[GRASS-SVN] r73636 - grass/branches/releasebranch_7_6/vector/v.patch
svn_grass at osgeo.org
Thu Nov 1 00:54:26 PDT 2018
Author: mmetz
Date: 2018-11-01 00:54:25 -0700 (Thu, 01 Nov 2018)
New Revision: 73636
grass/branches/releasebranch_7_6/vector/v.patch/v.patch.html
v.patch: update manual (backport trunk r73635)
Modified: grass/branches/releasebranch_7_6/vector/v.patch/v.patch.html
--- grass/branches/releasebranch_7_6/vector/v.patch/v.patch.html 2018-11-01 07:53:55 UTC (rev 73635)
+++ grass/branches/releasebranch_7_6/vector/v.patch/v.patch.html 2018-11-01 07:54:25 UTC (rev 73636)
@@ -12,16 +12,25 @@
edited or removed after <em>v.patch</em> is run. Such
editing can be done automatically using
<em><a href="v.clean.html">v.clean</a></em>.
-<p>Lines may need to be
-snapped with <em><a href="v.clean.html">v.clean</a>
-tool=snap,break,rmdupl</em>.
-<p>Boundaries may need to be cleaned with
+<p>
+Lines may need to be snapped with <em><a
+href="v.clean.html">v.clean</a> tool=snap,break,rmdupl</em>.
+<p>
+Boundaries may need to be cleaned with
<em><a href="v.clean.html">v.clean</a> tool=break,rmdupl,rmsa</em>
repeatedly until the <em>rmsa</em> tool (Remove small angles at nodes)
no longer modifies any boundaries. If vector topology is still not
clean, boundaries may also need to be snapped with
<em><a href="v.clean.html">v.clean</a> tool=snap,break,rmdupl</em>.
-<p>When using the <em>-a</em> flag, the user has to make sure that the
+<p>
+When using the <em>-e</em> flag, <em>v.patch</em> shifts category (cat)
+values in the output so that category numbers from the different input
+maps do not overlap. This shift is applied to both the category values
+of the features and the category values in the attribute tables. Hence,
+there is no need to run <em><a href="v.category.html">v.category</a></em>
+and <em><a href="v.db.update.html">v.db.update</a></em> beforehand.
+<p>
+When using the <em>-a</em> flag, the user has to make sure that the
features in the different maps added to the output map do not have
overlapping category numbers, unless identical category numbers
reflect identical attributes, otherwise the attributes of the added
