.c:200
+msgid "Subset"
+msgstr ""
+#: ../display/d.legend/main.c:199
+msgid "Use a subset of the map range for the legend (min,max)"
+msgstr ""
+#: ../display/d.legend/main.c:219
+msgid "Default: Auto-scaled"
+msgstr ""
+#: ../display/d.legend/main.c:225 ../display/d.rast.num/main.c:125
+#: ../display/d.text/main.c:239
+msgid "Path to font file"
+msgstr ""
+#: ../display/d.legend/main.c:234 ../display/d.rast.num/main.c:134
+#: ../display/d.text/main.c:248
+msgid "Text encoding (only applicable to TrueType fonts)"
+msgstr ""
+#: ../display/d.legend/main.c:252
+msgid "Do not show category labels"
+msgstr ""
+#: ../display/d.legend/main.c:257
+msgid "Do not show category numbers"
+msgstr ""
+#: ../display/d.legend/main.c:262
+msgid "Draw legend ticks for labels"
+msgstr ""
+#: ../display/d.legend/main.c:267
+msgid "Skip categories with no label"
+msgstr ""
+#: ../display/d.legend/main.c:282
+msgid "Add histogram to smoothed legend"
+msgstr ""
+#: ../display/d.legend/main.c:287
+msgid "Show background"
+msgstr ""
+#: ../display/d.legend/main.c:292
+msgid "Use logarithmic scale"
+msgstr ""
+#: ../display/d.legend/draw.c:109
+msgid "Legend box lies outside of frame. Text may not display properly."
+msgstr ""
+#: ../display/d.legend/draw.c:114
+msgid "Drawing horizontal legend as box width exceeds height"
+msgstr ""
+#: ../display/d.legend/draw.c:126
+#, c-format
+msgid "Range information for <%s> not available (run r.support)"
+msgstr ""
+#: ../display/d.legend/draw.c:131
+msgid "Input map contains no data"
+msgstr ""
+#: ../display/d.legend/draw.c:145
+msgid "Requested range exceeds lower limit of actual data"
+msgstr ""
+#: ../display/d.legend/draw.c:152
+msgid "Requested range exceeds upper limit of actual data"
+msgstr ""
+#: ../display/d.legend/draw.c:214
+#, c-format
+msgid "use=%s out of range [%d,%d] (extend with range= ?)"
+msgstr ""
+#: ../display/d.legend/draw.c:239
+msgid "Nothing to draw! (no categories with labels? out of range?)"
+msgstr ""
+#: ../display/d.legend/draw.c:250
+msgid "Forcing a smooth legend: too many categories for current window height"
+msgstr ""
+#: ../display/d.legend/draw.c:282 ../display/d.legend/draw.c:287
+#: ../display/d.histogram/main.c:177
+#, c-format
+msgid "Range information for <%s> not available"
+msgstr ""
+#: ../display/d.legend/draw.c:301
+msgid "Color range exceeds lower limit of actual data"
+msgstr ""
+#: ../display/d.legend/draw.c:305
+msgid "Color range exceeds upper limit of actual data"
+msgstr ""
+#: ../display/d.legend/draw.c:312
+#, c-format
+msgid "Range [%.3f, %.3f] out of the logarithm domain."
+msgstr ""
+#: ../display/d.legend/draw.c:319
+#, c-format
+msgid "use=%s out of range [%.3f, %.3f] (extend with range= ?)"
+msgstr ""
+#: ../display/d.legend/draw.c:613
+#, c-format
+msgid "tick_value=%.3f out of range [%.3f, %.3f]"
+msgstr ""
+#: ../display/d.legend/draw.c:1029
+msgid "Histogram plotting not implemented for categorical legends. Use the '-s' flag"
+msgstr ""
+#: ../display/d.legend/draw.c:1286
+msgid "Nothing to draw! (no categories with labels?)"
+msgstr ""
+#: ../display/d.legend/histogram.c:115
+msgid "Histogram constrained by range not yet implemented for categorical rasters"
+msgstr ""
+#: ../display/d.rast.num/main.c:78 ../display/d.rast.arrow/main.c:98
+msgid "map annotations"
+msgstr ""
+#: ../display/d.rast.num/main.c:81
+msgid "Overlays cell category values on a raster map displayed in the active graphics frame."
+msgstr ""
+#: ../display/d.rast.num/main.c:108 ../display/d.rast.arrow/main.c:164
+msgid "Align grids with raster cells"
+msgstr ""
+#: ../display/d.rast.num/main.c:112
+msgid "Get text color from cell color value"
+msgstr ""
+#: ../display/d.rast.num/main.c:200
+#, c-format
+msgid "%d col"
+msgid_plural "%d cols"
+msgstr[0] ""
+msgstr[1] ""
+#. GTC %s will be replaced by strings "X rows" and "Y cols"
+#: ../display/d.rast.num/main.c:202
+#, c-format
+msgid ""
+"Current region size: %s X %s\n"
+"Your current region setting may be too large. Cells displayed on your graphics window may be too small for cell category number to be visible."
+msgstr ""
+#: ../display/d.rast.num/main.c:212
+msgid "Aborting (region larger then 200 rows X 200 cols is not allowed)"
+msgstr ""
+#: ../display/d.fontlist/main.c:47
+msgid "Lists the available fonts."
+msgstr ""
+#: ../display/d.fontlist/main.c:51
+msgid "List fonts (default; provided for compatibility with d.font)"
+msgstr ""
+#: ../display/d.fontlist/main.c:55 ../display/d.font/main.c:78
+msgid "List fonts verbosely"
+msgstr ""
+#: ../display/d.labels/main.c:44 ../vector/v.label.sa/main.c:39
+#: ../vector/v.label/main.c:60
+msgid "paint labels"
+msgstr ""
+#: ../display/d.labels/main.c:46
+msgid "Displays text labels (created with v.label) to the active frame on the graphics monitor."
+msgstr ""
+#: ../display/d.labels/main.c:52
+msgid "Ignore rotation setting and draw horizontally"
+msgstr ""
+#: ../display/d.labels/main.c:59
+msgid "Name of label file"
+msgstr ""
+#: ../display/d.labels/main.c:66
+msgid "Minimum region size (diagonal) when labels are displayed"
+msgstr ""
+#: ../display/d.labels/main.c:73
+msgid "Maximum region size (diagonal) when labels are displayed"
+msgstr ""
+#: ../display/d.labels/main.c:85
+#, c-format
+msgid "Label file <%s> not found"
+msgstr ""
+#: ../display/d.labels/main.c:97
+msgid "Region size is lower than minreg, nothing displayed."
+msgstr ""
+#: ../display/d.labels/main.c:105
+msgid "Region size is greater than maxreg, nothing displayed."
+msgstr ""
+#: ../display/d.labels/main.c:114 ../vector/v.lrs/v.lrs.label/main.c:283
+#, c-format
+msgid "Unable to open label file <%s>"
+msgstr ""
+#: ../display/d.labels/do_labels.c:142
+#, c-format
+msgid "Error: %s\n"
+msgstr ""
+#: ../display/d.linegraph/main.c:234
+msgid "Generates and displays simple line graphs in the active graphics monitor display frame."
+msgstr ""
+#: ../display/d.linegraph/main.c:238
+msgid "Name of data file for X axis of graph"
+msgstr ""
+#: ../display/d.linegraph/main.c:244
+msgid "Name of data file(s) for Y axis of graph"
+msgstr ""
+#: ../display/d.linegraph/main.c:251
+msgid "Path to files"
+msgstr ""
+#: ../display/d.linegraph/main.c:253
+msgid "Path to the directory where the input files are located"
+msgstr ""
+#: ../display/d.linegraph/main.c:261
+msgid "Color for Y data"
+msgstr ""
+#: ../display/d.linegraph/main.c:274
+msgid "Width of the lines"
+msgstr ""
+#: ../display/d.linegraph/main.c:281
+msgid "Color for axis, tics, numbers, and title"
+msgstr ""
+#: ../display/d.linegraph/main.c:289
+msgid "Title for X data"
+msgstr ""
+#: ../display/d.linegraph/main.c:296
+msgid "Title for Y data"
+msgstr ""
+#: ../display/d.linegraph/main.c:303
+msgid "Title for Graph"
+msgstr ""
+#: ../display/d.linegraph/main.c:311
+msgid "Minimum and maximun value for Y axis (min,max)"
+msgstr ""
+#: ../display/d.linegraph/main.c:318
+msgid "Tic values for the Y axis"
+msgstr ""
+#: ../display/d.linegraph/main.c:325
+msgid "Scale for X values"
+msgstr ""
+#: ../display/d.linegraph/main.c:331
+msgid "Scale for Y values"
+msgstr ""
+#: ../display/d.linegraph/main.c:352
+msgid "Symbol for point"
+msgstr ""
+#: ../display/d.linegraph/main.c:361
+msgid "Point size"
+msgstr ""
+#: ../display/d.linegraph/main.c:370
+msgid "Color for point symbol edge color"
+msgstr ""
+#: ../display/d.linegraph/main.c:376
+msgid "Width of point symbol lines"
+msgstr ""
+#: ../display/d.linegraph/main.c:437
+msgid "Maximum of 10 Y data files exceeded"
+msgstr ""
+#: ../display/d.linegraph/main.c:494
+#, c-format
+msgid "Cannot find/open symbol: '%s'"
+msgstr ""
+#: ../display/d.linegraph/main.c:511
+#, c-format
+msgid "Color <%s> cannot for option %s be parsed"
+msgstr ""
+#: ../display/d.linegraph/main.c:549
+#, c-format
+msgid "Only <%d> colors given for <%d> lines"
+msgstr ""
+#: ../display/d.linegraph/main.c:593
+#, c-format
+msgid "Number of widths (%d) is higher then the number of files (%d)"
+msgstr ""
+#: ../display/d.linegraph/main.c:606
+#, c-format
+msgid "Number of widths (%d) is lower then the number of files (%d)"
+msgstr ""
+#: ../display/d.linegraph/main.c:659
+#, c-format
+msgid "Y input file <%s> contains fewer data points than the X input file"
+msgstr ""
+#: ../display/d.linegraph/main.c:663
+#, c-format
+msgid "Y input file <%s> contains more data points than the X input file"
+msgstr ""
+#: ../display/d.linegraph/main.c:668
+#, c-format
+msgid "The last point will be ignored"
+msgid_plural "The last %d points will be ignored"
+msgstr[0] ""
+msgstr[1] ""
+#: ../display/d.linegraph/main.c:722
+#, c-format
+msgid "Scale X labels cannot be used with this range of data (%f, %f)"
+msgstr ""
+#: ../display/d.linegraph/main.c:752
+#, c-format
+msgid "Problem reading X data file at line %d"
+msgstr ""
+#: ../display/d.linegraph/main.c:764
+#, c-format
+msgid "Problem reading <%s> data file at line %d"
+msgstr ""
+#: ../display/d.linegraph/main.c:971
+#, c-format
+msgid "Scale Y labels cannot be used with thisrange of data (%f, %f)"
+msgstr ""
+#: ../display/d.vect.chart/main.c:65
+msgid "chart maps"
+msgstr ""
+#: ../display/d.vect.chart/main.c:67
+msgid "Displays charts of vector data in the active frame on the graphics monitor."
+msgstr ""
+#: ../display/d.vect.chart/main.c:86
+msgid "Chart type"
+msgstr ""
+#: ../display/d.vect.chart/main.c:87 ../display/d.vect.chart/main.c:97
+#: ../display/d.vect.chart/main.c:105 ../display/d.vect.chart/main.c:112
+#: ../display/d.vect.chart/main.c:117 ../display/d.vect.chart/main.c:123
+#: ../display/d.vect.chart/main.c:129 ../display/d.vect.chart/main.c:148
+msgid "Chart properties"
+msgstr ""
+#: ../display/d.vect.chart/main.c:91
+msgid "Attribute columns containing data"
+msgstr ""
+#: ../display/d.vect.chart/main.c:96
+msgid "Column used for pie chart size"
+msgstr ""
+#: ../display/d.vect.chart/main.c:104
+msgid "Size of chart (diameter for pie, total width for bar)"
+msgstr ""
+#: ../display/d.vect.chart/main.c:111
+msgid "Scale for size (to get size in pixels)"
+msgstr ""
+#: ../display/d.vect.chart/main.c:116
+msgid "Outline color"
+msgstr ""
+#: ../display/d.vect.chart/main.c:122
+msgid "Colors used to fill charts"
+msgstr ""
+#: ../display/d.vect.chart/main.c:128
+msgid "Center the bar chart around a data point"
+msgstr ""
+#: ../display/d.vect.chart/main.c:137
+msgid "Maximum value used for bar plot reference"
+msgstr ""
+#: ../display/d.vect.chart/main.c:147
+msgid "Create 3D charts"
+msgstr ""
+#: ../display/d.vect.chart/plot.c:86 ../display/d.vect/attr.c:110
+#: ../vector/v.in.db/main.c:225
+#, c-format
+msgid "Unable to open select cursor: '%s'"
+msgstr ""
+#: ../display/d.text/main.c:142
+msgid "Draws text in the active display frame on the graphics monitor using the current font."
+msgstr ""
+#: ../display/d.text/main.c:148
+msgid "Text to display"
+msgstr ""
+#: ../display/d.text/main.c:153
+msgid "Input file"
+msgstr ""
+#: ../display/d.text/main.c:162
+msgid "Text color, either a standard GRASS color or R:G:B triplet"
+msgstr ""
+#: ../display/d.text/main.c:171
+msgid "Text background color, either a standard GRASS color or R:G:B triplet"
+msgstr ""
+#: ../display/d.text/main.c:181 ../display/d.northarrow/main.c:92
+#: ../vector/v.label/main.c:156
+msgid "Rotation angle in degrees (counter-clockwise)"
+msgstr ""
+#: ../display/d.text/main.c:189
+msgid "Line spacing"
+msgstr ""
+#: ../display/d.text/main.c:198
+msgid "Screen position at which text will begin to be drawn (percentage, [0,0] is lower left)"
+msgstr ""
+#: ../display/d.text/main.c:207
+msgid "The screen line number on which text will begin to be drawn"
+msgstr ""
+#: ../display/d.text/main.c:216
+msgid "Text alignment"
+msgstr ""
+#: ../display/d.text/main.c:233
+msgid "Height of letters in percentage of available frame height"
+msgstr ""
+#: ../display/d.text/main.c:253
+msgid "Screen position in pixels ([0,0] is top left)"
+msgstr ""
+#: ../display/d.text/main.c:258
+msgid "Screen position in geographic coordinates"
+msgstr ""
+#: ../display/d.text/main.c:263
+msgid "Use bold text"
+msgstr ""
+#: ../display/d.text/main.c:268 ../display/d.northarrow/main.c:144
+msgid "Use radians instead of degrees for rotation"
+msgstr ""
+#: ../display/d.text/main.c:273
+msgid "Font size is height in pixels"
+msgstr ""
+#: ../display/d.text/main.c:385
+#, c-format
+msgid ""
+"\n"
+"Please enter text instructions. Enter EOF (ctrl-d) on last line to quit\n"
+msgstr ""
+#: ../display/d.text/main.c:576
+#, c-format
+msgid "[%s]: No such color. Use '%s'"
+msgstr ""
+#: ../display/d.text/main.c:591
+msgid "Invalid coordinates"
+msgstr ""
+#: ../display/d.info/main.c:38
+msgid "Displays information about the active display monitor."
+msgstr ""
+#: ../display/d.info/main.c:40
+msgid "Display monitors are maintained by d.mon."
+msgstr ""
+#: ../display/d.info/main.c:45
+msgid "Display screen rectangle (left, right, top, bottom)"
+msgstr ""
+#: ../display/d.info/main.c:49
+msgid "Display screen dimensions (width, height)"
+msgstr ""
+#: ../display/d.info/main.c:53
+msgid "Display active frame rectangle"
+msgstr ""
+#: ../display/d.info/main.c:57
+msgid "Display frame dimensions (width, height)"
+msgstr ""
+#: ../display/d.info/main.c:61
+msgid "Display screen rectangle of current region"
+msgstr ""
+#: ../display/d.info/main.c:66
+msgid "Display geographic coordinates and resolution of entire frame"
+msgstr ""
+#: ../display/d.path/main.c:49 ../vector/v.net.distance/main.c:67
+#: ../vector/v.net.allpairs/main.c:62 ../vector/v.net.connectivity/main.c:53
+#: ../vector/v.net.path/main.c:43 ../vector/v.net.iso/main.c:77
+#: ../vector/v.net.spanningtree/main.c:47 ../vector/v.net.steiner/main.c:347
+#: ../vector/v.net.flow/main.c:59 ../vector/v.net.timetable/main.c:261
+#: ../vector/v.net.visibility/main.c:46 ../vector/v.net.bridge/main.c:48
+#: ../vector/v.net.components/main.c:73 ../vector/v.net.salesman/main.c:128
+#: ../vector/v.net.centrality/main.c:97 ../vector/v.lrs/v.lrs.label/main.c:104
+#: ../vector/v.lrs/v.lrs.where/main.c:59
+#: ../vector/v.lrs/v.lrs.segment/main.c:73
+#: ../vector/v.lrs/v.lrs.create/main.c:123 ../vector/v.net/main.c:48
+#: ../vector/v.net.alloc/main.c:65
+msgid "network"
+msgstr ""
+#: ../display/d.path/main.c:52
+msgid "Finds shortest path for selected starting and ending node."
+msgstr ""
+#: ../display/d.path/main.c:60 ../vector/v.net.distance/main.c:89
+#: ../vector/v.net.path/main.c:61 ../vector/v.net.iso/main.c:124
+#: ../vector/v.net.steiner/main.c:363 ../vector/v.net.salesman/main.c:156
+#: ../vector/v.net/args.c:63 ../vector/v.net.alloc/main.c:103
+msgid "Arc type"
+msgstr ""
+#: ../display/d.path/main.c:70 ../vector/v.net.distance/main.c:82
+#: ../vector/v.net.allpairs/main.c:74 ../vector/v.net.connectivity/main.c:64
+#: ../vector/v.net.path/main.c:54 ../vector/v.net.iso/main.c:117
+#: ../vector/v.net.spanningtree/main.c:59 ../vector/v.net.steiner/main.c:368
+#: ../vector/v.net.flow/main.c:70 ../vector/v.net.timetable/main.c:274
+#: ../vector/v.net.bridge/main.c:60 ../vector/v.net.components/main.c:84
+#: ../vector/v.net.salesman/main.c:149 ../vector/v.net.centrality/main.c:109
+#: ../vector/v.net/args.c:56 ../vector/v.net.alloc/main.c:96
+msgid "Arc layer"
+msgstr ""
+#: ../display/d.path/main.c:75 ../vector/v.net.distance/main.c:95
+#: ../vector/v.net.allpairs/main.c:80 ../vector/v.net.connectivity/main.c:70
+#: ../vector/v.net.path/main.c:67 ../vector/v.net.iso/main.c:130
+#: ../vector/v.net.spanningtree/main.c:65 ../vector/v.net.flow/main.c:76
+#: ../vector/v.net.timetable/main.c:280 ../vector/v.net.bridge/main.c:66
+#: ../vector/v.net.components/main.c:90 ../vector/v.net.centrality/main.c:115
+#: ../vector/v.net/args.c:70 ../vector/v.net.alloc/main.c:109
+msgid "Node layer"
+msgstr ""
+#: ../display/d.path/main.c:81 ../vector/v.net.distance/main.c:141
+#: ../vector/v.net.allpairs/main.c:93 ../vector/v.net.connectivity/main.c:77
+#: ../vector/v.net.path/main.c:79 ../vector/v.net.iso/main.c:135
+#: ../vector/v.net.spanningtree/main.c:72 ../vector/v.net.flow/main.c:90
+#: ../vector/v.net.timetable/main.c:288 ../vector/v.net.bridge/main.c:73
+#: ../vector/v.net.components/main.c:97 ../vector/v.net.salesman/main.c:168
+#: ../vector/v.net.centrality/main.c:129 ../vector/v.net.alloc/main.c:114
+msgid "Arc forward/both direction(s) cost column (number)"
+msgstr ""
+#: ../display/d.path/main.c:87 ../vector/v.net.distance/main.c:147
+#: ../vector/v.net.allpairs/main.c:99 ../vector/v.net.connectivity/main.c:83
+#: ../vector/v.net.path/main.c:86 ../vector/v.net.iso/main.c:140
+#: ../vector/v.net.flow/main.c:96 ../vector/v.net.timetable/main.c:295
+#: ../vector/v.net.bridge/main.c:79 ../vector/v.net.components/main.c:103
+#: ../vector/v.net.centrality/main.c:135 ../vector/v.net.alloc/main.c:119
+msgid "Arc backward direction cost column (number)"
+msgstr ""
+#: ../display/d.path/main.c:93
+msgid "Node cost column"
+msgstr ""
+#: ../display/d.path/main.c:101 ../display/d.path/main.c:109
+#: ../display/d.path/main.c:117 ../display/d.path/main.c:127
+msgid "Rendering"
+msgstr ""
+#: ../display/d.path/main.c:122 ../vector/v.net.distance/main.c:159
+#: ../vector/v.net.allpairs/main.c:112 ../vector/v.net.path/main.c:132
+#: ../vector/v.net.iso/main.c:172 ../vector/v.net.spanningtree/main.c:84
+#: ../vector/v.net.steiner/main.c:398 ../vector/v.net.salesman/main.c:208
+#: ../vector/v.net.centrality/main.c:188 ../vector/v.net.alloc/main.c:151
+msgid "Use geodesic calculation for longitude-latitude locations"
+msgstr ""
+#: ../display/d.path/main.c:126
+msgid "Render bold lines"
+msgstr ""
+#: ../display/d.path/main.c:143 ../display/d.path/main.c:147
+#, c-format
+msgid "%s - illegal x value"
+msgstr ""
+#: ../display/d.path/main.c:145 ../display/d.path/main.c:149
+#, c-format
+msgid "%s - illegal y value"
+msgstr ""
+#: ../display/d.path/main.c:178 ../vector/v.net.distance/main.c:205
+#: ../vector/v.net.allpairs/main.c:142 ../vector/v.net.path/main.c:148
+#: ../vector/v.net.spanningtree/main.c:113
+#: ../vector/v.net.centrality/main.c:222
+msgid "The current projection is not longitude-latitude"
+msgstr ""
+#: ../display/d.path/select.c:84 ../display/d.path/select.c:101
+#, c-format
+msgid "Node %d: %f %f\n"
+msgstr ""
+#: ../display/d.path/select.c:122
+#, c-format
+msgid "Destination unreachable\n"
+msgstr ""
+#: ../display/d.path/select.c:125
+#, c-format
+msgid "Costs on the network = %f\n"
+msgstr ""
+#: ../display/d.path/select.c:126
+#, c-format
+msgid ""
+" Distance to the network = %f, distance from the network = %f\n"
+"\n"
+msgstr ""
+#: ../display/d.rast/main.c:56
+msgid "Displays user-specified raster map in the active graphics frame."
+msgstr ""
+#: ../display/d.rast/main.c:61
+msgid "Name of raster map to be displayed"
+msgstr ""
+#: ../display/d.rast/main.c:69
+msgid "List of categories or values to be displayed"
+msgstr ""
+#: ../display/d.rast/main.c:76
+msgid "Background color (for null)"
+msgstr ""
+#: ../display/d.rast/main.c:86
+msgid "Invert value list"
+msgstr ""
+#: ../display/d.rast/main.c:204
+#, c-format
+msgid "[%s]: illegal category specified"
+msgstr ""
+#: ../display/d.rast/main.c:235
+#, c-format
+msgid "[%s]: illegal value specified"
+msgstr ""
+#: ../display/d.northarrow/main.c:49
+msgid "Displays a north arrow on the graphics monitor."
+msgstr ""
+#: ../display/d.northarrow/main.c:53
+msgid "North arrow style"
+msgstr ""
+#: ../display/d.northarrow/main.c:61
+msgid "Two color arrowhead"
+msgstr ""
+#: ../display/d.northarrow/main.c:62
+msgid "Two color arrowhead with circle"
+msgstr ""
+#: ../display/d.northarrow/main.c:63
+msgid "Narrow with blending N"
+msgstr ""
+msgid "Long with small arrowhead"
+msgstr ""
+#: ../display/d.northarrow/main.c:64
+msgid "Inverted narrow inside a circle"
+msgstr ""
+#: ../display/d.northarrow/main.c:65
+msgid "Triangle and N inside a circle"
+msgstr ""
+#: ../display/d.northarrow/main.c:66
+msgid "Arrowhead and N inside a circle"
+msgstr ""
+#: ../display/d.northarrow/main.c:67
+msgid "Tall half convex arrowhead"
+msgstr ""
+#: ../display/d.northarrow/main.c:68
+msgid "Tall half concave arrowhead"
+msgstr ""
+msgid "Thin arrow in a circle"
+msgstr ""
+#: ../display/d.northarrow/main.c:69
+msgid "Fat arrow in a circle"
+msgstr ""
+msgid "One color arrowhead"
+msgstr ""
+#: ../display/d.northarrow/main.c:70
+msgid "Fancy compass"
+msgstr ""
+msgid "Basic compass"
+msgstr ""
+msgid "Simple arrow"
+msgstr ""
+#: ../display/d.northarrow/main.c:71
+msgid "Thin arrow"
+msgstr ""
+msgid "Fat arrow"
+msgstr ""
+msgid "4-point star"
+msgstr ""
+#: ../display/d.northarrow/main.c:99
+msgid "Displayed letter on the top of arrow"
+msgstr ""
+#: ../display/d.northarrow/main.c:108
+msgid "Fill color"
+msgstr ""
+#: ../display/d.northarrow/main.c:121 ../display/d.vect/main.c:146
+msgid "Line width"
+msgstr ""
+#: ../display/d.northarrow/main.c:134
+msgid "Draw the symbol without text"
+msgstr ""
+#: ../display/d.northarrow/main.c:139
+msgid "Do not rotate text with symbol"
+msgstr ""
+#: ../display/d.northarrow/draw_n_arrow.c:108
+#: ../display/d.northarrow/draw_n_arrow.c:174
+msgid "Could not parse symbol"
+msgstr ""
+#: ../display/d.erase/main.c:33
+msgid "Erases the contents of the active graphics display frame with user defined color."
+msgstr ""
+#: ../display/d.erase/main.c:42
+msgid "Remove all frames and erase the screen"
+msgstr ""
+#: ../display/d.where/where.c:29
+#, c-format
+msgid "Invalid coordinates <%s,%s>"
+msgstr ""
+#: ../display/d.where/main.c:48
+msgid "Identifies the geographic coordinates associated with point locations given in display coordinates."
+msgstr ""
+#: ../display/d.where/main.c:58
+msgid "Display coordinates to convert"
+msgstr ""
+#: ../display/d.where/main.c:63
+msgid "File from which to read coordinates (\"-\" to read from stdin)"
+msgstr ""
+#: ../display/d.where/main.c:67
+msgid "Output lat/long in decimal degree"
+msgstr ""
+#: ../display/d.where/main.c:72
+msgid "Output lat/long referenced to current ellipsoid"
+msgstr ""
+#: ../display/d.where/main.c:77
+msgid "Output lat/long referenced to WGS84 ellipsoid using datum transformation parameters defined in current location (if available)"
+msgstr ""
+#: ../display/d.where/main.c:83
+msgid "Output frame coordinates of current display monitor (percentage)"
+msgstr ""
+#: ../display/d.where/main.c:91
+msgid "Ambiguous request for lat/long ellipsoids"
+msgstr ""
+#: ../display/d.where/main.c:94
+msgid "Please specify a lat/long ellipsoid with -l or -w"
+msgstr ""
+#: ../display/d.where/main.c:136
+msgid ""
+"WGS84 output not possible as this location does not contain\n"
+msgstr ""
+#: ../display/d.font/main.c:48
+msgid "Selects the font in which text will be displayed on the user's graphics monitor."
+msgstr ""
+#: ../display/d.font/main.c:56
+msgid "Choose new current font"
+msgstr ""
+#: ../display/d.font/main.c:62
+msgid "Path to Freetype-compatible font including file name"
+msgstr ""
+#: ../display/d.font/main.c:70
+msgid "Character encoding"
+msgstr ""
+#: ../display/d.font/main.c:74
+msgid "List fonts"
+msgstr ""
+#: ../display/d.font/main.c:103
+#, c-format
+msgid "Unable to access font path %s: %s"
+msgstr ""
+#: ../display/d.font/main.c:107
+#, c-format
+msgid "Font path %s is not a file"
+msgstr ""
+#: ../display/d.font/main.c:124
+#, c-format
+msgid "Font name <%s> is invalid. Check font name or consider running 'g.mkfontcap'"
+msgstr ""
+#: ../display/d.histogram/main.c:84
+msgid "histogram"
+msgstr ""
+#: ../display/d.histogram/main.c:87
+msgid "Displays a histogram in the form of a pie or bar chart for a user-specified raster map."
+msgstr ""
+#: ../display/d.histogram/main.c:91
+msgid "Raster map for which histogram will be displayed"
+msgstr ""
+#: ../display/d.histogram/main.c:95
+msgid "Indicate if a pie or bar chart is desired"
+msgstr ""
+#: ../display/d.histogram/main.c:104
+msgid "Color for text and axes"
+msgstr ""
+#: ../display/d.histogram/main.c:115
+msgid "Indicate if cell counts or map areas should be displayed"
+msgstr ""
+#: ../display/d.histogram/main.c:125
+msgid "Number of steps to divide the data range into (fp maps only)"
+msgstr ""
+#: ../display/d.histogram/main.c:132
+msgid "Display information for null cells"
+msgstr ""
+#: ../display/d.histogram/main.c:137
+msgid "Report for ranges defined in cats file (fp maps only)"
+msgstr ""
+#: ../display/d.histogram/main.c:161
+#, c-format
+msgid "Invalid number of steps: %s"
+msgstr ""
+#: ../display/d.histogram/main.c:166
+msgid "When -C flag is set, the nsteps argument is ignored"
+msgstr ""
+#: ../display/d.vect/main.c:77
+msgid "Displays user-specified vector map in the active graphics frame."
+msgstr ""
+#: ../display/d.vect/main.c:93
+msgid "Display"
+msgstr ""
+#: ../display/d.vect/main.c:97
+msgid "Display geometry of features"
+msgstr ""
+#: ../display/d.vect/main.c:98
+msgid "Display category numbers of features"
+msgstr ""
+#: ../display/d.vect/main.c:99
+msgid "Display topology information (nodes, edges)"
+msgstr ""
+#: ../display/d.vect/main.c:100
+msgid "Display vertices of features"
+msgstr ""
+#: ../display/d.vect/main.c:101
+msgid "Display direction of linear features"
+msgstr ""
+#: ../display/d.vect/main.c:102
+msgid "Display z-coordinate of features (only for 3D vector maps)"
+msgstr ""
+#: ../display/d.vect/main.c:120
+msgid "Feature color"
+msgstr ""
+#: ../display/d.vect/main.c:126
+msgid "Area fill color"
+msgstr ""
+#: ../display/d.vect/main.c:132
+msgid "Colorize features according to color definition column"
+msgstr ""
+#: ../display/d.vect/main.c:133 ../vector/v.out.lidar/main.c:544
+msgid "Color definition in R:G:B form"
+msgstr ""
+#: ../display/d.vect/main.c:137
+msgid "Colorize point or area features according to z-coordinate"
+msgstr ""
+#: ../display/d.vect/main.c:145 ../display/d.vect/main.c:150
+#: ../display/d.vect/main.c:158
+msgid "Lines"
+msgstr ""
+#: ../display/d.vect/main.c:151
+msgid "Name of numeric column containing line width"
+msgstr ""
+#: ../display/d.vect/main.c:152
+msgid "These values will be scaled by width_scale"
+msgstr ""
+#: ../display/d.vect/main.c:159
+msgid "Scale factor for width_column"
+msgstr ""
+#: ../display/d.vect/main.c:180
+msgid "When used with the size_column option this becomes the scale factor"
+msgstr ""
+#: ../display/d.vect/main.c:186
+msgid "Name of numeric column containing symbol size"
+msgstr ""
+#: ../display/d.vect/main.c:192
+msgid "Name of numeric column containing symbol rotation angle"
+msgstr ""
+#: ../display/d.vect/main.c:194
+msgid "Measured in degrees CCW from east"
+msgstr ""
+#: ../display/d.vect/main.c:204
+msgid "Area/boundary symbol for legend"
+msgstr ""
+#: ../display/d.vect/main.c:214
+msgid "Line symbol for legend"
+msgstr ""
+#: ../display/d.vect/main.c:220
+msgid "Label to display after symbol in vector legend"
+msgstr ""
+#: ../display/d.vect/main.c:226 ../display/d.vect/main.c:233
+#: ../display/d.vect/main.c:240 ../display/d.vect/main.c:245
+#: ../display/d.vect/main.c:252 ../display/d.vect/main.c:259
+#: ../display/d.vect/main.c:265 ../display/d.vect/main.c:271
+#: ../display/d.vect/main.c:277 ../display/d.vect/main.c:285
+msgid "Labels"
+msgstr ""
+#: ../display/d.vect/main.c:228
+msgid "Layer number for labels (default: the given layer number)"
+msgstr ""
+#: ../display/d.vect/main.c:234
+msgid "Name of column to be displayed as a label"
+msgstr ""
+#: ../display/d.vect/main.c:239
+msgid "Label color"
+msgstr ""
+#: ../display/d.vect/main.c:246
+msgid "Label background color"
+msgstr ""
+#: ../display/d.vect/main.c:253
+msgid "Label border color"
+msgstr ""
+#: ../display/d.vect/main.c:260
+msgid "Label size (pixels)"
+msgstr ""
+#: ../display/d.vect/main.c:272
+msgid "Text encoding"
+msgstr ""
+#: ../display/d.vect/main.c:280
+msgid "Label horizontal justification"
+msgstr ""
+#: ../display/d.vect/main.c:288
+msgid "Label vertical justification"
+msgstr ""
+#: ../display/d.vect/main.c:295
+msgid "Minimum region size (average from height and width) when map is displayed"
+msgstr ""
+#: ../display/d.vect/main.c:303
+msgid "Maximum region size (average from height and width) when map is displayed"
+msgstr ""
+#: ../display/d.vect/main.c:311
+msgid "Random colors according to category number (or layer number if 'layer=-1' is given)"
+msgstr ""
+#: ../display/d.vect/main.c:318
+msgid "Use values from 'cats' option as feature id"
+msgstr ""
+#: ../display/d.vect/main.c:322
+msgid "Use square root of the value of size_column"
+msgstr ""
+#: ../display/d.vect/main.c:324
+msgid "This makes circle areas proportionate to the size_column values instead of circle radius"
+msgstr ""
+#: ../display/d.vect/main.c:349
+msgid "Region size is lower than minreg, nothing displayed"
+msgstr ""
+#: ../display/d.vect/main.c:357
+msgid "Region size is greater than maxreg, nothing displayed"
+msgstr ""
+#: ../display/d.vect/main.c:370
+#, c-format
+msgid "The -%c flag and <%s> option cannot be used together, the -%c flag will be ignored!"
+msgstr ""
+#: ../display/d.vect/main.c:394 ../display/d.vect/main.c:400
+#, c-format
+msgid "Option <%s> must be > 0"
+msgstr ""
+#: ../display/d.vect/main.c:404
+#, c-format
+msgid "%d error in cat option"
+msgid_plural "%d errors in cat option"
+msgstr[0] ""
+msgstr[1] ""
+#: ../display/d.vect/main.c:420
+msgid "Plotting..."
+msgstr ""
+#: ../display/d.vect/main.c:431
+msgid "The bounding box of the map is outside the current region, nothing drawn"
+msgstr ""
+#: ../display/d.vect/main.c:502
+msgid "Rendering failed"
+msgstr ""
+#: ../display/d.vect/lines.c:121
+msgid "Unable to display features by id, topology not available. Please try to rebuild topology using v.build or v.build.all."
+msgstr ""
+#: ../display/d.vect/lines.c:169
+#, c-format
+msgid "%d invalid color rule for lines skipped"
+msgid_plural "%d invalid color rules for lines skipped"
+msgstr[0] ""
+msgstr[1] ""
+#: ../display/d.vect/shape.c:53
+#, c-format
+msgid "Both color table and <%s> option detected. Color table will ignored."
+msgstr ""
+#: ../display/d.vect/shape.c:68
+#, c-format
+msgid "Color definition column ('%s') not a string. Column must be of form 'RRR:GGG:BBB' where RGB values range 0-255. You can use '%s' module to define color rules. Unable to colorize features."
+msgstr ""
+#: ../display/d.vect/shape.c:77 ../display/d.vect/shape.c:100
+#: ../display/d.vect/shape.c:131 ../display/d.vect/shape.c:162
+#, c-format
+msgid "Unable to select data ('%s') from table"
+msgstr ""
+#: ../display/d.vect/shape.c:85
+msgid "Line width column not specified"
+msgstr ""
+#: ../display/d.vect/shape.c:96
+#, c-format
+msgid "Line width column ('%s') not a number"
+msgstr ""
+#: ../display/d.vect/shape.c:116
+msgid "Symbol size column not specified"
+msgstr ""
+#: ../display/d.vect/shape.c:127
+#, c-format
+msgid "Symbol size column ('%s') is not numeric"
+msgstr ""
+#: ../display/d.vect/shape.c:147
+msgid "Symbol rotation column not specified"
+msgstr ""
+#: ../display/d.vect/shape.c:158
+#, c-format
+msgid "Symbol rotation column ('%s') is not numeric"
+msgstr ""
+#: ../display/d.vect/shape.c:182
+msgid "Vector map is not 3D. Unable to colorize features based on z-coordinates."
+msgstr ""
+#: ../display/d.vect/shape.c:201
+msgid "Unable to colorize features, unknown map bounding box"
+msgstr ""
+#: ../display/d.vect/shape.c:338
+#, c-format
+msgid "Invalid negative value - feature %d with category %d"
+msgstr ""
+#: ../display/d.vect/label.c:33
+msgid "Topology level required for drawing centroids for OGR layers"
+msgstr ""
+#: ../display/d.vect/zcoor.c:19
+msgid "Vector map is not 3D. Unable to display z-coordinates."
+msgstr ""
+#: ../display/d.vect/topo.c:18
+msgid "Unable to display topology, not available.Please try to rebuild topology using v.build or v.build.all."
+msgstr ""
+#: ../display/d.vect/attr.c:28
+msgid "attrcol not specified, cannot display attributes"
+msgstr ""
+#: ../display/d.vect/attr.c:129
+#, c-format
+msgid "No attribute found for cat %d: %s"
+msgstr ""
+#: ../display/d.vect/area.c:37
+msgid "Unable to display areas, topology not available. Please try to rebuild topology using v.build or v.build.all."
+msgstr ""
+#: ../display/d.vect/area.c:135
+#, c-format
+msgid "Invalid area %d skipped (not enough points)"
+msgstr ""
+#: ../display/d.vect/area.c:234
+#, c-format
+msgid "%d invalid color rule for areas skipped"
+msgid_plural "%d invalid color rules for areas skipped"
+msgstr[0] ""
+msgstr[1] ""
+#: ../display/d.vect/opt.c:126
+#, c-format
+msgid "Unknown color: '%s'"
+msgstr ""
+#: ../display/d.profile/main.c:68
+#, c-format
+msgid "Unable to read range for %s"
+msgstr ""
+#: ../display/d.profile/main.c:79
+#, c-format
+msgid "Unable to read FP range for %s"
+msgstr ""
+#: ../display/d.profile/main.c:194
+msgid "Plots profile of a transect."
+msgstr ""
+#: ../display/d.profile/main.c:198
+msgid "Raster map to be profiled"
+msgstr ""
+#: ../display/d.profile/main.c:207
+msgid "Use map's range recorded range"
+msgstr ""
+#: ../display/d.profile/main.c:256
+msgid "At least two points are required"
+msgstr ""
+#: ../display/d.title/main.c:52
+msgid "Create a TITLE for a raster map in a form suitable for display with d.text."
+msgstr ""
+#: ../display/d.title/main.c:63
+msgid "Sets the text color"
+msgstr ""
+#: ../display/d.title/main.c:71
+msgid "Sets the text size as percentage of the frame's height"
+msgstr ""
+#: ../display/d.title/main.c:75
+msgid "Draw title on current display"
+msgstr ""
+#: ../display/d.title/main.c:79
+msgid "Do a fancier title"
+msgstr ""
+#: ../display/d.title/main.c:84
+msgid "Do a simple title"
+msgstr ""
+#: ../display/d.title/main.c:102
+msgid "Title can be fancy or simple, not both"
+msgstr ""
+#: ../display/d.title/main.c:105
+msgid "No map name given"
+msgstr ""
+#: ../display/d.rast.arrow/main.c:101
+msgid "Draws arrows representing cell aspect direction for a raster map containing aspect data."
+msgstr ""
+#: ../display/d.rast.arrow/main.c:105
+msgid "Name of raster aspect map to be displayed"
+msgstr ""
+#: ../display/d.rast.arrow/main.c:113
+msgid "Type of existing raster aspect map"
+msgstr ""
+#: ../display/d.rast.arrow/main.c:118
+msgid "Color for drawing arrows"
+msgstr ""
+#: ../display/d.rast.arrow/main.c:124
+msgid "Color for drawing drawing grid"
+msgstr ""
+#: ../display/d.rast.arrow/main.c:130
+msgid "Color for drawing null values (X symbol)"
+msgstr ""
+#: ../display/d.rast.arrow/main.c:136
+msgid "Color for showing unknown information (? symbol)"
+msgstr ""
+#: ../display/d.rast.arrow/main.c:144
+msgid "Draw arrow every Nth grid cell"
+msgstr ""
+#: ../display/d.rast.arrow/main.c:153
+msgid "Raster map containing values used for arrow length"
+msgstr ""
+#: ../display/d.rast.arrow/main.c:160
+msgid "Scale factor for arrows (magnitude map)"
+msgstr ""
+#: ../display/d.rast.arrow/main.c:210
+msgid "Illegal value for scale factor"
+msgstr ""
+#: ../display/d.rast.arrow/main.c:214
+msgid "Illegal value for skip factor"
+msgstr ""
+#: ../display/d.rast.arrow/main.c:219
+msgid "Magnitude is only supported for GRASS and compass aspect maps."
+msgstr ""
+#: ../display/d.rast.arrow/main.c:224
+msgid "Scale option requires magnitude_map"
+msgstr ""
+#: ../display/d.rast.arrow/main.c:275
+msgid "Problem reading range file"
+msgstr ""
+#: ../raster3d/r3.support/main.c:52
+msgid "Allows creation and/or modification of 3D raster map layer support files."
+msgstr ""
+#: ../raster3d/r3.support/main.c:62
+msgid "Text to use for map title"
+msgstr ""
+#: ../raster3d/r3.support/main.c:76
+msgid "The map data unit"
+msgstr ""
+#: ../raster3d/r3.support/main.c:82
+msgid "The vertical unit of the map"
+msgstr ""
+#: ../raster3d/r3.support/main.c:125
+msgid "Update range"
+msgstr ""
+#: ../raster3d/r3.support/check.c:20
+#, c-format
+msgid "Updating statistics for <%s>"
+msgstr ""
+#: ../raster3d/r3.support/check.c:36
+#, c-format
+msgid "Updating the number of categories for <%s>"
+msgstr ""
+#: ../raster3d/r3.gwflow/main.c:54
+msgid "Input 3D raster map with initial piezometric heads in [m]"
+msgstr ""
+#: ../raster3d/r3.gwflow/main.c:60
+msgid "Input 3D raster map providing the status for each cell, = 0 - inactive, 1 - active, 2 - dirichlet"
+msgstr ""
+#: ../raster3d/r3.gwflow/main.c:65
+msgid "Input 3D raster map with the x-part of the hydraulic conductivity tensor in [m/s]"
+msgstr ""
+#: ../raster3d/r3.gwflow/main.c:70
+msgid "Input 3D raster map with the y-part of the hydraulic conductivity tensor in [m/s]"
+msgstr ""
+#: ../raster3d/r3.gwflow/main.c:75
+msgid "Input 3D raster map with the z-part of the hydraulic conductivity tensor in [m/s]"
+msgstr ""
+#: ../raster3d/r3.gwflow/main.c:80
+msgid "Input 3D raster map with sources and sinks in [m^3/s]"
+msgstr ""
+#: ../raster3d/r3.gwflow/main.c:84
+msgid "Specific yield [1/m] input 3D raster map"
+msgstr ""
+#: ../raster3d/r3.gwflow/main.c:89
+msgid "Recharge input 3D raster map in m^3/s"
+msgstr ""
+#: ../raster3d/r3.gwflow/main.c:93
+msgid "Output 3D raster map storing the piezometric head result of the numerical calculation"
+msgstr ""
+#: ../raster3d/r3.gwflow/main.c:99
+msgid "Output 3D raster map storing the groundwater filter velocity vector part in x direction [m/s]"
+msgstr ""
+#: ../raster3d/r3.gwflow/main.c:105
+msgid "Output 3D raster map storing the groundwater filter velocity vector part in y direction [m/s]"
+msgstr ""
+#: ../raster3d/r3.gwflow/main.c:111
+msgid "Output 3D raster map storing the groundwater filter velocity vector part in z direction [m/s]"
+msgstr ""
+#: ../raster3d/r3.gwflow/main.c:117
+msgid "Output 3D raster map storing the groundwater budget for each cell [m^3/s]"
+msgstr ""
+#: ../raster3d/r3.gwflow/main.c:127
+msgid "Use 3D raster mask (if exists)"
+msgstr ""
+#: ../raster3d/r3.gwflow/main.c:163
+msgid "Numerical calculation program for transient, confined groundwater flow in three dimensions."
+msgstr ""
+#: ../raster3d/r3.gwflow/main.c:180
+msgid ""
+"The cholesky solver does not work with sparse matrices.\n"
+"Consider to choose a full filled quadratic matrix with flag -f "
+msgstr ""
+#: ../raster3d/r3.gwflow/main.c:365 ../raster3d/r3.in.lidar/main.c:484
+#: ../raster3d/r3.in.lidar/main.c:493 ../raster3d/r3.in.lidar/main.c:501
+#: ../raster3d/r3.in.lidar/main.c:509 ../raster3d/r3.in.lidar/main.c:517
+#: ../raster3d/r3.in.lidar/main.c:527 ../raster3d/r3.in.lidar/main.c:536
+#, c-format
+msgid "Unable to create 3D raster map <%s>"
+msgstr ""
+#: ../raster3d/r3.gwflow/main.c:412 ../raster3d/r3.out.netcdf/main.c:649
+#: ../raster3d/r3.out.vtk/main.c:252 ../raster3d/r3.out.vtk/main.c:338
+#: ../raster3d/r3.in.v5d/main.c:206 ../raster3d/r3.cross.rast/main.c:55
+#: ../raster3d/r3.out.v5d/main.c:55 ../raster3d/r3.out.v5d/main.c:326
+#: ../raster3d/r3.in.bin/main.c:471 ../raster3d/r3.to.rast/main.c:75
+#: ../raster3d/r3.to.rast/main.c:445 ../raster3d/r3.out.ascii/main.c:63
+#: ../raster3d/r3.out.ascii/main.c:367 ../raster3d/r3.in.ascii/main.c:393
+msgid "Unable to close 3D raster map"
+msgstr ""
+#: ../raster3d/r3.out.netcdf/main.c:81
+#, c-format
+msgid "Unable to close 3D raster map while catching error: %s"
+msgstr ""
+#: ../raster3d/r3.out.netcdf/main.c:97
+msgid "Name for netCDF output file"
+msgstr ""
+#: ../raster3d/r3.out.netcdf/main.c:106
+msgid "The value to be used for null values, default is the netCDF standard"
+msgstr ""
+#: ../raster3d/r3.out.netcdf/main.c:111
+msgid "Export projection information as wkt and proj4 parameter"
+msgstr ""
+#: ../raster3d/r3.out.netcdf/main.c:588
+msgid "netCDF"
+msgstr ""
+#: ../raster3d/r3.out.netcdf/main.c:590
+msgid "Export a 3D raster map as netCDF file."
+msgstr ""
+#: ../raster3d/r3.retile/main.c:49
+msgid "Unable to close the 3D raster map"
+msgstr ""
+#: ../raster3d/r3.retile/main.c:71
+msgid "Name of the retiled 3D raster map"
+msgstr ""
+#: ../raster3d/r3.retile/main.c:99
+msgid "Retiles an existing 3D raster map with user defined x, y and z tile size."
+msgstr ""
+#: ../raster3d/r3.retile/main.c:135
+msgid "Rast3d_get_standard3d_params: tile dimension value invalid"
+msgstr ""
+#: ../raster3d/r3.retile/main.c:148
+msgid "Error closing 3D raster map"
+msgstr ""
+#: ../raster3d/r3.neighbors/main.c:137
+msgid "The size of the window in x, y and z direction, values must be odd integer numbers, eg: 3,3,3"
+msgstr ""
+#: ../raster3d/r3.neighbors/main.c:218
+msgid "Makes each voxel value a function of the values assigned to the voxels around it, and stores new voxel values in an output 3D raster map"
+msgstr ""
+#: ../raster3d/r3.neighbors/main.c:287
+msgid "Unable to allocate buffer"
+msgstr ""
+#: ../raster3d/r3.neighbors/main.c:311 ../raster3d/r3.in.bin/main.c:202
+msgid "Error flushing tiles"
+msgstr ""
+#: ../raster3d/r3.out.vtk/main.c:117
+msgid "Specify top and bottom map"
+msgstr ""
+#: ../raster3d/r3.out.vtk/main.c:124
+#, c-format
+msgid "Top cell map <%s> not found"
+msgstr ""
+#: ../raster3d/r3.out.vtk/main.c:133
+#, c-format
+msgid "Bottom cell map <%s> not found"
+msgstr ""
+#: ../raster3d/r3.out.vtk/main.c:152
+#, c-format
+msgid "3D raster map RGB map <%s> not found"
+msgstr ""
+#: ../raster3d/r3.out.vtk/main.c:155
+msgid "Please provide three RGB 3D raster maps"
+msgstr ""
+#: ../raster3d/r3.out.vtk/main.c:165
+#, c-format
+msgid "3D vector map <%s> not found"
+msgstr ""
+#: ../raster3d/r3.out.vtk/main.c:168
+msgid "Please provide three 3D raster maps for the xyz-vector maps [x,y,z]"
+msgstr ""
+#: ../raster3d/r3.out.vtk/main.c:175
+msgid "No 3D raster data, RGB or xyz-vector maps are provided! Will only write the geometry."
+msgstr ""
+#: ../raster3d/r3.out.vtk/main.c:209
+msgid "No RGB Data will be created."
+msgstr ""
+#: ../raster3d/r3.out.vtk/main.c:294
+msgid "No vector data will be created."
+msgstr ""
+#: ../raster3d/r3.out.vtk/main.c:381
+msgid "Converts 3D raster maps into the VTK-ASCII format."
+msgstr ""
+#: ../raster3d/r3.out.vtk/main.c:392
+msgid "failed to interpret dp as an integer"
+msgstr ""
+#: ../raster3d/r3.out.vtk/main.c:451 ../raster3d/r3.to.rast/main.c:332
+msgid "The 2D and 3D region settings are different. Using the 2D window settings to adjust the 2D part of the 3D region."
+msgstr ""
+#: ../raster3d/r3.out.vtk/main.c:542
+msgid "Unable to close 3D raster map, the VTK file may be incomplete"
+msgstr ""
+#: ../raster3d/r3.out.vtk/main.c:557
+msgid "Unable to close VTK-ASCII file"
+msgstr ""
+#: ../raster3d/r3.out.vtk/errorHandling.c:65
+#: ../raster3d/r3.cross.rast/main.c:343 ../raster3d/r3.info/main.c:499
+#: ../raster3d/r3.null/main.c:163
+#, c-format
+msgid "Unable to close 3D raster map <%s>"
+msgstr ""
+#: ../raster3d/r3.out.vtk/errorHandling.c:105
+msgid "Unable to close input raster maps"
+msgstr ""
+#: ../raster3d/r3.out.vtk/writeVTKData.c:122
+msgid "write_vtk_points: Writing point coordinates"
+msgstr ""
+#: ../raster3d/r3.out.vtk/writeVTKData.c:256
+msgid "write_vtk_unstructured_grid_cells: Writing the cells"
+msgstr ""
+#: ../raster3d/r3.out.vtk/writeVTKData.c:335
+#, c-format
+msgid "write_vtk_data: Writing Celldata %s with rows %i cols %i depths %i to vtk-ascii file"
+msgstr ""
+#: ../raster3d/r3.out.vtk/writeVTKData.c:441
+msgid "Wrong 3D raster map values! Values should in between 0 and 255!"
+msgstr ""
+#: ../raster3d/r3.out.vtk/parameters.c:30
+msgid "3D raster map(s) to be converted to VTK-ASCII data format"
+msgstr ""
+#: ../raster3d/r3.out.vtk/parameters.c:41
+msgid "Float value to represent no data cell/points"
+msgstr ""
+#: ../raster3d/r3.out.vtk/parameters.c:47
+msgid "Create VTK pointdata instead of VTK celldata (celldata is default)"
+msgstr ""
+#: ../raster3d/r3.out.vtk/parameters.c:56
+msgid "Top surface 2D raster map"
+msgstr ""
+#: ../raster3d/r3.out.vtk/parameters.c:65
+msgid "Bottom surface 2D raster map"
+msgstr ""
+#: ../raster3d/r3.out.vtk/parameters.c:71
+msgid "Create 3D elevation output with a top and a bottom surface, both raster maps are required."
+msgstr ""
+#: ../raster3d/r3.out.vtk/parameters.c:80
+msgid "Three (R,G,B) 3D raster maps to create RGB values [redmap,greenmap,bluemap]"
+msgstr ""
+#: ../raster3d/r3.out.vtk/parameters.c:88
+msgid "Three (x,y,z) 3D raster maps to create vector values [xmap,ymap,zmap]"
+msgstr ""
+#: ../raster3d/r3.out.vtk/parameters.c:112
+msgid "Use 3D raster mask (if exists) with input maps"
+msgstr ""
+#: ../raster3d/r3.out.vtk/parameters.c:117
+msgid "Scale factor affects the origin"
+msgstr ""
+#: ../raster3d/r3.out.vtk/parameters.c:129
+msgid "Do not convert the top-bottom resolution in case of lat long projection to meters"
+msgstr ""
+#: ../raster3d/r3.mkdspf/main.c:83
+msgid "Creates a display file from an existing 3D raster map according to specified threshold levels."
+msgstr ""
+#: ../raster3d/r3.mkdspf/main.c:91
+msgid "Name of an existing 3D raster map"
+msgstr ""
+#: ../raster3d/r3.mkdspf/main.c:96
+msgid "Name for output display file"
+msgstr ""
+#: ../raster3d/r3.mkdspf/main.c:103
+msgid "List of thresholds for isosurfaces"
+msgstr ""
+#: ../raster3d/r3.mkdspf/main.c:109
+msgid "Minimum isosurface level"
+msgstr ""
+#: ../raster3d/r3.mkdspf/main.c:115
+msgid "Maximum isosurface level"
+msgstr ""
+#: ../raster3d/r3.mkdspf/main.c:121
+msgid "Positive increment between isosurface levels"
+msgstr ""
+#: ../raster3d/r3.mkdspf/main.c:128
+msgid "Number of isosurface threshold levels"
+msgstr ""
+#: ../raster3d/r3.mkdspf/main.c:132
+msgid "Suppress progress report & min/max information"
+msgstr ""
+#: ../raster3d/r3.mkdspf/main.c:136
+msgid "Use flat shading rather than gradient"
+msgstr ""
+#: ../raster3d/r3.mkdspf/main.c:144
+#, c-format
+msgid "Region from getWindow: %d %d %d"
+msgstr ""
+#: ../raster3d/r3.mkdspf/main.c:156
+#, c-format
+msgid "Not able to find grid3 file for [%s]"
+msgstr ""
+#: ../raster3d/r3.mkdspf/main.c:171 ../raster3d/r3.info/main.c:328
+#: ../raster3d/r3.info/main.c:448
+#, c-format
+msgid "Unable to read range of 3D raster map <%s>"
+msgstr ""
+#: ../raster3d/r3.mkdspf/main.c:200
+#, c-format
+msgid "Unable to open display file <%s>"
+msgstr ""
+#: ../raster3d/r3.mkdspf/main.c:221
+#, c-format
+msgid "Writing %s from %s..."
+msgstr ""
+#: ../raster3d/r3.mask/main.c:75
+msgid "Unable to open 3D raster mask file"
+msgstr ""
+#: ../raster3d/r3.mask/main.c:104
+msgid "makeMask: error flushing tiles in cube"
+msgstr ""
+#: ../raster3d/r3.mask/main.c:109
+msgid "makeMask: error flushing all tiles"
+msgstr ""
+#: ../raster3d/r3.mask/main.c:117
+msgid "Unable to close 3D raster mask file"
+msgstr ""
+#: ../raster3d/r3.mask/main.c:119
+#, c-format
+msgid "Unable to close raster map <%s>"
+msgstr ""
+#: ../raster3d/r3.mask/main.c:137
+msgid "Establishes the current working 3D raster mask."
+msgstr ""
+#: ../raster3d/r3.mask/main.c:145
+msgid "3D raster map with reference values"
+msgstr ""
+#: ../raster3d/r3.mask/main.c:153
+msgid "List of cell values to be masked out"
+msgstr ""
+#: ../raster3d/r3.mask/main.c:159
+msgid "Cannot create mask file: RASTER3D_MASK already exists"
+msgstr ""
+#: ../raster3d/r3.in.v5d/main.c:66
+msgid "Name of V5D raster file to be imported"
+msgstr ""
+#: ../raster3d/r3.in.v5d/main.c:182
+msgid "Import 3-dimensional Vis5D files."
+msgstr ""
+#: ../raster3d/r3.in.v5d/main.c:201 ../raster3d/r3.in.bin/main.c:463
+#: ../raster3d/r3.in.ascii/main.c:387
+msgid "Unable to open 3D raster map"
+msgstr ""
+#: ../raster3d/r3.out.bin/main.c:208
+msgid "Exports a GRASS 3D raster map to a binary array."
+msgstr ""
+#: ../raster3d/r3.out.bin/main.c:228 ../raster3d/r3.in.bin/main.c:268
+msgid "Number of bytes per cell in binary file"
+msgstr ""
+#: ../raster3d/r3.out.bin/main.c:240 ../raster3d/r3.in.bin/main.c:354
+#: ../raster3d/r3.out.ascii/main.c:106
+msgid "Switch the row order in output from north->south to south->north"
+msgstr ""
+#: ../raster3d/r3.out.bin/main.c:245 ../raster3d/r3.in.bin/main.c:359
+#: ../raster3d/r3.out.ascii/main.c:110
+msgid "Switch the depth order in output from bottom->top to top->bottom"
+msgstr ""
+#: ../raster3d/r3.out.bin/main.c:250
+msgid "Write data as integer"
+msgstr ""
+#: ../raster3d/r3.out.bin/main.c:269
+msgid "Floating-point output requires bytes=4 or bytes=8"
+msgstr ""
+#: ../raster3d/r3.out.bin/main.c:273
+msgid "Integer output doesn't support bytes=8 in this build"
+msgstr ""
+#: ../raster3d/r3.out.bin/main.c:328
+#, c-format
+msgid "top=%f"
+msgstr ""
+#: ../raster3d/r3.out.bin/main.c:329
+#, c-format
+msgid "bottom=%f"
+msgstr ""
+#: ../raster3d/r3.out.bin/main.c:332
+#, c-format
+msgid "depths=%d"
+msgstr ""
+#: ../raster3d/r3.flow/main.c:91
+msgid "Please provide three 3D raster maps"
+msgstr ""
+#: ../raster3d/r3.flow/main.c:98
+#, c-format
+msgid "Vector seed map <%s> not found"
+msgstr ""
+#: ../raster3d/r3.flow/main.c:147
+msgid "init_flowaccum: error in Rast3d_put_float"
+msgstr ""
+#: ../raster3d/r3.flow/main.c:183
+msgid "Computes 3D flow lines and 3D flow accumulation."
+msgstr ""
+#: ../raster3d/r3.flow/main.c:193
+msgid "Names of three 3D raster maps describing x, y, z components of vector field"
+msgstr ""
+#: ../raster3d/r3.flow/main.c:200
+msgid "If no map is provided, flow lines are generated from each cell of the input 3D raster"
+msgstr ""
+#: ../raster3d/r3.flow/main.c:203
+msgid "Name of vector map with points from which flow lines are generated"
+msgstr ""
+#: ../raster3d/r3.flow/main.c:210
+msgid "Name for vector map of flow lines"
+msgstr ""
+#: ../raster3d/r3.flow/main.c:217
+msgid "Name for output flowaccumulation 3D raster"
+msgstr ""
+#: ../raster3d/r3.flow/main.c:224
+msgid "Name for 3D raster sampled by flowlines"
+msgstr ""
+#: ../raster3d/r3.flow/main.c:226
+msgid "Values of this 3D raster will be stored as attributes of flowlines segments"
+msgstr ""
+#: ../raster3d/r3.flow/main.c:240
+msgid "elapsed time"
+msgstr ""
+#: ../raster3d/r3.flow/main.c:241
+msgid "length in map units"
+msgstr ""
+msgid "length in cells (voxels)"
+msgstr ""
+#: ../raster3d/r3.flow/main.c:243
+msgid "Unit of integration step"
+msgstr ""
+#: ../raster3d/r3.flow/main.c:244
+msgid "Default unit is cell"
+msgstr ""
+#: ../raster3d/r3.flow/main.c:245 ../raster3d/r3.flow/main.c:254
+#: ../raster3d/r3.flow/main.c:262 ../raster3d/r3.flow/main.c:272
+msgid "Integration"
+msgstr ""
+#: ../raster3d/r3.flow/main.c:252
+msgid "Integration step in selected unit"
+msgstr ""
+#: ../raster3d/r3.flow/main.c:253
+msgid "Default step is 0.25 cell"
+msgstr ""
+#: ../raster3d/r3.flow/main.c:261
+msgid "Maximum number of steps"
+msgstr ""
+#: ../raster3d/r3.flow/main.c:269
+msgid "Maximum error of integration"
+msgstr ""
+#: ../raster3d/r3.flow/main.c:270
+msgid "Influences step, increase maximum error to allow bigger steps"
+msgstr ""
+#: ../raster3d/r3.flow/main.c:280
+msgid "Number of cells between flow lines in x, y and z direction"
+msgstr ""
+#: ../raster3d/r3.flow/main.c:289
+msgid "Compute flowlines upstream, downstream or in both direction."
+msgstr ""
+#: ../raster3d/r3.flow/main.c:294
+msgid "Create and fill attribute table"
+msgstr ""
+#: ../raster3d/r3.flow/main.c:349
+msgid "Please provide 3 integer values for skip option."
+msgstr ""
+#: ../raster3d/r3.flow/main.c:414 ../vector/v.to.rast/vect2rast.c:48
+#: ../vector/v.colors/main.c:266
+#, c-format
+msgid "Vector map <%s> is not 3D"
+msgstr ""
+#: ../raster3d/r3.flow/main.c:441
+msgid "Error during reading seed vector map"
+msgstr ""
+#: ../raster3d/r3.flow/test_main.c:44
+msgid "unit test"
+msgstr ""
+#: ../raster3d/r3.flow/test_main.c:45
+msgid "Testing flow lines."
+msgstr ""
+#: ../raster3d/r3.cross.rast/main.c:90
+msgid "Input 3D raster map for cross section"
+msgstr ""
+#: ../raster3d/r3.cross.rast/main.c:97
+msgid "2D elevation map used to create the cross section map"
+msgstr ""
+#: ../raster3d/r3.cross.rast/main.c:104
+msgid "Resulting cross section 2D raster map"
+msgstr ""
+#: ../raster3d/r3.cross.rast/main.c:233
+msgid "Creates cross section 2D raster map from 3D raster map based on 2D elevation map"
+msgstr ""
+#: ../raster3d/r3.cross.rast/main.c:259
+msgid "The 2D and 3D region settings are different. Using the 3D raster map settings to adjust the 2D region."
+msgstr ""
+#: ../raster3d/r3.cross.rast/main.c:302
+msgid "Output map already exists. Will be overwritten!"
+msgstr ""
+#: ../raster3d/r3.cross.rast/main.c:338
+msgid "Wrong 3D raster datatype! Cannot create raster map"
+msgstr ""
+#: ../raster3d/r3.out.v5d/main.c:73
+msgid "3D raster map to be converted to Vis5D (V5D) file"
+msgstr ""
+#: ../raster3d/r3.out.v5d/main.c:77
+msgid "Name for V5D output file"
+msgstr ""
+#: ../raster3d/r3.out.v5d/main.c:147
+#, c-format
+msgid "Vis5D allows %d columns, %d columns found"
+msgstr ""
+#: ../raster3d/r3.out.v5d/main.c:150
+#, c-format
+msgid "Vis5D allows %d rows, %d rows found"
+msgstr ""
+#: ../raster3d/r3.out.v5d/main.c:257
+#, c-format
+msgid "Unable to create V5D file <%s>"
+msgstr ""
+#: ../raster3d/r3.out.v5d/main.c:262
+msgid "Failed writing V5D file"
+msgstr ""
+#: ../raster3d/r3.out.v5d/main.c:288
+msgid "Exports GRASS 3D raster map to 3-dimensional Vis5D file."
+msgstr ""
+#: ../raster3d/r3.out.v5d/main.c:295
+msgid "Use map coordinates instead of xyz coordinates"
+msgstr ""
+#: ../raster3d/r3.timestamp/main.c:48
+msgid "Modifies a timestamp for a 3D raster map."
+msgstr ""
+#: ../raster3d/r3.timestamp/main.c:49
+msgid "Print/add/remove a timestamp for a 3D raster map."
+msgstr ""
+#: ../raster3d/r3.timestamp/main.c:58
+msgid "Datetime, datetime1/datetime2, or none"
+msgstr ""
+#: ../raster3d/r3.timestamp/main.c:91
+msgid "Timestamp format is invalid"
+msgstr ""
+#: ../raster3d/r3.in.bin/main.c:73
+msgid "Error reading binary data"
+msgstr ""
+#: ../raster3d/r3.in.bin/main.c:154
+#, c-format
+msgid "Loading %s data with %i bytes ... (%dx%dx%d)"
+msgstr ""
+#: ../raster3d/r3.in.bin/main.c:256
+msgid "Imports a binary raster file into a GRASS 3D raster map."
+msgstr ""
+#: ../raster3d/r3.in.bin/main.c:259
+msgid "Name of binary 3D raster file to be imported"
+msgstr ""
+#: ../raster3d/r3.in.bin/main.c:275
+msgid "Byte order in binary file"
+msgstr ""
+#: ../raster3d/r3.in.bin/main.c:315
+msgid "Bottom limit of geographic region (outer edge)"
+msgstr ""
+#: ../raster3d/r3.in.bin/main.c:322
+msgid "Top limit of geographic region (outer edge)"
+msgstr ""
+#: ../raster3d/r3.in.bin/main.c:343
+msgid "Number of depths"
+msgstr ""
+#: ../raster3d/r3.in.bin/main.c:365
+msgid "Binary data is of type integer"
+msgstr ""
+#: ../raster3d/r3.in.bin/main.c:399
+#, c-format
+msgid "bytes=%d; must be 4 or 8 in case of floating point input"
+msgstr ""
+#: ../raster3d/r3.in.bin/main.c:409
+msgid "Integer input doesn't support size=8 in this build"
+msgstr ""
+#: ../raster3d/r3.in.bin/main.c:413
+msgid "bytes= must be 1, 2, 4 or 8"
+msgstr ""
+#: ../raster3d/r3.in.bin/main.c:446
+#, c-format
+msgid "File Size %lld ... Total Bytes %lld"
+msgstr ""
+#: ../raster3d/r3.info/main.c:80
+msgid "Outputs basic information about a user-specified 3D raster map layer."
+msgstr ""
+#: ../raster3d/r3.info/main.c:86
+msgid "Print raster3d information in shell style"
+msgstr ""
+#: ../raster3d/r3.info/main.c:90
+msgid "Print range in shell style only"
+msgstr ""
+#: ../raster3d/r3.info/main.c:103
+#, c-format
+msgid "3D Raster map <%s> not found"
+msgstr ""
+#: ../raster3d/r3.info/main.c:492
+msgid "Error while reading history file"
+msgstr ""
+#: ../raster3d/r3.to.rast/main.c:100
+msgid "3D raster map(s) to be converted to 2D raster slices"
+msgstr ""
+#: ../raster3d/r3.to.rast/main.c:106
+msgid "Basename for resultant raster slice maps"
+msgstr ""
+#: ../raster3d/r3.to.rast/main.c:116
+msgid "Value to multiply the raster values with"
+msgstr ""
+#: ../raster3d/r3.to.rast/main.c:117
+msgid "Coefficient a in the equation y = ax + b"
+msgstr ""
+#: ../raster3d/r3.to.rast/main.c:123
+msgid "Value to add to the raster values"
+msgstr ""
+#: ../raster3d/r3.to.rast/main.c:124
+msgid "Coefficient b in the equation y = ax + b"
+msgstr ""
+#: ../raster3d/r3.to.rast/main.c:133
+msgid "Use the same resolution as the input 3D raster map for the 2D output maps, independent of the current region settings"
+msgstr ""
+#: ../raster3d/r3.to.rast/main.c:174
+#, c-format
+msgid "Unknown raster type <%d>"
+msgstr ""
+#: ../raster3d/r3.to.rast/main.c:263
+msgid "Converts 3D raster maps to 2D raster maps"
+msgstr ""
+#: ../raster3d/r3.to.rast/main.c:362
+#, c-format
+msgid "Creating %i raster maps"
+msgstr ""
+#: ../raster3d/r3.to.rast/main.c:368
+#, c-format
+msgid "Raster map %i Filename: %s"
+msgstr ""
+#: ../raster3d/r3.to.rast/main.c:373
+#, c-format
+msgid "Raster map %d Filename: %s already exists. Use the flag --o to overwrite."
+msgstr ""
+#: ../raster3d/r3.stats/main.c:52
+msgid "Generates volume statistics for 3D raster maps."
+msgstr ""
+#: ../raster3d/r3.stats/main.c:63
+msgid "Number of subranges to collect stats from"
+msgstr ""
+#: ../raster3d/r3.stats/main.c:68
+msgid "Calculate statistics based on equal value groups"
+msgstr ""
+#: ../raster3d/r3.stats/main.c:72
+msgid "Only print cell counts"
+msgstr ""
+#: ../raster3d/r3.stats/main.c:92
+msgid "The number of subranges has to be equal or greater than 1"
+msgstr ""
+#: ../raster3d/r3.stats/main.c:151
+msgid "Sort non-null values"
+msgstr ""
+#: ../raster3d/r3.gradient/main.c:44
+msgid "gradient"
+msgstr ""
+#: ../raster3d/r3.gradient/main.c:47
+msgid "Computes gradient of a 3D raster map and outputs gradient components as three 3D raster maps."
+msgstr ""
+#: ../raster3d/r3.gradient/main.c:56
+msgid "Name for output 3D raster map(s)"
+msgstr ""
+#: ../raster3d/r3.gradient/main.c:63
+msgid "Size of blocks"
+msgstr ""
+#: ../raster3d/r3.gradient/main.c:130
+msgid "Failed to allocate memory for blocks"
+msgstr ""
+#: ../raster3d/r3.gradient/main.c:292
+msgid "Writing gradient 3D raster maps..."
+msgstr ""
+#: ../raster3d/r3.out.ascii/main.c:82
+msgid "3D raster map to be converted to ASCII"
+msgstr ""
+#: ../raster3d/r3.out.ascii/main.c:86
+msgid "Name for ASCII output file"
+msgstr ""
+#: ../raster3d/r3.out.ascii/main.c:95
+msgid "Number of decimal places for floats"
+msgstr ""
+#: ../raster3d/r3.out.ascii/main.c:114
+msgid "Print grass6 compatible format. Flags -d and -r are ignored."
+msgstr ""
+#: ../raster3d/r3.out.ascii/main.c:308
+msgid "Converts a 3D raster map layer into a ASCII text file."
+msgstr ""
+#: ../raster3d/r3.out.ascii/main.c:371
+msgid "Unable to close new ASCII file"
+msgstr ""
+#: ../raster3d/r3.in.lidar/main.c:170
+msgid "Creates a 3D raster map from LAS LiDAR points using univariate statistics."
+msgstr ""
+#: ../raster3d/r3.in.lidar/main.c:176
+msgid "LiDAR input file in LAS format (*.las or *.laz)"
+msgstr ""
+#: ../raster3d/r3.in.lidar/main.c:189
+msgid "Count of points per cell"
+msgstr ""
+#: ../raster3d/r3.in.lidar/main.c:195
+msgid "Sum of values of point intensities per cell"
+msgstr ""
+#: ../raster3d/r3.in.lidar/main.c:201
+msgid "Mean of point intensities per cell"
+msgstr ""
+#: ../raster3d/r3.in.lidar/main.c:209
+msgid "3D raster map of proportional point count"
+msgstr ""
+#: ../raster3d/r3.in.lidar/main.c:211
+msgid "Point count per 3D cell divided by point count per vertical column"
+msgstr ""
+#: ../raster3d/r3.in.lidar/main.c:213 ../raster3d/r3.in.lidar/main.c:223
+msgid "Proportional output"
+msgstr ""
+#: ../raster3d/r3.in.lidar/main.c:219
+msgid "3D raster map of proportional sum of values"
+msgstr ""
+#: ../raster3d/r3.in.lidar/main.c:221
+msgid "Sum of values per 3D cell divided by sum of values per vertical column"
+msgstr ""
+#: ../raster3d/r3.in.lidar/main.c:248
+msgid "Subtract raster values from the z coordinates"
+msgstr ""
+#: ../raster3d/r3.in.lidar/main.c:250
+msgid "The scale for z is applied beforehand, the filter afterwards"
+msgstr ""
+#: ../raster3d/r3.in.lidar/main.c:256
+msgid "Use base raster actual resolution instead of computational region"
+msgstr ""
+#: ../raster3d/r3.in.lidar/main.c:329
+#, c-format
+msgid "%s will not be taken into account during scan"
+msgstr ""
+#: ../raster3d/r3.in.lidar/main.c:540
+msgid "Preparing the maps..."
+msgstr ""
+#: ../raster3d/r3.in.lidar/main.c:574 ../vector/v.sample/main.c:200
+msgid "Reading points..."
+msgstr ""
+#: ../raster3d/r3.in.lidar/main.c:656
+msgid "Computing proportional count map..."
+msgstr ""
+#: ../raster3d/r3.in.lidar/main.c:661
+msgid "Computing proportional sum map..."
+msgstr ""
+#: ../raster3d/r3.in.lidar/main.c:666
+msgid "Computing mean map..."
+msgstr ""
+#: ../raster3d/r3.in.lidar/main.c:671
+msgid "Closing the maps..."
+msgstr ""
+#: ../raster3d/r3.in.lidar/main.c:707 ../vector/v.in.lidar/main.c:785
+#, c-format
+msgid "%lu input points were not valid and filtered out"
+msgstr ""
+#: ../raster3d/r3.in.lidar/main.c:710 ../vector/v.in.lidar/main.c:791
+#, c-format
+msgid "%lu input points were filtered out by return number"
+msgstr ""
+#: ../raster3d/r3.in.lidar/main.c:712 ../vector/v.in.lidar/main.c:793
+#, c-format
+msgid "%lu input points were filtered out by class number"
+msgstr ""
+#: ../raster3d/r3.in.lidar/main.c:714
+#, c-format
+msgid "%lu input points had intensity out of range"
+msgstr ""
+#: ../raster3d/r3.in.lidar/main.c:716 ../vector/v.in.lidar/main.c:813
+#, c-format
+msgid "%lu input points were not valid, use -%c flag to filter them out"
+msgstr ""
+#: ../raster3d/r3.in.lidar/filters.c:27
+#, c-format
+msgid "Invalid range <%s> for option %s"
+msgstr ""
+#: ../raster3d/r3.in.lidar/filters.c:54 ../vector/v.in.lidar/filters.c:36
+#: ../vector/v.in.pdal/filters.c:95
+#, c-format
+msgid "Unknown return filter value <%s>"
+msgstr ""
+#: ../raster3d/r3.null/main.c:55
+msgid "3D raster map for which to modify null values"
+msgstr ""
+#: ../raster3d/r3.null/main.c:85
+msgid "Illegal value for null"
+msgstr ""
+#: ../raster3d/r3.null/main.c:122
+msgid "modifyNull: error opening tmp file"
+msgstr ""
+#: ../raster3d/r3.null/main.c:155
+msgid "modifyNull: error flushing all tiles"
+msgstr ""
+#: ../raster3d/r3.null/main.c:165
+msgid "modifyNull: Unable to close tmp file"
+msgstr ""
+#: ../raster3d/r3.null/main.c:184
+msgid "Explicitly create the 3D NULL-value bitmap file."
+msgstr ""
+#: ../raster3d/r3.in.ascii/main.c:94
+msgid "String representing NULL value data cell (use 'none' if no such value)"
+msgstr ""
+#: ../raster3d/r3.in.ascii/main.c:221
+#, c-format
+msgid "Unsupported GRASS version %s"
+msgstr ""
+#: ../raster3d/r3.in.ascii/main.c:265
+#, c-format
+msgid "Loading data ... (%dx%dx%d)"
+msgstr ""
+#: ../raster3d/r3.in.ascii/main.c:298
+msgid "End of file reached while still loading data."
+msgstr ""
+#: ../raster3d/r3.in.ascii/main.c:310
+#, c-format
+msgid "Invalid value detected (at col=%d row=%d depth=%d): %s"
+msgstr ""
+#: ../raster3d/r3.in.ascii/main.c:322
+#, c-format
+msgid "Data exists in input file after fully importing expected data. [%.4f ...]"
+msgstr ""
+#: ../raster3d/r3.in.ascii/main.c:360
+msgid "Converts a 3D ASCII raster text file into a (binary) 3D raster map."
+msgstr ""
+#: ../raster3d/r3.in.ascii/main.c:403
+msgid "Unable to close ASCII file"
+msgstr ""
+#: ../general/g.findfile/main.c:40 ../general/g.findetc/main.c:30
+#: ../general/g.dirseps/main.c:36 ../general/g.gisenv/main.c:46
+#: ../general/g.message/main.c:35 ../general/g.filename/main.c:41
+#: ../general/g.tempfile/main.c:40
+msgid "scripts"
+msgstr ""
+#: ../general/g.findfile/main.c:42
+msgid "Searches for GRASS data base files and sets variables for the shell."
+msgstr ""
+#: ../general/g.findfile/main.c:53 ../general/g.filename/main.c:50
+msgid "Name of an element"
+msgstr ""
+#: ../general/g.findfile/main.c:59
+msgid "Name of an existing map"
+msgstr ""
+#: ../general/g.findfile/main.c:65
+msgid "Name of a mapset (default: search path)"
+msgstr ""
+#: ../general/g.findfile/main.c:66
+msgid "'.' for current mapset"
+msgstr ""
+#: ../general/g.findfile/main.c:70
+msgid "Do not add quotes"
+msgstr ""
+#: ../general/g.findfile/main.c:74
+msgid "List available elements and exit"
+msgstr ""
+#: ../general/g.findfile/main.c:97
+#, c-format
+msgid "Parameter 'file' contains reference to <%s> mapset, but mapset parameter <%s> does not correspond"
+msgstr ""
+#: ../general/g.findfile/element.c:7
+msgid "List of available elements:"
+msgstr ""
+#: ../general/g.version/main.c:66 ../general/g.message/main.c:34
+#: ../general/g.tempfile/main.c:39
+msgid "support"
+msgstr ""
+#: ../general/g.version/main.c:67
+msgid "citing"
+msgstr ""
+#: ../general/g.version/main.c:68
+msgid "copyright"
+msgstr ""
+#: ../general/g.version/main.c:69
+msgid "version"
+msgstr ""
+#: ../general/g.version/main.c:70
+msgid "license"
+msgstr ""
+#: ../general/g.version/main.c:71
+msgid "Displays GRASS GIS version info."
+msgstr ""
+#: ../general/g.version/main.c:72
+msgid "Optionally also prints build or copyright information."
+msgstr ""
+#: ../general/g.version/main.c:76
+msgid "Print also the copyright message"
+msgstr ""
+#: ../general/g.version/main.c:77 ../general/g.version/main.c:82
+#: ../general/g.version/main.c:87 ../general/g.version/main.c:93
+#: ../general/g.version/main.c:99
+msgid "Additional info"
+msgstr ""
+#: ../general/g.version/main.c:81
+msgid "Print also the citation options"
+msgstr ""
+#: ../general/g.version/main.c:86
+msgid "Print also the build information"
+msgstr ""
+#: ../general/g.version/main.c:92
+msgid "Print also the GIS library revision number and date"
+msgstr ""
+#: ../general/g.version/main.c:97
+msgid "Print also extended info for additional libraries"
+msgstr ""
+#: ../general/g.version/main.c:98
+msgid "GDAL/OGR, PROJ.4, GEOS"
+msgstr ""
+#: ../general/g.version/main.c:103
+msgid "Print info in shell script style (including SVN revision number)"
+msgstr ""
+#: ../general/g.version/main.c:104
+msgid "Shell"
+msgstr ""
+#: ../general/g.version/main.c:172
+#, c-format
+msgid "Cannot determine GRASS libgis version and date number. The GRASS build might be broken. Report this to developers or packagers.\n"
+msgstr ""
+#: ../general/g.version/main.c:179
+msgid "GRASS GIS libgis version and date number don't have the expected format. Trying to print the original strings..."
+msgstr ""
+#: ../general/g.version/main.c:181
+#, c-format
+msgid "GIS_H_VERSION=\"%s\""
+msgstr ""
+#: ../general/g.version/main.c:182
+#, c-format
+msgid "GIS_H_DATE=\"%s\""
+msgstr ""
+#: ../general/g.version/main.c:212
+msgid "GRASS not compiled with GDAL/OGR support"
+msgstr ""
+#: ../general/g.version/main.c:223
+msgid "GRASS not compiled with GEOS support"
+msgstr ""
+#: ../general/g.version/main.c:234
+msgid "GRASS not compiled with SQLite support"
+msgstr ""
+#: ../general/g.ppmtopng/main.c:34
+#, c-format
+msgid "Unable to open input file %s"
+msgstr ""
+#: ../general/g.ppmtopng/main.c:37
+#, c-format
+msgid "Invalid input file %s"
+msgstr ""
+#: ../general/g.ppmtopng/main.c:77
+msgid "Error writing PNG file"
+msgstr ""
+#: ../general/g.ppmtopng/main.c:81
+#, c-format
+msgid "Unable to open output file %s"
+msgstr ""
+#: ../general/g.ppmtopng/main.c:119
+msgid "Converts between PPM/PGM and PNG image formats."
+msgstr ""
+#: ../general/g.parser/rules.c:14
+#, c-format
+msgid "Unknown flag \"-%c\" in rule\n"
+msgstr ""
+#: ../general/g.parser/rules.c:26
+#, c-format
+msgid "Unknown option \"%s\" in rule\n"
+msgstr ""
+#: ../general/g.parser/rules.c:94
+#, c-format
+msgid "Unknown rule type \"%s\" at line %d\n"
+msgstr ""
+#: ../general/g.parser/main.c:74
+msgid "Usage"
+msgstr ""
+#: ../general/g.parser/main.c:84
+msgid "Unable to open script file"
+msgstr ""
+#: ../general/g.parser/main.c:99
+#, c-format
+msgid "Line too long or missing newline at line %d\n"
+msgstr ""
+#: ../general/g.parser/main.c:139
+msgid "Error closing script file"
+msgstr ""
+#: ../general/g.parser/revoke.c:64
+msgid "G_spawn() failed"
+msgstr ""
+#: ../general/g.parser/revoke.c:72
+msgid "execl() failed"
+msgstr ""
+#: ../general/g.parser/parse.c:22
+#, c-format
+msgid "Unknown boolean value \"%s\" at line %d\n"
+msgstr ""
+#: ../general/g.parser/parse.c:70
+#, c-format
+msgid "Unknown command \"%s\" at line %d\n"
+msgstr ""
+#: ../general/g.parser/parse.c:103
+#, c-format
+msgid "Unknown module parameter \"%s\" at line %d\n"
+msgstr ""
+#: ../general/g.parser/parse.c:140
+#, c-format
+msgid "Unknown flag parameter \"%s\" at line %d\n"
+msgstr ""
+#: ../general/g.parser/parse.c:155
+#, c-format
+msgid "Unknown type \"%s\" at line %d\n"
+msgstr ""
+#: ../general/g.parser/parse.c:233
+#, c-format
+msgid "Unknown option parameter \"%s\" at line %d\n"
+msgstr ""
+#: ../general/g.list/main.c:70
+msgid "Lists available GRASS data base files of the user-specified data type optionally using the search pattern."
+msgstr ""
+#: ../general/g.list/main.c:86
+msgid "Map name search pattern (default: all)"
+msgstr ""
+#: ../general/g.list/main.c:87 ../general/g.list/main.c:95
+#: ../general/g.list/main.c:121 ../general/g.list/main.c:127
+#: ../general/g.list/main.c:133 ../general/g.remove/main.c:100
+#: ../general/g.remove/main.c:106 ../general/g.remove/main.c:112
+#: ../general/g.remove/main.c:117 ../general/g.remove/main.c:123
+#: ../general/g.remove/main.c:129
+msgid "Pattern"
+msgstr ""
+#: ../general/g.list/main.c:94
+msgid "Map name exclusion pattern (default: none)"
+msgstr ""
+#: ../general/g.list/main.c:100
+msgid "Name of mapset to list (default: current search path)"
+msgstr ""
+#: ../general/g.list/main.c:102
+msgid "'.' for current mapset; '*' for all mapsets in location"
+msgstr ""
+#: ../general/g.list/main.c:108
+msgid "Name of saved region for map search (default: not restricted)"
+msgstr ""
+#: ../general/g.list/main.c:110
+msgid "'.' for current region; '*' for default region"
+msgstr ""
+#: ../general/g.list/main.c:115 ../vector/v.out.ascii/args.c:33
+msgid "If not given or '-' then standard output"
+msgstr ""
+#: ../general/g.list/main.c:120 ../general/g.remove/main.c:116
+msgid "Ignore case"
+msgstr ""
+#: ../general/g.list/main.c:126 ../general/g.remove/main.c:122
+msgid "Use basic regular expressions instead of wildcards"
+msgstr ""
+#: ../general/g.list/main.c:132 ../general/g.remove/main.c:128
+msgid "Use extended regular expressions instead of wildcards"
+msgstr ""
+#: ../general/g.list/main.c:137
+msgid "Print data types"
+msgstr ""
+#: ../general/g.list/main.c:142
+msgid "Print fully-qualified map names (including mapsets)"
+msgstr ""
+#: ../general/g.list/main.c:147
+msgid "Pretty printing in human readable format"
+msgstr ""
+#: ../general/g.list/main.c:152
+msgid "Verbose listing (also list map titles)"
+msgstr ""
+#: ../general/g.list/main.c:185 ../general/g.list/main.c:212
+#: ../general/g.remove/main.c:178 ../general/g.remove/main.c:202
+#, c-format
+msgid "Unable to compile pattern <%s>"
+msgstr ""
+#: ../general/g.list/main.c:269
+#, c-format
+msgid "Mapset <%s> does not exist"
+msgstr ""
+#: ../general/g.list/list.c:123 ../general/g.region/main.c:471
+#, c-format
+msgid "Unable to read header of 3D raster map <%s@%s>"
+msgstr ""
+#: ../general/g.list/list.c:131
+#, c-format
+msgid "Unable to open vector map <%s@%s> on topological level"
+msgstr ""
+#: ../general/g.cairocomp/main.c:49 ../scripts/v.in.lines/v.in.lines.py:75
+#: ../scripts/r3.in.xyz/r3.in.xyz.py:212
+#, c-format, python-format
+msgid "Unable to read input file <%s>"
+msgstr ""
+#: ../general/g.cairocomp/main.c:52
+#, c-format
+msgid "Unable to parse input file <%s>"
+msgstr ""
+#: ../general/g.cairocomp/main.c:71
+#, c-format
+msgid "Unable to write output file <%s>"
+msgstr ""
+#: ../general/g.cairocomp/main.c:89 ../general/g.cairocomp/main.c:256
+#: ../visualization/ximgview/main.c:64
+msgid "Unable to open display"
+msgstr ""
+#: ../general/g.cairocomp/main.c:113
+msgid "Unable to obtain visual"
+msgstr ""
+#: ../general/g.cairocomp/main.c:129
+msgid "Failed to initialize output surface"
+msgstr ""
+#: ../general/g.cairocomp/main.c:150 ../general/g.pnmcomp/main.c:38
+#, c-format
+msgid "Invalid color: %s"
+msgstr ""
+#: ../general/g.cairocomp/main.c:171
+msgid "Failed to initialize input surface"
+msgstr ""
+#: ../general/g.cairocomp/main.c:198
+msgid "Overlays multiple X Pixmaps."
+msgstr ""
+#: ../general/g.cairocomp/main.c:203 ../general/g.pnmcomp/main.c:290
+msgid "Name of input file(s)"
+msgstr ""
+#: ../general/g.cairocomp/main.c:212
+msgid "Output Visual XID"
+msgstr ""
+#: ../general/g.cairocomp/main.c:218
+msgid "Output screen"
+msgstr ""
+#: ../general/g.cairocomp/main.c:224 ../general/g.pnmcomp/main.c:302
+msgid "Layer opacities"
+msgstr ""
+#: ../general/g.cairocomp/main.c:230 ../general/g.pnmcomp/main.c:315
+msgid "Image width"
+msgstr ""
+#: ../general/g.cairocomp/main.c:236 ../general/g.pnmcomp/main.c:321
+msgid "Image height"
+msgstr ""
+#: ../general/g.cairocomp/main.c:240
+msgid "Background color (R:G:B:A)"
+msgstr ""
+#: ../general/g.cairocomp/main.c:245
+msgid "Do not composite; just delete input Pixmaps"
+msgstr ""
+#: ../general/g.cairocomp/main.c:277
+msgid "input= and opacity= must have the same number of values"
+msgstr ""
+#: ../general/g.region/main.c:67
+msgid "computational region"
+msgstr ""
+#: ../general/g.region/main.c:69
+msgid "resolution"
+msgstr ""
+#: ../general/g.region/main.c:72
+msgid "Manages the boundary definitions for the geographic region."
+msgstr ""
+#: ../general/g.region/main.c:83
+msgid "Save as default region"
+msgstr ""
+#: ../general/g.region/main.c:84
+msgid "Only possible from the PERMANENT mapset"
+msgstr ""
+#: ../general/g.region/main.c:89
+msgid "Print the current region"
+msgstr ""
+#: ../general/g.region/main.c:94
+msgid "Print the current region in lat/long using the current ellipsoid/datum"
+msgstr ""
+#: ../general/g.region/main.c:100
+msgid "Print the current region extent"
+msgstr ""
+#: ../general/g.region/main.c:106
+msgid "Print the current region map center coordinates"
+msgstr ""
+#: ../general/g.region/main.c:112
+msgid "Print the current region in GMT style"
+msgstr ""
+#: ../general/g.region/main.c:118
+msgid "Print the current region in WMS style"
+msgstr ""
+#: ../general/g.region/main.c:124
+msgid "Print region resolution in meters (geodesic)"
+msgstr ""
+#: ../general/g.region/main.c:129
+msgid "Print the convergence angle (degrees CCW)"
+msgstr ""
+#: ../general/g.region/main.c:131
+msgid "The difference between the projection's grid north and true north, measured at the center coordinates of the current region."
+msgstr ""
+#: ../general/g.region/main.c:137
+msgid "Print also 3D settings"
+msgstr ""
+#: ../general/g.region/main.c:143
+msgid "Print the maximum bounding box in lat/long on WGS84"
+msgstr ""
+#: ../general/g.region/main.c:153
+msgid "Print in shell script style, but in one line (flat)"
+msgstr ""
+#: ../general/g.region/main.c:159
+msgid "Align region to resolution (default = align to bounds, works only for 2D resolution)"
+msgstr ""
+#: ../general/g.region/main.c:165
+msgid "Do not update the current region"
+msgstr ""
+#: ../general/g.region/main.c:166 ../general/g.region/main.c:360
+#: ../vector/v.label/main.c:90 ../vector/v.label/main.c:95
+#: ../vector/v.label/main.c:170 ../vector/v.label/main.c:183
+msgid "Effects"
+msgstr ""
+#: ../general/g.region/main.c:171
+msgid "Set current region from named region"
+msgstr ""
+#: ../general/g.region/main.c:178
+msgid "Set region to match raster map(s)"
+msgstr ""
+#: ../general/g.region/main.c:186
+msgid "Set region to match 3D raster map(s) (both 2D and 3D values)"
+msgstr ""
+#: ../general/g.region/main.c:194
+msgid "Set region to match vector map(s)"
+msgstr ""
+#: ../general/g.region/main.c:240
+msgid "Value for the top edge"
+msgstr ""
+#: ../general/g.region/main.c:249
+msgid "Value for the bottom edge"
+msgstr ""
+#: ../general/g.region/main.c:258
+msgid "Number of rows in the new region"
+msgstr ""
+#: ../general/g.region/main.c:259 ../general/g.region/main.c:268
+#: ../general/g.region/main.c:278 ../general/g.region/main.c:288
+#: ../general/g.region/main.c:297 ../general/g.region/main.c:306
+#: ../general/g.region/main.c:315
+msgid "Resolution"
+msgstr ""
+#: ../general/g.region/main.c:267
+msgid "Number of columns in the new region"
+msgstr ""
+#: ../general/g.region/main.c:277
+msgid "2D grid resolution (north-south and east-west)"
+msgstr ""
+#: ../general/g.region/main.c:287
+msgid "3D grid resolution (north-south, east-west and top-bottom)"
+msgstr ""
+#: ../general/g.region/main.c:296
+msgid "North-south 2D grid resolution"
+msgstr ""
+#: ../general/g.region/main.c:305
+msgid "East-west 2D grid resolution"
+msgstr ""
+#: ../general/g.region/main.c:314
+msgid "Top-bottom 3D grid resolution"
+msgstr ""
+#: ../general/g.region/main.c:324
+msgid "Shrink region until it meets non-NULL data from this raster map"
+msgstr ""
+#: ../general/g.region/main.c:335
+msgid "Adjust region cells to cleanly align with this raster map"
+msgstr ""
+#: ../general/g.region/main.c:346
+msgid "Number of cells to add to each side of the current region extent"
+msgstr ""
+#: ../general/g.region/main.c:348
+msgid "A negative number shrinks the current region extent"
+msgstr ""
+#: ../general/g.region/main.c:358
+msgid "Save current region settings in named region file"
+msgstr ""
+#: ../general/g.region/main.c:427 ../scripts/r.in.wms/r.in.wms.py:196
+msgid "Region <%s> not found"
+msgstr ""
+#: ../general/g.region/main.c:512
+msgid "Unable to get map bounding box"
+msgstr ""
+#: ../general/g.region/main.c:812
+#, c-format
+msgid "Unable to set region <%s>"
+msgstr ""
+#: ../general/g.region/main.c:818
+msgid "Unable to update current region"
+msgstr ""
+#: ../general/g.region/main.c:826
+msgid "Unable to change default region. The current mapset is not <PERMANENT>."
+msgstr ""
+#: ../general/g.region/printwindow.c:383
+msgid "You are already in Lat/Long. Use the -p flag instead."
+msgstr ""
+#: ../general/g.region/printwindow.c:385
+msgid "You are in a simple XY location, projection to Lat/Lon is not possible. Use the -p flag instead."
+msgstr ""
+#: ../general/g.region/printwindow.c:559
+msgid "WGS84 output not possible as this location does not contain datum transformation parameters. Try running g.setproj."
+msgstr ""
+#: ../general/g.region/printwindow.c:711
+msgid "Lat/Long calculations are not possible from a simple XY system"
+msgstr ""
+#: ../general/g.gui/main.c:40
+msgid "GUI"
+msgstr ""
+#: ../general/g.gui/main.c:41
+msgid "user interface"
+msgstr ""
+#: ../general/g.gui/main.c:44
+msgid "Launches a GRASS graphical user interface (GUI) session."
+msgstr ""
+#: ../general/g.gui/main.c:45
+msgid "Optionally updates default user interface settings."
+msgstr ""
+#: ../general/g.gui/main.c:50
+msgid "User interface"
+msgstr ""
+#: ../general/g.gui/main.c:54
+msgid "wxPython based GUI (wxGUI)"
+msgstr ""
+#: ../general/g.gui/main.c:55
+msgid "command line interface only"
+msgstr ""
+#: ../general/g.gui/main.c:56
+msgid "command line interface with GUI startup screen"
+msgstr ""
+#: ../general/g.gui/main.c:60 ../general/g.message/main.c:43
+#: ../general/g.message/main.c:48 ../general/g.message/main.c:53
+#: ../general/g.message/main.c:58
+msgid "Type"
+msgstr ""
+#: ../general/g.gui/main.c:66
+msgid "Name of workspace file to load on start-up"
+msgstr ""
+#: ../general/g.gui/main.c:67
+msgid "This is valid only for wxGUI (wxpython)"
+msgstr ""
+#: ../general/g.gui/main.c:71
+msgid "Start GUI in the foreground"
+msgstr ""
+#: ../general/g.gui/main.c:72
+msgid "By default the GUI starts in the background and control is immediately returned to the caller. When GUI runs in foregreound, it blocks the command line"
+msgstr ""
+#: ../general/g.gui/main.c:78
+msgid "Update default user interface settings"
+msgstr ""
+#: ../general/g.gui/main.c:79 ../general/g.gui/main.c:85
+msgid "Default"
+msgstr ""
+#: ../general/g.gui/main.c:84
+msgid "Do not launch GUI after updating the default user interface settings"
+msgstr ""
+#: ../general/g.gui/main.c:95
+#, c-format
+msgid "<%s> is now the default GUI"
+msgstr ""
+#: ../general/g.gui/main.c:101
+#, c-format
+msgid "Nothing to do. For setting up <%s> as default UI use -%c flag."
+msgstr ""
+#: ../general/g.gui/main.c:108
+msgid "Your installation doesn't include GUI, exiting."
+msgstr ""
+#: ../general/g.gui/main.c:111
+#, c-format
+msgid "Launching <%s> GUI, please wait..."
+msgstr ""
+#: ../general/g.gui/main.c:122
+#, c-format
+msgid "Launching <%s> GUI in the background, please wait..."
+msgstr ""
+#: ../general/g.rename/main.c:49
+msgid "Renames data base element files in the user's current mapset."
+msgstr ""
+#: ../general/g.rename/main.c:55
+msgid "renamed"
+msgstr ""
+#: ../general/g.rename/main.c:76
+#, c-format
+msgid "%s <%s> not found"
+msgstr ""
+#: ../general/g.rename/main.c:80
+#, c-format
+msgid "<%s> already exists in mapset <%s>"
+msgstr ""
+#: ../general/g.rename/main.c:90
+#, c-format
+msgid "%s=%s,%s: files could be the same, no rename possible"
+msgstr ""
+#: ../general/g.rename/main.c:116
+msgid "Updating reclass maps"
+msgstr ""
+#: ../general/g.rename/main.c:184
+#, c-format
+msgid "Unable to find reclass information for <%s> in base map <%s@%s>"
+msgstr ""
+#: ../general/g.rename/main.c:188
+#, c-format
+msgid "Updating base map <%s@%s>"
+msgstr ""
+#: ../general/g.rename/main.c:194
+#, c-format
+msgid "Unable to update dependency file in <%s@%s>"
+msgstr ""
+#: ../general/g.mapsets/main.c:65
+msgid "search path"
+msgstr ""
+#: ../general/g.mapsets/main.c:66
+msgid "Modifies/prints the user's current mapset search path."
+msgstr ""
+#: ../general/g.mapsets/main.c:67
+msgid "Affects the user's access to data existing under the other mapsets in the current location."
+msgstr ""
+#: ../general/g.mapsets/main.c:73
+msgid "Name(s) of existing mapset(s) to add/remove or set"
+msgstr ""
+#: ../general/g.mapsets/main.c:85
+msgid "Field separator for printing (-l and -p flags)"
+msgstr ""
+#: ../general/g.mapsets/main.c:91
+msgid "List all available mapsets in alphabetical order"
+msgstr ""
+#: ../general/g.mapsets/main.c:97
+msgid "Print mapsets in current search path"
+msgstr ""
+#: ../general/g.mapsets/main.c:103
+msgid "Launch mapset selection GUI dialog"
+msgstr ""
+#: ../general/g.mapsets/main.c:126
+#, c-format
+msgid "Unknown operation '%s'"
+msgstr ""
+#: ../general/g.mapsets/main.c:174 ../general/g.mapsets/main.c:208
+#, c-format
+msgid "Mapset <%s> not found"
+msgstr ""
+#: ../general/g.mapsets/main.c:181 ../general/g.mapsets/main.c:240
+#, c-format
+msgid "Current mapset (<%s>) must always included in the search path"
+msgstr ""
+#: ../general/g.mapsets/main.c:203
+#, c-format
+msgid "Mapset <%s> already in the path"
+msgstr ""
+#: ../general/g.mapsets/main.c:210
+#, c-format
+msgid "Mapset <%s> added to search path"
+msgstr ""
+#: ../general/g.mapsets/main.c:243
+#, c-format
+msgid "Mapset <%s> removed from search path"
+msgstr ""
+#: ../general/g.mapsets/main.c:255
+msgid "Search path not modified"
+msgstr ""
+#: ../general/g.mapsets/main.c:273
+msgid "Unable to open SEARCH_PATH for write"
+msgstr ""
+#: ../general/g.mapsets/list.c:10
+msgid "Available mapsets:"
+msgstr ""
+#: ../general/g.mapsets/list.c:35
+msgid "Accessible mapsets:"
+msgstr ""
+#: ../general/g.pnmcomp/main.c:54
+msgid "Error reading PPM file"
+msgstr ""
+#: ../general/g.pnmcomp/main.c:69 ../general/g.pnmcomp/main.c:74
+#: ../general/g.pnmcomp/main.c:83 ../general/g.pnmcomp/main.c:134
+#: ../general/g.pnmcomp/main.c:147
+msgid "Invalid PPM file"
+msgstr ""
+#: ../general/g.pnmcomp/main.c:96 ../scripts/v.unpack/v.unpack.py:76
+#: ../scripts/v.in.geonames/v.in.geonames.py:57
+#: ../scripts/v.db.update/v.db.update.py:92
+msgid "File <%s> not found"
+msgstr ""
+#: ../general/g.pnmcomp/main.c:104
+msgid "Expecting PPM but got PGM"
+msgstr ""
+#: ../general/g.pnmcomp/main.c:109
+msgid "Expecting PGM but got PPM"
+msgstr ""
+#: ../general/g.pnmcomp/main.c:112
+#, c-format
+msgid "Invalid magic number: 'P%c'"
+msgstr ""
+#: ../general/g.pnmcomp/main.c:125 ../general/g.pnmcomp/main.c:142
+msgid "Invalid PGM file"
+msgstr ""
+#: ../general/g.pnmcomp/main.c:247
+msgid "Error writing PPM file"
+msgstr ""
+#: ../general/g.pnmcomp/main.c:264
+msgid "Error writing PGM file"
+msgstr ""
+#: ../general/g.pnmcomp/main.c:285
+msgid "Overlays multiple PPM image files."
+msgstr ""
+#: ../general/g.pnmcomp/main.c:296
+msgid "Name of input mask file(s)"
+msgstr ""
+#: ../general/g.pnmcomp/main.c:309
+msgid "Name for output mask file"
+msgstr ""
+#: ../general/g.copy/main.c:44
+msgid "Copies available data files in the current mapset search path to the user's current mapset."
+msgstr ""
+#: ../general/g.copy/main.c:51
+msgid "copied"
+msgstr ""
+#: ../general/g.copy/main.c:66
+#, c-format
+msgid "<%s> not found"
+msgstr ""
+#: ../general/g.copy/main.c:71
+#, c-format
+msgid "%s=%s,%s: files are the same, no copy required"
+msgstr ""
+#: ../general/g.copy/main.c:76
+#, c-format
+msgid "<%s> already exists. File not copied."
+msgstr ""
+#: ../general/g.proj/main.c:69
+msgid "Prints or modifies GRASS projection information files (in various co-ordinate system descriptions)."
+msgstr ""
+#: ../general/g.proj/main.c:72
+msgid "Can also be used to create new GRASS locations."
+msgstr ""
+#: ../general/g.proj/main.c:75
+msgid "Prints and manipulates GRASS projection information files."
+msgstr ""
+#: ../general/g.proj/main.c:82
+msgid "Print projection information in conventional GRASS format"
+msgstr ""
+#: ../general/g.proj/main.c:88
+msgid "Print projection information in shell script style"
+msgstr ""
+#: ../general/g.proj/main.c:94
+msgid "Verify datum information and print transformation parameters"
+msgstr ""
+#: ../general/g.proj/main.c:100
+msgid "Print projection information in PROJ.4 format"
+msgstr ""
+#: ../general/g.proj/main.c:106
+msgid "Print 'flat' output with no linebreaks (applies to WKT and PROJ.4 output)"
+msgstr ""
+#: ../general/g.proj/main.c:116
+msgid "Print projection information in WKT format"
+msgstr ""
+#: ../general/g.proj/main.c:122
+msgid "Use ESRI-style format (applies to WKT output only)"
+msgstr ""
+#: ../general/g.proj/main.c:129 ../general/g.proj/main.c:138
+#: ../general/g.proj/main.c:148 ../general/g.proj/main.c:158
+msgid "Specification"
+msgstr ""
+#: ../general/g.proj/main.c:130
+msgid "Name of georeferenced data file to read projection information from"
+msgstr ""
+#: ../general/g.proj/main.c:139
+msgid "Name of ASCII file containing a WKT projection description"
+msgstr ""
+#: ../general/g.proj/main.c:149
+msgid "PROJ.4 projection description"
+msgstr ""
+#: ../general/g.proj/main.c:167 ../general/g.proj/main.c:180
+#: ../general/g.proj/main.c:186
+msgid "Datum"
+msgstr ""
+#: ../general/g.proj/main.c:169
+msgid "Datum (overrides any datum specified in input co-ordinate system)"
+msgstr ""
+#: ../general/g.proj/main.c:171
+msgid "Accepts standard GRASS datum codes, or \"list\" to list and exit"
+msgstr ""
+#: ../general/g.proj/main.c:182
+msgid "\"0\" for unspecified or \"-1\" to list and exit"
+msgstr ""
+#: ../general/g.proj/main.c:188
+msgid "Force override of datum transformation information in input co-ordinate system"
+msgstr ""
+#: ../general/g.proj/main.c:194
+msgid "Modify current location projection files"
+msgstr ""
+#: ../general/g.proj/main.c:202
+msgid "Name of new location to create"
+msgstr ""
+#: ../general/g.proj/main.c:218
+#, c-format
+msgid "Only one of '%s', '%s', '%s' or '%s' options may be specified"
+msgstr ""
+#: ../general/g.proj/main.c:264
+msgid "Projection files missing"
+msgstr ""
+#: ../general/g.proj/main.c:284
+#, c-format
+msgid "Only one of -%c, -%c, -%c, -%c, -%c or -%c flags may be specified"
+msgstr ""
+#: ../general/g.proj/main.c:311
+#, c-format
+msgid "No output format specified, define one of flags -%c, -%c, -%c, or -%c"
+msgstr ""
+#: ../general/g.proj/main.c:315
+#, c-format
+msgid "No output format specified, define one of flags -%c, -%c, or -%c"
+msgstr ""
+#: ../general/g.proj/output.c:135
+msgid "Unable to convert projection information to PROJ.4 format"
+msgstr ""
+#: ../general/g.proj/output.c:179
+msgid "Unable to convert to WKT"
+msgstr ""
+#: ../general/g.proj/input.c:92
+msgid "Error reading WKT projection description"
+msgstr ""
+#: ../general/g.proj/input.c:99
+#, c-format
+msgid "Unable to open file '%s' for reading"
+msgstr ""
+#: ../general/g.proj/input.c:166
+msgid "Can't parse PROJ.4-style parameter string"
+msgstr ""
+#: ../general/g.proj/input.c:205
+msgid "Unable to translate EPSG code"
+msgstr ""
+#: ../general/g.proj/input.c:247
+msgid "Trying to open with OGR..."
+msgstr ""
+#: ../general/g.proj/input.c:255 ../general/g.proj/input.c:274
+msgid "...succeeded."
+msgstr ""
+#: ../general/g.proj/input.c:268
+msgid "Trying to open with GDAL..."
+msgstr ""
+#: ../general/g.proj/input.c:284
+#, c-format
+msgid "Could not read georeferenced file %s using either OGR nor GDAL"
+msgstr ""
+#: ../general/g.proj/input.c:289
+#, c-format
+msgid "Read of file %s was successful, but it did not contain projection information. 'XY (unprojected)' will be used"
+msgstr ""
+#: ../general/g.proj/datumtrans.c:47
+#, c-format
+msgid "Invalid datum code <%s>"
+msgstr ""
+#: ../general/g.proj/datumtrans.c:77
+#, c-format
+msgid "Datum set to <%s>"
+msgstr ""
+#: ../general/g.proj/datumtrans.c:79
+#, c-format
+msgid "Ellipsoid set to <%s>"
+msgstr ""
+#: ../general/g.proj/create.c:18
+#, c-format
+msgid "Unable to create location <%s>: %s"
+msgstr ""
+#: ../general/g.proj/create.c:21
+#, c-format
+msgid "Unable to create projection files: %s"
+msgstr ""
+#: ../general/g.proj/create.c:25
+#, c-format
+msgid "Unable to create location <%s>"
+msgstr ""
+#: ../general/g.proj/create.c:27
+#, c-format
+msgid ""
+"You can switch to the new location by\n"
+"`%s=%s`"
+msgstr ""
+#: ../general/g.proj/create.c:37
+#, c-format
+msgid "You must select the PERMANENT mapset before updating the current location's projection (current mapset is <%s>)"
+msgstr ""
+#: ../general/g.proj/create.c:68
+msgid "Default region was updated to the new projection, but if you have multiple mapsets `g.region -d` should be run in each to update the region from the default"
+msgstr ""
+#: ../general/g.proj/create.c:72
+msgid "Projection information updated"
+msgstr ""
+#: ../general/g.mapset/main.c:51
+msgid "Changes/reports current mapset."
+msgstr ""
+#: ../general/g.mapset/main.c:52
+msgid "Optionally create new mapset or list available mapsets in given location."
+msgstr ""
+#: ../general/g.mapset/main.c:56
+msgid "Name of mapset where to switch"
+msgstr ""
+#: ../general/g.mapset/main.c:57 ../general/g.mapset/main.c:61
+#: ../general/g.mapset/main.c:64
+msgid "Mapset"
+msgstr ""
+#: ../general/g.mapset/main.c:68
+msgid "Create mapset if it doesn't exist"
+msgstr ""
+#: ../general/g.mapset/main.c:75
+msgid "List available mapsets and exit"
+msgstr ""
+#: ../general/g.mapset/main.c:81
+msgid "Print current mapset and exit"
+msgstr ""
+#: ../general/g.mapset/main.c:136
+#, c-format
+msgid "<%s> is already the current mapset"
+msgstr ""
+#: ../general/g.mapset/main.c:145
+#, c-format
+msgid "You don't have permission to use the mapset <%s>"
+msgstr ""
+#: ../general/g.mapset/main.c:153
+#, c-format
+msgid "Unable to create new mapset <%s>"
+msgstr ""
+#: ../general/g.mapset/main.c:156
+#, c-format
+msgid "Mapset <%s> does not exist. Use -c flag to create it."
+msgstr ""
+#: ../general/g.mapset/main.c:166
+msgid "Unable to read GIS_LOCK environment variable"
+msgstr ""
+#: ../general/g.mapset/main.c:182
+#, c-format
+msgid "Lock file of mapset <%s> cannot be checked"
+msgstr ""
+#: ../general/g.mapset/main.c:185
+#, c-format
+msgid "There appears to be an active GRASS session in selected mapset <%s>"
+msgstr ""
+#: ../general/g.mapset/main.c:191
+msgid "Cleaning up temporary files..."
+msgstr ""
+#: ../general/g.mapset/main.c:205
+msgid "Mapset switched. Your shell continues to use the history for the old mapset"
+msgstr ""
+#: ../general/g.mapset/main.c:210
+#, c-format
+msgid ""
+"You can switch the history by commands:\n"
+"history -w; history -r %s/.bash_history; HISTFILE=%s/.bash_history"
+msgstr ""
+#: ../general/g.mapset/main.c:215
+#, c-format
+msgid ""
+"history -S; history -L %s/.history; setenv histfile=%s/.history"
+msgstr ""
+#: ../general/g.mapset/main.c:221
+#, c-format
+msgid "Your current mapset is <%s>"
+msgstr ""
+#: ../general/g.dirseps/main.c:38
+msgid "Internal GRASS utility for converting directory separator characters."
+msgstr ""
+#: ../general/g.gisenv/main.c:45
+msgid "variables"
+msgstr ""
+#: ../general/g.gisenv/main.c:48
+msgid "Outputs and modifies the user's current GRASS variable settings."
+msgstr ""
+#: ../general/g.gisenv/main.c:49
+msgid "Prints all defined GRASS variables if no option is given."
+msgstr ""
+#: ../general/g.gisenv/main.c:54
+msgid "GRASS variable to get"
+msgstr ""
+#: ../general/g.gisenv/main.c:57
+msgid "Get"
+msgstr ""
+#: ../general/g.gisenv/main.c:63
+msgid "GRASS variable to set"
+msgstr ""
+#: ../general/g.gisenv/main.c:71
+msgid "GRASS variable to unset"
+msgstr ""
+#: ../general/g.gisenv/main.c:82
+msgid "Where GRASS variable is stored"
+msgstr ""
+#: ../general/g.gisenv/main.c:87
+msgid "Separator for multiple GRASS variables"
+msgstr ""
+#: ../general/g.gisenv/main.c:92
+msgid "Use shell syntax (for \"eval\")"
+msgstr ""
+#: ../general/g.gisenv/main.c:93 ../general/g.gisenv/main.c:98
+#: ../db/db.select/main.c:227 ../db/db.select/main.c:233
+#: ../db/db.select/main.c:236 ../db/db.select/main.c:246
+#: ../db/db.select/main.c:256 ../vector/v.db.select/main.c:85
+#: ../vector/v.db.select/main.c:88 ../vector/v.db.select/main.c:106
+#: ../vector/v.db.select/main.c:111 ../vector/v.profile/main.c:184
+#: ../vector/v.profile/main.c:187 ../vector/v.profile/main.c:196
+msgid "Format"
+msgstr ""
+#: ../general/g.gisenv/main.c:97
+msgid "Do not use shell syntax"
+msgstr ""
+#: ../general/g.gisenv/main.c:171
+#, c-format
+msgid "Variable <%s> is mandatory. No operation performed."
+msgstr ""
+#: ../general/g.gisenv/main.c:177
+#, c-format
+msgid "Value '%s' ignored when unsetting the GRASS variable"
+msgstr ""
+#: ../general/g.gisenv/main.c:216
+msgid "GRASS variable not defined"
+msgstr ""
+#: ../general/g.gisenv/main.c:222
+#, c-format
+msgid "GRASS variable must be uppercase. Using '%s'."
+msgstr ""
+#: ../general/g.message/main.c:37
+msgid "Prints a message, warning, progress info, or fatal error in the GRASS way."
+msgstr ""
+#: ../general/g.message/main.c:39
+msgid "This module should be used in scripts for messages served to user."
+msgstr ""
+#: ../general/g.message/main.c:44
+msgid "Print message as warning"
+msgstr ""
+#: ../general/g.message/main.c:49
+msgid "Print message as fatal error"
+msgstr ""
+#: ../general/g.message/main.c:54
+msgid "Print message as debug message"
+msgstr ""
+#: ../general/g.message/main.c:59
+msgid "Print message as progress info"
+msgstr ""
+#: ../general/g.message/main.c:63 ../general/g.message/main.c:69
+#: ../general/g.message/main.c:85
+msgid "Level"
+msgstr ""
+#: ../general/g.message/main.c:64
+msgid "Print message in all modes except of quiet mode"
+msgstr ""
+#: ../general/g.message/main.c:65
+msgid "Message is printed on GRASS_VERBOSE>=1"
+msgstr ""
+#: ../general/g.message/main.c:70
+msgid "Print message only in verbose mode"
+msgstr ""
+#: ../general/g.message/main.c:71
+msgid "Message is printed only on GRASS_VERBOSE>=3"
+msgstr ""
+#: ../general/g.message/main.c:78
+msgid "Text of the message to be printed"
+msgstr ""
+#: ../general/g.message/main.c:79
+msgid "Message is printed on GRASS_VERBOSE>=2"
+msgstr ""
+#: ../general/g.message/main.c:88
+msgid "Level to use for debug messages"
+msgstr ""
+#: ../general/g.message/main.c:95
+msgid "Select only one message level"
+msgstr ""
+#: ../general/g.message/main.c:108
+msgid "Unable to parse input message"
+msgstr ""
+#: ../general/g.setproj/main.c:81
+msgid "Interactively reset the location's projection settings."
+msgstr ""
+#: ../general/g.setproj/main.c:88
+msgid "You must be in the PERMANENT mapset to run g.setproj"
+msgstr ""
+#: ../general/g.setproj/main.c:101
+msgid "PERMANENT: permission denied"
+msgstr ""
+#: ../general/g.setproj/main.c:105
+msgid "Current region cannot be set"
+msgstr ""
+#: ../general/g.setproj/main.c:108
+msgid "Retrieving and setting region failed"
+msgstr ""
+#: ../general/g.setproj/main.c:135
+msgid "Would you still like to change some of the parameters?"
+msgstr ""
+#: ../general/g.setproj/main.c:137
+msgid "The projection information will not be updated"
+msgstr ""
+#: ../general/g.setproj/main.c:148
+#, c-format
+msgid ""
+"Zone in default geographic region definition: %d\n"
+" is different from zone in PROJ_INFO file: %d"
+msgstr ""
+#: ../general/g.setproj/main.c:158
+msgid "XY-location cannot be projected"
+msgstr ""
+#: ../general/g.setproj/main.c:192
+msgid "Unknown projection"
+msgstr ""
+#: ../general/g.setproj/main.c:198
+#, c-format
+msgid "Projection %s is not specified in the file 'proj-parms.table'"
+msgstr ""
+#: ../general/g.setproj/main.c:205
+msgid "Do you wish to specify a geodetic datum for this location?"
+msgstr ""
+#: ../general/g.setproj/main.c:214
+#, c-format
+msgid "The current datum is %s (%s)"
+msgstr ""
+#: ../general/g.setproj/main.c:217
+msgid "Do you wish to change the datum (or datum transformation parameters)?"
+msgstr ""
+#: ../general/g.setproj/main.c:225
+msgid "The datum information has not been changed"
+msgstr ""
+#: ../general/g.setproj/main.c:288
+#, c-format
+msgid "The current ellipsoid is %s"
+msgstr ""
+#: ../general/g.setproj/main.c:290
+msgid "Do you want to change ellipsoid parameter?"
+msgstr ""
+#: ../general/g.setproj/main.c:294
+msgid "The ellipse information has not been changed"
+msgstr ""
+#: ../general/g.setproj/main.c:311
+#, c-format
+msgid "The radius is currently %f"
+msgstr ""
+#: ../general/g.setproj/main.c:312
+msgid "Do you want to change the radius?"
+msgstr ""
+#: ../general/g.setproj/main.c:314 ../general/g.setproj/main.c:320
+msgid "Enter radius for the sphere in meters"
+msgstr ""
+#: ../general/g.setproj/main.c:336
+msgid "Invalid input ellipsoid"
+msgstr ""
+#: ../general/g.setproj/main.c:447
+#, c-format
+msgid "The UTM zone is now set to %d"
+msgstr ""
+#: ../general/g.setproj/main.c:450
+msgid "Do you want to change the UTM zone?"
+msgstr ""
+#: ../general/g.setproj/main.c:451
+msgid "UTM zone information has not been updated"
+msgstr ""
+#: ../general/g.setproj/main.c:456
+msgid "But if you change zone, all the existing data will be interpreted by projection software. GRASS will not automatically re-project or even change the headers for existing maps."
+msgstr ""
+#: ../general/g.setproj/main.c:461
+msgid "Would you still like to change the UTM zone?"
+msgstr ""
+#: ../general/g.setproj/main.c:497
+#, c-format
+msgid "Error writing PROJ_INFO file <%s>"
+msgstr ""
+#: ../general/g.setproj/main.c:571
+#, c-format
+msgid "Enter plural form of units [meters]: "
+msgstr ""
+#: ../general/g.setproj/main.c:603
+#, c-format
+msgid "Enter singular for unit: "
+msgstr ""
+#: ../general/g.setproj/main.c:611
+#, c-format
+msgid "Enter conversion factor from %s to meters: "
+msgstr ""
+#: ../general/g.setproj/main.c:636
+#, c-format
+msgid "Error writing into UNITS output file <%s>"
+msgstr ""
+#: ../general/g.setproj/main.c:643
+msgid "Unable to write to DEFAULT_WIND region file"
+msgstr ""
+#: ../general/g.setproj/main.c:645
+#, c-format
+msgid ""
+"\n"
+"Projection information has been recorded for this location\n"
+"\n"
+msgstr ""
+#: ../general/g.setproj/main.c:647
+msgid "The geographic region information in WIND is now obsolete"
+msgstr ""
+#: ../general/g.setproj/main.c:648
+msgid "Run g.region -d to update it"
+msgstr ""
+#: ../general/g.setproj/proj.c:168
+#, c-format
+msgid "Unrecognized 'ask' value in parms.table: %s"
+msgstr ""
+#: ../general/g.setproj/proj.c:178
+#, c-format
+msgid "Unrecognized default value in parms.table: %s"
+msgstr ""
+#: ../general/g.setproj/get_stp.c:43
+msgid "This should not happen. See your system admin."
+msgstr ""
+#: ../general/g.setproj/get_stp.c:99
+msgid "Unable to open FIPS code file"
+msgstr ""
+#: ../general/g.setproj/get_stp.c:125
+#, c-format
+msgid "No match of FIPS state %d county %d"
+msgstr ""
+#: ../general/g.setproj/get_stp.c:179
+msgid "Reading sf key_value temp file"
+msgstr ""
+#: ../general/g.setproj/get_stp.c:212
+msgid "Invalid State FIPS code"
+msgstr ""
+#: ../general/g.setproj/get_stp.c:302
+msgid "Reading cf key_value temp file"
+msgstr ""
+#: ../general/g.setproj/get_stp.c:336
+msgid "Invalid County FIPS code"
+msgstr ""
+#: ../general/g.access/exp_perms.c:11 ../general/g.access/exp_perms.c:29
+msgid "have"
+msgstr ""
+#: ../general/g.access/exp_perms.c:12
+msgid "read "
+msgstr ""
+#: ../general/g.access/exp_perms.c:15
+msgid "Everyone"
+msgstr ""
+#: ../general/g.access/exp_perms.c:16
+msgid "has"
+msgstr ""
+#: ../general/g.access/exp_perms.c:19
+msgid "Only users in your group"
+msgstr ""
+#: ../general/g.access/exp_perms.c:22
+msgid "Only users outside your group"
+msgstr ""
+#: ../general/g.access/exp_perms.c:25
+msgid "Only you"
+msgstr ""
+#: ../general/g.access/exp_perms.c:31
+#, c-format
+msgid "%s %s %s %saccess to mapset %s"
+msgstr ""
+#: ../general/g.access/exp_perms.c:32
+msgid "will"
+msgstr ""
+msgid "now"
+msgstr ""
+#: ../general/g.access/main.c:39
+msgid "permission"
+msgstr ""
+#: ../general/g.access/main.c:41
+msgid "Controls access to the current mapset for other users on the system."
+msgstr ""
+#: ../general/g.access/main.c:42
+msgid "If no option given, prints current status."
+msgstr ""
+#: ../general/g.access/main.c:49
+msgid "Access for group"
+msgstr ""
+#: ../general/g.access/main.c:57
+msgid "Access for others"
+msgstr ""
+#: ../general/g.access/main.c:64
+msgid "UNIX filesystem access controls are not supported by MS-Windows"
+msgstr ""
+#: ../general/g.access/main.c:72
+msgid "Access to the PERMANENT mapset must be open, nothing changed"
+msgstr ""
+#: ../general/g.access/main.c:76
+msgid "Unable to determine mapset permissions"
+msgstr ""
+#: ../general/g.access/set_perms.c:26
+msgid "Unable to change mapset permissions"
+msgstr ""
+#: ../general/g.filename/main.c:42
+msgid "Prints GRASS data base file names."
+msgstr ""
+#: ../general/g.filename/main.c:56
+msgid "Name of a database file"
+msgstr ""
+#: ../general/g.filename/main.c:62
+msgid "Name of a mapset (default: current)"
+msgstr ""
+#: ../general/g.remove/check_reclass.c:16
+#, c-format
+msgid "Raster map <%s@%s> is a base map for <%s>. Remove forced."
+msgstr ""
+#: ../general/g.remove/check_reclass.c:19
+#, c-format
+msgid "Raster map <%s@%s> is a base map. Remove reclassed map <%s> first."
+msgstr ""
+#: ../general/g.remove/check_reclass.c:41
+#: ../general/g.remove/check_reclass.c:54
+#, c-format
+msgid "Removing information about reclassed map from <%s@%s> failed"
+msgstr ""
+#: ../general/g.remove/main.c:73
+msgid "Removes data base element files from the user's current mapset using the search pattern."
+msgstr ""
+#: ../general/g.remove/main.c:83 ../general/g.remove/main.c:91
+#: ../general/g.remove/main.c:133 ../vector/v.kernel/main.c:121
+#: ../vector/v.kernel/main.c:135 ../vector/v.kernel/main.c:149
+msgid "Basic"
+msgstr ""
+#: ../general/g.remove/main.c:90
+msgid "Name of file(s) to remove"
+msgstr ""
+#: ../general/g.remove/main.c:99
+msgid "Name of file(s) to ignore (default: none)"
+msgstr ""
+#: ../general/g.remove/main.c:105
+msgid "File name search pattern"
+msgstr ""
+#: ../general/g.remove/main.c:111
+msgid "File name exclusion pattern (default: none)"
+msgstr ""
+#: ../general/g.remove/main.c:139
+msgid "Remove base raster maps"
+msgstr ""
+#: ../general/g.remove/main.c:208
+msgid "The following data base element files would be deleted:"
+msgstr ""
+#: ../general/g.remove/main.c:259
+msgid "No data base element files found"
+msgstr ""
+#: ../general/g.remove/main.c:267
+#, c-format
+msgid "Nothing removed. You must use the force flag (-%c) to actually remove them. Exiting."
+msgstr ""
+#: ../general/g.remove/construct_pattern.c:37
+#, c-format
+msgid "%s: Cannot remove or exclude files not in the current mapset."
+msgstr ""
+#: ../general/g.remove/construct_pattern.c:57
+msgid "Illegal filenames not allowed in the name or ignore option."
+msgstr ""
+#: ../general/g.tempfile/main.c:41
+msgid "Creates a temporary file and prints it's file name."
+msgstr ""
+#: ../general/g.tempfile/main.c:47
+msgid "Process id to use when naming the tempfile"
+msgstr ""
+#: ../general/g.tempfile/main.c:51
+msgid "Dry run - don't create a file, just prints it's file name"
+msgstr ""
+#: ../general/g.mkfontcap/freetype_fonts.c:55
+msgid "Unable to initialise Freetype"
+msgstr ""
+#: ../general/g.mkfontcap/main.c:73
+msgid "Generates the font configuration file by scanning various directories for fonts."
+msgstr ""
+#: ../general/g.mkfontcap/main.c:79
+msgid "Overwrite font configuration file if already existing"
+msgstr ""
+#: ../general/g.mkfontcap/main.c:84
+msgid "Write font configuration file to standard output instead of $GISBASE/etc"
+msgstr ""
+#: ../general/g.mkfontcap/main.c:91
+msgid "List of extra directories to scan"
+msgstr ""
+#: ../general/g.mkfontcap/main.c:93
+msgid "Comma-separated list of extra directories to scan for Freetype-compatible fonts as well as the defaults (see documentation)"
+msgstr ""
+#: ../general/g.mkfontcap/main.c:110
+#, c-format
+msgid "Fontcap file %s already exists; use -%c flag if you wish to overwrite it"
+msgstr ""
+#: ../general/g.mkfontcap/main.c:122
+msgid "This GRASS installation was compiled without Freetype support, extradirs parameter ignored"
+msgstr ""
+#: ../general/g.mkfontcap/main.c:149
+#, c-format
+msgid "Cannot open %s for writing: %s"
+msgstr ""
+#: ../imagery/i.eb.hsebal01/main.c:105 ../imagery/i.eb.soilheatflux/main.c:50
+#: ../imagery/i.eb.eta/main.c:43 ../imagery/i.eb.evapfr/main.c:48
+#: ../imagery/i.eb.netrad/main.c:57 ../imagery/i.emissivity/main.c:47
+msgid "energy balance"
+msgstr ""
+#: ../imagery/i.eb.hsebal01/main.c:106 ../imagery/i.eb.evapfr/main.c:49
+msgid "soil moisture"
+msgstr ""
+#: ../imagery/i.eb.hsebal01/main.c:107 ../imagery/i.eb.evapfr/main.c:50
+msgid "evaporative fraction"
+msgstr ""
+#: ../imagery/i.eb.hsebal01/main.c:108 ../imagery/i.eb.soilheatflux/main.c:52
+#: ../imagery/i.eb.eta/main.c:45 ../imagery/i.eb.evapfr/main.c:51
+#: ../imagery/i.eb.netrad/main.c:59
+msgid "SEBAL"
+msgstr ""
+#: ../imagery/i.eb.hsebal01/main.c:110
+msgid "Computes sensible heat flux iteration SEBAL 01."
+msgstr ""
+#: ../imagery/i.eb.hsebal01/main.c:116
+msgid "Name of instantaneous net radiation raster map [W/m2]"
+msgstr ""
+#: ../imagery/i.eb.hsebal01/main.c:121
+msgid "Name of instantaneous soil heat flux raster map [W/m2]"
+msgstr ""
+#: ../imagery/i.eb.hsebal01/main.c:126
+msgid "Name of aerodynamic resistance to heat momentum raster map [s/m]"
+msgstr ""
+#: ../imagery/i.eb.hsebal01/main.c:131
+msgid "Name of altitude corrected surface temperature raster map [K]"
+msgstr ""
+#: ../imagery/i.eb.hsebal01/main.c:140
+msgid "Value of the height independent friction velocity (u*) [m/s]"
+msgstr ""
+#: ../imagery/i.eb.hsebal01/main.c:149
+msgid "Value of the actual vapour pressure (e_act) [KPa]"
+msgstr ""
+#: ../imagery/i.eb.hsebal01/main.c:156
+msgid "Row value of the wet pixel"
+msgstr ""
+#: ../imagery/i.eb.hsebal01/main.c:163
+msgid "Column value of the wet pixel"
+msgstr ""
+#: ../imagery/i.eb.hsebal01/main.c:170
+msgid "Row value of the dry pixel"
+msgstr ""
+#: ../imagery/i.eb.hsebal01/main.c:177
+msgid "Column value of the dry pixel"
+msgstr ""
+#: ../imagery/i.eb.hsebal01/main.c:182
+msgid "Name for output sensible heat flux raster map [W/m2]"
+msgstr ""
+#: ../imagery/i.eb.hsebal01/main.c:187
+msgid "Automatic wet/dry pixel (careful!)"
+msgstr ""
+#: ../imagery/i.eb.hsebal01/main.c:192
+msgid "Dry/Wet pixels coordinates are in image projection, not row/col"
+msgstr ""
+#: ../imagery/i.eb.hsebal01/main.c:210
+msgid "Automatic mode selected"
+msgstr ""
+#: ../imagery/i.eb.hsebal01/main.c:222
+msgid "Manual wet/dry pixels in image coordinates"
+msgstr ""
+#: ../imagery/i.eb.hsebal01/main.c:223
+#, c-format
+msgid "Wet Pixel=> x:%f y:%f"
+msgstr ""
+#: ../imagery/i.eb.hsebal01/main.c:224
+#, c-format
+msgid "Dry Pixel=> x:%f y:%f"
+msgstr ""
+#: ../imagery/i.eb.hsebal01/main.c:228
+msgid "Either auto-mode either wet/dry pixels coordinates should be provided!"
+msgstr ""
+#: ../imagery/i.eb.hsebal01/main.c:233
+#, c-format
+msgid "<%s> is an illegal name"
+msgstr ""
+#: ../imagery/i.rgb.his/main.c:52
+msgid "Transforms raster maps from RGB (Red-Green-Blue) color space to HIS (Hue-Intensity-Saturation) color space."
+msgstr ""
+#: ../imagery/i.rgb.his/main.c:58
+msgid "Name of input raster map (red)"
+msgstr ""
+#: ../imagery/i.rgb.his/main.c:62
+msgid "Name of input raster map (green)"
+msgstr ""
+#: ../imagery/i.rgb.his/main.c:66
+msgid "Name of input raster map (blue)"
+msgstr ""
+#: ../imagery/i.rgb.his/main.c:70
+msgid "Name for output raster map (hue)"
+msgstr ""
+#: ../imagery/i.rgb.his/main.c:74
+msgid "Name for output raster map (intensity)"
+msgstr ""
+#: ../imagery/i.rgb.his/main.c:78
+msgid "Name for output raster map (saturation)"
+msgstr ""
+#: ../imagery/i.segment/region_growing.c:93 ../imagery/i.segment/cluster.c:342
+#: ../imagery/i.segment/cluster.c:412
+msgid "Too many objects: integer overflow"
+msgstr ""
+#: ../imagery/i.segment/region_growing.c:256
+#: ../imagery/i.segment/mean_shift.c:220
+#, c-format
+msgid "Processing pass %d..."
+msgstr ""
+#: ../imagery/i.segment/region_growing.c:534
+#, c-format
+msgid "Segmentation processes stopped at %d due to reaching max iteration limit, more merges may be possible"
+msgstr ""
+#: ../imagery/i.segment/region_growing.c:536
+#, c-format
+msgid "Segmentation converged after %d iterations"
+msgstr ""
+#: ../imagery/i.segment/region_growing.c:539
+msgid "Assigning region IDs to remaining single-cell regions..."
+msgstr ""
+#: ../imagery/i.segment/region_growing.c:563
+#: ../imagery/i.segment/mean_shift.c:686
+#, c-format
+msgid "Merging segments smaller than %d cells..."
+msgstr ""
+#: ../imagery/i.segment/region_growing.c:988
+#, c-format
+msgid "Region stats should go in tree, %d >= %d"
+msgstr ""
+#: ../imagery/i.segment/region_growing.c:995
+msgid "Region ids are different"
+msgstr ""
+#: ../imagery/i.segment/region_growing.c:999
+#, c-format
+msgid "Region id %d is invalid"
+msgstr ""
+#: ../imagery/i.segment/region_growing.c:1003
+msgid "Region consists of only one cell, nothing to update"
+msgstr ""
+#: ../imagery/i.segment/region_growing.c:1047
+#: ../imagery/i.segment/region_growing.c:1509
+#, c-format
+msgid "Region size is larger than 2: %d"
+msgstr ""
+#: ../imagery/i.segment/region_growing.c:1122
+#, c-format
+msgid "Region size is %d, should be %d"
+msgstr ""
+#: ../imagery/i.segment/region_growing.c:1364
+#, c-format
+msgid "Candidate flag is already %s"
+msgstr ""
+msgid "set"
+msgstr ""
+msgid "unset"
+msgstr ""
+#: ../imagery/i.segment/region_growing.c:1601
+#, c-format
+msgid "Region of size %d should be in search tree"
+msgstr ""
+#: ../imagery/i.segment/write_output.c:24
+msgid "Writing out segment IDs..."
+msgstr ""
+#: ../imagery/i.segment/write_output.c:120
+msgid "Writing out goodness of fit"
+msgstr ""
+#: ../imagery/i.segment/write_output.c:236
+msgid "Writing out shifted band values..."
+msgstr ""
+#: ../imagery/i.segment/main.c:37 ../imagery/i.smap/main.c:41
+msgid "segmentation"
+msgstr ""
+#: ../imagery/i.segment/main.c:39
+msgid "object recognition"
+msgstr ""
+#: ../imagery/i.segment/main.c:41
+msgid "Identifies segments (objects) from imagery data."
+msgstr ""
+#: ../imagery/i.segment/main.c:47
+msgid "Error in reading data"
+msgstr ""
+#: ../imagery/i.segment/main.c:51
+msgid "Error in creating segments"
+msgstr ""
+#: ../imagery/i.segment/main.c:55
+msgid "Error in writing IDs"
+msgstr ""
+#: ../imagery/i.segment/main.c:59
+msgid "Error in writing goodness of fit"
+msgstr ""
+#: ../imagery/i.segment/main.c:64
+msgid "Error in writing new band values"
+msgstr ""
+#: ../imagery/i.segment/main.c:70
+#, c-format
+msgid "Number of segments created: %d"
+msgstr ""
+#: ../imagery/i.segment/flag.c:21 ../imagery/i.segment/flag.c:28
+#: ../vector/v.distance/main.c:810 ../vector/v.distance/main.c:887
+#: ../vector/v.distance/main.c:1097
+msgid "Out of memory!"
+msgstr ""
+#: ../imagery/i.segment/watershed.c:19
+msgid "Watershed is not yet implemented"
+msgstr ""
+#: ../imagery/i.segment/cluster.c:66
+#, c-format
+msgid "%d-band clustering with threshold %g"
+msgstr ""
+#: ../imagery/i.segment/cluster.c:135
+msgid "Assigning initial region IDs..."
+msgstr ""
+#: ../imagery/i.segment/cluster.c:425
+msgid "Assigning final region IDs..."
