[GRASS-SVN] r72684 - grass/trunk/raster/r.to.vect/testsuite
Fri May 4 20:27:58 PDT 2018
Author: annakrat
Date: 2018-05-04 20:27:58 -0700 (Fri, 04 May 2018)
New Revision: 72684
   grass/trunk/raster/r.to.vect/testsuite/test_r_to_vect.py
r.to.vect: fix failed test due to inconsistent use of tabs and spaces
Modified: grass/trunk/raster/r.to.vect/testsuite/test_r_to_vect.py
--- grass/trunk/raster/r.to.vect/testsuite/test_r_to_vect.py	2018-05-05 03:16:50 UTC (rev 72683)
+++ grass/trunk/raster/r.to.vect/testsuite/test_r_to_vect.py	2018-05-05 03:27:58 UTC (rev 72684)
@@ -1,28 +1,28 @@
 Purpose:    Tests r.to.vect and its flags/options.
 Author:     Sunveer Singh, Google Code-in 2017
 Copyright:  (C) 2017 by Sunveer Singh and the GRASS Development Team
 Licence:    This program is free software under the GNU General Public
-	            License (>=v2). Read the file COPYING that comes with GRASS
-	            for details.
+            License (>=v2). Read the file COPYING that comes with GRASS
+            for details.
 from grass.gunittest.case import TestCase
 from grass.gunittest.main import test
-from grass.gunittest.gmodules import SimpleModule
 class Testrr(TestCase):
-    input='lakes'
-    output='testrtovect'
-    point='point'
-    area="area"
+    input = 'lakes'
+    output = 'testrtovect'
+    point = 'point'
+    area = "area"
     @classmethod
     def setUpClass(cls):
         cls.use_temp_region()
         cls.runModule('g.region', raster=cls.input)
     @classmethod
     def tearDownClass(cls):
         cls.del_temp_region()
@@ -32,28 +32,29 @@
     def test_flags(self):
         """Testing flag s"""
-        self.assertModule('r.to.vect', input=self.input, output=self.output, type=self.point, flags='s')
+        self.assertModule('r.to.vect', input=self.input, output=self.output, type=self.point, flags='s')
         topology = dict(points=36011, lines=0, areas=0)
-	self.assertVectorFitsTopoInfo(self.output, topology)
+        self.assertVectorFitsTopoInfo(self.output, topology)
     def test_flagz(self):
         """Testing flag z"""
-        self.assertModule('r.to.vect', input=self.input, output=self.output, type=self.point, flags='z')
+        self.assertModule('r.to.vect', input=self.input, output=self.output, type=self.point, flags='z')
     def test_flagb(self):
         """Testing flag b"""
-        self.assertModule('r.to.vect', input=self.input, output=self.output, type=self.area, flags='b')
+        self.assertModule('r.to.vect', input=self.input, output=self.output, type=self.area, flags='b')
         topology = dict(points=0, lines=0, areas=0)
     def test_flagt(self):
         """Testing flag t"""
-        self.assertModule('r.to.vect', input=self.input, output=self.output, type=self.area, flags='t')
+        self.assertModule('r.to.vect', input=self.input, output=self.output, type=self.area, flags='t')
         topology = dict(points=0, lines=0, areas=33)
 if __name__ == '__main__':
     test()
