[GRASS-SVN] r72557 - in grass/branches/releasebranch_7_4/imagery/i.atcorr: . sensors_csv
svn_grass at osgeo.org
Sat Mar 24 09:50:40 PDT 2018
Author: neteler
Date: 2018-03-24 09:50:40 -0700 (Sat, 24 Mar 2018)
New Revision: 72557
Added:
grass/branches/releasebranch_7_4/imagery/i.atcorr/sensors_csv/README
grass/branches/releasebranch_7_4/imagery/i.atcorr/sensors_csv/etmplus.csv
grass/branches/releasebranch_7_4/imagery/i.atcorr/sensors_csv/sentinel_2B_msi.csv
grass/branches/releasebranch_7_4/imagery/i.atcorr/6s.cpp
grass/branches/releasebranch_7_4/imagery/i.atcorr/abstra.cpp
grass/branches/releasebranch_7_4/imagery/i.atcorr/aerosolconcentration.cpp
grass/branches/releasebranch_7_4/imagery/i.atcorr/aerosolmodel.cpp
grass/branches/releasebranch_7_4/imagery/i.atcorr/altitude.cpp
grass/branches/releasebranch_7_4/imagery/i.atcorr/computations.cpp
grass/branches/releasebranch_7_4/imagery/i.atcorr/create_iwave.py
grass/branches/releasebranch_7_4/imagery/i.atcorr/geomcond.cpp
grass/branches/releasebranch_7_4/imagery/i.atcorr/geomcond.h
grass/branches/releasebranch_7_4/imagery/i.atcorr/i.atcorr.html
grass/branches/releasebranch_7_4/imagery/i.atcorr/iwave.cpp
grass/branches/releasebranch_7_4/imagery/i.atcorr/iwave.h
grass/branches/releasebranch_7_4/imagery/i.atcorr/main.cpp
grass/branches/releasebranch_7_4/imagery/i.atcorr/sensors_csv/sentinel_2A_msi.csv
grass/branches/releasebranch_7_4/imagery/i.atcorr/sensors_csv/worldview2.csv
grass/branches/releasebranch_7_4/imagery/i.atcorr/transform.cpp
i.atcorr: sync to trunk (updated spectral curves for various satellites; fix band order for Worldview2; addition of Sentinel-2B, improvement of numerical stability (trunk, r72445, r72399, r72390, r72153, r72148, r72147, r72146, r72145, r72144, r72143, r72142, r72141, r72140, r72139, r72133, r72132, r72131, r72130, r72129, r72128, r72127, r72126, r72124, r72120, r72119, r72118, r72100, r72072, r72054)
Modified: grass/branches/releasebranch_7_4/imagery/i.atcorr/6s.cpp
--- grass/branches/releasebranch_7_4/imagery/i.atcorr/6s.cpp 2018-03-24 16:42:50 UTC (rev 72556)
+++ grass/branches/releasebranch_7_4/imagery/i.atcorr/6s.cpp 2018-03-24 16:50:40 UTC (rev 72557)
@@ -224,12 +224,12 @@
Output::WriteLn(15," gaseous content at target level: ");
- ostringstream s;
- s.setf(ios::fixed, ios::floatfield);
- s << setprecision(3);
- s << " uh2o=" << setw(9) << atms.uw << " g/cm2 "
- << " uo3=" << setw(9) << atms.uo3 << " cm-atm" << ends;
- Output::WriteLn(15,s.str());
+ ostringstream s3;
+ s3.setf(ios::fixed, ios::floatfield);
+ s3 << setprecision(3);
+ s3 << " uh2o=" << setw(9) << atms.uw << " g/cm2 "
+ << " uo3=" << setw(9) << atms.uo3 << " cm-atm" << ends;
+ Output::WriteLn(15,s3.str());
alt.print();
@@ -578,8 +578,10 @@
sroaer = sroaer / seb;
srotot = srotot / seb;
alumet = alumet / sb;
float pizera = 0.0f;
if(aero.iaer != 0) pizera = ssdaer / sodaer;
sodray = sodray / seb;
sodaer = sodaer / seb;
sodtot = sodtot / seb;
Modified: grass/branches/releasebranch_7_4/imagery/i.atcorr/abstra.cpp
--- grass/branches/releasebranch_7_4/imagery/i.atcorr/abstra.cpp 2018-03-24 16:42:50 UTC (rev 72556)
+++ grass/branches/releasebranch_7_4/imagery/i.atcorr/abstra.cpp 2018-03-24 16:50:40 UTC (rev 72557)
@@ -10418,7 +10418,6 @@
else
- int k;
for(k = 0; k < 33; k++)
roair = air * 273.16f * alt.plane_sim.ppl[k] / (1013.25f * alt.plane_sim.tpl[k]);
Modified: grass/branches/releasebranch_7_4/imagery/i.atcorr/aerosolconcentration.cpp
--- grass/branches/releasebranch_7_4/imagery/i.atcorr/aerosolconcentration.cpp 2018-03-24 16:42:50 UTC (rev 72556)
+++ grass/branches/releasebranch_7_4/imagery/i.atcorr/aerosolconcentration.cpp 2018-03-24 16:50:40 UTC (rev 72557)
@@ -37,7 +37,7 @@
else if(v > 0) oda550(v, atms);
-void AerosolConcentration::oda550(const float v, const AtmosModel& atms)
+void AerosolConcentration::oda550(const float vis, const AtmosModel& atms)
/* aerosol optical depth at wl=550nm */
/* vertical repartition of aerosol density for v=23km */
@@ -66,7 +66,7 @@
taer55 = 0;
- if(fabs(v) <= 0) return;
+ if(fabs(vis) <= 0) return;
if(iaer == 0) return;
for(int k = 0; k < 32; k++)
@@ -78,8 +78,8 @@
float bz = (5.f * an5[k] / 18.f) - (23.f * an23[k] / 18.f);
float bz1 = (5.f * an5[k+1] / 18.f) - (23.f * an23[k+1] / 18.f);
- float bnz = az / v - bz;
- float bnz1 = az1 / v - bz1;
+ float bnz = az / vis - bz;
+ float bnz1 = az1 / vis - bz1;
float ev = (float)(dz * exp((log(bnz) + log(bnz1)) / 2));
taer55 += ev * sigma * 1.0e-03f;
Modified: grass/branches/releasebranch_7_4/imagery/i.atcorr/aerosolmodel.cpp
--- grass/branches/releasebranch_7_4/imagery/i.atcorr/aerosolmodel.cpp 2018-03-24 16:42:50 UTC (rev 72556)
+++ grass/branches/releasebranch_7_4/imagery/i.atcorr/aerosolmodel.cpp 2018-03-24 16:50:40 UTC (rev 72557)
@@ -61,7 +61,7 @@
double np[4];
double ext[10][4];
- double sca[10][4];
+ double sca2[10][4];
double p1[10][4][83];
const double rmul = 0.99526231496887960135245539673954; /*rlogpas = 0.030; (10**rlogpas-1.D+00)*/
@@ -78,7 +78,7 @@
ex[i][j] = 0;
sc[i][j] = 0;
ext[j][i] = 0;
- sca[j][i] = 0;
+ sca2[j][i] = 0;
for(int k = 0; k < 83; k++) p1[j][i][k] = 0;
@@ -159,7 +159,7 @@
double p11[83];
exscphase(alpha, mie_in.rn[j][i], mie_in.ri[j][i], Qext, Qsca, p11);
ext[j][i] += xndpr2 * Qext;
- sca[j][i] += xndpr2 * Qsca;
+ sca2[j][i] += xndpr2 * Qsca;
/* phase function for each type of particle */
for(int k = 0; k < 83; k++) p1[j][i][k] += p11[k]*xndpr2;
@@ -176,12 +176,12 @@
at 0.550 micron (the extinction coefficient is normalized at 0.550 micron) */
int j;
for(j = 0; j < 10; j++)
- for(int i = 0; i < mie_in.icp; i++)
+ for(i = 0; i < mie_in.icp; i++)
ext[j][i] /= np[i] * 1000;
- sca[j][i] /= np[i] * 1000;
+ sca2[j][i] /= np[i] * 1000;
ex[0][j] += (float)(mie_in.cij[i] * ext[j][i]);
- sc[0][j] += (float)(mie_in.cij[i] * sca[j][i]);
+ sc[0][j] += (float)(mie_in.cij[i] * sca2[j][i]);
/* computation of the phase function and the asymetry coefficient
@@ -195,7 +195,7 @@
sixs_aerbas.usr_ph[j][k] = 0;
sixs_aerbas.usr_ph[j][k] += (float)(mie_in.cij[i] * p1[j][i][k] / np[i] / 1000);
sixs_aerbas.usr_ph[j][k] += (float)sc[0][j];
@@ -383,7 +383,7 @@
PIn[1] = 0;
TAUn[1] = sixs_sos.cgaus[j];
- for(int k = 1; k <= mu; k++)
+ for(k = 1; k <= mu; k++)
double co_n = (2.0 * k + 1) / k / (k + 1);
RS1 += co_n * (RAn[k] * PIn[k] + RBn[k] * TAUn[k]);
@@ -694,7 +694,7 @@
case 11: mie (ex, sc, asy); break;
- for (int i = 0; i < 10; i++)
+ for (i = 0; i < 10; i++)
dd[0][i] = (*sixs_aerbas.ph)[i][j1] + coef * ((*sixs_aerbas.ph)[i][j1] - (*sixs_aerbas.ph)[i][j1+1]);
for(int k = 0; k < 83; k++) pha[0][i][k] = (*sixs_aerbas.ph)[i][k];
@@ -850,7 +850,7 @@
case 4:
- for(int i = 0; i < 4; i++) cin >> c[i];
+ for(i = 0; i < 4; i++) cin >> c[i];
cin.ignore(numeric_limits<int>::max(),'\n');
break;
@@ -865,7 +865,7 @@
G_fatal_error(_("mie_in.icp: %ld > 4, will cause internal buffer overflow"), mie_in.icp);
cin >> mie_in.x1[i];
cin >> mie_in.x2[i];
@@ -929,7 +929,6 @@
G_fatal_error(_("mie_in.irsunph: %ld > 50, will cause internal buffer overflow"), mie_in.irsunph);
- int i;
for(i = 0; i < mie_in.irsunph; i++)
cin >> mie_in.rsunph[i];
Modified: grass/branches/releasebranch_7_4/imagery/i.atcorr/altitude.cpp
--- grass/branches/releasebranch_7_4/imagery/i.atcorr/altitude.cpp 2018-03-24 16:42:50 UTC (rev 72556)
+++ grass/branches/releasebranch_7_4/imagery/i.atcorr/altitude.cpp 2018-03-24 16:50:40 UTC (rev 72557)
@@ -75,18 +75,22 @@
float rmwh[34];
float rmo3[34];
int k;
- for (k = 0; k < 33; ++k)
+ float roair, ds;
+ k = 0;
+ roair = air * 273.16f * atms.p[k] / (atms.t[k] * 1013.25f);
+ rmwh[k] = atms.wh[k] / (roair * 1e3f);
+ rmo3[k] = atms.wo[k] / (roair * 1e3f);
+ for (k = 1; k < 33; ++k)
- float roair = air * 273.16f * atms.p[k] / (atms.t[k] * 1013.25f);
- for (k = 1; k < 33; ++k)
- float ds = (atms.p[k - 1] - atms.p[k]) / atms.p[0];
- uw += (rmwh[k] + rmwh[k - 1]) * ds / 2.f;
- uo3 += (rmo3[k] + rmo3[k - 1]) * ds / 2.f;
+ ds = (atms.p[k - 1] - atms.p[k]) / (atms.p[0] * 2);
+ uw += (rmwh[k] + rmwh[k - 1]) * ds;
+ uo3 += (rmo3[k] + rmo3[k - 1]) * ds;
uw = uw * atms.p[0] * 100.f / g;
uo3 = uo3 * atms.p[0] * 100.f / g;
Modified: grass/branches/releasebranch_7_4/imagery/i.atcorr/computations.cpp
--- grass/branches/releasebranch_7_4/imagery/i.atcorr/computations.cpp 2018-03-24 16:42:50 UTC (rev 72556)
+++ grass/branches/releasebranch_7_4/imagery/i.atcorr/computations.cpp 2018-03-24 16:50:40 UTC (rev 72557)
@@ -36,7 +36,7 @@
/* air refraction index edlen 1966 / metrologia,2,71-80 putting pw=0 */
float ak=1/wl;
- double awl= wl*wl*wl*wl;
+ double awl= wl*wl*wl*wl * 0.0254743;
double a1 = 130 - ak * ak;
double a2 = 38.9 - ak * ak;
double a3 = 2406030 / a1;
@@ -49,7 +49,7 @@
for(int k = 0; k < 33; k++)
double dppt = (288.15 / 1013.25) * (atms.p[k] / atms.t[k] + atms.p[k+1] / atms.t[k+1]) / 2;
- double sr = a * dppt / awl / 0.0254743;
+ double sr = a * dppt / awl;
tray += (float)((atms.z[k+1] - atms.z[k]) * sr);
@@ -143,7 +143,7 @@
pl[IPL(-1)] = 0;
pl[IPL(0)] = 1;
- for(int k = 0; k <= 80; k++)
+ for(k = 0; k <= 80; k++)
pl[IPL(k+1)] = ((2 * k + 1) * rm * pl[IPL(k)] - k * pl[IPL(k-1)]) / (k + 1);
sixs_trunc.betal[k] += x * pl[IPL(k)];
@@ -169,7 +169,7 @@
float discre(const float ta, const float ha, const float tr, const float hr,
- const int it, const int nt, const float yy, const float dd,
+ const int it, const int ntd, const float yy, const float dd,
const float ppp2, const float ppp1)
if( ha >= 7 )
@@ -180,7 +180,7 @@
double dt;
if( it == 0 ) dt = 1e-17;
- else dt = 2 * (ta + tr - yy) / (nt - it + 1);
+ else dt = 2 * (ta + tr - yy) / (ntd - it + 1);
float zx; /* return value */
float ecart = 0;
@@ -207,8 +207,8 @@
zx = y2;
- float delta = (float)(1. / (1 + ta * hr / tr / ha * exp((zx - ppp1) * (1. / hr - 1. / ha))));
- if(dd != 0) ecart = (float)fabs((dd - delta) / dd);
+ float cdelta = (float)(1. / (1 + ta * hr / tr / ha * exp((zx - ppp1) * (1. / hr - 1. / ha))));
+ if(dd != 0) ecart = (float)fabs((dd - cdelta) / dd);
} while((ecart > 0.75) && (it != 0));
return zx;
@@ -304,7 +304,7 @@
for(j = 0; j <= mu; j++)
- for(int k = -mu; k <= mu; k++)
+ for(k = -mu; k <= mu; k++)
double sbp = 0;
if(is <= 80)
@@ -496,7 +496,7 @@
float phi = (float)geom.phirad;
- int i;
+ int i, k;
for(i = 0; i < np; i++) for(int m = -mu; m <= mu; m++) xl[STDI(m)][i] = 0;
/* ************ incident angle mus ******* */
@@ -562,7 +562,7 @@
/* primary scattering source function at every level within the layer */
- for(int k = 0; k <= snt; k++)
+ for(k = 0; k <= snt; k++)
float c = ch[k];
double a = ydel[k];
@@ -570,8 +570,7 @@
i2[k][STDI(j)] = (float)(c * (sa2 * b + sa1 * a));
- int k;
/* vertical integration, primary upward radiation */
@@ -578,7 +577,7 @@
i1[snt][STDI(k)] = 0;
float zi1 = i1[snt][STDI(k)];
- for(int i = snt - 1; i >= 0; i--)
+ for(i = snt - 1; i >= 0; i--)
float f = h[i + 1] - h[i];
double a = (i2[i + 1][STDI(k)] - i2[i][STDI(k)]) / f;
@@ -597,7 +596,7 @@
i1[0][STDI(k)] = 0;
float zi1 = i1[0][STDI(k)];
- for(int i = 1; i <= snt; i++)
+ for(i = 1; i <= snt; i++)
float f = h[i] - h[i - 1];
float c = (float)exp(f / gauss.rm[STDI(k)]);
@@ -641,14 +640,14 @@
if(is - 2 <= 0)
- for(int i = 0; i <= snt; i++)
+ for(i = 0; i <= snt; i++)
double ii1 = 0;
double ii2 = 0;
- for(int j = 1; j <= mu; j++)
+ for(j = 1; j <= mu; j++)
double bpjk = bp[j][STDI(k)] * xdel[i] + ydel[i] * (beta0 + beta2 * xpl[STDI(j)] * xpl[STDI(k)]);
double bpjmk = bp[j][STDI(-k)] * xdel[i] + ydel[i] * (beta0 + beta2 * xpl[STDI(j)] * xpl[STDI(-k)]);
@@ -667,17 +666,17 @@
else
double ii1;
double ii2;
ii1 = 0;
ii2 = 0;
double bpjk = bp[j][STDI(k)] * xdel[i];
double bpjmk = bp[j][STDI(-k)] * xdel[i];
@@ -697,13 +696,12 @@
/* vertical integration, upward radiation */
- int k;
- for(int i = snt-1; i >= 0; i--)
+ for(i = snt-1; i >= 0; i--)
@@ -722,7 +720,7 @@
i1[0][STDI(k)] = 0;
@@ -812,7 +810,7 @@
/* inm2 is the (n-2)ieme scattering order */
- for(int k = -mu; k <= mu; k++) inm2[STDI(k)] = inm1[STDI(k)];
+ for(k = -mu; k <= mu; k++) inm2[STDI(k)] = inm1[STDI(k)];
roavion2 = roavion1;
@@ -857,7 +855,7 @@
if(is == 0)
- for(int k = 1; k <= mum1; k++) xl[STDI(0)][0] += gauss.rm[STDI(k)] * gauss.gb[STDI(k)] * i3[STDI(-k)];
+ for(k = 1; k <= mum1; k++) xl[STDI(0)][0] += gauss.rm[STDI(k)] * gauss.gb[STDI(k)] * i3[STDI(-k)];
xl[STDI(mu)][0] += (float)(delta0s * i3[STDI(mu)] * cos(is * (geom.phirad + M_PI)));
xl[STDI(-mu)][0] += (float)(delta0s * roavion * cos(is * (geom.phirad + M_PI)));
@@ -1116,7 +1114,7 @@
float x = xdel[i];
float y = ydel[i];
float bpjk = bp[j][STDI(k)] * x + y * (beta0 + beta2 * xpl[STDI(j)] * xpl[STDI(k)]);
float bpjmk= bp[j][STDI(-k)] * x + y * (beta0 + beta2 * xpl[STDI(j)] * xpl[STDI(-k)]);
@@ -1602,7 +1600,9 @@
memset(&oap, 0, sizeof(oap));
Gauss gauss;
gauss.init(); /* discom is the only function that uses the gauss data */
memset(&sixs_trunc, 0, sizeof(sixs_trunc)); /* clear this to keep preconditions the same and output consistent */
/* computation of all scattering parameters at wavelength
@@ -1690,8 +1690,11 @@
int linf = 0;
- for(int i = 0; i < 9; i++)
- if(wl >= sixs_disc.wldis[i] && wl <= sixs_disc.wldis[i+1]) linf = i;
+ int i = 8;
+ while (i >= 0 && linf == 0) {
+ if (wl >= sixs_disc.wldis[i] && wl <= sixs_disc.wldis[i+1]) linf = i;
+ i--;
if(wl > sixs_disc.wldis[9]) linf = 8;
int lsup = linf + 1;
Modified: grass/branches/releasebranch_7_4/imagery/i.atcorr/create_iwave.py
--- grass/branches/releasebranch_7_4/imagery/i.atcorr/create_iwave.py 2018-03-24 16:42:50 UTC (rev 72556)
+++ grass/branches/releasebranch_7_4/imagery/i.atcorr/create_iwave.py 2018-03-24 16:50:40 UTC (rev 72557)
@@ -71,7 +71,7 @@
# fix nodata or \n
conv = {}
for b in range(len(bands)):
- conv[b+1] = lambda s: float(s or -99)
+ conv[b+1] = lambda s: float(s or 0)
values = np.loadtxt(csvfile, delimiter=',', skiprows=1, converters = conv)
@@ -85,49 +85,62 @@
and min, max wl values
values must be numpy array with 2 columns
- # These 2 lines select the subarray
- # remove nodata (-99) lines in values array
- # where response is nodata?
+ # removing nodata and invalid values
w = values[:,1] >= 0
- response = values[w]
+ values_clean = values[w]
- wavelengths = response[:,0] # 1st column of input array
- spectral_response = response[:,1] # 2nd column
- assert len(wavelengths) == len(spectral_response), "Number of wavelength slots and spectral responses are not equal!"
+ wavelengths = values_clean[:,0] # 1st column of input array
+ responses = values_clean[:,1] # 2nd column
+ assert len(wavelengths) == len(responses), "Number of wavelength slots and spectral responses are not equal!"
- # interpolating
- f = interpolate.interp1d(wavelengths, spectral_response)
- start = wavelengths[0]
+ # spectral responses are written out with .4f in pretty_print()
+ # anything smaller than 0.0001 will become 0.0000 -> discard with ...
+ rthresh = 0.0001
- # considering last entry for np.arange
- input_step = wavelengths[-1] - wavelengths[-2]
+ # i.atcorr not only expects steps of 2.5 nm, it also expects
+ # wavelentgh values to be exact multiples of 2.5 nm
+ # in the range 250 - 4000 nm
- # if wavelength step in input data is 1 nm
- # print " > Wavelength step in input data is", input_step, "nm"
- if input_step == 1:
- addendum = 0
- # print " i No need to modify the stop value for the np.arrange function."
+ # find first response > rthresh
+ nvalues = len(responses)
+ start = 0
+ i = 0
+ while i < nvalues - 1 and responses[i] <= rthresh:
+ i += 1
+ start = wavelengths[i] - step
+ # align to multiple of step
+ nsteps = int(start / step)
+ start = step * nsteps
+ while start < wavelengths[0]:
+ start += step
- # what if input step != 1 and input step != 2.5?
- else:
- addendum = step
- # print " ! Wavelength step in input data is nor 1 nm, neither 2.5 nm.",
- # print "Internally setting the \"stop\" value for the np.arrange()",
- # print "function so as to not exceed the end value", wavelengths[-1],
- # print "of the open half ended range."
+ # find last response > rthresh
+ stop = 0
+ i = nvalues - 1
+ while i > 0 and responses[i] <= rthresh:
+ i -= 1
+ stop = wavelengths[i] + step
+ nsteps = np.ceil(stop / step)
+ stop = step * nsteps
+ while stop > wavelengths[nvalues - 1]:
+ stop -= step
- stop = wavelengths[-1] + addendum
+ assert start < stop, "Empty spectral responses!"
+ # interpolating
+ f = interpolate.interp1d(wavelengths, responses)
filter_f = f(np.arange(start, stop, step))
# how many spectral responses?
expected = np.ceil((stop - start) / step)
- assert len(filter_f) == expected, "Number of interpolated spectral responses not equal to expected number of interpolations"
+ assert len(filter_f) == expected, "Number of interpolated spectral responses not equal to expected number of interpolations"
# convert limits from nanometers to micrometers
- lowerlimit = wavelengths[0]/1000
- upperlimit = wavelengths[-1]/1000
+ lowerlimit = start/1000
+ upperlimit = stop/1000
return(filter_f, (lowerlimit, upperlimit))
@@ -158,14 +171,18 @@
if i%8 is 0:
if i is not 0:
value_wo_leading_zero = ('%.4f' % (filter_f[i-1])).lstrip('0')
- pstring += value_wo_leading_zero+', '
+ pstring += value_wo_leading_zero
+ if i > 1 and i < len(filter_f):
+ pstring += ', '
if i is not 1:
# trim the trailing whitespace at the end of line
pstring = pstring.rstrip()
- pstring += "\n\t\t"
+ pstring += "\n "
else:
+ if i < len(filter_f):
+ pstring += ', '
# trim starting \n and trailing ,
pstring = pstring.lstrip("\n").rstrip(", ")
return pstring
@@ -177,10 +194,32 @@
needs other functions: interpolate_bands, pretty_print
+ # keep in sync with IWave::parse()
+ rthresh = 0.01
+ print
+ print " > Response peaks from interpolation to 2.5 nm steps:"
# getting necessary data
# single or multiple bands?
if len(bands) == 1:
filter_f, limits = interpolate_band(values)
+ fi = filter_f
+ li = limits
+ # Get wavelength range for spectral response in band
+ maxresponse_idx = np.argmax(fi)
+ # Get minimum wavelength with spectral response
+ c = maxresponse_idx
+ while c > 0 and fi[c - 1] > rthresh:
+ c = c - 1
+ min_wavelength = np.ceil(li[0] * 1000 + (2.5 * c))
+ # Get maximum wavelength with spectral response
+ while c < len(fi) - 1 and fi[c + 1] > rthresh:
+ c = c + 1
+ max_wavelength = np.floor(li[0] * 1000 + (2.5 * c))
+ print " %s (%inm - %inm)" % (bands[b], min_wavelength, max_wavelength)
else:
filter_f = []
limits = []
@@ -188,6 +227,20 @@
fi, li = interpolate_band(values[:,[0,b+1]])
filter_f.append(fi)
limits.append(li)
+ c = c - 1
+ c = c + 1
# writing...
outfile = open(os.path.join(folder, sensor+"_cpp_template.txt"), 'w')
@@ -228,8 +281,8 @@
# writing band limits
- inf = ", ".join(["%.3f" % i[0] for i in limits])
- sup = ", ".join(["%.3f" % i[1] for i in limits])
+ inf = ", ".join(["%.4f" % i[0] for i in limits])
+ sup = ", ".join(["%.4f" % i[1] for i in limits])
outfile.write(' static const float wli[%i] = {%s};\n' % (len(bands), inf))
outfile.write(' static const float wls[%i] = {%s};\n' % (len(bands), sup))
@@ -266,9 +319,39 @@
# getting data from file
bands, values = read_input(inputfile)
+ # print spectral ranges from input file
+ # consider only wavelengths with a reasonably large response
+ # around the peak response, keep in sync with IWave::parse()
+ rthresh = 0.01
+ print
+ print " > Response peaks from input file:"
+ for b in range(1, len(bands) + 1):
+ lowl = 0
+ hiwl = 0
+ maxr = 0
+ maxi = 0
+ for i in range(len(values[:,0])):
+ if maxr < values[i,b]:
+ maxr = values[i,b]
+ maxi = i
+ i = maxi
+ while i >= 0 and values[i,b] > rthresh:
+ lowl = values[i,0]
+ i -= 1
+ i = maxi
+ nvalues = len(values[:,0])
+ while i < nvalues and values[i,b] > rthresh:
+ hiwl = values[i,0]
+ i += 1
+ print " %s (%inm - %inm)" % (bands[b - 1], lowl, hiwl)
# writing file in same folder of input file
write_cpp(bands, values, sensor, os.path.dirname(inputfile))
+ print
print " > Filter functions exported to %s" % ("sensors_csv/"+sensor+"_cpp_template.txt")
print " > Please check this file for possible errors before inserting the code into file iwave.cpp"
print " > Don't forget to add the necessary data to the files iwave.h, geomcond.h, geomcond.cpp, and to i.atcorr.html"
Modified: grass/branches/releasebranch_7_4/imagery/i.atcorr/geomcond.cpp
--- grass/branches/releasebranch_7_4/imagery/i.atcorr/geomcond.cpp 2018-03-24 16:42:50 UTC (rev 72556)
+++ grass/branches/releasebranch_7_4/imagery/i.atcorr/geomcond.cpp 2018-03-24 16:50:40 UTC (rev 72557)
@@ -110,7 +110,7 @@
void GeomCond::pos_fft (long int j, float tu)
/* Local variables */
- double ah, et, az, caz, xla, tet, tsm, tsv, elev, azim, delta, amuzero;
+ double ah, et, az, caz, xla, tet, tsm, tsv, elev, azim, gdelta, amuzero;
/* solar position (zenithal angle asol,azimuthal angle phi0 */
/* in degrees) */
@@ -135,18 +135,18 @@
ah = tsv * 15.f * M_PI / 180.f;
/* solar declination (in radian) */
- delta = 0.006918f - 0.399912f * cos (tet) + 0.070257f * sin (tet) -
+ gdelta = 0.006918f - 0.399912f * cos (tet) + 0.070257f * sin (tet) -
0.006758f * cos (tet * 2.f) + 9.07e-4f * sin (tet * 2.f) -
0.002697f * cos (tet * 3.f) + 0.00148f * sin (tet * 3.f);
/* elevation,azimuth */
- amuzero = sin (xla) * sin (delta) + cos (xla) * cos (delta) * cos (ah);
+ amuzero = sin (xla) * sin (gdelta) + cos (xla) * cos (gdelta) * cos (ah);
elev = asin (amuzero);
- az = cos (delta) * sin (ah) / cos (elev);
+ az = cos (gdelta) * sin (ah) / cos (elev);
if (fabs (az) - 1.f > 0.f) az = SIGN(az);
- caz = (-cos (xla) * sin (delta) + sin (xla) * cos (delta) * cos (ah)) / cos (elev);
+ caz = (-cos (xla) * sin (gdelta) + sin (xla) * cos (gdelta) * cos (ah)) / cos (elev);
azim = asin (az);
if (caz <= 0.f) azim = M_PI - azim;
@@ -346,8 +346,8 @@
posobs(tu, nc, nl);
break;
- case 4: campm = 1.0f;
- case 5:
+ case 4: campm = 1.0f; /* avhrr PM */
+ case 5: /* avhrr PM and avhrr AM */
cin >> month;
cin >> jday;
@@ -379,6 +379,7 @@
case 23: /* pleiades1b * enter month,day,hh.ddd,long.,lat. */
case 24: /* worldview3 * enter month,day,hh.ddd,long.,lat. */
case 25: /* sentinel2a * enter month,day,hh.ddd,long.,lat. */
+ case 26: /* sentinel2b * enter month,day,hh.ddd,long.,lat. */
cin >> month;
cin >> jday;
@@ -450,7 +451,8 @@
string(" pleiades1a observation "),
string(" pleiades1b observation "),
string(" worldview3 observation "),
- string(" sentinel2a observation ")
+ string(" sentinel2a observation "),
+ string(" sentinel2b observation ")
static const string head(" geometrical conditions identity ");
Modified: grass/branches/releasebranch_7_4/imagery/i.atcorr/geomcond.h
--- grass/branches/releasebranch_7_4/imagery/i.atcorr/geomcond.h 2018-03-24 16:42:50 UTC (rev 72556)
+++ grass/branches/releasebranch_7_4/imagery/i.atcorr/geomcond.h 2018-03-24 16:50:40 UTC (rev 72557)
@@ -79,6 +79,8 @@
/* 25 sentinel2a * enter month,day,hh.ddd,long.,lat. */
+/* 26 sentinel2b * enter month,day,hh.ddd,long.,lat. */
/* note: for hrv and tm experiments long. and lat. are the */
/* coordinates of the scene center. */
/* lat. must be > 0 for north lat., < 0 for south lat. */
Modified: grass/branches/releasebranch_7_4/imagery/i.atcorr/i.atcorr.html
--- grass/branches/releasebranch_7_4/imagery/i.atcorr/i.atcorr.html 2018-03-24 16:42:50 UTC (rev 72556)
+++ grass/branches/releasebranch_7_4/imagery/i.atcorr/i.atcorr.html 2018-03-24 16:50:40 UTC (rev 72557)
@@ -222,6 +222,12 @@
<td>enter month,day,hh.ddd,long.,lat. *</td>
</tr>
+<tr>
+<td>26</td>
+<td><b>Sentinel-2B</b></td>
+<td>enter month,day,hh.ddd,long.,lat. *</td>
+</tr>
</table>
<p>
@@ -493,42 +499,37 @@
<table border="1">
-<tr><td><b>Code</b></td><td><b>Meaning</b></td></tr>
+<tr><td><b>Code</b></td><td><b>Band name (peak response)</b></td></tr>
<tr><td>2</td><td><b>meteosat</b> vis band (0.350-1.110)</td></tr>
<tr><td>3</td><td><b>goes east</b> band vis (0.490-0.900)</td></tr>
-<tr><td>4</td><td>goes west band vis (0.490-0.900)</td></tr>
-<tr><td>5</td><td><b>avhrr (noaa6)</b> band 1 (0.550-0.750)</td></tr>
+<tr><td>4</td><td><b>goes west</b> band vis (0.490-0.900)</td></tr>
+<tr><td>5</td><td><b>avhrr</b> (noaa6) band 1 (0.550-0.750)</td></tr>
<tr><td>6</td><td>avhrr (noaa6) band 2 (0.690-1.120)</td></tr>
-<tr><td>7</td><td><b>avhrr (noaa7)</b> band 1 (0.500-0.800)</td></tr>
+<tr><td>7</td><td>avhrr (noaa7) band 1 (0.500-0.800)</td></tr>
<tr><td>8</td><td>avhrr (noaa7) band 2 (0.640-1.170)</td></tr>
-<tr><td>9</td><td><b>avhrr (noaa8)</b> band 1 (0.540-1.010)</td></tr>
+<tr><td>9</td><td>avhrr (noaa8) band 1 (0.540-1.010)</td></tr>
<tr><td>10</td><td>avhrr (noaa8) band 2 (0.680-1.120)</td></tr>
-<tr><td>11</td><td><b>avhrr (noaa9)</b> band 1 (0.530-0.810)</td></tr>
+<tr><td>11</td><td>avhrr (noaa9) band 1 (0.530-0.810)</td></tr>
<tr><td>12</td><td>avhrr (noaa9) band 1 (0.680-1.170)</td></tr>
-<tr><td>13</td><td><b>avhrr (noaa10)</b> band 1 (0.530-0.780)</td></tr>
+<tr><td>13</td><td>avhrr (noaa10) band 1 (0.530-0.780)</td></tr>
<tr><td>14</td><td>avhrr (noaa10) band 2 (0.600-1.190)</td></tr>
-<tr><td>15</td><td><b>avhrr (noaa11)</b> band 1 (0.540-0.820)</td></tr>
+<tr><td>15</td><td>avhrr (noaa11) band 1 (0.540-0.820)</td></tr>
<tr><td>16</td><td>avhrr (noaa11) band 2 (0.600-1.120)</td></tr>
-<tr><td>17</td><td><b>hrv1 (spot1)</b> band 1 (0.470-0.650)</td></tr>
+<tr><td>17</td><td><b>hrv1</b> (spot1) band 1 (0.470-0.650)</td></tr>
<tr><td>18</td><td>hrv1 (spot1) band 2 (0.600-0.720)</td></tr>
<tr><td>19</td><td>hrv1 (spot1) band 3 (0.730-0.930)</td></tr>
<tr><td>20</td><td>hrv1 (spot1) band pan (0.470-0.790)</td></tr>
-<tr><td>21</td><td><b>hrv2 (spot1)</b> band 1 (0.470-0.650)</td></tr>
+<tr><td>21</td><td>hrv2 (spot1) band 1 (0.470-0.650)</td></tr>
<tr><td>22</td><td>hrv2 (spot1) band 2 (0.590-0.730)</td></tr>
<tr><td>23</td><td>hrv2 (spot1) band 3 (0.740-0.940)</td></tr>
<tr><td>24</td><td>hrv2 (spot1) band pan (0.470-0.790)</td></tr>
-<tr><td>25</td><td><b>tm (landsat5)</b> band 1 (0.430-0.560)</td></tr>
+<tr><td>25</td><td><b>tm</b> (landsat5) band 1 (0.430-0.560)</td></tr>
<tr><td>26</td><td>tm (landsat5) band 2 (0.500-0.650)</td></tr>
<tr><td>27</td><td>tm (landsat5) band 3 (0.580-0.740)</td></tr>
<tr><td>28</td><td>tm (landsat5) band 4 (0.730-0.950)</td></tr>
@@ -535,12 +536,12 @@
<tr><td>29</td><td>tm (landsat5) band 5 (1.5025-1.890)</td></tr>
<tr><td>30</td><td>tm (landsat5) band 7 (1.950-2.410)</td></tr>
-<tr><td>31</td><td><b>mss (landsat5)</b> band 1 (0.475-0.640)</td></tr>
+<tr><td>31</td><td><b>mss</b> (landsat5) band 1 (0.475-0.640)</td></tr>
<tr><td>32</td><td>mss (landsat5) band 2 (0.580-0.750)</td></tr>
<tr><td>33</td><td>mss (landsat5) band 3 (0.655-0.855)</td></tr>
<tr><td>34</td><td>mss (landsat5) band 4 (0.785-1.100)</td></tr>
-<tr><td>35</td><td><b>MAS (ER2)</b> band 1 (0.5025-0.5875)</td></tr>
+<tr><td>35</td><td><b>MAS</b> (ER2) band 1 (0.5025-0.5875)</td></tr>
<tr><td>36</td><td>MAS (ER2) band 2 (0.6075-0.7000)</td></tr>
<tr><td>37</td><td>MAS (ER2) band 3 (0.8300-0.9125)</td></tr>
<tr><td>38</td><td>MAS (ER2) band 4 (0.9000-0.9975)</td></tr>
@@ -556,10 +557,9 @@
<tr><td>47</td><td>MODIS band 6 (1.6000-1.6650)</td></tr>
<tr><td>48</td><td>MODIS band 7 (2.0575-2.1825)</td></tr>
-<tr><td>49</td><td><b>avhrr (noaa12)</b> band 1 (0.500-1.000)</td></tr>
+<tr><td>49</td><td><b>avhrr</b> (noaa12) band 1 (0.500-1.000)</td></tr>
<tr><td>50</td><td>avhrr (noaa12) band 2 (0.650-1.120)</td></tr>
-<tr><td>51</td><td><b>avhrr (noaa14)</b> band 1 (0.500-1.110)</td></tr>
+<tr><td>51</td><td>avhrr (noaa14) band 1 (0.500-1.110)</td></tr>
<tr><td>52</td><td>avhrr (noaa14) band 2 (0.680-1.100)</td></tr>
<tr><td>53</td><td><b>POLDER</b> band 1 (0.4125-0.4775)</td></tr>
@@ -571,20 +571,20 @@
<tr><td>59</td><td>POLDER band 7 P1 (0.8100-0.9200)</td></tr>
<tr><td>60</td><td>POLDER band 8 (non polar) (0.8650-0.9400)</td></tr>
-<tr><td>61</td><td><b>etm+ (landsat7)</b> band 1 blue (0.435-0.520)</td></tr>
-<tr><td>62</td><td>etm+ (landsat7) band 2 green (0.506-0.621)</td></tr>
-<tr><td>63</td><td>etm+ (landsat7) band 3 red (0.622-0.702)</td></tr>
-<tr><td>64</td><td>etm+ (landsat7) band 4 NIR (0.751-0.911)</td></tr>
-<tr><td>65</td><td>etm+ (landsat7) band 5 SWIR (1.512-1.792)</td></tr>
-<tr><td>66</td><td>etm+ (landsat7) band 7 SWIR (2.020-2.380)</td></tr>
-<tr><td>67</td><td>etm+ (landsat7) band 8 PAN (0.504-0.909)</td></tr>
+<tr><td>61</td><td><b>etm+ (landsat7)</b> band 1 blue (435nm - 517nm)</td></tr>
+<tr><td>62</td><td>etm+ (landsat7) band 2 green (508nm - 617nm)</td></tr>
+<tr><td>63</td><td>etm+ (landsat7) band 3 red (625nm - 702nm)</td></tr>
+<tr><td>64</td><td>etm+ (landsat7) band 4 NIR (753nm - 910nm)</td></tr>
+<tr><td>65</td><td>etm+ (landsat7) band 5 SWIR (1520nm - 1785nm)</td></tr>
+<tr><td>66</td><td>etm+ (landsat7) band 7 SWIR (2028nm - 2375nm)</td></tr>
+<tr><td>67</td><td>etm+ (landsat7) band 8 PAN (505nm - 917nm)</td></tr>
-<tr><td>68</td><td><b>liss (IRC 1C)</b> band 2 (0.502-0.620)</td></tr>
+<tr><td>68</td><td><b>liss</b> (IRC 1C) band 2 (0.502-0.620)</td></tr>
<tr><td>69</td><td>liss (IRC 1C) band 3 (0.612-0.700)</td></tr>
<tr><td>70</td><td>liss (IRC 1C) band 4 (0.752-0.880)</td></tr>
<tr><td>71</td><td>liss (IRC 1C) band 5 (1.452-1.760)</td></tr>
-<tr><td>72</td><td><b>aster </b> band 1 (0.480-0.645)</td></tr>
+<tr><td>72</td><td><b>aster</b> band 1 (0.480-0.645)</td></tr>
<tr><td>73</td><td>aster band 2 (0.588-0.733)</td></tr>
<tr><td>74</td><td>aster band 3N (0.723-0.913)</td></tr>
<tr><td>75</td><td>aster band 4 (1.530-1.750)</td></tr>
@@ -594,120 +594,133 @@
<tr><td>79</td><td>aster band 8 (2.248-2.475)</td></tr>
<tr><td>80</td><td>aster band 9 (2.295-2.538)</td></tr>
-<tr><td>81</td><td><b>avnir</b> band 1 (0.390-0.550)</td></tr>
-<tr><td>82</td><td>avnir band 2 (0.485-0.695)</td></tr>
-<tr><td>83</td><td>avnir band 3 (0.545-0.745)</td></tr>
-<tr><td>84</td><td>avnir band 4 (0.700-0.925)</td></tr>
+<tr><td>81</td><td><b>avnir</b> band 1 (408nm - 517nm)</td></tr>
+<tr><td>82</td><td>avnir band 2 (503nm - 612nm)</td></tr>
+<tr><td>83</td><td>avnir band 3 (583nm - 717nm)</td></tr>
+<tr><td>84</td><td>avnir band 4 (735nm - 922nm)</td></tr>
-<tr><td>85</td><td><b>ikonos</b> Green band (0.350-1.035)</td></tr>
-<tr><td>86</td><td>ikonos Red band (0.350-1.035)</td></tr>
-<tr><td>87</td><td>ikonos NIR band (0.350-1.035)</td></tr>
+<tr><td>85</td><td><b>Ikonos</b> Green band (408nm - 642nm)</td></tr>
+<tr><td>86</td><td>Ikonos Red band (448nm - 715nm)</td></tr>
+<tr><td>87</td><td>Ikonos NIR band (575nm - 787nm)</td></tr>
-<tr><td>88</td><td><b>RapidEye</b> Blue band (0.438-0.513)</td></tr>
-<tr><td>89</td><td>RapidEye Green band (0.463-0.594)</td></tr>
-<tr><td>90</td><td>RapidEye Red band (0.624-0.690)</td></tr>
-<tr><td>91</td><td>RapidEye RedEdge band (0.500-0.737)</td></tr>
-<tr><td>92</td><td>RapidEye NIR band (0.520-0.862)</td></tr>
+<tr><td>88</td><td><b>RapidEye</b> Blue band (440nm - 512nm)</td></tr>
+<tr><td>89</td><td>RapidEye Green band (515nm - 592nm)</td></tr>
+<tr><td>90</td><td>RapidEye Red band (628nm - 687nm)</td></tr>
+<tr><td>91</td><td>RapidEye Red edge band (685nm - 735nm)</td></tr>
+<tr><td>92</td><td>RapidEye NIR band (750nm - 860nm)</td></tr>
-<tr><td>93</td><td><b>VGT1 (SPOT4)</b> band 0 (0.400-0.500)</td></tr>
-<tr><td>94</td><td>VGT1 (SPOT4) band 2 (0.580-0.782)</td></tr>
-<tr><td>95</td><td>VGT1 (SPOT4) band 3 (0.700-1.030)</td></tr>
-<tr><td>96</td><td>VGT1 (SPOT4) MIR band (1.450-1.800)</td></tr>
+<tr><td>93</td><td><b>VGT1 (SPOT4)</b> band 0 (420nm - 497nm)</td></tr>
+<tr><td>94</td><td>VGT1 (SPOT4) band 2 (603nm - 747nm)</td></tr>
+<tr><td>95</td><td>VGT1 (SPOT4) band 3 (740nm - 942nm)</td></tr>
+<tr><td>96</td><td>VGT1 (SPOT4) MIR band (1540nm - 1777nm)</td></tr>
-<tr><td>97</td><td><b>VGT2 (SPOT5)</b> band 0 (0.400-0.550)</td></tr>
-<tr><td>98</td><td>VGT2 (SPOT5) band 2 (0.580-0.780)</td></tr>
-<tr><td>99</td><td>VGT2 (SPOT5) band 3 (0.700-1.000)</td></tr>
-<tr><td>100</td><td>VGT2 (SPOT5) MIR band (1.450-1.800)</td></tr>
+<tr><td>97</td><td><b>VGT2 (SPOT5)</b> band 0 (423nm - 492nm)</td></tr>
+<tr><td>98</td><td>VGT2 (SPOT5) band 2 (600nm - 737nm)</td></tr>
+<tr><td>99</td><td>VGT2 (SPOT5) band 3 (745nm - 945nm)</td></tr>
+<tr><td>100</td><td>VGT2 (SPOT5) MIR band (1523nm - 1757nm)</td></tr>
-<tr><td>101</td><td>WorldView 2 Panchromatic band (0.447-0.808)</td></tr>
-<tr><td>102</td><td>WorldView 2 Coastal Blue band (0.396-0.458)</td></tr>
-<tr><td>103</td><td>WorldView 2 Blue band (0.442-0.515)</td></tr>
-<tr><td>104</td><td>WorldView 2 Green band (0.506-0.586)</td></tr>
-<tr><td>105</td><td>WorldView 2 Yellow band (0.584-0.632)</td></tr>
-<tr><td>106</td><td>WorldView 2 Red band (0.624-0.694)</td></tr>
-<tr><td>107</td><td>WorldView 2 Red Edge band (0.699-0.749)</td></tr>
-<tr><td>108</td><td>WorldView 2 NIR1 band (0.765-0.901)</td></tr>
-<tr><td>109</td><td>WorldView 2 NIR2 band (0.856-0.1043)</td></tr>
+<tr><td>101</td><td><b>WorldView2</b> Panchromatic band (448nm - 812nm)</td></tr>
+<tr><td>102</td><td>WorldView2 Coastal Blue band (395nm - 457nm)</td></tr>
+<tr><td>103</td><td>WorldView2 Blue band (440nm - 517nm)</td></tr>
+<tr><td>104</td><td>WorldView2 Green band (503nm - 587nm)</td></tr>
+<tr><td>105</td><td>WorldView2 Yellow band (583nm - 632nm)</td></tr>
+<tr><td>106</td><td>WorldView2 Red band (623nm - 695nm)</td></tr>
+<tr><td>107</td><td>WorldView2 Red edge band (698nm - 750nm)</td></tr>
+<tr><td>108</td><td>WorldView2 NIR1 band (760nm - 905nm)</td></tr>
+<tr><td>109</td><td>WorldView2 NIR2 band (853nm - 1047nm)</td></tr>
-<tr><td>110</td><td><b>QuickBird</b> Panchromatic band (0.405-1.053)</td></tr>
-<tr><td>111</td><td>QuickBird Blue band (0.430-0.545)</td></tr>
-<tr><td>112</td><td>QuickBird Green band (0.466-0.620)</td></tr>
-<tr><td>113</td><td>QuickBird Red band (0.590-0.710)</td></tr>
-<tr><td>114</td><td>QuickBird NIR1 band (0.715-0.918)</td></tr>
+<tr><td>110</td><td><b>QuickBird</b> Panchromatic band (385nm - 1060nm)</td></tr>
+<tr><td>111</td><td>QuickBird Blue band (420nm - 585nm)</td></tr>
+<tr><td>112</td><td>QuickBird Green band (448nm - 682nm)</td></tr>
+<tr><td>113</td><td>QuickBird Red band (560nm - 747nm)</td></tr>
+<tr><td>114</td><td>QuickBird NIR1 band (650nm - 935nm)</td></tr>
-<tr><td>115</td><td><b>Landsat 8 </b> Coastal Aerosol Band (0.427nm - 0.459nm)</td></tr>
-<tr><td>116</td><td>Landsat 8 Blue Band (436nm - 527nm)</td></tr>
-<tr><td>117</td><td>Landsat 8 Green Band (512nm-610nm)</td></tr>
-<tr><td>118</td><td>Landsat 8 Red Band (625nm-691nm)</td></tr>
-<tr><td>119</td><td>Landsat 8 Panchromatic Band (488nm-692nm)</td></tr>
-<tr><td>120</td><td>Landsat 8 NIR Band (829nm-900nm)</td></tr>
-<tr><td>121</td><td>Landsat 8 Cirrus Band (1340nm-1409nm)</td></tr>
-<tr><td>122</td><td>Landsat 8 SWIR1 Band (1515nm - 1697nm)</td></tr>
-<tr><td>123</td><td>Landsat 8 SWIR2 Band (2037nm - 2355nm)</td></tr>
+<tr><td>115</td><td><b>Landsat 8</b> Coastal aerosol band (433nm - 455nm)</td></tr>
+<tr><td>116</td><td>Landsat 8 Blue band (448nm - 515nm)</td></tr>
+<tr><td>117</td><td>Landsat 8 Green band (525nm - 595nm)</td></tr>
+<tr><td>118</td><td>Landsat 8 Red band (633nm - 677nm)</td></tr>
+<tr><td>119</td><td>Landsat 8 Panchromatic band (498nm - 682nm)</td></tr>
+<tr><td>120</td><td>Landsat 8 NIR band (845nm - 885nm)</td></tr>
+<tr><td>121</td><td>Landsat 8 Cirrus band (1355nm - 1390nm)</td></tr>
+<tr><td>122</td><td>Landsat 8 SWIR1 band (1540nm - 1672nm)</td></tr>
+<tr><td>123</td><td>Landsat 8 SWIR2 band (2073nm - 2322nm)</td></tr>
-<tr><td>124</td><td><b>GeoEye 1</b> Panchromatic band (0.450-0.800)</td></tr>
-<tr><td>125</td><td>GeoEye 1 Blue Band (0.450-0.510)</td></tr>
-<tr><td>126</td><td>GeoEye 1 Green Band (0.510-0.580)</td></tr>
-<tr><td>127</td><td>GeoEye 1 Red Band (0.655-0.690)</td></tr>
-<tr><td>128</td><td>GeoEye 1 NIR Band (0.780-0.920)</td></tr>
+<tr><td>124</td><td><b>GeoEye 1</b> Panchromatic band (448nm - 812nm)</td></tr>
+<tr><td>125</td><td>GeoEye 1 Blue band (443nm - 525nm)</td></tr>
+<tr><td>126</td><td>GeoEye 1 Green band (503nm - 587nm)</td></tr>
+<tr><td>127</td><td>GeoEye 1 Red band (653nm - 697nm)</td></tr>
+<tr><td>128</td><td>GeoEye 1 NIR band (770nm - 932nm)</td></tr>
-<tr><td>129</td><td><b>Spot6</b> Blue band (455nm - 525nm)</td></tr>
-<tr><td>130</td><td>Spot6 Green band (530nm - 527nm)</td></tr>
-<tr><td>131</td><td>Spot6 Red band (625nm - 695nm)</td></tr>
-<tr><td>132</td><td>Spot6 NIR band (760nm - 890nm)</td></tr>
-<tr><td>133</td><td>Spot6 Pan band (455nm - 745nm)</td></tr>
+<tr><td>129</td><td><b>Spot6</b> Blue band (440nm - 532nm)</td></tr>
+<tr><td>130</td><td>Spot6 Green band (515nm - 600nm)</td></tr>
+<tr><td>131</td><td>Spot6 Red band (610nm - 710nm)</td></tr>
+<tr><td>132</td><td>Spot6 NIR band (738nm - 897nm)</td></tr>
+<tr><td>133</td><td>Spot6 Pan band (438nm - 760nm)</td></tr>
-<tr><td>134</td><td><b>Spot7</b> Blue band (455nm - 525nm)</td></tr>
-<tr><td>135</td><td>Spot7 Green band (530nm - 527nm)</td></tr>
-<tr><td>136</td><td>Spot7 Red band (625nm - 695nm)</td></tr>
-<tr><td>137</td><td>Spot7 NIR band (760nm - 890nm)</td></tr>
-<tr><td>138</td><td>Spot7 Pan band (455nm - 745nm)</td></tr>
+<tr><td>134</td><td><b>Spot7</b> Blue band (445nm - 532nm)</td></tr>
+<tr><td>135</td><td>Spot7 Green band (525nm - 607nm)</td></tr>
+<tr><td>136</td><td>Spot7 Red band (610nm - 727nm)</td></tr>
+<tr><td>137</td><td>Spot7 NIR band (745nm - 902nm)</td></tr>
+<tr><td>138</td><td>Spot7 Pan band (443nm - 760nm)</td></tr>
-<tr><td>139</td><td><b>Pleiades1A</b> Blue band (430nm - 550nm)</td></tr>
-<tr><td>140</td><td>Pleiades1A Green band (490nm - 610nm)</td></tr>
-<tr><td>141</td><td>Pleiades1A Red band (600nm - 720nm)</td></tr>
-<tr><td>142</td><td>Pleiades1A NIR band (750nm - 950nm)</td></tr>
-<tr><td>143</td><td>Pleiades1A Pan band (480nm - 830nm)</td></tr>
+<tr><td>139</td><td><b>Pleiades1A</b> Blue band (433nm - 560nm)</td></tr>
+<tr><td>140</td><td>Pleiades1A Green band (500nm - 617nm)</td></tr>
+<tr><td>141</td><td>Pleiades1A Red band (590nm - 722nm)</td></tr>
+<tr><td>142</td><td>Pleiades1A NIR band (740nm - 945nm)</td></tr>
+<tr><td>143</td><td>Pleiades1A Pan band (460nm - 845nm)</td></tr>
-<tr><td>144</td><td><b>Pleiades1B </b> Blue band (430nm - 550nm)</td></tr>
-<tr><td>145</td><td>Pleiades1B Green band (490nm - 610nm)</td></tr>
-<tr><td>146</td><td>Pleiades1B Red band (600nm - 720nm)</td></tr>
-<tr><td>147</td><td>Pleiades1B NIR band (750nm - 950nm)</td></tr>
-<tr><td>148</td><td>Pleiades1B Pan band (480nm - 830nm)</td></tr>
+<tr><td>144</td><td><b>Pleiades1B</b> Blue band 438nm - 560nm)</td></tr>
+<tr><td>145</td><td>Pleiades1B Green band (498nm - 615nm)</td></tr>
+<tr><td>146</td><td>Pleiades1B Red band (608nm - 727nm)</td></tr>
+<tr><td>147</td><td>Pleiades1B NIR band (750nm - 945nm)</td></tr>
+<tr><td>148</td><td>Pleiades1B Pan band (460nm - 845nm)</td></tr>
-<tr><td>149</td><td><b>Worldview3 </b> Pan band (450nm - 800nm)</td></tr>
-<tr><td>150</td><td>Worldview3 Coastal blue band (400nm - 450 nm)</td></tr>
-<tr><td>151</td><td>Worldview3 Blue band (450nm - 510 nm)</td></tr>
-<tr><td>152</td><td>Worldview3 Green band (510nm - 580 nm)</td></tr>
-<tr><td>153</td><td>Worldview3 Yellow band (585nm - 625 nm)</td></tr>
-<tr><td>154</td><td>Worldview3 Red band (630nm - 690 nm)</td></tr>
-<tr><td>155</td><td>Worldview3 Red edge band (705nm - 745 nm)</td></tr>
-<tr><td>156</td><td>Worldview3 NIR1 band (770nm - 895 nm)</td></tr>
-<tr><td>157</td><td>Worldview3 NIR2 band (860nm - 1040 nm)</td></tr>
-<tr><td>158</td><td>Worldview3 SWIR1 band (1195nm - 1225 nm)</td></tr>
-<tr><td>159</td><td>Worldview3 SWIR2 band (1550nm - 1590 nm)</td></tr>
-<tr><td>160</td><td>Worldview3 SWIR3 band (1640nm - 1680 nm)</td></tr>
-<tr><td>161</td><td>Worldview3 SWIR4 band (1710nm - 1750 nm)</td></tr>
-<tr><td>162</td><td>Worldview3 SWIR5 band (2145nm - 2185 nm)</td></tr>
-<tr><td>163</td><td>Worldview3 SWIR6 band (2185nm - 2225 nm)</td></tr>
-<tr><td>163</td><td>Worldview3 SWIR7 band (2235nm - 2285 nm)</td></tr>
-<tr><td>165</td><td>Worldview3 SWIR8 band (2295nm - 2365 nm)</td></tr>
+<tr><td>149</td><td><b>Worldview3</b> Pan band (445nm - 812nm)</td></tr>
+<tr><td>150</td><td>Worldview3 Coastal blue band (395nm - 455nm)</td></tr>
+<tr><td>151</td><td>Worldview3 Blue band (443nm - 517nm)</td></tr>
+<tr><td>152</td><td>Worldview3 Green band (508nm - 587nm)</td></tr>
+<tr><td>153</td><td>Worldview3 Yellow band (580nm - 630nm)</td></tr>
+<tr><td>154</td><td>Worldview3 Red band 625nm - 697nm)</td></tr>
+<tr><td>155</td><td>Worldview3 Red edge band (698nm - 752nm)</td></tr>
+<tr><td>156</td><td>Worldview3 NIR1 band (760nm - 902nm)</td></tr>
+<tr><td>157</td><td>Worldview3 NIR2 band (855nm - 1042nm)</td></tr>
+<tr><td>158</td><td>Worldview3 SWIR1 band (1178nm - 1242nm)</td></tr>
+<tr><td>159</td><td>Worldview3 SWIR2 band (1545nm - 1600nm)</td></tr>
+<tr><td>160</td><td>Worldview3 SWIR3 band (1633nm - 1687nm)</td></tr>
+<tr><td>161</td><td>Worldview3 SWIR4 band (1698nm - 1762nm)</td></tr>
+<tr><td>162</td><td>Worldview3 SWIR5 band (2133nm - 2195nm)</td></tr>
+<tr><td>163</td><td>Worldview3 SWIR6 band (2170nm - 2235nm)</td></tr>
+<tr><td>164</td><td>Worldview3 SWIR7 band (2225nm - 2295nm)</td></tr>
+<tr><td>165</td><td>Worldview3 SWIR8 band (2283nm - 2377nm)</td></tr>
-<!-- derived from sensors_csv/sentinel_2A_msi.csv -->
-<tr><td>166</td><td><b>Sentinel2A</b> Coastal blue band B1 ( 430nm - 457nm)</td></tr>
-<tr><td>167</td><td>Sentinel2A Blue band B2 ( 440nm - 535nm)</td></tr>
-<tr><td>168</td><td>Sentinel2A Green band B3 ( 537nm - 582nm)</td></tr>
-<tr><td>169</td><td>Sentinel2A Red band B4 ( 646nm - 684nm)</td></tr>
-<tr><td>170</td><td>Sentinel2A Red edge band B5 ( 694nm - 713nm)</td></tr>
-<tr><td>171</td><td>Sentinel2A Red edge band B6 ( 731nm - 749nm)</td></tr>
-<tr><td>172</td><td>Sentinel2A Red edge band B7 ( 769nm - 797nm)</td></tr>
-<tr><td>173</td><td>Sentinel2A NIR band B8 ( 773nm - 908nm)</td></tr>
-<tr><td>174</td><td>Sentinel2A Red edge band B8A ( 848nm - 881nm)</td></tr>
-<tr><td>175</td><td>Sentinel2A Water vapour band B9 ( 932nm - 958nm)</td></tr>
-<tr><td>176</td><td>Sentinel2A SWIR Cirrus band B10 ( 1337nm - 1412nm)</td></tr>
-<tr><td>177</td><td>Sentinel2A SWIR band B11 ( 1539nm - 1682nm)</td></tr>
-<tr><td>178</td><td>Sentinel2A SWIR band B12 ( 2078nm - 2320nm)</td></tr>
+<tr><td>166</td><td><b>Sentinel2A</b> Coastal blue band B1 (430nm - 455nm)</td></tr>
+<tr><td>167</td><td>Sentinel2A Blue band B2 (440nm - 530nm)</td></tr>
+<tr><td>168</td><td>Sentinel2A Green band B3 (540nm - 580nm)</td></tr>
+<tr><td>169</td><td>Sentinel2A Red band B4 (648nm - 682nm)</td></tr>
+<tr><td>170</td><td>Sentinel2A Red edge band B5 (695nm - 712nm)</td></tr>
+<tr><td>171</td><td>Sentinel2A Red edge band B6 (733nm - 747nm)</td></tr>
+<tr><td>172</td><td>Sentinel2A Red edge band B7 (770nm - 795nm)</td></tr>
+<tr><td>173</td><td>Sentinel2A NIR band B8 (775nm - 905nm)</td></tr>
+<tr><td>174</td><td>Sentinel2A Red edge band B8A (850nm - 880nm)</td></tr>
+<tr><td>175</td><td>Sentinel2A Water vapour band B9 (933nm - 957nm)</td></tr>
+<tr><td>176</td><td>Sentinel2A SWIR Cirrus band B10 (1355nm - 1392nm)</td></tr>
+<tr><td>177</td><td>Sentinel2A SWIR band B11 (1558nm - 1667nm)</td></tr>
+<tr><td>178</td><td>Sentinel2A SWIR band B12 (2088nm - 2315nm)</td></tr>
+<tr><td>179</td><td><b>Sentinel2B</b> Coastal blue band B1 (430nm - 455nm)</td></tr>
+<tr><td>180</td><td>Sentinel2B Blue band B2 (440nm - 530nm)</td></tr>
+<tr><td>181</td><td>Sentinel2B Green band B3 (538nm - 580nm)</td></tr>
+<tr><td>182</td><td>Sentinel2B Red band B4 (648nm - 682nm)</td></tr>
+<tr><td>183</td><td>Sentinel2B Red edge band B5 (695nm - 712nm)</td></tr>
+<tr><td>184</td><td>Sentinel2B Red edge band B6 (730nm - 747nm)</td></tr>
+<tr><td>185</td><td>Sentinel2B Red edge band B7 (768nm - 792nm)</td></tr>
+<tr><td>186</td><td>Sentinel2B NIR band B8 (778nm - 905nm)</td></tr>
+<tr><td>187</td><td>Sentinel2B Red edge band B8A (850nm - 877nm)</td></tr>
+<tr><td>188</td><td>Sentinel2B Water vapour band B9 (930nm - 955nm)</td></tr>
+<tr><td>189</td><td>Sentinel2B SWIR Cirrus band B10 (1358nm - 1397nm)</td></tr>
+<tr><td>190</td><td>Sentinel2B SWIR band B11 (1555nm - 1667nm)</td></tr>
+<tr><td>191</td><td>Sentinel2B SWIR band B12 (2075nm - 2300nm)</td></tr>
</table>
<h2>EXAMPLES</h2>
@@ -743,7 +756,8 @@
<ol>
<li><em>Geometrical conditions</em>
-<p>For Sentinel-2A, the geometrical conditions take the value <tt>25</tt> (See table A).
+<p>For Sentinel-2A, the geometrical conditions take the value <tt>25</tt> and for
+Sentinel-2B, the geometrical conditions value is <tt>26</tt> (See table A).
Our scene comes from the Sentinel-2A mission (the file name begins with
S2A_...).
<br><br>
@@ -813,7 +827,8 @@
<br><br>
<li><em>Sensor band</em>
<p>The overview of satellite bands can be found in table F (see above).
-For Sentinel-2A, the band numbers span from 166 to 178.
+For Sentinel-2A, the band numbers span from 166 to 178, and for
+Sentinel-2B, from 179 to 191.
</ol>
<p>Finally, here is what the 6S file would look like for Band 02 of our
@@ -839,7 +854,7 @@
<li><b>input</b> = raster band to be processed,
<li><b>parameters</b> = path to 6S file created in the previous step (we could also enter the values directly),
<li><b>output</b> = name for the output corrected raster band,
- <li><b>range</b> = from 1 to the <tt>QUANTIFICATION_VALUE</tt> stored in the metadata file. It is <tt>10000</tt> for Sentinel-2A.
+ <li><b>range</b> = from 1 to the <tt>QUANTIFICATION_VALUE</tt> stored in the metadata file. It is <tt>10000</tt> for both Sentinel-2A and Sentinel-2B.
<li><b>rescale</b> = the output range of values for the corrected bands. This is up to the user to choose, for example: 0-255, 0-1, 1-10000.
</ul>
<p>If the data is available, the following parameters can be specified
@@ -1069,6 +1084,9 @@
<p><em>Sentinel-2A addition 12/2016:</em>
<br>Markus Neteler, mundialis.de, Germany
+<p><em>Sentinel-2B addition 1/2018:</em>
+<br>Stefan Blumentrath, Zofie Cimburova, Norwegian Institute for Nature Research, NINA, Oslo, Norway
<p>
<i>Last changed: $Date$</i>
Modified: grass/branches/releasebranch_7_4/imagery/i.atcorr/iwave.cpp
--- grass/branches/releasebranch_7_4/imagery/i.atcorr/iwave.cpp 2018-03-24 16:42:50 UTC (rev 72556)
+++ grass/branches/releasebranch_7_4/imagery/i.atcorr/iwave.cpp 2018-03-24 16:50:40 UTC (rev 72557)
@@ -1325,143 +1325,145 @@
http://ltpwww.gsfc.nasa.gov/IAS/handbook/handbook_toc.html
/* 1st spectral band of enhanced thematic mapper plus */
- static const float sr1[35] = {
- .0160, .0710, .2870, .6665, .7920, .8570, .8390, .8060,
- .7790, .8460, .9010, .8995, .8900, .8510, .8750, .8930,
- .8840, .9300, .9580, .9540, .9800, .9750, .9650, .9625,
- .9950, .9900, .9900, .9795, .9830, .9685, .9600, .7685,
- .2930, .0545, .0090
+ static const float sr1[36] = {
+ .0000, .0160, .0710, .2870, .6665, .7920, .8570, .8390,
+ .8060, .7790, .8460, .9010, .8995, .8900, .8510, .8750,
+ .8930, .8840, .9300, .9580, .9540, .9800, .9750, .9650,
+ .9625, .9950, .9900, .9900, .9795, .9830, .9685, .9600,
+ .7685, .2930, .0545, .0090
/* 2nd spectral band of enhanced thematic mapper plus */
- static const float sr2[50] = {
- .0006, .0015, .0030, .0117, .0260, .0740, .1740, .3480,
- .5520, .6960, .7590, .7845, .8220, .8695, .9050, .9285,
- .9470, .9525, .9520, .9515, .9530, .9500, .9540, .9670,
- .9590, .9405, .9330, .9385, .9510, .9565, .9550, .9560,
- .9730, .9915,1.0000, .9760, .9420, .9300, .9120, .7985,
- .5740, .3400, .1850, .1055, .0620, .0375, .0210, .0109,
- .0048, .0021
+ static const float sr2[52] = {
+ .0000, .0006, .0015, .0030, .0118, .0260, .0740, .1740,
+ .3480, .5520, .6960, .7590, .7845, .8220, .8695, .9050,
+ .9285, .9470, .9525, .9520, .9515, .9530, .9500, .9540,
+ .9670, .9590, .9405, .9330, .9385, .9510, .9565, .9550,
+ .9560, .9730, .9915, 1.0000, .9760, .9420, .9300, .9120,
+ .7985, .5740, .3400, .1850, .1055, .0620, .0375, .0210,
+ .0109, .0048, .0022, .0000
/* 3rd spectral band of enhanced thematic mapper plus */
- static const float sr3[36] = {
- .0001, .0006, .0020, .0095, .0470, .1740, .4190, .7310,
- .9210, .9425, .9370, .9365, .9490, .9645, .9730, .9705,
- .9580, .9550, .9620, .9800, .9930, .9980,1.0000, .9955,
- .9920, .9885, .9770, .9545, .9320, .8805, .7290, .4440,
- .1830, .0660, .0250, .0121
+ static const float sr3[39] = {
+ .0000, .0000, .0001, .0005, .0020, .0095, .0470, .1740,
+ .4190, .7310, .9210, .9425, .9370, .9365, .9490, .9645,
+ .9730, .9705, .9580, .9550, .9620, .9800, .9930, .9980,
+ 1.0000, .9955, .9920, .9885, .9770, .9545, .9320, .8805,
+ .7290, .4440, .1830, .0660, .0250, .0122, .0000
/* 4th spectral band of enhanced thematic mapper plus */
- static const float sr4[70] = {
- .0004, .0021, .0037, .0024, .0010, .0199, .0315, .0518,
- .0690, .1100, .1750, .2710, .4020, .5555, .7050, .8120,
- .8710, .8955, .9080, .9180, .9260, .9280, .9300, .9255,
- .9250, .9280, .9230, .9165, .9080, .9035, .9090, .9240,
- .9460, .9655, .9710, .9690, .9670, .9655, .9670, .9605,
- .9490, .9310, .9250, .9295, .9430, .9610, .9850, .9925,
- .9980, .9915, .9940, .9970, .9980, .9995, .9910, .9880,
- .9690, .9265, .8680, .8175, .8190, .8800, .8540, .5725,
- .2560, .1035, .0440, .0220, .0110, .0071
+ static const float sr4[68] = {
+ .0000, .0010, .0199, .0315, .0518, .0690, .1100, .1750,
+ .2710, .4020, .5555, .7050, .8120, .8710, .8955, .9080,
+ .9180, .9260, .9280, .9300, .9255, .9250, .9280, .9230,
+ .9165, .9080, .9035, .9090, .9240, .9460, .9655, .9710,
+ .9690, .9670, .9655, .9670, .9605, .9490, .9310, .9250,
+ .9295, .9430, .9610, .9850, .9925, .9980, .9915, .9940,
+ .9970, .9980, .9995, .9910, .9880, .9690, .9265, .8680,
+ .8175, .8190, .8800, .8540, .5725, .2560, .1035, .0440,
+ .0220, .0110, .0071, .0000
/* 5th spectral band of enhanced thematic mapper plus */
- static const float sr5[116] = {
- .0015, .0000, .0010, .0112, .0120, .0060, .0135, .0210,
- .0400, .0530, .0760, .1028, .1480, .2052, .2740, .3660,
- .4620, .5137, .5780, .6250, .6670, .7090, .7370, .7710,
- .8080, .8315, .8590, .8750, .8930, .9013, .8960, .8953,
- .8945, .8878, .8760, .8685, .8725, .8773, .8740, .8605,
- .8680, .8785, .8990, .8940, .9000, .9020, .9190, .9248,
- .9290, .9455, .9475, .9533, .9520, .9668, .9610, .9598,
- .9780, .9587, .9535, .9513, .9517, .9550, .9440, .9345,
- .9305, .9385, .9480, .9398, .9385, .9470, .9450, .9450,
- .9553, .9648, .9690, .9733, .9910, .9960, .9975, .9945,
- 1.0000, .9913, .9865, .9885, .9895, .9875, .9810, .9812,
- .9780, .9685, .9600, .9383, .9020, .8545, .7910, .6928,
- .6077, .5257, .4275, .3420, .2670, .2028, .1585, .1187,
- .0840, .0723, .0535, .0437, .0390, .0305, .0205, .0217,
- .0110, .0100, .0060, .0020
+ static const float sr5[114] = {
+ .0060, .0060, .0120, .0060, .0135, .0210, .0400, .0530,
+ .0760, .1028, .1480, .2052, .2740, .3660, .4620, .5138,
+ .5780, .6250, .6670, .7090, .7370, .7710, .8080, .8315,
+ .8590, .8750, .8930, .9012, .8960, .8952, .8945, .8878,
+ .8760, .8685, .8725, .8772, .8740, .8605, .8680, .8785,
+ .8990, .8940, .9000, .9020, .9190, .9248, .9290, .9455,
+ .9475, .9532, .9520, .9667, .9610, .9597, .9780, .9587,
+ .9535, .9512, .9517, .9550, .9440, .9345, .9305, .9385,
+ .9480, .9397, .9385, .9470, .9450, .9450, .9553, .9647,
+ .9690, .9732, .9910, .9960, .9975, .9945, 1.0000, .9912,
+ .9865, .9885, .9895, .9875, .9810, .9812, .9780, .9685,
+ .9600, .9383, .9020, .8545, .7910, .6927, .6077, .5258,
+ .4275, .3420, .2670, .2027, .1585, .1187, .0840, .0722,
+ .0535, .0438, .0390, .0305, .0205, .0217, .0110, .0100,
+ .0060, .0079
/* 7th spectral band of enhanced thematic mapper plus */
- static const float sr6[147] = {
- .0020, .0020, .0120, .0085, .0090, .0177, .0170, .0313,
- .0370, .0458, .0580, .0762, .0880, .1097, .1490, .1960,
- .2420, .3030, .3670, .4368, .5190, .6100, .6765, .7182,
- .7560, .7738, .7840, .7755, .7890, .7817, .7780, .7665,
- .7615, .7680, .7750, .7690, .7880, .8085, .7940, .8230,
- .8115, .8195, .8365, .8370, .8360, .8513, .8585, .8553,
- .8710, .8735, .8750, .8590, .8715, .8593, .8720, .8625,
- .8650, .8680, .8765, .8730, .8690, .8760, .8680, .8793,
- .8735, .8760, .8800, .8745, .8700, .8578, .8630, .8585,
- .8440, .8585, .8545, .8625, .8680, .8560, .8470, .8613,
- .8510, .8520, .8380, .8465, .8403, .8305, .8355, .8382,
- .8220, .8380, .8385, .8425, .8535, .8623, .8730, .8680,
- .8790, .8908, .8980, .9195, .9200, .9263, .9275, .9340,
- .9360, .9533, .9540, .9518, .9600, .9728, .9850, .9720,
- .9700, .9938, .9895, .9748,1.0000, .9912, .9680, .9658,
- .9555, .9295, .9290, .9255, .9030, .9235, .9290, .9285,
- .9200, .8533, .7750, .6587, .5315, .4035, .2750, .2175,
- .1310, .1035, .0750, .0518, .0290, .0280, .0135, .0193,
- .0130, .0065, .0150
+ static const float sr6[155] = {
+ .0029, .0030, .0023, .0030, .0008, .0020, .0040, .0020,
+ .0020, .0120, .0085, .0090, .0178, .0170, .0312, .0370,
+ .0457, .0580, .0762, .0880, .1098, .1490, .1960, .2420,
+ .3030, .3670, .4367, .5190, .6100, .6765, .7183, .7560,
+ .7738, .7840, .7755, .7890, .7818, .7780, .7665, .7615,
+ .7680, .7750, .7690, .7880, .8085, .7940, .8230, .8115,
+ .8195, .8365, .8370, .8360, .8512, .8585, .8552, .8710,
+ .8735, .8750, .8590, .8715, .8592, .8720, .8625, .8650,
+ .8680, .8765, .8730, .8690, .8760, .8680, .8792, .8735,
+ .8760, .8800, .8745, .8700, .8578, .8630, .8585, .8440,
+ .8585, .8545, .8625, .8680, .8560, .8470, .8612, .8510,
+ .8520, .8380, .8465, .8403, .8305, .8355, .8382, .8220,
+ .8380, .8385, .8425, .8535, .8622, .8730, .8680, .8790,
+ .8908, .8980, .9195, .9200, .9263, .9275, .9340, .9360,
+ .9532, .9540, .9517, .9600, .9728, .9850, .9720, .9700,
+ .9938, .9895, .9748, 1.0000, .9912, .9680, .9657, .9555,
+ .9295, .9290, .9255, .9030, .9235, .9290, .9285, .9200,
+ .8532, .7750, .6588, .5315, .4035, .2750, .2175, .1310,
+ .1035, .0750, .0518, .0290, .0290, .0155, .0192, .0130,
+ .0065, .0150, .0022
/* 8th spectral band of enhanced thematic mapper plus (Pan) */
- static const float sr7[164] = {
- .0028, .0175, .0563, .1500, .3285, .5015, .5845, .5990,
- .6018, .6095, .6143, .6100, .6035, .6035, .6118, .6270,
- .6385, .6445, .6438, .6320, .6260, .6245, .6320, .6420,
- .6593, .6775, .6898, .6970, .7005, .7050, .7110, .7130,
- .7165, .7180, .7120, .7070, .7040, .7030, .7148, .7300,
- .7440, .7535, .7615, .7640, .7533, .7450, .7353, .7290,
- .7285, .7310, .7328, .7340, .7435, .7495, .7540, .7580,
- .7618, .7680, .7720, .7790, .7815, .7850, .7900, .7930,
- .7918, .7915, .7950, .7980, .8018, .8060, .8133, .8200,
- .8275, .8315, .8370, .8420, .8485, .8545, .8605, .8680,
- .8723, .8795, .8853, .8920, .8945, .8960, .8945, .8940,
- .8943, .8955, .8975, .9000, .9033, .9035, .9023, .9000,
- .8968, .8935, .8828, .8790, .8783, .8730, .8760, .8800,
- .8813, .8865, .8910, .8930, .9035, .9105, .9183, .9200,
- .9175, .9160, .9183, .9180, .9168, .9155, .9173, .9270,
- .9290, .9375, .9497, .9570, .9638, .9695, .9715, .9770,
- .9795, .9840, .9908, .9970, .9985, .9980, .9953, .9940,
- .9920, .9930, .9925, .9870, .9755, .9650, .9583, .9490,
- .9348, .9240, .9133, .9070, .9053, .9085, .9193, .9400,
- .9658, .9780, .9625, .8950, .7520, .5715, .3962, .2580,
- .1675, .1080, .0687, .0440
+ static const float sr7[175] = {
+ .0000, .0000, .0027, .0175, .0563, .1500, .3285, .5015,
+ .5845, .5990, .6018, .6095, .6142, .6100, .6035, .6035,
+ .6118, .6270, .6385, .6445, .6438, .6320, .6260, .6245,
+ .6320, .6420, .6593, .6775, .6897, .6970, .7005, .7050,
+ .7110, .7130, .7165, .7180, .7120, .7070, .7040, .7030,
+ .7147, .7300, .7440, .7535, .7615, .7640, .7532, .7450,
+ .7352, .7290, .7285, .7310, .7328, .7340, .7435, .7495,
+ .7540, .7580, .7617, .7680, .7720, .7790, .7815, .7850,
+ .7900, .7930, .7917, .7915, .7950, .7980, .8017, .8060,
+ .8133, .8200, .8275, .8315, .8370, .8420, .8485, .8545,
+ .8605, .8680, .8722, .8795, .8852, .8920, .8945, .8960,
+ .8945, .8940, .8942, .8955, .8975, .9000, .9032, .9035,
+ .9022, .9000, .8967, .8935, .8827, .8790, .8782, .8730,
+ .8760, .8800, .8812, .8865, .8910, .8930, .9035, .9105,
+ .9183, .9200, .9175, .9160, .9183, .9180, .9167, .9155,
+ .9173, .9270, .9290, .9375, .9497, .9570, .9637, .9695,
+ .9715, .9770, .9795, .9840, .9908, .9970, .9985, .9980,
+ .9952, .9940, .9920, .9930, .9925, .9870, .9755, .9650,
+ .9583, .9490, .9347, .9240, .9133, .9070, .9052, .9085,
+ .9193, .9400, .9657, .9780, .9625, .8950, .7520, .5715,
+ .3962, .2580, .1675, .1080, .0688, .0440, .0297, .0195,
+ .0130, .0080, .0055, .0035, .0023, .0020, .0010
- static const float wli[7] = { 0.4350, 0.5000, 0.6150, 0.7400, 1.5050, 2.0150, 0.5025 };
- static const float wls[7] = { 0.5200, 0.6225, 0.7025, 0.9125, 1.7925, 2.3800, 0.9100 };
+ static const float wli[7] = {0.4325, 0.4975, 0.6100, 0.7475, 1.5100, 1.9975, 0.4975};
+ static const float wls[7] = {0.5225, 0.6275, 0.7075, 0.9175, 1.7950, 2.3850, 0.9350};
- ffu.wlinf = wli[iwa-1];
- ffu.wlsup = wls[iwa-1];
+ ffu.wlinf = (float)wli[iwa-1];
+ ffu.wlsup = (float)wls[iwa-1];
int i;
- for(i = 0; i < 1501; i++) ffu.s[i] = 0;
+ for(i = 0; i < 1501; i++) ffu.s[i] = 0;
switch(iwa)
- case 1: for(i = 0; i < 35; i++) ffu.s[74+i] = sr1[i];
- break;
- case 2: for(i = 0; i < 50; i++) ffu.s[100+i] = sr2[i];
- break;
- case 3: for(i = 0; i < 36; i++) ffu.s[146+i] = sr3[i];
- break;
- case 4: for(i = 0; i < 70; i++) ffu.s[196+i] = sr4[i];
- break;
- case 5: for(i = 0; i < 116; i++) ffu.s[502+i] = sr5[i];
- break;
- case 6: for(i = 0; i < 147; i++) ffu.s[706+i] = sr6[i];
- break;
- case 7: for(i = 0; i < 164; i++) ffu.s[101+i] = sr7[i];
+ case 1: for(i = 0; i < 36; i++) ffu.s[73+i] = sr1[i];
+ break;
+ case 2: for(i = 0; i < 52; i++) ffu.s[99+i] = sr2[i];
+ break;
+ case 3: for(i = 0; i < 39; i++) ffu.s[144+i] = sr3[i];
+ break;
+ case 4: for(i = 0; i < 68; i++) ffu.s[199+i] = sr4[i];
+ break;
+ case 5: for(i = 0; i < 114; i++) ffu.s[504+i] = sr5[i];
+ break;
+ case 6: for(i = 0; i < 155; i++) ffu.s[699+i] = sr6[i];
+ break;
+ case 7: for(i = 0; i < 175; i++) ffu.s[99+i] = sr7[i];
+ break;
-float IWave::solirr(const float wl) const
+float IWave::solirr(const float fwl) const
/* si (in w/m2/micron) contains the values of the solar
irradiance between 0.25 and 4.0 microns, by step of 0.0025 m.
@@ -1687,7 +1689,7 @@
float pas = 0.0025;
- int iwl = (int)((wl - 0.250) / pas + 1.5);
+ int iwl = (int)((fwl - 0.250) / pas + 1.5);
if(iwl >= 0) return si[iwl-1];
@@ -1949,67 +1951,60 @@
void IWave::avnir(int iwa)
/* "band 1" of AVNIR */
- static const float sr1[65] = {
- .0000, .0000, .0000, .0008, .0017, .0049, .0080, .0186,
- .0293, .0776, .1260, .2609, .3958, .5315, .6672, .6947,
- .7223, .7262, .7300, .7272, .7245, .7717, .8189, .8502,
- .8815, .9068, .9322, .9496, .9669, .9708, .9747, .9873,
- 1.0000, .9849, .9699, .9507, .9316, .9365, .9415, .9632,
- .9849, .9600, .9351, .7552, .5754, .3911, .2068, .1361,
- .0655, .0440, .0226, .0150, .0075, .0046, .0018, .0009,
- .0000, .0000, .0000, .0000, .0000, .0000, .0000, .0000,
- .0000
+ static const float sr1[52] = {
+ .0008, .0017, .0049, .0080, .0186, .0293, .0776, .1260,
+ .2609, .3958, .5315, .6672, .6947, .7223, .7262, .7300,
+ .7272, .7245, .7717, .8189, .8502, .8815, .9068, .9322,
+ .9496, .9669, .9708, .9747, .9873, 1.0000, .9849, .9699,
+ .9507, .9316, .9365, .9415, .9632, .9849, .9600, .9351,
+ .7552, .5754, .3911, .2068, .1361, .0655, .0440, .0226,
+ .0150, .0075, .0046, .0018
/* "band 2" of AVNIR */
- static const float sr2[57] = {
- .0000, .0000, .0000, .0008, .0015, .0030, .0045, .0123,
- .0202, .0470, .0739, .1358, .1977, .3205, .4433, .5633,
- .6832, .7137, .7442, .7594, .7746, .8089, .8432, .8576,
- .8719, .8721, .8724, .8873, .9022, .9254, .9486, .9625,
- .9764, .9882, 1.0000, .9904, .9808, .9349, .8890, .8367,
- .7843, .7651, .7458, .7156, .6854, .5639, .4425, .3005,
- .1586, .0985, .0384, .0236, .0088, .0053, .0017, .0008,
- .0000
+ .0008, .0015, .0030, .0045, .0123, .0202, .0470, .0739,
+ .1358, .1977, .3205, .4433, .5633, .6832, .7137, .7442,
+ .7594, .7746, .8089, .8432, .8576, .8719, .8721, .8724,
+ .8873, .9022, .9254, .9486, .9625, .9764, .9882, 1.0000,
+ .9904, .9808, .9349, .8890, .8367, .7843, .7651, .7458,
+ .7156, .6854, .5639, .4425, .3005, .1586, .0985, .0384,
+ .0236, .0088, .0053, .0017
/* "band 3" of AVNIR */
- static const float sr3[81] = {
- .0000, .0000, .0000, .0000, .0000, .0000, .0000, .0008,
- .0016, .0025, .0034, .0043, .0051, .0075, .0099, .0126,
- .0153, .0228, .0304, .0462, .0620, .0995, .1370, .2107,
- .2844, .3857, .4871, .5747, .6624, .7198, .7771, .7896,
- .8021, .7991, .7960, .7989, .8017, .8312, .8606, .8982,
- .9359, .9592, .9825, .9912, 1.0000, .9931, .9862, .9568,
- .9275, .9046, .8818, .8607, .8395, .8344, .8293, .8215,
- .8136, .7470, .6804, .5481, .4158, .3100, .2043, .1471,
- .0898, .0634, .0369, .0273, .0177, .0135, .0093, .0076,
- .0060, .0045, .0030, .0023, .0015, .0016, .0016, .0008,
- .0000
+ static const float sr3[72] = {
+ .0008, .0016, .0025, .0034, .0043, .0051, .0075, .0099,
+ .0126, .0153, .0228, .0304, .0462, .0620, .0995, .1370,
+ .2107, .2844, .3857, .4871, .5747, .6624, .7198, .7771,
+ .7896, .8021, .7991, .7960, .7989, .8017, .8312, .8606,
+ .8982, .9359, .9592, .9825, .9912, 1.0000, .9931, .9862,
+ .9568, .9275, .9046, .8818, .8607, .8395, .8344, .8293,
+ .8215, .8136, .7470, .6804, .5481, .4158, .3100, .2043,
+ .1471, .0898, .0634, .0369, .0273, .0177, .0135, .0093,
+ .0076, .0060, .0045, .0030, .0023, .0015, .0016, .0016
/* "band 4" of AVNIR */
- static const float sr4[121] = {
- .0000, .0000, .0000, .0000, .0000, .0000, .0000, .0011,
- .0023, .0023, .0022, .0033, .0045, .0080, .0115, .0190,
- .0264, .0484, .0704, .1138, .1572, .2351, .3129, .4431,
- .5733, .7244, .8754, .9377, 1.0000, .9884, .9768, .9528,
- .9288, .9091, .8894, .8763, .8633, .8627, .8622, .8753,
- .8885, .9136, .9388, .9437, .9486, .9531, .9576, .9411,
- .9247, .8969, .8691, .8467, .8242, .7893, .7545, .7331,
- .7117, .6911, .6705, .6560, .6414, .6357, .6299, .6258,
- .6217, .6227, .6237, .6025, .5812, .5843, .5874, .5867,
- .5860, .5696, .5532, .5251, .4969, .4438, .3908, .3191,
- .2475, .1906, .1338, .1033, .0727, .0543, .0359, .0292,
- .0224, .0161, .0097, .0069, .0040, .0038, .0036, .0030,
- .0025, .0024, .0024, .0015, .0007, .0004, .0000, .0003,
- .0007, .0006, .0006, .0006, .0006, .0003, .0000, .0000,
- .0000
+ static const float sr4[102] = {
+ .0011, .0023, .0023, .0022, .0033, .0045, .0080, .0115,
+ .0190, .0264, .0484, .0704, .1138, .1572, .2351, .3129,
+ .4431, .5733, .7244, .8754, .9377, 1.0000, .9884, .9768,
+ .9528, .9288, .9091, .8894, .8763, .8633, .8627, .8622,
+ .8753, .8885, .9136, .9388, .9437, .9486, .9531, .9576,
+ .9411, .9247, .8969, .8691, .8467, .8242, .7893, .7545,
+ .7331, .7117, .6911, .6705, .6560, .6414, .6357, .6299,
+ .6258, .6217, .6227, .6237, .6025, .5812, .5843, .5874,
+ .5867, .5860, .5696, .5532, .5251, .4969, .4438, .3908,
+ .3191, .2475, .1906, .1338, .1033, .0727, .0543, .0359,
+ .0292, .0224, .0161, .0097, .0069, .0040, .0038, .0036,
+ .0030, .0025, .0024, .0024, .0015, .0007, .0004, .0000,
+ .0003, .0007, .0006, .0006, .0006, .0006
- static const float wli[4] = {0.390, 0.485, 0.545, 0.700};
- static const float wls[4] = {0.550, 0.625, 0.745, 1.000};
+ static const float wli[4] = {0.3975, 0.4925, 0.5625, 0.7175};
+ static const float wls[4] = {0.5275, 0.6225, 0.7425, 0.9725};
@@ -2019,13 +2014,13 @@
switch(iwa)
- case 1: for(i = 0; i < 65; i++) ffu.s[56+i] = sr1[i];
+ case 1: for(i = 0; i < 52; i++) ffu.s[59+i] = sr1[i];
break;
- case 2: for(i = 0; i < 57; i++) ffu.s[94+i] = sr2[i];
+ case 2: for(i = 0; i < 52; i++) ffu.s[97+i] = sr2[i];
break;
- case 3: for(i = 0; i < 81; i++) ffu.s[118+i] = sr3[i];
+ case 3: for(i = 0; i < 72; i++) ffu.s[125+i] = sr3[i];
break;
- case 4: for(i = 0; i < 121; i++) ffu.s[180+i] = sr4[i];
+ case 4: for(i = 0; i < 102; i++) ffu.s[187+i] = sr4[i];
break;
@@ -2036,124 +2031,124 @@
/* Ikonos Green of ikonos */
- static const float sr1[275] = {
- .0008, .0011, .0015, .0012, .0009, .0008, .0007, .0007,
- .0007, .0010, .0013, .0015, .0017, .0018, .0019, .0024,
- .0028, .0040, .0052, .0064, .0077, .0082, .0088, .0103,
- .0119, .0147, .0175, .0262, .0350, .0602, .0854, .1392,
- .1929, .2617, .3305, .3750, .4195, .4638, .5082, .5607,
- .6132, .6437, .6742, .6973, .7204, .7406, .7608, .7605,
- .7601, .7742, .7883, .8225, .8566, .8730, .8894, .9165,
- .9436, .9718, 1.0000, .9934, .9868, .9562, .9255, .8434,
- .7613, .6519, .5424, .4282, .3139, .2590, .2041, .1780,
- .1519, .1188, .0856, .0644, .0432, .0371, .0310, .0288,
- .0266, .0244, .0222, .0221, .0221, .0242, .0262, .0279,
- .0296, .0283, .0270, .0248, .0226, .0240, .0254, .0280,
- .0305, .0289, .0274, .0243, .0213, .0215, .0217, .0257,
- .0296, .0319, .0342, .0306, .0271, .0233, .0195, .0195,
- .0195, .0193, .0190, .0165, .0140, .0107, .0073, .0067,
- .0060, .0056, .0051, .0065, .0079, .0101, .0123, .0161,
- .0200, .0210, .0221, .0214, .0208, .0199, .0190, .0172,
- .0155, .0126, .0097, .0083, .0068, .0059, .0049, .0052,
- .0054, .0085, .0115, .0169, .0222, .0231, .0240, .0180,
- .0121, .0080, .0040, .0031, .0022, .0024, .0026, .0024,
- .0023, .0029, .0035, .0030, .0025, .0024, .0023, .0032,
- .0040, .0038, .0036, .0032, .0027, .0025, .0024, .0025,
- .0026, .0024, .0022, .0019, .0016, .0016, .0016, .0018,
- .0020, .0020, .0020, .0023, .0025, .0031, .0036, .0046,
- .0056, .0061, .0066, .0071, .0075, .0078, .0080, .0087,
- .0095, .0089, .0083, .0085, .0088, .0090, .0093, .0100,
- .0107, .0116, .0125, .0128, .0131, .0131, .0131, .0125,
- .0119, .0112, .0105, .0100, .0095, .0091, .0088, .0086,
- .0084, .0083, .0082, .0081, .0080, .0082, .0084, .0082,
- .0081, .0081, .0080, .0080, .0080, .0074, .0069, .0062,
- .0054, .0051, .0048, .0046, .0045, .0043, .0041, .0038,
- .0036, .0035, .0035, .0034, .0033, .0030, .0028, .0028,
- .0028, .0026, .0024, .0024, .0023, .0025, .0026, .0026,
- .0026, .0026, .0026, .0021, .0016, .0018, .0019, .0022,
- .0024, .0019, .0013
+ static const float sr1[274] = {
+ .0008, .0011, .0015, .0012, .0009, .0008, .0007, .0007,
+ .0007, .0010, .0013, .0015, .0017, .0018, .0019, .0024,
+ .0028, .0040, .0052, .0064, .0077, .0082, .0088, .0103,
+ .0119, .0147, .0175, .0262, .0350, .0602, .0854, .1392,
+ .1929, .2617, .3305, .3750, .4195, .4638, .5082, .5607,
+ .6132, .6437, .6742, .6973, .7204, .7406, .7608, .7605,
+ .7601, .7742, .7883, .8225, .8566, .8730, .8894, .9165,
+ .9436, .9718, 1.0000, .9934, .9868, .9562, .9255, .8434,
+ .7613, .6519, .5424, .4282, .3139, .2590, .2041, .1780,
+ .1519, .1188, .0856, .0644, .0432, .0371, .0310, .0288,
+ .0266, .0244, .0222, .0221, .0221, .0242, .0262, .0279,
+ .0296, .0283, .0270, .0248, .0226, .0240, .0254, .0280,
+ .0305, .0289, .0274, .0243, .0213, .0215, .0217, .0257,
+ .0296, .0319, .0342, .0306, .0271, .0233, .0195, .0195,
+ .0195, .0193, .0190, .0165, .0140, .0107, .0073, .0067,
+ .0060, .0056, .0051, .0065, .0079, .0101, .0123, .0161,
+ .0200, .0210, .0221, .0214, .0208, .0199, .0190, .0172,
+ .0155, .0126, .0097, .0083, .0068, .0059, .0049, .0052,
+ .0054, .0085, .0115, .0169, .0222, .0231, .0240, .0180,
+ .0121, .0080, .0040, .0031, .0022, .0024, .0026, .0024,
+ .0023, .0029, .0035, .0030, .0025, .0024, .0023, .0032,
+ .0040, .0038, .0036, .0032, .0027, .0025, .0024, .0025,
+ .0026, .0024, .0022, .0019, .0016, .0016, .0016, .0018,
+ .0020, .0020, .0020, .0023, .0025, .0031, .0036, .0046,
+ .0056, .0061, .0066, .0071, .0075, .0078, .0080, .0087,
+ .0095, .0089, .0083, .0085, .0088, .0090, .0093, .0100,
+ .0107, .0116, .0125, .0128, .0131, .0131, .0131, .0125,
+ .0119, .0112, .0105, .0100, .0095, .0091, .0088, .0086,
+ .0084, .0083, .0082, .0081, .0080, .0082, .0084, .0082,
+ .0081, .0081, .0080, .0080, .0080, .0074, .0069, .0062,
+ .0054, .0051, .0048, .0046, .0045, .0043, .0041, .0038,
+ .0036, .0035, .0035, .0034, .0033, .0030, .0028, .0028,
+ .0028, .0026, .0024, .0024, .0023, .0025, .0026, .0026,
+ .0026, .0026, .0026, .0021, .0016, .0018, .0019, .0022,
+ .0024, .0019
/* Ikonos Red of ikonos */
- static const float sr2[275] = {
- .0006, .0007, .0008, .0008, .0007, .0008, .0008, .0007,
- .0006, .0007, .0008, .0007, .0006, .0008, .0009, .0007,
- .0006, .0010, .0013, .0013, .0012, .0019, .0027, .0018,
- .0010, .0011, .0013, .0016, .0019, .0023, .0027, .0030,
- .0034, .0037, .0040, .0049, .0057, .0074, .0091, .0102,
- .0113, .0113, .0113, .0122, .0130, .0151, .0172, .0208,
- .0245, .0306, .0367, .0435, .0503, .0565, .0628, .0861,
- .1094, .1512, .1931, .2421, .2911, .3653, .4396, .5451,
- .6507, .7286, .8066, .8391, .8717, .8801, .8884, .8891,
- .8898, .8824, .8749, .8635, .8521, .8722, .8923, .9450,
- .9977, .9819, .9661, .9369, .9077, .9005, .8932, .9195,
- .9459, .9715, .9972, .9785, .9598, .9186, .8774, .8136,
- .7497, .6259, .5020, .3926, .2832, .2215, .1599, .1334,
- .1068, .0947, .0825, .0732, .0640, .0557, .0474, .0397,
- .0320, .0273, .0227, .0196, .0166, .0155, .0145, .0147,
- .0148, .0155, .0162, .0174, .0186, .0193, .0199, .0193,
- .0188, .0170, .0152, .0138, .0125, .0122, .0119, .0114,
- .0109, .0122, .0135, .0150, .0165, .0174, .0183, .0171,
- .0159, .0135, .0112, .0088, .0063, .0059, .0055, .0044,
- .0034, .0036, .0039, .0037, .0035, .0032, .0030, .0030,
- .0031, .0027, .0023, .0029, .0034, .0035, .0036, .0044,
- .0053, .0059, .0065, .0068, .0072, .0080, .0089, .0092,
- .0095, .0088, .0080, .0075, .0070, .0067, .0064, .0063,
- .0061, .0059, .0056, .0054, .0053, .0057, .0061, .0068,
- .0074, .0070, .0067, .0067, .0067, .0081, .0094, .0111,
- .0128, .0135, .0143, .0151, .0159, .0165, .0171, .0172,
- .0172, .0168, .0163, .0158, .0152, .0143, .0134, .0127,
- .0120, .0113, .0106, .0103, .0100, .0096, .0092, .0095,
- .0098, .0093, .0089, .0087, .0084, .0081, .0078, .0077,
- .0075, .0072, .0070, .0064, .0059, .0056, .0054, .0050,
- .0046, .0043, .0039, .0038, .0036, .0034, .0033, .0031,
- .0029, .0029, .0028, .0028, .0028, .0025, .0022, .0024,
- .0025, .0024, .0022, .0024, .0025, .0023, .0021, .0019,
- .0017, .0019, .0021, .0021, .0020, .0021, .0022, .0018,
- .0014, .0015, .0016
+ static const float sr2[274] = {
+ .0006, .0007, .0008, .0008, .0007, .0008, .0008, .0007,
+ .0006, .0007, .0008, .0007, .0006, .0008, .0009, .0007,
+ .0006, .0010, .0013, .0013, .0012, .0019, .0027, .0018,
+ .0010, .0011, .0013, .0016, .0019, .0023, .0027, .0030,
+ .0034, .0037, .0040, .0049, .0057, .0074, .0091, .0102,
+ .0113, .0113, .0113, .0122, .0130, .0151, .0172, .0208,
+ .0245, .0306, .0367, .0435, .0503, .0565, .0628, .0861,
+ .1094, .1512, .1931, .2421, .2911, .3653, .4396, .5451,
+ .6507, .7286, .8066, .8391, .8717, .8801, .8884, .8891,
+ .8898, .8824, .8749, .8635, .8521, .8722, .8923, .9450,
+ .9977, .9819, .9661, .9369, .9077, .9005, .8932, .9195,
+ .9459, .9715, .9972, .9785, .9598, .9186, .8774, .8136,
+ .7497, .6259, .5020, .3926, .2832, .2215, .1599, .1334,
+ .1068, .0947, .0825, .0732, .0640, .0557, .0474, .0397,
+ .0320, .0273, .0227, .0196, .0166, .0155, .0145, .0147,
+ .0148, .0155, .0162, .0174, .0186, .0193, .0199, .0193,
+ .0188, .0170, .0152, .0138, .0125, .0122, .0119, .0114,
+ .0109, .0122, .0135, .0150, .0165, .0174, .0183, .0171,
+ .0159, .0135, .0112, .0088, .0063, .0059, .0055, .0044,
+ .0034, .0036, .0039, .0037, .0035, .0032, .0030, .0030,
+ .0031, .0027, .0023, .0029, .0034, .0035, .0036, .0044,
+ .0053, .0059, .0065, .0068, .0072, .0080, .0089, .0092,
+ .0095, .0088, .0080, .0075, .0070, .0067, .0064, .0063,
+ .0061, .0059, .0056, .0054, .0053, .0057, .0061, .0068,
+ .0074, .0070, .0067, .0067, .0067, .0081, .0094, .0111,
+ .0128, .0135, .0143, .0151, .0159, .0165, .0171, .0172,
+ .0172, .0168, .0163, .0158, .0152, .0143, .0134, .0127,
+ .0120, .0113, .0106, .0103, .0100, .0096, .0092, .0095,
+ .0098, .0093, .0089, .0087, .0084, .0081, .0078, .0077,
+ .0075, .0072, .0070, .0064, .0059, .0056, .0054, .0050,
+ .0046, .0043, .0039, .0038, .0036, .0034, .0033, .0031,
+ .0029, .0029, .0028, .0028, .0028, .0025, .0022, .0024,
+ .0025, .0024, .0022, .0024, .0025, .0023, .0021, .0019,
+ .0017, .0019, .0021, .0021, .0020, .0021, .0022, .0018,
+ .0014, .0015
/* Ikonos NIR of ikonos */
- static const float sr3[275] = {
- .0000, .0003, .0005, .0004, .0004, .0005, .0006, .0005,
- .0003, .0006, .0008, .0007, .0007, .0005, .0004, .0009,
- .0015, .0018, .0020, .0025, .0030, .0033, .0035, .0038,
- .0040, .0041, .0041, .0060, .0078, .0081, .0084, .0083,
- .0082, .0066, .0051, .0038, .0026, .0035, .0043, .0049,
- .0055, .0055, .0055, .0042, .0029, .0023, .0017, .0016,
- .0015, .0026, .0036, .0040, .0043, .0034, .0025, .0023,
- .0020, .0017, .0013, .0014, .0015, .0015, .0015, .0018,
- .0021, .0022, .0024, .0025, .0027, .0030, .0034, .0031,
- .0029, .0029, .0029, .0035, .0041, .0050, .0060, .0066,
- .0072, .0083, .0093, .0093, .0093, .0090, .0087, .0091,
- .0095, .0099, .0103, .0118, .0133, .0169, .0204, .0244,
- .0285, .0316, .0347, .0388, .0428, .0502, .0575, .0715,
- .0855, .1052, .1249, .1506, .1764, .2174, .2584, .3386,
- .4188, .5285, .6381, .7213, .8045, .8414, .8784, .8990,
- .9196, .9364, .9532, .9545, .9559, .9424, .9289, .9339,
- .9389, .9628, .9866, .9917, .9968, .9524, .9079, .8388,
- .7698, .6808, .5919, .5067, .4215, .3634, .3053, .2658,
- .2262, .1923, .1583, .1315, .1046, .0860, .0674, .0560,
- .0447, .0373, .0299, .0269, .0239, .0230, .0220, .0202,
- .0184, .0171, .0159, .0161, .0162, .0159, .0157, .0161,
- .0165, .0168, .0171, .0167, .0163, .0142, .0121, .0106,
- .0091, .0079, .0068, .0065, .0062, .0059, .0056, .0049,
- .0042, .0042, .0042, .0046, .0050, .0045, .0040, .0040,
- .0040, .0033, .0027, .0028, .0030, .0028, .0025, .0029,
- .0033, .0029, .0026, .0026, .0026, .0027, .0028, .0027,
- .0027, .0028, .0028, .0027, .0026, .0026, .0026, .0025,
- .0025, .0024, .0024, .0024, .0023, .0026, .0029, .0028,
- .0027, .0029, .0031, .0035, .0039, .0040, .0040, .0040,
- .0040, .0037, .0035, .0031, .0026, .0024, .0022, .0019,
- .0016, .0015, .0014, .0014, .0013, .0013, .0014, .0012,
- .0011, .0011, .0012, .0012, .0012, .0011, .0010, .0013,
- .0016, .0013, .0010, .0012, .0013, .0014, .0014, .0022,
- .0029, .0023, .0018, .0020, .0023, .0018, .0013, .0011,
- .0009, .0004, .0000
+ static const float sr3[272] = {
+ .0003, .0005, .0004, .0004, .0005, .0006, .0005, .0003,
+ .0006, .0008, .0007, .0007, .0005, .0004, .0009, .0015,
+ .0018, .0020, .0025, .0030, .0033, .0035, .0038, .0040,
+ .0041, .0041, .0060, .0078, .0081, .0084, .0083, .0082,
+ .0066, .0051, .0038, .0026, .0035, .0043, .0049, .0055,
+ .0055, .0055, .0042, .0029, .0023, .0017, .0016, .0015,
+ .0026, .0036, .0040, .0043, .0034, .0025, .0023, .0020,
+ .0017, .0013, .0014, .0015, .0015, .0015, .0018, .0021,
+ .0022, .0024, .0025, .0027, .0030, .0034, .0031, .0029,
+ .0029, .0029, .0035, .0041, .0050, .0060, .0066, .0072,
+ .0083, .0093, .0093, .0093, .0090, .0087, .0091, .0095,
+ .0099, .0103, .0118, .0133, .0169, .0204, .0244, .0285,
+ .0316, .0347, .0388, .0428, .0502, .0575, .0715, .0855,
+ .1052, .1249, .1506, .1764, .2174, .2584, .3386, .4188,
+ .5285, .6381, .7213, .8045, .8414, .8784, .8990, .9196,
+ .9364, .9532, .9545, .9559, .9424, .9289, .9339, .9389,
+ .9628, .9866, .9917, .9968, .9524, .9079, .8388, .7698,
+ .6808, .5919, .5067, .4215, .3634, .3053, .2658, .2262,
+ .1923, .1583, .1315, .1046, .0860, .0674, .0560, .0447,
+ .0373, .0299, .0269, .0239, .0230, .0220, .0202, .0184,
+ .0171, .0159, .0161, .0162, .0159, .0157, .0161, .0165,
+ .0168, .0171, .0167, .0163, .0142, .0121, .0106, .0091,
+ .0079, .0068, .0065, .0062, .0059, .0056, .0049, .0042,
+ .0042, .0042, .0046, .0050, .0045, .0040, .0040, .0040,
+ .0033, .0027, .0028, .0030, .0028, .0025, .0029, .0033,
+ .0029, .0026, .0026, .0026, .0027, .0028, .0027, .0027,
+ .0028, .0028, .0027, .0026, .0026, .0026, .0025, .0025,
+ .0024, .0024, .0024, .0023, .0026, .0029, .0028, .0027,
+ .0029, .0031, .0035, .0039, .0040, .0040, .0040, .0040,
+ .0037, .0035, .0031, .0026, .0024, .0022, .0019, .0016,
+ .0015, .0014, .0014, .0013, .0013, .0014, .0012, .0011,
+ .0011, .0012, .0012, .0012, .0011, .0010, .0013, .0016,
+ .0013, .0010, .0012, .0013, .0014, .0014, .0022, .0029,
+ .0023, .0018, .0020, .0023, .0018, .0013, .0011, .0009
- static const float wli[3] = {0.350, 0.350, 0.350};
- static const float wls[3] = {1.035, 1.035, 1.035};
+ static const float wli[3] = {0.3500, 0.3500, 0.3525};
+ static const float wls[3] = {1.0350, 1.0350, 1.0325};
@@ -2163,11 +2158,11 @@
switch(iwa)
- case 1: for(i = 0; i < 275; i++) ffu.s[40+i] = sr1[i];
+ case 1: for(i = 0; i < 274; i++) ffu.s[40+i] = sr1[i];
break;
- case 2: for(i = 0; i < 275; i++) ffu.s[40+i] = sr2[i];
+ case 2: for(i = 0; i < 274; i++) ffu.s[40+i] = sr2[i];
break;
- case 3: for(i = 0; i < 275; i++) ffu.s[40+i] = sr3[i];
+ case 3: for(i = 0; i < 272; i++) ffu.s[41+i] = sr3[i];
break;
@@ -2178,113 +2173,115 @@
/* "Blue" of rapideye */
- static const float sr1[128] = {
- .0020, .0023, .0026, .0029, .0018, .0014, .0010, .0095,
- .3210, .7250, .7400, .7590, .7700, .7810, .7840, .7935,
- .7960, .8005, .8060, .8040, .8070, .8170, .8200, .8275,
- .8400, .8470, .8620, .8765, .8860, .9105, .9280, .9415,
- .9690, .9685, 1.0000, .9875, .4370, .0190, .0010, .0010,
- .0010, .0010, .0010, .0010, .0010, .0010, .0010, .0010,
+ static const float sr1[129] = {
+ .0020, .0000, .0000, .0015, .0000, .0000, .0010, .0095,
+ .3210, .7250, .7400, .7590, .7700, .7810, .7840, .7935,
+ .7960, .8005, .8060, .8040, .8070, .8170, .8200, .8275,
+ .8400, .8470, .8620, .8765, .8860, .9105, .9280, .9415,
+ .9690, .9685, 1.0000, .9875, .4370, .0190, .0010, .0000,
+ .0000, .0000, .0000, .0000, .0000, .0000, .0000, .0000,
+ .0000, .0000, .0000, .0000, .0000, .0000, .0000, .0005,
+ .0000
/* "Green" of rapideye */
- static const float sr2[181] = {
- .0010, .0010, .0010, .0010, .0010, .0010, .0010, .0015,
- .0030, .0015, .0340, .0010, .0010, .0010, .0010, .0010,
- .0010, .0010, .0270, .0019, .0018, .0017, .0015, .0014,
- .0013, .0011, .0010, .0020, .0070, .0400, .2720, .8260,
- .8640, .8750, .8730, .8730, .8810, .8825, .8800, .8845,
- .8940, .8985, .8980, .9075, .9200, .9275, .9330, .9440,
- .9520, .9575, .9700, .9765, .9740, .9855, .9930, .9830,
- 1.0000, .9730, .8900, .0825, .0060, .0010, .0010, .0010,
+ static const float sr2[184] = {
+ .0000, .0035, .0020, .0030, .0080, .0000, .0000, .0000,
+ .0000, .0000, .0000, .0005, .0020, .0000, .0000, .0000,
+ .0000, .0000, .0000, .0000, .0010, .0030, .0130, .0875,
+ .5390, .8690, .8680, .8765, .8710, .8755, .8820, .8815,
+ .8810, .8885, .8970, .8985, .9010, .9125, .9240, .9290,
+ .9360, .9475, .9530, .9625, .9740, .9755, .9760, .9910,
+ .9880, .9880, .9940, .9845, .4170, .0265, .0020, .0005,
+ .0000, .0000, .0010, .0010, .0010, .0005, .0000, .0000,
+ .0000, .0000, .0000, .0000, .0000, .0000, .0010, .0000
/* "Red" of rapideye */
- static const float sr3[94] = {
- .0010, .0011, .0012, .0013, .0014, .0015, .0016, .0017,
- .0018, .0019, .0020, .0019, .0017, .0016, .0014, .0012,
- .0011, .0010, .0010, .0010, .0010, .0010, .0010, .0010,
- .0010, .0010, .0010, .0010, .0020, .0019, .0018, .0018,
- .0017, .0016, .0015, .0014, .0013, .0013, .0012, .0011,
- .0010, .0025, .0090, .0620, .4370, .8595, .8540, .8785,
- .8810, .8875, .9020, .9105, .9150, .9255, .9390, .9490,
- .9580, .9645, .9700, .9785, .9890, .9900, .9850, .9970,
- .9890, .9940, .4630, .0430, .0050, .0010
+ static const float sr3[96] = {
+ .0000, .0010, .0000, .0000, .0000, .0000, .0000, .0000,
+ .0000, .0000, .0010, .0000, .0000, .0000, .0000, .0000,
+ .0000, .0000, .0005, .0000, .0000, .0000, .0000, .0000,
+ .0005, .0000, .0000, .0000, .0000, .0020, .0000, .0000,
+ .0000, .0010, .0025, .0090, .0620, .4370, .8595, .8540,
+ .8785, .8810, .8875, .9020, .9105, .9150, .9255, .9390,
+ .9490, .9580, .9645, .9700, .9785, .9890, .9900, .9850,
+ .9970, .9890, .9940, .4630, .0430, .0050, .0010, .0000
/* "RedEdge " of rapideye */
- static const float sr4[98] = {
- .0270, .0247, .0224, .0200, .0177, .0154, .0131, .0107,
- .0084, .0061, .0038, .0015, .0010, .0010, .0010, .0010,
- .0010, .0010, .0010, .0010, .0017, .0025, .0034, .0042,
- .0051, .0059, .0068, .0076, .0085, .0093, .0101, .0110,
- .0118, .0127, .0135, .0144, .0152, .0161, .0169, .0178,
- .0186, .0195, .0203, .0212, .0220, .0195, .0170, .0145,
- .0120, .0095, .0070, .0045, .0020, .0016, .0047, .0079,
- .0110, .0141, .0010, .0010, .0010, .0010, .0010, .0010,
- .0020, .0055, .0210, .1085, .4910, .9490, .9980, .9995,
- .9980, .9915, .9870, .9855, .9820, .9740, .9660, .9640,
- .9610, .9455, .9390, .8980, .4250, .0940, .0200, .0055,
- .0020, .0010
+ static const float sr4[100] = {
+ .0000, .0270, .0000, .0000, .0000, .0000, .0000, .0000,
+ .0000, .0000, .0000, .0000, .0005, .0000, .0005, .0010,
+ .0000, .0000, .0000, .0000, .0005, .0000, .0000, .0000,
+ .0000, .0000, .0000, .0000, .0000, .0220, .0000, .0000,
+ .0000, .0000, .0000, .0000, .0000, .0000, .0005, .0000,
+ .0000, .0000, .0000, .0010, .0000, .0000, .0000, .0000,
+ .0010, .0020, .0055, .0210, .1085, .4910, .9490, .9980,
+ .9995, .9980, .9915, .9870, .9855, .9820, .9740, .9660,
+ .9640, .9610, .9455, .9390, .8980, .4250, .0940, .0200,
+ .0055, .0020, .0010, .0000
/* "NIR " of rapideye */
- static const float sr5[160] = {
- .0010, .0010, .0010, .0010, .0010, .0010, .0010, .0012,
- .0014, .0015, .0017, .0019, .0110, .0010, .0010, .0010,
- .0010, .0010, .0010, .0010, .0013, .0016, .0019, .0020,
- .0019, .0018, .0017, .0016, .0015, .0014, .0013, .0012,
- .0011, .0010, .0010, .0011, .0012, .0013, .0014, .0015,
- .0016, .0016, .0017, .0018, .0019, .0020, .0010, .0010,
- .0010, .0010, .0010, .0010, .0010, .0010, .0030, .0010,
- .0010, .0010, .0010, .0010, .0010, .0010, .0020, .0010,
- .0010, .0015, .0030, .0010, .0010, .0010, .0010, .0010,
- .0010, .0010, .0010, .0010, .0010, .0015, .0030, .0055,
- .0120, .0275, .0680, .1920, .4970, .8825, 1.0000, .9775,
- .9670, .9760, .9830, .9795, .9700, .9620, .9580, .9575,
- .9580, .9585, .9560, .9535, .9480, .9425, .9370, .9320,
- .9280, .9270, .9260, .9255, .9230, .9165, .9060, .8965,
- .8890, .8845, .8820, .8735, .8570, .8400, .8400, .8135,
- .5820, .2440, .0800, .0285, .0110, .0050, .0020, .0010,
+ static const float sr5[162] = {
+ .0000, .0000, .0000, .0000, .0000, .0000, .0000, .0010,
+ .0000, .0000, .0000, .0000, .0000, .0110, .0000, .0000,
+ .0000, .0000, .0000, .0000, .0010, .0000, .0000, .0000,
+ .0010, .0000, .0000, .0000, .0000, .0000, .0000, .0000,
+ .0000, .0000, .0000, .0000, .0000, .0000, .0010, .0010,
+ .0000, .0000, .0000, .0000, .0000, .0000, .0005, .0030,
+ .0010, .0000, .0000, .0000, .0000, .0000, .0010, .0020,
+ .0000, .0000, .0015, .0030, .0000, .0000, .0000, .0000,
+ .0000, .0000, .0000, .0000, .0005, .0010, .0015, .0030,
+ .0055, .0120, .0275, .0680, .1920, .4970, .8825, 1.0000,
+ .9775, .9670, .9760, .9830, .9795, .9700, .9620, .9580,
+ .9575, .9580, .9585, .9560, .9535, .9480, .9425, .9370,
+ .9320, .9280, .9270, .9260, .9255, .9230, .9165, .9060,
+ .8965, .8890, .8845, .8820, .8735, .8570, .8400, .8400,
+ .8135, .5820, .2440, .0800, .0285, .0110, .0050, .0020,
+ .0010, .0010
- static const float wli[5] = {0.420, 0.424, 0.460, 0.500, 0.470};
- static const float wls[5] = {0.739, 0.876, 0.693, 0.743, 0.870};
+ static const float wli[5] = {0.4200, 0.4200, 0.4575, 0.4975, 0.4675};
+ static const float wls[5] = {0.7425, 0.8800, 0.6975, 0.7475, 0.8725};
@@ -2294,15 +2291,15 @@
switch(iwa)
- case 1: for(i = 0; i < 128; i++) ffu.s[68+i] = sr1[i];
+ case 1: for(i = 0; i < 129; i++) ffu.s[68+i] = sr1[i];
break;
- case 2: for(i = 0; i < 181; i++) ffu.s[69+i] = sr2[i];
+ case 2: for(i = 0; i < 184; i++) ffu.s[68+i] = sr2[i];
break;
- case 3: for(i = 0; i < 94; i++) ffu.s[84+i] = sr3[i];
+ case 3: for(i = 0; i < 96; i++) ffu.s[83+i] = sr3[i];
break;
- case 4: for(i = 0; i < 98; i++) ffu.s[100+i] = sr4[i];
+ case 4: for(i = 0; i < 100; i++) ffu.s[99+i] = sr4[i];
break;
- case 5: for(i = 0; i < 160; i++) ffu.s[88+i] = sr5[i];
+ case 5: for(i = 0; i < 162; i++) ffu.s[87+i] = sr5[i];
break;
@@ -2312,77 +2309,77 @@
void IWave::vgt1_spot4(int iwa)
- /* B0 of VGT1-spot4 */
- static const float sr1[41] = {
- .0001, .0003, .0005, .0007, .0010, .0013, .0028, .0050,
- .0182, .0377, .0828, .1423, .2234, .3168, .4108, .5052,
- .5925, .6759, .7509, .8212, .8815, .9361, .9699, .9920,
- .9907, .9761, .9528, .9248, .8811, .8287, .7223, .5857,
- .4394, .2876, .1820, .1024, .0579, .0331, .0196, .0125,
- .0000
+ /* B0 of VGT1_spot4 */
+ static const float sr1[40] = {
+ .0001, .0003, .0005, .0007, .0010, .0013, .0028, .0050,
+ .0182, .0377, .0828, .1423, .2234, .3168, .4108, .5052,
+ .5925, .6759, .7509, .8212, .8815, .9361, .9699, .9920,
+ .9907, .9761, .9528, .9248, .8811, .8287, .7223, .5857,
+ .4394, .2876, .1820, .1024, .0579, .0331, .0196, .0125
- /* B2 of VGT1-spot4 */
+ /* B2 of VGT1_spot4 */
static const float sr2[82] = {
- .0017, .0017, .0016, .0016, .0016, .0024, .0031, .0039,
- .0046, .0439, .0832, .1225, .1618, .2737, .3856, .4975,
- .6094, .6615, .7136, .7657, .8178, .8278, .8377, .8477,
- .8577, .8673, .8769, .8865, .8961, .9088, .9214, .9341,
- .9468, .9595, .9722, .9849, .9976, .9895, .9815, .9734,
- .9653, .9169, .8685, .8201, .7717, .6989, .6260, .5532,
- .4804, .4243, .3681, .3120, .2559, .2229, .1899, .1569,
- .1239, .1063, .0887, .0712, .0536, .0454, .0372, .0289,
- .0207, .0175, .0143, .0111, .0079, .0069, .0060, .0050,
- .0040, .0034, .0027, .0021, .0015, .0015, .0015, .0015,
- .0015, .0000
+ .0000, .0017, .0017, .0016, .0016, .0016, .0024, .0031,
+ .0039, .0046, .0439, .0832, .1225, .1618, .2737, .3856,
+ .4975, .6094, .6615, .7136, .7657, .8178, .8278, .8377,
+ .8477, .8577, .8673, .8769, .8865, .8961, .9088, .9214,
+ .9341, .9468, .9595, .9722, .9849, .9976, .9895, .9815,
+ .9734, .9653, .9169, .8685, .8201, .7717, .6989, .6260,
+ .5532, .4804, .4243, .3681, .3120, .2559, .2229, .1899,
+ .1569, .1239, .1063, .0887, .0712, .0536, .0454, .0372,
+ .0289, .0207, .0175, .0143, .0111, .0079, .0069, .0060,
+ .0050, .0040, .0034, .0027, .0021, .0015, .0015, .0015,
+ .0015, .0015
- /* B3 of VGT1-spot4 */
- static const float sr3[133] = {
- .0007, .0008, .0008, .0009, .0010, .0011, .0013, .0014,
- .0015, .0019, .0022, .0026, .0030, .0051, .0072, .0092,
- .0113, .0210, .0308, .0406, .0503, .0806, .1109, .1411,
- .1714, .2271, .2828, .3385, .3942, .4584, .5226, .5869,
- .6511, .6966, .7421, .7876, .8331, .8607, .8883, .9159,
- .9435, .9552, .9668, .9785, .9902, .9927, .9951, .9976,
- 1.0000, .9999, .9997, .9996, .9994, .9984, .9974, .9964,
- .9954, .9927, .9900, .9873, .9846, .9766, .9686, .9606,
- .9526, .9445, .9365, .9284, .9203, .9008, .8813, .8618,
- .8423, .7897, .7370, .6844, .6318, .5584, .4849, .4114,
- .3380, .2893, .2407, .1920, .1434, .1222, .1010, .0798,
- .0586, .0505, .0425, .0345, .0264, .0229, .0194, .0159,
- .0124, .0111, .0098, .0085, .0072, .0065, .0057, .0050,
- .0042, .0038, .0034, .0031, .0027, .0024, .0021, .0017,
- .0014, .0014, .0014, .0013, .0013, .0013, .0013, .0012,
- .0012, .0012, .0011, .0011, .0011, .0010, .0009, .0009,
- .0008, .0007, .0006, .0006, .0005
+ /* B3 of VGT1_spot4 */
+ static const float sr3[134] = {
+ .0000, .0007, .0008, .0008, .0009, .0010, .0011, .0013,
+ .0014, .0015, .0019, .0022, .0026, .0030, .0051, .0072,
+ .0092, .0113, .0210, .0308, .0406, .0503, .0806, .1109,
+ .1411, .1714, .2271, .2828, .3385, .3942, .4584, .5226,
+ .5869, .6511, .6966, .7421, .7876, .8331, .8607, .8883,
+ .9159, .9435, .9552, .9668, .9785, .9902, .9927, .9951,
+ .9976, 1.0000, .9999, .9997, .9996, .9994, .9984, .9974,
+ .9964, .9954, .9927, .9900, .9873, .9846, .9766, .9686,
+ .9606, .9526, .9445, .9365, .9284, .9203, .9008, .8813,
+ .8618, .8423, .7897, .7370, .6844, .6318, .5584, .4849,
+ .4114, .3380, .2893, .2407, .1920, .1434, .1222, .1010,
+ .0798, .0586, .0505, .0425, .0345, .0264, .0229, .0194,
+ .0159, .0124, .0111, .0098, .0085, .0072, .0065, .0057,
+ .0050, .0042, .0038, .0034, .0031, .0027, .0024, .0021,
+ .0017, .0014, .0014, .0014, .0013, .0013, .0013, .0013,
+ .0012, .0012, .0012, .0011, .0011, .0011, .0010, .0009,
+ .0009, .0008, .0007, .0006, .0006, .0005
- /* MIR of VGT1-spot4 */
+ /* MIR of VGT1_spot4 */
static const float sr4[141] = {
- .0010, .0010, .0010, .0010, .0010, .0011, .0011, .0012,
- .0013, .0014, .0014, .0015, .0016, .0016, .0017, .0018,
- .0018, .0019, .0021, .0022, .0024, .0026, .0028, .0030,
- .0032, .0035, .0038, .0041, .0044, .0050, .0055, .0060,
- .0066, .0075, .0083, .0092, .0101, .0118, .0136, .0154,
- .0171, .0203, .0235, .0267, .0299, .0366, .0433, .0501,
- .0568, .0708, .0848, .0989, .1129, .1406, .1684, .1961,
- .2239, .2691, .3142, .3594, .4045, .4677, .5308, .5939,
- .6571, .7099, .7628, .8156, .8685, .8934, .9183, .9433,
- .9682, .9761, .9841, .9920, 1.0000, .9971, .9941, .9912,
- .9883, .9840, .9797, .9753, .9710, .9517, .9325, .9132,
- .8939, .8713, .8488, .8262, .8036, .7457, .6878, .6299,
- .5720, .5109, .4498, .3887, .3276, .2926, .2576, .2226,
- .1876, .1704, .1531, .1358, .1186, .1078, .0970, .0863,
- .0755, .0685, .0614, .0544, .0474, .0430, .0385, .0340,
- .0296, .0269, .0242, .0214, .0187, .0172, .0157, .0142,
- .0127, .0118, .0109, .0101, .0092, .0086, .0080, .0075,
- .0069, .0064, .0060, .0055, .0050
+ .0000, .0010, .0010, .0010, .0010, .0010, .0011, .0011,
+ .0012, .0013, .0014, .0014, .0015, .0016, .0016, .0017,
+ .0018, .0018, .0019, .0021, .0022, .0024, .0026, .0028,
+ .0030, .0032, .0035, .0038, .0041, .0044, .0050, .0055,
+ .0060, .0066, .0075, .0083, .0092, .0101, .0118, .0136,
+ .0154, .0171, .0203, .0235, .0267, .0299, .0366, .0433,
+ .0501, .0568, .0708, .0848, .0989, .1129, .1406, .1684,
+ .1961, .2239, .2691, .3142, .3594, .4045, .4677, .5308,
+ .5939, .6571, .7099, .7628, .8156, .8685, .8934, .9183,
+ .9433, .9682, .9761, .9841, .9920, 1.0000, .9971, .9941,
+ .9912, .9883, .9840, .9797, .9753, .9710, .9517, .9325,
+ .9132, .8939, .8713, .8488, .8262, .8036, .7457, .6878,
+ .6299, .5720, .5109, .4498, .3887, .3276, .2926, .2576,
+ .2226, .1876, .1704, .1531, .1358, .1186, .1078, .0970,
+ .0863, .0755, .0685, .0614, .0544, .0474, .0430, .0385,
+ .0340, .0296, .0269, .0242, .0214, .0187, .0172, .0157,
+ .0142, .0127, .0118, .0109, .0101, .0092, .0086, .0080,
+ .0075, .0069, .0064, .0060, .0055
+ static const float wli[4] = {0.4000, 0.5775, 0.6975, 1.4475};
+ static const float wls[4] = {0.5000, 0.7825, 1.0325, 1.8000};
- static const float wli[4] = {0.400, 0.580, 0.700, 1.450};
- static const float wls[4] = {0.500, 0.782, 1.030, 1.800};
@@ -2391,13 +2388,13 @@
switch(iwa)
- case 1: for(i = 0; i < 41; i++) ffu.s[60+i] = sr1[i];
+ case 1: for(i = 0; i < 40; i++) ffu.s[60+i] = sr1[i];
break;
- case 2: for(i = 0; i < 82; i++) ffu.s[132+i] = sr2[i];
+ case 2: for(i = 0; i < 82; i++) ffu.s[131+i] = sr2[i];
break;
- case 3: for(i = 0; i < 133; i++) ffu.s[180+i] = sr3[i];
+ case 3: for(i = 0; i < 134; i++) ffu.s[179+i] = sr3[i];
break;
- case 4: for(i = 0; i < 141; i++) ffu.s[480+i] = sr4[i];
+ case 4: for(i = 0; i < 141; i++) ffu.s[479+i] = sr4[i];
break;
@@ -2409,76 +2406,76 @@
/* B0 of VGT2_spot5 */
static const float sr1[61] = {
- .0007, .0008, .0010, .0010, .0011, .0012, .0013, .0029,
- .0045, .0209, .0374, .0964, .1553, .2551, .3549, .4536,
- .5524, .6318, .7111, .7602, .8093, .8304, .8514, .8698,
- .8882, .9441, 1.0000, .9787, .9574, .7493, .5412, .3553,
- .1694, .1083, .0472, .0318, .0163, .0116, .0069, .0053,
- .0036, .0028, .0020, .0017, .0014, .0011, .0009, .0008,
- .0008, .0008, .0007, .0006, .0006, .0006, .0005, .0004,
- .0004, .0004, .0004, .0003, .0003
+ .0007, .0008, .0010, .0010, .0011, .0012, .0013, .0029,
+ .0045, .0209, .0374, .0964, .1553, .2551, .3549, .4536,
+ .5524, .6318, .7111, .7602, .8093, .8304, .8514, .8698,
+ .8882, .9441, 1.0000, .9787, .9574, .7493, .5412, .3553,
+ .1694, .1083, .0472, .0318, .0163, .0116, .0069, .0053,
+ .0036, .0028, .0020, .0017, .0014, .0011, .0009, .0008,
+ .0008, .0008, .0007, .0006, .0006, .0006, .0005, .0004,
+ .0004, .0004, .0004, .0003, .0003
/* B2 of VGT2_spot5 */
- static const float sr2[81] = {
- .0006, .0006, .0006, .0007, .0007, .0033, .0059, .0084,
- .0110, .0688, .1265, .1842, .2420, .3532, .4643, .5755,
- .6866, .7306, .7745, .8185, .8625, .8766, .8906, .9046,
- .9187, .9307, .9426, .9546, .9666, .9749, .9833, .9917,
- 1.0000, .9957, .9915, .9872, .9829, .9387, .8945, .8503,
- .8061, .7316, .6570, .5825, .5079, .4468, .3856, .3245,
- .2634, .2293, .1952, .1611, .1270, .1095, .0921, .0746,
- .0572, .0490, .0408, .0326, .0244, .0208, .0171, .0135,
- .0099, .0085, .0071, .0057, .0043, .0037, .0031, .0025,
- .0019, .0017, .0014, .0012, .0010, .0009, .0008, .0007,
- .0006
+ static const float sr2[82] = {
+ .0000, .0006, .0006, .0006, .0007, .0007, .0033, .0059,
+ .0084, .0110, .0688, .1265, .1842, .2420, .3532, .4643,
+ .5755, .6866, .7306, .7745, .8185, .8625, .8766, .8906,
+ .9046, .9187, .9307, .9426, .9546, .9666, .9749, .9833,
+ .9917, 1.0000, .9957, .9915, .9872, .9829, .9387, .8945,
+ .8503, .8061, .7316, .6570, .5825, .5079, .4468, .3856,
+ .3245, .2634, .2293, .1952, .1611, .1270, .1095, .0921,
+ .0746, .0572, .0490, .0408, .0326, .0244, .0208, .0171,
+ .0135, .0099, .0085, .0071, .0057, .0043, .0037, .0031,
+ .0025, .0019, .0017, .0014, .0012, .0010, .0009, .0008,
+ .0007, .0006
/* B3 of VGT2_spot5 */
- static const float sr3[121] = {
- .0003, .0003, .0003, .0003, .0003, .0003, .0003, .0004,
- .0004, .0005, .0006, .0008, .0009, .0017, .0024, .0032,
- .0040, .0082, .0124, .0166, .0208, .0361, .0514, .0667,
- .0820, .1175, .1530, .1885, .2240, .2774, .3309, .3844,
- .4378, .4906, .5434, .5962, .6490, .6899, .7308, .7716,
- .8125, .8369, .8612, .8856, .9100, .9248, .9396, .9544,
- .9692, .9761, .9829, .9898, .9967, .9975, .9983, .9992,
- 1.0000, .9939, .9878, .9817, .9756, .9618, .9480, .9342,
- .9204, .9030, .8856, .8682, .8508, .8236, .7965, .7693,
- .7422, .6945, .6467, .5989, .5512, .4910, .4308, .3706,
- .3104, .2681, .2258, .1836, .1413, .1213, .1013, .0813,
- .0613, .0530, .0447, .0364, .0281, .0245, .0209, .0172,
- .0136, .0120, .0104, .0089, .0073, .0065, .0056, .0047,
- .0039, .0036, .0032, .0029, .0025, .0023, .0021, .0018,
- .0016, .0015, .0014, .0012, .0011, .0010, .0008, .0007,
- .0006
+ static const float sr3[122] = {
+ .0000, .0003, .0003, .0003, .0003, .0003, .0003, .0003,
+ .0004, .0004, .0005, .0006, .0008, .0009, .0017, .0024,
+ .0032, .0040, .0082, .0124, .0166, .0208, .0361, .0514,
+ .0667, .0820, .1175, .1530, .1885, .2240, .2774, .3309,
+ .3844, .4378, .4906, .5434, .5962, .6490, .6899, .7308,
+ .7716, .8125, .8369, .8612, .8856, .9100, .9248, .9396,
+ .9544, .9692, .9761, .9829, .9898, .9967, .9975, .9983,
+ .9992, 1.0000, .9939, .9878, .9817, .9756, .9618, .9480,
+ .9342, .9204, .9030, .8856, .8682, .8508, .8236, .7965,
+ .7693, .7422, .6945, .6467, .5989, .5512, .4910, .4308,
+ .3706, .3104, .2681, .2258, .1836, .1413, .1213, .1013,
+ .0813, .0613, .0530, .0447, .0364, .0281, .0245, .0209,
+ .0172, .0136, .0120, .0104, .0089, .0073, .0065, .0056,
+ .0047, .0039, .0036, .0032, .0029, .0025, .0023, .0021,
+ .0018, .0016, .0015, .0014, .0012, .0011, .0010, .0008,
+ .0007, .0006
/* MIR of VGT2_spot5 */
- .0005, .0006, .0006, .0007, .0008, .0008, .0008, .0009,
- .0009, .0009, .0009, .0009, .0009, .0011, .0014, .0016,
- .0019, .0022, .0024, .0027, .0029, .0034, .0040, .0045,
- .0050, .0060, .0070, .0080, .0090, .0108, .0126, .0143,
- .0161, .0196, .0231, .0266, .0301, .0372, .0444, .0515,
- .0586, .0723, .0860, .0997, .1134, .1401, .1668, .1936,
- .2203, .2668, .3134, .3599, .4065, .4664, .5263, .5863,
- .6462, .6929, .7396, .7862, .8329, .8630, .8931, .9233,
- .9534, .9644, .9754, .9863, .9973, .9980, .9987, .9993,
- 1.0000, .9987, .9974, .9962, .9949, .9914, .9879, .9845,
- .9810, .9687, .9564, .9440, .9317, .9055, .8793, .8532,
- .8270, .7811, .7351, .6892, .6433, .5746, .5059, .4371,
- .3684, .3244, .2803, .2363, .1923, .1713, .1502, .1292,
- .1082, .0970, .0859, .0747, .0636, .0575, .0514, .0453,
- .0392, .0360, .0327, .0295, .0262, .0235, .0209, .0182,
- .0155, .0139, .0123, .0106, .0090, .0082, .0073, .0065,
- .0057, .0053, .0050, .0046, .0043, .0040, .0037, .0033,
- .0030, .0026, .0022, .0019, .0015
+ .0000, .0005, .0006, .0006, .0007, .0008, .0008, .0008,
+ .0009, .0009, .0009, .0009, .0009, .0009, .0011, .0014,
+ .0016, .0019, .0022, .0024, .0027, .0029, .0034, .0040,
+ .0045, .0050, .0060, .0070, .0080, .0090, .0108, .0126,
+ .0143, .0161, .0196, .0231, .0266, .0301, .0372, .0444,
+ .0515, .0586, .0723, .0860, .0997, .1134, .1401, .1668,
+ .1936, .2203, .2668, .3134, .3599, .4065, .4664, .5263,
+ .5863, .6462, .6929, .7396, .7862, .8329, .8630, .8931,
+ .9233, .9534, .9644, .9754, .9863, .9973, .9980, .9987,
+ .9993, 1.0000, .9987, .9974, .9962, .9949, .9914, .9879,
+ .9845, .9810, .9687, .9564, .9440, .9317, .9055, .8793,
+ .8532, .8270, .7811, .7351, .6892, .6433, .5746, .5059,
+ .4371, .3684, .3244, .2803, .2363, .1923, .1713, .1502,
+ .1292, .1082, .0970, .0859, .0747, .0636, .0575, .0514,
+ .0453, .0392, .0360, .0327, .0295, .0262, .0235, .0209,
+ .0182, .0155, .0139, .0123, .0106, .0090, .0082, .0073,
+ .0065, .0057, .0053, .0050, .0046, .0043, .0040, .0037,
+ .0033, .0030, .0026, .0022, .0019
+ static const float wls[4] = {0.5525, 0.7825, 1.0025, 1.8000};
- static const float wls[4] = {0.550, 0.780, 1.000, 1.800};
@@ -2489,11 +2486,11 @@
case 1: for(i = 0; i < 61; i++) ffu.s[60+i] = sr1[i];
break;
- case 2: for(i = 0; i < 81; i++) ffu.s[132+i] = sr2[i];
break;
- case 3: for(i = 0; i < 121; i++) ffu.s[180+i] = sr3[i];
+ case 3: for(i = 0; i < 122; i++) ffu.s[179+i] = sr3[i];
break;
break;
@@ -2743,209 +2740,209 @@
/* pan of quickbird2 */
- static const float sr1[285] = {
- .0014, .0013, .0012, .0011, .0011, .0010, .0009, .0010,
- .0012, .0016, .0020, .0044, .0069, .0089, .0109, .0138,
- .0167, .0213, .0259, .0311, .0362, .0434, .0506, .0588,
- .0669, .0758, .0846, .0939, .1032, .1125, .1219, .1334,
- .1450, .1567, .1684, .1789, .1895, .2011, .2127, .2163,
- .2198, .2392, .2586, .2669, .2753, .2854, .2955, .3055,
- .3154, .3259, .3364, .3410, .3456, .3501, .3546, .3579,
- .3611, .3648, .3685, .3733, .3781, .3875, .3969, .4055,
- .4141, .4276, .4410, .4543, .4676, .4829, .4982, .5167,
- .5352, .5532, .5712, .5925, .6137, .6382, .6627, .6839,
- .7051, .7275, .7499, .7705, .7910, .8105, .8301, .8465,
- .8629, .8770, .8911, .9081, .9251, .9293, .9335, .9426,
- .9518, .9570, .9621, .9610, .9598, .9753, .9907, .9941,
- .9975, .9922, .9869, .9935, 1.0000, .9938, .9876, .9877,
- .9878, .9770, .9662, .9573, .9483, .9340, .9197, .9190,
- .9183, .9063, .8944, .8912, .8880, .8831, .8781, .8865,
- .8949, .8921, .8893, .8858, .8823, .8869, .8916, .8848,
- .8780, .8879, .8978, .8933, .8888, .8801, .8714, .8690,
- .8667, .8677, .8687, .8699, .8712, .8668, .8625, .8718,
- .8810, .8814, .8818, .8897, .8976, .9024, .9072, .9183,
- .9295, .9311, .9326, .9198, .9070, .9130, .9191, .9173,
- .9155, .9097, .9039, .8988, .8936, .8871, .8805, .8761,
- .8717, .8605, .8493, .8475, .8457, .8505, .8553, .8568,
- .8582, .8582, .8583, .8627, .8671, .8505, .8339, .8390,
- .8440, .8470, .8500, .8526, .8553, .8447, .8341, .8368,
- .8394, .8235, .8076, .8091, .8106, .7850, .7594, .7616,
- .7638, .7490, .7342, .7204, .7066, .7003, .6941, .6788,
- .6634, .6589, .6545, .6365, .6186, .6094, .6003, .5961,
- .5919, .5832, .5744, .5527, .5309, .5139, .4969, .4883,
- .4798, .4630, .4463, .4305, .4147, .4097, .4048, .3893,
- .3738, .3593, .3448, .3283, .3118, .3035, .2952, .2840,
- .2729, .2648, .2567, .2498, .2428, .2322, .2216, .2162,
- .2107, .2039, .1971, .1874, .1776, .1703, .1630, .1557,
- .1485, .1421, .1358, .1299, .1240, .1162, .1085, .1020,
- .0954, .0893, .0831, .0773, .0715, .0675, .0634, .0591,
- .0548, .0512, .0476, .0288, .0101
+ static const float sr1[286] = {
+ .0007, .0014, .0013, .0012, .0011, .0011, .0010, .0009,
+ .0010, .0012, .0016, .0020, .0044, .0069, .0089, .0109,
+ .0138, .0167, .0213, .0259, .0311, .0362, .0434, .0506,
+ .0588, .0669, .0758, .0846, .0939, .1032, .1125, .1219,
+ .1334, .1450, .1567, .1684, .1789, .1895, .2011, .2127,
+ .2163, .2198, .2392, .2586, .2669, .2753, .2854, .2955,
+ .3055, .3154, .3259, .3364, .3410, .3456, .3501, .3546,
+ .3579, .3611, .3648, .3685, .3733, .3781, .3875, .3969,
+ .4055, .4141, .4276, .4410, .4543, .4676, .4829, .4982,
+ .5167, .5352, .5532, .5712, .5925, .6137, .6382, .6627,
+ .6839, .7051, .7275, .7499, .7705, .7910, .8105, .8301,
+ .8465, .8629, .8770, .8911, .9081, .9251, .9293, .9335,
+ .9426, .9518, .9570, .9621, .9610, .9598, .9753, .9907,
+ .9941, .9975, .9922, .9869, .9935, 1.0000, .9938, .9876,
+ .9877, .9878, .9770, .9662, .9573, .9483, .9340, .9197,
+ .9190, .9183, .9063, .8944, .8912, .8880, .8831, .8781,
+ .8865, .8949, .8921, .8893, .8858, .8823, .8869, .8916,
+ .8848, .8780, .8879, .8978, .8933, .8888, .8801, .8714,
+ .8690, .8667, .8677, .8687, .8699, .8712, .8668, .8625,
+ .8718, .8810, .8814, .8818, .8897, .8976, .9024, .9072,
+ .9183, .9295, .9311, .9326, .9198, .9070, .9130, .9191,
+ .9173, .9155, .9097, .9039, .8988, .8936, .8871, .8805,
+ .8761, .8717, .8605, .8493, .8475, .8457, .8505, .8553,
+ .8568, .8582, .8582, .8583, .8627, .8671, .8505, .8339,
+ .8390, .8440, .8470, .8500, .8526, .8553, .8447, .8341,
+ .8368, .8394, .8235, .8076, .8091, .8106, .7850, .7594,
+ .7616, .7638, .7490, .7342, .7204, .7066, .7003, .6941,
+ .6788, .6634, .6589, .6545, .6365, .6186, .6094, .6003,
+ .5961, .5919, .5832, .5744, .5527, .5309, .5139, .4969,
+ .4883, .4798, .4630, .4463, .4305, .4147, .4097, .4048,
+ .3893, .3738, .3593, .3448, .3283, .3118, .3035, .2952,
+ .2840, .2729, .2648, .2567, .2498, .2428, .2322, .2216,
+ .2162, .2107, .2039, .1971, .1874, .1776, .1703, .1630,
+ .1557, .1485, .1421, .1358, .1299, .1240, .1162, .1085,
+ .1020, .0954, .0893, .0831, .0773, .0715, .0675, .0634,
+ .0591, .0548, .0512, .0476, .0288, .0101
/* blue of quickbird2 */
- static const float sr2[291] = {
- .0010, .0015, .0021, .0026, .0031, .0037, .0042, .0044,
- .0045, .0049, .0053, .0047, .0041, .0037, .0033, .0030,
- .0027, .0025, .0023, .0018, .0013, .0015, .0018, .0020,
- .0022, .0023, .0024, .0025, .0026, .0025, .0025, .0027,
- .0029, .0035, .0040, .0053, .0066, .0098, .0131, .0208,
- .0284, .0483, .0681, .1116, .1552, .2164, .2776, .3544,
- .4313, .5306, .6299, .6770, .7241, .7577, .7914, .8176,
- .8439, .8667, .8896, .9037, .9178, .9235, .9293, .9447,
- .9602, .9801, 1.0000, .9958, .9916, .9548, .9179, .8452,
- .7724, .6729, .5734, .4787, .3840, .3247, .2653, .2123,
- .1592, .1204, .0816, .0754, .0692, .0663, .0633, .0551,
- .0469, .0381, .0293, .0235, .0176, .0152, .0127, .0126,
- .0125, .0127, .0129, .0128, .0126, .0119, .0111, .0106,
- .0101, .0098, .0096, .0094, .0093, .0095, .0098, .0102,
- .0106, .0105, .0104, .0091, .0079, .0066, .0054, .0045,
- .0036, .0031, .0026, .0026, .0025, .0025, .0025, .0025,
- .0025, .0027, .0028, .0027, .0027, .0027, .0027, .0030,
- .0033, .0039, .0044, .0067, .0089, .0125, .0162, .0202,
- .0242, .0256, .0271, .0231, .0191, .0137, .0083, .0070,
- .0056, .0063, .0070, .0086, .0102, .0111, .0121, .0106,
- .0091, .0064, .0037, .0032, .0027, .0028, .0029, .0028,
- .0027, .0029, .0031, .0032, .0032, .0034, .0036, .0034,
- .0033, .0034, .0036, .0036, .0036, .0034, .0031, .0032,
- .0034, .0033, .0032, .0031, .0031, .0031, .0030, .0031,
- .0033, .0033, .0033, .0035, .0036, .0036, .0037, .0039,
- .0040, .0041, .0041, .0042, .0043, .0042, .0042, .0046,
- .0050, .0049, .0048, .0053, .0059, .0058, .0057, .0057,
- .0056, .0055, .0053, .0053, .0052, .0052, .0052, .0052,
- .0052, .0052, .0053, .0055, .0057, .0063, .0068, .0075,
- .0083, .0090, .0098, .0101, .0105, .0107, .0109, .0101,
- .0093, .0085, .0076, .0069, .0061, .0056, .0050, .0046,
- .0042, .0039, .0035, .0032, .0029, .0025, .0021, .0019,
- .0017, .0016, .0016, .0015, .0014, .0013, .0012, .0012,
- .0012, .0012, .0012, .0012, .0011, .0011, .0011, .0011,
- .0010, .0011, .0011, .0012, .0012, .0012, .0012, .0013,
- .0015, .0016, .0018, .0017, .0015, .0015, .0015, .0015,
+ static const float sr2[292] = {
+ .0005, .0010, .0015, .0021, .0026, .0031, .0037, .0042,
+ .0044, .0045, .0049, .0053, .0047, .0041, .0037, .0033,
+ .0030, .0027, .0025, .0023, .0018, .0013, .0015, .0018,
+ .0020, .0022, .0023, .0024, .0025, .0026, .0025, .0025,
+ .0027, .0029, .0035, .0040, .0053, .0066, .0098, .0131,
+ .0208, .0284, .0483, .0681, .1116, .1552, .2164, .2776,
+ .3544, .4313, .5306, .6299, .6770, .7241, .7577, .7914,
+ .8176, .8439, .8667, .8896, .9037, .9178, .9235, .9293,
+ .9447, .9602, .9801, 1.0000, .9958, .9916, .9548, .9179,
+ .8452, .7724, .6729, .5734, .4787, .3840, .3247, .2653,
+ .2123, .1592, .1204, .0816, .0754, .0692, .0663, .0633,
+ .0551, .0469, .0381, .0293, .0235, .0176, .0152, .0127,
+ .0126, .0125, .0127, .0129, .0128, .0126, .0119, .0111,
+ .0106, .0101, .0098, .0096, .0094, .0093, .0095, .0098,
+ .0102, .0106, .0105, .0104, .0091, .0079, .0066, .0054,
+ .0045, .0036, .0031, .0026, .0026, .0025, .0025, .0025,
+ .0025, .0025, .0027, .0028, .0027, .0027, .0027, .0027,
+ .0030, .0033, .0039, .0044, .0067, .0089, .0125, .0162,
+ .0202, .0242, .0256, .0271, .0231, .0191, .0137, .0083,
+ .0070, .0056, .0063, .0070, .0086, .0102, .0111, .0121,
+ .0106, .0091, .0064, .0037, .0032, .0027, .0028, .0029,
+ .0028, .0027, .0029, .0031, .0032, .0032, .0034, .0036,
+ .0034, .0033, .0034, .0036, .0036, .0036, .0034, .0031,
+ .0032, .0034, .0033, .0032, .0031, .0031, .0031, .0030,
+ .0031, .0033, .0033, .0033, .0035, .0036, .0036, .0037,
+ .0039, .0040, .0041, .0041, .0042, .0043, .0042, .0042,
+ .0046, .0050, .0049, .0048, .0053, .0059, .0058, .0057,
+ .0057, .0056, .0055, .0053, .0053, .0052, .0052, .0052,
+ .0052, .0052, .0052, .0053, .0055, .0057, .0063, .0068,
+ .0075, .0083, .0090, .0098, .0101, .0105, .0107, .0109,
+ .0101, .0093, .0085, .0076, .0069, .0061, .0056, .0050,
+ .0046, .0042, .0039, .0035, .0032, .0029, .0025, .0021,
+ .0019, .0017, .0016, .0016, .0015, .0014, .0013, .0012,
+ .0012, .0012, .0012, .0012, .0012, .0011, .0011, .0011,
+ .0011, .0010, .0011, .0011, .0012, .0012, .0012, .0012,
+ .0013, .0015, .0016, .0018, .0017, .0015, .0015, .0015,
+ .0015, .0014, .0013, .0012
/* green of quickbird2 */
- static const float sr3[281] = {
- .0031, .0036, .0040, .0031, .0022, .0023, .0023, .0019,
- .0015, .0015, .0014, .0011, .0008, .0010, .0011, .0012,
- .0012, .0012, .0012, .0012, .0012, .0012, .0011, .0012,
- .0012, .0013, .0014, .0016, .0019, .0021, .0023, .0026,
- .0028, .0033, .0037, .0046, .0055, .0077, .0098, .0138,
- .0178, .0206, .0234, .0268, .0301, .0356, .0412, .0504,
- .0597, .0789, .0982, .1274, .1566, .1924, .2282, .2739,
- .3196, .3686, .4175, .4726, .5277, .5928, .6579, .7138,
- .7698, .8005, .8312, .8378, .8445, .8575, .8705, .8893,
- .9082, .9271, .9460, .9640, .9819, .9910, 1.0000, .9967,
- .9934, .9876, .9818, .9755, .9691, .9733, .9774, .9822,
- .9869, .9761, .9652, .9316, .8979, .8445, .7910, .7230,
- .6551, .5687, .4822, .3973, .3124, .2579, .2033, .1706,
- .1378, .1139, .0901, .0729, .0557, .0461, .0365, .0322,
- .0278, .0270, .0262, .0268, .0274, .0275, .0275, .0259,
- .0242, .0214, .0186, .0167, .0148, .0140, .0132, .0132,
- .0132, .0132, .0132, .0124, .0116, .0104, .0092, .0076,
- .0061, .0052, .0043, .0038, .0032, .0030, .0029, .0029,
- .0029, .0035, .0040, .0051, .0062, .0069, .0076, .0076,
- .0076, .0067, .0057, .0047, .0037, .0032, .0026, .0024,
- .0022, .0024, .0026, .0028, .0030, .0029, .0028, .0030,
- .0031, .0032, .0034, .0037, .0040, .0039, .0038, .0041,
- .0044, .0043, .0041, .0040, .0038, .0036, .0035, .0034,
- .0032, .0031, .0030, .0030, .0030, .0031, .0031, .0032,
- .0032, .0033, .0033, .0035, .0037, .0041, .0044, .0048,
- .0051, .0060, .0069, .0073, .0078, .0084, .0091, .0091,
- .0092, .0091, .0090, .0088, .0086, .0083, .0080, .0078,
- .0076, .0075, .0075, .0075, .0076, .0077, .0078, .0080,
- .0081, .0081, .0082, .0080, .0078, .0072, .0067, .0061,
- .0056, .0051, .0046, .0043, .0039, .0035, .0031, .0029,
- .0027, .0023, .0020, .0018, .0017, .0016, .0015, .0014,
- .0012, .0012, .0013, .0012, .0011, .0010, .0009, .0010,
- .0010, .0009, .0009, .0008, .0008, .0008, .0009, .0009,
- .0009, .0009, .0010, .0010, .0011, .0012, .0013, .0012,
- .0011, .0011, .0011, .0010, .0009, .0009, .0010, .0009,
- .0009
+ static const float sr3[282] = {
+ .0015, .0031, .0036, .0040, .0031, .0022, .0023, .0023,
+ .0019, .0015, .0015, .0014, .0011, .0008, .0010, .0011,
