[GRASS-SVN] r72357 - grass/branches/releasebranch_7_4/gui/icons
svn_grass at osgeo.org
Mon Mar 12 23:22:01 PDT 2018
Author: neteler
Date: 2018-03-12 23:22:01 -0700 (Mon, 12 Mar 2018)
New Revision: 72357
grass/branches/releasebranch_7_4/gui/icons/Makefile
store grass.appdata.xml under share/metainfo/org.osgeo.grass.appdata.xml
Modified: grass/branches/releasebranch_7_4/gui/icons/Makefile
--- grass/branches/releasebranch_7_4/gui/icons/Makefile 2018-03-12 22:24:14 UTC (rev 72356)
+++ grass/branches/releasebranch_7_4/gui/icons/Makefile 2018-03-13 06:22:01 UTC (rev 72357)
@@ -52,8 +52,8 @@
$(INSTALL_DATA) grass-192x192.png $(ARCH_DISTDIR)/share/icons/hicolor/192x192/apps/grass.png
$(MKDIR) $(ARCH_DISTDIR)/share/icons/hicolor/scalable/apps
$(INSTALL_DATA) grass.svg $(ARCH_DISTDIR)/share/icons/hicolor/scalable/apps/grass.svg
- $(MKDIR) $(ARCH_DISTDIR)/share/appdata
- $(INSTALL_DATA) grass.appdata.xml $(ARCH_DISTDIR)/share/appdata
+ $(MKDIR) $(ARCH_DISTDIR)/share/metainfo
+ $(INSTALL_DATA) grass.appdata.xml $(ARCH_DISTDIR)/share/metainfo/org.osgeo.grass.appdata.xml
### disable special 64bit icons (using different icons can be confusing for the user)
# ifeq ($(findstring x86_64,$(ARCH)),x86_64)
# $(INSTALL_DATA) x86_64/grass.ico $(GUIDIR)/icons
