[GRASS-SVN] r73669 - grass/branches/releasebranch_7_6/vector/v.generalize
svn_grass at osgeo.org
Tue Nov 13 06:53:29 PST 2018
Author: mmetz
Date: 2018-11-13 06:53:29 -0800 (Tue, 13 Nov 2018)
New Revision: 73669
grass/branches/releasebranch_7_6/vector/v.generalize/main.c
v.generalize: preserve boundary categories (backport trunk r73668)
Modified: grass/branches/releasebranch_7_6/vector/v.generalize/main.c
--- grass/branches/releasebranch_7_6/vector/v.generalize/main.c 2018-11-13 14:52:37 UTC (rev 73668)
+++ grass/branches/releasebranch_7_6/vector/v.generalize/main.c 2018-11-13 14:53:29 UTC (rev 73669)
@@ -44,7 +44,7 @@
struct Map_info In, Out, Error;
struct line_pnts *Points;
- struct line_cats *Cats;
+ struct line_cats *Cats, *ACats;
int i, type, iter;
struct GModule *module; /* GRASS module for parsing arguments */
struct Option *map_in, *map_out, *error_out, *thresh_opt, *method_opt,
@@ -317,6 +317,7 @@
Points = Vect_new_line_struct();
Cats = Vect_new_cats_struct();
+ ACats = Vect_new_cats_struct();
Vect_check_input_output_name(map_in->answer, map_out->answer,
G_FATAL_EXIT);
@@ -438,13 +439,13 @@
right = Vect_get_isle_area(&Out, abs(right));
if (left > 0) {
- Vect_get_area_cats(&Out, left, Cats);
- do_line = Vect_cats_in_constraint(Cats, layer, cat_list);
+ Vect_get_area_cats(&Out, left, ACats);
+ do_line = Vect_cats_in_constraint(ACats, layer, cat_list);
if (!do_line && right > 0) {
- Vect_get_area_cats(&Out, right, Cats);
+ Vect_get_area_cats(&Out, right, ACats);
if (!do_line)