+ .0012, .0012, .0012, .0012, .0012, .0012, .0012, .0011,
+ .0012, .0012, .0013, .0014, .0016, .0019, .0021, .0023,
+ .0026, .0028, .0033, .0037, .0046, .0055, .0077, .0098,
+ .0138, .0178, .0206, .0234, .0268, .0301, .0356, .0412,
+ .0504, .0597, .0789, .0982, .1274, .1566, .1924, .2282,
+ .2739, .3196, .3686, .4175, .4726, .5277, .5928, .6579,
+ .7138, .7698, .8005, .8312, .8378, .8445, .8575, .8705,
+ .8893, .9082, .9271, .9460, .9640, .9819, .9910, 1.0000,
+ .9967, .9934, .9876, .9818, .9755, .9691, .9733, .9774,
+ .9822, .9869, .9761, .9652, .9316, .8979, .8445, .7910,
+ .7230, .6551, .5687, .4822, .3973, .3124, .2579, .2033,
+ .1706, .1378, .1139, .0901, .0729, .0557, .0461, .0365,
+ .0322, .0278, .0270, .0262, .0268, .0274, .0275, .0275,
+ .0259, .0242, .0214, .0186, .0167, .0148, .0140, .0132,
+ .0132, .0132, .0132, .0132, .0124, .0116, .0104, .0092,
+ .0076, .0061, .0052, .0043, .0038, .0032, .0030, .0029,
+ .0029, .0029, .0035, .0040, .0051, .0062, .0069, .0076,
+ .0076, .0076, .0067, .0057, .0047, .0037, .0032, .0026,
+ .0024, .0022, .0024, .0026, .0028, .0030, .0029, .0028,
+ .0030, .0031, .0032, .0034, .0037, .0040, .0039, .0038,
+ .0041, .0044, .0043, .0041, .0040, .0038, .0036, .0035,
+ .0034, .0032, .0031, .0030, .0030, .0030, .0031, .0031,
+ .0032, .0032, .0033, .0033, .0035, .0037, .0041, .0044,
+ .0048, .0051, .0060, .0069, .0073, .0078, .0084, .0091,
+ .0091, .0092, .0091, .0090, .0088, .0086, .0083, .0080,
+ .0078, .0076, .0075, .0075, .0075, .0076, .0077, .0078,
+ .0080, .0081, .0081, .0082, .0080, .0078, .0072, .0067,
+ .0061, .0056, .0051, .0046, .0043, .0039, .0035, .0031,
+ .0029, .0027, .0023, .0020, .0018, .0017, .0016, .0015,
+ .0014, .0012, .0012, .0013, .0012, .0011, .0010, .0009,
+ .0010, .0010, .0009, .0009, .0008, .0008, .0008, .0009,
+ .0009, .0009, .0009, .0010, .0010, .0011, .0012, .0013,
+ .0012, .0011, .0011, .0011, .0010, .0009, .0009, .0010,
+ .0009, .0009
/* red of quickbird2 */
- static const float sr4[281] = {
- .0037, .0031, .0024, .0020, .0016, .0018, .0019, .0016,
- .0012, .0011, .0011, .0010, .0009, .0009, .0010, .0009,
- .0009, .0011, .0013, .0010, .0007, .0009, .0012, .0012,
- .0013, .0013, .0013, .0012, .0012, .0011, .0010, .0013,
- .0015, .0018, .0021, .0024, .0028, .0029, .0031, .0030,
- .0029, .0029, .0028, .0029, .0030, .0032, .0035, .0036,
- .0037, .0034, .0032, .0026, .0021, .0021, .0022, .0023,
- .0024, .0025, .0027, .0029, .0031, .0032, .0033, .0034,
- .0035, .0036, .0037, .0041, .0046, .0049, .0053, .0056,
- .0060, .0061, .0063, .0065, .0066, .0068, .0069, .0073,
- .0078, .0084, .0090, .0096, .0102, .0110, .0118, .0128,
- .0139, .0158, .0177, .0207, .0238, .0286, .0334, .0399,
- .0464, .0548, .0631, .0751, .0872, .1077, .1281, .1666,
- .2050, .2675, .3301, .4130, .4960, .5790, .6620, .7337,
- .8054, .8447, .8840, .8976, .9112, .9265, .9418, .9608,
- .9798, .9878, .9958, .9979, 1.0000, .9961, .9923, .9723,
- .9524, .9125, .8726, .8128, .7530, .6767, .6004, .5119,
- .4235, .3520, .2806, .2228, .1651, .1304, .0957, .0744,
- .0531, .0417, .0302, .0261, .0220, .0210, .0201, .0204,
- .0207, .0211, .0215, .0205, .0196, .0172, .0148, .0121,
- .0095, .0081, .0066, .0058, .0050, .0048, .0045, .0043,
- .0042, .0043, .0045, .0048, .0051, .0055, .0060, .0063,
- .0067, .0064, .0062, .0053, .0045, .0038, .0031, .0029,
- .0027, .0026, .0024, .0025, .0025, .0025, .0025, .0024,
- .0024, .0025, .0026, .0025, .0024, .0025, .0026, .0026,
- .0025, .0026, .0026, .0026, .0025, .0024, .0023, .0024,
- .0024, .0023, .0022, .0022, .0021, .0021, .0020, .0019,
- .0019, .0019, .0020, .0021, .0021, .0023, .0025, .0026,
- .0028, .0028, .0028, .0027, .0025, .0020, .0015, .0013,
- .0012, .0011, .0011, .0010, .0010, .0010, .0010, .0010,
- .0010, .0009, .0008, .0008, .0008, .0008, .0007, .0007,
- .0007, .0007, .0007, .0007, .0007, .0006, .0006, .0006,
- .0006, .0007, .0007, .0007, .0008, .0007, .0007, .0007,
- .0006, .0007, .0009, .0009, .0009, .0008, .0008, .0008,
- .0008, .0009, .0009, .0009, .0009, .0008, .0006, .0007,
- .0008
+ static const float sr4[282] = {
+ .0019, .0037, .0031, .0024, .0020, .0016, .0018, .0019,
+ .0016, .0012, .0011, .0011, .0010, .0009, .0009, .0010,
+ .0009, .0009, .0011, .0013, .0010, .0007, .0009, .0012,
+ .0012, .0013, .0013, .0013, .0012, .0012, .0011, .0010,
+ .0013, .0015, .0018, .0021, .0024, .0028, .0029, .0031,
+ .0030, .0029, .0029, .0028, .0029, .0030, .0032, .0035,
+ .0036, .0037, .0034, .0032, .0026, .0021, .0021, .0022,
+ .0023, .0024, .0025, .0027, .0029, .0031, .0032, .0033,
+ .0034, .0035, .0036, .0037, .0041, .0046, .0049, .0053,
+ .0056, .0060, .0061, .0063, .0065, .0066, .0068, .0069,
+ .0073, .0078, .0084, .0090, .0096, .0102, .0110, .0118,
+ .0128, .0139, .0158, .0177, .0207, .0238, .0286, .0334,
+ .0399, .0464, .0548, .0631, .0751, .0872, .1077, .1281,
+ .1666, .2050, .2675, .3301, .4130, .4960, .5790, .6620,
+ .7337, .8054, .8447, .8840, .8976, .9112, .9265, .9418,
+ .9608, .9798, .9878, .9958, .9979, 1.0000, .9961, .9923,
+ .9723, .9524, .9125, .8726, .8128, .7530, .6767, .6004,
+ .5119, .4235, .3520, .2806, .2228, .1651, .1304, .0957,
+ .0744, .0531, .0417, .0302, .0261, .0220, .0210, .0201,
+ .0204, .0207, .0211, .0215, .0205, .0196, .0172, .0148,
+ .0121, .0095, .0081, .0066, .0058, .0050, .0048, .0045,
+ .0043, .0042, .0043, .0045, .0048, .0051, .0055, .0060,
+ .0063, .0067, .0064, .0062, .0053, .0045, .0038, .0031,
+ .0029, .0027, .0026, .0024, .0025, .0025, .0025, .0025,
+ .0024, .0024, .0025, .0026, .0025, .0024, .0025, .0026,
+ .0026, .0025, .0026, .0026, .0026, .0025, .0024, .0023,
+ .0024, .0024, .0023, .0022, .0022, .0021, .0021, .0020,
+ .0019, .0019, .0019, .0020, .0021, .0021, .0023, .0025,
+ .0026, .0028, .0028, .0028, .0027, .0025, .0020, .0015,
+ .0013, .0012, .0011, .0011, .0010, .0010, .0010, .0010,
+ .0010, .0010, .0009, .0008, .0008, .0008, .0008, .0007,
+ .0007, .0007, .0007, .0007, .0007, .0007, .0006, .0006,
+ .0006, .0006, .0007, .0007, .0007, .0008, .0007, .0007,
+ .0007, .0006, .0007, .0009, .0009, .0009, .0008, .0008,
+ .0008, .0008, .0009, .0009, .0009, .0009, .0008, .0006,
+ .0007, .0008
/* nir of quickbird2 */
- static const float sr5[291] = {
- .0014, .0021, .0029, .0036, .0044, .0051, .0059, .0061,
- .0063, .0062, .0060, .0057, .0054, .0045, .0035, .0028,
- .0021, .0023, .0024, .0021, .0017, .0020, .0023, .0021,
- .0019, .0017, .0016, .0018, .0019, .0019, .0018, .0017,
- .0015, .0015, .0015, .0017, .0019, .0018, .0017, .0021,
- .0024, .0025, .0025, .0028, .0031, .0036, .0040, .0044,
- .0047, .0047, .0047, .0048, .0049, .0045, .0042, .0043,
- .0044, .0046, .0048, .0050, .0052, .0054, .0056, .0054,
- .0052, .0047, .0042, .0036, .0030, .0028, .0026, .0026,
- .0026, .0026, .0025, .0027, .0029, .0027, .0026, .0030,
- .0034, .0043, .0053, .0066, .0079, .0089, .0099, .0101,
- .0102, .0090, .0079, .0064, .0049, .0049, .0048, .0056,
- .0063, .0070, .0077, .0078, .0079, .0072, .0065, .0054,
- .0044, .0041, .0038, .0038, .0037, .0037, .0036, .0036,
- .0036, .0038, .0039, .0042, .0045, .0047, .0049, .0053,
- .0057, .0059, .0061, .0064, .0068, .0070, .0073, .0079,
- .0086, .0093, .0100, .0106, .0112, .0117, .0122, .0126,
- .0129, .0132, .0135, .0140, .0144, .0150, .0156, .0164,
- .0172, .0184, .0196, .0218, .0241, .0268, .0294, .0319,
- .0343, .0375, .0407, .0448, .0490, .0545, .0599, .0664,
- .0729, .0817, .0905, .1050, .1195, .1410, .1625, .2024,
- .2424, .3015, .3606, .4268, .4930, .5640, .6350, .7166,
- .7983, .8726, .9469, .9735, 1.0000, .9986, .9971, .9837,
- .9702, .9526, .9350, .9179, .9009, .8853, .8698, .8606,
- .8515, .8449, .8382, .8352, .8322, .8289, .8256, .8230,
- .8204, .8137, .8070, .7957, .7844, .7669, .7495, .7267,
- .7040, .6911, .6782, .6638, .6494, .6313, .6132, .5900,
- .5669, .5493, .5317, .5117, .4917, .4644, .4371, .3943,
- .3515, .3134, .2753, .2485, .2216, .1910, .1604, .1385,
- .1166, .1003, .0840, .0756, .0672, .0540, .0409, .0307,
- .0205, .0170, .0135, .0118, .0100, .0089, .0078, .0071,
- .0064, .0059, .0054, .0050, .0046, .0040, .0035, .0031,
- .0028, .0026, .0024, .0023, .0022, .0022, .0021, .0020,
- .0019, .0018, .0018, .0019, .0019, .0018, .0016, .0017,
- .0017, .0017, .0017, .0019, .0020, .0021, .0021, .0021,
- .0020, .0020, .0019, .0018, .0017, .0018, .0018, .0018,
- .0017, .0018, .0020
+ static const float sr5[292] = {
+ .0007, .0014, .0021, .0029, .0036, .0044, .0051, .0059,
+ .0061, .0063, .0062, .0060, .0057, .0054, .0045, .0035,
+ .0028, .0021, .0023, .0024, .0021, .0017, .0020, .0023,
+ .0021, .0019, .0017, .0016, .0018, .0019, .0019, .0018,
+ .0017, .0015, .0015, .0015, .0017, .0019, .0018, .0017,
+ .0021, .0024, .0025, .0025, .0028, .0031, .0036, .0040,
+ .0044, .0047, .0047, .0047, .0048, .0049, .0045, .0042,
+ .0043, .0044, .0046, .0048, .0050, .0052, .0054, .0056,
+ .0054, .0052, .0047, .0042, .0036, .0030, .0028, .0026,
+ .0026, .0026, .0026, .0025, .0027, .0029, .0027, .0026,
+ .0030, .0034, .0043, .0053, .0066, .0079, .0089, .0099,
+ .0101, .0102, .0090, .0079, .0064, .0049, .0049, .0048,
+ .0056, .0063, .0070, .0077, .0078, .0079, .0072, .0065,
+ .0054, .0044, .0041, .0038, .0038, .0037, .0037, .0036,
+ .0036, .0036, .0038, .0039, .0042, .0045, .0047, .0049,
+ .0053, .0057, .0059, .0061, .0064, .0068, .0070, .0073,
+ .0079, .0086, .0093, .0100, .0106, .0112, .0117, .0122,
+ .0126, .0129, .0132, .0135, .0140, .0144, .0150, .0156,
+ .0164, .0172, .0184, .0196, .0218, .0241, .0268, .0294,
+ .0319, .0343, .0375, .0407, .0448, .0490, .0545, .0599,
+ .0664, .0729, .0817, .0905, .1050, .1195, .1410, .1625,
+ .2024, .2424, .3015, .3606, .4268, .4930, .5640, .6350,
+ .7166, .7983, .8726, .9469, .9735, 1.0000, .9986, .9971,
+ .9837, .9702, .9526, .9350, .9179, .9009, .8853, .8698,
+ .8606, .8515, .8449, .8382, .8352, .8322, .8289, .8256,
+ .8230, .8204, .8137, .8070, .7957, .7844, .7669, .7495,
+ .7267, .7040, .6911, .6782, .6638, .6494, .6313, .6132,
+ .5900, .5669, .5493, .5317, .5117, .4917, .4644, .4371,
+ .3943, .3515, .3134, .2753, .2485, .2216, .1910, .1604,
+ .1385, .1166, .1003, .0840, .0756, .0672, .0540, .0409,
+ .0307, .0205, .0170, .0135, .0118, .0100, .0089, .0078,
+ .0071, .0064, .0059, .0054, .0050, .0046, .0040, .0035,
+ .0031, .0028, .0026, .0024, .0023, .0022, .0022, .0021,
+ .0020, .0019, .0018, .0018, .0019, .0019, .0018, .0016,
+ .0017, .0017, .0017, .0017, .0019, .0020, .0021, .0021,
+ .0021, .0020, .0020, .0019, .0018, .0017, .0018, .0018,
+ .0018, .0017, .0018, .0020
- static const float wli[5] = {0.350, 0.325, 0.350, 0.350, 0.325};
- static const float wls[5] = {1.060, 1.050, 1.050, 1.050, 1.050};
+ static const float wli[5] = {0.3475, 0.3225, 0.3475, 0.3475, 0.3225};
+ static const float wls[5] = {1.0625, 1.0525, 1.0525, 1.0525, 1.0525};
ffu.wlinf = (float)wli[iwa-1];
ffu.wlsup = (float)wls[iwa-1];
@@ -2955,15 +2952,15 @@
switch(iwa)
- case 1: for(i = 0; i < 285; i++) ffu.s[40+i] = sr1[i];
+ case 1: for(i = 0; i < 286; i++) ffu.s[39+i] = sr1[i];
break;
- case 2: for(i = 0; i < 291; i++) ffu.s[30+i] = sr2[i];
+ case 2: for(i = 0; i < 292; i++) ffu.s[29+i] = sr2[i];
break;
- case 3: for(i = 0; i < 281; i++) ffu.s[40+i] = sr3[i];
+ case 3: for(i = 0; i < 282; i++) ffu.s[39+i] = sr3[i];
break;
- case 4: for(i = 0; i < 281; i++) ffu.s[40+i] = sr4[i];
+ case 4: for(i = 0; i < 282; i++) ffu.s[39+i] = sr4[i];
break;
- case 5: for(i = 0; i < 291; i++) ffu.s[30+i] = sr5[i];
+ case 5: for(i = 0; i < 292; i++) ffu.s[29+i] = sr5[i];
break;
@@ -2972,103 +2969,104 @@
/* Coastal Aerosol of landsat_8 */
- static const float sr1[13] = {
- .0001, .0025, .0248, .3860, .9087, .9806, .9867, .9966,
- .9828, .8257, .2264, .0256, .0024
+ static const float sr1[14] = {
+ .0003, .0034, .0552, .5178, .9335, .9838, .9902, 1.0000,
+ .9777, .7456, .1596, .0145, .0017, .0000
/* Blue of landsat_8 */
static const float sr2[37] = {
- .0000, .0002, .0005, .0016, .0069, .0429, .2714, .7907,
- .9030, .9047, .8897, .8792, .8797, .8898, .8485, .8363,
- .8685, .9115, .9317, .9549, .9564, .9838, .9895, .9681,
- .9887, .9611, .9661, .9821, .9631, .9982, .8449, .1195,
- .0053, .0013, .0005, .0001, .0000
+ .0000, .0001, .0003, .0010, .0037, .0202, .1309, .6088,
+ .8942, .9104, .8980, .8805, .8747, .8892, .8612, .8346,
+ .8659, .9014, .9188, .9430, .9624, .9660, .9856, .9755,
+ .9768, .9741, .9641, .9743, .9657, .9844, .9556, .3627,
+ .0139, .0021, .0008, .0002, .0001
/* Green of landsat_8 */
- static const float sr3[35] = {
- .0000, .0003, .0009, .0022, .0049, .0133, .0415, .1676,
- .5459, .8963, .9542, .9631, .9525, .9779, .9809, .9961,
- .9838, .9612, .9479, .9721, .9534, .9743, .9810, .9733,
- .9758, .9744, .9678, .9717, .9837, .9603, .8093, .4353,
- .0878, .0100, .0010
+ static const float sr3[37] = {
+ .0000, .0000, .0002, .0008, .0018, .0042, .0104, .0335,
+ .1234, .4499, .8652, .9544, .9613, .9612, .9783, .9789,
+ 1.0000, .9832, .9651, .9471, .9665, .9599, .9700, .9822,
+ .9672, .9770, .9800, .9685, .9796, .9763, .9742, .8569,
+ .5253, .1391, .0141, .0018, .0001
/* Red of landsat_8 */
- static const float sr4[23] = {
- .0003, .0027, .0145, .1077, .5268, .9267, .9474, .9689,
- .9836, .9783, .9556, .9550, 1.0000, .9831, .9730, .9945,
- .9640, .9690, .9499, .4629, .0460, .0053, .0006
+ static const float sr4[25] = {
+ .0000, .0001, .0014, .0072, .0486, .2998, .8350, .9508,
+ .9573, .9842, .9832, .9594, .9544, .9817, .9885, .9770,
+ .9889, .9807, .9665, .9669, .7291, .1239, .0125, .0014,
+ .0001
/* Pan of landsat_8 */
- static const float sr5[82] = {
- .0002, .0013, .0038, .0123, .0427, .1601, .4725, .7454,
- .8319, .8553, .8596, .8577, .8585, .8583, .8502, .8582,
- .8615, .8577, .8792, .8917, .9063, .9129, .9029, .9207,
- .9130, .8857, .8794, .8742, .8754, .8917, .8741, .8869,
- .9035, .9110, .9132, .9202, .9244, .9298, .9489, .9405,
- .9457, .9394, .9467, .9340, .9408, .9580, .9682, .9665,
- .9572, .9477, .9525, .9575, .9642, .9674, .9770, .9760,
- .9696, .9728, .9658, .9667, .9721, .9793, .9711, .9534,
- .9639, .9671, .9706, .9800, .9883, .9918, 1.0000, .9985,
- .9926, .9858, .9139, .5244, .1673, .0462, .0152, .0067,
- .0032, .0012
+ static const float sr5[84] = {
+ .0000, .0001, .0010, .0032, .0090, .0330, .1243, .3979,
+ .7148, .8242, .8490, .8612, .8582, .8571, .8606, .8515,
+ .8573, .8607, .8603, .8718, .8887, .9042, .9117, .9064,
+ .9199, .9162, .8927, .8781, .8757, .8724, .8899, .8800,
+ .8824, .9024, .9076, .9141, .9196, .9227, .9301, .9432,
+ .9403, .9449, .9425, .9431, .9338, .9393, .9524, .9678,
+ .9679, .9593, .9493, .9503, .9558, .9637, .9659, .9749,
+ .9779, .9693, .9729, .9678, .9668, .9690, .9810, .9728,
+ .9533, .9607, .9695, .9686, .9771, .9890, .9880, .9993,
+ .9991, .9946, .9859, .9348, .6102, .2170, .0576, .0190,
+ .0077, .0038, .0015, .0001
/* Nir of landsat_8 */
static const float sr6[27] = {
- .0000, .0002, .0005, .0012, .0032, .0090, .0283, .1149,
- .4035, .8177, .9868, .9884, .9898, .9740, .9512, .9523,
- .9401, .9613, .9366, .7120, .2888, .0793, .0207, .0062,
- .0019, .0006, .0001
+ .0000, .0002, .0005, .0012, .0032, .0090, .0283, .1149,
+ .4035, .8177, .9868, .9884, .9898, .9740, .9512, .9523,
+ .9401, .9613, .9366, .7120, .2888, .0793, .0207, .0062,
+ .0019, .0006, .0001
/* Cirrus of landsat_8 */
- static const float sr7[25] = {
- .0001, .0004, .0009, .0016, .0030, .0063, .0170, .0560,
- .1828, .5269, .8624, .9465, .9387, .9933, .9832, .9638,
- .8727, .5295, .1910, .0538, .0162, .0056, .0018, .0007,
- .0001
+ static const float sr7[27] = {
+ .0000, .0000, .0003, .0006, .0013, .0023, .0047, .0111,
+ .0345, .1154, .3867, .7721, .9009, .9312, .9917, 1.0000,
+ .9771, .8713, .6549, .2979, .0896, .0261, .0083, .0028,
+ .0011, .0002, .0000
/* SWIR1 of landsat_8 */
- static const float sr8[73] = {
- .0001, .0003, .0006, .0010, .0016, .0023, .0033, .0046,
- .0064, .0090, .0124, .0176, .0259, .0378, .0554, .0826,
- .1202, .1755, .2529, .3528, .4736, .6052, .7213, .8047,
- .8734, .9035, .9187, .9270, .9251, .9241, .9214, .9237,
- .9346, .9451, .9464, .9489, .9513, .9548, .9615, .9591,
- .9609, .9611, .9679, .9722, .9791, .9813, .9959, .9999,
- .9966, .9826, .9551, .8983, .7965, .6654, .5099, .3684,
- .2513, .1657, .1067, .0694, .0450, .0291, .0187, .0124,
- .0082, .0054, .0036, .0024, .0015, .0009, .0005, .0003,
- .0000
+ static const float sr8[74] = {
+ .0000, .0000, .0002, .0005, .0008, .0014, .0020, .0029,
+ .0040, .0055, .0079, .0110, .0153, .0218, .0326, .0479,
+ .0709, .1019, .1509, .2203, .3106, .4215, .5522, .6767,
+ .7715, .8541, .8958, .9130, .9251, .9264, .9238, .9228,
+ .9224, .9266, .9434, .9462, .9473, .9529, .9514, .9590,
+ .9592, .9615, .9605, .9647, .9700, .9769, .9813, .9886,
+ .9990, .9996, .9898, .9671, .9267, .8410, .7231, .5732,
+ .4230, .2918, .1960, .1285, .0828, .0528, .0346, .0225,
+ .0147, .0096, .0064, .0043, .0028, .0018, .0011, .0007,
+ .0004, .0001
/* SWIR2 of landsat_8 */
static const float sr9[125] = {
- .0000, .0002, .0003, .0005, .0007, .0010, .0014, .0019,
- .0024, .0032, .0041, .0054, .0071, .0094, .0123, .0159,
- .0210, .0274, .0354, .0482, .0633, .0841, .1128, .1534,
- .2028, .2673, .3425, .4315, .5225, .6134, .6897, .7665,
- .8137, .8500, .8836, .8907, .9097, .9221, .9322, .9420,
- .9431, .9464, .9497, .9510, .9531, .9509, .9475, .9494,
- .9533, .9494, .9515, .9437, .9434, .9426, .9381, .9468,
- .9474, .9473, .9341, .9390, .9347, .9264, .9369, .9295,
- .9358, .9364, .9566, .9543, .9644, .9630, .9637, .9600,
- .9578, .9502, .9588, .9576, .9520, .9607, .9493, .9619,
- .9643, .9694, .9809, .9844, .9915, .9954, .9927, .9996,
- .9944, .9860, .9891, .9765, .9742, .9757, .9737, .9584,
- .9551, .9419, .9071, .8695, .7849, .6751, .5526, .4283,
- .3157, .2284, .1617, .1143, .0803, .0567, .0404, .0294,
- .0213, .0156, .0114, .0085, .0063, .0047, .0034, .0025,
- .0018, .0012, .0008, .0005, .0002
+ .0000, .0001, .0003, .0004, .0007, .0009, .0013, .0017,
+ .0023, .0030, .0039, .0051, .0067, .0089, .0116, .0150,
+ .0199, .0259, .0337, .0454, .0598, .0794, .1067, .1447,
+ .1912, .2537, .3269, .4126, .5056, .5932, .6764, .7565,
+ .8032, .8463, .8757, .8861, .9081, .9180, .9310, .9414,
+ .9430, .9452, .9492, .9494, .9549, .9491, .9492, .9471,
+ .9555, .9478, .9516, .9450, .9419, .9450, .9384, .9470,
+ .9459, .9493, .9370, .9388, .9368, .9271, .9337, .9280,
+ .9361, .9351, .9514, .9520, .9638, .9635, .9633, .9607,
+ .9578, .9533, .9553, .9603, .9498, .9606, .9525, .9600,
+ .9656, .9655, .9793, .9842, .9883, .9977, .9926, 1.0000,
+ .9958, .9877, .9876, .9780, .9735, .9762, .9740, .9599,
+ .9551, .9472, .9148, .8836, .8044, .6985, .5776, .4527,
+ .3356, .2446, .1739, .1220, .0861, .0607, .0434, .0312,
+ .0226, .0166, .0122, .0090, .0067, .0050, .0037, .0027,
+ .0019, .0013, .0009, .0006, .0003
- static const float wli[9] = {0.427, 0.436, 0.513, 0.626, 0.488, 0.830, 1.341, 1.516, 2.038};
- static const float wls[9] = {0.459, 0.527, 0.600, 0.682, 0.692, 0.896, 1.402, 1.696, 2.350};
+ static const float wli[9] = {0.4275, 0.4350, 0.5100, 0.6225, 0.4850, 0.8300, 1.3375, 1.5125, 2.0375};
+ static const float wls[9] = {0.4625, 0.5275, 0.6025, 0.6850, 0.6950, 0.8975, 1.4050, 1.6975, 2.3500};
@@ -3078,21 +3076,21 @@
switch(iwa)
- case 1: for(i = 0; i < 13; i++) ffu.s[70+i] = sr1[i];
+ case 1: for(i = 0; i < 14; i++) ffu.s[71+i] = sr1[i];
break;
case 2: for(i = 0; i < 37; i++) ffu.s[74+i] = sr2[i];
break;
- case 3: for(i = 0; i < 35; i++) ffu.s[105+i] = sr3[i];
+ case 3: for(i = 0; i < 37; i++) ffu.s[104+i] = sr3[i];
break;
- case 4: for(i = 0; i < 23; i++) ffu.s[150+i] = sr4[i];
+ case 4: for(i = 0; i < 25; i++) ffu.s[149+i] = sr4[i];
break;
- case 5: for(i = 0; i < 82; i++) ffu.s[95+i] = sr5[i];
+ case 5: for(i = 0; i < 84; i++) ffu.s[94+i] = sr5[i];
break;
case 6: for(i = 0; i < 27; i++) ffu.s[232+i] = sr6[i];
break;
- case 7: for(i = 0; i < 25; i++) ffu.s[436+i] = sr7[i];
+ case 7: for(i = 0; i < 27; i++) ffu.s[435+i] = sr7[i];
break;
- case 8: for(i = 0; i < 73; i++) ffu.s[506+i] = sr8[i];
+ case 8: for(i = 0; i < 74; i++) ffu.s[505+i] = sr8[i];
break;
case 9: for(i = 0; i < 125; i++) ffu.s[715+i] = sr9[i];
break;
@@ -3101,194 +3099,105 @@
void IWave::geoeye1(int iwa)
+ /* "Panchromatic" of geoeye1 */
+ static const float sr1[216] = {
+ .0000, .0001, .0001, .0004, .0007, .0027, .0046, .0863,
+ .1679, .4137, .6595, .6918, .7240, .7334, .7428, .7525,
+ .7622, .7650, .7679, .7528, .7378, .7411, .7443, .7345,
+ .7247, .7443, .7638, .7579, .7520, .7812, .8105, .8202,
+ .8299, .8051, .7802, .7983, .8164, .8400, .8636, .8480,
+ .8325, .8532, .8739, .8670, .8601, .8408, .8216, .8401,
+ .8586, .8624, .8661, .8594, .8527, .8830, .9134, .9046,
+ .8959, .8935, .8912, .9079, .9246, .9236, .9226, .9300,
+ .9375, .9355, .9335, .9372, .9409, .9505, .9601, .9559,
+ .9516, .9537, .9557, .9621, .9684, .9765, .9847, .9869,
+ .9890, .9792, .9693, .9744, .9796, .9898, 1.0000, .9886,
+ .9772, .9706, .9641, .9722, .9804, .9813, .9823, .9745,
+ .9666, .9669, .9672, .9730, .9787, .9610, .9434, .9406,
+ .9378, .9368, .9358, .9411, .9463, .9588, .9714, .9646,
+ .9577, .9439, .9301, .9266, .9232, .9256, .9279, .9167,
+ .9055, .8945, .8834, .8836, .8839, .8859, .8878, .8823,
+ .8767, .8675, .8583, .8486, .8389, .8350, .8310, .8382,
+ .8454, .8521, .8588, .8479, .8370, .8163, .7957, .7838,
+ .7719, .7910, .8100, .6449, .4797, .2768, .0738, .0443,
+ .0148, .0102, .0057, .0037, .0018, .0013, .0008, .0006,
+ .0004, .0004, .0004, .0004, .0003, .0003, .0003, .0003,
+ .0004, .0003, .0003, .0003, .0002, .0002, .0002, .0002,
+ .0002, .0002, .0002, .0002, .0002, .0002, .0002, .0002,
+ .0001, .0001, .0001, .0001, .0001, .0001, .0001, .0001
- /* Pan of geoeye1 */
- static const float sr1[261] = {
- .0001, .0001, .0001, .0000, .0000, .0000, .0000, .0000,
- .0000, .0000, .0000, .0000, .0000, .0000, .0000, .0000,
- .0000, .0001, .0001, .0004, .0007, .0027, .0046, .0863,
- .1679, .4137, .6595, .6918, .7240, .7334, .7428, .7525,
- .7622, .7650, .7679, .7528, .7378, .7411, .7443, .7345,
- .7247, .7443, .7638, .7579, .7520, .7812, .8105, .8202,
- .8299, .8051, .7802, .7983, .8164, .8400, .8636, .8480,
- .8325, .8532, .8739, .8670, .8601, .8408, .8216, .8401,
- .8586, .8624, .8661, .8594, .8527, .8830, .9134, .9046,
- .8959, .8935, .8912, .9079, .9246, .9236, .9226, .9300,
- .9375, .9355, .9335, .9372, .9409, .9505, .9601, .9559,
- .9516, .9537, .9557, .9621, .9684, .9765, .9847, .9869,
- .9890, .9792, .9693, .9744, .9796, .9898, 1.0000, .9886,
- .9772, .9706, .9641, .9722, .9804, .9813, .9823, .9745,
- .9666, .9669, .9672, .9730, .9787, .9610, .9434, .9406,
- .9378, .9368, .9358, .9411, .9463, .9588, .9714, .9646,
- .9577, .9439, .9301, .9266, .9232, .9256, .9279, .9167,
- .9055, .8945, .8834, .8836, .8839, .8859, .8878, .8823,
- .8767, .8675, .8583, .8486, .8389, .8350, .8310, .8382,
- .8454, .8521, .8588, .8479, .8370, .8163, .7957, .7838,
- .7719, .7910, .8100, .6449, .4797, .2768, .0738, .0443,
- .0148, .0102, .0057, .0037, .0018, .0013, .0008, .0006,
- .0004, .0004, .0004, .0004, .0003, .0003, .0003, .0003,
- .0004, .0003, .0003, .0003, .0002, .0002, .0002, .0002,
- .0002, .0002, .0002, .0002, .0002, .0002, .0002, .0002,
- .0001, .0001, .0001, .0001, .0001, .0001, .0001, .0001,
- /* Blue of geoeye1 */
- static const float sr2[261] = {
- .0000, .0000, .0000, .0000, .0000, .0002, .0003, .0003,
- .0003, .0004, .0004, .0004, .0004, .0005, .0006, .0006,
- .0007, .0010, .0013, .0036, .0060, .0222, .0384, .1251,
- .2119, .4473, .6828, .7713, .8597, .8677, .8756, .8771,
- .8786, .8878, .8971, .9065, .9160, .9209, .9259, .9328,
- .9397, .9416, .9435, .9595, .9754, .9877, 1.0000, .9868,
- .9736, .7085, .4435, .2623, .0812, .0470, .0129, .0082,
- .0035, .0024, .0013, .0011, .0008, .0007, .0006, .0003,
- .0001, .0000, .0000, .0000, .0000, .0000, .0000, .0000,
- .0000, .0000, .0000, .0000, .0000, .0000, .0000, .0001,
- .0001, .0001, .0000, .0000, .0000, .0000, .0000, .0000,
- .0000, .0000, .0000, .0000, .0000, .0000, .0001, .0000,
+ /* "Blue" of geoeye1 */
+ static const float sr2[62] = {
+ .0000, .0000, .0002, .0003, .0003, .0003, .0004, .0004,
+ .0004, .0004, .0005, .0006, .0006, .0007, .0010, .0013,
+ .0036, .0060, .0222, .0384, .1251, .2119, .4473, .6828,
+ .7713, .8597, .8677, .8756, .8771, .8786, .8878, .8971,
+ .9065, .9160, .9209, .9259, .9328, .9397, .9416, .9435,
+ .9595, .9754, .9877, 1.0000, .9868, .9736, .7085, .4435,
+ .2623, .0812, .0470, .0129, .0082, .0035, .0024, .0013,
+ .0011, .0008, .0007, .0006, .0003, .0001
- /* Green of geoeye1 */
- static const float sr3[261] = {
- .0000, .0001, .0003, .0003, .0003, .0003, .0003, .0003,
- .0004, .0005, .0005, .0011, .0016, .0117, .0219, .1132,
- .2045, .4832, .7619, .8086, .8554, .8617, .8680, .8817,
- .8955, .8955, .8955, .8957, .8960, .9002, .9044, .9032,
- .9020, .9193, .9366, .9503, .9641, .9762, .9883, .9942,
- 1.0000, .9882, .9763, .8664, .7564, .4210, .0857, .0462,
- .0067, .0040, .0014, .0010, .0006, .0005, .0004, .0004,
- .0003, .0003, .0003, .0003, .0003, .0003, .0003, .0003,
- .0003, .0003, .0003, .0003, .0003, .0003, .0003, .0002,
+ /* "Green" of geoeye1 */
+ static const float sr3[82] = {
+ .0000, .0000, .0001, .0003, .0003, .0003, .0003, .0003,
+ .0003, .0003, .0003, .0003, .0003, .0003, .0003, .0003,
+ .0004, .0004, .0005, .0005, .0011, .0016, .0117, .0219,
+ .1132, .2045, .4832, .7619, .8086, .8554, .8617, .8680,
+ .8817, .8955, .8955, .8955, .8957, .8960, .9002, .9044,
+ .9032, .9020, .9193, .9366, .9503, .9641, .9762, .9883,
+ .9942, 1.0000, .9882, .9763, .8664, .7564, .4210, .0857,
+ .0462, .0067, .0040, .0014, .0010, .0006, .0005, .0004,
+ .0004, .0003, .0003, .0003, .0003, .0003, .0003, .0003,
+ .0002, .0000
- /* Red of geoeye1 */
- static const float sr4[261] = {
- .0000, .0000, .0001, .0001, .0002, .0001, .0000, .0000,
- .0000, .0000, .0000, .0000, .0001, .0002, .0003, .0017,
- .0032, .0247, .0463, .2688, .4913, .7407, .9901, .9918,
- .9936, .9968, 1.0000, .9856, .9713, .9688, .9663, .8722,
- .7781, .4300, .0819, .0431, .0044, .0025, .0007, .0004,
- .0002, .0001, .0000, .0000, .0000, .0000, .0000, .0000,
+ /* "Red" of geoeye1 */
+ static const float sr4[144] = {
+ .0001, .0001, .0002, .0001, .0000, .0000, .0000, .0000,
+ .0000, .0000, .0001, .0002, .0003, .0017, .0032, .0247,
+ .0463, .2688, .4913, .7407, .9901, .9918, .9936, .9968,
+ 1.0000, .9856, .9713, .9688, .9663, .8722, .7781, .4300,
+ .0819, .0431, .0044, .0025, .0007, .0004, .0002, .0001
/* "Near IR" of geoeye1 */
- static const float sr5[261] = {
- .0000, .0000, .0000, .0000, .0000, .0001, .0001, .0001,
- .0002, .0003, .0004, .0006, .0009, .0021, .0033, .0080,
- .0128, .0459, .0791, .2192, .3593, .6220, .8847, .9423,
- 1.0000, .9865, .9731, .9620, .9510, .9322, .9135, .8973,
- .8811, .8735, .8660, .8582, .8503, .8385, .8268, .8155,
- .8042, .7969, .7895, .7832, .7769, .7689, .7608, .7526,
- .7444, .7341, .7237, .7111, .6985, .6851, .6717, .6579,
- .6440, .6250, .6061, .5877, .5693, .5586, .5479, .5373,
- .5267, .5096, .4925, .4802, .4679, .4608, .4536, .4466,
- .4396, .4300, .4205, .3784, .3364, .2346, .1329, .0784,
- .0240, .0139, .0038, .0024, .0010, .0007, .0004, .0004,
- .0004, .0003, .0001, .0001, .0000, .0000, .0000, .0000,
+ static const float sr5[86] = {
+ .0001, .0001, .0001, .0002, .0003, .0004, .0006, .0009,
+ .0021, .0033, .0080, .0128, .0459, .0791, .2192, .3593,
+ .6220, .8847, .9423, 1.0000, .9865, .9731, .9620, .9510,
+ .9322, .9135, .8973, .8811, .8735, .8660, .8582, .8503,
+ .8385, .8268, .8155, .8042, .7969, .7895, .7832, .7769,
+ .7689, .7608, .7526, .7444, .7341, .7237, .7111, .6985,
+ .6851, .6717, .6579, .6440, .6250, .6061, .5877, .5693,
+ .5586, .5479, .5373, .5267, .5096, .4925, .4802, .4679,
+ .4608, .4536, .4466, .4396, .4300, .4205, .3784, .3364,
+ .2346, .1329, .0784, .0240, .0139, .0038, .0024, .0010,
+ .0007, .0004, .0004, .0004, .0003, .0001
- static const float wli[5] = {0.350, 0.350, 0.350, 0.350, 0.350};
- static const float wls[5] = {1.000, 1.000, 1.000, 1.000, 1.000};
+ static const float wli[5] = {0.4300, 0.3975, 0.4475, 0.3550, 0.7425};
+ static const float wls[5] = {0.9700, 0.5525, 0.6525, 0.7150, 0.9575};
@@ -3298,15 +3207,15 @@
switch(iwa)
- case 1: for(i = 0; i < 261; i++) ffu.s[40+i] = sr1[i];
+ case 1: for(i = 0; i < 216; i++) ffu.s[72+i] = sr1[i];
break;
- case 2: for(i = 0; i < 261; i++) ffu.s[40+i] = sr2[i];
+ case 2: for(i = 0; i < 62; i++) ffu.s[59+i] = sr2[i];
break;
- case 3: for(i = 0; i < 261; i++) ffu.s[40+i] = sr3[i];
+ case 3: for(i = 0; i < 82; i++) ffu.s[79+i] = sr3[i];
break;
- case 4: for(i = 0; i < 261; i++) ffu.s[40+i] = sr4[i];
+ case 4: for(i = 0; i < 144; i++) ffu.s[42+i] = sr4[i];
break;
- case 5: for(i = 0; i < 261; i++) ffu.s[40+i] = sr5[i];
+ case 5: for(i = 0; i < 86; i++) ffu.s[197+i] = sr5[i];
break;
@@ -3315,182 +3224,119 @@
/* Spot6 Blue of spot6 */
- static const float sr1[241] = {
- .0001, .0002, .0002, .0005, .0012, .0022, .0039, .0084,
- .0182, .0319, .0680, .1467, .2649, .4506, .6147, .7798,
- .8575, .8527, .8532, .8547, .8756, .9153, .9331, .9370,
- .9338, .9225, .9209, .9396, .9636, .9747, .9664, .9522,
- .9582, .9861, 1.0000, .9973, .9840, .9234, .8339, .6537,
- .4313, .2393, .1046, .0502, .0279, .0156, .0081, .0049,
- .0033, .0024, .0017, .0012, .0009, .0006, .0005, .0005,
- .0004, .0004, .0003, .0002, .0002, .0002, .0002, .0002,
- .0002, .0002, .0002, .0002, .0002, .0002, .0001, .0001,
- .0001, .0001, .0001, .0001, .0002, .0002, .0002, .0001,
- .0001, .0001, .0001, .0001, .0001, .0001, .0002, .0002,
- .0001, .0002, .0002, .0002, .0002, .0002, .0002, .0002,
- .0002, .0002, .0001, .0001, .0001, .0001, .0001, .0001,
- .0000
+ static const float sr1[202] = {
+ .0001, .0001, .0001, .0001, .0001, .0001, .0002, .0002,
+ .0005, .0012, .0022, .0039, .0084, .0182, .0319, .0680,
+ .1467, .2649, .4506, .6147, .7798, .8575, .8527, .8532,
+ .8547, .8756, .9153, .9331, .9370, .9338, .9225, .9209,
+ .9396, .9636, .9747, .9664, .9522, .9582, .9861, 1.0000,
+ .9973, .9840, .9234, .8339, .6537, .4313, .2393, .1046,
+ .0502, .0279, .0156, .0081, .0049, .0033, .0024, .0017,
+ .0012, .0009, .0006, .0005, .0005, .0004, .0004, .0003,
+ .0002, .0002, .0002, .0001, .0001, .0001, .0001, .0001,
+ .0001, .0001, .0001, .0001, .0001, .0001, .0001, .0001,
+ .0001, .0002, .0002, .0002, .0001, .0001, .0001, .0001,
+ .0001, .0001, .0001, .0002, .0002, .0001, .0001, .0001,
+ .0002, .0002, .0002, .0002, .0002, .0002, .0002, .0001,
+ .0001, .0001
- /* spot6 Green of spot6 */
- static const float sr2[241] = {
- .0000, .0000, .0000, .0000, .0001, .0000, .0000, .0000,
- .0000, .0000, .0001, .0001, .0001, .0001, .0002, .0003,
- .0004, .0006, .0010, .0019, .0033, .0061, .0127, .0313,
- .0704, .1541, .3075, .5195, .7467, .9229, 1.0057, 1.0230,
- 1.0212, 1.0164, 1.0096, 1.0029, .9996, 1.0026, 1.0091, 1.0100,
- .9990, .9815, .9702, .9709, .9807, .9944, .9991, .9871,
- .9639, .8850, .7236, .5325, .2984, .1244, .0510, .0246,
- .0118, .0055, .0025, .0013, .0008, .0006, .0004, .0003,
- .0001, .0001, .0001, .0001, .0001, .0000, .0000, .0000,
- .0000, .0000, .0000, .0000, .0001, .0001, .0000, .0000,
- .0001, .0001, .0001, .0001, .0000, .0000, .0000, .0000,
- .0000
+ /* Spot6 Green of spot6 */
+ static const float sr2[72] = {
+ .0001, .0001, .0001, .0002, .0003, .0004, .0006, .0010,
+ .0019, .0033, .0061, .0127, .0313, .0704, .1541, .3075,
+ .5195, .7467, .9229, 1.0057, 1.0230, 1.0212, 1.0164, 1.0096,
+ 1.0029, .9996, 1.0026, 1.0091, 1.0100, .9990, .9815, .9702,
+ .9709, .9807, .9944, .9991, .9871, .9639, .8850, .7236,
+ .5325, .2984, .1244, .0510, .0246, .0118, .0055, .0025,
+ .0013, .0008, .0006, .0004, .0003, .0002, .0002, .0001,
- /* spot6 Red of spot6 */
- static const float sr3[241] = {
- .0000, .0000, .0000, .0000, .0000, .0001, .0001, .0000,
- .0001, .0001, .0001, .0002, .0003, .0004, .0005, .0006,
- .0009, .0016, .0031, .0065, .0125, .0222, .0387, .0747,
- .1634, .3494, .5463, .7600, .9267, .9767, .9951, .9979,
- .9662, .9217, .8987, .9033, .9255, .9573, .9887, 1.0107,
- 1.0137, .9960, .9674, .9391, .9198, .9138, .9211, .9366,
- .9466, .9308, .8765, .7978, .6985, .5868, .4715, .3531,
- .2351, .1401, .0776, .0416, .0206, .0098, .0045, .0023,
- .0013, .0008, .0005, .0005, .0004, .0003, .0003, .0002,
- .0001, .0001, .0000, .0000, .0000, .0000, .0001, .0001,
- .0001, .0002, .0001, .0000, .0000, .0000, .0000, .0000,
- .0000
+ /* Spot6 Red of spot6 */
+ static const float sr3[75] = {
+ .0001, .0001, .0002, .0003, .0004, .0005, .0006, .0009,
+ .0016, .0031, .0065, .0125, .0222, .0387, .0747, .1634,
+ .3494, .5463, .7600, .9267, .9767, .9951, .9979, .9662,
+ .9217, .8987, .9033, .9255, .9573, .9887, 1.0107, 1.0137,
+ .9960, .9674, .9391, .9198, .9138, .9211, .9366, .9466,
+ .9308, .8765, .7978, .6985, .5868, .4715, .3531, .2351,
+ .1401, .0776, .0416, .0206, .0098, .0045, .0023, .0013,
+ .0008, .0005, .0005, .0004, .0003, .0003, .0002, .0001,
+ .0001, .0000, .0000, .0000, .0000, .0001, .0001, .0001,
+ .0002, .0001, .0000
- /* spot6 NIR of spot6 */
- static const float sr4[241] = {
- .0000, .0000, .0000, .0008, .0008, .0010, .0000, .0000,
- .0000, .0001, .0001, .0001, .0001, .0000, .0000, .0000,
- .0002, .0002, .0003, .0003, .0003, .0003, .0003, .0004,
- .0005, .0006, .0006, .0004, .0003, .0001, .0001, .0001,
- .0000, .0000, .0000, .0000, .0000, .0000, .0001, .0001,
- .0001, .0001, .0001, .0002, .0002, .0003, .0004, .0005,
- .0007, .0010, .0014, .0019, .0028, .0042, .0065, .0104,
- .0170, .0290, .0496, .0862, .1462, .2549, .3877, .5465,
- .7084, .8466, .9436, .9893, 1.0000, .9932, .9834, .9753,
- .9694, .9633, .9552, .9448, .9330, .9201, .9087, .8988,
- .8904, .8829, .8749, .8643, .8520, .8377, .8224, .8081,
- .7954, .7842, .7751, .7670, .7592, .7514, .7431, .7336,
- .7233, .7118, .6987, .6841, .6699, .6567, .6454, .6366,
- .6299, .6230, .6150, .6053, .5943, .5805, .5570, .5102,
- .4427, .3607, .2673, .1717, .0941, .0480, .0243, .0132,
- .0074, .0046, .0029, .0020, .0014, .0011, .0008, .0007,
- .0006, .0005, .0004, .0003, .0003, .0002, .0002, .0001,
- .0000
+ /* Spot6 NIR of spot6 */
+ static const float sr4[200] = {
+ .0000, .0000, .0008, .0008, .0010, .0000, .0000, .0000,
+ .0001, .0001, .0001, .0001, .0000, .0000, .0000, .0000,
+ .0000, .0000, .0000, .0000, .0000, .0000, .0001, .0001,
+ .0002, .0003, .0003, .0003, .0003, .0003, .0004, .0005,
+ .0006, .0006, .0004, .0003, .0001, .0001, .0001, .0001,
+ .0000, .0000, .0000, .0000, .0000, .0000, .0000, .0000,
+ .0000, .0000, .0000, .0000, .0000, .0001, .0001, .0001,
+ .0001, .0001, .0002, .0002, .0003, .0004, .0005, .0007,
+ .0010, .0014, .0019, .0028, .0042, .0065, .0104, .0170,
+ .0290, .0496, .0862, .1462, .2549, .3877, .5465, .7084,
+ .8466, .9436, .9893, 1.0000, .9932, .9834, .9753, .9694,
+ .9633, .9552, .9448, .9330, .9201, .9087, .8988, .8904,
+ .8829, .8749, .8643, .8520, .8377, .8224, .8081, .7954,
+ .7842, .7751, .7670, .7592, .7514, .7431, .7336, .7233,
+ .7118, .6987, .6841, .6699, .6567, .6454, .6366, .6299,
+ .6230, .6150, .6053, .5943, .5805, .5570, .5102, .4427,
+ .3607, .2673, .1717, .0941, .0480, .0243, .0132, .0074,
+ .0046, .0029, .0020, .0014, .0011, .0008, .0007, .0006,
+ .0005, .0004, .0003, .0003, .0002, .0002, .0001, .0001
- /* spot6 Pan of spot6 */
- static const float sr5[241] = {
- .0001, .0001, .0001, .0001, .0002, .0002, .0002, .0002,
- .0003, .0004, .0007, .0010, .0017, .0036, .0066, .0105,
- .0161, .0327, .0717, .1335, .2227, .3529, .5156, .6744,
- .7759, .8080, .8143, .8112, .8188, .8450, .8704, .8801,
- .8818, .8903, .9054, .9170, .9198, .9199, .9258, .9378,
- .9461, .9454, .9412, .9432, .9542, .9668, .9732, .9716,
- .9700, .9751, .9831, .9870, .9830, .9731, .9665, .9703,
- .9820, .9939, .9973, .9903, .9797, .9738, .9773, .9886,
- .9989, 1.0017, .9947, .9834, .9750, .9752, .9831, .9934,
- .9995, .9972, .9883, .9779, .9716, .9725, .9790, .9867,
- .9906, .9880, .9807, .9719, .9663, .9660, .9693, .9736,
- .9754, .9719, .9638, .9531, .9437, .9383, .9375, .9407,
- .9449, .9469, .9449, .9373, .9260, .9148, .9056, .9009,
- .9006, .9039, .9079, .9100, .9088, .9026, .8936, .8832,
- .8737, .8675, .8649, .8644, .8650, .8654, .8633, .8590,
- .8522, .8434, .8344, .8267, .8205, .8160, .8128, .8096,
- .8061, .7995, .7908, .7812, .7707, .7633, .7544, .7290,
- .6647, .5549, .4157, .2694, .1503, .0778, .0392, .0209,
- .0115, .0067, .0044, .0026, .0017, .0011, .0008, .0006,
- .0004, .0003, .0003, .0002, .0002, .0001, .0001, .0001,
- .0000, .0001, .0001, .0001, .0001, .0001, .0001, .0001,
- .0000
+ /* Spot6 Pan of spot6 */
+ static const float sr5[159] = {
+ .0001, .0001, .0001, .0001, .0002, .0002, .0002, .0002,
+ .0003, .0004, .0007, .0010, .0017, .0036, .0066, .0105,
+ .0161, .0327, .0717, .1335, .2227, .3529, .5156, .6744,
+ .7759, .8080, .8143, .8112, .8188, .8450, .8704, .8801,
+ .8818, .8903, .9054, .9170, .9198, .9199, .9258, .9378,
+ .9461, .9454, .9412, .9432, .9542, .9668, .9732, .9716,
+ .9700, .9751, .9831, .9870, .9830, .9731, .9665, .9703,
+ .9820, .9939, .9973, .9903, .9797, .9738, .9773, .9886,
+ .9989, 1.0017, .9947, .9834, .9750, .9752, .9831, .9934,
+ .9995, .9972, .9883, .9779, .9716, .9725, .9790, .9867,
+ .9906, .9880, .9807, .9719, .9663, .9660, .9693, .9736,
+ .9754, .9719, .9638, .9531, .9437, .9383, .9375, .9407,
+ .9449, .9469, .9449, .9373, .9260, .9148, .9056, .9009,
+ .9006, .9039, .9079, .9100, .9088, .9026, .8936, .8832,
+ .8737, .8675, .8649, .8644, .8650, .8654, .8633, .8590,
+ .8522, .8434, .8344, .8267, .8205, .8160, .8128, .8096,
+ .8061, .7995, .7908, .7812, .7707, .7633, .7544, .7290,
+ .6647, .5549, .4157, .2694, .1503, .0778, .0392, .0209,
+ .0115, .0067, .0044, .0026, .0017, .0011, .0008, .0006,
+ .0004, .0003, .0003, .0002, .0002, .0001, .0001
- static const float wli[5] = {0.400, 0.400, 0.400, 0.400, 0.400};
+ static const float wli[5] = {0.4075, 0.4875, 0.5825, 0.4425, 0.4000};
+ static const float wls[5] = {0.9125, 0.6675, 0.7700, 0.9425, 0.7975};
@@ -3500,15 +3346,15 @@
switch(iwa)
- case 1: for(i = 0; i < 241; i++) ffu.s[60+i] = sr1[i];
+ case 1: for(i = 0; i < 202; i++) ffu.s[63+i] = sr1[i];
break;
- case 2: for(i = 0; i < 241; i++) ffu.s[60+i] = sr2[i];
+ case 2: for(i = 0; i < 72; i++) ffu.s[95+i] = sr2[i];
break;
- case 3: for(i = 0; i < 241; i++) ffu.s[60+i] = sr3[i];
+ case 3: for(i = 0; i < 75; i++) ffu.s[133+i] = sr3[i];
break;
- case 4: for(i = 0; i < 241; i++) ffu.s[60+i] = sr4[i];
+ case 4: for(i = 0; i < 200; i++) ffu.s[77+i] = sr4[i];
break;
- case 5: for(i = 0; i < 241; i++) ffu.s[60+i] = sr5[i];
+ case 5: for(i = 0; i < 159; i++) ffu.s[60+i] = sr5[i];
break;
@@ -3518,183 +3364,168 @@
void IWave::spot7(int iwa)
- /* spot7 Blue of spot7 */
- .0001, .0001, .0001, .0001, .0001, .0002, .0004, .0007,
- .0014, .0036, .0145, .0771, .2058, .3851, .5883, .7118,
- .7732, .8001, .8134, .8290, .8540, .8798, .8934, .9007,
- .9104, .9133, .9290, .9436, .9534, .9595, .9525, .9394,
- .9498, .9599, .9648, .9754, .9792, .9920, 1.0000, .9602,
- .8198, .6370, .4136, .1930, .0761, .0275, .0075, .0037,
- .0029, .0021, .0007, .0003, .0002, .0002, .0002, .0002,
- .0003, .0003, .0003, .0003, .0003, .0003, .0002, .0002,
- .0002, .0002, .0003, .0003, .0003, .0003, .0003, .0003,
- .0002, .0002, .0002, .0002, .0003, .0003, .0003, .0005,
- .0007, .0013, .0010, .0004, .0003, .0015, .0014, .0046,
- .0036, .0034, .0002, .0011, .0031, .0034, .0041, .0024,
- .0014, .0004, .0004, .0005, .0003, .0004, .0002, .0002,
- .0003, .0002, .0002, .0002, .0002, .0001, .0002, .0001,
- .0002, .0001, .0002, .0002, .0002, .0001, .0002, .0002,
- .0003, .0004, .0003, .0003, .0001, .0002, .0001, .0001,
- .0001, .0002, .0001, .0001, .0000, .0001, .0000, .0001,
- .0000, .0001, .0002, .0002, .0001, .0002, .0002, .0002,
- .0001, .0001, .0001, .0002, .0002, .0003, .0004, .0004,
- .0005, .0005, .0005, .0005, .0005, .0005, .0005, .0005,
- .0005, .0004, .0004, .0005, .0006, .0006, .0008, .0015,
- .0021, .0020, .0022, .0019, .0018, .0014, .0013, .0011,
- .0009, .0008, .0008, .0007, .0008, .0009, .0011, .0012,
- .0012, .0022, .0021, .0027, .0028, .0021, .0021, .0009,
- .0008, .0003, .0002, .0001, .0000, .0000, .0000, .0000,
- .0000
+ /* spot7 blue of spot7 */
+ static const float sr1[229] = {
+ .0001, .0001, .0001, .0001, .0001, .0002, .0004, .0007,
+ .0014, .0036, .0145, .0771, .2058, .3851, .5883, .7118,
+ .7732, .8001, .8134, .8290, .8540, .8798, .8934, .9007,
+ .9104, .9133, .9290, .9436, .9534, .9595, .9525, .9394,
+ .9498, .9599, .9648, .9754, .9792, .9920, 1.0000, .9602,
+ .8198, .6370, .4136, .1930, .0761, .0275, .0075, .0037,
+ .0029, .0021, .0007, .0003, .0002, .0002, .0002, .0002,
+ .0003, .0003, .0003, .0003, .0003, .0003, .0002, .0002,
+ .0002, .0002, .0003, .0003, .0003, .0003, .0003, .0003,
+ .0002, .0002, .0002, .0002, .0003, .0003, .0003, .0005,
+ .0007, .0013, .0010, .0004, .0003, .0015, .0014, .0046,
+ .0036, .0034, .0002, .0011, .0031, .0034, .0041, .0024,
+ .0014, .0004, .0004, .0005, .0003, .0004, .0002, .0002,
+ .0003, .0002, .0002, .0002, .0002, .0001, .0002, .0001,
+ .0002, .0001, .0002, .0002, .0002, .0001, .0002, .0002,
+ .0003, .0004, .0003, .0003, .0001, .0002, .0001, .0001,
+ .0001, .0002, .0001, .0001, .0000, .0001, .0000, .0001,
+ .0000, .0001, .0002, .0002, .0001, .0002, .0002, .0002,
+ .0001, .0001, .0001, .0002, .0002, .0003, .0004, .0004,
+ .0005, .0005, .0005, .0005, .0005, .0005, .0005, .0005,
+ .0005, .0004, .0004, .0005, .0006, .0006, .0008, .0015,
+ .0021, .0020, .0022, .0019, .0018, .0014, .0013, .0011,
+ .0009, .0008, .0008, .0007, .0008, .0009, .0011, .0012,
+ .0012, .0022, .0021, .0027, .0028, .0021, .0021, .0009,
+ .0008, .0003, .0002, .0001, .0000
- /* spot7 Green of spot7 */
- .0000, .0000, .0000, .0001, .0001, .0002, .0004, .0007,
- .0019, .0051, .0154, .0747, .2220, .4198, .6371, .7791,
- .8264, .8142, .8193, .8678, .9098, .9331, .9473, .9534,
- .9543, .9588, .9665, .9740, .9853, .9949, .9985, .9979,
- .9994, .9992, .9761, .9071, .8632, .7668, .6158, .5032,
- .3340, .1427, .0470, .0192, .0085, .0037, .0014, .0007,
- .0004, .0002, .0001, .0000, .0000, .0000, .0001, .0000,
- .0000, .0000, .0000, .0000, .0000, .0001, .0001, .0003,
- .0004, .0003, .0001, .0001, .0002, .0001, .0002, .0002,
- .0002, .0000, .0000, .0000, .0000, .0001, .0001, .0001,
- .0002, .0002, .0002, .0003, .0003, .0002, .0002, .0001,
- .0001, .0001, .0002, .0003, .0004, .0006, .0008, .0008,
- .0008, .0007, .0006, .0003, .0003, .0003, .0003, .0003,
- .0003, .0002, .0001, .0001, .0001, .0002, .0003, .0004,
- .0005, .0005, .0005, .0006, .0004, .0004, .0002, .0002,
- .0002, .0001, .0001, .0001, .0001, .0001, .0001, .0001,
- .0000
+ /* spot7 green of spot7 */
+ static const float sr2[180] = {
+ .0001, .0001, .0002, .0004, .0007, .0019, .0051, .0154,
+ .0747, .2220, .4198, .6371, .7791, .8264, .8142, .8193,
+ .8678, .9098, .9331, .9473, .9534, .9543, .9588, .9665,
+ .9740, .9853, .9949, .9985, .9979, .9994, .9992, .9761,
+ .9071, .8632, .7668, .6158, .5032, .3340, .1427, .0470,
+ .0192, .0085, .0037, .0014, .0007, .0004, .0002, .0001,
+ .0000, .0000, .0000, .0001, .0000, .0000, .0000, .0000,
+ .0000, .0000, .0001, .0001, .0003, .0004, .0003, .0001,
+ .0001, .0002, .0001, .0002, .0002, .0002, .0000, .0000,
+ .0000, .0000, .0001, .0001, .0001, .0002, .0002, .0002,
+ .0003, .0003, .0002, .0002, .0001, .0001, .0001, .0001,
+ .0001, .0001, .0000, .0000, .0000, .0000, .0001, .0001,
+ .0001, .0001, .0001, .0001, .0001, .0001, .0001, .0002,
+ .0003, .0004, .0006, .0008, .0008, .0008, .0007, .0006,
+ .0003, .0003, .0003, .0003, .0003, .0003, .0002, .0001,
+ .0001, .0001, .0002, .0003, .0004, .0005, .0005, .0005,
+ .0006, .0004, .0004, .0002, .0002, .0002, .0001, .0001,
- /* spot7 Red of spot7 */
- .0001, .0001, .0001, .0002, .0002, .0002, .0006, .0033,
- .0059, .0064, .0040, .0009, .0013, .0016, .0013, .0009,
- .0011, .0013, .0012, .0012, .0012, .0013, .0015, .0010,
- .0008, .0011, .0013, .0012, .0012, .0008, .0008, .0009,
- .0010, .0009, .0008, .0007, .0006, .0007, .0007, .0008,
- .0009, .0008, .0008, .0008, .0008, .0009, .0009, .0009,
- .0009, .0008, .0008, .0008, .0008, .0009, .0011, .0011,
- .0011, .0009, .0008, .0007, .0008, .0008, .0008, .0010,
- .0011, .0013, .0011, .0010, .0008, .0007, .0008, .0008,
- .0008, .0009, .0014, .0024, .0029, .0031, .0026, .0019,
- .0019, .0027, .0045, .0078, .0140, .0292, .0802, .1791,
- .2523, .3239, .3762, .3703, .3855, .4631, .5767, .6899,
- .7903, .8963, .9694, .9814, .9837, .9964, .9995, .9920,
- .9851, .9778, .9612, .9341, .9075, .8951, .9035, .9239,
- .9382, .9348, .9219, .9104, .9044, .8952, .8624, .7922,
- .6672, .5121, .3598, .2257, .1290, .0793, .0577, .0468,
- .0390, .0318, .0232, .0138, .0070, .0040, .0028, .0025,
- .0026, .0028, .0027, .0027, .0024, .0019, .0015, .0016,
- .0019, .0017, .0019, .0018, .0013, .0009, .0008, .0008,
- .0008, .0008, .0008, .0010, .0007, .0010, .0011, .0015,
- .0014, .0016, .0016, .0015, .0014, .0012, .0011, .0008,
- .0009, .0008, .0007, .0007, .0005, .0006, .0005, .0005,
- .0007, .0006, .0005, .0004, .0005, .0011, .0016, .0017,
- .0016, .0019, .0018, .0013, .0013, .0006, .0003, .0003,
- .0002, .0004, .0004, .0004, .0003, .0004, .0006, .0008,
- .0010, .0012, .0013, .0013, .0015, .0015, .0014, .0011,
- .0011, .0017, .0026, .0033, .0026, .0032, .0044, .0040,
- .0028, .0021, .0010, .0009, .0006, .0006, .0004, .0004,
- .0003, .0003, .0003, .0002, .0002, .0002, .0002, .0001,
- .0002, .0001, .0001, .0001, .0001, .0001, .0001, .0000,
- .0001
+ /* spot7 red of spot7 */
+ static const float sr3[235] = {
+ .0001, .0001, .0001, .0002, .0002, .0002, .0006, .0033,
+ .0059, .0064, .0040, .0009, .0013, .0016, .0013, .0009,
+ .0011, .0013, .0012, .0012, .0012, .0013, .0015, .0010,
+ .0008, .0011, .0013, .0012, .0012, .0008, .0008, .0009,
+ .0010, .0009, .0008, .0007, .0006, .0007, .0007, .0008,
+ .0009, .0008, .0008, .0008, .0008, .0009, .0009, .0009,
+ .0009, .0008, .0008, .0008, .0008, .0009, .0011, .0011,
+ .0011, .0009, .0008, .0007, .0008, .0008, .0008, .0010,
+ .0011, .0013, .0011, .0010, .0008, .0007, .0008, .0008,
+ .0008, .0009, .0014, .0024, .0029, .0031, .0026, .0019,
+ .0019, .0027, .0045, .0078, .0140, .0292, .0802, .1791,
+ .2523, .3239, .3762, .3703, .3855, .4631, .5767, .6899,
+ .7903, .8963, .9694, .9814, .9837, .9964, .9995, .9920,
+ .9851, .9778, .9612, .9341, .9075, .8951, .9035, .9239,
+ .9382, .9348, .9219, .9104, .9044, .8952, .8624, .7922,
+ .6672, .5121, .3598, .2257, .1290, .0793, .0577, .0468,
+ .0390, .0318, .0232, .0138, .0070, .0040, .0028, .0025,
+ .0026, .0028, .0027, .0027, .0024, .0019, .0015, .0016,
+ .0019, .0017, .0019, .0018, .0013, .0009, .0008, .0008,
+ .0008, .0008, .0008, .0010, .0007, .0010, .0011, .0015,
+ .0014, .0016, .0016, .0015, .0014, .0012, .0011, .0008,
+ .0009, .0008, .0007, .0007, .0005, .0006, .0005, .0005,
+ .0007, .0006, .0005, .0004, .0005, .0011, .0016, .0017,
+ .0016, .0019, .0018, .0013, .0013, .0006, .0003, .0003,
+ .0002, .0004, .0004, .0004, .0003, .0004, .0006, .0008,
+ .0010, .0012, .0013, .0013, .0015, .0015, .0014, .0011,
+ .0011, .0017, .0026, .0033, .0026, .0032, .0044, .0040,
+ .0028, .0021, .0010, .0009, .0006, .0006, .0004, .0004,
+ .0003, .0003, .0003, .0002, .0002, .0002, .0002, .0001,
+ .0002, .0001, .0001
- /* spot7 NIR of spot7 */
- .0000, .0000, .0000, .0001, .0003, .0004, .0005, .0005,
- .0004, .0004, .0003, .0003, .0004, .0005, .0008, .0009,
- .0009, .0008, .0006, .0007, .0010, .0013, .0019, .0021,
- .0022, .0018, .0013, .0010, .0008, .0005, .0003, .0003,
- .0002, .0001, .0001, .0001, .0001, .0002, .0002, .0002,
- .0002, .0002, .0003, .0003, .0003, .0003, .0001, .0004,
- .0007, .0010, .0010, .0006, .0003, .0005, .0008, .0010,
- .0011, .0008, .0006, .0007, .0010, .0013, .0013, .0010,
- .0006, .0004, .0002, .0002, .0002, .0003, .0003, .0003,
- .0003, .0002, .0002, .0003, .0005, .0007, .0009, .0009,
- .0010, .0007, .0004, .0002, .0001, .0002, .0001, .0001,
- .0002, .0001, .0001, .0001, .0002, .0001, .0001, .0002,
- .0002, .0001, .0001, .0002, .0002, .0002, .0002, .0002,
- .0002, .0002, .0002, .0001, .0002, .0001, .0001, .0002,
- .0002, .0002, .0002, .0002, .0002, .0002, .0002, .0001,
- .0001, .0001, .0001, .0002, .0002, .0002, .0002, .0003,
- .0003, .0004, .0005, .0006, .0007, .0010, .0015, .0024,
- .0039, .0065, .0113, .0202, .0353, .0606, .1026, .1796,
- .3276, .4949, .6522, .7976, .9149, .9645, .9593, .9472,
- .9500, .9614, .9741, .9798, .9945, .9989, .9942, .9787,
- .9669, .9546, .9411, .9290, .9171, .9071, .8970, .8867,
- .8749, .8603, .8429, .8247, .8050, .7864, .7700, .7573,
- .7482, .7402, .7312, .7216, .7074, .6893, .6667, .6404,
- .6118, .5830, .5529, .5224, .4938, .4658, .4379, .4077,
- .3707, .3252, .2748, .2212, .1662, .1137, .0696, .0391,
- .0211, .0120, .0073, .0049, .0035, .0029, .0024, .0021,
- .0018, .0016, .0014, .0012, .0010, .0007, .0005, .0004,
- .0003, .0002, .0001, .0001, .0001, .0000, .0000, .0000,
- .0000
+ /* spot7 nir of spot7 */
+ static const float sr4[219] = {
+ .0000, .0000, .0001, .0003, .0004, .0005, .0005, .0004,
+ .0004, .0003, .0003, .0004, .0005, .0008, .0009, .0009,
+ .0008, .0006, .0007, .0010, .0013, .0019, .0021, .0022,
+ .0018, .0013, .0010, .0008, .0005, .0003, .0003, .0002,
+ .0002, .0003, .0003, .0003, .0003, .0001, .0004, .0007,
+ .0010, .0010, .0006, .0003, .0005, .0008, .0010, .0011,
+ .0008, .0006, .0007, .0010, .0013, .0013, .0010, .0006,
+ .0004, .0002, .0002, .0002, .0003, .0003, .0003, .0003,
+ .0002, .0002, .0003, .0005, .0007, .0009, .0009, .0010,
+ .0007, .0004, .0002, .0001, .0002, .0001, .0001, .0002,
+ .0001, .0001, .0001, .0002, .0001, .0001, .0002, .0002,
+ .0001, .0001, .0002, .0002, .0002, .0002, .0002, .0002,
+ .0002, .0002, .0001, .0002, .0001, .0001, .0002, .0002,
+ .0002, .0002, .0002, .0002, .0002, .0002, .0001, .0001,
+ .0001, .0001, .0002, .0002, .0002, .0002, .0003, .0003,
+ .0004, .0005, .0006, .0007, .0010, .0015, .0024, .0039,
+ .0065, .0113, .0202, .0353, .0606, .1026, .1796, .3276,
+ .4949, .6522, .7976, .9149, .9645, .9593, .9472, .9500,
+ .9614, .9741, .9798, .9945, .9989, .9942, .9787, .9669,
+ .9546, .9411, .9290, .9171, .9071, .8970, .8867, .8749,
+ .8603, .8429, .8247, .8050, .7864, .7700, .7573, .7482,
+ .7402, .7312, .7216, .7074, .6893, .6667, .6404, .6118,
+ .5830, .5529, .5224, .4938, .4658, .4379, .4077, .3707,
+ .3252, .2748, .2212, .1662, .1137, .0696, .0391, .0211,
+ .0120, .0073, .0049, .0035, .0029, .0024, .0021, .0018,
+ .0016, .0014, .0012, .0010, .0007, .0005, .0004, .0003,
- /* spot7 Pan of spot7 */
- .0001, .0001, .0001, .0001, .0001, .0001, .0000, .0001,
- .0001, .0001, .0001, .0002, .0003, .0004, .0008, .0026,
- .0089, .0293, .0911, .2322, .4161, .5766, .6555, .6834,
- .7001, .7313, .7615, .7761, .7760, .7811, .7970, .8226,
- .8557, .8692, .8794, .8849, .8867, .8913, .8908, .8982,
- .9110, .9220, .9366, .9446, .9460, .9504, .9514, .9529,
- .9519, .9403, .9273, .9205, .9230, .9388, .9551, .9536,
- .9457, .9484, .9614, .9764, .9866, .9868, .9811, .9784,
- .9806, .9841, .9873, .9898, .9901, .9918, .9963, .9997,
- .9971, .9877, .9793, .9768, .9791, .9821, .9814, .9755,
- .9703, .9717, .9777, .9819, .9814, .9786, .9764, .9741,
- .9742, .9739, .9734, .9716, .9677, .9634, .9616, .9617,
- .9620, .9614, .9587, .9529, .9441, .9352, .9302, .9315,
- .9357, .9386, .9379, .9331, .9277, .9235, .9198, .9155,
- .9093, .8992, .8850, .8686, .8561, .8524, .8583, .8648,
- .8692, .8681, .8631, .8572, .8521, .8469, .8403, .8349,
- .8280, .8152, .7916, .7543, .7074, .6639, .6386, .6187,
- .5794, .5198, .4311, .3047, .1803, .1007, .0572, .0331,
- .0176, .0090, .0044, .0026, .0017, .0013, .0011, .0009,
- .0009, .0008, .0008, .0010, .0007, .0010, .0011, .0011,
- .0007, .0008, .0009, .0009, .0008, .0009, .0008, .0008,
- .0008, .0008, .0009, .0010, .0012, .0008, .0007, .0009,
- .0010, .0007, .0007, .0006, .0006, .0006, .0004, .0004,
- .0008, .0005, .0006, .0004, .0007, .0006, .0005, .0004,
- .0003, .0004, .0005, .0004, .0004, .0004, .0004, .0004,
- .0003, .0003, .0002, .0004, .0003, .0003, .0002, .0002,
- .0004, .0003, .0003, .0002, .0003, .0002, .0002, .0002,
- .0002, .0002, .0001, .0002, .0001, .0002, .0002, .0002,
- .0001, .0001, .0002, .0001, .0000, .0001, .0001, .0001,
- .0000
+ /* spot7 pan of spot7 */
+ static const float sr5[235] = {
+ .0001, .0001, .0001, .0001, .0000, .0001, .0001, .0001,
+ .0001, .0002, .0003, .0004, .0008, .0026, .0089, .0293,
+ .0911, .2322, .4161, .5766, .6555, .6834, .7001, .7313,
+ .7615, .7761, .7760, .7811, .7970, .8226, .8557, .8692,
+ .8794, .8849, .8867, .8913, .8908, .8982, .9110, .9220,
+ .9366, .9446, .9460, .9504, .9514, .9529, .9519, .9403,
+ .9273, .9205, .9230, .9388, .9551, .9536, .9457, .9484,
+ .9614, .9764, .9866, .9868, .9811, .9784, .9806, .9841,
+ .9873, .9898, .9901, .9918, .9963, .9997, .9971, .9877,
+ .9793, .9768, .9791, .9821, .9814, .9755, .9703, .9717,
+ .9777, .9819, .9814, .9786, .9764, .9741, .9742, .9739,
+ .9734, .9716, .9677, .9634, .9616, .9617, .9620, .9614,
+ .9587, .9529, .9441, .9352, .9302, .9315, .9357, .9386,
+ .9379, .9331, .9277, .9235, .9198, .9155, .9093, .8992,
+ .8850, .8686, .8561, .8524, .8583, .8648, .8692, .8681,
+ .8631, .8572, .8521, .8469, .8403, .8349, .8280, .8152,
+ .7916, .7543, .7074, .6639, .6386, .6187, .5794, .5198,
+ .4311, .3047, .1803, .1007, .0572, .0331, .0176, .0090,
+ .0044, .0026, .0017, .0013, .0011, .0009, .0009, .0008,
+ .0008, .0010, .0007, .0010, .0011, .0011, .0007, .0008,
+ .0009, .0009, .0008, .0009, .0008, .0008, .0008, .0008,
+ .0009, .0010, .0012, .0008, .0007, .0009, .0010, .0007,
+ .0007, .0006, .0006, .0006, .0004, .0004, .0008, .0005,
+ .0006, .0004, .0007, .0006, .0005, .0004, .0003, .0004,
+ .0005, .0004, .0004, .0004, .0004, .0004, .0004, .0004,
+ .0004, .0004, .0003, .0003, .0003, .0003, .0003, .0003,
+ .0002, .0004, .0003, .0003, .0002, .0002, .0004, .0003,
+ .0003, .0002, .0003, .0002, .0002, .0002, .0002, .0002,
+ .0001, .0002, .0001, .0002, .0002, .0002, .0001, .0001,
+ static const float wli[5] = {0.4000, 0.5075, 0.4000, 0.4025, 0.4050};
+ static const float wls[5] = {0.9725, 0.9575, 0.9875, 0.9500, 0.9925};
@@ -3704,15 +3535,15 @@
switch(iwa)
+ case 1: for(i = 0; i < 229; i++) ffu.s[60+i] = sr1[i];
break;
+ case 2: for(i = 0; i < 180; i++) ffu.s[102+i] = sr2[i];
break;
+ case 3: for(i = 0; i < 235; i++) ffu.s[60+i] = sr3[i];
break;
+ case 4: for(i = 0; i < 219; i++) ffu.s[61+i] = sr4[i];
break;
+ case 5: for(i = 0; i < 235; i++) ffu.s[62+i] = sr5[i];
break;
@@ -3722,163 +3553,154 @@
void IWave::pleiades1a(int iwa)
- /* pleiades1a Blue of pleiades1a */
- static const float sr1[209] = {
- .0100, .0296, .0886, .1300, .1355, .2482, .4389, .5185,
- .4758, .5178, .6596, .7786, .7959, .7725, .7796, .8094,
- .8324, .8437, .8410, .8332, .8250, .8246, .8369, .8711,
- .9167, .9474, .9601, .9669, .9748, .9730, .9684, .9664,
- .9744, .9903, 1.0000, .9938, .9817, .9813, .9671, .8859,
- .7175, .4994, .3052, .1740, .0953, .0549, .0349, .0264,
- .0232, .0225, .0212, .0175, .0120, .0074, .0047, .0034,
- .0026, .0020, .0015, .0011, .0007, .0005, .0004, .0004,
- .0005, .0010, .0014, .0014, .0009, .0003, .0001, .0001,
- .0000, .0000, .0001, .0002, .0005, .0008, .0010, .0007,
- .0005, .0004, .0006, .0012, .0016, .0017, .0010, .0004,
- .0002, .0001, .0001, .0001, .0001, .0000, .0000, .0001,
- .0001, .0000, .0001, .0001, .0001, .0001, .0002, .0002,
- .0004, .0005, .0007, .0008, .0007, .0005, .0004, .0003,
- .0003, .0003, .0002, .0002, .0002, .0003, .0003, .0004,
- .0005, .0006, .0008, .0012, .0018, .0031, .0056, .0105,
- .0168, .0214, .0218, .0179, .0138, .0108, .0090, .0081,
- .0080, .0081, .0090, .0103, .0127, .0164, .0224, .0311,
- .0416, .0503, .0537, .0489, .0395, .0294, .0215, .0164,
- .0130, .0109, .0095, .0085, .0078, .0075, .0073, .0074,
- .0075, .0077, .0079, .0079, .0078, .0073, .0067, .0058,
- .0049
+ /* Pleiades1a blue of pleiades1a */
+ static const float sr1[208] = {
+ .0100, .0296, .0886, .1300, .1355, .2482, .4389, .5185,
+ .4758, .5178, .6596, .7786, .7959, .7725, .7796, .8094,
+ .8324, .8437, .8410, .8332, .8250, .8246, .8369, .8711,
+ .9167, .9474, .9601, .9669, .9748, .9730, .9684, .9664,
+ .9744, .9903, 1.0000, .9938, .9817, .9813, .9671, .8859,
+ .7175, .4994, .3052, .1740, .0953, .0549, .0349, .0264,
+ .0232, .0225, .0212, .0175, .0120, .0074, .0047, .0034,
+ .0026, .0020, .0015, .0011, .0007, .0005, .0004, .0004,
+ .0005, .0010, .0014, .0014, .0009, .0003, .0001, .0001,
+ .0000, .0000, .0001, .0002, .0005, .0008, .0010, .0007,
+ .0005, .0004, .0006, .0012, .0016, .0017, .0010, .0004,
+ .0002, .0001, .0001, .0001, .0001, .0000, .0000, .0001,
+ .0001, .0000, .0001, .0001, .0001, .0001, .0002, .0002,
+ .0004, .0005, .0007, .0008, .0007, .0005, .0004, .0003,
+ .0003, .0003, .0002, .0002, .0002, .0003, .0003, .0004,
+ .0005, .0006, .0008, .0012, .0018, .0031, .0056, .0105,
+ .0168, .0214, .0218, .0179, .0138, .0108, .0090, .0081,
+ .0080, .0081, .0090, .0103, .0127, .0164, .0224, .0311,
+ .0416, .0503, .0537, .0489, .0395, .0294, .0215, .0164,
+ .0130, .0109, .0095, .0085, .0078, .0075, .0073, .0074,
+ .0075, .0077, .0079, .0079, .0078, .0073, .0067, .0058
- /* Pleiades1a Green of pleiades1a */
- static const float sr2[209] = {
- .0000, .0001, .0001, .0001, .0001, .0002, .0003, .0004,
- .0005, .0008, .0046, .0086, .0145, .0246, .0486, .1109,
- .2379, .4375, .6562, .8184, .8944, .9165, .9230, .9287,
- .9374, .9507, .9616, .9692, .9772, .9815, .9834, .9876,
- .9958, 1.0000, .9973, .9849, .9679, .9538, .9542, .9675,
- .9818, .9868, .9724, .9345, .8829, .8441, .8255, .8103,
- .7517, .6227, .4368, .2572, .1376, .0778, .0485, .0346,
- .0270, .0215, .0162, .0108, .0061, .0031, .0016, .0008,
- .0005, .0003, .0002, .0001, .0001, .0001, .0001, .0001,
- .0001, .0001, .0001, .0001, .0001, .0002, .0002, .0002,
- .0000, .0000, .0000, .0000, .0000, .0001, .0002, .0002,
- .0002, .0001, .0001, .0001, .0000, .0000, .0000, .0000,
- .0000, .0000, .0001, .0000, .0000, .0001, .0001, .0001,
- .0002, .0004, .0010, .0042, .0067, .0079, .0069, .0030,
- .0011, .0007, .0006, .0005, .0005, .0005, .0006, .0008,
- .0011, .0017, .0031, .0056, .0092, .0126, .0146, .0143,
- .0119, .0091, .0069, .0057, .0053, .0054, .0061, .0068,
- .0084, .0108, .0141, .0186, .0234, .0276, .0301, .0304,
- .0290, .0269, .0250, .0240, .0235, .0239, .0248, .0260,
- .0271, .0270, .0257, .0230, .0191, .0150, .0111, .0081,
- .0058
+ /* Pleiades1a green of pleiades1a */
+ static const float sr2[191] = {
+ .0001, .0001, .0001, .0001, .0002, .0003, .0004, .0005,
+ .0008, .0046, .0086, .0145, .0246, .0486, .1109, .2379,
+ .4375, .6562, .8184, .8944, .9165, .9230, .9287, .9374,
+ .9507, .9616, .9692, .9772, .9815, .9834, .9876, .9958,
+ 1.0000, .9973, .9849, .9679, .9538, .9542, .9675, .9818,
+ .9868, .9724, .9345, .8829, .8441, .8255, .8103, .7517,
+ .6227, .4368, .2572, .1376, .0778, .0485, .0346, .0270,
+ .0215, .0162, .0108, .0061, .0031, .0016, .0008, .0005,
+ .0003, .0002, .0001, .0001, .0001, .0001, .0001, .0001,
+ .0001, .0000, .0000, .0000, .0000, .0000, .0000, .0000,
+ .0000, .0000, .0000, .0000, .0001, .0002, .0002, .0002,
+ .0001, .0001, .0001, .0000, .0000, .0000, .0000, .0000,
+ .0000, .0001, .0000, .0000, .0001, .0001, .0001, .0002,
+ .0004, .0010, .0042, .0067, .0079, .0069, .0030, .0011,
+ .0007, .0006, .0005, .0005, .0005, .0006, .0008, .0011,
+ .0017, .0031, .0056, .0092, .0126, .0146, .0143, .0119,
+ .0091, .0069, .0057, .0053, .0054, .0061, .0068, .0084,
+ .0108, .0141, .0186, .0234, .0276, .0301, .0304, .0290,
+ .0269, .0250, .0240, .0235, .0239, .0248, .0260, .0271,
+ .0270, .0257, .0230, .0191, .0150, .0111, .0081
- /* Pleiades1a Red of pleiades1a */
- static const float sr3[209] = {
- .0097, .0035, .0035, .0114, .0267, .0374, .0905, .0908,
- .0400, .0209, .0081, .0027, .0011, .0006, .0005, .0006,
- .0010, .0019, .0015, .0006, .0003, .0003, .0003, .0003,
- .0005, .0008, .0005, .0002, .0001, .0001, .0000, .0000,
- .0000, .0000, .0001, .0001, .0001, .0001, .0001, .0001,
- .0001, .0002, .0002, .0003, .0004, .0006, .0010, .0033,
- .0100, .0182, .0331, .0625, .1184, .2220, .3759, .5579,
- .7347, .8643, .9326, .9533, .9627, .9534, .9444, .9463,
- .9569, .9700, .9846, .9956, .9999, 1.0000, .9970, .9951,
- .9890, .9864, .9814, .9690, .9551, .9378, .9176, .8929,
- .8669, .8448, .8226, .7893, .7378, .6630, .5666, .4496,
- .3262, .2196, .1417, .0926, .0620, .0457, .0356, .0311,
- .0295, .0234, .0190, .0159, .0132, .0108, .0084, .0064,
- .0047, .0034, .0024, .0017, .0013, .0010, .0007, .0006,
- .0005, .0004, .0004, .0003, .0003, .0003, .0003, .0003,
- .0003, .0003, .0003, .0004, .0005, .0005, .0006, .0007,
- .0007, .0007, .0006, .0005, .0004, .0004, .0002, .0003,
- .0002, .0002, .0003, .0003, .0003, .0005, .0005, .0007,
- .0008, .0011, .0014, .0019, .0025, .0034, .0042, .0054,
- .0063, .0069, .0071, .0070, .0066, .0068, .0067, .0069,
- .0071, .0074, .0081, .0087, .0097, .0107, .0120, .0137,
- .0160, .0181, .0207, .0237, .0270, .0311, .0353, .0399,
- .0439, .0463, .0455, .0409, .0333, .0251, .0179, .0125,
- .0086
+ /* Pleiades1a red of pleiades1a */
+ static const float sr3[208] = {
+ .0097, .0035, .0035, .0114, .0267, .0374, .0905, .0908,
+ .0400, .0209, .0081, .0027, .0011, .0006, .0005, .0006,
+ .0010, .0019, .0015, .0006, .0003, .0003, .0003, .0003,
+ .0005, .0008, .0005, .0002, .0001, .0001, .0000, .0000,
+ .0000, .0000, .0001, .0001, .0001, .0001, .0001, .0001,
+ .0001, .0002, .0002, .0003, .0004, .0006, .0010, .0033,
+ .0100, .0182, .0331, .0625, .1184, .2220, .3759, .5579,
+ .7347, .8643, .9326, .9533, .9627, .9534, .9444, .9463,
+ .9569, .9700, .9846, .9956, .9999, 1.0000, .9970, .9951,
+ .9890, .9864, .9814, .9690, .9551, .9378, .9176, .8929,
+ .8669, .8448, .8226, .7893, .7378, .6630, .5666, .4496,
+ .3262, .2196, .1417, .0926, .0620, .0457, .0356, .0311,
+ .0295, .0234, .0190, .0159, .0132, .0108, .0084, .0064,
+ .0047, .0034, .0024, .0017, .0013, .0010, .0007, .0006,
+ .0005, .0004, .0004, .0003, .0003, .0003, .0003, .0003,
+ .0003, .0003, .0003, .0004, .0005, .0005, .0006, .0007,
+ .0007, .0007, .0006, .0005, .0004, .0004, .0002, .0003,
+ .0002, .0002, .0003, .0003, .0003, .0005, .0005, .0007,
+ .0008, .0011, .0014, .0019, .0025, .0034, .0042, .0054,
+ .0063, .0069, .0071, .0070, .0066, .0068, .0067, .0069,
+ .0071, .0074, .0081, .0087, .0097, .0107, .0120, .0137,
+ .0160, .0181, .0207, .0237, .0270, .0311, .0353, .0399,
+ .0439, .0463, .0455, .0409, .0333, .0251, .0179, .0125
- /* pleiades1a NIR of pleiades1a */
- static const float sr4[209] = {
- .0024, .0017, .0021, .0021, .0013, .0007, .0006, .0006,
- .0008, .0012, .0021, .0024, .0013, .0006, .0004, .0003,
- .0003, .0003, .0003, .0005, .0009, .0010, .0007, .0004,
- .0003, .0002, .0002, .0003, .0004, .0006, .0007, .0007,
- .0006, .0004, .0003, .0003, .0003, .0003, .0004, .0005,
- .0006, .0007, .0009, .0009, .0009, .0008, .0007, .0006,
- .0005, .0006, .0006, .0008, .0014, .0024, .0027, .0014,
- .0006, .0004, .0002, .0002, .0002, .0002, .0002, .0002,
- .0003, .0007, .0014, .0013, .0006, .0002, .0001, .0001,
- .0000, .0000, .0001, .0001, .0001, .0001, .0001, .0002,
- .0002, .0003, .0004, .0005, .0006, .0008, .0010, .0012,
- .0014, .0016, .0018, .0019, .0021, .0023, .0025, .0038,
- .0045, .0054, .0067, .0084, .0108, .0152, .0214, .0295,
- .0417, .0591, .0841, .1200, .1685, .2344, .3148, .4102,
- .5131, .6196, .7196, .8080, .8783, .9313, .9662, .9859,
- .9959, 1.0000, .9979, .9931, .9853, .9735, .9606, .9494,
- .9376, .9313, .9284, .9275, .9289, .9299, .9302, .9309,
- .9315, .9278, .9226, .9162, .9073, .8975, .8845, .8736,
- .8604, .8494, .8370, .8259, .8132, .7983, .7852, .7720,
- .7580, .7433, .7273, .7098, .6906, .6694, .6464, .6221,
- .5966, .5716, .5472, .5225, .4996, .4771, .4563, .4366,
- .4164, .3950, .3688, .3351, .2940, .2473, .1978, .1498,
- .1077, .0744, .0496, .0331, .0218, .0147, .0104, .0077,
- .0062
+ /* Pleiades1a nir of pleiades1a */
+ static const float sr4[208] = {
+ .0024, .0017, .0021, .0021, .0013, .0007, .0006, .0006,
+ .0008, .0012, .0021, .0024, .0013, .0006, .0004, .0003,
+ .0003, .0003, .0003, .0005, .0009, .0010, .0007, .0004,
+ .0003, .0002, .0002, .0003, .0004, .0006, .0007, .0007,
+ .0006, .0004, .0003, .0003, .0003, .0003, .0004, .0005,
+ .0006, .0007, .0009, .0009, .0009, .0008, .0007, .0006,
+ .0005, .0006, .0006, .0008, .0014, .0024, .0027, .0014,
+ .0006, .0004, .0002, .0002, .0002, .0002, .0002, .0002,
+ .0003, .0007, .0014, .0013, .0006, .0002, .0001, .0001,
+ .0000, .0001, .0001, .0001, .0001, .0001, .0001, .0001,
+ .0002, .0001, .0001, .0001, .0001, .0001, .0001, .0000,
+ .0000, .0000, .0001, .0001, .0001, .0001, .0001, .0002,
+ .0002, .0003, .0004, .0005, .0006, .0008, .0010, .0012,
+ .0014, .0016, .0018, .0019, .0021, .0023, .0025, .0038,
+ .0045, .0054, .0067, .0084, .0108, .0152, .0214, .0295,
+ .0417, .0591, .0841, .1200, .1685, .2344, .3148, .4102,
+ .5131, .6196, .7196, .8080, .8783, .9313, .9662, .9859,
+ .9959, 1.0000, .9979, .9931, .9853, .9735, .9606, .9494,
+ .9376, .9313, .9284, .9275, .9289, .9299, .9302, .9309,
+ .9315, .9278, .9226, .9162, .9073, .8975, .8845, .8736,
+ .8604, .8494, .8370, .8259, .8132, .7983, .7852, .7720,
+ .7580, .7433, .7273, .7098, .6906, .6694, .6464, .6221,
+ .5966, .5716, .5472, .5225, .4996, .4771, .4563, .4366,
+ .4164, .3950, .3688, .3351, .2940, .2473, .1978, .1498,
+ .1077, .0744, .0496, .0331, .0218, .0147, .0104, .0077
- /* Pleiades1a Pan of pleiades1a */
- static const float sr5[209] = {
- .0004, .0008, .0030, .0061, .0130, .0240, .0422, .0718,
- .1152, .1739, .2443, .3204, .3941, .4553, .5016, .5325,
- .5538, .5684, .5825, .5968, .6108, .6233, .6336, .6422,
- .6502, .6571, .6641, .6708, .6766, .6809, .6830, .6835,
- .6832, .6832, .6847, .6893, .6965, .7074, .7194, .7324,
- .7450, .7555, .7639, .7717, .7777, .7827, .7872, .7914,
- .7950, .7975, .7998, .8008, .8004, .8003, .8001, .8013,
- .8037, .8078, .8137, .8211, .8304, .8391, .8483, .8565,
- .8635, .8690, .8739, .8769, .8801, .8826, .8851, .8895,
- .8940, .8995, .9057, .9125, .9190, .9246, .9290, .9339,
- .9375, .9416, .9450, .9481, .9511, .9533, .9561, .9582,
- .9602, .9610, .9632, .9650, .9675, .9730, .9775, .9829,
- .9875, .9928, .9967, .9995, 1.0000, .9944, .9883, .9812,
- .9752, .9701, .9661, .9633, .9625, .9622, .9634, .9655,
- .9672, .9673, .9678, .9654, .9634, .9580, .9534, .9487,
- .9424, .9359, .9300, .9245, .9191, .9142, .9089, .9041,
- .8981, .8928, .8871, .8829, .8773, .8735, .8695, .8665,
- .8661, .8589, .8478, .8332, .8137, .7867, .7491, .6982,
- .6307, .5507, .4617, .3696, .2824, .2075, .1465, .1010,
- .0687, .0471, .0324, .0247, .0174, .0127, .0117, .0087,
- .0082, .0000, .0000, .0000, .0000, .0000, .0000, .0000,
- .0000
+ /* Pleiades1a pan of pleiades1a */
+ static const float sr5[162] = {
+ .0000, .0004, .0008, .0030, .0061, .0130, .0240, .0422,
+ .0718, .1152, .1739, .2443, .3204, .3941, .4553, .5016,
+ .5325, .5538, .5684, .5825, .5968, .6108, .6233, .6336,
+ .6422, .6502, .6571, .6641, .6708, .6766, .6809, .6830,
+ .6835, .6832, .6832, .6847, .6893, .6965, .7074, .7194,
+ .7324, .7450, .7555, .7639, .7717, .7777, .7827, .7872,
+ .7914, .7950, .7975, .7998, .8008, .8004, .8003, .8001,
+ .8013, .8037, .8078, .8137, .8211, .8304, .8391, .8483,
+ .8565, .8635, .8690, .8739, .8769, .8801, .8826, .8851,
+ .8895, .8940, .8995, .9057, .9125, .9190, .9246, .9290,
+ .9339, .9375, .9416, .9450, .9481, .9511, .9533, .9561,
+ .9582, .9602, .9610, .9632, .9650, .9675, .9730, .9775,
+ .9829, .9875, .9928, .9967, .9995, 1.0000, .9944, .9883,
+ .9812, .9752, .9701, .9661, .9633, .9625, .9622, .9634,
+ .9655, .9672, .9673, .9678, .9654, .9634, .9580, .9534,
+ .9487, .9424, .9359, .9300, .9245, .9191, .9142, .9089,
+ .9041, .8981, .8928, .8871, .8829, .8773, .8735, .8695,
+ .8665, .8661, .8589, .8478, .8332, .8137, .7867, .7491,
+ .6982, .6307, .5507, .4617, .3696, .2824, .2075, .1465,
+ .1010, .0687, .0471, .0324, .0247, .0174, .0127, .0117,
+ .0087, .0082
- static const float wli[5] = {0.430, 0.430, 0.430, 0.430, 0.430};
- static const float wls[5] = {0.950, 0.950, 0.950, 0.950, 0.950};
+ static const float wli[5] = {0.4300, 0.4725, 0.4300, 0.4300, 0.4475};
+ static const float wls[5] = {0.9500, 0.9500, 0.9500, 0.9500, 0.8525};
@@ -3888,15 +3710,15 @@
switch(iwa)
- case 1: for(i = 0; i < 209; i++) ffu.s[72+i] = sr1[i];
+ case 1: for(i = 0; i < 208; i++) ffu.s[72+i] = sr1[i];
break;
- case 2: for(i = 0; i < 209; i++) ffu.s[72+i] = sr2[i];
+ case 2: for(i = 0; i < 191; i++) ffu.s[89+i] = sr2[i];
break;
- case 3: for(i = 0; i < 209; i++) ffu.s[72+i] = sr3[i];
+ case 3: for(i = 0; i < 208; i++) ffu.s[72+i] = sr3[i];
break;
- case 4: for(i = 0; i < 209; i++) ffu.s[72+i] = sr4[i];
+ case 4: for(i = 0; i < 208; i++) ffu.s[72+i] = sr4[i];
break;
- case 5: for(i = 0; i < 209; i++) ffu.s[72+i] = sr5[i];
+ case 5: for(i = 0; i < 162; i++) ffu.s[79+i] = sr5[i];
break;
@@ -3906,163 +3728,160 @@
void IWave::pleiades1b(int iwa)
- /* pleiades1b Blue of pleiades1b */
- .0016, .0013, .0043, .0111, .0176, .0234, .0574, .1346,
- .2238, .3085, .4616, .6508, .7554, .7477, .7168, .7185,
- .7567, .8101, .8422, .8234, .7752, .7527, .7802, .8199,
- .8517, .8603, .8587, .8658, .8828, .9040, .9197, .9326,
- .9502, .9758, .9950, 1.0000, .9951, .9806, .9417, .8436,
- .6711, .4633, .2889, .1671, .0902, .0505, .0315, .0238,
- .0213, .0206, .0196, .0168, .0114, .0067, .0041, .0030,
- .0024, .0020, .0016, .0011, .0013, .0008, .0006, .0004,
- .0004, .0004, .0005, .0011, .0020, .0012, .0004, .0001,
- .0000, .0000, .0000, .0000, .0001, .0002, .0008, .0011,
- .0008, .0004, .0004, .0004, .0007, .0016, .0024, .0010,
- .0003, .0002, .0001, .0001, .0000, .0000, .0000, .0000,
- .0000, .0000, .0000, .0001, .0000, .0001, .0001, .0001,
- .0002, .0003, .0004, .0007, .0009, .0007, .0006, .0004,
- .0003, .0002, .0002, .0002, .0002, .0002, .0002, .0002,
- .0003, .0004, .0004, .0005, .0007, .0010, .0016, .0026,
- .0046, .0091, .0172, .0238, .0215, .0159, .0120, .0095,
- .0079, .0072, .0072, .0076, .0084, .0099, .0123, .0163,
- .0226, .0320, .0444, .0547, .0564, .0480, .0358, .0258,
- .0189, .0144, .0117, .0099, .0086, .0078, .0072, .0070,
- .0069, .0069, .0070, .0073, .0074, .0075, .0075, .0071,
- .0064
+ /* Pleiades1b blue of pleiades1b */
+ .0016, .0013, .0043, .0111, .0176, .0234, .0574, .1346,
+ .2238, .3085, .4616, .6508, .7554, .7477, .7168, .7185,
+ .7567, .8101, .8422, .8234, .7752, .7527, .7802, .8199,
+ .8517, .8603, .8587, .8658, .8828, .9040, .9197, .9326,
+ .9502, .9758, .9950, 1.0000, .9951, .9806, .9417, .8436,
+ .6711, .4633, .2889, .1671, .0902, .0505, .0315, .0238,
+ .0213, .0206, .0196, .0168, .0114, .0067, .0041, .0030,
+ .0024, .0020, .0016, .0011, .0013, .0008, .0006, .0004,
+ .0004, .0004, .0005, .0011, .0020, .0012, .0004, .0001,
+ .0001, .0001, .0001, .0001, .0001, .0000, .0000, .0000,
+ .0000, .0000, .0000, .0000, .0001, .0002, .0008, .0011,
+ .0008, .0004, .0004, .0004, .0007, .0016, .0024, .0010,
+ .0003, .0002, .0001, .0001, .0000, .0000, .0000, .0000,
+ .0000, .0000, .0000, .0001, .0000, .0001, .0001, .0001,
+ .0002, .0003, .0004, .0007, .0009, .0007, .0006, .0004,
+ .0003, .0002, .0002, .0002, .0002, .0002, .0002, .0002,
+ .0003, .0004, .0004, .0005, .0007, .0010, .0016, .0026,
+ .0046, .0091, .0172, .0238, .0215, .0159, .0120, .0095,
+ .0079, .0072, .0072, .0076, .0084, .0099, .0123, .0163,
+ .0226, .0320, .0444, .0547, .0564, .0480, .0358, .0258,
+ .0189, .0144, .0117, .0099, .0086, .0078, .0072, .0070,
+ .0069, .0069, .0070, .0073, .0074, .0075, .0075, .0071
- /* Pleiades1b Green of pleiades1b */
- .0001, .0001, .0001, .0002, .0003, .0005, .0006, .0008,
- .0015, .0041, .0100, .0196, .0325, .0568, .1238, .2859,
- .5290, .7716, .8838, .9080, .9131, .9137, .9225, .9367,
- .9498, .9545, .9586, .9642, .9705, .9723, .9675, .9589,
- .9524, .9525, .9560, .9552, .9490, .9471, .9544, .9711,
- .9898, 1.0000, .9954, .9698, .9253, .8633, .7948, .7239,
- .6453, .5439, .4170, .2767, .1575, .0856, .0492, .0327,
- .0238, .0182, .0141, .0100, .0058, .0030, .0015, .0008,
- .0000, .0001, .0000, .0000, .0001, .0001, .0001, .0003,
- .0003, .0002, .0001, .0000, .0000, .0000, .0000, .0000,
- .0000, .0001, .0001, .0001, .0003, .0007, .0032, .0142,
- .0083, .0022, .0009, .0006, .0004, .0004, .0004, .0004,
- .0005, .0006, .0008, .0011, .0019, .0037, .0064, .0103,
- .0131, .0133, .0111, .0084, .0066, .0057, .0054, .0056,
- .0062, .0072, .0089, .0115, .0149, .0193, .0235, .0264,
- .0270, .0255, .0234, .0214, .0199, .0193, .0191, .0197,
- .0207, .0220, .0232, .0238, .0230, .0207, .0172, .0133,
- .0098
+ /* Pleiades1b green of pleiades1b */
+ static const float sr2[192] = {
+ .0001, .0001, .0001, .0002, .0003, .0005, .0006, .0008,
+ .0015, .0041, .0100, .0196, .0325, .0568, .1238, .2859,
+ .5290, .7716, .8838, .9080, .9131, .9137, .9225, .9367,
+ .9498, .9545, .9586, .9642, .9705, .9723, .9675, .9589,
+ .9524, .9525, .9560, .9552, .9490, .9471, .9544, .9711,
+ .9898, 1.0000, .9954, .9698, .9253, .8633, .7948, .7239,
+ .6453, .5439, .4170, .2767, .1575, .0856, .0492, .0327,
+ .0238, .0182, .0141, .0100, .0058, .0030, .0015, .0008,
+ .0005, .0003, .0002, .0001, .0001, .0001, .0001, .0001,
+ .0000, .0001, .0000, .0000, .0001, .0001, .0001, .0003,
+ .0000, .0000, .0000, .0000, .0000, .0000, .0000, .0001,
+ .0003, .0002, .0001, .0000, .0000, .0000, .0000, .0000,
+ .0000, .0001, .0001, .0001, .0003, .0007, .0032, .0142,
+ .0083, .0022, .0009, .0006, .0004, .0004, .0004, .0004,
+ .0005, .0006, .0008, .0011, .0019, .0037, .0064, .0103,
+ .0131, .0133, .0111, .0084, .0066, .0057, .0054, .0056,
+ .0062, .0072, .0089, .0115, .0149, .0193, .0235, .0264,
+ .0270, .0255, .0234, .0214, .0199, .0193, .0191, .0197,
+ .0207, .0220, .0232, .0238, .0230, .0207, .0172, .0133
- /* Pleiades1b Red of pleiades1b */
- .0005, .0009, .0005, .0012, .0051, .0080, .0067, .0109,
- .0247, .0654, .1225, .0570, .0214, .0128, .0063, .0024,
- .0009, .0005, .0004, .0004, .0005, .0008, .0010, .0006,
- .0004, .0003, .0002, .0003, .0004, .0005, .0005, .0004,
- .0003, .0002, .0001, .0001, .0001, .0001, .0001, .0000,
- .0002, .0002, .0007, .0012, .0021, .0038, .0068, .0123,
- .0222, .0413, .0781, .1519, .2777, .4510, .6291, .7625,
- .8329, .8579, .8659, .8693, .8752, .8858, .9006, .9175,
- .9349, .9478, .9570, .9623, .9648, .9624, .9613, .9620,
- .9699, .9812, .9934, 1.0000, .9810, .9523, .9132, .8694,
- .8252, .7830, .7361, .6735, .5878, .4805, .3630, .2523,
- .1626, .1022, .0641, .0419, .0285, .0205, .0154, .0121,
- .0099, .0083, .0071, .0061, .0052, .0043, .0035, .0028,
- .0036, .0030, .0023, .0018, .0013, .0010, .0008, .0006,
- .0005, .0004, .0004, .0004, .0003, .0003, .0003, .0003,
- .0003, .0003, .0003, .0003, .0004, .0004, .0005, .0006,
- .0006, .0007, .0007, .0006, .0005, .0005, .0004, .0003,
- .0003, .0003, .0002, .0002, .0002, .0002, .0002, .0002,
- .0002, .0002, .0002, .0003, .0003, .0003, .0003, .0004,
- .0005, .0006, .0008, .0010, .0013, .0018, .0024, .0033,
- .0044, .0057, .0069, .0078, .0083, .0084, .0082, .0081,
- .0080, .0078, .0078, .0080, .0082, .0085, .0088, .0093,
- .0098, .0101, .0104, .0104, .0102, .0095, .0086, .0073,
- .0060
+ /* Pleiades1b red of pleiades1b */
+ .0005, .0009, .0005, .0012, .0051, .0080, .0067, .0109,
+ .0247, .0654, .1225, .0570, .0214, .0128, .0063, .0024,
+ .0009, .0005, .0004, .0004, .0005, .0008, .0010, .0006,
+ .0004, .0003, .0002, .0003, .0004, .0005, .0005, .0004,
+ .0003, .0002, .0001, .0001, .0001, .0001, .0001, .0000,
+ .0002, .0002, .0007, .0012, .0021, .0038, .0068, .0123,
+ .0222, .0413, .0781, .1519, .2777, .4510, .6291, .7625,
+ .8329, .8579, .8659, .8693, .8752, .8858, .9006, .9175,
+ .9349, .9478, .9570, .9623, .9648, .9624, .9613, .9620,
+ .9699, .9812, .9934, 1.0000, .9810, .9523, .9132, .8694,
+ .8252, .7830, .7361, .6735, .5878, .4805, .3630, .2523,
+ .1626, .1022, .0641, .0419, .0285, .0205, .0154, .0121,
+ .0099, .0083, .0071, .0061, .0052, .0043, .0035, .0028,
+ .0036, .0030, .0023, .0018, .0013, .0010, .0008, .0006,
+ .0005, .0004, .0004, .0004, .0003, .0003, .0003, .0003,
+ .0003, .0003, .0003, .0003, .0004, .0004, .0005, .0006,
+ .0006, .0007, .0007, .0006, .0005, .0005, .0004, .0003,
+ .0003, .0003, .0002, .0002, .0002, .0002, .0002, .0002,
+ .0002, .0002, .0002, .0003, .0003, .0003, .0003, .0004,
+ .0005, .0006, .0008, .0010, .0013, .0018, .0024, .0033,
+ .0044, .0057, .0069, .0078, .0083, .0084, .0082, .0081,
+ .0080, .0078, .0078, .0080, .0082, .0085, .0088, .0093,
+ .0098, .0101, .0104, .0104, .0102, .0095, .0086, .0073
- /* pleiades1b NIR of pleiades1b */
- .0002, .0008, .0004, .0005, .0017, .0027, .0012, .0007,
- .0007, .0008, .0008, .0010, .0015, .0022, .0020, .0010,
- .0005, .0003, .0002, .0002, .0002, .0003, .0004, .0006,
- .0006, .0004, .0003, .0002, .0002, .0002, .0002, .0002,
- .0004, .0006, .0007, .0006, .0005, .0004, .0004, .0004,
- .0004, .0005, .0006, .0006, .0007, .0008, .0008, .0007,
- .0006, .0006, .0005, .0005, .0005, .0006, .0007, .0012,
- .0023, .0029, .0020, .0008, .0004, .0002, .0001, .0001,
- .0001, .0001, .0001, .0001, .0002, .0003, .0005, .0008,
- .0007, .0003, .0002, .0001, .0001, .0001, .0000, .0000,
- .0000, .0000, .0000, .0000, .0001, .0001, .0001, .0001,
- .0001, .0002, .0002, .0002, .0002, .0001, .0001, .0001,
- .0001, .0001, .0001, .0001, .0002, .0002, .0003, .0003,
- .0004, .0005, .0006, .0008, .0010, .0012, .0014, .0016,
- .0018, .0020, .0023, .0025, .0029, .0052, .0064, .0080,
- .0101, .0131, .0171, .0229, .0310, .0427, .0592, .0835,
- .1179, .1664, .2311, .3159, .4172, .5285, .6410, .7472,
- .8386, .9088, .9594, .9881, 1.0000, .9992, .9896, .9677,
- .9514, .9375, .9255, .9152, .9088, .9026, .8967, .8925,
- .8855, .8777, .8676, .8569, .8474, .8360, .8237, .8130,
- .8016, .7922, .7828, .7769, .7715, .7631, .7543, .7452,
- .7349, .7255, .7146, .7031, .6919, .6816, .6705, .6595,
- .6476, .6292, .6111, .5934, .5761, .5600, .5449, .5306,
- .5155, .4977, .4734, .4388, .3934, .3368, .2743, .2114,
- .1536, .1063, .0704, .0459, .0295, .0193, .0127, .0085,
- .0058
+ /* Pleiades1b nir of pleiades1b */
+ .0002, .0008, .0004, .0005, .0017, .0027, .0012, .0007,
+ .0007, .0008, .0008, .0010, .0015, .0022, .0020, .0010,
+ .0005, .0003, .0002, .0002, .0002, .0003, .0004, .0006,
+ .0006, .0004, .0003, .0002, .0002, .0002, .0002, .0002,
+ .0004, .0006, .0007, .0006, .0005, .0004, .0004, .0004,
+ .0004, .0005, .0006, .0006, .0007, .0008, .0008, .0007,
+ .0006, .0006, .0005, .0005, .0005, .0006, .0007, .0012,
+ .0023, .0029, .0020, .0008, .0004, .0002, .0001, .0001,
+ .0001, .0001, .0001, .0001, .0002, .0003, .0005, .0008,
+ .0007, .0003, .0002, .0001, .0001, .0001, .0000, .0000,
+ .0000, .0000, .0000, .0000, .0001, .0001, .0001, .0001,
+ .0001, .0002, .0002, .0002, .0002, .0001, .0001, .0001,
+ .0001, .0001, .0001, .0001, .0002, .0002, .0003, .0003,
+ .0004, .0005, .0006, .0008, .0010, .0012, .0014, .0016,
+ .0018, .0020, .0023, .0025, .0029, .0052, .0064, .0080,
+ .0101, .0131, .0171, .0229, .0310, .0427, .0592, .0835,
+ .1179, .1664, .2311, .3159, .4172, .5285, .6410, .7472,
+ .8386, .9088, .9594, .9881, 1.0000, .9992, .9896, .9677,
+ .9514, .9375, .9255, .9152, .9088, .9026, .8967, .8925,
+ .8855, .8777, .8676, .8569, .8474, .8360, .8237, .8130,
+ .8016, .7922, .7828, .7769, .7715, .7631, .7543, .7452,
+ .7349, .7255, .7146, .7031, .6919, .6816, .6705, .6595,
+ .6476, .6292, .6111, .5934, .5761, .5600, .5449, .5306,
+ .5155, .4977, .4734, .4388, .3934, .3368, .2743, .2114,
+ .1536, .1063, .0704, .0459, .0295, .0193, .0127, .0085
- /* Pleiades1b Pan of pleiades1b */
- .0000, .0000, .0000, .0000, .0001, .0001, .0001, .0002,
- .0004, .0008, .0028, .0056, .0120, .0221, .0389, .0664,
- .1067, .1614, .2272, .2987, .3678, .4258, .4697, .4992,
- .5193, .5333, .5467, .5603, .5736, .5855, .5957, .6041,
- .6120, .6188, .6256, .6319, .6378, .6422, .6444, .6449,
- .6449, .6451, .6468, .6513, .6591, .6691, .6812, .6937,
- .7056, .7158, .7251, .7324, .7384, .7439, .7493, .7536,
- .7581, .7611, .7639, .7652, .7662, .7666, .7675, .7688,
- .7723, .7771, .7834, .7917, .8015, .8110, .8200, .8291,
- .8365, .8427, .8482, .8519, .8555, .8583, .8620, .8667,
- .8716, .8780, .8847, .8913, .8989, .9046, .9105, .9155,
- .9208, .9253, .9290, .9329, .9370, .9401, .9442, .9469,
- .9503, .9521, .9543, .9574, .9608, .9663, .9721, .9788,
- .9846, .9912, .9957, .9991, 1.0000, .9963, .9915, .9870,
- .9817, .9771, .9746, .9729, .9739, .9742, .9769, .9798,
- .9828, .9846, .9851, .9837, .9826, .9790, .9746, .9697,
- .9648, .9598, .9533, .9484, .9445, .9397, .9345, .9297,
- .9248, .9183, .9112, .9061, .9006, .8953, .8908, .8895,
- .8885, .8810, .8708, .8567, .8369, .8102, .7729, .7190,
- .6529, .5711, .4796, .3846, .2948, .2166, .1531, .1057,
- .0717, .0491, .0338, .0257, .0182, .0132, .0122, .0090,
- .0084, .0043, .0033, .0027, .0022, .0018, .0015, .0014,
- .0012, .0011, .0010, .0009, .0009, .0008, .0007, .0007,
- .0007, .0006, .0006, .0006, .0006, .0006, .0005, .0005,
- .0005, .0005, .0004, .0004, .0004, .0005, .0004, .0004,
- .0004, .0004, .0004, .0004, .0003, .0004, .0003, .0003,
- .0003
+ /* Pleiades1b pan of pleiades1b */
+ static const float sr5[203] = {
+ .0001, .0001, .0002, .0004, .0008, .0028, .0056, .0120,
+ .0221, .0389, .0664, .1067, .1614, .2272, .2987, .3678,
+ .4258, .4697, .4992, .5193, .5333, .5467, .5603, .5736,
+ .5855, .5957, .6041, .6120, .6188, .6256, .6319, .6378,
+ .6422, .6444, .6449, .6449, .6451, .6468, .6513, .6591,
+ .6691, .6812, .6937, .7056, .7158, .7251, .7324, .7384,
+ .7439, .7493, .7536, .7581, .7611, .7639, .7652, .7662,
+ .7666, .7675, .7688, .7723, .7771, .7834, .7917, .8015,
+ .8110, .8200, .8291, .8365, .8427, .8482, .8519, .8555,
+ .8583, .8620, .8667, .8716, .8780, .8847, .8913, .8989,
+ .9046, .9105, .9155, .9208, .9253, .9290, .9329, .9370,
+ .9401, .9442, .9469, .9503, .9521, .9543, .9574, .9608,
+ .9663, .9721, .9788, .9846, .9912, .9957, .9991, 1.0000,
+ .9963, .9915, .9870, .9817, .9771, .9746, .9729, .9739,
+ .9742, .9769, .9798, .9828, .9846, .9851, .9837, .9826,
+ .9790, .9746, .9697, .9648, .9598, .9533, .9484, .9445,
+ .9397, .9345, .9297, .9248, .9183, .9112, .9061, .9006,
+ .8953, .8908, .8895, .8885, .8810, .8708, .8567, .8369,
+ .8102, .7729, .7190, .6529, .5711, .4796, .3846, .2948,
+ .2166, .1531, .1057, .0717, .0491, .0338, .0257, .0182,
+ .0132, .0122, .0090, .0084, .0043, .0033, .0027, .0022,
+ .0018, .0015, .0014, .0012, .0011, .0010, .0009, .0009,
+ .0008, .0007, .0007, .0007, .0006, .0006, .0006, .0006,
+ .0006, .0005, .0005, .0005, .0005, .0004, .0004, .0004,
+ .0005, .0004, .0004, .0004, .0004, .0004, .0004, .0003,
+ static const float wli[5] = {0.4300, 0.4700, 0.4300, 0.4300, 0.4425};
+ static const float wls[5] = {0.9500, 0.9500, 0.9500, 0.9500, 0.9500};
ffu.wlinf = (float)wli[iwa-1];
ffu.wlsup = (float)wls[iwa-1];
@@ -4072,15 +3891,15 @@
switch(iwa)
break;
+ case 2: for(i = 0; i < 192; i++) ffu.s[88+i] = sr2[i];
break;
break;
break;
+ case 5: for(i = 0; i < 203; i++) ffu.s[77+i] = sr5[i];
break;
@@ -4373,1572 +4192,123 @@
void IWave::sentinel2a(int iwa)
- /* SR_AV_B1 of sentinel_2A_msi */
- static const float sr1[920] = {
- .0000, .0000, .0000, .0000, .0000, .0000, .0000, .0000,
- .0000, .0000, .0000, .0000, .0153, .2766, .5116, .6004,
- .6992, .8274, .9939, .9815, .9567, .5561, .0518, .0002,
+ /* S2A_SR_AV_B1 of sentinel_2A_msi */
+ static const float sr1[21] = {
+ .0000, .0000, .0029, .0035, .0032, .0020, .0009, .0014,
+ .0017, .0290, .4483, .7620, .8098, .8542, .9068, 1.0000,
+ .9130, .8257, .4721, .0437, .0000
- /* SR_AV_B2 of sentinel_2A_msi */
- static const float sr2[920] = {
- .0012, .0027, .0021, .0025, .0024, .0030, .0090, .0615,
- .2922, .3841, .4002, .4370, .5053, .5321, .5347, .5507,
- .6020, .6173, .5759, .5441, .5717, .6533, .7384, .7708,
- .7884, .8166, .8450, .8330, .7869, .7637, .8100, .9282,
- 1.0000, .8162, .2870, .0840, .0251, .0018, .0004, .0002,
+ /* S2A_SR_AV_B2 of sentinel_2A_msi */
+ static const float sr2[41] = {
+ .0000, .0000, .0300, .0222, .0246, .0188, .0185, .0184,
+ .0274, .1130, .5534, .7526, .7633, .8004, .8928, .9161,
+ .8899, .8802, .9323, .9329, .8474, .7778, .7874, .8669,
+ .9507, .9675, .9541, .9613, .9771, .9470, .8717, .8191,
+ .8395, .9380, 1.0000, .8257, .3050, .0867, .0266, .0017,
+ .0000
- /* SR_AV_B3 of sentinel_2A_msi */
- static const float sr3[920] = {
- .0000, .0000, .0000, .0000, .0000, .0000, .0000, .0086,
- .0807, .4572, .8280, .8901, .8603, .8333, .8677, .9504,
- 1.0000, .9641, .8687, .8027, .7896, .8384, .8580, .5060,
- .0983, .0083, .0000, .0000, .0000, .0000, .0000, .0000,
+ /* S2A_SR_AV_B3 of sentinel_2A_msi */
+ static const float sr3[21] = {
+ .0000, .0072, .0735, .4349, .8489, .9236, .8882, .8430,
+ .8622, .9423, 1.0000, .9630, .8558, .7766, .7506, .7907,
+ .8141, .5164, .1072, .0098, .0000
- /* SR_AV_B4 of sentinel_2A_msi */
- static const float sr4[920] = {
- .0000, .0000, .0000, .0922, .8177, .9904, .9954, .9570,
- .8142, .7700, .8308, .8963, .9559, .9724, .9657, .9145,
- .4230, .0419, .0000, .0000, .0000, .0000, .0000, .0000,
+ /* S2A_SR_AV_B4 of sentinel_2A_msi */
+ static const float sr4[18] = {
+ .0000, .0000, .0712, .7496, .9871, .9955, .9589, .8163,
+ .7572, .8102, .8737, .9341, .9598, .9581, .9193, .4768,
+ .0531, .0000
- /* SR_AV_B5 of sentinel_2A_msi */
- static const float sr5[920] = {
- .0000, .0000, .0000, .0000, .0000, .0000, .0413, .6562,
- 1.0000, .9878, .9460, .8940, .7572, .1168, .0000, .0000,
+ /* S2A_SR_AV_B5 of sentinel_2A_msi */
+ static const float sr5[10] = {
+ .0000, .0284, .5775, .9989, .9887, .9485, .8949, .7908,
+ .1601, .0000
- /* SR_AV_B6 of sentinel_2A_msi */
- static const float sr6[920] = {
- .0000, .0000, .0000, .0000, .0000, .2154, .9203, .9460,
- .9819, .9967, .9626, .3210, .0000, .0000, .0000, .0000,
+ /* S2A_SR_AV_B6 of sentinel_2A_msi */
+ static const float sr6[10] = {
+ .0000, .0000, .1564, .8922, .9281, .9751, .9937, .9718,
+ .4060, .0000
- /* SR_AV_B7 of sentinel_2A_msi */
- static const float sr7[920] = {
- .0000, .0000, .0000, .0000, .0147, .3111, .8985, .9974,
- .9647, .8245, .7772, .8019, .7577, .4504, .0772, .0016,
+ /* S2A_SR_AV_B7 of sentinel_2A_msi */
+ static const float sr7[14] = {
+ .0000, .0000, .0117, .2673, .8612, .9951, .9773, .8429,
+ .7911, .8224, .7922, .5010, .0985, .0026
- /* SR_AV_B8 of sentinel_2A_msi */
- static const float sr8[920] = {
- .0014, .0000, .0000, .0000, .0000, .0002, .0191, .0718,
- .2034, .5188, .8183, .9772, .9852, .9312, .9413, .9639,
- .9590, .9441, .9454, .9325, .9010, .8527, .8018, .7468,
- .7087, .6862, .6826, .6736, .6608, .6612, .6855, .7315,
- .7766, .7877, .7762, .7526, .7206, .6834, .6493, .6232,
- .6043, .5893, .5812, .5814, .5895, .5991, .6055, .6161,
- .6374, .6633, .6599, .5997, .5264, .4978, .5291, .5170,
- .3268, .1191, .0332, .0046, .0000, .0000, .0000, .0000,
+ /* S2A_SR_AV_B8 of sentinel_2A_msi */
+ static const float sr8[61] = {
+ .0000, .0007, .0000, .0000, .0000, .0000, .0001, .0175,
+ .0681, .1959, .5035, .8030, .9709, .9884, .9395, .9540,
+ .9826, .9839, .9777, .9876, .9835, .9572, .9065, .8516,
+ .7916, .7496, .7268, .7256, .7192, .7083, .7001, .7182,
+ .7583, .7968, .8035, .7892, .7582, .7226, .6744, .6301,
+ .5962, .5714, .5490, .5351, .5300, .5321, .5329, .5305,
+ .5313, .5424, .5577, .5482, .4929, .4280, .4006, .4209,
+ .4080, .2572, .0934, .0259, .0020
- /* SR_AV_B8A of sentinel_2A_msi */
- static const float sr9[920] = {
- .0000, .0000, .0000, .0008, .0247, .1608, .5857, .8967,
- .9260, .9413, .9655, .9816, .9885, .9603, .4722, .0765,
- .0088, .0000, .0000, .0000, .0000, .0000, .0000, .0000,
+ /* S2A_SR_AV_B8A of sentinel_2A_msi */
+ static const float sr9[21] = {
+ .0000, .0000, .0002, .0000, .0000, .0000, .0020, .0261,
+ .1647, .6099, .9522, .9754, .9782, .9909, .9996, .9954,
+ .9600, .4897, .0799, .0106, .0000
- /* SR_AV_B9 of sentinel_2A_msi */
- static const float sr10[920] = {
- .0000, .0000, .0000, .0000, .0000, .0419, .4081, .9018,
- .9836, .9870, .9981, .9938, .9564, .8974, .4504, .0369,
+ /* S2A_SR_AV_B9 of sentinel_2A_msi */
+ static const float sr10[14] = {
+ .0000, .0000, .0389, .3895, .9058, .9893, .9892, .9922,
+ .9889, .9502, .8891, .4643, .0408, .0000
- /* SR_AV_B10 of sentinel_2A_msi */
- static const float sr11[920] = {
- .0000, .0000, .0000, .0000, .0000, .0000, .0000, .0001,
- .0000, .0001, .0002, .0004, .0011, .0059, .0447, .2716,
- .6625, .8856, .9620, .9848, .9965, .9995, .9910, .9742,
- .9486, .9045, .8307, .5816, .2193, .0505, .0055, .0008,
- .0002, .0002, .0001, .0000, .0001, .0000, .0000, .0000,
+ /* S2A_SR_AV_B10 of sentinel_2A_msi */
+ static const float sr11[33] = {
+ .0000, .0000, .0001, .0000, .0001, .0002, .0004, .0011,
+ .0059, .0447, .2716, .6625, .8856, .9620, .9848, .9965,
+ .9995, .9910, .9742, .9486, .9045, .8307, .5816, .2193,
+ .0505, .0055, .0008, .0002, .0002, .0001, .0000, .0001,
+ .0000
- /* SR_AV_B11 of sentinel_2A_msi */
- static const float sr12[920] = {
- .0000, .0000, .0001, .0005, .0009, .0021, .0053, .0158,
- .0396, .0880, .1826, .3802, .6472, .8372, .8870, .8945,
- .9165, .9389, .9514, .9573, .9635, .9696, .9759, .9802,
- .9814, .9805, .9827, .9891, .9933, .9888, .9800, .9712,
- .9664, .9667, .9735, .9856, .9955, .9989, .9988, .9997,
- .9998, .9887, .9699, .9499, .9386, .9201, .8250, .5879,
- .3237, .1371, .0462, .0163, .0065, .0029, .0014, .0004,
+ /* S2A_SR_AV_B11 of sentinel_2A_msi */
+ static const float sr12[56] = {
+ .0000, .0001, .0005, .0009, .0021, .0053, .0158, .0396,
+ .0880, .1826, .3802, .6472, .8372, .8870, .8945, .9165,
+ .9389, .9514, .9573, .9635, .9696, .9759, .9802, .9814,
+ .9805, .9827, .9891, .9933, .9888, .9800, .9712, .9664,
+ .9667, .9735, .9856, .9955, .9989, .9988, .9997, .9998,
+ .9887, .9699, .9499, .9386, .9201, .8250, .5879, .3237,
+ .1371, .0462, .0163, .0065, .0029, .0014, .0004, .0000
- /* SR_AV_B12 of sentinel_2A_msi */
- static const float sr13[920] = {
- .0000, .0000, .0000, .0000, .0000, .0000, .0000, .0003,
- .0029, .0071, .0085, .0105, .0134, .0185, .0277, .0446,
- .0732, .1242, .2035, .3060, .4080, .4898, .5434, .5738,
- .5989, .6278, .6637, .7041, .7413, .7788, .8097, .8327,
- .8511, .8555, .8595, .8642, .8697, .8805, .8895, .8983,
- .9048, .9056, .9048, .9031, .9020, .9048, .9081, .9143,
- .9213, .9285, .9341, .9374, .9377, .9429, .9421, .9375,
- .9330, .9183, .9083, .9097, .9229, .9195, .9245, .9344,
- .9468, .9557, .9625, .9663, .9655, .9627, .9573, .9531,
- .9517, .9533, .9606, .9705, .9829, .9924, .9988, .9995,
- .9939, .9800, .9583, .9330, .9060, .8752, .8406, .8007,
- .7491, .6697, .5660, .4520, .3421, .2454, .1681, .1165,
- .0824, .0588, .0429, .0335, .0274, .0228, .0163, .0069,
- .0021, .0000, .0000, .0000, .0000, .0000, .0000, .0000,
+ /* S2A_SR_AV_B12 of sentinel_2A_msi */
+ static const float sr13[99] = {
+ .0000, .0003, .0029, .0071, .0085, .0105, .0134, .0185,
+ .0277, .0446, .0732, .1242, .2035, .3060, .4080, .4898,
+ .5434, .5738, .5989, .6278, .6637, .7041, .7413, .7788,
+ .8097, .8327, .8511, .8555, .8595, .8642, .8697, .8805,
+ .8895, .8983, .9048, .9056, .9048, .9031, .9020, .9048,
+ .9081, .9143, .9213, .9285, .9341, .9374, .9377, .9429,
+ .9421, .9375, .9330, .9183, .9083, .9097, .9229, .9195,
+ .9245, .9344, .9468, .9557, .9625, .9663, .9655, .9627,
+ .9573, .9531, .9517, .9533, .9606, .9705, .9829, .9924,
+ .9988, .9995, .9939, .9800, .9583, .9330, .9060, .8752,
+ .8406, .8007, .7491, .6697, .5660, .4520, .3421, .2454,
+ .1681, .1165, .0824, .0588, .0429, .0335, .0274, .0228,
+ .0163, .0069, .0021
- static const float wli[13] = {0.300, 0.300, 0.300, 0.300, 0.300, 0.300, 0.300, 0.300, 0.300, 0.300, 0.300, 0.300, 0.300};
- static const float wls[13] = {2.600, 2.600, 2.600, 2.600, 2.600, 2.600, 2.600, 2.600, 2.600, 2.600, 2.600, 2.600, 2.600};
+ static const float wli[13] = {0.4075, 0.4350, 0.5350, 0.6425, 0.6925, 0.7275, 0.7650, 0.7575, 0.8325, 0.9275, 1.3325, 1.5425, 2.0750};
+ static const float wls[13] = {0.4600, 0.5375, 0.5875, 0.6875, 0.7175, 0.7525, 0.8000, 0.9100, 0.8850, 0.9625, 1.4150, 1.6825, 2.3225};
@@ -5948,36 +4318,189 @@
switch(iwa)
- case 1: for(i = 0; i < 920; i++) ffu.s[20+i] = sr1[i];
+ case 1: for(i = 0; i < 21; i++) ffu.s[63+i] = sr1[i];
break;
- case 2: for(i = 0; i < 920; i++) ffu.s[20+i] = sr2[i];
+ case 2: for(i = 0; i < 41; i++) ffu.s[74+i] = sr2[i];
break;
- case 3: for(i = 0; i < 920; i++) ffu.s[20+i] = sr3[i];
+ case 3: for(i = 0; i < 21; i++) ffu.s[114+i] = sr3[i];
break;
- case 4: for(i = 0; i < 920; i++) ffu.s[20+i] = sr4[i];
+ case 4: for(i = 0; i < 18; i++) ffu.s[157+i] = sr4[i];
break;
- case 5: for(i = 0; i < 920; i++) ffu.s[20+i] = sr5[i];
+ case 5: for(i = 0; i < 10; i++) ffu.s[177+i] = sr5[i];
break;
- case 6: for(i = 0; i < 920; i++) ffu.s[20+i] = sr6[i];
+ case 6: for(i = 0; i < 10; i++) ffu.s[191+i] = sr6[i];
break;
- case 7: for(i = 0; i < 920; i++) ffu.s[20+i] = sr7[i];
+ case 7: for(i = 0; i < 14; i++) ffu.s[206+i] = sr7[i];
break;
- case 8: for(i = 0; i < 920; i++) ffu.s[20+i] = sr8[i];
+ case 8: for(i = 0; i < 61; i++) ffu.s[203+i] = sr8[i];
break;
- case 9: for(i = 0; i < 920; i++) ffu.s[20+i] = sr9[i];
+ case 9: for(i = 0; i < 21; i++) ffu.s[233+i] = sr9[i];
break;
- case 10: for(i = 0; i < 920; i++) ffu.s[20+i] = sr10[i];
+ case 10: for(i = 0; i < 14; i++) ffu.s[271+i] = sr10[i];
break;
- case 11: for(i = 0; i < 920; i++) ffu.s[20+i] = sr11[i];
+ case 11: for(i = 0; i < 33; i++) ffu.s[433+i] = sr11[i];
break;
- case 12: for(i = 0; i < 920; i++) ffu.s[20+i] = sr12[i];
+ case 12: for(i = 0; i < 56; i++) ffu.s[517+i] = sr12[i];
break;
- case 13: for(i = 0; i < 920; i++) ffu.s[20+i] = sr13[i];
+ case 13: for(i = 0; i < 99; i++) ffu.s[730+i] = sr13[i];
break;
+void IWave::sentinel2b(int iwa)
+ /* SR_AV_B1 of sentinel_2B_msi */
+ .0000, .0000, .0076, .0059, .0053, .0025, .0026, .0034,
+ .0035, .0506, .5946, .8712, .9090, .9460, .9615, 1.0000,
+ .9591, .8855, .4542, .0305, .0000
+ /* SR_AV_B2 of sentinel_2B_msi */
+ static const float sr2[40] = {
+ .0000, .0009, .0201, .0155, .0133, .0120, .0133, .0145,
+ .0307, .1862, .6524, .8282, .8388, .8945, .9366, .9221,
+ .8979, .9149, .9188, .8927, .8578, .8507, .9040, .9581,
+ .9993, .9896, .9782, .9582, .9248, .8973, .8919, .9178,
+ .9535, .9922, .9816, .8147, .3326, .0963, .0322, .0022
+ /* SR_AV_B3 of sentinel_2B_msi */
+ .0000, .0000, .0261, .1695, .6992, .9455, .9359, .9015,
+ .9150, .9640, .9997, .9766, .9082, .8476, .8319, .8488,
+ .8728, .8097, .3521, .0590, .0026
+ /* SR_AV_B4 of sentinel_2B_msi */
+ .0000, .0000, .0739, .6036, .9209, .9112, .8981, .9025,
+ .9217, .9542, .9865, .9998, .9752, .9456, .8678, .4935,
+ .0688, .0008
+ /* SR_AV_B5 of sentinel_2B_msi */
+ static const float sr5[11] = {
+ .0000, .0000, .0573, .7091, .9912, .9913, .9709, .9345,
+ .7672, .1073, .0000
+ /* SR_AV_B6 of sentinel_2B_msi */
+ .0000, .0174, .5842, .9164, .9398, .9786, 1.0000, .8192,
+ .0520, .0000
+ /* SR_AV_B7 of sentinel_2B_msi */
+ .0000, .0000, .0747, .4790, .9421, .9557, .9931, .9839,
+ .9372, .8869, .8022, .4818, .0415, .0000
+ /* SR_AV_B8 of sentinel_2B_msi */
+ static const float sr8[56] = {
+ .0000, .0000, .0030, .0393, .1496, .5284, .9050, .9466,
+ .9799, .9982, .9985, .9756, .9517, .9463, .9421, .9040,
+ .8526, .8193, .8037, .7756, .7423, .7166, .7265, .7560,
+ .7817, .7829, .7804, .7817, .7776, .7592, .7338, .7062,
+ .6740, .6362, .6032, .5866, .5815, .5757, .5710, .5709,
+ .5754, .5794, .5757, .5594, .5459, .5409, .5320, .4968,
+ .4561, .4444, .4402, .3356, .1742, .0698, .0242, .0031
+ /* SR_AV_B8A of sentinel_2B_msi */
+ static const float sr9[15] = {
+ .0000, .0008, .0323, .2572, .7963, .9841, .9990, .9972,
+ .9832, .9740, .9582, .8364, .3774, .0562, .0016
+ /* SR_AV_B9 of sentinel_2B_msi */
+ static const float sr10[13] = {
+ .0000, .0121, .2550, .8373, .9494, .9974, .9803, .9738,
+ .9279, .8551, .6211, .0948, .0017
+ /* SR_AV_B10 of sentinel_2B_msi */
+ static const float sr11[32] = {
+ .0000, .0001, .0001, .0001, .0002, .0003, .0008, .0048,
+ .0421, .1953, .5416, .8805, .9800, .9977, .9978, .9842,
+ .9670, .9513, .9392, .9352, .9011, .7493, .4241, .1101,
+ .0129, .0016, .0004, .0002, .0002, .0001, .0002, .0000
+ /* SR_AV_B11 of sentinel_2B_msi */
+ static const float sr12[58] = {
+ .0000, .0001, .0003, .0007, .0013, .0027, .0064, .0171,
+ .0521, .1397, .3312, .6062, .8367, .9466, .9751, .9769,
+ .9724, .9691, .9716, .9789, .9842, .9839, .9804, .9763,
+ .9763, .9820, .9905, .9959, .9934, .9849, .9752, .9705,
+ .9738, .9830, .9945, 1.0000, .9950, .9858, .9796, .9825,
+ .9906, .9894, .9617, .9080, .8576, .8434, .8446, .7568,
+ .5117, .2569, .0947, .0291, .0106, .0046, .0022, .0011,
+ .0004, .0000
+ /* SR_AV_B12 of sentinel_2B_msi */
+ static const float sr13[98] = {
+ .0000, .0002, .0023, .0059, .0095, .0146, .0232, .0372,
+ .0632, .1107, .1938, .3172, .4861, .6721, .8143, .8863,
+ .9012, .8924, .8833, .8827, .8958, .9128, .9300, .9434,
+ .9480, .9481, .9455, .9419, .9438, .9462, .9484, .9507,
+ .9519, .9526, .9528, .9538, .9552, .9580, .9609, .9641,
+ .9629, .9607, .9577, .9531, .9554, .9554, .9528, .9486,
+ .9484, .9466, .9428, .9389, .9448, .9485, .9514, .9553,
+ .9501, .9497, .9574, .9739, .9687, .9676, .9687, .9700,
+ .9679, .9655, .9623, .9594, .9610, .9637, .9659, .9689,
+ .9734, .9772, .9810, .9833, .9879, .9932, .9975, 1.0000,
+ .9932, .9687, .9158, .8319, .7091, .5640, .4259, .3098,
+ .2182, .1494, .1042, .0741, .0529, .0380, .0270, .0138,
+ .0026, .0000
+ static const float wli[13] = {0.4075, 0.4350, 0.5325, 0.6425, 0.6900, 0.7275, 0.7625, 0.7700, 0.8450, 0.9275, 1.3375, 1.5375, 2.0625};
+ static const float wls[13] = {0.4600, 0.5350, 0.5850, 0.6875, 0.7175, 0.7525, 0.7975, 0.9100, 0.8825, 0.9600, 1.4175, 1.6825, 2.3075};
+ ffu.wlinf = (float)wli[iwa-1];
+ ffu.wlsup = (float)wls[iwa-1];
+ int i;
+ for(i = 0; i < 1501; i++) ffu.s[i] = 0;
+ switch(iwa)
+ break;
+ case 2: for(i = 0; i < 40; i++) ffu.s[74+i] = sr2[i];
+ break;
+ case 3: for(i = 0; i < 21; i++) ffu.s[113+i] = sr3[i];
+ break;
+ break;
+ case 5: for(i = 0; i < 11; i++) ffu.s[176+i] = sr5[i];
+ break;
+ break;
+ case 7: for(i = 0; i < 14; i++) ffu.s[205+i] = sr7[i];
+ break;
+ case 8: for(i = 0; i < 56; i++) ffu.s[208+i] = sr8[i];
+ break;
+ case 9: for(i = 0; i < 15; i++) ffu.s[238+i] = sr9[i];
+ break;
+ case 10: for(i = 0; i < 13; i++) ffu.s[271+i] = sr10[i];
+ break;
+ case 11: for(i = 0; i < 32; i++) ffu.s[435+i] = sr11[i];
+ break;
+ case 12: for(i = 0; i < 58; i++) ffu.s[515+i] = sr12[i];
+ break;
+ case 13: for(i = 0; i < 98; i++) ffu.s[725+i] = sr13[i];
+ break;
/* filter functions must be defined above */
float IWave::equivwl() const
@@ -5989,11 +4512,11 @@
float sbor = ffu.s[i];
if(i == iinf || i == isup) sbor *= 0.5;
- float wl = (float)(0.25 + i * step);
- float swl = solirr(wl);
+ float fwl = (float)(0.25 + i * step);
+ float swl = solirr(fwl);
float coef = sbor * step * swl;
seb += coef;
- wlwave += wl * coef;
+ wlwave += fwl * coef;
return wlwave/seb;
@@ -6062,6 +4585,7 @@
else if(iwave <= 148) pleiades1b(iwave - 143);
else if(iwave <= 165) worldview3(iwave - 148);
else if(iwave <= 178) sentinel2a(iwave - 165);
+ else if(iwave <= 191) sentinel2b(iwave - 178);
else G_warning(_("Unsupported iwave value: %d"), iwave);
if (iwave > 1) {
@@ -6084,20 +4608,20 @@
/* set wlinf, wlsup */
iinf = imax;
- ffu.wlinf = imax * 0.0025 + 0.25;
while (iinf > 0 && ffu.s[iinf - 1] > sthreshold) {
iinf--;
- ffu.wlinf -= 0.0025;
+ ffu.wlinf = iinf * 0.0025 + 0.25;
isup = imax;
- ffu.wlsup = imax * 0.0025 + 0.25;
while (isup < 1500 && ffu.s[isup + 1] > sthreshold) {
isup++;
- ffu.wlsup += 0.0025;
+ ffu.wlsup = isup * 0.0025 + 0.25;
+ /* assuming that wlinf and wlsup are exact multiples of 2.5 nm */
iinf = (int)((ffu.wlinf - 0.25f) / 0.0025f + 1.5f) - 1; /* remember indexing */
isup = (int)((ffu.wlsup - 0.25f) / 0.0025f + 1.5f) - 1; /* " */
@@ -6187,7 +4711,13 @@
string(" sentinel2a red edge b6"), string(" sentinel2a red edge b7"),
string(" sentinel2a nir b8"), string(" sentinel2a red edge b8A"),
string(" sentinel2a water vapor b9"), string(" sentinel2a swir b10"),
- string(" sentinel2a swir b11"), string(" sentinel2a swir b12")
+ string(" sentinel2a swir b11"), string(" sentinel2a swir b12"),
+ string(" sentinel2b coastal b1"),
+ string(" sentinel2b blue b2"), string(" sentinel2b green b3"), string(" sentinel2b red b4"), string(" sentinel2b red edge b5"),
+ string(" sentinel2b red edge b6"), string(" sentinel2b red edge b7"),
+ string(" sentinel2b nir b8"), string(" sentinel2b red edge b8A"),
+ string(" sentinel2b water vapor b9"), string(" sentinel2b swir b10"),
+ string(" sentinel2b swir b11"), string(" sentinel2b swir b12")
Modified: grass/branches/releasebranch_7_4/imagery/i.atcorr/iwave.h
--- grass/branches/releasebranch_7_4/imagery/i.atcorr/iwave.h 2018-03-24 16:42:50 UTC (rev 72556)
+++ grass/branches/releasebranch_7_4/imagery/i.atcorr/iwave.h 2018-03-24 16:50:40 UTC (rev 72557)
@@ -84,6 +84,7 @@
void pleiades1b(int iwa);
void worldview3(int iwa);
void sentinel2a(int iwa);
+ void sentinel2b(int iwa);
public:
/* To compute the equivalent wavelength needed for the calculation of the
Modified: grass/branches/releasebranch_7_4/imagery/i.atcorr/main.cpp
--- grass/branches/releasebranch_7_4/imagery/i.atcorr/main.cpp 2018-03-24 16:42:50 UTC (rev 72556)
+++ grass/branches/releasebranch_7_4/imagery/i.atcorr/main.cpp 2018-03-24 16:50:40 UTC (rev 72557)
@@ -37,6 +37,7 @@
#include <cstdlib>
#include <map>
+#include <cmath>
extern "C"
@@ -49,13 +50,13 @@
#include "transform.h"
#include "6s.h"
-/* TICache: create 1 meter bins for altitude in km */
-/* 10m bins are also ok */
-/* BIN_ALT = 1000 / <bin size in meters> */
-#define BIN_ALT 1000.
-/* TICache: create 1 km bins for visibility */
-#define BIN_VIS 1.
+/* MODIS surface reflectance (MOD09) uses pre-computed 6S parameters
+ * for 10 aerosol optical depths. Here we use finer grain. */
+/* TICache: create bins for altitude and visibility */
+#define BIN_ALT 10 /* unit is meters */
+#define BIN_VIS 100 /* unit is meters */
/* uncomment to disable cache usage */
/* #define _NO_OPTIMIZE_ */
@@ -95,7 +96,6 @@
/* function prototypes */
static void adjust_region(const char *);
-static CELL round_c(FCELL);
static void write_fp_to_cell(int, FCELL *);
static void process_raster(int, InputMask, ScaleRange, int, int, int, bool,
ScaleRange);
@@ -129,7 +129,26 @@
return (CELL) (-(-x + .5));
+/* round height, input and output unit is meters */
+static int round_h(float x)
+ x /= BIN_ALT;
+ x = floor(x + 0.5);
+ x *= BIN_ALT;
+ return x;
+/* round visibility, input unit is km, output unit is meters */
+static int round_v(float x)
+ x *= 1000. / BIN_VIS;
+ x *= BIN_VIS;
+ return x;
/* Converts the buffer to cell and write it to disk */
static void write_fp_to_cell(int ofd, FCELL *buf)
@@ -182,11 +201,8 @@
struct RBitem rbitem;
- /* although alt and vis are already rounded,
- * the + 0.5 is needed for fp representation errors */
- /* alt has been converted to kilometers */
- rbitem.alt = (int) (alt * BIN_ALT + 0.5);
- /* vis should be kilometers */
+ /* alt and vis must be in meters */
+ rbitem.alt = (alt < 0 ? (int) (alt - 0.5) : (int) (alt + 0.5));
rbitem.vis = (int) (vis + 0.5);
return rbitem;
@@ -248,8 +264,8 @@
FCELL *buf; /* buffer for the input values */
FCELL *alt = NULL; /* buffer for the elevation values */
FCELL *vis = NULL; /* buffer for the visibility values */
- FCELL prev_alt = -1.f;
- FCELL prev_vis = -1.f;
+ int cur_alt = -100000;
+ int cur_vis = -100000;
int row, col, nrows, ncols;
/* switch on optimization automatically if elevation and/or visibility map is given */
bool optimize = (ialt_fd >= 0 || ivis_fd >= 0);
@@ -300,80 +316,77 @@
continue;
if (ialt_fd >= 0) {
- if (alt[col] < 0)
- alt[col] = 0; /* on or below sea level, all the same for 6S */
- else
- alt[col] /= 1000.0f; /* converting to km from input which should be in meter */
- /* round to nearest altitude bin */
- /* rounding result: watch out for fp representation error */
- alt[col] = ((int) (alt[col] * BIN_ALT + 0.5)) / BIN_ALT;
+ alt[col] = round_h(alt[col]); /* in meters */
if (ivis_fd >= 0) {
- if (vis[col] < 0)
- vis[col] = 0; /* negative visibility is invalid, print a WARNING ? */
- /* round to nearest visibility bin */
- vis[col] = ((int) (vis[col] + 0.5));
+ if (vis[col] < 0) {
+ /* negative visibility is invalid */
+ G_warning(_("Negative visibility!"));
+ vis[col] = 0;
+ if (vis[col] < 5.0) {
+ /* too low visibility, text comes from 6S main.f L109-113 */
+ G_warning(_("The visibility must be better than 5.0km, "
+ "for smaller values calculations might be no more valid!"));
+ vis[col] = round_v(vis[col]); /* from km to meters */
- /* check if both maps are active and if whether any value has changed */
+ /* check if altitude or visibility has changed */
if ((ialt_fd >= 0) && (ivis_fd >= 0) &&
- ((prev_vis != vis[col]) || (prev_alt != alt[col]))) {
- prev_alt = alt[col]; /* update new values */
- prev_vis = vis[col];
+ ((cur_vis != vis[col]) || (cur_alt != alt[col]))) {
+ cur_alt = alt[col];
+ cur_vis = vis[col];
if (optimize) {
- int in_cache = ticache.search(alt[col], vis[col], &ti);
+ int in_cache = ticache.search(cur_alt, cur_vis, &ti);
if (!in_cache) {
- pre_compute_hv(alt[col], vis[col]); /* re-compute transformation inputs */
+ pre_compute_hv(alt[col] / 1000., vis[col] / 1000.); /* re-compute transformation inputs */
ti = compute(); /* ... */
- ticache.add(ti, alt[col], vis[col]);
+ ticache.add(ti, cur_alt, cur_vis);
else {
- else { /* only one of the maps is being used */
+ else {
+ if ((ivis_fd >= 0) && (cur_vis != vis[col])) {
- if ((ivis_fd >= 0) && (prev_vis != vis[col])) {
- prev_vis = vis[col]; /* keep track of previous visibility */
if (optimize) {
- int in_cache = ticache.search(0, vis[col], &ti);
if (!in_cache) {
- pre_compute_v(vis[col]); /* re-compute transformation inputs */
+ pre_compute_v(vis[col] / 1000.); /* re-compute transformation inputs */
- ticache.add(ti, 0, vis[col]);
else {
- if ((ialt_fd >= 0) && (prev_alt != alt[col])) {
- prev_alt = alt[col]; /* keep track of previous altitude */
+ if ((ialt_fd >= 0) && (cur_alt != alt[col])) {
if (optimize) {
- int in_cache = ticache.search(alt[col], 0, &ti);
+ int in_cache = ticache.search(alt[col], cur_vis, &ti);
if (!in_cache) {
- pre_compute_h(alt[col]); /* re-compute transformation inputs */
+ pre_compute_h(alt[col] / 1000.); /* re-compute transformation inputs */
- ticache.add(ti, alt[col], 0);
else {
@@ -469,7 +482,7 @@
opts.iscl->type = TYPE_INTEGER;
opts.iscl->key_desc = "min,max";
opts.iscl->required = NO;
- opts.iscl->answer = "0,255";
+ opts.iscl->answer = G_store("0,255");
opts.iscl->description = _("Input range");
opts.iscl->guisection = _("Input");
@@ -495,7 +508,7 @@
opts.oscl->key = "rescale";
opts.oscl->type = TYPE_INTEGER;
opts.oscl->key_desc = "min,max";
- opts.oscl->answer = "0,255";
+ opts.oscl->answer = G_store("0,255");
opts.oscl->required = NO;
opts.oscl->description = _("Rescale output raster map");
opts.oscl->guisection = _("Output");
Copied: grass/branches/releasebranch_7_4/imagery/i.atcorr/sensors_csv/README (from rev 72120, grass/trunk/imagery/i.atcorr/sensors_csv/README)
--- grass/branches/releasebranch_7_4/imagery/i.atcorr/sensors_csv/README (rev 0)
+++ grass/branches/releasebranch_7_4/imagery/i.atcorr/sensors_csv/README 2018-03-24 16:50:40 UTC (rev 72557)
@@ -0,0 +1,80 @@
+AVNIR
+ see https://doi.org/10.1109/IGARSS.2007.4423393
+ files
+ AVNIR.csv
+Landsat
+ see https://landsat.usgs.gov/spectral-characteristics-viewer
+ files
+ etmplus.csv
+ landsat_8.csv
+geoeye
+ see https://apollomapping.com/blog/new-documents-atmospheric-correction-digitalglobe-satellites-2
+ files
+ geoeye1.csv
+ikonos
+ see https://web.archive.org/web/20150331094259/https://www.digitalglobe.com/sites/default/files/DigitalGlobe_Spectral_Response_1.pdf
+ files
+ ikonos.csv
+pleiades
+ see https://trac.osgeo.org/grass/ticket/3054
+ files
+ pleiades1a.csv
+ pleiades1b.csv
+PRISM
+ see ?
+ files
+ PRISM-B.csv
+ PRISM-F.csv
+ PRISM-N.csv
+quickbird
+ files
+ quickbird2.csv
+rapideye
+ see https://resa.planet.com/files/2014-06/Spectral_Response_Curves.pdf
+ files
+ rapideye.csv
+sentinel
+ see https://sentinels.copernicus.eu/documents/247904/685211/S2-SRF_COPE-GSEG-EOPG-TN-15-0007_3.0.xlsx
+ updates on https://sentinels.copernicus.eu/web/sentinel/home
+ go to Home › User Guides › Sentinel-2 MSI › S2-MSI Document Library
+ files
+ sentinel_2A_msi.csv
+spot
+ files
+ spot6.csv
+ spot7.csv
+ VGT1_spot4.csv
+ VGT2_spot5.csv
+worldview2
+ files
+ worldview2.csv
+worldview3
+ see ?
