[GRASS-SVN] r72443 - grass/trunk/ps/ps.map
Tue Mar 20 13:10:29 PDT 2018
Author: mmetz
Date: 2018-03-20 13:10:29 -0700 (Tue, 20 Mar 2018)
New Revision: 72443
   grass/trunk/ps/ps.map/do_geogrid.c
ps.map: use new PROJ 5+ API if available
Modified: grass/trunk/ps/ps.map/do_geogrid.c
--- grass/trunk/ps/ps.map/do_geogrid.c	2018-03-20 20:00:20 UTC (rev 72442)
+++ grass/trunk/ps/ps.map/do_geogrid.c	2018-03-20 20:10:29 UTC (rev 72443)
@@ -22,11 +22,14 @@
 /* number of segments in curved geographic lines */
 #define SEGS 10
+#ifndef HAVE_PROJ_H
 static void init_proj(struct pj_info *, struct pj_info *);
+static struct pj_info info_out;
+#endif
 static void get_ll_bounds(double *, double *, double *, double *);
 static void check_coords(double, double, double *, double *, int);
 static struct pj_info info_in;
-static struct pj_info info_out;
  * Use proj library to create geographic grid
@@ -43,6 +46,9 @@
     if (PS.geogrid <= 0)
 	return 1;
+    if (color_none(&PS.geogrid_color))
+	return 1;
     grid = (double)PS.geogrid;	/* default to degrees */
     if (strncmp(PS.geogridunit, "d", 1) == 0)
@@ -62,8 +68,10 @@
      * start with first grid line just south of the window north
     /* initialize projection stuff */
     init_proj(&info_in, &info_out);
+#endif
     /* get lat long min max */
     /* probably need something like boardwalk ?? */
@@ -82,12 +90,20 @@
 	    n1 = n2 = g;
 	    e1 = west + (ll * ((east - west) / SEGS));
 	    e2 = e1 + ((east - west) / SEGS);
+#ifdef HAVE_PROJ_H
+	    if (GPJ_do_proj_ll(&e1, &n1, &info_in, PJ_INV) < 0)
+#else
 	    if (pj_do_proj(&e1, &n1, &info_in, &info_out) < 0)
+#endif
 		G_fatal_error(_("Error in pj_do_proj"));
 	    check_coords(e1, n1, &lon, &lat, 1);
 	    e1 = lon;
 	    n1 = lat;
+#ifdef HAVE_PROJ_H
+	    if (GPJ_do_proj_ll(&e2, &n2, &info_in, PJ_INV) < 0)
+#else
 	    if (pj_do_proj(&e2, &n2, &info_in, &info_out) < 0)
+#endif
 	    check_coords(e2, n2, &lon, &lat, 1);
 	    e2 = lon;
@@ -111,12 +127,20 @@
 	    e1 = e2 = g;
 	    n1 = south + (ll * ((north - south) / SEGS));
 	    n2 = n1 + ((north - south) / SEGS);
+#ifdef HAVE_PROJ_H
+#else
+#endif
 	    check_coords(e1, n1, &lon, &lat, 2);
 	    e1 = lon;
 	    n1 = lat;
+#ifdef HAVE_PROJ_H
+#else
+#endif
 	    check_coords(e2, n2, &lon, &lat, 2);
 	    e2 = lon;
@@ -152,6 +176,11 @@
     if (PS.geogrid <= 0 || PS.geogrid_numbers <= 0)
 	return 1;
+    /* initialize projection stuff */
+    init_proj(&info_in, &info_out);
+#endif
 	grid = (double)PS.geogrid;	/* degrees */
@@ -185,7 +214,11 @@
     for (; g > south; g -= grid) {
 	e1 = east;		/* draw at east boundary */
 	n1 = g;
+#ifdef HAVE_PROJ_H
+#else
+#endif
 	e1 = lon;
@@ -226,7 +259,11 @@
     for (; g < east; g += grid) {
 	e1 = g;
 	n1 = south;		/* draw at south edge */
+#ifdef HAVE_PROJ_H
+#else
+#endif
 	e1 = lon;
@@ -257,6 +294,7 @@
     return 0;
  * initialize projection stuff and return proj structures
@@ -280,6 +318,7 @@
     return;
+#endif
  * Use Proj to get min max bounds of region in lat long
@@ -302,7 +341,11 @@
     for (ew = PS.w.west; ew <= PS.w.east; ew += PS.w.ew_res) {
 	e1 = ew;
 	n1 = PS.w.north;
+#ifdef HAVE_PROJ_H
+	if (GPJ_do_proj_ll(&e1, &n1, &info_in, PJ_FWD) < 0)
+#else
 	if (pj_do_proj(&e1, &n1, &info_out, &info_in) < 0)
+#endif
 	if (!first) {
 	    north = n1;
@@ -318,7 +361,11 @@
 	e1 = ew;
 	s1 = PS.w.south;
+#ifdef HAVE_PROJ_H
+	if (GPJ_do_proj_ll(&e1, &s1, &info_in, PJ_FWD) < 0)
+#else
 	if (pj_do_proj(&e1, &s1, &info_out, &info_in) < 0)
+#endif
 	if (!first) {
 	    south = s1;
@@ -335,7 +382,11 @@
     for (ns = PS.w.south; ns <= PS.w.north; ns += PS.w.ns_res) {
 	e1 = PS.w.east;
 	n1 = ns;
+#ifdef HAVE_PROJ_H
+#else
+#endif
 	if (!first) {
 	    east = e1;
@@ -352,7 +403,11 @@
 	w1 = PS.w.west;
 	n1 = ns;
+#ifdef HAVE_PROJ_H
+	if (GPJ_do_proj_ll(&w1, &n1, &info_in, PJ_FWD) < 0)
+#else
 	if (pj_do_proj(&w1, &n1, &info_out, &info_in) < 0)
+#endif
 	if (!first) {
 	    west = w1;
@@ -408,17 +463,29 @@
     if (proj) {
 	/* convert original coords to ll */
+#ifdef HAVE_PROJ_H
+	if (GPJ_do_proj_ll(&e, &n, &info_in, PJ_FWD) < 0)
+#else
 	if (pj_do_proj(&e, &n, &info_out, &info_in) < 0)
+#endif
 	if (par == 1) {
 	    /* lines of latitude -- const. northing */
 	    /* convert correct UTM to ll */
+#ifdef HAVE_PROJ_H
+	    if (GPJ_do_proj_ll(&x, &y, &info_in, PJ_FWD) < 0)
+#else
 	    if (pj_do_proj(&x, &y, &info_out, &info_in) < 0)
+#endif
 	    /* convert new ll back to coords */
+#ifdef HAVE_PROJ_H
+	    if (GPJ_do_proj_ll(&x, &n, &info_in, PJ_INV) < 0)
+#else
 	    if (pj_do_proj(&x, &n, &info_in, &info_out) < 0)
+#endif
 	    *lat = n;
 	    *lon = x;
@@ -426,11 +493,19 @@
 	if (par == 2) {
 	    /* lines of longitude -- const. easting */
+#ifdef HAVE_PROJ_H
+#else
+#endif
+#ifdef HAVE_PROJ_H
+	    if (GPJ_do_proj_ll(&e, &y, &info_in, PJ_INV) < 0)
+#else
 	    if (pj_do_proj(&e, &y, &info_in, &info_out) < 0)
+#endif
 	    *lat = y;
 	    *lon = e;
