[GRASS-SVN] r72375 - grass/trunk/vector/v.random
Fri Mar 16 07:30:48 PDT 2018
Author: martinl
Date: 2018-03-16 07:30:48 -0700 (Fri, 16 Mar 2018)
New Revision: 72375
   grass/trunk/vector/v.random/main.c
v.random: fix comparison between signed and unsigned integer expressions warnings (TODO: replace long with int64)
Modified: grass/trunk/vector/v.random/main.c
--- grass/trunk/vector/v.random/main.c	2018-03-16 12:07:20 UTC (rev 72374)
+++ grass/trunk/vector/v.random/main.c	2018-03-16 14:30:48 UTC (rev 72375)
@@ -189,7 +189,7 @@
         seed = atoi(parm.seed->answer);
     if (n <= 0) {
-	G_fatal_error(_("Number of points must be > 0 (%d given)"), n);
+	G_fatal_error(_("Number of points must be > 0 (%ld given)"), n);
     nareas = 0;
@@ -457,7 +457,7 @@
 		    Vect_append_point(Points, x, y, 0.0);
 		if (parm.zcol->answer) {
-		    sprintf(buf, "insert into %s values ( %d, ", Fi->table, i + 1);
+		    sprintf(buf, "insert into %s values ( %ld, ", Fi->table, i + 1);
 		    db_set_string(&sql, buf);
 		    /* Round random value if column is integer type */
 		    if (usefloat)
@@ -577,7 +577,7 @@
 		if (usefloat)