+ files
+ worldview3.csv
Copied: grass/branches/releasebranch_7_4/imagery/i.atcorr/sensors_csv/etmplus.csv (from rev 72119, grass/trunk/imagery/i.atcorr/sensors_csv/etmplus.csv)
--- grass/branches/releasebranch_7_4/imagery/i.atcorr/sensors_csv/etmplus.csv (rev 0)
+++ grass/branches/releasebranch_7_4/imagery/i.atcorr/sensors_csv/etmplus.csv 2018-03-24 16:50:40 UTC (rev 72557)
@@ -0,0 +1,868 @@
+Wavelength,1 blue,2 green,3 red,4 NIR,5 SWIR,7 SWIR,8 PAN
+410,,,,,,,
+411,,,,,,,
+412,,,,,,,
+413,,,,,,,
+414,,,,,,,
+415,,,,,,,
+416,,,,,,,
+417,,,,,,,
+418,,,,,,,
+419,,,,,,,
+420,,,,,,,
+421,,,,,,,
+422,,,,,,,
+423,,,,,,,
+424,,,,,,,
+425,,,,,,,
+426,,,,,,,
+427,,,,,,,
+428,,,,,,,
+429,,,,,,,
+430,,,,,,,
+431,,,,,,,
+432,,,,,,,
+433,,,,,,,
+434,,,,,,,
+435,0.016,,,,,,
+436,0.027,,,,,,
+437,0.048,,,,,,
+438,0.094,,,,,,
+439,0.167,,,,,,
+440,0.287,,,,,,
+441,0.459,,,,,,
+442,0.605,,,,,,
+443,0.728,,,,,,
+444,0.769,,,,,,
+445,0.792,,,,,,
+446,0.821,,,,,,
+447,0.857,,,,,,
+448,0.857,,,,,,
+449,0.862,,,,,,
+450,0.839,,,,,,
+451,0.845,,,,,,
+452,0.81,,,,,,
+453,0.802,,,,,,
+454,0.804,,,,,,
+455,0.779,,,,,,
+456,0.798,,,,,,
+457,0.816,,,,,,
+458,0.876,,,,,,
+459,0.888,,,,,,
+460,0.901,,,,,,
+461,0.918,,,,,,
+462,0.896,,,,,,
+463,0.903,,,,,,
+464,0.888,,,,,,
+465,0.89,,,,,,
+466,0.863,,,,,,
+467,0.86,,,,,,
+468,0.842,,,,,,
+469,0.866,,,,,,
+470,0.875,,,,,,
+471,0.881,,,,,,
+472,0.888,,,,,,
+473,0.898,,,,,,
+474,0.879,,,,,,
+475,0.884,,,,,,
+476,0.907,,,,,,
+477,0.928,,,,,,
+478,0.932,,,,,,
+479,0.955,,,,,,
+480,0.958,,,,,,
+481,0.948,,,,,,
+482,0.952,,,,,,
+483,0.956,,,,,,
+484,0.98,,,,,,
+485,0.98,,,,,,
+486,0.975,,,,,,
+487,0.973,,,,,,
+488,0.977,,,,,,
+489,0.958,,,,,,
+490,0.965,,,,,,
+491,0.957,,,,,,
+492,0.952,,,,,,
+493,0.973,,,,,,
+494,0.974,,,,,,
+495,0.995,,,,,,
+496,0.986,,,,,,
+497,0.986,,,,,,
+498,0.994,,,,,,
+499,1,,,,,,
+500,0.99,0.0006,,,,,
+501,0.99,0.0009,,,,,
+502,0.976,0.001,,,,,0.001
+503,0.983,0.002,,,,,0.0045
+504,0.976,0.002,,,,,0.008
+505,0.983,0.003,,,,,0.0175
+506,0.96,0.005,,,,,0.027
+507,0.973,0.009,,,,,0.0465
+508,0.964,0.0145,,,,,0.066
+509,0.975,0.0236,,,,,0.108
+510,0.96,0.026,,,,,0.15
+511,0.932,0.041,,,,,0.2195
+512,0.853,0.06,,,,,0.289
+513,0.684,0.088,,,,,0.368
+514,0.486,0.126,,,,,0.447
+515,0.293,0.174,,,,,0.5015
+516,0.15,0.236,,,,,0.556
+517,0.073,0.308,,,,,0.575
+518,0.036,0.388,,,,,0.594
+519,0.019,0.472,,,,,0.5965
+520,0.009,0.552,,,,,0.599
+521,,0.621,,,,,0.5995
+522,,0.676,,,,,0.6
+523,,0.716,,,,,0.6035
+524,,0.743,,,,,0.607
+525,,0.759,,,,,0.6095
+526,,0.769,,,,,0.612
+527,,0.779,,,,,0.6135
+528,,0.79,,,,,0.615
+529,,0.805,,,,,0.6125
+530,,0.822,,,,,0.61
+531,,0.842,,,,,0.607
+532,,0.861,,,,,0.604
+533,,0.878,,,,,0.603
+534,,0.893,,,,,0.602
+535,,0.905,,,,,0.6035
+536,,0.916,,,,,0.605
+537,,0.924,,,,,0.6095
+538,,0.933,,,,,0.614
+539,,0.942,,,,,0.6205
+540,,0.947,,,,,0.627
+541,,0.951,,,,,0.632
+542,,0.953,,,,,0.637
+543,,0.952,,,,,0.64
+544,,0.951,,,,,0.643
+545,,0.952,,,,,0.6445
+546,,0.951,,,,,0.646
+547,,0.951,,,,,0.6445
+548,,0.952,,,,,0.643
+549,,0.952,,,,,0.6375
+550,,0.953,,,,,0.632
+551,,0.951,,,,,0.6295
+552,,0.95,,,,,0.627
+553,,0.95,,,,,0.625
+554,,0.951,,,,,0.623
+555,,0.954,,,,,0.6245
+556,,0.96,,,,,0.626
+557,,0.966,,,,,0.63
+558,,0.968,,,,,0.634
+559,,0.965,,,,,0.638
+560,,0.959,,,,,0.642
+561,,0.951,,,,,0.6485
+562,,0.944,,,,,0.655
+563,,0.937,,,,,0.6635
+564,,0.932,,,,,0.672
+565,,0.933,,,,,0.6775
+566,,0.935,,,,,0.683
+567,,0.937,,,,,0.6875
+568,,0.94,,,,,0.692
+569,,0.945,,,,,0.6945
+570,,0.951,,,,,0.697
+571,,0.955,,,,,0.6985
+572,,0.957,,,,,0.7
+573,,0.956,,,,,0.701
+574,,0.957,,,,,0.702
+575,,0.955,,,,,0.705
+576,,0.952,,,,,0.708
+577,,0.954,,,,,0.71
+578,,0.958,,,,,0.712
+579,,0.963,,,,,0.7125
+580,,0.973,,,,,0.713
+581,,0.981,,,,,0.7145
+582,,0.988,,,,,0.716
+583,,0.995,,,,,0.717
+584,,1,,,,,0.718
+585,,1,,,,,0.718
+586,,0.994,,,,,0.718
+587,,0.983,,,,,0.714
+588,,0.969,,,,,0.71
+589,,0.954,,,,,0.7085
+590,,0.942,,,,,0.707
+591,,0.936,,,,,0.706
+592,,0.932,,,,,0.705
+593,,0.928,,,,,0.703
+594,,0.924,,,,,0.701
+595,,0.912,,,,,0.703
+596,,0.883,,,,,0.705
+597,,0.834,,,,,0.7115
+598,,0.763,,,,,0.718
+599,,0.674,,,,,0.724
+600,,0.574,,,,,0.73
+601,,0.473,,,,,0.736
+602,,0.38,,,,,0.742
+603,,0.3,,,,,0.746
+604,,0.235,,,,,0.75
+605,,0.185,,,,,0.7535
+606,,0.146,,,,,0.757
+607,,0.117,,,,,0.76
+608,,0.094,,,,,0.763
+609,,0.077,,,,,0.7635
+610,,0.062,,,,,0.764
+611,,0.052,,,,,0.7595
+612,,0.042,,,,,0.755
+613,,0.033,,,,,0.7515
+614,,0.026,0.0005,,,,0.748
+615,,0.021,0.0001,,,,0.745
+616,,0.0158,0,,,,0.742
+617,,0.01235,0.0005,,,,0.7375
+618,,0.0094,0.0006,,,,0.733
+619,,0.00717,0.0014,,,,0.731
+620,,0.0048,0.002,,,,0.729
+621,,0.0037,0.003,,,,0.7285
+622,,0.0026,0.006,,,,0.728
+623,,0.0017,0.013,,,,0.729
+624,,0.0014,0.025,,,,0.73
+625,,,0.047,,,,0.731
+626,,,0.083,,,,0.732
+627,,,0.137,,,,0.7325
+628,,,0.211,,,,0.733
+629,,,0.306,,,,0.7335
+630,,,0.419,,,,0.734
+631,,,0.545,,,,0.738
+632,,,0.674,,,,0.742
+633,,,0.788,,,,0.745
+634,,,0.873,,,,0.748
+635,,,0.921,,,,0.7495
+636,,,0.941,,,,0.751
+637,,,0.943,,,,0.753
+638,,,0.942,,,,0.755
+639,,,0.939,,,,0.7565
+640,,,0.937,,,,0.758
+641,,,0.935,,,,0.759
+642,,,0.935,,,,0.76
+643,,,0.938,,,,0.7635
+644,,,0.943,,,,0.767
+645,,,0.949,,,,0.768
+646,,,0.953,,,,0.769
+647,,,0.961,,,,0.771
+648,,,0.968,,,,0.773
+649,,,0.971,,,,0.776
+650,,,0.973,,,,0.779
+651,,,0.974,,,,0.78
+652,,,0.972,,,,0.781
+653,,,0.969,,,,0.782
+654,,,0.963,,,,0.783
+655,,,0.958,,,,0.785
+656,,,0.956,,,,0.787
+657,,,0.955,,,,0.789
+658,,,0.955,,,,0.791
+659,,,0.956,,,,0.792
+660,,,0.962,,,,0.793
+661,,,0.969,,,,0.7925
+662,,,0.977,,,,0.792
+663,,,0.983,,,,0.7915
+664,,,0.988,,,,0.791
+665,,,0.993,,,,0.7915
+666,,,0.996,,,,0.792
+667,,,0.997,,,,0.794
+668,,,0.999,,,,0.796
+669,,,1,,,,0.797
+670,,,1,,,,0.798
+671,,,0.998,,,,0.7995
+672,,,0.996,,,,0.801
+673,,,0.995,,,,0.8025
+674,,,0.993,,,,0.804
+675,,,0.992,,,,0.806
+676,,,0.991,,,,0.808
+677,,,0.989,,,,0.8115
+678,,,0.988,,,,0.815
+679,,,0.984,,,,0.8175
+680,,,0.977,,,,0.82
+681,,,0.97,,,,0.8235
+682,,,0.96,,,,0.827
+683,,,0.949,,,,0.828
+684,,,0.94,,,,0.829
+685,,,0.932,,,,0.8315
+686,,,0.919,,,,0.834
+687,,,0.898,,,,0.836
+688,,,0.863,,,,0.838
+689,,,0.809,,,,0.84
+690,,,0.729,,,,0.842
+691,,,0.625,,,,0.8445
+692,,,0.506,,,,0.847
+693,,,0.382,,,,0.85
+694,,,0.272,,,,0.853
+695,,,0.183,,,,0.8545
+696,,,0.12,,,,0.856
+697,,,0.079,,,,0.859
+698,,,0.053,,,,0.862
+699,,,0.036,,,,0.865
+700,,,0.025,,,,0.868
+701,,,0.0196,,,,0.8695
+702,,,0.0142,,,,0.871
+703,,,0.0101,,,,0.8735
+704,,,0.0075,,,,0.876
+705,,,,,,,0.8795
+706,,,,,,,0.883
+707,,,,,,,0.8845
+708,,,,,,,0.886
+709,,,,,,,0.889
+710,,,,,,,0.892
+711,,,,,,,0.893
+712,,,,,,,0.894
+713,,,,,,,0.895
+714,,,,,,,0.896
+715,,,,,,,0.896
+716,,,,,,,0.896
+717,,,,,,,0.895
+718,,,,,,,0.894
+719,,,,,,,0.894
+720,,,,,,,0.894
+721,,,,,,,0.894
+722,,,,,,,0.894
+723,,,,,,,0.8945
+724,,,,,,,0.895
+725,,,,,,,0.8955
+726,,,,,,,0.896
+727,,,,,,,0.897
+728,,,,,,,0.898
+729,,,,,,,0.899
+730,,,,,,,0.9
+731,,,,,,,0.9015
+732,,,,,,,0.903
+733,,,,,,,0.9035
+734,,,,,,,0.904
+735,,,,,,,0.9035
+736,,,,,,,0.903
+737,,,,,,,0.9025
+738,,,,,,,0.902
+739,,,,,,,0.901
+740,,,,,,,0.9
+741,,,,,,,0.8985
+742,,,,,,,0.897
+743,,,,,,,0.8965
+744,,,,,,,0.896
+745,,,,,,,0.8935
+746,,,,,,,0.891
+747,,,,,,,0.8855
+748,,,,,,,0.88
+749,,,,,,,0.8795
+750,,,,0.001,,,0.879
+751,,,,0.0144,,,0.8795
+752,,,,0.0182,,,0.88
+753,,,,0.0216,,,0.8765
+754,,,,0.0269,,,0.873
+755,,,,0.0315,,,0.873
+756,,,,0.0377,,,0.873
+757,,,,0.0474,,,0.875
+758,,,,0.0562,,,0.877
+759,,,,0.0688,,,0.8785
+760,,,,0.069,,,0.88
+761,,,,0.083,,,0.88
+762,,,,0.099,,,0.88
+763,,,,0.121,,,0.8825
+764,,,,0.146,,,0.885
+765,,,,0.175,,,0.8865
+766,,,,0.209,,,0.888
+767,,,,0.248,,,0.89
+768,,,,0.294,,,0.892
+769,,,,0.346,,,0.8925
+770,,,,0.402,,,0.893
+771,,,,0.463,,,0.8975
+772,,,,0.523,,,0.902
+773,,,,0.588,,,0.905
+774,,,,0.649,,,0.908
+775,,,,0.705,,,0.9105
+776,,,,0.757,,,0.913
+777,,,,0.797,,,0.9165
+778,,,,0.827,,,0.92
+779,,,,0.853,,,0.92
+780,,,,0.871,,,0.92
+781,,,,0.884,,,0.919
+782,,,,0.892,,,0.918
+783,,,,0.899,,,0.917
+784,,,,0.903,,,0.916
+785,,,,0.908,,,0.916
+786,,,,0.911,,,0.916
+787,,,,0.916,,,0.9175
+788,,,,0.92,,,0.919
+789,,,,0.925,,,0.9185
+790,,,,0.926,,,0.918
+791,,,,0.927,,,0.9175
+792,,,,0.927,,,0.917
+793,,,,0.929,,,0.9165
+794,,,,0.932,,,0.916
+795,,,,0.93,,,0.9155
+796,,,,0.926,,,0.915
+797,,,,0.926,,,0.9165
+798,,,,0.925,,,0.918
+799,,,,0.928,,,0.9225
+800,,,,0.925,,,0.927
+801,,,,0.926,,,0.9275
+802,,,,0.928,,,0.928
+803,,,,0.928,,,0.93
+804,,,,0.928,,,0.932
+805,,,,0.923,,,0.9375
+806,,,,0.92,,,0.943
+807,,,,0.919,,,0.9475
+808,,,,0.914,,,0.952
+809,,,,0.91,,,0.9545
+810,,,,0.908,,,0.957
+811,,,,0.905,,,0.9595
+812,,,,0.903,,,0.962
+813,,,,0.904,,,0.9655
+814,,,,0.902,,,0.969
+815,,,,0.909,,,0.9695
+816,,,,0.917,,,0.97
+817,,,,0.92,,,0.971
+818,,,,0.928,,,0.972
+819,,,,0.938,,,0.9745
+820,,,,0.946,,,0.977
+821,,,,0.953,,,0.978
+822,,,,0.962,,,0.979
+823,,,,0.969,,,0.98
+824,,,,0.971,,,0.981
+825,,,,0.971,,,0.984
+826,,,,0.97,,,0.987
+827,,,,0.969,,,0.9895
+828,,,,0.969,,,0.992
+829,,,,0.97,,,0.9945
+830,,,,0.967,,,0.997
+831,,,,0.969,,,0.9975
+832,,,,0.968,,,0.998
+833,,,,0.963,,,0.999
+834,,,,0.965,,,1
+835,,,,0.967,,,0.998
+836,,,,0.965,,,0.996
+837,,,,0.963,,,0.9955
+838,,,,0.958,,,0.995
+839,,,,0.95,,,0.9945
+840,,,,0.949,,,0.994
+841,,,,0.943,,,0.993
+842,,,,0.933,,,0.992
+843,,,,0.929,,,0.992
+844,,,,0.928,,,0.992
+845,,,,0.925,,,0.993
+846,,,,0.924,,,0.994
+847,,,,0.927,,,0.993
+848,,,,0.932,,,0.992
+849,,,,0.934,,,0.9895
+850,,,,0.943,,,0.987
+851,,,,0.952,,,0.9825
+852,,,,0.956,,,0.978
+853,,,,0.966,,,0.973
+854,,,,0.977,,,0.968
+855,,,,0.985,,,0.965
+856,,,,0.99,,,0.962
+857,,,,0.992,,,0.9595
+858,,,,0.993,,,0.957
+859,,,,0.994,,,0.953
+860,,,,0.998,,,0.949
+861,,,,0.996,,,0.943
+862,,,,0.992,,,0.937
+863,,,,0.991,,,0.9325
+864,,,,0.992,,,0.928
+865,,,,0.994,,,0.924
+866,,,,0.993,,,0.92
+867,,,,0.997,,,0.9155
+868,,,,0.997,,,0.911
+869,,,,0.996,,,0.909
+870,,,,0.998,,,0.907
+871,,,,0.999,,,0.906
+872,,,,1,,,0.905
+873,,,,0.999,,,0.9055
+874,,,,0.996,,,0.906
+875,,,,0.991,,,0.9085
+876,,,,0.99,,,0.911
+877,,,,0.991,,,0.9165
+878,,,,0.985,,,0.922
+879,,,,0.978,,,0.931
+880,,,,0.969,,,0.94
+881,,,,0.955,,,0.951
+882,,,,0.937,,,0.962
+883,,,,0.916,,,0.9695
+884,,,,0.892,,,0.977
+885,,,,0.868,,,0.978
+886,,,,0.845,,,0.979
+887,,,,0.824,,,0.968
+888,,,,0.811,,,0.957
+889,,,,0.807,,,0.926
+890,,,,0.819,,,0.895
+891,,,,0.841,,,0.841
+892,,,,0.868,,,0.787
+893,,,,0.892,,,0.717
+894,,,,0.892,,,0.647
+895,,,,0.854,,,0.5715
+896,,,,0.77,,,0.496
+897,,,,0.644,,,0.4295
+898,,,,0.501,,,0.363
+899,,,,0.365,,,0.3105
+900,,,,0.256,,,0.258
+901,,,,0.177,,,0.2195
+902,,,,0.122,,,0.181
+903,,,,0.085,,,0.154
+904,,,,0.061,,,0.127
+905,,,,0.044,,,0.108
+906,,,,0.032,,,0.089
+907,,,,0.025,,,0.0755
+908,,,,0.019,,,0.062
+909,,,,0.014,,,0.053
+910,,,,0.011,,,0.044
+911,,,,0.0107,,,0.038
+912,,,,0.008,,,0.032
+913,,,,0.0061,,,0.0275
+914,,,,0.0052,,,0.023
+915,,,,,,,0.0195
+916,,,,,,,0.016
+917,,,,,,,0.014
+918,,,,,,,0.012
+919,,,,,,,0.01
+920,,,,,,,0.008
+921,,,,,,,0.007
+922,,,,,,,0.006
+923,,,,,,,0.005
+924,,,,,,,0.004
+925,,,,,,,0.0035
+926,,,,,,,0.003
+927,,,,,,,0.0025
+928,,,,,,,0.002
+929,,,,,,,0.002
+930,,,,,,,0.002
+931,,,,,,,0.0015
+932,,,,,,,0.001
+1514,,,,,0.006,,
+1515,,,,,0.012,,
+1517,,,,,0.003,,
+1519,,,,,0.015,,
+1521,,,,,0.012,,
+1523,,,,,0.024,,
+1525,,,,,0.04,,
+1526,,,,,0.041,,
+1528,,,,,0.057,,
+1530,,,,,0.076,,
+1532,,,,,0.097,,
+1534,,,,,0.12,,
+1536,,,,,0.176,,
+1538,,,,,0.215,,
+1540,,,,,0.274,,
+1542,,,,,0.339,,
+1543,,,,,0.393,,
+1545,,,,,0.462,,
+1547,,,,,0.499,,
+1549,,,,,0.558,,
+1551,,,,,0.598,,
+1553,,,,,0.634,,
+1555,,,,,0.667,,
+1557,,,,,0.704,,
+1559,,,,,0.724,,
+1561,,,,,0.75,,
+1563,,,,,0.778,,
+1565,,,,,0.808,,
+1567,,,,,0.825,,
+1569,,,,,0.851,,
+1571,,,,,0.867,,
+1572,,,,,0.872,,
+1574,,,,,0.884,,
+1576,,,,,0.902,,
+1578,,,,,0.901,,
+1580,,,,,0.896,,
+1582,,,,,0.897,,
+1584,,,,,0.89,,
+1586,,,,,0.899,,
+1588,,,,,0.884,,
+1590,,,,,0.876,,
+1592,,,,,0.867,,
+1594,,,,,0.873,,
+1596,,,,,0.872,,
+1598,,,,,0.879,,
+1600,,,,,0.874,,
+1602,,,,,0.861,,
+1604,,,,,0.859,,
+1606,,,,,0.877,,
+1608,,,,,0.879,,
+1610,,,,,0.899,,
+1613,,,,,0.893,,
+1615,,,,,0.9,,
+1617,,,,,0.897,,
+1619,,,,,0.917,,
+1621,,,,,0.921,,
+1623,,,,,0.926,,
+1625,,,,,0.929,,
+1627,,,,,0.945,,
+1629,,,,,0.947,,
+1631,,,,,0.948,,
+1633,,,,,0.955,,
+1635,,,,,0.952,,
+1637,,,,,0.969,,
+1639,,,,,0.96,,
+1641,,,,,0.962,,
+1643,,,,,0.959,,
+1645,,,,,0.978,,
+1647,,,,,0.96,,
+1649,,,,,0.955,,
+1651,,,,,0.952,,
+1653,,,,,0.951,,
+1656,,,,,0.952,,
+1658,,,,,0.956,,
+1660,,,,,0.944,,
+1662,,,,,0.935,,
+1664,,,,,0.933,,
+1666,,,,,0.928,,
+1668,,,,,0.942,,
+1670,,,,,0.948,,
+1672,,,,,0.942,,
+1674,,,,,0.933,,
+1676,,,,,0.944,,
+1678,,,,,0.948,,
+1680,,,,,0.945,,
+1682,,,,,0.943,,
+1684,,,,,0.951,,
+1687,,,,,0.964,,
+1689,,,,,0.967,,
+1691,,,,,0.971,,
+1693,,,,,0.974,,
+1695,,,,,0.991,,
+1697,,,,,0.995,,
+1699,,,,,0.999,,
+1701,,,,,0.996,,
+1703,,,,,0.994,,
+1705,,,,,1,,
+1707,,,,,0.994,,
+1709,,,,,0.983,,
+1711,,,,,0.99,,
+1714,,,,,0.987,,
+1716,,,,,0.992,,
+1718,,,,,0.986,,
+1720,,,,,0.981,,
+1722,,,,,0.983,,
+1724,,,,,0.976,,
+1725,,,,,0.978,,
+1726,,,,,0.97,,
+1728,,,,,0.968,,
+1730,,,,,0.96,,
+1732,,,,,0.944,,
+1734,,,,,0.921,,
+1736,,,,,0.883,,
+1738,,,,,0.845,,
+1740,,,,,0.791,,
+1742,,,,,0.711,,
+1744,,,,,0.638,,
+1747,,,,,0.547,,
+1749,,,,,0.462,,
+1751,,,,,0.393,,
+1753,,,,,0.325,,
+1755,,,,,0.267,,
+1757,,,,,0.212,,
+1759,,,,,0.175,,
+1761,,,,,0.142,,
+1763,,,,,0.111,,
+1765,,,,,0.084,,
+1767,,,,,0.077,,
+1769,,,,,0.058,,
+1771,,,,,0.049,,
+1773,,,,,0.042,,
+1775,,,,,0.039,,
+1777,,,,,0.034,,
+1779,,,,,0.02,,
+1781,,,,,0.021,,
+1783,,,,,0.022,,
+1785,,,,,0.011,,
+1787,,,,,0.012,,
+1789,,,,,0.004,,
+1791,,,,,0.008,,
+2001,,,,,,0.003,
+2003,,,,,,0.002,
+2005,,,,,,0.003,
+2007,,,,,,0.001,
+2009,,,,,,0,
+2011,,,,,,0.004,
+2013,,,,,,0.004,
+2015,,,,,,0.002,
+2017,,,,,,0.002,
+2018,,,,,,0.002,
+2020,,,,,,0.012,
+2022,,,,,,0.009,
+2024,,,,,,0.007,
+2026,,,,,,0.011,
+2028,,,,,,0.02,
+2030,,,,,,0.017,
+2032,,,,,,0.03,
+2034,,,,,,0.035,
+2035,,,,,,0.037,
+2037,,,,,,0.044,
+2039,,,,,,0.051,
+2041,,,,,,0.065,
+2043,,,,,,0.08,
+2045,,,,,,0.088,
+2047,,,,,,0.102,
+2049,,,,,,0.133,
+2051,,,,,,0.165,
+2052,,,,,,0.188,
+2054,,,,,,0.22,
+2056,,,,,,0.264,
+2058,,,,,,0.316,
+2060,,,,,,0.367,
+2062,,,,,,0.421,
+2064,,,,,,0.484,
+2066,,,,,,0.554,
+2067,,,,,,0.59,
+2069,,,,,,0.67,
+2071,,,,,,0.683,
+2073,,,,,,0.73,
+2075,,,,,,0.756,
+2077,,,,,,0.767,
+2079,,,,,,0.794,
+2081,,,,,,0.774,
+2083,,,,,,0.776,
+2085,,,,,,0.789,
+2086,,,,,,0.775,
+2088,,,,,,0.784,
+2090,,,,,,0.778,
+2092,,,,,,0.768,
+2094,,,,,,0.762,
+2096,,,,,,0.761,
+2099,,,,,,0.775,
+2100,,,,,,0.775,
+2102,,,,,,0.764,
+2104,,,,,,0.784,
+2106,,,,,,0.792,
+2108,,,,,,0.814,
+2110,,,,,,0.794,
+2112,,,,,,0.825,
+2114,,,,,,0.817,
+2116,,,,,,0.806,
+2117,,,,,,0.819,
+2119,,,,,,0.821,
+2121,,,,,,0.852,
+2123,,,,,,0.832,
+2125,,,,,,0.836,
+2127,,,,,,0.85,
+2129,,,,,,0.855,
+2131,,,,,,0.862,
+2133,,,,,,0.853,
+2135,,,,,,0.871,
+2136,,,,,,0.848,
+2138,,,,,,0.882,
+2140,,,,,,0.875,
+2142,,,,,,0.86,
+2144,,,,,,0.856,
+2146,,,,,,0.887,
+2148,,,,,,0.85,
+2150,,,,,,0.872,
+2151,,,,,,0.879,
+2153,,,,,,0.857,
+2155,,,,,,0.865,
+2157,,,,,,0.867,
+2159,,,,,,0.871,
+2161,,,,,,0.882,
+2163,,,,,,0.87,
+2165,,,,,,0.869,
+2166,,,,,,0.873,
+2168,,,,,,0.877,
+2170,,,,,,0.868,
+2172,,,,,,0.88,
+2174,,,,,,0.877,
+2176,,,,,,0.87,
+2178,,,,,,0.878,
+2180,,,,,,0.88,
+2182,,,,,,0.868,
+2183,,,,,,0.881,
+2185,,,,,,0.87,
+2187,,,,,,0.856,
+2189,,,,,,0.863,
+2191,,,,,,0.863,
+2193,,,,,,0.857,
+2195,,,,,,0.844,
+2197,,,,,,0.859,
+2199,,,,,,0.857,
+2201,,,,,,0.852,
+2203,,,,,,0.866,
+2205,,,,,,0.868,
+2207,,,,,,0.856,
+2209,,,,,,0.856,
+2210,,,,,,0.847,
+2212,,,,,,0.861,
+2214,,,,,,0.862,
+2216,,,,,,0.84,
+2218,,,,,,0.856,
+2220,,,,,,0.838,
+2222,,,,,,0.856,
+2223,,,,,,0.837,
+2226,,,,,,0.842,
+2227,,,,,,0.826,
+2229,,,,,,0.844,
+2231,,,,,,0.827,
+2233,,,,,,0.842,
+2235,,,,,,0.822,
+2237,,,,,,0.843,
+2239,,,,,,0.823,
+2241,,,,,,0.854,
+2242,,,,,,0.839,
+2244,,,,,,0.853,
+2246,,,,,,0.854,
+2248,,,,,,0.865,
+2250,,,,,,0.873,
+2252,,,,,,0.869,
+2254,,,,,,0.865,
+2256,,,,,,0.893,
+2258,,,,,,0.89,
+2259,,,,,,0.89,
+2261,,,,,,0.906,
+2263,,,,,,0.924,
+2265,,,,,,0.92,
+2267,,,,,,0.922,
+2269,,,,,,0.939,
+2271,,,,,,0.916,
+2273,,,,,,0.94,
+2274,,,,,,0.93,
+2276,,,,,,0.942,
+2278,,,,,,0.957,
+2280,,,,,,0.954,
+2282,,,,,,0.951,
+2284,,,,,,0.954,
+2286,,,,,,0.966,
+2288,,,,,,0.975,
+2290,,,,,,0.985,
+2292,,,,,,0.971,
+2293,,,,,,0.973,
+2295,,,,,,0.97,
+2297,,,,,,0.993,
+2299,,,,,,0.996,
+2301,,,,,,0.983,
+2303,,,,,,0.972,
+2305,,,,,,1,
+2307,,,,,,0.998,
+2309,,,,,,0.971,
+2310,,,,,,0.968,
+2312,,,,,,0.967,
+2314,,,,,,0.962,
+2316,,,,,,0.949,
+2318,,,,,,0.923,
+2320,,,,,,0.929,
+2322,,,,,,0.917,
+2323,,,,,,0.934,
+2325,,,,,,0.903,
+2327,,,,,,0.926,
+2329,,,,,,0.916,
+2331,,,,,,0.942,
+2333,,,,,,0.924,
+2335,,,,,,0.92,
+2337,,,,,,0.863,
+2339,,,,,,0.824,
+2340,,,,,,0.775,
+2342,,,,,,0.684,
+2344,,,,,,0.583,
+2346,,,,,,0.48,
+2348,,,,,,0.378,
+2350,,,,,,0.275,
+2352,,,,,,0.233,
+2354,,,,,,0.171,
+2355,,,,,,0.131,
+2357,,,,,,0.111,
+2359,,,,,,0.081,
+2361,,,,,,0.069,
+2363,,,,,,0.046,
+2365,,,,,,0.029,
+2367,,,,,,0.038,
+2369,,,,,,0.002,
+2371,,,,,,0.029,
+2373,,,,,,0.016,
+2374,,,,,,0.009,
+2376,,,,,,0.017,
+2378,,,,,,0.003,
+2380,,,,,,0.015,
+2382,,,,,,0,
+2384,,,,,,0.009,
+2386,,,,,,0.007,
Modified: grass/branches/releasebranch_7_4/imagery/i.atcorr/sensors_csv/sentinel_2A_msi.csv
--- grass/branches/releasebranch_7_4/imagery/i.atcorr/sensors_csv/sentinel_2A_msi.csv 2018-03-24 16:42:50 UTC (rev 72556)
+++ grass/branches/releasebranch_7_4/imagery/i.atcorr/sensors_csv/sentinel_2A_msi.csv 2018-03-24 16:50:40 UTC (rev 72557)
@@ -1,2302 +1,2302 @@
-SR_WL,SR_AV_B1,SR_AV_B2,SR_AV_B3,SR_AV_B4,SR_AV_B5,SR_AV_B6,SR_AV_B7,SR_AV_B8,SR_AV_B8A,SR_AV_B9,SR_AV_B10,SR_AV_B11,SR_AV_B12
-300,0,0,0,0,0,0,0,0,0,0,0,0,0
-301,0,0,0,0,0,0,0,0,0,0,0,0,0
-302,0,0,0,0,0,0,0,0,0,0,0,0,0
-303,0,0,0,0,0,0,0,0,0,0,0,0,0
-304,0,0,0,0,0,0,0,0,0,0,0,0,0
-305,0,0,0,0,0,0,0,0,0,0,0,0,0
-306,0,0,0,0,0,0,0,0,0,0,0,0,0
-307,0,0,0,0,0,0,0,0,0,0,0,0,0
-308,0,0,0,0,0,0,0,0,0,0,0,0,0
-309,0,0,0,0,0,0,0,0,0,0,0,0,0
-310,0,0,0,0,0,0,0,0,0,0,0,0,0
-311,0,0,0,0,0,0,0,0,0,0,0,0,0
-312,0,0,0,0,0,0,0,0,0,0,0,0,0
-313,0,0,0,0,0,0,0,0,0,0,0,0,0
-314,0,0,0,0,0,0,0,0,0,0,0,0,0
-315,0,0,0,0,0,0,0,0,0,0,0,0,0
-316,0,0,0,0,0,0,0,0,0,0,0,0,0
-317,0,0,0,0,0,0,0,0,0,0,0,0,0
-318,0,0,0,0,0,0,0,0,0,0,0,0,0
-319,0,0,0,0,0,0,0,0,0,0,0,0,0
-320,0,0,0,0,0,0,0,0,0,0,0,0,0
-321,0,0,0,0,0,0,0,0,0,0,0,0,0
-322,0,0,0,0,0,0,0,0,0,0,0,0,0
-323,0,0,0,0,0,0,0,0,0,0,0,0,0
-324,0,0,0,0,0,0,0,0,0,0,0,0,0
-325,0,0,0,0,0,0,0,0,0,0,0,0,0
-326,0,0,0,0,0,0,0,0,0,0,0,0,0
-327,0,0,0,0,0,0,0,0,0,0,0,0,0
-328,0,0,0,0,0,0,0,0,0,0,0,0,0
-329,0,0,0,0,0,0,0,0,0,0,0,0,0
-330,0,0,0,0,0,0,0,0,0,0,0,0,0
-331,0,0,0,0,0,0,0,0,0,0,0,0,0
-332,0,0,0,0,0,0,0,0,0,0,0,0,0
-333,0,0,0,0,0,0,0,0,0,0,0,0,0
-334,0,0,0,0,0,0,0,0,0,0,0,0,0
-335,0,0,0,0,0,0,0,0,0,0,0,0,0
-336,0,0,0,0,0,0,0,0,0,0,0,0,0
-337,0,0,0,0,0,0,0,0,0,0,0,0,0
-338,0,0,0,0,0,0,0,0,0,0,0,0,0
-339,0,0,0,0,0,0,0,0,0,0,0,0,0
-340,0,0,0,0,0,0,0,0,0,0,0,0,0
-341,0,0,0,0,0,0,0,0,0,0,0,0,0
-342,0,0,0,0,0,0,0,0,0,0,0,0,0
-343,0,0,0,0,0,0,0,0,0,0,0,0,0
-344,0,0,0,0,0,0,0,0,0,0,0,0,0
-345,0,0,0,0,0,0,0,0,0,0,0,0,0
-346,0,0,0,0,0,0,0,0,0,0,0,0,0
-347,0,0,0,0,0,0,0,0,0,0,0,0,0
-348,0,0,0,0,0,0,0,0,0,0,0,0,0
-349,0,0,0,0,0,0,0,0,0,0,0,0,0
-350,0,0,0,0,0,0,0,0,0,0,0,0,0
-351,0,0,0,0,0,0,0,0,0,0,0,0,0
-352,0,0,0,0,0,0,0,0,0,0,0,0,0
-353,0,0,0,0,0,0,0,0,0,0,0,0,0
-354,0,0,0,0,0,0,0,0,0,0,0,0,0
-355,0,0,0,0,0,0,0,0,0,0,0,0,0
-356,0,0,0,0,0,0,0,0,0,0,0,0,0
-357,0,0,0,0,0,0,0,0,0,0,0,0,0
-358,0,0,0,0,0,0,0,0,0,0,0,0,0
-359,0,0,0,0,0,0,0,0,0,0,0,0,0
-360,0,0,0,0,0,0,0,0,0,0,0,0,0
-361,0,0,0,0,0,0,0,0,0,0,0,0,0
-362,0,0,0,0,0,0,0,0,0,0,0,0,0
-363,0,0,0,0,0,0,0,0,0,0,0,0,0
-364,0,0,0,0,0,0,0,0,0,0,0,0,0
-365,0,0,0,0,0,0,0,0,0,0,0,0,0
-366,0,0,0,0,0,0,0,0,0,0,0,0,0
-367,0,0,0,0,0,0,0,0,0,0,0,0,0
-368,0,0,0,0,0,0,0,0,0,0,0,0,0
-369,0,0,0,0,0,0,0,0,0,0,0,0,0
-370,0,0,0,0,0,0,0,0,0,0,0,0,0
-371,0,0,0,0,0,0,0,0,0,0,0,0,0
-372,0,0,0,0,0,0,0,0,0,0,0,0,0
-373,0,0,0,0,0,0,0,0,0,0,0,0,0
-374,0,0,0,0,0,0,0,0,0,0,0,0,0
-375,0,0,0,0,0,0,0,0,0,0,0,0,0
-376,0,0,0,0,0,0,0,0,0,0,0,0,0
-377,0,0,0,0,0,0,0,0,0,0,0,0,0
-378,0,0,0,0,0,0,0,0,0,0,0,0,0
-379,0,0,0,0,0,0,0,0,0,0,0,0,0
-380,0,0,0,0,0,0,0,0,0,0,0,0,0
-381,0,0,0,0,0,0,0,0,0,0,0,0,0
-382,0,0,0,0,0,0,0,0,0,0,0,0,0
-383,0,0,0,0,0,0,0,0,0,0,0,0,0
-384,0,0,0,0,0,0,0,0,0,0,0,0,0
-385,0,0,0,0,0,0,0,0,0,0,0,0,0
-386,0,0,0,0,0,0,0,0,0,0,0,0,0
-387,0,0,0,0,0,0,0,0,0,0,0,0,0
-388,0,0,0,0,0,0,0,0,0,0,0,0,0
-389,0,0,0,0,0,0,0,0,0,0,0,0,0
-390,0,0,0,0,0,0,0,0,0,0,0,0,0
-391,0,0,0,0,0,0,0,0,0,0,0,0,0
-392,0,0,0,0,0,0,0,0,0,0,0,0,0
-393,0,0,0,0,0,0,0,0,0,0,0,0,0
-394,0,0,0,0,0,0,0,0,0,0,0,0,0
-395,0,0,0,0,0,0,0,0,0,0,0,0,0
-396,0,0,0,0,0,0,0,0,0,0,0,0,0
-397,0,0,0,0,0,0,0,0,0,0,0,0,0
-398,0,0,0,0,0,0,0,0,0,0,0,0,0
-399,0,0,0,0,0,0,0,0,0,0,0,0,0
-400,0,0,0,0,0,0,0,0,0,0,0,0,0
-401,0,0,0,0,0,0,0,0,0,0,0,0,0
-402,0,0,0,0,0,0,0,0,0,0,0,0,0
-403,0,0,0,0,0,0,0,0,0,0,0,0,0
-404,0,0,0,0,0,0,0,0,0,0,0,0,0
-405,0,0,0,0,0,0,0,0,0,0,0,0,0
-406,0,0,0,0,0,0,0,0,0,0,0,0,0
-407,0,0,0,0,0,0,0,0,0,0,0,0,0
-408,0,0,0,0,0,0,0,0,0,0,0,0,0
-409,0,0,0,0,0,0,0,0,0,0,0,0,0
-410,0,0,0,0,0,0,0,0,0,0,0,0,0
-411,0,0,0,0,0,0,0,0,0,0,0,0,0
-412,0,0,0,0,0,0,0,0,0,0,0,0,0
-413,0,0,0,0,0,0,0,0,0,0,0,0,0
-414,0,0,0,0,0,0,0,0,0,0,0,0,0
-415,0,0,0,0,0,0,0,0,0,0,0,0,0
-416,0,0,0,0,0,0,0,0,0,0,0,0,0
-417,0,0,0,0,0,0,0,0,0,0,0,0,0
-418,0,0,0,0,0,0,0,0,0,0,0,0,0
-419,0,0,0,0,0,0,0,0,0,0,0,0,0
-420,0,0,0,0,0,0,0,0,0,0,0,0,0
-421,0,0,0,0,0,0,0,0,0,0,0,0,0
-422,0,0,0,0,0,0,0,0,0,0,0,0,0
-423,0,0,0,0,0,0,0,0,0,0,0,0,0
-424,0,0,0,0,0,0,0,0,0,0,0,0,0
-425,0,0,0,0,0,0,0,0,0,0,0,0,0
-426,0,0,0,0,0,0,0,0,0,0,0,0,0
-427,0,0,0,0,0,0,0,0,0,0,0,0,0
-428,0,0,0,0,0,0,0,0,0,0,0,0,0
-429,0,0,0,0,0,0,0,0,0,0,0,0,0
-430,0.015297481,0,0,0,0,0,0,0,0,0,0,0,0
-431,0.067133233,0,0,0,0,0,0,0,0,0,0,0,0
-432,0.195930113,0,0,0,0,0,0,0,0,0,0,0,0
-433,0.357242315,0,0,0,0,0,0,0,0,0,0,0,0
-434,0.460570898,0,0,0,0,0,0,0,0,0,0,0,0
-435,0.511598127,0,0,0,0,0,0,0,0,0,0,0,0
-436,0.551050641,0,0,0,0,0,0,0,0,0,0,0,0
-437,0.587384921,0,0,0,0,0,0,0,0,0,0,0,0
-438,0.613478291,0,0,0,0,0,0,0,0,0,0,0,0
-439,0.650014299,0,0,0,0,0,0,0,0,0,0,0,0
-440,0.699199359,0.001205888,0,0,0,0,0,0,0,0,0,0,0
-441,0.745429719,0.002040369,0,0,0,0,0,0,0,0,0,0,0
-442,0.792047382,0.002622943,0,0,0,0,0,0,0,0,0,0,0
-443,0.862823932,0.002738239,0,0,0,0,0,0,0,0,0,0,0
-444,0.947306968,0.002746267,0,0,0,0,0,0,0,0,0,0,0
-445,0.993877543,0.002076292,0,0,0,0,0,0,0,0,0,0,0
-446,1,0.003245683,0,0,0,0,0,0,0,0,0,0,0
-447,0.990178205,0.002224086,0,0,0,0,0,0,0,0,0,0,0
-448,0.972897069,0.002788526,0,0,0,0,0,0,0,0,0,0,0
-449,0.957041994,0.003127464,0,0,0,0,0,0,0,0,0,0,0
-450,0.956725717,0.002376761,0,0,0,0,0,0,0,0,0,0,0
-451,0.922388676,0.003775739,0,0,0,0,0,0,0,0,0,0,0
-452,0.723932953,0.002855863,0,0,0,0,0,0,0,0,0,0,0
-453,0.388301825,0.003063208,0,0,0,0,0,0,0,0,0,0,0
-454,0.145959579,0.00606979,0,0,0,0,0,0,0,0,0,0,0
-455,0.051814319,0.009028311,0,0,0,0,0,0,0,0,0,0,0
-456,0.017459195,0.019546756,0,0,0,0,0,0,0,0,0,0,0
-457,0.00030266,0.038955457,0,0,0,0,0,0,0,0,0,0,0
-458,0,0.084087582,0,0,0,0,0,0,0,0,0,0,0
-459,0,0.176255447,0,0,0,0,0,0,0,0,0,0,0
-460,0,0.292197461,0,0,0,0,0,0,0,0,0,0,0
-461,0,0.364611634,0,0,0,0,0,0,0,0,0,0,0
-462,0,0.382417769,0,0,0,0,0,0,0,0,0,0,0
-463,0,0.385788698,0,0,0,0,0,0,0,0,0,0,0
-464,0,0.393447498,0,0,0,0,0,0,0,0,0,0,0
-465,0,0.400157587,0,0,0,0,0,0,0,0,0,0,0
-466,0,0.410290956,0,0,0,0,0,0,0,0,0,0,0
-467,0,0.424686229,0,0,0,0,0,0,0,0,0,0,0
-468,0,0.449286442,0,0,0,0,0,0,0,0,0,0,0
-469,0,0.481594435,0,0,0,0,0,0,0,0,0,0,0
-470,0,0.505322972,0,0,0,0,0,0,0,0,0,0,0
-471,0,0.523406072,0,0,0,0,0,0,0,0,0,0,0
-472,0,0.529542808,0,0,0,0,0,0,0,0,0,0,0
-473,0,0.534687923,0,0,0,0,0,0,0,0,0,0,0
-474,0,0.53378568,0,0,0,0,0,0,0,0,0,0,0
-475,0,0.534655585,0,0,0,0,0,0,0,0,0,0,0
-476,0,0.538100358,0,0,0,0,0,0,0,0,0,0,0
-477,0,0.543690952,0,0,0,0,0,0,0,0,0,0,0
-478,0,0.557717041,0,0,0,0,0,0,0,0,0,0,0
-479,0,0.578584682,0,0,0,0,0,0,0,0,0,0,0
-480,0,0.601967211,0,0,0,0,0,0,0,0,0,0,0
-481,0,0.616036805,0,0,0,0,0,0,0,0,0,0,0
-482,0,0.621092399,0,0,0,0,0,0,0,0,0,0,0
-483,0,0.613596882,0,0,0,0,0,0,0,0,0,0,0
-484,0,0.596062382,0,0,0,0,0,0,0,0,0,0,0
-485,0,0.575862788,0,0,0,0,0,0,0,0,0,0,0
-486,0,0.558063043,0,0,0,0,0,0,0,0,0,0,0
-487,0,0.546131078,0,0,0,0,0,0,0,0,0,0,0
-488,0,0.54209908,0,0,0,0,0,0,0,0,0,0,0
-489,0,0.553601967,0,0,0,0,0,0,0,0,0,0,0
-490,0,0.571684349,0,0,0,0,0,0,0,0,0,0,0
-491,0,0.59826863,0,0,0,0,0,0,0,0,0,0,0
-492,0,0.633236261,0,0,0,0,0,0,0,0,0,0,0
-493,0,0.673370128,0,0,0,0,0,0,0,0,0,0,0
-494,0,0.711752423,0,0,0,0,0,0,0,0,0,0,0
-495,0,0.738396013,0,0,0,0,0,0,0,0,0,0,0
-496,0,0.758249128,0,0,0,0,0,0,0,0,0,0,0
-497,0,0.768324786,0,0,0,0,0,0,0,0,0,0,0
-498,0,0.773366977,0,0,0,0,0,0,0,0,0,0,0
-499,0,0.780467611,0,0,0,0,0,0,0,0,0,0,0
-500,0,0.788363273,0,0,0,0,0,0,0,0,0,0,0
-501,0,0.795449465,0,0,0,0,0,0,0,0,0,0,0
-502,0,0.80915086,0,0,0,0,0,0,0,0,0,0,0
-503,0,0.824011214,0,0,0,0,0,0,0,0,0,0,0
-504,0,0.837708797,0,0,0,0,0,0,0,0,0,0,0
-505,0,0.844983399,0,0,0,0,0,0,0,0,0,0,0
-506,0,0.847328129,0,0,0,0,0,0,0,0,0,0,0
-507,0,0.840111452,0,0,0,0,0,0,0,0,0,0,0
-508,0,0.825797103,0,0,0,0,0,0,0,0,0,0,0
-509,0,0.804777753,0,0,0,0,0,0,0,0,0,0,0
-510,0,0.786940349,0,0,0,0,0,0,0,0,0,0,0
-511,0,0.77157774,0,0,0,0,0,0,0,0,0,0,0
-512,0,0.761922541,0,0,0,0,0,0,0,0,0,0,0
-513,0,0.765487222,0,0,0,0,0,0,0,0,0,0,0
-514,0,0.781682215,0,0,0,0,0,0,0,0,0,0,0
-515,0,0.810031414,0,0,0,0,0,0,0,0,0,0,0
-516,0,0.850586321,0,0,0,0,0,0,0,0,0,0,0
-517,0,0.901670684,0,0,0,0,0,0,0,0,0,0,0
-518,0,0.954670055,0,0,0,0,0,0,0,0,0,0,0
-519,0,0.987257367,0,0,0,0,0,0,0,0,0,0,0
-520,0,1,0,0,0,0,0,0,0,0,0,0,0
-521,0,0.986389206,0,0,0,0,0,0,0,0,0,0,0
-522,0,0.908308105,0,0,0,0,0,0,0,0,0,0,0
-523,0,0.724000074,0,0,0,0,0,0,0,0,0,0,0
-524,0,0.478912868,0,0,0,0,0,0,0,0,0,0,0
-525,0,0.286992071,0,0,0,0,0,0,0,0,0,0,0
-526,0,0.1699762,0,0,0,0,0,0,0,0,0,0,0
-527,0,0.102833112,0,0,0,0,0,0,0,0,0,0,0
-528,0,0.06516336,0,0,0,0,0,0,0,0,0,0,0
-529,0,0.041159879,0,0,0,0,0,0,0,0,0,0,0
-530,0,0.025079521,0,0,0,0,0,0,0,0,0,0,0
-531,0,0.013112047,0,0,0,0,0,0,0,0,0,0,0
-532,0,0.002584728,0,0,0,0,0,0,0,0,0,0,0
-533,0,0.001094622,0,0,0,0,0,0,0,0,0,0,0
-534,0,0.000307621,0,0,0,0,0,0,0,0,0,0,0
-535,0,0.000441445,0,0,0,0,0,0,0,0,0,0,0
-536,0,0,0,0,0,0,0,0,0,0,0,0,0
-537,0,0,0.000840124,0,0,0,0,0,0,0,0,0,0
-538,0,0.000443422,0.016371608,0,0,0,0,0,0,0,0,0,0
-539,0,0,0.037688294,0,0,0,0,0,0,0,0,0,0
-540,0,0,0.080665026,0,0,0,0,0,0,0,0,0,0
-541,0,0,0.169508863,0,0,0,0,0,0,0,0,0,0
-542,0,0,0.341374391,0,0,0,0,0,0,0,0,0,0
-543,0,0,0.573031109,0,0,0,0,0,0,0,0,0,0
-544,0,0,0.746711409,0,0,0,0,0,0,0,0,0,0
-545,0,0,0.828036215,0,0,0,0,0,0,0,0,0,0
-546,0,0,0.868227545,0,0,0,0,0,0,0,0,0,0
-547,0,0,0.888565006,0,0,0,0,0,0,0,0,0,0
-548,0,0,0.891572433,0,0,0,0,0,0,0,0,0,0
-549,0,0,0.878150361,0,0,0,0,0,0,0,0,0,0
-550,0,0,0.860270532,0,0,0,0,0,0,0,0,0,0
-551,0,0,0.843697821,0,0,0,0,0,0,0,0,0,0
-552,0,0,0.83403461,0,0,0,0,0,0,0,0,0,0
-553,0,0,0.832616875,0,0,0,0,0,0,0,0,0,0
-554,0,0,0.844968248,0,0,0,0,0,0,0,0,0,0
-555,0,0,0.867733874,0,0,0,0,0,0,0,0,0,0
-556,0,0,0.897360859,0,0,0,0,0,0,0,0,0,0
-557,0,0,0.933938145,0,0,0,0,0,0,0,0,0,0
-558,0,0,0.966922619,0,0,0,0,0,0,0,0,0,0
-559,0,0,0.990762023,0,0,0,0,0,0,0,0,0,0
-560,0,0,1,0,0,0,0,0,0,0,0,0,0
-561,0,0,0.9978116,0,0,0,0,0,0,0,0,0,0
-562,0,0,0.981107343,0,0,0,0,0,0,0,0,0,0
-563,0,0,0.947088021,0,0,0,0,0,0,0,0,0,0
-564,0,0,0.907183271,0,0,0,0,0,0,0,0,0,0
-565,0,0,0.86865614,0,0,0,0,0,0,0,0,0,0
-566,0,0,0.837621551,0,0,0,0,0,0,0,0,0,0
-567,0,0,0.812909776,0,0,0,0,0,0,0,0,0,0
-568,0,0,0.792433535,0,0,0,0,0,0,0,0,0,0
-569,0,0,0.7850998,0,0,0,0,0,0,0,0,0,0
-570,0,0,0.789606081,0,0,0,0,0,0,0,0,0,0
-571,0,0,0.807011178,0,0,0,0,0,0,0,0,0,0
-572,0,0,0.830457678,0,0,0,0,0,0,0,0,0,0
-573,0,0,0.846432825,0,0,0,0,0,0,0,0,0,0
-574,0,0,0.858401768,0,0,0,0,0,0,0,0,0,0
-575,0,0,0.857990221,0,0,0,0,0,0,0,0,0,0
-576,0,0,0.799824045,0,0,0,0,0,0,0,0,0,0
-577,0,0,0.624979915,0,0,0,0,0,0,0,0,0,0
-578,0,0,0.38699351,0,0,0,0,0,0,0,0,0,0
-579,0,0,0.200178754,0,0,0,0,0,0,0,0,0,0
-580,0,0,0.098292953,0,0,0,0,0,0,0,0,0,0
-581,0,0,0.042843571,0,0,0,0,0,0,0,0,0,0
-582,0,0,0.01651236,0,0,0,0,0,0,0,0,0,0
-583,0,0,0,0,0,0,0,0,0,0,0,0,0
-584,0,0,0,0,0,0,0,0,0,0,0,0,0
-585,0,0,0,0,0,0,0,0,0,0,0,0,0
-586,0,0,0,0,0,0,0,0,0,0,0,0,0
-587,0,0,0,0,0,0,0,0,0,0,0,0,0
-588,0,0,0,0,0,0,0,0,0,0,0,0,0
-589,0,0,0,0,0,0,0,0,0,0,0,0,0
-590,0,0,0,0,0,0,0,0,0,0,0,0,0
-591,0,0,0,0,0,0,0,0,0,0,0,0,0
-592,0,0,0,0,0,0,0,0,0,0,0,0,0
-593,0,0,0,0,0,0,0,0,0,0,0,0,0
-594,0,0,0,0,0,0,0,0,0,0,0,0,0
-595,0,0,0,0,0,0,0,0,0,0,0,0,0
-596,0,0,0,0,0,0,0,0,0,0,0,0,0
-597,0,0,0,0,0,0,0,0,0,0,0,0,0
-598,0,0,0,0,0,0,0,0,0,0,0,0,0
-599,0,0,0,0,0,0,0,0,0,0,0,0,0
-600,0,0,0,0,0,0,0,0,0,0,0,0,0
-601,0,0,0,0,0,0,0,0,0,0,0,0,0
-602,0,0,0,0,0,0,0,0,0,0,0,0,0
-603,0,0,0,0,0,0,0,0,0,0,0,0,0
-604,0,0,0,0,0,0,0,0,0,0,0,0,0
-605,0,0,0,0,0,0,0,0,0,0,0,0,0
-606,0,0,0,0,0,0,0,0,0,0,0,0,0
-607,0,0,0,0,0,0,0,0,0,0,0,0,0
-608,0,0,0,0,0,0,0,0,0,0,0,0,0
-609,0,0,0,0,0,0,0,0,0,0,0,0,0
-610,0,0,0,0,0,0,0,0,0,0,0,0,0
-611,0,0,0,0,0,0,0,0,0,0,0,0,0
-612,0,0,0,0,0,0,0,0,0,0,0,0,0
-613,0,0,0,0,0,0,0,0,0,0,0,0,0
-614,0,0,0,0,0,0,0,0,0,0,0,0,0
-615,0,0,0,0,0,0,0,0,0,0,0,0,0
-616,0,0,0,0,0,0,0,0,0,0,0,0,0
-617,0,0,0,0,0,0,0,0,0,0,0,0,0
-618,0,0,0,0,0,0,0,0,0,0,0,0,0
-619,0,0,0,0,0,0,0,0,0,0,0,0,0
-620,0,0,0,0,0,0,0,0,0,0,0,0,0
-621,0,0,0,0,0,0,0,0,0,0,0,0,0
-622,0,0,0,0,0,0,0,0,0,0,0,0,0
-623,0,0,0,0,0,0,0,0,0,0,0,0,0
-624,0,0,0,0,0,0,0,0,0,0,0,0,0
-625,0,0,0,0,0,0,0,0,0,0,0,0,0
-626,0,0,0,0,0,0,0,0,0,0,0,0,0
-627,0,0,0,0,0,0,0,0,0,0,0,0,0
-628,0,0,0,0,0,0,0,0,0,0,0,0,0
-629,0,0,0,0,0,0,0,0,0,0,0,0,0
-630,0,0,0,0,0,0,0,0,0,0,0,0,0
-631,0,0,0,0,0,0,0,0,0,0,0,0,0
-632,0,0,0,0,0,0,0,0,0,0,0,0,0
-633,0,0,0,0,0,0,0,0,0,0,0,0,0
-634,0,0,0,0,0,0,0,0,0,0,0,0,0
-635,0,0,0,0,0,0,0,0,0,0,0,0,0
-636,0,0,0,0,0,0,0,0,0,0,0,0,0
-637,0,0,0,0,0,0,0,0,0,0,0,0,0
-638,0,0,0,0,0,0,0,0,0,0,0,0,0
-639,0,0,0,0,0,0,0,0,0,0,0,0,0
-640,0,0,0,0,0,0,0,0,0,0,0,0,0
-641,0,0,0,0,0,0,0,0,0,0,0,0,0
-642,0,0,0,0,0,0,0,0,0,0,0,0,0
-643,0,0,0,0,0,0,0,0,0,0,0,0,0
-644,0,0,0,0,0,0,0,0,0,0,0,0,0
-645,0,0,0,0,0,0,0,0,0,0,0,0,0
-646,0,0,0,0.002584161,0,0,0,0,0,0,0,0,0
-647,0,0,0,0.034529234,0,0,0,0,0,0,0,0,0
-648,0,0,0,0.149970293,0,0,0,0,0,0,0,0,0
-649,0,0,0,0.464825627,0,0,0,0,0,0,0,0,0
-650,0,0,0,0.81774561,0,0,0,0,0,0,0,0,0
-651,0,0,0,0.965323761,0,0,0,0,0,0,0,0,0
-652,0,0,0,0.983869281,0,0,0,0,0,0,0,0,0
-653,0,0,0,0.996900219,0,0,0,0,0,0,0,0,0
-654,0,0,0,1,0,0,0,0,0,0,0,0,0
-655,0,0,0,0.995449387,0,0,0,0,0,0,0,0,0
-656,0,0,0,0.991334334,0,0,0,0,0,0,0,0,0
-657,0,0,0,0.977215143,0,0,0,0,0,0,0,0,0
-658,0,0,0,0.936802357,0,0,0,0,0,0,0,0,0
-659,0,0,0,0.873776426,0,0,0,0,0,0,0,0,0
-660,0,0,0,0.814165825,0,0,0,0,0,0,0,0,0
-661,0,0,0,0.776668942,0,0,0,0,0,0,0,0,0
-662,0,0,0,0.764863979,0,0,0,0,0,0,0,0,0
-663,0,0,0,0.77509069,0,0,0,0,0,0,0,0,0
-664,0,0,0,0.801358663,0,0,0,0,0,0,0,0,0
-665,0,0,0,0.830827664,0,0,0,0,0,0,0,0,0
-666,0,0,0,0.857111548,0,0,0,0,0,0,0,0,0
-667,0,0,0,0.883580858,0,0,0,0,0,0,0,0,0
-668,0,0,0,0.908949643,0,0,0,0,0,0,0,0,0
-669,0,0,0,0.934759132,0,0,0,0,0,0,0,0,0
-670,0,0,0,0.955930529,0,0,0,0,0,0,0,0,0
-671,0,0,0,0.968110072,0,0,0,0,0,0,0,0,0
-672,0,0,0,0.973218918,0,0,0,0,0,0,0,0,0
-673,0,0,0,0.971572352,0,0,0,0,0,0,0,0,0
-674,0,0,0,0.969002767,0,0,0,0,0,0,0,0,0
-675,0,0,0,0.965711927,0,0,0,0,0,0,0,0,0
-676,0,0,0,0.960481316,0,0,0,0,0,0,0,0,0
-677,0,0,0,0.944810855,0,0,0,0,0,0,0,0,0
-678,0,0,0,0.884152441,0,0,0,0,0,0,0,0,0
-679,0,0,0,0.706167011,0,0,0,0,0,0,0,0,0
-680,0,0,0,0.422966946,0,0,0,0,0,0,0,0,0
-681,0,0,0,0.189853092,0,0,0,0,0,0,0,0,0
-682,0,0,0,0.063171769,0,0,0,0,0,0,0,0,0
-683,0,0,0,0.020615018,0,0,0,0,0,0,0,0,0
-684,0,0,0,0.00203356,0,0,0,0,0,0,0,0,0
-685,0,0,0,0,0,0,0,0,0,0,0,0,0
-686,0,0,0,0,0,0,0,0,0,0,0,0,0
-687,0,0,0,0,0,0,0,0,0,0,0,0,0
-688,0,0,0,0,0,0,0,0,0,0,0,0,0
-689,0,0,0,0,0,0,0,0,0,0,0,0,0
-690,0,0,0,0,0,0,0,0,0,0,0,0,0
-691,0,0,0,0,0,0,0,0,0,0,0,0,0
-692,0,0,0,0,0,0,0,0,0,0,0,0,0
-693,0,0,0,0,0,0,0,0,0,0,0,0,0
-694,0,0,0,0,0.001187444,0,0,0,0,0,0,0,0
-695,0,0,0,0,0.04125993,0,0,0,0,0,0,0,0
-696,0,0,0,0,0.167711986,0,0,0,0,0,0,0,0
-697,0,0,0,0,0.478496499,0,0,0,0,0,0,0,0
-698,0,0,0,0,0.833877813,0,0,0,0,0,0,0,0
-699,0,0,0,0,0.985479087,0,0,0,0,0,0,0,0
-700,0,0,0,0,1,0,0,0,0,0,0,0,0
-701,0,0,0,0,0.999264633,0,0,0,0,0,0,0,0
-702,0,0,0,0,0.993238984,0,0,0,0,0,0,0,0
-703,0,0,0,0,0.982416076,0,0,0,0,0,0,0,0
-704,0,0,0,0,0.965583054,0,0,0,0,0,0,0,0
-705,0,0,0,0,0.945953346,0,0,0,0,0,0,0,0
-706,0,0,0,0,0.92469939,0,0,0,0,0,0,0,0
-707,0,0,0,0,0.902398691,0,0,0,0,0,0,0,0
-708,0,0,0,0,0.885582389,0,0,0,0,0,0,0,0
-709,0,0,0,0,0.861231139,0,0,0,0,0,0,0,0
-710,0,0,0,0,0.75719742,0,0,0,0,0,0,0,0
-711,0,0,0,0,0.521268244,0,0,0,0,0,0,0,0
-712,0,0,0,0,0.196705539,0,0,0,0,0,0,0,0
-713,0,0,0,0,0.036825443,0,0,0,0,0,0,0,0
-714,0,0,0,0,0,0,0,0,0,0,0,0,0
-715,0,0,0,0,0,0,0,0,0,0,0,0,0
-716,0,0,0,0,0,0,0,0,0,0,0,0,0
-717,0,0,0,0,0,0,0,0,0,0,0,0,0
-718,0,0,0,0,0,0,0,0,0,0,0,0,0
-719,0,0,0,0,0,0,0,0,0,0,0,0,0
-720,0,0,0,0,0,0,0,0,0,0,0,0,0
-721,0,0,0,0,0,0,0,0,0,0,0,0,0
-722,0,0,0,0,0,0,0,0,0,0,0,0,0
-723,0,0,0,0,0,0,0,0,0,0,0,0,0
-724,0,0,0,0,0,0,0,0,0,0,0,0,0
-725,0,0,0,0,0,0,0,0,0,0,0,0,0
-726,0,0,0,0,0,0,0,0,0,0,0,0,0
-727,0,0,0,0,0,0,0,0,0,0,0,0,0
-728,0,0,0,0,0,0,0,0,0,0,0,0,0
-729,0,0,0,0,0,0,0,0,0,0,0,0,0
-730,0,0,0,0,0,0,0,0,0,0,0,0,0
-731,0,0,0,0,0,0.005330671,0,0,0,0,0,0,0
-732,0,0,0,0,0,0.085006217,0,0,0,0,0,0,0
-733,0,0,0,0,0,0.345713766,0,0,0,0,0,0,0
-734,0,0,0,0,0,0.750597792,0,0,0,0,0,0,0
-735,0,0,0,0,0,0.920264708,0,0,0,0,0,0,0
-736,0,0,0,0,0,0.917916631,0,0,0,0,0,0,0
-737,0,0,0,0,0,0.934211456,0,0,0,0,0,0,0
-738,0,0,0,0,0,0.957861013,0,0,0,0,0,0,0
-739,0,0,0,0,0,0.975828536,0,0,0,0,0,0,0
-740,0,0,0,0,0,0.98193229,0,0,0,0,0,0,0
-741,0,0,0,0,0,0.981517629,0,0,0,0,0,0,0
-742,0,0,0,0,0,0.993405644,0,0,0,0,0,0,0
-743,0,0,0,0,0,1,0,0,0,0,0,0,0
-744,0,0,0,0,0,0.982578961,0,0,0,0,0,0,0
-745,0,0,0,0,0,0.962584247,0,0,0,0,0,0,0
-746,0,0,0,0,0,0.854907617,0,0,0,0,0,0,0
-747,0,0,0,0,0,0.506721697,0,0,0,0,0,0,0
-748,0,0,0,0,0,0.135356773,0,0,0,0,0,0,0
-749,0,0,0,0,0,0.013437848,0,0,0,0,0,0,0
-750,0,0,0,0,0,0,0,0,0,0,0,0,0
-751,0,0,0,0,0,0,0,0,0,0,0,0,0
-752,0,0,0,0,0,0,0,0,0,0,0,0,0
-753,0,0,0,0,0,0,0,0,0,0,0,0,0
-754,0,0,0,0,0,0,0,0,0,0,0,0,0
-755,0,0,0,0,0,0,0,0,0,0,0,0,0
-756,0,0,0,0,0,0,0,0,0,0,0,0,0
-757,0,0,0,0,0,0,0,0,0,0,0,0,0
-758,0,0,0,0,0,0,0,0,0,0,0,0,0
-759,0,0,0,0,0,0,0,0,0,0,0,0,0
-760,0,0,0,0,0,0,0,0.001355706,0,0,0,0,0
-761,0,0,0,0,0,0,0,0.00392374,0,0,0,0,0
-762,0,0,0,0,0,0,0,0,0,0,0,0,0
-763,0,0,0,0,0,0,0,0,0,0,0,0,0
-764,0,0,0,0,0,0,0,0,0,0,0,0,0
-765,0,0,0,0,0,0,0,0,0,0,0,0,0
-766,0,0,0,0,0,0,0,0,0,0,0,0,0
-767,0,0,0,0,0,0,0,0,0,0,0,0,0
-768,0,0,0,0,0,0,0,0,0,0,0,0,0
-769,0,0,0,0,0,0,0.001594992,0,0,0,0,0,0
-770,0,0,0,0,0,0,0.014730731,0,0,0,0,0,0
-771,0,0,0,0,0,0,0.067032359,0,0,0,0,0,0
-772,0,0,0,0,0,0,0.199494764,0,0,0,0,0,0
-773,0,0,0,0,0,0,0.422803402,0.000450635,0,0,0,0,0
-774,0,0,0,0,0,0,0.694015129,0.007613759,0,0,0,0,0
-775,0,0,0,0,0,0,0.898494293,0.019071631,0,0,0,0,0
-776,0,0,0,0,0,0,0.98317272,0.033498212,0,0,0,0,0
-777,0,0,0,0,0,0,0.994759437,0.056535957,0,0,0,0,0
-778,0,0,0,0,0,0,1,0.087148412,0,0,0,0,0
-779,0,0,0,0,0,0,0.994912942,0.132460432,0,0,0,0,0
-780,0,0,0,0,0,0,0.964656595,0.203435597,0,0,0,0,0
-781,0,0,0,0,0,0,0.9081173,0.314067835,0,0,0,0,0
-782,0,0,0,0,0,0,0.846897588,0.450084527,0,0,0,0,0
-783,0,0,0,0,0,0,0.802090526,0.587432873,0,0,0,0,0
-784,0,0,0,0,0,0,0.778839292,0.714518008,0,0,0,0,0
-785,0,0,0,0,0,0,0.777241149,0.818289983,0,0,0,0,0
-786,0,0,0,0,0,0,0.789523421,0.902931705,0,0,0,0,0
-787,0,0,0,0,0,0,0.800984088,0.960731839,0,0,0,0,0
-788,0,0,0,0,0,0,0.802915583,0.993723492,0,0,0,0,0
-789,0,0,0,0,0,0,0.791711439,1,0,0,0,0,0
-790,0,0,0,0,0,0,0.75769539,0.985213358,0,0,0,0,0
-791,0,0,0,0,0,0,0.6779514,0.958375658,0,0,0,0,0
-792,0,0,0,0,0,0,0.536855477,0.936550397,0,0,0,0,0
-793,0,0,0,0,0,0,0.36403261,0.925816084,0,0,0,0,0
-794,0,0,0,0,0,0,0.193498289,0.930376113,0,0,0,0,0
-795,0,0,0,0,0,0,0.077219076,0.941280824,0,0,0,0,0
-796,0,0,0,0,0,0,0.019707088,0.953344085,0,0,0,0,0
-797,0,0,0,0,0,0,0.003152148,0.962183412,0,0,0,0,0
-798,0,0,0,0,0,0,0,0.965630921,0,0,0,0,0
-799,0,0,0,0,0,0,0,0.963105088,0,0,0,0,0
-800,0,0,0,0,0,0,0,0.959009302,0,0,0,0,0
-801,0,0,0,0,0,0,0,0.951205343,0,0,0,0,0
-802,0,0,0,0,0,0,0,0.945147193,0,0,0,0,0
-803,0,0,0,0,0,0,0,0.943136098,0,0,0,0,0
-804,0,0,0,0,0,0,0,0.945814423,0,0,0,0,0
-805,0,0,0,0,0,0,0,0.945357393,0,0,0,0,0
-806,0,0,0,0,0,0,0,0.94376216,0,0,0,0,0
-807,0,0,0,0,0,0,0,0.937084132,0,0,0,0,0
-808,0,0,0,0,0,0,0,0.92789036,0,0,0,0,0
-809,0,0,0,0,0,0,0,0.915897097,0,0,0,0,0
-810,0,0,0,0,0,0,0,0.900979012,0,0,0,0,0
-811,0,0,0,0,0,0,0,0.881577413,0,0,0,0,0
-812,0,0,0,0,0,0,0,0.862159752,0,0,0,0,0
-813,0,0,0,0,0,0,0,0.843199839,0,0,0,0,0
-814,0,0,0,0,0,0,0,0.822684437,0,0,0,0,0
-815,0,0,0,0,0,0,0,0.801818585,0,0,0,0,0
-816,0,0,0,0,0,0,0,0.776911255,0,0,0,0,0
-817,0,0,0,0,0,0,0,0.755631985,0,0,0,0,0
-818,0,0,0,0,0,0,0,0.737893018,0,0,0,0,0
-819,0,0,0,0,0,0,0,0.722216874,0,0,0,0,0
-820,0,0,0,0,0,0,0,0.708669463,0,0,0,0,0
-821,0,0,0,0,0,0,0,0.698415904,0,0,0,0,0
-822,0,0,0,0,0,0,0,0.690210597,0,0,0,0,0
-823,0,0,0,0,0,0,0,0.682257441,0,0,0,0,0
-824,0,0,0,0,0,0,0,0.681493822,0,0,0,0,0
-825,0,0,0,0,0,0,0,0.682648562,0,0,0,0,0
-826,0,0,0,0,0,0,0,0.678490529,0,0,0,0,0
-827,0,0,0,0,0,0,0,0.675950258,0,0,0,0,0
-828,0,0,0,0,0,0,0,0.671303773,0,0,0,0,0
-829,0,0,0,0,0,0,0,0.665537745,0,0,0,0,0
-830,0,0,0,0,0,0,0,0.66081163,0,0,0,0,0
-831,0,0,0,0,0,0,0,0.658738951,0,0,0,0,0
-832,0,0,0,0,0,0,0,0.658309532,0,0,0,0,0
-833,0,0,0,0,0,0,0,0.664070258,0,0,0,0,0
-834,0,0,0,0,0,0,0,0.672731215,0,0,0,0,0
-835,0,0,0,0,0,0,0,0.685500932,0,0,0,0,0
-836,0,0,0,0,0,0,0,0.701159193,0,0,0,0,0
-837,0,0,0,0,0,0,0,0.720686012,0,0,0,0,0
-838,0,0,0,0,0,0,0,0.742291656,0,0,0,0,0
-839,0,0,0,0,0,0,0,0.759530325,0,0,0,0,0
-840,0,0,0,0,0,0,0,0.776608407,0,0,0,0,0
-841,0,0,0,0,0,0,0,0.784061465,0,0,0,0,0
-842,0,0,0,0,0,0,0,0.787719795,0,0,0,0,0
-843,0,0,0,0,0,0,0,0.787693087,0,0,0,0,0
-844,0,0,0,0,0,0,0,0.783525132,0,0,0,0,0
-845,0,0,0,0,0,0,0,0.776160838,0,0,0,0,0
-846,0,0,0,0,0,0,0,0.768338994,0,0,0,0,0
-847,0,0,0,0,0,0,0,0.759263845,0,0,0,0,0
-848,0,0,0,0,0,0,0,0.745942736,0.001651482,0,0,0,0
-849,0,0,0,0,0,0,0,0.733021996,0.013241944,0,0,0,0
-850,0,0,0,0,0,0,0,0.720589328,0.02470983,0,0,0,0
-851,0,0,0,0,0,0,0,0.70666322,0.051378748,0,0,0,0
-852,0,0,0,0,0,0,0,0.690869992,0.104943729,0,0,0,0
-853,0,0,0,0,0,0,0,0.675896147,0.216577278,0,0,0,0
-854,0,0,0,0,0,0,0,0.661558281,0.384864982,0,0,0,0
-855,0,0,0,0,0,0,0,0.64933885,0.58573065,0,0,0,0
-856,0,0,0,0,0,0,0,0.638008141,0.774480911,0,0,0,0
-857,0,0,0,0,0,0,0,0.627423662,0.878430125,0,0,0,0
-858,0,0,0,0,0,0,0,0.618963341,0.914944349,0,0,0,0
-859,0,0,0,0,0,0,0,0.610944526,0.922574113,0,0,0,0
-860,0,0,0,0,0,0,0,0.604321526,0.926042621,0,0,0,0
-861,0,0,0,0,0,0,0,0.597408353,0.929675951,0,0,0,0
-862,0,0,0,0,0,0,0,0.591723999,0.935961875,0,0,0,0
-863,0,0,0,0,0,0,0,0.586961129,0.946583152,0,0,0,0
-864,0,0,0,0,0,0,0,0.582746486,0.955792448,0,0,0,0
-865,0,0,0,0,0,0,0,0.581201871,0.965457804,0,0,0,0
-866,0,0,0,0,0,0,0,0.579479626,0.97446123,0,0,0,0
-867,0,0,0,0,0,0,0,0.580196837,0.979880105,0,0,0,0
-868,0,0,0,0,0,0,0,0.582505031,0.983324607,0,0,0,0
-869,0,0,0,0,0,0,0,0.58530811,0.982880911,0,0,0,0
-870,0,0,0,0,0,0,0,0.589480742,0.988474082,0,0,0,0
-871,0,0,0,0,0,0,0,0.592827138,1,0,0,0,0
-872,0,0,0,0,0,0,0,0.596748769,0.999625841,0,0,0,0
-873,0,0,0,0,0,0,0,0.601371824,0.921004618,0,0,0,0
-874,0,0,0,0,0,0,0,0.603233742,0.728632177,0,0,0,0
-875,0,0,0,0,0,0,0,0.605476073,0.472188662,0,0,0,0
-876,0,0,0,0,0,0,0,0.608971784,0.238081733,0,0,0,0
-877,0,0,0,0,0,0,0,0.613462535,0.106954864,0,0,0,0
-878,0,0,0,0,0,0,0,0.618715384,0.046095951,0,0,0,0
-879,0,0,0,0,0,0,0,0.626840684,0.022225825,0,0,0,0
-880,0,0,0,0,0,0,0,0.637435801,0.008818811,0,0,0,0
-881,0,0,0,0,0,0,0,0.648790775,0.000455417,0,0,0,0
-882,0,0,0,0,0,0,0,0.659233472,0,0,0,0,0
-883,0,0,0,0,0,0,0,0.667340083,0,0,0,0,0
-884,0,0,0,0,0,0,0,0.668623741,0,0,0,0,0
-885,0,0,0,0,0,0,0,0.659923886,0,0,0,0,0
-886,0,0,0,0,0,0,0,0.641665694,0,0,0,0,0
-887,0,0,0,0,0,0,0,0.615841396,0,0,0,0,0
-888,0,0,0,0,0,0,0,0.583567134,0,0,0,0,0
-889,0,0,0,0,0,0,0,0.552075805,0,0,0,0,0
-890,0,0,0,0,0,0,0,0.526406778,0,0,0,0,0
-891,0,0,0,0,0,0,0,0.507116158,0,0,0,0,0
-892,0,0,0,0,0,0,0,0.496530349,0,0,0,0,0
-893,0,0,0,0,0,0,0,0.499119291,0,0,0,0,0
-894,0,0,0,0,0,0,0,0.512088404,0,0,0,0,0
-895,0,0,0,0,0,0,0,0.529092988,0,0,0,0,0
-896,0,0,0,0,0,0,0,0.542739266,0,0,0,0,0
-897,0,0,0,0,0,0,0,0.5379639,0,0,0,0,0
-898,0,0,0,0,0,0,0,0.495953057,0,0,0,0,0
-899,0,0,0,0,0,0,0,0.419304575,0,0,0,0,0
-900,0,0,0,0,0,0,0,0.326791448,0,0,0,0,0
-901,0,0,0,0,0,0,0,0.231084503,0,0,0,0,0
-902,0,0,0,0,0,0,0,0.148540083,0,0,0,0,0
-903,0,0,0,0,0,0,0,0.089683145,0,0,0,0,0
-904,0,0,0,0,0,0,0,0.05497712,0,0,0,0,0
-905,0,0,0,0,0,0,0,0.033245719,0,0,0,0,0
-906,0,0,0,0,0,0,0,0.019774274,0,0,0,0,0
-907,0,0,0,0,0,0,0,0.007847675,0,0,0,0,0
-908,0,0,0,0,0,0,0,0.001285769,0,0,0,0,0
-909,0,0,0,0,0,0,0,0,0,0,0,0,0
-910,0,0,0,0,0,0,0,0,0,0,0,0,0
-911,0,0,0,0,0,0,0,0,0,0,0,0,0
-912,0,0,0,0,0,0,0,0,0,0,0,0,0
-913,0,0,0,0,0,0,0,0,0,0,0,0,0
-914,0,0,0,0,0,0,0,0,0,0,0,0,0
-915,0,0,0,0,0,0,0,0,0,0,0,0,0
-916,0,0,0,0,0,0,0,0,0,0,0,0,0
-917,0,0,0,0,0,0,0,0,0,0,0,0,0
-918,0,0,0,0,0,0,0,0,0,0,0,0,0
-919,0,0,0,0,0,0,0,0,0,0,0,0,0
-920,0,0,0,0,0,0,0,0,0,0,0,0,0
-921,0,0,0,0,0,0,0,0,0,0,0,0,0
-922,0,0,0,0,0,0,0,0,0,0,0,0,0
-923,0,0,0,0,0,0,0,0,0,0,0,0,0
-924,0,0,0,0,0,0,0,0,0,0,0,0,0
-925,0,0,0,0,0,0,0,0,0,0,0,0,0
-926,0,0,0,0,0,0,0,0,0,0,0,0,0
-927,0,0,0,0,0,0,0,0,0,0,0,0,0
-928,0,0,0,0,0,0,0,0,0,0,0,0,0
-929,0,0,0,0,0,0,0,0,0,0,0,0,0
-930,0,0,0,0,0,0,0,0,0,0,0,0,0
-931,0,0,0,0,0,0,0,0,0,0,0,0,0
-932,0,0,0,0,0,0,0,0,0,0.018022081,0,0,0
-933,0,0,0,0,0,0,0,0,0,0.065697659,0,0,0
-934,0,0,0,0,0,0,0,0,0,0.184736705,0,0,0
-935,0,0,0,0,0,0,0,0,0,0.40810832,0,0,0
-936,0,0,0,0,0,0,0,0,0,0.679541184,0,0,0
-937,0,0,0,0,0,0,0,0,0,0.873658311,0,0,0
-938,0,0,0,0,0,0,0,0,0,0.92993853,0,0,0
-939,0,0,0,0,0,0,0,0,0,0.963266163,0,0,0
-940,0,0,0,0,0,0,0,0,0,0.983565755,0,0,0
-941,0,0,0,0,0,0,0,0,0,0.99068994,0,0,0
-942,0,0,0,0,0,0,0,0,0,0.996767012,0,0,0
-943,0,0,0,0,0,0,0,0,0,0.97723688,0,0,0
-944,0,0,0,0,0,0,0,0,0,0.979056662,0,0,0
-945,0,0,0,0,0,0,0,0,0,0.998123124,0,0,0
-946,0,0,0,0,0,0,0,0,0,0.989646376,0,0,0
-947,0,0,0,0,0,0,0,0,0,1,0,0,0
-948,0,0,0,0,0,0,0,0,0,0.987515816,0,0,0
-949,0,0,0,0,0,0,0,0,0,0.985535072,0,0,0
-950,0,0,0,0,0,0,0,0,0,0.956407998,0,0,0
-951,0,0,0,0,0,0,0,0,0,0.965774628,0,0,0
-952,0,0,0,0,0,0,0,0,0,0.931093947,0,0,0
-953,0,0,0,0,0,0,0,0,0,0.863762098,0,0,0
-954,0,0,0,0,0,0,0,0,0,0.704632989,0,0,0
-955,0,0,0,0,0,0,0,0,0,0.450443414,0,0,0
-956,0,0,0,0,0,0,0,0,0,0.201668037,0,0,0
-957,0,0,0,0,0,0,0,0,0,0.059806765,0,0,0
-958,0,0,0,0,0,0,0,0,0,0.013927678,0,0,0
-959,0,0,0,0,0,0,0,0,0,0,0,0,0
-960,0,0,0,0,0,0,0,0,0,0,0,0,0
-961,0,0,0,0,0,0,0,0,0,0,0,0,0
-962,0,0,0,0,0,0,0,0,0,0,0,0,0
-963,0,0,0,0,0,0,0,0,0,0,0,0,0
-964,0,0,0,0,0,0,0,0,0,0,0,0,0
-965,0,0,0,0,0,0,0,0,0,0,0,0,0
-966,0,0,0,0,0,0,0,0,0,0,0,0,0
-967,0,0,0,0,0,0,0,0,0,0,0,0,0
-968,0,0,0,0,0,0,0,0,0,0,0,0,0
-969,0,0,0,0,0,0,0,0,0,0,0,0,0
-970,0,0,0,0,0,0,0,0,0,0,0,0,0
-971,0,0,0,0,0,0,0,0,0,0,0,0,0
-972,0,0,0,0,0,0,0,0,0,0,0,0,0
-973,0,0,0,0,0,0,0,0,0,0,0,0,0
-974,0,0,0,0,0,0,0,0,0,0,0,0,0
-975,0,0,0,0,0,0,0,0,0,0,0,0,0
-976,0,0,0,0,0,0,0,0,0,0,0,0,0
-977,0,0,0,0,0,0,0,0,0,0,0,0,0
-978,0,0,0,0,0,0,0,0,0,0,0,0,0
-979,0,0,0,0,0,0,0,0,0,0,0,0,0
-980,0,0,0,0,0,0,0,0,0,0,0,0,0
-981,0,0,0,0,0,0,0,0,0,0,0,0,0
-982,0,0,0,0,0,0,0,0,0,0,0,0,0
-983,0,0,0,0,0,0,0,0,0,0,0,0,0
-984,0,0,0,0,0,0,0,0,0,0,0,0,0
-985,0,0,0,0,0,0,0,0,0,0,0,0,0
-986,0,0,0,0,0,0,0,0,0,0,0,0,0
-987,0,0,0,0,0,0,0,0,0,0,0,0,0
-988,0,0,0,0,0,0,0,0,0,0,0,0,0
-989,0,0,0,0,0,0,0,0,0,0,0,0,0
-990,0,0,0,0,0,0,0,0,0,0,0,0,0
-991,0,0,0,0,0,0,0,0,0,0,0,0,0
-992,0,0,0,0,0,0,0,0,0,0,0,0,0
-993,0,0,0,0,0,0,0,0,0,0,0,0,0
-994,0,0,0,0,0,0,0,0,0,0,0,0,0
-995,0,0,0,0,0,0,0,0,0,0,0,0,0
-996,0,0,0,0,0,0,0,0,0,0,0,0,0
-997,0,0,0,0,0,0,0,0,0,0,0,0,0
-998,0,0,0,0,0,0,0,0,0,0,0,0,0
-999,0,0,0,0,0,0,0,0,0,0,0,0,0
-1000,0,0,0,0,0,0,0,0,0,0,0,0,0
-1001,0,0,0,0,0,0,0,0,0,0,0,0,0
-1002,0,0,0,0,0,0,0,0,0,0,0,0,0
-1003,0,0,0,0,0,0,0,0,0,0,0,0,0
-1004,0,0,0,0,0,0,0,0,0,0,0,0,0
-1005,0,0,0,0,0,0,0,0,0,0,0,0,0
-1006,0,0,0,0,0,0,0,0,0,0,0,0,0
-1007,0,0,0,0,0,0,0,0,0,0,0,0,0
-1008,0,0,0,0,0,0,0,0,0,0,0,0,0
-1009,0,0,0,0,0,0,0,0,0,0,0,0,0
-1010,0,0,0,0,0,0,0,0,0,0,0,0,0
-1011,0,0,0,0,0,0,0,0,0,0,0,0,0
-1012,0,0,0,0,0,0,0,0,0,0,0,0,0
-1013,0,0,0,0,0,0,0,0,0,0,0,0,0
-1014,0,0,0,0,0,0,0,0,0,0,0,0,0
-1015,0,0,0,0,0,0,0,0,0,0,0,0,0
-1016,0,0,0,0,0,0,0,0,0,0,0,0,0
-1017,0,0,0,0,0,0,0,0,0,0,0,0,0
-1018,0,0,0,0,0,0,0,0,0,0,0,0,0
-1019,0,0,0,0,0,0,0,0,0,0,0,0,0
-1020,0,0,0,0,0,0,0,0,0,0,0,0,0
-1021,0,0,0,0,0,0,0,0,0,0,0,0,0
-1022,0,0,0,0,0,0,0,0,0,0,0,0,0
-1023,0,0,0,0,0,0,0,0,0,0,0,0,0
-1024,0,0,0,0,0,0,0,0,0,0,0,0,0
-1025,0,0,0,0,0,0,0,0,0,0,0,0,0
-1026,0,0,0,0,0,0,0,0,0,0,0,0,0
-1027,0,0,0,0,0,0,0,0,0,0,0,0,0
-1028,0,0,0,0,0,0,0,0,0,0,0,0,0
-1029,0,0,0,0,0,0,0,0,0,0,0,0,0
-1030,0,0,0,0,0,0,0,0,0,0,0,0,0
-1031,0,0,0,0,0,0,0,0,0,0,0,0,0
-1032,0,0,0,0,0,0,0,0,0,0,0,0,0
-1033,0,0,0,0,0,0,0,0,0,0,0,0,0
-1034,0,0,0,0,0,0,0,0,0,0,0,0,0
-1035,0,0,0,0,0,0,0,0,0,0,0,0,0
-1036,0,0,0,0,0,0,0,0,0,0,0,0,0
-1037,0,0,0,0,0,0,0,0,0,0,0,0,0
-1038,0,0,0,0,0,0,0,0,0,0,0,0,0
-1039,0,0,0,0,0,0,0,0,0,0,0,0,0
-1040,0,0,0,0,0,0,0,0,0,0,0,0,0
-1041,0,0,0,0,0,0,0,0,0,0,0,0,0
-1042,0,0,0,0,0,0,0,0,0,0,0,0,0
-1043,0,0,0,0,0,0,0,0,0,0,0,0,0
-1044,0,0,0,0,0,0,0,0,0,0,0,0,0
-1045,0,0,0,0,0,0,0,0,0,0,0,0,0
-1046,0,0,0,0,0,0,0,0,0,0,0,0,0
-1047,0,0,0,0,0,0,0,0,0,0,0,0,0
-1048,0,0,0,0,0,0,0,0,0,0,0,0,0
-1049,0,0,0,0,0,0,0,0,0,0,0,0,0
-1050,0,0,0,0,0,0,0,0,0,0,0,0,0
-1051,0,0,0,0,0,0,0,0,0,0,0,0,0
-1052,0,0,0,0,0,0,0,0,0,0,0,0,0
-1053,0,0,0,0,0,0,0,0,0,0,0,0,0
-1054,0,0,0,0,0,0,0,0,0,0,0,0,0
-1055,0,0,0,0,0,0,0,0,0,0,0,0,0
-1056,0,0,0,0,0,0,0,0,0,0,0,0,0
-1057,0,0,0,0,0,0,0,0,0,0,0,0,0
-1058,0,0,0,0,0,0,0,0,0,0,0,0,0
-1059,0,0,0,0,0,0,0,0,0,0,0,0,0
-1060,0,0,0,0,0,0,0,0,0,0,0,0,0
-1061,0,0,0,0,0,0,0,0,0,0,0,0,0
-1062,0,0,0,0,0,0,0,0,0,0,0,0,0
-1063,0,0,0,0,0,0,0,0,0,0,0,0,0
-1064,0,0,0,0,0,0,0,0,0,0,0,0,0
-1065,0,0,0,0,0,0,0,0,0,0,0,0,0
-1066,0,0,0,0,0,0,0,0,0,0,0,0,0
-1067,0,0,0,0,0,0,0,0,0,0,0,0,0
-1068,0,0,0,0,0,0,0,0,0,0,0,0,0
-1069,0,0,0,0,0,0,0,0,0,0,0,0,0
-1070,0,0,0,0,0,0,0,0,0,0,0,0,0
-1071,0,0,0,0,0,0,0,0,0,0,0,0,0
-1072,0,0,0,0,0,0,0,0,0,0,0,0,0
-1073,0,0,0,0,0,0,0,0,0,0,0,0,0
-1074,0,0,0,0,0,0,0,0,0,0,0,0,0
-1075,0,0,0,0,0,0,0,0,0,0,0,0,0
-1076,0,0,0,0,0,0,0,0,0,0,0,0,0
-1077,0,0,0,0,0,0,0,0,0,0,0,0,0
-1078,0,0,0,0,0,0,0,0,0,0,0,0,0
-1079,0,0,0,0,0,0,0,0,0,0,0,0,0
-1080,0,0,0,0,0,0,0,0,0,0,0,0,0
-1081,0,0,0,0,0,0,0,0,0,0,0,0,0
-1082,0,0,0,0,0,0,0,0,0,0,0,0,0
-1083,0,0,0,0,0,0,0,0,0,0,0,0,0
-1084,0,0,0,0,0,0,0,0,0,0,0,0,0
-1085,0,0,0,0,0,0,0,0,0,0,0,0,0
-1086,0,0,0,0,0,0,0,0,0,0,0,0,0
-1087,0,0,0,0,0,0,0,0,0,0,0,0,0
-1088,0,0,0,0,0,0,0,0,0,0,0,0,0
-1089,0,0,0,0,0,0,0,0,0,0,0,0,0
-1090,0,0,0,0,0,0,0,0,0,0,0,0,0
-1091,0,0,0,0,0,0,0,0,0,0,0,0,0
-1092,0,0,0,0,0,0,0,0,0,0,0,0,0
-1093,0,0,0,0,0,0,0,0,0,0,0,0,0
-1094,0,0,0,0,0,0,0,0,0,0,0,0,0
-1095,0,0,0,0,0,0,0,0,0,0,0,0,0
-1096,0,0,0,0,0,0,0,0,0,0,0,0,0
-1097,0,0,0,0,0,0,0,0,0,0,0,0,0
-1098,0,0,0,0,0,0,0,0,0,0,0,0,0
-1099,0,0,0,0,0,0,0,0,0,0,0,0,0
-1100,0,0,0,0,0,0,0,0,0,0,0,0,0
-1101,0,0,0,0,0,0,0,0,0,0,0,0,0
-1102,0,0,0,0,0,0,0,0,0,0,0,0,0
-1103,0,0,0,0,0,0,0,0,0,0,0,0,0
-1104,0,0,0,0,0,0,0,0,0,0,0,0,0
-1105,0,0,0,0,0,0,0,0,0,0,0,0,0
-1106,0,0,0,0,0,0,0,0,0,0,0,0,0
-1107,0,0,0,0,0,0,0,0,0,0,0,0,0
-1108,0,0,0,0,0,0,0,0,0,0,0,0,0
-1109,0,0,0,0,0,0,0,0,0,0,0,0,0
-1110,0,0,0,0,0,0,0,0,0,0,0,0,0
-1111,0,0,0,0,0,0,0,0,0,0,0,0,0
-1112,0,0,0,0,0,0,0,0,0,0,0,0,0
-1113,0,0,0,0,0,0,0,0,0,0,0,0,0
-1114,0,0,0,0,0,0,0,0,0,0,0,0,0
-1115,0,0,0,0,0,0,0,0,0,0,0,0,0
-1116,0,0,0,0,0,0,0,0,0,0,0,0,0
-1117,0,0,0,0,0,0,0,0,0,0,0,0,0
-1118,0,0,0,0,0,0,0,0,0,0,0,0,0
-1119,0,0,0,0,0,0,0,0,0,0,0,0,0
-1120,0,0,0,0,0,0,0,0,0,0,0,0,0
-1121,0,0,0,0,0,0,0,0,0,0,0,0,0
-1122,0,0,0,0,0,0,0,0,0,0,0,0,0
-1123,0,0,0,0,0,0,0,0,0,0,0,0,0
-1124,0,0,0,0,0,0,0,0,0,0,0,0,0
-1125,0,0,0,0,0,0,0,0,0,0,0,0,0
-1126,0,0,0,0,0,0,0,0,0,0,0,0,0
-1127,0,0,0,0,0,0,0,0,0,0,0,0,0
-1128,0,0,0,0,0,0,0,0,0,0,0,0,0
-1129,0,0,0,0,0,0,0,0,0,0,0,0,0
-1130,0,0,0,0,0,0,0,0,0,0,0,0,0
-1131,0,0,0,0,0,0,0,0,0,0,0,0,0
-1132,0,0,0,0,0,0,0,0,0,0,0,0,0
-1133,0,0,0,0,0,0,0,0,0,0,0,0,0
-1134,0,0,0,0,0,0,0,0,0,0,0,0,0
-1135,0,0,0,0,0,0,0,0,0,0,0,0,0
-1136,0,0,0,0,0,0,0,0,0,0,0,0,0
-1137,0,0,0,0,0,0,0,0,0,0,0,0,0
-1138,0,0,0,0,0,0,0,0,0,0,0,0,0
-1139,0,0,0,0,0,0,0,0,0,0,0,0,0
-1140,0,0,0,0,0,0,0,0,0,0,0,0,0
-1141,0,0,0,0,0,0,0,0,0,0,0,0,0
-1142,0,0,0,0,0,0,0,0,0,0,0,0,0
-1143,0,0,0,0,0,0,0,0,0,0,0,0,0
-1144,0,0,0,0,0,0,0,0,0,0,0,0,0
-1145,0,0,0,0,0,0,0,0,0,0,0,0,0
-1146,0,0,0,0,0,0,0,0,0,0,0,0,0
-1147,0,0,0,0,0,0,0,0,0,0,0,0,0
-1148,0,0,0,0,0,0,0,0,0,0,0,0,0
-1149,0,0,0,0,0,0,0,0,0,0,0,0,0
-1150,0,0,0,0,0,0,0,0,0,0,0,0,0
-1151,0,0,0,0,0,0,0,0,0,0,0,0,0
-1152,0,0,0,0,0,0,0,0,0,0,0,0,0
-1153,0,0,0,0,0,0,0,0,0,0,0,0,0
-1154,0,0,0,0,0,0,0,0,0,0,0,0,0
-1155,0,0,0,0,0,0,0,0,0,0,0,0,0
-1156,0,0,0,0,0,0,0,0,0,0,0,0,0
-1157,0,0,0,0,0,0,0,0,0,0,0,0,0
-1158,0,0,0,0,0,0,0,0,0,0,0,0,0
-1159,0,0,0,0,0,0,0,0,0,0,0,0,0
-1160,0,0,0,0,0,0,0,0,0,0,0,0,0
-1161,0,0,0,0,0,0,0,0,0,0,0,0,0
-1162,0,0,0,0,0,0,0,0,0,0,0,0,0
-1163,0,0,0,0,0,0,0,0,0,0,0,0,0
-1164,0,0,0,0,0,0,0,0,0,0,0,0,0
-1165,0,0,0,0,0,0,0,0,0,0,0,0,0
-1166,0,0,0,0,0,0,0,0,0,0,0,0,0
-1167,0,0,0,0,0,0,0,0,0,0,0,0,0
-1168,0,0,0,0,0,0,0,0,0,0,0,0,0
-1169,0,0,0,0,0,0,0,0,0,0,0,0,0
-1170,0,0,0,0,0,0,0,0,0,0,0,0,0
-1171,0,0,0,0,0,0,0,0,0,0,0,0,0
-1172,0,0,0,0,0,0,0,0,0,0,0,0,0
-1173,0,0,0,0,0,0,0,0,0,0,0,0,0
-1174,0,0,0,0,0,0,0,0,0,0,0,0,0
-1175,0,0,0,0,0,0,0,0,0,0,0,0,0
-1176,0,0,0,0,0,0,0,0,0,0,0,0,0
-1177,0,0,0,0,0,0,0,0,0,0,0,0,0
-1178,0,0,0,0,0,0,0,0,0,0,0,0,0
-1179,0,0,0,0,0,0,0,0,0,0,0,0,0
-1180,0,0,0,0,0,0,0,0,0,0,0,0,0
-1181,0,0,0,0,0,0,0,0,0,0,0,0,0
-1182,0,0,0,0,0,0,0,0,0,0,0,0,0
-1183,0,0,0,0,0,0,0,0,0,0,0,0,0
-1184,0,0,0,0,0,0,0,0,0,0,0,0,0
-1185,0,0,0,0,0,0,0,0,0,0,0,0,0
-1186,0,0,0,0,0,0,0,0,0,0,0,0,0
-1187,0,0,0,0,0,0,0,0,0,0,0,0,0
-1188,0,0,0,0,0,0,0,0,0,0,0,0,0
-1189,0,0,0,0,0,0,0,0,0,0,0,0,0
-1190,0,0,0,0,0,0,0,0,0,0,0,0,0
-1191,0,0,0,0,0,0,0,0,0,0,0,0,0
-1192,0,0,0,0,0,0,0,0,0,0,0,0,0
-1193,0,0,0,0,0,0,0,0,0,0,0,0,0
-1194,0,0,0,0,0,0,0,0,0,0,0,0,0
-1195,0,0,0,0,0,0,0,0,0,0,0,0,0
-1196,0,0,0,0,0,0,0,0,0,0,0,0,0
-1197,0,0,0,0,0,0,0,0,0,0,0,0,0
-1198,0,0,0,0,0,0,0,0,0,0,0,0,0
-1199,0,0,0,0,0,0,0,0,0,0,0,0,0
-1200,0,0,0,0,0,0,0,0,0,0,0,0,0
-1201,0,0,0,0,0,0,0,0,0,0,0,0,0
-1202,0,0,0,0,0,0,0,0,0,0,0,0,0
-1203,0,0,0,0,0,0,0,0,0,0,0,0,0
-1204,0,0,0,0,0,0,0,0,0,0,0,0,0
-1205,0,0,0,0,0,0,0,0,0,0,0,0,0
-1206,0,0,0,0,0,0,0,0,0,0,0,0,0
-1207,0,0,0,0,0,0,0,0,0,0,0,0,0
-1208,0,0,0,0,0,0,0,0,0,0,0,0,0
-1209,0,0,0,0,0,0,0,0,0,0,0,0,0
-1210,0,0,0,0,0,0,0,0,0,0,0,0,0
-1211,0,0,0,0,0,0,0,0,0,0,0,0,0
-1212,0,0,0,0,0,0,0,0,0,0,0,0,0
-1213,0,0,0,0,0,0,0,0,0,0,0,0,0
-1214,0,0,0,0,0,0,0,0,0,0,0,0,0
-1215,0,0,0,0,0,0,0,0,0,0,0,0,0
-1216,0,0,0,0,0,0,0,0,0,0,0,0,0
-1217,0,0,0,0,0,0,0,0,0,0,0,0,0
-1218,0,0,0,0,0,0,0,0,0,0,0,0,0
-1219,0,0,0,0,0,0,0,0,0,0,0,0,0
-1220,0,0,0,0,0,0,0,0,0,0,0,0,0
-1221,0,0,0,0,0,0,0,0,0,0,0,0,0
-1222,0,0,0,0,0,0,0,0,0,0,0,0,0
-1223,0,0,0,0,0,0,0,0,0,0,0,0,0
-1224,0,0,0,0,0,0,0,0,0,0,0,0,0
-1225,0,0,0,0,0,0,0,0,0,0,0,0,0
-1226,0,0,0,0,0,0,0,0,0,0,0,0,0
-1227,0,0,0,0,0,0,0,0,0,0,0,0,0
-1228,0,0,0,0,0,0,0,0,0,0,0,0,0
-1229,0,0,0,0,0,0,0,0,0,0,0,0,0
-1230,0,0,0,0,0,0,0,0,0,0,0,0,0
-1231,0,0,0,0,0,0,0,0,0,0,0,0,0
-1232,0,0,0,0,0,0,0,0,0,0,0,0,0
-1233,0,0,0,0,0,0,0,0,0,0,0,0,0
-1234,0,0,0,0,0,0,0,0,0,0,0,0,0
-1235,0,0,0,0,0,0,0,0,0,0,0,0,0
-1236,0,0,0,0,0,0,0,0,0,0,0,0,0
-1237,0,0,0,0,0,0,0,0,0,0,0,0,0
-1238,0,0,0,0,0,0,0,0,0,0,0,0,0
-1239,0,0,0,0,0,0,0,0,0,0,0,0,0
-1240,0,0,0,0,0,0,0,0,0,0,0,0,0
-1241,0,0,0,0,0,0,0,0,0,0,0,0,0
-1242,0,0,0,0,0,0,0,0,0,0,0,0,0
-1243,0,0,0,0,0,0,0,0,0,0,0,0,0
-1244,0,0,0,0,0,0,0,0,0,0,0,0,0
-1245,0,0,0,0,0,0,0,0,0,0,0,0,0
-1246,0,0,0,0,0,0,0,0,0,0,0,0,0
-1247,0,0,0,0,0,0,0,0,0,0,0,0,0
-1248,0,0,0,0,0,0,0,0,0,0,0,0,0
-1249,0,0,0,0,0,0,0,0,0,0,0,0,0
-1250,0,0,0,0,0,0,0,0,0,0,0,0,0
-1251,0,0,0,0,0,0,0,0,0,0,0,0,0
-1252,0,0,0,0,0,0,0,0,0,0,0,0,0
-1253,0,0,0,0,0,0,0,0,0,0,0,0,0
-1254,0,0,0,0,0,0,0,0,0,0,0,0,0
-1255,0,0,0,0,0,0,0,0,0,0,0,0,0
-1256,0,0,0,0,0,0,0,0,0,0,0,0,0
-1257,0,0,0,0,0,0,0,0,0,0,0,0,0
-1258,0,0,0,0,0,0,0,0,0,0,0,0,0
-1259,0,0,0,0,0,0,0,0,0,0,0,0,0
-1260,0,0,0,0,0,0,0,0,0,0,0,0,0
-1261,0,0,0,0,0,0,0,0,0,0,0,0,0
-1262,0,0,0,0,0,0,0,0,0,0,0,0,0
-1263,0,0,0,0,0,0,0,0,0,0,0,0,0
-1264,0,0,0,0,0,0,0,0,0,0,0,0,0
-1265,0,0,0,0,0,0,0,0,0,0,0,0,0
-1266,0,0,0,0,0,0,0,0,0,0,0,0,0
-1267,0,0,0,0,0,0,0,0,0,0,0,0,0
-1268,0,0,0,0,0,0,0,0,0,0,0,0,0
-1269,0,0,0,0,0,0,0,0,0,0,0,0,0
-1270,0,0,0,0,0,0,0,0,0,0,0,0,0
-1271,0,0,0,0,0,0,0,0,0,0,0,0,0
-1272,0,0,0,0,0,0,0,0,0,0,0,0,0
-1273,0,0,0,0,0,0,0,0,0,0,0,0,0
-1274,0,0,0,0,0,0,0,0,0,0,0,0,0
-1275,0,0,0,0,0,0,0,0,0,0,0,0,0
-1276,0,0,0,0,0,0,0,0,0,0,0,0,0
-1277,0,0,0,0,0,0,0,0,0,0,0,0,0
-1278,0,0,0,0,0,0,0,0,0,0,0,0,0
-1279,0,0,0,0,0,0,0,0,0,0,0,0,0
-1280,0,0,0,0,0,0,0,0,0,0,0,0,0
-1281,0,0,0,0,0,0,0,0,0,0,0,0,0
-1282,0,0,0,0,0,0,0,0,0,0,0,0,0
-1283,0,0,0,0,0,0,0,0,0,0,0,0,0
-1284,0,0,0,0,0,0,0,0,0,0,0,0,0
-1285,0,0,0,0,0,0,0,0,0,0,0,0,0
-1286,0,0,0,0,0,0,0,0,0,0,0,0,0
-1287,0,0,0,0,0,0,0,0,0,0,0,0,0
-1288,0,0,0,0,0,0,0,0,0,0,0,0,0
-1289,0,0,0,0,0,0,0,0,0,0,0,0,0
-1290,0,0,0,0,0,0,0,0,0,0,0,0,0
-1291,0,0,0,0,0,0,0,0,0,0,0,0,0
-1292,0,0,0,0,0,0,0,0,0,0,0,0,0
-1293,0,0,0,0,0,0,0,0,0,0,0,0,0
-1294,0,0,0,0,0,0,0,0,0,0,0,0,0
-1295,0,0,0,0,0,0,0,0,0,0,0,0,0
-1296,0,0,0,0,0,0,0,0,0,0,0,0,0
-1297,0,0,0,0,0,0,0,0,0,0,0,0,0
-1298,0,0,0,0,0,0,0,0,0,0,0,0,0
-1299,0,0,0,0,0,0,0,0,0,0,0,0,0
-1300,0,0,0,0,0,0,0,0,0,0,0,0,0
-1301,0,0,0,0,0,0,0,0,0,0,0,0,0
-1302,0,0,0,0,0,0,0,0,0,0,0,0,0
-1303,0,0,0,0,0,0,0,0,0,0,0,0,0
-1304,0,0,0,0,0,0,0,0,0,0,0,0,0
-1305,0,0,0,0,0,0,0,0,0,0,0,0,0
-1306,0,0,0,0,0,0,0,0,0,0,0,0,0
-1307,0,0,0,0,0,0,0,0,0,0,0,0,0
-1308,0,0,0,0,0,0,0,0,0,0,0,0,0
-1309,0,0,0,0,0,0,0,0,0,0,0,0,0
-1310,0,0,0,0,0,0,0,0,0,0,0,0,0
-1311,0,0,0,0,0,0,0,0,0,0,0,0,0
-1312,0,0,0,0,0,0,0,0,0,0,0,0,0
-1313,0,0,0,0,0,0,0,0,0,0,0,0,0
-1314,0,0,0,0,0,0,0,0,0,0,0,0,0
-1315,0,0,0,0,0,0,0,0,0,0,0,0,0
-1316,0,0,0,0,0,0,0,0,0,0,0,0,0
-1317,0,0,0,0,0,0,0,0,0,0,0,0,0
-1318,0,0,0,0,0,0,0,0,0,0,0,0,0
-1319,0,0,0,0,0,0,0,0,0,0,0,0,0
-1320,0,0,0,0,0,0,0,0,0,0,0,0,0
-1321,0,0,0,0,0,0,0,0,0,0,0,0,0
-1322,0,0,0,0,0,0,0,0,0,0,0,0,0
-1323,0,0,0,0,0,0,0,0,0,0,0,0,0
-1324,0,0,0,0,0,0,0,0,0,0,0,0,0
-1325,0,0,0,0,0,0,0,0,0,0,0,0,0
-1326,0,0,0,0,0,0,0,0,0,0,0,0,0
-1327,0,0,0,0,0,0,0,0,0,0,0,0,0
-1328,0,0,0,0,0,0,0,0,0,0,0,0,0
-1329,0,0,0,0,0,0,0,0,0,0,0,0,0
-1330,0,0,0,0,0,0,0,0,0,0,0,0,0
-1331,0,0,0,0,0,0,0,0,0,0,0,0,0
-1332,0,0,0,0,0,0,0,0,0,0,0,0,0
-1333,0,0,0,0,0,0,0,0,0,0,0,0,0
-1334,0,0,0,0,0,0,0,0,0,0,0,0,0
-1335,0,0,0,0,0,0,0,0,0,0,0,0,0
-1336,0,0,0,0,0,0,0,0,0,0,0,0,0
-1337,0,0,0,0,0,0,0,0,0,0,0.000238032,0,0
-1338,0,0,0,0,0,0,0,0,0,0,0.000054011,0,0
-1339,0,0,0,0,0,0,0,0,0,0,0.000030555,0,0
-1340,0,0,0,0,0,0,0,0,0,0,0.000028606,0,0
-1341,0,0,0,0,0,0,0,0,0,0,0.000076414,0,0
-1342,0,0,0,0,0,0,0,0,0,0,0.000109542,0,0
-1343,0,0,0,0,0,0,0,0,0,0,0.000088112,0,0
-1344,0,0,0,0,0,0,0,0,0,0,0.000124276,0,0
-1345,0,0,0,0,0,0,0,0,0,0,0.000175866,0,0
-1346,0,0,0,0,0,0,0,0,0,0,0.000334017,0,0
-1347,0,0,0,0,0,0,0,0,0,0,0.000371868,0,0
-1348,0,0,0,0,0,0,0,0,0,0,0.000448739,0,0
-1349,0,0,0,0,0,0,0,0,0,0,0.000658249,0,0
-1350,0,0,0,0,0,0,0,0,0,0,0.001089206,0,0
-1351,0,0,0,0,0,0,0,0,0,0,0.00196845,0,0
-1352,0,0,0,0,0,0,0,0,0,0,0.003736281,0,0
-1353,0,0,0,0,0,0,0,0,0,0,0.008016927,0,0
-1354,0,0,0,0,0,0,0,0,0,0,0.018845345,0,0
-1355,0,0,0,0,0,0,0,0,0,0,0.044655923,0,0
-1356,0,0,0,0,0,0,0,0,0,0,0.101545368,0,0
-1357,0,0,0,0,0,0,0,0,0,0,0.200854803,0,0
-1358,0,0,0,0,0,0,0,0,0,0,0.342389339,0,0
-1359,0,0,0,0,0,0,0,0,0,0,0.506471542,0,0
-1360,0,0,0,0,0,0,0,0,0,0,0.662498209,0,0
-1361,0,0,0,0,0,0,0,0,0,0,0.783168494,0,0
-1362,0,0,0,0,0,0,0,0,0,0,0.861210463,0,0
-1363,0,0,0,0,0,0,0,0,0,0,0.910000298,0,0
-1364,0,0,0,0,0,0,0,0,0,0,0.942126255,0,0
-1365,0,0,0,0,0,0,0,0,0,0,0.962015449,0,0
-1366,0,0,0,0,0,0,0,0,0,0,0.973750495,0,0
-1367,0,0,0,0,0,0,0,0,0,0,0.981720971,0,0
-1368,0,0,0,0,0,0,0,0,0,0,0.987945142,0,0
-1369,0,0,0,0,0,0,0,0,0,0,0.992810636,0,0
-1370,0,0,0,0,0,0,0,0,0,0,0.996478958,0,0
-1371,0,0,0,0,0,0,0,0,0,0,0.99904946,0,0
-1372,0,0,0,0,0,0,0,0,0,0,1,0,0
-1373,0,0,0,0,0,0,0,0,0,0,0.999092287,0,0
-1374,0,0,0,0,0,0,0,0,0,0,0.996049616,0,0
-1375,0,0,0,0,0,0,0,0,0,0,0.990956135,0,0
-1376,0,0,0,0,0,0,0,0,0,0,0.984853732,0,0
-1377,0,0,0,0,0,0,0,0,0,0,0.978085355,0,0
-1378,0,0,0,0,0,0,0,0,0,0,0.970372704,0,0
-1379,0,0,0,0,0,0,0,0,0,0,0.960890124,0,0
-1380,0,0,0,0,0,0,0,0,0,0,0.948599028,0,0
-1381,0,0,0,0,0,0,0,0,0,0,0.933274986,0,0
-1382,0,0,0,0,0,0,0,0,0,0,0.915013686,0,0
-1383,0,0,0,0,0,0,0,0,0,0,0.894075033,0,0
-1384,0,0,0,0,0,0,0,0,0,0,0.868634853,0,0
-1385,0,0,0,0,0,0,0,0,0,0,0.830744554,0,0
-1386,0,0,0,0,0,0,0,0,0,0,0.76452492,0,0
-1387,0,0,0,0,0,0,0,0,0,0,0.65530055,0,0
-1388,0,0,0,0,0,0,0,0,0,0,0.507853983,0,0
-1389,0,0,0,0,0,0,0,0,0,0,0.35145525,0,0
-1390,0,0,0,0,0,0,0,0,0,0,0.219307816,0,0
-1391,0,0,0,0,0,0,0,0,0,0,0.1274815,0,0
-1392,0,0,0,0,0,0,0,0,0,0,0.068371642,0,0
-1393,0,0,0,0,0,0,0,0,0,0,0.032620423,0,0
-1394,0,0,0,0,0,0,0,0,0,0,0.013687992,0,0
-1395,0,0,0,0,0,0,0,0,0,0,0.005499615,0,0
-1396,0,0,0,0,0,0,0,0,0,0,0.002399545,0,0
-1397,0,0,0,0,0,0,0,0,0,0,0.001125292,0,0
-1398,0,0,0,0,0,0,0,0,0,0,0.000545136,0,0
-1399,0,0,0,0,0,0,0,0,0,0,0.000350108,0,0
-1400,0,0,0,0,0,0,0,0,0,0,0.000176863,0,0
-1401,0,0,0,0,0,0,0,0,0,0,0.000218748,0,0
-1402,0,0,0,0,0,0,0,0,0,0,0.000196998,0,0
-1403,0,0,0,0,0,0,0,0,0,0,0.0001058,0,0
-1404,0,0,0,0,0,0,0,0,0,0,0.000059528,0,0
-1405,0,0,0,0,0,0,0,0,0,0,0.000051435,0,0
-1406,0,0,0,0,0,0,0,0,0,0,0.000061894,0,0
-1407,0,0,0,0,0,0,0,0,0,0,0.000056196,0,0
-1408,0,0,0,0,0,0,0,0,0,0,0.000039155,0,0
-1409,0,0,0,0,0,0,0,0,0,0,0.00003185,0,0
-1410,0,0,0,0,0,0,0,0,0,0,0.000121264,0,0
-1411,0,0,0,0,0,0,0,0,0,0,0.000108791,0,0
-1412,0,0,0,0,0,0,0,0,0,0,0.000025451,0,0
-1413,0,0,0,0,0,0,0,0,0,0,0,0,0
-1414,0,0,0,0,0,0,0,0,0,0,0,0,0
-1415,0,0,0,0,0,0,0,0,0,0,0,0,0
-1416,0,0,0,0,0,0,0,0,0,0,0,0,0
-1417,0,0,0,0,0,0,0,0,0,0,0,0,0
-1418,0,0,0,0,0,0,0,0,0,0,0,0,0
-1419,0,0,0,0,0,0,0,0,0,0,0,0,0
-1420,0,0,0,0,0,0,0,0,0,0,0,0,0
-1421,0,0,0,0,0,0,0,0,0,0,0,0,0
-1422,0,0,0,0,0,0,0,0,0,0,0,0,0
-1423,0,0,0,0,0,0,0,0,0,0,0,0,0
-1424,0,0,0,0,0,0,0,0,0,0,0,0,0
-1425,0,0,0,0,0,0,0,0,0,0,0,0,0
-1426,0,0,0,0,0,0,0,0,0,0,0,0,0
-1427,0,0,0,0,0,0,0,0,0,0,0,0,0
-1428,0,0,0,0,0,0,0,0,0,0,0,0,0
-1429,0,0,0,0,0,0,0,0,0,0,0,0,0
-1430,0,0,0,0,0,0,0,0,0,0,0,0,0
-1431,0,0,0,0,0,0,0,0,0,0,0,0,0
-1432,0,0,0,0,0,0,0,0,0,0,0,0,0
-1433,0,0,0,0,0,0,0,0,0,0,0,0,0
-1434,0,0,0,0,0,0,0,0,0,0,0,0,0
-1435,0,0,0,0,0,0,0,0,0,0,0,0,0
-1436,0,0,0,0,0,0,0,0,0,0,0,0,0
-1437,0,0,0,0,0,0,0,0,0,0,0,0,0
-1438,0,0,0,0,0,0,0,0,0,0,0,0,0
-1439,0,0,0,0,0,0,0,0,0,0,0,0,0
-1440,0,0,0,0,0,0,0,0,0,0,0,0,0
-1441,0,0,0,0,0,0,0,0,0,0,0,0,0
-1442,0,0,0,0,0,0,0,0,0,0,0,0,0
-1443,0,0,0,0,0,0,0,0,0,0,0,0,0
-1444,0,0,0,0,0,0,0,0,0,0,0,0,0
-1445,0,0,0,0,0,0,0,0,0,0,0,0,0
-1446,0,0,0,0,0,0,0,0,0,0,0,0,0
-1447,0,0,0,0,0,0,0,0,0,0,0,0,0
-1448,0,0,0,0,0,0,0,0,0,0,0,0,0
-1449,0,0,0,0,0,0,0,0,0,0,0,0,0
-1450,0,0,0,0,0,0,0,0,0,0,0,0,0
-1451,0,0,0,0,0,0,0,0,0,0,0,0,0
-1452,0,0,0,0,0,0,0,0,0,0,0,0,0
-1453,0,0,0,0,0,0,0,0,0,0,0,0,0
-1454,0,0,0,0,0,0,0,0,0,0,0,0,0
-1455,0,0,0,0,0,0,0,0,0,0,0,0,0
-1456,0,0,0,0,0,0,0,0,0,0,0,0,0
-1457,0,0,0,0,0,0,0,0,0,0,0,0,0
-1458,0,0,0,0,0,0,0,0,0,0,0,0,0
-1459,0,0,0,0,0,0,0,0,0,0,0,0,0
-1460,0,0,0,0,0,0,0,0,0,0,0,0,0
-1461,0,0,0,0,0,0,0,0,0,0,0,0,0
-1462,0,0,0,0,0,0,0,0,0,0,0,0,0
-1463,0,0,0,0,0,0,0,0,0,0,0,0,0
-1464,0,0,0,0,0,0,0,0,0,0,0,0,0
-1465,0,0,0,0,0,0,0,0,0,0,0,0,0
-1466,0,0,0,0,0,0,0,0,0,0,0,0,0
-1467,0,0,0,0,0,0,0,0,0,0,0,0,0
-1468,0,0,0,0,0,0,0,0,0,0,0,0,0
-1469,0,0,0,0,0,0,0,0,0,0,0,0,0
-1470,0,0,0,0,0,0,0,0,0,0,0,0,0
-1471,0,0,0,0,0,0,0,0,0,0,0,0,0
-1472,0,0,0,0,0,0,0,0,0,0,0,0,0
-1473,0,0,0,0,0,0,0,0,0,0,0,0,0
-1474,0,0,0,0,0,0,0,0,0,0,0,0,0
-1475,0,0,0,0,0,0,0,0,0,0,0,0,0
-1476,0,0,0,0,0,0,0,0,0,0,0,0,0
-1477,0,0,0,0,0,0,0,0,0,0,0,0,0
-1478,0,0,0,0,0,0,0,0,0,0,0,0,0
-1479,0,0,0,0,0,0,0,0,0,0,0,0,0
-1480,0,0,0,0,0,0,0,0,0,0,0,0,0
-1481,0,0,0,0,0,0,0,0,0,0,0,0,0
-1482,0,0,0,0,0,0,0,0,0,0,0,0,0
-1483,0,0,0,0,0,0,0,0,0,0,0,0,0
-1484,0,0,0,0,0,0,0,0,0,0,0,0,0
-1485,0,0,0,0,0,0,0,0,0,0,0,0,0
-1486,0,0,0,0,0,0,0,0,0,0,0,0,0
-1487,0,0,0,0,0,0,0,0,0,0,0,0,0
-1488,0,0,0,0,0,0,0,0,0,0,0,0,0
-1489,0,0,0,0,0,0,0,0,0,0,0,0,0
-1490,0,0,0,0,0,0,0,0,0,0,0,0,0
-1491,0,0,0,0,0,0,0,0,0,0,0,0,0
-1492,0,0,0,0,0,0,0,0,0,0,0,0,0
-1493,0,0,0,0,0,0,0,0,0,0,0,0,0
-1494,0,0,0,0,0,0,0,0,0,0,0,0,0
-1495,0,0,0,0,0,0,0,0,0,0,0,0,0
-1496,0,0,0,0,0,0,0,0,0,0,0,0,0
-1497,0,0,0,0,0,0,0,0,0,0,0,0,0
-1498,0,0,0,0,0,0,0,0,0,0,0,0,0
-1499,0,0,0,0,0,0,0,0,0,0,0,0,0
-1500,0,0,0,0,0,0,0,0,0,0,0,0,0
-1501,0,0,0,0,0,0,0,0,0,0,0,0,0
-1502,0,0,0,0,0,0,0,0,0,0,0,0,0
-1503,0,0,0,0,0,0,0,0,0,0,0,0,0
-1504,0,0,0,0,0,0,0,0,0,0,0,0,0
-1505,0,0,0,0,0,0,0,0,0,0,0,0,0
-1506,0,0,0,0,0,0,0,0,0,0,0,0,0
-1507,0,0,0,0,0,0,0,0,0,0,0,0,0
-1508,0,0,0,0,0,0,0,0,0,0,0,0,0
-1509,0,0,0,0,0,0,0,0,0,0,0,0,0
-1510,0,0,0,0,0,0,0,0,0,0,0,0,0
-1511,0,0,0,0,0,0,0,0,0,0,0,0,0
-1512,0,0,0,0,0,0,0,0,0,0,0,0,0
-1513,0,0,0,0,0,0,0,0,0,0,0,0,0
-1514,0,0,0,0,0,0,0,0,0,0,0,0,0
-1515,0,0,0,0,0,0,0,0,0,0,0,0,0
-1516,0,0,0,0,0,0,0,0,0,0,0,0,0
-1517,0,0,0,0,0,0,0,0,0,0,0,0,0
-1518,0,0,0,0,0,0,0,0,0,0,0,0,0
-1519,0,0,0,0,0,0,0,0,0,0,0,0,0
-1520,0,0,0,0,0,0,0,0,0,0,0,0,0
-1521,0,0,0,0,0,0,0,0,0,0,0,0,0
-1522,0,0,0,0,0,0,0,0,0,0,0,0,0
-1523,0,0,0,0,0,0,0,0,0,0,0,0,0
-1524,0,0,0,0,0,0,0,0,0,0,0,0,0
-1525,0,0,0,0,0,0,0,0,0,0,0,0,0
-1526,0,0,0,0,0,0,0,0,0,0,0,0,0
-1527,0,0,0,0,0,0,0,0,0,0,0,0,0
-1528,0,0,0,0,0,0,0,0,0,0,0,0,0
-1529,0,0,0,0,0,0,0,0,0,0,0,0,0
-1530,0,0,0,0,0,0,0,0,0,0,0,0,0
-1531,0,0,0,0,0,0,0,0,0,0,0,0,0
-1532,0,0,0,0,0,0,0,0,0,0,0,0,0
-1533,0,0,0,0,0,0,0,0,0,0,0,0,0
-1534,0,0,0,0,0,0,0,0,0,0,0,0,0
-1535,0,0,0,0,0,0,0,0,0,0,0,0,0
-1536,0,0,0,0,0,0,0,0,0,0,0,0,0
-1537,0,0,0,0,0,0,0,0,0,0,0,0,0
-1538,0,0,0,0,0,0,0,0,0,0,0,0,0
-1539,0,0,0,0,0,0,0,0,0,0,0,0.000006934,0
-1540,0,0,0,0,0,0,0,0,0,0,0,0.000006804,0
-1541,0,0,0,0,0,0,0,0,0,0,0,0.000008224,0
-1542,0,0,0,0,0,0,0,0,0,0,0,0.000028105,0
-1543,0,0,0,0,0,0,0,0,0,0,0,0.00003784,0
-1544,0,0,0,0,0,0,0,0,0,0,0,0.000090746,0
-1545,0,0,0,0,0,0,0,0,0,0,0,0.000147452,0
-1546,0,0,0,0,0,0,0,0,0,0,0,0.000251399,0
-1547,0,0,0,0,0,0,0,0,0,0,0,0.000480203,0
-1548,0,0,0,0,0,0,0,0,0,0,0,0.000569537,0
-1549,0,0,0,0,0,0,0,0,0,0,0,0.000662261,0
-1550,0,0,0,0,0,0,0,0,0,0,0,0.000910566,0
-1551,0,0,0,0,0,0,0,0,0,0,0,0.001166089,0
-1552,0,0,0,0,0,0,0,0,0,0,0,0.001684036,0
-1553,0,0,0,0,0,0,0,0,0,0,0,0.00245816,0
-1554,0,0,0,0,0,0,0,0,0,0,0,0.00356747,0
-1555,0,0,0,0,0,0,0,0,0,0,0,0.005345161,0
-1556,0,0,0,0,0,0,0,0,0,0,0,0.008317784,0
-1557,0,0,0,0,0,0,0,0,0,0,0,0.012628433,0
-1558,0,0,0,0,0,0,0,0,0,0,0,0.018996334,0
-1559,0,0,0,0,0,0,0,0,0,0,0,0.027780618,0
-1560,0,0,0,0,0,0,0,0,0,0,0,0.03958367,0
-1561,0,0,0,0,0,0,0,0,0,0,0,0.054865088,0
-1562,0,0,0,0,0,0,0,0,0,0,0,0.074929768,0
-1563,0,0,0,0,0,0,0,0,0,0,0,0.101069914,0
-1564,0,0,0,0,0,0,0,0,0,0,0,0.135475748,0
-1565,0,0,0,0,0,0,0,0,0,0,0,0.182597282,0
-1566,0,0,0,0,0,0,0,0,0,0,0,0.247275543,0
-1567,0,0,0,0,0,0,0,0,0,0,0,0.330736144,0
-1568,0,0,0,0,0,0,0,0,0,0,0,0.429690906,0
-1569,0,0,0,0,0,0,0,0,0,0,0,0.537634456,0
-1570,0,0,0,0,0,0,0,0,0,0,0,0.647173334,0
-1571,0,0,0,0,0,0,0,0,0,0,0,0.743528409,0
-1572,0,0,0,0,0,0,0,0,0,0,0,0.815215305,0
-1573,0,0,0,0,0,0,0,0,0,0,0,0.859201504,0
-1574,0,0,0,0,0,0,0,0,0,0,0,0.879668577,0
-1575,0,0,0,0,0,0,0,0,0,0,0,0.887029952,0
-1576,0,0,0,0,0,0,0,0,0,0,0,0.889097838,0
-1577,0,0,0,0,0,0,0,0,0,0,0,0.891416958,0
-1578,0,0,0,0,0,0,0,0,0,0,0,0.897586018,0
-1579,0,0,0,0,0,0,0,0,0,0,0,0.90663052,0
-1580,0,0,0,0,0,0,0,0,0,0,0,0.916528056,0
-1581,0,0,0,0,0,0,0,0,0,0,0,0.92657894,0
-1582,0,0,0,0,0,0,0,0,0,0,0,0.935322165,0
-1583,0,0,0,0,0,0,0,0,0,0,0,0.942393561,0
-1584,0,0,0,0,0,0,0,0,0,0,0,0.947506732,0
-1585,0,0,0,0,0,0,0,0,0,0,0,0.951415577,0
-1586,0,0,0,0,0,0,0,0,0,0,0,0.954254286,0
-1587,0,0,0,0,0,0,0,0,0,0,0,0.956429305,0
-1588,0,0,0,0,0,0,0,0,0,0,0,0.958205215,0
-1589,0,0,0,0,0,0,0,0,0,0,0,0.960687866,0
-1590,0,0,0,0,0,0,0,0,0,0,0,0.963480014,0
-1591,0,0,0,0,0,0,0,0,0,0,0,0.965796837,0
-1592,0,0,0,0,0,0,0,0,0,0,0,0.968180454,0
-1593,0,0,0,0,0,0,0,0,0,0,0,0.97101157,0
-1594,0,0,0,0,0,0,0,0,0,0,0,0.973379886,0
-1595,0,0,0,0,0,0,0,0,0,0,0,0.97591493,0
-1596,0,0,0,0,0,0,0,0,0,0,0,0.978581496,0
-1597,0,0,0,0,0,0,0,0,0,0,0,0.979877753,0
-1598,0,0,0,0,0,0,0,0,0,0,0,0.98058868,0
-1599,0,0,0,0,0,0,0,0,0,0,0,0.980912334,0
-1600,0,0,0,0,0,0,0,0,0,0,0,0.981411503,0
-1601,0,0,0,0,0,0,0,0,0,0,0,0.981243863,0
-1602,0,0,0,0,0,0,0,0,0,0,0,0.980705072,0
-1603,0,0,0,0,0,0,0,0,0,0,0,0.980376964,0
-1604,0,0,0,0,0,0,0,0,0,0,0,0.981066319,0
-1605,0,0,0,0,0,0,0,0,0,0,0,0.982735565,0
-1606,0,0,0,0,0,0,0,0,0,0,0,0.985121995,0
-1607,0,0,0,0,0,0,0,0,0,0,0,0.987806954,0
-1608,0,0,0,0,0,0,0,0,0,0,0,0.990375969,0
-1609,0,0,0,0,0,0,0,0,0,0,0,0.992015684,0
-1610,0,0,0,0,0,0,0,0,0,0,0,0.993287985,0
-1611,0,0,0,0,0,0,0,0,0,0,0,0.992536418,0
-1612,0,0,0,0,0,0,0,0,0,0,0,0.990404949,0
-1613,0,0,0,0,0,0,0,0,0,0,0,0.987128016,0
-1614,0,0,0,0,0,0,0,0,0,0,0,0.983502057,0
-1615,0,0,0,0,0,0,0,0,0,0,0,0.980022548,0
-1616,0,0,0,0,0,0,0,0,0,0,0,0.976174463,0
-1617,0,0,0,0,0,0,0,0,0,0,0,0.972568388,0
-1618,0,0,0,0,0,0,0,0,0,0,0,0.969828489,0
-1619,0,0,0,0,0,0,0,0,0,0,0,0.967709002,0
-1620,0,0,0,0,0,0,0,0,0,0,0,0.966371474,0
-1621,0,0,0,0,0,0,0,0,0,0,0,0.965848924,0
-1622,0,0,0,0,0,0,0,0,0,0,0,0.966050474,0
-1623,0,0,0,0,0,0,0,0,0,0,0,0.967426617,0
-1624,0,0,0,0,0,0,0,0,0,0,0,0.969869577,0
-1625,0,0,0,0,0,0,0,0,0,0,0,0.973463419,0
-1626,0,0,0,0,0,0,0,0,0,0,0,0.97868284,0
-1627,0,0,0,0,0,0,0,0,0,0,0,0.983472137,0
-1628,0,0,0,0,0,0,0,0,0,0,0,0.987635453,0
-1629,0,0,0,0,0,0,0,0,0,0,0,0.991875079,0
-1630,0,0,0,0,0,0,0,0,0,0,0,0.995476405,0
-1631,0,0,0,0,0,0,0,0,0,0,0,0.997586172,0
-1632,0,0,0,0,0,0,0,0,0,0,0,0.998568438,0
-1633,0,0,0,0,0,0,0,0,0,0,0,0.999327749,0
-1634,0,0,0,0,0,0,0,0,0,0,0,0.999234469,0
-1635,0,0,0,0,0,0,0,0,0,0,0,0.998803511,0
-1636,0,0,0,0,0,0,0,0,0,0,0,0.999110558,0
-1637,0,0,0,0,0,0,0,0,0,0,0,0.999729529,0
-1638,0,0,0,0,0,0,0,0,0,0,0,0.999744808,0
-1639,0,0,0,0,0,0,0,0,0,0,0,1,0
-1640,0,0,0,0,0,0,0,0,0,0,0,0.999814319,0
-1641,0,0,0,0,0,0,0,0,0,0,0,0.996693294,0
-1642,0,0,0,0,0,0,0,0,0,0,0,0.991619643,0
-1643,0,0,0,0,0,0,0,0,0,0,0,0.985701748,0
-1644,0,0,0,0,0,0,0,0,0,0,0,0.978569228,0
-1645,0,0,0,0,0,0,0,0,0,0,0,0.969902949,0
-1646,0,0,0,0,0,0,0,0,0,0,0,0.960896391,0
-1647,0,0,0,0,0,0,0,0,0,0,0,0.953286699,0
-1648,0,0,0,0,0,0,0,0,0,0,0,0.946546283,0
-1649,0,0,0,0,0,0,0,0,0,0,0,0.941712152,0
-1650,0,0,0,0,0,0,0,0,0,0,0,0.938586421,0
-1651,0,0,0,0,0,0,0,0,0,0,0,0.935489328,0
-1652,0,0,0,0,0,0,0,0,0,0,0,0.928113913,0
-1653,0,0,0,0,0,0,0,0,0,0,0,0.912102443,0
-1654,0,0,0,0,0,0,0,0,0,0,0,0.88059783,0
-1655,0,0,0,0,0,0,0,0,0,0,0,0.824980062,0
-1656,0,0,0,0,0,0,0,0,0,0,0,0.743118017,0
-1657,0,0,0,0,0,0,0,0,0,0,0,0.64189077,0
-1658,0,0,0,0,0,0,0,0,0,0,0,0.534002282,0
-1659,0,0,0,0,0,0,0,0,0,0,0,0.426963072,0
-1660,0,0,0,0,0,0,0,0,0,0,0,0.323709698,0
-1661,0,0,0,0,0,0,0,0,0,0,0,0.234284076,0
-1662,0,0,0,0,0,0,0,0,0,0,0,0.163971597,0
-1663,0,0,0,0,0,0,0,0,0,0,0,0.110210711,0
-1664,0,0,0,0,0,0,0,0,0,0,0,0.072477896,0
-1665,0,0,0,0,0,0,0,0,0,0,0,0.04619413,0
-1666,0,0,0,0,0,0,0,0,0,0,0,0.029400532,0
-1667,0,0,0,0,0,0,0,0,0,0,0,0.019358665,0
-1668,0,0,0,0,0,0,0,0,0,0,0,0.013308246,0
-1669,0,0,0,0,0,0,0,0,0,0,0,0.009316851,0
-1670,0,0,0,0,0,0,0,0,0,0,0,0.006522833,0
-1671,0,0,0,0,0,0,0,0,0,0,0,0.004864189,0
-1672,0,0,0,0,0,0,0,0,0,0,0,0.003409053,0
-1673,0,0,0,0,0,0,0,0,0,0,0,0.002490561,0
-1674,0,0,0,0,0,0,0,0,0,0,0,0.001958315,0
-1675,0,0,0,0,0,0,0,0,0,0,0,0.001422504,0
-1676,0,0,0,0,0,0,0,0,0,0,0,0.001055276,0
-1677,0,0,0,0,0,0,0,0,0,0,0,0.000497731,0
-1678,0,0,0,0,0,0,0,0,0,0,0,0.000227763,0
-1679,0,0,0,0,0,0,0,0,0,0,0,0.00015918,0
-1680,0,0,0,0,0,0,0,0,0,0,0,0.000033942,0
-1681,0,0,0,0,0,0,0,0,0,0,0,0.000044875,0
-1682,0,0,0,0,0,0,0,0,0,0,0,0.000013044,0
-1683,0,0,0,0,0,0,0,0,0,0,0,0,0
-1684,0,0,0,0,0,0,0,0,0,0,0,0,0
-1685,0,0,0,0,0,0,0,0,0,0,0,0,0
-1686,0,0,0,0,0,0,0,0,0,0,0,0,0
-1687,0,0,0,0,0,0,0,0,0,0,0,0,0
-1688,0,0,0,0,0,0,0,0,0,0,0,0,0
-1689,0,0,0,0,0,0,0,0,0,0,0,0,0
-1690,0,0,0,0,0,0,0,0,0,0,0,0,0
-1691,0,0,0,0,0,0,0,0,0,0,0,0,0
-1692,0,0,0,0,0,0,0,0,0,0,0,0,0
-1693,0,0,0,0,0,0,0,0,0,0,0,0,0
-1694,0,0,0,0,0,0,0,0,0,0,0,0,0
-1695,0,0,0,0,0,0,0,0,0,0,0,0,0
-1696,0,0,0,0,0,0,0,0,0,0,0,0,0
-1697,0,0,0,0,0,0,0,0,0,0,0,0,0
-1698,0,0,0,0,0,0,0,0,0,0,0,0,0
-1699,0,0,0,0,0,0,0,0,0,0,0,0,0
-1700,0,0,0,0,0,0,0,0,0,0,0,0,0
-1701,0,0,0,0,0,0,0,0,0,0,0,0,0
-1702,0,0,0,0,0,0,0,0,0,0,0,0,0
-1703,0,0,0,0,0,0,0,0,0,0,0,0,0
-1704,0,0,0,0,0,0,0,0,0,0,0,0,0
-1705,0,0,0,0,0,0,0,0,0,0,0,0,0
-1706,0,0,0,0,0,0,0,0,0,0,0,0,0
-1707,0,0,0,0,0,0,0,0,0,0,0,0,0
-1708,0,0,0,0,0,0,0,0,0,0,0,0,0
-1709,0,0,0,0,0,0,0,0,0,0,0,0,0
-1710,0,0,0,0,0,0,0,0,0,0,0,0,0
-1711,0,0,0,0,0,0,0,0,0,0,0,0,0
-1712,0,0,0,0,0,0,0,0,0,0,0,0,0
-1713,0,0,0,0,0,0,0,0,0,0,0,0,0
-1714,0,0,0,0,0,0,0,0,0,0,0,0,0
-1715,0,0,0,0,0,0,0,0,0,0,0,0,0
-1716,0,0,0,0,0,0,0,0,0,0,0,0,0
-1717,0,0,0,0,0,0,0,0,0,0,0,0,0
-1718,0,0,0,0,0,0,0,0,0,0,0,0,0
-1719,0,0,0,0,0,0,0,0,0,0,0,0,0
-1720,0,0,0,0,0,0,0,0,0,0,0,0,0
-1721,0,0,0,0,0,0,0,0,0,0,0,0,0
-1722,0,0,0,0,0,0,0,0,0,0,0,0,0
-1723,0,0,0,0,0,0,0,0,0,0,0,0,0
-1724,0,0,0,0,0,0,0,0,0,0,0,0,0
-1725,0,0,0,0,0,0,0,0,0,0,0,0,0
-1726,0,0,0,0,0,0,0,0,0,0,0,0,0
-1727,0,0,0,0,0,0,0,0,0,0,0,0,0
-1728,0,0,0,0,0,0,0,0,0,0,0,0,0
-1729,0,0,0,0,0,0,0,0,0,0,0,0,0
-1730,0,0,0,0,0,0,0,0,0,0,0,0,0
-1731,0,0,0,0,0,0,0,0,0,0,0,0,0
-1732,0,0,0,0,0,0,0,0,0,0,0,0,0
-1733,0,0,0,0,0,0,0,0,0,0,0,0,0
-1734,0,0,0,0,0,0,0,0,0,0,0,0,0
-1735,0,0,0,0,0,0,0,0,0,0,0,0,0
-1736,0,0,0,0,0,0,0,0,0,0,0,0,0
-1737,0,0,0,0,0,0,0,0,0,0,0,0,0
-1738,0,0,0,0,0,0,0,0,0,0,0,0,0
-1739,0,0,0,0,0,0,0,0,0,0,0,0,0
-1740,0,0,0,0,0,0,0,0,0,0,0,0,0
-1741,0,0,0,0,0,0,0,0,0,0,0,0,0
-1742,0,0,0,0,0,0,0,0,0,0,0,0,0
-1743,0,0,0,0,0,0,0,0,0,0,0,0,0
-1744,0,0,0,0,0,0,0,0,0,0,0,0,0
-1745,0,0,0,0,0,0,0,0,0,0,0,0,0
-1746,0,0,0,0,0,0,0,0,0,0,0,0,0
-1747,0,0,0,0,0,0,0,0,0,0,0,0,0
-1748,0,0,0,0,0,0,0,0,0,0,0,0,0
-1749,0,0,0,0,0,0,0,0,0,0,0,0,0
-1750,0,0,0,0,0,0,0,0,0,0,0,0,0
-1751,0,0,0,0,0,0,0,0,0,0,0,0,0
-1752,0,0,0,0,0,0,0,0,0,0,0,0,0
-1753,0,0,0,0,0,0,0,0,0,0,0,0,0
-1754,0,0,0,0,0,0,0,0,0,0,0,0,0
-1755,0,0,0,0,0,0,0,0,0,0,0,0,0
-1756,0,0,0,0,0,0,0,0,0,0,0,0,0
-1757,0,0,0,0,0,0,0,0,0,0,0,0,0
-1758,0,0,0,0,0,0,0,0,0,0,0,0,0
-1759,0,0,0,0,0,0,0,0,0,0,0,0,0
-1760,0,0,0,0,0,0,0,0,0,0,0,0,0
-1761,0,0,0,0,0,0,0,0,0,0,0,0,0
-1762,0,0,0,0,0,0,0,0,0,0,0,0,0
-1763,0,0,0,0,0,0,0,0,0,0,0,0,0
-1764,0,0,0,0,0,0,0,0,0,0,0,0,0
-1765,0,0,0,0,0,0,0,0,0,0,0,0,0
-1766,0,0,0,0,0,0,0,0,0,0,0,0,0
-1767,0,0,0,0,0,0,0,0,0,0,0,0,0
-1768,0,0,0,0,0,0,0,0,0,0,0,0,0
-1769,0,0,0,0,0,0,0,0,0,0,0,0,0
-1770,0,0,0,0,0,0,0,0,0,0,0,0,0
-1771,0,0,0,0,0,0,0,0,0,0,0,0,0
-1772,0,0,0,0,0,0,0,0,0,0,0,0,0
-1773,0,0,0,0,0,0,0,0,0,0,0,0,0
-1774,0,0,0,0,0,0,0,0,0,0,0,0,0
-1775,0,0,0,0,0,0,0,0,0,0,0,0,0
-1776,0,0,0,0,0,0,0,0,0,0,0,0,0
-1777,0,0,0,0,0,0,0,0,0,0,0,0,0
-1778,0,0,0,0,0,0,0,0,0,0,0,0,0
-1779,0,0,0,0,0,0,0,0,0,0,0,0,0
-1780,0,0,0,0,0,0,0,0,0,0,0,0,0
-1781,0,0,0,0,0,0,0,0,0,0,0,0,0
-1782,0,0,0,0,0,0,0,0,0,0,0,0,0
-1783,0,0,0,0,0,0,0,0,0,0,0,0,0
-1784,0,0,0,0,0,0,0,0,0,0,0,0,0
-1785,0,0,0,0,0,0,0,0,0,0,0,0,0
-1786,0,0,0,0,0,0,0,0,0,0,0,0,0
-1787,0,0,0,0,0,0,0,0,0,0,0,0,0
-1788,0,0,0,0,0,0,0,0,0,0,0,0,0
-1789,0,0,0,0,0,0,0,0,0,0,0,0,0
-1790,0,0,0,0,0,0,0,0,0,0,0,0,0
-1791,0,0,0,0,0,0,0,0,0,0,0,0,0
-1792,0,0,0,0,0,0,0,0,0,0,0,0,0
-1793,0,0,0,0,0,0,0,0,0,0,0,0,0
-1794,0,0,0,0,0,0,0,0,0,0,0,0,0
-1795,0,0,0,0,0,0,0,0,0,0,0,0,0
-1796,0,0,0,0,0,0,0,0,0,0,0,0,0
-1797,0,0,0,0,0,0,0,0,0,0,0,0,0
-1798,0,0,0,0,0,0,0,0,0,0,0,0,0
-1799,0,0,0,0,0,0,0,0,0,0,0,0,0
-1800,0,0,0,0,0,0,0,0,0,0,0,0,0
-1801,0,0,0,0,0,0,0,0,0,0,0,0,0
-1802,0,0,0,0,0,0,0,0,0,0,0,0,0
-1803,0,0,0,0,0,0,0,0,0,0,0,0,0
-1804,0,0,0,0,0,0,0,0,0,0,0,0,0
-1805,0,0,0,0,0,0,0,0,0,0,0,0,0
-1806,0,0,0,0,0,0,0,0,0,0,0,0,0
-1807,0,0,0,0,0,0,0,0,0,0,0,0,0
-1808,0,0,0,0,0,0,0,0,0,0,0,0,0
-1809,0,0,0,0,0,0,0,0,0,0,0,0,0
-1810,0,0,0,0,0,0,0,0,0,0,0,0,0
-1811,0,0,0,0,0,0,0,0,0,0,0,0,0
-1812,0,0,0,0,0,0,0,0,0,0,0,0,0
-1813,0,0,0,0,0,0,0,0,0,0,0,0,0
-1814,0,0,0,0,0,0,0,0,0,0,0,0,0
-1815,0,0,0,0,0,0,0,0,0,0,0,0,0
-1816,0,0,0,0,0,0,0,0,0,0,0,0,0
-1817,0,0,0,0,0,0,0,0,0,0,0,0,0
-1818,0,0,0,0,0,0,0,0,0,0,0,0,0
-1819,0,0,0,0,0,0,0,0,0,0,0,0,0
-1820,0,0,0,0,0,0,0,0,0,0,0,0,0
-1821,0,0,0,0,0,0,0,0,0,0,0,0,0
-1822,0,0,0,0,0,0,0,0,0,0,0,0,0
-1823,0,0,0,0,0,0,0,0,0,0,0,0,0
-1824,0,0,0,0,0,0,0,0,0,0,0,0,0
-1825,0,0,0,0,0,0,0,0,0,0,0,0,0
-1826,0,0,0,0,0,0,0,0,0,0,0,0,0
-1827,0,0,0,0,0,0,0,0,0,0,0,0,0
-1828,0,0,0,0,0,0,0,0,0,0,0,0,0
-1829,0,0,0,0,0,0,0,0,0,0,0,0,0
-1830,0,0,0,0,0,0,0,0,0,0,0,0,0
-1831,0,0,0,0,0,0,0,0,0,0,0,0,0
-1832,0,0,0,0,0,0,0,0,0,0,0,0,0
-1833,0,0,0,0,0,0,0,0,0,0,0,0,0
-1834,0,0,0,0,0,0,0,0,0,0,0,0,0
-1835,0,0,0,0,0,0,0,0,0,0,0,0,0
-1836,0,0,0,0,0,0,0,0,0,0,0,0,0
-1837,0,0,0,0,0,0,0,0,0,0,0,0,0
-1838,0,0,0,0,0,0,0,0,0,0,0,0,0
-1839,0,0,0,0,0,0,0,0,0,0,0,0,0
-1840,0,0,0,0,0,0,0,0,0,0,0,0,0
-1841,0,0,0,0,0,0,0,0,0,0,0,0,0
-1842,0,0,0,0,0,0,0,0,0,0,0,0,0
-1843,0,0,0,0,0,0,0,0,0,0,0,0,0
-1844,0,0,0,0,0,0,0,0,0,0,0,0,0
-1845,0,0,0,0,0,0,0,0,0,0,0,0,0
-1846,0,0,0,0,0,0,0,0,0,0,0,0,0
-1847,0,0,0,0,0,0,0,0,0,0,0,0,0
-1848,0,0,0,0,0,0,0,0,0,0,0,0,0
-1849,0,0,0,0,0,0,0,0,0,0,0,0,0
-1850,0,0,0,0,0,0,0,0,0,0,0,0,0
-1851,0,0,0,0,0,0,0,0,0,0,0,0,0
-1852,0,0,0,0,0,0,0,0,0,0,0,0,0
-1853,0,0,0,0,0,0,0,0,0,0,0,0,0
-1854,0,0,0,0,0,0,0,0,0,0,0,0,0
-1855,0,0,0,0,0,0,0,0,0,0,0,0,0
-1856,0,0,0,0,0,0,0,0,0,0,0,0,0
-1857,0,0,0,0,0,0,0,0,0,0,0,0,0
-1858,0,0,0,0,0,0,0,0,0,0,0,0,0
-1859,0,0,0,0,0,0,0,0,0,0,0,0,0
-1860,0,0,0,0,0,0,0,0,0,0,0,0,0
-1861,0,0,0,0,0,0,0,0,0,0,0,0,0
-1862,0,0,0,0,0,0,0,0,0,0,0,0,0
-1863,0,0,0,0,0,0,0,0,0,0,0,0,0
-1864,0,0,0,0,0,0,0,0,0,0,0,0,0
-1865,0,0,0,0,0,0,0,0,0,0,0,0,0
-1866,0,0,0,0,0,0,0,0,0,0,0,0,0
-1867,0,0,0,0,0,0,0,0,0,0,0,0,0
-1868,0,0,0,0,0,0,0,0,0,0,0,0,0
-1869,0,0,0,0,0,0,0,0,0,0,0,0,0
-1870,0,0,0,0,0,0,0,0,0,0,0,0,0
-1871,0,0,0,0,0,0,0,0,0,0,0,0,0
-1872,0,0,0,0,0,0,0,0,0,0,0,0,0
-1873,0,0,0,0,0,0,0,0,0,0,0,0,0
-1874,0,0,0,0,0,0,0,0,0,0,0,0,0
-1875,0,0,0,0,0,0,0,0,0,0,0,0,0
-1876,0,0,0,0,0,0,0,0,0,0,0,0,0
-1877,0,0,0,0,0,0,0,0,0,0,0,0,0
-1878,0,0,0,0,0,0,0,0,0,0,0,0,0
-1879,0,0,0,0,0,0,0,0,0,0,0,0,0
-1880,0,0,0,0,0,0,0,0,0,0,0,0,0
-1881,0,0,0,0,0,0,0,0,0,0,0,0,0
-1882,0,0,0,0,0,0,0,0,0,0,0,0,0
-1883,0,0,0,0,0,0,0,0,0,0,0,0,0
-1884,0,0,0,0,0,0,0,0,0,0,0,0,0
-1885,0,0,0,0,0,0,0,0,0,0,0,0,0
-1886,0,0,0,0,0,0,0,0,0,0,0,0,0
-1887,0,0,0,0,0,0,0,0,0,0,0,0,0
-1888,0,0,0,0,0,0,0,0,0,0,0,0,0
-1889,0,0,0,0,0,0,0,0,0,0,0,0,0
-1890,0,0,0,0,0,0,0,0,0,0,0,0,0
-1891,0,0,0,0,0,0,0,0,0,0,0,0,0
-1892,0,0,0,0,0,0,0,0,0,0,0,0,0
-1893,0,0,0,0,0,0,0,0,0,0,0,0,0
-1894,0,0,0,0,0,0,0,0,0,0,0,0,0
-1895,0,0,0,0,0,0,0,0,0,0,0,0,0
-1896,0,0,0,0,0,0,0,0,0,0,0,0,0
-1897,0,0,0,0,0,0,0,0,0,0,0,0,0
-1898,0,0,0,0,0,0,0,0,0,0,0,0,0
-1899,0,0,0,0,0,0,0,0,0,0,0,0,0
-1900,0,0,0,0,0,0,0,0,0,0,0,0,0
-1901,0,0,0,0,0,0,0,0,0,0,0,0,0
-1902,0,0,0,0,0,0,0,0,0,0,0,0,0
-1903,0,0,0,0,0,0,0,0,0,0,0,0,0
-1904,0,0,0,0,0,0,0,0,0,0,0,0,0
-1905,0,0,0,0,0,0,0,0,0,0,0,0,0
-1906,0,0,0,0,0,0,0,0,0,0,0,0,0
-1907,0,0,0,0,0,0,0,0,0,0,0,0,0
-1908,0,0,0,0,0,0,0,0,0,0,0,0,0
-1909,0,0,0,0,0,0,0,0,0,0,0,0,0
-1910,0,0,0,0,0,0,0,0,0,0,0,0,0
-1911,0,0,0,0,0,0,0,0,0,0,0,0,0
-1912,0,0,0,0,0,0,0,0,0,0,0,0,0
-1913,0,0,0,0,0,0,0,0,0,0,0,0,0
-1914,0,0,0,0,0,0,0,0,0,0,0,0,0
-1915,0,0,0,0,0,0,0,0,0,0,0,0,0
-1916,0,0,0,0,0,0,0,0,0,0,0,0,0
-1917,0,0,0,0,0,0,0,0,0,0,0,0,0
-1918,0,0,0,0,0,0,0,0,0,0,0,0,0
-1919,0,0,0,0,0,0,0,0,0,0,0,0,0
-1920,0,0,0,0,0,0,0,0,0,0,0,0,0
-1921,0,0,0,0,0,0,0,0,0,0,0,0,0
-1922,0,0,0,0,0,0,0,0,0,0,0,0,0
-1923,0,0,0,0,0,0,0,0,0,0,0,0,0
-1924,0,0,0,0,0,0,0,0,0,0,0,0,0
-1925,0,0,0,0,0,0,0,0,0,0,0,0,0
-1926,0,0,0,0,0,0,0,0,0,0,0,0,0
-1927,0,0,0,0,0,0,0,0,0,0,0,0,0
-1928,0,0,0,0,0,0,0,0,0,0,0,0,0
-1929,0,0,0,0,0,0,0,0,0,0,0,0,0
-1930,0,0,0,0,0,0,0,0,0,0,0,0,0
-1931,0,0,0,0,0,0,0,0,0,0,0,0,0
-1932,0,0,0,0,0,0,0,0,0,0,0,0,0
-1933,0,0,0,0,0,0,0,0,0,0,0,0,0
-1934,0,0,0,0,0,0,0,0,0,0,0,0,0
-1935,0,0,0,0,0,0,0,0,0,0,0,0,0
-1936,0,0,0,0,0,0,0,0,0,0,0,0,0
-1937,0,0,0,0,0,0,0,0,0,0,0,0,0
-1938,0,0,0,0,0,0,0,0,0,0,0,0,0
-1939,0,0,0,0,0,0,0,0,0,0,0,0,0
-1940,0,0,0,0,0,0,0,0,0,0,0,0,0
-1941,0,0,0,0,0,0,0,0,0,0,0,0,0
-1942,0,0,0,0,0,0,0,0,0,0,0,0,0
-1943,0,0,0,0,0,0,0,0,0,0,0,0,0
-1944,0,0,0,0,0,0,0,0,0,0,0,0,0
-1945,0,0,0,0,0,0,0,0,0,0,0,0,0
-1946,0,0,0,0,0,0,0,0,0,0,0,0,0
-1947,0,0,0,0,0,0,0,0,0,0,0,0,0
-1948,0,0,0,0,0,0,0,0,0,0,0,0,0
-1949,0,0,0,0,0,0,0,0,0,0,0,0,0
-1950,0,0,0,0,0,0,0,0,0,0,0,0,0
-1951,0,0,0,0,0,0,0,0,0,0,0,0,0
-1952,0,0,0,0,0,0,0,0,0,0,0,0,0
-1953,0,0,0,0,0,0,0,0,0,0,0,0,0
-1954,0,0,0,0,0,0,0,0,0,0,0,0,0
-1955,0,0,0,0,0,0,0,0,0,0,0,0,0
-1956,0,0,0,0,0,0,0,0,0,0,0,0,0
-1957,0,0,0,0,0,0,0,0,0,0,0,0,0
-1958,0,0,0,0,0,0,0,0,0,0,0,0,0
-1959,0,0,0,0,0,0,0,0,0,0,0,0,0
-1960,0,0,0,0,0,0,0,0,0,0,0,0,0
-1961,0,0,0,0,0,0,0,0,0,0,0,0,0
-1962,0,0,0,0,0,0,0,0,0,0,0,0,0
-1963,0,0,0,0,0,0,0,0,0,0,0,0,0
-1964,0,0,0,0,0,0,0,0,0,0,0,0,0
-1965,0,0,0,0,0,0,0,0,0,0,0,0,0
-1966,0,0,0,0,0,0,0,0,0,0,0,0,0
-1967,0,0,0,0,0,0,0,0,0,0,0,0,0
-1968,0,0,0,0,0,0,0,0,0,0,0,0,0
-1969,0,0,0,0,0,0,0,0,0,0,0,0,0
-1970,0,0,0,0,0,0,0,0,0,0,0,0,0
-1971,0,0,0,0,0,0,0,0,0,0,0,0,0
-1972,0,0,0,0,0,0,0,0,0,0,0,0,0
-1973,0,0,0,0,0,0,0,0,0,0,0,0,0
-1974,0,0,0,0,0,0,0,0,0,0,0,0,0
-1975,0,0,0,0,0,0,0,0,0,0,0,0,0
-1976,0,0,0,0,0,0,0,0,0,0,0,0,0
-1977,0,0,0,0,0,0,0,0,0,0,0,0,0
-1978,0,0,0,0,0,0,0,0,0,0,0,0,0
-1979,0,0,0,0,0,0,0,0,0,0,0,0,0
-1980,0,0,0,0,0,0,0,0,0,0,0,0,0
-1981,0,0,0,0,0,0,0,0,0,0,0,0,0
-1982,0,0,0,0,0,0,0,0,0,0,0,0,0
-1983,0,0,0,0,0,0,0,0,0,0,0,0,0
-1984,0,0,0,0,0,0,0,0,0,0,0,0,0
-1985,0,0,0,0,0,0,0,0,0,0,0,0,0
-1986,0,0,0,0,0,0,0,0,0,0,0,0,0
-1987,0,0,0,0,0,0,0,0,0,0,0,0,0
-1988,0,0,0,0,0,0,0,0,0,0,0,0,0
-1989,0,0,0,0,0,0,0,0,0,0,0,0,0
-1990,0,0,0,0,0,0,0,0,0,0,0,0,0
-1991,0,0,0,0,0,0,0,0,0,0,0,0,0
-1992,0,0,0,0,0,0,0,0,0,0,0,0,0
-1993,0,0,0,0,0,0,0,0,0,0,0,0,0
-1994,0,0,0,0,0,0,0,0,0,0,0,0,0
-1995,0,0,0,0,0,0,0,0,0,0,0,0,0
-1996,0,0,0,0,0,0,0,0,0,0,0,0,0
-1997,0,0,0,0,0,0,0,0,0,0,0,0,0
-1998,0,0,0,0,0,0,0,0,0,0,0,0,0
-1999,0,0,0,0,0,0,0,0,0,0,0,0,0
-2000,0,0,0,0,0,0,0,0,0,0,0,0,0
-2001,0,0,0,0,0,0,0,0,0,0,0,0,0
-2002,0,0,0,0,0,0,0,0,0,0,0,0,0
-2003,0,0,0,0,0,0,0,0,0,0,0,0,0
-2004,0,0,0,0,0,0,0,0,0,0,0,0,0
-2005,0,0,0,0,0,0,0,0,0,0,0,0,0
-2006,0,0,0,0,0,0,0,0,0,0,0,0,0
-2007,0,0,0,0,0,0,0,0,0,0,0,0,0
-2008,0,0,0,0,0,0,0,0,0,0,0,0,0
-2009,0,0,0,0,0,0,0,0,0,0,0,0,0
-2010,0,0,0,0,0,0,0,0,0,0,0,0,0
-2011,0,0,0,0,0,0,0,0,0,0,0,0,0
-2012,0,0,0,0,0,0,0,0,0,0,0,0,0
-2013,0,0,0,0,0,0,0,0,0,0,0,0,0
-2014,0,0,0,0,0,0,0,0,0,0,0,0,0
-2015,0,0,0,0,0,0,0,0,0,0,0,0,0
-2016,0,0,0,0,0,0,0,0,0,0,0,0,0
-2017,0,0,0,0,0,0,0,0,0,0,0,0,0
-2018,0,0,0,0,0,0,0,0,0,0,0,0,0
-2019,0,0,0,0,0,0,0,0,0,0,0,0,0
-2020,0,0,0,0,0,0,0,0,0,0,0,0,0
-2021,0,0,0,0,0,0,0,0,0,0,0,0,0
-2022,0,0,0,0,0,0,0,0,0,0,0,0,0
-2023,0,0,0,0,0,0,0,0,0,0,0,0,0
-2024,0,0,0,0,0,0,0,0,0,0,0,0,0
-2025,0,0,0,0,0,0,0,0,0,0,0,0,0
-2026,0,0,0,0,0,0,0,0,0,0,0,0,0
-2027,0,0,0,0,0,0,0,0,0,0,0,0,0
-2028,0,0,0,0,0,0,0,0,0,0,0,0,0
-2029,0,0,0,0,0,0,0,0,0,0,0,0,0
-2030,0,0,0,0,0,0,0,0,0,0,0,0,0
-2031,0,0,0,0,0,0,0,0,0,0,0,0,0
-2032,0,0,0,0,0,0,0,0,0,0,0,0,0
-2033,0,0,0,0,0,0,0,0,0,0,0,0,0
-2034,0,0,0,0,0,0,0,0,0,0,0,0,0
-2035,0,0,0,0,0,0,0,0,0,0,0,0,0
-2036,0,0,0,0,0,0,0,0,0,0,0,0,0
-2037,0,0,0,0,0,0,0,0,0,0,0,0,0
-2038,0,0,0,0,0,0,0,0,0,0,0,0,0
-2039,0,0,0,0,0,0,0,0,0,0,0,0,0
-2040,0,0,0,0,0,0,0,0,0,0,0,0,0
-2041,0,0,0,0,0,0,0,0,0,0,0,0,0
-2042,0,0,0,0,0,0,0,0,0,0,0,0,0
-2043,0,0,0,0,0,0,0,0,0,0,0,0,0
-2044,0,0,0,0,0,0,0,0,0,0,0,0,0
-2045,0,0,0,0,0,0,0,0,0,0,0,0,0
-2046,0,0,0,0,0,0,0,0,0,0,0,0,0
-2047,0,0,0,0,0,0,0,0,0,0,0,0,0
-2048,0,0,0,0,0,0,0,0,0,0,0,0,0
-2049,0,0,0,0,0,0,0,0,0,0,0,0,0
-2050,0,0,0,0,0,0,0,0,0,0,0,0,0
-2051,0,0,0,0,0,0,0,0,0,0,0,0,0
-2052,0,0,0,0,0,0,0,0,0,0,0,0,0
-2053,0,0,0,0,0,0,0,0,0,0,0,0,0
-2054,0,0,0,0,0,0,0,0,0,0,0,0,0
-2055,0,0,0,0,0,0,0,0,0,0,0,0,0
-2056,0,0,0,0,0,0,0,0,0,0,0,0,0
-2057,0,0,0,0,0,0,0,0,0,0,0,0,0
-2058,0,0,0,0,0,0,0,0,0,0,0,0,0
-2059,0,0,0,0,0,0,0,0,0,0,0,0,0
-2060,0,0,0,0,0,0,0,0,0,0,0,0,0
-2061,0,0,0,0,0,0,0,0,0,0,0,0,0
-2062,0,0,0,0,0,0,0,0,0,0,0,0,0
-2063,0,0,0,0,0,0,0,0,0,0,0,0,0
-2064,0,0,0,0,0,0,0,0,0,0,0,0,0
-2065,0,0,0,0,0,0,0,0,0,0,0,0,0
-2066,0,0,0,0,0,0,0,0,0,0,0,0,0
-2067,0,0,0,0,0,0,0,0,0,0,0,0,0
-2068,0,0,0,0,0,0,0,0,0,0,0,0,0
-2069,0,0,0,0,0,0,0,0,0,0,0,0,0
-2070,0,0,0,0,0,0,0,0,0,0,0,0,0
-2071,0,0,0,0,0,0,0,0,0,0,0,0,0
-2072,0,0,0,0,0,0,0,0,0,0,0,0,0
-2073,0,0,0,0,0,0,0,0,0,0,0,0,0
-2074,0,0,0,0,0,0,0,0,0,0,0,0,0
-2075,0,0,0,0,0,0,0,0,0,0,0,0,0
-2076,0,0,0,0,0,0,0,0,0,0,0,0,0
-2077,0,0,0,0,0,0,0,0,0,0,0,0,0
-2078,0,0,0,0,0,0,0,0,0,0,0,0,0.000639264
-2079,0,0,0,0,0,0,0,0,0,0,0,0,0.001022905
-2080,0,0,0,0,0,0,0,0,0,0,0,0,0.002884721
-2081,0,0,0,0,0,0,0,0,0,0,0,0,0.003997454
-2082,0,0,0,0,0,0,0,0,0,0,0,0,0.006597118
-2083,0,0,0,0,0,0,0,0,0,0,0,0,0.007659826
-2084,0,0,0,0,0,0,0,0,0,0,0,0,0.00800413
-2085,0,0,0,0,0,0,0,0,0,0,0,0,0.008539692
-2086,0,0,0,0,0,0,0,0,0,0,0,0,0.009300309
-2087,0,0,0,0,0,0,0,0,0,0,0,0,0.010001938
-2088,0,0,0,0,0,0,0,0,0,0,0,0,0.010972178
-2089,0,0,0,0,0,0,0,0,0,0,0,0,0.012089456
-2090,0,0,0,0,0,0,0,0,0,0,0,0,0.013364144
-2091,0,0,0,0,0,0,0,0,0,0,0,0,0.015017309
-2092,0,0,0,0,0,0,0,0,0,0,0,0,0.01712566
-2093,0,0,0,0,0,0,0,0,0,0,0,0,0.01978032
-2094,0,0,0,0,0,0,0,0,0,0,0,0,0.023335884
-2095,0,0,0,0,0,0,0,0,0,0,0,0,0.027667597
-2096,0,0,0,0,0,0,0,0,0,0,0,0,0.033215941
-2097,0,0,0,0,0,0,0,0,0,0,0,0,0.040217377
-2098,0,0,0,0,0,0,0,0,0,0,0,0,0.048882662
-2099,0,0,0,0,0,0,0,0,0,0,0,0,0.059642173
-2100,0,0,0,0,0,0,0,0,0,0,0,0,0.073175151
-2101,0,0,0,0,0,0,0,0,0,0,0,0,0.090534716
-2102,0,0,0,0,0,0,0,0,0,0,0,0,0.111470124
-2103,0,0,0,0,0,0,0,0,0,0,0,0,0.13690299
-2104,0,0,0,0,0,0,0,0,0,0,0,0,0.167810536
-2105,0,0,0,0,0,0,0,0,0,0,0,0,0.203460906
-2106,0,0,0,0,0,0,0,0,0,0,0,0,0.242871255
-2107,0,0,0,0,0,0,0,0,0,0,0,0,0.284898317
-2108,0,0,0,0,0,0,0,0,0,0,0,0,0.327177957
-2109,0,0,0,0,0,0,0,0,0,0,0,0,0.36840376
-2110,0,0,0,0,0,0,0,0,0,0,0,0,0.40800276
-2111,0,0,0,0,0,0,0,0,0,0,0,0,0.444778149
-2112,0,0,0,0,0,0,0,0,0,0,0,0,0.476537405
-2113,0,0,0,0,0,0,0,0,0,0,0,0,0.503106894
-2114,0,0,0,0,0,0,0,0,0,0,0,0,0.525317548
-2115,0,0,0,0,0,0,0,0,0,0,0,0,0.543351996
-2116,0,0,0,0,0,0,0,0,0,0,0,0,0.557252862
-2117,0,0,0,0,0,0,0,0,0,0,0,0,0.568634197
-2118,0,0,0,0,0,0,0,0,0,0,0,0,0.579029932
-2119,0,0,0,0,0,0,0,0,0,0,0,0,0.588683995
-2120,0,0,0,0,0,0,0,0,0,0,0,0,0.59889121
-2121,0,0,0,0,0,0,0,0,0,0,0,0,0.609981083
-2122,0,0,0,0,0,0,0,0,0,0,0,0,0.621362162
-2123,0,0,0,0,0,0,0,0,0,0,0,0,0.634282516
-2124,0,0,0,0,0,0,0,0,0,0,0,0,0.64854644
-2125,0,0,0,0,0,0,0,0,0,0,0,0,0.663707315
-2126,0,0,0,0,0,0,0,0,0,0,0,0,0.680046291
-2127,0,0,0,0,0,0,0,0,0,0,0,0,0.696164765
-2128,0,0,0,0,0,0,0,0,0,0,0,0,0.711964139
-2129,0,0,0,0,0,0,0,0,0,0,0,0,0.727011081
-2130,0,0,0,0,0,0,0,0,0,0,0,0,0.741301118
-2131,0,0,0,0,0,0,0,0,0,0,0,0,0.757405387
-2132,0,0,0,0,0,0,0,0,0,0,0,0,0.772070514
-2133,0,0,0,0,0,0,0,0,0,0,0,0,0.78558074
-2134,0,0,0,0,0,0,0,0,0,0,0,0,0.798238093
-2135,0,0,0,0,0,0,0,0,0,0,0,0,0.809677071
-2136,0,0,0,0,0,0,0,0,0,0,0,0,0.819701739
-2137,0,0,0,0,0,0,0,0,0,0,0,0,0.82859933
-2138,0,0,0,0,0,0,0,0,0,0,0,0,0.836721896
-2139,0,0,0,0,0,0,0,0,0,0,0,0,0.844443431
-2140,0,0,0,0,0,0,0,0,0,0,0,0,0.851107219
-2141,0,0,0,0,0,0,0,0,0,0,0,0,0.853252319
-2142,0,0,0,0,0,0,0,0,0,0,0,0,0.854746271
-2143,0,0,0,0,0,0,0,0,0,0,0,0,0.85617419
-2144,0,0,0,0,0,0,0,0,0,0,0,0,0.857820928
-2145,0,0,0,0,0,0,0,0,0,0,0,0,0.859531818
-2146,0,0,0,0,0,0,0,0,0,0,0,0,0.861459829
-2147,0,0,0,0,0,0,0,0,0,0,0,0,0.863256985
-2148,0,0,0,0,0,0,0,0,0,0,0,0,0.865138808
-2149,0,0,0,0,0,0,0,0,0,0,0,0,0.867319035
-2150,0,0,0,0,0,0,0,0,0,0,0,0,0.869696339
-2151,0,0,0,0,0,0,0,0,0,0,0,0,0.874301992
-2152,0,0,0,0,0,0,0,0,0,0,0,0,0.878588437
-2153,0,0,0,0,0,0,0,0,0,0,0,0,0.882438825
-2154,0,0,0,0,0,0,0,0,0,0,0,0,0.885928758
-2155,0,0,0,0,0,0,0,0,0,0,0,0,0.889473121
-2156,0,0,0,0,0,0,0,0,0,0,0,0,0.89322574
-2157,0,0,0,0,0,0,0,0,0,0,0,0,0.896696495
-2158,0,0,0,0,0,0,0,0,0,0,0,0,0.899896619
-2159,0,0,0,0,0,0,0,0,0,0,0,0,0.902596288
-2160,0,0,0,0,0,0,0,0,0,0,0,0,0.90483074
-2161,0,0,0,0,0,0,0,0,0,0,0,0,0.905524618
-2162,0,0,0,0,0,0,0,0,0,0,0,0,0.905665281
-2163,0,0,0,0,0,0,0,0,0,0,0,0,0.905502587
-2164,0,0,0,0,0,0,0,0,0,0,0,0,0.905157893
-2165,0,0,0,0,0,0,0,0,0,0,0,0,0.904782854
-2166,0,0,0,0,0,0,0,0,0,0,0,0,0.90408183
-2167,0,0,0,0,0,0,0,0,0,0,0,0,0.903347495
-2168,0,0,0,0,0,0,0,0,0,0,0,0,0.902760831
-2169,0,0,0,0,0,0,0,0,0,0,0,0,0.902377006
-2170,0,0,0,0,0,0,0,0,0,0,0,0,0.901982966
-2171,0,0,0,0,0,0,0,0,0,0,0,0,0.903423562
-2172,0,0,0,0,0,0,0,0,0,0,0,0,0.904312941
-2173,0,0,0,0,0,0,0,0,0,0,0,0,0.905315323
-2174,0,0,0,0,0,0,0,0,0,0,0,0,0.906446178
-2175,0,0,0,0,0,0,0,0,0,0,0,0,0.90809207
-2176,0,0,0,0,0,0,0,0,0,0,0,0,0.910123185
-2177,0,0,0,0,0,0,0,0,0,0,0,0,0.912949979
-2178,0,0,0,0,0,0,0,0,0,0,0,0,0.915584774
-2179,0,0,0,0,0,0,0,0,0,0,0,0,0.918444254
-2180,0,0,0,0,0,0,0,0,0,0,0,0,0.921302412
-2181,0,0,0,0,0,0,0,0,0,0,0,0,0.924337167
-2182,0,0,0,0,0,0,0,0,0,0,0,0,0.927218563
-2183,0,0,0,0,0,0,0,0,0,0,0,0,0.929740263
-2184,0,0,0,0,0,0,0,0,0,0,0,0,0.931921865
-2185,0,0,0,0,0,0,0,0,0,0,0,0,0.934142166
-2186,0,0,0,0,0,0,0,0,0,0,0,0,0.935906112
-2187,0,0,0,0,0,0,0,0,0,0,0,0,0.937086137
-2188,0,0,0,0,0,0,0,0,0,0,0,0,0.937641167
-2189,0,0,0,0,0,0,0,0,0,0,0,0,0.938301157
-2190,0,0,0,0,0,0,0,0,0,0,0,0,0.937652085
-2191,0,0,0,0,0,0,0,0,0,0,0,0,0.940440758
-2192,0,0,0,0,0,0,0,0,0,0,0,0,0.942517533
-2193,0,0,0,0,0,0,0,0,0,0,0,0,0.943259037
-2194,0,0,0,0,0,0,0,0,0,0,0,0,0.943031026
-2195,0,0,0,0,0,0,0,0,0,0,0,0,0.942117106
-2196,0,0,0,0,0,0,0,0,0,0,0,0,0.940631648
-2197,0,0,0,0,0,0,0,0,0,0,0,0,0.938427922
-2198,0,0,0,0,0,0,0,0,0,0,0,0,0.936660033
-2199,0,0,0,0,0,0,0,0,0,0,0,0,0.935256327
-2200,0,0,0,0,0,0,0,0,0,0,0,0,0.933022239
-2201,0,0,0,0,0,0,0,0,0,0,0,0,0.926879998
-2202,0,0,0,0,0,0,0,0,0,0,0,0,0.921056996
-2203,0,0,0,0,0,0,0,0,0,0,0,0,0.915482617
-2204,0,0,0,0,0,0,0,0,0,0,0,0,0.911020114
-2205,0,0,0,0,0,0,0,0,0,0,0,0,0.908292872
-2206,0,0,0,0,0,0,0,0,0,0,0,0,0.907283492
-2207,0,0,0,0,0,0,0,0,0,0,0,0,0.90819092
-2208,0,0,0,0,0,0,0,0,0,0,0,0,0.911168883
-2209,0,0,0,0,0,0,0,0,0,0,0,0,0.916188526
-2210,0,0,0,0,0,0,0,0,0,0,0,0,0.922854635
-2211,0,0,0,0,0,0,0,0,0,0,0,0,0.920605167
-2212,0,0,0,0,0,0,0,0,0,0,0,0,0.919482312
-2213,0,0,0,0,0,0,0,0,0,0,0,0,0.919489205
-2214,0,0,0,0,0,0,0,0,0,0,0,0,0.921276392
-2215,0,0,0,0,0,0,0,0,0,0,0,0,0.924526038
-2216,0,0,0,0,0,0,0,0,0,0,0,0,0.927732919
-2217,0,0,0,0,0,0,0,0,0,0,0,0,0.931974489
-2218,0,0,0,0,0,0,0,0,0,0,0,0,0.936769555
-2219,0,0,0,0,0,0,0,0,0,0,0,0,0.941482728
-2220,0,0,0,0,0,0,0,0,0,0,0,0,0.946801994
-2221,0,0,0,0,0,0,0,0,0,0,0,0,0.951202607
-2222,0,0,0,0,0,0,0,0,0,0,0,0,0.954436663
-2223,0,0,0,0,0,0,0,0,0,0,0,0,0.957046915
-2224,0,0,0,0,0,0,0,0,0,0,0,0,0.959729173
-2225,0,0,0,0,0,0,0,0,0,0,0,0,0.962538601
-2226,0,0,0,0,0,0,0,0,0,0,0,0,0.964857726
-2227,0,0,0,0,0,0,0,0,0,0,0,0,0.966042031
-2228,0,0,0,0,0,0,0,0,0,0,0,0,0.966647037
-2229,0,0,0,0,0,0,0,0,0,0,0,0,0.966309991
-2230,0,0,0,0,0,0,0,0,0,0,0,0,0.965460063
-2231,0,0,0,0,0,0,0,0,0,0,0,0,0.964841278
-2232,0,0,0,0,0,0,0,0,0,0,0,0,0.963655749
-2233,0,0,0,0,0,0,0,0,0,0,0,0,0.961698492
-2234,0,0,0,0,0,0,0,0,0,0,0,0,0.959453949
-2235,0,0,0,0,0,0,0,0,0,0,0,0,0.957327053
-2236,0,0,0,0,0,0,0,0,0,0,0,0,0.955140475
-2237,0,0,0,0,0,0,0,0,0,0,0,0,0.953558145
-2238,0,0,0,0,0,0,0,0,0,0,0,0,0.95273179
-2239,0,0,0,0,0,0,0,0,0,0,0,0,0.952180853
-2240,0,0,0,0,0,0,0,0,0,0,0,0,0.951730689
-2241,0,0,0,0,0,0,0,0,0,0,0,0,0.952145994
-2242,0,0,0,0,0,0,0,0,0,0,0,0,0.952641408
-2243,0,0,0,0,0,0,0,0,0,0,0,0,0.954056643
-2244,0,0,0,0,0,0,0,0,0,0,0,0,0.957078482
-2245,0,0,0,0,0,0,0,0,0,0,0,0,0.960638803
-2246,0,0,0,0,0,0,0,0,0,0,0,0,0.964221982
-2247,0,0,0,0,0,0,0,0,0,0,0,0,0.968307493
-2248,0,0,0,0,0,0,0,0,0,0,0,0,0.972691041
-2249,0,0,0,0,0,0,0,0,0,0,0,0,0.97742349
-2250,0,0,0,0,0,0,0,0,0,0,0,0,0.982898416
-2251,0,0,0,0,0,0,0,0,0,0,0,0,0.98714443
-2252,0,0,0,0,0,0,0,0,0,0,0,0,0.990734152
-2253,0,0,0,0,0,0,0,0,0,0,0,0,0.993982826
-2254,0,0,0,0,0,0,0,0,0,0,0,0,0.996786808
-2255,0,0,0,0,0,0,0,0,0,0,0,0,0.998752904
-2256,0,0,0,0,0,0,0,0,0,0,0,0,1
-2257,0,0,0,0,0,0,0,0,0,0,0,0,0.999927455
-2258,0,0,0,0,0,0,0,0,0,0,0,0,0.999151921
-2259,0,0,0,0,0,0,0,0,0,0,0,0,0.997129452
-2260,0,0,0,0,0,0,0,0,0,0,0,0,0.993883695
-2261,0,0,0,0,0,0,0,0,0,0,0,0,0.989685968
-2262,0,0,0,0,0,0,0,0,0,0,0,0,0.983735405
-2263,0,0,0,0,0,0,0,0,0,0,0,0,0.976212761
-2264,0,0,0,0,0,0,0,0,0,0,0,0,0.967813199
-2265,0,0,0,0,0,0,0,0,0,0,0,0,0.958342887
-2266,0,0,0,0,0,0,0,0,0,0,0,0,0.948440151
-2267,0,0,0,0,0,0,0,0,0,0,0,0,0.9382028
-2268,0,0,0,0,0,0,0,0,0,0,0,0,0.927724853
-2269,0,0,0,0,0,0,0,0,0,0,0,0,0.917038819
-2270,0,0,0,0,0,0,0,0,0,0,0,0,0.905999348
-2271,0,0,0,0,0,0,0,0,0,0,0,0,0.893868367
-2272,0,0,0,0,0,0,0,0,0,0,0,0,0.881682515
-2273,0,0,0,0,0,0,0,0,0,0,0,0,0.86864716
-2274,0,0,0,0,0,0,0,0,0,0,0,0,0.854635458
-2275,0,0,0,0,0,0,0,0,0,0,0,0,0.840619936
-2276,0,0,0,0,0,0,0,0,0,0,0,0,0.826015692
-2277,0,0,0,0,0,0,0,0,0,0,0,0,0.809516209
-2278,0,0,0,0,0,0,0,0,0,0,0,0,0.791866591
-2279,0,0,0,0,0,0,0,0,0,0,0,0,0.772443017
-2280,0,0,0,0,0,0,0,0,0,0,0,0,0.749106638
-2281,0,0,0,0,0,0,0,0,0,0,0,0,0.720345599
-2282,0,0,0,0,0,0,0,0,0,0,0,0,0.688185271
-2283,0,0,0,0,0,0,0,0,0,0,0,0,0.651282733
-2284,0,0,0,0,0,0,0,0,0,0,0,0,0.610049759
-2285,0,0,0,0,0,0,0,0,0,0,0,0,0.56603087
-2286,0,0,0,0,0,0,0,0,0,0,0,0,0.520969977
-2287,0,0,0,0,0,0,0,0,0,0,0,0,0.474659094
-2288,0,0,0,0,0,0,0,0,0,0,0,0,0.429259293
-2289,0,0,0,0,0,0,0,0,0,0,0,0,0.38585714
-2290,0,0,0,0,0,0,0,0,0,0,0,0,0.342091763
-2291,0,0,0,0,0,0,0,0,0,0,0,0,0.300680041
-2292,0,0,0,0,0,0,0,0,0,0,0,0,0.263176181
-2293,0,0,0,0,0,0,0,0,0,0,0,0,0.227703987
-2294,0,0,0,0,0,0,0,0,0,0,0,0,0.195720706
-2295,0,0,0,0,0,0,0,0,0,0,0,0,0.168090024
-2296,0,0,0,0,0,0,0,0,0,0,0,0,0.144679716
-2297,0,0,0,0,0,0,0,0,0,0,0,0,0.124830647
-2298,0,0,0,0,0,0,0,0,0,0,0,0,0.108237331
-2299,0,0,0,0,0,0,0,0,0,0,0,0,0.09440058
-2300,0,0,0,0,0,0,0,0,0,0,0,0,0.082363039
-2301,0,0,0,0,0,0,0,0,0,0,0,0,0.071500068
-2302,0,0,0,0,0,0,0,0,0,0,0,0,0.062690603
-2303,0,0,0,0,0,0,0,0,0,0,0,0,0.054985448
-2304,0,0,0,0,0,0,0,0,0,0,0,0,0.048194534
-2305,0,0,0,0,0,0,0,0,0,0,0,0,0.042864117
-2306,0,0,0,0,0,0,0,0,0,0,0,0,0.038598228
-2307,0,0,0,0,0,0,0,0,0,0,0,0,0.034947252
-2308,0,0,0,0,0,0,0,0,0,0,0,0,0.031998848
-2309,0,0,0,0,0,0,0,0,0,0,0,0,0.029587869
-2310,0,0,0,0,0,0,0,0,0,0,0,0,0.027418116
-2311,0,0,0,0,0,0,0,0,0,0,0,0,0.025576973
-2312,0,0,0,0,0,0,0,0,0,0,0,0,0.023959421
-2313,0,0,0,0,0,0,0,0,0,0,0,0,0.021671692
-2314,0,0,0,0,0,0,0,0,0,0,0,0,0.019147972
-2315,0,0,0,0,0,0,0,0,0,0,0,0,0.016331132
-2316,0,0,0,0,0,0,0,0,0,0,0,0,0.010988591
-2317,0,0,0,0,0,0,0,0,0,0,0,0,0.007378602
-2318,0,0,0,0,0,0,0,0,0,0,0,0,0.006510601
-2319,0,0,0,0,0,0,0,0,0,0,0,0,0.004709556
-2320,0,0,0,0,0,0,0,0,0,0,0,0,0.002065107
-2321,0,0,0,0,0,0,0,0,0,0,0,0,0
-2322,0,0,0,0,0,0,0,0,0,0,0,0,0
-2323,0,0,0,0,0,0,0,0,0,0,0,0,0
-2324,0,0,0,0,0,0,0,0,0,0,0,0,0
-2325,0,0,0,0,0,0,0,0,0,0,0,0,0
-2326,0,0,0,0,0,0,0,0,0,0,0,0,0
-2327,0,0,0,0,0,0,0,0,0,0,0,0,0
-2328,0,0,0,0,0,0,0,0,0,0,0,0,0
-2329,0,0,0,0,0,0,0,0,0,0,0,0,0
-2330,0,0,0,0,0,0,0,0,0,0,0,0,0
-2331,0,0,0,0,0,0,0,0,0,0,0,0,0
-2332,0,0,0,0,0,0,0,0,0,0,0,0,0
-2333,0,0,0,0,0,0,0,0,0,0,0,0,0
-2334,0,0,0,0,0,0,0,0,0,0,0,0,0
-2335,0,0,0,0,0,0,0,0,0,0,0,0,0
-2336,0,0,0,0,0,0,0,0,0,0,0,0,0
-2337,0,0,0,0,0,0,0,0,0,0,0,0,0
-2338,0,0,0,0,0,0,0,0,0,0,0,0,0
-2339,0,0,0,0,0,0,0,0,0,0,0,0,0
-2340,0,0,0,0,0,0,0,0,0,0,0,0,0
-2341,0,0,0,0,0,0,0,0,0,0,0,0,0
-2342,0,0,0,0,0,0,0,0,0,0,0,0,0
-2343,0,0,0,0,0,0,0,0,0,0,0,0,0
-2344,0,0,0,0,0,0,0,0,0,0,0,0,0
-2345,0,0,0,0,0,0,0,0,0,0,0,0,0
-2346,0,0,0,0,0,0,0,0,0,0,0,0,0
-2347,0,0,0,0,0,0,0,0,0,0,0,0,0
-2348,0,0,0,0,0,0,0,0,0,0,0,0,0
-2349,0,0,0,0,0,0,0,0,0,0,0,0,0
-2350,0,0,0,0,0,0,0,0,0,0,0,0,0
-2351,0,0,0,0,0,0,0,0,0,0,0,0,0
-2352,0,0,0,0,0,0,0,0,0,0,0,0,0
-2353,0,0,0,0,0,0,0,0,0,0,0,0,0
-2354,0,0,0,0,0,0,0,0,0,0,0,0,0
-2355,0,0,0,0,0,0,0,0,0,0,0,0,0
-2356,0,0,0,0,0,0,0,0,0,0,0,0,0
-2357,0,0,0,0,0,0,0,0,0,0,0,0,0
-2358,0,0,0,0,0,0,0,0,0,0,0,0,0
-2359,0,0,0,0,0,0,0,0,0,0,0,0,0
-2360,0,0,0,0,0,0,0,0,0,0,0,0,0
-2361,0,0,0,0,0,0,0,0,0,0,0,0,0
-2362,0,0,0,0,0,0,0,0,0,0,0,0,0
-2363,0,0,0,0,0,0,0,0,0,0,0,0,0
-2364,0,0,0,0,0,0,0,0,0,0,0,0,0
-2365,0,0,0,0,0,0,0,0,0,0,0,0,0
-2366,0,0,0,0,0,0,0,0,0,0,0,0,0
-2367,0,0,0,0,0,0,0,0,0,0,0,0,0
-2368,0,0,0,0,0,0,0,0,0,0,0,0,0
-2369,0,0,0,0,0,0,0,0,0,0,0,0,0
-2370,0,0,0,0,0,0,0,0,0,0,0,0,0
-2371,0,0,0,0,0,0,0,0,0,0,0,0,0
-2372,0,0,0,0,0,0,0,0,0,0,0,0,0
-2373,0,0,0,0,0,0,0,0,0,0,0,0,0
-2374,0,0,0,0,0,0,0,0,0,0,0,0,0
-2375,0,0,0,0,0,0,0,0,0,0,0,0,0
-2376,0,0,0,0,0,0,0,0,0,0,0,0,0
-2377,0,0,0,0,0,0,0,0,0,0,0,0,0
-2378,0,0,0,0,0,0,0,0,0,0,0,0,0
-2379,0,0,0,0,0,0,0,0,0,0,0,0,0
-2380,0,0,0,0,0,0,0,0,0,0,0,0,0
-2381,0,0,0,0,0,0,0,0,0,0,0,0,0
-2382,0,0,0,0,0,0,0,0,0,0,0,0,0
-2383,0,0,0,0,0,0,0,0,0,0,0,0,0
-2384,0,0,0,0,0,0,0,0,0,0,0,0,0
-2385,0,0,0,0,0,0,0,0,0,0,0,0,0
-2386,0,0,0,0,0,0,0,0,0,0,0,0,0
-2387,0,0,0,0,0,0,0,0,0,0,0,0,0
-2388,0,0,0,0,0,0,0,0,0,0,0,0,0
-2389,0,0,0,0,0,0,0,0,0,0,0,0,0
-2390,0,0,0,0,0,0,0,0,0,0,0,0,0
-2391,0,0,0,0,0,0,0,0,0,0,0,0,0
-2392,0,0,0,0,0,0,0,0,0,0,0,0,0
-2393,0,0,0,0,0,0,0,0,0,0,0,0,0
-2394,0,0,0,0,0,0,0,0,0,0,0,0,0
-2395,0,0,0,0,0,0,0,0,0,0,0,0,0
-2396,0,0,0,0,0,0,0,0,0,0,0,0,0
-2397,0,0,0,0,0,0,0,0,0,0,0,0,0
-2398,0,0,0,0,0,0,0,0,0,0,0,0,0
-2399,0,0,0,0,0,0,0,0,0,0,0,0,0
-2400,0,0,0,0,0,0,0,0,0,0,0,0,0
-2401,0,0,0,0,0,0,0,0,0,0,0,0,0
-2402,0,0,0,0,0,0,0,0,0,0,0,0,0
-2403,0,0,0,0,0,0,0,0,0,0,0,0,0
-2404,0,0,0,0,0,0,0,0,0,0,0,0,0
-2405,0,0,0,0,0,0,0,0,0,0,0,0,0
-2406,0,0,0,0,0,0,0,0,0,0,0,0,0
-2407,0,0,0,0,0,0,0,0,0,0,0,0,0
-2408,0,0,0,0,0,0,0,0,0,0,0,0,0
-2409,0,0,0,0,0,0,0,0,0,0,0,0,0
-2410,0,0,0,0,0,0,0,0,0,0,0,0,0
-2411,0,0,0,0,0,0,0,0,0,0,0,0,0
-2412,0,0,0,0,0,0,0,0,0,0,0,0,0
-2413,0,0,0,0,0,0,0,0,0,0,0,0,0
-2414,0,0,0,0,0,0,0,0,0,0,0,0,0
-2415,0,0,0,0,0,0,0,0,0,0,0,0,0
-2416,0,0,0,0,0,0,0,0,0,0,0,0,0
-2417,0,0,0,0,0,0,0,0,0,0,0,0,0
-2418,0,0,0,0,0,0,0,0,0,0,0,0,0
-2419,0,0,0,0,0,0,0,0,0,0,0,0,0
-2420,0,0,0,0,0,0,0,0,0,0,0,0,0
-2421,0,0,0,0,0,0,0,0,0,0,0,0,0
-2422,0,0,0,0,0,0,0,0,0,0,0,0,0
-2423,0,0,0,0,0,0,0,0,0,0,0,0,0
-2424,0,0,0,0,0,0,0,0,0,0,0,0,0
-2425,0,0,0,0,0,0,0,0,0,0,0,0,0
-2426,0,0,0,0,0,0,0,0,0,0,0,0,0
-2427,0,0,0,0,0,0,0,0,0,0,0,0,0
-2428,0,0,0,0,0,0,0,0,0,0,0,0,0
-2429,0,0,0,0,0,0,0,0,0,0,0,0,0
-2430,0,0,0,0,0,0,0,0,0,0,0,0,0
-2431,0,0,0,0,0,0,0,0,0,0,0,0,0
-2432,0,0,0,0,0,0,0,0,0,0,0,0,0
-2433,0,0,0,0,0,0,0,0,0,0,0,0,0
-2434,0,0,0,0,0,0,0,0,0,0,0,0,0
-2435,0,0,0,0,0,0,0,0,0,0,0,0,0
