[GRASS-SVN] r72506 - in sandbox: . sbl sbl/t.rast.aggregate.update
Thu Mar 22 15:09:50 PDT 2018
Author: sbl
Date: 2018-03-22 15:09:50 -0700 (Thu, 22 Mar 2018)
New Revision: 72506
Added:
   sandbox/sbl/
   sandbox/sbl/t.rast.aggregate.update/
   sandbox/sbl/t.rast.aggregate.update/t.rast.aggregate.update.py
draft for t.rast.aggregate.updat
Added: sandbox/sbl/t.rast.aggregate.update/t.rast.aggregate.update.py
--- sandbox/sbl/t.rast.aggregate.update/t.rast.aggregate.update.py	                        (rev 0)
+++ sandbox/sbl/t.rast.aggregate.update/t.rast.aggregate.update.py	2018-03-22 22:09:50 UTC (rev 72506)
@@ -0,0 +1,487 @@
+#!/usr/bin/env python
+MODULE:    t.rast.aggregate.update
+AUTHOR(S): Stefan Blumentrath < stefan.blumentrath AT nina.no>
+PURPOSE:   Update a STRDS generated by t.rast.aggregate from updated input STRDS
+COPYRIGHT: (C) 2018 by the GRASS Development Team
+           This program is free software under the GNU General Public
+           License (>=v2). Read the file COPYING that comes with GRASS
+           for details.
+To Dos:
+- use proper cleanup routine, esp if using csv + vrt (copy from other modules)
+- handle layers in mask input
+- add progress bar
+- make date_from and date_to dependent on each other or use today as date_to if not specified
+#%module
+#% description: Update a STRDS generated by t.rast.aggregate from updated input STRDS
+#% keyword: temporal
+#% keyword: aggregate
+#%end
+#%option G_OPT_STRDS_INPUT
+#%end
+#%option
+#% key: completeness
+#% type: integer
+#% description: Percentage of completeness for granules to add/update
+#% answer: 100
+#% required: no
+#%end
+#%flag
+#% key: n
+#% description: Do not check for potenitally reprocessed input
+#%end
+import sys
+import os
+import grass.script as grass
+import grass.pygrass.modules.interface as mod_iface
+from datetime import datetime
+from grass.temporal import datetime_math
+from grass.temporal.core import get_current_mapset
+from copy import deepcopy
+import grass.temporal as tgis
+if not "GISBASE" in os.environ.keys():
+    grass.message("You must be in GRASS GIS to run this program.")
+    sys.exit(1)
+def cmd2dict(command):
+    """Parse GRASS shell command string (e.g. from history) into Python dict
+    :param command: GRASS shell command string
+    :returns: Module name as string and Python dict with command options and flags
+    :type command: string
+    :rtype: string, dict
+    :Example:
+    >>> cmd2dict("v.db.select -r map=roadsmajor where=\"ROAD_NAME = 'NC-98'\")
+    ('t.rast.aggregate',
+     {'basename': 'snow_days_seNorge_1km_years',
+      'granularity': '1 years',
+      'input': 'snow_bin_seNorge_1km_days',
+      'method': 'sum',
+      'nprocs': '10',
+      'output': 'snow_days_seNorge_1km_years',
+      'overwrite': True,
+      'quiet': True,
+      'where': 'start_time >=  1958-01-01  AND start_time <=  2016-12-31 '})
+    import shlex
+    command_dict = {}
+    name = command.split(' ')[0]
+    if command.find('--v') > -1 or command.find('--verbose') > -1:
+        command_dict['verbose'] = True
+    elif command.find('--q') > -1 or command.find('--quiet') > -1:
+        command_dict['quiet'] = True
+    if command.find('--o') > -1 or command.find('--overwrite') > -1:
+        command_dict['overwrite'] = True
+    for opt in shlex.split(command):
+        if opt.find('=') > 0:
+            optlist = opt.split('=', 1)
+            opt_str = optlist[1].lstrip(' ').rstrip(' ')
+            #if opt_str.find(' ') > 0:
+            #    command_dict[optlist[0]] = '"{}"'.format(opt_str)
+            #else:
+            command_dict[optlist[0]] = opt_str
+        if opt.startswith('-') and opt.find('--') <0:
+            command_dict['flags'] = opt.lstrip('-')
+    return name, command_dict
+def genRandomName(length):
+    """Generate a random name of length "length" starting with a letter
+    :param length: length of the random name to generate
+    :returns: String with a random name of length "length" starting with a letter
+    :type length: int
