[GRASS-SVN] r72454 - in grass-addons/grass7/imagery: . i.signature.copy
svn_grass at osgeo.org
Tue Mar 20 16:49:03 PDT 2018
Author: lucadelu
Date: 2018-03-20 16:49:03 -0700 (Tue, 20 Mar 2018)
New Revision: 72454
Added:
grass-addons/grass7/imagery/i.signature.copy/
grass-addons/grass7/imagery/i.signature.copy/Makefile
grass-addons/grass7/imagery/i.signature.copy/i.signature.copy.html
grass-addons/grass7/imagery/i.signature.copy/i.signature.copy.py
i.signature.copy: first version, for sajid birthday, see #3526
Added: grass-addons/grass7/imagery/i.signature.copy/Makefile
--- grass-addons/grass7/imagery/i.signature.copy/Makefile (rev 0)
+++ grass-addons/grass7/imagery/i.signature.copy/Makefile 2018-03-20 23:49:03 UTC (rev 72454)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = i.signature.copy
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Added: grass-addons/grass7/imagery/i.signature.copy/i.signature.copy.html
--- grass-addons/grass7/imagery/i.signature.copy/i.signature.copy.html (rev 0)
+++ grass-addons/grass7/imagery/i.signature.copy/i.signature.copy.html 2018-03-20 23:49:03 UTC (rev 72454)
@@ -0,0 +1,12 @@
+<H2>DESCRIPTION</H2>
+<em>i.signature.copy</em> copies a signature file from a group/subgroup to another group/subgroup
+<H2>EXAMPLE</H2>
+<div div="code"><pre>
+i.signature.copy igroup=name isubgroup=subname isignature=test ogroup=name2 osubgroup=subname2
+</pre></div>
+<H2>AUTHOR</H2>
+Luca Delucchi
Added: grass-addons/grass7/imagery/i.signature.copy/i.signature.copy.py
--- grass-addons/grass7/imagery/i.signature.copy/i.signature.copy.py (rev 0)
+++ grass-addons/grass7/imagery/i.signature.copy/i.signature.copy.py 2018-03-20 23:49:03 UTC (rev 72454)
@@ -0,0 +1,134 @@
+#!/usr/bin/env python
+# MODULE: i.signature.copy
+# AUTHOR(S): Luca Delucchi
+# PURPOSE: List signature file for a group/subgroup
+# COPYRIGHT: (C) 2018 by the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+#%module
+#% description: List signature file for a group/subgroup
+#% keyword: imagery
+#% keyword: copy
+#% keyword: group
+#%end
+#%option G_OPT_I_GROUP
+#% key: igroup
+#% description: Input group for signature file to copy
+#% required : yes
+#%end
+#%option G_OPT_I_SUBGROUP
+#% key: isubgroup
+#% description: Input subgroup for signature file to copy
+#% required : yes
+#%end
+#%option
+#% key: isignature
+#% type: string
+#% gisprompt: old,sig,sigfile
+#% label: Input signature file
+#% description: The name of the input signature file to copy
+#% required: yes
+#%end
+#%option
+#% key: ogroup
+#% type: string
+#% gisprompt: old,group,group
+#% label: Output group where copy the signature file
+#% required : yes
+#%end
+#%option
+#% key: osubgroup
+#% type: string
+#% gisprompt: old,subgroup,subgroup
+#% description: Output subgroup where copy the signature file
+#% required : yes
+#%end
+#%option
+#% key: osignature
+#% type: string
+#% label: Output signature file
+#% description: The name of the output signature file
+#% required: no
+#%end
+import os
+import sys
+import shutil
+import grass.script as grass
+def main():
+ igroup = options['igroup']
+ isub = options['isubgroup']
+ isign = options['isignature']
+ ogroup = options['ogroup']
+ osub = options['osubgroup']
+ osign = options['osignature']
+ #check if output signature is set
+ if not osign:
+ osign = isign
+ gisenv = grass.gisenv()
+ # try to split input group and mapset
+ try:
+ name, mapset = igroup.split('@', 1)
+ except ValueError:
+ name = igroup
+ mapset = gisenv['MAPSET']
+ ipath = os.path.join(gisenv['GISDBASE'], gisenv['LOCATION_NAME'],
+ mapset, name, 'subgroup', isub, isign)
+ if not os.path.exists(ipath):
+ grass.fatal(_("<{}> does not exist".format(ipath)))
+ # try to split output group and mapset
+ try:
+ oname, omapset = ogroup.split('@', 1)
+ oname = ogroup
+ omapset = gisenv['MAPSET']
+ opath = os.path.join(gisenv['GISDBASE'], gisenv['LOCATION_NAME'],
+ omapset, oname, 'subgroup', osub)
+ if not os.path.exists(opath):
+ grass.fatal(_("<{pa}> does not exist, do group <{gr}> and "
+ "subgroup <{su}> exist?".format(pa=ipath, gr=ogroup,
+ su=osub)))
+ else:
+ opath = os.path.join(opath, osign)
+ if os.path.exists(opath) and not grass.overwrite():
+ grass.fatal(_("ERROR: option <osignature>: <{}> exists. To "
+ "overwrite, use the --overwrite flag".format(osign)))
+ # try to copy the signature file otherwise return an error
+ try:
+ shutil.copy2(ipath, opath)
+ return
+ except:
+ grass.fatal(_("ERROR: copying {inp} to {oup}".format(inp=ipath,
+ oup=opath)))
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ sys.exit(main())
+ sys.exit(main())