-2436,0,0,0,0,0,0,0,0,0,0,0,0,0
-2437,0,0,0,0,0,0,0,0,0,0,0,0,0
-2438,0,0,0,0,0,0,0,0,0,0,0,0,0
-2439,0,0,0,0,0,0,0,0,0,0,0,0,0
-2440,0,0,0,0,0,0,0,0,0,0,0,0,0
-2441,0,0,0,0,0,0,0,0,0,0,0,0,0
-2442,0,0,0,0,0,0,0,0,0,0,0,0,0
-2443,0,0,0,0,0,0,0,0,0,0,0,0,0
-2444,0,0,0,0,0,0,0,0,0,0,0,0,0
-2445,0,0,0,0,0,0,0,0,0,0,0,0,0
-2446,0,0,0,0,0,0,0,0,0,0,0,0,0
-2447,0,0,0,0,0,0,0,0,0,0,0,0,0
-2448,0,0,0,0,0,0,0,0,0,0,0,0,0
-2449,0,0,0,0,0,0,0,0,0,0,0,0,0
-2450,0,0,0,0,0,0,0,0,0,0,0,0,0
-2451,0,0,0,0,0,0,0,0,0,0,0,0,0
-2452,0,0,0,0,0,0,0,0,0,0,0,0,0
-2453,0,0,0,0,0,0,0,0,0,0,0,0,0
-2454,0,0,0,0,0,0,0,0,0,0,0,0,0
-2455,0,0,0,0,0,0,0,0,0,0,0,0,0
-2456,0,0,0,0,0,0,0,0,0,0,0,0,0
-2457,0,0,0,0,0,0,0,0,0,0,0,0,0
-2458,0,0,0,0,0,0,0,0,0,0,0,0,0
-2459,0,0,0,0,0,0,0,0,0,0,0,0,0
-2460,0,0,0,0,0,0,0,0,0,0,0,0,0
-2461,0,0,0,0,0,0,0,0,0,0,0,0,0
-2462,0,0,0,0,0,0,0,0,0,0,0,0,0
-2463,0,0,0,0,0,0,0,0,0,0,0,0,0
-2464,0,0,0,0,0,0,0,0,0,0,0,0,0
-2465,0,0,0,0,0,0,0,0,0,0,0,0,0
-2466,0,0,0,0,0,0,0,0,0,0,0,0,0
-2467,0,0,0,0,0,0,0,0,0,0,0,0,0
-2468,0,0,0,0,0,0,0,0,0,0,0,0,0
-2469,0,0,0,0,0,0,0,0,0,0,0,0,0
-2470,0,0,0,0,0,0,0,0,0,0,0,0,0
-2471,0,0,0,0,0,0,0,0,0,0,0,0,0
-2472,0,0,0,0,0,0,0,0,0,0,0,0,0
-2473,0,0,0,0,0,0,0,0,0,0,0,0,0
-2474,0,0,0,0,0,0,0,0,0,0,0,0,0
-2475,0,0,0,0,0,0,0,0,0,0,0,0,0
-2476,0,0,0,0,0,0,0,0,0,0,0,0,0
-2477,0,0,0,0,0,0,0,0,0,0,0,0,0
-2478,0,0,0,0,0,0,0,0,0,0,0,0,0
-2479,0,0,0,0,0,0,0,0,0,0,0,0,0
-2480,0,0,0,0,0,0,0,0,0,0,0,0,0
-2481,0,0,0,0,0,0,0,0,0,0,0,0,0
-2482,0,0,0,0,0,0,0,0,0,0,0,0,0
-2483,0,0,0,0,0,0,0,0,0,0,0,0,0
-2484,0,0,0,0,0,0,0,0,0,0,0,0,0
-2485,0,0,0,0,0,0,0,0,0,0,0,0,0
-2486,0,0,0,0,0,0,0,0,0,0,0,0,0
-2487,0,0,0,0,0,0,0,0,0,0,0,0,0
-2488,0,0,0,0,0,0,0,0,0,0,0,0,0
-2489,0,0,0,0,0,0,0,0,0,0,0,0,0
-2490,0,0,0,0,0,0,0,0,0,0,0,0,0
-2491,0,0,0,0,0,0,0,0,0,0,0,0,0
-2492,0,0,0,0,0,0,0,0,0,0,0,0,0
-2493,0,0,0,0,0,0,0,0,0,0,0,0,0
-2494,0,0,0,0,0,0,0,0,0,0,0,0,0
-2495,0,0,0,0,0,0,0,0,0,0,0,0,0
-2496,0,0,0,0,0,0,0,0,0,0,0,0,0
-2497,0,0,0,0,0,0,0,0,0,0,0,0,0
-2498,0,0,0,0,0,0,0,0,0,0,0,0,0
-2499,0,0,0,0,0,0,0,0,0,0,0,0,0
-2500,0,0,0,0,0,0,0,0,0,0,0,0,0
-2501,0,0,0,0,0,0,0,0,0,0,0,0,0
-2502,0,0,0,0,0,0,0,0,0,0,0,0,0
-2503,0,0,0,0,0,0,0,0,0,0,0,0,0
-2504,0,0,0,0,0,0,0,0,0,0,0,0,0
-2505,0,0,0,0,0,0,0,0,0,0,0,0,0
-2506,0,0,0,0,0,0,0,0,0,0,0,0,0
-2507,0,0,0,0,0,0,0,0,0,0,0,0,0
-2508,0,0,0,0,0,0,0,0,0,0,0,0,0
-2509,0,0,0,0,0,0,0,0,0,0,0,0,0
-2510,0,0,0,0,0,0,0,0,0,0,0,0,0
-2511,0,0,0,0,0,0,0,0,0,0,0,0,0
-2512,0,0,0,0,0,0,0,0,0,0,0,0,0
-2513,0,0,0,0,0,0,0,0,0,0,0,0,0
-2514,0,0,0,0,0,0,0,0,0,0,0,0,0
-2515,0,0,0,0,0,0,0,0,0,0,0,0,0
-2516,0,0,0,0,0,0,0,0,0,0,0,0,0
-2517,0,0,0,0,0,0,0,0,0,0,0,0,0
-2518,0,0,0,0,0,0,0,0,0,0,0,0,0
-2519,0,0,0,0,0,0,0,0,0,0,0,0,0
-2520,0,0,0,0,0,0,0,0,0,0,0,0,0
-2521,0,0,0,0,0,0,0,0,0,0,0,0,0
-2522,0,0,0,0,0,0,0,0,0,0,0,0,0
-2523,0,0,0,0,0,0,0,0,0,0,0,0,0
-2524,0,0,0,0,0,0,0,0,0,0,0,0,0
-2525,0,0,0,0,0,0,0,0,0,0,0,0,0
-2526,0,0,0,0,0,0,0,0,0,0,0,0,0
-2527,0,0,0,0,0,0,0,0,0,0,0,0,0
-2528,0,0,0,0,0,0,0,0,0,0,0,0,0
-2529,0,0,0,0,0,0,0,0,0,0,0,0,0
-2530,0,0,0,0,0,0,0,0,0,0,0,0,0
-2531,0,0,0,0,0,0,0,0,0,0,0,0,0
-2532,0,0,0,0,0,0,0,0,0,0,0,0,0
-2533,0,0,0,0,0,0,0,0,0,0,0,0,0
-2534,0,0,0,0,0,0,0,0,0,0,0,0,0
-2535,0,0,0,0,0,0,0,0,0,0,0,0,0
-2536,0,0,0,0,0,0,0,0,0,0,0,0,0
-2537,0,0,0,0,0,0,0,0,0,0,0,0,0
-2538,0,0,0,0,0,0,0,0,0,0,0,0,0
-2539,0,0,0,0,0,0,0,0,0,0,0,0,0
-2540,0,0,0,0,0,0,0,0,0,0,0,0,0
-2541,0,0,0,0,0,0,0,0,0,0,0,0,0
-2542,0,0,0,0,0,0,0,0,0,0,0,0,0
-2543,0,0,0,0,0,0,0,0,0,0,0,0,0
-2544,0,0,0,0,0,0,0,0,0,0,0,0,0
-2545,0,0,0,0,0,0,0,0,0,0,0,0,0
-2546,0,0,0,0,0,0,0,0,0,0,0,0,0
-2547,0,0,0,0,0,0,0,0,0,0,0,0,0
-2548,0,0,0,0,0,0,0,0,0,0,0,0,0
-2549,0,0,0,0,0,0,0,0,0,0,0,0,0
-2550,0,0,0,0,0,0,0,0,0,0,0,0,0
-2551,0,0,0,0,0,0,0,0,0,0,0,0,0
-2552,0,0,0,0,0,0,0,0,0,0,0,0,0
-2553,0,0,0,0,0,0,0,0,0,0,0,0,0
-2554,0,0,0,0,0,0,0,0,0,0,0,0,0
-2555,0,0,0,0,0,0,0,0,0,0,0,0,0
-2556,0,0,0,0,0,0,0,0,0,0,0,0,0
-2557,0,0,0,0,0,0,0,0,0,0,0,0,0
-2558,0,0,0,0,0,0,0,0,0,0,0,0,0
-2559,0,0,0,0,0,0,0,0,0,0,0,0,0
-2560,0,0,0,0,0,0,0,0,0,0,0,0,0
-2561,0,0,0,0,0,0,0,0,0,0,0,0,0
-2562,0,0,0,0,0,0,0,0,0,0,0,0,0
-2563,0,0,0,0,0,0,0,0,0,0,0,0,0
-2564,0,0,0,0,0,0,0,0,0,0,0,0,0
-2565,0,0,0,0,0,0,0,0,0,0,0,0,0
-2566,0,0,0,0,0,0,0,0,0,0,0,0,0
-2567,0,0,0,0,0,0,0,0,0,0,0,0,0
-2568,0,0,0,0,0,0,0,0,0,0,0,0,0
-2569,0,0,0,0,0,0,0,0,0,0,0,0,0
-2570,0,0,0,0,0,0,0,0,0,0,0,0,0
-2571,0,0,0,0,0,0,0,0,0,0,0,0,0
-2572,0,0,0,0,0,0,0,0,0,0,0,0,0
-2573,0,0,0,0,0,0,0,0,0,0,0,0,0
-2574,0,0,0,0,0,0,0,0,0,0,0,0,0
-2575,0,0,0,0,0,0,0,0,0,0,0,0,0
-2576,0,0,0,0,0,0,0,0,0,0,0,0,0
-2577,0,0,0,0,0,0,0,0,0,0,0,0,0
-2578,0,0,0,0,0,0,0,0,0,0,0,0,0
-2579,0,0,0,0,0,0,0,0,0,0,0,0,0
-2580,0,0,0,0,0,0,0,0,0,0,0,0,0
-2581,0,0,0,0,0,0,0,0,0,0,0,0,0
-2582,0,0,0,0,0,0,0,0,0,0,0,0,0
-2583,0,0,0,0,0,0,0,0,0,0,0,0,0
-2584,0,0,0,0,0,0,0,0,0,0,0,0,0
-2585,0,0,0,0,0,0,0,0,0,0,0,0,0
-2586,0,0,0,0,0,0,0,0,0,0,0,0,0
-2587,0,0,0,0,0,0,0,0,0,0,0,0,0
-2588,0,0,0,0,0,0,0,0,0,0,0,0,0
-2589,0,0,0,0,0,0,0,0,0,0,0,0,0
-2590,0,0,0,0,0,0,0,0,0,0,0,0,0
-2591,0,0,0,0,0,0,0,0,0,0,0,0,0
-2592,0,0,0,0,0,0,0,0,0,0,0,0,0
-2593,0,0,0,0,0,0,0,0,0,0,0,0,0
-2594,0,0,0,0,0,0,0,0,0,0,0,0,0
-2595,0,0,0,0,0,0,0,0,0,0,0,0,0
-2596,0,0,0,0,0,0,0,0,0,0,0,0,0
-2597,0,0,0,0,0,0,0,0,0,0,0,0,0
-2598,0,0,0,0,0,0,0,0,0,0,0,0,0
-2599,0,0,0,0,0,0,0,0,0,0,0,0,0
-2600,0,0,0,0,0,0,0,0,0,0,0,0,0
+SR_WL,S2A_SR_AV_B1,S2A_SR_AV_B2,S2A_SR_AV_B3,S2A_SR_AV_B4,S2A_SR_AV_B5,S2A_SR_AV_B6,S2A_SR_AV_B7,S2A_SR_AV_B8,S2A_SR_AV_B8A,S2A_SR_AV_B9,S2A_SR_AV_B10,S2A_SR_AV_B11,S2A_SR_AV_B12
+300,0,0,0,0,0,0,0,0,0,0,0,0,0
+301,0,0,0,0,0,0,0,0,0,0,0,0,0
+302,0,0,0,0,0,0,0,0,0,0,0,0,0
+303,0,0,0,0,0,0,0,0,0,0,0,0,0
+304,0,0,0,0,0,0,0,0,0,0,0,0,0
+305,0,0,0,0,0,0,0,0,0,0,0,0,0
+306,0,0,0,0,0,0,0,0,0,0,0,0,0
+307,0,0,0,0,0,0,0,0,0,0,0,0,0
+308,0,0,0,0,0,0,0,0,0,0,0,0,0
+309,0,0,0,0,0,0,0,0,0,0,0,0,0
+310,0,0,0,0,0,0,0,0,0,0,0,0,0
+311,0,0,0,0,0,0,0,0,0,0,0,0,0
+312,0,0,0,0,0,0,0,0,0,0,0,0,0
+313,0,0,0,0,0,0,0,0,0,0,0,0,0
+314,0,0,0,0,0,0,0,0,0,0,0,0,0
+315,0,0,0,0,0,0,0,0,0,0,0,0,0
+316,0,0,0,0,0,0,0,0,0,0,0,0,0
+317,0,0,0,0,0,0,0,0,0,0,0,0,0
+318,0,0,0,0,0,0,0,0,0,0,0,0,0
+319,0,0,0,0,0,0,0,0,0,0,0,0,0
+320,0,0,0,0,0,0,0,0,0,0,0,0,0
+321,0,0,0,0,0,0,0,0,0,0,0,0,0
+322,0,0,0,0,0,0,0,0,0,0,0,0,0
+323,0,0,0,0,0,0,0,0,0,0,0,0,0
+324,0,0,0,0,0,0,0,0,0,0,0,0,0
+325,0,0,0,0,0,0,0,0,0,0,0,0,0
+326,0,0,0,0,0,0,0,0,0,0,0,0,0
+327,0,0,0,0,0,0,0,0,0,0,0,0,0
+328,0,0,0,0,0,0,0,0,0,0,0,0,0
+329,0,0,0,0,0,0,0,0,0,0,0,0,0
+330,0,0,0,0,0,0,0,0,0,0,0,0,0
+331,0,0,0,0,0,0,0,0,0,0,0,0,0
+332,0,0,0,0,0,0,0,0,0,0,0,0,0
+333,0,0,0,0,0,0,0,0,0,0,0,0,0
+334,0,0,0,0,0,0,0,0,0,0,0,0,0
+335,0,0,0,0,0,0,0,0,0,0,0,0,0
+336,0,0,0,0,0,0,0,0,0,0,0,0,0
+337,0,0,0,0,0,0,0,0,0,0,0,0,0
+338,0,0,0,0,0,0,0,0,0,0,0,0,0
+339,0,0,0,0,0,0,0,0,0,0,0,0,0
+340,0,0,0,0,0,0,0,0,0,0,0,0,0
+341,0,0,0,0,0,0,0,0,0,0,0,0,0
+342,0,0,0,0,0,0,0,0,0,0,0,0,0
+343,0,0,0,0,0,0,0,0,0,0,0,0,0
+344,0,0,0,0,0,0,0,0,0,0,0,0,0
+345,0,0,0,0,0,0,0,0,0,0,0,0,0
+346,0,0,0,0,0,0,0,0,0,0,0,0,0
+347,0,0,0,0,0,0,0,0,0,0,0,0,0
+348,0,0,0,0,0,0,0,0,0,0,0,0,0
+349,0,0,0,0,0,0,0,0,0,0,0,0,0
+350,0,0,0,0,0,0,0,0,0,0,0,0,0
+351,0,0,0,0,0,0,0,0,0,0,0,0,0
+352,0,0,0,0,0,0,0,0,0,0,0,0,0
+353,0,0,0,0,0,0,0,0,0,0,0,0,0
+354,0,0,0,0,0,0,0,0,0,0,0,0,0
+355,0,0,0,0,0,0,0,0,0,0,0,0,0
+356,0,0,0,0,0,0,0,0,0,0,0,0,0
+357,0,0,0,0,0,0,0,0,0,0,0,0,0
+358,0,0,0,0,0,0,0,0,0,0,0,0,0
+359,0,0,0,0,0,0,0,0,0,0,0,0,0
+360,0,0,0,0,0,0,0,0,0,0,0,0,0
+361,0,0,0,0,0,0,0,0,0,0,0,0,0
+362,0,0,0,0,0,0,0,0,0,0,0,0,0
+363,0,0,0,0,0,0,0,0,0,0,0,0,0
+364,0,0,0,0,0,0,0,0,0,0,0,0,0
+365,0,0,0,0,0,0,0,0,0,0,0,0,0
+366,0,0,0,0,0,0,0,0,0,0,0,0,0
+367,0,0,0,0,0,0,0,0,0,0,0,0,0
+368,0,0,0,0,0,0,0,0,0,0,0,0,0
+369,0,0,0,0,0,0,0,0,0,0,0,0,0
+370,0,0,0,0,0,0,0,0,0,0,0,0,0
+371,0,0,0,0,0,0,0,0,0,0,0,0,0
+372,0,0,0,0,0,0,0,0,0,0,0,0,0
+373,0,0,0,0,0,0,0,0,0,0,0,0,0
+374,0,0,0,0,0,0,0,0,0,0,0,0,0
+375,0,0,0,0,0,0,0,0,0,0,0,0,0
+376,0,0,0,0,0,0,0,0,0,0,0,0,0
+377,0,0,0,0,0,0,0,0,0,0,0,0,0
+378,0,0,0,0,0,0,0,0,0,0,0,0,0
+379,0,0,0,0,0,0,0,0,0,0,0,0,0
+380,0,0,0,0,0,0,0,0,0,0,0,0,0
+381,0,0,0,0,0,0,0,0,0,0,0,0,0
+382,0,0,0,0,0,0,0,0,0,0,0,0,0
+383,0,0,0,0,0,0,0,0,0,0,0,0,0
+384,0,0,0,0,0,0,0,0,0,0,0,0,0
+385,0,0,0,0,0,0,0,0,0,0,0,0,0
+386,0,0,0,0,0,0,0,0,0,0,0,0,0
+387,0,0,0,0,0,0,0,0,0,0,0,0,0
+388,0,0,0,0,0,0,0,0,0,0,0,0,0
+389,0,0,0,0,0,0,0,0,0,0,0,0,0
+390,0,0,0,0,0,0,0,0,0,0,0,0,0
+391,0,0,0,0,0,0,0,0,0,0,0,0,0
+392,0,0,0,0,0,0,0,0,0,0,0,0,0
+393,0,0,0,0,0,0,0,0,0,0,0,0,0
+394,0,0,0,0,0,0,0,0,0,0,0,0,0
+395,0,0,0,0,0,0,0,0,0,0,0,0,0
+396,0,0,0,0,0,0,0,0,0,0,0,0,0
+397,0,0,0,0,0,0,0,0,0,0,0,0,0
+398,0,0,0,0,0,0,0,0,0,0,0,0,0
+399,0,0,0,0,0,0,0,0,0,0,0,0,0
+400,0,0,0,0,0,0,0,0,0,0,0,0,0
+401,0,0,0,0,0,0,0,0,0,0,0,0,0
+402,0,0,0,0,0,0,0,0,0,0,0,0,0
+403,0,0,0,0,0,0,0,0,0,0,0,0,0
+404,0,0,0,0,0,0,0,0,0,0,0,0,0
+405,0,0,0,0,0,0,0,0,0,0,0,0,0
+406,0,0,0,0,0,0,0,0,0,0,0,0,0
+407,0,0,0,0,0,0,0,0,0,0,0,0,0
+408,0,0,0,0,0,0,0,0,0,0,0,0,0
+409,0,0,0,0,0,0,0,0,0,0,0,0,0
+410,0,0,0,0,0,0,0,0,0,0,0,0,0
+411,0,0,0,0,0,0,0,0,0,0,0,0,0
+412,0.001775742,0,0,0,0,0,0,0,0,0,0,0,0
+413,0.004073061,0,0,0,0,0,0,0,0,0,0,0,0
+414,0.003626143,0,0,0,0,0,0,0,0,0,0,0,0
+415,0.003515199,0,0,0,0,0,0,0,0,0,0,0,0
+416,0.005729163,0,0,0,0,0,0,0,0,0,0,0,0
+417,0.003780292,0,0,0,0,0,0,0,0,0,0,0,0
+418,0.002636732,0,0,0,0,0,0,0,0,0,0,0,0
+419,0.001262113,0,0,0,0,0,0,0,0,0,0,0,0
+420,0.001987583,0,0,0,0,0,0,0,0,0,0,0,0
+421,0.001368913,0,0,0,0,0,0,0,0,0,0,0,0
+422,0.001250444,0,0,0,0,0,0,0,0,0,0,0,0
+423,0.000463454,0,0,0,0,0,0,0,0,0,0,0,0
+424,0.000814293,0,0,0,0,0,0,0,0,0,0,0,0
+425,0.001376431,0,0,0,0,0,0,0,0,0,0,0,0
+426,0.001485086,0,0,0,0,0,0,0,0,0,0,0,0
+427,0.001823735,0,0,0,0,0,0,0,0,0,0,0,0
+428,0.001626817,0,0,0,0,0,0,0,0,0,0,0,0
+429,0.004392062,0,0,0,0,0,0,0,0,0,0,0,0
+430,0.029008099,0,0,0,0,0,0,0,0,0,0,0,0
+431,0.118745933,0,0,0,0,0,0,0,0,0,0,0,0
+432,0.323875058,0,0,0,0,0,0,0,0,0,0,0,0
+433,0.572819207,0,0,0,0,0,0,0,0,0,0,0,0
+434,0.714727494,0,0,0,0,0,0,0,0,0,0,0,0
+435,0.761967778,0,0,0,0,0,0,0,0,0,0,0,0
+436,0.789297016,0,0,0,0,0,0,0,0,0,0,0,0
+437,0.808623866,0,0,0,0,0,0,0,0,0,0,0,0
+438,0.810893815,0,0,0,0,0,0,0,0,0,0,0,0
+439,0.824198756,0.010315429,0,0,0,0,0,0,0,0,0,0,0
+440,0.854158107,0.030041933,0,0,0,0,0,0,0,0,0,0,0
+441,0.870790877,0.026875891,0,0,0,0,0,0,0,0,0,0,0
+442,0.887310969,0.02414315,0,0,0,0,0,0,0,0,0,0,0
+443,0.926199242,0.020210064,0,0,0,0,0,0,0,0,0,0,0
+444,0.982281495,0.022693489,0,0,0,0,0,0,0,0,0,0,0
+445,1,0.024564087,0,0,0,0,0,0,0,0,0,0,0
+446,0.975238202,0.016667005,0,0,0,0,0,0,0,0,0,0,0
+447,0.93596338,0.021413132,0,0,0,0,0,0,0,0,0,0,0
+448,0.889971481,0.016144221,0,0,0,0,0,0,0,0,0,0,0
+449,0.850210477,0.021307208,0,0,0,0,0,0,0,0,0,0,0
+450,0.825694526,0.018466093,0,0,0,0,0,0,0,0,0,0,0
+451,0.783902388,0.018185017,0,0,0,0,0,0,0,0,0,0,0
+452,0.614174215,0.017679055,0,0,0,0,0,0,0,0,0,0,0
+453,0.330071087,0.019114826,0,0,0,0,0,0,0,0,0,0,0
+454,0.124108313,0.019246427,0,0,0,0,0,0,0,0,0,0,0
+455,0.04365694,0.027395745,0,0,0,0,0,0,0,0,0,0,0
+456,0.014749595,0.042555308,0,0,0,0,0,0,0,0,0,0,0
+457,0,0.072298295,0,0,0,0,0,0,0,0,0,0,0
+458,0,0.153743222,0,0,0,0,0,0,0,0,0,0,0
+459,0,0.32799225,0,0,0,0,0,0,0,0,0,0,0
+460,0,0.553367878,0,0,0,0,0,0,0,0,0,0,0
+461,0,0.710111663,0,0,0,0,0,0,0,0,0,0,0
+462,0,0.752851788,0,0,0,0,0,0,0,0,0,0,0
+463,0,0.75232691,0,0,0,0,0,0,0,0,0,0,0
+464,0,0.756680807,0,0,0,0,0,0,0,0,0,0,0
+465,0,0.763269482,0,0,0,0,0,0,0,0,0,0,0
+466,0,0.76239425,0,0,0,0,0,0,0,0,0,0,0
+467,0,0.785251503,0,0,0,0,0,0,0,0,0,0,0
+468,0,0.815466688,0,0,0,0,0,0,0,0,0,0,0
+469,0,0.861791756,0,0,0,0,0,0,0,0,0,0,0
+470,0,0.892825992,0,0,0,0,0,0,0,0,0,0,0
+471,0,0.919522103,0,0,0,0,0,0,0,0,0,0,0
+472,0,0.919006495,0,0,0,0,0,0,0,0,0,0,0
+473,0,0.913157536,0,0,0,0,0,0,0,0,0,0,0
+474,0,0.900353663,0,0,0,0,0,0,0,0,0,0,0
+475,0,0.889896935,0,0,0,0,0,0,0,0,0,0,0
+476,0,0.882324603,0,0,0,0,0,0,0,0,0,0,0
+477,0,0.876061177,0,0,0,0,0,0,0,0,0,0,0
+478,0,0.884299872,0,0,0,0,0,0,0,0,0,0,0
+479,0,0.906955442,0,0,0,0,0,0,0,0,0,0,0
+480,0,0.932320853,0,0,0,0,0,0,0,0,0,0,0
+481,0,0.939472521,0,0,0,0,0,0,0,0,0,0,0
+482,0,0.943835429,0,0,0,0,0,0,0,0,0,0,0
+483,0,0.922040861,0,0,0,0,0,0,0,0,0,0,0
+484,0,0.886023105,0,0,0,0,0,0,0,0,0,0,0
+485,0,0.847436088,0,0,0,0,0,0,0,0,0,0,0
+486,0,0.812516871,0,0,0,0,0,0,0,0,0,0,0
+487,0,0.782397097,0,0,0,0,0,0,0,0,0,0,0
+488,0,0.7731087,0,0,0,0,0,0,0,0,0,0,0
+489,0,0.772090538,0,0,0,0,0,0,0,0,0,0,0
+490,0,0.787426523,0,0,0,0,0,0,0,0,0,0,0
+491,0,0.812171771,0,0,0,0,0,0,0,0,0,0,0
+492,0,0.846050519,0,0,0,0,0,0,0,0,0,0,0
+493,0,0.887679959,0,0,0,0,0,0,0,0,0,0,0
+494,0,0.927939973,0,0,0,0,0,0,0,0,0,0,0
+495,0,0.950692347,0,0,0,0,0,0,0,0,0,0,0
+496,0,0.965733107,0,0,0,0,0,0,0,0,0,0,0
+497,0,0.969382533,0,0,0,0,0,0,0,0,0,0,0
+498,0,0.965702943,0,0,0,0,0,0,0,0,0,0,0
+499,0,0.95832003,0,0,0,0,0,0,0,0,0,0,0
+500,0,0.954050638,0,0,0,0,0,0,0,0,0,0,0
+501,0,0.951782684,0,0,0,0,0,0,0,0,0,0,0
+502,0,0.956997215,0,0,0,0,0,0,0,0,0,0,0
+503,0,0.965565145,0,0,0,0,0,0,0,0,0,0,0
+504,0,0.977051397,0,0,0,0,0,0,0,0,0,0,0
+505,0,0.977095739,0,0,0,0,0,0,0,0,0,0,0
+506,0,0.974366055,0,0,0,0,0,0,0,0,0,0,0
+507,0,0.959031834,0,0,0,0,0,0,0,0,0,0,0
+508,0,0.935063176,0,0,0,0,0,0,0,0,0,0,0
+509,0,0.90190134,0,0,0,0,0,0,0,0,0,0,0
+510,0,0.871657924,0,0,0,0,0,0,0,0,0,0,0
+511,0,0.844024435,0,0,0,0,0,0,0,0,0,0,0
+512,0,0.822808519,0,0,0,0,0,0,0,0,0,0,0
+513,0,0.815360426,0,0,0,0,0,0,0,0,0,0,0
+514,0,0.820576391,0,0,0,0,0,0,0,0,0,0,0
+515,0,0.839514898,0,0,0,0,0,0,0,0,0,0,0
+516,0,0.86992171,0,0,0,0,0,0,0,0,0,0,0
+517,0,0.915262055,0,0,0,0,0,0,0,0,0,0,0
+518,0,0.960670278,0,0,0,0,0,0,0,0,0,0,0
+519,0,0.991636995,0,0,0,0,0,0,0,0,0,0,0
+520,0,1,0,0,0,0,0,0,0,0,0,0,0
+521,0,0.98356097,0,0,0,0,0,0,0,0,0,0,0
+522,0,0.91130763,0,0,0,0,0,0,0,0,0,0,0
+523,0,0.740182556,0,0,0,0,0,0,0,0,0,0,0
+524,0,0.503958576,0,0,0,0,0,0,0,0,0,0,0
+525,0,0.305015502,0,0,0,0,0,0,0,0,0,0,0
+526,0,0.180046045,0,0,0,0,0,0,0,0,0,0,0
+527,0,0.107383424,0,0,0,0,0,0,0,0,0,0,0
+528,0,0.06593592,0,0,0,0,0,0,0,0,0,0,0
+529,0,0.042077455,0,0,0,0,0,0,0,0,0,0,0
+530,0,0.026621288,0,0,0,0,0,0,0,0,0,0,0
+531,0,0.0143396,0,0,0,0,0,0,0,0,0,0,0
+532,0,0.002657787,0,0,0,0,0,0,0,0,0,0,0
+533,0,0.000818224,0,0,0,0,0,0,0,0,0,0,0
+534,0,0,0,0,0,0,0,0,0,0,0,0,0
+535,0,0,0,0,0,0,0,0,0,0,0,0,0
+536,0,0,0,0,0,0,0,0,0,0,0,0,0
+537,0,0,0,0,0,0,0,0,0,0,0,0,0
+538,0,0,0.014481812,0,0,0,0,0,0,0,0,0,0
+539,0,0,0.034222507,0,0,0,0,0,0,0,0,0,0
+540,0,0,0.073463348,0,0,0,0,0,0,0,0,0,0
+541,0,0,0.154448431,0,0,0,0,0,0,0,0,0,0
+542,0,0,0.316614247,0,0,0,0,0,0,0,0,0,0
+543,0,0,0.553222787,0,0,0,0,0,0,0,0,0,0
+544,0,0,0.748594059,0,0,0,0,0,0,0,0,0,0
+545,0,0,0.848903056,0,0,0,0,0,0,0,0,0,0
+546,0,0,0.897722157,0,0,0,0,0,0,0,0,0,0
+547,0,0,0.921536798,0,0,0,0,0,0,0,0,0,0
+548,0,0,0.925728454,0,0,0,0,0,0,0,0,0,0
+549,0,0,0.911226879,0,0,0,0,0,0,0,0,0,0
+550,0,0,0.888189237,0,0,0,0,0,0,0,0,0,0
+551,0,0,0.865237556,0,0,0,0,0,0,0,0,0,0
+552,0,0,0.84718187,0,0,0,0,0,0,0,0,0,0
+553,0,0,0.838757201,0,0,0,0,0,0,0,0,0,0
+554,0,0,0.844590812,0,0,0,0,0,0,0,0,0,0
+555,0,0,0.862196533,0,0,0,0,0,0,0,0,0,0
+556,0,0,0.888387136,0,0,0,0,0,0,0,0,0,0
+557,0,0,0.924432355,0,0,0,0,0,0,0,0,0,0
+558,0,0,0.96017974,0,0,0,0,0,0,0,0,0,0
+559,0,0,0.986855165,0,0,0,0,0,0,0,0,0,0
+560,0,0,1,0,0,0,0,0,0,0,0,0,0
+561,0,0,0.998600802,0,0,0,0,0,0,0,0,0,0
+562,0,0,0.980764717,0,0,0,0,0,0,0,0,0,0
+563,0,0,0.945220892,0,0,0,0,0,0,0,0,0,0
+564,0,0,0.898177804,0,0,0,0,0,0,0,0,0,0
+565,0,0,0.855803233,0,0,0,0,0,0,0,0,0,0
+566,0,0,0.818417342,0,0,0,0,0,0,0,0,0,0
+567,0,0,0.788620476,0,0,0,0,0,0,0,0,0,0
+568,0,0,0.764606533,0,0,0,0,0,0,0,0,0,0
+569,0,0,0.749637446,0,0,0,0,0,0,0,0,0,0
+570,0,0,0.75055111,0,0,0,0,0,0,0,0,0,0
+571,0,0,0.761378883,0,0,0,0,0,0,0,0,0,0
+572,0,0,0.782444788,0,0,0,0,0,0,0,0,0,0
+573,0,0,0.798900864,0,0,0,0,0,0,0,0,0,0
+574,0,0,0.810169565,0,0,0,0,0,0,0,0,0,0
+575,0,0,0.814088864,0,0,0,0,0,0,0,0,0,0
+576,0,0,0.773585961,0,0,0,0,0,0,0,0,0,0
+577,0,0,0.628810649,0,0,0,0,0,0,0,0,0,0
+578,0,0,0.403975549,0,0,0,0,0,0,0,0,0,0
+579,0,0,0.215420982,0,0,0,0,0,0,0,0,0,0
+580,0,0,0.107152815,0,0,0,0,0,0,0,0,0,0
+581,0,0,0.047928768,0,0,0,0,0,0,0,0,0,0
+582,0,0,0.01848693,0,0,0,0,0,0,0,0,0,0
+583,0,0,0.001085875,0,0,0,0,0,0,0,0,0,0
+584,0,0,0,0,0,0,0,0,0,0,0,0,0
+585,0,0,0,0,0,0,0,0,0,0,0,0,0
+586,0,0,0,0,0,0,0,0,0,0,0,0,0
+587,0,0,0,0,0,0,0,0,0,0,0,0,0
+588,0,0,0,0,0,0,0,0,0,0,0,0,0
+589,0,0,0,0,0,0,0,0,0,0,0,0,0
+590,0,0,0,0,0,0,0,0,0,0,0,0,0
+591,0,0,0,0,0,0,0,0,0,0,0,0,0
+592,0,0,0,0,0,0,0,0,0,0,0,0,0
+593,0,0,0,0,0,0,0,0,0,0,0,0,0
+594,0,0,0,0,0,0,0,0,0,0,0,0,0
+595,0,0,0,0,0,0,0,0,0,0,0,0,0
+596,0,0,0,0,0,0,0,0,0,0,0,0,0
+597,0,0,0,0,0,0,0,0,0,0,0,0,0
+598,0,0,0,0,0,0,0,0,0,0,0,0,0
+599,0,0,0,0,0,0,0,0,0,0,0,0,0
+600,0,0,0,0,0,0,0,0,0,0,0,0,0
+601,0,0,0,0,0,0,0,0,0,0,0,0,0
+602,0,0,0,0,0,0,0,0,0,0,0,0,0
+603,0,0,0,0,0,0,0,0,0,0,0,0,0
+604,0,0,0,0,0,0,0,0,0,0,0,0,0
+605,0,0,0,0,0,0,0,0,0,0,0,0,0
+606,0,0,0,0,0,0,0,0,0,0,0,0,0
+607,0,0,0,0,0,0,0,0,0,0,0,0,0
+608,0,0,0,0,0,0,0,0,0,0,0,0,0
+609,0,0,0,0,0,0,0,0,0,0,0,0,0
+610,0,0,0,0,0,0,0,0,0,0,0,0,0
+611,0,0,0,0,0,0,0,0,0,0,0,0,0
+612,0,0,0,0,0,0,0,0,0,0,0,0,0
+613,0,0,0,0,0,0,0,0,0,0,0,0,0
+614,0,0,0,0,0,0,0,0,0,0,0,0,0
+615,0,0,0,0,0,0,0,0,0,0,0,0,0
+616,0,0,0,0,0,0,0,0,0,0,0,0,0
+617,0,0,0,0,0,0,0,0,0,0,0,0,0
+618,0,0,0,0,0,0,0,0,0,0,0,0,0
+619,0,0,0,0,0,0,0,0,0,0,0,0,0
+620,0,0,0,0,0,0,0,0,0,0,0,0,0
+621,0,0,0,0,0,0,0,0,0,0,0,0,0
+622,0,0,0,0,0,0,0,0,0,0,0,0,0
+623,0,0,0,0,0,0,0,0,0,0,0,0,0
+624,0,0,0,0,0,0,0,0,0,0,0,0,0
+625,0,0,0,0,0,0,0,0,0,0,0,0,0
+626,0,0,0,0,0,0,0,0,0,0,0,0,0
+627,0,0,0,0,0,0,0,0,0,0,0,0,0
+628,0,0,0,0,0,0,0,0,0,0,0,0,0
+629,0,0,0,0,0,0,0,0,0,0,0,0,0
+630,0,0,0,0,0,0,0,0,0,0,0,0,0
+631,0,0,0,0,0,0,0,0,0,0,0,0,0
+632,0,0,0,0,0,0,0,0,0,0,0,0,0
+633,0,0,0,0,0,0,0,0,0,0,0,0,0
+634,0,0,0,0,0,0,0,0,0,0,0,0,0
+635,0,0,0,0,0,0,0,0,0,0,0,0,0
+636,0,0,0,0,0,0,0,0,0,0,0,0,0
+637,0,0,0,0,0,0,0,0,0,0,0,0,0
+638,0,0,0,0,0,0,0,0,0,0,0,0,0
+639,0,0,0,0,0,0,0,0,0,0,0,0,0
+640,0,0,0,0,0,0,0,0,0,0,0,0,0
+641,0,0,0,0,0,0,0,0,0,0,0,0,0
+642,0,0,0,0,0,0,0,0,0,0,0,0,0
+643,0,0,0,0,0,0,0,0,0,0,0,0,0
+644,0,0,0,0,0,0,0,0,0,0,0,0,0
+645,0,0,0,0,0,0,0,0,0,0,0,0,0
+646,0,0,0,0.001415212,0,0,0,0,0,0,0,0,0
+647,0,0,0,0.025902381,0,0,0,0,0,0,0,0,0
+648,0,0,0,0.116511775,0,0,0,0,0,0,0,0,0
+649,0,0,0,0.390886162,0,0,0,0,0,0,0,0,0
+650,0,0,0,0.749593421,0,0,0,0,0,0,0,0,0
+651,0,0,0,0.944858051,0,0,0,0,0,0,0,0,0
+652,0,0,0,0.980111731,0,0,0,0,0,0,0,0,0
+653,0,0,0,0.994063086,0,0,0,0,0,0,0,0,0
+654,0,0,0,1,0,0,0,0,0,0,0,0,0
+655,0,0,0,0.995454747,0,0,0,0,0,0,0,0,0
+656,0,0,0,0.990527717,0,0,0,0,0,0,0,0,0
+657,0,0,0,0.977334762,0,0,0,0,0,0,0,0,0
+658,0,0,0,0.940559882,0,0,0,0,0,0,0,0,0
+659,0,0,0,0.878949559,0,0,0,0,0,0,0,0,0
+660,0,0,0,0.81629384,0,0,0,0,0,0,0,0,0
+661,0,0,0,0.773459516,0,0,0,0,0,0,0,0,0
+662,0,0,0,0.754487656,0,0,0,0,0,0,0,0,0
+663,0,0,0,0.75991531,0,0,0,0,0,0,0,0,0
+664,0,0,0,0.782634297,0,0,0,0,0,0,0,0,0
+665,0,0,0,0.8101689,0,0,0,0,0,0,0,0,0
+666,0,0,0,0.836129749,0,0,0,0,0,0,0,0,0
+667,0,0,0,0.861254237,0,0,0,0,0,0,0,0,0
+668,0,0,0,0.886091059,0,0,0,0,0,0,0,0,0
+669,0,0,0,0.911387666,0,0,0,0,0,0,0,0,0
+670,0,0,0,0.934051464,0,0,0,0,0,0,0,0,0
+671,0,0,0,0.950420633,0,0,0,0,0,0,0,0,0
+672,0,0,0,0.959257302,0,0,0,0,0,0,0,0,0
+673,0,0,0,0.960395551,0,0,0,0,0,0,0,0,0
+674,0,0,0,0.959133945,0,0,0,0,0,0,0,0,0
+675,0,0,0,0.958090128,0,0,0,0,0,0,0,0,0
+676,0,0,0,0.955274589,0,0,0,0,0,0,0,0,0
+677,0,0,0,0.943764654,0,0,0,0,0,0,0,0,0
+678,0,0,0,0.894907986,0,0,0,0,0,0,0,0,0
+679,0,0,0,0.744263079,0,0,0,0,0,0,0,0,0
+680,0,0,0,0.476777001,0,0,0,0,0,0,0,0,0
+681,0,0,0,0.229603988,0,0,0,0,0,0,0,0,0
+682,0,0,0,0.080091177,0,0,0,0,0,0,0,0,0
+683,0,0,0,0.026170762,0,0,0,0,0,0,0,0,0
+684,0,0,0,0.004152419,0,0,0,0,0,0,0,0,0
+685,0,0,0,0,0,0,0,0,0,0,0,0,0
+686,0,0,0,0,0,0,0,0,0,0,0,0,0
+687,0,0,0,0,0,0,0,0,0,0,0,0,0
+688,0,0,0,0,0,0,0,0,0,0,0,0,0
+689,0,0,0,0,0,0,0,0,0,0,0,0,0
+690,0,0,0,0,0,0,0,0,0,0,0,0,0
+691,0,0,0,0,0,0,0,0,0,0,0,0,0
+692,0,0,0,0,0,0,0,0,0,0,0,0,0
+693,0,0,0,0,0,0,0,0,0,0,0,0,0
+694,0,0,0,0,,0,0,0,0,0,0,0,0
+695,0,0,0,0,0.028357856,0,0,0,0,0,0,0,0
+696,0,0,0,0,0.123693367,0,0,0,0,0,0,0,0
+697,0,0,0,0,0.393787739,0,0,0,0,0,0,0,0
+698,0,0,0,0,0.761130707,0,0,0,0,0,0,0,0
+699,0,0,0,0,0.971085018,0,0,0,0,0,0,0,0
+700,0,0,0,0,0.998895232,0,0,0,0,0,0,0,0
+701,0,0,0,0,1,0,0,0,0,0,0,0,0
+702,0,0,0,0,0.994122578,0,0,0,0,0,0,0,0
+703,0,0,0,0,0.983217889,0,0,0,0,0,0,0,0
+704,0,0,0,0,0.967040926,0,0,0,0,0,0,0,0
+705,0,0,0,0,0.948473886,0,0,0,0,0,0,0,0
+706,0,0,0,0,0.92714833,0,0,0,0,0,0,0,0
+707,0,0,0,0,0.903724584,0,0,0,0,0,0,0,0
+708,0,0,0,0,0.886147127,0,0,0,0,0,0,0,0
+709,0,0,0,0,0.867237453,0,0,0,0,0,0,0,0
+710,0,0,0,0,0.790753191,0,0,0,0,0,0,0,0
+711,0,0,0,0,0.588403315,0,0,0,0,0,0,0,0
+712,0,0,0,0,0.263348326,0,0,0,0,0,0,0,0
+713,0,0,0,0,0.056754223,0,0,0,0,0,0,0,0
+714,0,0,0,0,0.006188334,0,0,0,0,0,0,0,0
+715,0,0,0,0,0,0,0,0,0,0,0,0,0
+716,0,0,0,0,0,0,0,0,0,0,0,0,0
+717,0,0,0,0,0,0,0,0,0,0,0,0,0
+718,0,0,0,0,0,0,0,0,0,0,0,0,0
+719,0,0,0,0,0,0,0,0,0,0,0,0,0
+720,0,0,0,0,0,0,0,0,0,0,0,0,0
+721,0,0,0,0,0,0,0,0,0,0,0,0,0
+722,0,0,0,0,0,0,0,0,0,0,0,0,0
+723,0,0,0,0,0,0,0,0,0,0,0,0,0
+724,0,0,0,0,0,0,0,0,0,0,0,0,0
+725,0,0,0,0,0,0,0,0,0,0,0,0,0
+726,0,0,0,0,0,0,0,0,0,0,0,0,0
+727,0,0,0,0,0,0,0,0,0,0,0,0,0
+728,0,0,0,0,0,0,0,0,0,0,0,0,0
+729,0,0,0,0,0,0,0,0,0,0,0,0,0
+730,0,0,0,0,0,0,0,0,0,0,0,0,0
+731,0,0,0,0,0,0.001710882,0,0,0,0,0,0,0
+732,0,0,0,0,0,0.054671525,0,0,0,0,0,0,0
+733,0,0,0,0,0,0.258066763,0,0,0,0,0,0,0
+734,0,0,0,0,0,0.647220984,0,0,0,0,0,0,0
+735,0,0,0,0,0,0.892189986,0,0,0,0,0,0,0
+736,0,0,0,0,0,0.902328766,0,0,0,0,0,0,0
+737,0,0,0,0,0,0.915087676,0,0,0,0,0,0,0
+738,0,0,0,0,0,0.941158459,0,0,0,0,0,0,0
+739,0,0,0,0,0,0.962999932,0,0,0,0,0,0,0
+740,0,0,0,0,0,0.975104812,0,0,0,0,0,0,0
+741,0,0,0,0,0,0.977021704,0,0,0,0,0,0,0
+742,0,0,0,0,0,0.987362514,0,0,0,0,0,0,0
+743,0,0,0,0,0,1,0,0,0,0,0,0,0
+744,0,0,0,0,0,0.988802771,0,0,0,0,0,0,0
+745,0,0,0,0,0,0.971799161,0,0,0,0,0,0,0
+746,0,0,0,0,0,0.901267389,0,0,0,0,0,0,0
+747,0,0,0,0,0,0.606723913,0,0,0,0,0,0,0
+748,0,0,0,0,0,0.205202268,0,0,0,0,0,0,0
+749,0,0,0,0,0,0.026756898,0,0,0,0,0,0,0
+750,0,0,0,0,0,0,0,0,0,0,0,0,0
+751,0,0,0,0,0,0,0,0,0,0,0,0,0
+752,0,0,0,0,0,0,0,0,0,0,0,0,0
+753,0,0,0,0,0,0,0,0,0,0,0,0,0
+754,0,0,0,0,0,0,0,0,0,0,0,0,0
+755,0,0,0,0,0,0,0,0,0,0,0,0,0
+756,0,0,0,0,0,0,0,0,0,0,0,0,0
+757,0,0,0,0,0,0,0,0,0,0,0,0,0
+758,0,0,0,0,0,0,0,0,0,0,0,0,0
+759,0,0,0,0,0,0,0,0,0,0,0,0,0
+760,0,0,0,0,0,0,0,0.000672587,0,0,0,0,0
+761,0,0,0,0,0,0,0,0.003888561,0,0,0,0,0
+762,0,0,0,0,0,0,0,0,0,0,0,0,0
+763,0,0,0,0,0,0,0,0,0,0,0,0,0
+764,0,0,0,0,0,0,0,0,0,0,0,0,0
+765,0,0,0,0,0,0,0,0,0,0,0,0,0
+766,0,0,0,0,0,0,0,0,0,0,0,0,0
+767,0,0,0,0,0,0,0,0,0,0,0,0,0
+768,0,0,0,0,0,0,0,0,0,0,0,0,0
+769,0,0,0,0,0,0,0.000458987,0,0,0,0,0,0
+770,0,0,0,0,0,0,0.011720097,0,0,0,0,0,0
+771,0,0,0,0,0,0,0.052197152,0,0,0,0,0,0
+772,0,0,0,0,0,0,0.165617326,0,0,0,0,0,0
+773,0,0,0,0,0,0,0.369033555,0.000289559,0,0,0,0,0
+774,0,0,0,0,0,0,0.636854532,0.00702964,0,0,0,0,0
+775,0,0,0,0,0,0,0.861196383,0.017523915,0,0,0,0,0
+776,0,0,0,0,0,0,0.970028971,0.032311111,0,0,0,0,0
+777,0,0,0,0,0,0,0.991196015,0.05328661,0,0,0,0,0
+778,0,0,0,0,0,0,0.998979212,0.082998852,0,0,0,0,0
+779,0,0,0,0,0,0,1,0.127485024,0,0,0,0,0
+780,0,0,0,0,0,0,0.97725155,0.195910652,0,0,0,0,0
+781,0,0,0,0,0,0,0.925723851,0.302463232,0,0,0,0,0
+782,0,0,0,0,0,0,0.86605804,0.435539537,0,0,0,0,0
+783,0,0,0,0,0,0,0.819696105,0.571416366,0,0,0,0,0
+784,0,0,0,0,0,0,0.794076736,0.697667008,0,0,0,0,0
+785,0,0,0,0,0,0,0.791110289,0.803038519,0,0,0,0,0
+786,0,0,0,0,0,0,0.804315523,0.891157437,0,0,0,0,0
+787,0,0,0,0,0,0,0.819027212,0.952845837,0,0,0,0,0
+788,0,0,0,0,0,0,0.825712924,0.988941605,0,0,0,0,0
+789,0,0,0,0,0,0,0.820118286,1,0,0,0,0,0
+790,0,0,0,0,0,0,0.792221951,0.988406528,0,0,0,0,0
+791,0,0,0,0,0,0,0.720545593,0.963892161,0,0,0,0,0
+792,0,0,0,0,0,0,0.587677944,0.942079674,0,0,0,0,0
+793,0,0,0,0,0,0,0.414303554,0.936946427,0,0,0,0,0
+794,0,0,0,0,0,0,0.230888169,0.942273429,0,0,0,0,0
+795,0,0,0,0,0,0,0.098502825,0.953957178,0,0,0,0,0
+796,0,0,0,0,0,0,0.027365511,0.968288956,0,0,0,0,0
+797,0,0,0,0,0,0,0.00516235,0.979665494,0,0,0,0,0
+798,0,0,0,0,0,0,0,0.985444404,0,0,0,0,0
+799,0,0,0,0,0,0,0,0.985926806,0,0,0,0,0
+800,0,0,0,0,0,0,0,0.983911811,0,0,0,0,0
+801,0,0,0,0,0,0,0,0.97793903,0,0,0,0,0
+802,0,0,0,0,0,0,0,0.977227714,0,0,0,0,0
+803,0,0,0,0,0,0,0,0.978106086,0,0,0,0,0
+804,0,0,0,0,0,0,0,0.981444864,0,0,0,0,0
+805,0,0,0,0,0,0,0,0.987645575,0,0,0,0,0
+806,0,0,0,0,0,0,0,0.988577078,0,0,0,0,0
+807,0,0,0,0,0,0,0,0.986242198,0,0,0,0,0
+808,0,0,0,0,0,0,0,0.980709208,0,0,0,0,0
+809,0,0,0,0,0,0,0,0.970786244,0,0,0,0,0
+810,0,0,0,0,0,0,0,0.957210894,0,0,0,0,0
+811,0,0,0,0,0,0,0,0.938658206,0,0,0,0,0
+812,0,0,0,0,0,0,0,0.91672388,0,0,0,0,0
+813,0,0,0,0,0,0,0,0.896207585,0,0,0,0,0
+814,0,0,0,0,0,0,0,0.872887998,0,0,0,0,0
+815,0,0,0,0,0,0,0,0.851603307,0,0,0,0,0
+816,0,0,0,0,0,0,0,0.824639396,0,0,0,0,0
+817,0,0,0,0,0,0,0,0.800781174,0,0,0,0,0
+818,0,0,0,0,0,0,0,0.782338598,0,0,0,0,0
+819,0,0,0,0,0,0,0,0.763602744,0,0,0,0,0
+820,0,0,0,0,0,0,0,0.749627707,0,0,0,0,0
+821,0,0,0,0,0,0,0,0.738722099,0,0,0,0,0
+822,0,0,0,0,0,0,0,0.730794069,0,0,0,0,0
+823,0,0,0,0,0,0,0,0.722712368,0,0,0,0,0
+824,0,0,0,0,0,0,0,0.725077084,0,0,0,0,0
+825,0,0,0,0,0,0,0,0.725638556,0,0,0,0,0
+826,0,0,0,0,0,0,0,0.723042174,0,0,0,0,0
+827,0,0,0,0,0,0,0,0.722292106,0,0,0,0,0
+828,0,0,0,0,0,0,0,0.716163645,0,0,0,0,0
+829,0,0,0,0,0,0,0,0.711594459,0,0,0,0,0
+830,0,0,0,0,0,0,0,0.708269542,0,0,0,0,0
+831,0,0,0,0,0,0,0,0.701572051,0,0,0,0,0
+832,0,0,0,0,0,0,0,0.699245321,0,0,0,0,0
+833,0,0,0,0,0,0,0,0.700937618,0,0,0,0,0
+834,0,0,0,0,0,0,0,0.706927327,0,0,0,0,0
+835,0,0,0,0,0,0,0,0.718240007,0,0,0,0,0
+836,0,0,0,0,0,0,0,0.731246343,0,0,0,0,0
+837,0,0,0,0,0,0,0,0.748406102,0.000300966,0,0,0,0
+838,0,0,0,0,0,0,0,0.76818541,0,0,0,0,0
+839,0,0,0,0,0,0,0,0.783948066,0,0,0,0,0
+840,0,0,0,0,0,0,0,0.7968381,0,0,0,0,0
+841,0,0,0,0,0,0,0,0.802602063,0,0,0,0,0
+842,0,0,0,0,0,0,0,0.804519396,0,0,0,0,0
+843,0,0,0,0,0,0,0,0.802409182,0,0,0,0,0
+844,0,0,0,0,0,0,0,0.796990717,0,0,0,0,0
+845,0,0,0,0,0,0,0,0.789203043,0,0,0,0,0
+846,0,0,0,0,0,0,0,0.776916211,0,0,0,0,0
+847,0,0,0,0,0,0,0,0.765184064,0.001572174,0,0,0,0
+848,0,0,0,0,0,0,0,0.751197174,0.002498858,0,0,0,0
+849,0,0,0,0,0,0,0,0.737003566,0.013320367,0,0,0,0
+850,0,0,0,0,0,0,0,0.722623995,0.026148658,0,0,0,0
+851,0,0,0,0,0,0,0,0.704125782,0.052604793,0,0,0,0
+852,0,0,0,0,0,0,0,0.684108046,0.107797093,0,0,0,0
+853,0,0,0,0,0,0,0,0.664745277,0.221607547,0,0,0,0
+854,0,0,0,0,0,0,0,0.647368908,0.39721628,0,0,0,0
+855,0,0,0,0,0,0,0,0.630051247,0.609868852,0,0,0,0
+856,0,0,0,0,0,0,0,0.615642224,0.816588834,0,0,0,0
+857,0,0,0,0,0,0,0,0.602495567,0.932244502,0,0,0,0
+858,0,0,0,0,0,0,0,0.589889921,0.972100329,0,0,0,0
+859,0,0,0,0,0,0,0,0.579933995,0.975454822,0,0,0,0
+860,0,0,0,0,0,0,0,0.571365058,0.975380485,0,0,0,0
+861,0,0,0,0,0,0,0,0.560942415,0.97328205,0,0,0,0
+862,0,0,0,0,0,0,0,0.552351052,0.976078281,0,0,0,0
+863,0,0,0,0,0,0,0,0.54568236,0.980349546,0,0,0,0
+864,0,0,0,0,0,0,0,0.539580517,0.986909276,0,0,0,0
+865,0,0,0,0,0,0,0,0.535102151,0.990874648,0,0,0,0
+866,0,0,0,0,0,0,0,0.530936751,0.997418177,0,0,0,0
+867,0,0,0,0,0,0,0,0.530165085,0.999846733,0,0,0,0
+868,0,0,0,0,0,0,0,0.52984662,0.999391415,0,0,0,0
+869,0,0,0,0,0,0,0,0.530366818,0.995879284,0,0,0,0
+870,0,0,0,0,0,0,0,0.532114628,0.995412276,0,0,0,0
+871,0,0,0,0,0,0,0,0.53271918,1,0,0,0,0
+872,0,0,0,0,0,0,0,0.532468057,0.996407621,0,0,0,0
+873,0,0,0,0,0,0,0,0.53331158,0.923594329,0,0,0,0
+874,0,0,0,0,0,0,0,0.531927797,0.741376842,0,0,0,0
+875,0,0,0,0,0,0,0,0.530510552,0.489659709,0,0,0,0
+876,0,0,0,0,0,0,0,0.52951499,0.25020643,0,0,0,0
+877,0,0,0,0,0,0,0,0.52996848,0.112212459,0,0,0,0
+878,0,0,0,0,0,0,0,0.532533725,0.047559844,0,0,0,0
+879,0,0,0,0,0,0,0,0.537050849,0.022978146,0,0,0,0
+880,0,0,0,0,0,0,0,0.542353442,0.010614375,0,0,0,0
+881,0,0,0,0,0,0,0,0.549124971,0.001081494,0,0,0,0
+882,0,0,0,0,0,0,0,0.555230551,0,0,0,0,0
+883,0,0,0,0,0,0,0,0.560111348,0,0,0,0,0
+884,0,0,0,0,0,0,0,0.557679988,0,0,0,0,0
+885,0,0,0,0,0,0,0,0.548219844,0,0,0,0,0
+886,0,0,0,0,0,0,0,0.531446128,0,0,0,0,0
+887,0,0,0,0,0,0,0,0.507635285,0,0,0,0,0
+888,0,0,0,0,0,0,0,0.478112241,0,0,0,0,0
+889,0,0,0,0,0,0,0,0.450927929,0,0,0,0,0
+890,0,0,0,0,0,0,0,0.427984659,0,0,0,0,0
+891,0,0,0,0,0,0,0,0.41051405,0,0,0,0,0
+892,0,0,0,0,0,0,0,0.400391391,0,0,0,0,0
+893,0,0,0,0,0,0,0,0.400873018,0,0,0,0,0
+894,0,0,0,0,0,0,0,0.40829375,0,0,0,0,0
+895,0,0,0,0,0,0,0,0.420865558,0,0,0,0,0
+896,0,0,0,0,0,0,0,0.430070218,0,0,0,0,0
+897,0,0,0,0,0,0,0,0.424566916,0,0,0,0,0
+898,0,0,0,0,0,0,0,0.391368172,0,0,0,0,0
+899,0,0,0,0,0,0,0,0.330090082,0,0,0,0,0
+900,0,0,0,0,0,0,0,0.257205092,0,0,0,0,0
+901,0,0,0,0,0,0,0,0.181890305,0,0,0,0,0
+902,0,0,0,0,0,0,0,0.116506681,0,0,0,0,0
+903,0,0,0,0,0,0,0,0.070315795,0,0,0,0,0
+904,0,0,0,0,0,0,0,0.042753811,0,0,0,0,0
+905,0,0,0,0,0,0,0,0.025931542,0,0,0,0,0
+906,0,0,0,0,0,0,0,0.015743939,0,0,0,0,0
+907,0,0,0,0,0,0,0,0.003943258,0,0,0,0,0
+908,0,0,0,0,0,0,0,0,0,0,0,0,0
+909,0,0,0,0,0,0,0,0,0,0,0,0,0
+910,0,0,0,0,0,0,0,0,0,0,0,0,0
+911,0,0,0,0,0,0,0,0,0,0,0,0,0
+912,0,0,0,0,0,0,0,0,0,0,0,0,0
+913,0,0,0,0,0,0,0,0,0,0,0,0,0
+914,0,0,0,0,0,0,0,0,0,0,0,0,0
+915,0,0,0,0,0,0,0,0,0,0,0,0,0
+916,0,0,0,0,0,0,0,0,0,0,0,0,0
+917,0,0,0,0,0,0,0,0,0,0,0,0,0
+918,0,0,0,0,0,0,0,0,0,0,0,0,0
+919,0,0,0,0,0,0,0,0,0,0,0,0,0
+920,0,0,0,0,0,0,0,0,0,0,0,0,0
+921,0,0,0,0,0,0,0,0,0,0,0,0,0
+922,0,0,0,0,0,0,0,0,0,0,0,0,0
+923,0,0,0,0,0,0,0,0,0,0,0,0,0
+924,0,0,0,0,0,0,0,0,0,0,0,0,0
+925,0,0,0,0,0,0,0,0,0,0,0,0,0
+926,0,0,0,0,0,0,0,0,0,0,0,0,0
+927,0,0,0,0,0,0,0,0,0,0,0,0,0
+928,0,0,0,0,0,0,0,0,0,0,0,0,0
+929,0,0,0,0,0,0,0,0,0,0,0,0,0
+930,0,0,0,0,0,0,0,0,0,0,0,0,0
+931,0,0,0,0,0,0,0,0,0,0,0,0,0
+932,0,0,0,0,0,0,0,0,0,0.016629527,0,0,0
+933,0,0,0,0,0,0,0,0,0,0.061118571,0,0,0
+934,0,0,0,0,0,0,0,0,0,0.174070942,0,0,0
+935,0,0,0,0,0,0,0,0,0,0.389464545,0,0,0
+936,0,0,0,0,0,0,0,0,0,0.664591498,0,0,0
+937,0,0,0,0,0,0,0,0,0,0.874541137,0,0,0
+938,0,0,0,0,0,0,0,0,0,0.936959878,0,0,0
+939,0,0,0,0,0,0,0,0,0,0.967510143,0,0,0
+940,0,0,0,0,0,0,0,0,0,0.989339103,0,0,0
+941,0,0,0,0,0,0,0,0,0,0.995126896,0,0,0
+942,0,0,0,0,0,0,0,0,0,1,0,0,0
+943,0,0,0,0,0,0,0,0,0,0.978457624,0,0,0
+944,0,0,0,0,0,0,0,0,0,0.980691181,0,0,0
+945,0,0,0,0,0,0,0,0,0,0.992233503,0,0,0
+946,0,0,0,0,0,0,0,0,0,0.987983794,0,0,0
+947,0,0,0,0,0,0,0,0,0,0.994283126,0,0,0
+948,0,0,0,0,0,0,0,0,0,0.983480409,0,0,0
+949,0,0,0,0,0,0,0,0,0,0.978200134,0,0,0
+950,0,0,0,0,0,0,0,0,0,0.950233675,0,0,0
+951,0,0,0,0,0,0,0,0,0,0.952996037,0,0,0
+952,0,0,0,0,0,0,0,0,0,0.922403082,0,0,0
+953,0,0,0,0,0,0,0,0,0,0.85573828,0,0,0
+954,0,0,0,0,0,0,0,0,0,0.709702275,0,0,0
+955,0,0,0,0,0,0,0,0,0,0.464295419,0,0,0
+956,0,0,0,0,0,0,0,0,0,0.215384267,0,0,0
+957,0,0,0,0,0,0,0,0,0,0.065341206,0,0,0
+958,0,0,0,0,0,0,0,0,0,0.016255961,0,0,0
+959,0,0,0,0,0,0,0,0,0,0,0,0,0
+960,0,0,0,0,0,0,0,0,0,0,0,0,0
+961,0,0,0,0,0,0,0,0,0,0,0,0,0
+962,0,0,0,0,0,0,0,0,0,0,0,0,0
+963,0,0,0,0,0,0,0,0,0,0,0,0,0
+964,0,0,0,0,0,0,0,0,0,0,0,0,0
+965,0,0,0,0,0,0,0,0,0,0,0,0,0
+966,0,0,0,0,0,0,0,0,0,0,0,0,0
+967,0,0,0,0,0,0,0,0,0,0,0,0,0
+968,0,0,0,0,0,0,0,0,0,0,0,0,0
+969,0,0,0,0,0,0,0,0,0,0,0,0,0
+970,0,0,0,0,0,0,0,0,0,0,0,0,0
+971,0,0,0,0,0,0,0,0,0,0,0,0,0
+972,0,0,0,0,0,0,0,0,0,0,0,0,0
+973,0,0,0,0,0,0,0,0,0,0,0,0,0
+974,0,0,0,0,0,0,0,0,0,0,0,0,0
+975,0,0,0,0,0,0,0,0,0,0,0,0,0
+976,0,0,0,0,0,0,0,0,0,0,0,0,0
+977,0,0,0,0,0,0,0,0,0,0,0,0,0
+978,0,0,0,0,0,0,0,0,0,0,0,0,0
+979,0,0,0,0,0,0,0,0,0,0,0,0,0
+980,0,0,0,0,0,0,0,0,0,0,0,0,0
+981,0,0,0,0,0,0,0,0,0,0,0,0,0
+982,0,0,0,0,0,0,0,0,0,0,0,0,0
+983,0,0,0,0,0,0,0,0,0,0,0,0,0
+984,0,0,0,0,0,0,0,0,0,0,0,0,0
+985,0,0,0,0,0,0,0,0,0,0,0,0,0
+986,0,0,0,0,0,0,0,0,0,0,0,0,0
+987,0,0,0,0,0,0,0,0,0,0,0,0,0
+988,0,0,0,0,0,0,0,0,0,0,0,0,0
+989,0,0,0,0,0,0,0,0,0,0,0,0,0
+990,0,0,0,0,0,0,0,0,0,0,0,0,0
+991,0,0,0,0,0,0,0,0,0,0,0,0,0
+992,0,0,0,0,0,0,0,0,0,0,0,0,0
+993,0,0,0,0,0,0,0,0,0,0,0,0,0
+994,0,0,0,0,0,0,0,0,0,0,0,0,0
+995,0,0,0,0,0,0,0,0,0,0,0,0,0
+996,0,0,0,0,0,0,0,0,0,0,0,0,0
+997,0,0,0,0,0,0,0,0,0,0,0,0,0
+998,0,0,0,0,0,0,0,0,0,0,0,0,0
+999,0,0,0,0,0,0,0,0,0,0,0,0,0
+1000,0,0,0,0,0,0,0,0,0,0,0,0,0
+1001,0,0,0,0,0,0,0,0,0,0,0,0,0
+1002,0,0,0,0,0,0,0,0,0,0,0,0,0
+1003,0,0,0,0,0,0,0,0,0,0,0,0,0
+1004,0,0,0,0,0,0,0,0,0,0,0,0,0
+1005,0,0,0,0,0,0,0,0,0,0,0,0,0
+1006,0,0,0,0,0,0,0,0,0,0,0,0,0
+1007,0,0,0,0,0,0,0,0,0,0,0,0,0
+1008,0,0,0,0,0,0,0,0,0,0,0,0,0
+1009,0,0,0,0,0,0,0,0,0,0,0,0,0
+1010,0,0,0,0,0,0,0,0,0,0,0,0,0
+1011,0,0,0,0,0,0,0,0,0,0,0,0,0
+1012,0,0,0,0,0,0,0,0,0,0,0,0,0
+1013,0,0,0,0,0,0,0,0,0,0,0,0,0
+1014,0,0,0,0,0,0,0,0,0,0,0,0,0
+1015,0,0,0,0,0,0,0,0,0,0,0,0,0
+1016,0,0,0,0,0,0,0,0,0,0,0,0,0
+1017,0,0,0,0,0,0,0,0,0,0,0,0,0
+1018,0,0,0,0,0,0,0,0,0,0,0,0,0
+1019,0,0,0,0,0,0,0,0,0,0,0,0,0
+1020,0,0,0,0,0,0,0,0,0,0,0,0,0
+1021,0,0,0,0,0,0,0,0,0,0,0,0,0
+1022,0,0,0,0,0,0,0,0,0,0,0,0,0
+1023,0,0,0,0,0,0,0,0,0,0,0,0,0
+1024,0,0,0,0,0,0,0,0,0,0,0,0,0
+1025,0,0,0,0,0,0,0,0,0,0,0,0,0
+1026,0,0,0,0,0,0,0,0,0,0,0,0,0
+1027,0,0,0,0,0,0,0,0,0,0,0,0,0
+1028,0,0,0,0,0,0,0,0,0,0,0,0,0
+1029,0,0,0,0,0,0,0,0,0,0,0,0,0
+1030,0,0,0,0,0,0,0,0,0,0,0,0,0
+1031,0,0,0,0,0,0,0,0,0,0,0,0,0
+1032,0,0,0,0,0,0,0,0,0,0,0,0,0
+1033,0,0,0,0,0,0,0,0,0,0,0,0,0
+1034,0,0,0,0,0,0,0,0,0,0,0,0,0
+1035,0,0,0,0,0,0,0,0,0,0,0,0,0
+1036,0,0,0,0,0,0,0,0,0,0,0,0,0
+1037,0,0,0,0,0,0,0,0,0,0,0,0,0
+1038,0,0,0,0,0,0,0,0,0,0,0,0,0
+1039,0,0,0,0,0,0,0,0,0,0,0,0,0
+1040,0,0,0,0,0,0,0,0,0,0,0,0,0
+1041,0,0,0,0,0,0,0,0,0,0,0,0,0
+1042,0,0,0,0,0,0,0,0,0,0,0,0,0
+1043,0,0,0,0,0,0,0,0,0,0,0,0,0
+1044,0,0,0,0,0,0,0,0,0,0,0,0,0
+1045,0,0,0,0,0,0,0,0,0,0,0,0,0
+1046,0,0,0,0,0,0,0,0,0,0,0,0,0
+1047,0,0,0,0,0,0,0,0,0,0,0,0,0
+1048,0,0,0,0,0,0,0,0,0,0,0,0,0
+1049,0,0,0,0,0,0,0,0,0,0,0,0,0
+1050,0,0,0,0,0,0,0,0,0,0,0,0,0
+1051,0,0,0,0,0,0,0,0,0,0,0,0,0
+1052,0,0,0,0,0,0,0,0,0,0,0,0,0
+1053,0,0,0,0,0,0,0,0,0,0,0,0,0
+1054,0,0,0,0,0,0,0,0,0,0,0,0,0
+1055,0,0,0,0,0,0,0,0,0,0,0,0,0
+1056,0,0,0,0,0,0,0,0,0,0,0,0,0
+1057,0,0,0,0,0,0,0,0,0,0,0,0,0
+1058,0,0,0,0,0,0,0,0,0,0,0,0,0
+1059,0,0,0,0,0,0,0,0,0,0,0,0,0
+1060,0,0,0,0,0,0,0,0,0,0,0,0,0
+1061,0,0,0,0,0,0,0,0,0,0,0,0,0
+1062,0,0,0,0,0,0,0,0,0,0,0,0,0
+1063,0,0,0,0,0,0,0,0,0,0,0,0,0
+1064,0,0,0,0,0,0,0,0,0,0,0,0,0
+1065,0,0,0,0,0,0,0,0,0,0,0,0,0
+1066,0,0,0,0,0,0,0,0,0,0,0,0,0
+1067,0,0,0,0,0,0,0,0,0,0,0,0,0
+1068,0,0,0,0,0,0,0,0,0,0,0,0,0
+1069,0,0,0,0,0,0,0,0,0,0,0,0,0
+1070,0,0,0,0,0,0,0,0,0,0,0,0,0
+1071,0,0,0,0,0,0,0,0,0,0,0,0,0
+1072,0,0,0,0,0,0,0,0,0,0,0,0,0
+1073,0,0,0,0,0,0,0,0,0,0,0,0,0
+1074,0,0,0,0,0,0,0,0,0,0,0,0,0
+1075,0,0,0,0,0,0,0,0,0,0,0,0,0
+1076,0,0,0,0,0,0,0,0,0,0,0,0,0
+1077,0,0,0,0,0,0,0,0,0,0,0,0,0
+1078,0,0,0,0,0,0,0,0,0,0,0,0,0
+1079,0,0,0,0,0,0,0,0,0,0,0,0,0
+1080,0,0,0,0,0,0,0,0,0,0,0,0,0
+1081,0,0,0,0,0,0,0,0,0,0,0,0,0
+1082,0,0,0,0,0,0,0,0,0,0,0,0,0
+1083,0,0,0,0,0,0,0,0,0,0,0,0,0
+1084,0,0,0,0,0,0,0,0,0,0,0,0,0
+1085,0,0,0,0,0,0,0,0,0,0,0,0,0
+1086,0,0,0,0,0,0,0,0,0,0,0,0,0
+1087,0,0,0,0,0,0,0,0,0,0,0,0,0
+1088,0,0,0,0,0,0,0,0,0,0,0,0,0
+1089,0,0,0,0,0,0,0,0,0,0,0,0,0
+1090,0,0,0,0,0,0,0,0,0,0,0,0,0
+1091,0,0,0,0,0,0,0,0,0,0,0,0,0
+1092,0,0,0,0,0,0,0,0,0,0,0,0,0
+1093,0,0,0,0,0,0,0,0,0,0,0,0,0
+1094,0,0,0,0,0,0,0,0,0,0,0,0,0
+1095,0,0,0,0,0,0,0,0,0,0,0,0,0
+1096,0,0,0,0,0,0,0,0,0,0,0,0,0
+1097,0,0,0,0,0,0,0,0,0,0,0,0,0
+1098,0,0,0,0,0,0,0,0,0,0,0,0,0
+1099,0,0,0,0,0,0,0,0,0,0,0,0,0
+1100,0,0,0,0,0,0,0,0,0,0,0,0,0
+1101,0,0,0,0,0,0,0,0,0,0,0,0,0
+1102,0,0,0,0,0,0,0,0,0,0,0,0,0
+1103,0,0,0,0,0,0,0,0,0,0,0,0,0
+1104,0,0,0,0,0,0,0,0,0,0,0,0,0
+1105,0,0,0,0,0,0,0,0,0,0,0,0,0
+1106,0,0,0,0,0,0,0,0,0,0,0,0,0
+1107,0,0,0,0,0,0,0,0,0,0,0,0,0
+1108,0,0,0,0,0,0,0,0,0,0,0,0,0
+1109,0,0,0,0,0,0,0,0,0,0,0,0,0
+1110,0,0,0,0,0,0,0,0,0,0,0,0,0
+1111,0,0,0,0,0,0,0,0,0,0,0,0,0
+1112,0,0,0,0,0,0,0,0,0,0,0,0,0
+1113,0,0,0,0,0,0,0,0,0,0,0,0,0
+1114,0,0,0,0,0,0,0,0,0,0,0,0,0
+1115,0,0,0,0,0,0,0,0,0,0,0,0,0
+1116,0,0,0,0,0,0,0,0,0,0,0,0,0
+1117,0,0,0,0,0,0,0,0,0,0,0,0,0
+1118,0,0,0,0,0,0,0,0,0,0,0,0,0
+1119,0,0,0,0,0,0,0,0,0,0,0,0,0
+1120,0,0,0,0,0,0,0,0,0,0,0,0,0
+1121,0,0,0,0,0,0,0,0,0,0,0,0,0
+1122,0,0,0,0,0,0,0,0,0,0,0,0,0
+1123,0,0,0,0,0,0,0,0,0,0,0,0,0
+1124,0,0,0,0,0,0,0,0,0,0,0,0,0
+1125,0,0,0,0,0,0,0,0,0,0,0,0,0
+1126,0,0,0,0,0,0,0,0,0,0,0,0,0
+1127,0,0,0,0,0,0,0,0,0,0,0,0,0
+1128,0,0,0,0,0,0,0,0,0,0,0,0,0
+1129,0,0,0,0,0,0,0,0,0,0,0,0,0
+1130,0,0,0,0,0,0,0,0,0,0,0,0,0
+1131,0,0,0,0,0,0,0,0,0,0,0,0,0
+1132,0,0,0,0,0,0,0,0,0,0,0,0,0
+1133,0,0,0,0,0,0,0,0,0,0,0,0,0
+1134,0,0,0,0,0,0,0,0,0,0,0,0,0
+1135,0,0,0,0,0,0,0,0,0,0,0,0,0
+1136,0,0,0,0,0,0,0,0,0,0,0,0,0
+1137,0,0,0,0,0,0,0,0,0,0,0,0,0
+1138,0,0,0,0,0,0,0,0,0,0,0,0,0
+1139,0,0,0,0,0,0,0,0,0,0,0,0,0
+1140,0,0,0,0,0,0,0,0,0,0,0,0,0
+1141,0,0,0,0,0,0,0,0,0,0,0,0,0
+1142,0,0,0,0,0,0,0,0,0,0,0,0,0
+1143,0,0,0,0,0,0,0,0,0,0,0,0,0
+1144,0,0,0,0,0,0,0,0,0,0,0,0,0
+1145,0,0,0,0,0,0,0,0,0,0,0,0,0
+1146,0,0,0,0,0,0,0,0,0,0,0,0,0
+1147,0,0,0,0,0,0,0,0,0,0,0,0,0
+1148,0,0,0,0,0,0,0,0,0,0,0,0,0
+1149,0,0,0,0,0,0,0,0,0,0,0,0,0
+1150,0,0,0,0,0,0,0,0,0,0,0,0,0
+1151,0,0,0,0,0,0,0,0,0,0,0,0,0
+1152,0,0,0,0,0,0,0,0,0,0,0,0,0
+1153,0,0,0,0,0,0,0,0,0,0,0,0,0
+1154,0,0,0,0,0,0,0,0,0,0,0,0,0
+1155,0,0,0,0,0,0,0,0,0,0,0,0,0
+1156,0,0,0,0,0,0,0,0,0,0,0,0,0
+1157,0,0,0,0,0,0,0,0,0,0,0,0,0
+1158,0,0,0,0,0,0,0,0,0,0,0,0,0
+1159,0,0,0,0,0,0,0,0,0,0,0,0,0
+1160,0,0,0,0,0,0,0,0,0,0,0,0,0
+1161,0,0,0,0,0,0,0,0,0,0,0,0,0
+1162,0,0,0,0,0,0,0,0,0,0,0,0,0
+1163,0,0,0,0,0,0,0,0,0,0,0,0,0
+1164,0,0,0,0,0,0,0,0,0,0,0,0,0
+1165,0,0,0,0,0,0,0,0,0,0,0,0,0
+1166,0,0,0,0,0,0,0,0,0,0,0,0,0
+1167,0,0,0,0,0,0,0,0,0,0,0,0,0
+1168,0,0,0,0,0,0,0,0,0,0,0,0,0
+1169,0,0,0,0,0,0,0,0,0,0,0,0,0
+1170,0,0,0,0,0,0,0,0,0,0,0,0,0
+1171,0,0,0,0,0,0,0,0,0,0,0,0,0
+1172,0,0,0,0,0,0,0,0,0,0,0,0,0
+1173,0,0,0,0,0,0,0,0,0,0,0,0,0
+1174,0,0,0,0,0,0,0,0,0,0,0,0,0
+1175,0,0,0,0,0,0,0,0,0,0,0,0,0
+1176,0,0,0,0,0,0,0,0,0,0,0,0,0
+1177,0,0,0,0,0,0,0,0,0,0,0,0,0
+1178,0,0,0,0,0,0,0,0,0,0,0,0,0
+1179,0,0,0,0,0,0,0,0,0,0,0,0,0
+1180,0,0,0,0,0,0,0,0,0,0,0,0,0
+1181,0,0,0,0,0,0,0,0,0,0,0,0,0
+1182,0,0,0,0,0,0,0,0,0,0,0,0,0
+1183,0,0,0,0,0,0,0,0,0,0,0,0,0
+1184,0,0,0,0,0,0,0,0,0,0,0,0,0
+1185,0,0,0,0,0,0,0,0,0,0,0,0,0
+1186,0,0,0,0,0,0,0,0,0,0,0,0,0
+1187,0,0,0,0,0,0,0,0,0,0,0,0,0
+1188,0,0,0,0,0,0,0,0,0,0,0,0,0
+1189,0,0,0,0,0,0,0,0,0,0,0,0,0
+1190,0,0,0,0,0,0,0,0,0,0,0,0,0
+1191,0,0,0,0,0,0,0,0,0,0,0,0,0
+1192,0,0,0,0,0,0,0,0,0,0,0,0,0
+1193,0,0,0,0,0,0,0,0,0,0,0,0,0
+1194,0,0,0,0,0,0,0,0,0,0,0,0,0
+1195,0,0,0,0,0,0,0,0,0,0,0,0,0
+1196,0,0,0,0,0,0,0,0,0,0,0,0,0
+1197,0,0,0,0,0,0,0,0,0,0,0,0,0
+1198,0,0,0,0,0,0,0,0,0,0,0,0,0
+1199,0,0,0,0,0,0,0,0,0,0,0,0,0
+1200,0,0,0,0,0,0,0,0,0,0,0,0,0
+1201,0,0,0,0,0,0,0,0,0,0,0,0,0
+1202,0,0,0,0,0,0,0,0,0,0,0,0,0
+1203,0,0,0,0,0,0,0,0,0,0,0,0,0
+1204,0,0,0,0,0,0,0,0,0,0,0,0,0
+1205,0,0,0,0,0,0,0,0,0,0,0,0,0
+1206,0,0,0,0,0,0,0,0,0,0,0,0,0
+1207,0,0,0,0,0,0,0,0,0,0,0,0,0
+1208,0,0,0,0,0,0,0,0,0,0,0,0,0
+1209,0,0,0,0,0,0,0,0,0,0,0,0,0
+1210,0,0,0,0,0,0,0,0,0,0,0,0,0
+1211,0,0,0,0,0,0,0,0,0,0,0,0,0
+1212,0,0,0,0,0,0,0,0,0,0,0,0,0
+1213,0,0,0,0,0,0,0,0,0,0,0,0,0
+1214,0,0,0,0,0,0,0,0,0,0,0,0,0
+1215,0,0,0,0,0,0,0,0,0,0,0,0,0
+1216,0,0,0,0,0,0,0,0,0,0,0,0,0
+1217,0,0,0,0,0,0,0,0,0,0,0,0,0
+1218,0,0,0,0,0,0,0,0,0,0,0,0,0
+1219,0,0,0,0,0,0,0,0,0,0,0,0,0
+1220,0,0,0,0,0,0,0,0,0,0,0,0,0
+1221,0,0,0,0,0,0,0,0,0,0,0,0,0
+1222,0,0,0,0,0,0,0,0,0,0,0,0,0
+1223,0,0,0,0,0,0,0,0,0,0,0,0,0
+1224,0,0,0,0,0,0,0,0,0,0,0,0,0
+1225,0,0,0,0,0,0,0,0,0,0,0,0,0
+1226,0,0,0,0,0,0,0,0,0,0,0,0,0
+1227,0,0,0,0,0,0,0,0,0,0,0,0,0
+1228,0,0,0,0,0,0,0,0,0,0,0,0,0
+1229,0,0,0,0,0,0,0,0,0,0,0,0,0
+1230,0,0,0,0,0,0,0,0,0,0,0,0,0
+1231,0,0,0,0,0,0,0,0,0,0,0,0,0
+1232,0,0,0,0,0,0,0,0,0,0,0,0,0
+1233,0,0,0,0,0,0,0,0,0,0,0,0,0
+1234,0,0,0,0,0,0,0,0,0,0,0,0,0
+1235,0,0,0,0,0,0,0,0,0,0,0,0,0
+1236,0,0,0,0,0,0,0,0,0,0,0,0,0
+1237,0,0,0,0,0,0,0,0,0,0,0,0,0
+1238,0,0,0,0,0,0,0,0,0,0,0,0,0
+1239,0,0,0,0,0,0,0,0,0,0,0,0,0
+1240,0,0,0,0,0,0,0,0,0,0,0,0,0
+1241,0,0,0,0,0,0,0,0,0,0,0,0,0
+1242,0,0,0,0,0,0,0,0,0,0,0,0,0
+1243,0,0,0,0,0,0,0,0,0,0,0,0,0
+1244,0,0,0,0,0,0,0,0,0,0,0,0,0
+1245,0,0,0,0,0,0,0,0,0,0,0,0,0
+1246,0,0,0,0,0,0,0,0,0,0,0,0,0
+1247,0,0,0,0,0,0,0,0,0,0,0,0,0
+1248,0,0,0,0,0,0,0,0,0,0,0,0,0
+1249,0,0,0,0,0,0,0,0,0,0,0,0,0
+1250,0,0,0,0,0,0,0,0,0,0,0,0,0
+1251,0,0,0,0,0,0,0,0,0,0,0,0,0
+1252,0,0,0,0,0,0,0,0,0,0,0,0,0
+1253,0,0,0,0,0,0,0,0,0,0,0,0,0
+1254,0,0,0,0,0,0,0,0,0,0,0,0,0
+1255,0,0,0,0,0,0,0,0,0,0,0,0,0
+1256,0,0,0,0,0,0,0,0,0,0,0,0,0
+1257,0,0,0,0,0,0,0,0,0,0,0,0,0
+1258,0,0,0,0,0,0,0,0,0,0,0,0,0
+1259,0,0,0,0,0,0,0,0,0,0,0,0,0
+1260,0,0,0,0,0,0,0,0,0,0,0,0,0
+1261,0,0,0,0,0,0,0,0,0,0,0,0,0
+1262,0,0,0,0,0,0,0,0,0,0,0,0,0
+1263,0,0,0,0,0,0,0,0,0,0,0,0,0
+1264,0,0,0,0,0,0,0,0,0,0,0,0,0
+1265,0,0,0,0,0,0,0,0,0,0,0,0,0
+1266,0,0,0,0,0,0,0,0,0,0,0,0,0
+1267,0,0,0,0,0,0,0,0,0,0,0,0,0
+1268,0,0,0,0,0,0,0,0,0,0,0,0,0
+1269,0,0,0,0,0,0,0,0,0,0,0,0,0
+1270,0,0,0,0,0,0,0,0,0,0,0,0,0
+1271,0,0,0,0,0,0,0,0,0,0,0,0,0
+1272,0,0,0,0,0,0,0,0,0,0,0,0,0
+1273,0,0,0,0,0,0,0,0,0,0,0,0,0
+1274,0,0,0,0,0,0,0,0,0,0,0,0,0
+1275,0,0,0,0,0,0,0,0,0,0,0,0,0
+1276,0,0,0,0,0,0,0,0,0,0,0,0,0
+1277,0,0,0,0,0,0,0,0,0,0,0,0,0
+1278,0,0,0,0,0,0,0,0,0,0,0,0,0
+1279,0,0,0,0,0,0,0,0,0,0,0,0,0
+1280,0,0,0,0,0,0,0,0,0,0,0,0,0
+1281,0,0,0,0,0,0,0,0,0,0,0,0,0
+1282,0,0,0,0,0,0,0,0,0,0,0,0,0
+1283,0,0,0,0,0,0,0,0,0,0,0,0,0
+1284,0,0,0,0,0,0,0,0,0,0,0,0,0
+1285,0,0,0,0,0,0,0,0,0,0,0,0,0
+1286,0,0,0,0,0,0,0,0,0,0,0,0,0
+1287,0,0,0,0,0,0,0,0,0,0,0,0,0
+1288,0,0,0,0,0,0,0,0,0,0,0,0,0
+1289,0,0,0,0,0,0,0,0,0,0,0,0,0
+1290,0,0,0,0,0,0,0,0,0,0,0,0,0
+1291,0,0,0,0,0,0,0,0,0,0,0,0,0
+1292,0,0,0,0,0,0,0,0,0,0,0,0,0
+1293,0,0,0,0,0,0,0,0,0,0,0,0,0
+1294,0,0,0,0,0,0,0,0,0,0,0,0,0
+1295,0,0,0,0,0,0,0,0,0,0,0,0,0
+1296,0,0,0,0,0,0,0,0,0,0,0,0,0
+1297,0,0,0,0,0,0,0,0,0,0,0,0,0
+1298,0,0,0,0,0,0,0,0,0,0,0,0,0
+1299,0,0,0,0,0,0,0,0,0,0,0,0,0
+1300,0,0,0,0,0,0,0,0,0,0,0,0,0
+1301,0,0,0,0,0,0,0,0,0,0,0,0,0
+1302,0,0,0,0,0,0,0,0,0,0,0,0,0
+1303,0,0,0,0,0,0,0,0,0,0,0,0,0
+1304,0,0,0,0,0,0,0,0,0,0,0,0,0
+1305,0,0,0,0,0,0,0,0,0,0,0,0,0
+1306,0,0,0,0,0,0,0,0,0,0,0,0,0
+1307,0,0,0,0,0,0,0,0,0,0,0,0,0
+1308,0,0,0,0,0,0,0,0,0,0,0,0,0
+1309,0,0,0,0,0,0,0,0,0,0,0,0,0
+1310,0,0,0,0,0,0,0,0,0,0,0,0,0
+1311,0,0,0,0,0,0,0,0,0,0,0,0,0
+1312,0,0,0,0,0,0,0,0,0,0,0,0,0
+1313,0,0,0,0,0,0,0,0,0,0,0,0,0
+1314,0,0,0,0,0,0,0,0,0,0,0,0,0
+1315,0,0,0,0,0,0,0,0,0,0,0,0,0
+1316,0,0,0,0,0,0,0,0,0,0,0,0,0
+1317,0,0,0,0,0,0,0,0,0,0,0,0,0
+1318,0,0,0,0,0,0,0,0,0,0,0,0,0
+1319,0,0,0,0,0,0,0,0,0,0,0,0,0
+1320,0,0,0,0,0,0,0,0,0,0,0,0,0
+1321,0,0,0,0,0,0,0,0,0,0,0,0,0
+1322,0,0,0,0,0,0,0,0,0,0,0,0,0
+1323,0,0,0,0,0,0,0,0,0,0,0,0,0
+1324,0,0,0,0,0,0,0,0,0,0,0,0,0
+1325,0,0,0,0,0,0,0,0,0,0,0,0,0
+1326,0,0,0,0,0,0,0,0,0,0,0,0,0
+1327,0,0,0,0,0,0,0,0,0,0,0,0,0
+1328,0,0,0,0,0,0,0,0,0,0,0,0,0
+1329,0,0,0,0,0,0,0,0,0,0,0,0,0
+1330,0,0,0,0,0,0,0,0,0,0,0,0,0
+1331,0,0,0,0,0,0,0,0,0,0,0,0,0
+1332,0,0,0,0,0,0,0,0,0,0,0,0,0
+1333,0,0,0,0,0,0,0,0,0,0,0,0,0
+1334,0,0,0,0,0,0,0,0,0,0,0,0,0
+1335,0,0,0,0,0,0,0,0,0,0,0,0,0
+1336,0,0,0,0,0,0,0,0,0,0,0,0,0
+1337,0,0,0,0,0,0,0,0,0,0,0.000238032,0,0
+1338,0,0,0,0,0,0,0,0,0,0,0.000054011,0,0
+1339,0,0,0,0,0,0,0,0,0,0,0.000030555,0,0
+1340,0,0,0,0,0,0,0,0,0,0,0.000028606,0,0
+1341,0,0,0,0,0,0,0,0,0,0,0.000076414,0,0
+1342,0,0,0,0,0,0,0,0,0,0,0.000109542,0,0
+1343,0,0,0,0,0,0,0,0,0,0,0.000088112,0,0
+1344,0,0,0,0,0,0,0,0,0,0,0.000124276,0,0
+1345,0,0,0,0,0,0,0,0,0,0,0.000175866,0,0
+1346,0,0,0,0,0,0,0,0,0,0,0.000334017,0,0
+1347,0,0,0,0,0,0,0,0,0,0,0.000371868,0,0
+1348,0,0,0,0,0,0,0,0,0,0,0.000448739,0,0
+1349,0,0,0,0,0,0,0,0,0,0,0.000658249,0,0
+1350,0,0,0,0,0,0,0,0,0,0,0.001089206,0,0
+1351,0,0,0,0,0,0,0,0,0,0,0.00196845,0,0
+1352,0,0,0,0,0,0,0,0,0,0,0.003736281,0,0
+1353,0,0,0,0,0,0,0,0,0,0,0.008016927,0,0
+1354,0,0,0,0,0,0,0,0,0,0,0.018845345,0,0
+1355,0,0,0,0,0,0,0,0,0,0,0.044655923,0,0
+1356,0,0,0,0,0,0,0,0,0,0,0.101545368,0,0
+1357,0,0,0,0,0,0,0,0,0,0,0.200854803,0,0
+1358,0,0,0,0,0,0,0,0,0,0,0.342389339,0,0
+1359,0,0,0,0,0,0,0,0,0,0,0.506471542,0,0
+1360,0,0,0,0,0,0,0,0,0,0,0.662498209,0,0
+1361,0,0,0,0,0,0,0,0,0,0,0.783168494,0,0
+1362,0,0,0,0,0,0,0,0,0,0,0.861210463,0,0
+1363,0,0,0,0,0,0,0,0,0,0,0.910000298,0,0
+1364,0,0,0,0,0,0,0,0,0,0,0.942126255,0,0
+1365,0,0,0,0,0,0,0,0,0,0,0.962015449,0,0
+1366,0,0,0,0,0,0,0,0,0,0,0.973750495,0,0
+1367,0,0,0,0,0,0,0,0,0,0,0.981720971,0,0
+1368,0,0,0,0,0,0,0,0,0,0,0.987945142,0,0
+1369,0,0,0,0,0,0,0,0,0,0,0.992810636,0,0
+1370,0,0,0,0,0,0,0,0,0,0,0.996478958,0,0
+1371,0,0,0,0,0,0,0,0,0,0,0.99904946,0,0
+1372,0,0,0,0,0,0,0,0,0,0,1,0,0
+1373,0,0,0,0,0,0,0,0,0,0,0.999092287,0,0
+1374,0,0,0,0,0,0,0,0,0,0,0.996049616,0,0
+1375,0,0,0,0,0,0,0,0,0,0,0.990956135,0,0
+1376,0,0,0,0,0,0,0,0,0,0,0.984853732,0,0
+1377,0,0,0,0,0,0,0,0,0,0,0.978085355,0,0
+1378,0,0,0,0,0,0,0,0,0,0,0.970372704,0,0
+1379,0,0,0,0,0,0,0,0,0,0,0.960890124,0,0
+1380,0,0,0,0,0,0,0,0,0,0,0.948599028,0,0
+1381,0,0,0,0,0,0,0,0,0,0,0.933274986,0,0
+1382,0,0,0,0,0,0,0,0,0,0,0.915013686,0,0
+1383,0,0,0,0,0,0,0,0,0,0,0.894075033,0,0
+1384,0,0,0,0,0,0,0,0,0,0,0.868634853,0,0
+1385,0,0,0,0,0,0,0,0,0,0,0.830744554,0,0
+1386,0,0,0,0,0,0,0,0,0,0,0.76452492,0,0
+1387,0,0,0,0,0,0,0,0,0,0,0.65530055,0,0
+1388,0,0,0,0,0,0,0,0,0,0,0.507853983,0,0
+1389,0,0,0,0,0,0,0,0,0,0,0.35145525,0,0
+1390,0,0,0,0,0,0,0,0,0,0,0.219307816,0,0
+1391,0,0,0,0,0,0,0,0,0,0,0.1274815,0,0
+1392,0,0,0,0,0,0,0,0,0,0,0.068371642,0,0
+1393,0,0,0,0,0,0,0,0,0,0,0.032620423,0,0
+1394,0,0,0,0,0,0,0,0,0,0,0.013687992,0,0
+1395,0,0,0,0,0,0,0,0,0,0,0.005499615,0,0
+1396,0,0,0,0,0,0,0,0,0,0,0.002399545,0,0
+1397,0,0,0,0,0,0,0,0,0,0,0.001125292,0,0
+1398,0,0,0,0,0,0,0,0,0,0,0.000545136,0,0
+1399,0,0,0,0,0,0,0,0,0,0,0.000350108,0,0
+1400,0,0,0,0,0,0,0,0,0,0,0.000176863,0,0
+1401,0,0,0,0,0,0,0,0,0,0,0.000218748,0,0
+1402,0,0,0,0,0,0,0,0,0,0,0.000196998,0,0
+1403,0,0,0,0,0,0,0,0,0,0,0.0001058,0,0
+1404,0,0,0,0,0,0,0,0,0,0,0.000059528,0,0
+1405,0,0,0,0,0,0,0,0,0,0,0.000051435,0,0
+1406,0,0,0,0,0,0,0,0,0,0,0.000061894,0,0
+1407,0,0,0,0,0,0,0,0,0,0,0.000056196,0,0
+1408,0,0,0,0,0,0,0,0,0,0,0.000039155,0,0
+1409,0,0,0,0,0,0,0,0,0,0,0.00003185,0,0
+1410,0,0,0,0,0,0,0,0,0,0,0.000121264,0,0
+1411,0,0,0,0,0,0,0,0,0,0,0.000108791,0,0
+1412,0,0,0,0,0,0,0,0,0,0,0.000025451,0,0
+1413,0,0,0,0,0,0,0,0,0,0,0,0,0
+1414,0,0,0,0,0,0,0,0,0,0,0,0,0
+1415,0,0,0,0,0,0,0,0,0,0,0,0,0
+1416,0,0,0,0,0,0,0,0,0,0,0,0,0
+1417,0,0,0,0,0,0,0,0,0,0,0,0,0
+1418,0,0,0,0,0,0,0,0,0,0,0,0,0
+1419,0,0,0,0,0,0,0,0,0,0,0,0,0
+1420,0,0,0,0,0,0,0,0,0,0,0,0,0
+1421,0,0,0,0,0,0,0,0,0,0,0,0,0
+1422,0,0,0,0,0,0,0,0,0,0,0,0,0
+1423,0,0,0,0,0,0,0,0,0,0,0,0,0
+1424,0,0,0,0,0,0,0,0,0,0,0,0,0
+1425,0,0,0,0,0,0,0,0,0,0,0,0,0
+1426,0,0,0,0,0,0,0,0,0,0,0,0,0
+1427,0,0,0,0,0,0,0,0,0,0,0,0,0
+1428,0,0,0,0,0,0,0,0,0,0,0,0,0
+1429,0,0,0,0,0,0,0,0,0,0,0,0,0
+1430,0,0,0,0,0,0,0,0,0,0,0,0,0
+1431,0,0,0,0,0,0,0,0,0,0,0,0,0
+1432,0,0,0,0,0,0,0,0,0,0,0,0,0
+1433,0,0,0,0,0,0,0,0,0,0,0,0,0
+1434,0,0,0,0,0,0,0,0,0,0,0,0,0
+1435,0,0,0,0,0,0,0,0,0,0,0,0,0
+1436,0,0,0,0,0,0,0,0,0,0,0,0,0
+1437,0,0,0,0,0,0,0,0,0,0,0,0,0
+1438,0,0,0,0,0,0,0,0,0,0,0,0,0
+1439,0,0,0,0,0,0,0,0,0,0,0,0,0
+1440,0,0,0,0,0,0,0,0,0,0,0,0,0
+1441,0,0,0,0,0,0,0,0,0,0,0,0,0
+1442,0,0,0,0,0,0,0,0,0,0,0,0,0
+1443,0,0,0,0,0,0,0,0,0,0,0,0,0
+1444,0,0,0,0,0,0,0,0,0,0,0,0,0
+1445,0,0,0,0,0,0,0,0,0,0,0,0,0
+1446,0,0,0,0,0,0,0,0,0,0,0,0,0
+1447,0,0,0,0,0,0,0,0,0,0,0,0,0
+1448,0,0,0,0,0,0,0,0,0,0,0,0,0
+1449,0,0,0,0,0,0,0,0,0,0,0,0,0
+1450,0,0,0,0,0,0,0,0,0,0,0,0,0
+1451,0,0,0,0,0,0,0,0,0,0,0,0,0
+1452,0,0,0,0,0,0,0,0,0,0,0,0,0
+1453,0,0,0,0,0,0,0,0,0,0,0,0,0
+1454,0,0,0,0,0,0,0,0,0,0,0,0,0
+1455,0,0,0,0,0,0,0,0,0,0,0,0,0
+1456,0,0,0,0,0,0,0,0,0,0,0,0,0
+1457,0,0,0,0,0,0,0,0,0,0,0,0,0
+1458,0,0,0,0,0,0,0,0,0,0,0,0,0
+1459,0,0,0,0,0,0,0,0,0,0,0,0,0
+1460,0,0,0,0,0,0,0,0,0,0,0,0,0
+1461,0,0,0,0,0,0,0,0,0,0,0,0,0
+1462,0,0,0,0,0,0,0,0,0,0,0,0,0
+1463,0,0,0,0,0,0,0,0,0,0,0,0,0
+1464,0,0,0,0,0,0,0,0,0,0,0,0,0
+1465,0,0,0,0,0,0,0,0,0,0,0,0,0
+1466,0,0,0,0,0,0,0,0,0,0,0,0,0
+1467,0,0,0,0,0,0,0,0,0,0,0,0,0
+1468,0,0,0,0,0,0,0,0,0,0,0,0,0
+1469,0,0,0,0,0,0,0,0,0,0,0,0,0
+1470,0,0,0,0,0,0,0,0,0,0,0,0,0
+1471,0,0,0,0,0,0,0,0,0,0,0,0,0
+1472,0,0,0,0,0,0,0,0,0,0,0,0,0
+1473,0,0,0,0,0,0,0,0,0,0,0,0,0
+1474,0,0,0,0,0,0,0,0,0,0,0,0,0
+1475,0,0,0,0,0,0,0,0,0,0,0,0,0
+1476,0,0,0,0,0,0,0,0,0,0,0,0,0
+1477,0,0,0,0,0,0,0,0,0,0,0,0,0
+1478,0,0,0,0,0,0,0,0,0,0,0,0,0
+1479,0,0,0,0,0,0,0,0,0,0,0,0,0
+1480,0,0,0,0,0,0,0,0,0,0,0,0,0
+1481,0,0,0,0,0,0,0,0,0,0,0,0,0
+1482,0,0,0,0,0,0,0,0,0,0,0,0,0
+1483,0,0,0,0,0,0,0,0,0,0,0,0,0
+1484,0,0,0,0,0,0,0,0,0,0,0,0,0
+1485,0,0,0,0,0,0,0,0,0,0,0,0,0
+1486,0,0,0,0,0,0,0,0,0,0,0,0,0
+1487,0,0,0,0,0,0,0,0,0,0,0,0,0
+1488,0,0,0,0,0,0,0,0,0,0,0,0,0
+1489,0,0,0,0,0,0,0,0,0,0,0,0,0
+1490,0,0,0,0,0,0,0,0,0,0,0,0,0
+1491,0,0,0,0,0,0,0,0,0,0,0,0,0
+1492,0,0,0,0,0,0,0,0,0,0,0,0,0
+1493,0,0,0,0,0,0,0,0,0,0,0,0,0
+1494,0,0,0,0,0,0,0,0,0,0,0,0,0
+1495,0,0,0,0,0,0,0,0,0,0,0,0,0
+1496,0,0,0,0,0,0,0,0,0,0,0,0,0
+1497,0,0,0,0,0,0,0,0,0,0,0,0,0
+1498,0,0,0,0,0,0,0,0,0,0,0,0,0
+1499,0,0,0,0,0,0,0,0,0,0,0,0,0
+1500,0,0,0,0,0,0,0,0,0,0,0,0,0
+1501,0,0,0,0,0,0,0,0,0,0,0,0,0
+1502,0,0,0,0,0,0,0,0,0,0,0,0,0
+1503,0,0,0,0,0,0,0,0,0,0,0,0,0
+1504,0,0,0,0,0,0,0,0,0,0,0,0,0
+1505,0,0,0,0,0,0,0,0,0,0,0,0,0
+1506,0,0,0,0,0,0,0,0,0,0,0,0,0
+1507,0,0,0,0,0,0,0,0,0,0,0,0,0
+1508,0,0,0,0,0,0,0,0,0,0,0,0,0
+1509,0,0,0,0,0,0,0,0,0,0,0,0,0
+1510,0,0,0,0,0,0,0,0,0,0,0,0,0
+1511,0,0,0,0,0,0,0,0,0,0,0,0,0
+1512,0,0,0,0,0,0,0,0,0,0,0,0,0
+1513,0,0,0,0,0,0,0,0,0,0,0,0,0
+1514,0,0,0,0,0,0,0,0,0,0,0,0,0
+1515,0,0,0,0,0,0,0,0,0,0,0,0,0
+1516,0,0,0,0,0,0,0,0,0,0,0,0,0
+1517,0,0,0,0,0,0,0,0,0,0,0,0,0
+1518,0,0,0,0,0,0,0,0,0,0,0,0,0
+1519,0,0,0,0,0,0,0,0,0,0,0,0,0
+1520,0,0,0,0,0,0,0,0,0,0,0,0,0
+1521,0,0,0,0,0,0,0,0,0,0,0,0,0
+1522,0,0,0,0,0,0,0,0,0,0,0,0,0
+1523,0,0,0,0,0,0,0,0,0,0,0,0,0
+1524,0,0,0,0,0,0,0,0,0,0,0,0,0
+1525,0,0,0,0,0,0,0,0,0,0,0,0,0
+1526,0,0,0,0,0,0,0,0,0,0,0,0,0
+1527,0,0,0,0,0,0,0,0,0,0,0,0,0
+1528,0,0,0,0,0,0,0,0,0,0,0,0,0
+1529,0,0,0,0,0,0,0,0,0,0,0,0,0
+1530,0,0,0,0,0,0,0,0,0,0,0,0,0
+1531,0,0,0,0,0,0,0,0,0,0,0,0,0
+1532,0,0,0,0,0,0,0,0,0,0,0,0,0
+1533,0,0,0,0,0,0,0,0,0,0,0,0,0
+1534,0,0,0,0,0,0,0,0,0,0,0,0,0
+1535,0,0,0,0,0,0,0,0,0,0,0,0,0
+1536,0,0,0,0,0,0,0,0,0,0,0,0,0
+1537,0,0,0,0,0,0,0,0,0,0,0,0,0
+1538,0,0,0,0,0,0,0,0,0,0,0,0,0
+1539,0,0,0,0,0,0,0,0,0,0,0,0.000006934,0
+1540,0,0,0,0,0,0,0,0,0,0,0,0.000006804,0
+1541,0,0,0,0,0,0,0,0,0,0,0,0.000008224,0
+1542,0,0,0,0,0,0,0,0,0,0,0,0.000028105,0
+1543,0,0,0,0,0,0,0,0,0,0,0,0.00003784,0
+1544,0,0,0,0,0,0,0,0,0,0,0,0.000090746,0
+1545,0,0,0,0,0,0,0,0,0,0,0,0.000147452,0
+1546,0,0,0,0,0,0,0,0,0,0,0,0.000251399,0
+1547,0,0,0,0,0,0,0,0,0,0,0,0.000480203,0
+1548,0,0,0,0,0,0,0,0,0,0,0,0.000569537,0
+1549,0,0,0,0,0,0,0,0,0,0,0,0.000662261,0
+1550,0,0,0,0,0,0,0,0,0,0,0,0.000910566,0
+1551,0,0,0,0,0,0,0,0,0,0,0,0.001166089,0
+1552,0,0,0,0,0,0,0,0,0,0,0,0.001684036,0
+1553,0,0,0,0,0,0,0,0,0,0,0,0.00245816,0
+1554,0,0,0,0,0,0,0,0,0,0,0,0.00356747,0
+1555,0,0,0,0,0,0,0,0,0,0,0,0.005345161,0
+1556,0,0,0,0,0,0,0,0,0,0,0,0.008317784,0
+1557,0,0,0,0,0,0,0,0,0,0,0,0.012628433,0
+1558,0,0,0,0,0,0,0,0,0,0,0,0.018996334,0
+1559,0,0,0,0,0,0,0,0,0,0,0,0.027780618,0
+1560,0,0,0,0,0,0,0,0,0,0,0,0.03958367,0
+1561,0,0,0,0,0,0,0,0,0,0,0,0.054865088,0
+1562,0,0,0,0,0,0,0,0,0,0,0,0.074929768,0
+1563,0,0,0,0,0,0,0,0,0,0,0,0.101069914,0
+1564,0,0,0,0,0,0,0,0,0,0,0,0.135475748,0
+1565,0,0,0,0,0,0,0,0,0,0,0,0.182597282,0
+1566,0,0,0,0,0,0,0,0,0,0,0,0.247275543,0
+1567,0,0,0,0,0,0,0,0,0,0,0,0.330736144,0
+1568,0,0,0,0,0,0,0,0,0,0,0,0.429690906,0
+1569,0,0,0,0,0,0,0,0,0,0,0,0.537634456,0
+1570,0,0,0,0,0,0,0,0,0,0,0,0.647173334,0
+1571,0,0,0,0,0,0,0,0,0,0,0,0.743528409,0
+1572,0,0,0,0,0,0,0,0,0,0,0,0.815215305,0
+1573,0,0,0,0,0,0,0,0,0,0,0,0.859201504,0
+1574,0,0,0,0,0,0,0,0,0,0,0,0.879668577,0
+1575,0,0,0,0,0,0,0,0,0,0,0,0.887029952,0
+1576,0,0,0,0,0,0,0,0,0,0,0,0.889097838,0
+1577,0,0,0,0,0,0,0,0,0,0,0,0.891416958,0
+1578,0,0,0,0,0,0,0,0,0,0,0,0.897586018,0
+1579,0,0,0,0,0,0,0,0,0,0,0,0.90663052,0
+1580,0,0,0,0,0,0,0,0,0,0,0,0.916528056,0
+1581,0,0,0,0,0,0,0,0,0,0,0,0.92657894,0
+1582,0,0,0,0,0,0,0,0,0,0,0,0.935322165,0
+1583,0,0,0,0,0,0,0,0,0,0,0,0.942393561,0
+1584,0,0,0,0,0,0,0,0,0,0,0,0.947506732,0
+1585,0,0,0,0,0,0,0,0,0,0,0,0.951415577,0
+1586,0,0,0,0,0,0,0,0,0,0,0,0.954254286,0
+1587,0,0,0,0,0,0,0,0,0,0,0,0.956429305,0
+1588,0,0,0,0,0,0,0,0,0,0,0,0.958205215,0
+1589,0,0,0,0,0,0,0,0,0,0,0,0.960687866,0
+1590,0,0,0,0,0,0,0,0,0,0,0,0.963480014,0
+1591,0,0,0,0,0,0,0,0,0,0,0,0.965796837,0
+1592,0,0,0,0,0,0,0,0,0,0,0,0.968180454,0
+1593,0,0,0,0,0,0,0,0,0,0,0,0.97101157,0
+1594,0,0,0,0,0,0,0,0,0,0,0,0.973379886,0
+1595,0,0,0,0,0,0,0,0,0,0,0,0.97591493,0
+1596,0,0,0,0,0,0,0,0,0,0,0,0.978581496,0
+1597,0,0,0,0,0,0,0,0,0,0,0,0.979877753,0
+1598,0,0,0,0,0,0,0,0,0,0,0,0.98058868,0
+1599,0,0,0,0,0,0,0,0,0,0,0,0.980912334,0
+1600,0,0,0,0,0,0,0,0,0,0,0,0.981411503,0
+1601,0,0,0,0,0,0,0,0,0,0,0,0.981243863,0
+1602,0,0,0,0,0,0,0,0,0,0,0,0.980705072,0
+1603,0,0,0,0,0,0,0,0,0,0,0,0.980376964,0
+1604,0,0,0,0,0,0,0,0,0,0,0,0.981066319,0
+1605,0,0,0,0,0,0,0,0,0,0,0,0.982735565,0
+1606,0,0,0,0,0,0,0,0,0,0,0,0.985121995,0
+1607,0,0,0,0,0,0,0,0,0,0,0,0.987806954,0
+1608,0,0,0,0,0,0,0,0,0,0,0,0.990375969,0
+1609,0,0,0,0,0,0,0,0,0,0,0,0.992015684,0
+1610,0,0,0,0,0,0,0,0,0,0,0,0.993287985,0
+1611,0,0,0,0,0,0,0,0,0,0,0,0.992536418,0
+1612,0,0,0,0,0,0,0,0,0,0,0,0.990404949,0
+1613,0,0,0,0,0,0,0,0,0,0,0,0.987128016,0
+1614,0,0,0,0,0,0,0,0,0,0,0,0.983502057,0
+1615,0,0,0,0,0,0,0,0,0,0,0,0.980022548,0
+1616,0,0,0,0,0,0,0,0,0,0,0,0.976174463,0
+1617,0,0,0,0,0,0,0,0,0,0,0,0.972568388,0
+1618,0,0,0,0,0,0,0,0,0,0,0,0.969828489,0
+1619,0,0,0,0,0,0,0,0,0,0,0,0.967709002,0
+1620,0,0,0,0,0,0,0,0,0,0,0,0.966371474,0
+1621,0,0,0,0,0,0,0,0,0,0,0,0.965848924,0
+1622,0,0,0,0,0,0,0,0,0,0,0,0.966050474,0
+1623,0,0,0,0,0,0,0,0,0,0,0,0.967426617,0
+1624,0,0,0,0,0,0,0,0,0,0,0,0.969869577,0
+1625,0,0,0,0,0,0,0,0,0,0,0,0.973463419,0
+1626,0,0,0,0,0,0,0,0,0,0,0,0.97868284,0
+1627,0,0,0,0,0,0,0,0,0,0,0,0.983472137,0
+1628,0,0,0,0,0,0,0,0,0,0,0,0.987635453,0
+1629,0,0,0,0,0,0,0,0,0,0,0,0.991875079,0
+1630,0,0,0,0,0,0,0,0,0,0,0,0.995476405,0
+1631,0,0,0,0,0,0,0,0,0,0,0,0.997586172,0
+1632,0,0,0,0,0,0,0,0,0,0,0,0.998568438,0
+1633,0,0,0,0,0,0,0,0,0,0,0,0.999327749,0
+1634,0,0,0,0,0,0,0,0,0,0,0,0.999234469,0
+1635,0,0,0,0,0,0,0,0,0,0,0,0.998803511,0
+1636,0,0,0,0,0,0,0,0,0,0,0,0.999110558,0
+1637,0,0,0,0,0,0,0,0,0,0,0,0.999729529,0
+1638,0,0,0,0,0,0,0,0,0,0,0,0.999744808,0
+1639,0,0,0,0,0,0,0,0,0,0,0,1,0
+1640,0,0,0,0,0,0,0,0,0,0,0,0.999814319,0
+1641,0,0,0,0,0,0,0,0,0,0,0,0.996693294,0
+1642,0,0,0,0,0,0,0,0,0,0,0,0.991619643,0
+1643,0,0,0,0,0,0,0,0,0,0,0,0.985701748,0
+1644,0,0,0,0,0,0,0,0,0,0,0,0.978569228,0
+1645,0,0,0,0,0,0,0,0,0,0,0,0.969902949,0
+1646,0,0,0,0,0,0,0,0,0,0,0,0.960896391,0
+1647,0,0,0,0,0,0,0,0,0,0,0,0.953286699,0
+1648,0,0,0,0,0,0,0,0,0,0,0,0.946546283,0
+1649,0,0,0,0,0,0,0,0,0,0,0,0.941712152,0
+1650,0,0,0,0,0,0,0,0,0,0,0,0.938586421,0
+1651,0,0,0,0,0,0,0,0,0,0,0,0.935489328,0
+1652,0,0,0,0,0,0,0,0,0,0,0,0.928113913,0
+1653,0,0,0,0,0,0,0,0,0,0,0,0.912102443,0
+1654,0,0,0,0,0,0,0,0,0,0,0,0.88059783,0
+1655,0,0,0,0,0,0,0,0,0,0,0,0.824980062,0
+1656,0,0,0,0,0,0,0,0,0,0,0,0.743118017,0
+1657,0,0,0,0,0,0,0,0,0,0,0,0.64189077,0
+1658,0,0,0,0,0,0,0,0,0,0,0,0.534002282,0
+1659,0,0,0,0,0,0,0,0,0,0,0,0.426963072,0
+1660,0,0,0,0,0,0,0,0,0,0,0,0.323709698,0
+1661,0,0,0,0,0,0,0,0,0,0,0,0.234284076,0
+1662,0,0,0,0,0,0,0,0,0,0,0,0.163971597,0
+1663,0,0,0,0,0,0,0,0,0,0,0,0.110210711,0
+1664,0,0,0,0,0,0,0,0,0,0,0,0.072477896,0
+1665,0,0,0,0,0,0,0,0,0,0,0,0.04619413,0
+1666,0,0,0,0,0,0,0,0,0,0,0,0.029400532,0
+1667,0,0,0,0,0,0,0,0,0,0,0,0.019358665,0
+1668,0,0,0,0,0,0,0,0,0,0,0,0.013308246,0
+1669,0,0,0,0,0,0,0,0,0,0,0,0.009316851,0
+1670,0,0,0,0,0,0,0,0,0,0,0,0.006522833,0
+1671,0,0,0,0,0,0,0,0,0,0,0,0.004864189,0
+1672,0,0,0,0,0,0,0,0,0,0,0,0.003409053,0
+1673,0,0,0,0,0,0,0,0,0,0,0,0.002490561,0
+1674,0,0,0,0,0,0,0,0,0,0,0,0.001958315,0
+1675,0,0,0,0,0,0,0,0,0,0,0,0.001422504,0
+1676,0,0,0,0,0,0,0,0,0,0,0,0.001055276,0
+1677,0,0,0,0,0,0,0,0,0,0,0,0.000497731,0
+1678,0,0,0,0,0,0,0,0,0,0,0,0.000227763,0
+1679,0,0,0,0,0,0,0,0,0,0,0,0.00015918,0
+1680,0,0,0,0,0,0,0,0,0,0,0,0.000033942,0
+1681,0,0,0,0,0,0,0,0,0,0,0,0.000044875,0
+1682,0,0,0,0,0,0,0,0,0,0,0,0.000013044,0
+1683,0,0,0,0,0,0,0,0,0,0,0,0,0
+1684,0,0,0,0,0,0,0,0,0,0,0,0,0
+1685,0,0,0,0,0,0,0,0,0,0,0,0,0
+1686,0,0,0,0,0,0,0,0,0,0,0,0,0
+1687,0,0,0,0,0,0,0,0,0,0,0,0,0
+1688,0,0,0,0,0,0,0,0,0,0,0,0,0
+1689,0,0,0,0,0,0,0,0,0,0,0,0,0
+1690,0,0,0,0,0,0,0,0,0,0,0,0,0
+1691,0,0,0,0,0,0,0,0,0,0,0,0,0
+1692,0,0,0,0,0,0,0,0,0,0,0,0,0
+1693,0,0,0,0,0,0,0,0,0,0,0,0,0
+1694,0,0,0,0,0,0,0,0,0,0,0,0,0
+1695,0,0,0,0,0,0,0,0,0,0,0,0,0
+1696,0,0,0,0,0,0,0,0,0,0,0,0,0
+1697,0,0,0,0,0,0,0,0,0,0,0,0,0
+1698,0,0,0,0,0,0,0,0,0,0,0,0,0
+1699,0,0,0,0,0,0,0,0,0,0,0,0,0
+1700,0,0,0,0,0,0,0,0,0,0,0,0,0
+1701,0,0,0,0,0,0,0,0,0,0,0,0,0
+1702,0,0,0,0,0,0,0,0,0,0,0,0,0
+1703,0,0,0,0,0,0,0,0,0,0,0,0,0
+1704,0,0,0,0,0,0,0,0,0,0,0,0,0
+1705,0,0,0,0,0,0,0,0,0,0,0,0,0
+1706,0,0,0,0,0,0,0,0,0,0,0,0,0
+1707,0,0,0,0,0,0,0,0,0,0,0,0,0
+1708,0,0,0,0,0,0,0,0,0,0,0,0,0
+1709,0,0,0,0,0,0,0,0,0,0,0,0,0
+1710,0,0,0,0,0,0,0,0,0,0,0,0,0
+1711,0,0,0,0,0,0,0,0,0,0,0,0,0
+1712,0,0,0,0,0,0,0,0,0,0,0,0,0
+1713,0,0,0,0,0,0,0,0,0,0,0,0,0
+1714,0,0,0,0,0,0,0,0,0,0,0,0,0
+1715,0,0,0,0,0,0,0,0,0,0,0,0,0
+1716,0,0,0,0,0,0,0,0,0,0,0,0,0
+1717,0,0,0,0,0,0,0,0,0,0,0,0,0
+1718,0,0,0,0,0,0,0,0,0,0,0,0,0
+1719,0,0,0,0,0,0,0,0,0,0,0,0,0
+1720,0,0,0,0,0,0,0,0,0,0,0,0,0
+1721,0,0,0,0,0,0,0,0,0,0,0,0,0
+1722,0,0,0,0,0,0,0,0,0,0,0,0,0
+1723,0,0,0,0,0,0,0,0,0,0,0,0,0
+1724,0,0,0,0,0,0,0,0,0,0,0,0,0
+1725,0,0,0,0,0,0,0,0,0,0,0,0,0
+1726,0,0,0,0,0,0,0,0,0,0,0,0,0
+1727,0,0,0,0,0,0,0,0,0,0,0,0,0
+1728,0,0,0,0,0,0,0,0,0,0,0,0,0
+1729,0,0,0,0,0,0,0,0,0,0,0,0,0
+1730,0,0,0,0,0,0,0,0,0,0,0,0,0
+1731,0,0,0,0,0,0,0,0,0,0,0,0,0
+1732,0,0,0,0,0,0,0,0,0,0,0,0,0
+1733,0,0,0,0,0,0,0,0,0,0,0,0,0
+1734,0,0,0,0,0,0,0,0,0,0,0,0,0
+1735,0,0,0,0,0,0,0,0,0,0,0,0,0
+1736,0,0,0,0,0,0,0,0,0,0,0,0,0
+1737,0,0,0,0,0,0,0,0,0,0,0,0,0
+1738,0,0,0,0,0,0,0,0,0,0,0,0,0
+1739,0,0,0,0,0,0,0,0,0,0,0,0,0
+1740,0,0,0,0,0,0,0,0,0,0,0,0,0
+1741,0,0,0,0,0,0,0,0,0,0,0,0,0
+1742,0,0,0,0,0,0,0,0,0,0,0,0,0
+1743,0,0,0,0,0,0,0,0,0,0,0,0,0
+1744,0,0,0,0,0,0,0,0,0,0,0,0,0
+1745,0,0,0,0,0,0,0,0,0,0,0,0,0
+1746,0,0,0,0,0,0,0,0,0,0,0,0,0
+1747,0,0,0,0,0,0,0,0,0,0,0,0,0
+1748,0,0,0,0,0,0,0,0,0,0,0,0,0
+1749,0,0,0,0,0,0,0,0,0,0,0,0,0
+1750,0,0,0,0,0,0,0,0,0,0,0,0,0
+1751,0,0,0,0,0,0,0,0,0,0,0,0,0
+1752,0,0,0,0,0,0,0,0,0,0,0,0,0
+1753,0,0,0,0,0,0,0,0,0,0,0,0,0
+1754,0,0,0,0,0,0,0,0,0,0,0,0,0
+1755,0,0,0,0,0,0,0,0,0,0,0,0,0
+1756,0,0,0,0,0,0,0,0,0,0,0,0,0
+1757,0,0,0,0,0,0,0,0,0,0,0,0,0
+1758,0,0,0,0,0,0,0,0,0,0,0,0,0
+1759,0,0,0,0,0,0,0,0,0,0,0,0,0
+1760,0,0,0,0,0,0,0,0,0,0,0,0,0
+1761,0,0,0,0,0,0,0,0,0,0,0,0,0
+1762,0,0,0,0,0,0,0,0,0,0,0,0,0
+1763,0,0,0,0,0,0,0,0,0,0,0,0,0
+1764,0,0,0,0,0,0,0,0,0,0,0,0,0
+1765,0,0,0,0,0,0,0,0,0,0,0,0,0
+1766,0,0,0,0,0,0,0,0,0,0,0,0,0
+1767,0,0,0,0,0,0,0,0,0,0,0,0,0
+1768,0,0,0,0,0,0,0,0,0,0,0,0,0
+1769,0,0,0,0,0,0,0,0,0,0,0,0,0
+1770,0,0,0,0,0,0,0,0,0,0,0,0,0
+1771,0,0,0,0,0,0,0,0,0,0,0,0,0
+1772,0,0,0,0,0,0,0,0,0,0,0,0,0
+1773,0,0,0,0,0,0,0,0,0,0,0,0,0
+1774,0,0,0,0,0,0,0,0,0,0,0,0,0
+1775,0,0,0,0,0,0,0,0,0,0,0,0,0
+1776,0,0,0,0,0,0,0,0,0,0,0,0,0
+1777,0,0,0,0,0,0,0,0,0,0,0,0,0
+1778,0,0,0,0,0,0,0,0,0,0,0,0,0
+1779,0,0,0,0,0,0,0,0,0,0,0,0,0
+1780,0,0,0,0,0,0,0,0,0,0,0,0,0
+1781,0,0,0,0,0,0,0,0,0,0,0,0,0
+1782,0,0,0,0,0,0,0,0,0,0,0,0,0
+1783,0,0,0,0,0,0,0,0,0,0,0,0,0
+1784,0,0,0,0,0,0,0,0,0,0,0,0,0
+1785,0,0,0,0,0,0,0,0,0,0,0,0,0
+1786,0,0,0,0,0,0,0,0,0,0,0,0,0
+1787,0,0,0,0,0,0,0,0,0,0,0,0,0
+1788,0,0,0,0,0,0,0,0,0,0,0,0,0
+1789,0,0,0,0,0,0,0,0,0,0,0,0,0
+1790,0,0,0,0,0,0,0,0,0,0,0,0,0
+1791,0,0,0,0,0,0,0,0,0,0,0,0,0
+1792,0,0,0,0,0,0,0,0,0,0,0,0,0
+1793,0,0,0,0,0,0,0,0,0,0,0,0,0
+1794,0,0,0,0,0,0,0,0,0,0,0,0,0
+1795,0,0,0,0,0,0,0,0,0,0,0,0,0
+1796,0,0,0,0,0,0,0,0,0,0,0,0,0
+1797,0,0,0,0,0,0,0,0,0,0,0,0,0
+1798,0,0,0,0,0,0,0,0,0,0,0,0,0
+1799,0,0,0,0,0,0,0,0,0,0,0,0,0
+1800,0,0,0,0,0,0,0,0,0,0,0,0,0
+1801,0,0,0,0,0,0,0,0,0,0,0,0,0
+1802,0,0,0,0,0,0,0,0,0,0,0,0,0
+1803,0,0,0,0,0,0,0,0,0,0,0,0,0
+1804,0,0,0,0,0,0,0,0,0,0,0,0,0
+1805,0,0,0,0,0,0,0,0,0,0,0,0,0
+1806,0,0,0,0,0,0,0,0,0,0,0,0,0
+1807,0,0,0,0,0,0,0,0,0,0,0,0,0
+1808,0,0,0,0,0,0,0,0,0,0,0,0,0
+1809,0,0,0,0,0,0,0,0,0,0,0,0,0
+1810,0,0,0,0,0,0,0,0,0,0,0,0,0
+1811,0,0,0,0,0,0,0,0,0,0,0,0,0
+1812,0,0,0,0,0,0,0,0,0,0,0,0,0
+1813,0,0,0,0,0,0,0,0,0,0,0,0,0
+1814,0,0,0,0,0,0,0,0,0,0,0,0,0
+1815,0,0,0,0,0,0,0,0,0,0,0,0,0
+1816,0,0,0,0,0,0,0,0,0,0,0,0,0
+1817,0,0,0,0,0,0,0,0,0,0,0,0,0
+1818,0,0,0,0,0,0,0,0,0,0,0,0,0
+1819,0,0,0,0,0,0,0,0,0,0,0,0,0
+1820,0,0,0,0,0,0,0,0,0,0,0,0,0
+1821,0,0,0,0,0,0,0,0,0,0,0,0,0
+1822,0,0,0,0,0,0,0,0,0,0,0,0,0
+1823,0,0,0,0,0,0,0,0,0,0,0,0,0
+1824,0,0,0,0,0,0,0,0,0,0,0,0,0
+1825,0,0,0,0,0,0,0,0,0,0,0,0,0
+1826,0,0,0,0,0,0,0,0,0,0,0,0,0
+1827,0,0,0,0,0,0,0,0,0,0,0,0,0
+1828,0,0,0,0,0,0,0,0,0,0,0,0,0
+1829,0,0,0,0,0,0,0,0,0,0,0,0,0
+1830,0,0,0,0,0,0,0,0,0,0,0,0,0
+1831,0,0,0,0,0,0,0,0,0,0,0,0,0
+1832,0,0,0,0,0,0,0,0,0,0,0,0,0
+1833,0,0,0,0,0,0,0,0,0,0,0,0,0
+1834,0,0,0,0,0,0,0,0,0,0,0,0,0
+1835,0,0,0,0,0,0,0,0,0,0,0,0,0
+1836,0,0,0,0,0,0,0,0,0,0,0,0,0
+1837,0,0,0,0,0,0,0,0,0,0,0,0,0
+1838,0,0,0,0,0,0,0,0,0,0,0,0,0
+1839,0,0,0,0,0,0,0,0,0,0,0,0,0
+1840,0,0,0,0,0,0,0,0,0,0,0,0,0
+1841,0,0,0,0,0,0,0,0,0,0,0,0,0
+1842,0,0,0,0,0,0,0,0,0,0,0,0,0
+1843,0,0,0,0,0,0,0,0,0,0,0,0,0
+1844,0,0,0,0,0,0,0,0,0,0,0,0,0
+1845,0,0,0,0,0,0,0,0,0,0,0,0,0
+1846,0,0,0,0,0,0,0,0,0,0,0,0,0
+1847,0,0,0,0,0,0,0,0,0,0,0,0,0
+1848,0,0,0,0,0,0,0,0,0,0,0,0,0
+1849,0,0,0,0,0,0,0,0,0,0,0,0,0
+1850,0,0,0,0,0,0,0,0,0,0,0,0,0
+1851,0,0,0,0,0,0,0,0,0,0,0,0,0
+1852,0,0,0,0,0,0,0,0,0,0,0,0,0
+1853,0,0,0,0,0,0,0,0,0,0,0,0,0
+1854,0,0,0,0,0,0,0,0,0,0,0,0,0
+1855,0,0,0,0,0,0,0,0,0,0,0,0,0
+1856,0,0,0,0,0,0,0,0,0,0,0,0,0
+1857,0,0,0,0,0,0,0,0,0,0,0,0,0
+1858,0,0,0,0,0,0,0,0,0,0,0,0,0
+1859,0,0,0,0,0,0,0,0,0,0,0,0,0
+1860,0,0,0,0,0,0,0,0,0,0,0,0,0
+1861,0,0,0,0,0,0,0,0,0,0,0,0,0
+1862,0,0,0,0,0,0,0,0,0,0,0,0,0
+1863,0,0,0,0,0,0,0,0,0,0,0,0,0
+1864,0,0,0,0,0,0,0,0,0,0,0,0,0
+1865,0,0,0,0,0,0,0,0,0,0,0,0,0
+1866,0,0,0,0,0,0,0,0,0,0,0,0,0
+1867,0,0,0,0,0,0,0,0,0,0,0,0,0
+1868,0,0,0,0,0,0,0,0,0,0,0,0,0
+1869,0,0,0,0,0,0,0,0,0,0,0,0,0
+1870,0,0,0,0,0,0,0,0,0,0,0,0,0
+1871,0,0,0,0,0,0,0,0,0,0,0,0,0
+1872,0,0,0,0,0,0,0,0,0,0,0,0,0
+1873,0,0,0,0,0,0,0,0,0,0,0,0,0
+1874,0,0,0,0,0,0,0,0,0,0,0,0,0
+1875,0,0,0,0,0,0,0,0,0,0,0,0,0
+1876,0,0,0,0,0,0,0,0,0,0,0,0,0
+1877,0,0,0,0,0,0,0,0,0,0,0,0,0
+1878,0,0,0,0,0,0,0,0,0,0,0,0,0
+1879,0,0,0,0,0,0,0,0,0,0,0,0,0
+1880,0,0,0,0,0,0,0,0,0,0,0,0,0
+1881,0,0,0,0,0,0,0,0,0,0,0,0,0
+1882,0,0,0,0,0,0,0,0,0,0,0,0,0
+1883,0,0,0,0,0,0,0,0,0,0,0,0,0
+1884,0,0,0,0,0,0,0,0,0,0,0,0,0
+1885,0,0,0,0,0,0,0,0,0,0,0,0,0
+1886,0,0,0,0,0,0,0,0,0,0,0,0,0
+1887,0,0,0,0,0,0,0,0,0,0,0,0,0
+1888,0,0,0,0,0,0,0,0,0,0,0,0,0
+1889,0,0,0,0,0,0,0,0,0,0,0,0,0
+1890,0,0,0,0,0,0,0,0,0,0,0,0,0
+1891,0,0,0,0,0,0,0,0,0,0,0,0,0
+1892,0,0,0,0,0,0,0,0,0,0,0,0,0
+1893,0,0,0,0,0,0,0,0,0,0,0,0,0
+1894,0,0,0,0,0,0,0,0,0,0,0,0,0
+1895,0,0,0,0,0,0,0,0,0,0,0,0,0
+1896,0,0,0,0,0,0,0,0,0,0,0,0,0
+1897,0,0,0,0,0,0,0,0,0,0,0,0,0
+1898,0,0,0,0,0,0,0,0,0,0,0,0,0
+1899,0,0,0,0,0,0,0,0,0,0,0,0,0
+1900,0,0,0,0,0,0,0,0,0,0,0,0,0
+1901,0,0,0,0,0,0,0,0,0,0,0,0,0
+1902,0,0,0,0,0,0,0,0,0,0,0,0,0
+1903,0,0,0,0,0,0,0,0,0,0,0,0,0
+1904,0,0,0,0,0,0,0,0,0,0,0,0,0
+1905,0,0,0,0,0,0,0,0,0,0,0,0,0
+1906,0,0,0,0,0,0,0,0,0,0,0,0,0
+1907,0,0,0,0,0,0,0,0,0,0,0,0,0
+1908,0,0,0,0,0,0,0,0,0,0,0,0,0
+1909,0,0,0,0,0,0,0,0,0,0,0,0,0
+1910,0,0,0,0,0,0,0,0,0,0,0,0,0
+1911,0,0,0,0,0,0,0,0,0,0,0,0,0
+1912,0,0,0,0,0,0,0,0,0,0,0,0,0
+1913,0,0,0,0,0,0,0,0,0,0,0,0,0
+1914,0,0,0,0,0,0,0,0,0,0,0,0,0
+1915,0,0,0,0,0,0,0,0,0,0,0,0,0
+1916,0,0,0,0,0,0,0,0,0,0,0,0,0
+1917,0,0,0,0,0,0,0,0,0,0,0,0,0
+1918,0,0,0,0,0,0,0,0,0,0,0,0,0
+1919,0,0,0,0,0,0,0,0,0,0,0,0,0
+1920,0,0,0,0,0,0,0,0,0,0,0,0,0
+1921,0,0,0,0,0,0,0,0,0,0,0,0,0
+1922,0,0,0,0,0,0,0,0,0,0,0,0,0
+1923,0,0,0,0,0,0,0,0,0,0,0,0,0
+1924,0,0,0,0,0,0,0,0,0,0,0,0,0
+1925,0,0,0,0,0,0,0,0,0,0,0,0,0
+1926,0,0,0,0,0,0,0,0,0,0,0,0,0
+1927,0,0,0,0,0,0,0,0,0,0,0,0,0
+1928,0,0,0,0,0,0,0,0,0,0,0,0,0
+1929,0,0,0,0,0,0,0,0,0,0,0,0,0
+1930,0,0,0,0,0,0,0,0,0,0,0,0,0
+1931,0,0,0,0,0,0,0,0,0,0,0,0,0
+1932,0,0,0,0,0,0,0,0,0,0,0,0,0
+1933,0,0,0,0,0,0,0,0,0,0,0,0,0
+1934,0,0,0,0,0,0,0,0,0,0,0,0,0
+1935,0,0,0,0,0,0,0,0,0,0,0,0,0
+1936,0,0,0,0,0,0,0,0,0,0,0,0,0
+1937,0,0,0,0,0,0,0,0,0,0,0,0,0
+1938,0,0,0,0,0,0,0,0,0,0,0,0,0
+1939,0,0,0,0,0,0,0,0,0,0,0,0,0
+1940,0,0,0,0,0,0,0,0,0,0,0,0,0
+1941,0,0,0,0,0,0,0,0,0,0,0,0,0
+1942,0,0,0,0,0,0,0,0,0,0,0,0,0
+1943,0,0,0,0,0,0,0,0,0,0,0,0,0
+1944,0,0,0,0,0,0,0,0,0,0,0,0,0
+1945,0,0,0,0,0,0,0,0,0,0,0,0,0
+1946,0,0,0,0,0,0,0,0,0,0,0,0,0
+1947,0,0,0,0,0,0,0,0,0,0,0,0,0
+1948,0,0,0,0,0,0,0,0,0,0,0,0,0
+1949,0,0,0,0,0,0,0,0,0,0,0,0,0
+1950,0,0,0,0,0,0,0,0,0,0,0,0,0
+1951,0,0,0,0,0,0,0,0,0,0,0,0,0
+1952,0,0,0,0,0,0,0,0,0,0,0,0,0
+1953,0,0,0,0,0,0,0,0,0,0,0,0,0
+1954,0,0,0,0,0,0,0,0,0,0,0,0,0
+1955,0,0,0,0,0,0,0,0,0,0,0,0,0
+1956,0,0,0,0,0,0,0,0,0,0,0,0,0
+1957,0,0,0,0,0,0,0,0,0,0,0,0,0
+1958,0,0,0,0,0,0,0,0,0,0,0,0,0
+1959,0,0,0,0,0,0,0,0,0,0,0,0,0
+1960,0,0,0,0,0,0,0,0,0,0,0,0,0
+1961,0,0,0,0,0,0,0,0,0,0,0,0,0
+1962,0,0,0,0,0,0,0,0,0,0,0,0,0
+1963,0,0,0,0,0,0,0,0,0,0,0,0,0
+1964,0,0,0,0,0,0,0,0,0,0,0,0,0
+1965,0,0,0,0,0,0,0,0,0,0,0,0,0
+1966,0,0,0,0,0,0,0,0,0,0,0,0,0
+1967,0,0,0,0,0,0,0,0,0,0,0,0,0
+1968,0,0,0,0,0,0,0,0,0,0,0,0,0
+1969,0,0,0,0,0,0,0,0,0,0,0,0,0
+1970,0,0,0,0,0,0,0,0,0,0,0,0,0
+1971,0,0,0,0,0,0,0,0,0,0,0,0,0
+1972,0,0,0,0,0,0,0,0,0,0,0,0,0
+1973,0,0,0,0,0,0,0,0,0,0,0,0,0
+1974,0,0,0,0,0,0,0,0,0,0,0,0,0
+1975,0,0,0,0,0,0,0,0,0,0,0,0,0
+1976,0,0,0,0,0,0,0,0,0,0,0,0,0
+1977,0,0,0,0,0,0,0,0,0,0,0,0,0
+1978,0,0,0,0,0,0,0,0,0,0,0,0,0
+1979,0,0,0,0,0,0,0,0,0,0,0,0,0
+1980,0,0,0,0,0,0,0,0,0,0,0,0,0
+1981,0,0,0,0,0,0,0,0,0,0,0,0,0
+1982,0,0,0,0,0,0,0,0,0,0,0,0,0
+1983,0,0,0,0,0,0,0,0,0,0,0,0,0
+1984,0,0,0,0,0,0,0,0,0,0,0,0,0
+1985,0,0,0,0,0,0,0,0,0,0,0,0,0
+1986,0,0,0,0,0,0,0,0,0,0,0,0,0
+1987,0,0,0,0,0,0,0,0,0,0,0,0,0
+1988,0,0,0,0,0,0,0,0,0,0,0,0,0
+1989,0,0,0,0,0,0,0,0,0,0,0,0,0
+1990,0,0,0,0,0,0,0,0,0,0,0,0,0
+1991,0,0,0,0,0,0,0,0,0,0,0,0,0
+1992,0,0,0,0,0,0,0,0,0,0,0,0,0
+1993,0,0,0,0,0,0,0,0,0,0,0,0,0
+1994,0,0,0,0,0,0,0,0,0,0,0,0,0
+1995,0,0,0,0,0,0,0,0,0,0,0,0,0
+1996,0,0,0,0,0,0,0,0,0,0,0,0,0
+1997,0,0,0,0,0,0,0,0,0,0,0,0,0
+1998,0,0,0,0,0,0,0,0,0,0,0,0,0
+1999,0,0,0,0,0,0,0,0,0,0,0,0,0
+2000,0,0,0,0,0,0,0,0,0,0,0,0,0
+2001,0,0,0,0,0,0,0,0,0,0,0,0,0
+2002,0,0,0,0,0,0,0,0,0,0,0,0,0
+2003,0,0,0,0,0,0,0,0,0,0,0,0,0
+2004,0,0,0,0,0,0,0,0,0,0,0,0,0
+2005,0,0,0,0,0,0,0,0,0,0,0,0,0
+2006,0,0,0,0,0,0,0,0,0,0,0,0,0
+2007,0,0,0,0,0,0,0,0,0,0,0,0,0
+2008,0,0,0,0,0,0,0,0,0,0,0,0,0
+2009,0,0,0,0,0,0,0,0,0,0,0,0,0
+2010,0,0,0,0,0,0,0,0,0,0,0,0,0
+2011,0,0,0,0,0,0,0,0,0,0,0,0,0
+2012,0,0,0,0,0,0,0,0,0,0,0,0,0
+2013,0,0,0,0,0,0,0,0,0,0,0,0,0
+2014,0,0,0,0,0,0,0,0,0,0,0,0,0
+2015,0,0,0,0,0,0,0,0,0,0,0,0,0
+2016,0,0,0,0,0,0,0,0,0,0,0,0,0
+2017,0,0,0,0,0,0,0,0,0,0,0,0,0
+2018,0,0,0,0,0,0,0,0,0,0,0,0,0
+2019,0,0,0,0,0,0,0,0,0,0,0,0,0
+2020,0,0,0,0,0,0,0,0,0,0,0,0,0
+2021,0,0,0,0,0,0,0,0,0,0,0,0,0
+2022,0,0,0,0,0,0,0,0,0,0,0,0,0
+2023,0,0,0,0,0,0,0,0,0,0,0,0,0
+2024,0,0,0,0,0,0,0,0,0,0,0,0,0
+2025,0,0,0,0,0,0,0,0,0,0,0,0,0
+2026,0,0,0,0,0,0,0,0,0,0,0,0,0
+2027,0,0,0,0,0,0,0,0,0,0,0,0,0
+2028,0,0,0,0,0,0,0,0,0,0,0,0,0
+2029,0,0,0,0,0,0,0,0,0,0,0,0,0
+2030,0,0,0,0,0,0,0,0,0,0,0,0,0
+2031,0,0,0,0,0,0,0,0,0,0,0,0,0
+2032,0,0,0,0,0,0,0,0,0,0,0,0,0
+2033,0,0,0,0,0,0,0,0,0,0,0,0,0
+2034,0,0,0,0,0,0,0,0,0,0,0,0,0
+2035,0,0,0,0,0,0,0,0,0,0,0,0,0
+2036,0,0,0,0,0,0,0,0,0,0,0,0,0
+2037,0,0,0,0,0,0,0,0,0,0,0,0,0
+2038,0,0,0,0,0,0,0,0,0,0,0,0,0
+2039,0,0,0,0,0,0,0,0,0,0,0,0,0
+2040,0,0,0,0,0,0,0,0,0,0,0,0,0
+2041,0,0,0,0,0,0,0,0,0,0,0,0,0
+2042,0,0,0,0,0,0,0,0,0,0,0,0,0
+2043,0,0,0,0,0,0,0,0,0,0,0,0,0
+2044,0,0,0,0,0,0,0,0,0,0,0,0,0
+2045,0,0,0,0,0,0,0,0,0,0,0,0,0
+2046,0,0,0,0,0,0,0,0,0,0,0,0,0
+2047,0,0,0,0,0,0,0,0,0,0,0,0,0
+2048,0,0,0,0,0,0,0,0,0,0,0,0,0
+2049,0,0,0,0,0,0,0,0,0,0,0,0,0
+2050,0,0,0,0,0,0,0,0,0,0,0,0,0
+2051,0,0,0,0,0,0,0,0,0,0,0,0,0
+2052,0,0,0,0,0,0,0,0,0,0,0,0,0
+2053,0,0,0,0,0,0,0,0,0,0,0,0,0
+2054,0,0,0,0,0,0,0,0,0,0,0,0,0
+2055,0,0,0,0,0,0,0,0,0,0,0,0,0
+2056,0,0,0,0,0,0,0,0,0,0,0,0,0
+2057,0,0,0,0,0,0,0,0,0,0,0,0,0
+2058,0,0,0,0,0,0,0,0,0,0,0,0,0
+2059,0,0,0,0,0,0,0,0,0,0,0,0,0
+2060,0,0,0,0,0,0,0,0,0,0,0,0,0
+2061,0,0,0,0,0,0,0,0,0,0,0,0,0
+2062,0,0,0,0,0,0,0,0,0,0,0,0,0
+2063,0,0,0,0,0,0,0,0,0,0,0,0,0
+2064,0,0,0,0,0,0,0,0,0,0,0,0,0
+2065,0,0,0,0,0,0,0,0,0,0,0,0,0
+2066,0,0,0,0,0,0,0,0,0,0,0,0,0
+2067,0,0,0,0,0,0,0,0,0,0,0,0,0
+2068,0,0,0,0,0,0,0,0,0,0,0,0,0
+2069,0,0,0,0,0,0,0,0,0,0,0,0,0
+2070,0,0,0,0,0,0,0,0,0,0,0,0,0
+2071,0,0,0,0,0,0,0,0,0,0,0,0,0
+2072,0,0,0,0,0,0,0,0,0,0,0,0,0
+2073,0,0,0,0,0,0,0,0,0,0,0,0,0
+2074,0,0,0,0,0,0,0,0,0,0,0,0,0
+2075,0,0,0,0,0,0,0,0,0,0,0,0,0
+2076,0,0,0,0,0,0,0,0,0,0,0,0,0
+2077,0,0,0,0,0,0,0,0,0,0,0,0,0
+2078,0,0,0,0,0,0,0,0,0,0,0,0,0.000639264
+2079,0,0,0,0,0,0,0,0,0,0,0,0,0.001022905
+2080,0,0,0,0,0,0,0,0,0,0,0,0,0.002884721
+2081,0,0,0,0,0,0,0,0,0,0,0,0,0.003997454
+2082,0,0,0,0,0,0,0,0,0,0,0,0,0.006597118
+2083,0,0,0,0,0,0,0,0,0,0,0,0,0.007659826
+2084,0,0,0,0,0,0,0,0,0,0,0,0,0.00800413
+2085,0,0,0,0,0,0,0,0,0,0,0,0,0.008539692
+2086,0,0,0,0,0,0,0,0,0,0,0,0,0.009300309
+2087,0,0,0,0,0,0,0,0,0,0,0,0,0.010001938
+2088,0,0,0,0,0,0,0,0,0,0,0,0,0.010972178
+2089,0,0,0,0,0,0,0,0,0,0,0,0,0.012089456
+2090,0,0,0,0,0,0,0,0,0,0,0,0,0.013364144
+2091,0,0,0,0,0,0,0,0,0,0,0,0,0.015017309
+2092,0,0,0,0,0,0,0,0,0,0,0,0,0.01712566
+2093,0,0,0,0,0,0,0,0,0,0,0,0,0.01978032
+2094,0,0,0,0,0,0,0,0,0,0,0,0,0.023335884
+2095,0,0,0,0,0,0,0,0,0,0,0,0,0.027667597
+2096,0,0,0,0,0,0,0,0,0,0,0,0,0.033215941
+2097,0,0,0,0,0,0,0,0,0,0,0,0,0.040217377
+2098,0,0,0,0,0,0,0,0,0,0,0,0,0.048882662
+2099,0,0,0,0,0,0,0,0,0,0,0,0,0.059642173
+2100,0,0,0,0,0,0,0,0,0,0,0,0,0.073175151
+2101,0,0,0,0,0,0,0,0,0,0,0,0,0.090534716
+2102,0,0,0,0,0,0,0,0,0,0,0,0,0.111470124
+2103,0,0,0,0,0,0,0,0,0,0,0,0,0.13690299
+2104,0,0,0,0,0,0,0,0,0,0,0,0,0.167810536
+2105,0,0,0,0,0,0,0,0,0,0,0,0,0.203460906
+2106,0,0,0,0,0,0,0,0,0,0,0,0,0.242871255
+2107,0,0,0,0,0,0,0,0,0,0,0,0,0.284898317
+2108,0,0,0,0,0,0,0,0,0,0,0,0,0.327177957
+2109,0,0,0,0,0,0,0,0,0,0,0,0,0.36840376
+2110,0,0,0,0,0,0,0,0,0,0,0,0,0.40800276
+2111,0,0,0,0,0,0,0,0,0,0,0,0,0.444778149
+2112,0,0,0,0,0,0,0,0,0,0,0,0,0.476537405
+2113,0,0,0,0,0,0,0,0,0,0,0,0,0.503106894
+2114,0,0,0,0,0,0,0,0,0,0,0,0,0.525317548
+2115,0,0,0,0,0,0,0,0,0,0,0,0,0.543351996
+2116,0,0,0,0,0,0,0,0,0,0,0,0,0.557252862
+2117,0,0,0,0,0,0,0,0,0,0,0,0,0.568634197
+2118,0,0,0,0,0,0,0,0,0,0,0,0,0.579029932
+2119,0,0,0,0,0,0,0,0,0,0,0,0,0.588683995
+2120,0,0,0,0,0,0,0,0,0,0,0,0,0.59889121
+2121,0,0,0,0,0,0,0,0,0,0,0,0,0.609981083
+2122,0,0,0,0,0,0,0,0,0,0,0,0,0.621362162
+2123,0,0,0,0,0,0,0,0,0,0,0,0,0.634282516
+2124,0,0,0,0,0,0,0,0,0,0,0,0,0.64854644
+2125,0,0,0,0,0,0,0,0,0,0,0,0,0.663707315
+2126,0,0,0,0,0,0,0,0,0,0,0,0,0.680046291
+2127,0,0,0,0,0,0,0,0,0,0,0,0,0.696164765
+2128,0,0,0,0,0,0,0,0,0,0,0,0,0.711964139
+2129,0,0,0,0,0,0,0,0,0,0,0,0,0.727011081
+2130,0,0,0,0,0,0,0,0,0,0,0,0,0.741301118
+2131,0,0,0,0,0,0,0,0,0,0,0,0,0.757405387
+2132,0,0,0,0,0,0,0,0,0,0,0,0,0.772070514
+2133,0,0,0,0,0,0,0,0,0,0,0,0,0.78558074
+2134,0,0,0,0,0,0,0,0,0,0,0,0,0.798238093
+2135,0,0,0,0,0,0,0,0,0,0,0,0,0.809677071
+2136,0,0,0,0,0,0,0,0,0,0,0,0,0.819701739
+2137,0,0,0,0,0,0,0,0,0,0,0,0,0.82859933
+2138,0,0,0,0,0,0,0,0,0,0,0,0,0.836721896
+2139,0,0,0,0,0,0,0,0,0,0,0,0,0.844443431
+2140,0,0,0,0,0,0,0,0,0,0,0,0,0.851107219
+2141,0,0,0,0,0,0,0,0,0,0,0,0,0.853252319
+2142,0,0,0,0,0,0,0,0,0,0,0,0,0.854746271
+2143,0,0,0,0,0,0,0,0,0,0,0,0,0.85617419
+2144,0,0,0,0,0,0,0,0,0,0,0,0,0.857820928
+2145,0,0,0,0,0,0,0,0,0,0,0,0,0.859531818
+2146,0,0,0,0,0,0,0,0,0,0,0,0,0.861459829
+2147,0,0,0,0,0,0,0,0,0,0,0,0,0.863256985
+2148,0,0,0,0,0,0,0,0,0,0,0,0,0.865138808
+2149,0,0,0,0,0,0,0,0,0,0,0,0,0.867319035
+2150,0,0,0,0,0,0,0,0,0,0,0,0,0.869696339
+2151,0,0,0,0,0,0,0,0,0,0,0,0,0.874301992
+2152,0,0,0,0,0,0,0,0,0,0,0,0,0.878588437
+2153,0,0,0,0,0,0,0,0,0,0,0,0,0.882438825
+2154,0,0,0,0,0,0,0,0,0,0,0,0,0.885928758
+2155,0,0,0,0,0,0,0,0,0,0,0,0,0.889473121
+2156,0,0,0,0,0,0,0,0,0,0,0,0,0.89322574
+2157,0,0,0,0,0,0,0,0,0,0,0,0,0.896696495
+2158,0,0,0,0,0,0,0,0,0,0,0,0,0.899896619
+2159,0,0,0,0,0,0,0,0,0,0,0,0,0.902596288
+2160,0,0,0,0,0,0,0,0,0,0,0,0,0.90483074
+2161,0,0,0,0,0,0,0,0,0,0,0,0,0.905524618
+2162,0,0,0,0,0,0,0,0,0,0,0,0,0.905665281
+2163,0,0,0,0,0,0,0,0,0,0,0,0,0.905502587
+2164,0,0,0,0,0,0,0,0,0,0,0,0,0.905157893
+2165,0,0,0,0,0,0,0,0,0,0,0,0,0.904782854
+2166,0,0,0,0,0,0,0,0,0,0,0,0,0.90408183
+2167,0,0,0,0,0,0,0,0,0,0,0,0,0.903347495
+2168,0,0,0,0,0,0,0,0,0,0,0,0,0.902760831
+2169,0,0,0,0,0,0,0,0,0,0,0,0,0.902377006
+2170,0,0,0,0,0,0,0,0,0,0,0,0,0.901982966
+2171,0,0,0,0,0,0,0,0,0,0,0,0,0.903423562
+2172,0,0,0,0,0,0,0,0,0,0,0,0,0.904312941
+2173,0,0,0,0,0,0,0,0,0,0,0,0,0.905315323
+2174,0,0,0,0,0,0,0,0,0,0,0,0,0.906446178
+2175,0,0,0,0,0,0,0,0,0,0,0,0,0.90809207
+2176,0,0,0,0,0,0,0,0,0,0,0,0,0.910123185
+2177,0,0,0,0,0,0,0,0,0,0,0,0,0.912949979
+2178,0,0,0,0,0,0,0,0,0,0,0,0,0.915584774
+2179,0,0,0,0,0,0,0,0,0,0,0,0,0.918444254
+2180,0,0,0,0,0,0,0,0,0,0,0,0,0.921302412
+2181,0,0,0,0,0,0,0,0,0,0,0,0,0.924337167
+2182,0,0,0,0,0,0,0,0,0,0,0,0,0.927218563
+2183,0,0,0,0,0,0,0,0,0,0,0,0,0.929740263
+2184,0,0,0,0,0,0,0,0,0,0,0,0,0.931921865
+2185,0,0,0,0,0,0,0,0,0,0,0,0,0.934142166
+2186,0,0,0,0,0,0,0,0,0,0,0,0,0.935906112
+2187,0,0,0,0,0,0,0,0,0,0,0,0,0.937086137
+2188,0,0,0,0,0,0,0,0,0,0,0,0,0.937641167
+2189,0,0,0,0,0,0,0,0,0,0,0,0,0.938301157
+2190,0,0,0,0,0,0,0,0,0,0,0,0,0.937652085
+2191,0,0,0,0,0,0,0,0,0,0,0,0,0.940440758
+2192,0,0,0,0,0,0,0,0,0,0,0,0,0.942517533
+2193,0,0,0,0,0,0,0,0,0,0,0,0,0.943259037
+2194,0,0,0,0,0,0,0,0,0,0,0,0,0.943031026
+2195,0,0,0,0,0,0,0,0,0,0,0,0,0.942117106
+2196,0,0,0,0,0,0,0,0,0,0,0,0,0.940631648
+2197,0,0,0,0,0,0,0,0,0,0,0,0,0.938427922
+2198,0,0,0,0,0,0,0,0,0,0,0,0,0.936660033
+2199,0,0,0,0,0,0,0,0,0,0,0,0,0.935256327
+2200,0,0,0,0,0,0,0,0,0,0,0,0,0.933022239
+2201,0,0,0,0,0,0,0,0,0,0,0,0,0.926879998
+2202,0,0,0,0,0,0,0,0,0,0,0,0,0.921056996
+2203,0,0,0,0,0,0,0,0,0,0,0,0,0.915482617
+2204,0,0,0,0,0,0,0,0,0,0,0,0,0.911020114
+2205,0,0,0,0,0,0,0,0,0,0,0,0,0.908292872
+2206,0,0,0,0,0,0,0,0,0,0,0,0,0.907283492
+2207,0,0,0,0,0,0,0,0,0,0,0,0,0.90819092
+2208,0,0,0,0,0,0,0,0,0,0,0,0,0.911168883
+2209,0,0,0,0,0,0,0,0,0,0,0,0,0.916188526
+2210,0,0,0,0,0,0,0,0,0,0,0,0,0.922854635
+2211,0,0,0,0,0,0,0,0,0,0,0,0,0.920605167
+2212,0,0,0,0,0,0,0,0,0,0,0,0,0.919482312
+2213,0,0,0,0,0,0,0,0,0,0,0,0,0.919489205
+2214,0,0,0,0,0,0,0,0,0,0,0,0,0.921276392
+2215,0,0,0,0,0,0,0,0,0,0,0,0,0.924526038
+2216,0,0,0,0,0,0,0,0,0,0,0,0,0.927732919
+2217,0,0,0,0,0,0,0,0,0,0,0,0,0.931974489
+2218,0,0,0,0,0,0,0,0,0,0,0,0,0.936769555
+2219,0,0,0,0,0,0,0,0,0,0,0,0,0.941482728
+2220,0,0,0,0,0,0,0,0,0,0,0,0,0.946801994
+2221,0,0,0,0,0,0,0,0,0,0,0,0,0.951202607
+2222,0,0,0,0,0,0,0,0,0,0,0,0,0.954436663
+2223,0,0,0,0,0,0,0,0,0,0,0,0,0.957046915
+2224,0,0,0,0,0,0,0,0,0,0,0,0,0.959729173
+2225,0,0,0,0,0,0,0,0,0,0,0,0,0.962538601
+2226,0,0,0,0,0,0,0,0,0,0,0,0,0.964857726
+2227,0,0,0,0,0,0,0,0,0,0,0,0,0.966042031
+2228,0,0,0,0,0,0,0,0,0,0,0,0,0.966647037
+2229,0,0,0,0,0,0,0,0,0,0,0,0,0.966309991
+2230,0,0,0,0,0,0,0,0,0,0,0,0,0.965460063
+2231,0,0,0,0,0,0,0,0,0,0,0,0,0.964841278
+2232,0,0,0,0,0,0,0,0,0,0,0,0,0.963655749
+2233,0,0,0,0,0,0,0,0,0,0,0,0,0.961698492
+2234,0,0,0,0,0,0,0,0,0,0,0,0,0.959453949
+2235,0,0,0,0,0,0,0,0,0,0,0,0,0.957327053
+2236,0,0,0,0,0,0,0,0,0,0,0,0,0.955140475
+2237,0,0,0,0,0,0,0,0,0,0,0,0,0.953558145
+2238,0,0,0,0,0,0,0,0,0,0,0,0,0.95273179
+2239,0,0,0,0,0,0,0,0,0,0,0,0,0.952180853
+2240,0,0,0,0,0,0,0,0,0,0,0,0,0.951730689
+2241,0,0,0,0,0,0,0,0,0,0,0,0,0.952145994
+2242,0,0,0,0,0,0,0,0,0,0,0,0,0.952641408
+2243,0,0,0,0,0,0,0,0,0,0,0,0,0.954056643
+2244,0,0,0,0,0,0,0,0,0,0,0,0,0.957078482
+2245,0,0,0,0,0,0,0,0,0,0,0,0,0.960638803
+2246,0,0,0,0,0,0,0,0,0,0,0,0,0.964221982
+2247,0,0,0,0,0,0,0,0,0,0,0,0,0.968307493
+2248,0,0,0,0,0,0,0,0,0,0,0,0,0.972691041
+2249,0,0,0,0,0,0,0,0,0,0,0,0,0.97742349
+2250,0,0,0,0,0,0,0,0,0,0,0,0,0.982898416
+2251,0,0,0,0,0,0,0,0,0,0,0,0,0.98714443
+2252,0,0,0,0,0,0,0,0,0,0,0,0,0.990734152
+2253,0,0,0,0,0,0,0,0,0,0,0,0,0.993982826
+2254,0,0,0,0,0,0,0,0,0,0,0,0,0.996786808
+2255,0,0,0,0,0,0,0,0,0,0,0,0,0.998752904
+2256,0,0,0,0,0,0,0,0,0,0,0,0,1
+2257,0,0,0,0,0,0,0,0,0,0,0,0,0.999927455
+2258,0,0,0,0,0,0,0,0,0,0,0,0,0.999151921
+2259,0,0,0,0,0,0,0,0,0,0,0,0,0.997129452
+2260,0,0,0,0,0,0,0,0,0,0,0,0,0.993883695
+2261,0,0,0,0,0,0,0,0,0,0,0,0,0.989685968
+2262,0,0,0,0,0,0,0,0,0,0,0,0,0.983735405
+2263,0,0,0,0,0,0,0,0,0,0,0,0,0.976212761
+2264,0,0,0,0,0,0,0,0,0,0,0,0,0.967813199
+2265,0,0,0,0,0,0,0,0,0,0,0,0,0.958342887
+2266,0,0,0,0,0,0,0,0,0,0,0,0,0.948440151
+2267,0,0,0,0,0,0,0,0,0,0,0,0,0.9382028
+2268,0,0,0,0,0,0,0,0,0,0,0,0,0.927724853
+2269,0,0,0,0,0,0,0,0,0,0,0,0,0.917038819
+2270,0,0,0,0,0,0,0,0,0,0,0,0,0.905999348
+2271,0,0,0,0,0,0,0,0,0,0,0,0,0.893868367
+2272,0,0,0,0,0,0,0,0,0,0,0,0,0.881682515
+2273,0,0,0,0,0,0,0,0,0,0,0,0,0.86864716
+2274,0,0,0,0,0,0,0,0,0,0,0,0,0.854635458
+2275,0,0,0,0,0,0,0,0,0,0,0,0,0.840619936
+2276,0,0,0,0,0,0,0,0,0,0,0,0,0.826015692
+2277,0,0,0,0,0,0,0,0,0,0,0,0,0.809516209
+2278,0,0,0,0,0,0,0,0,0,0,0,0,0.791866591
+2279,0,0,0,0,0,0,0,0,0,0,0,0,0.772443017
+2280,0,0,0,0,0,0,0,0,0,0,0,0,0.749106638
+2281,0,0,0,0,0,0,0,0,0,0,0,0,0.720345599
+2282,0,0,0,0,0,0,0,0,0,0,0,0,0.688185271
+2283,0,0,0,0,0,0,0,0,0,0,0,0,0.651282733
+2284,0,0,0,0,0,0,0,0,0,0,0,0,0.610049759
+2285,0,0,0,0,0,0,0,0,0,0,0,0,0.56603087
+2286,0,0,0,0,0,0,0,0,0,0,0,0,0.520969977
+2287,0,0,0,0,0,0,0,0,0,0,0,0,0.474659094
+2288,0,0,0,0,0,0,0,0,0,0,0,0,0.429259293
+2289,0,0,0,0,0,0,0,0,0,0,0,0,0.38585714
+2290,0,0,0,0,0,0,0,0,0,0,0,0,0.342091763
+2291,0,0,0,0,0,0,0,0,0,0,0,0,0.300680041
+2292,0,0,0,0,0,0,0,0,0,0,0,0,0.263176181
+2293,0,0,0,0,0,0,0,0,0,0,0,0,0.227703987
+2294,0,0,0,0,0,0,0,0,0,0,0,0,0.195720706
+2295,0,0,0,0,0,0,0,0,0,0,0,0,0.168090024
+2296,0,0,0,0,0,0,0,0,0,0,0,0,0.144679716
+2297,0,0,0,0,0,0,0,0,0,0,0,0,0.124830647
+2298,0,0,0,0,0,0,0,0,0,0,0,0,0.108237331
+2299,0,0,0,0,0,0,0,0,0,0,0,0,0.09440058
+2300,0,0,0,0,0,0,0,0,0,0,0,0,0.082363039
+2301,0,0,0,0,0,0,0,0,0,0,0,0,0.071500068
+2302,0,0,0,0,0,0,0,0,0,0,0,0,0.062690603
+2303,0,0,0,0,0,0,0,0,0,0,0,0,0.054985448
+2304,0,0,0,0,0,0,0,0,0,0,0,0,0.048194534
+2305,0,0,0,0,0,0,0,0,0,0,0,0,0.042864117
+2306,0,0,0,0,0,0,0,0,0,0,0,0,0.038598228
+2307,0,0,0,0,0,0,0,0,0,0,0,0,0.034947252
+2308,0,0,0,0,0,0,0,0,0,0,0,0,0.031998848
+2309,0,0,0,0,0,0,0,0,0,0,0,0,0.029587869
+2310,0,0,0,0,0,0,0,0,0,0,0,0,0.027418116
+2311,0,0,0,0,0,0,0,0,0,0,0,0,0.025576973
+2312,0,0,0,0,0,0,0,0,0,0,0,0,0.023959421
+2313,0,0,0,0,0,0,0,0,0,0,0,0,0.021671692
+2314,0,0,0,0,0,0,0,0,0,0,0,0,0.019147972
+2315,0,0,0,0,0,0,0,0,0,0,0,0,0.016331132
+2316,0,0,0,0,0,0,0,0,0,0,0,0,0.010988591
+2317,0,0,0,0,0,0,0,0,0,0,0,0,0.007378602
+2318,0,0,0,0,0,0,0,0,0,0,0,0,0.006510601
+2319,0,0,0,0,0,0,0,0,0,0,0,0,0.004709556
+2320,0,0,0,0,0,0,0,0,0,0,0,0,0.002065107
+2321,0,0,0,0,0,0,0,0,0,0,0,0,0
+2322,0,0,0,0,0,0,0,0,0,0,0,0,0
+2323,0,0,0,0,0,0,0,0,0,0,0,0,0
+2324,0,0,0,0,0,0,0,0,0,0,0,0,0
+2325,0,0,0,0,0,0,0,0,0,0,0,0,0
+2326,0,0,0,0,0,0,0,0,0,0,0,0,0
+2327,0,0,0,0,0,0,0,0,0,0,0,0,0
+2328,0,0,0,0,0,0,0,0,0,0,0,0,0
+2329,0,0,0,0,0,0,0,0,0,0,0,0,0
+2330,0,0,0,0,0,0,0,0,0,0,0,0,0
+2331,0,0,0,0,0,0,0,0,0,0,0,0,0
+2332,0,0,0,0,0,0,0,0,0,0,0,0,0
+2333,0,0,0,0,0,0,0,0,0,0,0,0,0
+2334,0,0,0,0,0,0,0,0,0,0,0,0,0
+2335,0,0,0,0,0,0,0,0,0,0,0,0,0
+2336,0,0,0,0,0,0,0,0,0,0,0,0,0
+2337,0,0,0,0,0,0,0,0,0,0,0,0,0
+2338,0,0,0,0,0,0,0,0,0,0,0,0,0
+2339,0,0,0,0,0,0,0,0,0,0,0,0,0
+2340,0,0,0,0,0,0,0,0,0,0,0,0,0
+2341,0,0,0,0,0,0,0,0,0,0,0,0,0
+2342,0,0,0,0,0,0,0,0,0,0,0,0,0
+2343,0,0,0,0,0,0,0,0,0,0,0,0,0
+2344,0,0,0,0,0,0,0,0,0,0,0,0,0
+2345,0,0,0,0,0,0,0,0,0,0,0,0,0
+2346,0,0,0,0,0,0,0,0,0,0,0,0,0
+2347,0,0,0,0,0,0,0,0,0,0,0,0,0
+2348,0,0,0,0,0,0,0,0,0,0,0,0,0
+2349,0,0,0,0,0,0,0,0,0,0,0,0,0
+2350,0,0,0,0,0,0,0,0,0,0,0,0,0
+2351,0,0,0,0,0,0,0,0,0,0,0,0,0
+2352,0,0,0,0,0,0,0,0,0,0,0,0,0
+2353,0,0,0,0,0,0,0,0,0,0,0,0,0
+2354,0,0,0,0,0,0,0,0,0,0,0,0,0
+2355,0,0,0,0,0,0,0,0,0,0,0,0,0
+2356,0,0,0,0,0,0,0,0,0,0,0,0,0
+2357,0,0,0,0,0,0,0,0,0,0,0,0,0
+2358,0,0,0,0,0,0,0,0,0,0,0,0,0
+2359,0,0,0,0,0,0,0,0,0,0,0,0,0
+2360,0,0,0,0,0,0,0,0,0,0,0,0,0
+2361,0,0,0,0,0,0,0,0,0,0,0,0,0
+2362,0,0,0,0,0,0,0,0,0,0,0,0,0
+2363,0,0,0,0,0,0,0,0,0,0,0,0,0
+2364,0,0,0,0,0,0,0,0,0,0,0,0,0
+2365,0,0,0,0,0,0,0,0,0,0,0,0,0
+2366,0,0,0,0,0,0,0,0,0,0,0,0,0
+2367,0,0,0,0,0,0,0,0,0,0,0,0,0
+2368,0,0,0,0,0,0,0,0,0,0,0,0,0
+2369,0,0,0,0,0,0,0,0,0,0,0,0,0
+2370,0,0,0,0,0,0,0,0,0,0,0,0,0
+2371,0,0,0,0,0,0,0,0,0,0,0,0,0
+2372,0,0,0,0,0,0,0,0,0,0,0,0,0
+2373,0,0,0,0,0,0,0,0,0,0,0,0,0
+2374,0,0,0,0,0,0,0,0,0,0,0,0,0
+2375,0,0,0,0,0,0,0,0,0,0,0,0,0
+2376,0,0,0,0,0,0,0,0,0,0,0,0,0
+2377,0,0,0,0,0,0,0,0,0,0,0,0,0
+2378,0,0,0,0,0,0,0,0,0,0,0,0,0
+2379,0,0,0,0,0,0,0,0,0,0,0,0,0
+2380,0,0,0,0,0,0,0,0,0,0,0,0,0
+2381,0,0,0,0,0,0,0,0,0,0,0,0,0
+2382,0,0,0,0,0,0,0,0,0,0,0,0,0
+2383,0,0,0,0,0,0,0,0,0,0,0,0,0
+2384,0,0,0,0,0,0,0,0,0,0,0,0,0
+2385,0,0,0,0,0,0,0,0,0,0,0,0,0
+2386,0,0,0,0,0,0,0,0,0,0,0,0,0
+2387,0,0,0,0,0,0,0,0,0,0,0,0,0
+2388,0,0,0,0,0,0,0,0,0,0,0,0,0
+2389,0,0,0,0,0,0,0,0,0,0,0,0,0
+2390,0,0,0,0,0,0,0,0,0,0,0,0,0
+2391,0,0,0,0,0,0,0,0,0,0,0,0,0
+2392,0,0,0,0,0,0,0,0,0,0,0,0,0
+2393,0,0,0,0,0,0,0,0,0,0,0,0,0
+2394,0,0,0,0,0,0,0,0,0,0,0,0,0
+2395,0,0,0,0,0,0,0,0,0,0,0,0,0
+2396,0,0,0,0,0,0,0,0,0,0,0,0,0
+2397,0,0,0,0,0,0,0,0,0,0,0,0,0
+2398,0,0,0,0,0,0,0,0,0,0,0,0,0
+2399,0,0,0,0,0,0,0,0,0,0,0,0,0
+2400,0,0,0,0,0,0,0,0,0,0,0,0,0
+2401,0,0,0,0,0,0,0,0,0,0,0,0,0
+2402,0,0,0,0,0,0,0,0,0,0,0,0,0
+2403,0,0,0,0,0,0,0,0,0,0,0,0,0
+2404,0,0,0,0,0,0,0,0,0,0,0,0,0
+2405,0,0,0,0,0,0,0,0,0,0,0,0,0
+2406,0,0,0,0,0,0,0,0,0,0,0,0,0
+2407,0,0,0,0,0,0,0,0,0,0,0,0,0
+2408,0,0,0,0,0,0,0,0,0,0,0,0,0
+2409,0,0,0,0,0,0,0,0,0,0,0,0,0
+2410,0,0,0,0,0,0,0,0,0,0,0,0,0
+2411,0,0,0,0,0,0,0,0,0,0,0,0,0
+2412,0,0,0,0,0,0,0,0,0,0,0,0,0
+2413,0,0,0,0,0,0,0,0,0,0,0,0,0
+2414,0,0,0,0,0,0,0,0,0,0,0,0,0
+2415,0,0,0,0,0,0,0,0,0,0,0,0,0
+2416,0,0,0,0,0,0,0,0,0,0,0,0,0
+2417,0,0,0,0,0,0,0,0,0,0,0,0,0
+2418,0,0,0,0,0,0,0,0,0,0,0,0,0
+2419,0,0,0,0,0,0,0,0,0,0,0,0,0
+2420,0,0,0,0,0,0,0,0,0,0,0,0,0
+2421,0,0,0,0,0,0,0,0,0,0,0,0,0
+2422,0,0,0,0,0,0,0,0,0,0,0,0,0
+2423,0,0,0,0,0,0,0,0,0,0,0,0,0
+2424,0,0,0,0,0,0,0,0,0,0,0,0,0
+2425,0,0,0,0,0,0,0,0,0,0,0,0,0
+2426,0,0,0,0,0,0,0,0,0,0,0,0,0
+2427,0,0,0,0,0,0,0,0,0,0,0,0,0
+2428,0,0,0,0,0,0,0,0,0,0,0,0,0
+2429,0,0,0,0,0,0,0,0,0,0,0,0,0
+2430,0,0,0,0,0,0,0,0,0,0,0,0,0
+2431,0,0,0,0,0,0,0,0,0,0,0,0,0
+2432,0,0,0,0,0,0,0,0,0,0,0,0,0
+2433,0,0,0,0,0,0,0,0,0,0,0,0,0
+2434,0,0,0,0,0,0,0,0,0,0,0,0,0
+2435,0,0,0,0,0,0,0,0,0,0,0,0,0
+2436,0,0,0,0,0,0,0,0,0,0,0,0,0
+2437,0,0,0,0,0,0,0,0,0,0,0,0,0
+2438,0,0,0,0,0,0,0,0,0,0,0,0,0
+2439,0,0,0,0,0,0,0,0,0,0,0,0,0
+2440,0,0,0,0,0,0,0,0,0,0,0,0,0
+2441,0,0,0,0,0,0,0,0,0,0,0,0,0
+2442,0,0,0,0,0,0,0,0,0,0,0,0,0
+2443,0,0,0,0,0,0,0,0,0,0,0,0,0
+2444,0,0,0,0,0,0,0,0,0,0,0,0,0
+2445,0,0,0,0,0,0,0,0,0,0,0,0,0
+2446,0,0,0,0,0,0,0,0,0,0,0,0,0
+2447,0,0,0,0,0,0,0,0,0,0,0,0,0
+2448,0,0,0,0,0,0,0,0,0,0,0,0,0
+2449,0,0,0,0,0,0,0,0,0,0,0,0,0
+2450,0,0,0,0,0,0,0,0,0,0,0,0,0
+2451,0,0,0,0,0,0,0,0,0,0,0,0,0
+2452,0,0,0,0,0,0,0,0,0,0,0,0,0
+2453,0,0,0,0,0,0,0,0,0,0,0,0,0
+2454,0,0,0,0,0,0,0,0,0,0,0,0,0
+2455,0,0,0,0,0,0,0,0,0,0,0,0,0
+2456,0,0,0,0,0,0,0,0,0,0,0,0,0
+2457,0,0,0,0,0,0,0,0,0,0,0,0,0
+2458,0,0,0,0,0,0,0,0,0,0,0,0,0
+2459,0,0,0,0,0,0,0,0,0,0,0,0,0
+2460,0,0,0,0,0,0,0,0,0,0,0,0,0
+2461,0,0,0,0,0,0,0,0,0,0,0,0,0
+2462,0,0,0,0,0,0,0,0,0,0,0,0,0
+2463,0,0,0,0,0,0,0,0,0,0,0,0,0
+2464,0,0,0,0,0,0,0,0,0,0,0,0,0
+2465,0,0,0,0,0,0,0,0,0,0,0,0,0
+2466,0,0,0,0,0,0,0,0,0,0,0,0,0
+2467,0,0,0,0,0,0,0,0,0,0,0,0,0
+2468,0,0,0,0,0,0,0,0,0,0,0,0,0
+2469,0,0,0,0,0,0,0,0,0,0,0,0,0
+2470,0,0,0,0,0,0,0,0,0,0,0,0,0
+2471,0,0,0,0,0,0,0,0,0,0,0,0,0
+2472,0,0,0,0,0,0,0,0,0,0,0,0,0
+2473,0,0,0,0,0,0,0,0,0,0,0,0,0
+2474,0,0,0,0,0,0,0,0,0,0,0,0,0
+2475,0,0,0,0,0,0,0,0,0,0,0,0,0
+2476,0,0,0,0,0,0,0,0,0,0,0,0,0
+2477,0,0,0,0,0,0,0,0,0,0,0,0,0
+2478,0,0,0,0,0,0,0,0,0,0,0,0,0
+2479,0,0,0,0,0,0,0,0,0,0,0,0,0
+2480,0,0,0,0,0,0,0,0,0,0,0,0,0
+2481,0,0,0,0,0,0,0,0,0,0,0,0,0
+2482,0,0,0,0,0,0,0,0,0,0,0,0,0
+2483,0,0,0,0,0,0,0,0,0,0,0,0,0
+2484,0,0,0,0,0,0,0,0,0,0,0,0,0
+2485,0,0,0,0,0,0,0,0,0,0,0,0,0
+2486,0,0,0,0,0,0,0,0,0,0,0,0,0
+2487,0,0,0,0,0,0,0,0,0,0,0,0,0
+2488,0,0,0,0,0,0,0,0,0,0,0,0,0
+2489,0,0,0,0,0,0,0,0,0,0,0,0,0
+2490,0,0,0,0,0,0,0,0,0,0,0,0,0
+2491,0,0,0,0,0,0,0,0,0,0,0,0,0
+2492,0,0,0,0,0,0,0,0,0,0,0,0,0
+2493,0,0,0,0,0,0,0,0,0,0,0,0,0
+2494,0,0,0,0,0,0,0,0,0,0,0,0,0
+2495,0,0,0,0,0,0,0,0,0,0,0,0,0
+2496,0,0,0,0,0,0,0,0,0,0,0,0,0
+2497,0,0,0,0,0,0,0,0,0,0,0,0,0
+2498,0,0,0,0,0,0,0,0,0,0,0,0,0
+2499,0,0,0,0,0,0,0,0,0,0,0,0,0
+2500,0,0,0,0,0,0,0,0,0,0,0,0,0
+2501,0,0,0,0,0,0,0,0,0,0,0,0,0
+2502,0,0,0,0,0,0,0,0,0,0,0,0,0
+2503,0,0,0,0,0,0,0,0,0,0,0,0,0
+2504,0,0,0,0,0,0,0,0,0,0,0,0,0
+2505,0,0,0,0,0,0,0,0,0,0,0,0,0
+2506,0,0,0,0,0,0,0,0,0,0,0,0,0
+2507,0,0,0,0,0,0,0,0,0,0,0,0,0
+2508,0,0,0,0,0,0,0,0,0,0,0,0,0
+2509,0,0,0,0,0,0,0,0,0,0,0,0,0
+2510,0,0,0,0,0,0,0,0,0,0,0,0,0
+2511,0,0,0,0,0,0,0,0,0,0,0,0,0
+2512,0,0,0,0,0,0,0,0,0,0,0,0,0
+2513,0,0,0,0,0,0,0,0,0,0,0,0,0
+2514,0,0,0,0,0,0,0,0,0,0,0,0,0
+2515,0,0,0,0,0,0,0,0,0,0,0,0,0
+2516,0,0,0,0,0,0,0,0,0,0,0,0,0
+2517,0,0,0,0,0,0,0,0,0,0,0,0,0
+2518,0,0,0,0,0,0,0,0,0,0,0,0,0
+2519,0,0,0,0,0,0,0,0,0,0,0,0,0
+2520,0,0,0,0,0,0,0,0,0,0,0,0,0
+2521,0,0,0,0,0,0,0,0,0,0,0,0,0
+2522,0,0,0,0,0,0,0,0,0,0,0,0,0
+2523,0,0,0,0,0,0,0,0,0,0,0,0,0
+2524,0,0,0,0,0,0,0,0,0,0,0,0,0
+2525,0,0,0,0,0,0,0,0,0,0,0,0,0
+2526,0,0,0,0,0,0,0,0,0,0,0,0,0
+2527,0,0,0,0,0,0,0,0,0,0,0,0,0
+2528,0,0,0,0,0,0,0,0,0,0,0,0,0
+2529,0,0,0,0,0,0,0,0,0,0,0,0,0
+2530,0,0,0,0,0,0,0,0,0,0,0,0,0
+2531,0,0,0,0,0,0,0,0,0,0,0,0,0
+2532,0,0,0,0,0,0,0,0,0,0,0,0,0
+2533,0,0,0,0,0,0,0,0,0,0,0,0,0
+2534,0,0,0,0,0,0,0,0,0,0,0,0,0
+2535,0,0,0,0,0,0,0,0,0,0,0,0,0
+2536,0,0,0,0,0,0,0,0,0,0,0,0,0
+2537,0,0,0,0,0,0,0,0,0,0,0,0,0
+2538,0,0,0,0,0,0,0,0,0,0,0,0,0
+2539,0,0,0,0,0,0,0,0,0,0,0,0,0
+2540,0,0,0,0,0,0,0,0,0,0,0,0,0
+2541,0,0,0,0,0,0,0,0,0,0,0,0,0
+2542,0,0,0,0,0,0,0,0,0,0,0,0,0
+2543,0,0,0,0,0,0,0,0,0,0,0,0,0
+2544,0,0,0,0,0,0,0,0,0,0,0,0,0
+2545,0,0,0,0,0,0,0,0,0,0,0,0,0
+2546,0,0,0,0,0,0,0,0,0,0,0,0,0
+2547,0,0,0,0,0,0,0,0,0,0,0,0,0
+2548,0,0,0,0,0,0,0,0,0,0,0,0,0
+2549,0,0,0,0,0,0,0,0,0,0,0,0,0
+2550,0,0,0,0,0,0,0,0,0,0,0,0,0
+2551,0,0,0,0,0,0,0,0,0,0,0,0,0
+2552,0,0,0,0,0,0,0,0,0,0,0,0,0
+2553,0,0,0,0,0,0,0,0,0,0,0,0,0
+2554,0,0,0,0,0,0,0,0,0,0,0,0,0
+2555,0,0,0,0,0,0,0,0,0,0,0,0,0
+2556,0,0,0,0,0,0,0,0,0,0,0,0,0
+2557,0,0,0,0,0,0,0,0,0,0,0,0,0
+2558,0,0,0,0,0,0,0,0,0,0,0,0,0
+2559,0,0,0,0,0,0,0,0,0,0,0,0,0
+2560,0,0,0,0,0,0,0,0,0,0,0,0,0
+2561,0,0,0,0,0,0,0,0,0,0,0,0,0
+2562,0,0,0,0,0,0,0,0,0,0,0,0,0
+2563,0,0,0,0,0,0,0,0,0,0,0,0,0
+2564,0,0,0,0,0,0,0,0,0,0,0,0,0
+2565,0,0,0,0,0,0,0,0,0,0,0,0,0
+2566,0,0,0,0,0,0,0,0,0,0,0,0,0
+2567,0,0,0,0,0,0,0,0,0,0,0,0,0
+2568,0,0,0,0,0,0,0,0,0,0,0,0,0
+2569,0,0,0,0,0,0,0,0,0,0,0,0,0
+2570,0,0,0,0,0,0,0,0,0,0,0,0,0
+2571,0,0,0,0,0,0,0,0,0,0,0,0,0
+2572,0,0,0,0,0,0,0,0,0,0,0,0,0
+2573,0,0,0,0,0,0,0,0,0,0,0,0,0
+2574,0,0,0,0,0,0,0,0,0,0,0,0,0
+2575,0,0,0,0,0,0,0,0,0,0,0,0,0
+2576,0,0,0,0,0,0,0,0,0,0,0,0,0
+2577,0,0,0,0,0,0,0,0,0,0,0,0,0
+2578,0,0,0,0,0,0,0,0,0,0,0,0,0
+2579,0,0,0,0,0,0,0,0,0,0,0,0,0
+2580,0,0,0,0,0,0,0,0,0,0,0,0,0
+2581,0,0,0,0,0,0,0,0,0,0,0,0,0
+2582,0,0,0,0,0,0,0,0,0,0,0,0,0
+2583,0,0,0,0,0,0,0,0,0,0,0,0,0
+2584,0,0,0,0,0,0,0,0,0,0,0,0,0
+2585,0,0,0,0,0,0,0,0,0,0,0,0,0
+2586,0,0,0,0,0,0,0,0,0,0,0,0,0
+2587,0,0,0,0,0,0,0,0,0,0,0,0,0
+2588,0,0,0,0,0,0,0,0,0,0,0,0,0
+2589,0,0,0,0,0,0,0,0,0,0,0,0,0
+2590,0,0,0,0,0,0,0,0,0,0,0,0,0
+2591,0,0,0,0,0,0,0,0,0,0,0,0,0
+2592,0,0,0,0,0,0,0,0,0,0,0,0,0
+2593,0,0,0,0,0,0,0,0,0,0,0,0,0
+2594,0,0,0,0,0,0,0,0,0,0,0,0,0
+2595,0,0,0,0,0,0,0,0,0,0,0,0,0
+2596,0,0,0,0,0,0,0,0,0,0,0,0,0
+2597,0,0,0,0,0,0,0,0,0,0,0,0,0
+2598,0,0,0,0,0,0,0,0,0,0,0,0,0
+2599,0,0,0,0,0,0,0,0,0,0,0,0,0
+2600,0,0,0,0,0,0,0,0,0,0,0,0,0
Copied: grass/branches/releasebranch_7_4/imagery/i.atcorr/sensors_csv/sentinel_2B_msi.csv (from rev 72128, grass/trunk/imagery/i.atcorr/sensors_csv/sentinel_2B_msi.csv)
--- grass/branches/releasebranch_7_4/imagery/i.atcorr/sensors_csv/sentinel_2B_msi.csv (rev 0)
+++ grass/branches/releasebranch_7_4/imagery/i.atcorr/sensors_csv/sentinel_2B_msi.csv 2018-03-24 16:50:40 UTC (rev 72557)
@@ -0,0 +1,4604 @@
+SR_WL,SR_AV_B1,SR_AV_B2,SR_AV_B3,SR_AV_B4,SR_AV_B5,SR_AV_B6,SR_AV_B7,SR_AV_B8,SR_AV_B8A,SR_AV_B9,SR_AV_B10,SR_AV_B11,SR_AV_B12
+300,0,0,0,0,0,0,0,0,0,0,0,0,0
+301,0,0,0,0,0,0,0,0,0,0,0,0,0
+302,0,0,0,0,0,0,0,0,0,0,0,0,0
+303,0,0,0,0,0,0,0,0,0,0,0,0,0
+304,0,0,0,0,0,0,0,0,0,0,0,0,0
+305,0,0,0,0,0,0,0,0,0,0,0,0,0
+306,0,0,0,0,0,0,0,0,0,0,0,0,0
+307,0,0,0,0,0,0,0,0,0,0,0,0,0
+308,0,0,0,0,0,0,0,0,0,0,0,0,0
+309,0,0,0,0,0,0,0,0,0,0,0,0,0
+310,0,0,0,0,0,0,0,0,0,0,0,0,0
+311,0,0,0,0,0,0,0,0,0,0,0,0,0
+312,0,0,0,0,0,0,0,0,0,0,0,0,0
+313,0,0,0,0,0,0,0,0,0,0,0,0,0
+314,0,0,0,0,0,0,0,0,0,0,0,0,0
+315,0,0,0,0,0,0,0,0,0,0,0,0,0
+316,0,0,0,0,0,0,0,0,0,0,0,0,0
+317,0,0,0,0,0,0,0,0,0,0,0,0,0
+318,0,0,0,0,0,0,0,0,0,0,0,0,0
+319,0,0,0,0,0,0,0,0,0,0,0,0,0
+320,0,0,0,0,0,0,0,0,0,0,0,0,0
+321,0,0,0,0,0,0,0,0,0,0,0,0,0
+322,0,0,0,0,0,0,0,0,0,0,0,0,0
+323,0,0,0,0,0,0,0,0,0,0,0,0,0
+324,0,0,0,0,0,0,0,0,0,0,0,0,0
+325,0,0,0,0,0,0,0,0,0,0,0,0,0
+326,0,0,0,0,0,0,0,0,0,0,0,0,0
+327,0,0,0,0,0,0,0,0,0,0,0,0,0
+328,0,0,0,0,0,0,0,0,0,0,0,0,0
+329,0,0,0,0,0,0,0,0,0,0,0,0,0
+330,0,0,0,0,0,0,0,0,0,0,0,0,0
+331,0,0,0,0,0,0,0,0,0,0,0,0,0
+332,0,0,0,0,0,0,0,0,0,0,0,0,0
+333,0,0,0,0,0,0,0,0,0,0,0,0,0
+334,0,0,0,0,0,0,0,0,0,0,0,0,0
+335,0,0,0,0,0,0,0,0,0,0,0,0,0
+336,0,0,0,0,0,0,0,0,0,0,0,0,0
+337,0,0,0,0,0,0,0,0,0,0,0,0,0
+338,0,0,0,0,0,0,0,0,0,0,0,0,0
+339,0,0,0,0,0,0,0,0,0,0,0,0,0
+340,0,0,0,0,0,0,0,0,0,0,0,0,0
+341,0,0,0,0,0,0,0,0,0,0,0,0,0
+342,0,0,0,0,0,0,0,0,0,0,0,0,0
+343,0,0,0,0,0,0,0,0,0,0,0,0,0
+344,0,0,0,0,0,0,0,0,0,0,0,0,0
+345,0,0,0,0,0,0,0,0,0,0,0,0,0
+346,0,0,0,0,0,0,0,0,0,0,0,0,0
+347,0,0,0,0,0,0,0,0,0,0,0,0,0
+348,0,0,0,0,0,0,0,0,0,0,0,0,0
+349,0,0,0,0,0,0,0,0,0,0,0,0,0
+350,0,0,0,0,0,0,0,0,0,0,0,0,0
+351,0,0,0,0,0,0,0,0,0,0,0,0,0
+352,0,0,0,0,0,0,0,0,0,0,0,0,0
+353,0,0,0,0,0,0,0,0,0,0,0,0,0
+354,0,0,0,0,0,0,0,0,0,0,0,0,0
+355,0,0,0,0,0,0,0,0,0,0,0,0,0
+356,0,0,0,0,0,0,0,0,0,0,0,0,0
+357,0,0,0,0,0,0,0,0,0,0,0,0,0
+358,0,0,0,0,0,0,0,0,0,0,0,0,0
+359,0,0,0,0,0,0,0,0,0,0,0,0,0
+360,0,0,0,0,0,0,0,0,0,0,0,0,0
+361,0,0,0,0,0,0,0,0,0,0,0,0,0
+362,0,0,0,0,0,0,0,0,0,0,0,0,0
+363,0,0,0,0,0,0,0,0,0,0,0,0,0
+364,0,0,0,0,0,0,0,0,0,0,0,0,0
+365,0,0,0,0,0,0,0,0,0,0,0,0,0
+366,0,0,0,0,0,0,0,0,0,0,0,0,0
+367,0,0,0,0,0,0,0,0,0,0,0,0,0
+368,0,0,0,0,0,0,0,0,0,0,0,0,0
+369,0,0,0,0,0,0,0,0,0,0,0,0,0
+370,0,0,0,0,0,0,0,0,0,0,0,0,0
+371,0,0,0,0,0,0,0,0,0,0,0,0,0
+372,0,0,0,0,0,0,0,0,0,0,0,0,0
+373,0,0,0,0,0,0,0,0,0,0,0,0,0
+374,0,0,0,0,0,0,0,0,0,0,0,0,0
+375,0,0,0,0,0,0,0,0,0,0,0,0,0
+376,0,0,0,0,0,0,0,0,0,0,0,0,0
+377,0,0,0,0,0,0,0,0,0,0,0,0,0
+378,0,0,0,0,0,0,0,0,0,0,0,0,0
+379,0,0,0,0,0,0,0,0,0,0,0,0,0
+380,0,0,0,0,0,0,0,0,0,0,0,0,0
+381,0,0,0,0,0,0,0,0,0,0,0,0,0
+382,0,0,0,0,0,0,0,0,0,0,0,0,0
+383,0,0,0,0,0,0,0,0,0,0,0,0,0
+384,0,0,0,0,0,0,0,0,0,0,0,0,0
+385,0,0,0,0,0,0,0,0,0,0,0,0,0
+386,0,0,0,0,0,0,0,0,0,0,0,0,0
+387,0,0,0,0,0,0,0,0,0,0,0,0,0
+388,0,0,0,0,0,0,0,0,0,0,0,0,0
+389,0,0,0,0,0,0,0,0,0,0,0,0,0
+390,0,0,0,0,0,0,0,0,0,0,0,0,0
+391,0,0,0,0,0,0,0,0,0,0,0,0,0
+392,0,0,0,0,0,0,0,0,0,0,0,0,0
+393,0,0,0,0,0,0,0,0,0,0,0,0,0
+394,0,0,0,0,0,0,0,0,0,0,0,0,0
+395,0,0,0,0,0,0,0,0,0,0,0,0,0
+396,0,0,0,0,0,0,0,0,0,0,0,0,0
+397,0,0,0,0,0,0,0,0,0,0,0,0,0
+398,0,0,0,0,0,0,0,0,0,0,0,0,0
+399,0,0,0,0,0,0,0,0,0,0,0,0,0
+400,0,0,0,0,0,0,0,0,0,0,0,0,0
+401,0,0,0,0,0,0,0,0,0,0,0,0,0
+402,0,0,0,0,0,0,0,0,0,0,0,0,0
+403,0,0,0,0,0,0,0,0,0,0,0,0,0
+404,0,0,0,0,0,0,0,0,0,0,0,0,0
+405,0,0,0,0,0,0,0,0,0,0,0,0,0
+406,0,0,0,0,0,0,0,0,0,0,0,0,0
+407,0,0,0,0,0,0,0,0,0,0,0,0,0
+408,0,0,0,0,0,0,0,0,0,0,0,0,0
+409,0,0,0,0,0,0,0,0,0,0,0,0,0
+410,0,0,0,0,0,0,0,0,0,0,0,0,0
+411,0.006797798,0,0,0,0,0,0,0,0,0,0,0,0
+412,0.01099643,0,0,0,0,0,0,0,0,0,0,0,0
+413,0.004208363,0,0,0,0,0,0,0,0,0,0,0,0
+414,0.006568034,0,0,0,0,0,0,0,0,0,0,0,0
+415,0.005883123,0,0,0,0,0,0,0,0,0,0,0,0
+416,0.00713011,0,0,0,0,0,0,0,0,0,0,0,0
+417,0.004333651,0,0,0,0,0,0,0,0,0,0,0,0
+418,0.006263537,0,0,0,0,0,0,0,0,0,0,0,0
+419,0.004393687,0,0,0,0,0,0,0,0,0,0,0,0
+420,0.00253157,0,0,0,0,0,0,0,0,0,0,0,0
+421,0.000621707,0,0,0,0,0,0,0,0,0,0,0,0
+422,0.002117729,0,0,0,0,0,0,0,0,0,0,0,0
+423,0.003175796,0,0,0,0,0,0,0,0,0,0,0,0
+424,0.005213085,0,0,0,0,0,0,0,0,0,0,0,0
+425,0.003387375,0,0,0,0,0,0,0,0,0,0,0,0
+426,0.00258671,0,0,0,0,0,0,0,0,0,0,0,0
+427,0.002384167,0,0,0,0,0,0,0,0,0,0,0,0
+428,0.004595227,0,0,0,0,0,0,0,0,0,0,0,0
+429,0.012990945,0,0,0,0,0,0,0,0,0,0,0,0
+430,0.050622293,0,0,0,0,0,0,0,0,0,0,0,0
+431,0.18872241,0,0,0,0,0,0,0,0,0,0,0,0
+432,0.459106539,0,0,0,0,0,0,0,0,0,0,0,0
+433,0.730160597,0,0,0,0,0,0,0,0,0,0,0,0
+434,0.847259495,0,0,0,0,0,0,0,0,0,0,0,0
+435,0.871235903,0,0,0,0,0,0,0,0,0,0,0,0
+436,0.881448354,0,0,0,0,0,0,0,0,0,0,0,0
+437,0.899392736,0,0,0,0,0,0,0,0,0,0,0,0
+438,0.918669431,0.001893306,0,0,0,0,0,0,0,0,0,0,0
+439,0.933420754,0.019440751,0,0,0,0,0,0,0,0,0,0,0
+440,0.94596319,0.020059028,0,0,0,0,0,0,0,0,0,0,0
+441,0.95041031,0.014109631,0,0,0,0,0,0,0,0,0,0,0
+442,0.953972339,0.015612858,0,0,0,0,0,0,0,0,0,0,0
+443,0.96903168,0.015448868,0,0,0,0,0,0,0,0,0,0,0
+444,0.999546173,0.017034152,0,0,0,0,0,0,0,0,0,0,0
+445,1,0.013311359,0,0,0,0,0,0,0,0,0,0,0
+446,0.976368067,0.014462036,0,0,0,0,0,0,0,0,0,0,0
+447,0.96404957,0.009592091,0,0,0,0,0,0,0,0,0,0,0
+448,0.95417544,0.014500694,0,0,0,0,0,0,0,0,0,0,0
+449,0.923744832,0.011159264,0,0,0,0,0,0,0,0,0,0,0
+450,0.88548879,0.013332524,0,0,0,0,0,0,0,0,0,0,0
+451,0.809016274,0.01355731,0,0,0,0,0,0,0,0,0,0,0
+452,0.601561144,0.01426,0,0,0,0,0,0,0,0,0,0,0
+453,0.306766029,0.014717634,0,0,0,0,0,0,0,0,0,0,0
+454,0.108527711,0.015989541,0,0,0,0,0,0,0,0,0,0,0
+455,0.030542088,0.030654247,0,0,0,0,0,0,0,0,0,0,0
+456,0.008935131,0.055432753,0,0,0,0,0,0,0,0,0,0,0
+457,0,0.120228972,0,0,0,0,0,0,0,0,0,0,0
+458,0,0.252260953,0,0,0,0,0,0,0,0,0,0,0
+459,0,0.462862499,0,0,0,0,0,0,0,0,0,0,0
+460,0,0.65241169,0,0,0,0,0,0,0,0,0,0,0
+461,0,0.77750832,0,0,0,0,0,0,0,0,0,0,0
+462,0,0.824333103,0,0,0,0,0,0,0,0,0,0,0
+463,0,0.832077099,0,0,0,0,0,0,0,0,0,0,0
+464,0,0.835037767,0,0,0,0,0,0,0,0,0,0,0
+465,0,0.838761115,0,0,0,0,0,0,0,0,0,0,0
+466,0,0.864126031,0,0,0,0,0,0,0,0,0,0,0
+467,0,0.883293587,0,0,0,0,0,0,0,0,0,0,0
+468,0,0.90569382,0,0,0,0,0,0,0,0,0,0,0
+469,0,0.921186621,0,0,0,0,0,0,0,0,0,0,0
+470,0,0.936616967,0,0,0,0,0,0,0,0,0,0,0
+471,0,0.931024626,0,0,0,0,0,0,0,0,0,0,0
+472,0,0.927547539,0,0,0,0,0,0,0,0,0,0,0
+473,0,0.916622744,0,0,0,0,0,0,0,0,0,0,0
+474,0,0.9060165,0,0,0,0,0,0,0,0,0,0,0
+475,0,0.897870416,0,0,0,0,0,0,0,0,0,0,0
+476,0,0.903146598,0,0,0,0,0,0,0,0,0,0,0
+477,0,0.908994286,0,0,0,0,0,0,0,0,0,0,0
+478,0,0.920859439,0,0,0,0,0,0,0,0,0,0,0
+479,0,0.924523699,0,0,0,0,0,0,0,0,0,0,0
+480,0,0.918843658,0,0,0,0,0,0,0,0,0,0,0