+    :rtype: string
+    :Example:
+    >>> genRandomName(12)
+    'MxMa1kAS13s9'
+    import string
+    import random
+    chars = string.ascii_uppercase + string.ascii_lowercase + string.digits
+    randomname = '1'
+    while randomname[0].isdigit():
+        randomname = ''.join(random.choice(chars) for _ in range(length))
+    return randomname
+randname =  genRandomName(21)
+def integrateUpdates(agg_strds, input_strds, tempfile):
+    """Integrates updates into input STRDS from t.rast.aggregate
+    :param agg_strds: STRDS produced by t.rast.aggregate
+    :param input_strds: STRDS with updated granules
+    :param tempfile: Path to a tempfile
+    :returns: None
+    :type agg_strds: string
+    :type input_strds: string
+    :type tempfile: string
+    :rtype: None
+    :Example:
+    >>> integrateUpdates(strds, randname, tmpf)
+    with open(tempfile, 'w') as new_maps:
+        #new_maps = StringIO()
+        new_maps.write(grass.read_command('t.rast.list',
+                              input=input_strds, flags='u',
+                              columns='name,start_time,end_time').rstrip('\n'))
+    grass.run_command('t.remove', inputs=input_strds)
+    grass.run_command('t.register', input=agg_strds, file=tempfile, separator='|', overwrite=True)
+def gran2where(datetime_start, granularity):
+    end = datetime_math.increment_datetime_by_string(datetime_start, granularity, mult=1)
+    start_str = datetime.strftime(datetime_start, "%Y-%m-%dT%H:%M:%S.%s")
+    end_str = datetime.strftime(end, "%Y-%m-%dT%H:%M:%S.%s")
+    where_str = "(end_time >= '{0}'  AND start_time <= '{1}')".format(start_str, end_str)
+    return where_str
+def checkGranule(instrds, datetime_start, completeness, from_gran, to_gran):
+    end = datetime_math.increment_datetime_by_string(datetime_start, to_gran, mult=1)
+    n = 0
+    inc = datetime_start
+    while inc < end:
+        n = n + 1
+        inc = datetime_math.increment_datetime_by_string(inc, from_gran, mult=1)
+    inmaps = grass.read_command('t.rast.list',
+                              input=instrds,
+                              where=where_str, flags='u',
+                              columns='id,start_time,end_time').rstrip('\n').split('\n')
+    if len(inmaps) / float(completeness) >= n / 100.0:
+        return where_str
+def main():
+    # Parse input options
+    strds = options['input']
+    completeness = options['completeness']
+    tmpf = grass.tempfile()
+    no_checks = flags['n']
+    tgis.init()
+    dbif = tgis.SQLDatabaseInterfaceConnection()
+    dbif.connect()
+    stds = tgis.open_old_stds(strds, 'strds', dbif)
+    try:
+        strdsinfo = grass.parse_command('t.info', flags='g', input=strds.split('@')[0])
+    except:
+        grass.fatal('{} not in current mapset! Cannot modify.'.format(strds))
+    hist = grass.read_command('t.info', flags='h', input=strds).rstrip('\n')
+    for l in hist.replace('\\\n','').split('\n'):
+         if l.split(' ')[0] == 't.rast.aggregate':
+             command = l
+    name, command_dict = cmd2dict(command)
+    cmapset = get_current_mapset()
+    if command_dict['input'].find('@') < 0:
+        strds_names = []
+        strds_list = grass.read_command('t.list', quiet = True).rstrip('\n').split('\n')
+        for s in strds_list:
+            if s.startswith('{}@{}'.format(command_dict['input'], cmapset)):
+                strds_name = s
+            elif s.startswith('{}@'.format(command_dict['input'])):
+                strds_names.append(s)
+            if len(strds_names) > 1:
+                grass.warning('Found more than one STRDS with the same name as the aggregation input')
+                grass.warning('Using: {}'.format(strds_names[0]))
+                grass.warning('Found also: {}'.format(','.join(strds_names[1:])))
+        strds_name = strds_names[0]
+        command_dict['input'] = strds_name
+    inputinfo = grass.parse_command('t.info', flags='g', input=command_dict['input'])
+    # Get all maps for update
+    # get possibly reprocessed maps
