[GRASS-SVN] r72528 - grass/trunk/gui/wxpython/tplot
svn_grass at osgeo.org
Fri Mar 23 07:53:38 PDT 2018
Author: lucadelu
Date: 2018-03-23 07:53:38 -0700 (Fri, 23 Mar 2018)
New Revision: 72528
grass/trunk/gui/wxpython/tplot/frame.py
grass/trunk/gui/wxpython/tplot/g.gui.tplot.py
g.gui.tplot: added capabilities to export plotted data in CSV file, see #3533
Modified: grass/trunk/gui/wxpython/tplot/frame.py
--- grass/trunk/gui/wxpython/tplot/frame.py 2018-03-23 12:23:59 UTC (rev 72527)
+++ grass/trunk/gui/wxpython/tplot/frame.py 2018-03-23 14:53:38 UTC (rev 72528)
@@ -18,6 +18,7 @@
@author Luca Delucchi
@author start stvds support Matej Krejci
+import os
from itertools import cycle
import numpy as np
@@ -59,6 +60,8 @@
import wx.lib.agw.flatnotebook as FN
except ImportError:
import wx.lib.flatnotebook as FN
+import wx.lib.filebrowsebutton as filebrowse
from gui_core.widgets import GNotebook
ALPHA = 0.5
@@ -100,6 +103,7 @@
self._giface = giface
self.datasetsV = None
self.datasetsR = None
+ self.overwrite = False
# self.vectorDraw=False
# self.rasterDraw=False
self.init()
@@ -297,6 +301,38 @@
self.ntb.AddPage(page=self.controlPanelLabels, text=_('Labels'),
name='Labels')
+ # ------------ITEMS IN NOTEBOOK PAGE (EXPORT)------------------------
+ self.controlPanelExport = wx.Panel(parent=self.ntb, id=wx.ID_ANY)
+ self.csvLabel = wx.StaticText(parent=self.controlPanelExport,
+ id=wx.ID_ANY,
+ label=_('Path for output CSV file '
+ 'with plotted data'))
+ self.csvButton = filebrowse.FileBrowseButton(parent=self.controlPanelExport,
+ id=wx.ID_ANY,
+ size=globalvar.DIALOG_GSELECT_SIZE,
+ labelText='',
+ dialogTitle=_('CVS path'),
+ buttonText=_('Browse'),
+ startDirectory=os.getcwd(),
+ fileMode=wx.FD_SAVE)
+ self.headerLabel = wx.StaticText(parent=self.controlPanelExport,
+ id=wx.ID_ANY,
+ label=_('Do you want the CSV header?'
+ self.headerCheck = wx.CheckBox(parent=self.controlPanelExport,
+ id=wx.ID_ANY)
+ self.controlPanelSizerCheck = wx.BoxSizer(wx.HORIZONTAL)
+ self.controlPanelSizerCheck.Add(self.headerCheck)
+ self.controlPanelSizerCheck.Add(self.headerLabel)
+ self.controlPanelSizerExport = wx.BoxSizer(wx.VERTICAL)
+ self.controlPanelSizerExport.Add(self.csvLabel)
+ self.controlPanelSizerExport.Add(self.csvButton)
+ self.controlPanelSizerExport.Add(self.controlPanelSizerCheck)
+ self.controlPanelExport.SetSizer(self.controlPanelSizerExport)
+ self.controlPanelSizerCheck.Fit(self)
+ self.controlPanelSizerExport.Fit(self)
+ self.ntb.AddPage(page=self.controlPanelExport, text=_('Export'),
+ name='Export')
# ------------Buttons on the bottom(draw,help)------------
self.vButtPanel = wx.Panel(self.mainPanel, id=wx.ID_ANY)
@@ -607,8 +643,24 @@
self.axes2d.set_ylabel(', '.join(self.yticksNames))
if self.drawTitle != '':
self.axes2d.set_title(self.drawTitle)
+ def _writeCSV(self, x, y):
+ """Used to write CSV file of plotted data"""
+ import csv
+ if len(y) > 1:
+ zipped = zip(x, *y)
+ else:
+ zipped = zip(x, y)
+ with open(self.csvpath, "wb") as fi:
+ writer = csv.writer(fi)
+ if self.header:
+ head = ["Time"]
+ head.extend(self.yticksNames)
+ writer.writerow(head)
+ writer.writerows(zipped)
def drawR(self):
+ ycsv = []
for i, name in enumerate(self.datasetsR):
name = name[0]
# just name; with mapset it would be long
@@ -616,6 +668,7 @@
self.yticksPos.append(1) # TODO
xdata = []
ydata = []
+ xcsv = []
for keys, values in self.timeDataR[name].iteritems():
if keys in ['temporalType', 'granularity', 'validTopology',
'unit', 'temporalDataType']:
@@ -622,6 +675,7 @@
continue
xdata.append(self.convert(values['start_datetime']))
ydata.append(values['value'])
+ xcsv.append(values['start_datetime'])
if len(ydata) == ydata.count(None):
GError(parent=self, showTraceback=False,
@@ -634,7 +688,11 @@
self.plots.append(self.axes2d.plot(xdata, ydata, marker='o',