+msgstr ""
+#: ../imagery/i.segment/cluster.c:455
+#, c-format
+msgid "Found %d clumps"
+msgstr ""
+#: ../imagery/i.segment/parse_args.c:26
+msgid "Name of input imagery group or raster maps"
+msgstr ""
+#: ../imagery/i.segment/parse_args.c:33
+msgid "Suffix for output bands with modified band values"
+msgstr ""
+#: ../imagery/i.segment/parse_args.c:39
+msgid "Difference threshold between 0 and 1"
+msgstr ""
+#: ../imagery/i.segment/parse_args.c:40
+msgid "Threshold = 0 merges only identical segments; threshold = 1 merges all"
+msgstr ""
+#: ../imagery/i.segment/parse_args.c:49
+msgid "Spatial radius in number of cells"
+msgstr ""
+#: ../imagery/i.segment/parse_args.c:50
+msgid "Must be >= 1, only cells within spatial bandwidth are considered for mean shift"
+msgstr ""
+#: ../imagery/i.segment/parse_args.c:56
+msgid "Range (spectral) bandwidth [0, 1]"
+msgstr ""
+#: ../imagery/i.segment/parse_args.c:57
+msgid "Only cells within range (spectral) bandwidth are considered for mean shift. Range bandwidth is used as conductance parameter for adaptive bandwidth"
+msgstr ""
+#: ../imagery/i.segment/parse_args.c:70
+msgid "Segmentation method"
+msgstr ""
+#: ../imagery/i.segment/parse_args.c:79
+msgid "Similarity calculation method"
+msgstr ""
+#: ../imagery/i.segment/parse_args.c:88
+msgid "Minimum number of cells in a segment"
+msgstr ""
+#: ../imagery/i.segment/parse_args.c:90
+msgid "The final step will merge small segments with their best neighbor"
+msgstr ""
+#: ../imagery/i.segment/parse_args.c:101
+msgid "Importance of radiometric (input raster) values relative to shape"
+msgstr ""
+#: ../imagery/i.segment/parse_args.c:111
+msgid "Importance of smoothness relative to compactness"
+msgstr ""
+#: ../imagery/i.segment/parse_args.c:120
+msgid "Memory in MB"
+msgstr ""
+#: ../imagery/i.segment/parse_args.c:129 ../imagery/i.cluster/main.c:126
+msgid "Maximum number of iterations"
+msgstr ""
+#: ../imagery/i.segment/parse_args.c:137
+msgid "Name for input raster map with starting seeds"
+msgstr ""
+#: ../imagery/i.segment/parse_args.c:144
+msgid "Name of input bounding/constraining raster map"
+msgstr ""
+#: ../imagery/i.segment/parse_args.c:146
+msgid "Must be integer values, each area will be segmented independent of the others"
+msgstr ""
+#: ../imagery/i.segment/parse_args.c:153
+msgid "Name for output goodness of fit estimate map"
+msgstr ""
+#: ../imagery/i.segment/parse_args.c:159
+msgid "Use 8 neighbors (3x3 neighborhood) instead of the default 4 neighbors for each pixel"
+msgstr ""
+#: ../imagery/i.segment/parse_args.c:165
+msgid "Weighted input, do not perform the default scaling of input raster maps"
+msgstr ""
+#: ../imagery/i.segment/parse_args.c:170
+msgid "Use adaptive bandwidth for mean shift"
+msgstr ""
+#: ../imagery/i.segment/parse_args.c:171
+msgid "Range (spectral) bandwidth is adapted for each moving window"
+msgstr ""
+#: ../imagery/i.segment/parse_args.c:176
+msgid "Use progressive bandwidth for mean shift"
+msgstr ""
+#: ../imagery/i.segment/parse_args.c:178
+msgid "Spatial bandwidth is increased, range (spectral) bandwidth is decreased in each iteration"
+msgstr ""
+#: ../imagery/i.segment/parse_args.c:210
+#, c-format
+msgid "Group <%s> not found in the current mapset"
+msgstr ""
+#: ../imagery/i.segment/parse_args.c:214
+#, c-format
+msgid "Group <%s> contains no raster maps"
+msgstr ""
+#: ../imagery/i.segment/parse_args.c:229
+msgid "Threshold should be > 0 and < 1"
+msgstr ""
+#: ../imagery/i.segment/parse_args.c:235
+#, c-format
+msgid "Option '%s' must be >= 1"
+msgstr ""
+#: ../imagery/i.segment/parse_args.c:243
+#, c-format
+msgid "Negative value %s for option '%s': disabling"
+msgstr ""
+#: ../imagery/i.segment/parse_args.c:248
+#, c-format
+msgid "Value %s for option '%s' is >= 1: disabling"
+msgstr ""
+#: ../imagery/i.segment/parse_args.c:270
+msgid "Unable to assign segmentation method"
+msgstr ""
+#: ../imagery/i.segment/parse_args.c:280
+msgid "Invalid similarity method"
+msgstr ""
+#: ../imagery/i.segment/parse_args.c:286
+#, c-format
+msgid "Option '%s' must be > 0"
+msgstr ""
+#: ../imagery/i.segment/parse_args.c:288 ../imagery/i.segment/parse_args.c:293
+#, c-format
+msgid "Option '%s' must be <= 1"
+msgstr ""
+#: ../imagery/i.segment/parse_args.c:291
+#, c-format
+msgid "Option '%s' must be >= 0"
+msgstr ""
+#: ../imagery/i.segment/parse_args.c:319
+msgid "Seeds raster map not found"
+msgstr ""
+#: ../imagery/i.segment/parse_args.c:323
+msgid "Seeeds raster map must be CELL type (integers)"
+msgstr ""
+#: ../imagery/i.segment/parse_args.c:333
+msgid "Segmentation constraint/boundary raster map not found"
+msgstr ""
+#: ../imagery/i.segment/parse_args.c:337
+msgid "Segmentation constraint raster map must be CELL type (integers)"
+msgstr ""
+#: ../imagery/i.segment/parse_args.c:356
+msgid "Integer overflow: too many cells in current region"
+msgstr ""
+#: ../imagery/i.segment/parse_args.c:369
+msgid "Invalid output raster name for goodness of fit"
+msgstr ""
+#: ../imagery/i.segment/parse_args.c:376
+#, c-format
+msgid "Maximum number of iterations set to %d"
+msgstr ""
+#: ../imagery/i.segment/parse_args.c:386
+#, c-format
+msgid "Invalid number of iterations, %d will be used"
+msgstr ""
+#: ../imagery/i.segment/parse_args.c:395
+msgid "Invalid number of MB, 300 will be used"
+msgstr ""
+#: ../imagery/i.segment/open_files.c:106
+msgid "Insufficient number of non-NULL cells in current region"
+msgstr ""
+#: ../imagery/i.segment/open_files.c:137
+msgid "Loading input bands..."
+msgstr ""
+#: ../imagery/i.segment/open_files.c:139
+msgid "Loading input band..."
+msgstr ""
+#: ../imagery/i.segment/open_files.c:171 ../imagery/i.segment/open_files.c:176
+#: ../imagery/i.segment/open_files.c:198 ../imagery/i.segment/open_files.c:256
+#: ../imagery/i.segment/open_files.c:344 ../imagery/i.segment/open_files.c:410
+#: ../imagery/i.segment/open_files.c:466
+msgid "Unable to write to temporary file"
+msgstr ""
+#: ../imagery/i.segment/open_files.c:263
+#, c-format
+msgid "There are no boundary constraints in '%s'"
+msgstr ""
+#: ../imagery/i.segment/open_files.c:319
+#, c-format
+msgid "Loading seeds from raster map <%s>..."
+msgstr ""
+#: ../imagery/i.segment/open_files.c:349
+#, c-format
+msgid "No seeds found in '%s'!"
+msgstr ""
+#: ../imagery/i.segment/open_files.c:369
+msgid "Too many seeds: integer overflow"
+msgstr ""
+#: ../imagery/i.segment/open_files.c:486
+#, c-format
+msgid "Segment %d is already registered!"
+msgstr ""
+#: ../imagery/i.segment/open_files.c:540
+#, c-format
+msgid "Regions with at least %d cells are stored in memory"
+msgstr ""
+#: ../imagery/i.segment/open_files.c:580
+#, c-format
+msgid "Number of segments in memory: %d of %d total"
+msgstr ""
+#: ../imagery/i.segment/mean_shift.c:93
+#, c-format
+msgid "Estimating spectral bandwidth for spatial bandwidth %g..."
+msgstr ""
+#: ../imagery/i.segment/mean_shift.c:167
+msgid "Empty moving windows"
+msgstr ""
+#: ../imagery/i.segment/mean_shift.c:186
+#, c-format
+msgid "Initial range bandwidth: %g"
+msgstr ""
+#: ../imagery/i.segment/mean_shift.c:188 ../imagery/i.segment/mean_shift.c:192
+#, c-format
+msgid "Estimated range bandwidth: %g"
+msgstr ""
+#: ../imagery/i.segment/mean_shift.c:208 ../imagery/i.segment/mean_shift.c:245
+#, c-format
+msgid "Spatial bandwidth: %g"
+msgstr ""
+#: ../imagery/i.segment/mean_shift.c:209 ../imagery/i.segment/mean_shift.c:246
+#, c-format
+msgid "Range bandwidth: %g"
+msgstr ""
+#: ../imagery/i.segment/mean_shift.c:395
+#, c-format
+msgid "Changes > threshold: %d, largest change: %g"
+msgstr ""
+#: ../imagery/i.segment/mean_shift.c:398
+#, c-format
+msgid "Mean shift stopped at %d due to reaching max iteration limit, more changes may be possible"
+msgstr ""
+#: ../imagery/i.segment/mean_shift.c:400
+#, c-format
+msgid "Mean shift converged after %d iterations"
+msgstr ""
+#: ../imagery/i.segment/mean_shift.c:769
+#, c-format
+msgid "Renumbering remaining %d segments..."
+msgstr ""
+#: ../imagery/i.eb.soilheatflux/main.c:51
+msgid "soil heat flux"
+msgstr ""
+#: ../imagery/i.eb.soilheatflux/main.c:53
+msgid "Soil heat flux approximation (Bastiaanssen, 1995)."
+msgstr ""
+#: ../imagery/i.eb.soilheatflux/main.c:58 ../imagery/i.eb.netrad/main.c:66
+msgid "Name of albedo raster map [0.0;1.0]"
+msgstr ""
+#: ../imagery/i.eb.soilheatflux/main.c:62 ../imagery/i.eb.netrad/main.c:70
+msgid "Name of NDVI raster map [-1.0;+1.0]"
+msgstr ""
+#: ../imagery/i.eb.soilheatflux/main.c:67
+msgid "Name of Surface temperature raster map [K]"
+msgstr ""
+#: ../imagery/i.eb.soilheatflux/main.c:71 ../imagery/i.eb.evapfr/main.c:58
+msgid "Name of Net Radiation raster map [W/m2]"
+msgstr ""
+#: ../imagery/i.eb.soilheatflux/main.c:76 ../imagery/i.eb.netrad/main.c:80
+msgid "Name of time of satellite overpass raster map [local time in UTC]"
+msgstr ""
+#: ../imagery/i.eb.soilheatflux/main.c:83
+msgid "HAPEX-Sahel empirical correction (Roerink, 1995)"
+msgstr ""
+#: ../imagery/i.gensig/covariance.c:30
+msgid "Calculating class covariance matrices..."
+msgstr ""
+#: ../imagery/i.gensig/main.c:41 ../imagery/i.smap/main.c:40
+#: ../imagery/i.gensigset/main.c:42
+msgid "supervised classification"
+msgstr ""
+#: ../imagery/i.gensig/main.c:42 ../imagery/i.maxlik/main.c:63
+msgid "Maximum Likelihood Classification"
+msgstr ""
+#: ../imagery/i.gensig/main.c:44 ../imagery/i.gensigset/main.c:44
+#: ../imagery/i.cluster/main.c:77
+msgid "signatures"
+msgstr ""
+#: ../imagery/i.gensig/main.c:46
+msgid "Generates statistics for i.maxlik from raster map."
+msgstr ""
+#: ../imagery/i.gensig/openfiles.c:19 ../imagery/i.smap/openfiles.c:18
+#: ../imagery/i.smap/read_sig.c:13 ../imagery/i.gensigset/openfiles.c:18
+#, c-format
+msgid "Unable to read REF file for subgroup <%s> in group <%s>"
+msgstr ""
+#: ../imagery/i.gensig/openfiles.c:23 ../imagery/i.gensigset/openfiles.c:22
+#, c-format
+msgid "Subgroup <%s> in group <%s> contains no raster maps."
+msgstr ""
+#: ../imagery/i.gensig/check.c:21
+#, c-format
+msgid "Signature %d not invertible"
+msgstr ""
+#: ../imagery/i.gensig/check.c:27
+#, c-format
+msgid "Signature %d unable to get eigen values"
+msgstr ""
+#: ../imagery/i.gensig/check.c:33
+#, c-format
+msgid "Signature %d not positive definite"
+msgstr ""
+#: ../imagery/i.gensig/write_sig.c:15 ../imagery/i.gensigset/write_sig.c:13
+#, c-format
+msgid "Unable to create signature file <%s>"
+msgstr ""
+#: ../imagery/i.gensig/write_sig.c:18 ../imagery/i.gensigset/write_sig.c:16
+msgid "Writing signatures..."
+msgstr ""
+#: ../imagery/i.gensig/get_train.c:32 ../imagery/i.gensigset/get_train.c:35
+msgid "Finding training classes..."
+msgstr ""
+#: ../imagery/i.gensig/get_train.c:55 ../imagery/i.gensigset/get_train.c:58
+#, c-format
+msgid "Training class %d only has one cell - this class will be ignored"
+msgstr ""
+#: ../imagery/i.gensig/get_train.c:60 ../imagery/i.gensigset/get_train.c:63
+msgid "Training map has no classes"
+msgstr ""
+#: ../imagery/i.gensig/get_train.c:75 ../imagery/i.gensigset/get_train.c:79
+msgid "1 class found"
+msgstr ""
+#: ../imagery/i.gensig/get_train.c:77 ../imagery/i.gensigset/get_train.c:81
+#, c-format
+msgid "%d classes found"
+msgstr ""
+#: ../imagery/i.gensig/means.c:26
+msgid "Calculating class means..."
+msgstr ""
+#: ../imagery/i.gensig/parse.c:14 ../imagery/i.gensigset/parse.c:13
+msgid "Ground truth training map"
+msgstr ""
+#: ../imagery/i.gensig/parse.c:26 ../imagery/i.gensigset/parse.c:25
+#: ../imagery/i.cluster/main.c:95
+msgid "Name for output file containing result signatures"
+msgstr ""
+#: ../imagery/i.gensig/parse.c:41 ../imagery/i.maxlik/open.c:17
+#: ../imagery/i.smap/parse.c:61 ../imagery/i.gensigset/parse.c:47
+#: ../imagery/i.cluster/main.c:169
+#, c-format
+msgid "Group <%s> not found in current mapset"
+msgstr ""
+#: ../imagery/i.gensig/parse.c:44 ../imagery/i.maxlik/open.c:20
+#: ../imagery/i.smap/parse.c:64 ../imagery/i.gensigset/parse.c:50
+#: ../imagery/i.cluster/main.c:172
+#, c-format
+msgid "Subgroup <%s> in group <%s> not found"
+msgstr ""
+#: ../imagery/i.evapo.mh/main.c:70 ../imagery/i.evapo.pt/main.c:67
+#: ../imagery/i.evapo.time/main.c:78 ../imagery/i.evapo.pm/main.c:59
+msgid "evapotranspiration"
+msgstr ""
+#: ../imagery/i.evapo.mh/main.c:72
+msgid "Computes evapotranspiration calculation modified or original Hargreaves formulation, 2001."
+msgstr ""
+#: ../imagery/i.evapo.mh/main.c:78
+msgid "Name of input diurnal net radiation raster map [W/m2/d]"
+msgstr ""
+#: ../imagery/i.evapo.mh/main.c:82
+msgid "Name of input average air temperature raster map [C]"
+msgstr ""
+#: ../imagery/i.evapo.mh/main.c:86
+msgid "Name of input minimum air temperature raster map [C]"
+msgstr ""
+#: ../imagery/i.evapo.mh/main.c:90
+msgid "Name of input maximum air temperature raster map [C]"
+msgstr ""
+#: ../imagery/i.evapo.mh/main.c:96
+msgid "Name of precipitation raster map [mm/month]"
+msgstr ""
+#: ../imagery/i.evapo.mh/main.c:97
+msgid "Disabled for original Hargreaves (1985)"
+msgstr ""
+#: ../imagery/i.evapo.mh/main.c:100
+msgid "Name for output raster map [mm/d]"
+msgstr ""
+#: ../imagery/i.evapo.mh/main.c:105 ../imagery/i.evapo.pt/main.c:102
+msgid "Set negative ETa to zero"
+msgstr ""
+#: ../imagery/i.evapo.mh/main.c:109
+msgid "Use original Hargreaves (1985)"
+msgstr ""
+#: ../imagery/i.evapo.mh/main.c:113
+msgid "Use Hargreaves-Samani (1985)"
+msgstr ""
+#: ../imagery/i.eb.eta/main.c:44
+msgid "actual evapotranspiration"
+msgstr ""
+#: ../imagery/i.eb.eta/main.c:47
+msgid "Actual evapotranspiration for diurnal period (Bastiaanssen, 1995)."
+msgstr ""
+#: ../imagery/i.eb.eta/main.c:52
+msgid "Name of the diurnal net radiation map [W/m2]"
+msgstr ""
+#: ../imagery/i.eb.eta/main.c:57
+msgid "Name of the evaporative fraction map [-]"
+msgstr ""
+#: ../imagery/i.eb.eta/main.c:62
+msgid "Name of the surface skin temperature [K]"
+msgstr ""
+#: ../imagery/i.eb.eta/main.c:67
+msgid "Name of the output actual evapotranspiration layer [mm/d]"
+msgstr ""
+#: ../imagery/i.his.rgb/main.c:52
+msgid "Transforms raster maps from HIS (Hue-Intensity-Saturation) color space to RGB (Red-Green-Blue) color space."
+msgstr ""
+#: ../imagery/i.his.rgb/main.c:58
+msgid "Name of input raster map (hue)"
+msgstr ""
+#: ../imagery/i.his.rgb/main.c:62
+msgid "Name of input raster map (intensity)"
+msgstr ""
+#: ../imagery/i.his.rgb/main.c:66
+msgid "Name of input raster map (saturation)"
+msgstr ""
+#: ../imagery/i.his.rgb/main.c:70
+msgid "Name for output raster map (red)"
+msgstr ""
+#: ../imagery/i.his.rgb/main.c:74
+msgid "Name for output raster map (green)"
+msgstr ""
+#: ../imagery/i.his.rgb/main.c:78
+msgid "Name for output raster map (blue)"
+msgstr ""
+#: ../imagery/i.rectify/readcell.c:63
+#: ../imagery/i.ortho.photo/i.ortho.rectify/readcell.c:74
+msgid "Allocating memory and reading input map..."
+msgstr ""
+#: ../imagery/i.rectify/rectify.c:43
+#: ../imagery/i.ortho.photo/i.ortho.rectify/rectify.c:43
+#, c-format
+msgid "Rectify <%s@%s> (location <%s>)"
+msgstr ""
+#: ../imagery/i.rectify/rectify.c:46
+#: ../imagery/i.ortho.photo/i.ortho.rectify/rectify.c:47
+#, c-format
+msgid "into <%s@%s> (location <%s>) ..."
+msgstr ""
+#: ../imagery/i.rectify/rectify.c:110
+#: ../imagery/i.ortho.photo/i.ortho.rectify/rectify.c:127
+#, c-format
+msgid "Raster map <%s@%s>: projection don't match current settings"
+msgstr ""
+#: ../imagery/i.rectify/rectify.c:116
+#: ../imagery/i.ortho.photo/i.ortho.rectify/rectify.c:133
+#, c-format
+msgid "Raster map <%s@%s>: zone don't match current settings"
+msgstr ""
+#: ../imagery/i.rectify/cp.c:12 ../vector/v.rectify/cp.c:350
+#, c-format
+msgid "Control Point file for group <%s@%s> - "
+msgstr ""
+#: ../imagery/i.rectify/cp.c:15
+#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:15
+msgid "Computing equations..."
+msgstr ""
+#: ../imagery/i.rectify/cp.c:24
+msgid "Not enough active control points for thin plate spline."
+msgstr ""
+#: ../imagery/i.rectify/cp.c:27 ../imagery/i.rectify/cp.c:51
+#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:21
+#: ../vector/v.rectify/cp.c:363
+msgid "Poorly placed control points."
+msgstr ""
+#: ../imagery/i.rectify/cp.c:28 ../imagery/i.rectify/cp.c:52
+#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:22
+#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:27
+#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:52
+#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:58
+#: ../vector/v.rectify/cp.c:364
+msgid " Can not generate the transformation equation."
+msgstr ""
+#: ../imagery/i.rectify/cp.c:31 ../imagery/i.rectify/cp.c:55
+msgid "Not enough memory to solve transformation equations."
+msgstr ""
+#: ../imagery/i.rectify/cp.c:34
+msgid "Invalid order."
+msgstr ""
+#: ../imagery/i.rectify/cp.c:47 ../vector/v.rectify/cp.c:359
+#, c-format
+msgid "Not enough active control points for current order, %d are required."
+msgstr ""
+#: ../imagery/i.rectify/cp.c:58 ../vector/v.rectify/cp.c:370
+msgid "Invalid order"
+msgstr ""
+#: ../imagery/i.rectify/main.c:84 ../vector/v.rectify/main.c:71
+msgid "rectify"
+msgstr ""
+#: ../imagery/i.rectify/main.c:86
+msgid "Rectifies an image by computing a coordinate transformation for each pixel in the image based on the control points."
+msgstr ""
+#: ../imagery/i.rectify/main.c:100
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:102
+msgid "Output raster map(s) suffix"
+msgstr ""
+#: ../imagery/i.rectify/main.c:108 ../vector/v.rectify/main.c:104
+msgid "Rectification polynomial order (1-3)"
+msgstr ""
+#: ../imagery/i.rectify/main.c:114
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:108
+msgid "Target resolution (ignored if -c flag used)"
+msgstr ""
+#: ../imagery/i.rectify/main.c:122
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:116
+msgid "Amount of memory to use in MB"
+msgstr ""
+#: ../imagery/i.rectify/main.c:137
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:136
+msgid "Use current region settings in target location (def.=calculate smallest area)"
+msgstr ""
+#: ../imagery/i.rectify/main.c:141
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:140
+msgid "Rectify all raster maps in group"
+msgstr ""
+#: ../imagery/i.rectify/main.c:145
+msgid "Use thin plate spline"
+msgstr ""
+#: ../imagery/i.rectify/main.c:180 ../vector/v.rectify/main.c:145
+#, c-format
+msgid "Invalid order (%d); please enter 1 to %d"
+msgstr ""
+#: ../imagery/i.rectify/main.c:187 ../imagery/i.pca/main.c:148
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:179
+#, c-format
+msgid "Group <%s> not found"
+msgstr ""
+#: ../imagery/i.rectify/main.c:192
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:184
+#, c-format
+msgid "Location: %s"
+msgstr ""
+#: ../imagery/i.rectify/main.c:193
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:185
+#, c-format
+msgid "Mapset: %s"
+msgstr ""
+#: ../imagery/i.rectify/main.c:194
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:186
+#, c-format
+msgid "Could not read REF file for group <%s>"
+msgstr ""
+#: ../imagery/i.rectify/main.c:199
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:191
+#, c-format
+msgid "Group <%s> contains no raster maps; run i.group"
+msgstr ""
+#: ../imagery/i.rectify/main.c:274
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:285
+#, c-format
+msgid "Extension <%s> is illegal"
+msgstr ""
+#: ../imagery/i.rectify/main.c:277
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:288
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:297
+msgid "The following raster map already exists in"
+msgstr ""
+#: ../imagery/i.rectify/main.c:278
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:289
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:298
+#: ../vector/v.rectify/main.c:204
+#, c-format
+msgid "target LOCATION %s, MAPSET %s:"
+msgstr ""
+#: ../imagery/i.rectify/main.c:281
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:292
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:301
+msgid "Orthorectification cancelled."
+msgstr ""
+#: ../imagery/i.rectify/main.c:296
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:316
+msgid "Target resolution must be > 0, ignored"
+msgstr ""
+#: ../imagery/i.rectify/main.c:303
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:323
+#, c-format
+msgid "Using region: N=%f S=%f, E=%f W=%f"
+msgstr ""
+#: ../imagery/i.rectify/main.c:325
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:390
+#, c-format
+msgid "Input raster map <%s> does not exist in group <%s>."
+msgstr ""
+#: ../imagery/i.rectify/main.c:327
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:392
+msgid "Try:"
+msgstr ""
+#: ../imagery/i.rectify/main.c:332
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:397
+msgid "Exit!"
+msgstr ""
+#: ../imagery/i.rectify/get_wind.c:180
+#, c-format
+msgid "Region N=%f S=%f E=%f W=%f"
+msgstr ""
+#: ../imagery/i.rectify/get_wind.c:182
+#, c-format
+msgid "Resolution EW=%f NS=%f"
+msgstr ""
+#: ../imagery/i.rectify/report.c:10
+#: ../imagery/i.ortho.photo/i.ortho.rectify/report.c:10
+msgid "complete"
+msgstr ""
+#: ../db/db.select/main.c:105
+msgid "failed"
+msgstr ""
+#: ../imagery/i.rectify/report.c:20
+#: ../imagery/i.ortho.photo/i.ortho.rectify/report.c:20
+#, c-format
+msgid "%d rows, %d cols (%ld cells) completed in"
+msgstr ""
+#: ../imagery/i.rectify/report.c:23
+#: ../imagery/i.ortho.photo/i.ortho.rectify/report.c:23
+#, c-format
+msgid "%d:%02d:%02d hours"
+msgstr ""
+#: ../imagery/i.rectify/report.c:25
+#: ../imagery/i.ortho.photo/i.ortho.rectify/report.c:25
+#, c-format
+msgid "%d:%02d minutes"
+msgstr ""
+#: ../imagery/i.rectify/report.c:27
+#: ../imagery/i.ortho.photo/i.ortho.rectify/report.c:27
+#, c-format
+msgid "%.1f cells per minute"
+msgstr ""
+#: ../imagery/i.rectify/target.c:13
+#: ../imagery/i.ortho.photo/i.ortho.rectify/target.c:13
+#: ../vector/v.rectify/target.c:18
+#, c-format
+msgid "Target information for group <%s> missing"
+msgstr ""
+#: ../imagery/i.rectify/target.c:19
+#: ../imagery/i.ortho.photo/i.ortho.rectify/target.c:19
+#: ../vector/v.rectify/target.c:29
+#, c-format
+msgid "Target location <%s> not found"
+msgstr ""
+#: ../imagery/i.rectify/target.c:35
+#: ../imagery/i.ortho.photo/i.ortho.rectify/target.c:35
+msgid "Please run i.target for group "
+msgstr ""
+#: ../imagery/i.maxlik/open.c:27
+#, c-format
+msgid "Subgroup <%s> of group <%s> doesn't have any raster maps. The subgroup must have at least 2 raster maps."
+msgstr ""
+#: ../imagery/i.maxlik/open.c:30
+#, c-format
+msgid "Subgroup <%s> of group <%s> only has 1 raster map. The subgroup must have at least 2 raster maps."
+msgstr ""
+#: ../imagery/i.maxlik/open.c:47
+#, c-format
+msgid "Unable to open signature file <%s>"
+msgstr ""
+#: ../imagery/i.maxlik/open.c:53 ../imagery/i.smap/read_sig.c:23
+#: ../imagery/i.cluster/open_files.c:60
+#, c-format
+msgid "Unable to read signature file <%s>"
+msgstr ""
+#: ../imagery/i.maxlik/open.c:57 ../imagery/i.cluster/open_files.c:64
+#, c-format
+msgid "<%s> has too many signatures (limit is 255)"
+msgstr ""
+#: ../imagery/i.maxlik/main.c:66
+msgid "Classifies the cell spectral reflectances in imagery data."
+msgstr ""
+#: ../imagery/i.maxlik/main.c:68
+msgid "Classification is based on the spectral signature information generated by either i.cluster, g.gui.iclass, or i.gensig."
+msgstr ""
+#: ../imagery/i.maxlik/main.c:81 ../imagery/i.smap/parse.c:20
+msgid "Name of input file containing signatures"
+msgstr ""
+#: ../imagery/i.maxlik/main.c:82
+msgid "Generated by either i.cluster, g.gui.iclass, or i.gensig"
+msgstr ""
+#: ../imagery/i.maxlik/main.c:86 ../imagery/i.smap/parse.c:28
+msgid "Name for output raster map holding classification results"
+msgstr ""
+#: ../imagery/i.maxlik/main.c:92
+msgid "Name for output raster map holding reject threshold results"
+msgstr ""
+#: ../imagery/i.maxlik/invert.c:28
+#, c-format
+msgid "Signature %d is not valid (ill-conditioned) - ignored"
+msgstr ""
+#: ../imagery/i.maxlik/invert.c:31
+#, c-format
+msgid "Signature %d is not valid (singular) - ignored"
+msgstr ""
+#: ../imagery/i.fft/main.c:80 ../imagery/i.ifft/main.c:79
+msgid "Fast Fourier Transform"
+msgstr ""
+#: ../imagery/i.fft/main.c:82
+msgid "Fast Fourier Transform (FFT) for image processing."
+msgstr ""
+#: ../imagery/i.fft/main.c:90
+msgid "Name for output real part arrays stored as raster map"
+msgstr ""
+#: ../imagery/i.fft/main.c:94
+msgid "Name for output imaginary part arrays stored as raster map"
+msgstr ""
+#: ../imagery/i.fft/main.c:106
+msgid "Raster MASK found, consider to remove (see man-page). Will continue..."
+msgstr ""
+#: ../imagery/i.fft/main.c:129
+#, c-format
+msgid "Reading the raster map <%s>..."
+msgstr ""
+#: ../imagery/i.fft/main.c:145
+msgid "Starting FFT..."
+msgstr ""
+#: ../imagery/i.fft/main.c:166 ../imagery/i.ifft/main.c:191
+msgid "Rotating data..."
+msgstr ""
+#: ../imagery/i.fft/main.c:174
+msgid "Writing transformed data..."
+msgstr ""
+#: ../imagery/i.fft/main.c:200
+msgid "FFT is now complete"
+msgstr ""
+#: ../imagery/i.smap/write_img.c:15
+msgid "Writing output raster map(s)..."
+msgstr ""
+#: ../imagery/i.smap/main.c:42 ../imagery/i.gensigset/main.c:43
+msgid "SMAP"
+msgstr ""
+#: ../imagery/i.smap/main.c:44
+msgid "Performs contextual image classification using sequential maximum a posteriori (SMAP) estimation."
+msgstr ""
+#: ../imagery/i.smap/openfiles.c:22 ../imagery/i.smap/read_sig.c:17
+#, c-format
+msgid "Subgroup <%s> in group <%s> contains no raster maps"
+msgstr ""
+#: ../imagery/i.smap/model.c:43
+#, c-format
+msgid "Nonsymetric covariance for class %d subclass %d"
+msgstr ""
+#: ../imagery/i.smap/model.c:55
+#, c-format
+msgid "Nonpositive eigenvalues for class %d subclass %d"
+msgstr ""
+#: ../imagery/i.smap/interp.c:233
+msgid "Invalid parameter values"
+msgstr ""
+#: ../imagery/i.smap/segment.c:67
+msgid "Number of classes must be < 256"
+msgstr ""
+#: ../imagery/i.smap/segment.c:102
+#, c-format
+msgid "Processing rows %d-%d (of %d)..."
+msgstr ""
+#: ../imagery/i.smap/read_sig.c:27
+#, c-format
+msgid "Signature file <%s> is invalid"
+msgstr ""
+#: ../imagery/i.smap/read_sig.c:30
+#, c-format
+msgid "Signature file <%s> is empty"
+msgstr ""
+#: ../imagery/i.smap/parse.c:21
+msgid "Generated by i.gensigset"
+msgstr ""
+#: ../imagery/i.smap/parse.c:33
+msgid "Name for output raster map holding goodness of fit (lower is better)"
+msgstr ""
+#: ../imagery/i.smap/parse.c:37
+msgid "Size of submatrix to process at one time"
+msgstr ""
+#: ../imagery/i.smap/parse.c:45
+msgid "Use maximum likelihood estimation (instead of smap)"
+msgstr ""
+#: ../imagery/i.eb.evapfr/main.c:53
+msgid "Computes evaporative fraction and root zone soil moisture."
+msgstr ""
+#: ../imagery/i.eb.evapfr/main.c:62
+msgid "Name of soil heat flux raster map [W/m2]"
+msgstr ""
+#: ../imagery/i.eb.evapfr/main.c:66
+msgid "Name of sensible heat flux raster map [W/m2]"
+msgstr ""
+#: ../imagery/i.eb.evapfr/main.c:71
+msgid "Name for output evaporative fraction raster map"
+msgstr ""
+#: ../imagery/i.eb.evapfr/main.c:77
+msgid "Name for output root zone soil moisture raster map"
+msgstr ""
+#: ../imagery/i.eb.evapfr/main.c:82
+msgid "Root zone soil moisture output (Makin, Molden and Bastiaanssen, 2001)"
+msgstr ""
+#: ../imagery/i.target/main.c:48
+msgid "Targets an imagery group to a GRASS location and mapset."
+msgstr ""
+#: ../imagery/i.target/main.c:57
+msgid "Name of imagery target location"
+msgstr ""
+#: ../imagery/i.target/main.c:63
+msgid "Name of target mapset"
+msgstr ""
+#: ../imagery/i.target/main.c:68
+msgid "Set current location and mapset as target for imagery group"
+msgstr ""
+#: ../imagery/i.target/main.c:80 ../imagery/i.group/main.c:117
+msgid "Group must exist in the current mapset"
+msgstr ""
+#: ../imagery/i.target/main.c:90 ../imagery/i.target/main.c:107
+#: ../imagery/i.target/main.c:116
+#, c-format
+msgid "Group <%s> targeted for location [%s], mapset [%s]"
+msgstr ""
+#: ../imagery/i.target/main.c:93
+#, c-format
+msgid "Group <%s> has no target"
+msgstr ""
+#: ../imagery/i.target/main.c:101
+msgid ""
+"Use either the Current Mapset and Location Flag (-c)\n"
+" OR\n"
+" manually enter the variables"
+msgstr ""
+#: ../imagery/i.evapo.pt/main.c:69
+msgid "Computes evapotranspiration calculation Priestley and Taylor formulation, 1972."
+msgstr ""
+#: ../imagery/i.evapo.pt/main.c:75
+msgid "Name of input net radiation raster map [W/m2]"
+msgstr ""
+#: ../imagery/i.evapo.pt/main.c:79
+msgid "Name of input soil heat flux raster map [W/m2]"
+msgstr ""
+#: ../imagery/i.evapo.pt/main.c:83
+msgid "Name of input air temperature raster map [K]"
+msgstr ""
+#: ../imagery/i.evapo.pt/main.c:87
+msgid "Name of input atmospheric pressure raster map [millibars]"
+msgstr ""
+#: ../imagery/i.evapo.pt/main.c:93
+msgid "Priestley-Taylor coefficient"
+msgstr ""
+#: ../imagery/i.evapo.pt/main.c:97
+msgid "Name of output evapotranspiration raster map [mm/d]"
+msgstr ""
+#: ../imagery/i.gensigset/main.c:46
+msgid "Generates statistics for i.smap from raster map."
+msgstr ""
+#: ../imagery/i.gensigset/main.c:56
+#, c-format
+msgid "Clustering class %d (%d pixels)..."
+msgstr ""
+#: ../imagery/i.gensigset/main.c:59
+#, c-format
+msgid "Number of subclasses is %d"
+msgstr ""
+#: ../imagery/i.gensigset/subcluster.c:76
+#, c-format
+msgid "Not enough pixels in class %d"
+msgstr ""
+#: ../imagery/i.gensigset/subcluster.c:86
+#, c-format
+msgid "Too many subclasses for class index %d"
+msgstr ""
+#: ../imagery/i.gensigset/subcluster.c:88
+#, c-format
+msgid "Number of subclasses set to %d"
+msgstr ""
+#: ../imagery/i.gensigset/subcluster.c:106
+#, c-format
+msgid "Combining subclasses (%d,%d)..."
+msgstr ""
+#: ../imagery/i.gensigset/subcluster.c:318
+#, c-format
+msgid "Subsignature %d only contains %.0f pixels"
+msgstr ""
+#: ../imagery/i.gensigset/subcluster.c:552
+msgid "Unreliable clustering. Try a smaller initial number of clusters"
+msgstr ""
+#: ../imagery/i.gensigset/subcluster.c:561
+#, c-format
+msgid "Removed a singular subsignature number %d (%d remain)"
+msgstr ""
+#: ../imagery/i.gensigset/parse.c:29
+msgid "Maximum number of sub-signatures in any class"
+msgstr ""
+#: ../imagery/i.gensigset/parse.c:63
+#, c-format
+msgid "Illegal number of sub-signatures (%s)"
+msgstr ""
+#: ../imagery/i.gensigset/read_data.c:22 ../imagery/i.cluster/main.c:293
+#: ../imagery/i.ifft/main.c:141
+msgid "Reading raster maps..."
+msgstr ""
+#: ../imagery/i.topo.corr/main.c:49
+msgid "topographic correction"
+msgstr ""
+#: ../imagery/i.topo.corr/main.c:50
+msgid "Computes topographic correction of reflectance."
+msgstr ""
+#: ../imagery/i.topo.corr/main.c:58
+msgid "Name of reflectance raster maps to be corrected topographically"
+msgstr ""
+#: ../imagery/i.topo.corr/main.c:62
+msgid "Name (flag -i) or prefix for output raster maps"
+msgstr ""
+#: ../imagery/i.topo.corr/main.c:66
+msgid "Name of input base raster map (elevation or illumination)"
+msgstr ""
+#: ../imagery/i.topo.corr/main.c:72
+msgid "Solar zenith in degrees"
+msgstr ""
+#: ../imagery/i.topo.corr/main.c:78
+msgid "Solar azimuth in degrees (only if flag -i)"
+msgstr ""
+#: ../imagery/i.topo.corr/main.c:85
+msgid "Topographic correction method"
+msgstr ""
+#: ../imagery/i.topo.corr/main.c:90
+msgid "Output sun illumination terrain model"
+msgstr ""
+#: ../imagery/i.topo.corr/main.c:94
+msgid "Scale output to input and copy color rules"
+msgstr ""
+#: ../imagery/i.topo.corr/main.c:100
+msgid "Solar azimuth is necessary to calculate illumination terrain model"
+msgstr ""
+#: ../imagery/i.topo.corr/main.c:104
+msgid "Reflectance maps are necessary to make topographic correction"
+msgstr ""
+#: ../imagery/i.topo.corr/main.c:164
+msgid "Illumination model is of CELL type"
+msgstr ""
+#: ../imagery/i.topo.corr/main.c:167
+#, c-format
+msgid "Band %s: "
+msgstr ""
+#: ../imagery/i.topo.corr/main.c:175
+#, c-format
+msgid "Reflectance of <%s> is not of DCELL type - ignored."
+msgstr ""
+#: ../imagery/i.albedo/main.c:96
+msgid "albedo"
+msgstr ""
+#: ../imagery/i.albedo/main.c:97 ../imagery/i.aster.toar/main.c:100
+#: ../imagery/i.modis.qc/main.c:170 ../imagery/i.landsat.toar/main.c:73
+#: ../imagery/i.landsat.toar/main.c:579
+msgid "reflectance"
+msgstr ""
+#: ../imagery/i.albedo/main.c:101
+msgid "AVHRR"
+msgstr ""
+#: ../imagery/i.albedo/main.c:103
+msgid "Computes broad band albedo from surface reflectance."
+msgstr ""
+#: ../imagery/i.albedo/main.c:116
+msgid "MODIS (7 input bands:1,2,3,4,5,6,7)"
+msgstr ""
+#: ../imagery/i.albedo/main.c:120
+msgid "NOAA AVHRR (2 input bands:1,2)"
+msgstr ""
+#: ../imagery/i.albedo/main.c:124
+msgid "Landsat 5+7 (6 input bands:1,2,3,4,5,7)"
+msgstr ""
+#: ../imagery/i.albedo/main.c:128
+msgid "Landsat 8 (7 input bands:1,2,3,4,5,6,7)"
+msgstr ""
+#: ../imagery/i.albedo/main.c:132
+msgid "ASTER (6 input bands:1,3,5,6,8,9)"
+msgstr ""
+#: ../imagery/i.albedo/main.c:136
+msgid "Aggressive mode (Landsat)"
+msgstr ""
+#: ../imagery/i.albedo/main.c:138 ../imagery/i.albedo/main.c:145
+msgid "Albedo dry run to calculate some water to beach/sand/desert stretching, a kind of simple atmospheric correction"
+msgstr ""
+#: ../imagery/i.albedo/main.c:143
+msgid "Soft mode (MODIS)"
+msgstr ""
+#: ../imagery/i.albedo/main.c:167 ../imagery/i.aster.toar/main.c:231
+#, c-format
+msgid "Too many input maps. Only %d allowed."
+msgstr ""
+#: ../imagery/i.albedo/main.c:181
+msgid "At least two raster maps are required"
+msgstr ""
+#: ../imagery/i.vi/main.c:90
+msgid "vegetation index"
+msgstr ""
+#: ../imagery/i.vi/main.c:91
+msgid "biophysical parameters"
+msgstr ""
+#: ../imagery/i.vi/main.c:93
+msgid "Calculates different types of vegetation indices."
+msgstr ""
+#: ../imagery/i.vi/main.c:94
+msgid "Uses red and nir bands mostly, and some indices require additional bands."
+msgstr ""
+#: ../imagery/i.vi/main.c:101
+msgid "Name of input red channel surface reflectance map"
+msgstr ""
+#: ../imagery/i.vi/main.c:102 ../imagery/i.vi/main.c:141
+#: ../imagery/i.vi/main.c:149 ../imagery/i.vi/main.c:157
+#: ../imagery/i.vi/main.c:165 ../imagery/i.vi/main.c:173
+msgid "Range: [0.0;1.0]"
+msgstr ""
+#: ../imagery/i.vi/main.c:110
+msgid "Type of vegetation index"
+msgstr ""
+#: ../imagery/i.vi/main.c:115
+msgid "Atmospherically Resistant Vegetation Index"
+msgstr ""
+#: ../imagery/i.vi/main.c:116
+msgid "Difference Vegetation Index"
+msgstr ""
+#: ../imagery/i.vi/main.c:117
+msgid "Enhanced Vegetation Index"
+msgstr ""
+#: ../imagery/i.vi/main.c:118
+msgid "Enhanced Vegetation Index 2"
+msgstr ""
+#: ../imagery/i.vi/main.c:119
+msgid "Green Vegetation Index"
+msgstr ""
+#: ../imagery/i.vi/main.c:120
+msgid "Green Atmospherically Resistant Vegetation Index"
+msgstr ""
+#: ../imagery/i.vi/main.c:121
+msgid "Global Environmental Monitoring Index"
+msgstr ""
+#: ../imagery/i.vi/main.c:122
+msgid "Infrared Percentage Vegetation Index"
+msgstr ""
+#: ../imagery/i.vi/main.c:123
+msgid "Modified Soil Adjusted Vegetation Index"
+msgstr ""
+#: ../imagery/i.vi/main.c:124
+msgid "second Modified Soil Adjusted Vegetation Index"
+msgstr ""
+#: ../imagery/i.vi/main.c:125
+msgid "Normalized Difference Vegetation Index"
+msgstr ""
+#: ../imagery/i.vi/main.c:126
+msgid "Perpendicular Vegetation Index"
+msgstr ""
+#: ../imagery/i.vi/main.c:127
+msgid "Soil Adjusted Vegetation Index"
+msgstr ""
+#: ../imagery/i.vi/main.c:128
+msgid "Simple Ratio"
+msgstr ""
+#: ../imagery/i.vi/main.c:129
+msgid "Visible Atmospherically Resistant Index"
+msgstr ""
+#: ../imagery/i.vi/main.c:130
+msgid "Weighted Difference Vegetation Index"
+msgstr ""
+#: ../imagery/i.vi/main.c:134
+msgid "type"
+msgstr ""
+#: ../imagery/i.vi/main.c:140
+msgid "Name of input nir channel surface reflectance map"
+msgstr ""
+#: ../imagery/i.vi/main.c:142 ../imagery/i.vi/main.c:150
+#: ../imagery/i.vi/main.c:158 ../imagery/i.vi/main.c:166
+#: ../imagery/i.vi/main.c:174 ../vector/v.vol.rst/main.c:254
+#: ../vector/v.vol.rst/main.c:303
+msgid "Optional inputs"
+msgstr ""
+#: ../imagery/i.vi/main.c:148
+msgid "Name of input green channel surface reflectance map"
+msgstr ""
+#: ../imagery/i.vi/main.c:156
+msgid "Name of input blue channel surface reflectance map"
+msgstr ""
+#: ../imagery/i.vi/main.c:164
+msgid "Name of input 5th channel surface reflectance map"
+msgstr ""
+#: ../imagery/i.vi/main.c:172
+msgid "Name of input 7th channel surface reflectance map"
+msgstr ""
+#: ../imagery/i.vi/main.c:180
+msgid "Value of the slope of the soil line (MSAVI only)"
+msgstr ""
+#: ../imagery/i.vi/main.c:181 ../imagery/i.vi/main.c:188
+#: ../imagery/i.vi/main.c:195
+msgid "MSAVI settings"
+msgstr ""
+#: ../imagery/i.vi/main.c:187
+msgid "Value of the intercept of the soil line (MSAVI only)"
+msgstr ""
+#: ../imagery/i.vi/main.c:194
+msgid "Value of the factor of reduction of soil noise (MSAVI only)"
+msgstr ""
+#: ../imagery/i.vi/main.c:201
+msgid "Maximum bits for digital numbers"
+msgstr ""
+#: ../imagery/i.vi/main.c:202
+msgid "If data is in Digital Numbers (i.e. integer type), give the max bits (i.e. 8 for Landsat -> [0-255])"
+msgstr ""
+#: ../imagery/i.vi/main.c:228
+msgid "sr index requires red and nir maps"
+msgstr ""
+#: ../imagery/i.vi/main.c:231
+msgid "ndvi index requires red and nir maps"
+msgstr ""
+#: ../imagery/i.vi/main.c:234
+msgid "ipvi index requires red and nir maps"
+msgstr ""
+#: ../imagery/i.vi/main.c:237
+msgid "dvi index requires red and nir maps"
+msgstr ""
+#: ../imagery/i.vi/main.c:240
+msgid "pvi index requires red and nir maps"
+msgstr ""
+#: ../imagery/i.vi/main.c:243
+msgid "wdvi index requires red and nir maps"
+msgstr ""
+#: ../imagery/i.vi/main.c:246
+msgid "savi index requires red and nir maps"
+msgstr ""
+#: ../imagery/i.vi/main.c:251
+msgid "msavi index requires red and nir maps, and 3 parameters related to soil line"
+msgstr ""
+#: ../imagery/i.vi/main.c:254
+msgid "msavi2 index requires red and nir maps"
+msgstr ""
+#: ../imagery/i.vi/main.c:257
+msgid "gemi index requires red and nir maps"
+msgstr ""
+#: ../imagery/i.vi/main.c:261
+msgid "arvi index requires blue, red and nir maps"
+msgstr ""
+#: ../imagery/i.vi/main.c:265
+msgid "evi index requires blue, red and nir maps"
+msgstr ""
+#: ../imagery/i.vi/main.c:268
+msgid "evi2 index requires red and nir maps"
+msgstr ""
+#: ../imagery/i.vi/main.c:272
+msgid "vari index requires blue, green and red maps"
+msgstr ""
+#: ../imagery/i.vi/main.c:276
+msgid "gari index requires blue, green, red and nir maps"
+msgstr ""
+#: ../imagery/i.vi/main.c:281
+msgid "gvi index requires blue, green, red, nir, chan5 and chan7 maps"
+msgstr ""
+#: ../imagery/i.cca/main.c:87
+msgid "canonical components analysis"
+msgstr ""
+#: ../imagery/i.cca/main.c:89
+msgid "Canonical components analysis (CCA) program for image processing."
+msgstr ""
+#: ../imagery/i.cca/main.c:96
+msgid "Name of input imagery subgroup"
+msgstr ""
+#: ../imagery/i.cca/main.c:103
+msgid "File containing spectral signatures"
+msgstr ""
+#: ../imagery/i.cca/main.c:106
+msgid "Output raster map prefix name"
+msgstr ""
+#: ../imagery/i.cca/main.c:114
+msgid "Unknown imagery group."
+msgstr ""
+#: ../imagery/i.cca/main.c:117
+msgid "Unable to find subgroup reference information."
+msgstr ""
+#: ../imagery/i.cca/main.c:123
+msgid "Unable to open the signature file"
+msgstr ""
+#: ../imagery/i.cca/main.c:127
+msgid "Error while reading the signatures file."
+msgstr ""
+#: ../imagery/i.cca/main.c:132
+msgid "Need at least two signatures in signature file."
+msgstr ""
+#: ../imagery/i.cca/main.c:226
+#, c-format
+msgid "The output cell map <%s.%d> has values outside the 0-255 range."
+msgstr ""
+#: ../imagery/i.cca/transform.c:24
+msgid "Unable to allocate cell buffers."
+msgstr ""
+#: ../imagery/i.cca/transform.c:58
+msgid "Transform completed.\n"
+msgstr ""
+#: ../imagery/i.evapo.time/main.c:79
+msgid "Computes temporal integration of satellite ET actual (ETa) following the daily ET reference (ETo) from meteorological station(s)."
+msgstr ""
+#: ../imagery/i.evapo.time/main.c:86
+msgid "Names of satellite ETa raster maps [mm/d or cm/d]"
+msgstr ""
+#: ../imagery/i.evapo.time/main.c:91
+msgid "Names of satellite ETa Day of Year (DOY) raster maps [0-400] [-]"
+msgstr ""
+#: ../imagery/i.evapo.time/main.c:96
+msgid "Names of meteorological station ETo raster maps [0-400] [mm/d or cm/d]"
+msgstr ""
+#: ../imagery/i.evapo.time/main.c:102
+msgid "Value of DOY for ETo first day"
+msgstr ""
+#: ../imagery/i.evapo.time/main.c:108
+msgid "Value of DOY for the first day of the period studied"
+msgstr ""
+#: ../imagery/i.evapo.time/main.c:114
+msgid "Value of DOY for the last day of the period studied"
+msgstr ""
+#: ../imagery/i.evapo.time/main.c:142
+msgid "The DOY for end_period can not be smaller than start_period"
+msgstr ""
+#: ../imagery/i.evapo.time/main.c:146
+msgid "The DOY for start_period can not be smaller than eto_doy_min"
+msgstr ""
+#: ../imagery/i.evapo.time/main.c:151
+#, c-format
+msgid "Too many ETa files. Only %d allowed."
+msgstr ""
+#: ../imagery/i.evapo.time/main.c:162 ../imagery/i.evapo.time/main.c:178
+#: ../imagery/i.evapo.time/main.c:200
+msgid "The min specified input map is two"
+msgstr ""
+#: ../imagery/i.evapo.time/main.c:167
+#, c-format
+msgid "Too many ETa_doy files. Only %d allowed."
+msgstr ""
+#: ../imagery/i.evapo.time/main.c:183
+msgid "ETa and ETa_DOY file numbers are not equal!"
+msgstr ""
+#: ../imagery/i.evapo.time/main.c:189
+#, c-format
+msgid "Too many ETo files. Only %d allowed."
+msgstr ""
+#: ../imagery/i.eb.netrad/main.c:58
+msgid "net radiation"
+msgstr ""
+#: ../imagery/i.eb.netrad/main.c:61
+msgid "Net radiation approximation (Bastiaanssen, 1995)."
+msgstr ""
+#: ../imagery/i.eb.netrad/main.c:75
+msgid "Name of surface temperature raster map [K]"
+msgstr ""
+#: ../imagery/i.eb.netrad/main.c:85
+msgid "Name of the difference map of temperature from surface skin to about 2 m height [K]"
+msgstr ""
+#: ../imagery/i.eb.netrad/main.c:89
+msgid "Name of the emissivity map [-]"
+msgstr ""
+#: ../imagery/i.eb.netrad/main.c:94
+msgid "Name of the single-way atmospheric transmissivitymap [-]"
+msgstr ""
+#: ../imagery/i.eb.netrad/main.c:98
+msgid "Name of the Day Of Year (DOY) map [-]"
+msgstr ""
+#: ../imagery/i.eb.netrad/main.c:102
+msgid "Name of the sun zenith angle map [degrees]"
+msgstr ""
+#: ../imagery/i.eb.netrad/main.c:105
+msgid "Name of the output net radiation layer"
+msgstr ""
+#: ../imagery/i.cluster/print6.c:11
+#, c-format
+msgid "class distribution"
+msgstr ""
+#: ../imagery/i.cluster/print3.c:16
+#, c-format
+msgid "%sinitial means for each band%s%s"
+msgstr ""
+#: ../imagery/i.cluster/print3.c:20
+#, c-format
+msgid "class %-3d "
+msgstr ""
+#: ../imagery/i.cluster/main.c:79
+msgid "Generates spectral signatures for land cover types in an image using a clustering algorithm."
+msgstr ""
+#: ../imagery/i.cluster/main.c:82
+msgid "The resulting signature file is used as input for i.maxlik, to generate an unsupervised image classification."
+msgstr ""
+#: ../imagery/i.cluster/main.c:102
+msgid "Initial number of classes"
+msgstr ""
+#: ../imagery/i.cluster/main.c:111
+msgid "Name of file containing initial signatures"
+msgstr ""
+#: ../imagery/i.cluster/main.c:119
+msgid "Sampling intervals (by row and col); default: ~10,000 pixels"
+msgstr ""
+#: ../imagery/i.cluster/main.c:135
+msgid "Percent convergence"
+msgstr ""
+#: ../imagery/i.cluster/main.c:143
+msgid "Cluster separation"
+msgstr ""
+#: ../imagery/i.cluster/main.c:151
+msgid "Minimum number of pixels in a class"
+msgstr ""
+#: ../imagery/i.cluster/main.c:158
+msgid "Name for output file containing final report"
+msgstr ""
+#: ../imagery/i.cluster/main.c:192
+#, c-format
+msgid "Illegal number of initial classes (%s)"
+msgstr ""
+#: ../imagery/i.cluster/main.c:203
+#, c-format
+msgid "Illegal value(s) of sample intervals (%s)"
+msgstr ""
+#: ../imagery/i.cluster/main.c:217
+#, c-format
+msgid "Illegal value of iterations (%s)"
+msgstr ""
+#: ../imagery/i.cluster/main.c:223
+#, c-format
+msgid "Illegal value of convergence (%s)"
+msgstr ""
+#: ../imagery/i.cluster/main.c:228
+#, c-format
+msgid "Illegal value of separation (%s)"
+msgstr ""
+#: ../imagery/i.cluster/main.c:233
+#, c-format
+msgid "Illegal value of min_size (%s)"
+msgstr ""
+#: ../imagery/i.cluster/main.c:242
+#, c-format
+msgid "Unable to create report file <%s>"
+msgstr ""
+#: ../imagery/i.cluster/main.c:250
+#, c-format
+msgid "#################### CLUSTER (%s) ####################%s%s"
+msgstr ""
+#: ../imagery/i.cluster/main.c:252
+#, c-format
+msgid "Location: %s%s"
+msgstr ""
+#: ../imagery/i.cluster/main.c:253
+#, c-format
+msgid "Mapset: %s%s"
+msgstr ""
+#: ../imagery/i.cluster/main.c:254
+#, c-format
+msgid "Group: %s%s"
+msgstr ""
+#: ../imagery/i.cluster/main.c:255
+#, c-format
+msgid "Subgroup: %s%s"
+msgstr ""
+#: ../imagery/i.cluster/main.c:257
+#, c-format
+msgid " %s%s"
+msgstr ""
+#: ../imagery/i.cluster/main.c:260
+#, c-format
+msgid "Result signature file: %s%s"
+msgstr ""
+#: ../imagery/i.cluster/main.c:262
+#, c-format
+msgid "Region%s"
+msgstr ""
+#: ../imagery/i.cluster/main.c:263
+#, c-format
+msgid " North: %12.2f East: %12.2f%s"
+msgstr ""
+#: ../imagery/i.cluster/main.c:265
+#, c-format
+msgid " South: %12.2f West: %12.2f%s"
+msgstr ""
+#: ../imagery/i.cluster/main.c:267
+#, c-format
+msgid " Res: %12.2f Res: %12.2f%s"
+msgstr ""
+#: ../imagery/i.cluster/main.c:269
+#, c-format
+msgid " Rows: %12d Cols: %12d Cells: %d%s"
+msgstr ""
+#: ../imagery/i.cluster/main.c:271
+#, c-format
+msgid "Mask: %s%s"
+msgstr ""
+#: ../imagery/i.cluster/main.c:273
+#, c-format
+msgid "Cluster parameters%s"
+msgstr ""
+#: ../imagery/i.cluster/main.c:274
+#, c-format
+msgid " Number of initial classes: %d"
+msgstr ""
+#: ../imagery/i.cluster/main.c:276
+#, c-format
+msgid " [from signature file %s]"
+msgstr ""
+#: ../imagery/i.cluster/main.c:278
+#, c-format
+msgid " Minimum class size: %d%s"
+msgstr ""
+#: ../imagery/i.cluster/main.c:279
+#, c-format
+msgid " Minimum class separation: %f%s"
+msgstr ""
+#: ../imagery/i.cluster/main.c:280
+#, c-format
+msgid " Percent convergence: %f%s"
+msgstr ""
+#: ../imagery/i.cluster/main.c:281
+#, c-format
+msgid " Maximum number of iterations: %d%s"
+msgstr ""
+#: ../imagery/i.cluster/main.c:283
+#, c-format
+msgid " Row sampling interval: %d%s"
+msgstr ""
+#: ../imagery/i.cluster/main.c:284
+#, c-format
+msgid " Col sampling interval: %d%s"
+msgstr ""
+#: ../imagery/i.cluster/main.c:303
+msgid "Out of Memory. Please run again and choose a smaller sample size."
+msgstr ""
+#: ../imagery/i.cluster/main.c:309
+#, c-format
+msgid "Sample size: %d points%s"
+msgstr ""
+#: ../imagery/i.cluster/main.c:312
+msgid "Not enough sample points. Please run again and choose a larger sample size."
+msgstr ""
+#: ../imagery/i.cluster/main.c:316
+msgid "Not enough non-zero sample data points. Check your current region (and mask)."
+msgstr ""
+#: ../imagery/i.cluster/main.c:329
+#, c-format
+msgid "%s########## final results #############%s"
+msgstr ""
+#: ../imagery/i.cluster/main.c:330
+#, c-format
+msgid "%d classes (convergence=%.1f%%)%s"
+msgstr ""
+#: ../imagery/i.cluster/main.c:341
+#, c-format
+msgid "Unable to create signature file <%s> for group <%s>, subsgroup <%s>"
+msgstr ""
+#: ../imagery/i.cluster/main.c:346
+#, c-format
+msgid "%s%s#################### CLASSES ####################%s"
+msgstr ""
+#: ../imagery/i.cluster/main.c:348
+#, c-format
+msgid "%s%d classes, %.2f%% points stable%s"
+msgstr ""
+#: ../imagery/i.cluster/main.c:350
+#, c-format
+msgid "%s######## CLUSTER END (%s) ########%s"
+msgstr ""
+#: ../imagery/i.cluster/main.c:354 ../misc/m.nviz.image/main.c:242
+#, c-format
+msgid "File <%s> created."
+msgstr ""
+#: ../imagery/i.cluster/print5.c:15
+#, c-format
+msgid "%sclass separability matrix%s%s"
+msgstr ""
+#: ../imagery/i.cluster/print4.c:16
+#, c-format
+msgid "class centroids (sum/count=mean)%s"
+msgstr ""
+#: ../imagery/i.cluster/print4.c:18
+#, c-format
+msgid "band %d"
+msgstr ""
+#: ../imagery/i.cluster/print1.c:12
+#, c-format
+msgid "means and standard deviations for %d band%s%s%s"
+msgstr ""
+#: ../imagery/i.cluster/print1.c:14
+#, c-format
+msgid " means "
+msgstr ""
+#: ../imagery/i.cluster/print1.c:18
+#, c-format
+msgid " stddev "
+msgstr ""
+#: ../imagery/i.cluster/checkpt.c:16
+#, c-format
+msgid "using seed means (%d files)%s"
+msgstr ""
+#: ../imagery/i.cluster/checkpt.c:29
+#, c-format
+msgid "%s######## iteration %d ###########%s"
+msgstr ""
+#: ../imagery/i.cluster/checkpt.c:31
+#, c-format
+msgid "%d classes, %.2f%% points stable%s"
+msgstr ""
+#: ../imagery/i.cluster/checkpt.c:42
+#, c-format
+msgid "Iteration %.2d: convergence %.2f%% (%s elapsed, %s left)"
+msgstr ""
+#: ../imagery/i.cluster/print2.c:18
+#, c-format
+msgid "%sclass means/stddev for each band%s%s"
+msgstr ""
+#: ../imagery/i.cluster/print2.c:23
+#, c-format
+msgid "class %d (%d)%s"
+msgstr ""
+#: ../imagery/i.cluster/print2.c:24
+#, c-format
+msgid " means "
+msgstr ""
+#: ../imagery/i.cluster/print2.c:29
+#, c-format
+msgid " stddev"
+msgstr ""
+#: ../imagery/i.cluster/open_files.c:24
+#, c-format
+msgid "Raster map <%s> do not exists in subgroup <%s>"
+msgstr ""
+#: ../imagery/i.cluster/open_files.c:29
+msgid "No raster maps found"
+msgstr ""
+#: ../imagery/i.cluster/open_files.c:33
+#, c-format
+msgid "Subgroup <%s> doesn't have any raster maps"
+msgstr ""
+#: ../imagery/i.cluster/open_files.c:36
+#, c-format
+msgid "Subgroup <%s> only has 1 raster map"
+msgstr ""
+#: ../imagery/i.cluster/open_files.c:37
+msgid "Subgroup must have at least 2 raster maps"
+msgstr ""
+#: ../imagery/i.cluster/open_files.c:54
+#, c-format
+msgid "Unable to open seed signature file <%s>"
+msgstr ""
+#: ../imagery/i.aster.toar/main.c:98 ../imagery/i.landsat.toar/main.c:71
+msgid "radiometric conversion"
+msgstr ""
+#: ../imagery/i.aster.toar/main.c:99 ../imagery/i.landsat.toar/main.c:72
+#: ../imagery/i.landsat.toar/main.c:577
+msgid "radiance"
+msgstr ""
+#: ../imagery/i.aster.toar/main.c:101 ../imagery/i.landsat.toar/main.c:74
+msgid "brightness temperature"
+msgstr ""
+#: ../imagery/i.aster.toar/main.c:105
+msgid "Calculates Top of Atmosphere Radiance/Reflectance/Brightness Temperature from ASTER DN."
+msgstr ""
+#: ../imagery/i.aster.toar/main.c:109
+msgid "Names of ASTER DN layers (15 layers)"
+msgstr ""
+#: ../imagery/i.aster.toar/main.c:116
+msgid "Day of Year of satellite overpass [0-366]"
+msgstr ""
+#: ../imagery/i.aster.toar/main.c:123
+msgid "Sun elevation angle (degrees, < 90.0)"
+msgstr ""
+#: ../imagery/i.aster.toar/main.c:126
+msgid "Base name of the output layers (will add .x)"
+msgstr ""
+#: ../imagery/i.aster.toar/main.c:131
+msgid "Output is radiance (W/m2)"
+msgstr ""
+#: ../imagery/i.aster.toar/main.c:135
+msgid "VNIR is High Gain"
+msgstr ""
+#: ../imagery/i.aster.toar/main.c:139
+msgid "SWIR is High Gain"
+msgstr ""
+#: ../imagery/i.aster.toar/main.c:143
+msgid "VNIR is Low Gain 1"
+msgstr ""
+#: ../imagery/i.aster.toar/main.c:147
+msgid "SWIR is Low Gain 1"
+msgstr ""
+#: ../imagery/i.aster.toar/main.c:151
+msgid "SWIR is Low Gain 2"
+msgstr ""
+#: ../imagery/i.aster.toar/main.c:246
+msgid "The input band number should be 15"
+msgstr ""
+#: ../imagery/i.landsat.acca/main.c:70
+#, c-format
+msgid "Input raster map <%s> is not floating point (process DN using i.landsat.toar to radiance first)"
+msgstr ""
+#: ../imagery/i.landsat.acca/main.c:104
+msgid "Performs Landsat TM/ETM+ Automatic Cloud Cover Assessment (ACCA)."
+msgstr ""
+#: ../imagery/i.landsat.acca/main.c:107
+msgid "cloud detection"
+msgstr ""
+#: ../imagery/i.landsat.acca/main.c:112 ../imagery/i.landsat.toar/main.c:82
+msgid "Base name of input raster bands"
+msgstr ""
+#: ../imagery/i.landsat.acca/main.c:113 ../imagery/i.landsat.toar/main.c:83
+msgid "Example: 'B.' for B.1, B.2, ..."
+msgstr ""
+#: ../imagery/i.landsat.acca/main.c:121
+msgid "B56composite (step 6)"
+msgstr ""
+#: ../imagery/i.landsat.acca/main.c:128
+msgid "B45ratio: Desert detection (step 10)"
+msgstr ""
+#: ../imagery/i.landsat.acca/main.c:136
+msgid "Number of classes in the cloud temperature histogram"
+msgstr ""
+#: ../imagery/i.landsat.acca/main.c:138 ../imagery/i.landsat.acca/main.c:153
+#: ../imagery/i.landsat.acca/main.c:159 ../imagery/i.landsat.acca/main.c:164
+msgid "Cloud settings"
+msgstr ""
+#: ../imagery/i.landsat.acca/main.c:142
+msgid "Data is Landsat-5 TM"
+msgstr ""
+#: ../imagery/i.landsat.acca/main.c:143
+msgid "I.e. Thermal band is '.6' not '.61')"
+msgstr ""
+#: ../imagery/i.landsat.acca/main.c:148
+msgid "Apply post-processing filter to remove small holes"
+msgstr ""
+#: ../imagery/i.landsat.acca/main.c:152
+msgid "Always use cloud signature (step 14)"
+msgstr ""
+#: ../imagery/i.landsat.acca/main.c:158
+msgid "Bypass second-pass processing, and merge warm (not ambiguous) and cold clouds"
+msgstr ""
+#: ../imagery/i.landsat.acca/main.c:163
+msgid "Include a category for cloud shadows"
+msgstr ""
+#: ../imagery/i.landsat.acca/tools.c:138
+msgid "Filling small holes in clouds..."
+msgstr ""
+#: ../imagery/i.landsat.acca/algorithm.c:124
+msgid "Preliminary scene analysis:"
+msgstr ""
+#: ../imagery/i.landsat.acca/algorithm.c:125
+#, c-format
+msgid "* Desert index: %.2lf"
+msgstr ""
+#: ../imagery/i.landsat.acca/algorithm.c:126
+#, c-format
+msgid "* Snow cover: %.2lf %%"
+msgstr ""
+#: ../imagery/i.landsat.acca/algorithm.c:127
+#, c-format
+msgid "* Cloud cover: %.2lf %%"
+msgstr ""
+#: ../imagery/i.landsat.acca/algorithm.c:128
+msgid "* Temperature of clouds:"
+msgstr ""
+#: ../imagery/i.landsat.acca/algorithm.c:129
+#, c-format
+msgid "** Maximum: %.2lf K"
+msgstr ""
+#: ../imagery/i.landsat.acca/algorithm.c:130
+#, c-format
+msgid "** Mean (%s cloud): %.2lf K"
+msgstr ""
+#: ../imagery/i.landsat.acca/algorithm.c:132
+#, c-format
+msgid "** Minimum: %.2lf K"
+msgstr ""
+#: ../imagery/i.landsat.acca/algorithm.c:142
+msgid "Histogram cloud signature:"
+msgstr ""
+#: ../imagery/i.landsat.acca/algorithm.c:148
+#, c-format
+msgid "* Mean temperature: %.2lf K"
+msgstr ""
+#: ../imagery/i.landsat.acca/algorithm.c:149
+#, c-format
+msgid "* Standard deviation: %.2lf"
+msgstr ""
+#: ../imagery/i.landsat.acca/algorithm.c:150
+#, c-format
+msgid "* Skewness: %.2lf"
+msgstr ""
+#: ../imagery/i.landsat.acca/algorithm.c:151
+#, c-format
+msgid "* Histogram classes: %d"
+msgstr ""
+#: ../imagery/i.landsat.acca/algorithm.c:163
+#, c-format
+msgid "* 98.75 percentile: %.2lf K"
+msgstr ""
+#: ../imagery/i.landsat.acca/algorithm.c:164
+#, c-format
+msgid "* 97.50 percentile: %.2lf K"
+msgstr ""
+#: ../imagery/i.landsat.acca/algorithm.c:165
+#, c-format
+msgid "* 83.50 percentile: %.2lf K"
+msgstr ""
+#: ../imagery/i.landsat.acca/algorithm.c:186
+msgid "Maximum temperature:"
+msgstr ""
+#: ../imagery/i.landsat.acca/algorithm.c:187
+#, c-format
+msgid "* Cold cloud: %.2lf K"
+msgstr ""
+#: ../imagery/i.landsat.acca/algorithm.c:188
+#, c-format
+msgid "* Warm cloud: %.2lf K"
+msgstr ""
+#: ../imagery/i.landsat.acca/algorithm.c:193
+msgid "Result: Scene with clouds"
+msgstr ""
+#: ../imagery/i.landsat.acca/algorithm.c:200
+msgid "Result: Scene cloud free"
+msgstr ""
+#: ../imagery/i.landsat.acca/algorithm.c:237
+msgid "Processing first pass..."
+msgstr ""
+#: ../imagery/i.landsat.acca/algorithm.c:391
+msgid "Removing ambiguous pixels..."
+msgstr ""
+#: ../imagery/i.landsat.acca/algorithm.c:393
+msgid "Pass two processing..."
+msgstr ""
+#: ../imagery/i.find/main.c:63
+#, c-format
+msgid "usage: %s location mapset element file."
+msgstr ""
+#: ../imagery/i.find/main.c:83
+msgid "Unable to open temp file."
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:169
+msgid "imagery quality assessment"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:171
+msgid "land surface temperature"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:172
+msgid "vegetation"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:176
+msgid "Extracts quality control parameters from MODIS QC layers."
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:181
+msgid "Name of input surface reflectance QC layer [bit array]"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:186
+msgid "Name for output QC type classification layer"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:192
+msgid "Name of MODIS product type"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:209
+msgid "surf. refl. 250m 8-days"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:210
+msgid "surf. refl. 500m 8-days"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:211
+msgid "surf. refl. 500m 8-days, State QA"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:212
+msgid "surf. refl. 500m daily"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:213
+msgid "surf. refl. 500m daily, State QA"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:214
+msgid "surf. refl. 5000m daily"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:215
+msgid "surf. refl. 5000m daily, State QA"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:216
+msgid "surf. refl. 5000m daily, Internal Climatology"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:217
+msgid "LST 1km daily (Day/Night)"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:218
+msgid "LST 1km 8-days (Day/Night)"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:219
+msgid "VI 1km 16-days"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:220
+msgid "Brdf-Albedo Quality (Ancillary SDS) 1km 8-days"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:221
+msgid "Brdf-Albedo Quality (BRDF SDS) 1km 8-days"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:222
+msgid "VI 250m 16-days"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:230
+msgid "Name of QC type to extract"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:295
+msgid "mod09: Adjacency Correction"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:296
+msgid "mod09: Atmospheric Correction"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:297
+msgid "mod09: Cloud State"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:298
+msgid "mod09: Band-Wise Data Quality Flag"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:299
+msgid "mod09: 250m Band is at Different Orbit than 500m"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:300
+msgid "mod09: MODIS Land General Quality Assessment"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:301
+msgid "mod11A1: MODIS Land General Quality Assessment"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:302
+msgid "mod11A1: Detailed Quality Indications"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:303
+msgid "mod11A1: Average Emissivity Error Classes"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:304
+msgid "mod11A1: Average LST Error Classes"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:305
+msgid "mod11A2: Detailed Quality Indications"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:306
+msgid "mod11A2: Average Emissivity Error Classes"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:307
+msgid "mod11A2: MODIS Land General Quality Assessment"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:308
+msgid "mod11A2: Average LST Error Classes"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:309
+msgid "mod09*s: StateQA Aerosol Quantity"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:310
+msgid "mod09*s: StateQA BRDF Correction Performed"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:311
+msgid "mod09*s: StateQA Cirrus Detected"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:312
+msgid "mod09*s: StateQA Cloud Shadow"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:313
+msgid "mod09*s: StateQA Cloud State"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:314
+msgid "mod09*s: StateQA Internal Cloud Algorithm"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:315
+msgid "mod09*s: StateQA Internal Fire Algorithm"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:316
+msgid "mod09*s: StateQA Internal Snow Mask"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:317
+msgid "mod09*s: StateQA Land Water"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:318
+msgid "mod09*s: StateQA mod35 Snow Ice"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:319
+msgid "mod09*s: StateQA Pixel Adjacent to Cloud"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:320
+msgid "mod09*s: StateQA Salt Pan (mod09GAs)"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:321
+msgid "mod09*i: Internal CM: Cloudy"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:322
+msgid "mod09*i: Internal CM: Clear"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:323
+msgid "mod09*i: Internal CM: High Clouds"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:324
+msgid "mod09*i: Internal CM: Low Clouds"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:325
+msgid "mod09*i: Internal CM: Snow"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:326
+msgid "mod09*i: Internal CM: Fire"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:327
+msgid "mod09*i: Internal CM: Sun Glint"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:328
+msgid "mod09*i: Internal CM: Dust"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:329
+msgid "mod09*i: Internal CM: Cloud Shadow"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:330
+msgid "mod09*i: Internal CM: Pixel is Adjacent to Cloud"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:331
+msgid "mod09*i: Internal CM: Cirrus"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:332
+msgid "mod09*i: Internal CM: Pan Flag"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:333
+msgid "mod09*i: Internal CM: Criteria for Aerosol Retrieval"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:334
+msgid "mod09*i: Internal CM: AOT (aerosol optical depth) has clim. val."
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:335
+msgid "mod13A2: MODIS Land General Quality Assessment"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:336
+msgid "mod13A2: Quality estimation of the pixel"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:337
+msgid "mod13A2: Quantity range of Aerosol"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:338
+msgid "mod13A2: if pixel is a cloud neighbour"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:339
+msgid "mod13A2: if BRDF correction performed"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:340
+msgid "mod13A2: if pixel mixed with clouds"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:341
+msgid "mod13A2: separate land from various water objects"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:342
+msgid "mod13A2: if snow/ice present in pixel"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:343
+msgid "mod13A2: if shadow is present in pixel"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:344 ../imagery/i.modis.qc/main.c:345
+#: ../imagery/i.modis.qc/main.c:346
+msgid "mcd43B2: Quality of BRDF correction performed"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:347
+msgid "mcd43B2q: Quality of BRDF correction performed"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:348
+msgid "mod13Q1: MODIS Land General Quality Assessment"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:349
+msgid "mod13Q1: Quality estimation of the pixel"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:350
+msgid "mod13Q1: Quantity range of Aerosol"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:351
+msgid "mod13Q1: if pixel is a cloud neighbour"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:352
+msgid "mod13Q1: if BRDF correction performed"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:353
+msgid "mod13Q1: if pixel mixed with clouds"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:354
+msgid "mod13Q1: separate land from various water objects"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:355
+msgid "mod13Q1: if snow/ice present in pixel"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:356
+msgid "mod13Q1: if shadow is present in pixel"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:365
+msgid "Band number of MODIS product (mod09Q1=[1,2],mod09A1=[1-7],m[o/y]d09GA=[1-7],m[o/y]d09CMG=[1-7], mcd43B2q=[1-7])"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:369
+msgid "Band 1: Red"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:370
+msgid "Band 2: NIR"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:371
+msgid "Band 3: Blue"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:372
+msgid "Band 4: Green"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:373
+msgid "Band 5: SWIR 1"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:374
+msgid "Band 6: SWIR 2"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:375
+msgid "Band 7: SWIR 3"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:392
+msgid "Please specify a product to extract"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:395
+msgid "Please specify a valid QC flag to extract"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:400
+msgid "This bit flag is only available for MOD09Q1 @ 250m products"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:404
+msgid "Band number out of allowed range [1-2]"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:406 ../imagery/i.modis.qc/main.c:408
+#: ../imagery/i.modis.qc/main.c:410 ../imagery/i.modis.qc/main.c:412
+#: ../imagery/i.modis.qc/main.c:414 ../imagery/i.modis.qc/main.c:416
+#: ../imagery/i.modis.qc/main.c:418 ../imagery/i.modis.qc/main.c:455
+msgid "Band number out of allowed range [1-7]"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:420
+msgid "mod09Q1 product only has 2 bands"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:425
+msgid "This bit flag is only available for MOD09A1s @ 500m or MOD09CMG @ 5000m products"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:429
+msgid "This bit flag is only available for MOD09GAs @ 500m products"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:440
+msgid "This bit flag is only available for mod09CMGi @ 5000m products"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:446
+msgid "This bit flag is only available for MOD13A2 @ 1km products"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:451
+msgid "This bit flag is only available for MCD43B2 @ 1km products"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:461
+msgid "This bit flag is only available for MOD13Q1 @ 250m products"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:826
+msgid "Unknown names and/or combination, please check spelling"
+msgstr ""
+#: ../imagery/i.zc/main.c:54 ../vector/v.lidar.edgedetection/main.c:77
+msgid "edges"
+msgstr ""
+#: ../imagery/i.zc/main.c:56
+msgid "Zero-crossing \"edge detection\" raster function for image processing."
+msgstr ""
+#: ../imagery/i.zc/main.c:74
+msgid "Zero crossing raster map"
+msgstr ""
+#: ../imagery/i.zc/main.c:81
+msgid "x-y extent of the Gaussian filter"
+msgstr ""
+#: ../imagery/i.zc/main.c:89
+msgid "Sensitivity of Gaussian filter"
+msgstr ""
+#: ../imagery/i.zc/main.c:97
+msgid "Number of azimuth directions categorized"
+msgstr ""
+#: ../imagery/i.zc/main.c:109
+msgid "Threshold less than or equal to zero not allowed"
+msgstr ""
+#: ../imagery/i.zc/main.c:119
+msgid "Width less than or equal to zero not allowed"
+msgstr ""
+#: ../imagery/i.zc/main.c:123
+msgid "Fewer than 1 orientation classes not allowed"
+msgstr ""
+#: ../imagery/i.zc/main.c:137
+#, c-format
+msgid "Power 2 values : %d rows %d columns"
+msgstr ""
+#: ../imagery/i.zc/main.c:147
+msgid "Initializing data..."
+msgstr ""
+#: ../imagery/i.zc/main.c:177
+msgid "Writing transformed data to file..."
+msgstr ""
+#: ../imagery/i.zc/main.c:200
+msgid "Transform successful"
+msgstr ""
+#: ../imagery/i.pca/main.c:75
+msgid "principal components analysis"
+msgstr ""
+#: ../imagery/i.pca/main.c:76
+msgid "Principal components analysis (PCA) for image processing."
+msgstr ""
+#: ../imagery/i.pca/main.c:82
+msgid "Name of two or more input raster maps or imagery group"
+msgstr ""
+#: ../imagery/i.pca/main.c:87
+msgid "A numerical suffix will be added for each component map"
+msgstr ""
+#: ../imagery/i.pca/main.c:96
+msgid "Rescaling range for output maps"
+msgstr ""
+#: ../imagery/i.pca/main.c:98
+msgid "For no rescaling use 0,0"
+msgstr ""
+#: ../imagery/i.pca/main.c:99
+msgid "Rescale"
+msgstr ""
+#: ../imagery/i.pca/main.c:108
+msgid "Cumulative percent importance for filtering"
+msgstr ""
+#: ../imagery/i.pca/main.c:113
+msgid "Normalize (center and scale) input maps"
+msgstr ""
+#: ../imagery/i.pca/main.c:114
+msgid "Default: center only"
+msgstr ""
+#: ../imagery/i.pca/main.c:118
+msgid "Output will be filtered input bands"
+msgstr ""
+#: ../imagery/i.pca/main.c:119
+msgid "Apply inverse PCA after PCA"
+msgstr ""
+#: ../imagery/i.pca/main.c:154
+msgid "Sorry, at least 2 input bands must be provided"
+msgstr ""
+#: ../imagery/i.pca/main.c:169
+#, c-format
+msgid "'%s' must be positive"
+msgstr ""
+#: ../imagery/i.pca/main.c:171
+#, c-format
+msgid "'%s' must be < 100"
+msgstr ""
+#: ../imagery/i.pca/main.c:233
+msgid "Not enough principal components left for filtering"
+msgstr ""
+#: ../imagery/i.pca/main.c:235
+#, c-format
+msgid "Using %d of %d principal components for filtering"
+msgstr ""
+#: ../imagery/i.pca/main.c:297
+msgid "Scale range length should be > 0. Using default values: 0,255."
+msgstr ""
+#: ../imagery/i.pca/main.c:343
+msgid "Computing covariance matrix..."
+msgstr ""
+#: ../imagery/i.pca/main.c:456
+#, c-format
+msgid "Rescaling to range %d,%d..."
+msgstr ""
+#: ../imagery/i.pca/main.c:464
+msgid "Calculating principal components..."
+msgstr ""
+#: ../imagery/i.pca/support.c:50
+msgid "Eigen values, (vectors), and [percent importance]:"
+msgstr ""
+#: ../imagery/i.ifft/main.c:81
+msgid "Inverse Fast Fourier Transform (IFFT) for image processing."
+msgstr ""
+#: ../imagery/i.ifft/main.c:86
+msgid "Name of input raster map (image fft, real part)"
+msgstr ""
+#: ../imagery/i.ifft/main.c:90
+msgid "Name of input raster map (image fft, imaginary part"
+msgstr ""
+#: ../imagery/i.ifft/main.c:115
+msgid "The real and imaginary original windows did not match"
+msgstr ""
+#: ../imagery/i.ifft/main.c:157
+msgid "Masking raster maps..."
+msgstr ""
+#: ../imagery/i.ifft/main.c:200
+msgid "Starting Inverse FFT..."
+msgstr ""
+#: ../imagery/i.landsat.toar/landsat.c:116
+msgid "The DOS4 method is not applicable here: approximation of atmospheric transmittance coefficients is unstable. Use another DOS method or use other sun_elevation parameter"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:69
+msgid "Calculates top-of-atmosphere radiance or reflectance and temperature for Landsat MSS/TM/ETM+/OLI"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:75
+msgid "atmospheric correction"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:86
+msgid "Prefix for output raster maps"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:88
+msgid "Example: 'B.toar.' generates B.toar.1, B.toar.2, ..."
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:93
+msgid "Name of Landsat metadata file (.met or MTL.txt)"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:99
+msgid "Spacecraft sensor"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:100
+msgid "Required only if 'metfile' not given (recommended for sanity)"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:105
+msgid "Landsat-1 MSS"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:106
+msgid "Landsat-2 MSS"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:107
+msgid "Landsat-3 MSS"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:108
+msgid "Landsat-4 MSS"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:109
+msgid "Landsat-5 MSS"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:110
+msgid "Landsat-4 TM"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:111
+msgid "Landsat-5 TM"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:112
+msgid "Landsat-7 ETM+"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:113
+msgid "Landsat_8 OLI/TIRS"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:123
+msgid "Atmospheric correction method"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:132
+msgid "Image acquisition date (yyyy-mm-dd)"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:133 ../imagery/i.landsat.toar/main.c:141
+#: ../imagery/i.landsat.toar/main.c:150 ../imagery/i.landsat.toar/main.c:158
+msgid "Required only if 'metfile' not given"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:140
+msgid "Sun elevation in degrees"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:149
+msgid "Image creation date (yyyy-mm-dd)"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:157
+msgid "Gain (H/L) of all Landsat ETM+ bands (1-5,61,62,7,8)"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:165
+msgid "Percent of solar radiance in path radiance"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:166 ../imagery/i.landsat.toar/main.c:176
+msgid "Required only if 'method' is any DOS"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:175
+msgid "Minimum pixels to consider digital number as dark object"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:184
+msgid "Rayleigh atmosphere (diffuse sky irradiance)"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:185
+msgid "Required only if 'method' is DOS3"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:194
+msgid "return value stored for a given metadata"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:195
+msgid "Required only if 'metfile' and -p given"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:201
+msgid "Landsat Number"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:202
+msgid "Creation timestamp"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:203
+msgid "Date"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:204
+msgid "Sun Elevation"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:205
+msgid "Sensor"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:206
+msgid "Bands count"
+msgstr ""
+msgid "Sun Azimuth Angle"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:215
+msgid "Scale factor for output"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:221
+msgid "Output at-sensor radiance instead of reflectance for all bands"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:226
+msgid "Input raster maps use as extension the number of the band instead the code"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:230
+msgid "Print output metadata info"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:256 ../imagery/i.landsat.toar/main.c:264
+#, c-format
+msgid "Illegal date format: [%s] (yyyy-mm-dd)"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:286
+msgid "Please use a metadata keyword with -p"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:323
+msgid "Failed to identify satellite"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:337
+#, c-format
+msgid "Lacking '%s' and/or '%s' for this satellite"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:343
+msgid "Landsat-7 requires band gain with 9 (H/L) characters"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:363
+#, c-format
+msgid "Unknown satellite type (defined by '%s')"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:410 ../imagery/i.landsat.toar/main.c:559
+#, c-format
+msgid "Unable to read data type of raster map <%s>"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:552
+#, c-format
+msgid "Raster map <%s> exists. Skipping."
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:575
+#, c-format
+msgid "Writing %s of <%s> to <%s>..."
+msgstr ""
+msgid "temperature"
+msgstr ""
+#: ../imagery/i.landsat.toar/landsat_met.c:117
+#, c-format
+msgid "Metadata file <%s> not found"
+msgstr ""
+#: ../imagery/i.emissivity/main.c:45
+msgid "emissivity"
+msgstr ""
+#: ../imagery/i.emissivity/main.c:46
+msgid "land flux"
+msgstr ""
+#: ../imagery/i.emissivity/main.c:49
+msgid "Computes emissivity from NDVI, generic method for sparse land."
+msgstr ""
+#: ../imagery/i.emissivity/main.c:53
+msgid "Name of the NDVI map [-]"
+msgstr ""
+#: ../imagery/i.emissivity/main.c:56
+msgid "Name of the output emissivity layer"
+msgstr ""
+#: ../imagery/i.group/main.c:55
+msgid "Creates, edits, and lists groups of imagery data."
+msgstr ""
+#: ../imagery/i.group/main.c:59
+msgid "Name of imagery group"
+msgstr ""
+#: ../imagery/i.group/main.c:63
+msgid "Name of imagery subgroup"
+msgstr ""
+#: ../imagery/i.group/main.c:67
+msgid "Name of raster map(s) to include in group"
+msgstr ""
+#: ../imagery/i.group/main.c:68 ../imagery/i.group/main.c:74
+msgid "Maps"
+msgstr ""
+#: ../imagery/i.group/main.c:73
+msgid "Remove selected files from specified group or subgroup"
+msgstr ""
+#: ../imagery/i.group/main.c:78
+msgid "List files from specified (sub)group"
+msgstr ""
+#: ../imagery/i.group/main.c:83
+msgid "List subgroups from specified group"
+msgstr ""
+#: ../imagery/i.group/main.c:109
+msgid "No input raster map(s) specified"
+msgstr ""
+#: ../imagery/i.group/main.c:128 ../imagery/i.group/main.c:150
+msgid "Specified group does not exist in current mapset"
+msgstr ""
+#: ../imagery/i.group/main.c:132
+#, c-format
+msgid "Removing raster maps from subgroup <%s>..."
+msgstr ""
+#: ../imagery/i.group/main.c:137
+#, c-format
+msgid "Removing raster maps from group <%s>..."
+msgstr ""
+#: ../imagery/i.group/main.c:158
+#, c-format
+msgid "Subgroup <%s> of group <%s> references the following raster maps:"
+msgstr ""
+#: ../imagery/i.group/main.c:173
+#, c-format
+msgid "Group <%s> references the following raster maps:"
+msgstr ""
+#: ../imagery/i.group/main.c:185
+#, c-format
+msgid "Group <%s> does not yet exist. Creating..."
+msgstr ""
+#: ../imagery/i.group/main.c:189 ../imagery/i.group/main.c:198
+#, c-format
+msgid "Adding raster maps to group <%s>..."
+msgstr ""
+#: ../imagery/i.group/main.c:193
+#, c-format
+msgid "Adding raster maps to subgroup <%s>..."
+msgstr ""
+#: ../imagery/i.group/main.c:219
+msgid "No input raster maps defined"
+msgstr ""
+#: ../imagery/i.group/main.c:223 ../imagery/i.group/main.c:265
+#, c-format
+msgid "Raster map <%s> not found. Skipped."
+msgstr ""
+#: ../imagery/i.group/main.c:228
+#, c-format
+msgid "Adding raster map <%s> to group"
+msgstr ""
+#: ../imagery/i.group/main.c:234
+#, c-format
+msgid "Raster map <%s> exists in group. Skipped."
+msgstr ""
+#: ../imagery/i.group/main.c:271
+#, c-format
+msgid "Adding raster map <%s> to subgroup"
+msgstr ""
+#: ../imagery/i.group/main.c:278
+#, c-format
+msgid "Raster map <%s> exists in subgroup. Skipping..."
+msgstr ""
+#: ../imagery/i.group/main.c:327
+#, c-format
+msgid "Removing raster map <%s> from group"
+msgstr ""
+#: ../imagery/i.group/main.c:344 ../imagery/i.group/main.c:403
+msgid "No raster map removed"
+msgstr ""
+#: ../imagery/i.group/main.c:386
+#, c-format
+msgid "Removing raster map <%s> from subgroup"
+msgstr ""
+#: ../imagery/i.group/main.c:422
+#, c-format
+msgid "Group <%s> does not contain any subgroup.\n"
+msgstr ""
+#: ../imagery/i.group/main.c:433
+#, c-format
+msgid "group <%s> references the following subgroups\n"
+msgstr ""
+#: ../imagery/i.biomass/main.c:51
+msgid "biomass"
+msgstr ""
+#: ../imagery/i.biomass/main.c:53
+msgid "yield"
+msgstr ""
+#: ../imagery/i.biomass/main.c:55
+msgid "Computes biomass growth, precursor of crop yield calculation."
+msgstr ""
+#: ../imagery/i.biomass/main.c:60
+msgid "Name of fPAR raster map"
+msgstr ""
+#: ../imagery/i.biomass/main.c:65
+msgid "Name of light use efficiency raster map (UZB:cotton=1.9)"
+msgstr ""
+#: ../imagery/i.biomass/main.c:69
+msgid "Name of degree latitude raster map [dd.ddd]"
+msgstr ""
+#: ../imagery/i.biomass/main.c:73
+msgid "Name of Day of Year raster map [1-366]"
+msgstr ""
+#: ../imagery/i.biomass/main.c:78
+msgid "Name of single-way transmissivity raster map [0.0-1.0]"
+msgstr ""
+#: ../imagery/i.biomass/main.c:83
+msgid "Value of water availability raster map [0.0-1.0]"
+msgstr ""
+#: ../imagery/i.biomass/main.c:87
+msgid "Name for output daily biomass growth raster map [kg/ha/d]"
+msgstr ""
+#: ../imagery/i.evapo.pm/main.c:61
+msgid "Computes potential evapotranspiration calculation with hourly Penman-Monteith."
+msgstr ""
+#: ../imagery/i.evapo.pm/main.c:65
+msgid "Name of input elevation raster map [m a.s.l.]"
+msgstr ""
+#: ../imagery/i.evapo.pm/main.c:69
+msgid "Name of input temperature raster map [C]"
+msgstr ""
+#: ../imagery/i.evapo.pm/main.c:73
+msgid "Name of input relative humidity raster map [%]"
+msgstr ""
+#: ../imagery/i.evapo.pm/main.c:77
+msgid "Name of input wind speed raster map [m/s]"
+msgstr ""
+#: ../imagery/i.evapo.pm/main.c:82
+msgid "Name of input net solar radiation raster map [MJ/m2/h]"
+msgstr ""
+#: ../imagery/i.evapo.pm/main.c:86
+msgid "Name of input crop height raster map [m]"
+msgstr ""
+#: ../imagery/i.evapo.pm/main.c:89
+msgid "Name for output raster map [mm/h]"
+msgstr ""
+#: ../imagery/i.evapo.pm/main.c:93
+msgid "Set negative evapotranspiration to zero"
+msgstr ""
+#: ../imagery/i.evapo.pm/main.c:97
+msgid "Use Night-time"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:57
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:88
+#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:65
+#: ../imagery/i.ortho.photo/i.ortho.target/main.c:48
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:389
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:48
+#: ../imagery/i.ortho.photo/i.ortho.photo/menu.c:47
+msgid "orthorectify"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:59
+msgid "Select and modify the imagery group camera reference file."
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:64
+#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:71
+#: ../imagery/i.ortho.photo/i.ortho.target/main.c:54
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:57
+#: ../imagery/i.ortho.photo/i.ortho.photo/menu.c:53
+msgid "Name of imagery group for ortho-rectification"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:71
+msgid "Name of camera reference file"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:77
+msgid "Camera name"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:83
+msgid "Camera id"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:89
+msgid "Calibrated focal length"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:94
+msgid "Principal point coordinates"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:100
+msgid "Fiducial coordinates"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:129
+#, c-format
+msgid "Can not read camera file '%s'"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:132
+#, c-format
+msgid "Replacing camera name '%s' with '%s'"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:138
+#, c-format
+msgid "Replacing camera cam_id '%s' with '%s'"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:146
+#, c-format
+msgid "Replacing calibrated focal length '%g' with '%g'"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:153
+#, c-format
+msgid "Replacing coordinates of principal point '%.17g, %.17g' with '%.17g, %.17g'"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:164
+msgid "Please provide a camera name for a new camera definition"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:168
+msgid "Please provide a camera ID for a new camera definition"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:172
+msgid "Please provide calibrated focal length for a new camera definition"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:176
+msgid "Using default coordinates 0.0, 0.0 for the principal point"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:190
+msgid "Too many fiducials!"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:212
+#, c-format
+msgid "No group '%s' in current mapset"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:217
+#, c-format
+msgid "Group [%s] in location [%s] mapset [%s] now uses camera file [%s]"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.rectify/rectify.c:81
+#, c-format
+msgid "No elevation available at row = %d, col = %d"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:12
+#, c-format
+msgid "Control Z Point file for group <%s@%s> - "
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:23
+msgid " Run OPTION 7 of i.ortho.photo again!\n"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:26
+msgid "No active Control Points!"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:28
+msgid " Run OPTION 7 of i.ortho.photo!\n"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:45
+#, c-format
+msgid "Reference Point file for group <%s@%s> - "
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:51
+msgid "Poorly placed reference points."
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:53
+msgid " Run OPTION 5 of i.ortho.photo again!"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:57
+msgid "No active reference points."
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:59
+msgid " Run OPTION 5 of i.ortho.photo!"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:90
+msgid "Orthorectifies an image by using the image to photo coordinate transformation matrix."
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:131
+msgid "Raster map with camera angle relative to ground surface"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:245
+#, c-format
+msgid "No camera reference file selected for group <%s>"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:249
+#, c-format
+msgid "Bad format in camera file for group <%s>"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:255
+#, c-format
+msgid "Bad format in initial exposure station file for group <%s>"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:331
+#, c-format
+msgid "No target elevation model selected for group <%s>"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.rectify/exec.c:47
+#: ../imagery/i.ortho.photo/i.ortho.rectify/angle.c:50
+msgid "Could not open elevation raster"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.rectify/angle.c:36
+msgid "Calculating camera angle to local surface..."
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.rectify/angle.c:66
+#, c-format
+msgid "Converting units to meters, factor=%.6f"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:67
+msgid "Select or modify the target elevation model."
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:76
+msgid "Name of the target location"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:81
+msgid "Name of the target mapset"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:86
+msgid "Name of elevation map to use for ortho-rectification"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:92
+msgid "Math expression to convert to real elevation"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:97
+msgid "Unit of the elevation map"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:102
+msgid "No data value"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:107
+msgid "Print currently selected elevation map and exit"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:141
+#, c-format
+msgid "Please select a target for group [%s] first"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:146
+#, c-format
+msgid "Target location [%s] not found\n"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:153
+#, c-format
+msgid "Cannot find default elevation map for target in group [%s]"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:190
+#, c-format
+msgid "Elevation map name is missing. Please set '%s' option"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:211
+#, c-format
+msgid "Group [%s] in location [%s] mapset [%s] now uses elevation map [%s]"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:214
+#, c-format
+msgid "Mapset [%s] in target location [%s] - %s "
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:216
+msgid "permission denied\n"
+msgstr ""
+msgid "not found\n"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.target/main.c:50
+msgid "Select or modify the imagery group target."
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.target/main.c:60
+msgid "Name of target location for ortho-rectification"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.target/main.c:66
+msgid "Name of target mapset for ortho-rectification"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.target/main.c:81
+#, c-format
+msgid "Group [%s] targeted for location [%s], mapset [%s]"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:93
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:136
+#: ../misc/m.transform/main.c:96
+#, c-format
+msgid "Error conducting transform (%d)"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:251
+msgid "Poorly placed image to photo control points"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:253
+msgid "Poorly placed image to target control points"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:255
+#: ../misc/m.transform/main.c:196
+msgid "Insufficient memory"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:257
+#: ../misc/m.transform/main.c:198
+msgid "Parameter error"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:259
+#: ../misc/m.transform/main.c:200
+msgid "No active control points"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:367
+#: ../misc/m.transform/main.c:295
+#, c-format
+msgid "Invalid coordinates: [%s]"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:391
+msgid "GCP"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:393
+#: ../misc/m.transform/main.c:320
+msgid "Computes a coordinate transformation based on the control points."
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:406
+#: ../misc/m.transform/main.c:341
+msgid "point index"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:407
+#: ../misc/m.transform/main.c:342
+msgid "source coordinates"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:408
+#: ../misc/m.transform/main.c:343
+msgid "destination coordinates"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:409
+#: ../misc/m.transform/main.c:344
+msgid "forward coordinates (destination)"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:410
+#: ../misc/m.transform/main.c:345
+msgid "reverse coordinates (source)"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:411
+#: ../misc/m.transform/main.c:346
+msgid "forward coordinates difference (destination)"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:412
+#: ../misc/m.transform/main.c:347
+msgid "reverse coordinates difference (source)"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:413
+#: ../misc/m.transform/main.c:348
+msgid "forward error (destination)"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:414
+#: ../misc/m.transform/main.c:349
+msgid "reverse error (source)"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:417
+#: ../misc/m.transform/main.c:352 ../vector/v.out.ascii/args.c:55
+msgid "Output format"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:421
+#: ../misc/m.transform/main.c:356
+msgid "Display summary information"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:427
+#: ../misc/m.transform/main.c:361
+msgid "File containing coordinates to transform (\"-\" to read from stdin)"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:428
+msgid "Local x,y,z coordinates to target east,north,height"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:432
+#: ../misc/m.transform/main.c:366
+msgid "Reverse transform of coords file or coeff. dump"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:433
+msgid "Target east,north,height coordinates to local x,y,z"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:437
+#: ../misc/m.transform/main.c:371
+msgid "Display transform matrix coefficients"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:452
+#, c-format
+msgid "Can not read reference points for group <%s>"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:456
+#, c-format
+msgid "Can not read control points for group <%s>"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:50
+msgid "Interactively creates or modifies entries in a camera initial exposure station file for imagery group referenced by a sub-block."
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:62
+msgid "Initial Camera Exposure X-coordinate"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:67
+msgid "Initial Camera Exposure Y-coordinate"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:72
+msgid "Initial Camera Exposure Z-coordinate"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:77
+msgid "Apriori X-coordinate standard deviation"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:82
+msgid "Apriori Y-coordinate standard deviation"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:87
+msgid "Apriori Z-coordinate standard deviation"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:92
+msgid "Initial Camera Omega (roll) degrees"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:97
+msgid "Initial Camera Phi (pitch) degrees"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:102
+msgid "Initial Camera Kappa (yaw) degrees"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:107
+msgid "Apriori Omega (roll) standard deviation"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:112
+msgid "Apriori Phi (pitch) standard deviation"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:117
+msgid "Apriori Kappa (yaw) standard deviation"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:121
+msgid "Use initial values at run time"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:125
+msgid "Print initial values"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:137
+#, c-format
+msgid "Group [%s] not found"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:150
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:154
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:158
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:162
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:166
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:170
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:174
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:178
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:182
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:186
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:190
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:194
+#, c-format
+msgid "Option '%s' is required for new exposure info"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.photo/menu.c:48
+msgid "Menu driver for the photo imagery programs."
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.photo/menu.c:59
+msgid "Name of Modules"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.photo/menu.c:70
+msgid "1 - Select/Modify imagery group"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.photo/menu.c:71
+msgid "2 - Select/Modify imagery group target"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.photo/menu.c:72
+msgid "3 - Select/Modify target elevation model"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.photo/menu.c:73
+msgid "4 - Select/Modify imagery group camera"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.photo/menu.c:74
+msgid "5 - Compute image-to-photo transformation"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.photo/menu.c:75
+msgid "6 - Initialize exposure station parameters"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.photo/menu.c:76
+msgid "7 - Compute ortho-rectification parameters"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.photo/menu.c:77
+msgid "8 - Ortho-rectify imagery files"
+msgstr ""
+#: ../misc/m.cogo/main.c:227
+msgid "polar"
+msgstr ""
+#: ../misc/m.cogo/main.c:228
+msgid "A simple utility for converting bearing and distance measurements to coordinates and vice versa."
+msgstr ""
+#: ../misc/m.cogo/main.c:230
+msgid "It assumes a cartesian coordinate system"
+msgstr ""
+#: ../misc/m.cogo/main.c:234
+msgid "Lines are labelled"
+msgstr ""
+#: ../misc/m.cogo/main.c:239
+msgid "Convert from coordinates to bearing and distance"
+msgstr ""
+#: ../misc/m.cogo/main.c:244
+msgid "Repeat the starting coordinate at the end to close a loop"
+msgstr ""
+#: ../misc/m.cogo/main.c:255
+msgid "Starting coordinate pair"
+msgstr ""
+#: ../misc/m.cogo/main.c:265
+#, c-format
+msgid "Couldn't open COGO file <%s>"
+msgstr ""
+#: ../misc/m.cogo/main.c:274
+#, c-format
+msgid "Couldn't open output file <%s>"
+msgstr ""
+#: ../misc/m.cogo/main.c:301 ../misc/m.cogo/main.c:304
+msgid "Converting starting coordinate pair"
+msgstr ""
+#: ../misc/m.cogo/main.c:319
+#, c-format
+msgid "Input parse error on line %lu"
+msgstr ""
+#: ../misc/m.transform/main.c:92
+#, c-format
+msgid "Not enough points, %d are required"
+msgstr ""
+#: ../misc/m.transform/main.c:194
+msgid "Poorly placed control points"
+msgstr ""
+#: ../misc/m.transform/main.c:330
+msgid "Rectification polynomial order"
+msgstr ""
+#: ../misc/m.transform/main.c:362
+msgid "Local x,y coordinates to target east,north"
+msgstr ""
+#: ../misc/m.transform/main.c:367
+msgid "Target east,north coordinates to local x,y"
+msgstr ""
+#: ../misc/m.nviz.image/main.c:56
+msgid "Creates a 3D rendering of GIS data."
+msgstr ""
+#: ../misc/m.nviz.image/main.c:57
+msgid "Renders surfaces (raster data), 2D/3D vector data, and volumes (3D raster data) in 3D."
+msgstr ""
+#: ../misc/m.nviz.image/main.c:83
+msgid "Unable to render data"
+msgstr ""
+#: ../misc/m.nviz.image/main.c:142
+#, c-format
+msgid "Vertical exaggeration not given, using calculated value %.0f"
+msgstr ""
+#: ../misc/m.nviz.image/main.c:154
+#, c-format
+msgid "Viewpoint height not given, using calculated value %.0f"
+msgstr ""
+#: ../misc/m.nviz.image/main.c:240
+msgid "Unsupported output format"
+msgstr ""
+#: ../misc/m.nviz.image/cplane.c:40
+#, c-format
+msgid "Cutting plane number <%d> not found"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:51
+msgid "Use draw mode for all loaded surfaces"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:52 ../misc/m.nviz.image/args.c:133
+#: ../misc/m.nviz.image/args.c:143 ../misc/m.nviz.image/args.c:150
+#: ../misc/m.nviz.image/args.c:156 ../misc/m.nviz.image/args.c:164
+#: ../misc/m.nviz.image/args.c:173 ../misc/m.nviz.image/args.c:183
+#: ../misc/m.nviz.image/args.c:191 ../misc/m.nviz.image/args.c:201
+#: ../misc/m.nviz.image/args.c:209 ../misc/m.nviz.image/args.c:219
+msgid "Surfaces"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:92
+msgid "Name for output image file (without extension)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:93 ../misc/m.nviz.image/args.c:107
+#: ../misc/m.nviz.image/args.c:117
+msgid "Image"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:115
+msgid "Size (width, height) of output image"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:132
+msgid "Name of raster map(s) for elevation"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:142
+msgid "Constant elevation value(s) to use instead of a raster DEM"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:149
+msgid "Name of raster map(s) for color"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:155
+msgid "Color value(s)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:163
+msgid "Name of raster map(s) for mask"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:172
+msgid "Name of raster map(s) for transparency"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:182
+msgid "Transparency value(s)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:190
+msgid "Name of raster map(s) for shininess"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:200
+msgid "Shininess value(s)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:208
+msgid "Name of raster map(s) for emission"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:218
+msgid "Emission value(s)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:230
+msgid "Draw mode"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:242
+msgid "Fine resolution"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:253
+msgid "Coarse resolution"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:264
+msgid "Draw style"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:276
+msgid "Shading"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:285
+msgid "Wire color"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:297
+msgid "Surface position"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:309
+msgid "Name of line vector overlay map(s)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:310 ../misc/m.nviz.image/args.c:318
+#: ../misc/m.nviz.image/args.c:330 ../misc/m.nviz.image/args.c:339
+#: ../misc/m.nviz.image/args.c:348 ../misc/m.nviz.image/args.c:355
+#: ../misc/m.nviz.image/args.c:369 ../misc/m.nviz.image/args.c:379
+#: ../misc/m.nviz.image/args.c:391
+msgid "Vector lines"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:317 ../misc/m.nviz.image/args.c:410
+msgid "Layer number or name for thematic mapping"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:329
+msgid "Vector line width"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:337 ../misc/m.nviz.image/args.c:449
+msgid "Name of width definition column"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:345
+msgid "Vector line color"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:353 ../misc/m.nviz.image/args.c:465
+msgid "Name of color definition column"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:364
+msgid "Vector line display mode"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:366
+msgid "surface;drape on raster surface;flat;draw at constant elevation"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:378
+msgid "Vector line height"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:390
+msgid "Vector lines position"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:402
+msgid "Name of point vector overlay map(s)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:403 ../misc/m.nviz.image/args.c:411
+#: ../misc/m.nviz.image/args.c:423 ../misc/m.nviz.image/args.c:432
+#: ../misc/m.nviz.image/args.c:442 ../misc/m.nviz.image/args.c:451
+#: ../misc/m.nviz.image/args.c:460 ../misc/m.nviz.image/args.c:467
+#: ../misc/m.nviz.image/args.c:480 ../misc/m.nviz.image/args.c:488
+#: ../misc/m.nviz.image/args.c:503 ../misc/m.nviz.image/args.c:513
+msgid "Vector points"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:422
+msgid "Icon size (map units)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:430
+msgid "Name of size definition column"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:441
+msgid "Icon width"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:457
+msgid "Icon color"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:476
+msgid "Icon marker"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:486
+msgid "Name of marker definition column"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:497
+msgid "3D vector point display mode"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:499
+msgid "surface;drape on raster surface;3D;place at 3D point's z-elevation"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:512
+msgid "Vector points position"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:529
+msgid "Viewpoint position (x,y model coordinates)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:530 ../misc/m.nviz.image/args.c:542
+#: ../misc/m.nviz.image/args.c:552 ../misc/m.nviz.image/args.c:564
+#: ../misc/m.nviz.image/args.c:586
+msgid "Viewpoint"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:541
+msgid "Viewpoint height (in map units)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:551
+msgid "Viewpoint field of view (in degrees)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:563
+msgid "Viewpoint twist angle (in degrees)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:585
+msgid "Focus to point on surface (from SW corner in map units)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:595 ../misc/m.nviz.image/args.c:630
+#: ../misc/m.nviz.image/args.c:642 ../misc/m.nviz.image/args.c:652
+#: ../misc/m.nviz.image/args.c:661 ../misc/m.nviz.image/args.c:669
+#: ../misc/m.nviz.image/args.c:678 ../misc/m.nviz.image/args.c:689
+#: ../misc/m.nviz.image/args.c:698 ../misc/m.nviz.image/args.c:709
+#: ../misc/m.nviz.image/args.c:716 ../misc/m.nviz.image/args.c:722
+#: ../misc/m.nviz.image/args.c:734 ../misc/m.nviz.image/args.c:744
+#: ../misc/m.nviz.image/args.c:755
+msgid "Volumes"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:605
+msgid "Volume draw mode"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:617
+msgid "Volume shading"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:629
+msgid "Volume position"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:640
+msgid "Volume resolution"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:651
+msgid "Isosurface level"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:660
+msgid "Name of volume for isosurface color"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:668
+msgid "Isosurface color"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:677
+msgid "Name of 3D raster map(s) for isosurface transparency"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:688
+msgid "Transparency value(s)for isosurfaces"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:697
+msgid "Name of 3D raster map(s) for shininess"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:708
+msgid "Shininess value(s) for isosurfaces"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:715
+msgid "Toggles normal direction of all isosurfaces (changes light effect)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:721
+msgid "Draw volume box"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:733
+msgid "Volume slice parallel to given axis (x, y, z)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:743
+msgid "Volume slice position"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:754
+msgid "Volume slice transparency"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:771
+msgid "Light position (x,y,z model coordinates)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:772 ../misc/m.nviz.image/args.c:778
+#: ../misc/m.nviz.image/args.c:787 ../misc/m.nviz.image/args.c:797
+msgid "Lighting"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:777
+msgid "Light color"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:786
+msgid "Light brightness"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:796
+msgid "Light ambient"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:810
+msgid "Cutting plane index (0-5)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:811 ../misc/m.nviz.image/args.c:820
+#: ../misc/m.nviz.image/args.c:829 ../misc/m.nviz.image/args.c:841
+#: ../misc/m.nviz.image/args.c:852
+msgid "Cutting planes"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:819
+msgid "Cutting plane x,y,z coordinates"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:831
+msgid "Cutting plane rotation along the vertical axis"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:842
+msgid "Cutting plane tilt"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:854
+msgid "Cutting plane color (between two surfaces)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:870
+msgid "North-West edge"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:871
+msgid "North-East edge"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:872
+msgid "South-West edge"
+msgstr ""
+msgid "South-East edge"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:874
+msgid "Fringe edges"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:875 ../misc/m.nviz.image/args.c:881
+#: ../misc/m.nviz.image/args.c:890
+msgid "Fringe"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:880
+msgid "Fringe color"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:889
+msgid "Fringe elevation"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:903
+msgid "Place north arrow at given position \t(in screen coordinates from bottom left corner)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:905 ../misc/m.nviz.image/args.c:915
+#: ../misc/m.nviz.image/args.c:922
+msgid "Decoration"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:914
+msgid "North arrow size (in map units)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:921
+msgid "North arrow color"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:973
+#, c-format
+msgid "At least one <%s> or <%s> required"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:987 ../misc/m.nviz.image/args.c:1017
+#: ../misc/m.nviz.image/args.c:1023 ../misc/m.nviz.image/args.c:1029
+#: ../misc/m.nviz.image/args.c:1035 ../misc/m.nviz.image/args.c:1041
+#: ../misc/m.nviz.image/args.c:1047
+#, c-format
+msgid "Inconsistent number of attributes (<%s/%s>: %d vs. <%s>: %d)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:1058
+#, c-format
+msgid "Inconsistent number of attributes (<%s>: %d vs. <%s>: %d x 3)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:1064 ../misc/m.nviz.image/args.c:1070
+#: ../misc/m.nviz.image/args.c:1082 ../misc/m.nviz.image/args.c:1089
+#: ../misc/m.nviz.image/args.c:1096 ../misc/m.nviz.image/args.c:1103
+#: ../misc/m.nviz.image/args.c:1110 ../misc/m.nviz.image/args.c:1122
+#: ../misc/m.nviz.image/args.c:1127 ../misc/m.nviz.image/args.c:1164
+#, c-format
+msgid "Inconsistent number of attributes (<%s>: %d vs. <%s>: %d)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:1146 ../misc/m.nviz.image/args.c:1156
+#, c-format
+msgid "Inconsistent number of attributes (<%s>: %d vs. <%s>: %d, <%s>: %d)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:1171
+#, c-format
+msgid "Inconsistent number of attributes (<%s>: %d vs. <%s>: %d x 6)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:1183
+#, c-format
+msgid "Inconsistent number of attributes (<%s/%s>: %d vs. <%s>: %d, <%s>: %d)"
+msgstr ""
+#: ../misc/m.nviz.image/volume.c:42 ../misc/m.nviz.image/volume.c:133
+#, c-format
+msgid "3d raster map <%s> not found"
+msgstr ""
+#: ../misc/m.nviz.image/volume.c:96 ../misc/m.nviz.image/volume.c:256
+#, c-format
+msgid "Error tokenize '%s'"
+msgstr ""
+#: ../misc/m.nviz.image/volume.c:103 ../misc/m.nviz.image/volume.c:271
+#, c-format
+msgid "Volume set number %d is not available"
+msgstr ""
+#: ../misc/m.nviz.image/volume.c:108
+#, c-format
+msgid "Unable to add isosurface (volume set %d)"
+msgstr ""
+#: ../misc/m.nviz.image/volume.c:119 ../misc/m.nviz.image/volume.c:140
+#: ../misc/m.nviz.image/volume.c:153 ../misc/m.nviz.image/volume.c:172
+#: ../misc/m.nviz.image/volume.c:182 ../misc/m.nviz.image/volume.c:195
+#: ../misc/m.nviz.image/volume.c:205
+#, c-format
+msgid "Unable to set isosurface (%d) attribute (%d) of volume %d"
+msgstr ""
+#: ../misc/m.nviz.image/volume.c:159 ../misc/m.nviz.image/surface.c:131
+#, c-format
+msgid "Color attribute not defined, using default <%s>"
+msgstr ""
+#: ../misc/m.nviz.image/volume.c:267
+#, c-format
+msgid "Wrong name for axis: %s"
+msgstr ""
+#: ../misc/m.nviz.image/volume.c:276
+#, c-format
+msgid "Unable to add slice (volume set %d)"
+msgstr ""
+#: ../misc/m.nviz.image/volume.c:288
+#, c-format
+msgid "Unable to set slice (%d) position of volume %d"
+msgstr ""
+#: ../misc/m.nviz.image/volume.c:294
+#, c-format
+msgid "Unable to set slice (%d) transparency of volume %d"
+msgstr ""
+#: ../misc/m.nviz.image/surface.c:67
+#, c-format
+msgid "Missing topography attribute for surface %d"
+msgstr ""
+#: ../misc/m.nviz.image/surface.c:137
+#, c-format
+msgid "Missing color attribute for surface %d"
+msgstr ""
+#: ../misc/m.nviz.image/surface.c:217
+#, c-format
+msgid "Surface id %d doesn't exist"
+msgstr ""
+#: ../misc/m.nviz.image/surface.c:264 ../misc/m.nviz.image/surface.c:271
+#, c-format
+msgid "Unable to set draw mode for surface id %d"
+msgstr ""
+#: ../misc/m.nviz.image/vector.c:300 ../misc/m.nviz.image/vector.c:309
+#: ../misc/m.nviz.image/vector.c:319 ../misc/m.nviz.image/vector.c:329
+#, c-format
+msgid "Column <%s> in table <%s> not found"
+msgstr ""
+#: ../misc/m.nviz.image/vector.c:304
+msgid "Data type of color column must be character"
+msgstr ""
+#: ../misc/m.nviz.image/vector.c:314
+msgid "Data type of size column must be numeric"
+msgstr ""
+#: ../misc/m.nviz.image/vector.c:324
+msgid "Data type of width column must be numeric"
+msgstr ""
+#: ../misc/m.nviz.image/vector.c:335
+msgid "Data type of marker column must be character"
+msgstr ""
+#: ../misc/m.nviz.script/main.c:75
+msgid "Creates fly-through script to run in NVIZ."
+msgstr ""
+#: ../misc/m.nviz.script/main.c:80
+msgid "Name of output script"
+msgstr ""
+#: ../misc/m.nviz.script/main.c:86
+msgid "Prefix of output images (default = NVIZ)"
+msgstr ""
+#: ../misc/m.nviz.script/main.c:94
+msgid "Route coordinates (east,north)"
+msgstr ""
+#: ../misc/m.nviz.script/main.c:100
+msgid "Camera layback distance (in map units)"
+msgstr ""
+#: ../misc/m.nviz.script/main.c:106
+msgid "Camera height above terrain"
+msgstr ""
+#: ../misc/m.nviz.script/main.c:112
+msgid "Number of frames"
+msgstr ""
+#: ../misc/m.nviz.script/main.c:118
+msgid "Start frame number (default=0)"
+msgstr ""
+#: ../misc/m.nviz.script/main.c:123
+msgid "Full render -- Save images"
+msgstr ""
+#: ../misc/m.nviz.script/main.c:127
+msgid "Fly at constant elevation (ht)"
+msgstr ""
+#: ../misc/m.nviz.script/main.c:132
+msgid "Include command in the script to output a KeyFrame file"
+msgstr ""
+#: ../misc/m.nviz.script/main.c:136
+msgid "Render images off-screen"
+msgstr ""
+#: ../misc/m.nviz.script/main.c:140
+msgid "Enable vector and sites drawing"
+msgstr ""
+#: ../misc/m.nviz.script/main.c:148
+msgid "Either -i flag and/or route parameter must be used"
+msgstr ""
+#: ../misc/m.nviz.script/main.c:172
+msgid "Off-screen only available with full render mode"
+msgstr ""
+#: ../misc/m.nviz.script/main.c:250
+#, c-format
+msgid "You must provide at least four points %d"
+msgstr ""
+#: ../misc/m.nviz.script/main.c:324
+#, c-format
+msgid "Created NVIZ script <%s>."
+msgstr ""
+#: ../misc/m.nviz.script/main.c:439
+msgid "Skipping this point, selected point is outside region. Perhaps the camera setback distance puts it beyond the edge?"
+msgstr ""
+#: ../misc/m.measure/main.c:45
+msgid "Measures the lengths and areas of features."
+msgstr ""
+#: ../misc/m.measure/main.c:47
+msgid "measurement"
+msgstr ""
+#: ../misc/m.measure/main.c:56
+msgid "Units"
+msgstr ""
+#: ../misc/m.measure/main.c:57
+msgid "Default: location map units"
+msgstr ""
+#: ../misc/m.measure/main.c:61
+msgid "Shell script style"
+msgstr ""
+#: ../misc/m.measure/main.c:104
+msgid "Length:"
+msgstr ""
+#: ../misc/m.measure/main.c:115
+msgid "Area:"
+msgstr ""
+#: ../db/db.databases/main.c:53
+msgid "Unable to list databases. Try to define correct connection settings by db.login."
+msgstr ""
+#: ../db/db.databases/main.c:63
+msgid "No databases found"
+msgstr ""
+#: ../db/db.databases/main.c:87
+msgid "Location"
+msgstr ""
+#: ../db/db.databases/main.c:88
+msgid "Path for SQLite driver, or connection string for PostgreSQL driver"
+msgstr ""
+#: ../db/db.databases/main.c:97 ../db/db.copy/main.c:37
+#: ../db/db.execute/main.c:127 ../db/db.execute/main.c:134
+#: ../db/db.execute/main.c:140 ../db/db.select/main.c:267
+#: ../db/db.dropdb/main.c:73 ../db/db.createdb/main.c:73
+#: ../vector/v.db.select/main.c:57
+msgid "SQL"
+msgstr ""
+#: ../db/db.databases/main.c:99
+msgid "Lists all databases for a given driver and location."
+msgstr ""
+#: ../db/db.drivers/main.c:39
+msgid "Unable to read dbmscap file"
+msgstr ""
+#: ../db/db.drivers/main.c:63
+msgid "Full output"
+msgstr ""
+#: ../db/db.drivers/main.c:67
+msgid "Print drivers and exit"
+msgstr ""
+#: ../db/db.drivers/main.c:72 ../db/db.connect/main.c:45
+#: ../db/db.login/main.c:41
+msgid "connection settings"
+msgstr ""
+#: ../db/db.drivers/main.c:73
+msgid "Lists all database drivers."
+msgstr ""
+#: ../db/db.columns/main.c:44 ../db/db.copy/main.c:100
+#: ../db/db.describe/main.c:50 ../db/db.select/main.c:53
+#, c-format
+msgid "Table <%s> not found in database <%s> using driver <%s>"
+msgstr ""
+#: ../db/db.columns/main.c:101
+msgid "List all columns for a given table."
+msgstr ""
+#: ../db/db.copy/main.c:38
+msgid "Copy a table."
+msgstr ""
+#: ../db/db.copy/main.c:40
+msgid "Either 'from_table' (optionally with 'where') can be used or 'select' option, but not 'from_table' and 'select' at the same time."
+msgstr ""
+#: ../db/db.copy/main.c:46
+msgid "Input driver name"
+msgstr ""
+#: ../db/db.copy/main.c:52
+msgid "Input database name"
+msgstr ""
+#: ../db/db.copy/main.c:59
+msgid "Input table name (only, if 'select' is not used)"
+msgstr ""
+#: ../db/db.copy/main.c:65
+msgid "Output driver name"
+msgstr ""
+#: ../db/db.copy/main.c:71
+msgid "Output database name"
+msgstr ""
+#: ../db/db.copy/main.c:78
+msgid "Output table name"
+msgstr ""
+#: ../db/db.copy/main.c:87
+msgid "Full select statement (only, if 'from_table' and 'where' is not used)"
+msgstr ""
+#: ../db/db.copy/main.c:88
+msgid "E.g.: SELECT dedek FROM starobince WHERE obec = 'Frimburg'"
+msgstr ""
+#: ../db/db.copy/main.c:96
+msgid "Cannot combine 'from_table' and 'select' options"
+msgstr ""
+#: ../db/db.copy/main.c:122
+msgid "Either 'from_table' or 'select' option must be given."
+msgstr ""
+#: ../db/db.copy/main.c:125
+msgid "Cannot combine 'select' and 'where' options"
+msgstr ""
+#: ../db/db.copy/main.c:135
+msgid "Copy table failed"
+msgstr ""
+#: ../db/db.connect/main.c:47
+msgid "Prints/sets general DB connection for current mapset."
+msgstr ""
+#: ../db/db.connect/main.c:52
+msgid "Substitute variables in database settings"
+msgstr ""
+#: ../db/db.connect/main.c:57
+msgid "Print current connection parameters using shell style and exit"
+msgstr ""
+#: ../db/db.connect/main.c:69
+msgid "Overwrite current settings if already initialized"
+msgstr ""
+#: ../db/db.connect/main.c:91
+msgid "Default group of database users to which select privilege is granted"
+msgstr ""
+#: ../db/db.connect/main.c:141 ../db/db.tables/main.c:41
+msgid "Database connection not defined. Run db.connect."
+msgstr ""
+#: ../db/db.connect/main.c:166
+msgid "DB settings already defined, nothing to do"
+msgstr ""
+#: ../db/db.connect/main.c:172
+msgid "Default driver is not set"
+msgstr ""
+#: ../db/db.connect/main.c:175
+msgid "Default database is not set"
+msgstr ""
+#: ../db/db.describe/main.c:108
+msgid "Print column names only instead of full column descriptions"
+msgstr ""
+#: ../db/db.describe/main.c:113
+msgid "Print table structure"
+msgstr ""
+#: ../db/db.describe/main.c:131
+msgid "Describes a table in detail."
+msgstr ""
+#: ../db/db.execute/main.c:57 ../db/db.select/main.c:63
+#, c-format
+msgid "Unable to open file <%s>: %s"
+msgstr ""
+#: ../db/db.execute/main.c:94 ../db/db.execute/main.c:99
+#, c-format
+msgid "Error while executing: '%s'"
+msgstr ""
+#: ../db/db.execute/main.c:128
+msgid "Executes any SQL statement."
+msgstr ""
+#: ../db/db.execute/main.c:129
+msgid "For SELECT statements use 'db.select'."
+msgstr ""
+#: ../db/db.execute/main.c:132
+msgid "SQL statement"
+msgstr ""
+#: ../db/db.execute/main.c:133
+msgid "Example: update rybniky set kapri = 'hodne' where kapri = 'malo'"
+msgstr ""
+#: ../db/db.execute/main.c:138
+msgid "Name of file containing SQL statement(s)"
+msgstr ""
+#: ../db/db.execute/main.c:160
+msgid "Ignore SQL errors and continue"
+msgstr ""
+#: ../db/db.execute/main.c:161 ../vector/v.build/main.c:51
+#: ../vector/v.build/main.c:77
+msgid "Errors"
+msgstr ""
+#: ../db/db.execute/main.c:167
+#, c-format
+msgid "You must provide <%s> or <%s> option"
+msgstr ""
+#: ../db/db.select/main.c:105
+#, c-format
+msgid "Test %s."
+msgstr ""
+msgid "succeeded"
+msgstr ""
+#: ../db/db.select/main.c:207
+msgid "Name of file containing SQL select statement(s)"
+msgstr ""
+#: ../db/db.select/main.c:212
+msgid "Name of table to query"
+msgstr ""
+#: ../db/db.select/main.c:231
+msgid "Vertical record separator (requires -v flag)"
+msgstr ""
+#: ../db/db.select/main.c:245 ../vector/v.db.select/main.c:105
+msgid "Do not include column names in output"
+msgstr ""
+#: ../db/db.select/main.c:250
+msgid "Describe query only (don't run it)"
+msgstr ""
+#: ../db/db.select/main.c:255 ../vector/v.db.select/main.c:110
+msgid "Vertical output (instead of horizontal)"
+msgstr ""
+#: ../db/db.select/main.c:260
+msgid "Only test query, do not execute"
+msgstr ""
+#: ../db/db.select/main.c:268
+msgid "Selects data from attribute table."
+msgstr ""
+#: ../db/db.select/main.c:269
+msgid "Performs SQL query statement(s)."
+msgstr ""
+#: ../db/db.select/main.c:304
+#, c-format
+msgid "You must provide one of these options: <%s>, <%s>, or <%s>"
+msgstr ""
+#: ../db/db.login/main.c:42
+msgid "Sets user/password for DB driver/database."
+msgstr ""
+#: ../db/db.login/main.c:59
+msgid "Username"
+msgstr ""
+#: ../db/db.login/main.c:67
+msgid "Password"
+msgstr ""
+#: ../db/db.login/main.c:75
+msgid "Hostname"
+msgstr ""
+#: ../db/db.login/main.c:76 ../db/db.login/main.c:85
+msgid "Relevant only for pg and mysql driver"
+msgstr ""
+#: ../db/db.login/main.c:84
+msgid "Port"
+msgstr ""
+#: ../db/db.login/main.c:90
+msgid "Print connection settings and exit"
+msgstr ""
+#: ../db/db.login/main.c:105
+msgid "Unable to set user/password"
+msgstr ""
+#: ../db/db.login/main.c:109
+#, c-format
+msgid "The password was stored in file (%s%cdblogin)"
+msgstr ""
+#: ../db/db.tables/main.c:54
+#, c-format
+msgid "Unable to list tables from database <%s>"
+msgstr ""
+#: ../db/db.tables/main.c:60
+msgid "No tables found"
+msgstr ""
+#: ../db/db.tables/main.c:89
+msgid "Print tables and exit"
+msgstr ""
+#: ../db/db.tables/main.c:93
+msgid "System tables instead of user tables"
+msgstr ""
+#: ../db/db.tables/main.c:99
+msgid "Lists all tables for a given database."
+msgstr ""
+#: ../db/db.dropdb/main.c:74
+msgid "Removes an existing database."
+msgstr ""
+#: ../db/db.createdb/main.c:74
+msgid "Creates an empty database."
+msgstr ""
+#: ../db/drivers/ogr/listtab.c:49 ../db/drivers/sqlite/listtab.c:78
+msgid "Unable to db_alloc_string_array()"
+msgstr ""
+#: ../db/drivers/ogr/execute.c:56 ../vector/v.out.ogr/main.c:648
+#, c-format
+msgid "OGR layer <%s> not found"
+msgstr ""
+#: ../db/drivers/ogr/execute.c:69 ../vector/v.out.lidar/main.c:118
+#: ../vector/v.out.lidar/main.c:155 ../vector/v.db.connect/main.c:289
+#: ../vector/v.reclass/main.c:145 ../vector/v.to.3d/trans2.c:63
+#: ../vector/v.to.3d/trans3.c:65 ../vector/v.univar/main.c:355
+#: ../vector/v.distance/main.c:533 ../vector/v.distance/main.c:574
+#: ../vector/v.in.db/main.c:187 ../vector/v.colors/scan_attr.c:35
+#: ../vector/v.colors.out/make_colors.c:42 ../vector/v.vect.stats/main.c:428
+#: ../vector/v.transform/trans_digit.c:116
+#: ../scripts/v.db.renamecolumn/v.db.renamecolumn.py:96
+#: ../scripts/v.db.join/v.db.join.py:98 ../scripts/v.db.join/v.db.join.py:106
+#: ../scripts/v.db.join/v.db.join.py:123 ../scripts/db.univar/db.univar.py:120
+#, c-format, python-format
+msgid "Column <%s> not found in table <%s>"
+msgstr ""
+#: ../db/drivers/ogr/db.c:56
+msgid "Had to open data source read-only"
+msgstr ""
+#: ../db/drivers/ogr/db.c:60
+msgid "Unable to open OGR data source"
+msgstr ""
+#: ../db/drivers/ogr/describe.c:55
+#, c-format
+msgid "OGR layer <%s> does not exist\n"
+msgstr ""
+#: ../db/drivers/ogr/describe.c:63 ../db/drivers/ogr/select.c:58
+msgid "Unable to describe table\n"
+msgstr ""
+#: ../db/drivers/ogr/describe.c:116
+#, c-format
+msgid "OGR driver: column '%s', OGR type %d is not supported"
+msgstr ""
+#: ../db/drivers/ogr/describe.c:186 ../db/drivers/postgres/describe.c:130
+#, c-format
+msgid "Column '%s' : type int8 (bigint) is stored as integer (4 bytes) some data may be damaged"
+msgstr ""
+#: ../db/drivers/ogr/describe.c:204
+#, c-format
+msgid "column '%s', type 'string': unknown width -> stored as varchar(250) some data may be lost"
+msgstr ""
+#: ../db/drivers/ogr/describe.c:212 ../db/drivers/ogr/fetch.c:160
+msgid "Unknown type"
+msgstr ""
+#: ../db/drivers/ogr/cursor.c:65 ../db/drivers/odbc/cursor.c:36
+msgid "Unable to allocate cursor"
+msgstr ""
+#: ../db/drivers/ogr/cursor.c:74
+msgid "Unable to add new token"
+msgstr ""
+#: ../db/drivers/ogr/fetch.c:55 ../db/drivers/ogr/fetch.c:188
+#: ../db/drivers/sqlite/fetch.c:265 ../db/drivers/postgres/fetch.c:33
+#: ../db/drivers/mysql/fetch.c:34 ../db/drivers/mysql/fetch.c:276
+msgid "Cursor not found"
+msgstr ""
+#: ../db/drivers/ogr/fetch.c:71
+msgid "DB_PREVIOUS not supported"
+msgstr ""
+#: ../db/drivers/ogr/fetch.c:82
+msgid "DB_LAST not supported"
+msgstr ""
+#: ../db/drivers/ogr/select.c:50
+msgid "Unable to select: \n"
+msgstr ""
+#: ../db/drivers/sqlite/listtab.c:50 ../db/drivers/sqlite/listtab.c:66
+msgid "Unable to list tables:"
+msgstr ""
+#: ../db/drivers/sqlite/table.c:37
+msgid "Error in sqlite3_exec():"
+msgstr ""
+#: ../db/drivers/sqlite/main.c:47
+#, c-format
+msgid "Busy SQLITE db, already waiting for %d seconds..."
+msgstr ""
+#: ../db/drivers/sqlite/execute.c:53 ../db/drivers/sqlite/describe.c:60
+#: ../db/drivers/sqlite/select.c:63
+msgid "Error in sqlite3_prepare():"
+msgstr ""
+#: ../db/drivers/sqlite/execute.c:69 ../db/drivers/sqlite/describe.c:78
+#: ../db/drivers/sqlite/describe.c:132 ../db/drivers/sqlite/create_table.c:141
+#: ../db/drivers/sqlite/select.c:80 ../db/drivers/sqlite/index.c:96
+msgid "Error in sqlite3_step():"
+msgstr ""
+#: ../db/drivers/sqlite/execute.c:83
+msgid "Error in sqlite3_finalize():"
+msgstr ""
+#: ../db/drivers/sqlite/execute.c:111
+msgid "'BEGIN' transaction failed:"
+msgstr ""
+#: ../db/drivers/sqlite/execute.c:139
+msgid "'COMMIT' transaction failed:"
+msgstr ""
+#: ../db/drivers/sqlite/db.c:99
+#, c-format
+msgid "Unable to create directory '%s' for sqlite database"
+msgstr ""
+#: ../db/drivers/sqlite/db.c:107
+msgid "Unable to open database:"
+msgstr ""
+#: ../db/drivers/sqlite/db.c:134
+msgid "SQLite database connection is still busy"
+msgstr ""
+#: ../db/drivers/sqlite/db.c:155
+#, c-format
+msgid "Database <%s> already exists"
+msgstr ""
+#: ../db/drivers/sqlite/db.c:162
+msgid "Unable to create database:"
+msgstr ""
+#: ../db/drivers/sqlite/db.c:186
+#, c-format
+msgid "Database <%s> not found"
+msgstr ""
+#: ../db/drivers/sqlite/listdb.c:45 ../db/drivers/postgres/listdb.c:35
+msgid "No path given"
+msgstr ""
+#: ../db/drivers/sqlite/listdb.c:99
+#, c-format
+msgid "Unable to open directory '%s'"
+msgstr ""
+#: ../db/drivers/sqlite/listdb.c:117
+#, c-format
+msgid "SQLite database connection '%s' is still busy"
+msgstr ""
+#: ../db/drivers/sqlite/listdb.c:147 ../db/drivers/postgres/listdb.c:96
+#: ../db/drivers/odbc/listdb.c:40
+msgid "Unable to set handle"
+msgstr ""
+#: ../db/drivers/sqlite/describe.c:92 ../db/drivers/sqlite/select.c:95
+#: ../db/drivers/mysql/describe.c:32
+msgid "Unable to describe table:"
+msgstr ""
+#: ../db/drivers/sqlite/describe.c:194
+#, c-format
+msgid "SQLite driver: column '%s', SQLite type %d is not supported"
+msgstr ""
+#: ../db/drivers/sqlite/cursor.c:47
+msgid "Unable to allocate cursor."
+msgstr ""
+#: ../db/drivers/sqlite/cursor.c:56 ../db/drivers/postgres/cursor.c:50
+#: ../db/drivers/odbc/cursor.c:55
+msgid "Unable to add new token."
+msgstr ""
+#: ../db/drivers/sqlite/create_table.c:122
+#: ../db/drivers/postgres/create_table.c:103
+#: ../db/drivers/mysql/create_table.c:108
+msgid "Unable to create table:"
+msgstr ""
+#: ../db/drivers/sqlite/fetch.c:72
+msgid "Unable to fetch:"
+msgstr ""
+#: ../db/drivers/sqlite/fetch.c:87
+msgid "DB_PREVIOUS is not supported"
+msgstr ""
+#: ../db/drivers/sqlite/fetch.c:93
+msgid "DB_LAST is not supported"
+msgstr ""
+#: ../db/drivers/sqlite/fetch.c:171 ../db/drivers/postgres/fetch.c:129
+msgid "Unable to scan date:"
+msgstr ""
+#: ../db/drivers/sqlite/fetch.c:188 ../db/drivers/postgres/fetch.c:147
+msgid "Unable to scan time:"
+msgstr ""
+#: ../db/drivers/sqlite/fetch.c:203
+msgid "Unable to scan timestamp:"
+msgstr ""
+#: ../db/drivers/sqlite/fetch.c:218
+msgid "SQLite driver: parsing of interval values not implemented; assuming seconds"
+msgstr ""
+#: ../db/drivers/sqlite/fetch.c:223
+msgid "Unable to scan interval:"
+msgstr ""
+#: ../db/drivers/sqlite/fetch.c:286
+msgid "Unable to get number of rows:"
+msgstr ""
+#: ../db/drivers/sqlite/index.c:77 ../db/drivers/mysql/index.c:55
+msgid "Unable to create index:"
+msgstr ""
+#: ../db/drivers/postgres/listtab.c:38
+msgid "Unable to select table names."
+msgstr ""
+#: ../db/drivers/postgres/listtab.c:65
+msgid "Unable to select view names."
+msgstr ""
+#: ../db/drivers/postgres/table.c:37
+msgid "Unable to execute():"
+msgstr ""
+#: ../db/drivers/postgres/execute.c:42 ../db/drivers/mysql/execute.c:41
+msgid "Unable to execute:"
+msgstr ""
+#: ../db/drivers/postgres/execute.c:68
+msgid "Unable to 'BEGIN' transaction"
+msgstr ""
+#: ../db/drivers/postgres/execute.c:88
+msgid "Unable to 'COMMIT' transaction"
+msgstr ""
+#: ../db/drivers/postgres/db.c:71 ../db/drivers/postgres/db.c:250
+#: ../db/drivers/mysql/db.c:61
+msgid "Connection failed."
+msgstr ""
+#: ../db/drivers/postgres/db.c:99
+msgid "Unable to set schema:"
+msgstr ""
+#: ../db/drivers/postgres/db.c:117
+msgid "Unable to select data types"
+msgstr ""
+#: ../db/drivers/postgres/db.c:269
+#, c-format
+msgid "Unable to create database <%s>"
+msgstr ""
+#: ../db/drivers/postgres/db.c:271
+#, c-format
+msgid "Unable to drop database <%s>"
+msgstr ""
+#: ../db/drivers/postgres/priv.c:53
+msgid "Unable grant on table:"
+msgstr ""
+#: ../db/drivers/postgres/listdb.c:65
+msgid "Unable to connect to Postgres:"
+msgstr ""
+#: ../db/drivers/postgres/listdb.c:76
+msgid "Unable to select from Postgres:"
+msgstr ""
+#: ../db/drivers/postgres/describe.c:40 ../db/drivers/mysql/select.c:64
+msgid "Unable to describe table."
+msgstr ""
+#: ../db/drivers/postgres/describe.c:123
+#, c-format
+msgid "PostgreSQL driver: column '%s', type %d is not supported"
+msgstr ""
+#: ../db/drivers/postgres/describe.c:134
+#, c-format
+msgid "Column '%s' : type character varying is stored as varchar(250) some data may be lost"
+msgstr ""
+#: ../db/drivers/postgres/describe.c:140
+#, c-format
+msgid "column '%s' : type bool (boolean) is stored as char(1), values: 0 (false), 1 (true)"
+msgstr ""
+#: ../db/drivers/postgres/cursor.c:41 ../db/drivers/mysql/cursor.c:44
+msgid "Unable allocate cursor."
+msgstr ""
+#: ../db/drivers/postgres/create_table.c:90
+#, c-format
+msgid "Unknown column type (%s)"
+msgstr ""
+#: ../db/drivers/postgres/create_table.c:132
+msgid "Unable to grant select on table:"
+msgstr ""
+#: ../db/drivers/postgres/parse.c:60 ../db/drivers/mysql/parse.c:73
+msgid "'user' in database definition is not supported, use db.login"
+msgstr ""
+#: ../db/drivers/postgres/parse.c:64 ../db/drivers/mysql/parse.c:77
+msgid "'password' in database definition is not supported, use db.login"
+msgstr ""
+#: ../db/drivers/postgres/parse.c:69
+msgid "Unknown option in database definition for PostgreSQL: "
+msgstr ""
+#: ../db/drivers/postgres/fetch.c:166
+msgid "Unable to scan timestamp (no idea how to process time zone):"
+msgstr ""
+#: ../db/drivers/postgres/fetch.c:174
+msgid "Unable to scan timestamp (not enough arguments):"
+msgstr ""
+#: ../db/drivers/postgres/fetch.c:188
+msgid "Unable to recognize boolean value"
+msgstr ""
+#: ../db/drivers/postgres/fetch.c:206
+msgid "Taken not found"
+msgstr ""
+#: ../db/drivers/postgres/select.c:31
+msgid "Unable set DATESTYLE"
+msgstr ""
+#: ../db/drivers/postgres/select.c:55
+msgid "Unable to select:"
+msgstr ""
+#: ../db/drivers/postgres/select.c:69 ../db/drivers/mysql/describe.c:50
+msgid "Unable to describe table"
+msgstr ""
+#: ../db/drivers/odbc/table.c:159
+#, c-format
+msgid "Table %s doesn't exist"
+msgstr ""
+#: ../db/drivers/odbc/table.c:176
+#, c-format
+msgid "Table %s isn't 'TABLE' or 'VIEW' but %s"
+msgstr ""
+#: ../db/drivers/odbc/listdb.c:29
+msgid "Unable to allocate handle."
