[GRASS-SVN] r72457 - grass/trunk/lib/gis
svn_grass at osgeo.org
Wed Mar 21 02:03:11 PDT 2018
Author: martinl
Date: 2018-03-21 02:03:10 -0700 (Wed, 21 Mar 2018)
New Revision: 72457
grass/trunk/lib/gis/parser.c
libgis: improve parser UI description error reporting
Modified: grass/trunk/lib/gis/parser.c
--- grass/trunk/lib/gis/parser.c 2018-03-21 01:07:35 UTC (rev 72456)
+++ grass/trunk/lib/gis/parser.c 2018-03-21 09:03:10 UTC (rev 72457)
@@ -344,6 +344,9 @@
G_basename(tmp_name, "exe");
st->pgm_name = tmp_name;
+ if (!st->module_info.label && !st->module_info.description)
+ G_warning(_("Bug in UI description. Missing module description"));
/* Stash default answers */
opt = &st->first_option;
@@ -351,8 +354,12 @@
if (opt->required)
st->has_required = 1;
+ if (!opt->key)
+ G_warning(_("Bug in UI description. Missing option key"));
if (!valid_option_name(opt->key))
- G_warning(_("BUG in option name, '%s' is not valid"), opt->key);
+ G_warning(_("Bug in UI description. Option key <%s> is not valid"), opt->key);
+ if (!opt->label && !opt->description)
+ G_warning(_("Bug in UI description. Description for option <%s> missing"), opt->key ? opt->key : "?");
/* Parse options */
if (opt->options) {
@@ -404,7 +411,7 @@
j++;
if (!found) {
- G_warning(_("BUG in descriptions, option '%s' in <%s> does not exist"),
+ G_warning(_("Bug in UI description. Option '%s' in <%s> does not exist"),
tokens[i], opt->key);
else {
