[GRASS-SVN] r72346 - grass/branches/releasebranch_7_2/temporal/t.rast.algebra
Sat Mar 10 12:02:26 PST 2018
Author: neteler
Date: 2018-03-10 12:02:26 -0800 (Sat, 10 Mar 2018)
New Revision: 72346
   grass/branches/releasebranch_7_2/temporal/t.rast.algebra/t.rast.algebra.html
t.rast.algebra manual: formatting fixed + See also section added
Modified: grass/branches/releasebranch_7_2/temporal/t.rast.algebra/t.rast.algebra.html
--- grass/branches/releasebranch_7_2/temporal/t.rast.algebra/t.rast.algebra.html	2018-03-10 20:00:37 UTC (rev 72345)
+++ grass/branches/releasebranch_7_2/temporal/t.rast.algebra/t.rast.algebra.html	2018-03-10 20:02:26 UTC (rev 72346)
@@ -1,6 +1,6 @@
 <h2>DESCRIPTION</h2>
-t.rast.algebra performs temporal and spatial map algebra operations on
+<em>t.rast.algebra</em> performs temporal and spatial map algebra operations on
 space time raster datasets (STRDS) using the temporal raster algebra.
 <h3>PROGRAM USE</h3>
@@ -97,9 +97,10 @@
 overlaps          A ------
                   B   ------
-over              booth overlaps and overlapped
+over              both overlaps and overlapped
 </pre></div>
+<!- TODO: fix formatting of next sentence to become readable! ->
 The relations must be read as: A is related to B, like - A equals B - A
 is during B - A contains B.
 <p>
@@ -382,8 +383,8 @@
 log(x)                  natural log of x
 sqrt(x)                 square root of x
 tan(x)                  tangent of x (x is in degrees)
-round(x)		round x to nearest integer
-sin(x)			sine of x (x is in degrees)
+round(x)                round x to nearest integer
+sin(x)                  sine of x (x is in degrees)
 isnull(x)               check if x = NULL
 isntnull(x)             check if x is not NULL
 null                    set null value
@@ -450,21 +451,27 @@
 <pre class="code">
 strds[2]
 </pre>
-Refers to the second successor of the current map
+refers to the second successor of the current map.
+<p>
 <pre class="code">
 strds[1,2]
 </pre>
-Refers to the cell one row below and two columns to the right of the current
-cell in the current map
+refers to the cell one row below and two columns to the right of the current
+cell in the current map.
+<p>
 <pre class="code">
 strds[1,-2,-1]
 </pre>
-Refers to the cell two rows above and one column to the left of the current
-cell of the first successor map
+refers to the cell two rows above and one column to the left of the current
+cell of the first successor map.
+<p>
 <pre class="code">
 strds[-2,0,1]
 </pre>
-Refers to the cell one column to the right of the current cell in the
+refers to the cell one column to the right of the current cell in the
 second predecessor map.
 <h2>EXAMPLES</h2>
@@ -555,7 +562,15 @@
 sudo dnf install python-ply
 </pre></div>
+<h2>SEE ALSO</h2>
+<em>
+<a href="v.overlay.html">v.overlay</a>,
+<a href="v.buffer.html">v.buffer</a>,
+<a href="v.patch.html">v.patch</a>,
+<a href="r.mapcalc.html">r.mapcalc</a>
+</em>
 <h2>AUTHORS</h2>
 Thomas Leppelt, Sören Gebbert, Thünen Institute of Climate-Smart Agriculture
