[GRASS-SVN] r72584 - grass-addons/grass7/vector/v.surf.nnbathy
svn_grass at osgeo.org
Thu Mar 29 06:20:37 PDT 2018
Author: robertomarzocchi
Date: 2018-03-29 06:20:37 -0700 (Thu, 29 Mar 2018)
New Revision: 72584
grass-addons/grass7/vector/v.surf.nnbathy/nnbathy.py
Correct problem related to computational region (lat/lon) location, v.out.ascii "r" flag and string concatenation.
Modified: grass-addons/grass7/vector/v.surf.nnbathy/nnbathy.py
--- grass-addons/grass7/vector/v.surf.nnbathy/nnbathy.py 2018-03-28 20:16:45 UTC (rev 72583)
+++ grass-addons/grass7/vector/v.surf.nnbathy/nnbathy.py 2018-03-29 13:20:37 UTC (rev 72584)
@@ -15,18 +15,26 @@
def region(self):
# set the computive region
- reg = grass.read_command("g.region", flags='p')
- kv = grass.parse_key_val(reg, sep=':')
- reg_N = float(kv['north'])
- reg_W = float(kv['west'])
- reg_S = float(kv['south'])
- reg_E = float(kv['east'])
+ #reg = grass.read_command("g.region", flags='p')
+ #kv = grass.parse_key_val(reg, sep=':')
+ kv = grass.region()
+ #reg_N = float(kv['north'])
+ #reg_W = float(kv['west'])
+ #reg_S = float(kv['south'])
+ #reg_E = float(kv['east'])
+ #nsres = float(kv['nsres'])
+ #ewres = float(kv['ewres'])
+ reg_N = float(kv['n'])
+ reg_W = float(kv['w'])
+ reg_S = float(kv['s'])
+ reg_E = float(kv['e'])
# set variables
self.cols = int(kv['cols'])
- self.rows = int(kv['rows'])
+ self.rows = int(kv['rows'])
self.area = (reg_N-reg_S)*(reg_E-reg_W)
self.ALG = 'nn'
@@ -130,14 +138,17 @@
_column = options['column']
else:
grass.message('Name of z column required for 2D vector maps.')
# convert vector to ASCII
- grass.run_command("v.out.ascii", flags='r', overwrite=1,
+ grass.run_command("v.out.ascii", overwrite=1,
input=options['input'], output=self._tmpcat,
format="point", separator="space", precision=15,
where=options['where'], layer=_layer,
columns=_column)
+# grass.run_command("v.out.ascii", flags='r', overwrite=1,
+# input=options['input'], output=self._tmpcat,
+# format="point", separator="space", precision=15,
+# where=options['where'], layer=_layer,
+# columns=_column
# edit ASCII file, crop out one column
if int(options['layer']) > 0:
fin = open(self._tmpcat, 'r')
@@ -145,7 +156,17 @@
try:
for line in fin:
parts = line.split(" ")
- fout.write(parts[0]+' '+parts[1]+' '+parts[3])
+ from grass.pygrass.vector import VectorTopo
+ pnt = VectorTopo(options['input'])
+ pnt.open(mode='r')
+ check=pnt.read(1)
+ if check.is2D==True:
+ #fout.write(parts[0]+' '+parts[1]+' '+parts[3])
+ fout.write('{} {} {}'.format(parts[0],parts[1],parts[3]))
+ else:
+ #fout.write(parts[0]+' '+parts[1]+' '+parts[4])
+ fout.write('{} {} {}'.format(parts[0],parts[1],parts[4]))
+ pnt.close()
except StandardError, e:
grass.fatal_error("Invalid input: %s" % e)
fin.close()
