[GRASS-SVN] r72730 - in grass-addons/grass7/imagery/i.ann.maskrcnn: . i.ann.maskrcnn.detect i.ann.maskrcnn.train maskrcnnlib
Tue May 22 04:53:59 PDT 2018
Author: pesekon2
Date: 2018-05-22 04:53:59 -0700 (Tue, 22 May 2018)
New Revision: 72730
Added:
   grass-addons/grass7/imagery/i.ann.maskrcnn/Makefile
   grass-addons/grass7/imagery/i.ann.maskrcnn/i.ann.maskrcnn.detect/
   grass-addons/grass7/imagery/i.ann.maskrcnn/i.ann.maskrcnn.detect/Makefile
   grass-addons/grass7/imagery/i.ann.maskrcnn/i.ann.maskrcnn.detect/i.ann.maskrcnn.detect.html
   grass-addons/grass7/imagery/i.ann.maskrcnn/i.ann.maskrcnn.detect/i.ann.maskrcnn.detect.py
   grass-addons/grass7/imagery/i.ann.maskrcnn/i.ann.maskrcnn.html
   grass-addons/grass7/imagery/i.ann.maskrcnn/i.ann.maskrcnn.train/
   grass-addons/grass7/imagery/i.ann.maskrcnn/i.ann.maskrcnn.train/Makefile
   grass-addons/grass7/imagery/i.ann.maskrcnn/i.ann.maskrcnn.train/i.ann.maskrcnn.train.html
   grass-addons/grass7/imagery/i.ann.maskrcnn/i.ann.maskrcnn.train/i.ann.maskrcnn.train.py
   grass-addons/grass7/imagery/i.ann.maskrcnn/maskrcnnlib/
   grass-addons/grass7/imagery/i.ann.maskrcnn/maskrcnnlib/Makefile
   grass-addons/grass7/imagery/i.ann.maskrcnn/maskrcnnlib/__init__.py
   grass-addons/grass7/imagery/i.ann.maskrcnn/maskrcnnlib/config.py
   grass-addons/grass7/imagery/i.ann.maskrcnn/maskrcnnlib/model.py
   grass-addons/grass7/imagery/i.ann.maskrcnn/maskrcnnlib/parallel_model.py
   grass-addons/grass7/imagery/i.ann.maskrcnn/maskrcnnlib/utils.py
i.ann.maskrcnn initial commit
Added: grass-addons/grass7/imagery/i.ann.maskrcnn/Makefile
--- grass-addons/grass7/imagery/i.ann.maskrcnn/Makefile	                        (rev 0)
+++ grass-addons/grass7/imagery/i.ann.maskrcnn/Makefile	2018-05-22 11:53:59 UTC (rev 72730)
@@ -0,0 +1,14 @@
+MODULE_TOPDIR =../../..
+PGM = i.ann.maskrcnn
+SUBDIRS = maskrcnnlib \
+	i.ann.maskrcnn.train \
+	i.ann.maskrcnn.detect \
+include $(MODULE_TOPDIR)/include/Make/Dir.make
+default: parsubdirs htmldir
+install: installsubdirs
+	$(INSTALL_DATA) $(PGM).html $(INST_DIR)/docs/html/
Added: grass-addons/grass7/imagery/i.ann.maskrcnn/i.ann.maskrcnn.detect/Makefile
--- grass-addons/grass7/imagery/i.ann.maskrcnn/i.ann.maskrcnn.detect/Makefile	                        (rev 0)
+++ grass-addons/grass7/imagery/i.ann.maskrcnn/i.ann.maskrcnn.detect/Makefile	2018-05-22 11:53:59 UTC (rev 72730)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../../..
+PGM = i.ann.maskrcnn.detect
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Added: grass-addons/grass7/imagery/i.ann.maskrcnn/i.ann.maskrcnn.detect/i.ann.maskrcnn.detect.html
--- grass-addons/grass7/imagery/i.ann.maskrcnn/i.ann.maskrcnn.detect/i.ann.maskrcnn.detect.html	                        (rev 0)
+++ grass-addons/grass7/imagery/i.ann.maskrcnn/i.ann.maskrcnn.detect/i.ann.maskrcnn.detect.html	2018-05-22 11:53:59 UTC (rev 72730)
@@ -0,0 +1,83 @@
+<h2>DESCRIPTION</h2>
+<em>i.ann.maskrcnn.detect</em> allows the user to use a Mask R-CNN model to
+detect features in GRASS GIS raster maps or georeferenced files and extract
+them either as areas or points. The module creates a separate map for each
+class.
+<h2>NOTES</h2>
+<p>
+The detection may be used for raster maps imported in GRASS GIS or for external
+files (or using both). To use raster maps in GRASS GIS, you need to pass them
+in three bands following the order used during the training, e.g. if the
+training has been made on RGB images, use <em>band1=*.red</em>,
+<em>band1=*.green</em> and <em>band3=*.blue</em>. To pass multiple images, put
+more maps into <em>band*</em> parameters, divided by ",".
+<p>
+The detection may be used also for multiple external files. However, all files
+for the detection must be in one directory specified in the
+<em>images_directory</em> parameter. Even when using only one image, the module
+finds it through this parameter.
+<p>
+When detecting, you can use new names of classes. Classes in the model are not
+referenced by their name, but by their order. It means that if the model was
+trained with classes <em>corn,rice</em> and you use
+<em>i.ann.maskrcnn.detect</em> with classes <em>zea,oryza</em>, zea areas will
+present areas detected as corn and oryza areas will present areas detected as
+rice.
+<p>
+If the external file is georeferenced externally (by a worldfile or an
+<em>.aux.xml</em> file), please use <em>-e</em> flag.
+<h2>EXAMPLES</h2>
+<h3>Detect buildings and lakes and import them as areas</h3>
+<p>
+One map imported in GRASS GIS:
+<div class="code"><pre>
+i.ann.maskrcnn.detect band1=map1.red band2=map1.green band3=map1.blue classes=buildings,lakes model=/home/user/Documents/logs/mask_rcnn_buildings_lakes_0100.h5
+</pre></div>
+<p>
+Two maps (map1, map2) imported in GRASS GIS:
+i.ann.maskrcnn.detect band1=map1.red,map2.red band2=map1.green,map2.green band3=map1.blue,map2.blue classes=buildings,lakes model=/home/user/Documents/logs/mask_rcnn_buildings_lakes_0100.h5
+</pre></div>
+<p>
+External files, the georeferencing is internal (GeoTIFF):
+i.ann.maskrcnn.detect images_directory=/home/user/Documents/georeferenced_images classes=buildings,lakes model=/home/user/Documents/logs/mask_rcnn_buildings_lakes_0100.h5 images_format=tif
+</pre></div>
+<p>
+External files, the georeferencing is external:
+i.ann.maskrcnn.detect images_directory=/home/user/Documents/georeferenced_images classes=buildings,lakes model=/home/user/Documents/logs/mask_rcnn_buildings_lakes_0100.h5 images_format=png -e
+</pre></div>
+<h3>Detect cottages and plattenbaus and import them as points</h3>
+i.ann.maskrcnn.detect band1=map1.red band2=map1.green band3=map1.blue classes=buildings,lakes model=/home/user/Documents/logs/mask_rcnn_buildings_lakes_0100.h5 output_type=point
+</pre></div>
+<h2>SEE ALSO</h2>
+<em>
+    <a href="maskrcnn.html">Mask R-CNN in GRASS GIS</a>
+    <a href="i.ann.maskrcnn.train.html">i.ann.maskrcnn.train</a>
+</em>
+<h2>AUTHORS</h2>
+Ondrej Pesek
Added: grass-addons/grass7/imagery/i.ann.maskrcnn/i.ann.maskrcnn.detect/i.ann.maskrcnn.detect.py
--- grass-addons/grass7/imagery/i.ann.maskrcnn/i.ann.maskrcnn.detect/i.ann.maskrcnn.detect.py	                        (rev 0)
+++ grass-addons/grass7/imagery/i.ann.maskrcnn/i.ann.maskrcnn.detect/i.ann.maskrcnn.detect.py	2018-05-22 11:53:59 UTC (rev 72730)
@@ -0,0 +1,596 @@
+#!/usr/bin/env python3
+# MODULE:	    i.ann.maskrcnn.detect
+# AUTHOR(S):	Ondrej Pesek <pesej.ondrek at gmail.com>
+# PURPOSE:	    Train your Mask R-CNN network
+# COPYRIGHT:	(C) 2017 Ondrej Pesek and the GRASS Development Team
+#		This program is free software under the GNU General
+#		Public License (>=v2). Read the file COPYING that
+#		comes with GRASS for details.
+#%module
+#% description: Detect features in images using a Mask R-CNN model
+#% keyword: ann
+#% keyword: vector
+#% keyword: raster
+#%end
+#%flag
+#%  key: e
+#%  description: External georeferencing in the images folder (when using images_directory)
+#%end
+#%option
+#% key: band1
+#% type: string
+#% label: Name of raster maps to use for detection as the first band (divided by ",")
+#%end
+#%option
+#% key: band2
+#% type: string
+#% label: Name of raster maps to use for detection as the second band (divided by ",")
+#%end
+#%option
+#% key: band3
+#% type: string
+#% label: Name of raster maps to use for detection as the third band (divided by ",")
+#%end
+#%option G_OPT_M_DIR
+#% key: images_directory
+#% label: Path to a directory with external images to detect
+#% required: no
+#%end
+#%option
+#% key: images_format
+#% type: string
+#% label: Format suffix of images
+#% description: .jpg, .tiff, .png, etc.
+#%end
+#%option
+#% key: model
+#% type: string
+#% label: Path to the .h5 file containing the model
+#% required: yes
+#% multiple: no
+#%end
+#%option
+#% key: classes
+#% type: string
+#% label: Names of classes separated with ","
+#% required: yes
+#% multiple: yes
+#%end
+#%option
+#% key: output_type
+#% type: string
+#% label: Type of output
+#% options: area, point
+#% answer: area
+#% required: no
+#%end
+#%rules
+#% requires_all: images_directory, images_format
+#% requires_all: band1, band2, band3
+#% required: images_directory, band1
+#%end
+import os
+from shutil import copyfile
+import sys
+from io import BytesIO
+import numpy as np
+from skimage.measure import find_contours
+import matplotlib.pyplot as plt
+from matplotlib.patches import Polygon
+import grass.script as gscript
+from grass.script.utils import get_lib_path
+import grass.script.array as garray
+import skimage.io
+from PIL import Image
+from osgeo import gdal, osr
+path = get_lib_path(modname='maskrcnn', libname='model')
+if path is None:
+    gscript.fatal('Not able to find the maskrcnn library directory.')
+sys.path.append(path)
+def main(options, flags):
+    import model as modellib
+    from config import ModelConfig
+    try:
+        imagesDir = options['images_directory']
+        modelPath = options['model']
+        classes = options['classes'].split(',')
+        band1 = options['band1'].split(',')
+        band2 = options['band2'].split(',')
+        band3 = options['band3'].split(',')
+        outputType = options['output_type']
+        if options['images_format']:
+            extension = options['images_format']
+            if options['images_format'][0] != '.':
+                extension = '.{}'.format(extension)
+        else:
+            extension = ''
+        # a directory where masks and georeferencing will be saved in case of
+        # external images
+        masksDir = gscript.core.tempfile().rsplit(os.sep, 1)[0]
+    except KeyError:
+        # GRASS parses keys and values as bytes instead of strings
+        imagesDir = options[b'images_directory'].decode('utf-8')
+        modelPath = options[b'model'].decode('utf-8')
+        classes = options[b'classes'].decode('utf-8').split(',')
+        if options[b'band1'].decode('utf-8'):
+            band1 = options[b'band1'].decode('utf-8').split(',')
+            band2 = options[b'band2'].decode('utf-8').split(',')
+            band3 = options[b'band3'].decode('utf-8').split(',')
+        else:
+            band1 = list()
+            band2 = list()
+            band3 = list()
+        outputType = options[b'output_type'].decode('utf-8')
+        if options[b'images_format'].decode('utf-8'):
+            extension = options[b'images_format'].decode('utf-8')
+            if extension[0] != '.':
+        else:
+            extension = ''
+        newFlags = dict()
+        for flag, value in flags.items():
+            newFlags.update({flag.decode('utf-8'): value})
+        flags = newFlags
+        # external images
+        masksDir = gscript.core.tempfile().decode('utf-8').rsplit(os.sep, 1)[0]
+    if len(band1) != len(band2) or len(band2) != len(band3):
+        gscript.fatal('Length of band1, band2 and band3 must be equal.')
+    # TODO: (3 different brands in case of lot of classes?)
+    if len(classes) > 255:
+        gscript.fatal('Too many classes. Must be less than 256.')
+    if len(set(classes)) != len(classes):
+        gscript.fatal('Two or more classes have the same name.')
+    # used colour corresponds to class_id
+    classesColours = range(len(classes) + 1)
+    # Create model object in inference mode.
+    config = ModelConfig(numClasses=len(classes) + 1)
+    model = modellib.MaskRCNN(mode="inference", model_dir=modelPath,
+                              config=config)
+    model.load_weights(modelPath, by_name=True)
+    masks = list()
+    detectedClasses = list()
+    # TODO: Use the whole list instead of iteration
+    if len(band1) > 0:
+        gscript.message('Detecting features in raster maps...')
+        # using maps imported in GRASS
+        mapsCount = len(band1)
+        for i in range(mapsCount):
+            gscript.percent(i + 1, mapsCount, 1)
+            maskTitle = '{}_{}'.format(band1[i].split('.')[0], i)
+            # load map into 3-band np.array
+            gscript.run_command('g.region', raster=band1[i], quiet=True)
+            bands = np.stack((garray.array(band1[i]),
+                              garray.array(band2[i]),
+                              garray.array(band3[i])), 2)
+            # Run detection
+            results = model.detect([bands], verbosity=gscript.verbosity())
+            # Save results
+            for r in results:
+                parse_instances(bands,
+                               r['rois'],
+                               r['masks'],
+                               r['class_ids'],
+                               # ['BG'] + [i for i in classes],
+                               # r['scores'],
+                               outputDir=masksDir,
+                               which=outputType,
+                               title=maskTitle,
+                               colours=classesColours,
+                               mList=masks,
+                               cList=detectedClasses,
+                               grassMap=True)
+    if imagesDir:
+        gscript.message('Detecting features in images from the directory...')
+        for imageFile in [file for file in next(os.walk(imagesDir))[2] if
+                          os.path.splitext(file)[1] == extension]:
+            image = skimage.io.imread(os.path.join(imagesDir, imageFile))
+            if image.shape[2] > 3:
+                image = image[:, :, 0:3]
+            source = gdal.Open(os.path.join(imagesDir, imageFile))
+            sourceProj = source.GetProjection()
+            sourceTrans = source.GetGeoTransform()
+            # Run detection
+            results = model.detect([image], verbosity=gscript.verbosity())
+            # Save results
+            for r in results:
+                parse_instances(image,
+                               r['rois'],
+                               r['masks'],
+                               r['class_ids'],
+                               # r['scores'],
+                               which=outputType,
+                               title=imageFile,
+                               proj=sourceProj,
+                               trans=sourceTrans,
+                               mList=masks,
+                               externalReferencing=flags['e'])
+    if flags['e']:
+        gscript.message('Masks detected. Georeferencing masks...')
+        external_georeferencing(imagesDir, classes, masksDir, masks,
+                                detectedClasses, extension)
+    gscript.message('Converting masks to vectors...')
+    masksString = ','.join(masks)
+    for parsedClass in detectedClasses:
+        gscript.message('Processing {} map...'.format(
+            classes[parsedClass - 1]))
+        i = 0
+        for maskName in masks:
+            gscript.percent(i, len(masks), 1)
+                                raster=maskName,
+                                quiet=True)
+            gscript.run_command('r.mask',
+                                raster=maskName,
+                                maskcats=classesColours[parsedClass],
+                                quiet=True)
+            gscript.run_command('r.to.vect',
+                                's',
+                                input=maskName,
+                                output=maskName,
+                                type=outputType,
+                                quiet=True)
+                                'r',
+                                quiet=True)
+            i += 1
+        gscript.run_command('v.patch',
+                            input=masksString,
+                            output=classes[parsedClass - 1])
+        gscript.run_command('g.remove',
+                            'f',
+                            name=masksString,
+                            type='vector',
+                            quiet=True)
+                        'f',
+                        name=masksString,
+                        type='raster',
+                        quiet=True)
+def external_georeferencing(imagesDir, classes, masksDir, mList, cList,
+                            extension):
+    Find the external georeferencing and copy it to the directory with
+    the image.
+    :param imagesDir: a directory of original images
+    :param classes: a list of classes names
+    :param masksDir: intermediate directory where masks are saved
+    :param mList: list of names of imported rasters
+    :param cList: list of classes with at least one instance
+    :param extension: extension if images
+    for referencing in [file for file in next(os.walk(imagesDir))[2] if (
+                    os.path.splitext(file)[1] != extension and
+                    extension in file)]:
+        fileName, refExtension = referencing.split(extension)
+        # TODO: Join with converting to one loop
+        for i in range(1, len(classes) + 1):
+            maskName = fileName + '_' + str(i)
+            maskFileName = maskName + '.png'
+            if os.path.isfile(os.path.join(masksDir, maskFileName)):
+                if i not in cList:
+                    cList.append(i)
+                mList.append(maskName)
+                copy_georeferencing(imagesDir, masksDir, maskFileName,
+                                    refExtension, referencing)
+                gscript.run_command('r.in.gdal',
+                                    input=os.path.join(masksDir,
+                                                       maskFileName),
+                                    output=maskName,
+                                    band=1,  # TODO: 3 if 3 band masks
+                                    overwrite=gscript.overwrite(),
+                                    quiet=True)
+def copy_georeferencing(imagesDir, masksDir, maskFileName, refExtension,
+                        referencing):
+    Copy georeferencing file.
+    :param maskFileName: title given to mask during parse_instances
+    :param refExtension: extension of referencing file
+    :param referencing: path to the file containing georeferencing
+    r2 = os.path.join(masksDir, maskFileName + refExtension)
+    copyfile(os.path.join(imagesDir, referencing), r2)
+def apply_mask(image, mask, colour):
+    Apply the given mask to the image.
+    :param image: [band1, band2, band3]
+    :param mask: [height, width]
+    :param colour: integer giving corresponding to the class ID
+    :return image: A three band mask
+    for c in range(3):
+        image[:, :, c] = np.where(mask == 1,
+                                  np.zeros([image.shape[0],
+                                            image.shape[1]]) + colour[c],
+                                  image[:, :, c])
+    return image
+def parse_instances(image,
+                   boxes,
+                   masks,
+                   class_ids,
+                   # class_names,
+                   # scores=None,
+                   title="",
+                   # figsize=(16, 16),
+                   # ax=None,
+                   outputDir='',
+                   which='area',
+                   colours=None,
+                   proj=None,
+                   trans=None,
+                   mList=None,
+                   cList=None,
+                   grassMap=False,
+                   externalReferencing=None):
+    Create a raster from results of detection and import it into GRASS GIS or
+    save to a temporal directory to wait for external georeferencing.
+    :param boxes: [num_instance, (y1, x1, y2, x2, class_id)] in image
+        coordinates
+    :param masks: [height, width, num_instances]
+    :param class_ids: [num_instances]
+    :param class_names: list of class names of the dataset
+    :param scores: (optional) confidence scores for each box
+    :param title: title used for importing as a raster map
+    :param figsize: (optional) the size of the image.
+    :param outputDir: intermediate directory where masks will be saved
+    :param which: either 'area' or 'point', a representation of detections
+    :param colours: list of colours i order of class_ids
+    :param proj: projection of image
+    :param trans: geotransform of image
+    :param grassMap: boolean. True=using maps in GRASS, False=using external
+        images
+    :param externalReferencing: boolean. True=images are georeferenced by
+        an external file
+    May be extended in the future (commented parameters)
+    dpi = 80
+    height, width = image.shape[:2]
+    figsize = width / float(dpi), height / float(dpi)
+    N = boxes.shape[0]
+    if not N:
+        gscript.message(
+            "\n*** No instances to detect in image {}*** \n".format(title))
+    else:
+        assert boxes.shape[0] == masks.shape[-1] == class_ids.shape[0]
+    # Show area outside image boundaries.
+    if which == 'area':
+        for classId in set(class_ids):
+            fig = plt.figure(figsize=figsize)
+            ax = fig.add_axes([0, 0, 1, 1])
+            ax.axis('off')
+            masked_image = np.zeros(image.shape)
+            index = 0
+            for i in range(N):
+                if class_ids[i] != classId:
+                    continue
+                colour = (colours[class_ids[i]],) * 3
+                # Bounding box
+                if not np.any(boxes[i]):
+                    # Skip this instance. Has no bbox.
+                    # Likely lost in image cropping.
+                    continue
+                # Mask
+                mask = masks[:, :, i]
+                masked_image = apply_mask(masked_image, mask, colour)
+                # Mask Polygon
+                # Pad to ensure proper polygons for masks that touch image
+                # edges.
+                padded_mask = np.zeros(
+                    (mask.shape[0] + 2, mask.shape[1] + 2), dtype=np.uint8)
+                padded_mask[1:-1, 1:-1] = mask
+                contours = find_contours(padded_mask, 0.5)
+                for verts in contours:
+                    # Subtract the padding and flip (y, x) to (x, y)
+                    verts = np.fliplr(verts) - 1
+                    p = Polygon(verts, facecolor="none", edgecolor='none')
+                    ax.add_patch(p)
+                index = i
+                # TODO: write probabilities
+                # score = scores[i] if scores is not None else None
+            masked_image = masked_image.astype(np.uint8)
+            ax.imshow(masked_image, interpolation='nearest')
+            ax.set(xlim=[0, width], ylim=[height, 0], aspect=1)
+            maskName = '{}_{}'.format(os.path.splitext(title)[0],
+                                      str(class_ids[index]))
+            if not externalReferencing and not grassMap:
+                targetPath = os.path.join(
+                    outputDir,
+                    '{}{}'.format(maskName, os.path.splitext(title)[1]))
+                plt.savefig(targetPath, dpi=dpi)
+                plt.close()
+                target = gdal.Open(targetPath, gdal.GA_Update)
+                target.SetGeoTransform(trans)
+                target.SetProjection(proj)
+                target.FlushCache()
+                if class_ids[index] not in cList:
+                    cList.append(class_ids[index])
+                                    input=targetPath,
+                                    output=maskName,
+                                    quiet=True)
+            elif grassMap:
+                plt.close()
+                mask2d = garray.array(dtype=np.uint8)
+                np.copyto(mask2d, masked_image[:, :, 0])
+                mask2d.write(mapname=maskName)
+            else:
+                plt.savefig(
+                    os.path.join(
+                        outputDir,
+                        maskName),
+                    dpi=dpi)
+                # plt.show()
+                plt.close()
+    elif which == 'point':
+            ax.axis('off')
+            index = 0
+                    continue
+                ax.axis('off')
+                # Bounding box
+                    continue
+                y1, x1, y2, x2 = boxes[i]
+                masked_image[int((y1 + y2) / 2)][int((x1 + x2) / 2)] = colours[
+                    class_ids[i]]
+                index = i
+                # Label
+                # class_id = class_ids[i]
+                # label = class_names[class_id]
+            ax.imshow(masked_image.astype(np.uint8), interpolation='nearest')
+                    outputDir,
+                plt.close()
+                                    input=targetPath,
+                                    output=maskName,
+                                    quiet=True)
+            elif grassMap:
+                plt.close()
+            else:
+                plt.savefig(
+                    os.path.join(
+                        outputDir,
+                        maskName),
+                    dpi=dpi)
+                # plt.show()
+                plt.close()
+if __name__ == "__main__":
+    options, flags = gscript.parser()
+    main(options, flags)
Added: grass-addons/grass7/imagery/i.ann.maskrcnn/i.ann.maskrcnn.html
--- grass-addons/grass7/imagery/i.ann.maskrcnn/i.ann.maskrcnn.html	                        (rev 0)
+++ grass-addons/grass7/imagery/i.ann.maskrcnn/i.ann.maskrcnn.html	2018-05-22 11:53:59 UTC (rev 72730)
@@ -0,0 +1,79 @@
+<p>
+Mask R-CNN tools allow the user to train his own model and use it for
+a detection of objects, or to use a model provided by someone else. It can be
+seen as a supervised classification using convolutional neural networks.
+<p>
+The training is done using module <em>ann.maskrcnn.train</em>. The user feeds
+the module with training data consisting of images and masks for each instance
+of intended classes, and gets a model. For difficult tasks and when not using
+a pretrained model, the training may take even weeks; in case of a good
+pretrained model and powerful PC with GPU support, the training could get good
+results after 1 day and even less.
+<p>
+When the user has a model, it can be used for the detection.
+<em>ann.maskrcnn.detect</em> detects classes learned during the training and
+extracts from given images vectors corresponding to detected objects. Objects
+can be extracted either as areas or points.
+<h2>DEPENDENCIES</h2>
+<p>
+<em>ann.maskrcnn.*</em> modules contain a lot of external python dependencies.
+To run modules, it is necessary to have them installed. Modules use python3, so
+please install python3 versions.