+msgstr ""
+#: ../db/drivers/mysql/listtab.c:37
+msgid "Unable get list of tables:"
+msgstr ""
+#: ../db/drivers/mysql/execute.c:62
+msgid "Unable to start transaction:"
+msgstr ""
+#: ../db/drivers/mysql/execute.c:77
+msgid "Unable to commit transaction:"
+msgstr ""
+#: ../db/drivers/mysql/dbe.c:45
+msgid "Unable parse MySQL embedded database name"
+msgstr ""
+#: ../db/drivers/mysql/dbe.c:61
+msgid "Cannot initialize MySQL embedded server"
+msgstr ""
+#: ../db/drivers/mysql/dbe.c:80
+msgid "Unable to connect to MySQL embedded server: "
+msgstr ""
+#: ../db/drivers/mysql/describe.c:121
+#, c-format
+msgid "MySQL driver: column '%s', type %d is not supported"
+msgstr ""
+#: ../db/drivers/mysql/describe.c:127
+#, c-format
+msgid "column '%s' : type BIGINT is stored as integer (4 bytes) some data may be damaged"
+msgstr ""
+#: ../db/drivers/mysql/cursor.c:53
+msgid "Unable to add dnew token."
+msgstr ""
+#: ../db/drivers/mysql/parse.c:62
+msgid "Wrong port number in MySQL database definition: "
+msgstr ""
+#: ../db/drivers/mysql/parse.c:82
+msgid "Unknown option in database definition for MySQL: "
+msgstr ""
+#: ../db/drivers/mysql/fetch.c:52
+msgid "Cursor position is not supported by MySQL driver"
+msgstr ""
+#: ../db/drivers/mysql/fetch.c:191
+msgid "Unable to scan timestamp: "
+msgstr ""
+#: ../db/drivers/mysql/fetch.c:200
+msgid "Unknown timestamp format: "
+msgstr ""
+#: ../db/drivers/mysql/fetch.c:215
+msgid "Unable to scan date: "
+msgstr ""
+#: ../db/drivers/mysql/fetch.c:229
+msgid "Unable to scan time: "
+msgstr ""
+#: ../db/drivers/mysql/fetch.c:245
+msgid "Unable to scan datetime:"
+msgstr ""
+#: ../db/drivers/mysql/select.c:42
+msgid "Unable to select data:"
+msgstr ""
+#: ../db/drivers/dbf/dbfexe.c:72
+msgid "SQL parser error"
+msgstr ""
+#: ../db/drivers/dbf/dbfexe.c:74
+msgid "in statement:"
+msgstr ""
+#: ../db/drivers/dbf/dbfexe.c:88
+#, c-format
+msgid "Table '%s' doesn't exist."
+msgstr ""
+#: ../db/drivers/dbf/dbfexe.c:96
+msgid "Unable to load table head."
+msgstr ""
+#: ../db/drivers/dbf/dbfexe.c:106
+msgid "Unable to modify table, don't have write permission for DBF file."
+msgstr ""
+#: ../db/drivers/dbf/dbfexe.c:121 ../db/drivers/dbf/dbfexe.c:1023
+#, c-format
+msgid "Column '%s' not found"
+msgstr ""
+#: ../db/drivers/dbf/dbfexe.c:145
+msgid "Incompatible value type."
+msgstr ""
+#: ../db/drivers/dbf/dbfexe.c:161
+msgid "Unable to add column."
+msgstr ""
+#: ../db/drivers/dbf/dbfexe.c:183
+msgid "Unable to delete column."
+msgstr ""
+#: ../db/drivers/dbf/dbfexe.c:191
+#, c-format
+msgid "Table %s already exists"
+msgstr ""
+#: ../db/drivers/dbf/dbfexe.c:206
+msgid "Unable to create table."
+msgstr ""
+#: ../db/drivers/dbf/dbfexe.c:263 ../db/drivers/dbf/dbfexe.c:273
+#: ../db/drivers/dbf/dbfexe.c:303
+msgid "Error in selecting rows"
+msgstr ""
+#: ../db/drivers/dbf/dbfexe.c:552
+msgid "Cannot load table."
+msgstr ""
+#: ../db/drivers/dbf/dbfexe.c:567
+msgid "Incompatible types in WHERE condition."
+msgstr ""
+#: ../db/drivers/dbf/dbfexe.c:572
+msgid "Result of WHERE condition is not of type BOOL."
+msgstr ""
+#: ../db/drivers/dbf/dbfexe.c:588
+msgid "Error in evaluation of WHERE condition."
+msgstr ""
+#: ../db/drivers/dbf/dbfexe.c:600
+#, c-format
+msgid "Unknown result (%d) of WHERE evaluation"
+msgstr ""
+#: ../db/drivers/dbf/dbfexe.c:607
+msgid "Unknown WHERE condition type (bug in DBF driver)."
+msgstr ""
+#: ../db/drivers/dbf/dbfexe.c:633
+#, c-format
+msgid "Unable to find order column '%s'"
+msgstr ""
+#: ../db/drivers/dbf/dbfexe.c:778
+msgid "Division by zero"
+msgstr ""
+#: ../db/drivers/dbf/dbfexe.c:917
+msgid "Value operand for AND"
+msgstr ""
+#: ../db/drivers/dbf/dbfexe.c:931
+msgid "Value operand for OR"
+msgstr ""
+#: ../db/drivers/dbf/dbfexe.c:946
+msgid "Value operand for NOT"
+msgstr ""
+#: ../db/drivers/dbf/dbfexe.c:954 ../db/drivers/dbf/dbfexe.c:1151
+#, c-format
+msgid "Unknown operator %d"
+msgstr ""
+#: ../db/drivers/dbf/dbfexe.c:1061
+msgid "Arithmetical operation with strings is not allowed"
+msgstr ""
+#: ../db/drivers/dbf/dbfexe.c:1083
+msgid "Comparison between string and number is not allowed"
+msgstr ""
+#: ../db/drivers/dbf/dbfexe.c:1098
+#, c-format
+msgid "Comparison '%s' between strings not allowed"
+msgstr ""
+#: ../db/drivers/dbf/dbfexe.c:1112
+msgid "Match (~) between numbers not allowed"
+msgstr ""
+#: ../db/drivers/dbf/table.c:117 ../db/drivers/dbf/table.c:170
+msgid "Unable to open DBF file."
+msgstr ""
+#: ../db/drivers/dbf/table.c:312
+#, c-format
+msgid "Unable to move '%s' to '%s'."
+msgstr ""
+#: ../db/drivers/dbf/execute.c:32
+msgid "Unable to execute statement."
+msgstr ""
+#: ../db/drivers/dbf/db.c:94
+#, c-format
+msgid "Unable create DBF database: %s"
+msgstr ""
+#: ../db/drivers/dbf/db.c:102
+#, c-format
+msgid "Cannot open DBF database directory: %s"
+msgstr ""
+#: ../db/drivers/dbf/db.c:110
+#, c-format
+msgid "Unable to open DBF database: %s"
+msgstr ""
+#: ../db/drivers/dbf/describe.c:34
+#, c-format
+msgid "Table '%s' doesn't exist"
+msgstr ""
+#: ../db/drivers/dbf/cursor.c:47
+msgid "Unable to allocate new cursor"
+msgstr ""
+#: ../db/drivers/dbf/cursor.c:59
+msgid "Unable to tokenize new cursor"
+msgstr ""
+#: ../db/drivers/dbf/create_table.c:22
+msgid "Unable to create table"
+msgstr ""
+#: ../db/drivers/dbf/column.c:49
+#, c-format
+msgid "Column '%s' already exists (duplicate name)"
+msgstr ""
+#: ../db/drivers/dbf/column.c:99
+#, c-format
+msgid "Column '%s' does not exist"
+msgstr ""
+#: ../db/drivers/dbf/select.c:44
+msgid "Unable to open cursor."
+msgstr ""
+#: ../vector/v.out.vtk/main.c:51
+msgid "Converts a vector map to VTK ASCII output."
+msgstr ""
+#: ../vector/v.out.vtk/main.c:59
+msgid "Name for output VTK file"
+msgstr ""
+#: ../vector/v.out.vtk/main.c:89
+msgid "Export numeric attribute table fields as VTK scalar variables"
+msgstr ""
+#: ../vector/v.out.vtk/main.c:153 ../vector/v.out.ascii/args.c:109
+msgid "Failed to interpret 'dp' parameter as an integer"
+msgstr ""
+#: ../vector/v.out.vtk/main.c:155
+msgid "dp has to be from 0 to 8"
+msgstr ""
+#: ../vector/v.out.vtk/main.c:164
+msgid "Failed to interpret 'layer' parameter as an integer"
+msgstr ""
+#: ../vector/v.out.vtk/main.c:183
+#, c-format
+msgid "Export of areas requires topology. Please adjust '%s' option or rebuild topology."
+msgstr ""
+#: ../vector/v.out.vtk/writeVTK.c:196
+msgid "No coordinates to generate the output! Maybe an empty vector type chosen?"
+msgstr ""
+#: ../vector/v.out.vtk/writeVTK.c:585 ../vector/v.out.ogr/attrb.c:48
+#, c-format
+msgid "Cannot select attributes for cat = %d"
+msgstr ""
+#: ../vector/v.out.vtk/writeVTK.c:589 ../vector/v.out.ogr/attrb.c:53
+#: ../vector/v.out.svg/main.c:400 ../vector/v.overlay/main.c:487
+#: ../vector/v.lrs/v.lrs.label/main.c:331
+msgid "Unable to fetch data from table"
+msgstr ""
+#: ../vector/v.out.vtk/writeVTK.c:632
+msgid "Cannot export attribute table fields for layer < 1. Skipping export"
+msgstr ""
+#: ../vector/v.out.vtk/writeVTK.c:640
+msgid "No attribute table found"
+msgstr ""
+#: ../vector/v.out.vtk/writeVTK.c:673
+msgid "No numerical attributes found. Skipping export"
+msgstr ""
+#: ../vector/v.out.vtk/writeVTK.c:732 ../vector/v.out.vtk/writeVTK.c:763
+#: ../vector/v.out.vtk/writeVTK.c:794 ../vector/v.out.vtk/writeVTK.c:823
+#, c-format
+msgid "Error reading value of attribute '%s'"
+msgstr ""
+#: ../vector/v.out.vtk/head.c:27
+msgid "writeVTKHeader: Writing VTK-Header"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:73 ../vector/v.kcv/main.c:58
+#: ../vector/v.random/main.c:101 ../vector/v.perturb/main.c:66
+#: ../vector/v.normal/main.c:75 ../vector/v.qcount/main.c:62
+msgid "point pattern"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:74
+msgid "hexagon"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:75
+msgid "Creates a vector map of a user-defined grid."
+msgstr ""
+#: ../vector/v.mkgrid/main.c:82
+msgid "rows,columns"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:86
+msgid "Number of rows and columns in grid"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:95
+msgid "Where to place the grid"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:99
+msgid "current region"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:100
+msgid "use 'coor' and 'box' options"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:105
+msgid "Lower left easting and northing coordinates of map"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:109
+msgid "width,height"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:113
+msgid "Width and height of boxes in grid"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:120
+msgid "Angle of rotation (in degrees counter-clockwise)"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:128
+msgid "Number of vertex points per grid cell"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:141
+msgid "Create hexagons (default: rectangles)"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:146
+msgid "Allow asymmetric hexagons"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:186
+msgid "'coor' and 'position=region' are exclusive options"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:189
+msgid "'box' and 'grid' are exclusive options for 'position=region'"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:212 ../vector/v.mkgrid/main.c:248
+msgid "Invalid width"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:215 ../vector/v.mkgrid/main.c:251
+msgid "Invalid height"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:231
+msgid "'grid' option missing"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:234
+msgid "'coor' option missing"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:237
+msgid "'box' option missing"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:241
+msgid "Invalid easting"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:244
+msgid "Invalid northing"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:309
+msgid "The hexagons will be asymmetrical."
+msgstr ""
+#: ../vector/v.mkgrid/main.c:322 ../vector/v.mkgrid/main.c:325
+msgid "Please use a higher resolution or a larger region"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:329
+#, c-format
+msgid "The number of rows has been adjusted from %d to %d"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:332
+#, c-format
+msgid "The number of columns has been adjusted from %d to %d"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:361 ../vector/v.mkgrid/main.c:446
+#: ../vector/v.mkgrid/main.c:458
+msgid "Unable to fill attribute table"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:365 ../vector/v.mkgrid/main.c:463
+#: ../vector/v.in.ascii/points.c:452 ../vector/v.in.dxf/write_vect.c:70
+#, c-format
+msgid "Unable to insert new record: %s"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:372
+msgid "The rectangles will be asymmetrical."
+msgstr ""
+#: ../vector/v.mkgrid/main.c:417
+msgid "Creating centroids..."
+msgstr ""
+#: ../vector/v.mkgrid/write_grid.c:68
+msgid "Writing out vector rows..."
+msgstr ""
+#: ../vector/v.mkgrid/write_grid.c:107
+msgid "Writing out vector columns..."
+msgstr ""
+#: ../vector/v.mkgrid/hexgrid.c:86
+msgid "Writing out hexagon grid..."
+msgstr ""
+#: ../vector/v.external.out/main.c:49
+msgid "Defines vector output format."
+msgstr ""
+#: ../vector/v.external.out/main.c:63
+msgid "Switched from OGR to native format"
+msgstr ""
+#: ../vector/v.external.out/main.c:67
+msgid "Switched from PostGIS to native format"
+msgstr ""
+#: ../vector/v.external.out/main.c:69 ../vector/v.external.out/main.c:96
+#, c-format
+msgid "Current output format for vectors: %s"
+msgstr ""
+#: ../vector/v.external.out/args.c:14
+msgid "Name of output directory or OGR or PostGIS data source"
+msgstr ""
+#: ../vector/v.external.out/args.c:15 ../vector/v.external/args.c:15
+msgid ""
+"Examples:\n"
+"\t\tESRI Shapefile: directory containing a shapefile\n"
+"\t\tMapInfo File: directory containing a mapinfo file\n"
+"\t\tPostGIS database: connection string, eg. 'PG:dbname=db user=grass'"
+msgstr ""
+#: ../vector/v.external.out/args.c:24
+msgid "Format for output vector data"
+msgstr ""
+#: ../vector/v.external.out/args.c:40
+msgid ""
+"Examples:\n"
+"\t\t'SHPT=POINTZ': create 3D point Shapefile data\n"
+"\t\t'GEOM_TYPE=geography': use geography PostGIS data\n"
+"\t\t'SCHEMA=grass': create new PostGIS tables in 'grass' schema"
+msgstr ""
+#: ../vector/v.external.out/args.c:52
+msgid "Name of input file to read settings from"
+msgstr ""
+#: ../vector/v.external.out/args.c:58
+msgid "Name for output file where to save current settings"
+msgstr ""
+#: ../vector/v.external.out/args.c:68
+msgid "Cease using OGR/PostGIS, revert to native output and exit"
+msgstr ""
+#: ../vector/v.external.out/args.c:70
+msgid "Native"
+msgstr ""
+#: ../vector/v.external.out/args.c:80
+msgid "Print current status in shell script style"
+msgstr ""
+#: ../vector/v.external.out/args.c:98
+#, c-format
+msgid "%s= or %s= must be specified"
+msgstr ""
+#: ../vector/v.external.out/args.c:101
+#, c-format
+msgid "%s= must be specified"
+msgstr ""
+#: ../vector/v.external.out/format.c:22 ../vector/v.external/main.c:78
+msgid "Environment variable GRASS_VECTOR_OGR defined, but GRASS is compiled with OGR support. Using GRASS-PostGIS data driver instead."
+msgstr ""
+#: ../vector/v.external.out/format.c:27 ../vector/v.external/main.c:83
+msgid "GRASS is not compiled with PostgreSQL support. Using OGR-PostgreSQL driver instead of native GRASS-PostGIS data driver."
+msgstr ""
+#: ../vector/v.external.out/link.c:26 ../vector/v.out.ogr/main.c:103
+#, c-format
+msgid "Data source starts with \"PG:\" prefix, expecting \"PostgreSQL\" format (\"%s\" given)"
+msgstr ""
+#: ../vector/v.external.out/link.c:88 ../vector/v.external.out/status.c:158
+msgid "Unable to create settings file"
+msgstr ""
+#: ../vector/v.external.out/link.c:91 ../vector/v.external.out/status.c:160
+msgid "Error writing settings file"
+msgstr ""
+#: ../vector/v.external.out/link.c:96
+#, c-format
+msgid "Switched to OGR format (%s)"
+msgstr ""
+#: ../vector/v.external.out/link.c:99
+msgid "Switched to PostGIS format"
+msgstr ""
+#: ../vector/v.external.out/link.c:110
+#, c-format
+msgid "Unable to parse option '%s'"
+msgstr ""
+#: ../vector/v.external.out/status.c:25
+#, c-format
+msgid "format: native\n"
+msgstr ""
+#: ../vector/v.external.out/status.c:80
+msgid "No settings defined"
+msgstr ""
+#: ../vector/v.external.out/status.c:109 ../vector/v.external.out/status.c:149
+msgid "Format not defined"
+msgstr ""
+#: ../vector/v.external.out/status.c:116
+msgid "OGR datasource (dsn) not defined"
+msgstr ""
+#: ../vector/v.external.out/status.c:124
+msgid "PG connection info (conninfo) not defined"
+msgstr ""
+#: ../vector/v.what.rast3/main.c:70 ../vector/v.drape/main.c:60
+#: ../vector/v.what.rast/main.c:77
+msgid "surface information"
+msgstr ""
+#: ../vector/v.what.rast3/main.c:72
+msgid "Uploads 3D raster values at positions of vector points to the table."
+msgstr ""
+#: ../vector/v.what.rast3/main.c:82
+msgid "Name of existing 3D raster map to be queried"
+msgstr ""
+#: ../vector/v.what.rast3/main.c:135
+#, c-format
+msgid "Error opening 3D raster map <%s>"
+msgstr ""
+#: ../vector/v.what.rast3/main.c:141 ../vector/v.to.rast/support.c:308
+#: ../vector/v.to.rast/support.c:547 ../vector/v.to.rast/vect2rast.c:69
+#: ../scripts/v.dissolve/v.dissolve.py:85
+#: ../scripts/v.db.update/v.db.update.py:98
+msgid "Column <%s> not found"
+msgstr ""
+#: ../vector/v.what.rast3/main.c:144
+msgid "Column type not supported, please use a column with double type"
+msgstr ""
+#: ../vector/v.what.rast3/main.c:158 ../vector/v.what.rast/main.c:206
+msgid "Reading features from vector map..."
+msgstr ""
+#: ../vector/v.what.rast3/main.c:215
+#, c-format
+msgid "%d point outside current region was skipped"
+msgid_plural "%d points outside current region were skipped"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.what.rast3/main.c:220
+#, c-format
+msgid "%d point without category was skipped"
+msgid_plural "%d points without category were skipped"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.what.rast3/main.c:259
+#, c-format
+msgid "More points (%d) of category %d, value set to 'NULL'"
+msgstr ""
+#: ../vector/v.what.rast3/main.c:272 ../vector/v.label.sa/labels.c:166
+#: ../vector/v.buffer/main.c:540 ../vector/v.buffer/main.c:642
+#: ../vector/v.what.rast/main.c:623 ../vector/v.sample/main.c:226
+#: ../vector/v.sample/main.c:234 ../vector/v.vol.rst/user1.c:172
+#: ../vector/v.label/main.c:325
+#, c-format
+msgid "No record for category %d in table <%s>"
+msgstr ""
+#: ../vector/v.what.rast3/main.c:329
+#, c-format
+msgid "%d category loaded from table"
+msgid_plural "%d categories loaded from table"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.what.rast3/main.c:332
+#, c-format
+msgid "%d category loaded from vector"
+msgid_plural "%d categories loaded from vector"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.what.rast3/main.c:335
+#, c-format
+msgid "%d category from vector missing in table"
+msgid_plural "%d categories from vector missing in table"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.what.rast3/main.c:339
+#, c-format
+msgid "%d duplicate category in vector"
+msgid_plural "%d duplicate categories in vector"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.what.rast3/main.c:343
+#, c-format
+msgid "%d update error"
+msgid_plural "%d update errors"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.what.rast3/main.c:347
+#, c-format
+msgid "%d record updated."
+msgid_plural "%d records updated."
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.to.rast/main.c:47
+msgid "rasterization"
+msgstr ""
+#: ../vector/v.to.rast/main.c:48
+msgid "Converts (rasterize) a vector map into a raster map."
+msgstr ""
+#: ../vector/v.to.rast/main.c:73
+msgid "Source of raster values"
+msgstr ""
+#: ../vector/v.to.rast/main.c:77
+msgid "read values from attribute table"
+msgstr ""
+#: ../vector/v.to.rast/main.c:78 ../vector/v.colors/main.c:74
+msgid "use category values"
+msgstr ""
+#: ../vector/v.to.rast/main.c:79
+msgid "use value specified by value option"
+msgstr ""
+#: ../vector/v.to.rast/main.c:80
+msgid "use z coordinate (points or contours only)"
+msgstr ""
+#: ../vector/v.to.rast/main.c:81
+msgid "line direction in degrees CCW from east (lines only)"
+msgstr ""
+#: ../vector/v.to.rast/main.c:87
+msgid "Name of column for 'attr' parameter (data type must be numeric)"
+msgstr ""
+#: ../vector/v.to.rast/main.c:93
+msgid "Name of color definition column (with RRR:GGG:BBB entries)"
+msgstr ""
+#: ../vector/v.to.rast/main.c:99
+msgid "Name of column used as raster category labels"
+msgstr ""
+#: ../vector/v.to.rast/main.c:108
+msgid "Raster value (for use=val)"
+msgstr ""
+#: ../vector/v.to.rast/main.c:132
+#, c-format
+msgid "Cache size must be at least 1 MiB, changing %d to 1"
+msgstr ""
+#: ../vector/v.to.rast/main.c:141
+msgid "Column parameter missing (or use value parameter)"
+msgstr ""
+#: ../vector/v.to.rast/main.c:146
+msgid "Column parameter cannot be combined with use of category values option"
+msgstr ""
+#: ../vector/v.to.rast/main.c:151
+msgid "Column parameter cannot be combined with use of value option"
+msgstr ""
+#: ../vector/v.to.rast/main.c:156
+msgid "Column parameter cannot be combined with use of z coordinate"
+msgstr ""
+#: ../vector/v.to.rast/main.c:162
+#, c-format
+msgid "Unknown option '%s'"
+msgstr ""
+#: ../vector/v.to.rast/do_lines.c:36 ../vector/v.colors/scan_z.c:31
+#: ../vector/v.colors/scan_cats.c:19 ../vector/v.voronoi/main.c:208
+#: ../vector/v.colors.out/scan_cats.c:28 ../vector/v.to.db/lines.c:75
+#: ../vector/v.to.db/query.c:23
+msgid "Reading features..."
+msgstr ""
+#: ../vector/v.to.rast/do_lines.c:59 ../vector/v.to.rast/do_lines.c:67
+#: ../vector/v.to.rast3/main.c:145
+#, c-format
+msgid "No record for line (cat = %d)"
+msgstr ""
+#: ../vector/v.to.rast/do_lines.c:73 ../vector/v.to.rast/do_areas.c:64
+msgid "Unable to use column specified"
+msgstr ""
+#: ../vector/v.to.rast/do_lines.c:133
+#, c-format
+msgid "%d lines with varying height were not written to raster"
+msgstr ""
+#: ../vector/v.to.rast/support.c:119 ../vector/v.to.rast/support.c:291
+#: ../vector/v.to.rast/support.c:530
+#, c-format
+msgid "Unknown column <%s> in table <%s>"
+msgstr ""
+#: ../vector/v.to.rast/support.c:123 ../vector/v.to.rast/support.c:295
+#: ../vector/v.to.rast/support.c:534 ../vector/v.to.rast/vect2rast.c:78
+#: ../vector/v.reclass/main.c:241
+#, c-format
+msgid "No records selected from table <%s>"
+msgstr ""
+#: ../vector/v.to.rast/support.c:140 ../vector/v.to.rast/support.c:320
+msgid "No records selected"
+msgstr ""
+#: ../vector/v.to.rast/support.c:153
+#, c-format
+msgid "Error in color definition column (%s) with cat %d: colorstring [%s]"
+msgstr ""
+#: ../vector/v.to.rast/support.c:156
+msgid "Color set to [200:200:200]"
+msgstr ""
+#: ../vector/v.to.rast/support.c:161
+#, c-format
+msgid "Error in color definition column (%s), with cat %d"
+msgstr ""
+#: ../vector/v.to.rast/support.c:263
+msgid "Label column was not specified, no labels will be written"
+msgstr ""
+#: ../vector/v.to.rast/support.c:343 ../vector/v.to.rast/support.c:576
+#, c-format
+msgid "Column type (%s) not supported"
+msgstr ""
+#: ../vector/v.to.rast/support.c:392 ../vector/v.to.rast/support.c:433
+msgid "Different labels for the same value are not supported"
+msgstr ""
+#: ../vector/v.to.rast/support.c:652 ../vector/v.to.rast/vect2rast.c:122
+#, c-format
+msgid "Unknown use type: %d"
+msgstr ""
+#: ../vector/v.to.rast/vect2rast.c:36
+msgid "Loading data..."
+msgstr ""
+#: ../vector/v.to.rast/vect2rast.c:55 ../vector/v.db.connect/main.c:213
+#: ../vector/v.to.rast3/main.c:80 ../vector/v.db.select/main.c:171
+#: ../vector/v.to.3d/trans2.c:49 ../vector/v.to.3d/trans3.c:51
+#: ../vector/v.distance/main.c:515 ../vector/v.distance/main.c:596
+#: ../vector/v.colors.out/make_colors.c:31 ../vector/v.info/print.c:138
+#: ../vector/v.extract/main.c:255
+#, c-format
+msgid "Database connection not defined for layer <%s>"
+msgstr ""
+#: ../vector/v.to.rast/vect2rast.c:74
+#, c-format
+msgid "Column type (%s) not supported (did you mean 'labelcolumn'?)"
+msgstr ""
+#: ../vector/v.to.rast/vect2rast.c:104
+#, c-format
+msgid "Unable to use column <%s>"
+msgstr ""
+#: ../vector/v.to.rast/vect2rast.c:131
+#, c-format
+msgid "No areas selected from vector map <%s>"
+msgstr ""
+#: ../vector/v.to.rast/vect2rast.c:137
+msgid "Area conversion and line densification are mutually exclusive, disabling line densification."
+msgstr ""
+#: ../vector/v.to.rast/vect2rast.c:152
+#, c-format
+msgid "Pass %d of %d:"
+msgstr ""
+#: ../vector/v.to.rast/vect2rast.c:160
+#, c-format
+msgid "Problem processing areas from vector map <%s>, continuing..."
+msgstr ""
+#: ../vector/v.to.rast/vect2rast.c:172
+#, c-format
+msgid "Problem processing lines from vector map <%s>, continuing..."
+msgstr ""
+#: ../vector/v.to.rast/vect2rast.c:197
+msgid "Creating support files for raster map..."
+msgstr ""
+#: ../vector/v.to.rast/vect2rast.c:204
+msgid "Color can be updated from database only if use=attr"
+msgstr ""
+#: ../vector/v.to.rast/vect2rast.c:224
+#, c-format
+msgid "Converted areas: %d of %d"
+msgstr ""
+#: ../vector/v.to.rast/vect2rast.c:231
+#, c-format
+msgid "Converted points/lines: %d of %d"
+msgstr ""
+#: ../vector/v.to.rast/do_areas.c:34 ../vector/v.to.db/areas.c:28
+msgid "Reading areas..."
+msgstr ""
+#: ../vector/v.to.rast/do_areas.c:50 ../vector/v.to.rast/do_areas.c:58
+#, c-format
+msgid "No record for area (cat = %d)"
+msgstr ""
+#: ../vector/v.to.rast/do_areas.c:79
+#, c-format
+msgid "Get area %d failed"
+msgstr ""
+#: ../vector/v.to.rast/do_areas.c:84
+msgid "Failed to plot polygon"
+msgstr ""
+#: ../vector/v.to.rast/do_areas.c:118
+msgid "Area without centroid (OK for island)"
+msgstr ""
+#: ../vector/v.to.rast/do_areas.c:128
+msgid "Area centroid without category"
+msgstr ""
+#: ../vector/v.lidar.edgedetection/main.c:79
+msgid "Detects the object's edges from a LIDAR data set."
+msgstr ""
+#: ../vector/v.lidar.edgedetection/main.c:83
+#: ../vector/v.lidar.correction/main.c:78
+msgid "Estimate point density and distance and quit"
+msgstr ""
+#: ../vector/v.lidar.edgedetection/main.c:85
+#: ../vector/v.lidar.correction/main.c:80 ../vector/v.surf.bspline/main.c:107
+msgid "Estimate point density and distance in map units for the input vector points within the current region extents and quit"
+msgstr ""
+#: ../vector/v.lidar.edgedetection/main.c:97
+#: ../vector/v.lidar.correction/main.c:100 ../vector/v.surf.bspline/main.c:148
+#: ../vector/v.outlier/main.c:102
+msgid "Length of each spline step in the east-west direction"
+msgstr ""
+#: ../vector/v.lidar.edgedetection/main.c:98
+#: ../vector/v.surf.bspline/main.c:149
+msgid "Default: 4 * east-west resolution"
+msgstr ""
+#: ../vector/v.lidar.edgedetection/main.c:106
+#: ../vector/v.lidar.correction/main.c:109 ../vector/v.surf.bspline/main.c:157
+#: ../vector/v.outlier/main.c:111
+msgid "Length of each spline step in the north-south direction"
+msgstr ""
+#: ../vector/v.lidar.edgedetection/main.c:107
+#: ../vector/v.surf.bspline/main.c:158
+msgid "Default: 4 * north-south resolution"
+msgstr ""
+#: ../vector/v.lidar.edgedetection/main.c:115
+msgid "Regularization weight in gradient evaluation"
+msgstr ""
+#: ../vector/v.lidar.edgedetection/main.c:124
+msgid "High gradient threshold for edge classification"
+msgstr ""
+#: ../vector/v.lidar.edgedetection/main.c:133
+msgid "Low gradient threshold for edge classification"
+msgstr ""
+#: ../vector/v.lidar.edgedetection/main.c:141
+msgid "Angle range for same direction detection"
+msgstr ""
+#: ../vector/v.lidar.edgedetection/main.c:150
+msgid "Regularization weight in residual evaluation"
+msgstr ""
+#: ../vector/v.lidar.edgedetection/main.c:190
+#: ../vector/v.lidar.correction/main.c:165 ../vector/v.outlier/main.c:210
+#, c-format
+msgid "Input vector map <%s> is not 3D!"
+msgstr ""
+#: ../vector/v.lidar.edgedetection/main.c:196
+#: ../vector/v.lidar.correction/main.c:171
+#, c-format
+msgid "Estimated point density: %.4g\n"
+msgstr ""
+#: ../vector/v.lidar.edgedetection/main.c:197
+#: ../vector/v.lidar.correction/main.c:172
+#, c-format
+msgid "Estimated mean distance between points: %.4g\n"
+msgstr ""
+#: ../vector/v.lidar.edgedetection/main.c:200
+#: ../vector/v.lidar.correction/main.c:175 ../vector/v.outlier/main.c:220
+msgid "No points in current region!"
+msgstr ""
+#: ../vector/v.lidar.edgedetection/main.c:207
+#: ../vector/v.lidar.correction/main.c:182 ../vector/v.outlier/main.c:146
+msgid "Unable to read name of database"
+msgstr ""
+#: ../vector/v.lidar.edgedetection/main.c:210
+#: ../vector/v.lidar.correction/main.c:185 ../vector/v.outlier/main.c:149
+msgid "Unable to read name of driver"
+msgstr ""
+#: ../vector/v.lidar.edgedetection/main.c:227
+#: ../vector/v.lidar.edgedetection/main.c:239
+#: ../vector/v.lidar.edgedetection/main.c:261
+#: ../vector/v.lidar.correction/main.c:199
+#: ../vector/v.lidar.correction/main.c:235 ../vector/v.surf.bspline/main.c:252
+#: ../vector/v.surf.bspline/main.c:412 ../vector/v.lidar.growing/main.c:163
+#: ../vector/v.outlier/main.c:193 ../vector/v.outlier/main.c:261
+#, c-format
+msgid "No database connection for driver <%s> is defined. Run db.connect."
+msgstr ""
+#: ../vector/v.lidar.edgedetection/main.c:230
+#: ../vector/v.lidar.edgedetection/main.c:242
+#: ../vector/v.lidar.correction/main.c:204 ../vector/v.surf.bspline/main.c:257
+#: ../vector/v.outlier/main.c:198
+msgid "Old auxiliary table could not be dropped"
+msgstr ""
+#: ../vector/v.lidar.edgedetection/main.c:267
+#, c-format
+msgid "It was impossible to create <%s>."
+msgstr ""
+#: ../vector/v.lidar.edgedetection/main.c:270
+#, c-format
+msgid "It was impossible to create <%s> interpolation table in database."
+msgstr ""
+#: ../vector/v.lidar.edgedetection/main.c:304
+#: ../vector/v.surf.bspline/main.c:554 ../vector/v.outlier/main.c:300
+#, c-format
+msgid "Adjusted EW splines %d"
+msgstr ""
+#: ../vector/v.lidar.edgedetection/main.c:305
+#: ../vector/v.surf.bspline/main.c:555 ../vector/v.outlier/main.c:301
+#, c-format
+msgid "Adjusted NS splines %d"
+msgstr ""
+#: ../vector/v.lidar.edgedetection/main.c:360
+#: ../vector/v.lidar.correction/main.c:338 ../vector/v.lidar.growing/main.c:246
+#, c-format
+msgid "Subregion %d of %d"
+msgstr ""
+#: ../vector/v.lidar.edgedetection/main.c:423
+msgid "Performing bilinear interpolation..."
+msgstr ""
+#: ../vector/v.lidar.edgedetection/main.c:440
+msgid "Performing bicubic interpolation..."
+msgstr ""
+#: ../vector/v.lidar.edgedetection/main.c:452
+msgid "Point classification..."
+msgstr ""
+#: ../vector/v.lidar.edgedetection/main.c:466
+#: ../vector/v.lidar.correction/main.c:433
+msgid "No data within this subregion. Consider changing the spline step."
+msgstr ""
+#: ../vector/v.lidar.edgedetection/main.c:476
+#: ../vector/v.lidar.correction/main.c:444 ../vector/v.surf.bspline/main.c:946
+#: ../vector/v.outlier/main.c:460
+msgid "Auxiliary table could not be dropped"
+msgstr ""
+#: ../vector/v.lidar.edgedetection/edgedetection.c:228
+#: ../vector/v.lidar.edgedetection/edgedetection.c:274
+#: ../vector/v.lidar.edgedetection/edgedetection.c:304
+#: ../vector/v.lidar.edgedetection/edgedetection.c:322
+#: ../vector/v.lidar.edgedetection/edgedetection.c:352
+msgid "Impossible to read from aux table"
+msgstr ""
+#: ../vector/v.lidar.edgedetection/edgedetection.c:233
+#: ../vector/v.lidar.edgedetection/edgedetection.c:309
+msgid "Impossible to update aux table"
+msgstr ""
+#: ../vector/v.lidar.edgedetection/edgedetection.c:246
+#: ../vector/v.lidar.edgedetection/edgedetection.c:258
+#: ../vector/v.lidar.edgedetection/edgedetection.c:379
+msgid "Impossible to write to aux table"
+msgstr ""
+#: ../vector/v.out.ogr/attrb.c:65
+#, c-format
+msgid "No database record for cat = %d and export of 'cat' disabled"
+msgstr ""
+#: ../vector/v.out.ogr/main.c:88
+msgid "Exports a vector map layer to any of the supported OGR vector formats."
+msgstr ""
+#: ../vector/v.out.ogr/main.c:89
+msgid "By default a vector map layer is exported to OGC GeoPackage format."
+msgstr ""
+#: ../vector/v.out.ogr/main.c:171
+msgid "Volumes will be exported as sets of faces"
+msgstr ""
+#: ../vector/v.out.ogr/main.c:189
+msgid "Unable to determine input map's vector feature type(s)."
+msgstr ""
+#: ../vector/v.out.ogr/main.c:255
+msgid "The combination of types is not supported by all formats."
+msgstr ""
+#: ../vector/v.out.ogr/main.c:272
+msgid "Unable to create OGR spatial reference"
+msgstr ""
+#: ../vector/v.out.ogr/main.c:294
+#, c-format
+msgid "OGR layer <%s> created in datasource <%s> (format '%s')"
+msgstr ""
+#: ../vector/v.out.ogr/main.c:306
+msgid "The map contains islands. With the -c flag, islands will appear as filled areas, not holes in the output map."
+msgstr ""
+#: ../vector/v.out.ogr/main.c:312
+#, c-format
+msgid "%d point found, but not requested to be exported. Verify 'type' parameter."
+msgid_plural "%d points found, but not requested to be exported. Verify 'type' parameter."
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.out.ogr/main.c:320
+#, c-format
+msgid "%d line found, but not requested to be exported. Verify 'type' parameter."
+msgid_plural "%d line(s) found, but not requested to be exported. Verify 'type' parameter."
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.out.ogr/main.c:329
+#, c-format
+msgid "%d boundary found, but not requested to be exported. Verify 'type' parameter."
+msgid_plural "%d boundaries found, but not requested to be exported. Verify 'type' parameter."
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.out.ogr/main.c:338
+#, c-format
+msgid "%d centroid found, but not requested to be exported. Verify 'type' parameter."
+msgid_plural "%d centroids found, but not requested to be exported. Verify 'type' parameter."
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.out.ogr/main.c:346
+#, c-format
+msgid "%d area found, but not requested to be exported. Verify 'type' parameter."
+msgid_plural "%d areas found, but not requested to be exported. Verify 'type' parameter."
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.out.ogr/main.c:354
+#, c-format
+msgid "%d face found, but not requested to be exported. Verify 'type' parameter."
+msgid_plural "%d faces found, but not requested to be exported. Verify 'type' parameter."
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.out.ogr/main.c:362
+#, c-format
+msgid "%d volume found, but not requested to be exported. Verify 'type' parameter."
+msgid_plural "%d volumes found, but not requested to be exported. Verify 'type' parameter."
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.out.ogr/main.c:372
+msgid "No points found, but requested to be exported. Will skip this feature type."
+msgstr ""
+#: ../vector/v.out.ogr/main.c:381
+msgid "No lines found, but requested to be exported. Will skip this feature type."
+msgstr ""
+#: ../vector/v.out.ogr/main.c:391
+msgid "No boundaries found, but requested to be exported. Will skip this feature type."
+msgstr ""
+#: ../vector/v.out.ogr/main.c:400
+msgid "No areas found, but requested to be exported. Will skip this feature type."
+msgstr ""
+#: ../vector/v.out.ogr/main.c:410
+msgid "No centroids found, but requested to be exported. Will skip this feature type."
+msgstr ""
+#: ../vector/v.out.ogr/main.c:419
+msgid "No faces found, but requested to be exported. Will skip this feature type."
+msgstr ""
+#: ../vector/v.out.ogr/main.c:428
+msgid "No kernels found, but requested to be exported. Will skip this feature type."
+msgstr ""
+#: ../vector/v.out.ogr/main.c:437
+msgid "No volumes found, but requested to be exported. Will skip this feature type."
+msgstr ""
+#: ../vector/v.out.ogr/main.c:478
+#, c-format
+msgid "OGR driver <%s> not found"
+msgstr ""
+#: ../vector/v.out.ogr/main.c:523
+#, c-format
+msgid "Unable to open OGR data source '%s'"
+msgstr ""
+#: ../vector/v.out.ogr/main.c:543
+#, c-format
+msgid "Layer <%s> already exists in OGR data source '%s'"
+msgstr ""
+#: ../vector/v.out.ogr/main.c:547
+#, c-format
+msgid "OGR layer <%s> already exists and will be overwritten"
+msgstr ""
+#: ../vector/v.out.ogr/main.c:559
+#, c-format
+msgid "OGR layer <%s> doesn't exists, creating new OGR layer instead"
+msgstr ""
+#: ../vector/v.out.ogr/main.c:587
+msgid "Overriding existing user-defined 'SHPT=' LCO."
+msgstr ""
+#: ../vector/v.out.ogr/main.c:602
+#, c-format
+msgid "Vector map <%s> is 3D. Use format specific layer creation options SHPT (parameter 'lco') or '-z' flag to export in 3D rather than 2D (default)"
+msgstr ""
+#: ../vector/v.out.ogr/main.c:614
+#, c-format
+msgid "Vector map <%s> is 3D. Use format specific layer creation options DIM (parameter 'lco') to export in 3D rather than 2D (default)."
+msgstr ""
+#: ../vector/v.out.ogr/main.c:621
+#, c-format
+msgid "Vector map <%s> is 3D. Use format specific layer creation options (parameter 'lco') to export <in 3D rather than 2D (default)."
+msgstr ""
+#: ../vector/v.out.ogr/main.c:650
+msgid "Unable to create OGR layer"
+msgstr ""
+#: ../vector/v.out.ogr/main.c:662
+msgid "No attribute table found -> using only category numbers as attributes"
+msgstr ""
+#: ../vector/v.out.ogr/main.c:666
+msgid "Exporting 'cat' anyway, as it is the only attribute table field"
+msgstr ""
+#: ../vector/v.out.ogr/main.c:675 ../vector/v.out.ogr/main.c:747
+#, c-format
+msgid "New attribute column <%s> added to the table"
+msgstr ""
+#: ../vector/v.out.ogr/main.c:759
+#, c-format
+msgid "Key column <%s> not found"
+msgstr ""
+#: ../vector/v.out.ogr/main.c:787
+#, c-format
+msgid "Exporting %d feature..."
+msgid_plural "Exporting %d features..."
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.out.ogr/main.c:802
+#, c-format
+msgid "Exporting %d area (may take some time)..."
+msgid_plural "Exporting %d areas (may take some time)..."
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.out.ogr/main.c:821
+#, c-format
+msgid "Exporting %d volume..."
+msgid_plural "Exporting %d volumes..."
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.out.ogr/main.c:825
+msgid "Export of volumes not implemented yet. Skipping."
+msgstr ""
+#: ../vector/v.out.ogr/main.c:842
+#, c-format
+msgid "%d feature without attributes was written"
+msgid_plural "%d features without attributes were written"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.out.ogr/main.c:848
+#, c-format
+msgid "%d feature without category was written"
+msgid_plural "%d features without category were written"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.out.ogr/main.c:852
+#, c-format
+msgid "%d feature without category was skipped. Features without category are written only when -%c flag is given."
+msgid_plural "%d features without category were skipped. Features without category are written only when -%c flag is given."
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.out.ogr/main.c:868
+msgid "Output layer is empty, no features written"
+msgstr ""
+#: ../vector/v.out.ogr/main.c:869
+#, c-format
+msgid "%d feature (%s type) written to <%s> (%s format)."
+msgid_plural "%d features (%s type) written to <%s> (%s format)."
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.out.ogr/args.c:9
+msgid "Name of input vector map to export"
+msgstr ""
+#: ../vector/v.out.ogr/args.c:18
+msgid "Feature type(s)"
+msgstr ""
+#: ../vector/v.out.ogr/args.c:20
+msgid "Combination of types is not supported by all output formats. Default is to use first type found in input vector map."
+msgstr ""
+#: ../vector/v.out.ogr/args.c:25
+msgid "Name of output OGR datasource"
+msgstr ""
+#: ../vector/v.out.ogr/args.c:27
+msgid ""
+"For example: ESRI Shapefile: filename or directory for storage\n"
+"\t\t\tPostGIS database: connection string"
+msgstr ""
+#: ../vector/v.out.ogr/args.c:37
+msgid "Data format to write"
+msgstr ""
+#: ../vector/v.out.ogr/args.c:44
+msgid "Name for output OGR layer. If not specified, input name is used"
+msgstr ""
+#: ../vector/v.out.ogr/args.c:46
+msgid ""
+"For example: ESRI Shapefile: shapefile name\n"
+"\t\t\tPostGIS database: table name"
+msgstr ""
+#: ../vector/v.out.ogr/args.c:54
+msgid "Optionally change default output type"
+msgstr ""
+#: ../vector/v.out.ogr/args.c:57
+msgid "export area boundaries as linestrings"
+msgstr ""
+#: ../vector/v.out.ogr/args.c:58
+msgid "export lines as polygons"
+msgstr ""
+#: ../vector/v.out.ogr/args.c:68
+msgid "OGR dataset creation option (format specific, NAME=VALUE)"
+msgstr ""
+#: ../vector/v.out.ogr/args.c:78
+msgid "OGR layer creation option (format specific, NAME=VALUE)"
+msgstr ""
+#: ../vector/v.out.ogr/args.c:83
+msgid "Open an existing OGR datasource for update"
+msgstr ""
+#: ../vector/v.out.ogr/args.c:87
+msgid "Append to existing layer"
+msgstr ""
+#: ../vector/v.out.ogr/args.c:88
+msgid "A new OGR layer is created if it does not exist"
+msgstr ""
+#: ../vector/v.out.ogr/args.c:94
+msgid "Skip export of GRASS category ID ('cat') attribute"
+msgstr ""
+#: ../vector/v.out.ogr/args.c:100
+msgid "Also export features without category (not labeled). Otherwise only features with category are exported."
+msgstr ""
+#: ../vector/v.out.ogr/args.c:106
+msgid "Use ESRI-style .prj file format (applies to Shapefile output only)"
+msgstr ""
+#: ../vector/v.out.ogr/args.c:112
+msgid "Force 2D output even if input is 3D (applies to Shapefile output only)"
+msgstr ""
+#: ../vector/v.out.ogr/args.c:114 ../vector/v.in.ogr/main.c:339
+#: ../vector/v.out.postgis/args.c:78
+msgid "Useful if input is 3D but all z coordinates are identical"
+msgstr ""
+#: ../vector/v.out.ogr/args.c:120
+msgid "Export vector data as multi-features"
+msgstr ""
+#: ../vector/v.out.ogr/args.c:126
+msgid "Create a new empty layer in defined OGR datasource and exit. Nothing is read from input."
+msgstr ""
+#: ../vector/v.out.ogr/args.c:133
+msgid "List supported output formats and exit"
+msgstr ""
+#: ../vector/v.out.ogr/dsn.c:21 ../vector/v.in.ogr/dsn.c:26
+#: ../vector/v.external/dsn.c:21
+msgid "Invalid connection string (dbname missing)"
+msgstr ""
+#: ../vector/v.out.ogr/create.c:20
+#, c-format
+msgid "OGR driver <%s> not available"
+msgstr ""
+#: ../vector/v.out.ogr/create.c:30
+#, c-format
+msgid "Creation of output OGR datasource <%s> failed"
+msgstr ""
+#: ../vector/v.out.ogr/create.c:44
+#, c-format
+msgid "Creation of OGR layer <%s> failed"
+msgstr ""
+#: ../vector/v.out.ogr/export_lines.c:178
+#: ../vector/v.out.ogr/export_areas.c:166
+#, c-format
+msgid "Unable to export multi-features. No category index for layer %d."
+msgstr ""
+#: ../vector/v.out.ogr/export_lines.c:212
+#: ../vector/v.out.ogr/export_areas.c:199
+#, c-format
+msgid "Unable to create multi-feature. Category %d not found in line %d, field %d"
+msgstr ""
+#: ../vector/v.out.ogr/export_areas.c:177
+msgid "Exporting features with category..."
+msgstr ""
+#: ../vector/v.out.ogr/export_areas.c:237
+msgid "Exporting features without category..."
+msgstr ""
+#: ../vector/v.kcv/main.c:57 ../vector/v.out.lidar/main.c:474
+#: ../vector/v.normal/main.c:74 ../vector/v.in.db/main.c:55
+#: ../vector/v.decimate/main.c:129
+msgid "points"
+msgstr ""
+#: ../vector/v.kcv/main.c:60
+msgid "Randomly partition points into test/train sets."
+msgstr ""
+#: ../vector/v.kcv/main.c:70
+msgid "Number of partitions"
+msgstr ""
+#: ../vector/v.kcv/main.c:71
+msgid "Must be > 1"
+msgstr ""
+#: ../vector/v.kcv/main.c:76
+msgid "Name for new column to which partition number is written"
+msgstr ""
+#: ../vector/v.kcv/main.c:85
+#, c-format
+msgid "'%s' must be > 1"
+msgstr ""
+#: ../vector/v.kcv/main.c:96 ../vector/v.kcv/main.c:186
+#: ../vector/v.category/main.c:186 ../vector/v.category/main.c:250
+#: ../vector/v.category/main.c:258
+#, c-format
+msgid "Unable to open vector map <%s> at topological level %d"
+msgstr ""
+#: ../vector/v.kcv/main.c:102
+msgid "Layer number must be positive"
+msgstr ""
+#: ../vector/v.kcv/main.c:107
+#, c-format
+msgid "More partitions than points (%d)"
+msgstr ""
+#: ../vector/v.kcv/main.c:120
+#, c-format
+msgid "Unable to get layer info for vector map <%s>"
+msgstr ""
+#: ../vector/v.kcv/main.c:145
+#, c-format
+msgid "Column <%s> already exists but is not numeric"
+msgstr ""
+#: ../vector/v.kcv/main.c:160
+#, c-format
+msgid "Unable to alter table: %s"
+msgstr ""
+#: ../vector/v.kcv/main.c:168 ../vector/v.db.connect/main.c:158
+msgid "Unable to modify vector map stored in other mapset"
+msgstr ""
+#: ../vector/v.kcv/main.c:175 ../vector/v.net.distance/main.c:295
+#: ../vector/v.db.connect/main.c:336 ../vector/v.net.allpairs/main.c:183
+#: ../vector/v.net.path/path.c:113 ../vector/v.net.iso/main.c:394
+#: ../vector/v.net.flow/main.c:185 ../vector/v.sample/main.c:193
+#: ../vector/v.net.timetable/main.c:107 ../vector/v.net.components/main.c:194
+#: ../vector/v.net.centrality/main.c:270 ../vector/v.net.alloc/main.c:333
+msgid "Cannot create index"
+msgstr ""
+#: ../vector/v.kcv/main.c:179 ../vector/v.db.connect/main.c:341
+#, c-format
+msgid "Cannot grant privileges on table %s"
+msgstr ""
+#: ../vector/v.kcv/main.c:182 ../vector/v.db.connect/main.c:344
+msgid "Select privileges were granted on the table"
+msgstr ""
+#: ../vector/v.kcv/main.c:267
+#, c-format
+msgid "No category for line %d in layer %d"
+msgstr ""
+#: ../vector/v.kcv/main.c:284 ../vector/v.sample/main.c:263
+#, c-format
+msgid "Unable to insert row: %s"
+msgstr ""
+#: ../vector/v.kcv/main.c:300
+msgid "internal error"
+msgstr ""
+#: ../vector/v.surf.idw/main.c:92
+msgid "Provides surface interpolation from vector point data by Inverse Distance Squared Weighting."
+msgstr ""
+#: ../vector/v.surf.idw/main.c:101
+msgid "Name of attribute column with values to interpolate"
+msgstr ""
+#: ../vector/v.surf.idw/main.c:102 ../vector/v.surf.rst/main.c:185
+msgid "If not given and input is 2D vector map then category values are used. If input is 3D vector map then z-coordinates are used."
+msgstr ""
+#: ../vector/v.surf.idw/main.c:104
+msgid "Values"
+msgstr ""
+#: ../vector/v.surf.idw/main.c:121
+msgid "Power parameter"
+msgstr ""
+#: ../vector/v.surf.idw/main.c:123
+msgid "Greater values assign greater influence to closer points"
+msgstr ""
+#: ../vector/v.surf.idw/main.c:128
+msgid "Don't index points by raster cell"
+msgstr ""
+#: ../vector/v.surf.idw/main.c:129
+msgid "Slower but uses less memory and includes points from outside region in the interpolation"
+msgstr ""
+#: ../vector/v.surf.idw/main.c:139
+#, c-format
+msgid "Illegal number (%s) of interpolation points"
+msgstr ""
+#: ../vector/v.surf.idw/main.c:176 ../vector/v.normal/main.c:195
+#: ../vector/v.neighbors/main.c:175
+msgid "No points found"
+msgstr ""
+#. GTC First argument is map name, second - message about number of rows, third - columns.
+#: ../vector/v.surf.idw/main.c:263
+#, c-format
+msgid "Interpolating raster map <%s> (%s, %s)..."
+msgstr ""
+#: ../vector/v.surf.idw/read_sites.c:37
+#, c-format
+msgid "Input vector map <%s> is 2D - using categories to interpolate"
+msgstr ""
+#: ../vector/v.surf.idw/read_sites.c:40
+#, c-format
+msgid "Input vector map <%s> is 3D - using z-coordinates to interpolate"
+msgstr ""
+#: ../vector/v.surf.idw/read_sites.c:50 ../vector/v.reclass/main.c:128
+#: ../vector/v.sample/main.c:133
+#, c-format
+msgid "Database connection not defined for layer %s"
+msgstr ""
+#: ../vector/v.surf.idw/read_sites.c:65 ../vector/v.class/main.c:129
+#: ../vector/v.to.rast3/main.c:99 ../vector/v.surf.bspline/main.c:395
+#: ../vector/v.surf.bspline/crosscorr.c:133 ../vector/v.buffer/main.c:448
+#: ../vector/v.what.rast/main.c:183 ../vector/v.sample/main.c:240
+msgid "Column type not supported"
+msgstr ""
+#: ../vector/v.surf.idw/read_sites.c:70
+#, c-format
+msgid "One record selected from table"
+msgid_plural "%d records selected from table"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.surf.idw/read_sites.c:107
+#: ../vector/v.surf.bspline/crosscorr.c:220
+#, c-format
+msgid "No record for point (cat = %d)"
+msgstr ""
+#: ../vector/v.surf.idw/read_sites.c:123
+#, c-format
+msgid "%ld point loaded"
+msgid_plural "%ld points loaded"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.class/main.c:50
+msgid "Classifies attribute data, e.g. for thematic mapping"
+msgstr ""
+#: ../vector/v.class/main.c:58
+msgid "Column name or expression"
+msgstr ""
+#: ../vector/v.class/main.c:93
+msgid "Print only class breaks (without min and max)"
+msgstr ""
+#: ../vector/v.class/main.c:138
+msgid "Unable to sort array of values"
+msgstr ""
+#: ../vector/v.class/main.c:173
+msgid "The discontinuities algorithm indicates that some class breaks are not statistically significant at alpha=0.05. You are advised to reduce the number of classes."
+msgstr ""
+#: ../vector/v.class/main.c:201
+#, c-format
+msgid ""
+"\n"
+"Classification of %s into %i classes\n"
+msgstr ""
+#: ../vector/v.class/main.c:208
+#, c-format
+msgid "Lowest chi2 = %f\n"
+msgstr ""
+#: ../vector/v.class/main.c:214
+#, c-format
+msgid ""
+"%15s%15s%15s\n"
+"\n"
+msgstr ""
+#: ../vector/v.class/main.c:226
+#, c-format
+msgid ""
+"\n"
+"Note: Minimum of first class is including\n"
+"\n"
+msgstr ""
+#: ../vector/v.clean/main.c:55
+msgid "Toolset for cleaning topology of vector map."
+msgstr ""
+#: ../vector/v.clean/main.c:70
+msgid "Name of output map where errors are written"
+msgstr ""
+#: ../vector/v.clean/main.c:81
+msgid "Cleaning tool"
+msgstr ""
+#: ../vector/v.clean/main.c:97
+msgid "break lines at each intersection"
+msgstr ""
+#: ../vector/v.clean/main.c:98
+msgid "remove duplicate geometry features (pay attention to categories!)"
+msgstr ""
+#: ../vector/v.clean/main.c:99
+msgid "remove dangles, threshold ignored if < 0"
+msgstr ""
+#: ../vector/v.clean/main.c:100
+msgid "change the type of boundary dangle to line, threshold ignored if < 0, input line type is ignored"
+msgstr ""
+#: ../vector/v.clean/main.c:102
+msgid "remove bridges connecting area and island or 2 islands"
+msgstr ""
+#: ../vector/v.clean/main.c:103
+msgid "change the type of bridges connecting area and island or 2 islands from boundary to line"
+msgstr ""
+#: ../vector/v.clean/main.c:105
+msgid "snap lines to vertex in threshold"
+msgstr ""
+#: ../vector/v.clean/main.c:106
+msgid "remove duplicate area centroids ('type' option ignored)"
+msgstr ""
+#: ../vector/v.clean/main.c:107
+msgid "break (topologically clean) polygons (imported from non topological format, like ShapeFile). Boundaries are broken on each point shared between 2 and more polygons where angles of segments are different"
+msgstr ""
+#: ../vector/v.clean/main.c:110
+msgid "remove vertices in threshold from lines and boundaries, boundary is pruned only if topology is not damaged (new intersection, changed attachment of centroid), first and last segment of the boundary is never changed"
+msgstr ""
+#: ../vector/v.clean/main.c:114
+msgid "remove small areas, the longest boundary with adjacent area is removed"
+msgstr ""
+#: ../vector/v.clean/main.c:115
+msgid "remove all lines or boundaries of zero length, threshold is ignored"
+msgstr ""
+#: ../vector/v.clean/main.c:116
+msgid "remove small angles between lines at nodes"
+msgstr ""
+#: ../vector/v.clean/main.c:124
+msgid "Threshold in map units, one value for each tool"
+msgstr ""
+#: ../vector/v.clean/main.c:125
+msgid "Default: 0.0[,0.0,...])"
+msgstr ""
+#: ../vector/v.clean/main.c:130
+msgid "Do not build topology for the output vector"
+msgstr ""
+#: ../vector/v.clean/main.c:135
+msgid "Combine tools with recommended follow-up tools"
+msgstr ""
+#: ../vector/v.clean/main.c:156
+msgid "You must select at least one tool"
+msgstr ""
+#: ../vector/v.clean/main.c:191
+msgid "Tool doesn't exist"
+msgstr ""
+#: ../vector/v.clean/main.c:202
+msgid "Note: In latitude-longitude coordinate system specify threshold in degree unit"
+msgstr ""
+#: ../vector/v.clean/main.c:215
+#, c-format
+msgid "Threshold for tool %d may not be > 0, set to 0"
+msgstr ""
+#: ../vector/v.clean/main.c:224
+msgid "Tool: Threshold"
+msgstr ""
+#: ../vector/v.clean/main.c:229
+msgid "Break"
+msgstr ""
+#: ../vector/v.clean/main.c:232
+msgid "Remove duplicates"
+msgstr ""
+#: ../vector/v.clean/main.c:235
+msgid "Remove dangles"
+msgstr ""
+#: ../vector/v.clean/main.c:238
+msgid "Change type of boundary dangles"
+msgstr ""
+#: ../vector/v.clean/main.c:242
+msgid "Remove bridges"
+msgstr ""
+#: ../vector/v.clean/main.c:245
+msgid "Change type of boundary bridges"
+msgstr ""
+#: ../vector/v.clean/main.c:249
+msgid "Snap vertices"
+msgstr ""
+#: ../vector/v.clean/main.c:252
+msgid "Remove duplicate area centroids"
+msgstr ""
+#: ../vector/v.clean/main.c:256
+msgid "Break polygons"
+msgstr ""
+#: ../vector/v.clean/main.c:259
+msgid "Prune"
+msgstr ""
+#: ../vector/v.clean/main.c:262
+msgid "Remove small areas"
+msgstr ""
+#: ../vector/v.clean/main.c:265
+msgid "Remove small angles at nodes"
+msgstr ""
+#: ../vector/v.clean/main.c:270
+msgid "Remove all lines or boundaries of zero length"
+msgstr ""
+#: ../vector/v.clean/main.c:314
+msgid "Topological cleaning works best with native GRASS vector format"
+msgstr ""
+#: ../vector/v.clean/main.c:325
+msgid "Failed to copy attribute table to output vector map"
+msgstr ""
+#: ../vector/v.clean/main.c:340 ../vector/v.clean/main.c:351
+msgid "Rebuilding parts of topology..."
+msgstr ""
+#: ../vector/v.clean/main.c:360 ../vector/v.clean/main.c:405
+#: ../vector/v.clean/main.c:456
+msgid "Tool: Split lines"
+msgstr ""
+#: ../vector/v.clean/main.c:363 ../vector/v.clean/main.c:409
+#: ../vector/v.clean/main.c:462
+msgid "Tool: Break lines at intersections"
+msgstr ""
+#: ../vector/v.clean/main.c:366 ../vector/v.clean/main.c:375
+#: ../vector/v.clean/main.c:411 ../vector/v.clean/main.c:427
+#: ../vector/v.clean/main.c:464
+msgid "Tool: Remove duplicates"
+msgstr ""
+#: ../vector/v.clean/main.c:369 ../vector/v.clean/main.c:418
+#: ../vector/v.clean/main.c:469
+msgid "Tool: Merge lines"
+msgstr ""
+#: ../vector/v.clean/main.c:379
+msgid "Tool: Remove dangles"
+msgstr ""
+#: ../vector/v.clean/main.c:383
+msgid "Tool: Change type of boundary dangles"
+msgstr ""
+#: ../vector/v.clean/main.c:387
+msgid "Tool: Remove bridges"
+msgstr ""
+#: ../vector/v.clean/main.c:391
+msgid "Tool: Change type of boundary bridges"
+msgstr ""
+#: ../vector/v.clean/main.c:395
+msgid "Tool: Remove duplicate area centroids"
+msgstr ""
+#: ../vector/v.clean/main.c:399
+msgid "Tool: Snap line to vertex in threshold"
+msgstr ""
+#: ../vector/v.clean/main.c:413 ../vector/v.clean/main.c:447
+#: ../vector/v.clean/main.c:466
+msgid "Tool: Remove small angles at nodes"
+msgstr ""
+#: ../vector/v.clean/main.c:424
+msgid "Tool: Break polygons"
+msgstr ""
+#: ../vector/v.clean/main.c:432
+msgid "Tool: Prune lines/boundaries"
+msgstr ""
+#: ../vector/v.clean/main.c:436
+msgid "Tool: Remove small areas"
+msgstr ""
+#: ../vector/v.clean/main.c:442
+msgid "Tool: Merge boundaries"
+msgstr ""
+#: ../vector/v.clean/main.c:475
+msgid "Tool: Remove all lines and boundaries of zero length"
+msgstr ""
+#: ../vector/v.clean/main.c:484
+msgid "Rebuilding topology for output vector map..."
+msgstr ""
+#: ../vector/v.clean/main.c:495
+msgid "Building topology for error vector map..."
+msgstr ""
+#: ../vector/v.clean/rmline.c:64
+#, c-format
+msgid "Lines / boundaries removed: %d"
+msgstr ""
+#: ../vector/v.clean/prune.c:216
+#, c-format
+msgid "%d vertices from input %d (vertices of given type) removed, i.e. %.2f %%"
+msgstr ""
+#: ../vector/v.clean/prune.c:220
+#, c-format
+msgid "%d boundaries not pruned because pruning would damage topology"
+msgstr ""
+#: ../vector/v.clean/split.c:85
+#, c-format
+msgid "Line splits: %d"
+msgstr ""
+#: ../vector/v.clean/rmdac.c:60
+#, c-format
+msgid "Duplicate area centroids: %d"
+msgstr ""
+#: ../vector/v.label.sa/main.c:41
+msgid "Create optimally placed labels for vector map(s)"
+msgstr ""
+#: ../vector/v.label.sa/main.c:57 ../vector/v.label/main.c:78
+msgid "Name of attribute column to be used for labels"
+msgstr ""
+#: ../vector/v.label.sa/main.c:61 ../vector/v.label/main.c:67
+msgid "Name for new paint-label file"
+msgstr ""
+#: ../vector/v.label.sa/main.c:71
+msgid "Name of TrueType font (as listed in the fontcap)"
+msgstr ""
+#: ../vector/v.label.sa/main.c:72 ../vector/v.label.sa/main.c:80
+#: ../vector/v.label/main.c:125 ../vector/v.label/main.c:132
+#: ../vector/v.label/main.c:140 ../vector/v.label/main.c:148
+#: ../vector/v.lrs/v.lrs.label/main.c:181
+msgid "Font"
+msgstr ""
+#: ../vector/v.label.sa/main.c:77 ../vector/v.label/main.c:129
+#: ../vector/v.lrs/v.lrs.label/main.c:187
+msgid "Label size (in map-units)"
+msgstr ""
+#: ../vector/v.label.sa/main.c:84
+msgid "Icon size of point features (in map-units)"
+msgstr ""
+#: ../vector/v.label.sa/main.c:107 ../vector/v.label/main.c:174
+#: ../vector/v.lrs/v.lrs.label/main.c:205
+msgid "Highlight color for text"
+msgstr ""
+#: ../vector/v.label.sa/main.c:117 ../vector/v.label/main.c:180
+msgid "Width of highlight coloring"
+msgstr ""
+#: ../vector/v.label.sa/main.c:135 ../vector/v.label/main.c:200
+msgid "Opaque to vector (only relevant if background color is selected)"
+msgstr ""
+#: ../vector/v.label.sa/main.c:154
+msgid "Border width (only for ps.map output)"
+msgstr ""
+#: ../vector/v.label.sa/font.c:54
+#, c-format
+msgid "%s: Unable to read font definition file; use the default"
+msgstr ""
+#: ../vector/v.label.sa/font.c:60
+#, c-format
+msgid "%s: No font definition file"
+msgstr ""
+#: ../vector/v.label.sa/labels.c:68
+#, c-format
+msgid "Cannot allocate %lu bytes of memory"
+msgstr ""
+#: ../vector/v.label.sa/labels.c:87
+msgid "Unable to initialise FreeType"
+msgstr ""
+#: ../vector/v.label.sa/labels.c:90
+#, c-format
+msgid "Unable to find font '%s'\n"
+msgstr ""
+#: ../vector/v.label.sa/labels.c:92
+#, c-format
+msgid "Font '%s' is not a FreeType font\n"
+msgstr ""
+#: ../vector/v.label.sa/labels.c:96
+msgid "Font file format is not supported by FreeType"
+msgstr ""
+#: ../vector/v.label.sa/labels.c:98
+msgid "Font file can not be loaded"
+msgstr ""
+#: ../vector/v.label.sa/labels.c:107
+msgid "Unable to set font size"
+msgstr ""
+#: ../vector/v.label.sa/labels.c:128
+msgid "Cannot allocate more memory"
+msgstr ""
+#: ../vector/v.label.sa/labels.c:162 ../vector/v.overlay/main.c:423
+#: ../vector/v.label/main.c:319
+msgid "Unable to select attributes"
+msgstr ""
+#: ../vector/v.label.sa/labels.c:244
+#, c-format
+msgid "Cannot load glyph for '%c'"
+msgstr ""
+#: ../vector/v.net.distance/main.c:69
+msgid "Computes shortest distance via the network between the given sets of features."
+msgstr ""
+#: ../vector/v.net.distance/main.c:72
+msgid "Finds the shortest paths from each 'from' point to the nearest 'to' feature and various information about this relation are uploaded to the attribute table."
+msgstr ""
+#: ../vector/v.net.distance/main.c:83 ../vector/v.net.distance/main.c:90
+#: ../vector/v.net.distance/main.c:96 ../vector/v.net.distance/main.c:142
+#: ../vector/v.net.distance/main.c:148 ../vector/v.net.distance/main.c:154
+#: ../vector/v.net.allpairs/main.c:94 ../vector/v.net.allpairs/main.c:100
+#: ../vector/v.net.allpairs/main.c:107 ../vector/v.net.connectivity/main.c:65
+#: ../vector/v.net.connectivity/main.c:71
+#: ../vector/v.net.connectivity/main.c:78
+#: ../vector/v.net.connectivity/main.c:84
+#: ../vector/v.net.connectivity/main.c:92 ../vector/v.net.path/main.c:80
+#: ../vector/v.net.path/main.c:87 ../vector/v.net.path/main.c:94
+#: ../vector/v.net.iso/main.c:96 ../vector/v.net.iso/main.c:136
+#: ../vector/v.net.iso/main.c:141 ../vector/v.net.iso/main.c:146
+#: ../vector/v.net.spanningtree/main.c:60
+#: ../vector/v.net.spanningtree/main.c:66
+#: ../vector/v.net.spanningtree/main.c:73
+#: ../vector/v.net.spanningtree/main.c:79 ../vector/v.net.flow/main.c:71
+#: ../vector/v.net.flow/main.c:77 ../vector/v.net.flow/main.c:91
+#: ../vector/v.net.flow/main.c:97 ../vector/v.net.flow/main.c:103
+#: ../vector/v.net.timetable/main.c:275 ../vector/v.net.timetable/main.c:281
+#: ../vector/v.net.timetable/main.c:289 ../vector/v.net.timetable/main.c:296
+#: ../vector/v.net.timetable/main.c:303 ../vector/v.net.bridge/main.c:61
+#: ../vector/v.net.bridge/main.c:67 ../vector/v.net.bridge/main.c:74
+#: ../vector/v.net.bridge/main.c:80 ../vector/v.net.bridge/main.c:87
+#: ../vector/v.net.components/main.c:85 ../vector/v.net.components/main.c:91
+#: ../vector/v.net.components/main.c:98 ../vector/v.net.components/main.c:104
+#: ../vector/v.net.components/main.c:111 ../vector/v.net.salesman/main.c:169
+#: ../vector/v.net.salesman/main.c:177 ../vector/v.net.centrality/main.c:110
+#: ../vector/v.net.centrality/main.c:116 ../vector/v.net.centrality/main.c:130
+#: ../vector/v.net.centrality/main.c:136 ../vector/v.net.centrality/main.c:143
+#: ../vector/v.net.alloc/main.c:82 ../vector/v.net.alloc/main.c:115
+#: ../vector/v.net.alloc/main.c:120 ../vector/v.net.alloc/main.c:125
+msgid "Cost"
+msgstr ""
+#: ../vector/v.net.distance/main.c:100
+msgid "From layer number or name"
+msgstr ""
+#: ../vector/v.net.distance/main.c:101 ../vector/v.net.distance/main.c:106
+#: ../vector/v.net.distance/main.c:112 ../vector/v.distance/main.c:131
+#: ../vector/v.distance/main.c:136 ../vector/v.distance/main.c:143
+#: ../vector/v.distance/main.c:187 ../vector/v.distance/main.c:224
+msgid "From"
+msgstr ""
+#: ../vector/v.net.distance/main.c:105
+msgid "From category values"
+msgstr ""
+#: ../vector/v.net.distance/main.c:111
+msgid "From WHERE conditions of SQL statement without 'where' keyword"
+msgstr ""
+#: ../vector/v.net.distance/main.c:116
+msgid "To layer number or name"
+msgstr ""
+#: ../vector/v.net.distance/main.c:117 ../vector/v.net.distance/main.c:124
+#: ../vector/v.net.distance/main.c:129 ../vector/v.net.distance/main.c:135
+#: ../vector/v.distance/main.c:148 ../vector/v.distance/main.c:153
+#: ../vector/v.distance/main.c:160 ../vector/v.distance/main.c:230
+msgid "To"
+msgstr ""
+#: ../vector/v.net.distance/main.c:123
+msgid "To feature type"
+msgstr ""
+#: ../vector/v.net.distance/main.c:128
+msgid "To category values"
+msgstr ""
+#: ../vector/v.net.distance/main.c:134
+msgid "To WHERE conditions of SQL statement without 'where' keyword"
+msgstr ""
+#: ../vector/v.net.distance/main.c:153 ../vector/v.net.allpairs/main.c:106
+#: ../vector/v.net.connectivity/main.c:91 ../vector/v.net.path/main.c:93
+#: ../vector/v.net.iso/main.c:145 ../vector/v.net.spanningtree/main.c:78
+#: ../vector/v.net.flow/main.c:102 ../vector/v.net.timetable/main.c:302
+#: ../vector/v.net.bridge/main.c:86 ../vector/v.net.components/main.c:110
+#: ../vector/v.net.centrality/main.c:142 ../vector/v.net.alloc/main.c:124
+msgid "Node cost column (number)"
+msgstr ""
+#: ../vector/v.net.distance/main.c:165 ../vector/v.net.path/main.c:136
+msgid "Write output as original input segments, not each path as one line."
+msgstr ""
+#: ../vector/v.net.distance/main.c:169
+msgid "Write each output path as one line, not as original input segments."
+msgstr ""
+#: ../vector/v.net.distance/main.c:244
+#, c-format
+msgid "No 'from' features selected. Please check options '%s', '%s', '%s'."
+msgstr ""
+#: ../vector/v.net.distance/main.c:251
+#, c-format
+msgid "No 'to' features selected. Please check options '%s', '%s', '%s'."
+msgstr ""
+#: ../vector/v.net.distance/main.c:260
+msgid "No 'to' features"
+msgstr ""
+#: ../vector/v.net.distance/main.c:264 ../vector/v.net.connectivity/main.c:178
+#: ../vector/v.net.spanningtree/main.c:124 ../vector/v.net.flow/main.c:226
+#: ../vector/v.net.timetable/main.c:405 ../vector/v.net.bridge/main.c:134
+#: ../vector/v.net.components/main.c:163 ../vector/v.net.centrality/main.c:284
+#: ../vector/v.generalize/network.c:89
+#, c-format
+msgid "Unable to build graph for vector map <%s>"
+msgstr ""
+#: ../vector/v.net.distance/main.c:268
+msgid "Distances to 'to' features ..."
+msgstr ""
+#: ../vector/v.net.distance/main.c:299 ../vector/v.net.allpairs/main.c:187
+#: ../vector/v.net.path/path.c:117 ../vector/v.net.iso/main.c:398
+#: ../vector/v.net.flow/main.c:189 ../vector/v.net.timetable/main.c:112
+#: ../vector/v.net.components/main.c:198 ../vector/v.net.centrality/main.c:274
+#: ../vector/v.net.alloc/main.c:337
+#, c-format
+msgid "Cannot grant privileges on table <%s>"
+msgstr ""
+#: ../vector/v.net.distance/main.c:307
+msgid "Tracing paths from 'from' features ..."
+msgstr ""
+#: ../vector/v.net.distance/main.c:423
+#, c-format
+msgid "%d 'from' feature was not reachable"
+msgid_plural "%d 'from' features were not reachable"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.random/main.c:102
+msgid "stratified random sampling"
+msgstr ""
+#: ../vector/v.random/main.c:105
+msgid "Generates random 2D/3D vector points."
+msgstr ""
+#: ../vector/v.random/main.c:113
+msgid "Number of points to be created"
+msgstr ""
+#: ../vector/v.random/main.c:118
+msgid "Restrict points to areas in input vector"
+msgstr ""
+#: ../vector/v.random/main.c:135
+msgid "Minimum z height (needs -z flag or column name)"
+msgstr ""
+#: ../vector/v.random/main.c:137 ../vector/v.random/main.c:146
+#: ../vector/v.random/main.c:159 ../vector/v.random/main.c:169
+#: ../vector/v.random/main.c:174 ../vector/v.in.db/main.c:85
+msgid "3D output"
+msgstr ""
+#: ../vector/v.random/main.c:144
+msgid "Maximum z height (needs -z flag or column name)"
+msgstr ""
+#: ../vector/v.random/main.c:153
+msgid "The seed to initialize the random generator. If not set the process ID is used"
+msgstr ""
+#: ../vector/v.random/main.c:156
+msgid "Name of column for z values"
+msgstr ""
+#: ../vector/v.random/main.c:158
+msgid "Writes z values to column"
+msgstr ""
+#: ../vector/v.random/main.c:166
+msgid "Type of column for z values"
+msgstr ""
+#: ../vector/v.random/main.c:173
+msgid "Create 3D output"
+msgstr ""
+#: ../vector/v.random/main.c:178
+msgid "Generate n points for each individual area"
+msgstr ""
+#: ../vector/v.random/main.c:192
+#, c-format
+msgid "Number of points must be > 0 (%d given)"
+msgstr ""
+#: ../vector/v.random/main.c:208 ../vector/v.drape/main.c:150
+#: ../vector/v.buffer/main.c:347
+#, c-format
+msgid "Invalid layer number (%d). Parameter '%s' or '%s' specified, assuming layer '1'."
+msgstr ""
+#: ../vector/v.random/main.c:218
+#, c-format
+msgid "No areas in vector map <%s>"
+msgstr ""
+#: ../vector/v.random/main.c:223
+#, c-format
+msgid "The <-%c> flag requires an input vector with areas"
+msgstr ""
+#: ../vector/v.random/main.c:277
+msgid "Table should contain only two columns"
+msgstr ""
+#: ../vector/v.random/main.c:286
+msgid "You have created unsupported column type. This module supports only INTEGER and DOUBLE PRECISION column types."
+msgstr ""
+#: ../vector/v.random/main.c:349
+#, c-format
+msgid "Selected areas in input vector <%s> do not overlap with the current region"
+msgstr ""
+#: ../vector/v.random/main.c:361
+#, c-format
+msgid "Input vector <%s> does not overlap with the current region"
+msgstr ""
+#: ../vector/v.random/main.c:386
+msgid "Generating points..."
+msgstr ""
+#: ../vector/v.support/main.c:41
+msgid "Updates vector map metadata."
+msgstr ""
+#: ../vector/v.support/main.c:52
+msgid "Organization where vector map was created"
+msgstr ""
+#: ../vector/v.support/main.c:61
+msgid "Date of vector map digitization (e.g., \"15 Mar 2007\")"
+msgstr ""
+#: ../vector/v.support/main.c:68
+msgid "Person who created vector map"
+msgstr ""
+#: ../vector/v.support/main.c:75
+msgid "Vector map title"
+msgstr ""
+#: ../vector/v.support/main.c:83
+msgid "Date when the source map was originally produced"
+msgstr ""
+#: ../vector/v.support/main.c:89
+msgid "Vector map scale number (e.g., 24000)"
+msgstr ""
+#: ../vector/v.support/main.c:95
+msgid "Vector map projection zone"
+msgstr ""
+#: ../vector/v.support/main.c:102
+msgid "Vector map digitizing threshold number (e.g., 0.5)"
+msgstr ""
+#: ../vector/v.support/main.c:110
+msgid "Text to append to the comment line of the map's metadata file"
+msgstr ""
+#: ../vector/v.support/main.c:118
+msgid "Command line to store into vector map history file (used for vector scripts)"
+msgstr ""
+#: ../vector/v.support/main.c:122
+msgid "Replace comment instead of appending it"
+msgstr ""
+#: ../vector/v.support/main.c:126
+msgid "Replace command line instead of appending it"
+msgstr ""
+#: ../vector/v.support/main.c:190
+#, c-format
+msgid "Unable to open history file for vector map <%s>"
+msgstr ""
+#: ../vector/v.out.dxf/main.c:58
+msgid "DXF"
+msgstr ""
+#: ../vector/v.out.dxf/main.c:60
+msgid "Exports vector map to DXF file format."
+msgstr ""
+#: ../vector/v.out.dxf/main.c:68
+msgid "Name for DXF output file"
+msgstr ""
+#: ../vector/v.out.dxf/main.c:93
+#, c-format
+msgid "%d features written to '%s'."
+msgstr ""
+#: ../vector/v.out.dxf/write_dxf.c:21
+#, c-format
+msgid "The file '%s' already exists."
+msgstr ""
+#: ../vector/v.out.dxf/write_dxf.c:23
+#, c-format
+msgid "The file '%s' already exists and will be overwritten."
+msgstr ""
+#: ../vector/v.out.dxf/write_dxf.c:27
+#, c-format
+msgid "%s: Cannot write dxf file."
+msgstr ""
+#: ../vector/v.out.lidar/main.c:77
+#, c-format
+msgid "Database connection not defined for layer <%d>"
+msgstr ""
+#: ../vector/v.out.lidar/main.c:121 ../vector/v.out.lidar/main.c:158
+#: ../vector/v.univar/main.c:358
+msgid "Only numeric column type is supported"
+msgstr ""
+#: ../vector/v.out.lidar/main.c:123
+msgid "Double values will be converted to integers"
+msgstr ""
+#: ../vector/v.out.lidar/main.c:184
+#, c-format
+msgid "No record for cat = %d"
+msgstr ""
+#: ../vector/v.out.lidar/main.c:187
+#, c-format
+msgid "NULL value for cat = %d"
+msgstr ""
+#: ../vector/v.out.lidar/main.c:196
+#, c-format
+msgid "Column type is not numeric (type = %d, cat = %d"
+msgstr ""
+#: ../vector/v.out.lidar/main.c:475
+msgid "Exports vector points as LAS point cloud"
+msgstr ""
+#: ../vector/v.out.lidar/main.c:476
+msgid "Converts LAS LiDAR point clouds to a GRASS vector map with libLAS"
+msgstr ""
+#: ../vector/v.out.lidar/main.c:496 ../vector/v.in.lidar/main.c:151
+msgid "Layer number to store generated point ID as category"
+msgstr ""
+#: ../vector/v.out.lidar/main.c:498 ../vector/v.out.lidar/main.c:505
+#: ../vector/v.out.lidar/main.c:512 ../vector/v.out.lidar/main.c:519
+#: ../vector/v.in.lidar/main.c:154 ../vector/v.in.lidar/main.c:162
+#: ../vector/v.in.lidar/main.c:170 ../vector/v.in.lidar/main.c:178
+msgid "Categories"
+msgstr ""
+#: ../vector/v.out.lidar/main.c:503
+msgid "Layer number to store return number as category"
+msgstr ""
+#: ../vector/v.out.lidar/main.c:510 ../vector/v.in.lidar/main.c:167
+msgid "Layer number to store class number as category"
+msgstr ""
+#: ../vector/v.out.lidar/main.c:517
+msgid "Layer number where RGB color is stored as category"
+msgstr ""
+#: ../vector/v.out.lidar/main.c:525 ../vector/v.out.lidar/main.c:531
+#: ../vector/v.out.lidar/main.c:537
+msgid "Column with return number"
+msgstr ""
+#: ../vector/v.out.lidar/main.c:527 ../vector/v.out.lidar/main.c:533
+#: ../vector/v.out.lidar/main.c:539 ../vector/v.out.lidar/main.c:546
+#: ../vector/v.out.lidar/main.c:552 ../vector/v.out.lidar/main.c:558
+#: ../vector/v.out.lidar/main.c:564 ../vector/v.net.centrality/main.c:149
+#: ../vector/v.net.centrality/main.c:155 ../vector/v.net.centrality/main.c:161
+#: ../vector/v.net.centrality/main.c:167
+msgid "Columns"
+msgstr ""
+#: ../vector/v.out.lidar/main.c:543
+msgid "RGB color definition column"
+msgstr ""
+#: ../vector/v.out.lidar/main.c:550
+msgid "Column with red color"
+msgstr ""
+#: ../vector/v.out.lidar/main.c:556
+msgid "Column with green color"
+msgstr ""
+#: ../vector/v.out.lidar/main.c:562
+msgid "Column with blue color"
+msgstr ""
+#: ../vector/v.out.lidar/main.c:571
+msgid "Internal scale to apply to X and Y values"
+msgstr ""
+#: ../vector/v.out.lidar/main.c:572 ../vector/v.out.lidar/main.c:582
+msgid "This scale does not change the values itself but only how precisely they are stored, for example 0.01 will preserve two decimal places"
+msgstr ""
+#: ../vector/v.out.lidar/main.c:581
+msgid "Internal scale to apply to z values"
+msgstr ""
+#: ../vector/v.out.lidar/main.c:589
+msgid "Limit export to the current region"
+msgstr ""
+#: ../vector/v.out.lidar/main.c:593
+msgid "Ignore color table"
+msgstr ""
+#: ../vector/v.out.lidar/main.c:595
+msgid "Ignore color table even when set and not other options are present"
+msgstr ""
+#: ../vector/v.proj/main.c:72
+msgid "Re-projects a vector map from one location to the current location."
+msgstr ""
+#: ../vector/v.proj/main.c:78
+msgid "Location containing input vector map"
+msgstr ""
+#: ../vector/v.proj/main.c:82
+msgid "Mapset containing input vector map"
+msgstr ""
+#: ../vector/v.proj/main.c:88
+msgid "Name of input vector map to re-project"
+msgstr ""
+#: ../vector/v.proj/main.c:100
+msgid "Maximum segment length in meters in output vector map"
+msgstr ""
+#: ../vector/v.proj/main.c:101
+msgid "Increases accuracy of reprojected shapes, disable with smax=0"
+msgstr ""
+#: ../vector/v.proj/main.c:111
+msgid "List vector maps in input mapset and exit"
+msgstr ""
+#: ../vector/v.proj/main.c:115
+msgid "3D vector maps only"
+msgstr ""
+#: ../vector/v.proj/main.c:117
+msgid "Assume z coordinate is ellipsoidal height and transform if possible"
+msgstr ""
+#: ../vector/v.proj/main.c:123
+msgid "Latlon output only, default is -180,180"
+msgstr ""
+#: ../vector/v.proj/main.c:125
+msgid "Disable wrapping to -180,180 for latlon output"
+msgstr ""
+#: ../vector/v.proj/main.c:131
+msgid "Recommended for massive point projection"
+msgstr ""
+#: ../vector/v.proj/main.c:200
+msgid "No vector maps found"
+msgstr ""
+#: ../vector/v.proj/main.c:213
+#, c-format
+msgid "Vector map <%s> in location <%s> mapset <%s> not found"
+msgstr ""
+#: ../vector/v.proj/main.c:243
+#, c-format
+msgid "Mapset <%s> in input location <%s> - permission denied"
+msgstr ""
+#: ../vector/v.proj/main.c:246
+#, c-format
+msgid "Mapset <%s> in input location <%s> not found"
+msgstr ""
+#: ../vector/v.proj/main.c:291 ../vector/v.proj/main.c:417
+#: ../vector/v.rectify/main.c:235
+msgid "Reading input vector map"
+msgstr ""
+#: ../vector/v.proj/main.c:314
+#, c-format
+msgid "Input vector map <%s> is empty"
+msgstr ""
+#: ../vector/v.proj/main.c:322 ../vector/v.proj/main.c:333
+#: ../vector/v.proj/main.c:348 ../vector/v.proj/main.c:363
+msgid "Error in pj_do_transform"
+msgstr ""
+#: ../vector/v.proj/main.c:408
+msgid "Reprojecting primitives ..."
+msgstr ""
+#: ../vector/v.proj/main.c:445 ../vector/v.proj/main.c:452
+#: ../vector/v.proj/main.c:478 ../vector/v.proj/main.c:492
+#, c-format
+msgid "Unable to re-project vector map <%s> from <%s>"
+msgstr ""
+#: ../vector/v.proj/main.c:503 ../vector/v.build.polylines/main.c:241
+#: ../vector/v.type/main.c:155 ../vector/v.rectify/main.c:278
+#: ../vector/v.category/main.c:763 ../vector/v.net/main.c:158
+#: ../vector/v.transform/main.c:304
+msgid "Failed to copy attribute table to output map"
+msgstr ""
+#: ../vector/v.proj/main.c:512
+msgid "Try to disable wrapping to -180,180 if topological errors occurred"
+msgstr ""
+#: ../vector/v.db.connect/main.c:55 ../vector/v.category/main.c:77
+msgid "layer"
+msgstr ""
+#: ../vector/v.db.connect/main.c:57
+msgid "Prints/sets DB connection for a vector map to attribute table."
+msgstr ""
+#: ../vector/v.db.connect/main.c:79
+msgid "Format: layer number[/layer name]"
+msgstr ""
+#: ../vector/v.db.connect/main.c:83
+msgid "Field separator for shell script style output"
+msgstr ""
+#: ../vector/v.db.connect/main.c:88
+msgid "Print all map connection parameters and exit"
+msgstr ""
+#: ../vector/v.db.connect/main.c:93
+msgid "Print all map connection parameters in shell script style and exit"
+msgstr ""
+#: ../vector/v.db.connect/main.c:95
+msgid "Format: layer[/layer name] table key database driver"
+msgstr ""
+#: ../vector/v.db.connect/main.c:101
+msgid "Print types/names of table columns for specified layer and exit"
+msgstr ""
+#: ../vector/v.db.connect/main.c:108
+msgid "Overwrite connection parameter for certain layer"
+msgstr ""
+#: ../vector/v.db.connect/main.c:113
+msgid "Delete connection for certain layer (not the table)"
+msgstr ""
+#: ../vector/v.db.connect/main.c:149
+msgid "Please choose only one print style"
+msgstr ""
+#: ../vector/v.db.connect/main.c:166
+#, c-format
+msgid "Map <%s> is not connected to a database"
+msgstr ""
+#: ../vector/v.db.connect/main.c:175
+#, c-format
+msgid "Vector map <%s> is connected by:\n"
+msgstr ""
+#: ../vector/v.db.connect/main.c:197
+#, c-format
+msgid "layer <%d/%s> table <%s> in database <%s> through driver <%s> with key <%s>\n"
+msgstr ""
+#: ../vector/v.db.connect/main.c:203
+#, c-format
+msgid "layer <%d> table <%s> in database <%s> through driver <%s> with key <%s>\n"
+msgstr ""
+#: ../vector/v.db.connect/main.c:266
+#, c-format
+msgid "Use -o to overwrite existing link for layer <%d>"
+msgstr ""
+#: ../vector/v.db.connect/main.c:274 ../vector/v.db.connect/main.c:314
+#, c-format
+msgid "Table <%s> does not exist in database <%s>"
+msgstr ""
+#: ../vector/v.db.connect/main.c:295 ../vector/v.in.db/main.c:190
+msgid "Data type of key column must be integer"
+msgstr ""
+#: ../vector/v.db.connect/main.c:302 ../vector/v.db.connect/main.c:320
+#, c-format
+msgid "The table <%s> is now part of vector map <%s> and may be deleted or overwritten by GRASS modules"
+msgstr ""
+#: ../vector/v.db.connect/main.c:351
+msgid "For defining a new connection you have to specify these parameters: driver, database, table [, key [, layer]]"
+msgstr ""
+#: ../vector/v.to.rast3/main.c:51
+msgid "Converts a vector map (only points) into a 3D raster map."
+msgstr ""
+#: ../vector/v.to.rast3/main.c:62
+msgid "Name of attribute column (data type must be numeric)"
+msgstr ""
+#: ../vector/v.to.rast3/main.c:107
+msgid "Unable to create output map"
+msgstr ""
+#: ../vector/v.to.rast3/main.c:157
+msgid "Unable to close new 3d raster map"
+msgstr ""
+#: ../vector/v.out.ascii/main.c:51
+msgid "Exports a vector map to a GRASS ASCII vector representation."
+msgstr ""
+#: ../vector/v.out.ascii/main.c:52
+msgid "By default only features with category are exported. To export all features use 'layer=-1'."
+msgstr ""
+#: ../vector/v.out.ascii/main.c:60
+#, c-format
+msgid "Parameter '%s' ignored in standard mode"
+msgstr ""
+#: ../vector/v.out.ascii/main.c:69
+#, c-format
+msgid "Format '%s' is not supported for old version"
+msgstr ""
+#: ../vector/v.out.ascii/main.c:73
+#, c-format
+msgid "Parameter '%s' must be given for old version"
+msgstr ""
+#: ../vector/v.out.ascii/main.c:80
+#, c-format
+msgid "Unable to open vector map <%s> at topology level. Areas will not be processed."
+msgstr ""
+#: ../vector/v.out.ascii/main.c:104 ../vector/v.surf.rst/main.c:570
+#: ../vector/v.colors/main.c:270 ../vector/v.colors.out/scan_cats.c:24
+#: ../vector/v.colors.out/make_colors.c:27
+#, c-format
+msgid "Layer <%s> not found"
+msgstr ""
+#: ../vector/v.out.ascii/main.c:107
+#, c-format
+msgid "%d error in <%s> option"
+msgid_plural "%d errors in <%s> option"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.out.ascii/main.c:141
+msgid "dig_att file already exist"
+msgstr ""
+#: ../vector/v.out.ascii/main.c:144
+#, c-format
+msgid "Unable to open dig_att file <%s>"
+msgstr ""
+#: ../vector/v.out.ascii/main.c:149
+msgid "Fetching data..."
+msgstr ""
+#: ../vector/v.out.ascii/main.c:156
+msgid "No points found, nothing to be exported"
+msgstr ""
+#: ../vector/v.out.ascii/main.c:159
+msgid "No features found, nothing to be exported"
+msgstr ""
+#: ../vector/v.out.ascii/main.c:163
+msgid "An error occurred, nothing to be exported"
+msgstr ""
+#: ../vector/v.out.ascii/args.c:31
+msgid "Name for output ASCII file or ASCII vector name if '-o' is defined"
+msgstr ""
+#: ../vector/v.out.ascii/args.c:38
+msgid "Name of attribute column(s) to be exported (point mode)"
+msgstr ""
+#: ../vector/v.out.ascii/args.c:39
+msgid "\"*\" for all columns"
+msgstr ""
+#: ../vector/v.out.ascii/args.c:59
+msgid "Simple point format (point per row)"
+msgstr ""
+#: ../vector/v.out.ascii/args.c:60
+msgid "GRASS ASCII vector format"
+msgstr ""
+#: ../vector/v.out.ascii/args.c:61
+msgid "OGC well-known text"
+msgstr ""
+#: ../vector/v.out.ascii/args.c:65
+msgid "Field separator (points mode)"
+msgstr ""
+#: ../vector/v.out.ascii/args.c:80
+msgid "Create old (version 4) ASCII file"
+msgstr ""
+#: ../vector/v.out.ascii/args.c:85
+msgid "Include column names in output (points mode)"
+msgstr ""
+#: ../vector/v.out.ascii/args.c:91
+msgid "Only export points falling within current 3D region (points mode)"
+msgstr ""
+#: ../vector/v.cluster/main.c:91
+msgid "point cloud"
+msgstr ""
+#: ../vector/v.cluster/main.c:92
+msgid "cluster"
+msgstr ""
+#: ../vector/v.cluster/main.c:93
+msgid "clump"
+msgstr ""
+#: ../vector/v.cluster/main.c:96
+msgid "Performs cluster identification."
+msgstr ""
+#: ../vector/v.cluster/main.c:104
+msgid "Layer number or name for cluster ids"
+msgstr ""
+#: ../vector/v.cluster/main.c:111
+msgid "Maximum distance to neighbors"
+msgstr ""
+#: ../vector/v.cluster/main.c:117
+msgid "Minimum number of points to create a cluster"
+msgstr ""
+#: ../vector/v.cluster/main.c:125
+msgid "Clustering method"
+msgstr ""
+#: ../vector/v.cluster/main.c:129
+msgid "Force 2D clustering"
+msgstr ""
+#: ../vector/v.cluster/main.c:167
+msgid "Minimum number of points must be at least 2"
+msgstr ""
+#: ../vector/v.cluster/main.c:175 ../vector/v.to.points/main.c:113
+#, c-format
+msgid "Option %s must be positive"
+msgstr ""
+#: ../vector/v.cluster/main.c:188
+msgid "Counting input points ..."
+msgstr ""
+#: ../vector/v.cluster/main.c:194
+#, c-format
+msgid "Layer %d is not empty, choose another layer"
+msgstr ""
+#: ../vector/v.cluster/main.c:201
+msgid "Not enough points in input, nothing to do"
+msgstr ""
+#: ../vector/v.cluster/main.c:218
+msgid "Creating search index ..."
+msgstr ""
+#: ../vector/v.cluster/main.c:253 ../vector/v.cluster/main.c:458
+#: ../vector/v.cluster/main.c:708
+#, c-format
+msgid "Option %s must be a positive number"
+msgstr ""
+#: ../vector/v.cluster/main.c:262 ../vector/v.cluster/main.c:467
+msgid "Estimating maximum distance ..."
+msgstr ""
+#: ../vector/v.cluster/main.c:293 ../vector/v.cluster/main.c:498
+msgid "No neighbors found"
+msgstr ""
+#: ../vector/v.cluster/main.c:303 ../vector/v.cluster/main.c:508
+#, c-format
+msgid "Distance to the %d nearest neighbor:"
+msgstr ""
+#: ../vector/v.cluster/main.c:304 ../vector/v.cluster/main.c:509
+#, c-format
+msgid "Min: %g, max: %g"
+msgstr ""
+#: ../vector/v.cluster/main.c:305 ../vector/v.cluster/main.c:510
+#, c-format
+msgid "Mean: %g"
+msgstr ""
+#: ../vector/v.cluster/main.c:306 ../vector/v.cluster/main.c:511
+#, c-format
+msgid "Standard deviation: %g"
+msgstr ""
+#: ../vector/v.cluster/main.c:308 ../vector/v.cluster/main.c:513
+#, c-format
+msgid "Estimated maximum distance: %g"
+msgstr ""
+#: ../vector/v.cluster/main.c:312 ../vector/v.cluster/main.c:517
+#: ../vector/v.cluster/main.c:930 ../vector/v.cluster/main.c:1091
+msgid "Building clusters ..."
+msgstr ""
+#: ../vector/v.cluster/main.c:354 ../vector/v.cluster/main.c:562
+#, c-format
+msgid "nlines: %d, nclusters: %d"
+msgstr ""
+#: ../vector/v.cluster/main.c:398 ../vector/v.cluster/main.c:607
+#, c-format
+msgid "No clusters found, adjust option %s"
+msgstr ""
+#: ../vector/v.cluster/main.c:434 ../vector/v.cluster/main.c:649
+#: ../vector/v.cluster/main.c:828 ../vector/v.cluster/main.c:1000
+#: ../vector/v.cluster/main.c:1154
+msgid "Write out cluster ids ..."
+msgstr ""
+#: ../vector/v.cluster/main.c:712
+msgid "Loading points ..."
+msgstr ""
+#: ../vector/v.cluster/main.c:736 ../vector/v.cluster/main.c:880
+msgid "Reachability network ..."
+msgstr ""
+#: ../vector/v.cluster/main.c:748 ../vector/v.cluster/main.c:781
+#: ../vector/v.cluster/main.c:890 ../vector/v.cluster/main.c:1068
+#: ../vector/v.cluster/main.c:1102 ../vector/v.cluster/main.c:1139
+msgid "Not enough points found"
+msgstr ""
+#: ../vector/v.cluster/main.c:809
+msgid "Set cluster ids ..."
+msgstr ""
+#: ../vector/v.cluster/main.c:911
+msgid "Neighbor point's core dist is -1"
+msgstr ""
+#: ../vector/v.cluster/main.c:1056
+msgid "Core density ..."
+msgstr ""
+#: ../vector/v.cluster/main.c:1180
+#, c-format
+msgid "%d clusters found"
+msgstr ""
+#: ../vector/v.cluster/main.c:1181
+#, c-format
+msgid "%d outliers found"
+msgstr ""
+#: ../vector/v.in.lidar/vector_mask.c:20
+#, c-format
+msgid "Failed to open vector <%s>"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:48
+#, c-format
+msgid "Values of %s and %s are the same. All categories would be stored only in layer number <%d>"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:141
+msgid "Converts LAS LiDAR point clouds to a GRASS vector map with libLAS."
+msgstr ""
+#: ../vector/v.in.lidar/main.c:152
+msgid "Set to 1 by default, use -c to not store it"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:159
+msgid "Layer number to store return information as category"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:160 ../vector/v.in.lidar/main.c:168
+#: ../vector/v.in.lidar/main.c:176
+msgid "Leave empty to not store it"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:175
+msgid "Layer number where RBG colors are stored as category"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:186 ../vector/v.in.ogr/main.c:237
+msgid "Import subregion only"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:189 ../vector/v.in.ogr/main.c:240
+msgid "Format: xmin,ymin,xmax,ymax - usually W,S,E,N"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:221
+msgid "Areas where to import points"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:222
+msgid "Name of vector map with areas where the points should be imported"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:227
+msgid "Layer number or name for mask option"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:235
+msgid "Do not import every n-th point"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:236
+msgid "For example, 5 will import 80 percent of points. If not specified, all points are imported"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:238 ../vector/v.in.lidar/main.c:248
+#: ../vector/v.in.lidar/main.c:257 ../vector/v.in.lidar/main.c:266
+msgid "Decimation"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:245
+msgid "Import only every n-th point"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:246
+msgid "For example, 4 will import 25 percent of points. If not specified, all points are imported"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:255 ../vector/v.decimate/main.c:183
+msgid "Skip first n points"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:256 ../vector/v.decimate/main.c:185
+msgid "Skips the given number of points at the beginning."
+msgstr ""
+#: ../vector/v.in.lidar/main.c:264
+msgid "Import only n points"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:265
+msgid "Imports only the given number of points"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:288
+msgid "Invert mask when selecting points"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:305 ../vector/v.in.lidar/main.c:313
+#: ../vector/v.in.lidar/main.c:316 ../vector/v.decimate/main.c:243
+#: ../vector/v.decimate/main.c:246
+msgid "Speed"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:310
+msgid "Do not automatically add unique ID as category to each point"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:312
+msgid "Create only requested layers and categories"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:328 ../vector/v.in.ogr/main.c:380
+msgid "Create the location specified by the \"location\" parameter and exit. Do not import the vector data."
+msgstr ""
+#: ../vector/v.in.lidar/main.c:354
+#, c-format
+msgid "Unable to open file <%s> as a LiDAR point cloud. %s"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:415
+#, c-format
+msgid "-%c flag is not set but ID layer is not specified"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:416
+msgid "ID layer is required to store attribute table"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:425
+#, c-format
+msgid "Storing generated point IDs as categories in the layer <%d>, consequently no more than %d points can be imported"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:435 ../vector/v.in.pdal/filters.c:68
+#: ../vector/v.decimate/main.c:294
+#, c-format
+msgid "Invalid zrange <%s>"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:450 ../vector/v.in.ogr/main.c:703
+#: ../vector/v.in.ogr/main.c:2126
+msgid "Select either the current region flag or the spatial option, not both"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:478 ../vector/v.in.ogr/main.c:2153
+msgid "4 parameters required for 'spatial' parameter"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:542 ../scripts/v.unpack/v.unpack.py:119
+#, c-format, python-format
+msgid "Vector map <%s> already exists and will be overwritten"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:545 ../vector/v.in.ogr/main.c:674
+#: ../vector/v.edit/main.c:99 ../scripts/v.unpack/v.unpack.py:117
+msgid "Vector map <%s> already exists"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:605 ../vector/v.decimate/main.c:344
+msgid "Settings for count-based decimation are not valid"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:609
+#, c-format
+msgid "Scanning %llu points..."
+msgstr ""
+#: ../vector/v.in.lidar/main.c:611
+#, c-format
+msgid "Scanning %lu points..."
+msgstr ""
+#: ../vector/v.in.lidar/main.c:746
+msgid "The underlying libLAS library is at its limits. Previously reported counts might have been distorted. However, the import itself should be unaffected."
+msgstr ""
+#: ../vector/v.in.lidar/main.c:752
+#, c-format
+msgid "%llu points imported (limit was %llu)"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:757
+#, c-format
+msgid "%llu points imported"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:760
+#, c-format
+msgid "%llu input points were not valid and filtered out"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:762
+#, c-format
+msgid "%llu input points were outside of the selected area"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:764
+#, c-format
+msgid "%llu input points were outside of the area specified by mask"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:766
+#, c-format
+msgid "%llu input points were filtered out by return number"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:768
+#, c-format
+msgid "%llu input points were filtered out by class number"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:770
+#, c-format
+msgid "%llu input points were filtered outsite the range for z coordinate"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:772
+#, c-format
+msgid "%llu input points were skipped at the begging using offset"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:775
+#, c-format
+msgid "%llu input points were skipped by count-based decimation"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:779
+#, c-format
+msgid "%lu points imported (limit was %d)"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:783
+#, c-format
+msgid "%lu points imported"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:787
+#, c-format
+msgid "%lu input points were outside of the selected area"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:789
+#, c-format
+msgid "%lu input points were outside of the area specified by mask"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:795
+#, c-format
+msgid "%lu input points were filtered outsite the range for z coordinate"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:797
+#, c-format
+msgid "%lu input points were skipped at the begging using offset"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:800
+#, c-format
+msgid "%lu input points were skipped by count-based decimation"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:802
+msgid "Accuracy of the printed point counts might be limited by your computer architecture."
+msgstr ""
+#: ../vector/v.in.lidar/main.c:805
+msgid "The rest of points was ignored"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:809
+#, c-format
+msgid "%llu input points were not valid, use -%c flag to filter them out"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:818
+#, c-format
+msgid "Maximum number of categories reached (%d). Import ended prematurely. Try to import without using category as an ID."
+msgstr ""
+#: ../vector/v.in.lidar/attributes.c:129
+#, c-format
+msgid "Unable open database <%s> by driver <%s>"
+msgstr ""
+#: ../vector/v.build.polylines/main.c:114 ../vector/v.segment/main.c:62
+#: ../vector/v.to.points/main.c:57 ../vector/v.split/main.c:57
+#: ../vector/v.edit/main.c:58
+msgid "node"
+msgstr ""
+#: ../vector/v.build.polylines/main.c:115 ../vector/v.segment/main.c:65
+#: ../vector/v.to.points/main.c:58 ../vector/v.split/main.c:59
+#: ../vector/v.edit/main.c:60
+msgid "vertex"
+msgstr ""
+#: ../vector/v.build.polylines/main.c:116
+msgid "Builds polylines from lines or boundaries."
+msgstr ""
+#: ../vector/v.build.polylines/main.c:126
+msgid "Category number mode"
+msgstr ""
+#: ../vector/v.build.polylines/main.c:131
+msgid "Do not assign any category number to polyline"
+msgstr ""
+#: ../vector/v.build.polylines/main.c:132
+msgid "Assign category number of first line to polyline"
+msgstr ""
+#: ../vector/v.build.polylines/main.c:133
+msgid "Assign multiple category numbers to polyline"
+msgstr ""
+#: ../vector/v.build.polylines/main.c:134
+msgid "Create polyline from lines with same categories"
+msgstr ""
+#: ../vector/v.build.polylines/main.c:231
+#, c-format
+msgid "%d line or boundaries found in input vector map"
+msgid_plural "%d lines or boundaries found in input vector map"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.build.polylines/main.c:234
+#, c-format
+msgid "%d polyline stored in output vector map"
+msgid_plural "%d polylines stored in output vector map"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.lidar.correction/main.c:74
+msgid "Corrects the v.lidar.growing output. It is the last of the three algorithms for LIDAR filtering."
+msgstr ""
+#: ../vector/v.lidar.correction/main.c:85
+msgid "Input observation vector map name (v.lidar.growing output)"
+msgstr ""
+#: ../vector/v.lidar.correction/main.c:88
+msgid "Output classified vector map name"
+msgstr ""
+#: ../vector/v.lidar.correction/main.c:93
+msgid "Name for output only 'terrain' points vector map"
+msgstr ""
+#: ../vector/v.lidar.correction/main.c:101
+msgid "Default: 25 * east-west resolution"
+msgstr ""
+#: ../vector/v.lidar.correction/main.c:110
+msgid "Default: 25 * north-south resolution"
+msgstr ""
+#: ../vector/v.lidar.correction/main.c:118
+msgid "Regularization weight in reclassification evaluation"
+msgstr ""
+#: ../vector/v.lidar.correction/main.c:126
+msgid "High threshold for object to terrain reclassification"
+msgstr ""
+#: ../vector/v.lidar.correction/main.c:134
+msgid "Low threshold for terrain to object reclassification"
+msgstr ""
+#: ../vector/v.lidar.correction/main.c:278
+#, c-format
+msgid "Adjusted EW spline %d"
+msgid_plural "Adjusted EW splines %d"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.lidar.correction/main.c:281
+#, c-format
+msgid "Adjusted NS spline %d"
+msgid_plural "Adjusted NS splines %d"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.lidar.correction/main.c:376
+msgid "Performing mean calculation..."
+msgstr ""
+#: ../vector/v.lidar.correction/main.c:420
+msgid "Correction and creation of terrain vector map..."
+msgstr ""
+#: ../vector/v.lidar.correction/correction.c:93
+#: ../vector/v.lidar.correction/correction.c:127
+#: ../vector/v.lidar.correction/correction.c:151
+#: ../vector/v.lidar.correction/correction.c:163
+#: ../vector/v.lidar.correction/correction.c:187
+#: ../vector/v.outlier/outlier.c:86 ../vector/v.outlier/outlier.c:123
+#: ../vector/v.outlier/outlier.c:148 ../vector/v.outlier/outlier.c:161
+#: ../vector/v.outlier/outlier.c:185
+msgid "Impossible to read the database"
+msgstr ""
+#: ../vector/v.lidar.correction/correction.c:97
+#: ../vector/v.lidar.correction/correction.c:155
+#: ../vector/v.outlier/outlier.c:90 ../vector/v.outlier/outlier.c:152
+msgid "Impossible to update the database"
+msgstr ""
+#: ../vector/v.lidar.correction/correction.c:107
+#: ../vector/v.lidar.correction/correction.c:115
+#: ../vector/v.lidar.correction/correction.c:210
+#: ../vector/v.outlier/outlier.c:101 ../vector/v.outlier/outlier.c:110
+#: ../vector/v.outlier/outlier.c:207
+msgid "Impossible to write in the database"
+msgstr ""
+#: ../vector/v.reclass/main.c:69
+msgid "attributes"
+msgstr ""
+#: ../vector/v.reclass/main.c:71
+msgid "Changes vector category values for an existing vector map according to results of SQL queries or a value in attribute table column."
+msgstr ""
+#: ../vector/v.reclass/main.c:88
+msgid "The name of the column whose values are to be used as new categories"
+msgstr ""
+#: ../vector/v.reclass/main.c:89
+msgid "The source for the new key column must be type integer or string"
+msgstr ""
+#: ../vector/v.reclass/main.c:94
+msgid "Full path to the reclass rule file"
+msgstr ""
+#: ../vector/v.reclass/main.c:104
+#, c-format
+msgid "Either '%s' or '%s' must be specified"
+msgstr ""
+#: ../vector/v.reclass/main.c:254
+msgid "Key column type is not integer"
+msgstr ""
+#: ../vector/v.reclass/main.c:267 ../vector/v.db.select/main.c:229
+#, c-format
+msgid "Unable to fetch data from table <%s>"
+msgstr ""
+#: ../vector/v.reclass/main.c:298
+#, c-format
+msgid "Cannot insert data: [%s]"
+msgstr ""
+#: ../vector/v.reclass/main.c:336
+msgid "Column type must be integer or string"
+msgstr ""
+#: ../vector/v.reclass/main.c:348
+#, c-format
+msgid "Unable to open rule file <%s>"
+msgstr ""
+#: ../vector/v.reclass/main.c:364
+#, c-format
+msgid "Category %d overwritten by '%s'"
+msgstr ""
+#: ../vector/v.reclass/main.c:368
+#, c-format
+msgid "Category '%s' invalid"
+msgstr ""
+#: ../vector/v.reclass/main.c:372
+#, c-format
+msgid "Label '%s' overwritten by '%s'"
+msgstr ""
+#: ../vector/v.reclass/main.c:378
+#, c-format
+msgid "Condition '%s' overwritten by '%s'"
+msgstr ""
+#: ../vector/v.reclass/main.c:383
+#, c-format
+msgid "Unknown rule option: '%s'"
+msgstr ""
+#: ../vector/v.reclass/main.c:397
+msgid "Cannot select values from database"
+msgstr ""
+#: ../vector/v.reclass/main.c:413
+#, c-format
+msgid "%d previously set categories overwritten by new category %d"
+msgstr ""
+#: ../vector/v.reclass/main.c:439
+msgid "Incomplete rule"
+msgstr ""
+#: ../vector/v.reclass/main.c:475
+#, c-format
+msgid "%d features reclassed."
+msgstr ""
+#: ../vector/v.segment/main.c:64 ../vector/v.split/main.c:58
+msgid "segment"
+msgstr ""
+#: ../vector/v.segment/main.c:67
+msgid "Creates points/segments from input vector lines and positions."
+msgstr ""
+#: ../vector/v.segment/main.c:70
+msgid "Name of input vector lines map"
+msgstr ""
+#: ../vector/v.segment/main.c:79
+msgid "Name of file containing segment rules"
+msgstr ""
+#: ../vector/v.segment/main.c:146 ../vector/v.segment/main.c:190
+#, c-format
+msgid "Unable to read input: %s"
+msgstr ""
+#: ../vector/v.segment/main.c:157 ../vector/v.segment/main.c:201
+#, c-format
+msgid "Unable to find line of cat %d"
+msgstr ""
+#: ../vector/v.segment/main.c:172
+#, c-format
+msgid ""
+"Unable to get point on line: cat = %d offset = %f (line length = %.15g)\n"
+"%s"
+msgstr ""
+#: ../vector/v.segment/main.c:226
+msgid "End of segment > line length -> cut"
+msgstr ""
+#: ../vector/v.segment/main.c:232
+#, c-format
+msgid ""
+"Unable to make line segment: cat = %d : %f - %f (line length = %.15g)\n"
+"%s"
+msgstr ""
+#: ../vector/v.segment/main.c:256 ../vector/v.lrs/v.lrs.segment/main.c:337
+#, c-format
+msgid "Incorrect segment type: %s"
+msgstr ""
+#: ../vector/v.segment/main.c:263
+#, c-format
+msgid "%d point read from input"
+msgid_plural "%d points read from input"
+msgstr[0] ""
+msgstr[1] ""
+#. GTC Number of lost points
+#. GTC Number of lost lines
+#: ../vector/v.segment/main.c:267 ../vector/v.segment/main.c:278
+#: ../vector/v.lrs/v.lrs.segment/main.c:360
+#: ../vector/v.lrs/v.lrs.segment/main.c:372
+#, c-format
+msgid "%d lost"
+msgid_plural "%d lost"
+msgstr[0] ""
+msgstr[1] ""
+#. GTC %s is replaced with message indicating number of lost points.
+#: ../vector/v.segment/main.c:269
+#, c-format
+msgid "%d point written to output map (%s)"
+msgid_plural "%d points written to output map (%s)"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.segment/main.c:274
+#, c-format
+msgid "%d line read from input"
+msgid_plural "%d lines read from input"
+msgstr[0] ""
+msgstr[1] ""
+#. GTC %s is replaced with message indicating number of lost lines.
+#: ../vector/v.segment/main.c:280
+#, c-format
+msgid "%d line written to output map (%s)"
+msgid_plural "%d lines written to output map (%s)"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.surf.rst/main.c:150 ../vector/v.drape/main.c:59
+#: ../vector/v.extrude/main.c:70 ../vector/v.hull/main.c:54
+#: ../vector/v.to.3d/main.c:38 ../vector/v.out.postgis/main.c:49
+msgid "3D"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:151
+msgid "Performs surface interpolation from vector points map by splines."
+msgstr ""
+#: ../vector/v.surf.rst/main.c:153
+msgid "Spatial approximation and topographic analysis from given point or isoline data in vector format to floating point raster format using regularized spline with tension."
+msgstr ""
+#: ../vector/v.surf.rst/main.c:160
+msgid "Perform cross-validation procedure without raster approximation"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:165
+msgid "Use scale dependent tension"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:184 ../vector/v.surf.bspline/main.c:118
+msgid "Name of the attribute column with values to be used for approximation"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:195
+msgid "Name for output surface elevation raster map"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:225
+msgid "Name for output mean curvature raster map"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:231 ../vector/v.vol.rst/main.c:290
+msgid "Name for output deviations vector point map"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:238 ../vector/v.vol.rst/main.c:296
+msgid "Name for output cross-validation errors vector point map"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:245
+msgid "Name for output vector map showing quadtree segmentation"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:252
+msgid "Name for output vector map showing overlapping windows"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:261
+msgid "Number of threads for parallel computing"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:267
+msgid "Name of raster map used as mask"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:275 ../vector/v.vol.rst/main.c:267
+msgid "Tension parameter"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:282 ../vector/v.vol.rst/main.c:275
+msgid "Smoothing parameter"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:290
+msgid "Name of the attribute column with smoothing parameters"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:315 ../vector/v.vol.rst/main.c:336
+msgid "Minimum distance between points (to remove almost identical points)"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:323
+msgid "Maximum distance between points on isoline (to insert additional points)"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:332
+msgid "Conversion factor for values used for approximation"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:409
+msgid "Parallel computation disabled when deviation output is required"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:416
+msgid "GRASS GIS is not compiled with OpenMP support, parallel computation is disabled."
+msgstr ""
+#: ../vector/v.surf.rst/main.c:421 ../vector/v.surf.rst/main.c:426
+#: ../vector/v.surf.rst/main.c:431 ../vector/v.surf.rst/main.c:436
+#, c-format
+msgid "Output vector map name <%s> is not valid map name"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:449
+msgid "You are not outputting any raster or vector maps"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:458
+msgid "Both cross-validation options (-c flag and cvdev vector output) must be specified"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:461
+msgid "The cross-validation cannot be computed simultaneously with output raster or devi file"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:479
+msgid "Using anisotropy - both theta and scalex have to be specified"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:487
+msgid "Both smatt and smooth options specified - using constant"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:497
+msgid "The computation will last too long - lower npmin is suggested"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:515 ../vector/v.surf.rst/main.c:520
+#: ../vector/v.surf.rst/main.c:524 ../vector/v.surf.rst/main.c:529
+#: ../vector/v.surf.rst/main.c:533 ../vector/v.surf.rst/main.c:537
+#: ../vector/v.vol.rst/main.c:507 ../vector/v.vol.rst/main.c:510
+#: ../vector/v.vol.rst/main.c:513 ../vector/v.vol.rst/main.c:516
+#: ../vector/v.vol.rst/main.c:519 ../vector/v.vol.rst/main.c:522
+#: ../vector/v.vol.rst/main.c:525 ../vector/v.vol.rst/main.c:528
+#: ../vector/v.vol.rst/main.c:531 ../vector/v.vol.rst/main.c:534
+#: ../vector/v.vol.rst/main.c:621 ../vector/v.vol.rst/main.c:652
+#: ../vector/v.vol.rst/main.c:674 ../vector/v.vol.rst/main.c:696
+#: ../vector/v.vol.rst/main.c:718 ../vector/v.vol.rst/main.c:740
+#: ../vector/v.vol.rst/main.c:762 ../vector/v.vol.rst/main.c:784
+#: ../vector/v.vol.rst/user3.c:273 ../vector/v.vol.rst/user3.c:279
+#: ../vector/v.vol.rst/user3.c:285 ../vector/v.vol.rst/user2.c:122
+#: ../vector/v.vol.rst/user2.c:232
+#, c-format
+msgid "Not enough memory for %s"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:544 ../vector/v.surf.rst/main.c:550
+#: ../vector/v.surf.rst/main.c:553 ../vector/v.surf.rst/main.c:557
+#: ../vector/v.vol.rst/main.c:539 ../vector/v.vol.rst/main.c:544
+#: ../vector/v.vol.rst/main.c:546
+#, c-format
+msgid "Unable to create %s"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:574 ../vector/v.surf.bspline/main.c:277
+msgid "Input is 3D: using attribute values instead of z-coordinates for approximation"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:576 ../vector/v.surf.bspline/main.c:279
+msgid "Input is 3D: using z-coordinates for approximation"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:580
+msgid "Input is 2D: using attribute values for approximation"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:582
+msgid "Input is 2D: using category values for approximation"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:625 ../vector/v.vol.rst/main.c:605
+#, c-format
+msgid "Unable to create table '%s'"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:695
+#, c-format
+msgid "Processing all selected output files will require %d bytes of disk space for temp files"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:716
+msgid "Processing segments in parallel..."
+msgstr ""
+#: ../vector/v.surf.rst/main.c:722 ../vector/v.surf.rst/main.c:731
+msgid "Interp_segmets failed"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:725
+msgid "Processing segments..."
+msgstr ""
+#: ../vector/v.surf.rst/main.c:749
+msgid "Unable to write raster maps - try to increase resolution"
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:96
+msgid "Performs bicubic or bilinear spline interpolation with Tykhonov regularization."
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:105 ../vector/v.outlier/main.c:79
+msgid "Estimate point density and distance"
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:110 ../vector/v.sample/main.c:82
+msgid "Name of input vector point map"
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:119
+msgid "If not given and input is 3D vector map then z-coordinates are used."
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:126
+msgid "Name of input vector map with sparse points"
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:139
+msgid "Raster map to use for masking (applies to raster output only)"
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:207
+msgid "Choose either vector or raster output, not both"
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:210
+msgid "No raster or vector or cross-validation output"
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:231
+msgid "Unable to set default DB connection"
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:236
+msgid "No default DB defined"
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:267 ../vector/v.surf.bspline/main.c:336
+#: ../vector/v.outlier/main.c:205
+#, c-format
+msgid "Unable to open vector map <%s> at the topological level"
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:283
+#, c-format
+msgid "Input vector map is 2D. Parameter <%s> required."
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:295
+#, c-format
+msgid "Estimated point density: %.4g"
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:296
+#, c-format
+msgid "Estimated mean distance between points: %.4g"
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:299
+#, c-format
+msgid "No points in current region"
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:328
+#, c-format
+msgid "Vector map <%s> of sparse points will be interpolated"
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:344
+#, c-format
+msgid "Sorry, the <%s> driver is not compatible with the vector output of this module. Try with raster output or another driver."
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:367
+#, c-format
+msgid "Points in input vector map <%s> will be interpolated"
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:374
+msgid "Reading values from attribute table..."
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:378
+msgid "Cannot read layer info"
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:400 ../vector/v.normal/main.c:135
+#, c-format
+msgid "%d records selected from table"
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:420
+#, c-format
+msgid "Interpolation: Creating table: It was impossible to create table <%s>."
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:437
+#, c-format
+msgid "Cells for raster map <%s> will be interpolated"
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:498
+msgid "Load masking map"
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:626 ../vector/v.outlier/main.c:357
+#, c-format
+msgid "Processing subregion %d of %d..."
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:710
+#, c-format
+msgid "%d points found in this subregion"
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:757
+#, c-format
+msgid "Interpolation: (%d,%d): No record for point (cat = %d)"
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:893 ../vector/v.outlier/main.c:450
+msgid "No data within this subregion. Consider increasing spline step values."
+msgstr ""
+#: ../vector/v.surf.bspline/crosscorr.c:75
+#, c-format
+msgid "%d are too many points. The cross validation would take too much time."
+msgstr ""
+#: ../vector/v.surf.bspline/crosscorr.c:84
+#, c-format
+msgid "%d points read in region"
+msgstr ""
+#: ../vector/v.surf.bspline/crosscorr.c:88
+msgid "Maybe it takes too long. It will depend on how many points you are considering."
+msgstr ""
+#: ../vector/v.surf.bspline/crosscorr.c:119
+#, c-format
+msgid "CrossCorrelation: driver=%s db=%s"
+msgstr ""
+#: ../vector/v.surf.bspline/crosscorr.c:136
+#, c-format
+msgid "No records selected from table <%s> "
+msgstr ""
+#: ../vector/v.in.pdal/projection.c:125
+msgid "Overriding projection check"
+msgstr ""
+#: ../vector/v.in.pdal/filters.c:46
+#, c-format
+msgid "4 values required for '%s' option"
+msgstr ""
+#: ../vector/v.db.select/main.c:58
+msgid "Prints vector map attributes."
+msgstr ""
+#: ../vector/v.db.select/main.c:61 ../vector/v.db.select/main.c:79
+#: ../vector/v.db.select/main.c:93
+msgid "Main"
+msgstr ""
+#: ../vector/v.db.select/main.c:75
+msgid "GROUP BY conditions of SQL statement without 'group by' keyword"
+msgstr ""
+#: ../vector/v.db.select/main.c:83
+msgid "Output vertical record separator"
+msgstr ""
+#: ../vector/v.db.select/main.c:100
+msgid "Print minimal region extent of selected vector features instead of attributes"
+msgstr ""
+#: ../vector/v.db.select/main.c:115
+msgid "Exclude attributes not linked to features"
+msgstr ""
+#: ../vector/v.db.select/main.c:157
+#, c-format
+msgid "Unable to open vector map <%s> at topology level. Flag '%c' requires topology level."
+msgstr ""
+#: ../vector/v.db.select/main.c:208
+msgid "Unable to open select cursor"
+msgstr ""
+#: ../vector/v.db.select/main.c:286
+#, c-format
+msgid "Unable to get bounding box of area %d"
+msgstr ""
+#: ../vector/v.db.select/main.c:292
+#, c-format
+msgid "Unable to get bounding box of line %d"
+msgstr ""
+#: ../vector/v.net.allpairs/main.c:65
+msgid "Computes the shortest path between all pairs of nodes in the network."
+msgstr ""
+#: ../vector/v.net.allpairs/main.c:208
+msgid "Writing node points..."
+msgstr ""
+#: ../vector/v.net.allpairs/main.c:242
+msgid "Collecting shortest paths..."
+msgstr ""
+#: ../vector/v.net.allpairs/main.c:296
+msgid "Writing shortest paths..."
+msgstr ""
+#: ../vector/v.in.dwg/main.c:84
+msgid "Converts DWG/DXF to GRASS vector map"
+msgstr ""
+#: ../vector/v.in.dwg/main.c:87
+msgid "Name of DWG or DXF file"
+msgstr ""
+#: ../vector/v.in.dwg/main.c:97
+msgid "List of layers to import"
+msgstr ""
+#: ../vector/v.in.dwg/main.c:102
+msgid "Invert selection by layers (don't import layers in list)"
+msgstr ""
+#: ../vector/v.in.dwg/main.c:106 ../vector/v.in.ascii/main.c:176
+msgid "Create 3D vector map"
+msgstr ""
+#: ../vector/v.in.dwg/main.c:110
+msgid "Write circles as points (centre)"
+msgstr ""
+#: ../vector/v.in.dwg/main.c:114
+msgid "List available layers and exit"
+msgstr ""
+#: ../vector/v.in.dwg/main.c:118
+msgid "Use numeric type for attribute \"layer\""
+msgstr ""
+#: ../vector/v.in.dwg/main.c:138
+#, c-format
+msgid "Unable to initialize OpenDWG Toolkit, error: %d: %s."
+msgstr ""
+#: ../vector/v.in.dwg/main.c:141
+#, c-format
+msgid "%s Cannot open %s"
+msgstr ""
+#: ../vector/v.in.dwg/main.c:149
+#, c-format
+msgid "Unable to open input file <%s>. Error %d: %s"
+msgstr ""
+#: ../vector/v.in.dwg/main.c:287
+#, c-format
+msgid "%d elements skipped (layer name was not in list)"
+msgstr ""
+#: ../vector/v.in.dwg/main.c:290
+#, c-format
+msgid "%d elements processed"
+msgstr ""
+#: ../vector/v.drape/main.c:62
+msgid "Converts 2D vector features to 3D by sampling of elevation raster map."
+msgstr ""
+#: ../vector/v.drape/main.c:83 ../vector/v.extrude/main.c:124
+msgid "Elevation raster map for height extraction"
+msgstr ""
+#: ../vector/v.drape/main.c:87 ../vector/v.drape/main.c:94
+#: ../vector/v.drape/main.c:101 ../vector/v.extrude/main.c:79
+#: ../vector/v.extrude/main.c:125 ../vector/v.extrude/main.c:129
+#: ../vector/v.extrude/main.c:136 ../vector/v.extrude/main.c:143
+msgid "Elevation"
+msgstr ""
+#: ../vector/v.drape/main.c:92 ../vector/v.extrude/main.c:134
+msgid "Scale factor sampled raster values"
+msgstr ""
+#: ../vector/v.drape/main.c:100 ../vector/v.extrude/main.c:142
+msgid "Height for sampled raster NULL values"
+msgstr ""
+#: ../vector/v.drape/main.c:177 ../vector/v.select/select.c:41
+#: ../vector/v.category/main.c:332
+msgid "Processing features..."
+msgstr ""
+#: ../vector/v.drape/main.c:199
+#, c-format
+msgid "Undefined height for feature %d. Skipping."
+msgstr ""
+#: ../vector/v.drape/main.c:204
+msgid "Copying attribute tables..."
+msgstr ""
+#: ../vector/v.buffer/main.c:227
+msgid "grow"
+msgstr ""
+#: ../vector/v.buffer/main.c:228
+msgid "shrink"
+msgstr ""
+#: ../vector/v.buffer/main.c:230
+msgid "Creates a buffer around vector features of given type."
+msgstr ""
+#: ../vector/v.buffer/main.c:255
+msgid "Buffer distance along major axis in map units"
+msgstr ""
+#: ../vector/v.buffer/main.c:256 ../vector/v.buffer/main.c:264
+#: ../vector/v.buffer/main.c:272 ../vector/v.buffer/main.c:277
+#: ../vector/v.buffer/main.c:285 ../vector/v.buffer/main.c:293
+msgid "Distance"
+msgstr ""
+#: ../vector/v.buffer/main.c:263
+msgid "Buffer distance along minor axis in map units"
+msgstr ""
+#: ../vector/v.buffer/main.c:271 ../vector/v.parallel/main.c:84
+msgid "Angle of major axis in degrees"
+msgstr ""
+#: ../vector/v.buffer/main.c:276
+msgid "Name of column to use for buffer distances"
+msgstr ""
+#: ../vector/v.buffer/main.c:284
+msgid "Scaling factor for attribute column values"
+msgstr ""
+#: ../vector/v.buffer/main.c:292
+msgid "Maximum distance between theoretical arc and polygon segments as multiple of buffer (default 0.01)"
+msgstr ""
+#: ../vector/v.buffer/main.c:297
+msgid "Make outside corners straight"
+msgstr ""
+#: ../vector/v.buffer/main.c:301
+msgid "Do not make caps at the ends of polylines"
+msgstr ""
+#: ../vector/v.buffer/main.c:305
+msgid "Transfer categories and attributes"
+msgstr ""
+#: ../vector/v.buffer/main.c:325
+msgid "Note: In latitude-longitude coordinate system specify distances in degree unit"
+msgstr ""
+#: ../vector/v.buffer/main.c:329
+msgid "Select a buffer distance/minordistance/angle or column, but not both."
+msgstr ""
+#: ../vector/v.buffer/main.c:358
+msgid "The bufcol option requires a valid layer."
+msgstr ""
+#: ../vector/v.buffer/main.c:364
+msgid "The tolerance must be > 0."
+msgstr ""
+#: ../vector/v.buffer/main.c:368
+#, c-format
+msgid "The tolerance was reset to %g"
+msgstr ""
+#: ../vector/v.buffer/main.c:372
+msgid "Illegal scale value"
+msgstr ""
+#: ../vector/v.buffer/main.c:389
+#, c-format
+msgid "The tolerance in map units = %g"
+msgstr ""
+#: ../vector/v.buffer/main.c:393 ../vector/v.buffer/main.c:396
+#: ../vector/v.buffer/main.c:399
+#, c-format
+msgid "Option '%s' is not available with GEOS buffering"
+msgstr ""
+#: ../vector/v.buffer/main.c:442
+#, c-format
+msgid "Unable to select data from table <%s>"
+msgstr ""
+#: ../vector/v.buffer/main.c:478
+msgid "No features available for buffering. Check type option and features available in the input vector."
+msgstr ""
+#: ../vector/v.buffer/main.c:495
+#, c-format
+msgid "Flags -%c/%c ignored by this version, GEOS >= 3.3 is required"
+msgstr ""
+#: ../vector/v.buffer/main.c:500
+msgid "Negative distances for internal buffers are not supported and converted to positive values."
+msgstr ""
+#: ../vector/v.buffer/main.c:510
+msgid "Buffering areas..."
+msgstr ""
+#: ../vector/v.buffer/main.c:546 ../vector/v.buffer/main.c:648
+#, c-format
+msgid "Attribute is of invalid size (%.3f) for category %d"
+msgstr ""
+#: ../vector/v.buffer/main.c:560 ../vector/v.buffer/main.c:666
+#, c-format
+msgid "The tolerance in map units: %g"
+msgstr ""
+#: ../vector/v.buffer/main.c:606
+msgid "Buffering features..."
+msgstr ""
+#: ../vector/v.buffer/main.c:609 ../vector/v.buffer/main.c:658
+msgid "Negative distances are only supported for areas"
+msgstr ""
+#: ../vector/v.buffer/main.c:732
+msgid "Cleaning buffers..."
+msgstr ""
+#: ../vector/v.buffer/main.c:735
+msgid "Building parts of topology..."
+msgstr ""
+#: ../vector/v.buffer/main.c:749
+msgid "Snapping boundaries..."
+msgstr ""
+#: ../vector/v.buffer/main.c:752 ../vector/v.in.ogr/main.c:1429
+msgid "Breaking polygons..."
+msgstr ""
+#: ../vector/v.buffer/main.c:755 ../vector/v.buffer/main.c:762
+#: ../vector/v.in.ogr/main.c:1434 ../vector/v.in.ogr/main.c:1448
+#: ../vector/v.overlay/area_area.c:113 ../vector/v.delaunay/main.c:144
+msgid "Removing duplicates..."
+msgstr ""
+#: ../vector/v.buffer/main.c:759 ../vector/v.in.ogr/main.c:1444
+msgid "Breaking boundaries..."
+msgstr ""
+#: ../vector/v.buffer/main.c:765
+msgid "Cleaning boundaries at nodes"
+msgstr ""
+#: ../vector/v.buffer/main.c:773 ../vector/v.in.ogr/main.c:1468
+#: ../vector/v.voronoi/clean_topo.c:87
+msgid "Removing dangles..."
+msgstr ""
+#: ../vector/v.buffer/main.c:776 ../vector/v.in.ogr/main.c:1483
+#: ../vector/v.voronoi/clean_topo.c:89
+msgid "Removing bridges..."
+msgstr ""
+#: ../vector/v.buffer/main.c:779 ../vector/v.overlay/area_area.c:158
+msgid "Attaching islands..."
+msgstr ""
+#: ../vector/v.buffer/main.c:786
+msgid "Calculating centroids for all areas..."
+msgstr ""
+#: ../vector/v.buffer/main.c:800 ../vector/v.overlay/area_area.c:171
+msgid "Cannot calculate area centroid"
+msgstr ""
+#: ../vector/v.buffer/main.c:817
+msgid "Generating list of boundaries to be deleted..."
+msgstr ""
+#: ../vector/v.buffer/main.c:850
+msgid "Deleting boundaries..."
+msgstr ""
+#: ../vector/v.buffer/main.c:882
+msgid "Calculating centroids for areas..."
+msgstr ""
+#: ../vector/v.buffer/main.c:895
+#, c-format
+msgid "Unable to calculate centroid for area %d"
+msgstr ""
+#: ../vector/v.buffer/geos.c:19 ../vector/v.profile/main.c:60
+msgid "Invalid GEOS geometry!"
+msgstr ""
+#: ../vector/v.buffer/geos.c:25 ../vector/v.profile/main.c:66
+msgid "No coordinates in GEOS geometry (can be ok for negative distance)!"
+msgstr ""
+#: ../vector/v.buffer/geos.c:33 ../vector/v.profile/main.c:74
+#, c-format
+msgid "Invalid x coordinate %f"
+msgstr ""
+#: ../vector/v.buffer/geos.c:35 ../vector/v.profile/main.c:76
+#, c-format
+msgid "Invalid y coordinate %f"
+msgstr ""
+#: ../vector/v.buffer/geos.c:107 ../vector/v.profile/main.c:93
+#: ../vector/v.profile/main.c:104
+msgid "Corrupt GEOS geometry"
+msgstr ""
+#: ../vector/v.buffer/geos.c:135
+msgid "Unknown GEOS geometry type"
+msgstr ""
+#: ../vector/v.buffer/geos.c:178
+#, c-format
+msgid "Buffering failed (feature %d)"
+msgstr ""
+#: ../vector/v.lidar.growing/main.c:78
+msgid "Building contour determination and Region Growing algorithm for determining the building inside"
+msgstr ""
+#: ../vector/v.lidar.growing/main.c:83
+msgid "Input vector (v.lidar.edgedetection output)"
+msgstr ""
+#: ../vector/v.lidar.growing/main.c:93
+msgid "Name of the first pulse vector map"
+msgstr ""
+#: ../vector/v.lidar.growing/main.c:100
+msgid "Threshold for cell object frequency in region growing"
+msgstr ""
+#: ../vector/v.lidar.growing/main.c:108
+msgid "Threshold for double pulse in region growing"
+msgstr ""
+#: ../vector/v.lidar.growing/main.c:176
+#, c-format
+msgid "Unable to open table <%s>"
+msgstr ""
+#: ../vector/v.lidar.growing/main.c:201
+msgid "Setting regions and boxes"
+msgstr ""
+#: ../vector/v.lidar.growing/main.c:267
+#, c-format
+msgid "Rows = %d"
+msgstr ""
+#: ../vector/v.lidar.growing/main.c:268
+#, c-format
+msgid "Columns = %d"
+msgstr ""
+#: ../vector/v.lidar.growing/main.c:288
+msgid "read points in input vector"
+msgstr ""
+#: ../vector/v.lidar.growing/main.c:446
+msgid "Region Growing"
+msgstr ""
+#: ../vector/v.lidar.growing/ConvexHull.c:269
+msgid "...now exiting to system..."
+msgstr ""
+#: ../vector/v.select/copy_tabs.c:51 ../scripts/v.to.lines/v.to.lines.py:157
+msgid "No table for layer %d"
+msgstr ""
+#: ../vector/v.select/copy_tabs.c:71
+#, c-format
+msgid "Unable to copy table for layer %d"
+msgstr ""
+#: ../vector/v.select/main.c:50 ../vector/v.overlay/main.c:65
+msgid "spatial query"
+msgstr ""
+#: ../vector/v.select/main.c:52
+msgid "Selects features from vector map (A) by features from other vector map (B)."
+msgstr ""
+#: ../vector/v.select/main.c:85 ../vector/v.overlay/main.c:178
+#, c-format
+msgid "Unknown operator '%s'"
+msgstr ""
+#: ../vector/v.select/main.c:94
+msgid "Operator can only be 'overlap'"
+msgstr ""
+#: ../vector/v.select/main.c:128
+msgid "Output from v.select"
+msgstr ""
+#: ../vector/v.select/main.c:181
+#, c-format
+msgid "%d features from <%s> without category skipped"
+msgstr ""
+#: ../vector/v.select/main.c:190
+#, c-format
+msgid "%d features written to output."
+msgstr ""
+#: ../vector/v.select/main.c:192
+msgid "No features found !"
+msgstr ""
+#: ../vector/v.select/write.c:27
+msgid "Writing selected features..."
+msgstr ""
+#: ../vector/v.select/args.c:12
+msgid "Input vector map from which to select features (A)"
+msgstr ""
+#: ../vector/v.select/args.c:16
+msgid "Layer number (vector map A)"
+msgstr ""
+#: ../vector/v.select/args.c:21 ../vector/v.overlay/main.c:81
+msgid "Feature type (vector map A)"
+msgstr ""
+#: ../vector/v.select/args.c:27
+msgid "Query vector map (B)"
+msgstr ""
+#: ../vector/v.select/args.c:31
+msgid "Layer number (vector map B)"
+msgstr ""
+#: ../vector/v.select/args.c:36 ../vector/v.overlay/main.c:95
+msgid "Feature type (vector map B)"
+msgstr ""
+#: ../vector/v.select/args.c:49
+msgid "Operator defines required relation between features"
+msgstr ""
+#: ../vector/v.select/args.c:51
+msgid "A feature is written to output if the result of operation 'ainput operator binput' is true. An input feature is considered to be true, if category of given layer is defined."
