[GRASS-SVN] r72547 - in grass/trunk: gui/wxpython/dbmgr gui/wxpython/gui_core lib/gis
svn_grass at osgeo.org
Sat Mar 24 04:09:29 PDT 2018
Author: martinl
Date: 2018-03-24 04:09:29 -0700 (Sat, 24 Mar 2018)
New Revision: 72547
grass/trunk/gui/wxpython/dbmgr/sqlbuilder.py
grass/trunk/gui/wxpython/gui_core/forms.py
grass/trunk/gui/wxpython/gui_core/gselect.py
grass/trunk/lib/gis/parser_standard_options.c
wxGUI: implement widget for SQL WHERE params
Modified: grass/trunk/gui/wxpython/dbmgr/sqlbuilder.py
--- grass/trunk/gui/wxpython/dbmgr/sqlbuilder.py 2018-03-24 09:04:40 UTC (rev 72546)
+++ grass/trunk/gui/wxpython/dbmgr/sqlbuilder.py 2018-03-24 11:09:29 UTC (rev 72547)
@@ -46,7 +46,7 @@
Base class for classes, which builds SQL statements.
- def __init__(self, parent, title, vectmap, modeChoices, id=wx.ID_ANY,
+ def __init__(self, parent, title, vectmap, modeChoices=[], id=wx.ID_ANY,
layer=1):
wx.Frame.__init__(self, parent, id, title)
@@ -68,6 +68,7 @@
self.layer = layer
self.dbInfo = VectorDBInfo(self.vectmap)
self.tablename = self.dbInfo.GetTable(self.layer)
self.driver, self.database = self.dbInfo.GetDbSettings(self.layer)
self.colvalues = [] # array with unique values in selected column
@@ -130,7 +131,7 @@
self.btn_clear.SetToolTipString(_("Set SQL statement to default"))
self.btn_apply = wx.Button(parent=self.panel, id=wx.ID_APPLY)
self.btn_apply.SetToolTipString(
- _("Apply SQL statement in Attribute Table Manager"))
+ _("Apply SQL statement"))
self.btn_close = wx.Button(parent=self.panel, id=wx.ID_CLOSE)
self.btn_close.SetToolTipString(_("Close the dialog"))
@@ -230,18 +231,19 @@
columnsizer.Add(self.list_columns, proportion=1,
flag=wx.EXPAND)
- modesizer = wx.BoxSizer(wx.VERTICAL)
+ if modeChoices:
+ modesizer = wx.BoxSizer(wx.VERTICAL)
+ self.mode = wx.RadioBox(parent=self.panel, id=wx.ID_ANY,
+ label=" %s " % _("Interactive insertion"),
+ choices=modeChoices,
+ style=wx.RA_SPECIFY_COLS,
+ majorDimension=1)
+ self.mode.SetSelection(1) # default 'values'
+ modesizer.Add(self.mode, proportion=1,
+ flag=wx.ALIGN_CENTER_HORIZONTAL | wx.EXPAND, border=5)
- self.mode = wx.RadioBox(parent=self.panel, id=wx.ID_ANY,
- label=" %s " % _("Interactive insertion"),
- choices=modeChoices,
- style=wx.RA_SPECIFY_COLS,
- majorDimension=1)
- self.mode.SetSelection(1) # default 'values'
- modesizer.Add(self.mode, proportion=1,
- flag=wx.ALIGN_CENTER_HORIZONTAL | wx.EXPAND, border=5)
# self.list_columns.SetMinSize((-1,130))
# self.list_values.SetMinSize((-1,100))
@@ -302,12 +304,13 @@
if showDbInfo:
self.pagesizer.Add(databaseboxsizer,
flag=wx.ALL | wx.EXPAND, border=5)
+ if modeChoices:
+ self.pagesizer.Add(
+ modesizer,
+ proportion=0,
+ flag=wx.LEFT | wx.RIGHT | wx.BOTTOM | wx.EXPAND,
+ border=5)
self.pagesizer.Add(
- modesizer,
- proportion=0,
- flag=wx.LEFT | wx.RIGHT | wx.BOTTOM | wx.EXPAND,
- border=5)
- self.pagesizer.Add(
self.hsizer,
proportion=1,
@@ -329,7 +332,8 @@
# bindings
- self.mode.Bind(wx.EVT_RADIOBOX, self.OnMode)
+ if modeChoices:
+ self.mode.Bind(wx.EVT_RADIOBOX, self.OnMode)
# self.text_sql.Bind(wx.EVT_ACTIVATE, self.OnTextSqlActivate)TODO
self.btn_unique.Bind(wx.EVT_BUTTON, self.OnUniqueValues)
@@ -840,6 +844,52 @@
'TRIM': ['TRIM (,)']
+class SQLBuilderWhere(SQLBuilder):
+ """Class for building SELECT SQL WHERE statement"""
+ def __init__(self, parent, vectmap, id=wx.ID_ANY,
+ layer=1):
+ title = _("GRASS SQL Builder (%(type)s) - <%(map)s>") % \
+ {'type': "WHERE", 'map': vectmap}
+ super(SQLBuilderWhere, self).__init__(
+ parent, title, vectmap, id=wx.ID_ANY,
+ layer=layer)
+ def OnClear(self, event):
+ self.text_sql.SetValue('')
+ def OnApply(self, event):
+ self.parent.SetValue(self.text_sql.GetValue())
+ if self.close_onapply.IsChecked():
+ self.Destroy()
+ event.Skip()
+ def _add(self, element, value):
+ """Add element to the query
+ :param element: element to add (column, value)
+ sqlstr = self.text_sql.GetValue()
+ inspoint = self.text_sql.GetInsertionPoint()