+<p>
+<ul>
+  <li>NumPy</li>
+  <li>Pillow</li>
+  <li>SciPy</li>
+  <li>Cython</li>
+  <li>scikit-image</li>
+  <li>OSGeo</li>
+  <li>TensorFlow</li>
+  <li>Keras</li>
+  <li>h5py</li>
+</ul>
+<p>
+After dependencies are fulfilled, modules can be installed using
+<em>g.extension</em> module:
+g.extension extension=maskrcnn url=path/to/the/maskrcnn/folder
+</pre></div>
+<h2>GRASS GIS PATCH</h2>
+<p>
+Unfortunately, python3 is not fully supported by GRASS GIS yet. To use
+environment setting flags like <em>--overwrite</em>, the user has to update
+his GRASS GIS with the following patch:
+--- lib/python/script/core.py	(revision 72644)
++++ lib/python/script/core.py	(working copy)
+@@ -746,7 +746,7 @@
+         elif var.startswith(b'opt_'):
+             options[var[4:]] = val
+         elif var in [b'GRASS_OVERWRITE', b'GRASS_VERBOSE']:
+-            os.environ[var] = val
++            os.environ[var.decode("utf-8")] = val.decode("utf-8")
+         else:
+             raise SyntaxError("invalid output from g.parser: %s" % line)
+</pre></div>
+<h2>MODULES</h2>
+<em>
+    <a href="ann.maskrcnn.train.html">ann.maskrcnn.train</a>
+    <a href="ann.maskrcnn.detect.html">ann.maskrcnn.detect</a>
+</em>
+<h2>AUTHORS</h2>
+Ondrej Pesek
Added: grass-addons/grass7/imagery/i.ann.maskrcnn/i.ann.maskrcnn.train/Makefile
--- grass-addons/grass7/imagery/i.ann.maskrcnn/i.ann.maskrcnn.train/Makefile	                        (rev 0)
+++ grass-addons/grass7/imagery/i.ann.maskrcnn/i.ann.maskrcnn.train/Makefile	2018-05-22 11:53:59 UTC (rev 72730)
@@ -0,0 +1,7 @@
+PGM = i.ann.maskrcnn.train
+default: script
Added: grass-addons/grass7/imagery/i.ann.maskrcnn/i.ann.maskrcnn.train/i.ann.maskrcnn.train.html
--- grass-addons/grass7/imagery/i.ann.maskrcnn/i.ann.maskrcnn.train/i.ann.maskrcnn.train.html	                        (rev 0)
+++ grass-addons/grass7/imagery/i.ann.maskrcnn/i.ann.maskrcnn.train/i.ann.maskrcnn.train.html	2018-05-22 11:53:59 UTC (rev 72730)
@@ -0,0 +1,153 @@
+<em>i.ann.maskrcnn.train</em> allows the user to train a Mask R-CNN model on
+his own dataset. The dataset has to be prepared in a predefined structure.
+<h3>DATASET STRUCTURE</h3>
+<p>
+Training dataset should be in the following structure:
+<p>
+dataset-directory
+    <ul>
+      <li>imagenumber
+	  <ul>
+          <li>imagenumber.jpg (training image)</li>
+          <li>imagenumber-class1-number.png (mask for one instance of class1)</li>
+          <li>imagenumber-class1-number.png (mask for another instance of class1)</li>
+          <li>...</li>
+	  </ul>
+	  </li>
+	  <li>imagenumber2
+	  <ul>
+         <li>imagenumber2.jpg</li>
+	     <li>imagenumber2-class1-number.png (mask for one instance of class1)</li>
+	     <li>imagenumber2-class2-number.png (mask for another class instance)</li>
+	     <li>...</li>
+      </ul>
+    </ul>
+<p>
+files with 3 channels (for example RGB), masks must be *.png files consisting
+of numbers between 1 and 255 (object instance) and 0s (elsewhere). A mask file
+for each instance of an object should be provided separately distinguished by
+the suffix number.
+<h2>NOTES</h2>
+<p>
+If you are using initial weights (the <em>model</em> parameter), epochs are
+divided into three segments. Firstly training layers 5+, then fine-tuning
+layers 4+ and the last segment is fine-tuning the whole architecture.
+Ending number of epochs is shown for your segment, not for the whole training.
+<p>
+The usage of the <em>-b</em> flag will result in an activation of batch
+normalization layers training. By default, this option is set to False, as it
+is not recommended to train them when using just small batches (batch is
+defined by the <em>images_per_gpu</em> parameter).
+<p>
+If the dataset consists of images of the same size, the user may use the
+<em>-n</em> flag to avoid resizing or padding of images. When the flag is not
+used, images are resized to have their longer side equal to the value of the
+<em>images_max_dim</em> parameter and the shorter side longer or equal to the
+value of the <em>images_min_dim</em> parameter and zero-padded to be of shape
+<div class="code">images_max_dim x images_max_dim</div>. It results in the fact
+that even images of different sizes may be used.
+<p>
+After each epoch, the current model is saved. It allows the user to stop the
+training when he feels satisfied with loss functions. It also allows the user to
+test models even during the training (and, again, stop it even before the last
+epoch).
+<h2>EXAMPLES</h2>
+<p>
+Dataset for examples:
+<p>
+crops
+     <ul>
+        <li>000000
+         <ul>
+          <li>000000.jpg</li>
+          <li>000000-corn-0.png</li>
+          <li>000000-corn-1.png</li>
+          <li>...</li>
+         </ul>
+        </li>
+        <li>000001
+         <ul>
+            <li>000001.jpg</li>
+            <li>000001-corn-0.png</li>
+            <li>000001-rice-0.png</li>
+            <li>...</li>
+         </ul>
+        </li>
+     </ul>
+<h3>Training from scratch</h3>
+<p>
+i.ann.maskrcnn.train training_dataset=/home/user/Documents/crops classes=corn,rice logs=/home/user/Documents/logs name=crops
+</pre></div>
+After default number of epochs, we will get a model where the first class is
+trained to detect corn fields and the second one to detect rice fields.
+<p>
+If we use the command with reversed classes order, we will get a model where
+the first class is trained to detect rice fields and the second one to detect
+corn fields.
+i.ann.maskrcnn.train training_dataset=/home/user/Documents/crops classes=rice,corn logs=/home/user/Documents/logs name=crops
+</pre></div>
+<p>
+The name of the model does not have to be the same as the dataset folder but
+should be referring to the task of the dataset. A good name for this one
+(referring also to the order of classes) could be also this one:
+i.ann.maskrcnn.train training_dataset=/home/user/Documents/crops classes=rice,corn logs=/home/user/Documents/logs name=rice_corn
+</pre></div>
+<h3>Training from a pretrained model</h3>
+<p>
+We can use a pretrained model to make our training faster. It is necessary for
+the model to be trained on the same channels and similar features, but it does
+not have to be the same ones (e.g. model trained on swimming pools in maps can
+be used for a training on buildings in maps).
+<p>
+A model trained on different classes (use <em>-e</em> flag to exclude head
+weights).
+i.ann.maskrcnn.train training_dataset=/home/user/Documents/crops classes=corn,rice logs=/home/user/Documents/logs name=crops model=/home/user/Documents/models/buildings.h5 -e
+</pre></div>
+<p>
+A model trained on the same classes.
+i.ann.maskrcnn.train training_dataset=/home/user/Documents/crops classes=corn,rice logs=/home/user/Documents/logs name=crops model=/home/user/Documents/models/corn_rice.h5
+</pre></div>
+<h3>Fine-tuning a model</h3>
+<p>
+It is also possible to stop your training and then continue. To continue in
+the training, just use the last saved epoch as a pretrained model.
+i.ann.maskrcnn.train training_dataset=/home/user/Documents/crops classes=corn,rice logs=/home/user/Documents/logs name=crops model=/home/user/Documents/models/mask_rcnn_crops_0005.h5
+</pre></div>
+<h2>SEE ALSO</h2>
+<em>
+    <a href="i.ann.maskrcnn.detect.html">i.ann.maskrcnn.detect</a>
+</em>
+<h2>AUTHORS</h2>
+Ondrej Pesek
Added: grass-addons/grass7/imagery/i.ann.maskrcnn/i.ann.maskrcnn.train/i.ann.maskrcnn.train.py
--- grass-addons/grass7/imagery/i.ann.maskrcnn/i.ann.maskrcnn.train/i.ann.maskrcnn.train.py	                        (rev 0)
+++ grass-addons/grass7/imagery/i.ann.maskrcnn/i.ann.maskrcnn.train/i.ann.maskrcnn.train.py	2018-05-22 11:53:59 UTC (rev 72730)
@@ -0,0 +1,339 @@
+# MODULE:	    i.ann.maskrcnn.train
+#%module
+#% description: Train your Mask R-CNN network
+#% keyword: ann
+#% keyword: vector
+#% keyword: raster
+#%end
+#%flag
+#%  key: e
+#%  description: Pretrained weights were trained on another classes / resolution / sizes
+#%end
+#%flag
+#%  key: s
+#%  description: Do not use 10 % of images and save their list to logs dir
+#%end
+#%flag
+#%  key: b
+#%  description: Train also batch normalization layers (not recommended for small batches)
+#%end
+#%flag
+#%  key: n
+#%  description: No resizing or padding of images (images must be of the same size)
+#%end
+#% key: training_dataset
+#% label: Path to the dataset with images and masks
+#% required: yes
+#%end
+#%option
+#% key: model
+#% type: string
+#% label: Path to the .h5 file to use as initial values
+#% description: Keep empty to train from a scratch
+#% required: no
+#% multiple: no
+#%end
+#%option
+#% key: classes
+#% type: string
+#% required: yes
+#% multiple: yes
+#%end
+#% key: logs
+#% label: Path to the directory in which will be models saved
+#% required: yes
+#%end
+#%option
+#% key: name
+#% type: string
+#% label: Name for output models
+#% required: yes
+#%end
+#%option
+#% key: epochs
+#% type: integer
+#% label: Number of epochs
+#% required: no
+#% multiple: no
+#% answer: 200
+#% guisection: Training parameters
+#%end
+#%option
+#% key: steps_per_epoch
+#% type: integer
+#% label: Steps per each epoch
+#% required: no
+#% multiple: no
+#% answer: 3000
+#%end
+#%option
+#% key: rois_per_image
+#% type: integer
+#% label: How many ROIs train per image
+#% required: no
+#% multiple: no
+#% answer: 64
+#%end
+#%option
+#% key: images_per_gpu
+#% type: integer
+#% label: Number of images per GPU
+#% description: Bigger number means faster training but needs a bigger GPU
+#% required: no
+#% multiple: no
+#% answer: 1
+#%end
+#%option
+#% key: gpu_count
+#% type: integer
+#% label: Number of GPUs to be used
+#% required: no
+#% multiple: no
+#% answer: 1
+#%end
+#%option
+#% key: mini_mask_size
+#% type: integer
+#% label: Size of mini mask separated with ","
+#% description: To use full sized masks, keep empty. Mini mask saves memory at the expense of precision
+#% required: no
+#% multiple: yes
+#%end
+#%option
+#% key: validation_steps
+#% type: integer
+#% label: Number of validation steps
+#% description: Bigger number means more accurate estimation of the model precision
+#% required: no
+#% multiple: no
+#% answer: 100
+#%end
+#%option
+#% key: images_min_dim
+#% type: integer
+#% label: Minimum length of images sides
+#% description: Images will be resized to have their shortest side at least of this value (has to be a multiple of 64)
+#% required: no
+#% multiple: no
+#% answer: 256
+#%end
+#%option
+#% key: images_max_dim
+#% type: integer
+#% label: Maximum length of images sides
+#% description: Images will be resized to have their longest side of this value (has to be a multiple of 64)
+#% required: no
+#% multiple: no
+#% answer: 1280
+#%end
+#%option
+#% key: backbone
+#% type: string
+#% label: Backbone architecture
+#% required: no
+#% multiple: no
+#% answer: resnet101
+#% options: resnet50,resnet101
+#%end
+import os
+import sys
+from random import shuffle
+if path is None:
+    grass.script.fatal('Not able to find the maskrcnn library directory.')
+    import utils
+    try:
+        dataset = options['training_dataset']
+        initialWeights = options['model']
+        name = options['name']
+        logs = options['logs']
+        epochs = int(options['epochs'])
+        stepsPerEpoch = int(options['steps_per_epoch'])
+        ROIsPerImage = int(options['rois_per_image'])
+        imagesPerGPU = int(options['images_per_gpu'])
+        GPUcount = int(options['gpu_count'])
+        miniMaskSize = options['mini_mask_size']
+        validationSteps = int(options['validation_steps'])
+        imMaxDim = int(options['images_max_dim'])
+        imMinDim = int(options['images_min_dim'])
+        backbone = options['backbone']
+    except KeyError:
+        dataset = options[b'training_dataset'].decode('utf-8')
+        initialWeights = options[b'model'].decode('utf-8')
+        name = options[b'name'].decode('utf-8')
+        logs = options[b'logs'].decode('utf-8')
+        epochs = int(options[b'epochs'])
+        stepsPerEpoch = int(options[b'steps_per_epoch'])
+        ROIsPerImage = int(options[b'rois_per_image'])
+        imagesPerGPU = int(options[b'images_per_gpu'])
+        GPUcount = int(options[b'gpu_count'])
+        miniMaskSize = options[b'mini_mask_size'].decode('utf-8')
+        validationSteps = int(options[b'validation_steps'])
+        imMaxDim = int(options[b'images_max_dim'])
+        imMinDim = int(options[b'images_min_dim'])
+        backbone = options[b'backbone'].decode('utf-8')
+        newFlags = dict()
+        flags = newFlags
+    if not flags['b']:
+        trainBatchNorm = False
+    else:
+        # None means train in normal mode but do not force it when inferencing
+        trainBatchNorm = None
+    if not flags['n']:
+        # Resize and pad with zeros to get a square image of
+        # size [max_dim, max_dim].
+        resizeMode = 'square'
+    else:
+        resizeMode = 'none'
+    # Configurations
+    config = ModelConfig(name=name,
+                         imagesPerGPU=imagesPerGPU,
+                         GPUcount=GPUcount,
+                         numClasses=len(classes) + 1,
+                         trainROIsPerImage=ROIsPerImage,
+                         stepsPerEpoch=stepsPerEpoch,
+                         miniMaskShape=miniMaskSize,
+                         validationSteps=validationSteps,
+                         imageMaxDim=imMaxDim,
+                         imageMinDim=imMinDim,
+                         backbone=backbone,
+                         trainBatchNorm=trainBatchNorm,
+                         resizeMode=resizeMode)
+    config.display()
+    # Create model
+    model = modellib.MaskRCNN(mode="training", config=config,
+                              model_dir=logs)
+    # Load weights
+    if initialWeights:
+        gscript.message("Loading weights {}".format(initialWeights))
+    if initialWeights and flags['e']:
+        model.load_weights(initialWeights, by_name=True,
+                           exclude=["mrcnn_class_logits", "mrcnn_bbox_fc",
+                                    "mrcnn_bbox", "mrcnn_mask"])
+    elif initialWeights:
+        model.load_weights(initialWeights, by_name=True)
+    gscript.message('Reading images from dataset {}'.format(dataset))
+    images = list()
+    for root, subdirs, _ in os.walk(dataset):
+        if not subdirs:
+            # TODO: More structures
+            images.append(root)
+    shuffle(images)
+    if flags['s']:
+        # Write list of unused images to logs
+        testImagesThreshold = int(len(images) * .9)
+        gscript.message('List of unused images saved in the logs directory'
+                        'as "unused.txt"')
+        with open(os.path.join(logs, 'unused.txt'), 'w') as unused:
+            for filename in images[testImagesThreshold:]:
+                unused.write('{}\n'.format(filename))
+    else:
+        testImagesThreshold = len(images)
+    evalImagesThreshold = int(testImagesThreshold * .75)
+    # augmentation = imgaug/augmenters.Fliplr(0.5)
+    # Training dataset
+    trainImages = images[:evalImagesThreshold]
+    dataset_train = utils.Dataset()
+    dataset_train.import_contents(classes, trainImages, name)
+    dataset_train.prepare()
+    # Validation dataset
+    evalImages = images[evalImagesThreshold:testImagesThreshold]
+    dataset_val = utils.Dataset()
+    dataset_val.import_contents(classes, evalImages, name)
+    dataset_val.prepare()
+        # Training - Stage 1
+        # Adjust epochs and layers as needed
+        gscript.message("Training network heads")
+        model.train(dataset_train, dataset_val,
+                    learning_rate=config.LEARNING_RATE,
+                    epochs=int(epochs / 7),
+                    layers='heads')  # augmentation=augmentation
+        # Training - Stage 2
+        # Finetune layers from ResNet stage 4 and up
+        gscript.message("Fine tune Resnet stage 4 and up")
+        # divide the learning rate by 10 if ran out of memory or
+        # if weights exploded
+                    epochs=int(epochs / 7) * 3,
+                    layers='4+')  # augmentation=augmentation
+        # Training - Stage 3
+        # Fine tune all layers
+        gscript.message("Fine tune all layers")
+        # out of if statement
+    else:
+        gscript.message("Training all layers")
+    # divide the learning rate by 100 if ran out of memory or
+                learning_rate=config.LEARNING_RATE / 10,
+                epochs=epochs,
+                layers='all')  # augmentation=augmentation
Added: grass-addons/grass7/imagery/i.ann.maskrcnn/maskrcnnlib/Makefile
--- grass-addons/grass7/imagery/i.ann.maskrcnn/maskrcnnlib/Makefile	                        (rev 0)
+++ grass-addons/grass7/imagery/i.ann.maskrcnn/maskrcnnlib/Makefile	2018-05-22 11:53:59 UTC (rev 72730)
@@ -0,0 +1,22 @@
+include $(MODULE_TOPDIR)/include/Make/Other.make
+include $(MODULE_TOPDIR)/include/Make/Python.make
+MODULES = __init__ config utils model parallel_model
+ETCDIR = $(ETC)/maskrcnn
+PYFILES := $(patsubst %,$(ETCDIR)/%.py,$(MODULES))
+PYCFILES := $(patsubst %,$(ETCDIR)/%.pyc,$(MODULES))
+default: $(PYFILES) $(PYCFILES)
+$(ETCDIR):
+	$(MKDIR) $@
+$(ETCDIR)/%: % | $(ETCDIR)
+	$(INSTALL_DATA) $< $@
+install:
+	cp -r $(ETCDIR) $(INST_DIR)/etc
Added: grass-addons/grass7/imagery/i.ann.maskrcnn/maskrcnnlib/__init__.py
Added: grass-addons/grass7/imagery/i.ann.maskrcnn/maskrcnnlib/config.py
--- grass-addons/grass7/imagery/i.ann.maskrcnn/maskrcnnlib/config.py	                        (rev 0)
+++ grass-addons/grass7/imagery/i.ann.maskrcnn/maskrcnnlib/config.py	2018-05-22 11:53:59 UTC (rev 72730)
@@ -0,0 +1,214 @@
+# -*- coding: utf-8 -*-
+# MODULE:	    ann.maskrcnn config
+# PURPOSE:	    Configuration class used in ann.maskrcnn.* modules
+# WRITTEN:  	2017    Ondrej Pesek
+#                       Based on config.py by Waleed Abdulla (Matterport, Inc.)
+#                           https://github.com/matterport/Mask_RCNN
+#                           Written __init__ to allow attributes to be
+#                               modified during the class call
+# Licensed under the MIT License (see LICENSE for details)
+import math
+import numpy as np
+class ModelConfig(object):
+    Base configuration class.
+    Written by Waleed Abdulla (Matterport, Inc.)
+    # NOT RECOMMENDED TO MODIFY:
+    # The strides of each layer of the FPN Pyramid. These values
+    # are based on a Resnet101 backbone.
+    BACKBONE_STRIDES = [4, 8, 16, 32, 64]
+    ## RPN ##
+    # Length of square anchor side in pixels
+    RPN_ANCHOR_SCALES = (32, 64, 128, 256, 512)
+    # Ratios of anchors at each cell (width/height)
+    # A value of 1 represents a square anchor, and 0.5 is a wide anchor
+    RPN_ANCHOR_RATIOS = [0.5, 1, 2]
+    # Anchor stride
+    # If 1 then anchors are created for each cell in the backbone feature map.
+    # If 2, then anchors are created for every other cell, and so on.
+    RPN_ANCHOR_STRIDE = 1  # 2 before change
+    # Non-max suppression threshold to filter RPN proposals.
+    # You can increase this during training to generate more proposals.
+    RPN_NMS_THRESHOLD = 0.7
+    # How many anchors per image to use for RPN training
+    RPN_TRAIN_ANCHORS_PER_IMAGE = 256
+    # ROIs kept after non-maximum supression (training and inference)
+    POST_NMS_ROIS_TRAINING = 2000
+    POST_NMS_ROIS_INFERENCE = 1000
+    # Minimum scaling ratio. Checked after MIN_IMAGE_DIM and can force further
+    # up scaling. For example, if set to 2 then images are scaled up to double
+    # the width and height, or more, even if MIN_IMAGE_DIM doesn't require it.
+    # Howver, in 'square' mode, it can be overruled by IMAGE_MAX_DIM.
+    IMAGE_MIN_SCALE = 0
+    # Image mean (RGB)
+    MEAN_PIXEL = np.array([123.7, 116.8, 103.9])
+    # Percent of positive ROIs used to train classifier/mask heads
+    ROI_POSITIVE_RATIO = 0.33
+    # Pooled ROIs
+    POOL_SIZE = 7
+    MASK_POOL_SIZE = 14
+    # Shape of output mask
+    # To change this you also need to change the neural network mask branch
+    MASK_SHAPE = [28, 28]
+    # Maximum number of ground truth instances to use in one image
+    MAX_GT_INSTANCES = 100
+    # Bounding box refinement standard deviation for RPN and final detections.
+    RPN_BBOX_STD_DEV = np.array([0.1, 0.1, 0.2, 0.2])
+    BBOX_STD_DEV = np.array([0.1, 0.1, 0.2, 0.2])
+    # Max number of final detections
+    DETECTION_MAX_INSTANCES = 100
+    # Minimum probability value to accept a detected instance
+    # ROIs below this threshold are skipped
+    DETECTION_MIN_CONFIDENCE = 0.7
+    # Non-maximum suppression threshold for detection
+    DETECTION_NMS_THRESHOLD = 0.3
+    # Learning rate and momentum
+    # The Mask RCNN paper uses lr=0.02, but on TensorFlow it causes
+    # weights to explode. Likely due to differences in optimzer
+    # implementation.
+    LEARNING_RATE = 0.001  # 0.002 before change
+    LEARNING_MOMENTUM = 0.9
+    # Weight decay regularization
+    WEIGHT_DECAY = 0.0001
+    # Loss weights for more precise optimization.
+    # Can be used for R-CNN training setup.
+    LOSS_WEIGHTS = {
+        "rpn_class_loss": 1.,
+        "rpn_bbox_loss": 1.,
+        "mrcnn_class_loss": 1.,
+        "mrcnn_bbox_loss": 1.,
+        "mrcnn_mask_loss": 1.
+    # Use RPN ROIs or externally generated ROIs for training
+    # Keep this True for most situations. Set to False if you want to train
+    # the head branches on ROI generated by code rather than the ROIs from
+    # the RPN. For example, to debug the classifier head without having to
+    # train the RPN.
+    USE_RPN_ROIS = True
+    # Gradient norm clipping
+    GRADIENT_CLIP_NORM = 5.0
+    def __init__(self, name='model', imagesPerGPU=1, GPUcount=1, numClasses=1,
+                 trainROIsPerImage=64, stepsPerEpoch=1500,
+                 miniMaskShape=None, validationSteps=100,
+                 imageMaxDim=768, imageMinDim=768, backbone='resnet101',
+                 trainBatchNorm=False, resizeMode='square'):
+        """Set values of attributes.
+        Written by Ondrej Pesek, but using attributes from Waleed Abdulla"""
+        # Give the configuration a recognizable name
+        self.NAME = name
+        # Number of images to train on each GPU
+        self.IMAGES_PER_GPU = imagesPerGPU
+        # NUMBER OF GPUs to use. For CPU training, use 1
+        self.GPU_COUNT = GPUcount
+        # Number of classes (including background)
+        self.NUM_CLASSES = numClasses
+        # Number of ROIs per image to feed to classifier/mask heads
+        # Try to keep keep a positive:negative
+        # ratio of 1:3. You can increase the number of proposals by adjusting
+        # the RPN NMS threshold.
+        self.TRAIN_ROIS_PER_IMAGE = trainROIsPerImage
+        # Number of training steps per epoch. A model is saved after each epoch
+        self.STEPS_PER_EPOCH = stepsPerEpoch // self.IMAGES_PER_GPU
+        # Number of steps to run at the end of every training epoch
+        self.VALIDATION_STEPS = validationSteps
+        # Input image resizing
+        # Generally, use the "square" resizing mode for training and inferencing
+        # and it should work well in most cases. In this mode, images are scaled
+        # up such that the small side is = IMAGE_MIN_DIM, but ensuring that the
+        # scaling doesn't make the long side > IMAGE_MAX_DIM. Then the image is
+        # padded with zeros to make it a square so multiple images can be put
+        # in one batch.
+        # Available resizing modes:
+        # none:   No resizing or padding. Return the image unchanged.
+        # square: Resize and pad with zeros to get a square image
+        #         of size [max_dim, max_dim].
+        self.IMAGE_RESIZE_MODE = resizeMode
+        self.IMAGE_MAX_DIM = imageMaxDim
+        self.IMAGE_MIN_DIM = imageMinDim
+        # mini_mask to save memory
+        # If True, resizes masks to a smaller size to reduce memory load
+        if miniMaskShape:
+            self.USE_MINI_MASK = True
+            self.MINI_MASK_SHAPE = tuple(
+                int(a) for a in miniMaskShape.split(','))  # (height, width)
+        else:
+            self.USE_MINI_MASK = False
+            self.MINI_MASK_SHAPE = None
+        # Effective batch size
+        self.BATCH_SIZE = self.IMAGES_PER_GPU * self.GPU_COUNT
+        # Set the backbone architecture
+        self.BACKBONE = backbone
+        # Input image size
+        self.IMAGE_SHAPE = np.array(
+            [self.IMAGE_MAX_DIM, self.IMAGE_MAX_DIM, 3])
+        # Compute backbone size from input image size
+        self.BACKBONE_SHAPES = np.array(
+            [[int(math.ceil(self.IMAGE_SHAPE[0] / stride)),
+              int(math.ceil(self.IMAGE_SHAPE[1] / stride))]
+             for stride in self.BACKBONE_STRIDES])
+        # Train or freeze batch normalization layers
+        #  None: Train BN layers in a normal mode
+        #  False: Freeze BN layers (recommended for small batch size)
+        #  True: Set layer in training mode even when inferencing
+        self.TRAIN_BN = trainBatchNorm
+        # Image meta data length
+        # See compose_image_meta() for details
+        self.IMAGE_META_SIZE = 1 + 3 + 3 + 4 + 1 + self.NUM_CLASSES
+    def display(self):
+        """Display Configuration values."""