+msgstr ""
+#: ../vector/v.select/args.c:59 ../vector/v.select/args.c:75
+msgid "features partially or completely overlap"
+msgstr ""
+#: ../vector/v.select/args.c:76
+msgid "features are spatially equals (using GEOS)"
+msgstr ""
+#: ../vector/v.select/args.c:77
+msgid "features do not spatially intersect (using GEOS)"
+msgstr ""
+#: ../vector/v.select/args.c:78
+msgid "features spatially intersect (using GEOS)"
+msgstr ""
+#: ../vector/v.select/args.c:79
+msgid "features spatially touches (using GEOS)"
+msgstr ""
+#: ../vector/v.select/args.c:80
+msgid "features spatially crosses (using GEOS)"
+msgstr ""
+#: ../vector/v.select/args.c:81
+msgid "feature A is completely inside feature B (using GEOS)"
+msgstr ""
+#: ../vector/v.select/args.c:82
+msgid "feature B is completely inside feature A (using GEOS)"
+msgstr ""
+#: ../vector/v.select/args.c:83
+msgid "features spatially overlap (using GEOS)"
+msgstr ""
+#: ../vector/v.select/args.c:84
+msgid "feature A is spatially related to feature B (using GEOS, requires 'relate' option)"
+msgstr ""
+#: ../vector/v.select/args.c:94
+msgid "Intersection Matrix Pattern used for 'relate' operator"
+msgstr ""
+#: ../vector/v.select/args.c:101
+msgid "Do not skip features without category"
+msgstr ""
+#: ../vector/v.select/args.c:105 ../vector/v.edit/args.c:204
+#: ../vector/v.extract/main.c:97
+msgid "Reverse selection"
+msgstr ""
+#: ../vector/v.select/select.c:65
+#, c-format
+msgid "Unable to read line id %d from vector map <%s>"
+msgstr ""
+#: ../vector/v.select/select.c:171 ../vector/v.out.pov/main.c:175
+msgid "Processing areas..."
+msgstr ""
+#: ../vector/v.select/select.c:195
+#, c-format
+msgid "Unable to read area id %d from vector map <%s>"
+msgstr ""
+#: ../vector/v.profile/main.c:156
+msgid "Vector map profiling tool"
+msgstr ""
+#: ../vector/v.profile/main.c:172
+msgid "Use features only from specified layer"
+msgstr ""
+#: ../vector/v.profile/main.c:183
+msgid "Path to output text file or - for stdout"
+msgstr ""
+#: ../vector/v.profile/main.c:195
+msgid "Number of significant digits"
+msgstr ""
+#: ../vector/v.profile/main.c:204
+msgid "Buffer (tolerance) for points in map units"
+msgstr ""
+#: ../vector/v.profile/main.c:205
+msgid "How far points can be from sampling line"
+msgstr ""
+#: ../vector/v.profile/main.c:215
+msgid "Name for profile line and buffer output map"
+msgstr ""
+#: ../vector/v.profile/main.c:217
+msgid "Profile line and buffer around it will be written"
+msgstr ""
+#: ../vector/v.profile/main.c:222
+msgid "Do not print column names"
+msgstr ""
+#: ../vector/v.profile/main.c:227
+msgid "Do not print 3D vector data (z values)"
+msgstr ""
+#: ../vector/v.profile/main.c:228
+msgid "Only affects 3D vectors"
+msgstr ""
+#: ../vector/v.profile/main.c:235
+msgid "Coordinates for profiling line nodes"
+msgstr ""
+#: ../vector/v.profile/main.c:236
+msgid "Specify profiling line vertexes and nodes"
+msgstr ""
+#: ../vector/v.profile/main.c:237 ../vector/v.profile/main.c:249
+#: ../vector/v.profile/main.c:260 ../vector/v.profile/main.c:268
+msgid "Profiling line"
+msgstr ""
+#: ../vector/v.profile/main.c:247
+msgid "Profiling line map"
+msgstr ""
+#: ../vector/v.profile/main.c:248
+msgid "Vector map containing profiling line"
+msgstr ""
+#: ../vector/v.profile/main.c:257
+msgid "WHERE conditions for input profile line map"
+msgstr ""
+#: ../vector/v.profile/main.c:259
+msgid "Use to select only one line from profiling line map"
+msgstr ""
+#: ../vector/v.profile/main.c:267
+msgid "Profiling line map layer"
+msgstr ""
+#: ../vector/v.profile/main.c:288
+msgid "Layer 0 not supported"
+msgstr ""
+#: ../vector/v.profile/main.c:293
+msgid "Failed to interpreter 'dp' parameter as an integer"
+msgstr ""
+#: ../vector/v.profile/main.c:299
+msgid "Tolerance value must be greater than 0"
+msgstr ""
+#: ../vector/v.profile/main.c:304
+#, c-format
+msgid "<%s> is not a valid vector map name"
+msgstr ""
+#: ../vector/v.profile/main.c:309
+msgid "No input profile map name provided, but WHERE conditions for it have been set"
+msgstr ""
+#: ../vector/v.profile/main.c:313
+msgid "Profile input coordinates and vector map are provided. Please provide only one of them"
+msgstr ""
+#: ../vector/v.profile/main.c:317
+msgid "No profile input coordinates nor vector map are provided. Please provide one of them"
+msgstr ""
+#: ../vector/v.profile/main.c:354
+msgid "At least profile start and end coordinates are required!"
+msgstr ""
+#: ../vector/v.profile/main.c:385 ../vector/v.profile/main.c:401
+#, c-format
+msgid "No database connection defined for map <%s> layer %d, but WHERE condition is provided"
+msgstr ""
+#: ../vector/v.profile/main.c:444 ../vector/v.profile/main.c:596
+msgid "No features match Your query"
+msgstr ""
+#: ../vector/v.profile/main.c:449 ../vector/v.profile/main.c:462
+msgid "Your query matches more than one record in input profiling map. Currently it's not supported. Enhance WHERE conditions to get only one line."
+msgstr ""
+#: ../vector/v.profile/main.c:455
+msgid "Error while initialising line list"
+msgstr ""
+#: ../vector/v.profile/main.c:467
+msgid "Error while reading vector feature from profile line map"
+msgstr ""
+#: ../vector/v.profile/main.c:481
+msgid "Your input profile map contains more than one line. Currently it's not supported. Provide WHERE conditions to get only one line."
+msgstr ""
+#: ../vector/v.profile/main.c:501
+msgid "Failed to convert GRASS line to GEOS line"
+msgstr ""
+#: ../vector/v.profile/main.c:509
+msgid "Buffering failed"
+msgstr ""
+#: ../vector/v.profile/main.c:556
+#, c-format
+msgid "Vector map <%s> does not have cat's defined on layer %d"
+msgstr ""
+#: ../vector/v.profile/main.c:683
+#, c-format
+msgid "Unabale to get attribute data for cat %d"
+msgstr ""
+#: ../vector/v.profile/main.c:692
+#, c-format
+msgid "Error while retreiving database record for cat %d"
+msgstr ""
+#: ../vector/v.profile/main.c:730
+msgid "Can not write data portion to provided output"
+msgstr ""
+#: ../vector/v.extrude/main.c:72
+msgid "Extrudes flat vector features to 3D vector features with defined height."
+msgstr ""
+#: ../vector/v.extrude/main.c:74
+msgid "Optionally the height can be derived from sampling of elevation raster map."
+msgstr ""
+#: ../vector/v.extrude/main.c:78
+msgid "Trace elevation"
+msgstr ""
+#: ../vector/v.extrude/main.c:101 ../vector/v.transform/main.c:136
+msgid "Shifting value for z coordinates"
+msgstr ""
+#: ../vector/v.extrude/main.c:105 ../vector/v.extrude/main.c:113
+#: ../vector/v.extrude/main.c:119 ../vector/v.to.3d/args.c:33
+#: ../vector/v.to.3d/args.c:41
+msgid "Height"
+msgstr ""
+#: ../vector/v.extrude/main.c:112 ../vector/v.to.3d/args.c:40
+msgid "Fixed height for 3D vector features"
+msgstr ""
+#: ../vector/v.extrude/main.c:118
+msgid "Name of attribute column with feature height"
+msgstr ""
+#: ../vector/v.extrude/main.c:151
+#, c-format
+msgid "One of '%s' or '%s' parameters must be set"
+msgstr ""
+#: ../vector/v.extrude/main.c:202
+#, c-format
+msgid "Invalid layer number (%d). Parameter '%s', '%s' or '%s' specified, assuming layer '1'."
+msgstr ""
+#: ../vector/v.extrude/main.c:234
+#, c-format
+msgid "Column <%s> does not exist"
+msgstr ""
+#: ../vector/v.extrude/main.c:243
+#, c-format
+msgid "Column <%s>: invalid data type"
+msgstr ""
+#: ../vector/v.extrude/main.c:265
+msgid "Extruding areas..."
+msgstr ""
+#: ../vector/v.extrude/main.c:275 ../vector/v.out.svg/main.c:233
+#, c-format
+msgid "Skipping area %d without centroid"
+msgstr ""
+#: ../vector/v.extrude/main.c:287
+#, c-format
+msgid "No category defined for area %d. Using default fixed height %f."
+msgstr ""
+#: ../vector/v.extrude/main.c:293
+#, c-format
+msgid "Unable to fetch height from DB for area %d. Using default fixed height %f."
+msgstr ""
+#: ../vector/v.extrude/main.c:319
+msgid "Extruding features..."
+msgstr ""
+#: ../vector/v.extrude/main.c:340
+#, c-format
+msgid "No category defined for feature %d. Using default fixed height %f."
+msgstr ""
+#: ../vector/v.extrude/main.c:346
+#, c-format
+msgid "Unable to fetch height from DB for line %d. Using default fixed height %f."
+msgstr ""
+#: ../vector/v.extrude/main.c:364
+msgid "Copying attribute table..."
+msgstr ""
+#: ../vector/v.extrude/db.c:27
+#, c-format
+msgid "Unable to select attributes category %d"
+msgstr ""
+#: ../vector/v.in.region/main.c:43
+msgid "Creates a vector polygon from the current region extent."
+msgstr ""
+#: ../vector/v.in.region/main.c:51
+msgid "Select type: line or area"
+msgstr ""
+#: ../vector/v.in.region/main.c:58
+msgid "Densify lines using region resolution"
+msgstr ""
+#: ../vector/v.hull/main.c:56
+msgid "Produces a 2D/3D convex hull for a given vector map."
+msgstr ""
+#: ../vector/v.hull/main.c:70
+msgid "Limit to current region"
+msgstr ""
+#: ../vector/v.hull/main.c:75
+msgid "Create a 'flat' 2D hull even if the input is 3D points"
+msgstr ""
+#: ../vector/v.hull/main.c:100
+#, c-format
+msgid "Error loading vector points from <%s>"
+msgstr ""
+#: ../vector/v.hull/main.c:103
+#, c-format
+msgid "Convex hull calculation requires at least three points (%d found)"
+msgstr ""
+#: ../vector/v.hull/main.c:105
+#, c-format
+msgid "%d points read from vector map <%s>"
+msgstr ""
+#: ../vector/v.hull/chull.c:212
+msgid "Reading 3D vertices..."
+msgstr ""
+#: ../vector/v.hull/chull.c:396
+msgid "Constructing 3D hull..."
+msgstr ""
+#: ../vector/v.hull/hull.c:107
+msgid "Simple planar hulls not implemented yet"
+msgstr ""
+#: ../vector/v.out.svg/main.c:76
+msgid "Exports a vector map to SVG file."
+msgstr ""
+#: ../vector/v.out.svg/main.c:85
+msgid "Name for SVG output file"
+msgstr ""
+#: ../vector/v.out.svg/main.c:94
+msgid "Output type"
+msgstr ""
+#: ../vector/v.out.svg/main.c:95
+msgid "Defines which feature-type will be extracted"
+msgstr ""
+#: ../vector/v.out.svg/main.c:103
+msgid "Coordinate precision"
+msgstr ""
+#: ../vector/v.out.svg/main.c:109
+msgid "Attribute(s) to include in output SVG"
+msgstr ""
+#: ../vector/v.out.svg/main.c:130
+msgid "Precision must not be negative"
+msgstr ""
+#: ../vector/v.out.svg/main.c:133
+msgid "Precision must not be higher than 15"
+msgstr ""
+#: ../vector/v.out.svg/main.c:201
+#, c-format
+msgid "Unable to create SVG file <%s>"
+msgstr ""
+#: ../vector/v.out.svg/main.c:218
+#, c-format
+msgid "No areas found, skipping %s"
+msgstr ""
+#: ../vector/v.out.svg/main.c:259
+#, c-format
+msgid "%d areas extracted"
+msgstr ""
+#: ../vector/v.out.svg/main.c:266
+#, c-format
+msgid "No points found, skipping %s"
+msgstr ""
+#: ../vector/v.out.svg/main.c:295
+#, c-format
+msgid "%d points extracted"
+msgstr ""
+#: ../vector/v.out.svg/main.c:302
+#, c-format
+msgid "No lines found, skipping %s"
+msgstr ""
+#: ../vector/v.out.svg/main.c:329
+#, c-format
+msgid "%d lines extracted"
+msgstr ""
+#: ../vector/v.out.svg/main.c:396
+#, c-format
+msgid "Cannot select attributes for cat=%d"
+msgstr ""
+#: ../vector/v.net.connectivity/main.c:54
+msgid "connectivity"
+msgstr ""
+#: ../vector/v.net.connectivity/main.c:56
+msgid "Computes vertex connectivity between two sets of nodes in the network."
+msgstr ""
+#: ../vector/v.net.connectivity/main.c:96
+msgid "Set1 category values"
+msgstr ""
+#: ../vector/v.net.connectivity/main.c:97
+#: ../vector/v.net.connectivity/main.c:103
+msgid "Set1"
+msgstr ""
+#: ../vector/v.net.connectivity/main.c:102
+msgid "Set1 WHERE conditions of SQL statement without 'where' keyword"
+msgstr ""
+#: ../vector/v.net.connectivity/main.c:107
+msgid "Set2 category values"
+msgstr ""
+#: ../vector/v.net.connectivity/main.c:108
+#: ../vector/v.net.connectivity/main.c:114
+msgid "Set2"
+msgstr ""
+#: ../vector/v.net.connectivity/main.c:113
+msgid "Set2 WHERE conditions of SQL statement without 'where' keyword"
+msgstr ""
+#: ../vector/v.net.connectivity/main.c:146
+#: ../vector/v.net.connectivity/main.c:153
+#, c-format
+msgid "No features for %s selected. Please check options '%s', '%s'."
+msgstr ""
+#: ../vector/v.net.connectivity/main.c:167
+#: ../vector/v.net.connectivity/main.c:170
+#, c-format
+msgid "%s is empty"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:202
+msgid "Imports vector data into a GRASS vector map using OGR library."
+msgstr ""
+#: ../vector/v.in.ogr/main.c:209
+msgid ""
+"Examples:\n"
+"\t\tESRI Shapefile: directory containing shapefiles\n"
+"\t\tMapInfo File: directory containing mapinfo files"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:222
+msgid ""
+"Examples:\n"
+"\t\tESRI Shapefile: shapefile name\n"
+"\t\tMapInfo File: mapinfo file name"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:251
+msgid "Minimum size of area to be imported (square meters)"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:253
+msgid "Smaller areas and islands are ignored. Should be greater than snap^2"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:259
+msgid "Optionally change default input type"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:263
+msgid "import area centroids as points"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:264
+msgid "import area boundaries as lines"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:265
+msgid "import lines as area boundaries"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:266
+msgid "import points as centroids"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:276
+msgid "'-1' for no snap"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:288
+msgid "List of column names to be used instead of original names, first is used for category column"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:307
+msgid "Name of column used for categories"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:309
+msgid "If not given, categories are generated as unique values and stored in 'cat' column"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:314
+msgid "Name of geometry column"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:315
+msgid "If not given, all geometry columns from the input are used"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:333
+msgid "Do not clean polygons (not recommended)"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:338
+msgid "Force 2D output even if input is 3D"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:374
+msgid "Change column names to lowercase characters"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:505 ../vector/v.external/main.c:151
+#, c-format
+msgid "Unable to open data source <%s>"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:510
+#, c-format
+msgid "Using OGR driver '%s/%s'"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:514
+#, c-format
+msgid "Using OGR driver '%s'"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:532
+msgid "Using interleaved reading mode"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:538 ../vector/v.in.ogr/main.c:542
+#, c-format
+msgid "Option <%s> will be ignored. OGR doesn't support it for selected format (%s)."
+msgstr ""
+#: ../vector/v.in.ogr/main.c:548
+#, c-format
+msgid "Option <%s> will be ignored. Multiple geometry fields are supported by GDAL >= 1.11"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:558
+#, c-format
+msgid "Encoding value not supported by OGR driver <%s>"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:568
+msgid "No OGR layers available"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:575
+#, c-format
+msgid "Data source <%s> (format '%s') contains %d layers:"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:614 ../vector/v.external/main.c:124
+#, c-format
+msgid "Layer <%s> not available"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:628
+msgid "Detected different projections of input layers. Input layers must be imported separately."
+msgstr ""
+#: ../vector/v.in.ogr/main.c:668
+#, c-format
+msgid "Illegal output name <%s>"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:689
+#, c-format
+msgid "All available OGR layers will be imported into vector map <%s>"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:698
+msgid "When creating a new location, the current region can not be used as spatial filter, disabling"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:716 ../vector/v.in.ogr/main.c:1992
+#, c-format
+msgid "Error setting attribute filter '%s'"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:756
+#, c-format
+msgid "Geometry column <%s> not found in OGR layer <%s>"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:769
+#, c-format
+msgid "Check if OGR layer <%s> contains polygons..."
+msgstr ""
+#: ../vector/v.in.ogr/main.c:827
+#, c-format
+msgid "Boundary splitting distance in map units: %G"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:857
+#, c-format
+msgid "Using temporary vector <%s>"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:899
+#, c-format
+msgid "Key column '%s' not found in input layer <%s>"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:912
+#, c-format
+msgid "Key column '%s' in input layer <%s> is not integer"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:924
+#, c-format
+msgid "Creating attribute table for layer <%s>..."
+msgstr ""
+#: ../vector/v.in.ogr/main.c:994
+#, c-format
+msgid "Column name <%s> renamed to <%s>"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1026
+#, c-format
+msgid "Writing column <%s> with integer 64 as integer 32"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1039
+#, c-format
+msgid "Writing column <%s> with fixed length %d chars (may be truncated)"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1063
+#, c-format
+msgid "Width for column %s set to 255 (was not specified by OGR), some strings may be truncated!"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1075
+#, c-format
+msgid "Writing column %s with fixed length %d chars (may be truncated)"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1079
+#, c-format
+msgid "Column type (Ogr_ftype: %d) not supported (Ogr_fieldname: %s)"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1100
+#, c-format
+msgid "Column name <%s> renamed to <%s_%d>"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1164
+#, c-format
+msgid "Importing %lld features (OGR layer <%s>)..."
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1327
+#, c-format
+msgid "Cannot insert new row for input layer <%s>: %s"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1343
+#, c-format
+msgid "%d %s without geometry in input layer <%s> skipped"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1344
+msgid "feature"
+msgstr ""
+msgid "features"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1368
+#, c-format
+msgid "Unable to drop table: '%s'"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1409
+msgid "Cleaning polygons"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1413
+#, c-format
+msgid "Snapping boundaries (threshold = %.3e)..."
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1452 ../vector/v.overlay/area_area.c:116
+msgid "Cleaning boundaries at nodes..."
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1459
+msgid "Merging boundaries..."
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1464
+msgid "Changing boundary dangles to lines..."
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1477
+msgid "Changing boundary bridges to lines..."
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1506 ../vector/v.delaunay/main.c:172
+#: ../vector/v.category/main.c:364
+msgid "Unable to calculate area centroid"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1523
+#, c-format
+msgid "Finding centroids for OGR layer <%s>..."
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1580 ../vector/v.overlay/area_area.c:218
+msgid "Writing centroids..."
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1626
+#, c-format
+msgid "%d input polygons\n"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1627
+#, c-format
+msgid "%d input polygons"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1630
+#, c-format
+msgid "Total area: %G (%d areas)\n"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1631
+#, c-format
+msgid "Total area: %G (%d areas)"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1634
+#, c-format
+msgid "Overlapping area: %G (%d areas)\n"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1637
+#, c-format
+msgid "Overlapping area: %G (%d areas)"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1642
+#, c-format
+msgid "Area without category: %G (%d areas)\n"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1645
+#, c-format
+msgid "Area without category: %G (%d areas)"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1769
+msgid "The output contains topological errors:"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1773
+#, c-format
+msgid "Unable to calculate a centroid for %d areas"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1779
+#, c-format
+msgid "Number of incorrect boundaries: %d"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1785
+#, c-format
+msgid "Number of centroids outside area: %d"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1791
+#, c-format
+msgid "Number of duplicate centroids: %d"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1796 ../vector/v.in.ogr/main.c:1865
+msgid "The input could be cleaned by snapping vertices to each other."
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1799 ../vector/v.in.ogr/main.c:1834
+#: ../vector/v.in.ogr/main.c:1860 ../vector/v.in.ogr/main.c:1866
+#, c-format
+msgid "Estimated range of snapping threshold: [%g, %g]"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1810 ../vector/v.in.ogr/main.c:1817
+#: ../vector/v.in.ogr/main.c:1843
+#, c-format
+msgid "Try to import again, snapping with %g: 'snap=%g'"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1813 ../vector/v.in.ogr/main.c:1839
+#, c-format
+msgid "Try to import again, snapping with at least %g: 'snap=%g'"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1821 ../vector/v.in.ogr/main.c:1847
+msgid "Manual cleaning may be needed."
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1825
+#, c-format
+msgid "%d areas represent multiple (overlapping) features, because polygons overlap in input layer(s). Such areas are linked to more than 1 row in attribute table. The number of features for those areas is stored as category in layer %d"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1830
+msgid "If overlapping is not desired, the input data can be cleaned by snapping vertices to each other."
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1853
+#, c-format
+msgid "%d input polygons got lost during import."
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1856
+#, c-format
+msgid "%d additional areas where created during import."
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1859
+#, c-format
+msgid "The snapping threshold %g might be too large."
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1862
+msgid "Try to reduce the snapping threshold or clean the output manually."
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1873 ../vector/v.in.ascii/main.c:552
+#: ../vector/v.in.ascii/main.c:555
+msgid "Import failed"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1908
+msgid "Input data contains 3D features. Created vector is 2D only, disable -2 flag to import 3D vector."
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1930
+#, c-format
+msgid "Using GDAL 2.2+ style interleaved reading for GDAL version %d.%d.%d"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1933
+#, c-format
+msgid "Using GDAL 1.x style interleaved reading for GDAL version %d.%d.%d"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1983
+#, c-format
+msgid "Unable to re-open data source <%s>"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:2155
+msgid "xmin is larger than xmax in 'spatial' parameters"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:2157
+msgid "ymin is larger than ymax in 'spatial' parameters"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:2174
+#, c-format
+msgid "The spatial filter does not overlap with OGR layer <%s>. Nothing to import."
+msgstr ""
+#: ../vector/v.in.ogr/proj.c:36 ../vector/v.external/proj.c:36
+#, c-format
+msgid "Geometry column <%s> not found in input layer <%s>"
+msgstr ""
+#: ../vector/v.in.ogr/proj.c:54 ../vector/v.external/proj.c:54
+msgid "Unable to convert input layer projection information to GRASS format for checking"
+msgstr ""
+#: ../vector/v.in.ogr/proj.c:60 ../vector/v.in.ogr/proj.c:88
+#: ../vector/v.external/proj.c:60 ../vector/v.external/proj.c:88
+msgid "Can't get WKT parameter string"
+msgstr ""
+#: ../vector/v.in.ogr/proj.c:63 ../vector/v.in.ogr/proj.c:91
+#: ../vector/v.external/proj.c:63 ../vector/v.external/proj.c:91
+#, c-format
+msgid ""
+"WKT definition:\n"
+"%s"
+msgstr ""
+#: ../vector/v.in.ogr/proj.c:73 ../vector/v.external/proj.c:73
+#, c-format
+msgid "No projection information available for layer <%s>"
+msgstr ""
+#: ../vector/v.in.ogr/proj.c:81 ../vector/v.external/proj.c:81
+#, c-format
+msgid "Projection for layer <%s> does not contain a valid SRS"
+msgstr ""
+#: ../vector/v.in.ogr/proj.c:116 ../vector/v.external/proj.c:116
+#, c-format
+msgid "Projection for layer <%s> can not be converted to proj4"
+msgstr ""
+#: ../vector/v.in.ogr/proj.c:123 ../vector/v.external/proj.c:123
+msgid "Can't get WKT-style parameter string"
+msgstr ""
+#: ../vector/v.in.ogr/proj.c:126 ../vector/v.external/proj.c:126
+#, c-format
+msgid ""
+"WKT-style definition:\n"
+"%s"
+msgstr ""
+#: ../vector/v.in.ogr/proj.c:171
+msgid "Layer projections are unreadable"
+msgstr ""
+#: ../vector/v.in.ogr/proj.c:184
+#, c-format
+msgid "Projection for layer <%s> is unreadable"
+msgstr ""
+#: ../vector/v.in.ogr/proj.c:228
+#, c-format
+msgid "Projection of layer <%s> is different from projection of layer <%s>"
+msgstr ""
+#: ../vector/v.in.ogr/clean.c:19
+msgid "Converting OSM lines..."
+msgstr ""
+#: ../vector/v.in.ogr/clean.c:65
+#, c-format
+msgid "Number of OSM line splits: %d"
+msgstr ""
+#: ../vector/v.in.ogr/clean.c:66 ../vector/v.overlay/area_area.c:154
+msgid "Merging lines..."
+msgstr ""
+#: ../vector/v.in.ogr/geom.c:76 ../vector/v.in.ogr/geom.c:261
+#: ../vector/v.in.ogr/geom.c:275 ../vector/v.in.ogr/geom.c:304
+#: ../vector/v.in.ogr/geom.c:352
+#, c-format
+msgid "Skipping empty geometry feature %d"
+msgstr ""
+#: ../vector/v.in.ogr/geom.c:199 ../vector/v.in.ogr/geom.c:220
+msgid "Unable to read part of geometry"
+msgstr ""
+#: ../vector/v.in.ogr/geom.c:320
+#, c-format
+msgid "Feature (cat %d): degenerated polygon (%d vertices)"
+msgstr ""
+#: ../vector/v.in.ogr/geom.c:366
+#, c-format
+msgid "Degenerate island (%d vertices)"
+msgstr ""
+#: ../vector/v.in.ogr/geom.c:400
+msgid "Unable calculate centroid"
+msgstr ""
+#: ../vector/v.in.ogr/geom.c:431
+msgid "No centroid written for polygon with 0 vertices"
+msgstr ""
+#: ../vector/v.in.ogr/geom.c:452
+msgid "Unable to write part of geometry"
+msgstr ""
+#: ../vector/v.in.ogr/geom.c:458
+#, c-format
+msgid "Skipping unsupported geometry type '%s'"
+msgstr ""
+#: ../vector/v.patch/main.c:73
+msgid "Creates a new vector map by combining other vector maps."
+msgstr ""
+#: ../vector/v.patch/main.c:84
+msgid "Name for output vector map where bounding boxes of input vector maps are written to"
+msgstr ""
+#: ../vector/v.patch/main.c:88
+msgid "Do not expect input with topology"
+msgstr ""
+#: ../vector/v.patch/main.c:90
+msgid "Applicable when input is points without topology"
+msgstr ""
+#: ../vector/v.patch/main.c:94
+msgid "Expect z coordinate even when not using topology"
+msgstr ""
+#: ../vector/v.patch/main.c:96
+msgid "Applicable when input is points with z coordinate but without topology"
+msgstr ""
+#: ../vector/v.patch/main.c:100
+msgid "Copy also attribute table"
+msgstr ""
+#: ../vector/v.patch/main.c:102
+msgid "Only the table of layer 1 is currently supported"
+msgstr ""
+#: ../vector/v.patch/main.c:106
+msgid "Append files to existing file (overwriting existing files must be activated)"
+msgstr ""
+#: ../vector/v.patch/main.c:216
+msgid "Missing table"
+msgstr ""
+#: ../vector/v.patch/main.c:220
+msgid "Key columns differ"
+msgstr ""
+#: ../vector/v.patch/main.c:226
+msgid "Number of columns differ"
+msgstr ""
+#: ../vector/v.patch/main.c:238
+msgid "Column names differ"
+msgstr ""
+#: ../vector/v.patch/main.c:246
+msgid "Column types differ"
+msgstr ""
+#: ../vector/v.patch/main.c:251
+msgid "Length of string columns differ"
+msgstr ""
+#: ../vector/v.patch/main.c:265
+msgid "Key column not found"
+msgstr ""
+#: ../vector/v.patch/main.c:277
+msgid "The output map is not 3D"
+msgstr ""
+#: ../vector/v.patch/main.c:322 ../vector/v.sample/main.c:190
+#: ../scripts/v.db.addtable/v.db.addtable.py:137
+#, c-format, python-format
+msgid "Unable to create table <%s>"
+msgstr ""
+#: ../vector/v.patch/main.c:349
+#, c-format
+msgid "Patching vector map <%s>..."
+msgstr ""
+#: ../vector/v.patch/main.c:373
+#, c-format
+msgid "Error reading vector map <%s> - some data may not be correct"
+msgstr ""
+#: ../vector/v.patch/main.c:429
+#, c-format
+msgid "Building topology for vector map <%s>..."
+msgstr ""
+#: ../vector/v.patch/main.c:435
+msgid "Intersections at borders will have to be snapped"
+msgstr ""
+#: ../vector/v.patch/main.c:436
+msgid "Lines common between files will have to be edited"
+msgstr ""
+#: ../vector/v.patch/main.c:437
+msgid "The header information also may have to be edited"
+msgstr ""
+#: ../vector/v.patch/main.c:439
+#, c-format
+msgid "%d vector maps patched"
+msgstr ""
+#: ../vector/v.patch/main.c:462
+#, c-format
+msgid "Cannot open select cursor: '%s'"
+msgstr ""
+#: ../vector/v.patch/main.c:474
+msgid "Cannot fetch row"
+msgstr ""
+#: ../vector/v.patch/main.c:524
+msgid "Unknown column type"
+msgstr ""
+#: ../vector/v.patch/main.c:532
+#, c-format
+msgid "Cannot insert new record: '%s'"
+msgstr ""
+#: ../vector/v.net.path/main.c:45
+msgid "Finds shortest path on vector network."
+msgstr ""
+#: ../vector/v.net.path/main.c:72
+msgid "Name of file containing start and end points. If not given, read from stdin"
+msgstr ""
+#: ../vector/v.net.path/main.c:101
+msgid "Maximum distance to the network"
+msgstr ""
+#: ../vector/v.net.path/main.c:102
+msgid "If start/end are given as coordinates. If start/end point is outside this threshold, the path is not found and error message is printed. To speed up the process, keep this value as low as possible."
+msgstr ""
+#: ../vector/v.net.path/main.c:110 ../vector/v.net.iso/main.c:150
+#: ../vector/v.net.salesman/main.c:181 ../vector/v.net.alloc/main.c:129
+msgid "Use turntable"
+msgstr ""
+#: ../vector/v.net.path/main.c:111 ../vector/v.net.path/main.c:119
+#: ../vector/v.net.path/main.c:127 ../vector/v.net.iso/main.c:151
+#: ../vector/v.net.iso/main.c:159 ../vector/v.net.iso/main.c:167
+#: ../vector/v.net.salesman/main.c:182 ../vector/v.net.salesman/main.c:189
+#: ../vector/v.net.salesman/main.c:196 ../vector/v.net/args.c:64
+#: ../vector/v.net/args.c:111 ../vector/v.net/args.c:123
+#: ../vector/v.net.alloc/main.c:130 ../vector/v.net.alloc/main.c:138
+#: ../vector/v.net.alloc/main.c:146
+msgid "Turntable"
+msgstr ""
+#: ../vector/v.net.path/main.c:116 ../vector/v.net.iso/main.c:156
+#: ../vector/v.net.salesman/main.c:187 ../vector/v.net.alloc/main.c:135
+msgid "Layer with turntable"
+msgstr ""
+#: ../vector/v.net.path/main.c:118 ../vector/v.net.path/main.c:126
+#: ../vector/v.net.iso/main.c:158 ../vector/v.net.iso/main.c:166
+#: ../vector/v.net.salesman/main.c:188 ../vector/v.net.salesman/main.c:195
+#: ../vector/v.net.alloc/main.c:137 ../vector/v.net.alloc/main.c:145
+msgid "Relevant only with -t flag"
+msgstr ""
+#: ../vector/v.net.path/main.c:124 ../vector/v.net.iso/main.c:164
+#: ../vector/v.net.salesman/main.c:194 ../vector/v.net/args.c:114
+#: ../vector/v.net.alloc/main.c:143
+msgid "Layer with unique categories used in turntable"
+msgstr ""
+#: ../vector/v.net.path/path.c:82
+#, c-format
+msgid "[%d] points without category (nfield: [%d])"
+msgstr ""
+#: ../vector/v.net.path/path.c:146 ../vector/v.net.path/path.c:211
+#, c-format
+msgid "From and to are identical (id %d)"
+msgstr ""
+#: ../vector/v.net.path/path.c:153 ../vector/v.net.timetable/main.c:482
+#, c-format
+msgid "Wrong input format: %s"
+msgstr ""
+#: ../vector/v.net.path/path.c:164 ../vector/v.net.path/path.c:188
+#, c-format
+msgid "No point with category [%d]"
+msgstr ""
+#: ../vector/v.net.path/path.c:234
+#, c-format
+msgid "Point with category [%d] is not reachable from point with category [%d]"
+msgstr ""
+#: ../vector/v.net.path/path.c:303
+#, c-format
+msgid "Point %f,%f is not reachable from point %f,%f"
+msgstr ""
+#: ../vector/v.net.path/path.c:368
+#, c-format
+msgid "[%d] input format errors"
+msgstr ""
+#: ../vector/v.net.path/path.c:370
+#, c-format
+msgid "[%d] points of given category missing"
+msgstr ""
+#: ../vector/v.net.path/path.c:372
+#, c-format
+msgid "%d destination(s) unreachable (including points out of threshold)"
+msgstr ""
+#: ../vector/v.overlay/main.c:67
+msgid "difference"
+msgstr ""
+#: ../vector/v.overlay/main.c:68
+msgid "intersection"
+msgstr ""
+#: ../vector/v.overlay/main.c:69
+msgid "union"
+msgstr ""
+#: ../vector/v.overlay/main.c:70
+msgid "Overlays two vector maps offering clip, intersection, difference, symmetrical difference, union operators."
+msgstr ""
+#: ../vector/v.overlay/main.c:73
+msgid "Name of input vector map (A)"
+msgstr ""
+#: ../vector/v.overlay/main.c:77
+msgid "Layer number or name (vector map A)"
+msgstr ""
+#: ../vector/v.overlay/main.c:87
+msgid "Name of input vector map (B)"
+msgstr ""
+#: ../vector/v.overlay/main.c:91
+msgid "Layer number or name (vector map B)"
+msgstr ""
+#: ../vector/v.overlay/main.c:106
+msgid "Operator defines features written to output vector map"
+msgstr ""
+#: ../vector/v.overlay/main.c:109
+msgid "Feature is written to output if the result of operation 'ainput operator binput' is true. Input feature is considered to be true, if category of given layer is defined."
+msgstr ""
+#: ../vector/v.overlay/main.c:116
+msgid "also known as 'intersection' in GIS"
+msgstr ""
+#: ../vector/v.overlay/main.c:117
+msgid "also known as 'union' in GIS (only for atype=area)"
+msgstr ""
+#: ../vector/v.overlay/main.c:118
+msgid "also known as 'difference' (features from ainput not overlayed by features from binput)"
+msgstr ""
+#: ../vector/v.overlay/main.c:120
+msgid "also known as 'symmetrical difference' (features from either ainput or binput but not those from ainput overlayed by binput (only for atype=area)"
+msgstr ""
+#: ../vector/v.overlay/main.c:131
+msgid "Output layer for new category, ainput and binput"
+msgstr ""
+#: ../vector/v.overlay/main.c:132
+msgid "If 0 or not given, the category is not written"
+msgstr ""
+#: ../vector/v.overlay/main.c:139
+msgid "Snapping threshold for boundaries"
+msgstr ""
+#: ../vector/v.overlay/main.c:140
+msgid "Disable snapping with snap <= 0"
+msgstr ""
+#: ../vector/v.overlay/main.c:195
+#, c-format
+msgid "Unable to determine feature type for <%s>"
+msgstr ""
+#: ../vector/v.overlay/main.c:201
+#, c-format
+msgid "Invalid feature type (%d) for <%s>. Only '%s' or '%s' supported."
+msgstr ""
+#: ../vector/v.overlay/main.c:209
+#, c-format
+msgid "Operator '%s' is not supported for type line"
+msgstr ""
+#: ../vector/v.overlay/main.c:264
+#, c-format
+msgid "Copying vector features from <%s>..."
+msgstr ""
+#: ../vector/v.overlay/main.c:345
+#, c-format
+msgid "No %s features found in vector map <%s>. Verify '%s' parameter."
+msgstr ""
+#: ../vector/v.overlay/main.c:394
+msgid "Collecting input attributes..."
+msgstr ""
+#: ../vector/v.overlay/main.c:474
+#, c-format
+msgid "Unknown column type '%s' of column '%s'"
+msgstr ""
+#: ../vector/v.overlay/main.c:539
+#, c-format
+msgid "Unknown column type '%s' of column '%s', values lost"
+msgstr ""
+#: ../vector/v.overlay/line_area.c:273
+msgid "Selecting lines..."
+msgstr ""
+#: ../vector/v.overlay/line_area.c:345
+#, c-format
+msgid "Ambiguous line %d: not all vertices are really outside any area"
+msgstr ""
+#: ../vector/v.overlay/line_area.c:387 ../vector/v.overlay/line_area.c:415
+#: ../vector/v.overlay/area_area.c:208 ../vector/v.overlay/area_area.c:290
+#: ../vector/v.overlay/area_area.c:318
+msgid "Attribute not found"
+msgstr ""
+#: ../vector/v.overlay/area_area.c:51
+#, c-format
+msgid "Snapping boundaries with %g ..."
+msgstr ""
+#: ../vector/v.overlay/area_area.c:99
+#, c-format
+msgid "%d boundary snapped"
+msgid_plural "%d boundaries snapped"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.overlay/area_area.c:181
+#, c-format
+msgid "Querying vector map <%s>..."
+msgstr ""
+#: ../vector/v.perturb/main.c:70
+msgid "Random location perturbations of vector points."
+msgstr ""
+#: ../vector/v.perturb/main.c:84
+msgid "Distribution of perturbation"
+msgstr ""
+#: ../vector/v.perturb/main.c:91
+msgid "Parameter(s) of distribution"
+msgstr ""
+#: ../vector/v.perturb/main.c:92
+msgid "If the distribution is uniform, only one parameter, the maximum, is needed. For a normal distribution, two parameters, the mean and standard deviation, are required."
+msgstr ""
+#: ../vector/v.perturb/main.c:102
+msgid "Minimum deviation in map units"
+msgstr ""
+#: ../vector/v.perturb/main.c:109
+msgid "Seed for random number generation"
+msgstr ""
+#: ../vector/v.perturb/main.c:130 ../vector/v.perturb/main.c:137
+msgid "Error scanning arguments"
+msgstr ""
+#: ../vector/v.perturb/main.c:133
+msgid "Maximum of uniform distribution must be >= zero"
+msgstr ""
+#: ../vector/v.perturb/main.c:140
+msgid "Standard deviation of normal distribution must be >= zero"
+msgstr ""
+#: ../vector/v.perturb/main.c:245
+msgid "Cannot get db link info"
+msgstr ""
+#: ../vector/v.perturb/normalrs.c:31
+msgid "normalsv: restoration of uninitialized block"
+msgstr ""
+#: ../vector/v.perturb/normalsv.c:29
+msgid "normalsv: save of uninitialized block"
+msgstr ""
+#: ../vector/v.net.iso/main.c:79
+msgid "isolines"
+msgstr ""
+#: ../vector/v.net.iso/main.c:80
+msgid "Splits subnets for nearest centers by cost isolines."
+msgstr ""
+#: ../vector/v.net.iso/main.c:82
+msgid "Splits net to bands between cost isolines (direction from center). Center node must be opened (costs >= 0). Costs of center node are used in calculation."
+msgstr ""
+#: ../vector/v.net.iso/main.c:95 ../vector/v.net.alloc/main.c:81
+msgid "Use costs from centers or costs to centers"
+msgstr ""
+#: ../vector/v.net.iso/main.c:102 ../vector/v.net.alloc/main.c:88
+msgid "Categories of centers (points on nodes) to which net will be allocated, layer for this categories is given by nlayer option"
+msgstr ""
+#: ../vector/v.net.iso/main.c:111
+msgid "Costs for isolines"
+msgstr ""
+#: ../vector/v.net.iso/main.c:177 ../vector/v.net.alloc/main.c:156
+msgid "Create unique categories and attribute table"
+msgstr ""
+#: ../vector/v.net.iso/main.c:179
+msgid "Default: one category for each iso-band"
+msgstr ""
+#: ../vector/v.net.iso/main.c:215
+#, c-format
+msgid "Wrong iso cost: %f"
+msgstr ""
+#: ../vector/v.net.iso/main.c:218
+#, c-format
+msgid "Iso cost: %f less than previous"
+msgstr ""
+#: ../vector/v.net.iso/main.c:223
+#, c-format
+msgid "Iso cost %d: %f"
+msgstr ""
+#: ../vector/v.net.iso/main.c:231
+msgid "Not enough costs, everything reachable falls to first band"
+msgstr ""
+#: ../vector/v.net.iso/main.c:282 ../vector/v.net.salesman/main.c:277
+#: ../vector/v.net.alloc/main.c:224
+msgid "Point is not connected to the network"
+msgstr ""
+#: ../vector/v.net.iso/main.c:290 ../vector/v.net.alloc/main.c:232
+msgid "Center at closed node (costs = -1) ignored"
+msgstr ""
+#: ../vector/v.net.iso/main.c:308 ../vector/v.net.alloc/main.c:250
+#, c-format
+msgid "Number of centers: %d (nlayer %d)"
+msgstr ""
+#: ../vector/v.net.iso/main.c:311 ../vector/v.net.alloc/main.c:253
+msgid "Not enough centers for selected nlayer. Nothing will be allocated."
+msgstr ""
+#: ../vector/v.net.iso/main.c:333 ../vector/v.net.iso/main.c:345
+#: ../vector/v.net.alloc/main.c:275 ../vector/v.net.alloc/main.c:287
+msgid "Calculating costs from centers ..."
+msgstr ""
+#: ../vector/v.net.iso/main.c:338 ../vector/v.net.iso/main.c:349
+#: ../vector/v.net.alloc/main.c:280 ../vector/v.net.alloc/main.c:291
+msgid "Calculating costs to centers ..."
+msgstr ""
+#: ../vector/v.net.iso/main.c:403
+msgid "Generating isolines..."
+msgstr ""
+#: ../vector/v.net.iso/main.c:704 ../vector/v.net.alloc/main.c:592
+#: ../vector/v.net.alloc/main.c:627
+msgid "Cannot get line segment, segment out of line"
+msgstr ""
+#: ../vector/v.to.3d/main.c:40
+msgid "Performs transformation of 2D vector features to 3D."
+msgstr ""
+#: ../vector/v.to.3d/main.c:52
+#, c-format
+msgid "Either '%s' or '%s' parameter have to be used"
+msgstr ""
+#: ../vector/v.to.3d/main.c:58
+#, c-format
+msgid "Parameters '%s' ignored"
+msgstr ""
+#: ../vector/v.to.3d/main.c:63
+msgid "Attribute table required"
+msgstr ""
+#: ../vector/v.to.3d/main.c:76
+#, c-format
+msgid "Vector map <%s> is 2D"
+msgstr ""
+#: ../vector/v.to.3d/main.c:80
+#, c-format
+msgid "Vector map <%s> is 3D"
+msgstr ""
+#: ../vector/v.to.3d/main.c:96 ../vector/v.to.3d/main.c:117
+#: ../vector/v.in.db/main.c:282 ../vector/v.net/main.c:156
+#: ../vector/v.transform/main.c:302
+msgid "Copying attributes..."
+msgstr ""
+#: ../vector/v.to.3d/main.c:98 ../vector/v.to.3d/main.c:119
+msgid "Unable to copy attributes"
+msgstr ""
+#: ../vector/v.to.3d/main.c:128
+#, c-format
+msgid "Vertical extent of vector map <%s>: B: %f T: %f"
+msgstr ""
+#: ../vector/v.to.3d/args.c:11
+msgid "Reverse transformation; 3D vector features to 2D"
+msgstr ""
+#: ../vector/v.to.3d/args.c:14
+msgid "Do not copy attribute table"
+msgstr ""
+#: ../vector/v.to.3d/args.c:30
+msgid "Name of attribute column used for height"
+msgstr ""
+#: ../vector/v.to.3d/args.c:32
+msgid "Can be used for reverse transformation, to store height of points"
+msgstr ""
+#: ../vector/v.to.3d/trans2.c:43 ../vector/v.to.3d/trans3.c:45
+#, c-format
+msgid "Invalid layer number %d, assuming 1"
+msgstr ""
+#: ../vector/v.to.3d/trans2.c:67 ../vector/v.to.3d/trans3.c:69
+msgid "Column must be numeric"
+msgstr ""
+#: ../vector/v.to.3d/trans2.c:70
+#, c-format
+msgid "Fetching height from <%s> column..."
+msgstr ""
+#: ../vector/v.to.3d/trans2.c:79 ../vector/v.to.3d/trans3.c:80
+#: ../vector/v.transform/main.c:296
+msgid "Transforming features..."
+msgstr ""
+#: ../vector/v.to.3d/trans2.c:101
+msgid "Skipping feature without category"
+msgstr ""
+#: ../vector/v.to.3d/trans2.c:116
+#, c-format
+msgid "Unable to get height for feature category %d"
+msgstr ""
+#: ../vector/v.to.3d/trans3.c:75
+msgid "Reading categories..."
+msgstr ""
+#: ../vector/v.to.3d/trans3.c:101
+#, c-format
+msgid "Feature id %d has no category - skipping"
+msgstr ""
+#: ../vector/v.to.3d/trans3.c:104
+#, c-format
+msgid "Feature id %d has more categories. Using category %d."
+msgstr ""
+#: ../vector/v.to.3d/trans3.c:130 ../vector/v.to.db/update.c:231
+#, c-format
+msgid "Record (cat %d) does not exist (not updated)"
+msgstr ""
+#: ../vector/v.timestamp/main.c:39
+msgid "Modifies a timestamp for a vector map."
+msgstr ""
+#: ../vector/v.timestamp/main.c:40
+msgid "Print/add/remove a timestamp for a vector map."
+msgstr ""
+#: ../vector/v.timestamp/main.c:66
+#, c-format
+msgid "Vector map <%s> not found %s"
+msgstr ""
+#: ../vector/v.type/main.c:44
+msgid "Changes type of vector features."
+msgstr ""
+#: ../vector/v.type/main.c:57
+msgid "Feature type to convert from"
+msgstr ""
+#: ../vector/v.type/main.c:65
+msgid "Feature type to convert to"
+msgstr ""
+#: ../vector/v.type/main.c:120
+msgid "Incompatible types"
+msgstr ""
+#: ../vector/v.what.rast/main.c:79
+msgid "Uploads raster values at positions of vector points to the table."
+msgstr ""
+#: ../vector/v.what.rast/main.c:93
+msgid "Name of existing raster map to be queried"
+msgstr ""
+#: ../vector/v.what.rast/main.c:105
+msgid "Interpolate values from the nearest four cells"
+msgstr ""
+#: ../vector/v.what.rast/main.c:110
+msgid "Print categories and values instead of updating the database"
+msgstr ""
+#: ../vector/v.what.rast/main.c:170
+#, c-format
+msgid "Column <%s> not found in the table <%s>. Creating..."
+msgstr ""
+#: ../vector/v.what.rast/main.c:177 ../vector/v.colors/write_rgb.c:37
+#, c-format
+msgid "Unable to add column <%s> to table <%s>"
+msgstr ""
+#: ../vector/v.what.rast/main.c:186
+msgid "Raster type is integer and column type is float"
+msgstr ""
+#: ../vector/v.what.rast/main.c:189
+msgid "Raster type is float and column type is integer, some data lost!!"
+msgstr ""
+#: ../vector/v.what.rast/main.c:271
+#, c-format
+msgid "No features of type (%s) found in vector map <%s>"
+msgstr ""
+#: ../vector/v.what.rast/main.c:295
+#, c-format
+msgid "%d points outside current region were skipped"
+msgstr ""
+#: ../vector/v.what.rast/main.c:299
+#, c-format
+msgid "%d points without category were skipped"
+msgstr ""
+#: ../vector/v.what.rast/main.c:570 ../vector/v.what.rast/main.c:610
+#, c-format
+msgid "Multiple points (%d) of category %d, value set to 'NULL'"
+msgstr ""
+#: ../vector/v.what.rast/main.c:678
+#, c-format
+msgid "%d categories loaded from vector"
+msgstr ""
+#: ../vector/v.what.rast/main.c:680
+#, c-format
+msgid "%d duplicate categories in vector map <%s>"
+msgstr ""
+#: ../vector/v.what.rast/main.c:684
+#, c-format
+msgid "%d categories loaded from table"
+msgstr ""
+#: ../vector/v.what.rast/main.c:685
+#, c-format
+msgid "%d categories from vector missing in table"
+msgstr ""
+#: ../vector/v.what.rast/main.c:688 ../vector/v.distance/main.c:1736
+#: ../vector/v.vect.stats/main.c:756
+#, c-format
+msgid "%d update errors"
+msgstr ""
+#: ../vector/v.what.rast/main.c:690 ../vector/v.distance/main.c:1738
+#, c-format
+msgid "%d records updated."
+msgstr ""
+#: ../vector/v.net.spanningtree/main.c:48
+msgid "spanning tree"
+msgstr ""
+#: ../vector/v.net.spanningtree/main.c:50
+msgid "Computes minimum spanning tree for the network."
+msgstr ""
+#: ../vector/v.net.steiner/main.c:58
+#, c-format
+msgid "Init costs from node %d"
+msgstr ""
+#: ../vector/v.net.steiner/main.c:348
+msgid "steiner tree"
+msgstr ""
+#: ../vector/v.net.steiner/main.c:350
+msgid "Creates Steiner tree for the network and given terminals."
+msgstr ""
+#: ../vector/v.net.steiner/main.c:352
+msgid "Note that 'Minimum Steiner Tree' problem is NP-hard and heuristic algorithm is used in this module so the result may be sub optimal."
+msgstr ""
+#: ../vector/v.net.steiner/main.c:373
+msgid "Node layer (used for terminals)"
+msgstr ""
+#: ../vector/v.net.steiner/main.c:379
+msgid "Arcs' cost column (for both directions)"
+msgstr ""
+#: ../vector/v.net.steiner/main.c:385
+msgid "Categories of points on terminals (layer is specified by nlayer)"
+msgstr ""
+#: ../vector/v.net.steiner/main.c:393
+msgid "Number of Steiner points (-1 for all possible)"
+msgstr ""
+#: ../vector/v.net.steiner/main.c:448
+#, c-format
+msgid "Point is not connected to the network (cat=%d)"
+msgstr ""
+#. GTC Terminal refers to an Steiner tree endpoint
+#: ../vector/v.net.steiner/main.c:458
+#, c-format
+msgid "Number of terminals: %d\n"
+msgstr ""
+#: ../vector/v.net.steiner/main.c:462
+msgid "Not enough terminals (< 2)"
+msgstr ""
+#: ../vector/v.net.steiner/main.c:469
+msgid "Requested number of Steiner points > than possible"
+msgstr ""
+#: ../vector/v.net.steiner/main.c:475
+#, c-format
+msgid "Number of Steiner points set to %d\n"
+msgstr ""
+#: ../vector/v.net.steiner/main.c:522
+#, c-format
+msgid "Terminal at node [%d] cannot be connected to terminal at node [%d]"
+msgstr ""
+#: ../vector/v.net.steiner/main.c:538
+#, c-format
+msgid "[%d] (not reachable) nodes removed from list of Steiner point candidates"
+msgstr ""
+#: ../vector/v.net.steiner/main.c:543
+#, c-format
+msgid "MST costs = %f"
+msgstr ""
+#: ../vector/v.net.steiner/main.c:549
+#, c-format
+msgid "Search for [%d]. Steiner point"
+msgstr ""
+#: ../vector/v.net.steiner/main.c:570
+#, c-format
+msgid "Steiner point at node [%d] was added to terminals (MST costs = %f)"
+msgstr ""
+#: ../vector/v.net.steiner/main.c:582
+msgid "No Steiner point found -> leaving cycle"
+msgstr ""
+#: ../vector/v.net.steiner/main.c:587
+#, c-format
+msgid "Number of added Steiner points: %d (theoretic max is %d).\n"
+msgstr ""
+#: ../vector/v.net.steiner/main.c:598
+#, c-format
+msgid ""
+"Spanning tree costs on complete graph = %f\n"
+"(may be higher than resulting Steiner tree costs!!!)"
+msgstr ""
+#: ../vector/v.net.steiner/main.c:603
+#, c-format
+msgid "Steiner tree costs = %f"
+msgstr ""
+#: ../vector/v.net.steiner/main.c:656
+#, c-format
+msgid "A Steiner tree with %d arc has been built"
+msgid_plural "A Steiner tree with %d arcs has been built"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.net.flow/main.c:62
+msgid "Computes the maximum flow between two sets of nodes in the network."
+msgstr ""
+#: ../vector/v.net.flow/main.c:84
+msgid "Name for output vector map containing a minimum cut"
+msgstr ""
+#: ../vector/v.net.flow/main.c:107
+msgid "Source category values"
+msgstr ""
+#: ../vector/v.net.flow/main.c:113
+msgid "Source WHERE conditions of SQL statement without 'where' keyword"
+msgstr ""
+#: ../vector/v.net.flow/main.c:118
+msgid "Sink category values"
+msgstr ""
+#: ../vector/v.net.flow/main.c:119 ../vector/v.net.flow/main.c:125
+msgid "Sink"
+msgstr ""
+#: ../vector/v.net.flow/main.c:124
+msgid "Sink WHERE conditions of SQL statement without 'where' keyword"
+msgstr ""
+#: ../vector/v.net.flow/main.c:199
+#, c-format
+msgid "No source features selected. Please check options '%s', '%s'."
+msgstr ""
+#: ../vector/v.net.flow/main.c:206
+#, c-format
+msgid "No sink features selected. Please check options '%s', '%s'."
+msgstr ""
+#: ../vector/v.net.flow/main.c:215
+msgid "No sources"
+msgstr ""
+#: ../vector/v.net.flow/main.c:218
+msgid "No sinks"
+msgstr ""
+#: ../vector/v.net.flow/main.c:242
+msgid "Writing the output..."
+msgstr ""
+#: ../vector/v.delaunay/memory.c:64 ../vector/v.delaunay/memory.c:70
+#: ../vector/v.delaunay/memory.c:74 ../vector/v.delaunay/memory.c:84
+#: ../vector/v.delaunay/memory.c:92 ../vector/v.delaunay/memory.c:104
+#: ../vector/v.delaunay/memory.c:108
+msgid "Not enough memory."
+msgstr ""
+#: ../vector/v.delaunay/memory.c:124
+msgid "All allocated edges have been used."
+msgstr ""
+#: ../vector/v.delaunay/main.c:87 ../vector/v.voronoi/main.c:125
+msgid "triangulation"
+msgstr ""
+#: ../vector/v.delaunay/main.c:88
+msgid "Creates a Delaunay triangulation from an input vector map containing points or centroids."
+msgstr ""
+#: ../vector/v.delaunay/main.c:98 ../vector/v.normal/main.c:96
+msgid "Use only points in current region"
+msgstr ""
+#: ../vector/v.delaunay/main.c:103
+msgid "Output triangulation as a graph (lines), not areas"
+msgstr ""
+#: ../vector/v.delaunay/main.c:147
+msgid "no points to triangulate"
+msgstr ""
+#: ../vector/v.delaunay/main.c:150
+msgid "Delaunay triangulation..."
+msgstr ""
+#: ../vector/v.delaunay/main.c:162
+msgid "Calculating area centroids..."
+msgstr ""
+#: ../vector/v.delaunay/main.c:178
+msgid "Unable to calculate area centroid z coordinate"
+msgstr ""
+#: ../vector/v.delaunay/in_out.c:93 ../vector/v.voronoi/main.c:230
+msgid "Writing edges..."
+msgstr ""
+#: ../vector/v.delaunay/in_out.c:214
+msgid "Reading point features..."
+msgstr ""
+#: ../vector/v.normal/main.c:76
+msgid "Tests for normality for vector points."
+msgstr ""
+#: ../vector/v.normal/main.c:88
+msgid "Lists of tests (1-15)"
+msgstr ""
+#: ../vector/v.normal/main.c:89
+msgid "E.g. 1,3-8,13"
+msgstr ""
+#: ../vector/v.normal/main.c:100
+msgid "Lognormality instead of normality"
+msgstr ""
+#: ../vector/v.normal/main.c:131
+msgid "Only numeric column type supported"
+msgstr ""
+#: ../vector/v.normal/main.c:174 ../vector/v.normal/main.c:182
+#, c-format
+msgid "No record for cat %d"
+msgstr ""
+#: ../vector/v.normal/main.c:192
+#, c-format
+msgid "Number of points: %d"
+msgstr ""
+#: ../vector/v.normal/main.c:198
+msgid "Too small sample"
+msgstr ""
+#: ../vector/v.normal/main.c:206
+msgid "Negative or very small point values set to -10.0"
+msgstr ""
+#: ../vector/v.normal/main.c:223
+#, c-format
+msgid "Moments \\sqrt{b_1} and b_2: "
+msgstr ""
+#: ../vector/v.normal/main.c:228
+#, c-format
+msgid "Geary's a-statistic & an approx. normal: "
+msgstr ""
+#: ../vector/v.normal/main.c:233
+#, c-format
+msgid "Extreme normal deviates: "
+msgstr ""
+#: ../vector/v.normal/main.c:238
+#, c-format
+msgid "D'Agostino's D & an approx. normal: "
+msgstr ""
+#: ../vector/v.normal/main.c:244
+#, c-format
+msgid "Kuiper's V (regular & modified for normality): "
+msgstr ""
+#: ../vector/v.normal/main.c:250
+#, c-format
+msgid "Watson's U^2 (regular & modified for normality): "
+msgstr ""
+#: ../vector/v.normal/main.c:256
+#, c-format
+msgid "Durbin's Exact Test (modified Kolmogorov): "
+msgstr ""
+#: ../vector/v.normal/main.c:262
+#, c-format
+msgid "Anderson-Darling's A^2 (regular & modified for normality): "
+msgstr ""
+#: ../vector/v.normal/main.c:268
+#, c-format
+msgid "Cramer-Von Mises W^2(regular & modified for normality): "
+msgstr ""
+#: ../vector/v.normal/main.c:274
+#, c-format
+msgid "Kolmogorov-Smirnov's D (regular & modified for normality): "
+msgstr ""
+#: ../vector/v.normal/main.c:280
+#, c-format
+msgid "Chi-Square stat (equal probability classes) and d.f.: "
+msgstr ""
+#: ../vector/v.normal/main.c:286
+msgid "Shapiro-Wilk's W cannot be used for n > 50"
+msgstr ""
+#: ../vector/v.normal/main.c:288
+msgid "Use Weisberg-Binghams's W''"
+msgstr ""
+#: ../vector/v.normal/main.c:291
+#, c-format
+msgid "Shapiro-Wilk W: "
+msgstr ""
+#: ../vector/v.normal/main.c:298
+msgid "Weisberg-Bingham's W'' cannot be used for n < 50 or n > 99"
+msgstr ""
+#: ../vector/v.normal/main.c:300
+#, c-format
+msgid "Weisberg-Bingham's W'': "
+msgstr ""
+#: ../vector/v.normal/main.c:307
+msgid "Royston only extended Shapiro-Wilk's W up to n = 2000"
+msgstr ""
+#: ../vector/v.normal/main.c:309
+#, c-format
+msgid "Shapiro-Wilk W'': "
+msgstr ""
+#: ../vector/v.normal/main.c:315
+#, c-format
+msgid "Kotz' T'_f (Lognormality vs. Normality): "
+msgstr ""
+#: ../vector/v.sample/main.c:79
+msgid "Samples a raster map at vector point locations."
+msgstr ""
+#: ../vector/v.sample/main.c:89
+msgid "Name of attribute column to use for comparison"
+msgstr ""
+#: ../vector/v.sample/main.c:92
+msgid "Name for output vector map to store differences"
+msgstr ""
+#: ../vector/v.sample/main.c:96
+msgid "Name of raster map to be sampled"
+msgstr ""
+#: ../vector/v.sample/main.c:107
+msgid "Scaling factor for values read from raster map"
+msgstr ""
+#: ../vector/v.sample/main.c:109
+msgid "Sampled values will be multiplied by this factor"
+msgstr ""
+#: ../vector/v.sample/main.c:148
+#, c-format
+msgid "Column type <%s> not supported (must be integer or double precision)"
+msgstr ""
+#: ../vector/v.sample/main.c:154
+#, c-format
+msgid "%d record selected from table"
+msgid_plural "%d records selected from table"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.rectify/cp.c:307 ../vector/v.rectify/cp.c:331
+#, c-format
+msgid "Can not open file <%s>"
+msgstr ""
+#: ../vector/v.rectify/cp.c:314 ../vector/v.rectify/cp.c:338
+#, c-format
+msgid "Bad format in control point file <%s>"
+msgstr ""
+#: ../vector/v.rectify/cp.c:367
+msgid "Not enough memory to solve for transformation equation"
+msgstr ""
+#: ../vector/v.rectify/main.c:75
+msgid "Rectifies a vector by computing a coordinate transformation for each object in the vector based on the control points."
+msgstr ""
+#: ../vector/v.rectify/main.c:90
+msgid "Name of input file with control points"
+msgstr ""
+#: ../vector/v.rectify/main.c:95
+msgid "Name of output file with RMS errors (if omitted or '-' output to stdout"
+msgstr ""
+#: ../vector/v.rectify/main.c:107
+msgid "Field separator for RMS report"
+msgstr ""
+#: ../vector/v.rectify/main.c:111
+msgid "Perform 3D transformation"
+msgstr ""
+#: ../vector/v.rectify/main.c:115
+msgid "Perform orthogonal 3D transformation"
+msgstr ""
+#: ../vector/v.rectify/main.c:119
+msgid "Print RMS errors"
+msgstr ""
+#: ../vector/v.rectify/main.c:120
+msgid "Print RMS errors and exit without rectifying the input map"
+msgstr ""
+#: ../vector/v.rectify/main.c:138
+msgid "Please select a group or give an input file."
+msgstr ""
+#: ../vector/v.rectify/main.c:140
+msgid "Points in group will be ignored, GCPs in input file are used."
+msgstr ""
+#: ../vector/v.rectify/main.c:156
+msgid "3D transformation requires a 3D vector"
+msgstr ""
+#: ../vector/v.rectify/main.c:159
+msgid "A file with 3D control points is needed for 3D transformation"
+msgstr ""
+#: ../vector/v.rectify/main.c:172 ../vector/v.net.salesman/main.c:580
+#, c-format
+msgid "Unable to open file '%s' for writing"
+msgstr ""
+#: ../vector/v.rectify/main.c:203
+#, c-format
+msgid "The vector map <%s> already exists in"
+msgstr ""
+#: ../vector/v.rectify/main.c:206
+msgid "Rectification cancelled."
+msgstr ""
+#: ../vector/v.rectify/main.c:276 ../vector/v.category/main.c:761
+msgid "Copying attribute table(s)..."
+msgstr ""
+#: ../vector/v.rectify/target.c:43
+msgid "Please run i.target for group."
+msgstr ""
+#: ../vector/v.qcount/main.c:63
+msgid "Indices for quadrat counts of vector point lists."
+msgstr ""
+#: ../vector/v.qcount/main.c:72
+msgid "Name for output quadrat centers map (number of points is written as category)"
+msgstr ""
+#: ../vector/v.qcount/main.c:78
+msgid "Number of quadrats"
+msgstr ""
+#: ../vector/v.qcount/main.c:84
+msgid "Quadrat radius"
+msgstr ""
+#: ../vector/v.qcount/main.c:88
+msgid "Print results in shell script style"
+msgstr ""
+#: ../vector/v.qcount/main.c:104
+msgid "Finding quadrats..."
+msgstr ""
+#: ../vector/v.qcount/main.c:109
+msgid "Counting points quadrats..."
+msgstr ""
+#: ../vector/v.univar/main.c:98
+msgid "Calculates univariate statistics of vector map features."
+msgstr ""
+#: ../vector/v.univar/main.c:99
+msgid "Variance and standard deviation is calculated only for points if specified."
+msgstr ""
+#: ../vector/v.univar/main.c:134
+msgid "Weigh by line length or area size"
+msgstr ""
+#: ../vector/v.univar/main.c:138
+msgid "Calculate geometric distances instead of attribute statistics"
+msgstr ""
+#: ../vector/v.univar/main.c:192
+#, c-format
+msgid "Geometry distances are not supported for areas. Use '%s' instead."
+msgstr ""
+#: ../vector/v.univar/main.c:195
+msgid "Incompatible vector type(s) specified, only number of features, minimum, maximum and range can be calculated"
+msgstr ""
+#: ../vector/v.univar/main.c:200
+msgid "Extended statistics is currently supported only for points/centroids"
+msgstr ""
+#: ../vector/v.univar/main.c:225
+msgid "'layer' must be > 0 for 'where'."
+msgstr ""
+#: ../vector/v.univar/main.c:242
+#, c-format
+msgid "Unable select categories from table <%s>"
+msgstr ""
+#: ../vector/v.univar/main.c:253
+#, c-format
+msgid "Calculating geometric distances between %d primitives..."
+msgstr ""
+#: ../vector/v.univar/main.c:343
+#, c-format
+msgid " Database connection not defined for layer <%s>"
+msgstr ""
+#: ../vector/v.univar/main.c:652
+msgid "Cannot sort the key/value array"
+msgstr ""
+#: ../vector/v.distance/distance.c:49
+#, c-format
+msgid "Invalid segment number %d for %d points"
+msgstr ""
+#: ../vector/v.distance/distance.c:426
+msgid "At least one point is really inside the area!"
+msgstr ""
+#: ../vector/v.distance/main.c:126
+msgid "Finds the nearest element in vector map 'to' for elements in vector map 'from'."
+msgstr ""
+#: ../vector/v.distance/main.c:130
+msgid "Name of existing vector map (from)"
+msgstr ""
+#: ../vector/v.distance/main.c:135
+msgid "Layer number or name (from)"
+msgstr ""
+#: ../vector/v.distance/main.c:142
+msgid "Feature type (from)"
+msgstr ""
+#: ../vector/v.distance/main.c:147
+msgid "Name of existing vector map (to)"
+msgstr ""
+#: ../vector/v.distance/main.c:152
+msgid "Layer number or name (to)"
+msgstr ""
+#: ../vector/v.distance/main.c:159
+msgid "Feature type (to)"
+msgstr ""
+#: ../vector/v.distance/main.c:165
+msgid "Name for output vector map containing lines connecting nearest elements"
+msgstr ""
+#: ../vector/v.distance/main.c:173
+msgid "Maximum distance or -1 for no limit"
+msgstr ""
+#: ../vector/v.distance/main.c:180
+msgid "Minimum distance or -1 for no limit"
+msgstr ""
+#: ../vector/v.distance/main.c:190
+msgid "Values describing the relation between two nearest features"
+msgstr ""
+#: ../vector/v.distance/main.c:200
+msgid "category of the nearest feature"
+msgstr ""
+#: ../vector/v.distance/main.c:201
+msgid "minimum distance to nearest feature"
+msgstr ""
+#: ../vector/v.distance/main.c:202
+msgid "x coordinate of the nearest point on the 'to' feature"
+msgstr ""
+#: ../vector/v.distance/main.c:203
+msgid "y coordinate of the nearest point on the 'to' feature"
+msgstr ""
+#: ../vector/v.distance/main.c:204
+msgid "distance to the nearest point on the 'to' feature along that linear feature"
+msgstr ""
+#: ../vector/v.distance/main.c:206
+msgid "angle along the nearest linear feature in the 'to' map, measured CCW from the +x axis, in radians, between -Pi and Pi inclusive"
+msgstr ""
+#: ../vector/v.distance/main.c:209
+msgid "attribute of nearest feature given by to_column option"
+msgstr ""
+#: ../vector/v.distance/main.c:223
+msgid "Column name(s) where values specified by 'upload' option will be uploaded"
+msgstr ""
+#: ../vector/v.distance/main.c:229
+msgid "Column name of nearest feature (used with upload=to_attr)"
+msgstr ""
+#: ../vector/v.distance/main.c:234
+msgid "Name for new attribute table"
+msgstr ""
+#: ../vector/v.distance/main.c:237
+msgid "Field separator for printing output to stdout"
+msgstr ""
+#: ../vector/v.distance/main.c:242
+msgid "Print output to stdout, don't update attribute table"
+msgstr ""
+#: ../vector/v.distance/main.c:244
+msgid "First column is always category of 'from' feature called from_cat"
+msgstr ""
+#: ../vector/v.distance/main.c:249
+msgid "Calculate distances to all features within the threshold"
+msgstr ""
+#: ../vector/v.distance/main.c:251
+msgid "Output may be written to stdout using the '-p' flag or uploaded to a new table created by the 'table' option; multiple 'upload' options may be used."
+msgstr ""
+#: ../vector/v.distance/main.c:291
+msgid "Updating the from= table is not supported with -a"
+msgstr ""
+#: ../vector/v.distance/main.c:307
+msgid "Printing distance matrix is not supported with dmin= or dmax="
+msgstr ""
+#: ../vector/v.distance/main.c:334
+msgid "to_column option missing"
+msgstr ""
+#: ../vector/v.distance/main.c:350
+msgid "Too many column names"
+msgstr ""
+#: ../vector/v.distance/main.c:357
+msgid "Not enough column names"
+msgstr ""
+#: ../vector/v.distance/main.c:369 ../vector/v.distance/main.c:389
+#, c-format
+msgid "Input vector map <%s> is 3D"
+msgstr ""
+#: ../vector/v.distance/main.c:380 ../vector/v.distance/main.c:401
+#, c-format
+msgid "No features of selected type found in <%s>"
+msgstr ""
+#: ../vector/v.distance/main.c:474
+msgid "dmin can not be larger than dmax"
+msgstr ""
+#: ../vector/v.distance/main.c:617
+msgid "Incompatible column types"
+msgstr ""
+#: ../vector/v.distance/main.c:667
+msgid "No categories for 'from' for slected type and layer"
+msgstr ""
+#: ../vector/v.distance/main.c:695
+msgid "Finding nearest features..."
+msgstr ""
+#: ../vector/v.distance/main.c:796 ../vector/v.distance/main.c:1083
+#, c-format
+msgid "More cats found in to_layer (line=%d)"
+msgstr ""
+#: ../vector/v.distance/main.c:873 ../vector/v.distance/main.c:1230
+#, c-format
+msgid "More cats found in to_layer (area=%d)"
+msgstr ""
+#: ../vector/v.distance/main.c:983
+msgid "Finding nearest features for areas..."
+msgstr ""
+#: ../vector/v.distance/main.c:1349
+msgid "DATETIME type not yet supported, no attributes will be uploaded"
+msgstr ""
+#: ../vector/v.distance/main.c:1365
+msgid "Unable to open default database"
+msgstr ""
+#: ../vector/v.distance/main.c:1707
+#, c-format
+msgid "%d categories with more than 1 feature in vector map <%s>"
+msgstr ""
+#: ../vector/v.distance/main.c:1710
+#, c-format
+msgid "%d categories - no nearest feature found"
+msgstr ""
+#: ../vector/v.distance/main.c:1719
+#, c-format
+msgid "%d distances calculated"
+msgstr ""
+#: ../vector/v.distance/main.c:1720
+#, c-format
+msgid "%d records inserted"
+msgstr ""
+#: ../vector/v.distance/main.c:1722
+#, c-format
+msgid "%d insert errors"
+msgstr ""
+#: ../vector/v.distance/main.c:1726
+#, c-format
+msgid "%d categories read from the map"
+msgstr ""
+#: ../vector/v.distance/main.c:1728
+#, c-format
+msgid "%d categories exist in the table"
+msgstr ""
+#: ../vector/v.distance/main.c:1730
+#, c-format
+msgid "%d categories read from the map exist in the table"
+msgstr ""
+#: ../vector/v.distance/main.c:1733
+#, c-format
+msgid "%d categories read from the map don't exist in the table"
+msgstr ""
+#: ../vector/v.net.timetable/main.c:218
+#, c-format
+msgid "Could not find a path between stops %d and %d"
+msgstr ""
+#: ../vector/v.net.timetable/main.c:263
+msgid "Finds shortest path using timetables."
+msgstr ""
+#: ../vector/v.net.timetable/main.c:309
+msgid "Layer number or name with walking connections or -1"
+msgstr ""
+#: ../vector/v.net.timetable/main.c:315
+msgid "Name of column with route ids"
+msgstr ""
+#: ../vector/v.net.timetable/main.c:322
+msgid "Name of column with stop timestamps"
+msgstr ""
+#: ../vector/v.net.timetable/main.c:328
+msgid "Name of column with stop ids"
+msgstr ""
+#: ../vector/v.net.timetable/main.c:334
+msgid "Name of column with walk lengths"
+msgstr ""
+#: ../vector/v.net.timetable/main.c:381
+msgid "Could not initialize the timetables"
+msgstr ""
+#: ../vector/v.net.timetable/main.c:459 ../vector/v.net.timetable/main.c:490
+#: ../vector/v.net.timetable/main.c:498
+#, c-format
+msgid "No stop with category: %d"
+msgstr ""
+#: ../vector/v.net.timetable/main.c:505
+msgid "'From' and 'To' stops are the same"
+msgstr ""
+#: ../vector/v.net.timetable/main.c:514
+msgid "No path between the stops"
+msgstr ""
+#: ../vector/v.in.db/main.c:57
+msgid "Creates new vector (points) map from database table containing coordinates."
+msgstr ""
+#: ../vector/v.in.db/main.c:61
+msgid "Input table name"
+msgstr ""
+#: ../vector/v.in.db/main.c:66 ../vector/v.in.db/main.c:70
+msgid "Input DB"
+msgstr ""
+#: ../vector/v.in.db/main.c:75
+msgid "Name of column containing x coordinate"
+msgstr ""
+#: ../vector/v.in.db/main.c:80
+msgid "Name of column containing y coordinate"
+msgstr ""
+#: ../vector/v.in.db/main.c:84
+msgid "Name of column containing z coordinate"
+msgstr ""
+#: ../vector/v.in.db/main.c:90
+msgid "Name of column containing category number"
+msgstr ""
+#: ../vector/v.in.db/main.c:91
+msgid "Must refer to an integer column"
+msgstr ""
+#: ../vector/v.in.db/main.c:101
+msgid "Use imported table as attribute table for new map"
+msgstr ""
+#: ../vector/v.in.db/main.c:141
+#, c-format
+msgid "Vector map <%s> cannot be overwritten because input table <%s> is linked to this map."
+msgstr ""
+#: ../vector/v.in.db/main.c:177
+#, c-format
+msgid "Output vector map, table <%s> (driver: <%s>, database: <%s>) already exists"
+msgstr ""
+#: ../vector/v.in.db/main.c:194
+#, c-format
+msgid "Option <%s> must be specified when -%c flag is given"
+msgstr ""
+#: ../vector/v.in.db/main.c:199
+#, c-format
+msgid "Unable to define key column. This operation is not supported by <%s> driver. You need to define <%s> option."
+msgstr ""
+#: ../vector/v.in.db/main.c:235 ../vector/v.voronoi/main.c:322
+msgid "Writing features..."
+msgstr ""
+#: ../vector/v.in.db/main.c:243
+msgid "Key column must be integer"
+msgstr ""
+#: ../vector/v.in.db/main.c:256
+msgid "x/y/z column must be integer or double"
+msgstr ""
+#: ../vector/v.in.db/main.c:288
+msgid "Unable to copy table"
+msgstr ""
+#: ../vector/v.in.db/main.c:313
+#, c-format
+msgid "Unable to add key column <%s>: SERIAL type is not supported by <%s>"
+msgstr ""
+#: ../vector/v.in.db/main.c:324
+#, c-format
+msgid "Failed to update key column <%s>"
+msgstr ""
+#: ../vector/v.in.db/main.c:340
+#, c-format
+msgid "%d point written to vector map."
+msgid_plural "%d points written to vector map."
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.in.ascii/main.c:76
+msgid "Creates a vector map from an ASCII points file or ASCII vector file."
+msgstr ""
+#: ../vector/v.in.ascii/main.c:94
+msgid "simple x,y[,z] list"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:95
+msgid "GRASS vector ASCII format"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:98
+msgid "Input file format"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:99 ../vector/v.in.ascii/main.c:102
+#: ../vector/v.in.ascii/main.c:109 ../vector/v.in.ascii/main.c:187
+msgid "Input format"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:108
+msgid "Special characters: doublequote, singlequote, none"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:118
+msgid "Number of header lines to skip at top of input file (points mode)"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:127
+msgid "Column definition in SQL style (points mode)"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:128
+msgid "For example: 'x double precision, y double precision, cat int, name varchar(10)'"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:140 ../vector/v.in.ascii/main.c:150
+msgid "First column is 1"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:149
+msgid "Number of column used as y coordinate (points mode)"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:159
+msgid "Number of column used as z coordinate (points mode)"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:160
+msgid "First column is 1. If 0, z coordinate is not used"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:170
+msgid "Number of column used as category (points mode)"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:172
+msgid "First column is 1. If 0, unique category is assigned to each row and written to new column 'cat'"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:181
+msgid "Create a new empty vector map and exit. Nothing is read from input."
+msgstr ""
+#: ../vector/v.in.ascii/main.c:186
+msgid "Do not expect a header when reading in standard format"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:191
+msgid "Do not create table in points mode"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:201
+msgid "Only import points falling within current region (points mode)"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:206
+msgid "Ignore broken line(s) in points mode"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:223
+msgid "Please specify z column"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:234
+msgid "Please specify reasonable z column"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:239
+msgid "Column numbers must not be negative"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:283
+#, c-format
+msgid "Maximum input row length: %d"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:285
+#, c-format
+msgid "Maximum number of columns: %d"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:286
+#, c-format
+msgid "Minimum number of columns: %d"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:289
+#, c-format
+msgid "Number of columns: %d"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:292
+#, c-format
+msgid "Number of rows: %d"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:296 ../vector/v.in.ascii/main.c:300
+#: ../vector/v.in.ascii/main.c:305 ../vector/v.in.ascii/main.c:310
+#, c-format
+msgid "'%s' column number > minimum last column number (incorrect field separator or format?)"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:315 ../vector/v.in.ascii/main.c:318
+#: ../vector/v.in.ascii/main.c:321 ../vector/v.in.ascii/main.c:324
+#, c-format
+msgid "'%s' column is not of number type"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:366
+msgid "Category column is not of integer type"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:443
+#, c-format
+msgid "Number of columns defined (%d) does not match number of columns (%d) in input"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:471
+#, c-format
+msgid "Column number %d <%s> defined as double has only integer values"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:476
+#, c-format
+msgid "Column number %d <%s> defined as string has only integer values"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:483
+#, c-format
+msgid "Column number %d <%s> defined as integer has double values"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:488
+#, c-format
+msgid "Column number %d <%s> defined as string has double values"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:495
+#, c-format
+msgid "Column number %d <%s> defined as integer has string values"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:500
+#, c-format
+msgid "Column number %d <%s> defined as double has string values"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:505
+#, c-format
+msgid "Length of column %d <%s> (%d) is less than maximum value length (%d)"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:541
+msgid "Populating table..."
+msgstr ""
+#: ../vector/v.in.ascii/main.c:544
+msgid "Unable to close attribute table. The DBMI driver did not accept all attributes"
+msgstr ""
+#: ../vector/v.in.ascii/points.c:82
+msgid "Scanning input for column types..."
+msgstr ""
+#: ../vector/v.in.ascii/points.c:130
+#, c-format
+msgid "Row %d: '%s' can not be imported into the attribute table"
+msgstr ""
+#: ../vector/v.in.ascii/points.c:134 ../vector/v.in.ascii/points.c:144
+#, c-format
+msgid "Broken row %d: '%s'"
+msgstr ""
+#: ../vector/v.in.ascii/points.c:188 ../vector/v.in.ascii/points.c:207
+#, c-format
+msgid ""
+"Current row %d:\n"
+"%s\n"
+msgstr ""
+#: ../vector/v.in.ascii/points.c:189 ../vector/v.in.ascii/points.c:217
+#, c-format
+msgid "Unparsable longitude value in column %d: %s"
+msgstr ""
+#: ../vector/v.in.ascii/points.c:208 ../vector/v.in.ascii/points.c:221
+#, c-format
+msgid "Unparsable latitude value in column %d: %s"
+msgstr ""
+#: ../vector/v.in.ascii/points.c:298
+#, c-format
+msgid "Skipping %d of %d row falling outside of current region"
+msgid_plural "Skipping %d of %d rows falling outside of current region"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.in.ascii/points.c:328
+msgid "Importing points..."
+msgstr ""
+#: ../vector/v.net.visibility/main.c:48
+msgid "visibility"
+msgstr ""
+#: ../vector/v.net.visibility/main.c:49
+msgid "Performs visibility graph construction."
+msgstr ""
+#: ../vector/v.net.visibility/main.c:60
+msgid "Name of input vector map containing visible points"
+msgstr ""
+#: ../vector/v.net.visibility/main.c:61
+msgid "Add points after computing the visibility graph"
+msgstr ""
+#: ../vector/v.net.visibility/main.c:85
+#, c-format
+msgid "Unable to copy elements from vector map <%s>"
+msgstr ""
+#: ../vector/v.net.visibility/main.c:90
+msgid "Lat-long projection"
+msgstr ""
+#: ../vector/v.out.pov/main.c:49
+msgid "Converts GRASS x,y,z points to POV-Ray x,z,y format."
+msgstr ""
+#: ../vector/v.out.pov/main.c:60
+msgid "Name for output POV file"
+msgstr ""
+#: ../vector/v.out.pov/main.c:67
+msgid "Radius of sphere for points and tube for lines"
+msgstr ""
+#: ../vector/v.out.pov/main.c:68
+msgid "May be also variable, e.g. grass_r."
+msgstr ""
+#: ../vector/v.out.pov/main.c:74
+msgid "Modifier for z coordinates"
+msgstr ""
+#: ../vector/v.out.pov/main.c:75
+msgid "This string is appended to each z coordinate. Examples: '*10', '+1000', '*10+100', '*exaggeration'"
+msgstr ""
+#: ../vector/v.out.pov/main.c:82
+msgid "Object modifier (OBJECT_MODIFIER in POV-Ray documentation)"
+msgstr ""
+#: ../vector/v.out.pov/main.c:83
+msgid "Example: \"pigment { color red 0 green 1 blue 0 }\""
+msgstr ""
+#: ../vector/v.out.pov/main.c:218
+#, c-format
+msgid "%d feature written."
+msgid_plural "%d features written."
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.to.points/main.c:61
+msgid "Creates points along input lines in new vector map with 2 layers."
+msgstr ""
+#: ../vector/v.to.points/main.c:79
+msgid "Use line nodes or vertices only"
+msgstr ""
+#: ../vector/v.to.points/main.c:87
+msgid "Maximum distance between points in map units or percentage with -p"
+msgstr ""
+#: ../vector/v.to.points/main.c:91
+msgid "Interpolate points between line vertices (only for use=vertex)"
+msgstr ""
+#: ../vector/v.to.points/main.c:95
+msgid "Use dmax as percentage of line length"
+msgstr ""
+#: ../vector/v.to.points/main.c:99
+msgid "Start from the end node"
+msgstr ""
+#: ../vector/v.to.points/main.c:165 ../vector/v.extract/copy_tab.c:108
+#: ../vector/v.generalize/misc.c:184
+#: ../scripts/v.db.reconnect.all/v.db.reconnect.all.py:128
+msgid "Unable to copy table <%s>"
+msgstr ""
+#: ../vector/v.to.points/main.c:246
+#, c-format
+msgid "%d features without category in layer <%d> skipped. Note that features without category (usually boundaries) are not skipped when '%s=-1' is given."
+msgstr ""
+#: ../vector/v.to.points/main.c:310
+#, c-format
+msgid "%d points written to output vector map."
+msgstr ""
+#: ../vector/v.colors/main.c:58
+msgid "Creates/modifies the color table associated with a vector map."
+msgstr ""
+#: ../vector/v.colors/main.c:70
+msgid "Source values"
+msgstr ""
+#: ../vector/v.colors/main.c:73
+msgid "read values from attribute table (requires <column> option)"
+msgstr ""
+#: ../vector/v.colors/main.c:75
+msgid "use z coordinate (3D points or centroids only)"
+msgstr ""
+#: ../vector/v.colors/main.c:79
+msgid "Name of column containing numeric data"
+msgstr ""
+#: ../vector/v.colors/main.c:80
+msgid "Required for use=attr"
+msgstr ""
+#: ../vector/v.colors/main.c:87
+msgid "Manually set range (refers to 'column' option)"
+msgstr ""
+#: ../vector/v.colors/main.c:88
+msgid "Ignored when 'rules' given"
+msgstr ""
+#: ../vector/v.colors/main.c:116
+msgid "Name of color column to populate RGB values"
+msgstr ""
+#: ../vector/v.colors/main.c:117
+msgid "If not given writes color table"
+msgstr ""
+#: ../vector/v.colors/main.c:152
+msgid "Convert color rules from RGB values to color table"
+msgstr ""
+#: ../vector/v.colors/main.c:153
+msgid "Option 'rgb_column' with valid RGB values required"
+msgstr ""
+#: ../vector/v.colors/main.c:196
+msgid "No vector map specified"
+msgstr ""
+#: ../vector/v.colors/main.c:201
+#, c-format
+msgid "Option <%s> given, assuming <use=attr>..."
+msgstr ""
+#: ../vector/v.colors/main.c:216
+#, c-format
+msgid "One of -%c, -%c or %s=, %s= or %s= must be specified"
+msgstr ""
+#: ../vector/v.colors/main.c:221
+#, c-format
+msgid "%s=, %s= and %s= are mutually exclusive"
+msgstr ""
+#: ../vector/v.colors/main.c:229
+#, c-format
+msgid "%s= required for -%c"
+msgstr ""
+#: ../vector/v.colors/main.c:234
+msgid "Reading rules from standard input is not implemented yet, please provide path to rules file instead."
+msgstr ""
+#: ../vector/v.colors/main.c:244
+#, c-format
+msgid "Unable to remove color table of vector map <%s>"
+msgstr ""
+#: ../vector/v.colors/main.c:246
+#, c-format
+msgid "Color table of vector map <%s> not found"
+msgstr ""
+#: ../vector/v.colors/main.c:254
+msgid "Color table exists. Exiting."
+msgstr ""
+#: ../vector/v.colors/main.c:276
+#, c-format
+msgid "Option <%s>: min must be greater or equal to max"
+msgstr ""
+#: ../vector/v.colors/main.c:282
+msgid "Reading color rules from standard input is currently not supported"
+msgstr ""
+#: ../vector/v.colors/main.c:289
+#, c-format
+msgid "Color table <%s> not found"
+msgstr ""
+#: ../vector/v.colors/main.c:347
+msgid "Writing color rules..."
+msgstr ""
+#: ../vector/v.colors/main.c:363
+#, c-format
+msgid "Color table for vector map <%s> set to '%s'"
+msgstr ""
+#: ../vector/v.colors/scan_z.c:68 ../vector/v.colors/scan_attr.c:59
+#, c-format
+msgid "Min value (%f) is out of range %f,%f"
+msgstr ""
+#: ../vector/v.colors/scan_z.c:74 ../vector/v.colors/scan_attr.c:65
+#, c-format
+msgid "Max value (%f) is out of range %f,%f"
+msgstr ""
+#: ../vector/v.colors/scan_cats.c:43 ../vector/v.colors/scan_attr.c:77
+#, c-format
+msgid "Min value (%d) is out of range %d,%d"
+msgstr ""
+#: ../vector/v.colors/scan_cats.c:49 ../vector/v.colors/scan_attr.c:83
+#, c-format
+msgid "Max value (%d) is out of range %d,%d"
+msgstr ""
+#: ../vector/v.colors/make_colors.c:14
+#, c-format
+msgid "Color table '%s' is not supported for floating point attributes"
+msgstr ""
+#: ../vector/v.colors/make_colors.c:18 ../vector/v.colors/make_colors.c:25
+#, c-format
+msgid "Color table <%s> not supported"
+msgstr ""
+#: ../vector/v.colors/scan_attr.c:38 ../vector/v.colors.out/make_colors.c:45
+#: ../scripts/db.univar/db.univar.py:118
+msgid "Column <%s> is not numeric"
+msgstr ""
+#: ../vector/v.colors/scan_attr.c:45 ../vector/v.colors.out/make_colors.c:52
+msgid "No data selected"
+msgstr ""
+#: ../vector/v.colors/scan_attr.c:108
+msgid "Converting color rules into categories..."
+msgstr ""
+#: ../vector/v.colors/read_rgb.c:32
+#, c-format
+msgid "Data type of RGB column <%s> must be char"
+msgstr ""
+#: ../vector/v.colors/read_rgb.c:37
+msgid "No RGB values found"
+msgstr ""
+#: ../vector/v.colors/read_rgb.c:65
+#, c-format
+msgid "%d invalid RGB color values skipped"
+msgstr ""
+#: ../vector/v.colors/write_rgb.c:60
+#, c-format
+msgid "Column <%s> added to table <%s>"
+msgstr ""
+#: ../vector/v.colors/write_rgb.c:64
+#, c-format
+msgid "Data type of column <%s> must be char"
+msgstr ""
+#: ../vector/v.colors/write_rgb.c:68
+msgid "No categories found"
+msgstr ""
+#: ../vector/v.colors/write_rgb.c:78
+#, c-format
+msgid "No color value defined for category %d"
+msgstr ""
+#: ../vector/v.colors/write_rgb.c:86
+msgid "Unable to update RGB values"
+msgstr ""
+#: ../vector/v.build/main.c:39
+msgid "Creates topology for vector map."
+msgstr ""
+#: ../vector/v.build/main.c:40
+msgid "Optionally also checks for topological errors."
+msgstr ""
+#: ../vector/v.build/main.c:44
+msgid "Name of vector map"
+msgstr ""
+#: ../vector/v.build/main.c:49
+msgid "Name for output vector map where erroneous vector features are written to"
+msgstr ""
+#: ../vector/v.build/main.c:61
+msgid "Build topology or dump topology or indices to standard output"
+msgstr ""
+#: ../vector/v.build/main.c:65
+msgid "build topology"
+msgstr ""
+#: ../vector/v.build/main.c:66
+msgid "write topology to stdout"
+msgstr ""
+#: ../vector/v.build/main.c:67
+msgid "write spatial index to stdout"
+msgstr ""
+#: ../vector/v.build/main.c:68
+msgid "write category index to stdout"
+msgstr ""
+#: ../vector/v.build/main.c:69
+msgid "write feature index to stdout (OGR simple-feature-based formats only)"
+msgstr ""
+#: ../vector/v.build/main.c:75
+msgid "Extensive checks for topological errors"
+msgstr ""
+#: ../vector/v.build/main.c:76
+msgid "Perform in-depth checks for topological errors when building topology"
+msgstr ""
+#: ../vector/v.build/main.c:106
+#, c-format
+msgid "Direct read access to OGR layers is not supported by this module. Run %s to create a link as GRASS vector map in the current mapset."
+msgstr ""
+#: ../vector/v.build/main.c:111
+#, c-format
+msgid "Vector map <%s> is not in current mapset"
+msgstr ""
+#: ../vector/v.voronoi/skeleton.c:293 ../vector/v.voronoi/skeleton.c:400
+#, c-format
+msgid "Pass %d"
+msgstr ""
+#: ../vector/v.voronoi/skeleton.c:509
+msgid "Node is outside any input area"
+msgstr ""
+#: ../vector/v.voronoi/main.c:126
+msgid "skeleton"
+msgstr ""
+#: ../vector/v.voronoi/main.c:127
+msgid "Creates a Voronoi diagram constrained to the extents of the current region from an input vector map containing points or centroids."
+msgstr ""
+#: ../vector/v.voronoi/main.c:131
+msgid "Name of input vector map"
+msgstr ""
+#: ../vector/v.voronoi/main.c:141
+msgid "Factor for output smoothness"
+msgstr ""
+#: ../vector/v.voronoi/main.c:142
+msgid "Applies to input areas only. Smaller values produce smoother output but can cause numerical instability."
+msgstr ""
+#: ../vector/v.voronoi/main.c:149
+msgid "Maximum dangle length of skeletons"
+msgstr ""
+#: ../vector/v.voronoi/main.c:150
+msgid "Applies only to skeleton extraction. Default = -1 will extract the center line."
+msgstr ""
+#: ../vector/v.voronoi/main.c:156
+msgid "Create Voronoi diagram for input areas"
+msgstr ""
+#: ../vector/v.voronoi/main.c:161
+msgid "Extract skeletons for input areas"
+msgstr ""
+#: ../vector/v.voronoi/main.c:166
+msgid "Output tessellation as a graph (lines), not areas"
+msgstr ""
+#: ../vector/v.voronoi/main.c:182
+#, c-format
+msgid "Option '%s' is too small, set to %g"
+msgstr ""
+#: ../vector/v.voronoi/main.c:226
+#, c-format
+msgid "Voronoi triangulation for %d point..."
+msgid_plural "Voronoi triangulation for %d points..."
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.voronoi/main.c:239
+msgid "Thin skeletons ..."
+msgstr ""
+#: ../vector/v.voronoi/main.c:396
+msgid "No table"
+msgstr ""
+#: ../vector/v.voronoi/main.c:411
+msgid "Cannot copy table"
+msgstr ""
+#: ../vector/v.voronoi/sw_main.c:188
+#, c-format
+msgid "Found %d point/centroid in <%s>, but at least 2 are needed. Are the current region extents covering at least parts of the input map?"
+msgid_plural "Found %d points/centroids in <%s>, but at least 2 are needed. Are the current region extents covering at least parts of the input map?"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.voronoi/sw_main.c:412 ../vector/v.voronoi/sw_main.c:438
+msgid "All boundaries in the list should be valid"
+msgstr ""
+#: ../vector/v.voronoi/sw_main.c:418 ../vector/v.voronoi/sw_main.c:444
+msgid "Boundary is degenerate"
+msgstr ""
+#: ../vector/v.voronoi/sw_main.c:470
+#, c-format
+msgid "Found %d vertex in <%s>, but at least 2 are needed"
+msgid_plural "Found %d vertices in <%s>, but at least 2 are needed"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.voronoi/clean_topo.c:20
+msgid "Searching for topology errors..."
+msgstr ""
+#: ../vector/v.voronoi/clean_topo.c:78
+msgid "Cleaning output topology"
+msgstr ""
+#: ../vector/v.voronoi/clean_topo.c:115
+msgid "Removing incorrect boundaries from output"
+msgstr ""
+#: ../vector/v.net.bridge/main.c:49
+msgid "articulation points"
+msgstr ""
+#: ../vector/v.net.bridge/main.c:51
+msgid "Computes bridges and articulation points in the network."
+msgstr ""
+#: ../vector/v.net.bridge/main.c:98
+msgid "Finds bridges"
+msgstr ""
+#: ../vector/v.net.bridge/main.c:99
+msgid "Finds articulation points"
+msgstr ""
+#: ../vector/v.net.bridge/main.c:101 ../vector/v.vect.stats/main.c:151
+#: ../vector/v.to.db/parse.c:41
+msgid "Feature type"
+msgstr ""
+#: ../vector/v.neighbors/main.c:55
+msgid "Neighborhood analysis tool for vector point maps."
+msgstr ""
+#: ../vector/v.neighbors/main.c:56
+msgid "Makes each cell value a function of the attribute values assigned to the vector points or centroids around it, and stores new cell values in an output raster map."
+msgstr ""
+#: ../vector/v.neighbors/main.c:78
+msgid "Neighborhood diameter in map units"
+msgstr ""
+#: ../vector/v.neighbors/main.c:98
+msgid "Input vector and computational region do not overlap"
+msgstr ""
+#: ../vector/v.neighbors/main.c:103
+#, c-format
+msgid "The search diameter %g is smaller than cell diagonal %g: some points could not be detected"
+msgstr ""
+#: ../vector/v.split/main.c:56
+msgid "densification"
+msgstr ""
+#: ../vector/v.split/main.c:60
+msgid "Splits vector lines to shorter segments."
+msgstr ""
+#: ../vector/v.split/main.c:73
+msgid "Maximum segment length"
+msgstr ""
+#: ../vector/v.split/main.c:82
+msgid "Length units"
+msgstr ""
+#: ../vector/v.split/main.c:89
+msgid "Maximum number of vertices in segment"
+msgstr ""
+#: ../vector/v.split/main.c:93
+msgid "Add new vertices, but do not split"
+msgstr ""
+#: ../vector/v.split/main.c:94 ../vector/v.split/main.c:99
+msgid "Applies only to 'length' option"
+msgstr ""
+#: ../vector/v.split/main.c:98
+msgid "Force segments to be exactly of given length, except for last one"
+msgstr ""
+#: ../vector/v.split/main.c:108
+msgid "Use either length or vertices"
+msgstr ""
+#: ../vector/v.split/main.c:115
+#, c-format
+msgid "Length must be positive but is %g"
+msgstr ""
+#: ../vector/v.split/main.c:131
+#, c-format
+msgid "Unknown unit %s"
+msgstr ""
+#: ../vector/v.split/main.c:149
+msgid "Can not get projection units"
+msgstr ""
+#: ../vector/v.split/main.c:156
+#, c-format
+msgid "Length in map units: %g"
+msgstr ""
+#: ../vector/v.split/main.c:158
+#, c-format
+msgid "Length in meters: %g"
+msgstr ""
+#: ../vector/v.split/main.c:164
+msgid "Number of vertices must be at least 2"
+msgstr ""
+#: ../vector/v.split/main.c:250
+#, c-format
+msgid "Unable to make line segment: %f - %f (line length = %f)"
+msgstr ""
+#: ../vector/v.vol.rst/user1.c:109
+msgid "Column type of wcolumn is not supported (must be integer or double)"
+msgstr ""
+#: ../vector/v.vol.rst/user1.c:123
+msgid "Cannot read column type of smooth column"
+msgstr ""
+#: ../vector/v.vol.rst/user1.c:126
+msgid "Column type of smooth column (datetime) is not supported"
+msgstr ""
+#: ../vector/v.vol.rst/user1.c:128
+msgid "Column type of smooth column is not supported (must be integer or double)"
+msgstr ""
+#: ../vector/v.vol.rst/user1.c:150
+msgid "Point without category"
+msgstr ""
+#: ../vector/v.vol.rst/user1.c:208
+msgid "Some points outside of region -- will ignore..."
+msgstr ""
+#: ../vector/v.vol.rst/user1.c:215
+msgid "Cannot allocate memory for point"
+msgstr ""
+#: ../vector/v.vol.rst/user1.c:223
+#, c-format
+msgid "Can't insert %lf,%lf,%lf,%lf,%lf a=%d"
+msgstr ""
+#: ../vector/v.vol.rst/user1.c:270
+msgid "Strip exists with insufficient data"
+msgstr ""
+#: ../vector/v.vol.rst/user1.c:280
+msgid "Zero segments!"
+msgstr ""
+#: ../vector/v.vol.rst/user1.c:311
+#, c-format
+msgid "There are points outside specified 2D/3D region--ignored %d points (total points: %d)"
+msgstr ""
+#: ../vector/v.vol.rst/user1.c:315
+#, c-format
+msgid "Points are more dense than specified 'DMIN'--ignored %d points (remain %d)"
+msgstr ""
+#: ../vector/v.vol.rst/user1.c:321
+#, c-format
+msgid "%d points given for interpolation (after thinning) is less than given NPMIN=%d"
+msgstr ""
+#: ../vector/v.vol.rst/user1.c:341
+#, c-format
+msgid "There is less than %d points for interpolation, no segmentation is necessary, to run the program faster, set segmax=%d (see manual)"
+msgstr ""
+#: ../vector/v.vol.rst/user1.c:368
+#, c-format
+msgid "Mask raster map [%s] not found"
+msgstr ""
+#: ../vector/v.vol.rst/user1.c:383
+msgid "Bitmap mask created"
+msgstr ""
+#: ../vector/v.vol.rst/user1.c:432 ../vector/v.vol.rst/user1.c:485
+#: ../vector/v.vol.rst/user1.c:538 ../vector/v.vol.rst/user1.c:591
+#: ../vector/v.vol.rst/user1.c:644 ../vector/v.vol.rst/user1.c:697
+#: ../vector/v.vol.rst/user1.c:750
+#, c-format
+msgid "Unable to open %s for writing"
+msgstr ""
+#: ../vector/v.vol.rst/user1.c:443 ../vector/v.vol.rst/user1.c:496
+#: ../vector/v.vol.rst/user1.c:549 ../vector/v.vol.rst/user1.c:602
+#: ../vector/v.vol.rst/user1.c:655 ../vector/v.vol.rst/user1.c:708
+#: ../vector/v.vol.rst/user1.c:761
+msgid "Unable to read data from temp file"
+msgstr ""
+#: ../vector/v.vol.rst/user1.c:461 ../vector/v.vol.rst/user1.c:514
+#: ../vector/v.vol.rst/user1.c:567 ../vector/v.vol.rst/user1.c:620
+#: ../vector/v.vol.rst/user1.c:673 ../vector/v.vol.rst/user1.c:726
+#: ../vector/v.vol.rst/user1.c:779
+#, c-format
+msgid "Error writing cell (%d,%d,%d) with value %f"
+msgstr ""
+#: ../vector/v.vol.rst/user1.c:474 ../vector/v.vol.rst/user1.c:527
+#: ../vector/v.vol.rst/user1.c:580 ../vector/v.vol.rst/user1.c:633
+#: ../vector/v.vol.rst/user1.c:686 ../vector/v.vol.rst/user1.c:739
+#: ../vector/v.vol.rst/user1.c:792
+#, c-format
+msgid "Error closing output file %s"
+msgstr ""
+#: ../vector/v.vol.rst/user1.c:476 ../vector/v.vol.rst/user1.c:529
+#: ../vector/v.vol.rst/user1.c:582 ../vector/v.vol.rst/user1.c:635
+#: ../vector/v.vol.rst/user1.c:688 ../vector/v.vol.rst/user1.c:741
+#: ../vector/v.vol.rst/user1.c:794
+#, c-format
+msgid "3D raster map <%s> created"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:239
+msgid "RST"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:241
+msgid "Interpolates point data to a 3D raster map using regularized spline with tension (RST) algorithm."
+msgstr ""
+#: ../vector/v.vol.rst/main.c:246
+msgid "Name of input 3D vector points map"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:253
+msgid "Name of input surface raster map for cross-section"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:260
+msgid "Name of column containing w-values attribute to interpolate"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:282
+msgid "Name of column with smoothing parameters"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:302
+msgid "Name of input raster map used as mask"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:328
+msgid "Maximum number of points for approximation in a segment (>npmin)"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:345
+msgid "Conversion factor for w-values used for interpolation"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:353
+msgid "Conversion factor for z-values"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:359
+msgid "Name for output cross-section raster map"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:365
+msgid "Name for output elevation 3D raster map"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:371
+msgid "Name for output gradient magnitude 3D raster map"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:378
+msgid "Name for output gradient horizontal angle 3D raster map"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:384
+msgid "Name for output gradient vertical angle 3D raster map"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:390
+msgid "Name for output change of gradient 3D raster map"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:396
+msgid "Name for output Gaussian curvature 3D raster map"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:402
+msgid "Name for output mean curvature 3D raster map"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:408
+msgid "Perform a cross-validation procedure without volume interpolation"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:471
+msgid "Smoothing must be a positive value"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:477
+#, c-format
+msgid "Both crossvalidation options (-%c, %s) must be specified"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:480
+msgid "Both crossvalidation and deviations must be specified"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:491
+msgid "Crossvalidation cannot be computed simultanuously with output grids or devi file"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:555
+#, c-format
+msgid "Unable to open %s"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:563
+msgid "Vector is not 3D"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:628 ../vector/v.vol.rst/main.c:659
+#: ../vector/v.vol.rst/main.c:681 ../vector/v.vol.rst/main.c:703
+#: ../vector/v.vol.rst/main.c:725 ../vector/v.vol.rst/main.c:747
+#: ../vector/v.vol.rst/main.c:769 ../vector/v.vol.rst/main.c:791
+#, c-format
+msgid "Unable to open temp file '%s'"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:636 ../vector/v.vol.rst/main.c:665
+#: ../vector/v.vol.rst/main.c:687 ../vector/v.vol.rst/main.c:709
+#: ../vector/v.vol.rst/main.c:731 ../vector/v.vol.rst/main.c:753
+#: ../vector/v.vol.rst/main.c:775 ../vector/v.vol.rst/main.c:797
+msgid "Not enough disk space - cannot write temp files"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:640
+#, c-format
+msgid "Unable to create <%s> raster map without cross_input raster map being specified"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:818
+msgid "Finished interpolating"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:853
+#, c-format
+msgid "Raster map <%s> created"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:893
+#, c-format
+msgid "Vector map <%s> created"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:909
+msgid "Interpolation failed"
+msgstr ""
+#: ../vector/v.vol.rst/user3.c:548
+msgid "Secpar_loop failed"
+msgstr ""
+#: ../vector/v.vol.rst/user3.c:588 ../vector/v.vol.rst/user3.c:599
+#: ../vector/v.vol.rst/user3.c:610 ../vector/v.vol.rst/user3.c:621
+#: ../vector/v.vol.rst/user3.c:632 ../vector/v.vol.rst/user3.c:643
+#: ../vector/v.vol.rst/user3.c:654 ../vector/v.vol.rst/user3.c:665
+msgid "Not enough disk space--cannot write files"
+msgstr ""
+#: ../vector/v.vol.rst/user2.c:213
+msgid "Cannot allocate A"
+msgstr ""
+#: ../vector/v.vol.rst/user2.c:217
+msgid "Cannot allocate b"
+msgstr ""
+#: ../vector/v.vol.rst/user2.c:221
+msgid "Cannot allocate w"
+msgstr ""
+#: ../vector/v.vol.rst/dataoct.c:196
+msgid "Points are too concentrated -- please increase DMIN"
+msgstr ""
+#: ../vector/v.vol.rst/dataoct.c:245
+msgid "Point out of range"
+msgstr ""
+#: ../vector/v.net.components/main.c:74
+msgid "components"
+msgstr ""
+#: ../vector/v.net.components/main.c:76
+msgid "Computes strongly and weakly connected components in the network."
+msgstr ""
+#: ../vector/v.net.components/main.c:124
+msgid "Weakly connected components"
+msgstr ""
+#: ../vector/v.net.components/main.c:125
+msgid "Strongly connected components"
+msgstr ""
+#: ../vector/v.net.components/main.c:127
+msgid "Type of components"
+msgstr ""
+#: ../vector/v.net.components/main.c:131 ../vector/v.net.centrality/main.c:192
+msgid "Add points on nodes"
+msgstr ""
+#: ../vector/v.net.components/main.c:203
+msgid "Computing weakly connected components..."
+msgstr ""
+#: ../vector/v.net.components/main.c:207
+msgid "Computing strongly connected components..."
+msgstr ""
+#: ../vector/v.net.components/main.c:279
+#, c-format
+msgid "Found %d components."
+msgstr ""
+#: ../vector/v.decimate/main.c:125 ../vector/v.generalize/main.c:77
+msgid "generalization"
+msgstr ""
+#: ../vector/v.decimate/main.c:126
+msgid "decimation"
+msgstr ""
+#: ../vector/v.decimate/main.c:132
+msgid "Decimates a point cloud"
+msgstr ""
+#: ../vector/v.decimate/main.c:133
+msgid "Copies points from one vector to another while applying different decimations"
+msgstr ""
+#: ../vector/v.decimate/main.c:161
+msgid "Throw away every n-th point"
+msgstr ""
+#: ../vector/v.decimate/main.c:163
+msgid "For example, 5 will import 80 percent of points. If not specified, all points are copied"
+msgstr ""
+#: ../vector/v.decimate/main.c:165 ../vector/v.decimate/main.c:176
+#: ../vector/v.decimate/main.c:186 ../vector/v.decimate/main.c:195
+msgid "Count"
+msgstr ""
+#: ../vector/v.decimate/main.c:172
+msgid "Preserve only every n-th point"
+msgstr ""
+#: ../vector/v.decimate/main.c:174
+msgid "For example, 4 will import 25 percent of points. If not specified, all points are copied"
+msgstr ""
+#: ../vector/v.decimate/main.c:193
+msgid "Copy only n points"
+msgstr ""
+#: ../vector/v.decimate/main.c:194
+msgid "Copies only the given number of points"
+msgstr ""
+#: ../vector/v.decimate/main.c:201
+msgid "Minimal difference of z values"
+msgstr ""
+#: ../vector/v.decimate/main.c:203
+msgid "Minimal difference between z values in grid-based decimation"
+msgstr ""
+#: ../vector/v.decimate/main.c:204 ../vector/v.decimate/main.c:214
+#: ../vector/v.decimate/main.c:219 ../vector/v.decimate/main.c:225
+#: ../vector/v.decimate/main.c:230 ../vector/v.decimate/main.c:235
+msgid "Grid"
+msgstr ""
+#: ../vector/v.decimate/main.c:211
+msgid "Preserve only n points per grid cell"
+msgstr ""
+#: ../vector/v.decimate/main.c:213
+msgid "Preserves only the given number of points per grid cell in grid-based decimation"
+msgstr ""
+#: ../vector/v.decimate/main.c:218
+msgid "Apply grid-based decimation"
+msgstr ""
+#: ../vector/v.decimate/main.c:224
+msgid "Use only first point in grid cell during grid-based decimation"
+msgstr ""
+#: ../vector/v.decimate/main.c:229
+msgid "Only one point per cat in grid cell"
+msgstr ""
+#: ../vector/v.decimate/main.c:234
+msgid "Use z in grid decimation"
+msgstr ""
+#: ../vector/v.decimate/main.c:240
+msgid "Store only the coordinates, throw away categories"
+msgstr ""
+#: ../vector/v.decimate/main.c:242
+msgid "Do not story any categories even if they are present in input data"
+msgstr ""
+#: ../vector/v.decimate/main.c:276
+#, c-format
+msgid "Input layer must be set to a particular layer, not <%s>, when using <%s> option or <-%c> flag"
+msgstr ""
+#: ../vector/v.decimate/main.c:318
+msgid "Cannot use z for decimation, input is not 3D"
+msgstr ""
+#: ../vector/v.decimate/main.c:320
+msgid "Cannot select by z range, input is not 3D"
+msgstr ""
+#: ../vector/v.decimate/main.c:350
+msgid "Settings for count-based decimation would cause it to do nothing and no other options has been set."
+msgstr ""
+#: ../vector/v.what/what.c:45
+msgid "Cannot open driver"
+msgstr ""
+#: ../vector/v.what/what.c:53
+msgid "Cannot open database"
+msgstr ""
+#: ../vector/v.what/what.c:66
+msgid "Cannot open select cursor"
+msgstr ""
+#: ../vector/v.what/what.c:73
+msgid "Cannot fetch next record"
+msgstr ""
+#: ../vector/v.what/what.c:76
+msgid "No database record"
+msgstr ""
+#: ../vector/v.what/what.c:177
+#, c-format
+msgid ""
+"Layer: %d\n"
+"Category: %d\n"
+msgstr ""
+#: ../vector/v.what/what.c:201
+#, c-format
+msgid ""
+"\n"
+"Driver: %s\n"
+"Database: %s\n"
+"Table: %s\n"
+"Key column: %s\n"
+msgstr ""
+#: ../vector/v.what/what.c:380
+#, c-format
+msgid "Nothing found.\n"
+msgstr ""
+#: ../vector/v.what/what.c:475
+#, c-format
+msgid ""
+"Id: %d\n"
+"Type: %s\n"
+"Left: %d\n"
+"Right: %d\n"
+msgstr ""
+#: ../vector/v.what/what.c:481 ../vector/v.what/what.c:557
+#, c-format
+msgid "Length: %f\n"
+msgstr ""
+#: ../vector/v.what/what.c:501
+#, c-format
+msgid ""
+"Node[%d]=%d\n"
+"Number_lines=%d\n"
+"Coordinates=%.6f,%.6f,%.6f\n"
+msgstr ""
+#: ../vector/v.what/what.c:506
+#, c-format
+msgid ""
+",\n"
+"\"Node[%d]\": %d,\n"
+"\"Number_lines\": %d,\n"
+"\"Coordinates\": %.6f,%.6f,%.6f"
+msgstr ""
+#: ../vector/v.what/what.c:511
+#, c-format
+msgid ""
+"Node[%d]: %d\n"
+"Number of lines: %d\n"
+"Coordinates: %.6f, %.6f, %.6f\n"
+msgstr ""
+#: ../vector/v.what/what.c:531
+#, c-format
+msgid ""
+"Id: %5d\n"
+"Angle: %.8f\n"
+msgstr ""
+#: ../vector/v.what/what.c:554
+#, c-format
+msgid "Type: %s\n"
+msgstr ""
+#: ../vector/v.what/what.c:555
+#, c-format
+msgid "Id: %d\n"
+msgstr ""
+#: ../vector/v.what/what.c:576
+#, c-format
+msgid "Point height: %f\n"
+msgstr ""
+#: ../vector/v.what/what.c:600
+#, c-format
+msgid "Line height: %f\n"
+msgstr ""
+#: ../vector/v.what/what.c:618
+#, c-format
+msgid ""
+"Line height min: %f\n"
+"Line height max: %f\n"
+msgstr ""
+#: ../vector/v.what/what.c:662
+#, c-format
+msgid ""
+"Type: Area\n"
+"Area height: %f\n"
+msgstr ""
+#: ../vector/v.what/what.c:676
+#, c-format
+msgid "Type: Area\n"
+msgstr ""
+#: ../vector/v.what/what.c:704
+#, c-format
+msgid ""
+"Area: %d\n"
+"Number of isles: %d\n"
+msgstr ""
+#: ../vector/v.what/what.c:719
+#, c-format
+msgid "Isle[%d]: %d\n"
+msgstr ""
+#: ../vector/v.what/what.c:738
+#, c-format
+msgid "Island: %d In area: %d\n"
+msgstr ""
+#: ../vector/v.what/what.c:759
+#, c-format
+msgid ""
+"Sq Meters: %.3f\n"
+"Hectares: %.3f\n"
+msgstr ""
+#: ../vector/v.what/what.c:761
+#, c-format
+msgid ""
+"Acres: %.3f\n"
+"Sq Miles: %.4f\n"
+msgstr ""
+#: ../vector/v.what/main.c:65
+msgid "Queries a vector map at given locations."
+msgstr ""
+#: ../vector/v.what/main.c:85
+msgid "Query threshold distance"
+msgstr ""
+#: ../vector/v.what/main.c:86
+msgid "Threshold"
+msgstr ""
+#: ../vector/v.what/main.c:90
+msgid "Print topological information (debugging)"
+msgstr ""
+#: ../vector/v.what/main.c:95
+msgid "Print attribute information"
+msgstr ""
+#: ../vector/v.what/main.c:105
+msgid "Print the stats in JSON"
+msgstr ""
+#: ../vector/v.what/main.c:110
+msgid "Print multiple features if overlapping features are found"
+msgstr ""
+#: ../vector/v.what/main.c:127
+msgid "No input vector maps!"
+msgstr ""
+#: ../vector/v.what/main.c:175
+#, c-format
+msgid "Number of given vector maps (%d) differs from number of layers (%d)"
+msgstr ""
+#: ../vector/v.what/main.c:184
+#, c-format
+msgid "You must build topology on vector map <%s>"
+msgstr ""
+#: ../vector/v.what/main.c:202
+#, c-format
+msgid "Unknown input format, skipping: '%s'"
+msgstr ""
+#: ../vector/v.outlier/main.c:75
+msgid "Removes outliers from vector point data."
+msgstr ""
+#: ../vector/v.outlier/main.c:81
+msgid "Estimate point density and distance for the input vector points within the current region extends and quit"
+msgstr ""
+#: ../vector/v.outlier/main.c:90
+msgid "Name for output outlier vector map"
+msgstr ""
+#: ../vector/v.outlier/main.c:95
+msgid "Name for vector map for visualization in QGIS"
+msgstr ""
+#: ../vector/v.outlier/main.c:103
+msgid "Default: 10 * east-west resolution"
+msgstr ""
+#: ../vector/v.outlier/main.c:112
+msgid "Default: 10 * north-south resolution"
+msgstr ""
+#: ../vector/v.outlier/main.c:119
+msgid "Tykhonov regularization weight"
+msgstr ""
+#: ../vector/v.outlier/main.c:127
+msgid "Threshold for the outliers"
+msgstr ""
+#: ../vector/v.outlier/main.c:134
+msgid "Filtering option"
+msgstr ""
+#: ../vector/v.outlier/main.c:268
+#, c-format
+msgid "It was impossible to create <%s> table."
+msgstr ""
+#: ../vector/v.outlier/main.c:430
+msgid "Outlier detection"
+msgstr ""
+#: ../vector/v.net.salesman/main.c:129
+msgid "salesman"
+msgstr ""
+#: ../vector/v.net.salesman/main.c:131
+msgid "Creates a cycle connecting given nodes (Traveling salesman problem)."
+msgstr ""
+#: ../vector/v.net.salesman/main.c:133
+msgid "Note that TSP is NP-hard, heuristic algorithm is used by this module and created cycle may be sub optimal"
+msgstr ""
+#: ../vector/v.net.salesman/main.c:142
+msgid "Categories of points ('cities') on nodes (layer is specified by nlayer)"
+msgstr ""
+#: ../vector/v.net.salesman/main.c:162
+msgid "Node layer (used for cities)"
+msgstr ""
+#: ../vector/v.net.salesman/main.c:176
+msgid "EXPERIMENTAL: Arc backward direction cost column (number)"
+msgstr ""
+#: ../vector/v.net.salesman/main.c:203
+msgid "Name for output file holding node sequence (\"-\" for stdout)"
+msgstr ""
+#: ../vector/v.net.salesman/main.c:286
+#, c-format
+msgid "Number of cities: %d"
+msgstr ""
+#: ../vector/v.net.salesman/main.c:288
+msgid "Not enough cities (< 2)"
+msgstr ""
+#: ../vector/v.net.salesman/main.c:328
+msgid "Creating cost cache..."
+msgstr ""
+#: ../vector/v.net.salesman/main.c:357 ../vector/v.net.salesman/main.c:371
+#, c-format
+msgid "No point at node %d"
+msgstr ""
+#: ../vector/v.net.salesman/main.c:361 ../vector/v.net.salesman/main.c:375
+#, c-format
+msgid "No category for point at node %d"
+msgstr ""
+#: ../vector/v.net.salesman/main.c:378
+#, c-format
+msgid "Destination node [cat %d] is unreachable from node [cat %d]"
+msgstr ""
+#: ../vector/v.net.salesman/main.c:421
+msgid "Searching for the shortest cycle..."
+msgstr ""
+#: ../vector/v.net.salesman/main.c:555
+#, c-format
+msgid "Cycle with total cost %.3f"
+msgstr ""
+#: ../vector/v.colors.out/main.c:53
+msgid "Exports the color table associated with a vector map."
+msgstr ""
+#: ../vector/v.colors.out/main.c:66
+msgid "Name of attribute (numeric) column to which refer color rules"
+msgstr ""
+#: ../vector/v.colors.out/main.c:67
+msgid "If not given, color rules refer to categories"
+msgstr ""
+#: ../vector/v.colors.out/main.c:85
+#, c-format
+msgid "Unable to read color table for vector map <%s>"
+msgstr ""
+#: ../vector/v.colors.out/main.c:88
+#, c-format
+msgid "No color table defined for vector map <%s>"
+msgstr ""
+#: ../vector/v.kernel/main.c:68
+#, c-format
+msgid "\tScore Value=%f\tsmoothing parameter (standard deviation)=%f"
+msgstr ""
+#: ../vector/v.kernel/main.c:109
+msgid "kernel density"
+msgstr ""
+#: ../vector/v.kernel/main.c:110
+msgid "point density"
+msgstr ""
+#: ../vector/v.kernel/main.c:111
+msgid "heatmap"
+msgstr ""
+#: ../vector/v.kernel/main.c:112
+msgid "hotspot"
+msgstr ""
+#: ../vector/v.kernel/main.c:114
+msgid "Generates a raster density map from vector points map."
+msgstr ""
+#: ../vector/v.kernel/main.c:115
+msgid "Density is computed using a moving kernel. Optionally generates a vector density map on a vector network."
+msgstr ""
+#: ../vector/v.kernel/main.c:119
+msgid "Name of input vector map with training points"
+msgstr ""
+#: ../vector/v.kernel/main.c:125
+msgid "Name of input network vector map"
+msgstr ""
+#: ../vector/v.kernel/main.c:128 ../vector/v.kernel/main.c:142
+#: ../vector/v.kernel/main.c:164 ../vector/v.kernel/main.c:172
+#: ../vector/v.kernel/main.c:194 ../vector/v.kernel/main.c:219
+#: ../vector/v.kernel/main.c:225
+msgid "Network"
+msgstr ""
+#: ../vector/v.kernel/main.c:140
+msgid "Name for output vector density map"
+msgstr ""
+#: ../vector/v.kernel/main.c:141
+msgid "Outputs vector map if network map is given"
+msgstr ""
+#: ../vector/v.kernel/main.c:148
+msgid "Kernel radius in map units"
+msgstr ""
+#: ../vector/v.kernel/main.c:155
+msgid "Discretization error in map units"
+msgstr ""
+#: ../vector/v.kernel/main.c:162
+msgid "Maximum length of segment on network"
+msgstr ""
+#: ../vector/v.kernel/main.c:170
+msgid "Maximum distance from point to network"
+msgstr ""
+#: ../vector/v.kernel/main.c:178
+msgid "Multiply the density result by this number"
+msgstr ""
+#: ../vector/v.kernel/main.c:185
+msgid "Node method"
+msgstr ""
+#: ../vector/v.kernel/main.c:191
+msgid "No method applied at nodes with more than 2 arcs"
+msgstr ""
+#: ../vector/v.kernel/main.c:192
+msgid "Equal split (Okabe 2009) applied at nodes"
+msgstr ""
+#: ../vector/v.kernel/main.c:200
+msgid "Kernel function"
+msgstr ""
+#: ../vector/v.kernel/main.c:208
+msgid "Try to calculate an optimal radius with given 'radius' taken as maximum (experimental)"
+msgstr ""
+#: ../vector/v.kernel/main.c:213
+msgid "Only calculate optimal radius and exit (no map is written)"
+msgstr ""
+#: ../vector/v.kernel/main.c:218
+msgid "In network mode, normalize values by sum of density multiplied by length of each segment. Integral over the output map then gives 1.0 * mult"
+msgstr ""
+#: ../vector/v.kernel/main.c:224
+msgid "In network mode, multiply the result by number of input points"
+msgstr ""
+#: ../vector/v.kernel/main.c:237
+msgid "Use option net_output if you compute network density. Name provided in option output will be used for net_output."
+msgstr ""
+#: ../vector/v.kernel/main.c:256
+msgid "Unknown node method"
+msgstr ""
+#: ../vector/v.kernel/main.c:274
+msgid "Unknown kernel function"
+msgstr ""
+#: ../vector/v.kernel/main.c:280
+msgid "Optimal standard deviation calculation is supported only for node method 'none' and kernel function 'gaussian'."
+msgstr ""
+#: ../vector/v.kernel/main.c:284
+msgid "Optimal standard deviation calculation is supported only for kernel function 'gaussian'."
+msgstr ""
+#: ../vector/v.kernel/main.c:301
+#, c-format
+msgid "Standard deviation: %f"
+msgstr ""
+#: ../vector/v.kernel/main.c:306
+#, c-format
+msgid "Output raster map: resolution: %f\t%s\t%s"
+msgstr ""
+#: ../vector/v.kernel/main.c:309
+#, c-format
+msgid "Output raster map resolution: %f"
+msgstr ""
+#: ../vector/v.kernel/main.c:357
+#, c-format
+msgid "%d point outside threshold"
+msgid_plural "%d points outside threshold"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.kernel/main.c:380
+#, c-format
+msgid "Automatic choice of smoothing parameter (radius), maximum possible value of radius is set to %f"
+msgstr ""
+#: ../vector/v.kernel/main.c:387
+#, c-format
+msgid "Using maximum distance between points: %f"
+msgstr ""
+#: ../vector/v.kernel/main.c:401
+#, c-format
+msgid "Number of input points: %d."
+msgstr ""
+#: ../vector/v.kernel/main.c:402
+#, c-format
+msgid "%d distance read from the map."
+msgid_plural "%d distances read from the map."
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.kernel/main.c:407
+#, c-format
+msgid "Distances between all points are beyond %e (4 * standard deviation), unable to calculate optimal value."
+msgstr ""
+#: ../vector/v.kernel/main.c:418
+#, c-format
+msgid "Optimal smoothing parameter (standard deviation): %f."
+msgstr ""
+#: ../vector/v.kernel/main.c:449
+#, c-format
+msgid "Writing output vector map using smooth parameter %f"
+msgstr ""
+#: ../vector/v.kernel/main.c:451 ../vector/v.kernel/main.c:561
+#, c-format
+msgid "Normalising factor %f"
+msgstr ""
+#: ../vector/v.kernel/main.c:559
+#, c-format
+msgid "Writing output raster map using smooth parameter %f"
+msgstr ""
+#: ../vector/v.kernel/main.c:611
+#, c-format
+msgid "Maximum value in output: %e."
+msgstr ""
+#: ../vector/v.category/main.c:79
+msgid "Attaches, deletes or reports vector categories to map geometry."
+msgstr ""
+#: ../vector/v.category/main.c:92
+msgid "Feature ids (by default all features are processed)"
+msgstr ""
+#: ../vector/v.category/main.c:104
+msgid "Action to be done"
+msgstr ""
+#: ../vector/v.category/main.c:115
+msgid "add a category to features without category in the given layer"
+msgstr ""
+#: ../vector/v.category/main.c:116
+msgid "delete category (cat=-1 to delete all categories of given layer)"
+msgstr ""
+#: ../vector/v.category/main.c:117
+msgid "change layer number (e.g. layer=3,1 changes layer 3 to layer 1)"
+msgstr ""
+#: ../vector/v.category/main.c:118
+msgid "add the value specified by cat option to the current category value"
+msgstr ""
+#: ../vector/v.category/main.c:119
+msgid "copy values from one layer to another (e.g. layer=1,2,3 copies values from layer 1 to layer 2 and 3)"
+msgstr ""
+#: ../vector/v.category/main.c:120
+msgid "print report (statistics), in shell style: layer type count min max"
+msgstr ""
+#: ../vector/v.category/main.c:121
+msgid "print category values, layers are separated by '|', more cats in the same layer are separated by '/'"
+msgstr ""
+#: ../vector/v.category/main.c:122
+msgid "print only layer numbers"
+msgstr ""
+#: ../vector/v.category/main.c:138
+msgid "Shell script style, currently only for report"
+msgstr ""
+#: ../vector/v.category/main.c:139
+msgid "Format: layer type count min max"
+msgstr ""
+#: ../vector/v.category/main.c:142
+msgid "Do not copy attribute table(s)"
+msgstr ""
+#: ../vector/v.category/main.c:160
+msgid "Database connection and attribute tables for concerned layers are not changed"
+msgstr ""
+#: ../vector/v.category/main.c:208
+msgid "Invalid category number (must be equal to or greater than 0). Normally category number starts at 1."
+msgstr ""
+#: ../vector/v.category/main.c:217
+#, c-format
+msgid "%d error in id option"
+msgid_plural "%d errors in id option"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.category/main.c:228
+msgid "Output vector wasn't entered"
+msgstr ""
+#: ../vector/v.category/main.c:275
+msgid "Too many layers for this operation"
+msgstr ""
+#: ../vector/v.category/main.c:278 ../vector/v.category/main.c:281
+msgid "2 layers must be specified"
+msgstr ""
+#: ../vector/v.category/main.c:289
+#, c-format
+msgid "Categories already exist in layer %d"
+msgstr ""
+#: ../vector/v.category/main.c:378
+#, c-format
+msgid "%d new centroid placed in output map"
+msgid_plural "%d new centroids placed in output map"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.category/main.c:672
+msgid "Layer/table"
+msgstr ""
+#: ../vector/v.category/main.c:676
+msgid "Layer"
+msgstr ""
+#: ../vector/v.category/main.c:678
+#, c-format
+msgid "type count min max\n"
+msgstr ""
+#: ../vector/v.category/main.c:687
+msgid "boundary"
+msgstr ""
+#: ../vector/v.category/main.c:699
+msgid "face"
+msgstr ""
+#: ../vector/v.category/main.c:703
+msgid "kernel"
+msgstr ""
+#: ../vector/v.category/main.c:707
+msgid "all"
+msgstr ""
+#: ../vector/v.category/main.c:771
+#, c-format
+msgid "Categories copied from layer %d to layer %d"
+msgstr ""
+#: ../vector/v.category/main.c:775
+#, c-format
+msgid "%d feature modified."
+msgid_plural "%d features modified."
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.label/main.c:62
+msgid "Creates paint labels for a vector map from attached attributes."
+msgstr ""
+#: ../vector/v.label/main.c:69
+msgid "If not given the name of the input map is used"
+msgstr ""
+#: ../vector/v.label/main.c:89
+msgid "Rotate labels to align with lines"
+msgstr ""
+#: ../vector/v.label/main.c:94
+msgid "Curl labels along lines"
+msgstr ""
+#: ../vector/v.label/main.c:99
+msgid "Offset label in x-direction"
+msgstr ""
+#: ../vector/v.label/main.c:102 ../vector/v.label/main.c:109
+#: ../vector/v.label/main.c:118 ../vector/v.label/main.c:162
+msgid "Placement"
+msgstr ""
+#: ../vector/v.label/main.c:106
+msgid "Offset label in y-direction"
+msgstr ""
+#: ../vector/v.label/main.c:113 ../vector/v.lrs/v.lrs.label/main.c:174
+msgid "Reference position"
+msgstr ""
+#: ../vector/v.label/main.c:137
+msgid "Space between letters for curled labels (in map-units)"
+msgstr ""
+#: ../vector/v.label/main.c:144
+msgid "Label size (in points)"
+msgstr ""
+#: ../vector/v.label/main.c:166
+msgid "Border width"
+msgstr ""
+#: ../vector/v.label/main.c:251
+msgid "size and space options vary significantly which may lead to crummy output"
+msgstr ""
+#: ../vector/v.label/main.c:259
+msgid "Too many parameters for <reference>"
+msgstr ""
+#: ../vector/v.label/main.c:438
+#, c-format
+msgid "Labeled %d lines."
+msgstr ""
+#: ../vector/v.edit/main.c:63
+msgid "Edits a vector map, allows adding, deleting and modifying selected vector features."
+msgstr ""
+#: ../vector/v.edit/main.c:72
+#, c-format
+msgid "Unable to get category list <%s>"
+msgstr ""
+#: ../vector/v.edit/main.c:119
+msgid "Supported feature types for non-native formats:"
+msgstr ""
+#: ../vector/v.edit/main.c:140
+#, c-format
+msgid "Unable to open vector map <%s> on topological level. Try to rebuild vector topology by v.build."
+msgstr ""
+#: ../vector/v.edit/main.c:160
+#, c-format
+msgid "Unable to open vector map <%s> as the background map. It is given as vector map to be edited."
+msgstr ""
+#: ../vector/v.edit/main.c:171
+#, c-format
+msgid "Background vector map <%s> registered"
+msgstr ""
+#: ../vector/v.edit/main.c:208
+msgid "Threshold for snapping must be > 0. No snapping applied."
+msgstr ""
+#: ../vector/v.edit/main.c:215
+msgid "Selecting features..."
+msgstr ""
+#: ../vector/v.edit/main.c:227
+msgid "No features selected, nothing to edit"
+msgstr ""
+#: ../vector/v.edit/main.c:235
+#, c-format
+msgid "Vector map <%s> is not 3D. Tool '%s' requires 3D vector map. Please convert the vector map to 3D using e.g. %s."
+msgstr ""
+#: ../vector/v.edit/main.c:277
+#, c-format
+msgid "%d feature added"
+msgid_plural "%d features added"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.edit/main.c:285 ../vector/v.edit/main.c:314
+#: ../vector/v.edit/main.c:325 ../vector/v.edit/main.c:357
+#: ../vector/v.edit/main.c:365 ../vector/v.edit/main.c:374
+#: ../vector/v.edit/main.c:383 ../vector/v.edit/main.c:430
+#, c-format
+msgid "Threshold value for snapping is %.2f"
+msgstr ""
+#: ../vector/v.edit/main.c:297
+#, c-format
+msgid "%d boundary closed"
+msgid_plural "%d boundaries closed"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.edit/main.c:306
+#, c-format
+msgid "%d feature deleted"
+msgid_plural "%d features deleted"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.edit/main.c:317
+#, c-format
+msgid "%d feature moved"
+msgid_plural "%d features moved"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.edit/main.c:328
+#, c-format
+msgid "%d vertex moved"
+msgid_plural "%d vertices moved"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.edit/main.c:334
+#, c-format
+msgid "%d vertex added"
+msgid_plural "%d vertices added"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.edit/main.c:340
+#, c-format
+msgid "%d vertex removed"
+msgid_plural "%d vertices removed"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.edit/main.c:352
+#, c-format
+msgid "%d line broken"
+msgid_plural "%d lines broken"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.edit/main.c:360
+#, c-format
+msgid "%d line connected"
+msgid_plural "%d lines connected"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.edit/main.c:369 ../vector/v.edit/main.c:378
+#: ../vector/v.edit/main.c:387
+#, c-format
+msgid "%d line extended"
+msgid_plural "%d lines extended"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.edit/main.c:393
+#, c-format
+msgid "%d line merged"
+msgid_plural "%d lines merged"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.edit/main.c:402 ../vector/v.edit/main.c:408
+#, c-format
+msgid "%d feature modified"
+msgid_plural "%d features modified"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.edit/main.c:415
+#, c-format
+msgid "Multiple background maps were given. Selected features will be copied only from vector map <%s>."
+msgstr ""
+#: ../vector/v.edit/main.c:425
+#, c-format
+msgid "%d feature copied"
+msgid_plural "%d features copied"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.edit/main.c:436
+#, c-format
+msgid "%d line flipped"
+msgid_plural "%d lines flipped"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.edit/main.c:457
+#, c-format
+msgid "%d line labeled"
+msgid_plural "%d lines labeled"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.edit/main.c:466
+#, c-format
+msgid "%d feature converted"
+msgid_plural "%d features converted"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.edit/main.c:471
+msgid "No feature modified"
+msgstr ""
+#: ../vector/v.edit/main.c:478
+#, c-format
+msgid "Select feature %d is not centroid, ignoring..."
+msgstr ""
+#: ../vector/v.edit/main.c:485
+#, c-format
+msgid "%d area removed"
+msgid_plural "%d areas removed"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.edit/main.c:491
+msgid "Operation not implemented"
+msgstr ""
+#: ../vector/v.edit/args.c:20
+msgid "Name of vector map to edit"
+msgstr ""
+#: ../vector/v.edit/args.c:36
+msgid "Tool"
+msgstr ""
+#: ../vector/v.edit/args.c:61
+msgid "Create new (empty) vector map"
+msgstr ""
+#: ../vector/v.edit/args.c:62
+msgid "Add new features to existing vector map"
+msgstr ""
+#: ../vector/v.edit/args.c:63
+msgid "Delete selected features from vector map"
+msgstr ""
+#: ../vector/v.edit/args.c:64
+msgid "Move selected features in vector map"
+msgstr ""
+#: ../vector/v.edit/args.c:65
+msgid "Move vertex of selected vector lines"
+msgstr ""
+#: ../vector/v.edit/args.c:66
+msgid "Remove vertex from selected vector lines"
+msgstr ""
+#: ../vector/v.edit/args.c:67
+msgid "Add new vertex to selected vector lines"
+msgstr ""
+#: ../vector/v.edit/args.c:68
+msgid "Merge selected vector lines"
+msgstr ""
+#: ../vector/v.edit/args.c:69
+msgid "Break/split vector lines"
+msgstr ""
+#: ../vector/v.edit/args.c:70
+msgid "Select lines and print their ID's"
+msgstr ""
+#: ../vector/v.edit/args.c:71
+msgid "Set new categories to selected vector features for defined layer"
+msgstr ""
+#: ../vector/v.edit/args.c:73
+msgid "Delete categories from selected vector features for defined layer"
+msgstr ""
+#: ../vector/v.edit/args.c:75
+msgid "Copy selected features"
+msgstr ""
+#: ../vector/v.edit/args.c:76
+msgid "Snap vector features in given threshold"
+msgstr ""
+#: ../vector/v.edit/args.c:77
+msgid "Flip direction of selected vector lines"
+msgstr ""
+#: ../vector/v.edit/args.c:78
+msgid "Connect two lines"
+msgstr ""
+#: ../vector/v.edit/args.c:79
+msgid "Extend lines"
+msgstr ""
+#: ../vector/v.edit/args.c:80
+msgid "Extend start nodes"
+msgstr ""
+#: ../vector/v.edit/args.c:81
+msgid "Extend end nodes"
+msgstr ""
+#: ../vector/v.edit/args.c:82
+msgid "Z bulk-labeling (automated assignment of z coordinate to vector lines)"
+msgstr ""
+#: ../vector/v.edit/args.c:84
+msgid "Change feature type (point<->centroid, line<->boundary)"
+msgstr ""
+#: ../vector/v.edit/args.c:85
+msgid "Delete selected areas from vector map (based on selected centroids)"
+msgstr ""
+#: ../vector/v.edit/args.c:93
+msgid "Name of file containing data in GRASS ASCII vector format"
+msgstr ""
+#: ../vector/v.edit/args.c:105
+msgid "Difference in x,y,z direction for moving feature or vertex"
+msgstr ""
+#: ../vector/v.edit/args.c:112
+msgid "Threshold distance (coords,snap,query)"
+msgstr ""
+#: ../vector/v.edit/args.c:114
+msgid "'-1' for threshold based on the current resolution settings"
+msgstr ""
+#: ../vector/v.edit/args.c:130
+msgid "List of point coordinates"
+msgstr ""
+#: ../vector/v.edit/args.c:139
+msgid "Bounding box for selecting features"
+msgstr ""
+#: ../vector/v.edit/args.c:148
+msgid "Polygon for selecting features"
+msgstr ""
+#: ../vector/v.edit/args.c:158
+msgid "Query tool"
+msgstr ""
+#: ../vector/v.edit/args.c:160
+msgid "For 'shorter' use negative threshold value, positive value for 'longer'"
+msgstr ""
+#: ../vector/v.edit/args.c:166
+msgid "Select only lines or boundaries shorter/longer than threshold distance"
+msgstr ""
+#: ../vector/v.edit/args.c:168
+msgid "Select dangles shorter/longer than threshold distance"
+msgstr ""
+#: ../vector/v.edit/args.c:175
+msgid "Name of background vector map(s)"
+msgstr ""
+#: ../vector/v.edit/args.c:182
+msgid "Snap added or modified features in the given threshold to the nearest existing feature"
+msgstr ""
+#: ../vector/v.edit/args.c:188
+msgid "Not apply snapping"
+msgstr ""
+#: ../vector/v.edit/args.c:189
+msgid "Snap only to node"
+msgstr ""
+#: ../vector/v.edit/args.c:190
+msgid "Allow snapping also to vertex"
+msgstr ""
+#: ../vector/v.edit/args.c:198
+msgid "Starting value and step for z bulk-labeling"
+msgstr ""
+#: ../vector/v.edit/args.c:199
+msgid "Pair: value,step (e.g. 1100,10)"
+msgstr ""
+#: ../vector/v.edit/args.c:210
+msgid "Close added boundaries (using threshold distance)"
+msgstr ""
+#: ../vector/v.edit/args.c:214
+msgid "Do not expect header of input data"
+msgstr ""
+#: ../vector/v.edit/args.c:222
+msgid "Modify only first found feature in bounding box"
+msgstr ""
+#: ../vector/v.edit/args.c:227
+msgid "Connect parallel lines (using extend tools and threshold distance)"
+msgstr ""
+#: ../vector/v.edit/args.c:239
+msgid "Polygon must have at least 3 coordinate pairs"
+msgstr ""
+#: ../vector/v.edit/args.c:312
+#, c-format
+msgid "Operation '%s' not implemented"
+msgstr ""
+#: ../vector/v.edit/args.c:321
+#, c-format
+msgid "At least one option from %s must be specified"
+msgstr ""
+#: ../vector/v.edit/args.c:327 ../vector/v.edit/args.c:336
+#: ../vector/v.edit/args.c:343 ../vector/v.edit/args.c:350
+#: ../vector/v.edit/args.c:354
+#, c-format
+msgid "Tool %s requires option %s"
+msgstr ""
+#: ../vector/v.edit/snap.c:111 ../vector/v.edit/close.c:56
+#, c-format
+msgid "Unable to rewrite line %d"
+msgstr ""
+#: ../vector/v.edit/select.c:73
+#, c-format
+msgid "Threshold value for coordinates is %.2f"
+msgstr ""
+#: ../vector/v.edit/select.c:160
+#, c-format
+msgid "Threshold value for querying is %.2f"
+msgstr ""
+#: ../vector/v.edit/select.c:176
+#, c-format
+msgid "%d of %d feature selected from vector map <%s>"
+msgid_plural "%d of %d features selected from vector map <%s>"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.edit/select.c:496
+msgid "Layer must be > 0 for 'where'"
+msgstr ""
+#: ../vector/v.net.centrality/main.c:98
+msgid "centrality measures"
+msgstr ""
+#: ../vector/v.net.centrality/main.c:100
+msgid "Computes degree, centrality, betweeness, closeness and eigenvector centrality measures in the network."
