[GRASS-SVN] r72385 - grass-addons/grass7/imagery/i.cutlines
svn_grass at osgeo.org
Sun Mar 18 13:18:00 PDT 2018
Author: mlennert
Date: 2018-03-18 13:18:00 -0700 (Sun, 18 Mar 2018)
New Revision: 72385
grass-addons/grass7/imagery/i.cutlines/i.cutlines.py
i.cutlines: use the new '_' suffix enabled pygrass library in trunk
Modified: grass-addons/grass7/imagery/i.cutlines/i.cutlines.py
--- grass-addons/grass7/imagery/i.cutlines/i.cutlines.py 2018-03-18 19:55:51 UTC (rev 72384)
+++ grass-addons/grass7/imagery/i.cutlines/i.cutlines.py 2018-03-18 20:18:00 UTC (rev 72385)
@@ -235,16 +235,18 @@
if edge_detection_algorithm == 'zc':
kwargs = {'input' : inputraster,
'output' : temp_edge_map,
- 'width' : int(options['zc_width']),
+ 'width_' : int(options['zc_width']),
'threshold' : float(options['zc_threshold']),
'quiet' : True}
if tiled:
- message = "Currently there is a parameter name conflict between\n"
- message += "i.zc and GridModule used for tiling.\n"
- message += "Please use i.edge for edge detection if you want to\n"
- message += "tile this part."
- gscript.fatal(message)
+ if gscript.version()['version'] < '7.5':
+ message = "Currently there is a parameter name conflict between\n"
+ message += "i.zc and GridModule used for tiling.\n"
+ message += "This is solved in GRASS trunk.\n"
+ message += "Please use i.edge for edge detection or GRASS trunk\n"
+ message += "if you want to tile this part."
+ gscript.fatal(message)
grd = GridModule('i.zc',
width=width,
height=height,
