[GRASS-SVN] r72451 - grass/trunk/general/g.region
svn_grass at osgeo.org
Tue Mar 20 15:56:47 PDT 2018
Author: mmetz
Date: 2018-03-20 15:56:47 -0700 (Tue, 20 Mar 2018)
New Revision: 72451
grass/trunk/general/g.region/printwindow.c
g.region: simplify PROJ 5 usage
Modified: grass/trunk/general/g.region/printwindow.c
--- grass/trunk/general/g.region/printwindow.c 2018-03-20 22:47:36 UTC (rev 72450)
+++ grass/trunk/general/g.region/printwindow.c 2018-03-20 22:56:47 UTC (rev 72451)
@@ -244,9 +244,6 @@
/* projection information of input map */
struct Key_Value *in_proj_info, *in_unit_info;
struct pj_info iproj; /* input map proj parameters */
-#ifndef HAVE_PROJ_H
- struct pj_info oproj; /* output map proj parameters */
-#endif
/* read current projection info */
if ((in_proj_info = G_get_projinfo()) == NULL)
@@ -261,22 +258,7 @@
G_free_key_value(in_proj_info);
G_free_key_value(in_unit_info);
- /* output projection to lat/long w/ same ellipsoid as input */
- oproj.zone = 0;
- oproj.meters = 1.;
- sprintf(oproj.proj, "ll");
- if ((oproj.pj = pj_latlong_from_proj(iproj.pj)) == NULL)
- G_fatal_error(_("Unable to update lat/long projection parameters"));
-#endif
- /* for DEBUG
- pj_print_proj_params(&iproj,&oproj);
- /* do the transform
- * syntax: pj_do_proj(outx, outy, in_info, out_info)
* 1 ------ 2
* | | map corners
@@ -285,11 +267,8 @@
latitude = window->north;
longitude = window->west;
-#ifdef HAVE_PROJ_H
+ /* get lat/long w/ same datum/ellipsoid as input */
if (GPJ_do_proj_ll(&longitude, &latitude, &iproj, PJ_INV) < 0)
-#else
- if (pj_do_proj(&longitude, &latitude, &iproj, &oproj) < 0)
-#endif
G_fatal_error(_("Error in pj_do_proj (projection of input coordinate pair)"));
lo1 = longitude;
@@ -297,11 +276,8 @@
longitude = window->east;
-#ifdef HAVE_PROJ_H
-#else
-#endif
lo2 = longitude;
@@ -309,11 +285,8 @@
latitude = window->south;
-#ifdef HAVE_PROJ_H
-#else
-#endif
lo3 = longitude;
@@ -321,11 +294,8 @@
-#ifdef HAVE_PROJ_H
-#else
-#endif
lo4 = longitude;
@@ -335,11 +305,8 @@
* not average of the projected corner coordinates */
latitude = (window->north + window->south) / 2.;
longitude = (window->west + window->east) / 2.;
-#ifdef HAVE_PROJ_H
-#else
-#endif
loc = longitude;
@@ -494,11 +461,8 @@
PJ_COORD c;
PJ_FACTORS fact;
#else
struct FACTORS fact;
LP lp;
- G_zero(&fact, sizeof(struct FACTORS));
#endif
@@ -511,31 +475,15 @@
if (pj_get_kv(&iproj, in_proj_info, in_unit_info) < 0)
G_fatal_error(_("Can't get projection key values of current location"));
- oproj.zone = 0;
-#endif
- /* for DEBUG
- pj_print_proj_params(&iproj, &oproj);
+ G_free_key_value(in_proj_info);
+ G_free_key_value(in_unit_info);
/* center coordinates of the current region,
-#ifdef HAVE_PROJ_H
-#else
-#endif
#ifdef HAVE_PROJ_H
@@ -546,14 +494,12 @@
fact = proj_factors(iproj.pj, c);
convergence = RAD2DEG(fact.meridian_convergence);
#else
+ G_zero(&fact, sizeof(struct FACTORS));
lp.u = DEG2RAD(longitude);
lp.v = DEG2RAD(latitude);
pj_factors(lp, iproj.pj, 0.0, &fact);
convergence = RAD2DEG(fact.conv);
#endif
- G_free_key_value(in_proj_info);
- G_free_key_value(in_unit_info);
if (print_flag & PRINT_SH)
@@ -570,8 +516,6 @@
if (print_flag & PRINT_MBBOX) {
double sh_ll_w, sh_ll_e, sh_ll_n, sh_ll_s, loc;
- /*double sh_ll_rows, sh_ll_cols; */
/* Needed to calculate the LL bounding box */
if ((G_projection() != PROJECTION_XY)) {
/* projection information of input and output map */
@@ -618,20 +562,6 @@
G_free_key_value(out_proj_info);
G_free_key_value(out_unit_info);
- oproj.zone = 0;
- G_fatal_error(_("Unable to up lat/long projection parameters"));
/*Calculate the largest bounding box */
/* center */
