[GRASS-SVN] r72539 - grass/trunk/rpm
svn_grass at osgeo.org
Fri Mar 23 15:55:29 PDT 2018
Author: neteler
Date: 2018-03-23 15:55:29 -0700 (Fri, 23 Mar 2018)
New Revision: 72539
grass/trunk/rpm/grass.spec
SPEC file: minor cleanup
Modified: grass/trunk/rpm/grass.spec
--- grass/trunk/rpm/grass.spec 2018-03-23 19:44:43 UTC (rev 72538)
+++ grass/trunk/rpm/grass.spec 2018-03-23 22:55:29 UTC (rev 72539)
@@ -13,7 +13,6 @@
URL: https://grass.osgeo.org
Source0: https://grass.osgeo.org/%{name}%{shortver}/source/%{name}-%{version}.tar.gz
Source2: %{name}-config.h
-# Patch0: grass72_ctypes_gcc7.diff
BuildRequires: bison
BuildRequires: blas-devel
@@ -126,7 +125,6 @@
%prep
%setup -q
-# %patch0 -p1
# Correct mysql_config query
sed -i -e 's/--libmysqld-libs/--libs/g' configure
@@ -204,25 +202,25 @@
# fix paths:
# Change GISBASE in startup script
-sed -i -e 's|%{buildroot}%{_libdir}/%{name}-%{version}|%{_libdir}/%{name}-%{version}|g' \
+sed -i -e 's|%{buildroot}%{_libdir}/%{name}-%{version}|%{_libdir}/%{name}%{shortver}|g' \
%{buildroot}%{_bindir}/%{name}%{shortver}
# fix GRASS_HOME and RUN_GISBASE in Platform.make
%{buildroot}%{_libdir}/%{name}-%{version}/include/Make/Platform.make
# fix ARCH_DISTDIR in Grass.make
%{buildroot}%{_libdir}/%{name}-%{version}/include/Make/Grass.make
# fix ARCH_BINDIR in Grass.make
sed -i -e 's|%{buildroot}%{_bindir}|%{_bindir}|g' \
# fix GISDBASE in demolocation
%{buildroot}%{_libdir}/%{name}-%{version}/demolocation/.grassrc%{shortver}
# Correct font path
-sed -i -e 's|%{buildroot}%{_libdir}/%{name}-%{version}|%{_libdir}/%{name}-%{version}|' \
+sed -i -e 's|%{buildroot}%{_libdir}/%{name}-%{version}|%{_libdir}/%{name}%{shortver}|' \
%{buildroot}%{_libdir}/%{name}-%{version}/etc/fontcap
# fix paths in grass.pc
-sed -i -e 's|%{_prefix}/%{name}-%{version}|%{_libdir}/%{name-%{version}}|g' \
+sed -i -e 's|%{_prefix}/%{name}-%{version}|%{_libdir}/%{name}%{shortver}|g' \
%{name}.pc
mkdir -p %{buildroot}%{_libdir}/pkgconfig
@@ -230,7 +228,7 @@
# Create multilib header
mv %{buildroot}%{_libdir}/%{name}-%{version}/include/%{name}/config.h \
- %{buildroot}%{_libdir}/%{name}-%{version}/include/%{name}/config-%{cpuarch}.h
+ %{buildroot}%{_libdir}/%{name}-%{version}/include/%{name}/config-%{cpuarch}.h
install -p -m 644 %{SOURCE2} %{buildroot}%{_libdir}/%{name}-%{version}/include/%{name}/config.h
# Make man pages available on the system, convert to utf8 and avoid name conflict
@@ -243,20 +241,19 @@
# symlink docs from GISBASE to standard system location
mkdir -p %{buildroot}%{_docdir}
# append shortver to destination ? man pages are unversioned
-ln -s %{_libdir}/%{name}-%{version}/docs %{buildroot}%{_docdir}/%{name}%{shortver}
+ln -s %{_libdir}/%{name}%{shortver}/docs %{buildroot}%{_docdir}/%{name}%{shortver}
# Make desktop, appdata and icon files available on the system
mv %{buildroot}%{_libdir}/%{name}-%{version}/share/* %{buildroot}%{_datadir}
desktop-file-validate %{buildroot}/%{_datadir}/applications/*.desktop
-# EPEL7 fails on url tag, so we ignore failure:
-appstream-util validate-relax --nonet %{buildroot}/%{_datadir}/appdata/%{name}*.appdata.xml || echo "Ignoring appstream-util failure"
-# as per https://fedoraproject.org/wiki/Packaging:AppData
-mkdir -p %{buildroot}%{_datadir}/metainfo/
-cp %{buildroot}/%{_datadir}/appdata/%{name}*.appdata.xml %{buildroot}%{_datadir}/metainfo/
+appstream-util validate-relax --nonet %{buildroot}/%{_datadir}/metainfo/org.osgeo.%{name}.appdata.xml
# Cleanup: nothing to do
#rm -rf %%{buildroot}%%{_prefix}/%%{name}-%%{version}
+# Finally move entire tree to shortver subdir
+mv %{buildroot}%{_libdir}/%{name}-%{version} %{buildroot}%{_libdir}/%{name}%{shortver}
