[GRASS-SVN] r72448 - grass/trunk/lib/proj
Tue Mar 20 15:24:58 PDT 2018
Author: mmetz
Date: 2018-03-20 15:24:58 -0700 (Tue, 20 Mar 2018)
New Revision: 72448
   grass/trunk/lib/proj/do_proj.c
   grass/trunk/lib/proj/do_proj_ll.c
libproj: simplify PROJ 5 usage
Modified: grass/trunk/lib/proj/do_proj.c
--- grass/trunk/lib/proj/do_proj.c	2018-03-20 22:16:17 UTC (rev 72447)
+++ grass/trunk/lib/proj/do_proj.c	2018-03-20 22:24:58 UTC (rev 72448)
@@ -53,6 +53,28 @@
     return pjdef;
+/* TODO: add to gprojects.h */
+/* Create a transformation object */
+int GPJ_prepare_pjinfo(const struct pj_info *info_in,
+                       const struct pj_info *info_out,
+		       struct pj_info *info_new)
+    char *projdef, *projdefin, *projdefout;
+    projdefin = gpj_get_def(info_in->pj);
+    projdefout = gpj_get_def(info_out->pj);
+    projdef = NULL;
+    G_asprintf(&projdef, "+proj=pipeline +step %s +inv +step %s", projdefin, projdefout);
+    info_new->pj = proj_create(PJ_DEFAULT_CTX, projdef);
+    if (info_new->pj == NULL)
+	G_fatal_error(_("proj_create() failed"));
+    G_free(projdefin);
+    G_free(projdefout);
+    G_free(projdef);
+    return 1;
 #endif
 /* TODO: rename pj_ to GPJ_ to avoid symbol clash with PROJ lib */
@@ -79,20 +101,10 @@
     int ok;
 #ifdef HAVE_PROJ_H
-    PJ *P;
-    char *projdef, *projdefin, *projdefout;
+    struct pj_info info_new;
     PJ_COORD c;
-    projdefin = gpj_get_def(info_in->pj);
-    projdefout = gpj_get_def(info_out->pj);
-    projdef = NULL;
-    G_asprintf(&projdef, "+proj=pipeline +step %s +inv +step %s", projdefin, projdefout);
-    P = proj_create(PJ_DEFAULT_CTX, projdef);
-    if (P == NULL)
-	G_fatal_error(_("proj_create() failed"));
-    G_free(projdefin);
-    G_free(projdefout);
-    G_free(projdef);
+    GPJ_prepare_pjinfo(info_in, info_out, &info_new);
     METERS_in = info_in->meters;
     METERS_out = info_out->meters;
@@ -103,8 +115,8 @@
 	c.lpzt.phi = (*y) / RAD_TO_DEG;
 	c.lpzt.z = 0;
 	c.lpzt.t = 0;
-	c = proj_trans(P, PJ_FWD, c);
-	ok = proj_errno(P);
+	c = proj_trans(info_new.pj, PJ_FWD, c);
+	ok = proj_errno(info_new.pj);
 	if (strncmp(info_out->proj, "ll", 2) == 0) {
 	    /* convert to degrees */
@@ -123,8 +135,8 @@
 	c.xyzt.y = *y * METERS_in;
 	c.xyzt.z = 0;
 	c.xyzt.t = 0;
@@ -137,7 +149,7 @@
 	    *y = c.xy.y / METERS_out;
-    proj_destroy(P);
+    proj_destroy(info_new.pj);
     if (ok < 0) {
 	G_warning(_("proj_trans() failed: %d"), ok);
@@ -218,20 +230,10 @@
     int has_h = 1;
 #ifdef HAVE_PROJ_H
     int i;
-    PJ *P;
     PJ_COORD c;
-    projdef = NULL;
-    if (P == NULL)
-    G_free(projdef);
@@ -252,8 +254,8 @@
 		c.lpzt.lam = x[i] / RAD_TO_DEG;
 		c.lpzt.phi = y[i] / RAD_TO_DEG;
 		c.lpzt.z = h[i];
-		if ((ok = proj_errno(P)) < 0)
+		if ((ok = proj_errno(info_new.pj)) < 0)
 		    break;
 		x[i] = c.lp.lam * RAD_TO_DEG;
@@ -266,8 +268,8 @@
 		c.lpzt.z = h[i];
 		    break;
 		/* convert to map units */
 		x[i] = c.xy.x / METERS_out;
@@ -283,8 +285,8 @@
 		c.xyzt.x = x[i] * METERS_in;
 		c.xyzt.y = y[i] * METERS_in;
 		c.xyzt.z = h[i];
 		    break;
@@ -297,8 +299,8 @@
 		c.xyzt.z = h[i];
 		    break;
@@ -308,7 +310,7 @@
     if (!has_h)
 	G_free(h);
-    proj_destroy(P);
     if (ok < 0) {
Modified: grass/trunk/lib/proj/do_proj_ll.c
--- grass/trunk/lib/proj/do_proj_ll.c	2018-03-20 22:16:17 UTC (rev 72447)
+++ grass/trunk/lib/proj/do_proj_ll.c	2018-03-20 22:24:58 UTC (rev 72448)
@@ -24,17 +24,6 @@
 static double METERS_in = 1.0;
-#ifdef HAVE_PROJ_H
-static char *gpj_get_def(PJ *P)
-    char *pjdef;
-    PJ_PROJ_INFO pj_proj_info = proj_pj_info(P);
-    pjdef = G_store(pj_proj_info.definition);
-    return pjdef;
  * \brief Re-project a point between a co-ordinate system and its
  *        latitude / longitude equivalent, using the same datum,
@@ -43,8 +32,8 @@
  * This function takes a pointer to a pj_info structure as argument,
  * and projects a point between the co-ordinate system and its
  * latitude / longitude equivalent. With forward projection, the point
- * is projected from the co-ordinate system to its latitude / longitude
- * equivalent, while backward projection does the reverse.
