[GRASS-SVN] r72739 - grass/trunk/lib/python/script
svn_grass at osgeo.org
Fri May 25 18:22:39 PDT 2018
Author: lucadelu
Date: 2018-05-25 18:22:38 -0700 (Fri, 25 May 2018)
New Revision: 72739
grass/trunk/lib/python/script/array.py
array.py: added quiet option to write function, thanks to Ond?\197?\153ej Pe?\197?\161ek
Modified: grass/trunk/lib/python/script/array.py
--- grass/trunk/lib/python/script/array.py 2018-05-26 00:49:41 UTC (rev 72738)
+++ grass/trunk/lib/python/script/array.py 2018-05-26 01:22:38 UTC (rev 72739)
@@ -224,7 +224,7 @@
else:
return 0
- def write(self, mapname, title=None, null=None, overwrite=None):
+ def write(self, mapname, title=None, null=None, overwrite=None, quiet=None):
"""Write array into raster map
:param str mapname: name for raster map
@@ -265,6 +265,7 @@
bytes=size,
anull=null,
overwrite=overwrite,
+ quiet=quiet,
north=reg['n'],
south=reg['s'],
east=reg['e'],
@@ -373,7 +374,7 @@
else:
return 0
- def write(self, mapname, null=None, overwrite=None):
+ def write(self, mapname, null=None, overwrite=None, quiet=None):
"""Write array into 3D raster map
:param str mapname: name for 3D raster map
@@ -408,6 +409,7 @@
bytes=size,
null=null,
+ quiet=quiet,
north=reg['n'],
south=reg['s'],
top=reg['t'],
