[GRASS-SVN] r72694 - grass/branches/releasebranch_7_4/vector/v.out.ogr
svn_grass at osgeo.org
Mon May 7 05:40:16 PDT 2018
Author: mmetz
Date: 2018-05-07 05:40:16 -0700 (Mon, 07 May 2018)
New Revision: 72694
grass/branches/releasebranch_7_4/vector/v.out.ogr/export_areas.c
grass/branches/releasebranch_7_4/vector/v.out.ogr/export_lines.c
v.out.ogr: create and write a new feature only once to avoid duplicate fid's, check return of OGR_L_CreateFeature() (backport trunk r72693)
Modified: grass/branches/releasebranch_7_4/vector/v.out.ogr/export_areas.c
--- grass/branches/releasebranch_7_4/vector/v.out.ogr/export_areas.c 2018-05-07 12:35:46 UTC (rev 72693)
+++ grass/branches/releasebranch_7_4/vector/v.out.ogr/export_areas.c 2018-05-07 12:40:16 UTC (rev 72694)
@@ -78,9 +78,6 @@
/* create polygon from area */
Ogr_geometry = create_polygon(In, area, Points);
- /* add feature */
- Ogr_feature = OGR_F_Create(Ogr_featuredefn);
- OGR_F_SetGeometry(Ogr_feature, Ogr_geometry);
/* output one feature for each category */
for (i = -1; i < Cats->n_cats; i++) {
@@ -96,14 +93,21 @@
continue;
+ /* add feature */
+ Ogr_feature = OGR_F_Create(Ogr_featuredefn);
+ OGR_F_SetGeometry(Ogr_feature, Ogr_geometry);
mk_att(cat, Fi, driver, ncol, colctype, colname, doatt, nocat,
Ogr_feature, n_noatt);
- OGR_L_CreateFeature(Ogr_layer, Ogr_feature);
- n_exported++;
+ if (OGR_L_CreateFeature(Ogr_layer, Ogr_feature) != OGRERR_NONE ) {
+ G_warning(_("Failed to create OGR feature"));
+ else
+ n_exported++;
+ OGR_F_Destroy(Ogr_feature);
OGR_G_DestroyGeometry(Ogr_geometry);
- OGR_F_Destroy(Ogr_feature);
Vect_destroy_line_struct(Points);
@@ -196,11 +200,13 @@
+ else
+ n_exported++;
- n_exported++;
else {
/* skip empty features */
@@ -245,11 +251,13 @@
+ else
+ n_exported++;
- n_exported++;
else {
Modified: grass/branches/releasebranch_7_4/vector/v.out.ogr/export_lines.c
--- grass/branches/releasebranch_7_4/vector/v.out.ogr/export_lines.c 2018-05-07 12:35:46 UTC (rev 72693)
+++ grass/branches/releasebranch_7_4/vector/v.out.ogr/export_lines.c 2018-05-07 12:40:16 UTC (rev 72694)
@@ -110,11 +110,7 @@
- /* create feature & set geometry */
/* output one feature for each category, export also features
* without category (cat = -1) */
for (j = -1; j < Cats->n_cats; j++) {
@@ -130,14 +126,20 @@
continue;
+ /* add feature */
+ else
+ n_exported++;
- n_exported++;
@@ -225,11 +227,13 @@
+ else
+ n_exported++;
- n_exported++;
else {
@@ -272,11 +276,13 @@
+ else
+ n_exported++;
- n_exported++;
else {