color=color,
label=self.plotNameListR[i])[0])
+ if self.csvpath:
+ ycsv.append(ydata)
+ if self.csvpath:
+ self._writeCSV(xcsv, ycsv)
self._setLabels(self.timeDataR[name]['granularity'])
# legend
handles, labels = self.axes2d.get_legend_handles_labels()
@@ -641,6 +699,7 @@
self.axes2d.legend(loc=0)
def drawVCats(self):
+ ycsv = []
for i, name in enumerate(self.plotNameListV):
labelname = name.replace('+', ' ')
@@ -650,6 +709,7 @@
xdata = []
ydata = []
+ xcsv = []
for keys, values in self.timeDataV[
name_cat[0]][
name_cat[1]].iteritems():
@@ -661,6 +721,7 @@
ydata.append(None)
else:
@@ -680,7 +741,11 @@
marker='o',
color=color,
label=labelname)[0])
+ if self.csvpath:
+ if self.csvpath:
self._setLabels(self.timeDataV[name]['granularity'])
# legend
@@ -689,6 +754,7 @@
self.listWhereConditions = []
def drawV(self):
+ ycsv = []
self.yticksNames.append(self.attribute.GetValue())
@@ -695,6 +761,7 @@
self.yticksPos.append(0) # TODO
xdata = []
ydata = []
+ xcsv = []
for keys, values in self.timeDataV[name].iteritems():
@@ -701,6 +768,7 @@
continue
@@ -713,7 +781,11 @@
color=color, label=name)[0])
+ if self.csvpath:
+ if self.csvpath:
# legend
@@ -723,6 +795,19 @@
def OnRedraw(self, event=None):
"""Required redrawing."""
+ self.csvpath = self.csvButton.GetValue()
+ self.header = self.headerCheck.IsChecked()
+ if (os.path.exists(self.csvpath) and not self.overwrite):
+ dlg = wx.MessageDialog(self, _("{pa} already exists, do you want "
+ "to overwrite?".format(pa=self.csvpath)),
+ _("File exists"),
+ wx.OK | wx.CANCEL | wx.ICON_QUESTION)
+ if dlg.ShowModal() != wx.ID_OK:
+ dlg.Destroy()
+ GError(parent=self, showTraceback=False,
+ message=_("Please change name of output CSV file or "))
+ return
+ dlg.Destroy()
self.init()
datasetsR = self.datasetSelectR.GetValue().strip()
datasetsV = self.datasetSelectV.GetValue().strip()
@@ -879,7 +964,7 @@
RunCommand(prog='g.manual', quiet=True, entry='g.gui.tplot')
def SetDatasets(self, rasters, vectors, coors, cats, attr, title, xlabel,
- ylabel):
+ ylabel, csvfile, head, overwrite):
"""Set the data
:param list rasters: a list of temporal raster dataset's name
:param list vectors: a list of temporal vector dataset's name
@@ -927,6 +1012,10 @@
self.x.SetValue(xlabel)
if ylabel:
self.y.SetValue(ylabel)
+ if csvfile:
+ self.csvpath = csvfile
+ self.header = head
+ self.overwrite = overwrite
self._redraw()
def OnVectorSelected(self, event):
Modified: grass/trunk/gui/wxpython/tplot/g.gui.tplot.py
--- grass/trunk/gui/wxpython/tplot/g.gui.tplot.py 2018-03-23 12:23:59 UTC (rev 72527)
+++ grass/trunk/gui/wxpython/tplot/g.gui.tplot.py 2018-03-23 14:53:38 UTC (rev 72528)
@@ -27,6 +27,11 @@
#% keywords: temporal
#%end
+#%flag
+#% key: h
+#% description: Set the header of CSV file, to be used with csv option
+#%end
#%option G_OPT_STVDS_INPUTS
#% key: stvds
#% required: no
@@ -58,10 +63,17 @@
#%option G_OPT_F_OUTPUT
#% required: no
-#% label: Name for output file
-#% description: Add extension to specify format (.png, .pdf, .svg)
+#% label: Name for output graphical file
+#% description: Full path for output file containing the plot, ddd extension to specify format (.png, .pdf, .svg)
#%end
+#%option G_OPT_F_OUTPUT
+#% key: csv
+#% required: no
+#% label: Name for output CSV file
+#% description: Full path for the CSV file containing the plotted data
+#%end
#%option
#% key: title
#% label: Title for plot
@@ -141,10 +153,13 @@
ylabel = None
if options['ylabel']:
ylabel = options['ylabel']
+ csvfile = None
+ if options['csv']:
+ csvfile = options['csv']
app = wx.App()
frame = TplotFrame(parent=None, giface=StandaloneGrassInterface())
frame.SetDatasets(rasters, vectors, coords, cats, attr, title, xlabel,
- ylabel)
+ ylabel, csvfile, flags['h'], gscript .overwrite)
if output:
frame.OnRedraw()
if options['size']:
