[GRASS-SVN] r72673 - grass/branches/releasebranch_7_4/raster/r.contour
svn_grass at osgeo.org
Fri May 4 13:05:32 PDT 2018
Author: mmetz
Date: 2018-05-04 13:05:32 -0700 (Fri, 04 May 2018)
New Revision: 72673
grass/branches/releasebranch_7_4/raster/r.contour/cont.c
grass/branches/releasebranch_7_4/raster/r.contour/main.c
r.contour: avoid tracing back of contour lines (backport trunk r72668)
Modified: grass/branches/releasebranch_7_4/raster/r.contour/cont.c
--- grass/branches/releasebranch_7_4/raster/r.contour/cont.c 2018-05-04 17:18:05 UTC (rev 72672)
+++ grass/branches/releasebranch_7_4/raster/r.contour/cont.c 2018-05-04 20:05:32 UTC (rev 72673)
@@ -92,6 +92,7 @@
hit[i][j] = 0;
/* check each cell of top and bottom borders */
for (startrow = 0; startrow < nrow; startrow += (nrow - 2)) {
for (startcol = 0; startcol <= ncol - 2; startcol++) {
@@ -113,14 +114,14 @@
if (checkedge(current.z[p1], current.z[p2], level)) {
getpoint(¤t, level, Cell, Points);
/* while not off an edge, follow line */
- while (!outside) {
- hit[current.r][current.c] +=
+ while (!outside && !hit[current.r][current.c]) {
+ hit[current.r][current.c] |=
findcrossing(¤t, level, Cell, Points,
&ncrossing);
newedge(¤t);
outside = getnewcell(¤t, nrow, ncol, z);
- if ((n_cut <= 0) || ((Points->n_points) > n_cut)) {
+ if ((n_cut <= 0) || ((Points->n_points) >= n_cut)) {
Vect_reset_cats(Cats);
Vect_cat_set(Cats, 1, n + 1);
Vect_write_line(&Map, GV_LINE, Points, Cats);
@@ -150,14 +151,14 @@
&ncrossing);
newedge(¤t);
@@ -180,7 +181,7 @@
if (!outside &&
checkedge(current.z[0], current.z[1], level)) {
&ncrossing);
newedge(¤t);
@@ -187,17 +188,17 @@
/* while not back to starting point, follow line */
- while (!outside &&
+ while (!outside && !hit[current.r][current.c] &&
((current.edge != 0) ||
((current.r != startrow) ||
(current.c != startcol)))) {
&ncrossing);
newedge(¤t);
@@ -378,8 +379,11 @@
y = Cell.north - (y + .5) * Cell.ns_res;
x = Cell.west + (x + .5) * Cell.ew_res;
- Vect_append_point(Points, x, y, level);
+ if (Points->n_points == 0 || (Points->n_points > 0 &&
+ (Points->x[Points->n_points - 1] != x ||
+ Points->y[Points->n_points - 1] != y))) {
+ Vect_append_point(Points, x, y, level);
Modified: grass/branches/releasebranch_7_4/raster/r.contour/main.c
--- grass/branches/releasebranch_7_4/raster/r.contour/main.c 2018-05-04 17:18:05 UTC (rev 72672)
+++ grass/branches/releasebranch_7_4/raster/r.contour/main.c 2018-05-04 20:05:32 UTC (rev 72673)
@@ -127,7 +127,7 @@
cut->key = "cut";
cut->type = TYPE_INTEGER;
cut->required = NO;
- cut->answer = "0";
+ cut->answer = "2";
cut->description =
_("Minimum number of points for a contour line (0 -> no limit)");
