[GRASS-SVN] r72445 - grass/trunk/imagery/i.atcorr
svn_grass at osgeo.org
Tue Mar 20 13:24:52 PDT 2018
Author: neteler
Date: 2018-03-20 13:24:52 -0700 (Tue, 20 Mar 2018)
New Revision: 72445
grass/trunk/imagery/i.atcorr/i.atcorr.html
i.atcorr manual: fix some sensor numbering (fixes #3527) - happy b-day, Sajid
Modified: grass/trunk/imagery/i.atcorr/i.atcorr.html
--- grass/trunk/imagery/i.atcorr/i.atcorr.html 2018-03-20 20:11:05 UTC (rev 72444)
+++ grass/trunk/imagery/i.atcorr/i.atcorr.html 2018-03-20 20:24:52 UTC (rev 72445)
@@ -504,37 +504,32 @@
<tr><td>2</td><td><b>meteosat</b> vis band (0.350-1.110)</td></tr>
<tr><td>3</td><td><b>goes east</b> band vis (0.490-0.900)</td></tr>
-<tr><td>4</td><td>goes west band vis (0.490-0.900)</td></tr>
-<tr><td>5</td><td><b>avhrr (noaa6)</b> band 1 (0.550-0.750)</td></tr>
+<tr><td>4</td><td><b>goes west</b> band vis (0.490-0.900)</td></tr>
+<tr><td>5</td><td><b>avhrr</b> (noaa6) band 1 (0.550-0.750)</td></tr>
<tr><td>6</td><td>avhrr (noaa6) band 2 (0.690-1.120)</td></tr>
-<tr><td>7</td><td><b>avhrr (noaa7)</b> band 1 (0.500-0.800)</td></tr>
+<tr><td>7</td><td>avhrr (noaa7) band 1 (0.500-0.800)</td></tr>
<tr><td>8</td><td>avhrr (noaa7) band 2 (0.640-1.170)</td></tr>
-<tr><td>9</td><td><b>avhrr (noaa8)</b> band 1 (0.540-1.010)</td></tr>
+<tr><td>9</td><td>avhrr (noaa8) band 1 (0.540-1.010)</td></tr>
<tr><td>10</td><td>avhrr (noaa8) band 2 (0.680-1.120)</td></tr>
-<tr><td>11</td><td><b>avhrr (noaa9)</b> band 1 (0.530-0.810)</td></tr>
+<tr><td>11</td><td>avhrr (noaa9) band 1 (0.530-0.810)</td></tr>
<tr><td>12</td><td>avhrr (noaa9) band 1 (0.680-1.170)</td></tr>
-<tr><td>13</td><td><b>avhrr (noaa10)</b> band 1 (0.530-0.780)</td></tr>
+<tr><td>13</td><td>avhrr (noaa10) band 1 (0.530-0.780)</td></tr>
<tr><td>14</td><td>avhrr (noaa10) band 2 (0.600-1.190)</td></tr>
-<tr><td>15</td><td><b>avhrr (noaa11)</b> band 1 (0.540-0.820)</td></tr>
+<tr><td>15</td><td>avhrr (noaa11) band 1 (0.540-0.820)</td></tr>
<tr><td>16</td><td>avhrr (noaa11) band 2 (0.600-1.120)</td></tr>
-<tr><td>17</td><td><b>hrv1 (spot1)</b> band 1 (0.470-0.650)</td></tr>
+<tr><td>17</td><td><b>hrv1</b> (spot1) band 1 (0.470-0.650)</td></tr>
<tr><td>18</td><td>hrv1 (spot1) band 2 (0.600-0.720)</td></tr>
<tr><td>19</td><td>hrv1 (spot1) band 3 (0.730-0.930)</td></tr>
<tr><td>20</td><td>hrv1 (spot1) band pan (0.470-0.790)</td></tr>
-<tr><td>21</td><td><b>hrv2 (spot1)</b> band 1 (0.470-0.650)</td></tr>
+<tr><td>21</td><td>hrv2 (spot1) band 1 (0.470-0.650)</td></tr>
<tr><td>22</td><td>hrv2 (spot1) band 2 (0.590-0.730)</td></tr>
<tr><td>23</td><td>hrv2 (spot1) band 3 (0.740-0.940)</td></tr>
<tr><td>24</td><td>hrv2 (spot1) band pan (0.470-0.790)</td></tr>
