[GRASS-SVN] r72570 - grass/trunk/scripts/r.in.srtm
svn_grass at osgeo.org
Sun Mar 25 06:52:33 PDT 2018
Author: lucadelu
Date: 2018-03-25 06:52:33 -0700 (Sun, 25 Mar 2018)
New Revision: 72570
grass/trunk/scripts/r.in.srtm/r.in.srtm.py
r.in.srtm: removed unzip dependencies, now it uses zipfile library
Modified: grass/trunk/scripts/r.in.srtm/r.in.srtm.py
--- grass/trunk/scripts/r.in.srtm/r.in.srtm.py 2018-03-25 13:37:23 UTC (rev 72569)
+++ grass/trunk/scripts/r.in.srtm/r.in.srtm.py 2018-03-25 13:52:33 UTC (rev 72570)
@@ -6,6 +6,7 @@
# AUTHOR(S): Markus Neteler 11/2003 neteler AT itc it
# Hamish Bowman
# Glynn Clements
+# Luca Delucchi
# PURPOSE: import of SRTM hgt files into GRASS
# COPYRIGHT: (C) 2004, 2006 by the GRASS Development Team
@@ -22,6 +23,9 @@
# April 2006: links updated from ftp://e0dps01u.ecs.nasa.gov/srtm/
# to current links below
# October 2008: Converted to Python by Glynn Clements
+# March 2018: Added capabilities to import SRTM SWBD
+# Removed unzip dependencies, now it use Python zipfile library
+# by Luca Delucchi
# Derived from:
# ftp://e0srp01u.ecs.nasa.gov/srtm/version1/Documentation/Notes_for_ARCInfo_users.txt
@@ -129,6 +133,7 @@
import atexit
import grass.script as grass
from grass.exceptions import CalledModuleError
+import zipfile as zfile
# i18N
import gettext
@@ -183,15 +188,8 @@
hgtfile = "{im}{su}".format(im=infile, su=suff)
if os.path.isfile(zipfile):
- # check if we have unzip
- if not grass.find_program('unzip'):
- grass.fatal(_('The "unzip" program is required, please install it first'))
# really a ZIP file?
- # make it quiet in a safe way (just in case -qq isn't portable)
- tenv = os.environ.copy()
- tenv['UNZIP'] = '-qq'
- if grass.call(['unzip', '-t', zipfile], env=tenv) != 0:
+ if not zfile.is_zipfile(zipfile):
grass.fatal(_("'%s' does not appear to be a valid zip file.") % zipfile)
is_zip = True
@@ -226,7 +224,10 @@
if is_zip:
# unzip & rename data file:
grass.message(_("Extracting '%s'...") % infile)
- if grass.call(['unzip', zipfile], env=tenv) != 0:
+ try:
+ zf=zfile.ZipFile(zipfile)
+ zf.extractall()
+ except:
grass.fatal(_("Unable to unzip file."))
grass.message(_("Converting input file to BIL..."))
