[GRASS-SVN] r72438 - grass/trunk/scripts/db.droptable
svn_grass at osgeo.org
Tue Mar 20 12:25:01 PDT 2018
Author: mmetz
Date: 2018-03-20 12:25:01 -0700 (Tue, 20 Mar 2018)
New Revision: 72438
grass/trunk/scripts/db.droptable/db.droptable.py
db.droptable: fatal -> warning if table not found, as for g.remove
Modified: grass/trunk/scripts/db.droptable/db.droptable.py
--- grass/trunk/scripts/db.droptable/db.droptable.py 2018-03-20 19:09:33 UTC (rev 72437)
+++ grass/trunk/scripts/db.droptable/db.droptable.py 2018-03-20 19:25:01 UTC (rev 72438)
@@ -75,8 +75,9 @@
# check if table exists
if not grass.db_table_exist(table):
- grass.fatal(_("Table <%s> not found in database <%s>") %
- (table, database))
+ grass.warning(_("Table <%s> not found in database <%s>") %
+ (table, database))
+ sys.exit(0)
# check if table is used somewhere (connected to vector map)
used = grass.db.db_table_in_vector(table)