-<tr><td>25</td><td><b>tm (landsat5)</b> band 1 (0.430-0.560)</td></tr>
+<tr><td>25</td><td><b>tm</b> (landsat5) band 1 (0.430-0.560)</td></tr>
<tr><td>26</td><td>tm (landsat5) band 2 (0.500-0.650)</td></tr>
<tr><td>27</td><td>tm (landsat5) band 3 (0.580-0.740)</td></tr>
<tr><td>28</td><td>tm (landsat5) band 4 (0.730-0.950)</td></tr>
@@ -541,12 +536,12 @@
<tr><td>29</td><td>tm (landsat5) band 5 (1.5025-1.890)</td></tr>
<tr><td>30</td><td>tm (landsat5) band 7 (1.950-2.410)</td></tr>
-<tr><td>31</td><td><b>mss (landsat5)</b> band 1 (0.475-0.640)</td></tr>
+<tr><td>31</td><td><b>mss</b> (landsat5) band 1 (0.475-0.640)</td></tr>
<tr><td>32</td><td>mss (landsat5) band 2 (0.580-0.750)</td></tr>
<tr><td>33</td><td>mss (landsat5) band 3 (0.655-0.855)</td></tr>
<tr><td>34</td><td>mss (landsat5) band 4 (0.785-1.100)</td></tr>
-<tr><td>35</td><td><b>MAS (ER2)</b> band 1 (0.5025-0.5875)</td></tr>
+<tr><td>35</td><td><b>MAS</b> (ER2) band 1 (0.5025-0.5875)</td></tr>
<tr><td>36</td><td>MAS (ER2) band 2 (0.6075-0.7000)</td></tr>
<tr><td>37</td><td>MAS (ER2) band 3 (0.8300-0.9125)</td></tr>
<tr><td>38</td><td>MAS (ER2) band 4 (0.9000-0.9975)</td></tr>
@@ -562,10 +557,9 @@
<tr><td>47</td><td>MODIS band 6 (1.6000-1.6650)</td></tr>
<tr><td>48</td><td>MODIS band 7 (2.0575-2.1825)</td></tr>
-<tr><td>49</td><td><b>avhrr (noaa12)</b> band 1 (0.500-1.000)</td></tr>
+<tr><td>49</td><td><b>avhrr</b> (noaa12) band 1 (0.500-1.000)</td></tr>
<tr><td>50</td><td>avhrr (noaa12) band 2 (0.650-1.120)</td></tr>
-<tr><td>51</td><td><b>avhrr (noaa14)</b> band 1 (0.500-1.110)</td></tr>
+<tr><td>51</td><td>avhrr (noaa14) band 1 (0.500-1.110)</td></tr>
<tr><td>52</td><td>avhrr (noaa14) band 2 (0.680-1.100)</td></tr>
<tr><td>53</td><td><b>POLDER</b> band 1 (0.4125-0.4775)</td></tr>
@@ -577,7 +571,7 @@
<tr><td>59</td><td>POLDER band 7 P1 (0.8100-0.9200)</td></tr>
<tr><td>60</td><td>POLDER band 8 (non polar) (0.8650-0.9400)</td></tr>
-<tr><td>61</td><td><b>etm+ (landsat7)</b> band 1 blue (435nm - 517nm)</td></tr>
+<tr><td>61</td><td><b>etm+</b> (landsat7) band 1 blue (435nm - 517nm)</td></tr>
<tr><td>62</td><td>etm+ (landsat7) band 2 green (508nm - 617nm)</td></tr>
<tr><td>63</td><td>etm+ (landsat7) band 3 red (625nm - 702nm)</td></tr>
<tr><td>64</td><td>etm+ (landsat7) band 4 NIR (753nm - 910nm)</td></tr>
@@ -585,12 +579,12 @@
<tr><td>66</td><td>etm+ (landsat7) band 7 SWIR (2028nm - 2375nm)</td></tr>
<tr><td>67</td><td>etm+ (landsat7) band 8 PAN (505nm - 917nm)</td></tr>
-<tr><td>68</td><td><b>liss (IRC 1C)</b> band 2 (0.502-0.620)</td></tr>
+<tr><td>68</td><td><b>liss</b> (IRC 1C) band 2 (0.502-0.620)</td></tr>
<tr><td>69</td><td>liss (IRC 1C) band 3 (0.612-0.700)</td></tr>
<tr><td>70</td><td>liss (IRC 1C) band 4 (0.752-0.880)</td></tr>
<tr><td>71</td><td>liss (IRC 1C) band 5 (1.452-1.760)</td></tr>
-<tr><td>72</td><td><b>aster </b> band 1 (0.480-0.645)</td></tr>
+<tr><td>72</td><td><b>aster</b> band 1 (0.480-0.645)</td></tr>
<tr><td>73</td><td>aster band 2 (0.588-0.733)</td></tr>
<tr><td>74</td><td>aster band 3N (0.723-0.913)</td></tr>
<tr><td>75</td><td>aster band 4 (1.530-1.750)</td></tr>
@@ -599,8 +593,7 @@
<tr><td>78</td><td>aster band 7 (2.200-2.393)</td></tr>
<tr><td>79</td><td>aster band 8 (2.248-2.475)</td></tr>
<tr><td>80</td><td>aster band 9 (2.295-2.538)</td></tr>
-<tr><td>81</td><td><b>avnir</b> band 1 (408nm - 517nm)</td></tr>
+<tr><td>81</td><td>avnir band 1 (408nm - 517nm)</td></tr>
<tr><td>82</td><td>avnir band 2 (503nm - 612nm)</td></tr>
<tr><td>83</td><td>avnir band 3 (583nm - 717nm)</td></tr>
<tr><td>84</td><td>avnir band 4 (735nm - 922nm)</td></tr>
@@ -615,25 +608,25 @@
<tr><td>91</td><td>RapidEye Red edge band (685nm - 735nm)</td></tr>
<tr><td>92</td><td>RapidEye NIR band (750nm - 860nm)</td></tr>
-<tr><td>93</td><td><b>VGT1 (SPOT4)</b> band 0 (420nm - 497nm)</td></tr>
+<tr><td>93</td><td><b>VGT1</b> (SPOT4) band 0 (420nm - 497nm)</td></tr>
<tr><td>94</td><td>VGT1 (SPOT4) band 2 (603nm - 747nm)</td></tr>
<tr><td>95</td><td>VGT1 (SPOT4) band 3 (740nm - 942nm)</td></tr>
<tr><td>96</td><td>VGT1 (SPOT4) MIR band (1540nm - 1777nm)</td></tr>
-<tr><td>97</td><td><b>VGT2 (SPOT5)</b> band 0 (423nm - 492nm)</td></tr>
+<tr><td>97</td><td><b>VGT2</b> (SPOT5) band 0 (423nm - 492nm)</td></tr>
<tr><td>98</td><td>VGT2 (SPOT5) band 2 (600nm - 737nm)</td></tr>
<tr><td>99</td><td>VGT2 (SPOT5) band 3 (745nm - 945nm)</td></tr>
<tr><td>100</td><td>VGT2 (SPOT5) MIR band (1523nm - 1757nm)</td></tr>
-<tr><td>101</td><td>WorldView 2 Panchromatic band (448nm - 812nm)</td></tr>
-<tr><td>102</td><td>WorldView 2 Coastal Blue band (395nm - 457nm)</td></tr>
-<tr><td>103</td><td>WorldView 2 Blue band (440nm - 517nm)</td></tr>
-<tr><td>104</td><td>WorldView 2 Green band (503nm - 587nm)</td></tr>
-<tr><td>105</td><td>WorldView 2 Yellow band (583nm - 632nm)</td></tr>
-<tr><td>106</td><td>WorldView 2 Red band (623nm - 695nm)</td></tr>
-<tr><td>107</td><td>WorldView 2 Red edge band (698nm - 750nm)</td></tr>
-<tr><td>108</td><td>WorldView 2 NIR1 band (760nm - 905nm)</td></tr>
-<tr><td>109</td><td>WorldView 2 NIR2 band (853nm - 1047nm)</td></tr>
+<tr><td>101</td><td><b>WorldView2</b> Panchromatic band (448nm - 812nm)</td></tr>
+<tr><td>102</td><td>WorldView2 Coastal Blue band (395nm - 457nm)</td></tr>
+<tr><td>103</td><td>WorldView2 Blue band (440nm - 517nm)</td></tr>
+<tr><td>104</td><td>WorldView2 Green band (503nm - 587nm)</td></tr>
+<tr><td>105</td><td>WorldView2 Yellow band (583nm - 632nm)</td></tr>
+<tr><td>106</td><td>WorldView2 Red band (623nm - 695nm)</td></tr>
+<tr><td>107</td><td>WorldView2 Red edge band (698nm - 750nm)</td></tr>
+<tr><td>108</td><td>WorldView2 NIR1 band (760nm - 905nm)</td></tr>
+<tr><td>109</td><td>WorldView2 NIR2 band (853nm - 1047nm)</td></tr>
<tr><td>110</td><td><b>QuickBird</b> Panchromatic band (385nm - 1060nm)</td></tr>
<tr><td>111</td><td>QuickBird Blue band (420nm - 585nm)</td></tr>
@@ -641,8 +634,8 @@
<tr><td>113</td><td>QuickBird Red band (560nm - 747nm)</td></tr>
<tr><td>114</td><td>QuickBird NIR1 band (650nm - 935nm)</td></tr>
-<tr><td>115</td><td><b>Landsat 8 </b> Coastal aerosol band (433nm - 455nm)</td></tr>
-<tr><td>116</td><td>Landsat 8 Blue band (448nm - 515nm)</td></tr>
+<tr><td>115</td><td><b>Landsat 8</b> Coastal aerosol band (433nm - 455nm)</td></tr>
+<tr><td>116</td><td>Landsat 8 Blue band (448nm - 515nm)</td></tr>
<tr><td>117</td><td>Landsat 8 Green band (525nm - 595nm)</td></tr>
<tr><td>118</td><td>Landsat 8 Red band (633nm - 677nm)</td></tr>
<tr><td>119</td><td>Landsat 8 Panchromatic band (498nm - 682nm)</td></tr>
@@ -651,11 +644,11 @@
<tr><td>122</td><td>Landsat 8 SWIR1 band (1540nm - 1672nm)</td></tr>
<tr><td>123</td><td>Landsat 8 SWIR2 band (2073nm - 2322nm)</td></tr>
-<tr><td>115</td><td><b>GeoEye 1</b> Panchromatic band (448nm - 812nm)</td></tr>
-<tr><td>116</td><td>GeoEye 1 Blue band (443nm - 525nm)</td></tr>
-<tr><td>117</td><td>GeoEye 1 Green band (503nm - 587nm)</td></tr>
-<tr><td>118</td><td>GeoEye 1 Red band (653nm - 697nm)</td></tr>
-<tr><td>120</td><td>GeoEye 1 NIR band (770nm - 932nm)</td></tr>
+<tr><td>124</td><td><b>GeoEye 1</b> Panchromatic band (448nm - 812nm)</td></tr>
+<tr><td>125</td><td>GeoEye 1 Blue band (443nm - 525nm)</td></tr>
+<tr><td>126</td><td>GeoEye 1 Green band (503nm - 587nm)</td></tr>
+<tr><td>127</td><td>GeoEye 1 Red band (653nm - 697nm)</td></tr>
+<tr><td>128</td><td>GeoEye 1 NIR band (770nm - 932nm)</td></tr>
<tr><td>129</td><td><b>Spot6</b> Blue band (440nm - 532nm)</td></tr>
<tr><td>130</td><td>Spot6 Green band (515nm - 600nm)</td></tr>
@@ -675,13 +668,13 @@
<tr><td>142</td><td>Pleiades1A NIR band (740nm - 945nm)</td></tr>
<tr><td>143</td><td>Pleiades1A Pan band (460nm - 845nm)</td></tr>
-<tr><td>144</td><td><b>Pleiades1B </b> Blue band 438nm - 560nm)</td></tr>
+<tr><td>144</td><td><b>Pleiades1B</b> Blue band 438nm - 560nm)</td></tr>
<tr><td>145</td><td>Pleiades1B Green band (498nm - 615nm)</td></tr>
<tr><td>146</td><td>Pleiades1B Red band (608nm - 727nm)</td></tr>
<tr><td>147</td><td>Pleiades1B NIR band (750nm - 945nm)</td></tr>
<tr><td>148</td><td>Pleiades1B Pan band (460nm - 845nm)</td></tr>
-<tr><td>149</td><td><b>Worldview3 </b> Pan band (445nm - 812nm)</td></tr>