+        print("\nConfigurations:")
+        for a in dir(self):
+            if not a.startswith("__") and not callable(getattr(self, a)):
+                print("{:30} {}".format(a, getattr(self, a)))
+        print("\n")
Added: grass-addons/grass7/imagery/i.ann.maskrcnn/maskrcnnlib/model.py
--- grass-addons/grass7/imagery/i.ann.maskrcnn/maskrcnnlib/model.py	                        (rev 0)
+++ grass-addons/grass7/imagery/i.ann.maskrcnn/maskrcnnlib/model.py	2018-05-22 11:53:59 UTC (rev 72730)
@@ -0,0 +1,2860 @@
+Mask R-CNN
+The main Mask R-CNN model implemenetation.
+Copyright (c) 2017 Matterport, Inc.
+Licensed under the MIT License (see LICENSE for details)
+Written by Waleed Abdulla
+Modified by Ondrej Pesek
+    Written error handling in load_image_gt and data_generator
+    Changed the verbosity to correspond GRASS verbosity in detect
+import os
+import random
+import datetime
+import re
+import math
+import logging
+from collections import OrderedDict
+import multiprocessing
+import numpy as np
+import skimage.transform
+import tensorflow as tf
+import keras
+import keras.backend as K
+import keras.layers as KL
+import keras.engine as KE
+import keras.models as KM
+import utils
+# Requires TensorFlow 1.3+ and Keras 2.0.8+.
+from distutils.version import LooseVersion
+assert LooseVersion(tf.__version__) >= LooseVersion("1.3")
+assert LooseVersion(keras.__version__) >= LooseVersion('2.0.8')
+#  Utility Functions
+def log(text, array=None):
+    """Prints a text message. And, optionally, if a Numpy array is provided it
+    prints it's shape, min, and max values.
+    if array is not None:
+        text = text.ljust(25)
+        text += ("shape: {:20}  min: {:10.5f}  max: {:10.5f}  {}".format(
+            str(array.shape),
+            array.min() if array.size else "",
+            array.max() if array.size else "",
+            array.dtype))
+    print(text)
+class BatchNorm(KL.BatchNormalization):
+    """Extends the Keras BatchNormalization class to allow a central place
+    to make changes if needed.
+    Batch normalization has a negative effect on training if batches are small
+    so this layer is often frozen (via setting in Config class) and functions
+    as linear layer.
+    def call(self, inputs, training=None):
+        Note about training values:
+            None: Train BN layers. This is the normal mode
+            False: Freeze BN layers. Good when batch size is small
+            True: (don't use). Set layer in training mode even when inferencing
+        return super(self.__class__, self).call(inputs, training=training)
+def compute_backbone_shapes(config, image_shape):
+    """Computes the width and height of each stage of the backbone network.
+    Returns:
+        [N, (height, width)]. Where N is the number of stages
+    # Currently supports ResNet only
+    assert config.BACKBONE in ["resnet50", "resnet101"]
+    return np.array(
+        [[int(math.ceil(image_shape[0] / stride)),
+            int(math.ceil(image_shape[1] / stride))]
+            for stride in config.BACKBONE_STRIDES])
+#  Resnet Graph
+# Code adopted from:
+# https://github.com/fchollet/deep-learning-models/blob/master/resnet50.py
+def identity_block(input_tensor, kernel_size, filters, stage, block,
+                   use_bias=True, train_bn=True):
+    """The identity_block is the block that has no conv layer at shortcut
+    # Arguments
+        input_tensor: input tensor
+        kernel_size: defualt 3, the kernel size of middle conv layer at main path
+        filters: list of integers, the nb_filters of 3 conv layer at main path
+        stage: integer, current stage label, used for generating layer names
+        block: 'a','b'..., current block label, used for generating layer names
+        use_bias: Boolean. To use or not use a bias in conv layers.
+        train_bn: Boolean. Train or freeze Batch Norm layres
+    nb_filter1, nb_filter2, nb_filter3 = filters
+    conv_name_base = 'res' + str(stage) + block + '_branch'
+    bn_name_base = 'bn' + str(stage) + block + '_branch'
+    x = KL.Conv2D(nb_filter1, (1, 1), name=conv_name_base + '2a',
+                  use_bias=use_bias)(input_tensor)
+    x = BatchNorm(name=bn_name_base + '2a')(x, training=train_bn)
+    x = KL.Activation('relu')(x)
+    x = KL.Conv2D(nb_filter2, (kernel_size, kernel_size), padding='same',
+                  name=conv_name_base + '2b', use_bias=use_bias)(x)
+    x = BatchNorm(name=bn_name_base + '2b')(x, training=train_bn)
+    x = KL.Conv2D(nb_filter3, (1, 1), name=conv_name_base + '2c',
+                  use_bias=use_bias)(x)
+    x = BatchNorm(name=bn_name_base + '2c')(x, training=train_bn)
+    x = KL.Add()([x, input_tensor])
+    x = KL.Activation('relu', name='res' + str(stage) + block + '_out')(x)
+    return x
+def conv_block(input_tensor, kernel_size, filters, stage, block,
+               strides=(2, 2), use_bias=True, train_bn=True):
+    """conv_block is the block that has a conv layer at shortcut
+    # Arguments
+    Note that from stage 3, the first conv layer at main path is with subsample=(2,2)
+    And the shortcut should have subsample=(2,2) as well
+    x = KL.Conv2D(nb_filter1, (1, 1), strides=strides,
+                  name=conv_name_base + '2a', use_bias=use_bias)(input_tensor)
+                  '2c', use_bias=use_bias)(x)
+    shortcut = KL.Conv2D(nb_filter3, (1, 1), strides=strides,
+                         name=conv_name_base + '1', use_bias=use_bias)(input_tensor)
+    shortcut = BatchNorm(name=bn_name_base + '1')(shortcut, training=train_bn)
+    x = KL.Add()([x, shortcut])
+    return x
+def resnet_graph(input_image, architecture, stage5=False, train_bn=True):
+    """Build a ResNet graph.
+        architecture: Can be resnet50 or resnet101
+        stage5: Boolean. If False, stage5 of the network is not created
+    assert architecture in ["resnet50", "resnet101"]
+    # Stage 1
+    x = KL.ZeroPadding2D((3, 3))(input_image)
+    x = KL.Conv2D(64, (7, 7), strides=(2, 2), name='conv1', use_bias=True)(x)
+    x = BatchNorm(name='bn_conv1')(x, training=train_bn)
+    C1 = x = KL.MaxPooling2D((3, 3), strides=(2, 2), padding="same")(x)
+    # Stage 2
+    x = conv_block(x, 3, [64, 64, 256], stage=2, block='a', strides=(1, 1), train_bn=train_bn)
+    x = identity_block(x, 3, [64, 64, 256], stage=2, block='b', train_bn=train_bn)
+    C2 = x = identity_block(x, 3, [64, 64, 256], stage=2, block='c', train_bn=train_bn)
+    # Stage 3
+    x = conv_block(x, 3, [128, 128, 512], stage=3, block='a', train_bn=train_bn)
+    x = identity_block(x, 3, [128, 128, 512], stage=3, block='b', train_bn=train_bn)
+    x = identity_block(x, 3, [128, 128, 512], stage=3, block='c', train_bn=train_bn)
+    C3 = x = identity_block(x, 3, [128, 128, 512], stage=3, block='d', train_bn=train_bn)
+    # Stage 4
+    x = conv_block(x, 3, [256, 256, 1024], stage=4, block='a', train_bn=train_bn)
+    block_count = {"resnet50": 5, "resnet101": 22}[architecture]
+    for i in range(block_count):
+        x = identity_block(x, 3, [256, 256, 1024], stage=4, block=chr(98 + i), train_bn=train_bn)
+    C4 = x
+    # Stage 5
+    if stage5:
+        x = conv_block(x, 3, [512, 512, 2048], stage=5, block='a', train_bn=train_bn)
+        x = identity_block(x, 3, [512, 512, 2048], stage=5, block='b', train_bn=train_bn)
+        C5 = x = identity_block(x, 3, [512, 512, 2048], stage=5, block='c', train_bn=train_bn)
+    else:
+        C5 = None
+    return [C1, C2, C3, C4, C5]
+#  Proposal Layer
+def apply_box_deltas_graph(boxes, deltas):
+    """Applies the given deltas to the given boxes.
+    boxes: [N, (y1, x1, y2, x2)] boxes to update
+    deltas: [N, (dy, dx, log(dh), log(dw))] refinements to apply
+    # Convert to y, x, h, w
+    height = boxes[:, 2] - boxes[:, 0]
+    width = boxes[:, 3] - boxes[:, 1]
+    center_y = boxes[:, 0] + 0.5 * height
+    center_x = boxes[:, 1] + 0.5 * width
+    # Apply deltas
+    center_y += deltas[:, 0] * height
+    center_x += deltas[:, 1] * width
+    height *= tf.exp(deltas[:, 2])
+    width *= tf.exp(deltas[:, 3])
+    # Convert back to y1, x1, y2, x2
+    y1 = center_y - 0.5 * height
+    x1 = center_x - 0.5 * width
+    y2 = y1 + height
+    x2 = x1 + width
+    result = tf.stack([y1, x1, y2, x2], axis=1, name="apply_box_deltas_out")
+    return result
+def clip_boxes_graph(boxes, window):
+    window: [4] in the form y1, x1, y2, x2
+    # Split
+    wy1, wx1, wy2, wx2 = tf.split(window, 4)
+    y1, x1, y2, x2 = tf.split(boxes, 4, axis=1)
+    # Clip
+    y1 = tf.maximum(tf.minimum(y1, wy2), wy1)
+    x1 = tf.maximum(tf.minimum(x1, wx2), wx1)
+    y2 = tf.maximum(tf.minimum(y2, wy2), wy1)
+    x2 = tf.maximum(tf.minimum(x2, wx2), wx1)
+    clipped = tf.concat([y1, x1, y2, x2], axis=1, name="clipped_boxes")
+    clipped.set_shape((clipped.shape[0], 4))
+    return clipped
+class ProposalLayer(KE.Layer):
+    """Receives anchor scores and selects a subset to pass as proposals
+    to the second stage. Filtering is done based on anchor scores and
+    non-max suppression to remove overlaps. It also applies bounding
+    box refinement deltas to anchors.
+    Inputs:
+        rpn_probs: [batch, anchors, (bg prob, fg prob)]
+        rpn_bbox: [batch, anchors, (dy, dx, log(dh), log(dw))]
+        anchors: [batch, (y1, x1, y2, x2)] anchors in normalized coordinates
+    Returns:
+        Proposals in normalized coordinates [batch, rois, (y1, x1, y2, x2)]
+    def __init__(self, proposal_count, nms_threshold,
+                 config=None, **kwargs):
+        super(ProposalLayer, self).__init__(**kwargs)
+        self.config = config
+        self.proposal_count = proposal_count
+        self.nms_threshold = nms_threshold
+    def call(self, inputs):
+        # Box Scores. Use the foreground class confidence. [Batch, num_rois, 1]
+        scores = inputs[0][:, :, 1]
+        # Box deltas [batch, num_rois, 4]
+        deltas = inputs[1]
+        deltas = deltas * np.reshape(self.config.RPN_BBOX_STD_DEV, [1, 1, 4])
+        # Anchors
+        anchors = inputs[2]
+        # Improve performance by trimming to top anchors by score
+        # and doing the rest on the smaller subset.
+        pre_nms_limit = tf.minimum(6000, tf.shape(anchors)[1])
+        ix = tf.nn.top_k(scores, pre_nms_limit, sorted=True,
+                         name="top_anchors").indices
+        scores = utils.batch_slice([scores, ix], lambda x, y: tf.gather(x, y),
+                                   self.config.IMAGES_PER_GPU)
+        deltas = utils.batch_slice([deltas, ix], lambda x, y: tf.gather(x, y),
+        pre_nms_anchors = utils.batch_slice([anchors, ix], lambda a, x: tf.gather(a, x),
+                                    self.config.IMAGES_PER_GPU,
+                                    names=["pre_nms_anchors"])
+        # Apply deltas to anchors to get refined anchors.
+        # [batch, N, (y1, x1, y2, x2)]
+        boxes = utils.batch_slice([pre_nms_anchors, deltas],
+                                  lambda x, y: apply_box_deltas_graph(x, y),
+                                  names=["refined_anchors"])
+        # Clip to image boundaries. Since we're in normalized coordinates,
+        # clip to 0..1 range. [batch, N, (y1, x1, y2, x2)]
+        window = np.array([0, 0, 1, 1], dtype=np.float32)
+        boxes = utils.batch_slice(boxes,
+                                  lambda x: clip_boxes_graph(x, window),
+                                  names=["refined_anchors_clipped"])
+        # Filter out small boxes
+        # According to Xinlei Chen's paper, this reduces detection accuracy
+        # for small objects, so we're skipping it.
+        def nms(boxes, scores):
+            indices = tf.image.non_max_suppression(
+                boxes, scores, self.proposal_count,
+                self.nms_threshold, name="rpn_non_max_suppression")
+            proposals = tf.gather(boxes, indices)
+            # Pad if needed
+            padding = tf.maximum(self.proposal_count - tf.shape(proposals)[0], 0)
+            proposals = tf.pad(proposals, [(0, padding), (0, 0)])
+            return proposals
+        proposals = utils.batch_slice([boxes, scores], nms,
+        return proposals
+    def compute_output_shape(self, input_shape):
+        return (None, self.proposal_count, 4)
+#  ROIAlign Layer
+def log2_graph(x):
+    """Implementatin of Log2. TF doesn't have a native implemenation."""
+    return tf.log(x) / tf.log(2.0)
+class PyramidROIAlign(KE.Layer):
+    """Implements ROI Pooling on multiple levels of the feature pyramid.
+    Params:
+    - pool_shape: [height, width] of the output pooled regions. Usually [7, 7]
+    Inputs:
+    - boxes: [batch, num_boxes, (y1, x1, y2, x2)] in normalized
+             coordinates. Possibly padded with zeros if not enough
+             boxes to fill the array.
+    - image_meta: [batch, (meta data)] Image details. See compose_image_meta()
+    - Feature maps: List of feature maps from different levels of the pyramid.
+                    Each is [batch, height, width, channels]
+    Output:
+    Pooled regions in the shape: [batch, num_boxes, height, width, channels].
+    The width and height are those specific in the pool_shape in the layer
+    constructor.
+    def __init__(self, pool_shape, **kwargs):
+        super(PyramidROIAlign, self).__init__(**kwargs)
+        self.pool_shape = tuple(pool_shape)
+        # Crop boxes [batch, num_boxes, (y1, x1, y2, x2)] in normalized coords
+        boxes = inputs[0]
+        # Image meta
+        # Holds details about the image. See compose_image_meta()
+        image_meta = inputs[1]
+        # Feature Maps. List of feature maps from different level of the
+        # feature pyramid. Each is [batch, height, width, channels]
+        feature_maps = inputs[2:]
+        # Assign each ROI to a level in the pyramid based on the ROI area.
+        y1, x1, y2, x2 = tf.split(boxes, 4, axis=2)
+        h = y2 - y1
+        w = x2 - x1
+        # Use shape of first image. Images in a batch must have the same size.
+        image_shape = parse_image_meta_graph(image_meta)['image_shape'][0]
+        # Equation 1 in the Feature Pyramid Networks paper. Account for
+        # the fact that our coordinates are normalized here.
+        # e.g. a 224x224 ROI (in pixels) maps to P4
+        image_area = tf.cast(image_shape[0] * image_shape[1], tf.float32)
+        roi_level = log2_graph(tf.sqrt(h * w) / (224.0 / tf.sqrt(image_area)))
+        roi_level = tf.minimum(5, tf.maximum(
+            2, 4 + tf.cast(tf.round(roi_level), tf.int32)))
+        roi_level = tf.squeeze(roi_level, 2)
+        # Loop through levels and apply ROI pooling to each. P2 to P5.
+        pooled = []
+        box_to_level = []
+        for i, level in enumerate(range(2, 6)):
+            ix = tf.where(tf.equal(roi_level, level))
+            level_boxes = tf.gather_nd(boxes, ix)
+            # Box indicies for crop_and_resize.
+            box_indices = tf.cast(ix[:, 0], tf.int32)
+            # Keep track of which box is mapped to which level
+            box_to_level.append(ix)
+            # Stop gradient propogation to ROI proposals
+            level_boxes = tf.stop_gradient(level_boxes)
+            box_indices = tf.stop_gradient(box_indices)
+            # Crop and Resize
+            # From Mask R-CNN paper: "We sample four regular locations, so
+            # that we can evaluate either max or average pooling. In fact,
+            # interpolating only a single value at each bin center (without
+            # pooling) is nearly as effective."
+            # Here we use the simplified approach of a single value per bin,
+            # which is how it's done in tf.crop_and_resize()
+            # Result: [batch * num_boxes, pool_height, pool_width, channels]
+            pooled.append(tf.image.crop_and_resize(
+                feature_maps[i], level_boxes, box_indices, self.pool_shape,
+                method="bilinear"))
+        # Pack pooled features into one tensor
+        pooled = tf.concat(pooled, axis=0)
+        # Pack box_to_level mapping into one array and add another
+        # column representing the order of pooled boxes
+        box_to_level = tf.concat(box_to_level, axis=0)
+        box_range = tf.expand_dims(tf.range(tf.shape(box_to_level)[0]), 1)
+        box_to_level = tf.concat([tf.cast(box_to_level, tf.int32), box_range],
+                                 axis=1)
+        # Rearrange pooled features to match the order of the original boxes
+        # Sort box_to_level by batch then box index
+        # TF doesn't have a way to sort by two columns, so merge them and sort.
+        sorting_tensor = box_to_level[:, 0] * 100000 + box_to_level[:, 1]
+        ix = tf.nn.top_k(sorting_tensor, k=tf.shape(
+            box_to_level)[0]).indices[::-1]
+        ix = tf.gather(box_to_level[:, 2], ix)
+        pooled = tf.gather(pooled, ix)
+        # Re-add the batch dimension
+        pooled = tf.expand_dims(pooled, 0)
+        return pooled
+        return input_shape[0][:2] + self.pool_shape + (input_shape[2][-1], )
+#  Detection Target Layer
+def overlaps_graph(boxes1, boxes2):
+    """Computes IoU overlaps between two sets of boxes.
+    boxes1, boxes2: [N, (y1, x1, y2, x2)].
+    # 1. Tile boxes2 and repeate boxes1. This allows us to compare
+    # every boxes1 against every boxes2 without loops.
+    # TF doesn't have an equivalent to np.repeate() so simulate it
+    # using tf.tile() and tf.reshape.
+    b1 = tf.reshape(tf.tile(tf.expand_dims(boxes1, 1),
+                            [1, 1, tf.shape(boxes2)[0]]), [-1, 4])
+    b2 = tf.tile(boxes2, [tf.shape(boxes1)[0], 1])
+    # 2. Compute intersections
+    b1_y1, b1_x1, b1_y2, b1_x2 = tf.split(b1, 4, axis=1)
+    b2_y1, b2_x1, b2_y2, b2_x2 = tf.split(b2, 4, axis=1)
+    y1 = tf.maximum(b1_y1, b2_y1)
+    x1 = tf.maximum(b1_x1, b2_x1)
+    y2 = tf.minimum(b1_y2, b2_y2)
+    x2 = tf.minimum(b1_x2, b2_x2)
+    intersection = tf.maximum(x2 - x1, 0) * tf.maximum(y2 - y1, 0)
+    # 3. Compute unions
+    b1_area = (b1_y2 - b1_y1) * (b1_x2 - b1_x1)
+    b2_area = (b2_y2 - b2_y1) * (b2_x2 - b2_x1)
+    union = b1_area + b2_area - intersection
+    # 4. Compute IoU and reshape to [boxes1, boxes2]
+    iou = intersection / union
+    overlaps = tf.reshape(iou, [tf.shape(boxes1)[0], tf.shape(boxes2)[0]])
+    return overlaps
+def detection_targets_graph(proposals, gt_class_ids, gt_boxes, gt_masks, config):
+    """Generates detection targets for one image. Subsamples proposals and
+    generates target class IDs, bounding box deltas, and masks for each.
+    Inputs:
+    proposals: [N, (y1, x1, y2, x2)] in normalized coordinates. Might
+               be zero padded if there are not enough proposals.
+    gt_class_ids: [MAX_GT_INSTANCES] int class IDs
+    gt_boxes: [MAX_GT_INSTANCES, (y1, x1, y2, x2)] in normalized coordinates.
+    gt_masks: [height, width, MAX_GT_INSTANCES] of boolean type.
+    Returns: Target ROIs and corresponding class IDs, bounding box shifts,
+    and masks.
+    rois: [TRAIN_ROIS_PER_IMAGE, (y1, x1, y2, x2)] in normalized coordinates
+    class_ids: [TRAIN_ROIS_PER_IMAGE]. Integer class IDs. Zero padded.
+    deltas: [TRAIN_ROIS_PER_IMAGE, NUM_CLASSES, (dy, dx, log(dh), log(dw))]
+            Class-specific bbox refinements.
+    masks: [TRAIN_ROIS_PER_IMAGE, height, width). Masks cropped to bbox
+           boundaries and resized to neural network output size.
+    Note: Returned arrays might be zero padded if not enough target ROIs.
+    # Assertions
+    asserts = [
+        tf.Assert(tf.greater(tf.shape(proposals)[0], 0), [proposals],
+                  name="roi_assertion"),
+    with tf.control_dependencies(asserts):
+        proposals = tf.identity(proposals)
+    # Remove zero padding
+    proposals, _ = trim_zeros_graph(proposals, name="trim_proposals")
+    gt_boxes, non_zeros = trim_zeros_graph(gt_boxes, name="trim_gt_boxes")
+    gt_class_ids = tf.boolean_mask(gt_class_ids, non_zeros,
+                                   name="trim_gt_class_ids")
+    gt_masks = tf.gather(gt_masks, tf.where(non_zeros)[:, 0], axis=2,
+                         name="trim_gt_masks")
+    # Handle COCO crowds
+    # A crowd box in COCO is a bounding box around several instances. Exclude
+    # them from training. A crowd box is given a negative class ID.
+    crowd_ix = tf.where(gt_class_ids < 0)[:, 0]
+    non_crowd_ix = tf.where(gt_class_ids > 0)[:, 0]
+    crowd_boxes = tf.gather(gt_boxes, crowd_ix)
+    crowd_masks = tf.gather(gt_masks, crowd_ix, axis=2)
+    gt_class_ids = tf.gather(gt_class_ids, non_crowd_ix)
+    gt_boxes = tf.gather(gt_boxes, non_crowd_ix)
+    gt_masks = tf.gather(gt_masks, non_crowd_ix, axis=2)
+    # Compute overlaps matrix [proposals, gt_boxes]
+    overlaps = overlaps_graph(proposals, gt_boxes)
+    # Compute overlaps with crowd boxes [anchors, crowds]
+    crowd_overlaps = overlaps_graph(proposals, crowd_boxes)
+    crowd_iou_max = tf.reduce_max(crowd_overlaps, axis=1)
+    no_crowd_bool = (crowd_iou_max < 0.001)
+    # Determine postive and negative ROIs
+    roi_iou_max = tf.reduce_max(overlaps, axis=1)
+    # 1. Positive ROIs are those with >= 0.5 IoU with a GT box
+    positive_roi_bool = (roi_iou_max >= 0.5)
+    positive_indices = tf.where(positive_roi_bool)[:, 0]
+    # 2. Negative ROIs are those with < 0.5 with every GT box. Skip crowds.
+    negative_indices = tf.where(tf.logical_and(roi_iou_max < 0.5, no_crowd_bool))[:, 0]
+    # Subsample ROIs. Aim for 33% positive
+    # Positive ROIs
+    positive_count = int(config.TRAIN_ROIS_PER_IMAGE *
+                         config.ROI_POSITIVE_RATIO)
+    positive_indices = tf.random_shuffle(positive_indices)[:positive_count]
+    positive_count = tf.shape(positive_indices)[0]
+    # Negative ROIs. Add enough to maintain positive:negative ratio.
+    r = 1.0 / config.ROI_POSITIVE_RATIO
+    negative_count = tf.cast(r * tf.cast(positive_count, tf.float32), tf.int32) - positive_count
+    negative_indices = tf.random_shuffle(negative_indices)[:negative_count]
+    # Gather selected ROIs
+    positive_rois = tf.gather(proposals, positive_indices)
+    negative_rois = tf.gather(proposals, negative_indices)
+    # Assign positive ROIs to GT boxes.
+    positive_overlaps = tf.gather(overlaps, positive_indices)
+    roi_gt_box_assignment = tf.argmax(positive_overlaps, axis=1)
+    roi_gt_boxes = tf.gather(gt_boxes, roi_gt_box_assignment)
+    roi_gt_class_ids = tf.gather(gt_class_ids, roi_gt_box_assignment)
+    # Compute bbox refinement for positive ROIs
+    deltas = utils.box_refinement_graph(positive_rois, roi_gt_boxes)
+    deltas /= config.BBOX_STD_DEV
+    # Assign positive ROIs to GT masks
+    # Permute masks to [N, height, width, 1]
+    transposed_masks = tf.expand_dims(tf.transpose(gt_masks, [2, 0, 1]), -1)
+    # Pick the right mask for each ROI
+    roi_masks = tf.gather(transposed_masks, roi_gt_box_assignment)
+    # Compute mask targets
+    boxes = positive_rois
+    if config.USE_MINI_MASK:
+        # Transform ROI corrdinates from normalized image space
+        # to normalized mini-mask space.
+        y1, x1, y2, x2 = tf.split(positive_rois, 4, axis=1)
+        gt_y1, gt_x1, gt_y2, gt_x2 = tf.split(roi_gt_boxes, 4, axis=1)
+        gt_h = gt_y2 - gt_y1
+        gt_w = gt_x2 - gt_x1
+        y1 = (y1 - gt_y1) / gt_h
+        x1 = (x1 - gt_x1) / gt_w
+        y2 = (y2 - gt_y1) / gt_h
+        x2 = (x2 - gt_x1) / gt_w
+        boxes = tf.concat([y1, x1, y2, x2], 1)
+    box_ids = tf.range(0, tf.shape(roi_masks)[0])
+    masks = tf.image.crop_and_resize(tf.cast(roi_masks, tf.float32), boxes,
+                                     box_ids,
+                                     config.MASK_SHAPE)
+    # Remove the extra dimension from masks.
+    masks = tf.squeeze(masks, axis=3)
+    # Threshold mask pixels at 0.5 to have GT masks be 0 or 1 to use with
+    # binary cross entropy loss.