# rpm macro for version checking (not from buildroot!)
mkdir -p ${RPM_BUILD_ROOT}%{macrosdir}
cat > ${RPM_BUILD_ROOT}%{macrosdir}/macros.%{name} <<EOF
@@ -286,41 +283,42 @@
%postun libs -p /sbin/ldconfig
%files
-%exclude %{_libdir}/%{name}-%{version}/driver/db/*
-%exclude %{_libdir}/%{name}-%{version}/lib
-%exclude %{_libdir}/%{name}-%{version}/include
-%exclude %{_libdir}/%{name}-%{version}/gui
-%{_libdir}/%{name}-%{version}
+%exclude %{_libdir}/%{name}%{shortver}/driver/db/*
+%exclude %{_libdir}/%{name}%{shortver}/lib
+%exclude %{_libdir}/%{name}%{shortver}/include
+%exclude %{_libdir}/%{name}%{shortver}/gui
+%{_libdir}/%{name}%{shortver}
%{_bindir}/*
-%{_datadir}/appdata/*
+%{_datadir}/metainfo/*
%{_datadir}/icons/hicolor/*/apps/*
-%{_datadir}/metainfo/
%{_mandir}/man1/*
%files libs
%license AUTHORS COPYING GPL.TXT CHANGES
-%{_libdir}/%{name}-%{version}/lib/*.%{version}.so
-%{_libdir}/%{name}-%{version}/lib/*.a
-%dir %{_libdir}/%{name}-%{version}/driver
-%dir %{_libdir}/%{name}-%{version}/driver/db
-%{_libdir}/%{name}-%{version}/driver/db/*
+%{_libdir}/%{name}%{shortver}/lib/*.%{version}.so
+%{_libdir}/%{name}%{shortver}/lib/*.a
+%dir %{_libdir}/%{name}%{shortver}/driver
+%dir %{_libdir}/%{name}%{shortver}/driver/db
+%{_libdir}/%{name}%{shortver}/driver/db/*
%files gui
-%{_libdir}/%{name}-%{version}/gui
+%{_libdir}/%{name}%{shortver}/gui
%files devel
%doc TODO doc/* SUBMITTING
%{_libdir}/pkgconfig/*
-%dir %{_libdir}/%{name}-%{version}/lib
-%{_libdir}/%{name}-%{version}/lib/*[!%{version}].so
-%{_libdir}/%{name}-%{version}/include
+%dir %{_libdir}/%{name}%{shortver}/lib
+%{_libdir}/%{name}%{shortver}/lib/*[!%{version}].so
+%{_libdir}/%{name}%{shortver}/include
%changelog
-* Sun Jan 28 2018 Markus Neteler <neteler at mundialis.de> - 7.4.0-2
-- SPEC cleanup as per review in https://bugzilla.redhat.com/show_bug.cgi?id=1539116
+* Sun Jan 28 2018 Markus Neteler <neteler at mundialis.de> - 7.4.1-2
+- SPEC cleanup with fix of dependencies between packages (review #1539116)
+- appdata.xml file into '/usr/share/metainfo'
+- use icon cache scriplets only on EPEL
* Mon Jan 15 2018 Markus Metz <metz at mundialis.de> - 7.4.0-1
- New upstream version 7.4.0