+<tr><td>149</td><td><b>Worldview3</b> Pan band (445nm - 812nm)</td></tr>
<tr><td>150</td><td>Worldview3 Coastal blue band (395nm - 455nm)</td></tr>
<tr><td>151</td><td>Worldview3 Blue band (443nm - 517nm)</td></tr>
<tr><td>152</td><td>Worldview3 Green band (508nm - 587nm)</td></tr>
@@ -696,10 +689,9 @@
<tr><td>161</td><td>Worldview3 SWIR4 band (1698nm - 1762nm)</td></tr>
<tr><td>162</td><td>Worldview3 SWIR5 band (2133nm - 2195nm)</td></tr>
<tr><td>163</td><td>Worldview3 SWIR6 band (2170nm - 2235nm)</td></tr>
-<tr><td>163</td><td>Worldview3 SWIR7 band (2225nm - 2295nm)</td></tr>
+<tr><td>164</td><td>Worldview3 SWIR7 band (2225nm - 2295nm)</td></tr>
<tr><td>165</td><td>Worldview3 SWIR8 band (2283nm - 2377nm)</td></tr>
-<!-- derived from sensors_csv/sentinel_2A_msi.csv -->
<tr><td>166</td><td><b>Sentinel2A</b> Coastal blue band B1 (430nm - 455nm)</td></tr>
<tr><td>167</td><td>Sentinel2A Blue band B2 (440nm - 530nm)</td></tr>
<tr><td>168</td><td>Sentinel2A Green band B3 (540nm - 580nm)</td></tr>
@@ -707,7 +699,7 @@
<tr><td>170</td><td>Sentinel2A Red edge band B5 (695nm - 712nm)</td></tr>
<tr><td>171</td><td>Sentinel2A Red edge band B6 (733nm - 747nm)</td></tr>
<tr><td>172</td><td>Sentinel2A Red edge band B7 (770nm - 795nm)</td></tr>
-<tr><td>173</td><td>Sentinel2A NIR band B8 (775nm - 905nm)</td></tr>
+<tr><td>173</td><td>Sentinel2A NIR band B8 (775nm - 905nm)</td></tr>
<tr><td>174</td><td>Sentinel2A Red edge band B8A (850nm - 880nm)</td></tr>
<tr><td>175</td><td>Sentinel2A Water vapour band B9 (933nm - 957nm)</td></tr>
<tr><td>176</td><td>Sentinel2A SWIR Cirrus band B10 (1355nm - 1392nm)</td></tr>
@@ -714,7 +706,6 @@
<tr><td>177</td><td>Sentinel2A SWIR band B11 (1558nm - 1667nm)</td></tr>
<tr><td>178</td><td>Sentinel2A SWIR band B12 (2088nm - 2315nm)</td></tr>
-<!-- derived from sensors_csv/sentinel_2B_msi.csv -->
<tr><td>179</td><td><b>Sentinel2B</b> Coastal blue band B1 (430nm - 455nm)</td></tr>
<tr><td>180</td><td>Sentinel2B Blue band B2 (440nm - 530nm)</td></tr>
<tr><td>181</td><td>Sentinel2B Green band B3 (538nm - 580nm)</td></tr>
@@ -722,7 +713,7 @@
<tr><td>183</td><td>Sentinel2B Red edge band B5 (695nm - 712nm)</td></tr>
<tr><td>184</td><td>Sentinel2B Red edge band B6 (730nm - 747nm)</td></tr>
<tr><td>185</td><td>Sentinel2B Red edge band B7 (768nm - 792nm)</td></tr>
-<tr><td>186</td><td>Sentinel2B NIR band B8 (778nm - 905nm)</td></tr>
+<tr><td>186</td><td>Sentinel2B NIR band B8 (778nm - 905nm)</td></tr>
<tr><td>187</td><td>Sentinel2B Red edge band B8A (850nm - 877nm)</td></tr>
<tr><td>188</td><td>Sentinel2B Water vapour band B9 (930nm - 955nm)</td></tr>
<tr><td>189</td><td>Sentinel2B SWIR Cirrus band B10 (1358nm - 1397nm)</td></tr>