+msgstr ""
+#: ../vector/v.net.centrality/main.c:148
+msgid "Name of degree centrality column"
+msgstr ""
+#: ../vector/v.net.centrality/main.c:154
+msgid "Name of closeness centrality column"
+msgstr ""
+#: ../vector/v.net.centrality/main.c:160
+msgid "Name of betweenness centrality column"
+msgstr ""
+#: ../vector/v.net.centrality/main.c:166
+msgid "Name of eigenvector centrality column"
+msgstr ""
+#: ../vector/v.net.centrality/main.c:175
+msgid "Maximum number of iterations to compute eigenvector centrality"
+msgstr ""
+#: ../vector/v.net.centrality/main.c:183
+msgid "Cumulative error tolerance for eigenvector centrality"
+msgstr ""
+#: ../vector/v.net.centrality/main.c:321
+msgid "Computing degree centrality measure"
+msgstr ""
+#: ../vector/v.net.centrality/main.c:325
+msgid "Computing betweenness and/or closeness centrality measure"
+msgstr ""
+#: ../vector/v.net.centrality/main.c:332
+msgid "Computing eigenvector centrality measure"
+msgstr ""
+#: ../vector/v.net.centrality/main.c:339
+msgid "Writing data into the table..."
+msgstr ""
+#: ../vector/v.info/print.c:130
+#, c-format
+msgid "Database connection for map <%s> is not defined in DB file"
+msgstr ""
+#: ../vector/v.info/print.c:134
+#, c-format
+msgid "Displaying column types/names for database connection of layer <%s>:"
+msgstr ""
+#: ../vector/v.info/print.c:142
+#, c-format
+msgid "Unable to open driver <%s>"
+msgstr ""
+#: ../vector/v.info/print.c:317
+msgid "Name:"
+msgstr ""
+#: ../vector/v.info/print.c:320
+msgid "Mapset:"
+msgstr ""
+#: ../vector/v.info/print.c:324
+msgid "Location:"
+msgstr ""
+#: ../vector/v.info/print.c:327
+msgid "Database:"
+msgstr ""
+#: ../vector/v.info/print.c:331
+msgid "Title:"
+msgstr ""
+#: ../vector/v.info/print.c:334
+msgid "Map scale:"
+msgstr ""
+#: ../vector/v.info/print.c:338
+msgid "Name of creator:"
+msgstr ""
+#: ../vector/v.info/print.c:341
+msgid "Organization:"
+msgstr ""
+#: ../vector/v.info/print.c:344
+msgid "Source date:"
+msgstr ""
+#: ../vector/v.info/print.c:351
+msgid "Timestamp (first layer): "
+msgstr ""
+#: ../vector/v.info/print.c:355
+msgid "Timestamp (first layer): none"
+msgstr ""
+#: ../vector/v.info/print.c:363 ../vector/v.info/print.c:387
+#: ../vector/v.info/print.c:427
+msgid "Map format:"
+msgstr ""
+#: ../vector/v.info/print.c:368
+msgid "OGR layer:"
+msgstr ""
+#: ../vector/v.info/print.c:371
+msgid "OGR datasource:"
+msgstr ""
+#: ../vector/v.info/print.c:374 ../vector/v.info/print.c:403
+msgid "Feature type:"
+msgstr ""
+#: ../vector/v.info/print.c:392
+msgid "DB table:"
+msgstr ""
+#: ../vector/v.info/print.c:395
+msgid "DB name:"
+msgstr ""
+#: ../vector/v.info/print.c:399
+msgid "Geometry column:"
+msgstr ""
+#: ../vector/v.info/print.c:413 ../vector/v.info/print.c:422
+msgid "Topology:"
+msgstr ""
+#: ../vector/v.info/print.c:414
+msgid "schema:"
+msgstr ""
+#: ../vector/v.info/print.c:418
+msgid "Topology column:"
+msgstr ""
+#: ../vector/v.info/print.c:436
+msgid "Type of map"
+msgstr ""
+msgid "level"
+msgstr ""
+#: ../vector/v.info/print.c:443
+msgid "Number of points:"
+msgstr ""
+#: ../vector/v.info/print.c:445
+msgid "Number of centroids:"
+msgstr ""
+#: ../vector/v.info/print.c:450
+msgid "Number of lines:"
+msgstr ""
+#: ../vector/v.info/print.c:452
+msgid "Number of boundaries:"
+msgstr ""
+#: ../vector/v.info/print.c:457
+msgid "Number of areas:"
+msgstr ""
+#: ../vector/v.info/print.c:459
+msgid "Number of islands:"
+msgstr ""
+#: ../vector/v.info/print.c:465
+msgid "Number of faces:"
+msgstr ""
+#: ../vector/v.info/print.c:467
+msgid "Number of kernels:"
+msgstr ""
+#: ../vector/v.info/print.c:472
+msgid "Number of volumes:"
+msgstr ""
+#: ../vector/v.info/print.c:474
+msgid "Number of holes:"
+msgstr ""
+#: ../vector/v.info/print.c:481
+msgid "Map is 3D:"
+msgstr ""
+#: ../vector/v.info/print.c:482
+msgid "Yes"
+msgstr ""
+msgid "No"
+msgstr ""
+#: ../vector/v.info/print.c:485
+msgid "Number of dblinks:"
+msgstr ""
+#: ../vector/v.info/print.c:498
+msgid "invalid"
+msgstr ""
+#: ../vector/v.info/print.c:500
+msgid "unspecified"
+msgstr ""
+#: ../vector/v.info/print.c:506
+msgid "zone"
+msgstr ""
+#: ../vector/v.info/print.c:539
+msgid "Digitization threshold"
+msgstr ""
+#: ../vector/v.info/print.c:541
+msgid "Comment"
+msgstr ""
+#: ../vector/v.info/main.c:42
+msgid "attribute columns"
+msgstr ""
+#: ../vector/v.info/main.c:46
+msgid "Outputs basic information about a vector map."
+msgstr ""
+#: ../vector/v.info/level1.c:29
+#, c-format
+msgid "Topology not available for vector map <%s>. Registering primitives..."
+msgstr ""
+#: ../vector/v.info/parse.c:24
+msgid "Print history instead of info and exit"
+msgstr ""
+#: ../vector/v.info/parse.c:30
+msgid "Print types/names of table columns for specified layer instead of info and exit"
+msgstr ""
+#: ../vector/v.info/parse.c:35
+msgid "Print region info in shell script style"
+msgstr ""
+#: ../vector/v.info/parse.c:40
+msgid "Print extended metadata info in shell script style"
+msgstr ""
+#: ../vector/v.info/parse.c:45
+msgid "Print topology info in shell script style"
+msgstr ""
+#: ../vector/v.parallel/main.c:53
+msgid "Creates parallel line to input vector lines."
+msgstr ""
+#: ../vector/v.parallel/main.c:68
+msgid "Offset along major axis in map units"
+msgstr ""
+#: ../vector/v.parallel/main.c:76
+msgid "Offset along minor axis in map units"
+msgstr ""
+#: ../vector/v.parallel/main.c:93
+msgid "Side"
+msgstr ""
+#: ../vector/v.parallel/main.c:97
+msgid "Parallel line is on the left"
+msgstr ""
+#: ../vector/v.parallel/main.c:98
+msgid "Parallel line is on the right"
+msgstr ""
+#: ../vector/v.parallel/main.c:99
+msgid "Parallel lines on both sides"
+msgstr ""
+#: ../vector/v.parallel/main.c:108
+msgid "Tolerance of arc polylines in map units"
+msgstr ""
+#: ../vector/v.parallel/main.c:112
+msgid "Make outside corners round"
+msgstr ""
+#: ../vector/v.parallel/main.c:116
+msgid "Create buffer-like parallel lines"
+msgstr ""
+#: ../vector/v.out.postgis/table.c:27
+#, c-format
+msgid "No database connection for layer <%s>"
+msgstr ""
+#: ../vector/v.out.postgis/table.c:50
+#, c-format
+msgid "Invalid FID column (%s). FID column must be integer. Please specify different FID column by 'options=\"FID=<name>\"'."
+msgstr ""
+#: ../vector/v.out.postgis/table.c:57
+#, c-format
+msgid "Column (%s) already exists in the table. Please specify different geometry column by 'options=\"GEOMETRY_NAME=<name>\"'."
+msgstr ""
+#: ../vector/v.out.postgis/main.c:46
+msgid "PostGIS"
+msgstr ""
+#: ../vector/v.out.postgis/main.c:47
+msgid "simple features"
+msgstr ""
+#: ../vector/v.out.postgis/main.c:52
+msgid "Exports a vector map layer to PostGIS feature table."
+msgstr ""
+#: ../vector/v.out.postgis/main.c:103
+#, c-format
+msgid "Vector map <%s> is not in native format. Export cancelled."
+msgstr ""
+#: ../vector/v.out.postgis/main.c:110
+#, c-format
+msgid "Unable to open vector map <%s> on topological level"
+msgstr ""
+#: ../vector/v.out.postgis/main.c:134
+#, c-format
+msgid "Unable to create PostGIS layer <%s>"
+msgstr ""
+#: ../vector/v.out.postgis/main.c:156
+#, c-format
+msgid "Feature type '%s' not supported"
+msgstr ""
+#: ../vector/v.out.postgis/main.c:161
+#, c-format
+msgid "Feature type %d is not supported"
+msgstr ""
+#: ../vector/v.out.postgis/main.c:168
+msgid "Copying features failed"
+msgstr ""
+#: ../vector/v.out.postgis/main.c:181
+#, c-format
+msgid "Building %s topology failed"
+msgstr ""
+#: ../vector/v.out.postgis/main.c:186
+#, c-format
+msgid "No features exported. PostGIS layer <%s> not created."
+msgstr ""
+#: ../vector/v.out.postgis/main.c:190
+#, c-format
+msgid "%d feature (%s type) written to <%s>."
+msgid_plural "%d features (%s type) written to <%s>."
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.out.postgis/main.c:196
+#, c-format
+msgid "%d primitive written to <%s>."
+msgid_plural "%d primitives written to <%s>."
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.out.postgis/main.c:247
+#, c-format
+msgid "Unable to drop topology schema <%s>"
+msgstr ""
+#: ../vector/v.out.postgis/args.c:25
+msgid "Name for output PostGIS datasource"
+msgstr ""
+#: ../vector/v.out.postgis/args.c:27
+msgid "Starts with 'PG' prefix, eg. 'PG:dbname=grass'"
+msgstr ""
+#: ../vector/v.out.postgis/args.c:35
+msgid "Name for output PostGIS layer"
+msgstr ""
+#: ../vector/v.out.postgis/args.c:37
+msgid "If not specified, input name is used"
+msgstr ""
+#: ../vector/v.out.postgis/args.c:44
+msgid "Name for output vector map defined as a link to the PostGIS feature table"
+msgstr ""
+#: ../vector/v.out.postgis/args.c:46
+msgid "If not specified, the vector link is not created. The link can be also manually created by 'v.external' module."
+msgstr ""
+#: ../vector/v.out.postgis/args.c:53
+msgid ""
+"Examples:\n"
+"\t\t'FID=cat': define feature id column 'cat'\n"
+"\t\t'GEOMETRY_NAME=wkb_geometry': define geometry column 'wkb_geometry'\n"
+"\t\t'SPATIAL_INDEX=NO': do not create spatial index on geometry column"
+msgstr ""
+#: ../vector/v.out.postgis/args.c:66
+msgid "Do not export attribute table"
+msgstr ""
+#: ../vector/v.out.postgis/args.c:72
+msgid "Export PostGIS topology instead of simple features"
+msgstr ""
+#: ../vector/v.out.postgis/args.c:77
+msgid "Force 2D output even if input is 3D "
+msgstr ""
+#: ../vector/v.out.postgis/create.c:28
+#, c-format
+msgid "Unable to create <%s> file"
+msgstr ""
+#: ../vector/v.out.postgis/create.c:66
+#, c-format
+msgid "Invalid option skipped: %s"
+msgstr ""
+#: ../vector/v.out.postgis/create.c:77
+#, c-format
+msgid "EPSG code defined for current location (%s) is overridden by %s"
+msgstr ""
+#: ../vector/v.out.postgis/create.c:105
+#, c-format
+msgid "Error writing <%s> file"
+msgstr ""
+#: ../vector/v.in.dxf/layer_list.c:16
+#, c-format
+msgid "Layer %d: %s\n"
+msgstr ""
+#: ../vector/v.in.dxf/main.c:70
+msgid "Converts file in DXF format to GRASS vector map."
+msgstr ""
+#: ../vector/v.in.dxf/main.c:74
+msgid "Ignore the map extent of DXF file"
+msgstr ""
+#: ../vector/v.in.dxf/main.c:82
+msgid "Import polyface meshes as 3D wire frame"
+msgstr ""
+#: ../vector/v.in.dxf/main.c:86
+msgid "List available DXF layers and exit"
+msgstr ""
+#: ../vector/v.in.dxf/main.c:87 ../vector/v.in.dxf/main.c:94
+#: ../vector/v.in.dxf/main.c:99 ../vector/v.in.dxf/main.c:112
+msgid "DXF layers"
+msgstr ""
+#: ../vector/v.in.dxf/main.c:93
+msgid "Invert selection by DXF layers (don't import layers in list)"
+msgstr ""
+#: ../vector/v.in.dxf/main.c:98
+msgid "Import all objects into one layer"
+msgstr ""
+#: ../vector/v.in.dxf/main.c:102
+msgid "Path to input DXF file"
+msgstr ""
+#: ../vector/v.in.dxf/main.c:111
+msgid "List of DXF layers to import (default: all)"
+msgstr ""
+#: ../vector/v.in.dxf/main.c:126
+msgid "Please specify list of DXF layers to exclude"
+msgstr ""
+#: ../vector/v.in.dxf/main.c:130
+#, c-format
+msgid "Unable to open DXF file <%s>"
+msgstr ""
+#: ../vector/v.in.dxf/main.c:133
+msgid "Layer number: layer name / GRASS compliant name"
+msgstr ""
+#: ../vector/v.in.dxf/main.c:167
+msgid "Building topology failed"
+msgstr ""
+#: ../vector/v.in.dxf/main.c:173
+msgid "Failed to import DXF file!"
+msgstr ""
+#: ../vector/v.in.dxf/write_vect.c:52
+msgid "Entity handle truncated to 16 characters."
+msgstr ""
+#: ../vector/v.in.dxf/write_vect.c:91
+msgid "No DXF layers found!"
+msgstr ""
+#: ../vector/v.in.dxf/write_vect.c:100
+msgid "Following DXF layers found:"
+msgstr ""
+#: ../vector/v.in.dxf/write_vect.c:104
+#, c-format
+msgid "Layer %d: %s"
+msgstr ""
+#: ../vector/v.in.dxf/write_vect.c:246
+#, c-format
+msgid "Unable to add database link for vector map <%s>"
+msgstr ""
+#: ../vector/v.in.dxf/read_dxf.c:57
+msgid "end of file while looking for HEADER"
+msgstr ""
+#: ../vector/v.in.dxf/add_polyline.c:47
+msgid "vertices following flag missing"
+msgstr ""
+#: ../vector/v.vect.stats/main.c:135
+msgid "Count points in areas, calculate statistics from point attributes."
+msgstr ""
+#: ../vector/v.vect.stats/main.c:139
+msgid "Name of existing vector map with points"
+msgstr ""
+#: ../vector/v.vect.stats/main.c:144
+msgid "Name of existing vector map with areas"
+msgstr ""
+#: ../vector/v.vect.stats/main.c:156
+msgid "Layer number for points map"
+msgstr ""
+#: ../vector/v.vect.stats/main.c:161
+msgid "Category values for points map"
+msgstr ""
+#: ../vector/v.vect.stats/main.c:166
+msgid "WHERE conditions of SQL statement without 'where' keyword for points map"
+msgstr ""
+#: ../vector/v.vect.stats/main.c:171
+msgid "Layer number for area map"
+msgstr ""
+#: ../vector/v.vect.stats/main.c:176
+msgid "Category values for area map"
+msgstr ""
+#: ../vector/v.vect.stats/main.c:181
+msgid "WHERE conditions of SQL statement without 'where' keyword for area map"
+msgstr ""
+#: ../vector/v.vect.stats/main.c:198
+msgid "Method for aggregate statistics"
+msgstr ""
+#: ../vector/v.vect.stats/main.c:205
+msgid "Column name of points map to use for statistics"
+msgstr ""
+#: ../vector/v.vect.stats/main.c:206
+msgid "Column of points map must be numeric"
+msgstr ""
+#: ../vector/v.vect.stats/main.c:213
+msgid "Column name to upload points count"
+msgstr ""
+#: ../vector/v.vect.stats/main.c:215
+msgid "Column to hold points count, must be of type integer, will be created if not existing"
+msgstr ""
+#: ../vector/v.vect.stats/main.c:222
+msgid "Column name to upload statistics"
+msgstr ""
+#: ../vector/v.vect.stats/main.c:224
+msgid "Column to hold statistics, must be of type double, will be created if not existing"
+msgstr ""
+#: ../vector/v.vect.stats/main.c:231
+msgid "Print output to stdout, do not update attribute table"
+msgstr ""
+#: ../vector/v.vect.stats/main.c:232
+msgid "First column is always area category"
+msgstr ""
+#: ../vector/v.vect.stats/main.c:273
+#, c-format
+msgid "Vector map <%s> is not in user mapset and cannot be updated"
+msgstr ""
+#: ../vector/v.vect.stats/main.c:335 ../vector/v.vect.stats/main.c:417
+#: ../vector/v.extract/copy_tab.c:117
+#, c-format
+msgid "Unable to open database <%s> with driver <%s>"
+msgstr ""
+#: ../vector/v.vect.stats/main.c:339
+msgid "count_column is required to upload point counts"
+msgstr ""
+#: ../vector/v.vect.stats/main.c:348
+msgid "count_column must be of type integer"
+msgstr ""
+#: ../vector/v.vect.stats/main.c:361 ../vector/v.vect.stats/main.c:391
+#, c-format
+msgid "Unable to add column <%s>"
+msgstr ""
+#: ../vector/v.vect.stats/main.c:367
+msgid "stats_column is required to upload point stats"
+msgstr ""
+#: ../vector/v.vect.stats/main.c:378
+msgid "stats_column must be of type double precision"
+msgstr ""
+#: ../vector/v.vect.stats/main.c:400
+msgid "collecting attributes from points vector..."
+msgstr ""
+#: ../vector/v.vect.stats/main.c:437
+msgid "column for points vector must be numeric"
+msgstr ""
+#: ../vector/v.vect.stats/main.c:498
+#, c-format
+msgid "No area categories in vector <%s>, layer <%s>"
+msgstr ""
+#: ../vector/v.vect.stats/main.c:523
+msgid "Selecting points for each area..."
+msgstr ""
+#: ../vector/v.vect.stats/main.c:628
+#, c-format
+msgid "could not find area category %d"
+msgstr ""
+#: ../vector/v.vect.stats/main.c:754
+#, c-format
+msgid "%d records updated"
+msgstr ""
+#: ../vector/v.extract/main.c:83
+msgid "Selects vector features from an existing vector map and creates a new vector map containing only the selected features."
+msgstr ""
+#: ../vector/v.extract/main.c:88
+msgid "Dissolve common boundaries (default is no)"
+msgstr ""
+#: ../vector/v.extract/main.c:92
+msgid "Do not copy attributes (see also 'new' parameter)"
+msgstr ""
+#: ../vector/v.extract/main.c:108
+msgid "Types to be extracted"
+msgstr ""
+#: ../vector/v.extract/main.c:123
+msgid "Input text file with category numbers/number ranges to be extracted"
+msgstr ""
+#: ../vector/v.extract/main.c:124
+msgid "If '-' given reads from standard input"
+msgstr ""
+#: ../vector/v.extract/main.c:132
+msgid "Number of random categories matching vector objects to extract"
+msgstr ""
+#: ../vector/v.extract/main.c:134
+msgid "Number must be smaller than unique cat count in layer"
+msgstr ""
+#: ../vector/v.extract/main.c:142
+msgid "Desired new category value (enter -1 to keep original categories)"
+msgstr ""
+#: ../vector/v.extract/main.c:144
+msgid "If new >= 0, attributes is not copied"
+msgstr ""
+#: ../vector/v.extract/main.c:161
+#, c-format
+msgid "Options <%s>, <%s>, <%s> and <%s> options are exclusive. Please specify only one of them."
+msgstr ""
+#: ../vector/v.extract/main.c:208
+#, c-format
+msgid "Category value in '%s' not valid"
+msgstr ""
+#: ../vector/v.extract/main.c:224
+#, c-format
+msgid "Process file <%s> for category numbers..."
+msgstr ""
+#: ../vector/v.extract/main.c:229
+#, c-format
+msgid "Unable to open specified file <%s>"
+msgstr ""
+#: ../vector/v.extract/main.c:240
+#, c-format
+msgid "Ignored text entry: %s"
+msgstr ""
+#: ../vector/v.extract/main.c:259
+#, c-format
+msgid "Loading categories from table <%s>..."
+msgstr ""
+#: ../vector/v.extract/main.c:269
+#, c-format
+msgid "Unable select records from table <%s>"
+msgstr ""
+#: ../vector/v.extract/main.c:271
+#, c-format
+msgid "%d category loaded"
+msgid_plural "%d categories loaded"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.extract/main.c:286
+msgid "This map has no categories attached. Use v.category to attach categories to this vector map."
+msgstr ""
+#: ../vector/v.extract/main.c:293
+msgid "Please specify random number larger than 0"
+msgstr ""
+#: ../vector/v.extract/main.c:297
+#, c-format
+msgid "Random category count must be smaller than feature count. There are only %d features of type(s): %s"
+msgstr ""
+#: ../vector/v.extract/main.c:320
+#, c-format
+msgid "Random category count is larger or equal to uniq <%s> feature category count %d"
+msgstr ""
+#: ../vector/v.extract/main.c:354
+msgid "Extracting features..."
+msgstr ""
+#: ../vector/v.extract/main.c:378
+msgid "Removing duplicate centroids..."
+msgstr ""
+#: ../vector/v.extract/extract.c:171
+#, c-format
+msgid "No category found for area %d. Skipping."
+msgstr ""
+#: ../vector/v.extract/extract.c:175
+#, c-format
+msgid "More categories (%d) found for area %d. Using first found category %d"
+msgstr ""
+#: ../vector/v.extract/extract.c:228
+msgid "Topology level required for extracting areas for OGR layers. Areas will be not processed."
+msgstr ""
+#: ../vector/v.extract/copy_tab.c:90
+#, c-format
+msgid "Writing attributes for layer %d"
+msgstr ""
+#: ../vector/v.extract/copy_tab.c:95
+#, c-format
+msgid "No attribute table for layer %d"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.label/main.c:103 ../vector/v.lrs/v.lrs.where/main.c:58
+#: ../vector/v.lrs/v.lrs.segment/main.c:72
+#: ../vector/v.lrs/v.lrs.create/main.c:122
+msgid "linear reference system"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.label/main.c:105
+msgid "Creates stationing from input lines, and linear reference system."
+msgstr ""
+#: ../vector/v.lrs/v.lrs.label/main.c:109 ../vector/v.lrs/v.lrs.where/main.c:66
+#: ../vector/v.lrs/v.lrs.segment/main.c:79
+#: ../vector/v.lrs/v.lrs.create/main.c:128
+msgid "Input vector map containing lines"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.label/main.c:113
+msgid "Output vector map where stationing will be written"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.label/main.c:118 ../vector/v.lrs/v.lrs.where/main.c:75
+#: ../vector/v.lrs/v.lrs.segment/main.c:88
+#: ../vector/v.lrs/v.lrs.create/main.c:147
+msgid "Line layer"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.label/main.c:124 ../vector/v.lrs/v.lrs.where/main.c:86
+#: ../vector/v.lrs/v.lrs.segment/main.c:94
+#: ../vector/v.lrs/v.lrs.create/main.c:207
+msgid "Driver name for reference system table"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.label/main.c:132 ../vector/v.lrs/v.lrs.where/main.c:94
+#: ../vector/v.lrs/v.lrs.segment/main.c:102
+#: ../vector/v.lrs/v.lrs.create/main.c:215
+msgid "Database name for reference system table"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.label/main.c:139
+#: ../vector/v.lrs/v.lrs.where/main.c:101
+#: ../vector/v.lrs/v.lrs.segment/main.c:109
+msgid "Name of the reference system table"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.label/main.c:147
+msgid "Label file"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.label/main.c:156
+msgid "PM left, MP right, stationing left, stationing right offset"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.label/main.c:161
+msgid "Offset label in label x-direction in map units"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.label/main.c:168
+msgid "Offset label in label y-direction in map units"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.label/main.c:197
+msgid "Line width of text"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.label/main.c:198
+#: ../vector/v.lrs/v.lrs.label/main.c:211
+msgid "Only for d.label output"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.label/main.c:210
+msgid "Line width of highlight color"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.label/main.c:228
+msgid "Opaque to vector"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.label/main.c:229
+msgid "Only relevant if background color is selected"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.label/main.c:292
+#: ../vector/v.lrs/v.lrs.where/main.c:147
+#: ../vector/v.lrs/v.lrs.segment/main.c:155
+#: ../vector/v.lrs/v.lrs.create/main.c:315
+msgid "Unable to open database for reference table"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.label/main.c:322
+#, c-format
+msgid "Unable to select records from LRS table: %s"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.label/main.c:412
+msgid "No record in LR table"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.label/main.c:416
+msgid "More than one record in LR table"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.where/main.c:61
+msgid "Finds line id and real km+offset for given points in vector map using linear reference system."
+msgstr ""
+#: ../vector/v.lrs/v.lrs.where/main.c:70
+msgid "Input vector map containing points"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.where/main.c:80
+#: ../vector/v.lrs/v.lrs.create/main.c:151
+msgid "Point layer"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.where/main.c:108
+msgid "Maximum distance to nearest line"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.where/main.c:222
+#: ../vector/v.lrs/v.lrs.segment/main.c:357
+#, c-format
+msgid "[%d] point read from input"
+msgid_plural "[%d] points read from input"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.lrs/v.lrs.where/main.c:225
+#, c-format
+msgid "[%d] position found"
+msgid_plural "[%d] positions found"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.lrs/v.lrs.where/main.c:229
+#, c-format
+msgid "[%d] point outside threshold"
+msgid_plural "[%d] points outside threshold"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.lrs/v.lrs.where/main.c:233
+#, c-format
+msgid "[%d] point - no record found"
+msgid_plural "[%d] points - no record found"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.lrs/v.lrs.where/main.c:237
+#, c-format
+msgid "[%d] point - too many records found"
+msgid_plural "[%d] points - too many records found"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.lrs/v.lrs.segment/main.c:75
+msgid "Creates points/segments from input lines, linear reference system and positions read from stdin or a file."
+msgstr ""
+#: ../vector/v.lrs/v.lrs.segment/main.c:83
+msgid "Output vector map where segments will be written"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.segment/main.c:114
+msgid "Name of file containing segment rules. If not given, read from stdin."
+msgstr ""
+#: ../vector/v.lrs/v.lrs.segment/main.c:184
+#: ../vector/v.lrs/v.lrs.segment/main.c:238
+#, c-format
+msgid "Cannot read input: %s"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.segment/main.c:196
+#, c-format
+msgid "No record in LR table for: %s"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.segment/main.c:200
+#, c-format
+msgid "More than one record in LR table for: %s"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.segment/main.c:207
+#: ../vector/v.lrs/v.lrs.segment/main.c:294
+#, c-format
+msgid "Unable to find line of cat [%d]"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.segment/main.c:217
+#, c-format
+msgid ""
+"Cannot get point on line: cat = [%d] distance = [%f] (line length = %f)\n"
+"%s"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.segment/main.c:253
+#, c-format
+msgid ""
+"No record in LRS table for 1. point of:\n"
+" %s"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.segment/main.c:258
+#, c-format
+msgid ""
+"Using last from more offsets found for 1. point of:\n"
+" %s"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.segment/main.c:262
+#, c-format
+msgid ""
+"Requested offset for the 1. point not found, using nearest found:\n"
+" %s"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.segment/main.c:273
+#, c-format
+msgid ""
+"No record in LRS table for 2. point of:\n"
+" %s"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.segment/main.c:278
+#, c-format
+msgid ""
+"Requested offset for the 2. point not found, using nearest found:\n"
+" %s"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.segment/main.c:282
+#, c-format
+msgid ""
+"Using first from more offsets found for 2. point of:\n"
+" %s"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.segment/main.c:287
+msgid "Segment over 2 (or more) segments, not yet supported"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.segment/main.c:304
+#, c-format
+msgid "End of segment > line length (%e) -> cut"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.segment/main.c:313
+#, c-format
+msgid ""
+"Cannot make line segment: cat = %d : %f - %f (line length = %f)\n"
+"%s"
+msgstr ""
+#. GTC %s will be replaced with a message about lost points.
+#: ../vector/v.lrs/v.lrs.segment/main.c:364
+#, c-format
+msgid "[%d] point written to output map (%s)"
+msgid_plural "[%d] points written to output map (%s)"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.lrs/v.lrs.segment/main.c:369
+#, c-format
+msgid "[%d] line read from input"
+msgid_plural "[%d] lines read from input"
+msgstr[0] ""
+msgstr[1] ""
+#. GTC %s will be replaced with a message about lost lines.
+#: ../vector/v.lrs/v.lrs.segment/main.c:376
+#, c-format
+msgid "[%d] line written to output map (%s)"
+msgid_plural "[%d] lines written to output map (%s)"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.lrs/v.lrs.create/main.c:124
+msgid "Creates a linear reference system."
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:133
+msgid "Output vector map where oriented lines are written"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:138
+msgid "Output vector map of errors"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:143
+msgid "Input vector map containing reference points"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:158
+msgid "Column containing line identifiers for lines"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:165
+msgid "Column containing line identifiers for points"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:173
+msgid "Column containing milepost position for the beginning of next segment"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:182
+msgid "Column containing offset from milepost for the beginning of next segment"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:191
+msgid "Column containing milepost position for the end of previous segment"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:200
+msgid "Column containing offset from milepost for the end of previous segment"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:223
+msgid "Name of table where the reference system will be written"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:224
+msgid "New table is created by this module"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:231
+msgid "Maximum distance of point to line allowed"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:286
+msgid "Cannot get layer info for lines"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:289
+msgid "Cannot get layer info for points"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:327
+#, c-format
+msgid "Unable to drop table: %s"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:346
+#, c-format
+msgid "Unable to select line id values from %s.%s."
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:356
+msgid "Line id column must be integer"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:367
+#: ../vector/v.lrs/v.lrs.create/main.c:469
+msgid "Unable to fetch line id from line table"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:419
+#, c-format
+msgid "Line [%d] without category (layer [%d])"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:439
+#, c-format
+msgid "No lines selected for line id [%d]"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:459
+#, c-format
+msgid "Unable to select point attributes from <%s>"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:490
+#, c-format
+msgid "Milepost (start) %f+%f used as %f+%f (change MP to integer)"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:512
+#, c-format
+msgid "Milepost (end) %f+%f used as %f+%f (change MP to integer)"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:538
+#, c-format
+msgid "Point [%d] without category (layer [%d])"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:585
+#, c-format
+msgid "Point [%d] cat [%d] is out of threshold (distance = %f)"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:717
+#, c-format
+msgid "End > start for point cat [%d]"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:734
+msgid "Start of 1. MP >= end of 2. MP for points' cats %[d], [%d]"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:751
+#, c-format
+msgid "Start of 1. MP >= start of 2. MP for points' cats [%d], [%d]"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:761
+#, c-format
+msgid "Distance along line identical for points' cats [%d], [%d]"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:775
+#, c-format
+msgid "Not enough points (%d) attached to the line (cat %d), line skip."
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:780
+#, c-format
+msgid "Unable to guess direction for the line (cat %d), line skip."
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:784
+#, c-format
+msgid "Incorrect order of points along line cat [%d]"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:834
+#, c-format
+msgid "Unable to insert reference records: %s"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:875
+msgid "Building topology for output (out_lines) map..."
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:886
+msgid "Building topology for error (err) map..."
+msgstr ""
+#: ../vector/v.net/main.c:49
+msgid "network maintenance"
+msgstr ""
+#: ../vector/v.net/main.c:50
+msgid "Performs network maintenance."
+msgstr ""
+#: ../vector/v.net/main.c:122
+#, c-format
+msgid "Unable to open vector map <%s> at topology level %d"
+msgstr ""
+#: ../vector/v.net/main.c:139
+#, c-format
+msgid "%d new points (nodes) written to output."
+msgstr ""
+#: ../vector/v.net/main.c:151
+#, c-format
+msgid "%d lines (network arcs) written to output."
+msgstr ""
+#: ../vector/v.net/args.c:14
+msgid "Name of input vector line map (arcs)"
+msgstr ""
+#: ../vector/v.net/args.c:15
+msgid "Required for operation 'nodes', 'connect', 'report' and 'nreport'"
+msgstr ""
+#: ../vector/v.net/args.c:17 ../vector/v.net/args.c:57
+msgid "Arcs"
+msgstr ""
+#: ../vector/v.net/args.c:21
+msgid "Name of input vector point map (nodes)"
+msgstr ""
+#: ../vector/v.net/args.c:23
+msgid "Required for operation 'connect' and 'arcs'"
+msgstr ""
+#: ../vector/v.net/args.c:25 ../vector/v.net/args.c:71
+#: ../vector/v.net/args.c:93 ../vector/v.net/args.c:100
+msgid "Nodes"
+msgstr ""
+#: ../vector/v.net/args.c:40
+msgid "new point is placed on each node (line end) if doesn't exist"
+msgstr ""
+#: ../vector/v.net/args.c:42
+msgid "connect still unconnected points to vector network by inserting new line(s)"
+msgstr ""
+#: ../vector/v.net/args.c:44
+msgid "new line is created from start point to end point"
+msgstr ""
+#: ../vector/v.net/args.c:46
+msgid "print to standard output {line_category start_point_category end_point_category}"
+msgstr ""
+#: ../vector/v.net/args.c:48
+msgid "print to standard output {point_category line_category[,line_category...]}"
+msgstr ""
+#: ../vector/v.net/args.c:50
+msgid "create turntable on vector network"
+msgstr ""
+#: ../vector/v.net/args.c:80
+msgid "Required for operation 'connect'. Connect points in given threshold."
+msgstr ""
+#: ../vector/v.net/args.c:84
+msgid "Name of input file"
+msgstr ""
+#: ../vector/v.net/args.c:86
+msgid "Required for operation 'arcs' ('-' for standard input)"
+msgstr ""
+#: ../vector/v.net/args.c:91
+msgid "Assign unique categories to new points"
+msgstr ""
+#: ../vector/v.net/args.c:92
+msgid "For operation 'nodes'"
+msgstr ""
+#: ../vector/v.net/args.c:97
+msgid "Snap points to network"
+msgstr ""
+#: ../vector/v.net/args.c:99
+msgid "For operation 'connect'. By default, a new line from the point to the network is created."
+msgstr ""
+#: ../vector/v.net/args.c:103
+msgid "Turntable layer"
+msgstr ""
+#: ../vector/v.net/args.c:106
+msgid "Layer where turntable will be attached. Format: layer number[/layer name].Required for operation 'turntable'."
+msgstr ""
+#: ../vector/v.net/args.c:117
+msgid "Layer with unique categories for every line in arc_layer and point on every node. The categories are used in turntable. Format: layer number[/layer name]. Required for operation 'turntable'."
+msgstr ""
+#: ../vector/v.net/args.c:146
+msgid "Unknown operation"
+msgstr ""
+#: ../vector/v.net/args.c:175
+msgid "Threshold value must be >= 0"
+msgstr ""
+#: ../vector/v.net/arcs.c:42
+#, c-format
+msgid "Error reading file: '%s'"
+msgstr ""
+#: ../vector/v.net/arcs.c:48
+#, c-format
+msgid "Skipping arc %d"
+msgstr ""
+#: ../vector/v.net/arcs.c:85
+#, c-format
+msgid "No point with category %d found"
+msgstr ""
+#: ../vector/v.net/arcs.c:89
+#, c-format
+msgid "More points with category %d found"
+msgstr ""
+#: ../vector/v.net/connect.c:78
+msgid "Failed to find intersection segment"
+msgstr ""
+#: ../vector/v.net/turntable.c:326 ../vector/v.net/turntable.c:346
+#: ../vector/v.net/turntable.c:366 ../vector/v.net/turntable.c:487
+#: ../vector/v.net/turntable.c:554
+#, c-format
+msgid "Unable to read line from <%s>."
+msgstr ""
+#: ../vector/v.net/turntable.c:448 ../vector/v.net/turntable.c:523
+msgid "Unable to insert data into turntable."
+msgstr ""
+#: ../vector/v.net/turntable.c:637
+#, c-format
+msgid "Unable to open vector map <%s>."
+msgstr ""
+#: ../vector/v.net/turntable.c:642
+#, c-format
+msgid "Unable to create vector map <%s>."
+msgstr ""
+#: ../vector/v.net/turntable.c:655
+#, c-format
+msgid "Arc layer <%s> does not exist in map <%s>."
+msgstr ""
+#: ../vector/v.net/turntable.c:660
+#, c-format
+msgid ""
+"Layer <%s> already exist in map <%s>.\n"
+"It will be overwritten by tlayer data."
+msgstr ""
+#: ../vector/v.net/turntable.c:665
+#, c-format
+msgid ""
+"It will be overwritten by tuclayer data."
+msgstr ""
+#: ../vector/v.net/turntable.c:700
+#, c-format
+msgid "Unable to open database <%s> using driver <%s>"
+msgstr ""
+#: ../vector/v.net/turntable.c:715
+#, c-format
+msgid "Unable to create turntable <%s>."
+msgstr ""
+#: ../vector/v.net/turntable.c:722
+#, c-format
+msgid "Unable to connect table <%s> to vector map <%s>."
+msgstr ""
+#: ../vector/v.net/turntable.c:727
+#, c-format
+msgid "Unable to create index for column <%s> in table <%s>."
+msgstr ""
+#: ../vector/v.net/report.c:37
+#, c-format
+msgid "Line %d has no category"
+msgstr ""
+#: ../vector/v.net/report.c:67
+#, c-format
+msgid "%d points found: %g %g %g line category: %d"
+msgstr ""
+#: ../vector/v.net/report.c:94
+#, c-format
+msgid "Duplicate nodes at x=%g y=%g z=%g "
+msgstr ""
+#: ../vector/v.net.alloc/main.c:67
+msgid "Allocates subnets for nearest centers."
+msgstr ""
+#: ../vector/v.net.alloc/main.c:69
+msgid "Center node must be opened (costs >= 0). Costs of center node are used in calculation."
+msgstr ""
+#: ../vector/v.net.alloc/main.c:158
+msgid "Default: same category like nearest center"
+msgstr ""
+#: ../vector/v.net.alloc/main.c:342
+msgid "Allocating subnets..."
+msgstr ""
+#: ../vector/v.transform/main.c:75
+msgid "Performs an affine transformation (shift, scale and rotate) on vector map."
+msgstr ""
+#: ../vector/v.transform/main.c:80
+msgid "Shift all z values to bottom=0"
+msgstr ""
+#: ../vector/v.transform/main.c:85
+msgid "Swap coordinates x, y and then apply other parameters"
+msgstr ""
+#: ../vector/v.transform/main.c:90
+msgid "Swap coordinates x, z and then apply other parameters"
+msgstr ""
+#: ../vector/v.transform/main.c:95
+msgid "Swap coordinates y, z and then apply other parameters"
+msgstr ""
+#: ../vector/v.transform/main.c:100
+msgid "Swap coordinates after the other transformations"
+msgstr ""
+#: ../vector/v.transform/main.c:104
+msgid "Do not build topology"
+msgstr ""
+#: ../vector/v.transform/main.c:109 ../vector/v.transform/main.c:120
+#: ../vector/v.transform/main.c:129 ../vector/v.transform/main.c:138
+#: ../vector/v.transform/main.c:147 ../vector/v.transform/main.c:156
+#: ../vector/v.transform/main.c:165 ../vector/v.transform/main.c:175
+#: ../vector/v.transform/main.c:182
+msgid "Custom"
+msgstr ""
+#: ../vector/v.transform/main.c:118
+msgid "Shifting value for x coordinates"
+msgstr ""
+#: ../vector/v.transform/main.c:127
+msgid "Shifting value for y coordinates"
+msgstr ""
+#: ../vector/v.transform/main.c:145
+msgid "Scaling factor for x coordinates"
+msgstr ""
+#: ../vector/v.transform/main.c:154
+msgid "Scaling factor for y coordinates"
+msgstr ""
+#: ../vector/v.transform/main.c:163
+msgid "Scaling factor for z coordinates"
+msgstr ""
+#: ../vector/v.transform/main.c:173
+msgid "Rotation around z axis in degrees (counter-clockwise)"
+msgstr ""
+#: ../vector/v.transform/main.c:179
+msgid "Name of attribute column(s) used as transformation parameters"
+msgstr ""
+#: ../vector/v.transform/main.c:181
+msgid "Format: parameter:column, e.g. xshift:xs,yshift:ys,zrot:zr"
+msgstr ""
+#: ../vector/v.transform/main.c:201
+#, c-format
+msgid "Columns require a valid layer. Please use '%s' parameter."
+msgstr ""
+#: ../vector/v.transform/main.c:231
+#, c-format
+msgid "Unknown column parameter '%s'"
+msgstr ""
+#: ../vector/v.transform/main.c:242
+#, c-format
+msgid "Unable to tokenize column string: [%s]"
+msgstr ""
+#: ../vector/v.transform/main.c:310
+#, c-format
+msgid "New vector map <%s> boundary coordinates:"
+msgstr ""
+#: ../vector/v.transform/main.c:312
+#, c-format
+msgid " N: %-10.3f S: %-10.3f"
+msgstr ""
+#: ../vector/v.transform/main.c:313
+#, c-format
+msgid " E: %-10.3f W: %-10.3f"
+msgstr ""
+#: ../vector/v.transform/main.c:314
+#, c-format
+msgid " B: %6.3f T: %6.3f"
+msgstr ""
+#: ../vector/v.transform/trans_digit.c:119
+#, c-format
+msgid "Unsupported column type of <%s>"
+msgstr ""
+#: ../vector/v.transform/trans_digit.c:127
+#, c-format
+msgid "Unable to select value for category %d from table <%s>, column <%s>. For category %d using default transformation parameter %.3f."
+msgstr ""
+#: ../vector/v.transform/trans_digit.c:138
+msgid "No category number defined. Using default transformation parameters."
+msgstr ""
+#: ../vector/v.generalize/misc.c:166
+#, c-format
+msgid "Layer %d"
+msgstr ""
+#: ../vector/v.generalize/main.c:78
+msgid "simplification"
+msgstr ""
+#: ../vector/v.generalize/main.c:79
+msgid "smoothing"
+msgstr ""
+#: ../vector/v.generalize/main.c:80
+msgid "displacement"
+msgstr ""
+#: ../vector/v.generalize/main.c:81
+msgid "network generalization"
+msgstr ""
+#: ../vector/v.generalize/main.c:84
+msgid "Performs vector based generalization."
+msgstr ""
+#: ../vector/v.generalize/main.c:102
+msgid "Error map with failed generalizations"
+msgstr ""
+#: ../vector/v.generalize/main.c:104
+msgid "Lines and boundaries causing errors (collapsed to a point or topology errors)"
+msgstr ""
+#: ../vector/v.generalize/main.c:128
+msgid "Douglas-Peucker Algorithm"
+msgstr ""
+#: ../vector/v.generalize/main.c:129
+msgid "Douglas-Peucker Algorithm with reduction parameter"
+msgstr ""
+#: ../vector/v.generalize/main.c:130
+msgid "Lang Simplification Algorithm"
+msgstr ""
+#: ../vector/v.generalize/main.c:131
+msgid "Vertex Reduction Algorithm eliminates points close to each other"
+msgstr ""
+#: ../vector/v.generalize/main.c:132
+msgid "Reumann-Witkam Algorithm"
+msgstr ""
+#: ../vector/v.generalize/main.c:133
+msgid "Boyle's Forward-Looking Algorithm"
+msgstr ""
+#: ../vector/v.generalize/main.c:134
+msgid "McMaster's Sliding Averaging Algorithm"
+msgstr ""
+#: ../vector/v.generalize/main.c:135
+msgid "McMaster's Distance-Weighting Algorithm"
+msgstr ""
+#: ../vector/v.generalize/main.c:136
+msgid "Chaiken's Algorithm"
+msgstr ""
+#: ../vector/v.generalize/main.c:137
+msgid "Interpolation by Cubic Hermite Splines"
+msgstr ""
+#: ../vector/v.generalize/main.c:138
+msgid "Snakes method for line smoothing"
+msgstr ""
+#: ../vector/v.generalize/main.c:139
+msgid "Network generalization"
+msgstr ""
+#: ../vector/v.generalize/main.c:140
+msgid "Displacement of lines close to each other"
+msgstr ""
+#: ../vector/v.generalize/main.c:143
+msgid "Generalization algorithm"
+msgstr ""
+#: ../vector/v.generalize/main.c:150
+msgid "Maximal tolerance value"
+msgstr ""
+#: ../vector/v.generalize/main.c:157
+msgid "Look-ahead parameter"
+msgstr ""
+#: ../vector/v.generalize/main.c:166
+msgid "Percentage of the points in the output of 'douglas_reduction' algorithm"
+msgstr ""
+#: ../vector/v.generalize/main.c:175
+msgid "Slide of computed point toward the original point"
+msgstr ""
+#: ../vector/v.generalize/main.c:184
+msgid "Minimum angle between two consecutive segments in Hermite method"
+msgstr ""
+#: ../vector/v.generalize/main.c:192
+msgid "Degree threshold in network generalization"
+msgstr ""
+#: ../vector/v.generalize/main.c:201
+msgid "Closeness threshold in network generalization"
+msgstr ""
+#: ../vector/v.generalize/main.c:209
+msgid "Betweeness threshold in network generalization"
+msgstr ""
+#: ../vector/v.generalize/main.c:216
+msgid "Snakes alpha parameter"
+msgstr ""
+#: ../vector/v.generalize/main.c:223
+msgid "Snakes beta parameter"
+msgstr ""
+#: ../vector/v.generalize/main.c:230
+msgid "Number of iterations"
+msgstr ""
+#: ../vector/v.generalize/main.c:240
+msgid "Disable loop support"
+msgstr ""
+#: ../vector/v.generalize/main.c:241
+msgid "Do not modify end points of lines forming a closed loop"
+msgstr ""
+#: ../vector/v.generalize/main.c:244
+msgid "Do not copy attributes"
+msgstr ""
+#: ../vector/v.generalize/main.c:298
+msgid "Unknown method"
+msgstr ""
+#: ../vector/v.generalize/main.c:330
+#, c-format
+msgid "No lines found in input map <%s>"
+msgstr ""
+#: ../vector/v.generalize/main.c:344
+#, c-format
+msgid "Unable to create error vector map <%s>"
+msgstr ""
+#: ../vector/v.generalize/main.c:364
+msgid "Displacement..."
+msgstr ""
+#: ../vector/v.generalize/main.c:373
+msgid "Network generalization..."
+msgstr ""
+#: ../vector/v.generalize/main.c:388
+msgid "Attributes are needed for 'where' option, copying table"
+msgstr ""
+#: ../vector/v.generalize/main.c:404
+#, c-format
+msgid "Generalization (%s)..."
+msgstr ""
+#: ../vector/v.generalize/main.c:405
+#, c-format
+msgid "Using threshold: %g %s"
+msgstr ""
+#: ../vector/v.generalize/main.c:525
+#, c-format
+msgid "Method '%s' did not preserve first point"
+msgstr ""
+#: ../vector/v.generalize/main.c:530
+#, c-format
+msgid "Method '%s' did not preserve last point"
+msgstr ""
+#: ../vector/v.generalize/main.c:537
+#, c-format
+msgid "Method '%s' did not preserve loop"
+msgstr ""
+#: ../vector/v.generalize/main.c:569
+#, c-format
+msgid "%d boundaries were not modified because modification would damage topology"
+msgstr ""
+#: ../vector/v.generalize/main.c:572
+#, c-format
+msgid "%d lines/boundaries were not modified due to over-simplification"
+msgstr ""
+#: ../vector/v.generalize/main.c:593
+#, c-format
+msgid "Number of vertices for selected features %s from %d to %d (%d%% remaining)"
+msgstr ""
+#: ../vector/v.generalize/main.c:594
+msgid "reduced"
+msgstr ""
+msgid "changed"
+msgstr ""
+#: ../vector/v.generalize/network.c:166
+msgid "Calculating centrality measures..."
+msgstr ""
+#: ../vector/v.generalize/smoothing.c:135
+#: ../vector/v.generalize/smoothing.c:225
+msgid "Look ahead parameter must be odd"
+msgstr ""
+#: ../vector/v.generalize/smoothing.c:664
+msgid "Unable to find the inverse matrix"
+msgstr ""
+#: ../vector/v.generalize/smoothing.c:671
+msgid "Unable to calculate the output vectors"
+msgstr ""
+#: ../vector/v.generalize/displacement.c:199
+msgid "Inverting matrix..."
+msgstr ""
+#: ../vector/v.generalize/displacement.c:201
+msgid "Unable to calculate the inverse matrix"
+msgstr ""
+#: ../vector/v.generalize/displacement.c:204
+msgid "Resolving conflicts..."
+msgstr ""
+#: ../vector/v.external/main.c:59
+msgid "Creates a new pseudo-vector map as a link to an OGR-supported layer or a PostGIS feature table."
+msgstr ""
+#: ../vector/v.external/main.c:126
+msgid "No layer defined"
+msgstr ""
+#: ../vector/v.external/main.c:192
+#, c-format
+msgid "Unable to delete '%s'"
+msgstr ""
+#: ../vector/v.external/main.c:199
+#, c-format
+msgid "Unable to create file '%s/%s'"
+msgstr ""
+#: ../vector/v.external/main.c:233
+#, c-format
+msgid "Link to vector map <%s> created."
+msgstr ""
+#: ../vector/v.external/args.c:14
+msgid "Name of input OGR or PostGIS data source"
+msgstr ""
+#: ../vector/v.external/args.c:27
+msgid "Name of OGR layer or PostGIS feature table to be linked"
+msgstr ""
+#: ../vector/v.external/args.c:28
+msgid ""
+"Examples:\n"
+"\t\tESRI Shapefile: shapefile name\n"
+"\t\tMapInfo File: mapinfo file name\n"
+"\t\tPostGIS database: table name"
+msgstr ""
+#: ../vector/v.external/args.c:40
+msgid "Name for output GRASS vector map (default: input layer)"
+msgstr ""
+#: ../vector/v.external/args.c:62
+msgid "List available layers in data source and exit"
+msgstr ""
+#: ../vector/v.external/args.c:68
+msgid "List available layers including feature type in data source and exit"
+msgstr ""
+#: ../vector/v.external/args.c:70
+msgid "Format: layer name,type,projection check,geometry"
+msgstr ""
+#: ../vector/v.external/list.c:111
+msgid "GRASS is not compiled with PostgreSQL support"
+msgstr ""
+#: ../vector/v.external/list.c:117
+msgid "GRASS is not compiled with OGR support"
+msgstr ""
+#: ../vector/v.external/list.c:158
+msgid "Connection to PostgreSQL database failed."
+msgstr ""
+#: ../vector/v.external/list.c:168
+msgid "No feature tables found in database."
+msgstr ""
+#: ../vector/v.external/list.c:179
+#, c-format
+msgid "PostGIS database <%s> contains %d feature table:"
+msgid_plural "PostGIS database <%s> contains %d feature tables:"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.external/list.c:260
+#, c-format
+msgid "Unable to open data source '%s'"
+msgstr ""
+#: ../vector/v.external/list.c:267
+#, c-format
+msgid "Data source <%s> (format '%s') contains %d layer:"
+msgid_plural "Data source <%s> (format '%s') contains %d layers:"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.external/list.c:310
+#, c-format
+msgid "Unable to convert input map projection to GRASS format. Projection check cannot be provided for OGR layer <%s>"
+msgstr ""
+#: ../vector/v.external/list.c:326
+#, c-format
+msgid "Invalid geometry column %d"
+msgstr ""
+#: ../vector/v.to.db/main.c:39
+msgid "Populates attribute values from vector features."
+msgstr ""
+#: ../vector/v.to.db/main.c:48
+#, c-format
+msgid "Vector map <%s> not found in the current mapset. Unable to modify vector maps from different mapsets."
+msgstr ""
+#: ../vector/v.to.db/main.c:65 ../vector/v.to.db/update.c:28
+#: ../vector/v.to.db/update.c:32 ../vector/v.to.db/query.c:83
+#, c-format
+msgid "Database connection not defined for layer %d. Use v.db.connect first."
+msgstr ""
+#: ../vector/v.to.db/main.c:114
+#, c-format
+msgid "Category index for vector map <%s> is not sorted"
+msgstr ""
+#: ../vector/v.to.db/update.c:84
+msgid "Updating database..."
+msgstr ""
+#: ../vector/v.to.db/update.c:125
+#, c-format
+msgid "More elements of category %d, nothing loaded to database"
+msgstr ""
+#: ../vector/v.to.db/update.c:223
+#, c-format
+msgid "Record (cat %d) already exists (not inserted)"
+msgstr ""
+#: ../vector/v.to.db/query.c:93
+msgid "Querying database... "
+msgstr ""
+#: ../vector/v.to.db/query.c:109
+#, c-format
+msgid "Query for category '0' (no category) was not executed because of too many (%d) query categories. All later reported values for cat 0 are not valid."
+msgstr ""
+#: ../vector/v.to.db/query.c:146
+#, c-format
+msgid "Multiple query results, output value set to NULL (category [%d])"
+msgstr ""
+#: ../vector/v.to.db/query.c:153
+msgid "Unable to fetch record"
+msgstr ""
+#: ../vector/v.to.db/report.c:13
+msgid "No totals for selected option"
+msgstr ""
+#: ../vector/v.to.db/report.c:211
+#, c-format
+msgid "%d categories read from vector map (layer %d)"
+msgstr ""
+#: ../vector/v.to.db/report.c:215
+#, c-format
+msgid "%d records selected from table (layer %d)"
+msgstr ""
+#: ../vector/v.to.db/report.c:218
+#, c-format
+msgid "%d categories read from vector map exist in selection from table"
+msgstr ""
+#: ../vector/v.to.db/report.c:221
+#, c-format
+msgid "%d categories read from vector map don't exist in selection from table"
+msgstr ""
+#: ../vector/v.to.db/report.c:223
+#, c-format
+msgid "%d records updated/inserted (layer %d)"
+msgstr ""
+#: ../vector/v.to.db/report.c:226
+#, c-format
+msgid "%d update/insert errors (layer %d)"
+msgstr ""
+#: ../vector/v.to.db/report.c:229
+#, c-format
+msgid "%d categories with more points (coordinates not loaded)"
+msgstr ""
+#: ../vector/v.to.db/parse.c:36
+msgid "Layer number or name (write to)"
+msgstr ""
+#: ../vector/v.to.db/parse.c:43
+msgid "For coor valid point/centroid, for length valid line/boundary"
+msgstr ""
+#: ../vector/v.to.db/parse.c:54
+msgid "Value to upload"
+msgstr ""
+#: ../vector/v.to.db/parse.c:73
+msgid "insert new row for each category if doesn't exist yet"
+msgstr ""
+#: ../vector/v.to.db/parse.c:74
+msgid "area size"
+msgstr ""
+#: ../vector/v.to.db/parse.c:75
+msgid ""
+"compactness of an area, calculated as \n"
+" compactness = perimeter / (2 * sqrt(PI * area))"
+msgstr ""
+#: ../vector/v.to.db/parse.c:77
+msgid ""
+"fractal dimension of boundary defining a polygon, calculated as \n"
+" fd = 2 * (log(perimeter) / log(area))"
+msgstr ""
+#: ../vector/v.to.db/parse.c:79
+msgid "perimeter length of an area"
+msgstr ""
+#: ../vector/v.to.db/parse.c:80
+msgid "line length"
+msgstr ""
+#: ../vector/v.to.db/parse.c:81
+msgid "number of features for each category"
+msgstr ""
+#: ../vector/v.to.db/parse.c:82
+msgid "point coordinates, X,Y or X,Y,Z"
+msgstr ""
+#: ../vector/v.to.db/parse.c:83
+msgid "line/boundary starting point coordinates, X,Y or X,Y,Z"
+msgstr ""
+#: ../vector/v.to.db/parse.c:84
+msgid "line/boundary end point coordinates, X,Y or X,Y,Z"
+msgstr ""
+#: ../vector/v.to.db/parse.c:85
+msgid "categories of areas on the left and right side of the boundary, 'query_layer' is used for area category"
+msgstr ""
+#: ../vector/v.to.db/parse.c:87
+msgid "result of a database query for all records of the geometry(or geometries) from table specified by 'query_layer' option"
+msgstr ""
+#: ../vector/v.to.db/parse.c:89
+msgid "slope steepness of vector line or boundary"
+msgstr ""
+#: ../vector/v.to.db/parse.c:90
+msgid "line sinuousity, calculated as line length / distance between end points"
+msgstr ""
+#: ../vector/v.to.db/parse.c:91
+msgid "line azimuth, calculated as angle between North direction and endnode direction at startnode"
+msgstr ""
+#: ../vector/v.to.db/parse.c:92
+msgid "bounding box of area, N,S,E,W"
+msgstr ""
+#: ../vector/v.to.db/parse.c:96
+msgid "Name of attribute column(s) to populate"
+msgstr ""
+#: ../vector/v.to.db/parse.c:105
+msgid "Query layer number or name (read from)"
+msgstr ""
+#: ../vector/v.to.db/parse.c:111
+msgid "Name of attribute column used for 'query' option"
+msgstr ""
+#: ../vector/v.to.db/parse.c:112
+msgid "E.g. 'cat', 'count(*)', 'sum(val)'"
+msgstr ""
+#: ../vector/v.to.db/parse.c:117
+msgid "Field separator for print mode"
+msgstr ""
+#: ../vector/v.to.db/parse.c:122
+msgid "Print only"
+msgstr ""
+#: ../vector/v.to.db/parse.c:128
+msgid "Only print SQL statements"
+msgstr ""
+#: ../vector/v.to.db/parse.c:134
+msgid "Print also totals for option length, area, or count"
+msgstr ""
+#: ../vector/v.to.db/parse.c:181
+msgid "This option requires one column"
+msgstr ""
+#: ../vector/v.to.db/parse.c:186
+msgid "This option requires two columns"
+msgstr ""
+#: ../vector/v.to.db/parse.c:191
+msgid "This option requires at least two columns"
+msgstr ""
+#: ../vector/v.to.db/parse.c:196
+msgid "This option requires four columns"
+msgstr ""
+#: ../vector/v.to.db/parse.c:203
+msgid "Parameter 'qcolumn' must be specified for 'option=query'"
+msgstr ""
+#: ../vector/v.to.db/parse.c:208
+msgid "The 'sides' option makes sense only for boundaries"
+msgstr ""
+#: ../vector/v.to.db/parse.c:211
+msgid "The 'sinuous' option makes sense only for lines"
+msgstr ""
+#: ../vector/v.to.db/parse.c:214
+msgid "The 'azimuth' option makes sense only for lines"
+msgstr ""
+#: ../visualization/ximgview/main.c:84
+msgid "Unable to get window attributes"
+msgstr ""
+#: ../visualization/ximgview/main.c:258
+msgid "Unable to open image file"
+msgstr ""
+#: ../visualization/ximgview/main.c:261
+msgid "Unable to read BMP header"
+msgstr ""
+#: ../visualization/ximgview/main.c:264
+msgid "Invalid BMP header"
+msgstr ""
+#: ../visualization/ximgview/main.c:270
+msgid "Unable to map image file"
+msgstr ""
+#: ../visualization/ximgview/main.c:295
+msgid "View BMP images from the PNG driver."
+msgstr ""
+#: ../visualization/ximgview/main.c:301
+msgid "Image file"
+msgstr ""
+#: ../visualization/ximgview/color.c:90 ../visualization/ximgview/color.c:288
+#, c-format
+msgid "Unknown visual class [%d]."
+msgstr ""
+#: ../visualization/ximgview/color.c:239
+msgid "Unable to get sufficient gray shades."
+msgstr ""
+#: ../visualization/ximgview/color.c:256
+msgid "Unable to get sufficient colors."
+msgstr ""
+#: ../visualization/ximgview/color.c:269
+msgid "Using private colormap for DirectColor visual."
+msgstr ""
+#: ../scripts/v.db.renamecolumn/v.db.renamecolumn.py:59
+#: ../scripts/v.rast.stats/v.rast.stats.py:120
+#: ../scripts/v.db.addcolumn/v.db.addcolumn.py:63
+#: ../scripts/v.db.addtable/v.db.addtable.py:75
+#: ../scripts/v.db.dropcolumn/v.db.dropcolumn.py:60
+#: ../scripts/v.db.update/v.db.update.py:75
+#, python-format
+msgid "Vector map <%s> not found in current mapset"
+msgstr ""
+#: ../scripts/v.db.renamecolumn/v.db.renamecolumn.py:69
+msgid "There is no table connected to the input vector map. Cannot rename any column"
+msgstr ""
+#: ../scripts/v.db.renamecolumn/v.db.renamecolumn.py:78
+#, python-format
+msgid "Column name <%s> too long. The DBF driver supports column names not longer than 10 characters"
+msgstr ""
+#: ../scripts/v.db.renamecolumn/v.db.renamecolumn.py:83
+#, python-format
+msgid "Cannot rename column <%s> as it is needed to keep table <%s> connected to the input vector map"
+msgstr ""
+#: ../scripts/v.rast.stats/v.rast.stats.py:137
+msgid "Preprocessing input data..."
+msgstr ""
+#: ../scripts/v.rast.stats/v.rast.stats.py:148
+msgid "An error occurred while converting vector to raster"
+msgstr ""
+#: ../scripts/v.rast.stats/v.rast.stats.py:160
+msgid "No categories found in raster map"
+msgstr ""
+#: ../scripts/v.rast.stats/v.rast.stats.py:167
+#: ../scripts/v.rast.stats/v.rast.stats.py:174
+#: ../scripts/v.db.addcolumn/v.db.addcolumn.py:69
+#: ../scripts/v.db.update/v.db.update.py:81
+msgid "There is no table connected to this map. Run v.db.connect or v.db.addtable first."
+msgstr ""
+#: ../scripts/v.rast.stats/v.rast.stats.py:227
+#, python-format
+msgid "Cannot create column <%s> (already present). "
+msgstr ""
+#: ../scripts/v.rast.stats/v.rast.stats.py:228
+msgid "Use -c flag to update values in this column."
+msgstr ""
+#: ../scripts/v.rast.stats/v.rast.stats.py:237
+#, python-format
+msgid "Adding columns '%s'"
+msgstr ""
+#: ../scripts/v.rast.stats/v.rast.stats.py:242
+msgid "Adding columns failed. Exiting."
+msgstr ""
+#: ../scripts/v.rast.stats/v.rast.stats.py:245
+#, python-format
+msgid "Processing input data (%d categories)..."
+msgstr ""
+#: ../scripts/v.rast.stats/v.rast.stats.py:289
+msgid "Updating the database ..."
+msgstr ""
+#: ../scripts/v.rast.stats/v.rast.stats.py:294
+#, python-brace-format
+msgid "Statistics calculated from raster map <{raster}> and uploaded to attribute table of vector map <{vector}>."
+msgstr ""
+#: ../scripts/v.rast.stats/v.rast.stats.py:300
+#, python-format
+msgid "Failed to upload statistics to attribute table of vector map <%s>."
+msgstr ""
+#: ../scripts/m.proj/m.proj.py:142
+msgid "cs2cs program not found, install PROJ.4 first: http://proj.maptools.org"
+msgstr ""
+#: ../scripts/m.proj/m.proj.py:147
+msgid "Choose only one input parameter method"
+msgstr ""
+#: ../scripts/m.proj/m.proj.py:150
+msgid "Choose only one output parameter method"
+msgstr ""
+#: ../scripts/m.proj/m.proj.py:153
+msgid "Choose only one auto-projection parameter method"
+msgstr ""
+#: ../scripts/m.proj/m.proj.py:156
+msgid "Output file already exists"
+msgstr ""
+#: ../scripts/m.proj/m.proj.py:159
+msgid "One of <coordinates> and <input> must be given"
+msgstr ""
+#: ../scripts/m.proj/m.proj.py:162
+msgid "Options <coordinates> and <input> are mutually exclusive"
+msgstr ""
+#: ../scripts/m.proj/m.proj.py:181
+msgid "Unable to project to or from a XY location"
+msgstr ""
+#: ../scripts/m.proj/m.proj.py:197
+msgid "Invalid PROJ.4 input specification"
+msgstr ""
+#: ../scripts/m.proj/m.proj.py:220
+msgid "Invalid PROJ.4 output specification"
+msgstr ""
+#: ../scripts/m.proj/m.proj.py:223
+msgid "Missing output projection parameters "
+msgstr ""
+#: ../scripts/m.proj/m.proj.py:242
+msgid "Unable to read input data"
+msgstr ""
+#: ../scripts/m.proj/m.proj.py:304
+msgid "Projection transform probably failed, please investigate"
+msgstr ""
+#: ../scripts/i.tasscap/i.tasscap.py:139
+#, python-format
+msgid "Satellite %s..."
+msgstr ""
+#: ../scripts/i.tasscap/i.tasscap.py:162
+#, python-format
+msgid "The number of input raster maps (bands) should be %s"
+msgstr ""
+#: ../scripts/i.tasscap/i.tasscap.py:178
+msgid "Tasseled Cap components calculated"
+msgstr ""
+#: ../scripts/r.mask/r.mask.py:101
+msgid "Either parameter <raster> or parameter <vector> is required"
+msgstr ""
+#: ../scripts/r.mask/r.mask.py:115
+msgid "Raster MASK removed"
+msgstr ""
+#: ../scripts/r.mask/r.mask.py:117
+msgid "No existing MASK to remove"
+msgstr ""
+#: ../scripts/r.mask/r.mask.py:122
+msgid "MASK already found in current mapset. Delete first or overwrite."
+msgstr ""
+#: ../scripts/r.mask/r.mask.py:124
+msgid "MASK already exists and will be overwritten"
+msgstr ""
+#: ../scripts/r.mask/r.mask.py:135
+#, python-format
+msgid "The raster map <%s> must be integer (CELL type) in order to use the 'maskcats' parameter"
+msgstr ""
+#: ../scripts/r.mask/r.mask.py:159
+#, python-format
+msgid "No area found in vector map <%s>. Creating a convex hull for MASK."
+msgstr ""
+#: ../scripts/r.mask/r.mask.py:171
+#, python-format
+msgid "Unable to create a convex hull for vector map <%s>"
+msgstr ""
+#: ../scripts/r.mask/r.mask.py:187
+msgid "Creating inverted raster MASK..."
+msgstr ""
+#: ../scripts/r.mask/r.mask.py:189
+msgid "Inverted raster MASK created"
+msgstr ""
+#: ../scripts/r.mask/r.mask.py:191
+msgid "Raster MASK created"
+msgstr ""
+#: ../scripts/r.mask/r.mask.py:193
+msgid "All subsequent raster operations will be limited to the MASK area. Removing or renaming raster map named 'MASK' will restore raster operations to normal."
+msgstr ""
+#: ../scripts/d.what.rast/d.what.rast.py:48
+#: ../scripts/d.what.vect/d.what.vect.py:48 ../scripts/d.frame/d.frame.py:264
+#: ../scripts/d.out.file/d.out.file.py:61 ../scripts/d.redraw/d.redraw.py:37
+#: ../scripts/d.to.rast/d.to.rast.py:48
+msgid "No graphics device selected. Use d.mon to select graphics device."
+msgstr ""
+#: ../scripts/r.in.srtm/r.in.srtm.py:143
+msgid "This module only operates in LatLong locations"
+msgstr ""
+#: ../scripts/r.in.srtm/r.in.srtm.py:161
+msgid "The \"unzip\" program is required, please install it first"
+msgstr ""
+#: ../scripts/r.in.srtm/r.in.srtm.py:168
+#, python-format
+msgid "'%s' does not appear to be a valid zip file."
+msgstr ""
+#: ../scripts/r.in.srtm/r.in.srtm.py:175
+#, python-format
+msgid "File '%s' or '%s' not found"
+msgstr ""
+#: ../scripts/r.in.srtm/r.in.srtm.py:197
+#, python-format
+msgid "Extracting '%s'..."
+msgstr ""
+#: ../scripts/r.in.srtm/r.in.srtm.py:199
+msgid "Unable to unzip file."
+msgstr ""
+#: ../scripts/r.in.srtm/r.in.srtm.py:201
+msgid "Converting input file to BIL..."
+msgstr ""
+#: ../scripts/r.in.srtm/r.in.srtm.py:225
+msgid "Attempting to import 1-arcsec data."
+msgstr ""
+#: ../scripts/r.in.srtm/r.in.srtm.py:243
+msgid "Unable to import data"
+msgstr ""
+#: ../scripts/r.in.srtm/r.in.srtm.py:251
+msgid "Done: generated map "
+msgstr ""
+#: ../scripts/r.in.srtm/r.in.srtm.py:252
+msgid "(Note: Holes in the data can be closed with 'r.fillnulls' using splines)"
+msgstr ""
+#: ../scripts/v.in.lines/v.in.lines.py:114
+msgid "Not enough data columns. (incorrect fs setting?)"
+msgstr ""
+#: ../scripts/v.pack/v.pack.py:69
+#, python-format
+msgid "Unable to pack vector map <%s>. Only native format supported."
+msgstr ""
+#: ../scripts/v.pack/v.pack.py:85 ../scripts/r.pack/r.pack.py:78
+#, python-format
+msgid "Pack file <%s> already exists and will be overwritten"
+msgstr ""
+#: ../scripts/v.pack/v.pack.py:88 ../scripts/v.import/v.import.py:272
+#, python-format
+msgid "option <%s>: <%s> exists."
+msgstr ""
+#: ../scripts/v.pack/v.pack.py:91
+#, python-format
+msgid "Packing <%s>..."
+msgstr ""
+#: ../scripts/v.pack/v.pack.py:103
+#, python-format
+msgid "There is not database connected with vector map <%s>"
+msgstr ""
+#: ../scripts/v.pack/v.pack.py:124
+#, python-format
+msgid "Pack file <%s> created"
+msgstr ""
+#: ../scripts/v.dissolve/v.dissolve.py:72
+#, python-format
+msgid "No '%s' option specified. Dissolving based on category values from layer <%s>."
+msgstr ""
+#: ../scripts/v.dissolve/v.dissolve.py:78
+#, python-format
+msgid "Invalid layer number (%d). Parameter '%s' specified, assuming layer '1'."
+msgstr ""
+#: ../scripts/v.dissolve/v.dissolve.py:88
+msgid "Key column must be of type integer or string"
+msgstr ""
+#: ../scripts/v.dissolve/v.dissolve.py:102
+#, python-format
+msgid ""
+"Final extraction steps failed. Check above error messages and see following details:\n"
+"%s"
+msgstr ""
+#: ../scripts/g.extension/g.extension.py:191
+#, python-format
+msgid "'%s' required. Please install '%s' first."
+msgstr ""
+#: ../scripts/g.extension/g.extension.py:254
+msgid "List of installed extensions (toolboxes):"
+msgstr ""
+#: ../scripts/g.extension/g.extension.py:256
+msgid "List of installed extensions (modules):"
+msgstr ""
+#: ../scripts/g.extension/g.extension.py:261
+msgid "No extension (toolbox) installed"
+msgstr ""
+#: ../scripts/g.extension/g.extension.py:263
+msgid "No extension (module) installed"
+msgstr ""
+#: ../scripts/g.extension/g.extension.py:335
+msgid "List of available extensions (toolboxes):"
+msgstr ""
+#: ../scripts/g.extension/g.extension.py:349
+msgid "List of available extensions (modules):"
+msgstr ""
+#: ../scripts/g.extension/g.extension.py:372
+#: ../scripts/g.extension/g.extension.py:395
+msgid "Unable to fetch addons metadata file"
+msgstr ""
+#: ../scripts/g.extension/g.extension.py:465
+#, python-format
+msgid "Unable to parse '%s'. Trying to scan SVN repository (may take some time)..."
+msgstr ""
+#: ../scripts/g.extension/g.extension.py:509
+msgid "Fetching list of extensions from GRASS-Addons SVN repository (be patient)..."
+msgstr ""
+#: ../scripts/g.extension/g.extension.py:515
+msgid "Flag 'c' ignored, addons metadata file not available"
+msgstr ""
+#: ../scripts/g.extension/g.extension.py:518
+msgid "Flag 'g' ignored, addons metadata file not available"
+msgstr ""
+#: ../scripts/g.extension/g.extension.py:524
+#: ../scripts/g.extension/g.extension.py:557
+#, python-format
+msgid "Checking for '%s' modules..."
+msgstr ""
+#: ../scripts/g.extension/g.extension.py:532
+#: ../scripts/g.extension/g.extension.py:564
+#, python-format
+msgid "Unable to fetch '%s'"
+msgstr ""
+#: ../scripts/g.extension/g.extension.py:584
+msgid "Path to the source code:"
+msgstr ""
+#: ../scripts/g.extension/g.extension.py:666
+msgid "$GISBASE not defined"
+msgstr ""
+#: ../scripts/g.extension/g.extension.py:669
+#, python-format
+msgid "Extension <%s> already installed. Re-installing..."
+msgstr ""
+#: ../scripts/g.extension/g.extension.py:673
+#, python-format
+msgid "Installing toolbox <%s>..."
+msgstr ""
+#: ../scripts/g.extension/g.extension.py:678
+msgid "Nothing to install"
+msgstr ""
+#: ../scripts/g.extension/g.extension.py:695
+msgid "Installation failed, sorry. Please check above error messages."
+msgstr ""
+#: ../scripts/g.extension/g.extension.py:701
+#: ../scripts/g.extension/g.extension.py:1231
+msgid "Updating addons metadata file..."
+msgstr ""
+#: ../scripts/g.extension/g.extension.py:707
+#, python-format
+msgid "Installation of <%s> successfully finished"
+msgstr ""
+#: ../scripts/g.extension/g.extension.py:711
+msgid "This add-on module will not function until you set the GRASS_ADDON_BASE environment variable (see \"g.manual variables\")"
+msgstr ""
+#: ../scripts/g.extension/g.extension.py:744
+msgid "Unable to read addons metadata file from the remote server"
+msgstr ""
+#: ../scripts/g.extension/g.extension.py:755
+msgid "No addons metadata available"
+msgstr ""
+#: ../scripts/g.extension/g.extension.py:758
+#, python-format
+msgid "No addons metadata available for <%s>"
+msgstr ""
+#: ../scripts/g.extension/g.extension.py:814
+msgid "Unable to read addons metadata file from the remote server: {0}"
+msgstr ""
+#: ../scripts/g.extension/g.extension.py:818
+#, python-format, python-brace-format
+msgid "Unable to parse '%s': {0}"
+msgstr ""
+#: ../scripts/g.extension/g.extension.py:863
+msgid "No addons metadata available. Addons metadata file not updated."
+msgstr ""
+#: ../scripts/g.extension/g.extension.py:884
+#, python-format
+msgid "No addons metadata found for <%s>"
+msgstr ""
+#: ../scripts/g.extension/g.extension.py:929
+#, python-format
+msgid "Downloading precompiled GRASS Addons <%s>..."
+msgstr ""
+#: ../scripts/g.extension/g.extension.py:990
+#, python-format
+msgid "GRASS Addons <%s> not found"
+msgstr ""
+#: ../scripts/g.extension/g.extension.py:1063
+msgid "ZIP file is unreadable: {0}"
+msgstr ""
+#: ../scripts/g.extension/g.extension.py:1082
+msgid "Archive file is unreadable: {0}"
+msgstr ""
+#: ../scripts/g.extension/g.extension.py:1100
+#: ../scripts/g.extension/g.extension.py:1262
+#: ../scripts/g.extension/g.extension.py:1285
+#, python-format
+msgid "Extension <%s> not found"
+msgstr ""
+#: ../scripts/g.extension/g.extension.py:1123
+msgid "Unknown extension (addon) source type '{0}'. Please report this to the grass-user mailing list."
+msgstr ""
+#: ../scripts/g.extension/g.extension.py:1135
+#, python-format
+msgid "Fetching <%s> from GRASS GIS Addons repository (be patient)..."
+msgstr ""
+#: ../scripts/g.extension/g.extension.py:1138
+msgid "Fetching <{name}> from <{url}> (be patient)..."
+msgstr ""
+#: ../scripts/g.extension/g.extension.py:1189
+msgid "To compile run:"
+msgstr ""
+#: ../scripts/g.extension/g.extension.py:1191
+msgid "To install run:"
+msgstr ""
+#: ../scripts/g.extension/g.extension.py:1197
+msgid "Compiling..."
+msgstr ""
+#: ../scripts/g.extension/g.extension.py:1200
+msgid "Please install GRASS development package"
+msgstr ""
+#: ../scripts/g.extension/g.extension.py:1204
+msgid "Compilation failed, sorry. Please check above error messages."
+msgstr ""
+#: ../scripts/g.extension/g.extension.py:1210
+msgid "Installing..."
+msgstr ""
+#: ../scripts/g.extension/g.extension.py:1224
+msgid "List of removed files:"
+msgstr ""
+#: ../scripts/g.extension/g.extension.py:1226
+msgid "Files to be removed:"
+msgstr ""
+#: ../scripts/g.extension/g.extension.py:1233
+#, python-format
+msgid "Extension <%s> successfully uninstalled."
+msgstr ""
+#: ../scripts/g.extension/g.extension.py:1236
+#, python-format
+msgid "Extension <%s> not removed. Re-run '%s' with '-f' flag to force removal"
+msgstr ""
+#: ../scripts/g.extension/g.extension.py:1376
+#: ../scripts/g.extension/g.extension.py:1390
+#, python-format
+msgid "Unable to create '%s': %s"
+msgstr ""
+#: ../scripts/g.extension/g.extension.py:1414
+#, python-format
+msgid "Manual page for <%s> updated"
+msgstr ""
+#: ../scripts/g.extension/g.extension.py:1422
+#, python-format
+msgid "Unable to read manual page: %s"
+msgstr ""
+#: ../scripts/g.extension/g.extension.py:1458
+#, python-format
+msgid "Unable for write manual page: %s"
+msgstr ""
+#: ../scripts/g.extension/g.extension.py:1469
+#, python-format
+msgid "GRASS_ADDON_BASE is not defined, installing to ~/.grass%s/addons"
+msgstr ""
+#: ../scripts/g.extension/g.extension.py:1477
+msgid "You don't have permission to install extension to <{0}>. Try to run {1} with administrator rights (su or sudo)."
+msgstr ""
+#: ../scripts/g.extension/g.extension.py:1559
+msgid "Identified {0} as known hosting service"
+msgstr ""
+#: ../scripts/g.extension/g.extension.py:1564
+msgid "Not using {service} as known hosting service because the URL ends with '{suffix}'"
+msgstr ""
+#: ../scripts/g.extension/g.extension.py:1576
+msgid "Will use the following URL for download: {0}"
+msgstr ""
+#: ../scripts/g.extension/g.extension.py:1716
+msgid "Flag 'd' is relevant only to 'operation=add'. Ignoring this flag."
+msgstr ""
+#: ../scripts/g.extension.all/g.extension.all.py:58
+#, python-format
+msgid "%s not defined"
+msgstr ""
+#: ../scripts/g.extension.all/g.extension.all.py:68
+#, python-format
+msgid "Unable to parse metadata file: %s"
+msgstr ""
+#: ../scripts/g.extension.all/g.extension.all.py:97
+msgid "No extension found. Nothing to remove."
+msgstr ""
+#: ../scripts/g.extension.all/g.extension.all.py:100
+msgid "Nothing to rebuild. Rebuilding process can be forced with -f flag."
+msgstr ""
+#: ../scripts/g.extension.all/g.extension.all.py:104
+msgid "List of extensions to be removed:"
+msgstr ""
+#: ../scripts/g.extension.all/g.extension.all.py:107
+msgid "You must use the force flag (-f) to actually remove them. Exiting."
+msgstr ""
+#: ../scripts/g.extension.all/g.extension.all.py:113
+#, python-format
+msgid "Removing extension <%s>..."
+msgstr ""
+#: ../scripts/g.extension.all/g.extension.all.py:115
+#, python-format
+msgid "Reinstalling extension <%s>..."
+msgstr ""
+#: ../scripts/g.extension.all/g.extension.all.py:127
+#, python-format
+msgid "Unable to process extension:%s"
+msgstr ""
+#: ../scripts/g.search.modules/g.search.modules.py:175
+msgid "Cannot colorize, python-termcolor is not installed"
+msgstr ""
+#: ../scripts/r.tileset/r.tileset.py:247
+#, python-format
+msgid "It is not possible to set 'maxcols=%s' and 'overlap=%s'. Please set maxcols>overlap"
+msgstr ""
+#: ../scripts/r.tileset/r.tileset.py:251
+#, python-format
+msgid "It is not possible to set 'maxrows=%s' and 'overlap=%s'. Please set maxrows>overlap"
+msgstr ""
+#: ../scripts/r.tileset/r.tileset.py:260 ../scripts/r.tileset/r.tileset.py:271
+msgid "g.proj failed"
+msgstr ""
+#: ../scripts/r.tileset/r.tileset.py:277
+#, python-format
+msgid "Scale (%s) not found, assuming '1'"
+msgstr ""
+#: ../scripts/r.tileset/r.tileset.py:308
+msgid "There are no tiles available. Probably the output projection system it is not compatible with the projection of the current location"
+msgstr ""
+#: ../scripts/r.tileset/r.tileset.py:355
+msgid "Computing tiling..."
+msgstr ""
+#: ../scripts/r.tileset/r.tileset.py:393
+#, python-format
+msgid "During computation %i tiles could not be created"
+msgstr ""
+#: ../scripts/i.spectral/i.spectral.py:121
+#, python-format
+msgid "Programmer error (%s)"
+msgstr ""
+#: ../scripts/i.spectral/i.spectral.py:213
+msgid "Either group= or raster= is required"
+msgstr ""
+#: ../scripts/i.spectral/i.spectral.py:216
+msgid "group= and raster= are mutually exclusive"
+msgstr ""
+#: ../scripts/i.spectral/i.spectral.py:220
+msgid "Writing to text file requires output=filename"
+msgstr ""
+#: ../scripts/i.spectral/i.spectral.py:224
+msgid "gnuplot required, please install first"
+msgstr ""
+#: ../scripts/i.spectral/i.spectral.py:243
+msgid "No data returned from query"
+msgstr ""
+#: ../scripts/v.db.addcolumn/v.db.addcolumn.py:78
+msgid "There is an empty column. Did you leave a trailing comma?"
+msgstr ""
+#: ../scripts/v.db.addcolumn/v.db.addcolumn.py:81
+#, python-format
+msgid "Column <%s> is already in the table. Skipping."
+msgstr ""
+#: ../scripts/v.db.addcolumn/v.db.addcolumn.py:83
+#, python-format
+msgid "Adding column <%s> to the table"
+msgstr ""
+#: ../scripts/v.db.addcolumn/v.db.addcolumn.py:89
+#, python-format
+msgid "Unable to add column <%s>."
+msgstr ""
+#: ../scripts/v.db.reconnect.all/v.db.reconnect.all.py:98
+#, python-format
+msgid "Target database doesn't exist, creating a new database using <%s> driver..."
+msgstr ""
+#: ../scripts/v.db.reconnect.all/v.db.reconnect.all.py:104
+#, python-format
+msgid "Unable to create database <%s> by driver <%s>"
+msgstr ""
+#: ../scripts/v.db.reconnect.all/v.db.reconnect.all.py:141
+#, python-format
+msgid "Unable to disconnect table <%s> from vector <%s>"
+msgstr ""
+#: ../scripts/v.db.reconnect.all/v.db.reconnect.all.py:149
+#, python-format
+msgid "Unable to drop table <%s>"
+msgstr ""
+#: ../scripts/v.db.reconnect.all/v.db.reconnect.all.py:158
+#, python-format
+msgid "Creating index <%s>..."
+msgstr ""
+#: ../scripts/v.db.reconnect.all/v.db.reconnect.all.py:165
+#, python-format
+msgid "Unable to create index <%s>"
+msgstr ""
+#: ../scripts/v.db.reconnect.all/v.db.reconnect.all.py:196
+msgid "Old and new database connection is identical. Nothing to do."
+msgstr ""
+#: ../scripts/v.db.reconnect.all/v.db.reconnect.all.py:212
+#, python-format
+msgid ""
+"%s\n"
+"Reconnecting vector map <%s> (%d of %d)...\n"
+"%s"
+msgstr ""
+#: ../scripts/v.db.reconnect.all/v.db.reconnect.all.py:249
+#, python-format
+msgid "Reconnecting layer %d..."
+msgstr ""
+#: ../scripts/v.db.reconnect.all/v.db.reconnect.all.py:274
+#, python-format
+msgid "Unable to connect table <%s> to vector <%s> on layer <%s>"
+msgstr ""
+#: ../scripts/v.db.reconnect.all/v.db.reconnect.all.py:280
+#, python-format
+msgid "Layer <%d> will not be reconnected because database or schema do not match."
+msgstr ""
+#: ../scripts/r.shade/r.shade.py:127 ../scripts/d.shade/d.shade.py:63
+#, python-format
+msgid "Module %s failed. Check the above error messages."
+msgstr ""
+#: ../scripts/r.unpack/r.unpack.py:69
+msgid "File {name} not found."
+msgstr ""
+#: ../scripts/r.unpack/r.unpack.py:82 ../scripts/r.unpack/r.unpack.py:120
+#: ../scripts/v.unpack/v.unpack.py:86 ../scripts/v.unpack/v.unpack.py:133
+msgid "Pack file unreadable"
+msgstr ""
+#: ../scripts/r.unpack/r.unpack.py:91 ../scripts/v.unpack/v.unpack.py:95
+msgid "Pack file unreadable: file '{}' missing"
+msgstr ""
+#: ../scripts/r.unpack/r.unpack.py:104
+msgid "Raster map <{name}> already exists"
+msgstr ""
+#: ../scripts/r.unpack/r.unpack.py:107
+msgid "Raster map <{name}> already exists and will be overwritten"
+msgstr ""
+#: ../scripts/r.unpack/r.unpack.py:117
+msgid "This GRASS GIS pack file contains vector data. Use v.unpack to unpack <{name}>"
+msgstr ""
+#: ../scripts/r.unpack/r.unpack.py:125
+msgid "Overriding projection check (using current location's projection)."
+msgstr ""
+#: ../scripts/r.unpack/r.unpack.py:138
+msgid "PROJ_INFO file is missing, unpack raster map in XY (unprojected) location."
+msgstr ""
+#: ../scripts/r.unpack/r.unpack.py:158 ../scripts/v.unpack/v.unpack.py:164
+msgid ""
+"Difference between PROJ_INFO file of packed map and of current location:\n"
+"{diff}"
+msgstr ""
+#: ../scripts/r.unpack/r.unpack.py:161 ../scripts/v.unpack/v.unpack.py:167
+msgid ""
+"Difference between PROJ_UNITS file of packed map and of current location:\n"
+"{diff}"
+msgstr ""
+#: ../scripts/r.unpack/r.unpack.py:163 ../scripts/v.unpack/v.unpack.py:169
+msgid "Projection of dataset does not appear to match current location. In case of no significant differences in the projection definitions, use the -o flag to ignore them and use current location definition."
+msgstr ""
+#: ../scripts/r.unpack/r.unpack.py:183
+msgid "Raster map <{name}> unpacked"
+msgstr ""
+#: ../scripts/v.in.mapgen/v.in.mapgen.py:80
+#, python-format
+msgid "Input file <%s> not found"
+msgstr ""
+#: ../scripts/v.in.mapgen/v.in.mapgen.py:101
+#: ../scripts/v.in.wfs/v.in.wfs.py:159
+msgid "Importing data..."
+msgstr ""
+#: ../scripts/v.in.mapgen/v.in.mapgen.py:137
+#, python-format
+msgid "An error occurred on line '%s', exiting."
+msgstr ""
+#: ../scripts/v.in.mapgen/v.in.mapgen.py:202
+msgid "Importing with v.in.ascii..."
+msgstr ""
+#: ../scripts/v.in.mapgen/v.in.mapgen.py:207
+#, python-format
+msgid "An error occurred on creating \"%s\", please check"
+msgstr ""
+#: ../scripts/d.frame/d.frame.py:92 ../scripts/d.frame/d.frame.py:121
+#, python-format
+msgid "Unable to get monitor info. %s"
+msgstr ""
+#: ../scripts/d.frame/d.frame.py:108
+#, python-format
+msgid "Unable to get monitor info (no %s found)"
+msgstr ""
+#: ../scripts/d.frame/d.frame.py:200
+#, python-format
+msgid "Invalid frame position: %s"
+msgstr ""
+#: ../scripts/d.frame/d.frame.py:228
+#, python-format
+msgid "Invalid monitor size: %dx%d"
+msgstr ""
+#: ../scripts/d.frame/d.frame.py:284
+#, python-format
+msgid "Frame <%s> doesn't exist, exiting. To create a new frame use '-c' flag."
+msgstr ""
+#: ../scripts/d.frame/d.frame.py:293
+#, python-format
+msgid "Frame <%s> already exists and will be overwritten"
+msgstr ""
+#: ../scripts/d.frame/d.frame.py:298
+#, python-format
+msgid "Frame <%s> already found. An existing frame can be overwritten by '%s' flag."
+msgstr ""
+#: ../scripts/r.grow/r.grow.py:130
+msgid "Output can be written only to the current mapset"
+msgstr ""
+#: ../scripts/r.grow/r.grow.py:140
+msgid "Growing failed. Removing temporary maps."
+msgstr ""
+#: ../scripts/r.grow/r.grow.py:152
+msgid "Shrinking failed. Removing temporary maps."
+msgstr ""
+#: ../scripts/d.polar/d.polar.py:190
+#, python-format
+msgid "Generating %s ..."
+msgstr ""
+#: ../scripts/d.polar/d.polar.py:423
+msgid "Please select only one output method"
+msgstr ""
+#: ../scripts/d.polar/d.polar.py:428
+msgid "xgraph required, please install first (www.xgraph.org)"
+msgstr ""
+#: ../scripts/d.polar/d.polar.py:446
+msgid "Calculating statistics for polar diagram... (be patient)"
+msgstr ""
+#: ../scripts/d.polar/d.polar.py:476
+msgid "No data pixel found"
+msgstr ""
+#: ../scripts/d.polar/d.polar.py:523
+msgid "Average vector:"
+msgstr ""
+#: ../scripts/d.polar/d.polar.py:525
+#, python-format
+msgid "direction: %.1f degrees CCW from East"
+msgstr ""
+#: ../scripts/d.polar/d.polar.py:531
+#, python-format
+msgid "magnitude: %.1f percent of fullscale"
+msgstr ""
+#: ../scripts/db.droptable/db.droptable.py:74
+#: ../scripts/db.dropcolumn/db.dropcolumn.py:64
+msgid "Forcing ..."
+msgstr ""
+#: ../scripts/db.droptable/db.droptable.py:78
+#, python-format
+msgid "Table <%s> not found in database <%s>"
+msgstr ""
+#: ../scripts/db.droptable/db.droptable.py:84
+#, python-format
+msgid "Deleting table <%s> which is attached to following map(s):"
+msgstr ""
+#: ../scripts/db.droptable/db.droptable.py:89
+#, python-format
+msgid "The table <%s> would be deleted."
+msgstr ""
+#: ../scripts/db.droptable/db.droptable.py:91
+msgid "You must use the force flag to actually remove it. Exiting."
+msgstr ""
+#: ../scripts/db.droptable/db.droptable.py:100
+msgid "Cannot continue (problem deleting table)."
+msgstr ""
+#: ../scripts/v.db.univar/v.db.univar.py:80
+#, python-format
+msgid "No attribute table linked to layer <%s>"
+msgstr ""
+#: ../scripts/r.pack/r.pack.py:81
+#, python-format
+msgid "option <output>: <%s> exists."
+msgstr ""
+#: ../scripts/r.pack/r.pack.py:83
+#, python-format
+msgid "Packing <%s> to <%s>..."
+msgstr ""
+#: ../scripts/r.pack/r.pack.py:100
+msgid "No raster map components found"
+msgstr ""
+#: ../scripts/r.pack/r.pack.py:126
+#, python-format
+msgid "Raster map saved to '%s'"
+msgstr ""
+#: ../scripts/i.oif/i.oif.py:54
+#, python-format
+msgid "Calculating OIF for combination: %s, %s, %s"
+msgstr ""
+#: ../scripts/i.oif/i.oif.py:83
+msgid "At least four input maps required"
+msgstr ""
+#: ../scripts/i.oif/i.oif.py:87
+msgid "Calculating standard deviations for all bands..."
+msgstr ""
+#: ../scripts/i.oif/i.oif.py:128
+msgid "Calculating Correlation Matrix..."
+msgstr ""
+#: ../scripts/i.oif/i.oif.py:140
+msgid "Calculating OIF for all band combinations..."
+msgstr ""
+#: ../scripts/i.oif/i.oif.py:147
+msgid "The Optimum Index Factor analysis result (best combination shown first):"
+msgstr ""
+#: ../scripts/r.buffer.lowmem/r.buffer.lowmem.py:110
+msgid "Extracting buffers (1/2)..."
+msgstr ""
+#: ../scripts/r.buffer.lowmem/r.buffer.lowmem.py:122
+msgid "Extracting buffers (2/2)..."
+msgstr ""
+#: ../scripts/v.to.lines/v.to.lines.py:71
+msgid "The input vector map contains both polygons and points, cannot handle mixed types"
+msgstr ""
+#: ../scripts/v.to.lines/v.to.lines.py:81
+#, python-format
+msgid "Processing point data (%d points found)..."
+msgstr ""
+#: ../scripts/v.to.lines/v.to.lines.py:91
+msgid "The input vector map does not contain polygons"
+msgstr ""
+#: ../scripts/v.to.lines/v.to.lines.py:96
+#, python-format
+msgid "Processing area data (%d areas found)..."
+msgstr ""
+#: ../scripts/v.to.lines/v.to.lines.py:105
+msgid "Error creating layer 2"
+msgstr ""
+#: ../scripts/v.to.lines/v.to.lines.py:113
+msgid "Error creating new table for layer 2"
+msgstr ""
+#: ../scripts/v.to.lines/v.to.lines.py:120
+msgid "Error populating new table for layer 2"
+msgstr ""
+#: ../scripts/v.to.lines/v.to.lines.py:128
+msgid "Error converting polygon to line"
+msgstr ""
+#: ../scripts/v.to.lines/v.to.lines.py:144
+msgid "Error removing centroids"
+msgstr ""
+#: ../scripts/v.to.lines/v.to.lines.py:154
+msgid "Error removing table from layer 1"
+msgstr ""
+#: ../scripts/v.to.lines/v.to.lines.py:165
+msgid "Error adding categories"
+msgstr ""
+#: ../scripts/d.correlate/d.correlate.py:44
+msgid "At least 2 maps are required"
+msgstr ""
+#: ../scripts/v.db.addtable/v.db.addtable.py:81
+#, python-format
+msgid "Using vector map name as table name: <%s>"
+msgstr ""
+#: ../scripts/v.db.addtable/v.db.addtable.py:87
+#, python-format
+msgid "Using vector map name extended by layer number as table name: <%s>"
+msgstr ""
+#: ../scripts/v.db.addtable/v.db.addtable.py:90
+#, python-format
+msgid "Using user specified table name: %s"
+msgstr ""
+#: ../scripts/v.db.addtable/v.db.addtable.py:94
+msgid "Creating new DB connection based on default mapset settings..."
+msgstr ""
+#: ../scripts/v.db.addtable/v.db.addtable.py:104
+#, python-format
+msgid "There is already a table linked to layer <%s>"
+msgstr ""
+#: ../scripts/v.db.addtable/v.db.addtable.py:119
+#, python-format
+msgid "Duplicate column name '%s' not allowed"
+msgstr ""
+#: ../scripts/v.db.addtable/v.db.addtable.py:130
+#, python-format
+msgid "Creating table with columns (%s)..."
+msgstr ""
+#: ../scripts/v.db.addtable/v.db.addtable.py:158
+msgid "Current attribute table links:"
+msgstr ""
+#: ../scripts/db.in.ogr/db.in.ogr.py:99
+#, python-format
+msgid "Table <%s> already exists and will be overwritten"
+msgstr ""
+#: ../scripts/db.in.ogr/db.in.ogr.py:105
+#, python-format
+msgid "Table <%s> already exists"
+msgstr ""
+#: ../scripts/db.in.ogr/db.in.ogr.py:120
+#, python-format
+msgid "Input table <%s> not found or not readable"
+msgstr ""
+#: ../scripts/db.in.ogr/db.in.ogr.py:123
+#, python-format
+msgid "Input DSN <%s> not found or not readable"
+msgstr ""
+#: ../scripts/db.in.ogr/db.in.ogr.py:136
+msgid "Something went wrong. Should not happen"
+msgstr ""
+#: ../scripts/db.in.ogr/db.in.ogr.py:151
+#, python-format
+msgid "Imported table <%s> with %d rows"
+msgstr ""
+#: ../scripts/r.in.wms/r.in.wms.py:228
+msgid "Importing raster map into GRASS..."
+msgstr ""
+#: ../scripts/r.in.wms/r.in.wms.py:230
+msgid ""
+"Nothing to import.\n"
+"No data has been downloaded from wms server."
+msgstr ""
+#: ../scripts/r.in.wms/wms_drv.py:33
+msgid "Unable to load GDAL python bindings"
+msgstr ""
+#: ../scripts/r.in.wms/wms_drv.py:65
+msgid "Downloading data from WMS server..."
+msgstr ""
+#: ../scripts/r.in.wms/wms_drv.py:134
+#, python-format
+msgid ""
+"Authorization failed to '%s' when fetching data.\n"
+"%s"
+msgstr ""
+#: ../scripts/r.in.wms/wms_drv.py:138
+#, python-format
+msgid ""
+"Unable to fetch data from: '%s'\n"
+"%s"
+msgstr ""
+#: ../scripts/r.in.wms/wms_drv.py:161
+#, python-format
+msgid ""
+"Server refused to send data for a tile.\n"
+"Request will be repeated after %d s."
+msgstr ""
+#: ../scripts/r.in.wms/wms_drv.py:167
+#, python-format
+msgid ""
+"Unable to write data into tempfile.\n"
+"%s"
+msgstr ""
+#: ../scripts/r.in.wms/wms_drv.py:180
+#, python-format
+msgid ""
+"Unable to read data from tempfile.\n"
+"%s"
+msgstr ""
+#: ../scripts/r.in.wms/wms_drv.py:185
+#, python-format
+msgid "WMS server error: %s"
+msgstr ""
+#: ../scripts/r.in.wms/wms_drv.py:187
+msgid "WMS server unknown error"
+msgstr ""
+#: ../scripts/r.in.wms/wms_drv.py:206
+#, python-format
+msgid "Driver %s does not supports Create() method"
+msgstr ""
+#: ../scripts/r.in.wms/wms_drv.py:260
+#, python-format
+msgid "Unable to open %s "
+msgstr ""
+#: ../scripts/r.in.wms/wms_drv.py:326
+msgid "Region is out of server data extend."
+msgstr ""
+#: ../scripts/r.in.wms/wms_drv.py:354
+#, python-format
+msgid "Fetching %d tiles with %d x %d pixel size per tile..."
+msgstr ""
+#: ../scripts/r.in.wms/wms_drv.py:562 ../scripts/r.in.wms/wms_drv.py:801
+#, python-format
+msgid ""
+"Unable to parse tile service file.\n"
+"%s\n"
+msgstr ""
+#: ../scripts/r.in.wms/wms_drv.py:606
+#, python-format
+msgid "Layer '%s' was not found in capabilities file"
+msgstr ""
+#: ../scripts/r.in.wms/wms_drv.py:625
+#, python-format
+msgid "Layer '%s' is not available with %s code."
+msgstr ""
+#: ../scripts/r.in.wms/wms_drv.py:825
+#, python-format
+msgid ""
+"Unable to parse tile service file. \n"
+" No tag '%s' was found."
+msgstr ""
+#: ../scripts/r.in.wms/wms_drv.py:836
+#, python-format
+msgid "Tiled group '%s' was not found in tile service file"
+msgstr ""
+#: ../scripts/r.in.wms/wms_drv.py:930
+#, python-format
+msgid ""
+"Wrong form of parameter '%s' in '%s'. \n"
+" The parameter was ignored."
+msgstr ""
+#: ../scripts/r.in.wms/wms_drv.py:953
+#, python-format
+msgid "Parameter '%s' in '%s' is not variable in tile pattern url."
+msgstr ""
+#: ../scripts/r.in.wms/wms_drv.py:958
+#, python-format
+msgid "%s driver supports only '%s' parameter in '%s'. Other parameters are ignored."
+msgstr ""
+#: ../scripts/r.in.wms/wms_base.py:90
+#, python-format
+msgid "Please insert both %s and %s parameters or none of them."
+msgstr ""
+#: ../scripts/r.in.wms/wms_base.py:99
+msgid "JPEG format does not support transparency"
+msgstr ""
+#: ../scripts/r.in.wms/wms_base.py:108
+#, python-format
+msgid "Invalid EPSG code %d"
+msgstr ""
+#: ../scripts/r.in.wms/wms_base.py:114
+#, python-format
+msgid "WMS version <1.3.0> will be used, because version <1.1.1> does not support <%s>projection"
+msgstr ""
+#: ../scripts/r.in.wms/wms_base.py:141
+msgid "Unable to get projection info"
+msgstr ""
+#: ../scripts/r.in.wms/wms_base.py:148
+msgid "Maxcols must be greater than 100"
+msgstr ""
+#: ../scripts/r.in.wms/wms_base.py:152
+msgid "Maxrows must be greater than 100"
+msgstr ""
+#: ../scripts/r.in.wms/wms_base.py:193
+#, python-format
+msgid ""
+"These parameter are ignored: %s\n"
+" %s driver does not support the parameters."
+msgstr ""
+#: ../scripts/r.in.wms/wms_base.py:204
+#, python-format
+msgid ""
+"These flags are ignored: %s\n"
+" %s driver does not support the flags."
+msgstr ""
+#: ../scripts/r.in.wms/wms_base.py:250
+#, python-format
+msgid "Authorization failed to <%s> when fetching capabilities"
+msgstr ""
+#: ../scripts/r.in.wms/wms_base.py:253
+msgid "Unable to fetch capabilities from <{0}>. Reason: "
+msgstr ""
+#: ../scripts/r.in.wms/wms_base.py:293
+#, python-format
+msgid ""
+"Unabble to open file '%s'.\n"
+"%s\n"
+msgstr ""
+#: ../scripts/r.in.wms/wms_base.py:330
+msgid "Unable to write data into tempfile"
+msgstr ""
+#: ../scripts/r.in.wms/wms_base.py:341
+#, python-format
+msgid "Unable to determine region, %s failed"
+msgstr ""
+#: ../scripts/r.in.wms/wms_base.py:345
+msgid "Region definition: 4 points required"
+msgstr ""
+#: ../scripts/r.in.wms/wms_base.py:351
+msgid "Reprojection of region using m.proj failed."
+msgstr ""
+#: ../scripts/r.in.wms/wms_base.py:382
+msgid "Reprojecting raster..."
+msgstr ""
+#: ../scripts/r.in.wms/wms_base.py:421 ../scripts/r.in.wms/wms_base.py:478
+#: ../scripts/r.in.wms/wms_base.py:488 ../scripts/r.in.wms/wms_base.py:518
+#: ../scripts/r.in.wms/wms_base.py:542 ../scripts/r.in.wms/wms_base.py:553
+#: ../scripts/r.in.wms/wms_base.py:565
+#, python-format
+msgid "%s failed"
+msgstr ""
+#: ../scripts/r.in.wms/wms_base.py:438
+msgid "Unable to create temporary files"
+msgstr ""
+#: ../scripts/r.in.wms/wms_base.py:468
+#, python-format
+msgid "Please change output name, or change names of these rasters: %s, module needs to create this temporary maps during execution."
+msgstr ""
+#: ../scripts/r.in.wms/wms_base.py:567
+#, python-format
+msgid "<%s> created."
+msgstr ""
+#: ../scripts/r.in.wms/wms_cap_parsers.py:41
+msgid "Unable to parse XML file"
+msgstr ""
+#: ../scripts/r.in.wms/wms_cap_parsers.py:43
+#, python-format
+msgid ""
+"Unable to open XML file '%s'.\n"
+"%s\n"
+msgstr ""
+#: ../scripts/r.in.wms/wms_cap_parsers.py:46
+msgid "Root node was not found."
+msgstr ""
+#: ../scripts/r.in.wms/wms_cap_parsers.py:61
+#, python-format
+msgid ""
+"Unable to parse capabilities file.\n"
+" Tag <%s> was not found."
+msgstr ""
+#: ../scripts/r.in.wms/wms_cap_parsers.py:92
+msgid "Missing version attribute root node in Capabilities XML file"
+msgstr ""
+#: ../scripts/r.in.wms/wms_cap_parsers.py:104
+#, python-format
+msgid "WMS server does not support '%s' version."
+msgstr ""
+#: ../scripts/r.in.wms/wms_cap_parsers.py:238
+#: ../scripts/r.in.wms/wms_cap_parsers.py:250
+#, python-format
+msgid ""
+"Unable to parse capabilities file. \n"
+msgstr ""
+#: ../scripts/r.in.wms/wms_cap_parsers.py:484
+#: ../scripts/r.in.wms/wms_cap_parsers.py:499
+#, python-format
+msgid ""
+" Tag '%s' was not found."
+msgstr ""
+#: ../scripts/r.in.wms/wms_cap_parsers.py:555
+#, python-format
+msgid ""
+msgstr ""
+#: ../scripts/r.in.wms/wms_gdal_drv.py:27
+msgid "Unable to load GDAL Python bindings"
+msgstr ""
+#: ../scripts/r.in.wms/wms_gdal_drv.py:126
+msgid ""
+"If module will not be able to fetch the data in this geographic projection, \n"
+" try 'WMS_GRASS' driver or use WMS version 1.1.1."
+msgstr ""
+#: ../scripts/r.in.wms/wms_gdal_drv.py:137
+msgid "Unable to open GDAL WMS driver"
+msgstr ""
+#: ../scripts/r.in.wms/wms_gdal_drv.py:143
+#, python-format
+msgid "Unable to find %s driver"
+msgstr ""
+#: ../scripts/r.in.wms/wms_gdal_drv.py:148
+#, python-format
+msgid "Driver %s supports CreateCopy() method."
+msgstr ""
+#: ../scripts/r.in.wms/wms_gdal_drv.py:155
+msgid "Incorrect WMS query"
+msgstr ""
+#: ../scripts/v.unpack/v.unpack.py:130
+#, python-format
+msgid "This GRASS GIS pack file contains raster data. Use r.unpack to unpack <%s>"
+msgstr ""
+#: ../scripts/v.unpack/v.unpack.py:143
+msgid "PROJ_INFO file is missing, unpack vector map in XY (unprojected) location."
+msgstr ""
+#: ../scripts/v.unpack/v.unpack.py:161
+msgid "Projection information does not match. Proceeding..."
+msgstr ""
+#: ../scripts/v.unpack/v.unpack.py:215
+#, python-format
+msgid "Coping table <%s> as table <%s>"
+msgstr ""
+#: ../scripts/v.unpack/v.unpack.py:226
+#, python-format
+msgid "Unable to copy table <%s> as table <%s>"
+msgstr ""
+#: ../scripts/v.unpack/v.unpack.py:228
+#, python-format
+msgid "Connect table <%s> to vector map <%s> at layer <%s>"
+msgstr ""
+#: ../scripts/v.unpack/v.unpack.py:238
+#, python-format
+msgid "Unable to connect table <%s> to vector map <%s>"
+msgstr ""
+#: ../scripts/v.unpack/v.unpack.py:241
+#, python-format
+msgid "Vector map <%s> successfully unpacked"
+msgstr ""
+#: ../scripts/v.import/v.import.py:159
+#, python-format
+msgid "Missing value for parameter <%s>"
+msgstr ""
+#: ../scripts/v.import/v.import.py:178 ../scripts/r.import/r.import.py:194
+#, python-format
+msgid "Input <%s> successfully imported without reprojection"
+msgstr ""
+#: ../scripts/v.import/v.import.py:182
+#, python-format
+msgid "Unable to import <%s>"
+msgstr ""
+#: ../scripts/v.import/v.import.py:190 ../scripts/r.import/r.import.py:206
+#, python-format
+msgid "Coordinate reference system not available for current location <%s>"
+msgstr ""
+#: ../scripts/v.import/v.import.py:210 ../scripts/r.import/r.import.py:226
+#, python-format
+msgid "Creating temporary location for <%s>..."
+msgstr ""
+#: ../scripts/v.import/v.import.py:215
+#, python-format
+msgid "Unable to create location from OGR datasource <%s>"
+msgstr ""
+#: ../scripts/v.import/v.import.py:231 ../scripts/r.import/r.import.py:245
+#, python-format
+msgid "Coordinate reference system not available for input <%s>"
+msgstr ""
+#: ../scripts/v.import/v.import.py:248 ../scripts/r.import/r.import.py:328
+msgid "Unable to reproject to source location"
+msgstr ""
+#: ../scripts/v.import/v.import.py:255
+#, python-format
+msgid "Importing <%s> ..."
+msgstr ""
+#: ../scripts/v.import/v.import.py:260
+#, python-format
+msgid "Unable to import OGR datasource <%s>"
+msgstr ""
+#: ../scripts/v.import/v.import.py:279 ../scripts/r.import/r.import.py:374
+#, python-format
+msgid "Reprojecting <%s>..."
+msgstr ""
+#: ../scripts/v.import/v.import.py:284
+#, python-format
+msgid "Unable to to reproject vector <%s>"
+msgstr ""
+#: ../scripts/v.centroids/v.centroids.py:65
+msgid "Input vector map contains no boundaries."
+msgstr ""
+#: ../scripts/v.db.join/v.db.join.py:91
+msgid "JOIN is not supported for tables stored in DBF format"
+msgstr ""
+#: ../scripts/v.db.join/v.db.join.py:94
+msgid "There is no table connected to this map. Unable to join any column."
+msgstr ""
+#: ../scripts/v.db.join/v.db.join.py:159
+#, python-format
+msgid "Error creating column <%s>"
+msgstr ""
+#: ../scripts/v.db.join/v.db.join.py:166
+#, python-format
+msgid "Updating column <%s> of vector map <%s>..."
+msgstr ""
+#: ../scripts/v.db.join/v.db.join.py:172
+#, python-format
+msgid "Error filling column <%s>"
+msgstr ""
+#: ../scripts/v.db.dropcolumn/v.db.dropcolumn.py:70
+msgid "There is no table connected to the input vector map. Unable to delete any column. Exiting."
+msgstr ""
+#: ../scripts/v.db.dropcolumn/v.db.dropcolumn.py:74
+#, python-format
+msgid "Unable to delete <%s> column as it is needed to keep table <%s> connected to the input vector map <%s>"
+msgstr ""
+#: ../scripts/v.db.dropcolumn/v.db.dropcolumn.py:80
+#, python-format
+msgid "Column <%s> not found in table <%s>. Skipped"
+msgstr ""
+#: ../scripts/v.db.dropcolumn/v.db.dropcolumn.py:117
+msgid "Deleting column failed"
+msgstr ""
+#: ../scripts/g.manual/g.manual.py:72
+#, python-format
+msgid "Browser '%s' not found"
+msgstr ""
+#: ../scripts/g.manual/g.manual.py:86
+#, python-format
+msgid "No HTML manual page entry for '%s'"
+msgstr ""
+#: ../scripts/g.manual/g.manual.py:93
+#, python-format
+msgid "Starting browser '%(browser)s' for manual entry '%(entry)s'..."
+msgstr ""
+#: ../scripts/g.manual/g.manual.py:100
+#, python-format
+msgid "Error starting browser '%(browser)s' for HTML file '%(path)s'"
+msgstr ""
+#: ../scripts/g.manual/g.manual.py:112
+#, python-format
+msgid "Error starting 'man' for '%s'"
+msgstr ""
+#: ../scripts/g.manual/g.manual.py:113
+#, python-format
+msgid "No manual page entry for '%s'"
+msgstr ""
+#: ../scripts/g.manual/g.manual.py:120
+#, python-format
+msgid "Flags -%c and -%c are mutually exclusive"
+msgstr ""
+#: ../scripts/v.report/v.report.py:109
+#, python-format
+msgid "There is a table connected to input vector map '%s', but there is no key column '%s'."
+msgstr ""
+#: ../scripts/v.report/v.report.py:123
+#, python-format
+msgid "There is a table connected to input vector map '%s', but there are no categories present in the key column '%s'. Consider using v.to.db to correct this."
+msgstr ""
+#: ../scripts/db.dropcolumn/db.dropcolumn.py:67
+#, python-format
+msgid "Deleting <%s> column which may be needed to keep table connected to a vector map"
+msgstr ""
+#: ../scripts/db.dropcolumn/db.dropcolumn.py:72
+#, python-format
+msgid "Column <%s> not found in table"
+msgstr ""
+#: ../scripts/db.dropcolumn/db.dropcolumn.py:75
+#, python-format
+msgid "Column <%s> would be deleted."
+msgstr ""
+#: ../scripts/db.dropcolumn/db.dropcolumn.py:77
+msgid "You must use the force flag (-f) to actually remove it. Exiting."
+msgstr ""
+#: ../scripts/db.dropcolumn/db.dropcolumn.py:113
+msgid "Cannot continue (problem deleting column)"
+msgstr ""
+#: ../scripts/i.pansharpen/i.pansharpen.py:100
+msgid "Required dependency NumPy not found. Exiting."
+msgstr ""
+#: ../scripts/i.pansharpen/i.pansharpen.py:116
+msgid "Maps with selected output prefix names already exist. Delete them or use overwrite flag"
+msgstr ""
+#: ../scripts/i.pansharpen/i.pansharpen.py:133
+#, python-format
+msgid "Performing pan sharpening with hi res pan image: %f"
+msgstr ""
+#: ../scripts/i.pansharpen/i.pansharpen.py:136
+msgid "Using Brovey algorithm"
+msgstr ""
+#: ../scripts/i.pansharpen/i.pansharpen.py:153
+msgid "Calculating Brovey transformation..."
+msgstr ""
+#: ../scripts/i.pansharpen/i.pansharpen.py:186
+msgid "Using IHS<->RGB algorithm"
+msgstr ""
+#: ../scripts/i.pansharpen/i.pansharpen.py:188
+msgid "Transforming to IHS color space..."
+msgstr ""
+#: ../scripts/i.pansharpen/i.pansharpen.py:203
+msgid "Transforming back to RGB color space and sharpening..."
+msgstr ""
+#: ../scripts/i.pansharpen/i.pansharpen.py:217
+msgid "Using PCA/inverse PCA algorithm"
+msgstr ""
+#: ../scripts/i.pansharpen/i.pansharpen.py:218
+msgid "Creating PCA images and calculating eigenvectors..."
+msgstr ""
+#: ../scripts/i.pansharpen/i.pansharpen.py:225
+#: ../scripts/i.pansharpen/i.pansharpen.py:385
+msgid "Input has no data. Check region settings."
+msgstr ""
+#: ../scripts/i.pansharpen/i.pansharpen.py:252
+msgid "Performing inverse PCA ..."
+msgstr ""
+#: ../scripts/i.pansharpen/i.pansharpen.py:319
+msgid "Assigning grey equalized color tables to output images..."
+msgstr ""
+#: ../scripts/i.pansharpen/i.pansharpen.py:328
+msgid "Adjusting blue channel color table..."
+msgstr ""
+#: ../scripts/i.pansharpen/i.pansharpen.py:338
+msgid "The following pan-sharpened output maps have been generated:"
+msgstr ""
+#: ../scripts/i.pansharpen/i.pansharpen.py:340
+#, python-format
+msgid "%s_%s"
+msgstr ""
+#: ../scripts/i.pansharpen/i.pansharpen.py:342
+#, python-format
+msgid "To visualize output, run: g.region -p raster=%s_red"
+msgstr ""
+#: ../scripts/i.pansharpen/i.pansharpen.py:343
+#, python-format
+msgid "d.rgb r=%s_red g=%s_green b=%s_blue"
+msgstr ""
+#: ../scripts/i.pansharpen/i.pansharpen.py:344
+msgid "If desired, combine channels into a single RGB map with 'r.composite'."
+msgstr ""
+#: ../scripts/i.pansharpen/i.pansharpen.py:345
+msgid "Channel colors can be rebalanced using i.colors.enhance."
+msgstr ""
+#: ../scripts/i.pansharpen/i.pansharpen.py:362
+msgid "Histogram matching..."
+msgstr ""
+#: ../scripts/i.image.mosaic/i.image.mosaic.py:74
+msgid "Do not forget to set region properly to cover all images."
+msgstr ""
+#: ../scripts/i.image.mosaic/i.image.mosaic.py:86
+#, python-format
+msgid "Mosaicing %d images..."
+msgstr ""
+#: ../scripts/i.image.mosaic/i.image.mosaic.py:99
+#, python-format
+msgid "Done. Raster map <%s> created."
+msgstr ""
+#. GTC Invalid WFS maximum features parameter
+#: ../scripts/v.in.wfs/v.in.wfs.py:109
+msgid "Invalid maximum number of features"
+msgstr ""
+#. GTC Invalid WFS start index parameter
+#: ../scripts/v.in.wfs/v.in.wfs.py:115
+msgid "Features begin with index \"1\""
+msgstr ""
+#. GTC Downloading WFS features
+#: ../scripts/v.in.wfs/v.in.wfs.py:130
+msgid "Retrieving data..."
+msgstr ""
+#. GTC WFS request HTTP failure
+#: ../scripts/v.in.wfs/v.in.wfs.py:135
+#, python-format
+msgid ""
+"The server couldn't fulfill the request.\n"
+"Error code: %s"
+msgstr ""
+#. GTC WFS request network failure
+#: ../scripts/v.in.wfs/v.in.wfs.py:138
+#, python-format
+msgid ""
+"Failed to reach the server.\n"
+"Reason: %s"
+msgstr ""
+#: ../scripts/v.in.wfs/v.in.wfs.py:153
+msgid "A file called \"wms_capabilities.xml\" already exists here"
+msgstr ""
+#: ../scripts/v.in.wfs/v.in.wfs.py:162
+#, python-format
+msgid "Vector map <%s> imported from WFS."
+msgstr ""
+#: ../scripts/v.in.wfs/v.in.wfs.py:164
+msgid "WFS import failed"
+msgstr ""
+#: ../scripts/r.blend/r.blend.py:67
+#, python-format
+msgid "Raster map <%s> already exists."
+msgstr ""
+#: ../scripts/r.blend/r.blend.py:75
+msgid "Calculating the three component maps..."
+msgstr ""
+#: ../scripts/r.blend/r.blend.py:117
+msgid "Done. Use the following command to visualize the result:"
+msgstr ""
+#: ../scripts/r.blend/r.blend.py:119
+#, python-format
+msgid "d.rgb r=%s.r g=%s.g b=%s.b"
+msgstr ""
+#: ../scripts/v.build.all/v.build.all.py:47
+#, python-format
+msgid ""
+"%s\n"
+"Building topology for vector map <%s> (%d of %d)...\n"
+"%s"
+msgstr ""
+#: ../scripts/v.build.all/v.build.all.py:49
+#, python-format
+msgid "v.build map=%s"
+msgstr ""
+#: ../scripts/v.build.all/v.build.all.py:53
+#, python-format
+msgid "Building topology for vector map <%s> failed"
+msgstr ""
+#: ../scripts/i.in.spotvgt/i.in.spotvgt.py:127
+msgid "'gdalinfo' not found, install GDAL tools first (http://www.gdal.org)"
+msgstr ""
+#: ../scripts/i.in.spotvgt/i.in.spotvgt.py:144
+#, python-format
+msgid "<%s> already exists. Aborting."
+msgstr ""
+#: ../scripts/i.in.spotvgt/i.in.spotvgt.py:149
+#: ../scripts/i.in.spotvgt/i.in.spotvgt.py:155
+#, python-format
+msgid "Please extract %s before import."
+msgstr ""
+#: ../scripts/i.in.spotvgt/i.in.spotvgt.py:169
+msgid "Importing SPOT VGT NDVI map..."
+msgstr ""
+#: ../scripts/i.in.spotvgt/i.in.spotvgt.py:173
+#: ../scripts/i.in.spotvgt/i.in.spotvgt.py:245
+msgid "An error occurred. Stop."
+msgstr ""
+#: ../scripts/i.in.spotvgt/i.in.spotvgt.py:175
+#, python-format
+msgid "Imported SPOT VEGETATION NDVI map <%s>."
+msgstr ""
+#: ../scripts/i.in.spotvgt/i.in.spotvgt.py:192
+msgid "Remapping digital numbers to NDVI..."
+msgstr ""
+#: ../scripts/i.in.spotvgt/i.in.spotvgt.py:234
+msgid "Importing SPOT VGT NDVI quality map..."
+msgstr ""
+#: ../scripts/i.in.spotvgt/i.in.spotvgt.py:261
+#, python-format
+msgid "Imported SPOT VEGETATION SM quality map <%s>."
+msgstr ""
+#: ../scripts/i.in.spotvgt/i.in.spotvgt.py:263
+#, python-format
+msgid "Note: A snow map can be extracted by category 252 (d.rast %s cat=252)"
+msgstr ""
+#: ../scripts/i.in.spotvgt/i.in.spotvgt.py:266
+msgid "Filtering NDVI map by Status Map quality layer..."
+msgstr ""
+#: ../scripts/i.in.spotvgt/i.in.spotvgt.py:273
+#, python-format
+msgid "Filtered SPOT VEGETATION NDVI map <%s>."
+msgstr ""
+#: ../scripts/db.test/db.test.py:48
+#, python-format
+msgid "Using DB driver: %s"
+msgstr ""
+#: ../scripts/db.test/db.test.py:75
+msgid "EXECUTE: OK"
+msgstr ""
+#: ../scripts/db.test/db.test.py:89
+msgid "RESULT: OK"
+msgstr ""
+#: ../scripts/v.what.strds/v.what.strds.py:113
+msgid "Cannot combine 'output' option and 'u' flag"
+msgstr ""
+#: ../scripts/v.what.strds/v.what.strds.py:115
+msgid "'output' option or 'u' flag must be given"
+msgstr ""
+#: ../scripts/v.what.strds/v.what.strds.py:117
+msgid "Attribute table of vector {name} will be updated..."
+msgstr ""
+#: ../scripts/v.what.strds/v.what.strds.py:150
+#, python-format
+msgid "Space time raster dataset <%s> is empty"
+msgstr ""
+#: ../scripts/v.what.strds/v.what.strds.py:164
+#, python-format
+msgid ""
+"Temporal type of space time raster datasets must be equal\n"
+"<%(a)s> of type %(type_a)s do not match <%(b)s> of type %(type_b)s"
+msgstr ""
+#: ../scripts/v.what.strds/v.what.strds.py:225
+#, python-format
+msgid "Unable to add table <%s> to vector map <%s>"
+msgstr ""
+#: ../scripts/v.what.strds/v.what.strds.py:250
+#, python-format
+msgid "Unable to add column %s to vector map <%s> "
+msgstr ""
+#: ../scripts/v.what.strds/v.what.strds.py:258
+#, python-format
+msgid "Unable to run v.what.rast for vector map <%s> and raster map <%s>"
+msgstr ""
+#: ../scripts/r.plane/r.plane.py:89
+msgid "dip must be between -90 and 90."
+msgstr ""
+#: ../scripts/r.plane/r.plane.py:92
+msgid "azimuth must be between 0 and 360"
+msgstr ""
+#: ../scripts/r.reclass.area/r.reclass.area.py:99
+#: ../scripts/r.reclass.area/r.reclass.area.py:205
+msgid "xy-locations are not supported"
+msgstr ""
+#: ../scripts/r.reclass.area/r.reclass.area.py:100
+msgid "Need projected data with grids in meters"
+msgstr ""
+#: ../scripts/r.reclass.area/r.reclass.area.py:106
+msgid "flags c and d are mutually exclusive"
+msgstr ""
+#: ../scripts/r.reclass.area/r.reclass.area.py:116
+#, python-format
+msgid "Temporary raster map <%s> exists"
+msgstr ""
+#: ../scripts/r.reclass.area/r.reclass.area.py:118
+msgid "Generating a clumped raster file including diagonal neighbors..."
+msgstr ""
+#: ../scripts/r.reclass.area/r.reclass.area.py:123
+msgid "Generating a clumped raster file ..."
+msgstr ""
+#: ../scripts/r.reclass.area/r.reclass.area.py:127
+#, python-format
+msgid "Generating a reclass map with area size less than or equal to %f hectares..."
+msgstr ""
+#: ../scripts/r.reclass.area/r.reclass.area.py:130
+#, python-format
+msgid "Generating a reclass map with area size greater than or equal to %f hectares..."
+msgstr ""
+#: ../scripts/r.reclass.area/r.reclass.area.py:162
+#, python-format
+msgid "No areas of size less than or equal to %f hectares found."
+msgstr ""
+#: ../scripts/r.reclass.area/r.reclass.area.py:165
+#, python-format
+msgid "No areas of size greater than or equal to %f hectares found."
+msgstr ""
+#: ../scripts/r.reclass.area/r.reclass.area.py:203
+msgid "Latitude-longitude locations are not supported"
+msgstr ""
+#: ../scripts/r.reclass.area/r.reclass.area.py:210
+msgid "You have to specify mode='lesser' with method='rmarea'"
+msgstr ""
+#: ../scripts/r.reclass.area/r.reclass.area.py:220
+#, python-format
+msgid "Generating output raster map <%s>..."
+msgstr ""
+#: ../scripts/d.redraw/d.redraw.py:54
+#, python-format
+msgid "Unable to open file '%s' for reading. Details: %s"
+msgstr ""
+#: ../scripts/d.redraw/d.redraw.py:64
+#, python-format
+msgid "Unable to open file '%s' for writing. Details: %s"
+msgstr ""
+#: ../scripts/v.in.geonames/v.in.geonames.py:53
+msgid "This module only operates in LatLong/WGS84 locations"
+msgstr ""
+#: ../scripts/v.in.geonames/v.in.geonames.py:64
+msgid "Since DBF driver is used, the content of the 'alternatenames' column might be cut with respect to the original Geonames.org column content"
+msgstr ""
+#: ../scripts/v.in.geonames/v.in.geonames.py:68
+#, python-format
+msgid "Converting %d place names..."
+msgstr ""
+#: ../scripts/r3.in.xyz/r3.in.xyz.py:247
+msgid "The 2D and 3D region settings are different. Can not continue."
+msgstr ""
+#: ../scripts/r3.in.xyz/r3.in.xyz.py:249
+#, python-format
+msgid "Region bottom=%.15g top=%.15g vertical_cell_res=%.15g (%d depths)"
+msgstr ""
+#: ../scripts/r3.in.xyz/r3.in.xyz.py:252
+msgid "Creating slices ..."
+msgstr ""
+#: ../scripts/r3.in.xyz/r3.in.xyz.py:281
+#, python-format
+msgid "Processing horizontal slice %d of %d [%.15g,%.15g) ..."
+msgstr ""
+#: ../scripts/r3.in.xyz/r3.in.xyz.py:298 ../scripts/r3.in.xyz/r3.in.xyz.py:304
+msgid "Trouble importing data. Aborting."
+msgstr ""
+#: ../scripts/r3.in.xyz/r3.in.xyz.py:308
+msgid "Assembling 3D cube ..."
+msgstr ""
+#: ../scripts/r3.in.xyz/r3.in.xyz.py:318
+#, python-format
+msgid "Done. 3D raster map <%s> created."
+msgstr ""
+#: ../scripts/r.import/r.import.py:170
+msgid "To set custom resolution value, select 'value' in resolution option"
+msgstr ""
+#: ../scripts/r.import/r.import.py:173
+msgid "Resolution value can't be smaller than 0"
+msgstr ""
+#: ../scripts/r.import/r.import.py:176
+msgid "Please provide the resolution for the imported dataset or change to 'estimated' resolution"
+msgstr ""
+#: ../scripts/r.import/r.import.py:198 ../scripts/r.import/r.import.py:256
+#, python-format
+msgid "Unable to import GDAL dataset <%s>"
+msgstr ""
+#: ../scripts/r.import/r.import.py:235
+#, python-format
+msgid "Unable to read GDAL dataset <%s>"
+msgstr ""
+#: ../scripts/r.import/r.import.py:248
+#, python-format
+msgid "Importing <%s> to temporary location..."
+msgstr ""
+#: ../scripts/r.import/r.import.py:267
+msgid "Input contains GCPs, rectification is required"
+msgstr ""
+#: ../scripts/r.import/r.import.py:295
+msgid "Unable to get reprojected map extent"
+msgstr ""
+#: ../scripts/r.import/r.import.py:348
+msgid "Estimated target resolution for input band <{out}>: {res}"
+msgstr ""
+#: ../scripts/r.import/r.import.py:363
+msgid "Using given resolution for input band <{out}>: {res}"
+msgstr ""
+#: ../scripts/r.import/r.import.py:369
+msgid "Using current region resolution for input band <{out}>: nsres={ns}, ewres={ew}"
+msgstr ""
+#: ../scripts/r.import/r.import.py:381
+#, python-format
+msgid "Unable to to reproject raster <%s>"
+msgstr ""
+#: ../scripts/r.import/r.import.py:384
+#, python-format
+msgid "The reprojected raster <%s> is empty"
+msgstr ""
+#: ../scripts/r.fillnulls/r.fillnulls.py:159
+msgid "A user raster mask (MASK) is present. Saving it..."
+msgstr ""
+#: ../scripts/r.fillnulls/r.fillnulls.py:174
+msgid "Using RST interpolation..."
+msgstr ""
+#: ../scripts/r.fillnulls/r.fillnulls.py:175
+msgid "Locating and isolating NULL areas..."
+msgstr ""
+#: ../scripts/r.fillnulls/r.fillnulls.py:179
+msgid "Skipping masked raster parts"
+msgstr ""
+#: ../scripts/r.fillnulls/r.fillnulls.py:190
+#: ../scripts/r.fillnulls/r.fillnulls.py:459
+msgid "Restoring user mask (MASK)..."
+msgstr ""
+#: ../scripts/r.fillnulls/r.fillnulls.py:194
+#: ../scripts/r.fillnulls/r.fillnulls.py:463
+msgid "Failed to restore user MASK!"
+msgstr ""
+#: ../scripts/r.fillnulls/r.fillnulls.py:198
+msgid "Growing NULL areas"
+msgstr ""
+#: ../scripts/r.fillnulls/r.fillnulls.py:205
+#: ../scripts/r.fillnulls/r.fillnulls.py:220
+#: ../scripts/r.fillnulls/r.fillnulls.py:314
+msgid "abandoned. Removing temporary map, restoring user mask if needed:"
+msgstr ""
+#: ../scripts/r.fillnulls/r.fillnulls.py:209
+msgid "Assigning IDs to NULL areas"
+msgstr ""
+#: ../scripts/r.fillnulls/r.fillnulls.py:234
+#: ../scripts/r.fillnulls/r.fillnulls.py:272
+#: ../scripts/r.fillnulls/r.fillnulls.py:287
+#: ../scripts/r.fillnulls/r.fillnulls.py:295
+#: ../scripts/r.fillnulls/r.fillnulls.py:329
+#: ../scripts/r.fillnulls/r.fillnulls.py:402
+#: ../scripts/r.fillnulls/r.fillnulls.py:423
+#: ../scripts/r.fillnulls/r.fillnulls.py:433
+msgid "abandoned. Removing temporary maps, restoring user mask if needed:"
+msgstr ""
+#: ../scripts/r.fillnulls/r.fillnulls.py:255
+msgid "Input map has no holes. Check region settings."
+msgstr ""
+#. GTC Hole is NULL area in a raster map
+#: ../scripts/r.fillnulls/r.fillnulls.py:258
+#, python-format
+msgid "Processing %d map holes"
+msgstr ""
+#. GTC Hole is a NULL area in a raster map
+#: ../scripts/r.fillnulls/r.fillnulls.py:264
+#, python-format
+msgid "Filling hole %s of %s"
+msgstr ""
+#: ../scripts/r.fillnulls/r.fillnulls.py:334
+#, python-format
+msgid "Interpolating %d points"
+msgstr ""
+#: ../scripts/r.fillnulls/r.fillnulls.py:337
+msgid "No points to interpolate"
+msgstr ""
+#: ../scripts/r.fillnulls/r.fillnulls.py:358
+#, python-format
+msgid "Failed to fill hole %s"
+msgstr ""
+#: ../scripts/r.fillnulls/r.fillnulls.py:372
+#, python-format
+msgid "Filling has failed silently. Leaving temporary maps with prefix <%s> for debugging."
+msgstr ""
+#: ../scripts/r.fillnulls/r.fillnulls.py:437
+#, python-format
+msgid "Using %s bspline interpolation"
+msgstr ""
+#: ../scripts/r.fillnulls/r.fillnulls.py:471
+msgid "Patching fill data into NULL areas..."
+msgstr ""
+#: ../scripts/r.fillnulls/r.fillnulls.py:479
+#, python-format
+msgid "Filled raster map is: %s"
+msgstr ""
+#: ../scripts/r.fillnulls/r.fillnulls.py:486
+msgid "Following holes where not filled. Temporary maps with are left in place to allow examination of unfilled holes"
+msgstr ""
+#: ../scripts/v.in.e00/v.in.e00.py:63
+msgid "'avcimport' program not found, install it first"
+msgstr ""
+#: ../scripts/v.in.e00/v.in.e00.py:68
+msgid "'e00conv' program not found, install it first"
+msgstr ""
+#: ../scripts/v.in.e00/v.in.e00.py:73
+msgid "Must specify one of \"point\", \"line\", or \"area\"."
+msgstr ""
+#: ../scripts/v.in.e00/v.in.e00.py:82
+msgid "Found that E00 file is split into pieces (.e01, ...). Merging..."
+msgstr ""
+#: ../scripts/v.in.e00/v.in.e00.py:121
+msgid "An error may appear next which will be ignored..."
+msgstr ""
+#: ../scripts/v.in.e00/v.in.e00.py:124
+msgid "E00 ASCII found and converted to Arc Coverage in current directory"
+msgstr ""
+#: ../scripts/v.in.e00/v.in.e00.py:128
+msgid "E00 Compressed ASCII found. Will uncompress first..."
+msgstr ""
+#: ../scripts/v.in.e00/v.in.e00.py:131
+msgid "...converted to Arc Coverage in current directory"
+msgstr ""
+#: ../scripts/v.in.e00/v.in.e00.py:138
+#, python-format
+msgid "Importing %ss..."
+msgstr ""
+#: ../scripts/v.in.e00/v.in.e00.py:148
+msgid "An error occurred while running v.in.ogr"
+msgstr ""
+#: ../scripts/v.in.e00/v.in.e00.py:150
+#, python-format
+msgid "Imported <%s> vector map <%s>."
+msgstr ""
+#: ../scripts/v.clip/v.clip.py:73
+#, python-format
+msgid ""
+"Deleting of temporary layer failed. Check above error messages and see following details:\n"
+"%s"
+msgstr ""
+#: ../scripts/v.clip/v.clip.py:180 ../scripts/v.clip/v.clip.py:191
+#, python-format
+msgid ""
+"Clipping steps failed. Check above error messages and see following details:\n"
+"%s"
+msgstr ""
+#: ../scripts/v.db.droptable/v.db.droptable.py:60
+#, python-format
+msgid "No table assigned to layer <%s>"
+msgstr ""
+#: ../scripts/v.db.droptable/v.db.droptable.py:65
+#, python-format
+msgid "User selected table <%s> but the table <%s> is linked to layer <%s>"
+msgstr ""
+#: ../scripts/v.db.droptable/v.db.droptable.py:73
+#, python-format
+msgid "Removing table <%s> linked to layer <%s> of vector map <%s>"
+msgstr ""
+#: ../scripts/v.db.droptable/v.db.droptable.py:77
+msgid "You must use the -f (force) flag to actually remove the table. Exiting."
+msgstr ""
+#: ../scripts/v.db.droptable/v.db.droptable.py:79
+msgid "Leaving map/table unchanged."
+msgstr ""
+#: ../scripts/v.db.droptable/v.db.droptable.py:82
+#, python-format
+msgid "Dropping table <%s>..."
+msgstr ""
+#: ../scripts/v.db.droptable/v.db.droptable.py:88
+msgid "An error occurred while running db.execute"
+msgstr ""
+#: ../scripts/v.db.droptable/v.db.droptable.py:92
+msgid "Current attribute table link(s):"
+msgstr ""
+#: ../scripts/v.db.droptable/v.db.droptable.py:99
+msgid "(No database links remaining)"
+msgstr ""
+#: ../scripts/db.univar/db.univar.py:83
+msgid "'sort' not found: sorting in memory"
+msgstr ""
+#: ../scripts/db.univar/db.univar.py:123
+#, python-format
+msgid "Calculation for column <%s> of table <%s>..."
+msgstr ""
+#: ../scripts/db.univar/db.univar.py:125
+msgid "Reading column values..."
+msgstr ""
+#: ../scripts/db.univar/db.univar.py:146
+#, python-format
+msgid "Table <%s> contains no data."
+msgstr ""
+#: ../scripts/db.univar/db.univar.py:151
+msgid "Calculating statistics..."