+    masks = tf.round(masks)
+    # Append negative ROIs and pad bbox deltas and masks that
+    # are not used for negative ROIs with zeros.
+    rois = tf.concat([positive_rois, negative_rois], axis=0)
+    N = tf.shape(negative_rois)[0]
+    P = tf.maximum(config.TRAIN_ROIS_PER_IMAGE - tf.shape(rois)[0], 0)
+    rois = tf.pad(rois, [(0, P), (0, 0)])
+    roi_gt_boxes = tf.pad(roi_gt_boxes, [(0, N + P), (0, 0)])
+    roi_gt_class_ids = tf.pad(roi_gt_class_ids, [(0, N + P)])
+    deltas = tf.pad(deltas, [(0, N + P), (0, 0)])
+    masks = tf.pad(masks, [[0, N + P], (0, 0), (0, 0)])
+    return rois, roi_gt_class_ids, deltas, masks
+class DetectionTargetLayer(KE.Layer):
+    """Subsamples proposals and generates target box refinement, class_ids,
+    and masks for each.
+    Inputs:
+    proposals: [batch, N, (y1, x1, y2, x2)] in normalized coordinates. Might
+    gt_class_ids: [batch, MAX_GT_INSTANCES] Integer class IDs.
+    gt_boxes: [batch, MAX_GT_INSTANCES, (y1, x1, y2, x2)] in normalized
+              coordinates.
+    gt_masks: [batch, height, width, MAX_GT_INSTANCES] of boolean type
+    and masks.
+    rois: [batch, TRAIN_ROIS_PER_IMAGE, (y1, x1, y2, x2)] in normalized
+          coordinates
+    target_class_ids: [batch, TRAIN_ROIS_PER_IMAGE]. Integer class IDs.
+    target_deltas: [batch, TRAIN_ROIS_PER_IMAGE, NUM_CLASSES,
+                    (dy, dx, log(dh), log(dw), class_id)]
+    target_mask: [batch, TRAIN_ROIS_PER_IMAGE, height, width)
+                 Masks cropped to bbox boundaries and resized to neural
+                 network output size.
+    def __init__(self, config, **kwargs):
+        super(DetectionTargetLayer, self).__init__(**kwargs)
+        proposals = inputs[0]
+        gt_class_ids = inputs[1]
+        gt_boxes = inputs[2]
+        gt_masks = inputs[3]
+        # Slice the batch and run a graph for each slice
+        # TODO: Rename target_bbox to target_deltas for clarity
+        names = ["rois", "target_class_ids", "target_bbox", "target_mask"]
+        outputs = utils.batch_slice(
+            [proposals, gt_class_ids, gt_boxes, gt_masks],
+            lambda w, x, y, z: detection_targets_graph(
+                w, x, y, z, self.config),
+            self.config.IMAGES_PER_GPU, names=names)
+        return outputs
+        return [
+            (None, self.config.TRAIN_ROIS_PER_IMAGE, 4),  # rois
+            (None, 1),  # class_ids
+            (None, self.config.TRAIN_ROIS_PER_IMAGE, 4),  # deltas
+            (None, self.config.TRAIN_ROIS_PER_IMAGE, self.config.MASK_SHAPE[0],
+             self.config.MASK_SHAPE[1])  # masks
+    def compute_mask(self, inputs, mask=None):
+        return [None, None, None, None]
+#  Detection Layer
+def refine_detections_graph(rois, probs, deltas, window, config):
+    """Refine classified proposals and filter overlaps and return final
+    detections.
+    Inputs:
+        rois: [N, (y1, x1, y2, x2)] in normalized coordinates
+        probs: [N, num_classes]. Class probabilities.
+        deltas: [N, num_classes, (dy, dx, log(dh), log(dw))]. Class-specific
+                bounding box deltas.
+        window: (y1, x1, y2, x2) in image coordinates. The part of the image
+            that contains the image excluding the padding.
+    Returns detections shaped: [N, (y1, x1, y2, x2, class_id, score)] where
+        coordinates are normalized.
+    # Class IDs per ROI
+    class_ids = tf.argmax(probs, axis=1, output_type=tf.int32)
+    # Class probability of the top class of each ROI
+    indices = tf.stack([tf.range(probs.shape[0]), class_ids], axis=1)
+    class_scores = tf.gather_nd(probs, indices)
+    # Class-specific bounding box deltas
+    deltas_specific = tf.gather_nd(deltas, indices)
+    # Apply bounding box deltas
+    # Shape: [boxes, (y1, x1, y2, x2)] in normalized coordinates
+    refined_rois = apply_box_deltas_graph(
+        rois, deltas_specific * config.BBOX_STD_DEV)
+    # Clip boxes to image window
+    refined_rois = clip_boxes_graph(refined_rois, window)
+    # TODO: Filter out boxes with zero area
+    # Filter out background boxes
+    keep = tf.where(class_ids > 0)[:, 0]
+    # Filter out low confidence boxes
+    if config.DETECTION_MIN_CONFIDENCE:
+        conf_keep = tf.where(class_scores >= config.DETECTION_MIN_CONFIDENCE)[:, 0]
+        keep = tf.sets.set_intersection(tf.expand_dims(keep, 0),
+                                        tf.expand_dims(conf_keep, 0))
+        keep = tf.sparse_tensor_to_dense(keep)[0]
+    # Apply per-class NMS
+    # 1. Prepare variables
+    pre_nms_class_ids = tf.gather(class_ids, keep)
+    pre_nms_scores = tf.gather(class_scores, keep)
+    pre_nms_rois = tf.gather(refined_rois,   keep)
+    unique_pre_nms_class_ids = tf.unique(pre_nms_class_ids)[0]
+    def nms_keep_map(class_id):
+        """Apply Non-Maximum Suppression on ROIs of the given class."""
+        # Indices of ROIs of the given class
+        ixs = tf.where(tf.equal(pre_nms_class_ids, class_id))[:, 0]
+        # Apply NMS
+        class_keep = tf.image.non_max_suppression(
+                tf.gather(pre_nms_rois, ixs),
+                tf.gather(pre_nms_scores, ixs),
+                max_output_size=config.DETECTION_MAX_INSTANCES,
+                iou_threshold=config.DETECTION_NMS_THRESHOLD)
+        # Map indicies
+        class_keep = tf.gather(keep, tf.gather(ixs, class_keep))
+        # Pad with -1 so returned tensors have the same shape
+        gap = config.DETECTION_MAX_INSTANCES - tf.shape(class_keep)[0]
+        class_keep = tf.pad(class_keep, [(0, gap)],
+                            mode='CONSTANT', constant_values=-1)
+        # Set shape so map_fn() can infer result shape
+        class_keep.set_shape([config.DETECTION_MAX_INSTANCES])
+        return class_keep
+    # 2. Map over class IDs
+    nms_keep = tf.map_fn(nms_keep_map, unique_pre_nms_class_ids,
+                         dtype=tf.int64)
+    # 3. Merge results into one list, and remove -1 padding
+    nms_keep = tf.reshape(nms_keep, [-1])
+    nms_keep = tf.gather(nms_keep, tf.where(nms_keep > -1)[:, 0])
+    # 4. Compute intersection between keep and nms_keep
+                                    tf.expand_dims(nms_keep, 0))
+    # Keep top detections
+    roi_count = config.DETECTION_MAX_INSTANCES
+    class_scores_keep = tf.gather(class_scores, keep)
+    num_keep = tf.minimum(tf.shape(class_scores_keep)[0], roi_count)
+    top_ids = tf.nn.top_k(class_scores_keep, k=num_keep, sorted=True)[1]
+    keep = tf.gather(keep, top_ids)
+    # Arrange output as [N, (y1, x1, y2, x2, class_id, score)]
+    # Coordinates are normalized.
+    detections = tf.concat([
+        tf.gather(refined_rois, keep),
+        tf.to_float(tf.gather(class_ids, keep))[..., tf.newaxis],
+        tf.gather(class_scores, keep)[..., tf.newaxis]
+        ], axis=1)
+    # Pad with zeros if detections < DETECTION_MAX_INSTANCES
+    gap = config.DETECTION_MAX_INSTANCES - tf.shape(detections)[0]
+    detections = tf.pad(detections, [(0, gap), (0, 0)], "CONSTANT")
+    return detections
+class DetectionLayer(KE.Layer):
+    """Takes classified proposal boxes and their bounding box deltas and
+    returns the final detection boxes.
+    Returns:
+    [batch, num_detections, (y1, x1, y2, x2, class_id, class_score)] where
+    def __init__(self, config=None, **kwargs):
+        super(DetectionLayer, self).__init__(**kwargs)
+        rois = inputs[0]
+        mrcnn_class = inputs[1]
+        mrcnn_bbox = inputs[2]
+        image_meta = inputs[3]
+        # Get windows of images in normalized coordinates. Windows are the area
+        # in the image that excludes the padding.
+        # Use the shape of the first image in the batch to normalize the window
+        # because we know that all images get resized to the same size.
+        m = parse_image_meta_graph(image_meta)
+        image_shape = m['image_shape'][0]
+        window = norm_boxes_graph(m['window'], image_shape[:2])
+        # Run detection refinement graph on each item in the batch
+        detections_batch = utils.batch_slice(
+            [rois, mrcnn_class, mrcnn_bbox, window],
+            lambda x, y, w, z: refine_detections_graph(x, y, w, z, self.config),
+        # Reshape output
+        # [batch, num_detections, (y1, x1, y2, x2, class_score)] in
+        # normalized coordinates
+        return tf.reshape(
+            detections_batch,
+            [self.config.BATCH_SIZE, self.config.DETECTION_MAX_INSTANCES, 6])
+        return (None, self.config.DETECTION_MAX_INSTANCES, 6)
+#  Region Proposal Network (RPN)
+def rpn_graph(feature_map, anchors_per_location, anchor_stride):
+    """Builds the computation graph of Region Proposal Network.
+    feature_map: backbone features [batch, height, width, depth]
+    anchors_per_location: number of anchors per pixel in the feature map
+    anchor_stride: Controls the density of anchors. Typically 1 (anchors for
+                   every pixel in the feature map), or 2 (every other pixel).
+    Returns:
+        rpn_logits: [batch, H, W, 2] Anchor classifier logits (before softmax)
+        rpn_probs: [batch, H, W, 2] Anchor classifier probabilities.
+        rpn_bbox: [batch, H, W, (dy, dx, log(dh), log(dw))] Deltas to be
+                  applied to anchors.
+    # TODO: check if stride of 2 causes alignment issues if the featuremap
+    #       is not even.
+    # Shared convolutional base of the RPN
+    shared = KL.Conv2D(512, (3, 3), padding='same', activation='relu',
+                       strides=anchor_stride,
+                       name='rpn_conv_shared')(feature_map)
+    # Anchor Score. [batch, height, width, anchors per location * 2].
+    x = KL.Conv2D(2 * anchors_per_location, (1, 1), padding='valid',
+                  activation='linear', name='rpn_class_raw')(shared)
+    # Reshape to [batch, anchors, 2]
+    rpn_class_logits = KL.Lambda(
+        lambda t: tf.reshape(t, [tf.shape(t)[0], -1, 2]))(x)
+    # Softmax on last dimension of BG/FG.
+    rpn_probs = KL.Activation(
+        "softmax", name="rpn_class_xxx")(rpn_class_logits)
+    # Bounding box refinement. [batch, H, W, anchors per location, depth]
+    # where depth is [x, y, log(w), log(h)]
+    x = KL.Conv2D(anchors_per_location * 4, (1, 1), padding="valid",
+                  activation='linear', name='rpn_bbox_pred')(shared)
+    # Reshape to [batch, anchors, 4]
+    rpn_bbox = KL.Lambda(lambda t: tf.reshape(t, [tf.shape(t)[0], -1, 4]))(x)
+    return [rpn_class_logits, rpn_probs, rpn_bbox]
+def build_rpn_model(anchor_stride, anchors_per_location, depth):
+    """Builds a Keras model of the Region Proposal Network.
+    It wraps the RPN graph so it can be used multiple times with shared
+    weights.
+    depth: Depth of the backbone feature map.
+    Returns a Keras Model object. The model outputs, when called, are:
+    rpn_probs: [batch, W, W, 2] Anchor classifier probabilities.
+    input_feature_map = KL.Input(shape=[None, None, depth],
+                                 name="input_rpn_feature_map")
+    outputs = rpn_graph(input_feature_map, anchors_per_location, anchor_stride)
+    return KM.Model([input_feature_map], outputs, name="rpn_model")
+#  Feature Pyramid Network Heads
+def fpn_classifier_graph(rois, feature_maps, image_meta,
+                         pool_size, num_classes, train_bn=True):
+    """Builds the computation graph of the feature pyramid network classifier
+    and regressor heads.
+    rois: [batch, num_rois, (y1, x1, y2, x2)] Proposal boxes in normalized
+          coordinates.
+    feature_maps: List of feature maps from diffent layers of the pyramid,
+                  [P2, P3, P4, P5]. Each has a different resolution.
+    pool_size: The width of the square feature map generated from ROI Pooling.
+    num_classes: number of classes, which determines the depth of the results
+    Returns:
+        logits: [N, NUM_CLASSES] classifier logits (before softmax)
+        probs: [N, NUM_CLASSES] classifier probabilities
+        bbox_deltas: [N, (dy, dx, log(dh), log(dw))] Deltas to apply to
+                     proposal boxes
+    # ROI Pooling
+    # Shape: [batch, num_boxes, pool_height, pool_width, channels]
+    x = PyramidROIAlign([pool_size, pool_size],
+                        name="roi_align_classifier")(
+                            [rois, image_meta] + feature_maps)
+    # Two 1024 FC layers (implemented with Conv2D for consistency)
+    x = KL.TimeDistributed(KL.Conv2D(1024, (pool_size, pool_size), padding="valid"),
+                           name="mrcnn_class_conv1")(x)
+    x = KL.TimeDistributed(BatchNorm(), name='mrcnn_class_bn1')(x, training=train_bn)
+    x = KL.TimeDistributed(KL.Conv2D(1024, (1, 1)),
+                           name="mrcnn_class_conv2")(x)
+    x = KL.TimeDistributed(BatchNorm(), name='mrcnn_class_bn2')(x, training=train_bn)
+    shared = KL.Lambda(lambda x: K.squeeze(K.squeeze(x, 3), 2),
+                       name="pool_squeeze")(x)
+    # Classifier head
+    mrcnn_class_logits = KL.TimeDistributed(KL.Dense(num_classes),
+                                            name='mrcnn_class_logits')(shared)
+    mrcnn_probs = KL.TimeDistributed(KL.Activation("softmax"),
+                                     name="mrcnn_class")(mrcnn_class_logits)
+    # BBox head
+    # [batch, boxes, num_classes * (dy, dx, log(dh), log(dw))]
+    x = KL.TimeDistributed(KL.Dense(num_classes * 4, activation='linear'),
+                           name='mrcnn_bbox_fc')(shared)
+    # Reshape to [batch, boxes, num_classes, (dy, dx, log(dh), log(dw))]
+    s = K.int_shape(x)
+    mrcnn_bbox = KL.Reshape((s[1], num_classes, 4), name="mrcnn_bbox")(x)
+    return mrcnn_class_logits, mrcnn_probs, mrcnn_bbox
+def build_fpn_mask_graph(rois, feature_maps, image_meta,
+    """Builds the computation graph of the mask head of Feature Pyramid Network.
+          coordinates.
+    image_meta: [batch, (meta data)] Image details. See compose_image_meta()
+    Returns: Masks [batch, roi_count, height, width, num_classes]
+    # ROI Pooling
+    # Shape: [batch, boxes, pool_height, pool_width, channels]
+                        name="roi_align_mask")([rois, image_meta] + feature_maps)
+    # Conv layers
+    x = KL.TimeDistributed(KL.Conv2D(256, (3, 3), padding="same"),
+                           name="mrcnn_mask_conv1")(x)
+                           name='mrcnn_mask_bn1')(x, training=train_bn)
+                           name="mrcnn_mask_conv2")(x)
+                           name='mrcnn_mask_bn2')(x, training=train_bn)
+                           name="mrcnn_mask_conv3")(x)
+                           name='mrcnn_mask_bn3')(x, training=train_bn)
+                           name="mrcnn_mask_conv4")(x)
+                           name='mrcnn_mask_bn4')(x, training=train_bn)
+    x = KL.TimeDistributed(KL.Conv2DTranspose(256, (2, 2), strides=2, activation="relu"),
+                           name="mrcnn_mask_deconv")(x)
+    x = KL.TimeDistributed(KL.Conv2D(num_classes, (1, 1), strides=1, activation="sigmoid"),
+                           name="mrcnn_mask")(x)
+    return x
+#  Loss Functions
+def smooth_l1_loss(y_true, y_pred):
+    """Implements Smooth-L1 loss.
+    y_true and y_pred are typicallly: [N, 4], but could be any shape.
+    diff = K.abs(y_true - y_pred)
+    less_than_one = K.cast(K.less(diff, 1.0), "float32")
+    loss = (less_than_one * 0.5 * diff**2) + (1 - less_than_one) * (diff - 0.5)
+    return loss
+def rpn_class_loss_graph(rpn_match, rpn_class_logits):
+    """RPN anchor classifier loss.
+    rpn_match: [batch, anchors, 1]. Anchor match type. 1=positive,
+               -1=negative, 0=neutral anchor.
+    rpn_class_logits: [batch, anchors, 2]. RPN classifier logits for FG/BG.
+    # Squeeze last dim to simplify
+    rpn_match = tf.squeeze(rpn_match, -1)
+    # Get anchor classes. Convert the -1/+1 match to 0/1 values.
+    anchor_class = K.cast(K.equal(rpn_match, 1), tf.int32)
+    # Positive and Negative anchors contribute to the loss,
+    # but neutral anchors (match value = 0) don't.
+    indices = tf.where(K.not_equal(rpn_match, 0))
+    # Pick rows that contribute to the loss and filter out the rest.
+    rpn_class_logits = tf.gather_nd(rpn_class_logits, indices)
+    anchor_class = tf.gather_nd(anchor_class, indices)
+    # Crossentropy loss
+    loss = K.sparse_categorical_crossentropy(target=anchor_class,
+                                             output=rpn_class_logits,
+                                             from_logits=True)
+    loss = K.switch(tf.size(loss) > 0, K.mean(loss), tf.constant(0.0))
+    return loss
+def rpn_bbox_loss_graph(config, target_bbox, rpn_match, rpn_bbox):
+    """Return the RPN bounding box loss graph.
+    config: the model config object.
+    target_bbox: [batch, max positive anchors, (dy, dx, log(dh), log(dw))].
+        Uses 0 padding to fill in unsed bbox deltas.
+    # Positive anchors contribute to the loss, but negative and
+    # neutral anchors (match value of 0 or -1) don't.
+    rpn_match = K.squeeze(rpn_match, -1)
+    indices = tf.where(K.equal(rpn_match, 1))
+    # Pick bbox deltas that contribute to the loss
+    rpn_bbox = tf.gather_nd(rpn_bbox, indices)
+    # Trim target bounding box deltas to the same length as rpn_bbox.
+    batch_counts = K.sum(K.cast(K.equal(rpn_match, 1), tf.int32), axis=1)
+    target_bbox = batch_pack_graph(target_bbox, batch_counts,
+                                   config.IMAGES_PER_GPU)
+    # TODO: use smooth_l1_loss() rather than reimplementing here
+    #       to reduce code duplication
+    diff = K.abs(target_bbox - rpn_bbox)
+    return loss
+def mrcnn_class_loss_graph(target_class_ids, pred_class_logits,
+                           active_class_ids):
+    """Loss for the classifier head of Mask RCNN.
+    target_class_ids: [batch, num_rois]. Integer class IDs. Uses zero
+        padding to fill in the array.
+    pred_class_logits: [batch, num_rois, num_classes]
+    active_class_ids: [batch, num_classes]. Has a value of 1 for
+        classes that are in the dataset of the image, and 0
+        for classes that are not in the dataset.
+    # During model building, Keras calls this function with
+    # target_class_ids of type float32. Unclear why. Cast it
+    # to int to get around it.
+    target_class_ids = tf.cast(target_class_ids, 'int64')
+    # Find predictions of classes that are not in the dataset.
+    pred_class_ids = tf.argmax(pred_class_logits, axis=2)
+    # TODO: Update this line to work with batch > 1. Right now it assumes all
+    #       images in a batch have the same active_class_ids
+    pred_active = tf.gather(active_class_ids[0], pred_class_ids)
+    # Loss
+    loss = tf.nn.sparse_softmax_cross_entropy_with_logits(
+        labels=target_class_ids, logits=pred_class_logits)
+    # Erase losses of predictions of classes that are not in the active
+    # classes of the image.
+    loss = loss * pred_active
+    # Computer loss mean. Use only predictions that contribute
+    # to the loss to get a correct mean.
+    loss = tf.reduce_sum(loss) / tf.reduce_sum(pred_active)
+    return loss
+def mrcnn_bbox_loss_graph(target_bbox, target_class_ids, pred_bbox):
+    """Loss for Mask R-CNN bounding box refinement.
+    target_bbox: [batch, num_rois, (dy, dx, log(dh), log(dw))]
+    pred_bbox: [batch, num_rois, num_classes, (dy, dx, log(dh), log(dw))]
+    # Reshape to merge batch and roi dimensions for simplicity.
+    target_class_ids = K.reshape(target_class_ids, (-1,))
+    target_bbox = K.reshape(target_bbox, (-1, 4))
+    pred_bbox = K.reshape(pred_bbox, (-1, K.int_shape(pred_bbox)[2], 4))
+    # Only positive ROIs contribute to the loss. And only
+    # the right class_id of each ROI. Get their indicies.
+    positive_roi_ix = tf.where(target_class_ids > 0)[:, 0]
+    positive_roi_class_ids = tf.cast(
+        tf.gather(target_class_ids, positive_roi_ix), tf.int64)
+    indices = tf.stack([positive_roi_ix, positive_roi_class_ids], axis=1)
+    # Gather the deltas (predicted and true) that contribute to loss
+    target_bbox = tf.gather(target_bbox, positive_roi_ix)
+    pred_bbox = tf.gather_nd(pred_bbox, indices)
+    # Smooth-L1 Loss
+    loss = K.switch(tf.size(target_bbox) > 0,
+                    smooth_l1_loss(y_true=target_bbox, y_pred=pred_bbox),
+                    tf.constant(0.0))
+    loss = K.mean(loss)
+    return loss
+def mrcnn_mask_loss_graph(target_masks, target_class_ids, pred_masks):
+    """Mask binary cross-entropy loss for the masks head.
+    target_masks: [batch, num_rois, height, width].
+        A float32 tensor of values 0 or 1. Uses zero padding to fill array.
+    target_class_ids: [batch, num_rois]. Integer class IDs. Zero padded.
+    pred_masks: [batch, proposals, height, width, num_classes] float32 tensor
+                with values from 0 to 1.
+    # Reshape for simplicity. Merge first two dimensions into one.
+    mask_shape = tf.shape(target_masks)
+    target_masks = K.reshape(target_masks, (-1, mask_shape[2], mask_shape[3]))
+    pred_shape = tf.shape(pred_masks)
+    pred_masks = K.reshape(pred_masks,
+                           (-1, pred_shape[2], pred_shape[3], pred_shape[4]))
+    # Permute predicted masks to [N, num_classes, height, width]
+    pred_masks = tf.transpose(pred_masks, [0, 3, 1, 2])
+    # the class specific mask of each ROI.
+    positive_ix = tf.where(target_class_ids > 0)[:, 0]
+    positive_class_ids = tf.cast(
+        tf.gather(target_class_ids, positive_ix), tf.int64)
+    indices = tf.stack([positive_ix, positive_class_ids], axis=1)
+    # Gather the masks (predicted and true) that contribute to loss
+    y_true = tf.gather(target_masks, positive_ix)
+    y_pred = tf.gather_nd(pred_masks, indices)
+    # Compute binary cross entropy. If no positive ROIs, then return 0.
+    # shape: [batch, roi, num_classes]
+    loss = K.switch(tf.size(y_true) > 0,
+                    K.binary_crossentropy(target=y_true, output=y_pred),
+                    tf.constant(0.0))
+    return loss
+#  Data Generator
+def load_image_gt(dataset, config, image_id, augment=False, augmentation=None,
+                  use_mini_mask=False):
+    Load and return ground truth data for an image (image, mask, bounding boxes).
+    augment: (Depricated. Use augmentation instead). If true, apply random
+        image augmentation. Currently, only horizontal flipping is offered.
+    augmentation: Optional. An imgaug (https://github.com/aleju/imgaug) augmentation.
+        For example, passing imgaug.augmenters.Fliplr(0.5) flips images
+        right/left 50% of the time.
+    use_mini_mask: If False, returns full-size masks that are the same height
+        and width as the original image. These can be big, for example
+        1024x1024x100 (for 100 instances). Mini masks are smaller, typically,
+        224x224 and are generated by extracting the bounding box of the
+        object and resizing it to MINI_MASK_SHAPE.
+    Returns:
+    image: [height, width, 3]
+    shape: the original shape of the image before resizing and cropping.
+    class_ids: [instance_count] Integer class IDs
+    bbox: [instance_count, (y1, x1, y2, x2)]
+    mask: [height, width, instance_count]. The height and width are those
+        of the image unless use_mini_mask is True, in which case they are
+        defined in MINI_MASK_SHAPE.
+    # Load image and mask
+    image = dataset.load_image(image_id)
+    mask, class_ids, error = dataset.get_mask(image_id)
+    if error:
+        return None, None, None, None, None, 1
+    original_shape = image.shape
+    image, window, scale, padding, crop = utils.resize_image(
+        image,
+        min_dim=config.IMAGE_MIN_DIM,
+        min_scale=config.IMAGE_MIN_SCALE,
+        max_dim=config.IMAGE_MAX_DIM,
+        mode=config.IMAGE_RESIZE_MODE)
+    mask = utils.resize_mask(mask, scale, padding, crop)
+    # Random horizontal flips.
+    # TODO: will be removed in a future update in favor of augmentation
+    if augment:
+        logging.warning("'augment' is depricated. Use 'augmentation' instead.")
