[GRASS-SVN] r72699 - grass/trunk/raster3d
svn_grass at osgeo.org
Tue May 8 13:55:07 PDT 2018
Author: neteler
Date: 2018-05-08 13:55:07 -0700 (Tue, 08 May 2018)
New Revision: 72699
grass/trunk/raster3d/raster3dintro.html
raster3dintro manual: more details and better structure for section: 3D raster import
Modified: grass/trunk/raster3d/raster3dintro.html
--- grass/trunk/raster3d/raster3dintro.html 2018-05-08 13:38:21 UTC (rev 72698)
+++ grass/trunk/raster3d/raster3dintro.html 2018-05-08 20:55:07 UTC (rev 72699)
@@ -87,25 +87,34 @@
<h3>3D raster import</h3>
+<h4>Import from external files</h4>
The modules <a href="r3.in.ascii.html">r3.in.ascii</a> and
<a href="r3.in.bin.html">r3.in.bin</a> supports
generic x,y,z ASCII and binary array import.
-Alternatively, 3D rasters can be generated
-from 3D point vector data (<a href="v.to.rast3.html">v.to.rast3</a>).
-Always the full map is imported.
-3D raster can also be created based on 2D elevation map(s) and value raster map(s)
-(<a href="r.to.rast3elev.html">r.to.rast3elev</a>). Alternatively,
-a 3D raster can be composed of several 2D raster maps.
-2D rasters are considered as slices in this case and
-merged into one 3D raster map (<a href="r.to.rast3.html">r.to.rast3</a>).
<p>
-Import of 3D points and their statistics can be done using
+In case of CSV tables, the modules <a href="v.in.ascii.html">v.in.ascii</a>
+(using the <b>-z</b> flag) may be a choice to first import the 3D points
+as vector points and the convert them to 3D raster (see below).
+<p>
+Import of 3D (LiDAR) points and their statistics can be done using
<a href="r3.in.lidar.html">r3.in.lidar</a> for LiDAR data and
<a href="r3.in.xyz.html">r3.in.xyz</a> for CSV and other ASCII text
formats.
+<h4>Conversion from 3D vector points</h4>
+3D rasters can be generated from 3D point vector data
+(<a href="v.to.rast3.html">v.to.rast3</a>). Always the full map is imported.
+<h4>Conversion from 2D raster maps</h4>
+3D raster can also be created based on 2D elevation map(s) and value raster map(s)
+(<a href="r.to.rast3elev.html">r.to.rast3elev</a>). Alternatively,
+a 3D raster can be composed of several 2D raster maps (stack of maps).
+2D rasters are considered as slices in this case and
+merged into one 3D raster map (<a href="r.to.rast3.html">r.to.rast3</a>).
<h3>3D region settings and 3D MASK</h3>
GRASS GIS 3D raster map processing is always performed in the current 3D region