+msgstr ""
+#: ../scripts/db.univar/db.univar.py:174
+msgid "No non-null values found"
+msgstr ""
+#: ../scripts/db.out.ogr/db.out.ogr.py:86
+#, python-format
+msgid "File <%s> already exists"
+msgstr ""
+#: ../scripts/db.out.ogr/db.out.ogr.py:94
+#: ../scripts/db.out.ogr/db.out.ogr.py:102
+#, python-format
+msgid "Module <%s> failed"
+msgstr ""
+#: ../scripts/db.out.ogr/db.out.ogr.py:120
+#, python-format
+msgid "Exported table <%s>"
+msgstr ""
+#: ../scripts/r.in.aster/r.in.aster.py:109
+msgid "gdalwarp is not in the path and executable"
+msgstr ""
+#: ../scripts/r.in.aster/r.in.aster.py:119
+#, python-format
+msgid "This module needs to be run in a projected location (found: %s)"
+msgstr ""
+#: ../scripts/r.in.aster/r.in.aster.py:136
+#, python-format
+msgid "band %s is not an available Terra/ASTER band"
+msgstr ""
+#: ../scripts/r.in.aster/r.in.aster.py:142
+msgid "Cleaning up ..."
+msgstr ""
+#: ../scripts/r.in.aster/r.in.aster.py:152
+msgid "Georeferencing aster image ..."
+msgstr ""
+#: ../scripts/r.in.aster/r.in.aster.py:165
+msgid "Importing into GRASS ..."
+msgstr ""
+#: ../scripts/v.db.update/v.db.update.py:89
+msgid "Use of libsqlitefunctions only with SQLite backend"
+msgstr ""
+#: ../scripts/v.db.update/v.db.update.py:102
+msgid "<value> and <qcolumn> are mutually exclusive"
+msgstr ""
+#: ../scripts/v.db.update/v.db.update.py:107
+msgid "Either <value> or <qcolumn> must be given"
+msgstr ""
Added: grass/trunk/locale/po/grasswxpy_hu.po
--- grass/trunk/locale/po/grasswxpy_hu.po (rev 0)
+++ grass/trunk/locale/po/grasswxpy_hu.po 2018-03-10 18:27:01 UTC (rev 72338)
@@ -0,0 +1,20268 @@
+# Translation of grasswxpy_hu.po
+# Copyright (C) 2017 GRASS Development Team
+# This file is distributed under the same license as the GRASS GIS package.
+# transifex generated, 2017
+msgid ""
+msgstr ""
+"Project-Id-Version: grasslibs_hu\n"
+"Report-Msgid-Bugs-To: \n"
+"POT-Creation-Date: 2018-03-10 19:26+0100\n"
+"PO-Revision-Date: 2018-03-10 17:22+0100\n"
+"Last-Translator: Zoltan Siki <siki at agt.bme.hu>, 2018\n"
+"Language-Team: Hungarian (https://www.transifex.com/grass-gis/teams/45198/hu/)\n"
+"Language: hu\n"
+"MIME-Version: 1.0\n"
+"Content-Type: text/plain; charset=UTF-8\n"
+"Content-Transfer-Encoding: 8bit\n"
+"Plural-Forms: nplurals=2; plural=(n != 1);\n"
+#: ../gui/wxpython/rdigit/toolbars.py:27
+msgid "Digitize area"
+msgstr "Terület digitalizálás"
+#: ../gui/wxpython/rdigit/toolbars.py:29
+msgid "Digitize line"
+msgstr "Vonal digitalizálás"
+#: ../gui/wxpython/rdigit/toolbars.py:31
+msgid "Digitize point"
+msgstr "Pont digitalizálás"
+#: ../gui/wxpython/rdigit/toolbars.py:32
+msgid "Save raster map"
+msgstr "Raszter térkép mentés"
+#: ../gui/wxpython/rdigit/toolbars.py:33 ../gui/wxpython/vdigit/toolbars.py:185
+msgid "Undo"
+msgstr "Visszavon"
+#: ../gui/wxpython/rdigit/toolbars.py:34
+msgid "Raster Digitizer manual"
+msgstr ""
+#: ../gui/wxpython/rdigit/toolbars.py:35
+msgid "Quit raster digitizer"
+msgstr ""
+#: ../gui/wxpython/rdigit/toolbars.py:52
+msgid "Select raster map"
+msgstr "Raszter térkép választás"
+#: ../gui/wxpython/rdigit/toolbars.py:67
+msgid "Set drawing color (not raster cell color)"
+msgstr ""
+#: ../gui/wxpython/rdigit/toolbars.py:88
+msgid "Cell value:"
+msgstr "Cella érték:"
+#: ../gui/wxpython/rdigit/toolbars.py:101
+msgid "Width of currently digitized line or diameter of a digitized point in map units."
+msgstr ""
+#: ../gui/wxpython/rdigit/toolbars.py:102
+#: ../gui/wxpython/nviz/preferences.py:559
+#: ../gui/wxpython/gui_core/dialogs.py:1933
+#: ../gui/wxpython/psmap/dialogs.py:3831
+#: ../gui/wxpython/gmodeler/preferences.py:184
+#: ../gui/wxpython/gmodeler/preferences.py:350
+#: ../gui/wxpython/gmodeler/preferences.py:462
+#: ../gui/wxpython/gmodeler/preferences.py:578
+msgid "Width:"
+msgstr "Szélesség:"
+#: ../gui/wxpython/rdigit/toolbars.py:142
+msgid "New raster map"
+msgstr "Új raszter térkép"
+#: ../gui/wxpython/rdigit/dialogs.py:34
+msgid "Create new raster map"
+msgstr "Új raszter térkép létrehozás"
+#: ../gui/wxpython/rdigit/dialogs.py:53
+msgid "Name for new raster map:"
+msgstr "Új raszter térkép neve:"
+#: ../gui/wxpython/rdigit/dialogs.py:58
+msgid "Optionally select background raster map:"
+msgstr "Opcionális háttér raszter térkép:"
+#: ../gui/wxpython/rdigit/dialogs.py:62
+msgid "New raster map type:"
+msgstr "Új raszter térkép típus:"
+#: ../gui/wxpython/rdigit/dialogs.py:92
+msgid "Please specify name for a new raster map"
+msgstr ""
+#: ../gui/wxpython/rdigit/dialogs.py:100
+#, python-format
+msgid "Raster map <%s> already exists in the current mapset. Do you want to overwrite it?"
+msgstr ""
+#: ../gui/wxpython/rdigit/dialogs.py:104
+#: ../gui/wxpython/modules/colorrules.py:679
+#: ../gui/wxpython/gui_core/dialogs.py:475
+#: ../gui/wxpython/lmgr/layertree.py:1085
+#: ../gui/wxpython/datacatalog/tree.py:220
+msgid "Overwrite?"
+msgstr "Felülírhatom?"
+#: ../gui/wxpython/rdigit/controller.py:123
+msgid "Please select first the raster map"
+msgstr ""
+#: ../gui/wxpython/rdigit/controller.py:155
+msgid "Right click to finish area"
+msgstr ""
+#: ../gui/wxpython/rdigit/controller.py:160
+msgid "Right click to finish line"
+msgstr ""
+#: ../gui/wxpython/rdigit/controller.py:303
+msgid "Do you want to save changes?"
+msgstr ""
+#: ../gui/wxpython/rdigit/controller.py:304
+msgid "Save raster map changes"
+msgstr ""
+#: ../gui/wxpython/rdigit/controller.py:383
+msgid "Failed to create backup copy of edited raster map."
+msgstr ""
+#: ../gui/wxpython/rdigit/controller.py:402
+msgid "Failed to create new raster map."
+msgstr ""
+#: ../gui/wxpython/rdigit/controller.py:490
+#: ../gui/wxpython/rdigit/controller.py:518
+msgid "Rasterizing..."
+msgstr "Raszterizálás..."
+#: ../gui/wxpython/rdigit/controller.py:558
+msgid "Failed to set default color table for edited raster map"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:79
+msgid "Check all"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:82
+msgid "Clear all"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:140
+msgid "Enter vector attribute values"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:311
+msgid "Bad color format. Use color format '0:0:0'"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:413
+#: ../gui/wxpython/wxplot/dialogs.py:467
+msgid "Select raster map:"
+msgstr "Raszter térkép:"
+#: ../gui/wxpython/modules/colorrules.py:415
+msgid "Select vector map:"
+msgstr "Vektor térkép:"
+#: ../gui/wxpython/modules/colorrules.py:435
+msgid "Import or export color table:"
+msgstr "Szín tábla import vagy export"
+#: ../gui/wxpython/modules/colorrules.py:440
+msgid "Choose file to load color table"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:441
+msgid "Load"
+msgstr "Betöltés"
+#: ../gui/wxpython/modules/colorrules.py:443
+msgid "Type filename or click to choose file and load color table"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:449
+msgid "Choose file to save color table"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:451
+msgid "Type filename or click to choose file and save color table"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:453 ../gui/wxpython/menustrings.py:9
+#: ../gui/wxpython/menustrings.py:2010
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:10
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1977
+msgid "Save"
+msgstr "Mentés"
+#: ../gui/wxpython/modules/colorrules.py:465
+msgid "&Set"
+msgstr "Beállítá&s"
+#: ../gui/wxpython/modules/colorrules.py:473
+msgid "Load color table:"
+msgstr "Színtábla betöltés:"
+#: ../gui/wxpython/modules/colorrules.py:479
+msgid "Load color table from file:"
+msgstr "Színtábla betöltése fájlból:"
+#: ../gui/wxpython/modules/colorrules.py:487
+msgid "Save color table to file:"
+msgstr "Színtábla mentése fájlba:"
+#: ../gui/wxpython/modules/colorrules.py:519
+msgid "Reload default table"
+msgstr "Alapértelmezett tábla újra betöltése"
+#: ../gui/wxpython/modules/colorrules.py:582
+#: ../gui/wxpython/iclass/toolbars.py:78
+msgid "Preview"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:587
+msgid "Show preview of map (current Map Display extent is used)."
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:619
+#: ../gui/wxpython/modules/colorrules.py:1889
+msgid "No valid color rules given."
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:676
+#, python-format
+msgid "File <%s> already already exists. Do you want to overwrite it?"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:690
+#: ../gui/wxpython/gui_core/forms.py:2348
+msgid "Nothing to save."
+msgstr "Nincs mit menteni."
+#: ../gui/wxpython/modules/colorrules.py:723
+msgid "Invalid color table format"
+msgstr "Hibás szín tábla formátum"
+#: ../gui/wxpython/modules/colorrules.py:804
+#, python-format
+msgid "Invalid rule value '%s'. Unable to apply color table."
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:890
+msgid "Create new color table for raster map"
+msgstr "Új szín tábla létrehozása a raszter térképhez"
+#: ../gui/wxpython/modules/colorrules.py:968
+msgid "Enter raster category values or percents"
+msgstr "Adja meg a raszter kategória értékeket vagy százalékokat"
+#: ../gui/wxpython/modules/colorrules.py:972
+#: ../gui/wxpython/modules/colorrules.py:1654
+#: ../gui/wxpython/modules/colorrules.py:1658
+#: ../gui/wxpython/psmap/dialogs.py:3537
+msgid "range"
+msgstr "tartomány"
+#: ../gui/wxpython/modules/colorrules.py:974
+msgid "fp range"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:976
+#, python-format
+msgid "Enter raster category values or percents (%(range)s = %(min)d-%(max)d)"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:1083
+msgid "Create new color rules for vector map"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:1096
+#: ../gui/wxpython/modules/colorrules.py:1673
+msgid "Enter vector attribute values or percents:"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:1098
+#: ../gui/wxpython/modules/colorrules.py:1675
+msgid "Enter vector attribute values:"
+msgstr "Adja meg a vektor attribútum értékeket:"
+#: ../gui/wxpython/modules/colorrules.py:1109
+msgid "Select vector columns"
+msgstr "Válasszon vektor oszlopokat"
+#: ../gui/wxpython/modules/colorrules.py:1111
+msgid "Layer:"
+msgstr "Réteg:"
+#: ../gui/wxpython/modules/colorrules.py:1113
+msgid "Attribute column:"
+msgstr "Attribútum oszlop:"
+#: ../gui/wxpython/modules/colorrules.py:1116
+msgid "Load color from column:"
+msgstr "Szín betöltés oszlopból:"
+msgid "Save color to column:"
+msgstr "Szín mentés oszlopba:"
+#: ../gui/wxpython/modules/colorrules.py:1118
+msgid "Load size from column:"
+msgstr "Méret betöltése oszlopból:"
+msgid "Save size to column:"
+msgstr "Méret mentése oszlopba:"
+#: ../gui/wxpython/modules/colorrules.py:1120
+msgid "Load width from column:"
+msgstr "Szélesség betöltése oszlopból:"
+msgid "Save width to column:"
+msgstr "Szélesség mentése oszlopba:"
+#: ../gui/wxpython/modules/colorrules.py:1125
+msgid "Use color column instead of color table:"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:1139 ../gui/wxpython/dbmgr/base.py:467
+#: ../gui/wxpython/dbmgr/base.py:2307
+msgid "Add column"
+msgstr "Oszlop hozzáadás"
+#: ../gui/wxpython/modules/colorrules.py:1141
+msgid "Add GRASSRGB column to current attribute table."
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:1200
+#: ../gui/wxpython/modules/colorrules.py:1256
+msgid "Import or export color table"
+#: ../gui/wxpython/modules/colorrules.py:1270
+#, python-format
+msgid "Database connection for vector map <%s> is not defined in DB file. Do you want to create and connect new attribute table?"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:1274
+msgid "No database connection defined"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:1347
+#, python-format
+msgid "Selected map <%(map)s> is not in current mapset <%(mapset)s>. Attribute table cannot be edited."
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:1518
+#, python-format
+msgid "%s column already exists."
+msgstr "%s oszlop már létezik."
+#: ../gui/wxpython/modules/colorrules.py:1552
+msgid "Please wait, loading data from attribute table..."
+msgstr "Kérem várjon, amíg betöltöm az adatokat az attribútum táblából..."
+#: ../gui/wxpython/modules/colorrules.py:1613
+#, python-format
+msgid "Number of loaded records reached %d, displaying all the records will be time-consuming and may lead to computer freezing, do you still want to continue?"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:1617
+msgid "Too many records"
+msgstr "Túl sok rekord"
+#: ../gui/wxpython/modules/colorrules.py:1664
+#, python-format
+msgid "Enter vector attribute values or percents %s:"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:1668
+#, python-format
+msgid "Enter vector attribute values %s:"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:1821
+msgid "Please select column to save values to."
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:1857
+msgid "No color column defined. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:1874
+msgid "Thematic mapping for vector map in 3D view"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:56
+msgid "GRASS GIS Raster Map Calculator"
+msgstr "GRASS GIS raszter térkép kalkulátor"
+#: ../gui/wxpython/modules/mcalc_builder.py:59
+msgid "GRASS GIS 3D Raster Map Calculator"
+msgstr "GRASS GIS 3D raszter térkép kalkulátor"
+#: ../gui/wxpython/modules/mcalc_builder.py:75
+msgid "mapcalc statement"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:142
+msgid "Operators"
+msgstr "Műveletek"
+#: ../gui/wxpython/modules/mcalc_builder.py:144
+#: ../gui/wxpython/vnet/dialogs.py:348
+msgid "Output"
+msgstr "Output"
+#: ../gui/wxpython/modules/mcalc_builder.py:146
+msgid "Operands"
+msgstr "Operandusok"
+#: ../gui/wxpython/modules/mcalc_builder.py:148
+msgid "Expression"
+msgstr "Kifejezés"
+#: ../gui/wxpython/modules/mcalc_builder.py:158
+#: ../gui/wxpython/modules/vclean.py:173 ../gui/wxpython/gui_core/forms.py:597
+#: ../gui/wxpython/gui_core/menu.py:174 ../gui/wxpython/gmodeler/model.py:2835
+#: ../gui/wxpython/gmodeler/frame.py:1983
+msgid "&Run"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:163
+msgid "Save expression to file"
+msgstr "Kifejezés mentése fájlba"
+#: ../gui/wxpython/modules/mcalc_builder.py:165
+#: ../gui/wxpython/gui_core/forms.py:1860
+msgid "&Load"
+msgstr "Betö<és"
+#: ../gui/wxpython/modules/mcalc_builder.py:166
+msgid "Load expression from file"
+msgstr "Kifejezés betöltése fájlból"
+#: ../gui/wxpython/modules/mcalc_builder.py:169
+#: ../gui/wxpython/gui_core/forms.py:617
+msgid "Copy the current command string to the clipboard"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:173
+msgid "exponent"
+msgstr "exponens"
+#: ../gui/wxpython/modules/mcalc_builder.py:175
+msgid "divide"
+msgstr "osztás"
+#: ../gui/wxpython/modules/mcalc_builder.py:177
+msgid "add"
+msgstr "összeadás"
+#: ../gui/wxpython/modules/mcalc_builder.py:180
+msgid "subtract"
+msgstr "kivonás"
+#: ../gui/wxpython/modules/mcalc_builder.py:182
+msgid "modulus"
+msgstr "maradék"
+#: ../gui/wxpython/modules/mcalc_builder.py:185
+msgid "multiply"
+msgstr "szorzás"
+#: ../gui/wxpython/modules/mcalc_builder.py:193
+msgid "left shift"
+msgstr "eltolás balra"
+#: ../gui/wxpython/modules/mcalc_builder.py:196
+msgid "right shift"
+msgstr "eltolás jobbra"
+#: ../gui/wxpython/modules/mcalc_builder.py:199
+msgid "right shift (unsigned)"
+msgstr "eltolás jobbra (előjel nélküli)"
+#: ../gui/wxpython/modules/mcalc_builder.py:201
+msgid "greater than"
+msgstr "nagyobb"
+#: ../gui/wxpython/modules/mcalc_builder.py:204
+msgid "greater than or equal to"
+msgstr "nagyobb vagy egyenlő"
+#: ../gui/wxpython/modules/mcalc_builder.py:206
+msgid "less than"
+msgstr "kisebb"
+#: ../gui/wxpython/modules/mcalc_builder.py:209
+msgid "less than or equal to"
+msgstr "kisebb vagy egyenlő"
+#: ../gui/wxpython/modules/mcalc_builder.py:211
+msgid "equal to"
+msgstr "egyenlő"
+#: ../gui/wxpython/modules/mcalc_builder.py:214
+msgid "not equal to"
+msgstr "nem egyenlő"
+#: ../gui/wxpython/modules/mcalc_builder.py:218
+msgid "one's complement"
+msgstr "egyes komplemens"
+#: ../gui/wxpython/modules/mcalc_builder.py:220
+msgid "NOT"
+msgstr "NEM"
+#: ../gui/wxpython/modules/mcalc_builder.py:223
+msgid "bitwise AND"
+msgstr "bitenkénti ÉS"
+#: ../gui/wxpython/modules/mcalc_builder.py:226
+msgid "bitwise OR"
+msgstr "bitenkénti vagy"
+#: ../gui/wxpython/modules/mcalc_builder.py:229
+msgid "logical AND"
+msgstr "logikai ÉS"
+#: ../gui/wxpython/modules/mcalc_builder.py:232
+msgid "logical AND (ignores NULLs)"
+msgstr "logikai ÉS (NULL értékeket figyelmen kívül hagyja)"
+#: ../gui/wxpython/modules/mcalc_builder.py:234
+msgid "logical OR"
+msgstr "logikai VAGY"
+#: ../gui/wxpython/modules/mcalc_builder.py:237
+msgid "logical OR (ignores NULLs)"
+msgstr "logikai VAGY (NULL értékeket figyelmen kívül hagyja)"
+#: ../gui/wxpython/modules/mcalc_builder.py:242
+msgid "conditional"
+msgstr "feltétel"
+#: ../gui/wxpython/modules/mcalc_builder.py:257
+msgid "Name for new 3D raster map to create"
+msgstr "Létrehozandó új 3D raszter térkép neve"
+#: ../gui/wxpython/modules/mcalc_builder.py:259
+msgid "Name for new raster map to create"
+msgstr "Létrehozandó új raszter térkép neve"
+#: ../gui/wxpython/modules/mcalc_builder.py:268
+msgid "Insert existing 3D raster map"
+msgstr "Létező 3D raszter térkép beillesztés"
+#: ../gui/wxpython/modules/mcalc_builder.py:270
+msgid "Insert existing raster map"
+msgstr "Létező raszter térkép beillesztés"
+#: ../gui/wxpython/modules/mcalc_builder.py:275
+msgid "Insert mapcalc function"
+msgstr "Mapcalc függvény beszúrás"
+#: ../gui/wxpython/modules/mcalc_builder.py:283
+#: ../gui/wxpython/modules/import_export.py:96
+#: ../gui/wxpython/modules/vclean.py:145
+#: ../gui/wxpython/gui_core/preferences.py:1114
+#: ../gui/wxpython/gmodeler/preferences.py:682
+msgid "Allow output files to overwrite existing files"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:292
+msgid "Generate random seed for rand()"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:294
+msgid "Seed:"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:298
+msgid "Integer seed for rand() function"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:305
+msgid "Add created raster map into layer tree"
+msgstr "Létrehozott raszter térkép hozzáadása a rétegfához"
+#: ../gui/wxpython/modules/mcalc_builder.py:642
+msgid "You must enter the name of a new raster map to create."
+msgstr "A létrehozandó új raszter térkép nevét meg kell adnia."
+#: ../gui/wxpython/modules/mcalc_builder.py:653
+msgid "You must enter an expression to create a new raster map."
+msgstr "A raszter térkép létrehozásához egy kifejezést kell megadnia."
+#: ../gui/wxpython/modules/mcalc_builder.py:713
+msgid "Choose a file name to save the expression"
+msgstr "Válasszon egy fájlnevet a kifejezés mentéséhez"
+#: ../gui/wxpython/modules/mcalc_builder.py:714
+#: ../gui/wxpython/modules/mcalc_builder.py:736
+msgid "Expression file (*)|*"
+msgstr "Kifejezés fájl (*)|*"
+#: ../gui/wxpython/modules/mcalc_builder.py:735
+msgid "Choose a file name to load the expression"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:771
+#, python-brace-format
+msgid "'{cmd}' copied to clipboard"
+msgstr "'{cmd}'-t a vágólapra másoltam"
+#: ../gui/wxpython/modules/import_export.py:52
+msgid "Multiple import"
+msgstr "Többszörös import"
+#: ../gui/wxpython/modules/import_export.py:69
+msgid "List of raster layers"
+msgstr "Raszter réteg lista"
+#: ../gui/wxpython/modules/import_export.py:71
+msgid "List of vector layers"
+msgstr "Vektor réteg lista"
+#: ../gui/wxpython/modules/import_export.py:73
+#, python-format
+msgid "List of %s layers"
+msgstr ""
+#: ../gui/wxpython/modules/import_export.py:75
+#: ../gui/wxpython/modules/import_export.py:892
+msgid "right click to (un)select all"
+msgstr ""
+#: ../gui/wxpython/modules/import_export.py:78
+#: ../gui/wxpython/modules/import_export.py:869
+#: ../gui/wxpython/gui_core/forms.py:2033
+msgid "Layer id"
+msgstr "Réteg id"
+#: ../gui/wxpython/modules/import_export.py:79
+#: ../gui/wxpython/gui_core/forms.py:2034
+#: ../gui/wxpython/web_services/widgets.py:937
+msgid "Layer name"
+msgstr ""
+#: ../gui/wxpython/modules/import_export.py:80
+msgid "Name for output GRASS map (editable)"
+msgstr "Output GRASS térképneve (szerkeszthető)"
+#: ../gui/wxpython/modules/import_export.py:82
+#: ../gui/wxpython/gui_core/forms.py:2035 ../gui/wxpython/psmap/dialogs.py:2176
+msgid "Feature type"
+msgstr "Elemtípus"
+#: ../gui/wxpython/modules/import_export.py:83
+#: ../gui/wxpython/modules/import_export.py:85
+#: ../gui/wxpython/gui_core/forms.py:2036
+msgid "Projection match"
+msgstr ""
+#: ../gui/wxpython/modules/import_export.py:92
+msgid "Override projection check (use current location's projection)"
+msgstr "Vetület felülbírálása (az aktuális hely vetületét használja)"
+#: ../gui/wxpython/modules/import_export.py:105
+#: ../gui/wxpython/gui_core/forms.py:686
+msgid "Close dialog on finish"
+msgstr ""
+#: ../gui/wxpython/modules/import_export.py:117
+#: ../gui/wxpython/modules/import_export.py:670
+#: ../gui/wxpython/iscatt/dialogs.py:402
+#: ../gui/wxpython/photo2image/ip2i_manager.py:1880
+#: ../gui/wxpython/image2target/ii2t_manager.py:2706
+#: ../gui/wxpython/gcp/manager.py:2632 ../gui/wxpython/vnet/dialogs.py:1312
+#: ../gui/wxpython/web_services/dialogs.py:145
+#: ../gui/wxpython/web_services/dialogs.py:901
+msgid "Close dialog"
+msgstr "Párbeszédablak lezárás"
+#: ../gui/wxpython/modules/import_export.py:123
+#: ../gui/wxpython/modules/import_export.py:400
+#: ../gui/wxpython/modules/import_export.py:541
+msgid "&Import"
+msgstr "&Import"
+#: ../gui/wxpython/modules/import_export.py:124
+#: ../gui/wxpython/modules/import_export.py:401
+#: ../gui/wxpython/modules/import_export.py:542
+msgid "Import selected layers"
+msgstr "Szelektált rétegek importálása"
+#: ../gui/wxpython/modules/import_export.py:135
+msgid "Source settings"
+msgstr "Forrás beállítások"
+#: ../gui/wxpython/modules/import_export.py:156
+msgid "Import settings"
+msgstr "Beállítások importálása"
+#: ../gui/wxpython/modules/import_export.py:376
+#: ../gui/wxpython/menustrings.py:161 ../gui/wxpython/menustrings.py:1180
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:159
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1160
+#: ../gui/wxpython/lmgr/layertree.py:60
+msgid "Link external raster data"
+msgstr ""
+#: ../gui/wxpython/modules/import_export.py:378
+#: ../gui/wxpython/menustrings.py:36 ../gui/wxpython/menustrings.py:1055
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:37
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1038
+#: ../gui/wxpython/lmgr/layertree.py:58
+msgid "Import raster data"
+msgstr "Raszter adat import"
+#: ../gui/wxpython/modules/import_export.py:386
+#: ../gui/wxpython/modules/import_export.py:527
+msgid "Add linked layers into layer tree"
+msgstr ""
+#: ../gui/wxpython/modules/import_export.py:388
+#: ../gui/wxpython/modules/import_export.py:529
+#: ../gui/wxpython/modules/import_export.py:758
+msgid "Add imported layers into layer tree"
+msgstr "Importált rétegek hozzáadása a rétegfához"
+#: ../gui/wxpython/modules/import_export.py:397
+#: ../gui/wxpython/modules/import_export.py:538
+msgid "&Link"
+msgstr ""
+#: ../gui/wxpython/modules/import_export.py:398
+#: ../gui/wxpython/modules/import_export.py:539
+msgid "Link selected layers"
+msgstr ""
+#: ../gui/wxpython/modules/import_export.py:421
+#: ../gui/wxpython/modules/import_export.py:562
+msgid "No layers selected. Operation canceled."
+msgstr "Nem szelektált réteget. A művelet megszakadt."
+#: ../gui/wxpython/modules/import_export.py:447
+msgid "Unable to determine number of raster bands"
+msgstr "Nem tudom meghatározni a raszter sávok számát"
+#: ../gui/wxpython/modules/import_export.py:517
+#: ../gui/wxpython/menustrings.py:163 ../gui/wxpython/menustrings.py:1182
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:161
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1162
+#: ../gui/wxpython/lmgr/layertree.py:68
+msgid "Link external vector data"
+msgstr ""
+#: ../gui/wxpython/modules/import_export.py:519
+#: ../gui/wxpython/menustrings.py:67 ../gui/wxpython/menustrings.py:1086
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:67
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1068
+#: ../gui/wxpython/lmgr/layertree.py:66
+msgid "Import vector data"
+msgstr "Vektor adat import"
+#: ../gui/wxpython/modules/import_export.py:662
+msgid "Define output format for vector data"
+msgstr "Adja meg a vektor adatokhoz az output formátumot"
+#: ../gui/wxpython/modules/import_export.py:664
+msgid "Define output format for raster data"
+msgstr "Adja meg a raszter adatokhoz az output formátumot"
+#: ../gui/wxpython/modules/import_export.py:672
+msgid "Set external format and close dialog"
+msgstr ""
+#: ../gui/wxpython/modules/import_export.py:729
+msgid "No data source selected."
+msgstr "Nem választott adatforrást."
+#: ../gui/wxpython/modules/import_export.py:744
+msgid "Import DXF layers"
+msgstr "DXF rétegek import"
+#: ../gui/wxpython/modules/import_export.py:751
+msgid "Choose DXF file to import"
+msgstr "Válasszon importálandó DXF fájlt"
+#: ../gui/wxpython/modules/import_export.py:752
+#: ../gui/wxpython/location_wizard/wizard.py:163
+#: ../gui/wxpython/location_wizard/wizard.py:1345
+#: ../gui/wxpython/location_wizard/wizard.py:1421
+#: ../gui/wxpython/location_wizard/wizard.py:1511
+#: ../gui/wxpython/location_wizard/wizard.py:1739
+#: ../gui/wxpython/nviz/tools.py:626 ../gui/wxpython/gui_core/forms.py:1821
+#: ../gui/wxpython/gui_core/forms.py:1913
+#: ../gui/wxpython/gui_core/gselect.py:1196
+#: ../gui/wxpython/gui_core/gselect.py:1510
+#: ../gui/wxpython/gui_core/gselect.py:1526
+#: ../gui/wxpython/gui_core/gselect.py:1573
+#: ../gui/wxpython/gui_core/gselect.py:1609
+#: ../gui/wxpython/psmap/dialogs.py:2679 ../gui/wxpython/psmap/dialogs.py:3021
+#: ../gui/wxpython/psmap/dialogs.py:5796
+#: ../gui/wxpython/animation/dialogs.py:511
+#: ../gui/wxpython/animation/dialogs.py:1083
+#: ../gui/wxpython/animation/dialogs.py:1201
+#: ../gui/wxpython/animation/dialogs.py:1237
+#: ../gui/wxpython/animation/dialogs.py:1261
+#: ../gui/wxpython/animation/dialogs.py:1292
+msgid "Browse"
+msgstr "Tallózás"
+#: ../gui/wxpython/modules/import_export.py:780
+msgid "No layers selected."
+msgstr "Nem szelektált réteget."
+#: ../gui/wxpython/modules/import_export.py:858
+#: ../gui/wxpython/datacatalog/dialogs.py:32
+msgid "Reprojection"
+msgstr ""
+#: ../gui/wxpython/modules/import_export.py:870
+msgid "Name for output GRASS map"
+msgstr "Output GRASS térkép neve"
+#: ../gui/wxpython/modules/import_export.py:888
+msgid "Projection of following layers do not match with projection of current location. "
+msgstr "A következő rétegek vetülete nem egyezik az aktuális hely vetületével."
+#: ../gui/wxpython/modules/import_export.py:890
+msgid "Layers to be reprojected"
+msgstr "Átvetítendő rétegek"
+#: ../gui/wxpython/modules/import_export.py:904
+msgid "&Import && reproject"
+msgstr "&Import && átvetítés"
+#: ../gui/wxpython/modules/import_export.py:905
+msgid "Reproject selected layers"
+msgstr "Kiválasztott rétegek átvetítése"
+#: ../gui/wxpython/modules/extensions.py:41
+msgid "Fetch & install extension from GRASS Addons"
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:58
+msgid "Repository (leave empty to use the official one)"
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:61
+msgid "List of extensions - double-click to install"
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:85
+msgid "Options"
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:113
+msgid "&Fetch"
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:114
+msgid "Fetch list of available modules from GRASS Addons SVN repository"
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:118
+msgid "&Install"
+msgstr "Telepít"
+#: ../gui/wxpython/modules/extensions.py:120
+msgid "Install selected add-ons GRASS module"
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:123
+msgid "Show g.extension manual page"
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:187
+msgid "Extension not defined"
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:211
+msgid "Fetching list of modules from GRASS-Addons SVN (be patient)..."
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:226
+#, python-format
+msgid "%d extensions loaded"
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:238
+msgid "Install"
+msgstr "Telepít"
+#: ../gui/wxpython/modules/extensions.py:243
+msgid "Show manual page"
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:344
+#, python-format
+msgid "Unable to load extensions. %s"
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:390
+msgid "Manage installed GRASS Addons extensions"
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:406
+msgid "List of installed extensions"
+msgstr "Telepített bővítmények listája"
+#: ../gui/wxpython/modules/extensions.py:414
+msgid "Uninstall"
+msgstr "Eltávolítás"
+#: ../gui/wxpython/modules/extensions.py:416
+msgid "Uninstall selected Addons extensions"
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:420
+msgid "Reinstall"
+msgstr "Újratelepítés"
+#: ../gui/wxpython/modules/extensions.py:422
+msgid "Reinstall selected Addons extensions"
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:463
+msgid "No extension selected. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:490
+#, python-format
+msgid ""
+"List of files to be removed:\n"
+"%(files)s\n"
+"\n"
+"Do you want really to remove <%(ext)s> extension?"
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:494
+msgid "Remove extension"
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:527
+msgid "Extension"
+msgstr "Bővítmény"
+#: ../gui/wxpython/modules/histogram.py:191
+#: ../gui/wxpython/mapwin/buffered.py:701
+msgid "Please wait, exporting image..."
+msgstr "Kérem várjon, kép exportálás..."
+#: ../gui/wxpython/modules/histogram.py:293
+msgid "GRASS GIS Histogramming Tool (d.histogram)"
+msgstr ""
+#: ../gui/wxpython/modules/histogram.py:400
+#: ../gui/wxpython/iclass/g.gui.iclass.py:91 ../gui/wxpython/nviz/wxnviz.py:352
+#: ../gui/wxpython/nviz/wxnviz.py:363
+#: ../gui/wxpython/mapswipe/g.gui.mapswipe.py:79
+#, python-format
+msgid "Raster map <%s> not found"
+msgstr ""
+#: ../gui/wxpython/modules/histogram.py:425
+msgid "Select font for histogram text"
+msgstr ""
+#: ../gui/wxpython/modules/histogram.py:472
+#: ../gui/wxpython/photo2image/ip2i_mapdisplay.py:396
+#: ../gui/wxpython/image2target/ii2t_mapdisplay.py:397
+#: ../gui/wxpython/mapswipe/frame.py:556 ../gui/wxpython/gcp/mapdisplay.py:397
+#: ../gui/wxpython/gmodeler/frame.py:707 ../gui/wxpython/mapdisp/frame.py:641
+msgid "Choose a file name to save the image (no need to add extension)"
+msgstr ""
+#: ../gui/wxpython/modules/histogram.py:501 ../gui/wxpython/wxplot/base.py:610
+#: ../gui/wxpython/photo2image/ip2i_mapdisplay.py:425
+#: ../gui/wxpython/menustrings.py:2056
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:2023
+#: ../gui/wxpython/image2target/ii2t_mapdisplay.py:426
+#: ../gui/wxpython/psmap/toolbars.py:76 ../gui/wxpython/gcp/mapdisplay.py:426
+#: ../gui/wxpython/mapdisp/frame.py:811
+msgid "Page setup"
+msgstr "Oldal beállítás"
+#: ../gui/wxpython/modules/histogram.py:505 ../gui/wxpython/wxplot/base.py:611
+#: ../gui/wxpython/photo2image/ip2i_mapdisplay.py:429
+#: ../gui/wxpython/image2target/ii2t_mapdisplay.py:430
+#: ../gui/wxpython/gcp/mapdisplay.py:430 ../gui/wxpython/mapdisp/frame.py:815
+msgid "Print preview"
+msgstr "Nyomtatási kép"
+#: ../gui/wxpython/modules/histogram.py:509 ../gui/wxpython/wxplot/base.py:612
+#: ../gui/wxpython/photo2image/ip2i_mapdisplay.py:433
+#: ../gui/wxpython/image2target/ii2t_mapdisplay.py:434
+#: ../gui/wxpython/gui_core/toolbars.py:68
+#: ../gui/wxpython/gcp/mapdisplay.py:434 ../gui/wxpython/mapdisp/frame.py:819
+msgid "Print display"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:34 ../gui/wxpython/modules/vclean.py:120
+msgid "Set up vector cleaning tools"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:75
+msgid "break lines/boundaries"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:76
+msgid "remove duplicates"
+msgstr "duplikáltak eltávolítása"
+#: ../gui/wxpython/modules/vclean.py:77
+msgid "remove dangles"
+msgstr "lógó vonalak eltávolítása"
+#: ../gui/wxpython/modules/vclean.py:78
+msgid "change boundary dangles to lines"
+msgstr "lógó határvonalak módosítása vonallá"
+#: ../gui/wxpython/modules/vclean.py:79
+msgid "remove bridges"
+msgstr "hidak eltávolítása"
+#: ../gui/wxpython/modules/vclean.py:80
+msgid "change bridges to lines"
+msgstr "hidak módosítása vonallá"
+#: ../gui/wxpython/modules/vclean.py:81
+msgid "snap lines/boundaries"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:82
+msgid "remove duplicate area centroids"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:83
+msgid "break polygons"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:84
+msgid "prune lines/boundaries"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:85
+msgid "remove small areas"
+msgstr "kis területek eltávolítása"
+#: ../gui/wxpython/modules/vclean.py:86
+msgid "remove lines/boundaries of zero length"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:87
+msgid "remove small angles at nodes"
+msgstr "kis szögek megszüntetése a töréspontokban"
+#: ../gui/wxpython/modules/vclean.py:122
+msgid "Choose cleaning tools and set thresholds"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:126
+msgid "Select input vector map:"
+msgstr "Válasszon input vektor térképet:"
+#: ../gui/wxpython/modules/vclean.py:132
+msgid " Feature type: "
+msgstr "Elemtípus:"
+#: ../gui/wxpython/modules/vclean.py:136
+msgid "Select output vector map:"
+msgstr "Output vektor térkép:"
+#: ../gui/wxpython/modules/vclean.py:177
+msgid "Copy the current command string to the clipboard (Ctrl+C)"
+msgstr "Aktuális parancs szöveg vágólapra másolása (Ctrl+C)"
+#: ../gui/wxpython/modules/vclean.py:222 ../gui/wxpython/psmap/utils.py:106
+msgid "point"
+msgstr "pont"
+#: ../gui/wxpython/modules/vclean.py:223
+msgid "line"
+msgstr "vonal"
+#: ../gui/wxpython/modules/vclean.py:224
+msgid "boundary"
+msgstr "határ"
+#: ../gui/wxpython/modules/vclean.py:225
+msgid "centroid"
+msgstr "centrális"
+#: ../gui/wxpython/modules/vclean.py:226
+#: ../gui/wxpython/vdigit/preferences.py:695
+msgid "area"
+msgstr "terület"
+#: ../gui/wxpython/modules/vclean.py:227
+msgid "face"
+msgstr "lap"
+#: ../gui/wxpython/modules/vclean.py:401
+#, python-format
+msgid "%s. cleaning tool removed, will be ignored"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:404
+msgid "Please select a cleaning tool to remove"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:428
+#, python-format
+msgid "%s. cleaning tool moved up"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:430
+msgid "1. cleaning tool can not be moved up "
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:432
+msgid "Please select a cleaning tool to move up"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:460
+#, python-format
+msgid "%s. cleaning tool moved down"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:462
+msgid "Last cleaning tool can not be moved down "
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:464
+msgid "Please select a cleaning tool to move down"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:478
+#, python-format
+msgid "cleaning tool: '%s'"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:488
+#, python-format
+msgid "Threshold for %(num)s. tool '%(tool)s': %(thresh)s"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:516
+msgid "Name of input vector map"
+msgstr "Input vektor térkép neve"
+#: ../gui/wxpython/modules/vclean.py:517
+msgid "Name for output vector map"
+msgstr "Output vektor térkép neve"
+#: ../gui/wxpython/modules/vclean.py:518
+#: ../gui/wxpython/mapswipe/toolbars.py:29
+msgid "Tools"
+msgstr "Eszközök"
+#: ../gui/wxpython/modules/vclean.py:519
+msgid "Threshold"
+msgstr "Küszöbérték"
+#: ../gui/wxpython/modules/vclean.py:521
+#, python-format
+msgid "'%s' not defined"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:523
+#, python-format
+msgid ""
+"Some parameters not defined. Operation canceled.\n"
+"\n"
+"%s"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:528
+msgid "Executing selected cleaning operations..."
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:585
+msgid "Vector cleaning command copied to clipboard"
+msgstr ""
+#: ../gui/wxpython/wxplot/profile.py:49
+msgid "GRASS Profile Analysis Tool"
+msgstr ""
+#: ../gui/wxpython/wxplot/profile.py:65 ../gui/wxpython/wxplot/profile.py:173
+msgid "Profile of"
+msgstr ""
+#: ../gui/wxpython/wxplot/profile.py:94
+#, python-format
+msgid "Distance (%s)"
+msgstr "Távolság (%s)"
+#: ../gui/wxpython/wxplot/profile.py:96
+msgid "Distance along transect"
+msgstr ""
+#: ../gui/wxpython/wxplot/profile.py:97
+msgid "Cell values"
+msgstr "Cella értékek"
+#: ../gui/wxpython/wxplot/profile.py:166
+msgid "Not all points of profile lie inside computational region."
+msgstr ""
+#: ../gui/wxpython/wxplot/profile.py:237
+msgid "Raster values"
+msgstr "Raszter értékek"
+#: ../gui/wxpython/wxplot/profile.py:290
+msgid "You must draw a transect to profile in the map display window."
+msgstr ""
+#: ../gui/wxpython/wxplot/profile.py:291
+msgid "Nothing to profile"
+msgstr ""
+#: ../gui/wxpython/wxplot/profile.py:359
+msgid "Choose prefix for file(s) where to save profile values..."
+msgstr ""
+#: ../gui/wxpython/wxplot/profile.py:361
+msgid "Comma separated value (*.csv)|*.csv"
+msgstr "Vesszővel elválasztott értékek (*.csv)|*.csv"
+#: ../gui/wxpython/wxplot/profile.py:372 ../gui/wxpython/gui_core/pyedit.py:333
+#: ../gui/wxpython/gmodeler/frame.py:2077
+#, python-format
+msgid "File <%s> already exists. Do you want to overwrite this file?"
+msgstr ""
+#: ../gui/wxpython/wxplot/profile.py:375
+msgid "Overwrite file?"
+msgstr "Fájl felülírása?"
+#: ../gui/wxpython/wxplot/profile.py:386
+#, python-format
+msgid ""
+"Unable to open file <%s> for writing.\n"
+"Reason: %s"
+msgstr ""
+"<%s> fájlt nem tudom megnyitni írásra.\n"
+"Ok: %s"
+#: ../gui/wxpython/wxplot/profile.py:402
+#, python-format
+msgid ""
+"%d files created:\n"
+"%s"
+msgstr ""
+"%d fájlt létrehoztam:\n"
+"%s"
+#: ../gui/wxpython/wxplot/profile.py:405
+msgid "No files generated."
+msgstr ""
+#: ../gui/wxpython/wxplot/profile.py:413
+msgid "Statistics for Profile(s)"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:41
+msgid "Select raster maps to profile"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:81
+msgid "Select raster map(s) to profile:"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:132
+msgid "Select pairs of raster maps for scatterplots"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:180
+msgid "Select pairs of raster maps for bivariate scatterplots:"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:195 ../gui/wxpython/wxplot/dialogs.py:502
+msgid "Number of bins (for FP maps)"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:290 ../gui/wxpython/dbmgr/base.py:462
+msgid "Statistics"
+msgstr "Statisztika"
+#: ../gui/wxpython/wxplot/dialogs.py:360
+msgid "C&opy"
+msgstr "Másolás"
+#: ../gui/wxpython/wxplot/dialogs.py:362
+msgid "Copy regression statistics the clipboard (Ctrl+C)"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:403
+msgid "Regression statistics copied to clipboard"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:414
+msgid "Select raster map or imagery group to histogram"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:442
+msgid "Histogram single raster"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:445
+msgid "Histogram imagery group"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:486
+msgid "Select image group:"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:515
+msgid "Histogram type"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:601
+msgid "Selected group must be in current mapset"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:602 ../gui/wxpython/psmap/dialogs.py:595
+#: ../gui/wxpython/psmap/dialogs.py:1421 ../gui/wxpython/psmap/dialogs.py:1445
+#: ../gui/wxpython/psmap/dialogs.py:1496 ../gui/wxpython/psmap/dialogs.py:5104
+#: ../gui/wxpython/animation/dialogs.py:746
+#: ../gui/wxpython/animation/controller.py:295
+msgid "Invalid input"
+msgstr "Hibás input"
+#: ../gui/wxpython/wxplot/dialogs.py:664 ../gui/wxpython/wxplot/base.py:517
+#: ../gui/wxpython/wxplot/base.py:584
+msgid "Text settings"
+msgstr "Szöveg beállítások"
+#: ../gui/wxpython/wxplot/dialogs.py:674
+msgid "Profile title:"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:688
+msgid "Title font size (pts):"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:705
+msgid "X-axis label:"
+msgstr "X tengely címke:"
+#: ../gui/wxpython/wxplot/dialogs.py:719
+msgid "Y-axis label:"
+msgstr "Y tengely címke:"
+#: ../gui/wxpython/wxplot/dialogs.py:733
+msgid "Label font size (pts):"
+msgstr "Címke betűméret (pt):"
+#: ../gui/wxpython/wxplot/dialogs.py:751
+#: ../gui/wxpython/gui_core/preferences.py:498
+#: ../gui/wxpython/gui_core/preferences.py:779
+#: ../gui/wxpython/gui_core/dialogs.py:2414
+#: ../gui/wxpython/psmap/dialogs.py:3947 ../gui/wxpython/psmap/dialogs.py:4554
+#: ../gui/wxpython/psmap/dialogs.py:5218
+msgid "Font settings"
+msgstr "Betűkészlet beállítások"
+#: ../gui/wxpython/wxplot/dialogs.py:761
+msgid "Font family:"
+msgstr "Betűkészlet család:"
+#: ../gui/wxpython/wxplot/dialogs.py:777
+msgid "Style:"
+msgstr "Stílus:"
+#: ../gui/wxpython/wxplot/dialogs.py:793
+msgid "Weight:"
+msgstr "Súly:"
+#: ../gui/wxpython/wxplot/dialogs.py:829 ../gui/wxpython/wxplot/dialogs.py:1428
+#: ../gui/wxpython/iscatt/dialogs.py:397
+#: ../gui/wxpython/photo2image/ip2i_manager.py:1875
+#: ../gui/wxpython/image2target/ii2t_manager.py:2701
+#: ../gui/wxpython/gcp/manager.py:2627 ../gui/wxpython/vnet/dialogs.py:1307
+msgid "Apply changes for the current session"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:832 ../gui/wxpython/wxplot/dialogs.py:1430
+msgid "Apply changes for the current session and close dialog"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:836 ../gui/wxpython/wxplot/dialogs.py:1432
+#: ../gui/wxpython/iscatt/dialogs.py:400
+#: ../gui/wxpython/photo2image/ip2i_manager.py:1878
+#: ../gui/wxpython/image2target/ii2t_manager.py:2704
+#: ../gui/wxpython/gui_core/preferences.py:98
+#: ../gui/wxpython/gcp/manager.py:2630 ../gui/wxpython/vnet/dialogs.py:1310
+msgid "Apply and save changes to user settings file (default for next sessions)"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:838 ../gui/wxpython/wxplot/dialogs.py:1433
+#: ../gui/wxpython/vdigit/preferences.py:70
+#: ../gui/wxpython/gui_core/preferences.py:101
+#: ../gui/wxpython/psmap/dialogs.py:475
+#: ../gui/wxpython/gmodeler/preferences.py:696
+msgid "Close dialog and ignore changes"
+msgstr "Párbeszédablak lezárása és a módosítások eldobása"
+#: ../gui/wxpython/wxplot/dialogs.py:904
+#, python-format
+msgid "Plot text sizes saved to file '%s'."
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:964
+msgid "No map or image group selected to plot."
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:965 ../gui/wxpython/core/workspace.py:1635
+#: ../gui/wxpython/core/gcmd.py:142 ../gui/wxpython/mapwin/buffered.py:2143
+msgid "Warning"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:986 ../gui/wxpython/wxplot/base.py:521
+#: ../gui/wxpython/wxplot/base.py:598
+msgid "Plot settings"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:1007
+msgid "Map/image plotted"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:1019
+msgid "Settings for selected map"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:1037
+msgid "Line color"
+msgstr "Vonalszín"
+#: ../gui/wxpython/wxplot/dialogs.py:1054
+#: ../gui/wxpython/vdigit/preferences.py:166
+msgid "Line width"
+msgstr "Vonalszélesség"
+#: ../gui/wxpython/wxplot/dialogs.py:1072 ../gui/wxpython/psmap/dialogs.py:2942
+#: ../gui/wxpython/psmap/dialogs.py:6807
+msgid "Line style"
+msgstr "Vonalstílus"
+#: ../gui/wxpython/wxplot/dialogs.py:1087
+#: ../gui/wxpython/wxplot/dialogs.py:1150
+#: ../gui/wxpython/wxplot/dialogs.py:1231 ../gui/wxpython/psmap/toolbars.py:95
+msgid "Legend"
+msgstr "Jelmagyarázat"
+#: ../gui/wxpython/wxplot/dialogs.py:1104
+msgid "Transect segment marker settings"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:1109
+#: ../gui/wxpython/wxplot/dialogs.py:1191 ../gui/wxpython/iclass/dialogs.py:396
+#: ../gui/wxpython/nviz/tools.py:976 ../gui/wxpython/nviz/tools.py:2816
+#: ../gui/wxpython/psmap/dialogs.py:6378 ../gui/wxpython/psmap/dialogs.py:6738
+#: ../gui/wxpython/gmodeler/preferences.py:107
+#: ../gui/wxpython/gmodeler/preferences.py:421
+#: ../gui/wxpython/gmodeler/preferences.py:533
+msgid "Color"
+msgstr "Szín"
+#: ../gui/wxpython/wxplot/dialogs.py:1123
+#: ../gui/wxpython/wxplot/dialogs.py:1204 ../gui/wxpython/psmap/dialogs.py:2730
+#: ../gui/wxpython/psmap/dialogs.py:3804 ../gui/wxpython/psmap/dialogs.py:4852
+msgid "Size"
+msgstr "Méret"
+#: ../gui/wxpython/wxplot/dialogs.py:1137
+#: ../gui/wxpython/wxplot/dialogs.py:1218 ../gui/wxpython/psmap/dialogs.py:2414
+#: ../gui/wxpython/psmap/dialogs.py:2575
+msgid "Fill"
+msgstr "Kitöltés"
+#: ../gui/wxpython/wxplot/dialogs.py:1164
+#: ../gui/wxpython/wxplot/dialogs.py:1245 ../gui/wxpython/psmap/dialogs.py:4942
+msgid "Style"
+msgstr "Stílus"
+#: ../gui/wxpython/wxplot/dialogs.py:1186
+msgid "Scatterplot points"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:1268
+msgid "Axis settings"
+msgstr "Tengely beállítások"
+#: ../gui/wxpython/wxplot/dialogs.py:1274
+msgid "X-Axis"
+msgstr "X tengely"
+#: ../gui/wxpython/wxplot/dialogs.py:1275
+msgid "Y-Axis"
+msgstr "Y tengely"
+#: ../gui/wxpython/wxplot/dialogs.py:1284
+msgid "Scale"
+msgstr "Méretarány"
+#: ../gui/wxpython/wxplot/dialogs.py:1296
+msgid "Automatic axis scaling, custom max and min, or scale matches data range (min)"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:1304
+msgid "Custom min"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:1321
+msgid "Custom max"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:1335
+msgid "Log scale"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:1359
+msgid "Grid and Legend settings"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:1364
+msgid "Grid color"
+msgstr "Rács szín"
+#: ../gui/wxpython/wxplot/dialogs.py:1374
+msgid "Show grid"
+msgstr "Rács megjelenítés"
+#: ../gui/wxpython/wxplot/dialogs.py:1383
+msgid "Legend font size"
+msgstr "Jelmagyarázat betűméret"
+#: ../gui/wxpython/wxplot/dialogs.py:1397
+msgid "Show legend"
+msgstr "Jelmagyarázat megjelenítés"
+#: ../gui/wxpython/wxplot/dialogs.py:1597
+#, python-format
+msgid "Plot settings saved to file '%s'."
+msgstr ""
+#: ../gui/wxpython/wxplot/base.py:37
+msgid "Draw/re-draw plot"
+msgstr ""
+#: ../gui/wxpython/wxplot/base.py:40
+msgid "Draw transect in map display window to profile"
+msgstr ""
+#: ../gui/wxpython/wxplot/base.py:43
+msgid "Plot options"
+msgstr ""
+#: ../gui/wxpython/wxplot/base.py:46
+msgid "Plot statistics"
+msgstr ""
+#: ../gui/wxpython/wxplot/base.py:49
+msgid "Save profile data to CSV file"
+msgstr ""
+#: ../gui/wxpython/wxplot/base.py:51
+msgid "Quit plot tool"
+msgstr ""
+#: ../gui/wxpython/wxplot/base.py:485
+msgid "Left Mouse Down at Point:"
+msgstr ""
+#: ../gui/wxpython/wxplot/base.py:534
+msgid "This feature is not yet functional"
+msgstr "Ez a funkció még nem működik"
+#: ../gui/wxpython/wxplot/base.py:535
+msgid "Under Construction"
+msgstr "Készítés alatt"
+#: ../gui/wxpython/wxplot/scatter.py:44
+msgid "GRASS Bivariate Scatterplot Tool"
+msgstr ""
+#: ../gui/wxpython/wxplot/scatter.py:51
+msgid "Bivariate Scatterplot"
+msgstr ""
+#: ../gui/wxpython/wxplot/scatter.py:52 ../gui/wxpython/wxplot/scatter.py:53
+#: ../gui/wxpython/wxplot/histogram.py:52
+#: ../gui/wxpython/wxplot/histogram.py:156
+msgid "Raster cell values"
+msgstr "Raszter cella értékek"
+#: ../gui/wxpython/wxplot/scatter.py:102 ../gui/wxpython/wxplot/scatter.py:254
+msgid "Nothing to plot."
+msgstr ""
+#: ../gui/wxpython/wxplot/scatter.py:113
+msgid "At least 2 raster maps must be specified"
+msgstr ""
+#: ../gui/wxpython/wxplot/scatter.py:136
+msgid "Bivariate Scatterplot of "
+msgstr ""
+#: ../gui/wxpython/wxplot/scatter.py:157 ../gui/wxpython/wxplot/scatter.py:158
+#, python-format
+msgid "Raster <%s> cell values"
+msgstr ""
+#: ../gui/wxpython/wxplot/scatter.py:162 ../gui/wxpython/wxplot/scatter.py:166
+#, python-format
+msgid ": %s"
+msgstr ": %s"
+#: ../gui/wxpython/wxplot/scatter.py:260
+msgid "Regression Statistics for Scatterplot(s)"
+msgstr ""
+#: ../gui/wxpython/wxplot/scatter.py:271
+#, python-format
+msgid ""
+"Regression equation for raster map <%(rast1)s> vs. <%(rast2)s>:\n"
+"\n"
+msgstr ""
+#: ../gui/wxpython/wxplot/histogram.py:43
+msgid "GRASS GIS Histogramming Tool"
+msgstr ""
+#: ../gui/wxpython/wxplot/histogram.py:51
+msgid "Histogram of"
+msgstr ""
+#: ../gui/wxpython/wxplot/histogram.py:53
+#: ../gui/wxpython/wxplot/histogram.py:162
+msgid "Cell counts"
+msgstr "Calla számok"
+#: ../gui/wxpython/wxplot/histogram.py:141
+#, python-format
+msgid "Histogram of image group <%s>"
+msgstr ""
+#: ../gui/wxpython/wxplot/histogram.py:145
+#, python-format
+msgid "Histogram of raster map <%s>"
+msgstr ""
+#: ../gui/wxpython/wxplot/histogram.py:147
+msgid "Histogram of selected raster maps"
+msgstr ""
+#: ../gui/wxpython/wxplot/histogram.py:154
+#, python-format
+msgid "Raster cell values %s"
+msgstr "Raszter cella értékek %s"
+#: ../gui/wxpython/wxplot/histogram.py:164
+msgid "Percent of total cells"
+msgstr "Az összes cella százaléka"
+#: ../gui/wxpython/wxplot/histogram.py:166
+msgid "Area"
+msgstr "Terület"
+#: ../gui/wxpython/wxplot/histogram.py:252
+msgid "Statistics for Map(s) Histogrammed"
+msgstr ""
+#: ../gui/wxpython/wxplot/histogram.py:257
+#, python-format
+msgid "Statistics for raster map <%s>"
+msgstr "Raszter térkép statisztika <%s>"
+#: ../gui/wxpython/iclass/plots.py:73
+msgid "Histograms"
+msgstr ""
+#: ../gui/wxpython/iclass/plots.py:74
+msgid "Coincident plots"
+msgstr ""
+#: ../gui/wxpython/iclass/plots.py:75
+msgid "Scatter plots"
+msgstr ""
+#: ../gui/wxpython/iclass/plots.py:99
+#, python-format
+msgid ""
+"Scatter plot functionality is disabled.\n"
+"\n"
+"Reason: Unable to import packages needed for scatter plot.\n"
+"%s"
+msgstr ""
+#: ../gui/wxpython/iclass/toolbars.py:36
+msgid "Set opacity level"
+msgstr ""
+#: ../gui/wxpython/iclass/toolbars.py:39 ../gui/wxpython/iclass/dialogs.py:280
+msgid "Class manager"
+msgstr ""
+#: ../gui/wxpython/iclass/toolbars.py:42 ../gui/wxpython/iclass/dialogs.py:44
+#: ../gui/wxpython/iscatt/toolbars.py:46
+msgid "Select imagery group"
+msgstr ""
+#: ../gui/wxpython/iclass/toolbars.py:45
+msgid "Run analysis, update histogram and coincidence plots"
+msgstr ""
+#: ../gui/wxpython/iclass/toolbars.py:48
+msgid "Save signature file for i.maxlik"
+msgstr ""
+#: ../gui/wxpython/iclass/toolbars.py:51
+msgid "Remove selected map layer"
+msgstr ""
+#: ../gui/wxpython/iclass/toolbars.py:54
+msgid "Export training areas to vector map"
+msgstr ""
+#: ../gui/wxpython/iclass/toolbars.py:57
+msgid "Import training areas from vector map"
+msgstr ""
+#: ../gui/wxpython/iclass/toolbars.py:60
+#: ../gui/wxpython/gui_core/simplelmgr.py:480
+#: ../gui/wxpython/lmgr/layertree.py:82
+msgid "Add RGB map layer"
+msgstr ""
+msgid "Training"
+msgstr ""
+#: ../gui/wxpython/iclass/toolbars.py:84
+msgid "Set map canvas for "
+msgstr ""
+#: ../gui/wxpython/iclass/toolbars.py:86
+msgid "/ Zoom to map"
+msgstr ""
+#: ../gui/wxpython/iclass/toolbars.py:262
+#: ../gui/wxpython/iclass/toolbars.py:271
+msgid "std dev"
+msgstr ""
+#: ../gui/wxpython/iclass/toolbars.py:345
+msgid "Add raster map"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:39
+#, python-format
+msgid ""
+"Loading imagery lib failed.\n"
+"%s"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:79
+msgid "GRASS GIS Supervised Classification Tool"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:312
+#: ../gui/wxpython/photo2image/ip2i_mapdisplay.py:260
+#: ../gui/wxpython/image2target/ii2t_mapdisplay.py:261
+#: ../gui/wxpython/mapswipe/frame.py:291 ../gui/wxpython/gcp/mapdisplay.py:261
+#: ../gui/wxpython/rlisetup/sampling_frame.py:102
+#: ../gui/wxpython/mapdisp/frame.py:505
+msgid "Map Toolbar"
+msgstr "Térkép eszközsor"
+#: ../gui/wxpython/iclass/frame.py:325
+msgid "IClass Toolbar"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:337
+msgid "IClass Misc Toolbar"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:364
+msgid "Digitization Toolbar"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:388
+msgid "Plots"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:408
+msgid "Preview Display"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:411
+msgid "Training Areas Display"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:485
+msgid "Adjust Training Area Display to Preview Display"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:487
+msgid "Adjust Preview display to Training Area Display"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:489
+msgid "Display synchronization ON"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:491
+msgid "Display synchronization OFF"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:564
+msgid "All changes will be lost. Do you want to continue?"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:573
+msgid "Import vector map"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:593
+#, python-format
+msgid "No areas in vector map <%s>.\n"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:595
+#, python-format
+msgid "Vector map <%s> contains points or lines, these features are ignored."
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:622
+#, python-format
+msgid "Unable to open vector map <%s>"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:633
+#, python-format
+msgid "Unable to copy vector features from <%s>"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:645
+msgid "Unable to open temporary vector map"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:741
+msgid "No training areas to export."
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:754
+#, python-format
+msgid "%d training areas (%d classes) exported to vector map <%s>."
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:994
+msgid "Failed to create temporary vector map."
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:1090
+#, python-format
+msgid "No area in category %s. Category skipped."
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:1094
+msgid "Analysis failed."
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:1101
+msgid "results"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:1107
+msgid "No imagery group selected."
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:1114
+msgid "Due to recent changes in classes, signatures can be outdated and should be recalculated. Do you still want to continue?"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:1117
+msgid "Outdated signatures"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:1135
+#, python-format
+msgid ""
+"A signature file named %s already exists.\n"
+"Do you want to replace it?"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:1138 ../gui/wxpython/gmodeler/frame.py:562
+msgid "File already exists"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:1188
+msgid "No imagery group selected. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:1199
+#, python-format
+msgid "Group <%(group)s> does not have enough files (it has %(files)d files). Operation canceled."
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:1207
+msgid "No areas given. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:1222
+msgid "Vector features are outside raster layers. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/iclass/g.gui.iclass.py:75
+msgid "Name of subgroup required"
+msgstr ""
+#: ../gui/wxpython/iclass/g.gui.iclass.py:79
+#: ../gui/wxpython/iclass/dialogs.py:202
+#, python-format
+msgid "Group <%s> not found"
+msgstr ""
+#: ../gui/wxpython/iclass/g.gui.iclass.py:84
+#, python-format
+msgid "Subgroup <%s> not found"
+msgstr ""
+#: ../gui/wxpython/iclass/g.gui.iclass.py:98 ../gui/wxpython/nviz/wxnviz.py:440
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:64
+#: ../gui/wxpython/dbmgr/g.gui.dbmgr.py:48
+#, python-format
+msgid "Vector map <%s> not found"
+msgstr "Vektor térképet <%s> nem találom"
+#: ../gui/wxpython/iclass/g.gui.iclass.py:121
+#, python-format
+msgid "Loading raster map <%s>..."
+msgstr ""
+#: ../gui/wxpython/iclass/g.gui.iclass.py:124
+#, python-format
+msgid "Loading training map <%s>..."
+msgstr ""
+#: ../gui/wxpython/iclass/digit.py:61
+msgid "You are trying to create a training area outside the computational region. Please, use g.region to set the appropriate region first."
+msgstr ""
+#: ../gui/wxpython/iclass/digit.py:72
+msgid ""
+"In order to create a training area, you have to select class first.\n"
+"\n"
+"There is no class yet, do you want to create one?"
+msgstr ""
+#: ../gui/wxpython/iclass/digit.py:76 ../gui/wxpython/iscatt/controllers.py:413
+msgid "No class selected"
+msgstr ""
+#: ../gui/wxpython/iclass/dialogs.py:78
+#: ../gui/wxpython/image2target/ii2t_manager.py:567
+#: ../gui/wxpython/gcp/manager.py:538
+msgid "Create/edit group..."
+msgstr "Csoport létrehozás/szerkesztés..."
+#: ../gui/wxpython/iclass/dialogs.py:85
+msgid "Name of imagery group is missing."
+msgstr ""
+#: ../gui/wxpython/iclass/dialogs.py:92
+msgid "Name of imagery group:"
+msgstr ""
+#: ../gui/wxpython/iclass/dialogs.py:107
+msgid "Name of imagery subgroup:"
+msgstr ""
+#: ../gui/wxpython/iclass/dialogs.py:182
+msgid "Please choose a subgroup."
+msgstr ""
+#: ../gui/wxpython/iclass/dialogs.py:186
+#, python-format
+msgid "Subgroup <%s> not found in group <%s>"
+msgstr ""
+#: ../gui/wxpython/iclass/dialogs.py:193
+#, python-format
+msgid ""
+"No data found in subgroup <%s> of group <%s>.\n"
+msgstr ""
+#: ../gui/wxpython/iclass/dialogs.py:198
+#, python-format
+msgid ""
+"No data found in group <%s>.\n"
+msgstr ""
+#: ../gui/wxpython/iclass/dialogs.py:250
+msgid "Name of map is missing."
+msgstr ""
+#: ../gui/wxpython/iclass/dialogs.py:257 ../gui/wxpython/gmodeler/dialogs.py:89
+msgid "Name of raster map:"
+msgstr ""
+#: ../gui/wxpython/iclass/dialogs.py:259
+#: ../gui/wxpython/gui_core/dialogs.py:239
+#: ../gui/wxpython/gmodeler/dialogs.py:91
+msgid "Name of vector map:"
+msgstr ""
+#: ../gui/wxpython/iclass/dialogs.py:295 ../gui/wxpython/iscatt/frame.py:143
+msgid "Classes"
+msgstr ""
+#: ../gui/wxpython/iclass/dialogs.py:395 ../gui/wxpython/iscatt/frame.py:416
+msgid "Class name"
+msgstr ""
+#: ../gui/wxpython/iclass/dialogs.py:429 ../gui/wxpython/iscatt/frame.py:454
+msgid "Please use only ASCII characters."
+msgstr ""
+#: ../gui/wxpython/iclass/dialogs.py:545
+msgid "Zoom to training areas of selected class"
+msgstr ""
+#: ../gui/wxpython/iclass/dialogs.py:607
+msgid "Save signature file"
+msgstr ""
+#: ../gui/wxpython/iclass/dialogs.py:668
+msgid "Enter name of signature file:"
+msgstr ""
+#: ../gui/wxpython/iclass/dialogs.py:680
+msgid "Signature file path:"
+msgstr ""
+#: ../gui/wxpython/iclass/dialogs.py:730
+msgid "Export training areas"
+msgstr ""
+#: ../gui/wxpython/iclass/dialogs.py:777 ../gui/wxpython/iscatt/dialogs.py:281
+msgid "Enter name of new vector map:"
+msgstr ""
+#: ../gui/wxpython/iclass/dialogs.py:790 ../gui/wxpython/lmgr/layertree.py:602
+msgid "Export attribute table"
+msgstr ""
+#: ../gui/wxpython/iclass/dialogs.py:793
+msgid "Export attribute table containing computed statistical data"
+msgstr ""
+#: ../gui/wxpython/iclass/dialogs.py:832
+#, python-format
+msgid "Vector map <%s> already exists. Do you want to overwrite it?"
+msgstr ""
+#: ../gui/wxpython/iclass/dialogs.py:835
+#, python-format
+msgid "Vector <%s> exists"
+msgstr ""
+#: ../gui/wxpython/iclass/statistics.py:29
+msgid "Loading imagery lib failed"
+msgstr ""
+#: ../gui/wxpython/iscatt/iscatt_core.py:110
+#: ../gui/wxpython/iscatt/iscatt_core.py:160
+msgid "Select category for editing."
+msgstr "Válasszon kategóriát a szerkesztéshez."
+#: ../gui/wxpython/iscatt/iscatt_core.py:151
+msgid "Computing of scatter plots failed."
+msgstr ""
+#: ../gui/wxpython/iscatt/iscatt_core.py:298
+msgid "Patching category raster conditions file failed."
+msgstr ""
+#: ../gui/wxpython/iscatt/iscatt_core.py:321
+#, python-format
+msgid ""
+"v.build failed:\n"
+"%s"
+msgstr ""
+#: ../gui/wxpython/iscatt/iscatt_core.py:339
+#, python-format
+msgid ""
+"v.to.rast failed:\n"
+"%s"
+msgstr ""
+#: ../gui/wxpython/iscatt/plots.py:42
+msgid "The Scatterplot Tool needs the \"matplotlib\" (python-matplotlib) package to be installed. {0}"
+msgstr ""
+#: ../gui/wxpython/iscatt/plots.py:617
+msgid "Zoom to scatter plot extend"
+msgstr ""
+#: ../gui/wxpython/iscatt/controllers.py:139 ../gui/wxpython/dbmgr/base.py:161
+msgid "Loading data..."
+msgstr "Adatok betöltése..."
+#: ../gui/wxpython/iscatt/controllers.py:204
+msgid "No data set."
+msgstr ""
+#: ../gui/wxpython/iscatt/controllers.py:222
+#, python-format
+msgid ""
+"Interactive Scatter Plot Tool can not be used.\n"
+"Number of cells (rows*cols) <%d> in current regionis higher than maximum limit <%d>.\n"
+"\n"
+"You can reduce number of cells in current region using <g.region> command."
+msgstr ""
+#: ../gui/wxpython/iscatt/controllers.py:231
+#, python-format
+msgid ""
+"Number of cells (rows*cols) <%d> in current region is higher than recommended threshold <%d>.\n"
+"It is strongly advised to reduce number of cells in current region below recommend threshold.\n"
+" It can be done by <g.region> command.\n"
+"\n"
+"Do you want to continue using Interactive Scatter Plot Tool with this region?"
+msgstr ""
+#: ../gui/wxpython/iscatt/controllers.py:288
+msgid "Scatter plot with same band combination (regardless x y order) is already displayed."
+msgstr ""
+#: ../gui/wxpython/iscatt/controllers.py:301
+#, python-format
+msgid "Band <%s> is not CELL (integer) type.\n"
+msgstr ""
+#: ../gui/wxpython/iscatt/controllers.py:304
+msgid "Scatter plot cannot be added.\n"
+msgstr ""
+#: ../gui/wxpython/iscatt/controllers.py:310
+#, python-format
+msgid ""
+"Scatter plot cannot be added.\n"
+"Multiple of bands ranges <%s:%d * %s:%d = %d> is higher than maximum limit <%d>.\n"
+msgstr ""
+#: ../gui/wxpython/iscatt/controllers.py:320
+#, python-format
+msgid ""
+"Multiple of bands ranges <%s:%d * %s:%d = %d> is higher than recommended limit <%d>.\n"
+"It is strongly advised to reduce range extend of bands(e. g. using r.rescale) below recommended threshold.\n"
+"\n"
+"Do you really want to add this scatter plot?"
+msgstr ""
+#: ../gui/wxpython/iscatt/controllers.py:409
+msgid ""
+"In order to select arrea in scatter plot, you have to select class first.\n"
+"\n"
+msgstr ""
+#: ../gui/wxpython/iscatt/controllers.py:444
+#, python-format
+msgid ""
+"Error occurred during computation of scatter plot category:\n"
+"%s"
+msgstr ""
+#: ../gui/wxpython/iscatt/controllers.py:764
+#, python-format
+msgid "Export scatter plot raster of class <%s>"
+msgstr ""
+#: ../gui/wxpython/iscatt/controllers.py:782
+#, python-format
+msgid "Scatter plot raster of class <%s> exported to raster map <%s>."
+msgstr ""
+#: ../gui/wxpython/iscatt/controllers.py:786
+#, python-format
+msgid ""
+"Export of scatter plot raster of class <%s> to map <%s> failed.\n"
+"%s"
+msgstr ""
+#: ../gui/wxpython/iscatt/toolbars.py:48 ../gui/wxpython/iscatt/toolbars.py:146
+#: ../gui/wxpython/nviz/tools.py:2272 ../gui/wxpython/gui_core/toolbars.py:85
+#: ../gui/wxpython/vnet/dialogs.py:946
+msgid "Settings"
+msgstr ""
+#: ../gui/wxpython/iscatt/toolbars.py:51
+#: ../gui/wxpython/gui_core/toolbars.py:72 ../gui/wxpython/vnet/toolbars.py:137
+msgid "Show manual"
+msgstr ""
+#: ../gui/wxpython/iscatt/toolbars.py:54
+msgid "Add scatter plot"
+msgstr ""
+#: ../gui/wxpython/iscatt/toolbars.py:57
+msgid "Select area with polygon"
+msgstr ""
+#: ../gui/wxpython/iscatt/toolbars.py:60
+msgid "Pan mode for scatter plots"
+msgstr ""
+#: ../gui/wxpython/iscatt/toolbars.py:63
+msgid "Zoom mode for scatter plots (left mouse button, wheel)"
+msgstr ""
+#: ../gui/wxpython/iscatt/toolbars.py:66
+msgid "Zoom to scatter plot data extend mode (click on scatter plot for zooming to extend)"
+msgstr ""
+#: ../gui/wxpython/iscatt/toolbars.py:69
+msgid "Show/hide class manager"
+msgstr ""
+#: ../gui/wxpython/iscatt/toolbars.py:175
+#: ../gui/wxpython/iscatt/toolbars.py:176
+msgid "Include selected area to class"
+msgstr ""
+#: ../gui/wxpython/iscatt/toolbars.py:178
+#: ../gui/wxpython/iscatt/toolbars.py:179
+msgid "Exclude selected area from class"
+msgstr ""
+#: ../gui/wxpython/iscatt/toolbars.py:181
+msgid "Add new vertex"
+msgstr ""
+#: ../gui/wxpython/iscatt/toolbars.py:182
+msgid "Add new vertex to polygon boundary scatter plot"
+msgstr ""
+#: ../gui/wxpython/iscatt/toolbars.py:184
+msgid "Create selection polygon"
+msgstr ""
+#: ../gui/wxpython/iscatt/toolbars.py:185
+msgid "Add new vertex between last and first points of the boundary"
+msgstr ""
+#: ../gui/wxpython/iscatt/toolbars.py:187
+msgid "Move vertex"
+msgstr "Töréspont mozgatás"
+#: ../gui/wxpython/iscatt/toolbars.py:188
+msgid "Move boundary vertex"
+msgstr ""
+#: ../gui/wxpython/iscatt/toolbars.py:190
+msgid "Remove vertex"
+msgstr "Töréspont eltávolítás"
+#: ../gui/wxpython/iscatt/toolbars.py:191
+msgid "Remove boundary vertex"
+msgstr "Határvonal töréspont eltávolítás"
+#: ../gui/wxpython/iscatt/toolbars.py:193
+msgid "Remove polygon (click on scatter plot for removing it's polygon)"
+msgstr ""
+#: ../gui/wxpython/iscatt/toolbars.py:271
+msgid "Add class"
+msgstr ""
+#: ../gui/wxpython/iscatt/toolbars.py:273
+msgid "Remove selected class"
+msgstr ""
+#: ../gui/wxpython/iscatt/frame.py:169
+msgid "GRASS GIS Interactive Scatter Plot Tool"
+msgstr ""
+#: ../gui/wxpython/iscatt/frame.py:401
+msgid "scatter plot"
+msgstr ""
+#: ../gui/wxpython/iscatt/frame.py:479
+msgid "Maximum limit of categories number was reached."
+msgstr ""
+#: ../gui/wxpython/iscatt/frame.py:575
+msgid "Rename class"
+msgstr "Osztály átnevezés"
+#: ../gui/wxpython/iscatt/frame.py:579
+msgid "Set color"
+msgstr "Szín beállítás"
+#: ../gui/wxpython/iscatt/frame.py:583 ../gui/wxpython/lmgr/layertree.py:491
+msgid "Change opacity level"
+msgstr "Átlátszósági szint módosítás"
+#: ../gui/wxpython/iscatt/frame.py:587
+msgid "Hide"
+msgstr "Elrejt"
+#: ../gui/wxpython/iscatt/frame.py:589
+msgid "Show"
+msgstr "Mutat"
+#: ../gui/wxpython/iscatt/frame.py:604
+msgid "Move to top"
+msgstr "Felülre mozgat"
+#: ../gui/wxpython/iscatt/frame.py:610
+msgid "Move to bottom"
+msgstr "Alulra mozgat"
+#: ../gui/wxpython/iscatt/frame.py:618
+msgid "Move category up"
+msgstr "Kategória mozgatás fel"
+#: ../gui/wxpython/iscatt/frame.py:624
+msgid "Move category down"
+msgstr "Kategória mozgatás le"
+#: ../gui/wxpython/iscatt/frame.py:632
+msgid "Export class raster"
+msgstr ""
+#: ../gui/wxpython/iscatt/frame.py:704
+#, python-format
+msgid "Change opacity of class <%s>"
+msgstr ""
+#: ../gui/wxpython/iscatt/frame.py:729
+msgid "Empty name was inserted."
+msgstr ""
+msgid "Add scatter plots"
+msgstr ""
+#: ../gui/wxpython/iscatt/dialogs.py:59
+msgid "x axis:"
+msgstr "x tengely:"
+#: ../gui/wxpython/iscatt/dialogs.py:66
+msgid "y axis:"
+msgstr "y tengely:"
+#: ../gui/wxpython/iscatt/dialogs.py:105
+msgid "Bands of scatter plots to be added (x y):"
+msgstr ""
+#: ../gui/wxpython/iscatt/dialogs.py:155
+msgid "No scatter plots selected."
+msgstr ""
+#: ../gui/wxpython/iscatt/dialogs.py:203
+msgid "Select both x and y bands."
+msgstr ""
+#: ../gui/wxpython/iscatt/dialogs.py:207
+msgid "Selected bands must be different."
+msgstr ""
+#: ../gui/wxpython/iscatt/dialogs.py:214
+msgid "Scatter plot with same bands combination (regardless x y order) has been already added into the list."
+msgstr ""
+#: ../gui/wxpython/iscatt/dialogs.py:323
+#, python-format
+msgid "Raster map <%s> already exists. Do you want to overwrite it?"
+msgstr "<%s> raszter térkép már létezik. Felül akarja írni?"
+#: ../gui/wxpython/iscatt/dialogs.py:326
+#, python-format
+msgid "Raster <%s> exists"
+msgstr "<%s> raszter létezik"
+#: ../gui/wxpython/iscatt/dialogs.py:352
+msgid "Show confidence ellipses"
+msgstr "Konfidencia ellipszis megjelenítés"
+#: ../gui/wxpython/iscatt/dialogs.py:359
+msgid "Selection polygon color:"
+msgstr ""
+#: ../gui/wxpython/iscatt/dialogs.py:360
+msgid "Color of selection polygon vertex:"
+msgstr ""
+#: ../gui/wxpython/iscatt/dialogs.py:361
+msgid "Selected area color:"
+msgstr ""
+#: ../gui/wxpython/iscatt/dialogs.py:372 ../gui/wxpython/vnet/dialogs.py:1282
+msgid "Snapping threshold in pixels:"
+msgstr ""
+#: ../gui/wxpython/iscatt/dialogs.py:373
+msgid "Selected area opacity:"
+msgstr ""
+#: ../gui/wxpython/iscatt/dialogs.py:412
+msgid "Selection style:"
+msgstr "Kiválasztás stílus:"
+#: ../gui/wxpython/iscatt/dialogs.py:439
+msgid "Ellipses settings:"
+msgstr ""
+#: ../gui/wxpython/iscatt/core_c.py:23
+msgid "Loading ctypes libs failed"
+msgstr ""
+#: ../gui/wxpython/location_wizard/dialogs.py:38
+#: ../gui/wxpython/location_wizard/wizard.py:176
+msgid "Set default region extent and resolution"
+msgstr ""
+#: ../gui/wxpython/location_wizard/dialogs.py:109
+msgid "&Set region"
+msgstr "Régió beállítá&s"
+#: ../gui/wxpython/location_wizard/dialogs.py:141
+msgid "Invalid location selected."
+msgstr "Hibás helyet választott"
+#: ../gui/wxpython/location_wizard/dialogs.py:142
+#: ../gui/wxpython/location_wizard/dialogs.py:161
+#: ../gui/wxpython/location_wizard/dialogs.py:490
+#: ../gui/wxpython/location_wizard/wizard.py:675
+#: ../gui/wxpython/location_wizard/wizard.py:864
+#: ../gui/wxpython/location_wizard/wizard.py:2013
+#: ../gui/wxpython/core/workspace.py:1616 ../gui/wxpython/core/gcmd.py:115
+#: ../gui/wxpython/gis_set.py:281 ../gui/wxpython/gis_set.py:711
+#: ../gui/wxpython/gis_set.py:755
+#: ../gui/wxpython/image2target/ii2t_gis_set.py:276
+#: ../gui/wxpython/image2target/ii2t_gis_set.py:654
+#: ../gui/wxpython/image2target/ii2t_gis_set.py:698
+#: ../gui/wxpython/vdigit/dialogs.py:253 ../gui/wxpython/vdigit/dialogs.py:447
+#: ../gui/wxpython/gui_core/preferences.py:229
+#: ../gui/wxpython/gui_core/preferences.py:1886
+#: ../gui/wxpython/gui_core/preferences.py:1919
+#: ../gui/wxpython/gui_core/preferences.py:1931
+#: ../gui/wxpython/gui_core/preferences.py:1943
+#: ../gui/wxpython/psmap/dialogs.py:5594 ../gui/wxpython/lmgr/layertree.py:1003
+#: ../gui/wxpython/gmodeler/frame.py:1141
+msgid "Error"
+msgstr "Hiba"
+#: ../gui/wxpython/location_wizard/dialogs.py:160
+msgid "Invalid region"
+msgstr "Hibás régió"
+#: ../gui/wxpython/location_wizard/dialogs.py:191
+msgid "Click here to show 3D settings"
+msgstr ""
+#: ../gui/wxpython/location_wizard/dialogs.py:192
+msgid "Click here to hide 3D settings"
+msgstr ""
+#: ../gui/wxpython/location_wizard/dialogs.py:218
+#: ../gui/wxpython/location_wizard/dialogs.py:526
+#, python-format
+msgid "Rows: %d"
+msgstr "Sorok: %d"
+#: ../gui/wxpython/location_wizard/dialogs.py:219
+#: ../gui/wxpython/location_wizard/dialogs.py:527
+#, python-format
+msgid "Cols: %d"
+msgstr "Oszlopok: %d"
+#: ../gui/wxpython/location_wizard/dialogs.py:220
+#: ../gui/wxpython/location_wizard/dialogs.py:528
+#, python-format
+msgid "Cells: %d"
+msgstr "Cellák: %d"
+#: ../gui/wxpython/location_wizard/dialogs.py:268
+#: ../gui/wxpython/location_wizard/dialogs.py:530
+#, python-format
+msgid "Depth: %d"
+msgstr "Mélység: %d"
+#: ../gui/wxpython/location_wizard/dialogs.py:272
+#: ../gui/wxpython/location_wizard/dialogs.py:531
+#, python-format
+msgid "3D Cells: %d"
+msgstr "3D cellák: %d"
+#: ../gui/wxpython/location_wizard/dialogs.py:276
+#: ../gui/wxpython/psmap/dialogs.py:531
+msgid "Top"
+msgstr "Felső"
+#: ../gui/wxpython/location_wizard/dialogs.py:284
+#: ../gui/wxpython/psmap/dialogs.py:532
+msgid "Bottom"
+msgstr "Alsó"
+#: ../gui/wxpython/location_wizard/dialogs.py:295
+msgid "T-B resolution"
+msgstr ""
+#: ../gui/wxpython/location_wizard/dialogs.py:360
+msgid "North"
+msgstr "Észak"
+#: ../gui/wxpython/location_wizard/dialogs.py:368
+msgid "West"
+msgstr "Nyugat"
+#: ../gui/wxpython/location_wizard/dialogs.py:390
+msgid "East"
+msgstr "Kelet"
+#: ../gui/wxpython/location_wizard/dialogs.py:399
+msgid "South"
+msgstr "Dél"
+#: ../gui/wxpython/location_wizard/dialogs.py:403
+msgid "N-S resolution"
+msgstr "É-D felbontás"
+#: ../gui/wxpython/location_wizard/dialogs.py:411
+msgid "E-W resolution"
+msgstr "K-Ny felbontás"
+#: ../gui/wxpython/location_wizard/dialogs.py:489
+#, python-format
+msgid "Invalid value: %s"
+msgstr "Hibás érték: %s"
+#: ../gui/wxpython/location_wizard/dialogs.py:586
+msgid "Select datum transformation"
+msgstr "Válasszon dátum transzformációt"
+#: ../gui/wxpython/location_wizard/dialogs.py:612
+msgid "Select from list of datum transformations"
+msgstr "Válasszon dátum transzformációk listájából"
+#: ../gui/wxpython/location_wizard/wizard.py:156
+msgid "Define GRASS Database and Location Name"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:177
+msgid "This option allows setting default computation region immediately after new location is created. Default computation region can be defined later using g.region based on imported data."
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:183
+msgid "Create user mapset"
+msgstr "Felhasználói térképcsoport létrehozás"
+#: ../gui/wxpython/location_wizard/wizard.py:184
+msgid "This option allows creating user mapset immediately after new location is created. Note that GRASS always creates PERMANENT mapset."
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:190
+msgid "GIS Data Directory:"
+msgstr "GISadat könyvtár:"
+#: ../gui/wxpython/location_wizard/wizard.py:209
+msgid "Project Location"
+msgstr "Projekt hely"
+#: ../gui/wxpython/location_wizard/wizard.py:210
+msgid "Name of location directory in GIS Data Directory"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:224
+msgid "Location Title"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:226
+msgid "Optional location title, you can leave this field blank."
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:257
+#, python-format
+msgid "Name <%(name)s> is not a valid name for location. Please use only ASCII characters excluding %(chars)s and space."
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:265
+msgid "Invalid location name"
+msgstr "Hibás hely név"
+#: ../gui/wxpython/location_wizard/wizard.py:280
+msgid "Choose GRASS data directory:"
+msgstr "GRASS adat könyvtár:"
+#: ../gui/wxpython/location_wizard/wizard.py:294
+#: ../gui/wxpython/location_wizard/wizard.py:2560
+msgid "Location already exists in GRASS Database."
+msgstr "A hely már létezik a GRASS adatbázisban"
+#: ../gui/wxpython/location_wizard/wizard.py:298
+msgid "Unable to create location"
+msgstr "Nem tudom létrehozni a helyet"
+#: ../gui/wxpython/location_wizard/wizard.py:312
+msgid "Title of the location is limited only to one line and 256 characters. The rest of the text will be ignored."
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:322
+msgid "Choose method for creating a new location"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:329
+msgid "Select EPSG code of spatial reference system"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:335
+msgid "Read projection and datum terms from a georeferenced data file"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:339
+msgid "Read projection and datum terms from a Well Known Text (WKT) .prj file"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:342
+msgid "Select coordinate system parameters from a list"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:345
+msgid "Specify projection and datum terms using custom PROJ.4 parameters"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:348
+msgid "Create a generic Cartesian coordinate system (XY)"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:352
+msgid "Simple methods:"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:364
+msgid "Advanced methods:"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:467
+msgid "Choose projection"
+msgstr "Válasszon vetületet"
+#: ../gui/wxpython/location_wizard/wizard.py:483
+#: ../gui/wxpython/location_wizard/wizard.py:1010
+#: ../gui/wxpython/location_wizard/wizard.py:1191
+#: ../gui/wxpython/location_wizard/wizard.py:1521
+#: ../gui/wxpython/location_wizard/wizard.py:1749
+msgid "Code"
+msgstr "Kód"
+#: ../gui/wxpython/location_wizard/wizard.py:1522
+#: ../gui/wxpython/location_wizard/wizard.py:1750
+#: ../gui/wxpython/gmodeler/frame.py:1734
+#: ../gui/wxpython/gmodeler/frame.py:1798
+msgid "Description"
+msgstr "Leírás"
+#: ../gui/wxpython/location_wizard/wizard.py:487
+msgid "Projection code:"
+msgstr "Vetület kód:"
+#: ../gui/wxpython/location_wizard/wizard.py:495
+#: ../gui/wxpython/location_wizard/wizard.py:1023
+#: ../gui/wxpython/location_wizard/wizard.py:1208
+msgid "Search in description:"
+msgstr "Keresés a leírásban:"
+#: ../gui/wxpython/location_wizard/wizard.py:674
+#, python-format
+msgid "Unable to read list: %s"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:779
+msgid "Choose projection parameters"
+msgstr "Válasszon vetület paramétereket"
+#: ../gui/wxpython/location_wizard/wizard.py:793
+msgid "Select datum or ellipsoid (next page)"
+msgstr "Válasszon dátumot vagy ellipszoidot (következő lap)"
+#: ../gui/wxpython/location_wizard/wizard.py:801
+msgid "Datum with associated ellipsoid"
+msgstr "Dátum a kapcsolt ellipszissel"
+#: ../gui/wxpython/location_wizard/wizard.py:804
+msgid "Ellipsoid only"
+msgstr "Csak ellipszoid"
+#: ../gui/wxpython/location_wizard/wizard.py:862
+#, python-format
+msgid "You must enter a value for %s"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:881
+#: ../gui/wxpython/location_wizard/wizard.py:902
+#, python-format
+msgid " Enter parameters for %s projection "
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:932
+#: ../gui/wxpython/gui_core/gselect.py:2103
+#: ../gui/wxpython/gmodeler/dialogs.py:919
+msgid "No"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:2105
+#: ../gui/wxpython/gmodeler/dialogs.py:921
+msgid "Yes"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:987
+msgid "Specify geodetic datum"
+msgstr ""
+msgid "Ellipsoid"
+msgstr "Ellipszoid"
+#: ../gui/wxpython/location_wizard/wizard.py:1014
+msgid "Datum code:"
+msgstr "Dátum kód:"
+#: ../gui/wxpython/location_wizard/wizard.py:1162
+msgid "Specify ellipsoid"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1179
+msgid "Earth based"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1182
+msgid "Planetary bodies"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1196
+msgid "Ellipsoid code:"
+msgstr "Ellipszoid kód:"
+#: ../gui/wxpython/location_wizard/wizard.py:1338
+#: ../gui/wxpython/location_wizard/wizard.py:1398
+msgid "Select georeferenced file"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1343
+msgid "Georeferenced file:"
+msgstr "Georeferált fájl:"
+#: ../gui/wxpython/location_wizard/wizard.py:1414
+#: ../gui/wxpython/location_wizard/wizard.py:1472
+msgid "Select Well Known Text (WKT) .prj file"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1419
+msgid "WKT .prj file:"
+msgstr "WKT .prj fáll:"
+#: ../gui/wxpython/location_wizard/wizard.py:1490
+msgid "Choose EPSG Code"
+msgstr "Válasszon EPSG kódot"
+#: ../gui/wxpython/location_wizard/wizard.py:1499
+msgid "Path to the EPSG-codes file:"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1502
+#: ../gui/wxpython/gui_core/preferences.py:1689
+msgid "EPSG code:"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1523
+#: ../gui/wxpython/location_wizard/wizard.py:1751
+#: ../gui/wxpython/vnet/dialogs.py:365
+msgid "Parameters"
+msgstr "Paraméterek"
+#: ../gui/wxpython/location_wizard/wizard.py:1663
+msgid "Choose EPSG codes file"
+msgstr "Válasszon EPSG kódok fájlt"
+#: ../gui/wxpython/location_wizard/wizard.py:1696
+#: ../gui/wxpython/gui_core/preferences.py:1877
+#, python-brace-format
+msgid "Unable to read EPGS codes: {0}"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1714
+msgid "Choose IAU Code"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1723
+msgid "Path to the IAU-codes file:"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1726
+msgid "IAU code:"
+msgstr "IAU kód:"
+#: ../gui/wxpython/location_wizard/wizard.py:1908
+msgid "Choose IAU codes file"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1943
+msgid "Unable to read IAU codes: {0}"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1963
+msgid "Choose method of specifying georeferencing parameters"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1972
+msgid "Enter PROJ.4 parameters string:"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:2028
+#: ../gui/wxpython/location_wizard/wizard.py:2032
+msgid "Datum transform is required."
+msgstr "Dátum transzformáció szükséges."
+#: ../gui/wxpython/location_wizard/wizard.py:2072
+#: ../gui/wxpython/rlisetup/wizard.py:1737
+msgid "Summary"
+msgstr "Összegzés"
+#: ../gui/wxpython/location_wizard/wizard.py:2114
+msgid "GRASS Database:"
+msgstr "GRASS adatbázis:"
+#: ../gui/wxpython/location_wizard/wizard.py:2120
+msgid "Location Name:"
+msgstr "Hely név:"
+#: ../gui/wxpython/location_wizard/wizard.py:2126
+msgid "Location Title:"
+msgstr "Hely cím:"
+#: ../gui/wxpython/location_wizard/wizard.py:2132
+msgid "Projection:"
+msgstr "Vetület:"
+#: ../gui/wxpython/location_wizard/wizard.py:2140
+msgid ""
+"PROJ.4 definition:\n"
+" (non-definitive)"
+msgstr ""
+"PROJ.4 definció:\n"
+#: ../gui/wxpython/location_wizard/wizard.py:2249
+#: ../gui/wxpython/psmap/dialogs.py:702 ../gui/wxpython/psmap/dialogs.py:723
+msgid "custom"
+msgstr "egyéni"
+#: ../gui/wxpython/location_wizard/wizard.py:2264
+#, python-format
+msgid "Do you want to create GRASS location <%s>?"
+msgstr "Létre akar hozni egy GRASS helyet <%s>?"
+#: ../gui/wxpython/location_wizard/wizard.py:2266
+msgid "Create new location?"
+msgstr "Új hely létrehozása?"
+#: ../gui/wxpython/location_wizard/wizard.py:2318
+msgid "Define new GRASS Location"
+msgstr "Új GRASS hely definiálása"
+#: ../gui/wxpython/location_wizard/wizard.py:2417
+#, python-format
+msgid ""
+"Unable to create new location. Location <%(loc)s> not created.\n"
+"\n"
+"Details: %(err)s"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:2425
+msgid "Location wizard canceled. Location not created."
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:2558
+msgid "Unable to create new location"
+msgstr "Nem tudok új helyet létrehozni"
+#: ../gui/wxpython/location_wizard/wizard.py:2573
+msgid "Unable to create new GRASS Database"
+msgstr "Nem tudok új GRASS adatbázist létrehozni"
+#: ../gui/wxpython/location_wizard/wizard.py:2585
+#, python-format
+msgid "Location <%(loc)s> will be created in GIS data directory <%(dir)s>. You will need to change the default GIS data directory in the GRASS startup screen."
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:2590
+msgid "New GIS data directory"
+msgstr "Új GIS adatkönyvtár"
+#: ../gui/wxpython/location_wizard/wizard.py:2621
+msgid "EPSG code missing."
+msgstr "EPSG kód hiányzik."
+#: ../gui/wxpython/location_wizard/wizard.py:2631
+msgid "IAU code missing."
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:2642
+#: ../gui/wxpython/location_wizard/wizard.py:2651
+#, python-format
+msgid "File <%s> not found."
+msgstr "<%s> fájlt nem találom."
+#: ../gui/wxpython/photo2image/ip2i_manager.py:278
+msgid "Manage Location of Fiducial Points on a Scanned Photo"
+msgstr ""
+#: ../gui/wxpython/photo2image/ip2i_manager.py:382
+msgid "A POINTS file exists, renaming it to POINTS_BAK"
+msgstr ""
+#: ../gui/wxpython/photo2image/ip2i_manager.py:408
+msgid "Opening CAMERA file failed"
+msgstr ""
+#: ../gui/wxpython/photo2image/ip2i_manager.py:443
+#: ../gui/wxpython/photo2image/ip2i_manager.py:845
+#: ../gui/wxpython/gcp/manager.py:1421
+msgid "Writing POINTS file failed"
+msgstr ""
+#: ../gui/wxpython/photo2image/ip2i_manager.py:618
+#: ../gui/wxpython/image2target/ii2t_manager.py:1227
+#: ../gui/wxpython/gcp/manager.py:1194
+#, python-format
+msgid "At least %d GCPs required. Operation canceled."
+msgstr "Legalább %dGCP szükséges. A művelet megszakadt."
+#: ../gui/wxpython/photo2image/ip2i_manager.py:761
+#: ../gui/wxpython/image2target/ii2t_manager.py:1369
+#: ../gui/wxpython/gcp/manager.py:1337
+msgid "source"
+msgstr "forrás"
+#: ../gui/wxpython/photo2image/ip2i_manager.py:763
+#: ../gui/wxpython/image2target/ii2t_manager.py:1371
+#: ../gui/wxpython/gcp/manager.py:1339
+msgid "target"
+msgstr "cél"
+#: ../gui/wxpython/photo2image/ip2i_manager.py:765
+#: ../gui/wxpython/image2target/ii2t_manager.py:1373
+#: ../gui/wxpython/gcp/manager.py:1341
+msgid "Set GCP coordinates"
+msgstr "GCP koordináták beállítása"
+#: ../gui/wxpython/photo2image/ip2i_manager.py:767
+#: ../gui/wxpython/image2target/ii2t_manager.py:1375
+#: ../gui/wxpython/gcp/manager.py:1343
+#, python-format
+msgid ""
+"Set %(coor)s coordinates for GCP No. %(key)s? \n"
+"\n"
+"East: %(coor0)s \n"
+"North: %(coor1)s"
+msgstr ""
+#: ../gui/wxpython/photo2image/ip2i_manager.py:858
+#: ../gui/wxpython/gcp/manager.py:1433
+#, python-format
+msgid "POINTS file saved for group <%s>"
+msgstr ""
+#: ../gui/wxpython/photo2image/ip2i_manager.py:874
+#: ../gui/wxpython/image2target/ii2t_manager.py:1513
+#: ../gui/wxpython/gcp/manager.py:1449
+msgid "source mapwin not defined"
+msgstr ""
+#: ../gui/wxpython/photo2image/ip2i_manager.py:879
+#: ../gui/wxpython/image2target/ii2t_manager.py:1518
+#: ../gui/wxpython/gcp/manager.py:1454
+msgid "target mapwin not defined"
+msgstr ""
+#: ../gui/wxpython/photo2image/ip2i_manager.py:909
+#: ../gui/wxpython/gcp/manager.py:1484
+msgid "Reading POINTS file failed"
+msgstr "Sikertelen pont fájl olvasás"
+#: ../gui/wxpython/photo2image/ip2i_manager.py:994
+#: ../gui/wxpython/image2target/ii2t_manager.py:1635
+#: ../gui/wxpython/gcp/manager.py:1569
+#, python-format
+msgid ""
+"Insufficient points defined and active (checked) for selected rectification method (order: %d).\n"
+"3+ points needed for 1st order,\n"
+"6+ points for 2nd order, and\n"
+"10+ points for 3rd order."
+msgstr ""
+#: ../gui/wxpython/photo2image/ip2i_manager.py:1022
+#: ../gui/wxpython/image2target/ii2t_manager.py:1663
+#: ../gui/wxpython/gcp/manager.py:1597
+msgid "Rectifying images, please wait..."
+msgstr ""
+#: ../gui/wxpython/photo2image/ip2i_manager.py:1044
+msgid "Writing output image to group, please wait..."
+msgstr ""
+#: ../gui/wxpython/photo2image/ip2i_manager.py:1074
+#: ../gui/wxpython/image2target/ii2t_manager.py:1749
+#: ../gui/wxpython/gcp/manager.py:1682
+msgid "GCP Manager settings"
+msgstr "GCP kezelő beállítások"
+#: ../gui/wxpython/photo2image/ip2i_manager.py:1119
+#: ../gui/wxpython/image2target/ii2t_manager.py:1796
+#: ../gui/wxpython/gcp/manager.py:1729
+msgid "Quit GCP Manager"
+msgstr "Kilépés a GCP kezelőből"
+#: ../gui/wxpython/photo2image/ip2i_manager.py:1120
+#: ../gui/wxpython/image2target/ii2t_manager.py:1797
+#: ../gui/wxpython/gcp/manager.py:1730
+msgid "Save ground control points?"
+msgstr "Illesztőpontok mentése?"
+#: ../gui/wxpython/photo2image/ip2i_manager.py:1198
+#: ../gui/wxpython/gcp/manager.py:1809
+msgid ""
+"Could not calculate RMS Error.\n"
+"Possible error with m.transform."
+msgstr ""
+"Az RMS hibát nem tudom kiszámítani.\n"
+"Valószínűleg m.transform hiba."
+#: ../gui/wxpython/photo2image/ip2i_manager.py:1326
+#: ../gui/wxpython/gcp/manager.py:1937
+msgid ""
+"Could not calculate new extends.\n"
+msgstr ""
+"Nem tudom az új terjedelmet kiszámítani.\n"
+#: ../gui/wxpython/photo2image/ip2i_manager.py:1458
+#: ../gui/wxpython/image2target/ii2t_manager.py:2133
+#: ../gui/wxpython/gcp/manager.py:2069
+msgid "Adjust source display to target display"
+msgstr ""
+#: ../gui/wxpython/photo2image/ip2i_manager.py:1463
+#: ../gui/wxpython/image2target/ii2t_manager.py:2138
+#: ../gui/wxpython/gcp/manager.py:2074
+msgid "Adjust target display to source display"
+msgstr ""
+#: ../gui/wxpython/photo2image/ip2i_manager.py:1537
+#: ../gui/wxpython/photo2image/ip2i_manager.py:1555
+#: ../gui/wxpython/image2target/ii2t_manager.py:2212
+#: ../gui/wxpython/image2target/ii2t_manager.py:2232
+#: ../gui/wxpython/gcp/manager.py:2148 ../gui/wxpython/gcp/manager.py:2166
+#: ../gui/wxpython/vnet/widgets.py:85 ../gui/wxpython/vnet/vnet_data.py:259
+msgid "use"
+msgstr ""
+#: ../gui/wxpython/photo2image/ip2i_manager.py:1538
+#: ../gui/wxpython/photo2image/ip2i_manager.py:1556
+msgid "source X"
+msgstr "forrás X"
+#: ../gui/wxpython/photo2image/ip2i_manager.py:1539
+#: ../gui/wxpython/photo2image/ip2i_manager.py:1557
+msgid "source Y"
+msgstr "forrás Y"
+#: ../gui/wxpython/photo2image/ip2i_manager.py:1540
+#: ../gui/wxpython/photo2image/ip2i_manager.py:1558
+msgid "target X"
+msgstr "cél X"
+#: ../gui/wxpython/photo2image/ip2i_manager.py:1541
+#: ../gui/wxpython/photo2image/ip2i_manager.py:1559
+msgid "target Y"
+msgstr "cél Y"
+#: ../gui/wxpython/photo2image/ip2i_manager.py:1542
+#: ../gui/wxpython/photo2image/ip2i_manager.py:1560
+#: ../gui/wxpython/image2target/ii2t_manager.py:2219
+#: ../gui/wxpython/image2target/ii2t_manager.py:2239
+#: ../gui/wxpython/gcp/manager.py:2153 ../gui/wxpython/gcp/manager.py:2171
+msgid "Forward error"
+msgstr ""
+#: ../gui/wxpython/photo2image/ip2i_manager.py:1543
+#: ../gui/wxpython/photo2image/ip2i_manager.py:1561
+#: ../gui/wxpython/image2target/ii2t_manager.py:2220
+#: ../gui/wxpython/image2target/ii2t_manager.py:2240
+#: ../gui/wxpython/gcp/manager.py:2154 ../gui/wxpython/gcp/manager.py:2172
+msgid "Backward error"
+msgstr ""
+#: ../gui/wxpython/photo2image/ip2i_manager.py:1698
+#: ../gui/wxpython/image2target/ii2t_manager.py:2379
+#: ../gui/wxpython/gcp/manager.py:2309
+msgid "Invalid coordinate value. Operation canceled."
+msgstr "Hibás koordináta érték. A művelet megszakadt."
+#: ../gui/wxpython/photo2image/ip2i_manager.py:1736
+#: ../gui/wxpython/image2target/ii2t_manager.py:2554
+#: ../gui/wxpython/gcp/manager.py:2487
+msgid "Edit GCP"
+msgstr "GCP szerkesztés"
+#: ../gui/wxpython/photo2image/ip2i_manager.py:1748
+#: ../gui/wxpython/image2target/ii2t_manager.py:2566
+#: ../gui/wxpython/gcp/manager.py:2499
+msgid "Ground Control Point No."
+msgstr "Illesztőpont szám"
+#: ../gui/wxpython/photo2image/ip2i_manager.py:1767
+msgid "source X:"
+msgstr "forrás X:"
+#: ../gui/wxpython/photo2image/ip2i_manager.py:1768
+msgid "target X:"
+msgstr "cél X:"
+#: ../gui/wxpython/photo2image/ip2i_manager.py:1769
+msgid "source Y:"
+msgstr "forrás Y:"
+#: ../gui/wxpython/photo2image/ip2i_manager.py:1770
+msgid "target Y:"
+msgstr "cél Y:"
+#: ../gui/wxpython/photo2image/ip2i_manager.py:1906
+#: ../gui/wxpython/image2target/ii2t_manager.py:2732
+#: ../gui/wxpython/vdigit/preferences.py:98
+#: ../gui/wxpython/psmap/dialogs.py:2656 ../gui/wxpython/gcp/manager.py:2658
+msgid "Symbology"
+msgstr ""
+#: ../gui/wxpython/photo2image/ip2i_manager.py:1915
+#: ../gui/wxpython/image2target/ii2t_manager.py:2741
+#: ../gui/wxpython/gcp/manager.py:2667
+msgid "Highlight highest RMS error only"
+msgstr "Csak a legnagyobb RMS hiba kiemelése"
+#: ../gui/wxpython/photo2image/ip2i_manager.py:1928
+#: ../gui/wxpython/image2target/ii2t_manager.py:2754
+#: ../gui/wxpython/gcp/manager.py:2680
+msgid "Highlight RMS error > M + SD * factor:"
+msgstr ""
+#: ../gui/wxpython/photo2image/ip2i_manager.py:1932
+#: ../gui/wxpython/image2target/ii2t_manager.py:2758
+#: ../gui/wxpython/gcp/manager.py:2684
+msgid ""
+"Highlight GCPs with an RMS error larger than \n"
+"mean + standard deviation * given factor. \n"
+"Recommended values for this factor are between 1 and 2."
+msgstr ""
+"GCP-k kiemelése, melyek RMS-e nagyobb mint az\n"
+"átlag + szórás * szorzó.\n"
+"A szorzóra ajánlott érték 1 és 2 között van."
+#: ../gui/wxpython/photo2image/ip2i_manager.py:1955
+#: ../gui/wxpython/image2target/ii2t_manager.py:2781
+#: ../gui/wxpython/gcp/manager.py:2707
+msgid "Symbol settings"
+msgstr "Szimbólum beállítások"
+#: ../gui/wxpython/photo2image/ip2i_manager.py:1963
+#: ../gui/wxpython/image2target/ii2t_manager.py:2789
+#: ../gui/wxpython/nviz/tools.py:1423 ../gui/wxpython/nviz/tools.py:2154
+#: ../gui/wxpython/nviz/tools.py:2296 ../gui/wxpython/nviz/preferences.py:372
+#: ../gui/wxpython/nviz/preferences.py:574
+#: ../gui/wxpython/nviz/preferences.py:640
+#: ../gui/wxpython/gui_core/preferences.py:1481
+#: ../gui/wxpython/psmap/dialogs.py:2375 ../gui/wxpython/psmap/dialogs.py:2536
+#: ../gui/wxpython/mapswipe/dialogs.py:280 ../gui/wxpython/gcp/manager.py:2715
+msgid "Color:"
+msgstr "Szín:"
+#: ../gui/wxpython/photo2image/ip2i_manager.py:1983
+#: ../gui/wxpython/image2target/ii2t_manager.py:2809
+#: ../gui/wxpython/gcp/manager.py:2735
+msgid "Color for high RMS error:"
+msgstr "Szín nagy RMS hibához:"
+#: ../gui/wxpython/photo2image/ip2i_manager.py:2003
+#: ../gui/wxpython/image2target/ii2t_manager.py:2829
+#: ../gui/wxpython/gcp/manager.py:2755
+msgid "Color for selected GCP:"
+msgstr "Szín a kiválasztott GCP-hez:"
+#: ../gui/wxpython/photo2image/ip2i_manager.py:2023
+#: ../gui/wxpython/image2target/ii2t_manager.py:2849
+#: ../gui/wxpython/gcp/manager.py:2775
+msgid "Color for unused GCPs:"
+msgstr "Szín a nem használt GCP-khez:"
+#: ../gui/wxpython/photo2image/ip2i_manager.py:2039
+#: ../gui/wxpython/image2target/ii2t_manager.py:2865
+#: ../gui/wxpython/gcp/manager.py:2791
+msgid "Show unused GCPs"
+msgstr "Nem használ GCP-k mutatása"
+#: ../gui/wxpython/photo2image/ip2i_manager.py:2056
+#: ../gui/wxpython/image2target/ii2t_manager.py:2882
+#: ../gui/wxpython/gui_core/preferences.py:1408
+#: ../gui/wxpython/gcp/manager.py:2808
+msgid "Symbol size:"
+msgstr "Szimbólum méret:"
+#: ../gui/wxpython/photo2image/ip2i_manager.py:2078
+#: ../gui/wxpython/image2target/ii2t_manager.py:2904
+#: ../gui/wxpython/gui_core/preferences.py:1391
+#: ../gui/wxpython/psmap/dialogs.py:6813
+#: ../gui/wxpython/mapswipe/dialogs.py:327 ../gui/wxpython/gcp/manager.py:2830
+#: ../gui/wxpython/vnet/dialogs.py:1279
+msgid "Line width:"
+msgstr "Vonalvastagság:"
+#: ../gui/wxpython/photo2image/ip2i_manager.py:2124
+#: ../gui/wxpython/image2target/ii2t_manager.py:743
+#: ../gui/wxpython/image2target/ii2t_manager.py:2956
+#: ../gui/wxpython/gcp/manager.py:720 ../gui/wxpython/gcp/manager.py:2882
+msgid "Select source map to display:"
+msgstr "Megjelenítendő forrás térkép:"
+#: ../gui/wxpython/photo2image/ip2i_manager.py:2138
+#: ../gui/wxpython/image2target/ii2t_manager.py:769
+#: ../gui/wxpython/image2target/ii2t_manager.py:2970
+#: ../gui/wxpython/gcp/manager.py:746 ../gui/wxpython/gcp/manager.py:2896
+msgid "Select target raster map to display:"
+msgstr "Megjelenítendő cél raszter térkép:"
+#: ../gui/wxpython/photo2image/ip2i_manager.py:2163
+#: ../gui/wxpython/image2target/ii2t_manager.py:3010
+#: ../gui/wxpython/gcp/manager.py:2936
+msgid "Rectification"
+msgstr "Rektifikáció"
+#: ../gui/wxpython/photo2image/ip2i_manager.py:2172
+#: ../gui/wxpython/image2target/ii2t_manager.py:3019
+#: ../gui/wxpython/gcp/manager.py:2945
+msgid "Select rectification order"
+msgstr ""
+#: ../gui/wxpython/photo2image/ip2i_manager.py:2174
+#: ../gui/wxpython/image2target/ii2t_manager.py:3021
+#: ../gui/wxpython/gcp/manager.py:2947
+msgid "1st order"
+msgstr "1. rendű"
+#: ../gui/wxpython/photo2image/ip2i_manager.py:2175
+#: ../gui/wxpython/image2target/ii2t_manager.py:3022
+#: ../gui/wxpython/gcp/manager.py:2948
+msgid "2nd order"
+msgstr "2. rendű"
+#: ../gui/wxpython/photo2image/ip2i_manager.py:2176
+#: ../gui/wxpython/image2target/ii2t_manager.py:3023
+#: ../gui/wxpython/gcp/manager.py:2949
+msgid "3rd order"
+msgstr "3. rendű"
+#: ../gui/wxpython/photo2image/ip2i_manager.py:2188
+#: ../gui/wxpython/image2target/ii2t_manager.py:3035
+#: ../gui/wxpython/gcp/manager.py:2961
+msgid "Select interpolation method:"
+msgstr "Válasszon interpoláció módszert:"
+#: ../gui/wxpython/photo2image/ip2i_manager.py:2204
+#: ../gui/wxpython/image2target/ii2t_manager.py:3051
+#: ../gui/wxpython/gcp/manager.py:2977
+msgid "clip to computational region in target location"
+msgstr ""
+#: ../gui/wxpython/photo2image/ip2i_manager.py:2214
+#: ../gui/wxpython/image2target/ii2t_manager.py:591
+#: ../gui/wxpython/image2target/ii2t_manager.py:3061
+#: ../gui/wxpython/gcp/manager.py:562 ../gui/wxpython/gcp/manager.py:2987
+msgid "Extension for output maps:"
+msgstr "Terjedelem az output térképhez:"
+#: ../gui/wxpython/photo2image/ip2i_manager.py:2255
+#: ../gui/wxpython/image2target/ii2t_manager.py:3102
+#: ../gui/wxpython/gcp/manager.py:3028
+msgid "RMS threshold factor must be > 0"
+msgstr ""
+#: ../gui/wxpython/photo2image/ip2i_manager.py:2258
+#: ../gui/wxpython/image2target/ii2t_manager.py:3105
+#: ../gui/wxpython/gcp/manager.py:3031
+msgid ""
+"RMS threshold factor is < 1\n"
+"Too many points might be highlighted"
+msgstr ""
+#: ../gui/wxpython/photo2image/ip2i_manager.py:2418
+#: ../gui/wxpython/image2target/ii2t_manager.py:3289
+#: ../gui/wxpython/gcp/manager.py:3215
+#, python-format
+msgid "GCP Manager settings saved to file '%s'."
+msgstr "GCP kezelő beállításokat mentettem a(z) '%s' fájlba."
+#: ../gui/wxpython/photo2image/ip2i_mapdisplay.py:50
+msgid "GRASS GIS Manage Location of Tick Points on a Scanned Photo"
+msgstr ""
+#: ../gui/wxpython/photo2image/ip2i_mapdisplay.py:176
+#: ../gui/wxpython/image2target/ii2t_mapdisplay.py:176
+#: ../gui/wxpython/gcp/mapdisplay.py:176
+msgid "GCP List"
+msgstr "GCP lista"
+#: ../gui/wxpython/photo2image/ip2i_mapdisplay.py:181
+#: ../gui/wxpython/image2target/ii2t_mapdisplay.py:181
+#: ../gui/wxpython/gcp/mapdisplay.py:181
+msgid "Source Display"
+msgstr ""
+#: ../gui/wxpython/photo2image/ip2i_mapdisplay.py:185
+#: ../gui/wxpython/image2target/ii2t_mapdisplay.py:185
+#: ../gui/wxpython/gcp/mapdisplay.py:185
+msgid "Target Display"
+msgstr ""
+#: ../gui/wxpython/photo2image/ip2i_mapdisplay.py:274
+#: ../gui/wxpython/image2target/ii2t_mapdisplay.py:275
+#: ../gui/wxpython/gcp/mapdisplay.py:275
+msgid "GCP Display toolbar"
+msgstr "GCP megjelenítés eszközsor"
+#: ../gui/wxpython/photo2image/ip2i_mapdisplay.py:287
+#: ../gui/wxpython/image2target/ii2t_mapdisplay.py:288
+#: ../gui/wxpython/gcp/mapdisplay.py:288
+msgid "GCP Manager toolbar"
+msgstr "GCP kezelő eszközsor"
+#: ../gui/wxpython/photo2image/ip2i_mapdisplay.py:381
+#: ../gui/wxpython/image2target/ii2t_mapdisplay.py:382
+#: ../gui/wxpython/mapswipe/frame.py:550 ../gui/wxpython/gcp/mapdisplay.py:382
+#: ../gui/wxpython/mapdisp/frame.py:800
+msgid "Nothing to render (empty map). Operation canceled."
+msgstr ""
+#: ../gui/wxpython/photo2image/ip2i_mapdisplay.py:473
+#: ../gui/wxpython/image2target/ii2t_mapdisplay.py:474
+#: ../gui/wxpython/gcp/mapdisplay.py:474
+msgid "Zoom to computational region (set with g.region)"
+msgstr ""
+#: ../gui/wxpython/photo2image/ip2i_mapdisplay.py:478
+#: ../gui/wxpython/image2target/ii2t_mapdisplay.py:479
+#: ../gui/wxpython/gcp/mapdisplay.py:479 ../gui/wxpython/mapdisp/frame.py:1390
+msgid "Zoom to default region"
+msgstr "Nagyítás az alapértelmezett régióra"
+#: ../gui/wxpython/photo2image/ip2i_mapdisplay.py:482
+#: ../gui/wxpython/image2target/ii2t_mapdisplay.py:483
+#: ../gui/wxpython/gcp/mapdisplay.py:483 ../gui/wxpython/mapdisp/frame.py:1392
+msgid "Zoom to saved region"
+msgstr "Nagyítás a mentett régióra"
+#: ../gui/wxpython/photo2image/ip2i_mapdisplay.py:487
+#: ../gui/wxpython/image2target/ii2t_mapdisplay.py:488
+#: ../gui/wxpython/gcp/mapdisplay.py:488
+msgid "Set computational region from display"
+msgstr ""
+#: ../gui/wxpython/photo2image/ip2i_mapdisplay.py:492
+#: ../gui/wxpython/image2target/ii2t_mapdisplay.py:493
+#: ../gui/wxpython/gcp/mapdisplay.py:493 ../gui/wxpython/mapdisp/frame.py:1402
+msgid "Save display geometry to named region"
+msgstr ""
+#: ../gui/wxpython/photo2image/g.gui.photo2image.py:96
+msgid "Please provide a group name to process"
+msgstr ""
+#: ../gui/wxpython/photo2image/g.gui.photo2image.py:101
+msgid "Please provide a raster map name to process"
+msgstr ""
+#: ../gui/wxpython/photo2image/g.gui.photo2image.py:106
+msgid "Please provide a camera name (generated by i.ortho.camera)"
+msgstr ""
+#: ../gui/wxpython/photo2image/g.gui.photo2image.py:111
+msgid "Please provive an order value (1 if 4 Fiducials, 2 if 8 Fiducials)"
+msgstr ""
+#: ../gui/wxpython/photo2image/g.gui.photo2image.py:116
+msgid "Please provive an output files extension (used by i.rectify)"
+msgstr ""
+#: ../gui/wxpython/photo2image/ip2i_statusbar.py:38
+#: ../gui/wxpython/image2target/ii2t_statusbar.py:38
+#: ../gui/wxpython/gcp/statusbar.py:38
+msgid "Go to GCP No."
+msgstr ""
+#: ../gui/wxpython/photo2image/ip2i_statusbar.py:55
+#: ../gui/wxpython/image2target/ii2t_statusbar.py:55
+#: ../gui/wxpython/gcp/statusbar.py:55
+msgid "Valid Range:"
+msgstr "Helyes tartomány:"
+#: ../gui/wxpython/photo2image/ip2i_statusbar.py:121
+#: ../gui/wxpython/image2target/ii2t_statusbar.py:121
+#: ../gui/wxpython/gcp/statusbar.py:121
+msgid "RMS error"
+msgstr "RMS hiba"
+#: ../gui/wxpython/photo2image/ip2i_statusbar.py:125
+#: ../gui/wxpython/image2target/ii2t_statusbar.py:125
+#: ../gui/wxpython/gcp/statusbar.py:125
+#, python-format
+msgid "Forward: %(forw)s, Backward: %(back)s"
+msgstr ""
+#: ../gui/wxpython/core/render.py:151
+#, python-format
+msgid "<%(name)s>: layer type <%(type)s> is not supported"
+msgstr ""
+#: ../gui/wxpython/core/render.py:170
+#, python-format
+msgid "Command '%s' failed\n"
+msgstr ""
+#: ../gui/wxpython/core/render.py:173
+#, python-format
+msgid "Details: %s\n"
+msgstr ""
+#: ../gui/wxpython/core/render.py:258
+#, python-format
+msgid "Unsupported map layer type '%s'"
+msgstr ""
+#: ../gui/wxpython/core/render.py:623
+#, python-format
+msgid "Rendering failed: %s"
+msgstr ""
+#: ../gui/wxpython/core/render.py:666
+msgid "Rendering aborted"
+msgstr ""
+#: ../gui/wxpython/core/render.py:697
+msgid "Downloading data "
+msgstr ""
+#: ../gui/wxpython/core/render.py:707
+msgid "Rendering & "
+msgstr ""
+#: ../gui/wxpython/core/render.py:709
+msgid "Rendering..."
+msgstr ""
+#: ../gui/wxpython/core/render.py:754
+msgid "Trying to recover from default region..."
+msgstr ""
+#: ../gui/wxpython/core/render.py:779 ../gui/wxpython/gui_core/mapdisp.py:140
+#: ../gui/wxpython/mapdisp/test_mapdisp.py:92
+#, python-format
+msgid "GRASS module '%s' not found. Unable to start map display window."
+msgstr ""
+#: ../gui/wxpython/core/render.py:814
+#, python-format
+msgid "Error: Unable to open '%(file)s'. Reason: %(ret)s. wxGUI exited.\n"
+msgstr ""
+#: ../gui/wxpython/core/render.py:824
+#, python-format
+msgid ""
+"\n"
+"ERROR: Unable to read WIND file: %s\n"
+msgstr ""
+#: ../gui/wxpython/core/render.py:928
+#, python-format
+msgid "Invalid map size %d,%d\n"
+msgstr ""
+#: ../gui/wxpython/core/render.py:1009
+#, python-format
+msgid "Unable to zoom to raster map <%s>."
+msgstr ""
+#: ../gui/wxpython/core/render.py:1010 ../gui/wxpython/core/render.py:1013
+#: ../gui/wxpython/core/render.py:1016 ../gui/wxpython/core/gcmd.py:437
+msgid "Details:"
+msgstr ""
+#: ../gui/wxpython/core/render.py:1012
+#, python-format
+msgid "Unable to zoom to vector map <%s>."
+msgstr ""
+#: ../gui/wxpython/core/render.py:1015
+#, python-format
+msgid "Unable to zoom to 3d raster map <%s>."
+msgstr ""
+#: ../gui/wxpython/core/render.py:1019
+msgid "Unable to get current geographic extent. Force quiting wxGUI. Please manually run g.region to fix the problem."
+msgstr ""
+#: ../gui/wxpython/core/toolboxes.py:227
+msgid "Unable to parse user toolboxes XML files. Default files will be loaded."
+msgstr ""
+#: ../gui/wxpython/core/toolboxes.py:271
+msgid "Unable to create toolboxes directory."
+msgstr ""
+#: ../gui/wxpython/core/toolboxes.py:495
+msgid "Custom toolboxes"
+msgstr ""
+#: ../gui/wxpython/core/toolboxes.py:519
+#, python-format
+msgid "List of addons cannot be obtained because g.extension failed. Details: %s"
+msgstr ""
+#: ../gui/wxpython/core/toolboxes.py:576
+msgid "Addons"
+msgstr ""
+#: ../gui/wxpython/core/workspace.py:1614
+#, python-format
+msgid "Unable to open file <%s> for reading."
+msgstr ""
+#: ../gui/wxpython/core/workspace.py:1631
+#, python-format
+msgid ""
+"Some lines were skipped when reading settings from file <%(file)s>.\n"
+"See 'Command output' window for details.\n"
+"\n"
+"Number of skipped lines: %(line)d"
+msgstr ""
+#: ../gui/wxpython/core/workspace.py:1856
+#, python-format
+msgid " row %d:"
+msgstr ""
+#: ../gui/wxpython/core/ws.py:51
+msgid ""
+"Unable to load GDAL Python bindings.\n"
+"WMS layers can not be displayed without the bindings.\n"
+msgstr ""
+#: ../gui/wxpython/core/gcmd.py:128
+msgid "Reason"
+msgstr ""
+#: ../gui/wxpython/core/gcmd.py:153 ../gui/wxpython/gis_set.py:697
+#: ../gui/wxpython/gis_set.py:740
+#: ../gui/wxpython/image2target/ii2t_gis_set.py:640
+#: ../gui/wxpython/image2target/ii2t_gis_set.py:683
+#: ../gui/wxpython/lmgr/frame.py:2558
+msgid "Message"
+msgstr ""
+#: ../gui/wxpython/core/gcmd.py:434
+msgid "Execution failed:"
+msgstr ""
+#: ../gui/wxpython/core/gcmd.py:439 ../gui/wxpython/core/gcmd.py:446
+msgid "Error: "
+msgstr ""
+#: ../gui/wxpython/core/gcmd.py:523
+#, python-format
+msgid "Unable to exectute command: '%s'"
+msgstr ""
+#: ../gui/wxpython/core/gcmd.py:749 ../gui/wxpython/gui_core/forms.py:2742
+#, python-format
+msgid "Error in %s"
+msgstr ""
+#: ../gui/wxpython/core/debug.py:48
+msgid "Wx debug level {0}."
+msgstr ""
+#: ../gui/wxpython/core/debug.py:53
+msgid "WARNING: Ignoring unsupported wx debug level (must be >=0 and <=5). {0}\n"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:499
+msgid "Segment break"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:565
+msgid "Data point"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:639
+msgid "animation"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:862
+msgid "Collapse all except PERMANENT and current"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:863
+msgid "Collapse all except PERMANENT"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:864
+msgid "Collapse all except current"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:865
+msgid "Collapse all"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:866
+msgid "Expand all"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:871 ../gui/wxpython/dbmgr/base.py:1406
+msgid "Edit selected record"
+msgstr "Kiválasztott rekord szerkesztése"
+msgid "Display selected"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:880
+msgid "Classic (labels only)"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:881
+msgid "Combined (labels and module names)"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:882
+msgid "Expert (module names only)"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:887
+msgid "Basic top"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:888
+msgid "Basic left"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:889
+msgid "Fancy green"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:890
+msgid "List left"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:897
+msgid "Zoom and recenter"
+msgstr ""
+msgid "Zoom to mouse cursor"
+msgstr ""
+msgid "Nothing"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:899
+msgid "Scroll forward to zoom in"
+msgstr ""
+msgid "Scroll back to zoom in"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:932 ../gui/wxpython/core/settings.py:944
+msgid "box"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:933
+msgid "sphere"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:934
+msgid "cube"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:935
+msgid "diamond"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:936
+msgid "aster"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:937
+msgid "gyro"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:938
+msgid "histogram"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:944
+msgid "cross"
+msgstr ""
+msgid "circle"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:977
+#, python-format
+msgid "Unable to read settings file <%s>\n"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:1003
+#, python-format
+msgid ""
+"Error: Reading settings from file <%(file)s> failed.\n"
+"\t\tDetails: %(detail)s\n"
+"\t\tLine: '%(line)s'\n"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:1022
+msgid "Unable to create settings directory"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:1070
+#, python-format
+msgid ""
+"Writing settings to file <%(file)s> failed.\n"
+"\n"
+"Details: %(detail)s"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:1176
+msgid "Unable to set "
+msgstr ""
+#: ../gui/wxpython/core/settings.py:1212 ../gui/wxpython/core/settings.py:1223
+#, python-format
+msgid "Unable to parse settings '%s'"
+msgstr ""
+#: ../gui/wxpython/core/gconsole.py:504
+#, python-format
+msgid ""
+"Unable to run command:\n"
+"%(cmd)s\n"
+"\n"
+"Option <%(opt)s>: read from standard input is not supported by wxGUI"
+msgstr ""
+#: ../gui/wxpython/core/gconsole.py:528
+#, python-format
+msgid "Module <%s> not found."
+msgstr ""
+#: ../gui/wxpython/core/gconsole.py:658 ../gui/wxpython/gmodeler/frame.py:299
+#, python-format
+msgid "%d sec"
+msgstr ""
+#: ../gui/wxpython/core/gconsole.py:661 ../gui/wxpython/gmodeler/frame.py:302
+#, python-format
+msgid "%(min)d min %(sec)d sec"
+msgstr ""
+#: ../gui/wxpython/core/gconsole.py:665 ../gui/wxpython/gui_core/ghelp.py:231
+#: ../gui/wxpython/gmodeler/model.py:1123
+#: ../gui/wxpython/gmodeler/model.py:1229 ../gui/wxpython/gmodeler/frame.py:306
+msgid "unknown"
+msgstr ""
+#: ../gui/wxpython/core/gconsole.py:669
+msgid "Please note that the data are left in inconsistent state and may be corrupted"
+msgstr ""
+#: ../gui/wxpython/core/gconsole.py:671
+msgid "Command aborted"
+msgstr ""
+#: ../gui/wxpython/core/gconsole.py:673 ../gui/wxpython/gmodeler/frame.py:312
+msgid "Command finished"
+msgstr ""
+#: ../gui/wxpython/core/gconsole.py:749 ../gui/wxpython/gui_core/goutput.py:496
+#, python-format
+msgid ""
+"Unable to write file '%(filePath)s'.\n"
+"\n"
+"Details: %(error)s"
+msgstr ""
+#: ../gui/wxpython/core/menutree.py:153
+#, python-format
+msgid "Unknow tag %s"
+msgstr ""
+#: ../gui/wxpython/core/utils.py:60
+#, python-format
+msgid "Syntax error: %s"
+msgstr ""
+#: ../gui/wxpython/core/utils.py:351
+#, python-format
+msgid "Vector map <%(map)s>: %(msg)s\n"
+msgstr ""
+#: ../gui/wxpython/core/utils.py:535
+msgid "failed to open '{0}'"
+msgstr ""
+#: ../gui/wxpython/core/utils.py:841
+#, python-format
+msgid "ERROR: Unable to determine GRASS version. Details: %s"
+msgstr ""
+#: ../gui/wxpython/core/utils.py:882
+#, python-format
+msgid "Unable to open file '%s'\n"
+msgstr ""
+#: ../gui/wxpython/core/utils.py:892
+#, python-format
+msgid ""
+"%s: line skipped - unable to parse '%s'\n"
+"Reason: %s\n"
+msgstr ""
+#: ../gui/wxpython/core/utils.py:897
+#, python-format
+msgid "Duplicated key: %s\n"
+msgstr ""
+#: ../gui/wxpython/core/utils.py:913
+#, python-format
+msgid "Unable to create file '%s'\n"
+msgstr ""
+#: ../gui/wxpython/core/utils.py:996 ../gui/wxpython/gui_core/forms.py:1731
+msgid "Select Color"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:122
+#: ../gui/wxpython/image2target/ii2t_gis_set.py:122
+msgid "1. Select GRASS GIS database directory"
+msgstr "1. Válasszon GRASS GIS adatbázis könyvtárat"
+#: ../gui/wxpython/gis_set.py:125
+#: ../gui/wxpython/image2target/ii2t_gis_set.py:125
+msgid "2. Select GRASS Location"
+msgstr "2. Válasszon GRASS helyet"
+#: ../gui/wxpython/gis_set.py:128
+#: ../gui/wxpython/image2target/ii2t_gis_set.py:128
+msgid "3. Select GRASS Mapset"
+msgstr "3. Válasszon GRASS térképcsoportot"
+#: ../gui/wxpython/gis_set.py:146
+#: ../gui/wxpython/image2target/ii2t_gis_set.py:146
+msgid "GRASS GIS database directory contains Locations."
+msgstr ""
+#: ../gui/wxpython/gis_set.py:150
+#: ../gui/wxpython/image2target/ii2t_gis_set.py:150
+msgid "All data in one Location is in the same coordinate reference system (projection). One Location can be one project. Location contains Mapsets."
+msgstr ""
+#: ../gui/wxpython/gis_set.py:158
+#: ../gui/wxpython/image2target/ii2t_gis_set.py:158
+msgid "Mapset contains GIS data related to one project, task within one project, subregion or user."
+msgstr ""
+#: ../gui/wxpython/gis_set.py:173
+#: ../gui/wxpython/image2target/ii2t_gis_set.py:173
+msgid "Start &GRASS session"
+msgstr "&GRASS indítása"
+#: ../gui/wxpython/gis_set.py:179
+#: ../gui/wxpython/image2target/ii2t_gis_set.py:179
+msgid "&Browse"
+msgstr "Tallózás"
+#. GTC New mapset
+#: ../gui/wxpython/gis_set.py:182
+#: ../gui/wxpython/image2target/ii2t_gis_set.py:182
+msgid "&New"
+msgstr "Új"
+#: ../gui/wxpython/gis_set.py:183
+#: ../gui/wxpython/image2target/ii2t_gis_set.py:183
+msgid "Create a new Mapset in selected Location"
+msgstr "Új térképcsoport létrehozása a kiválasztott helyen"
+#. GTC New location
+#: ../gui/wxpython/gis_set.py:186
+#: ../gui/wxpython/image2target/ii2t_gis_set.py:186
+msgid "N&ew"
+msgstr "Új"
+#: ../gui/wxpython/gis_set.py:189
+#: ../gui/wxpython/image2target/ii2t_gis_set.py:189
+msgid "Create a new location using location wizard. After location is created successfully, GRASS session is started."
+msgstr ""
+#. GTC Rename location
+#: ../gui/wxpython/gis_set.py:194
+#: ../gui/wxpython/image2target/ii2t_gis_set.py:194
+msgid "Ren&ame"
+msgstr "Átnevezés"
+#: ../gui/wxpython/gis_set.py:195 ../gui/wxpython/gis_set.py:727
+#: ../gui/wxpython/image2target/ii2t_gis_set.py:195
+#: ../gui/wxpython/image2target/ii2t_gis_set.py:670
+msgid "Rename selected location"
+msgstr "Kiválasztott hely átnevezése"
+#. GTC Delete location
+#: ../gui/wxpython/gis_set.py:198
+#: ../gui/wxpython/image2target/ii2t_gis_set.py:198
+msgid "De&lete"
+msgstr "Törlés"
+#: ../gui/wxpython/gis_set.py:199 ../gui/wxpython/gis_set.py:810
+#: ../gui/wxpython/image2target/ii2t_gis_set.py:199
+#: ../gui/wxpython/image2target/ii2t_gis_set.py:753
+msgid "Delete selected location"
+msgstr "Kiválasztott hely törlése"
+#: ../gui/wxpython/gis_set.py:201 ../gui/wxpython/startup/locdownload.py:303
+msgid "Do&wnload"
+msgstr "Letöltés"
+#: ../gui/wxpython/gis_set.py:202
+msgid "Download sample location"
+msgstr "Minta hely letöltése"
+#. GTC Rename mapset
+#: ../gui/wxpython/gis_set.py:206
+#: ../gui/wxpython/image2target/ii2t_gis_set.py:202
+#: ../gui/wxpython/datacatalog/tree.py:974 ../gui/wxpython/dbmgr/base.py:2409
+msgid "&Rename"
+msgstr "Átnevezés"
+#: ../gui/wxpython/gis_set.py:207 ../gui/wxpython/gis_set.py:684
+#: ../gui/wxpython/image2target/ii2t_gis_set.py:203
+#: ../gui/wxpython/image2target/ii2t_gis_set.py:627
+msgid "Rename selected mapset"
+msgstr "Kiválasztott térképcsoport átnevezése"
+#. GTC Delete mapset
+#: ../gui/wxpython/gis_set.py:210
+#: ../gui/wxpython/image2target/ii2t_gis_set.py:206
+#: ../gui/wxpython/datacatalog/tree.py:969
+msgid "&Delete"
+msgstr "Törlés"
+#: ../gui/wxpython/gis_set.py:211 ../gui/wxpython/gis_set.py:782
+#: ../gui/wxpython/image2target/ii2t_gis_set.py:207
+#: ../gui/wxpython/image2target/ii2t_gis_set.py:725
+msgid "Delete selected mapset"
+msgstr "Kiválasztott térképcsoport törlése"
+#: ../gui/wxpython/gis_set.py:257
+#: ../gui/wxpython/image2target/ii2t_gis_set.py:252
+#, python-format
+msgid "GRASS GIS %s startup%s"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:262
+#: ../gui/wxpython/image2target/ii2t_gis_set.py:257
+msgid "Enter GRASS session"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:282
+#: ../gui/wxpython/image2target/ii2t_gis_set.py:277
+msgid "Unable to set GRASS database. Check your locale settings."
+msgstr ""
+#: ../gui/wxpython/gis_set.py:302
+#: ../gui/wxpython/image2target/ii2t_gis_set.py:297
+#, python-format
+msgid "ERROR: Location <%s> not found\n"
+msgstr "HIBA: <%s> helyet nem találom\n"
+#: ../gui/wxpython/gis_set.py:320
+#: ../gui/wxpython/image2target/ii2t_gis_set.py:315
+#, python-format
+msgid "ERROR: Mapset <%s> not found\n"
+msgstr "HIBA: <%s> térképcsoportot nem találom\n"
+#: ../gui/wxpython/gis_set.py:480
+#: ../gui/wxpython/image2target/ii2t_gis_set.py:474
+#, python-format
+msgid "Invalid line in GISRC file (%s):%s\n"
+msgstr "Hibás sor a GISRC fájlban (%s): %s\n"
+#: ../gui/wxpython/gis_set.py:511
+#: ../gui/wxpython/image2target/ii2t_gis_set.py:505
+#: ../gui/wxpython/startup/locdownload.py:441
+msgid "Error: {text}"
+msgstr "Hiba: {text}"
+#: ../gui/wxpython/gis_set.py:549
+msgid "Documents"
+msgstr "Dokumentációk"
+#: ../gui/wxpython/gis_set.py:550
+msgid "My Documents"
+msgstr "Dokumentumaim"
+#: ../gui/wxpython/gis_set.py:574
+#: ../gui/wxpython/image2target/ii2t_gis_set.py:1171
+msgid "GRASS needs a directory (GRASS database) in which to store its data. Create one now if you have not already done so. A popular choice is \"grassdata\", located in your home directory. Press Browse button to select the directory."
+msgstr ""
+#: ../gui/wxpython/gis_set.py:596
+#: ../gui/wxpython/image2target/ii2t_gis_set.py:539
+#, python-format
+msgid "Do you want to import <%(name)s> to the newly created location?"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:599
+#: ../gui/wxpython/image2target/ii2t_gis_set.py:542
+msgid "Import data?"
+msgstr "Adat import?"
+#: ../gui/wxpython/gis_set.py:613
+#: ../gui/wxpython/image2target/ii2t_gis_set.py:556
+msgid "New mapset:"
+msgstr "Új térképcsoport"
+#: ../gui/wxpython/gis_set.py:614 ../gui/wxpython/gis_set.py:1015
+#: ../gui/wxpython/menustrings.py:246
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:240
+#: ../gui/wxpython/image2target/ii2t_gis_set.py:557
+#: ../gui/wxpython/image2target/ii2t_gis_set.py:938
+#: ../gui/wxpython/lmgr/frame.py:1072
+msgid "Create new mapset"
+msgstr "Új térképcsoport létrehozás"
+#: ../gui/wxpython/gis_set.py:655
+#: ../gui/wxpython/image2target/ii2t_gis_set.py:598
+#, python-format
+msgid ""
+"Import of <%(name)s> failed.\n"
+"Reason: %(msg)s"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:662
+#: ../gui/wxpython/image2target/ii2t_gis_set.py:605
+#, python-format
+msgid "Data file <%(name)s> imported successfully. The location's default region was set from this imported map."
+msgstr ""
+#: ../gui/wxpython/gis_set.py:676
+#: ../gui/wxpython/image2target/ii2t_gis_set.py:619
+msgid ""
+"Mapset <PERMANENT> is required for valid GRASS location.\n"
+"\n"
+"This mapset cannot be renamed."
+msgstr ""
+#: ../gui/wxpython/gis_set.py:682 ../gui/wxpython/gis_set.py:725
+#: ../gui/wxpython/image2target/ii2t_gis_set.py:625
+#: ../gui/wxpython/image2target/ii2t_gis_set.py:668
+#, python-format
+msgid ""
+"Current name: %s\n"
+"\n"
+"Enter new name:"
+msgstr ""
+"Aktuális név: %s\n"
+"\n"
+"Új név:"
+#: ../gui/wxpython/gis_set.py:698
+#: ../gui/wxpython/image2target/ii2t_gis_set.py:641
+#, python-format
+msgid ""
+"Unable to rename mapset.\n"
+"\n"
+"Mapset <%s> already exists in location."