+        if random.randint(0, 1):
+            image = np.fliplr(image)
+            mask = np.fliplr(mask)
+    # Augmentation
+    # This requires the imgaug lib (https://github.com/aleju/imgaug)
+    if augmentation:
+        import imgaug
+        # Augmentors that are safe to apply to masks
+        # Some, such as Affine, have settings that make them unsafe, so always
+        # test your augmentation on masks
+        MASK_AUGMENTERS = ["Sequential", "SomeOf", "OneOf", "Sometimes",
+                           "Fliplr", "Flipud", "CropAndPad",
+                           "Affine", "PiecewiseAffine"]
+        def hook(images, augmenter, parents, default):
+            """Determines which augmenters to apply to masks."""
+            return (augmenter.__class__.__name__ in MASK_AUGMENTERS)
+        # Store shapes before augmentation to compare
+        image_shape = image.shape
+        mask_shape = mask.shape
+        # Make augmenters deterministic to apply similarly to images and masks
+        det = augmentation.to_deterministic()
+        image = det.augment_image(image)
+        # Change mask to np.uint8 because imgaug doesn't support np.bool
+        mask = det.augment_image(mask.astype(np.uint8),
+                                 hooks=imgaug.HooksImages(activator=hook))
+        # Verify that shapes didn't change
+        assert image.shape == image_shape, "Augmentation shouldn't change image size"
+        assert mask.shape == mask_shape, "Augmentation shouldn't change mask size"
+        # Change mask back to bool
+        mask = mask.astype(np.bool)
+    # Note that some boxes might be all zeros if the corresponding mask got cropped out.
+    # and here is to filter them out
+    _idx = np.sum(mask, axis=(0, 1)) > 0
+    mask = mask[:, :, _idx]
+    class_ids = class_ids[_idx]
+    # Bounding boxes. Note that some boxes might be all zeros
+    # if the corresponding mask got cropped out.
+    # bbox: [num_instances, (y1, x1, y2, x2)]
+    bbox = utils.extract_bboxes(mask)
+    # Active classes
+    # Different datasets have different classes, so track the
+    # classes supported in the dataset of this image.
+    active_class_ids = np.zeros([dataset.num_classes], dtype=np.int32)
+    source_class_ids = dataset.source_class_ids[dataset.image_info[image_id]["source"]]
+    active_class_ids[source_class_ids] = 1
+    # Resize masks to smaller size to reduce memory usage
+    if use_mini_mask:
+        mask = utils.minimize_mask(bbox, mask, config.MINI_MASK_SHAPE)
+    # Image meta data
+    image_meta = compose_image_meta(image_id, original_shape, image.shape,
+                                    window, scale, active_class_ids)
+    return image, image_meta, class_ids, bbox, mask, 0
+def build_detection_targets(rpn_rois, gt_class_ids, gt_boxes, gt_masks, config):
+    """Generate targets for training Stage 2 classifier and mask heads.
+    This is not used in normal training. It's useful for debugging or to train
+    the Mask RCNN heads without using the RPN head.
+    Inputs:
+    rpn_rois: [N, (y1, x1, y2, x2)] proposal boxes.
+    gt_class_ids: [instance count] Integer class IDs
+    gt_boxes: [instance count, (y1, x1, y2, x2)]
+    gt_masks: [height, width, instance count] Grund truth masks. Can be full
+              size or mini-masks.
+    Returns:
+    bboxes: [TRAIN_ROIS_PER_IMAGE, NUM_CLASSES, (y, x, log(h), log(w))]. Class-specific
+            bbox refinements.
+    masks: [TRAIN_ROIS_PER_IMAGE, height, width, NUM_CLASSES). Class specific masks cropped
+           to bbox boundaries and resized to neural network output size.
+    assert rpn_rois.shape[0] > 0
+    assert gt_class_ids.dtype == np.int32, "Expected int but got {}".format(
+        gt_class_ids.dtype)
+    assert gt_boxes.dtype == np.int32, "Expected int but got {}".format(
+        gt_boxes.dtype)
+    assert gt_masks.dtype == np.bool_, "Expected bool but got {}".format(
+        gt_masks.dtype)
+    # It's common to add GT Boxes to ROIs but we don't do that here because
+    # according to XinLei Chen's paper, it doesn't help.
+    # Trim empty padding in gt_boxes and gt_masks parts
+    instance_ids = np.where(gt_class_ids > 0)[0]
+    assert instance_ids.shape[0] > 0, "Image must contain instances."
+    gt_class_ids = gt_class_ids[instance_ids]
+    gt_boxes = gt_boxes[instance_ids]
+    gt_masks = gt_masks[:, :, instance_ids]
+    # Compute areas of ROIs and ground truth boxes.
+    rpn_roi_area = (rpn_rois[:, 2] - rpn_rois[:, 0]) * \
+        (rpn_rois[:, 3] - rpn_rois[:, 1])
+    gt_box_area = (gt_boxes[:, 2] - gt_boxes[:, 0]) * \
+        (gt_boxes[:, 3] - gt_boxes[:, 1])
+    # Compute overlaps [rpn_rois, gt_boxes]
+    overlaps = np.zeros((rpn_rois.shape[0], gt_boxes.shape[0]))
+    for i in range(overlaps.shape[1]):
+        gt = gt_boxes[i]
+        overlaps[:, i] = utils.compute_iou(
+            gt, rpn_rois, gt_box_area[i], rpn_roi_area)
+    # Assign ROIs to GT boxes
+    rpn_roi_iou_argmax = np.argmax(overlaps, axis=1)
+    rpn_roi_iou_max = overlaps[np.arange(
+        overlaps.shape[0]), rpn_roi_iou_argmax]
+    # GT box assigned to each ROI
+    rpn_roi_gt_boxes = gt_boxes[rpn_roi_iou_argmax]
+    rpn_roi_gt_class_ids = gt_class_ids[rpn_roi_iou_argmax]
+    # Positive ROIs are those with >= 0.5 IoU with a GT box.
+    fg_ids = np.where(rpn_roi_iou_max > 0.5)[0]
+    # Negative ROIs are those with max IoU 0.1-0.5 (hard example mining)
+    # TODO: To hard example mine or not to hard example mine, that's the question
+#     bg_ids = np.where((rpn_roi_iou_max >= 0.1) & (rpn_roi_iou_max < 0.5))[0]
+    bg_ids = np.where(rpn_roi_iou_max < 0.5)[0]
+    # Subsample ROIs. Aim for 33% foreground.
+    # FG
+    fg_roi_count = int(config.TRAIN_ROIS_PER_IMAGE * config.ROI_POSITIVE_RATIO)
+    if fg_ids.shape[0] > fg_roi_count:
+        keep_fg_ids = np.random.choice(fg_ids, fg_roi_count, replace=False)
+    else:
+        keep_fg_ids = fg_ids
+    # BG
+    remaining = config.TRAIN_ROIS_PER_IMAGE - keep_fg_ids.shape[0]
+    if bg_ids.shape[0] > remaining:
+        keep_bg_ids = np.random.choice(bg_ids, remaining, replace=False)
+    else:
+        keep_bg_ids = bg_ids
+    # Combine indicies of ROIs to keep
+    keep = np.concatenate([keep_fg_ids, keep_bg_ids])
+    # Need more?
+    remaining = config.TRAIN_ROIS_PER_IMAGE - keep.shape[0]
+    if remaining > 0:
+        # Looks like we don't have enough samples to maintain the desired
+        # balance. Reduce requirements and fill in the rest. This is
+        # likely different from the Mask RCNN paper.
+        # There is a small chance we have neither fg nor bg samples.
+        if keep.shape[0] == 0:
+            # Pick bg regions with easier IoU threshold
+            assert bg_ids.shape[0] >= remaining
+            assert keep_bg_ids.shape[0] == remaining
+            keep = np.concatenate([keep, keep_bg_ids])
+        else:
+            # Fill the rest with repeated bg rois.
+            keep_extra_ids = np.random.choice(
+                keep_bg_ids, remaining, replace=True)
+            keep = np.concatenate([keep, keep_extra_ids])
+    assert keep.shape[0] == config.TRAIN_ROIS_PER_IMAGE, \
+        "keep doesn't match ROI batch size {}, {}".format(
+            keep.shape[0], config.TRAIN_ROIS_PER_IMAGE)
+    # Reset the gt boxes assigned to BG ROIs.
+    rpn_roi_gt_boxes[keep_bg_ids, :] = 0
+    rpn_roi_gt_class_ids[keep_bg_ids] = 0
+    # For each kept ROI, assign a class_id, and for FG ROIs also add bbox refinement.
+    rois = rpn_rois[keep]
+    roi_gt_boxes = rpn_roi_gt_boxes[keep]
+    roi_gt_class_ids = rpn_roi_gt_class_ids[keep]
+    roi_gt_assignment = rpn_roi_iou_argmax[keep]
+    # Class-aware bbox deltas. [y, x, log(h), log(w)]
+    bboxes = np.zeros((config.TRAIN_ROIS_PER_IMAGE,
+                       config.NUM_CLASSES, 4), dtype=np.float32)
+    pos_ids = np.where(roi_gt_class_ids > 0)[0]
+    bboxes[pos_ids, roi_gt_class_ids[pos_ids]] = utils.box_refinement(
+        rois[pos_ids], roi_gt_boxes[pos_ids, :4])
+    # Normalize bbox refinements
+    bboxes /= config.BBOX_STD_DEV
+    # Generate class-specific target masks
+    masks = np.zeros((config.TRAIN_ROIS_PER_IMAGE, config.MASK_SHAPE[0], config.MASK_SHAPE[1], config.NUM_CLASSES),
+                     dtype=np.float32)
+    for i in pos_ids:
+        class_id = roi_gt_class_ids[i]
+        assert class_id > 0, "class id must be greater than 0"
+        gt_id = roi_gt_assignment[i]
+        class_mask = gt_masks[:, :, gt_id]
+            # Create a mask placeholder, the size of the image
+            placeholder = np.zeros(config.IMAGE_SHAPE[:2], dtype=bool)
+            # GT box
+            gt_y1, gt_x1, gt_y2, gt_x2 = gt_boxes[gt_id]
+            # Resize mini mask to size of GT box
+            placeholder[gt_y1:gt_y2, gt_x1:gt_x2] = \
+                np.round(skimage.transform.resize(
+                    class_mask,
+                    (gt_h, gt_w),
+                    order=1,
+                    mode="constant")).astype(bool)
+            # Place the mini batch in the placeholder
+            class_mask = placeholder
+        # Pick part of the mask and resize it
+        y1, x1, y2, x2 = rois[i].astype(np.int32)
+        m = class_mask[y1:y2, x1:x2]
+        mask = skimage.transform.resize(m, config.MASK_SHAPE, order=1,
+                                        mode="constant")
+        masks[i, :, :, class_id] = mask
+    return rois, roi_gt_class_ids, bboxes, masks
+def build_rpn_targets(image_shape, anchors, gt_class_ids, gt_boxes, config):
+    """Given the anchors and GT boxes, compute overlaps and identify positive
+    anchors and deltas to refine them to match their corresponding GT boxes.
+    anchors: [num_anchors, (y1, x1, y2, x2)]
+    gt_class_ids: [num_gt_boxes] Integer class IDs.
+    gt_boxes: [num_gt_boxes, (y1, x1, y2, x2)]
+    Returns:
+    rpn_match: [N] (int32) matches between anchors and GT boxes.
+               1 = positive anchor, -1 = negative anchor, 0 = neutral
+    rpn_bbox: [N, (dy, dx, log(dh), log(dw))] Anchor bbox deltas.
+    # RPN Match: 1 = positive anchor, -1 = negative anchor, 0 = neutral
+    rpn_match = np.zeros([anchors.shape[0]], dtype=np.int32)
+    # RPN bounding boxes: [max anchors per image, (dy, dx, log(dh), log(dw))]
+    rpn_bbox = np.zeros((config.RPN_TRAIN_ANCHORS_PER_IMAGE, 4))
+    crowd_ix = np.where(gt_class_ids < 0)[0]
+    if crowd_ix.shape[0] > 0:
+        # Filter out crowds from ground truth class IDs and boxes
+        non_crowd_ix = np.where(gt_class_ids > 0)[0]
+        crowd_boxes = gt_boxes[crowd_ix]
+        gt_class_ids = gt_class_ids[non_crowd_ix]
+        gt_boxes = gt_boxes[non_crowd_ix]
+        crowd_overlaps = utils.compute_overlaps(anchors, crowd_boxes)
+        crowd_iou_max = np.amax(crowd_overlaps, axis=1)
+    else:
+        # All anchors don't intersect a crowd
+        no_crowd_bool = np.ones([anchors.shape[0]], dtype=bool)
+    # Compute overlaps [num_anchors, num_gt_boxes]
+    overlaps = utils.compute_overlaps(anchors, gt_boxes)
+    # Match anchors to GT Boxes
+    # If an anchor overlaps a GT box with IoU >= 0.7 then it's positive.
+    # If an anchor overlaps a GT box with IoU < 0.3 then it's negative.
+    # Neutral anchors are those that don't match the conditions above,
+    # and they don't influence the loss function.
+    # However, don't keep any GT box unmatched (rare, but happens). Instead,
+    # match it to the closest anchor (even if its max IoU is < 0.3).
+    # 1. Set negative anchors first. They get overwritten below if a GT box is
+    # matched to them. Skip boxes in crowd areas.
+    anchor_iou_argmax = np.argmax(overlaps, axis=1)
+    anchor_iou_max = overlaps[np.arange(overlaps.shape[0]), anchor_iou_argmax]
+    rpn_match[(anchor_iou_max < 0.3) & (no_crowd_bool)] = -1
+    # 2. Set an anchor for each GT box (regardless of IoU value).
+    # TODO: If multiple anchors have the same IoU match all of them
+    gt_iou_argmax = np.argmax(overlaps, axis=0)
+    rpn_match[gt_iou_argmax] = 1
+    # 3. Set anchors with high overlap as positive.
+    rpn_match[anchor_iou_max >= 0.7] = 1
+    # Subsample to balance positive and negative anchors
+    # Don't let positives be more than half the anchors
+    ids = np.where(rpn_match == 1)[0]
+    extra = len(ids) - (config.RPN_TRAIN_ANCHORS_PER_IMAGE // 2)
+    if extra > 0:
+        # Reset the extra ones to neutral
+        ids = np.random.choice(ids, extra, replace=False)
+        rpn_match[ids] = 0
+    # Same for negative proposals
+    ids = np.where(rpn_match == -1)[0]
+    extra = len(ids) - (config.RPN_TRAIN_ANCHORS_PER_IMAGE -
+                        np.sum(rpn_match == 1))
+    if extra > 0:
+        # Rest the extra ones to neutral
+    # For positive anchors, compute shift and scale needed to transform them
+    # to match the corresponding GT boxes.
+    ix = 0  # index into rpn_bbox
+    # TODO: use box_refinement() rather than duplicating the code here
+    for i, a in zip(ids, anchors[ids]):
+        # Closest gt box (it might have IoU < 0.7)
+        gt = gt_boxes[anchor_iou_argmax[i]]
+        # Convert coordinates to center plus width/height.
+        # GT Box
+        gt_h = gt[2] - gt[0]
+        gt_w = gt[3] - gt[1]
+        gt_center_y = gt[0] + 0.5 * gt_h
+        gt_center_x = gt[1] + 0.5 * gt_w
+        # Anchor
+        a_h = a[2] - a[0]
+        a_w = a[3] - a[1]
+        a_center_y = a[0] + 0.5 * a_h
+        a_center_x = a[1] + 0.5 * a_w
+        # Compute the bbox refinement that the RPN should predict.
+        rpn_bbox[ix] = [
+            (gt_center_y - a_center_y) / a_h,
+            (gt_center_x - a_center_x) / a_w,
+            np.log(gt_h / a_h),
+            np.log(gt_w / a_w),
+        # Normalize
+        rpn_bbox[ix] /= config.RPN_BBOX_STD_DEV
+        ix += 1
+    return rpn_match, rpn_bbox
+def generate_random_rois(image_shape, count, gt_class_ids, gt_boxes):
+    """Generates ROI proposals similar to what a region proposal network
+    would generate.
+    image_shape: [Height, Width, Depth]
+    count: Number of ROIs to generate
+    gt_class_ids: [N] Integer ground truth class IDs
+    gt_boxes: [N, (y1, x1, y2, x2)] Ground truth boxes in pixels.
+    Returns: [count, (y1, x1, y2, x2)] ROI boxes in pixels.
+    # placeholder
+    rois = np.zeros((count, 4), dtype=np.int32)
+    # Generate random ROIs around GT boxes (90% of count)
+    rois_per_box = int(0.9 * count / gt_boxes.shape[0])
+    for i in range(gt_boxes.shape[0]):
+        gt_y1, gt_x1, gt_y2, gt_x2 = gt_boxes[i]
+        h = gt_y2 - gt_y1
+        w = gt_x2 - gt_x1
+        # random boundaries
+        r_y1 = max(gt_y1 - h, 0)
+        r_y2 = min(gt_y2 + h, image_shape[0])
+        r_x1 = max(gt_x1 - w, 0)
+        r_x2 = min(gt_x2 + w, image_shape[1])
+        # To avoid generating boxes with zero area, we generate double what
+        # we need and filter out the extra. If we get fewer valid boxes
+        # than we need, we loop and try again.
+        while True:
+            y1y2 = np.random.randint(r_y1, r_y2, (rois_per_box * 2, 2))
+            x1x2 = np.random.randint(r_x1, r_x2, (rois_per_box * 2, 2))
+            # Filter out zero area boxes
+            threshold = 1
+            y1y2 = y1y2[np.abs(y1y2[:, 0] - y1y2[:, 1]) >=
+                        threshold][:rois_per_box]
+            x1x2 = x1x2[np.abs(x1x2[:, 0] - x1x2[:, 1]) >=
+            if y1y2.shape[0] == rois_per_box and x1x2.shape[0] == rois_per_box:
+                break
+        # Sort on axis 1 to ensure x1 <= x2 and y1 <= y2 and then reshape
+        # into x1, y1, x2, y2 order
+        x1, x2 = np.split(np.sort(x1x2, axis=1), 2, axis=1)
+        y1, y2 = np.split(np.sort(y1y2, axis=1), 2, axis=1)
+        box_rois = np.hstack([y1, x1, y2, x2])
+        rois[rois_per_box * i:rois_per_box * (i + 1)] = box_rois
+    # Generate random ROIs anywhere in the image (10% of count)
+    remaining_count = count - (rois_per_box * gt_boxes.shape[0])
+    while True:
+        y1y2 = np.random.randint(0, image_shape[0], (remaining_count * 2, 2))
+        x1x2 = np.random.randint(0, image_shape[1], (remaining_count * 2, 2))
+        threshold = 1
+                    threshold][:remaining_count]
+        if y1y2.shape[0] == remaining_count and x1x2.shape[0] == remaining_count:
+            break
+    global_rois = np.hstack([y1, x1, y2, x2])
+    rois[-remaining_count:] = global_rois
+    return rois
+def data_generator(dataset, config, shuffle=True, augment=False, augmentation=None,
+                   random_rois=0, batch_size=1, detection_targets=False):
+    """A generator that returns images and corresponding target class ids,
+    bounding box deltas, and masks.
+    dataset: The Dataset object to pick data from
+    config: The model config object
+    shuffle: If True, shuffles the samples before every epoch
+    random_rois: If > 0 then generate proposals to be used to train the
+                 network classifier and mask heads. Useful if training
+                 the Mask RCNN part without the RPN.
+    batch_size: How many images to return in each call
+    detection_targets: If True, generate detection targets (class IDs, bbox
+        deltas, and masks). Typically for debugging or visualizations because
+        in trainig detection targets are generated by DetectionTargetLayer.
+    Returns a Python generator. Upon calling next() on it, the
+    generator returns two lists, inputs and outputs. The containtes
+    of the lists differs depending on the received arguments:
+    inputs list:
+    - images: [batch, H, W, C]
+    - rpn_match: [batch, N] Integer (1=positive anchor, -1=negative, 0=neutral)
+    - rpn_bbox: [batch, N, (dy, dx, log(dh), log(dw))] Anchor bbox deltas.
+    - gt_class_ids: [batch, MAX_GT_INSTANCES] Integer class IDs
+    - gt_boxes: [batch, MAX_GT_INSTANCES, (y1, x1, y2, x2)]
+    - gt_masks: [batch, height, width, MAX_GT_INSTANCES]. The height and width
+                are those of the image unless use_mini_mask is True, in which
+                case they are defined in MINI_MASK_SHAPE.
+    outputs list: Usually empty in regular training. But if detection_targets
+        is True then the outputs list contains target class_ids, bbox deltas,
+        and masks.
+    b = 0  # batch item index
+    image_index = -1
+    image_ids = np.copy(dataset.image_ids)
+    error_count = 0
+    # Anchors
+    # [anchor_count, (y1, x1, y2, x2)]
+    backbone_shapes = compute_backbone_shapes(config, config.IMAGE_SHAPE)
+    anchors = utils.generate_pyramid_anchors(config.RPN_ANCHOR_SCALES,
+                                             config.RPN_ANCHOR_RATIOS,
+                                             backbone_shapes,
+                                             config.BACKBONE_STRIDES,
+                                             config.RPN_ANCHOR_STRIDE)
+    # Keras requires a generator to run indefinately.
+    while True:
+        try:
+            # Increment index to pick next image. Shuffle if at the start of an epoch.
+            image_index = (image_index + 1) % len(image_ids)
+            if shuffle and image_index == 0:
+                np.random.shuffle(image_ids)
+            # Get GT bounding boxes and masks for image.
+            image_id = image_ids[image_index]
+            image, image_meta, gt_class_ids, gt_boxes, gt_masks, error = \
+                load_image_gt(dataset, config, image_id, augment=augment,
+                              augmentation=augmentation,
+                              use_mini_mask=config.USE_MINI_MASK)
+            if error:
+                import warnings
+                warnings.warn(
+                    'Problems while processing masks of image '
+                    '{}. This image is skipped in the training and should be checked.'.format(
+                        image_id),
+                    stacklevel=2)
+                continue
+            # Skip images that have no instances. This can happen in cases
+            # where we train on a subset of classes and the image doesn't
+            # have any of the classes we care about.
+            if not np.any(gt_class_ids > 0):
+                continue
+            # RPN Targets
+            rpn_match, rpn_bbox = build_rpn_targets(image.shape, anchors,
+                                                    gt_class_ids, gt_boxes, config)
+            # Mask R-CNN Targets
+            if random_rois:
+                rpn_rois = generate_random_rois(
+                    image.shape, random_rois, gt_class_ids, gt_boxes)
+                if detection_targets:
+                    rois, mrcnn_class_ids, mrcnn_bbox, mrcnn_mask =\
+                        build_detection_targets(
+                            rpn_rois, gt_class_ids, gt_boxes, gt_masks, config)
+            # Init batch arrays
+            if b == 0:
+                batch_image_meta = np.zeros(
+                    (batch_size,) + image_meta.shape, dtype=image_meta.dtype)
+                batch_rpn_match = np.zeros(
+                    [batch_size, anchors.shape[0], 1], dtype=rpn_match.dtype)
+                batch_rpn_bbox = np.zeros(
+                    [batch_size, config.RPN_TRAIN_ANCHORS_PER_IMAGE, 4], dtype=rpn_bbox.dtype)
+                batch_images = np.zeros(
+                    (batch_size,) + image.shape, dtype=np.float32)
+                batch_gt_class_ids = np.zeros(
+                    (batch_size, config.MAX_GT_INSTANCES), dtype=np.int32)
+                batch_gt_boxes = np.zeros(
+                    (batch_size, config.MAX_GT_INSTANCES, 4), dtype=np.int32)
+                batch_gt_masks = np.zeros(
+                    (batch_size, gt_masks.shape[0], gt_masks.shape[1],
+                     config.MAX_GT_INSTANCES), dtype=gt_masks.dtype)
+                if random_rois:
+                    batch_rpn_rois = np.zeros(
+                        (batch_size, rpn_rois.shape[0], 4), dtype=rpn_rois.dtype)
+                        batch_rois = np.zeros(
+                            (batch_size,) + rois.shape, dtype=rois.dtype)
+                        batch_mrcnn_class_ids = np.zeros(
+                            (batch_size,) + mrcnn_class_ids.shape, dtype=mrcnn_class_ids.dtype)
+                        batch_mrcnn_bbox = np.zeros(
+                            (batch_size,) + mrcnn_bbox.shape, dtype=mrcnn_bbox.dtype)
+                        batch_mrcnn_mask = np.zeros(
+                            (batch_size,) + mrcnn_mask.shape, dtype=mrcnn_mask.dtype)
+            # If more instances than fits in the array, sub-sample from them.
+            if gt_boxes.shape[0] > config.MAX_GT_INSTANCES:
+                    np.arange(gt_boxes.shape[0]), config.MAX_GT_INSTANCES, replace=False)
+                gt_class_ids = gt_class_ids[ids]
+                gt_boxes = gt_boxes[ids]
+                gt_masks = gt_masks[:, :, ids]
+            # Add to batch
+            batch_image_meta[b] = image_meta
+            batch_rpn_match[b] = rpn_match[:, np.newaxis]
+            batch_rpn_bbox[b] = rpn_bbox
+            batch_images[b] = mold_image(image.astype(np.float32), config)
+            batch_gt_class_ids[b, :gt_class_ids.shape[0]] = gt_class_ids
+            batch_gt_boxes[b, :gt_boxes.shape[0]] = gt_boxes
+            batch_gt_masks[b, :, :, :gt_masks.shape[-1]] = gt_masks
+            if random_rois:
+                batch_rpn_rois[b] = rpn_rois
+                    batch_rois[b] = rois
+                    batch_mrcnn_class_ids[b] = mrcnn_class_ids
+                    batch_mrcnn_bbox[b] = mrcnn_bbox
+                    batch_mrcnn_mask[b] = mrcnn_mask
+            b += 1
+            # Batch full?
+            if b >= batch_size:
+                inputs = [batch_images, batch_image_meta, batch_rpn_match, batch_rpn_bbox,
+                          batch_gt_class_ids, batch_gt_boxes, batch_gt_masks]
+                outputs = []
+                if random_rois:
+                    inputs.extend([batch_rpn_rois])
+                        inputs.extend([batch_rois])
+                        # Keras requires that output and targets have the same number of dimensions
+                        batch_mrcnn_class_ids = np.expand_dims(
+                            batch_mrcnn_class_ids, -1)
+                        outputs.extend(
+                            [batch_mrcnn_class_ids, batch_mrcnn_bbox, batch_mrcnn_mask])
+                yield inputs, outputs
+                # start a new batch
+                b = 0
+        except (GeneratorExit, KeyboardInterrupt):
+            raise
+        except:
+            # Log it and skip the image
+            logging.exception("Error processing image {}".format(
+                dataset.image_info[image_id]))
+            error_count += 1
+            if error_count > 5:
+                raise
+#  MaskRCNN Class
+class MaskRCNN():
+    """Encapsulates the Mask RCNN model functionality.
