[GRASS-SVN] r72436 - in grass/branches/releasebranch_7_4/gui/wxpython: core gui_core lmgr mapdisp
svn_grass at osgeo.org
Tue Mar 20 12:07:29 PDT 2018
Author: martinl
Date: 2018-03-20 12:07:28 -0700 (Tue, 20 Mar 2018)
New Revision: 72436
grass/branches/releasebranch_7_4/gui/wxpython/core/settings.py
grass/branches/releasebranch_7_4/gui/wxpython/gui_core/preferences.py
grass/branches/releasebranch_7_4/gui/wxpython/lmgr/frame.py
grass/branches/releasebranch_7_4/gui/wxpython/mapdisp/main.py
wxGUI: set up default map display properties when new display is open
add settings to show comp. region extent, see #3519
(merge r72379, r72381 from trunk)
Modified: grass/branches/releasebranch_7_4/gui/wxpython/core/settings.py
--- grass/branches/releasebranch_7_4/gui/wxpython/core/settings.py 2018-03-20 19:03:07 UTC (rev 72435)
+++ grass/branches/releasebranch_7_4/gui/wxpython/core/settings.py 2018-03-20 19:07:28 UTC (rev 72436)
@@ -188,6 +188,9 @@
'autoZooming': {
'enabled': False
+ 'showCompExtent': {
+ 'enabled': False
'statusbarMode': {
'selection': 0
Modified: grass/branches/releasebranch_7_4/gui/wxpython/gui_core/preferences.py
--- grass/branches/releasebranch_7_4/gui/wxpython/gui_core/preferences.py 2018-03-20 19:03:07 UTC (rev 72435)
+++ grass/branches/releasebranch_7_4/gui/wxpython/gui_core/preferences.py 2018-03-20 19:07:28 UTC (rev 72436)
@@ -973,6 +973,22 @@
pos=(row, 0), span=(1, 2))
+ # show computation extent
+ row += 1
+ showCompExtent = wx.CheckBox(parent=panel, id=wx.ID_ANY, label=_(
+ "Show computational region extent"), name="IsChecked")
+ showCompExtent.SetValue(
+ self.settings.Get(
+ group='display',
+ key='showCompExtent',
+ subkey='enabled'))
+ self.winId['display:showCompExtent:enabled'] = showCompExtent.GetId()
+ gridSizer.Add(showCompExtent,
+ pos=(row, 0), span=(1, 2))
# mouse wheel zoom
row += 1
Modified: grass/branches/releasebranch_7_4/gui/wxpython/lmgr/frame.py
--- grass/branches/releasebranch_7_4/gui/wxpython/lmgr/frame.py 2018-03-20 19:03:07 UTC (rev 72435)
+++ grass/branches/releasebranch_7_4/gui/wxpython/lmgr/frame.py 2018-03-20 19:07:28 UTC (rev 72436)
@@ -2094,6 +2094,18 @@
except:
pass
+ # set default properties
+ mapdisplay.SetProperties(render=UserSettings.Get(
+ group='display', key='autoRendering', subkey='enabled'),
+ mode=UserSettings.Get(
+ group='display', key='statusbarMode', subkey='selection'),
+ alignExtent=UserSettings.Get(
+ group='display', key='alignExtent', subkey='enabled'),
+ constrainRes=UserSettings.Get(
+ group='display', key='compResolution', subkey='enabled'),
+ showCompExtent=UserSettings.Get(
+ group='display', key='showCompExtent', subkey='enabled'))
self.displayIndex += 1
return self.GetMapDisplay()
Modified: grass/branches/releasebranch_7_4/gui/wxpython/mapdisp/main.py
--- grass/branches/releasebranch_7_4/gui/wxpython/mapdisp/main.py 2018-03-20 19:03:07 UTC (rev 72435)
+++ grass/branches/releasebranch_7_4/gui/wxpython/mapdisp/main.py 2018-03-20 19:07:28 UTC (rev 72436)
@@ -533,6 +533,18 @@
self.mapFrm.GetMapWindow().SetAlwaysRenderEnabled(False)
+ self.mapFrm.SetProperties(render=UserSettings.Get(
self.Map.saveToFile.connect(lambda cmd: self.mapFrm.DOutFile(cmd))
self.Map.dToRast.connect(lambda cmd: self.mapFrm.DToRast(cmd))
self.Map.query.connect(