+481,0,0.907981319,0,0,0,0,0,0,0,0,0,0,0
+482,0,0.898032665,0,0,0,0,0,0,0,0,0,0,0
+483,0,0.88735796,0,0,0,0,0,0,0,0,0,0,0
+484,0,0.873065866,0,0,0,0,0,0,0,0,0,0,0
+485,0,0.857761622,0,0,0,0,0,0,0,0,0,0,0
+486,0,0.846132814,0,0,0,0,0,0,0,0,0,0,0
+487,0,0.843382711,0,0,0,0,0,0,0,0,0,0,0
+488,0,0.857924772,0,0,0,0,0,0,0,0,0,0,0
+489,0,0.879320632,0,0,0,0,0,0,0,0,0,0,0
+490,0,0.903975503,0,0,0,0,0,0,0,0,0,0,0
+491,0,0.919580552,0,0,0,0,0,0,0,0,0,0,0
+492,0,0.946712663,0,0,0,0,0,0,0,0,0,0,0
+493,0,0.969406608,0,0,0,0,0,0,0,0,0,0,0
+494,0,0.993636046,0,0,0,0,0,0,0,0,0,0,0
+495,0,0.999320649,0,0,0,0,0,0,0,0,0,0,0
+496,0,1,0,0,0,0,0,0,0,0,0,0,0
+497,0,0.995107621,0,0,0,0,0,0,0,0,0,0,0
+498,0,0.984163047,0,0,0,0,0,0,0,0,0,0,0
+499,0,0.979509527,0,0,0,0,0,0,0,0,0,0,0
+500,0,0.978185449,0,0,0,0,0,0,0,0,0,0,0
+501,0,0.972278886,0,0,0,0,0,0,0,0,0,0,0
+502,0,0.96293492,0,0,0,0,0,0,0,0,0,0,0
+503,0,0.95355824,0,0,0,0,0,0,0,0,0,0,0
+504,0,0.938134944,0,0,0,0,0,0,0,0,0,0,0
+505,0,0.924777929,0,0,0,0,0,0,0,0,0,0,0
+506,0,0.909590075,0,0,0,0,0,0,0,0,0,0,0
+507,0,0.902313691,0,0,0,0,0,0,0,0,0,0,0
+508,0,0.892251397,0,0,0,0,0,0,0,0,0,0,0
+509,0,0.890060534,0,0,0,0,0,0,0,0,0,0,0
+510,0,0.891851681,0,0,0,0,0,0,0,0,0,0,0
+511,0,0.899164865,0,0,0,0,0,0,0,0,0,0,0
+512,0,0.910901434,0,0,0,0,0,0,0,0,0,0,0
+513,0,0.924636296,0,0,0,0,0,0,0,0,0,0,0
+514,0,0.938626228,0,0,0,0,0,0,0,0,0,0,0
+515,0,0.953526854,0,0,0,0,0,0,0,0,0,0,0
+516,0,0.971831245,0,0,0,0,0,0,0,0,0,0,0
+517,0,0.987690608,0,0,0,0,0,0,0,0,0,0,0
+518,0,0.996791216,0,0,0,0,0,0,0,0,0,0,0
+519,0,0.993851876,0,0,0,0,0,0,0,0,0,0,0
+520,0,0.9816383,0,0,0,0,0,0,0,0,0,0,0
+521,0,0.958970396,0,0,0,0,0,0,0,0,0,0,0
+522,0,0.893259218,0,0,0,0,0,0,0,0,0,0,0
+523,0,0.736063596,0,0,0,0,0,0,0,0,0,0,0
+524,0,0.52101528,0,0,0,0,0,0,0,0,0,0,0
+525,0,0.332578748,0,0,0,0,0,0,0,0,0,0,0
+526,0,0.195080476,0,0,0,0,0,0,0,0,0,0,0
+527,0,0.117429222,0,0,0,0,0,0,0,0,0,0,0
+528,0,0.075138809,0,0,0,0,0,0,0,0,0,0,0
+529,0,0.050991983,0,0,0,0,0,0,0,0,0,0,0
+530,0,0.032154822,0,0,0,0,0,0,0,0,0,0,0
+531,0,0.015134166,0,0,0,0,0,0,0,0,0,0,0
+532,0,0.004477169,0,0,0,0,0,0,0,0,0,0,0
+533,0,0,0,0,0,0,0,0,0,0,0,0,0
+534,0,0,0,0,0,0,0,0,0,0,0,0,0
+535,0,0,0,0,0,0,0,0,0,0,0,0,0
+536,0,0,0.001849077,0,0,0,0,0,0,0,0,0,0
+537,0,0,0.015481298,0,0,0,0,0,0,0,0,0,0
+538,0,0,0.036661939,0,0,0,0,0,0,0,0,0,0
+539,0,0,0.081181302,0,0,0,0,0,0,0,0,0,0
+540,0,0,0.169521526,0,0,0,0,0,0,0,0,0,0
+541,0,0,0.333499478,0,0,0,0,0,0,0,0,0,0
+542,0,0,0.587551283,0,0,0,0,0,0,0,0,0,0
+543,0,0,0.810898276,0,0,0,0,0,0,0,0,0,0
+544,0,0,0.914486774,0,0,0,0,0,0,0,0,0,0
+545,0,0,0.945520385,0,0,0,0,0,0,0,0,0,0
+546,0,0,0.949175317,0,0,0,0,0,0,0,0,0,0
+547,0,0,0.943501504,0,0,0,0,0,0,0,0,0,0
+548,0,0,0.928333429,0,0,0,0,0,0,0,0,0,0
+549,0,0,0.912819616,0,0,0,0,0,0,0,0,0,0
+550,0,0,0.901482543,0,0,0,0,0,0,0,0,0,0
+551,0,0,0.900858652,0,0,0,0,0,0,0,0,0,0
+552,0,0,0.907289434,0,0,0,0,0,0,0,0,0,0
+553,0,0,0.922649114,0,0,0,0,0,0,0,0,0,0
+554,0,0,0.942932043,0,0,0,0,0,0,0,0,0,0
+555,0,0,0.964024785,0,0,0,0,0,0,0,0,0,0
+556,0,0,0.983470408,0,0,0,0,0,0,0,0,0,0
+557,0,0,0.999446482,0,0,0,0,0,0,0,0,0,0
+558,0,0,1,0,0,0,0,0,0,0,0,0,0
+559,0,0,0.991955712,0,0,0,0,0,0,0,0,0,0
+560,0,0,0.976582923,0,0,0,0,0,0,0,0,0,0
+561,0,0,0.951151834,0,0,0,0,0,0,0,0,0,0
+562,0,0,0.924621468,0,0,0,0,0,0,0,0,0,0
+563,0,0,0.891851701,0,0,0,0,0,0,0,0,0,0
+564,0,0,0.868157818,0,0,0,0,0,0,0,0,0,0
+565,0,0,0.847608394,0,0,0,0,0,0,0,0,0,0
+566,0,0,0.83920859,0,0,0,0,0,0,0,0,0,0
+567,0,0,0.832980675,0,0,0,0,0,0,0,0,0,0
+568,0,0,0.830820549,0,0,0,0,0,0,0,0,0,0
+569,0,0,0.835211024,0,0,0,0,0,0,0,0,0,0
+570,0,0,0.84875691,0,0,0,0,0,0,0,0,0,0
+571,0,0,0.866563551,0,0,0,0,0,0,0,0,0,0
+572,0,0,0.875196149,0,0,0,0,0,0,0,0,0,0
+573,0,0,0.87037822,0,0,0,0,0,0,0,0,0,0
+574,0,0,0.857256926,0,0,0,0,0,0,0,0,0,0
+575,0,0,0.809749622,0,0,0,0,0,0,0,0,0,0
+576,0,0,0.677463956,0,0,0,0,0,0,0,0,0,0
+577,0,0,0.456507841,0,0,0,0,0,0,0,0,0,0
+578,0,0,0.247691784,0,0,0,0,0,0,0,0,0,0
+579,0,0,0.127866254,0,0,0,0,0,0,0,0,0,0
+580,0,0,0.059016809,0,0,0,0,0,0,0,0,0,0
+581,0,0,0.025724357,0,0,0,0,0,0,0,0,0,0
+582,0,0,0.005219158,0,0,0,0,0,0,0,0,0,0
+583,0,0,0,0,0,0,0,0,0,0,0,0,0
+584,0,0,0,0,0,0,0,0,0,0,0,0,0
+585,0,0,0,0,0,0,0,0,0,0,0,0,0
+586,0,0,0,0,0,0,0,0,0,0,0,0,0
+587,0,0,0,0,0,0,0,0,0,0,0,0,0
+588,0,0,0,0,0,0,0,0,0,0,0,0,0
+589,0,0,0,0,0,0,0,0,0,0,0,0,0
+590,0,0,0,0,0,0,0,0,0,0,0,0,0
+591,0,0,0,0,0,0,0,0,0,0,0,0,0
+592,0,0,0,0,0,0,0,0,0,0,0,0,0
+593,0,0,0,0,0,0,0,0,0,0,0,0,0
+594,0,0,0,0,0,0,0,0,0,0,0,0,0
+595,0,0,0,0,0,0,0,0,0,0,0,0,0
+596,0,0,0,0,0,0,0,0,0,0,0,0,0
+597,0,0,0,0,0,0,0,0,0,0,0,0,0
+598,0,0,0,0,0,0,0,0,0,0,0,0,0
+599,0,0,0,0,0,0,0,0,0,0,0,0,0
+600,0,0,0,0,0,0,0,0,0,0,0,0,0
+601,0,0,0,0,0,0,0,0,0,0,0,0,0
+602,0,0,0,0,0,0,0,0,0,0,0,0,0
+603,0,0,0,0,0,0,0,0,0,0,0,0,0
+604,0,0,0,0,0,0,0,0,0,0,0,0,0
+605,0,0,0,0,0,0,0,0,0,0,0,0,0
+606,0,0,0,0,0,0,0,0,0,0,0,0,0
+607,0,0,0,0,0,0,0,0,0,0,0,0,0
+608,0,0,0,0,0,0,0,0,0,0,0,0,0
+609,0,0,0,0,0,0,0,0,0,0,0,0,0
+610,0,0,0,0,0,0,0,0,0,0,0,0,0
+611,0,0,0,0,0,0,0,0,0,0,0,0,0
+612,0,0,0,0,0,0,0,0,0,0,0,0,0
+613,0,0,0,0,0,0,0,0,0,0,0,0,0
+614,0,0,0,0,0,0,0,0,0,0,0,0,0
+615,0,0,0,0,0,0,0,0,0,0,0,0,0
+616,0,0,0,0,0,0,0,0,0,0,0,0,0
+617,0,0,0,0,0,0,0,0,0,0,0,0,0
+618,0,0,0,0,0,0,0,0,0,0,0,0,0
+619,0,0,0,0,0,0,0,0,0,0,0,0,0
+620,0,0,0,0,0,0,0,0,0,0,0,0,0
+621,0,0,0,0,0,0,0,0,0,0,0,0,0
+622,0,0,0,0,0,0,0,0,0,0,0,0,0
+623,0,0,0,0,0,0,0,0,0,0,0,0,0
+624,0,0,0,0,0,0,0,0,0,0,0,0,0
+625,0,0,0,0,0,0,0,0,0,0,0,0,0
+626,0,0,0,0,0,0,0,0,0,0,0,0,0
+627,0,0,0,0,0,0,0,0,0,0,0,0,0
+628,0,0,0,0,0,0,0,0,0,0,0,0,0
+629,0,0,0,0,0,0,0,0,0,0,0,0,0
+630,0,0,0,0,0,0,0,0,0,0,0,0,0
+631,0,0,0,0,0,0,0,0,0,0,0,0,0
+632,0,0,0,0,0,0,0,0,0,0,0,0,0
+633,0,0,0,0,0,0,0,0,0,0,0,0,0
+634,0,0,0,0,0,0,0,0,0,0,0,0,0
+635,0,0,0,0,0,0,0,0,0,0,0,0,0
+636,0,0,0,0,0,0,0,0,0,0,0,0,0
+637,0,0,0,0,0,0,0,0,0,0,0,0,0
+638,0,0,0,0,0,0,0,0,0,0,0,0,0
+639,0,0,0,0,0,0,0,0,0,0,0,0,0
+640,0,0,0,0,0,0,0,0,0,0,0,0,0
+641,0,0,0,0,0,0,0,0,0,0,0,0,0
+642,0,0,0,0,0,0,0,0,0,0,0,0,0
+643,0,0,0,0,0,0,0,0,0,0,0,0,0
+644,0,0,0,0,0,0,0,0,0,0,0,0,0
+645,0,0,0,0,0,0,0,0,0,0,0,0,0
+646,0,0,0,0.005090312,0,0,0,0,0,0,0,0,0
+647,0,0,0,0.026897029,0,0,0,0,0,0,0,0,0
+648,0,0,0,0.12087986,0,0,0,0,0,0,0,0,0
+649,0,0,0,0.33742273,0,0,0,0,0,0,0,0,0
+650,0,0,0,0.603624689,0,0,0,0,0,0,0,0,0
+651,0,0,0,0.810967523,0,0,0,0,0,0,0,0,0
+652,0,0,0,0.91573833,0,0,0,0,0,0,0,0,0
+653,0,0,0,0.92605288,0,0,0,0,0,0,0,0,0
+654,0,0,0,0.92083242,0,0,0,0,0,0,0,0,0
+655,0,0,0,0.911237119,0,0,0,0,0,0,0,0,0
+656,0,0,0,0.902005739,0,0,0,0,0,0,0,0,0
+657,0,0,0,0.897081513,0,0,0,0,0,0,0,0,0
+658,0,0,0,0.899066029,0,0,0,0,0,0,0,0,0
+659,0,0,0,0.900672338,0,0,0,0,0,0,0,0,0
+660,0,0,0,0.902488081,0,0,0,0,0,0,0,0,0
+661,0,0,0,0.906886173,0,0,0,0,0,0,0,0,0
+662,0,0,0,0.915610562,0,0,0,0,0,0,0,0,0
+663,0,0,0,0.927756371,0,0,0,0,0,0,0,0,0
+664,0,0,0,0.941055569,0,0,0,0,0,0,0,0,0
+665,0,0,0,0.954196504,0,0,0,0,0,0,0,0,0
+666,0,0,0,0.966908428,0,0,0,0,0,0,0,0,0
+667,0,0,0,0.981390028,0,0,0,0,0,0,0,0,0
+668,0,0,0,0.991619278,0,0,0,0,0,0,0,0,0
+669,0,0,0,1,0,0,0,0,0,0,0,0,0
+670,0,0,0,0.999754078,0,0,0,0,0,0,0,0,0
+671,0,0,0,0.994046577,0,0,0,0,0,0,0,0,0
+672,0,0,0,0.981792818,0,0,0,0,0,0,0,0,0
+673,0,0,0,0.968692612,0,0,0,0,0,0,0,0,0
+674,0,0,0,0.957607907,0,0,0,0,0,0,0,0,0
+675,0,0,0,0.945644641,0,0,0,0,0,0,0,0,0
+676,0,0,0,0.92580977,0,0,0,0,0,0,0,0,0
+677,0,0,0,0.897152993,0,0,0,0,0,0,0,0,0
+678,0,0,0,0.838534201,0,0,0,0,0,0,0,0,0
+679,0,0,0,0.698446797,0,0,0,0,0,0,0,0,0
+680,0,0,0,0.493502787,0,0,0,0,0,0,0,0,0
+681,0,0,0,0.276900547,0,0,0,0,0,0,0,0,0
+682,0,0,0,0.107781358,0,0,0,0,0,0,0,0,0
+683,0,0,0,0.029913795,0,0,0,0,0,0,0,0,0
+684,0,0,0,0.007336673,0,0,0,0,0,0,0,0,0
+685,0,0,0,0.000838123,0,0,0,0,0,0,0,0,0
+686,0,0,0,0,0,0,0,0,0,0,0,0,0
+687,0,0,0,0,0,0,0,0,0,0,0,0,0
+688,0,0,0,0,0,0,0,0,0,0,0,0,0
+689,0,0,0,0,0,0,0,0,0,0,0,0,0
+690,0,0,0,0,0,0,0,0,0,0,0,0,0
+691,0,0,0,0,0,0,0,0,0,0,0,0,0
+692,0,0,0,0,0,0,0,0,0,0,0,0,0
+693,0,0,0,0,0,0,0,0,0,0,0,0,0
+694,0,0,0,0,0.010471827,0,0,0,0,0,0,0,0
+695,0,0,0,0,0.057252544,0,0,0,0,0,0,0,0
+696,0,0,0,0,0.214724996,0,0,0,0,0,0,0,0
+697,0,0,0,0,0.547189415,0,0,0,0,0,0,0,0
+698,0,0,0,0,0.871043978,0,0,0,0,0,0,0,0
+699,0,0,0,0,0.968446586,0,0,0,0,0,0,0,0
+700,0,0,0,0,0.99124182,0,0,0,0,0,0,0,0
+701,0,0,0,0,1,0,0,0,0,0,0,0,0
+702,0,0,0,0,0.99509331,0,0,0,0,0,0,0,0
+703,0,0,0,0,0.987602081,0,0,0,0,0,0,0,0
+704,0,0,0,0,0.979408704,0,0,0,0,0,0,0,0
+705,0,0,0,0,0.970910946,0,0,0,0,0,0,0,0
+706,0,0,0,0,0.959528083,0,0,0,0,0,0,0,0
+707,0,0,0,0,0.94236861,0,0,0,0,0,0,0,0
+708,0,0,0,0,0.926720132,0,0,0,0,0,0,0,0
+709,0,0,0,0,0.894557475,0,0,0,0,0,0,0,0
+710,0,0,0,0,0.767248071,0,0,0,0,0,0,0,0
+711,0,0,0,0,0.504134435,0,0,0,0,0,0,0,0
+712,0,0,0,0,0.180610636,0,0,0,0,0,0,0,0
+713,0,0,0,0,0.034019737,0,0,0,0,0,0,0,0
+714,0,0,0,0,0.002436944,0,0,0,0,0,0,0,0
+715,0,0,0,0,0,0,0,0,0,0,0,0,0
+716,0,0,0,0,0,0,0,0,0,0,0,0,0
+717,0,0,0,0,0,0,0,0,0,0,0,0,0
+718,0,0,0,0,0,0,0,0,0,0,0,0,0
+719,0,0,0,0,0,0,0,0,0,0,0,0,0
+720,0,0,0,0,0,0,0,0,0,0,0,0,0
+721,0,0,0,0,0,0,0,0,0,0,0,0,0
+722,0,0,0,0,0,0,0,0,0,0,0,0,0
+723,0,0,0,0,0,0,0,0,0,0,0,0,0
+724,0,0,0,0,0,0,0,0,0,0,0,0,0
+725,0,0,0,0,0,0,0,0,0,0,0,0,0
+726,0,0,0,0,0,0,0,0,0,0,0,0,0
+727,0,0,0,0,0,0,0,0,0,0,0,0,0
+728,0,0,0,0,0,0,0,0,0,0,0,0,0
+729,0,0,0,0,0,0,0,0,0,0,0,0,0
+730,0,0,0,0,0,0.017433807,0,0,0,0,0,0,0
+731,0,0,0,0,0,0.105812957,0,0,0,0,0,0,0
+732,0,0,0,0,0,0.386050533,0,0,0,0,0,0,0
+733,0,0,0,0,0,0.782313159,0,0,0,0,0,0,0
+734,0,0,0,0,0,0.905953099,0,0,0,0,0,0,0
+735,0,0,0,0,0,0.916416606,0,0,0,0,0,0,0
+736,0,0,0,0,0,0.92333441,0,0,0,0,0,0,0
+737,0,0,0,0,0,0.932013378,0,0,0,0,0,0,0
+738,0,0,0,0,0,0.947550036,0,0,0,0,0,0,0
+739,0,0,0,0,0,0.965839591,0,0,0,0,0,0,0
+740,0,0,0,0,0,0.978552758,0,0,0,0,0,0,0
+741,0,0,0,0,0,0.991319723,0,0,0,0,0,0,0
+742,0,0,0,0,0,1,0,0,0,0,0,0,0
+743,0,0,0,0,0,0.999955845,0,0,0,0,0,0,0
+744,0,0,0,0,0,0.971267313,0,0,0,0,0,0,0
+745,0,0,0,0,0,0.81917496,0,0,0,0,0,0,0
+746,0,0,0,0,0,0.467395748,0,0,0,0,0,0,0
+747,0,0,0,0,0,0.094120897,0,0,0,0,0,0,0
+748,0,0,0,0,0,0.009834009,0,0,0,0,0,0,0
+749,0,0,0,0,0,0,0,0,0,0,0,0,0
+750,0,0,0,0,0,0,0,0,0,0,0,0,0
+751,0,0,0,0,0,0,0,0,0,0,0,0,0
+752,0,0,0,0,0,0,0,0,0,0,0,0,0
+753,0,0,0,0,0,0,0,0,0,0,0,0,0
+754,0,0,0,0,0,0,0,0,0,0,0,0,0
+755,0,0,0,0,0,0,0,0,0,0,0,0,0
+756,0,0,0,0,0,0,0,0,0,0,0,0,0
+757,0,0,0,0,0,0,0,0,0,0,0,0,0
+758,0,0,0,0,0,0,0,0,0,0,0,0,0
+759,0,0,0,0,0,0,0,0,0,0,0,0,0
+760,0,0,0,0,0,0,0,0,0,0,0,0,0
+761,0,0,0,0,0,0,0,0,0,0,0,0,0
+762,0,0,0,0,0,0,0,0,0,0,0,0,0
+763,0,0,0,0,0,0,0,0,0,0,0,0,0
+764,0,0,0,0,0,0,0,0,0,0,0,0,0
+765,0,0,0,0,0,0,0,0,0,0,0,0,0
+766,0,0,0,0,0,0,0.010282026,0,0,0,0,0,0
+767,0,0,0,0,0,0,0.037427714,0,0,0,0,0,0
+768,0,0,0,0,0,0,0.112026989,0,0,0,0,0,0
+769,0,0,0,0,0,0,0.257953812,0,0,0,0,0,0
+770,0,0,0,0,0,0,0.478980823,0,0,0,0,0,0
+771,0,0,0,0,0,0,0.730216783,0,0,0,0,0,0
+772,0,0,0,0,0,0,0.912510408,0,0,0,0,0,0
+773,0,0,0,0,0,0,0.971721033,0,0,0,0,0,0
+774,0,0,0,0,0,0,0.964616097,0.000386696,0,0,0,0,0
+775,0,0,0,0,0,0,0.955734525,0.003018401,0,0,0,0,0
+776,0,0,0,0,0,0,0.964925586,0.01669158,0,0,0,0,0
+777,0,0,0,0,0,0,0.986223289,0.028340486,0,0,0,0,0
+778,0,0,0,0,0,0,1,0.0502885,0,0,0,0,0
+779,0,0,0,0,0,0,0.998046627,0.08626388,0,0,0,0,0
+780,0,0,0,0,0,0,0.98393444,0.149596686,0,0,0,0,0
+781,0,0,0,0,0,0,0.96569621,0.258428566,0,0,0,0,0
+782,0,0,0,0,0,0,0.947277433,0.425108406,0,0,0,0,0
+783,0,0,0,0,0,0,0.927083998,0.631697563,0,0,0,0,0
+784,0,0,0,0,0,0,0.90976539,0.803109115,0,0,0,0,0
+785,0,0,0,0,0,0,0.886948914,0.904984654,0,0,0,0,0
+786,0,0,0,0,0,0,0.859517187,0.939674653,0,0,0,0,0
+787,0,0,0,0,0,0,0.827959173,0.944958731,0,0,0,0,0
+788,0,0,0,0,0,0,0.776383783,0.948238826,0,0,0,0,0
+789,0,0,0,0,0,0,0.671173028,0.963880684,0,0,0,0,0
+790,0,0,0,0,0,0,0.481809979,0.979861632,0,0,0,0,0
+791,0,0,0,0,0,0,0.236251944,0.991635585,0,0,0,0,0
+792,0,0,0,0,0,0,0.069538392,0.996362309,0,0,0,0,0
+793,0,0,0,0,0,0,0.013431956,1,0,0,0,0,0
+794,0,0,0,0,0,0,0.001257675,0.998257939,0,0,0,0,0
+795,0,0,0,0,0,0,0,0.998488834,0,0,0,0,0
+796,0,0,0,0,0,0,0,0.989253171,0,0,0,0,0
+797,0,0,0,0,0,0,0,0.98294089,0,0,0,0,0
+798,0,0,0,0,0,0,0,0.968189827,0,0,0,0,0
+799,0,0,0,0,0,0,0,0.958222106,0,0,0,0,0
+800,0,0,0,0,0,0,0,0.951650369,0,0,0,0,0
+801,0,0,0,0,0,0,0,0.947054991,0,0,0,0,0
+802,0,0,0,0,0,0,0,0.944166995,0,0,0,0,0
+803,0,0,0,0,0,0,0,0.948383123,0,0,0,0,0
+804,0,0,0,0,0,0,0,0.946461415,0,0,0,0,0
+805,0,0,0,0,0,0,0,0.942132884,0,0,0,0,0
+806,0,0,0,0,0,0,0,0.929937199,0,0,0,0,0
+807,0,0,0,0,0,0,0,0.914683918,0,0,0,0,0
+808,0,0,0,0,0,0,0,0.893248878,0,0,0,0,0
+809,0,0,0,0,0,0,0,0.873037871,0,0,0,0,0
+810,0,0,0,0,0,0,0,0.852648452,0,0,0,0,0
+811,0,0,0,0,0,0,0,0.836447483,0,0,0,0,0
+812,0,0,0,0,0,0,0,0.824300756,0,0,0,0,0
+813,0,0,0,0,0,0,0,0.814333379,0,0,0,0,0
+814,0,0,0,0,0,0,0,0.810955964,0,0,0,0,0
+815,0,0,0,0,0,0,0,0.803715941,0,0,0,0,0
+816,0,0,0,0,0,0,0,0.791980175,0,0,0,0,0
+817,0,0,0,0,0,0,0,0.783270185,0,0,0,0,0
+818,0,0,0,0,0,0,0,0.767838865,0,0,0,0,0
+819,0,0,0,0,0,0,0,0.754167357,0,0,0,0,0
+820,0,0,0,0,0,0,0,0.742309406,0,0,0,0,0
+821,0,0,0,0,0,0,0,0.727235815,0,0,0,0,0
+822,0,0,0,0,0,0,0,0.719323269,0,0,0,0,0
+823,0,0,0,0,0,0,0,0.713866399,0,0,0,0,0
+824,0,0,0,0,0,0,0,0.718941021,0,0,0,0,0
+825,0,0,0,0,0,0,0,0.726527917,0,0,0,0,0
+826,0,0,0,0,0,0,0,0.738324031,0,0,0,0,0
+827,0,0,0,0,0,0,0,0.750210769,0,0,0,0,0
+828,0,0,0,0,0,0,0,0.761800392,0,0,0,0,0
+829,0,0,0,0,0,0,0,0.769900245,0,0,0,0,0
+830,0,0,0,0,0,0,0,0.781725199,0,0,0,0,0
+831,0,0,0,0,0,0,0,0.78381047,0,0,0,0,0
+832,0,0,0,0,0,0,0,0.783069959,0,0,0,0,0
+833,0,0,0,0,0,0,0,0.782718588,0,0,0,0,0
+834,0,0,0,0,0,0,0,0.781644143,0,0,0,0,0
+835,0,0,0,0,0,0,0,0.780380397,0,0,0,0,0
+836,0,0,0,0,0,0,0,0.781443024,0,0,0,0,0
+837,0,0,0,0,0,0,0,0.781701218,0,0,0,0,0
+838,0,0,0,0,0,0,0,0.78177353,0,0,0,0,0
+839,0,0,0,0,0,0,0,0.780064535,0,0,0,0,0
+840,0,0,0,0,0,0,0,0.777591823,0,0,0,0,0
+841,0,0,0,0,0,0,0,0.770831803,0,0,0,0,0
+842,0,0,0,0,0,0,0,0.764574958,0,0,0,0,0
+843,0,0,0,0,0,0,0,0.753876586,0,0,0,0,0
+844,0,0,0,0,0,0,0,0.743324604,0,0,0,0,0
+845,0,0,0,0,0,0,0,0.733775698,0,0,0,0,0
+846,0,0,0,0,0,0,0,0.722497914,0,0,0,0,0
+847,0,0,0,0,0,0,0,0.712900724,0,0,0,0,0
+848,0,0,0,0,0,0,0,0.699439134,0.001661751,0,0,0,0
+849,0,0,0,0,0,0,0,0.688575227,0.01602581,0,0,0,0
+850,0,0,0,0,0,0,0,0.674039061,0.032253895,0,0,0,0
+851,0,0,0,0,0,0,0,0.657552716,0.073411273,0,0,0,0
+852,0,0,0,0,0,0,0,0.643729834,0.168937582,0,0,0,0
+853,0,0,0,0,0,0,0,0.62865391,0.345506138,0,0,0,0
+854,0,0,0,0,0,0,0,0.614005803,0.569417239,0,0,0,0
+855,0,0,0,0,0,0,0,0.603233252,0.79634996,0,0,0,0
+856,0,0,0,0,0,0,0,0.594982815,0.937581155,0,0,0,0
+857,0,0,0,0,0,0,0,0.588091928,0.980942645,0,0,0,0
+858,0,0,0,0,0,0,0,0.585186507,0.987241334,0,0,0,0
+859,0,0,0,0,0,0,0,0.582889219,0.994409463,0,0,0,0
+860,0,0,0,0,0,0,0,0.581493721,0.998963959,0,0,0,0
+861,0,0,0,0,0,0,0,0.580137218,0.999788107,0,0,0,0
+862,0,0,0,0,0,0,0,0.574804624,1,0,0,0,0
+863,0,0,0,0,0,0,0,0.576654614,0.994482469,0,0,0,0
+864,0,0,0,0,0,0,0,0.572399696,0.987807181,0,0,0,0
+865,0,0,0,0,0,0,0,0.570992768,0.983157165,0,0,0,0
+866,0,0,0,0,0,0,0,0.569291451,0.979826684,0,0,0,0
+867,0,0,0,0,0,0,0,0.571025201,0.975089851,0,0,0,0
+868,0,0,0,0,0,0,0,0.570861066,0.972818786,0,0,0,0
+869,0,0,0,0,0,0,0,0.572213154,0.966320275,0,0,0,0
+870,0,0,0,0,0,0,0,0.575418141,0.958195153,0,0,0,0
+871,0,0,0,0,0,0,0,0.577804028,0.941870745,0,0,0,0
+872,0,0,0,0,0,0,0,0.579603586,0.894185366,0,0,0,0
+873,0,0,0,0,0,0,0,0.579294979,0.778588669,0,0,0,0
+874,0,0,0,0,0,0,0,0.578302049,0.597362542,0,0,0,0
+875,0,0,0,0,0,0,0,0.57565598,0.377361257,0,0,0,0
+876,0,0,0,0,0,0,0,0.569721665,0.184667876,0,0,0,0
+877,0,0,0,0,0,0,0,0.561891364,0.079045495,0,0,0,0
+878,0,0,0,0,0,0,0,0.556830745,0.033393337,0,0,0,0
+879,0,0,0,0,0,0,0,0.549385012,0.015808546,0,0,0,0
+880,0,0,0,0,0,0,0,0.545858439,0.00162404,0,0,0,0
+881,0,0,0,0,0,0,0,0.542536249,0,0,0,0,0
+882,0,0,0,0,0,0,0,0.541895109,0,0,0,0,0
+883,0,0,0,0,0,0,0,0.539852497,0,0,0,0,0
+884,0,0,0,0,0,0,0,0.537997281,0,0,0,0,0
+885,0,0,0,0,0,0,0,0.53195493,0,0,0,0,0
+886,0,0,0,0,0,0,0,0.522275927,0,0,0,0,0
+887,0,0,0,0,0,0,0,0.505572421,0,0,0,0,0
+888,0,0,0,0,0,0,0,0.48804203,0,0,0,0,0
+889,0,0,0,0,0,0,0,0.469610434,0,0,0,0,0
+890,0,0,0,0,0,0,0,0.456107021,0,0,0,0,0
+891,0,0,0,0,0,0,0,0.445848869,0,0,0,0,0
+892,0,0,0,0,0,0,0,0.443119818,0,0,0,0,0
+893,0,0,0,0,0,0,0,0.445581498,0,0,0,0,0
+894,0,0,0,0,0,0,0,0.447532506,0,0,0,0,0
+895,0,0,0,0,0,0,0,0.440183411,0,0,0,0,0
+896,0,0,0,0,0,0,0,0.418240241,0,0,0,0,0
+897,0,0,0,0,0,0,0,0.369455837,0,0,0,0,0
+898,0,0,0,0,0,0,0,0.301788007,0,0,0,0,0
+899,0,0,0,0,0,0,0,0.235014942,0,0,0,0,0
+900,0,0,0,0,0,0,0,0.174244972,0,0,0,0,0
+901,0,0,0,0,0,0,0,0.122382945,0,0,0,0,0
+902,0,0,0,0,0,0,0,0.083462794,0,0,0,0,0
+903,0,0,0,0,0,0,0,0.056162189,0,0,0,0,0
+904,0,0,0,0,0,0,0,0.038006008,0,0,0,0,0
+905,0,0,0,0,0,0,0,0.024240249,0,0,0,0,0
+906,0,0,0,0,0,0,0,0.014845963,0,0,0,0,0
+907,0,0,0,0,0,0,0,0.006132899,0,0,0,0,0
+908,0,0,0,0,0,0,0,0,0,0,0,0,0
+909,0,0,0,0,0,0,0,0,0,0,0,0,0
+910,0,0,0,0,0,0,0,0,0,0,0,0,0
+911,0,0,0,0,0,0,0,0,0,0,0,0,0
+912,0,0,0,0,0,0,0,0,0,0,0,0,0
+913,0,0,0,0,0,0,0,0,0,0,0,0,0
+914,0,0,0,0,0,0,0,0,0,0,0,0,0
+915,0,0,0,0,0,0,0,0,0,0,0,0,0
+916,0,0,0,0,0,0,0,0,0,0,0,0,0
+917,0,0,0,0,0,0,0,0,0,0,0,0,0
+918,0,0,0,0,0,0,0,0,0,0,0,0,0
+919,0,0,0,0,0,0,0,0,0,0,0,0,0
+920,0,0,0,0,0,0,0,0,0,0,0,0,0
+921,0,0,0,0,0,0,0,0,0,0,0,0,0
+922,0,0,0,0,0,0,0,0,0,0,0,0,0
+923,0,0,0,0,0,0,0,0,0,0,0,0,0
+924,0,0,0,0,0,0,0,0,0,0,0,0,0
+925,0,0,0,0,0,0,0,0,0,0,0,0,0
+926,0,0,0,0,0,0,0,0,0,0,0,0,0
+927,0,0,0,0,0,0,0,0,0,0,0,0,0
+928,0,0,0,0,0,0,0,0,0,0,0,0,0
+929,0,0,0,0,0,0,0,0,0,0,0,0,0
+930,0,0,0,0,0,0,0,0,0,0.012121122,0,0,0
+931,0,0,0,0,0,0,0,0,0,0.046022418,0,0,0
+932,0,0,0,0,0,0,0,0,0,0.151408217,0,0,0
+933,0,0,0,0,0,0,0,0,0,0.358642184,0,0,0
+934,0,0,0,0,0,0,0,0,0,0.606574394,0,0,0
+935,0,0,0,0,0,0,0,0,0,0.837342317,0,0,0
+936,0,0,0,0,0,0,0,0,0,0.933378313,0,0,0
+937,0,0,0,0,0,0,0,0,0,0.941428569,0,0,0
+938,0,0,0,0,0,0,0,0,0,0.95729331,0,0,0
+939,0,0,0,0,0,0,0,0,0,0.989803625,0,0,0
+940,0,0,0,0,0,0,0,0,0,0.997444519,0,0,0
+941,0,0,0,0,0,0,0,0,0,1,0,0,0
+942,0,0,0,0,0,0,0,0,0,0.9863781,0,0,0
+943,0,0,0,0,0,0,0,0,0,0.974191899,0,0,0
+944,0,0,0,0,0,0,0,0,0,0.958968621,0,0,0
+945,0,0,0,0,0,0,0,0,0,0.973776634,0,0,0
+946,0,0,0,0,0,0,0,0,0,0.950411873,0,0,0
+947,0,0,0,0,0,0,0,0,0,0.94578786,0,0,0
+948,0,0,0,0,0,0,0,0,0,0.909973936,0,0,0
+949,0,0,0,0,0,0,0,0,0,0.887002674,0,0,0
+950,0,0,0,0,0,0,0,0,0,0.855135879,0,0,0
+951,0,0,0,0,0,0,0,0,0,0.836537904,0,0,0
+952,0,0,0,0,0,0,0,0,0,0.718536234,0,0,0
+953,0,0,0,0,0,0,0,0,0,0.52369103,0,0,0
+954,0,0,0,0,0,0,0,0,0,0.269748749,0,0,0
+955,0,0,0,0,0,0,0,0,0,0.09480081,0,0,0
+956,0,0,0,0,0,0,0,0,0,0.026387561,0,0,0
+957,0,0,0,0,0,0,0,0,0,0.003433415,0,0,0
+958,0,0,0,0,0,0,0,0,0,0,0,0,0
+959,0,0,0,0,0,0,0,0,0,0,0,0,0
+960,0,0,0,0,0,0,0,0,0,0,0,0,0
+961,0,0,0,0,0,0,0,0,0,0,0,0,0
+962,0,0,0,0,0,0,0,0,0,0,0,0,0
+963,0,0,0,0,0,0,0,0,0,0,0,0,0
+964,0,0,0,0,0,0,0,0,0,0,0,0,0
+965,0,0,0,0,0,0,0,0,0,0,0,0,0
+966,0,0,0,0,0,0,0,0,0,0,0,0,0
+967,0,0,0,0,0,0,0,0,0,0,0,0,0
+968,0,0,0,0,0,0,0,0,0,0,0,0,0
+969,0,0,0,0,0,0,0,0,0,0,0,0,0
+970,0,0,0,0,0,0,0,0,0,0,0,0,0
+971,0,0,0,0,0,0,0,0,0,0,0,0,0
+972,0,0,0,0,0,0,0,0,0,0,0,0,0
+973,0,0,0,0,0,0,0,0,0,0,0,0,0
+974,0,0,0,0,0,0,0,0,0,0,0,0,0
+975,0,0,0,0,0,0,0,0,0,0,0,0,0
+976,0,0,0,0,0,0,0,0,0,0,0,0,0
+977,0,0,0,0,0,0,0,0,0,0,0,0,0
+978,0,0,0,0,0,0,0,0,0,0,0,0,0
+979,0,0,0,0,0,0,0,0,0,0,0,0,0
+980,0,0,0,0,0,0,0,0,0,0,0,0,0
+981,0,0,0,0,0,0,0,0,0,0,0,0,0
+982,0,0,0,0,0,0,0,0,0,0,0,0,0
+983,0,0,0,0,0,0,0,0,0,0,0,0,0
+984,0,0,0,0,0,0,0,0,0,0,0,0,0
+985,0,0,0,0,0,0,0,0,0,0,0,0,0
+986,0,0,0,0,0,0,0,0,0,0,0,0,0
+987,0,0,0,0,0,0,0,0,0,0,0,0,0
+988,0,0,0,0,0,0,0,0,0,0,0,0,0
+989,0,0,0,0,0,0,0,0,0,0,0,0,0
+990,0,0,0,0,0,0,0,0,0,0,0,0,0
+991,0,0,0,0,0,0,0,0,0,0,0,0,0
+992,0,0,0,0,0,0,0,0,0,0,0,0,0
+993,0,0,0,0,0,0,0,0,0,0,0,0,0
+994,0,0,0,0,0,0,0,0,0,0,0,0,0
+995,0,0,0,0,0,0,0,0,0,0,0,0,0
+996,0,0,0,0,0,0,0,0,0,0,0,0,0
+997,0,0,0,0,0,0,0,0,0,0,0,0,0
+998,0,0,0,0,0,0,0,0,0,0,0,0,0
+999,0,0,0,0,0,0,0,0,0,0,0,0,0
+1000,0,0,0,0,0,0,0,0,0,0,0,0,0
+1001,0,0,0,0,0,0,0,0,0,0,0,0,0
+1002,0,0,0,0,0,0,0,0,0,0,0,0,0
+1003,0,0,0,0,0,0,0,0,0,0,0,0,0
+1004,0,0,0,0,0,0,0,0,0,0,0,0,0
+1005,0,0,0,0,0,0,0,0,0,0,0,0,0
+1006,0,0,0,0,0,0,0,0,0,0,0,0,0
+1007,0,0,0,0,0,0,0,0,0,0,0,0,0
+1008,0,0,0,0,0,0,0,0,0,0,0,0,0
+1009,0,0,0,0,0,0,0,0,0,0,0,0,0
+1010,0,0,0,0,0,0,0,0,0,0,0,0,0
+1011,0,0,0,0,0,0,0,0,0,0,0,0,0
+1012,0,0,0,0,0,0,0,0,0,0,0,0,0
+1013,0,0,0,0,0,0,0,0,0,0,0,0,0
+1014,0,0,0,0,0,0,0,0,0,0,0,0,0
+1015,0,0,0,0,0,0,0,0,0,0,0,0,0
+1016,0,0,0,0,0,0,0,0,0,0,0,0,0
+1017,0,0,0,0,0,0,0,0,0,0,0,0,0
+1018,0,0,0,0,0,0,0,0,0,0,0,0,0
+1019,0,0,0,0,0,0,0,0,0,0,0,0,0
+1020,0,0,0,0,0,0,0,0,0,0,0,0,0
+1021,0,0,0,0,0,0,0,0,0,0,0,0,0
+1022,0,0,0,0,0,0,0,0,0,0,0,0,0
+1023,0,0,0,0,0,0,0,0,0,0,0,0,0
+1024,0,0,0,0,0,0,0,0,0,0,0,0,0
+1025,0,0,0,0,0,0,0,0,0,0,0,0,0
+1026,0,0,0,0,0,0,0,0,0,0,0,0,0
+1027,0,0,0,0,0,0,0,0,0,0,0,0,0
+1028,0,0,0,0,0,0,0,0,0,0,0,0,0
+1029,0,0,0,0,0,0,0,0,0,0,0,0,0
+1030,0,0,0,0,0,0,0,0,0,0,0,0,0
+1031,0,0,0,0,0,0,0,0,0,0,0,0,0
+1032,0,0,0,0,0,0,0,0,0,0,0,0,0
+1033,0,0,0,0,0,0,0,0,0,0,0,0,0
+1034,0,0,0,0,0,0,0,0,0,0,0,0,0
+1035,0,0,0,0,0,0,0,0,0,0,0,0,0
+1036,0,0,0,0,0,0,0,0,0,0,0,0,0
+1037,0,0,0,0,0,0,0,0,0,0,0,0,0
+1038,0,0,0,0,0,0,0,0,0,0,0,0,0
+1039,0,0,0,0,0,0,0,0,0,0,0,0,0
+1040,0,0,0,0,0,0,0,0,0,0,0,0,0
+1041,0,0,0,0,0,0,0,0,0,0,0,0,0
+1042,0,0,0,0,0,0,0,0,0,0,0,0,0
+1043,0,0,0,0,0,0,0,0,0,0,0,0,0
+1044,0,0,0,0,0,0,0,0,0,0,0,0,0
+1045,0,0,0,0,0,0,0,0,0,0,0,0,0
+1046,0,0,0,0,0,0,0,0,0,0,0,0,0
+1047,0,0,0,0,0,0,0,0,0,0,0,0,0
+1048,0,0,0,0,0,0,0,0,0,0,0,0,0
+1049,0,0,0,0,0,0,0,0,0,0,0,0,0
+1050,0,0,0,0,0,0,0,0,0,0,0,0,0
+1051,0,0,0,0,0,0,0,0,0,0,0,0,0
+1052,0,0,0,0,0,0,0,0,0,0,0,0,0
+1053,0,0,0,0,0,0,0,0,0,0,0,0,0
+1054,0,0,0,0,0,0,0,0,0,0,0,0,0
+1055,0,0,0,0,0,0,0,0,0,0,0,0,0
+1056,0,0,0,0,0,0,0,0,0,0,0,0,0
+1057,0,0,0,0,0,0,0,0,0,0,0,0,0
+1058,0,0,0,0,0,0,0,0,0,0,0,0,0
+1059,0,0,0,0,0,0,0,0,0,0,0,0,0
+1060,0,0,0,0,0,0,0,0,0,0,0,0,0
+1061,0,0,0,0,0,0,0,0,0,0,0,0,0
+1062,0,0,0,0,0,0,0,0,0,0,0,0,0
+1063,0,0,0,0,0,0,0,0,0,0,0,0,0
+1064,0,0,0,0,0,0,0,0,0,0,0,0,0
+1065,0,0,0,0,0,0,0,0,0,0,0,0,0
+1066,0,0,0,0,0,0,0,0,0,0,0,0,0
+1067,0,0,0,0,0,0,0,0,0,0,0,0,0
+1068,0,0,0,0,0,0,0,0,0,0,0,0,0
+1069,0,0,0,0,0,0,0,0,0,0,0,0,0
+1070,0,0,0,0,0,0,0,0,0,0,0,0,0
+1071,0,0,0,0,0,0,0,0,0,0,0,0,0
+1072,0,0,0,0,0,0,0,0,0,0,0,0,0
+1073,0,0,0,0,0,0,0,0,0,0,0,0,0
+1074,0,0,0,0,0,0,0,0,0,0,0,0,0
+1075,0,0,0,0,0,0,0,0,0,0,0,0,0
+1076,0,0,0,0,0,0,0,0,0,0,0,0,0
+1077,0,0,0,0,0,0,0,0,0,0,0,0,0
+1078,0,0,0,0,0,0,0,0,0,0,0,0,0
+1079,0,0,0,0,0,0,0,0,0,0,0,0,0
+1080,0,0,0,0,0,0,0,0,0,0,0,0,0
+1081,0,0,0,0,0,0,0,0,0,0,0,0,0
+1082,0,0,0,0,0,0,0,0,0,0,0,0,0
+1083,0,0,0,0,0,0,0,0,0,0,0,0,0
+1084,0,0,0,0,0,0,0,0,0,0,0,0,0
+1085,0,0,0,0,0,0,0,0,0,0,0,0,0
+1086,0,0,0,0,0,0,0,0,0,0,0,0,0
+1087,0,0,0,0,0,0,0,0,0,0,0,0,0
+1088,0,0,0,0,0,0,0,0,0,0,0,0,0
+1089,0,0,0,0,0,0,0,0,0,0,0,0,0
+1090,0,0,0,0,0,0,0,0,0,0,0,0,0
+1091,0,0,0,0,0,0,0,0,0,0,0,0,0
+1092,0,0,0,0,0,0,0,0,0,0,0,0,0
+1093,0,0,0,0,0,0,0,0,0,0,0,0,0
+1094,0,0,0,0,0,0,0,0,0,0,0,0,0
+1095,0,0,0,0,0,0,0,0,0,0,0,0,0
+1096,0,0,0,0,0,0,0,0,0,0,0,0,0
+1097,0,0,0,0,0,0,0,0,0,0,0,0,0
+1098,0,0,0,0,0,0,0,0,0,0,0,0,0
+1099,0,0,0,0,0,0,0,0,0,0,0,0,0
+1100,0,0,0,0,0,0,0,0,0,0,0,0,0
+1101,0,0,0,0,0,0,0,0,0,0,0,0,0
+1102,0,0,0,0,0,0,0,0,0,0,0,0,0
+1103,0,0,0,0,0,0,0,0,0,0,0,0,0
+1104,0,0,0,0,0,0,0,0,0,0,0,0,0
+1105,0,0,0,0,0,0,0,0,0,0,0,0,0
+1106,0,0,0,0,0,0,0,0,0,0,0,0,0
+1107,0,0,0,0,0,0,0,0,0,0,0,0,0
+1108,0,0,0,0,0,0,0,0,0,0,0,0,0
+1109,0,0,0,0,0,0,0,0,0,0,0,0,0
+1110,0,0,0,0,0,0,0,0,0,0,0,0,0
+1111,0,0,0,0,0,0,0,0,0,0,0,0,0
+1112,0,0,0,0,0,0,0,0,0,0,0,0,0
+1113,0,0,0,0,0,0,0,0,0,0,0,0,0
+1114,0,0,0,0,0,0,0,0,0,0,0,0,0
+1115,0,0,0,0,0,0,0,0,0,0,0,0,0
+1116,0,0,0,0,0,0,0,0,0,0,0,0,0
+1117,0,0,0,0,0,0,0,0,0,0,0,0,0
+1118,0,0,0,0,0,0,0,0,0,0,0,0,0
+1119,0,0,0,0,0,0,0,0,0,0,0,0,0
+1120,0,0,0,0,0,0,0,0,0,0,0,0,0
+1121,0,0,0,0,0,0,0,0,0,0,0,0,0
+1122,0,0,0,0,0,0,0,0,0,0,0,0,0
+1123,0,0,0,0,0,0,0,0,0,0,0,0,0
+1124,0,0,0,0,0,0,0,0,0,0,0,0,0
+1125,0,0,0,0,0,0,0,0,0,0,0,0,0
+1126,0,0,0,0,0,0,0,0,0,0,0,0,0
+1127,0,0,0,0,0,0,0,0,0,0,0,0,0
+1128,0,0,0,0,0,0,0,0,0,0,0,0,0
+1129,0,0,0,0,0,0,0,0,0,0,0,0,0
+1130,0,0,0,0,0,0,0,0,0,0,0,0,0
+1131,0,0,0,0,0,0,0,0,0,0,0,0,0
+1132,0,0,0,0,0,0,0,0,0,0,0,0,0
+1133,0,0,0,0,0,0,0,0,0,0,0,0,0
+1134,0,0,0,0,0,0,0,0,0,0,0,0,0
+1135,0,0,0,0,0,0,0,0,0,0,0,0,0
+1136,0,0,0,0,0,0,0,0,0,0,0,0,0
+1137,0,0,0,0,0,0,0,0,0,0,0,0,0
+1138,0,0,0,0,0,0,0,0,0,0,0,0,0
+1139,0,0,0,0,0,0,0,0,0,0,0,0,0
+1140,0,0,0,0,0,0,0,0,0,0,0,0,0
+1141,0,0,0,0,0,0,0,0,0,0,0,0,0
+1142,0,0,0,0,0,0,0,0,0,0,0,0,0
+1143,0,0,0,0,0,0,0,0,0,0,0,0,0
+1144,0,0,0,0,0,0,0,0,0,0,0,0,0
+1145,0,0,0,0,0,0,0,0,0,0,0,0,0
+1146,0,0,0,0,0,0,0,0,0,0,0,0,0
+1147,0,0,0,0,0,0,0,0,0,0,0,0,0
+1148,0,0,0,0,0,0,0,0,0,0,0,0,0
+1149,0,0,0,0,0,0,0,0,0,0,0,0,0
+1150,0,0,0,0,0,0,0,0,0,0,0,0,0
+1151,0,0,0,0,0,0,0,0,0,0,0,0,0
+1152,0,0,0,0,0,0,0,0,0,0,0,0,0
+1153,0,0,0,0,0,0,0,0,0,0,0,0,0
+1154,0,0,0,0,0,0,0,0,0,0,0,0,0
+1155,0,0,0,0,0,0,0,0,0,0,0,0,0
+1156,0,0,0,0,0,0,0,0,0,0,0,0,0
+1157,0,0,0,0,0,0,0,0,0,0,0,0,0
+1158,0,0,0,0,0,0,0,0,0,0,0,0,0
+1159,0,0,0,0,0,0,0,0,0,0,0,0,0
+1160,0,0,0,0,0,0,0,0,0,0,0,0,0
+1161,0,0,0,0,0,0,0,0,0,0,0,0,0
+1162,0,0,0,0,0,0,0,0,0,0,0,0,0
+1163,0,0,0,0,0,0,0,0,0,0,0,0,0
+1164,0,0,0,0,0,0,0,0,0,0,0,0,0
+1165,0,0,0,0,0,0,0,0,0,0,0,0,0
+1166,0,0,0,0,0,0,0,0,0,0,0,0,0
+1167,0,0,0,0,0,0,0,0,0,0,0,0,0
+1168,0,0,0,0,0,0,0,0,0,0,0,0,0
+1169,0,0,0,0,0,0,0,0,0,0,0,0,0
+1170,0,0,0,0,0,0,0,0,0,0,0,0,0
+1171,0,0,0,0,0,0,0,0,0,0,0,0,0
+1172,0,0,0,0,0,0,0,0,0,0,0,0,0
+1173,0,0,0,0,0,0,0,0,0,0,0,0,0
+1174,0,0,0,0,0,0,0,0,0,0,0,0,0
+1175,0,0,0,0,0,0,0,0,0,0,0,0,0
+1176,0,0,0,0,0,0,0,0,0,0,0,0,0
+1177,0,0,0,0,0,0,0,0,0,0,0,0,0
+1178,0,0,0,0,0,0,0,0,0,0,0,0,0
+1179,0,0,0,0,0,0,0,0,0,0,0,0,0
+1180,0,0,0,0,0,0,0,0,0,0,0,0,0
+1181,0,0,0,0,0,0,0,0,0,0,0,0,0
+1182,0,0,0,0,0,0,0,0,0,0,0,0,0
+1183,0,0,0,0,0,0,0,0,0,0,0,0,0
+1184,0,0,0,0,0,0,0,0,0,0,0,0,0
+1185,0,0,0,0,0,0,0,0,0,0,0,0,0
+1186,0,0,0,0,0,0,0,0,0,0,0,0,0
+1187,0,0,0,0,0,0,0,0,0,0,0,0,0
+1188,0,0,0,0,0,0,0,0,0,0,0,0,0
+1189,0,0,0,0,0,0,0,0,0,0,0,0,0
+1190,0,0,0,0,0,0,0,0,0,0,0,0,0
+1191,0,0,0,0,0,0,0,0,0,0,0,0,0
+1192,0,0,0,0,0,0,0,0,0,0,0,0,0
+1193,0,0,0,0,0,0,0,0,0,0,0,0,0
+1194,0,0,0,0,0,0,0,0,0,0,0,0,0
+1195,0,0,0,0,0,0,0,0,0,0,0,0,0
+1196,0,0,0,0,0,0,0,0,0,0,0,0,0
+1197,0,0,0,0,0,0,0,0,0,0,0,0,0
+1198,0,0,0,0,0,0,0,0,0,0,0,0,0
+1199,0,0,0,0,0,0,0,0,0,0,0,0,0
+1200,0,0,0,0,0,0,0,0,0,0,0,0,0
+1201,0,0,0,0,0,0,0,0,0,0,0,0,0
+1202,0,0,0,0,0,0,0,0,0,0,0,0,0
+1203,0,0,0,0,0,0,0,0,0,0,0,0,0
+1204,0,0,0,0,0,0,0,0,0,0,0,0,0
+1205,0,0,0,0,0,0,0,0,0,0,0,0,0
+1206,0,0,0,0,0,0,0,0,0,0,0,0,0
+1207,0,0,0,0,0,0,0,0,0,0,0,0,0
+1208,0,0,0,0,0,0,0,0,0,0,0,0,0
+1209,0,0,0,0,0,0,0,0,0,0,0,0,0
+1210,0,0,0,0,0,0,0,0,0,0,0,0,0
+1211,0,0,0,0,0,0,0,0,0,0,0,0,0
+1212,0,0,0,0,0,0,0,0,0,0,0,0,0
+1213,0,0,0,0,0,0,0,0,0,0,0,0,0
+1214,0,0,0,0,0,0,0,0,0,0,0,0,0
+1215,0,0,0,0,0,0,0,0,0,0,0,0,0
+1216,0,0,0,0,0,0,0,0,0,0,0,0,0
+1217,0,0,0,0,0,0,0,0,0,0,0,0,0
+1218,0,0,0,0,0,0,0,0,0,0,0,0,0
+1219,0,0,0,0,0,0,0,0,0,0,0,0,0
+1220,0,0,0,0,0,0,0,0,0,0,0,0,0
+1221,0,0,0,0,0,0,0,0,0,0,0,0,0
+1222,0,0,0,0,0,0,0,0,0,0,0,0,0
+1223,0,0,0,0,0,0,0,0,0,0,0,0,0
+1224,0,0,0,0,0,0,0,0,0,0,0,0,0
+1225,0,0,0,0,0,0,0,0,0,0,0,0,0
+1226,0,0,0,0,0,0,0,0,0,0,0,0,0
+1227,0,0,0,0,0,0,0,0,0,0,0,0,0
+1228,0,0,0,0,0,0,0,0,0,0,0,0,0
+1229,0,0,0,0,0,0,0,0,0,0,0,0,0
+1230,0,0,0,0,0,0,0,0,0,0,0,0,0
+1231,0,0,0,0,0,0,0,0,0,0,0,0,0
+1232,0,0,0,0,0,0,0,0,0,0,0,0,0
+1233,0,0,0,0,0,0,0,0,0,0,0,0,0
+1234,0,0,0,0,0,0,0,0,0,0,0,0,0
+1235,0,0,0,0,0,0,0,0,0,0,0,0,0
+1236,0,0,0,0,0,0,0,0,0,0,0,0,0
+1237,0,0,0,0,0,0,0,0,0,0,0,0,0
+1238,0,0,0,0,0,0,0,0,0,0,0,0,0
+1239,0,0,0,0,0,0,0,0,0,0,0,0,0
+1240,0,0,0,0,0,0,0,0,0,0,0,0,0
+1241,0,0,0,0,0,0,0,0,0,0,0,0,0
+1242,0,0,0,0,0,0,0,0,0,0,0,0,0
+1243,0,0,0,0,0,0,0,0,0,0,0,0,0
+1244,0,0,0,0,0,0,0,0,0,0,0,0,0
+1245,0,0,0,0,0,0,0,0,0,0,0,0,0
+1246,0,0,0,0,0,0,0,0,0,0,0,0,0
+1247,0,0,0,0,0,0,0,0,0,0,0,0,0
+1248,0,0,0,0,0,0,0,0,0,0,0,0,0
+1249,0,0,0,0,0,0,0,0,0,0,0,0,0
+1250,0,0,0,0,0,0,0,0,0,0,0,0,0
+1251,0,0,0,0,0,0,0,0,0,0,0,0,0
+1252,0,0,0,0,0,0,0,0,0,0,0,0,0
+1253,0,0,0,0,0,0,0,0,0,0,0,0,0
+1254,0,0,0,0,0,0,0,0,0,0,0,0,0
+1255,0,0,0,0,0,0,0,0,0,0,0,0,0
+1256,0,0,0,0,0,0,0,0,0,0,0,0,0
+1257,0,0,0,0,0,0,0,0,0,0,0,0,0
+1258,0,0,0,0,0,0,0,0,0,0,0,0,0
+1259,0,0,0,0,0,0,0,0,0,0,0,0,0
+1260,0,0,0,0,0,0,0,0,0,0,0,0,0
+1261,0,0,0,0,0,0,0,0,0,0,0,0,0
+1262,0,0,0,0,0,0,0,0,0,0,0,0,0
+1263,0,0,0,0,0,0,0,0,0,0,0,0,0
+1264,0,0,0,0,0,0,0,0,0,0,0,0,0
+1265,0,0,0,0,0,0,0,0,0,0,0,0,0
+1266,0,0,0,0,0,0,0,0,0,0,0,0,0
+1267,0,0,0,0,0,0,0,0,0,0,0,0,0
+1268,0,0,0,0,0,0,0,0,0,0,0,0,0
+1269,0,0,0,0,0,0,0,0,0,0,0,0,0
+1270,0,0,0,0,0,0,0,0,0,0,0,0,0
+1271,0,0,0,0,0,0,0,0,0,0,0,0,0
+1272,0,0,0,0,0,0,0,0,0,0,0,0,0
+1273,0,0,0,0,0,0,0,0,0,0,0,0,0
+1274,0,0,0,0,0,0,0,0,0,0,0,0,0
+1275,0,0,0,0,0,0,0,0,0,0,0,0,0
+1276,0,0,0,0,0,0,0,0,0,0,0,0,0
+1277,0,0,0,0,0,0,0,0,0,0,0,0,0
+1278,0,0,0,0,0,0,0,0,0,0,0,0,0
+1279,0,0,0,0,0,0,0,0,0,0,0,0,0
+1280,0,0,0,0,0,0,0,0,0,0,0,0,0
+1281,0,0,0,0,0,0,0,0,0,0,0,0,0
+1282,0,0,0,0,0,0,0,0,0,0,0,0,0
+1283,0,0,0,0,0,0,0,0,0,0,0,0,0
+1284,0,0,0,0,0,0,0,0,0,0,0,0,0
+1285,0,0,0,0,0,0,0,0,0,0,0,0,0
+1286,0,0,0,0,0,0,0,0,0,0,0,0,0
+1287,0,0,0,0,0,0,0,0,0,0,0,0,0
+1288,0,0,0,0,0,0,0,0,0,0,0,0,0
+1289,0,0,0,0,0,0,0,0,0,0,0,0,0
+1290,0,0,0,0,0,0,0,0,0,0,0,0,0
+1291,0,0,0,0,0,0,0,0,0,0,0,0,0
+1292,0,0,0,0,0,0,0,0,0,0,0,0,0
+1293,0,0,0,0,0,0,0,0,0,0,0,0,0
+1294,0,0,0,0,0,0,0,0,0,0,0,0,0
+1295,0,0,0,0,0,0,0,0,0,0,0,0,0
+1296,0,0,0,0,0,0,0,0,0,0,0,0,0
+1297,0,0,0,0,0,0,0,0,0,0,0,0,0
+1298,0,0,0,0,0,0,0,0,0,0,0,0,0
+1299,0,0,0,0,0,0,0,0,0,0,0,0,0
+1300,0,0,0,0,0,0,0,0,0,0,0,0,0
+1301,0,0,0,0,0,0,0,0,0,0,0,0,0
+1302,0,0,0,0,0,0,0,0,0,0,0,0,0
+1303,0,0,0,0,0,0,0,0,0,0,0,0,0
+1304,0,0,0,0,0,0,0,0,0,0,0,0,0
+1305,0,0,0,0,0,0,0,0,0,0,0,0,0
+1306,0,0,0,0,0,0,0,0,0,0,0,0,0
+1307,0,0,0,0,0,0,0,0,0,0,0,0,0
+1308,0,0,0,0,0,0,0,0,0,0,0,0,0
+1309,0,0,0,0,0,0,0,0,0,0,0,0,0
+1310,0,0,0,0,0,0,0,0,0,0,0,0,0
+1311,0,0,0,0,0,0,0,0,0,0,0,0,0
+1312,0,0,0,0,0,0,0,0,0,0,0,0,0
+1313,0,0,0,0,0,0,0,0,0,0,0,0,0
+1314,0,0,0,0,0,0,0,0,0,0,0,0,0
+1315,0,0,0,0,0,0,0,0,0,0,0,0,0
+1316,0,0,0,0,0,0,0,0,0,0,0,0,0
+1317,0,0,0,0,0,0,0,0,0,0,0,0,0
+1318,0,0,0,0,0,0,0,0,0,0,0,0,0
+1319,0,0,0,0,0,0,0,0,0,0,0,0,0
+1320,0,0,0,0,0,0,0,0,0,0,0,0,0
+1321,0,0,0,0,0,0,0,0,0,0,0,0,0
+1322,0,0,0,0,0,0,0,0,0,0,0,0,0
+1323,0,0,0,0,0,0,0,0,0,0,0,0,0
+1324,0,0,0,0,0,0,0,0,0,0,0,0,0
+1325,0,0,0,0,0,0,0,0,0,0,0,0,0
+1326,0,0,0,0,0,0,0,0,0,0,0,0,0
+1327,0,0,0,0,0,0,0,0,0,0,0,0,0
+1328,0,0,0,0,0,0,0,0,0,0,0,0,0
+1329,0,0,0,0,0,0,0,0,0,0,0,0,0
+1330,0,0,0,0,0,0,0,0,0,0,0,0,0
+1331,0,0,0,0,0,0,0,0,0,0,0,0,0
+1332,0,0,0,0,0,0,0,0,0,0,0,0,0
+1333,0,0,0,0,0,0,0,0,0,0,0,0,0
+1334,0,0,0,0,0,0,0,0,0,0,0,0,0
+1335,0,0,0,0,0,0,0,0,0,0,0,0,0
+1336,0,0,0,0,0,0,0,0,0,0,0,0,0
+1337,0,0,0,0,0,0,0,0,0,0,0,0,0
+1338,0,0,0,0,0,0,0,0,0,0,0,0,0
+1339,0,0,0,0,0,0,0,0,0,0,0.000024519,0,0
+1340,0,0,0,0,0,0,0,0,0,0,0.000136201,0,0
+1341,0,0,0,0,0,0,0,0,0,0,0.000124629,0,0
+1342,0,0,0,0,0,0,0,0,0,0,0.000088936,0,0
+1343,0,0,0,0,0,0,0,0,0,0,0.000124168,0,0
+1344,0,0,0,0,0,0,0,0,0,0,0.000099355,0,0
+1345,0,0,0,0,0,0,0,0,0,0,0.000139099,0,0
+1346,0,0,0,0,0,0,0,0,0,0,0.000157557,0,0
+1347,0,0,0,0,0,0,0,0,0,0,0.000192392,0,0
+1348,0,0,0,0,0,0,0,0,0,0,0.00025967,0,0
+1349,0,0,0,0,0,0,0,0,0,0,0.000322212,0,0
+1350,0,0,0,0,0,0,0,0,0,0,0.00034665,0,0
+1351,0,0,0,0,0,0,0,0,0,0,0.000368979,0,0
+1352,0,0,0,0,0,0,0,0,0,0,0.000547142,0,0
+1353,0,0,0,0,0,0,0,0,0,0,0.001050938,0,0
+1354,0,0,0,0,0,0,0,0,0,0,0.00218105,0,0
+1355,0,0,0,0,0,0,0,0,0,0,0.004790717,0,0
+1356,0,0,0,0,0,0,0,0,0,0,0.011310302,0,0
+1357,0,0,0,0,0,0,0,0,0,0,0.026613248,0,0
+1358,0,0,0,0,0,0,0,0,0,0,0.057559739,0,0
+1359,0,0,0,0,0,0,0,0,0,0,0.111412066,0,0
+1360,0,0,0,0,0,0,0,0,0,0,0.19534134,0,0
+1361,0,0,0,0,0,0,0,0,0,0,0.313481067,0,0
+1362,0,0,0,0,0,0,0,0,0,0,0.461097437,0,0
+1363,0,0,0,0,0,0,0,0,0,0,0.6221953,0,0
+1364,0,0,0,0,0,0,0,0,0,0,0.770430827,0,0
+1365,0,0,0,0,0,0,0,0,0,0,0.880535922,0,0
+1366,0,0,0,0,0,0,0,0,0,0,0.944739275,0,0
+1367,0,0,0,0,0,0,0,0,0,0,0.97397875,0,0
+1368,0,0,0,0,0,0,0,0,0,0,0.98611756,0,0
+1369,0,0,0,0,0,0,0,0,0,0,0.993032255,0,0
+1370,0,0,0,0,0,0,0,0,0,0,0.997734947,0,0
+1371,0,0,0,0,0,0,0,0,0,0,1,0,0
+1372,0,0,0,0,0,0,0,0,0,0,0.999440391,0,0
+1373,0,0,0,0,0,0,0,0,0,0,0.996198129,0,0
+1374,0,0,0,0,0,0,0,0,0,0,0.990856204,0,0
+1375,0,0,0,0,0,0,0,0,0,0,0.984248642,0,0
+1376,0,0,0,0,0,0,0,0,0,0,0.977116358,0,0
+1377,0,0,0,0,0,0,0,0,0,0,0.970164279,0,0
+1378,0,0,0,0,0,0,0,0,0,0,0.963770069,0,0
+1379,0,0,0,0,0,0,0,0,0,0,0.957577366,0,0
+1380,0,0,0,0,0,0,0,0,0,0,0.951303557,0,0
+1381,0,0,0,0,0,0,0,0,0,0,0.945493586,0,0
+1382,0,0,0,0,0,0,0,0,0,0,0.940718335,0,0
+1383,0,0,0,0,0,0,0,0,0,0,0.937614311,0,0
+1384,0,0,0,0,0,0,0,0,0,0,0.936274454,0,0
+1385,0,0,0,0,0,0,0,0,0,0,0.935168115,0,0
+1386,0,0,0,0,0,0,0,0,0,0,0.930686598,0,0
+1387,0,0,0,0,0,0,0,0,0,0,0.916569659,0,0
+1388,0,0,0,0,0,0,0,0,0,0,0.885721386,0,0
+1389,0,0,0,0,0,0,0,0,0,0,0.831894981,0,0
+1390,0,0,0,0,0,0,0,0,0,0,0.749343254,0,0
+1391,0,0,0,0,0,0,0,0,0,0,0.636158996,0,0
+1392,0,0,0,0,0,0,0,0,0,0,0.498288066,0,0
+1393,0,0,0,0,0,0,0,0,0,0,0.349944188,0,0
+1394,0,0,0,0,0,0,0,0,0,0,0.21325372,0,0
+1395,0,0,0,0,0,0,0,0,0,0,0.110112562,0,0
+1396,0,0,0,0,0,0,0,0,0,0,0.048081597,0,0
+1397,0,0,0,0,0,0,0,0,0,0,0.018603066,0,0
+1398,0,0,0,0,0,0,0,0,0,0,0.007193874,0,0
+1399,0,0,0,0,0,0,0,0,0,0,0.003163765,0,0
+1400,0,0,0,0,0,0,0,0,0,0,0.001575442,0,0
+1401,0,0,0,0,0,0,0,0,0,0,0.000851825,0,0
+1402,0,0,0,0,0,0,0,0,0,0,0.000531218,0,0
+1403,0,0,0,0,0,0,0,0,0,0,0.00033209,0,0
+1404,0,0,0,0,0,0,0,0,0,0,0.000194334,0,0
+1405,0,0,0,0,0,0,0,0,0,0,0.000220804,0,0
+1406,0,0,0,0,0,0,0,0,0,0,0.000226309,0,0
+1407,0,0,0,0,0,0,0,0,0,0,0.000181374,0,0
+1408,0,0,0,0,0,0,0,0,0,0,0.000160139,0,0
+1409,0,0,0,0,0,0,0,0,0,0,0.000154509,0,0
+1410,0,0,0,0,0,0,0,0,0,0,0.000147455,0,0
+1411,0,0,0,0,0,0,0,0,0,0,0.000147793,0,0
+1412,0,0,0,0,0,0,0,0,0,0,0.000174384,0,0
+1413,0,0,0,0,0,0,0,0,0,0,0.000234351,0,0
+1414,0,0,0,0,0,0,0,0,0,0,0.000119559,0,0
+1415,0,0,0,0,0,0,0,0,0,0,0.000043811,0,0
+1416,0,0,0,0,0,0,0,0,0,0,0,0,0
+1417,0,0,0,0,0,0,0,0,0,0,0,0,0
+1418,0,0,0,0,0,0,0,0,0,0,0,0,0
+1419,0,0,0,0,0,0,0,0,0,0,0,0,0
+1420,0,0,0,0,0,0,0,0,0,0,0,0,0
+1421,0,0,0,0,0,0,0,0,0,0,0,0,0
+1422,0,0,0,0,0,0,0,0,0,0,0,0,0
+1423,0,0,0,0,0,0,0,0,0,0,0,0,0
+1424,0,0,0,0,0,0,0,0,0,0,0,0,0
+1425,0,0,0,0,0,0,0,0,0,0,0,0,0
+1426,0,0,0,0,0,0,0,0,0,0,0,0,0
+1427,0,0,0,0,0,0,0,0,0,0,0,0,0
+1428,0,0,0,0,0,0,0,0,0,0,0,0,0
+1429,0,0,0,0,0,0,0,0,0,0,0,0,0
+1430,0,0,0,0,0,0,0,0,0,0,0,0,0
+1431,0,0,0,0,0,0,0,0,0,0,0,0,0
+1432,0,0,0,0,0,0,0,0,0,0,0,0,0
+1433,0,0,0,0,0,0,0,0,0,0,0,0,0
+1434,0,0,0,0,0,0,0,0,0,0,0,0,0
+1435,0,0,0,0,0,0,0,0,0,0,0,0,0
+1436,0,0,0,0,0,0,0,0,0,0,0,0,0
+1437,0,0,0,0,0,0,0,0,0,0,0,0,0
+1438,0,0,0,0,0,0,0,0,0,0,0,0,0
+1439,0,0,0,0,0,0,0,0,0,0,0,0,0
+1440,0,0,0,0,0,0,0,0,0,0,0,0,0
+1441,0,0,0,0,0,0,0,0,0,0,0,0,0
+1442,0,0,0,0,0,0,0,0,0,0,0,0,0
+1443,0,0,0,0,0,0,0,0,0,0,0,0,0
+1444,0,0,0,0,0,0,0,0,0,0,0,0,0
+1445,0,0,0,0,0,0,0,0,0,0,0,0,0
+1446,0,0,0,0,0,0,0,0,0,0,0,0,0
+1447,0,0,0,0,0,0,0,0,0,0,0,0,0
+1448,0,0,0,0,0,0,0,0,0,0,0,0,0
+1449,0,0,0,0,0,0,0,0,0,0,0,0,0
+1450,0,0,0,0,0,0,0,0,0,0,0,0,0
+1451,0,0,0,0,0,0,0,0,0,0,0,0,0
+1452,0,0,0,0,0,0,0,0,0,0,0,0,0
+1453,0,0,0,0,0,0,0,0,0,0,0,0,0
+1454,0,0,0,0,0,0,0,0,0,0,0,0,0
+1455,0,0,0,0,0,0,0,0,0,0,0,0,0
+1456,0,0,0,0,0,0,0,0,0,0,0,0,0
+1457,0,0,0,0,0,0,0,0,0,0,0,0,0
+1458,0,0,0,0,0,0,0,0,0,0,0,0,0
+1459,0,0,0,0,0,0,0,0,0,0,0,0,0
+1460,0,0,0,0,0,0,0,0,0,0,0,0,0
+1461,0,0,0,0,0,0,0,0,0,0,0,0,0
+1462,0,0,0,0,0,0,0,0,0,0,0,0,0
+1463,0,0,0,0,0,0,0,0,0,0,0,0,0
+1464,0,0,0,0,0,0,0,0,0,0,0,0,0
+1465,0,0,0,0,0,0,0,0,0,0,0,0,0
+1466,0,0,0,0,0,0,0,0,0,0,0,0,0
+1467,0,0,0,0,0,0,0,0,0,0,0,0,0
+1468,0,0,0,0,0,0,0,0,0,0,0,0,0
+1469,0,0,0,0,0,0,0,0,0,0,0,0,0
+1470,0,0,0,0,0,0,0,0,0,0,0,0,0
+1471,0,0,0,0,0,0,0,0,0,0,0,0,0
+1472,0,0,0,0,0,0,0,0,0,0,0,0,0
+1473,0,0,0,0,0,0,0,0,0,0,0,0,0
+1474,0,0,0,0,0,0,0,0,0,0,0,0,0
+1475,0,0,0,0,0,0,0,0,0,0,0,0,0
+1476,0,0,0,0,0,0,0,0,0,0,0,0,0
+1477,0,0,0,0,0,0,0,0,0,0,0,0,0
+1478,0,0,0,0,0,0,0,0,0,0,0,0,0
+1479,0,0,0,0,0,0,0,0,0,0,0,0,0
+1480,0,0,0,0,0,0,0,0,0,0,0,0,0
+1481,0,0,0,0,0,0,0,0,0,0,0,0,0
+1482,0,0,0,0,0,0,0,0,0,0,0,0,0
+1483,0,0,0,0,0,0,0,0,0,0,0,0,0
+1484,0,0,0,0,0,0,0,0,0,0,0,0,0
+1485,0,0,0,0,0,0,0,0,0,0,0,0,0
+1486,0,0,0,0,0,0,0,0,0,0,0,0,0
+1487,0,0,0,0,0,0,0,0,0,0,0,0,0
+1488,0,0,0,0,0,0,0,0,0,0,0,0,0
+1489,0,0,0,0,0,0,0,0,0,0,0,0,0
+1490,0,0,0,0,0,0,0,0,0,0,0,0,0
+1491,0,0,0,0,0,0,0,0,0,0,0,0,0
+1492,0,0,0,0,0,0,0,0,0,0,0,0,0
+1493,0,0,0,0,0,0,0,0,0,0,0,0,0
+1494,0,0,0,0,0,0,0,0,0,0,0,0,0
+1495,0,0,0,0,0,0,0,0,0,0,0,0,0
+1496,0,0,0,0,0,0,0,0,0,0,0,0,0
+1497,0,0,0,0,0,0,0,0,0,0,0,0,0
+1498,0,0,0,0,0,0,0,0,0,0,0,0,0
+1499,0,0,0,0,0,0,0,0,0,0,0,0,0
+1500,0,0,0,0,0,0,0,0,0,0,0,0,0
+1501,0,0,0,0,0,0,0,0,0,0,0,0,0
+1502,0,0,0,0,0,0,0,0,0,0,0,0,0
+1503,0,0,0,0,0,0,0,0,0,0,0,0,0
+1504,0,0,0,0,0,0,0,0,0,0,0,0,0
+1505,0,0,0,0,0,0,0,0,0,0,0,0,0
+1506,0,0,0,0,0,0,0,0,0,0,0,0,0
+1507,0,0,0,0,0,0,0,0,0,0,0,0,0
+1508,0,0,0,0,0,0,0,0,0,0,0,0,0
+1509,0,0,0,0,0,0,0,0,0,0,0,0,0
+1510,0,0,0,0,0,0,0,0,0,0,0,0,0
+1511,0,0,0,0,0,0,0,0,0,0,0,0,0
+1512,0,0,0,0,0,0,0,0,0,0,0,0,0
+1513,0,0,0,0,0,0,0,0,0,0,0,0,0
+1514,0,0,0,0,0,0,0,0,0,0,0,0,0
+1515,0,0,0,0,0,0,0,0,0,0,0,0,0
+1516,0,0,0,0,0,0,0,0,0,0,0,0,0
+1517,0,0,0,0,0,0,0,0,0,0,0,0,0
+1518,0,0,0,0,0,0,0,0,0,0,0,0,0
+1519,0,0,0,0,0,0,0,0,0,0,0,0,0
+1520,0,0,0,0,0,0,0,0,0,0,0,0,0
+1521,0,0,0,0,0,0,0,0,0,0,0,0,0
+1522,0,0,0,0,0,0,0,0,0,0,0,0,0
+1523,0,0,0,0,0,0,0,0,0,0,0,0,0
+1524,0,0,0,0,0,0,0,0,0,0,0,0,0
+1525,0,0,0,0,0,0,0,0,0,0,0,0,0
+1526,0,0,0,0,0,0,0,0,0,0,0,0,0
+1527,0,0,0,0,0,0,0,0,0,0,0,0,0
+1528,0,0,0,0,0,0,0,0,0,0,0,0,0
+1529,0,0,0,0,0,0,0,0,0,0,0,0,0
+1530,0,0,0,0,0,0,0,0,0,0,0,0,0
+1531,0,0,0,0,0,0,0,0,0,0,0,0,0
+1532,0,0,0,0,0,0,0,0,0,0,0,0,0
+1533,0,0,0,0,0,0,0,0,0,0,0,0,0
+1534,0,0,0,0,0,0,0,0,0,0,0,0,0
+1535,0,0,0,0,0,0,0,0,0,0,0,0,0
+1536,0,0,0,0,0,0,0,0,0,0,0,0,0
+1537,0,0,0,0,0,0,0,0,0,0,0,0,0
+1538,0,0,0,0,0,0,0,0,0,0,0,0.0000115,0
+1539,0,0,0,0,0,0,0,0,0,0,0,0.000026996,0
+1540,0,0,0,0,0,0,0,0,0,0,0,0.000081157,0
+1541,0,0,0,0,0,0,0,0,0,0,0,0.000169507,0
+1542,0,0,0,0,0,0,0,0,0,0,0,0.000273428,0
+1543,0,0,0,0,0,0,0,0,0,0,0,0.000343776,0
+1544,0,0,0,0,0,0,0,0,0,0,0,0.000459515,0
+1545,0,0,0,0,0,0,0,0,0,0,0,0.000651677,0
+1546,0,0,0,0,0,0,0,0,0,0,0,0.0008223,0
+1547,0,0,0,0,0,0,0,0,0,0,0,0.001076746,0
+1548,0,0,0,0,0,0,0,0,0,0,0,0.001428776,0
+1549,0,0,0,0,0,0,0,0,0,0,0,0.001958681,0
+1550,0,0,0,0,0,0,0,0,0,0,0,0.002660821,0
+1551,0,0,0,0,0,0,0,0,0,0,0,0.003682001,0
+1552,0,0,0,0,0,0,0,0,0,0,0,0.005217308,0
+1553,0,0,0,0,0,0,0,0,0,0,0,0.007572684,0
+1554,0,0,0,0,0,0,0,0,0,0,0,0.011246256,0
+1555,0,0,0,0,0,0,0,0,0,0,0,0.01713141,0
+1556,0,0,0,0,0,0,0,0,0,0,0,0.026703068,0
+1557,0,0,0,0,0,0,0,0,0,0,0,0.041388968,0
+1558,0,0,0,0,0,0,0,0,0,0,0,0.062904714,0
+1559,0,0,0,0,0,0,0,0,0,0,0,0.094492263,0
+1560,0,0,0,0,0,0,0,0,0,0,0,0.139743066,0
+1561,0,0,0,0,0,0,0,0,0,0,0,0.200760503,0
+1562,0,0,0,0,0,0,0,0,0,0,0,0.281513117,0
+1563,0,0,0,0,0,0,0,0,0,0,0,0.380879812,0
+1564,0,0,0,0,0,0,0,0,0,0,0,0.490209915,0
+1565,0,0,0,0,0,0,0,0,0,0,0,0.606204368,0
+1566,0,0,0,0,0,0,0,0,0,0,0,0.714558374,0
+1567,0,0,0,0,0,0,0,0,0,0,0,0.80351452,0
+1568,0,0,0,0,0,0,0,0,0,0,0,0.86986655,0
+1569,0,0,0,0,0,0,0,0,0,0,0,0.916284448,0
+1570,0,0,0,0,0,0,0,0,0,0,0,0.946609049,0
+1571,0,0,0,0,0,0,0,0,0,0,0,0.963892644,0
+1572,0,0,0,0,0,0,0,0,0,0,0,0.973065345,0
+1573,0,0,0,0,0,0,0,0,0,0,0,0.977057349,0
+1574,0,0,0,0,0,0,0,0,0,0,0,0.977796293,0
+1575,0,0,0,0,0,0,0,0,0,0,0,0.976890332,0
+1576,0,0,0,0,0,0,0,0,0,0,0,0.975338048,0
+1577,0,0,0,0,0,0,0,0,0,0,0,0.973392995,0
+1578,0,0,0,0,0,0,0,0,0,0,0,0.971480798,0
+1579,0,0,0,0,0,0,0,0,0,0,0,0.969740168,0
+1580,0,0,0,0,0,0,0,0,0,0,0,0.969095034,0
+1581,0,0,0,0,0,0,0,0,0,0,0,0.96969742,0
+1582,0,0,0,0,0,0,0,0,0,0,0,0.970522078,0
+1583,0,0,0,0,0,0,0,0,0,0,0,0.972736269,0
+1584,0,0,0,0,0,0,0,0,0,0,0,0.976138953,0
+1585,0,0,0,0,0,0,0,0,0,0,0,0.978944681,0
+1586,0,0,0,0,0,0,0,0,0,0,0,0.981010782,0
+1587,0,0,0,0,0,0,0,0,0,0,0,0.983513536,0
+1588,0,0,0,0,0,0,0,0,0,0,0,0.984837133,0
+1589,0,0,0,0,0,0,0,0,0,0,0,0.984404132,0
+1590,0,0,0,0,0,0,0,0,0,0,0,0.983920166,0
+1591,0,0,0,0,0,0,0,0,0,0,0,0.983372624,0
+1592,0,0,0,0,0,0,0,0,0,0,0,0.981458796,0
+1593,0,0,0,0,0,0,0,0,0,0,0,0.979391949,0
+1594,0,0,0,0,0,0,0,0,0,0,0,0.978058392,0
+1595,0,0,0,0,0,0,0,0,0,0,0,0.976263051,0
+1596,0,0,0,0,0,0,0,0,0,0,0,0.975392679,0
+1597,0,0,0,0,0,0,0,0,0,0,0,0.9757089,0
+1598,0,0,0,0,0,0,0,0,0,0,0,0.976805245,0
+1599,0,0,0,0,0,0,0,0,0,0,0,0.978986183,0
+1600,0,0,0,0,0,0,0,0,0,0,0,0.981998545,0
+1601,0,0,0,0,0,0,0,0,0,0,0,0.98520893,0
+1602,0,0,0,0,0,0,0,0,0,0,0,0.988659162,0
+1603,0,0,0,0,0,0,0,0,0,0,0,0.992331977,0
+1604,0,0,0,0,0,0,0,0,0,0,0,0.994804634,0
+1605,0,0,0,0,0,0,0,0,0,0,0,0.99589809,0
+1606,0,0,0,0,0,0,0,0,0,0,0,0.995903119,0
+1607,0,0,0,0,0,0,0,0,0,0,0,0.994773417,0
+1608,0,0,0,0,0,0,0,0,0,0,0,0.992101664,0
+1609,0,0,0,0,0,0,0,0,0,0,0,0.988591774,0
+1610,0,0,0,0,0,0,0,0,0,0,0,0.984908418,0
+1611,0,0,0,0,0,0,0,0,0,0,0,0.981101728,0
+1612,0,0,0,0,0,0,0,0,0,0,0,0.976805235,0
+1613,0,0,0,0,0,0,0,0,0,0,0,0.97354566,0
+1614,0,0,0,0,0,0,0,0,0,0,0,0.971948013,0
+1615,0,0,0,0,0,0,0,0,0,0,0,0.97053597,0
+1616,0,0,0,0,0,0,0,0,0,0,0,0.970436371,0
+1617,0,0,0,0,0,0,0,0,0,0,0,0.972382602,0
+1618,0,0,0,0,0,0,0,0,0,0,0,0.975244492,0
+1619,0,0,0,0,0,0,0,0,0,0,0,0.978552743,0
+1620,0,0,0,0,0,0,0,0,0,0,0,0.982971465,0
+1621,0,0,0,0,0,0,0,0,0,0,0,0.98808508,0
+1622,0,0,0,0,0,0,0,0,0,0,0,0.992662671,0
+1623,0,0,0,0,0,0,0,0,0,0,0,0.996435703,0
+1624,0,0,0,0,0,0,0,0,0,0,0,0.99906056,0
+1625,0,0,0,0,0,0,0,0,0,0,0,1,0
+1626,0,0,0,0,0,0,0,0,0,0,0,0.999036445,0
+1627,0,0,0,0,0,0,0,0,0,0,0,0.996642174,0
+1628,0,0,0,0,0,0,0,0,0,0,0,0.993293536,0
+1629,0,0,0,0,0,0,0,0,0,0,0,0.989674029,0
+1630,0,0,0,0,0,0,0,0,0,0,0,0.98579838,0
+1631,0,0,0,0,0,0,0,0,0,0,0,0.982153372,0
+1632,0,0,0,0,0,0,0,0,0,0,0,0.979817194,0
+1633,0,0,0,0,0,0,0,0,0,0,0,0.979473331,0
+1634,0,0,0,0,0,0,0,0,0,0,0,0.980262857,0
+1635,0,0,0,0,0,0,0,0,0,0,0,0.982464858,0
+1636,0,0,0,0,0,0,0,0,0,0,0,0.986000509,0
+1637,0,0,0,0,0,0,0,0,0,0,0,0.989562258,0
+1638,0,0,0,0,0,0,0,0,0,0,0,0.991723341,0
+1639,0,0,0,0,0,0,0,0,0,0,0,0.992201372,0
+1640,0,0,0,0,0,0,0,0,0,0,0,0.98939229,0
+1641,0,0,0,0,0,0,0,0,0,0,0,0.982102331,0
+1642,0,0,0,0,0,0,0,0,0,0,0,0.970157085,0
+1643,0,0,0,0,0,0,0,0,0,0,0,0.953186779,0
+1644,0,0,0,0,0,0,0,0,0,0,0,0.932369062,0
+1645,0,0,0,0,0,0,0,0,0,0,0,0.908001591,0
+1646,0,0,0,0,0,0,0,0,0,0,0,0.884086561,0
+1647,0,0,0,0,0,0,0,0,0,0,0,0.864271526,0
+1648,0,0,0,0,0,0,0,0,0,0,0,0.850889881,0
+1649,0,0,0,0,0,0,0,0,0,0,0,0.844206087,0
+1650,0,0,0,0,0,0,0,0,0,0,0,0.843448232,0
+1651,0,0,0,0,0,0,0,0,0,0,0,0.847024828,0
+1652,0,0,0,0,0,0,0,0,0,0,0,0.848701823,0
+1653,0,0,0,0,0,0,0,0,0,0,0,0.840540222,0
+1654,0,0,0,0,0,0,0,0,0,0,0,0.81352592,0
+1655,0,0,0,0,0,0,0,0,0,0,0,0.756843245,0
+1656,0,0,0,0,0,0,0,0,0,0,0,0.670393147,0
+1657,0,0,0,0,0,0,0,0,0,0,0,0.565754809,0
+1658,0,0,0,0,0,0,0,0,0,0,0,0.457566037,0
+1659,0,0,0,0,0,0,0,0,0,0,0,0.353763564,0
+1660,0,0,0,0,0,0,0,0,0,0,0,0.256912748,0
+1661,0,0,0,0,0,0,0,0,0,0,0,0.176281,0
+1662,0,0,0,0,0,0,0,0,0,0,0,0.115842988,0
+1663,0,0,0,0,0,0,0,0,0,0,0,0.073512768,0
+1664,0,0,0,0,0,0,0,0,0,0,0,0.046527708,0
+1665,0,0,0,0,0,0,0,0,0,0,0,0.02905985,0
+1666,0,0,0,0,0,0,0,0,0,0,0,0.018579999,0
+1667,0,0,0,0,0,0,0,0,0,0,0,0.012463091,0
+1668,0,0,0,0,0,0,0,0,0,0,0,0.00878944,0
+1669,0,0,0,0,0,0,0,0,0,0,0,0.006316358,0
+1670,0,0,0,0,0,0,0,0,0,0,0,0.004582867,0
+1671,0,0,0,0,0,0,0,0,0,0,0,0.003359394,0
+1672,0,0,0,0,0,0,0,0,0,0,0,0.002462997,0
+1673,0,0,0,0,0,0,0,0,0,0,0,0.001990739,0
+1674,0,0,0,0,0,0,0,0,0,0,0,0.001501488,0
+1675,0,0,0,0,0,0,0,0,0,0,0,0.001123371,0
+1676,0,0,0,0,0,0,0,0,0,0,0,0.00078272,0
+1677,0,0,0,0,0,0,0,0,0,0,0,0.000541322,0
+1678,0,0,0,0,0,0,0,0,0,0,0,0.000281204,0
+1679,0,0,0,0,0,0,0,0,0,0,0,0.00013347,0
+1680,0,0,0,0,0,0,0,0,0,0,0,0,0
+1681,0,0,0,0,0,0,0,0,0,0,0,0,0
+1682,0,0,0,0,0,0,0,0,0,0,0,0,0
+1683,0,0,0,0,0,0,0,0,0,0,0,0,0
+1684,0,0,0,0,0,0,0,0,0,0,0,0,0
+1685,0,0,0,0,0,0,0,0,0,0,0,0,0
+1686,0,0,0,0,0,0,0,0,0,0,0,0,0
+1687,0,0,0,0,0,0,0,0,0,0,0,0,0
+1688,0,0,0,0,0,0,0,0,0,0,0,0,0
+1689,0,0,0,0,0,0,0,0,0,0,0,0,0
+1690,0,0,0,0,0,0,0,0,0,0,0,0,0
+1691,0,0,0,0,0,0,0,0,0,0,0,0,0
+1692,0,0,0,0,0,0,0,0,0,0,0,0,0
+1693,0,0,0,0,0,0,0,0,0,0,0,0,0
+1694,0,0,0,0,0,0,0,0,0,0,0,0,0
+1695,0,0,0,0,0,0,0,0,0,0,0,0,0
+1696,0,0,0,0,0,0,0,0,0,0,0,0,0
+1697,0,0,0,0,0,0,0,0,0,0,0,0,0
+1698,0,0,0,0,0,0,0,0,0,0,0,0,0
+1699,0,0,0,0,0,0,0,0,0,0,0,0,0
+1700,0,0,0,0,0,0,0,0,0,0,0,0,0
+1701,0,0,0,0,0,0,0,0,0,0,0,0,0
+1702,0,0,0,0,0,0,0,0,0,0,0,0,0
+1703,0,0,0,0,0,0,0,0,0,0,0,0,0
+1704,0,0,0,0,0,0,0,0,0,0,0,0,0
+1705,0,0,0,0,0,0,0,0,0,0,0,0,0
+1706,0,0,0,0,0,0,0,0,0,0,0,0,0
+1707,0,0,0,0,0,0,0,0,0,0,0,0,0
+1708,0,0,0,0,0,0,0,0,0,0,0,0,0
+1709,0,0,0,0,0,0,0,0,0,0,0,0,0
+1710,0,0,0,0,0,0,0,0,0,0,0,0,0
+1711,0,0,0,0,0,0,0,0,0,0,0,0,0
+1712,0,0,0,0,0,0,0,0,0,0,0,0,0
+1713,0,0,0,0,0,0,0,0,0,0,0,0,0
+1714,0,0,0,0,0,0,0,0,0,0,0,0,0
+1715,0,0,0,0,0,0,0,0,0,0,0,0,0
+1716,0,0,0,0,0,0,0,0,0,0,0,0,0
+1717,0,0,0,0,0,0,0,0,0,0,0,0,0
+1718,0,0,0,0,0,0,0,0,0,0,0,0,0
+1719,0,0,0,0,0,0,0,0,0,0,0,0,0
+1720,0,0,0,0,0,0,0,0,0,0,0,0,0
+1721,0,0,0,0,0,0,0,0,0,0,0,0,0
+1722,0,0,0,0,0,0,0,0,0,0,0,0,0
+1723,0,0,0,0,0,0,0,0,0,0,0,0,0
+1724,0,0,0,0,0,0,0,0,0,0,0,0,0
+1725,0,0,0,0,0,0,0,0,0,0,0,0,0
+1726,0,0,0,0,0,0,0,0,0,0,0,0,0
+1727,0,0,0,0,0,0,0,0,0,0,0,0,0
+1728,0,0,0,0,0,0,0,0,0,0,0,0,0
+1729,0,0,0,0,0,0,0,0,0,0,0,0,0
+1730,0,0,0,0,0,0,0,0,0,0,0,0,0
+1731,0,0,0,0,0,0,0,0,0,0,0,0,0
+1732,0,0,0,0,0,0,0,0,0,0,0,0,0
+1733,0,0,0,0,0,0,0,0,0,0,0,0,0
+1734,0,0,0,0,0,0,0,0,0,0,0,0,0
+1735,0,0,0,0,0,0,0,0,0,0,0,0,0
+1736,0,0,0,0,0,0,0,0,0,0,0,0,0
+1737,0,0,0,0,0,0,0,0,0,0,0,0,0
+1738,0,0,0,0,0,0,0,0,0,0,0,0,0
+1739,0,0,0,0,0,0,0,0,0,0,0,0,0
+1740,0,0,0,0,0,0,0,0,0,0,0,0,0
+1741,0,0,0,0,0,0,0,0,0,0,0,0,0
+1742,0,0,0,0,0,0,0,0,0,0,0,0,0
+1743,0,0,0,0,0,0,0,0,0,0,0,0,0
+1744,0,0,0,0,0,0,0,0,0,0,0,0,0
+1745,0,0,0,0,0,0,0,0,0,0,0,0,0
+1746,0,0,0,0,0,0,0,0,0,0,0,0,0
+1747,0,0,0,0,0,0,0,0,0,0,0,0,0
+1748,0,0,0,0,0,0,0,0,0,0,0,0,0
+1749,0,0,0,0,0,0,0,0,0,0,0,0,0
+1750,0,0,0,0,0,0,0,0,0,0,0,0,0
+1751,0,0,0,0,0,0,0,0,0,0,0,0,0
+1752,0,0,0,0,0,0,0,0,0,0,0,0,0
+1753,0,0,0,0,0,0,0,0,0,0,0,0,0
+1754,0,0,0,0,0,0,0,0,0,0,0,0,0
+1755,0,0,0,0,0,0,0,0,0,0,0,0,0
+1756,0,0,0,0,0,0,0,0,0,0,0,0,0
+1757,0,0,0,0,0,0,0,0,0,0,0,0,0
+1758,0,0,0,0,0,0,0,0,0,0,0,0,0
+1759,0,0,0,0,0,0,0,0,0,0,0,0,0
+1760,0,0,0,0,0,0,0,0,0,0,0,0,0
+1761,0,0,0,0,0,0,0,0,0,0,0,0,0
+1762,0,0,0,0,0,0,0,0,0,0,0,0,0
+1763,0,0,0,0,0,0,0,0,0,0,0,0,0
+1764,0,0,0,0,0,0,0,0,0,0,0,0,0
+1765,0,0,0,0,0,0,0,0,0,0,0,0,0
+1766,0,0,0,0,0,0,0,0,0,0,0,0,0
+1767,0,0,0,0,0,0,0,0,0,0,0,0,0
+1768,0,0,0,0,0,0,0,0,0,0,0,0,0
+1769,0,0,0,0,0,0,0,0,0,0,0,0,0
+1770,0,0,0,0,0,0,0,0,0,0,0,0,0
+1771,0,0,0,0,0,0,0,0,0,0,0,0,0
+1772,0,0,0,0,0,0,0,0,0,0,0,0,0
+1773,0,0,0,0,0,0,0,0,0,0,0,0,0
+1774,0,0,0,0,0,0,0,0,0,0,0,0,0
+1775,0,0,0,0,0,0,0,0,0,0,0,0,0
+1776,0,0,0,0,0,0,0,0,0,0,0,0,0
+1777,0,0,0,0,0,0,0,0,0,0,0,0,0
+1778,0,0,0,0,0,0,0,0,0,0,0,0,0
+1779,0,0,0,0,0,0,0,0,0,0,0,0,0
+1780,0,0,0,0,0,0,0,0,0,0,0,0,0
+1781,0,0,0,0,0,0,0,0,0,0,0,0,0
+1782,0,0,0,0,0,0,0,0,0,0,0,0,0
+1783,0,0,0,0,0,0,0,0,0,0,0,0,0
+1784,0,0,0,0,0,0,0,0,0,0,0,0,0
+1785,0,0,0,0,0,0,0,0,0,0,0,0,0
+1786,0,0,0,0,0,0,0,0,0,0,0,0,0
+1787,0,0,0,0,0,0,0,0,0,0,0,0,0
+1788,0,0,0,0,0,0,0,0,0,0,0,0,0
+1789,0,0,0,0,0,0,0,0,0,0,0,0,0
+1790,0,0,0,0,0,0,0,0,0,0,0,0,0
+1791,0,0,0,0,0,0,0,0,0,0,0,0,0
+1792,0,0,0,0,0,0,0,0,0,0,0,0,0
+1793,0,0,0,0,0,0,0,0,0,0,0,0,0
+1794,0,0,0,0,0,0,0,0,0,0,0,0,0
+1795,0,0,0,0,0,0,0,0,0,0,0,0,0
+1796,0,0,0,0,0,0,0,0,0,0,0,0,0
+1797,0,0,0,0,0,0,0,0,0,0,0,0,0
+1798,0,0,0,0,0,0,0,0,0,0,0,0,0
+1799,0,0,0,0,0,0,0,0,0,0,0,0,0
+1800,0,0,0,0,0,0,0,0,0,0,0,0,0
+1801,0,0,0,0,0,0,0,0,0,0,0,0,0
+1802,0,0,0,0,0,0,0,0,0,0,0,0,0
+1803,0,0,0,0,0,0,0,0,0,0,0,0,0
+1804,0,0,0,0,0,0,0,0,0,0,0,0,0
+1805,0,0,0,0,0,0,0,0,0,0,0,0,0
+1806,0,0,0,0,0,0,0,0,0,0,0,0,0
+1807,0,0,0,0,0,0,0,0,0,0,0,0,0
+1808,0,0,0,0,0,0,0,0,0,0,0,0,0
+1809,0,0,0,0,0,0,0,0,0,0,0,0,0
+1810,0,0,0,0,0,0,0,0,0,0,0,0,0
+1811,0,0,0,0,0,0,0,0,0,0,0,0,0
+1812,0,0,0,0,0,0,0,0,0,0,0,0,0
+1813,0,0,0,0,0,0,0,0,0,0,0,0,0
+1814,0,0,0,0,0,0,0,0,0,0,0,0,0
+1815,0,0,0,0,0,0,0,0,0,0,0,0,0
+1816,0,0,0,0,0,0,0,0,0,0,0,0,0
+1817,0,0,0,0,0,0,0,0,0,0,0,0,0
+1818,0,0,0,0,0,0,0,0,0,0,0,0,0
+1819,0,0,0,0,0,0,0,0,0,0,0,0,0
+1820,0,0,0,0,0,0,0,0,0,0,0,0,0
+1821,0,0,0,0,0,0,0,0,0,0,0,0,0
+1822,0,0,0,0,0,0,0,0,0,0,0,0,0
+1823,0,0,0,0,0,0,0,0,0,0,0,0,0
+1824,0,0,0,0,0,0,0,0,0,0,0,0,0
+1825,0,0,0,0,0,0,0,0,0,0,0,0,0
+1826,0,0,0,0,0,0,0,0,0,0,0,0,0
+1827,0,0,0,0,0,0,0,0,0,0,0,0,0
+1828,0,0,0,0,0,0,0,0,0,0,0,0,0
+1829,0,0,0,0,0,0,0,0,0,0,0,0,0
+1830,0,0,0,0,0,0,0,0,0,0,0,0,0
+1831,0,0,0,0,0,0,0,0,0,0,0,0,0
+1832,0,0,0,0,0,0,0,0,0,0,0,0,0
+1833,0,0,0,0,0,0,0,0,0,0,0,0,0
+1834,0,0,0,0,0,0,0,0,0,0,0,0,0
+1835,0,0,0,0,0,0,0,0,0,0,0,0,0
+1836,0,0,0,0,0,0,0,0,0,0,0,0,0
+1837,0,0,0,0,0,0,0,0,0,0,0,0,0
+1838,0,0,0,0,0,0,0,0,0,0,0,0,0
+1839,0,0,0,0,0,0,0,0,0,0,0,0,0
+1840,0,0,0,0,0,0,0,0,0,0,0,0,0
+1841,0,0,0,0,0,0,0,0,0,0,0,0,0
+1842,0,0,0,0,0,0,0,0,0,0,0,0,0
+1843,0,0,0,0,0,0,0,0,0,0,0,0,0
+1844,0,0,0,0,0,0,0,0,0,0,0,0,0
+1845,0,0,0,0,0,0,0,0,0,0,0,0,0
+1846,0,0,0,0,0,0,0,0,0,0,0,0,0
+1847,0,0,0,0,0,0,0,0,0,0,0,0,0
+1848,0,0,0,0,0,0,0,0,0,0,0,0,0
+1849,0,0,0,0,0,0,0,0,0,0,0,0,0
+1850,0,0,0,0,0,0,0,0,0,0,0,0,0
+1851,0,0,0,0,0,0,0,0,0,0,0,0,0
+1852,0,0,0,0,0,0,0,0,0,0,0,0,0
+1853,0,0,0,0,0,0,0,0,0,0,0,0,0
+1854,0,0,0,0,0,0,0,0,0,0,0,0,0
+1855,0,0,0,0,0,0,0,0,0,0,0,0,0
+1856,0,0,0,0,0,0,0,0,0,0,0,0,0
+1857,0,0,0,0,0,0,0,0,0,0,0,0,0
+1858,0,0,0,0,0,0,0,0,0,0,0,0,0
+1859,0,0,0,0,0,0,0,0,0,0,0,0,0
+1860,0,0,0,0,0,0,0,0,0,0,0,0,0
+1861,0,0,0,0,0,0,0,0,0,0,0,0,0
+1862,0,0,0,0,0,0,0,0,0,0,0,0,0
+1863,0,0,0,0,0,0,0,0,0,0,0,0,0
+1864,0,0,0,0,0,0,0,0,0,0,0,0,0
+1865,0,0,0,0,0,0,0,0,0,0,0,0,0
+1866,0,0,0,0,0,0,0,0,0,0,0,0,0
+1867,0,0,0,0,0,0,0,0,0,0,0,0,0
+1868,0,0,0,0,0,0,0,0,0,0,0,0,0
+1869,0,0,0,0,0,0,0,0,0,0,0,0,0
+1870,0,0,0,0,0,0,0,0,0,0,0,0,0
+1871,0,0,0,0,0,0,0,0,0,0,0,0,0
+1872,0,0,0,0,0,0,0,0,0,0,0,0,0
+1873,0,0,0,0,0,0,0,0,0,0,0,0,0
+1874,0,0,0,0,0,0,0,0,0,0,0,0,0
+1875,0,0,0,0,0,0,0,0,0,0,0,0,0
+1876,0,0,0,0,0,0,0,0,0,0,0,0,0
+1877,0,0,0,0,0,0,0,0,0,0,0,0,0
+1878,0,0,0,0,0,0,0,0,0,0,0,0,0
+1879,0,0,0,0,0,0,0,0,0,0,0,0,0
+1880,0,0,0,0,0,0,0,0,0,0,0,0,0
+1881,0,0,0,0,0,0,0,0,0,0,0,0,0
+1882,0,0,0,0,0,0,0,0,0,0,0,0,0
+1883,0,0,0,0,0,0,0,0,0,0,0,0,0
+1884,0,0,0,0,0,0,0,0,0,0,0,0,0
+1885,0,0,0,0,0,0,0,0,0,0,0,0,0
+1886,0,0,0,0,0,0,0,0,0,0,0,0,0
+1887,0,0,0,0,0,0,0,0,0,0,0,0,0
+1888,0,0,0,0,0,0,0,0,0,0,0,0,0
+1889,0,0,0,0,0,0,0,0,0,0,0,0,0
+1890,0,0,0,0,0,0,0,0,0,0,0,0,0
+1891,0,0,0,0,0,0,0,0,0,0,0,0,0
+1892,0,0,0,0,0,0,0,0,0,0,0,0,0
+1893,0,0,0,0,0,0,0,0,0,0,0,0,0
+1894,0,0,0,0,0,0,0,0,0,0,0,0,0
+1895,0,0,0,0,0,0,0,0,0,0,0,0,0
+1896,0,0,0,0,0,0,0,0,0,0,0,0,0
+1897,0,0,0,0,0,0,0,0,0,0,0,0,0
+1898,0,0,0,0,0,0,0,0,0,0,0,0,0
+1899,0,0,0,0,0,0,0,0,0,0,0,0,0
+1900,0,0,0,0,0,0,0,0,0,0,0,0,0
+1901,0,0,0,0,0,0,0,0,0,0,0,0,0
+1902,0,0,0,0,0,0,0,0,0,0,0,0,0
+1903,0,0,0,0,0,0,0,0,0,0,0,0,0
+1904,0,0,0,0,0,0,0,0,0,0,0,0,0
+1905,0,0,0,0,0,0,0,0,0,0,0,0,0
+1906,0,0,0,0,0,0,0,0,0,0,0,0,0
+1907,0,0,0,0,0,0,0,0,0,0,0,0,0
+1908,0,0,0,0,0,0,0,0,0,0,0,0,0
+1909,0,0,0,0,0,0,0,0,0,0,0,0,0
+1910,0,0,0,0,0,0,0,0,0,0,0,0,0
+1911,0,0,0,0,0,0,0,0,0,0,0,0,0
+1912,0,0,0,0,0,0,0,0,0,0,0,0,0
+1913,0,0,0,0,0,0,0,0,0,0,0,0,0
+1914,0,0,0,0,0,0,0,0,0,0,0,0,0
+1915,0,0,0,0,0,0,0,0,0,0,0,0,0
+1916,0,0,0,0,0,0,0,0,0,0,0,0,0
+1917,0,0,0,0,0,0,0,0,0,0,0,0,0
+1918,0,0,0,0,0,0,0,0,0,0,0,0,0
+1919,0,0,0,0,0,0,0,0,0,0,0,0,0
+1920,0,0,0,0,0,0,0,0,0,0,0,0,0
+1921,0,0,0,0,0,0,0,0,0,0,0,0,0
+1922,0,0,0,0,0,0,0,0,0,0,0,0,0
+1923,0,0,0,0,0,0,0,0,0,0,0,0,0
+1924,0,0,0,0,0,0,0,0,0,0,0,0,0
+1925,0,0,0,0,0,0,0,0,0,0,0,0,0
+1926,0,0,0,0,0,0,0,0,0,0,0,0,0
+1927,0,0,0,0,0,0,0,0,0,0,0,0,0
+1928,0,0,0,0,0,0,0,0,0,0,0,0,0
+1929,0,0,0,0,0,0,0,0,0,0,0,0,0
+1930,0,0,0,0,0,0,0,0,0,0,0,0,0
+1931,0,0,0,0,0,0,0,0,0,0,0,0,0
+1932,0,0,0,0,0,0,0,0,0,0,0,0,0
+1933,0,0,0,0,0,0,0,0,0,0,0,0,0
+1934,0,0,0,0,0,0,0,0,0,0,0,0,0
+1935,0,0,0,0,0,0,0,0,0,0,0,0,0
+1936,0,0,0,0,0,0,0,0,0,0,0,0,0
+1937,0,0,0,0,0,0,0,0,0,0,0,0,0
+1938,0,0,0,0,0,0,0,0,0,0,0,0,0
+1939,0,0,0,0,0,0,0,0,0,0,0,0,0
+1940,0,0,0,0,0,0,0,0,0,0,0,0,0
+1941,0,0,0,0,0,0,0,0,0,0,0,0,0
+1942,0,0,0,0,0,0,0,0,0,0,0,0,0
+1943,0,0,0,0,0,0,0,0,0,0,0,0,0
+1944,0,0,0,0,0,0,0,0,0,0,0,0,0
+1945,0,0,0,0,0,0,0,0,0,0,0,0,0
+1946,0,0,0,0,0,0,0,0,0,0,0,0,0
+1947,0,0,0,0,0,0,0,0,0,0,0,0,0
+1948,0,0,0,0,0,0,0,0,0,0,0,0,0
+1949,0,0,0,0,0,0,0,0,0,0,0,0,0
+1950,0,0,0,0,0,0,0,0,0,0,0,0,0
+1951,0,0,0,0,0,0,0,0,0,0,0,0,0
+1952,0,0,0,0,0,0,0,0,0,0,0,0,0
+1953,0,0,0,0,0,0,0,0,0,0,0,0,0
+1954,0,0,0,0,0,0,0,0,0,0,0,0,0
+1955,0,0,0,0,0,0,0,0,0,0,0,0,0
+1956,0,0,0,0,0,0,0,0,0,0,0,0,0
+1957,0,0,0,0,0,0,0,0,0,0,0,0,0
+1958,0,0,0,0,0,0,0,0,0,0,0,0,0
+1959,0,0,0,0,0,0,0,0,0,0,0,0,0
+1960,0,0,0,0,0,0,0,0,0,0,0,0,0
+1961,0,0,0,0,0,0,0,0,0,0,0,0,0
+1962,0,0,0,0,0,0,0,0,0,0,0,0,0
+1963,0,0,0,0,0,0,0,0,0,0,0,0,0
+1964,0,0,0,0,0,0,0,0,0,0,0,0,0
+1965,0,0,0,0,0,0,0,0,0,0,0,0,0
+1966,0,0,0,0,0,0,0,0,0,0,0,0,0
+1967,0,0,0,0,0,0,0,0,0,0,0,0,0
+1968,0,0,0,0,0,0,0,0,0,0,0,0,0
+1969,0,0,0,0,0,0,0,0,0,0,0,0,0
+1970,0,0,0,0,0,0,0,0,0,0,0,0,0
+1971,0,0,0,0,0,0,0,0,0,0,0,0,0
+1972,0,0,0,0,0,0,0,0,0,0,0,0,0
+1973,0,0,0,0,0,0,0,0,0,0,0,0,0
+1974,0,0,0,0,0,0,0,0,0,0,0,0,0
+1975,0,0,0,0,0,0,0,0,0,0,0,0,0
+1976,0,0,0,0,0,0,0,0,0,0,0,0,0
+1977,0,0,0,0,0,0,0,0,0,0,0,0,0
+1978,0,0,0,0,0,0,0,0,0,0,0,0,0
+1979,0,0,0,0,0,0,0,0,0,0,0,0,0
+1980,0,0,0,0,0,0,0,0,0,0,0,0,0
+1981,0,0,0,0,0,0,0,0,0,0,0,0,0
+1982,0,0,0,0,0,0,0,0,0,0,0,0,0
+1983,0,0,0,0,0,0,0,0,0,0,0,0,0
+1984,0,0,0,0,0,0,0,0,0,0,0,0,0
+1985,0,0,0,0,0,0,0,0,0,0,0,0,0
+1986,0,0,0,0,0,0,0,0,0,0,0,0,0
+1987,0,0,0,0,0,0,0,0,0,0,0,0,0
+1988,0,0,0,0,0,0,0,0,0,0,0,0,0
+1989,0,0,0,0,0,0,0,0,0,0,0,0,0
+1990,0,0,0,0,0,0,0,0,0,0,0,0,0
+1991,0,0,0,0,0,0,0,0,0,0,0,0,0
+1992,0,0,0,0,0,0,0,0,0,0,0,0,0
+1993,0,0,0,0,0,0,0,0,0,0,0,0,0
+1994,0,0,0,0,0,0,0,0,0,0,0,0,0
+1995,0,0,0,0,0,0,0,0,0,0,0,0,0
+1996,0,0,0,0,0,0,0,0,0,0,0,0,0
+1997,0,0,0,0,0,0,0,0,0,0,0,0,0
+1998,0,0,0,0,0,0,0,0,0,0,0,0,0
+1999,0,0,0,0,0,0,0,0,0,0,0,0,0
+2000,0,0,0,0,0,0,0,0,0,0,0,0,0
+2001,0,0,0,0,0,0,0,0,0,0,0,0,0
+2002,0,0,0,0,0,0,0,0,0,0,0,0,0
+2003,0,0,0,0,0,0,0,0,0,0,0,0,0
+2004,0,0,0,0,0,0,0,0,0,0,0,0,0
+2005,0,0,0,0,0,0,0,0,0,0,0,0,0
+2006,0,0,0,0,0,0,0,0,0,0,0,0,0
+2007,0,0,0,0,0,0,0,0,0,0,0,0,0
+2008,0,0,0,0,0,0,0,0,0,0,0,0,0
+2009,0,0,0,0,0,0,0,0,0,0,0,0,0
+2010,0,0,0,0,0,0,0,0,0,0,0,0,0
+2011,0,0,0,0,0,0,0,0,0,0,0,0,0
+2012,0,0,0,0,0,0,0,0,0,0,0,0,0
+2013,0,0,0,0,0,0,0,0,0,0,0,0,0
+2014,0,0,0,0,0,0,0,0,0,0,0,0,0
+2015,0,0,0,0,0,0,0,0,0,0,0,0,0
+2016,0,0,0,0,0,0,0,0,0,0,0,0,0
+2017,0,0,0,0,0,0,0,0,0,0,0,0,0
+2018,0,0,0,0,0,0,0,0,0,0,0,0,0
+2019,0,0,0,0,0,0,0,0,0,0,0,0,0
+2020,0,0,0,0,0,0,0,0,0,0,0,0,0
+2021,0,0,0,0,0,0,0,0,0,0,0,0,0
+2022,0,0,0,0,0,0,0,0,0,0,0,0,0
+2023,0,0,0,0,0,0,0,0,0,0,0,0,0
+2024,0,0,0,0,0,0,0,0,0,0,0,0,0
+2025,0,0,0,0,0,0,0,0,0,0,0,0,0
+2026,0,0,0,0,0,0,0,0,0,0,0,0,0
+2027,0,0,0,0,0,0,0,0,0,0,0,0,0
+2028,0,0,0,0,0,0,0,0,0,0,0,0,0
+2029,0,0,0,0,0,0,0,0,0,0,0,0,0
+2030,0,0,0,0,0,0,0,0,0,0,0,0,0
+2031,0,0,0,0,0,0,0,0,0,0,0,0,0
+2032,0,0,0,0,0,0,0,0,0,0,0,0,0
+2033,0,0,0,0,0,0,0,0,0,0,0,0,0
+2034,0,0,0,0,0,0,0,0,0,0,0,0,0
+2035,0,0,0,0,0,0,0,0,0,0,0,0,0
+2036,0,0,0,0,0,0,0,0,0,0,0,0,0
+2037,0,0,0,0,0,0,0,0,0,0,0,0,0
+2038,0,0,0,0,0,0,0,0,0,0,0,0,0
+2039,0,0,0,0,0,0,0,0,0,0,0,0,0
+2040,0,0,0,0,0,0,0,0,0,0,0,0,0
+2041,0,0,0,0,0,0,0,0,0,0,0,0,0
+2042,0,0,0,0,0,0,0,0,0,0,0,0,0
+2043,0,0,0,0,0,0,0,0,0,0,0,0,0
+2044,0,0,0,0,0,0,0,0,0,0,0,0,0
+2045,0,0,0,0,0,0,0,0,0,0,0,0,0
+2046,0,0,0,0,0,0,0,0,0,0,0,0,0
+2047,0,0,0,0,0,0,0,0,0,0,0,0,0
+2048,0,0,0,0,0,0,0,0,0,0,0,0,0
+2049,0,0,0,0,0,0,0,0,0,0,0,0,0
+2050,0,0,0,0,0,0,0,0,0,0,0,0,0
+2051,0,0,0,0,0,0,0,0,0,0,0,0,0
+2052,0,0,0,0,0,0,0,0,0,0,0,0,0
+2053,0,0,0,0,0,0,0,0,0,0,0,0,0
+2054,0,0,0,0,0,0,0,0,0,0,0,0,0
+2055,0,0,0,0,0,0,0,0,0,0,0,0,0
+2056,0,0,0,0,0,0,0,0,0,0,0,0,0
+2057,0,0,0,0,0,0,0,0,0,0,0,0,0
+2058,0,0,0,0,0,0,0,0,0,0,0,0,0
+2059,0,0,0,0,0,0,0,0,0,0,0,0,0
+2060,0,0,0,0,0,0,0,0,0,0,0,0,0
+2061,0,0,0,0,0,0,0,0,0,0,0,0,0
+2062,0,0,0,0,0,0,0,0,0,0,0,0,0
+2063,0,0,0,0,0,0,0,0,0,0,0,0,0
+2064,0,0,0,0,0,0,0,0,0,0,0,0,0
+2065,0,0,0,0,0,0,0,0,0,0,0,0,0.000227567
+2066,0,0,0,0,0,0,0,0,0,0,0,0,0.000739283
+2067,0,0,0,0,0,0,0,0,0,0,0,0,0.001656775
+2068,0,0,0,0,0,0,0,0,0,0,0,0,0.003019587
+2069,0,0,0,0,0,0,0,0,0,0,0,0,0.004589377
+2070,0,0,0,0,0,0,0,0,0,0,0,0,0.005924935
+2071,0,0,0,0,0,0,0,0,0,0,0,0,0.007534774
+2072,0,0,0,0,0,0,0,0,0,0,0,0,0.008748008
+2073,0,0,0,0,0,0,0,0,0,0,0,0,0.010265481
+2074,0,0,0,0,0,0,0,0,0,0,0,0,0.012236179
+2075,0,0,0,0,0,0,0,0,0,0,0,0,0.014593479
+2076,0,0,0,0,0,0,0,0,0,0,0,0,0.017458937
+2077,0,0,0,0,0,0,0,0,0,0,0,0,0.021063245
+2078,0,0,0,0,0,0,0,0,0,0,0,0,0.025428056
+2079,0,0,0,0,0,0,0,0,0,0,0,0,0.03060944
+2080,0,0,0,0,0,0,0,0,0,0,0,0,0.037234457
+2081,0,0,0,0,0,0,0,0,0,0,0,0,0.045771325
+2082,0,0,0,0,0,0,0,0,0,0,0,0,0.056362502
+2083,0,0,0,0,0,0,0,0,0,0,0,0,0.070016996
+2084,0,0,0,0,0,0,0,0,0,0,0,0,0.088004988
+2085,0,0,0,0,0,0,0,0,0,0,0,0,0.110694417
+2086,0,0,0,0,0,0,0,0,0,0,0,0,0.138884174
+2087,0,0,0,0,0,0,0,0,0,0,0,0,0.173287791
+2088,0,0,0,0,0,0,0,0,0,0,0,0,0.214374591
+2089,0,0,0,0,0,0,0,0,0,0,0,0,0.261990789
+2090,0,0,0,0,0,0,0,0,0,0,0,0,0.317227795
+2091,0,0,0,0,0,0,0,0,0,0,0,0,0.380865706
+2092,0,0,0,0,0,0,0,0,0,0,0,0,0.449470316
+2093,0,0,0,0,0,0,0,0,0,0,0,0,0.522785467
+2094,0,0,0,0,0,0,0,0,0,0,0,0,0.598898522
+2095,0,0,0,0,0,0,0,0,0,0,0,0,0.672128213
+2096,0,0,0,0,0,0,0,0,0,0,0,0,0.737899139
+2097,0,0,0,0,0,0,0,0,0,0,0,0,0.792930708
+2098,0,0,0,0,0,0,0,0,0,0,0,0,0.835658783
+2099,0,0,0,0,0,0,0,0,0,0,0,0,0.866335142
+2100,0,0,0,0,0,0,0,0,0,0,0,0,0.886329697
+2101,0,0,0,0,0,0,0,0,0,0,0,0,0.897588245
+2102,0,0,0,0,0,0,0,0,0,0,0,0,0.901517855
+2103,0,0,0,0,0,0,0,0,0,0,0,0,0.900790721
+2104,0,0,0,0,0,0,0,0,0,0,0,0,0.897113531
+2105,0,0,0,0,0,0,0,0,0,0,0,0,0.892352598
+2106,0,0,0,0,0,0,0,0,0,0,0,0,0.88796428
+2107,0,0,0,0,0,0,0,0,0,0,0,0,0.884432193
+2108,0,0,0,0,0,0,0,0,0,0,0,0,0.882095059
+2109,0,0,0,0,0,0,0,0,0,0,0,0,0.881695748
+2110,0,0,0,0,0,0,0,0,0,0,0,0,0.88269782
+2111,0,0,0,0,0,0,0,0,0,0,0,0,0.887154405
+2112,0,0,0,0,0,0,0,0,0,0,0,0,0.892732955
+2113,0,0,0,0,0,0,0,0,0,0,0,0,0.898903582
+2114,0,0,0,0,0,0,0,0,0,0,0,0,0.905619271
+2115,0,0,0,0,0,0,0,0,0,0,0,0,0.912841006
+2116,0,0,0,0,0,0,0,0,0,0,0,0,0.920179789
+2117,0,0,0,0,0,0,0,0,0,0,0,0,0.926912882
+2118,0,0,0,0,0,0,0,0,0,0,0,0,0.933094888
+2119,0,0,0,0,0,0,0,0,0,0,0,0,0.938438355
+2120,0,0,0,0,0,0,0,0,0,0,0,0,0.943377038
+2121,0,0,0,0,0,0,0,0,0,0,0,0,0.945579227
+2122,0,0,0,0,0,0,0,0,0,0,0,0,0.947407512
+2123,0,0,0,0,0,0,0,0,0,0,0,0,0.948568289
+2124,0,0,0,0,0,0,0,0,0,0,0,0,0.94882972
+2125,0,0,0,0,0,0,0,0,0,0,0,0,0.948111791
+2126,0,0,0,0,0,0,0,0,0,0,0,0,0.947115734
+2127,0,0,0,0,0,0,0,0,0,0,0,0,0.946126982
+2128,0,0,0,0,0,0,0,0,0,0,0,0,0.944870644
+2129,0,0,0,0,0,0,0,0,0,0,0,0,0.943485039
+2130,0,0,0,0,0,0,0,0,0,0,0,0,0.941894052
+2131,0,0,0,0,0,0,0,0,0,0,0,0,0.942445527
+2132,0,0,0,0,0,0,0,0,0,0,0,0,0.943274219
+2133,0,0,0,0,0,0,0,0,0,0,0,0,0.944243794
+2134,0,0,0,0,0,0,0,0,0,0,0,0,0.94528606
+2135,0,0,0,0,0,0,0,0,0,0,0,0,0.946212496
+2136,0,0,0,0,0,0,0,0,0,0,0,0,0.947084905
+2137,0,0,0,0,0,0,0,0,0,0,0,0,0.947941677
+2138,0,0,0,0,0,0,0,0,0,0,0,0,0.948940117
+2139,0,0,0,0,0,0,0,0,0,0,0,0,0.949880321
+2140,0,0,0,0,0,0,0,0,0,0,0,0,0.950676414
+2141,0,0,0,0,0,0,0,0,0,0,0,0,0.951054332
+2142,0,0,0,0,0,0,0,0,0,0,0,0,0.951531833
+2143,0,0,0,0,0,0,0,0,0,0,0,0,0.952326952
+2144,0,0,0,0,0,0,0,0,0,0,0,0,0.952721089
+2145,0,0,0,0,0,0,0,0,0,0,0,0,0.952552047
+2146,0,0,0,0,0,0,0,0,0,0,0,0,0.952417855
+2147,0,0,0,0,0,0,0,0,0,0,0,0,0.952654092
+2148,0,0,0,0,0,0,0,0,0,0,0,0,0.95296197
+2149,0,0,0,0,0,0,0,0,0,0,0,0,0.95331832
+2150,0,0,0,0,0,0,0,0,0,0,0,0,0.953779111
+2151,0,0,0,0,0,0,0,0,0,0,0,0,0.954291677
+2152,0,0,0,0,0,0,0,0,0,0,0,0,0.954837035
+2153,0,0,0,0,0,0,0,0,0,0,0,0,0.955539257
+2154,0,0,0,0,0,0,0,0,0,0,0,0,0.956750259
+2155,0,0,0,0,0,0,0,0,0,0,0,0,0.957986198
+2156,0,0,0,0,0,0,0,0,0,0,0,0,0.959237259
+2157,0,0,0,0,0,0,0,0,0,0,0,0,0.960451396
+2158,0,0,0,0,0,0,0,0,0,0,0,0,0.96141302
+2159,0,0,0,0,0,0,0,0,0,0,0,0,0.96264388
+2160,0,0,0,0,0,0,0,0,0,0,0,0,0.964122014
+2161,0,0,0,0,0,0,0,0,0,0,0,0,0.963609737
+2162,0,0,0,0,0,0,0,0,0,0,0,0,0.963104517
+2163,0,0,0,0,0,0,0,0,0,0,0,0,0.962753979
+2164,0,0,0,0,0,0,0,0,0,0,0,0,0.961850624
+2165,0,0,0,0,0,0,0,0,0,0,0,0,0.960730243
+2166,0,0,0,0,0,0,0,0,0,0,0,0,0.959560745
+2167,0,0,0,0,0,0,0,0,0,0,0,0,0.958377188
+2168,0,0,0,0,0,0,0,0,0,0,0,0,0.956972347
+2169,0,0,0,0,0,0,0,0,0,0,0,0,0.955119849
+2170,0,0,0,0,0,0,0,0,0,0,0,0,0.953076144
+2171,0,0,0,0,0,0,0,0,0,0,0,0,0.95406055
+2172,0,0,0,0,0,0,0,0,0,0,0,0,0.955176712
+2173,0,0,0,0,0,0,0,0,0,0,0,0,0.955719159
+2174,0,0,0,0,0,0,0,0,0,0,0,0,0.955674616
+2175,0,0,0,0,0,0,0,0,0,0,0,0,0.955356546
+2176,0,0,0,0,0,0,0,0,0,0,0,0,0.954611539
+2177,0,0,0,0,0,0,0,0,0,0,0,0,0.953453566
+2178,0,0,0,0,0,0,0,0,0,0,0,0,0.952124922
+2179,0,0,0,0,0,0,0,0,0,0,0,0,0.950597985
+2180,0,0,0,0,0,0,0,0,0,0,0,0,0.948594073
+2181,0,0,0,0,0,0,0,0,0,0,0,0,0.948562399
+2182,0,0,0,0,0,0,0,0,0,0,0,0,0.948548442
+2183,0,0,0,0,0,0,0,0,0,0,0,0,0.94829598
+2184,0,0,0,0,0,0,0,0,0,0,0,0,0.947706109
+2185,0,0,0,0,0,0,0,0,0,0,0,0,0.946620434
+2186,0,0,0,0,0,0,0,0,0,0,0,0,0.94521576
+2187,0,0,0,0,0,0,0,0,0,0,0,0,0.943480979
+2188,0,0,0,0,0,0,0,0,0,0,0,0,0.942137936
+2189,0,0,0,0,0,0,0,0,0,0,0,0,0.940654943
+2190,0,0,0,0,0,0,0,0,0,0,0,0,0.938918576
+2191,0,0,0,0,0,0,0,0,0,0,0,0,0.941493007
+2192,0,0,0,0,0,0,0,0,0,0,0,0,0.943778866
+2193,0,0,0,0,0,0,0,0,0,0,0,0,0.945751584
+2194,0,0,0,0,0,0,0,0,0,0,0,0,0.947277308
+2195,0,0,0,0,0,0,0,0,0,0,0,0,0.948481875
+2196,0,0,0,0,0,0,0,0,0,0,0,0,0.949621704
+2197,0,0,0,0,0,0,0,0,0,0,0,0,0.950767479
+2198,0,0,0,0,0,0,0,0,0,0,0,0,0.951991493
+2199,0,0,0,0,0,0,0,0,0,0,0,0,0.953624457
+2200,0,0,0,0,0,0,0,0,0,0,0,0,0.955262594
+2201,0,0,0,0,0,0,0,0,0,0,0,0,0.952413026
+2202,0,0,0,0,0,0,0,0,0,0,0,0,0.950488752
+2203,0,0,0,0,0,0,0,0,0,0,0,0,0.949721652
+2204,0,0,0,0,0,0,0,0,0,0,0,0,0.949105026
+2205,0,0,0,0,0,0,0,0,0,0,0,0,0.949712169
+2206,0,0,0,0,0,0,0,0,0,0,0,0,0.95167296
+2207,0,0,0,0,0,0,0,0,0,0,0,0,0.955012323
+2208,0,0,0,0,0,0,0,0,0,0,0,0,0.959777857
+2209,0,0,0,0,0,0,0,0,0,0,0,0,0.966208245
+2210,0,0,0,0,0,0,0,0,0,0,0,0,0.973886163
+2211,0,0,0,0,0,0,0,0,0,0,0,0,0.970920044
+2212,0,0,0,0,0,0,0,0,0,0,0,0,0.969139883
+2213,0,0,0,0,0,0,0,0,0,0,0,0,0.968329935
+2214,0,0,0,0,0,0,0,0,0,0,0,0,0.967635904
+2215,0,0,0,0,0,0,0,0,0,0,0,0,0.967555279
+2216,0,0,0,0,0,0,0,0,0,0,0,0,0.968040602
+2217,0,0,0,0,0,0,0,0,0,0,0,0,0.968508397
+2218,0,0,0,0,0,0,0,0,0,0,0,0,0.968956722
+2219,0,0,0,0,0,0,0,0,0,0,0,0,0.969510275
+2220,0,0,0,0,0,0,0,0,0,0,0,0,0.969967732
+2221,0,0,0,0,0,0,0,0,0,0,0,0,0.969097684
+2222,0,0,0,0,0,0,0,0,0,0,0,0,0.968258197
+2223,0,0,0,0,0,0,0,0,0,0,0,0,0.967549788
+2224,0,0,0,0,0,0,0,0,0,0,0,0,0.96650394
+2225,0,0,0,0,0,0,0,0,0,0,0,0,0.965459532
+2226,0,0,0,0,0,0,0,0,0,0,0,0,0.964366923
+2227,0,0,0,0,0,0,0,0,0,0,0,0,0.962929804
+2228,0,0,0,0,0,0,0,0,0,0,0,0,0.961665594
+2229,0,0,0,0,0,0,0,0,0,0,0,0,0.96063821
+2230,0,0,0,0,0,0,0,0,0,0,0,0,0.959368085
+2231,0,0,0,0,0,0,0,0,0,0,0,0,0.959707097
+2232,0,0,0,0,0,0,0,0,0,0,0,0,0.960359643
+2233,0,0,0,0,0,0,0,0,0,0,0,0,0.9616448
+2234,0,0,0,0,0,0,0,0,0,0,0,0,0.962729828
+2235,0,0,0,0,0,0,0,0,0,0,0,0,0.96370081
+2236,0,0,0,0,0,0,0,0,0,0,0,0,0.964773629
+2237,0,0,0,0,0,0,0,0,0,0,0,0,0.965512685
+2238,0,0,0,0,0,0,0,0,0,0,0,0,0.96634935
+2239,0,0,0,0,0,0,0,0,0,0,0,0,0.96753842
+2240,0,0,0,0,0,0,0,0,0,0,0,0,0.96886815
+2241,0,0,0,0,0,0,0,0,0,0,0,0,0.970549249
+2242,0,0,0,0,0,0,0,0,0,0,0,0,0.972426171
+2243,0,0,0,0,0,0,0,0,0,0,0,0,0.974301395
+2244,0,0,0,0,0,0,0,0,0,0,0,0,0.976012041
+2245,0,0,0,0,0,0,0,0,0,0,0,0,0.977203216
+2246,0,0,0,0,0,0,0,0,0,0,0,0,0.978986062
+2247,0,0,0,0,0,0,0,0,0,0,0,0,0.980446263
+2248,0,0,0,0,0,0,0,0,0,0,0,0,0.981524356
+2249,0,0,0,0,0,0,0,0,0,0,0,0,0.982531672
+2250,0,0,0,0,0,0,0,0,0,0,0,0,0.983336508
+2251,0,0,0,0,0,0,0,0,0,0,0,0,0.98463147
+2252,0,0,0,0,0,0,0,0,0,0,0,0,0.986737985
+2253,0,0,0,0,0,0,0,0,0,0,0,0,0.989144288
+2254,0,0,0,0,0,0,0,0,0,0,0,0,0.991223348
+2255,0,0,0,0,0,0,0,0,0,0,0,0,0.99318448
+2256,0,0,0,0,0,0,0,0,0,0,0,0,0.995273324
+2257,0,0,0,0,0,0,0,0,0,0,0,0,0.996704667
+2258,0,0,0,0,0,0,0,0,0,0,0,0,0.998282418
+2259,0,0,0,0,0,0,0,0,0,0,0,0,0.999605161
+2260,0,0,0,0,0,0,0,0,0,0,0,0,1
+2261,0,0,0,0,0,0,0,0,0,0,0,0,0.998654554
+2262,0,0,0,0,0,0,0,0,0,0,0,0,0.995753158
+2263,0,0,0,0,0,0,0,0,0,0,0,0,0.990605371
+2264,0,0,0,0,0,0,0,0,0,0,0,0,0.981520886
+2265,0,0,0,0,0,0,0,0,0,0,0,0,0.968715091
+2266,0,0,0,0,0,0,0,0,0,0,0,0,0.951679125
+2267,0,0,0,0,0,0,0,0,0,0,0,0,0.929343556
+2268,0,0,0,0,0,0,0,0,0,0,0,0,0.902305299
+2269,0,0,0,0,0,0,0,0,0,0,0,0,0.87044084
+2270,0,0,0,0,0,0,0,0,0,0,0,0,0.831947776
+2271,0,0,0,0,0,0,0,0,0,0,0,0,0.786119345
+2272,0,0,0,0,0,0,0,0,0,0,0,0,0.736343248
+2273,0,0,0,0,0,0,0,0,0,0,0,0,0.681862245
+2274,0,0,0,0,0,0,0,0,0,0,0,0,0.623137717
+2275,0,0,0,0,0,0,0,0,0,0,0,0,0.564024643
+2276,0,0,0,0,0,0,0,0,0,0,0,0,0.506650261
+2277,0,0,0,0,0,0,0,0,0,0,0,0,0.451376118
+2278,0,0,0,0,0,0,0,0,0,0,0,0,0.400487569
+2279,0,0,0,0,0,0,0,0,0,0,0,0,0.354176773
+2280,0,0,0,0,0,0,0,0,0,0,0,0,0.309839746
+2281,0,0,0,0,0,0,0,0,0,0,0,0,0.269312679
+2282,0,0,0,0,0,0,0,0,0,0,0,0,0.234102225
+2283,0,0,0,0,0,0,0,0,0,0,0,0,0.20225298
+2284,0,0,0,0,0,0,0,0,0,0,0,0,0.173669677
+2285,0,0,0,0,0,0,0,0,0,0,0,0,0.149356419
+2286,0,0,0,0,0,0,0,0,0,0,0,0,0.128957364
+2287,0,0,0,0,0,0,0,0,0,0,0,0,0.111530972
+2288,0,0,0,0,0,0,0,0,0,0,0,0,0.09689948
+2289,0,0,0,0,0,0,0,0,0,0,0,0,0.084874763
+2290,0,0,0,0,0,0,0,0,0,0,0,0,0.074063524
+2291,0,0,0,0,0,0,0,0,0,0,0,0,0.064469344
+2292,0,0,0,0,0,0,0,0,0,0,0,0,0.056321561
+2293,0,0,0,0,0,0,0,0,0,0,0,0,0.049381236
+2294,0,0,0,0,0,0,0,0,0,0,0,0,0.043196026
+2295,0,0,0,0,0,0,0,0,0,0,0,0,0.037986086
+2296,0,0,0,0,0,0,0,0,0,0,0,0,0.033468826
+2297,0,0,0,0,0,0,0,0,0,0,0,0,0.028983375
+2298,0,0,0,0,0,0,0,0,0,0,0,0,0.025085752
+2299,0,0,0,0,0,0,0,0,0,0,0,0,0.020007676
+2300,0,0,0,0,0,0,0,0,0,0,0,0,0.013837921
+2301,0,0,0,0,0,0,0,0,0,0,0,0,0.008464001
+2302,0,0,0,0,0,0,0,0,0,0,0,0,0.004443102
+2303,0,0,0,0,0,0,0,0,0,0,0,0,0.000848571
+2304,0,0,0,0,0,0,0,0,0,0,0,0,0
+2305,0,0,0,0,0,0,0,0,0,0,0,0,0
+2306,0,0,0,0,0,0,0,0,0,0,0,0,0
+2307,0,0,0,0,0,0,0,0,0,0,0,0,0
+2308,0,0,0,0,0,0,0,0,0,0,0,0,0
+2309,0,0,0,0,0,0,0,0,0,0,0,0,0
+2310,0,0,0,0,0,0,0,0,0,0,0,0,0
+2311,0,0,0,0,0,0,0,0,0,0,0,0,0
+2312,0,0,0,0,0,0,0,0,0,0,0,0,0
+2313,0,0,0,0,0,0,0,0,0,0,0,0,0
+2314,0,0,0,0,0,0,0,0,0,0,0,0,0
+2315,0,0,0,0,0,0,0,0,0,0,0,0,0
+2316,0,0,0,0,0,0,0,0,0,0,0,0,0
+2317,0,0,0,0,0,0,0,0,0,0,0,0,0
+2318,0,0,0,0,0,0,0,0,0,0,0,0,0
+2319,0,0,0,0,0,0,0,0,0,0,0,0,0
+2320,0,0,0,0,0,0,0,0,0,0,0,0,0
+2321,0,0,0,0,0,0,0,0,0,0,0,0,0
+2322,0,0,0,0,0,0,0,0,0,0,0,0,0
+2323,0,0,0,0,0,0,0,0,0,0,0,0,0
+2324,0,0,0,0,0,0,0,0,0,0,0,0,0
+2325,0,0,0,0,0,0,0,0,0,0,0,0,0
+2326,0,0,0,0,0,0,0,0,0,0,0,0,0
+2327,0,0,0,0,0,0,0,0,0,0,0,0,0
+2328,0,0,0,0,0,0,0,0,0,0,0,0,0
+2329,0,0,0,0,0,0,0,0,0,0,0,0,0
+2330,0,0,0,0,0,0,0,0,0,0,0,0,0
+2331,0,0,0,0,0,0,0,0,0,0,0,0,0
+2332,0,0,0,0,0,0,0,0,0,0,0,0,0
+2333,0,0,0,0,0,0,0,0,0,0,0,0,0
+2334,0,0,0,0,0,0,0,0,0,0,0,0,0
+2335,0,0,0,0,0,0,0,0,0,0,0,0,0
+2336,0,0,0,0,0,0,0,0,0,0,0,0,0
+2337,0,0,0,0,0,0,0,0,0,0,0,0,0
+2338,0,0,0,0,0,0,0,0,0,0,0,0,0
+2339,0,0,0,0,0,0,0,0,0,0,0,0,0
+2340,0,0,0,0,0,0,0,0,0,0,0,0,0
+2341,0,0,0,0,0,0,0,0,0,0,0,0,0
+2342,0,0,0,0,0,0,0,0,0,0,0,0,0
+2343,0,0,0,0,0,0,0,0,0,0,0,0,0
+2344,0,0,0,0,0,0,0,0,0,0,0,0,0
+2345,0,0,0,0,0,0,0,0,0,0,0,0,0
+2346,0,0,0,0,0,0,0,0,0,0,0,0,0
+2347,0,0,0,0,0,0,0,0,0,0,0,0,0
+2348,0,0,0,0,0,0,0,0,0,0,0,0,0
+2349,0,0,0,0,0,0,0,0,0,0,0,0,0
+2350,0,0,0,0,0,0,0,0,0,0,0,0,0
+2351,0,0,0,0,0,0,0,0,0,0,0,0,0
+2352,0,0,0,0,0,0,0,0,0,0,0,0,0
+2353,0,0,0,0,0,0,0,0,0,0,0,0,0
+2354,0,0,0,0,0,0,0,0,0,0,0,0,0
+2355,0,0,0,0,0,0,0,0,0,0,0,0,0
+2356,0,0,0,0,0,0,0,0,0,0,0,0,0
+2357,0,0,0,0,0,0,0,0,0,0,0,0,0
+2358,0,0,0,0,0,0,0,0,0,0,0,0,0
+2359,0,0,0,0,0,0,0,0,0,0,0,0,0
+2360,0,0,0,0,0,0,0,0,0,0,0,0,0
+2361,0,0,0,0,0,0,0,0,0,0,0,0,0
+2362,0,0,0,0,0,0,0,0,0,0,0,0,0
+2363,0,0,0,0,0,0,0,0,0,0,0,0,0
+2364,0,0,0,0,0,0,0,0,0,0,0,0,0
+2365,0,0,0,0,0,0,0,0,0,0,0,0,0
+2366,0,0,0,0,0,0,0,0,0,0,0,0,0
+2367,0,0,0,0,0,0,0,0,0,0,0,0,0
+2368,0,0,0,0,0,0,0,0,0,0,0,0,0
+2369,0,0,0,0,0,0,0,0,0,0,0,0,0
+2370,0,0,0,0,0,0,0,0,0,0,0,0,0
+2371,0,0,0,0,0,0,0,0,0,0,0,0,0
+2372,0,0,0,0,0,0,0,0,0,0,0,0,0
+2373,0,0,0,0,0,0,0,0,0,0,0,0,0
+2374,0,0,0,0,0,0,0,0,0,0,0,0,0
+2375,0,0,0,0,0,0,0,0,0,0,0,0,0
+2376,0,0,0,0,0,0,0,0,0,0,0,0,0
+2377,0,0,0,0,0,0,0,0,0,0,0,0,0
+2378,0,0,0,0,0,0,0,0,0,0,0,0,0
+2379,0,0,0,0,0,0,0,0,0,0,0,0,0
+2380,0,0,0,0,0,0,0,0,0,0,0,0,0
+2381,0,0,0,0,0,0,0,0,0,0,0,0,0
+2382,0,0,0,0,0,0,0,0,0,0,0,0,0
+2383,0,0,0,0,0,0,0,0,0,0,0,0,0
+2384,0,0,0,0,0,0,0,0,0,0,0,0,0
+2385,0,0,0,0,0,0,0,0,0,0,0,0,0
+2386,0,0,0,0,0,0,0,0,0,0,0,0,0
+2387,0,0,0,0,0,0,0,0,0,0,0,0,0
+2388,0,0,0,0,0,0,0,0,0,0,0,0,0
+2389,0,0,0,0,0,0,0,0,0,0,0,0,0
+2390,0,0,0,0,0,0,0,0,0,0,0,0,0
+2391,0,0,0,0,0,0,0,0,0,0,0,0,0
+2392,0,0,0,0,0,0,0,0,0,0,0,0,0
+2393,0,0,0,0,0,0,0,0,0,0,0,0,0
+2394,0,0,0,0,0,0,0,0,0,0,0,0,0
+2395,0,0,0,0,0,0,0,0,0,0,0,0,0
+2396,0,0,0,0,0,0,0,0,0,0,0,0,0
+2397,0,0,0,0,0,0,0,0,0,0,0,0,0
+2398,0,0,0,0,0,0,0,0,0,0,0,0,0
+2399,0,0,0,0,0,0,0,0,0,0,0,0,0
+2400,0,0,0,0,0,0,0,0,0,0,0,0,0
+2401,0,0,0,0,0,0,0,0,0,0,0,0,0
+2402,0,0,0,0,0,0,0,0,0,0,0,0,0
+2403,0,0,0,0,0,0,0,0,0,0,0,0,0
+2404,0,0,0,0,0,0,0,0,0,0,0,0,0
+2405,0,0,0,0,0,0,0,0,0,0,0,0,0
+2406,0,0,0,0,0,0,0,0,0,0,0,0,0
+2407,0,0,0,0,0,0,0,0,0,0,0,0,0
+2408,0,0,0,0,0,0,0,0,0,0,0,0,0
+2409,0,0,0,0,0,0,0,0,0,0,0,0,0
+2410,0,0,0,0,0,0,0,0,0,0,0,0,0
+2411,0,0,0,0,0,0,0,0,0,0,0,0,0
+2412,0,0,0,0,0,0,0,0,0,0,0,0,0
+2413,0,0,0,0,0,0,0,0,0,0,0,0,0
+2414,0,0,0,0,0,0,0,0,0,0,0,0,0
+2415,0,0,0,0,0,0,0,0,0,0,0,0,0
+2416,0,0,0,0,0,0,0,0,0,0,0,0,0
+2417,0,0,0,0,0,0,0,0,0,0,0,0,0
+2418,0,0,0,0,0,0,0,0,0,0,0,0,0
+2419,0,0,0,0,0,0,0,0,0,0,0,0,0
+2420,0,0,0,0,0,0,0,0,0,0,0,0,0
+2421,0,0,0,0,0,0,0,0,0,0,0,0,0
+2422,0,0,0,0,0,0,0,0,0,0,0,0,0
+2423,0,0,0,0,0,0,0,0,0,0,0,0,0
+2424,0,0,0,0,0,0,0,0,0,0,0,0,0
+2425,0,0,0,0,0,0,0,0,0,0,0,0,0
+2426,0,0,0,0,0,0,0,0,0,0,0,0,0
+2427,0,0,0,0,0,0,0,0,0,0,0,0,0
+2428,0,0,0,0,0,0,0,0,0,0,0,0,0
+2429,0,0,0,0,0,0,0,0,0,0,0,0,0
+2430,0,0,0,0,0,0,0,0,0,0,0,0,0
+2431,0,0,0,0,0,0,0,0,0,0,0,0,0
+2432,0,0,0,0,0,0,0,0,0,0,0,0,0
+2433,0,0,0,0,0,0,0,0,0,0,0,0,0
+2434,0,0,0,0,0,0,0,0,0,0,0,0,0
+2435,0,0,0,0,0,0,0,0,0,0,0,0,0
+2436,0,0,0,0,0,0,0,0,0,0,0,0,0
+2437,0,0,0,0,0,0,0,0,0,0,0,0,0
+2438,0,0,0,0,0,0,0,0,0,0,0,0,0
+2439,0,0,0,0,0,0,0,0,0,0,0,0,0
+2440,0,0,0,0,0,0,0,0,0,0,0,0,0
+2441,0,0,0,0,0,0,0,0,0,0,0,0,0
+2442,0,0,0,0,0,0,0,0,0,0,0,0,0
+2443,0,0,0,0,0,0,0,0,0,0,0,0,0
+2444,0,0,0,0,0,0,0,0,0,0,0,0,0
+2445,0,0,0,0,0,0,0,0,0,0,0,0,0
+2446,0,0,0,0,0,0,0,0,0,0,0,0,0
+2447,0,0,0,0,0,0,0,0,0,0,0,0,0
+2448,0,0,0,0,0,0,0,0,0,0,0,0,0
+2449,0,0,0,0,0,0,0,0,0,0,0,0,0
+2450,0,0,0,0,0,0,0,0,0,0,0,0,0
+2451,0,0,0,0,0,0,0,0,0,0,0,0,0
+2452,0,0,0,0,0,0,0,0,0,0,0,0,0
+2453,0,0,0,0,0,0,0,0,0,0,0,0,0
+2454,0,0,0,0,0,0,0,0,0,0,0,0,0
+2455,0,0,0,0,0,0,0,0,0,0,0,0,0
+2456,0,0,0,0,0,0,0,0,0,0,0,0,0
+2457,0,0,0,0,0,0,0,0,0,0,0,0,0
+2458,0,0,0,0,0,0,0,0,0,0,0,0,0
+2459,0,0,0,0,0,0,0,0,0,0,0,0,0
+2460,0,0,0,0,0,0,0,0,0,0,0,0,0
+2461,0,0,0,0,0,0,0,0,0,0,0,0,0
+2462,0,0,0,0,0,0,0,0,0,0,0,0,0
+2463,0,0,0,0,0,0,0,0,0,0,0,0,0
+2464,0,0,0,0,0,0,0,0,0,0,0,0,0
+2465,0,0,0,0,0,0,0,0,0,0,0,0,0
+2466,0,0,0,0,0,0,0,0,0,0,0,0,0
+2467,0,0,0,0,0,0,0,0,0,0,0,0,0
+2468,0,0,0,0,0,0,0,0,0,0,0,0,0
+2469,0,0,0,0,0,0,0,0,0,0,0,0,0
+2470,0,0,0,0,0,0,0,0,0,0,0,0,0
+2471,0,0,0,0,0,0,0,0,0,0,0,0,0
+2472,0,0,0,0,0,0,0,0,0,0,0,0,0
+2473,0,0,0,0,0,0,0,0,0,0,0,0,0
+2474,0,0,0,0,0,0,0,0,0,0,0,0,0
+2475,0,0,0,0,0,0,0,0,0,0,0,0,0
+2476,0,0,0,0,0,0,0,0,0,0,0,0,0
+2477,0,0,0,0,0,0,0,0,0,0,0,0,0
+2478,0,0,0,0,0,0,0,0,0,0,0,0,0
+2479,0,0,0,0,0,0,0,0,0,0,0,0,0
+2480,0,0,0,0,0,0,0,0,0,0,0,0,0
+2481,0,0,0,0,0,0,0,0,0,0,0,0,0
+2482,0,0,0,0,0,0,0,0,0,0,0,0,0
+2483,0,0,0,0,0,0,0,0,0,0,0,0,0
+2484,0,0,0,0,0,0,0,0,0,0,0,0,0
+2485,0,0,0,0,0,0,0,0,0,0,0,0,0
+2486,0,0,0,0,0,0,0,0,0,0,0,0,0
+2487,0,0,0,0,0,0,0,0,0,0,0,0,0
+2488,0,0,0,0,0,0,0,0,0,0,0,0,0
+2489,0,0,0,0,0,0,0,0,0,0,0,0,0
+2490,0,0,0,0,0,0,0,0,0,0,0,0,0
+2491,0,0,0,0,0,0,0,0,0,0,0,0,0
+2492,0,0,0,0,0,0,0,0,0,0,0,0,0
+2493,0,0,0,0,0,0,0,0,0,0,0,0,0
+2494,0,0,0,0,0,0,0,0,0,0,0,0,0
+2495,0,0,0,0,0,0,0,0,0,0,0,0,0
+2496,0,0,0,0,0,0,0,0,0,0,0,0,0
+2497,0,0,0,0,0,0,0,0,0,0,0,0,0
+2498,0,0,0,0,0,0,0,0,0,0,0,0,0
+2499,0,0,0,0,0,0,0,0,0,0,0,0,0
+2500,0,0,0,0,0,0,0,0,0,0,0,0,0
+2501,0,0,0,0,0,0,0,0,0,0,0,0,0
+2502,0,0,0,0,0,0,0,0,0,0,0,0,0
+2503,0,0,0,0,0,0,0,0,0,0,0,0,0
+2504,0,0,0,0,0,0,0,0,0,0,0,0,0
+2505,0,0,0,0,0,0,0,0,0,0,0,0,0
+2506,0,0,0,0,0,0,0,0,0,0,0,0,0
+2507,0,0,0,0,0,0,0,0,0,0,0,0,0
+2508,0,0,0,0,0,0,0,0,0,0,0,0,0
+2509,0,0,0,0,0,0,0,0,0,0,0,0,0
+2510,0,0,0,0,0,0,0,0,0,0,0,0,0
+2511,0,0,0,0,0,0,0,0,0,0,0,0,0
+2512,0,0,0,0,0,0,0,0,0,0,0,0,0
+2513,0,0,0,0,0,0,0,0,0,0,0,0,0
+2514,0,0,0,0,0,0,0,0,0,0,0,0,0
+2515,0,0,0,0,0,0,0,0,0,0,0,0,0
+2516,0,0,0,0,0,0,0,0,0,0,0,0,0
+2517,0,0,0,0,0,0,0,0,0,0,0,0,0
+2518,0,0,0,0,0,0,0,0,0,0,0,0,0
+2519,0,0,0,0,0,0,0,0,0,0,0,0,0
+2520,0,0,0,0,0,0,0,0,0,0,0,0,0
+2521,0,0,0,0,0,0,0,0,0,0,0,0,0
+2522,0,0,0,0,0,0,0,0,0,0,0,0,0
+2523,0,0,0,0,0,0,0,0,0,0,0,0,0
+2524,0,0,0,0,0,0,0,0,0,0,0,0,0
+2525,0,0,0,0,0,0,0,0,0,0,0,0,0
+2526,0,0,0,0,0,0,0,0,0,0,0,0,0
+2527,0,0,0,0,0,0,0,0,0,0,0,0,0
+2528,0,0,0,0,0,0,0,0,0,0,0,0,0
+2529,0,0,0,0,0,0,0,0,0,0,0,0,0
+2530,0,0,0,0,0,0,0,0,0,0,0,0,0
+2531,0,0,0,0,0,0,0,0,0,0,0,0,0
+2532,0,0,0,0,0,0,0,0,0,0,0,0,0
+2533,0,0,0,0,0,0,0,0,0,0,0,0,0
+2534,0,0,0,0,0,0,0,0,0,0,0,0,0
+2535,0,0,0,0,0,0,0,0,0,0,0,0,0
+2536,0,0,0,0,0,0,0,0,0,0,0,0,0
+2537,0,0,0,0,0,0,0,0,0,0,0,0,0
+2538,0,0,0,0,0,0,0,0,0,0,0,0,0
+2539,0,0,0,0,0,0,0,0,0,0,0,0,0
+2540,0,0,0,0,0,0,0,0,0,0,0,0,0
+2541,0,0,0,0,0,0,0,0,0,0,0,0,0
+2542,0,0,0,0,0,0,0,0,0,0,0,0,0
+2543,0,0,0,0,0,0,0,0,0,0,0,0,0
+2544,0,0,0,0,0,0,0,0,0,0,0,0,0
+2545,0,0,0,0,0,0,0,0,0,0,0,0,0
+2546,0,0,0,0,0,0,0,0,0,0,0,0,0
+2547,0,0,0,0,0,0,0,0,0,0,0,0,0
+2548,0,0,0,0,0,0,0,0,0,0,0,0,0
+2549,0,0,0,0,0,0,0,0,0,0,0,0,0
+2550,0,0,0,0,0,0,0,0,0,0,0,0,0
+2551,0,0,0,0,0,0,0,0,0,0,0,0,0
+2552,0,0,0,0,0,0,0,0,0,0,0,0,0
+2553,0,0,0,0,0,0,0,0,0,0,0,0,0
+2554,0,0,0,0,0,0,0,0,0,0,0,0,0
+2555,0,0,0,0,0,0,0,0,0,0,0,0,0
+2556,0,0,0,0,0,0,0,0,0,0,0,0,0
+2557,0,0,0,0,0,0,0,0,0,0,0,0,0
+2558,0,0,0,0,0,0,0,0,0,0,0,0,0
+2559,0,0,0,0,0,0,0,0,0,0,0,0,0
+2560,0,0,0,0,0,0,0,0,0,0,0,0,0
+2561,0,0,0,0,0,0,0,0,0,0,0,0,0
+2562,0,0,0,0,0,0,0,0,0,0,0,0,0
+2563,0,0,0,0,0,0,0,0,0,0,0,0,0
+2564,0,0,0,0,0,0,0,0,0,0,0,0,0
+2565,0,0,0,0,0,0,0,0,0,0,0,0,0
+2566,0,0,0,0,0,0,0,0,0,0,0,0,0
+2567,0,0,0,0,0,0,0,0,0,0,0,0,0
+2568,0,0,0,0,0,0,0,0,0,0,0,0,0
+2569,0,0,0,0,0,0,0,0,0,0,0,0,0
+2570,0,0,0,0,0,0,0,0,0,0,0,0,0
+2571,0,0,0,0,0,0,0,0,0,0,0,0,0
+2572,0,0,0,0,0,0,0,0,0,0,0,0,0
+2573,0,0,0,0,0,0,0,0,0,0,0,0,0
+2574,0,0,0,0,0,0,0,0,0,0,0,0,0
+2575,0,0,0,0,0,0,0,0,0,0,0,0,0
+2576,0,0,0,0,0,0,0,0,0,0,0,0,0
+2577,0,0,0,0,0,0,0,0,0,0,0,0,0
+2578,0,0,0,0,0,0,0,0,0,0,0,0,0
+2579,0,0,0,0,0,0,0,0,0,0,0,0,0
+2580,0,0,0,0,0,0,0,0,0,0,0,0,0
+2581,0,0,0,0,0,0,0,0,0,0,0,0,0
+2582,0,0,0,0,0,0,0,0,0,0,0,0,0
+2583,0,0,0,0,0,0,0,0,0,0,0,0,0
+2584,0,0,0,0,0,0,0,0,0,0,0,0,0
+2585,0,0,0,0,0,0,0,0,0,0,0,0,0
+2586,0,0,0,0,0,0,0,0,0,0,0,0,0
+2587,0,0,0,0,0,0,0,0,0,0,0,0,0
+2588,0,0,0,0,0,0,0,0,0,0,0,0,0
+2589,0,0,0,0,0,0,0,0,0,0,0,0,0
+2590,0,0,0,0,0,0,0,0,0,0,0,0,0
+2591,0,0,0,0,0,0,0,0,0,0,0,0,0
+2592,0,0,0,0,0,0,0,0,0,0,0,0,0
+2593,0,0,0,0,0,0,0,0,0,0,0,0,0
+2594,0,0,0,0,0,0,0,0,0,0,0,0,0
+2595,0,0,0,0,0,0,0,0,0,0,0,0,0
+2596,0,0,0,0,0,0,0,0,0,0,0,0,0
+2597,0,0,0,0,0,0,0,0,0,0,0,0,0
+2598,0,0,0,0,0,0,0,0,0,0,0,0,0
+2599,0,0,0,0,0,0,0,0,0,0,0,0,0
+2600,0,0,0,0,0,0,0,0,0,0,0,0,0
+SR_WL,SR_AV_B1,SR_AV_B2,SR_AV_B3,SR_AV_B4,SR_AV_B5,SR_AV_B6,SR_AV_B7,SR_AV_B8,SR_AV_B8A,SR_AV_B9,SR_AV_B10,SR_AV_B11,SR_AV_B12
+300,0,0,0,0,0,0,0,0,0,0,0,0,0
+301,0,0,0,0,0,0,0,0,0,0,0,0,0
+302,0,0,0,0,0,0,0,0,0,0,0,0,0
+303,0,0,0,0,0,0,0,0,0,0,0,0,0
+304,0,0,0,0,0,0,0,0,0,0,0,0,0
+305,0,0,0,0,0,0,0,0,0,0,0,0,0
+306,0,0,0,0,0,0,0,0,0,0,0,0,0
+307,0,0,0,0,0,0,0,0,0,0,0,0,0
+308,0,0,0,0,0,0,0,0,0,0,0,0,0
+309,0,0,0,0,0,0,0,0,0,0,0,0,0
+310,0,0,0,0,0,0,0,0,0,0,0,0,0
+311,0,0,0,0,0,0,0,0,0,0,0,0,0
+312,0,0,0,0,0,0,0,0,0,0,0,0,0
+313,0,0,0,0,0,0,0,0,0,0,0,0,0
+314,0,0,0,0,0,0,0,0,0,0,0,0,0
+315,0,0,0,0,0,0,0,0,0,0,0,0,0
+316,0,0,0,0,0,0,0,0,0,0,0,0,0
+317,0,0,0,0,0,0,0,0,0,0,0,0,0
+318,0,0,0,0,0,0,0,0,0,0,0,0,0
+319,0,0,0,0,0,0,0,0,0,0,0,0,0
+320,0,0,0,0,0,0,0,0,0,0,0,0,0
+321,0,0,0,0,0,0,0,0,0,0,0,0,0
+322,0,0,0,0,0,0,0,0,0,0,0,0,0
+323,0,0,0,0,0,0,0,0,0,0,0,0,0
+324,0,0,0,0,0,0,0,0,0,0,0,0,0
+325,0,0,0,0,0,0,0,0,0,0,0,0,0
+326,0,0,0,0,0,0,0,0,0,0,0,0,0
+327,0,0,0,0,0,0,0,0,0,0,0,0,0
+328,0,0,0,0,0,0,0,0,0,0,0,0,0
+329,0,0,0,0,0,0,0,0,0,0,0,0,0
+330,0,0,0,0,0,0,0,0,0,0,0,0,0
+331,0,0,0,0,0,0,0,0,0,0,0,0,0
+332,0,0,0,0,0,0,0,0,0,0,0,0,0
+333,0,0,0,0,0,0,0,0,0,0,0,0,0
+334,0,0,0,0,0,0,0,0,0,0,0,0,0
+335,0,0,0,0,0,0,0,0,0,0,0,0,0
+336,0,0,0,0,0,0,0,0,0,0,0,0,0
+337,0,0,0,0,0,0,0,0,0,0,0,0,0
+338,0,0,0,0,0,0,0,0,0,0,0,0,0
+339,0,0,0,0,0,0,0,0,0,0,0,0,0
+340,0,0,0,0,0,0,0,0,0,0,0,0,0
+341,0,0,0,0,0,0,0,0,0,0,0,0,0
+342,0,0,0,0,0,0,0,0,0,0,0,0,0
+343,0,0,0,0,0,0,0,0,0,0,0,0,0
+344,0,0,0,0,0,0,0,0,0,0,0,0,0
+345,0,0,0,0,0,0,0,0,0,0,0,0,0
+346,0,0,0,0,0,0,0,0,0,0,0,0,0
+347,0,0,0,0,0,0,0,0,0,0,0,0,0
+348,0,0,0,0,0,0,0,0,0,0,0,0,0
+349,0,0,0,0,0,0,0,0,0,0,0,0,0
+350,0,0,0,0,0,0,0,0,0,0,0,0,0
+351,0,0,0,0,0,0,0,0,0,0,0,0,0
+352,0,0,0,0,0,0,0,0,0,0,0,0,0
+353,0,0,0,0,0,0,0,0,0,0,0,0,0
+354,0,0,0,0,0,0,0,0,0,0,0,0,0
+355,0,0,0,0,0,0,0,0,0,0,0,0,0
+356,0,0,0,0,0,0,0,0,0,0,0,0,0
+357,0,0,0,0,0,0,0,0,0,0,0,0,0
+358,0,0,0,0,0,0,0,0,0,0,0,0,0
+359,0,0,0,0,0,0,0,0,0,0,0,0,0
+360,0,0,0,0,0,0,0,0,0,0,0,0,0
+361,0,0,0,0,0,0,0,0,0,0,0,0,0
+362,0,0,0,0,0,0,0,0,0,0,0,0,0
+363,0,0,0,0,0,0,0,0,0,0,0,0,0
+364,0,0,0,0,0,0,0,0,0,0,0,0,0
+365,0,0,0,0,0,0,0,0,0,0,0,0,0
+366,0,0,0,0,0,0,0,0,0,0,0,0,0
+367,0,0,0,0,0,0,0,0,0,0,0,0,0
+368,0,0,0,0,0,0,0,0,0,0,0,0,0
+369,0,0,0,0,0,0,0,0,0,0,0,0,0
+370,0,0,0,0,0,0,0,0,0,0,0,0,0
+371,0,0,0,0,0,0,0,0,0,0,0,0,0
+372,0,0,0,0,0,0,0,0,0,0,0,0,0
+373,0,0,0,0,0,0,0,0,0,0,0,0,0
+374,0,0,0,0,0,0,0,0,0,0,0,0,0
+375,0,0,0,0,0,0,0,0,0,0,0,0,0
+376,0,0,0,0,0,0,0,0,0,0,0,0,0
+377,0,0,0,0,0,0,0,0,0,0,0,0,0
+378,0,0,0,0,0,0,0,0,0,0,0,0,0
+379,0,0,0,0,0,0,0,0,0,0,0,0,0
+380,0,0,0,0,0,0,0,0,0,0,0,0,0
+381,0,0,0,0,0,0,0,0,0,0,0,0,0
+382,0,0,0,0,0,0,0,0,0,0,0,0,0
+383,0,0,0,0,0,0,0,0,0,0,0,0,0
+384,0,0,0,0,0,0,0,0,0,0,0,0,0
+385,0,0,0,0,0,0,0,0,0,0,0,0,0
+386,0,0,0,0,0,0,0,0,0,0,0,0,0
+387,0,0,0,0,0,0,0,0,0,0,0,0,0
+388,0,0,0,0,0,0,0,0,0,0,0,0,0
+389,0,0,0,0,0,0,0,0,0,0,0,0,0
+390,0,0,0,0,0,0,0,0,0,0,0,0,0
+391,0,0,0,0,0,0,0,0,0,0,0,0,0
+392,0,0,0,0,0,0,0,0,0,0,0,0,0
+393,0,0,0,0,0,0,0,0,0,0,0,0,0
+394,0,0,0,0,0,0,0,0,0,0,0,0,0
+395,0,0,0,0,0,0,0,0,0,0,0,0,0
+396,0,0,0,0,0,0,0,0,0,0,0,0,0
+397,0,0,0,0,0,0,0,0,0,0,0,0,0
+398,0,0,0,0,0,0,0,0,0,0,0,0,0
+399,0,0,0,0,0,0,0,0,0,0,0,0,0
+400,0,0,0,0,0,0,0,0,0,0,0,0,0
+401,0,0,0,0,0,0,0,0,0,0,0,0,0
+402,0,0,0,0,0,0,0,0,0,0,0,0,0
+403,0,0,0,0,0,0,0,0,0,0,0,0,0
+404,0,0,0,0,0,0,0,0,0,0,0,0,0
+405,0,0,0,0,0,0,0,0,0,0,0,0,0
+406,0,0,0,0,0,0,0,0,0,0,0,0,0
+407,0,0,0,0,0,0,0,0,0,0,0,0,0
+408,0,0,0,0,0,0,0,0,0,0,0,0,0
+409,0,0,0,0,0,0,0,0,0,0,0,0,0
+410,0,0,0,0,0,0,0,0,0,0,0,0,0
+411,0.006797798,0,0,0,0,0,0,0,0,0,0,0,0
+412,0.01099643,0,0,0,0,0,0,0,0,0,0,0,0
+413,0.004208363,0,0,0,0,0,0,0,0,0,0,0,0
+414,0.006568034,0,0,0,0,0,0,0,0,0,0,0,0
+415,0.005883123,0,0,0,0,0,0,0,0,0,0,0,0
+416,0.00713011,0,0,0,0,0,0,0,0,0,0,0,0
+417,0.004333651,0,0,0,0,0,0,0,0,0,0,0,0
+418,0.006263537,0,0,0,0,0,0,0,0,0,0,0,0
+419,0.004393687,0,0,0,0,0,0,0,0,0,0,0,0
+420,0.00253157,0,0,0,0,0,0,0,0,0,0,0,0
+421,0.000621707,0,0,0,0,0,0,0,0,0,0,0,0
+422,0.002117729,0,0,0,0,0,0,0,0,0,0,0,0
+423,0.003175796,0,0,0,0,0,0,0,0,0,0,0,0
+424,0.005213085,0,0,0,0,0,0,0,0,0,0,0,0
+425,0.003387375,0,0,0,0,0,0,0,0,0,0,0,0
+426,0.00258671,0,0,0,0,0,0,0,0,0,0,0,0
+427,0.002384167,0,0,0,0,0,0,0,0,0,0,0,0
+428,0.004595227,0,0,0,0,0,0,0,0,0,0,0,0
+429,0.012990945,0,0,0,0,0,0,0,0,0,0,0,0
+430,0.050622293,0,0,0,0,0,0,0,0,0,0,0,0
+431,0.18872241,0,0,0,0,0,0,0,0,0,0,0,0
+432,0.459106539,0,0,0,0,0,0,0,0,0,0,0,0
+433,0.730160597,0,0,0,0,0,0,0,0,0,0,0,0
+434,0.847259495,0,0,0,0,0,0,0,0,0,0,0,0
+435,0.871235903,0,0,0,0,0,0,0,0,0,0,0,0
+436,0.881448354,0,0,0,0,0,0,0,0,0,0,0,0
+437,0.899392736,0,0,0,0,0,0,0,0,0,0,0,0
+438,0.918669431,0.001893306,0,0,0,0,0,0,0,0,0,0,0
+439,0.933420754,0.019440751,0,0,0,0,0,0,0,0,0,0,0
+440,0.94596319,0.020059028,0,0,0,0,0,0,0,0,0,0,0
+441,0.95041031,0.014109631,0,0,0,0,0,0,0,0,0,0,0
+442,0.953972339,0.015612858,0,0,0,0,0,0,0,0,0,0,0
+443,0.96903168,0.015448868,0,0,0,0,0,0,0,0,0,0,0
+444,0.999546173,0.017034152,0,0,0,0,0,0,0,0,0,0,0
+445,1,0.013311359,0,0,0,0,0,0,0,0,0,0,0
+446,0.976368067,0.014462036,0,0,0,0,0,0,0,0,0,0,0
+447,0.96404957,0.009592091,0,0,0,0,0,0,0,0,0,0,0
+448,0.95417544,0.014500694,0,0,0,0,0,0,0,0,0,0,0
+449,0.923744832,0.011159264,0,0,0,0,0,0,0,0,0,0,0
+450,0.88548879,0.013332524,0,0,0,0,0,0,0,0,0,0,0
+451,0.809016274,0.01355731,0,0,0,0,0,0,0,0,0,0,0
+452,0.601561144,0.01426,0,0,0,0,0,0,0,0,0,0,0
+453,0.306766029,0.014717634,0,0,0,0,0,0,0,0,0,0,0
+454,0.108527711,0.015989541,0,0,0,0,0,0,0,0,0,0,0
+455,0.030542088,0.030654247,0,0,0,0,0,0,0,0,0,0,0
+456,0.008935131,0.055432753,0,0,0,0,0,0,0,0,0,0,0
+457,0,0.120228972,0,0,0,0,0,0,0,0,0,0,0
+458,0,0.252260953,0,0,0,0,0,0,0,0,0,0,0
+459,0,0.462862499,0,0,0,0,0,0,0,0,0,0,0
+460,0,0.65241169,0,0,0,0,0,0,0,0,0,0,0
+461,0,0.77750832,0,0,0,0,0,0,0,0,0,0,0
+462,0,0.824333103,0,0,0,0,0,0,0,0,0,0,0
+463,0,0.832077099,0,0,0,0,0,0,0,0,0,0,0
+464,0,0.835037767,0,0,0,0,0,0,0,0,0,0,0
+465,0,0.838761115,0,0,0,0,0,0,0,0,0,0,0
+466,0,0.864126031,0,0,0,0,0,0,0,0,0,0,0
+467,0,0.883293587,0,0,0,0,0,0,0,0,0,0,0
+468,0,0.90569382,0,0,0,0,0,0,0,0,0,0,0
+469,0,0.921186621,0,0,0,0,0,0,0,0,0,0,0
+470,0,0.936616967,0,0,0,0,0,0,0,0,0,0,0
+471,0,0.931024626,0,0,0,0,0,0,0,0,0,0,0
+472,0,0.927547539,0,0,0,0,0,0,0,0,0,0,0
+473,0,0.916622744,0,0,0,0,0,0,0,0,0,0,0
+474,0,0.9060165,0,0,0,0,0,0,0,0,0,0,0
+475,0,0.897870416,0,0,0,0,0,0,0,0,0,0,0
+476,0,0.903146598,0,0,0,0,0,0,0,0,0,0,0
+477,0,0.908994286,0,0,0,0,0,0,0,0,0,0,0
+478,0,0.920859439,0,0,0,0,0,0,0,0,0,0,0
+479,0,0.924523699,0,0,0,0,0,0,0,0,0,0,0
+480,0,0.918843658,0,0,0,0,0,0,0,0,0,0,0
+481,0,0.907981319,0,0,0,0,0,0,0,0,0,0,0
+482,0,0.898032665,0,0,0,0,0,0,0,0,0,0,0
+483,0,0.88735796,0,0,0,0,0,0,0,0,0,0,0
+484,0,0.873065866,0,0,0,0,0,0,0,0,0,0,0
+485,0,0.857761622,0,0,0,0,0,0,0,0,0,0,0
+486,0,0.846132814,0,0,0,0,0,0,0,0,0,0,0
+487,0,0.843382711,0,0,0,0,0,0,0,0,0,0,0
+488,0,0.857924772,0,0,0,0,0,0,0,0,0,0,0
+489,0,0.879320632,0,0,0,0,0,0,0,0,0,0,0
+490,0,0.903975503,0,0,0,0,0,0,0,0,0,0,0
+491,0,0.919580552,0,0,0,0,0,0,0,0,0,0,0
+492,0,0.946712663,0,0,0,0,0,0,0,0,0,0,0
+493,0,0.969406608,0,0,0,0,0,0,0,0,0,0,0
+494,0,0.993636046,0,0,0,0,0,0,0,0,0,0,0
+495,0,0.999320649,0,0,0,0,0,0,0,0,0,0,0
+496,0,1,0,0,0,0,0,0,0,0,0,0,0
+497,0,0.995107621,0,0,0,0,0,0,0,0,0,0,0
+498,0,0.984163047,0,0,0,0,0,0,0,0,0,0,0
+499,0,0.979509527,0,0,0,0,0,0,0,0,0,0,0
+500,0,0.978185449,0,0,0,0,0,0,0,0,0,0,0
+501,0,0.972278886,0,0,0,0,0,0,0,0,0,0,0
+502,0,0.96293492,0,0,0,0,0,0,0,0,0,0,0
+503,0,0.95355824,0,0,0,0,0,0,0,0,0,0,0
+504,0,0.938134944,0,0,0,0,0,0,0,0,0,0,0
+505,0,0.924777929,0,0,0,0,0,0,0,0,0,0,0
+506,0,0.909590075,0,0,0,0,0,0,0,0,0,0,0
+507,0,0.902313691,0,0,0,0,0,0,0,0,0,0,0
+508,0,0.892251397,0,0,0,0,0,0,0,0,0,0,0
+509,0,0.890060534,0,0,0,0,0,0,0,0,0,0,0
+510,0,0.891851681,0,0,0,0,0,0,0,0,0,0,0
+511,0,0.899164865,0,0,0,0,0,0,0,0,0,0,0
+512,0,0.910901434,0,0,0,0,0,0,0,0,0,0,0
+513,0,0.924636296,0,0,0,0,0,0,0,0,0,0,0
+514,0,0.938626228,0,0,0,0,0,0,0,0,0,0,0
+515,0,0.953526854,0,0,0,0,0,0,0,0,0,0,0
+516,0,0.971831245,0,0,0,0,0,0,0,0,0,0,0
+517,0,0.987690608,0,0,0,0,0,0,0,0,0,0,0
+518,0,0.996791216,0,0,0,0,0,0,0,0,0,0,0
+519,0,0.993851876,0,0,0,0,0,0,0,0,0,0,0
+520,0,0.9816383,0,0,0,0,0,0,0,0,0,0,0
+521,0,0.958970396,0,0,0,0,0,0,0,0,0,0,0
+522,0,0.893259218,0,0,0,0,0,0,0,0,0,0,0
+523,0,0.736063596,0,0,0,0,0,0,0,0,0,0,0
+524,0,0.52101528,0,0,0,0,0,0,0,0,0,0,0
+525,0,0.332578748,0,0,0,0,0,0,0,0,0,0,0
+526,0,0.195080476,0,0,0,0,0,0,0,0,0,0,0
+527,0,0.117429222,0,0,0,0,0,0,0,0,0,0,0
+528,0,0.075138809,0,0,0,0,0,0,0,0,0,0,0
+529,0,0.050991983,0,0,0,0,0,0,0,0,0,0,0
+530,0,0.032154822,0,0,0,0,0,0,0,0,0,0,0
+531,0,0.015134166,0,0,0,0,0,0,0,0,0,0,0
+532,0,0.004477169,0,0,0,0,0,0,0,0,0,0,0
+533,0,0,0,0,0,0,0,0,0,0,0,0,0
+534,0,0,0,0,0,0,0,0,0,0,0,0,0
+535,0,0,0,0,0,0,0,0,0,0,0,0,0
+536,0,0,0.001849077,0,0,0,0,0,0,0,0,0,0
+537,0,0,0.015481298,0,0,0,0,0,0,0,0,0,0
+538,0,0,0.036661939,0,0,0,0,0,0,0,0,0,0
+539,0,0,0.081181302,0,0,0,0,0,0,0,0,0,0
+540,0,0,0.169521526,0,0,0,0,0,0,0,0,0,0
+541,0,0,0.333499478,0,0,0,0,0,0,0,0,0,0
+542,0,0,0.587551283,0,0,0,0,0,0,0,0,0,0
+543,0,0,0.810898276,0,0,0,0,0,0,0,0,0,0
+544,0,0,0.914486774,0,0,0,0,0,0,0,0,0,0
+545,0,0,0.945520385,0,0,0,0,0,0,0,0,0,0
+546,0,0,0.949175317,0,0,0,0,0,0,0,0,0,0
+547,0,0,0.943501504,0,0,0,0,0,0,0,0,0,0
+548,0,0,0.928333429,0,0,0,0,0,0,0,0,0,0
+549,0,0,0.912819616,0,0,0,0,0,0,0,0,0,0
+550,0,0,0.901482543,0,0,0,0,0,0,0,0,0,0
+551,0,0,0.900858652,0,0,0,0,0,0,0,0,0,0
+552,0,0,0.907289434,0,0,0,0,0,0,0,0,0,0
+553,0,0,0.922649114,0,0,0,0,0,0,0,0,0,0
+554,0,0,0.942932043,0,0,0,0,0,0,0,0,0,0
+555,0,0,0.964024785,0,0,0,0,0,0,0,0,0,0
+556,0,0,0.983470408,0,0,0,0,0,0,0,0,0,0
+557,0,0,0.999446482,0,0,0,0,0,0,0,0,0,0
+558,0,0,1,0,0,0,0,0,0,0,0,0,0
+559,0,0,0.991955712,0,0,0,0,0,0,0,0,0,0
+560,0,0,0.976582923,0,0,0,0,0,0,0,0,0,0
+561,0,0,0.951151834,0,0,0,0,0,0,0,0,0,0
+562,0,0,0.924621468,0,0,0,0,0,0,0,0,0,0
+563,0,0,0.891851701,0,0,0,0,0,0,0,0,0,0
+564,0,0,0.868157818,0,0,0,0,0,0,0,0,0,0
+565,0,0,0.847608394,0,0,0,0,0,0,0,0,0,0
+566,0,0,0.83920859,0,0,0,0,0,0,0,0,0,0
+567,0,0,0.832980675,0,0,0,0,0,0,0,0,0,0
+568,0,0,0.830820549,0,0,0,0,0,0,0,0,0,0
+569,0,0,0.835211024,0,0,0,0,0,0,0,0,0,0
+570,0,0,0.84875691,0,0,0,0,0,0,0,0,0,0
+571,0,0,0.866563551,0,0,0,0,0,0,0,0,0,0
+572,0,0,0.875196149,0,0,0,0,0,0,0,0,0,0
+573,0,0,0.87037822,0,0,0,0,0,0,0,0,0,0
+574,0,0,0.857256926,0,0,0,0,0,0,0,0,0,0
+575,0,0,0.809749622,0,0,0,0,0,0,0,0,0,0
+576,0,0,0.677463956,0,0,0,0,0,0,0,0,0,0
+577,0,0,0.456507841,0,0,0,0,0,0,0,0,0,0
+578,0,0,0.247691784,0,0,0,0,0,0,0,0,0,0
+579,0,0,0.127866254,0,0,0,0,0,0,0,0,0,0
+580,0,0,0.059016809,0,0,0,0,0,0,0,0,0,0
+581,0,0,0.025724357,0,0,0,0,0,0,0,0,0,0
+582,0,0,0.005219158,0,0,0,0,0,0,0,0,0,0
+583,0,0,0,0,0,0,0,0,0,0,0,0,0
+584,0,0,0,0,0,0,0,0,0,0,0,0,0
+585,0,0,0,0,0,0,0,0,0,0,0,0,0
+586,0,0,0,0,0,0,0,0,0,0,0,0,0
+587,0,0,0,0,0,0,0,0,0,0,0,0,0
+588,0,0,0,0,0,0,0,0,0,0,0,0,0
+589,0,0,0,0,0,0,0,0,0,0,0,0,0
+590,0,0,0,0,0,0,0,0,0,0,0,0,0
+591,0,0,0,0,0,0,0,0,0,0,0,0,0
+592,0,0,0,0,0,0,0,0,0,0,0,0,0
+593,0,0,0,0,0,0,0,0,0,0,0,0,0
+594,0,0,0,0,0,0,0,0,0,0,0,0,0
+595,0,0,0,0,0,0,0,0,0,0,0,0,0
+596,0,0,0,0,0,0,0,0,0,0,0,0,0
+597,0,0,0,0,0,0,0,0,0,0,0,0,0
+598,0,0,0,0,0,0,0,0,0,0,0,0,0
+599,0,0,0,0,0,0,0,0,0,0,0,0,0
+600,0,0,0,0,0,0,0,0,0,0,0,0,0
+601,0,0,0,0,0,0,0,0,0,0,0,0,0
+602,0,0,0,0,0,0,0,0,0,0,0,0,0
+603,0,0,0,0,0,0,0,0,0,0,0,0,0
+604,0,0,0,0,0,0,0,0,0,0,0,0,0
+605,0,0,0,0,0,0,0,0,0,0,0,0,0
+606,0,0,0,0,0,0,0,0,0,0,0,0,0
+607,0,0,0,0,0,0,0,0,0,0,0,0,0
+608,0,0,0,0,0,0,0,0,0,0,0,0,0
+609,0,0,0,0,0,0,0,0,0,0,0,0,0
+610,0,0,0,0,0,0,0,0,0,0,0,0,0
+611,0,0,0,0,0,0,0,0,0,0,0,0,0
+612,0,0,0,0,0,0,0,0,0,0,0,0,0
+613,0,0,0,0,0,0,0,0,0,0,0,0,0
+614,0,0,0,0,0,0,0,0,0,0,0,0,0
+615,0,0,0,0,0,0,0,0,0,0,0,0,0
+616,0,0,0,0,0,0,0,0,0,0,0,0,0
+617,0,0,0,0,0,0,0,0,0,0,0,0,0
+618,0,0,0,0,0,0,0,0,0,0,0,0,0
+619,0,0,0,0,0,0,0,0,0,0,0,0,0
+620,0,0,0,0,0,0,0,0,0,0,0,0,0
+621,0,0,0,0,0,0,0,0,0,0,0,0,0
+622,0,0,0,0,0,0,0,0,0,0,0,0,0
+623,0,0,0,0,0,0,0,0,0,0,0,0,0
+624,0,0,0,0,0,0,0,0,0,0,0,0,0
+625,0,0,0,0,0,0,0,0,0,0,0,0,0
+626,0,0,0,0,0,0,0,0,0,0,0,0,0
+627,0,0,0,0,0,0,0,0,0,0,0,0,0
+628,0,0,0,0,0,0,0,0,0,0,0,0,0
+629,0,0,0,0,0,0,0,0,0,0,0,0,0
+630,0,0,0,0,0,0,0,0,0,0,0,0,0
+631,0,0,0,0,0,0,0,0,0,0,0,0,0
+632,0,0,0,0,0,0,0,0,0,0,0,0,0
+633,0,0,0,0,0,0,0,0,0,0,0,0,0
+634,0,0,0,0,0,0,0,0,0,0,0,0,0
+635,0,0,0,0,0,0,0,0,0,0,0,0,0
+636,0,0,0,0,0,0,0,0,0,0,0,0,0
+637,0,0,0,0,0,0,0,0,0,0,0,0,0
+638,0,0,0,0,0,0,0,0,0,0,0,0,0
+639,0,0,0,0,0,0,0,0,0,0,0,0,0
+640,0,0,0,0,0,0,0,0,0,0,0,0,0
+641,0,0,0,0,0,0,0,0,0,0,0,0,0
+642,0,0,0,0,0,0,0,0,0,0,0,0,0
+643,0,0,0,0,0,0,0,0,0,0,0,0,0
+644,0,0,0,0,0,0,0,0,0,0,0,0,0
+645,0,0,0,0,0,0,0,0,0,0,0,0,0
+646,0,0,0,0.005090312,0,0,0,0,0,0,0,0,0
+647,0,0,0,0.026897029,0,0,0,0,0,0,0,0,0
+648,0,0,0,0.12087986,0,0,0,0,0,0,0,0,0
+649,0,0,0,0.33742273,0,0,0,0,0,0,0,0,0
+650,0,0,0,0.603624689,0,0,0,0,0,0,0,0,0
+651,0,0,0,0.810967523,0,0,0,0,0,0,0,0,0
+652,0,0,0,0.91573833,0,0,0,0,0,0,0,0,0
+653,0,0,0,0.92605288,0,0,0,0,0,0,0,0,0
+654,0,0,0,0.92083242,0,0,0,0,0,0,0,0,0
+655,0,0,0,0.911237119,0,0,0,0,0,0,0,0,0
+656,0,0,0,0.902005739,0,0,0,0,0,0,0,0,0
+657,0,0,0,0.897081513,0,0,0,0,0,0,0,0,0
+658,0,0,0,0.899066029,0,0,0,0,0,0,0,0,0
+659,0,0,0,0.900672338,0,0,0,0,0,0,0,0,0
+660,0,0,0,0.902488081,0,0,0,0,0,0,0,0,0
+661,0,0,0,0.906886173,0,0,0,0,0,0,0,0,0
+662,0,0,0,0.915610562,0,0,0,0,0,0,0,0,0
+663,0,0,0,0.927756371,0,0,0,0,0,0,0,0,0
+664,0,0,0,0.941055569,0,0,0,0,0,0,0,0,0
+665,0,0,0,0.954196504,0,0,0,0,0,0,0,0,0
+666,0,0,0,0.966908428,0,0,0,0,0,0,0,0,0
+667,0,0,0,0.981390028,0,0,0,0,0,0,0,0,0
+668,0,0,0,0.991619278,0,0,0,0,0,0,0,0,0
+669,0,0,0,1,0,0,0,0,0,0,0,0,0
+670,0,0,0,0.999754078,0,0,0,0,0,0,0,0,0
+671,0,0,0,0.994046577,0,0,0,0,0,0,0,0,0
+672,0,0,0,0.981792818,0,0,0,0,0,0,0,0,0
+673,0,0,0,0.968692612,0,0,0,0,0,0,0,0,0
+674,0,0,0,0.957607907,0,0,0,0,0,0,0,0,0
+675,0,0,0,0.945644641,0,0,0,0,0,0,0,0,0
+676,0,0,0,0.92580977,0,0,0,0,0,0,0,0,0
+677,0,0,0,0.897152993,0,0,0,0,0,0,0,0,0
+678,0,0,0,0.838534201,0,0,0,0,0,0,0,0,0
+679,0,0,0,0.698446797,0,0,0,0,0,0,0,0,0
+680,0,0,0,0.493502787,0,0,0,0,0,0,0,0,0
+681,0,0,0,0.276900547,0,0,0,0,0,0,0,0,0
+682,0,0,0,0.107781358,0,0,0,0,0,0,0,0,0
+683,0,0,0,0.029913795,0,0,0,0,0,0,0,0,0
+684,0,0,0,0.007336673,0,0,0,0,0,0,0,0,0
+685,0,0,0,0.000838123,0,0,0,0,0,0,0,0,0
+686,0,0,0,0,0,0,0,0,0,0,0,0,0
+687,0,0,0,0,0,0,0,0,0,0,0,0,0
+688,0,0,0,0,0,0,0,0,0,0,0,0,0
+689,0,0,0,0,0,0,0,0,0,0,0,0,0
+690,0,0,0,0,0,0,0,0,0,0,0,0,0
+691,0,0,0,0,0,0,0,0,0,0,0,0,0
+692,0,0,0,0,0,0,0,0,0,0,0,0,0
+693,0,0,0,0,0,0,0,0,0,0,0,0,0
+694,0,0,0,0,0.010471827,0,0,0,0,0,0,0,0
+695,0,0,0,0,0.057252544,0,0,0,0,0,0,0,0
+696,0,0,0,0,0.214724996,0,0,0,0,0,0,0,0
+697,0,0,0,0,0.547189415,0,0,0,0,0,0,0,0
+698,0,0,0,0,0.871043978,0,0,0,0,0,0,0,0
+699,0,0,0,0,0.968446586,0,0,0,0,0,0,0,0
+700,0,0,0,0,0.99124182,0,0,0,0,0,0,0,0
+701,0,0,0,0,1,0,0,0,0,0,0,0,0
+702,0,0,0,0,0.99509331,0,0,0,0,0,0,0,0
+703,0,0,0,0,0.987602081,0,0,0,0,0,0,0,0
+704,0,0,0,0,0.979408704,0,0,0,0,0,0,0,0
+705,0,0,0,0,0.970910946,0,0,0,0,0,0,0,0
+706,0,0,0,0,0.959528083,0,0,0,0,0,0,0,0
+707,0,0,0,0,0.94236861,0,0,0,0,0,0,0,0
+708,0,0,0,0,0.926720132,0,0,0,0,0,0,0,0
+709,0,0,0,0,0.894557475,0,0,0,0,0,0,0,0
+710,0,0,0,0,0.767248071,0,0,0,0,0,0,0,0
+711,0,0,0,0,0.504134435,0,0,0,0,0,0,0,0
+712,0,0,0,0,0.180610636,0,0,0,0,0,0,0,0
+713,0,0,0,0,0.034019737,0,0,0,0,0,0,0,0
+714,0,0,0,0,0.002436944,0,0,0,0,0,0,0,0
+715,0,0,0,0,0,0,0,0,0,0,0,0,0
+716,0,0,0,0,0,0,0,0,0,0,0,0,0
+717,0,0,0,0,0,0,0,0,0,0,0,0,0
+718,0,0,0,0,0,0,0,0,0,0,0,0,0
+719,0,0,0,0,0,0,0,0,0,0,0,0,0
+720,0,0,0,0,0,0,0,0,0,0,0,0,0
+721,0,0,0,0,0,0,0,0,0,0,0,0,0
+722,0,0,0,0,0,0,0,0,0,0,0,0,0
+723,0,0,0,0,0,0,0,0,0,0,0,0,0
+724,0,0,0,0,0,0,0,0,0,0,0,0,0
+725,0,0,0,0,0,0,0,0,0,0,0,0,0
+726,0,0,0,0,0,0,0,0,0,0,0,0,0
+727,0,0,0,0,0,0,0,0,0,0,0,0,0
+728,0,0,0,0,0,0,0,0,0,0,0,0,0
+729,0,0,0,0,0,0,0,0,0,0,0,0,0
+730,0,0,0,0,0,0.017433807,0,0,0,0,0,0,0
+731,0,0,0,0,0,0.105812957,0,0,0,0,0,0,0
+732,0,0,0,0,0,0.386050533,0,0,0,0,0,0,0
+733,0,0,0,0,0,0.782313159,0,0,0,0,0,0,0
+734,0,0,0,0,0,0.905953099,0,0,0,0,0,0,0
+735,0,0,0,0,0,0.916416606,0,0,0,0,0,0,0
+736,0,0,0,0,0,0.92333441,0,0,0,0,0,0,0
+737,0,0,0,0,0,0.932013378,0,0,0,0,0,0,0
+738,0,0,0,0,0,0.947550036,0,0,0,0,0,0,0
+739,0,0,0,0,0,0.965839591,0,0,0,0,0,0,0
+740,0,0,0,0,0,0.978552758,0,0,0,0,0,0,0
+741,0,0,0,0,0,0.991319723,0,0,0,0,0,0,0
+742,0,0,0,0,0,1,0,0,0,0,0,0,0
+743,0,0,0,0,0,0.999955845,0,0,0,0,0,0,0
+744,0,0,0,0,0,0.971267313,0,0,0,0,0,0,0
+745,0,0,0,0,0,0.81917496,0,0,0,0,0,0,0
+746,0,0,0,0,0,0.467395748,0,0,0,0,0,0,0
+747,0,0,0,0,0,0.094120897,0,0,0,0,0,0,0
+748,0,0,0,0,0,0.009834009,0,0,0,0,0,0,0
+749,0,0,0,0,0,0,0,0,0,0,0,0,0
+750,0,0,0,0,0,0,0,0,0,0,0,0,0
+751,0,0,0,0,0,0,0,0,0,0,0,0,0
+752,0,0,0,0,0,0,0,0,0,0,0,0,0
+753,0,0,0,0,0,0,0,0,0,0,0,0,0
+754,0,0,0,0,0,0,0,0,0,0,0,0,0
+755,0,0,0,0,0,0,0,0,0,0,0,0,0
+756,0,0,0,0,0,0,0,0,0,0,0,0,0
+757,0,0,0,0,0,0,0,0,0,0,0,0,0
+758,0,0,0,0,0,0,0,0,0,0,0,0,0
+759,0,0,0,0,0,0,0,0,0,0,0,0,0
+760,0,0,0,0,0,0,0,0,0,0,0,0,0
+761,0,0,0,0,0,0,0,0,0,0,0,0,0
+762,0,0,0,0,0,0,0,0,0,0,0,0,0
+763,0,0,0,0,0,0,0,0,0,0,0,0,0
+764,0,0,0,0,0,0,0,0,0,0,0,0,0
+765,0,0,0,0,0,0,0,0,0,0,0,0,0
+766,0,0,0,0,0,0,0.010282026,0,0,0,0,0,0
+767,0,0,0,0,0,0,0.037427714,0,0,0,0,0,0
+768,0,0,0,0,0,0,0.112026989,0,0,0,0,0,0
+769,0,0,0,0,0,0,0.257953812,0,0,0,0,0,0
+770,0,0,0,0,0,0,0.478980823,0,0,0,0,0,0
+771,0,0,0,0,0,0,0.730216783,0,0,0,0,0,0
+772,0,0,0,0,0,0,0.912510408,0,0,0,0,0,0
+773,0,0,0,0,0,0,0.971721033,0,0,0,0,0,0
+774,0,0,0,0,0,0,0.964616097,0.000386696,0,0,0,0,0
+775,0,0,0,0,0,0,0.955734525,0.003018401,0,0,0,0,0
+776,0,0,0,0,0,0,0.964925586,0.01669158,0,0,0,0,0
+777,0,0,0,0,0,0,0.986223289,0.028340486,0,0,0,0,0
+778,0,0,0,0,0,0,1,0.0502885,0,0,0,0,0
+779,0,0,0,0,0,0,0.998046627,0.08626388,0,0,0,0,0
+780,0,0,0,0,0,0,0.98393444,0.149596686,0,0,0,0,0
+781,0,0,0,0,0,0,0.96569621,0.258428566,0,0,0,0,0
+782,0,0,0,0,0,0,0.947277433,0.425108406,0,0,0,0,0
+783,0,0,0,0,0,0,0.927083998,0.631697563,0,0,0,0,0
+784,0,0,0,0,0,0,0.90976539,0.803109115,0,0,0,0,0
+785,0,0,0,0,0,0,0.886948914,0.904984654,0,0,0,0,0
+786,0,0,0,0,0,0,0.859517187,0.939674653,0,0,0,0,0
+787,0,0,0,0,0,0,0.827959173,0.944958731,0,0,0,0,0
+788,0,0,0,0,0,0,0.776383783,0.948238826,0,0,0,0,0
+789,0,0,0,0,0,0,0.671173028,0.963880684,0,0,0,0,0
+790,0,0,0,0,0,0,0.481809979,0.979861632,0,0,0,0,0
+791,0,0,0,0,0,0,0.236251944,0.991635585,0,0,0,0,0
+792,0,0,0,0,0,0,0.069538392,0.996362309,0,0,0,0,0
+793,0,0,0,0,0,0,0.013431956,1,0,0,0,0,0
+794,0,0,0,0,0,0,0.001257675,0.998257939,0,0,0,0,0
+795,0,0,0,0,0,0,0,0.998488834,0,0,0,0,0
+796,0,0,0,0,0,0,0,0.989253171,0,0,0,0,0
+797,0,0,0,0,0,0,0,0.98294089,0,0,0,0,0
+798,0,0,0,0,0,0,0,0.968189827,0,0,0,0,0
+799,0,0,0,0,0,0,0,0.958222106,0,0,0,0,0
+800,0,0,0,0,0,0,0,0.951650369,0,0,0,0,0
+801,0,0,0,0,0,0,0,0.947054991,0,0,0,0,0
+802,0,0,0,0,0,0,0,0.944166995,0,0,0,0,0
+803,0,0,0,0,0,0,0,0.948383123,0,0,0,0,0
+804,0,0,0,0,0,0,0,0.946461415,0,0,0,0,0
+805,0,0,0,0,0,0,0,0.942132884,0,0,0,0,0
+806,0,0,0,0,0,0,0,0.929937199,0,0,0,0,0