+    The actual Keras model is in the keras_model property.
+    def __init__(self, mode, config, model_dir):
+        mode: Either "training" or "inference"
+        config: A Sub-class of the Config class
+        model_dir: Directory to save training logs and trained weights
+        assert mode in ['training', 'inference']
+        self.mode = mode
+        self.model_dir = model_dir
+        self.set_log_dir()
+        self.keras_model = self.build(mode=mode, config=config)
+    def build(self, mode, config):
+        """Build Mask R-CNN architecture.
+            input_shape: The shape of the input image.
+            mode: Either "training" or "inference". The inputs and
+                outputs of the model differ accordingly.
+        # Image size must be dividable by 2 multiple times
+        h, w = config.IMAGE_SHAPE[:2]
+        if h / 2**6 != int(h / 2**6) or w / 2**6 != int(w / 2**6):
+            raise Exception("Image size must be dividable by 2 at least 6 times "
+                            "to avoid fractions when downscaling and upscaling."
+                            "For example, use 256, 320, 384, 448, 512, ... etc. ")
+        # Inputs
+        input_image = KL.Input(
+            shape=[None, None, 3], name="input_image")
+        input_image_meta = KL.Input(shape=[config.IMAGE_META_SIZE],
+                                    name="input_image_meta")
+        if mode == "training":
+            # RPN GT
+            input_rpn_match = KL.Input(
+                shape=[None, 1], name="input_rpn_match", dtype=tf.int32)
+            input_rpn_bbox = KL.Input(
+                shape=[None, 4], name="input_rpn_bbox", dtype=tf.float32)
+            # Detection GT (class IDs, bounding boxes, and masks)
+            # 1. GT Class IDs (zero padded)
+            input_gt_class_ids = KL.Input(
+                shape=[None], name="input_gt_class_ids", dtype=tf.int32)
+            # 2. GT Boxes in pixels (zero padded)
+            # [batch, MAX_GT_INSTANCES, (y1, x1, y2, x2)] in image coordinates
+            input_gt_boxes = KL.Input(
+                shape=[None, 4], name="input_gt_boxes", dtype=tf.float32)
+            # Normalize coordinates
+            gt_boxes = KL.Lambda(lambda x: norm_boxes_graph(
+                x, K.shape(input_image)[1:3]))(input_gt_boxes)
+            # 3. GT Masks (zero padded)
+            # [batch, height, width, MAX_GT_INSTANCES]
+                input_gt_masks = KL.Input(
+                    shape=[config.MINI_MASK_SHAPE[0],
+                           config.MINI_MASK_SHAPE[1], None],
+                    name="input_gt_masks", dtype=bool)
+            else:
+                    shape=[config.IMAGE_SHAPE[0], config.IMAGE_SHAPE[1], None],
+        elif mode == "inference":
+            # Anchors in normalized coordinates
+            input_anchors = KL.Input(shape=[None, 4], name="input_anchors")
+        # Build the shared convolutional layers.
+        # Bottom-up Layers
+        # Returns a list of the last layers of each stage, 5 in total.
+        # Don't create the thead (stage 5), so we pick the 4th item in the list.
+        _, C2, C3, C4, C5 = resnet_graph(input_image, config.BACKBONE,
+                                         stage5=True, train_bn=config.TRAIN_BN)
+        # Top-down Layers
+        # TODO: add assert to varify feature map sizes match what's in config
+        P5 = KL.Conv2D(256, (1, 1), name='fpn_c5p5')(C5)
+        P4 = KL.Add(name="fpn_p4add")([
+            KL.UpSampling2D(size=(2, 2), name="fpn_p5upsampled")(P5),
+            KL.Conv2D(256, (1, 1), name='fpn_c4p4')(C4)])
+        P3 = KL.Add(name="fpn_p3add")([
+            KL.UpSampling2D(size=(2, 2), name="fpn_p4upsampled")(P4),
+            KL.Conv2D(256, (1, 1), name='fpn_c3p3')(C3)])
+        P2 = KL.Add(name="fpn_p2add")([
+            KL.UpSampling2D(size=(2, 2), name="fpn_p3upsampled")(P3),
+            KL.Conv2D(256, (1, 1), name='fpn_c2p2')(C2)])
+        # Attach 3x3 conv to all P layers to get the final feature maps.
+        P2 = KL.Conv2D(256, (3, 3), padding="SAME", name="fpn_p2")(P2)
+        P3 = KL.Conv2D(256, (3, 3), padding="SAME", name="fpn_p3")(P3)
+        P4 = KL.Conv2D(256, (3, 3), padding="SAME", name="fpn_p4")(P4)
+        P5 = KL.Conv2D(256, (3, 3), padding="SAME", name="fpn_p5")(P5)
+        # P6 is used for the 5th anchor scale in RPN. Generated by
+        # subsampling from P5 with stride of 2.
+        P6 = KL.MaxPooling2D(pool_size=(1, 1), strides=2, name="fpn_p6")(P5)
+        # Note that P6 is used in RPN, but not in the classifier heads.
+        rpn_feature_maps = [P2, P3, P4, P5, P6]
+        mrcnn_feature_maps = [P2, P3, P4, P5]
+        # Anchors
+            anchors = self.get_anchors(config.IMAGE_SHAPE)
+            # Duplicate across the batch dimension because Keras requires it
+            # TODO: can this be optimized to avoid duplicating the anchors?
+            anchors = np.broadcast_to(anchors,
+                                      (config.BATCH_SIZE,) + anchors.shape)
+            # A hack to get around Keras's bad support for constants
+            anchors = KL.Lambda(lambda x: tf.Variable(anchors), name="anchors")(input_image)
+        else:
+            anchors = input_anchors
+        # RPN Model
+        rpn = build_rpn_model(config.RPN_ANCHOR_STRIDE,
+                              len(config.RPN_ANCHOR_RATIOS), 256)
+        # Loop through pyramid layers
+        layer_outputs = []  # list of lists
+        for p in rpn_feature_maps:
+            layer_outputs.append(rpn([p]))
+        # Concatenate layer outputs
+        # Convert from list of lists of level outputs to list of lists
+        # of outputs across levels.
+        # e.g. [[a1, b1, c1], [a2, b2, c2]] => [[a1, a2], [b1, b2], [c1, c2]]
+        output_names = ["rpn_class_logits", "rpn_class", "rpn_bbox"]
+        outputs = list(zip(*layer_outputs))
+        outputs = [KL.Concatenate(axis=1, name=n)(list(o))
+                   for o, n in zip(outputs, output_names)]
+        rpn_class_logits, rpn_class, rpn_bbox = outputs
+        # Generate proposals
+        # Proposals are [batch, N, (y1, x1, y2, x2)] in normalized coordinates
+        # and zero padded.
+        proposal_count = config.POST_NMS_ROIS_TRAINING if mode == "training"\
+            else config.POST_NMS_ROIS_INFERENCE
+        rpn_rois = ProposalLayer(
+            proposal_count=proposal_count,
+            nms_threshold=config.RPN_NMS_THRESHOLD,
+            name="ROI",
+            config=config)([rpn_class, rpn_bbox, anchors])
+            # Class ID mask to mark class IDs supported by the dataset the image
+            # came from.
+            active_class_ids = KL.Lambda(
+                lambda x: parse_image_meta_graph(x)["active_class_ids"]
+                )(input_image_meta)
+            if not config.USE_RPN_ROIS:
+                # Ignore predicted ROIs and use ROIs provided as an input.
+                input_rois = KL.Input(shape=[config.POST_NMS_ROIS_TRAINING, 4],
+                                      name="input_roi", dtype=np.int32)
+                target_rois = KL.Lambda(lambda x: norm_boxes_graph(
+                    x, K.shape(input_image)[1:3]))(input_rois)
+            else:
+                target_rois = rpn_rois
+            # Generate detection targets
+            # Subsamples proposals and generates target outputs for training
+            # Note that proposal class IDs, gt_boxes, and gt_masks are zero
+            # padded. Equally, returned rois and targets are zero padded.
+            rois, target_class_ids, target_bbox, target_mask =\
+                DetectionTargetLayer(config, name="proposal_targets")([
+                    target_rois, input_gt_class_ids, gt_boxes, input_gt_masks])
+            # Network Heads
+            # TODO: verify that this handles zero padded ROIs
+            mrcnn_class_logits, mrcnn_class, mrcnn_bbox =\
+                fpn_classifier_graph(rois,
+                                     mrcnn_feature_maps,
+                                     input_image_meta,
+                                     config.POOL_SIZE,
+                                     train_bn=config.TRAIN_BN)
+            mrcnn_mask = build_fpn_mask_graph(rois,
+                                              input_image_meta,
+                                              config.MASK_POOL_SIZE,
+            # TODO: clean up (use tf.identify if necessary)
+            output_rois = KL.Lambda(lambda x: x * 1, name="output_rois")(rois)
+            # Losses
+            rpn_class_loss = KL.Lambda(lambda x: rpn_class_loss_graph(*x), name="rpn_class_loss")(
+                [input_rpn_match, rpn_class_logits])
+            rpn_bbox_loss = KL.Lambda(lambda x: rpn_bbox_loss_graph(config, *x), name="rpn_bbox_loss")(
+                [input_rpn_bbox, input_rpn_match, rpn_bbox])
+            class_loss = KL.Lambda(lambda x: mrcnn_class_loss_graph(*x), name="mrcnn_class_loss")(
+                [target_class_ids, mrcnn_class_logits, active_class_ids])
+            bbox_loss = KL.Lambda(lambda x: mrcnn_bbox_loss_graph(*x), name="mrcnn_bbox_loss")(
+                [target_bbox, target_class_ids, mrcnn_bbox])
+            mask_loss = KL.Lambda(lambda x: mrcnn_mask_loss_graph(*x), name="mrcnn_mask_loss")(
+                [target_mask, target_class_ids, mrcnn_mask])
+            # Model
+            inputs = [input_image, input_image_meta,
+                      input_rpn_match, input_rpn_bbox, input_gt_class_ids, input_gt_boxes, input_gt_masks]
+                inputs.append(input_rois)
+            outputs = [rpn_class_logits, rpn_class, rpn_bbox,
+                       mrcnn_class_logits, mrcnn_class, mrcnn_bbox, mrcnn_mask,
+                       rpn_rois, output_rois,
+                       rpn_class_loss, rpn_bbox_loss, class_loss, bbox_loss, mask_loss]
+            model = KM.Model(inputs, outputs, name='mask_rcnn')
+        else:
+            # Network Heads
+            # Proposal classifier and BBox regressor heads
+                fpn_classifier_graph(rpn_rois,
+                                     input_image_meta,
+                                     config.POOL_SIZE,
+            # Detections
+            # output is [batch, num_detections, (y1, x1, y2, x2, class_id, score)] in
+            detections = DetectionLayer(config, name="mrcnn_detection")(
+                [rpn_rois, mrcnn_class, mrcnn_bbox, input_image_meta])
+            # Create masks for detections
+            detection_boxes = KL.Lambda(lambda x: x[..., :4])(detections)
+            mrcnn_mask = build_fpn_mask_graph(detection_boxes,
+                                              input_image_meta,
+            model = KM.Model([input_image, input_image_meta, input_anchors],
+                             [detections, mrcnn_class, mrcnn_bbox,
+                                 mrcnn_mask, rpn_rois, rpn_class, rpn_bbox],
+                             name='mask_rcnn')
+        # Add multi-GPU support.
+        if config.GPU_COUNT > 1:
+            from parallel_model import ParallelModel
+            model = ParallelModel(model, config.GPU_COUNT)
+        return model
+    def find_last(self):
+        """Finds the last checkpoint file of the last trained model in the
+        model directory.
+        Returns:
+            log_dir: The directory where events and weights are saved
+            checkpoint_path: the path to the last checkpoint file
+        # Get directory names. Each directory corresponds to a model
+        dir_names = next(os.walk(self.model_dir))[1]
+        key = self.config.NAME.lower()
+        dir_names = filter(lambda f: f.startswith(key), dir_names)
+        dir_names = sorted(dir_names)
+        if not dir_names:
+            return None, None
+        # Pick last directory
+        dir_name = os.path.join(self.model_dir, dir_names[-1])
+        # Find the last checkpoint
+        checkpoints = next(os.walk(dir_name))[2]
+        checkpoints = filter(lambda f: f.startswith("mask_rcnn"), checkpoints)
+        checkpoints = sorted(checkpoints)
+        if not checkpoints:
+            return dir_name, None
+        checkpoint = os.path.join(dir_name, checkpoints[-1])
+        return dir_name, checkpoint
+    def load_weights(self, filepath, by_name=False, exclude=None):
+        """Modified version of the correspoding Keras function with
+        the addition of multi-GPU support and the ability to exclude
+        some layers from loading.
+        exlude: list of layer names to excluce
+        import h5py
+        from keras.engine import topology
+        if exclude:
+            by_name = True
+        if h5py is None:
+            raise ImportError('`load_weights` requires h5py.')
+        f = h5py.File(filepath, mode='r')
+        if 'layer_names' not in f.attrs and 'model_weights' in f:
+            f = f['model_weights']
+        # In multi-GPU training, we wrap the model. Get layers
+        # of the inner model because they have the weights.
+        keras_model = self.keras_model
+        layers = keras_model.inner_model.layers if hasattr(keras_model, "inner_model")\
+            else keras_model.layers
+        # Exclude some layers
+        if exclude:
+            layers = filter(lambda l: l.name not in exclude, layers)
+        if by_name:
+            topology.load_weights_from_hdf5_group_by_name(f, layers)
+        else:
+            topology.load_weights_from_hdf5_group(f, layers)
+        if hasattr(f, 'close'):
+            f.close()
+        # Update the log directory
+        self.set_log_dir(filepath)
+    def get_imagenet_weights(self):
+        """Downloads ImageNet trained weights from Keras.
+        Returns path to weights file.
+        from keras.utils.data_utils import get_file
+        TF_WEIGHTS_PATH_NO_TOP = 'https://github.com/fchollet/deep-learning-models/'\
+                                 'releases/download/v0.2/'\
+                                 'resnet50_weights_tf_dim_ordering_tf_kernels_notop.h5'
+        weights_path = get_file('resnet50_weights_tf_dim_ordering_tf_kernels_notop.h5',
+                                TF_WEIGHTS_PATH_NO_TOP,
+                                cache_subdir='models',
+                                md5_hash='a268eb855778b3df3c7506639542a6af')
+        return weights_path
+    def compile(self, learning_rate, momentum):
+        """Gets the model ready for training. Adds losses, regularization, and
+        metrics. Then calls the Keras compile() function.
+        # Optimizer object
+        optimizer = keras.optimizers.SGD(
+            lr=learning_rate, momentum=momentum,
+            clipnorm=self.config.GRADIENT_CLIP_NORM)
+        # Add Losses
+        # First, clear previously set losses to avoid duplication
+        self.keras_model._losses = []
+        self.keras_model._per_input_losses = {}
+        loss_names = [
+            "rpn_class_loss",  "rpn_bbox_loss",
+            "mrcnn_class_loss", "mrcnn_bbox_loss", "mrcnn_mask_loss"]
+        for name in loss_names:
+            layer = self.keras_model.get_layer(name)
+            if layer.output in self.keras_model.losses:
+                continue
+            loss = (
+                tf.reduce_mean(layer.output, keepdims=True)
+                * self.config.LOSS_WEIGHTS.get(name, 1.))
+            self.keras_model.add_loss(loss)
+        # Add L2 Regularization
+        # Skip gamma and beta weights of batch normalization layers.
+        reg_losses = [
+            keras.regularizers.l2(self.config.WEIGHT_DECAY)(w) / tf.cast(tf.size(w), tf.float32)
+            for w in self.keras_model.trainable_weights
+            if 'gamma' not in w.name and 'beta' not in w.name]
+        self.keras_model.add_loss(tf.add_n(reg_losses))
+        # Compile
+        self.keras_model.compile(
+            optimizer=optimizer,
+            loss=[None] * len(self.keras_model.outputs))
+        # Add metrics for losses
+            if name in self.keras_model.metrics_names:
+                continue
+            self.keras_model.metrics_names.append(name)
+            loss = (
+            self.keras_model.metrics_tensors.append(loss)
+    def set_trainable(self, layer_regex, keras_model=None, indent=0, verbose=1):
+        """Sets model layers as trainable if their names match
+        the given regular expression.
+        # Print message on the first call (but not on recursive calls)
+        if verbose > 0 and keras_model is None:
+            log("Selecting layers to train")
+        keras_model = keras_model or self.keras_model
+        for layer in layers:
+            # Is the layer a model?
+            if layer.__class__.__name__ == 'Model':
+                print("In model: ", layer.name)
+                self.set_trainable(
+                    layer_regex, keras_model=layer, indent=indent + 4)
+                continue
+            if not layer.weights:
+                continue
+            # Is it trainable?
+            trainable = bool(re.fullmatch(layer_regex, layer.name))
+            # Update layer. If layer is a container, update inner layer.
+            if layer.__class__.__name__ == 'TimeDistributed':
+                layer.layer.trainable = trainable
+            else:
+                layer.trainable = trainable
+            # Print trainble layer names
+            if trainable and verbose > 0:
+                log("{}{:20}   ({})".format(" " * indent, layer.name,
+                                            layer.__class__.__name__))
+    def set_log_dir(self, model_path=None):
+        """Sets the model log directory and epoch counter.
+        model_path: If None, or a format different from what this code uses
+            then set a new log directory and start epochs from 0. Otherwise,
+            extract the log directory and the epoch counter from the file
+            name.
+        # Set date and epoch counter as if starting a new model
+        self.epoch = 0
+        now = datetime.datetime.now()
+        # If we have a model path with date and epochs use them
+        if model_path:
+            # Continue from we left of. Get epoch and date from the file name
+            # A sample model path might look like:
+            # /path/to/logs/coco20171029T2315/mask_rcnn_coco_0001.h5
+            regex = r".*/\w+(\d{4})(\d{2})(\d{2})T(\d{2})(\d{2})/mask\_rcnn\_\w+(\d{4})\.h5"
+            m = re.match(regex, model_path)
+            if m:
+                now = datetime.datetime(int(m.group(1)), int(m.group(2)), int(m.group(3)),
+                                        int(m.group(4)), int(m.group(5)))
+                # Epoch number in file is 1-based, and in Keras code it's 0-based.
+                # So, adjust for that then increment by one to start from the next epoch
+                self.epoch = int(m.group(6))
+        # Directory for training logs
+        self.log_dir = os.path.join(self.model_dir, "{}{:%Y%m%dT%H%M}".format(
+            self.config.NAME.lower(), now))
+        # Path to save after each epoch. Include placeholders that get filled by Keras.
+        self.checkpoint_path = os.path.join(self.log_dir, "mask_rcnn_{}_*epoch*.h5".format(
+            self.config.NAME.lower()))
+        self.checkpoint_path = self.checkpoint_path.replace(
+            "*epoch*", "{epoch:04d}")
+    def train(self, train_dataset, val_dataset, learning_rate, epochs, layers,
+              augmentation=None):
+        """Train the model.
+        train_dataset, val_dataset: Training and validation Dataset objects.
+        learning_rate: The learning rate to train with
+        epochs: Number of training epochs. Note that previous training epochs
+                are considered to be done alreay, so this actually determines
+                the epochs to train in total rather than in this particaular
+                call.
+        layers: Allows selecting wich layers to train. It can be:
+            - A regular expression to match layer names to train
+            - One of these predefined values:
+              heaads: The RPN, classifier and mask heads of the network
+              all: All the layers
+              3+: Train Resnet stage 3 and up
+              4+: Train Resnet stage 4 and up
+              5+: Train Resnet stage 5 and up
+            augmentation. For example, passing imgaug.augmenters.Fliplr(0.5)
+            flips images right/left 50% of the time. You can pass complex
+            augmentations as well. This augmentation applies 50% of the
+            time, and when it does it flips images right/left half the time
+            and adds a Gausssian blur with a random sigma in range 0 to 5.
+                augmentation = imgaug.augmenters.Sometimes(0.5, [
+                    imgaug.augmenters.Fliplr(0.5),
+                    imgaug.augmenters.GaussianBlur(sigma=(0.0, 5.0))
+        assert self.mode == "training", "Create model in training mode."
+        # Pre-defined layer regular expressions
+        layer_regex = {
+            # all layers but the backbone
+            "heads": r"(mrcnn\_.*)|(rpn\_.*)|(fpn\_.*)",
+            # From a specific Resnet stage and up
+            "3+": r"(res3.*)|(bn3.*)|(res4.*)|(bn4.*)|(res5.*)|(bn5.*)|(mrcnn\_.*)|(rpn\_.*)|(fpn\_.*)",
+            "4+": r"(res4.*)|(bn4.*)|(res5.*)|(bn5.*)|(mrcnn\_.*)|(rpn\_.*)|(fpn\_.*)",
+            "5+": r"(res5.*)|(bn5.*)|(mrcnn\_.*)|(rpn\_.*)|(fpn\_.*)",
+            # All layers
+            "all": ".*",
+        if layers in layer_regex.keys():
+            layers = layer_regex[layers]
+        # Data generators
+        train_generator = data_generator(train_dataset, self.config,
+                                         shuffle=True,
+                                         batch_size=self.config.BATCH_SIZE)
+        val_generator = data_generator(val_dataset, self.config, shuffle=True,
+        # Callbacks
+        callbacks = [
+            keras.callbacks.TensorBoard(log_dir=self.log_dir,
+                                        histogram_freq=0, write_graph=True, write_images=False),
+            keras.callbacks.ModelCheckpoint(self.checkpoint_path,
+                                            verbose=0, save_weights_only=True),
+        # Train
+        log("\nStarting at epoch {}. LR={}\n".format(self.epoch, learning_rate))
+        log("Checkpoint Path: {}".format(self.checkpoint_path))
+        self.set_trainable(layers)
+        self.compile(learning_rate, self.config.LEARNING_MOMENTUM)
+        # Work-around for Windows: Keras fails on Windows when using
+        # multiprocessing workers. See discussion here:
+        # https://github.com/matterport/Mask_RCNN/issues/13#issuecomment-353124009
+        if os.name is 'nt':
+            workers = 0
+        else:
+            workers = multiprocessing.cpu_count()
+        self.keras_model.fit_generator(
+            train_generator,
+            initial_epoch=self.epoch,
+            epochs=epochs,
+            steps_per_epoch=self.config.STEPS_PER_EPOCH,
+            callbacks=callbacks,
+            validation_data=val_generator,
+            validation_steps=self.config.VALIDATION_STEPS,
+            max_queue_size=100,
+            workers=workers,
+            use_multiprocessing=True,
+        self.epoch = max(self.epoch, epochs)
+    def mold_inputs(self, images):
+        """Takes a list of images and modifies them to the format expected
+        as an input to the neural network.
+        images: List of image matricies [height,width,depth]. Images can have
+            different sizes.
+        Returns 3 Numpy matricies:
+        molded_images: [N, h, w, 3]. Images resized and normalized.
+        image_metas: [N, length of meta data]. Details about each image.
+        windows: [N, (y1, x1, y2, x2)]. The portion of the image that has the
+            original image (padding excluded).
+        molded_images = []
+        image_metas = []
+        windows = []
+        for image in images:
+            # Resize image
+            # TODO: move resizing to mold_image()
+            molded_image, window, scale, padding, crop = utils.resize_image(
+                image,
+                min_dim=self.config.IMAGE_MIN_DIM,
+                min_scale=self.config.IMAGE_MIN_SCALE,
+                max_dim=self.config.IMAGE_MAX_DIM,
+                mode=self.config.IMAGE_RESIZE_MODE)
+            molded_image = mold_image(molded_image, self.config)
+            # Build image_meta
+                0, image.shape, molded_image.shape, window, scale,
+                np.zeros([self.config.NUM_CLASSES], dtype=np.int32))
+            # Append
+            molded_images.append(molded_image)
+            windows.append(window)
+            image_metas.append(image_meta)
+        # Pack into arrays
+        molded_images = np.stack(molded_images)
+        image_metas = np.stack(image_metas)
+        windows = np.stack(windows)
+        return molded_images, image_metas, windows
+    def unmold_detections(self, detections, mrcnn_mask, original_image_shape,
+                          image_shape, window):
+        """Reformats the detections of one image from the format of the neural
+        network output to a format suitable for use in the rest of the
+        application.
+        detections: [N, (y1, x1, y2, x2, class_id, score)] in normalized coordinates
+        mrcnn_mask: [N, height, width, num_classes]
+        original_image_shape: [H, W, C] Original image shape before resizing
+        image_shape: [H, W, C] Shape of the image after resizing and padding
+        window: [y1, x1, y2, x2] Pixel coordinates of box in the image where the real
+                image is excluding the padding.
+        Returns:
+        boxes: [N, (y1, x1, y2, x2)] Bounding boxes in pixels
+        class_ids: [N] Integer class IDs for each bounding box
+        scores: [N] Float probability scores of the class_id
+        masks: [height, width, num_instances] Instance masks
+        # How many detections do we have?
+        # Detections array is padded with zeros. Find the first class_id == 0.
