[GRASS-SVN] r72440 - grass/trunk/lib/proj
svn_grass at osgeo.org
Tue Mar 20 12:51:46 PDT 2018
Author: mmetz
Date: 2018-03-20 12:51:46 -0700 (Tue, 20 Mar 2018)
New Revision: 72440
grass/trunk/lib/proj/do_proj.c
grass/trunk/lib/proj/do_proj_ll.c
libproj: use 4D type with PROJ 5+
Modified: grass/trunk/lib/proj/do_proj.c
--- grass/trunk/lib/proj/do_proj.c 2018-03-20 19:34:25 UTC (rev 72439)
+++ grass/trunk/lib/proj/do_proj.c 2018-03-20 19:51:46 UTC (rev 72440)
@@ -99,10 +99,10 @@
if (strncmp(info_in->proj, "ll", 2) == 0) {
/* convert to radians */
- c.lp.lam = (*x) / RAD_TO_DEG;
- c.lp.phi = (*y) / RAD_TO_DEG;
- c.lp.z = 0;
- c.lp.t = 0;
+ c.lpzt.lam = (*x) / RAD_TO_DEG;
+ c.lpzt.phi = (*y) / RAD_TO_DEG;
+ c.lpzt.z = 0;
+ c.lpzt.t = 0;
c = proj_trans(P, PJ_FWD, c);
ok = proj_errno(P);
@@ -119,10 +119,10 @@
else {
/* convert to meters */
- c.xy.x = *x * METERS_in;
- c.xy.y = *y * METERS_in;
- c.xy.z = 0;
- c.xy.t = 0;
+ c.xyzt.x = *x * METERS_in;
+ c.xyzt.y = *y * METERS_in;
+ c.xyzt.z = 0;
+ c.xyzt.t = 0;
ok = proj_errno(P);
@@ -245,13 +245,13 @@
ok = 0;
- c.lp.t = 0;
+ c.lpzt.t = 0;
if (strncmp(info_out->proj, "ll", 2) == 0) {
for (i = 0; i < count; i++) {
- c.lp.lam = x[i] / RAD_TO_DEG;
- c.lp.phi = y[i] / RAD_TO_DEG;
- c.lp.z = h[i];
+ c.lpzt.lam = x[i] / RAD_TO_DEG;
+ c.lpzt.phi = y[i] / RAD_TO_DEG;
+ c.lpzt.z = h[i];
if ((ok = proj_errno(P)) < 0)
break;
@@ -263,9 +263,9 @@
else {
- c.lp.z = h[i];
+ c.lpzt.z = h[i];
break;
@@ -276,13 +276,13 @@
else {
- c.xy.t = 0;
+ c.xyzt.t = 0;
- c.xy.x = x[i] * METERS_in;
- c.xy.y = y[i] * METERS_in;
- c.xy.z = h[i];
+ c.xyzt.x = x[i] * METERS_in;
+ c.xyzt.y = y[i] * METERS_in;
+ c.xyzt.z = h[i];
break;
@@ -294,9 +294,9 @@
else {
- c.xy.z = h[i];
+ c.xyzt.z = h[i];
break;
Modified: grass/trunk/lib/proj/do_proj_ll.c
--- grass/trunk/lib/proj/do_proj_ll.c 2018-03-20 19:34:25 UTC (rev 72439)
+++ grass/trunk/lib/proj/do_proj_ll.c 2018-03-20 19:51:46 UTC (rev 72440)
@@ -83,8 +83,10 @@
/* from ll to projected */
+ c.lpzt.z = 0;
+ c.lpzt.t = 0;
ok = proj_errno(P);
@@ -97,8 +99,10 @@
/* from projected to ll */
+ c.xyzt.z = 0;
+ c.xyzt.t = 0;
c = proj_trans(P, PJ_INV, c);
ok = proj_errno(P);
@@ -178,8 +182,10 @@
+ c.lpzt.z = h[i];
+ c.lpzt.t = 0;
@@ -195,8 +201,10 @@
+ c.xyzt.z = h[i];
+ c.xyzt.t = 0;