+807,0,0,0,0,0,0,0,0.914683918,0,0,0,0,0
+808,0,0,0,0,0,0,0,0.893248878,0,0,0,0,0
+809,0,0,0,0,0,0,0,0.873037871,0,0,0,0,0
+810,0,0,0,0,0,0,0,0.852648452,0,0,0,0,0
+811,0,0,0,0,0,0,0,0.836447483,0,0,0,0,0
+812,0,0,0,0,0,0,0,0.824300756,0,0,0,0,0
+813,0,0,0,0,0,0,0,0.814333379,0,0,0,0,0
+814,0,0,0,0,0,0,0,0.810955964,0,0,0,0,0
+815,0,0,0,0,0,0,0,0.803715941,0,0,0,0,0
+816,0,0,0,0,0,0,0,0.791980175,0,0,0,0,0
+817,0,0,0,0,0,0,0,0.783270185,0,0,0,0,0
+818,0,0,0,0,0,0,0,0.767838865,0,0,0,0,0
+819,0,0,0,0,0,0,0,0.754167357,0,0,0,0,0
+820,0,0,0,0,0,0,0,0.742309406,0,0,0,0,0
+821,0,0,0,0,0,0,0,0.727235815,0,0,0,0,0
+822,0,0,0,0,0,0,0,0.719323269,0,0,0,0,0
+823,0,0,0,0,0,0,0,0.713866399,0,0,0,0,0
+824,0,0,0,0,0,0,0,0.718941021,0,0,0,0,0
+825,0,0,0,0,0,0,0,0.726527917,0,0,0,0,0
+826,0,0,0,0,0,0,0,0.738324031,0,0,0,0,0
+827,0,0,0,0,0,0,0,0.750210769,0,0,0,0,0
+828,0,0,0,0,0,0,0,0.761800392,0,0,0,0,0
+829,0,0,0,0,0,0,0,0.769900245,0,0,0,0,0
+830,0,0,0,0,0,0,0,0.781725199,0,0,0,0,0
+831,0,0,0,0,0,0,0,0.78381047,0,0,0,0,0
+832,0,0,0,0,0,0,0,0.783069959,0,0,0,0,0
+833,0,0,0,0,0,0,0,0.782718588,0,0,0,0,0
+834,0,0,0,0,0,0,0,0.781644143,0,0,0,0,0
+835,0,0,0,0,0,0,0,0.780380397,0,0,0,0,0
+836,0,0,0,0,0,0,0,0.781443024,0,0,0,0,0
+837,0,0,0,0,0,0,0,0.781701218,0,0,0,0,0
+838,0,0,0,0,0,0,0,0.78177353,0,0,0,0,0
+839,0,0,0,0,0,0,0,0.780064535,0,0,0,0,0
+840,0,0,0,0,0,0,0,0.777591823,0,0,0,0,0
+841,0,0,0,0,0,0,0,0.770831803,0,0,0,0,0
+842,0,0,0,0,0,0,0,0.764574958,0,0,0,0,0
+843,0,0,0,0,0,0,0,0.753876586,0,0,0,0,0
+844,0,0,0,0,0,0,0,0.743324604,0,0,0,0,0
+845,0,0,0,0,0,0,0,0.733775698,0,0,0,0,0
+846,0,0,0,0,0,0,0,0.722497914,0,0,0,0,0
+847,0,0,0,0,0,0,0,0.712900724,0,0,0,0,0
+848,0,0,0,0,0,0,0,0.699439134,0.001661751,0,0,0,0
+849,0,0,0,0,0,0,0,0.688575227,0.01602581,0,0,0,0
+850,0,0,0,0,0,0,0,0.674039061,0.032253895,0,0,0,0
+851,0,0,0,0,0,0,0,0.657552716,0.073411273,0,0,0,0
+852,0,0,0,0,0,0,0,0.643729834,0.168937582,0,0,0,0
+853,0,0,0,0,0,0,0,0.62865391,0.345506138,0,0,0,0
+854,0,0,0,0,0,0,0,0.614005803,0.569417239,0,0,0,0
+855,0,0,0,0,0,0,0,0.603233252,0.79634996,0,0,0,0
+856,0,0,0,0,0,0,0,0.594982815,0.937581155,0,0,0,0
+857,0,0,0,0,0,0,0,0.588091928,0.980942645,0,0,0,0
+858,0,0,0,0,0,0,0,0.585186507,0.987241334,0,0,0,0
+859,0,0,0,0,0,0,0,0.582889219,0.994409463,0,0,0,0
+860,0,0,0,0,0,0,0,0.581493721,0.998963959,0,0,0,0
+861,0,0,0,0,0,0,0,0.580137218,0.999788107,0,0,0,0
+862,0,0,0,0,0,0,0,0.574804624,1,0,0,0,0
+863,0,0,0,0,0,0,0,0.576654614,0.994482469,0,0,0,0
+864,0,0,0,0,0,0,0,0.572399696,0.987807181,0,0,0,0
+865,0,0,0,0,0,0,0,0.570992768,0.983157165,0,0,0,0
+866,0,0,0,0,0,0,0,0.569291451,0.979826684,0,0,0,0
+867,0,0,0,0,0,0,0,0.571025201,0.975089851,0,0,0,0
+868,0,0,0,0,0,0,0,0.570861066,0.972818786,0,0,0,0
+869,0,0,0,0,0,0,0,0.572213154,0.966320275,0,0,0,0
+870,0,0,0,0,0,0,0,0.575418141,0.958195153,0,0,0,0
+871,0,0,0,0,0,0,0,0.577804028,0.941870745,0,0,0,0
+872,0,0,0,0,0,0,0,0.579603586,0.894185366,0,0,0,0
+873,0,0,0,0,0,0,0,0.579294979,0.778588669,0,0,0,0
+874,0,0,0,0,0,0,0,0.578302049,0.597362542,0,0,0,0
+875,0,0,0,0,0,0,0,0.57565598,0.377361257,0,0,0,0
+876,0,0,0,0,0,0,0,0.569721665,0.184667876,0,0,0,0
+877,0,0,0,0,0,0,0,0.561891364,0.079045495,0,0,0,0
+878,0,0,0,0,0,0,0,0.556830745,0.033393337,0,0,0,0
+879,0,0,0,0,0,0,0,0.549385012,0.015808546,0,0,0,0
+880,0,0,0,0,0,0,0,0.545858439,0.00162404,0,0,0,0
+881,0,0,0,0,0,0,0,0.542536249,0,0,0,0,0
+882,0,0,0,0,0,0,0,0.541895109,0,0,0,0,0
+883,0,0,0,0,0,0,0,0.539852497,0,0,0,0,0
+884,0,0,0,0,0,0,0,0.537997281,0,0,0,0,0
+885,0,0,0,0,0,0,0,0.53195493,0,0,0,0,0
+886,0,0,0,0,0,0,0,0.522275927,0,0,0,0,0
+887,0,0,0,0,0,0,0,0.505572421,0,0,0,0,0
+888,0,0,0,0,0,0,0,0.48804203,0,0,0,0,0
+889,0,0,0,0,0,0,0,0.469610434,0,0,0,0,0
+890,0,0,0,0,0,0,0,0.456107021,0,0,0,0,0
+891,0,0,0,0,0,0,0,0.445848869,0,0,0,0,0
+892,0,0,0,0,0,0,0,0.443119818,0,0,0,0,0
+893,0,0,0,0,0,0,0,0.445581498,0,0,0,0,0
+894,0,0,0,0,0,0,0,0.447532506,0,0,0,0,0
+895,0,0,0,0,0,0,0,0.440183411,0,0,0,0,0
+896,0,0,0,0,0,0,0,0.418240241,0,0,0,0,0
+897,0,0,0,0,0,0,0,0.369455837,0,0,0,0,0
+898,0,0,0,0,0,0,0,0.301788007,0,0,0,0,0
+899,0,0,0,0,0,0,0,0.235014942,0,0,0,0,0
+900,0,0,0,0,0,0,0,0.174244972,0,0,0,0,0
+901,0,0,0,0,0,0,0,0.122382945,0,0,0,0,0
+902,0,0,0,0,0,0,0,0.083462794,0,0,0,0,0
+903,0,0,0,0,0,0,0,0.056162189,0,0,0,0,0
+904,0,0,0,0,0,0,0,0.038006008,0,0,0,0,0
+905,0,0,0,0,0,0,0,0.024240249,0,0,0,0,0
+906,0,0,0,0,0,0,0,0.014845963,0,0,0,0,0
+907,0,0,0,0,0,0,0,0.006132899,0,0,0,0,0
+908,0,0,0,0,0,0,0,0,0,0,0,0,0
+909,0,0,0,0,0,0,0,0,0,0,0,0,0
+910,0,0,0,0,0,0,0,0,0,0,0,0,0
+911,0,0,0,0,0,0,0,0,0,0,0,0,0
+912,0,0,0,0,0,0,0,0,0,0,0,0,0
+913,0,0,0,0,0,0,0,0,0,0,0,0,0
+914,0,0,0,0,0,0,0,0,0,0,0,0,0
+915,0,0,0,0,0,0,0,0,0,0,0,0,0
+916,0,0,0,0,0,0,0,0,0,0,0,0,0
+917,0,0,0,0,0,0,0,0,0,0,0,0,0
+918,0,0,0,0,0,0,0,0,0,0,0,0,0
+919,0,0,0,0,0,0,0,0,0,0,0,0,0
+920,0,0,0,0,0,0,0,0,0,0,0,0,0
+921,0,0,0,0,0,0,0,0,0,0,0,0,0
+922,0,0,0,0,0,0,0,0,0,0,0,0,0
+923,0,0,0,0,0,0,0,0,0,0,0,0,0
+924,0,0,0,0,0,0,0,0,0,0,0,0,0
+925,0,0,0,0,0,0,0,0,0,0,0,0,0
+926,0,0,0,0,0,0,0,0,0,0,0,0,0
+927,0,0,0,0,0,0,0,0,0,0,0,0,0
+928,0,0,0,0,0,0,0,0,0,0,0,0,0
+929,0,0,0,0,0,0,0,0,0,0,0,0,0
+930,0,0,0,0,0,0,0,0,0,0.012121122,0,0,0
+931,0,0,0,0,0,0,0,0,0,0.046022418,0,0,0
+932,0,0,0,0,0,0,0,0,0,0.151408217,0,0,0
+933,0,0,0,0,0,0,0,0,0,0.358642184,0,0,0
+934,0,0,0,0,0,0,0,0,0,0.606574394,0,0,0
+935,0,0,0,0,0,0,0,0,0,0.837342317,0,0,0
+936,0,0,0,0,0,0,0,0,0,0.933378313,0,0,0
+937,0,0,0,0,0,0,0,0,0,0.941428569,0,0,0
+938,0,0,0,0,0,0,0,0,0,0.95729331,0,0,0
+939,0,0,0,0,0,0,0,0,0,0.989803625,0,0,0
+940,0,0,0,0,0,0,0,0,0,0.997444519,0,0,0
+941,0,0,0,0,0,0,0,0,0,1,0,0,0
+942,0,0,0,0,0,0,0,0,0,0.9863781,0,0,0
+943,0,0,0,0,0,0,0,0,0,0.974191899,0,0,0
+944,0,0,0,0,0,0,0,0,0,0.958968621,0,0,0
+945,0,0,0,0,0,0,0,0,0,0.973776634,0,0,0
+946,0,0,0,0,0,0,0,0,0,0.950411873,0,0,0
+947,0,0,0,0,0,0,0,0,0,0.94578786,0,0,0
+948,0,0,0,0,0,0,0,0,0,0.909973936,0,0,0
+949,0,0,0,0,0,0,0,0,0,0.887002674,0,0,0
+950,0,0,0,0,0,0,0,0,0,0.855135879,0,0,0
+951,0,0,0,0,0,0,0,0,0,0.836537904,0,0,0
+952,0,0,0,0,0,0,0,0,0,0.718536234,0,0,0
+953,0,0,0,0,0,0,0,0,0,0.52369103,0,0,0
+954,0,0,0,0,0,0,0,0,0,0.269748749,0,0,0
+955,0,0,0,0,0,0,0,0,0,0.09480081,0,0,0
+956,0,0,0,0,0,0,0,0,0,0.026387561,0,0,0
+957,0,0,0,0,0,0,0,0,0,0.003433415,0,0,0
+958,0,0,0,0,0,0,0,0,0,0,0,0,0
+959,0,0,0,0,0,0,0,0,0,0,0,0,0
+960,0,0,0,0,0,0,0,0,0,0,0,0,0
+961,0,0,0,0,0,0,0,0,0,0,0,0,0
+962,0,0,0,0,0,0,0,0,0,0,0,0,0
+963,0,0,0,0,0,0,0,0,0,0,0,0,0
+964,0,0,0,0,0,0,0,0,0,0,0,0,0
+965,0,0,0,0,0,0,0,0,0,0,0,0,0
+966,0,0,0,0,0,0,0,0,0,0,0,0,0
+967,0,0,0,0,0,0,0,0,0,0,0,0,0
+968,0,0,0,0,0,0,0,0,0,0,0,0,0
+969,0,0,0,0,0,0,0,0,0,0,0,0,0
+970,0,0,0,0,0,0,0,0,0,0,0,0,0
+971,0,0,0,0,0,0,0,0,0,0,0,0,0
+972,0,0,0,0,0,0,0,0,0,0,0,0,0
+973,0,0,0,0,0,0,0,0,0,0,0,0,0
+974,0,0,0,0,0,0,0,0,0,0,0,0,0
+975,0,0,0,0,0,0,0,0,0,0,0,0,0
+976,0,0,0,0,0,0,0,0,0,0,0,0,0
+977,0,0,0,0,0,0,0,0,0,0,0,0,0
+978,0,0,0,0,0,0,0,0,0,0,0,0,0
+979,0,0,0,0,0,0,0,0,0,0,0,0,0
+980,0,0,0,0,0,0,0,0,0,0,0,0,0
+981,0,0,0,0,0,0,0,0,0,0,0,0,0
+982,0,0,0,0,0,0,0,0,0,0,0,0,0
+983,0,0,0,0,0,0,0,0,0,0,0,0,0
+984,0,0,0,0,0,0,0,0,0,0,0,0,0
+985,0,0,0,0,0,0,0,0,0,0,0,0,0
+986,0,0,0,0,0,0,0,0,0,0,0,0,0
+987,0,0,0,0,0,0,0,0,0,0,0,0,0
+988,0,0,0,0,0,0,0,0,0,0,0,0,0
+989,0,0,0,0,0,0,0,0,0,0,0,0,0
+990,0,0,0,0,0,0,0,0,0,0,0,0,0
+991,0,0,0,0,0,0,0,0,0,0,0,0,0
+992,0,0,0,0,0,0,0,0,0,0,0,0,0
+993,0,0,0,0,0,0,0,0,0,0,0,0,0
+994,0,0,0,0,0,0,0,0,0,0,0,0,0
+995,0,0,0,0,0,0,0,0,0,0,0,0,0
+996,0,0,0,0,0,0,0,0,0,0,0,0,0
+997,0,0,0,0,0,0,0,0,0,0,0,0,0
+998,0,0,0,0,0,0,0,0,0,0,0,0,0
+999,0,0,0,0,0,0,0,0,0,0,0,0,0
+1000,0,0,0,0,0,0,0,0,0,0,0,0,0
+1001,0,0,0,0,0,0,0,0,0,0,0,0,0
+1002,0,0,0,0,0,0,0,0,0,0,0,0,0
+1003,0,0,0,0,0,0,0,0,0,0,0,0,0
+1004,0,0,0,0,0,0,0,0,0,0,0,0,0
+1005,0,0,0,0,0,0,0,0,0,0,0,0,0
+1006,0,0,0,0,0,0,0,0,0,0,0,0,0
+1007,0,0,0,0,0,0,0,0,0,0,0,0,0
+1008,0,0,0,0,0,0,0,0,0,0,0,0,0
+1009,0,0,0,0,0,0,0,0,0,0,0,0,0
+1010,0,0,0,0,0,0,0,0,0,0,0,0,0
+1011,0,0,0,0,0,0,0,0,0,0,0,0,0
+1012,0,0,0,0,0,0,0,0,0,0,0,0,0
+1013,0,0,0,0,0,0,0,0,0,0,0,0,0
+1014,0,0,0,0,0,0,0,0,0,0,0,0,0
+1015,0,0,0,0,0,0,0,0,0,0,0,0,0
+1016,0,0,0,0,0,0,0,0,0,0,0,0,0
+1017,0,0,0,0,0,0,0,0,0,0,0,0,0
+1018,0,0,0,0,0,0,0,0,0,0,0,0,0
+1019,0,0,0,0,0,0,0,0,0,0,0,0,0
+1020,0,0,0,0,0,0,0,0,0,0,0,0,0
+1021,0,0,0,0,0,0,0,0,0,0,0,0,0
+1022,0,0,0,0,0,0,0,0,0,0,0,0,0
+1023,0,0,0,0,0,0,0,0,0,0,0,0,0
+1024,0,0,0,0,0,0,0,0,0,0,0,0,0
+1025,0,0,0,0,0,0,0,0,0,0,0,0,0
+1026,0,0,0,0,0,0,0,0,0,0,0,0,0
+1027,0,0,0,0,0,0,0,0,0,0,0,0,0
+1028,0,0,0,0,0,0,0,0,0,0,0,0,0
+1029,0,0,0,0,0,0,0,0,0,0,0,0,0
+1030,0,0,0,0,0,0,0,0,0,0,0,0,0
+1031,0,0,0,0,0,0,0,0,0,0,0,0,0
+1032,0,0,0,0,0,0,0,0,0,0,0,0,0
+1033,0,0,0,0,0,0,0,0,0,0,0,0,0
+1034,0,0,0,0,0,0,0,0,0,0,0,0,0
+1035,0,0,0,0,0,0,0,0,0,0,0,0,0
+1036,0,0,0,0,0,0,0,0,0,0,0,0,0
+1037,0,0,0,0,0,0,0,0,0,0,0,0,0
+1038,0,0,0,0,0,0,0,0,0,0,0,0,0
+1039,0,0,0,0,0,0,0,0,0,0,0,0,0
+1040,0,0,0,0,0,0,0,0,0,0,0,0,0
+1041,0,0,0,0,0,0,0,0,0,0,0,0,0
+1042,0,0,0,0,0,0,0,0,0,0,0,0,0
+1043,0,0,0,0,0,0,0,0,0,0,0,0,0
+1044,0,0,0,0,0,0,0,0,0,0,0,0,0
+1045,0,0,0,0,0,0,0,0,0,0,0,0,0
+1046,0,0,0,0,0,0,0,0,0,0,0,0,0
+1047,0,0,0,0,0,0,0,0,0,0,0,0,0
+1048,0,0,0,0,0,0,0,0,0,0,0,0,0
+1049,0,0,0,0,0,0,0,0,0,0,0,0,0
+1050,0,0,0,0,0,0,0,0,0,0,0,0,0
+1051,0,0,0,0,0,0,0,0,0,0,0,0,0
+1052,0,0,0,0,0,0,0,0,0,0,0,0,0
+1053,0,0,0,0,0,0,0,0,0,0,0,0,0
+1054,0,0,0,0,0,0,0,0,0,0,0,0,0
+1055,0,0,0,0,0,0,0,0,0,0,0,0,0
+1056,0,0,0,0,0,0,0,0,0,0,0,0,0
+1057,0,0,0,0,0,0,0,0,0,0,0,0,0
+1058,0,0,0,0,0,0,0,0,0,0,0,0,0
+1059,0,0,0,0,0,0,0,0,0,0,0,0,0
+1060,0,0,0,0,0,0,0,0,0,0,0,0,0
+1061,0,0,0,0,0,0,0,0,0,0,0,0,0
+1062,0,0,0,0,0,0,0,0,0,0,0,0,0
+1063,0,0,0,0,0,0,0,0,0,0,0,0,0
+1064,0,0,0,0,0,0,0,0,0,0,0,0,0
+1065,0,0,0,0,0,0,0,0,0,0,0,0,0
+1066,0,0,0,0,0,0,0,0,0,0,0,0,0
+1067,0,0,0,0,0,0,0,0,0,0,0,0,0
+1068,0,0,0,0,0,0,0,0,0,0,0,0,0
+1069,0,0,0,0,0,0,0,0,0,0,0,0,0
+1070,0,0,0,0,0,0,0,0,0,0,0,0,0
+1071,0,0,0,0,0,0,0,0,0,0,0,0,0
+1072,0,0,0,0,0,0,0,0,0,0,0,0,0
+1073,0,0,0,0,0,0,0,0,0,0,0,0,0
+1074,0,0,0,0,0,0,0,0,0,0,0,0,0
+1075,0,0,0,0,0,0,0,0,0,0,0,0,0
+1076,0,0,0,0,0,0,0,0,0,0,0,0,0
+1077,0,0,0,0,0,0,0,0,0,0,0,0,0
+1078,0,0,0,0,0,0,0,0,0,0,0,0,0
+1079,0,0,0,0,0,0,0,0,0,0,0,0,0
+1080,0,0,0,0,0,0,0,0,0,0,0,0,0
+1081,0,0,0,0,0,0,0,0,0,0,0,0,0
+1082,0,0,0,0,0,0,0,0,0,0,0,0,0
+1083,0,0,0,0,0,0,0,0,0,0,0,0,0
+1084,0,0,0,0,0,0,0,0,0,0,0,0,0
+1085,0,0,0,0,0,0,0,0,0,0,0,0,0
+1086,0,0,0,0,0,0,0,0,0,0,0,0,0
+1087,0,0,0,0,0,0,0,0,0,0,0,0,0
+1088,0,0,0,0,0,0,0,0,0,0,0,0,0
+1089,0,0,0,0,0,0,0,0,0,0,0,0,0
+1090,0,0,0,0,0,0,0,0,0,0,0,0,0
+1091,0,0,0,0,0,0,0,0,0,0,0,0,0
+1092,0,0,0,0,0,0,0,0,0,0,0,0,0
+1093,0,0,0,0,0,0,0,0,0,0,0,0,0
+1094,0,0,0,0,0,0,0,0,0,0,0,0,0
+1095,0,0,0,0,0,0,0,0,0,0,0,0,0
+1096,0,0,0,0,0,0,0,0,0,0,0,0,0
+1097,0,0,0,0,0,0,0,0,0,0,0,0,0
+1098,0,0,0,0,0,0,0,0,0,0,0,0,0
+1099,0,0,0,0,0,0,0,0,0,0,0,0,0
+1100,0,0,0,0,0,0,0,0,0,0,0,0,0
+1101,0,0,0,0,0,0,0,0,0,0,0,0,0
+1102,0,0,0,0,0,0,0,0,0,0,0,0,0
+1103,0,0,0,0,0,0,0,0,0,0,0,0,0
+1104,0,0,0,0,0,0,0,0,0,0,0,0,0
+1105,0,0,0,0,0,0,0,0,0,0,0,0,0
+1106,0,0,0,0,0,0,0,0,0,0,0,0,0
+1107,0,0,0,0,0,0,0,0,0,0,0,0,0
+1108,0,0,0,0,0,0,0,0,0,0,0,0,0
+1109,0,0,0,0,0,0,0,0,0,0,0,0,0
+1110,0,0,0,0,0,0,0,0,0,0,0,0,0
+1111,0,0,0,0,0,0,0,0,0,0,0,0,0
+1112,0,0,0,0,0,0,0,0,0,0,0,0,0
+1113,0,0,0,0,0,0,0,0,0,0,0,0,0
+1114,0,0,0,0,0,0,0,0,0,0,0,0,0
+1115,0,0,0,0,0,0,0,0,0,0,0,0,0
+1116,0,0,0,0,0,0,0,0,0,0,0,0,0
+1117,0,0,0,0,0,0,0,0,0,0,0,0,0
+1118,0,0,0,0,0,0,0,0,0,0,0,0,0
+1119,0,0,0,0,0,0,0,0,0,0,0,0,0
+1120,0,0,0,0,0,0,0,0,0,0,0,0,0
+1121,0,0,0,0,0,0,0,0,0,0,0,0,0
+1122,0,0,0,0,0,0,0,0,0,0,0,0,0
+1123,0,0,0,0,0,0,0,0,0,0,0,0,0
+1124,0,0,0,0,0,0,0,0,0,0,0,0,0
+1125,0,0,0,0,0,0,0,0,0,0,0,0,0
+1126,0,0,0,0,0,0,0,0,0,0,0,0,0
+1127,0,0,0,0,0,0,0,0,0,0,0,0,0
+1128,0,0,0,0,0,0,0,0,0,0,0,0,0
+1129,0,0,0,0,0,0,0,0,0,0,0,0,0
+1130,0,0,0,0,0,0,0,0,0,0,0,0,0
+1131,0,0,0,0,0,0,0,0,0,0,0,0,0
+1132,0,0,0,0,0,0,0,0,0,0,0,0,0
+1133,0,0,0,0,0,0,0,0,0,0,0,0,0
+1134,0,0,0,0,0,0,0,0,0,0,0,0,0
+1135,0,0,0,0,0,0,0,0,0,0,0,0,0
+1136,0,0,0,0,0,0,0,0,0,0,0,0,0
+1137,0,0,0,0,0,0,0,0,0,0,0,0,0
+1138,0,0,0,0,0,0,0,0,0,0,0,0,0
+1139,0,0,0,0,0,0,0,0,0,0,0,0,0
+1140,0,0,0,0,0,0,0,0,0,0,0,0,0
+1141,0,0,0,0,0,0,0,0,0,0,0,0,0
+1142,0,0,0,0,0,0,0,0,0,0,0,0,0
+1143,0,0,0,0,0,0,0,0,0,0,0,0,0
+1144,0,0,0,0,0,0,0,0,0,0,0,0,0
+1145,0,0,0,0,0,0,0,0,0,0,0,0,0
+1146,0,0,0,0,0,0,0,0,0,0,0,0,0
+1147,0,0,0,0,0,0,0,0,0,0,0,0,0
+1148,0,0,0,0,0,0,0,0,0,0,0,0,0
+1149,0,0,0,0,0,0,0,0,0,0,0,0,0
+1150,0,0,0,0,0,0,0,0,0,0,0,0,0
+1151,0,0,0,0,0,0,0,0,0,0,0,0,0
+1152,0,0,0,0,0,0,0,0,0,0,0,0,0
+1153,0,0,0,0,0,0,0,0,0,0,0,0,0
+1154,0,0,0,0,0,0,0,0,0,0,0,0,0
+1155,0,0,0,0,0,0,0,0,0,0,0,0,0
+1156,0,0,0,0,0,0,0,0,0,0,0,0,0
+1157,0,0,0,0,0,0,0,0,0,0,0,0,0
+1158,0,0,0,0,0,0,0,0,0,0,0,0,0
+1159,0,0,0,0,0,0,0,0,0,0,0,0,0
+1160,0,0,0,0,0,0,0,0,0,0,0,0,0
+1161,0,0,0,0,0,0,0,0,0,0,0,0,0
+1162,0,0,0,0,0,0,0,0,0,0,0,0,0
+1163,0,0,0,0,0,0,0,0,0,0,0,0,0
+1164,0,0,0,0,0,0,0,0,0,0,0,0,0
+1165,0,0,0,0,0,0,0,0,0,0,0,0,0
+1166,0,0,0,0,0,0,0,0,0,0,0,0,0
+1167,0,0,0,0,0,0,0,0,0,0,0,0,0
+1168,0,0,0,0,0,0,0,0,0,0,0,0,0
+1169,0,0,0,0,0,0,0,0,0,0,0,0,0
+1170,0,0,0,0,0,0,0,0,0,0,0,0,0
+1171,0,0,0,0,0,0,0,0,0,0,0,0,0
+1172,0,0,0,0,0,0,0,0,0,0,0,0,0
+1173,0,0,0,0,0,0,0,0,0,0,0,0,0
+1174,0,0,0,0,0,0,0,0,0,0,0,0,0
+1175,0,0,0,0,0,0,0,0,0,0,0,0,0
+1176,0,0,0,0,0,0,0,0,0,0,0,0,0
+1177,0,0,0,0,0,0,0,0,0,0,0,0,0
+1178,0,0,0,0,0,0,0,0,0,0,0,0,0
+1179,0,0,0,0,0,0,0,0,0,0,0,0,0
+1180,0,0,0,0,0,0,0,0,0,0,0,0,0
+1181,0,0,0,0,0,0,0,0,0,0,0,0,0
+1182,0,0,0,0,0,0,0,0,0,0,0,0,0
+1183,0,0,0,0,0,0,0,0,0,0,0,0,0
+1184,0,0,0,0,0,0,0,0,0,0,0,0,0
+1185,0,0,0,0,0,0,0,0,0,0,0,0,0
+1186,0,0,0,0,0,0,0,0,0,0,0,0,0
+1187,0,0,0,0,0,0,0,0,0,0,0,0,0
+1188,0,0,0,0,0,0,0,0,0,0,0,0,0
+1189,0,0,0,0,0,0,0,0,0,0,0,0,0
+1190,0,0,0,0,0,0,0,0,0,0,0,0,0
+1191,0,0,0,0,0,0,0,0,0,0,0,0,0
+1192,0,0,0,0,0,0,0,0,0,0,0,0,0
+1193,0,0,0,0,0,0,0,0,0,0,0,0,0
+1194,0,0,0,0,0,0,0,0,0,0,0,0,0
+1195,0,0,0,0,0,0,0,0,0,0,0,0,0
+1196,0,0,0,0,0,0,0,0,0,0,0,0,0
+1197,0,0,0,0,0,0,0,0,0,0,0,0,0
+1198,0,0,0,0,0,0,0,0,0,0,0,0,0
+1199,0,0,0,0,0,0,0,0,0,0,0,0,0
+1200,0,0,0,0,0,0,0,0,0,0,0,0,0
+1201,0,0,0,0,0,0,0,0,0,0,0,0,0
+1202,0,0,0,0,0,0,0,0,0,0,0,0,0
+1203,0,0,0,0,0,0,0,0,0,0,0,0,0
+1204,0,0,0,0,0,0,0,0,0,0,0,0,0
+1205,0,0,0,0,0,0,0,0,0,0,0,0,0
+1206,0,0,0,0,0,0,0,0,0,0,0,0,0
+1207,0,0,0,0,0,0,0,0,0,0,0,0,0
+1208,0,0,0,0,0,0,0,0,0,0,0,0,0
+1209,0,0,0,0,0,0,0,0,0,0,0,0,0
+1210,0,0,0,0,0,0,0,0,0,0,0,0,0
+1211,0,0,0,0,0,0,0,0,0,0,0,0,0
+1212,0,0,0,0,0,0,0,0,0,0,0,0,0
+1213,0,0,0,0,0,0,0,0,0,0,0,0,0
+1214,0,0,0,0,0,0,0,0,0,0,0,0,0
+1215,0,0,0,0,0,0,0,0,0,0,0,0,0
+1216,0,0,0,0,0,0,0,0,0,0,0,0,0
+1217,0,0,0,0,0,0,0,0,0,0,0,0,0
+1218,0,0,0,0,0,0,0,0,0,0,0,0,0
+1219,0,0,0,0,0,0,0,0,0,0,0,0,0
+1220,0,0,0,0,0,0,0,0,0,0,0,0,0
+1221,0,0,0,0,0,0,0,0,0,0,0,0,0
+1222,0,0,0,0,0,0,0,0,0,0,0,0,0
+1223,0,0,0,0,0,0,0,0,0,0,0,0,0
+1224,0,0,0,0,0,0,0,0,0,0,0,0,0
+1225,0,0,0,0,0,0,0,0,0,0,0,0,0
+1226,0,0,0,0,0,0,0,0,0,0,0,0,0
+1227,0,0,0,0,0,0,0,0,0,0,0,0,0
+1228,0,0,0,0,0,0,0,0,0,0,0,0,0
+1229,0,0,0,0,0,0,0,0,0,0,0,0,0
+1230,0,0,0,0,0,0,0,0,0,0,0,0,0
+1231,0,0,0,0,0,0,0,0,0,0,0,0,0
+1232,0,0,0,0,0,0,0,0,0,0,0,0,0
+1233,0,0,0,0,0,0,0,0,0,0,0,0,0
+1234,0,0,0,0,0,0,0,0,0,0,0,0,0
+1235,0,0,0,0,0,0,0,0,0,0,0,0,0
+1236,0,0,0,0,0,0,0,0,0,0,0,0,0
+1237,0,0,0,0,0,0,0,0,0,0,0,0,0
+1238,0,0,0,0,0,0,0,0,0,0,0,0,0
+1239,0,0,0,0,0,0,0,0,0,0,0,0,0
+1240,0,0,0,0,0,0,0,0,0,0,0,0,0
+1241,0,0,0,0,0,0,0,0,0,0,0,0,0
+1242,0,0,0,0,0,0,0,0,0,0,0,0,0
+1243,0,0,0,0,0,0,0,0,0,0,0,0,0
+1244,0,0,0,0,0,0,0,0,0,0,0,0,0
+1245,0,0,0,0,0,0,0,0,0,0,0,0,0
+1246,0,0,0,0,0,0,0,0,0,0,0,0,0
+1247,0,0,0,0,0,0,0,0,0,0,0,0,0
+1248,0,0,0,0,0,0,0,0,0,0,0,0,0
+1249,0,0,0,0,0,0,0,0,0,0,0,0,0
+1250,0,0,0,0,0,0,0,0,0,0,0,0,0
+1251,0,0,0,0,0,0,0,0,0,0,0,0,0
+1252,0,0,0,0,0,0,0,0,0,0,0,0,0
+1253,0,0,0,0,0,0,0,0,0,0,0,0,0
+1254,0,0,0,0,0,0,0,0,0,0,0,0,0
+1255,0,0,0,0,0,0,0,0,0,0,0,0,0
+1256,0,0,0,0,0,0,0,0,0,0,0,0,0
+1257,0,0,0,0,0,0,0,0,0,0,0,0,0
+1258,0,0,0,0,0,0,0,0,0,0,0,0,0
+1259,0,0,0,0,0,0,0,0,0,0,0,0,0
+1260,0,0,0,0,0,0,0,0,0,0,0,0,0
+1261,0,0,0,0,0,0,0,0,0,0,0,0,0
+1262,0,0,0,0,0,0,0,0,0,0,0,0,0
+1263,0,0,0,0,0,0,0,0,0,0,0,0,0
+1264,0,0,0,0,0,0,0,0,0,0,0,0,0
+1265,0,0,0,0,0,0,0,0,0,0,0,0,0
+1266,0,0,0,0,0,0,0,0,0,0,0,0,0
+1267,0,0,0,0,0,0,0,0,0,0,0,0,0
+1268,0,0,0,0,0,0,0,0,0,0,0,0,0
+1269,0,0,0,0,0,0,0,0,0,0,0,0,0
+1270,0,0,0,0,0,0,0,0,0,0,0,0,0
+1271,0,0,0,0,0,0,0,0,0,0,0,0,0
+1272,0,0,0,0,0,0,0,0,0,0,0,0,0
+1273,0,0,0,0,0,0,0,0,0,0,0,0,0
+1274,0,0,0,0,0,0,0,0,0,0,0,0,0
+1275,0,0,0,0,0,0,0,0,0,0,0,0,0
+1276,0,0,0,0,0,0,0,0,0,0,0,0,0
+1277,0,0,0,0,0,0,0,0,0,0,0,0,0
+1278,0,0,0,0,0,0,0,0,0,0,0,0,0
+1279,0,0,0,0,0,0,0,0,0,0,0,0,0
+1280,0,0,0,0,0,0,0,0,0,0,0,0,0
+1281,0,0,0,0,0,0,0,0,0,0,0,0,0
+1282,0,0,0,0,0,0,0,0,0,0,0,0,0
+1283,0,0,0,0,0,0,0,0,0,0,0,0,0
+1284,0,0,0,0,0,0,0,0,0,0,0,0,0
+1285,0,0,0,0,0,0,0,0,0,0,0,0,0
+1286,0,0,0,0,0,0,0,0,0,0,0,0,0
+1287,0,0,0,0,0,0,0,0,0,0,0,0,0
+1288,0,0,0,0,0,0,0,0,0,0,0,0,0
+1289,0,0,0,0,0,0,0,0,0,0,0,0,0
+1290,0,0,0,0,0,0,0,0,0,0,0,0,0
+1291,0,0,0,0,0,0,0,0,0,0,0,0,0
+1292,0,0,0,0,0,0,0,0,0,0,0,0,0
+1293,0,0,0,0,0,0,0,0,0,0,0,0,0
+1294,0,0,0,0,0,0,0,0,0,0,0,0,0
+1295,0,0,0,0,0,0,0,0,0,0,0,0,0
+1296,0,0,0,0,0,0,0,0,0,0,0,0,0
+1297,0,0,0,0,0,0,0,0,0,0,0,0,0
+1298,0,0,0,0,0,0,0,0,0,0,0,0,0
+1299,0,0,0,0,0,0,0,0,0,0,0,0,0
+1300,0,0,0,0,0,0,0,0,0,0,0,0,0
+1301,0,0,0,0,0,0,0,0,0,0,0,0,0
+1302,0,0,0,0,0,0,0,0,0,0,0,0,0
+1303,0,0,0,0,0,0,0,0,0,0,0,0,0
+1304,0,0,0,0,0,0,0,0,0,0,0,0,0
+1305,0,0,0,0,0,0,0,0,0,0,0,0,0
+1306,0,0,0,0,0,0,0,0,0,0,0,0,0
+1307,0,0,0,0,0,0,0,0,0,0,0,0,0
+1308,0,0,0,0,0,0,0,0,0,0,0,0,0
+1309,0,0,0,0,0,0,0,0,0,0,0,0,0
+1310,0,0,0,0,0,0,0,0,0,0,0,0,0
+1311,0,0,0,0,0,0,0,0,0,0,0,0,0
+1312,0,0,0,0,0,0,0,0,0,0,0,0,0
+1313,0,0,0,0,0,0,0,0,0,0,0,0,0
+1314,0,0,0,0,0,0,0,0,0,0,0,0,0
+1315,0,0,0,0,0,0,0,0,0,0,0,0,0
+1316,0,0,0,0,0,0,0,0,0,0,0,0,0
+1317,0,0,0,0,0,0,0,0,0,0,0,0,0
+1318,0,0,0,0,0,0,0,0,0,0,0,0,0
+1319,0,0,0,0,0,0,0,0,0,0,0,0,0
+1320,0,0,0,0,0,0,0,0,0,0,0,0,0
+1321,0,0,0,0,0,0,0,0,0,0,0,0,0
+1322,0,0,0,0,0,0,0,0,0,0,0,0,0
+1323,0,0,0,0,0,0,0,0,0,0,0,0,0
+1324,0,0,0,0,0,0,0,0,0,0,0,0,0
+1325,0,0,0,0,0,0,0,0,0,0,0,0,0
+1326,0,0,0,0,0,0,0,0,0,0,0,0,0
+1327,0,0,0,0,0,0,0,0,0,0,0,0,0
+1328,0,0,0,0,0,0,0,0,0,0,0,0,0
+1329,0,0,0,0,0,0,0,0,0,0,0,0,0
+1330,0,0,0,0,0,0,0,0,0,0,0,0,0
+1331,0,0,0,0,0,0,0,0,0,0,0,0,0
+1332,0,0,0,0,0,0,0,0,0,0,0,0,0
+1333,0,0,0,0,0,0,0,0,0,0,0,0,0
+1334,0,0,0,0,0,0,0,0,0,0,0,0,0
+1335,0,0,0,0,0,0,0,0,0,0,0,0,0
+1336,0,0,0,0,0,0,0,0,0,0,0,0,0
+1337,0,0,0,0,0,0,0,0,0,0,0,0,0
+1338,0,0,0,0,0,0,0,0,0,0,0,0,0
+1339,0,0,0,0,0,0,0,0,0,0,0.000024519,0,0
+1340,0,0,0,0,0,0,0,0,0,0,0.000136201,0,0
+1341,0,0,0,0,0,0,0,0,0,0,0.000124629,0,0
+1342,0,0,0,0,0,0,0,0,0,0,0.000088936,0,0
+1343,0,0,0,0,0,0,0,0,0,0,0.000124168,0,0
+1344,0,0,0,0,0,0,0,0,0,0,0.000099355,0,0
+1345,0,0,0,0,0,0,0,0,0,0,0.000139099,0,0
+1346,0,0,0,0,0,0,0,0,0,0,0.000157557,0,0
+1347,0,0,0,0,0,0,0,0,0,0,0.000192392,0,0
+1348,0,0,0,0,0,0,0,0,0,0,0.00025967,0,0
+1349,0,0,0,0,0,0,0,0,0,0,0.000322212,0,0
+1350,0,0,0,0,0,0,0,0,0,0,0.00034665,0,0
+1351,0,0,0,0,0,0,0,0,0,0,0.000368979,0,0
+1352,0,0,0,0,0,0,0,0,0,0,0.000547142,0,0
+1353,0,0,0,0,0,0,0,0,0,0,0.001050938,0,0
+1354,0,0,0,0,0,0,0,0,0,0,0.00218105,0,0
+1355,0,0,0,0,0,0,0,0,0,0,0.004790717,0,0
+1356,0,0,0,0,0,0,0,0,0,0,0.011310302,0,0
+1357,0,0,0,0,0,0,0,0,0,0,0.026613248,0,0
+1358,0,0,0,0,0,0,0,0,0,0,0.057559739,0,0
+1359,0,0,0,0,0,0,0,0,0,0,0.111412066,0,0
+1360,0,0,0,0,0,0,0,0,0,0,0.19534134,0,0
+1361,0,0,0,0,0,0,0,0,0,0,0.313481067,0,0
+1362,0,0,0,0,0,0,0,0,0,0,0.461097437,0,0
+1363,0,0,0,0,0,0,0,0,0,0,0.6221953,0,0
+1364,0,0,0,0,0,0,0,0,0,0,0.770430827,0,0
+1365,0,0,0,0,0,0,0,0,0,0,0.880535922,0,0
+1366,0,0,0,0,0,0,0,0,0,0,0.944739275,0,0
+1367,0,0,0,0,0,0,0,0,0,0,0.97397875,0,0
+1368,0,0,0,0,0,0,0,0,0,0,0.98611756,0,0
+1369,0,0,0,0,0,0,0,0,0,0,0.993032255,0,0
+1370,0,0,0,0,0,0,0,0,0,0,0.997734947,0,0
+1371,0,0,0,0,0,0,0,0,0,0,1,0,0
+1372,0,0,0,0,0,0,0,0,0,0,0.999440391,0,0
+1373,0,0,0,0,0,0,0,0,0,0,0.996198129,0,0
+1374,0,0,0,0,0,0,0,0,0,0,0.990856204,0,0
+1375,0,0,0,0,0,0,0,0,0,0,0.984248642,0,0
+1376,0,0,0,0,0,0,0,0,0,0,0.977116358,0,0
+1377,0,0,0,0,0,0,0,0,0,0,0.970164279,0,0
+1378,0,0,0,0,0,0,0,0,0,0,0.963770069,0,0
+1379,0,0,0,0,0,0,0,0,0,0,0.957577366,0,0
+1380,0,0,0,0,0,0,0,0,0,0,0.951303557,0,0
+1381,0,0,0,0,0,0,0,0,0,0,0.945493586,0,0
+1382,0,0,0,0,0,0,0,0,0,0,0.940718335,0,0
+1383,0,0,0,0,0,0,0,0,0,0,0.937614311,0,0
+1384,0,0,0,0,0,0,0,0,0,0,0.936274454,0,0
+1385,0,0,0,0,0,0,0,0,0,0,0.935168115,0,0
+1386,0,0,0,0,0,0,0,0,0,0,0.930686598,0,0
+1387,0,0,0,0,0,0,0,0,0,0,0.916569659,0,0
+1388,0,0,0,0,0,0,0,0,0,0,0.885721386,0,0
+1389,0,0,0,0,0,0,0,0,0,0,0.831894981,0,0
+1390,0,0,0,0,0,0,0,0,0,0,0.749343254,0,0
+1391,0,0,0,0,0,0,0,0,0,0,0.636158996,0,0
+1392,0,0,0,0,0,0,0,0,0,0,0.498288066,0,0
+1393,0,0,0,0,0,0,0,0,0,0,0.349944188,0,0
+1394,0,0,0,0,0,0,0,0,0,0,0.21325372,0,0
+1395,0,0,0,0,0,0,0,0,0,0,0.110112562,0,0
+1396,0,0,0,0,0,0,0,0,0,0,0.048081597,0,0
+1397,0,0,0,0,0,0,0,0,0,0,0.018603066,0,0
+1398,0,0,0,0,0,0,0,0,0,0,0.007193874,0,0
+1399,0,0,0,0,0,0,0,0,0,0,0.003163765,0,0
+1400,0,0,0,0,0,0,0,0,0,0,0.001575442,0,0
+1401,0,0,0,0,0,0,0,0,0,0,0.000851825,0,0
+1402,0,0,0,0,0,0,0,0,0,0,0.000531218,0,0
+1403,0,0,0,0,0,0,0,0,0,0,0.00033209,0,0
+1404,0,0,0,0,0,0,0,0,0,0,0.000194334,0,0
+1405,0,0,0,0,0,0,0,0,0,0,0.000220804,0,0
+1406,0,0,0,0,0,0,0,0,0,0,0.000226309,0,0
+1407,0,0,0,0,0,0,0,0,0,0,0.000181374,0,0
+1408,0,0,0,0,0,0,0,0,0,0,0.000160139,0,0
+1409,0,0,0,0,0,0,0,0,0,0,0.000154509,0,0
+1410,0,0,0,0,0,0,0,0,0,0,0.000147455,0,0
+1411,0,0,0,0,0,0,0,0,0,0,0.000147793,0,0
+1412,0,0,0,0,0,0,0,0,0,0,0.000174384,0,0
+1413,0,0,0,0,0,0,0,0,0,0,0.000234351,0,0
+1414,0,0,0,0,0,0,0,0,0,0,0.000119559,0,0
+1415,0,0,0,0,0,0,0,0,0,0,0.000043811,0,0
+1416,0,0,0,0,0,0,0,0,0,0,0,0,0
+1417,0,0,0,0,0,0,0,0,0,0,0,0,0
+1418,0,0,0,0,0,0,0,0,0,0,0,0,0
+1419,0,0,0,0,0,0,0,0,0,0,0,0,0
+1420,0,0,0,0,0,0,0,0,0,0,0,0,0
+1421,0,0,0,0,0,0,0,0,0,0,0,0,0
+1422,0,0,0,0,0,0,0,0,0,0,0,0,0
+1423,0,0,0,0,0,0,0,0,0,0,0,0,0
+1424,0,0,0,0,0,0,0,0,0,0,0,0,0
+1425,0,0,0,0,0,0,0,0,0,0,0,0,0
+1426,0,0,0,0,0,0,0,0,0,0,0,0,0
+1427,0,0,0,0,0,0,0,0,0,0,0,0,0
+1428,0,0,0,0,0,0,0,0,0,0,0,0,0
+1429,0,0,0,0,0,0,0,0,0,0,0,0,0
+1430,0,0,0,0,0,0,0,0,0,0,0,0,0
+1431,0,0,0,0,0,0,0,0,0,0,0,0,0
+1432,0,0,0,0,0,0,0,0,0,0,0,0,0
+1433,0,0,0,0,0,0,0,0,0,0,0,0,0
+1434,0,0,0,0,0,0,0,0,0,0,0,0,0
+1435,0,0,0,0,0,0,0,0,0,0,0,0,0
+1436,0,0,0,0,0,0,0,0,0,0,0,0,0
+1437,0,0,0,0,0,0,0,0,0,0,0,0,0
+1438,0,0,0,0,0,0,0,0,0,0,0,0,0
+1439,0,0,0,0,0,0,0,0,0,0,0,0,0
+1440,0,0,0,0,0,0,0,0,0,0,0,0,0
+1441,0,0,0,0,0,0,0,0,0,0,0,0,0
+1442,0,0,0,0,0,0,0,0,0,0,0,0,0
+1443,0,0,0,0,0,0,0,0,0,0,0,0,0
+1444,0,0,0,0,0,0,0,0,0,0,0,0,0
+1445,0,0,0,0,0,0,0,0,0,0,0,0,0
+1446,0,0,0,0,0,0,0,0,0,0,0,0,0
+1447,0,0,0,0,0,0,0,0,0,0,0,0,0
+1448,0,0,0,0,0,0,0,0,0,0,0,0,0
+1449,0,0,0,0,0,0,0,0,0,0,0,0,0
+1450,0,0,0,0,0,0,0,0,0,0,0,0,0
+1451,0,0,0,0,0,0,0,0,0,0,0,0,0
+1452,0,0,0,0,0,0,0,0,0,0,0,0,0
+1453,0,0,0,0,0,0,0,0,0,0,0,0,0
+1454,0,0,0,0,0,0,0,0,0,0,0,0,0
+1455,0,0,0,0,0,0,0,0,0,0,0,0,0
+1456,0,0,0,0,0,0,0,0,0,0,0,0,0
+1457,0,0,0,0,0,0,0,0,0,0,0,0,0
+1458,0,0,0,0,0,0,0,0,0,0,0,0,0
+1459,0,0,0,0,0,0,0,0,0,0,0,0,0
+1460,0,0,0,0,0,0,0,0,0,0,0,0,0
+1461,0,0,0,0,0,0,0,0,0,0,0,0,0
+1462,0,0,0,0,0,0,0,0,0,0,0,0,0
+1463,0,0,0,0,0,0,0,0,0,0,0,0,0
+1464,0,0,0,0,0,0,0,0,0,0,0,0,0
+1465,0,0,0,0,0,0,0,0,0,0,0,0,0
+1466,0,0,0,0,0,0,0,0,0,0,0,0,0
+1467,0,0,0,0,0,0,0,0,0,0,0,0,0
+1468,0,0,0,0,0,0,0,0,0,0,0,0,0
+1469,0,0,0,0,0,0,0,0,0,0,0,0,0
+1470,0,0,0,0,0,0,0,0,0,0,0,0,0
+1471,0,0,0,0,0,0,0,0,0,0,0,0,0
+1472,0,0,0,0,0,0,0,0,0,0,0,0,0
+1473,0,0,0,0,0,0,0,0,0,0,0,0,0
+1474,0,0,0,0,0,0,0,0,0,0,0,0,0
+1475,0,0,0,0,0,0,0,0,0,0,0,0,0
+1476,0,0,0,0,0,0,0,0,0,0,0,0,0
+1477,0,0,0,0,0,0,0,0,0,0,0,0,0
+1478,0,0,0,0,0,0,0,0,0,0,0,0,0
+1479,0,0,0,0,0,0,0,0,0,0,0,0,0
+1480,0,0,0,0,0,0,0,0,0,0,0,0,0
+1481,0,0,0,0,0,0,0,0,0,0,0,0,0
+1482,0,0,0,0,0,0,0,0,0,0,0,0,0
+1483,0,0,0,0,0,0,0,0,0,0,0,0,0
+1484,0,0,0,0,0,0,0,0,0,0,0,0,0
+1485,0,0,0,0,0,0,0,0,0,0,0,0,0
+1486,0,0,0,0,0,0,0,0,0,0,0,0,0
+1487,0,0,0,0,0,0,0,0,0,0,0,0,0
+1488,0,0,0,0,0,0,0,0,0,0,0,0,0
+1489,0,0,0,0,0,0,0,0,0,0,0,0,0
+1490,0,0,0,0,0,0,0,0,0,0,0,0,0
+1491,0,0,0,0,0,0,0,0,0,0,0,0,0
+1492,0,0,0,0,0,0,0,0,0,0,0,0,0
+1493,0,0,0,0,0,0,0,0,0,0,0,0,0
+1494,0,0,0,0,0,0,0,0,0,0,0,0,0
+1495,0,0,0,0,0,0,0,0,0,0,0,0,0
+1496,0,0,0,0,0,0,0,0,0,0,0,0,0
+1497,0,0,0,0,0,0,0,0,0,0,0,0,0
+1498,0,0,0,0,0,0,0,0,0,0,0,0,0
+1499,0,0,0,0,0,0,0,0,0,0,0,0,0
+1500,0,0,0,0,0,0,0,0,0,0,0,0,0
+1501,0,0,0,0,0,0,0,0,0,0,0,0,0
+1502,0,0,0,0,0,0,0,0,0,0,0,0,0
+1503,0,0,0,0,0,0,0,0,0,0,0,0,0
+1504,0,0,0,0,0,0,0,0,0,0,0,0,0
+1505,0,0,0,0,0,0,0,0,0,0,0,0,0
+1506,0,0,0,0,0,0,0,0,0,0,0,0,0
+1507,0,0,0,0,0,0,0,0,0,0,0,0,0
+1508,0,0,0,0,0,0,0,0,0,0,0,0,0
+1509,0,0,0,0,0,0,0,0,0,0,0,0,0
+1510,0,0,0,0,0,0,0,0,0,0,0,0,0
+1511,0,0,0,0,0,0,0,0,0,0,0,0,0
+1512,0,0,0,0,0,0,0,0,0,0,0,0,0
+1513,0,0,0,0,0,0,0,0,0,0,0,0,0
+1514,0,0,0,0,0,0,0,0,0,0,0,0,0
+1515,0,0,0,0,0,0,0,0,0,0,0,0,0
+1516,0,0,0,0,0,0,0,0,0,0,0,0,0
+1517,0,0,0,0,0,0,0,0,0,0,0,0,0
+1518,0,0,0,0,0,0,0,0,0,0,0,0,0
+1519,0,0,0,0,0,0,0,0,0,0,0,0,0
+1520,0,0,0,0,0,0,0,0,0,0,0,0,0
+1521,0,0,0,0,0,0,0,0,0,0,0,0,0
+1522,0,0,0,0,0,0,0,0,0,0,0,0,0
+1523,0,0,0,0,0,0,0,0,0,0,0,0,0
+1524,0,0,0,0,0,0,0,0,0,0,0,0,0
+1525,0,0,0,0,0,0,0,0,0,0,0,0,0
+1526,0,0,0,0,0,0,0,0,0,0,0,0,0
+1527,0,0,0,0,0,0,0,0,0,0,0,0,0
+1528,0,0,0,0,0,0,0,0,0,0,0,0,0
+1529,0,0,0,0,0,0,0,0,0,0,0,0,0
+1530,0,0,0,0,0,0,0,0,0,0,0,0,0
+1531,0,0,0,0,0,0,0,0,0,0,0,0,0
+1532,0,0,0,0,0,0,0,0,0,0,0,0,0
+1533,0,0,0,0,0,0,0,0,0,0,0,0,0
+1534,0,0,0,0,0,0,0,0,0,0,0,0,0
+1535,0,0,0,0,0,0,0,0,0,0,0,0,0
+1536,0,0,0,0,0,0,0,0,0,0,0,0,0
+1537,0,0,0,0,0,0,0,0,0,0,0,0,0
+1538,0,0,0,0,0,0,0,0,0,0,0,0.0000115,0
+1539,0,0,0,0,0,0,0,0,0,0,0,0.000026996,0
+1540,0,0,0,0,0,0,0,0,0,0,0,0.000081157,0
+1541,0,0,0,0,0,0,0,0,0,0,0,0.000169507,0
+1542,0,0,0,0,0,0,0,0,0,0,0,0.000273428,0
+1543,0,0,0,0,0,0,0,0,0,0,0,0.000343776,0
+1544,0,0,0,0,0,0,0,0,0,0,0,0.000459515,0
+1545,0,0,0,0,0,0,0,0,0,0,0,0.000651677,0
+1546,0,0,0,0,0,0,0,0,0,0,0,0.0008223,0
+1547,0,0,0,0,0,0,0,0,0,0,0,0.001076746,0
+1548,0,0,0,0,0,0,0,0,0,0,0,0.001428776,0
+1549,0,0,0,0,0,0,0,0,0,0,0,0.001958681,0
+1550,0,0,0,0,0,0,0,0,0,0,0,0.002660821,0
+1551,0,0,0,0,0,0,0,0,0,0,0,0.003682001,0
+1552,0,0,0,0,0,0,0,0,0,0,0,0.005217308,0
+1553,0,0,0,0,0,0,0,0,0,0,0,0.007572684,0
+1554,0,0,0,0,0,0,0,0,0,0,0,0.011246256,0
+1555,0,0,0,0,0,0,0,0,0,0,0,0.01713141,0
+1556,0,0,0,0,0,0,0,0,0,0,0,0.026703068,0
+1557,0,0,0,0,0,0,0,0,0,0,0,0.041388968,0
+1558,0,0,0,0,0,0,0,0,0,0,0,0.062904714,0
+1559,0,0,0,0,0,0,0,0,0,0,0,0.094492263,0
+1560,0,0,0,0,0,0,0,0,0,0,0,0.139743066,0
+1561,0,0,0,0,0,0,0,0,0,0,0,0.200760503,0
+1562,0,0,0,0,0,0,0,0,0,0,0,0.281513117,0
+1563,0,0,0,0,0,0,0,0,0,0,0,0.380879812,0
+1564,0,0,0,0,0,0,0,0,0,0,0,0.490209915,0
+1565,0,0,0,0,0,0,0,0,0,0,0,0.606204368,0
+1566,0,0,0,0,0,0,0,0,0,0,0,0.714558374,0
+1567,0,0,0,0,0,0,0,0,0,0,0,0.80351452,0
+1568,0,0,0,0,0,0,0,0,0,0,0,0.86986655,0
+1569,0,0,0,0,0,0,0,0,0,0,0,0.916284448,0
+1570,0,0,0,0,0,0,0,0,0,0,0,0.946609049,0
+1571,0,0,0,0,0,0,0,0,0,0,0,0.963892644,0
+1572,0,0,0,0,0,0,0,0,0,0,0,0.973065345,0
+1573,0,0,0,0,0,0,0,0,0,0,0,0.977057349,0
+1574,0,0,0,0,0,0,0,0,0,0,0,0.977796293,0
+1575,0,0,0,0,0,0,0,0,0,0,0,0.976890332,0
+1576,0,0,0,0,0,0,0,0,0,0,0,0.975338048,0
+1577,0,0,0,0,0,0,0,0,0,0,0,0.973392995,0
+1578,0,0,0,0,0,0,0,0,0,0,0,0.971480798,0
+1579,0,0,0,0,0,0,0,0,0,0,0,0.969740168,0
+1580,0,0,0,0,0,0,0,0,0,0,0,0.969095034,0
+1581,0,0,0,0,0,0,0,0,0,0,0,0.96969742,0
+1582,0,0,0,0,0,0,0,0,0,0,0,0.970522078,0
+1583,0,0,0,0,0,0,0,0,0,0,0,0.972736269,0
+1584,0,0,0,0,0,0,0,0,0,0,0,0.976138953,0
+1585,0,0,0,0,0,0,0,0,0,0,0,0.978944681,0
+1586,0,0,0,0,0,0,0,0,0,0,0,0.981010782,0
+1587,0,0,0,0,0,0,0,0,0,0,0,0.983513536,0
+1588,0,0,0,0,0,0,0,0,0,0,0,0.984837133,0
+1589,0,0,0,0,0,0,0,0,0,0,0,0.984404132,0
+1590,0,0,0,0,0,0,0,0,0,0,0,0.983920166,0
+1591,0,0,0,0,0,0,0,0,0,0,0,0.983372624,0
+1592,0,0,0,0,0,0,0,0,0,0,0,0.981458796,0
+1593,0,0,0,0,0,0,0,0,0,0,0,0.979391949,0
+1594,0,0,0,0,0,0,0,0,0,0,0,0.978058392,0
+1595,0,0,0,0,0,0,0,0,0,0,0,0.976263051,0
+1596,0,0,0,0,0,0,0,0,0,0,0,0.975392679,0
+1597,0,0,0,0,0,0,0,0,0,0,0,0.9757089,0
+1598,0,0,0,0,0,0,0,0,0,0,0,0.976805245,0
+1599,0,0,0,0,0,0,0,0,0,0,0,0.978986183,0
+1600,0,0,0,0,0,0,0,0,0,0,0,0.981998545,0
+1601,0,0,0,0,0,0,0,0,0,0,0,0.98520893,0
+1602,0,0,0,0,0,0,0,0,0,0,0,0.988659162,0
+1603,0,0,0,0,0,0,0,0,0,0,0,0.992331977,0
+1604,0,0,0,0,0,0,0,0,0,0,0,0.994804634,0
+1605,0,0,0,0,0,0,0,0,0,0,0,0.99589809,0
+1606,0,0,0,0,0,0,0,0,0,0,0,0.995903119,0
+1607,0,0,0,0,0,0,0,0,0,0,0,0.994773417,0
+1608,0,0,0,0,0,0,0,0,0,0,0,0.992101664,0
+1609,0,0,0,0,0,0,0,0,0,0,0,0.988591774,0
+1610,0,0,0,0,0,0,0,0,0,0,0,0.984908418,0
+1611,0,0,0,0,0,0,0,0,0,0,0,0.981101728,0
+1612,0,0,0,0,0,0,0,0,0,0,0,0.976805235,0
+1613,0,0,0,0,0,0,0,0,0,0,0,0.97354566,0
+1614,0,0,0,0,0,0,0,0,0,0,0,0.971948013,0
+1615,0,0,0,0,0,0,0,0,0,0,0,0.97053597,0
+1616,0,0,0,0,0,0,0,0,0,0,0,0.970436371,0
+1617,0,0,0,0,0,0,0,0,0,0,0,0.972382602,0
+1618,0,0,0,0,0,0,0,0,0,0,0,0.975244492,0
+1619,0,0,0,0,0,0,0,0,0,0,0,0.978552743,0
+1620,0,0,0,0,0,0,0,0,0,0,0,0.982971465,0
+1621,0,0,0,0,0,0,0,0,0,0,0,0.98808508,0
+1622,0,0,0,0,0,0,0,0,0,0,0,0.992662671,0
+1623,0,0,0,0,0,0,0,0,0,0,0,0.996435703,0
+1624,0,0,0,0,0,0,0,0,0,0,0,0.99906056,0
+1625,0,0,0,0,0,0,0,0,0,0,0,1,0
+1626,0,0,0,0,0,0,0,0,0,0,0,0.999036445,0
+1627,0,0,0,0,0,0,0,0,0,0,0,0.996642174,0
+1628,0,0,0,0,0,0,0,0,0,0,0,0.993293536,0
+1629,0,0,0,0,0,0,0,0,0,0,0,0.989674029,0
+1630,0,0,0,0,0,0,0,0,0,0,0,0.98579838,0
+1631,0,0,0,0,0,0,0,0,0,0,0,0.982153372,0
+1632,0,0,0,0,0,0,0,0,0,0,0,0.979817194,0
+1633,0,0,0,0,0,0,0,0,0,0,0,0.979473331,0
+1634,0,0,0,0,0,0,0,0,0,0,0,0.980262857,0
+1635,0,0,0,0,0,0,0,0,0,0,0,0.982464858,0
+1636,0,0,0,0,0,0,0,0,0,0,0,0.986000509,0
+1637,0,0,0,0,0,0,0,0,0,0,0,0.989562258,0
+1638,0,0,0,0,0,0,0,0,0,0,0,0.991723341,0
+1639,0,0,0,0,0,0,0,0,0,0,0,0.992201372,0
+1640,0,0,0,0,0,0,0,0,0,0,0,0.98939229,0
+1641,0,0,0,0,0,0,0,0,0,0,0,0.982102331,0
+1642,0,0,0,0,0,0,0,0,0,0,0,0.970157085,0
+1643,0,0,0,0,0,0,0,0,0,0,0,0.953186779,0
+1644,0,0,0,0,0,0,0,0,0,0,0,0.932369062,0
+1645,0,0,0,0,0,0,0,0,0,0,0,0.908001591,0
+1646,0,0,0,0,0,0,0,0,0,0,0,0.884086561,0
+1647,0,0,0,0,0,0,0,0,0,0,0,0.864271526,0
+1648,0,0,0,0,0,0,0,0,0,0,0,0.850889881,0
+1649,0,0,0,0,0,0,0,0,0,0,0,0.844206087,0
+1650,0,0,0,0,0,0,0,0,0,0,0,0.843448232,0
+1651,0,0,0,0,0,0,0,0,0,0,0,0.847024828,0
+1652,0,0,0,0,0,0,0,0,0,0,0,0.848701823,0
+1653,0,0,0,0,0,0,0,0,0,0,0,0.840540222,0
+1654,0,0,0,0,0,0,0,0,0,0,0,0.81352592,0
+1655,0,0,0,0,0,0,0,0,0,0,0,0.756843245,0
+1656,0,0,0,0,0,0,0,0,0,0,0,0.670393147,0
+1657,0,0,0,0,0,0,0,0,0,0,0,0.565754809,0
+1658,0,0,0,0,0,0,0,0,0,0,0,0.457566037,0
+1659,0,0,0,0,0,0,0,0,0,0,0,0.353763564,0
+1660,0,0,0,0,0,0,0,0,0,0,0,0.256912748,0
+1661,0,0,0,0,0,0,0,0,0,0,0,0.176281,0
+1662,0,0,0,0,0,0,0,0,0,0,0,0.115842988,0
+1663,0,0,0,0,0,0,0,0,0,0,0,0.073512768,0
+1664,0,0,0,0,0,0,0,0,0,0,0,0.046527708,0
+1665,0,0,0,0,0,0,0,0,0,0,0,0.02905985,0
+1666,0,0,0,0,0,0,0,0,0,0,0,0.018579999,0
+1667,0,0,0,0,0,0,0,0,0,0,0,0.012463091,0
+1668,0,0,0,0,0,0,0,0,0,0,0,0.00878944,0
+1669,0,0,0,0,0,0,0,0,0,0,0,0.006316358,0
+1670,0,0,0,0,0,0,0,0,0,0,0,0.004582867,0
+1671,0,0,0,0,0,0,0,0,0,0,0,0.003359394,0
+1672,0,0,0,0,0,0,0,0,0,0,0,0.002462997,0
+1673,0,0,0,0,0,0,0,0,0,0,0,0.001990739,0
+1674,0,0,0,0,0,0,0,0,0,0,0,0.001501488,0
+1675,0,0,0,0,0,0,0,0,0,0,0,0.001123371,0
+1676,0,0,0,0,0,0,0,0,0,0,0,0.00078272,0
+1677,0,0,0,0,0,0,0,0,0,0,0,0.000541322,0
+1678,0,0,0,0,0,0,0,0,0,0,0,0.000281204,0
+1679,0,0,0,0,0,0,0,0,0,0,0,0.00013347,0
+1680,0,0,0,0,0,0,0,0,0,0,0,0,0
+1681,0,0,0,0,0,0,0,0,0,0,0,0,0
+1682,0,0,0,0,0,0,0,0,0,0,0,0,0
+1683,0,0,0,0,0,0,0,0,0,0,0,0,0
+1684,0,0,0,0,0,0,0,0,0,0,0,0,0
+1685,0,0,0,0,0,0,0,0,0,0,0,0,0
+1686,0,0,0,0,0,0,0,0,0,0,0,0,0
+1687,0,0,0,0,0,0,0,0,0,0,0,0,0
+1688,0,0,0,0,0,0,0,0,0,0,0,0,0
+1689,0,0,0,0,0,0,0,0,0,0,0,0,0
+1690,0,0,0,0,0,0,0,0,0,0,0,0,0
+1691,0,0,0,0,0,0,0,0,0,0,0,0,0
+1692,0,0,0,0,0,0,0,0,0,0,0,0,0
+1693,0,0,0,0,0,0,0,0,0,0,0,0,0
+1694,0,0,0,0,0,0,0,0,0,0,0,0,0
+1695,0,0,0,0,0,0,0,0,0,0,0,0,0
+1696,0,0,0,0,0,0,0,0,0,0,0,0,0
+1697,0,0,0,0,0,0,0,0,0,0,0,0,0
+1698,0,0,0,0,0,0,0,0,0,0,0,0,0
+1699,0,0,0,0,0,0,0,0,0,0,0,0,0
+1700,0,0,0,0,0,0,0,0,0,0,0,0,0
+1701,0,0,0,0,0,0,0,0,0,0,0,0,0
+1702,0,0,0,0,0,0,0,0,0,0,0,0,0
+1703,0,0,0,0,0,0,0,0,0,0,0,0,0
+1704,0,0,0,0,0,0,0,0,0,0,0,0,0
+1705,0,0,0,0,0,0,0,0,0,0,0,0,0
+1706,0,0,0,0,0,0,0,0,0,0,0,0,0
+1707,0,0,0,0,0,0,0,0,0,0,0,0,0
+1708,0,0,0,0,0,0,0,0,0,0,0,0,0
+1709,0,0,0,0,0,0,0,0,0,0,0,0,0
+1710,0,0,0,0,0,0,0,0,0,0,0,0,0
+1711,0,0,0,0,0,0,0,0,0,0,0,0,0
+1712,0,0,0,0,0,0,0,0,0,0,0,0,0
+1713,0,0,0,0,0,0,0,0,0,0,0,0,0
+1714,0,0,0,0,0,0,0,0,0,0,0,0,0
+1715,0,0,0,0,0,0,0,0,0,0,0,0,0
+1716,0,0,0,0,0,0,0,0,0,0,0,0,0
+1717,0,0,0,0,0,0,0,0,0,0,0,0,0
+1718,0,0,0,0,0,0,0,0,0,0,0,0,0
+1719,0,0,0,0,0,0,0,0,0,0,0,0,0
+1720,0,0,0,0,0,0,0,0,0,0,0,0,0
+1721,0,0,0,0,0,0,0,0,0,0,0,0,0
+1722,0,0,0,0,0,0,0,0,0,0,0,0,0
+1723,0,0,0,0,0,0,0,0,0,0,0,0,0
+1724,0,0,0,0,0,0,0,0,0,0,0,0,0
+1725,0,0,0,0,0,0,0,0,0,0,0,0,0
+1726,0,0,0,0,0,0,0,0,0,0,0,0,0
+1727,0,0,0,0,0,0,0,0,0,0,0,0,0
+1728,0,0,0,0,0,0,0,0,0,0,0,0,0
+1729,0,0,0,0,0,0,0,0,0,0,0,0,0
+1730,0,0,0,0,0,0,0,0,0,0,0,0,0
+1731,0,0,0,0,0,0,0,0,0,0,0,0,0
+1732,0,0,0,0,0,0,0,0,0,0,0,0,0
+1733,0,0,0,0,0,0,0,0,0,0,0,0,0
+1734,0,0,0,0,0,0,0,0,0,0,0,0,0
+1735,0,0,0,0,0,0,0,0,0,0,0,0,0
+1736,0,0,0,0,0,0,0,0,0,0,0,0,0
+1737,0,0,0,0,0,0,0,0,0,0,0,0,0
+1738,0,0,0,0,0,0,0,0,0,0,0,0,0
+1739,0,0,0,0,0,0,0,0,0,0,0,0,0
+1740,0,0,0,0,0,0,0,0,0,0,0,0,0
+1741,0,0,0,0,0,0,0,0,0,0,0,0,0
+1742,0,0,0,0,0,0,0,0,0,0,0,0,0
+1743,0,0,0,0,0,0,0,0,0,0,0,0,0
+1744,0,0,0,0,0,0,0,0,0,0,0,0,0
+1745,0,0,0,0,0,0,0,0,0,0,0,0,0
+1746,0,0,0,0,0,0,0,0,0,0,0,0,0
+1747,0,0,0,0,0,0,0,0,0,0,0,0,0
+1748,0,0,0,0,0,0,0,0,0,0,0,0,0
+1749,0,0,0,0,0,0,0,0,0,0,0,0,0
+1750,0,0,0,0,0,0,0,0,0,0,0,0,0
+1751,0,0,0,0,0,0,0,0,0,0,0,0,0
+1752,0,0,0,0,0,0,0,0,0,0,0,0,0
+1753,0,0,0,0,0,0,0,0,0,0,0,0,0
+1754,0,0,0,0,0,0,0,0,0,0,0,0,0
+1755,0,0,0,0,0,0,0,0,0,0,0,0,0
+1756,0,0,0,0,0,0,0,0,0,0,0,0,0
+1757,0,0,0,0,0,0,0,0,0,0,0,0,0
+1758,0,0,0,0,0,0,0,0,0,0,0,0,0
+1759,0,0,0,0,0,0,0,0,0,0,0,0,0
+1760,0,0,0,0,0,0,0,0,0,0,0,0,0
+1761,0,0,0,0,0,0,0,0,0,0,0,0,0
+1762,0,0,0,0,0,0,0,0,0,0,0,0,0
+1763,0,0,0,0,0,0,0,0,0,0,0,0,0
+1764,0,0,0,0,0,0,0,0,0,0,0,0,0
+1765,0,0,0,0,0,0,0,0,0,0,0,0,0
+1766,0,0,0,0,0,0,0,0,0,0,0,0,0
+1767,0,0,0,0,0,0,0,0,0,0,0,0,0
+1768,0,0,0,0,0,0,0,0,0,0,0,0,0
+1769,0,0,0,0,0,0,0,0,0,0,0,0,0
+1770,0,0,0,0,0,0,0,0,0,0,0,0,0
+1771,0,0,0,0,0,0,0,0,0,0,0,0,0
+1772,0,0,0,0,0,0,0,0,0,0,0,0,0
+1773,0,0,0,0,0,0,0,0,0,0,0,0,0
+1774,0,0,0,0,0,0,0,0,0,0,0,0,0
+1775,0,0,0,0,0,0,0,0,0,0,0,0,0
+1776,0,0,0,0,0,0,0,0,0,0,0,0,0
+1777,0,0,0,0,0,0,0,0,0,0,0,0,0
+1778,0,0,0,0,0,0,0,0,0,0,0,0,0
+1779,0,0,0,0,0,0,0,0,0,0,0,0,0
+1780,0,0,0,0,0,0,0,0,0,0,0,0,0
+1781,0,0,0,0,0,0,0,0,0,0,0,0,0
+1782,0,0,0,0,0,0,0,0,0,0,0,0,0
+1783,0,0,0,0,0,0,0,0,0,0,0,0,0
+1784,0,0,0,0,0,0,0,0,0,0,0,0,0
+1785,0,0,0,0,0,0,0,0,0,0,0,0,0
+1786,0,0,0,0,0,0,0,0,0,0,0,0,0
+1787,0,0,0,0,0,0,0,0,0,0,0,0,0
+1788,0,0,0,0,0,0,0,0,0,0,0,0,0
+1789,0,0,0,0,0,0,0,0,0,0,0,0,0
+1790,0,0,0,0,0,0,0,0,0,0,0,0,0
+1791,0,0,0,0,0,0,0,0,0,0,0,0,0
+1792,0,0,0,0,0,0,0,0,0,0,0,0,0
+1793,0,0,0,0,0,0,0,0,0,0,0,0,0
+1794,0,0,0,0,0,0,0,0,0,0,0,0,0
+1795,0,0,0,0,0,0,0,0,0,0,0,0,0
+1796,0,0,0,0,0,0,0,0,0,0,0,0,0
+1797,0,0,0,0,0,0,0,0,0,0,0,0,0
+1798,0,0,0,0,0,0,0,0,0,0,0,0,0
+1799,0,0,0,0,0,0,0,0,0,0,0,0,0
+1800,0,0,0,0,0,0,0,0,0,0,0,0,0
+1801,0,0,0,0,0,0,0,0,0,0,0,0,0
+1802,0,0,0,0,0,0,0,0,0,0,0,0,0
+1803,0,0,0,0,0,0,0,0,0,0,0,0,0
+1804,0,0,0,0,0,0,0,0,0,0,0,0,0
+1805,0,0,0,0,0,0,0,0,0,0,0,0,0
+1806,0,0,0,0,0,0,0,0,0,0,0,0,0
+1807,0,0,0,0,0,0,0,0,0,0,0,0,0
+1808,0,0,0,0,0,0,0,0,0,0,0,0,0
+1809,0,0,0,0,0,0,0,0,0,0,0,0,0
+1810,0,0,0,0,0,0,0,0,0,0,0,0,0
+1811,0,0,0,0,0,0,0,0,0,0,0,0,0
+1812,0,0,0,0,0,0,0,0,0,0,0,0,0
+1813,0,0,0,0,0,0,0,0,0,0,0,0,0
+1814,0,0,0,0,0,0,0,0,0,0,0,0,0
+1815,0,0,0,0,0,0,0,0,0,0,0,0,0
+1816,0,0,0,0,0,0,0,0,0,0,0,0,0
+1817,0,0,0,0,0,0,0,0,0,0,0,0,0
+1818,0,0,0,0,0,0,0,0,0,0,0,0,0
+1819,0,0,0,0,0,0,0,0,0,0,0,0,0
+1820,0,0,0,0,0,0,0,0,0,0,0,0,0
+1821,0,0,0,0,0,0,0,0,0,0,0,0,0
+1822,0,0,0,0,0,0,0,0,0,0,0,0,0
+1823,0,0,0,0,0,0,0,0,0,0,0,0,0
+1824,0,0,0,0,0,0,0,0,0,0,0,0,0
+1825,0,0,0,0,0,0,0,0,0,0,0,0,0
+1826,0,0,0,0,0,0,0,0,0,0,0,0,0
+1827,0,0,0,0,0,0,0,0,0,0,0,0,0
+1828,0,0,0,0,0,0,0,0,0,0,0,0,0
+1829,0,0,0,0,0,0,0,0,0,0,0,0,0
+1830,0,0,0,0,0,0,0,0,0,0,0,0,0
+1831,0,0,0,0,0,0,0,0,0,0,0,0,0
+1832,0,0,0,0,0,0,0,0,0,0,0,0,0
+1833,0,0,0,0,0,0,0,0,0,0,0,0,0
+1834,0,0,0,0,0,0,0,0,0,0,0,0,0
+1835,0,0,0,0,0,0,0,0,0,0,0,0,0
+1836,0,0,0,0,0,0,0,0,0,0,0,0,0
+1837,0,0,0,0,0,0,0,0,0,0,0,0,0
+1838,0,0,0,0,0,0,0,0,0,0,0,0,0
+1839,0,0,0,0,0,0,0,0,0,0,0,0,0
+1840,0,0,0,0,0,0,0,0,0,0,0,0,0
+1841,0,0,0,0,0,0,0,0,0,0,0,0,0
+1842,0,0,0,0,0,0,0,0,0,0,0,0,0
+1843,0,0,0,0,0,0,0,0,0,0,0,0,0
+1844,0,0,0,0,0,0,0,0,0,0,0,0,0
+1845,0,0,0,0,0,0,0,0,0,0,0,0,0
+1846,0,0,0,0,0,0,0,0,0,0,0,0,0
+1847,0,0,0,0,0,0,0,0,0,0,0,0,0
+1848,0,0,0,0,0,0,0,0,0,0,0,0,0
+1849,0,0,0,0,0,0,0,0,0,0,0,0,0
+1850,0,0,0,0,0,0,0,0,0,0,0,0,0
+1851,0,0,0,0,0,0,0,0,0,0,0,0,0
+1852,0,0,0,0,0,0,0,0,0,0,0,0,0
+1853,0,0,0,0,0,0,0,0,0,0,0,0,0
+1854,0,0,0,0,0,0,0,0,0,0,0,0,0
+1855,0,0,0,0,0,0,0,0,0,0,0,0,0
+1856,0,0,0,0,0,0,0,0,0,0,0,0,0
+1857,0,0,0,0,0,0,0,0,0,0,0,0,0
+1858,0,0,0,0,0,0,0,0,0,0,0,0,0
+1859,0,0,0,0,0,0,0,0,0,0,0,0,0
+1860,0,0,0,0,0,0,0,0,0,0,0,0,0
+1861,0,0,0,0,0,0,0,0,0,0,0,0,0
+1862,0,0,0,0,0,0,0,0,0,0,0,0,0
+1863,0,0,0,0,0,0,0,0,0,0,0,0,0
+1864,0,0,0,0,0,0,0,0,0,0,0,0,0
+1865,0,0,0,0,0,0,0,0,0,0,0,0,0
+1866,0,0,0,0,0,0,0,0,0,0,0,0,0
+1867,0,0,0,0,0,0,0,0,0,0,0,0,0
+1868,0,0,0,0,0,0,0,0,0,0,0,0,0
+1869,0,0,0,0,0,0,0,0,0,0,0,0,0
+1870,0,0,0,0,0,0,0,0,0,0,0,0,0
+1871,0,0,0,0,0,0,0,0,0,0,0,0,0
+1872,0,0,0,0,0,0,0,0,0,0,0,0,0
+1873,0,0,0,0,0,0,0,0,0,0,0,0,0
+1874,0,0,0,0,0,0,0,0,0,0,0,0,0
+1875,0,0,0,0,0,0,0,0,0,0,0,0,0
+1876,0,0,0,0,0,0,0,0,0,0,0,0,0
+1877,0,0,0,0,0,0,0,0,0,0,0,0,0
+1878,0,0,0,0,0,0,0,0,0,0,0,0,0
+1879,0,0,0,0,0,0,0,0,0,0,0,0,0
+1880,0,0,0,0,0,0,0,0,0,0,0,0,0
+1881,0,0,0,0,0,0,0,0,0,0,0,0,0
+1882,0,0,0,0,0,0,0,0,0,0,0,0,0
+1883,0,0,0,0,0,0,0,0,0,0,0,0,0
+1884,0,0,0,0,0,0,0,0,0,0,0,0,0
+1885,0,0,0,0,0,0,0,0,0,0,0,0,0
+1886,0,0,0,0,0,0,0,0,0,0,0,0,0
+1887,0,0,0,0,0,0,0,0,0,0,0,0,0
+1888,0,0,0,0,0,0,0,0,0,0,0,0,0
+1889,0,0,0,0,0,0,0,0,0,0,0,0,0
+1890,0,0,0,0,0,0,0,0,0,0,0,0,0
+1891,0,0,0,0,0,0,0,0,0,0,0,0,0
+1892,0,0,0,0,0,0,0,0,0,0,0,0,0
+1893,0,0,0,0,0,0,0,0,0,0,0,0,0
+1894,0,0,0,0,0,0,0,0,0,0,0,0,0
+1895,0,0,0,0,0,0,0,0,0,0,0,0,0
+1896,0,0,0,0,0,0,0,0,0,0,0,0,0
+1897,0,0,0,0,0,0,0,0,0,0,0,0,0
+1898,0,0,0,0,0,0,0,0,0,0,0,0,0
+1899,0,0,0,0,0,0,0,0,0,0,0,0,0
+1900,0,0,0,0,0,0,0,0,0,0,0,0,0
+1901,0,0,0,0,0,0,0,0,0,0,0,0,0
+1902,0,0,0,0,0,0,0,0,0,0,0,0,0
+1903,0,0,0,0,0,0,0,0,0,0,0,0,0
+1904,0,0,0,0,0,0,0,0,0,0,0,0,0
+1905,0,0,0,0,0,0,0,0,0,0,0,0,0
+1906,0,0,0,0,0,0,0,0,0,0,0,0,0
+1907,0,0,0,0,0,0,0,0,0,0,0,0,0
+1908,0,0,0,0,0,0,0,0,0,0,0,0,0
+1909,0,0,0,0,0,0,0,0,0,0,0,0,0
+1910,0,0,0,0,0,0,0,0,0,0,0,0,0
+1911,0,0,0,0,0,0,0,0,0,0,0,0,0
+1912,0,0,0,0,0,0,0,0,0,0,0,0,0
+1913,0,0,0,0,0,0,0,0,0,0,0,0,0
+1914,0,0,0,0,0,0,0,0,0,0,0,0,0
+1915,0,0,0,0,0,0,0,0,0,0,0,0,0
+1916,0,0,0,0,0,0,0,0,0,0,0,0,0
+1917,0,0,0,0,0,0,0,0,0,0,0,0,0
+1918,0,0,0,0,0,0,0,0,0,0,0,0,0
+1919,0,0,0,0,0,0,0,0,0,0,0,0,0
+1920,0,0,0,0,0,0,0,0,0,0,0,0,0
+1921,0,0,0,0,0,0,0,0,0,0,0,0,0
+1922,0,0,0,0,0,0,0,0,0,0,0,0,0
+1923,0,0,0,0,0,0,0,0,0,0,0,0,0
+1924,0,0,0,0,0,0,0,0,0,0,0,0,0
+1925,0,0,0,0,0,0,0,0,0,0,0,0,0
+1926,0,0,0,0,0,0,0,0,0,0,0,0,0
+1927,0,0,0,0,0,0,0,0,0,0,0,0,0
+1928,0,0,0,0,0,0,0,0,0,0,0,0,0
+1929,0,0,0,0,0,0,0,0,0,0,0,0,0
+1930,0,0,0,0,0,0,0,0,0,0,0,0,0
+1931,0,0,0,0,0,0,0,0,0,0,0,0,0
+1932,0,0,0,0,0,0,0,0,0,0,0,0,0
+1933,0,0,0,0,0,0,0,0,0,0,0,0,0
+1934,0,0,0,0,0,0,0,0,0,0,0,0,0
+1935,0,0,0,0,0,0,0,0,0,0,0,0,0
+1936,0,0,0,0,0,0,0,0,0,0,0,0,0
+1937,0,0,0,0,0,0,0,0,0,0,0,0,0
+1938,0,0,0,0,0,0,0,0,0,0,0,0,0
+1939,0,0,0,0,0,0,0,0,0,0,0,0,0
+1940,0,0,0,0,0,0,0,0,0,0,0,0,0
+1941,0,0,0,0,0,0,0,0,0,0,0,0,0
+1942,0,0,0,0,0,0,0,0,0,0,0,0,0
+1943,0,0,0,0,0,0,0,0,0,0,0,0,0
+1944,0,0,0,0,0,0,0,0,0,0,0,0,0
+1945,0,0,0,0,0,0,0,0,0,0,0,0,0
+1946,0,0,0,0,0,0,0,0,0,0,0,0,0
+1947,0,0,0,0,0,0,0,0,0,0,0,0,0
+1948,0,0,0,0,0,0,0,0,0,0,0,0,0
+1949,0,0,0,0,0,0,0,0,0,0,0,0,0
+1950,0,0,0,0,0,0,0,0,0,0,0,0,0
+1951,0,0,0,0,0,0,0,0,0,0,0,0,0
+1952,0,0,0,0,0,0,0,0,0,0,0,0,0
+1953,0,0,0,0,0,0,0,0,0,0,0,0,0
+1954,0,0,0,0,0,0,0,0,0,0,0,0,0
+1955,0,0,0,0,0,0,0,0,0,0,0,0,0
+1956,0,0,0,0,0,0,0,0,0,0,0,0,0
+1957,0,0,0,0,0,0,0,0,0,0,0,0,0
+1958,0,0,0,0,0,0,0,0,0,0,0,0,0
+1959,0,0,0,0,0,0,0,0,0,0,0,0,0
+1960,0,0,0,0,0,0,0,0,0,0,0,0,0
+1961,0,0,0,0,0,0,0,0,0,0,0,0,0
+1962,0,0,0,0,0,0,0,0,0,0,0,0,0
+1963,0,0,0,0,0,0,0,0,0,0,0,0,0
+1964,0,0,0,0,0,0,0,0,0,0,0,0,0
+1965,0,0,0,0,0,0,0,0,0,0,0,0,0
+1966,0,0,0,0,0,0,0,0,0,0,0,0,0
+1967,0,0,0,0,0,0,0,0,0,0,0,0,0
+1968,0,0,0,0,0,0,0,0,0,0,0,0,0
+1969,0,0,0,0,0,0,0,0,0,0,0,0,0
+1970,0,0,0,0,0,0,0,0,0,0,0,0,0
+1971,0,0,0,0,0,0,0,0,0,0,0,0,0
+1972,0,0,0,0,0,0,0,0,0,0,0,0,0
+1973,0,0,0,0,0,0,0,0,0,0,0,0,0
+1974,0,0,0,0,0,0,0,0,0,0,0,0,0
+1975,0,0,0,0,0,0,0,0,0,0,0,0,0
+1976,0,0,0,0,0,0,0,0,0,0,0,0,0
+1977,0,0,0,0,0,0,0,0,0,0,0,0,0
+1978,0,0,0,0,0,0,0,0,0,0,0,0,0
+1979,0,0,0,0,0,0,0,0,0,0,0,0,0
+1980,0,0,0,0,0,0,0,0,0,0,0,0,0
+1981,0,0,0,0,0,0,0,0,0,0,0,0,0
+1982,0,0,0,0,0,0,0,0,0,0,0,0,0
+1983,0,0,0,0,0,0,0,0,0,0,0,0,0
+1984,0,0,0,0,0,0,0,0,0,0,0,0,0
+1985,0,0,0,0,0,0,0,0,0,0,0,0,0
+1986,0,0,0,0,0,0,0,0,0,0,0,0,0
+1987,0,0,0,0,0,0,0,0,0,0,0,0,0
+1988,0,0,0,0,0,0,0,0,0,0,0,0,0
+1989,0,0,0,0,0,0,0,0,0,0,0,0,0
+1990,0,0,0,0,0,0,0,0,0,0,0,0,0
+1991,0,0,0,0,0,0,0,0,0,0,0,0,0
+1992,0,0,0,0,0,0,0,0,0,0,0,0,0
+1993,0,0,0,0,0,0,0,0,0,0,0,0,0
+1994,0,0,0,0,0,0,0,0,0,0,0,0,0
+1995,0,0,0,0,0,0,0,0,0,0,0,0,0
+1996,0,0,0,0,0,0,0,0,0,0,0,0,0
+1997,0,0,0,0,0,0,0,0,0,0,0,0,0
+1998,0,0,0,0,0,0,0,0,0,0,0,0,0
+1999,0,0,0,0,0,0,0,0,0,0,0,0,0
+2000,0,0,0,0,0,0,0,0,0,0,0,0,0
+2001,0,0,0,0,0,0,0,0,0,0,0,0,0
+2002,0,0,0,0,0,0,0,0,0,0,0,0,0
+2003,0,0,0,0,0,0,0,0,0,0,0,0,0
+2004,0,0,0,0,0,0,0,0,0,0,0,0,0
+2005,0,0,0,0,0,0,0,0,0,0,0,0,0
+2006,0,0,0,0,0,0,0,0,0,0,0,0,0
+2007,0,0,0,0,0,0,0,0,0,0,0,0,0
+2008,0,0,0,0,0,0,0,0,0,0,0,0,0
+2009,0,0,0,0,0,0,0,0,0,0,0,0,0
+2010,0,0,0,0,0,0,0,0,0,0,0,0,0
+2011,0,0,0,0,0,0,0,0,0,0,0,0,0
+2012,0,0,0,0,0,0,0,0,0,0,0,0,0
+2013,0,0,0,0,0,0,0,0,0,0,0,0,0
+2014,0,0,0,0,0,0,0,0,0,0,0,0,0
+2015,0,0,0,0,0,0,0,0,0,0,0,0,0
+2016,0,0,0,0,0,0,0,0,0,0,0,0,0
+2017,0,0,0,0,0,0,0,0,0,0,0,0,0
+2018,0,0,0,0,0,0,0,0,0,0,0,0,0
+2019,0,0,0,0,0,0,0,0,0,0,0,0,0
+2020,0,0,0,0,0,0,0,0,0,0,0,0,0
+2021,0,0,0,0,0,0,0,0,0,0,0,0,0
+2022,0,0,0,0,0,0,0,0,0,0,0,0,0
+2023,0,0,0,0,0,0,0,0,0,0,0,0,0
+2024,0,0,0,0,0,0,0,0,0,0,0,0,0
+2025,0,0,0,0,0,0,0,0,0,0,0,0,0
+2026,0,0,0,0,0,0,0,0,0,0,0,0,0
+2027,0,0,0,0,0,0,0,0,0,0,0,0,0
+2028,0,0,0,0,0,0,0,0,0,0,0,0,0
+2029,0,0,0,0,0,0,0,0,0,0,0,0,0
+2030,0,0,0,0,0,0,0,0,0,0,0,0,0
+2031,0,0,0,0,0,0,0,0,0,0,0,0,0
+2032,0,0,0,0,0,0,0,0,0,0,0,0,0
+2033,0,0,0,0,0,0,0,0,0,0,0,0,0
+2034,0,0,0,0,0,0,0,0,0,0,0,0,0
+2035,0,0,0,0,0,0,0,0,0,0,0,0,0
+2036,0,0,0,0,0,0,0,0,0,0,0,0,0
+2037,0,0,0,0,0,0,0,0,0,0,0,0,0
+2038,0,0,0,0,0,0,0,0,0,0,0,0,0
+2039,0,0,0,0,0,0,0,0,0,0,0,0,0
+2040,0,0,0,0,0,0,0,0,0,0,0,0,0
+2041,0,0,0,0,0,0,0,0,0,0,0,0,0
+2042,0,0,0,0,0,0,0,0,0,0,0,0,0
+2043,0,0,0,0,0,0,0,0,0,0,0,0,0
+2044,0,0,0,0,0,0,0,0,0,0,0,0,0
+2045,0,0,0,0,0,0,0,0,0,0,0,0,0
+2046,0,0,0,0,0,0,0,0,0,0,0,0,0
+2047,0,0,0,0,0,0,0,0,0,0,0,0,0
+2048,0,0,0,0,0,0,0,0,0,0,0,0,0
+2049,0,0,0,0,0,0,0,0,0,0,0,0,0
+2050,0,0,0,0,0,0,0,0,0,0,0,0,0
+2051,0,0,0,0,0,0,0,0,0,0,0,0,0
+2052,0,0,0,0,0,0,0,0,0,0,0,0,0
+2053,0,0,0,0,0,0,0,0,0,0,0,0,0
+2054,0,0,0,0,0,0,0,0,0,0,0,0,0
+2055,0,0,0,0,0,0,0,0,0,0,0,0,0
+2056,0,0,0,0,0,0,0,0,0,0,0,0,0
+2057,0,0,0,0,0,0,0,0,0,0,0,0,0
+2058,0,0,0,0,0,0,0,0,0,0,0,0,0
+2059,0,0,0,0,0,0,0,0,0,0,0,0,0
+2060,0,0,0,0,0,0,0,0,0,0,0,0,0
+2061,0,0,0,0,0,0,0,0,0,0,0,0,0
+2062,0,0,0,0,0,0,0,0,0,0,0,0,0
+2063,0,0,0,0,0,0,0,0,0,0,0,0,0
+2064,0,0,0,0,0,0,0,0,0,0,0,0,0
+2065,0,0,0,0,0,0,0,0,0,0,0,0,0.000227567
+2066,0,0,0,0,0,0,0,0,0,0,0,0,0.000739283
+2067,0,0,0,0,0,0,0,0,0,0,0,0,0.001656775
+2068,0,0,0,0,0,0,0,0,0,0,0,0,0.003019587
+2069,0,0,0,0,0,0,0,0,0,0,0,0,0.004589377
+2070,0,0,0,0,0,0,0,0,0,0,0,0,0.005924935
+2071,0,0,0,0,0,0,0,0,0,0,0,0,0.007534774
+2072,0,0,0,0,0,0,0,0,0,0,0,0,0.008748008
+2073,0,0,0,0,0,0,0,0,0,0,0,0,0.010265481
+2074,0,0,0,0,0,0,0,0,0,0,0,0,0.012236179
+2075,0,0,0,0,0,0,0,0,0,0,0,0,0.014593479
+2076,0,0,0,0,0,0,0,0,0,0,0,0,0.017458937
+2077,0,0,0,0,0,0,0,0,0,0,0,0,0.021063245
+2078,0,0,0,0,0,0,0,0,0,0,0,0,0.025428056
+2079,0,0,0,0,0,0,0,0,0,0,0,0,0.03060944
+2080,0,0,0,0,0,0,0,0,0,0,0,0,0.037234457
+2081,0,0,0,0,0,0,0,0,0,0,0,0,0.045771325
+2082,0,0,0,0,0,0,0,0,0,0,0,0,0.056362502
+2083,0,0,0,0,0,0,0,0,0,0,0,0,0.070016996
+2084,0,0,0,0,0,0,0,0,0,0,0,0,0.088004988
+2085,0,0,0,0,0,0,0,0,0,0,0,0,0.110694417
+2086,0,0,0,0,0,0,0,0,0,0,0,0,0.138884174
+2087,0,0,0,0,0,0,0,0,0,0,0,0,0.173287791
+2088,0,0,0,0,0,0,0,0,0,0,0,0,0.214374591
+2089,0,0,0,0,0,0,0,0,0,0,0,0,0.261990789
+2090,0,0,0,0,0,0,0,0,0,0,0,0,0.317227795
+2091,0,0,0,0,0,0,0,0,0,0,0,0,0.380865706
+2092,0,0,0,0,0,0,0,0,0,0,0,0,0.449470316
+2093,0,0,0,0,0,0,0,0,0,0,0,0,0.522785467
+2094,0,0,0,0,0,0,0,0,0,0,0,0,0.598898522
+2095,0,0,0,0,0,0,0,0,0,0,0,0,0.672128213
+2096,0,0,0,0,0,0,0,0,0,0,0,0,0.737899139
+2097,0,0,0,0,0,0,0,0,0,0,0,0,0.792930708
+2098,0,0,0,0,0,0,0,0,0,0,0,0,0.835658783
+2099,0,0,0,0,0,0,0,0,0,0,0,0,0.866335142
+2100,0,0,0,0,0,0,0,0,0,0,0,0,0.886329697
+2101,0,0,0,0,0,0,0,0,0,0,0,0,0.897588245
+2102,0,0,0,0,0,0,0,0,0,0,0,0,0.901517855
+2103,0,0,0,0,0,0,0,0,0,0,0,0,0.900790721
+2104,0,0,0,0,0,0,0,0,0,0,0,0,0.897113531
+2105,0,0,0,0,0,0,0,0,0,0,0,0,0.892352598
+2106,0,0,0,0,0,0,0,0,0,0,0,0,0.88796428
+2107,0,0,0,0,0,0,0,0,0,0,0,0,0.884432193
+2108,0,0,0,0,0,0,0,0,0,0,0,0,0.882095059
+2109,0,0,0,0,0,0,0,0,0,0,0,0,0.881695748
+2110,0,0,0,0,0,0,0,0,0,0,0,0,0.88269782
+2111,0,0,0,0,0,0,0,0,0,0,0,0,0.887154405
+2112,0,0,0,0,0,0,0,0,0,0,0,0,0.892732955
+2113,0,0,0,0,0,0,0,0,0,0,0,0,0.898903582
+2114,0,0,0,0,0,0,0,0,0,0,0,0,0.905619271
+2115,0,0,0,0,0,0,0,0,0,0,0,0,0.912841006
+2116,0,0,0,0,0,0,0,0,0,0,0,0,0.920179789
+2117,0,0,0,0,0,0,0,0,0,0,0,0,0.926912882
+2118,0,0,0,0,0,0,0,0,0,0,0,0,0.933094888
+2119,0,0,0,0,0,0,0,0,0,0,0,0,0.938438355
+2120,0,0,0,0,0,0,0,0,0,0,0,0,0.943377038
+2121,0,0,0,0,0,0,0,0,0,0,0,0,0.945579227
+2122,0,0,0,0,0,0,0,0,0,0,0,0,0.947407512
+2123,0,0,0,0,0,0,0,0,0,0,0,0,0.948568289
+2124,0,0,0,0,0,0,0,0,0,0,0,0,0.94882972
+2125,0,0,0,0,0,0,0,0,0,0,0,0,0.948111791
+2126,0,0,0,0,0,0,0,0,0,0,0,0,0.947115734
+2127,0,0,0,0,0,0,0,0,0,0,0,0,0.946126982
+2128,0,0,0,0,0,0,0,0,0,0,0,0,0.944870644
+2129,0,0,0,0,0,0,0,0,0,0,0,0,0.943485039
+2130,0,0,0,0,0,0,0,0,0,0,0,0,0.941894052
+2131,0,0,0,0,0,0,0,0,0,0,0,0,0.942445527
+2132,0,0,0,0,0,0,0,0,0,0,0,0,0.943274219
+2133,0,0,0,0,0,0,0,0,0,0,0,0,0.944243794
+2134,0,0,0,0,0,0,0,0,0,0,0,0,0.94528606
+2135,0,0,0,0,0,0,0,0,0,0,0,0,0.946212496
+2136,0,0,0,0,0,0,0,0,0,0,0,0,0.947084905
+2137,0,0,0,0,0,0,0,0,0,0,0,0,0.947941677
+2138,0,0,0,0,0,0,0,0,0,0,0,0,0.948940117
+2139,0,0,0,0,0,0,0,0,0,0,0,0,0.949880321
+2140,0,0,0,0,0,0,0,0,0,0,0,0,0.950676414
+2141,0,0,0,0,0,0,0,0,0,0,0,0,0.951054332
+2142,0,0,0,0,0,0,0,0,0,0,0,0,0.951531833
+2143,0,0,0,0,0,0,0,0,0,0,0,0,0.952326952
+2144,0,0,0,0,0,0,0,0,0,0,0,0,0.952721089
+2145,0,0,0,0,0,0,0,0,0,0,0,0,0.952552047
+2146,0,0,0,0,0,0,0,0,0,0,0,0,0.952417855
+2147,0,0,0,0,0,0,0,0,0,0,0,0,0.952654092
+2148,0,0,0,0,0,0,0,0,0,0,0,0,0.95296197
+2149,0,0,0,0,0,0,0,0,0,0,0,0,0.95331832
+2150,0,0,0,0,0,0,0,0,0,0,0,0,0.953779111
+2151,0,0,0,0,0,0,0,0,0,0,0,0,0.954291677
+2152,0,0,0,0,0,0,0,0,0,0,0,0,0.954837035
+2153,0,0,0,0,0,0,0,0,0,0,0,0,0.955539257
+2154,0,0,0,0,0,0,0,0,0,0,0,0,0.956750259
+2155,0,0,0,0,0,0,0,0,0,0,0,0,0.957986198
+2156,0,0,0,0,0,0,0,0,0,0,0,0,0.959237259
+2157,0,0,0,0,0,0,0,0,0,0,0,0,0.960451396
+2158,0,0,0,0,0,0,0,0,0,0,0,0,0.96141302
+2159,0,0,0,0,0,0,0,0,0,0,0,0,0.96264388
+2160,0,0,0,0,0,0,0,0,0,0,0,0,0.964122014
+2161,0,0,0,0,0,0,0,0,0,0,0,0,0.963609737
+2162,0,0,0,0,0,0,0,0,0,0,0,0,0.963104517
+2163,0,0,0,0,0,0,0,0,0,0,0,0,0.962753979
+2164,0,0,0,0,0,0,0,0,0,0,0,0,0.961850624
+2165,0,0,0,0,0,0,0,0,0,0,0,0,0.960730243
+2166,0,0,0,0,0,0,0,0,0,0,0,0,0.959560745
+2167,0,0,0,0,0,0,0,0,0,0,0,0,0.958377188
+2168,0,0,0,0,0,0,0,0,0,0,0,0,0.956972347
+2169,0,0,0,0,0,0,0,0,0,0,0,0,0.955119849
+2170,0,0,0,0,0,0,0,0,0,0,0,0,0.953076144
+2171,0,0,0,0,0,0,0,0,0,0,0,0,0.95406055
+2172,0,0,0,0,0,0,0,0,0,0,0,0,0.955176712
+2173,0,0,0,0,0,0,0,0,0,0,0,0,0.955719159
+2174,0,0,0,0,0,0,0,0,0,0,0,0,0.955674616
+2175,0,0,0,0,0,0,0,0,0,0,0,0,0.955356546
+2176,0,0,0,0,0,0,0,0,0,0,0,0,0.954611539
+2177,0,0,0,0,0,0,0,0,0,0,0,0,0.953453566
+2178,0,0,0,0,0,0,0,0,0,0,0,0,0.952124922
+2179,0,0,0,0,0,0,0,0,0,0,0,0,0.950597985
+2180,0,0,0,0,0,0,0,0,0,0,0,0,0.948594073
+2181,0,0,0,0,0,0,0,0,0,0,0,0,0.948562399
+2182,0,0,0,0,0,0,0,0,0,0,0,0,0.948548442
+2183,0,0,0,0,0,0,0,0,0,0,0,0,0.94829598
+2184,0,0,0,0,0,0,0,0,0,0,0,0,0.947706109
+2185,0,0,0,0,0,0,0,0,0,0,0,0,0.946620434
+2186,0,0,0,0,0,0,0,0,0,0,0,0,0.94521576
+2187,0,0,0,0,0,0,0,0,0,0,0,0,0.943480979
+2188,0,0,0,0,0,0,0,0,0,0,0,0,0.942137936
+2189,0,0,0,0,0,0,0,0,0,0,0,0,0.940654943
+2190,0,0,0,0,0,0,0,0,0,0,0,0,0.938918576
+2191,0,0,0,0,0,0,0,0,0,0,0,0,0.941493007
+2192,0,0,0,0,0,0,0,0,0,0,0,0,0.943778866
+2193,0,0,0,0,0,0,0,0,0,0,0,0,0.945751584
+2194,0,0,0,0,0,0,0,0,0,0,0,0,0.947277308
+2195,0,0,0,0,0,0,0,0,0,0,0,0,0.948481875
+2196,0,0,0,0,0,0,0,0,0,0,0,0,0.949621704
+2197,0,0,0,0,0,0,0,0,0,0,0,0,0.950767479
+2198,0,0,0,0,0,0,0,0,0,0,0,0,0.951991493
+2199,0,0,0,0,0,0,0,0,0,0,0,0,0.953624457
+2200,0,0,0,0,0,0,0,0,0,0,0,0,0.955262594
+2201,0,0,0,0,0,0,0,0,0,0,0,0,0.952413026
+2202,0,0,0,0,0,0,0,0,0,0,0,0,0.950488752
+2203,0,0,0,0,0,0,0,0,0,0,0,0,0.949721652
+2204,0,0,0,0,0,0,0,0,0,0,0,0,0.949105026
+2205,0,0,0,0,0,0,0,0,0,0,0,0,0.949712169
+2206,0,0,0,0,0,0,0,0,0,0,0,0,0.95167296
+2207,0,0,0,0,0,0,0,0,0,0,0,0,0.955012323
+2208,0,0,0,0,0,0,0,0,0,0,0,0,0.959777857
+2209,0,0,0,0,0,0,0,0,0,0,0,0,0.966208245
+2210,0,0,0,0,0,0,0,0,0,0,0,0,0.973886163
+2211,0,0,0,0,0,0,0,0,0,0,0,0,0.970920044
+2212,0,0,0,0,0,0,0,0,0,0,0,0,0.969139883
+2213,0,0,0,0,0,0,0,0,0,0,0,0,0.968329935
+2214,0,0,0,0,0,0,0,0,0,0,0,0,0.967635904
+2215,0,0,0,0,0,0,0,0,0,0,0,0,0.967555279
+2216,0,0,0,0,0,0,0,0,0,0,0,0,0.968040602
+2217,0,0,0,0,0,0,0,0,0,0,0,0,0.968508397
+2218,0,0,0,0,0,0,0,0,0,0,0,0,0.968956722
+2219,0,0,0,0,0,0,0,0,0,0,0,0,0.969510275
+2220,0,0,0,0,0,0,0,0,0,0,0,0,0.969967732
+2221,0,0,0,0,0,0,0,0,0,0,0,0,0.969097684
+2222,0,0,0,0,0,0,0,0,0,0,0,0,0.968258197
+2223,0,0,0,0,0,0,0,0,0,0,0,0,0.967549788
+2224,0,0,0,0,0,0,0,0,0,0,0,0,0.96650394
+2225,0,0,0,0,0,0,0,0,0,0,0,0,0.965459532
+2226,0,0,0,0,0,0,0,0,0,0,0,0,0.964366923
+2227,0,0,0,0,0,0,0,0,0,0,0,0,0.962929804
+2228,0,0,0,0,0,0,0,0,0,0,0,0,0.961665594
+2229,0,0,0,0,0,0,0,0,0,0,0,0,0.96063821
+2230,0,0,0,0,0,0,0,0,0,0,0,0,0.959368085
+2231,0,0,0,0,0,0,0,0,0,0,0,0,0.959707097
+2232,0,0,0,0,0,0,0,0,0,0,0,0,0.960359643
+2233,0,0,0,0,0,0,0,0,0,0,0,0,0.9616448
+2234,0,0,0,0,0,0,0,0,0,0,0,0,0.962729828
+2235,0,0,0,0,0,0,0,0,0,0,0,0,0.96370081
+2236,0,0,0,0,0,0,0,0,0,0,0,0,0.964773629
+2237,0,0,0,0,0,0,0,0,0,0,0,0,0.965512685
+2238,0,0,0,0,0,0,0,0,0,0,0,0,0.96634935
+2239,0,0,0,0,0,0,0,0,0,0,0,0,0.96753842
+2240,0,0,0,0,0,0,0,0,0,0,0,0,0.96886815
+2241,0,0,0,0,0,0,0,0,0,0,0,0,0.970549249
+2242,0,0,0,0,0,0,0,0,0,0,0,0,0.972426171
+2243,0,0,0,0,0,0,0,0,0,0,0,0,0.974301395
+2244,0,0,0,0,0,0,0,0,0,0,0,0,0.976012041
+2245,0,0,0,0,0,0,0,0,0,0,0,0,0.977203216
+2246,0,0,0,0,0,0,0,0,0,0,0,0,0.978986062
+2247,0,0,0,0,0,0,0,0,0,0,0,0,0.980446263
+2248,0,0,0,0,0,0,0,0,0,0,0,0,0.981524356
+2249,0,0,0,0,0,0,0,0,0,0,0,0,0.982531672
+2250,0,0,0,0,0,0,0,0,0,0,0,0,0.983336508
+2251,0,0,0,0,0,0,0,0,0,0,0,0,0.98463147
+2252,0,0,0,0,0,0,0,0,0,0,0,0,0.986737985
+2253,0,0,0,0,0,0,0,0,0,0,0,0,0.989144288
+2254,0,0,0,0,0,0,0,0,0,0,0,0,0.991223348
+2255,0,0,0,0,0,0,0,0,0,0,0,0,0.99318448
+2256,0,0,0,0,0,0,0,0,0,0,0,0,0.995273324
+2257,0,0,0,0,0,0,0,0,0,0,0,0,0.996704667
+2258,0,0,0,0,0,0,0,0,0,0,0,0,0.998282418
+2259,0,0,0,0,0,0,0,0,0,0,0,0,0.999605161
+2260,0,0,0,0,0,0,0,0,0,0,0,0,1
+2261,0,0,0,0,0,0,0,0,0,0,0,0,0.998654554
+2262,0,0,0,0,0,0,0,0,0,0,0,0,0.995753158
+2263,0,0,0,0,0,0,0,0,0,0,0,0,0.990605371
+2264,0,0,0,0,0,0,0,0,0,0,0,0,0.981520886
+2265,0,0,0,0,0,0,0,0,0,0,0,0,0.968715091
+2266,0,0,0,0,0,0,0,0,0,0,0,0,0.951679125
+2267,0,0,0,0,0,0,0,0,0,0,0,0,0.929343556
+2268,0,0,0,0,0,0,0,0,0,0,0,0,0.902305299
+2269,0,0,0,0,0,0,0,0,0,0,0,0,0.87044084
+2270,0,0,0,0,0,0,0,0,0,0,0,0,0.831947776
+2271,0,0,0,0,0,0,0,0,0,0,0,0,0.786119345
+2272,0,0,0,0,0,0,0,0,0,0,0,0,0.736343248
+2273,0,0,0,0,0,0,0,0,0,0,0,0,0.681862245
+2274,0,0,0,0,0,0,0,0,0,0,0,0,0.623137717
+2275,0,0,0,0,0,0,0,0,0,0,0,0,0.564024643
+2276,0,0,0,0,0,0,0,0,0,0,0,0,0.506650261
+2277,0,0,0,0,0,0,0,0,0,0,0,0,0.451376118
+2278,0,0,0,0,0,0,0,0,0,0,0,0,0.400487569
+2279,0,0,0,0,0,0,0,0,0,0,0,0,0.354176773
+2280,0,0,0,0,0,0,0,0,0,0,0,0,0.309839746
+2281,0,0,0,0,0,0,0,0,0,0,0,0,0.269312679
+2282,0,0,0,0,0,0,0,0,0,0,0,0,0.234102225
+2283,0,0,0,0,0,0,0,0,0,0,0,0,0.20225298
+2284,0,0,0,0,0,0,0,0,0,0,0,0,0.173669677
+2285,0,0,0,0,0,0,0,0,0,0,0,0,0.149356419
+2286,0,0,0,0,0,0,0,0,0,0,0,0,0.128957364
+2287,0,0,0,0,0,0,0,0,0,0,0,0,0.111530972
+2288,0,0,0,0,0,0,0,0,0,0,0,0,0.09689948
+2289,0,0,0,0,0,0,0,0,0,0,0,0,0.084874763
+2290,0,0,0,0,0,0,0,0,0,0,0,0,0.074063524
+2291,0,0,0,0,0,0,0,0,0,0,0,0,0.064469344
+2292,0,0,0,0,0,0,0,0,0,0,0,0,0.056321561
+2293,0,0,0,0,0,0,0,0,0,0,0,0,0.049381236
+2294,0,0,0,0,0,0,0,0,0,0,0,0,0.043196026
+2295,0,0,0,0,0,0,0,0,0,0,0,0,0.037986086
+2296,0,0,0,0,0,0,0,0,0,0,0,0,0.033468826
+2297,0,0,0,0,0,0,0,0,0,0,0,0,0.028983375
+2298,0,0,0,0,0,0,0,0,0,0,0,0,0.025085752
+2299,0,0,0,0,0,0,0,0,0,0,0,0,0.020007676
+2300,0,0,0,0,0,0,0,0,0,0,0,0,0.013837921
+2301,0,0,0,0,0,0,0,0,0,0,0,0,0.008464001
+2302,0,0,0,0,0,0,0,0,0,0,0,0,0.004443102
+2303,0,0,0,0,0,0,0,0,0,0,0,0,0.000848571
+2304,0,0,0,0,0,0,0,0,0,0,0,0,0
+2305,0,0,0,0,0,0,0,0,0,0,0,0,0
+2306,0,0,0,0,0,0,0,0,0,0,0,0,0
+2307,0,0,0,0,0,0,0,0,0,0,0,0,0
+2308,0,0,0,0,0,0,0,0,0,0,0,0,0
+2309,0,0,0,0,0,0,0,0,0,0,0,0,0
+2310,0,0,0,0,0,0,0,0,0,0,0,0,0
+2311,0,0,0,0,0,0,0,0,0,0,0,0,0
+2312,0,0,0,0,0,0,0,0,0,0,0,0,0
+2313,0,0,0,0,0,0,0,0,0,0,0,0,0
+2314,0,0,0,0,0,0,0,0,0,0,0,0,0
+2315,0,0,0,0,0,0,0,0,0,0,0,0,0
+2316,0,0,0,0,0,0,0,0,0,0,0,0,0
+2317,0,0,0,0,0,0,0,0,0,0,0,0,0
+2318,0,0,0,0,0,0,0,0,0,0,0,0,0
+2319,0,0,0,0,0,0,0,0,0,0,0,0,0
+2320,0,0,0,0,0,0,0,0,0,0,0,0,0
+2321,0,0,0,0,0,0,0,0,0,0,0,0,0
+2322,0,0,0,0,0,0,0,0,0,0,0,0,0
+2323,0,0,0,0,0,0,0,0,0,0,0,0,0
+2324,0,0,0,0,0,0,0,0,0,0,0,0,0
+2325,0,0,0,0,0,0,0,0,0,0,0,0,0
+2326,0,0,0,0,0,0,0,0,0,0,0,0,0
+2327,0,0,0,0,0,0,0,0,0,0,0,0,0
+2328,0,0,0,0,0,0,0,0,0,0,0,0,0
+2329,0,0,0,0,0,0,0,0,0,0,0,0,0
+2330,0,0,0,0,0,0,0,0,0,0,0,0,0
+2331,0,0,0,0,0,0,0,0,0,0,0,0,0
+2332,0,0,0,0,0,0,0,0,0,0,0,0,0
+2333,0,0,0,0,0,0,0,0,0,0,0,0,0
+2334,0,0,0,0,0,0,0,0,0,0,0,0,0
+2335,0,0,0,0,0,0,0,0,0,0,0,0,0
+2336,0,0,0,0,0,0,0,0,0,0,0,0,0
+2337,0,0,0,0,0,0,0,0,0,0,0,0,0
+2338,0,0,0,0,0,0,0,0,0,0,0,0,0
+2339,0,0,0,0,0,0,0,0,0,0,0,0,0
+2340,0,0,0,0,0,0,0,0,0,0,0,0,0
+2341,0,0,0,0,0,0,0,0,0,0,0,0,0
+2342,0,0,0,0,0,0,0,0,0,0,0,0,0
+2343,0,0,0,0,0,0,0,0,0,0,0,0,0
+2344,0,0,0,0,0,0,0,0,0,0,0,0,0
+2345,0,0,0,0,0,0,0,0,0,0,0,0,0
+2346,0,0,0,0,0,0,0,0,0,0,0,0,0
+2347,0,0,0,0,0,0,0,0,0,0,0,0,0
+2348,0,0,0,0,0,0,0,0,0,0,0,0,0
+2349,0,0,0,0,0,0,0,0,0,0,0,0,0
+2350,0,0,0,0,0,0,0,0,0,0,0,0,0
+2351,0,0,0,0,0,0,0,0,0,0,0,0,0
+2352,0,0,0,0,0,0,0,0,0,0,0,0,0
+2353,0,0,0,0,0,0,0,0,0,0,0,0,0
+2354,0,0,0,0,0,0,0,0,0,0,0,0,0
+2355,0,0,0,0,0,0,0,0,0,0,0,0,0
+2356,0,0,0,0,0,0,0,0,0,0,0,0,0
+2357,0,0,0,0,0,0,0,0,0,0,0,0,0
+2358,0,0,0,0,0,0,0,0,0,0,0,0,0
+2359,0,0,0,0,0,0,0,0,0,0,0,0,0
+2360,0,0,0,0,0,0,0,0,0,0,0,0,0
+2361,0,0,0,0,0,0,0,0,0,0,0,0,0
+2362,0,0,0,0,0,0,0,0,0,0,0,0,0
+2363,0,0,0,0,0,0,0,0,0,0,0,0,0
+2364,0,0,0,0,0,0,0,0,0,0,0,0,0
+2365,0,0,0,0,0,0,0,0,0,0,0,0,0
+2366,0,0,0,0,0,0,0,0,0,0,0,0,0
+2367,0,0,0,0,0,0,0,0,0,0,0,0,0
+2368,0,0,0,0,0,0,0,0,0,0,0,0,0
+2369,0,0,0,0,0,0,0,0,0,0,0,0,0
+2370,0,0,0,0,0,0,0,0,0,0,0,0,0
+2371,0,0,0,0,0,0,0,0,0,0,0,0,0
+2372,0,0,0,0,0,0,0,0,0,0,0,0,0
+2373,0,0,0,0,0,0,0,0,0,0,0,0,0
+2374,0,0,0,0,0,0,0,0,0,0,0,0,0
+2375,0,0,0,0,0,0,0,0,0,0,0,0,0
+2376,0,0,0,0,0,0,0,0,0,0,0,0,0
+2377,0,0,0,0,0,0,0,0,0,0,0,0,0
+2378,0,0,0,0,0,0,0,0,0,0,0,0,0
+2379,0,0,0,0,0,0,0,0,0,0,0,0,0
+2380,0,0,0,0,0,0,0,0,0,0,0,0,0
+2381,0,0,0,0,0,0,0,0,0,0,0,0,0
+2382,0,0,0,0,0,0,0,0,0,0,0,0,0
+2383,0,0,0,0,0,0,0,0,0,0,0,0,0
+2384,0,0,0,0,0,0,0,0,0,0,0,0,0
+2385,0,0,0,0,0,0,0,0,0,0,0,0,0
+2386,0,0,0,0,0,0,0,0,0,0,0,0,0
+2387,0,0,0,0,0,0,0,0,0,0,0,0,0
+2388,0,0,0,0,0,0,0,0,0,0,0,0,0
+2389,0,0,0,0,0,0,0,0,0,0,0,0,0
+2390,0,0,0,0,0,0,0,0,0,0,0,0,0
+2391,0,0,0,0,0,0,0,0,0,0,0,0,0
+2392,0,0,0,0,0,0,0,0,0,0,0,0,0
+2393,0,0,0,0,0,0,0,0,0,0,0,0,0
+2394,0,0,0,0,0,0,0,0,0,0,0,0,0
+2395,0,0,0,0,0,0,0,0,0,0,0,0,0
+2396,0,0,0,0,0,0,0,0,0,0,0,0,0
+2397,0,0,0,0,0,0,0,0,0,0,0,0,0
+2398,0,0,0,0,0,0,0,0,0,0,0,0,0
+2399,0,0,0,0,0,0,0,0,0,0,0,0,0
+2400,0,0,0,0,0,0,0,0,0,0,0,0,0
+2401,0,0,0,0,0,0,0,0,0,0,0,0,0
+2402,0,0,0,0,0,0,0,0,0,0,0,0,0
+2403,0,0,0,0,0,0,0,0,0,0,0,0,0
+2404,0,0,0,0,0,0,0,0,0,0,0,0,0
+2405,0,0,0,0,0,0,0,0,0,0,0,0,0
+2406,0,0,0,0,0,0,0,0,0,0,0,0,0
+2407,0,0,0,0,0,0,0,0,0,0,0,0,0
+2408,0,0,0,0,0,0,0,0,0,0,0,0,0
+2409,0,0,0,0,0,0,0,0,0,0,0,0,0
+2410,0,0,0,0,0,0,0,0,0,0,0,0,0
+2411,0,0,0,0,0,0,0,0,0,0,0,0,0
+2412,0,0,0,0,0,0,0,0,0,0,0,0,0
+2413,0,0,0,0,0,0,0,0,0,0,0,0,0
+2414,0,0,0,0,0,0,0,0,0,0,0,0,0
+2415,0,0,0,0,0,0,0,0,0,0,0,0,0
+2416,0,0,0,0,0,0,0,0,0,0,0,0,0
+2417,0,0,0,0,0,0,0,0,0,0,0,0,0
+2418,0,0,0,0,0,0,0,0,0,0,0,0,0
+2419,0,0,0,0,0,0,0,0,0,0,0,0,0
+2420,0,0,0,0,0,0,0,0,0,0,0,0,0
+2421,0,0,0,0,0,0,0,0,0,0,0,0,0
+2422,0,0,0,0,0,0,0,0,0,0,0,0,0
+2423,0,0,0,0,0,0,0,0,0,0,0,0,0
+2424,0,0,0,0,0,0,0,0,0,0,0,0,0
+2425,0,0,0,0,0,0,0,0,0,0,0,0,0
+2426,0,0,0,0,0,0,0,0,0,0,0,0,0
+2427,0,0,0,0,0,0,0,0,0,0,0,0,0
+2428,0,0,0,0,0,0,0,0,0,0,0,0,0
+2429,0,0,0,0,0,0,0,0,0,0,0,0,0
+2430,0,0,0,0,0,0,0,0,0,0,0,0,0
+2431,0,0,0,0,0,0,0,0,0,0,0,0,0
+2432,0,0,0,0,0,0,0,0,0,0,0,0,0
+2433,0,0,0,0,0,0,0,0,0,0,0,0,0
+2434,0,0,0,0,0,0,0,0,0,0,0,0,0
+2435,0,0,0,0,0,0,0,0,0,0,0,0,0
+2436,0,0,0,0,0,0,0,0,0,0,0,0,0
+2437,0,0,0,0,0,0,0,0,0,0,0,0,0
+2438,0,0,0,0,0,0,0,0,0,0,0,0,0
+2439,0,0,0,0,0,0,0,0,0,0,0,0,0
+2440,0,0,0,0,0,0,0,0,0,0,0,0,0
+2441,0,0,0,0,0,0,0,0,0,0,0,0,0
+2442,0,0,0,0,0,0,0,0,0,0,0,0,0
+2443,0,0,0,0,0,0,0,0,0,0,0,0,0
+2444,0,0,0,0,0,0,0,0,0,0,0,0,0
+2445,0,0,0,0,0,0,0,0,0,0,0,0,0
+2446,0,0,0,0,0,0,0,0,0,0,0,0,0
+2447,0,0,0,0,0,0,0,0,0,0,0,0,0
+2448,0,0,0,0,0,0,0,0,0,0,0,0,0
+2449,0,0,0,0,0,0,0,0,0,0,0,0,0
+2450,0,0,0,0,0,0,0,0,0,0,0,0,0
+2451,0,0,0,0,0,0,0,0,0,0,0,0,0
+2452,0,0,0,0,0,0,0,0,0,0,0,0,0
+2453,0,0,0,0,0,0,0,0,0,0,0,0,0
+2454,0,0,0,0,0,0,0,0,0,0,0,0,0
+2455,0,0,0,0,0,0,0,0,0,0,0,0,0
+2456,0,0,0,0,0,0,0,0,0,0,0,0,0
+2457,0,0,0,0,0,0,0,0,0,0,0,0,0
+2458,0,0,0,0,0,0,0,0,0,0,0,0,0
+2459,0,0,0,0,0,0,0,0,0,0,0,0,0
+2460,0,0,0,0,0,0,0,0,0,0,0,0,0
+2461,0,0,0,0,0,0,0,0,0,0,0,0,0
+2462,0,0,0,0,0,0,0,0,0,0,0,0,0
+2463,0,0,0,0,0,0,0,0,0,0,0,0,0
+2464,0,0,0,0,0,0,0,0,0,0,0,0,0
+2465,0,0,0,0,0,0,0,0,0,0,0,0,0
+2466,0,0,0,0,0,0,0,0,0,0,0,0,0
+2467,0,0,0,0,0,0,0,0,0,0,0,0,0
+2468,0,0,0,0,0,0,0,0,0,0,0,0,0
+2469,0,0,0,0,0,0,0,0,0,0,0,0,0
+2470,0,0,0,0,0,0,0,0,0,0,0,0,0
+2471,0,0,0,0,0,0,0,0,0,0,0,0,0
+2472,0,0,0,0,0,0,0,0,0,0,0,0,0
+2473,0,0,0,0,0,0,0,0,0,0,0,0,0
+2474,0,0,0,0,0,0,0,0,0,0,0,0,0
+2475,0,0,0,0,0,0,0,0,0,0,0,0,0
+2476,0,0,0,0,0,0,0,0,0,0,0,0,0
+2477,0,0,0,0,0,0,0,0,0,0,0,0,0
+2478,0,0,0,0,0,0,0,0,0,0,0,0,0
+2479,0,0,0,0,0,0,0,0,0,0,0,0,0
+2480,0,0,0,0,0,0,0,0,0,0,0,0,0
+2481,0,0,0,0,0,0,0,0,0,0,0,0,0
+2482,0,0,0,0,0,0,0,0,0,0,0,0,0
+2483,0,0,0,0,0,0,0,0,0,0,0,0,0
+2484,0,0,0,0,0,0,0,0,0,0,0,0,0
+2485,0,0,0,0,0,0,0,0,0,0,0,0,0
+2486,0,0,0,0,0,0,0,0,0,0,0,0,0
+2487,0,0,0,0,0,0,0,0,0,0,0,0,0
+2488,0,0,0,0,0,0,0,0,0,0,0,0,0
+2489,0,0,0,0,0,0,0,0,0,0,0,0,0
+2490,0,0,0,0,0,0,0,0,0,0,0,0,0
+2491,0,0,0,0,0,0,0,0,0,0,0,0,0
+2492,0,0,0,0,0,0,0,0,0,0,0,0,0
+2493,0,0,0,0,0,0,0,0,0,0,0,0,0
+2494,0,0,0,0,0,0,0,0,0,0,0,0,0
+2495,0,0,0,0,0,0,0,0,0,0,0,0,0
+2496,0,0,0,0,0,0,0,0,0,0,0,0,0
+2497,0,0,0,0,0,0,0,0,0,0,0,0,0
+2498,0,0,0,0,0,0,0,0,0,0,0,0,0
+2499,0,0,0,0,0,0,0,0,0,0,0,0,0
+2500,0,0,0,0,0,0,0,0,0,0,0,0,0
+2501,0,0,0,0,0,0,0,0,0,0,0,0,0
+2502,0,0,0,0,0,0,0,0,0,0,0,0,0
+2503,0,0,0,0,0,0,0,0,0,0,0,0,0
+2504,0,0,0,0,0,0,0,0,0,0,0,0,0
+2505,0,0,0,0,0,0,0,0,0,0,0,0,0
+2506,0,0,0,0,0,0,0,0,0,0,0,0,0
+2507,0,0,0,0,0,0,0,0,0,0,0,0,0
+2508,0,0,0,0,0,0,0,0,0,0,0,0,0
+2509,0,0,0,0,0,0,0,0,0,0,0,0,0
+2510,0,0,0,0,0,0,0,0,0,0,0,0,0
+2511,0,0,0,0,0,0,0,0,0,0,0,0,0
+2512,0,0,0,0,0,0,0,0,0,0,0,0,0
+2513,0,0,0,0,0,0,0,0,0,0,0,0,0
+2514,0,0,0,0,0,0,0,0,0,0,0,0,0
+2515,0,0,0,0,0,0,0,0,0,0,0,0,0
+2516,0,0,0,0,0,0,0,0,0,0,0,0,0
+2517,0,0,0,0,0,0,0,0,0,0,0,0,0
+2518,0,0,0,0,0,0,0,0,0,0,0,0,0
+2519,0,0,0,0,0,0,0,0,0,0,0,0,0
+2520,0,0,0,0,0,0,0,0,0,0,0,0,0
+2521,0,0,0,0,0,0,0,0,0,0,0,0,0
+2522,0,0,0,0,0,0,0,0,0,0,0,0,0
+2523,0,0,0,0,0,0,0,0,0,0,0,0,0
+2524,0,0,0,0,0,0,0,0,0,0,0,0,0
+2525,0,0,0,0,0,0,0,0,0,0,0,0,0
+2526,0,0,0,0,0,0,0,0,0,0,0,0,0
+2527,0,0,0,0,0,0,0,0,0,0,0,0,0
+2528,0,0,0,0,0,0,0,0,0,0,0,0,0
+2529,0,0,0,0,0,0,0,0,0,0,0,0,0
+2530,0,0,0,0,0,0,0,0,0,0,0,0,0
+2531,0,0,0,0,0,0,0,0,0,0,0,0,0
+2532,0,0,0,0,0,0,0,0,0,0,0,0,0
+2533,0,0,0,0,0,0,0,0,0,0,0,0,0
+2534,0,0,0,0,0,0,0,0,0,0,0,0,0
+2535,0,0,0,0,0,0,0,0,0,0,0,0,0
+2536,0,0,0,0,0,0,0,0,0,0,0,0,0
+2537,0,0,0,0,0,0,0,0,0,0,0,0,0
+2538,0,0,0,0,0,0,0,0,0,0,0,0,0
+2539,0,0,0,0,0,0,0,0,0,0,0,0,0
+2540,0,0,0,0,0,0,0,0,0,0,0,0,0
+2541,0,0,0,0,0,0,0,0,0,0,0,0,0
+2542,0,0,0,0,0,0,0,0,0,0,0,0,0
+2543,0,0,0,0,0,0,0,0,0,0,0,0,0
+2544,0,0,0,0,0,0,0,0,0,0,0,0,0
+2545,0,0,0,0,0,0,0,0,0,0,0,0,0
+2546,0,0,0,0,0,0,0,0,0,0,0,0,0
+2547,0,0,0,0,0,0,0,0,0,0,0,0,0
+2548,0,0,0,0,0,0,0,0,0,0,0,0,0
+2549,0,0,0,0,0,0,0,0,0,0,0,0,0
+2550,0,0,0,0,0,0,0,0,0,0,0,0,0
+2551,0,0,0,0,0,0,0,0,0,0,0,0,0
+2552,0,0,0,0,0,0,0,0,0,0,0,0,0
+2553,0,0,0,0,0,0,0,0,0,0,0,0,0
+2554,0,0,0,0,0,0,0,0,0,0,0,0,0
+2555,0,0,0,0,0,0,0,0,0,0,0,0,0
+2556,0,0,0,0,0,0,0,0,0,0,0,0,0
+2557,0,0,0,0,0,0,0,0,0,0,0,0,0
+2558,0,0,0,0,0,0,0,0,0,0,0,0,0
+2559,0,0,0,0,0,0,0,0,0,0,0,0,0
+2560,0,0,0,0,0,0,0,0,0,0,0,0,0
+2561,0,0,0,0,0,0,0,0,0,0,0,0,0
+2562,0,0,0,0,0,0,0,0,0,0,0,0,0
+2563,0,0,0,0,0,0,0,0,0,0,0,0,0
+2564,0,0,0,0,0,0,0,0,0,0,0,0,0
+2565,0,0,0,0,0,0,0,0,0,0,0,0,0
+2566,0,0,0,0,0,0,0,0,0,0,0,0,0
+2567,0,0,0,0,0,0,0,0,0,0,0,0,0
+2568,0,0,0,0,0,0,0,0,0,0,0,0,0
+2569,0,0,0,0,0,0,0,0,0,0,0,0,0
+2570,0,0,0,0,0,0,0,0,0,0,0,0,0
+2571,0,0,0,0,0,0,0,0,0,0,0,0,0
+2572,0,0,0,0,0,0,0,0,0,0,0,0,0
+2573,0,0,0,0,0,0,0,0,0,0,0,0,0
+2574,0,0,0,0,0,0,0,0,0,0,0,0,0
+2575,0,0,0,0,0,0,0,0,0,0,0,0,0
+2576,0,0,0,0,0,0,0,0,0,0,0,0,0
+2577,0,0,0,0,0,0,0,0,0,0,0,0,0
+2578,0,0,0,0,0,0,0,0,0,0,0,0,0
+2579,0,0,0,0,0,0,0,0,0,0,0,0,0
+2580,0,0,0,0,0,0,0,0,0,0,0,0,0
+2581,0,0,0,0,0,0,0,0,0,0,0,0,0
+2582,0,0,0,0,0,0,0,0,0,0,0,0,0
+2583,0,0,0,0,0,0,0,0,0,0,0,0,0
+2584,0,0,0,0,0,0,0,0,0,0,0,0,0
+2585,0,0,0,0,0,0,0,0,0,0,0,0,0
+2586,0,0,0,0,0,0,0,0,0,0,0,0,0
+2587,0,0,0,0,0,0,0,0,0,0,0,0,0
+2588,0,0,0,0,0,0,0,0,0,0,0,0,0
+2589,0,0,0,0,0,0,0,0,0,0,0,0,0
+2590,0,0,0,0,0,0,0,0,0,0,0,0,0
+2591,0,0,0,0,0,0,0,0,0,0,0,0,0
+2592,0,0,0,0,0,0,0,0,0,0,0,0,0
+2593,0,0,0,0,0,0,0,0,0,0,0,0,0
+2594,0,0,0,0,0,0,0,0,0,0,0,0,0
+2595,0,0,0,0,0,0,0,0,0,0,0,0,0
+2596,0,0,0,0,0,0,0,0,0,0,0,0,0
+2597,0,0,0,0,0,0,0,0,0,0,0,0,0
+2598,0,0,0,0,0,0,0,0,0,0,0,0,0
+2599,0,0,0,0,0,0,0,0,0,0,0,0,0
+2600,0,0,0,0,0,0,0,0,0,0,0,0,0
\ No newline at end of file
Modified: grass/branches/releasebranch_7_4/imagery/i.atcorr/sensors_csv/worldview2.csv
--- grass/branches/releasebranch_7_4/imagery/i.atcorr/sensors_csv/worldview2.csv 2018-03-24 16:42:50 UTC (rev 72556)
+++ grass/branches/releasebranch_7_4/imagery/i.atcorr/sensors_csv/worldview2.csv 2018-03-24 16:50:40 UTC (rev 72557)
@@ -1,752 +1,752 @@
-nm_Band,Panchromatic,Blue,Green,Red,NIR1,Coastal,Yellow,Red Edge,NIR2
-350,0.000005534066300,0.000000750195790,0.000000415708370,0.000000312285900,0.000000342493730,0.000001939236900,0.000000312145220,0.000000131873370,0.000000275156740
-351,0.000005802300300,0.000000537313250,0.000000354692410,0.000000219603400,0.000000171666780,0.000002467298900,0.000000196138640,0.000000167608430,0.000001041523500
-352,0.000006073528000,0.000000323629890,0.000000292899220,0.000000126933950,0.000000000007231,0.000002996602900,0.000000079068775,0.000000203777120,0.000001817336500
-353,0.000006305955500,0.000000405748600,0.000000227387060,0.000000115596290,0.000000011505368,0.000003666522200,0.000000086638033,0.000000172075200,0.000012109853000
-354,0.000006549796700,0.000000487780370,0.000000161933660,0.000000104737010,0.000000023050938,0.000004335725400,0.000000094198330,0.000000140400520,0.000022395752000
-355,0.000006775856800,0.000000304219600,0.000000132493610,0.000000069418112,0.000000024305981,0.000003273195800,0.000000098318436,0.000000281591980,0.000019874005000
-356,0.000005816675600,0.000000122639460,0.000000102704820,0.000000034310218,0.000000025556959,0.000002182573500,0.000000102424700,0.000000422392870,0.000017379704000
-357,0.000004932278300,0.000000187190720,0.000000136390060,0.000000037976255,0.000000049849543,0.000002577129700,0.000000091299982,0.000000287356210,0.000063645450000
-358,0.000004022544600,0.000000252661760,0.000000171670650,0.000000041729825,0.000000074782573,0.000002986845200,0.000000079715824,0.000000147392150,0.000111139400000
-359,0.000003133088300,0.000000274459420,0.000000168374770,0.000000060845513,0.000000080374600,0.000002382327400,0.000000063937148,0.000000159550110,0.000093464106000
-360,0.000002184622600,0.000000295025010,0.000000164745560,0.000000080825989,0.000000086016870,0.000001748797500,0.000000047188687,0.000000170877180,0.000074834976000
-361,0.000002233841400,0.000000203773890,0.000000129812290,0.000000054246302,0.000000045018286,0.000002477441200,0.000000039688930,0.000000145983390,0.000042279220000
-362,0.000002278846600,0.000000102069340,0.000000090592164,0.000000025099509,0.000000000007744,0.000003273669000,0.000000031329589,0.000000116943360,0.000006511440400
-363,0.000002437437800,0.000000171556970,0.000000108813880,0.000000055782338,0.000000013081201,0.000003422352600,0.000000045789926,0.000000094296773,0.000003810523600
-364,0.000002570044800,0.000000251885020,0.000000128560710,0.000000091464712,0.000000028505989,0.000003579572400,0.000000062466244,0.000000065731766,0.000000541534760
-365,0.000002743944300,0.000000246454100,0.000000150248650,0.000000092652578,0.000000049819020,0.000003557852200,0.000000061326276,0.000000112978860,0.000000481495510
-366,0.000002985018700,0.000000236271060,0.000000173412540,0.000000092360666,0.000000074411918,0.000003478218500,0.000000058751547,0.000000167259990,0.000000398381730
-367,0.000003233177500,0.000000282450200,0.000000192435500,0.000000105191440,0.000000086525060,0.000004069587200,0.000000091275749,0.000000189182260,0.000000542948420
-368,0.000003479195300,0.000000332879060,0.000000212101180,0.000000118814000,0.000000099571845,0.000004708788100,0.000000128106530,0.000000212088880,0.000000705788800
-369,0.000003815296500,0.000000382418900,0.000000247338980,0.000000157213690,0.000000079943263,0.000003929972900,0.000000107870130,0.000000203220450,0.000000520757740
-370,0.000004125480400,0.000000435206860,0.000000284962360,0.000000200442100,0.000000055185195,0.000002941125000,0.000000081922881,0.000000189535920,0.000000289158020
-371,0.000004039379200,0.000000445110540,0.000000264215250,0.000000162533330,0.000000032570931,0.000004485195900,0.000000080006243,0.000000218817990,0.000000218626420
-372,0.000003892147000,0.000000450903520,0.000000236635990,0.000000116593190,0.000000005988468,0.000006219559500,0.000000076844635,0.000000250279600,0.000000134735150
-373,0.000003641406000,0.000000458661570,0.000000277902000,0.000000134228610,0.000000029069855,0.000006206777900,0.000000086894931,0.000000234318320,0.000000132959950
-374,0.000003332141500,0.000000464527090,0.000000322273000,0.000000153096770,0.000000054657932,0.000006154692400,0.000000097977873,0.000000214716180,0.000000130168220
-375,0.000002972529400,0.000000409999480,0.000000249117200,0.000000138036900,0.000000028747439,0.000005371632500,0.000000084437388,0.000000175878240,0.000000161045830
-376,0.000003349876000,0.000000347164090,0.000000166652150,0.000000120339520,0.000000000021881,0.000004472136000,0.000000069075230,0.000000132139200,0.000000194350080
-377,0.000003697460300,0.000000426253780,0.000000277484210,0.000000152097260,0.000000017846858,0.000004825806600,0.000000077627405,0.000000171926590,0.000000243038480
-378,0.000004060768700,0.000000509727210,0.000000395080390,0.000000185652250,0.000000036835017,0.000005184137800,0.000000086129318,0.000000214422260,0.000000295256860
-379,0.000004489825600,0.000000472219870,0.000000386034010,0.000000174494800,0.000000032827616,0.000006269802500,0.000000081038572,0.000000238693530,0.000000221582930
-380,0.000004945195600,0.000000430816780,0.000000375568490,0.000000162312050,0.000000028331600,0.000007416447700,0.000000074765146,0.000000264698020,0.000000141050870
-381,0.000004679664600,0.000000367005640,0.000000279515970,0.000000120937590,0.000000014605447,0.000009019071500,0.000000071268524,0.000000246172550,0.000000172612520
-382,0.000004401131000,0.000000298126510,0.000000177411070,0.000000076471255,0.000000000027496,0.000010744338000,0.000000067458295,0.000000225703940,0.000000204848670
-383,0.000004068936600,0.000000344531880,0.000000256496720,0.000000119818170,0.000000007624928,0.000016256417000,0.000000052760819,0.000000288898890,0.000000182722540
-384,0.000003721761900,0.000000391673440,0.000000338401060,0.000000164722680,0.000000015532055,0.000021965940000,0.000000037698682,0.000000353794530,0.000000159652520
-385,0.000003357411100,0.000000514891320,0.000000425352290,0.000000236616140,0.000000030714551,0.000045379730000,0.000000071229124,0.000000340166840,0.000000209570120
-386,0.000003493892800,0.000000642184700,0.000000514517330,0.000000311441560,0.000000046416714,0.000069595988000,0.000000106133670,0.000000325876120,0.000000260160220
-387,0.000003606539100,0.000000606665450,0.000000479546880,0.000000303871940,0.000000045838473,0.000138061160000,0.000000223287410,0.000000345223480,0.000000243280540
-388,0.000003726294400,0.000000571076220,0.000000443698400,0.000000296071770,0.000000045238040,0.000208076440000,0.000000343012260,0.000000365462690,0.000000225974670
-389,0.000003868703600,0.000000646678520,0.000000432036580,0.000000326331530,0.000000074660844,0.000418003070000,0.000000469610490,0.000000559896290,0.000000231721570
-390,0.000004014014600,0.000000724472320,0.000000419126480,0.000000357437210,0.000000104777560,0.000634651030000,0.000000600764750,0.000000760476370,0.000000236517760
-391,0.000004410288600,0.000000628364100,0.000000410328160,0.000000256333550,0.000000053176684,0.001257734500000,0.000005614135100,0.000001556908100,0.000000236386390
-392,0.000004815473600,0.000000528742630,0.000000401195520,0.000000153148490,0.000000000034087,0.001896352100000,0.000010751859000,0.000002367600500,0.000000236188200
-393,0.000005206465800,0.000000509839310,0.000000364189870,0.000000193326220,0.000000002443595,0.004933615100000,0.000031420874000,0.000002141054500,0.000000259150560
-394,0.000005596776500,0.000000491545490,0.000000327335620,0.000000234617160,0.000000004889554,0.008012588100000,0.000052311232000,0.000001916902400,0.000000282412050
-395,0.000006027536400,0.000000583070940,0.000000369657970,0.000000251164880,0.000000008251118,0.027428402000000,0.000027310406000,0.000001297489500,0.000000225345580
-396,0.000005651665500,0.000000677874320,0.000000413032300,0.000000267503160,0.000000011709429,0.047372325000000,0.000001525818700,0.000000666378640,0.000000166628980
-397,0.000005242280900,0.000000718051220,0.000000472611900,0.000000342056690,0.000000037449412,0.103999930000000,0.000000813247610,0.000001080999600,0.000000189574840
-398,0.000004829292600,0.000000758947780,0.000000532641050,0.000000418124630,0.000000063792528,0.161805980000000,0.000000088093860,0.000001510160100,0.000000212971580
-399,0.000004394308000,0.000001770039200,0.000000488416120,0.000000357193910,0.000000120639130,0.258051360000000,0.000000049879824,0.000001764559600,0.000000213739070
-400,0.000003950972600,0.000002804844300,0.000000442599220,0.000000295126210,0.000000179224540,0.355988370000000,0.000000010640207,0.000002017217200,0.000000214493210
-401,0.000003816988700,0.000002652837000,0.000000465532260,0.000000298416020,0.000000090053008,0.459027750000000,0.000000044854861,0.000001440977900,0.000000178662900
-402,0.000003681547000,0.000002499236600,0.000000487929380,0.000000301111650,0.000000000038089,0.563065310000000,0.000000079066967,0.000000859011330,0.000000141314930
-403,0.000003542732000,0.000002303399700,0.000000481823300,0.000000300566950,0.000000054872372,0.622093700000000,0.000000059931642,0.000001417375600,0.000000143093390
-404,0.000003402606200,0.000002115676800,0.000000476401660,0.000000300008930,0.000000110357620,0.681618750000000,0.000000040355178,0.000001980565300,0.000000144883270
-405,0.000003266767900,0.000001654245000,0.000000495356600,0.000000287379600,0.000000104372740,0.700719040000000,0.000000031332756,0.000001640783000,0.000000177840100
-406,0.000003450752000,0.000001185261800,0.000000515328940,0.000000273888330,0.000000098281639,0.720055100000000,0.000000022232041,0.000001295397800,0.000000211306720
-407,0.000003633946500,0.000001074040700,0.000000501353800,0.000000337397790,0.000000097745022,0.733055320000000,0.000000080344234,0.000001097399100,0.000000223932680
-408,0.000003819910600,0.000000956651570,0.000000487072880,0.000000401979380,0.000000096482881,0.746194410000000,0.000000138830910,0.000000895797060,0.000000235544830
-409,0.000004005821600,0.000001758766700,0.000000504220290,0.000000407749090,0.000000096383523,0.755713450000000,0.000000156727940,0.000000940088290,0.000000319689890
-410,0.000004187329300,0.000002566782100,0.000000520767390,0.000000413567060,0.000000096277066,0.765307100000000,0.000000174841860,0.000000978403340,0.000000404880010
-411,0.000004587363800,0.000003868368800,0.000000459553480,0.000000389647350,0.000000138634880,0.773397580000000,0.000000188068820,0.000001051811000,0.000000311324840
-412,0.000004982438000,0.000005175203700,0.000000398086190,0.000000364973580,0.000000181163370,0.781513020000000,0.000000201347590,0.000001125506100,0.000000218614580
-413,0.000005418119100,0.000007134031600,0.000000382188510,0.000000354754720,0.000000169631900,0.794170470000000,0.000000184191720,0.000000996862270,0.000000212949870
-414,0.000005860288300,0.000009123790800,0.000000365994780,0.000000344997880,0.000000157896700,0.806951290000000,0.000000166739720,0.000000866037160,0.000000208419840
-415,0.000006291701500,0.000013481310000,0.000000359035070,0.000000622912100,0.000000086310205,0.817088000000000,0.000000134675390,0.000000877214850,0.000000158073820
-416,0.000005726999100,0.000017926625000,0.000000351987680,0.000000905054100,0.000000014190521,0.827297410000000,0.000000101533740,0.000000888473670,0.000000107193690
-417,0.000005143254600,0.000024287438000,0.000000469223900,0.000000685657960,0.000000050353342,0.834880830000000,0.000000162300750,0.000001607573100,0.000000135300880
-418,0.000004556301800,0.000030789440000,0.000000586269430,0.000000461028200,0.000000086488329,0.842494140000000,0.000000223392630,0.000002337237200,0.000000164825440
-419,0.000003975406500,0.000036011530000,0.000000462192280,0.000000373248620,0.000000090637245,0.852104840000000,0.000000212619530,0.000001741479900,0.000000118505650
-420,0.000003395338200,0.000041176410000,0.000000337673680,0.000000285253130,0.000000094077807,0.861780010000000,0.000000202477230,0.000001146450300,0.000000071843712
-421,0.000004461446100,0.000045458544000,0.000000427344630,0.000000303370750,0.000000072613065,0.870335500000000,0.000000194214220,0.000001089338600,0.000000116447040
-422,0.000005535212800,0.000049770878000,0.000000518488290,0.000000321613900,0.000000050614772,0.878935440000000,0.000000186639760,0.000001024956400,0.000000161243230
-423,0.000006621517300,0.000053276261000,0.000000459089690,0.000000289955310,0.000000052421410,0.888089860000000,0.000000335600390,0.000000741182030,0.000000216358990
-424,0.000007689394600,0.000056920787000,0.000000399160170,0.000000258012470,0.000000054242307,0.897298820000000,0.000000485850150,0.000000452844790,0.000000270647920
-425,0.000008838899400,0.000070128558000,0.000000374122760,0.000000284931860,0.000000102132090,0.905055220000000,0.000000333295240,0.000000740957140,0.000000230080250
-426,0.000009509418700,0.000083346526000,0.000000348838780,0.000000311395700,0.000000150083890,0.912854630000000,0.000000180067830,0.000001036611800,0.000000189125350
-427,0.000010164798000,0.000116584200000,0.000000362438380,0.000000286296980,0.000000145096020,0.915665070000000,0.000000214332570,0.000001032303300,0.000000172494110
-428,0.000010823427000,0.000149952380000,0.000000376103560,0.000000260363840,0.000000140080730,0.918478840000000,0.000000248771020,0.000001020967100,0.000000155775180
-429,0.000011444277000,0.000243209810000,0.000000348171460,0.000000287803590,0.000000110629850,0.922839310000000,0.000000253922040,0.000005334945300,0.000000141980710
-430,0.000012142077000,0.000337418650000,0.000000320795410,0.000000314805670,0.000000080871065,0.927208060000000,0.000000258337930,0.000009679040100,0.000000127638300
-431,0.000027187372000,0.000548681340000,0.000000344795740,0.000000339165670,0.000000155509980,0.935541700000000,0.000000322175610,0.000037842890000,0.000000174243990
-432,0.000042309152000,0.000762019980000,0.000000369021410,0.000000363038730,0.000000231668650,0.943923610000000,0.000000386634510,0.000066284634000,0.000000222248300
-433,0.000057488382000,0.001153833200000,0.000000460939870,0.000000289173060,0.000000202248900,0.951391800000000,0.000000377993680,0.000035535409000,0.000000172771560
-434,0.000072730559000,0.001547273300000,0.000000554108270,0.000000214995530,0.000000172704080,0.958881960000000,0.000000369313010,0.000004628528100,0.000000124438730
-435,0.000088108926000,0.002277120400000,0.000000461503920,0.000000162257690,0.000000103608240,0.965088150000000,0.000000429747250,0.000002507843000,0.000000113677970
-436,0.000161520260000,0.003011192500000,0.000000369227680,0.000000109209840,0.000000034345748,0.971316890000000,0.000000489734280,0.000000373307520,0.000000102852800
-437,0.000235239490000,0.004623102600000,0.000000320123640,0.000000165296160,0.000000072991257,0.976636740000000,0.000000431238680,0.000000356867510,0.000000550958370
-438,0.000309310710000,0.006242715900000,0.000000270779880,0.000000221650420,0.000000111582730,0.981971420000000,0.000000371659420,0.000000340344490,0.000001002033400
-439,0.000384329290000,0.012985920000000,0.000000222422100,0.000000250250260,0.000000848177100,0.983950000000000,0.000000699012880,0.000000583778530,0.000001093826000
-440,0.000459931910000,0.019782129000000,0.000000174562870,0.000000279070330,0.000001598608100,0.985921070000000,0.000001028937900,0.000000832042840,0.000001187696500
-441,0.000951302680000,0.038890946000000,0.000000225376790,0.000000198081530,0.000004780944000,0.986628330000000,0.000003127470100,0.000015481973000,0.000000670419390
-442,0.001453054400000,0.058201572000000,0.000000277617700,0.000000115481680,0.000008005079600,0.987301120000000,0.000005256338000,0.000030242974000,0.000000147605950
-443,0.001944605500000,0.105444240000000,0.000000376564320,0.000000275699420,0.000004234780300,0.990886970000000,0.000004750029100,0.000017576080000,0.000000147777490
-444,0.002444712600000,0.152795670000000,0.000000474839930,0.000000435544660,0.000000452449000,0.994473550000000,0.000004242509500,0.000004931426600,0.000000147948300
-445,0.002951470700000,0.245200100000000,0.000000533897190,0.000000378067800,0.000000368930590,0.997235790000000,0.000003234384700,0.000002588114900,0.000000212793850
-446,0.023997017000000,0.338160110000000,0.000000593303970,0.000000320237520,0.000000284901290,1.000000000000000,0.000002211918900,0.000000229839970,0.000000278028690
-447,0.045203756000000,0.447938460000000,0.000000436297530,0.000000253429650,0.000000157063160,0.983135020000000,0.000001530538200,0.000000232355660,0.000001351187900
-448,0.066597859000000,0.558680390000000,0.000000277881130,0.000000186019810,0.000000027752479,0.966090910000000,0.000000843049230,0.000000234886870,0.000002436689600
-449,0.087651550000000,0.629696700000000,0.000000421699650,0.000000249742410,0.000000204390870,0.910122720000000,0.000000693075050,0.000000216525440,0.000001830895300
-450,0.109766400000000,0.700970070000000,0.000000566046010,0.000000313698340,0.000000381348640,0.853939950000000,0.000000538392910,0.000000198094320,0.000001220003100
-451,0.173626350000000,0.726558870000000,0.000000614557220,0.000000293747760,0.000000312198590,0.753461820000000,0.000000428729190,0.000000266299100,0.000001006866200
-452,0.238443890000000,0.752221970000000,0.000000663215230,0.000000274490800,0.000000241998390,0.652663810000000,0.000000318719410,0.000000333959380,0.000000793055410
-453,0.304243560000000,0.762987080000000,0.000000546214020,0.000000271818740,0.000000287256510,0.523399270000000,0.000000370173580,0.000000237469410,0.000000863650450
-454,0.369814450000000,0.773821750000000,0.000000427305390,0.000000269882130,0.000000332881900,0.393051300000000,0.000000422883240,0.000000140174630,0.000000934807730
-455,0.436162900000000,0.778254920000000,0.000000458233660,0.000000305173030,0.000000327124390,0.281577110000000,0.000000392980020,0.000000127594420,0.000000566846070
-456,0.445902890000000,0.782703190000000,0.000000488405640,0.000000340665480,0.000000322172170,0.169449020000000,0.000000362897000,0.000000114939110,0.000000195284460
-457,0.456487780000000,0.786647910000000,0.000000505631430,0.000000247223540,0.000000277916240,0.110348670000000,0.000000352714800,0.000000153964990,0.000000168580500
-458,0.467156470000000,0.790603870000000,0.000000523001270,0.000000152903280,0.000000233239120,0.050694291000000,0.000000342426330,0.000000192575960,0.000000142644380
-459,0.477314390000000,0.795293160000000,0.000001413201300,0.000001004628500,0.000000260504890,0.029890841000000,0.000000533323710,0.000000187018680,0.000000090973918
-460,0.487532620000000,0.800000190000000,0.000002306561900,0.000001867567100,0.000000287093510,0.008946148300000,0.000000725502960,0.000000182199140,0.000000038952353
-461,0.490531980000000,0.800133790000000,0.000003109247800,0.000003077929700,0.000000341850030,0.005276111200000,0.000000721022770,0.000000167360540,0.000000019544458
-462,0.492742310000000,0.800258730000000,0.000003920911600,0.000004279790900,0.000000396573080,0.001608012300000,0.000000716537270,0.000000151750020,0.000000000111211
-463,0.496969810000000,0.803215330000000,0.000004931616400,0.000002602717700,0.000000371426580,0.001058127900000,0.000000563534870,0.000000154670080,0.000000121661300
-464,0.501218650000000,0.806176950000000,0.000005949901500,0.000000912831840,0.000000345217680,0.000504038090000,0.000000408492840,0.000000156824870,0.000000244245320
-465,0.504992190000000,0.809859370000000,0.000008511690000,0.000000795772170,0.000000521920750,0.000360899630000,0.000000509299420,0.000000163298750,0.000000413505310
-466,0.507981460000000,0.813545180000000,0.000011070176000,0.000000684729920,0.000000699054750,0.000217404870000,0.000000609484620,0.000000169001360,0.000000584662590
-467,0.512529910000000,0.818554860000000,0.000012171667000,0.000000645664630,0.000000642956150,0.000169599870000,0.000000534705940,0.000000123937060,0.000000301030340
-468,0.517900020000000,0.823585040000000,0.000013378488000,0.000000606247880,0.000000586360600,0.000121184110000,0.000000459273640,0.000000078167159,0.000000014531954
-469,0.521740410000000,0.824816920000000,0.000013705324000,0.000000893556480,0.000000481245770,0.000096270561000,0.000000446544430,0.000000113682120,0.000000011495881
-470,0.525595580000000,0.826045170000000,0.000014130593000,0.000001176055700,0.000000375538590,0.000071216848000,0.000000432860530,0.000000149074830,0.000000008457780
-471,0.527003970000000,0.827548090000000,0.000014437581000,0.000002026430600,0.000000375093320,0.000058623617000,0.000000557302480,0.000000325629330,0.000000004294035
-472,0.528412030000000,0.829048840000000,0.000014842186000,0.000002870731100,0.000000373765030,0.000046177238000,0.000000682027210,0.000000502588190,0.000000000111773
-473,0.530766770000000,0.832800340000000,0.000017026133000,0.000001930155200,0.000000386327270,0.000029873415000,0.000000674318180,0.000000593013890,0.000001891039200
-474,0.533128050000000,0.836562420000000,0.000019222660000,0.000000992099870,0.000000399842510,0.000013615346000,0.000000665669460,0.000000684765750,0.000003793148100
-475,0.535582580000000,0.842262330000000,0.000019771336000,0.000000954706060,0.000000736488580,0.000011541162000,0.000000705903470,0.000000784427240,0.000003683091900
-476,0.533167760000000,0.847984890000000,0.000020323104000,0.000000925182870,0.000001076981800,0.000009436166100,0.000000745484640,0.000000881457500,0.000003572301400
-477,0.530901690000000,0.857781860000000,0.000020884719000,0.000000928326300,0.000001277121100,0.000009539820200,0.000000712269980,0.000001395649600,0.000001960718700
-478,0.528610850000000,0.867630350000000,0.000021548632000,0.000000923303940,0.000001478599100,0.000009644011200,0.000000677920170,0.000001905172300,0.000000339678480
-479,0.525022560000000,0.873047120000000,0.000021999389000,0.000000741326040,0.000001042122800,0.000007399794700,0.000000693115430,0.000001379429600,0.000000277359270
-480,0.522232830000000,0.878481710000000,0.000022551527000,0.000000561706220,0.000000607935010,0.000005144168300,0.000000707478590,0.000000851017760,0.000000214722440
-481,0.523947790000000,0.877920400000000,0.000023585164000,0.000000904870170,0.000000570178600,0.000008172392100,0.000000712296970,0.000002237733600,0.000000137564020
-482,0.525664740000000,0.877350690000000,0.000024622152000,0.000001244254000,0.000000532289190,0.000011192774000,0.000000717126540,0.000003629163400,0.000000060141372
-483,0.528750170000000,0.876535040000000,0.000028587445000,0.000001445940400,0.000001359264100,0.000011168752000,0.000000635654140,0.000007928495600,0.000000141903350
-484,0.531016290000000,0.875704340000000,0.000032573985000,0.000001648707600,0.000002189817200,0.000011126253000,0.000000553730400,0.000012218121000,0.000000224420520
-485,0.533660420000000,0.878267000000000,0.000035601629000,0.000001280237000,0.000001595540900,0.000010999763000,0.000000697945630,0.000013833697000,0.000000680249790
-486,0.532971640000000,0.880831620000000,0.000038750231000,0.000000909227590,0.000001006326800,0.000010853879000,0.000000843133320,0.000015376942000,0.000001140748800
-487,0.529781830000000,0.885353580000000,0.000041890501000,0.000001209869400,0.000000713781590,0.000010801970000,0.000000709680220,0.000010392802000,0.000000955866610
-488,0.527422130000000,0.889871520000000,0.000045133204000,0.000001510672200,0.000000423811680,0.000010768295000,0.000000577062350,0.000005422398400,0.000000770872720
-489,0.524842150000000,0.898713770000000,0.000055715036000,0.000002231696400,0.000000448263070,0.000009920527900,0.000000653122060,0.000004655730200,0.000000402506900
-490,0.523089450000000,0.907575790000000,0.000066428564000,0.000002946434000,0.000000472782660,0.000009088624900,0.000000730317480,0.000003878458600,0.000000031963888
-491,0.531063820000000,0.917397350000000,0.000089364675000,0.000002361491400,0.000000538261280,0.000009069403100,0.000000653908210,0.000003182114400,0.000000162827130
-492,0.538244180000000,0.927275430000000,0.000112382510000,0.000001763392100,0.000000604249120,0.000009068357500,0.000000577800210,0.000002480143200,0.000000295205910
-493,0.543978830000000,0.933843450000000,0.000175309000000,0.000001965236100,0.000000522645860,0.000011141674000,0.000000548913640,0.000008908751200,0.000000217364640
-494,0.549704280000000,0.940397900000000,0.000238190490000,0.000002166925300,0.000000441092270,0.000013213489000,0.000000520041070,0.000015374962000,0.000000137670230
-495,0.557279570000000,0.950191520000000,0.000396290630000,0.000002883794400,0.000000335752100,0.000011728878000,0.000000336904690,0.000015336754000,0.000000135378280
-496,0.557247320000000,0.960030560000000,0.000555332080000,0.000003604921100,0.000000229775670,0.000010235201000,0.000000153596490,0.000015382622000,0.000000133070690
-497,0.557865460000000,0.971188180000000,0.000941204070000,0.000002648956400,0.000000190565740,0.000007675655000,0.000000349604110,0.000011797266000,0.000000066812847
-498,0.558474230000000,0.982413680000000,0.001330274700000,0.000001676387100,0.000000150085410,0.000005094536700,0.000000547239330,0.000008087915300,0.000000000125976
-499,0.558356910000000,0.991188100000000,0.002208565100000,0.000001612571800,0.000000233299150,0.000003204994700,0.000000361478910,0.000004658111500,0.000000367879490
-500,0.558231670000000,1.000000000000000,0.003091863600000,0.000001539767600,0.000000317930580,0.000001306463800,0.000000174648310,0.000001200003000,0.000000736246190
-501,0.567008830000000,0.996612770000000,0.005402169100000,0.000002056480100,0.000000225540620,0.000001412747000,0.000000277628760,0.000000865964600,0.000000919357580
-502,0.575786990000000,0.993216650000000,0.007713745400000,0.000002573470900,0.000000133096750,0.000001517188800,0.000000380665600,0.000000528300400,0.000001102566300
-503,0.586010290000000,0.964663380000000,0.014494754000000,0.000001967764300,0.000000149553150,0.000001233016100,0.000000246264660,0.000002562752400,0.000000569842530
-504,0.596282660000000,0.935941680000000,0.021312825000000,0.000001358707800,0.000000166098120,0.000000945366030,0.000000112072470,0.000004613519500,0.000000034512133
-505,0.605533260000000,0.855779380000000,0.040519839000000,0.000000829005100,0.000000249862610,0.000000862503050,0.000000223410530,0.000004220911800,0.000000026560875
-506,0.608719590000000,0.775457670000000,0.059763601000000,0.000000294809090,0.000000332835960,0.000000777569620,0.000000334961680,0.000003836163100,0.000000018431043
-507,0.613995230000000,0.654641450000000,0.109017050000000,0.000000252195060,0.000000374827440,0.000000672819250,0.000000262459180,0.000002235684000,0.000000060036331
-508,0.618420210000000,0.533104610000000,0.158559200000000,0.000000209326560,0.000000418017810,0.000000565525630,0.000000190483200,0.000000625745520,0.000000102050000
-509,0.622163190000000,0.415580920000000,0.254861660000000,0.000000255141000,0.000000317194500,0.000000633765390,0.000000178361390,0.000000413564410,0.000000153516050
-510,0.626791890000000,0.297629470000000,0.351510380000000,0.000000301119210,0.000000216004490,0.000000702247260,0.000000167155160,0.000000200613430,0.000000205825670
-511,0.621211820000000,0.221450890000000,0.462548310000000,0.000000278520370,0.000000311243630,0.000000801425150,0.000000166814700,0.000000185603310,0.000000274356530
-512,0.615577100000000,0.144698610000000,0.574406090000000,0.000000255746890,0.000000407187750,0.000000901327220,0.000000166468210,0.000000170477180,0.000000345052520
-513,0.608658820000000,0.106623600000000,0.637671040000000,0.000000216996380,0.000000267976930,0.000000874401910,0.000000154891600,0.000000191613470,0.000000393255890
-514,0.600849500000000,0.068529709000000,0.700961840000000,0.000000179108220,0.000000128697870,0.000000849397080,0.000000143308420,0.000000211879370,0.000000443139280
-515,0.595413840000000,0.050368437000000,0.723007420000000,0.000000245071100,0.000000290124080,0.000000939240130,0.000000135934870,0.000000127829910,0.000000802174560
-516,0.602379640000000,0.032106602000000,0.745165690000000,0.000000311394110,0.000000451462320,0.000001031516400,0.000000127545480,0.000000042962713,0.000001163176400
-517,0.608497480000000,0.022842873000000,0.755065520000000,0.000000259387010,0.000000404309280,0.000001087521200,0.000000229099290,0.000000082938678,0.000000980873450
-518,0.615518360000000,0.013555038000000,0.764986560000000,0.000000206354350,0.000000356056380,0.000001145619600,0.000000331890700,0.000000123194860,0.000000798093070
-519,0.623093970000000,0.009658679900000,0.772169440000000,0.000000199061980,0.000000333839780,0.000001065370000,0.000000235117640,0.000000152990350,0.000000624648790
-520,0.630712000000000,0.005734109100000,0.779389020000000,0.000000190817440,0.000000311456910,0.000000984522470,0.000000138627080,0.000000182997210,0.000000448259600
-521,0.637751910000000,0.004513738100000,0.782403090000000,0.000000211376570,0.000000373274820,0.000000805165830,0.000000143512000,0.000000148151170,0.000000357182540
-522,0.644783430000000,0.003293865600000,0.785409340000000,0.000000231924930,0.000000435062490,0.000000625881280,0.000000148393580,0.000000112426930,0.000000266142520
-523,0.653521670000000,0.002653182600000,0.792212410000000,0.000000180419850,0.000000362273310,0.000000864130930,0.000000338873200,0.000000109118970,0.000000219503340
-524,0.662295540000000,0.002009400300000,0.799040490000000,0.000000128665830,0.000000288144470,0.000001105493400,0.000000530263800,0.000000105794070,0.000000172638190
-525,0.671540840000000,0.001655953700000,0.806849870000000,0.000000114463200,0.000000179901100,0.000000899363400,0.000000357075370,0.000000112259820,0.000000217010960
-526,0.667251040000000,0.001301300600000,0.814680420000000,0.000000100211730,0.000000071586995,0.000000690545030,0.000000182307240,0.000000118746730,0.000000261532590
-527,0.665199510000000,0.001087820300000,0.823567240000000,0.000000056907601,0.000000105345680,0.000001059593900,0.000000274479700,0.000000117383250,0.000001858004000
-528,0.662207970000000,0.000872725280000,0.832503220000000,0.000000013552173,0.000000138655700,0.000001429374100,0.000000367333900,0.000000116007160,0.000003456078200
-529,0.658477170000000,0.000738978110000,0.836626790000000,0.000000120209870,0.000000125845300,0.000002522051400,0.000000437754720,0.000000166061690,0.000006115668500
-530,0.654733380000000,0.000604892180000,0.840756040000000,0.000000227042610,0.000000113002150,0.000003627469500,0.000000509350000,0.000000216240540,0.000008781879800
-531,0.661558810000000,0.000513002590000,0.841167150000000,0.000000136862300,0.000000061941751,0.000002587018100,0.000000388521290,0.000000150922090,0.000004822901700
-532,0.668389530000000,0.000420990150000,0.841574190000000,0.000000046015642,0.000000010614048,0.000001559240600,0.000000268534600,0.000000084516754,0.000000862160600
-533,0.676674030000000,0.000362002980000,0.842503310000000,0.000000023163616,0.000000046390394,0.000000996112080,0.000000194929730,0.000000126809790,0.000000549396680
-534,0.684996600000000,0.000302683280000,0.843427400000000,0.000000000072623,0.000000082366078,0.000000429824940,0.000000119903620,0.000000169246120,0.000000236605540
-535,0.693098030000000,0.000259234360000,0.844304850000000,0.000000024204452,0.000000046732687,0.000000400517850,0.000000202004020,0.000000161400300,0.000000382596770