+        zero_ix = np.where(detections[:, 4] == 0)[0]
+        N = zero_ix[0] if zero_ix.shape[0] > 0 else detections.shape[0]
+        # Extract boxes, class_ids, scores, and class-specific masks
+        boxes = detections[:N, :4]
+        class_ids = detections[:N, 4].astype(np.int32)
+        scores = detections[:N, 5]
+        masks = mrcnn_mask[np.arange(N), :, :, class_ids]
+        # Translate normalized coordinates in the resized image to pixel
+        # coordinates in the original image before resizing
+        window = utils.norm_boxes(window, image_shape[:2])
+        wy1, wx1, wy2, wx2 = window
+        shift = np.array([wy1, wx1, wy1, wx1])
+        wh = wy2 - wy1  # window height
+        ww = wx2 - wx1  # window width
+        scale = np.array([wh, ww, wh, ww])
+        # Convert boxes to normalized coordinates on the window
+        boxes = np.divide(boxes - shift, scale)
+        # Convert boxes to pixel coordinates on the original image
+        boxes = utils.denorm_boxes(boxes, original_image_shape[:2])
+        # Filter out detections with zero area. Happens in early training when
+        # network weights are still random
+        exclude_ix = np.where(
+            (boxes[:, 2] - boxes[:, 0]) * (boxes[:, 3] - boxes[:, 1]) <= 0)[0]
+        if exclude_ix.shape[0] > 0:
+            boxes = np.delete(boxes, exclude_ix, axis=0)
+            class_ids = np.delete(class_ids, exclude_ix, axis=0)
+            scores = np.delete(scores, exclude_ix, axis=0)
+            masks = np.delete(masks, exclude_ix, axis=0)
+            N = class_ids.shape[0]
+        # Resize masks to original image size and set boundary threshold.
+        full_masks = []
+        for i in range(N):
+            # Convert neural network mask to full size mask
+            full_mask = utils.unmold_mask(masks[i], boxes[i], original_image_shape)
+            full_masks.append(full_mask)
+        full_masks = np.stack(full_masks, axis=-1)\
+            if full_masks else np.empty(masks.shape[1:3] + (0,))
+        return boxes, class_ids, scores, full_masks
+    def detect(self, images, verbosity=0):
+        """Runs the detection pipeline.
+        images: List of images, potentially of different sizes.
+        Returns a list of dicts, one dict per image. The dict contains:
+        rois: [N, (y1, x1, y2, x2)] detection bounding boxes
+        class_ids: [N] int class IDs
+        scores: [N] float probability scores for the class IDs
+        masks: [H, W, N] instance binary masks
+        Modified by Ondrej Pesek:
+            verbose -> verbosity
+            verbose form in case of verbosity == 3, not 1
+        assert self.mode == "inference", "Create model in inference mode."
+        assert len(
+            images) == self.config.BATCH_SIZE, "len(images) must be equal to BATCH_SIZE"
+        if verbosity == 3:
+            log("Processing {} images".format(len(images)))
+                log("image", image)
+        # Mold inputs to format expected by the neural network
+        molded_images, image_metas, windows = self.mold_inputs(images)
+        # Validate image sizes
+        # All images in a batch MUST be of the same size
+        image_shape = molded_images[0].shape
+        for g in molded_images[1:]:
+            assert g.shape == image_shape,\
+                "After resizing, all images must have the same size. Check IMAGE_RESIZE_MODE and image sizes."
+        # Anchors
+        anchors = self.get_anchors(image_shape)
+        anchors = np.broadcast_to(anchors, (self.config.BATCH_SIZE,) + anchors.shape)
+            log("molded_images", molded_images)
+            log("image_metas", image_metas)
+            log("anchors", anchors)
+        # Run object detection
+        detections, _, _, mrcnn_mask, _, _, _ =\
+            self.keras_model.predict([molded_images, image_metas, anchors], verbose=0)
+        # Process detections
+        results = []
+        for i, image in enumerate(images):
+            final_rois, final_class_ids, final_scores, final_masks =\
+                self.unmold_detections(detections[i], mrcnn_mask[i],
+                                       image.shape, molded_images[i].shape,
+                                       windows[i])
+            results.append({
+                "rois": final_rois,
+                "class_ids": final_class_ids,
+                "scores": final_scores,
+                "masks": final_masks,
+        return results
+    def detect_molded(self, molded_images, image_metas, verbose=0):
+        """Runs the detection pipeline, but expect inputs that are
+        molded already. Used mostly for debugging and inspecting
+        the model.
+        molded_images: List of images loaded using load_image_gt()
+        image_metas: image meta data, also retruned by load_image_gt()
+        assert len(molded_images) == self.config.BATCH_SIZE,\
+            "Number of images must be equal to BATCH_SIZE"
+        if verbose:
+            log("Processing {} images".format(len(molded_images)))
+            for image in molded_images:
+            assert g.shape == image_shape, "Images must have the same size"
+        # Anchors
+        if verbose:
+        results = []
+        for i, image in enumerate(molded_images):
+            window = [0, 0, image.shape[0], image.shape[1]]
+                                       window)
+            results.append({
+        return results
+    def get_anchors(self, image_shape):
+        """Returns anchor pyramid for the given image size."""
+        backbone_shapes = compute_backbone_shapes(self.config, image_shape)
+        # Cache anchors and reuse if image shape is the same
+        if not hasattr(self, "_anchor_cache"):
+            self._anchor_cache = {}
+        if not tuple(image_shape) in self._anchor_cache:
+            # Generate Anchors
+            a = utils.generate_pyramid_anchors(
+                self.config.RPN_ANCHOR_SCALES,
+                self.config.RPN_ANCHOR_RATIOS,
+                backbone_shapes,
+                self.config.BACKBONE_STRIDES,
+                self.config.RPN_ANCHOR_STRIDE)
+            # Keep a copy of the latest anchors in pixel coordinates because
+            # it's used in inspect_model notebooks.
+            # TODO: Remove this after the notebook are refactored to not use it
+            self.anchors = a
+            self._anchor_cache[tuple(image_shape)] = utils.norm_boxes(a, image_shape[:2])
+        return self._anchor_cache[tuple(image_shape)]
+    def ancestor(self, tensor, name, checked=None):
+        """Finds the ancestor of a TF tensor in the computation graph.
+        tensor: TensorFlow symbolic tensor.
+        name: Name of ancestor tensor to find
+        checked: For internal use. A list of tensors that were already
+                 searched to avoid loops in traversing the graph.
+        checked = checked if checked is not None else []
+        # Put a limit on how deep we go to avoid very long loops
+        if len(checked) > 500:
+            return None
+        # Convert name to a regex and allow matching a number prefix
+        # because Keras adds them automatically
+        if isinstance(name, str):
+            name = re.compile(name.replace("/", r"(\_\d+)*/"))
+        parents = tensor.op.inputs
+        for p in parents:
+            if p in checked:
+                continue
+            if bool(re.fullmatch(name, p.name)):
+                return p
+            checked.append(p)
+            a = self.ancestor(p, name, checked)
+            if a is not None:
+                return a
+        return None
+    def find_trainable_layer(self, layer):
+        """If a layer is encapsulated by another layer, this function
+        digs through the encapsulation and returns the layer that holds
+        the weights.
+            return self.find_trainable_layer(layer.layer)
+        return layer
+    def get_trainable_layers(self):
+        """Returns a list of layers that have weights."""
+        layers = []
+        # Loop through all layers
+        for l in self.keras_model.layers:
+            # If layer is a wrapper, find inner trainable layer
+            l = self.find_trainable_layer(l)
+            # Include layer if it has weights
+            if l.get_weights():
+                layers.append(l)
+        return layers
+    def run_graph(self, images, outputs, image_metas=None):
+        """Runs a sub-set of the computation graph that computes the given
+        outputs.
+        image_metas: If provided, the images are assumed to be already
+            molded (i.e. resized, padded, and noramlized)
+        outputs: List of tuples (name, tensor) to compute. The tensors are
+            symbolic TensorFlow tensors and the names are for easy tracking.
+        Returns an ordered dict of results. Keys are the names received in the
+        input and values are Numpy arrays.
+        model = self.keras_model
+        # Organize desired outputs into an ordered dict
+        outputs = OrderedDict(outputs)
+        for o in outputs.values():
+            assert o is not None
+        # Build a Keras function to run parts of the computation graph
+        inputs = model.inputs
+        if model.uses_learning_phase and not isinstance(K.learning_phase(), int):
+            inputs += [K.learning_phase()]
+        kf = K.function(model.inputs, list(outputs.values()))
+        # Prepare inputs
+        if image_metas is None:
+            molded_images, image_metas, _ = self.mold_inputs(images)
+        else:
+            molded_images = images
+        # Anchors
+        model_in = [molded_images, image_metas, anchors]
+        # Run inference
+            model_in.append(0.)
+        outputs_np = kf(model_in)
+        # Pack the generated Numpy arrays into a a dict and log the results.
+        outputs_np = OrderedDict([(k, v)
+                                  for k, v in zip(outputs.keys(), outputs_np)])
+        for k, v in outputs_np.items():
+            log(k, v)
+        return outputs_np
+#  Data Formatting
+def compose_image_meta(image_id, original_image_shape, image_shape,
+                       window, scale, active_class_ids):
+    """Takes attributes of an image and puts them in one 1D array.
+    image_id: An int ID of the image. Useful for debugging.
+    original_image_shape: [H, W, C] before resizing or padding.
+    image_shape: [H, W, C] after resizing and padding
+    window: (y1, x1, y2, x2) in pixels. The area of the image where the real
+            image is (excluding the padding)
+    scale: The scaling factor applied to the original image (float32)
+    active_class_ids: List of class_ids available in the dataset from which
+        the image came. Useful if training on images from multiple datasets
+        where not all classes are present in all datasets.
+    meta = np.array(
+        [image_id] +                  # size=1
+        list(original_image_shape) +  # size=3
+        list(image_shape) +           # size=3
+        list(window) +                # size=4 (y1, x1, y2, x2) in image cooredinates
+        [scale] +                     # size=1
+        list(active_class_ids)        # size=num_classes
+    return meta
+def parse_image_meta(meta):
+    """Parses an array that contains image attributes to its components.
+    See compose_image_meta() for more details.
+    meta: [batch, meta length] where meta length depends on NUM_CLASSES
+    Returns a dict of the parsed values.
+    image_id = meta[:, 0]
+    original_image_shape = meta[:, 1:4]
+    image_shape = meta[:, 4:7]
+    window = meta[:, 7:11]  # (y1, x1, y2, x2) window of image in in pixels
+    scale = meta[:, 11]
+    active_class_ids = meta[:, 12:]
+    return {
+        "image_id": image_id.astype(np.int32),
+        "original_image_shape": original_image_shape.astype(np.int32),
+        "image_shape": image_shape.astype(np.int32),
+        "window": window.astype(np.int32),
+        "scale": scale.astype(np.float32),
+        "active_class_ids": active_class_ids.astype(np.int32),
+def parse_image_meta_graph(meta):
+    """Parses a tensor that contains image attributes to its components.
+    Returns a dict of the parsed tensors.
+    return {
+        "image_id": image_id,
+        "original_image_shape": original_image_shape,
+        "image_shape": image_shape,
+        "window": window,
+        "scale": scale,
+        "active_class_ids": active_class_ids,
+def mold_image(images, config):
+    """Expects an RGB image (or array of images) and subtraces
+    the mean pixel and converts it to float. Expects image
+    colors in RGB order.
+    return images.astype(np.float32) - config.MEAN_PIXEL
+def unmold_image(normalized_images, config):
+    """Takes a image normalized with mold() and returns the original."""
+    return (normalized_images + config.MEAN_PIXEL).astype(np.uint8)
+#  Miscellenous Graph Functions
+def trim_zeros_graph(boxes, name=None):
+    """Often boxes are represented with matricies of shape [N, 4] and
+    are padded with zeros. This removes zero boxes.
+    boxes: [N, 4] matrix of boxes.
+    non_zeros: [N] a 1D boolean mask identifying the rows to keep
+    non_zeros = tf.cast(tf.reduce_sum(tf.abs(boxes), axis=1), tf.bool)
+    boxes = tf.boolean_mask(boxes, non_zeros, name=name)
+    return boxes, non_zeros
+def batch_pack_graph(x, counts, num_rows):
+    """Picks different number of values from each row
+    in x depending on the values in counts.
+    outputs = []
+    for i in range(num_rows):
+        outputs.append(x[i, :counts[i]])
+    return tf.concat(outputs, axis=0)
+def norm_boxes_graph(boxes, shape):
+    """Converts boxes from pixel coordinates to normalized coordinates.
+    boxes: [..., (y1, x1, y2, x2)] in pixel coordinates
+    shape: [..., (height, width)] in pixels
+    Note: In pixel coordinates (y2, x2) is outside the box. But in normalized
+    coordinates it's inside the box.
+    Returns:
+        [..., (y1, x1, y2, x2)] in normalized coordinates
+    h, w = tf.split(tf.cast(shape, tf.float32), 2)
+    scale = tf.concat([h, w, h, w], axis=-1) - tf.constant(1.0)
+    shift = tf.constant([0., 0., 1., 1.])
+    return tf.divide(boxes - shift, scale)
+def denorm_boxes_graph(boxes, shape):
+    """Converts boxes from normalized coordinates to pixel coordinates.
+    boxes: [..., (y1, x1, y2, x2)] in normalized coordinates
+    Returns:
+        [..., (y1, x1, y2, x2)] in pixel coordinates
+    return tf.cast(tf.round(tf.multiply(boxes, scale) + shift), tf.int32)
Added: grass-addons/grass7/imagery/i.ann.maskrcnn/maskrcnnlib/parallel_model.py
--- grass-addons/grass7/imagery/i.ann.maskrcnn/maskrcnnlib/parallel_model.py	                        (rev 0)
+++ grass-addons/grass7/imagery/i.ann.maskrcnn/maskrcnnlib/parallel_model.py	2018-05-22 11:53:59 UTC (rev 72730)
@@ -0,0 +1,175 @@
+Mask R-CNN
+Multi-GPU Support for Keras.
+Copyright (c) 2017 Matterport, Inc.
+Licensed under the MIT License (see LICENSE for details)
+Written by Waleed Abdulla
+Ideas and a small code snippets from these sources:
+https://github.com/fchollet/keras/issues/2436
+https://medium.com/@kuza55/transparent-multi-gpu-training-on-tensorflow-with-keras-8b0016fd9012
+https://github.com/avolkov1/keras_experiments/blob/master/keras_exp/multigpu/
+https://github.com/fchollet/keras/blob/master/keras/utils/training_utils.py
+import tensorflow as tf
+import keras.backend as K
+import keras.layers as KL
+import keras.models as KM
+class ParallelModel(KM.Model):
+    """Subclasses the standard Keras Model and adds multi-GPU support.
+    It works by creating a copy of the model on each GPU. Then it slices
+    the inputs and sends a slice to each copy of the model, and then
+    merges the outputs together and applies the loss on the combined
+    outputs.
+    def __init__(self, keras_model, gpu_count):
+        """Class constructor.
+        keras_model: The Keras model to parallelize
+        gpu_count: Number of GPUs. Must be > 1
+        self.inner_model = keras_model
+        self.gpu_count = gpu_count
+        merged_outputs = self.make_parallel()
+        super(ParallelModel, self).__init__(inputs=self.inner_model.inputs,
+                                            outputs=merged_outputs)
+    def __getattribute__(self, attrname):
+        """Redirect loading and saving methods to the inner model. That's where
+        the weights are stored."""
+        if 'load' in attrname or 'save' in attrname:
+            return getattr(self.inner_model, attrname)
+        return super(ParallelModel, self).__getattribute__(attrname)
+    def summary(self, *args, **kwargs):
+        """Override summary() to display summaries of both, the wrapper
+        and inner models."""
+        super(ParallelModel, self).summary(*args, **kwargs)
+        self.inner_model.summary(*args, **kwargs)
+    def make_parallel(self):
+        """Creates a new wrapper model that consists of multiple replicas of
+        the original model placed on different GPUs.
+        # Slice inputs. Slice inputs on the CPU to avoid sending a copy
+        # of the full inputs to all GPUs. Saves on bandwidth and memory.
+        input_slices = {name: tf.split(x, self.gpu_count)
+                        for name, x in zip(self.inner_model.input_names,
+                                           self.inner_model.inputs)}
+        output_names = self.inner_model.output_names
+        outputs_all = []
+        for i in range(len(self.inner_model.outputs)):
+            outputs_all.append([])
+        # Run the model call() on each GPU to place the ops there
+        for i in range(self.gpu_count):
+            with tf.device('/gpu:%d' % i):
+                with tf.name_scope('tower_%d' % i):
+                    # Run a slice of inputs through this replica
+                    zipped_inputs = zip(self.inner_model.input_names,
+                    inputs = [
+                        KL.Lambda(lambda s: input_slices[name][i],
+                                  output_shape=lambda s: (None,) + s[1:])(tensor)
+                        for name, tensor in zipped_inputs]
+                    # Create the model replica and get the outputs
+                    outputs = self.inner_model(inputs)
+                    if not isinstance(outputs, list):
+                        outputs = [outputs]
+                    # Save the outputs for merging back together later
+                    for l, o in enumerate(outputs):
+                        outputs_all[l].append(o)
+        # Merge outputs on CPU
+        with tf.device('/cpu:0'):
+            merged = []
+            for outputs, name in zip(outputs_all, output_names):
+                # Concatenate or average outputs?
+                # Outputs usually have a batch dimension and we concatenate
+                # across it. If they don't, then the output is likely a loss
+                # or a metric value that gets averaged across the batch.
+                # Keras expects losses and metrics to be scalars.
+                if K.int_shape(outputs[0]) == ():
+                    # Average
+                    m = KL.Lambda(lambda o: tf.add_n(o) / len(outputs), name=name)(outputs)
+                else:
+                    # Concatenate
+                    m = KL.Concatenate(axis=0, name=name)(outputs)
+                merged.append(m)
+        return merged
+if __name__ == "__main__":
+    # Testing code below. It creates a simple model to train on MNIST and
+    # tries to run it on 2 GPUs. It saves the graph so it can be viewed
+    # in TensorBoard. Run it as:
+    # python3 parallel_model.py
+    import os
+    import numpy as np
+    import keras.optimizers
+    from keras.datasets import mnist
+    from keras.preprocessing.image import ImageDataGenerator
+    GPU_COUNT = 2
+    # Root directory of the project
+    ROOT_DIR = os.path.abspath("../")
+    # Directory to save logs and trained model
+    MODEL_DIR = os.path.join(ROOT_DIR, "logs")
+    def build_model(x_train, num_classes):
+        # Reset default graph. Keras leaves old ops in the graph,
+        # which are ignored for execution but clutter graph
+        # visualization in TensorBoard.
+        tf.reset_default_graph()
+        inputs = KL.Input(shape=x_train.shape[1:], name="input_image")
+        x = KL.Conv2D(32, (3, 3), activation='relu', padding="same",
+                      name="conv1")(inputs)
+        x = KL.Conv2D(64, (3, 3), activation='relu', padding="same",
+                      name="conv2")(x)
+        x = KL.MaxPooling2D(pool_size=(2, 2), name="pool1")(x)
+        x = KL.Flatten(name="flat1")(x)
+        x = KL.Dense(128, activation='relu', name="dense1")(x)
+        x = KL.Dense(num_classes, activation='softmax', name="dense2")(x)
+        return KM.Model(inputs, x, "digit_classifier_model")
+    # Load MNIST Data
+    (x_train, y_train), (x_test, y_test) = mnist.load_data()
+    x_train = np.expand_dims(x_train, -1).astype('float32') / 255
+    x_test = np.expand_dims(x_test, -1).astype('float32') / 255
+    print('x_train shape:', x_train.shape)
+    print('x_test shape:', x_test.shape)
+    # Build data generator and model
+    datagen = ImageDataGenerator()
+    model = build_model(x_train, 10)
+    model = ParallelModel(model, GPU_COUNT)
+    optimizer = keras.optimizers.SGD(lr=0.01, momentum=0.9, clipnorm=5.0)
+    model.compile(loss='sparse_categorical_crossentropy',
+                  optimizer=optimizer, metrics=['accuracy'])
+    model.summary()
+    # Train
+    model.fit_generator(
+        datagen.flow(x_train, y_train, batch_size=64),
+        steps_per_epoch=50, epochs=10, verbose=1,
+        validation_data=(x_test, y_test),
+        callbacks=[keras.callbacks.TensorBoard(log_dir=MODEL_DIR,
+                                               write_graph=True)]
Added: grass-addons/grass7/imagery/i.ann.maskrcnn/maskrcnnlib/utils.py
--- grass-addons/grass7/imagery/i.ann.maskrcnn/maskrcnnlib/utils.py	                        (rev 0)
+++ grass-addons/grass7/imagery/i.ann.maskrcnn/maskrcnnlib/utils.py	2018-05-22 11:53:59 UTC (rev 72730)
@@ -0,0 +1,927 @@
+Mask R-CNN
+Common utility functions and classes.
+Modified by Ondrej Pesek
+    Written import_contents and load_mask methods
+    Different way of removing the alpha channel (contained in load_mask)
+    Deleted download_train_weights
+    A little refactoring made
+import os
+import random
+import numpy as np
+import scipy
+import skimage.color
+import skimage.io
+import skimage.transform
+import urllib.request
+import glob
+import warnings
+# URL from which to download the latest COCO trained weights
+# https://github.com/matterport/Mask_RCNN/releases/download/v2.0/mask_rcnn_coco.h5
+#  Bounding Boxes
+def extract_bboxes(mask):
+    """Compute bounding boxes from masks.
+    mask: [height, width, num_instances]. Mask pixels are either 1 or 0.
+    Returns: bbox array [num_instances, (y1, x1, y2, x2)].
+    boxes = np.zeros([mask.shape[-1], 4], dtype=np.int32)
+    for i in range(mask.shape[-1]):
+        m = mask[:, :, i]
+        # Bounding box.
+        horizontal_indicies = np.where(np.any(m, axis=0))[0]
+        vertical_indicies = np.where(np.any(m, axis=1))[0]
+        if horizontal_indicies.shape[0]:
+            x1, x2 = horizontal_indicies[[0, -1]]
+            y1, y2 = vertical_indicies[[0, -1]]
+            # x2 and y2 should not be part of the box. Increment by 1.
+            x2 += 1
+            y2 += 1
+        else:
+            # No mask for this instance. Might happen due to
+            # resizing or cropping. Set bbox to zeros
+            x1, x2, y1, y2 = 0, 0, 0, 0
+        boxes[i] = np.array([y1, x1, y2, x2])
+    return boxes.astype(np.int32)
+def compute_iou(box, boxes, box_area, boxes_area):
+    """Calculates IoU of the given box with the array of the given boxes.
+    box: 1D vector [y1, x1, y2, x2]
+    boxes: [boxes_count, (y1, x1, y2, x2)]
+    box_area: float. the area of 'box'
+    boxes_area: array of length boxes_count.
+    Note: the areas are passed in rather than calculated here for
+          efficency. Calculate once in the caller to avoid duplicate work.
+    # Calculate intersection areas
+    y1 = np.maximum(box[0], boxes[:, 0])
+    y2 = np.minimum(box[2], boxes[:, 2])
+    x1 = np.maximum(box[1], boxes[:, 1])
+    x2 = np.minimum(box[3], boxes[:, 3])
+    intersection = np.maximum(x2 - x1, 0) * np.maximum(y2 - y1, 0)
+    union = box_area + boxes_area[:] - intersection[:]
+    iou = intersection / union
+    return iou
+def compute_overlaps(boxes1, boxes2):
+    """Computes IoU overlaps between two sets of boxes.
+    boxes1, boxes2: [N, (y1, x1, y2, x2)].
+    For better performance, pass the largest set first and the smaller second.
+    # Areas of anchors and GT boxes
+    area1 = (boxes1[:, 2] - boxes1[:, 0]) * (boxes1[:, 3] - boxes1[:, 1])
+    area2 = (boxes2[:, 2] - boxes2[:, 0]) * (boxes2[:, 3] - boxes2[:, 1])
+    # Compute overlaps to generate matrix [boxes1 count, boxes2 count]
+    # Each cell contains the IoU value.
+    overlaps = np.zeros((boxes1.shape[0], boxes2.shape[0]))
+        box2 = boxes2[i]
+        overlaps[:, i] = compute_iou(box2, boxes1, area2[i], area1)
+    return overlaps
+def compute_overlaps_masks(masks1, masks2):
+    '''Computes IoU overlaps between two sets of masks.
+    masks1, masks2: [Height, Width, instances]
+    # flatten masks
+    masks1 = np.reshape(masks1 > .5, (-1, masks1.shape[-1])).astype(np.float32)
+    masks2 = np.reshape(masks2 > .5, (-1, masks2.shape[-1])).astype(np.float32)
+    area1 = np.sum(masks1, axis=0)
+    area2 = np.sum(masks2, axis=0)
+    # intersections and union
+    intersections = np.dot(masks1.T, masks2)
+    union = area1[:, None] + area2[None, :] - intersections
+    overlaps = intersections / union
+    return overlaps
+def non_max_suppression(boxes, scores, threshold):
+    """Performs non-maximum supression and returns indicies of kept boxes.
+    boxes: [N, (y1, x1, y2, x2)]. Notice that (y2, x2) lays outside the box.
+    scores: 1-D array of box scores.
+    threshold: Float. IoU threshold to use for filtering.
+    assert boxes.shape[0] > 0
+    if boxes.dtype.kind != "f":
+        boxes = boxes.astype(np.float32)
+    # Compute box areas
+    y1 = boxes[:, 0]
+    x1 = boxes[:, 1]
+    y2 = boxes[:, 2]
+    x2 = boxes[:, 3]
+    area = (y2 - y1) * (x2 - x1)
+    # Get indicies of boxes sorted by scores (highest first)
+    ixs = scores.argsort()[::-1]
+    pick = []
+    while len(ixs) > 0:
+        # Pick top box and add its index to the list
+        i = ixs[0]
+        pick.append(i)
+        # Compute IoU of the picked box with the rest
+        iou = compute_iou(boxes[i], boxes[ixs[1:]], area[i], area[ixs[1:]])
+        # Identify boxes with IoU over the threshold. This
+        # returns indicies into ixs[1:], so add 1 to get
+        # indicies into ixs.
+        remove_ixs = np.where(iou > threshold)[0] + 1
+        # Remove indicies of the picked and overlapped boxes.
+        ixs = np.delete(ixs, remove_ixs)
+        ixs = np.delete(ixs, 0)
+    return np.array(pick, dtype=np.int32)
+def apply_box_deltas(boxes, deltas):
+    """Applies the given deltas to the given boxes.
+    boxes: [N, (y1, x1, y2, x2)]. Note that (y2, x2) is outside the box.