+    updated_granules = []
+    if not no_checks:
+        agg_maps = grass.read_command('t.rast.list', input=strds, flags='u',
+                                      columns='id,name,creation_time,start_time,end_time').rstrip('\n').split('\n')
+        for m in agg_maps:
+            in_maps = grass.read_command('t.rast.list',
+                                         input=command_dict['input'],
+                                         where='creation_time > \'{0}\' AND \
+                                         end_time >= \'{1}\' AND \
+                                         end_time <= \'{2}\' '.format(m.split('|')[2],
+        m.split('|')[3],
+        m.split('|')[4]), flags='u',
+            if in_maps[0] != '':
+                if completeness > 0:
+                    gran = datetime_math.string_to_datetime(m.split('|')[3])
+                    checked_gran = checkGranule(command_dict['input'], gran, completeness, inputinfo['granularity'], strdsinfo['granularity'])
+                    if checked_gran:
+                        updated_granules.append(checked_gran)
+                    else:
+                        start_str = datetime.strftime(gran, "%Y-%m-%dT%H:%M:%S.%s")
+                        grass.warning('Found only too few maps for granule starting with {}.'.format(gran))
+                        grass.warning('Granule is incomplete and therefor not updated.'.format(start_str))
+                else:
+                    updated_granules.append(gran)
+    # get new maps
+    added_maps = grass.read_command('t.rast.list',
+                                    where='start_time >= \'{0}\''.format(strdsinfo['end_time']), flags='u',
+    new_granules = []
+    if not added_maps[0] == '':
+        # Get unique list of start based on granularity of aggregated map
+        added_granules = []
+        for m in added_maps:
+            dt = datetime_math.string_to_datetime(m.split('|')[3])
+            start = datetime_math.adjust_datetime_to_granularity(dt, strdsinfo['granularity'])
+            added_granules.append(start)
+        added_granules = list(set(added_granules))
+        if len(added_granules) > 0:
+                for gran in added_granules:
+                    if checked_gran:
+                        new_granules.append(checked_gran)
+                    else:
+            else:
+                new_granules = [gran2where(start, strdsinfo['granularity']) for start in added_granules]
+    #len(added_granules) + len(updated_granules)
+    # Compute number of required maps (n) within aggregated granule
+    #twhere = updated_granules + new_granules
+    updated = 0
+    twhere = []
+    for gran_list in (updated_granules, added_granules):
+        if len(gran_list) == 0:
+            continue
+        else:
+            for start in gran_list:
+                end = datetime_math.increment_datetime_by_string(start, strdsinfo['granularity'], mult=1)
+                start_str = datetime.strftime(start, "%Y-%m-%dT%H:%M:%S.%s")
+                if check_complete:
+                    n = 0
+                    inc = start
+                    while inc < end:
+                        n = n + 1
+                        inc = datetime_math.increment_datetime_by_string(inc, inputinfo['granularity'], mult=1)
+                    if n != len(inmaps):
+                        grass.warning('Found only {0} of {1} maps for granule starting with {2}.'.format(len(inmaps), n, start_str))
+                        continue
+                twhere.append(where_str)
+                updated = updated + 1
+                grass.message('Updating {0} of {1} granules.'.format(updated, len(start_dates)))
+    update_granule = deepcopy(command_dict)
+    update_granule['output'] = randname
+    update_granule['overwrite'] = True
+    num_suffix = False
+    if 'suffix' in command_dict.keys():
+        if command_dict['suffix'] == 'num':
+            num_suffix = True
+    if not num_suffix:
+        # Check if it is possible to use OR in where conditions!!!