-536,0.692916860000000,0.000215573590000,0.845178440000000,0.000000048340801,0.000000010825964,0.000000371065700,0.000000284498110,0.000000152595870,0.000000529287820
-537,0.692173490000000,0.000183965640000,0.846297980000000,0.000000024301428,0.000000016315567,0.000000471173880,0.000000228165030,0.000000162967670,0.000002867936300
-538,0.690496680000000,0.000152255580000,0.847415950000000,0.000000000073853,0.000000021721111,0.000000571599050,0.000000171650560,0.000000173371620,0.000005222744400
-539,0.689369940000000,0.000130649700000,0.848876280000000,0.000000033074587,0.000000010872020,0.000000419479370,0.000000148446370,0.000000144936580,0.000004949417200
-540,0.688237240000000,0.000108940030000,0.850335270000000,0.000000066218732,0.000000000083101,0.000000269075250,0.000000124174660,0.000000116440840,0.000004675488100
-541,0.684570200000000,0.000095459461000,0.854793280000000,0.000000042653050,0.000000011030841,0.000000405291020,0.000000263690710,0.000000113213080,0.000002400019100
-542,0.680854840000000,0.000081864194000,0.859266210000000,0.000000018983612,0.000000022050656,0.000000542630130,0.000000404361260,0.000000109955500,0.000000107129630
-543,0.675724570000000,0.000070752084000,0.860179410000000,0.000000102941340,0.000000037769845,0.000000427836310,0.000000318382610,0.000000120292620,0.000000076752606
-544,0.669645520000000,0.000059623563000,0.861089480000000,0.000000188237220,0.000000053511536,0.000000314932910,0.000000232278170,0.000000130644050,0.000000046507488
-545,0.664973280000000,0.000051422644000,0.863515540000000,0.000000141815730,0.000000106092560,0.000000369502750,0.000000362811170,0.000000069906929,0.000000298568290
-546,0.673471330000000,0.000043024317000,0.865944640000000,0.000000096069109,0.000000160108920,0.000000426449870,0.000000493051720,0.000000008596689,0.000000551002400
-547,0.679721910000000,0.000049063408000,0.868077350000000,0.000000090685225,0.000000132334070,0.000008515702000,0.000002669142000,0.000000013056549,0.000001572876400
-548,0.686924820000000,0.000054962574000,0.870209420000000,0.000000085291531,0.000000104510300,0.000016610671000,0.000004845893300,0.000000017580501,0.000002591193500
-549,0.694228420000000,0.000060812234000,0.876379410000000,0.000000102137410,0.000000057668167,0.000078988137000,0.000005926355800,0.000000022427983,0.000001814557700
-550,0.701560140000000,0.000066688956000,0.882570500000000,0.000000119441070,0.000000010708303,0.000141680230000,0.000007001461900,0.000000027203689,0.000001030672100
-551,0.703497360000000,0.000064278398000,0.889084060000000,0.000000076313757,0.000000046058621,0.000072510913000,0.000006845786600,0.000000069807734,0.000000567079020
-552,0.704480840000000,0.000062018075000,0.895592600000000,0.000000033086696,0.000000081412292,0.000003104784100,0.000006690051400,0.000000112415730,0.000000103612850
-553,0.707502620000000,0.000062654283000,0.905848320000000,0.000000041551180,0.000000076854565,0.000001686524400,0.000005780989800,0.000000134537210,0.000000090860506
-554,0.710532860000000,0.000063293406000,0.916152410000000,0.000000050064885,0.000000072269029,0.000000253615890,0.000004876973000,0.000000155836760,0.000000078211375
-555,0.713576420000000,0.000060657672000,0.924469030000000,0.000000075933161,0.000000099514922,0.000000306502750,0.000004371101800,0.000000155132970,0.000000150023860
-556,0.711835230000000,0.000057860934000,0.932806730000000,0.000000102361610,0.000000126951830,0.000000359556080,0.000003874094700,0.000000154426030,0.000000221344110
-557,0.710511960000000,0.000058823610000,0.939045670000000,0.000000194362250,0.000000144908950,0.000000303036920,0.000004560328400,0.000000151692860,0.000000156871320
-558,0.709183050000000,0.000059940124000,0.945290460000000,0.000000286515280,0.000000163946230,0.000000246422090,0.000005258200100,0.000000147999570,0.000000091389029
-559,0.709009250000000,0.000061241421000,0.953765660000000,0.000000202964100,0.000000127650460,0.000000382677140,0.000004539371600,0.000000253042140,0.000000119966450
-560,0.709785540000000,0.000062551349000,0.962284860000000,0.000000117802260,0.000000091285393,0.000000519968500,0.000003825528900,0.000000358884540,0.000000148760350
-561,0.721632160000000,0.000058037960000,0.968349270000000,0.000000076990185,0.000000045719326,0.000000520841470,0.000005742619900,0.000001069787300,0.000000090061050
-562,0.732543970000000,0.000053509070000,0.974428220000000,0.000000036331280,0.000000000085004,0.000000521714240,0.000007666112900,0.000001785966500,0.000000031346380
-563,0.744301020000000,0.000056212436000,0.978774710000000,0.000000094793180,0.000000042989673,0.000000454233650,0.000014587928000,0.000002262301800,0.000000015732557
-564,0.755115260000000,0.000058768730000,0.983128600000000,0.000000153522240,0.000000085891365,0.000000386553810,0.000021647152000,0.000002730332100,0.000000000165962
-565,0.765752490000000,0.000058683535000,0.985726390000000,0.000000086385634,0.000000074897259,0.000000269411590,0.000026690646000,0.000002084103000,0.000000000165976
-566,0.763731090000000,0.000058752872000,0.988325510000000,0.000000019089628,0.000000063769936,0.000000150706240,0.000031745952000,0.000001446038400,0.000000000165989
-567,0.763085600000000,0.000052087636000,0.992613470000000,0.000000049234766,0.000000070603626,0.000000257655700,0.000048887372000,0.000001022075100,0.000000000165751
-568,0.762425850000000,0.000045537651000,0.996913660000000,0.000000079658079,0.000000077584815,0.000000363951200,0.000066130973000,0.000000605317350,0.000000000165510
-569,0.760129950000000,0.000047449501000,0.998457830000000,0.000000151999190,0.000000038825497,0.000000214892820,0.000096644338000,0.000000753383490,0.000000004298085
-570,0.757826600000000,0.000049364385000,1.000000000000000,0.000000223775740,0.000000000093648,0.000000065148178,0.000127119810000,0.000000902676230,0.000000008455770
-571,0.759075060000000,0.000047411550000,0.997664250000000,0.000000159260490,0.000000000093910,0.000000032627752,0.000196685610000,0.000001244081700,0.000000004308821
-572,0.759337080000000,0.000045295276000,0.995315020000000,0.000000093744008,0.000000000094064,0.000000000177475,0.000266479460000,0.000001599360300,0.000000000160596
-573,0.758987060000000,0.000037647007000,0.990791640000000,0.000000112350650,0.000000074687688,0.000000000176324,0.000422502270000,0.000002405963100,0.000000000159062
-574,0.758632980000000,0.000029985759000,0.986256150000000,0.000000131185200,0.000000149283750,0.000000000174954,0.000578784410000,0.000003213905400,0.000000000157525
-575,0.759817800000000,0.000031016408000,0.979120710000000,0.000000132550560,0.000000074964402,0.000000206763790,0.000895024200000,0.000003114698500,0.000000000156488
-576,0.767954220000000,0.000032052585000,0.971932070000000,0.000000133922110,0.000000000093348,0.000000414275540,0.001213067700000,0.000003014883300,0.000000000155444
-577,0.775962150000000,0.000030554246000,0.929219420000000,0.000000230756400,0.000000000093050,0.000001178343000,0.001886311200000,0.000003062502100,0.000000089995409
-578,0.784004080000000,0.000028888915000,0.886270610000000,0.000000328100770,0.000000000092639,0.000001946442100,0.002563098000000,0.000003120277000,0.000000180278630
-579,0.788551960000000,0.000023161531000,0.775095590000000,0.000000267116490,0.000000000091931,0.000001831426000,0.004221959100000,0.000003803792700,0.000000723706920
-580,0.794085500000000,0.000017440465000,0.664040430000000,0.000000207195450,0.000000000091223,0.000001714335500,0.005878897500000,0.000004486497900,0.000001264824200
-581,0.795880400000000,0.000017479886000,0.510293750000000,0.000000271560330,0.000000012811015,0.000001110363300,0.010792315000000,0.000005571057000,0.000000657317180
-582,0.796674660000000,0.000017519340000,0.355847480000000,0.000000336214030,0.000000025679861,0.000000501451090,0.015727864000000,0.000006660474500,0.000000048563030
-583,0.799195640000000,0.000017415007000,0.247024490000000,0.000000399513760,0.000000012880561,0.000000251518940,0.037386593000000,0.000006741564800,0.000000142373620
-584,0.801720590000000,0.000017149476000,0.137508530000000,0.000000463208400,0.000000000089897,0.000000000188571,0.059181940000000,0.000006823067300,0.000000236776240
-585,0.800714760000000,0.000014344703000,0.092924133000000,0.000000511544870,0.000000029597502,0.000000097827164,0.134652350000000,0.000006050475200,0.000000293603500
-586,0.803738080000000,0.000011523815000,0.048339161000000,0.000000559878390,0.000000059084415,0.000000195653830,0.210122030000000,0.000005277847100,0.000000352323300
-587,0.808468590000000,0.000011112342000,0.032973451000000,0.000000578940170,0.000000066596865,0.000000136797120,0.329255070000000,0.000005114402700,0.000000224269690
-588,0.814232520000000,0.000010697906000,0.017503597000000,0.000000599134380,0.000000074270008,0.000000077764138,0.449185610000000,0.000004939668100,0.000000095158331
-589,0.817271310000000,0.000011746620000,0.011533107000000,0.000000714697360,0.000000069599744,0.000000300804270,0.556370700000000,0.000006020484900,0.000000159040820
-590,0.819290060000000,0.000012779107000,0.005562687800000,0.000000829239800,0.000000065040362,0.000000525842900,0.663550110000000,0.000007091140600,0.000000223111630
-591,0.819574020000000,0.000011199472000,0.004188538000000,0.000000814310800,0.000000032627493,0.000001477375800,0.749153800000000,0.000008852705800,0.000000378173010
-592,0.820872920000000,0.000009614761400,0.002810002600000,0.000000800346970,0.000000000093019,0.000002436392500,0.835025240000000,0.000010640083000,0.000000533724680
-593,0.820755910000000,0.000008766507000,0.002143405800000,0.000000913215490,0.000000000094126,0.000003289389800,0.861371580000000,0.000011970574000,0.000000534311520
-594,0.820635040000000,0.000007916350400,0.001475333900000,0.000001029385500,0.000000000095123,0.000004144246700,0.887772010000000,0.000013405493000,0.000000534897300
-595,0.823029560000000,0.000008622762800,0.001129404800000,0.000001318596100,0.000000000096522,0.000004493339600,0.899805830000000,0.000013750168000,0.000000613369630
-596,0.826454150000000,0.000009333189700,0.000781440920000,0.000001619730100,0.000000000097815,0.000004844413500,0.911898360000000,0.000014096679000,0.000000692292340
-597,0.828337580000000,0.000009228517700,0.000599586890000,0.000006598511600,0.000000000099042,0.000003473544800,0.917312270000000,0.000015440598000,0.000000345539380
-598,0.831250130000000,0.000009107239100,0.000417354090000,0.000011608109000,0.000000000100271,0.000002108856900,0.922733430000000,0.000016684869000,0.000000000187634
-599,0.835053730000000,0.000008596236700,0.000320452560000,0.000012059088000,0.000000103430810,0.000001545005900,0.927674760000000,0.000020335082000,0.000000288884580
-600,0.838868810000000,0.000008065221400,0.000222899010000,0.000012616287000,0.000000207550150,0.000000977366270,0.932633620000000,0.000024009316000,0.000000577746970
-601,0.842119450000000,0.000008165372700,0.000171465790000,0.000018617371000,0.000000103792790,0.000001345813000,0.935473840000000,0.000028651198000,0.000000535042210
-602,0.846402930000000,0.000008265516500,0.000120014400000,0.000024620380000,0.000000000104491,0.000001714376900,0.938310300000000,0.000033294497000,0.000000494266310
-603,0.851422800000000,0.000008812190200,0.000094446539000,0.000029030341000,0.000000000105181,0.000001597457500,0.942051300000000,0.000035538959000,0.000000466124060
-604,0.856458320000000,0.000009344714300,0.000068637063000,0.000033459925000,0.000000000105873,0.000001477714500,0.945801460000000,0.000037689695000,0.000000437851270
-605,0.860802080000000,0.000008966196700,0.000053940472000,0.000040950264000,0.000000007808207,0.000001258720400,0.947025860000000,0.000037490497000,0.000000514192500
-606,0.858896920000000,0.000008587478000,0.000039237501000,0.000048443521000,0.000000015505613,0.000001039628900,0.948246160000000,0.000037291035000,0.000000588607500
-607,0.858672810000000,0.000007916615900,0.000030211438000,0.000063057364000,0.000000110354460,0.000001246455700,0.951042090000000,0.000038985506000,0.000000595040160
-608,0.857401670000000,0.000007244445100,0.000021168079000,0.000077698748000,0.000000205611760,0.000001453670900,0.953839430000000,0.000040683041000,0.000000599523390
-609,0.858457570000000,0.000007677659300,0.000014020332000,0.000100232740000,0.000000102943350,0.000001858833800,0.960115030000000,0.000047233091000,0.000000883813010
-610,0.858462440000000,0.000008129585400,0.000006850059000,0.000122911900000,0.000000000105950,0.000002268267000,0.966412430000000,0.000053814825000,0.000001169488700
-611,0.861334800000000,0.000008731141200,0.000005341950900,0.000171538160000,0.000000075231345,0.000002512838100,0.972733780000000,0.000064589430000,0.000000879964590
-612,0.864212980000000,0.000009335186700,0.000003827399300,0.000220369630000,0.000000151012140,0.000002772290500,0.979074760000000,0.000075409309000,0.000000587227350
-613,0.866181100000000,0.000008903715000,0.000003224376300,0.000316961940000,0.000000075793563,0.000003403789900,0.983863030000000,0.000083454068000,0.000000481552920
-614,0.869208480000000,0.000008470203700,0.000002605805300,0.000413991790000,0.000000000558164,0.000004038138800,0.988664990000000,0.000091640010000,0.000000375392970
-615,0.870285310000000,0.000007377980800,0.000001711694500,0.000628091920000,0.000000000331200,0.000006080551500,0.989722820000000,0.000088380395000,0.000000286020070
-616,0.872415100000000,0.000006285676300,0.000000807320460,0.000842198260000,0.000000000103878,0.000008099804100,0.990775510000000,0.000085120190000,0.000000197039410
-617,0.876090680000000,0.000006869338100,0.000000453008620,0.001379578600000,0.000000076104498,0.000010416011000,0.992062840000000,0.000078947831000,0.000000212911700
-618,0.879774250000000,0.000007455043300,0.000000098326761,0.001918870100000,0.000000152247770,0.000012740425000,0.993348980000000,0.000072858570000,0.000000227244700
-619,0.885050540000000,0.000007709403400,0.000000959897810,0.003389641000000,0.000000076420790,0.000011416513000,0.996670990000000,0.000081604472000,0.000000379638760
-620,0.889277790000000,0.000007981848600,0.000001829024000,0.004867356900000,0.000000000103109,0.000010086222000,1.000000000000000,0.000090391133000,0.000000534755000
-621,0.892480490000000,0.000007219282800,0.000001507019200,0.009934890300000,0.000000000102992,0.000008003486900,0.998656100000000,0.000122199370000,0.000000542768660
-622,0.894612280000000,0.000006456676900,0.000001194021900,0.015002391000000,0.000000000102992,0.000005944105000,0.997307010000000,0.000154024050000,0.000000552782360
-623,0.898336960000000,0.000005680455500,0.000002165190500,0.030519236000000,0.000000007419316,0.000005174868400,0.941429000000000,0.000194698520000,0.000000551102100
-624,0.902062420000000,0.000004903305000,0.000003120720700,0.046054086000000,0.000000014730360,0.000004428142100,0.885481990000000,0.000235419730000,0.000000549417690
-625,0.909253110000000,0.000005538389400,0.000006191223600,0.095565862000000,0.000000007456338,0.000003859336600,0.759433470000000,0.000184765800000,0.000000632398440
-626,0.914326280000000,0.000006161794300,0.000009275614600,0.145511480000000,0.000000000104965,0.000003285399400,0.632250630000000,0.000133658530000,0.000000718115110
-627,0.913140370000000,0.000006153802200,0.000008821842000,0.244826560000000,0.000000079740960,0.000003210322200,0.501740010000000,0.000078977076000,0.000000993955980
-628,0.913020150000000,0.000006128681700,0.000008369139400,0.343880010000000,0.000000158802800,0.000003135399900,0.371562800000000,0.000024474383000,0.000001269066200
-629,0.915451300000000,0.000005163257800,0.000011812157000,0.469789800000000,0.000000079754884,0.000002903960200,0.253118920000000,0.000016697256000,0.000001182044300
-630,0.917885310000000,0.000004194943300,0.000015226298000,0.596071170000000,0.000000000107481,0.000002671819600,0.134322210000000,0.000008789770100,0.000001094758400
-631,0.916011390000000,0.000003759761700,0.000014353485000,0.700463420000000,0.000000000108477,0.000002987139000,0.086068956000000,0.000006835605200,0.000000722315970
-632,0.915200680000000,0.000003305004300,0.000013606694000,0.805405060000000,0.000000000109596,0.000003327878900,0.037557345000000,0.000004860164900,0.000000349913150
-633,0.913240840000000,0.000003676039000,0.000018495586000,0.839173490000000,0.000000000110714,0.000002907562200,0.024147689000000,0.000004094900700,0.000000299832610
-634,0.912350090000000,0.000004048969800,0.000023409770000,0.873109280000000,0.000000000111717,0.000002485024600,0.010667886000000,0.000003325605400,0.000000247442940
-635,0.910761890000000,0.000004143119500,0.000025692871000,0.872776170000000,0.000000000112760,0.000002489611500,0.007385241000000,0.000002691441200,0.000000362630090
-636,0.913533360000000,0.000004254959200,0.000027984248000,0.872436620000000,0.000000000113685,0.000002494200400,0.004090431400000,0.000002044046700,0.000000478240390
-637,0.915831720000000,0.000003977574600,0.000031024099000,0.881035900000000,0.000000093592566,0.000002542479100,0.002854741600000,0.000001652837200,0.000000525513440
-638,0.918126450000000,0.000003700104600,0.000034064543000,0.889633230000000,0.000000186728560,0.000002590757900,0.001618738600000,0.000001261525500,0.000000572795520
-639,0.922052170000000,0.000003237185100,0.000031615566000,0.908747290000000,0.000000093780619,0.000002643723000,0.001155548500000,0.000001165848200,0.000000329105840
-640,0.924889950000000,0.000002772495100,0.000029157133000,0.927928060000000,0.000000000116185,0.000002696872200,0.000690599620000,0.000001070893600,0.000000083256097
-641,0.929980730000000,0.000003158495700,0.000028516003000,0.940550850000000,0.000000047615534,0.000002723007500,0.000507117200000,0.000000871782740,0.000000344412740
-642,0.933976990000000,0.000003562530600,0.000028006534000,0.953189240000000,0.000000095062073,0.000002749172300,0.000323356100000,0.000000672368260,0.000000606787720
-643,0.939682150000000,0.000003952234700,0.000026051866000,0.958201030000000,0.000000047717890,0.000002583965700,0.000246888130000,0.000000638273040,0.000000642770140
-644,0.945399110000000,0.000004325497200,0.000024091627000,0.963222600000000,0.000000000117168,0.000002418286600,0.000170205620000,0.000000604079830,0.000000680919850
-645,0.950791390000000,0.000003843592900,0.000024144617000,0.965042450000000,0.000000099044172,0.000002496313800,0.000157593990000,0.000001384418700,0.000000690714410
-646,0.948453130000000,0.000003359538300,0.000024197655000,0.966862920000000,0.000000198765880,0.000002550376000,0.000144925650000,0.000002169282500,0.000000702625570
-647,0.945487620000000,0.000003276656700,0.000017406434000,0.967019280000000,0.000000315604440,0.000002233208900,0.000112600350000,0.000002591728500,0.000000791156880
-648,0.942508400000000,0.000003193502800,0.000010755028000,0.967171490000000,0.000000432803210,0.000001915049200,0.000080049133000,0.000003004424400,0.000000882043700
-649,0.939717440000000,0.000003676335100,0.000005494441300,0.966383950000000,0.000000468882740,0.000002067301600,0.000062275135000,0.000004016631900,0.000001056971500
-650,0.936911480000000,0.000004160845700,0.000000213973180,0.965588320000000,0.000000505086590,0.000002217633200,0.000044316187000,0.000005032378000,0.000001234601400
-651,0.934713360000000,0.000004674461600,0.000000152073860,0.961925410000000,0.000000463620920,0.000002046547400,0.000034916903000,0.000005597868600,0.000001422976100
-652,0.932510780000000,0.000005205793200,0.000000090304746,0.958257820000000,0.000000420930540,0.000001872996800,0.000025516899000,0.000006163367000,0.000001613448000
-653,0.932110970000000,0.000005659564400,0.000000113810740,0.957293710000000,0.000000506109420,0.000001771329300,0.000020673835000,0.000006675294800,0.000002264524900
-654,0.930585140000000,0.000006115083800,0.000000137813770,0.956319680000000,0.000000591620010,0.000001666795900,0.000015934166000,0.000007200321800,0.000002899239300
-655,0.929417280000000,0.000005659407300,0.000000197490020,0.955499630000000,0.000000597206530,0.000001739986100,0.000012884725000,0.000008099941800,0.000002355715700
-656,0.933848540000000,0.000005184843000,0.000000258657130,0.954674060000000,0.000000602803650,0.000001813338100,0.000009840499800,0.000009012756600,0.000001783557200
-657,0.937173950000000,0.000005505333000,0.000000203125680,0.953446640000000,0.000000563494330,0.000001803423700,0.000008243082600,0.000010038557000,0.000001252861600
-658,0.939373640000000,0.000005825769300,0.000000147598010,0.952214780000000,0.000000524185690,0.000001793501500,0.000006658046700,0.000011064221000,0.000000720099740
-659,0.945291830000000,0.000007913795400,0.000000202309290,0.954008540000000,0.000000601924060,0.000001788495200,0.000005826184700,0.000011295517000,0.000000633378560
-660,0.951231680000000,0.000010013061000,0.000000257315120,0.955801470000000,0.000000681311740,0.000001780968400,0.000004977395000,0.000011550371000,0.000000546179960
-661,0.954727440000000,0.000012908405000,0.000000352546430,0.959848970000000,0.000000633024900,0.000001931507600,0.000004264308300,0.000011367715000,0.000001160117000
-662,0.959364760000000,0.000015842830000,0.000000448471100,0.963906640000000,0.000000584369920,0.000002080623000,0.000003545888800,0.000011138297000,0.000001778546800
-663,0.960659220000000,0.000016605018000,0.000000506755720,0.966599680000000,0.000000796811430,0.000002080935200,0.000003052333100,0.000011764157000,0.000001294069100
-664,0.961953210000000,0.000017369193000,0.000000565195520,0.969296010000000,0.000001009822900,0.000002081239700,0.000002557433200,0.000012346350000,0.000000810417190
-665,0.962780990000000,0.000017544462000,0.000000677740930,0.970357880000000,0.000001008250900,0.000002410262400,0.000002157528000,0.000011776204000,0.000000498064130
-666,0.959052080000000,0.000017719517000,0.000000788834980,0.971413520000000,0.000001005428300,0.000002746547800,0.000001770337900,0.000011138445000,0.000000186338800
-667,0.957641390000000,0.000020293307000,0.000000773961910,0.974797310000000,0.000000881436970,0.000002877407200,0.000001536674700,0.000010708052000,0.000000093578754
-668,0.957360530000000,0.000022696176000,0.000000757641050,0.978188470000000,0.000000755668600,0.000003033868400,0.000001314540600,0.000010264412000,0.000000000214587
-669,0.955618420000000,0.000029284317000,0.000000873725010,0.982851670000000,0.000000917428140,0.000003717402700,0.000001071048400,0.000010760803000,0.000000141017840
-670,0.953864960000000,0.000035895580000,0.000000990214460,0.987526010000000,0.000001079754300,0.000004378170600,0.000000830459060,0.000011258890000,0.000000282102580
-671,0.953952290000000,0.000041547927000,0.000000887812000,0.991481210000000,0.000000927920360,0.000006039408800,0.000000894615710,0.000009685585000,0.000000247669980
-672,0.954035630000000,0.000047201110000,0.000000784002320,0.995432970000000,0.000000776055320,0.000007675752600,0.000000958780080,0.000008123367400,0.000000214091710
-673,0.955468210000000,0.000044116169000,0.000000719114840,0.997717660000000,0.000000879290170,0.000010849966000,0.000000943983440,0.000008753494100,0.000000144781380
-674,0.955750740000000,0.000041029228000,0.000000655572060,1.000000000000000,0.000000983839700,0.000014026028000,0.000000927917150,0.000009395379300,0.000000075429266
-675,0.957375840000000,0.000034340490000,0.000000620589800,0.999084860000000,0.000000935167090,0.000017152453000,0.000000818660840,0.000008210634900,0.000000282801010
-676,0.961304070000000,0.000027445854000,0.000000585485380,0.998161470000000,0.000000885063350,0.000020264157000,0.000000710290330,0.000007021818800,0.000000490876630
-677,0.965866760000000,0.000025126009000,0.000000848923800,0.994134120000000,0.000000937688540,0.000017652426000,0.000000705633450,0.000008243868300,0.000000528875910
-678,0.970442730000000,0.000022611233000,0.000001114988800,0.990079490000000,0.000000990552820,0.000015028288000,0.000000702216310,0.000009460075500,0.000000567049080
-679,0.974085650000000,0.000023378468000,0.000001106718800,0.986893080000000,0.000000998248860,0.000011388303000,0.000000808525610,0.000009588249200,0.000000667900430
-680,0.977734600000000,0.000024332040000,0.000001097020700,0.983693970000000,0.000001005961900,0.000007763778000,0.000000915122220,0.000009705194400,0.000000769024740
-681,0.971153690000000,0.000025447948000,0.000000849365820,0.985211710000000,0.000000970775490,0.000006035186700,0.000000742554870,0.000010851885000,0.000000492541850
-682,0.964564300000000,0.000026564634000,0.000000600113750,0.986727210000000,0.000000935558420,0.000004330708400,0.000000569851070,0.000012010977000,0.000000216496860
-683,0.958100680000000,0.000024393215000,0.000000650316210,0.969894880000000,0.000000800935460,0.000004083041400,0.000000513502050,0.000018626217000,0.000000108545670
-684,0.952774350000000,0.000022399241000,0.000000700689720,0.952998970000000,0.000000664564920,0.000003860055600,0.000000456954520,0.000025264347000,0.000000000215937
-685,0.949216890000000,0.000019507872000,0.000000927757450,0.885279540000000,0.000000897408920,0.000004361523400,0.000000831394840,0.000032799964000,0.000000232748820
-686,0.951480750000000,0.000016539179000,0.000001156455600,0.817050680000000,0.000001133210700,0.000004866545800,0.000001207252000,0.000040272917000,0.000000467183190
-687,0.948465180000000,0.000014441399000,0.000001131582000,0.693924610000000,0.000001174613000,0.000004420228100,0.000000975221270,0.000065942839000,0.000000492670530
-688,0.945444770000000,0.000012351522000,0.000001106785200,0.571265040000000,0.000001217113600,0.000003975568200,0.000000744075450,0.000091511824000,0.000000515855070
-689,0.949390200000000,0.000012474439000,0.000001142586000,0.432307560000000,0.000001253300700,0.000003790797500,0.000000683724440,0.000149142070000,0.000000673140030
-690,0.953333820000000,0.000012579328000,0.000001178721400,0.291823020000000,0.000001289821300,0.000003603845200,0.000000623981480,0.000207342030000,0.000000832098860
-691,0.949478800000000,0.000013407323000,0.000001165427400,0.195875140000000,0.000001136431500,0.000003821671100,0.000000809700820,0.000365052740000,0.000000477350830
-692,0.945608620000000,0.000014246576000,0.000001152184300,0.100695190000000,0.000000984229070,0.000004037545200,0.000000993875640,0.000521468790000,0.000000127655070
-693,0.947704370000000,0.000013940805000,0.000001143387300,0.065814274000000,0.000000988921910,0.000004386989800,0.000000724148030,0.000996710020000,0.000000326867510
-694,0.950977360000000,0.000013651416000,0.000001135934000,0.030690613000000,0.000000992337250,0.000004738775000,0.000000452539380,0.001475224400000,0.000000527453640
-695,0.952192930000000,0.000011979033000,0.000000893354630,0.020441228000000,0.000000925036540,0.000006611651500,0.000000517848950,0.003127526400000,0.000000408300520
-696,0.955773820000000,0.000010321131000,0.000000650151880,0.010165567000000,0.000000857560360,0.000008489290300,0.000000583323510,0.004784038800000,0.000000288841320
-697,0.959837160000000,0.000009201953600,0.000000773931360,0.007151594800000,0.000001650120600,0.000015180898000,0.000000629285310,0.014133814000000,0.000000325367440
-698,0.965101950000000,0.000008075908600,0.000000898446060,0.004119367500000,0.000002450039700,0.000021886495000,0.000000676819550,0.023539726000000,0.000000362109190
-699,0.967350760000000,0.000007828975900,0.000000974502100,0.003016402100000,0.000002084857400,0.000024103216000,0.000000818853620,0.061580298000000,0.000000243608330
-700,0.969594580000000,0.000007582075900,0.000001050532800,0.001913728300000,0.000001719766300,0.000026371438000,0.000000960844830,0.099610101000000,0.000000127150200
-701,0.974846690000000,0.000008021017400,0.000001075508100,0.001432650200000,0.000002255077400,0.000019958396000,0.000000727846530,0.194479230000000,0.000000213961950
-702,0.980101040000000,0.000008479304100,0.000001099066600,0.000951082870000,0.000002803963900,0.000013564951000,0.000000493305560,0.289443560000000,0.000000301979160
-703,0.987835250000000,0.000009196172400,0.000001066462400,0.000735408470000,0.000004233135100,0.000011154334000,0.000000606632070,0.404226030000000,0.000000170982210
-704,0.994396840000000,0.000009934574700,0.000001032290900,0.000518951280000,0.000005667444100,0.000008708720600,0.000000719054740,0.519420790000000,0.000000040409280
-705,1.000000000000000,0.000010094840000,0.000001041810300,0.000403589130000,0.000004807538000,0.000008085824300,0.000000865148890,0.622907840000000,0.000000087400823
-706,0.998426400000000,0.000010236311000,0.000001051342100,0.000288036040000,0.000003959313500,0.000007461879100,0.000001010168700,0.726563170000000,0.000000134469370
-707,0.996089010000000,0.000009418705100,0.000000968967640,0.000231834480000,0.000005559088800,0.000007567408300,0.000000901331930,0.811375540000000,0.000000305834110
-708,0.992550230000000,0.000008600972900,0.000000886580330,0.000175627010000,0.000007159019500,0.000007672920100,0.000000793791670,0.896194150000000,0.000000476766820
-709,0.993281630000000,0.000007826398000,0.000000980783700,0.000138802740000,0.000006195134500,0.000008118905200,0.000000760760460,0.924411040000000,0.000000482783990
-710,0.994002770000000,0.000007046811400,0.000001077023100,0.000101781000000,0.000005225065900,0.000008541143700,0.000000728829470,0.952792380000000,0.000000488831960
-711,0.988618550000000,0.000007377119500,0.000001013640100,0.000083548193000,0.000004845559200,0.000009022962300,0.000000986935350,0.964068630000000,0.000000577467150
-712,0.983224430000000,0.000007688659100,0.000000951629480,0.000065291557000,0.000004465547300,0.000009505377400,0.000001245372200,0.975356590000000,0.000000663949230
-713,0.978724360000000,0.000008507271400,0.000000923929300,0.000048502499000,0.000004128505900,0.000009758949200,0.000001040761300,0.981488110000000,0.000000717190710
-714,0.975416010000000,0.000009328412800,0.000000894676250,0.000031539734000,0.000003790389200,0.000010039833000,0.000000835504100,0.987634490000000,0.000000770595970
-715,0.969562680000000,0.000010888573000,0.000000988438650,0.000027194970000,0.000003923720100,0.000012193712000,0.000000913936020,0.987633590000000,0.000000713912880
-716,0.968546390000000,0.000012449328000,0.000001080773100,0.000022969245000,0.000004057091500,0.000014374990000,0.000000992396520,0.987629300000000,0.000000657204420
-717,0.967948450000000,0.000013051162000,0.000001117978700,0.000018410077000,0.000004303851600,0.000024305244000,0.000000894576740,0.988561030000000,0.000000815651360
-718,0.968557960000000,0.000013655194000,0.000001155318400,0.000013954935000,0.000004538210200,0.000034139497000,0.000000795050690,0.989490590000000,0.000000974691910
-719,0.968479210000000,0.000013013781000,0.000001125811400,0.000014092820000,0.000004756728800,0.000065955960000,0.000000991981030,0.991694960000000,0.000000936986400
-720,0.968397020000000,0.000012390176000,0.000001094760000,0.000014230982000,0.000004975744600,0.000097579601000,0.000001188035800,0.993901170000000,0.000000896901140
-721,0.971014650000000,0.000012039695000,0.000001103708000,0.000016200449000,0.000005557365800,0.000104145900000,0.000001142962600,0.996948190000000,0.000000664481520
-722,0.973635950000000,0.000011707570000,0.000001114153100,0.000018053553000,0.000006140643800,0.000110730740000,0.000001097754800,1.000000000000000,0.000000431388260
-723,0.973711240000000,0.000012193902000,0.000001005029100,0.000015615091000,0.000005793255700,0.000076418161000,0.000001127293900,0.999715140000000,0.000000674669980
-724,0.975004810000000,0.000012680262000,0.000000895884880,0.000013176204000,0.000005459174400,0.000041831971000,0.000001158172300,0.999426600000000,0.000000915691030
-725,0.978854970000000,0.000014856185000,0.000001049246300,0.000013334009000,0.000006600846100,0.000033340577000,0.000001503636300,0.999279840000000,0.000001040117000
-726,0.976573270000000,0.000017043670000,0.000001203422700,0.000013492520000,0.000007762050300,0.000024856987000,0.000001844214700,0.999121420000000,0.000001165202200
-727,0.970086170000000,0.000020660978000,0.000001265177200,0.000014082973000,0.000010019259000,0.000024143828000,0.000001478358300,0.992649590000000,0.000000997456400
-728,0.963607010000000,0.000024130042000,0.000001326714000,0.000014793580000,0.000012255594000,0.000023432659000,0.000001116353500,0.986185340000000,0.000000827942000
-729,0.964304310000000,0.000027563118000,0.000001132172700,0.000014001210000,0.000014277983000,0.000026643732000,0.000001153785300,0.986513860000000,0.000000773953820
-730,0.963740940000000,0.000031026585000,0.000000934328700,0.000013201162000,0.000016237153000,0.000029828970000,0.000001191520700,0.986813190000000,0.000000719448310
-731,0.958649790000000,0.000032199809000,0.000001077445000,0.000013199112000,0.000021105021000,0.000034975814000,0.000001072202100,0.983840940000000,0.000000684529980
-732,0.953556200000000,0.000033176218000,0.000001219019600,0.000013197007000,0.000026106535000,0.000040120891000,0.000000954270080,0.980865470000000,0.000000649619750
-733,0.950947980000000,0.000032077043000,0.000001042528600,0.000011782871000,0.000030781114000,0.000048372152000,0.000001149296700,0.981058100000000,0.000000790763570
-734,0.948318290000000,0.000031169443000,0.000000865159600,0.000010374064000,0.000035478415000,0.000056663574000,0.000001345272500,0.981242760000000,0.000000930263240
-735,0.946653880000000,0.000031039691000,0.000000830981480,0.000010570580000,0.000044001960000,0.000066888662000,0.000001282771700,0.977115870000000,0.000000880886810
-736,0.948715340000000,0.000031107284000,0.000000796648220,0.000010755428000,0.000052698895000,0.000077157871000,0.000001219989000,0.972963860000000,0.000000831288580
-737,0.946854540000000,0.000033023740000,0.000000804103670,0.000007640757400,0.000064586223000,0.000127525010000,0.000001280316700,0.953762160000000,0.000001039994000
-738,0.944985190000000,0.000034932108000,0.000000811516330,0.000004525805600,0.000076425731000,0.000177691970000,0.000001341746500,0.934619980000000,0.000001247861300
-739,0.948958030000000,0.000040033624000,0.000000918865270,0.000003797736900,0.000091222454000,0.000299646170000,0.000001188871200,0.890706330000000,0.000000904111210
-740,0.952938160000000,0.000045375988000,0.000001027092300,0.000003050932300,0.000106141190000,0.000422651460000,0.000001036048800,0.846398560000000,0.000000557443180
-741,0.953920280000000,0.000052127823000,0.000001143243000,0.000003550080000,0.000127634980000,0.000367966560000,0.000000946584530,0.756942600000000,0.000000757155670
-742,0.953645980000000,0.000058875567000,0.000001260834000,0.000004048926600,0.000149161160000,0.000313311180000,0.000000855795500,0.667534200000000,0.000000956750760
-743,0.955871240000000,0.000063315955000,0.000001065386500,0.000002802112500,0.000181460760000,0.000199339210000,0.000001018666400,0.564139950000000,0.000000929488780
-744,0.958098220000000,0.000067765208000,0.000000871052180,0.000001540226100,0.000213827050000,0.000085046220000,0.000001183240500,0.460533250000000,0.000000899812940
-745,0.962582540000000,0.000065278987000,0.000000847733740,0.000001547435000,0.000256229320000,0.000065258410000,0.000001129408700,0.359762940000000,0.000001048384400
-746,0.965809640000000,0.000062767203000,0.000000824167370,0.000001554657800,0.000299021370000,0.000045282924000,0.000001075033300,0.258035920000000,0.000001198311500
-747,0.963365540000000,0.000055731072000,0.000000940461920,0.000001428392600,0.000374506960000,0.000042786527000,0.000001076518200,0.178559200000000,0.000001065262600
-748,0.960917760000000,0.000048894713000,0.000001055244700,0.000001302100100,0.000450006130000,0.000040011681000,0.000001077999800,0.099067697000000,0.000000932186280
-749,0.958779540000000,0.000045090191000,0.000001084747800,0.000001264694300,0.000581467890000,0.000048923262000,0.000001045131800,0.064820090000000,0.000001082446600
-750,0.956636880000000,0.000041483804000,0.000001112741400,0.000001231050000,0.000713035740000,0.000057842008000,0.000001010845400,0.030544240000000,0.000001232827000
-751,0.955250010000000,0.000041185141000,0.000001305835300,0.000000854912750,0.000947291740000,0.000102316370000,0.000000892299060,0.019519889000000,0.000001004508200
-752,0.953846910000000,0.000040682169000,0.000001498357600,0.000000476859910,0.001182727900000,0.000147015280000,0.000000773142990,0.008439447700000,0.000000775022060
-753,0.946915690000000,0.000043229478000,0.000001166885600,0.000000395979150,0.001616095500000,0.000382185750000,0.000000864967590,0.005744036600000,0.000000969288970
-754,0.941264560000000,0.000045766199000,0.000000838213750,0.000000316672610,0.002047754800000,0.000616465010000,0.000000955031590,0.003058994800000,0.000001162786100
-755,0.940962420000000,0.000050996405000,0.000001055143700,0.000000581040930,0.002885705500000,0.000711194950000,0.000000860926750,0.002158483800000,0.000000803598870
-756,0.940637800000000,0.000056061521000,0.000001273673800,0.000000847374480,0.003729864300000,0.000806618270000,0.000000767499980,0.001251188600000,0.000000441707360
-757,0.937273270000000,0.000061253771000,0.000001064151000,0.000001071425200,0.005210288500000,0.000563211790000,0.000000804012820,0.000904153870000,0.000000505064270
-758,0.935173800000000,0.000066261207000,0.000000853839130,0.000001293745500,0.006696217100000,0.000318892440000,0.000000840657680,0.000555818370000,0.000000566245630
-759,0.930524730000000,0.000065389424000,0.000000970774800,0.000002150122800,0.009694126200000,0.000203943170000,0.000000803416100,0.000412724530000,0.000000705392950
-760,0.924596350000000,0.000064518672000,0.000001085954800,0.000003005007300,0.012686794000000,0.000089376215000,0.000000766232940,0.000269874540000,0.000000846700540
-761,0.924682180000000,0.000058703081000,0.000001075168000,0.000003470477300,0.017706636000000,0.000062205582000,0.000000796881020,0.000201967570000,0.000000734732520
-762,0.924764620000000,0.000052665911000,0.000001062793600,0.000003937311500,0.022741266000000,0.000035236161000,0.000000826209170,0.000133858780000,0.000000622430140
-763,0.921993820000000,0.000045715425000,0.000001242498100,0.000006013663100,0.032646337000000,0.000025759037000,0.000000911867570,0.000103746730000,0.000000759777300
-764,0.920504280000000,0.000038767825000,0.000001422118000,0.000008089072000,0.042546896000000,0.000016314174000,0.000000996077450,0.000073577322000,0.000000899472070
-765,0.921684330000000,0.000035393741000,0.000001410379900,0.000009511819300,0.058859880000000,0.000013137175000,0.000000782916350,0.000055330904000,0.000000855942600
-766,0.926732940000000,0.000031796040000,0.000001400122900,0.000010954985000,0.075259739000000,0.000009942993000,0.000000568603340,0.000036857586000,0.000000814594790
-767,0.931718150000000,0.000030601784000,0.000001286281900,0.000008542204500,0.107139240000000,0.000008735341100,0.000000693902680,0.000028286995000,0.000000691777360
-768,0.935418550000000,0.000029404574000,0.000001172164600,0.000006110707600,0.139094660000000,0.000007524773200,0.000000819499540,0.000019695815000,0.000000571094180
-769,0.937482310000000,0.000030826734000,0.000001435490200,0.000006417178900,0.199683910000000,0.000006725944500,0.000000709930770,0.000014667117000,0.000000510054480
-770,0.940830980000000,0.000032041734000,0.000001701634900,0.000006710366800,0.260204120000000,0.000005956338700,0.000000600481020,0.000009566828800,0.000000451507920
-771,0.948993600000000,0.000035330332000,0.000002434062800,0.000008035145800,0.356491080000000,0.000006048617800,0.000000544198050,0.000008304056400,0.000000764287850
-772,0.958505760000000,0.000038655819000,0.000003159223800,0.000009375142600,0.453897230000000,0.000006112941200,0.000000487217490,0.000007038868500,0.000001078269900
-773,0.957449060000000,0.000041406595000,0.000003776584700,0.000008493842500,0.559651500000000,0.000005775100800,0.000000463943290,0.000006830520300,0.000001147554600
-774,0.956359620000000,0.000043928313000,0.000004389059100,0.000007618926000,0.664572440000000,0.000005411120500,0.000000440827450,0.000006623475600,0.000001213822800
-775,0.963832150000000,0.000044359018000,0.000003954488700,0.000006850233900,0.759967160000000,0.000006955736200,0.000000537400440,0.000005294585600,0.000001031362300
-776,0.964786240000000,0.000044583919000,0.000003531163300,0.000006086518200,0.856301410000000,0.000008544557900,0.000000634934250,0.000003951943700,0.000000844538800
-777,0.960360450000000,0.000041077177000,0.000002995329800,0.000005266376800,0.912455770000000,0.000010337071000,0.000000616784820,0.000003511480800,0.000000596363080
-778,0.955924650000000,0.000037564358000,0.000002458576000,0.000004444825000,0.968703400000000,0.000012161429000,0.000000598602890,0.000003083323700,0.000000350229580
-779,0.947947940000000,0.000033711037000,0.000001913775300,0.000004955047400,0.982306810000000,0.000015747309000,0.000000627018790,0.000003699807200,0.000000479570800
-780,0.941296800000000,0.000029878927000,0.000001367319700,0.000005462205400,0.995805390000000,0.000019340823000,0.000000655254470,0.000004312650200,0.000000608156280
-781,0.935868710000000,0.000027498046000,0.000001200177800,0.000003821749800,0.997906650000000,0.000024164391000,0.000000386386720,0.000003912486100,0.000000686899360
-782,0.929058290000000,0.000025097513000,0.000001031674300,0.000002181268000,1.000000000000000,0.000029170206000,0.000000114357500,0.000003522130000,0.000000768724720
-783,0.919460860000000,0.000024459812000,0.000000948615140,0.000002206622500,0.995243380000000,0.000036952677000,0.000000292620880,0.000004554599000,0.000000956179070
-784,0.909867200000000,0.000023822534000,0.000000865621570,0.000002231945200,0.990486090000000,0.000044728412000,0.000000471164830,0.000005586176200,0.000001143470900
-785,0.903000310000000,0.000024512882000,0.000000754805960,0.000001500599700,0.988907330000000,0.000055259959000,0.000000394378450,0.000005076017700,0.000000928540370
-786,0.900053640000000,0.000025206567000,0.000000645003830,0.000000765441420,0.987310390000000,0.000065555567000,0.000000317189350,0.000004563158900,0.000000712484420
-787,0.897278850000000,0.000028015707000,0.000000651617620,0.000000582309830,0.984506310000000,0.000092500854000,0.000000496727340,0.000006633176900,0.000000756805960
-788,0.894477840000000,0.000030840298000,0.000000659866370,0.000000399469570,0.981674820000000,0.000119888140000,0.000000678724670,0.000008714746800,0.000000801367550
-789,0.890824420000000,0.000035553836000,0.000000472903990,0.000001309679200,0.977315030000000,0.000182944850000,0.000000494673780,0.000008532311500,0.000001012962100
-790,0.887152460000000,0.000040496843000,0.000000285239410,0.000002224619700,0.972933580000000,0.000246236520000,0.000000309931470,0.000008349146800,0.000001225343000
-791,0.896632010000000,0.000045235824000,0.000000455198140,0.000001401018000,0.967675220000000,0.000261892490000,0.000000355837070,0.000009094161400,0.000000803181870
-792,0.907477280000000,0.000049777503000,0.000000627332000,0.000000586723220,0.962395220000000,0.000277598900000,0.000000401892430,0.000009854909100,0.000000377111280
-793,0.913567830000000,0.000051582472000,0.000000745394740,0.000000734850480,0.954229600000000,0.000213987010000,0.000000427386450,0.000009010092100,0.000227794240000
-794,0.920949250000000,0.000053167049000,0.000000862942960,0.000000882335730,0.946081900000000,0.000150349030000,0.000000454225210,0.000008181965600,0.000454198950000
-795,0.929401650000000,0.000051497734000,0.000000771553110,0.000000609816020,0.941138910000000,0.000116182580000,0.000000561119140,0.000006447951600,0.000453417430000
-796,0.855146970000000,0.000049826660000,0.000000680071900,0.000000338360090,0.936188800000000,0.000081982399000,0.000000669578360,0.000004712223900,0.000452634040000
-797,0.781197190000000,0.000046346346000,0.000000977603730,0.000000714602110,0.933342720000000,0.000073395206000,0.000000652320510,0.000004911215900,0.000487315030000
-798,0.706841380000000,0.000043059988000,0.000001275104400,0.000001092859200,0.930471230000000,0.000064761052000,0.000000634962820,0.000005124569800,0.000522177200000
-799,0.630350040000000,0.000051157151000,0.000001119493600,0.000007459364200,0.924927660000000,0.000093014546000,0.000012022379000,0.000002588811900,0.000650875930000
-800,0.553866530000000,0.000059466236000,0.000000962279340,0.000013792881000,0.919381750000000,0.000121558400000,0.000023367131000,0.000000067117827,0.000779555830000
-801,0.460692310000000,0.000056781866000,0.000001963187900,0.000014216261000,0.915539400000000,0.000119090760000,0.000018692774000,0.000000156357080,0.000925863190000
-802,0.367232030000000,0.000054302872000,0.000002973641700,0.000014775197000,0.911681690000000,0.000116910350000,0.000013989343000,0.000000246269460,0.001072610700000
-803,0.273260380000000,0.000054340737000,0.000002211460500,0.000013306949000,0.906477620000000,0.000132649870000,0.000017849218000,0.000000361625650,0.001019581200000
-804,0.179157170000000,0.000054592616000,0.000001433567400,0.000011876978000,0.901264180000000,0.000148706650000,0.000021699667000,0.000000477141710,0.000966475430000
-805,0.085816415000000,0.000060903574000,0.000000930698500,0.000013405994000,0.897600200000000,0.000160506420000,0.000018926766000,0.000000316840070,0.000976304430000
-806,0.072174613000000,0.000067020704000,0.000000424498550,0.000014980589000,0.893919760000000,0.000172641840000,0.000016292551000,0.000000157341730,0.000986164610000
-807,0.058364589000000,0.000073908061000,0.000000249122310,0.000015882038000,0.886046490000000,0.000188147520000,0.000019645649000,0.000000229336130,0.001071073500000
-808,0.044493887000000,0.000080756099000,0.000000075019467,0.000016778188000,0.878194220000000,0.000203564150000,0.000022980006000,0.000000300932920,0.001155491200000
-809,0.030865224000000,0.000082686085000,0.000000037610194,0.000013727669000,0.874706700000000,0.000183698410000,0.000017133462000,0.000000254801740,0.001112215900000
-810,0.017298321000000,0.000084840312000,0.000000000100889,0.000010606674000,0.871191070000000,0.000163724220000,0.000011255396000,0.000000209765190,0.001068696700000
-811,0.015202384000000,0.000087369507000,0.000000000100675,0.000011547712000,0.869326900000000,0.000142695100000,0.000011914598000,0.000000267407580,0.001068050500000
-812,0.013101223000000,0.000089918225000,0.000000000100456,0.000012510269000,0.867419790000000,0.000121776280000,0.000012579221000,0.000000325547620,0.001067366000000
-813,0.010919233000000,0.000095523461000,0.000000000099707,0.000012328923000,0.858688420000000,0.000111914850000,0.000015348538000,0.000000274654980,0.001114397100000
-814,0.008748176500000,0.000100882270000,0.000000000098795,0.000012134685000,0.849982490000000,0.000102101430000,0.000018133050000,0.000000222667380,0.001161162200000
-815,0.006599806400000,0.000094984340000,0.000000000098223,0.000010812141000,0.844283850000000,0.000092797589000,0.000018860759000,0.000000167200960,0.001095517800000
-816,0.005700674800000,0.000088880278000,0.000000000097651,0.000009478178400,0.838589180000000,0.000083805620000,0.000019735540000,0.000000112902360,0.001029974200000
-817,0.004809700500000,0.000083351469000,0.000000000097654,0.000008289315500,0.837201570000000,0.000081107971000,0.000019951372000,0.000000144648320,0.001097220200000
-818,0.003926225000000,0.000077566984000,0.000000000097656,0.000007105847600,0.835789760000000,0.000078390575000,0.000020018922000,0.000000176335960,0.001164903400000
-819,0.003025847400000,0.000067457093000,0.000000000097747,0.000007984179300,0.836920460000000,0.000075724280000,0.000019805321000,0.000000194807480,0.001129852500000
-820,0.002131344800000,0.000057039237000,0.000000000097836,0.000008883599800,0.838036130000000,0.000073032682000,0.000019438598000,0.000000213432940,0.001094467600000
-821,0.001890584000000,0.000053295785000,0.000000021504273,0.000008364245800,0.840305680000000,0.000064511163000,0.000012672801000,0.000000171632790,0.001098700300000
-822,0.001661908000000,0.000049524425000,0.000000043162352,0.000007841000600,0.842574820000000,0.000055927245000,0.000005812697400,0.000000128978230,0.001102941600000
-823,0.001409394000000,0.000052266136000,0.000000021531863,0.000010223819000,0.839802920000000,0.000069142800000,0.000013960995000,0.000000129233450,0.001075298000000
-824,0.001166280800000,0.000054994300000,0.000000000097587,0.000012595533000,0.837027750000000,0.000081993972000,0.000022056613000,0.000000129485040,0.001047760400000
-825,0.000922226750000,0.000050971805000,0.000000034917397,0.000007875537800,0.835657180000000,0.000071596389000,0.000018251623000,0.000000097101063,0.001041569300000
-826,0.000841086230000,0.000046742728000,0.000000069560513,0.000003183756000,0.834281260000000,0.000061230104000,0.000014307571000,0.000000064952751,0.001035382800000
-827,0.000761215950000,0.000044192167000,0.000000435655990,0.000003917331200,0.833974610000000,0.000066463819000,0.000012459941000,0.000000220507550,0.001105255300000
-828,0.000682465810000,0.000041633266000,0.000000802753830,0.000004639469100,0.833663490000000,0.000072016584000,0.000010606351000,0.000000375872970,0.001175346700000
-829,0.000606273230000,0.000049062091000,0.000002939541500,0.000007692267100,0.838121370000000,0.000070802688000,0.000009935339100,0.000000282245420,0.001151452200000
-830,0.000528695580000,0.000056612095000,0.000005116004600,0.000010782457000,0.842548290000000,0.000069866670000,0.000009266907700,0.000000186975180,0.001126997600000
-831,0.000512319750000,0.000060066864000,0.000004903629600,0.000007254208900,0.837665480000000,0.000072195102000,0.000011443320000,0.000000228411880,0.001139144400000
-832,0.000497394520000,0.000063730023000,0.000004708849900,0.000003724988600,0.832788840000000,0.000074513872000,0.000013626810000,0.000000269691690,0.001151230100000
-833,0.000482049310000,0.000064399360000,0.000003611983800,0.000005301742800,0.828765690000000,0.000069611035000,0.000013413116000,0.000000191851980,0.001189916600000
-834,0.000466701300000,0.000065068583000,0.000002531882000,0.000006864680600,0.824739850000000,0.000065014207000,0.000013214677000,0.000000113309150,0.001228600800000
-835,0.000449662120000,0.000063500458000,0.000001782581100,0.000006978308800,0.818603530000000,0.000059274155000,0.000010633341000,0.000000164833540,0.001150937500000
-836,0.000439666280000,0.000061941455000,0.000001035409200,0.000007090821400,0.812480530000000,0.000053878690000,0.000008070707700,0.000000215279830,0.001073804300000
-837,0.000434448770000,0.000063719339000,0.000000681740670,0.000006723383900,0.815394860000000,0.000049667587000,0.000010241357000,0.000000118700050,0.001161593100000
-838,0.000429117550000,0.000065293578000,0.000000322916090,0.000006350056100,0.818278850000000,0.000045082621000,0.000012442372000,0.000000020718246,0.001250541100000
-839,0.000419053070000,0.000067046407000,0.000000296275360,0.000006269581200,0.812489440000000,0.000048292240000,0.000012194712000,0.000000181282560,0.001302826600000
-840,0.000409048750000,0.000068560994000,0.000000268141620,0.000006203405100,0.806710620000000,0.000051168629000,0.000011948453000,0.000000340320700,0.001354655900000
-841,0.000409962260000,0.000065380001000,0.000000246762150,0.000005908304500,0.810746750000000,0.000045760680000,0.000009170447600,0.000000333612780,0.001329624200000
-842,0.000409410880000,0.000062131347000,0.000000224956140,0.000005606949900,0.814737910000000,0.000040559268000,0.000006340368600,0.000000326733540,0.001303943300000
-843,0.000404853100000,0.000070193550000,0.000000545483690,0.000007222956900,0.806781720000000,0.000036970750000,0.000008904233200,0.000000245073030,0.001296407400000
-844,0.000398904560000,0.000078184232000,0.000000863277010,0.000008839035900,0.798853490000000,0.000033720105000,0.000011446006000,0.000000164090430,0.001288872000000
-845,0.000396445440000,0.000078031064000,0.000000772031390,0.000008424438700,0.794161240000000,0.000028734586000,0.000011982074000,0.000000206352280,0.001491810700000
-846,0.000405277880000,0.000078101869000,0.000000680618190,0.000008009068800,0.789458640000000,0.000023584980000,0.000012534564000,0.000000248690450,0.001695114800000
-847,0.000415263690000,0.000078345353000,0.000000400962860,0.000007235302400,0.783077190000000,0.000026690680000,0.000012615005000,0.000000326046430,0.002052314700000
-848,0.000425253380000,0.000078588772000,0.000000122365810,0.000006475251600,0.776690830000000,0.000029766815000,0.000012710939000,0.000000404844830,0.002409685500000
-849,0.000435872800000,0.000076696336000,0.000000129921880,0.000004592562800,0.772011600000000,0.000036028560000,0.000014903410000,0.000000421012590,0.003367437900000
-850,0.000446525920000,0.000074797209000,0.000000137502730,0.000002703536100,0.767313230000000,0.000042311156000,0.000017087637000,0.000000438643150,0.004328389000000
-851,0.000428145290000,0.000066249368000,0.000000172396950,0.000004769006700,0.759111790000000,0.000035973806000,0.000014865276000,0.000000250255360,0.006377571700000
-852,0.000411277430000,0.000057977966000,0.000000207573310,0.000006835196200,0.750939410000000,0.000029490373000,0.000012625789000,0.000000063904539,0.008413463900000
-853,0.000395344250000,0.000053407904000,0.000004417502600,0.000006175245100,0.748263750000000,0.000027362638000,0.000010150196000,0.000000266922900,0.012753672000000
-854,0.000379329180000,0.000049039851000,0.000008634406500,0.000005511994300,0.745568170000000,0.000025224197000,0.000007646832600,0.000000471781720,0.017115098000000
-855,0.000361257220000,0.000044855711000,0.000008608502300,0.000006340912600,0.739271150000000,0.000027626208000,0.000006711498500,0.000000801728850,0.030595678000000
-856,0.000346097600000,0.000040471867000,0.000008582513800,0.000007164672500,0.732991380000000,0.000030013014000,0.000005781598700,0.000001131070500,0.043994385000000
-857,0.000335693710000,0.000039110061000,0.000006013937400,0.000006760842900,0.736831870000000,0.000030875028000,0.000007653602400,0.000000884557480,0.086261884000000
-858,0.000324986550000,0.000037481070000,0.000003387280900,0.000006332252500,0.740596230000000,0.000031875587000,0.000009581063700,0.000000633833970,0.129444650000000
-859,0.000311549430000,0.000034843998000,0.000002543816100,0.000005703363900,0.737385530000000,0.000031972342000,0.000009262410500,0.000001247118800,0.221317930000000
-860,0.000298026300000,0.000032420348000,0.000001695191500,0.000005056128500,0.734144970000000,0.000032069236000,0.000008925837300,0.000001871309200,0.313746240000000
-861,0.000299604370000,0.000030218293000,0.000000950029540,0.000006213427700,0.724900140000000,0.000030190343000,0.000008160721500,0.000002407736400,0.421364930000000
-862,0.000299719180000,0.000028033966000,0.000000213075250,0.000007360275300,0.715699030000000,0.000028452245000,0.000007386170200,0.000002939343300,0.528019760000000
-863,0.000302535990000,0.000024838895000,0.000000153111040,0.000006829291500,0.707967540000000,0.000022468426000,0.000006253610900,0.000004950384100,0.615748300000000
-864,0.000305350870000,0.000021508134000,0.000000093166867,0.000006312782700,0.700236470000000,0.000016486585000,0.000005121419600,0.000006960720900,0.703444880000000
-865,0.000308537000000,0.000020187409000,0.000000114424360,0.000009156158200,0.697141210000000,0.000015504916000,0.000004439693600,0.000008779297000,0.789269440000000
-866,0.000301592990000,0.000018850479000,0.000000135918720,0.000012046030000,0.693972580000000,0.000014511176000,0.000003749929600,0.000010618192000,0.876032460000000
-867,0.000290865250000,0.000020882996000,0.000001207907000,0.000011227408000,0.684956910000000,0.000016038621000,0.000005550307200,0.000011014684000,0.926442830000000
-868,0.000281619930000,0.000022907121000,0.000002267941200,0.000010397447000,0.675966700000000,0.000017559753000,0.000007327620500,0.000011395065000,0.976638860000000
-869,0.000270815540000,0.000022184554000,0.000001757505800,0.000008529687500,0.667286030000000,0.000016345046000,0.000006109137500,0.000011408897000,0.981915410000000
-870,0.000261497470000,0.000021442375000,0.000001258327700,0.000006656972700,0.658635370000000,0.000015167746000,0.000004896769900,0.000011422409000,0.987143580000000
-871,0.000258889390000,0.000021860139000,0.000001441367800,0.000007625315700,0.656526070000000,0.000015871248000,0.000005166923300,0.000009799934300,0.990041030000000
-872,0.000256227420000,0.000022258669000,0.000001626725700,0.000008620457400,0.654339810000000,0.000016614839000,0.000005440270700,0.000008140743700,0.992902960000000
-873,0.000250980740000,0.000024901713000,0.000001694651500,0.000007170710200,0.645221300000000,0.000017957805000,0.000006184393100,0.000007159633600,0.990451750000000
-874,0.000245761920000,0.000027571354000,0.000001763789200,0.000005730847600,0.636143880000000,0.000019322478000,0.000006923095100,0.000006185131800,0.987982860000000
-875,0.000242266210000,0.000026975743000,0.000000983102690,0.000004142906100,0.632470650000000,0.000018275452000,0.000006009265200,0.000004719967000,0.993362600000000
-876,0.000254754700000,0.000026375468000,0.000000196952650,0.000002529275200,0.628759870000000,0.000017220778000,0.000005072995400,0.000003244494200,0.998761100000000
-877,0.000267998710000,0.000032176653000,0.000000188260110,0.000003723210100,0.622861380000000,0.000016590601000,0.000004948001000,0.000003912852600,0.999381200000000
-878,0.000281256270000,0.000037983933000,0.000000177797610,0.000004918405000,0.616955410000000,0.000015991705000,0.000004838834000,0.000004596412500,1.000000000000000
-879,0.000293394570000,0.000036654246000,0.000005942176800,0.000006748382600,0.613045620000000,0.000016178090000,0.000003375139000,0.000007508642000,0.998350550000000
-880,0.000307033490000,0.000035087675000,0.000011709535000,0.000008598930600,0.609120420000000,0.000016332930000,0.000001922653000,0.000010415840000,0.996691480000000
-881,0.000301226730000,0.000033000903000,0.000010439349000,0.000007519625500,0.604602790000000,0.000020796065000,0.000003092692900,0.000009544319500,0.990961960000000
-882,0.000296880160000,0.000030913484000,0.000009151126200,0.000006440008000,0.600082530000000,0.000025260371000,0.000004247019000,0.000008687089600,0.985228600000000
-883,0.000293133310000,0.000030748242000,0.000009808545100,0.000006000421000,0.597900700000000,0.000017016519000,0.000003597794800,0.000008210288300,0.981425980000000
-884,0.000287899060000,0.000030348604000,0.000010451031000,0.000005544197200,0.595705000000000,0.000008768654300,0.000002929603000,0.000007731338600,0.977599640000000
-885,0.000283703060000,0.000029670278000,0.000011240097000,0.000007236295900,0.590913690000000,0.000016808320000,0.000003608344000,0.000007605449600,0.970855750000000
-886,0.000275087100000,0.000028990886000,0.000012030313000,0.000008930893100,0.586114100000000,0.000024859890000,0.000004288085700,0.000007464722000,0.964099930000000
-887,0.000266043960000,0.000028266458000,0.000010102916000,0.000007074317700,0.572769600000000,0.000017097419000,0.000003366466700,0.000007444018600,0.956270890000000
-888,0.000257014070000,0.000027776466000,0.000008178608600,0.000005206068600,0.559443630000000,0.000009347526500,0.000002446333300,0.000007423306600,0.948449170000000
-889,0.000247969870000,0.000024718907000,0.000008596340400,0.000004541889800,0.533255070000000,0.000009628602600,0.000002862104000,0.000008160915100,0.940730200000000
-890,0.000237475160000,0.000021503842000,0.000009030941100,0.000003878928200,0.507112250000000,0.000009909089700,0.000003277076300,0.000008911672700,0.933019690000000
-891,0.000242361180000,0.000022340981000,0.000009049174200,0.000004913450800,0.467457570000000,0.000009832383700,0.000003042244600,0.000009952703600,0.928677250000000
-892,0.000245793640000,0.000023157973000,0.000009085204600,0.000005937426100,0.427639830000000,0.000009723005200,0.000002806445500,0.000011012523000,0.924311560000000
-893,0.000250866960000,0.000020990789000,0.000007896923500,0.000005009981900,0.377957550000000,0.000009424697100,0.000003185766800,0.000012495077000,0.920439820000000
-894,0.000255964370000,0.000018788468000,0.000006702307200,0.000004062831300,0.328009900000000,0.000009124721000,0.000003550836900,0.000013985302000,0.916538100000000
-895,0.000258996820000,0.000019240700000,0.000007687488700,0.000004802887700,0.275174370000000,0.000009224749600,0.000003113944100,0.000015314561000,0.910921940000000
-896,0.000263510860000,0.000019693148000,0.000008655327800,0.000005558134400,0.222308460000000,0.000009324815900,0.000002660575300,0.000016791836000,0.905300770000000
-897,0.000268400580000,0.000018264919000,0.000007380091400,0.000005197262800,0.179262590000000,0.000013766550000,0.000003997543300,0.000018295378000,0.901616800000000
-898,0.000271820160000,0.000016831828000,0.000006118494800,0.000004835160100,0.136071760000000,0.000018190500000,0.000005322694200,0.000019803876000,0.897916560000000
-899,0.000277138100000,0.000017665799000,0.000006893530600,0.000005266829200,0.105035910000000,0.000018574258000,0.000004620861100,0.000018531396000,0.895030120000000
-900,0.000282485090000,0.000018480959000,0.000007673302300,0.000005716039100,0.073804716000000,0.000018927332000,0.000003914576900,0.000017399406000,0.892112260000000
-901,0.000273547970000,0.000017841589000,0.000006988002100,0.000005433084800,0.055686113000000,0.000019224714000,0.000004111585600,0.000016955168000,0.886611610000000
-902,0.000266103220000,0.000017178277000,0.000006302534200,0.000005164983200,0.037563360000000,0.000019489309000,0.000004308628800,0.000016510794000,0.881107760000000
-903,0.000257204030000,0.000017563252000,0.000007604857300,0.000005032014800,0.028010548000000,0.000019461839000,0.000004277037200,0.000017705619000,0.876022150000000
-904,0.000249795230000,0.000017948403000,0.000008925946400,0.000004913899400,0.018452453000000,0.000019434315000,0.000004261811400,0.000018752236000,0.870932000000000
-905,0.000240818660000,0.000018090897000,0.000006016835500,0.000004241752100,0.013814732000000,0.000016807924000,0.000003868382900,0.000018305610000,0.864645260000000
-906,0.000243807670000,0.000018233343000,0.000003089694400,0.000003569606600,0.009177063000000,0.000014181539000,0.000003491343400,0.000017710122000,0.858356520000000
-907,0.000246975130000,0.000018555603000,0.000004683049000,0.000004155054900,0.006654115400000,0.000014914373000,0.000003723474100,0.000018318472000,0.853138370000000
-908,0.000250146650000,0.000018878287000,0.000006260571300,0.000004741329800,0.004127558300000,0.000015648223000,0.000003939514100,0.000019076690000,0.847911190000000
-909,0.000254071800000,0.000018350258000,0.000006192753500,0.000004353418800,0.003378879500000,0.000015078767000,0.000003608004600,0.000018548393000,0.844625410000000
-910,0.000258020400000,0.000017841939000,0.000006124305800,0.000003977631600,0.002624627200000,0.000014504806000,0.000003273982300,0.000018015820000,0.841297540000000
-911,0.000264742440000,0.000018297062000,0.000006706736300,0.000003852018700,0.002278120700000,0.000012915612000,0.000003066976500,0.000018815266000,0.836425550000000
-912,0.000271496750000,0.000018754366000,0.000007273806700,0.000003740858100,0.001929789900000,0.000011351306000,0.000002842241000,0.000019618680000,0.831519670000000
-913,0.000275584740000,0.000018554503000,0.000006621433100,0.000003220520500,0.001687472100000,0.000011066438000,0.000002837481800,0.000018380547000,0.822994670000000
-914,0.000281167440000,0.000018355094000,0.000005971170600,0.000002701890800,0.001445946000000,0.000010782397000,0.000002816139700,0.000017146353000,0.814488630000000
-915,0.000287576300000,0.000018354190000,0.000006216387300,0.000003491195500,0.001306332300000,0.000009500476600,0.000002471376800,0.000015662016000,0.808180050000000
-916,0.000284907730000,0.000018377317000,0.000006462205200,0.000004282481600,0.001166361100000,0.000008182035400,0.000002125737100,0.000014294519000,0.801853270000000
-917,0.000284001610000,0.000017572023000,0.000006567829500,0.000004094545000,0.001077455100000,0.000007666319100,0.000002097021800,0.000014431032000,0.796630270000000
-918,0.000281567630000,0.000016763142000,0.000006673862800,0.000003905771300,0.000988158970000,0.000007148330700,0.000002068168300,0.000014568033000,0.791379280000000
-919,0.000278130300000,0.000016256366000,0.000006627718700,0.000003293211600,0.000952623040000,0.000006637891600,0.000002048592300,0.000013625010000,0.782870040000000
-920,0.000276217750000,0.000015750870000,0.000006599975900,0.000002682354300,0.000917177010000,0.000006162143200,0.000002029052200,0.000012669428000,0.774377470000000
-921,0.000275198180000,0.000014812850000,0.000006134414200,0.000002869402500,0.000915558270000,0.000005372454100,0.000001782805400,0.000011648568000,0.768475360000000
-922,0.000275696720000,0.000013895561000,0.000005648733000,0.000003057114900,0.000913930750000,0.000004613302800,0.000001530648800,0.000010608791000,0.762547990000000
-923,0.000274914480000,0.000014564230000,0.000005885392700,0.000003095878000,0.000868392450000,0.000004726330500,0.000001841072900,0.000009877642500,0.758015670000000
-924,0.000274124970000,0.000015260694000,0.000006141766500,0.000003134816400,0.000822598240000,0.000004839917000,0.000002148121000,0.000009142430200,0.753450430000000
-925,0.000273131100000,0.000014827431000,0.000006042663400,0.000003202286100,0.000798343840000,0.000004041217800,0.000001782420700,0.000008137541100,0.746905550000000
-926,0.000267519310000,0.000014392372000,0.000005961706200,0.000003270003200,0.000773990750000,0.000003256214900,0.000001400103400,0.000007128639300,0.740330460000000
-927,0.000260853710000,0.000013803071000,0.000005597765400,0.000002696643000,0.000755135310000,0.000003738100200,0.000001698332300,0.000006519147600,0.730666130000000
-928,0.000252679320000,0.000013215900000,0.000005216683700,0.000002140801800,0.000736343520000,0.000004201221900,0.000001980254200,0.000005911971200,0.721029470000000
-929,0.000247452870000,0.000013093103000,0.000005309973000,0.000002593677800,0.000731784390000,0.000003609360500,0.000001514187000,0.000005230070800,0.715027440000000
-930,0.000242183090000,0.000012993651000,0.000005403831600,0.000003065207800,0.000727178290000,0.000003023259900,0.000001046376600,0.000004543083400,0.708966580000000
-931,0.000241220190000,0.000013221554000,0.000005230060700,0.000002979950500,0.000766358520000,0.000003281673600,0.000001259015500,0.000004261707700,0.701965580000000
-932,0.000240250540000,0.000013450440000,0.000005055406600,0.000002909733500,0.000805719240000,0.000003537902600,0.000001474367000,0.000003963516200,0.694924700000000
-933,0.000238123270000,0.000012778964000,0.000004781682400,0.000002532139600,0.000760825920000,0.000003081391100,0.000001286104000,0.000003861621200,0.683443710000000
-934,0.000236001720000,0.000012110494000,0.000004490559200,0.000002140923800,0.000716137120000,0.000002627031700,0.000001098728200,0.000003760145500,0.672005190000000
-935,0.000234252290000,0.000011781390000,0.000004021181400,0.000002139034300,0.000701058090000,0.000002530007000,0.000001317310200,0.000003158801400,0.661719890000000
-936,0.000229425080000,0.000011428328000,0.000003534010900,0.000002137135800,0.000686001710000,0.000002433139400,0.000001535497900,0.000002558503000,0.651448990000000
-937,0.000225386030000,0.000011114336000,0.000003599076600,0.000001849771400,0.000665578330000,0.000002812108600,0.000001388898400,0.000002534386900,0.644250670000000
-938,0.000221323830000,0.000010774012000,0.000003645746000,0.000001560904100,0.000645044440000,0.000003196403700,0.000001241527700,0.000002510120600,0.637008680000000
-939,0.000217432110000,0.000010712641000,0.000003583345400,0.000001643857600,0.000623990370000,0.000003105230800,0.000000947990630,0.000002271578900,0.629002500000000
-940,0.000213509270000,0.000010625874000,0.000003520443900,0.000001727355900,0.000602780090000,0.000003013366400,0.000000652398170,0.000002015832100,0.620928870000000
-941,0.000213427820000,0.000010349465000,0.000003575557000,0.000001664473600,0.000624826100000,0.000003176333000,0.000000670928440,0.000001844557700,0.610870360000000
-942,0.000214902970000,0.000010073234000,0.000003611804300,0.000001601633900,0.000646854830000,0.000003339164100,0.000000689442260,0.000001673408300,0.600817510000000
-943,0.000216557280000,0.000009755856300,0.000003368764700,0.000001552570100,0.000468894980000,0.000003388531300,0.000000867311090,0.000001581149700,0.592097330000000
-944,0.000216654040000,0.000009438177800,0.000003106673300,0.000001505016100,0.000290775000000,0.000003420832900,0.000001047045800,0.000001498110900,0.583368330000000
-945,0.000218602210000,0.000008809799800,0.000002923599300,0.000001319044800,0.000281186370000,0.000003564016500,0.000000925714300,0.000001479034500,0.574684990000000
-946,0.000212735130000,0.000008179135100,0.000002739857400,0.000001133964900,0.000271562140000,0.000003673363800,0.000000805659180,0.000001459882800,0.565967870000000
-947,0.000207995660000,0.000008003310700,0.000002625893300,0.000001116532500,0.000273342150000,0.000004015765500,0.000000846608780,0.000001216814000,0.556569140000000
-948,0.000201694220000,0.000007802693900,0.000002511973400,0.000001099104800,0.000275120590000,0.000004358001000,0.000000887537480,0.000000973851890,0.547173100000000
-949,0.000195635370000,0.000007412501900,0.000002401047500,0.000001153337500,0.000139859020000,0.000004224957500,0.000000854122010,0.000001004412100,0.539047880000000
-950,0.000191130660000,0.000007021514700,0.000002289894900,0.000001206111900,0.000004374955500,0.000004126022800,0.000000822354800,0.000001035031200,0.530905280000000
-951,0.000186543610000,0.000006527485200,0.000001988302100,0.000001012745700,0.000003879759400,0.000004438160400,0.000000766163540,0.000001046576000,0.523008260000000
-952,0.000181950710000,0.000006007917800,0.000001671182900,0.000000819143770,0.000003383957600,0.000004750668200,0.000000709902990,0.000001058133100,0.515100800000000
-953,0.000177817930000,0.000006277432000,0.000002528182400,0.000001101483100,0.000003067468100,0.000005284068100,0.000000874295560,0.000000937861650,0.508159060000000
-954,0.000173655540000,0.000006548587500,0.000003413568600,0.000001384054400,0.000002748881400,0.000005820832300,0.000001038007300,0.000000816796990,0.501164140000000
-955,0.000169030690000,0.000006402257500,0.000002919663900,0.000001255618000,0.000002889090700,0.000005443287700,0.000000862113240,0.000000770180810,0.493666510000000
-956,0.000172303290000,0.000006255724100,0.000002444199700,0.000001127010500,0.000003012168400,0.000005065237100,0.000000685986300,0.000000725074820,0.486158190000000
-957,0.000175472310000,0.000006683107500,0.000002444304200,0.000001040240400,0.000002492935600,0.000005689961600,0.000000822872280,0.000000725105810,0.478131970000000
-958,0.000178641240000,0.000007135637900,0.000002444403500,0.000000953460940,0.000001990967000,0.000006280030000,0.000000958035520,0.000000726708250,0.470104080000000
-959,0.000180118370000,0.000007282195300,0.000002328480600,0.000001019174000,0.000001989820600,0.000005860298100,0.000000794728940,0.000000782883830,0.462203850000000
-960,0.000183172130000,0.000007403457600,0.000002212682200,0.000001083230400,0.000001988667500,0.000005406371200,0.000000633338200,0.000000838991370,0.454310880000000
-961,0.000177307620000,0.000008101705200,0.000002218334500,0.000001016443000,0.000001751030400,0.000006010842500,0.000000830994400,0.000000671017460,0.447686480000000
-962,0.000171411390000,0.000008803442300,0.000002204821300,0.000000947719430,0.000001531280500,0.000006653178000,0.000001029652800,0.000000502178220,0.441023790000000
-963,0.000163727800000,0.000009271765400,0.000002246625600,0.000000907912310,0.000001410045600,0.000006244793500,0.000000954594540,0.000000694327790,0.434508830000000
-964,0.000157771130000,0.000009766801800,0.000002288550500,0.000000867979000,0.000001288431300,0.000005835125800,0.000000881045760,0.000000888651720,0.427972150000000
-965,0.000151300310000,0.000010464894000,0.000002022192800,0.000000770516000,0.000001126150100,0.000005423569000,0.000000863085380,0.000000713840140,0.421448770000000
-966,0.000146247440000,0.000011139572000,0.000001753138900,0.000000672772050,0.000000961653080,0.000005010818800,0.000000845070870,0.000000538526820,0.414905390000000
-967,0.000141300210000,0.000011736637000,0.000001753218400,0.000000686312130,0.000001018770700,0.000004946403100,0.000000770719600,0.000000505746040,0.409004720000000
-968,0.000136341290000,0.000012335044000,0.000001755227000,0.000000699881620,0.000001076016900,0.000004881827700,0.000000697949600,0.000000472888850,0.403089540000000
-969,0.000130991270000,0.000012964024000,0.000001796805400,0.000000723468030,0.000001105225100,0.000004598430400,0.000000800991400,0.000000539477070,0.396412370000000
-970,0.000125806280000,0.000013592288000,0.000001838333100,0.000000747026730,0.000001134398200,0.000004350399600,0.000000903921050,0.000000607583260,0.389740750000000
-971,0.000127265890000,0.000013942371000,0.000001810007600,0.000000696937890,0.000001002775800,0.000004180918700,0.000000815738670,0.000000582962770,0.384438080000000
-972,0.000128889550000,0.000014318884000,0.000001779659200,0.000000648305010,0.000000869020070,0.000004046125700,0.000000725545950,0.000000556675280,0.379119070000000
-973,0.000130502360000,0.000014789451000,0.000001661865000,0.000000767101630,0.000000911706430,0.000003738936100,0.000000683356370,0.000000638043160,0.374123990000000
-974,0.000132283200000,0.000015287872000,0.000001541510100,0.000000886494030,0.000000954600670,0.000003444295100,0.000000639180180,0.000000719818010,0.369099900000000
-975,0.000133721610000,0.000015235323000,0.000001518021000,0.000000810805590,0.000000871592330,0.000003677364800,0.000000704449080,0.000000718151980,0.363516800000000
-976,0.000129198910000,0.000015182748000,0.000001494532500,0.000000733520110,0.000000786832510,0.000003889171000,0.000000769704780,0.000000714881720,0.357933850000000
-977,0.000124809940000,0.000014794030000,0.000001523241900,0.000000728464440,0.000000756602370,0.000004029323900,0.000000783580530,0.000000632935420,0.352546880000000
-978,0.000120262380000,0.000014379928000,0.000001551928600,0.000000725017410,0.000000724626090,0.000004134042400,0.000000795680920,0.000000551039190,0.347162280000000
-979,0.000115769230000,0.000013588451000,0.000001396523800,0.000000702600350,0.000000722954610,0.000003993213600,0.000000829306930,0.000000615191460,0.341930520000000
-980,0.000111435760000,0.000012796749000,0.000001243022500,0.000000680176340,0.000000719517840,0.000003852341900,0.000000861175150,0.000000680960990,0.336696810000000
-981,0.000107980870000,0.000012313262000,0.000001399925100,0.000000659184050,0.000000692898630,0.000003861242300,0.000000831326750,0.000000533179720,0.332773150000000
-982,0.000104670920000,0.000011853152000,0.000001559496100,0.000000638089410,0.000000666150780,0.000003870152800,0.000000799560810,0.000000384710900,0.328828670000000
-983,0.000101126220000,0.000010920845000,0.000001337086600,0.000000601983810,0.000000717007160,0.000004125884200,0.000000841803500,0.000000390219880,0.325094460000000
-984,0.000097731020000,0.000009985230300,0.000001115855200,0.000000565749340,0.000000766259990,0.000004382489800,0.000000884189850,0.000000394131010,0.321345700000000
-985,0.000094171396000,0.000009409206800,0.000001355655000,0.000000639881210,0.000000701777770,0.000004604792000,0.000001001682200,0.000000428845800,0.317080500000000
-986,0.000098582443000,0.000008856894900,0.000001596337500,0.000000714284800,0.000000637052690,0.000004827895200,0.000001117819600,0.000000463687160,0.312797840000000
-987,0.000102674340000,0.000008159115900,0.000001409594000,0.000000634671010,0.000000660368020,0.000005150670000,0.000001328762900,0.000000561063870,0.308137030000000
-988,0.000106767500000,0.000007435169300,0.000001224751100,0.000000556655590,0.000000683690420,0.000005437775000,0.000001539778500,0.000000656852180,0.303474030000000
-989,0.000110991940000,0.000006874475600,0.000001202740700,0.000000515029720,0.000000561274230,0.000005158517100,0.000001541853000,0.000000521317600,0.299203220000000
-990,0.000115227430000,0.000006312250400,0.000001180667500,0.000000473290130,0.000000436736540,0.000004878491200,0.000001545719700,0.000000383789950,0.294920020000000
-991,0.000108817260000,0.000005998556300,0.000001097382500,0.000000505764050,0.000000526058260,0.000004697585900,0.000001534467200,0.000000432434220,0.289672150000000
-992,0.000102574360000,0.000005659093200,0.000001012176300,0.000000538215000,0.000000613530600,0.000004516786600,0.000001525007400,0.000000481045010,0.284426920000000
-993,0.000096376662000,0.000005617221100,0.000001245250700,0.000000548982570,0.000000648676400,0.000004596702700,0.000001692707000,0.000000551913630,0.279978140000000
-994,0.000090156281000,0.000005549119600,0.000001477174400,0.000000559786080,0.000000683945050,0.000004676883100,0.000001868184800,0.000000624664620,0.275512060000000
-995,0.000083857013000,0.000005294509200,0.000001268697600,0.000000547302760,0.000000664941050,0.000004249916100,0.000001787549500,0.000000535558810,0.271439470000000
-996,0.000084279237000,0.000005039317500,0.000001061736300,0.000000534790290,0.000000645893050,0.000003858041200,0.000001713931200,0.000000446252550,0.267357160000000
-997,0.000084424509000,0.000005194810200,0.000001246019200,0.000000582232530,0.000000616967780,0.000003640882500,0.000001760343700,0.000000455957610,0.262989630000000
-998,0.000084569500000,0.000005324120600,0.000001432199100,0.000000628012070,0.000000588054020,0.000003402188600,0.000001799532700,0.000000464023220,0.258623400000000
-999,0.000084997258000,0.000005251962500,0.000001263080800,0.000000572931220,0.000000455509910,0.000003315963500,0.000001673721900,0.000000458022950,0.254772720000000
-1000,0.000085261217000,0.000005153463200,0.000001093563800,0.000000517720080,0.000000322654510,0.000003229528700,0.000001536790100,0.000000450369840,0.250912410000000
-1001,0.000082220608000,0.000005316029200,0.000001204190400,0.000000569270820,0.000000445697330,0.000002958103100,0.000001511328200,0.000000447566550,0.247967310000000
-1002,0.000079173402000,0.000005452712400,0.000001315048200,0.000000620929240,0.000000567192730,0.000002689718000,0.000001485809400,0.000000444756390,0.245015460000000
-1003,0.000076051488000,0.000005401137000,0.000001315256300,0.000000555135980,0.000000498630460,0.000002487387200,0.000001334185900,0.000000425129640,0.241730250000000
-1004,0.000072928459000,0.000005349536000,0.000001315462100,0.000000490968600,0.000000430045750,0.000002281367100,0.000001184320600,0.000000403854300,0.238443580000000
-1005,0.000070070477000,0.000005318109300,0.000001446747200,0.000000545847510,0.000000471662120,0.000002428572300,0.000001196281300,0.000000390623070,0.235733570000000
-1006,0.000070347842000,0.000005286297400,0.000001579038100,0.000000602809000,0.000000515418240,0.000002576884600,0.000001208306600,0.000000378931520,0.232996020000000
-1007,0.000070560657000,0.000004945948000,0.000001563997300,0.000000540060990,0.000000504823390,0.000002425184000,0.000001055913900,0.000000362623300,0.229439030000000
-1008,0.000070773644000,0.000004605142300,0.000001548934300,0.000000477229420,0.000000494213790,0.000002273279700,0.000000903318750,0.000000347949940,0.225877000000000
-1009,0.000070927443000,0.000004207392300,0.000001594915000,0.000000355779700,0.000000415721510,0.000002316721500,0.000000711578000,0.000000357827150,0.221717540000000
-1010,0.000071081018000,0.000003836232700,0.000001638864400,0.000000236035210,0.000000335433570,0.000002360142000,0.000000521729020,0.000000367699950,0.217559050000000
-1011,0.000068906979000,0.000003553277600,0.000001821970100,0.000000413168800,0.000000401974750,0.000002328896200,0.000000460751650,0.000000400078340,0.214148160000000
-1012,0.000066722499000,0.000003269005900,0.000002003875500,0.000000591105990,0.000000466984570,0.000002301160000,0.000000401325470,0.000000434264920,0.210720060000000
-1013,0.000064619566000,0.000003139568200,0.000001941366900,0.000000578383000,0.000000425331610,0.000002369825200,0.000000484321620,0.000000408091600,0.206723710000000
-1014,0.000062344274000,0.000002983203200,0.000001880741000,0.000000565630760,0.000000381750750,0.000002434958000,0.000000567499270,0.000000381859810,0.202718130000000
-1015,0.000060030390000,0.000002718313200,0.000001867577800,0.000000520728340,0.000000448064880,0.000002557718800,0.000000464902470,0.000000362045130,0.198575730000000
-1016,0.000060901609000,0.000002429135300,0.000001854397700,0.000000475776700,0.000000512612600,0.000002680608400,0.000000362194260,0.000000342208530,0.194428580000000
-1017,0.000061773677000,0.000002251693400,0.000001796590100,0.000000437480630,0.000000384206630,0.000002917834600,0.000000406537960,0.000000350743610,0.190245500000000
-1018,0.000062478639000,0.000002074057600,0.000001736688900,0.000000399142770,0.000000253822810,0.000003151625400,0.000000452769250,0.000000359287340,0.186057650000000
-1019,0.000063423047000,0.000002037379400,0.000001820846800,0.000000386363660,0.000000246872940,0.000003149449400,0.000000429551130,0.000000307991270,0.182387710000000
-1020,0.000064201806000,0.000001997893200,0.000001907311000,0.000000371858090,0.000000239899070,0.000003143554900,0.000000408101080,0.000000254847680,0.178704880000000
-1021,0.000060830190000,0.000002078188200,0.000001919478800,0.000000425691700,0.000000369066740,0.000003383864200,0.000000445022750,0.000000259871410,0.174487870000000
-1022,0.000057458621000,0.000002161153100,0.000001929606700,0.000000477839280,0.000000498227300,0.000003627853000,0.000000483788240,0.000000263217830,0.170270720000000
-1023,0.000054033151000,0.000002125429400,0.000001847983800,0.000000401282260,0.000000412361500,0.000003683634700,0.000000449645020,0.000000258729450,0.166612110000000
-1024,0.000050762162000,0.000002089541800,0.000001766006300,0.000000322711850,0.000000327985810,0.000003750767000,0.000000417209870,0.000000255904120,0.162937060000000
-1025,0.000047318102000,0.000002242630000,0.000001745510100,0.000000337006960,0.000000289741460,0.000003707339100,0.000000410741500,0.000000242996740,0.159032200000000
-1026,0.000045897597000,0.000002396409200,0.000001722851300,0.000000351365580,0.000000251317590,0.000003678603300,0.000000406102700,0.000000231718970,0.155107970000000
-1027,0.000044176846000,0.000002416882700,0.000001635834400,0.000000288425040,0.000000251199090,0.000003680597900,0.000000363085720,0.000000207941560,0.150451520000000
-1028,0.000042457578000,0.000002437328900,0.000001546842900,0.000000225543100,0.000000249220030,0.000003682578500,0.000000318247150,0.000000185875750,0.145798990000000
-1029,0.000040814840000,0.000002659580500,0.000001629069800,0.000000302266170,0.000000253284550,0.000003732387400,0.000000322408260,0.000000211510390,0.141790280000000
-1030,0.000039167501000,0.000002895962900,0.000001711516200,0.000000379197600,0.000000257359410,0.000003812220900,0.000000324713600,0.000000238908710,0.137770220000000
-1031,0.000038018666000,0.000002872162800,0.000001532232300,0.000000415378990,0.000000309929590,0.000003610764700,0.000000381131970,0.000000193380070,0.132617080000000
-1032,0.000036696449000,0.000002848302200,0.000001352536700,0.000000453346120,0.000000364487910,0.000003420079600,0.000000437677920,0.000000150294710,0.127451910000000
-1033,0.000035464867000,0.000002872447200,0.000001365551800,0.000000475009060,0.000000349172110,0.000003293044000,0.000000401722960,0.000000196792180,0.121661580000000
-1034,0.000034235630000,0.000002896524600,0.000001380589100,0.000000496624110,0.000000332020730,0.000003166252400,0.000000363973760,0.000000242344480,0.115882560000000
-1035,0.000032917683000,0.000002819138900,0.000001322716100,0.000000527954300,0.000000296983290,0.000003061999500,0.000000364468300,0.000000220612510,0.109612240000000
-1036,0.000033474742000,0.000002768678500,0.000001266745000,0.000000557662720,0.000000261849740,0.000002953705900,0.000000364963120,0.000000198820820,0.103324550000000
-1037,0.000033852743000,0.000002573296600,0.000001272240000,0.000000587286220,0.000000286472570,0.000002780524600,0.000000365356200,0.000000182023430,0.095607494000000
-1038,0.000034402645000,0.000002388369300,0.000001277744200,0.000000616972300,0.000000309273460,0.000002606964400,0.000000365749370,0.000000165359760,0.087873610000000
-1039,0.000034817270000,0.000002227060000,0.000001218247800,0.000000616543690,0.000000249811970,0.000002529576400,0.000000355233300,0.000000166045210,0.079707492000000
-1040,0.000035233395000,0.000002067796000,0.000001158495800,0.000000616109300,0.000000188219040,0.000002451849700,0.000000344671140,0.000000166732430,0.071506845000000
-1041,0.000033718954000,0.000002036973900,0.000001201172900,0.000000721489470,0.000000212892030,0.000002288076300,0.000000369510930,0.000000152343130,0.062861841000000
-1042,0.000032201538000,0.000002008825700,0.000001243929700,0.000000828790440,0.000000237612070,0.000002123983700,0.000000394397810,0.000000137925870,0.054200092000000
-1043,0.000030681148000,0.000001832689500,0.000001293012900,0.000000805489970,0.000000243502960,0.000002057928900,0.000000339998730,0.000000142517260,0.046424917000000
-1044,0.000029157782000,0.000001656211900,0.000001342187900,0.000000782143300,0.000000251294140,0.000001987956800,0.000000285494620,0.000000147117200,0.038634733000000
-1045,0.000027631443000,0.000001539776300,0.000001330956600,0.000000741506090,0.000000215601300,0.000001876154700,0.000000312263140,0.000000122858290,0.032806362000000
-1046,0.000026793575000,0.000001423114700,0.000001317613300,0.000000702515760,0.000000179839680,0.000001764134900,0.000000339082360,0.000000098552678,0.026966762000000
-1047,0.000025954056000,0.000001432725100,0.000001431740100,0.000000649627650,0.000000202749920,0.000001655694900,0.000000333718160,0.000000125675800,0.022246400000000
-1048,0.000025112883000,0.000001442351300,0.000001546082500,0.000000596637230,0.000000223806920,0.000001543243500,0.000000326445150,0.000000152850560,0.017516969000000
-1049,0.000024270058000,0.000001407909900,0.000001602005000,0.000000545275540,0.000000182253950,0.000001529497200,0.000000264064960,0.000000151099050,0.013660035000000
-1050,0.000023425580000,0.000001370642400,0.000001660127400,0.000000493814840,0.000000140431320,0.000001515721900,0.000000199663690,0.000000149343910,0.009795717900000
-1051,0.000022579450000,0.000001523773000,0.000001762418100,0.000000421443120,0.000000145890930,0.000001494293600,0.000000186149580,0.000000156225990,0.007564682400000
-1052,0.000021557814000,0.000001677192500,0.000001864900400,0.000000347196800,0.000000151360690,0.000001472821800,0.000000172228360,0.000000163120880,0.005329386800000
-1053,0.000020708213000,0.000001847495100,0.000001992799700,0.000000326675220,0.000000170561750,0.000001478041000,0.000000173536270,0.000000163622230,0.004085882400000
-1054,0.000019856960000,0.000002020886600,0.000002125146700,0.000000304374760,0.000000189608250,0.000001479444700,0.000000174846350,0.000000164124240,0.002840009800000
-1055,0.000018829704000,0.000002225084300,0.000002337773200,0.000000261140180,0.000000170121960,0.000001545898500,0.000000160491570,0.000000154912350,0.002184910600000
-1056,0.000018498524000,0.000002432439100,0.000002550798900,0.000000219565670,0.000000150407290,0.000001608645500,0.000000146109270,0.000000145509070,0.001528564300000
-1057,0.000018166682000,0.000002604091800,0.000002848627700,0.000000173725790,0.000000123959620,0.000001656173700,0.000000129210930,0.000000145473060,0.001195884900000
-1058,0.000017834179000,0.000002778843800,0.000003125894500,0.000000128147960,0.000000097270155,0.000001707626300,0.000000112088750,0.000000145262750,0.000862576450000
-1059,0.000017483514000,0.000002892729100,0.000003488243900,0.000000132812680,0.000000100811930,0.000001801424000,0.000000092248969,0.000000152191190,0.000693305080000
-1060,0.000017114638000,0.000003006824600,0.000003830111200,0.000000137660890,0.000000104360220,0.000001899240500,0.000000072371521,0.000000158958160,0.000523709190000
-1061,0.000016324217000,0.000003093262900,0.000004363244400,0.000000153373200,0.000000114827730,0.000002135775100,0.000000110869400,0.000000179694480,0.000424032100000
-1062,0.000015532275000,0.000003207752300,0.000004897375900,0.000000169290120,0.000000125122590,0.000002372752200,0.000000149247380,0.000000199072600,0.000324054100000
-1063,0.000014738813000,0.000003127013500,0.000005602271200,0.000000144189970,0.000000119276580,0.000002548483800,0.000000137259770,0.000000188772680,0.000272884120000
-1064,0.000013943831000,0.000003018171100,0.000006308484200,0.000000119217880,0.000000113419350,0.000002728400900,0.000000125249350,0.000000178453030,0.000221287010000
-1065,0.000013147328000,0.000002993035400,0.000007207360500,0.000000121087360,0.000000125283300,0.000002897063500,0.000000112444610,0.000000165486870,0.000200006660000
-1066,0.000012754489000,0.000002967847200,0.000008086633100,0.000000122960140,0.000000137362260,0.000003066038100,0.000000099808662,0.000000152496050,0.000179016870000
-1067,0.000012343256000,0.000002788470000,0.000009180548500,0.000000129942360,0.000000111614980,0.000003308854600,0.000000092945846,0.000000158077960,0.000156993710000
-1068,0.000011931231000,0.000002614361500,0.000010297821000,0.000000136937450,0.000000086012484,0.000003552120900,0.000000085876574,0.000000163494470,0.000134928950000
-1069,0.000011536078000,0.000002549423700,0.000011758617000,0.000000147826300,0.000000085899553,0.000003803591400,0.000000089054532,0.000000157671160,0.000124436690000
-1070,0.000011122482000,0.000002484359900,0.000013222128000,0.000000158735270,0.000000085979908,0.000004074930700,0.000000092238285,0.000000152012620,0.000114256710000
-1071,0.000010672694000,0.000002329154400,0.000014709735000,0.000000178501070,0.000000094394928,0.000004195274400,0.000000084760087,0.000000150569740,0.000109376710000
-1072,0.000010204331000,0.000002170839100,0.000016178696000,0.000000196357610,0.000000103019520,0.000004315835800,0.000000077267764,0.000000149123910,0.000104820160000
-1073,0.000009752808600,0.000001989678400,0.000017821735000,0.000000177063770,0.000000080783614,0.000004319861800,0.000000098715175,0.000000122445070,0.000099255703000
-1074,0.000009300426300,0.000001808176300,0.000019467809000,0.000000158974220,0.000000058311708,0.000004362841700,0.000000120007930,0.000000095716254,0.000093680691000
-1075,0.000008847184700,0.000001846565400,0.000021095456000,0.000000180941680,0.000000079961423,0.000004561855000,0.000000107075880,0.000000092446884,0.000080086477000
-1076,0.000008802068800,0.000001885022700,0.000022769059000,0.000000204192640,0.000000101846050,0.000004761231000,0.000000094119560,0.000000088994339,0.000066466810000
-1077,0.000008774652200,0.000002005581900,0.000024510236000,0.000000218600320,0.000000092194937,0.000004804718700,0.000000103569220,0.000000095806526,0.000073214871000
-1078,0.000008747169500,0.000002123530500,0.000026469809000,0.000000233034400,0.000000082525726,0.000004887377900,0.000000113231490,0.000000102631210,0.000079975350000
-1079,0.000008701789100,0.000002423070400,0.000028217574000,0.000000224347880,0.000000079673122,0.000004774505800,0.000000120175810,0.000000089242464,0.000080049538000
-1080,0.000008674157700,0.000002723161900,0.000029968534000,0.000000217427040,0.000000076815088,0.000004700587600,0.000000127328390,0.000000076006310,0.000080123727000
-1081,0.000008378491300,0.000003123178800,0.000031938488000,0.000000228331400,0.000000069451923,0.000004861771300,0.000000146044430,0.000000090652126,0.000071809012000
-1082,0.000008100144200,0.000003523931200,0.000033912035000,0.000000241041050,0.000000062075003,0.000005062489300,0.000000164794890,0.000000105502820,0.000063478777000
-1083,0.000007803370600,0.000003982309100,0.000036321575000,0.000000230540980,0.000000068208410,0.000005027887800,0.000000173773150,0.000000091532158,0.000065554507000
-1084,0.000007506035100,0.000004441527500,0.000038951907000,0.000000220021120,0.000000074353038,0.000004953897000,0.000000182571390,0.000000077535513,0.000067633961000
-1085,0.000007226068500,0.000004730600700,0.000040720634000,0.000000214852770,0.000000073832540,0.000005037172900,0.000000204354200,0.000000072254831,0.000070053939000
-1086,0.000007160939600,0.000005020199300,0.000042492554000,0.000000209674520,0.000000073310956,0.000005159983000,0.000000226176850,0.000000067142854,0.000072815370000
-1087,0.000007095678500,0.000005367423500,0.000045786657000,0.000000193723930,0.000000067673434,0.000005440712500,0.000000257882180,0.000000052905812,0.000067483722000
-1088,0.000007030285200,0.000005743854400,0.000049086750000,0.000000176845940,0.000000062025414,0.000005721949900,0.000000289645450,0.000000038642461,0.000061804411000
-1089,0.000006964759600,0.000006035160200,0.000051958035000,0.000000162632160,0.000000059323204,0.000005727209000,0.000000313577930,0.000000054077543,0.000057804743000
-1090,0.000006899101900,0.000006326991400,0.000055052109000,0.000000148391980,0.000000056418659,0.000005772002400,0.000000337553870,0.000000069720136,0.000053797626000
-1091,0.000006797252300,0.000006160864800,0.000058805163000,0.000000134485460,0.000000063381135,0.000005975150500,0.000000375403950,0.000000080547714,0.000041655212000
-1092,0.000006713250700,0.000005965741700,0.000062565004000,0.000000120733400,0.000000070553909,0.000006178661300,0.000000415300470,0.000000091574581,0.000029185375000
-1093,0.000006611021000,0.000005856373900,0.000068077202000,0.000000102446820,0.000000060530159,0.000006382534700,0.000000441413400,0.000000082312874,0.000030399585000
-1094,0.000006508592900,0.000005718062100,0.000073599381000,0.000000084126576,0.000000050487949,0.000006586770900,0.000000469554660,0.000000073034066,0.000031582009000
-1095,0.000006424062500,0.000005119323700,0.000081098901000,0.000000082577227,0.000000059055535,0.000006831085400,0.000000483865250,0.000000113252260,0.000029979348000
-1096,0.000006393704300,0.000004548268700,0.000088830791000,0.000000081205767,0.000000067440332,0.000007075835100,0.000000500186060,0.000000153543800,0.000028373708000
-1097,0.000006381409000,0.000004350729100,0.000099861575000,0.000000074400940,0.000000054398562,0.000007559749000,0.000000522495870,0.000000223671390,0.000027956917000
-1098,0.000006350935100,0.000004152821900,0.000111131520000,0.000000067583573,0.000000041134186,0.000008044533400,0.000000544845530,0.000000292482230,0.000027505235000
-1099,0.000006338557100,0.000003752489800,0.000125493340000,0.000000061660435,0.000000048530833,0.000008091720600,0.000000561264130,0.000000381296020,0.000014089229000
-1100,0.000006326146100,0.000003322530600,0.000140100700000,0.000000055726406,0.000000055940872,0.000008138980400,0.000000577711710,0.000000468462220,0.000000676078870
+nm_Band,Panchromatic,Coastal Blue,Blue,Green,Yellow,Red,Red Edge,NIR1,NIR2
+350,5.5340663E-06,1.9392369E-06,7.5019579E-07,4.1570837E-07,3.1214522E-07,3.122859E-07,1.3187337E-07,3.4249373E-07,2.7515674E-07