+    deltas: [N, (dy, dx, log(dh), log(dw))]
+    # Convert to y, x, h, w
+    height = boxes[:, 2] - boxes[:, 0]
+    width = boxes[:, 3] - boxes[:, 1]
+    center_y = boxes[:, 0] + 0.5 * height
+    center_x = boxes[:, 1] + 0.5 * width
+    # Apply deltas
+    center_y += deltas[:, 0] * height
+    center_x += deltas[:, 1] * width
+    height *= np.exp(deltas[:, 2])
+    width *= np.exp(deltas[:, 3])
+    # Convert back to y1, x1, y2, x2
+    y1 = center_y - 0.5 * height
+    x1 = center_x - 0.5 * width
+    y2 = y1 + height
+    x2 = x1 + width
+    return np.stack([y1, x1, y2, x2], axis=1)
+def box_refinement_graph(box, gt_box):
+    """Compute refinement needed to transform box to gt_box.
+    box and gt_box are [N, (y1, x1, y2, x2)]
+    box = tf.cast(box, tf.float32)
+    gt_box = tf.cast(gt_box, tf.float32)
+    height = box[:, 2] - box[:, 0]
+    width = box[:, 3] - box[:, 1]
+    center_y = box[:, 0] + 0.5 * height
+    center_x = box[:, 1] + 0.5 * width
+    gt_height = gt_box[:, 2] - gt_box[:, 0]
+    gt_width = gt_box[:, 3] - gt_box[:, 1]
+    gt_center_y = gt_box[:, 0] + 0.5 * gt_height
+    gt_center_x = gt_box[:, 1] + 0.5 * gt_width
+    dy = (gt_center_y - center_y) / height
+    dx = (gt_center_x - center_x) / width
+    dh = tf.log(gt_height / height)
+    dw = tf.log(gt_width / width)
+    result = tf.stack([dy, dx, dh, dw], axis=1)
+    return result
+def box_refinement(box, gt_box):
+    box and gt_box are [N, (y1, x1, y2, x2)]. (y2, x2) is
+    assumed to be outside the box.
+    box = box.astype(np.float32)
+    gt_box = gt_box.astype(np.float32)
+    dh = np.log(gt_height / height)
+    dw = np.log(gt_width / width)
+    return np.stack([dy, dx, dh, dw], axis=1)
+#  Dataset
+class Dataset(object):
+    The base class for dataset classes.
+    def __init__(self, class_map=None):
+        self._image_ids = []
+        self.image_info = []
+        # Background is always the first class
+        self.class_info = [{"source": "", "id": 0, "name": "BG"}]
+        self.source_class_ids = {}
+    def add_class(self, source, class_id, class_name):
+        assert "." not in source, "Source name cannot contain a dot"
+        # Does the class exist already?
+        for info in self.class_info:
+            if info['source'] == source and info["id"] == class_id:
+                # source.class_id combination already available, skip
+                return
+        # Add the class
+        self.class_info.append({
+            "source": source,
+            "id": class_id,
+            "name": class_name,
+    def add_image(self, source, image_id, path, **kwargs):
+        image_info = {
+            "id": image_id,
+            "source": source,
+            "path": path,
+        image_info.update(kwargs)
+        self.image_info.append(image_info)
+    def image_reference(self, image_id):
+        """Return a link to the image in its source Website or details about
+        the image that help looking it up or debugging it.
+        Override for your dataset, but pass to this function
+        if you encounter images not in your dataset.
+        return ""
+    def prepare(self, class_map=None):
+        """Prepares the Dataset class for use.
+        TODO: class map is not supported yet. When done, it should handle mapping
+              classes from different datasets to the same class ID.
+        def clean_name(name):
+            """Returns a shorter version of object names for cleaner display."""
+            return ",".join(name.split(",")[:1])
+        # Build (or rebuild) everything else from the info dicts.
+        self.num_classes = len(self.class_info)
+        self.class_ids = np.arange(self.num_classes)
+        self.class_names = [clean_name(c["name"]) for c in self.class_info]
+        self.num_images = len(self.image_info)
+        self._image_ids = np.arange(self.num_images)
+        # Mapping from source class and image IDs to internal IDs
+        self.class_from_source_map = {"{}.{}".format(info['source'], info['id']): id
+                                      for info, id in zip(self.class_info, self.class_ids)}
+        self.image_from_source_map = {"{}.{}".format(info['source'], info['id']): id
+                                      for info, id in zip(self.image_info, self.image_ids)}
+        # Map sources to class_ids they support
+        self.sources = list(set([i['source'] for i in self.class_info]))
+        # Loop over datasets
+        for source in self.sources:
+            self.source_class_ids[source] = []
+            # Find classes that belong to this dataset
+            for i, info in enumerate(self.class_info):
+                # Include BG class in all datasets
+                if i == 0 or source == info['source']:
+                    self.source_class_ids[source].append(i)
+    def map_source_class_id(self, source_class_id):
+        Takes a source class ID and returns the int class ID assigned to it.
+        For example:
+        dataset.map_source_class_id("coco.12") -> 23
+        return self.class_from_source_map[source_class_id]
+    def get_source_class_id(self, class_id, source):
+        Map an internal class ID to the corresponding class ID in the source
+        dataset.
+        info = self.class_info[class_id]
+        assert info['source'] == source
+        return info['id']
+    def append_data(self, class_info, image_info):
+        self.external_to_class_id = {}
+        for i, c in enumerate(self.class_info):
+            for ds, id in c["map"]:
+                self.external_to_class_id[ds + str(id)] = i
+        # Map external image IDs to internal ones.
+        self.external_to_image_id = {}
+        for i, info in enumerate(self.image_info):
+            self.external_to_image_id[info["ds"] + str(info["id"])] = i
+    @property
+    def image_ids(self):
+        return self._image_ids
+    def source_image_link(self, image_id):
+        """Returns the path or URL to the image.
+        Override this to return a URL to the image if it's availble online for
+        easy debugging.
+        return self.image_info[image_id]["path"]
+    def load_image(self, image_id):
+        Load the specified image and return a [H,W,3] Numpy array.
+        Modified by Ondrej Pesek to not care about alpha channel
+        # Load image
+        image = skimage.io.imread(self.image_info[image_id]['path'])
+        # If grayscale. Convert to RGB for consistency.
+        if image.ndim != 3:
+            image = skimage.color.gray2rgb(image)
+        return image
+    def import_contents(self, classes, directories, modelName):
+        Initialize an empty Dataset class with classes and images
+        :param classes: List of classes names
+        :param directories: List of directories containing training images
+        :param modelName: Name of model
+        Written by Ondrej Pesek
+        self.classes = {'BG': 0}
+        for i in range(1, len(classes) + 1):
+            self.add_class(modelName, i, classes[i - 1])
+            self.classes.update({classes[i - 1]: i})
+        for directory in directories:
+            # TODO: Other types than jpg
+            for image in glob.iglob(os.path.join(directory, '*.jpg')):
+                # TODO: Smarter image_id than name of directory
+                self.add_image(modelName,
+                               image_id=os.path.split(directory)[1],
+                               path=image)
+    def get_mask(self, image_id):
+        Load instance masks for the given image.
+        This function converts the different mask format to one format in the
+        form of an array of binary masks of shape [height, width, instances].
+        Returns:
+        masks: A bool array of shape [height, width, instance count] with
+            a binary mask per instance.
+        class_ids: a 1D array of class IDs of the instance masks.
+        info = self.image_info[image_id]
+        # TODO: drop self.classes and use self.class_info
+        a = glob.glob(os.path.join(os.path.split(info['path'])[0], '*.png'))
+        try:
+            loadedImage = skimage.io.imread(a[0])
+            if len(np.shape(loadedImage)) == 2:
+                maskImage = loadedImage
+            else:
+                maskImage = loadedImage[:, :, 0]
+        except:
+            return None, None, 1
+        mask = np.zeros([maskImage.shape[0], maskImage.shape[1], 1])
+        # TODO: Take a look to resizing in square, etc. modes
+        maskAppend = np.zeros([maskImage.shape[0], maskImage.shape[1], 1])
+        class_ids = np.array([self.classes[a[0].split('-')[-2]]])
+        mask[:, :, 0] = maskImage.astype(np.bool)
+        for i in range(1, len(a)):
+            np.append(class_ids, self.classes[a[i].split('-')[-2]])
+            try:
+                    maskAppend[:, :, 0] = loadedImage.astype(np.bool)
+                else:
+                    maskAppend[:, :, 0] = loadedImage[:, :, 0].astype(np.bool)
+            except:
+            np.concatenate((mask, maskAppend), 2)
+        return mask, class_ids, 0
+def resize_image(image, min_dim=None, max_dim=None, min_scale=None,
+                 mode="square"):
+    Resizes an image keeping the aspect ratio unchanged.
+    min_dim: if provided, resizes the image such that it's smaller
+        dimension == min_dim
+    max_dim: if provided, ensures that the image longest side doesn't
+        exceed this value.
+    min_scale: if provided, ensure that the image is scaled up by at least
+        this percent even if min_dim doesn't require it.
+    mode: Resizing mode.
+        none: No resizing. Return the image unchanged.
+        square: Resize and pad with zeros to get a square image
+            of size [max_dim, max_dim].
+        pad64: Pads width and height with zeros to make them multiples of 64.
+               If min_dim or min_scale are provided, it scales the image up
+               before padding. max_dim is ignored in this mode.
+               The multiple of 64 is needed to ensure smooth scaling of feature
+               maps up and down the 6 levels of the FPN pyramid (2**6=64).
+        crop: Picks random crops from the image. First, scales the image based
+              on min_dim and min_scale, then picks a random crop of
+              size min_dim x min_dim. Can be used in training only.
+              max_dim is not used in this mode.
+    Returns:
+    image: the resized image
+    window: (y1, x1, y2, x2). If max_dim is provided, padding might
+        be inserted in the returned image. If so, this window is the
+        coordinates of the image part of the full image (excluding
+        the padding). The x2, y2 pixels are not included.
+    scale: The scale factor used to resize the image
+    padding: Padding added to the image [(top, bottom), (left, right), (0, 0)]
+    # Keep track of image dtype and return results in the same dtype
+    image_dtype = image.dtype
+    # Default window (y1, x1, y2, x2) and default scale == 1.
+    h, w = image.shape[:2]
+    window = (0, 0, h, w)
+    scale = 1
+    padding = [(0, 0), (0, 0), (0, 0)]
+    crop = None
+    if mode == "none":
+        return image, window, scale, padding, crop
+    # Scale?
+    if min_dim:
+        # Scale up but not down
+        scale = max(1, min_dim / min(h, w))
+    if min_scale and scale < min_scale:
+        scale = min_scale
+    # Does it exceed max dim?
+    if max_dim and mode == "square":
+        image_max = max(h, w)
+        if round(image_max * scale) > max_dim:
+            scale = max_dim / image_max
+    # Resize image using bilinear interpolation
+    if scale != 1:
+        image = skimage.transform.resize(
+            image, (round(h * scale), round(w * scale)),
+            order=1, mode="constant", preserve_range=True)
+    # Need padding or cropping?
+    if mode == "square":
+        # Get new height and width
+        top_pad = (max_dim - h) // 2
+        bottom_pad = max_dim - h - top_pad
+        left_pad = (max_dim - w) // 2
+        right_pad = max_dim - w - left_pad
+        padding = [(top_pad, bottom_pad), (left_pad, right_pad), (0, 0)]
+        image = np.pad(image, padding, mode='constant', constant_values=0)
+        window = (top_pad, left_pad, h + top_pad, w + left_pad)
+    elif mode == "pad64":
+        # Both sides must be divisible by 64
+        assert min_dim % 64 == 0, "Minimum dimension must be a multiple of 64"
+        # Height
+        if h % 64 > 0:
+            max_h = h - (h % 64) + 64
+            top_pad = (max_h - h) // 2
+            bottom_pad = max_h - h - top_pad
+        else:
+            top_pad = bottom_pad = 0
+        # Width
+        if w % 64 > 0:
+            max_w = w - (w % 64) + 64
+            left_pad = (max_w - w) // 2
+            right_pad = max_w - w - left_pad
+        else:
+            left_pad = right_pad = 0
+    elif mode == "crop":
+        # Pick a random crop
+        y = random.randint(0, (h - min_dim))
+        x = random.randint(0, (w - min_dim))
+        crop = (y, x, min_dim, min_dim)
+        image = image[y:y + min_dim, x:x + min_dim]
+        window = (0, 0, min_dim, min_dim)
+    else:
+        raise Exception("Mode {} not supported".format(mode))
+    return image.astype(image_dtype), window, scale, padding, crop
+def resize_mask(mask, scale, padding, crop=None):
+    """Resizes a mask using the given scale and padding.
+    Typically, you get the scale and padding from resize_image() to
+    ensure both, the image and the mask, are resized consistently.
+    scale: mask scaling factor
+    padding: Padding to add to the mask in the form
+            [(top, bottom), (left, right), (0, 0)]
+    # Suppress warning from scipy 0.13.0, the output shape of zoom() is
+    # calculated with round() instead of int()
+    with warnings.catch_warnings():
+        warnings.simplefilter("ignore")
+        mask = scipy.ndimage.zoom(mask, zoom=[scale, scale, 1], order=0)
+    if crop is not None:
+        y, x, h, w = crop
+        mask = mask[y:y + h, x:x + w]
+    else:
+        mask = np.pad(mask, padding, mode='constant', constant_values=0)
+    return mask
+def minimize_mask(bbox, mask, mini_shape):
+    """Resize masks to a smaller version to reduce memory load.
+    Mini-masks can be resized back to image scale using expand_masks()
+    See inspect_data.ipynb notebook for more details.
+    mini_mask = np.zeros(mini_shape + (mask.shape[-1],), dtype=bool)
+        # Pick slice and cast to bool in case load_mask() returned wrong dtype
+        m = mask[:, :, i].astype(bool)
+        y1, x1, y2, x2 = bbox[i][:4]
+        m = m[y1:y2, x1:x2]
+        if m.size == 0:
+            raise Exception("Invalid bounding box with area of zero")
+        # Resize with bilinear interpolation
+        m = skimage.transform.resize(m, mini_shape, order=1, mode="constant")
+        mini_mask[:, :, i] = np.around(m).astype(np.bool)
+    return mini_mask
+def expand_mask(bbox, mini_mask, image_shape):
+    """Resizes mini masks back to image size. Reverses the change
+    of minimize_mask().
+    mask = np.zeros(image_shape[:2] + (mini_mask.shape[-1],), dtype=bool)
+        m = mini_mask[:, :, i]
+        h = y2 - y1
+        w = x2 - x1
+        m = skimage.transform.resize(m, (h, w), order=1, mode="constant")
+        mask[y1:y2, x1:x2, i] = np.around(m).astype(np.bool)
+    return mask
+# TODO: Build and use this function to reduce code duplication
+def mold_mask(mask, config):
+    pass
+def unmold_mask(mask, bbox, image_shape):
+    """Converts a mask generated by the neural network to a format similar
+    to its original shape.
+    mask: [height, width] of type float. A small, typically 28x28 mask.
+    bbox: [y1, x1, y2, x2]. The box to fit the mask in.
+    Returns a binary mask with the same size as the original image.
+    threshold = 0.5
+    mask = skimage.transform.resize(mask, (y2 - y1, x2 - x1), order=1,
+                                    mode="constant")
+    mask = np.where(mask >= threshold, 1, 0).astype(np.bool)
+    # Put the mask in the right location.
+    full_mask = np.zeros(image_shape[:2], dtype=np.bool)
+    full_mask[y1:y2, x1:x2] = mask
+    return full_mask
+#  Anchors
+def generate_anchors(scales, ratios, shape, feature_stride, anchor_stride):
+    scales: 1D array of anchor sizes in pixels. Example: [32, 64, 128]
+    ratios: 1D array of anchor ratios of width/height. Example: [0.5, 1, 2]
+    shape: [height, width] spatial shape of the feature map over which
+            to generate anchors.
+    feature_stride: Stride of the feature map relative to the image in pixels.
+    anchor_stride: Stride of anchors on the feature map. For example, if the
+        value is 2 then generate anchors for every other feature map pixel.
+    # Get all combinations of scales and ratios
+    scales, ratios = np.meshgrid(np.array(scales), np.array(ratios))
+    scales = scales.flatten()
+    ratios = ratios.flatten()
+    # Enumerate heights and widths from scales and ratios
+    heights = scales / np.sqrt(ratios)
+    widths = scales * np.sqrt(ratios)
+    # Enumerate shifts in feature space
+    shifts_y = np.arange(0, shape[0], anchor_stride) * feature_stride
+    shifts_x = np.arange(0, shape[1], anchor_stride) * feature_stride
+    shifts_x, shifts_y = np.meshgrid(shifts_x, shifts_y)
+    # Enumerate combinations of shifts, widths, and heights
+    box_widths, box_centers_x = np.meshgrid(widths, shifts_x)
+    box_heights, box_centers_y = np.meshgrid(heights, shifts_y)
+    # Reshape to get a list of (y, x) and a list of (h, w)
+    box_centers = np.stack(
+        [box_centers_y, box_centers_x], axis=2).reshape([-1, 2])
+    box_sizes = np.stack([box_heights, box_widths], axis=2).reshape([-1, 2])
+    # Convert to corner coordinates (y1, x1, y2, x2)
+    boxes = np.concatenate([box_centers - 0.5 * box_sizes,
+                            box_centers + 0.5 * box_sizes], axis=1)
+    return boxes
+def generate_pyramid_anchors(scales, ratios, feature_shapes, feature_strides,
+                             anchor_stride):
+    """Generate anchors at different levels of a feature pyramid. Each scale
+    is associated with a level of the pyramid, but each ratio is used in
+    all levels of the pyramid.
+    Returns:
+    anchors: [N, (y1, x1, y2, x2)]. All generated anchors in one array. Sorted
+        with the same order of the given scales. So, anchors of scale[0] come
+        first, then anchors of scale[1], and so on.
+    # Anchors
+    # [anchor_count, (y1, x1, y2, x2)]
+    anchors = []
+    for i in range(len(scales)):
+        anchors.append(generate_anchors(scales[i], ratios, feature_shapes[i],
+                                        feature_strides[i], anchor_stride))
+    return np.concatenate(anchors, axis=0)
+#  Miscellaneous
+def trim_zeros(x):
+    """It's common to have tensors larger than the available data and
+    pad with zeros. This function removes rows that are all zeros.
+    x: [rows, columns].
+    assert len(x.shape) == 2
+    return x[~np.all(x == 0, axis=1)]
+def compute_matches(gt_boxes, gt_class_ids, gt_masks,
+                    pred_boxes, pred_class_ids, pred_scores, pred_masks,
+                    iou_threshold=0.5, score_threshold=0.0):
+    """Finds matches between prediction and ground truth instances.
+    Returns:
+        gt_match: 1-D array. For each GT box it has the index of the matched
+                  predicted box.
+        pred_match: 1-D array. For each predicted box, it has the index of
+                    the matched ground truth box.
+        overlaps: [pred_boxes, gt_boxes] IoU overlaps.
+    # Trim zero padding
+    # TODO: cleaner to do zero unpadding upstream
+    gt_boxes = trim_zeros(gt_boxes)
+    gt_masks = gt_masks[..., :gt_boxes.shape[0]]
+    pred_boxes = trim_zeros(pred_boxes)
+    pred_scores = pred_scores[:pred_boxes.shape[0]]
+    # Sort predictions by score from high to low
+    indices = np.argsort(pred_scores)[::-1]
+    pred_boxes = pred_boxes[indices]
+    pred_class_ids = pred_class_ids[indices]
+    pred_scores = pred_scores[indices]
+    pred_masks = pred_masks[..., indices]
+    # Compute IoU overlaps [pred_masks, gt_masks]
+    overlaps = compute_overlaps_masks(pred_masks, gt_masks)
+    # Loop through predictions and find matching ground truth boxes
+    match_count = 0
+    pred_match = -1 * np.ones([pred_boxes.shape[0]])
+    gt_match = -1 * np.ones([gt_boxes.shape[0]])
+    for i in range(len(pred_boxes)):
+        # Find best matching ground truth box
+        # 1. Sort matches by score
+        sorted_ixs = np.argsort(overlaps[i])[::-1]
+        # 2. Remove low scores
+        low_score_idx = np.where(overlaps[i, sorted_ixs] < score_threshold)[0]
+        if low_score_idx.size > 0:
+            sorted_ixs = sorted_ixs[:low_score_idx[0]]
+        # 3. Find the match
+        for j in sorted_ixs:
+            # If ground truth box is already matched, go to next one
+            if gt_match[j] > 0:
+                continue
+            # If we reach IoU smaller than the threshold, end the loop
+            iou = overlaps[i, j]
+            if iou < iou_threshold:
+                break
+            # Do we have a match?
+            if pred_class_ids[i] == gt_class_ids[j]:
+                match_count += 1
+                gt_match[j] = i
+                pred_match[i] = j
+                break
+    return gt_match, pred_match, overlaps
+def compute_ap(gt_boxes, gt_class_ids, gt_masks,
+               iou_threshold=0.5):
+    """Compute Average Precision at a set IoU threshold (default 0.5).
+    Returns:
+    mAP: Mean Average Precision
+    precisions: List of precisions at different class score thresholds.
+    recalls: List of recall values at different class score thresholds.
+    # Get matches and overlaps
+    gt_match, pred_match, overlaps = compute_matches(
+        gt_boxes, gt_class_ids, gt_masks,
+        iou_threshold)
+    # Compute precision and recall at each prediction box step
+    precisions = np.cumsum(pred_match > -1) / (np.arange(len(pred_match)) + 1)
+    recalls = np.cumsum(pred_match > -1).astype(np.float32) / len(gt_match)
+    # Pad with start and end values to simplify the math
+    precisions = np.concatenate([[0], precisions, [0]])
+    recalls = np.concatenate([[0], recalls, [1]])
+    # Ensure precision values decrease but don't increase. This way, the
+    # precision value at each recall threshold is the maximum it can be
+    # for all following recall thresholds, as specified by the VOC paper.
+    for i in range(len(precisions) - 2, -1, -1):
+        precisions[i] = np.maximum(precisions[i], precisions[i + 1])
+    # Compute mean AP over recall range
+    indices = np.where(recalls[:-1] != recalls[1:])[0] + 1
+    mAP = np.sum((recalls[indices] - recalls[indices - 1]) *
+                 precisions[indices])
+    return mAP, precisions, recalls, overlaps
+def compute_ap_range(gt_box, gt_class_id, gt_mask,
+                     pred_box, pred_class_id, pred_score, pred_mask,
+                     iou_thresholds=None, verbose=1):
+    """Compute AP over a range or IoU thresholds. Default range is 0.5-0.95."""
+    # Default is 0.5 to 0.95 with increments of 0.05
+    iou_thresholds = iou_thresholds or np.arange(0.5, 1.0, 0.05)
+    # Compute AP over range of IoU thresholds
+    AP = []
+    for iou_threshold in iou_thresholds:
+        ap, precisions, recalls, overlaps =\
+            compute_ap(gt_box, gt_class_id, gt_mask,
+                        iou_threshold=iou_threshold)
+        if verbose:
+            print("AP @{:.2f}:\t {:.3f}".format(iou_threshold, ap))
+        AP.append(ap)
+    AP = np.array(AP).mean()
+    if verbose:
+        print("AP @{:.2f}-{:.2f}:\t {:.3f}".format(
+            iou_thresholds[0], iou_thresholds[-1], AP))
+    return AP
+def compute_recall(pred_boxes, gt_boxes, iou):
+    """Compute the recall at the given IoU threshold. It's an indication
+    of how many GT boxes were found by the given prediction boxes.
+    pred_boxes: [N, (y1, x1, y2, x2)] in image coordinates
+    gt_boxes: [N, (y1, x1, y2, x2)] in image coordinates
+    # Measure overlaps
+    overlaps = compute_overlaps(pred_boxes, gt_boxes)
+    iou_max = np.max(overlaps, axis=1)
+    iou_argmax = np.argmax(overlaps, axis=1)
+    positive_ids = np.where(iou_max >= iou)[0]
+    matched_gt_boxes = iou_argmax[positive_ids]
+    recall = len(set(matched_gt_boxes)) / gt_boxes.shape[0]
+    return recall, positive_ids
+# ## Batch Slicing
+# Some custom layers support a batch size of 1 only, and require a lot of work
+# to support batches greater than 1. This function slices an input tensor
+# across the batch dimension and feeds batches of size 1. Effectively,
+# an easy way to support batches > 1 quickly with little code modification.
+# In the long run, it's more efficient to modify the code to support large
+# batches and getting rid of this function. Consider this a temporary solution
+def batch_slice(inputs, graph_fn, batch_size, names=None):
+    """Splits inputs into slices and feeds each slice to a copy of the given
+    computation graph and then combines the results. It allows you to run a
+    graph on a batch of inputs even if the graph is written to support one
+    instance only.
+    inputs: list of tensors. All must have the same first dimension length
+    graph_fn: A function that returns a TF tensor that's part of a graph.
+    batch_size: number of slices to divide the data into.
+    names: If provided, assigns names to the resulting tensors.
+    if not isinstance(inputs, list):
+        inputs = [inputs]
+    outputs = []
+    for i in range(batch_size):
+        inputs_slice = [x[i] for x in inputs]
+        output_slice = graph_fn(*inputs_slice)
+        if not isinstance(output_slice, (tuple, list)):
+            output_slice = [output_slice]
+        outputs.append(output_slice)
+    # Change outputs from a list of slices where each is
+    # a list of outputs to a list of outputs and each has
+    # a list of slices
+    outputs = list(zip(*outputs))
+    if names is None:
+        names = [None] * len(outputs)
+    result = [tf.stack(o, axis=0, name=n)
+              for o, n in zip(outputs, names)]
+    if len(result) == 1:
+        result = result[0]
+    return result
+def norm_boxes(boxes, shape):
+    boxes: [N, (y1, x1, y2, x2)] in pixel coordinates
+    Returns:
+        [N, (y1, x1, y2, x2)] in normalized coordinates
+    h, w = shape
+    scale = np.array([h - 1, w - 1, h - 1, w - 1])
+    shift = np.array([0, 0, 1, 1])
+    return np.divide((boxes - shift), scale).astype(np.float32)
+def denorm_boxes(boxes, shape):
+    boxes: [N, (y1, x1, y2, x2)] in normalized coordinates
+    Returns:
+        [N, (y1, x1, y2, x2)] in pixel coordinates
+    h, w = shape
+    return np.around(np.multiply(boxes, scale) + shift).astype(np.int32)