+msgstr ""
+"Nem tudom átnevezni a térképcsoportot.\n"
+"\n"
+"<%s> térképcsoport már létezik a helyen."
+#: ../gui/wxpython/gis_set.py:712
+#: ../gui/wxpython/image2target/ii2t_gis_set.py:655
+#, python-format
+msgid ""
+"\n"
+"%s"
+msgstr ""
+"\n"
+"%s"
+#: ../gui/wxpython/gis_set.py:741
+#: ../gui/wxpython/image2target/ii2t_gis_set.py:684
+#, python-format
+msgid ""
+"Unable to rename location.\n"
+"\n"
+"Location <%s> already exists in GRASS database."
+msgstr ""
+"Nem tudom átnevezni a hlyet.\n"
+"\n"
+"<%s> hely már létezik a GRASS adatbázisban."
+#: ../gui/wxpython/gis_set.py:756
+#: ../gui/wxpython/image2target/ii2t_gis_set.py:699
+#, python-format
+msgid ""
+"\n"
+"%s"
+msgstr ""
+"Nem tudom átnevezni a helyet.\n"
+"\n"
+"%s"
+#: ../gui/wxpython/gis_set.py:770
+#: ../gui/wxpython/image2target/ii2t_gis_set.py:713
+msgid ""
+"\n"
+"This mapset cannot be deleted."
+msgstr ""
+#: ../gui/wxpython/gis_set.py:777
+#: ../gui/wxpython/image2target/ii2t_gis_set.py:720
+#, python-format
+msgid ""
+"Do you want to continue with deleting mapset <%(mapset)s> from location <%(location)s>?\n"
+"\n"
+"ALL MAPS included in this mapset will be PERMANENTLY DELETED!"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:791
+#: ../gui/wxpython/image2target/ii2t_gis_set.py:734
+msgid "Unable to delete mapset"
+msgstr "Nem tudom törölni a térképcsoportot"
+#: ../gui/wxpython/gis_set.py:805
+#: ../gui/wxpython/image2target/ii2t_gis_set.py:748
+#, python-format
+msgid ""
+"Do you want to continue with deleting location <%s>?\n"
+"\n"
+"ALL MAPS included in this location will be PERMANENTLY DELETED!"
+msgstr ""
+"Folytani akarja a hely törlését <%s>?\n"
+"\n"
+"Minden a helyhez tartozó térképet véglegesen törlök!"
+#: ../gui/wxpython/gis_set.py:821
+#: ../gui/wxpython/image2target/ii2t_gis_set.py:764
+msgid "Unable to delete location"
+msgstr "Nem tudom törölni a helyet"
+#: ../gui/wxpython/gis_set.py:851
+#: ../gui/wxpython/image2target/ii2t_gis_set.py:774
+msgid "Unicode error detected. Check your locale settings. Details: {0}"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:863
+#: ../gui/wxpython/image2target/ii2t_gis_set.py:786
+#, python-format
+msgid "No GRASS Location found in '%s'. Create a new Location or choose different GRASS database directory."
+msgstr "Nem találtam GRASS helyet itt '%s'. Hozzon létre egy új helyet vagy válasszon egy másik GRASS adatbázis könyvtárat."
+#: ../gui/wxpython/gis_set.py:985
+#: ../gui/wxpython/image2target/ii2t_gis_set.py:908
+#, python-format
+msgid "Path '%s' doesn't exist."
+msgstr "'%s' útvonal nem létezik."
+#: ../gui/wxpython/gis_set.py:1000
+#: ../gui/wxpython/image2target/ii2t_gis_set.py:923
+#: ../gui/wxpython/gui_core/gselect.py:1195
+msgid "Choose GIS Data Directory"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:1014
+#: ../gui/wxpython/image2target/ii2t_gis_set.py:937
+#: ../gui/wxpython/lmgr/frame.py:1071
+msgid "Enter name for new mapset:"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:1029
+#: ../gui/wxpython/image2target/ii2t_gis_set.py:952
+#, python-format
+msgid "Mapset <%s> already exists."
+msgstr "<%s>térképcsoport már létezik."
+#: ../gui/wxpython/gis_set.py:1036
+#: ../gui/wxpython/image2target/ii2t_gis_set.py:959
+#, python-format
+msgid ""
+"Mapset <%s> is reserved for direct read access to OGR layers. Please consider to use another name for your mapset.\n"
+"\n"
+"Are you really sure that you want to create this mapset?"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:1041
+#: ../gui/wxpython/image2target/ii2t_gis_set.py:964
+msgid "Reserved mapset name"
+msgstr "Fenntartott térképcsoport név"
+#: ../gui/wxpython/gis_set.py:1073
+#: ../gui/wxpython/image2target/ii2t_gis_set.py:996
+#, python-format
+msgid "Unable to create new mapset: %s"
+msgstr "Nem tudok új térképcsoportot létrehozni: %s"
+#: ../gui/wxpython/gis_set.py:1088
+#: ../gui/wxpython/image2target/ii2t_gis_set.py:1011
+#, python-format
+msgid ""
+"GRASS is already running in selected mapset <%(mapset)s>\n"
+"(file %(lock)s found).\n"
+"\n"
+"Concurrent use not allowed.\n"
+"\n"
+"Do you want to try to remove .gislock (note that you need permission for this operation) and continue?"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:1094 ../gui/wxpython/gis_set.py:1107
+#: ../gui/wxpython/image2target/ii2t_gis_set.py:1017
+#: ../gui/wxpython/image2target/ii2t_gis_set.py:1030
+msgid "Lock file found"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:1103
+#: ../gui/wxpython/image2target/ii2t_gis_set.py:1026
+msgid ""
+"ARE YOU REALLY SURE?\n"
+"\n"
+"If you really are running another GRASS session doing this could corrupt your data. Have another look in the processor manager just to be sure..."
+msgstr ""
+#: ../gui/wxpython/gis_set.py:1117
+#: ../gui/wxpython/image2target/ii2t_gis_set.py:1040
+#, python-format
+msgid ""
+"Unable to remove '%(lock)s'.\n"
+"\n"
+"Details: %(reason)s"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:1167
+#: ../gui/wxpython/image2target/ii2t_gis_set.py:1090
+#, python-format
+msgid "Name <%(name)s> is not a valid name for location or mapset. Please use only ASCII characters excluding %(chars)s and space."
+msgstr ""
+#: ../gui/wxpython/gis_set.py:1172
+#: ../gui/wxpython/image2target/ii2t_gis_set.py:1095
+#: ../gui/wxpython/gui_core/widgets.py:859
+msgid "Invalid name"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:3 ../gui/wxpython/menustrings.py:2005
+#: ../gui/wxpython/menustrings.py:2055
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:4
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1972
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:2022
+msgid "&File"
+msgstr "&Fájl"
+#: ../gui/wxpython/menustrings.py:4
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:5
+msgid "Workspace"
+msgstr "Munkaterület"
+#: ../gui/wxpython/menustrings.py:5 ../gui/wxpython/menustrings.py:2006
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:6
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1973
+#: ../gui/wxpython/nviz/tools.py:1360
+msgid "New"
+msgstr "Új"
+#: ../gui/wxpython/menustrings.py:6
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:7
+msgid "Create new workspace"
+msgstr "Új munkaterület létrehozás"
+#: ../gui/wxpython/menustrings.py:7 ../gui/wxpython/menustrings.py:2008
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:8
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1975
+msgid "Open"
+msgstr "Megnyitás"
+#: ../gui/wxpython/menustrings.py:8
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:9
+msgid "Load workspace from file"
+msgstr "Munkaterület betöltése fájlból"
+#: ../gui/wxpython/menustrings.py:10
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:11
+#: ../gui/wxpython/lmgr/frame.py:1615 ../gui/wxpython/lmgr/frame.py:1636
+msgid "Save workspace"
+msgstr "Munkaterület mentés"
+#: ../gui/wxpython/menustrings.py:11 ../gui/wxpython/menustrings.py:2012
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:12
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1979
+msgid "Save as"
+msgstr "Mentés másként"
+#: ../gui/wxpython/menustrings.py:12
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:13
+msgid "Save workspace to file"
+msgstr "Munkaterület mentés fájlba"
+#: ../gui/wxpython/menustrings.py:13 ../gui/wxpython/menustrings.py:2014
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:14
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1981
+#: ../gui/wxpython/gui_core/forms.py:563
+#: ../gui/wxpython/mapswipe/dialogs.py:193
+msgid "Close"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:14
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:15
+msgid "Close workspace file"
+msgstr "Munkaterület fájl lezárás"
+#: ../gui/wxpython/menustrings.py:15
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:16
+msgid "Load GRC file (Tcl/Tk GUI)"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:16
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:17
+msgid "Load map layers from GRC file to layer tree"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:17
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:18
+#: ../gui/wxpython/web_services/dialogs.py:872
+msgid "Map display"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:18
+msgid "Add raster"
+msgstr "Raszter hozzáadás"
+#: ../gui/wxpython/menustrings.py:19
+msgid "Add raster map layer to current display"
+msgstr "Raszter térkép réteg hozzáadása az aktuális megjelenítőhöz"
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:21
+msgid "Add vector"
+msgstr "Vektor hozzáadás"
+#: ../gui/wxpython/menustrings.py:21
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:22
+msgid "Add vector map layer to current display"
+msgstr "Vektor térkép réteg hozzáadása az aktuális megjelenítőhöz"
+#: ../gui/wxpython/menustrings.py:22
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:23
+msgid "Add multiple rasters or vectors"
+msgstr "Több raszter vagy vektor hozzáadás"
+#: ../gui/wxpython/menustrings.py:23
+msgid "Add multiple raster or vector map layers to current display"
+msgstr "Több raszter vagy vektor réteg hozzáadása az aktuális ablakhoz"
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:25
+msgid "Add RGB raster layer"
+msgstr "RGB raszter réteg hozzáadás"
+#: ../gui/wxpython/menustrings.py:25
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:26
+msgid "Add RGB raster map layer to current display"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:26 ../gui/wxpython/menustrings.py:27
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:27
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:28
+#: ../gui/wxpython/web_services/dialogs.py:524
+msgid "Add web service layer"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:28
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:29
+msgid "New map display window"
+msgstr "Új térkép megjelenítő ablak"
+#: ../gui/wxpython/menustrings.py:29
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:30
+msgid "Open new map display window"
+msgstr "Új térkép megjelenítő ablak megnyitása"
+#: ../gui/wxpython/menustrings.py:30
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:31
+msgid "Render all map displays"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:31
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:32
+msgid "Re-render maps in all open map display windows"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:32 ../gui/wxpython/menustrings.py:33
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:33
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:34
+msgid "Close current map display window"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:34 ../gui/wxpython/menustrings.py:35
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:35
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:36
+msgid "Close all open map display windows"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:37 ../gui/wxpython/menustrings.py:1056
+msgid "Simplified raster import with reprojection"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:38 ../gui/wxpython/menustrings.py:40
+#: ../gui/wxpython/menustrings.py:1057 ../gui/wxpython/menustrings.py:1059
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:39
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1040
+msgid "Imports raster data into a GRASS raster map using GDAL library."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:39 ../gui/wxpython/menustrings.py:1058
+msgid "Import of common raster formats"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:41 ../gui/wxpython/menustrings.py:1060
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:42
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1043
+msgid "ASCII x,y,z point import and gridding"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:42 ../gui/wxpython/menustrings.py:1061
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:43
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1044
+msgid "Creates a raster map from an assemblage of many coordinates using univariate statistics."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:43 ../gui/wxpython/menustrings.py:1062
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:44
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1045
+msgid "ASCII grid import"
+msgstr "ASCII rács import"
+#: ../gui/wxpython/menustrings.py:44 ../gui/wxpython/menustrings.py:1063
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:45
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1046
+msgid "Converts a GRASS ASCII raster file to binary raster map."
+msgstr "GRASS ASCII raszter fájl konvertálás bináris raszter térképbe."
+#: ../gui/wxpython/menustrings.py:45 ../gui/wxpython/menustrings.py:1064
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:46
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1047
+msgid "ASCII polygons, lines, and point import"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:46 ../gui/wxpython/menustrings.py:1065
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:47
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1048
+msgid "Creates raster maps from ASCII polygon/line/point data files."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:47 ../gui/wxpython/menustrings.py:1066
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:48
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1049
+msgid "Raw binary array import"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:48 ../gui/wxpython/menustrings.py:1067
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:49
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1050
+msgid "Import a binary raster file into a GRASS raster map layer."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:49 ../gui/wxpython/menustrings.py:1068
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:50
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1051
+msgid "GRIDATB.FOR import"
+msgstr "GRIDATB.FOR import"
+#: ../gui/wxpython/menustrings.py:50 ../gui/wxpython/menustrings.py:1069
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:51
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1052
+msgid "Imports GRIDATB.FOR map file (TOPMODEL) into a GRASS raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:51 ../gui/wxpython/menustrings.py:1070
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:52
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1053
+msgid "Matlab 2D array import"
+msgstr "Matlab 2D tömb import"
+#: ../gui/wxpython/menustrings.py:52 ../gui/wxpython/menustrings.py:1071
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:53
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1054
+msgid "Imports a binary MAT-File(v4) to a GRASS raster."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:53 ../gui/wxpython/menustrings.py:1072
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:54
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1055
+msgid "PNG import"
+msgstr "PNG import"
+#: ../gui/wxpython/menustrings.py:54 ../gui/wxpython/menustrings.py:1073
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:55
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1056
+msgid "Imports non-georeferenced PNG format image."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:55 ../gui/wxpython/menustrings.py:1074
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:56
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1057
+msgid "SPOT NDVI import"
+msgstr "SPOT NDVI import"
+#: ../gui/wxpython/menustrings.py:56 ../gui/wxpython/menustrings.py:1075
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:57
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1058
+msgid "Imports SPOT VGT NDVI data into a raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:57 ../gui/wxpython/menustrings.py:1076
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:58
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1059
+msgid "SRTM HGT import"
+msgstr "SRTM HGT import"
+#: ../gui/wxpython/menustrings.py:58 ../gui/wxpython/menustrings.py:1077
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:59
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1060
+msgid "Imports SRTM HGT files into raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:59 ../gui/wxpython/menustrings.py:1078
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:60
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1061
+msgid "Terra ASTER HDF import"
+msgstr "Terra ASTER HDF import"
+#: ../gui/wxpython/menustrings.py:60 ../gui/wxpython/menustrings.py:1079
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:61
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1062
+msgid "Georeference, rectify, and import Terra-ASTER imagery and relative DEMs using gdalwarp."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:61 ../gui/wxpython/menustrings.py:86
+#: ../gui/wxpython/menustrings.py:1080 ../gui/wxpython/menustrings.py:1105
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:62
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:86
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1063
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1087
+msgid "LAS LiDAR points import"
+msgstr "LAS LiDAR pont import"
+#: ../gui/wxpython/menustrings.py:62 ../gui/wxpython/menustrings.py:1081
+msgid "Creates a raster map from LAS LiDAR points using univariate statistics."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:63 ../gui/wxpython/menustrings.py:1082
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:63
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1064
+msgid "Unpack raster map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:64 ../gui/wxpython/menustrings.py:1083
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:64
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1065
+msgid "Imports a raster map as GRASS GIS specific archive file (packed with r.pack)"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:65 ../gui/wxpython/menustrings.py:292
+#: ../gui/wxpython/menustrings.py:1084 ../gui/wxpython/menustrings.py:1234
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:65
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:286
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1066
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1212
+msgid "Reproject raster map from different GRASS location"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:66 ../gui/wxpython/menustrings.py:293
+#: ../gui/wxpython/menustrings.py:1085 ../gui/wxpython/menustrings.py:1235
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:66
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:287
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1067
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1213
+msgid "Re-projects a raster map from given location to the current location."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:68 ../gui/wxpython/menustrings.py:1087
+msgid "Simplified vector import with reprojection"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:69 ../gui/wxpython/menustrings.py:71
+#: ../gui/wxpython/menustrings.py:1088 ../gui/wxpython/menustrings.py:1090
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:69
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1070
+msgid "Imports vector data into a GRASS vector map using OGR library."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:70 ../gui/wxpython/menustrings.py:1089
+msgid "Import of common vector formats"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:72 ../gui/wxpython/menustrings.py:1091
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:72
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1073
+msgid "ASCII points or GRASS ASCII format"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:73 ../gui/wxpython/menustrings.py:1092
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:73
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1074
+msgid "Creates a vector map from an ASCII points file or ASCII vector file."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:74 ../gui/wxpython/menustrings.py:1093
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:74
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1075
+msgid "ASCII points as a vector lines"
+msgstr "ASCII pontok mint vektor vonalak"
+#: ../gui/wxpython/menustrings.py:75 ../gui/wxpython/menustrings.py:1094
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:75
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1076
+msgid "Imports ASCII x,y[,z] coordinates as a series of lines."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:76 ../gui/wxpython/menustrings.py:1095
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:76
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1077
+msgid "DXF import"
+msgstr "DXF import"
+#: ../gui/wxpython/menustrings.py:77 ../gui/wxpython/menustrings.py:1096
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:77
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1078
+msgid "Converts files in DXF format to GRASS vector map format."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:78 ../gui/wxpython/menustrings.py:1097
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:78
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1079
+msgid "WFS"
+msgstr "WFS"
+#: ../gui/wxpython/menustrings.py:79 ../gui/wxpython/menustrings.py:1098
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:79
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1080
+msgid "Imports GetFeature from a WFS server."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:80 ../gui/wxpython/menustrings.py:1099
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:80
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1081
+msgid "ESRI e00 import"
+msgstr "ESRI e00 import"
+#: ../gui/wxpython/menustrings.py:81 ../gui/wxpython/menustrings.py:1100
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:81
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1082
+msgid "Imports E00 file into a vector map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:82 ../gui/wxpython/menustrings.py:1101
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:82
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1083
+msgid "Geonames import"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:83 ../gui/wxpython/menustrings.py:1102
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:83
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1084
+msgid "Imports geonames.org country files into a vector points map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:84 ../gui/wxpython/menustrings.py:1103
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:84
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1085
+msgid "Matlab array or Mapgen format import"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:85 ../gui/wxpython/menustrings.py:1104
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:85
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1086
+msgid "Imports Mapgen or Matlab-ASCII vector maps into GRASS."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:87 ../gui/wxpython/menustrings.py:1106
+msgid "Converts LAS LiDAR point clouds to a GRASS vector map with libLAS."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:88 ../gui/wxpython/menustrings.py:1107
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:87
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1088
+msgid "Unpack vector map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:89 ../gui/wxpython/menustrings.py:1108
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:88
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1089
+msgid "Imports a vector map as GRASS GIS specific archive file (packed with v.pack)"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:90 ../gui/wxpython/menustrings.py:572
+#: ../gui/wxpython/menustrings.py:1109 ../gui/wxpython/menustrings.py:1514
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:89
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:564
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1090
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1490
+msgid "Reproject vector map from different GRASS location"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:91 ../gui/wxpython/menustrings.py:573
+#: ../gui/wxpython/menustrings.py:1110 ../gui/wxpython/menustrings.py:1515
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:90
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:565
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1091
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1491
+msgid "Re-projects a vector map from one location to the current location."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:92 ../gui/wxpython/menustrings.py:1111
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:91
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1092
+msgid "Import 3D raster data"
+msgstr "3D raszter adat import"
+#: ../gui/wxpython/menustrings.py:93 ../gui/wxpython/menustrings.py:1112
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:92
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1093
+msgid "ASCII 3D import"
+msgstr "ASCII 3D import"
+#: ../gui/wxpython/menustrings.py:94 ../gui/wxpython/menustrings.py:1113
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:93
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1094
+msgid "Converts a 3D ASCII raster text file into a (binary) 3D raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:95 ../gui/wxpython/menustrings.py:1114
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:94
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1095
+msgid "Raw binary array 3D import"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:96 ../gui/wxpython/menustrings.py:1115
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:95
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1096
+msgid "Imports a binary raster file into a GRASS 3D raster map."
+msgstr "Bináris raszter fájl import GRASS 3D raszter térképbe."
+#: ../gui/wxpython/menustrings.py:97 ../gui/wxpython/menustrings.py:1116
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:96
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1097
+msgid "Vis5D import"
+msgstr "Vis5D import"
+#: ../gui/wxpython/menustrings.py:98 ../gui/wxpython/menustrings.py:1117
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:97
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1098
+msgid "Import 3-dimensional Vis5D files."
+msgstr "3-dimenziós Vis5D fájlok importálása."
+#: ../gui/wxpython/menustrings.py:99 ../gui/wxpython/menustrings.py:1118
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:98
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1099
+msgid "Import database table"
+msgstr "Adatbázistábla import"
+#: ../gui/wxpython/menustrings.py:100 ../gui/wxpython/menustrings.py:1119
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:68
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:99
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1069
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1100
+msgid "Common import formats"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:101 ../gui/wxpython/menustrings.py:1120
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:100
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1101
+msgid "Imports attribute tables in various formats."
+msgstr "Attribútumtábla import változatos formátumokból."
+#: ../gui/wxpython/menustrings.py:102 ../gui/wxpython/menustrings.py:1121
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:101
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1102
+msgid "Export raster map"
+msgstr "Raszter térkép export"
+#: ../gui/wxpython/menustrings.py:103 ../gui/wxpython/menustrings.py:132
+#: ../gui/wxpython/menustrings.py:158 ../gui/wxpython/menustrings.py:1122
+#: ../gui/wxpython/menustrings.py:1151 ../gui/wxpython/menustrings.py:1177
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:102
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:131
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:156
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1103
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1132
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1157
+msgid "Common export formats"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:104 ../gui/wxpython/menustrings.py:1123
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:103
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1104
+msgid "Exports GRASS raster maps into GDAL supported formats."
+msgstr "GRASS raszter térképek exportálása GDAL támogatott formátumokba."
+#: ../gui/wxpython/menustrings.py:105 ../gui/wxpython/menustrings.py:1124
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1105
+msgid "ASCII grid export"
+msgstr "ASCII rács export"
+#: ../gui/wxpython/menustrings.py:106 ../gui/wxpython/menustrings.py:1125
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1106
+msgid "Converts a raster map layer into a GRASS ASCII text file."
+msgstr "Raszter térkép réteg konvertálása GRASS ASCII szövegfájlba."
+#: ../gui/wxpython/menustrings.py:107 ../gui/wxpython/menustrings.py:1126
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1107
+msgid "ASCII x,y,z points export"
+msgstr "ASCII x,y,z pont export"
+#: ../gui/wxpython/menustrings.py:108 ../gui/wxpython/menustrings.py:1127
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1108
+msgid "Exports a raster map to a text file as x,y,z values based on cell centers."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:109 ../gui/wxpython/menustrings.py:1128
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1109
+msgid "GRIDATB.FOR export"
+msgstr "GRIDATB.FOR export"
+#: ../gui/wxpython/menustrings.py:110 ../gui/wxpython/menustrings.py:1129
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1110
+msgid "Exports GRASS raster map to GRIDATB.FOR map file (TOPMODEL)."
+msgstr "GRASS raszter export GRIDATB.FOR térkép fájlba (TOPMODEL)."
+#: ../gui/wxpython/menustrings.py:111 ../gui/wxpython/menustrings.py:1130
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1111
+msgid "Matlab 2D array export"
+msgstr "Matlab 2D tömb export"
+#: ../gui/wxpython/menustrings.py:112 ../gui/wxpython/menustrings.py:1131
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1112
+msgid "Exports a GRASS raster to a binary MAT-File."
+msgstr "GRASS raszter export bináris MAT-fájlba"
+#: ../gui/wxpython/menustrings.py:113 ../gui/wxpython/menustrings.py:1132
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:112
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1113
+msgid "Raw binary array export"
+msgstr "Nyers bináris tömb export"
+#: ../gui/wxpython/menustrings.py:114 ../gui/wxpython/menustrings.py:1133
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1114
+msgid "Exports a GRASS raster to a binary array."
+msgstr "GRASS raszter exportálás bináris tömbbe."
+#: ../gui/wxpython/menustrings.py:115 ../gui/wxpython/menustrings.py:1134
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:114
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1115
+msgid "MPEG-1 export"
+msgstr "MPEG-1 export"
+#: ../gui/wxpython/menustrings.py:116 ../gui/wxpython/menustrings.py:1135
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1116
+msgid "Converts raster map series to MPEG movie."
+msgstr "Raszter térkép sorozat konvertálása MPEG filmbe."
+#: ../gui/wxpython/menustrings.py:117 ../gui/wxpython/menustrings.py:1136
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:116
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1117
+msgid "PNG export"
+msgstr "PNG export"
+#: ../gui/wxpython/menustrings.py:118 ../gui/wxpython/menustrings.py:1137
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:117
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1118
+msgid "Export a GRASS raster map as a non-georeferenced PNG image."
+msgstr "GRASS raszter térkép export nem georeferált PNG képbe."
+#: ../gui/wxpython/menustrings.py:119 ../gui/wxpython/menustrings.py:1138
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:118
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1119
+msgid "PPM export"
+msgstr "PPM export"
+#: ../gui/wxpython/menustrings.py:120 ../gui/wxpython/menustrings.py:1139
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:119
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1120
+msgid "Converts a GRASS raster map to a PPM image file."
+msgstr "GRASS raszter térkép konvertálás PPM kép fájlba."
+#: ../gui/wxpython/menustrings.py:121 ../gui/wxpython/menustrings.py:1140
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:120
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1121
+msgid "PPM from RGB export"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:122 ../gui/wxpython/menustrings.py:1141
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1122
+msgid "Converts 3 GRASS raster layers (R,G,B) to a PPM image file."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:123 ../gui/wxpython/menustrings.py:140
+#: ../gui/wxpython/menustrings.py:1142 ../gui/wxpython/menustrings.py:1159
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:122
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:138
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1123
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1139
+msgid "POV-Ray export"
+msgstr "POV-Ray export"
+#: ../gui/wxpython/menustrings.py:124 ../gui/wxpython/menustrings.py:1143
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:123
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1124
+msgid "Converts a raster map layer into a height-field file for POV-Ray."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:125 ../gui/wxpython/menustrings.py:1144
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:124
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1125
+msgid "VRML export"
+msgstr "VRML export"
+#: ../gui/wxpython/menustrings.py:126 ../gui/wxpython/menustrings.py:1145
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:125
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1126
+msgid "Exports a raster map to the Virtual Reality Modeling Language (VRML)."
+msgstr "Raszter térkép export virtuális valóság modellező nyelvbe (VRML)."
+#: ../gui/wxpython/menustrings.py:127 ../gui/wxpython/menustrings.py:144
+#: ../gui/wxpython/menustrings.py:155 ../gui/wxpython/menustrings.py:1146
+#: ../gui/wxpython/menustrings.py:1163 ../gui/wxpython/menustrings.py:1174
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:126
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:142
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:153
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1127
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1143
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1154
+msgid "VTK export"
+msgstr "VTK export"
+#: ../gui/wxpython/menustrings.py:128 ../gui/wxpython/menustrings.py:1147
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:127
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1128
+msgid "Converts raster maps into the VTK-ASCII format."
+msgstr "Raszter térkép konvertálás VTK-ASCII formátumba."
+#: ../gui/wxpython/menustrings.py:129 ../gui/wxpython/menustrings.py:1148
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:128
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1129
+msgid "Pack raster map"
+msgstr "Raszter térkép becsomagolás"
+#: ../gui/wxpython/menustrings.py:130 ../gui/wxpython/menustrings.py:1149
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:129
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1130
+msgid "Exports a raster map as GRASS GIS specific archive file"
+msgstr "Raszter térkép export GRASS GIS specifikus archive fájlba"
+#: ../gui/wxpython/menustrings.py:131 ../gui/wxpython/menustrings.py:1150
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:130
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1131
+msgid "Export vector map"
+msgstr "Vektor térkép export"
+#: ../gui/wxpython/menustrings.py:133 ../gui/wxpython/menustrings.py:1152
+msgid "Exports a vector map layer to any of the supported OGR vector formats. By default a vector map layer is exported to OGC GeoPackage format."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:134 ../gui/wxpython/menustrings.py:1153
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:133
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1134
+msgid "ASCII points or GRASS ASCII vector export"
+msgstr "ASCII pontok vagy GRASS ASCII vektor export"
+#: ../gui/wxpython/menustrings.py:135 ../gui/wxpython/menustrings.py:1154
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:134
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1135
+msgid "Exports a vector map to a GRASS ASCII vector representation. By default only features with category are exported. To export all features use 'layer=-1'."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:136 ../gui/wxpython/menustrings.py:1155
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:135
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1136
+msgid "DXF export"
+msgstr "DXF export"
+#: ../gui/wxpython/menustrings.py:137 ../gui/wxpython/menustrings.py:1156
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:136
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1137
+msgid "Exports vector map to DXF file format."
+msgstr "Vektor térkép exportálása DXF fájl formátumba."
+#: ../gui/wxpython/menustrings.py:138 ../gui/wxpython/menustrings.py:1157
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:137
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1138
+msgid "PostGIS export"
+msgstr "PostGIS export"
+#: ../gui/wxpython/menustrings.py:139 ../gui/wxpython/menustrings.py:1158
+msgid "Exports a vector map layer to PostGIS feature table."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:141 ../gui/wxpython/menustrings.py:1160
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:139
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1140
+msgid "Converts GRASS x,y,z points to POV-Ray x,z,y format."
+msgstr "GRASS x,y,z pontok konvertálása POV-Ray x,y,z formátumba."
+#: ../gui/wxpython/menustrings.py:142 ../gui/wxpython/menustrings.py:1161
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:140
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1141
+msgid "SVG export"
+msgstr "SVG export"
+#: ../gui/wxpython/menustrings.py:143 ../gui/wxpython/menustrings.py:1162
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:141
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1142
+msgid "Exports a vector map to SVG file."
+msgstr "Vektor térkép konvertálása SVG fájlba."
+#: ../gui/wxpython/menustrings.py:145 ../gui/wxpython/menustrings.py:1164
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:143
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1144
+msgid "Converts a vector map to VTK ASCII output."
+msgstr "Vektor térkép konvertálása VTK ASCII outputba."
+#: ../gui/wxpython/menustrings.py:146 ../gui/wxpython/menustrings.py:1165
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:144
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1145
+msgid "Pack vector map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:147 ../gui/wxpython/menustrings.py:1166
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:145
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1146
+msgid "Exports a vector map as GRASS GIS specific archive file"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:148 ../gui/wxpython/menustrings.py:1167
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:146
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1147
+msgid "Export 3D raster maps"
+msgstr "3D raszter térkép export"
+#: ../gui/wxpython/menustrings.py:149 ../gui/wxpython/menustrings.py:1168
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:147
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1148
+msgid "ASCII 3D export"
+msgstr "ASCII 3D export"
+#: ../gui/wxpython/menustrings.py:150 ../gui/wxpython/menustrings.py:1169
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:148
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1149
+msgid "Converts a 3D raster map layer into a ASCII text file."
+msgstr "3D raszter térkép konvertálása ASCII szövegfájlba."
+#: ../gui/wxpython/menustrings.py:151 ../gui/wxpython/menustrings.py:1170
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1150
+msgid "Raw binary array 3D export"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:152 ../gui/wxpython/menustrings.py:1171
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:150
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1151
+msgid "Exports a GRASS 3D raster map to a binary array."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:153 ../gui/wxpython/menustrings.py:1172
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:151
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1152
+msgid "Vis5D export"
+msgstr "Vis5D export"
+#: ../gui/wxpython/menustrings.py:154 ../gui/wxpython/menustrings.py:1173
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:152
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1153
+msgid "Exports GRASS 3D raster map to 3-dimensional Vis5D file."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:156 ../gui/wxpython/menustrings.py:1175
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:154
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1155
+msgid "Converts 3D raster maps into the VTK-ASCII format."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:157 ../gui/wxpython/menustrings.py:1176
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:155
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1156
+msgid "Export database table"
+msgstr "Adatbázistábla export"
+#: ../gui/wxpython/menustrings.py:159 ../gui/wxpython/menustrings.py:1178
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:157
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1158
+msgid "Exports attribute tables into various formats."
+msgstr "Attribútum táblák exportálása különböző formátumokba."
+#: ../gui/wxpython/menustrings.py:160 ../gui/wxpython/menustrings.py:1179
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:158
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1159
+msgid "Link external data"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:162 ../gui/wxpython/menustrings.py:1181
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:160
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1161
+msgid "Link GDAL supported raster data as a pseudo GRASS raster map layer."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:164 ../gui/wxpython/menustrings.py:1183
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:162
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1163
+msgid "Creates a new pseudo-vector map as a link to an OGR-supported layer."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:165 ../gui/wxpython/menustrings.py:1184
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:163
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1164
+msgid "Output format for raster data"
+msgstr "Output formátum a raszter adatokhoz"
+#: ../gui/wxpython/menustrings.py:166 ../gui/wxpython/menustrings.py:1185
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:164
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1165
+msgid "Redirects raster output to file utilizing GDAL library rather than storing in GRASS raster format."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:167 ../gui/wxpython/menustrings.py:1186
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:165
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1166
+msgid "Output format for vector data"
+msgstr "Output formátum vektor adatokhoz"
+#: ../gui/wxpython/menustrings.py:168 ../gui/wxpython/menustrings.py:1187
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:166
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1167
+msgid "Defines vector output format utilizing OGR library."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:169 ../gui/wxpython/menustrings.py:1188
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:167
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1168
+msgid "Manage maps"
+msgstr "Térképek kezelése"
+#: ../gui/wxpython/menustrings.py:170 ../gui/wxpython/menustrings.py:1189
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:168
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1169
+#: ../gui/wxpython/gui_core/forms.py:613
+msgid "Copy"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:171 ../gui/wxpython/menustrings.py:1190
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:169
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1170
+msgid "Copies available data files in the current mapset search path to the user's current mapset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:172 ../gui/wxpython/menustrings.py:963
+#: ../gui/wxpython/menustrings.py:1191 ../gui/wxpython/menustrings.py:1905
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:170
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:946
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1171
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1872
+msgid "List"
+msgstr "Lista"
+#: ../gui/wxpython/menustrings.py:173 ../gui/wxpython/menustrings.py:1192
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:171
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1172
+msgid "Lists available GRASS data base files of the user-specified data type optionally using the search pattern."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:174 ../gui/wxpython/menustrings.py:951
+#: ../gui/wxpython/menustrings.py:1193 ../gui/wxpython/menustrings.py:1893
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:172
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:934
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1173
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1860
+#: ../gui/wxpython/lmgr/layertree.py:468 ../gui/wxpython/rlisetup/frame.py:146
+msgid "Rename"
+msgstr "Átnevezés"
+#: ../gui/wxpython/menustrings.py:175 ../gui/wxpython/menustrings.py:1194
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:173
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1174
+msgid "Renames data base element files in the user's current mapset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:176 ../gui/wxpython/menustrings.py:1195
+#: ../gui/wxpython/menustrings.py:2089
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:174
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1175
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:2056
+#: ../gui/wxpython/nviz/tools.py:1364 ../gui/wxpython/nviz/tools.py:2367
+#: ../gui/wxpython/nviz/tools.py:2419 ../gui/wxpython/psmap/dialogs.py:1770
+msgid "Delete"
+msgstr "Törlés"
+#: ../gui/wxpython/menustrings.py:177 ../gui/wxpython/menustrings.py:1196
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:175
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1176
+msgid "Removes data base element files from the user's current mapset using the search pattern."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:178 ../gui/wxpython/menustrings.py:316
+#: ../gui/wxpython/menustrings.py:610 ../gui/wxpython/menustrings.py:864
+#: ../gui/wxpython/menustrings.py:1258 ../gui/wxpython/menustrings.py:1552
+#: ../gui/wxpython/menustrings.py:1806
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:176
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:310
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:602
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:847
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1236
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1528
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1773
+msgid "Map type conversions"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:179 ../gui/wxpython/menustrings.py:317
+#: ../gui/wxpython/menustrings.py:1259
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:311
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1237
+msgid "Raster to vector"
+msgstr "Raszter vektorrá"
+#: ../gui/wxpython/menustrings.py:180 ../gui/wxpython/menustrings.py:318
+#: ../gui/wxpython/menustrings.py:1260
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:178
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:312
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1238
+msgid "Converts a raster map into a vector map."
+msgstr "Raszter térkép konvertálása vektor térképpé."
+#: ../gui/wxpython/menustrings.py:181 ../gui/wxpython/menustrings.py:319
+#: ../gui/wxpython/menustrings.py:1261
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:179
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:313
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1239
+msgid "Raster series to 3D raster"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:182 ../gui/wxpython/menustrings.py:320
+#: ../gui/wxpython/menustrings.py:1262
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:180
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:314
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1240
+msgid "Converts 2D raster map slices to one 3D raster volume map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:183 ../gui/wxpython/menustrings.py:321
+#: ../gui/wxpython/menustrings.py:1263
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:181
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:315
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1241
+msgid "Raster 2.5D to 3D raster"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:184 ../gui/wxpython/menustrings.py:322
+#: ../gui/wxpython/menustrings.py:1264
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:182
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:316
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1242
+msgid "Creates a 3D volume map based on 2D elevation and value raster maps."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:185 ../gui/wxpython/menustrings.py:611
+#: ../gui/wxpython/menustrings.py:1553
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:183
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:603
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1529
+msgid "Vector to raster"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:186 ../gui/wxpython/menustrings.py:612
+#: ../gui/wxpython/menustrings.py:1554
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:184
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:604
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1530
+msgid "Converts (rasterize) a vector map into a raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:187 ../gui/wxpython/menustrings.py:613
+#: ../gui/wxpython/menustrings.py:1555
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:185
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:605
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1531
+msgid "Vector to 3D raster"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:188 ../gui/wxpython/menustrings.py:614
+#: ../gui/wxpython/menustrings.py:1556
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:606
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1532
+msgid "Converts a vector map (only points) into a 3D raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:189 ../gui/wxpython/menustrings.py:615
+#: ../gui/wxpython/menustrings.py:1557
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:607
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1533
+msgid "2D vector to 3D vector"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:190 ../gui/wxpython/menustrings.py:616
+#: ../gui/wxpython/menustrings.py:1558
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:188
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:608
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1534
+msgid "Performs transformation of 2D vector features to 3D."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:191
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:189
+msgid "3D raster to raster series"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:192 ../gui/wxpython/menustrings.py:866
+#: ../gui/wxpython/menustrings.py:1808
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:190
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:849
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1775
+msgid "Converts 3D raster maps to 2D raster maps"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:193 ../gui/wxpython/menustrings.py:1991
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:191
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1958
+msgid "Georectify"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:194 ../gui/wxpython/menustrings.py:1992
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:192
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1959
+msgid "Manage Ground Control Points for Georectification"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:195 ../gui/wxpython/menustrings.py:1993
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:193
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1960
+msgid "Graphical modeler"
+msgstr "Grafikus modellező"
+#: ../gui/wxpython/menustrings.py:196 ../gui/wxpython/menustrings.py:1994
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:194
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1961
+msgid "Launch Graphical modeler"
+msgstr "Grafikus modellező indítása"
+#: ../gui/wxpython/menustrings.py:197 ../gui/wxpython/menustrings.py:2044
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:2011
+msgid "Run model"
+msgstr "Modell futtatás"
+#: ../gui/wxpython/menustrings.py:198
+msgid "Run model prepared by Graphical modeler"
+msgstr "A grafikus modellezővel készített modell futtatása"
+#: ../gui/wxpython/menustrings.py:199
+msgid "3D image rendering"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:200
+msgid "Creates a 3D rendering of GIS data. Renders surfaces (raster data), 2D/3D vector data, and volumes (3D raster data) in 3D."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:201 ../gui/wxpython/menustrings.py:1037
+#: ../gui/wxpython/menustrings.py:1979 ../gui/wxpython/menustrings.py:1986
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:199
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1020
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1946
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1953
+msgid "Animation tool"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:202 ../gui/wxpython/menustrings.py:1038
+#: ../gui/wxpython/menustrings.py:1980 ../gui/wxpython/menustrings.py:1987
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:200
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1021
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1947
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1954
+msgid "Launch animation tool."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:203
+msgid "Bearing/distance to coordinates"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:204
+msgid "A simple utility for converting bearing and distance measurements to coordinates and vice versa. It assumes a cartesian coordinate system"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:205 ../gui/wxpython/menustrings.py:1989
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:203
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1956
+#: ../gui/wxpython/lmgr/toolbars.py:161
+msgid "Cartographic Composer"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:206 ../gui/wxpython/menustrings.py:1990
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:204
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1957
+msgid "Launch Cartographic Composer"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:207 ../gui/wxpython/menustrings.py:1997
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1964
+msgid "Map Swipe"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:208 ../gui/wxpython/menustrings.py:1998
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:206
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1965
+msgid "Launch Map Swipe"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:209
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:207
+msgid "Launch script"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:210
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:208
+msgid "Launches script file."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:211
+msgid "Simple Python Editor"
+msgstr "Egyszerű Python szerkesztő"
+#: ../gui/wxpython/menustrings.py:212
+msgid "Launches Simple Python Editor."
+msgstr "Egyszerű Python szerkesztő indítása."
+#: ../gui/wxpython/menustrings.py:213
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:209
+#: ../gui/wxpython/gui_core/dialogs.py:2347
+msgid "Close GUI"
+msgstr "GUI bezárás"
+#: ../gui/wxpython/menustrings.py:214
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:210
+msgid "Close graphical user interface."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:215
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:211
+#: ../gui/wxpython/gui_core/dialogs.py:2326
+#: ../gui/wxpython/gui_core/dialogs.py:2350
+msgid "Quit GRASS GIS"
+msgstr "Kilépés GRASS GIS-ből"
+#: ../gui/wxpython/menustrings.py:216
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:212
+msgid "Close GUI and exit GRASS GIS shell."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:217 ../gui/wxpython/menustrings.py:2022
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:213
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1989
+msgid "&Settings"
+msgstr "Beállítások"
+#: ../gui/wxpython/menustrings.py:218 ../gui/wxpython/menustrings.py:1197
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:214
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1177
+#: ../gui/wxpython/mapdisp/statusbar.py:1152
+#: ../gui/wxpython/web_services/dialogs.py:874
+msgid "Computational region"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:219 ../gui/wxpython/menustrings.py:1198
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:215
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1178
+msgid "Show current region"
+msgstr "Aktuális régió megjelenítése"
+#: ../gui/wxpython/menustrings.py:220 ../gui/wxpython/menustrings.py:222
+#: ../gui/wxpython/menustrings.py:1199 ../gui/wxpython/menustrings.py:1201
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:216
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:218
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1179
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1181
+msgid "Shows the extent and resolution of the computational region."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:221 ../gui/wxpython/menustrings.py:1200
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:217
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1180
+msgid "Show region using latitude and longitude"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:223 ../gui/wxpython/menustrings.py:1202
+msgid "Show current region extent in Map Display"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:224 ../gui/wxpython/menustrings.py:1203
+msgid "Shows the extent of the computational region in Map Display."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:225 ../gui/wxpython/menustrings.py:1204
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:219
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1182
+msgid "Set region"
+msgstr "Régió beállítás"
+#: ../gui/wxpython/menustrings.py:226 ../gui/wxpython/menustrings.py:1205
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:220
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1183
+msgid "Manages the boundary definitions for the geographic region."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:227
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:221
+msgid "GRASS working environment"
+msgstr "GRASS munka környezet"
+#: ../gui/wxpython/menustrings.py:228
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:222
+msgid "Mapset access"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:229
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:223
+msgid "Set/unset access to other mapsets in current location"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:230
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:224
+msgid "User access"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:231
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:225
+msgid "Controls access to the current mapset for other users on the system. If no option given, prints current status."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:232
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:226
+msgid "Change working environment"
+msgstr "Munkakörnyezet módosítás"
+#: ../gui/wxpython/menustrings.py:233
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:227
+msgid "Changes/reports current mapset. Optionally create new mapset or list available mapsets in given location."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:234
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:228
+msgid "Change location and mapset"
+msgstr "Hely és térképcsoport váltás"
+#: ../gui/wxpython/menustrings.py:235
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:229
+msgid "Change current location and mapset."
+msgstr "Aktuális hely és térképcsoport módosítása"
+#: ../gui/wxpython/menustrings.py:236
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:230
+msgid "Change mapset"
+msgstr "Térképcsoport váltás"
+#: ../gui/wxpython/menustrings.py:237
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:231
+msgid "Change current mapset."
+msgstr "Aktuális térképcsoport módosítása"
+#: ../gui/wxpython/menustrings.py:238 ../gui/wxpython/menustrings.py:239
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:232
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:233
+msgid "Change working directory"
+msgstr "Munkakönyvtár váltás"
+#: ../gui/wxpython/menustrings.py:240
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:234
+msgid "Show settings"
+msgstr "Beállítások megjelenítése"
+#: ../gui/wxpython/menustrings.py:241
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:235
+msgid "Outputs and modifies the user's current GRASS variable settings."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:242
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:236
+msgid "Change settings"
+msgstr "Beállítások módosítása"
+#: ../gui/wxpython/menustrings.py:243
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:237
+msgid "Outputs and modifies the user's current GRASS variable settings. Prints all defined GRASS variables if no option is given."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:244
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:238
+msgid "Create new location"
+msgstr "Új hely létrehozása"
+#: ../gui/wxpython/menustrings.py:245
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:239
+msgid "Launches location wizard to create new GRASS location."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:247
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:241
+msgid "Creates new mapset in the current location, changes current mapset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:248
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:242
+msgid "Version and copyright"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:249
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:243
+msgid "Displays version and copyright information."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:250
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:244
+msgid "Map projections"
+msgstr "Térkép vetületek"
+#: ../gui/wxpython/menustrings.py:251
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:245
+msgid "Display map projection"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:252
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:246
+msgid "Converts co-ordinate system descriptions (i.e. projection information) between various formats (including GRASS format)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:253
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:247
+msgid "Manage projections"
+msgstr "Vetületek kezelése"
+#: ../gui/wxpython/menustrings.py:254
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:248
+msgid "Prints or modifies GRASS projection information files (in various co-ordinate system descriptions). Can also be used to create new GRASS locations."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:255
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:249
+msgid "Convert coordinates"
+msgstr "Koordináta konvertálás"
+#: ../gui/wxpython/menustrings.py:256
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:250
+msgid "Converts coordinates from one projection to another (cs2cs frontend)."
+msgstr "Koordináták konvertálása egyik vetületből egy másikba (cs2cs frontend)"
+#: ../gui/wxpython/menustrings.py:257
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:251
+msgid "Addons extensions"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:258
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:252
+msgid "Install extension from addons"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:259
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:253
+msgid "Installs new extension from GRASS AddOns SVN repository."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:260
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:254
+msgid "Manage installed extension"
+msgstr "Telepített bővítmények kezelése"
+#: ../gui/wxpython/menustrings.py:261
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:255
+msgid "Updates or removes installed GRASS AddOns extension(s)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:262 ../gui/wxpython/menustrings.py:2023
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:256
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1990
+msgid "Preferences"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:263
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:257
+msgid "User GUI preferences (display font, commands, digitizer, etc.)"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:264 ../gui/wxpython/menustrings.py:1206
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:258
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1184
+msgid "&Raster"
+msgstr "&Raszter"
+#: ../gui/wxpython/menustrings.py:265 ../gui/wxpython/menustrings.py:1207
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:259
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1185
+msgid "Develop raster map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:266 ../gui/wxpython/menustrings.py:1208
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:260
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1186
+msgid "Compress/decompress"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:267 ../gui/wxpython/menustrings.py:1209
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:261
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1187
+msgid "Compresses and decompresses raster maps."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:268 ../gui/wxpython/menustrings.py:1210
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:262
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1188
+msgid "Region boundaries"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:269 ../gui/wxpython/menustrings.py:1211
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:263
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1189
+msgid "Sets the boundary definitions for a raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:270 ../gui/wxpython/menustrings.py:1212
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:264
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1190
+msgid "Manage NULL values"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:271 ../gui/wxpython/menustrings.py:1213
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:265
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1191
+msgid "Manages NULL-values of given raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:272 ../gui/wxpython/menustrings.py:1214
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:266
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1192
+msgid "Quantization"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:273 ../gui/wxpython/menustrings.py:1215
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:267
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1193
+msgid "Produces the quantization file for a floating-point map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:274 ../gui/wxpython/menustrings.py:1216
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:268
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1194
+msgid "Timestamp"
+msgstr "Időbélyeg"
+#: ../gui/wxpython/menustrings.py:275 ../gui/wxpython/menustrings.py:1217
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:269
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1195
+msgid "Modifies a timestamp for a raster map. Print/add/remove a timestamp for a raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:276 ../gui/wxpython/menustrings.py:1218
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:270
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1196
+msgid "Resample using aggregate statistics"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:277 ../gui/wxpython/menustrings.py:1219
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:271
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1197
+msgid "Resamples raster map layers to a coarser grid using aggregation."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:278 ../gui/wxpython/menustrings.py:1220
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:272
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1198
+msgid "Resample using multiple methods"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:279 ../gui/wxpython/menustrings.py:1221
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:273
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1199
+msgid "Resamples raster map to a finer grid using interpolation."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:280 ../gui/wxpython/menustrings.py:1222
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:274
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1200
+msgid "Resample using nearest neighbor"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:281 ../gui/wxpython/menustrings.py:1223
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:275
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1201
+msgid "GRASS raster map layer data resampling capability."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:282 ../gui/wxpython/menustrings.py:1224
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:276
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1202
+msgid "Resample using spline tension"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:283 ../gui/wxpython/menustrings.py:1225
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:277
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1203
+msgid "Reinterpolates and optionally computes topographic analysis from input raster map to a new raster map (possibly with different resolution) using regularized spline with tension and smoothing."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:284 ../gui/wxpython/menustrings.py:1226
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:278
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1204
+msgid "Resample using bspline"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:285 ../gui/wxpython/menustrings.py:1227
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:279
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1205
+msgid "Performs bilinear or bicubic spline interpolation with Tykhonov regularization."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:286 ../gui/wxpython/menustrings.py:1228
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:280
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1206
+msgid "Resample using analytic kernel"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:287 ../gui/wxpython/menustrings.py:1229
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:281
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1207
+msgid "Resamples raster map layers using an analytic kernel."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:288 ../gui/wxpython/menustrings.py:574
+#: ../gui/wxpython/menustrings.py:1230 ../gui/wxpython/menustrings.py:1516
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:282
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:566
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1208
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1492
+msgid "Support file maintenance"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:289 ../gui/wxpython/menustrings.py:1231
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:283
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1209
+msgid "Allows creation and/or modification of raster map layer support files."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:290 ../gui/wxpython/menustrings.py:1232
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:284
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1210
+msgid "Update map statistics"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:291 ../gui/wxpython/menustrings.py:1233
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:285
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1211
+msgid "Update raster map statistics"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:294 ../gui/wxpython/menustrings.py:1236
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:288
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1214
+msgid "Tiling"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:295 ../gui/wxpython/menustrings.py:1237
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:289
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1215
+msgid "Produces tilings of the source projection for use in the destination region and projection."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:296 ../gui/wxpython/menustrings.py:593
+#: ../gui/wxpython/menustrings.py:1238 ../gui/wxpython/menustrings.py:1535
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:290
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:585
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1216
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1511
+msgid "Manage colors"
+msgstr "Színek kezelése"
+#: ../gui/wxpython/menustrings.py:297 ../gui/wxpython/menustrings.py:594
+#: ../gui/wxpython/menustrings.py:1239 ../gui/wxpython/menustrings.py:1536
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:291
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:586
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1217
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1512
+msgid "Color tables"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:298 ../gui/wxpython/menustrings.py:1240
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:292
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1218
+msgid "Creates/modifies the color table associated with a raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:299 ../gui/wxpython/menustrings.py:1241
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:293
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1219
+msgid "Color tables (stddev)"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:300 ../gui/wxpython/menustrings.py:1242
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:294
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1220
+msgid "Sets color rules based on stddev from a raster map's mean value."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:301 ../gui/wxpython/menustrings.py:596
+#: ../gui/wxpython/menustrings.py:1243 ../gui/wxpython/menustrings.py:1538
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:295
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:588
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1221
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1514
+msgid "Manage color rules interactively"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:302 ../gui/wxpython/menustrings.py:1244
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:296
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1222
+msgid "Interactive management of raster color tables."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:303 ../gui/wxpython/menustrings.py:598
+#: ../gui/wxpython/menustrings.py:1245 ../gui/wxpython/menustrings.py:1540
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:297
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:590
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1223
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1516
+msgid "Export color table"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:304 ../gui/wxpython/menustrings.py:1246
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:298
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1224
+msgid "Exports the color table associated with a raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:305 ../gui/wxpython/menustrings.py:1247
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:299
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1225
+msgid "Blend 2 color rasters"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:306 ../gui/wxpython/menustrings.py:1248
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:300
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1226
+msgid "Blends color components of two raster maps by a given ratio."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:307 ../gui/wxpython/menustrings.py:1249
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:301
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1227
+msgid "Create RGB"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:308 ../gui/wxpython/menustrings.py:1250
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:302
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1228
+msgid "Combines red, green and blue raster maps into a single composite raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:309 ../gui/wxpython/menustrings.py:766
+#: ../gui/wxpython/menustrings.py:1251 ../gui/wxpython/menustrings.py:1708
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:303
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:754
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1229
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1680
+msgid "RGB to HIS"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:310 ../gui/wxpython/menustrings.py:1252
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:304
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1230
+msgid "Generates red, green and blue (RGB) raster map layers combining hue, intensity and saturation (HIS) values from user-specified input raster map layers."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:311 ../gui/wxpython/menustrings.py:1253
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:305
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1231
+msgid "Query raster maps"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:312 ../gui/wxpython/menustrings.py:1254
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:306
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1232
+msgid "Query values by coordinates"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:313 ../gui/wxpython/menustrings.py:1255
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:307
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1233
+msgid "Queries raster maps on their category values and category labels."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:314 ../gui/wxpython/menustrings.py:1256
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:308
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1234
+msgid "Query colors by value"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:315 ../gui/wxpython/menustrings.py:1257
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:309
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1235
+msgid "Queries colors for a raster map layer."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:323 ../gui/wxpython/menustrings.py:1265
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:317
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1243
+msgid "Raster buffers and distance"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:324 ../gui/wxpython/menustrings.py:1266
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:318
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1244
+msgid "Buffer rasters"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:325 ../gui/wxpython/menustrings.py:1267
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:319
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1245
+msgid "Creates a raster map showing buffer zones surrounding cells that contain non-NULL category values."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:326 ../gui/wxpython/menustrings.py:1268
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:320
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1246
+msgid "Concentric circles"
+msgstr "Koncentrikus körök"
+#: ../gui/wxpython/menustrings.py:327 ../gui/wxpython/menustrings.py:1269
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:321
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1247
+msgid "Creates a raster map containing concentric rings around a given point."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:328 ../gui/wxpython/menustrings.py:1270
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:322
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1248
+msgid "Closest points"
+msgstr "Legközelebbi pontok"
+#: ../gui/wxpython/menustrings.py:329 ../gui/wxpython/menustrings.py:1271
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:323
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1249
+msgid "Locates the closest points between objects in two raster maps."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:330 ../gui/wxpython/menustrings.py:1272
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:324
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1250
+msgid "Grow by one cell"
+msgstr "Növelés egy cellával"
+#: ../gui/wxpython/menustrings.py:331 ../gui/wxpython/menustrings.py:396
+#: ../gui/wxpython/menustrings.py:1273 ../gui/wxpython/menustrings.py:1338
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:325
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:388
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1251
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1314
+msgid "Generates a raster map layer with contiguous areas grown by one cell."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:332 ../gui/wxpython/menustrings.py:388
+#: ../gui/wxpython/menustrings.py:1274 ../gui/wxpython/menustrings.py:1330
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:326
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:380
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1252
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1306
+msgid "Distance to features"
+msgstr "Távolság az elemekhez"
+#: ../gui/wxpython/menustrings.py:333 ../gui/wxpython/menustrings.py:389
+#: ../gui/wxpython/menustrings.py:1275 ../gui/wxpython/menustrings.py:1331
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:327
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:381
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1253
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1307
+msgid "Generates a raster map containing distances to nearest raster features."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:334 ../gui/wxpython/menustrings.py:1276
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:328
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1254
+#: ../gui/wxpython/nviz/tools.py:977 ../gui/wxpython/nviz/tools.py:2817
+#: ../gui/wxpython/psmap/dialogs.py:2310
+msgid "Mask"
+msgstr "Maszk"
+#: ../gui/wxpython/menustrings.py:335 ../gui/wxpython/menustrings.py:1277
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:329
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1255
+msgid "Creates a MASK for limiting raster operation."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:336 ../gui/wxpython/menustrings.py:337
+#: ../gui/wxpython/menustrings.py:1278 ../gui/wxpython/menustrings.py:1279
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:330
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:331
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1256
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1257
+msgid "Raster map calculator"
+msgstr "Raszter térkép kalkulátor"
+#: ../gui/wxpython/menustrings.py:338 ../gui/wxpython/menustrings.py:1280
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:332
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1258
+msgid "Neighborhood analysis"
+msgstr "Szomszédsági elemzés"
+#: ../gui/wxpython/menustrings.py:339 ../gui/wxpython/menustrings.py:1281
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:333
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1259
+#: ../gui/wxpython/rlisetup/wizard.py:886
+msgid "Moving window"
+msgstr "Mozgó ablak"
+#: ../gui/wxpython/menustrings.py:340 ../gui/wxpython/menustrings.py:1282
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:334
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1260
+msgid "Makes each cell category value a function of the category values assigned to the cells around it, and stores new cell values in an output raster map layer."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:341 ../gui/wxpython/menustrings.py:1283
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:335
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1261
+msgid "Neighborhood points"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:342 ../gui/wxpython/menustrings.py:1284
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:336
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1262
+msgid "Neighborhood analysis tool for vector point maps. Makes each cell value a function of the attribute values assigned to the vector points or centroids around it, and stores new cell values in an output raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:343 ../gui/wxpython/menustrings.py:1285
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:337
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1263
+msgid "Overlay rasters"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:344 ../gui/wxpython/menustrings.py:1286
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:338
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1264
+msgid "Cross product"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:345 ../gui/wxpython/menustrings.py:1287
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:339
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1265
+msgid "Creates a cross product of the category values from multiple raster map layers."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:346 ../gui/wxpython/menustrings.py:1288
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:340
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1266
+msgid "Patch raster maps"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:347 ../gui/wxpython/menustrings.py:1289
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:341
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1267
+msgid "Creates a composite raster map layer by using known category values from one (or more) map layer(s) to fill in areas of \"no data\" in another map layer."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:348 ../gui/wxpython/menustrings.py:1290
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:342
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1268
+msgid "Raster series aggregation"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:349 ../gui/wxpython/menustrings.py:1291
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:343
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1269
+msgid "Makes each output cell value a function of the values assigned to the corresponding cells in the input raster map layers."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:350 ../gui/wxpython/menustrings.py:1292
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:344
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1270
+msgid "Raster series accumulation"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:351 ../gui/wxpython/menustrings.py:1293
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:345
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1271
+msgid "Makes each output cell value a accumulationfunction of the values assigned to the corresponding cells in the input raster map layers."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:352 ../gui/wxpython/menustrings.py:1294
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:346
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1272
+msgid "Statistical overlay"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:353 ../gui/wxpython/menustrings.py:1295
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:347
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1273
+msgid "Calculates category or object oriented statistics (accumulator-based statistics)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:354 ../gui/wxpython/menustrings.py:1296
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:348
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1274
+msgid "Quantiles overlay"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:355 ../gui/wxpython/menustrings.py:1297
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:349
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1275
+msgid "Compute category quantiles using two passes."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:356 ../gui/wxpython/menustrings.py:1298
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:350
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1276
+msgid "Solar radiance and shadows"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:357 ../gui/wxpython/menustrings.py:1299
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:351
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1277
+msgid "LatLong map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:358 ../gui/wxpython/menustrings.py:1300
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:352
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1278
+msgid "Creates a latitude/longitude raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:359 ../gui/wxpython/menustrings.py:1301
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:353
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1279
+msgid "Solar irradiance and irradiation"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:360 ../gui/wxpython/menustrings.py:1302
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:354
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1280
+msgid "Solar irradiance and irradiation model. Computes direct (beam), diffuse and reflected solar irradiation raster maps for given day, latitude, surface and atmospheric conditions. Solar parameters (e.g. sunrise, sunset times, declination, extraterrestrial irradiance, daylight length) are saved in the map history file. Alternatively, a local time can be specified to compute solar incidence angle and/or irradiance raster maps. The shadowing effect of the topography is optionally incorporated."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:361 ../gui/wxpython/menustrings.py:1303
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:355
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1281
+msgid "Shadows map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:362 ../gui/wxpython/menustrings.py:1304
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:356
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1282
+msgid "Calculates cast shadow areas from sun position and elevation raster map. Either exact sun position (A) is specified, or date/time to calculate the sun position (B) by r.sunmask itself."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:363 ../gui/wxpython/menustrings.py:1305
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:357
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1283
+msgid "Sunshine hours and solar angles"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:364 ../gui/wxpython/menustrings.py:1306
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:358
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1284
+msgid "Calculates solar elevation, solar azimuth, and sun hours. Solar elevation: the angle between the direction of the geometric center of the sun's apparent disk and the (idealized) horizon. Solar azimuth: the angle from due north in clockwise direction."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:365 ../gui/wxpython/menustrings.py:1307
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:359
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1285
+msgid "Terrain analysis"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:366 ../gui/wxpython/menustrings.py:1308
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:360
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1286
+msgid "Generate contour lines"
+msgstr "Szintvonalak generálása"
+#: ../gui/wxpython/menustrings.py:367 ../gui/wxpython/menustrings.py:1309
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:361
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1287
+msgid "Produces a vector map of specified contours from a raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:368 ../gui/wxpython/menustrings.py:1310
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:362
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1288
+msgid "Cost surface"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:369 ../gui/wxpython/menustrings.py:1311
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:363
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1289
+msgid "Creates a raster map showing the cumulative cost of moving between different geographic locations on an input raster map whose cell category values represent cost."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:370 ../gui/wxpython/menustrings.py:1312
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:364
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1290
+msgid "Cumulative movement costs"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:371 ../gui/wxpython/menustrings.py:1313
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:365
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1291
+msgid "Creates a raster map showing the anisotropic cumulative cost of moving between different geographic locations on an input raster map whose cell category values represent cost."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:372 ../gui/wxpython/menustrings.py:1314
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:366
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1292
+msgid "Least cost route or flow"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:373 ../gui/wxpython/menustrings.py:1315
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:367
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1293
+msgid "Traces a flow through an elevation model or cost surface on a raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:374 ../gui/wxpython/menustrings.py:1316
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:368
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1294
+msgid "Compute shaded relief"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:375 ../gui/wxpython/menustrings.py:1317
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:369
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1295
+msgid "Creates shaded relief map from an elevation map (DEM). "
+msgstr ""
+#: ../gui/wxpython/menustrings.py:376 ../gui/wxpython/menustrings.py:1318
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:370
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1296
+msgid "Apply shade to raster"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:377 ../gui/wxpython/menustrings.py:1319
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:371
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1297
+msgid "Drapes a color raster over an shaded relief or aspect map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:378 ../gui/wxpython/menustrings.py:1320
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:372
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1298
+msgid "Slope and aspect"
+msgstr "Lejtő és kitettség"
+#: ../gui/wxpython/menustrings.py:379 ../gui/wxpython/menustrings.py:1321
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:373
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1299
+msgid "Generates raster maps of slope, aspect, curvatures and partial derivatives from an elevation raster map. Aspect is calculated counterclockwise from east."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:380 ../gui/wxpython/menustrings.py:1322
+msgid "Landforms"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:381 ../gui/wxpython/menustrings.py:1323
+msgid "Calculates geomorphons (terrain forms) and associated geometry using machine vision approach."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:382 ../gui/wxpython/menustrings.py:1324
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:374
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1300
+msgid "Terrain parameters"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:383 ../gui/wxpython/menustrings.py:1325
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:375
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1301
+msgid "Extracts terrain parameters from a DEM. Uses a multi-scale approach by taking fitting quadratic parameters to any size window (via least squares)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:384 ../gui/wxpython/menustrings.py:1326
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:376
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1302
+msgid "Textural features"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:385 ../gui/wxpython/menustrings.py:1327
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:377
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1303
+msgid "Generate images with textural features from a raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:386 ../gui/wxpython/menustrings.py:1328
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:378
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1304
+msgid "Visibility"
+msgstr "Láthatóság"
+#: ../gui/wxpython/menustrings.py:387 ../gui/wxpython/menustrings.py:1329
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:379
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1305
+msgid "Computes the viewshed of a point on an elevation raster map. Default format: NULL (invisible), vertical angle wrt viewpoint (visible)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:390 ../gui/wxpython/menustrings.py:1332
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:382
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1308
+msgid "Horizon angle"
+msgstr "Vízszintes szög"
+#: ../gui/wxpython/menustrings.py:391 ../gui/wxpython/menustrings.py:1333
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:383
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1309
+msgid "Computes horizon angle height from a digital elevation model. The module has two different modes of operation: 1. Computes the entire horizon around a single point whose coordinates are given with the 'coord' option. The horizon height (in radians). 2. Computes one or more raster maps of the horizon height in a single direction. The input for this is the angle (in degrees), which is measured counterclockwise with east=0, north=90 etc. The output is the horizon height in radians."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:392 ../gui/wxpython/menustrings.py:1334
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:384
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1310
+msgid "Transform features"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:393 ../gui/wxpython/menustrings.py:1335
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:385
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1311
+msgid "Clump"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:394 ../gui/wxpython/menustrings.py:1336
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:386
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1312
+msgid "Recategorizes data in a raster map by grouping cells that form physically discrete areas into unique categories."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:395 ../gui/wxpython/menustrings.py:1337
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:387
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1313
+msgid "Grow"
+msgstr "Növel"
+#: ../gui/wxpython/menustrings.py:397 ../gui/wxpython/menustrings.py:1339
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:389
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1315
+msgid "Thin"
+msgstr "Vékonyít"
+#: ../gui/wxpython/menustrings.py:398 ../gui/wxpython/menustrings.py:1340
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:390
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1316
+msgid "Thins non-null cells that denote linear features in a raster map layer."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:399 ../gui/wxpython/menustrings.py:1341
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:391
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1317
+msgid "Hydrologic modeling"
+msgstr "Hidrológiai modellezés"
+#: ../gui/wxpython/menustrings.py:400 ../gui/wxpython/menustrings.py:1342
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:392
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1318
+msgid "Carve stream channels"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:401 ../gui/wxpython/menustrings.py:1343
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:393
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1319
+msgid "Generates stream channels. Takes vector stream data, transforms it to raster and subtracts depth from the output DEM."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:402 ../gui/wxpython/menustrings.py:1344
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:394
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1320
+msgid "Fill lake"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:403 ../gui/wxpython/menustrings.py:1345
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:395
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1321
+msgid "Fills lake at given point to given level."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:404 ../gui/wxpython/menustrings.py:1346
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:396
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1322
+msgid "Depressionless map and flowlines"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:405 ../gui/wxpython/menustrings.py:1347
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:397
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1323
+msgid "Filters and generates a depressionless elevation map and a flow direction map from a given elevation raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:406 ../gui/wxpython/menustrings.py:1348
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:398
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1324
+msgid "Flow accumulation"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:407 ../gui/wxpython/menustrings.py:1349
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:399
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1325
+msgid "Performs flow computation for massive grids."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:408 ../gui/wxpython/menustrings.py:1350
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:400
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1326
+msgid "Flow lines"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:409 ../gui/wxpython/menustrings.py:1351
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:401
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1327
+msgid "Constructs flowlines. Computes flowlines, flowpath lengths, and flowaccumulation (contributing areas) from a elevation raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:410 ../gui/wxpython/menustrings.py:1352
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:402
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1328
+msgid "Watershed analysis"
+msgstr "Vízgyűjtő elemzés"
+#: ../gui/wxpython/menustrings.py:411 ../gui/wxpython/menustrings.py:1353
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:403
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1329
+msgid "Calculates hydrological parameters and RUSLE factors."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:412 ../gui/wxpython/menustrings.py:1354
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:404
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1330
+msgid "Watershed subbasins"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:413 ../gui/wxpython/menustrings.py:1355
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:405
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1331
+msgid "Generates watershed subbasins raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:414 ../gui/wxpython/menustrings.py:1356
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:406
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1332
+msgid "Watershed basin creation"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:415 ../gui/wxpython/menustrings.py:1357
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:407
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1333
+msgid "Creates watershed basins from a drainage direction map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:416 ../gui/wxpython/menustrings.py:1358
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:408
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1334
+msgid "Extraction of stream networks"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:417 ../gui/wxpython/menustrings.py:1359
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:409
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1335
+msgid "Performs stream network extraction."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:418 ../gui/wxpython/menustrings.py:1360
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:410
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1336
+msgid "SIMWE Overland flow modeling"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:419 ../gui/wxpython/menustrings.py:1361
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:411
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1337
+msgid "Overland flow hydrologic simulation using path sampling method (SIMWE)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:420 ../gui/wxpython/menustrings.py:1362
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:412
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1338
+msgid "SIMWE Sediment flux modeling"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:421 ../gui/wxpython/menustrings.py:1363
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:413
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1339
+msgid "Sediment transport and erosion/deposition simulation using path sampling method (SIMWE)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:422 ../gui/wxpython/menustrings.py:1364
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:414
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1340
+msgid "Topographic index map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:423 ../gui/wxpython/menustrings.py:1365
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:415
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1341
+msgid "Creates a topographic index (wetness index) raster map from an elevation raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:424 ../gui/wxpython/menustrings.py:1366
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:416
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1342
+msgid "TOPMODEL simulation"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:425 ../gui/wxpython/menustrings.py:1367
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:417
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1343
+msgid "Simulates TOPMODEL which is a physically based hydrologic model."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:426 ../gui/wxpython/menustrings.py:1368
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:418
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1344
+msgid "USLE K-factor"
+msgstr "USLE K-faktor"
+#: ../gui/wxpython/menustrings.py:427 ../gui/wxpython/menustrings.py:1369
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:419
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1345
+msgid "Computes USLE Soil Erodibility Factor (K)."
+msgstr "USLE talajerózió faktor (K) számítás."
+#: ../gui/wxpython/menustrings.py:428 ../gui/wxpython/menustrings.py:1370
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:420
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1346
+msgid "USLE R-factor"
+msgstr "USLE R-faktor"
+#: ../gui/wxpython/menustrings.py:429 ../gui/wxpython/menustrings.py:1371
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:421
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1347
+msgid "Computes USLE R factor, Rainfall erosivity index."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:430 ../gui/wxpython/menustrings.py:877
+#: ../gui/wxpython/menustrings.py:1372 ../gui/wxpython/menustrings.py:1819
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:422
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:860
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1348
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1786
+msgid "Groundwater modeling"
+msgstr "Talajvíz modellezés"
+#: ../gui/wxpython/menustrings.py:431 ../gui/wxpython/menustrings.py:1373
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:423
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1349
+msgid "Groundwater flow"
+msgstr "Talajvíz áramlás"
+#: ../gui/wxpython/menustrings.py:432 ../gui/wxpython/menustrings.py:1374
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:424
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1350
+msgid "Numerical calculation program for transient, confined and unconfined groundwater flow in two dimensions."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:433 ../gui/wxpython/menustrings.py:1375
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:425
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1351
+msgid "Groundwater solute transport"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:434 ../gui/wxpython/menustrings.py:1376
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:426
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1352
+msgid "Numerical calculation program for transient, confined and unconfined solute transport in two dimensions"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:435 ../gui/wxpython/menustrings.py:1377
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:427
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1353
+msgid "Landscape patch analysis"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:436 ../gui/wxpython/menustrings.py:1378
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:428
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1354
+msgid "Set up sampling and analysis framework"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:437 ../gui/wxpython/menustrings.py:1379
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:429
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1355
+msgid "Configuration editor for r.li.'index'"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:438 ../gui/wxpython/menustrings.py:1380
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:430
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1356
+msgid "Edge density"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:439 ../gui/wxpython/menustrings.py:1381
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:431
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1357
+msgid "Calculates edge density index on a raster map, using a 4 neighbour algorithm"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:440 ../gui/wxpython/menustrings.py:1382
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:432
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1358
+msgid "Contrast weighted edge density"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:441 ../gui/wxpython/menustrings.py:1383
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:433
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1359
+msgid "Calculates contrast weighted edge density index on a raster map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:442 ../gui/wxpython/menustrings.py:1384
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:434
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1360
+msgid "Patch area mean"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:443 ../gui/wxpython/menustrings.py:1385
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:435
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1361
+msgid "Calculates mean patch size index on a raster map, using a 4 neighbour algorithm"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:444 ../gui/wxpython/menustrings.py:1386
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:436
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1362
+msgid "Patch area range"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:445 ../gui/wxpython/menustrings.py:1387
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:437
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1363
+msgid "Calculates range of patch area size on a raster map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:446 ../gui/wxpython/menustrings.py:1388
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:438
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1364
+msgid "Patch area Std Dev"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:447 ../gui/wxpython/menustrings.py:1389
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:439
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1365
+msgid "Calculates standard deviation of patch area a raster map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:448 ../gui/wxpython/menustrings.py:1390
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:440
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1366
+msgid "Patch area Coeff Var"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:449 ../gui/wxpython/menustrings.py:1391
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:441
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1367
+msgid "Calculates coefficient of variation of patch area on a raster map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:450 ../gui/wxpython/menustrings.py:1392
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:442
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1368
+msgid "Patch density"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:451 ../gui/wxpython/menustrings.py:1393
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:443
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1369
+msgid "Calculates patch density index on a raster map, using a 4 neighbour algorithm"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:452 ../gui/wxpython/menustrings.py:1394
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:444
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1370
+msgid "Patch number"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:453 ../gui/wxpython/menustrings.py:1395
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:445
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1371
+msgid "Calculates patch number index on a raster map, using a 4 neighbour algorithm."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:454 ../gui/wxpython/menustrings.py:1396
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:446
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1372
+msgid "Dominance's diversity"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:455 ../gui/wxpython/menustrings.py:1397
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:447
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1373
+msgid "Calculates dominance's diversity index on a raster map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:456 ../gui/wxpython/menustrings.py:1398
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:448
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1374
+msgid "Shannon's diversity"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:457 ../gui/wxpython/menustrings.py:1399
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:449
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1375
+msgid "Calculates Shannon's diversity index on a raster map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:458 ../gui/wxpython/menustrings.py:1400
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:450
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1376
+msgid "Simpson's diversity"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:459 ../gui/wxpython/menustrings.py:1401
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:451
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1377
+msgid "Calculates Simpson's diversity index on a raster map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:460 ../gui/wxpython/menustrings.py:1402
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:452
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1378
+msgid "Richness"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:461 ../gui/wxpython/menustrings.py:1403
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:453
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1379
+msgid "Calculates richness index on a raster map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:462 ../gui/wxpython/menustrings.py:1404
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:454
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1380
+msgid "Shape index"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:463 ../gui/wxpython/menustrings.py:1405
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:455
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1381
+msgid "Calculates shape index on a raster map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:464 ../gui/wxpython/menustrings.py:1406
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:456
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1382
+msgid "Wildfire modeling"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:465 ../gui/wxpython/menustrings.py:1407
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:457
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1383
+msgid "Rate of spread"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:466 ../gui/wxpython/menustrings.py:1408
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:458
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1384
+msgid "Generates rate of spread raster maps. Generates three, or four raster map layers showing the base (perpendicular) rate of spread (ROS), the maximum (forward) ROS, the direction of the maximum ROS, and optionally the maximum potential spotting distance for fire spread simulation."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:467 ../gui/wxpython/menustrings.py:1409
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:459
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1385
+msgid "Least-cost spread paths"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:468 ../gui/wxpython/menustrings.py:1410
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:460
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1386
+msgid "Recursively traces the least cost path backwards to cells from which the cumulative cost was determined."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:469 ../gui/wxpython/menustrings.py:1411
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:461
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1387
+msgid "Anisotropic spread simulation"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:470 ../gui/wxpython/menustrings.py:1412
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:462
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1388
+msgid "Simulates elliptically anisotropic spread. Generates a raster map of the cumulative time of spread, given raster maps containing the rates of spread (ROS), the ROS directions and the spread origins. It optionally produces raster maps to contain backlink UTM coordinates for tracing spread paths. Usable for fire spread simulations."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:471 ../gui/wxpython/menustrings.py:1413
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:463
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1389
+msgid "Change category values and labels"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:472 ../gui/wxpython/menustrings.py:522
+#: ../gui/wxpython/menustrings.py:1414 ../gui/wxpython/menustrings.py:1464
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:464
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:514
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1390
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1440
+msgid "Manage category information"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:473 ../gui/wxpython/menustrings.py:523
+#: ../gui/wxpython/menustrings.py:1415 ../gui/wxpython/menustrings.py:1465
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:465
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:515
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1391
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1441
+msgid "Manages category values and labels associated with user-specified raster map layers."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:474 ../gui/wxpython/menustrings.py:1416
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:466
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1392
+msgid "Interactively edit category values"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:475 ../gui/wxpython/menustrings.py:1417
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:467
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1393
+msgid "Edits cell values in a raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:476 ../gui/wxpython/menustrings.py:1418
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:468
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1394
+msgid "Reclassify by size"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:477 ../gui/wxpython/menustrings.py:1419
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:469
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1395
+msgid "Reclasses a raster map greater or less than user specified area size (in hectares)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:478 ../gui/wxpython/menustrings.py:697
+#: ../gui/wxpython/menustrings.py:1420 ../gui/wxpython/menustrings.py:1639
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:470
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:687
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1396
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1613
+msgid "Reclassify"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:479 ../gui/wxpython/menustrings.py:1421
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:471
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1397
+msgid "Reclassify raster map based on category values. Creates a new raster map whose category values are based upon a reclassification of the categories in an existing raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:480 ../gui/wxpython/menustrings.py:1422
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:472
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1398
+msgid "Recode"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:481 ../gui/wxpython/menustrings.py:1423
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:473
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1399
+msgid "Recodes categorical raster maps."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:482 ../gui/wxpython/menustrings.py:1424
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:474
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1400
+msgid "Rescale"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:483 ../gui/wxpython/menustrings.py:1425
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:475
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1401
+msgid "Rescales the range of category values in a raster map layer."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:484 ../gui/wxpython/menustrings.py:1426
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:476
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1402
+msgid "Rescale with histogram"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:485 ../gui/wxpython/menustrings.py:1427
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:477
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1403
+msgid "Rescales histogram equalized the range of category values in a raster map layer."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:486 ../gui/wxpython/menustrings.py:1428
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:478
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1404
+msgid "Generate random cells"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:487 ../gui/wxpython/menustrings.py:1429
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:479
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1405
+msgid "Random cells"
+msgstr "Véletlen cellák"
+#: ../gui/wxpython/menustrings.py:488 ../gui/wxpython/menustrings.py:1430
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:480
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1406
+msgid "Generates random cell values with spatial dependence."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:489 ../gui/wxpython/menustrings.py:1431
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:481
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1407
+msgid "Random cells and vector points"
+msgstr "Véletlen cellák és raszter pontok"
+#: ../gui/wxpython/menustrings.py:490 ../gui/wxpython/menustrings.py:1432
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:482
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1408
+msgid "Creates a raster map layer and vector point map containing randomly located points."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:491 ../gui/wxpython/menustrings.py:1433
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:483
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1409
+msgid "Generate surfaces"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:492 ../gui/wxpython/menustrings.py:1434
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:484
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1410
+msgid "Fractal surface"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:493 ../gui/wxpython/menustrings.py:1435
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:485
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1411
+msgid "Creates a fractal surface of a given fractal dimension."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:494 ../gui/wxpython/menustrings.py:1436
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:486
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1412
+msgid "Gaussian kernel density surface"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:495 ../gui/wxpython/menustrings.py:1437
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:487
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1413
+msgid "Generates a raster density map from vector points map. Density is computed using a moving kernel. Optionally generates a vector density map on a vector network."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:496 ../gui/wxpython/menustrings.py:1438
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:488
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1414
+msgid "Gaussian deviates surface"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:497 ../gui/wxpython/menustrings.py:1439
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:489
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1415
+msgid "Generates a raster map using gaussian random number generator. Mean and standard deviation of gaussian deviates can be expressed by the user."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:498 ../gui/wxpython/menustrings.py:1440
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:490
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1416
+#: ../gui/wxpython/nviz/tools.py:5181
+msgid "Plane"
+msgstr "Sík"
+#: ../gui/wxpython/menustrings.py:499 ../gui/wxpython/menustrings.py:1441
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:491
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1417
+msgid "Creates raster plane map given dip (inclination), aspect (azimuth) and one point."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:500 ../gui/wxpython/menustrings.py:1442
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:492
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1418
+msgid "Random deviates surface"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:501 ../gui/wxpython/menustrings.py:1443
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:493
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1419
+msgid "Produces a raster surface map of uniform random deviates with defined range."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:502 ../gui/wxpython/menustrings.py:1444
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:494
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1420
+msgid "Random surface with spatial dependence"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:503 ../gui/wxpython/menustrings.py:1445
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:495
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1421
+msgid "Generates random surface(s) with spatial dependence."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:504 ../gui/wxpython/menustrings.py:1446
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:496
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1422
+msgid "Interpolate surfaces"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:505 ../gui/wxpython/menustrings.py:1447
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:497
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1423
+msgid "Bilinear and bicubic from vector points"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:506 ../gui/wxpython/menustrings.py:1448
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:498
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1424
+msgid "Performs bicubic or bilinear spline interpolation with Tykhonov regularization."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:507 ../gui/wxpython/menustrings.py:1449
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:499
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1425
+msgid "IDW from raster points"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:508 ../gui/wxpython/menustrings.py:1450
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:500
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1426
+msgid "Provides surface interpolation from raster point data by Inverse Distance Squared Weighting."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:509 ../gui/wxpython/menustrings.py:1451
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:501
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1427
+msgid "IDW from vector points"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:510 ../gui/wxpython/menustrings.py:1452
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:502
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1428
+msgid "Provides surface interpolation from vector point data by Inverse Distance Squared Weighting."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:511 ../gui/wxpython/menustrings.py:1453
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:503
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1429
+msgid "Raster contours"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:512 ../gui/wxpython/menustrings.py:1454
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:504
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1430
+msgid "Generates surface raster map from rasterized contours."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:513 ../gui/wxpython/menustrings.py:1455
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:505
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1431
+msgid "Regularized spline tension"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:514 ../gui/wxpython/menustrings.py:1456
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:506
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1432
+msgid "Performs surface interpolation from vector points map by splines. Spatial approximation and topographic analysis from given point or isoline data in vector format to floating point raster format using regularized spline with tension."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:515 ../gui/wxpython/menustrings.py:1457
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:507
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1433
+msgid "Raster series interpolation"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:516 ../gui/wxpython/menustrings.py:1458
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:508
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1434
+msgid "Interpolates raster maps located (temporal or spatial) in between input raster maps at specific sampling positions."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:517 ../gui/wxpython/menustrings.py:1459
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:509
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1435
+msgid "Fill NULL cells"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:518 ../gui/wxpython/menustrings.py:1460
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:510
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1436
+msgid "Fills no-data areas in raster maps using spline interpolation."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:519 ../gui/wxpython/menustrings.py:736
+#: ../gui/wxpython/menustrings.py:853 ../gui/wxpython/menustrings.py:881
+#: ../gui/wxpython/menustrings.py:1025 ../gui/wxpython/menustrings.py:1461
+#: ../gui/wxpython/menustrings.py:1678 ../gui/wxpython/menustrings.py:1795
+#: ../gui/wxpython/menustrings.py:1823 ../gui/wxpython/menustrings.py:1967
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:511
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:726
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:836
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1008
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1437
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1652
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1762
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1934
+msgid "Reports and statistics"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:520 ../gui/wxpython/menustrings.py:1462
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:512
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1438
+msgid "Basic raster metadata"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:521 ../gui/wxpython/menustrings.py:1463
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:513
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1439
+msgid "Outputs basic information about a raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:524 ../gui/wxpython/menustrings.py:1466
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:516
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1442
+msgid "General statistics"
+msgstr "Általános statisztika"
+#: ../gui/wxpython/menustrings.py:525 ../gui/wxpython/menustrings.py:1467
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:517
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1443
+msgid "Generates area statistics for raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:526 ../gui/wxpython/menustrings.py:1468
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:518
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1444
+msgid "Quantiles for large data sets"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:527 ../gui/wxpython/menustrings.py:1469
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:519
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1445
+msgid "Compute quantiles using two passes."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:528 ../gui/wxpython/menustrings.py:1470
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:520
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1446
+msgid "Range of category values"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:529 ../gui/wxpython/menustrings.py:1471
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:521
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1447
+msgid "Prints terse list of category values found in a raster map layer."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:530 ../gui/wxpython/menustrings.py:1472
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:522
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1448
+msgid "Sum area by raster map and category"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:531 ../gui/wxpython/menustrings.py:1473
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:523
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1449
+msgid "Reports statistics for raster maps."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:532 ../gui/wxpython/menustrings.py:1474
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:524
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1450
+msgid "Statistics for clumped cells"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:533 ../gui/wxpython/menustrings.py:1475
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:525
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1451
+msgid "Calculates the volume of data \"clumps\". Optionally produces a GRASS vector points map containing the calculated centroids of these clumps."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:534 ../gui/wxpython/menustrings.py:1476
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:526
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1452
+msgid "Total corrected area"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:535 ../gui/wxpython/menustrings.py:1477
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:527
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1453
+msgid "Prints estimation of surface area for raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:536 ../gui/wxpython/menustrings.py:1478
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:528
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1454
+#: ../gui/wxpython/lmgr/layertree.py:804 ../gui/wxpython/lmgr/layertree.py:860
+msgid "Univariate raster statistics"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:537 ../gui/wxpython/menustrings.py:1479
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:529
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1455
+msgid "Calculates univariate statistics from the non-null cells of a raster map. Statistics include number of cells counted, minimum and maximum cell values, range, arithmetic mean, population variance, standard deviation, coefficient of variation, and sum."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:538 ../gui/wxpython/menustrings.py:747
+#: ../gui/wxpython/menustrings.py:1480 ../gui/wxpython/menustrings.py:1689
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:530
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1456
+msgid "Sample transects"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:539 ../gui/wxpython/menustrings.py:1481
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:531
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1457
+msgid "Outputs the raster map layer values lying on user-defined line(s)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:540 ../gui/wxpython/menustrings.py:1482
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:532
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1458
+msgid "Sample transects (bearing/distance)"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:541 ../gui/wxpython/menustrings.py:1483
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:533
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1459
+msgid "Outputs raster map layer values lying along user defined transect line(s)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:542 ../gui/wxpython/menustrings.py:1484
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:534
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1460
+msgid "Covariance/correlation"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:543 ../gui/wxpython/menustrings.py:1485
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:535
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1461
+msgid "Outputs a covariance/correlation matrix for user-specified raster map layer(s)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:544 ../gui/wxpython/menustrings.py:1486
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:536
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1462
+msgid "Linear regression"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:545 ../gui/wxpython/menustrings.py:1487
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:537
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1463
+msgid "Calculates linear regression from two raster maps: y = a + b*x."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:546 ../gui/wxpython/menustrings.py:1488
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:538
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1464
+msgid "Multiple regression"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:547 ../gui/wxpython/menustrings.py:1489
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:539
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1465
+msgid "Calculates multiple linear regression from raster maps."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:548 ../gui/wxpython/menustrings.py:1490
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:540
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1466
+msgid "Mutual category occurrences"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:549 ../gui/wxpython/menustrings.py:1491
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:541
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1467
+msgid "Tabulates the mutual occurrence (coincidence) of categories for two raster map layers."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:550 ../gui/wxpython/menustrings.py:1492
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:542
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1468
+msgid "&Vector"
+msgstr "&Vektor"
+#: ../gui/wxpython/menustrings.py:551 ../gui/wxpython/menustrings.py:1493
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:543
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1469
+msgid "Develop vector map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:552 ../gui/wxpython/menustrings.py:1494
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:544
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1470
+#: ../gui/wxpython/gui_core/dialogs.py:264
+#: ../gui/wxpython/gui_core/dialogs.py:402
+msgid "Create new vector map"
+msgstr "Új vektor térkép létrehozás"
+#: ../gui/wxpython/menustrings.py:553 ../gui/wxpython/menustrings.py:1495
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:545
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1471
+msgid "Create new empty vector map"
+msgstr "Új üres vektor térkép létrehozás"
+#: ../gui/wxpython/menustrings.py:554 ../gui/wxpython/menustrings.py:1496
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:546
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1472
+msgid "Edit vector map (non-interactively)"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:555 ../gui/wxpython/menustrings.py:1497
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:547
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1473
+msgid "Edits a vector map, allows adding, deleting and modifying selected vector features."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:556 ../gui/wxpython/menustrings.py:1498
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:548
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1474
+msgid "Convert object types"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:557 ../gui/wxpython/menustrings.py:1499
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:549
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1475
+msgid "Changes type of vector features."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:558 ../gui/wxpython/menustrings.py:1500
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:550
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1476
+msgid "Parallel lines"
+msgstr "Párhuzamos vonalak"
+#: ../gui/wxpython/menustrings.py:559 ../gui/wxpython/menustrings.py:1501
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:551
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1477
+msgid "Creates parallel line to input vector lines."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:560 ../gui/wxpython/menustrings.py:1502
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:552
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1478
+msgid "Dissolve boundaries"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:561 ../gui/wxpython/menustrings.py:1503
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:553
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1479
+msgid "Dissolves boundaries between adjacent areas sharing a common category number or attribute."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:562 ../gui/wxpython/menustrings.py:1504
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:554
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1480
+msgid "Create 3D vector over raster"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:563 ../gui/wxpython/menustrings.py:1505
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:555
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1481
+msgid "Converts 2D vector features to 3D by sampling of elevation raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:564 ../gui/wxpython/menustrings.py:1506
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:556
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1482
+msgid "Extrude 3D vector map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:565 ../gui/wxpython/menustrings.py:1507
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:557
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1483
+msgid "Extrudes flat vector features to 3D vector features with defined height. Optionally the height can be derived from sampling of elevation raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:566 ../gui/wxpython/menustrings.py:1508
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:558
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1484
+msgid "Create labels"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:567 ../gui/wxpython/menustrings.py:1509
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:559
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1485
+msgid "Creates paint labels for a vector map from attached attributes."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:568 ../gui/wxpython/menustrings.py:1510
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:560
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1486
+msgid "Reposition vector map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:569 ../gui/wxpython/menustrings.py:1511
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:561
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1487
+msgid "Performs an affine transformation (shift, scale and rotate) on vector map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:570 ../gui/wxpython/menustrings.py:1512
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:562
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1488
+msgid "Rectify vector map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:571 ../gui/wxpython/menustrings.py:1513
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:563
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1489
+msgid "Rectifies a vector by computing a coordinate transformation for each object in the vector based on the control points."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:575 ../gui/wxpython/menustrings.py:1517
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:567
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1493
+msgid "Updates vector map metadata."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:576 ../gui/wxpython/menustrings.py:1518
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:568
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1494
+msgid "Topology maintenance"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:577 ../gui/wxpython/menustrings.py:1519
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:569
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1495
+msgid "Create or rebuild topology"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:578 ../gui/wxpython/menustrings.py:1520
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:570
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1496
+msgid "Creates topology for vector map. Optionally also checks for topological errors."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:579 ../gui/wxpython/menustrings.py:1521
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:571
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1497
+msgid "Rebuild topology on all vector maps"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:580 ../gui/wxpython/menustrings.py:1522
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:572
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1498
+msgid "Rebuilds topology on all vector maps in the current mapset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:581 ../gui/wxpython/menustrings.py:1523
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:573
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1499
+msgid "Build polylines"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:582 ../gui/wxpython/menustrings.py:1524
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:574
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1500
+msgid "Builds polylines from lines or boundaries."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:583 ../gui/wxpython/menustrings.py:1525
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:575
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1501
+msgid "Split lines"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:584 ../gui/wxpython/menustrings.py:1526
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:576
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1502
+msgid "Splits vector lines to shorter segments."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:585 ../gui/wxpython/menustrings.py:1527
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:577
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1503
+msgid "Split polylines"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:586 ../gui/wxpython/menustrings.py:1528
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:578
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1504
+msgid "Creates points/segments from input vector lines and positions."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:587 ../gui/wxpython/menustrings.py:1529
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:579
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1505
+msgid "Clean vector map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:588 ../gui/wxpython/menustrings.py:1530
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:580
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1506
+msgid "Toolset for cleaning topology of vector map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:589 ../gui/wxpython/menustrings.py:1531
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:581
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1507
+msgid "Smooth or simplify"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:590 ../gui/wxpython/menustrings.py:1532
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:582
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1508
+msgid "Performs vector based generalization."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:591 ../gui/wxpython/menustrings.py:1533
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:583
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1509
+msgid "Add centroids"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:592 ../gui/wxpython/menustrings.py:1534
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:584
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1510
+msgid "Adds missing centroids to closed boundaries."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:595 ../gui/wxpython/menustrings.py:1537
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:587
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1513
+msgid "Creates/modifies the color table associated with a vector map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:597 ../gui/wxpython/menustrings.py:1539
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:589
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1515
+msgid "Interactive management of vector color tables."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:599 ../gui/wxpython/menustrings.py:1541
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:591
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1517
+msgid "Exports the color table associated with a vector map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:600 ../gui/wxpython/menustrings.py:1542
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:592
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1518
+msgid "Query vector map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:601 ../gui/wxpython/menustrings.py:1543
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:593
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1519
+msgid "Query with coordinate(s)"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:602 ../gui/wxpython/menustrings.py:1544
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:594
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1520
+msgid "Queries a vector map at given locations."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:603 ../gui/wxpython/menustrings.py:920
+#: ../gui/wxpython/menustrings.py:1545 ../gui/wxpython/menustrings.py:1862
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:595
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:903
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1521
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1829
+msgid "Query vector attribute data"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:604 ../gui/wxpython/menustrings.py:921
+#: ../gui/wxpython/menustrings.py:1546 ../gui/wxpython/menustrings.py:1863
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:596
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:904
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1522
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1830
+msgid "Prints vector map attributes."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:605 ../gui/wxpython/menustrings.py:1547
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:597
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1523
+msgid "Feature selection"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:606 ../gui/wxpython/menustrings.py:1548
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:598
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1524
+msgid "Select by attributes"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:607 ../gui/wxpython/menustrings.py:1549
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:599
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1525
+msgid "Selects vector features from an existing vector map and creates a new vector map containing only the selected features."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:608 ../gui/wxpython/menustrings.py:1550
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:600
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1526
+msgid "Select by another map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:609 ../gui/wxpython/menustrings.py:1551
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:601
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1527
+msgid "Selects features from vector map (A) by features from other vector map (B)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:617 ../gui/wxpython/menustrings.py:1559
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:609
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1535
+msgid "Buffer vectors"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:618 ../gui/wxpython/menustrings.py:1560
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:610
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1536
+msgid "Creates a buffer around vector features of given type."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:619 ../gui/wxpython/menustrings.py:1561
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:611
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1537
+msgid "Point analysis"
+msgstr "Pont elemzés"
+#: ../gui/wxpython/menustrings.py:620 ../gui/wxpython/menustrings.py:633
+#: ../gui/wxpython/menustrings.py:1562 ../gui/wxpython/menustrings.py:1575
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:612
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:625
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1538
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1551
+msgid "Identify and remove outliers"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:621 ../gui/wxpython/menustrings.py:634
+#: ../gui/wxpython/menustrings.py:733 ../gui/wxpython/menustrings.py:1563
+#: ../gui/wxpython/menustrings.py:1576 ../gui/wxpython/menustrings.py:1675
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:613
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:626
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:723
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1539
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1552
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1649
+msgid "Removes outliers from vector point data."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:622 ../gui/wxpython/menustrings.py:1564
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:614
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1540
+msgid "Identify point clusters"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:623 ../gui/wxpython/menustrings.py:1565
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:615
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1541
+msgid "Performs cluster identification."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:624 ../gui/wxpython/menustrings.py:1566
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:616
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1542
+msgid "Indices for quadrat counts of vector point lists"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:625 ../gui/wxpython/menustrings.py:750
+#: ../gui/wxpython/menustrings.py:1567 ../gui/wxpython/menustrings.py:1692
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:617
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:738
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1543
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1664
+msgid "Indices for quadrat counts of vector point lists."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:626 ../gui/wxpython/menustrings.py:730
+#: ../gui/wxpython/menustrings.py:1568 ../gui/wxpython/menustrings.py:1672
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:618
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:720
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1544
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1646
+msgid "Perturb points"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:627 ../gui/wxpython/menustrings.py:731
+#: ../gui/wxpython/menustrings.py:1569 ../gui/wxpython/menustrings.py:1673
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:619
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:721
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1545
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1647
+msgid "Random location perturbations of vector points."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:628 ../gui/wxpython/menustrings.py:734
+#: ../gui/wxpython/menustrings.py:1570 ../gui/wxpython/menustrings.py:1676
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:620
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:724
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1546
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1650
+msgid "Test/training point sets"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:629 ../gui/wxpython/menustrings.py:735
+#: ../gui/wxpython/menustrings.py:1571 ../gui/wxpython/menustrings.py:1677
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:621
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:725
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1547
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1651
+msgid "Randomly partition points into test/train sets."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:630 ../gui/wxpython/menustrings.py:1572
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:622
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1548
+msgid "Tests for normality for vector points"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:631 ../gui/wxpython/menustrings.py:752
+#: ../gui/wxpython/menustrings.py:1573 ../gui/wxpython/menustrings.py:1694
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:623
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:740
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1549
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1666
+msgid "Tests for normality for vector points."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:632 ../gui/wxpython/menustrings.py:1574
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:624
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1550
+msgid "Lidar analysis"
+msgstr "Lidar elemzés"
+#: ../gui/wxpython/menustrings.py:635 ../gui/wxpython/menustrings.py:1577
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:627
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1553
+msgid "Detect edges"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:636 ../gui/wxpython/menustrings.py:1578
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:628
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1554
+msgid "Detects the object's edges from a LIDAR data set."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:637 ../gui/wxpython/menustrings.py:1579
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:629
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1555
+msgid "Detect interiors"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:638 ../gui/wxpython/menustrings.py:1580
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:630
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1556
+msgid "Building contour determination and Region Growing algorithm for determining the building inside"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:639 ../gui/wxpython/menustrings.py:1581
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:631
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1557
+msgid "Correct and reclassify objects"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:640 ../gui/wxpython/menustrings.py:1582
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:632
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1558
+msgid "Corrects the v.lidar.growing output. It is the last of the three algorithms for LIDAR filtering."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:641 ../gui/wxpython/menustrings.py:1583
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:633
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1559
+msgid "Linear referencing"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:642 ../gui/wxpython/menustrings.py:1584
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:634
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1560
+msgid "Create LRS"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:643 ../gui/wxpython/menustrings.py:1585
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:635
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1561
+msgid "Creates a linear reference system."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:644 ../gui/wxpython/menustrings.py:1586
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:636
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1562
+msgid "Create stationing"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:645 ../gui/wxpython/menustrings.py:1587
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:637
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1563
+msgid "Creates stationing from input lines, and linear reference system."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:646 ../gui/wxpython/menustrings.py:1588
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:638
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1564
+msgid "Create points/segments"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:647 ../gui/wxpython/menustrings.py:1589
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:639
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1565
+msgid "Creates points/segments from input lines, linear reference system and positions read from stdin or a file."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:648 ../gui/wxpython/menustrings.py:1590
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:640
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1566
+msgid "Find line id and offset"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:649 ../gui/wxpython/menustrings.py:1591
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:641
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1567
+msgid "Finds line id and real km+offset for given points in vector map using linear reference system."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:650 ../gui/wxpython/menustrings.py:1592
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:642
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1568
+msgid "Nearest features"
+msgstr "Legközelebbi elemek"
+#: ../gui/wxpython/menustrings.py:651 ../gui/wxpython/menustrings.py:1593
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:643
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1569
+msgid "Finds the nearest element in vector map 'to' for elements in vector map 'from'."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:652 ../gui/wxpython/menustrings.py:1594
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:644
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1570
+msgid "Network analysis"
+msgstr "Hálózat elemzés"
+#: ../gui/wxpython/menustrings.py:653 ../gui/wxpython/menustrings.py:1595
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:645
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1571
+#: ../gui/wxpython/mapdisp/toolbars.py:58
+msgid "Vector network analysis tool"
+msgstr "Vektor hálózat elemző eszköz"
+#: ../gui/wxpython/menustrings.py:654 ../gui/wxpython/menustrings.py:1596
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:646
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1572
+msgid "Tool for interactive vector network analysis."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:655 ../gui/wxpython/menustrings.py:1597
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:647
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1573
+msgid "Network preparation"
+msgstr "Hálózat előkészítés"
+#: ../gui/wxpython/menustrings.py:656 ../gui/wxpython/menustrings.py:1598
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:648
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1574
+msgid "Performs network maintenance."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:657 ../gui/wxpython/menustrings.py:1599
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:649
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1575
+msgid "Allocate subnets"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:658 ../gui/wxpython/menustrings.py:1600
+msgid "Allocates subnets for nearest centers. Center node must be opened (costs >= 0). Costs of center node are used in calculation."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:659 ../gui/wxpython/menustrings.py:1601
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:651
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1577
+msgid "Split net"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:660 ../gui/wxpython/menustrings.py:1602
+msgid "Splits subnets for nearest centers by cost isolines. Splits net to bands between cost isolines (direction from center). Center node must be opened (costs >= 0). Costs of center node are used in calculation."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:661 ../gui/wxpython/menustrings.py:1603
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:653
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1579
+msgid "Shortest path"
+msgstr "Legrövidebb útvonal"
+#: ../gui/wxpython/menustrings.py:662 ../gui/wxpython/menustrings.py:1604
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:654
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1580
+msgid "Finds shortest path on vector network."
+msgstr "Legrövidebb útvonal megtalálása a vektor hálózaton."
+#: ../gui/wxpython/menustrings.py:663 ../gui/wxpython/menustrings.py:1605
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:655
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1581
+msgid "Shortest path for sets of features"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:664 ../gui/wxpython/menustrings.py:1606
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:656
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1582
+msgid "Computes shortest distance via the network between the given sets of features. Finds the shortest paths from each 'from' point to the nearest 'to' feature and various information about this relation are uploaded to the attribute table."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:665 ../gui/wxpython/menustrings.py:1607
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:657
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1583
+msgid "Shortest path using timetables"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:666 ../gui/wxpython/menustrings.py:1608
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:658
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1584
+msgid "Finds shortest path using timetables."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:667 ../gui/wxpython/menustrings.py:1609
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:659
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1585
+msgid "Shortest path for all pairs"
+msgstr "Legrövidebb útvonal minden párra"
+#: ../gui/wxpython/menustrings.py:668 ../gui/wxpython/menustrings.py:1610
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:660
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1586
+msgid "Computes the shortest path between all pairs of nodes in the network."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:669 ../gui/wxpython/menustrings.py:1611
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:661
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1587
+msgid "Visibility network"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:670 ../gui/wxpython/menustrings.py:1612
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:662
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1588
+msgid "Performs visibility graph construction."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:671 ../gui/wxpython/menustrings.py:1613
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:663
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1589
+msgid "Bridges and articulation points"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:672 ../gui/wxpython/menustrings.py:1614
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:664
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1590
+msgid "Computes bridges and articulation points in the network."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:673 ../gui/wxpython/menustrings.py:1615
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:665
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1591
+msgid "Maximum flow"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:674 ../gui/wxpython/menustrings.py:1616
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:666
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1592
+msgid "Computes the maximum flow between two sets of nodes in the network."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:675 ../gui/wxpython/menustrings.py:1617
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:667
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1593
+msgid "Vertex connectivity"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:676 ../gui/wxpython/menustrings.py:1618
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:668
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1594
+msgid "Computes vertex connectivity between two sets of nodes in the network."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:677 ../gui/wxpython/menustrings.py:1619
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:669
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1595
+msgid "Components"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:678 ../gui/wxpython/menustrings.py:1620
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:670
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1596
+msgid "Computes strongly and weakly connected components in the network."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:679 ../gui/wxpython/menustrings.py:1621
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:671
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1597
+msgid "Centrality"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:680 ../gui/wxpython/menustrings.py:1622
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:672
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1598
+msgid "Computes degree, centrality, betweeness, closeness and eigenvector centrality measures in the network."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:681 ../gui/wxpython/menustrings.py:1623
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:673
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1599
+msgid "Steiner tree"
+msgstr "Steiner fa"
+#: ../gui/wxpython/menustrings.py:682 ../gui/wxpython/menustrings.py:1624
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:674
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1600
+msgid "Creates Steiner tree for the network and given terminals. Note that 'Minimum Steiner Tree' problem is NP-hard and heuristic algorithm is used in this module so the result may be sub optimal."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:683 ../gui/wxpython/menustrings.py:1625
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:675
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1601
+msgid "Minimum spanning tree"
+msgstr "Minimális feszítő fa"
+#: ../gui/wxpython/menustrings.py:684 ../gui/wxpython/menustrings.py:1626
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:676
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1602
+msgid "Computes minimum spanning tree for the network."
+msgstr "Minimális feszítő fa számítás a hálózatra."
+#: ../gui/wxpython/menustrings.py:685 ../gui/wxpython/menustrings.py:1627
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:677
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1603
+msgid "Traveling salesman analysis"
+msgstr "Utazó ügynök elemzés"
+#: ../gui/wxpython/menustrings.py:686 ../gui/wxpython/menustrings.py:1628
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:678
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1604
+msgid "Creates a cycle connecting given nodes (Traveling salesman problem). Note that TSP is NP-hard, heuristic algorithm is used by this module and created cycle may be sub optimal"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:687 ../gui/wxpython/menustrings.py:690
+#: ../gui/wxpython/menustrings.py:1629 ../gui/wxpython/menustrings.py:1632
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:679
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:680
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1605
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1606
+msgid "Overlay vector maps"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:688 ../gui/wxpython/menustrings.py:1630
+msgid "Clip vector maps"
+msgstr "Vektor térkép vágás"
+#: ../gui/wxpython/menustrings.py:689 ../gui/wxpython/menustrings.py:1631
+msgid "Extracts features of input map which overlay features of clip map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:691 ../gui/wxpython/menustrings.py:1633
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:681
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1607
+msgid "Overlays two vector maps offering clip, intersection, difference, symmetrical difference, union operators."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:692 ../gui/wxpython/menustrings.py:1634
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:682
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1608
+msgid "Patch vector maps"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:693 ../gui/wxpython/menustrings.py:1635
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:683
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1609
+msgid "Creates a new vector map by combining other vector maps."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:694 ../gui/wxpython/menustrings.py:1636
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:684
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1610
+msgid "Manage categories"
+msgstr "Kategória kezelés"
+#: ../gui/wxpython/menustrings.py:695 ../gui/wxpython/menustrings.py:1637
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:685
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1611
+msgid "Change or report categories"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:696 ../gui/wxpython/menustrings.py:1638
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:686
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1612
+msgid "Attaches, deletes or reports vector categories to map geometry."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:698 ../gui/wxpython/menustrings.py:1640
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:688
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1614
+msgid "Changes vector category values for an existing vector map according to results of SQL queries or a value in attribute table column."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:699 ../gui/wxpython/menustrings.py:1641
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:689
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1615
+#: ../gui/wxpython/dbmgr/dialogs.py:122
+msgid "Update attributes"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:700 ../gui/wxpython/menustrings.py:1642
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:690
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1616
+msgid "Update area attributes from raster"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:701 ../gui/wxpython/menustrings.py:1643
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:691
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1617
+msgid "Calculates univariate statistics from a raster map based on a vector map and uploads statistics to new attribute columns."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:702 ../gui/wxpython/menustrings.py:1644
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:692
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1618
+msgid "Update area attributes from vector"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:703 ../gui/wxpython/menustrings.py:1645
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:693
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1619
+msgid "Count points in areas, calculate statistics from point attributes."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:704 ../gui/wxpython/menustrings.py:1646
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:694
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1620
+msgid "Update point attributes from areas"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:705 ../gui/wxpython/menustrings.py:1647
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:695
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1621
+msgid "Uploads vector values at positions of vector points to the table."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:706 ../gui/wxpython/menustrings.py:1648
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:696
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1622
+msgid "Update database values from vector"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:707 ../gui/wxpython/menustrings.py:1649
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:697
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1623
+msgid "Populates attribute values from vector features."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:708 ../gui/wxpython/menustrings.py:1650
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:698
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1624
+msgid "Sample raster maps at point locations"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:709 ../gui/wxpython/menustrings.py:1651
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:699
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1625
+msgid "Uploads raster values at positions of vector points to the table."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:710 ../gui/wxpython/menustrings.py:1652
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:700
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1626
+msgid "Sample raster neighborhood around points"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:711 ../gui/wxpython/menustrings.py:1653
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:701
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1627
+msgid "Samples a raster map at vector point locations."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:712 ../gui/wxpython/menustrings.py:1654
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:702
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1628
+msgid "Generate area for current region"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:713 ../gui/wxpython/menustrings.py:1655
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:703
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1629
+msgid "Creates a vector polygon from the current region extent."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:714 ../gui/wxpython/menustrings.py:1656
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:704
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1630
+msgid "Generate areas from points"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:715 ../gui/wxpython/menustrings.py:1657
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:705
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1631
+msgid "Convex hull"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:716 ../gui/wxpython/menustrings.py:1658
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:706
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1632
+msgid "Produces a 2D/3D convex hull for a given vector map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:717 ../gui/wxpython/menustrings.py:1659
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:707
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1633
+msgid "Delaunay triangles"
+msgstr "Delaunay háromszögek"
+#: ../gui/wxpython/menustrings.py:718 ../gui/wxpython/menustrings.py:1660
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:708
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1634
+msgid "Creates a Delaunay triangulation from an input vector map containing points or centroids."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:719 ../gui/wxpython/menustrings.py:1661
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:709
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1635
+msgid "Voronoi diagram/Thiessen polygons"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:720 ../gui/wxpython/menustrings.py:1662
+msgid "Creates a Voronoi diagram constrained to the extents of the current region from an input vector map containing points or centroids."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:721 ../gui/wxpython/menustrings.py:1663
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:711
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1637
+msgid "Generate grid"
+msgstr "Rács generálás"
+#: ../gui/wxpython/menustrings.py:722 ../gui/wxpython/menustrings.py:1664
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:712
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1638
+msgid "Creates a vector map of a user-defined grid."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:723 ../gui/wxpython/menustrings.py:1665
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:713
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1639
+msgid "Generate points"
+msgstr "Pont generálás"
+#: ../gui/wxpython/menustrings.py:724 ../gui/wxpython/menustrings.py:1666
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:714
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1640
+msgid "Generate from database"
+msgstr "Generálás adatbázisból"
+#: ../gui/wxpython/menustrings.py:725 ../gui/wxpython/menustrings.py:1667
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:715
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1641
+msgid "Creates new vector (points) map from database table containing coordinates."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:726 ../gui/wxpython/menustrings.py:1668
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:716
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1642
+msgid "Generate points along lines"
+msgstr "Pontok generálása vonalak mentén"
+#: ../gui/wxpython/menustrings.py:727 ../gui/wxpython/menustrings.py:1669
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:717
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1643
+msgid "Creates points along input lines in new vector map with 2 layers."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:728 ../gui/wxpython/menustrings.py:1670
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:718
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1644
+msgid "Generate random points"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:729 ../gui/wxpython/menustrings.py:1671
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:719
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1645
+msgid "Generates random 2D/3D vector points."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:732 ../gui/wxpython/menustrings.py:1674
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:722
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1648
+msgid "Remove outliers in point sets"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:737 ../gui/wxpython/menustrings.py:1679
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:727
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1653
+msgid "Basic vector metadata"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:738 ../gui/wxpython/menustrings.py:1680
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:728
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1654
+msgid "Outputs basic information about a vector map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:739 ../gui/wxpython/menustrings.py:1681
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:729
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1655
+msgid "Classify attribute data"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:740 ../gui/wxpython/menustrings.py:1682
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:730
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1656
+msgid "Classifies attribute data, e.g. for thematic mapping"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:741 ../gui/wxpython/menustrings.py:1683
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:731
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1657
+msgid "Report topology by category"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:742 ../gui/wxpython/menustrings.py:1684
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:732
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1658
+msgid "Reports geometry statistics for vector maps."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:743 ../gui/wxpython/menustrings.py:1685
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:733
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1659
+msgid "Univariate attribute statistics for points"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:744 ../gui/wxpython/menustrings.py:1686
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:734
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1660
+msgid "Calculates univariate statistics of vector map features. Variance and standard deviation is calculated only for points if specified."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:745 ../gui/wxpython/menustrings.py:1687
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:735
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1661
+msgid "Univariate statistics for attribute columns"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:746 ../gui/wxpython/menustrings.py:1688
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:736
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1662
+msgid "Calculates univariate statistics on selected table column for a GRASS vector map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:748 ../gui/wxpython/menustrings.py:1690
+msgid "Vector map profiling tool"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:749 ../gui/wxpython/menustrings.py:1691
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:737
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1663
+msgid "Quadrat indices"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:751 ../gui/wxpython/menustrings.py:1693
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:739
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1665
+msgid "Test normality"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:753 ../gui/wxpython/menustrings.py:1695
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:741
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1667
+msgid "&Imagery"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:754 ../gui/wxpython/menustrings.py:1696
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:742
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1668
+msgid "Develop images and groups"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:755 ../gui/wxpython/menustrings.py:1697
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:743
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1669
+msgid "Create/edit group"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:756 ../gui/wxpython/menustrings.py:1698
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:744
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1670
+msgid "Creates, edits, and lists groups of imagery files."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:757 ../gui/wxpython/menustrings.py:1699
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:745
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1671
+msgid "Target group"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:758 ../gui/wxpython/menustrings.py:1700
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:746
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1672
+msgid "Targets an imagery group to a GRASS location and mapset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:759 ../gui/wxpython/menustrings.py:1701
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:747
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1673
+msgid "Mosaic images"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:760 ../gui/wxpython/menustrings.py:1702
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:748
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1674
+msgid "Mosaics several images and extends colormap."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:761 ../gui/wxpython/menustrings.py:1703
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:749
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1675
+msgid "Manage image colors"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:762 ../gui/wxpython/menustrings.py:1704
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:750
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1676
+msgid "Color balance for RGB"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:763 ../gui/wxpython/menustrings.py:1705
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:751
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1677
+msgid "Performs auto-balancing of colors for RGB images."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:764 ../gui/wxpython/menustrings.py:1706
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:752
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1678
+msgid "HIS to RGB"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:765 ../gui/wxpython/menustrings.py:1707
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:753
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1679
+msgid "Transforms raster maps from HIS (Hue-Intensity-Saturation) color space to RGB (Red-Green-Blue) color space."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:767 ../gui/wxpython/menustrings.py:1709
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:755
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1681
+msgid "Transforms raster maps from RGB (Red-Green-Blue) color space to HIS (Hue-Intensity-Saturation) color space."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:768 ../gui/wxpython/menustrings.py:1710
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:756
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1682
+msgid "Rectify image or raster"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:769 ../gui/wxpython/menustrings.py:1711
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:757
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1683
+msgid "Rectifies an image by computing a coordinate transformation for each pixel in the image based on the control points."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:770 ../gui/wxpython/menustrings.py:1712
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:758
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1684
+#: ../gui/wxpython/lmgr/layertree.py:795
+msgid "Histogram"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:771 ../gui/wxpython/menustrings.py:1713
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:759
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1685
+msgid "Generate histogram of image"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:772 ../gui/wxpython/menustrings.py:1714
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:760
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1686
+msgid "Spectral response"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:773 ../gui/wxpython/menustrings.py:1715
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:761
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1687
+msgid "Displays spectral response at user specified locations in group or images."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:774 ../gui/wxpython/menustrings.py:1716
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:762
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1688
+msgid "Pan sharpening"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:775 ../gui/wxpython/menustrings.py:1717
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:763
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1689
+msgid "Image fusion algorithms to sharpen multispectral with high-res panchromatic channels"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:776 ../gui/wxpython/menustrings.py:1718
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:764
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1690
+msgid "Classify image"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:777 ../gui/wxpython/menustrings.py:1719
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:765
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1691
+msgid "Clustering input for unsupervised classification"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:778 ../gui/wxpython/menustrings.py:1720
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:766
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1692
+msgid "Generates spectral signatures for land cover types in an image using a clustering algorithm. The resulting signature file is used as input for i.maxlik, to generate an unsupervised image classification."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:779 ../gui/wxpython/menustrings.py:1721
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:767
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1693
+msgid "Input for supervised MLC"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:780 ../gui/wxpython/menustrings.py:1722
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:768
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1694
+msgid "Generates statistics for i.maxlik from raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:781 ../gui/wxpython/menustrings.py:1723
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:769
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1695
+msgid "Maximum likelihood classification (MLC)"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:782 ../gui/wxpython/menustrings.py:1724
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:770
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1696
+msgid "Classifies the cell spectral reflectances in imagery data. Classification is based on the spectral signature information generated by either i.cluster, g.gui.iclass, or i.gensig."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:783 ../gui/wxpython/menustrings.py:1725
+#: ../gui/wxpython/menustrings.py:1995
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:771
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1697
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1962
+msgid "Interactive input for supervised classification"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:784 ../gui/wxpython/menustrings.py:1726
+#: ../gui/wxpython/menustrings.py:1996
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:772
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1698
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1963
+msgid "Generates spectral signatures by allowing the user to outline training areas."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:785 ../gui/wxpython/menustrings.py:1727
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:773
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1699
+msgid "Input for supervised SMAP"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:786 ../gui/wxpython/menustrings.py:1728
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:774
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1700
+msgid "Generates statistics for i.smap from raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:787 ../gui/wxpython/menustrings.py:1729
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:775
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1701
+msgid "Sequential maximum a posteriori classification (SMAP)"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:788 ../gui/wxpython/menustrings.py:1730
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:776
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1702
+msgid "Performs contextual image classification using sequential maximum a posteriori (SMAP) estimation."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:789 ../gui/wxpython/menustrings.py:1731
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:777
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1703
+msgid "Object segmentation"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:790 ../gui/wxpython/menustrings.py:1732
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:778
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1704
+msgid "Identifies segments (objects) from imagery data."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:791 ../gui/wxpython/menustrings.py:1733
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:779
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1705
+msgid "Filter image"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:792 ../gui/wxpython/menustrings.py:1734
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:780
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1706
+msgid "Edge detection"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:793 ../gui/wxpython/menustrings.py:1735
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:781
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1707
+msgid "Zero-crossing \"edge detection\" raster function for image processing."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:794 ../gui/wxpython/menustrings.py:1736
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:782
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1708
+msgid "Matrix/convolving filter"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:795 ../gui/wxpython/menustrings.py:1737
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:783
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1709
+msgid "Performs raster map matrix filter."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:796 ../gui/wxpython/menustrings.py:1738
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:784
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1710
+msgid "Transform image"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:797 ../gui/wxpython/menustrings.py:1739
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:785
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1711
+msgid "Canonical correlation"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:798 ../gui/wxpython/menustrings.py:1740
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:786
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1712
+msgid "Canonical components analysis (CCA) program for image processing."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:799 ../gui/wxpython/menustrings.py:1741
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:787
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1713
+msgid "Principal components"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:800 ../gui/wxpython/menustrings.py:1742
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:788
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1714
+msgid "Principal components analysis (PCA) for image processing."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:801 ../gui/wxpython/menustrings.py:1743
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:789
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1715
+msgid "Fast Fourier"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:802 ../gui/wxpython/menustrings.py:1744
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:790
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1716
+msgid "Fast Fourier Transform (FFT) for image processing."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:803 ../gui/wxpython/menustrings.py:1745
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:791
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1717
+msgid "Inverse Fast Fourier"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:804 ../gui/wxpython/menustrings.py:1746
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:792
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1718
+msgid "Inverse Fast Fourier Transform (IFFT) for image processing."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:805 ../gui/wxpython/menustrings.py:1747
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:793
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1719
+msgid "Satellite images tools"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:806 ../gui/wxpython/menustrings.py:1748
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:794
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1720
+msgid "Aster DN to radiance/reflectance"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:807 ../gui/wxpython/menustrings.py:1749
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:795
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1721
+msgid "Calculates Top of Atmosphere Radiance/Reflectance/Brightness Temperature from ASTER DN."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:808 ../gui/wxpython/menustrings.py:1750
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:796
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1722
+msgid "Landsat DN to radiance/reflectance"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:809 ../gui/wxpython/menustrings.py:1751
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:797
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1723
+msgid "Calculates top-of-atmosphere radiance or reflectance and temperature for Landsat MSS/TM/ETM+/OLI"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:810 ../gui/wxpython/menustrings.py:1752
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:798
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1724
+msgid "Landsat cloud cover assessment"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:811 ../gui/wxpython/menustrings.py:1753
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:799
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1725
+msgid "Performs Landsat TM/ETM+ Automatic Cloud Cover Assessment (ACCA)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:812 ../gui/wxpython/menustrings.py:1754
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:800
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1726
+msgid "Modis quality control"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:813 ../gui/wxpython/menustrings.py:1755
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:801
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1727
+msgid "Extracts quality control parameters from MODIS QC layers."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:814 ../gui/wxpython/menustrings.py:1756
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:802
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1728
+msgid "Atmospheric correction"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:815 ../gui/wxpython/menustrings.py:1757
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:803
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1729
+msgid "Performs atmospheric correction using the 6S algorithm. 6S - Second Simulation of Satellite Signal in the Solar Spectrum."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:816 ../gui/wxpython/menustrings.py:1758
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:804
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1730
+msgid "Topographic correction"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:817 ../gui/wxpython/menustrings.py:1759
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:805
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1731
+msgid "Computes topographic correction of reflectance."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:818 ../gui/wxpython/menustrings.py:1760
+msgid "Orthophoto tools"
+msgstr "Ortofotó eszközök"
+#: ../gui/wxpython/menustrings.py:819 ../gui/wxpython/menustrings.py:1761
+msgid "Manage GCPs for 3D correction"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:820 ../gui/wxpython/menustrings.py:1762
+msgid "Georectifies a map and allows managing GCP for 3D correction."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:821 ../gui/wxpython/menustrings.py:1763
+msgid "Corrects scanning distortions"
+msgstr "Szkennelési torzítás korrekciója"
+#: ../gui/wxpython/menustrings.py:822 ../gui/wxpython/menustrings.py:1764
+msgid "Corrects scanning distortions of a scanned aerial photo."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:823 ../gui/wxpython/menustrings.py:1765
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:806
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1732
+msgid "Satellite images products"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:824 ../gui/wxpython/menustrings.py:1766
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:807
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1733
+msgid "Vegetation indices"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:825 ../gui/wxpython/menustrings.py:1767
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:808
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1734
+msgid "Calculates different types of vegetation indices. Uses red and nir bands mostly, and some indices require additional bands."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:826 ../gui/wxpython/menustrings.py:1768
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:809
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1735
+msgid "Tasseled cap vegetation index"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:827 ../gui/wxpython/menustrings.py:1769
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:810
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1736
+msgid "Performs Tasseled Cap (Kauth Thomas) transformation."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:828 ../gui/wxpython/menustrings.py:1770
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:811
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1737
+msgid "Albedo"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:829 ../gui/wxpython/menustrings.py:1771
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:812
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1738
+msgid "Computes broad band albedo from surface reflectance."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:830 ../gui/wxpython/menustrings.py:1772
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:813
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1739
+msgid "Emissivity"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:831 ../gui/wxpython/menustrings.py:1773
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:814
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1740
+msgid "Computes emissivity from NDVI, generic method for sparse land."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:832 ../gui/wxpython/menustrings.py:1774
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:815
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1741
+msgid "Biomass growth"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:833 ../gui/wxpython/menustrings.py:1775
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:816
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1742
+msgid "Computes biomass growth, precursor of crop yield calculation."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:834 ../gui/wxpython/menustrings.py:1776
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:817
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1743
+msgid "Evapotranspiration calculation"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:835 ../gui/wxpython/menustrings.py:1777
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:818
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1744
+msgid "Instantaneaous Net Radiation"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:836 ../gui/wxpython/menustrings.py:1778
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:819
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1745
+msgid "Net radiation approximation (Bastiaanssen, 1995)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:837 ../gui/wxpython/menustrings.py:1779
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:820
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1746
+msgid "Soil heat flux"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:838 ../gui/wxpython/menustrings.py:1780
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:821
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1747
+msgid "Soil heat flux approximation (Bastiaanssen, 1995)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:839 ../gui/wxpython/menustrings.py:1781
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:822
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1748
+msgid "Sensible heat flux"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:840 ../gui/wxpython/menustrings.py:1782
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:823
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1749
+msgid "Computes sensible heat flux iteration SEBAL 01."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:841 ../gui/wxpython/menustrings.py:1783
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:824
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1750
+msgid "Evaporative fraction"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:842 ../gui/wxpython/menustrings.py:1784
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:825
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1751
+msgid "Computes evaporative fraction and root zone soil moisture."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:843 ../gui/wxpython/menustrings.py:1785
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:826
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1752
+msgid "Actual Evapotranspiration"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:844 ../gui/wxpython/menustrings.py:1786
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:827
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1753
+msgid "Actual evapotranspiration for diurnal period (Bastiaanssen, 1995)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:845 ../gui/wxpython/menustrings.py:1787
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:828
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1754
+msgid "Temporal integration of ETa"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:846 ../gui/wxpython/menustrings.py:1788
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:829
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1755
+msgid "Computes temporal integration of satellite ET actual (ETa) following the daily ET reference (ETo) from meteorological station(s)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:847 ../gui/wxpython/menustrings.py:1789
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:830
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1756
+msgid "Hargreaves methods Evapotranspiration"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:848 ../gui/wxpython/menustrings.py:1790
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:831
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1757
+msgid "Computes evapotranspiration calculation modified or original Hargreaves formulation, 2001."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:849 ../gui/wxpython/menustrings.py:1791
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:832
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1758
+msgid "Penman-Monteith Evapotranspiration"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:850 ../gui/wxpython/menustrings.py:1792
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:833
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1759
+msgid "Computes potential evapotranspiration calculation with hourly Penman-Monteith."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:851 ../gui/wxpython/menustrings.py:1793
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:834
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1760
+msgid "Priestley-Taylor Evapotranspiration"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:852 ../gui/wxpython/menustrings.py:1794
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:835
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1761
+msgid "Computes evapotranspiration calculation Priestley and Taylor formulation, 1972."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:854 ../gui/wxpython/menustrings.py:1796
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:837
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1763
+msgid "Kappa analysis"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:855 ../gui/wxpython/menustrings.py:1797
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:838
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1764
+msgid "Calculates error matrix and kappa parameter for accuracy assessment of classification result."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:856 ../gui/wxpython/menustrings.py:1798
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:839
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1765
+msgid "OIF for LandSat TM"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:857 ../gui/wxpython/menustrings.py:1799
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:840
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1766
+msgid "Calculates Optimum-Index-Factor table for spectral bands"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:858 ../gui/wxpython/menustrings.py:1800
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:841
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1767
+msgid "3D r&aster"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:859 ../gui/wxpython/menustrings.py:1801
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:842
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1768
+msgid "Develop 3D raster map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:860 ../gui/wxpython/menustrings.py:1802
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:843
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1769
+msgid "Manage 3D NULL values"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:861 ../gui/wxpython/menustrings.py:1803
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:844
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1770
+msgid "Explicitly create the 3D NULL-value bitmap file."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:862 ../gui/wxpython/menustrings.py:1804
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:845
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1771
+msgid "Manage timestamp"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:863 ../gui/wxpython/menustrings.py:1805
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:846
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1772
+msgid "Modifies a timestamp for a 3D raster map. Print/add/remove a timestamp for a 3D raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:865 ../gui/wxpython/menustrings.py:1807
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:848
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1774
+msgid "3D rasters to raster series"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:867 ../gui/wxpython/menustrings.py:1809
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:850
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1776
+msgid "3D color tables"
+msgstr "3D színtáblák"
+#: ../gui/wxpython/menustrings.py:868 ../gui/wxpython/menustrings.py:1810
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:851
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1777
+msgid "Creates/modifies the color table associated with a 3D raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:869 ../gui/wxpython/menustrings.py:1811
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:852
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1778
+msgid "Export 3D color table"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:870 ../gui/wxpython/menustrings.py:1812
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:853
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1779
+msgid "Exports the color table associated with a 3D raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:871 ../gui/wxpython/menustrings.py:1813
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:854
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1780
+msgid "3D mask"
+msgstr "3D maszk"
+#: ../gui/wxpython/menustrings.py:872 ../gui/wxpython/menustrings.py:1814
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:855
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1781
+msgid "Establishes the current working 3D raster mask."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:873 ../gui/wxpython/menustrings.py:874
+#: ../gui/wxpython/menustrings.py:1815 ../gui/wxpython/menustrings.py:1816
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:856
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:857
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1782
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1783
+msgid "3D raster map calculator"
+msgstr "3D raszter térkép kalkulátor"
+#: ../gui/wxpython/menustrings.py:875 ../gui/wxpython/menustrings.py:1817
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:858
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1784
+msgid "Cross section"
+msgstr "Metszet"
+#: ../gui/wxpython/menustrings.py:876 ../gui/wxpython/menustrings.py:1818
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:859
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1785
+msgid "Creates cross section 2D raster map from 3D raster map based on 2D elevation map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:878 ../gui/wxpython/menustrings.py:1820
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:861
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1787
+msgid "Numerical calculation program for transient, confined groundwater flow in three dimensions."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:879 ../gui/wxpython/menustrings.py:1821
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:862
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1788
+msgid "Interpolate 3D raster from points"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:880 ../gui/wxpython/menustrings.py:1822
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:863
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1789
+msgid "Interpolates point data to a 3D raster map using regularized spline with tension (RST) algorithm."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:882 ../gui/wxpython/menustrings.py:1824
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:865
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1791
+msgid "Basic 3D raster metadata"
+msgstr "Alap 3D raszter meta adat"
+#: ../gui/wxpython/menustrings.py:883 ../gui/wxpython/menustrings.py:1825
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:866
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1792
+msgid "Outputs basic information about a user-specified 3D raster map layer."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:884 ../gui/wxpython/menustrings.py:1826
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:867
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1793
+msgid "3D raster statistics"
+msgstr "3D raszter statisztika"
+#: ../gui/wxpython/menustrings.py:885 ../gui/wxpython/menustrings.py:1827
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:868
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1794
+msgid "Generates volume statistics for 3D raster maps."
+msgstr "Térfogat statisztika generálás 3Draszter térképekhez."
+#: ../gui/wxpython/menustrings.py:886 ../gui/wxpython/menustrings.py:1828
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:869
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1795
+msgid "Univariate statistics for 3D rasters"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:887 ../gui/wxpython/menustrings.py:1829
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:870
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1796
+msgid "Calculates univariate statistics from the non-null cells of a 3D raster map. Statistics include number of cells counted, minimum and maximum cell values, range, arithmetic mean, population variance, standard deviation, coefficient of variation, and sum."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:888 ../gui/wxpython/menustrings.py:1830
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:871
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1797
+msgid "&Database"
+msgstr "A&datbázis"
+#: ../gui/wxpython/menustrings.py:889 ../gui/wxpython/menustrings.py:1831
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:872
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1798
+msgid "Database information"
+msgstr "Adatbázis információ"
+#: ../gui/wxpython/menustrings.py:890 ../gui/wxpython/menustrings.py:1832
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:873
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1799
+msgid "List databases"
+msgstr "Adatbázisok lista"
+#: ../gui/wxpython/menustrings.py:891 ../gui/wxpython/menustrings.py:1833
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:874
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1800
+msgid "Lists all databases for a given driver and location."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:892 ../gui/wxpython/menustrings.py:1834
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:875
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1801
+msgid "List drivers"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:893 ../gui/wxpython/menustrings.py:1835
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:876
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1802
+msgid "Lists all database drivers."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:894 ../gui/wxpython/menustrings.py:1836
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:877
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1803
+msgid "List tables"
+msgstr "Táblák listája"
+#: ../gui/wxpython/menustrings.py:895 ../gui/wxpython/menustrings.py:1837
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:878
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1804
+msgid "Lists all tables for a given database."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:896 ../gui/wxpython/menustrings.py:1838
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:879
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1805
+msgid "Describe table"
+msgstr "Tábla leírás"
+#: ../gui/wxpython/menustrings.py:897 ../gui/wxpython/menustrings.py:1839
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:880
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1806
+msgid "Describes a table in detail."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:898 ../gui/wxpython/menustrings.py:1840
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:881
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1807
+msgid "List columns"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:899 ../gui/wxpython/menustrings.py:1841
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:882
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1808
+msgid "List all columns for a given table."
+msgstr "Egy adott tábla összes oszlopának listája"
+#: ../gui/wxpython/menustrings.py:900 ../gui/wxpython/menustrings.py:1842
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:883
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1809
+msgid "Manage databases"
+msgstr "Adatbázisok kezelése"
+#: ../gui/wxpython/menustrings.py:901 ../gui/wxpython/menustrings.py:1843
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:884
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1810
+msgid "Connect"
+msgstr "Csatlakozás"
+#: ../gui/wxpython/menustrings.py:902 ../gui/wxpython/menustrings.py:1844
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:885
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1811
+msgid "Prints/sets general DB connection for current mapset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:903 ../gui/wxpython/menustrings.py:1845
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:886
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1812
+msgid "Login"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:904 ../gui/wxpython/menustrings.py:1846
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:887
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1813
+msgid "Sets user/password for DB driver/database."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:905 ../gui/wxpython/menustrings.py:1847
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:888
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1814
+msgid "Create database"
+msgstr "Adatbázis létrehozás"
+#: ../gui/wxpython/menustrings.py:906 ../gui/wxpython/menustrings.py:1848
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:889
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1815
+msgid "Creates an empty database."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:907 ../gui/wxpython/menustrings.py:1849
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:890
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1816
+msgid "Drop database"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:908 ../gui/wxpython/menustrings.py:1850
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:891
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1817
+msgid "Removes an existing database."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:909 ../gui/wxpython/menustrings.py:1851
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:892
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1818
+msgid "Drop table"
+msgstr "Tábla törlés"
+#: ../gui/wxpython/menustrings.py:910 ../gui/wxpython/menustrings.py:1852
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:893
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1819
+msgid "Drops an attribute table."
+msgstr "Egy attribútum tábla törlése."
+#: ../gui/wxpython/menustrings.py:911 ../gui/wxpython/menustrings.py:1853
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:894
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1820
+msgid "Copy table"
+msgstr "Tábla másolás"
+#: ../gui/wxpython/menustrings.py:912 ../gui/wxpython/menustrings.py:1854
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:895
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1821
+msgid "Copy a table. Either 'from_table' (optionally with 'where') can be used or 'select' option, but not 'from_table' and 'select' at the same time."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:913 ../gui/wxpython/menustrings.py:933
+#: ../gui/wxpython/menustrings.py:1855 ../gui/wxpython/menustrings.py:1875
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:896
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:916
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1822
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1842
+msgid "Drop column"
+msgstr "Oszlop törlés"
+#: ../gui/wxpython/menustrings.py:914 ../gui/wxpython/menustrings.py:1856
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:897
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1823
+msgid "Drops a column from selected attribute table."
+msgstr "Oszlop törlés a kiválasztott attribútum táblából."
+#: ../gui/wxpython/menustrings.py:915 ../gui/wxpython/menustrings.py:1857
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:898
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1824
+msgid "Test"
+msgstr "Teszt"
+#: ../gui/wxpython/menustrings.py:916 ../gui/wxpython/menustrings.py:1858
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:899
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1825
+msgid "Test database driver, database must exist and set by db.connect."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:917 ../gui/wxpython/menustrings.py:1859
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:900
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1826
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:113
+msgid "Query"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:918 ../gui/wxpython/menustrings.py:1860
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:901
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1827
+msgid "Query any table"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:919 ../gui/wxpython/menustrings.py:1861
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:902
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1828
+msgid "Selects data from attribute table. Performs SQL query statement(s)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:922 ../gui/wxpython/menustrings.py:1864
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:905
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1831
+msgid "SQL statement"
+msgstr "SQL mondat"
+#: ../gui/wxpython/menustrings.py:923 ../gui/wxpython/menustrings.py:1865
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:906
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1832
+msgid "Executes any SQL statement. For SELECT statements use 'db.select'."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:924 ../gui/wxpython/menustrings.py:1866
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:907
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1833
+msgid "Vector database connections"
+msgstr "Vektor adatbázis kapcsolatok"
+#: ../gui/wxpython/menustrings.py:925 ../gui/wxpython/menustrings.py:1867
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:908
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1834
+msgid "New table"
+msgstr "Új tábla"
+#: ../gui/wxpython/menustrings.py:926 ../gui/wxpython/menustrings.py:1868
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:909
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1835
+msgid "Creates and connects a new attribute table to a given layer of an existing vector map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:927 ../gui/wxpython/menustrings.py:1869
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:910
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1836
+msgid "Remove table"
+msgstr "Tábla eltávolítás"
+#: ../gui/wxpython/menustrings.py:928 ../gui/wxpython/menustrings.py:1870
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:911
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1837
+msgid "Removes existing attribute table of a vector map."
+msgstr "Egy vektor térkép attribútum táblájának eltávolítása."
+#: ../gui/wxpython/menustrings.py:929 ../gui/wxpython/menustrings.py:1871
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:912
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1838
+msgid "Join table"
+msgstr "Tábla kapcsolás"
+#: ../gui/wxpython/menustrings.py:930 ../gui/wxpython/menustrings.py:1872
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:913
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1839
+msgid "Joins a database table to a vector map table."
+msgstr "Adatbázis tábla kapcsolása egy vektor térkép táblához."