+ * is projected from the equivalent latitude / longitude system to the
+ * projected co-ordinate system, while backward projection does the reverse.
  * The easting and northing of the point are contained in two pointers
  * passed to the function; these will be overwritten by the co-ordinates
  * of the re-projected point.
@@ -58,11 +47,11 @@
 int GPJ_do_proj_ll(double *x, double *y,
-	          const struct pj_info *info_in, int direction)
+	           const struct pj_info *info_in, int direction)
     int ok;
-    PJ *P;
-    char *projdef;
+#ifdef HAVE_PROJ_H
     PJ_COORD c;
     ok = 0;
@@ -71,12 +60,6 @@
 	return ok;
-    projdef = gpj_get_def(info_in->pj);
-    if (P == NULL)
-    G_free(projdef);
     if (direction == PJ_FWD) {
@@ -88,8 +71,8 @@
 	c.lpzt.z = 0;
 	c.lpzt.t = 0;
+	c = proj_trans(info_in->pj, PJ_FWD, c);
+	ok = proj_errno(info_in->pj);
 	*x = c.xy.x / METERS_in;
@@ -104,18 +87,34 @@
 	c.xyzt.z = 0;
 	c.xyzt.t = 0;
-	c = proj_trans(P, PJ_INV, c);
+	c = proj_trans(info_in->pj, PJ_INV, c);
 	*x = c.lp.lam * RAD_TO_DEG;
 	*y = c.lp.phi * RAD_TO_DEG;
-    proj_destroy(P);
     if (ok < 0) {
+#else
+    struct pj_info info_out;
+    if ((ok = GPJ_get_equivalent_latlong(&info_out, info_in)) != 1)
+	return ok;
+    if (direction == PJ_FWD) {
+	/* from ll to projected */
+	ok = pj_do_proj(x, y, &info_out, info_in);
+    else {
+	/* from projected to ll */
+	ok = pj_do_proj(x, y, info_in, &info_out);
+    pj_free(info_out.pj);
+#endif
     return ok;
@@ -127,8 +126,8 @@
  * and projects an array of points between the co-ordinate system and its
  * latitude / longitude equivalent. With forward projection, the points
- * are projected from the co-ordinate system to its latitude / longitude
+ * are projected from the equivalent latitude / longitude system to the
  * The easting and northing of the points are contained in two pointers passed
  * to the function; these will be overwritten by the co-ordinates of the
  * re-projected point.
@@ -149,10 +148,10 @@
     int ok;
+#ifdef HAVE_PROJ_H
     int has_h = 1;
     int i;
-    PJ *P;
-    char *projdef;
     PJ_COORD c;
     ok = 0;
@@ -161,12 +160,6 @@
 	return ok;
-    if (P == NULL)
-    G_free(projdef);
     if (h == NULL) {
@@ -187,8 +180,8 @@
 	    c.lpzt.z = h[i];
 	    c.lpzt.t = 0;
+	    if ((ok = proj_errno(info_in->pj)) < 0)
 		break;
@@ -206,8 +199,8 @@
 	    c.xyzt.z = h[i];
 	    c.xyzt.t = 0;
 		break;
@@ -217,13 +210,27 @@
     if (!has_h)
 	G_free(h);
-    proj_destroy(P);
     if (ok < 0) {
+#else
+	return ok;
+	ok = pj_do_transform(count, x, y, h, &info_out, info_in);
+    else {
+	ok = pj_do_transform(count, x, y, h, info_in, &info_out);
+#endif
     return ok;
-#endif /* HAVE_PROJ_H */