+351,5.8023003E-06,2.4672989E-06,5.3731325E-07,3.5469241E-07,1.9613864E-07,2.196034E-07,1.6760843E-07,1.7166678E-07,1.0415235E-06
+352,6.073528E-06,2.9966029E-06,3.2362989E-07,2.9289922E-07,7.9068775E-08,1.2693395E-07,2.0377712E-07,7.231E-12,1.8173365E-06
+353,6.3059555E-06,3.6665222E-06,4.057486E-07,2.2738706E-07,8.6638033E-08,1.1559629E-07,1.720752E-07,1.1505368E-08,1.2109853E-05
+354,6.5497967E-06,4.3357254E-06,4.8778037E-07,1.6193366E-07,9.419833E-08,1.0473701E-07,1.4040052E-07,2.3050938E-08,2.2395752E-05
+355,6.7758568E-06,3.2731958E-06,3.042196E-07,1.3249361E-07,9.8318436E-08,6.9418112E-08,2.8159198E-07,2.4305981E-08,1.9874005E-05
+356,5.8166756E-06,2.1825735E-06,1.2263946E-07,1.0270482E-07,1.024247E-07,3.4310218E-08,4.2239287E-07,2.5556959E-08,1.7379704E-05
+357,4.9322783E-06,2.5771297E-06,1.8719072E-07,1.3639006E-07,9.1299982E-08,3.7976255E-08,2.8735621E-07,4.9849543E-08,6.364545E-05
+358,4.0225446E-06,2.9868452E-06,2.5266176E-07,1.7167065E-07,7.9715824E-08,4.1729825E-08,1.4739215E-07,7.4782573E-08,0.0001111394
+359,3.1330883E-06,2.3823274E-06,2.7445942E-07,1.6837477E-07,6.3937148E-08,6.0845513E-08,1.5955011E-07,8.03746E-08,9.3464106E-05
+360,2.1846226E-06,1.7487975E-06,2.9502501E-07,1.6474556E-07,4.7188687E-08,8.0825989E-08,1.7087718E-07,8.601687E-08,7.4834976E-05
+361,2.2338414E-06,2.4774412E-06,2.0377389E-07,1.2981229E-07,3.968893E-08,5.4246302E-08,1.4598339E-07,4.5018286E-08,4.227922E-05
+362,2.2788466E-06,3.273669E-06,1.0206934E-07,9.0592164E-08,3.1329589E-08,2.5099509E-08,1.1694336E-07,7.744E-12,6.5114404E-06
+363,2.4374378E-06,3.4223526E-06,1.7155697E-07,1.0881388E-07,4.5789926E-08,5.5782338E-08,9.4296773E-08,1.3081201E-08,3.8105236E-06
+364,2.5700448E-06,3.5795724E-06,2.5188502E-07,1.2856071E-07,6.2466244E-08,9.1464712E-08,6.5731766E-08,2.8505989E-08,5.4153476E-07
+365,2.7439443E-06,3.5578522E-06,2.464541E-07,1.5024865E-07,6.1326276E-08,9.2652578E-08,1.1297886E-07,4.981902E-08,4.8149551E-07
+366,2.9850187E-06,3.4782185E-06,2.3627106E-07,1.7341254E-07,5.8751547E-08,9.2360666E-08,1.6725999E-07,7.4411918E-08,3.9838173E-07
+367,3.2331775E-06,4.0695872E-06,2.824502E-07,1.924355E-07,9.1275749E-08,1.0519144E-07,1.8918226E-07,8.652506E-08,5.4294842E-07
+368,3.4791953E-06,4.7087881E-06,3.3287906E-07,2.1210118E-07,1.2810653E-07,1.18814E-07,2.1208888E-07,9.9571845E-08,7.057888E-07
+369,3.8152965E-06,3.9299729E-06,3.824189E-07,2.4733898E-07,1.0787013E-07,1.5721369E-07,2.0322045E-07,7.9943263E-08,5.2075774E-07
+370,4.1254804E-06,2.941125E-06,4.3520686E-07,2.8496236E-07,8.1922881E-08,2.004421E-07,1.8953592E-07,5.5185195E-08,2.8915802E-07
+371,4.0393792E-06,4.4851959E-06,4.4511054E-07,2.6421525E-07,8.0006243E-08,1.6253333E-07,2.1881799E-07,3.2570931E-08,2.1862642E-07
+372,3.892147E-06,6.2195595E-06,4.5090352E-07,2.3663599E-07,7.6844635E-08,1.1659319E-07,2.502796E-07,5.988468E-09,1.3473515E-07
+373,3.641406E-06,6.2067779E-06,4.5866157E-07,2.77902E-07,8.6894931E-08,1.3422861E-07,2.3431832E-07,2.9069855E-08,1.3295995E-07
+374,3.3321415E-06,6.1546924E-06,4.6452709E-07,3.22273E-07,9.7977873E-08,1.5309677E-07,2.1471618E-07,5.4657932E-08,1.3016822E-07
+375,2.9725294E-06,5.3716325E-06,4.0999948E-07,2.491172E-07,8.4437388E-08,1.380369E-07,1.7587824E-07,2.8747439E-08,1.6104583E-07
+376,3.349876E-06,4.472136E-06,3.4716409E-07,1.6665215E-07,6.907523E-08,1.2033952E-07,1.321392E-07,2.1881E-11,1.9435008E-07
+377,3.6974603E-06,4.8258066E-06,4.2625378E-07,2.7748421E-07,7.7627405E-08,1.5209726E-07,1.7192659E-07,1.7846858E-08,2.4303848E-07
+378,4.0607687E-06,5.1841378E-06,5.0972721E-07,3.9508039E-07,8.6129318E-08,1.8565225E-07,2.1442226E-07,3.6835017E-08,2.9525686E-07
+379,4.4898256E-06,6.2698025E-06,4.7221987E-07,3.8603401E-07,8.1038572E-08,1.744948E-07,2.3869353E-07,3.2827616E-08,2.2158293E-07
+380,4.9451956E-06,7.4164477E-06,4.3081678E-07,3.7556849E-07,7.4765146E-08,1.6231205E-07,2.6469802E-07,2.83316E-08,1.4105087E-07
+381,4.6796646E-06,9.0190715E-06,3.6700564E-07,2.7951597E-07,7.1268524E-08,1.2093759E-07,2.4617255E-07,1.4605447E-08,1.7261252E-07
+382,4.401131E-06,1.0744338E-05,2.9812651E-07,1.7741107E-07,6.7458295E-08,7.6471255E-08,2.2570394E-07,2.7496E-11,2.0484867E-07
+383,4.0689366E-06,1.6256417E-05,3.4453188E-07,2.5649672E-07,5.2760819E-08,1.1981817E-07,2.8889889E-07,7.624928E-09,1.8272254E-07
+384,3.7217619E-06,2.196594E-05,3.9167344E-07,3.3840106E-07,3.7698682E-08,1.6472268E-07,3.5379453E-07,1.5532055E-08,1.5965252E-07
+385,3.3574111E-06,4.537973E-05,5.1489132E-07,4.2535229E-07,7.1229124E-08,2.3661614E-07,3.4016684E-07,3.0714551E-08,2.0957012E-07
+386,3.4938928E-06,6.9595988E-05,6.421847E-07,5.1451733E-07,1.0613367E-07,3.1144156E-07,3.2587612E-07,4.6416714E-08,2.6016022E-07
+387,3.6065391E-06,0.00013806116,6.0666545E-07,4.7954688E-07,2.2328741E-07,3.0387194E-07,3.4522348E-07,4.5838473E-08,2.4328054E-07
+388,3.7262944E-06,0.00020807644,5.7107622E-07,4.436984E-07,3.4301226E-07,2.9607177E-07,3.6546269E-07,4.523804E-08,2.2597467E-07
+389,3.8687036E-06,0.00041800307,6.4667852E-07,4.3203658E-07,4.6961049E-07,3.2633153E-07,5.5989629E-07,7.4660844E-08,2.3172157E-07
+390,4.0140146E-06,0.00063465103,7.2447232E-07,4.1912648E-07,6.0076475E-07,3.5743721E-07,7.6047637E-07,1.0477756E-07,2.3651776E-07
+391,4.4102886E-06,0.0012577345,6.283641E-07,4.1032816E-07,5.6141351E-06,2.5633355E-07,1.5569081E-06,5.3176684E-08,2.3638639E-07
+392,4.8154736E-06,0.0018963521,5.2874263E-07,4.0119552E-07,1.0751859E-05,1.5314849E-07,2.3676005E-06,3.4087E-11,2.361882E-07
+393,5.2064658E-06,0.0049336151,5.0983931E-07,3.6418987E-07,3.1420874E-05,1.9332622E-07,2.1410545E-06,2.443595E-09,2.5915056E-07
+394,5.5967765E-06,0.0080125881,4.9154549E-07,3.2733562E-07,5.2311232E-05,2.3461716E-07,1.9169024E-06,4.889554E-09,2.8241205E-07
+395,6.0275364E-06,0.027428402,5.8307094E-07,3.6965797E-07,2.7310406E-05,2.5116488E-07,1.2974895E-06,8.251118E-09,2.2534558E-07
+396,5.6516655E-06,0.047372325,6.7787432E-07,4.130323E-07,1.5258187E-06,2.6750316E-07,6.6637864E-07,1.1709429E-08,1.6662898E-07
+397,5.2422809E-06,0.10399993,7.1805122E-07,4.726119E-07,8.1324761E-07,3.4205669E-07,1.0809996E-06,3.7449412E-08,1.8957484E-07
+398,4.8292926E-06,0.16180598,7.5894778E-07,5.3264105E-07,8.809386E-08,4.1812463E-07,1.5101601E-06,6.3792528E-08,2.1297158E-07
+399,4.394308E-06,0.25805136,1.7700392E-06,4.8841612E-07,4.9879824E-08,3.5719391E-07,1.7645596E-06,1.2063913E-07,2.1373907E-07
+400,3.9509726E-06,0.35598837,2.8048443E-06,4.4259922E-07,1.0640207E-08,2.9512621E-07,2.0172172E-06,1.7922454E-07,2.1449321E-07
+401,3.8169887E-06,0.45902775,2.652837E-06,4.6553226E-07,4.4854861E-08,2.9841602E-07,1.4409779E-06,9.0053008E-08,1.786629E-07
+402,3.681547E-06,0.56306531,2.4992366E-06,4.8792938E-07,7.9066967E-08,3.0111165E-07,8.5901133E-07,3.8089E-11,1.4131493E-07
+403,3.542732E-06,0.6220937,2.3033997E-06,4.818233E-07,5.9931642E-08,3.0056695E-07,1.4173756E-06,5.4872372E-08,1.4309339E-07
+404,3.4026062E-06,0.68161875,2.1156768E-06,4.7640166E-07,4.0355178E-08,3.0000893E-07,1.9805653E-06,1.1035762E-07,1.4488327E-07
+405,3.2667679E-06,0.70071904,1.654245E-06,4.953566E-07,3.1332756E-08,2.873796E-07,1.640783E-06,1.0437274E-07,1.778401E-07
+406,3.450752E-06,0.7200551,1.1852618E-06,5.1532894E-07,2.2232041E-08,2.7388833E-07,1.2953978E-06,9.8281639E-08,2.1130672E-07
+407,3.6339465E-06,0.73305532,1.0740407E-06,5.013538E-07,8.0344234E-08,3.3739779E-07,1.0973991E-06,9.7745022E-08,2.2393268E-07
+408,3.8199106E-06,0.74619441,9.5665157E-07,4.8707288E-07,1.3883091E-07,4.0197938E-07,8.9579706E-07,9.6482881E-08,2.3554483E-07
+409,4.0058216E-06,0.75571345,1.7587667E-06,5.0422029E-07,1.5672794E-07,4.0774909E-07,9.4008829E-07,9.6383523E-08,3.1968989E-07
+410,4.1873293E-06,0.7653071,2.5667821E-06,5.2076739E-07,1.7484186E-07,4.1356706E-07,9.7840334E-07,9.6277066E-08,4.0488001E-07
+411,4.5873638E-06,0.77339758,3.8683688E-06,4.5955348E-07,1.8806882E-07,3.8964735E-07,1.051811E-06,1.3863488E-07,3.1132484E-07
+412,4.982438E-06,0.78151302,5.1752037E-06,3.9808619E-07,2.0134759E-07,3.6497358E-07,1.1255061E-06,1.8116337E-07,2.1861458E-07
+413,5.4181191E-06,0.79417047,7.1340316E-06,3.8218851E-07,1.8419172E-07,3.5475472E-07,9.9686227E-07,1.696319E-07,2.1294987E-07
+414,5.8602883E-06,0.80695129,9.1237908E-06,3.6599478E-07,1.6673972E-07,3.4499788E-07,8.6603716E-07,1.578967E-07,2.0841984E-07
+415,6.2917015E-06,0.817088,1.348131E-05,3.5903507E-07,1.3467539E-07,6.229121E-07,8.7721485E-07,8.6310205E-08,1.5807382E-07
+416,5.7269991E-06,0.82729741,1.7926625E-05,3.5198768E-07,1.0153374E-07,9.050541E-07,8.8847367E-07,1.4190521E-08,1.0719369E-07
+417,5.1432546E-06,0.83488083,2.4287438E-05,4.692239E-07,1.6230075E-07,6.8565796E-07,1.6075731E-06,5.0353342E-08,1.3530088E-07
+418,4.5563018E-06,0.84249414,3.078944E-05,5.8626943E-07,2.2339263E-07,4.610282E-07,2.3372372E-06,8.6488329E-08,1.6482544E-07
+419,3.9754065E-06,0.85210484,3.601153E-05,4.6219228E-07,2.1261953E-07,3.7324862E-07,1.7414799E-06,9.0637245E-08,1.1850565E-07
+420,3.3953382E-06,0.86178001,4.117641E-05,3.3767368E-07,2.0247723E-07,2.8525313E-07,1.1464503E-06,9.4077807E-08,7.1843712E-08
+421,4.4614461E-06,0.8703355,4.5458544E-05,4.2734463E-07,1.9421422E-07,3.0337075E-07,1.0893386E-06,7.2613065E-08,1.1644704E-07
+422,5.5352128E-06,0.87893544,4.9770878E-05,5.1848829E-07,1.8663976E-07,3.216139E-07,1.0249564E-06,5.0614772E-08,1.6124323E-07
+423,6.6215173E-06,0.88808986,5.3276261E-05,4.5908969E-07,3.3560039E-07,2.8995531E-07,7.4118203E-07,5.242141E-08,2.1635899E-07
+424,7.6893946E-06,0.89729882,5.6920787E-05,3.9916017E-07,4.8585015E-07,2.5801247E-07,4.5284479E-07,5.4242307E-08,2.7064792E-07
+425,8.8388994E-06,0.90505522,7.0128558E-05,3.7412276E-07,3.3329524E-07,2.8493186E-07,7.4095714E-07,1.0213209E-07,2.3008025E-07
+426,9.5094187E-06,0.91285463,8.3346526E-05,3.4883878E-07,1.8006783E-07,3.113957E-07,1.0366118E-06,1.5008389E-07,1.8912535E-07
+427,1.0164798E-05,0.91566507,0.0001165842,3.6243838E-07,2.1433257E-07,2.8629698E-07,1.0323033E-06,1.4509602E-07,1.7249411E-07
+428,1.0823427E-05,0.91847884,0.00014995238,3.7610356E-07,2.4877102E-07,2.6036384E-07,1.0209671E-06,1.4008073E-07,1.5577518E-07
+429,1.1444277E-05,0.92283931,0.00024320981,3.4817146E-07,2.5392204E-07,2.8780359E-07,5.3349453E-06,1.1062985E-07,1.4198071E-07
+430,1.2142077E-05,0.92720806,0.00033741865,3.2079541E-07,2.5833793E-07,3.1480567E-07,9.6790401E-06,8.0871065E-08,1.276383E-07
+431,2.7187372E-05,0.9355417,0.00054868134,3.4479574E-07,3.2217561E-07,3.3916567E-07,3.784289E-05,1.5550998E-07,1.7424399E-07
+432,4.2309152E-05,0.94392361,0.00076201998,3.6902141E-07,3.8663451E-07,3.6303873E-07,6.6284634E-05,2.3166865E-07,2.222483E-07
+433,5.7488382E-05,0.9513918,0.0011538332,4.6093987E-07,3.7799368E-07,2.8917306E-07,3.5535409E-05,2.022489E-07,1.7277156E-07
+434,7.2730559E-05,0.95888196,0.0015472733,5.5410827E-07,3.6931301E-07,2.1499553E-07,4.6285281E-06,1.7270408E-07,1.2443873E-07
+435,8.8108926E-05,0.96508815,0.0022771204,4.6150392E-07,4.2974725E-07,1.6225769E-07,2.507843E-06,1.0360824E-07,1.1367797E-07
+436,0.00016152026,0.97131689,0.0030111925,3.6922768E-07,4.8973428E-07,1.0920984E-07,3.7330752E-07,3.4345748E-08,1.028528E-07
+437,0.00023523949,0.97663674,0.0046231026,3.2012364E-07,4.3123868E-07,1.6529616E-07,3.5686751E-07,7.2991257E-08,5.5095837E-07
+438,0.00030931071,0.98197142,0.0062427159,2.7077988E-07,3.7165942E-07,2.2165042E-07,3.4034449E-07,1.1158273E-07,1.0020334E-06
+439,0.00038432929,0.98395,0.01298592,2.224221E-07,6.9901288E-07,2.5025026E-07,5.8377853E-07,8.481771E-07,1.093826E-06
+440,0.00045993191,0.98592107,0.019782129,1.7456287E-07,1.0289379E-06,2.7907033E-07,8.3204284E-07,1.5986081E-06,1.1876965E-06
+441,0.00095130268,0.98662833,0.038890946,2.2537679E-07,3.1274701E-06,1.9808153E-07,1.5481973E-05,4.780944E-06,6.7041939E-07
+442,0.0014530544,0.98730112,0.058201572,2.776177E-07,5.256338E-06,1.1548168E-07,3.0242974E-05,8.0050796E-06,1.4760595E-07
+443,0.0019446055,0.99088697,0.10544424,3.7656432E-07,4.7500291E-06,2.7569942E-07,1.757608E-05,4.2347803E-06,1.4777749E-07
+444,0.0024447126,0.99447355,0.15279567,4.7483993E-07,4.2425095E-06,4.3554466E-07,4.9314266E-06,4.52449E-07,1.479483E-07
+445,0.0029514707,0.99723579,0.2452001,5.3389719E-07,3.2343847E-06,3.780678E-07,2.5881149E-06,3.6893059E-07,2.1279385E-07
+446,0.023997017,1,0.33816011,5.9330397E-07,2.2119189E-06,3.2023752E-07,2.2983997E-07,2.8490129E-07,2.7802869E-07
+447,0.045203756,0.98313502,0.44793846,4.3629753E-07,1.5305382E-06,2.5342965E-07,2.3235566E-07,1.5706316E-07,1.3511879E-06
+448,0.066597859,0.96609091,0.55868039,2.7788113E-07,8.4304923E-07,1.8601981E-07,2.3488687E-07,2.7752479E-08,2.4366896E-06
+449,0.08765155,0.91012272,0.6296967,4.2169965E-07,6.9307505E-07,2.4974241E-07,2.1652544E-07,2.0439087E-07,1.8308953E-06
+450,0.1097664,0.85393995,0.70097007,5.6604601E-07,5.3839291E-07,3.1369834E-07,1.9809432E-07,3.8134864E-07,1.2200031E-06
+451,0.17362635,0.75346182,0.72655887,6.1455722E-07,4.2872919E-07,2.9374776E-07,2.662991E-07,3.1219859E-07,1.0068662E-06
+452,0.23844389,0.65266381,0.75222197,6.6321523E-07,3.1871941E-07,2.744908E-07,3.3395938E-07,2.4199839E-07,7.9305541E-07
+453,0.30424356,0.52339927,0.76298708,5.4621402E-07,3.7017358E-07,2.7181874E-07,2.3746941E-07,2.8725651E-07,8.6365045E-07
+454,0.36981445,0.3930513,0.77382175,4.2730539E-07,4.2288324E-07,2.6988213E-07,1.4017463E-07,3.328819E-07,9.3480773E-07
+455,0.4361629,0.28157711,0.77825492,4.5823366E-07,3.9298002E-07,3.0517303E-07,1.2759442E-07,3.2712439E-07,5.6684607E-07
+456,0.44590289,0.16944902,0.78270319,4.8840564E-07,3.62897E-07,3.4066548E-07,1.1493911E-07,3.2217217E-07,1.9528446E-07
+457,0.45648778,0.11034867,0.78664791,5.0563143E-07,3.527148E-07,2.4722354E-07,1.5396499E-07,2.7791624E-07,1.685805E-07
+458,0.46715647,0.050694291,0.79060387,5.2300127E-07,3.4242633E-07,1.5290328E-07,1.9257596E-07,2.3323912E-07,1.4264438E-07
+459,0.47731439,0.029890841,0.79529316,1.4132013E-06,5.3332371E-07,1.0046285E-06,1.8701868E-07,2.6050489E-07,9.0973918E-08
+460,0.48753262,0.0089461483,0.80000019,2.3065619E-06,7.2550296E-07,1.8675671E-06,1.8219914E-07,2.8709351E-07,3.8952353E-08
+461,0.49053198,0.0052761112,0.80013379,3.1092478E-06,7.2102277E-07,3.0779297E-06,1.6736054E-07,3.4185003E-07,1.9544458E-08
+462,0.49274231,0.0016080123,0.80025873,3.9209116E-06,7.1653727E-07,4.2797909E-06,1.5175002E-07,3.9657308E-07,1.11211E-10
+463,0.49696981,0.0010581279,0.80321533,4.9316164E-06,5.6353487E-07,2.6027177E-06,1.5467008E-07,3.7142658E-07,1.216613E-07
+464,0.50121865,0.00050403809,0.80617695,5.9499015E-06,4.0849284E-07,9.1283184E-07,1.5682487E-07,3.4521768E-07,2.4424532E-07
+465,0.50499219,0.00036089963,0.80985937,8.51169E-06,5.0929942E-07,7.9577217E-07,1.6329875E-07,5.2192075E-07,4.1350531E-07
+466,0.50798146,0.00021740487,0.81354518,1.1070176E-05,6.0948462E-07,6.8472992E-07,1.6900136E-07,6.9905475E-07,5.8466259E-07
+467,0.51252991,0.00016959987,0.81855486,1.2171667E-05,5.3470594E-07,6.4566463E-07,1.2393706E-07,6.4295615E-07,3.0103034E-07
+468,0.51790002,0.00012118411,0.82358504,1.3378488E-05,4.5927364E-07,6.0624788E-07,7.8167159E-08,5.863606E-07,1.4531954E-08
+469,0.52174041,9.6270561E-05,0.82481692,1.3705324E-05,4.4654443E-07,8.9355648E-07,1.1368212E-07,4.8124577E-07,1.1495881E-08
+470,0.52559558,7.1216848E-05,0.82604517,1.4130593E-05,4.3286053E-07,1.1760557E-06,1.4907483E-07,3.7553859E-07,8.45778E-09
+471,0.52700397,5.8623617E-05,0.82754809,1.4437581E-05,5.5730248E-07,2.0264306E-06,3.2562933E-07,3.7509332E-07,4.294035E-09
+472,0.52841203,4.6177238E-05,0.82904884,1.4842186E-05,6.8202721E-07,2.8707311E-06,5.0258819E-07,3.7376503E-07,1.11773E-10
+473,0.53076677,2.9873415E-05,0.83280034,1.7026133E-05,6.7431818E-07,1.9301552E-06,5.9301389E-07,3.8632727E-07,1.8910392E-06
+474,0.53312805,1.3615346E-05,0.83656242,1.922266E-05,6.6566946E-07,9.9209987E-07,6.8476575E-07,3.9984251E-07,3.7931481E-06
+475,0.53558258,1.1541162E-05,0.84226233,1.9771336E-05,7.0590347E-07,9.5470606E-07,7.8442724E-07,7.3648858E-07,3.6830919E-06
+476,0.53316776,9.4361661E-06,0.84798489,2.0323104E-05,7.4548464E-07,9.2518287E-07,8.814575E-07,1.0769818E-06,3.5723014E-06
+477,0.53090169,9.5398202E-06,0.85778186,2.0884719E-05,7.1226998E-07,9.283263E-07,1.3956496E-06,1.2771211E-06,1.9607187E-06
+478,0.52861085,9.6440112E-06,0.86763035,2.1548632E-05,6.7792017E-07,9.2330394E-07,1.9051723E-06,1.4785991E-06,3.3967848E-07
+479,0.52502256,7.3997947E-06,0.87304712,2.1999389E-05,6.9311543E-07,7.4132604E-07,1.3794296E-06,1.0421228E-06,2.7735927E-07
+480,0.52223283,5.1441683E-06,0.87848171,2.2551527E-05,7.0747859E-07,5.6170622E-07,8.5101776E-07,6.0793501E-07,2.1472244E-07
+481,0.52394779,8.1723921E-06,0.8779204,2.3585164E-05,7.1229697E-07,9.0487017E-07,2.2377336E-06,5.701786E-07,1.3756402E-07
+482,0.52566474,1.1192774E-05,0.87735069,2.4622152E-05,7.1712654E-07,1.244254E-06,3.6291634E-06,5.3228919E-07,6.0141372E-08
+483,0.52875017,1.1168752E-05,0.87653504,2.8587445E-05,6.3565414E-07,1.4459404E-06,7.9284956E-06,1.3592641E-06,1.4190335E-07
+484,0.53101629,1.1126253E-05,0.87570434,3.2573985E-05,5.537304E-07,1.6487076E-06,1.2218121E-05,2.1898172E-06,2.2442052E-07
+485,0.53366042,1.0999763E-05,0.878267,3.5601629E-05,6.9794563E-07,1.280237E-06,1.3833697E-05,1.5955409E-06,6.8024979E-07
+486,0.53297164,1.0853879E-05,0.88083162,3.8750231E-05,8.4313332E-07,9.0922759E-07,1.5376942E-05,1.0063268E-06,1.1407488E-06
+487,0.52978183,1.080197E-05,0.88535358,4.1890501E-05,7.0968022E-07,1.2098694E-06,1.0392802E-05,7.1378159E-07,9.5586661E-07
+488,0.52742213,1.0768295E-05,0.88987152,4.5133204E-05,5.7706235E-07,1.5106722E-06,5.4223984E-06,4.2381168E-07,7.7087272E-07
+489,0.52484215,9.9205279E-06,0.89871377,5.5715036E-05,6.5312206E-07,2.2316964E-06,4.6557302E-06,4.4826307E-07,4.025069E-07
+490,0.52308945,9.0886249E-06,0.90757579,6.6428564E-05,7.3031748E-07,2.946434E-06,3.8784586E-06,4.7278266E-07,3.1963888E-08
+491,0.53106382,9.0694031E-06,0.91739735,8.9364675E-05,6.5390821E-07,2.3614914E-06,3.1821144E-06,5.3826128E-07,1.6282713E-07
+492,0.53824418,9.0683575E-06,0.92727543,0.00011238251,5.7780021E-07,1.7633921E-06,2.4801432E-06,6.0424912E-07,2.9520591E-07
+493,0.54397883,1.1141674E-05,0.93384345,0.000175309,5.4891364E-07,1.9652361E-06,8.9087512E-06,5.2264586E-07,2.1736464E-07
+494,0.54970428,1.3213489E-05,0.9403979,0.00023819049,5.2004107E-07,2.1669253E-06,1.5374962E-05,4.4109227E-07,1.3767023E-07
+495,0.55727957,1.1728878E-05,0.95019152,0.00039629063,3.3690469E-07,2.8837944E-06,1.5336754E-05,3.357521E-07,1.3537828E-07
+496,0.55724732,1.0235201E-05,0.96003056,0.00055533208,1.5359649E-07,3.6049211E-06,1.5382622E-05,2.2977567E-07,1.3307069E-07
+497,0.55786546,7.675655E-06,0.97118818,0.00094120407,3.4960411E-07,2.6489564E-06,1.1797266E-05,1.9056574E-07,6.6812847E-08
+498,0.55847423,5.0945367E-06,0.98241368,0.0013302747,5.4723933E-07,1.6763871E-06,8.0879153E-06,1.5008541E-07,1.25976E-10
+499,0.55835691,3.2049947E-06,0.9911881,0.0022085651,3.6147891E-07,1.6125718E-06,4.6581115E-06,2.3329915E-07,3.6787949E-07
+500,0.55823167,1.3064638E-06,1,0.0030918636,1.7464831E-07,1.5397676E-06,1.200003E-06,3.1793058E-07,7.3624619E-07
+501,0.56700883,1.412747E-06,0.99661277,0.0054021691,2.7762876E-07,2.0564801E-06,8.659646E-07,2.2554062E-07,9.1935758E-07
+502,0.57578699,1.5171888E-06,0.99321665,0.0077137454,3.806656E-07,2.5734709E-06,5.283004E-07,1.3309675E-07,1.1025663E-06
+503,0.58601029,1.2330161E-06,0.96466338,0.014494754,2.4626466E-07,1.9677643E-06,2.5627524E-06,1.4955315E-07,5.6984253E-07
+504,0.59628266,9.4536603E-07,0.93594168,0.021312825,1.1207247E-07,1.3587078E-06,4.6135195E-06,1.6609812E-07,3.4512133E-08
+505,0.60553326,8.6250305E-07,0.85577938,0.040519839,2.2341053E-07,8.290051E-07,4.2209118E-06,2.4986261E-07,2.6560875E-08
+506,0.60871959,7.7756962E-07,0.77545767,0.059763601,3.3496168E-07,2.9480909E-07,3.8361631E-06,3.3283596E-07,1.8431043E-08
+507,0.61399523,6.7281925E-07,0.65464145,0.10901705,2.6245918E-07,2.5219506E-07,2.235684E-06,3.7482744E-07,6.0036331E-08
+508,0.61842021,5.6552563E-07,0.53310461,0.1585592,1.904832E-07,2.0932656E-07,6.2574552E-07,4.1801781E-07,1.0205E-07
+509,0.62216319,6.3376539E-07,0.41558092,0.25486166,1.7836139E-07,2.55141E-07,4.1356441E-07,3.171945E-07,1.5351605E-07
+510,0.62679189,7.0224726E-07,0.29762947,0.35151038,1.6715516E-07,3.0111921E-07,2.0061343E-07,2.1600449E-07,2.0582567E-07
+511,0.62121182,8.0142515E-07,0.22145089,0.46254831,1.668147E-07,2.7852037E-07,1.8560331E-07,3.1124363E-07,2.7435653E-07
+512,0.6155771,9.0132722E-07,0.14469861,0.57440609,1.6646821E-07,2.5574689E-07,1.7047718E-07,4.0718775E-07,3.4505252E-07
+513,0.60865882,8.7440191E-07,0.1066236,0.63767104,1.548916E-07,2.1699638E-07,1.9161347E-07,2.6797693E-07,3.9325589E-07
+514,0.6008495,8.4939708E-07,0.068529709,0.70096184,1.4330842E-07,1.7910822E-07,2.1187937E-07,1.2869787E-07,4.4313928E-07
+515,0.59541384,9.3924013E-07,0.050368437,0.72300742,1.3593487E-07,2.450711E-07,1.2782991E-07,2.9012408E-07,8.0217456E-07
+516,0.60237964,1.0315164E-06,0.032106602,0.74516569,1.2754548E-07,3.1139411E-07,4.2962713E-08,4.5146232E-07,1.1631764E-06
+517,0.60849748,1.0875212E-06,0.022842873,0.75506552,2.2909929E-07,2.5938701E-07,8.2938678E-08,4.0430928E-07,9.8087345E-07
+518,0.61551836,1.1456196E-06,0.013555038,0.76498656,3.318907E-07,2.0635435E-07,1.2319486E-07,3.5605638E-07,7.9809307E-07
+519,0.62309397,1.06537E-06,0.0096586799,0.77216944,2.3511764E-07,1.9906198E-07,1.5299035E-07,3.3383978E-07,6.2464879E-07
+520,0.630712,9.8452247E-07,0.0057341091,0.77938902,1.3862708E-07,1.9081744E-07,1.8299721E-07,3.1145691E-07,4.482596E-07
+521,0.63775191,8.0516583E-07,0.0045137381,0.78240309,1.43512E-07,2.1137657E-07,1.4815117E-07,3.7327482E-07,3.5718254E-07
+522,0.64478343,6.2588128E-07,0.0032938656,0.78540934,1.4839358E-07,2.3192493E-07,1.1242693E-07,4.3506249E-07,2.6614252E-07
+523,0.65352167,8.6413093E-07,0.0026531826,0.79221241,3.388732E-07,1.8041985E-07,1.0911897E-07,3.6227331E-07,2.1950334E-07
+524,0.66229554,1.1054934E-06,0.0020094003,0.79904049,5.302638E-07,1.2866583E-07,1.0579407E-07,2.8814447E-07,1.7263819E-07
+525,0.67154084,8.993634E-07,0.0016559537,0.80684987,3.5707537E-07,1.144632E-07,1.1225982E-07,1.799011E-07,2.1701096E-07
+526,0.66725104,6.9054503E-07,0.0013013006,0.81468042,1.8230724E-07,1.0021173E-07,1.1874673E-07,7.1586995E-08,2.6153259E-07
+527,0.66519951,1.0595939E-06,0.0010878203,0.82356724,2.744797E-07,5.6907601E-08,1.1738325E-07,1.0534568E-07,1.858004E-06
+528,0.66220797,1.4293741E-06,0.00087272528,0.83250322,3.673339E-07,1.3552173E-08,1.1600716E-07,1.386557E-07,3.4560782E-06
+529,0.65847717,2.5220514E-06,0.00073897811,0.83662679,4.3775472E-07,1.2020987E-07,1.6606169E-07,1.258453E-07,6.1156685E-06
+530,0.65473338,3.6274695E-06,0.00060489218,0.84075604,5.0935E-07,2.2704261E-07,2.1624054E-07,1.1300215E-07,8.7818798E-06
+531,0.66155881,2.5870181E-06,0.00051300259,0.84116715,3.8852129E-07,1.368623E-07,1.5092209E-07,6.1941751E-08,4.8229017E-06
+532,0.66838953,1.5592406E-06,0.00042099015,0.84157419,2.685346E-07,4.6015642E-08,8.4516754E-08,1.0614048E-08,8.621606E-07
+533,0.67667403,9.9611208E-07,0.00036200298,0.84250331,1.9492973E-07,2.3163616E-08,1.2680979E-07,4.6390394E-08,5.4939668E-07
+534,0.6849966,4.2982494E-07,0.00030268328,0.8434274,1.1990362E-07,7.2623E-11,1.6924612E-07,8.2366078E-08,2.3660554E-07
+535,0.69309803,4.0051785E-07,0.00025923436,0.84430485,2.0200402E-07,2.4204452E-08,1.614003E-07,4.6732687E-08,3.8259677E-07
+536,0.69291686,3.710657E-07,0.00021557359,0.84517844,2.8449811E-07,4.8340801E-08,1.5259587E-07,1.0825964E-08,5.2928782E-07
+537,0.69217349,4.7117388E-07,0.00018396564,0.84629798,2.2816503E-07,2.4301428E-08,1.6296767E-07,1.6315567E-08,2.8679363E-06
+538,0.69049668,5.7159905E-07,0.00015225558,0.84741595,1.7165056E-07,7.3853E-11,1.7337162E-07,2.1721111E-08,5.2227444E-06
+539,0.68936994,4.1947937E-07,0.0001306497,0.84887628,1.4844637E-07,3.3074587E-08,1.4493658E-07,1.087202E-08,4.9494172E-06
+540,0.68823724,2.6907525E-07,0.00010894003,0.85033527,1.2417466E-07,6.6218732E-08,1.1644084E-07,8.3101E-11,4.6754881E-06
+541,0.6845702,4.0529102E-07,9.5459461E-05,0.85479328,2.6369071E-07,4.265305E-08,1.1321308E-07,1.1030841E-08,2.4000191E-06
+542,0.68085484,5.4263013E-07,8.1864194E-05,0.85926621,4.0436126E-07,1.8983612E-08,1.099555E-07,2.2050656E-08,1.0712963E-07
+543,0.67572457,4.2783631E-07,7.0752084E-05,0.86017941,3.1838261E-07,1.0294134E-07,1.2029262E-07,3.7769845E-08,7.6752606E-08
+544,0.66964552,3.1493291E-07,5.9623563E-05,0.86108948,2.3227817E-07,1.8823722E-07,1.3064405E-07,5.3511536E-08,4.6507488E-08
+545,0.66497328,3.6950275E-07,5.1422644E-05,0.86351554,3.6281117E-07,1.4181573E-07,6.9906929E-08,1.0609256E-07,2.9856829E-07
+546,0.67347133,4.2644987E-07,4.3024317E-05,0.86594464,4.9305172E-07,9.6069109E-08,8.596689E-09,1.6010892E-07,5.510024E-07
+547,0.67972191,8.515702E-06,4.9063408E-05,0.86807735,2.669142E-06,9.0685225E-08,1.3056549E-08,1.3233407E-07,1.5728764E-06
+548,0.68692482,1.6610671E-05,5.4962574E-05,0.87020942,4.8458933E-06,8.5291531E-08,1.7580501E-08,1.045103E-07,2.5911935E-06
+549,0.69422842,7.8988137E-05,6.0812234E-05,0.87637941,5.9263558E-06,1.0213741E-07,2.2427983E-08,5.7668167E-08,1.8145577E-06
+550,0.70156014,0.00014168023,6.6688956E-05,0.8825705,7.0014619E-06,1.1944107E-07,2.7203689E-08,1.0708303E-08,1.0306721E-06
+551,0.70349736,7.2510913E-05,6.4278398E-05,0.88908406,6.8457866E-06,7.6313757E-08,6.9807734E-08,4.6058621E-08,5.6707902E-07
+552,0.70448084,3.1047841E-06,6.2018075E-05,0.8955926,6.6900514E-06,3.3086696E-08,1.1241573E-07,8.1412292E-08,1.0361285E-07
+553,0.70750262,1.6865244E-06,6.2654283E-05,0.90584832,5.7809898E-06,4.155118E-08,1.3453721E-07,7.6854565E-08,9.0860506E-08
+554,0.71053286,2.5361589E-07,6.3293406E-05,0.91615241,4.876973E-06,5.0064885E-08,1.5583676E-07,7.2269029E-08,7.8211375E-08
+555,0.71357642,3.0650275E-07,6.0657672E-05,0.92446903,4.3711018E-06,7.5933161E-08,1.5513297E-07,9.9514922E-08,1.5002386E-07
+556,0.71183523,3.5955608E-07,5.7860934E-05,0.93280673,3.8740947E-06,1.0236161E-07,1.5442603E-07,1.2695183E-07,2.2134411E-07
+557,0.71051196,3.0303692E-07,5.882361E-05,0.93904567,4.5603284E-06,1.9436225E-07,1.5169286E-07,1.4490895E-07,1.5687132E-07
+558,0.70918305,2.4642209E-07,5.9940124E-05,0.94529046,5.2582001E-06,2.8651528E-07,1.4799957E-07,1.6394623E-07,9.1389029E-08
+559,0.70900925,3.8267714E-07,6.1241421E-05,0.95376566,4.5393716E-06,2.029641E-07,2.5304214E-07,1.2765046E-07,1.1996645E-07
+560,0.70978554,5.199685E-07,6.2551349E-05,0.96228486,3.8255289E-06,1.1780226E-07,3.5888454E-07,9.1285393E-08,1.4876035E-07
+561,0.72163216,5.2084147E-07,5.803796E-05,0.96834927,5.7426199E-06,7.6990185E-08,1.0697873E-06,4.5719326E-08,9.006105E-08
+562,0.73254397,5.2171424E-07,5.350907E-05,0.97442822,7.6661129E-06,3.633128E-08,1.7859665E-06,8.5004E-11,3.134638E-08
+563,0.74430102,4.5423365E-07,5.6212436E-05,0.97877471,1.4587928E-05,9.479318E-08,2.2623018E-06,4.2989673E-08,1.5732557E-08
+564,0.75511526,3.8655381E-07,5.876873E-05,0.9831286,2.1647152E-05,1.5352224E-07,2.7303321E-06,8.5891365E-08,1.65962E-10
+565,0.76575249,2.6941159E-07,5.8683535E-05,0.98572639,2.6690646E-05,8.6385634E-08,2.084103E-06,7.4897259E-08,1.65976E-10
+566,0.76373109,1.5070624E-07,5.8752872E-05,0.98832551,3.1745952E-05,1.9089628E-08,1.4460384E-06,6.3769936E-08,1.65989E-10
+567,0.7630856,2.576557E-07,5.2087636E-05,0.99261347,4.8887372E-05,4.9234766E-08,1.0220751E-06,7.0603626E-08,1.65751E-10
+568,0.76242585,3.639512E-07,4.5537651E-05,0.99691366,6.6130973E-05,7.9658079E-08,6.0531735E-07,7.7584815E-08,1.6551E-10
+569,0.76012995,2.1489282E-07,4.7449501E-05,0.99845783,9.6644338E-05,1.5199919E-07,7.5338349E-07,3.8825497E-08,4.298085E-09
+570,0.7578266,6.5148178E-08,4.9364385E-05,1,0.00012711981,2.2377574E-07,9.0267623E-07,9.3648E-11,8.45577E-09
+571,0.75907506,3.2627752E-08,4.741155E-05,0.99766425,0.00019668561,1.5926049E-07,1.2440817E-06,9.391E-11,4.308821E-09
+572,0.75933708,1.77475E-10,4.5295276E-05,0.99531502,0.00026647946,9.3744008E-08,1.5993603E-06,9.4064E-11,1.60596E-10
+573,0.75898706,1.76324E-10,3.7647007E-05,0.99079164,0.00042250227,1.1235065E-07,2.4059631E-06,7.4687688E-08,1.59062E-10
+574,0.75863298,1.74954E-10,2.9985759E-05,0.98625615,0.00057878441,1.311852E-07,3.2139054E-06,1.4928375E-07,1.57525E-10
+575,0.7598178,2.0676379E-07,3.1016408E-05,0.97912071,0.0008950242,1.3255056E-07,3.1146985E-06,7.4964402E-08,1.56488E-10
+576,0.76795422,4.1427554E-07,3.2052585E-05,0.97193207,0.0012130677,1.3392211E-07,3.0148833E-06,9.3348E-11,1.55444E-10
+577,0.77596215,1.178343E-06,3.0554246E-05,0.92921942,0.0018863112,2.307564E-07,3.0625021E-06,9.305E-11,8.9995409E-08
+578,0.78400408,1.9464421E-06,2.8888915E-05,0.88627061,0.002563098,3.2810077E-07,3.120277E-06,9.2639E-11,1.8027863E-07
+579,0.78855196,1.831426E-06,2.3161531E-05,0.77509559,0.0042219591,2.6711649E-07,3.8037927E-06,9.1931E-11,7.2370692E-07
+580,0.7940855,1.7143355E-06,1.7440465E-05,0.66404043,0.0058788975,2.0719545E-07,4.4864979E-06,9.1223E-11,1.2648242E-06
+581,0.7958804,1.1103633E-06,1.7479886E-05,0.51029375,0.010792315,2.7156033E-07,5.571057E-06,1.2811015E-08,6.5731718E-07
+582,0.79667466,5.0145109E-07,1.751934E-05,0.35584748,0.015727864,3.3621403E-07,6.6604745E-06,2.5679861E-08,4.856303E-08
+583,0.79919564,2.5151894E-07,1.7415007E-05,0.24702449,0.037386593,3.9951376E-07,6.7415648E-06,1.2880561E-08,1.4237362E-07
+584,0.80172059,1.88571E-10,1.7149476E-05,0.13750853,0.05918194,4.632084E-07,6.8230673E-06,8.9897E-11,2.3677624E-07
+585,0.80071476,9.7827164E-08,1.4344703E-05,0.092924133,0.13465235,5.1154487E-07,6.0504752E-06,2.9597502E-08,2.936035E-07
+586,0.80373808,1.9565383E-07,1.1523815E-05,0.048339161,0.21012203,5.5987839E-07,5.2778471E-06,5.9084415E-08,3.523233E-07
+587,0.80846859,1.3679712E-07,1.1112342E-05,0.032973451,0.32925507,5.7894017E-07,5.1144027E-06,6.6596865E-08,2.2426969E-07
+588,0.81423252,7.7764138E-08,1.0697906E-05,0.017503597,0.44918561,5.9913438E-07,4.9396681E-06,7.4270008E-08,9.5158331E-08
+589,0.81727131,3.0080427E-07,1.174662E-05,0.011533107,0.5563707,7.1469736E-07,6.0204849E-06,6.9599744E-08,1.5904082E-07
+590,0.81929006,5.258429E-07,1.2779107E-05,0.0055626878,0.66355011,8.292398E-07,7.0911406E-06,6.5040362E-08,2.2311163E-07
+591,0.81957402,1.4773758E-06,1.1199472E-05,0.004188538,0.7491538,8.143108E-07,8.8527058E-06,3.2627493E-08,3.7817301E-07
+592,0.82087292,2.4363925E-06,9.6147614E-06,0.0028100026,0.83502524,8.0034697E-07,1.0640083E-05,9.3019E-11,5.3372468E-07
+593,0.82075591,3.2893898E-06,8.766507E-06,0.0021434058,0.86137158,9.1321549E-07,1.1970574E-05,9.4126E-11,5.3431152E-07
+594,0.82063504,4.1442467E-06,7.9163504E-06,0.0014753339,0.88777201,1.0293855E-06,1.3405493E-05,9.5123E-11,5.348973E-07
+595,0.82302956,4.4933396E-06,8.6227628E-06,0.0011294048,0.89980583,1.3185961E-06,1.3750168E-05,9.6522E-11,6.1336963E-07
+596,0.82645415,4.8444135E-06,9.3331897E-06,0.00078144092,0.91189836,1.6197301E-06,1.4096679E-05,9.7815E-11,6.9229234E-07
+597,0.82833758,3.4735448E-06,9.2285177E-06,0.00059958689,0.91731227,6.5985116E-06,1.5440598E-05,9.9042E-11,3.4553938E-07
+598,0.83125013,2.1088569E-06,9.1072391E-06,0.00041735409,0.92273343,1.1608109E-05,1.6684869E-05,1.00271E-10,1.87634E-10
+599,0.83505373,1.5450059E-06,8.5962367E-06,0.00032045256,0.92767476,1.2059088E-05,2.0335082E-05,1.0343081E-07,2.8888458E-07
+600,0.83886881,9.7736627E-07,8.0652214E-06,0.00022289901,0.93263362,1.2616287E-05,2.4009316E-05,2.0755015E-07,5.7774697E-07
+601,0.84211945,1.345813E-06,8.1653727E-06,0.00017146579,0.93547384,1.8617371E-05,2.8651198E-05,1.0379279E-07,5.3504221E-07
+602,0.84640293,1.7143769E-06,8.2655165E-06,0.0001200144,0.9383103,2.462038E-05,3.3294497E-05,1.04491E-10,4.9426631E-07
+603,0.8514228,1.5974575E-06,8.8121902E-06,9.4446539E-05,0.9420513,2.9030341E-05,3.5538959E-05,1.05181E-10,4.6612406E-07
+604,0.85645832,1.4777145E-06,9.3447143E-06,6.8637063E-05,0.94580146,3.3459925E-05,3.7689695E-05,1.05873E-10,4.3785127E-07
+605,0.86080208,1.2587204E-06,8.9661967E-06,5.3940472E-05,0.94702586,4.0950264E-05,3.7490497E-05,7.808207E-09,5.141925E-07
+606,0.85889692,1.0396289E-06,8.587478E-06,3.9237501E-05,0.94824616,4.8443521E-05,3.7291035E-05,1.5505613E-08,5.886075E-07
+607,0.85867281,1.2464557E-06,7.9166159E-06,3.0211438E-05,0.95104209,6.3057364E-05,3.8985506E-05,1.1035446E-07,5.9504016E-07
+608,0.85740167,1.4536709E-06,7.2444451E-06,2.1168079E-05,0.95383943,7.7698748E-05,4.0683041E-05,2.0561176E-07,5.9952339E-07
+609,0.85845757,1.8588338E-06,7.6776593E-06,1.4020332E-05,0.96011503,0.00010023274,4.7233091E-05,1.0294335E-07,8.8381301E-07
+610,0.85846244,2.268267E-06,8.1295854E-06,6.850059E-06,0.96641243,0.0001229119,5.3814825E-05,1.0595E-10,1.1694887E-06
+611,0.8613348,2.5128381E-06,8.7311412E-06,5.3419509E-06,0.97273378,0.00017153816,6.458943E-05,7.5231345E-08,8.7996459E-07
+612,0.86421298,2.7722905E-06,9.3351867E-06,3.8273993E-06,0.97907476,0.00022036963,7.5409309E-05,1.5101214E-07,5.8722735E-07
+613,0.8661811,3.4037899E-06,8.903715E-06,3.2243763E-06,0.98386303,0.00031696194,8.3454068E-05,7.5793563E-08,4.8155292E-07
+614,0.86920848,4.0381388E-06,8.4702037E-06,2.6058053E-06,0.98866499,0.00041399179,9.164001E-05,5.58164E-10,3.7539297E-07
+615,0.87028531,6.0805515E-06,7.3779808E-06,1.7116945E-06,0.98972282,0.00062809192,8.8380395E-05,3.312E-10,2.8602007E-07
+616,0.8724151,8.0998041E-06,6.2856763E-06,8.0732046E-07,0.99077551,0.00084219826,8.512019E-05,1.03878E-10,1.9703941E-07
+617,0.87609068,1.0416011E-05,6.8693381E-06,4.5300862E-07,0.99206284,0.0013795786,7.8947831E-05,7.6104498E-08,2.129117E-07
+618,0.87977425,1.2740425E-05,7.4550433E-06,9.8326761E-08,0.99334898,0.0019188701,7.285857E-05,1.5224777E-07,2.272447E-07
+619,0.88505054,1.1416513E-05,7.7094034E-06,9.5989781E-07,0.99667099,0.003389641,8.1604472E-05,7.642079E-08,3.7963876E-07
+620,0.88927779,1.0086222E-05,7.9818486E-06,1.829024E-06,1,0.0048673569,9.0391133E-05,1.03109E-10,5.34755E-07
+621,0.89248049,8.0034869E-06,7.2192828E-06,1.5070192E-06,0.9986561,0.0099348903,0.00012219937,1.02992E-10,5.4276866E-07
+622,0.89461228,5.944105E-06,6.4566769E-06,1.1940219E-06,0.99730701,0.015002391,0.00015402405,1.02992E-10,5.5278236E-07
+623,0.89833696,5.1748684E-06,5.6804555E-06,2.1651905E-06,0.941429,0.030519236,0.00019469852,7.419316E-09,5.511021E-07
+624,0.90206242,4.4281421E-06,4.903305E-06,3.1207207E-06,0.88548199,0.046054086,0.00023541973,1.473036E-08,5.4941769E-07
+625,0.90925311,3.8593366E-06,5.5383894E-06,6.1912236E-06,0.75943347,0.095565862,0.0001847658,7.456338E-09,6.3239844E-07
+626,0.91432628,3.2853994E-06,6.1617943E-06,9.2756146E-06,0.63225063,0.14551148,0.00013365853,1.04965E-10,7.1811511E-07
+627,0.91314037,3.2103222E-06,6.1538022E-06,8.821842E-06,0.50174001,0.24482656,7.8977076E-05,7.974096E-08,9.9395598E-07
+628,0.91302015,3.1353999E-06,6.1286817E-06,8.3691394E-06,0.3715628,0.34388001,2.4474383E-05,1.588028E-07,1.2690662E-06
+629,0.9154513,2.9039602E-06,5.1632578E-06,1.1812157E-05,0.25311892,0.4697898,1.6697256E-05,7.9754884E-08,1.1820443E-06
+630,0.91788531,2.6718196E-06,4.1949433E-06,1.5226298E-05,0.13432221,0.59607117,8.7897701E-06,1.07481E-10,1.0947584E-06
+631,0.91601139,2.987139E-06,3.7597617E-06,1.4353485E-05,0.086068956,0.70046342,6.8356052E-06,1.08477E-10,7.2231597E-07
+632,0.91520068,3.3278789E-06,3.3050043E-06,1.3606694E-05,0.037557345,0.80540506,4.8601649E-06,1.09596E-10,3.4991315E-07
+633,0.91324084,2.9075622E-06,3.676039E-06,1.8495586E-05,0.024147689,0.83917349,4.0949007E-06,1.10714E-10,2.9983261E-07
+634,0.91235009,2.4850246E-06,4.0489698E-06,2.340977E-05,0.010667886,0.87310928,3.3256054E-06,1.11717E-10,2.4744294E-07
+635,0.91076189,2.4896115E-06,4.1431195E-06,2.5692871E-05,0.007385241,0.87277617,2.6914412E-06,1.1276E-10,3.6263009E-07
+636,0.91353336,2.4942004E-06,4.2549592E-06,2.7984248E-05,0.0040904314,0.87243662,2.0440467E-06,1.13685E-10,4.7824039E-07
+637,0.91583172,2.5424791E-06,3.9775746E-06,3.1024099E-05,0.0028547416,0.8810359,1.6528372E-06,9.3592566E-08,5.2551344E-07
+638,0.91812645,2.5907579E-06,3.7001046E-06,3.4064543E-05,0.0016187386,0.88963323,1.2615255E-06,1.8672856E-07,5.7279552E-07
+639,0.92205217,2.643723E-06,3.2371851E-06,3.1615566E-05,0.0011555485,0.90874729,1.1658482E-06,9.3780619E-08,3.2910584E-07
+640,0.92488995,2.6968722E-06,2.7724951E-06,2.9157133E-05,0.00069059962,0.92792806,1.0708936E-06,1.16185E-10,8.3256097E-08
+641,0.92998073,2.7230075E-06,3.1584957E-06,2.8516003E-05,0.0005071172,0.94055085,8.7178274E-07,4.7615534E-08,3.4441274E-07
+642,0.93397699,2.7491723E-06,3.5625306E-06,2.8006534E-05,0.0003233561,0.95318924,6.7236826E-07,9.5062073E-08,6.0678772E-07
+643,0.93968215,2.5839657E-06,3.9522347E-06,2.6051866E-05,0.00024688813,0.95820103,6.3827304E-07,4.771789E-08,6.4277014E-07
+644,0.94539911,2.4182866E-06,4.3254972E-06,2.4091627E-05,0.00017020562,0.9632226,6.0407983E-07,1.17168E-10,6.8091985E-07
+645,0.95079139,2.4963138E-06,3.8435929E-06,2.4144617E-05,0.00015759399,0.96504245,1.3844187E-06,9.9044172E-08,6.9071441E-07
+646,0.94845313,2.550376E-06,3.3595383E-06,2.4197655E-05,0.00014492565,0.96686292,2.1692825E-06,1.9876588E-07,7.0262557E-07
+647,0.94548762,2.2332089E-06,3.2766567E-06,1.7406434E-05,0.00011260035,0.96701928,2.5917285E-06,3.1560444E-07,7.9115688E-07
+648,0.9425084,1.9150492E-06,3.1935028E-06,1.0755028E-05,8.0049133E-05,0.96717149,3.0044244E-06,4.3280321E-07,8.820437E-07
+649,0.93971744,2.0673016E-06,3.6763351E-06,5.4944413E-06,6.2275135E-05,0.96638395,4.0166319E-06,4.6888274E-07,1.0569715E-06
+650,0.93691148,2.2176332E-06,4.1608457E-06,2.1397318E-07,4.4316187E-05,0.96558832,5.032378E-06,5.0508659E-07,1.2346014E-06
+651,0.93471336,2.0465474E-06,4.6744616E-06,1.5207386E-07,3.4916903E-05,0.96192541,5.5978686E-06,4.6362092E-07,1.4229761E-06
+652,0.93251078,1.8729968E-06,5.2057932E-06,9.0304746E-08,2.5516899E-05,0.95825782,6.163367E-06,4.2093054E-07,1.613448E-06
+653,0.93211097,1.7713293E-06,5.6595644E-06,1.1381074E-07,2.0673835E-05,0.95729371,6.6752948E-06,5.0610942E-07,2.2645249E-06
+654,0.93058514,1.6667959E-06,6.1150838E-06,1.3781377E-07,1.5934166E-05,0.95631968,7.2003218E-06,5.9162001E-07,2.8992393E-06
+655,0.92941728,1.7399861E-06,5.6594073E-06,1.9749002E-07,1.2884725E-05,0.95549963,8.0999418E-06,5.9720653E-07,2.3557157E-06
+656,0.93384854,1.8133381E-06,5.184843E-06,2.5865713E-07,9.8404998E-06,0.95467406,9.0127566E-06,6.0280365E-07,1.7835572E-06
+657,0.93717395,1.8034237E-06,5.505333E-06,2.0312568E-07,8.2430826E-06,0.95344664,1.0038557E-05,5.6349433E-07,1.2528616E-06
+658,0.93937364,1.7935015E-06,5.8257693E-06,1.4759801E-07,6.6580467E-06,0.95221478,1.1064221E-05,5.2418569E-07,7.2009974E-07
+659,0.94529183,1.7884952E-06,7.9137954E-06,2.0230929E-07,5.8261847E-06,0.95400854,1.1295517E-05,6.0192406E-07,6.3337856E-07
+660,0.95123168,1.7809684E-06,1.0013061E-05,2.5731512E-07,4.977395E-06,0.95580147,1.1550371E-05,6.8131174E-07,5.4617996E-07
+661,0.95472744,1.9315076E-06,1.2908405E-05,3.5254643E-07,4.2643083E-06,0.95984897,1.1367715E-05,6.330249E-07,1.160117E-06
+662,0.95936476,2.080623E-06,1.584283E-05,4.484711E-07,3.5458888E-06,0.96390664,1.1138297E-05,5.8436992E-07,1.7785468E-06
+663,0.96065922,2.0809352E-06,1.6605018E-05,5.0675572E-07,3.0523331E-06,0.96659968,1.1764157E-05,7.9681143E-07,1.2940691E-06
+664,0.96195321,2.0812397E-06,1.7369193E-05,5.6519552E-07,2.5574332E-06,0.96929601,1.234635E-05,1.0098229E-06,8.1041719E-07
+665,0.96278099,2.4102624E-06,1.7544462E-05,6.7774093E-07,2.157528E-06,0.97035788,1.1776204E-05,1.0082509E-06,4.9806413E-07
+666,0.95905208,2.7465478E-06,1.7719517E-05,7.8883498E-07,1.7703379E-06,0.97141352,1.1138445E-05,1.0054283E-06,1.863388E-07
+667,0.95764139,2.8774072E-06,2.0293307E-05,7.7396191E-07,1.5366747E-06,0.97479731,1.0708052E-05,8.8143697E-07,9.3578754E-08
+668,0.95736053,3.0338684E-06,2.2696176E-05,7.5764105E-07,1.3145406E-06,0.97818847,1.0264412E-05,7.556686E-07,2.14587E-10
+669,0.95561842,3.7174027E-06,2.9284317E-05,8.7372501E-07,1.0710484E-06,0.98285167,1.0760803E-05,9.1742814E-07,1.4101784E-07
+670,0.95386496,4.3781706E-06,3.589558E-05,9.9021446E-07,8.3045906E-07,0.98752601,1.125889E-05,1.0797543E-06,2.8210258E-07
+671,0.95395229,6.0394088E-06,4.1547927E-05,8.87812E-07,8.9461571E-07,0.99148121,9.685585E-06,9.2792036E-07,2.4766998E-07
+672,0.95403563,7.6757526E-06,4.720111E-05,7.8400232E-07,9.5878008E-07,0.99543297,8.1233674E-06,7.7605532E-07,2.1409171E-07
+673,0.95546821,1.0849966E-05,4.4116169E-05,7.1911484E-07,9.4398344E-07,0.99771766,8.7534941E-06,8.7929017E-07,1.4478138E-07
+674,0.95575074,1.4026028E-05,4.1029228E-05,6.5557206E-07,9.2791715E-07,1,9.3953793E-06,9.838397E-07,7.5429266E-08
+675,0.95737584,1.7152453E-05,3.434049E-05,6.205898E-07,8.1866084E-07,0.99908486,8.2106349E-06,9.3516709E-07,2.8280101E-07
+676,0.96130407,2.0264157E-05,2.7445854E-05,5.8548538E-07,7.1029033E-07,0.99816147,7.0218188E-06,8.8506335E-07,4.9087663E-07
+677,0.96586676,1.7652426E-05,2.5126009E-05,8.489238E-07,7.0563345E-07,0.99413412,8.2438683E-06,9.3768854E-07,5.2887591E-07
+678,0.97044273,1.5028288E-05,2.2611233E-05,1.1149888E-06,7.0221631E-07,0.99007949,9.4600755E-06,9.9055282E-07,5.6704908E-07
+679,0.97408565,1.1388303E-05,2.3378468E-05,1.1067188E-06,8.0852561E-07,0.98689308,9.5882492E-06,9.9824886E-07,6.6790043E-07
+680,0.9777346,7.763778E-06,2.433204E-05,1.0970207E-06,9.1512222E-07,0.98369397,9.7051944E-06,1.0059619E-06,7.6902474E-07
+681,0.97115369,6.0351867E-06,2.5447948E-05,8.4936582E-07,7.4255487E-07,0.98521171,1.0851885E-05,9.7077549E-07,4.9254185E-07
+682,0.9645643,4.3307084E-06,2.6564634E-05,6.0011375E-07,5.6985107E-07,0.98672721,1.2010977E-05,9.3555842E-07,2.1649686E-07
+683,0.95810068,4.0830414E-06,2.4393215E-05,6.5031621E-07,5.1350205E-07,0.96989488,1.8626217E-05,8.0093546E-07,1.0854567E-07
+684,0.95277435,3.8600556E-06,2.2399241E-05,7.0068972E-07,4.5695452E-07,0.95299897,2.5264347E-05,6.6456492E-07,2.15937E-10
+685,0.94921689,4.3615234E-06,1.9507872E-05,9.2775745E-07,8.3139484E-07,0.88527954,3.2799964E-05,8.9740892E-07,2.3274882E-07
+686,0.95148075,4.8665458E-06,1.6539179E-05,1.1564556E-06,1.207252E-06,0.81705068,4.0272917E-05,1.1332107E-06,4.6718319E-07
+687,0.94846518,4.4202281E-06,1.4441399E-05,1.131582E-06,9.7522127E-07,0.69392461,6.5942839E-05,1.174613E-06,4.9267053E-07
+688,0.94544477,3.9755682E-06,1.2351522E-05,1.1067852E-06,7.4407545E-07,0.57126504,9.1511824E-05,1.2171136E-06,5.1585507E-07
+689,0.9493902,3.7907975E-06,1.2474439E-05,1.142586E-06,6.8372444E-07,0.43230756,0.00014914207,1.2533007E-06,6.7314003E-07
+690,0.95333382,3.6038452E-06,1.2579328E-05,1.1787214E-06,6.2398148E-07,0.29182302,0.00020734203,1.2898213E-06,8.3209886E-07
+691,0.9494788,3.8216711E-06,1.3407323E-05,1.1654274E-06,8.0970082E-07,0.19587514,0.00036505274,1.1364315E-06,4.7735083E-07
+692,0.94560862,4.0375452E-06,1.4246576E-05,1.1521843E-06,9.9387564E-07,0.10069519,0.00052146879,9.8422907E-07,1.2765507E-07
+693,0.94770437,4.3869898E-06,1.3940805E-05,1.1433873E-06,7.2414803E-07,0.065814274,0.00099671002,9.8892191E-07,3.2686751E-07
+694,0.95097736,4.738775E-06,1.3651416E-05,1.135934E-06,4.5253938E-07,0.030690613,0.0014752244,9.9233725E-07,5.2745364E-07
+695,0.95219293,6.6116515E-06,1.1979033E-05,8.9335463E-07,5.1784895E-07,0.020441228,0.0031275264,9.2503654E-07,4.0830052E-07
+696,0.95577382,8.4892903E-06,1.0321131E-05,6.5015188E-07,5.8332351E-07,0.010165567,0.0047840388,8.5756036E-07,2.8884132E-07
+697,0.95983716,1.5180898E-05,9.2019536E-06,7.7393136E-07,6.2928531E-07,0.0071515948,0.014133814,1.6501206E-06,3.2536744E-07
+698,0.96510195,2.1886495E-05,8.0759086E-06,8.9844606E-07,6.7681955E-07,0.0041193675,0.023539726,2.4500397E-06,3.6210919E-07
+699,0.96735076,2.4103216E-05,7.8289759E-06,9.745021E-07,8.1885362E-07,0.0030164021,0.061580298,2.0848574E-06,2.4360833E-07
+700,0.96959458,2.6371438E-05,7.5820759E-06,1.0505328E-06,9.6084483E-07,0.0019137283,0.099610101,1.7197663E-06,1.271502E-07
+701,0.97484669,1.9958396E-05,8.0210174E-06,1.0755081E-06,7.2784653E-07,0.0014326502,0.19447923,2.2550774E-06,2.1396195E-07
+702,0.98010104,1.3564951E-05,8.4793041E-06,1.0990666E-06,4.9330556E-07,0.00095108287,0.28944356,2.8039639E-06,3.0197916E-07
+703,0.98783525,1.1154334E-05,9.1961724E-06,1.0664624E-06,6.0663207E-07,0.00073540847,0.40422603,4.2331351E-06,1.7098221E-07
+704,0.99439684,8.7087206E-06,9.9345747E-06,1.0322909E-06,7.1905474E-07,0.00051895128,0.51942079,5.6674441E-06,4.040928E-08
+705,1,8.0858243E-06,1.009484E-05,1.0418103E-06,8.6514889E-07,0.00040358913,0.62290784,4.807538E-06,8.7400823E-08
+706,0.9984264,7.4618791E-06,1.0236311E-05,1.0513421E-06,1.0101687E-06,0.00028803604,0.72656317,3.9593135E-06,1.3446937E-07
+707,0.99608901,7.5674083E-06,9.4187051E-06,9.6896764E-07,9.0133193E-07,0.00023183448,0.81137554,5.5590888E-06,3.0583411E-07
+708,0.99255023,7.6729201E-06,8.6009729E-06,8.8658033E-07,7.9379167E-07,0.00017562701,0.89619415,7.1590195E-06,4.7676682E-07
+709,0.99328163,8.1189052E-06,7.826398E-06,9.807837E-07,7.6076046E-07,0.00013880274,0.92441104,6.1951345E-06,4.8278399E-07
+710,0.99400277,8.5411437E-06,7.0468114E-06,1.0770231E-06,7.2882947E-07,0.000101781,0.95279238,5.2250659E-06,4.8883196E-07
+711,0.98861855,9.0229623E-06,7.3771195E-06,1.0136401E-06,9.8693535E-07,8.3548193E-05,0.96406863,4.8455592E-06,5.7746715E-07
+712,0.98322443,9.5053774E-06,7.6886591E-06,9.5162948E-07,1.2453722E-06,6.5291557E-05,0.97535659,4.4655473E-06,6.6394923E-07
+713,0.97872436,9.7589492E-06,8.5072714E-06,9.239293E-07,1.0407613E-06,4.8502499E-05,0.98148811,4.1285059E-06,7.1719071E-07
+714,0.97541601,1.0039833E-05,9.3284128E-06,8.9467625E-07,8.355041E-07,3.1539734E-05,0.98763449,3.7903892E-06,7.7059597E-07
+715,0.96956268,1.2193712E-05,1.0888573E-05,9.8843865E-07,9.1393602E-07,2.719497E-05,0.98763359,3.9237201E-06,7.1391288E-07
+716,0.96854639,1.437499E-05,1.2449328E-05,1.0807731E-06,9.9239652E-07,2.2969245E-05,0.9876293,4.0570915E-06,6.5720442E-07
+717,0.96794845,2.4305244E-05,1.3051162E-05,1.1179787E-06,8.9457674E-07,1.8410077E-05,0.98856103,4.3038516E-06,8.1565136E-07
+718,0.96855796,3.4139497E-05,1.3655194E-05,1.1553184E-06,7.9505069E-07,1.3954935E-05,0.98949059,4.5382102E-06,9.7469191E-07
+719,0.96847921,6.595596E-05,1.3013781E-05,1.1258114E-06,9.9198103E-07,1.409282E-05,0.99169496,4.7567288E-06,9.369864E-07
+720,0.96839702,9.7579601E-05,1.2390176E-05,1.09476E-06,1.1880358E-06,1.4230982E-05,0.99390117,4.9757446E-06,8.9690114E-07
+721,0.97101465,0.0001041459,1.2039695E-05,1.103708E-06,1.1429626E-06,1.6200449E-05,0.99694819,5.5573658E-06,6.6448152E-07
+722,0.97363595,0.00011073074,1.170757E-05,1.1141531E-06,1.0977548E-06,1.8053553E-05,1,6.1406438E-06,4.3138826E-07
+723,0.97371124,7.6418161E-05,1.2193902E-05,1.0050291E-06,1.1272939E-06,1.5615091E-05,0.99971514,5.7932557E-06,6.7466998E-07
+724,0.97500481,4.1831971E-05,1.2680262E-05,8.9588488E-07,1.1581723E-06,1.3176204E-05,0.9994266,5.4591744E-06,9.1569103E-07
+725,0.97885497,3.3340577E-05,1.4856185E-05,1.0492463E-06,1.5036363E-06,1.3334009E-05,0.99927984,6.6008461E-06,1.040117E-06
+726,0.97657327,2.4856987E-05,1.704367E-05,1.2034227E-06,1.8442147E-06,1.349252E-05,0.99912142,7.7620503E-06,1.1652022E-06
+727,0.97008617,2.4143828E-05,2.0660978E-05,1.2651772E-06,1.4783583E-06,1.4082973E-05,0.99264959,1.0019259E-05,9.974564E-07
+728,0.96360701,2.3432659E-05,2.4130042E-05,1.326714E-06,1.1163535E-06,1.479358E-05,0.98618534,1.2255594E-05,8.27942E-07
+729,0.96430431,2.6643732E-05,2.7563118E-05,1.1321727E-06,1.1537853E-06,1.400121E-05,0.98651386,1.4277983E-05,7.7395382E-07
+730,0.96374094,2.982897E-05,3.1026585E-05,9.343287E-07,1.1915207E-06,1.3201162E-05,0.98681319,1.6237153E-05,7.1944831E-07
+731,0.95864979,3.4975814E-05,3.2199809E-05,1.077445E-06,1.0722021E-06,1.3199112E-05,0.98384094,2.1105021E-05,6.8452998E-07
+732,0.9535562,4.0120891E-05,3.3176218E-05,1.2190196E-06,9.5427008E-07,1.3197007E-05,0.98086547,2.6106535E-05,6.4961975E-07
+733,0.95094798,4.8372152E-05,3.2077043E-05,1.0425286E-06,1.1492967E-06,1.1782871E-05,0.9810581,3.0781114E-05,7.9076357E-07
+734,0.94831829,5.6663574E-05,3.1169443E-05,8.651596E-07,1.3452725E-06,1.0374064E-05,0.98124276,3.5478415E-05,9.3026324E-07
+735,0.94665388,6.6888662E-05,3.1039691E-05,8.3098148E-07,1.2827717E-06,1.057058E-05,0.97711587,4.400196E-05,8.8088681E-07
+736,0.94871534,7.7157871E-05,3.1107284E-05,7.9664822E-07,1.219989E-06,1.0755428E-05,0.97296386,5.2698895E-05,8.3128858E-07
+737,0.94685454,0.00012752501,3.302374E-05,8.0410367E-07,1.2803167E-06,7.6407574E-06,0.95376216,6.4586223E-05,1.039994E-06
+738,0.94498519,0.00017769197,3.4932108E-05,8.1151633E-07,1.3417465E-06,4.5258056E-06,0.93461998,7.6425731E-05,1.2478613E-06
+739,0.94895803,0.00029964617,4.0033624E-05,9.1886527E-07,1.1888712E-06,3.7977369E-06,0.89070633,9.1222454E-05,9.0411121E-07
+740,0.95293816,0.00042265146,4.5375988E-05,1.0270923E-06,1.0360488E-06,3.0509323E-06,0.84639856,0.00010614119,5.5744318E-07
+741,0.95392028,0.00036796656,5.2127823E-05,1.143243E-06,9.4658453E-07,3.55008E-06,0.7569426,0.00012763498,7.5715567E-07
+742,0.95364598,0.00031331118,5.8875567E-05,1.260834E-06,8.557955E-07,4.0489266E-06,0.6675342,0.00014916116,9.5675076E-07
+743,0.95587124,0.00019933921,6.3315955E-05,1.0653865E-06,1.0186664E-06,2.8021125E-06,0.56413995,0.00018146076,9.2948878E-07
+744,0.95809822,8.504622E-05,6.7765208E-05,8.7105218E-07,1.1832405E-06,1.5402261E-06,0.46053325,0.00021382705,8.9981294E-07
+745,0.96258254,6.525841E-05,6.5278987E-05,8.4773374E-07,1.1294087E-06,1.547435E-06,0.35976294,0.00025622932,1.0483844E-06
+746,0.96580964,4.5282924E-05,6.2767203E-05,8.2416737E-07,1.0750333E-06,1.5546578E-06,0.25803592,0.00029902137,1.1983115E-06
+747,0.96336554,4.2786527E-05,5.5731072E-05,9.4046192E-07,1.0765182E-06,1.4283926E-06,0.1785592,0.00037450696,1.0652626E-06
+748,0.96091776,4.0011681E-05,4.8894713E-05,1.0552447E-06,1.0779998E-06,1.3021001E-06,0.099067697,0.00045000613,9.3218628E-07
+749,0.95877954,4.8923262E-05,4.5090191E-05,1.0847478E-06,1.0451318E-06,1.2646943E-06,0.06482009,0.00058146789,1.0824466E-06
+750,0.95663688,5.7842008E-05,4.1483804E-05,1.1127414E-06,1.0108454E-06,1.23105E-06,0.03054424,0.00071303574,1.232827E-06
+751,0.95525001,0.00010231637,4.1185141E-05,1.3058353E-06,8.9229906E-07,8.5491275E-07,0.019519889,0.00094729174,1.0045082E-06
+752,0.95384691,0.00014701528,4.0682169E-05,1.4983576E-06,7.7314299E-07,4.7685991E-07,0.0084394477,0.0011827279,7.7502206E-07
+753,0.94691569,0.00038218575,4.3229478E-05,1.1668856E-06,8.6496759E-07,3.9597915E-07,0.0057440366,0.0016160955,9.6928897E-07
+754,0.94126456,0.00061646501,4.5766199E-05,8.3821375E-07,9.5503159E-07,3.1667261E-07,0.0030589948,0.0020477548,1.1627861E-06
+755,0.94096242,0.00071119495,5.0996405E-05,1.0551437E-06,8.6092675E-07,5.8104093E-07,0.0021584838,0.0028857055,8.0359887E-07
+756,0.9406378,0.00080661827,5.6061521E-05,1.2736738E-06,7.6749998E-07,8.4737448E-07,0.0012511886,0.0037298643,4.4170736E-07
+757,0.93727327,0.00056321179,6.1253771E-05,1.064151E-06,8.0401282E-07,1.0714252E-06,0.00090415387,0.0052102885,5.0506427E-07
+758,0.9351738,0.00031889244,6.6261207E-05,8.5383913E-07,8.4065768E-07,1.2937455E-06,0.00055581837,0.0066962171,5.6624563E-07
+759,0.93052473,0.00020394317,6.5389424E-05,9.707748E-07,8.034161E-07,2.1501228E-06,0.00041272453,0.0096941262,7.0539295E-07
+760,0.92459635,8.9376215E-05,6.4518672E-05,1.0859548E-06,7.6623294E-07,3.0050073E-06,0.00026987454,0.012686794,8.4670054E-07
+761,0.92468218,6.2205582E-05,5.8703081E-05,1.075168E-06,7.9688102E-07,3.4704773E-06,0.00020196757,0.017706636,7.3473252E-07
+762,0.92476462,3.5236161E-05,5.2665911E-05,1.0627936E-06,8.2620917E-07,3.9373115E-06,0.00013385878,0.022741266,6.2243014E-07
+763,0.92199382,2.5759037E-05,4.5715425E-05,1.2424981E-06,9.1186757E-07,6.0136631E-06,0.00010374673,0.032646337,7.597773E-07
+764,0.92050428,1.6314174E-05,3.8767825E-05,1.422118E-06,9.9607745E-07,8.089072E-06,7.3577322E-05,0.042546896,8.9947207E-07
+765,0.92168433,1.3137175E-05,3.5393741E-05,1.4103799E-06,7.8291635E-07,9.5118193E-06,5.5330904E-05,0.05885988,8.559426E-07
+766,0.92673294,9.942993E-06,3.179604E-05,1.4001229E-06,5.6860334E-07,1.0954985E-05,3.6857586E-05,0.075259739,8.1459479E-07
+767,0.93171815,8.7353411E-06,3.0601784E-05,1.2862819E-06,6.9390268E-07,8.5422045E-06,2.8286995E-05,0.10713924,6.9177736E-07
+768,0.93541855,7.5247732E-06,2.9404574E-05,1.1721646E-06,8.1949954E-07,6.1107076E-06,1.9695815E-05,0.13909466,5.7109418E-07
+769,0.93748231,6.7259445E-06,3.0826734E-05,1.4354902E-06,7.0993077E-07,6.4171789E-06,1.4667117E-05,0.19968391,5.1005448E-07
+770,0.94083098,5.9563387E-06,3.2041734E-05,1.7016349E-06,6.0048102E-07,6.7103668E-06,9.5668288E-06,0.26020412,4.5150792E-07
+771,0.9489936,6.0486178E-06,3.5330332E-05,2.4340628E-06,5.4419805E-07,8.0351458E-06,8.3040564E-06,0.35649108,7.6428785E-07
+772,0.95850576,6.1129412E-06,3.8655819E-05,3.1592238E-06,4.8721749E-07,9.3751426E-06,7.0388685E-06,0.45389723,1.0782699E-06
+773,0.95744906,5.7751008E-06,4.1406595E-05,3.7765847E-06,4.6394329E-07,8.4938425E-06,6.8305203E-06,0.5596515,1.1475546E-06
+774,0.95635962,5.4111205E-06,4.3928313E-05,4.3890591E-06,4.4082745E-07,7.618926E-06,6.6234756E-06,0.66457244,1.2138228E-06
+775,0.96383215,6.9557362E-06,4.4359018E-05,3.9544887E-06,5.3740044E-07,6.8502339E-06,5.2945856E-06,0.75996716,1.0313623E-06
+776,0.96478624,8.5445579E-06,4.4583919E-05,3.5311633E-06,6.3493425E-07,6.0865182E-06,3.9519437E-06,0.85630141,8.445388E-07
+777,0.96036045,1.0337071E-05,4.1077177E-05,2.9953298E-06,6.1678482E-07,5.2663768E-06,3.5114808E-06,0.91245577,5.9636308E-07
+778,0.95592465,1.2161429E-05,3.7564358E-05,2.458576E-06,5.9860289E-07,4.444825E-06,3.0833237E-06,0.9687034,3.5022958E-07
+779,0.94794794,1.5747309E-05,3.3711037E-05,1.9137753E-06,6.2701879E-07,4.9550474E-06,3.6998072E-06,0.98230681,4.795708E-07
+780,0.9412968,1.9340823E-05,2.9878927E-05,1.3673197E-06,6.5525447E-07,5.4622054E-06,4.3126502E-06,0.99580539,6.0815628E-07
+781,0.93586871,2.4164391E-05,2.7498046E-05,1.2001778E-06,3.8638672E-07,3.8217498E-06,3.9124861E-06,0.99790665,6.8689936E-07
+782,0.92905829,2.9170206E-05,2.5097513E-05,1.0316743E-06,1.143575E-07,2.181268E-06,3.52213E-06,1,7.6872472E-07
+783,0.91946086,3.6952677E-05,2.4459812E-05,9.4861514E-07,2.9262088E-07,2.2066225E-06,4.554599E-06,0.99524338,9.5617907E-07
+784,0.9098672,4.4728412E-05,2.3822534E-05,8.6562157E-07,4.7116483E-07,2.2319452E-06,5.5861762E-06,0.99048609,1.1434709E-06
+785,0.90300031,5.5259959E-05,2.4512882E-05,7.5480596E-07,3.9437845E-07,1.5005997E-06,5.0760177E-06,0.98890733,9.2854037E-07
+786,0.90005364,6.5555567E-05,2.5206567E-05,6.4500383E-07,3.1718935E-07,7.6544142E-07,4.5631589E-06,0.98731039,7.1248442E-07
+787,0.89727885,9.2500854E-05,2.8015707E-05,6.5161762E-07,4.9672734E-07,5.8230983E-07,6.6331769E-06,0.98450631,7.5680596E-07
+788,0.89447784,0.00011988814,3.0840298E-05,6.5986637E-07,6.7872467E-07,3.9946957E-07,8.7147468E-06,0.98167482,8.0136755E-07
+789,0.89082442,0.00018294485,3.5553836E-05,4.7290399E-07,4.9467378E-07,1.3096792E-06,8.5323115E-06,0.97731503,1.0129621E-06
+790,0.88715246,0.00024623652,4.0496843E-05,2.8523941E-07,3.0993147E-07,2.2246197E-06,8.3491468E-06,0.97293358,1.225343E-06
+791,0.89663201,0.00026189249,4.5235824E-05,4.5519814E-07,3.5583707E-07,1.401018E-06,9.0941614E-06,0.96767522,8.0318187E-07
+792,0.90747728,0.0002775989,4.9777503E-05,6.27332E-07,4.0189243E-07,5.8672322E-07,9.8549091E-06,0.96239522,3.7711128E-07
+793,0.91356783,0.00021398701,5.1582472E-05,7.4539474E-07,4.2738645E-07,7.3485048E-07,9.0100921E-06,0.9542296,0.00022779424
+794,0.92094925,0.00015034903,5.3167049E-05,8.6294296E-07,4.5422521E-07,8.8233573E-07,8.1819656E-06,0.9460819,0.00045419895
+795,0.92940165,0.00011618258,5.1497734E-05,7.7155311E-07,5.6111914E-07,6.0981602E-07,6.4479516E-06,0.94113891,0.00045341743
+796,0.85514697,8.1982399E-05,4.982666E-05,6.800719E-07,6.6957836E-07,3.3836009E-07,4.7122239E-06,0.9361888,0.00045263404
+797,0.78119719,7.3395206E-05,4.6346346E-05,9.7760373E-07,6.5232051E-07,7.1460211E-07,4.9112159E-06,0.93334272,0.00048731503
+798,0.70684138,6.4761052E-05,4.3059988E-05,1.2751044E-06,6.3496282E-07,1.0928592E-06,5.1245698E-06,0.93047123,0.0005221772
+799,0.63035004,9.3014546E-05,5.1157151E-05,1.1194936E-06,1.2022379E-05,7.4593642E-06,2.5888119E-06,0.92492766,0.00065087593
+800,0.55386653,0.0001215584,5.9466236E-05,9.6227934E-07,2.3367131E-05,1.3792881E-05,6.7117827E-08,0.91938175,0.00077955583
+801,0.46069231,0.00011909076,5.6781866E-05,1.9631879E-06,1.8692774E-05,1.4216261E-05,1.5635708E-07,0.9155394,0.00092586319
+802,0.36723203,0.00011691035,5.4302872E-05,2.9736417E-06,1.3989343E-05,1.4775197E-05,2.4626946E-07,0.91168169,0.0010726107
+803,0.27326038,0.00013264987,5.4340737E-05,2.2114605E-06,1.7849218E-05,1.3306949E-05,3.6162565E-07,0.90647762,0.0010195812
+804,0.17915717,0.00014870665,5.4592616E-05,1.4335674E-06,2.1699667E-05,1.1876978E-05,4.7714171E-07,0.90126418,0.00096647543
+805,0.085816415,0.00016050642,6.0903574E-05,9.306985E-07,1.8926766E-05,1.3405994E-05,3.1684007E-07,0.8976002,0.00097630443
+806,0.072174613,0.00017264184,6.7020704E-05,4.2449855E-07,1.6292551E-05,1.4980589E-05,1.5734173E-07,0.89391976,0.00098616461
+807,0.058364589,0.00018814752,7.3908061E-05,2.4912231E-07,1.9645649E-05,1.5882038E-05,2.2933613E-07,0.88604649,0.0010710735
+808,0.044493887,0.00020356415,8.0756099E-05,7.5019467E-08,2.2980006E-05,1.6778188E-05,3.0093292E-07,0.87819422,0.0011554912
+809,0.030865224,0.00018369841,8.2686085E-05,3.7610194E-08,1.7133462E-05,1.3727669E-05,2.5480174E-07,0.8747067,0.0011122159
+810,0.017298321,0.00016372422,8.4840312E-05,1.00889E-10,1.1255396E-05,1.0606674E-05,2.0976519E-07,0.87119107,0.0010686967
+811,0.015202384,0.0001426951,8.7369507E-05,1.00675E-10,1.1914598E-05,1.1547712E-05,2.6740758E-07,0.8693269,0.0010680505
+812,0.013101223,0.00012177628,8.9918225E-05,1.00456E-10,1.2579221E-05,1.2510269E-05,3.2554762E-07,0.86741979,0.001067366
+813,0.010919233,0.00011191485,9.5523461E-05,9.9707E-11,1.5348538E-05,1.2328923E-05,2.7465498E-07,0.85868842,0.0011143971
+814,0.0087481765,0.00010210143,0.00010088227,9.8795E-11,1.813305E-05,1.2134685E-05,2.2266738E-07,0.84998249,0.0011611622
+815,0.0065998064,9.2797589E-05,9.498434E-05,9.8223E-11,1.8860759E-05,1.0812141E-05,1.6720096E-07,0.84428385,0.0010955178
+816,0.0057006748,8.380562E-05,8.8880278E-05,9.7651E-11,1.973554E-05,9.4781784E-06,1.1290236E-07,0.83858918,0.0010299742
+817,0.0048097005,8.1107971E-05,8.3351469E-05,9.7654E-11,1.9951372E-05,8.2893155E-06,1.4464832E-07,0.83720157,0.0010972202
+818,0.003926225,7.8390575E-05,7.7566984E-05,9.7656E-11,2.0018922E-05,7.1058476E-06,1.7633596E-07,0.83578976,0.0011649034
+819,0.0030258474,7.572428E-05,6.7457093E-05,9.7747E-11,1.9805321E-05,7.9841793E-06,1.9480748E-07,0.83692046,0.0011298525
+820,0.0021313448,7.3032682E-05,5.7039237E-05,9.7836E-11,1.9438598E-05,8.8835998E-06,2.1343294E-07,0.83803613,0.0010944676
+821,0.001890584,6.4511163E-05,5.3295785E-05,2.1504273E-08,1.2672801E-05,8.3642458E-06,1.7163279E-07,0.84030568,0.0010987003
+822,0.001661908,5.5927245E-05,4.9524425E-05,4.3162352E-08,5.8126974E-06,7.8410006E-06,1.2897823E-07,0.84257482,0.0011029416
+823,0.001409394,6.91428E-05,5.2266136E-05,2.1531863E-08,1.3960995E-05,1.0223819E-05,1.2923345E-07,0.83980292,0.001075298
+824,0.0011662808,8.1993972E-05,5.49943E-05,9.7587E-11,2.2056613E-05,1.2595533E-05,1.2948504E-07,0.83702775,0.0010477604
+825,0.00092222675,7.1596389E-05,5.0971805E-05,3.4917397E-08,1.8251623E-05,7.8755378E-06,9.7101063E-08,0.83565718,0.0010415693
+826,0.00084108623,6.1230104E-05,4.6742728E-05,6.9560513E-08,1.4307571E-05,3.183756E-06,6.4952751E-08,0.83428126,0.0010353828
+827,0.00076121595,6.6463819E-05,4.4192167E-05,4.3565599E-07,1.2459941E-05,3.9173312E-06,2.2050755E-07,0.83397461,0.0011052553
+828,0.00068246581,7.2016584E-05,4.1633266E-05,8.0275383E-07,1.0606351E-05,4.6394691E-06,3.7587297E-07,0.83366349,0.0011753467
+829,0.00060627323,7.0802688E-05,4.9062091E-05,2.9395415E-06,9.9353391E-06,7.6922671E-06,2.8224542E-07,0.83812137,0.0011514522
+830,0.00052869558,6.986667E-05,5.6612095E-05,5.1160046E-06,9.2669077E-06,1.0782457E-05,1.8697518E-07,0.84254829,0.0011269976
+831,0.00051231975,7.2195102E-05,6.0066864E-05,4.9036296E-06,1.144332E-05,7.2542089E-06,2.2841188E-07,0.83766548,0.0011391444
+832,0.00049739452,7.4513872E-05,6.3730023E-05,4.7088499E-06,1.362681E-05,3.7249886E-06,2.6969169E-07,0.83278884,0.0011512301
+833,0.00048204931,6.9611035E-05,6.439936E-05,3.6119838E-06,1.3413116E-05,5.3017428E-06,1.9185198E-07,0.82876569,0.0011899166
+834,0.0004667013,6.5014207E-05,6.5068583E-05,2.531882E-06,1.3214677E-05,6.8646806E-06,1.1330915E-07,0.82473985,0.0012286008
+835,0.00044966212,5.9274155E-05,6.3500458E-05,1.7825811E-06,1.0633341E-05,6.9783088E-06,1.6483354E-07,0.81860353,0.0011509375
+836,0.00043966628,5.387869E-05,6.1941455E-05,1.0354092E-06,8.0707077E-06,7.0908214E-06,2.1527983E-07,0.81248053,0.0010738043
+837,0.00043444877,4.9667587E-05,6.3719339E-05,6.8174067E-07,1.0241357E-05,6.7233839E-06,1.1870005E-07,0.81539486,0.0011615931
+838,0.00042911755,4.5082621E-05,6.5293578E-05,3.2291609E-07,1.2442372E-05,6.3500561E-06,2.0718246E-08,0.81827885,0.0012505411
+839,0.00041905307,4.829224E-05,6.7046407E-05,2.9627536E-07,1.2194712E-05,6.2695812E-06,1.8128256E-07,0.81248944,0.0013028266
+840,0.00040904875,5.1168629E-05,6.8560994E-05,2.6814162E-07,1.1948453E-05,6.2034051E-06,3.403207E-07,0.80671062,0.0013546559
+841,0.00040996226,4.576068E-05,6.5380001E-05,2.4676215E-07,9.1704476E-06,5.9083045E-06,3.3361278E-07,0.81074675,0.0013296242
+842,0.00040941088,4.0559268E-05,6.2131347E-05,2.2495614E-07,6.3403686E-06,5.6069499E-06,3.2673354E-07,0.81473791,0.0013039433
+843,0.0004048531,3.697075E-05,7.019355E-05,5.4548369E-07,8.9042332E-06,7.2229569E-06,2.4507303E-07,0.80678172,0.0012964074
+844,0.00039890456,3.3720105E-05,7.8184232E-05,8.6327701E-07,1.1446006E-05,8.8390359E-06,1.6409043E-07,0.79885349,0.001288872
+845,0.00039644544,2.8734586E-05,7.8031064E-05,7.7203139E-07,1.1982074E-05,8.4244387E-06,2.0635228E-07,0.79416124,0.0014918107
+846,0.00040527788,2.358498E-05,7.8101869E-05,6.8061819E-07,1.2534564E-05,8.0090688E-06,2.4869045E-07,0.78945864,0.0016951148
+847,0.00041526369,2.669068E-05,7.8345353E-05,4.0096286E-07,1.2615005E-05,7.2353024E-06,3.2604643E-07,0.78307719,0.0020523147
+848,0.00042525338,2.9766815E-05,7.8588772E-05,1.2236581E-07,1.2710939E-05,6.4752516E-06,4.0484483E-07,0.77669083,0.0024096855
+849,0.0004358728,3.602856E-05,7.6696336E-05,1.2992188E-07,1.490341E-05,4.5925628E-06,4.2101259E-07,0.7720116,0.0033674379
+850,0.00044652592,4.2311156E-05,7.4797209E-05,1.3750273E-07,1.7087637E-05,2.7035361E-06,4.3864315E-07,0.76731323,0.004328389
+851,0.00042814529,3.5973806E-05,6.6249368E-05,1.7239695E-07,1.4865276E-05,4.7690067E-06,2.5025536E-07,0.75911179,0.0063775717
+852,0.00041127743,2.9490373E-05,5.7977966E-05,2.0757331E-07,1.2625789E-05,6.8351962E-06,6.3904539E-08,0.75093941,0.0084134639
+853,0.00039534425,2.7362638E-05,5.3407904E-05,4.4175026E-06,1.0150196E-05,6.1752451E-06,2.669229E-07,0.74826375,0.012753672
+854,0.00037932918,2.5224197E-05,4.9039851E-05,8.6344065E-06,7.6468326E-06,5.5119943E-06,4.7178172E-07,0.74556817,0.017115098
+855,0.00036125722,2.7626208E-05,4.4855711E-05,8.6085023E-06,6.7114985E-06,6.3409126E-06,8.0172885E-07,0.73927115,0.030595678
+856,0.0003460976,3.0013014E-05,4.0471867E-05,8.5825138E-06,5.7815987E-06,7.1646725E-06,1.1310705E-06,0.73299138,0.043994385
+857,0.00033569371,3.0875028E-05,3.9110061E-05,6.0139374E-06,7.6536024E-06,6.7608429E-06,8.8455748E-07,0.73683187,0.086261884
+858,0.00032498655,3.1875587E-05,3.748107E-05,3.3872809E-06,9.5810637E-06,6.3322525E-06,6.3383397E-07,0.74059623,0.12944465
+859,0.00031154943,3.1972342E-05,3.4843998E-05,2.5438161E-06,9.2624105E-06,5.7033639E-06,1.2471188E-06,0.73738553,0.22131793
+860,0.0002980263,3.2069236E-05,3.2420348E-05,1.6951915E-06,8.9258373E-06,5.0561285E-06,1.8713092E-06,0.73414497,0.31374624
+861,0.00029960437,3.0190343E-05,3.0218293E-05,9.5002954E-07,8.1607215E-06,6.2134277E-06,2.4077364E-06,0.72490014,0.42136493
+862,0.00029971918,2.8452245E-05,2.8033966E-05,2.1307525E-07,7.3861702E-06,7.3602753E-06,2.9393433E-06,0.71569903,0.52801976
+863,0.00030253599,2.2468426E-05,2.4838895E-05,1.5311104E-07,6.2536109E-06,6.8292915E-06,4.9503841E-06,0.70796754,0.6157483
+864,0.00030535087,1.6486585E-05,2.1508134E-05,9.3166867E-08,5.1214196E-06,6.3127827E-06,6.9607209E-06,0.70023647,0.70344488
+865,0.000308537,1.5504916E-05,2.0187409E-05,1.1442436E-07,4.4396936E-06,9.1561582E-06,8.779297E-06,0.69714121,0.78926944
+866,0.00030159299,1.4511176E-05,1.8850479E-05,1.3591872E-07,3.7499296E-06,1.204603E-05,1.0618192E-05,0.69397258,0.87603246
+867,0.00029086525,1.6038621E-05,2.0882996E-05,1.207907E-06,5.5503072E-06,1.1227408E-05,1.1014684E-05,0.68495691,0.92644283
+868,0.00028161993,1.7559753E-05,2.2907121E-05,2.2679412E-06,7.3276205E-06,1.0397447E-05,1.1395065E-05,0.6759667,0.97663886
+869,0.00027081554,1.6345046E-05,2.2184554E-05,1.7575058E-06,6.1091375E-06,8.5296875E-06,1.1408897E-05,0.66728603,0.98191541
+870,0.00026149747,1.5167746E-05,2.1442375E-05,1.2583277E-06,4.8967699E-06,6.6569727E-06,1.1422409E-05,0.65863537,0.98714358
+871,0.00025888939,1.5871248E-05,2.1860139E-05,1.4413678E-06,5.1669233E-06,7.6253157E-06,9.7999343E-06,0.65652607,0.99004103
+872,0.00025622742,1.6614839E-05,2.2258669E-05,1.6267257E-06,5.4402707E-06,8.6204574E-06,8.1407437E-06,0.65433981,0.99290296
+873,0.00025098074,1.7957805E-05,2.4901713E-05,1.6946515E-06,6.1843931E-06,7.1707102E-06,7.1596336E-06,0.6452213,0.99045175
+874,0.00024576192,1.9322478E-05,2.7571354E-05,1.7637892E-06,6.9230951E-06,5.7308476E-06,6.1851318E-06,0.63614388,0.98798286
+875,0.00024226621,1.8275452E-05,2.6975743E-05,9.8310269E-07,6.0092652E-06,4.1429061E-06,4.719967E-06,0.63247065,0.9933626
+876,0.0002547547,1.7220778E-05,2.6375468E-05,1.9695265E-07,5.0729954E-06,2.5292752E-06,3.2444942E-06,0.62875987,0.9987611
+877,0.00026799871,1.6590601E-05,3.2176653E-05,1.8826011E-07,4.948001E-06,3.7232101E-06,3.9128526E-06,0.62286138,0.9993812
+878,0.00028125627,1.5991705E-05,3.7983933E-05,1.7779761E-07,4.838834E-06,4.918405E-06,4.5964125E-06,0.61695541,1
+879,0.00029339457,1.617809E-05,3.6654246E-05,5.9421768E-06,3.375139E-06,6.7483826E-06,7.508642E-06,0.61304562,0.99835055
+880,0.00030703349,1.633293E-05,3.5087675E-05,1.1709535E-05,1.922653E-06,8.5989306E-06,1.041584E-05,0.60912042,0.99669148
+881,0.00030122673,2.0796065E-05,3.3000903E-05,1.0439349E-05,3.0926929E-06,7.5196255E-06,9.5443195E-06,0.60460279,0.99096196
+882,0.00029688016,2.5260371E-05,3.0913484E-05,9.1511262E-06,4.247019E-06,6.440008E-06,8.6870896E-06,0.60008253,0.9852286
+883,0.00029313331,1.7016519E-05,3.0748242E-05,9.8085451E-06,3.5977948E-06,6.000421E-06,8.2102883E-06,0.5979007,0.98142598
+884,0.00028789906,8.7686543E-06,3.0348604E-05,1.0451031E-05,2.929603E-06,5.5441972E-06,7.7313386E-06,0.595705,0.97759964
+885,0.00028370306,1.680832E-05,2.9670278E-05,1.1240097E-05,3.608344E-06,7.2362959E-06,7.6054496E-06,0.59091369,0.97085575
+886,0.0002750871,2.485989E-05,2.8990886E-05,1.2030313E-05,4.2880857E-06,8.9308931E-06,7.464722E-06,0.5861141,0.96409993
+887,0.00026604396,1.7097419E-05,2.8266458E-05,1.0102916E-05,3.3664667E-06,7.0743177E-06,7.4440186E-06,0.5727696,0.95627089
+888,0.00025701407,9.3475265E-06,2.7776466E-05,8.1786086E-06,2.4463333E-06,5.2060686E-06,7.4233066E-06,0.55944363,0.94844917
+889,0.00024796987,9.6286026E-06,2.4718907E-05,8.5963404E-06,2.862104E-06,4.5418898E-06,8.1609151E-06,0.53325507,0.9407302
+890,0.00023747516,9.9090897E-06,2.1503842E-05,9.0309411E-06,3.2770763E-06,3.8789282E-06,8.9116727E-06,0.50711225,0.93301969
+891,0.00024236118,9.8323837E-06,2.2340981E-05,9.0491742E-06,3.0422446E-06,4.9134508E-06,9.9527036E-06,0.46745757,0.92867725
+892,0.00024579364,9.7230052E-06,2.3157973E-05,9.0852046E-06,2.8064455E-06,5.9374261E-06,1.1012523E-05,0.42763983,0.92431156
+893,0.00025086696,9.4246971E-06,2.0990789E-05,7.8969235E-06,3.1857668E-06,5.0099819E-06,1.2495077E-05,0.37795755,0.92043982
+894,0.00025596437,9.124721E-06,1.8788468E-05,6.7023072E-06,3.5508369E-06,4.0628313E-06,1.3985302E-05,0.3280099,0.9165381
+895,0.00025899682,9.2247496E-06,1.92407E-05,7.6874887E-06,3.1139441E-06,4.8028877E-06,1.5314561E-05,0.27517437,0.91092194
+896,0.00026351086,9.3248159E-06,1.9693148E-05,8.6553278E-06,2.6605753E-06,5.5581344E-06,1.6791836E-05,0.22230846,0.90530077
+897,0.00026840058,1.376655E-05,1.8264919E-05,7.3800914E-06,3.9975433E-06,5.1972628E-06,1.8295378E-05,0.17926259,0.9016168
+898,0.00027182016,1.81905E-05,1.6831828E-05,6.1184948E-06,5.3226942E-06,4.8351601E-06,1.9803876E-05,0.13607176,0.89791656
+899,0.0002771381,1.8574258E-05,1.7665799E-05,6.8935306E-06,4.6208611E-06,5.2668292E-06,1.8531396E-05,0.10503591,0.89503012
+900,0.00028248509,1.8927332E-05,1.8480959E-05,7.6733023E-06,3.9145769E-06,5.7160391E-06,1.7399406E-05,0.073804716,0.89211226
+901,0.00027354797,1.9224714E-05,1.7841589E-05,6.9880021E-06,4.1115856E-06,5.4330848E-06,1.6955168E-05,0.055686113,0.88661161
+902,0.00026610322,1.9489309E-05,1.7178277E-05,6.3025342E-06,4.3086288E-06,5.1649832E-06,1.6510794E-05,0.03756336,0.88110776
+903,0.00025720403,1.9461839E-05,1.7563252E-05,7.6048573E-06,4.2770372E-06,5.0320148E-06,1.7705619E-05,0.028010548,0.87602215
+904,0.00024979523,1.9434315E-05,1.7948403E-05,8.9259464E-06,4.2618114E-06,4.9138994E-06,1.8752236E-05,0.018452453,0.870932
+905,0.00024081866,1.6807924E-05,1.8090897E-05,6.0168355E-06,3.8683829E-06,4.2417521E-06,1.830561E-05,0.013814732,0.86464526
+906,0.00024380767,1.4181539E-05,1.8233343E-05,3.0896944E-06,3.4913434E-06,3.5696066E-06,1.7710122E-05,0.009177063,0.85835652
+907,0.00024697513,1.4914373E-05,1.8555603E-05,4.683049E-06,3.7234741E-06,4.1550549E-06,1.8318472E-05,0.0066541154,0.85313837
+908,0.00025014665,1.5648223E-05,1.8878287E-05,6.2605713E-06,3.9395141E-06,4.7413298E-06,1.907669E-05,0.0041275583,0.84791119
+909,0.0002540718,1.5078767E-05,1.8350258E-05,6.1927535E-06,3.6080046E-06,4.3534188E-06,1.8548393E-05,0.0033788795,0.84462541
+910,0.0002580204,1.4504806E-05,1.7841939E-05,6.1243058E-06,3.2739823E-06,3.9776316E-06,1.801582E-05,0.0026246272,0.84129754
+911,0.00026474244,1.2915612E-05,1.8297062E-05,6.7067363E-06,3.0669765E-06,3.8520187E-06,1.8815266E-05,0.0022781207,0.83642555
+912,0.00027149675,1.1351306E-05,1.8754366E-05,7.2738067E-06,2.842241E-06,3.7408581E-06,1.961868E-05,0.0019297899,0.83151967
+913,0.00027558474,1.1066438E-05,1.8554503E-05,6.6214331E-06,2.8374818E-06,3.2205205E-06,1.8380547E-05,0.0016874721,0.82299467
+914,0.00028116744,1.0782397E-05,1.8355094E-05,5.9711706E-06,2.8161397E-06,2.7018908E-06,1.7146353E-05,0.001445946,0.81448863
+915,0.0002875763,9.5004766E-06,1.835419E-05,6.2163873E-06,2.4713768E-06,3.4911955E-06,1.5662016E-05,0.0013063323,0.80818005
+916,0.00028490773,8.1820354E-06,1.8377317E-05,6.4622052E-06,2.1257371E-06,4.2824816E-06,1.4294519E-05,0.0011663611,0.80185327
+917,0.00028400161,7.6663191E-06,1.7572023E-05,6.5678295E-06,2.0970218E-06,4.094545E-06,1.4431032E-05,0.0010774551,0.79663027
+918,0.00028156763,7.1483307E-06,1.6763142E-05,6.6738628E-06,2.0681683E-06,3.9057713E-06,1.4568033E-05,0.00098815897,0.79137928
+919,0.0002781303,6.6378916E-06,1.6256366E-05,6.6277187E-06,2.0485923E-06,3.2932116E-06,1.362501E-05,0.00095262304,0.78287004
+920,0.00027621775,6.1621432E-06,1.575087E-05,6.5999759E-06,2.0290522E-06,2.6823543E-06,1.2669428E-05,0.00091717701,0.77437747
+921,0.00027519818,5.3724541E-06,1.481285E-05,6.1344142E-06,1.7828054E-06,2.8694025E-06,1.1648568E-05,0.00091555827,0.76847536
+922,0.00027569672,4.6133028E-06,1.3895561E-05,5.648733E-06,1.5306488E-06,3.0571149E-06,1.0608791E-05,0.00091393075,0.76254799
+923,0.00027491448,4.7263305E-06,1.456423E-05,5.8853927E-06,1.8410729E-06,3.095878E-06,9.8776425E-06,0.00086839245,0.75801567
+924,0.00027412497,4.839917E-06,1.5260694E-05,6.1417665E-06,2.148121E-06,3.1348164E-06,9.1424302E-06,0.00082259824,0.75345043
+925,0.0002731311,4.0412178E-06,1.4827431E-05,6.0426634E-06,1.7824207E-06,3.2022861E-06,8.1375411E-06,0.00079834384,0.74690555
+926,0.00026751931,3.2562149E-06,1.4392372E-05,5.9617062E-06,1.4001034E-06,3.2700032E-06,7.1286393E-06,0.00077399075,0.74033046
+927,0.00026085371,3.7381002E-06,1.3803071E-05,5.5977654E-06,1.6983323E-06,2.696643E-06,6.5191476E-06,0.00075513531,0.73066613
+928,0.00025267932,4.2012219E-06,1.32159E-05,5.2166837E-06,1.9802542E-06,2.1408018E-06,5.9119712E-06,0.00073634352,0.72102947
+929,0.00024745287,3.6093605E-06,1.3093103E-05,5.309973E-06,1.514187E-06,2.5936778E-06,5.2300708E-06,0.00073178439,0.71502744
+930,0.00024218309,3.0232599E-06,1.2993651E-05,5.4038316E-06,1.0463766E-06,3.0652078E-06,4.5430834E-06,0.00072717829,0.70896658
+931,0.00024122019,3.2816736E-06,1.3221554E-05,5.2300607E-06,1.2590155E-06,2.9799505E-06,4.2617077E-06,0.00076635852,0.70196558
+932,0.00024025054,3.5379026E-06,1.345044E-05,5.0554066E-06,1.474367E-06,2.9097335E-06,3.9635162E-06,0.00080571924,0.6949247
+933,0.00023812327,3.0813911E-06,1.2778964E-05,4.7816824E-06,1.286104E-06,2.5321396E-06,3.8616212E-06,0.00076082592,0.68344371
+934,0.00023600172,2.6270317E-06,1.2110494E-05,4.4905592E-06,1.0987282E-06,2.1409238E-06,3.7601455E-06,0.00071613712,0.67200519
+935,0.00023425229,2.530007E-06,1.178139E-05,4.0211814E-06,1.3173102E-06,2.1390343E-06,3.1588014E-06,0.00070105809,0.66171989
+936,0.00022942508,2.4331394E-06,1.1428328E-05,3.5340109E-06,1.5354979E-06,2.1371358E-06,2.558503E-06,0.00068600171,0.65144899
+937,0.00022538603,2.8121086E-06,1.1114336E-05,3.5990766E-06,1.3888984E-06,1.8497714E-06,2.5343869E-06,0.00066557833,0.64425067
+938,0.00022132383,3.1964037E-06,1.0774012E-05,3.645746E-06,1.2415277E-06,1.5609041E-06,2.5101206E-06,0.00064504444,0.63700868
+939,0.00021743211,3.1052308E-06,1.0712641E-05,3.5833454E-06,9.4799063E-07,1.6438576E-06,2.2715789E-06,0.00062399037,0.6290025
+940,0.00021350927,3.0133664E-06,1.0625874E-05,3.5204439E-06,6.5239817E-07,1.7273559E-06,2.0158321E-06,0.00060278009,0.62092887
+941,0.00021342782,3.176333E-06,1.0349465E-05,3.575557E-06,6.7092844E-07,1.6644736E-06,1.8445577E-06,0.0006248261,0.61087036
+942,0.00021490297,3.3391641E-06,1.0073234E-05,3.6118043E-06,6.8944226E-07,1.6016339E-06,1.6734083E-06,0.00064685483,0.60081751
+943,0.00021655728,3.3885313E-06,9.7558563E-06,3.3687647E-06,8.6731109E-07,1.5525701E-06,1.5811497E-06,0.00046889498,0.59209733
+944,0.00021665404,3.4208329E-06,9.4381778E-06,3.1066733E-06,1.0470458E-06,1.5050161E-06,1.4981109E-06,0.000290775,0.58336833
+945,0.00021860221,3.5640165E-06,8.8097998E-06,2.9235993E-06,9.257143E-07,1.3190448E-06,1.4790345E-06,0.00028118637,0.57468499
+946,0.00021273513,3.6733638E-06,8.1791351E-06,2.7398574E-06,8.0565918E-07,1.1339649E-06,1.4598828E-06,0.00027156214,0.56596787
+947,0.00020799566,4.0157655E-06,8.0033107E-06,2.6258933E-06,8.4660878E-07,1.1165325E-06,1.216814E-06,0.00027334215,0.55656914
+948,0.00020169422,4.358001E-06,7.8026939E-06,2.5119734E-06,8.8753748E-07,1.0991048E-06,9.7385189E-07,0.00027512059,0.5471731
+949,0.00019563537,4.2249575E-06,7.4125019E-06,2.4010475E-06,8.5412201E-07,1.1533375E-06,1.0044121E-06,0.00013985902,0.53904788
+950,0.00019113066,4.1260228E-06,7.0215147E-06,2.2898949E-06,8.223548E-07,1.2061119E-06,1.0350312E-06,4.3749555E-06,0.53090528
+951,0.00018654361,4.4381604E-06,6.5274852E-06,1.9883021E-06,7.6616354E-07,1.0127457E-06,1.046576E-06,3.8797594E-06,0.52300826
+952,0.00018195071,4.7506682E-06,6.0079178E-06,1.6711829E-06,7.0990299E-07,8.1914377E-07,1.0581331E-06,3.3839576E-06,0.5151008
+953,0.00017781793,5.2840681E-06,6.277432E-06,2.5281824E-06,8.7429556E-07,1.1014831E-06,9.3786165E-07,3.0674681E-06,0.50815906
+954,0.00017365554,5.8208323E-06,6.5485875E-06,3.4135686E-06,1.0380073E-06,1.3840544E-06,8.1679699E-07,2.7488814E-06,0.50116414
+955,0.00016903069,5.4432877E-06,6.4022575E-06,2.9196639E-06,8.6211324E-07,1.255618E-06,7.7018081E-07,2.8890907E-06,0.49366651
+956,0.00017230329,5.0652371E-06,6.2557241E-06,2.4441997E-06,6.859863E-07,1.1270105E-06,7.2507482E-07,3.0121684E-06,0.48615819
+957,0.00017547231,5.6899616E-06,6.6831075E-06,2.4443042E-06,8.2287228E-07,1.0402404E-06,7.2510581E-07,2.4929356E-06,0.47813197
+958,0.00017864124,6.28003E-06,7.1356379E-06,2.4444035E-06,9.5803552E-07,9.5346094E-07,7.2670825E-07,1.990967E-06,0.47010408
+959,0.00018011837,5.8602981E-06,7.2821953E-06,2.3284806E-06,7.9472894E-07,1.019174E-06,7.8288383E-07,1.9898206E-06,0.46220385
+960,0.00018317213,5.4063712E-06,7.4034576E-06,2.2126822E-06,6.333382E-07,1.0832304E-06,8.3899137E-07,1.9886675E-06,0.45431088
+961,0.00017730762,6.0108425E-06,8.1017052E-06,2.2183345E-06,8.309944E-07,1.016443E-06,6.7101746E-07,1.7510304E-06,0.44768648
+962,0.00017141139,6.653178E-06,8.8034423E-06,2.2048213E-06,1.0296528E-06,9.4771943E-07,5.0217822E-07,1.5312805E-06,0.44102379
+963,0.0001637278,6.2447935E-06,9.2717654E-06,2.2466256E-06,9.5459454E-07,9.0791231E-07,6.9432779E-07,1.4100456E-06,0.43450883
+964,0.00015777113,5.8351258E-06,9.7668018E-06,2.2885505E-06,8.8104576E-07,8.67979E-07,8.8865172E-07,1.2884313E-06,0.42797215
+965,0.00015130031,5.423569E-06,1.0464894E-05,2.0221928E-06,8.6308538E-07,7.70516E-07,7.1384014E-07,1.1261501E-06,0.42144877
+966,0.00014624744,5.0108188E-06,1.1139572E-05,1.7531389E-06,8.4507087E-07,6.7277205E-07,5.3852682E-07,9.6165308E-07,0.41490539
+967,0.00014130021,4.9464031E-06,1.1736637E-05,1.7532184E-06,7.707196E-07,6.8631213E-07,5.0574604E-07,1.0187707E-06,0.40900472
+968,0.00013634129,4.8818277E-06,1.2335044E-05,1.755227E-06,6.979496E-07,6.9988162E-07,4.7288885E-07,1.0760169E-06,0.40308954
+969,0.00013099127,4.5984304E-06,1.2964024E-05,1.7968054E-06,8.009914E-07,7.2346803E-07,5.3947707E-07,1.1052251E-06,0.39641237
+970,0.00012580628,4.3503996E-06,1.3592288E-05,1.8383331E-06,9.0392105E-07,7.4702673E-07,6.0758326E-07,1.1343982E-06,0.38974075
+971,0.00012726589,4.1809187E-06,1.3942371E-05,1.8100076E-06,8.1573867E-07,6.9693789E-07,5.8296277E-07,1.0027758E-06,0.38443808
+972,0.00012888955,4.0461257E-06,1.4318884E-05,1.7796592E-06,7.2554595E-07,6.4830501E-07,5.5667528E-07,8.6902007E-07,0.37911907
+973,0.00013050236,3.7389361E-06,1.4789451E-05,1.661865E-06,6.8335637E-07,7.6710163E-07,6.3804316E-07,9.1170643E-07,0.37412399
+974,0.0001322832,3.4442951E-06,1.5287872E-05,1.5415101E-06,6.3918018E-07,8.8649403E-07,7.1981801E-07,9.5460067E-07,0.3690999
+975,0.00013372161,3.6773648E-06,1.5235323E-05,1.518021E-06,7.0444908E-07,8.1080559E-07,7.1815198E-07,8.7159233E-07,0.3635168
+976,0.00012919891,3.889171E-06,1.5182748E-05,1.4945325E-06,7.6970478E-07,7.3352011E-07,7.1488172E-07,7.8683251E-07,0.35793385
+977,0.00012480994,4.0293239E-06,1.479403E-05,1.5232419E-06,7.8358053E-07,7.2846444E-07,6.3293542E-07,7.5660237E-07,0.35254688
+978,0.00012026238,4.1340424E-06,1.4379928E-05,1.5519286E-06,7.9568092E-07,7.2501741E-07,5.5103919E-07,7.2462609E-07,0.34716228
+979,0.00011576923,3.9932136E-06,1.3588451E-05,1.3965238E-06,8.2930693E-07,7.0260035E-07,6.1519146E-07,7.2295461E-07,0.34193052
+980,0.00011143576,3.8523419E-06,1.2796749E-05,1.2430225E-06,8.6117515E-07,6.8017634E-07,6.8096099E-07,7.1951784E-07,0.33669681
+981,0.00010798087,3.8612423E-06,1.2313262E-05,1.3999251E-06,8.3132675E-07,6.5918405E-07,5.3317972E-07,6.9289863E-07,0.33277315
+982,0.00010467092,3.8701528E-06,1.1853152E-05,1.5594961E-06,7.9956081E-07,6.3808941E-07,3.847109E-07,6.6615078E-07,0.32882867
+983,0.00010112622,4.1258842E-06,1.0920845E-05,1.3370866E-06,8.418035E-07,6.0198381E-07,3.9021988E-07,7.1700716E-07,0.32509446
+984,9.773102E-05,4.3824898E-06,9.9852303E-06,1.1158552E-06,8.8418985E-07,5.6574934E-07,3.9413101E-07,7.6625999E-07,0.3213457
+985,9.4171396E-05,4.604792E-06,9.4092068E-06,1.355655E-06,1.0016822E-06,6.3988121E-07,4.288458E-07,7.0177777E-07,0.3170805
+986,9.8582443E-05,4.8278952E-06,8.8568949E-06,1.5963375E-06,1.1178196E-06,7.142848E-07,4.6368716E-07,6.3705269E-07,0.31279784
+987,0.00010267434,5.15067E-06,8.1591159E-06,1.409594E-06,1.3287629E-06,6.3467101E-07,5.6106387E-07,6.6036802E-07,0.30813703
+988,0.0001067675,5.437775E-06,7.4351693E-06,1.2247511E-06,1.5397785E-06,5.5665559E-07,6.5685218E-07,6.8369042E-07,0.30347403
+989,0.00011099194,5.1585171E-06,6.8744756E-06,1.2027407E-06,1.541853E-06,5.1502972E-07,5.213176E-07,5.6127423E-07,0.29920322
+990,0.00011522743,4.8784912E-06,6.3122504E-06,1.1806675E-06,1.5457197E-06,4.7329013E-07,3.8378995E-07,4.3673654E-07,0.29492002
+991,0.00010881726,4.6975859E-06,5.9985563E-06,1.0973825E-06,1.5344672E-06,5.0576405E-07,4.3243422E-07,5.2605826E-07,0.28967215
+992,0.00010257436,4.5167866E-06,5.6590932E-06,1.0121763E-06,1.5250074E-06,5.38215E-07,4.8104501E-07,6.135306E-07,0.28442692
+993,9.6376662E-05,4.5967027E-06,5.6172211E-06,1.2452507E-06,1.692707E-06,5.4898257E-07,5.5191363E-07,6.486764E-07,0.27997814
+994,9.0156281E-05,4.6768831E-06,5.5491196E-06,1.4771744E-06,1.8681848E-06,5.5978608E-07,6.2466462E-07,6.8394505E-07,0.27551206
+995,8.3857013E-05,4.2499161E-06,5.2945092E-06,1.2686976E-06,1.7875495E-06,5.4730276E-07,5.3555881E-07,6.6494105E-07,0.27143947
+996,8.4279237E-05,3.8580412E-06,5.0393175E-06,1.0617363E-06,1.7139312E-06,5.3479029E-07,4.4625255E-07,6.4589305E-07,0.26735716
+997,8.4424509E-05,3.6408825E-06,5.1948102E-06,1.2460192E-06,1.7603437E-06,5.8223253E-07,4.5595761E-07,6.1696778E-07,0.26298963
+998,8.45695E-05,3.4021886E-06,5.3241206E-06,1.4321991E-06,1.7995327E-06,6.2801207E-07,4.6402322E-07,5.8805402E-07,0.2586234
+999,8.4997258E-05,3.3159635E-06,5.2519625E-06,1.2630808E-06,1.6737219E-06,5.7293122E-07,4.5802295E-07,4.5550991E-07,0.25477272
+1000,8.5261217E-05,3.2295287E-06,5.1534632E-06,1.0935638E-06,1.5367901E-06,5.1772008E-07,4.5036984E-07,3.2265451E-07,0.25091241
+1001,8.2220608E-05,2.9581031E-06,5.3160292E-06,1.2041904E-06,1.5113282E-06,5.6927082E-07,4.4756655E-07,4.4569733E-07,0.24796731
+1002,7.9173402E-05,2.689718E-06,5.4527124E-06,1.3150482E-06,1.4858094E-06,6.2092924E-07,4.4475639E-07,5.6719273E-07,0.24501546
+1003,7.6051488E-05,2.4873872E-06,5.401137E-06,1.3152563E-06,1.3341859E-06,5.5513598E-07,4.2512964E-07,4.9863046E-07,0.24173025
+1004,7.2928459E-05,2.2813671E-06,5.349536E-06,1.3154621E-06,1.1843206E-06,4.909686E-07,4.038543E-07,4.3004575E-07,0.23844358
+1005,7.0070477E-05,2.4285723E-06,5.3181093E-06,1.4467472E-06,1.1962813E-06,5.4584751E-07,3.9062307E-07,4.7166212E-07,0.23573357
+1006,7.0347842E-05,2.5768846E-06,5.2862974E-06,1.5790381E-06,1.2083066E-06,6.02809E-07,3.7893152E-07,5.1541824E-07,0.23299602
+1007,7.0560657E-05,2.425184E-06,4.945948E-06,1.5639973E-06,1.0559139E-06,5.4006099E-07,3.626233E-07,5.0482339E-07,0.22943903
+1008,7.0773644E-05,2.2732797E-06,4.6051423E-06,1.5489343E-06,9.0331875E-07,4.7722942E-07,3.4794994E-07,4.9421379E-07,0.225877
+1009,7.0927443E-05,2.3167215E-06,4.2073923E-06,1.594915E-06,7.11578E-07,3.557797E-07,3.5782715E-07,4.1572151E-07,0.22171754
+1010,7.1081018E-05,2.360142E-06,3.8362327E-06,1.6388644E-06,5.2172902E-07,2.3603521E-07,3.6769995E-07,3.3543357E-07,0.21755905
+1011,6.8906979E-05,2.3288962E-06,3.5532776E-06,1.8219701E-06,4.6075165E-07,4.131688E-07,4.0007834E-07,4.0197475E-07,0.21414816
+1012,6.6722499E-05,2.30116E-06,3.2690059E-06,2.0038755E-06,4.0132547E-07,5.9110599E-07,4.3426492E-07,4.6698457E-07,0.21072006
+1013,6.4619566E-05,2.3698252E-06,3.1395682E-06,1.9413669E-06,4.8432162E-07,5.78383E-07,4.080916E-07,4.2533161E-07,0.20672371
+1014,6.2344274E-05,2.434958E-06,2.9832032E-06,1.880741E-06,5.6749927E-07,5.6563076E-07,3.8185981E-07,3.8175075E-07,0.20271813
+1015,6.003039E-05,2.5577188E-06,2.7183132E-06,1.8675778E-06,4.6490247E-07,5.2072834E-07,3.6204513E-07,4.4806488E-07,0.19857573
+1016,6.0901609E-05,2.6806084E-06,2.4291353E-06,1.8543977E-06,3.6219426E-07,4.757767E-07,3.4220853E-07,5.126126E-07,0.19442858
+1017,6.1773677E-05,2.9178346E-06,2.2516934E-06,1.7965901E-06,4.0653796E-07,4.3748063E-07,3.5074361E-07,3.8420663E-07,0.1902455
+1018,6.2478639E-05,3.1516254E-06,2.0740576E-06,1.7366889E-06,4.5276925E-07,3.9914277E-07,3.5928734E-07,2.5382281E-07,0.18605765
+1019,6.3423047E-05,3.1494494E-06,2.0373794E-06,1.8208468E-06,4.2955113E-07,3.8636366E-07,3.0799127E-07,2.4687294E-07,0.18238771
+1020,6.4201806E-05,3.1435549E-06,1.9978932E-06,1.907311E-06,4.0810108E-07,3.7185809E-07,2.5484768E-07,2.3989907E-07,0.17870488
+1021,6.083019E-05,3.3838642E-06,2.0781882E-06,1.9194788E-06,4.4502275E-07,4.256917E-07,2.5987141E-07,3.6906674E-07,0.17448787
+1022,5.7458621E-05,3.627853E-06,2.1611531E-06,1.9296067E-06,4.8378824E-07,4.7783928E-07,2.6321783E-07,4.982273E-07,0.17027072
+1023,5.4033151E-05,3.6836347E-06,2.1254294E-06,1.8479838E-06,4.4964502E-07,4.0128226E-07,2.5872945E-07,4.123615E-07,0.16661211
+1024,5.0762162E-05,3.750767E-06,2.0895418E-06,1.7660063E-06,4.1720987E-07,3.2271185E-07,2.5590412E-07,3.2798581E-07,0.16293706
+1025,4.7318102E-05,3.7073391E-06,2.24263E-06,1.7455101E-06,4.107415E-07,3.3700696E-07,2.4299674E-07,2.8974146E-07,0.1590322
+1026,4.5897597E-05,3.6786033E-06,2.3964092E-06,1.7228513E-06,4.061027E-07,3.5136558E-07,2.3171897E-07,2.5131759E-07,0.15510797
+1027,4.4176846E-05,3.6805979E-06,2.4168827E-06,1.6358344E-06,3.6308572E-07,2.8842504E-07,2.0794156E-07,2.5119909E-07,0.15045152
+1028,4.2457578E-05,3.6825785E-06,2.4373289E-06,1.5468429E-06,3.1824715E-07,2.255431E-07,1.8587575E-07,2.4922003E-07,0.14579899
+1029,4.081484E-05,3.7323874E-06,2.6595805E-06,1.6290698E-06,3.2240826E-07,3.0226617E-07,2.1151039E-07,2.5328455E-07,0.14179028
+1030,3.9167501E-05,3.8122209E-06,2.8959629E-06,1.7115162E-06,3.247136E-07,3.791976E-07,2.3890871E-07,2.5735941E-07,0.13777022
+1031,3.8018666E-05,3.6107647E-06,2.8721628E-06,1.5322323E-06,3.8113197E-07,4.1537899E-07,1.9338007E-07,3.0992959E-07,0.13261708
+1032,3.6696449E-05,3.4200796E-06,2.8483022E-06,1.3525367E-06,4.3767792E-07,4.5334612E-07,1.5029471E-07,3.6448791E-07,0.12745191
+1033,3.5464867E-05,3.293044E-06,2.8724472E-06,1.3655518E-06,4.0172296E-07,4.7500906E-07,1.9679218E-07,3.4917211E-07,0.12166158
+1034,3.423563E-05,3.1662524E-06,2.8965246E-06,1.3805891E-06,3.6397376E-07,4.9662411E-07,2.4234448E-07,3.3202073E-07,0.11588256
+1035,3.2917683E-05,3.0619995E-06,2.8191389E-06,1.3227161E-06,3.644683E-07,5.279543E-07,2.2061251E-07,2.9698329E-07,0.10961224
+1036,3.3474742E-05,2.9537059E-06,2.7686785E-06,1.266745E-06,3.6496312E-07,5.5766272E-07,1.9882082E-07,2.6184974E-07,0.10332455
+1037,3.3852743E-05,2.7805246E-06,2.5732966E-06,1.27224E-06,3.653562E-07,5.8728622E-07,1.8202343E-07,2.8647257E-07,0.095607494
+1038,3.4402645E-05,2.6069644E-06,2.3883693E-06,1.2777442E-06,3.6574937E-07,6.169723E-07,1.6535976E-07,3.0927346E-07,0.08787361
+1039,3.481727E-05,2.5295764E-06,2.22706E-06,1.2182478E-06,3.552333E-07,6.1654369E-07,1.6604521E-07,2.4981197E-07,0.079707492
+1040,3.5233395E-05,2.4518497E-06,2.067796E-06,1.1584958E-06,3.4467114E-07,6.161093E-07,1.6673243E-07,1.8821904E-07,0.071506845
+1041,3.3718954E-05,2.2880763E-06,2.0369739E-06,1.2011729E-06,3.6951093E-07,7.2148947E-07,1.5234313E-07,2.1289203E-07,0.062861841
+1042,3.2201538E-05,2.1239837E-06,2.0088257E-06,1.2439297E-06,3.9439781E-07,8.2879044E-07,1.3792587E-07,2.3761207E-07,0.054200092
+1043,3.0681148E-05,2.0579289E-06,1.8326895E-06,1.2930129E-06,3.3999873E-07,8.0548997E-07,1.4251726E-07,2.4350296E-07,0.046424917
+1044,2.9157782E-05,1.9879568E-06,1.6562119E-06,1.3421879E-06,2.8549462E-07,7.821433E-07,1.471172E-07,2.5129414E-07,0.038634733
+1045,2.7631443E-05,1.8761547E-06,1.5397763E-06,1.3309566E-06,3.1226314E-07,7.4150609E-07,1.2285829E-07,2.156013E-07,0.032806362
+1046,2.6793575E-05,1.7641349E-06,1.4231147E-06,1.3176133E-06,3.3908236E-07,7.0251576E-07,9.8552678E-08,1.7983968E-07,0.026966762
+1047,2.5954056E-05,1.6556949E-06,1.4327251E-06,1.4317401E-06,3.3371816E-07,6.4962765E-07,1.256758E-07,2.0274992E-07,0.0222464
+1048,2.5112883E-05,1.5432435E-06,1.4423513E-06,1.5460825E-06,3.2644515E-07,5.9663723E-07,1.5285056E-07,2.2380692E-07,0.017516969
+1049,2.4270058E-05,1.5294972E-06,1.4079099E-06,1.602005E-06,2.6406496E-07,5.4527554E-07,1.5109905E-07,1.8225395E-07,0.013660035
+1050,2.342558E-05,1.5157219E-06,1.3706424E-06,1.6601274E-06,1.9966369E-07,4.9381484E-07,1.4934391E-07,1.4043132E-07,0.0097957179
+1051,2.257945E-05,1.4942936E-06,1.523773E-06,1.7624181E-06,1.8614958E-07,4.2144312E-07,1.5622599E-07,1.4589093E-07,0.0075646824
+1052,2.1557814E-05,1.4728218E-06,1.6771925E-06,1.8649004E-06,1.7222836E-07,3.471968E-07,1.6312088E-07,1.5136069E-07,0.0053293868
+1053,2.0708213E-05,1.478041E-06,1.8474951E-06,1.9927997E-06,1.7353627E-07,3.2667522E-07,1.6362223E-07,1.7056175E-07,0.0040858824
+1054,1.985696E-05,1.4794447E-06,2.0208866E-06,2.1251467E-06,1.7484635E-07,3.0437476E-07,1.6412424E-07,1.8960825E-07,0.0028400098
+1055,1.8829704E-05,1.5458985E-06,2.2250843E-06,2.3377732E-06,1.6049157E-07,2.6114018E-07,1.5491235E-07,1.7012196E-07,0.0021849106
+1056,1.8498524E-05,1.6086455E-06,2.4324391E-06,2.5507989E-06,1.4610927E-07,2.1956567E-07,1.4550907E-07,1.5040729E-07,0.0015285643
+1057,1.8166682E-05,1.6561737E-06,2.6040918E-06,2.8486277E-06,1.2921093E-07,1.7372579E-07,1.4547306E-07,1.2395962E-07,0.0011958849
+1058,1.7834179E-05,1.7076263E-06,2.7788438E-06,3.1258945E-06,1.1208875E-07,1.2814796E-07,1.4526275E-07,9.7270155E-08,0.00086257645
+1059,1.7483514E-05,1.801424E-06,2.8927291E-06,3.4882439E-06,9.2248969E-08,1.3281268E-07,1.5219119E-07,1.0081193E-07,0.00069330508
+1060,1.7114638E-05,1.8992405E-06,3.0068246E-06,3.8301112E-06,7.2371521E-08,1.3766089E-07,1.5895816E-07,1.0436022E-07,0.00052370919
+1061,1.6324217E-05,2.1357751E-06,3.0932629E-06,4.3632444E-06,1.108694E-07,1.533732E-07,1.7969448E-07,1.1482773E-07,0.0004240321
+1062,1.5532275E-05,2.3727522E-06,3.2077523E-06,4.8973759E-06,1.4924738E-07,1.6929012E-07,1.990726E-07,1.2512259E-07,0.0003240541
+1063,1.4738813E-05,2.5484838E-06,3.1270135E-06,5.6022712E-06,1.3725977E-07,1.4418997E-07,1.8877268E-07,1.1927658E-07,0.00027288412
+1064,1.3943831E-05,2.7284009E-06,3.0181711E-06,6.3084842E-06,1.2524935E-07,1.1921788E-07,1.7845303E-07,1.1341935E-07,0.00022128701
+1065,1.3147328E-05,2.8970635E-06,2.9930354E-06,7.2073605E-06,1.1244461E-07,1.2108736E-07,1.6548687E-07,1.252833E-07,0.00020000666
+1066,1.2754489E-05,3.0660381E-06,2.9678472E-06,8.0866331E-06,9.9808662E-08,1.2296014E-07,1.5249605E-07,1.3736226E-07,0.00017901687
+1067,1.2343256E-05,3.3088546E-06,2.78847E-06,9.1805485E-06,9.2945846E-08,1.2994236E-07,1.5807796E-07,1.1161498E-07,0.00015699371
+1068,1.1931231E-05,3.5521209E-06,2.6143615E-06,1.0297821E-05,8.5876574E-08,1.3693745E-07,1.6349447E-07,8.6012484E-08,0.00013492895
+1069,1.1536078E-05,3.8035914E-06,2.5494237E-06,1.1758617E-05,8.9054532E-08,1.478263E-07,1.5767116E-07,8.5899553E-08,0.00012443669
+1070,1.1122482E-05,4.0749307E-06,2.4843599E-06,1.3222128E-05,9.2238285E-08,1.5873527E-07,1.5201262E-07,8.5979908E-08,0.00011425671
+1071,1.0672694E-05,4.1952744E-06,2.3291544E-06,1.4709735E-05,8.4760087E-08,1.7850107E-07,1.5056974E-07,9.4394928E-08,0.00010937671
+1072,1.0204331E-05,4.3158358E-06,2.1708391E-06,1.6178696E-05,7.7267764E-08,1.9635761E-07,1.4912391E-07,1.0301952E-07,0.00010482016
+1073,9.7528086E-06,4.3198618E-06,1.9896784E-06,1.7821735E-05,9.8715175E-08,1.7706377E-07,1.2244507E-07,8.0783614E-08,9.9255703E-05
+1074,9.3004263E-06,4.3628417E-06,1.8081763E-06,1.9467809E-05,1.2000793E-07,1.5897422E-07,9.5716254E-08,5.8311708E-08,9.3680691E-05
+1075,8.8471847E-06,4.561855E-06,1.8465654E-06,2.1095456E-05,1.0707588E-07,1.8094168E-07,9.2446884E-08,7.9961423E-08,8.0086477E-05
+1076,8.8020688E-06,4.761231E-06,1.8850227E-06,2.2769059E-05,9.411956E-08,2.0419264E-07,8.8994339E-08,1.0184605E-07,6.646681E-05
+1077,8.7746522E-06,4.8047187E-06,2.0055819E-06,2.4510236E-05,1.0356922E-07,2.1860032E-07,9.5806526E-08,9.2194937E-08,7.3214871E-05
+1078,8.7471695E-06,4.8873779E-06,2.1235305E-06,2.6469809E-05,1.1323149E-07,2.330344E-07,1.0263121E-07,8.2525726E-08,7.997535E-05
+1079,8.7017891E-06,4.7745058E-06,2.4230704E-06,2.8217574E-05,1.2017581E-07,2.2434788E-07,8.9242464E-08,7.9673122E-08,8.0049538E-05
+1080,8.6741577E-06,4.7005876E-06,2.7231619E-06,2.9968534E-05,1.2732839E-07,2.1742704E-07,7.600631E-08,7.6815088E-08,8.0123727E-05
+1081,8.3784913E-06,4.8617713E-06,3.1231788E-06,3.1938488E-05,1.4604443E-07,2.283314E-07,9.0652126E-08,6.9451923E-08,7.1809012E-05
+1082,8.1001442E-06,5.0624893E-06,3.5239312E-06,3.3912035E-05,1.6479489E-07,2.4104105E-07,1.0550282E-07,6.2075003E-08,6.3478777E-05
+1083,7.8033706E-06,5.0278878E-06,3.9823091E-06,3.6321575E-05,1.7377315E-07,2.3054098E-07,9.1532158E-08,6.820841E-08,6.5554507E-05
+1084,7.5060351E-06,4.953897E-06,4.4415275E-06,3.8951907E-05,1.8257139E-07,2.2002112E-07,7.7535513E-08,7.4353038E-08,6.7633961E-05
+1085,7.2260685E-06,5.0371729E-06,4.7306007E-06,4.0720634E-05,2.043542E-07,2.1485277E-07,7.2254831E-08,7.383254E-08,7.0053939E-05
+1086,7.1609396E-06,5.159983E-06,5.0201993E-06,4.2492554E-05,2.2617685E-07,2.0967452E-07,6.7142854E-08,7.3310956E-08,7.281537E-05
+1087,7.0956785E-06,5.4407125E-06,5.3674235E-06,4.5786657E-05,2.5788218E-07,1.9372393E-07,5.2905812E-08,6.7673434E-08,6.7483722E-05
+1088,7.0302852E-06,5.7219499E-06,5.7438544E-06,4.908675E-05,2.8964545E-07,1.7684594E-07,3.8642461E-08,6.2025414E-08,6.1804411E-05
+1089,6.9647596E-06,5.727209E-06,6.0351602E-06,5.1958035E-05,3.1357793E-07,1.6263216E-07,5.4077543E-08,5.9323204E-08,5.7804743E-05
+1090,6.8991019E-06,5.7720024E-06,6.3269914E-06,5.5052109E-05,3.3755387E-07,1.4839198E-07,6.9720136E-08,5.6418659E-08,5.3797626E-05
+1091,6.7972523E-06,5.9751505E-06,6.1608648E-06,5.8805163E-05,3.7540395E-07,1.3448546E-07,8.0547714E-08,6.3381135E-08,4.1655212E-05
+1092,6.7132507E-06,6.1786613E-06,5.9657417E-06,6.2565004E-05,4.1530047E-07,1.207334E-07,9.1574581E-08,7.0553909E-08,2.9185375E-05
+1093,6.611021E-06,6.3825347E-06,5.8563739E-06,6.8077202E-05,4.414134E-07,1.0244682E-07,8.2312874E-08,6.0530159E-08,3.0399585E-05
+1094,6.5085929E-06,6.5867709E-06,5.7180621E-06,7.3599381E-05,4.6955466E-07,8.4126576E-08,7.3034066E-08,5.0487949E-08,3.1582009E-05
+1095,6.4240625E-06,6.8310854E-06,5.1193237E-06,8.1098901E-05,4.8386525E-07,8.2577227E-08,1.1325226E-07,5.9055535E-08,2.9979348E-05
+1096,6.3937043E-06,7.0758351E-06,4.5482687E-06,8.8830791E-05,5.0018606E-07,8.1205767E-08,1.535438E-07,6.7440332E-08,2.8373708E-05
+1097,6.381409E-06,7.559749E-06,4.3507291E-06,9.9861575E-05,5.2249587E-07,7.440094E-08,2.2367139E-07,5.4398562E-08,2.7956917E-05
+1098,6.3509351E-06,8.0445334E-06,4.1528219E-06,0.00011113152,5.4484553E-07,6.7583573E-08,2.9248223E-07,4.1134186E-08,2.7505235E-05
+1099,6.3385571E-06,8.0917206E-06,3.7524898E-06,0.00012549334,5.6126413E-07,6.1660435E-08,3.8129602E-07,4.8530833E-08,1.4089229E-05
+1100,6.3261461E-06,8.1389804E-06,3.3225306E-06,0.0001401007,5.7771171E-07,5.5726406E-08,4.6846222E-07,5.5940872E-08,6.7607887E-07
Modified: grass/branches/releasebranch_7_4/imagery/i.atcorr/transform.cpp
--- grass/branches/releasebranch_7_4/imagery/i.atcorr/transform.cpp 2018-03-24 16:42:50 UTC (rev 72556)
+++ grass/branches/releasebranch_7_4/imagery/i.atcorr/transform.cpp 2018-03-24 16:50:40 UTC (rev 72557)
@@ -150,9 +150,11 @@
float rapp = idn;
float ainrpix = ti.ainr[0][0];
float xa = 0.0f;
float xb = 0.0f;
float xc = 0.0f;
float rog = rapp / ti.tgasm;
/* The if below was added to avoid ground reflectances lower than
zero when ainr(1,1) greater than rapp/tgasm
@@ -176,9 +178,11 @@
rog = (rog - ainrpix / ti.tgasm) / ti.sutott / ti.sdtott;
rog = rog / (1.f + rog * ti.sast);
xa = (float)M_PI * ti.sb / ti.xmus / ti.seb / ti.tgasm / ti.sutott / ti.sdtott;
xb = ti.srotot / ti.sutott / ti.sdtott / ti.tgasm;
xc = ti.sast;
if (rog > 1) rog = 1;
if (rog < 0) rog = 0;