+ newsqlstr = ''
+ if inspoint > 0 and sqlstr[inspoint-1] != ' ':
+ newsqlstr += ' '
+ newsqlstr += value
+ if inspoint < len(sqlstr):
+ newsqlstr += ' ' if sqlstr[inspoint] != ' ' else ''
+ if newsqlstr:
+ self.text_sql.SetValue(sqlstr[:inspoint] + newsqlstr + sqlstr[inspoint:])
+ self.text_sql.SetInsertionPoint(inspoint + len(newsqlstr))
+ wx.CallAfter(self.text_sql.SetFocus)
if __name__ == "__main__":
if len(sys.argv) not in [3, 4]:
print(__doc__, file=sys.stderr)
Modified: grass/trunk/gui/wxpython/gui_core/forms.py
--- grass/trunk/gui/wxpython/gui_core/forms.py 2018-03-24 09:04:40 UTC (rev 72546)
+++ grass/trunk/gui/wxpython/gui_core/forms.py 2018-03-24 11:09:29 UTC (rev 72547)
@@ -240,7 +240,7 @@
map = layer = None
driver = db = None
- if name in ('LayerSelect', 'ColumnSelect'):
+ if name in ('LayerSelect', 'ColumnSelect', 'SqlWhereSelect'):
if p.get('element', '') == 'vector': # -> vector
# get map name
map = p.get('value', '')
@@ -325,7 +325,7 @@
if not cparams[map]['dbInfo']:
cparams[map]['dbInfo'] = gselect.VectorDBInfo(map)
- self.data[win.GetParent().InsertColumns] = {
+ self.data[win.GetParent().SetData] = {
'vector': map, 'layer': layer,
'dbInfo': cparams[map]['dbInfo']}
else: # table
@@ -397,6 +397,18 @@
'value', ''), 'mapset': pMapset.get(
'value', '')}
+ elif name == 'SqlWhereSelect':
+ if map:
+ 'vector': map, 'layer': layer }
+ else: # table
+ if driver and db:
+ self.data[win.GetParent().InsertTableColumns] = {
+ 'table': pTable.get('value'),
+ 'driver': driver, 'database': db}
+ elif pTable:
+ 'table': pTable.get('value')}
def UpdateDialog(parent, event, eventId, task):
return UpdateThread(parent, event, eventId, task)
@@ -1394,7 +1406,8 @@
'barscale',
'northarrow',
'datasource',
- 'datasource_layer'):
+ 'datasource_layer',
+ 'sql_query'):
multiple = p.get('multiple', False)
if p.get('age', '') == 'new':
mapsets = [grass.gisenv()['MAPSET'], ]
@@ -2060,6 +2073,17 @@
self.OnUpdateValues() # TODO: replace by signal
self.win1.OnCheckItem = OnCheckItem
+ elif prompt == 'sql_query':
+ win = gselect.SqlWhereSelect(
+ parent=which_panel, param=p)
+ p['wxId'] = [win.GetTextWin().GetId()]
+ win.GetTextWin().Bind(wx.EVT_TEXT, self.OnSetValue)
+ which_sizer.Add(
+ win,
+ proportion=0,
+ flag=wx.EXPAND | wx.BOTTOM | wx.LEFT | wx.RIGHT,
+ border=5)
if self.parent.GetName() == 'MainFrame' and (
self._giface and hasattr(self._giface, "_model")):
@@ -2110,6 +2134,7 @@
pDbase = None
pLocation = None
pMapset = None
+ pSqlWhere = []
for p in self.task.params:
if self.task.blackList['enabled'] and self.task.get_name() in self.task.blackList['items'] and \
p.get('name', '') in self.task.blackList['items'][self.task.get_name()]['params']:
@@ -2157,6 +2182,8 @@
pLocation = p
elif prompt == 'mapset':
pMapset = p
+ pSqlWhere.append(p)
# collect ids
pColumnIds = []
@@ -2168,7 +2195,10 @@
pSigFileIds = []
for p in pSigFile:
pSigFileIds += p['wxId']
+ pSqlWhereIds = []
+ for p in pSqlWhere:
+ pSqlWhereIds += p['wxId']
# set wxId-bindings
if pMap:
pMap['wxId-bind'] = []
@@ -2175,10 +2205,13 @@
if pLayer:
pMap['wxId-bind'] += pLayerIds
pMap['wxId-bind'] += copy.copy(pColumnIds)
+ pMap['wxId-bind'] += copy.copy(pSqlWhereIds)
if pLayer:
for p in pLayer:
p['wxId-bind'] = copy.copy(pColumnIds)
+ p['wxId-bind'] += copy.copy(pSqlWhereIds)
if pDriver and pTable:
pDriver['wxId-bind'] = pTable['wxId']
Modified: grass/trunk/gui/wxpython/gui_core/gselect.py
--- grass/trunk/gui/wxpython/gui_core/gselect.py 2018-03-24 09:04:40 UTC (rev 72546)
+++ grass/trunk/gui/wxpython/gui_core/gselect.py 2018-03-24 11:09:29 UTC (rev 72547)
@@ -27,8 +27,9 @@
- :class:`VectorCategorySelect`
- :class:`SignatureSelect`
- :class:`SeparatorSelect`
+ - :class:`SqlWhereSelect`
-(C) 2007-2014 by the GRASS Development Team
+(C) 2007-2018 by the GRASS Development Team
This program is free software under the GNU General Public License
(>=v2). Read the file COPYING that comes with GRASS for details.
