[GRASS-SVN] r72499 - in grass/branches/releasebranch_7_2/temporal/t.rast.series: . testsuite
Thu Mar 22 08:46:50 PDT 2018
Author: veroandreo
Date: 2018-03-22 08:46:50 -0700 (Thu, 22 Mar 2018)
New Revision: 72499
   grass/branches/releasebranch_7_2/temporal/t.rast.series/t.rast.series.py
   grass/branches/releasebranch_7_2/temporal/t.rast.series/testsuite/test_series.py
t.rast.series: Fixed bug #3223 wrong time stamp for raster map in case where condition was used (trunk, r72479)
Modified: grass/branches/releasebranch_7_2/temporal/t.rast.series/t.rast.series.py
--- grass/branches/releasebranch_7_2/temporal/t.rast.series/t.rast.series.py	2018-03-22 15:44:10 UTC (rev 72498)
+++ grass/branches/releasebranch_7_2/temporal/t.rast.series/t.rast.series.py	2018-03-22 15:46:50 UTC (rev 72499)
@@ -122,6 +122,7 @@
             grass.fatal(_("%s failed. Check above error messages.") % 'r.series')
         if not add_time:
             # Create the time range for the output map
             if output.find("@") >= 0:
                 id = output
@@ -131,8 +132,25 @@
             map = sp.get_new_map_instance(id)
             map.load()
-            map.set_temporal_extent(sp.get_temporal_extent())
+            # We need to set the temporal extent from the subset of selected maps
+            maps = sp.get_registered_maps_as_objects(where=where, order=order, dbif=None)
+            first_map = maps[0]
+            last_map = maps[-1]
+            start_a, end_a = first_map.get_temporal_extent_as_tuple()
+            start_b, end_b = last_map.get_temporal_extent_as_tuple()
+            if end_b is None:
+                end_b = start_b
+            if first_map.is_time_absolute():
+                extent = tgis.AbsoluteTemporalExtent(start_time=start_a, end_time=end_b)
+            else:
+                extent = tgis.RelativeTemporalExtent(start_time=start_a, end_time=end_b,
+                                                     unit=first_map.get_relative_time_unit())
+            map.set_temporal_extent(extent=extent)
             # Register the map in the temporal database
             if map.is_in_db():
                 map.update_all()
Modified: grass/branches/releasebranch_7_2/temporal/t.rast.series/testsuite/test_series.py
--- grass/branches/releasebranch_7_2/temporal/t.rast.series/testsuite/test_series.py	2018-03-22 15:44:10 UTC (rev 72498)
+++ grass/branches/releasebranch_7_2/temporal/t.rast.series/testsuite/test_series.py	2018-03-22 15:46:50 UTC (rev 72499)
@@ -45,11 +45,23 @@
         cls.del_temp_region()
         cls.runModule("t.remove", flags="rf", type="strds", inputs="A")
+        cls.runModule("t.unregister", type="raster",
+                      maps="series_average,series_maximum,series_minimum,series_minimum_2")
         cls.runModule("g.remove", flags="f", type="raster", name="series_average")
         cls.runModule("g.remove", flags="f", type="raster", name="series_maximum")
         cls.runModule("g.remove", flags="f", type="raster", name="series_minimum")
         cls.runModule("g.remove", flags="f", type="raster", name="series_minimum_2")
+    def test_time_stamp(self):
+        self.assertModule("t.rast.series", input="A", method="average",
+                          output="series_time_stamp", where="start_time > '2001-02-01'")
+        tinfo_string="""start_time=2001-02-01 00:00:00
+                        end_time=2001-05-01 00:00:00"""
+        info = SimpleModule("t.info", flags="g", type="raster", input="series_time_stamp")
+        self.assertModuleKeyValue(module=info, reference=tinfo_string, precision=2, sep="=")
     def test_average(self):
                           output="series_average")
@@ -112,6 +124,8 @@
