[GRASS-SVN] r72427 - grass/trunk/display/d.grid
Tue Mar 20 11:47:54 PDT 2018
Author: mmetz
Date: 2018-03-20 11:47:54 -0700 (Tue, 20 Mar 2018)
New Revision: 72427
   grass/trunk/display/d.grid/local_proto.h
   grass/trunk/display/d.grid/main.c
   grass/trunk/display/d.grid/plot.c
d.grid: use new PROJ 5+ API if available
Modified: grass/trunk/display/d.grid/local_proto.h
--- grass/trunk/display/d.grid/local_proto.h	2018-03-20 18:46:45 UTC (rev 72426)
+++ grass/trunk/display/d.grid/local_proto.h	2018-03-20 18:47:54 UTC (rev 72427)
@@ -8,7 +8,7 @@
 int plot_grid(double, double, double, int, int, int, int, int, int, double,
               int);
 int plot_geogrid(double, struct pj_info, struct pj_info, int, int, int, int,
-                 int, int, double, int);
+                 int, int, double, int, int);
 void init_proj(struct pj_info *, struct pj_info *, int);
 void get_ll_bounds(double *, double *, double *, double *, struct Cell_head,
                    struct pj_info, struct pj_info);
Modified: grass/trunk/display/d.grid/main.c
--- grass/trunk/display/d.grid/main.c	2018-03-20 18:46:45 UTC (rev 72426)
+++ grass/trunk/display/d.grid/main.c	2018-03-20 18:47:54 UTC (rev 72427)
@@ -289,7 +289,8 @@
             /* initialzie proj stuff */
             init_proj(&info_in, &info_out, wgs84->answer);
             plot_geogrid(gsize, info_in, info_out, do_text, colorg, colort,
-                         colorbg, fontsize, mark_type, line_width, dirn);
+                         colorbg, fontsize, mark_type, line_width, dirn,
+			 wgs84->answer);
         else {
             /* Do the grid plotting */
Modified: grass/trunk/display/d.grid/plot.c
--- grass/trunk/display/d.grid/plot.c	2018-03-20 18:46:45 UTC (rev 72426)
+++ grass/trunk/display/d.grid/plot.c	2018-03-20 18:47:54 UTC (rev 72427)
@@ -234,7 +234,7 @@
 int plot_geogrid(double size, struct pj_info info_in, struct pj_info info_out,
                  int do_text, int gcolor, int tcolor, int bgcolor, int fontsize,
-                 int mark_type, double line_width, int direction)
+                 int mark_type, double line_width, int direction, int wgs84)
     double g;
     double e1, e2, n1, n2;
@@ -289,9 +289,19 @@
             check_coords(e1, n1, &lon, &lat, 1, window, info_in, info_out);
             e1 = lon;
             n1 = lat;
+#ifdef HAVE_PROJ_H
+	    if (!wgs84) {
+		if (GPJ_do_proj_ll(&e2, &n2, &info_in, PJ_INV) < 0)
+		    G_fatal_error(_("Error in pj_do_proj"));
+	    else {
+		if (pj_do_proj(&e2, &n2, &info_in, &info_out) < 0)
+#else
+#endif
             check_coords(e2, n2, &lon, &lat, 1, window, info_in, info_out);
             e2 = lon;
             n2 = lat;
@@ -330,14 +340,36 @@
                n1 = south + (ll *((north - south)/SEGS));
                n2 = n1 + ((north - south)/SEGS);
+#ifdef HAVE_PROJ_H
+	    if (!wgs84) {
+		if (GPJ_do_proj_ll(&e1, &n1, &info_in, PJ_INV) < 0)
+	    else {
+		if (pj_do_proj(&e1, &n1, &info_in, &info_out) < 0)
+#else
+#endif
             check_coords(e1, n1, &lon, &lat, 2, window, info_in, info_out);
             e1 = lon;
             n1 = lat;
+#ifdef HAVE_PROJ_H
+	    if (!wgs84) {
+	    else {
+#else
+#endif
             check_coords(e2, n2, &lon, &lat, 2, window, info_in, info_out);
             e2 = lon;
@@ -423,14 +455,36 @@
                 n1 = n2 = g;
                 e1 = west + (ll * ((east - west) / SEGS));
                 e2 = e1 + ((east - west) / SEGS);
-                if (pj_do_proj(&e1, &n1, &info_in, &info_out) < 0)
-                    G_fatal_error(_("Error in pj_do_proj"));
+#ifdef HAVE_PROJ_H
+		if (!wgs84) {
+		else {
+#else
+#endif
                 e1 = lon;
                 n1 = lat;
-                if (pj_do_proj(&e2, &n2, &info_in, &info_out) < 0)
+#ifdef HAVE_PROJ_H
+		if (!wgs84) {
+		else {
+#else
+#endif
                 e2 = lon;
@@ -481,14 +535,36 @@
                 n1 = north - (ll * ((north - south) / SEGS));
                 n2 = n1 - ((north - south) / SEGS);
+#ifdef HAVE_PROJ_H
+		if (!wgs84) {
+		else {
+#else
+#endif
                 e1 = lon;
                 n1 = lat;
+#ifdef HAVE_PROJ_H
+		if (!wgs84) {
+		else {
+#else
+#endif
                 e2 = lon;
@@ -554,6 +630,9 @@
         G_fatal_error(_("Can't get projection key values of current location"));
     /* In Info */
+#ifdef HAVE_PROJ_H
+    if (wgs84) {
+#else
     if (!wgs84) {
         /* Set lat/long to same ellipsoid as location if we're not looking
          * for the WGS84 values */
@@ -562,6 +641,7 @@
     else {
+#endif
         struct Key_Value *in_proj_info, *in_unit_info;
         char buff[256], dum[256];