@@ -74,7 +75,7 @@
from gui_core.widgets import ManageSettingsWidget, CoordinatesValidator
-from core.gcmd import RunCommand, GError, GMessage, GWarning
+from core.gcmd import RunCommand, GError, GMessage, GWarning, GException
from core.utils import GetListOfLocations, GetListOfMapsets, \
GetFormats, rasterFormatExtension, vectorFormatExtension
from core.utils import GetSettingsPath, GetValidLayerName, ListSortLower
@@ -885,6 +886,8 @@
:param layer: vector layer number
+ if layer not in self.layers:
+ raise GException(_("No table linked to layer <{}>.".format(layer)))
return self.layers[layer]['table']
def GetDbSettings(self, layer):
@@ -2711,3 +2714,57 @@
**kwargs)
self.SetName("SeparatorSelect")
self.SetItems(['pipe', 'comma', 'space', 'tab', 'newline'])
+class SqlWhereSelect(wx.Panel):
+ def __init__(self, parent, **kwargs):
+ """Widget to define SQL WHERE condition.
+ :param parent: parent window
+ super(SqlWhereSelect, self).__init__(parent=parent, id=wx.ID_ANY)
+ self.parent = parent
+ self.sqlField = wx.TextCtrl(parent=self, id=wx.ID_ANY,
+ size=globalvar.DIALOG_TEXTCTRL_SIZE)
+ self.GetChildren()[0].SetName("SqlWhereSelect")
+ icon = wx.Bitmap(
+ os.path.join(
+ globalvar.ICONDIR,
+ "grass",
+ "table.png"))
+ self.buttonInsSql = buttons.ThemedGenBitmapButton(
+ parent=self, id=wx.ID_ANY, bitmap=icon, size=globalvar.DIALOG_COLOR_SIZE)
+ self.buttonInsSql.Bind(wx.EVT_BUTTON, self._onClick)
+ self._doLayout()
+ def _doLayout(self):
+ self.dialogSizer = wx.BoxSizer(wx.HORIZONTAL)
+ self.dialogSizer.Add(self.sqlField,
+ proportion=1,
+ flag=wx.EXPAND)
+ self.dialogSizer.Add(self.buttonInsSql)
+ self.SetSizer(self.dialogSizer)
+ def GetTextWin(self):
+ return self.sqlField
+ def _onClick(self, event):
+ from dbmgr.sqlbuilder import SQLBuilderWhere
+ try:
+ win = SQLBuilderWhere(parent=self,
+ vectmap=self.vector_map,
+ layer=self.vector_layer)
+ win.Show()
+ except GException as e:
+ GMessage(parent=self.parent, message='{}'.format(e))
+ def SetData(self, vector, layer):
+ self.vector_map = vector
+ self.vector_layer = int(layer) # TODO: support layer names
+ def SetValue(self, value):
+ self.sqlField.SetValue(value)
Modified: grass/trunk/lib/gis/parser_standard_options.c
--- grass/trunk/lib/gis/parser_standard_options.c 2018-03-24 09:04:40 UTC (rev 72546)
+++ grass/trunk/lib/gis/parser_standard_options.c 2018-03-24 11:09:29 UTC (rev 72547)
@@ -151,6 +151,7 @@
case G_OPT_DB_WHERE:
Opt->key = "where";
Opt->type = TYPE_STRING;
+ Opt->gisprompt = "old,sql_query,sql_query";
Opt->key_desc = "sql_query";
Opt->required = NO;
Opt->label = _("WHERE conditions of SQL statement without 'where' keyword");
