[GRASS-SVN] r73652 - grass/trunk/vector/v.select
svn_grass at osgeo.org
Wed Nov 7 07:35:47 PST 2018
Author: mlennert
Date: 2018-11-07 07:35:46 -0800 (Wed, 07 Nov 2018)
New Revision: 73652
grass/trunk/vector/v.select/main.c
v.select: Output map should only be created if any elements are found
Modified: grass/trunk/vector/v.select/main.c
--- grass/trunk/vector/v.select/main.c 2018-11-06 17:07:20 UTC (rev 73651)
+++ grass/trunk/vector/v.select/main.c 2018-11-07 15:35:46 UTC (rev 73652)
@@ -118,17 +118,6 @@
/* Read field info */
IFi = Vect_get_field(&(In[0]), ifield[0]);
- /* Open output */
- if (Vect_open_new(&Out, parm.output->answer, Vect_is_3d(&(In[0]))) < 0)
- G_fatal_error(_("Unable to create vector map <%s>"),
- parm.output->answer);
- Vect_set_map_name(&Out, _("Output from v.select"));
- Vect_set_person(&Out, G_whoami());
- Vect_copy_head_data(&(In[0]), &Out);
- Vect_hist_copy(&(In[0]), &Out);
- Vect_hist_command(&Out);
/* Select features */
#ifdef HAVE_GEOS
nfound = select_lines(&(In[0]), itype[0], ifield[0],
@@ -155,7 +144,17 @@
if (nfound != 0) {
+ /* Open output */
+ if (Vect_open_new(&Out, parm.output->answer, Vect_is_3d(&(In[0]))) < 0)
+ G_fatal_error(_("Unable to create vector map <%s>"),
+ parm.output->answer);
+ Vect_set_map_name(&Out, _("Output from v.select"));
+ Vect_set_person(&Out, G_whoami());
+ Vect_copy_head_data(&(In[0]), &Out);
+ Vect_hist_copy(&(In[0]), &Out);
+ Vect_hist_command(&Out);
native = Vect_maptype(&Out) == GV_FORMAT_NATIVE;
nfields = Vect_cidx_get_num_fields(&(In[0]));