+#: ../gui/wxpython/menustrings.py:931 ../gui/wxpython/menustrings.py:1873
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:914
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1840
+msgid "Add columns"
+msgstr "Oszlopok hozzáadása"
+#: ../gui/wxpython/menustrings.py:932 ../gui/wxpython/menustrings.py:1874
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:915
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1841
+msgid "Adds one or more columns to the attribute table connected to a given vector map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:934 ../gui/wxpython/menustrings.py:1876
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:917
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1843
+msgid "Drops a column from the attribute table connected to a given vector map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:935 ../gui/wxpython/menustrings.py:1877
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:918
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1844
+#: ../gui/wxpython/dbmgr/base.py:2370
+msgid "Rename column"
+msgstr "Oszlop átnevezés"
+#: ../gui/wxpython/menustrings.py:936 ../gui/wxpython/menustrings.py:1878
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:919
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1845
+msgid "Renames a column in the attribute table connected to a given vector map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:937 ../gui/wxpython/menustrings.py:1879
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:920
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1846
+msgid "Change values"
+msgstr "Értékek módosítása"
+#: ../gui/wxpython/menustrings.py:938 ../gui/wxpython/menustrings.py:1880
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:921
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1847
+msgid "Updates a column in the attribute table connected to a vector map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:939 ../gui/wxpython/menustrings.py:1881
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:922
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1848
+msgid "Drop row"
+msgstr "Sor eldobása"
+#: ../gui/wxpython/menustrings.py:940 ../gui/wxpython/menustrings.py:1882
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:923
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1849
+msgid "Removes a vector feature from a vector map through attribute selection."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:941 ../gui/wxpython/menustrings.py:1883
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:924
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1850
+msgid "Reconnect vectors to database"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:942 ../gui/wxpython/menustrings.py:1884
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:925
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1851
+msgid "Reconnects attribute tables for all vector maps from the current mapset to a new database."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:943 ../gui/wxpython/menustrings.py:1885
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:926
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1852
+msgid "Set vector map - database connection"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:944 ../gui/wxpython/menustrings.py:1886
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:927
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1853
+msgid "Prints/sets DB connection for a vector map to attribute table."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:945 ../gui/wxpython/menustrings.py:1887
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:928
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1854
+msgid "&Temporal"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:946 ../gui/wxpython/menustrings.py:1888
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:929
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1855
+msgid "Manage datasets"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:947 ../gui/wxpython/menustrings.py:1889
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:930
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1856
+msgid "Connect temporal database"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:948 ../gui/wxpython/menustrings.py:1890
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:931
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1857
+msgid "Prints/sets general temporal GIS database connection for current mapset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:949 ../gui/wxpython/menustrings.py:1891
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:932
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1858
+#: ../gui/wxpython/rlisetup/frame.py:143
+msgid "Create"
+msgstr "Létrehozás"
+#: ../gui/wxpython/menustrings.py:950 ../gui/wxpython/menustrings.py:1892
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:933
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1859
+msgid "Creates a space time dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:952 ../gui/wxpython/menustrings.py:1894
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:935
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1861
+msgid "Renames a space time dataset"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:953 ../gui/wxpython/menustrings.py:1895
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:936
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1862
+#: ../gui/wxpython/gui_core/simplelmgr.py:463
+#: ../gui/wxpython/animation/dialogs.py:783
+#: ../gui/wxpython/animation/dialogs.py:1015
+#: ../gui/wxpython/lmgr/layertree.py:459 ../gui/wxpython/rlisetup/frame.py:140
+#: ../gui/wxpython/gmodeler/frame.py:1499
+msgid "Remove"
+msgstr "Eltávolítás"
+#: ../gui/wxpython/menustrings.py:954 ../gui/wxpython/menustrings.py:1896
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:937
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1863
+msgid "Removes space time datasets from temporal database."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:955 ../gui/wxpython/menustrings.py:1897
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:938
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1864
+msgid "Update metadata"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:956 ../gui/wxpython/menustrings.py:1898
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:939
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1865
+msgid "Modifies the metadata of a space time dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:957 ../gui/wxpython/menustrings.py:1899
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:940
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1866
+msgid "Merge"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:958 ../gui/wxpython/menustrings.py:1900
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:941
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1867
+msgid "Merges several space time datasets into a single space time dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:959 ../gui/wxpython/menustrings.py:1901
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:942
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1868
+msgid "Temporally shift"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:960 ../gui/wxpython/menustrings.py:1902
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:943
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1869
+msgid "Shifts temporally the maps of a space time dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:961 ../gui/wxpython/menustrings.py:1903
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:944
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1870
+msgid "Snap maps of dataset"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:962 ../gui/wxpython/menustrings.py:1904
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:945
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1871
+msgid "Snaps temporally the maps of a space time dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:964 ../gui/wxpython/menustrings.py:1906
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:947
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1873
+msgid "Lists space time datasets and maps registered in the temporal database."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:965 ../gui/wxpython/menustrings.py:1907
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:948
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1874
+msgid "Manage maps in datasets"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:966 ../gui/wxpython/menustrings.py:1908
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:949
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1875
+msgid "Register maps in datasets"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:967 ../gui/wxpython/menustrings.py:1909
+msgid "Assigns timestamps and registers raster, vector and raster3d maps in a space time dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:968 ../gui/wxpython/menustrings.py:1910
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:951
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1877
+msgid "Unregister maps from datasets"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:969 ../gui/wxpython/menustrings.py:1911
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:952
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1878
+msgid "Unregisters raster, vector and raster3d maps from the temporal database or a specific space time dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:970 ../gui/wxpython/menustrings.py:1912
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:953
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1879
+msgid "List raster dataset maps"
+msgstr "Raszter térkép lista"
+#: ../gui/wxpython/menustrings.py:971 ../gui/wxpython/menustrings.py:1913
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:954
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1880
+msgid "Lists registered maps of a space time raster dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:972 ../gui/wxpython/menustrings.py:1914
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:955
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1881
+msgid "List vector dataset maps"
+msgstr "Vektor térkép lista"
+#: ../gui/wxpython/menustrings.py:973 ../gui/wxpython/menustrings.py:1915
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:956
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1882
+msgid "Lists registered maps of a space time vector dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:974 ../gui/wxpython/menustrings.py:1916
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:957
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1883
+msgid "List 3D raster dataset maps"
+msgstr "3D raszter térkép lista"
+#: ../gui/wxpython/menustrings.py:975 ../gui/wxpython/menustrings.py:1917
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:958
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1884
+msgid "Lists registered maps of a space time raster3d dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:976 ../gui/wxpython/menustrings.py:1918
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:959
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1885
+msgid "Import"
+msgstr "Import"
+#: ../gui/wxpython/menustrings.py:977 ../gui/wxpython/menustrings.py:1919
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:960
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1886
+msgid "Import raster dataset"
+msgstr "Raszter adathalmaz import"
+#: ../gui/wxpython/menustrings.py:978 ../gui/wxpython/menustrings.py:1920
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:961
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1887
+msgid "Imports space time raster dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:979 ../gui/wxpython/menustrings.py:1921
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:962
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1888
+msgid "Import vector dataset"
+msgstr "Vektor adathalmaz import"
+#: ../gui/wxpython/menustrings.py:980 ../gui/wxpython/menustrings.py:1922
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:963
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1889
+msgid "Imports a space time vector dataset from a GRASS GIS specific archive file."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:981 ../gui/wxpython/menustrings.py:1923
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:964
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1890
+#: ../gui/wxpython/animation/dialogs.py:937
+#: ../gui/wxpython/lmgr/layertree.py:739
+msgid "Export"
+msgstr "Export"
+#: ../gui/wxpython/menustrings.py:982 ../gui/wxpython/menustrings.py:1924
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:965
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1891
+msgid "Export raster dataset"
+msgstr "Raszter adathalmaz export"
+#: ../gui/wxpython/menustrings.py:983 ../gui/wxpython/menustrings.py:1925
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:966
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1892
+msgid "Exports space time raster dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:984 ../gui/wxpython/menustrings.py:1926
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:967
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1893
+msgid "Export raster dataset as VTK time series"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:985 ../gui/wxpython/menustrings.py:1927
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:968
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1894
+msgid "Exports space time raster dataset as VTK time series."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:986 ../gui/wxpython/menustrings.py:1928
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:969
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1895
+msgid "Export vector dataset"
+msgstr "Vektor adathalmaz export"
+#: ../gui/wxpython/menustrings.py:987 ../gui/wxpython/menustrings.py:1929
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:970
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1896
+msgid "Exports a space time vector dataset as GRASS GIS specific archive file."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:988 ../gui/wxpython/menustrings.py:1930
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:971
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1897
+msgid "Convert raster dataset to 3D raster"
+msgstr "Raszter adathalmaz konvertálás 3D rétegbe"
+#: ../gui/wxpython/menustrings.py:989 ../gui/wxpython/menustrings.py:1931
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:972
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1898
+msgid "Converts a space time raster dataset into a 3D raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:990 ../gui/wxpython/menustrings.py:1932
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:973
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1899
+msgid "Extraction"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:991 ../gui/wxpython/menustrings.py:1933
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:974
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1900
+msgid "Extract subset of raster dataset"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:992 ../gui/wxpython/menustrings.py:1934
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:975
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1901
+msgid "Extracts a subset of a space time raster datasets."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:993 ../gui/wxpython/menustrings.py:1935
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:976
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1902
+msgid "Extract subset of vector dataset"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:994 ../gui/wxpython/menustrings.py:1936
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:977
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1903
+msgid "Extracts a subset of a space time vector dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:995 ../gui/wxpython/menustrings.py:1937
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:978
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1904
+msgid "Extract subset of 3D raster dataset"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:996 ../gui/wxpython/menustrings.py:1938
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:979
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1905
+msgid "Extracts a subset of a space time 3D raster dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:997 ../gui/wxpython/menustrings.py:1939
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:980
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1906
+msgid "Query vector dataset attribute data"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:998 ../gui/wxpython/menustrings.py:1940
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:981
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1907
+msgid "Prints attributes of vector maps registered in a space time vector dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:999 ../gui/wxpython/menustrings.py:1941
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:982
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1908
+msgid "Raster dataset color table"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1000 ../gui/wxpython/menustrings.py:1942
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:983
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1909
+msgid "Creates/modifies the color table associated with each raster map of the space time raster dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1001 ../gui/wxpython/menustrings.py:1943
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:984
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1910
+msgid "Raster calculations"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1002 ../gui/wxpython/menustrings.py:1944
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:985
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1911
+msgid "Performs spatio-temporal mapcalc expressions on temporally sampled maps of space time raster datasets."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1003 ../gui/wxpython/menustrings.py:1945
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:986
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1912
+msgid "3D raster calculations"
+msgstr "3D raszter számítások"
+#: ../gui/wxpython/menustrings.py:1004 ../gui/wxpython/menustrings.py:1946
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:987
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1913
+msgid "Performs r3.mapcalc expressions on maps of sampled space time 3D raster datasets."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1005 ../gui/wxpython/menustrings.py:1947
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:988
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1914
+msgid "Interpolate gaps in raster datasets"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1006 ../gui/wxpython/menustrings.py:1948
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:989
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1915
+msgid "Replaces gaps in a space time raster dataset with interpolated raster maps."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1007 ../gui/wxpython/menustrings.py:1949
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:990
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1916
+msgid "Aggregation"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1008 ../gui/wxpython/menustrings.py:1950
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:991
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1917
+msgid "Neighborhood analysis in raster dataset"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1009 ../gui/wxpython/menustrings.py:1951
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:992
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1918
+msgid "Performs a neighborhood analysis for each map in a space time raster dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1010 ../gui/wxpython/menustrings.py:1952
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:993
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1919
+msgid "Aggregation in raster datasets"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1011 ../gui/wxpython/menustrings.py:1953
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:994
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1920
+msgid "Performs different aggregation algorithms from r.series on all or a subset of raster maps in a space time raster dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1012 ../gui/wxpython/menustrings.py:1954
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:995
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1921
+msgid "Temporal aggregation"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1013 ../gui/wxpython/menustrings.py:1955
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:996
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1922
+msgid "Aggregates temporally the maps of a space time raster dataset by a user defined granularity."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1014 ../gui/wxpython/menustrings.py:1956
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:997
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1923
+msgid "Temporal aggregation by dataset"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1015 ../gui/wxpython/menustrings.py:1957
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:998
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1924
+msgid "Aggregates data of an existing space time raster dataset using the time intervals of a second space time dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1016 ../gui/wxpython/menustrings.py:1958
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:999
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1925
+msgid "Sampling"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1017 ../gui/wxpython/menustrings.py:1959
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1000
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1926
+msgid "Sample a space time raster dataset at point coordinates"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1018 ../gui/wxpython/menustrings.py:1960
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1001
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1927
+msgid "Sample a space time raster dataset at specific vector point coordinates and write the output to stdout using different layouts"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1019 ../gui/wxpython/menustrings.py:1961
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1002
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1928
+msgid "Query raster dataset by vector points dataset"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1020 ../gui/wxpython/menustrings.py:1962
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1003
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1929
+msgid "Stores raster map values at spatial and temporal positions of vector points as vector attributes."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1021 ../gui/wxpython/menustrings.py:1963
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1004
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1930
+msgid "Observe specific locations in raster dataset"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1022 ../gui/wxpython/menustrings.py:1964
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1005
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1931
+msgid "Observes specific locations in a space time raster dataset over a period of time using vector points."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1023 ../gui/wxpython/menustrings.py:1965
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1006
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1932
+msgid "Temporal sampling"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1024 ../gui/wxpython/menustrings.py:1966
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1007
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1933
+msgid "Samples the input space time dataset(s) with a sample space time dataset and print the result to stdout."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1026 ../gui/wxpython/menustrings.py:1968
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1009
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1935
+msgid "Space time datasets metadata"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1027 ../gui/wxpython/menustrings.py:1969
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1010
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1936
+msgid "Lists information about space time datasets and maps."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1028 ../gui/wxpython/menustrings.py:1970
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1011
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1937
+msgid "Univariate raster dataset statistics"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1029 ../gui/wxpython/menustrings.py:1971
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1012
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1938
+msgid "Calculates univariate statistics from the non-null cells for each registered raster map of a space time raster dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1030 ../gui/wxpython/menustrings.py:1972
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1013
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1939
+msgid "Univariate vector dataset statistics"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1031 ../gui/wxpython/menustrings.py:1973
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1014
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1940
+msgid "Calculates univariate statistics of attributes for each registered vector map of a space time vector dataset"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1032 ../gui/wxpython/menustrings.py:1974
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1015
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1941
+msgid "Univariate 3D raster dataset statistics"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1033 ../gui/wxpython/menustrings.py:1975
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1016
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1942
+msgid "Calculates univariate statistics from the non-null cells for each registered 3D raster map of a space time 3D raster dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1034 ../gui/wxpython/menustrings.py:1976
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1017
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1943
+msgid "Report temporal topology"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1035 ../gui/wxpython/menustrings.py:1977
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1018
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1944
+msgid "Lists temporal topology of a space time dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1036 ../gui/wxpython/menustrings.py:1978
+#: ../gui/wxpython/menustrings.py:1985
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1019
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1945
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1952
+msgid "GUI tools"
+msgstr "GUI eszközök"
+#: ../gui/wxpython/menustrings.py:1039 ../gui/wxpython/menustrings.py:1981
+#: ../gui/wxpython/menustrings.py:2001
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1022
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1948
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1968
+msgid "Timeline tool"
+msgstr "Idővonal eszközök"
+#: ../gui/wxpython/menustrings.py:1040 ../gui/wxpython/menustrings.py:1982
+#: ../gui/wxpython/menustrings.py:2002
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1023
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1949
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1969
+msgid "Plot temporal extents."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1041 ../gui/wxpython/menustrings.py:1983
+#: ../gui/wxpython/menustrings.py:1999
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1024
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1950
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1966
+msgid "Temporal plot tool"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1042 ../gui/wxpython/menustrings.py:1984
+#: ../gui/wxpython/menustrings.py:2000
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1025
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1951
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1967
+msgid "Plot temporal values."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1043 ../gui/wxpython/menustrings.py:2048
+#: ../gui/wxpython/menustrings.py:2091
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1026
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:2015
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:2058
+msgid "&Help"
+msgstr "Súgó"
+#: ../gui/wxpython/menustrings.py:1044
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1027
+msgid "GRASS help"
+msgstr "GRASS súgó"
+#: ../gui/wxpython/menustrings.py:1045 ../gui/wxpython/menustrings.py:1047
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1028
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1030
+msgid "Display the HTML man pages of GRASS GIS"
+msgstr "GRASS GIS HTML kézikönyv oldalainak megjelenítése"
+#: ../gui/wxpython/menustrings.py:1046
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1029
+msgid "GUI help"
+msgstr "GUI súgó"
+#: ../gui/wxpython/menustrings.py:1048
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1031
+msgid "About system"
+msgstr "Rendszer névjegy"
+#: ../gui/wxpython/menustrings.py:1049
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1032
+msgid "Prints system information"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1050 ../gui/wxpython/menustrings.py:1051
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1033
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1034
+#: ../gui/wxpython/gui_core/ghelp.py:53
+msgid "About GRASS GIS"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1054
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1037
+msgid "Import, export and link data"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1988
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1955
+msgid "Attribute table manager"
+msgstr "Attribútum tábla kezelő"
+#: ../gui/wxpython/menustrings.py:2007
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1974
+msgid "Create new model"
+msgstr "Új modell létrehozás"
+#: ../gui/wxpython/menustrings.py:2009
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1976
+msgid "Load model from file"
+msgstr "Modell betöltés fájlból"
+#: ../gui/wxpython/menustrings.py:2011
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1978
+#: ../gui/wxpython/gmodeler/frame.py:518
+msgid "Save model"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2013
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1980
+msgid "Save model to file"
+msgstr "Modell mentés fájlba"
+#: ../gui/wxpython/menustrings.py:2015
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1982
+msgid "Close model file"
+msgstr "Modell fájl lezárás"
+#: ../gui/wxpython/menustrings.py:2016
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1983
+msgid "Export to image"
+msgstr "Exportálás képbe"
+#: ../gui/wxpython/menustrings.py:2017
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1984
+msgid "Export model to image"
+msgstr "Modell export képbe"
+#: ../gui/wxpython/menustrings.py:2018
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1985
+msgid "Export to Python"
+msgstr "Export Pythonba"
+#: ../gui/wxpython/menustrings.py:2019
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1986
+msgid "Export model to Python script"
+msgstr "Modell export Python szkriptbe"
+#: ../gui/wxpython/menustrings.py:2020
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1987
+msgid "Quit modeler"
+msgstr "Kilépés a modellezőből"
+#: ../gui/wxpython/menustrings.py:2021
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1988
+msgid "Close modeler window"
+msgstr "Modellező ablak lezárás"
+#: ../gui/wxpython/menustrings.py:2024
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1991
+#: ../gui/wxpython/gmodeler/preferences.py:32
+msgid "Modeler settings"
+msgstr "Modellező beállítások"
+#: ../gui/wxpython/menustrings.py:2025
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1992
+msgid "&Model"
+msgstr "&Modell"
+#: ../gui/wxpython/menustrings.py:2026
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1993
+msgid "Add command"
+msgstr "Parancs hozzáadás"
+#: ../gui/wxpython/menustrings.py:2027
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1994
+msgid "Add action (GRASS command) to model"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2028
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1995
+msgid "Add data"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2029
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1996
+msgid "Add data item to model"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2030
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1997
+msgid "Define relation"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2031
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1998
+msgid "Define relation between data and action items"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2032
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1999
+msgid "Add loop / series"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2033
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:2000
+msgid "Adds loop (series) to model"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2034
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:2001
+msgid "Add condition"
+msgstr "Feltétel hozzáadás"
+#: ../gui/wxpython/menustrings.py:2035
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:2002
+msgid "Adds condition (if/else) to model"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2036
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:2003
+#: ../gui/wxpython/gmodeler/frame.py:885
+msgid "Add comment"
+msgstr "Megjegyzés hozzáadás"
+#: ../gui/wxpython/menustrings.py:2037
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:2004
+msgid "Adds comment to model"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2038
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:2005
+msgid "Remove item"
+msgstr "Elem eltávoilítás"
+#: ../gui/wxpython/menustrings.py:2039
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:2006
+msgid "Remove action/data from model"
+msgstr "Művelet/adat eltávolítása a modellből"
+#: ../gui/wxpython/menustrings.py:2040
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:2007
+#: ../gui/wxpython/gmodeler/preferences.py:661
+msgid "Model properties"
+msgstr "Modell tulajdonságok"
+#: ../gui/wxpython/menustrings.py:2041
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:2008
+msgid "Model properties (name, purpose, etc.)"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2042
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:2009
+msgid "Delete intermediate data"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2043
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:2010
+msgid "Delete intermediate data defined in the model"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2045
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:2012
+msgid "Run entire model"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2046
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:2013
+msgid "Validate model"
+msgstr "Modell ellenőrzés"
+#: ../gui/wxpython/menustrings.py:2047
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:2014
+msgid "Validate entire model"
+msgstr "A teljes modell ellenőrzése"
+#: ../gui/wxpython/menustrings.py:2049 ../gui/wxpython/menustrings.py:2092
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:2016
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:2059
+#: ../gui/wxpython/tplot/frame.py:280 ../gui/wxpython/timeline/frame.py:137
+msgid "Help"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2050
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:2017
+msgid "Display the HTML man pages of Graphical modeler"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2051
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:2018
+msgid "About Graphical Modeler"
+msgstr "Grafikus modellező névjegy"
+#: ../gui/wxpython/menustrings.py:2052
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:2019
+msgid "Display information about Graphical Modeler"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2057
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:2024
+#: ../gui/wxpython/psmap/toolbars.py:77
+msgid "Specify paper size, margins and orientation"
+msgstr "Papír méret, margók és tájolás megadása"
+#: ../gui/wxpython/menustrings.py:2058
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:2025
+msgid "Load instruction file"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2059
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:2026
+#: ../gui/wxpython/psmap/toolbars.py:70
+msgid "Load text file with mapping instructions"
+msgstr "Térképi utasításokat tartalmazó szövegfájl betöltése "
+#: ../gui/wxpython/menustrings.py:2060
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:2027
+msgid "Export instruction file"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2061
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:2028
+#: ../gui/wxpython/psmap/toolbars.py:68
+msgid "Generate text file with mapping instructions"
+msgstr "Térképi utasításokat tartalmazó szövegfájl generálása"
+#: ../gui/wxpython/menustrings.py:2062
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:2029
+msgid "Export to PostScript"
+msgstr "Export PostScriptbe"
+#: ../gui/wxpython/menustrings.py:2063
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:2030
+#: ../gui/wxpython/psmap/toolbars.py:72
+msgid "Generate PostScript output"
+msgstr "PostScript output generálás"
+#: ../gui/wxpython/menustrings.py:2064
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:2031
+msgid "Export to PDF"
+msgstr "Export PDF-be"
+#: ../gui/wxpython/menustrings.py:2065
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:2032
+#: ../gui/wxpython/psmap/toolbars.py:74
+msgid "Generate PDF output"
+msgstr "PDF output generálás"
+#: ../gui/wxpython/menustrings.py:2066 ../gui/wxpython/menustrings.py:2067
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:2033
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:2034
+msgid "Launch ps.map dialog"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2068
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:2035
+#: ../gui/wxpython/gui_core/toolbars.py:74 ../gui/wxpython/lmgr/layertree.py:78
+msgid "Quit"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2069
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:2036
+msgid "Close Cartographic Composer"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2070
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:2037
+msgid "&Insert"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2071
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:2038
+#: ../gui/wxpython/psmap/toolbars.py:82 ../gui/wxpython/psmap/dialogs.py:833
+#: ../gui/wxpython/psmap/dialogs.py:887
+msgid "Map frame"
+msgstr "Térképkeret"
+#: ../gui/wxpython/menustrings.py:2072
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:2039
+msgid "Add or edit map frame"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2073
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:2040
+#: ../gui/wxpython/nviz/mapwindow.py:1675 ../gui/wxpython/nviz/tools.py:827
+#: ../gui/wxpython/psmap/dialogs.py:1540 ../gui/wxpython/lmgr/layertree.py:1044
+msgid "Raster map"
+msgstr "Raszter térkép"
+#: ../gui/wxpython/menustrings.py:2074
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:2041
+msgid "Add or edit raster map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2075
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:2042
+#: ../gui/wxpython/nviz/tools.py:1453 ../gui/wxpython/psmap/dialogs.py:3644
+#: ../gui/wxpython/lmgr/layertree.py:1048
+msgid "Vector map"
+msgstr "Vektor térkép"
+#: ../gui/wxpython/menustrings.py:2076
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:2043
+msgid "Add or edit vector map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2077
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:2044
+msgid "Map legend"
+msgstr "Térkép jelmagarázat"
+#: ../gui/wxpython/menustrings.py:2078
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:2045
+msgid "Add or edit raster and vector legend"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2079
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:2046
+#: ../gui/wxpython/psmap/toolbars.py:93
+msgid "Map info"
+msgstr "Térkép info"
+#: ../gui/wxpython/menustrings.py:2080
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:2047
+msgid "Add or edit map info"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2081
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:2048
+#: ../gui/wxpython/nviz/tools.py:2381 ../gui/wxpython/psmap/toolbars.py:97
+msgid "Scale bar"
+msgstr "Léptékvonalzó"
+#: ../gui/wxpython/menustrings.py:2082
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:2049
+msgid "Add or edit scale bar"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2083
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:2050
+#: ../gui/wxpython/psmap/toolbars.py:91 ../gui/wxpython/psmap/dialogs.py:5185
+#: ../gui/wxpython/psmap/dialogs.py:5194
+#: ../gui/wxpython/animation/dialogs.py:1540
+msgid "Text"
+msgstr "Szöveg"
+#: ../gui/wxpython/menustrings.py:2084
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:2051
+#: ../gui/wxpython/animation/dialogs.py:991
+#: ../gui/wxpython/mapdisp/toolbars.py:54
+msgid "Add text"
+msgstr "Szöveg hozzáadás"
+#: ../gui/wxpython/menustrings.py:2085
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:2052
+#: ../gui/wxpython/psmap/toolbars.py:99 ../gui/wxpython/psmap/dialogs.py:5720
+#: ../gui/wxpython/psmap/dialogs.py:5782
+#: ../gui/wxpython/animation/dialogs.py:1539
+msgid "Image"
+msgstr "Kép"
+#: ../gui/wxpython/menustrings.py:2086
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:2053
+msgid "Add image"
+msgstr "Kép hozzáadás"
+#: ../gui/wxpython/menustrings.py:2087
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:2054
+#: ../gui/wxpython/nviz/tools.py:2332 ../gui/wxpython/psmap/toolbars.py:101
+#: ../gui/wxpython/psmap/dialogs.py:6244
+msgid "North Arrow"
+msgstr "Észak nyíl"
+#: ../gui/wxpython/menustrings.py:2088
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:2055
+#: ../gui/wxpython/mapdisp/toolbars.py:41
+msgid "Add north arrow"
+msgstr "Észak nyíl hozzáadás"
+#: ../gui/wxpython/menustrings.py:2090
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:2057
+#: ../gui/wxpython/psmap/toolbars.py:85
+msgid "Delete selected object"
+msgstr "Szelektált objektum törlése"
+#: ../gui/wxpython/menustrings.py:2093
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:2060
+msgid "Display the HTML man pages of Cartographic Composer"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2094
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:2061
+msgid "About Cartographic Composer"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2095
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:2062
+msgid "Display information about Cartographic Composer"
+msgstr ""
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:38
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1039
+msgid "Common formats import"
+msgstr ""
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:40
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:70
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1041
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1071
+msgid "Import of common formats with reprojection"
+msgstr ""
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:41
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1042
+msgid "Imports raster data into a GRASS raster map using GDAL library and reprojects on the fly."
+msgstr ""
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:71
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1072
+msgid "Imports vector data into a GRASS vector map using OGR library and reprojects on the fly."
+msgstr ""
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:132
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1133
+msgid "Exports a vector map layer to any of the supported OGR vector formats. By default a vector map layer is exported to Esri Shapefile format."
+msgstr "Vektor térkép réteg export bármelyik támogatott OGR vektor formátumba. Alapértelmezés szerint a vektor térkép réteget ESRI shape fájl formátumba exportáljuk."
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:650
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1576
+msgid "Allocates subnets for nearest centers (direction from center). center node must be opened (costs >= 0). Costs of center node are used in calculation"
+msgstr ""
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:652
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1578
+msgid "Splits net by cost isolines. Splits net to bands between cost isolines (direction from center). Center node must be opened (costs >= 0). Costs of center node are used in calculation."
+msgstr ""
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:710
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1636
+msgid "Creates a Voronoi diagram in current region from an input vector map containing points or centroids."
+msgstr ""
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:864
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1790
+msgid "Reports and Statistics"
+msgstr "Jelentések és statisztikák"
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:950
+#: ../gui/wxpython/image2target/ii2t_menustrings.py:1876
+msgid "Registers raster, vector and raster3d maps in a space time datasets."
+msgstr ""
+#: ../gui/wxpython/image2target/ii2t_mapdisplay.py:50
+#: ../gui/wxpython/gcp/mapdisplay.py:50
+msgid "GRASS GIS Manage Ground Control Points"
+msgstr "GRASS GIS illesztőpont kezelés"
+#: ../gui/wxpython/image2target/ii2t_manager.py:179
+#: ../gui/wxpython/gcp/manager.py:150
+msgid "Setup for georectification"
+msgstr ""
+#: ../gui/wxpython/image2target/ii2t_manager.py:212
+#: ../gui/wxpython/image2target/ii2t_manager.py:216
+#: ../gui/wxpython/gcp/manager.py:183 ../gui/wxpython/gcp/manager.py:187
+msgid "Georectifying setup canceled."
+msgstr ""
+#: ../gui/wxpython/image2target/ii2t_manager.py:381
+#: ../gui/wxpython/gcp/manager.py:352
+msgid "Select map type and location/mapset"
+msgstr ""
+#: ../gui/wxpython/image2target/ii2t_manager.py:395
+#: ../gui/wxpython/gcp/manager.py:366
+msgid "Map type to georectify"
+msgstr ""
+#: ../gui/wxpython/image2target/ii2t_manager.py:396
+#: ../gui/wxpython/gui_core/dialogs.py:1452
+#: ../gui/wxpython/gui_core/dialogs.py:1697
+#: ../gui/wxpython/psmap/dialogs.py:920 ../gui/wxpython/gcp/manager.py:367
+#: ../gui/wxpython/gmodeler/frame.py:1746
+msgid "raster"
+msgstr "raszter"
+#: ../gui/wxpython/psmap/dialogs.py:923 ../gui/wxpython/gcp/manager.py:367
+#: ../gui/wxpython/gmodeler/frame.py:1747
+msgid "vector"
+msgstr "vektor"
+#: ../gui/wxpython/image2target/ii2t_manager.py:406
+#: ../gui/wxpython/gcp/manager.py:377
+msgid "Select source location:"
+msgstr "Válasszon forrás helyet:"
+#: ../gui/wxpython/image2target/ii2t_manager.py:427
+#: ../gui/wxpython/gcp/manager.py:398
+msgid "Select source mapset:"
+msgstr "Válasszon forrás térképcsoportot"
+#: ../gui/wxpython/image2target/ii2t_manager.py:483
+#: ../gui/wxpython/gcp/manager.py:454
+msgid "You must select a valid location before selecting a mapset"
+msgstr "A térképcsoport kiválasztás előtt ki kell választania egy helyet"
+#: ../gui/wxpython/image2target/ii2t_manager.py:496
+#: ../gui/wxpython/gcp/manager.py:467
+msgid "You must select a valid location and mapset in order to continue"
+msgstr "A folytatás érdekében egy helyet és egy térképcsoportot kell választania"
+#: ../gui/wxpython/image2target/ii2t_manager.py:518
+#: ../gui/wxpython/gcp/manager.py:489
+msgid "Select image/map group to georectify"
+msgstr ""
+#: ../gui/wxpython/image2target/ii2t_manager.py:540
+msgid "Select group:"
+msgstr "Válasszon csoportot:"
+#: ../gui/wxpython/image2target/ii2t_manager.py:557
+#: ../gui/wxpython/gcp/manager.py:528
+msgid "Create group if none exists"
+msgstr "Csoport létrehozása, ha nem létezik"
+#: ../gui/wxpython/image2target/ii2t_manager.py:571
+#: ../gui/wxpython/gcp/manager.py:542
+msgid "Add vector map to group..."
+msgstr "Vektor térkép hozzáadás a csoporthoz..."
+#: ../gui/wxpython/image2target/ii2t_manager.py:655
+#: ../gui/wxpython/gcp/manager.py:632
+msgid "You must select a valid image/map group in order to continue"
+msgstr "A folytat érdekében kép/térkép csoportot kell választania"
+#: ../gui/wxpython/image2target/ii2t_manager.py:662
+#: ../gui/wxpython/gcp/manager.py:639
+msgid "You must enter an map name extension in order to continue"
+msgstr ""
+#: ../gui/wxpython/image2target/ii2t_manager.py:731
+#: ../gui/wxpython/gcp/manager.py:708
+msgid "Select maps to display for ground control point (GCP) creation"
+msgstr ""
+#: ../gui/wxpython/image2target/ii2t_manager.py:792
+#: ../gui/wxpython/image2target/ii2t_manager.py:2984
+#: ../gui/wxpython/gcp/manager.py:769 ../gui/wxpython/gcp/manager.py:2910
+msgid "Select target vector map to display:"
+msgstr "Megjelenítendő cél vektor térkép:"
+#: ../gui/wxpython/image2target/ii2t_manager.py:864
+#: ../gui/wxpython/gcp/manager.py:841
+msgid "You must select a source map in order to continue"
+msgstr "A folytatás érdekében egy forrás térképet kell kiválasztania"
+#: ../gui/wxpython/image2target/ii2t_manager.py:891
+#: ../gui/wxpython/image2target/ii2t_manager.py:922
+#: ../gui/wxpython/gcp/manager.py:868 ../gui/wxpython/gcp/manager.py:899
+#, python-format
+msgid ""
+"No maps in selected group <%s>.\n"
+"Please edit group or select another group."
+msgstr ""
+#: ../gui/wxpython/image2target/ii2t_manager.py:952
+#: ../gui/wxpython/gcp/manager.py:929
+msgid "Manage Ground Control Points"
+msgstr "Illesztőpontok (GCP) kezelése"
+#: ../gui/wxpython/image2target/ii2t_manager.py:1485
+msgid "Writing CONTROL_POINTS file failed"
+msgstr ""
+#: ../gui/wxpython/image2target/ii2t_manager.py:1497
+#, python-format
+msgid "CONTROL_POINTS file saved for group <%s>"
+msgstr ""
+#: ../gui/wxpython/image2target/ii2t_manager.py:1548
+msgid "Reading CONTROL_POINTS file failed"
+msgstr ""
+#: ../gui/wxpython/image2target/ii2t_manager.py:1703
+#: ../gui/wxpython/gcp/manager.py:1637
+#, python-format
+msgid "Transforming <%s>..."
+msgstr "Transzformálás <%s>..."
+#: ../gui/wxpython/image2target/ii2t_manager.py:1708
+#: ../gui/wxpython/gcp/manager.py:1642
+#, python-format
+msgid "Rectifying vector map <%s>, please wait..."
+msgstr ""
+#: ../gui/wxpython/image2target/ii2t_manager.py:1743
+#: ../gui/wxpython/gcp/manager.py:1676
+#, python-format
+msgid "Georectification of vector map <%s> failed"
+msgstr ""
+#: ../gui/wxpython/image2target/ii2t_manager.py:1875
+msgid ""
+"Could not calculate RMS Error.\n"
+"Possible error with i.ortho.transform."
+msgstr ""
+#: ../gui/wxpython/image2target/ii2t_manager.py:2001
+msgid ""
+"Could not calculate new extends.\n"
+msgstr ""
+#: ../gui/wxpython/image2target/ii2t_manager.py:2213
+#: ../gui/wxpython/image2target/ii2t_manager.py:2233
+#: ../gui/wxpython/gcp/manager.py:2149 ../gui/wxpython/gcp/manager.py:2167
+msgid "source E"
+msgstr "forrás K"
+#: ../gui/wxpython/image2target/ii2t_manager.py:2214
+#: ../gui/wxpython/image2target/ii2t_manager.py:2234
+#: ../gui/wxpython/gcp/manager.py:2150 ../gui/wxpython/gcp/manager.py:2168
+msgid "source N"
+msgstr "forrás É"
+#: ../gui/wxpython/image2target/ii2t_manager.py:2215
+#: ../gui/wxpython/image2target/ii2t_manager.py:2235
+msgid "source Z"
+msgstr "forrás Z"
+#: ../gui/wxpython/image2target/ii2t_manager.py:2216
+#: ../gui/wxpython/image2target/ii2t_manager.py:2236
+#: ../gui/wxpython/gcp/manager.py:2151 ../gui/wxpython/gcp/manager.py:2169
+msgid "target E"
+msgstr "cél K"
+#: ../gui/wxpython/image2target/ii2t_manager.py:2217
+#: ../gui/wxpython/image2target/ii2t_manager.py:2237
+#: ../gui/wxpython/gcp/manager.py:2152 ../gui/wxpython/gcp/manager.py:2170
+msgid "target N"
+msgstr "cél É"
+#: ../gui/wxpython/image2target/ii2t_manager.py:2218
+#: ../gui/wxpython/image2target/ii2t_manager.py:2238
+msgid "target Z"
+msgstr "cél Z"
+#: ../gui/wxpython/image2target/ii2t_manager.py:2428
+#: ../gui/wxpython/gcp/manager.py:2356
+msgid "Create vector map group"
+msgstr "Vektor térkép csoport létrehozás"
+#: ../gui/wxpython/image2target/ii2t_manager.py:2503
+#: ../gui/wxpython/gcp/manager.py:2431
+msgid "Select vector map(s) to add to group:"
+msgstr "Csoporthoz adandó vektor térkép(ek):"
+#: ../gui/wxpython/image2target/ii2t_manager.py:2586
+#: ../gui/wxpython/gcp/manager.py:2518
+msgid "source E:"
+msgstr "forrás K:"
+#: ../gui/wxpython/image2target/ii2t_manager.py:2587
+#: ../gui/wxpython/gcp/manager.py:2519
+msgid "target E:"
+msgstr "cél K"
+#: ../gui/wxpython/image2target/ii2t_manager.py:2588
+#: ../gui/wxpython/gcp/manager.py:2520
+msgid "source N:"
+msgstr "forrás É:"
+#: ../gui/wxpython/image2target/ii2t_manager.py:2589
+#: ../gui/wxpython/gcp/manager.py:2521
+msgid "target N:"
+msgstr "cél É:"
+#: ../gui/wxpython/image2target/ii2t_manager.py:2590
+msgid "source Z:"
+msgstr "forrás Z:"
+#: ../gui/wxpython/image2target/ii2t_manager.py:2591
+msgid "target Z:"
+msgstr "Cél Z:"
+#: ../gui/wxpython/vdigit/mapwindow.py:425
+msgid "Update categories"
+msgstr "Kategóriák aktualizálása"
+#: ../gui/wxpython/vdigit/mapwindow.py:549
+#: ../gui/wxpython/vdigit/mapwindow.py:958
+msgid "No vector map selected for editing."
+msgstr ""
+#: ../gui/wxpython/vdigit/mapwindow.py:558
+msgid "Nothing to do. Choose appropriate tool from digitizer toolbar."
+msgstr ""
+#: ../gui/wxpython/vdigit/mapwindow.py:1092
+msgid "Z bulk-labeling dialog"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:108
+msgid "Select area/boundary/centroid tool"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:134
+msgid "Digitize new point"
+msgstr "Új pont digitalizálás"
+#: ../gui/wxpython/vdigit/toolbars.py:135
+#: ../gui/wxpython/vdigit/toolbars.py:144
+#: ../gui/wxpython/vdigit/toolbars.py:147
+msgid "Left: new point"
+msgstr "Bal: új pont"
+#: ../gui/wxpython/vdigit/toolbars.py:137
+msgid "Digitize new line"
+msgstr "Új vonal digitalizálás"
+#: ../gui/wxpython/vdigit/toolbars.py:138
+#: ../gui/wxpython/vdigit/toolbars.py:141
+#: ../gui/wxpython/vdigit/toolbars.py:165
+msgid "Left: new point; Ctrl+Left: undo last point; Right: close line"
+msgstr "Bal: új pont; Ctrl+bal: utolsó pont visszavonás; jobb: vonal lezárás"
+#: ../gui/wxpython/vdigit/toolbars.py:140
+msgid "Digitize new boundary"
+msgstr "Új határ digitalizálás"
+#: ../gui/wxpython/vdigit/toolbars.py:143
+msgid "Digitize new centroid"
+msgstr "Új centrális digitalizálás"
+#: ../gui/wxpython/vdigit/toolbars.py:146
+msgid "Digitize new area (boundary without category)"
+msgstr "Új terület digitalizálás (határvonal kategória nélkül)"
+#: ../gui/wxpython/vdigit/toolbars.py:149
+msgid "Add new vertex to line or boundary"
+msgstr "Új töréspont hozzáadása vonalhoz vagy határvonalhoz"
+#: ../gui/wxpython/vdigit/toolbars.py:150
+#: ../gui/wxpython/vdigit/toolbars.py:153
+#: ../gui/wxpython/vdigit/toolbars.py:156
+#: ../gui/wxpython/vdigit/toolbars.py:168
+#: ../gui/wxpython/vdigit/toolbars.py:171
+#: ../gui/wxpython/vdigit/toolbars.py:174
+#: ../gui/wxpython/vdigit/toolbars.py:183
+msgid "Left: Select; Ctrl+Left: Unselect; Right: Confirm"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:152
+msgid "Delete selected point(s), line(s), boundary(ies) or centroid(s)"
+msgstr "Szelektált pont(ok), vonal(ak), határvonal(ak) vagy centrális(ok) törlése"
+#: ../gui/wxpython/vdigit/toolbars.py:155
+msgid "Delete selected area(s)"
+msgstr "Szelektált terület(ek) törlése"
+#: ../gui/wxpython/vdigit/toolbars.py:158
+msgid "Display/update attributes"
+msgstr "Attribútumok megjelenítése/aktualizálása"
+#: ../gui/wxpython/vdigit/toolbars.py:159
+#: ../gui/wxpython/vdigit/toolbars.py:162
+msgid "Left: Select"
+msgstr "Bal: kiválaszt"
+#: ../gui/wxpython/vdigit/toolbars.py:161
+msgid "Display/update categories"
+msgstr "Kategóriák megjelenítése/frissítése"
+#: ../gui/wxpython/vdigit/toolbars.py:164
+msgid "Edit selected line/boundary"
+msgstr "Kiválasztott vonal/határvonal szerkesztése"
+#: ../gui/wxpython/vdigit/toolbars.py:167
+msgid "Move selected point(s), line(s), boundary(ies) or centroid(s)"
+msgstr "Kiválasztott pont(ok), vonal(ak), határvonal(ak) vagy centrális(ok) mozgatása"
+#: ../gui/wxpython/vdigit/toolbars.py:170
+msgid "Move selected vertex"
+msgstr "Kiválasztott töréspont mozgatás"
+#: ../gui/wxpython/vdigit/toolbars.py:173
+msgid "Remove selected vertex"
+msgstr "Kiválasztott töréspont eltávolítás"
+#: ../gui/wxpython/vdigit/toolbars.py:175
+#: ../gui/wxpython/vdigit/preferences.py:33
+msgid "Digitization settings"
+msgstr "Digitalizálás beállítások"
+#: ../gui/wxpython/vdigit/toolbars.py:176
+msgid "Quit digitizer"
+msgstr "Kilépés a digitalizálóból"
+#: ../gui/wxpython/vdigit/toolbars.py:177
+msgid "Quit digitizer and save changes"
+msgstr "Kilépés a digitalizálóból ésa módosítások mentése"
+#: ../gui/wxpython/vdigit/toolbars.py:178
+msgid "Vector Digitizer manual"
+msgstr "Vektor digitalizálás kézikönyv"
+#: ../gui/wxpython/vdigit/toolbars.py:179
+msgid "Show Vector Digitizer manual"
+msgstr "Vektor digitalizálás kézikönyv megjelenítése"
+#: ../gui/wxpython/vdigit/toolbars.py:181
+msgid "Additional tools (copy, flip, connect, etc.)"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:186
+msgid "Undo previous changes"
+msgstr "Előző módosítások visszavonása"
+#: ../gui/wxpython/vdigit/toolbars.py:188
+msgid "Redo"
+msgstr "Újra"
+#: ../gui/wxpython/vdigit/toolbars.py:189
+msgid "Redo previous changes"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:559
+msgid "Break selected lines/boundaries at intersection"
+msgstr "Kiválasztott vonalak/határok megtörése a metszéseknél"
+#: ../gui/wxpython/vdigit/toolbars.py:561
+msgid "Connect selected lines/boundaries"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:563
+msgid "Copy categories"
+msgstr "Kategóriák másolása"
+#: ../gui/wxpython/vdigit/toolbars.py:565
+msgid "Copy features from (background) vector map"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:567
+msgid "Copy attributes"
+msgstr "Attribútumok másolása"
+#: ../gui/wxpython/vdigit/toolbars.py:569
+msgid "Feature type conversion"
+msgstr "Elem típus konverzió"
+#: ../gui/wxpython/vdigit/toolbars.py:571
+msgid "Flip selected lines/boundaries"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:573
+msgid "Merge selected lines/boundaries"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:575
+msgid "Snap selected lines/boundaries (only to nodes)"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:577
+msgid "Split line/boundary"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:579
+msgid "Query features"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:581
+msgid "Z bulk-labeling of 3D lines"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:603 ../gui/wxpython/vdigit/wxdigit.py:64
+msgid "No vector map open for editing."
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:608
+msgid "Select background vector map"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:768
+msgid "Vector map is not 3D. Operation canceled."
+msgstr "A vektor térkép nem 3D-s. A művelet megszakadt."
+#: ../gui/wxpython/vdigit/toolbars.py:841
+#: ../gui/wxpython/vdigit/toolbars.py:998
+#: ../gui/wxpython/vdigit/toolbars.py:1096
+#: ../gui/wxpython/gui_core/dialogs.py:213
+msgid "Select vector map"
+msgstr "Válasszon vektor térképet"
+#: ../gui/wxpython/vdigit/toolbars.py:873
+#, python-format
+msgid ""
+"Topology for vector map <%s> is not available. Topology is required by digitizer.\n"
+"Do you want to rebuild topology (takes some time) and open the vector map for editing?"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:878
+msgid "Digitizer error"
+msgstr "Digitalizálási hiba"
+#: ../gui/wxpython/vdigit/toolbars.py:903
+#, python-format
+msgid "Please wait, opening vector map <%s> for editing..."
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:941
+#, python-format
+msgid "Unsupported feature type '%(type)s'. Unable to edit OGR layer <%(layer)s>."
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:953
+#: ../gui/wxpython/mapdisp/toolbars.py:116 ../gui/wxpython/mapdisp/frame.py:514
+msgid "Vector digitizer"
+msgstr "Vektor digitalizáló"
+#: ../gui/wxpython/vdigit/toolbars.py:1011
+#, python-format
+msgid "Do you want to save changes in vector map <%s>?"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:1014
+msgid "Save changes?"
+msgstr "Változások mentése?"
+#: ../gui/wxpython/vdigit/toolbars.py:1021
+#, python-format
+msgid "Please wait, closing and rebuilding topology of vector map <%s>..."
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:1039
+#, python-format
+msgid "Editing of vector map <%s> successfully finished"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:1104
+#: ../gui/wxpython/vdigit/toolbars.py:1111
+msgid "New vector map"
+msgstr "Új vektor térkép"
+#: ../gui/wxpython/vdigit/g.gui.vdigit.py:69
+msgid "GRASS GIS Vector Digitizer"
+msgstr "GRASS GIS vektor dgitalizáló"
+#: ../gui/wxpython/vdigit/g.gui.vdigit.py:85
+#, python-format
+msgid "Vector digitizer not available. %s"
+msgstr ""
+#: ../gui/wxpython/vdigit/g.gui.vdigit.py:90
+#, python-format
+msgid "Vector map <%s> not found in current mapset. New vector map can be created by providing '-c' flag."
+msgstr ""
+#: ../gui/wxpython/vdigit/g.gui.vdigit.py:94
+#, python-format
+msgid "New vector map <%s> created"
+msgstr "Új vektor térképet hoztam létre <%s>"
+#: ../gui/wxpython/vdigit/g.gui.vdigit.py:101
+#, python-format
+msgid "Unable to create new vector map <%s>"
+msgstr "Nem tudom az új vektor térképet létrehozni <%s>"
+#: ../gui/wxpython/vdigit/preferences.py:64
+msgid "Apply changes for this session"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:68
+msgid "Close dialog and save changes to user settings file"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:150
+#: ../gui/wxpython/gui_core/preferences.py:272
+#: ../gui/wxpython/animation/dialogs.py:343
+#: ../gui/wxpython/animation/dialogs.py:1857
+#: ../gui/wxpython/gmodeler/preferences.py:54
+msgid "General"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:161 ../gui/wxpython/nviz/tools.py:1574
+#: ../gui/wxpython/nviz/tools.py:1788 ../gui/wxpython/gmodeler/frame.py:1567
+msgid "Display"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:202
+msgid "Snapping"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:211
+msgid "Snapping threshold"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:220
+msgid "screen pixels"
+msgstr ""
+msgid "map units"
+msgstr "térkép egységek"
+#: ../gui/wxpython/vdigit/preferences.py:240
+msgid "Snap also to vertex"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:250
+#: ../gui/wxpython/vdigit/preferences.py:905
+#: ../gui/wxpython/vdigit/preferences.py:919
+#: ../gui/wxpython/vdigit/preferences.py:923
+#, python-format
+msgid "Snapping threshold is %(value).1f %(units)s"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:268
+msgid "Select vector features"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:288
+msgid "Select threshold"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:309
+msgid "Select only features inside of selection bounding box"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:316
+msgid "By default are selected all features overlapping selection bounding box "
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:319
+msgid "Check for duplicates"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:345
+msgid "Digitize lines/boundaries"
+msgstr "Vonalak, határok digitalizálása"
+#: ../gui/wxpython/vdigit/preferences.py:349
+msgid "Break lines at intersection"
+msgstr "Vonalak megszakítása metszéseknél"
+#: ../gui/wxpython/vdigit/preferences.py:372
+msgid "Digitize areas"
+msgstr "Területek digitalizálása"
+#: ../gui/wxpython/vdigit/preferences.py:376
+msgid "Close boundary (snap to the start node)"
+msgstr "Határ bezárása (illesztés a kezdő csomópontba)"
+#: ../gui/wxpython/vdigit/preferences.py:399
+msgid "Save changes"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:402
+msgid "Save changes on exit"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:423
+msgid "Query tool"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:434
+msgid "Choose query tool"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:442
+msgid "Select by box"
+msgstr "Kiválasztás téglalappal"
+#: ../gui/wxpython/vdigit/preferences.py:460
+#: ../gui/wxpython/vdigit/preferences.py:694
+msgid "length"
+msgstr "hossz"
+#: ../gui/wxpython/vdigit/preferences.py:472
+msgid "Select lines"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:475
+#: ../gui/wxpython/vdigit/preferences.py:529
+msgid "shorter than"
+msgstr ""
+msgid "longer than"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:514
+msgid "dangle"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:526
+msgid "Select dangles"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:582
+#: ../gui/wxpython/gui_core/preferences.py:1465
+msgid "Attributes"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:593
+msgid "Digitize new feature"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:598
+msgid "Add new record into table"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:612
+#: ../gui/wxpython/vdigit/preferences.py:615
+#: ../gui/wxpython/vdigit/dialogs.py:116 ../gui/wxpython/vdigit/dialogs.py:576
+#: ../gui/wxpython/dbmgr/dialogs.py:512 ../gui/wxpython/dbmgr/base.py:2952
+#: ../gui/wxpython/dbmgr/base.py:3073 ../gui/wxpython/dbmgr/base.py:3339
+msgid "Layer"
+msgstr "Réteg"
+#: ../gui/wxpython/vdigit/dialogs.py:123 ../gui/wxpython/vdigit/dialogs.py:577
+#: ../gui/wxpython/dbmgr/dialogs.py:512 ../gui/wxpython/dbmgr/dialogs.py:640
+msgid "Category"
+msgstr "Kategória"
+#: ../gui/wxpython/vdigit/preferences.py:613
+msgid "Mode"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:645
+msgid "Next to use"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:627
+msgid "Category number"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:643
+msgid "Category mode"
+msgstr ""
+msgid "Manual entry"
+msgstr ""
+msgid "No category"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:668
+msgid "Delete existing feature(s)"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:673
+msgid "Delete record from table"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:691
+msgid "Geometry attributes"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:696
+msgid "perimeter"
+msgstr "kerület"
+#: ../gui/wxpython/vdigit/preferences.py:767
+msgid "Note: These settings are stored in the workspace not in the vector digitizer preferences."
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:796
+msgid "Digitize new line segment"
+msgstr "Új vonalszakasz digitalizálás"
+#: ../gui/wxpython/vdigit/preferences.py:797
+msgid "Digitize new line/boundary"
+msgstr "Új vonal, határ digitalizálás"
+#: ../gui/wxpython/vdigit/preferences.py:798
+msgid "Highlight"
+msgstr "Kiemel"
+#: ../gui/wxpython/vdigit/preferences.py:799
+msgid "Highlight (duplicates)"
+msgstr "Kiemelés (duplikáltak)"
+#: ../gui/wxpython/vdigit/preferences.py:800
+#: ../gui/wxpython/gui_core/gselect.py:2345
+#: ../gui/wxpython/psmap/toolbars.py:103 ../gui/wxpython/psmap/dialogs.py:6279
+msgid "Point"
+msgstr "Pont"
+#: ../gui/wxpython/vdigit/preferences.py:801
+#: ../gui/wxpython/psmap/toolbars.py:105
+msgid "Line"
+msgstr "Vonal"
+#: ../gui/wxpython/vdigit/preferences.py:802
+msgid "Boundary (no area)"
+msgstr "Határvonal (nincs terület)"
+#: ../gui/wxpython/vdigit/preferences.py:803
+msgid "Boundary (one area)"
+msgstr "Határvonal (egy terület)"
+#: ../gui/wxpython/vdigit/preferences.py:804
+msgid "Boundary (two areas)"
+msgstr "Határvonal (két terület)"
+#: ../gui/wxpython/vdigit/preferences.py:805
+msgid "Centroid (in area)"
+msgstr "Centrális (területben)"
+#: ../gui/wxpython/vdigit/preferences.py:806
+msgid "Centroid (outside area)"
+msgstr "Centrális (területen kívül)"
+#: ../gui/wxpython/vdigit/preferences.py:807
+msgid "Centroid (duplicate in area)"
+msgstr "Centrális (duplán a területben)"
+#: ../gui/wxpython/vdigit/preferences.py:808
+msgid "Node (one line)"
+msgstr "Csomópont (egy vonal)"
+#: ../gui/wxpython/vdigit/preferences.py:809
+msgid "Node (two lines)"
+msgstr "Csomópont (két vonal)"
+#: ../gui/wxpython/vdigit/preferences.py:810
+msgid "Vertex"
+msgstr "Töréspont"
+#: ../gui/wxpython/vdigit/preferences.py:811
+msgid "Area (closed boundary + centroid)"
+msgstr "Terület (zárt határvonal + centrális)"
+#: ../gui/wxpython/vdigit/preferences.py:812
+msgid "Direction"
+msgstr "Irány"
+#: ../gui/wxpython/vdigit/preferences.py:896
+msgid "Snapping disabled"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:900
+#, python-format
+msgid "Snapping threshold is %(value).1f %(units)s (based on comp. resolution)"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:956
+#, python-format
+msgid "Vector digitizer settings saved to file <%s>."
+msgstr ""
+#: ../gui/wxpython/vdigit/dialogs.py:79
+msgid "List of categories - right-click to delete"
+msgstr ""
+#: ../gui/wxpython/vdigit/dialogs.py:110
+msgid "Add new category"
+msgstr "Új kategória hozzáadás"
+#: ../gui/wxpython/vdigit/dialogs.py:151 ../gui/wxpython/psmap/dialogs.py:479
+#: ../gui/wxpython/web_services/dialogs.py:685
+msgid "Apply changes"
+msgstr "Módosítások elfogadása"
+#: ../gui/wxpython/vdigit/dialogs.py:153
+msgid "Ignore changes and close dialog"
+msgstr ""
+#: ../gui/wxpython/vdigit/dialogs.py:155
+#: ../gui/wxpython/web_services/dialogs.py:690
+msgid "Apply changes and close dialog"
+msgstr ""
+#: ../gui/wxpython/vdigit/dialogs.py:175 ../gui/wxpython/dbmgr/dialogs.py:149
+msgid "Feature id:"
+msgstr ""
+#: ../gui/wxpython/vdigit/dialogs.py:248 ../gui/wxpython/vdigit/dialogs.py:472
+#, python-format
+msgid ""
+"Unable to add new layer/category <%(layer)s/%(category)s>.\n"
+"Layer and category number must be integer.\n"
+"Layer number must be greater than zero."
+msgstr ""
+#: ../gui/wxpython/vdigit/dialogs.py:284
+#: ../gui/wxpython/gmodeler/dialogs.py:844
+#: ../gui/wxpython/gmodeler/dialogs.py:1013
+msgid "Delete selected"
+msgstr "Szelektáltakat töröl"
+#: ../gui/wxpython/vdigit/dialogs.py:288
+#: ../gui/wxpython/gmodeler/dialogs.py:845
+msgid "Delete all"
+msgstr "Mindent töröl"
+#: ../gui/wxpython/vdigit/dialogs.py:290 ../gui/wxpython/dbmgr/base.py:1438
+#: ../gui/wxpython/dbmgr/base.py:2588 ../gui/wxpython/gmodeler/dialogs.py:851
+#: ../gui/wxpython/gmodeler/dialogs.py:1017
+msgid "Reload"
+msgstr ""
+#: ../gui/wxpython/vdigit/dialogs.py:446
+msgid "Unable to update vector map."
+msgstr ""
+#: ../gui/wxpython/vdigit/dialogs.py:622
+#, python-format
+msgid "%d lines selected for z bulk-labeling"
+msgstr ""
+#: ../gui/wxpython/vdigit/dialogs.py:630
+msgid "Set value"
+msgstr ""
+#: ../gui/wxpython/vdigit/dialogs.py:637
+msgid "Starting value"
+msgstr "Kezdőérték"
+#: ../gui/wxpython/vdigit/dialogs.py:649
+msgid "Step"
+msgstr "Lépés"
+#: ../gui/wxpython/vdigit/dialogs.py:692
+msgid "List of duplicates"
+msgstr "Duplikáltak listája"
+#: ../gui/wxpython/vdigit/dialogs.py:801
+msgid "Feature id"
+msgstr "Elem id"
+#: ../gui/wxpython/vdigit/dialogs.py:802
+msgid "Layer (Categories)"
+msgstr "Réteg (Kategóriák)"
+#: ../gui/wxpython/vdigit/wxdisplay.py:1019
+#, python-format
+msgid "Topology for vector map <%s> is not available. Topology is required by digitizer. Do you want to rebuild topology (takes some time) and open the vector map for editing?"
+msgstr ""
+#: ../gui/wxpython/vdigit/wxdisplay.py:1024
+msgid "Topology missing"
+msgstr ""
+#: ../gui/wxpython/vdigit/wxdigit.py:57
+msgid "Digitization Error"
+#: ../gui/wxpython/vdigit/wxdigit.py:62
+#, python-format
+msgid "Unable to open vector map <%s>."
+msgstr "Nem tudom a vektor térképet megnyitni <%s>."
+#: ../gui/wxpython/vdigit/wxdigit.py:65
+msgid "Operation canceled."
+msgstr "Művelet megszakítva."
+#: ../gui/wxpython/vdigit/wxdigit.py:72
+#, python-format
+msgid ""
+"Writing new feature failed. Operation canceled.\n"
+"\n"
+"Reason: %s"
+msgstr ""
+#: ../gui/wxpython/vdigit/wxdigit.py:81
+#, python-format
+msgid "Reading feature id %d failed. Operation canceled."
+msgstr "%delem id olvasása sikertelen. A művelet megszakadt."
+#: ../gui/wxpython/vdigit/wxdigit.py:89
+#, python-format
+msgid "Database link %d not available. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/vdigit/wxdigit.py:97
+#, python-format
+msgid "Unable to start database driver <%s>. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/vdigit/wxdigit.py:107
+#, python-format
+msgid "Unable to open database <%(db)s> by driver <%(driver)s>. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/vdigit/wxdigit.py:115
+#, python-format
+msgid "Unable to execute SQL query '%s'. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/vdigit/wxdigit.py:123
+#, python-format
+msgid "Feature id %d is marked as dead. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/vdigit/wxdigit.py:131
+#, python-format
+msgid "Unsupported feature type %d. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/vdigit/wxdigit.py:501
+#, python-format
+msgid "Unknown feature type '%s'"
+msgstr "Ismeretlen elem típus '%s'"
+#: ../gui/wxpython/vdigit/wxdigit.py:506
+msgid "Not enough points for line"
+msgstr "Nincs elég pont avonalhoz"
+#: ../gui/wxpython/startup/locdownload.py:150
+#, python-brace-format
+msgid "ZIP file is unreadable: {0}"
+msgstr "ZIP fájl nem olvasható: {0}"
+#: ../gui/wxpython/startup/locdownload.py:169
+msgid "Archive file is unreadable: {0}"
+msgstr "Archív fájl nem olvasható: {0}"
+#: ../gui/wxpython/startup/locdownload.py:201
+msgid "Download of <{url}> failed or file <{name}> is not a ZIP file"
+msgstr ""
+#: ../gui/wxpython/startup/locdownload.py:217
+msgid "Unknown format '{0}'."
+msgstr "Ismeretlen formátum '{0}'."
+#: ../gui/wxpython/startup/locdownload.py:233
+msgid "Downloaded location is not valid"
+msgstr ""
+#: ../gui/wxpython/startup/locdownload.py:293
+msgid "Select sample location to download:"
+msgstr ""
+#: ../gui/wxpython/startup/locdownload.py:304
+msgid "Download selected location"
+msgstr ""
+#: ../gui/wxpython/startup/locdownload.py:360
+#: ../gui/wxpython/startup/locdownload.py:389
+msgid "Download in progress, wait until it is finished"
+msgstr ""
+#: ../gui/wxpython/startup/locdownload.py:373
+#, python-format
+msgid "Location named <%s> already exists, download canceled"
+msgstr ""
+#: ../gui/wxpython/startup/locdownload.py:381
+#, python-format
+msgid "Download failed: %s"
+msgstr ""
+#: ../gui/wxpython/startup/locdownload.py:384
+msgid "Download completed. The downloaded sample data is listed in the location/mapset tabs upon closing of this window"
+msgstr ""
+#: ../gui/wxpython/startup/locdownload.py:406
+#, python-format
+msgid "Location named <%s> already exists, rename it first"
+msgstr ""
+#: ../gui/wxpython/startup/locdownload.py:458
+msgid "GRASS GIS Location Download"
+msgstr ""
+#: ../gui/wxpython/startup/locdownload.py:491
+msgid "Do you want to cancel location download?"
+msgstr ""
+#: ../gui/wxpython/startup/locdownload.py:492
+msgid "Abort download"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:244
+msgid "Opening 3D view was not successful. Please try to change the value of depth buffer in GUI Settings dialog > tab Map Display > Advanced and restart GUI."
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:509
+#, python-format
+msgid "Image is too large, your OpenGL implementation supports maximum texture size %d px."
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:1021
+msgid "Easting"
+msgstr "Kelet"
+#: ../gui/wxpython/nviz/mapwindow.py:1022
+msgid "Northing"
+msgstr "Észak"
+#: ../gui/wxpython/nviz/mapwindow.py:1023
+msgid "Elevation"
+msgstr "Magasság"
+#: ../gui/wxpython/nviz/mapwindow.py:1029
+msgid "Surface map name"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:1032
+msgid "Surface map elevation"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:1034
+msgid "Surface map color"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:1045
+msgid "XY distance from previous"
+msgstr "XY távolság az előzőtől"
+#: ../gui/wxpython/nviz/mapwindow.py:1048
+msgid "XYZ distance from previous"
+msgstr "XYZ távolság az előzőtől"
+#: ../gui/wxpython/nviz/mapwindow.py:1051
+msgid "Distance along surface"
+msgstr "Távolság a felszín mentén"
+#: ../gui/wxpython/nviz/mapwindow.py:1055
+msgid "Distance along exag. surface"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:1059
+msgid "No point on surface"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:1539
+msgid "Loading raster map"
+msgstr "Raszter térkép betöltés"
+#: ../gui/wxpython/nviz/mapwindow.py:1543
+msgid "Loading 3d raster map"
+msgstr "3D raszter térkép betöltés"
+#: ../gui/wxpython/nviz/mapwindow.py:1551
+msgid "failed"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:1554
+#, python-format
+msgid "Unsupported layer type '%s'"
+msgstr "Nem támogatott réteg típus '%s'"
+#: ../gui/wxpython/nviz/mapwindow.py:1674
+msgid "Unable to unload raster map"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:1679
+msgid "Unable to unload 3d raster map"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:1680
+msgid "3d raster map"
+msgstr "3D raszter térkép"
+#: ../gui/wxpython/nviz/mapwindow.py:1692
+msgid "unloaded successfully"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:1748
+#, python-format
+msgid "Loading vector map <%(name)s> (%(type)s) failed"
+msgstr "A <%(name)s> (%(type)s) vektor térkép betöltése sikertelen"
+#: ../gui/wxpython/nviz/mapwindow.py:1811
+#, python-format
+msgid "Unable to unload vector map <%(name)s> (%(type)s)"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:1815
+#, python-format
+msgid "Vector map <%(name)s> (%(type)s) unloaded successfully"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:2192
+#, python-format
+msgid "Vector point layer not found (id = %d)"
+msgstr "A vektor pont réteget nem találom (id = %d)"
+#: ../gui/wxpython/nviz/mapwindow.py:2194
+#, python-format
+msgid "Unable to set data layer properties (id = %d)"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:2198
+#, python-format
+msgid ""
+"Setting data layer properties failed.\n"
+"\n"
+"%s"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:2253
+#: ../gui/wxpython/nviz/mapwindow.py:2272 ../gui/wxpython/nviz/tools.py:2679
+#: ../gui/wxpython/nviz/tools.py:2728 ../gui/wxpython/nviz/tools.py:5172
+msgid "constant#"
+msgstr ""
+#: ../gui/wxpython/nviz/wxnviz.py:35
+msgid "This module requires the NumPy module, which could not be imported. It probably is not installed (it's not part of the standard Python distribution). See the Numeric Python site (http://numpy.scipy.org) for information on downloading source or binaries."
+msgstr "Ez a modul a NumPy modult igényli, melyet nem tudtam importálni. Ezt valószínűleg nem telepítették (ez nem része a standard Python kiadásoknak). Lásd a Numeric Python oldalt (http://numpy.scipy.org) a forrás vagy bináris letöltési információkért."
+#: ../gui/wxpython/nviz/wxnviz.py:510 ../gui/wxpython/nviz/wxnviz.py:522
+#, python-format
+msgid "3d raster map <%s> not found"
+msgstr "<%s> 3D raszter térképet nem találom"
+#: ../gui/wxpython/nviz/tools.py:92 ../gui/wxpython/nviz/preferences.py:69
+#: ../gui/wxpython/nviz/preferences.py:74
+msgid "View"
+msgstr "Nézet"
+#: ../gui/wxpython/nviz/tools.py:96 ../gui/wxpython/lmgr/frame.py:380
+#: ../gui/wxpython/gmodeler/preferences.py:250
+msgid "Data"
+msgstr "Adat"
+#: ../gui/wxpython/nviz/tools.py:100
+#: ../gui/wxpython/gui_core/preferences.py:490
+msgid "Appearance"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:104
+msgid "Analysis"
+msgstr "Elemzés"
+#: ../gui/wxpython/nviz/tools.py:107 ../gui/wxpython/nviz/tools.py:502
+msgid "Animation"
+msgstr "Animáció"
+#: ../gui/wxpython/nviz/tools.py:252
+msgid "Control View"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:276
+msgid "Adjusts the distance and angular perspective of the image viewpoint"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:292 ../gui/wxpython/nviz/preferences.py:86
+msgid "Perspective:"
+msgstr "Perspektíva:"
+#: ../gui/wxpython/nviz/tools.py:304
+msgid "Tilts the plane of the surface from the horizontal"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:316 ../gui/wxpython/nviz/tools.py:1263
+msgid "Tilt:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:329
+msgid "Adjusts the viewing height above the surface (angle of view automatically adjusts to maintain the same center of view)"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:345
+msgid "Adjusts the relative height of features above the plane of the surface"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:366 ../gui/wxpython/nviz/tools.py:1285
+#: ../gui/wxpython/nviz/tools.py:2126 ../gui/wxpython/gui_core/dialogs.py:1937
+#: ../gui/wxpython/psmap/dialogs.py:3849 ../gui/wxpython/psmap/dialogs.py:4066
+#: ../gui/wxpython/psmap/dialogs.py:4857
+#: ../gui/wxpython/gmodeler/preferences.py:210
+#: ../gui/wxpython/gmodeler/preferences.py:376
+#: ../gui/wxpython/gmodeler/preferences.py:488
+#: ../gui/wxpython/gmodeler/preferences.py:604
+msgid "Height:"
+msgstr "Magasság:"
+#: ../gui/wxpython/nviz/tools.py:387 ../gui/wxpython/nviz/preferences.py:176
+msgid "Z-exag:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:412
+msgid "Look:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:415
+msgid "here"
+msgstr "itt"
+#: ../gui/wxpython/nviz/tools.py:418
+msgid "Allows you to select a point on the surface that becomes the new center of view. Click on the button and then on the surface."
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:424
+msgid "center"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:428
+msgid "Resets the view to the original default center of view"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:432
+msgid "top"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:436
+msgid "Sets the viewer directly over the scene's center position. This top view orients approximately north south."
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:440
+msgid "reset"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:441
+msgid "Reset to default view"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:458 ../gui/wxpython/nviz/preferences.py:198
+msgid "Image Appearance"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:465 ../gui/wxpython/nviz/preferences.py:204
+#: ../gui/wxpython/gui_core/preferences.py:883
+#: ../gui/wxpython/animation/dialogs.py:1867
+#: ../gui/wxpython/web_services/widgets.py:317
+msgid "Background color:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:510
+msgid "Press 'Record' button and start changing the view. It is recommended to use fly-through mode (Map Display toolbar) to achieve smooth motion."
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:521
+msgid "Record"
+msgstr "Felvétel"
+#: ../gui/wxpython/nviz/tools.py:523
+msgid "Play"
+msgstr "Lejátszás"
+#: ../gui/wxpython/nviz/tools.py:525 ../gui/wxpython/animation/toolbars.py:42
+msgid "Pause"
+msgstr "Szünet"
+#: ../gui/wxpython/nviz/tools.py:527 ../gui/wxpython/animation/toolbars.py:39
+msgid "Stop"
+msgstr "Állj"
+#: ../gui/wxpython/nviz/tools.py:544
+msgid "Total number of frames :"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:551
+msgid "Frame rate (FPS):"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:559
+msgid "Frames are recorded with given frequency (FPS). "
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:615
+msgid "Save image sequence"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:624 ../gui/wxpython/psmap/dialogs.py:5794
+msgid "Choose a directory:"
+msgstr "Válasszon egy könyvtárat:"
+#: ../gui/wxpython/nviz/tools.py:625
+msgid "Choose a directory for images"
+msgstr "Válasszon könyvtárat a képekhez"
+#: ../gui/wxpython/nviz/tools.py:632 ../gui/wxpython/animation/dialogs.py:1190
+msgid "File prefix:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:638
+msgid "Generated files names will look like this: prefix_1.ppm, prefix_2.ppm, ..."
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:640 ../gui/wxpython/animation/dialogs.py:1194
+msgid "File format:"
+msgstr "Fájl formátum:"
+#: ../gui/wxpython/nviz/tools.py:705 ../gui/wxpython/nviz/tools.py:2236
+#: ../gui/wxpython/nviz/preferences.py:398
+msgid "Surface"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:713 ../gui/wxpython/nviz/tools.py:1345
+msgid "Constant surface"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:720 ../gui/wxpython/nviz/preferences.py:546
+msgid "Vector"
+msgstr "Vektor"
+#: ../gui/wxpython/nviz/tools.py:728 ../gui/wxpython/gui_core/dialogs.py:1452
+msgid "3D raster"
+msgstr "3D raszter"
+#: ../gui/wxpython/nviz/tools.py:766 ../gui/wxpython/nviz/preferences.py:287
+msgid "Lighting"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:773
+msgid "Fringe"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:782 ../gui/wxpython/animation/dialogs.py:932
+msgid "Decorations"
+msgstr "Dekorációk"
+#: ../gui/wxpython/nviz/tools.py:804 ../gui/wxpython/nviz/tools.py:1146
+msgid "Cutting planes"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:850 ../gui/wxpython/nviz/tools.py:1889
+#: ../gui/wxpython/nviz/preferences.py:405 ../gui/wxpython/tplot/frame.py:277
+#: ../gui/wxpython/timeline/frame.py:135
+msgid "Draw"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:856 ../gui/wxpython/nviz/tools.py:1896
+#: ../gui/wxpython/nviz/preferences.py:414
+msgid "Mode:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:859 ../gui/wxpython/nviz/preferences.py:420
+msgid "coarse"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:860 ../gui/wxpython/nviz/preferences.py:421
+msgid "fine"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:861 ../gui/wxpython/nviz/preferences.py:422
+msgid "both"
+msgstr "mindkettő"
+#: ../gui/wxpython/nviz/tools.py:871 ../gui/wxpython/nviz/tools.py:1162
+#: ../gui/wxpython/nviz/tools.py:1910
+msgid "Shading:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:874 ../gui/wxpython/nviz/tools.py:1913
+msgid "flat"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:875 ../gui/wxpython/nviz/tools.py:1914
+msgid "gouraud"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:883
+msgid "Set to all"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:884
+msgid "Use draw settings for all loaded surfaces"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:896 ../gui/wxpython/nviz/preferences.py:466
+msgid "Coarse mode:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:899 ../gui/wxpython/nviz/tools.py:945
+#: ../gui/wxpython/nviz/preferences.py:447
+#: ../gui/wxpython/nviz/preferences.py:478
+msgid "resolution:"
+msgstr "felbontás:"
+#: ../gui/wxpython/nviz/tools.py:914 ../gui/wxpython/nviz/preferences.py:496
+msgid "style:"
+msgstr "stílus:"
+#: ../gui/wxpython/nviz/tools.py:917 ../gui/wxpython/nviz/preferences.py:502
+msgid "wire"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:918 ../gui/wxpython/nviz/preferences.py:503
+msgid "surface"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:930
+msgid "Change wire color"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:941 ../gui/wxpython/nviz/preferences.py:435
+msgid "Fine mode:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:969
+msgid "Surface attributes"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:978 ../gui/wxpython/nviz/tools.py:2818
+msgid "Transparency"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:979 ../gui/wxpython/nviz/tools.py:2819
+msgid "Shininess"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:985 ../gui/wxpython/nviz/tools.py:2839
+msgid "map"
+msgstr "térkép"
+#: ../gui/wxpython/nviz/tools.py:988 ../gui/wxpython/nviz/tools.py:2844
+msgid "unset"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:993 ../gui/wxpython/nviz/tools.py:2849
+msgid "constant"
+msgstr "konstans"
+#: ../gui/wxpython/nviz/tools.py:1050 ../gui/wxpython/nviz/tools.py:2021
+#: ../gui/wxpython/psmap/dialogs.py:3798 ../gui/wxpython/psmap/dialogs.py:4518
+#: ../gui/wxpython/psmap/dialogs.py:4796 ../gui/wxpython/psmap/dialogs.py:5377
+#: ../gui/wxpython/psmap/dialogs.py:5385 ../gui/wxpython/psmap/dialogs.py:5945
+#: ../gui/wxpython/psmap/dialogs.py:5954 ../gui/wxpython/psmap/dialogs.py:6529
+#: ../gui/wxpython/psmap/dialogs.py:6538
+msgid "Position"
+msgstr "Pozíció"
+#: ../gui/wxpython/nviz/tools.py:1055
+msgid "Changes the x, y, and z position of the current surface"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1072 ../gui/wxpython/nviz/tools.py:1322
+#: ../gui/wxpython/nviz/tools.py:2041 ../gui/wxpython/nviz/tools.py:3042
+msgid "Reset"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1073 ../gui/wxpython/nviz/tools.py:2042
+msgid "Reset to default position"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1152
+msgid "Active cutting plane:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1164
+msgid "clear"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1165
+msgid "top color"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1166
+msgid "bottom color"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1167
+msgid "blend"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1168
+msgid "shaded"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1180
+msgid "Horizontal X:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1182
+msgid "Sets the X coordinate of the current cutting plane"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1210
+msgid "Horizontal Y:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1212
+msgid "Sets the Y coordinate of the current cutting plane"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1241
+msgid "Rotation:"
+msgstr "Forgatás:"
+#: ../gui/wxpython/nviz/tools.py:1243
+msgid "Rotates the current cutting plane about vertical axis"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1265
+msgid "Rotates the current cutting plane about horizontal axis"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1288
+msgid "Sets the Z coordinate of the current cutting plane (only meaningful when tilt is not 0)"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1385
+msgid "Fine resolution:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1399
+msgid "Value:"
+msgstr "Érték:"
+#: ../gui/wxpython/nviz/tools.py:1411 ../gui/wxpython/nviz/tools.py:3031
+msgid "Transparency:"
+msgstr "Átlátszóság:"
+#: ../gui/wxpython/nviz/tools.py:1477
+msgid "Show vector lines"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1487 ../gui/wxpython/nviz/preferences.py:552
+msgid "Vector lines"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1493
+msgid "Line:"
+msgstr "Vonal:"
+#: ../gui/wxpython/nviz/tools.py:1496
+msgid "width:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1512 ../gui/wxpython/nviz/tools.py:1684
+msgid "color:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1529 ../gui/wxpython/nviz/tools.py:1733
+msgid "use color for thematic mapping"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1532
+msgid "use width for thematic mapping"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1547 ../gui/wxpython/nviz/tools.py:1560
+#: ../gui/wxpython/nviz/tools.py:1756 ../gui/wxpython/nviz/tools.py:1773
+msgid "Set options..."
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1579 ../gui/wxpython/nviz/tools.py:5442
+#: ../gui/wxpython/nviz/tools.py:5497
+msgid "on surface(s):"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1580 ../gui/wxpython/nviz/tools.py:5442
+msgid "as 3D"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1589 ../gui/wxpython/nviz/tools.py:1796
+msgid "Height above surface:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1640
+msgid "Show vector points"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1649 ../gui/wxpython/nviz/preferences.py:592
+msgid "Vector points"
+msgstr "Vektor pontok"
+#: ../gui/wxpython/nviz/tools.py:1656
+msgid "Icon:"
+msgstr "Ikon:"
+#: ../gui/wxpython/nviz/tools.py:1659 ../gui/wxpython/psmap/dialogs.py:2735
+msgid "size:"
+msgstr "méret:"
+#: ../gui/wxpython/nviz/tools.py:1717 ../gui/wxpython/psmap/dialogs.py:2661
+msgid "symbol:"
+msgstr "szimbólum:"
+#: ../gui/wxpython/nviz/tools.py:1736
+msgid "use size for thematic mapping"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1866 ../gui/wxpython/lmgr/layertree.py:1052
+msgid "3D raster map"
+#: ../gui/wxpython/nviz/tools.py:1899
+msgid "isosurfaces"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1900
+msgid "slices"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1923
+msgid "Resolution:"
+msgstr "Felbontás:"
+#: ../gui/wxpython/nviz/tools.py:1937
+msgid "Draw wire box"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1953 ../gui/wxpython/nviz/tools.py:4279
+msgid "List of isosurfaces"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:2087
+msgid "Show light model"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:2100
+msgid "Light source position"
+msgstr "Fényforrás pozíció"
+#: ../gui/wxpython/nviz/tools.py:2117
+msgid "Adjusts the light height"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:2148
+msgid "Light color and intensity"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:2166 ../gui/wxpython/nviz/preferences.py:345
+msgid "Brightness:"
+msgstr "Fényesség:"
+#: ../gui/wxpython/nviz/tools.py:2168
+msgid "Adjusts the brightness of the light"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:2183 ../gui/wxpython/nviz/preferences.py:359
+msgid "Ambient:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:2185
+msgid "Adjusts the ambient light"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:2250
+msgid "Edges with fringe"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:2252
+msgid "N && W"
+msgstr "É && Ny"
+#: ../gui/wxpython/nviz/tools.py:2253
+msgid "N && E"
+msgstr "É && K"
+#: ../gui/wxpython/nviz/tools.py:2254
+msgid "S && W"
+msgstr "D && Ny"
+#: ../gui/wxpython/nviz/tools.py:2255
+msgid "S && E"
+msgstr "D && K"
+#: ../gui/wxpython/nviz/tools.py:2280
+msgid "Elevation of fringe from bottom:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:2337
+msgid "Arrow length (in map units):"
+msgstr "Nyíl hossz (térképi egységekben):"
+#: ../gui/wxpython/nviz/tools.py:2349
+msgid "Arrow color:"
+msgstr "Nyíl szín:"
+#: ../gui/wxpython/nviz/tools.py:2361
+msgid "Place arrow"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:2386
+msgid "Scale bar length (in map units):"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:2398
+msgid "Scale bar color:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:2410
+msgid "Place new scale bar"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:2482
+msgid "Do you want to record new animation without saving the previous one?"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:2485
+msgid "Animation already axists"
+msgstr "Animáció már létezik"
+#: ../gui/wxpython/nviz/tools.py:2655
+msgid "No file prefix given."
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:2659
+#, python-format
+msgid "Directory %s does not exist."
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:2800
+msgid "Isosurface attributes"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:2806
+msgid "toggle normal direction"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:2815
+msgid "Isosurface value"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:2932
+msgid "Slice attributes"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:2941
+msgid "Slice parallel to axis:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:3099
+msgid "W"
+msgstr "Ny"
+#: ../gui/wxpython/nviz/tools.py:3100
+msgid "N"
+msgstr "É"
+#: ../gui/wxpython/nviz/tools.py:3101
+msgid "S"
+msgstr "D"
+#: ../gui/wxpython/nviz/tools.py:3102
+msgid "E"
+msgstr "K"
+#: ../gui/wxpython/nviz/tools.py:3103
+msgid "NW"
+msgstr "ÉNy"
+#: ../gui/wxpython/nviz/tools.py:3104
+msgid "NE"
+msgstr "ÉK"
+#: ../gui/wxpython/nviz/tools.py:3105
+msgid "SE"
+msgstr "DK"
+#: ../gui/wxpython/nviz/tools.py:3106
+msgid "SW"
+msgstr "DNy"
+#: ../gui/wxpython/nviz/tools.py:3624 ../gui/wxpython/nviz/tools.py:5560
+msgid "Level"
+msgstr "Szint"
+#: ../gui/wxpython/nviz/tools.py:4285
+msgid "List of slices"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:4483 ../gui/wxpython/nviz/tools.py:4485
+msgid "Level {level}"
+msgstr "Szint {level}"
+#: ../gui/wxpython/nviz/tools.py:4493 ../gui/wxpython/nviz/tools.py:4497
+msgid "Slice parallel to {axis}"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:4785 ../gui/wxpython/nviz/tools.py:5573
+msgid "Slice parallel to"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:5017
+#, python-format
+msgid "Scalebar %d"
+msgstr "Lépték vonalzó %d"
+#: ../gui/wxpython/nviz/tools.py:5179
+msgid "None"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:5381
+msgid "Vector map is 3D"
+msgstr "A vektor térkép 3D-s"
+#: ../gui/wxpython/nviz/tools.py:5384
+msgid "Vector map is 2D"
+msgstr "A vektor térkép 2D-s"
+#: ../gui/wxpython/nviz/tools.py:5386
+#, python-format
+msgid "%(features)d features (%(points)d points)"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:5444 ../gui/wxpython/nviz/tools.py:5499
+msgid "on surface"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:5597
+msgid "range:"
+msgstr "tartomány:"
+#: ../gui/wxpython/nviz/tools.py:5676 ../gui/wxpython/nviz/tools.py:5687
+msgid "North edge:"
+msgstr "Északi él:"
+#: ../gui/wxpython/nviz/tools.py:5677 ../gui/wxpython/nviz/tools.py:5688
+msgid "South edge:"
+msgstr "Déli él:"
+#: ../gui/wxpython/nviz/tools.py:5678 ../gui/wxpython/nviz/tools.py:5685
+#: ../gui/wxpython/nviz/tools.py:5694
+msgid "West edge:"
+msgstr "Nyugati él:"
+#: ../gui/wxpython/nviz/tools.py:5679 ../gui/wxpython/nviz/tools.py:5686
+#: ../gui/wxpython/nviz/tools.py:5695
+msgid "East edge:"
+msgstr "Keleti él:"
+#: ../gui/wxpython/nviz/tools.py:5681 ../gui/wxpython/nviz/tools.py:5692
+#: ../gui/wxpython/nviz/tools.py:5700
+msgid "Northing (Y):"
+msgstr "Észak (Y):"
+#: ../gui/wxpython/nviz/tools.py:5682 ../gui/wxpython/nviz/tools.py:5691
+#: ../gui/wxpython/nviz/tools.py:5701
+msgid "Height (Z):"
+msgstr "Magasság (Z):"
+#: ../gui/wxpython/nviz/tools.py:5683 ../gui/wxpython/nviz/tools.py:5690
+#: ../gui/wxpython/nviz/tools.py:5699
+msgid "Easting (X):"
+msgstr "Kelet (X):"
+#: ../gui/wxpython/nviz/tools.py:5696
+msgid "Bottom edge:"
+msgstr "Alsó él:"
+#: ../gui/wxpython/nviz/tools.py:5697
+msgid "Top edge:"
+msgstr "Felső él:"
+#: ../gui/wxpython/nviz/tools.py:5808
+msgid "Adjusts the distance and direction of the image viewpoint"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:5843
+msgid "Adjusts the light direction. Click and drag the puck to change the light direction."
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:35
+msgid "3D view default settings"
+msgstr "3D nézet alapértelmezett beállítások"
+#: ../gui/wxpython/nviz/preferences.py:62
+msgid "Revert settings to default, changes are not applied"
+msgstr "Beállítások visszaállítása az alapértelmezettre, a változásokat nem alkalmazom"
+#: ../gui/wxpython/nviz/preferences.py:90
+#: ../gui/wxpython/nviz/preferences.py:161
+#: ../gui/wxpython/nviz/preferences.py:180
+msgid "value:"
+msgstr "érték:"
+#: ../gui/wxpython/nviz/preferences.py:103
+msgid "step:"
+msgstr "lépés:"
+#: ../gui/wxpython/nviz/preferences.py:118
+#: ../gui/wxpython/nviz/preferences.py:300
+msgid "Position:"
+msgstr "Pozíció:"
+#: ../gui/wxpython/nviz/preferences.py:122
+#: ../gui/wxpython/nviz/preferences.py:304
+msgid "x:"
+msgstr "x:"
+#: ../gui/wxpython/nviz/preferences.py:157
+msgid "Twist:"
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:237
+msgid "Fly-through"
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:241
+#: ../gui/wxpython/mapdisp/toolbars.py:68
+msgid "Fly-through mode"
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:247
+msgid "Move exag:"
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:260
+msgid "Turn exag:"
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:292
+msgid "Light"
+msgstr "Fény"
+#: ../gui/wxpython/nviz/preferences.py:330
+msgid "z:"
+msgstr "z:"
+#: ../gui/wxpython/nviz/preferences.py:517
+msgid "wire color:"
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:598
+msgid "Automatic size"
+msgstr "Automatikus méret"
+#: ../gui/wxpython/nviz/preferences.py:599
+msgid "Icon size is set automatically based on landscape dimensions."
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:607
+#: ../gui/wxpython/mapswipe/dialogs.py:350
+msgid "Size:"
+msgstr "Méret:"
+#: ../gui/wxpython/nviz/preferences.py:623
+msgid "Marker:"
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:724
+#, python-format
+msgid "3D view settings saved to file <%s>."
+msgstr ""
+#: ../gui/wxpython/gui_core/query.py:31
+msgid "Query results"
+msgstr "Lekérdezés eredmények"
+#: ../gui/wxpython/gui_core/query.py:43
+msgid "Right click to copy selected values to clipboard."
+msgstr "Jobb gomb kattintás a szelektált értékeke vágólapra másolásához."
+#: ../gui/wxpython/gui_core/query.py:49
+msgid "Feature"
+msgstr ""
+msgid "Value"
+msgstr "Érték"
+#: ../gui/wxpython/gui_core/query.py:71
+msgid "Copy all to clipboard"
+msgstr "Minden másolása a vágólapra"
+#: ../gui/wxpython/gui_core/query.py:74
+msgid "Redirect to console"
+msgstr ""
+#: ../gui/wxpython/gui_core/query.py:136 ../gui/wxpython/gui_core/query.py:139
+#, python-format
+msgid "Copy from '%s' column"
+msgstr "Másolás a '%s' oszlopból"
+#: ../gui/wxpython/gui_core/query.py:141
+msgid "Copy selected lines"
+msgstr "Szelektált sorok másolása"
+#: ../gui/wxpython/gui_core/query.py:144 ../gui/wxpython/gui_core/query.py:149
+#, python-format
+msgid "Copy '%s'"
+msgstr "Másolás '%s'"
+#: ../gui/wxpython/gui_core/query.py:151
+msgid "Copy line"
+msgstr "Sor másolás"
+#: ../gui/wxpython/gui_core/query.py:178
+msgid "Query results:"
+msgstr "Lekérdezés eredmények:"
+#: ../gui/wxpython/gui_core/query.py:181
+msgid " "
+msgstr ""
+#: ../gui/wxpython/gui_core/query.py:270
+msgid "east, north"
+msgstr "kelet, észak"
+#: ../gui/wxpython/gui_core/query.py:281
+msgid "Nothing found"
+msgstr "Semmit sem találtam"
+#: ../gui/wxpython/gui_core/forms.py:551
+msgid "Enter parameters for '"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:567
+msgid "Close this window without executing the command (Ctrl+Q)"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:598
+msgid "Run the command (Ctrl+R)"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:626
+msgid "Show manual page of the command (Ctrl+H)"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:665
+msgid "Add created map(s) into layer tree"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:695
+msgid "Close dialog when command is successfully finished. Change this settings in Preferences dialog ('Command' tab)."
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:880
+#, python-format
+msgid "'%s' copied to clipboard"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:964 ../gui/wxpython/gui_core/forms.py:978
+msgid "Required"
+msgstr "Kötelező"
+#: ../gui/wxpython/gui_core/forms.py:967 ../gui/wxpython/gui_core/forms.py:979
+msgid "Optional"
+msgstr "Opcionális"
+#: ../gui/wxpython/gui_core/forms.py:1062
+#: ../gui/wxpython/gui_core/forms.py:2067
+msgid "Parameterized in model"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:1131
+msgid "This option is required"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:1152
+msgid "[multiple]"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:1210
+msgid "valid range"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:1320
+#: ../gui/wxpython/gui_core/forms.py:2698
+#: ../gui/wxpython/gui_core/toolbars.py:70
+msgid "Select font"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:1432 ../gui/wxpython/lmgr/toolbars.py:157
+msgid "Graphical Modeler"
+msgstr "Grfikus modellező"
+#: ../gui/wxpython/gui_core/forms.py:1438
+#: ../gui/wxpython/gui_core/preferences.py:771
+msgid "Map Display"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:1551
+msgid "Show graphical representation of temporal extent of dataset(s) ."
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:1781
+#: ../gui/wxpython/gui_core/preferences.py:1339
+#: ../gui/wxpython/gui_core/preferences.py:1374
+msgid "Transparent"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:1817
+#: ../gui/wxpython/gui_core/forms.py:1909
+#, python-format
+msgid "Choose %s"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:1820
+#: ../gui/wxpython/gmodeler/frame.py:1750
+msgid "file"
+msgstr "fájl"
+#: ../gui/wxpython/gui_core/forms.py:1862
+msgid "Load and edit content of a file"
+msgstr "Fájl tartalmának betöltése és módosítása"
+#: ../gui/wxpython/gui_core/forms.py:1865
+msgid "&Save as"
+msgstr "Mentés másként"
+#: ../gui/wxpython/gui_core/forms.py:1867
+msgid "Save content to a file for further use"
+msgstr "Fájl tartalmának mentése későbbi felhasználásra"
+#: ../gui/wxpython/gui_core/forms.py:1872
+msgid "or enter values directly:"
+msgstr "vagy adja meg az értéket közvetlenül"
+#: ../gui/wxpython/gui_core/forms.py:1874
+msgid "Enter file content directly instead of specifying a file. Temporary file will be automatically created."
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:1912
+#: ../gui/wxpython/gui_core/gselect.py:1437
+msgid "Directory"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:2257 ../gui/wxpython/gmodeler/frame.py:171
+msgid "Command output"
+msgstr "Parancs output"
+#: ../gui/wxpython/gui_core/forms.py:2270
+msgid "Manual"
+msgstr "Kézikönyv"
+#: ../gui/wxpython/gui_core/forms.py:2314
+msgid "Nothing to load."
+msgstr "Nincs mit betölteni."
+#: ../gui/wxpython/gui_core/forms.py:2322
+#, python-format
+msgid ""
+"Unable to load file.\n"
+"\n"
+"Reason: %s"
+msgstr ""
+"Nem tudom betölteni a fájlt.\n"
+"\n"
+"Ok: %s"
+#: ../gui/wxpython/gui_core/forms.py:2352
+msgid "Save input as..."
+msgstr "Input mentése másként..."
+#: ../gui/wxpython/gui_core/forms.py:2685
+msgid "No dataset given."
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:2854
+#: ../gui/wxpython/gui_core/forms.py:2871
+#, python-format
+msgid "Unable to parse command '%s'"
+msgstr "Nem tudom értelmezni a parancsot '%s'"
+#: ../gui/wxpython/gui_core/forms.py:2878
+#, python-format
+msgid "%(cmd)s: parameter '%(key)s' not available"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:2960
+msgid "Try to set up GRASS_ADDON_PATH or GRASS_ADDON_BASE variable."
+msgstr ""
+#: ../gui/wxpython/gui_core/pyedit.py:279
+#: ../gui/wxpython/gmodeler/frame.py:2028
+#, python-format
+msgid "Unable to launch Python script. %s"
+msgstr ""
+#: ../gui/wxpython/gui_core/pyedit.py:315
+#: ../gui/wxpython/gmodeler/frame.py:2055
+msgid "Choose file to save"
+msgstr ""
+#: ../gui/wxpython/gui_core/pyedit.py:317
+#: ../gui/wxpython/gui_core/pyedit.py:379
+#: ../gui/wxpython/gmodeler/frame.py:2060
+msgid "Python script (*.py)|*.py"
+msgstr ""
+#: ../gui/wxpython/gui_core/pyedit.py:335
+#: ../gui/wxpython/gmodeler/frame.py:2080
+msgid "Save file"
+msgstr ""
+#: ../gui/wxpython/gui_core/pyedit.py:377
+msgid "Open file"
+msgstr ""
+#: ../gui/wxpython/gui_core/pyedit.py:448
+msgid "Replace the content by the template?"
+msgstr ""
+#: ../gui/wxpython/gui_core/pyedit.py:450
+msgid "Replace the content by the example?"
+msgstr ""
+#: ../gui/wxpython/gui_core/pyedit.py:452
+msgid "Replace the current content by the file content?"
+msgstr ""
+#: ../gui/wxpython/gui_core/pyedit.py:458
+msgid "Replace content"
+msgstr ""
+#: ../gui/wxpython/gui_core/pyedit.py:470
+msgid "Set parameters for the script"
+msgstr ""
+#: ../gui/wxpython/gui_core/pyedit.py:471
+msgid "Specify command line parameters for the script separated by spaces:"
+msgstr ""
+#: ../gui/wxpython/gui_core/pyedit.py:521
+msgid "Open (Ctrl+O)"
+msgstr ""
+#: ../gui/wxpython/gui_core/pyedit.py:523
+msgid "Save (Ctrl+S)"
+msgstr ""
+#: ../gui/wxpython/gui_core/pyedit.py:525
+msgid "Run (Ctrl+R)"
+msgstr ""
+#: ../gui/wxpython/gui_core/pyedit.py:528
+msgid "Activate overwrite"
+msgstr ""
+#: ../gui/wxpython/gui_core/pyedit.py:530
+msgid "Deactive overwrite"
+msgstr ""
+#: ../gui/wxpython/gui_core/pyedit.py:581
+msgid "GRASS GIS Simple Python Editor"
+msgstr ""
+#: ../gui/wxpython/gui_core/menu.py:153
+msgid "Double-click or Ctrl-Enter to run selected module"
+msgstr ""
+#: ../gui/wxpython/gui_core/menu.py:175
+msgid "Run selected module from the tree"
+msgstr ""
+#: ../gui/wxpython/gui_core/menu.py:176
+msgid "H&elp"
+msgstr ""
+#: ../gui/wxpython/gui_core/menu.py:178
+msgid "Show manual for selected module from the tree"
+msgstr ""
+#: ../gui/wxpython/gui_core/menu.py:180
+msgid "Adva&nced search..."
+msgstr ""
+#: ../gui/wxpython/gui_core/menu.py:182
+#, python-format
+msgid "Do advanced search using %s module"
+msgstr ""
+#: ../gui/wxpython/gui_core/menu.py:283
+#, python-format
+msgid "Documentation for %s is now open in the web browser"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:75
+msgid "Info"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:76
+msgid "Copyright"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:77
+msgid "License"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:78
+msgid "Citation"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:79
+msgid "Authors"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:80
+msgid "Contributors"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:81
+msgid "Extra contributors"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:82
+msgid "Translators"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:83
+msgid "Translation status"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:118 ../gui/wxpython/gui_core/ghelp.py:921
+#: ../gui/wxpython/lmgr/frame.py:87 ../gui/wxpython/lmgr/frame.py:1217
+msgid "Unable to get GRASS version\n"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:131 ../gui/wxpython/lmgr/frame.py:1241
+msgid "unknown version"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:147
+msgid "Official GRASS site:"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:158
+msgid "Code Revision"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:169
+msgid "Build Date"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:223 ../gui/wxpython/gui_core/ghelp.py:481
+msgid "Language"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:252 ../gui/wxpython/gui_core/ghelp.py:277
+#: ../gui/wxpython/gui_core/ghelp.py:328 ../gui/wxpython/gui_core/ghelp.py:391
+#: ../gui/wxpython/gui_core/ghelp.py:465 ../gui/wxpython/gui_core/ghelp.py:630
+#, python-format
+msgid "%s file missing"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:300
+msgid "Unable to provide citation suggestion, see GRASS GIS website instead. The error was: {0}"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:376 ../gui/wxpython/gui_core/ghelp.py:449
+#, python-format
+msgid "Error when reading file '%s'."
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:377 ../gui/wxpython/gui_core/ghelp.py:450
+msgid "Lines:"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:397 ../gui/wxpython/gui_core/ghelp.py:399
+#: ../gui/wxpython/gui_core/ghelp.py:473 ../gui/wxpython/gmodeler/frame.py:1731
+#: ../gui/wxpython/gmodeler/frame.py:1778
+#: ../gui/wxpython/web_services/widgets.py:934
+msgid "Name"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:477
+msgid "E-mail"
+msgstr ""
+msgid "Country"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:399
+msgid "OSGeo_ID"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:485
+msgid "Nation"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:534
+#, python-format
+msgid " %d translated"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:538 ../gui/wxpython/gui_core/ghelp.py:564
+#, python-format
+msgid " %d fuzzy"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:542 ../gui/wxpython/gui_core/ghelp.py:573
+#, python-format
+msgid " %d untranslated"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:555
+#, python-format
+msgid "%d translated"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:627
+#, python-format
+msgid "File <%s> not found"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:800
+msgid "&Next"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:803
+msgid "&Previous"
+msgstr ""
+#: ../gui/wxpython/gui_core/vselect.py:48
+msgid "category"
+msgstr ""
+#: ../gui/wxpython/gui_core/vselect.py:49 ../gui/wxpython/vnet/vnet_data.py:259
+msgid "type"
+msgstr ""
+#: ../gui/wxpython/gui_core/vselect.py:73
+msgid "Select features"
+msgstr ""
+#: ../gui/wxpython/gui_core/vselect.py:136
+msgid "Create a new map"
+msgstr ""
+#: ../gui/wxpython/gui_core/vselect.py:265
+#, python-format
+msgid "Selected map <%s> has been disabled for rendering. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/gui_core/vselect.py:277 ../gui/wxpython/lmgr/frame.py:2557
+#: ../gui/wxpython/mapdisp/frame.py:594
+msgid "No map layer selected. Operation canceled."
+msgstr "Nincs kiválasztott térkép réteg. A művelet megszakadt."
+#: ../gui/wxpython/gui_core/vselect.py:297
+#, python-format
+msgid "Failed to query vector map(s) <%s>."
+msgstr ""
+#: ../gui/wxpython/gui_core/vselect.py:322
+msgid "No features selected"
+msgstr ""
+#: ../gui/wxpython/gui_core/vselect.py:346
+#, python-format
+msgid "Vector map <%s> was created"
+msgstr ""
+#: ../gui/wxpython/gui_core/vselect.py:349
+#, python-format
+msgid ""
+"Unable to create a new vector map.\n"
+"\n"
+"Reason: %s"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:37
+msgid "Display map"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:38
+msgid "Re-render modified map layers only"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:40
+msgid "Render map"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:41
+msgid "Force re-rendering all map layers"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:43
+msgid "Erase display"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:44
+msgid "Erase display canvas with given background color"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:46
+msgid "Pointer"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:48
+msgid "Zoom in"
+msgstr "Nagyítás"
+#: ../gui/wxpython/gui_core/toolbars.py:49
+msgid "Drag or click mouse to zoom"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:51
+msgid "Zoom out"
+msgstr "Kicsinyítés"
+#: ../gui/wxpython/gui_core/toolbars.py:52
+msgid "Drag or click mouse to unzoom"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:54
+msgid "Return to previous zoom"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:56
+msgid "Various zoom options"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:57
+msgid "Zoom to default or saved region, save to named region, ..."
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:59
+msgid "Zoom to selected map layer(s)"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:61
+msgid "Zoom to computational region extent"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:63
+msgid "Pan"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:64
+msgid "Drag with mouse to pan"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:66
+msgid "Save display to file"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:76 ../gui/wxpython/lmgr/layertree.py:80
+msgid "Add raster map layer"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:78 ../gui/wxpython/lmgr/layertree.py:92
+msgid "Add vector map layer"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:80
+msgid "Add map elements"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:81
+msgid "Overlay elements like scale and legend onto map"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:83
+msgid "Create histogram with d.histogram"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:260
+msgid "Select graphics tool"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:71
+#, python-format
+msgid ""
+"Unable to import pyGRASS: %s\n"
+"Some functionality will be not accessible"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:510
+msgid "Not selectable element"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:547
+#: ../gui/wxpython/gui_core/preferences.py:2164
+msgid "Mapset"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:559
+msgid "Type: "
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:577
+#, python-format
+msgid "GSelect: invalid item: %s"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1414
+msgid "Output settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1416
+msgid "Source input"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1427
+msgid "Native"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1433
+msgid "File"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1441 ../gui/wxpython/dbmgr/base.py:2954
+#: ../gui/wxpython/dbmgr/base.py:3084 ../gui/wxpython/dbmgr/base.py:3353
+msgid "Database"
+msgstr "Adatbázis"
+#: ../gui/wxpython/gui_core/gselect.py:1445
+msgid "Protocol"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1456
+msgid "Output type"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1458
+msgid "Source type"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1480
+msgid "All files"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1496
+msgid "ZIP files"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1497
+msgid "GZIP files"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1498
+msgid "TAR files"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1500
+msgid "TARGZ files"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1508
+msgid "File:"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1509
+msgid "Choose file to import"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1524
+#: ../gui/wxpython/gui_core/gselect.py:1607
+#: ../gui/wxpython/animation/dialogs.py:1199
+msgid "Directory:"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1525
+#: ../gui/wxpython/gui_core/gselect.py:1608
+msgid "Choose input directory"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1542
+msgid "Extension:"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1571
+#: ../gui/wxpython/gui_core/gselect.py:1586
+#: ../gui/wxpython/gui_core/gselect.py:1588
+#: ../gui/wxpython/gui_core/widgets.py:1294
+#: ../gui/wxpython/animation/dialogs.py:405
+#: ../gui/wxpython/vnet/dialogs.py:1643
+#: ../gui/wxpython/gmodeler/preferences.py:706
+msgid "Name:"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1572
+msgid "Choose file"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1593
+#: ../gui/wxpython/gui_core/gselect.py:2353
+msgid "Feature type:"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1595
+msgid "simple features"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1596
+msgid "topological"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1707
+#: ../gui/wxpython/gui_core/gselect.py:1738
+#: ../gui/wxpython/gui_core/gselect.py:1789
+#: ../gui/wxpython/gui_core/gselect.py:1827
+msgid "Creation options:"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1721
+#: ../gui/wxpython/gui_core/gselect.py:1760
+#: ../gui/wxpython/gui_core/gselect.py:1812
+msgid "Format:"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1819
+msgid "Protocol:"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1842
+msgid "No settings available"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1962
+#: ../gui/wxpython/web_services/dialogs.py:302
+msgid "No data source defined, settings are not saved."
+msgstr ""
+msgid "LineString"
+msgstr ""
+msgid "Polygon"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:2564
+msgid "No vector map selected in layer manager. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:2577
+msgid "Input vector map is not selected"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:2581
+#, python-format
+msgid "Input vector map <%s> and selected map <%s> in layer manager are different. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/gui_core/widgets.py:113
+msgid " (...)"
+msgstr ""
+#: ../gui/wxpython/gui_core/widgets.py:854
+#, python-format
+msgid "Name <%(name)s> is not a valid name for GRASS map. Please use only ASCII characters excluding %(chars)s and space."
+msgstr ""
+#: ../gui/wxpython/gui_core/widgets.py:968
+#: ../gui/wxpython/gui_core/dialogs.py:768
+#: ../gui/wxpython/gui_core/dialogs.py:836
+#: ../gui/wxpython/gui_core/dialogs.py:1576 ../gui/wxpython/dbmgr/base.py:1419
+msgid "Select all"
+msgstr "Mindent szelektál"
+#: ../gui/wxpython/gui_core/widgets.py:969
+#: ../gui/wxpython/gui_core/dialogs.py:1578 ../gui/wxpython/dbmgr/base.py:1420
+msgid "Deselect all"
+msgstr ""
+#: ../gui/wxpython/gui_core/widgets.py:1082
+msgid "Fulltext search"
+msgstr ""
+#: ../gui/wxpython/gui_core/widgets.py:1084
+msgid "Type to search in all modules. Press Enter for next match."
+msgstr ""
+#: ../gui/wxpython/gui_core/widgets.py:1151
+msgid "Searching, please type more characters."
+msgstr ""
+#: ../gui/wxpython/gui_core/widgets.py:1160
+#, python-format
+msgid "%d modules match"
+msgstr ""
+#: ../gui/wxpython/gui_core/widgets.py:1230
+msgid "Profiles"
+msgstr ""
+#: ../gui/wxpython/gui_core/widgets.py:1236
+msgid "Save current settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/widgets.py:1240
+msgid "Delete currently selected settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/widgets.py:1263
+msgid "Load:"
+msgstr ""
+#: ../gui/wxpython/gui_core/widgets.py:1281
+#, python-format
+msgid "Settings <%s> not found"
+msgstr ""
+#: ../gui/wxpython/gui_core/widgets.py:1295
+#: ../gui/wxpython/gui_core/widgets.py:1315
+msgid "Save settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/widgets.py:1300
+msgid "Name not given, settings is not saved."
+msgstr ""
+#: ../gui/wxpython/gui_core/widgets.py:1312
+#, python-format
+msgid "Settings <%s> already exists. Do you want to overwrite the settings?"
+msgstr ""
+#: ../gui/wxpython/gui_core/widgets.py:1363
+msgid "No settings is defined. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/gui_core/widgets.py:1401
+msgid "Unable to save settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:59
+msgid "User settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:83
+msgid "Set to default"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:91
+msgid "Revert settings to default"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:94
+msgid "Apply changes for the current session only and close"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:95
+msgid "Save for this session only"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:165
+msgid "Settings applied to current session but not saved"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:228
+msgid "Key column cannot be empty string."
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:247
+msgid "GUI Settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:282
+msgid "Layer Manager settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:292
+msgid "Ask when removing map layer from layer tree"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:305
+msgid "Ask when quiting wxGUI or closing display"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:320
+#: ../gui/wxpython/gui_core/preferences.py:337
+#, python-format
+msgid "Hide '%s' tab (requires GUI restart)"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:321
+#: ../gui/wxpython/gui_core/preferences.py:1096
+#: ../gui/wxpython/lmgr/frame.py:366
+msgid "Modules"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:338
+#: ../gui/wxpython/lmgr/frame.py:390
+msgid "Python"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:357
+msgid "Automatically copy selected text to clipboard (in the Console tab)"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:385
+msgid "Workspace settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:392
+msgid "Suppress positioning Map Display Window(s)"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:408
+msgid "Suppress positioning Layer Manager window"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:423
+msgid "Save current window layout as default"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:432
+msgid "Save current position and size of Layer Manager window and opened Map Display window(s) and use as default for next sessions."
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:454
+msgid "Region settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:461
+msgid "Align region to resolution"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:515
+msgid "Font for command output:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:520
+#: ../gui/wxpython/gui_core/preferences.py:798
+#: ../gui/wxpython/animation/dialogs.py:1064
+msgid "Set font"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:533
+msgid "Language settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:549
+msgid "Choose language (requires to save and GRASS restart):"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:583
+msgid "Appearance settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:593
+msgid "Element list:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:623
+msgid "Menu style (requires to save and GUI restart):"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:658
+msgid "Height of map selection popup window (in pixels):"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:698
+msgid "Icon theme (requires GUI restart):"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:725
+msgid "Module dialog style:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:792
+msgid "Default font for GRASS displays:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:819
+msgid "Default display settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:829
+msgid "Display driver:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:855
+msgid "Statusbar mode:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:907
+#: ../gui/wxpython/mapdisp/statusbar.py:520
+msgid "Align region extent based on display size"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:923
+#: ../gui/wxpython/mapdisp/statusbar.py:563
+msgid "Constrain display resolution to computational settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:939
+msgid "Enable auto-rendering"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:956
+msgid "Enable auto-zooming to selected map layer"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:972
+msgid "Mouse wheel action:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:998
+msgid "Mouse scrolling direction:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1039
+msgid "Advanced display settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1048
+msgid "3D view depth buffer (possible values are 16, 24, 32):"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1103
+msgid "Module dialog settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1128
+msgid "Close dialog when module is successfully finished"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1142
+#: ../gui/wxpython/gui_core/dialogs.py:306
+msgid "Add created map into layer tree"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1157
+msgid "Allow interactive input"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1171
+msgid "Verbosity level:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1207
+#: ../gui/wxpython/lmgr/frame.py:323
+msgid "Layers"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1217
+msgid "Default raster settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1227
+msgid "Make null cells opaque"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1242
+msgid "Default color table"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1288
+msgid "Default vector settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1294
+msgid "Display:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1319
+msgid "Feature color:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1359
+msgid "Area fill color:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1420
+msgid "Symbol:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1474
+#: ../gui/wxpython/dbmgr/base.py:1422
+msgid "Highlight selected features"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1503
+msgid "Line width (in pixels):"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1519
+msgid "Automatically hightlight selected features in map display"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1543
+msgid "Data browser"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1551
+msgid "Left mouse double click:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1576
+msgid "Encoding (e.g. utf-8, ascii, iso8859-1, koi8-r):"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1591
+msgid "Ask when deleting data record(s) from table"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1615
+msgid "Create table"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1622
+#: ../gui/wxpython/gui_core/dialogs.py:351
+msgid "Key column:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1656
+#: ../gui/wxpython/mapdisp/statusbar.py:824
+msgid "Projection"
+msgstr "Vetület"
+#: ../gui/wxpython/gui_core/preferences.py:1665
+msgid "Projection statusbar settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1674
+msgid ""
+"\n"
+"Note: This only controls the coordinates displayed in the lower-left of the Map Display\n"
+"window's status bar. It is purely cosmetic and does not affect the working location's\n"
+"projection in any way. You will need to enable the Projection check box in the drop-down\n"
+"menu located at the bottom of the Map Display window.\n"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1707
+msgid "Proj.4 string (required):"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1724
+msgid "EPSG file:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1741
+msgid "Load EPSG codes (be patient), enter EPSG code or insert Proj.4 string directly."
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1749
+msgid "&Load EPSG codes"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1769
+msgid "Coordinates format"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1777
+msgid "Lat/long projections"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1798
+msgid "Precision:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1884
+#, python-format
+msgid "Unable to read EPSG codes: %s"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1917
+#: ../gui/wxpython/gui_core/preferences.py:1929
+#: ../gui/wxpython/gui_core/preferences.py:1941
+#, python-format
+msgid "EPSG code %s not found"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1951
+msgid "Select default display font"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1965
+msgid "Failed to set default display font. Try different font."
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1984
+msgid "Select default output font"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:2073
+msgid "Manage access to mapsets"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:2088
+msgid ""
+"Check a mapset to make it accessible, uncheck it to hide it.\n"
+" Notes:\n"
+" - The current mapset is always accessible.\n"
+" - You may only write to the current mapset.\n"
+" - You may only write to mapsets which you own."
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:2165
+msgid "Owner"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:72
+msgid "Required item is not set."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:103
+msgid "Select GRASS location and mapset"
+msgstr "Válasszon GRASS helyet és térképcsoportot"
+#: ../gui/wxpython/gui_core/dialogs.py:122
+msgid "Location or mapset is not defined."
+msgstr "Nem adott meg helyet vagy térkép csoportot."
+#: ../gui/wxpython/gui_core/dialogs.py:132
+msgid "Name of GRASS location:"
+msgstr "GRASS hely neve"
+#: ../gui/wxpython/gui_core/dialogs.py:143
+#: ../gui/wxpython/gui_core/dialogs.py:200
+msgid "Name of mapset:"
+msgstr "Térképcsoport neve"
+#: ../gui/wxpython/gui_core/dialogs.py:172
+msgid "Select mapset in GRASS location"
+msgstr "Válasszon térképcsoportot a helyen"
+#: ../gui/wxpython/gui_core/dialogs.py:192
+msgid "Name of mapset is missing."
+msgstr "Térképcsoport neve hiányzik"
+#: ../gui/wxpython/gui_core/dialogs.py:233
+msgid "Name of vector map is missing."
+msgstr "A vektor térkép neve hiányzik."
+#: ../gui/wxpython/gui_core/dialogs.py:286
+msgid "Create attribute table"
+msgstr "Attribútum tábla létrehozás"
+#: ../gui/wxpython/gui_core/dialogs.py:320
+msgid "Name of new vector map is missing."
+msgstr "Az új vektor térkép neve hiányzik."
+#: ../gui/wxpython/gui_core/dialogs.py:332
+msgid "Name for new vector map:"
+msgstr "Új vektor térkép neve:"
+#: ../gui/wxpython/gui_core/dialogs.py:435
+#, python-format
+msgid "Unable to create vector map <%s>."
+msgstr "Nem tudom a vektor térképet létrehozni <%s>."
+#: ../gui/wxpython/gui_core/dialogs.py:440
+#, python-format
+msgid ""
+"Invalid or empty key column.\n"
+"Unable to create vector map <%s>."
+msgstr ""
+"Hibás vagy üres kulcs oszlop.\n"
+"Nem tudom a vektor térképet létrehozni <%s>."
+#: ../gui/wxpython/gui_core/dialogs.py:471
+#, python-format
+msgid "Vector map <%s> already exists in the current mapset. Do you want to overwrite it?"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:561
+msgid "Load region:"
+msgstr "Régió betöltés:"
+#: ../gui/wxpython/gui_core/dialogs.py:567
+msgid "Save region:"
+msgstr "Régió mentés:"
+#: ../gui/wxpython/gui_core/dialogs.py:619
+msgid "Name cannot begin with '.' and must not contain space, quotes, '/', ''', '@', ',', '=', '*', and all other non-alphanumeric characters."
+msgstr "A névnem kezdődhet '.'-tal és nem tartalmazhat szóközt, idézőjelet, '/', ''', '@', ',', '=', '*', és minden más nem alfanumerikus karaktert."
+#: ../gui/wxpython/gui_core/dialogs.py:635
+msgid "Create or edit imagery groups"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:669
+msgid "Apply changes to selected group and close dialog"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:670
+msgid "Apply changes to selected group"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:671
+msgid "Close dialog, changes are not applied"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:712
+#: ../gui/wxpython/gui_core/dialogs.py:1509
+msgid "Put here a regular expression. Characters '.*' stand for anything, character '^' stands for the beginning and '$' for the end."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:719
+msgid "Select existing group or enter name of new group:"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:730
+msgid "Edit/create subgroup"
+msgstr "Alcsoport létrehozás, szerkesztés"
+#: ../gui/wxpython/gui_core/dialogs.py:743
+msgid "Select existing subgroup or enter name of new subgroup:"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:777
+#: ../gui/wxpython/gui_core/dialogs.py:845
+#: ../gui/wxpython/gui_core/dialogs.py:1494
+msgid "Pattern:"
+msgstr "Minta:"
+#: ../gui/wxpython/gui_core/dialogs.py:795
+#: ../gui/wxpython/gui_core/dialogs.py:863
+#: ../gui/wxpython/gui_core/dialogs.py:1518
+msgid "List of maps:"
+msgstr "Térképek listája:"
+#: ../gui/wxpython/gui_core/dialogs.py:811
+msgid "Select map layers and add them to the list."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:816
+msgid "Remove selected layer(s) from list."
+msgstr "Szelektált réteg(ek) eltávolítása a listából."
+#: ../gui/wxpython/gui_core/dialogs.py:873
+msgid "Check maps from group to be included into subgroup."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1037
+msgid "Add selected map layers into group"
+msgstr "Szelektált térkép rétegek hozzáadása a csoporthoz"
+#: ../gui/wxpython/gui_core/dialogs.py:1174
+#, python-format
+msgid "Group <%s> was changed, do you want to apply changes?"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1177
+#: ../gui/wxpython/gui_core/dialogs.py:1193
+msgid "Unapplied changes"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1190
+#, python-format
+msgid "Subgroup <%s> was changed, do you want to apply changes?"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1247
+msgid "No raster maps selected."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1276
+#, python-format
+msgid "No changes to apply in group <%s>."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1279
+#, python-format
+msgid "Group <%s> was successfully created."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1281
+#, python-format
+msgid "Group <%s> was successfully changed."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1284
+#, python-format
+msgid "Creating of new group <%s> failed."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1286
+#, python-format
+msgid "Changing of group <%s> failed."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1324
+msgid "No group selected."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1329
+msgid "No subgroup selected."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1436
+msgid "Use fully-qualified map names"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1462
+msgid "Map type:"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1477
+msgid "Select toggle"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1484
+msgid "Mapset:"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1577
+msgid "Invert selection"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1720
+#, python-format
+msgid "Dynamic series (%s)"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1747
+msgid "Set Map Layer Opacity"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1778
+#: ../gui/wxpython/psmap/dialogs.py:6389 ../gui/wxpython/psmap/dialogs.py:6416
+#: ../gui/wxpython/psmap/dialogs.py:6748 ../gui/wxpython/psmap/dialogs.py:6778
+msgid "transparent"
+msgstr "átlátszó"
+#: ../gui/wxpython/gui_core/dialogs.py:1781
+msgid "opaque"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1879
+msgid "Set image size"
+msgstr "Képméret beállítás"
+#: ../gui/wxpython/gui_core/dialogs.py:1894
+msgid "Image size"
+msgstr "Képméret"
+#: ../gui/wxpython/gui_core/dialogs.py:1941
+msgid "Template:"
+msgstr "Sablon:"
+#: ../gui/wxpython/gui_core/dialogs.py:1981
+msgid "GRASS GIS SQL Query Utility"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1997
+msgid " SQL statement "
+msgstr "SQL mondat"
+#: ../gui/wxpython/gui_core/dialogs.py:2045
+msgid "Symbols"
+msgstr "Szimbólumok"
+#: ../gui/wxpython/gui_core/dialogs.py:2080
+msgid "Symbol directory:"
+msgstr "Szimbólum könyvtár:"
+#: ../gui/wxpython/gui_core/dialogs.py:2092
+msgid "Symbol name:"
+msgstr "Szimbólum név:"
+#: ../gui/wxpython/gui_core/dialogs.py:2343
+msgid "Do you want to quit GRASS including shell prompt or just close the GUI?"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:2420
+msgid "Select font:"
+msgstr "Betűkészlet:"
+#: ../gui/wxpython/gui_core/dialogs.py:2451
+msgid "Character encoding:"
+msgstr "Karakter kódolás:"
+#: ../gui/wxpython/gui_core/dialogs.py:2469
+#: ../gui/wxpython/psmap/dialogs.py:398 ../gui/wxpython/psmap/dialogs.py:4979
+msgid "Font size:"
+msgstr "Betűméret:"
+#: ../gui/wxpython/gui_core/dialogs.py:2521
+msgid "Example"
+msgstr "Példa"
+#: ../gui/wxpython/gui_core/simplelmgr.py:109
+msgid "Toolbar"
+msgstr "Eszközsor"
+#: ../gui/wxpython/gui_core/simplelmgr.py:145
+msgid "Copy map names to clipboard (top to bottom)"
+msgstr ""
+#: ../gui/wxpython/gui_core/simplelmgr.py:146
+msgid "Copy map names to clipboard (bottom to top)"
+msgstr ""
+#: ../gui/wxpython/gui_core/simplelmgr.py:288
+#: ../gui/wxpython/lmgr/layertree.py:1236
+#, python-format
+msgid "Set opacity of <%s>"
+msgstr ""
+#: ../gui/wxpython/gui_core/simplelmgr.py:464
+msgid "Remove selected map(s) from list"
+msgstr "Szelektált térkép(ek) eltávolítása a listából"
+#: ../gui/wxpython/gui_core/simplelmgr.py:466
+msgid "Layer up"
+msgstr "Réteg fel"
+#: ../gui/wxpython/gui_core/simplelmgr.py:467
+msgid "Move selected layer(s) up"
+msgstr "Szelektált réteg(ek) mozgatása fel"
+#: ../gui/wxpython/gui_core/simplelmgr.py:469
+msgid "Layer down"
+msgstr "Réteg le"
+#: ../gui/wxpython/gui_core/simplelmgr.py:470
+msgid "Move selected layer(s) down"
+msgstr "Szelektált réteg(ek) mozgatás le"
+#: ../gui/wxpython/gui_core/simplelmgr.py:472
+#: ../gui/wxpython/gui_core/simplelmgr.py:473
+msgid "Edit layer properties"
+msgstr "Réteg tulajdonságok szerkesztése"
+#: ../gui/wxpython/gui_core/simplelmgr.py:475
+msgid "Change opacity"
+msgstr ""
+#: ../gui/wxpython/gui_core/simplelmgr.py:476
+msgid "Change layer opacity"
+msgstr ""
+#: ../gui/wxpython/gui_core/simplelmgr.py:478
+#: ../gui/wxpython/gui_core/simplelmgr.py:479
+#: ../gui/wxpython/lmgr/layertree.py:106
+msgid "Add 3D raster map layer"
+msgstr "3D raszter térkép réteg hozzáadás"
+#: ../gui/wxpython/gui_core/goutput.py:128
+msgid "Click here to show search module engine"
+msgstr ""
+#: ../gui/wxpython/gui_core/goutput.py:130
+msgid "Click here to hide search module engine"
+msgstr ""
+#: ../gui/wxpython/gui_core/goutput.py:147
+msgid "Command prompt"
+msgstr "Parancs prompt"
+#: ../gui/wxpython/gui_core/goutput.py:152
+msgid "Output window"
+msgstr "Output ablak"
+#: ../gui/wxpython/gui_core/goutput.py:160
+msgid "Clear output window content"
+msgstr "Output ablak tartalmának törlése"
+#: ../gui/wxpython/gui_core/goutput.py:162
+msgid "Clear command prompt content"
+msgstr ""
+#: ../gui/wxpython/gui_core/goutput.py:165
+msgid "Save output window content to the file"
+msgstr ""
+#: ../gui/wxpython/gui_core/goutput.py:167
+msgid "Abort running command"
+msgstr ""
+#: ../gui/wxpython/gui_core/goutput.py:171
+msgid "&Log file"
+msgstr ""
+#: ../gui/wxpython/gui_core/goutput.py:173
+msgid "Toggle to save list of executed commands into a file; content saved when switching off."
+msgstr ""
+#: ../gui/wxpython/gui_core/goutput.py:420
+#: ../gui/wxpython/gui_core/goutput.py:516
+msgid "Save file as..."
+msgstr "Fájl mentés másként..."
+#: ../gui/wxpython/gui_core/goutput.py:422
+#: ../gui/wxpython/gui_core/goutput.py:518
+#, python-format
+msgid "%(txt)s (*.txt)|*.txt|%(files)s (*)|*"
+msgstr ""
+#: ../gui/wxpython/gui_core/goutput.py:423
+#: ../gui/wxpython/gui_core/goutput.py:519
+msgid "Text files"
+msgstr "Szöveg fájlok"
+#: ../gui/wxpython/gui_core/goutput.py:424
+#: ../gui/wxpython/gui_core/goutput.py:520
+msgid "Files"
+msgstr "Fájlok"
+#: ../gui/wxpython/gui_core/goutput.py:437
+#, python-format
+msgid ""
+"Unable to write file '%(path)s'.\n"
+"\n"
+"Details: %(error)s"
+msgstr ""
+#: ../gui/wxpython/gui_core/goutput.py:442
+#, python-format
+msgid "Command output saved into '%s'"
+msgstr "Parancs outputot mentettem ide: '%s'"
+#: ../gui/wxpython/gui_core/goutput.py:501
+#, python-format
+msgid "Command log saved to '%s'"
+msgstr ""
+#: ../gui/wxpython/psmap/toolbars.py:79
+msgid "Full extent"
+msgstr "Teljes terjedelem"
+#: ../gui/wxpython/psmap/toolbars.py:80
+msgid "Zoom to full extent"
+msgstr "Nagyítás a teljes terjedelemre"
+#: ../gui/wxpython/psmap/toolbars.py:83
+msgid "Click and drag to place map frame"
+msgstr "Kattintás és húzás a térképkeret elhelyezéséhez"
+#: ../gui/wxpython/psmap/toolbars.py:87
+msgid "Show preview"
+msgstr "Előnézet megjelenítés"
+#: ../gui/wxpython/psmap/toolbars.py:89
+msgid "Quit Cartographic Composer"
+msgstr ""
+#: ../gui/wxpython/psmap/toolbars.py:107
+#: ../gui/wxpython/rlisetup/wizard.py:1187
+#: ../gui/wxpython/rlisetup/wizard.py:1360
+#: ../gui/wxpython/rlisetup/wizard.py:1450
+msgid "Rectangle"
+msgstr "Téglalap"
+#: ../gui/wxpython/psmap/toolbars.py:109
+msgid "Add overlays"
+msgstr ""
+#: ../gui/wxpython/psmap/toolbars.py:111 ../gui/wxpython/lmgr/layertree.py:104
+msgid "Add labels"
+msgstr "Címkék hozzáadása"
+#: ../gui/wxpython/psmap/toolbars.py:203
+msgid "Add simple graphics: points"
+msgstr "Egyszerű grafika hozzáadás: pontok"
+#: ../gui/wxpython/psmap/toolbars.py:219
+msgid "Add simple graphics: lines"
+msgstr "Egyszerű grafika hozzáadás: vonalak"
+#: ../gui/wxpython/psmap/toolbars.py:235
+msgid "Add simple graphics: rectangles"
+msgstr "Egyszerű grafika hozzáadás: téglalapok"
+#: ../gui/wxpython/psmap/frame.py:54
+msgid "GRASS GIS Cartographic Composer"
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:214
+msgid ""
+"Python Imaging Library is not available.\n"
+"'Preview' functionality won't work."
+msgstr ""
+"A Python Imaging könyvtár nem érhető el.\n"
+"Az 'előnézet' funkció nem fog működni,"
+#: ../gui/wxpython/psmap/frame.py:268
+msgid "Program ps2pdf is not available. Please install it first to create PDF."
+msgstr "A ps2pdf program nem érhető el. Kérjük a PDF létrehozáshoz előbb telepítse."
+#: ../gui/wxpython/psmap/frame.py:312
+msgid "Generating PDF..."
+msgstr "PDF generálás..."
+#: ../gui/wxpython/psmap/frame.py:314
+msgid "Generating PostScript..."
+msgstr "PostScript generálás..."
+#: ../gui/wxpython/psmap/frame.py:316
+msgid "Generating preview..."
+msgstr "Előnézet generálás"
+#: ../gui/wxpython/psmap/frame.py:333
+#, python-format
+msgid "Ps.map exited with return code %s"
+msgstr "Ps.map kilépett %s visszaadott kóddal"
+#: ../gui/wxpython/psmap/frame.py:369
+#, python-format
+msgid "%(prg)s exited with return code %(code)s"
+msgstr "%(prg)s kilépett %(code)skóddal visszaadott "
+#: ../gui/wxpython/psmap/frame.py:373
+msgid "PDF generated"
+msgstr "PDF elkészült"
+#: ../gui/wxpython/psmap/frame.py:376
+#, python-format
+msgid ""
+"Program ps2pdf is not available. Please install it to create PDF.\n"
+"\n"
+" %s"
+msgstr ""
+"A ps2pdf program nem érhető el. Kérjük telepítse PDF létrehozásához.\n"
+"%s"
+#: ../gui/wxpython/psmap/frame.py:379
+msgid "PostScript file generated"
+msgstr "PostScript fájl elkészült"
+#: ../gui/wxpython/psmap/frame.py:388
+msgid "Generating preview, wait please"
+msgstr "Előnézet generálás, kérem várjon"
+#: ../gui/wxpython/psmap/frame.py:404
+msgid "Preview not available"
+msgstr "Előnézet nem érhető el"
+#: ../gui/wxpython/psmap/frame.py:406
+msgid "Preview is not available probably because Ghostscript is not installed or not on PATH."
+msgstr "Előnézet nem érhető el valószínűleg, mert nem telepítette a Ghostscript programot vagy nincs rajta a PATH-on."
+#: ../gui/wxpython/psmap/frame.py:409
+msgid "Please follow instructions on GRASS Trac Wiki."
+msgstr "Kérjük kövesse az utasításokat a GRASS Trac Wiki-n."
+#: ../gui/wxpython/psmap/frame.py:420
+msgid "Preview generated"
+msgstr "Előnézet elkészült"
+#: ../gui/wxpython/psmap/frame.py:452
+msgid "Save file as"
+msgstr "File mentés másként"
+#: ../gui/wxpython/psmap/frame.py:499
+#, python-format
+msgid "Failed to read file %s."
+msgstr "Sikertelen fájl olvasás %s."
+#: ../gui/wxpython/psmap/frame.py:636 ../gui/wxpython/psmap/frame.py:661
+#: ../gui/wxpython/psmap/dialogs.py:1635
+msgid "Please, create map frame first."
+msgstr "Kérjük készítsen először egy térkép keretet."
+#: ../gui/wxpython/psmap/frame.py:678
+msgid "Scalebar is not appropriate for this projection"
+msgstr "A léptékvonalzó nem megfelelő ehhez a vetülethez"
+#: ../gui/wxpython/psmap/frame.py:1167
+msgid "Press button with green triangle icon to generate preview."
+msgstr "Az előnézet előállításához nyomja meg a gombot a zöld háromszög ikonnal."
+#: ../gui/wxpython/psmap/frame.py:1190
+msgid "wxGUI Cartographic Composer"
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:1241
+msgid "MAP FRAME"
+msgstr "TÉRKÉP KERET"
+#: ../gui/wxpython/psmap/frame.py:1242
+msgid "RASTER LEGEND"
+msgstr "RASZTER JELMAGYARÁZAT"
+#: ../gui/wxpython/psmap/frame.py:1243
+msgid "VECTOR LEGEND"
+msgstr "VEKTOR JELMAGYARÁZAT"
+#: ../gui/wxpython/psmap/frame.py:1244
+msgid "MAP INFO"
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:1245
+msgid "SCALE BAR"
+msgstr "LÉPTÉKVONALZÓ"
+#: ../gui/wxpython/psmap/frame.py:1246
+msgid "IMAGE"
+msgstr "KÉP"
+#: ../gui/wxpython/psmap/frame.py:1247
+msgid "NORTH ARROW"
+msgstr "ÉSZAK NYÍL"
+#: ../gui/wxpython/psmap/frame.py:1523
+msgid "Click and drag to resize object"
+msgstr "Kattintson és húzza az objektumot az átméretezéshez"
+#: ../gui/wxpython/psmap/frame.py:2471
+msgid "labels: "
+msgstr "címkék:"
+#: ../gui/wxpython/psmap/instructions.py:139
+#, python-format
+msgid ""
+"Unable to open file\n"
+"%s"
+msgstr ""
+"Nem tudom megnyitni a fájlt\n"
+"%s"
+#: ../gui/wxpython/psmap/instructions.py:498
+#, python-format
+msgid "Instruction file will be loaded with following region: %s\n"
+msgstr ""
+#: ../gui/wxpython/psmap/instructions.py:504
+#, python-format
+msgid ""
+"Region cannot be set\n"
+"%s"
+msgstr ""
+"A régió nem állítható be\n"
+"%s"
+#: ../gui/wxpython/psmap/instructions.py:664
+#: ../gui/wxpython/psmap/instructions.py:863
+#: ../gui/wxpython/psmap/instructions.py:996
+#: ../gui/wxpython/psmap/instructions.py:1074
+#: ../gui/wxpython/psmap/instructions.py:1248
+#: ../gui/wxpython/psmap/instructions.py:1315
+#: ../gui/wxpython/psmap/instructions.py:1382
+#: ../gui/wxpython/psmap/instructions.py:1466
+#: ../gui/wxpython/psmap/instructions.py:1588
+#: ../gui/wxpython/psmap/instructions.py:1733
+#: ../gui/wxpython/psmap/instructions.py:1787
+#: ../gui/wxpython/psmap/instructions.py:2158
+#, python-format
+msgid "Failed to read instruction %s"
+msgstr "Utasítások beolvasása sikertelen %s"
+#: ../gui/wxpython/psmap/instructions.py:679
+#, python-format
+msgid ""
+"Scale has changed, old value: %(old)s\n"
+"new value: %(new)s"
+msgstr ""
+"Méretarány megváltozott, régi érték: %(old)s\n"
+"új érték: %(new)s"
+#: ../gui/wxpython/psmap/instructions.py:683
+#, python-format
+msgid ""
+"Failed to read instruction %s.\n"
+"Use 1:25000 notation."
+msgstr ""
+#: ../gui/wxpython/psmap/instructions.py:693
+#, python-format
+msgid ""
+"Map frame position changed, old value: %(old1)s %(old2)s\n"
+"new value: %(new1)s %(new2)s"
+msgstr ""
+"A térkép keret pozíciója változott, régi érték: %(old1)s %(old2)s\n"
+"új érték: %(new1)s %(new2)s"
+#: ../gui/wxpython/psmap/instructions.py:704
+#, python-format
+msgid ""
+"Map frame size changed, old value: %(old1)s %(old2)s\n"
+msgstr ""
+"A térkép keret mérete módosult, régi érték: %(old1)s %(old2)s\n"
+#: ../gui/wxpython/psmap/instructions.py:771
+#, python-format
+msgid ""
+"Failed to read instruction %(file)s.\n"
+"Unknown format %(for)s"
+msgstr ""
+"Utasítások beolvasása sikertelen%(file)s.\n"
+"Ismeretlen formátum %(for)s"
+#: ../gui/wxpython/psmap/instructions.py:786
+#, python-format
+msgid "Failed to read instruction %s."
+msgstr "Az utasítások beolvasása sikertelen %s."
+#: ../gui/wxpython/psmap/instructions.py:936
+#: ../gui/wxpython/psmap/instructions.py:2006
+#, python-format
+msgid "Characters on position %s are not supported by ISO-8859-1 (Latin 1) encoding which is required by module ps.map."
+msgstr "A %s pozíción lévő karakter nem szerepel az ISO-8859-1 (Latin 1) kódolásban, melyet a ps.map modul megkövetel."
+#: ../gui/wxpython/psmap/instructions.py:940
+#: ../gui/wxpython/psmap/instructions.py:2010
+msgid "Not all characters are supported by ISO-8859-1 (Latin 1) encoding which is required by module ps.map."
+msgstr "Nem minden karakter szerepel az ISO-8859-1 (Latin 1) kódolásban, melyet a ps.map modul megkövetel."
+#: ../gui/wxpython/psmap/instructions.py:1077
+#, python-format
+msgid "Failed to read instruction %(inst)s: file %(file)s not found."
+msgstr "Az utasítások beolvasása sikertelen %(inst)s: %(file)sfájlt nem találom."
+#: ../gui/wxpython/psmap/dialogs.py:231
+msgid "Units:"
+msgstr "Egységek:"
+#: ../gui/wxpython/psmap/dialogs.py:242
+msgid ""
+"Position of the top left corner\n"
+"from the top left edge of the paper"
+msgstr ""
+"Bal felső sarok pozíciója\n"
+"a papír bal felső sarkától."
+#: ../gui/wxpython/psmap/dialogs.py:244
+#: ../gui/wxpython/animation/dialogs.py:1140
+msgid "X:"
+msgstr "X:"
+#: ../gui/wxpython/psmap/dialogs.py:246
+#: ../gui/wxpython/animation/dialogs.py:1142
+msgid "Y:"
+msgstr "Y:"
+#: ../gui/wxpython/psmap/dialogs.py:271
+msgid "Position is given:"
+msgstr "A pozíció adott:"
+#: ../gui/wxpython/psmap/dialogs.py:273
+msgid "relative to paper"
+msgstr "relatívan a papírhoz"
+#: ../gui/wxpython/psmap/dialogs.py:275
+msgid "by map coordinates"
+msgstr "térkép koordinátákkal"
+#: ../gui/wxpython/psmap/dialogs.py:305
+msgid ""
+"Position from the top left\n"
+"edge of the paper"
+msgstr ""
+"Pozíció a papír\n"
+"bal felső sarkától"
+#: ../gui/wxpython/psmap/dialogs.py:396
+msgid "Font:"
+#: ../gui/wxpython/psmap/dialogs.py:424
+msgid "Choose color:"
+msgstr "Válasszon színt:"
+#: ../gui/wxpython/psmap/dialogs.py:473
+msgid "Close dialog and apply changes"
+msgstr "Párbeszédablak lezárása és a változások érvényesítése"
+#: ../gui/wxpython/psmap/dialogs.py:524
+msgid "Units"
+msgstr "Egységek"
+#: ../gui/wxpython/psmap/dialogs.py:525
+#: ../gui/wxpython/animation/dialogs.py:929
+msgid "Format"
+msgstr "Formátum"
+#: ../gui/wxpython/psmap/dialogs.py:526
+msgid "Orientation"
+msgstr "Tájékozás"
+#: ../gui/wxpython/psmap/dialogs.py:527 ../gui/wxpython/psmap/dialogs.py:2888
+msgid "Width"
+msgstr "Szélesség"
+#: ../gui/wxpython/psmap/dialogs.py:528
+msgid "Height"
+msgstr "Magasság"
+#: ../gui/wxpython/psmap/dialogs.py:529
+msgid "Left"
+msgstr "Bal"
+#: ../gui/wxpython/psmap/dialogs.py:530
+msgid "Right"
+msgstr "Jobb"
+#: ../gui/wxpython/psmap/dialogs.py:594
+msgid "Literal is not allowed!"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:608
+msgid "Page size"
+msgstr "Lapméret"
+#: ../gui/wxpython/psmap/dialogs.py:612
+msgid "Margins"
+msgstr "Margók"
+#: ../gui/wxpython/psmap/dialogs.py:619
+msgid "Portrait"
+msgstr "Álló"
+msgid "Landscape"
+msgstr "Fekvő"
+#: ../gui/wxpython/psmap/dialogs.py:765
+msgid "Map settings"
+msgstr "Térkép beálítások"
+#: ../gui/wxpython/psmap/dialogs.py:775
+msgid "Map frame settings"
+msgstr "Térkép keret beállítások"
+#: ../gui/wxpython/psmap/dialogs.py:893
+msgid "Map frame options:"
+msgstr "Térkép keret opciók:"
+#: ../gui/wxpython/psmap/dialogs.py:894
+msgid "fit frame to match selected map"
+msgstr "keret illesztés a kiválasztott térképhez"
+#: ../gui/wxpython/psmap/dialogs.py:895
+msgid "fit frame to match saved region"
+msgstr "keret illesztés a mentett régióhoz"
+#: ../gui/wxpython/psmap/dialogs.py:896
+msgid "fit frame to match current computational region"
+msgstr "keret illesztés az aktuális számítási régióhoz"
+#: ../gui/wxpython/psmap/dialogs.py:897
+msgid "fixed scale and map center"
+msgstr "rögzített méretarány és térkép középpont"
+#: ../gui/wxpython/psmap/dialogs.py:914 ../gui/wxpython/psmap/dialogs.py:1224
+msgid "Map selection"
+msgstr "Térkép szelekció"
+#: ../gui/wxpython/psmap/dialogs.py:927 ../gui/wxpython/psmap/dialogs.py:1715
+msgid "Map:"
+msgstr "Térkép:"
+msgid "