+        #update_granule['where'] = '"{}"'.format(' OR '.join(twhere))
+        twhere = updated_granules + new_granules
+        if len(twhere) > 0:
+            update_granule['where'] = ' OR '.join(twhere)
+            #update_granule['where'] = where_str
+            if len(twhere) < int(command_dict['nprocs']):
+               update_granule['nprocs'] = len(twhere)
+            # run module with modified paramters
+            mod = mod_iface.module.Module(name, run_=False, **update_granule)
+            mod.run()
+            integrateUpdates(strds, randname, tmpf)
+    elif not no_checks and len(updated_granules) > 0:
+        update_granule['nprocs'] = 1
+        for w in updated_granules:
+            update_granule['where'] = w
+            cur_map = grass.read_command('t.rast.list', input=strds, where=w, flags='u',
+            mapid = cur_map[0].split('@')[0].split('_')[-1]
+            if not mapid.isdigit():
+                grass.warning('Could not identify the numerical suffix for granule starting with {}!'.format(w.split("'")[1]))
+            else:
+                update_granule['offset'] = int(mapid) - 1
+            mod.run()
+    else:
+        if len(new_granules) > 0:
+            if len(new_granules) < int(command_dict['nprocs']):
+               update_granule['nprocs'] = len(new_granules)
+            update_granule['where'] = ' OR '.join(new_granules)
+            old_offset = 0 if not 'offset' in command_dict.keys() else int(command_dict['offset'])
+            offset = int(strdsinfo['number_of_maps']) + old_offset
+            update_granule['offset'] = offset
+            mod.run()
+    grass.verbose('Done. Updated {} granules.'.format(len(new_granules) + len(updated_granules)))
+# Run the module
+# ToDo: Add an atexit procedure which closes and removes the current map
+if __name__ == "__main__":
+    options, flags = grass.parser()
+    sys.exit(main())
+def checkGranule(datetime_start, completeness):
+    end = datetime_math.increment_datetime_by_string(datetime_start, strdsinfo['granularity'], mult=1)
+    n = 0
+    while inc < end:
+        n = n + 1
+        return where_str
+agg_maps = grass.read_command('t.rast.list', input=strds, flags='u', columns='id,name,creation_time,start_time,end_time').rstrip('\n').split('\n')
+inmaps = grass.read_command('t.rast.list',
+for i in range(len(inmaps)):
+    if i + 1 < len(inmaps):
+        cur = datetime_math.string_to_datetime(inmaps[i].split('|')[2])
+        nd = datetime_math.string_to_datetime(inmaps[i + 1].split('|')[2])
+        if nd - cur > timedelta(1):
+            print(cur)
+            print(inmaps[i])
+            print(inmaps[i + 1])
+# run module with modified paramters
+mod = mod_iface.module.Module(name, run_=False, **update_granule)
+# Removes temporary strds
+# (Re-) Register
+time_string = added_maps.split('\n')[1].split('|')[3]
+dt = datetime_math.string_to_datetime(time_string)
+start = datetime_math.adjust_datetime_to_granularity(dt, strdsinfo['granularity'])
+end = datetime_math.increment_datetime_by_string(start, strdsinfo['granularity'], mult=1)
+datetime_math.datetime_to_grass_datetime_string(dt)
+tgis.init()
+t.rast.aggregate input=snow_bin_seNorge_1km_days basename=snow_days_seNorge_1km_years suffix=gran granularity=1 years method=sum offset=0 nprocs=10 file_limit=1000 sampling=contains where="end_time >= '2017-01-01T00:00:00.1483225200'  AND start_time <= '2018-01-01T00:00:00.1514761200'" output=suJnMuk0VEXUOF5BzZNnE --o --q
Property changes on: sandbox/sbl/t.rast.aggregate.update/t.rast.aggregate.update.py
___________________________________________________________________
Added: svn:mime-type
## -0,0 +1 ##
+text/x-python
\ No newline at end of property
Added: svn:eol-style
## -0,0 +1 ##
+native
